[GRASS-SVN] r52363 - grass/branches/develbranch_6/lib/vector/Vlib
Wed Jul 11 04:00:32 PDT 2012
Author: neteler
Date: 2012-07-11 04:00:31 -0700 (Wed, 11 Jul 2012)
New Revision: 52363
   grass/branches/develbranch_6/lib/vector/Vlib/cats.c
   grass/branches/develbranch_6/lib/vector/Vlib/line.c
Vlib: dox: note about freeing
Modified: grass/branches/develbranch_6/lib/vector/Vlib/cats.c
--- grass/branches/develbranch_6/lib/vector/Vlib/cats.c	2012-07-11 11:00:09 UTC (rev 52362)
+++ grass/branches/develbranch_6/lib/vector/Vlib/cats.c	2012-07-11 11:00:31 UTC (rev 52363)
@@ -33,6 +33,8 @@
    This structure is used for reading and writing vector cats. The
    library routines handle all memory allocation.
+   To free allocated memory call Vect_destroy_cats_struct().
    \return struct line_cats *
    \return NULL on error
Modified: grass/branches/develbranch_6/lib/vector/Vlib/line.c
--- grass/branches/develbranch_6/lib/vector/Vlib/line.c	2012-07-11 11:00:09 UTC (rev 52362)
+++ grass/branches/develbranch_6/lib/vector/Vlib/line.c	2012-07-11 11:00:31 UTC (rev 52363)
@@ -30,7 +30,7 @@
    This structure is used for reading and writing vector lines and
    polygons.  The library routines handle all memory allocation.  If
    3 lines in memory are needed at the same time, then simply 3
-   line_pnts structures have to be used
+   line_pnts structures have to be used.
    \param void
@@ -43,10 +43,12 @@
    \brief Creates and initializes a struct line_pnts.
-   polygons.  The library routines handle all memory allocation.  If
-   3 lines in memory are needed at the same time, then simply 3
+   polygons.  The library routines handle all memory allocation.  If 3
+   lines in memory are needed at the same time, then simply 3
+  To free allocated memory call Vect_destroy_line_struct().
    \param void
    \return pointer to line_pnts
