[GRASS-SVN] r52231 - grass-addons/grass7/vector/v.surf.icw
    svn_grass at osgeo.org
    Tue Jun 26 04:55:53 PDT 2012
Author: hamish
Date: 2012-06-26 04:55:52 -0700 (Tue, 26 Jun 2012)
New Revision: 52231
   grass-addons/grass7/vector/v.surf.icw/v.surf.icw.py
enable full parallelization
Modified: grass-addons/grass7/vector/v.surf.icw/v.surf.icw.py
--- grass-addons/grass7/vector/v.surf.icw/v.surf.icw.py	2012-06-26 11:55:10 UTC (rev 52230)
+++ grass-addons/grass7/vector/v.surf.icw/v.surf.icw.py	2012-06-26 11:55:52 UTC (rev 52231)
@@ -125,7 +125,8 @@
 def cleanup():
     grass.verbose(_("Cleanup.."))
     tmp_base = 'tmp_icw_' + str(os.getpid()) + '_'
-    grass.run_command('g.mremove', flags = 'f', rast = tmp_base + '*', quiet = True)
+    grass.run_command('g.mremove', flags = 'f', rast = tmp_base + '*',
+    		      quiet = True)
 def main():
@@ -142,6 +143,8 @@
     if workers is 1 and "WORKERS" in os.environ:
         workers = int(os.environ["WORKERS"])
+    if workers < 1:
+        workers = 1
     pid = str(os.getpid())
     tmp_base = 'tmp_icw_' + pid + '_'
@@ -156,7 +159,8 @@
             grass.fatal(_("Raster map <%s> not found") % post_mask)
     grass.verbose(_("v.surf.icw -- Inverse Cost Weighted Interpolation"))
-    grass.verbose(_("Processing %s -> %s, column=%s, Cf=%g") % (pts_input, output, column, friction))
+    grass.verbose(_("Processing %s -> %s, column=%s, Cf=%g")
+    		  % (pts_input, output, column, friction))
     if flags['r']:
         grass.verbose(_("Using (d^n)*log(d) radial basis function."))
@@ -176,7 +180,8 @@
     try:
        coltype = grass.vector_columns(pts_input, layer)[column]
     except KeyError:
-        grass.fatal(_("Data column <%s> not found in vector points map <%s>") % (column, pts_input))
+        grass.fatal(_("Data column <%s> not found in vector points map <%s>")
+		    % (column, pts_input))
     if coltype['type'] not in ('INTEGER', 'DOUBLE PRECISION'):
         grass.fatal(_("Data column must be numberic"))
@@ -184,7 +189,8 @@
     # cleanse cost area mask to a flat =1 for my porpoises
     area_mask = tmp_base + 'area'
     grass.mapcalc("$result = if($cost_map, 1, null())",
-                  result = area_mask, cost_map = cost_map)
+                  result = area_mask, cost_map = cost_map,
+		  quiet = True)
     ## done with prep work,
@@ -217,7 +223,7 @@
     #### generate cost maps for each site in range
-    grass.message(_("Generating cost maps.."))
+    grass.message(_("Generating cost maps ..."))
     # avoid do-it-yourself brain surgery
     points_list_orig = list(points_list)
@@ -241,8 +247,9 @@
             n -= 1
             continue
 	else:
-	    grass.message(_("Site %d of %d,  e=%.4f  n=%.4f  cat=%d  data=%.8g") % (num, n,
-                          float(easting), float(northing), cat, float(data_value)))
+	    grass.message(_("Site %d of %d,  e=%.4f  n=%.4f  cat=%d  data=%.8g")
+	    		  % (num, n, float(easting), float(northing), cat,
+			     float(data_value)))
 	# we know the point is in the region, but is it in a non-null area of the cost surface?
         rast_val = grass.read_command('r.what', input = area_mask,
@@ -261,33 +268,56 @@
 	    grass.fatal('Data value [%s] is non-numeric' % data_value)
         cost_site_name = tmp_base + 'cost_site.' + '%05d' % num
-        ret = grass.run_command('r.cost', flags = 'k', input = area_mask,
-                                output = cost_site_name,
-			        coordinate = easting + ',' + northing, quiet = True)
-        if ret is not 0:
-	    grass.fatal(_('Problem running %s') % 'r.cost')
+        proc[num-1] = grass.start_command('r.cost', flags = 'k', input = area_mask,
+	                                output = cost_site_name,
+				        coordinate = easting + ',' + northing,
+					quiet = True)
+	# stall to wait for the nth worker to complete,
+	if num % workers is 0:
+	    proc[num-1].wait()
+        num += 1
+    # make sure everyone is finished
+    for i in range(n):
+        if proc[i].wait() is not 0:
+	    grass.fatal(_('Problem running %s') % 'r.cost')
+    grass.message(_("Removing anomalies at site positions ..."))
+    proc = {}
+        cost_site_name = tmp_base + 'cost_site.' + '%05d' % (i+1)
         #max_cost="$GIS_OPT_MAX_COST"  : commented out until r.null cleansing/continue code is sorted out
         #start_points=tmp_idw_cost_site_$$
         # we do this so the divisor exists and the weighting is huge at the exact sample spots
         # more efficient to reclass to 1?
-        grass.mapcalc("$cost_n_cleansed = if($cost_n == 0, 0.1, $cost_n)",
+        proc[i] = grass.mapcalc_start("$cost_n_cleansed = if($cost_n == 0, 0.1, $cost_n)",
                       cost_n_cleansed = cost_site_name + '.cleansed',
-                      cost_n = cost_site_name)
+                      cost_n = cost_site_name, quiet = True)
+	if i % workers is 0:
+	    #print 'stalling ...'
+	    proc[i].wait()
+	    grass.fatal(_('Problem running %s') % 'r.mapcalc')
+    grass.message(_("Applying radial decay ..."))
+    proc = {}
         grass.run_command('g.remove', rast = cost_site_name, quiet = True)
         grass.run_command('g.rename', rast = cost_site_name + '.cleansed'
                           + ',' + cost_site_name, quiet = True)
         # r.to.vect then r.patch output
         # v.to.rast in=tmp_idw_cost_site_29978 out=tmp_idw_cost_val_$$ use=val val=10
@@ -303,31 +333,35 @@
         grass.debug("r.mapcalc expression is: [%s]" % expr)
-        one_by_cost_site_sq_n = tmp_base + '1by_cost_site_sq.' + '%05d' % num
+        one_by_cost_site_sq_n = tmp_base + '1by_cost_site_sq.' + '%05d' % (i+1)
-        proc[num-1] = grass.mapcalc_start("$result = " + expr,
+        proc[i] = grass.mapcalc_start("$result = " + expr,
 		                      result = one_by_cost_site_sq_n,
-		                      friction = friction)
+		                      friction = friction,
+				      quiet = True)
-	if num % workers is 0:
-	    proc[num-1].wait()
+	    proc[i].wait()
         # r.patch in=1by_cost_site_sqrd.${NUM},tmp_idw_cost_val_$$ out=1by_cost_site_sqrd.${NUM} --o
         # g.remove rast=cost_site.$NUM
-        num += 1
     for i in range(n):
-        proc[i].wait()
+    		      rast = tmp_base + 'cost_site.*', quiet = True)
+    #grass.run_command('g.list', type = 'rast', mapset = '.')
     #### Step 3) find sum(cost^2)
-    grass.message("")
-    grass.message(_("Finding sum of squares.."))
+    grass.verbose('')
+    grass.verbose(_("Finding sum of squares ..."))
     #todo: test if MASK exists already, fatal exit if it does?
     if post_mask:
@@ -335,15 +369,19 @@
         grass.mapcalc("MASK = $maskmap", maskmap = post_mask, overwrite = True)
-    grass.message(_("Summation of cost weights.."))
+    grass.message(_("Summation of cost weights ..."))
     input_maps = tmp_base + '1by_cost_site_sq.%05d' % 1
     for i in range(2, n+1):
         input_maps += ',%s1by_cost_site_sq.%05d' % (tmp_base, i)
     sum_of_1by_cost_sqs = tmp_base + 'sum_of_1by_cost_sqs'
-    grass.run_command('r.series', method = 'sum', input = input_maps,
+    ret = grass.run_command('r.series', method = 'sum', input = input_maps,
                       output = sum_of_1by_cost_sqs)
+    if ret is not 0:
+	grass.fatal(_('Problem running %s') % 'r.series')
     if post_mask:
         grass.message(_("Removing post_mask <%s>"), post_mask)
@@ -352,10 +390,9 @@
     #### Step 4) ( 1/di^2 / sum(1/d^2) ) *  ai
-    grass.message("")
-    grass.message(_("Creating partial weights.."))
+    grass.verbose('')
+    grass.message(_("Creating partial weights ..."))
     proc = {}
     num = 1
     for position in points_list:
@@ -376,8 +413,8 @@
 	    		  % (num, n, cat, data_value))
-        rast_val = grass.read_command('r.what', input = area_mask,
-				      east_north = '%s,%s' % (position[0], position[1])
+        rast_val = grass.read_command('r.what', map = area_mask,
+				      coordinates = '%s,%s' % (position[0], position[1])
 				     ).strip().split('|')[-1]
 	if rast_val == '*':
 	    grass.message(_(" -- Skipping, point lays outside of cost_map. [Probably programmer error]"))
@@ -390,11 +427,13 @@
         #"( $DATA_VALUE / $N ) * (1.0 - ( cost_sq_site.$NUM / sum_of_cost_sqs ))"
         #"( cost_sq_site.$NUM / sum_of_cost_sqs ) * ( $DATA_VALUE / $N )"
-	proc[num-1] = grass.mapcalc_start("$partial_n = ($data * $one_by_cost_sq) / $sum_of_1by_cost_sqs",
+	proc[num-1] = grass.mapcalc_start(
+		      "$partial_n = ($data * $one_by_cost_sq) / $sum_of_1by_cost_sqs",
                       partial_n = partial_n,
 		      data = data_value,
 		      one_by_cost_sq = one_by_cost_site_sq,
-		      sum_of_1by_cost_sqs = sum_of_1by_cost_sqs)
+		      sum_of_1by_cost_sqs = sum_of_1by_cost_sqs,
+		      quiet = True)
@@ -411,10 +450,16 @@
     for i in range(n):
         proc[i].wait()
+    # free up disk space ASAP
+    		      rast = tmp_base + '1by_cost_site_sq.*', quiet = True)
-    grass.message("")
-    grass.message(_("Calculating final values.."))
+    grass.message('')
+    grass.message(_("Calculating final values ..."))
     input_maps = tmp_base + 'partial.%05d' % 1
         input_maps += ',%spartial.%05d' % (tmp_base, i)
