[GRASS-SVN] r52176 - grass-addons/grass6/raster/r.in.onearth
Wed Jun 20 21:22:40 PDT 2012
Author: hamish
Date: 2012-06-20 21:22:40 -0700 (Wed, 20 Jun 2012)
New Revision: 52176
   grass-addons/grass6/raster/r.in.onearth/r.in.onearth.twms
reorg and merge, part 2
Modified: grass-addons/grass6/raster/r.in.onearth/r.in.onearth.twms
--- grass-addons/grass6/raster/r.in.onearth/r.in.onearth.twms	2012-06-21 02:46:36 UTC (rev 52175)
+++ grass-addons/grass6/raster/r.in.onearth/r.in.onearth.twms	2012-06-21 04:22:40 UTC (rev 52176)
@@ -92,34 +92,39 @@
 #%end
-#Only run if started in GRASS
+# Only run if started in GRASS
 if [ -z "$GISBASE" ] ; then
     echo "You must be in GRASS GIS to run this program." >&2
     exit 1
 fi
-#Parse the arguments
+# Parse the arguments
 if [ "$1" != "@ARGS_PARSED@" ] ; then
   exec g.parser "$0" "$@"
 fi
-#Set up important vars first
-SRC="EPSG:4326" #This is the Projection LatLong wgs84
-FORMAT="image/geotiff" #GeoTiff import for r.in.gdal
-NASASERVER="http://wms.jpl.nasa.gov/wms.cgi" #this server may change
-TYPE=""
-TIME=""
-IMPORT=0 #0 is true
-GLOBAL_MOSAIC_LAYER="global_mosaic_base" #Thats the NASA WMS Global Mosaic database
-SRTM_MAG_LAYER="srtm_mag" #Thats the NASA srtm_mag database
-BMNG_LAYER="BMNG" #Thats the Blue Marble Next Generation database
-DAILY_TERRA_LAYER="daily_terra" #Thats the NASA daily terra database
-DAILY_AQUA_LAYER="daily_aqua" #Thats the NASA daily aqua database
+# Set up important vars first
+BASE_URL="http://onearth.jpl.nasa.gov/wms.cgi"
+SRS="EPSG:4326"                           # This is Lat/Long WGS84
+FORMAT="image/jpeg"
+TILE_SIZE=512
+TYPE=""                                   # Pretty name of layer, no special chars
+TIME=""                                   # &time=YYYY-MM-DD time string for the MODIS time= option
+# Layer IDs:
+GLOBAL_MOSAIC_LAYER="global_mosaic_base"  # LANDSAT Global Mosaic
+SRTM_MAG_LAYER="srtm_mag"                 # srtm_mag (Space Shuttle Radar Topography Mission elevation)
+BMNG_LAYER="BMNG"                         # NASA' s Blue Marble Next Generation
+DAILY_TERRA_LAYER="daily_terra"           # Daily MODIS/TERRA
+DAILY_AQUA_LAYER="daily_aqua"             # Daily MODIS/AQUA
+IMPORT="true"
 USE_GDALWARP="true" #if we dont have gdalwarp, only LatLong projection is supported
-FILE_EXTENT=".tif"
+# try a few at once, but don't get abusive
+MAX_DL_JOBS=4
 # check if we have wget
 if [ ! -x "`which wget`" ] ; then
     g.message -e "wget required, please install first"
@@ -129,7 +134,7 @@
 # check if we have gdalwarp
 if [ ! -x "`which gdalwarp`" ] ; then
     g.message -w "gdalwarp is recommended, please install first (script still works in LatLong locations)"
-    USE_GDALWARP="false"  #use only LatLong
+    USE_GDALWARP="false"  # use only LatLong
 fi
@@ -138,265 +143,138 @@
-eval `g.region -g`
-if [ "$nsres" != "$ewres" ] ; then
-    g.message -e "East-West and North-South region resolution must be the same"
-    exit 1
-else
-    res="$nsres"
-fi
-#### find appropriate tile resolution
-fixed_res="
-0.000244140625
-0.00048828125
-0.0009765625
-0.001953125
-0.00390625
-0.0078125
-0.015625
-0.03125
-0.0625
-0.125
-0.25
-i=-3
-TAKE=9999
-TAKE_i=9999
-MIN=9999
-for val in $fixed_res ; do
-   # find nearest resolution:
-   #DIFF=`echo "$res $val" | awk '{printf("%.15g", $1 > $2 ? $1 - $2 : $2 - $1)}'`
-   # find nearest finer resolution:
-   DIFF=`echo "$res $val" | awk '{printf("%.15g", $1 > $2 ? $1 - $2 : 9999)}'`
-   NEW_MIN_DIFF=`echo "$MIN $DIFF" | awk '{printf("%d", $1 < $2 ? 0 : 1)}'`
-   if [ "$NEW_MIN_DIFF" -eq 1 ] ; then
-      MIN="$DIFF"
-      TAKE="$val"
-      TAKE_i="$i"
-   fi
-   i=`expr $i + 1`
-done
-if [ "$MIN" = "9999" ] ; then
-    #finer than the finest tested
-    TAKE_i=-3
-    TAKE=0.000244140625
-fi
-tile_res=`echo "$TAKE_i" | awk '{printf("%.15g", 2^$1)}'`
-g.message -i message="min_diff=$MIN  [2^$TAKE_i = $tile_res  ($TAKE * 512)]"
+# Get the data from the NASA server
+GetData()
+   IMPORT="true" #default
+   #local STRING="request=GetMap&layers=$LAYER&srs=$SRS&width=$WIDTH&height=$HEIGHT&bbox=$w,$s,$e,$n&format=$FORMAT&version=1.1.0&styles=$STYLE$TIME"
+   BASE_REQUEST="request=GetMap&layers=$LAYER&srs=$SRS&width=$TILE_SIZE&height=$TILE_SIZE"
+   BASE_META="format=$FORMAT&version=1.1.1&styles=$STYLE$TIME"
-#### adjust region to snap to grid
-# setup internal region
-g.region save="tmp_tiled_wms.$$"
-WIND_OVERRIDE="tmp_tiled_wms.$$"
-export WIND_OVERRIDE
+   local REQ_STRING="$BASE_REQUEST&$BBOX&$BASE_META"
+   URL="$BASE_URL?$REQ_STRING"
+   # Compose the filename
+   IMAGEFILE="$TMPDIR/OnEarth_${LAYER}_${STYLE}_$$.tif"
+   g.message -v "Download Data ..."
+   g.message -v "Requesting Data from '$BASE_URL'"
-g.region res="$TAKE" -a
-eval `g.region -g`
+   #download the File from the Server
+   #wget $WGET_OPTIONS --post-data="$REQ_STRING" "$BASE_URL" -O "$IMAGEFILE"
-# snap lat,long to upper-left corner of nearest tile grid node
-# Round lat to nearest grid node
-#lat = 90.0   - round( (90.0 - lat) / $res) * $res;
-#lon = -180.0 + floor( (180.0 + lon) / $res) * $res;
-# diff is always positive here, so int() acts like floor().
-n=`echo "$n $tile_res" | \
-   awk '{ printf("%.15g", 90.0 - int((90.0 - $1) / $2) * $2) }'`
-s=`echo "$s $tile_res" | awk '
- function ceil(x)
-   return (x == int(x)) ? x : int(x)+1
-   printf("%.15g", 90.0 - ceil((90.0 - $1) / $2) * $2)
-w=`echo "$w $tile_res" | \
-   awk '{ printf("%.15g", -180.0 + int((180.0 + $1) / $2) * $2) }'`
-e=`echo "$e $tile_res" | awk '
- function ceil(x)
-   printf("%.15g", -180.0 + ceil((180.0 + $1) / $2) * $2)
-#needed?
-#g.region n=$n s=$s e=$e w=$w
-#NUM_TILES_x=`echo "$e $w $tile_res" | awk '{ printf("%d", 1 + (($1 - $2) / $3)) }'`
-#NUM_TILES_y=`echo "$n $s $tile_res" | awk '{ printf("%d", 1 + (($1 - $2) / $3)) }'`
-NUM_TILES_x=`echo "$e $w $tile_res" | awk '{ printf("%d", ($1 - $2) / $3) }'`
-NUM_TILES_y=`echo "$n $s $tile_res" | awk '{ printf("%d", ($1 - $2) / $3) }'`
-TOTAL_TILES=`expr $NUM_TILES_x \* $NUM_TILES_y`
-if [ "$TOTAL_TILES" -gt 200 ] ; then
-    g.message -w "You've told it to download $TOTAL_TILES tiles from NASA's server. Are you sure you want to do that?"
-    read result
-    case $result in
-       y | yes | Y | Yes | YES)
-	  g.message -i "Aborting."
-	  exit 1
-     esac
-fi
-# start of todo code dump
-LAYER="global_mosaic_base"
-STYLE="visual"
-BASE_URL="http://onearth.jpl.nasa.gov/wms.cgi"
-BASE_REQUEST="request=GetMap&layers=$LAYER&srs=EPSG:4326&width=512&height=512"
-BASE_META="format=image/jpeg&version=1.1.1&styles=$STYLE"
-# try a few at once, but don't get abusive
-MAX_DL_JOBS=4
-for i in `seq $NUM_TILES_x` ; do
-   i_str=`echo "$i" | awk '{printf("%04d", $1)}'`
+   OLDDIR=`pwd`
+   cd "$TMDDIR"
+   for i in `seq $NUM_TILES_x` ; do
+      i_str=`echo "$i" | awk '{printf("%04d", $1)}'`
+      for j in `seq $NUM_TILES_y` ; do
+         j_str=`echo "$j" | awk '{printf("%04d", $1)}'`
+         minx=$(echo "$w $i $tile_res" | awk '{printf("%.9f", $1 + (($2 - 1) * $3))}')
+         maxx=$(echo "$w $i $tile_res" | awk '{printf("%.9f", $1 + ($2 * $3))}')
+         maxy=$(echo "$n $j $tile_res" | awk '{printf("%.9f", $1 - (($2 - 1) * $3))}')
+         miny=$(echo "$n $j $tile_res" | awk '{printf("%.9f", $1 - ($2 * $3))}')
+         BBOX_TILE="$minx,$miny,$maxx,$maxy"
+         BBOX="bbox=$BBOX_TILE"
+         g.message -d message="  $BBOX"
+         g.message -d "URL is [$BASE_URL?$REQ_STRING]"
+         #CMD="wget -nv \"$URL\" -O twms_${i_str}_${j_str}.jpg"
+         CMD="wget -nv --post-data="$REQ_STRING" "$BASE_URL" -O twms_${i_str}_${j_str}.jpg"
+         MODULUS=`echo "$j $MAX_DL_JOBS" | awk '{print $1 % $2}'`
+         g.message -d message="modulus=$MODULUS"
+         if [ "$MODULUS" = "0" ] || [ "$j" = "$NUM_TILES_y" ] ; then
+             # stall to let the background jobs finish
+            g.message -v "Downloading tile [$i,$j] of [${NUM_TILES_x}x$NUM_TILES_y]."
+            eval $CMD
+	    EXITCODE=$?
+	    wait
+	    if [ "$EXITCODE" -ne 0 ] ; then
+               g.message -e "wget was not able to download the data"
+               IMPORT="false"
+               return 1
+            fi
+         else
+            g.message -v "Downloading tile [$i,$j] of [${NUM_TILES_x}x$NUM_TILES_y],"
+            eval $CMD &
+         fi
+         wait
+      done
+   done
+   #### some checks before going on
+   if [ `ls -1 twms_*.jpg | wc -l` -lt "$TOTAL_TILES" ] ; then
+       g.message -e "Tile(s) appear to be missing."
+       IMPORT="false"
+       return 1
+   fi
+   for file in twms_*.jpg ; do
+       if [ ! -s "$file" ] ; then
+   	g.message -e "<$file> appears to be empty."
+	IMPORT="false"
+   	return 1
+       fi
+       if [ `file "$file" | grep -c JPEG` -eq 0 ] ; then
+   	g.message -e "<$file> appears to be bogus."
+   	if [ `file "$file" | grep -c XML` -eq 1 ] && [ "$GRASS_VERBOSE" = "true" ] ; then
+   	   cat "$file"
+   	fi
+	IMPORT="false"
+   	return 1
+       fi
+   done
+   g.message -v "Converting to pnm ..." 1>&2
+       jpegtopnm "$file" > `basename "$file" .jpg`.pnm
+   done
+   g.message -v "Patching ..." 1>&2
-      minx=$(echo "$w $i $tile_res" | awk '{printf("%.9f", $1 + (($2 - 1) * $3))}')
-      maxx=$(echo "$w $i $tile_res" | awk '{printf("%.9f", $1 + ($2 * $3))}')
-      maxy=$(echo "$n $j $tile_res" | awk '{printf("%.9f", $1 - (($2 - 1) * $3))}')
-      miny=$(echo "$n $j $tile_res" | awk '{printf("%.9f", $1 - ($2 * $3))}')
-      BBOX_TILE="$minx,$miny,$maxx,$maxy"
-      BBOX="bbox=$BBOX_TILE"
-      g.message -d message="  $BBOX"
-      URL="$BASE_URL?$BASE_REQUEST&$BBOX&$BASE_META"
-      CMD="wget -nv \"$URL\" -O twms_${i_str}_${j_str}.jpg"
-      MODULUS=`echo "$j $MAX_DL_JOBS" | awk '{print $1 % $2}'`
-      g.message -d message="modulus=$MODULUS"
-      if [ "$MODULUS" = "0" ] || [ "$j" = "$NUM_TILES_y" ] ; then
-          # stall to let the background jobs finish
-         g.message -v "Downloading tile [$i,$j] of [${NUM_TILES_x}x$NUM_TILES_y]."
-         eval $CMD
-         wait
-      else
-         g.message -v "Downloading tile [$i,$j] of [${NUM_TILES_x}x$NUM_TILES_y],"
-         eval $CMD &
-      fi
-      wait
+      tilefiles=`ls twms_*_${j_str}.pnm`
+      #echo $tilefiles
+      pnmcat -lr $tilefiles > "row_${j_str}.pnm"
    done
-done
+   pnmcat -tb row_*.pnm | pnmtojpeg --quality=75 > "mosaic_$$.jpg"
+   rm -f twms_*.pnm twms_*.jpg row*.pnm
+   #not needed
+   #far_e=$(echo "$e $tile_res" | awk '{printf("%.9f", $1 + $2)}')
+   #far_s=$(echo "$s $tile_res" | awk '{printf("%.9f", $1 - $2)}')
-#### some checks before going on
-if [ `ls -1 twms_*.jpg | wc -l` -lt "$TOTAL_TILES" ] ; then
-    g.message -e "Tile(s) appear to be missing."
-    exit 1
-fi
+   # Convert to GeoTIFF
+   gdal_translate "mosaic_$$.jpg" "mosaic_$$.tif" \
+      -a_srs EPSG:4326 -a_ullr $w $n $e $s
+      #-co COMPRESS=DEFLATE
+   mv "mosaic_$$.tif" "$IMAGEFILE"
+   \rm "mosaic_$$.jpg"
-for file in twms_*.jpg ; do
-    if [ ! -s "$file" ] ; then
-	echo "ERROR: <$file> appears to be empty." 1>&2
-	exit 1
-    fi
-    if [ `file "$file" | grep -c JPEG` -eq 0 ] ; then
-	echo "ERROR: <$file> appears to be bogus." 1>&2
-	if [ `file "$file" | grep -c XML` -eq 1 ] && [ "$GRASS_VERBOSE" = "true" ] ; then
-	   cat "$file"
-	fi
-	exit 1
-    fi
-done
-g.message -v "Converting to pnm ..." 1>&2
-    jpegtopnm "$file" > `basename "$file" .jpg`.pnm
-done
-g.message -v "Patching ..." 1>&2
-for j in `seq $NUM_TILES_y` ; do
-   j_str=`echo "$j" | awk '{printf("%04d", $1)}'`
-   tilefiles=`ls twms_*_${j_str}.pnm`
-   #echo $tilefiles
-   pnmcat -lr $tilefiles > "row_${j_str}.pnm"
-done
-rm -f twms_*.pnm twms_*.jpg row*.pnm
-#not needed
-#far_e=$(echo "$e $tile_res" | awk '{printf("%.9f", $1 + $2)}')
-#far_s=$(echo "$s $tile_res" | awk '{printf("%.9f", $1 - $2)}')
-gdal_translate mosaic_$$.jpg mosaic_$$.tif \
-  -a_srs EPSG:4326 -a_ullr $w $n $e $s
-  #-co COMPRESS=DEFLATE
-r.in.gdal in="mosaic_$$.tif" out="tmp_rio_$$" \
-   title="NASA OnEarth WMS $LAYER ($STYLE)"
-for COLOR in red green blue ; do
-   r.support "tmp_rio_$$.$COLOR" \
-      history="Data downloaded from NASA's OnEarth WMS server with r.in.onearth"
-done
-# free up the disk space ASAP
-\rm "mosaic_$$.tif"
-# end of todo code dump
-#Some functions
-#Get the data from the NASA server
-GetData()
-   IMPORT=0 #default
-   local STRING="request=GetMap&layers=$LAYER&srs=$SRC&width=$WIDTH&height=$HEIGHT&bbox=$w,$s,$e,$n&format=$FORMAT&version=1.1.0&styles=$STYLE$TIME"
-   #echo $STRING
-   #Create thefilename
-   IMAGEFILE="$TMPDIR/Image_${LAYER}_${STYLE}_${HEIGHT}_$WIDTH"
-   g.message -v "**** DOWNLOAD DATA ****"
-   g.message -v "Requesting Data from $NASASERVER"
-   #download the File from the Server
-   wget $WGET_OPTIONS --post-data="$STRING" "$NASASERVER" -O "$IMAGEFILE"
-   if [ $? -ne 0 ] ; then
-     g.message -e "wget was not able to download the data"
-     IMPORT=1
-     return 1
-   fi
    if [ -f "$IMAGEFILE" ] ; then
-     IMPORT=0
+     IMPORT="true"
    else
-     IMPORT=1
+     IMPORT="false"
      return 1
    fi
-return 0
+   return 0
 #warp the data to the current grass locationa via gdalwarp
 WarpData()
@@ -406,7 +284,7 @@
 	IMAGEFILE_GDALWARP="$TMPDIR/Image_${LAYER}_${STYLE}_${HEIGHT}_${WIDTH}_gdalwarp"
 	   #convert the data to the current location, create Erdas Imagine Images (HFA)
-	gdalwarp -s_srs "$SRC" -t_srs "`g.proj -wf`" -of HFA \
+	gdalwarp -s_srs "$SRS" -t_srs "`g.proj -wf`" -of HFA \
 	    "$IMAGEFILE" "$IMAGEFILE_GDALWARP"
 	  g.message -i '!-------- CAN NOT CONVERT DATA --------!'
@@ -426,54 +304,65 @@
 #Import the Data with r.in.gdal
 ImportData()
-   if [ "$IMPORT" -eq 0 ] ; then
-	#Check if Tiff file
-	FILETYPE=`file  "$IMAGEFILE" | cut --fields=2 --delimiter=:`
-	echo "$FILETYPE" | grep TIFF > /dev/null
-	    g.message -i "Downloaded file is not a GeoTiff file, but will try to import"
-	fi
-	g.message -v "**** CHECK DATA ****"
-	gdalinfo "$IMAGEFILE" | grep "GDALOpen failed" > /dev/null
-	local ReturnValueGdalBug=$?
-	local ReturnValueGdal=$?
+    if [ "$IMPORT" != "true" ] ; then
+	return 0
+    fi
-	if [ "$ReturnValueGdal" -eq 0 ] && [ "$ReturnValueGdalBug" -ne 0 ] ; then
-	    g.message -v "**** DATA CHECK OK ****"
-	    #Copy or import
-	    if [ "$GIS_FLAG_F" -eq 1 ] ; then
-		#Copy the data to the outputfile
-		g.message -v "Creating output file $GIS_OPT_FILE$TYPE$STYLE$FILE_EXTENT"
-		cp "$IMAGEFILE" "$GIS_OPT_FILE$TYPE$STYLE$FILE_EXTENT"
-	    else
-		#Warp the data!
-		WarpData
-		g.message -v "**** IMPORT DATA ****"
-		r.in.gdal -o input="$IMAGEFILE" \
-		     output="$GIS_OPT_OUTPUT${TYPE}_$STYLE"
-	    fi
-	else
-	    echo '!-------------------BREAK---------------------!'
-	    echo "Downloaded file is not supported by gdal, or cannot be imported"
-	    if [ $ReturnValueGdalBug -eq 0 ] ; then
-		echo "There was a problem while downloading the file, maybe you should try it again."
-	    fi
-	    g.message -v "File of Type: $FILETYPE"
-	    #If the File is XML, then cat the contents to stdout
-	    echo "$FILETYPE" | grep XML > /dev/null
-	    if [ $? -eq 0 ] ; then
-		g.message " "
-		g.message "Message from Server $NASASERVER"
-		echo " "
-		echo '!------------BEGIN-ERROR-MESSGAE--------------!'
-		cat "$IMAGEFILE"
-		echo '!-------------END-ERROR-MESSGAE---------------!'
-	    fi
-	fi
-	rm -rf "$IMAGEFILE"
+    #Check if Tiff file
+    FILETYPE=`file  "$IMAGEFILE" | cut -f2 -d':'`
+    g.message -v "File of Type: $FILETYPE"
+    if [ `echo "$FILETYPE" | grep -c 'TIFF'` -ne 1 ] ; then
+    	g.message -w "Downloaded file does not appear to be a TIFF image, but will try to import anyway"
     fi
+    g.message -v "Checking Data ..."
+    gdalinfo "$IMAGEFILE" > /dev/null
+    if [ $? -ne 0 ] ; then
+    	g.message -e "Downloaded file is not supported by gdal, or cannot be imported"
+    	#if [ $ReturnValueGdalBug -eq 0 ] ; then
+    	#    echo "There was a problem while downloading the file, maybe you should try it again."
+    	#fi
+    	#If the File is XML, then cat the contents to stdout
+    	echo "$FILETYPE" | grep XML > /dev/null
+    	if [ $? -eq 0 ] ; then
+    	    g.message " "
+    	    g.message "Message from Server $BASE_URL"
+    	    echo " " 1>&2
+    	    echo '!------------BEGIN-ERROR-MESSGAE--------------!' 1>&2
+    	    cat "$IMAGEFILE" 1>&2
+    	    echo '!-------------END-ERROR-MESSGAE---------------!' 1>&2
+    	fi
+    fi
+    g.message -d "Data checked & was ok."
+    ### Copy or import
+    if [ "$GIS_FLAG_F" -eq 1 ] ; then
+    	# Copy the data to the output file
+    	g.message -v "Creating output file $GIS_OPT_FILE$TYPE$STYLE$FILE_EXTENT"
+    	cp "$IMAGEFILE" "$GIS_OPT_FILE$TYPE$STYLE$FILE_EXTENT"
+    else
+    	# Warp the data!
+    	WarpData
+    	g.message -v "Importing image ..."
+	OUTNAME=`basename "$GIS_OPT_OUTPUT" _`
+	OUTNAME="${OUTNAME}_${TYPE}_$STYLE"
+	r.in.gdal input="$IMAGEFILE" output="$OUTNAME" \
+	   title="NASA OnEarth WMS $LAYER ($STYLE)"
+	for COLOR in red green blue ; do
+	   r.support "$OUTNAME.$COLOR" \
+	      history="Data downloaded from NASA's OnEarth WMS server with r.in.onearth"
+	done
+    fi
+    # free up the disk space ASAP
+    rm -f "$IMAGEFILE"
     return 0
@@ -482,6 +371,7 @@
 exitprocedure()
     g.message 'User break!'
+    cd ..
     rm -rf "$TMPDIR"
     unset WIND_OVERRIDE
     g.remove region="tmp_tiled_wms.$$" --quiet
@@ -499,10 +389,14 @@
 #Check if a file or a map should be created
-    if [ -z "$GIS_OPT_FILE"] ; then
-	  g.message -e "Please specify the output filename"
+    if [ -z "$GIS_OPT_FILE" ] ; then
+	g.message -e "Please specify an output filename"
 	exit 1
     fi
+    if [ -e "$GIS_OPT_FILE" ] ; then
+	g.message -e "Output filename already exists. Will not overwrite. Aborting."
+	exit 1
+    fi
 fi
 #Some mapset informations
@@ -514,14 +408,28 @@
 #wget has many options
 WGET_OPTIONS="$GIS_OPT_WGETOPT"
-#Get the region data
-eval `g.region -g`
-WIDTH="$cols"
-HEIGHT="$rows"
-eval `g.region -gb`
+# Tiled WMS is locked at one size fits all
+WIDTH="$TILE_SIZE"
+HEIGHT="$TILE_SIZE"
+# are we in the server's native projection?
+PROJ_CODE=`g.region -p | grep '^projection:' | awk '{print $2}'`
+DATUM=`g.region -p | grep '^datum:' | awk '{print $2}'`
+if [ $PROJ_CODE -eq 3 ] && [ `echo "$DATUM" | grep -ci 'wgs84'` -eq 1 ] ; then
+   IS_4326="true"
+else
+   IS_4326="false"
+fi
+# start of old code
 #Now get the LatLong Boundingbox
-grep -i 'proj: ll' $PERM/PROJ_INFO > /dev/null
-if [ $? -ne 0 ] && [ "$USE_GDALWARP" = "true" ] ; then
+if [ "$IS_4326" = "false" ] && [ "$USE_GDALWARP" = "true" ] ; then
+    eval `g.region -gb`
     n="$ll_n"
     s="$ll_s"
     e="$ll_e"
@@ -530,6 +438,9 @@
 else
     #We have LatLong projection, no warp is needed!
+fi
+if [ 0 -eq 1 ] ; then
     #There is a bug in nasa WMS service, it provides images which are lager then
     #the world :(, we have to crop the images
     if [ "$n" = "90" -a "$s" = "-90" ] && \
@@ -547,18 +458,146 @@
 	w=`echo "$w + 0.001" | bc`
     fi
 fi
+###old
+# end of old code
 #Break If we have no warp and no LatLong
-grep -i 'proj: ll' "$PERM/PROJ_INFO" > /dev/null
-if [ $? -ne 0 ] && [ "$USE_GDALWARP" = "false" ] ; then
-    g.message -e "NASA OnEarth data are in Latitude/Longitude. The \
+if [ "$IS_4326" = "false" ] && [ "$USE_GDALWARP" = "false" ] ; then
+    g.message -e "NASA OnEarth data are in Latitude-Longitude WGS84. The \
 		  current location projection differs and you don't \
-		  have gdalwarp! STOP."
+		  have 'gdalwarp' installed. Aborting."
     exit 1
 fi
-#make a temporary directory
+# start of todo code dump
+eval `g.region -g`
+if [ "$nsres" != "$ewres" ] ; then
+    g.message -e "East-West and North-South region resolution must be the same"
+    exit 1
+else
+    res="$nsres"
+fi
+#### find appropriate tile resolution
+fixed_res="
+0.000244140625
+0.00048828125
+0.0009765625
+0.001953125
+0.00390625
+0.0078125
+0.015625
+0.03125
+0.0625
+0.125
+0.25
+i=-3
+TAKE=9999
+TAKE_i=9999
+MIN=9999
+for val in $fixed_res ; do
+   # find nearest resolution:
+   #DIFF=`echo "$res $val" | awk '{printf("%.15g", $1 > $2 ? $1 - $2 : $2 - $1)}'`
+   # find nearest finer resolution:
+   DIFF=`echo "$res $val" | awk '{printf("%.15g", $1 > $2 ? $1 - $2 : 9999)}'`
+   NEW_MIN_DIFF=`echo "$MIN $DIFF" | awk '{printf("%d", $1 < $2 ? 0 : 1)}'`
+   if [ "$NEW_MIN_DIFF" -eq 1 ] ; then
+      MIN="$DIFF"
+      TAKE="$val"
+      TAKE_i="$i"
+   fi
+   i=`expr $i + 1`
+done
+if [ "$MIN" = "9999" ] ; then
+    #finer than the finest tested
+    TAKE_i=-3
+    TAKE=0.000244140625
+fi
+tile_res=`echo "$TAKE_i" | awk '{printf("%.15g", 2^$1)}'`
+g.message -i message="min_diff=$MIN  [2^$TAKE_i = $tile_res  ($TAKE * 512)]"
+#### adjust region to snap to grid
+# setup internal region
+g.region save="tmp_tiled_wms.$$"
+WIND_OVERRIDE="tmp_tiled_wms.$$"
+export WIND_OVERRIDE
+g.region res="$TAKE" -a
+eval `g.region -g`
+# snap lat,long to upper-left corner of nearest tile grid node
+# Round lat to nearest grid node
+#lat = 90.0   - round( (90.0 - lat) / $res) * $res;
+#lon = -180.0 + floor( (180.0 + lon) / $res) * $res;
+# diff is always positive here, so int() acts like floor().
+n=`echo "$n $tile_res" | \
+   awk '{ printf("%.15g", 90.0 - int((90.0 - $1) / $2) * $2) }'`
+s=`echo "$s $tile_res" | awk '
+ function ceil(x)
+   return (x == int(x)) ? x : int(x)+1
+   printf("%.15g", 90.0 - ceil((90.0 - $1) / $2) * $2)
+w=`echo "$w $tile_res" | \
+   awk '{ printf("%.15g", -180.0 + int((180.0 + $1) / $2) * $2) }'`
+e=`echo "$e $tile_res" | awk '
+ function ceil(x)
+   printf("%.15g", -180.0 + ceil((180.0 + $1) / $2) * $2)
+# needed?
+#g.region n=$n s=$s e=$e w=$w
+#NUM_TILES_x=`echo "$e $w $tile_res" | awk '{ printf("%d", 1 + (($1 - $2) / $3)) }'`
+#NUM_TILES_y=`echo "$n $s $tile_res" | awk '{ printf("%d", 1 + (($1 - $2) / $3)) }'`
+NUM_TILES_x=`echo "$e $w $tile_res" | awk '{ printf("%d", ($1 - $2) / $3) }'`
+NUM_TILES_y=`echo "$n $s $tile_res" | awk '{ printf("%d", ($1 - $2) / $3) }'`
+TOTAL_TILES=`expr $NUM_TILES_x \* $NUM_TILES_y`
+if [ "$TOTAL_TILES" -gt 200 ] ; then
+    g.message -w "You've told it to download $TOTAL_TILES tiles from NASA's server. Are you sure you want to do that?"
+    read result
+    case $result in
+       y | yes | Y | Yes | YES)
+	  g.message -i "Aborting."
+	  exit 1
+     esac
+fi
+# end of todo code dump
+# make a temporary directory
 TMPDIR="`g.tempfile pid=$$`"
 if [ $? -ne 0 ] || [ -z "$TMPDIR" ] ; then
     g.message -e "Unable to create temporary files"
@@ -567,24 +606,24 @@
 rm -f "$TMPDIR"
 mkdir "$TMPDIR"
-#Get the Data and import them
-#import every choice that can be made
+# Get the Data and import
+#  allow multiple outputs: import every choice that can be made
 if [ $GIS_FLAG_L -eq 1 ] ; then
     LAYER="$GLOBAL_MOSAIC_LAYER"
     STYLE="$GIS_OPT_TMBAND"
     TYPE="LandsatTM"
-    g.message -v "Will download and import $TYPE Data with band $STYLE"
+    g.message -v "Will download and import $TYPE Data for band $STYLE"
     GetData
     ImportData
 fi
 if [ $GIS_FLAG_S -eq 1 ] ; then
     LAYER="$SRTM_MAG_LAYER"
     STYLE="$GIS_OPT_SRTMBAND"
     TYPE="SRTM"
     GetData
     ImportData
 fi
@@ -593,7 +632,7 @@
     LAYER="$BMNG_LAYER"
     STYLE="$GIS_OPT_MONTH"
     TYPE="BMNG"
-    g.message -v "Will download and import $TYPE Data of month $STYLE"
+    g.message -v "Will download and import $TYPE Data for the month of $STYLE"
     GetData
     ImportData
 fi
@@ -618,12 +657,13 @@
     ImportData
 fi
 #remove the temp dir
 rm -rf "$TMPDIR"
 unset WIND_OVERRIDE
-g.message -v "Finished"
+g.message -v "$0 Done."
-exit 0
+exit
