[GRASS-SVN] r52440 - grass-addons/grass7/imagery/i.histo.match
Tue Jul 24 03:45:46 PDT 2012
Author: lucadelu
Date: 2012-07-24 03:45:35 -0700 (Tue, 24 Jul 2012)
New Revision: 52440
   grass-addons/grass7/imagery/i.histo.match/i.histo.match.py
improvements on hamish and micheal suggestions
Modified: grass-addons/grass7/imagery/i.histo.match/i.histo.match.py
--- grass-addons/grass7/imagery/i.histo.match/i.histo.match.py	2012-07-24 03:06:56 UTC (rev 52439)
+++ grass-addons/grass7/imagery/i.histo.match/i.histo.match.py	2012-07-24 10:45:35 UTC (rev 52440)
@@ -19,7 +19,8 @@
 #%module
 #% description: Calculate histogram matching of several images.
-#% keywords: raster
+#% keywords: imagery
+#% keywords: histogram matching
 #%end
 #%option G_OPT_R_INPUTS
 #% description: Name of raster maps to analize
@@ -64,10 +65,10 @@
     if dbopt.find('$GISDBASE/$LOCATION_NAME/$MAPSET') == 0:
         dbopt_split = dbopt.split(os.sep)[-1]
         env = grass.gisenv()
-        path = os.path.join(env['GISDBASE'],env['LOCATION_NAME'],env['MAPSET'])
-        dbpath = os.path.join(path,dbopt_split)
+        path = os.path.join(env['GISDBASE'], env['LOCATION_NAME'], env['MAPSET'])
+        dbpath = os.path.join(path, dbopt_split)
     else:
-        if os.access(os.path.dirname(dbopt),os.W_OK):
+        if os.access(os.path.dirname(dbopt), os.W_OK):
             path = os.path.dirname(dbopt)
             dbpath = dbopt
         else:
@@ -87,14 +88,15 @@
         query_create += "integer, cumulative_histogram integer, cdf real)"
         curs.execute(query_create)
         # set the region on the raster
+        grass.use_temp_region()
         grass.run_command('g.region', rast = i)
         # calculate statistics
-        stats_out = grass.pipe_command('r.stats', flags='c', input= i, fs=':')
+        stats_out = grass.pipe_command('r.stats', flags='cin', input= i, fs=':')
         stats =  stats_out.communicate()[0].split('\n')[:-1]
         stats_dict = dict( s.split(':', 1) for s in stats)
-        cdf = 0
+        cdf = 0
         # for each number in the range
-        for n in range(0,max_value):
+        for n in range(0, max_value):
             # try to insert the values otherwise insert 0
             try:
                 val = int(stats_dict[str(n)])
@@ -111,23 +113,23 @@
         # number of pixel is the cdf value
         numPixel = cdf
             # select value for cumulative_histogram for the range number
-            select_ch="SELECT cumulative_histogram FROM t%s WHERE (grey_value=%i)" % (
-                                                            iname, n)
+            select_ch = "SELECT cumulative_histogram FROM t%s WHERE " % iname
+            select_ch += "(grey_value=%i)" % n
             result = curs.execute(select_ch)
             val = result.fetchone()[0]
             # update cdf with new value
             if val != 0 and numPixel != 0:
-                update_cdf = round(float(val) / float(numPixel),6)
-                update_cdf = "UPDATE t%s SET cdf=%s WHERE (grey_value=%i)" % (
-                                                            iname, update_cdf, n)
+                update_cdf = round(float(val) / float(numPixel), 6)
+                update_cdf = "UPDATE t%s SET cdf=%s WHERE (grey_value=%i)" % (n,
+                                                            iname, update_cdf,)
                 curs.execute(update_cdf)
                 db.commit()
     db.commit()
     pixelTot = 0
         numPixel = 0
         # for each image
         for i in images:
@@ -149,7 +151,7 @@
     cHist = 0
         tot = 0
         # for each image
         for i in images:
@@ -165,20 +167,22 @@
         cHist = cHist + int(average)
         # insert new values into average table
         if cHist != 0 and pixelTot != 0:
-            cdf = round(float(cHist) / float(pixelTot),6)
-            insert = "INSERT INTO %s VALUES (%i, %i, %i, %s)" % (table_ave, n, int(average), cHist, cdf)
+            cdf = round(float(cHist) / float(pixelTot), 6)
+            insert = "INSERT INTO %s VALUES (%i, %i, %i, %s)" % (table_ave, n,
+                                                    int(average), cHist, cdf)
             curs.execute(insert)
             db.commit()
     # for each image
     for i in images:
         iname = i.split('@')[0]
         # write average rules file
-        outfile = open(os.path.join(path,'%s.reclass' % iname),'w')
+        outfile = open(grass.tempfile(), 'w')
         new_grey = 0
-            select_min = "SELECT min(abs(a.cdf - b.cdf)) FROM t%s as a," % iname \
-                        + " %s as b WHERE (a.grey_value=%i)" % (table_ave, n)
+            select_min = "SELECT min(abs(a.cdf - b.cdf)) FROM t%s as a," % iname
+            select_min += " %s as b WHERE (a.grey_value=%i)" % (table_ave, n)
             result_min = curs.execute(select_min)
             min_abs = result_min.fetchone()[0]
             select_cdf = "SELECT cdf FROM t%s WHERE grey_value=%i" % (iname, n)
@@ -201,11 +205,13 @@
         result = grass.core.find_file(outname, element = 'cell')
         if result['fullname'] and grass.overwrite():
             grass.run_command('g.remove', rast=outname)
-            grass.run_command('r.reclass', input= i, out = outname, rules = outfile.name)
+            grass.run_command('r.reclass', input= i, out = outname,
+                              rules = outfile.name)
         elif result['fullname'] and not grass.overwrite():
             grass.warning(_("Raster map %s already exists and it will be not overwrite" % i))
         else:
         # remove the rules file
         grass.try_remove(outfile.name)
     db.commit()
