[GRASS-SVN] r51037 - grass/trunk
Sun Mar 11 15:53:06 EDT 2012
Author: neteler
Date: 2012-03-11 12:53:06 -0700 (Sun, 11 Mar 2012)
New Revision: 51037
   grass/trunk/configure
   grass/trunk/configure.in
jpeg refs removed
Modified: grass/trunk/configure
--- grass/trunk/configure	2012-03-11 19:51:37 UTC (rev 51036)
+++ grass/trunk/configure	2012-03-11 19:53:06 UTC (rev 51037)
@@ -29,8 +29,6 @@
   --with-macosx-sdk[=path/sdk]
                           compile with a system SDK on MacOSX. (default: no)"
 ac_help="$ac_help
-  --with-jpeg             support JPEG functionality (default: yes)"
-ac_help="$ac_help
   --with-tiff             support TIFF functionality (default: yes)"
 ac_help="$ac_help
   --with-png              support PNG functionality (default: yes)"
@@ -105,11 +103,6 @@
   --with-readline-libs=DIRS
                           Readline library files are in DIRS"
 ac_help="$ac_help
-  --with-jpeg-includes=DIRS
-                          JPEG include files are in DIRS"
-ac_help="$ac_help
-  --with-jpeg-libs=DIRS   JPEG library files are in DIRS"
-ac_help="$ac_help
   --with-tiff-includes=DIRS
                           TIFF include files are in DIRS"
 ac_help="$ac_help
@@ -752,7 +745,7 @@
 fi
 echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:756: checking host system type" >&5
+echo "configure:749: checking host system type" >&5
 host_alias=$host
 case "$host_alias" in
@@ -775,7 +768,7 @@
 # Extract the first word of "gcc", so it can be a program name with args.
 set dummy gcc; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:779: checking for $ac_word" >&5
+echo "configure:772: checking for $ac_word" >&5
 if test -n "$CC"; then
   ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -802,7 +795,7 @@
   # Extract the first word of "cc", so it can be a program name with args.
 set dummy cc; ac_word=$2
-echo "configure:806: checking for $ac_word" >&5
+echo "configure:799: checking for $ac_word" >&5
@@ -850,7 +843,7 @@
       # Extract the first word of "cl", so it can be a program name with args.
 set dummy cl; ac_word=$2
-echo "configure:854: checking for $ac_word" >&5
+echo "configure:847: checking for $ac_word" >&5
@@ -879,7 +872,7 @@
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:883: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:876: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
 ac_ext=c
 # CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -890,12 +883,12 @@
 cat > conftest.$ac_ext << EOF
-#line 894 "configure"
+#line 887 "configure"
 #include "confdefs.h"
 main(){return(0);}
 EOF
-if { (eval echo configure:899: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cc_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -921,19 +914,19 @@
   { echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:925: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:918: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
 cross_compiling=$ac_cv_prog_cc_cross
 echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:930: checking whether we are using GNU C" >&5
+echo "configure:923: checking whether we are using GNU C" >&5
 cat > conftest.c <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:937: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:930: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gcc=yes
 else
   ac_cv_prog_gcc=no
@@ -951,7 +944,7 @@
 ac_save_CFLAGS="$CFLAGS"
 CFLAGS=
 echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:955: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:948: checking whether ${CC-cc} accepts -g" >&5
 echo 'void f(){}' > conftest.c
 if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -980,10 +973,10 @@
 fi
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:984: checking for Cygwin environment" >&5
+echo "configure:977: checking for Cygwin environment" >&5
 cat > conftest.$ac_ext <<EOF
-#line 987 "configure"
+#line 980 "configure"
 int main() {
@@ -994,7 +987,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:998: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:991: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -1010,17 +1003,17 @@
 CYGWIN=
 test "$ac_cv_cygwin" = yes && CYGWIN=yes
 echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:1014: checking for mingw32 environment" >&5
+echo "configure:1007: checking for mingw32 environment" >&5
-#line 1017 "configure"
+#line 1010 "configure"
 int main() {
 return __MINGW32__;
 ; return 0; }
 EOF
-if { (eval echo configure:1024: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1017: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_mingw32=yes
 else
@@ -1038,7 +1031,7 @@
 echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1042: checking for executable suffix" >&5
+echo "configure:1035: checking for executable suffix" >&5
 if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
   ac_cv_exeext=.exe
@@ -1057,23 +1050,23 @@
 IEEEFLAG=
 echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1061: checking for full floating-point support" >&5
+echo "configure:1054: checking for full floating-point support" >&5
 if test "$cross_compiling" = yes; then
      echo "$ac_t""unknown (cross-compiling)" 1>&6
 echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1066: checking whether "cc -mieee" works" >&5
+echo "configure:1059: checking whether "cc -mieee" works" >&5
 ac_save_cflags=${CFLAGS}
 CFLAGS="$CFLAGS -mieee"
-#line 1070 "configure"
+#line 1063 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:1077: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1070: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
      echo "$ac_t""yes" 1>&6
         IEEEFLAG="-mieee"
@@ -1089,7 +1082,7 @@
 else
-#line 1093 "configure"
+#line 1086 "configure"
 #include <float.h>
@@ -1103,7 +1096,7 @@
 EOF
-if { (eval echo configure:1107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1100: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
@@ -1116,14 +1109,14 @@
   CFLAGS=-mieee
 echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1120: checking for full floating-point support with -mieee" >&5
+echo "configure:1113: checking for full floating-point support with -mieee" >&5
     { echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
 else
-#line 1127 "configure"
+#line 1120 "configure"
 #include <float.h>
@@ -1137,7 +1130,7 @@
 EOF
-if { (eval echo configure:1141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1134: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
     IEEEFLAG="-mieee"
@@ -1174,7 +1167,7 @@
 # Extract the first word of "pwd", so it can be a program name with args.
 set dummy pwd; ac_word=$2
-echo "configure:1178: checking for $ac_word" >&5
+echo "configure:1171: checking for $ac_word" >&5
 case "$pwd" in
@@ -1212,7 +1205,7 @@
 fi
 echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1216: checking for source directory" >&5
+echo "configure:1209: checking for source directory" >&5
 if test -z "$srcdir" ; then
   SRCDIR=`$pwd`
@@ -1223,7 +1216,7 @@
 echo "$ac_t"""$SRCDIR"" 1>&6
 echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1227: checking for build directory" >&5
+echo "configure:1220: checking for build directory" >&5
 DSTDIR=`$pwd`
 WINDSTDIR=`$winpwd`
@@ -1291,7 +1284,7 @@
 # Extract the first word of "svnversion", so it can be a program name with args.
 set dummy svnversion; ac_word=$2
-echo "configure:1295: checking for $ac_word" >&5
+echo "configure:1288: checking for $ac_word" >&5
 case "$SVN_VERSION" in
@@ -1350,7 +1343,7 @@
 echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1354: checking for MacOSX App" >&5
+echo "configure:1347: checking for MacOSX App" >&5
 case "$enable_macosx_app" in
 	yes)	MACOSX_APP=1	;;
 	no)	MACOSX_APP=	;;
@@ -1362,7 +1355,7 @@
 # Check for MacOSX archs
 echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
-echo "configure:1366: checking for MacOSX architectures" >&5
+echo "configure:1359: checking for MacOSX architectures" >&5
 MACOSX_ARCHS=
@@ -1391,7 +1384,7 @@
 # Check for MacOSX SDK
 echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
-echo "configure:1395: checking for MacOSX SDK" >&5
+echo "configure:1388: checking for MacOSX SDK" >&5
 MACOSX_SDK=
@@ -1401,7 +1394,7 @@
 ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
-echo "configure:1405: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+echo "configure:1398: checking for $with_macosx_sdk/SDKSettings.plist" >&5
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -1445,7 +1438,7 @@
     echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1449: checking how to build libraries" >&5
+echo "configure:1442: checking how to build libraries" >&5
     # Check whether --enable-shared or --disable-shared was given.
 if test "${enable_shared+set}" = set; then
   enableval="$enable_shared"
@@ -1617,16 +1610,6 @@
 fi
-# Check whether --with-jpeg or --without-jpeg was given.
-if test "${with_jpeg+set}" = set; then
-  withval="$with_jpeg"
-else
-  with_jpeg=yes
-fi
 # Check whether --with-tiff or --without-tiff was given.
 if test "${with_tiff+set}" = set; then
   withval="$with_tiff"
@@ -1912,23 +1895,6 @@
-# Check whether --with-jpeg-includes or --without-jpeg-includes was given.
-if test "${with_jpeg_includes+set}" = set; then
-  withval="$with_jpeg_includes"
-fi
-# Check whether --with-jpeg-libs or --without-jpeg-libs was given.
-if test "${with_jpeg_libs+set}" = set; then
-  withval="$with_jpeg_libs"
-fi
 # Check whether --with-tiff-includes or --without-tiff-includes was given.
 if test "${with_tiff_includes+set}" = set; then
   withval="$with_tiff_includes"
@@ -2284,7 +2250,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:2288: checking for additional include dirs" >&5
+echo "configure:2254: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -2307,7 +2273,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:2311: checking for additional library dirs" >&5
+echo "configure:2277: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -2341,7 +2307,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:2345: checking for a BSD compatible install" >&5
+echo "configure:2311: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -2394,7 +2360,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
-echo "configure:2398: checking for $ac_word" >&5
+echo "configure:2364: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -2425,13 +2391,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:2429: checking for yywrap in -l$ac_lib" >&5
+echo "configure:2395: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-l$ac_lib  $LIBS"
-#line 2435 "configure"
+#line 2401 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -2442,7 +2408,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:2446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2412: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -2467,7 +2433,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:2471: checking for $ac_word" >&5
+echo "configure:2437: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -2507,7 +2473,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:2511: checking for $ac_word" >&5
+echo "configure:2477: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -2538,7 +2504,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:2542: checking for $ac_word" >&5
+echo "configure:2508: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -2576,7 +2542,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
-echo "configure:2580: checking for $ac_word" >&5
+echo "configure:2546: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -2605,7 +2571,7 @@
-echo "configure:2609: checking for $ac_word" >&5
+echo "configure:2575: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -2636,7 +2602,7 @@
-echo "configure:2640: checking for $ac_word" >&5
+echo "configure:2606: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -2665,7 +2631,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:2669: checking for $ac_word" >&5
+echo "configure:2635: checking for $ac_word" >&5
 case "$PERL" in
@@ -2696,7 +2662,7 @@
 fi
 echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:2700: checking how to run the C preprocessor" >&5
+echo "configure:2666: checking how to run the C preprocessor" >&5
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
@@ -2709,13 +2675,13 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp.
-#line 2713 "configure"
+#line 2679 "configure"
 #include <assert.h>
 Syntax Error
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:2719: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2685: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
@@ -2726,13 +2692,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -E -traditional-cpp"
-#line 2730 "configure"
+#line 2696 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:2736: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2702: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2743,13 +2709,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -nologo -E"
-#line 2747 "configure"
+#line 2713 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:2753: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2719: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2773,10 +2739,10 @@
 echo "$ac_t""$CPP" 1>&6
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:2777: checking for ANSI C header files" >&5
+echo "configure:2743: checking for ANSI C header files" >&5
-#line 2780 "configure"
+#line 2746 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -2784,7 +2750,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:2788: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2754: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2801,7 +2767,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 2805 "configure"
+#line 2771 "configure"
 #include <string.h>
 EOF
@@ -2819,7 +2785,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 2823 "configure"
+#line 2789 "configure"
 #include <stdlib.h>
 EOF
@@ -2840,7 +2806,7 @@
 else
-#line 2844 "configure"
+#line 2810 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -2851,7 +2817,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:2855: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:2821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -2878,15 +2844,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:2882: checking for $ac_hdr" >&5
+echo "configure:2848: checking for $ac_hdr" >&5
-#line 2885 "configure"
+#line 2851 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2890: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2856: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2915,15 +2881,15 @@
 do
-echo "configure:2919: checking for $ac_hdr" >&5
+echo "configure:2885: checking for $ac_hdr" >&5
-#line 2922 "configure"
+#line 2888 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2927: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2893: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2952,15 +2918,15 @@
 do
-echo "configure:2956: checking for $ac_hdr" >&5
+echo "configure:2922: checking for $ac_hdr" >&5
-#line 2959 "configure"
+#line 2925 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2964: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2930: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2989,15 +2955,15 @@
 do
-echo "configure:2993: checking for $ac_hdr" >&5
+echo "configure:2959: checking for $ac_hdr" >&5
-#line 2996 "configure"
+#line 2962 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3001: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2967: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3026,15 +2992,15 @@
 do
-echo "configure:3030: checking for $ac_hdr" >&5
+echo "configure:2996: checking for $ac_hdr" >&5
-#line 3033 "configure"
+#line 2999 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3038: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3004: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3060,10 +3026,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:3064: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:3030: checking whether time.h and sys/time.h may both be included" >&5
-#line 3067 "configure"
+#line 3033 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -3072,7 +3038,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:3076: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3042: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -3092,10 +3058,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:3096: checking for off_t" >&5
+echo "configure:3062: checking for off_t" >&5
-#line 3099 "configure"
+#line 3065 "configure"
 #if STDC_HEADERS
@@ -3122,10 +3088,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:3126: checking for uid_t in sys/types.h" >&5
+echo "configure:3092: checking for uid_t in sys/types.h" >&5
-#line 3129 "configure"
+#line 3095 "configure"
 EOF
@@ -3153,10 +3119,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:3157: checking return type of signal handlers" >&5
+echo "configure:3123: checking return type of signal handlers" >&5
-#line 3160 "configure"
+#line 3126 "configure"
 #include <signal.h>
@@ -3173,7 +3139,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:3177: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3143: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -3191,10 +3157,10 @@
-echo "configure:3195: checking for Cygwin environment" >&5
+echo "configure:3161: checking for Cygwin environment" >&5
-#line 3198 "configure"
+#line 3164 "configure"
 int main() {
@@ -3205,7 +3171,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:3209: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3175: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -3223,10 +3189,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:3227: checking for $ac_func" >&5
+echo "configure:3193: checking for $ac_func" >&5
-#line 3230 "configure"
+#line 3196 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -3249,7 +3215,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3253: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -3275,10 +3241,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:3279: checking for $ac_func" >&5
+echo "configure:3245: checking for $ac_func" >&5
-#line 3282 "configure"
+#line 3248 "configure"
@@ -3301,7 +3267,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3305: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3327,10 +3293,10 @@
 for ac_func in drand48
 do
-echo "configure:3331: checking for $ac_func" >&5
+echo "configure:3297: checking for $ac_func" >&5
-#line 3334 "configure"
+#line 3300 "configure"
@@ -3353,7 +3319,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3357: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3379,10 +3345,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:3383: checking for $ac_func" >&5
+echo "configure:3349: checking for $ac_func" >&5
-#line 3386 "configure"
+#line 3352 "configure"
@@ -3405,7 +3371,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3375: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3431,10 +3397,10 @@
 for ac_func in nanosleep
 do
-echo "configure:3435: checking for $ac_func" >&5
+echo "configure:3401: checking for $ac_func" >&5
-#line 3438 "configure"
+#line 3404 "configure"
@@ -3457,7 +3423,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3461: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3482,13 +3448,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:3486: checking whether setpgrp takes no argument" >&5
+echo "configure:3452: checking whether setpgrp takes no argument" >&5
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 3492 "configure"
+#line 3458 "configure"
 #ifdef HAVE_UNISTD_H
@@ -3508,7 +3474,7 @@
 EOF
-if { (eval echo configure:3512: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3478: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -3536,16 +3502,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:3540: checking for long long int" >&5
+echo "configure:3506: checking for long long int" >&5
-#line 3542 "configure"
+#line 3508 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:3549: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3515: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
@@ -3565,7 +3531,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:3569: checking for W11" >&5
+echo "configure:3535: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -3593,7 +3559,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:3597: checking for X" >&5
+echo "configure:3563: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -3653,12 +3619,12 @@
   # First, try using that file with no special directory specified.
-#line 3657 "configure"
+#line 3623 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:3662: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3628: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3727,14 +3693,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 3731 "configure"
+#line 3697 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:3738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3704: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -3839,17 +3805,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:3843: checking whether -R must be followed by a space" >&5
+echo "configure:3809: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 3846 "configure"
+#line 3812 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:3853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -3865,14 +3831,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 3869 "configure"
+#line 3835 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:3876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -3904,13 +3870,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:3908: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:3874: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 3914 "configure"
+#line 3880 "configure"
@@ -3921,7 +3887,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:3925: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3891: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3942,13 +3908,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:3946: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:3912: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 3952 "configure"
+#line 3918 "configure"
@@ -3959,7 +3925,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:3963: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3987,10 +3953,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:3991: checking for gethostbyname" >&5
+echo "configure:3957: checking for gethostbyname" >&5
-#line 3994 "configure"
+#line 3960 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -4013,7 +3979,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4017: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3983: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -4033,13 +3999,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:4037: checking for gethostbyname in -lnsl" >&5
+echo "configure:4003: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 4043 "configure"
+#line 4009 "configure"
@@ -4050,7 +4016,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:4054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4079,10 +4045,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:4083: checking for connect" >&5
+echo "configure:4049: checking for connect" >&5
-#line 4086 "configure"
+#line 4052 "configure"
     which can conflict with char connect(); below.  */
@@ -4105,7 +4071,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4109: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -4125,13 +4091,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:4129: checking for connect in -lsocket" >&5
+echo "configure:4095: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 4135 "configure"
+#line 4101 "configure"
@@ -4142,7 +4108,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:4146: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4165,10 +4131,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:4169: checking for remove" >&5
+echo "configure:4135: checking for remove" >&5
-#line 4172 "configure"
+#line 4138 "configure"
     which can conflict with char remove(); below.  */
@@ -4191,7 +4157,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4195: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4161: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -4211,13 +4177,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:4215: checking for remove in -lposix" >&5
+echo "configure:4181: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 4221 "configure"
+#line 4187 "configure"
@@ -4228,7 +4194,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:4232: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4198: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4251,10 +4217,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:4255: checking for shmat" >&5
+echo "configure:4221: checking for shmat" >&5
-#line 4258 "configure"
+#line 4224 "configure"
     which can conflict with char shmat(); below.  */
@@ -4277,7 +4243,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4281: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -4297,13 +4263,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:4301: checking for shmat in -lipc" >&5
+echo "configure:4267: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 4307 "configure"
+#line 4273 "configure"
@@ -4314,7 +4280,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:4318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4284: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4346,13 +4312,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:4350: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:4316: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 4356 "configure"
+#line 4322 "configure"
@@ -4363,7 +4329,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:4367: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4403,12 +4369,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:4407: checking for library containing cuserid" >&5
+echo "configure:4373: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 4412 "configure"
+#line 4378 "configure"
@@ -4419,7 +4385,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:4423: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4389: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -4430,7 +4396,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 4434 "configure"
+#line 4400 "configure"
@@ -4441,7 +4407,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:4445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4411: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -4467,10 +4433,10 @@
 # Note: -lxdr -liberty -lws2_32 is for MinGW
 echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:4471: checking for xdrmem_create" >&5
+echo "configure:4437: checking for xdrmem_create" >&5
-#line 4474 "configure"
+#line 4440 "configure"
     which can conflict with char xdrmem_create(); below.  */
@@ -4493,7 +4459,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4497: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4463: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_xdrmem_create=yes"
 else
@@ -4511,13 +4477,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:4515: checking for xdrmem_create in -lsun" >&5
+echo "configure:4481: checking for xdrmem_create in -lsun" >&5
 ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lsun  $LIBS"
-#line 4521 "configure"
+#line 4487 "configure"
@@ -4528,7 +4494,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:4532: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4547,13 +4513,13 @@
 echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:4551: checking for xdrmem_create in -lnsl" >&5
+echo "configure:4517: checking for xdrmem_create in -lnsl" >&5
 ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 4557 "configure"
+#line 4523 "configure"
@@ -4564,7 +4530,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:4568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4534: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4583,13 +4549,13 @@
 echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:4587: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:4553: checking for xdrmem_create in -lrpclib" >&5
 ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lrpclib  $LIBS"
-#line 4593 "configure"
+#line 4559 "configure"
@@ -4600,7 +4566,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:4604: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4570: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4619,13 +4585,13 @@
 echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:4623: checking for xdrmem_create in -lxdr" >&5
+echo "configure:4589: checking for xdrmem_create in -lxdr" >&5
 ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lxdr -liberty -lws2_32  $LIBS"
-#line 4629 "configure"
+#line 4595 "configure"
@@ -4636,7 +4602,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:4640: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4606: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4670,10 +4636,10 @@
 for ac_func in asprintf
 do
-echo "configure:4674: checking for $ac_func" >&5
+echo "configure:4640: checking for $ac_func" >&5
-#line 4677 "configure"
+#line 4643 "configure"
@@ -4696,7 +4662,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4700: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4666: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4723,10 +4689,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:4727: checking for atan" >&5
+echo "configure:4693: checking for atan" >&5
-#line 4730 "configure"
+#line 4696 "configure"
     which can conflict with char atan(); below.  */
@@ -4749,7 +4715,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4753: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4719: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -4767,13 +4733,13 @@
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:4771: checking for atan in -lm" >&5
+echo "configure:4737: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 4777 "configure"
+#line 4743 "configure"
@@ -4784,7 +4750,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:4788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4754: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4811,10 +4777,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:4815: checking for dlsym" >&5
+echo "configure:4781: checking for dlsym" >&5
-#line 4818 "configure"
+#line 4784 "configure"
     which can conflict with char dlsym(); below.  */
@@ -4837,7 +4803,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4841: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -4855,13 +4821,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:4859: checking for dlsym in -ldl" >&5
+echo "configure:4825: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 4865 "configure"
+#line 4831 "configure"
@@ -4872,7 +4838,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:4876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4899,10 +4865,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:4903: checking for iconv" >&5
+echo "configure:4869: checking for iconv" >&5
-#line 4906 "configure"
+#line 4872 "configure"
     which can conflict with char iconv(); below.  */
@@ -4925,7 +4891,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -4943,13 +4909,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:4947: checking for iconv in -liconv" >&5
+echo "configure:4913: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 4953 "configure"
+#line 4919 "configure"
@@ -4960,7 +4926,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4930: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4979,13 +4945,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4983: checking for iconv in -lgiconv" >&5
+echo "configure:4949: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 4989 "configure"
+#line 4955 "configure"
@@ -4996,7 +4962,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:5000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4966: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5015,10 +4981,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:5019: checking for libiconv" >&5
+echo "configure:4985: checking for libiconv" >&5
-#line 5022 "configure"
+#line 4988 "configure"
     which can conflict with char libiconv(); below.  */
@@ -5041,7 +5007,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -5059,13 +5025,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:5063: checking for libiconv in -liconv" >&5
+echo "configure:5029: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 5069 "configure"
+#line 5035 "configure"
@@ -5076,7 +5042,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:5080: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5095,13 +5061,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:5099: checking for libiconv in -lgiconv" >&5
+echo "configure:5065: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 5105 "configure"
+#line 5071 "configure"
@@ -5112,7 +5078,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:5116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5082: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5149,10 +5115,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:5153: checking for socket" >&5
+echo "configure:5119: checking for socket" >&5
-#line 5156 "configure"
+#line 5122 "configure"
     which can conflict with char socket(); below.  */
@@ -5175,7 +5141,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -5193,13 +5159,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:5197: checking for socket in -lsocket" >&5
+echo "configure:5163: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 5203 "configure"
+#line 5169 "configure"
@@ -5210,7 +5176,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:5214: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5258,7 +5224,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:5262: checking for location of zlib includes" >&5
+echo "configure:5228: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -5284,15 +5250,15 @@
 do
-echo "configure:5288: checking for $ac_hdr" >&5
+echo "configure:5254: checking for $ac_hdr" >&5
-#line 5291 "configure"
+#line 5257 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5296: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5262: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5326,7 +5292,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:5330: checking for location of zlib library" >&5
+echo "configure:5296: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -5351,13 +5317,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:5355: checking for deflate in -lz" >&5
+echo "configure:5321: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 5361 "configure"
+#line 5327 "configure"
@@ -5368,7 +5334,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:5372: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5338: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5416,7 +5382,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:5420: checking for location of External PROJ.4 includes" >&5
+echo "configure:5386: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -5442,15 +5408,15 @@
 do
-echo "configure:5446: checking for $ac_hdr" >&5
+echo "configure:5412: checking for $ac_hdr" >&5
-#line 5449 "configure"
+#line 5415 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5454: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5420: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5487,7 +5453,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:5491: checking External PROJ.4 version" >&5
+echo "configure:5457: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -5495,7 +5461,7 @@
 else
-#line 5499 "configure"
+#line 5465 "configure"
 #include <stdio.h>
@@ -5507,7 +5473,7 @@
 EOF
-if { (eval echo configure:5511: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:5477: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -5532,7 +5498,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:5536: checking for location of External PROJ.4 library" >&5
+echo "configure:5502: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -5557,13 +5523,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:5561: checking for pj_get_def in -lproj" >&5
+echo "configure:5527: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 5567 "configure"
+#line 5533 "configure"
@@ -5574,7 +5540,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:5578: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5608,7 +5574,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:5612: checking for location of External PROJ.4 data files" >&5
+echo "configure:5578: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -5632,14 +5598,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:5636: checking for epsg" >&5
+echo "configure:5602: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:5643: checking for $PROJSHARE/epsg" >&5
+echo "configure:5609: checking for $PROJSHARE/epsg" >&5
@@ -5671,7 +5637,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
-echo "configure:5675: checking for $ac_word" >&5
+echo "configure:5641: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -5711,7 +5677,7 @@
 echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:5715: checking whether to use regex" >&5
+echo "configure:5681: checking whether to use regex" >&5
 echo "$ac_t"""$with_regex"" 1>&6
 case "$with_regex" in
 	"no")	USE_REGEX=	;;
@@ -5731,7 +5697,7 @@
 echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:5735: checking for location of regex includes" >&5
+echo "configure:5701: checking for location of regex includes" >&5
 case "$with_regex_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -5757,15 +5723,15 @@
 do
-echo "configure:5761: checking for $ac_hdr" >&5
+echo "configure:5727: checking for $ac_hdr" >&5
-#line 5764 "configure"
+#line 5730 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5769: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5735: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5799,7 +5765,7 @@
 echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:5803: checking for location of regex library" >&5
+echo "configure:5769: checking for location of regex library" >&5
 case "$with_regex_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -5824,10 +5790,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:5828: checking for regcomp" >&5
+echo "configure:5794: checking for regcomp" >&5
-#line 5831 "configure"
+#line 5797 "configure"
     which can conflict with char regcomp(); below.  */
@@ -5850,7 +5816,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5854: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_regcomp=yes"
 else
@@ -5877,13 +5843,13 @@
 echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:5881: checking for regcomp in -lregex" >&5
+echo "configure:5847: checking for regcomp in -lregex" >&5
 ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
 LIBS="-lregex  $LIBS"
-#line 5887 "configure"
+#line 5853 "configure"
@@ -5894,7 +5860,7 @@
 regcomp()
 ; return 0; }
 EOF
-if { (eval echo configure:5898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5944,7 +5910,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:5948: checking whether to use Readline" >&5
+echo "configure:5914: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -5965,7 +5931,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:5969: checking for location of Readline includes" >&5
+echo "configure:5935: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -5991,15 +5957,15 @@
 do
-echo "configure:5995: checking for $ac_hdr" >&5
+echo "configure:5961: checking for $ac_hdr" >&5
-#line 5998 "configure"
+#line 5964 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6003: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5969: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6035,15 +6001,15 @@
 do
-echo "configure:6039: checking for $ac_hdr" >&5
+echo "configure:6005: checking for $ac_hdr" >&5
-#line 6042 "configure"
+#line 6008 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6047: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6013: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6077,7 +6043,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:6081: checking for location of Readline library" >&5
+echo "configure:6047: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -6102,13 +6068,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:6106: checking for readline in -lreadline" >&5
+echo "configure:6072: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
-#line 6112 "configure"
+#line 6078 "configure"
@@ -6119,7 +6085,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:6123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6154,13 +6120,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:6158: checking for add_history in -lhistory" >&5
+echo "configure:6124: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 6164 "configure"
+#line 6130 "configure"
@@ -6171,7 +6137,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:6175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6210,228 +6176,10 @@
 # Done checking Readline
-# Enable JPEG option
-echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:6218: checking whether to use JPEG" >&5
-echo "$ac_t"""$with_jpeg"" 1>&6
-case "$with_jpeg" in
-	"no")	USE_JPEG=	;;
-	"yes")	USE_JPEG="1"	;;
-	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
-esac
-JPEGINCPATH=
-JPEGLIBPATH=
-JPEGLIB=
-if test -n "$USE_JPEG"; then
-# With JPEG includes directory
-echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:6238: checking for location of JPEG includes" >&5
-case "$with_jpeg_includes" in
-y | ye | yes | n | no)
-	{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
-esac
-echo "$ac_t""$with_jpeg_includes" 1>&6
-if test -n "$with_jpeg_includes" ; then
-    for dir in $with_jpeg_includes; do
-        if test -d "$dir"; then
-            JPEGINCPATH="$JPEGINCPATH -I$dir"
-        else
-            { echo "configure: error: *** JPEG includes directory $dir does not exist." 1>&2; exit 1; }
-        fi
-    done
-fi
-ac_save_cppflags="$CPPFLAGS"
-CPPFLAGS="$JPEGINCPATH $CPPFLAGS"
-for ac_hdr in jpeglib.h
-do
-ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
-echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:6264: checking for $ac_hdr" >&5
-cat > conftest.$ac_ext <<EOF
-#line 6267 "configure"
-#include "confdefs.h"
-#include <$ac_hdr>
-EOF
-ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:6272: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
-ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
-if test -z "$ac_err"; then
-  rm -rf conftest*
-  eval "ac_cv_header_$ac_safe=yes"
-else
-  echo "$ac_err" >&5
-  echo "configure: failed program was:" >&5
-  cat conftest.$ac_ext >&5
-  rm -rf conftest*
-  eval "ac_cv_header_$ac_safe=no"
-fi
-rm -f conftest*
-if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
-  echo "$ac_t""yes" 1>&6
-    ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
-  cat >> confdefs.h <<EOF
-#define $ac_tr_hdr 1
-EOF
-else
-  echo "$ac_t""no" 1>&6
-{ echo "configure: error: *** Unable to locate JPEG includes." 1>&2; exit 1; }
-fi
-done
-CPPFLAGS=$ac_save_cppflags
-# With JPEG library directory
-echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:6306: checking for location of JPEG library" >&5
-case "$with_jpeg_libs" in
-	{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
-esac
-echo "$ac_t""$with_jpeg_libs" 1>&6
-if test -n "$with_jpeg_libs"; then
-    for dir in $with_jpeg_libs; do
-            JPEGLIBPATH="$JPEGLIBPATH -L$dir"
-        else
-            { echo "configure: error: *** JPEG library directory $dir does not exist." 1>&2; exit 1; }
-        fi
-    done
-fi
-ac_save_ldflags="$LDFLAGS"
-LDFLAGS="$JPEGLIBPATH $LDFLAGS"
-echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:6333: checking for jpeg_start_compress in -ljpeg" >&5
-ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
-ac_save_LIBS="$LIBS"
-LIBS="-ljpeg  $LIBS"
-#line 6339 "configure"
-/* Override any gcc2 internal prototype to avoid an error.  */
-/* We use char because int might match the return type of a gcc2
-    builtin and then its argument prototype would still apply.  */
-char jpeg_start_compress();
-int main() {
-jpeg_start_compress()
-; return 0; }
-EOF
-if { (eval echo configure:6350: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-  eval "ac_cv_lib_$ac_lib_var=yes"
-else
-  rm -rf conftest*
-  eval "ac_cv_lib_$ac_lib_var=no"
-fi
-rm -f conftest*
-LIBS="$ac_save_LIBS"
-if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
-  JPEGLIB="$JPEGLIB -ljpeg "
-else
-echo "configure:6369: checking for jpeg_start_compress in -ljpeg" >&5
-LIBS="-ljpeg $ZLIB $LIBS"
-#line 6375 "configure"
-int main() {
-; return 0; }
-EOF
-if { (eval echo configure:6386: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  JPEGLIB="$JPEGLIB -ljpeg $ZLIB"
-else
-LDFLAGS=${ac_save_ldflags}
-    { echo "configure: error: *** Unable to locate JPEG library." 1>&2; exit 1; }
-fi
-fi
-fi # $USE_JPEG
-# Done checking JPEG
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:6435: checking whether to use GDAL" >&5
+echo "configure:6183: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -6449,7 +6197,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:6453: checking for $ac_word" >&5
+echo "configure:6201: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -6504,14 +6252,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6508 "configure"
+#line 6256 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:6515: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6263: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6520,14 +6268,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6524 "configure"
+#line 6272 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -6559,7 +6307,7 @@
 # libLAS option
 echo $ac_n "checking whether to use libLAS""... $ac_c" 1>&6
-echo "configure:6563: checking whether to use libLAS" >&5
+echo "configure:6311: checking whether to use libLAS" >&5
 LIBLAS_LIBS=
 LIBLAS_CFLAGS=
@@ -6576,7 +6324,7 @@
   # Extract the first word of "liblas-config", so it can be a program name with args.
 set dummy liblas-config; ac_word=$2
-echo "configure:6580: checking for $ac_word" >&5
+echo "configure:6328: checking for $ac_word" >&5
 case "$LIBLAS_CONFIG" in
@@ -6624,14 +6372,14 @@
   LIBS="$LIBS $LIBLAS_LIBS"
   CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
-#line 6628 "configure"
+#line 6376 "configure"
 #include <liblas/capi/liblas.h>
 int main() {
 LASReader_Create("foo");
 ; return 0; }
 EOF
-if { (eval echo configure:6635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6383: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6639,14 +6387,14 @@
   rm -rf conftest*
-#line 6643 "configure"
+#line 6391 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6650: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6398: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LAS_LIBS="$LAS_LIBS"
 else
@@ -6678,7 +6426,7 @@
 # GEOS option
 echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:6682: checking whether to use GEOS" >&5
+echo "configure:6430: checking whether to use GEOS" >&5
 GEOS_LIBS=
 GGEOS_CFLAGS=
@@ -6696,7 +6444,7 @@
   # Extract the first word of "geos-config", so it can be a program name with args.
 set dummy geos-config; ac_word=$2
-echo "configure:6700: checking for $ac_word" >&5
+echo "configure:6448: checking for $ac_word" >&5
 case "$GEOS_CONFIG" in
@@ -6744,15 +6492,15 @@
 do
-echo "configure:6748: checking for $ac_hdr" >&5
+echo "configure:6496: checking for $ac_hdr" >&5
-#line 6751 "configure"
+#line 6499 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6756: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6504: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6788,13 +6536,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c_i""... $ac_c" 1>&6
-echo "configure:6792: checking for initGEOS in -lgeos_c_i" >&5
+echo "configure:6540: checking for initGEOS in -lgeos_c_i" >&5
 ac_lib_var=`echo geos_c_i'_'initGEOS | sed 'y%./+-%__p_%'`
 LIBS="-lgeos_c_i  $LIBS"
-#line 6798 "configure"
+#line 6546 "configure"
@@ -6805,7 +6553,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:6809: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6557: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6841,13 +6589,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6845: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6593: checking for initGEOS in -lgeos_c" >&5
 ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
 LIBS="-lgeos_c  $LIBS"
-#line 6851 "configure"
+#line 6599 "configure"
@@ -6858,7 +6606,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:6862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6610: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6902,7 +6650,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6906: checking whether to use TIFF" >&5
+echo "configure:6654: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -6922,7 +6670,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6926: checking for location of TIFF includes" >&5
+echo "configure:6674: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6948,15 +6696,15 @@
 do
-echo "configure:6952: checking for $ac_hdr" >&5
+echo "configure:6700: checking for $ac_hdr" >&5
-#line 6955 "configure"
+#line 6703 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6960: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6708: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6990,7 +6738,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:6994: checking for location of TIFF library" >&5
+echo "configure:6742: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7021,13 +6769,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7025: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6773: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 7031 "configure"
+#line 6779 "configure"
@@ -7038,7 +6786,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7042: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7057,13 +6805,13 @@
-echo "configure:7061: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6809: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 7067 "configure"
+#line 6815 "configure"
@@ -7074,7 +6822,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7078: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7093,13 +6841,13 @@
-echo "configure:7097: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6845: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 7103 "configure"
+#line 6851 "configure"
@@ -7110,7 +6858,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7114: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7129,13 +6877,13 @@
-echo "configure:7133: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6881: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 7139 "configure"
+#line 6887 "configure"
@@ -7146,7 +6894,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7165,13 +6913,13 @@
-echo "configure:7169: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6917: checking for TIFFOpen in -ltiff" >&5
-LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
+LIBS="-ltiff -ljpeg $LIBS"
-#line 7175 "configure"
+#line 6923 "configure"
@@ -7182,7 +6930,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7186: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7196,18 +6944,18 @@
-  TIFFLIB="$TIFFLIB -ltiff $JPEGLIBPATH $JPEGLIB"
+  TIFFLIB="$TIFFLIB -ltiff -ljpeg"
 else
-echo "configure:7205: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6953: checking for TIFFOpen in -ltiff" >&5
-LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
+LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 7211 "configure"
+#line 6959 "configure"
@@ -7218,7 +6966,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7222: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7232,18 +6980,18 @@
-  TIFFLIB="$TIFFLIB -ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB"
+  TIFFLIB="$TIFFLIB -ltiff -ljpeg $MATHLIB"
 else
-echo "configure:7241: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6989: checking for TIFFOpen in -ltiff" >&5
-LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
+LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 7247 "configure"
+#line 6995 "configure"
@@ -7254,7 +7002,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7258: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7006: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7268,18 +7016,18 @@
-  TIFFLIB="$TIFFLIB -ltiff $JPEGLIBPATH $JPEGLIB $ZLIB"
+  TIFFLIB="$TIFFLIB -ltiff -ljpeg $ZLIB"
 else
-echo "configure:7277: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7025: checking for TIFFOpen in -ltiff" >&5
-LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
+LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 7283 "configure"
+#line 7031 "configure"
@@ -7290,7 +7038,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7294: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7042: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7304,7 +7052,7 @@
-  TIFFLIB="$TIFFLIB -ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB"
+  TIFFLIB="$TIFFLIB -ltiff -ljpeg $ZLIB $MATHLIB"
 else
@@ -7388,7 +7136,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7392: checking whether to use PNG" >&5
+echo "configure:7140: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -7407,7 +7155,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7411: checking for location of PNG includes" >&5
+echo "configure:7159: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7433,15 +7181,15 @@
 do
-echo "configure:7437: checking for $ac_hdr" >&5
+echo "configure:7185: checking for $ac_hdr" >&5
-#line 7440 "configure"
+#line 7188 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7445: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7193: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7475,7 +7223,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7479: checking for location of PNG library" >&5
+echo "configure:7227: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7500,13 +7248,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7504: checking for png_read_image in -lpng" >&5
+echo "configure:7252: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7510 "configure"
+#line 7258 "configure"
@@ -7517,7 +7265,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:7521: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7269: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7559,7 +7307,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7563: checking whether to use PostgreSQL" >&5
+echo "configure:7311: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -7586,7 +7334,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7590: checking for location of PostgreSQL includes" >&5
+echo "configure:7338: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7612,15 +7360,15 @@
 do
-echo "configure:7616: checking for $ac_hdr" >&5
+echo "configure:7364: checking for $ac_hdr" >&5
-#line 7619 "configure"
+#line 7367 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7624: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7372: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7658,7 +7406,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7662: checking for location of PostgreSQL library" >&5
+echo "configure:7410: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7687,13 +7435,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7691: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7439: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 7697 "configure"
+#line 7445 "configure"
@@ -7704,7 +7452,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7708: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7456: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7723,13 +7471,13 @@
-echo "configure:7727: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7475: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7733 "configure"
+#line 7481 "configure"
@@ -7740,7 +7488,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7744: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7492: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7759,13 +7507,13 @@
-echo "configure:7763: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7511: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 7769 "configure"
+#line 7517 "configure"
@@ -7776,7 +7524,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7528: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7795,13 +7543,13 @@
-echo "configure:7799: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7547: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 7805 "configure"
+#line 7553 "configure"
@@ -7812,7 +7560,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7816: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7564: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7869,13 +7617,13 @@
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7873: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7621: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 7879 "configure"
+#line 7627 "configure"
@@ -7886,7 +7634,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:7890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7638: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7908,13 +7656,13 @@
-echo "configure:7912: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7660: checking for PQcmdTuples in -lpq" >&5
-#line 7918 "configure"
+#line 7666 "configure"
@@ -7925,7 +7673,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:7929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7677: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7968,7 +7716,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:7972: checking whether to use MySQL" >&5
+echo "configure:7720: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -7988,7 +7736,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:7992: checking for location of MySQL includes" >&5
+echo "configure:7740: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -8014,15 +7762,15 @@
 do
-echo "configure:8018: checking for $ac_hdr" >&5
+echo "configure:7766: checking for $ac_hdr" >&5
-#line 8021 "configure"
+#line 7769 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8026: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7774: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8059,7 +7807,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:8063: checking for location of MySQL library" >&5
+echo "configure:7811: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -8090,13 +7838,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:8094: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7842: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 8100 "configure"
+#line 7848 "configure"
@@ -8107,7 +7855,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8111: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8126,13 +7874,13 @@
-echo "configure:8130: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7878: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 8136 "configure"
+#line 7884 "configure"
@@ -8143,7 +7891,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8147: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8162,13 +7910,13 @@
-echo "configure:8166: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7914: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 8172 "configure"
+#line 7920 "configure"
@@ -8179,7 +7927,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7931: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8198,13 +7946,13 @@
-echo "configure:8202: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7950: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 8208 "configure"
+#line 7956 "configure"
@@ -8215,7 +7963,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8234,13 +7982,13 @@
-echo "configure:8238: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7986: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 8244 "configure"
+#line 7992 "configure"
@@ -8251,7 +7999,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8255: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8003: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8270,13 +8018,13 @@
-echo "configure:8274: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8022: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 8280 "configure"
+#line 8028 "configure"
@@ -8287,7 +8035,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8039: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8306,13 +8054,13 @@
-echo "configure:8310: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8058: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 8316 "configure"
+#line 8064 "configure"
@@ -8323,7 +8071,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8327: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8342,13 +8090,13 @@
-echo "configure:8346: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8094: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8352 "configure"
+#line 8100 "configure"
@@ -8359,7 +8107,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8111: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8449,7 +8197,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:8453: checking for $ac_word" >&5
+echo "configure:8201: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -8498,10 +8246,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8502: checking for mysql_server_init" >&5
+echo "configure:8250: checking for mysql_server_init" >&5
-#line 8505 "configure"
+#line 8253 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -8527,7 +8275,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:8531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -8579,7 +8327,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8583: checking whether to use SQLite" >&5
+echo "configure:8331: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -8599,7 +8347,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8603: checking for location of SQLite includes" >&5
+echo "configure:8351: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8625,15 +8373,15 @@
 do
-echo "configure:8629: checking for $ac_hdr" >&5
+echo "configure:8377: checking for $ac_hdr" >&5
-#line 8632 "configure"
+#line 8380 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8637: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8385: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8676,7 +8424,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8680: checking for location of SQLite library" >&5
+echo "configure:8428: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8705,13 +8453,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8709: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8457: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 8715 "configure"
+#line 8463 "configure"
@@ -8722,7 +8470,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8726: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8474: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8741,13 +8489,13 @@
-echo "configure:8745: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8493: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8751 "configure"
+#line 8499 "configure"
@@ -8758,7 +8506,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8762: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8510: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8777,13 +8525,13 @@
-echo "configure:8781: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8529: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8787 "configure"
+#line 8535 "configure"
@@ -8794,7 +8542,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8798: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8813,13 +8561,13 @@
-echo "configure:8817: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8565: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8823 "configure"
+#line 8571 "configure"
@@ -8830,7 +8578,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8834: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8582: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8899,7 +8647,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:8903: checking whether to use FFMPEG" >&5
+echo "configure:8651: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -8919,7 +8667,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:8923: checking for location of FFMPEG includes" >&5
+echo "configure:8671: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -8945,15 +8693,15 @@
 do
-echo "configure:8949: checking for $ac_hdr" >&5
+echo "configure:8697: checking for $ac_hdr" >&5
-#line 8952 "configure"
+#line 8700 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8957: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8705: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8989,15 +8737,15 @@
 do
-echo "configure:8993: checking for $ac_hdr" >&5
+echo "configure:8741: checking for $ac_hdr" >&5
-#line 8996 "configure"
+#line 8744 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9001: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8749: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9033,15 +8781,15 @@
 do
-echo "configure:9037: checking for $ac_hdr" >&5
+echo "configure:8785: checking for $ac_hdr" >&5
-#line 9040 "configure"
+#line 8788 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9045: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8793: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9084,7 +8832,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:9088: checking for location of FFMPEG library" >&5
+echo "configure:8836: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -9111,13 +8859,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:9115: checking for av_free in -lavutil" >&5
+echo "configure:8863: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 9121 "configure"
+#line 8869 "configure"
@@ -9128,7 +8876,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:9132: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8880: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9147,13 +8895,13 @@
-echo "configure:9151: checking for av_free in -lavutil" >&5
+echo "configure:8899: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 9157 "configure"
+#line 8905 "configure"
@@ -9164,7 +8912,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:9168: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8916: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9209,13 +8957,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:9213: checking for avcodec_init in -lavcodec" >&5
+echo "configure:8961: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 9219 "configure"
+#line 8967 "configure"
@@ -9226,7 +8974,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:9230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8978: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9245,13 +8993,13 @@
-echo "configure:9249: checking for avcodec_init in -lavcodec" >&5
+echo "configure:8997: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 9255 "configure"
+#line 9003 "configure"
@@ -9262,7 +9010,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:9266: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9014: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9307,13 +9055,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:9311: checking for av_set_parameters in -lavformat" >&5
+echo "configure:9059: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 9317 "configure"
+#line 9065 "configure"
@@ -9324,7 +9072,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:9328: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9343,13 +9091,13 @@
-echo "configure:9347: checking for av_set_parameters in -lavformat" >&5
+echo "configure:9095: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 9353 "configure"
+#line 9101 "configure"
@@ -9360,7 +9108,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:9364: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9419,7 +9167,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:9423: checking whether to use OpenGL" >&5
+echo "configure:9171: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -9453,7 +9201,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9457: checking for location of OpenGL includes" >&5
+echo "configure:9205: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9479,15 +9227,15 @@
 do
-echo "configure:9483: checking for $ac_hdr" >&5
+echo "configure:9231: checking for $ac_hdr" >&5
-#line 9486 "configure"
+#line 9234 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9491: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9239: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9521,7 +9269,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9525: checking for location of OpenGL library" >&5
+echo "configure:9273: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9550,13 +9298,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9554: checking for glBegin in -lGL" >&5
+echo "configure:9302: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 9560 "configure"
+#line 9308 "configure"
@@ -9567,7 +9315,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9319: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9586,13 +9334,13 @@
-echo "configure:9590: checking for glBegin in -lGL" >&5
+echo "configure:9338: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9596 "configure"
+#line 9344 "configure"
@@ -9603,7 +9351,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9607: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9622,13 +9370,13 @@
-echo "configure:9626: checking for glBegin in -lGL" >&5
+echo "configure:9374: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9632 "configure"
+#line 9380 "configure"
@@ -9639,7 +9387,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9391: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9658,13 +9406,13 @@
-echo "configure:9662: checking for glBegin in -lGL" >&5
+echo "configure:9410: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9668 "configure"
+#line 9416 "configure"
@@ -9675,7 +9423,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9679: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9737,13 +9485,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9741: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9489: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 9747 "configure"
+#line 9495 "configure"
@@ -9754,7 +9502,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9758: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9506: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9773,13 +9521,13 @@
-echo "configure:9777: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9525: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9783 "configure"
+#line 9531 "configure"
@@ -9790,7 +9538,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9542: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9837,10 +9585,10 @@
 LIBS=" $OPENGLLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9841: checking for glXCreatePbuffer" >&5
+echo "configure:9589: checking for glXCreatePbuffer" >&5
-#line 9844 "configure"
+#line 9592 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -9863,7 +9611,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9615: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -9900,10 +9648,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9904: checking for glXCreateGLXPixmap" >&5
+echo "configure:9652: checking for glXCreateGLXPixmap" >&5
-#line 9907 "configure"
+#line 9655 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -9926,7 +9674,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9930: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -9969,7 +9717,7 @@
 echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9973: checking for location of OpenGL framework" >&5
+echo "configure:9721: checking for location of OpenGL framework" >&5
 case "$with_opengl_framework" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9993,15 +9741,15 @@
 do
-echo "configure:9997: checking for $ac_hdr" >&5
+echo "configure:9745: checking for $ac_hdr" >&5
-#line 10000 "configure"
+#line 9748 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10005: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9753: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10037,10 +9785,10 @@
 LIBS="-framework OpenGL -framework AGL -framework ApplicationServices  $LIBS"
 LDFLAGS="$OPENGLPATH $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:10041: checking for glBegin" >&5
+echo "configure:9789: checking for glBegin" >&5
-#line 10044 "configure"
+#line 9792 "configure"
     which can conflict with char glBegin(); below.  */
@@ -10063,7 +9811,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9815: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -10100,10 +9848,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:10104: checking for gluBeginCurve" >&5
+echo "configure:9852: checking for gluBeginCurve" >&5
-#line 10107 "configure"
+#line 9855 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -10126,7 +9874,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10130: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -10174,7 +9922,7 @@
-echo "configure:10178: checking for location of OpenGL includes" >&5
+echo "configure:9926: checking for location of OpenGL includes" >&5
@@ -10200,15 +9948,15 @@
 do
-echo "configure:10204: checking for $ac_hdr" >&5
+echo "configure:9952: checking for $ac_hdr" >&5
-#line 10207 "configure"
+#line 9955 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10212: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9960: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10242,7 +9990,7 @@
-echo "configure:10246: checking for location of OpenGL library" >&5
+echo "configure:9994: checking for location of OpenGL library" >&5
@@ -10267,18 +10015,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:10271: checking for OpenGL library" >&5
+echo "configure:10019: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 10275 "configure"
+#line 10023 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:10282: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -10302,18 +10050,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:10306: checking for GLU library" >&5
+echo "configure:10054: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 10310 "configure"
+#line 10058 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:10317: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10065: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -10362,7 +10110,7 @@
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:10366: checking whether to use Tcl/Tk" >&5
+echo "configure:10114: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	"no")	USE_TCLTK=	;;
@@ -10382,7 +10130,7 @@
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:10386: checking for location of Tcl/Tk includes" >&5
+echo "configure:10134: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -10408,15 +10156,15 @@
 do
-echo "configure:10412: checking for $ac_hdr" >&5
+echo "configure:10160: checking for $ac_hdr" >&5
-#line 10415 "configure"
+#line 10163 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10420: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10168: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10453,15 +10201,15 @@
 do
-echo "configure:10457: checking for $ac_hdr" >&5
+echo "configure:10205: checking for $ac_hdr" >&5
-#line 10460 "configure"
+#line 10208 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10465: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10213: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10495,7 +10243,7 @@
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:10499: checking Tcl version" >&5
+echo "configure:10247: checking Tcl version" >&5
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -10503,7 +10251,7 @@
     echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 10507 "configure"
+#line 10255 "configure"
 #include <stdio.h>
@@ -10515,7 +10263,7 @@
 EOF
-if { (eval echo configure:10519: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:10267: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -10533,7 +10281,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:10537: checking Tk version" >&5
+echo "configure:10285: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -10541,7 +10289,7 @@
 else
-#line 10545 "configure"
+#line 10293 "configure"
 #include <stdio.h>
@@ -10553,7 +10301,7 @@
 EOF
-if { (eval echo configure:10557: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:10305: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -10582,7 +10330,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:10586: checking for location of Tcl/Tk library" >&5
+echo "configure:10334: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -10622,13 +10370,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:10626: checking for Tcl_Init in -ltcl" >&5
+echo "configure:10374: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 10632 "configure"
+#line 10380 "configure"
@@ -10639,7 +10387,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10391: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10658,13 +10406,13 @@
-echo "configure:10662: checking for Tcl_Init in -ltcl" >&5
+echo "configure:10410: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 10668 "configure"
+#line 10416 "configure"
@@ -10675,7 +10423,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10679: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10702,13 +10450,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:10706: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:10454: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 10712 "configure"
+#line 10460 "configure"
@@ -10719,7 +10467,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10723: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10738,13 +10486,13 @@
-echo "configure:10742: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:10490: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 10748 "configure"
+#line 10496 "configure"
@@ -10755,7 +10503,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10759: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10507: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10782,13 +10530,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:10786: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:10534: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 10792 "configure"
+#line 10540 "configure"
@@ -10799,7 +10547,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10551: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10818,13 +10566,13 @@
-echo "configure:10822: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:10570: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 10828 "configure"
+#line 10576 "configure"
@@ -10835,7 +10583,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10839: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10587: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10913,13 +10661,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:10917: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:10665: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 10923 "configure"
+#line 10671 "configure"
@@ -10930,7 +10678,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:10934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10682: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10949,13 +10697,13 @@
-echo "configure:10953: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:10701: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 10959 "configure"
+#line 10707 "configure"
@@ -10966,7 +10714,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:10970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10718: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10993,13 +10741,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:10997: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:10745: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 11003 "configure"
+#line 10751 "configure"
@@ -11010,7 +10758,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:11014: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10762: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11029,13 +10777,13 @@
-echo "configure:11033: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:10781: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 11039 "configure"
+#line 10787 "configure"
@@ -11046,7 +10794,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:11050: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10798: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11073,13 +10821,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:11077: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:10825: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 11083 "configure"
+#line 10831 "configure"
@@ -11090,7 +10838,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:11094: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11109,13 +10857,13 @@
-echo "configure:11113: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:10861: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 11119 "configure"
+#line 10867 "configure"
@@ -11126,7 +10874,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:11130: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11216,13 +10964,13 @@
   do
     # add only if in MACOSX_ARCHS
     echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:11220: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:10968: checking for Tcl_Init in -l$tlib" >&5
 ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 11226 "configure"
+#line 10974 "configure"
@@ -11233,7 +10981,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11237: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11283,7 +11031,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11287: checking whether to use ODBC" >&5
+echo "configure:11035: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -11302,7 +11050,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11306: checking for location of ODBC includes" >&5
+echo "configure:11054: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11328,15 +11076,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:11332: checking for $ac_hdr" >&5
+echo "configure:11080: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 11335 "configure"
+#line 11083 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:11340: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11088: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -11370,7 +11118,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11374: checking for location of ODBC library" >&5
+echo "configure:11122: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -11395,13 +11143,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:11399: checking for SQLConnect in -lodbc" >&5
+echo "configure:11147: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 11405 "configure"
+#line 11153 "configure"
@@ -11412,7 +11160,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:11416: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11437,13 +11185,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:11441: checking for SQLConnect in -liodbc" >&5
+echo "configure:11189: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-liodbc  $LIBS"
-#line 11447 "configure"
+#line 11195 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -11454,7 +11202,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:11458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11206: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -11479,11 +11227,11 @@
 ac_save_ldflags="$LDFLAGS"
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:11483: checking for ODBC library" >&5
+echo "configure:11231: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 11487 "configure"
+#line 11235 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -11491,7 +11239,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:11495: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11243: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11540,7 +11288,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:11544: checking whether to use FFTW" >&5
+echo "configure:11292: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -11559,7 +11307,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:11563: checking for location of FFTW includes" >&5
+echo "configure:11311: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -11585,15 +11333,15 @@
 do
-echo "configure:11589: checking for $ac_hdr" >&5
+echo "configure:11337: checking for $ac_hdr" >&5
-#line 11592 "configure"
+#line 11340 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11597: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11345: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11621,15 +11369,15 @@
 do
-echo "configure:11625: checking for $ac_hdr" >&5
+echo "configure:11373: checking for $ac_hdr" >&5
-#line 11628 "configure"
+#line 11376 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11633: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11381: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11657,15 +11405,15 @@
 do
-echo "configure:11661: checking for $ac_hdr" >&5
+echo "configure:11409: checking for $ac_hdr" >&5
-#line 11664 "configure"
+#line 11412 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11669: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11417: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11711,7 +11459,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:11715: checking for location of FFTW library" >&5
+echo "configure:11463: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -11736,13 +11484,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:11740: checking for fftw_execute in -lfftw3" >&5
+echo "configure:11488: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 11746 "configure"
+#line 11494 "configure"
@@ -11753,7 +11501,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:11757: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11505: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11778,13 +11526,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:11782: checking for fftwnd_one in -lfftw" >&5
+echo "configure:11530: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 11788 "configure"
+#line 11536 "configure"
@@ -11795,7 +11543,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:11799: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11820,13 +11568,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:11824: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:11572: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 11830 "configure"
+#line 11578 "configure"
@@ -11837,7 +11585,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:11841: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11589: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11894,7 +11642,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:11898: checking whether to use BLAS" >&5
+echo "configure:11646: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -11915,7 +11663,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:11919: checking for location of BLAS includes" >&5
+echo "configure:11667: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -11935,7 +11683,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:11939: checking for location of BLAS library" >&5
+echo "configure:11687: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -11961,15 +11709,15 @@
 do
-echo "configure:11965: checking for $ac_hdr" >&5
+echo "configure:11713: checking for $ac_hdr" >&5
-#line 11968 "configure"
+#line 11716 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11973: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11721: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12004,13 +11752,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12008: checking for dnrm2_ in -lblas" >&5
+echo "configure:11756: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 12014 "configure"
+#line 11762 "configure"
@@ -12021,7 +11769,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12040,13 +11788,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:12044: checking for dnrm2_ in -lblas" >&5
+echo "configure:11792: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12050 "configure"
+#line 11798 "configure"
@@ -12057,7 +11805,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11809: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12101,13 +11849,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12105: checking for ATL_xerbla in -latlas" >&5
+echo "configure:11853: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 12111 "configure"
+#line 11859 "configure"
@@ -12118,7 +11866,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:12122: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11870: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12133,13 +11881,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo "$ac_t""yes" 1>&6
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12137: checking for sgemm_ in -lf77blas" >&5
+echo "configure:11885: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 12143 "configure"
+#line 11891 "configure"
@@ -12150,7 +11898,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12154: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11902: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12165,13 +11913,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12169: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:11917: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12175 "configure"
+#line 11923 "configure"
@@ -12182,7 +11930,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:12186: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12228,16 +11976,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12232: checking for sgemm in $vlib_flags" >&5
+echo "configure:11980: checking for sgemm in $vlib_flags" >&5
-#line 12234 "configure"
+#line 11982 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:12241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11989: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -12255,13 +12003,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12259: checking for sgemm_ in -lblas" >&5
+echo "configure:12007: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 12265 "configure"
+#line 12013 "configure"
@@ -12272,7 +12020,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12276: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12287,13 +12035,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12291: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12039: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 12297 "configure"
+#line 12045 "configure"
@@ -12304,7 +12052,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12308: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12319,13 +12067,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12323: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12071: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 12329 "configure"
+#line 12077 "configure"
@@ -12336,7 +12084,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12088: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12370,13 +12118,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12374: checking for acosp in -lsunmath" >&5
+echo "configure:12122: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 12380 "configure"
+#line 12128 "configure"
@@ -12387,7 +12135,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:12391: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12402,13 +12150,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:12406: checking for sgemm_ in -lsunperf" >&5
+echo "configure:12154: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 12412 "configure"
+#line 12160 "configure"
@@ -12419,7 +12167,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12423: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12171: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12449,13 +12197,13 @@
 # Generic BLAS library
-echo "configure:12453: checking for sgemm_ in -lblas" >&5
+echo "configure:12201: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 12459 "configure"
+#line 12207 "configure"
@@ -12466,7 +12214,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12470: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12218: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12505,7 +12253,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:12509: checking whether to use LAPACK" >&5
+echo "configure:12257: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -12530,7 +12278,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:12534: checking for location of LAPACK includes" >&5
+echo "configure:12282: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -12550,7 +12298,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:12554: checking for location of LAPACK library" >&5
+echo "configure:12302: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -12576,15 +12324,15 @@
 do
-echo "configure:12580: checking for $ac_hdr" >&5
+echo "configure:12328: checking for $ac_hdr" >&5
-#line 12583 "configure"
+#line 12331 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12588: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12336: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12616,10 +12364,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:12620: checking for dsegv_" >&5
+echo "configure:12368: checking for dsegv_" >&5
-#line 12623 "configure"
+#line 12371 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -12642,7 +12390,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12646: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12394: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -12669,13 +12417,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:12673: checking for desgv_ in -llapack" >&5
+echo "configure:12421: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 12679 "configure"
+#line 12427 "configure"
@@ -12686,7 +12434,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:12690: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12438: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12718,13 +12466,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:12722: checking for dgesv_ in -llapack" >&5
+echo "configure:12470: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 12728 "configure"
+#line 12476 "configure"
@@ -12735,7 +12483,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:12739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12487: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12754,13 +12502,13 @@
-echo "configure:12758: checking for dgesv_ in -llapack" >&5
+echo "configure:12506: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 12764 "configure"
+#line 12512 "configure"
@@ -12771,7 +12519,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:12775: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12827,7 +12575,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:12831: checking whether to use Cairo" >&5
+echo "configure:12579: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -12859,7 +12607,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:12863: checking for location of cairo includes" >&5
+echo "configure:12611: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -12885,15 +12633,15 @@
 do
-echo "configure:12889: checking for $ac_hdr" >&5
+echo "configure:12637: checking for $ac_hdr" >&5
-#line 12892 "configure"
+#line 12640 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12897: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12645: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12929,7 +12677,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:12933: checking for location of cairo library" >&5
+echo "configure:12681: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -12949,7 +12697,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:12953: checking for cairo linking flags" >&5
+echo "configure:12701: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -12965,10 +12713,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:12969: checking for cairo_create" >&5
+echo "configure:12717: checking for cairo_create" >&5
-#line 12972 "configure"
+#line 12720 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -12991,7 +12739,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12995: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -13025,10 +12773,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:13029: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:12777: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 13032 "configure"
+#line 12780 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -13051,7 +12799,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13055: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -13084,10 +12832,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:13088: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:12836: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 13091 "configure"
+#line 12839 "configure"
     which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
@@ -13110,7 +12858,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13114: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
 else
@@ -13152,7 +12900,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:13156: checking whether to use FreeType" >&5
+echo "configure:12904: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -13171,7 +12919,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:13175: checking for location of FreeType includes" >&5
+echo "configure:12923: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -13197,15 +12945,15 @@
 do
-echo "configure:13201: checking for $ac_hdr" >&5
+echo "configure:12949: checking for $ac_hdr" >&5
-#line 13204 "configure"
+#line 12952 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13209: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12957: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13239,7 +12987,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:13243: checking for location of FreeType library" >&5
+echo "configure:12991: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -13264,13 +13012,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:13268: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:13016: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 13274 "configure"
+#line 13022 "configure"
@@ -13281,7 +13029,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:13285: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13322,7 +13070,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:13326: checking whether to use NLS" >&5
+echo "configure:13074: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -13342,10 +13090,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:13346: checking for gettext" >&5
+echo "configure:13094: checking for gettext" >&5
-#line 13349 "configure"
+#line 13097 "configure"
     which can conflict with char gettext(); below.  */
@@ -13368,7 +13116,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13372: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -13386,13 +13134,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:13390: checking for gettext in -lintl" >&5
+echo "configure:13138: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 13396 "configure"
+#line 13144 "configure"
@@ -13403,7 +13151,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:13407: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13438,7 +13186,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:13442: checking whether to use C++" >&5
+echo "configure:13190: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -13454,7 +13202,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13458: checking for $ac_word" >&5
+echo "configure:13206: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -13483,7 +13231,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:13487: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:13235: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -13494,12 +13242,12 @@
 cat > conftest.$ac_ext << EOF
-#line 13498 "configure"
+#line 13246 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:13503: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -13525,19 +13273,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:13529: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:13277: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:13534: checking whether we are using GNU C++" >&5
+echo "configure:13282: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13541: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13289: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -13555,7 +13303,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:13559: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:13307: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -13583,7 +13331,58 @@
   fi
 fi
+for ac_declaration in \
+   '#include <stdlib.h>' \
+   'extern "C" void std::exit (int) throw (); using std::exit;' \
+   'extern "C" void std::exit (int); using std::exit;' \
+   'extern "C" void exit (int) throw ();' \
+   'extern "C" void exit (int);' \
+   'void exit (int);'
+do
+  cat > conftest.$ac_ext <<EOF
+#line 13345 "configure"
+#include "confdefs.h"
+#include <stdlib.h>
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:13353: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  continue
+fi
+rm -f conftest*
+#line 13363 "configure"
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:13370: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+  rm -rf conftest*
+  break
+else
+fi
+rm -f conftest*
+done
+if test -n "$ac_declaration"; then
+  echo '#ifdef __cplusplus' >>confdefs.h
+  echo $ac_declaration      >>confdefs.h
+  echo '#endif'             >>confdefs.h
+fi
+else
 	CXX=
 	CXXFLAGS=
@@ -13596,7 +13395,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:13600: checking whether to use openDWG" >&5
+echo "configure:13399: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -13616,7 +13415,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:13620: checking for location of openDGW includes" >&5
+echo "configure:13419: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -13642,15 +13441,15 @@
 do
-echo "configure:13646: checking for $ac_hdr" >&5
+echo "configure:13445: checking for $ac_hdr" >&5
-#line 13649 "configure"
+#line 13448 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13654: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13453: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13684,7 +13483,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:13688: checking for location of openDWG library" >&5
+echo "configure:13487: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -13725,7 +13524,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:13729: checking whether to use POSIX threads" >&5
+echo "configure:13528: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -13745,7 +13544,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:13749: checking for location of POSIX threads includes" >&5
+echo "configure:13548: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -13771,15 +13570,15 @@
 do
-echo "configure:13775: checking for $ac_hdr" >&5
+echo "configure:13574: checking for $ac_hdr" >&5
-#line 13778 "configure"
+#line 13577 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13783: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13582: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13813,7 +13612,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:13817: checking for location of POSIX threads library" >&5
+echo "configure:13616: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -13838,10 +13637,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:13842: checking for pthread_create" >&5
+echo "configure:13641: checking for pthread_create" >&5
-#line 13845 "configure"
+#line 13644 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char pthread_create(); below.  */
@@ -13864,7 +13663,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13667: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -13891,13 +13690,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:13895: checking for pthread_create in -lpthread" >&5
+echo "configure:13694: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 LIBS="-lpthread  $LIBS"
-#line 13901 "configure"
+#line 13700 "configure"
@@ -13908,7 +13707,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:13912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13958,7 +13757,7 @@
 echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:13962: checking whether to use OpenMP" >&5
+echo "configure:13761: checking whether to use OpenMP" >&5
 echo "$ac_t"""$with_openmp"" 1>&6
 case "$with_openmp" in
 	"no")	USE_OPENMP=	;;
@@ -13979,7 +13778,7 @@
 echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:13983: checking for location of OpenMP includes" >&5
+echo "configure:13782: checking for location of OpenMP includes" >&5
 case "$with_openmp_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -14005,15 +13804,15 @@
 do
-echo "configure:14009: checking for $ac_hdr" >&5
+echo "configure:13808: checking for $ac_hdr" >&5
-#line 14012 "configure"
+#line 13811 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14017: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13816: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14051,7 +13850,7 @@
 echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:14055: checking for location of OpenMP library" >&5
+echo "configure:13854: checking for location of OpenMP library" >&5
 case "$with_gomp_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-gomp-libs." 1>&2; exit 1; }
@@ -14076,10 +13875,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:14080: checking for GOMP_parallel_start" >&5
+echo "configure:13879: checking for GOMP_parallel_start" >&5
-#line 14083 "configure"
+#line 13882 "configure"
     which can conflict with char GOMP_parallel_start(); below.  */
@@ -14102,7 +13901,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14106: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13905: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_GOMP_parallel_start=yes"
 else
@@ -14129,13 +13928,13 @@
 echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:14133: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:13932: checking for GOMP_parallel_start in -lgomp" >&5
 ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
 LIBS="-lgomp  $LIBS"
-#line 14139 "configure"
+#line 13938 "configure"
@@ -14146,7 +13945,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13949: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14225,7 +14024,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14229: checking for special C compiler options needed for large files" >&5
+echo "configure:14028: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -14233,7 +14032,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 14237 "configure"
+#line 14036 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -14249,7 +14048,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14253: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14052: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -14258,7 +14057,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 14262 "configure"
+#line 14061 "configure"
@@ -14274,7 +14073,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14278: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14077: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -14294,11 +14093,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14298: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14097: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 14302 "configure"
+#line 14101 "configure"
@@ -14314,14 +14113,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14318: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14117: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14325 "configure"
+#line 14124 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -14339,7 +14138,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14343: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14142: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -14358,11 +14157,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14362: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:14161: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 14366 "configure"
+#line 14165 "configure"
@@ -14378,14 +14177,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14382: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14181: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14389 "configure"
+#line 14188 "configure"
 #define _LARGE_FILES 1
@@ -14403,7 +14202,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14407: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14206: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -14422,25 +14221,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:14426: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14225: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 14430 "configure"
+#line 14229 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14437: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14236: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14444 "configure"
+#line 14243 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -14449,7 +14248,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14453: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14252: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -14470,25 +14269,25 @@
    fi
-echo "configure:14474: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14273: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 14478 "configure"
+#line 14277 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14485: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14284: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14492 "configure"
+#line 14291 "configure"
 #include <stdio.h>
@@ -14497,7 +14296,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14501: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14300: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 else
@@ -14520,18 +14319,18 @@
    # If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
    echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:14524: checking for fseeko" >&5
+echo "configure:14323: checking for fseeko" >&5
 ac_cv_func_fseeko=no
-#line 14528 "configure"
+#line 14327 "configure"
 #include <stdio.h>
 int main() {
 return fseeko && fseeko (stdin, 0, 0);
 ; return 0; }
 EOF
-if { (eval echo configure:14535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14334: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_func_fseeko=yes
 else
@@ -14548,10 +14347,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14552: checking if system supports Large Files at all" >&5
+echo "configure:14351: checking if system supports Large Files at all" >&5
-#line 14555 "configure"
+#line 14354 "configure"
 #include <stdio.h>
@@ -14583,7 +14382,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:14587: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14386: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -14612,7 +14411,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:14616: checking whether to use wxWidgets" >&5
+echo "configure:14415: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -14633,7 +14432,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:14637: checking for $ac_word" >&5
+echo "configure:14436: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -14681,7 +14480,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:14685: checking wxWidgets version" >&5
+echo "configure:14484: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -14704,15 +14503,15 @@
 do
-echo "configure:14708: checking for $ac_hdr" >&5
+echo "configure:14507: checking for $ac_hdr" >&5
-#line 14711 "configure"
+#line 14510 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14716: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14515: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14963,9 +14762,6 @@
 s%@READLINELIBPATH@%$READLINELIBPATH%g
 s%@READLINELIB@%$READLINELIB%g
 s%@HISTORYLIB@%$HISTORYLIB%g
-s%@JPEGINCPATH@%$JPEGINCPATH%g
-s%@JPEGLIBPATH@%$JPEGLIBPATH%g
-s%@JPEGLIB@%$JPEGLIB%g
 s%@GDAL_CONFIG@%$GDAL_CONFIG%g
 s%@GDAL_LIBS@%$GDAL_LIBS%g
 s%@GDAL_CFLAGS@%$GDAL_CFLAGS%g
@@ -15363,8 +15159,6 @@
 echo "  GEOS support:               `if test -n "${USE_GEOS}" ; then echo yes ; else echo no ; fi`"
-echo "  JPEG support:               `if test -n "${USE_JPEG}" ; then echo yes ; else echo no ; fi`"
 echo "  LAPACK support:             `if test -n "${USE_LAPACK}" ; then echo yes ; else echo no ; fi`"
 echo "  Large File support (LFS):   `if test -n "${USE_LARGEFILES}" ; then echo yes ; else echo no ; fi`"
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2012-03-11 19:51:37 UTC (rev 51036)
+++ grass/trunk/configure.in	2012-03-11 19:53:06 UTC (rev 51037)
@@ -244,7 +244,6 @@
 AC_ARG_WITH(macosx-sdk,
 [  --with-macosx-sdk[=path/sdk]
                           compile with a system SDK on MacOSX. (default: no)],, with_macosx_sdk="no")
-LOC_ARG_WITH(jpeg, JPEG)
 LOC_ARG_WITH(tiff, TIFF)
 LOC_ARG_WITH(png, PNG)
 LOC_ARG_WITH(tcltk, Tcl/Tk)
@@ -303,9 +302,6 @@
 LOC_ARG_WITH_INC(readline, Readline)
 LOC_ARG_WITH_LIB(readline, Readline)
-LOC_ARG_WITH_INC(jpeg, JPEG)
-LOC_ARG_WITH_LIB(jpeg, JPEG)
 LOC_ARG_WITH_INC(tiff, TIFF)
 LOC_ARG_WITH_LIB(tiff, TIFF)
@@ -724,36 +720,6 @@
 # Done checking Readline
-# Enable JPEG option
-LOC_CHECK_USE(jpeg,JPEG,USE_JPEG)
-JPEGINCPATH=
-JPEGLIBPATH=
-JPEGLIB=
-if test -n "$USE_JPEG"; then
-# With JPEG includes directory
-LOC_CHECK_INC_PATH(jpeg,JPEG,JPEGINCPATH)
-LOC_CHECK_INCLUDES(jpeglib.h,JPEG,$JPEGINCPATH)
-# With JPEG library directory
-LOC_CHECK_LIB_PATH(jpeg,JPEG,JPEGLIBPATH)
-LOC_CHECK_LIBS(jpeg,jpeg_start_compress,JPEG,$JPEGLIBPATH,JPEGLIB,,,,$ZLIB)
-fi # $USE_JPEG
-AC_SUBST(JPEGINCPATH)
-AC_SUBST(JPEGLIBPATH)
-AC_SUBST(JPEGLIB)
-# Done checking JPEG
 # GDAL option
 AC_MSG_CHECKING(whether to use GDAL)
@@ -922,7 +888,7 @@
 LOC_CHECK_LIB_PATH(tiff,TIFF,TIFF_LIBRARY_DIRS)
-LOC_CHECK_LIBS(tiff,TIFFOpen,TIFF,$TIFF_LIBRARY_DIRS,TIFFLIB,,,,$JPEGLIBPATH $JPEGLIB,$ZLIB,$MATHLIB)
+LOC_CHECK_LIBS(tiff,TIFFOpen,TIFF,$TIFF_LIBRARY_DIRS,TIFFLIB,,,,-ljpeg,$ZLIB,$MATHLIB)
 fi # $USE_TIFF
@@ -2010,7 +1976,6 @@
 LOC_MSG_USE(FreeType support,USE_FREETYPE)
 LOC_MSG_USE(GDAL support,USE_GDAL)
 LOC_MSG_USE(GEOS support,USE_GEOS)
-LOC_MSG_USE(JPEG support,USE_JPEG)
 LOC_MSG_USE(LAPACK support,USE_LAPACK)
 LOC_MSG_USE(Large File support (LFS), USE_LARGEFILES)
 LOC_MSG_USE(libLAS support,USE_LIBLAS)
