[GRASS-SVN] r52354 - grass-addons/grass7/imagery/i.segment
Mon Jul 9 08:42:51 PDT 2012
Author: momsen
Date: 2012-07-09 08:42:50 -0700 (Mon, 09 Jul 2012)
New Revision: 52354
   grass-addons/grass7/imagery/i.segment/create_isegs.c
   grass-addons/grass7/imagery/i.segment/iseg.h
   grass-addons/grass7/imagery/i.segment/times.txt
changed the find neighbor no_check flag from raster wide array to a tree. (with ifdef DEBUG commented out)
Modified: grass-addons/grass7/imagery/i.segment/create_isegs.c
--- grass-addons/grass7/imagery/i.segment/create_isegs.c	2012-07-09 12:30:15 UTC (rev 52353)
+++ grass-addons/grass7/imagery/i.segment/create_isegs.c	2012-07-09 15:42:50 UTC (rev 52354)
@@ -45,18 +45,19 @@
     for (files->current_bound = lower_bound; files->current_bound <= upper_bound; files->current_bound++) {	/* outer processing loop for polygon constraints */
 	G_debug(1, "current_bound = %d", files->current_bound);
-	if (functions->method == 0)
-	    successflag = io_debug(files, functions);	/* TODO: why does it want `&files` in main, but `files` here ??? */
-	else if (functions->method == 1) {
+	if (functions->method == 1) {
 	    G_debug(1, "starting region_growing()");
 	    successflag = region_growing(files, functions);
+	#ifdef DEBUG
+	else if (functions->method == 0)
+	    successflag = io_debug(files, functions);	/* TODO: why does it want `&files` in main, but `files` here ??? */
 	else if (functions->method == 2)
 	    successflag = ll_test(files, functions);
 	else if (functions->method == 3)
 	    successflag = seg_speed_test(files, functions);
+	#endif
     }				/* end outer loop for processing polygons */
     /* clean up? */
@@ -609,18 +610,18 @@
 		files->candidate_count);
 	/*process candidate pixels */
-	G_verbose_message("Pass %d: ", t);
+	G_message("Pass %d: ", t);
 	/*check each pixel, start the processing only if it is a candidate pixel */
 	/* for validation, select one of the two... could make this IFDEF or input parameter */
 	/* reverse order
 #ifdef REVERSE
 	for (row = files->nrows - 1; row >= 0; row--) {
-		G_percent(files->nrows - row, files->nrows, 1);
+		G_percent(files->nrows - row, files->nrows, 5);
 	    for (col = files->ncols - 1; col >= 0; col--) {
 #else
 	for (row = 0; row < files->nrows; row++) {
-		G_percent(row, files->nrows, 1);	/* TODO, can a message be included with G_percent? */
+		G_percent(row, files->nrows, 5);	/* TODO, can a message be included with G_percent? */
 	    for (col = 0; col < files->ncols; col++) {
 #endif
@@ -838,9 +839,9 @@
 		}		/*end if pixel is candidate pixel */
 	    }			/*next column */
 #ifdef REVERSE
 #else
-	    G_percent(row, files->nrows-1, 1);	/* TODO, can a message be included with G_percent? */
+	     G_percent(row, files->nrows-1, 5);	/* TODO, can a message be included with G_percent? */
 #endif
 	    /* TODO, the REVERSE version gets printed on a new line, and isnt' covered.  The else version is. ? */
 	    /* TODO, shows up in CLI, not in GUI */
@@ -1053,7 +1054,7 @@
 	}			/*next column */
     }			/*next row */
 	} /* end if for force merge */
 	else
Modified: grass-addons/grass7/imagery/i.segment/iseg.h
--- grass-addons/grass7/imagery/i.segment/iseg.h	2012-07-09 12:30:15 UTC (rev 52353)
+++ grass-addons/grass7/imagery/i.segment/iseg.h	2012-07-09 15:42:50 UTC (rev 52354)
@@ -16,7 +16,7 @@
 #include <grass/linkm.h>
 #include "flag.h"
-#define DEBUG
+/* #define DEBUG */
 /* pixel stack */
 struct pixels
Modified: grass-addons/grass7/imagery/i.segment/times.txt
--- grass-addons/grass7/imagery/i.segment/times.txt	2012-07-09 12:30:15 UTC (rev 52353)
+++ grass-addons/grass7/imagery/i.segment/times.txt	2012-07-09 15:42:50 UTC (rev 52354)
@@ -1,3 +1,11 @@
+Machine specifications:
+Virtual Machine, 12 cores.  (Only 1 is ever used at a time for i.segment)
+>> is an AMD quadcore at 4GhZ, 32 GB RAM, SSD for OS, SATA 7200rpm with
+>> 4000 MB/sec cached reads for data:
 Segment ID storage - RAM vs SEG and speed access.
 i.segment -w --overwrite --verbose group=landsat_1band at samples output=temp threshold=5 method=seg_time min=1
@@ -57,6 +65,17 @@
 So the processing time is sensitive to the size of the segments.
+Turning "debug" mode off (gets rid of some loops with G_debug statements)
+time i.segment --overwrite --verbose group=landsat_1band at samples output=val threshold=.02 method=region_growing min=1 final_mean=val_mean
+Pass 878:
+real	13m15.149s
 g.region s=222000 e=637000
 cells:      56334
 < 5 minutes
