[GRASS-SVN] r51128 - in grass/trunk: lib/vector/Vlib vector/v.edit
Wed Mar 21 10:21:47 EDT 2012
Author: martinl
Date: 2012-03-21 07:21:47 -0700 (Wed, 21 Mar 2012)
New Revision: 51128
   grass/trunk/lib/vector/Vlib/open_pg.c
   grass/trunk/vector/v.edit/main.c
v.edit: fix `tool=create` for PostGIS data driver
Modified: grass/trunk/lib/vector/Vlib/open_pg.c
--- grass/trunk/lib/vector/Vlib/open_pg.c	2012-03-21 11:37:08 UTC (rev 51127)
+++ grass/trunk/lib/vector/Vlib/open_pg.c	2012-03-21 14:21:47 UTC (rev 51128)
@@ -246,8 +246,9 @@
 	else {
-	    G_warning(_("PostGIS layer <%s> already exists in database '%s'"),
-		      pg_info->table_name, pg_info->db_name);
+	    G_fatal_error(_("PostGIS layer <%s.%s> already exists in database '%s'"),
+			  pg_info->schema_name, pg_info->table_name,
+			  pg_info->db_name);
 	    return -1;
Modified: grass/trunk/vector/v.edit/main.c
--- grass/trunk/vector/v.edit/main.c	2012-03-21 11:37:08 UTC (rev 51127)
+++ grass/trunk/vector/v.edit/main.c	2012-03-21 14:21:47 UTC (rev 51128)
@@ -84,10 +84,12 @@
 	G_fatal_error(_("Required parameter <%s> not set"), params.in->key);
     if (action_mode == MODE_CREATE) {
-	int overwrite;
+	int overwrite, map_type;
 	overwrite = G_check_overwrite(argc, argv);
-	if (G_find_vector2(params.map->answer, G_mapset())) {
+	if (G_find_vector2(params.map->answer, G_mapset()) &&
+	    (!G_find_file("", "OGR", G_mapset()) &&
+	     !G_find_file("", "PG", G_mapset()))) {
 	    if (!overwrite)
 		G_fatal_error(_("Vector map <%s> already exists"),
 			      params.map->answer);
@@ -95,20 +97,26 @@
 	/* 3D vector maps? */
 	ret = Vect_open_new(&Map, params.map->answer, WITHOUT_Z);
-	if (Vect_maptype(&Map) == GV_FORMAT_OGR_DIRECT) {
+	if (ret == -1) {
+	    G_fatal_error(_("Unable to create vector map <%s>"),
+			  params.map->answer);
+	/* native or external data source ? */
+	map_type = Vect_maptype(&Map);
+	if (map_type != GV_FORMAT_NATIVE) {
 	    int type;
 	    type = Vect_option_to_types(params.type);
 	    if (type != GV_POINT && type != GV_LINE &&
 		type != GV_BOUNDARY)
 		G_fatal_error(_("Supported feature type for OGR layer: "
 				"%s, %s or %s"), "point", "line", "boundary");
-	    V2_open_new_ogr(&Map, type);
+	    if (map_type == GV_FORMAT_POSTGIS)
+		V2_open_new_pg(&Map, type);
+	    else
+		V2_open_new_ogr(&Map, type);
-	if (ret == -1) {
-	    G_fatal_error(_("Unable to create vector map <%s>"),
-			  params.map->answer);
 	G_debug(1, "Map created");
 	if (ascii) {
