[GRASS-SVN] r51210 - grass/trunk/locale/po
Fri Mar 30 18:54:00 EDT 2012
Author: neteler
Date: 2012-03-30 15:53:59 -0700 (Fri, 30 Mar 2012)
New Revision: 51210
   grass/trunk/locale/po/grassmods_ar.po
   grass/trunk/locale/po/grassmods_cs.po
   grass/trunk/locale/po/grassmods_de.po
   grass/trunk/locale/po/grassmods_el.po
   grass/trunk/locale/po/grassmods_es.po
   grass/trunk/locale/po/grassmods_fr.po
   grass/trunk/locale/po/grassmods_hi.po
   grass/trunk/locale/po/grassmods_it.po
   grass/trunk/locale/po/grassmods_ja.po
   grass/trunk/locale/po/grassmods_ko.po
   grass/trunk/locale/po/grassmods_lv.po
   grass/trunk/locale/po/grassmods_mr.po
   grass/trunk/locale/po/grassmods_pl.po
   grass/trunk/locale/po/grassmods_pt.po
   grass/trunk/locale/po/grassmods_pt_br.po
   grass/trunk/locale/po/grassmods_ru.po
   grass/trunk/locale/po/grassmods_sl.po
   grass/trunk/locale/po/grassmods_th.po
   grass/trunk/locale/po/grassmods_tr.po
   grass/trunk/locale/po/grassmods_vi.po
   grass/trunk/locale/po/grassmods_zh.po
fix typo
Modified: grass/trunk/locale/po/grassmods_ar.po
--- grass/trunk/locale/po/grassmods_ar.po	2012-03-30 22:48:59 UTC (rev 51209)
+++ grass/trunk/locale/po/grassmods_ar.po	2012-03-30 22:53:59 UTC (rev 51210)
@@ -30701,7 +30701,7 @@
 #: ../vector/v.rectify/main.c:81
 #, fuzzy
-msgid "Name to input file with control points"
+msgid "Name of input file with control points"
 msgstr "اسم الطبقة المستخدمة كدرجة لون"
 #: ../vector/v.rectify/main.c:93
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po	2012-03-30 22:48:59 UTC (rev 51209)
+++ grass/trunk/locale/po/grassmods_cs.po	2012-03-30 22:53:59 UTC (rev 51210)
@@ -30245,7 +30245,7 @@
 #, fuzzy
 msgstr "Název vstupní bodové vektorové vrstvy"
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po	2012-03-30 22:48:59 UTC (rev 51209)
+++ grass/trunk/locale/po/grassmods_de.po	2012-03-30 22:53:59 UTC (rev 51210)
@@ -29782,7 +29782,7 @@
 #, fuzzy
 msgstr "Name der Eingabe-Vektorkarte mit Punkten."
Modified: grass/trunk/locale/po/grassmods_el.po
--- grass/trunk/locale/po/grassmods_el.po	2012-03-30 22:48:59 UTC (rev 51209)
+++ grass/trunk/locale/po/grassmods_el.po	2012-03-30 22:53:59 UTC (rev 51210)
@@ -29201,7 +29201,7 @@
 #, fuzzy
 msgstr "¼íïìá åéóáãþìåíïõ äéáíõóìáôéêïý ÷Üñôç "
Modified: grass/trunk/locale/po/grassmods_es.po
--- grass/trunk/locale/po/grassmods_es.po	2012-03-30 22:48:59 UTC (rev 51209)
+++ grass/trunk/locale/po/grassmods_es.po	2012-03-30 22:53:59 UTC (rev 51210)
@@ -29920,7 +29920,7 @@
 #, fuzzy
 msgstr "Nombre del mapa vectorial de puntos de entrada"
Modified: grass/trunk/locale/po/grassmods_fr.po
--- grass/trunk/locale/po/grassmods_fr.po	2012-03-30 22:48:59 UTC (rev 51209)
+++ grass/trunk/locale/po/grassmods_fr.po	2012-03-30 22:53:59 UTC (rev 51210)
@@ -31910,7 +31910,7 @@
 #, fuzzy
 msgstr "Nom de la couche vecteur 2D source"
Modified: grass/trunk/locale/po/grassmods_hi.po
--- grass/trunk/locale/po/grassmods_hi.po	2012-03-30 22:48:59 UTC (rev 51209)
+++ grass/trunk/locale/po/grassmods_hi.po	2012-03-30 22:53:59 UTC (rev 51210)
@@ -31263,7 +31263,7 @@
 #, fuzzy
 msgstr "घुमाएँ"
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po	2012-03-30 22:48:59 UTC (rev 51209)
+++ grass/trunk/locale/po/grassmods_it.po	2012-03-30 22:53:59 UTC (rev 51210)
@@ -29493,7 +29493,7 @@
 #, fuzzy
 msgstr "Nome della mappa di input"
 # script di shell ?
Modified: grass/trunk/locale/po/grassmods_ja.po
--- grass/trunk/locale/po/grassmods_ja.po	2012-03-30 22:48:59 UTC (rev 51209)
+++ grass/trunk/locale/po/grassmods_ja.po	2012-03-30 22:53:59 UTC (rev 51210)
@@ -29697,7 +29697,7 @@
 #, fuzzy
 msgstr "作動しているコントロールポイントはありません"
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po	2012-03-30 22:48:59 UTC (rev 51209)
+++ grass/trunk/locale/po/grassmods_ko.po	2012-03-30 22:53:59 UTC (rev 51210)
@@ -29578,7 +29578,7 @@
 #, fuzzy
 msgstr "출력할 래스터맵"
Modified: grass/trunk/locale/po/grassmods_lv.po
--- grass/trunk/locale/po/grassmods_lv.po	2012-03-30 22:48:59 UTC (rev 51209)
+++ grass/trunk/locale/po/grassmods_lv.po	2012-03-30 22:53:59 UTC (rev 51210)
@@ -30529,7 +30529,7 @@
 #, fuzzy
 msgstr "rotēt/grozīt izdruku"
Modified: grass/trunk/locale/po/grassmods_mr.po
--- grass/trunk/locale/po/grassmods_mr.po	2012-03-30 22:48:59 UTC (rev 51209)
+++ grass/trunk/locale/po/grassmods_mr.po	2012-03-30 22:53:59 UTC (rev 51210)
@@ -29797,7 +29797,7 @@
 #, fuzzy
 msgstr "'%s'. ड्राइवर चालू होत नाही"
Modified: grass/trunk/locale/po/grassmods_pl.po
--- grass/trunk/locale/po/grassmods_pl.po	2012-03-30 22:48:59 UTC (rev 51209)
+++ grass/trunk/locale/po/grassmods_pl.po	2012-03-30 22:53:59 UTC (rev 51210)
@@ -30125,7 +30125,7 @@
 #, fuzzy
 msgstr "Brak aktywnych punktów kontrolnych"
Modified: grass/trunk/locale/po/grassmods_pt.po
--- grass/trunk/locale/po/grassmods_pt.po	2012-03-30 22:48:59 UTC (rev 51209)
+++ grass/trunk/locale/po/grassmods_pt.po	2012-03-30 22:53:59 UTC (rev 51210)
@@ -31324,7 +31324,7 @@
 #, fuzzy
 msgstr "Nome do mapa vetorial (2d) de entrada"
Modified: grass/trunk/locale/po/grassmods_pt_br.po
--- grass/trunk/locale/po/grassmods_pt_br.po	2012-03-30 22:48:59 UTC (rev 51209)
+++ grass/trunk/locale/po/grassmods_pt_br.po	2012-03-30 22:53:59 UTC (rev 51210)
@@ -31164,7 +31164,7 @@
 #, fuzzy
 msgstr "Não pontos"
Modified: grass/trunk/locale/po/grassmods_ru.po
--- grass/trunk/locale/po/grassmods_ru.po	2012-03-30 22:48:59 UTC (rev 51209)
+++ grass/trunk/locale/po/grassmods_ru.po	2012-03-30 22:53:59 UTC (rev 51210)
@@ -30090,7 +30090,7 @@
 #, fuzzy
 msgstr "Нет активных контрольных точек"
Modified: grass/trunk/locale/po/grassmods_sl.po
--- grass/trunk/locale/po/grassmods_sl.po	2012-03-30 22:48:59 UTC (rev 51209)
+++ grass/trunk/locale/po/grassmods_sl.po	2012-03-30 22:53:59 UTC (rev 51210)
@@ -30893,7 +30893,7 @@
 #, fuzzy
 msgstr "Ime vhodnega rastrskega sloja"
Modified: grass/trunk/locale/po/grassmods_th.po
--- grass/trunk/locale/po/grassmods_th.po	2012-03-30 22:48:59 UTC (rev 51209)
+++ grass/trunk/locale/po/grassmods_th.po	2012-03-30 22:53:59 UTC (rev 51210)
@@ -30458,7 +30458,7 @@
 #, fuzzy
 msgstr "ไม่มีจุดเริ่มต้น"
Modified: grass/trunk/locale/po/grassmods_tr.po
--- grass/trunk/locale/po/grassmods_tr.po	2012-03-30 22:48:59 UTC (rev 51209)
+++ grass/trunk/locale/po/grassmods_tr.po	2012-03-30 22:53:59 UTC (rev 51210)
@@ -29827,7 +29827,7 @@
 #, fuzzy
 msgstr "Aktif kontrol noktası yok"
Modified: grass/trunk/locale/po/grassmods_vi.po
--- grass/trunk/locale/po/grassmods_vi.po	2012-03-30 22:48:59 UTC (rev 51209)
+++ grass/trunk/locale/po/grassmods_vi.po	2012-03-30 22:53:59 UTC (rev 51210)
@@ -30059,7 +30059,7 @@
 #, fuzzy
 msgstr "Không có các điểm khống chế được kích hoạt"
Modified: grass/trunk/locale/po/grassmods_zh.po
--- grass/trunk/locale/po/grassmods_zh.po	2012-03-30 22:48:59 UTC (rev 51209)
+++ grass/trunk/locale/po/grassmods_zh.po	2012-03-30 22:53:59 UTC (rev 51210)
@@ -30885,7 +30885,7 @@
 #, fuzzy
 msgstr "没有起始点"
