[GRASS-SVN] r51103 - grass/trunk/vector/v.external
Sun Mar 18 08:00:10 EDT 2012
Author: martinl
Date: 2012-03-18 05:00:10 -0700 (Sun, 18 Mar 2012)
New Revision: 51103
   grass/trunk/vector/v.external/list.c
v.external: -lp - report schema when there is at least one table in non-public schema, order by table name
Modified: grass/trunk/vector/v.external/list.c
--- grass/trunk/vector/v.external/list.c	2012-03-18 10:35:31 UTC (rev 51102)
+++ grass/trunk/vector/v.external/list.c	2012-03-18 12:00:10 UTC (rev 51103)
@@ -25,7 +25,7 @@
     int i;
     OGRSFDriverH Ogr_driver;
-    G_message(_("Supported OGR formats for reading:"));
+    G_message(_("List of supported OGR formats:"));
     for (i = 0; i < OGRGetDriverCount(); i++) {
 	Ogr_driver = OGRGetDriver(i);
 	fprintf(fd, "%s\n", OGR_Dr_GetName(Ogr_driver));
@@ -56,7 +56,7 @@
 int list_layers_pg(FILE *fd, const char *conninfo, const char *table, int print_types, int *is3D)
 #ifdef HAVE_POSTGRES
-    int row, ntables, ret;
+    int row, ntables, ret, print_schema;
     char *value;
     PGconn *conn;
     PGresult *res;
@@ -72,8 +72,9 @@
 		      PQerrorMessage(conn));
     db_init_string(&sql);
-    db_set_string(&sql, "SELECT f_table_name, type "
-		  "FROM geometry_columns");
+    db_set_string(&sql, "SELECT f_table_schema, f_table_name, type "
+		  "FROM geometry_columns ORDER BY "
+		  "f_table_schema, f_table_name");
     G_debug(2, "SQL: %s", db_get_string(&sql));
     res = PQexec(conn, db_get_string(&sql));
     if (PQresultStatus(res) != PGRES_TUPLES_OK)
@@ -86,13 +87,34 @@
 	G_message(_("PostGIS database <%s> contains %d feature table(s):"),
 		  PQdb(conn), ntables);
+    /* report also schemas */
+    print_schema = FALSE;
     for (row = 0; row < ntables; row++) {
 	value = PQgetvalue(res, row, 0);
+	if (strcmp(value, "public") != 0) {
+	    print_schema = TRUE;
+	    break;
+    /* report layers */
+    for (row = 0; row < ntables; row++) {
+	value = PQgetvalue(res, row, 1);
 	if (fd) {
-	    if (print_types)
-		fprintf(fd, "%s (%s)\n", value, PQgetvalue(res, row, 1));
-	    else
-		fprintf(fd, "%s\n", value);
+	    if (print_types) {
+		if (print_schema)
+		    fprintf(fd, "%s.%s (%s)\n",
+			    PQgetvalue(res, row, 0), value,
+			    PQgetvalue(res, row, 2));
+		else
+		    fprintf(fd, "%s (%s)\n", value, PQgetvalue(res, row, 2));
+	    else {
+		if (print_schema)
+		    fprintf(fd, "%s.%s\n", PQgetvalue(res, row, 0), value);
+		else
+		    fprintf(fd, "%s\n", value);
 	if (table && strcmp(value, table) == 0) {
 	    ret = row;
