[GRASS-SVN] r51919 - grass-addons/grass7/raster/r.massmov
Fri Jun 1 08:28:54 PDT 2012
Author: maxi
Date: 2012-06-01 08:28:53 -0700 (Fri, 01 Jun 2012)
New Revision: 51919
   grass-addons/grass7/raster/r.massmov/r.massmov.html
minor changes in html
Modified: grass-addons/grass7/raster/r.massmov/r.massmov.html
--- grass-addons/grass7/raster/r.massmov/r.massmov.html	2012-06-01 14:22:34 UTC (rev 51918)
+++ grass-addons/grass7/raster/r.massmov/r.massmov.html	2012-06-01 15:28:53 UTC (rev 51919)
@@ -28,7 +28,6 @@
 <p>The model outputs a series of flux velocity map and deposit depth raster map at different time step according to the setted <i>deltatime</i> parameter; Additionally the module outputs two raster maps representing the maximum thickness and velocity registered during the simulation.
 <h2>NOTES</h2>
 <p>The generation of the model input maps, in case the simulation refer to en existing collapse and pre and post event DTM is available, can be performed taking advantage of the GRASS modules; in
 particular:
 <ul>
@@ -41,12 +40,10 @@
 </ul>
 <h2>DIAGNOSTICS</h2>
 <p>The module has been tested in several cases (see references), but up to now most of the simulations was done using a Voellmy rheology thus other rheology laws should be better investigated.
 <h2>REFERENCES</h2>
 <p>Savage S B and Hutter K 1989 The motion of a finite mass of granular material down a rough
 incline. Journal of Fluid Mechanics 199:177-215
