[GRASS-SVN] r51934 - grass/trunk/gui/wxpython/dbmgr
Sat Jun 2 08:38:05 PDT 2012
Author: martinl
Date: 2012-06-02 08:38:05 -0700 (Sat, 02 Jun 2012)
New Revision: 51934
   grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py
wxGUI/dbmgr: fix getting samples (db_select())
Modified: grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py
--- grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py	2012-06-02 10:50:29 UTC (rev 51933)
+++ grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py	2012-06-02 15:38:05 UTC (rev 51934)
@@ -282,26 +282,22 @@
         self.list_values.Clear()
-        querystring = "SELECT %s FROM %s" % (column, self.tablename)
-        data = grass.db_select(table = self.tablename,
-                               sql = querystring,
+        data = grass.db_select(sql = "SELECT %s FROM %s" % (column, self.tablename),
                                database = self.database,
                                driver = self.driver)
         if not data:
             return
         desc = self.dbInfo.GetTableDesc(self.dbInfo.GetTable(self.layer))[column]
         i = 0
-        for item in sorted(map(desc['ctype'], data)):
-            if justsample and i < 256 or \
-               not justsample:
-                if desc['type'] != 'character':
-                    item = str(item)
-                self.list_values.Append(item)
-            else:
+        for item in sorted(set(map(lambda x: desc['ctype'](x[0]), data))):
+            if justsample and i > 255:
                 break
+            if desc['type'] != 'character':
+                item = str(item)
+            self.list_values.Append(item)
             i += 1
     def OnSampleValues(self, event):
