[GRASS-SVN] r51226 - grass/trunk/lib/python/temporal
Sat Mar 31 13:21:44 EDT 2012
Author: huhabla
Date: 2012-03-31 10:21:44 -0700 (Sat, 31 Mar 2012)
New Revision: 51226
   grass/trunk/lib/python/temporal/abstract_map_dataset.py
   grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
SQL statement gathering for efficient and fast DELETE and DROP table
execution for massive datasets.
Modified: grass/trunk/lib/python/temporal/abstract_map_dataset.py
--- grass/trunk/lib/python/temporal/abstract_map_dataset.py	2012-03-31 11:07:46 UTC (rev 51225)
+++ grass/trunk/lib/python/temporal/abstract_map_dataset.py	2012-03-31 17:21:44 UTC (rev 51226)
@@ -350,7 +350,7 @@
         return True
-    def delete(self, dbif=None, update=True):
+    def delete(self, dbif=None, update=True, execute = True):
 	"""!Delete a map entry from database if it exists
             Remove dependent entries:
@@ -363,6 +363,7 @@
         connect = False
+        statement = ""
         if dbif == None:
             dbif = sql_database_interface()
@@ -372,24 +373,19 @@
         if self.is_in_db(dbif):
             # SELECT all needed information from the database
-            self.select(dbif)
+            self.metadata.select(dbif)
             # First we unregister from all dependent space time datasets
-            self.unregister(dbif, update)
+            statement += self.unregister(dbif, update, False)
             # Remove the strds register table
             if self.get_stds_register():
-                sql = "DROP TABLE " + self.get_stds_register()
-                #print sql
-                try:
-                    dbif.cursor.execute(sql)
-                except:
-                    core.error(_("Unable to remove space time dataset register table <%s>") % (self.get_stds_register()))
+                statement += "DROP TABLE " + self.get_stds_register() + ";\n"
             core.verbose(_("Delete %s dataset <%s> from temporal database") % (self.get_type(), self.get_id()))
             # Delete yourself from the database, trigger functions will take care of dependencies
-            self.base.delete(dbif)
+            statement += self.base.get_delete_statement() + ";\n"
         # Remove the timestamp from the file system
         if self.get_type() == "vect":
@@ -400,13 +396,37 @@
 	else:
 	    core.run_command(self.get_timestamp_module_name(), map=self.get_map_id(), date="none")
+        if execute == True:
+            sql_script = ""
+            sql_script += "BEGIN TRANSACTION;\n"
+            sql_script += statement
+            sql_script += "END TRANSACTION;"
+            print sql_script
+            try:
+		if dbmi.__name__ == "sqlite3":
+		    dbif.cursor.executescript(statement)
+		else:
+		    dbif.cursor.execute(statement)
+            except:
+                if connect == True:
+                    dbif.close()
+                core.error(_("Unable to correctly delete %s map <%s>") % (self.get_type(), self.get_id()))
+                raise
+            dbif.connection.commit()
         self.reset(None)
-        dbif.connection.commit()
         if connect == True:
             dbif.close()
+        if execute:
+            return ""
-    def unregister(self, dbif=None, update=True):
+        return statement
+    def unregister(self, dbif=None, update=True, execute=True):
 	"""! Remove the map entry in each space time dataset in which this map is registered
            @param dbif: The database interface to be used
@@ -420,6 +440,7 @@
 	else:
 	    core.verbose(_("Unregister %s map <%s> from space time datasets") % (self.get_type(), self.get_map_id()))
+        statement = ""
         connect = False
         if dbif == None:
@@ -440,18 +461,40 @@
                 # Create a space time dataset object to remove the map
                 # from its register
                 stds = self.get_new_stds_instance(row["id"])
-                stds.select(dbif)
-                stds.unregister_map(self, dbif)
+                stds.metadata.select(dbif)
+                statement += stds.unregister_map(self, dbif, False)
                 # Take care to update the space time dataset after
                 # the map has been unregistered
-                if update == True:
+                if update == True and execute == True:
                     stds.update_from_registered_maps(dbif)
             core.percent(1, 1, 1)
+            sql_script = ""
+            print sql_script
+            try:
+		else:
+            except:
+                    dbif.close()
+                core.error(_("Unable to correctly unregister %s <%s>") % (self.get_type(), self.get_id()))
+                raise
         if connect == True:
             dbif.close()
+        if execute:
+            return ""
+        return statement
     def get_registered_datasets(self, dbif=None):
         """!Return all space time dataset ids in which this map is registered as
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2012-03-31 11:07:46 UTC (rev 51225)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2012-03-31 17:21:44 UTC (rev 51226)
@@ -758,18 +758,22 @@
         return rows
-    def delete(self, dbif=None):
+    def delete(self, dbif=None, execute=True):
         """!Delete a space time dataset from the temporal database
            This method removes the space time dataset from the temporal database and drops its map register table
+           @param execute: If ture the DELETE statements are executed
+           @return The DELETE SQL statements
         # First we need to check if maps are registered in this dataset and
         # unregister them
         core.verbose(_("Delete space time %s  dataset <%s> from temporal database") % (self.get_new_map_instance(ident=None).get_type(), self.get_id()))
+        statement = ""
         connect = False
         if dbif == None:
@@ -778,7 +782,7 @@
             connect = True
-        self.select(dbif)
         core.verbose(_("Drop map register table: %s") %  (self.get_map_register()))
         if self.get_map_register():
@@ -791,26 +795,40 @@
 	            core.percent(count, num_maps, 1)
                     # Unregister map
                     map = self.get_new_map_instance(row["id"])
-                    self.unregister_map(map, dbif)
+                    statement += self.unregister_map(map, dbif, False)
                     count += 1
+                # Safe the DROP table statement
+                statement += "DROP TABLE " + self.get_map_register() + ";\n"
+        # Remove the primary key, the foreign keys will be removed by trigger
+            sql_script = ""
+            print sql_script
             try:
-                # Drop the map register table
-                sql = "DROP TABLE " + self.get_map_register()
+		else:
             except:
                 if connect == True:
                     dbif.close()
-                core.error(_("Unable to drop table <%s>") % (self.get_map_register()))
+                core.error(_("Unable to correctly delete %s <%s>") % (self.get_type(), self.get_id()))
                 raise
-        # Remove the primary key, the foreign keys will be removed by trigger
         self.reset(None)
         if connect == True:
             dbif.close()
+        if execute:
+            return ""
+        return statement
     def register_map(self, map, dbif=None):
         """!Register a map in the space time dataset.
@@ -1031,7 +1049,7 @@
         return True
-    def unregister_map(self, map, dbif = None):
+    def unregister_map(self, map, dbif = None, execute=True):
         """!Unregister a map from the space time dataset.
            This method takes care of the un-registration of a map
@@ -1039,7 +1057,13 @@
            @param map: The map object to unregister
+        statement = ""
         connect = False
         if dbif == None:
@@ -1047,25 +1071,18 @@
             dbif.connect()
             connect = True
-        if map.is_in_db(dbif) == False:
-            dbif.close()
-	    if map.get_layer():
-		core.fatal(_("Unable to find map <%s> with layer %s in temporal database") % (map.get_map_id(), map.get_layer()))
-	    else:
-		core.fatal(_("Unable to find map <%s> in temporal database") % (map.get_map_id()))
+        # First select needed data from the database
+        map.metadata.select(dbif)
+        map_id = map.get_id()
+        map_register_table = map.get_stds_register()
+        stds_register_table = self.get_map_register()
 	if map.get_layer():
 	    core.verbose(_("Unregister %s map <%s> with layer %s") % (map.get_type(), map.get_map_id(), map.get_layer()))
 	else:
 	    core.verbose(_("Unregister %s map <%s>") % (map.get_type(), map.get_map_id()))
-        # First select all data from the database
-        map.select(dbif)
-        map_id = map.get_id()
-        map_register_table = map.get_stds_register()
-        stds_register_table = self.get_map_register()
         # Check if the map is registered in the space time raster dataset
 	if dbmi.paramstyle == "qmark":
 	    sql = "SELECT id FROM " + map_register_table + " WHERE id = ?"
@@ -1082,29 +1099,44 @@
 		core.warning(_("Map <%s> is not registered in space time dataset <%s>") %(map.get_map_id(), self.base.get_id()))
             if connect == True:
                 dbif.close()
-            return False
+            return None
         # Remove the space time raster dataset from the raster dataset register
         if map_register_table != None:
-	    if dbmi.paramstyle == "qmark":
-		sql = "DELETE FROM " + map_register_table + " WHERE id = ?"
-	    else:
-		sql = "DELETE FROM " + map_register_table + " WHERE id = %s"
-            dbif.cursor.execute(sql, (self.base.get_id(),))
+            statement += "DELETE FROM " + map_register_table + " WHERE id = \'%s\';\n"%(self.base.get_id())
+                if dbmi.paramstyle == "qmark":
+		    sql = "DELETE FROM " + map_register_table + " WHERE id = ?"
+	        else:
+		    sql = "DELETE FROM " + map_register_table + " WHERE id = %s"
+                dbif.cursor.execute(sql, (self.base.get_id(),))
         # Remove the raster map from the space time raster dataset register
         if stds_register_table != None:
-		sql = "DELETE FROM " + stds_register_table + " WHERE id = ?"
-	    else:
-		sql = "DELETE FROM " + stds_register_table + " WHERE id = %s"
-            dbif.cursor.execute(sql, (map_id,))
+            statement += "DELETE FROM " + stds_register_table + " WHERE id = \'%s\';\n"%(map_id)
+		    sql = "DELETE FROM " + stds_register_table + " WHERE id = ?"
+	        else:
+		    sql = "DELETE FROM " + stds_register_table + " WHERE id = %s"
+                dbif.cursor.execute(sql, (map_id,))
         if connect == True:
             dbif.close()
         # decrease the counter
         self.map_counter -= 1
+        if execute:
+            return ""
+        return statement
     def update_from_registered_maps(self, dbif = None):
         """!This methods updates the spatial and temporal extent as well as
