[GRASS-SVN] r52005 - grass/trunk/lib/vector/Vlib
Thu Jun 7 16:03:39 PDT 2012
Author: martinl
Date: 2012-06-07 16:03:39 -0700 (Thu, 07 Jun 2012)
New Revision: 52005
   grass/trunk/lib/vector/Vlib/open_pg.c
vlib/pg: attach centroids when building topo from PostGIS topology schema
Modified: grass/trunk/lib/vector/Vlib/open_pg.c
--- grass/trunk/lib/vector/Vlib/open_pg.c	2012-06-07 22:36:38 UTC (rev 52004)
+++ grass/trunk/lib/vector/Vlib/open_pg.c	2012-06-07 23:03:39 UTC (rev 52005)
@@ -1261,7 +1261,8 @@
     struct Format_info_pg *pg_info;
     struct Plus_head *plus;
-    struct P_line *Line;
+    struct P_line *line;
+    struct P_area *area;
     PGresult *res;
@@ -1366,9 +1367,9 @@
         line_data.right_face = atoi(PQgetvalue(res, i, 4));
         id = plus->n_plines + i + 1; /* points already registered */
-        Line = read_p_line(plus, id, &line_data);
+        line = read_p_line(plus, id, &line_data);
         if (line_data.left_face != 0 || line_data.right_face != 0) {
-            /* boundary detected -> build area on left and right*/
+            /* boundary detected -> build area/isle on left and right*/
             int s, side;
             for (s = 0; s < 2; s++) {
@@ -1382,7 +1383,7 @@
                 Vect_build_line_area(Map, id, side);
-        if (Line->type == GV_BOUNDARY) {
+        if (line->type == GV_BOUNDARY) {
             struct P_topo_b *topo;
             if (line_data.left_face == 0)
@@ -1390,7 +1391,7 @@
             if (line_data.right_face == 0)
                 line_data.right_face = -1;
-            topo = (struct P_topo_b *)Line->topo;
+            topo = (struct P_topo_b *)line->topo;
             if (topo->left != line_data.left_face)
                 G_warning(_("Left area detected as %d (should be %d"),
                           topo->left, line_data.left_face);
@@ -1401,6 +1402,16 @@
     PQclear(res);
+    /* attach centroids */
+    G_zero(&line_data, sizeof(struct edge_data));
+    for (i = 1; i <= plus->n_areas; i++) {
+        area = plus->Area[i];
+        line_data.id = plus->n_lines - plus->n_clines + i;
+        line_data.left_face = i;
+        read_p_line(plus, line_data.id, &line_data);
+        area->centroid = line_data.id;
     return 0;
