[GRASS-SVN] r51947 - in grass/trunk/raster: . r.shaded.relief2
Sun Jun 3 04:29:43 PDT 2012
Author: mmetz
Date: 2012-06-03 04:29:43 -0700 (Sun, 03 Jun 2012)
New Revision: 51947
Added:
   grass/trunk/raster/r.shaded.relief2/
   grass/trunk/raster/r.shaded.relief2/main.c
   grass/trunk/raster/r.shaded.relief2/r.shaded.relief2.html
Removed:
   grass/trunk/raster/r.shaded.relief2/r.shaded.relief.html
   grass/trunk/raster/r.shaded.relief2/r.shaded.relief.py
   grass/trunk/raster/r.shaded.relief2/Makefile
r.shaded.relief2: enhanced fast C version of r.shaded.relief
Modified: grass/trunk/raster/r.shaded.relief2/Makefile
--- grass/trunk/scripts/r.shaded.relief/Makefile	2012-06-02 17:12:24 UTC (rev 51942)
+++ grass/trunk/raster/r.shaded.relief2/Makefile	2012-06-03 11:29:43 UTC (rev 51947)
@@ -1,7 +1,10 @@
 MODULE_TOPDIR = ../..
-PGM=r.shaded.relief
+PGM = r.shaded.relief2
-include $(MODULE_TOPDIR)/include/Make/Script.make
+LIBES = $(RASTERLIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(RASTERDEP) $(GISDEP)
-default: script
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass/trunk/raster/r.shaded.relief2/main.c
--- grass/trunk/raster/r.shaded.relief2/main.c	                        (rev 0)
+++ grass/trunk/raster/r.shaded.relief2/main.c	2012-06-03 11:29:43 UTC (rev 51947)
@@ -0,0 +1,463 @@
+ * MODULE:       r.shaded.relief
+ * AUTHOR(S):	CERL
+ *               parameters standardized: Markus Neteler, 2008
+ *               updates: Michael Barton, 2004
+ *               updates: Gordon Keith, 2003
+ *               updates: Andreas Lange, 2001
+ *               updates: David Finlayson, 2001
+ *               updates: Markus Neteler, 2001, 1999
+ *               Converted to Python by Glynn Clements
+ *               Converted to C by Markus Metz
+ * PURPOSE:	Creates shaded relief map from raster elevation map (DEM)
+ * COPYRIGHT:	(C) 1999 - 2008, 2010, 2012 by the GRASS Development Team
+ *		This program is free software under the GNU General Public
+ *		License (>=v2). Read the file COPYING that comes with GRASS
+ *		for details.
+ *   July 2007 - allow input from other mapsets (Brad Douglas)
+ *   May 2005 - fixed wrong units parameter (Markus Neteler)
+ *   September 2004 - Added z exaggeration control (Michael Barton)
+ *   April 2004 - updated for GRASS 5.7 by Michael Barton
+ *   9/2004 Adds scale factor input (as per documentation); units set scale only if specified for lat/long regions
+ *    Also, adds option of controlling z-exaggeration.
+ *   6/2003 fixes for Lat/Long Gordon Keith <gordon.keith at csiro.au>
+ *   If n is a number then the ewres and nsres are mulitplied by that scale
+ *    to calculate the shading.
+ *   If n is the letter M (either case) the number of metres is degree of
+ *    latitude is used as the scale.
+ *   If n is the letter f then the number of feet in a degree is used.
+ *   It scales latitude and longitude equally, so it's only approximately
+ *   right, but for shading its close enough. It makes the difference
+ *   between an unusable and usable shade.
+ *   10/2001 fix for testing for dashes in raster file name
+ *        by Andreas Lange <andreas.lange at rhein-main.de>
+ *   10/2001 added parser support - Markus Neteler
+ *   9/2001 fix to keep NULLs as is (was value 22 before) - Markus Neteler
+ *   1/2001 fix for NULL by David Finlayson <david_finlayson at yahoo.com>
+ *   11/99 updated $ewres to ewres() and $nsres to nsres()
+ *       updated number to FP in r.mapcalc statement Markus Neteler
+#include <stdlib.h>
+#include <string.h>
+#include <math.h>
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include <grass/glocale.h>
+int main(int argc, char *argv[])
+    int in_fd;
+    int out_fd;
+    DCELL *elev_cell[3], *temp;
+    DCELL *out_rast, *out_ptr = NULL;
+    DCELL *c1, *c2, *c3, *c4, *c5, *c6, *c7, *c8, *c9;
+    int Wrap;			/* global wraparound */
+    struct Cell_head window;
+    struct History hist;
+    struct Colors colors;
+    const char *elev_name;
+    const char *sr_name;
+    int out_type = CELL_TYPE;
+    size_t out_size;
+    const char *units;
+    char buf[GNAME_MAX];
+    int nrows, row;
+    int ncols, col;
+    double zmult, scale, altitude, azimuth;
+    double north, east, south, west, ns_med;
+    double degrees_to_radians, radians_to_degrees;
+    double H, V;
+    double dx;			/* partial derivative in ew direction */
+    double dy;			/* partial derivative in ns direction */
+    double key;
+    double slp_in_rad, aspect, cang;
+    struct FPRange range;
+    DCELL min, max;
+    struct GModule *module;
+    struct
+	struct Option *elevation, *relief, *altitude, *azimuth, *zmult,
+	    *scale, *units;
+    } parm;
+    char *desc;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    G_add_keyword(_("raster"));
+    G_add_keyword(_("terrain"));
+    module->label = _("Creates shaded relief map from an elevation map (DEM).");
+    parm.elevation = G_define_standard_option(G_OPT_R_INPUT);
+    parm.relief = G_define_standard_option(G_OPT_R_OUTPUT);
+    parm.relief->required = NO;
+    parm.relief->label = _("Name for output shaded relief map");
+    parm.relief->description = _("Default: <input_map>.shade");
+    parm.altitude = G_define_option();
+    parm.altitude->key = "altitude";
+    parm.altitude->type = TYPE_DOUBLE;
+    parm.altitude->required = NO;
+    parm.altitude->answer = "30";
+    parm.altitude->options = "0-90";
+    parm.altitude->description = _("Altitude of the sun in degrees above the horizon");
+    parm.azimuth = G_define_option();
+    parm.azimuth->key = "azimuth";
+    parm.azimuth->type = TYPE_DOUBLE;
+    parm.azimuth->required = NO;
+    parm.azimuth->answer = "270";
+    parm.azimuth->options = "0-360";
+    parm.azimuth->description =
+	_("Azimuth of the sun in degrees to the east of north");
+    parm.zmult = G_define_option();
+    parm.zmult->key = "zmult";
+    parm.zmult->type = TYPE_DOUBLE;
+    parm.zmult->required = NO;
+    parm.zmult->answer = "1";
+    parm.zmult->description = _("Factor for exaggerating relief");
+    parm.scale = G_define_option();
+    parm.scale->key = "scale";
+    parm.scale->type = TYPE_DOUBLE;
+    parm.scale->required = NO;
+    parm.scale->answer = "1";
+    parm.scale->description =
+	_("Scale factor for converting meters to elevation units");
+    parm.units = G_define_option();
+    parm.units->key = "units";
+    parm.units->type = TYPE_STRING;
+    parm.units->required = NO;
+    parm.units->options = "intl,survey";
+    parm.units->description = _("Elevation units (overrides scale factor)");
+    desc = NULL;
+    G_asprintf(&desc,
+	       "intl;%s;"
+	       "survey;%s",
+	       _("international feet"),
+	       _("survey feet"));
+    parm.units->descriptions = desc;
+    degrees_to_radians = M_PI / 180.0;
+    radians_to_degrees = 180. / M_PI;
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    elev_name = parm.elevation->answer;
+    if (parm.relief->answer) {
+	sr_name = parm.relief->answer;
+    else {
+	char xname[GNAME_MAX], xmapset[GNAME_MAX];
+	if (G_name_is_fully_qualified(elev_name, xname, xmapset))
+	    sprintf(buf, "%s.shade", xname);
+	else
+	    sprintf(buf, "%s.shade", elev_name);
+	sr_name = G_store(buf);
+    G_check_input_output_name(elev_name, sr_name, G_FATAL_EXIT);
+    if (sscanf(parm.altitude->answer, "%lf", &altitude) != 1 || altitude < 0.0) {
+	G_fatal_error(_("%s=%s - must be a non-negative number"),
+		      parm.altitude->key, parm.altitude->answer);
+    altitude *= degrees_to_radians;
+    if (sscanf(parm.azimuth->answer, "%lf", &azimuth) != 1 || azimuth < 0.0) {
+		      parm.azimuth->key, parm.azimuth->answer);
+    /* correct azimuth to East (GRASS convention):
+     * this seems to be backwards, but in fact it works so leave it. */
+    azimuth = (azimuth - 90.) * degrees_to_radians;
+    if (sscanf(parm.zmult->answer, "%lf", &zmult) != 1 || zmult == 0.0) {
+	G_fatal_error(_("%s=%s - must not be zero"),
+		      parm.zmult->key, parm.zmult->answer);
+    if (sscanf(parm.scale->answer, "%lf", &scale) != 1 || scale <= 0.0) {
+	G_fatal_error(_("%s=%s - must be a positive number"),
+		      parm.scale->key,
+		      parm.scale->answer);
+    G_get_set_window(&window);
+    nrows = Rast_window_rows();
+    ncols = Rast_window_cols();
+    /* horizontal distances are calculated in meters by G_distance() */
+    if (parm.units->answer) {
+	units = parm.units->answer;
+	if (strcmp(units, "intl") == 0) {
+	    /* 1 international foot = 0.3048 meters */
+	    scale = 1. / 0.3048;
+	else if (strcmp(units, "survey") == 0) {
+	    /* 1 survey foot = 1200 / 3937 meters */
+	    scale = 3937. / 1200.;
+    Wrap = 0;
+    if (G_projection() == PROJECTION_LL) {
+	if ((window.west == (window.east - 360.))
+	     || (window.east == (window.west - 360.))) {
+	    Wrap = 1;
+	    ncols += 2;
+    /* H = window.ew_res * 4 * 2/ zmult; *//* horizontal (east-west) run
+       times 4 for weighted difference */
+    /* V = window.ns_res * 4 * 2/ zmult; *//* vertical (north-south) run
+    G_begin_distance_calculations();
+    north = Rast_row_to_northing(0.5, &window);
+    ns_med = Rast_row_to_northing(1.5, &window);
+    south = Rast_row_to_northing(2.5, &window);
+    east = Rast_col_to_easting(2.5, &window);
+    west = Rast_col_to_easting(0.5, &window);
+    V = G_distance(east, north, east, south) * 4 * scale / zmult;
+    H = G_distance(east, ns_med, west, ns_med) * 4 * scale / zmult;
+    /*    ____________________________
+       |c1      |c2      |c3      |
+       |        |  north |        |
+       |________|________|________|
+       |c4      |c5      |c6      |
+       |  east  | ns_med |  west  |
+       |c7      |c8      |c9      |
+       |        |  south |        |
+    /* open the elevation file for reading */
+    in_fd = Rast_open_old(elev_name, "");
+    elev_cell[0] = (DCELL *) G_calloc(ncols + 1, sizeof(DCELL));
+    Rast_set_d_null_value(elev_cell[0], ncols);
+    elev_cell[1] = (DCELL *) G_calloc(ncols, sizeof(DCELL));
+    Rast_set_d_null_value(elev_cell[1], ncols);
+    elev_cell[2] = (DCELL *) G_calloc(ncols, sizeof(DCELL));
+    Rast_set_d_null_value(elev_cell[2], ncols);
+    out_fd = Rast_open_new(sr_name, out_type);
+    out_rast = Rast_allocate_buf(out_type);
+    Rast_set_null_value(out_rast, Rast_window_cols(), out_type);
+    Rast_put_row(out_fd, out_rast, out_type);
+    out_size = Rast_cell_size(out_type);
+    if (Wrap) {
+	Rast_get_d_row_nomask(in_fd, elev_cell[1] + 1, 0);
+	elev_cell[1][0] = elev_cell[1][Rast_window_cols() - 1];
+	elev_cell[1][Rast_window_cols() + 1] = elev_cell[1][2];
+    else
+	Rast_get_d_row_nomask(in_fd, elev_cell[1], 0);
+    if (Wrap) {
+	Rast_get_d_row_nomask(in_fd, elev_cell[2] + 1, 1);
+	elev_cell[2][0] = elev_cell[2][Rast_window_cols() - 1];
+	elev_cell[2][Rast_window_cols() + 1] = elev_cell[2][2];
+    else
+	Rast_get_d_row_nomask(in_fd, elev_cell[2], 1);
+    G_verbose_message(_("Percent complete..."));
+    for (row = 2; row < nrows; row++) {
+	/*  if projection is Lat/Lon, recalculate  V and H   */
+	    north = Rast_row_to_northing((row - 2 + 0.5), &window);
+	    ns_med = Rast_row_to_northing((row - 1 + 0.5), &window);
+	    south = Rast_row_to_northing((row + 0.5), &window);
+	       |c1      |c2      |c3      |
+	       |        |  north |        |
+	       |c4      |c5      |c6      |
+	       |c7      |c8      |c9      |
+	       |        |  south |        |
+	G_percent(row, nrows, 2);
+	temp = elev_cell[0];
+	elev_cell[0] = elev_cell[1];
+	elev_cell[1] = elev_cell[2];
+	elev_cell[2] = temp;
+	if (Wrap) {
+	    Rast_get_d_row_nomask(in_fd, elev_cell[2] + 1, row);
+	else
+	    Rast_get_d_row_nomask(in_fd, elev_cell[2], row);
+	c1 = elev_cell[0];
+	c2 = c1 + 1;
+	c3 = c1 + 2;
+	c4 = elev_cell[1];
+	c5 = c4 + 1;
+	c6 = c4 + 2;
+	c7 = elev_cell[2];
+	c8 = c7 + 1;
+	c9 = c7 + 2;
+	if (Wrap)
+	    out_ptr = out_rast;
+	else
+	    out_ptr = G_incr_void_ptr(out_rast, out_size);
+	/*skip first cell of the row */
+	for (col = ncols - 2; col-- > 0;
+	     c1++, c2++, c3++, c4++, c5++, c6++, c7++, c8++, c9++) {
+	    /*  DEBUG:
+	       fprintf(stdout, "\n%.0f %.0f %.0f\n%.0f %.0f %.0f\n%.0f %.0f %.0f\n",
+	       *c1, *c2, *c3, *c4, *c5, *c6, *c7, *c8, *c9);
+	    if (Rast_is_d_null_value(c1) || Rast_is_d_null_value(c2) ||
+		Rast_is_d_null_value(c3) || Rast_is_d_null_value(c4) ||
+		Rast_is_d_null_value(c5) || Rast_is_d_null_value(c6) ||
+		Rast_is_d_null_value(c7) || Rast_is_d_null_value(c8) ||
+		Rast_is_d_null_value(c9)) {
+		Rast_set_null_value(out_ptr, 1, out_type);
+		out_ptr = G_incr_void_ptr(out_ptr, out_size);
+		continue;
+	    }			/* no data */
+	    /* shaded relief */
+	    /* slope */
+	    dx = (*c1 + 2 * *c4 + *c7 - *c3 - 2 * *c6 - *c9) / H;
+	    dy = (*c1 + 2 * *c2 + *c3 - *c7 - 2 * *c8 - *c9) / V;
+	    key = dx * dx + dy * dy;
+	    slp_in_rad = M_PI / 2. - atan(sqrt(key));
+	    /* aspect */
+	    aspect = atan2(dy, dx);
+	    if (aspect != aspect)
+		aspect = degrees_to_radians;
+	    if (dx != 0 || dy != 0) {
+		if (aspect == 0)
+		    aspect = 2 * M_PI;
+#if 0
+	    /* the original script was rounding aspect. Why? */
+	    aspect *= radians_to_degrees;
+	    if (aspect < 0)
+		aspect = (int)(aspect - 0.5);
+	    else
+		aspect = (int)(aspect + 0.5);
+	    aspect *= degrees_to_radians;
+#endif
+	    cang = sin(altitude) * sin(slp_in_rad) +
+	           cos(altitude) * cos(slp_in_rad) * cos(azimuth - aspect);
+	    Rast_set_d_value(out_ptr, (DCELL) 255 * cang, out_type);
+	}			/* column for loop */
+    }				/* row loop */
+    Rast_close(in_fd);
+    Rast_close(out_fd);
+    G_debug(1, "Creating support files...");
+    /* write colors for shaded relief */
+    Rast_init_colors(&colors);
+    Rast_read_fp_range(sr_name, G_mapset(), &range);
+    Rast_get_fp_range_min_max(&range, &min, &max);
+    min -= 0.01;
+    max += 0.01;
+    Rast_make_grey_scale_fp_colors(&colors, min, max);
+    Rast_write_colors(sr_name, G_mapset(), &colors);
+    sprintf(buf, "Shaded relief of \"%s\"", elev_name);
+    Rast_put_cell_title(sr_name, buf);
+    /* writing history file */
+    Rast_short_history(sr_name, "raster", &hist);
+    Rast_append_format_history(&hist, "r.shaded.relief settings:");
+                               "altitude=%f  azimuth=%f zmult=%f  scale=%f",
+			       altitude * radians_to_degrees,
+			       azimuth * radians_to_degrees,
+			       zmult, scale);
+    Rast_format_history(&hist, HIST_DATSRC_1, "raster elevation file %s", elev_name);
+    Rast_command_history(&hist);
+    Rast_write_history(sr_name, &hist);
+    G_message(_("Shaded relief raster map <%s> complete"), sr_name);
+    exit(EXIT_SUCCESS);
Property changes on: grass/trunk/raster/r.shaded.relief2/main.c
___________________________________________________________________
Added: svn:mime-type
   + text/x-csrc
Added: svn:eol-style
   + native
Deleted: grass/trunk/raster/r.shaded.relief2/r.shaded.relief.html
--- grass/trunk/scripts/r.shaded.relief/r.shaded.relief.html	2012-06-02 17:12:24 UTC (rev 51942)
+++ grass/trunk/raster/r.shaded.relief2/r.shaded.relief.html	2012-06-03 11:29:43 UTC (rev 51947)
@@ -1,95 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.shaded.relief</em> creates a raster shaded relief map based on current
-resolution settings and on sun altitude, azimuth, and z-exaggeration values
-entered by the user. If no output shademap name is given, the new shaded
-relief map is named <em><input_map>.shade</em>.
-The map is assigned a grey-scale color table.
-<p>The module then prompts the user to enter values for:
-<ol>
-<li>The <b>altitude</b> of the sun in degrees above the horizon
-(a value between 0 and 90 degrees), and
-<li>The <b>azimuth</b> of the sun in degrees to the east of north
-(a value between 0 and 360 degrees).
-<li>The name of a raster map layer to provide elevation values for the
-shaded relief map.  Typically, this would be a map layer of elevation;
-however, any raster map layer can be named.
-<li>The scaling parameter, which compensates for a different horizontal
-<b>scale</b> than vertical scale. If 'scale' is a number then the ewres
-and nsres are multiplied by that scale to calculate the shading. (Default=1.0
-for equivalent horizontal and vertical scales.)
-<li>For the special case when a latitude-longitude projection is used with an
-elevation map measured in meters (e.g., SRTM, ETOPO2 etc.) or feet, the
-<b>units</b> can be set to automatically set the horizontal scale to the the number of
-meters (scale=111120) or feet (scale=370400) in a degree of latitude. The script scales
-latitude and longitude equally, so it's only approximately right, but for shading
-it's close enough. It makes the difference between a usable and unusable shade.
-The <b>units</b> parameter overrides the <b>scale</b> parameter.
-<li>The <b>zmult</b> exaggeration factor that changes the apparent relief
-for the shaded relief map.  This can be any positive (or negative) floating
-point value. (Default=1.0)
-</ol>
-Specifically, <em>r.shaded.relief</em> executes a <em>r.mapcalc</em>
-statement. Refer to the manual entry for <em>r.mapcalc</em> for an explanation
-of the filtering syntax shown in the above expression.
-See, for example, the section on "The Neighborhood Modifier".
-<p><em>r.shaded.relief</em> then runs <em>r.colors</em>
-to assign a grey-scale color table to the new shaded relief map.
-<h2>NOTES</h2>
-To visually improve the result of shade maps from low resolution elevation
-models, use <em>r.resamp.interp</em> with bilinear or bicubic method to
-resample the DEM at higher resolution. <em>r.shaded.relief</em> is then
-run on the resampled DEM.
-<h2>EXAMPLES</h2>
-In this example, the aspect map in the North Carolina sample
-dataset location is used to hillshade the elevation map:
-<div class="code"><pre>
-g.region rast=elevation -p
-r.shaded.relief input=elevation output=elevation.shaded
-</pre></div>
-<p>In Latitude-Longitude locations (or other non-metric locations), the
-<em>scale</em> factor has to be used:
-# Latitude-Longitude example
-r.shaded.relief input=srtm output=srtm.shaded scale=111120
-</pre></div>
-<h2>SEE ALSO</h2>
-"<i>r.mapcalc: An Algebra for GIS and Image Processing</i>", by Michael Shapiro
-and Jim Westervelt, U.S. Army Construction Engineering Research Laboratory
-(March/1991) (available from the GRASS web site).
-<p><!-- RGB version not ported to GRASS 6:
-  <em><a href="shade.clr.sh.html">shade.clr.sh</a></em><br>
-<em>
-<a href="d.his.html">d.his</a>,
-<a href="g.region.html">g.region</a>,
-<a href="r.blend.html">r.blend</a>,
-<a href="r.colors.html">r.colors</a>,
-<a href="r.mapcalc.html">r.mapcalc</a>,
-<a href="r.resamp.interp.html">r.resamp.interp</a>
-</em>
-<h2>AUTHOR</h2>
-Jim Westervelt, U.S. Army Construction Engineering
-Research Laboratory
-<p><i>Last changed: $Date$</i>
Deleted: grass/trunk/raster/r.shaded.relief2/r.shaded.relief.py
--- grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py	2012-06-02 17:12:24 UTC (rev 51942)
+++ grass/trunk/raster/r.shaded.relief2/r.shaded.relief.py	2012-06-03 11:29:43 UTC (rev 51947)
@@ -1,179 +0,0 @@
-#!/usr/bin/env python
-# MODULE:       r.shaded.relief
-# AUTHOR(S):	CERL
-#               parameters standardized: Markus Neteler, 2008
-#               updates: Michael Barton, 2004
-#               updates: Gordon Keith, 2003
-#               updates: Andreas Lange, 2001
-#               updates: David Finlayson, 2001
-#               updates: Markus Neteler, 2001, 1999
-#               Converted to Python by Glynn Clements
-# PURPOSE:	Creates shaded relief map from raster elevation map (DEM)
-# COPYRIGHT:	(C) 1999 - 2008, 2010 by the GRASS Development Team
-#		This program is free software under the GNU General Public
-#		License (>=v2). Read the file COPYING that comes with GRASS
-#		for details.
-#   July 2007 - allow input from other mapsets (Brad Douglas)
-#   May 2005 - fixed wrong units parameter (Markus Neteler)
-#   September 2004 - Added z exaggeration control (Michael Barton)
-#   April 2004 - updated for GRASS 5.7 by Michael Barton
-#   9/2004 Adds scale factor input (as per documentation); units set scale only if specified for lat/long regions
-#    Also, adds option of controlling z-exaggeration.
-#   6/2003 fixes for Lat/Long Gordon Keith <gordon.keith at csiro.au>
-#   If n is a number then the ewres and nsres are mulitplied by that scale
-#    to calculate the shading.
-#   If n is the letter M (either case) the number of metres is degree of
-#    latitude is used as the scale.
-#   If n is the letter f then the number of feet in a degree is used.
-#   It scales latitude and longitude equally, so it's only approximately
-#   right, but for shading its close enough. It makes the difference
-#   between an unusable and usable shade.
-#   10/2001 fix for testing for dashes in raster file name
-#        by Andreas Lange <andreas.lange at rhein-main.de>
-#   10/2001 added parser support - Markus Neteler
-#   9/2001 fix to keep NULLs as is (was value 22 before) - Markus Neteler
-#   1/2001 fix for NULL by David Finlayson <david_finlayson at yahoo.com>
-#   11/99 updated $ewres to ewres() and $nsres to nsres()
-#       updated number to FP in r.mapcalc statement Markus Neteler
-#%module
-#% description: Creates shaded relief map from an elevation map (DEM).
-#% keywords: raster
-#% keywords: elevation
-#%end
-#%option G_OPT_R_INPUT
-#% description: Name of input elevation raster map
-#%end
-#%option G_OPT_R_OUTPUT
-#%end
-#%option
-#% key: altitude
-#% type: double
-#% description: Altitude of the sun in degrees above the horizon
-#% required: no
-#% options : 0-90
-#% answer: 30
-#%end
-#%option
-#% key: azimuth
-#% type: double
-#% description: Azimuth of the sun in degrees to the east of north
-#% required: no
-#% options : 0-360
-#% answer: 270
-#%end
-#%option
-#% key: zmult
-#% type: double
-#% description: Factor for exaggerating relief
-#% required: no
-#% answer: 1
-#%end
-#%option
-#% key: scale
-#% type: double
-#% description: Scale factor for converting horizontal units to elevation units
-#% required: no
-#% answer: 1
-#% guisection: Scaling
-#%end
-#%option
-#% key: units
-#% type: string
-#% description: Set scaling factor (applies to lat./long. locations only, none: scale=1)
-#% required: no
-#% options: none,meters,feet
-#% answer: none
-#%end
-import sys
-import os
-import string
-import grass.script as grass
-def main():
-    input = options['input']
-    output = options['output']
-    altitude = options['altitude']
-    azimuth = options['azimuth']
-    zmult = options['zmult']
-    scale = float(options['scale'])
-    units = options['units']
-    verbose_level = os.getenv('GRASS_VERBOSE')
-    if verbose_level is None:
-        verbose_level = 2
-    if not grass.find_file(input)['file']:
-	grass.fatal(_("Raster map <%s> not found") % input)
-    if input == output:
-	grass.fatal(_("Input elevation map and output relief map must have different names"))
-    # LatLong locations only:
-    if units == 'meters':
-        # scale=111120
-	scale *= 1852 * 60
-    if units == 'feet':
-        # scale=364567.2
-	scale *= 6076.12 * 60
-    #correct azimuth to East (GRASS convention):
-    #  this seems to be backwards, but in fact it works so leave it.
-    az = float(azimuth) - 90
-    t = string.Template(
-	r'''eval( \
-	x=($zmult*$input[-1,-1] + 2*$zmult*$input[0,-1] + $zmult*$input[1,-1] - \
-	$zmult*$input[-1,1] - 2*$zmult*$input[0,1] - $zmult*$input[1,1])/(8.*ewres()*$scale), \
-	y=($zmult*$input[-1,-1] + 2*$zmult*$input[-1,0] + $zmult*$input[-1,1] - \
-	$zmult*$input[1,-1] - 2*$zmult*$input[1,0] - $zmult*$input[1,1])/(8.*nsres()*$scale), \
-	slope=90.-atan(sqrt(x*x + y*y)), \
-	a=round(atan(x,y)), \
-	a=if(isnull(a),1,a), \
-	aspect=if(x!=0||y!=0,if(a,a,360.)), \
-	cang = sin($altitude)*sin(slope) + cos($altitude)*cos(slope) * cos($az-aspect) \
-	$output = if(isnull(cang), null(), 100.*cang)''')
-    expr = t.substitute(altitude = altitude, az = az, input = input, output = output, scale = scale, zmult = zmult)
-    p = grass.feed_command('r.mapcalc')
-    p.stdin.write(expr)
-    p.stdin.close()
-    if p.wait() != 0:
-	grass.fatal(_("In calculation, script aborted."))
-    if verbose_level < 3:
-        grass.run_command('r.colors', map = output, color = 'grey', quiet = True)
-    else:
-        grass.run_command('r.colors', map = output, color = 'grey')
-    # record metadata
-    grass.run_command('r.support', map = output, title = 'Shaded relief of "%s"' % input, history = '')
-    grass.run_command('r.support', map = output, history = "r.shaded.relief settings:")
-    t = string.Template("altitude=$altitude  azimuth=$azimuth zmult=$zmult  scale=$scale")
-    parms = dict(altitude = altitude, azimuth = azimuth, zmult = zmult, scale = options['scale'])
-    grass.run_command('r.support', map = output, history = t.substitute(parms))
-    if units:
-	grass.run_command('r.support', map = output, history = "  units=%s (adjusted scale=%s)" % (units, scale))
-    # write cmd history:
-    grass.raster_history(output)
-if __name__ == "__main__":
-    options, flags = grass.parser()
-    main()
Copied: grass/trunk/raster/r.shaded.relief2/r.shaded.relief2.html (from rev 51942, grass/trunk/scripts/r.shaded.relief/r.shaded.relief.html)
--- grass/trunk/raster/r.shaded.relief2/r.shaded.relief2.html	                        (rev 0)
+++ grass/trunk/raster/r.shaded.relief2/r.shaded.relief2.html	2012-06-03 11:29:43 UTC (rev 51947)
@@ -0,0 +1,87 @@
+<h2>DESCRIPTION</h2>
+<em>r.shaded.relief</em> creates a raster shaded relief map based on
+current resolution settings and on sun altitude, azimuth, and
+z-exaggeration values entered by the user. If no output shademap
+name is given, the new shaded relief map is named <em><input_map
+>.shade</em>. The map is assigned a grey-scale color table.
+<p>The parameters controlling the shading are:
+<ol>
+<li>A raster map layer to provide elevation values for the shaded
+relief map.  Typically, this would be a map layer of elevation;
+however, any raster map layer can be named.
+<li>The <b>altitude</b> of the sun in degrees above the horizon
+(a value between 0 and 90 degrees).
+<li>The <b>azimuth</b> of the sun in degrees to the east of north
+(a value between 0 and 360 degrees).
+<li>The scaling parameter, which compensates for a different
+horizontal <b>scale</b> than vertical scale. If <b>scale</b> is a
+number, then the ewres and nsres are multiplied by that scale to
+calculate the shading. (Default=1.0 for equivalent horizontal and
+vertical scales.)
+<li>The <b>zmult</b> exaggeration factor that changes the apparent relief
+for the shaded relief map.  This can be any positive (or negative) floating
+point value. (Default=1.0)
+<li>Horizontal distances are calculated in meters, using geodesic
+distances for a latitude-longitude projection. With an elevation map
+measured in feet, the <b>units</b> option can be set to automatically
+convert meters to international feet (0.3048 meters = 1 foot) or survey
+feet (1200 / 3937 meters = 1 foot). The <b>units</b> parameter overrides
+the <b>scale</b> parameter.
+</ol>
+<p><em>r.shaded.relief</em> assigns a grey-scale color table to the new
+shaded relief map.
+<h2>NOTES</h2>
+To visually improve the result of shade maps from low resolution elevation
+models, use <em>r.resamp.interp</em> with bilinear or bicubic method to
+resample the DEM at higher resolution. <em>r.shaded.relief</em> is then
+run on the resampled DEM.
+<h2>EXAMPLES</h2>
+In this example, the aspect map in the North Carolina sample
+dataset location is used to hillshade the elevation map:
+<div class="code"><pre>
+g.region rast=elevation -p
+r.shaded.relief input=elevation output=elevation.shaded
+</pre></div>
+<p>In Latitude-Longitude locations (or other non-metric locations), the
+<em>scale</em> factor has to be used:
+# Latitude-Longitude example
+r.shaded.relief input=srtm output=srtm.shaded scale=111120
+</pre></div>
+<h2>SEE ALSO</h2>
+<p><!-- RGB version not ported to GRASS 6 (why?):
+  <em><a href="shade.clr.sh.html">shade.clr.sh</a></em><br>
+<em>
+<a href="d.his.html">d.his</a>,
+<a href="g.region.html">g.region</a>,
+<a href="r.blend.html">r.blend</a>,
+<a href="r.colors.html">r.colors</a>,
+<a href="r.mapcalc.html">r.mapcalc</a>,
+<a href="r.resamp.interp.html">r.resamp.interp</a>
+</em>
+<h2>AUTHOR</h2>
+Jim Westervelt, U.S. Army Construction Engineering
+Research Laboratory
+<p><i>Last changed: $Date$</i>
Property changes on: grass/trunk/raster/r.shaded.relief2/r.shaded.relief2.html
   + text/html
Added: svn:keywords
   + Date
   + native
