[GRASS-SVN] r52065 - in grass/trunk/raster3d/r3.out.netcdf: . test_suite
Thu Jun 14 02:20:11 PDT 2012
Author: huhabla
Date: 2012-06-14 02:20:10 -0700 (Thu, 14 Jun 2012)
New Revision: 52065
   grass/trunk/raster3d/r3.out.netcdf/main.c
   grass/trunk/raster3d/r3.out.netcdf/r3.out.netcdf.html
   grass/trunk/raster3d/r3.out.netcdf/test_suite/test.r3.out.netcdf.sh
Code indention and documentation update
Modified: grass/trunk/raster3d/r3.out.netcdf/main.c
--- grass/trunk/raster3d/r3.out.netcdf/main.c	2012-06-14 06:35:44 UTC (rev 52064)
+++ grass/trunk/raster3d/r3.out.netcdf/main.c	2012-06-14 09:20:10 UTC (rev 52065)
@@ -1,11 +1,11 @@
- * MODULE:       r3.out.netcdf
+ * MODULE:       r3.out.netCDF
  * AUTHOR(S):    Soeren Gebbert
- * PURPOSE:      Export a 3D raster map as netcdf file
+ * PURPOSE:      Export a 3D raster map as netCDF file
  * COPYRIGHT:    (C) 2012 by the GRASS Development Team
@@ -51,7 +51,7 @@
 #define UNITS "units"
 #define DEGREES_EAST "degrees_east"
 #define DEGREES_NORTH "degrees_north"
-#define HISTORY_TEXT "GRASS GIS 7 NetCDF export of r3.out.netcdf"
+#define HISTORY_TEXT "GRASS GIS 7 netCDF export of r3.out.netcdf"
 #define CF_SUPPORT "CF-1.5"
 #define ERR(e) {fatalError(nc_strerror(e));}
@@ -94,7 +94,7 @@
     param.output = G_define_standard_option(G_OPT_F_OUTPUT);
     param.output->key = "output";
-    param.output->description = _("Name for netcdf output file");
+    param.output->description = _("Name for netCDF output file");
     param.null = G_define_option();
     param.null->key = "null";
@@ -103,7 +103,7 @@
     param.null->multiple = NO;
     param.null->description =
 	_
-	("The value to be used for null values, default is the NetCDF standard");
+	("The value to be used for null values, default is the netCDF standard");
     param.proj = G_define_flag();
     param.proj->key = 'p';
@@ -584,9 +584,9 @@
     G_gisinit(argv[0]);
     module = G_define_module();
     G_add_keyword(_("raster3d"));
-    G_add_keyword(_("netcdf"));
+    G_add_keyword(_("netCDF"));
     G_add_keyword(_("export"));
-    module->description = _("Export a 3D raster map as netcdf file.");
+    module->description = _("Export a 3D raster map as netCDF file.");
     /* Get parameters from user */
     setParams();
@@ -616,7 +616,7 @@
 	G_fatal_error(_("Error opening 3d raster map <%s>"),
 		      param.input->answer);
-    /* Create netcdf file */
+    /* Create netCDF file */
     if ((retval = nc_create(param.output->answer, NC_CLOBBER, &ncid)))
 	ERR(retval);
@@ -647,7 +647,7 @@
     if (!Rast3d_close(map))
 	fatalError(_("Unable to close 3D raster map"));
-    /* Close the netcdf file */
+    /* Close the netCDF file */
     if ((retval = nc_close(ncid)))
 	ERR(retval);
Modified: grass/trunk/raster3d/r3.out.netcdf/r3.out.netcdf.html
--- grass/trunk/raster3d/r3.out.netcdf/r3.out.netcdf.html	2012-06-14 06:35:44 UTC (rev 52064)
+++ grass/trunk/raster3d/r3.out.netcdf/r3.out.netcdf.html	2012-06-14 09:20:10 UTC (rev 52065)
@@ -1,76 +1,80 @@
 <h2>DESCRIPTION</h2>
-The module <em>r3.out.netcdf</em> exports a 3D raster map as NetCDF file.
+The module <em>r3.out.netcdf</em> exports a 3D raster map as netCDF file.
 Maps are valid 3D raster maps in the current mapset search path. The
-<em>output</em> parameter is the name of a NetCDF file that will be
+<em>output</em> parameter is the name of a netCDF file that will be
 written in the current working directory. The module is sensitive
 to mapset region settings (set with <em>g.region</em>) and the vertical unit settings
 of the 3D raster map. The vertical unit can be set with <a href="r3.support.html">r3.support</a>.
 <h2>Note</h2>
-The resulting NetCDF file will have time as third dimension in case a temporal
+The resulting netCDF file will have time as third dimension in case a temporal
 vertical unit is specified for the input map, otherwise the third dimension is assumed as spatial.
 If the 3D raster map has a time stamp with absolute time, the start time will be
-used as starting point for the NetCDF time series. If the absolute time stamp is missing
+used as starting point for the netCDF time series. If the absolute time stamp is missing
 the date "Jan. 01. 1900 00:00:00" will be used as default. In case of relative time stamp no start time
-is set in the NetCDF file. The number of depths of the 3D raster map are the number of time slices
-in the NetCDF file. You can use <em>t.rast.to.rast3</em> to convert a
+is set in the netCDF file. The number of depths of the 3D raster map are the number of time slices
+in the netCDF file. You can use <em>t.rast.to.rast3</em> to convert a
 space time raster dataset into a 3D raster map representing a space time voxel
-cube, then export the raster time series as NetCDF file.
+cube, then export the raster time series as netCDF file.
 <p>
-Spatial coordinates are exported as cell centered coordinates. The projection is stored
-in the metadata as <em>crs</em> attributes using a WKT parameter string.
-The export of projection parameters is suppressed when the XY-projection is set.
-The NetCDF projection metadata storage follows the spatial_ref GDAL/NetCDF suggestion
+Spatial coordinates are exported as cell centered coordinates. The projection can be optionally stored
+in the metadata as <em>crs</em> attributes .
+The netCDF projection metadata storage follows the spatial_ref GDAL/netCDF suggestion
 <a href="http://www.gdal.org/frmt_netcdf.html">here</a>
-and the NetCDF CF 1.6 convention
+and the netCDF CF 1.6 convention
 <a href="http://cf-pcmdi.llnl.gov/documents/cf-conventions/1.6/cf-conventions.html#coordinate-system">here</a>
 using WKT projection information. Additional a PROJ.4 string is
 stored in the <em>crs</em> attribute section.
+The export of projection parameters is suppressed when the XY-projection is set.
 <p>
-The NetCDF library must be installed on the system and activated at configuration time to compile this module.
+The range of the 3D raster map is set in the netCDF output file. Optionally a the netCDF missing value and
+_FillValue can be set using the <em>null</em> option. As default the netCDF floating point _FillValues are used
+to fill empty cell.
+<p>
+The netCDF library must be installed on the system and activated at configuration time to compile this module.
 <h2>Examples</h2>
-<h3>Using lat/lon projection without vertical unit specification</h3>
+<div class="code"><pre>
+g.region s=-90 n=90 w=-180 e=180 b=0 t=5 res=10 res3=10 tbres=1 -p3
-<p>Lets create a 3D raster map without the specification of a vertical unit</p>
+# We create a simple volume map with floating point values
-<div class="code"><pre>
-g.region s=-90 n=90 w=-180 e=180 b=0 t=50 res=10 res3=2 -p3
-r3.mapcalc expr="volume_double = double(col() + row() + depth())"
-r3.info
+r3.mapcalc --o expr="volume_float = float(col() + row() + depth())"
+r3.info volume_float
- | Layer:    volume_double                  Date: Wed May 16 20:08:22 2012    |
+ | Layer:    volume_float                   Date: Thu Jun 14 08:40:56 2012    |
  | Mapset:   PERMANENT                      Login of Creator: soeren          |
  | Location: TestLL                                                           |
  | DataBase: /1/soeren/grassdata                                              |
- | Title:    volume_double                                                    |
+ | Title:    volume_float                                                     |
  | Units:    none                                                             |
  | Vertical unit: units                                                       |
  | Timestamp: none                                                            |
  |   Type of Map:  3d cell              Number of Categories: 0               |
- |   Data Type:    DCELL                                                      |
- |   Rows:         90                                                         |
- |   Columns:      180                                                        |
- |   Depths:       25                                                         |
- |   Total Cells:  405000                                                     |
- |   Total size:           2835864 Bytes                                      |
- |   Number of tiles:      108                                                |
- |   Mean tile size:       26258 Bytes                                        |
- |   Tile size in memory:  32400 Bytes                                        |
- |   Number of tiles in x, y and  z:   6, 6, 3                                |
- |   Dimension of a tile in x, y, z:   30, 15, 9                              |
+ |   Data Type:    FCELL                                                      |
+ |   Rows:         18                                                         |
+ |   Columns:      36                                                         |
+ |   Depths:       5                                                          |
+ |   Total Cells:  3240                                                       |
+ |   Total size:           10114 Bytes                                        |
+ |   Number of tiles:      1                                                  |
+ |   Mean tile size:       10114 Bytes                                        |
+ |   Tile size in memory:  12960 Bytes                                        |
+ |   Number of tiles in x, y and  z:   1, 1, 1                                |
+ |   Dimension of a tile in x, y, z:   36, 18, 5                              |
  |        Projection: Latitude-Longitude (zone 0)                             |
- |            N:        90N    S:        90S   Res:     2                     |
- |            E:       180E    W:       180W   Res:     2                     |
- |            T:         50    B:          0   Res:     2                     |
- |   Range of data:   min =          3 max =        295                       |
+ |            N:        90N    S:        90S   Res:    10                     |
+ |            E:       180E    W:       180W   Res:    10                     |
+ |            T:          5    B:          0   Res:     1                     |
+ |   Range of data:   min =          3 max =         59                       |
  |   Data Source:                                                             |
@@ -80,147 +84,171 @@
  |    generated by r3.mapcalc                                                 |
  |   Comments:        |
- |    r3.mapcalc expression="volume_double = double(col() + row() + depth(\   |
+ |    r3.mapcalc expression="volume_float = float(col() + row() + depth())"   |
-</pre></div>
-<p>Export the map and show the NetCDF header</P>
+# We use the netCDF ncdump tool to have a look at the header
+# and coordinates of the exported netCDF file
-r3.out.netcdf input=volume_double output=test_double.nc
-ncdump -h test_double.nc
-netcdf test_double {
+r3.out.netcdf --o input=volume_float output=test_float.nc
+ncdump -c test_float.nc
+netcdf test_float {
 dimensions:
-	longitude = 180 ;
-	latitude = 90 ;
-	z = 25 ;
+        longitude = 36 ;
+        latitude = 18 ;
+        z = 5 ;
 variables:
-	char crs ;
-		crs:crs_wkt = "GEOGCS[\"wgs84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS_1984\",6378137,298.257223563]],PRIMEM[\"Greenwich\",0],UNIT[\"degree\",0.0174532925199433]]" ;
-		crs:spatial_ref = "GEOGCS[\"wgs84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS_1984\",6378137,298.257223563]],PRIMEM[\"Greenwich\",0],UNIT[\"degree\",0.0174532925199433]]" ;
-		crs:crs_proj4 = " +proj=longlat +no_defs +a=6378137 +rf=298.257223563 +towgs84=0.000,0.000,0.000" ;
-	float longitude(longitude) ;
-		longitude:units = "degrees_east" ;
-		longitude:long_name = "Longitude values" ;
-		longitude:standard_name = "longitude" ;
-		longitude:axis = "X" ;
-	float latitude(latitude) ;
-		latitude:units = "degrees_north" ;
-		latitude:long_name = "Latitude values" ;
-		latitude:standard_name = "latitude" ;
-		latitude:axis = "Y" ;
-	float z(z) ;
-		z:units = "meter" ;
-		z:long_name = "z coordinate of projection" ;
-		z:standard_name = "projection_z_coordinate" ;
-		z:positive = "up" ;
-		z:axis = "Z" ;
-	double volume_double(z, latitude, longitude) ;
-		volume_double:grid_mapping = "crs" ;
+        float longitude(longitude) ;
+                longitude:units = "degrees_east" ;
+                longitude:long_name = "Longitude values" ;
+                longitude:standard_name = "longitude" ;
+                longitude:axis = "X" ;
+        float latitude(latitude) ;
+                latitude:units = "degrees_north" ;
+                latitude:long_name = "Latitude values" ;
+                latitude:standard_name = "latitude" ;
+                latitude:axis = "Y" ;
+        float z(z) ;
+                z:units = "meter" ;
+                z:long_name = "z coordinate of projection" ;
+                z:standard_name = "projection_z_coordinate" ;
+                z:positive = "up" ;
+                z:axis = "Z" ;
+        float volume_float(z, latitude, longitude) ;
+                volume_float:valid_min = 3.f ;
+                volume_float:valid_max = 59.f ;
 // global attributes:
-		:Conventions = "CF-1.5" ;
-		:history = "GRASS GIS 7 NetCDF export of r3.out.netcdf" ;
+                :Conventions = "CF-1.5" ;
+                :history = "GRASS GIS 7 netCDF export of r3.out.netcdf" ;
+data:
+ longitude = -175, -165, -155, -145, -135, -125, -115, -105, -95, -85, -75,
+    -65, -55, -45, -35, -25, -15, -5, 5, 15, 25, 35, 45, 55, 65, 75, 85, 95,
+    105, 115, 125, 135, 145, 155, 165, 175 ;
+ latitude = 85, 75, 65, 55, 45, 35, 25, 15, 5, -5, -15, -25, -35, -45, -55,
+    -65, -75, -85 ;
+ z = 0.5, 1.5, 2.5, 3.5, 4.5 ;
-</pre></div>
-<p>Now we create a 3D raster map with a temporal vertical unit</p>
+# Exporting the projection specific settings and a null value
-r3.timestamp map=volume_time_double date='1 Jan 2001'
-r3.support map=volume_time_double vunit="days"
-r3.info
+r3.out.netcdf --o -p null=-1 input=volume_float output=test_float.nc
- | Layer:    volume_time_double             Date: Wed May 16 20:26:28 2012    |
- | Mapset:   PERMANENT                      Login of Creator: soeren          |
- | Location: TestLL                                                           |
- | DataBase: /1/soeren/grassdata                                              |
- | Title:    volume_time_double                                               |
- | Units:    none                                                             |
- | Vertical unit: days                                                        |
- | Timestamp: 1 Jan 2001                                         |
- |   Type of Map:  3d cell              Number of Categories: 0               |
- |   Rows:         90                                                         |
- |   Columns:      180                                                        |
- |   Depths:       25                                                         |
- |        Projection: Latitude-Longitude (zone 0)                             |
- |   Data Source:                                                             |
- |   Data Description:                                                        |
- |    generated by r3.mapcalc                                                 |
- |   Comments:        |
- |    r3.mapcalc expression="volume_time_double = double(col() + row() + d\   |
- |    epth())"        |
+dimensions:
+        longitude = 36 ;
+        latitude = 18 ;
+        z = 5 ;
+variables:
+        char crs ;
+                crs:crs_wkt = "GEOGCS[\"wgs84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS_1984\",6378137,298.257223563]],PRIMEM[\"Greenwich\",0],UNIT[\"degree\",0.0174532925199433]]" ;
+                crs:spatial_ref = "GEOGCS[\"wgs84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS_1984\",6378137,298.257223563]],PRIMEM[\"Greenwich\",0],UNIT[\"degree\",0.0174532925199433]]" ;
+                crs:crs_proj4 = " +proj=longlat +no_defs +a=6378137 +rf=298.257223563 +towgs84=0.000,0.000,0.000" ;
+        float z(z) ;
+                z:axis = "Z" ;
+                volume_float:missing_value = -1.f ;
+                volume_float:_FillValue = -1.f ;
+                volume_float:grid_mapping = "crs" ;
-</pre></div>
+// global attributes:
+data:
-<p>NetCDF header of an exported 3D raster map with vertical temporal unit in a Lat/Lon projection:</P>
-r3.out.netcdf --o input=volume_time_double output=test_time_double.nc
-ncdump -h test_time_double.nc
+    -65, -75, -85 ;
-netcdf test_time_double {
+# Assigning time as vertical unit and setting an absolute time stamp
+r3.timestamp map=volume_float date='1 Jan 2001/5 Jan 2001'
+r3.support map=volume_float vunit="days"
 dimensions:
-	longitude = 180 ;
-	latitude = 90 ;
-	time = 25 ;
+        longitude = 36 ;
+        latitude = 18 ;
+        time = 5 ;
 variables:
-	char crs ;
-	int time(time) ;
-		time:units = "days since 2001-01-01 00:00:00" ;
-		time:long_name = "Time in days" ;
-		time:calendar = "gregorian" ;
-		time:positive = "up" ;
-		time:axis = "T" ;
-	double volume_time_double(time, latitude, longitude) ;
-		volume_time_double:grid_mapping = "crs" ;
+        char crs ;
+        int time(time) ;
+                time:units = "days since 2001-01-01 00:00:00" ;
+                time:long_name = "Time in days" ;
+                time:calendar = "gregorian" ;
+                time:positive = "up" ;
+                time:axis = "T" ;
+        float volume_float(time, latitude, longitude) ;
+data:
+    -65, -75, -85 ;
+ time = 0, 1, 2, 3, 4 ;
 </pre></div>
 <h2>SEE ALSO</h2>
Modified: grass/trunk/raster3d/r3.out.netcdf/test_suite/test.r3.out.netcdf.sh
--- grass/trunk/raster3d/r3.out.netcdf/test_suite/test.r3.out.netcdf.sh	2012-06-14 06:35:44 UTC (rev 52064)
+++ grass/trunk/raster3d/r3.out.netcdf/test_suite/test.r3.out.netcdf.sh	2012-06-14 09:20:10 UTC (rev 52065)
@@ -13,21 +13,22 @@
 r3.mapcalc --o expr="volume_double = double(col() + row() + depth())"
 r3.mapcalc --o expr="volume_time_double = double(col() + row() + depth())"
 r3.mapcalc --o expr="volume_time_float = float(col() + row() + depth())"
-r3.timestamp map=volume_time_double date='1 Jan 1900/5 Jan 1900'
+r3.timestamp map=volume_time_double date='1 Jan 2001/5 Jan 2001'
 r3.timestamp map=volume_time_float date='5 seconds/10 seconds'
 r3.support map=volume_time_float vunit="seconds"
 # @test
-#r3.info volume_float
-#ncdump -h test_float.nc
+ncdump -h test_float.nc
 r3.out.netcdf --o null=-100 input=volume_double output=test_double.nc
-#r3.info volume_double
-#ncdump -h test_double.nc
+r3.info volume_double
+ncdump -h test_double.nc
 r3.out.netcdf --o -p input=volume_time_double output=test_time_double.nc
-#r3.info volume_time_double
-#ncdump -h test_time_double.nc
+r3.info volume_time_double
+ncdump -h test_time_double.nc
 r3.out.netcdf --o -p null=-1000 input=volume_time_float output=test_time_float.nc
-#r3.info volume_time_float
-#ncdump -h test_time_float.nc
+r3.info volume_time_float
+ncdump -h test_time_float.nc
+g.remove rast3=volume_float,volume_double,volume_time_double,volume_time_float
\ No newline at end of file
