[GRASS-SVN] r51147 - grass/trunk/lib/python/temporal
Thu Mar 22 15:30:11 EDT 2012
Author: huhabla
Date: 2012-03-22 12:30:10 -0700 (Thu, 22 Mar 2012)
New Revision: 51147
Added:
   grass/trunk/lib/python/temporal/temporal_relationships.py
Added missing file
Added: grass/trunk/lib/python/temporal/temporal_relationships.py
--- grass/trunk/lib/python/temporal/temporal_relationships.py	                        (rev 0)
+++ grass/trunk/lib/python/temporal/temporal_relationships.py	2012-03-22 19:30:10 UTC (rev 51147)
@@ -0,0 +1,153 @@
+"""!@package grass.temporal
+ at brief GRASS Python scripting module (temporal GIS functions)
+Temporal GIS related functions to be used in temporal GIS Python library package.
+Usage:
+ at code
+import grass.temporal as tgis
+tgis.print_temporal_relations(maps)
+ at endcode
+(C) 2008-2011 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Soeren Gebbert
+from abstract_dataset import *
+from datetime_math import *
+def print_temporal_relations(maps1, maps2):
+    """Print the temporal relation matrix of the temporal ordered map lists maps1 and maps2
+       to stdout.
+	@param maps1: a ordered by start_time list of map objects
+	@param maps2: a ordered by start_time list of map objects
+	@param dbif: The database interface to be used
+    identical = False
+    use_id = True
+    if maps1 == maps2:
+	identical = True
+	use_id = False
+    for i in range(len(maps1)):
+	if identical == True:
+	    start = i + 1
+	else:
+	    start = 0
+	for j in range(start, len(maps2)):
+	    relation = maps1[j].temporal_relation(maps2[i])
+	    if use_id == False:
+		print maps2[j].base.get_name(), relation, maps1[i].base.get_name()
+	    else:
+		print maps2[j].base.get_id(), relation, maps1[i].base.get_id()
+	    # Break if the last map follows
+	    if relation == "follows":
+		if j < len(maps1) - 1:
+		    relation = maps1[j + 1].temporal_relation(maps2[i])
+		    if relation == "after":
+			break
+	    # Break if the the next map is after
+		break
+def get_temporal_relation_matrix(maps1, maps2):
+    """Return the temporal relation matrix of all registered maps as list of lists
+	The map list must be ordered by start time
+	The temporal relation matrix includes the temporal relations between
+	all registered maps. Returned is a nested dict representing
+	a sparse (upper right side in case maps1 == maps2) relationship matrix.
+	@param maps: a ordered by start_time list of map objects
+    matrix = {}
+    identical = False
+	identical = True
+	    start = i + 1
+	else:
+	    start = 0
+	row = {}
+	    row[maps2[j].base.get_id()] = relation
+			break
+		break
+	matrix[maps1[i].base.get_id()] = row
+    return matrix
+def count_temporal_relations(maps1, maps2):
+    """Count the temporal relations between the registered maps.
+	The map lists must be ordered by start time. Temporal relations are counted
+	by analyzing the sparse (upper right side in case maps1 == maps2) temporal relationships matrix.
+	@param maps: A sorted (start_time) list of abstract_dataset objects
+	@return A dictionary with counted temporal relationships
+    tcount = {}
+    identical = False
+	identical = True
+	    start = i + 1
+	else:
+	    start = 0
+	    if tcount.has_key(relation):
+		tcount[relation] = tcount[relation] + 1
+	    else:
+		tcount[relation] = 1
+			break
+		break
+    return tcount
