[GRASS-SVN] r51961 - grass/trunk/db/drivers/postgres
Sun Jun 3 11:23:31 PDT 2012
Author: martinl
Date: 2012-06-03 11:23:30 -0700 (Sun, 03 Jun 2012)
New Revision: 51961
   grass/trunk/db/drivers/postgres/db.c
db-pg driver: print notice message only on verbose level
Modified: grass/trunk/db/drivers/postgres/db.c
--- grass/trunk/db/drivers/postgres/db.c	2012-06-03 17:17:25 UTC (rev 51960)
+++ grass/trunk/db/drivers/postgres/db.c	2012-06-03 18:23:30 UTC (rev 51961)
@@ -18,6 +18,14 @@
 #include "globals.h"
 #include "proto.h"
+static void notice_processor(void *arg, const char *message)
+    /* print notice messages only on verbose level */
+    if (G_verbose() > G_verbose_std()) {
+        fprintf(stderr, "%s", message);
 int db__driver_open_database(dbHandle * handle)
     char buf[500];
@@ -64,10 +72,11 @@
 	return DB_FAILED;
-    /* Set schema */
+    /* set schema */
     schema = db_get_handle_dbschema(handle);
-    /* Cannot use default schema because link to table can point to different database */
+    /* Cannot use default schema because link to table can point to
+       different database */
        if ( schema )
        schema = connection.schemaName;
@@ -92,7 +101,7 @@
-    /* Read internal codes */
+    /* read internal codes */
     res = PQexec(pg_conn,
 		 "select oid, typname from pg_type where typname in ( "
 		 "'bit', 'int2', 'int4', 'int8', 'serial', 'oid', "
@@ -164,7 +173,10 @@
 		PQgetvalue(res, row, 1), type);
 	pg_types[row][1] = type;
+    PQsetNoticeProcessor(pg_conn, notice_processor, NULL);
     PQclear(res);
     return DB_OK;
