[GRASS-SVN] r50978 - grass/branches/develbranch_6/lib/python
Sat Mar 3 09:50:43 EST 2012
Author: martinl
Date: 2012-03-03 06:50:43 -0800 (Sat, 03 Mar 2012)
New Revision: 50978
   grass/branches/develbranch_6/lib/python/core.py
glynn: Use KeyValue object for key-value data
       (allows use of e.g. region.rows as an alternative to region['rows'])
       (merge r50972 from trunk)
Modified: grass/branches/develbranch_6/lib/python/core.py
--- grass/branches/develbranch_6/lib/python/core.py	2012-03-03 14:49:26 UTC (rev 50977)
+++ grass/branches/develbranch_6/lib/python/core.py	2012-03-03 14:50:43 UTC (rev 50978)
@@ -479,6 +479,27 @@
     return tmp
+class KeyValue(dict):
+    """A general-purpose key-value store.
+    KeyValue is a subclass of dict, but also allows entries to be read and
+    written using attribute syntax. Example:
+    \code
+    >>> region = grass.region()
+    >>> region['rows']
+    477
+    >>> region.rows
+    477
+    \endcode
+    def __getattr__(self, key):
+        return self[key]
+    def __setattr__(self, key, value):
+        self[key] = value
 # key-value parsers
 def parse_key_val(s, sep = '=', dflt = None, val_type = None, vsep = None):
@@ -493,7 +514,7 @@
     @return parsed input (dictionary of keys/values)
-    result = {}
+    result = KeyValue()
     if not s:
         return result
