[GRASS-SVN] r51123 - grass/trunk/vector/v.external.out
Tue Mar 20 22:00:01 EDT 2012
Author: martinl
Date: 2012-03-20 19:00:01 -0700 (Tue, 20 Mar 2012)
New Revision: 51123
   grass/trunk/vector/v.external.out/link.c
   grass/trunk/vector/v.external.out/status.c
v.external.out(pg): add new options - spatial_index=on|off primary_key=on|off
Modified: grass/trunk/vector/v.external.out/link.c
--- grass/trunk/vector/v.external.out/link.c	2012-03-21 01:11:56 UTC (rev 51122)
+++ grass/trunk/vector/v.external.out/link.c	2012-03-21 02:00:01 UTC (rev 51123)
@@ -5,6 +5,7 @@
 #include <grass/glocale.h>
 static char *get_option_pg(char **, const char *);
+static void check_option_on_off(const char *, char **);
 void make_link(const char *dsn,
 	       const char *format,
@@ -12,6 +13,7 @@
     int use_ogr;
     char *filename, *pg_schema, *pg_fid, *pg_geom_name;
+    char *pg_spatial_index, *pg_primary_key;
     FILE *fp;
     struct Key_Value *key_val;
@@ -32,10 +34,19 @@
     /* parse options for PG data format */
     pg_schema = pg_fid = pg_geom_name = NULL;
+    pg_spatial_index = pg_primary_key = NULL;
     if (options && *options && !use_ogr) {
 	pg_schema    = get_option_pg(options, "schema");
 	pg_fid       = get_option_pg(options, "fid");
 	pg_geom_name = get_option_pg(options, "geometry_name");
+	pg_spatial_index = get_option_pg(options, "spatial_index");
+	if (pg_spatial_index) {
+	    check_option_on_off("spatial_index", &pg_spatial_index);
+	pg_primary_key = get_option_pg(options, "primary_key");
+	if (pg_primary_key) {
+	    check_option_on_off("primary_key", &pg_primary_key);
     /* add key/value items */
     if (dsn) {
@@ -58,6 +69,10 @@
 	    G_set_key_value("fid", pg_fid, key_val);
 	if (pg_geom_name)
 	    G_set_key_value("geometry_name", pg_geom_name, key_val);
+	    G_set_key_value("spatial_index", pg_spatial_index, key_val);
+	    G_set_key_value("primary_key", pg_primary_key, key_val);
     /* save file - OGR or PG */
@@ -97,3 +112,14 @@
     return value;
+void check_option_on_off(const char *key, char **value)
+    if(G_strcasecmp(*value, "on") != 0 &&
+       G_strcasecmp(*value, "off") != 0) {
+	G_warning(_("Invalid option '%s=%s' ignored (allowed values: '%s', '%s')"),
+		  key, *value, "ON", "OFF");
+	G_free(*value);
+	*value = NULL;
Modified: grass/trunk/vector/v.external.out/status.c
--- grass/trunk/vector/v.external.out/status.c	2012-03-21 01:11:56 UTC (rev 51122)
+++ grass/trunk/vector/v.external.out/status.c	2012-03-21 02:00:01 UTC (rev 51123)
@@ -82,6 +82,14 @@
 	/* geometry_name */
 	p = G_find_key_value("geometry_name", key_val);
 	print_key_value("geometry_name", p, shell);
+	/* spatial_index */
+	p = G_find_key_value("spatial_index", key_val);
+	print_key_value("spatial_index", p, shell);
+	/* primary_key */
+	p = G_find_key_value("primary_key", key_val);
+	print_key_value("primary_key", p, shell);
     G_free_key_value(key_val);
