[GRASS-SVN] r52019 - grass-addons/grass7/imagery/i.segment
Sat Jun 9 22:04:17 PDT 2012
Author: momsen
Date: 2012-06-09 22:04:16 -0700 (Sat, 09 Jun 2012)
New Revision: 52019
   grass-addons/grass7/imagery/i.segment/create_isegs.c
   grass-addons/grass7/imagery/i.segment/iseg.h
   grass-addons/grass7/imagery/i.segment/outline
   grass-addons/grass7/imagery/i.segment/parse_args.c
   grass-addons/grass7/imagery/i.segment/write_output.c
work in progress... hangs up... Using arrays - dumb/quick data structure, just to implement and see if logic works.
Modified: grass-addons/grass7/imagery/i.segment/create_isegs.c
--- grass-addons/grass7/imagery/i.segment/create_isegs.c	2012-06-09 17:42:15 UTC (rev 52018)
+++ grass-addons/grass7/imagery/i.segment/create_isegs.c	2012-06-10 05:04:16 UTC (rev 52019)
@@ -4,11 +4,13 @@
 #include <stdlib.h>
 #include <float.h>		/* to get value of LDBL_MAX -> change this if there is a more usual grass way */
+#include <math.h>		/* for sqrt() and pow() */
 #include <grass/gis.h>
 #include <grass/raster.h>
 #include <grass/segment.h>	/* segmentation library */
 #include "iseg.h"
 int create_isegs(struct files *files, struct functions *functions)
@@ -29,10 +31,11 @@
     if (functions->method == 0)
-	successflag = io_debug(files, functions);
-    else if (functions->method == 1)
+	successflag = io_debug(files, functions);	/* TODO: why does it want &files in main, but files here ??? */
+    else if (functions->method == 1) {
+	G_debug(1, "starting region_growing()");
 	successflag = region_growing(files, functions);
     if (successflag != 0)
 	G_fatal_error("Error creating segments");
@@ -70,18 +73,25 @@
 int region_growing(struct files *files, struct functions *functions)
-    int row, col, n, t, pixel_neighbors[8][2];	/* could dynamically declare to be only 4 or 8 elements, but this is shorter for now */
-    double threshold, Ri_simularity, Rk_simularity, tempsim;
+    int row, col, n, m, t;
+    double threshold, Ri_similarity, Rk_similarity, tempsim;
     int endflag;		/* =1 if there were no merges on that processing iteration */
     int pathflag;		/* =1 if we didn't find mutual neighbors, and should continue with Rk */
-    int mergeflag;		/* =1 if we have mutually agreeing best neighbors */
+    /*int mergeflag;    just did it based on if statment... *//* =1 if we have mutually agreeing best neighbors */
     /* Ri = current focus segment
      * Rk = Ri's most similar neighbor
      * Rkn = Rk's neighbors
      * Rin = Ri's neigbors (as pixels or segments ?!?
+    /* lets get this running, and just use fixed dimension arrays for now.  t is limited to 90, segments will be small. */
+    int Ri[100][2], Rk[100][2], Rin[100][2], Rkn[100][2];	/* 100 or so maximum members, second dimension is for:  0: row  1:  col */
+    int Ri_count, Rk_count, Rin_count, Rkn_count;	/*crutch for now, probably won't need later. */
+    int Rk_id;
     G_verbose_message("Running region growing algorithm");
     t = 0;
@@ -96,8 +106,10 @@
 	/* Set candidate flag to true/1 for all pixels TODO: for polygon group, need to just set to true for those being processed */
-	for (row = 0; row < files->nrows; row++) {
-	    for (col = 0; col < files->ncols; col++) {
+	/*      for (row = 0; row < files->nrows; row++) {
+	   for (col = 0; col < files->ncols; col++) {   -----need to deal with edges.... */
+	for (row = 1; row < files->nrows - 1; row++) {
+	    for (col = 1; col < files->ncols - 1; col++) {
 		segment_get(&files->out_seg, (void *)files->out_val, row, col);	/*need to get, since we only want to change the flag, and not overwrite the segment value. */
 		/* TODO: if we are starting from seeds...and only allow merges between unassigned pixels
 		 *  and seeds/existing segments, then this needs an if (and will be very inefficient)
@@ -107,7 +119,7 @@
 			    col);
+	G_debug(1, "Starting to process candidate pixels");
 	/*process candidate pixels */
 	/*check each pixel, start the processing only if it is a candidate pixel */
@@ -117,64 +129,93 @@
 			    col);
 		if (files->out_val[1] == 1) {	/* out_val[1] is the candidate pixel flag */
-		    /*TODO: need to empty/reset Ri, Rn, and Rk */
-		    Ri = Rin = Rk = Rkn = NULL;
+		    /*need to empty/reset Ri, Rn, and Rk */
+		    /* TODO: this will be different when Ri is different data structure. */
+		    for (n = 0; n < 100; n++) {
+			for (m = 0; m < 2; m++) {
+			    Ri[n][m] = Rk[n][m] = Rin[n][m] = Rkn[n][m] = 0;
+		    Rin_count = Rkn_count = Rk_count = 0;
+		    Ri_count = 1;	/*we'll have the focus pixel to start with. */
+		    /* First pixel in Ri is current pixel.  We may add more later if it is part of a segment */
+		    Ri[0][0] = row;
+		    Ri[0][1] = col;
+		    /* Ri_seg = files->out_val[0]; don't need this here -have it in merge_segments() *//* out_val[0] is segment ID, we still have data from call to check the flag. *//* TODO: if seperate segment ID from flag, need to get this value. */
 		    pathflag = 1;
 		    while (pathflag == 1) {	/*if don't find mutual neighbors on first try, will use Rk as next Ri. */
-			if (find_segment_neighbors(Ri, Rin) != 0) {
+			G_debug(1, "just before find_segment_neighbors(Ri)");
+			if (find_segment_neighbors
+			    (Ri, Rin, Ri_count, Rin_count, files,
+			     functions) != 0) {
 			    G_debug(1, "Couldn't find neighbors");	/*this could happen if there is a pixel surrounded by pixels that have already been processed */
 			    pathflag = 0;
-			    set candidate flag to false for this pixel;
+			    Ri_count = 0;
+			    set_candidate_flag(Ri, 0, files);	/* TODO: error trap? */
 			else {	/*found neighbors, go ahead until find mutually agreeing neighbors */
+			    G_debug(1, "Found neighbors");
 			    /* find Ri's most similar neighbor */
-			    Ri_similarity
-				= LDBL_MAX;
+			    Rk_id = -1;
+			    Ri_similarity = LDBL_MAX;	/* set current similarity to max value */
+			    segment_get(&files->bands_seg, (void *)files->bands_val, Ri[0][0], Ri[0][1]);	/* current segment values */
-			    for (each Rin) {
-				tempsim = calculate_simularity(Ri, one neighbor);	/*set up as function pointer... */
-				if tempsim
-				    <Ri_similarity {
+			    for (n = 0; n < Rin_count; n++) {	/* for each of Ri's neighbors */
+				tempsim = (*functions->calculate_similarity) (Ri[0], Rin[n], files, functions);	/*TODO: does this pass just the single point, row/col ???? */
+				if (tempsim < Ri_similarity) {
 				    Ri_similarity = tempsim;
-				    Rk = current neighbor;
+				    Rk_id = n;
-			    if (Rk != null(need correct null finding !) AND Ri_similarity < threshold) {	/* small TODO: should this be < or <=? */
+			    if (Rk_id >= 0 && Ri_similarity < threshold) {	/* small TODO: should this be < or <= for threshold? */
+				/*we'll have the neighbor pixel to start with. */
+				Rk_count = 1;
+				Rk[0][0] = Rin[Rk_id][0];
+				Rk[0][1] = Rin[Rk_id][1];
-				Rkn = Ri;	/* we know Ri should be a neighbor of Rk *//*Todo: is there a way to skip similarity calculations on these?  keep a count, and pop them before doing the similarity check? */
-				find_segment_neighbors(Rk, Rkn);	/* data structure for Rk's neighbors, and pixels in Rk if we don't already have it */
+				/* Rkn = Ri; *//* we know Ri should be a neighbor of Rk *//*Todo: is there a way to skip similarity calculations on these?  keep a count, and pop them before doing the similarity check? */
+				find_segment_neighbors(Rk, Rkn, Rk_count, Rkn_count, files, functions);	/* data structure for Rk's neighbors, and pixels in Rk if we don't already have it */
 				/*find Rk's most similar neighbor */
-				Rk_similarity = Ri_simularity;	/*Ri gets first priority - ties won't change anything, so we'll accept Ri and Rk as mutually best neighbors */
+				Rk_similarity = Ri_similarity;	/*Ri gets first priority - ties won't change anything, so we'll accept Ri and Rk as mutually best neighbors */
+				segment_get(&files->bands_seg, (void *)files->bands_val, Rk[0][0], Rk[0][1]);	/* current segment values */
-				for (each Rkn) {
+				for (n = 0; n < Rkn_count; n++) {	/* for each of Rk's neighbors */
 				    tempsim =
-					calculate_similarity(Rk,
-							     one neighbor);
+					functions->calculate_similarity(Rk[0],
+									Rkn
+									[n],
+									files,
+									functions);
 				    if (tempsim < Rk_similarity) {
 					Rk_similarity = tempsim;
-					break;	/* exit loop here, we know that Ri and Rk aren't mutually best neighbors */
+					break;	/* exit for Rk's neighbors loop here, we know that Ri and Rk aren't mutually best neighbors */
-				if (Rk_similarity == Ri_simularity) {	/* so they agree, both are mutually most similar neighbors */
-				    /* put these steps in merge_segments(Ri, Rk) function?  */
-				    update segment values for all pixels in Ri + Rk(mean)	/* I assume this is a weighted mean? */
-					set candidate flag to false for all pixels in Ri + Rk	/* do this at the same time, so there is only one segment_put statement */
-					  endflag = 0;	/* we've made at least one merge, so need another iteration */
-				    pathflag = 0;	/* go to next row,column pixel - end of Rk -> Ri chain since we found neighbors */
+				if (Rk_similarity == Ri_similarity) {	/* so they agree, both are mutually most similar neighbors */
+				    /* TODO: put these steps in merge_segments(Ri, Rk) function?  */
+				    merge_values(Ri, Rk, Ri_count, Rk_count, files);	/* TODO error trap */
+				    endflag = 0;	/* we've made at least one merge, so need another t iteration */
+				    pathflag = 0;	/* go to next row,column pixel - end of Rk -> Ri chain since we found mutual best neighbors */
 				else {	/* they weren't mutually best neighbors */
-				    set candidate flag to false for all pixels in Ri;	/* TODO !!!!!!!!!!!! hmm, maybe this raster should be its own data structure */
+				    set_candidate_flag(Ri, 0, files);	/* remove Ri from candidate pixels (set flag) */
-				    Rk
-					= Ri;	/* note, this is the eCognition technique.  Seems this is a bit faster, we already have segment membership pixels */
+				    /* Use Rk as next Ri:   this is the eCognition technique.  Seems this is a bit faster, we already have segment membership pixels */
+				    Ri_count = Rk_count;
+				    /* Ri = &Rk; *//* TODO fast/correct way to use arrays and pointers? Ri now will just point to Rk? */
+				    /* at beginning, when initialize Rk ` Rk[n][m] = 0 ` ?? with that just remove the Rk pointer, and leave Ri pointing to the original Rk data? */
+				    for (n = 0; n < 100; n++) {	/*TODO shortcut code...get rid of this... */
+					    Ri[n][m] = Rk[n][m];
 			    }	/*end if Rk exists and < threshold */
 			}	/* end else - Ri did have neighbors */
@@ -186,7 +227,7 @@
 	/* finished one pass for processing candidate pixels */
 	t++;
-    } while (endflag == 0);
+    } while (t < 90 && endflag == 0);
     /*end t loop */
     /* TODO: free memory */
@@ -194,8 +235,12 @@
     return 0;
-int find_segment_neighbors(Ri, Rin)
+int find_segment_neighbors(int Ri[][2], int Rin[][2], int seg_count,
+			   int segn_count, struct files *files,
+			   struct functions *functions)
+    G_debug(1, "in find_segment_neighbors()");
+    int n, m, Ri_seg_ID = -1;
     /* neighbor list will be a listing of pixels that are neighbors?  Include segment numbers?  Only include unique segments?
      * Maybe the most complete return would be a structure array, structure to include the segment ID and a list of points in it?
@@ -209,33 +254,86 @@
     /*local data structures... but maybe they should be allocated out in the main function, is it really slow to create/free on each pass? */
     /* Ri : input parameter, list of pixels in the current segment */
-    to_check;			/* queue or stack - need to check the neighbors of these pixels */
-    no_check;			/* sorted array or btree: list of pixels (by row / column ?) that have been put into the to_check queue, been processed, or are not candidate pixels */
+    int to_check[100][2];	/* queue or stack - need to check the neighbors of these pixels */
-    current_pixel;		/*what data type?  This will be the popped pixel in each loop. */
+    /* int[100][2] no_check;    *//* sorted array or btree: list of pixels (by row / column ?) that have been put into the to_check queue, been processed, or are not candidate pixels */
+    /* or use flag for no_check? ... need a better name for this variable??? */
+    int pixel_neighbors[8][2];	/* data type?  put in files to allocate memory once? */
+    int current_pixel = 0;	/*what data type?  This will be the popped pixel in each loop. */
     /* functions->pixel_neighbors  ...array, 4 or 8 long.  (Can be 4 or 8 neighbors to each pixel)
-     * functions->num_pn  int, 4 or 8.
+     * functions->num_pn  int, 4 or 8. */
-     to_check = Ri; /*need to copy data, not just pointer... */
-    /* Put input in "current segment" list  NOTE: in pseudo code, but think we should just pass Ri and use it directly */
-    no_check = Ri;		/*need to copy data, not just pointer... */
+    /*initialize data.... TODO: maybe remember min max row/col that was looked at each time, initialize in open_files, and reset smaller region at end of this functions */
+    G_debug(1, "setting files->no_check to 0...");
+    for (n = 0; n < files->nrows; n++)
+	for (m = 0; n < files->ncols; n++)
+	    files->no_check[n][m] = 0;	/* 0 means should be checked/expanded, 1 means it has already been checked/expanded. */
+    G_debug(1, "setting to_check to 0");
+	    to_check[n][m] = files->no_check[n][m] = 0;
+    /* Put Ri in to be checked and no check lists (don't expand them if we find them again) */
+    /* NOTE: in pseudo code also have a "current segment" list, but think we can just pass Ri and use it directly */
+    G_debug(1, "Setting up Ri... ");
+    for (n = 0; n < seg_count; n++) {
+	to_check[n][0] = Ri[n][0];
+	to_check[n][1] = Ri[n][1];
+	files->no_check[Ri[n][0]][Ri[n][1]] = 1;
     /* empty "neighbor" list  Note: in pseudo code, but think we just pass in Rin - it was already initialized, and later could have Ri data available to start from */
-    While(!empty(to_check)) {
-	current_pixel = pop next to_check element;
-	functions->(*find_pixel_neighbors) (current_pixel, pixel_neighbors);
+    /* get Ri's segment ID */
+    segment_get(&files->out_seg, (void *)files->out_val, Ri[0][0], Ri[0][1]);
+    Ri_seg_ID = files->out_val[1];
+    G_debug(1, "initializing is done, start processing");
+    while (current_pixel >= 0) {	/* change to not empty once there is a stack... */
+	G_debug(1, "current_pixel: %d", current_pixel);
+	/* current_pixel = pop next to_check element; */
+	/*syntax for function pointer?  functions->(*find_pixel_neighbors) (to_check[current_pixel], pixel_neighbors, files); */
+	functions->find_pixel_neighbors(to_check[current_pixel],
+					pixel_neighbors, files);
+	current_pixel--;	/* Done using this pixels coords, now check neighbors and add to the lists */
+	G_debug(1, "found pixel neighbors");
+	for (n = 0; n < functions->num_pn; n++) {	/*with pixel neighbors */
+	    if (files->no_check[pixel_neighbors[n][0]][pixel_neighbors[n][1]] == 0) {	/* want to check this neighbor */
+		files->no_check[pixel_neighbors[n][0]][pixel_neighbors[n][1]] = 1;	/* OK, check it, but don't check it again! */
-	for (n = 0; n < functions->num_pn; n++) {
-	    if (!pixel_neighbor[n] in "don't check" list) {
-		put pixel_neighbor[n] in "don't check" list segment_get(&files->out_seg, (void *)files->out_val, pixel_neighbor[n][0], pixel_neighbor[n][1]);	/*TODO : do I need a second "out_val" data structure? */
+		segment_get(&files->out_seg, (void *)files->out_val, pixel_neighbors[n][0], pixel_neighbors[n][1]);	/*TODO : do I need a second "out_val" data structure? */
 		if (files->out_val[1] == 1) {	/* valid candidate pixel */
-		    put pixel_neighbor[n] in to_check;	/*want to check this pixels neighbors */
-		    if (files->out_val[0] = current segment ID)
-			put pixel_neighbor[n] in Ri
-			else
-		  put pixel_neighbor[n] in Rin}
+		    G_debug(1, "files->out_val[0] = %d Ri_seg_ID = %d",
+			    files->out_val[0], Ri_seg_ID);
+		    if (files->out_val[0] == Ri_seg_ID) {
+			G_debug(1, "puting pixel_neighbor in Ri");
+			/* put pixel_neighbor[n] in Ri */
+			Ri[seg_count][0] = pixel_neighbors[n][0];
+			Ri[seg_count][1] = pixel_neighbors[n][1];
+			seg_count++;	/* zero index... so increment after save data. */
+			/* put pixel_neighbor[n] in to_check -- want to check this pixels neighbors */
+			current_pixel++;
+			to_check[current_pixel][0] = pixel_neighbors[n][0];
+			to_check[current_pixel][1] = pixel_neighbors[n][1];
+		    else {
+			/* put pixel_neighbor[n] in Rin */
+			Rin[segn_count][0] = pixel_neighbors[n][0];
+			Rin[segn_count][1] = pixel_neighbors[n][1];
+			segn_count++;
+		}		/*end if valid candidate pixel */
 	    }			/*end if for pixel_neighbor was in "don't check" list */
 	}			/* end for loop - next neighbor */
     }				/* while to_check has more elements */
@@ -243,35 +341,133 @@
     return 0;
-find_four_pixel_neighbors(pixel, pixel_neighbors)
+int find_four_pixel_neighbors(int pixel[2], int pixel_neighbors[][2],
+			      struct files *files)
+       G_debug(1,"in find 4 pixel neighbors () ");
+       G_debug(1,"pixel row: %d pixel col: %d", pixel[0], pixel[1]);
+       G_debug(1, "Total rows: %d, total cols: %d", files->nrows, files->ncols); /*check that we have files... */
     /* north */
-    pixel_neighbors[0][1] = pixel column;
-    if (pixel row > 0)
-	pixel_neighbors[0][0] = pixel row + 1;
+    pixel_neighbors[0][1] = pixel[1];
+    if (pixel[0] > 0)
+	pixel_neighbors[0][0] = pixel[0] + 1;
     else
-	pixel_neighbors[0][0] = pixel row;	/*This is itself, which will be in "already checked" list.  TODO: use null or -1 as flag to skip?  What is fastest to process? */
+	pixel_neighbors[0][0] = pixel[0];	/*This is itself, which will be in "already checked" list.  TODO: use null or -1 as flag to skip?  What is fastest to process? */
     /* east */
-    pixel_neighbors[1][0] = pixel row;
-    if (pixel column < files->ncols)
-	pixel_neighbors[1][1] = pixel column + 1;
+    pixel_neighbors[1][0] = pixel[0];
+    if (pixel[1] < files->ncols)
+	pixel_neighbors[1][1] = pixel[1] + 1;
     else
-	pixel_neighbors[1][1] = pixel column;	/* ditto... */
+	pixel_neighbors[1][1] = pixel[1];
-    /*TODO: continue for south and north */
+    /* south */
+    pixel_neighbors[2][1] = pixel[1];
+    if (pixel[0] < files->nrows)
+	pixel_neighbors[2][0] = pixel[0] - 1;
+    else
+	pixel_neighbors[2][0] = pixel[0];
+    /* west */
+    pixel_neighbors[3][0] = pixel[0];
+    if (pixel[1] < 0)
+	pixel_neighbors[3][1] = pixel[1] - 1;
+    else
+	pixel_neighbors[3][1] = pixel[1];
     /*TODO: seems there should be a more elegent way to do this... */
     return 0;
-find_eight_pixel_neighbors(pixel, neighbors)
+int find_eight_pixel_neighbors(int pixel[2], int pixel_neighbors[8][2],
     /* get the 4 orthogonal neighbors */
-    find_four_pixel_neighbors(pixel, neighbors);
+    find_four_pixel_neighbors(pixel, pixel_neighbors, files);
     /* get the 4 diagonal neighbors */
     /*TODO... continue as above */
     return 0;
+/* similarity / distance between two points based on their input raster values */
+/* TODO: I pulled getting the a values into the main function, they are stored in files.  Remove a from these parameters */
+double calculate_euclidean_similarity(int a[2], int b[2], struct files *files,
+    double val = 0;
+    int n;
+    /* get comparison values for point b (got values for a before loop on all neighbors... */
+    segment_get(&files->bands_seg, (void *)files->second_val, b[0], b[1]);
+    /* euclidean distance, sum the square differences for each dimension */
+    for (n = 0; n < files->nbands; n++) {
+	val = val + pow(files->bands_val[n] - files->second_val[n], 2);
+    val = sqrt(val);
+    return val;
+int merge_values(int Ri[100][2], int Rk[100][2], int Ri_count, int Rk_count,
+{				/* I assume this is a weighted mean? */
+    int n;
+    /*get input values, maybe if handle earlier gets correctly this can be avoided. */
+		Ri[0][1]);
+    segment_get(&files->bands_seg, (void *)files->second_val, Rk[0][0],
+		Rk[0][1]);
+	files->bands_val[n] =
+	    (files->bands_val[n] * Ri_count +
+	     files->second_val[n] * Rk_count) / (Ri_count + Rk_count);
+    /* update segment number and process flag ==0 */
+    files->out_val[1] = 0;	/*candidate pixel flag, only one merge allowed per t iteration */
+    /* for each member of Ri and Rk, write new average bands values and segment values */
+    for (n = 0; n < Ri_count; n++) {
+	segment_put(&files->bands_seg, (void *)files->bands_val, Ri[n][0],
+		    Ri[n][1]);
+	segment_put(&files->out_seg, (void *)files->out_val, Ri[n][0],
+		    Ri[n][1]);
+    for (n = 0; n < Rk_count; n++) {
+	segment_put(&files->bands_seg, (void *)files->bands_val, Rk[n][0],
+		    Rk[n][1]);
+	segment_put(&files->out_seg, (void *)files->out_val, Rk[n][0],
+		    Rk[n][1]);
+    return 0;
+/* TODO.. helper function, maybe make more general? */
+int set_candidate_flag(int Ri[100][2], int value, struct files *files)
+    /* Ri is list of pixels, value is new value of flag */
+    int n;
+    /* TODO: Ri data structure... eventually just need to process all pixels in Ri. */
+	segment_get(&files->out_seg, (void *)files->out_val, Ri[n][0], Ri[n][1]);	/* this may change... */
+	files->out_val[1] = value;	/*candidate pixel flag */
+		    Ri[n][1]);
+    return 0;
Modified: grass-addons/grass7/imagery/i.segment/iseg.h
--- grass-addons/grass7/imagery/i.segment/iseg.h	2012-06-09 17:42:15 UTC (rev 52018)
+++ grass-addons/grass7/imagery/i.segment/iseg.h	2012-06-10 05:04:16 UTC (rev 52019)
@@ -26,9 +26,13 @@
     int nbands;
     SEGMENT bands_seg, out_seg;	/* bands is for input, normal application is landsat bands, but other input can be included in the group. */
     double *bands_val;		/* array, to hold all input values at one pixel */
+    double *second_val;		/* to hold values at second point for similarity comparison */
     int *out_val;		/* array, to hold the segment ID and processing flag(s) */
     char *out_name;		/* name of output raster map */
+    /*int **no_check; *//* TODO maybe as SEGMENT.  Also can this be smaller then an int?  Just need to save 0 and 1. */
+    int no_check[100][2];
     /* RASTER_MAP_TYPE data_type;       Removed: input is always DCELL, output is CELL.
      *  TODO: if input might be smaller then DCELL, we could detect size and allocate accordingly. */
@@ -61,12 +65,10 @@
 struct functions
     int method;			/* Segmentation method */
-    int (*find_pixel_neighbors) (int *[], int *[][]);	/*pixel, pixel_neighbors *//*TODO need to define data types for these! */
+    int (*find_pixel_neighbors) (int[2], int[8][2], struct files *);	/*pixel, pixel_neighbors */
+    double (*calculate_similarity) (int[2], int[2], struct files *,
+				    struct functions *);
-    /*based on options, such as diagonal neighbors, etc, some function pointers:
-     *      calc_simularity
     int num_pn;			/* number of pixel neighbors  int, 4 or 8. */
     float threshold;		/* similarity threshold */
@@ -84,8 +86,15 @@
 int create_isegs(struct files *, struct functions *);
 int io_debug(struct files *, struct functions *);
 int region_growing(struct files *, struct functions *);
-int find_segment_neighbors(Ri, Rin);	/* TODO: need data structure for Ri, Rin */
+int find_segment_neighbors(int[][2], int[][2], int, int, struct files *, struct functions *);	/* TODO: need data structure for Ri, Rin */
+int set_candidate_flag(int[100][2], int, struct files *);
+int merge_values(int[100][2], int[100][2], int, int, struct files *);	/* I assume this is a weighted mean? */
+int find_four_pixel_neighbors(int[2], int[][2], struct files *);
+int find_eight_pixel_neighbors(int[2], int[8][2], struct files *);
+double calculate_euclidean_similarity(int[2], int[2], struct files *,
 /* write_output.c */
 /* also currently closes files */
 int write_output(struct files *);
Modified: grass-addons/grass7/imagery/i.segment/outline
--- grass-addons/grass7/imagery/i.segment/outline	2012-06-09 17:42:15 UTC (rev 52018)
+++ grass-addons/grass7/imagery/i.segment/outline	2012-06-10 05:04:16 UTC (rev 52019)
@@ -209,16 +209,17 @@
 While "to be checked" stack isn't empty:
 	pop
 	find pixel neighbors
-	with neighbors
+	with pixel neighbors
 		if in "don't check" list
 			do nothing
 		else
 			put in "don't check" list
-			add to "to be checked" stack
-			if segment ID = current segment ID
-				add to "current segment" list
-			else
-				add to "neighbor" list
+			if candidate pixel
+				if segment ID = current segment ID
+					add to "current segment" list
+					add to "to be checked" stack
+				else
+					add to "neighbor" list
 	next neighbor
 loop...
Modified: grass-addons/grass7/imagery/i.segment/parse_args.c
--- grass-addons/grass7/imagery/i.segment/parse_args.c	2012-06-09 17:42:15 UTC (rev 52018)
+++ grass-addons/grass7/imagery/i.segment/parse_args.c	2012-06-10 05:04:16 UTC (rev 52019)
@@ -48,6 +48,8 @@
 	_("Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for each pixel.");
+    /* input for distance function */
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -120,6 +122,9 @@
     /* note from tutorial: You may have got to use the complete name of the member function
      * including class-name and scope-operator (::).) */
+    /* TODO add user input for this */
+    functions->calculate_similarity = &calculate_euclidean_similarity;
     /* other data */
     files->nrows = Rast_window_rows();
     files->ncols = Rast_window_cols();
Modified: grass-addons/grass7/imagery/i.segment/write_output.c
--- grass-addons/grass7/imagery/i.segment/write_output.c	2012-06-09 17:42:15 UTC (rev 52018)
+++ grass-addons/grass7/imagery/i.segment/write_output.c	2012-06-10 05:04:16 UTC (rev 52019)
@@ -9,7 +9,7 @@
 int write_output(struct files *files)
-    int out_fd, row, col;
+    int out_fd, row, col, n;
     CELL *outbuf;
     outbuf = Rast_allocate_c_buf();	/*hold one row of data to put into raster */
@@ -43,6 +43,10 @@
     segment_close(&files->out_seg);
     Rast_close(out_fd);
+	G_free(files->no_check[n]);
+    G_free(files->no_check);
     /* anything else left to clean up? */
     return 0;
