[GRASS-SVN] r51228 - in grass/trunk/temporal: t.remove t.unregister
Sat Mar 31 16:44:23 EDT 2012
Author: huhabla
Date: 2012-03-31 13:44:22 -0700 (Sat, 31 Mar 2012)
New Revision: 51228
   grass/trunk/temporal/t.remove/t.remove.py
   grass/trunk/temporal/t.unregister/t.unregister.py
Use more efficient removal and unregistration methods.
Modified: grass/trunk/temporal/t.remove/t.remove.py
--- grass/trunk/temporal/t.remove/t.remove.py	2012-03-31 20:41:35 UTC (rev 51227)
+++ grass/trunk/temporal/t.remove/t.remove.py	2012-03-31 20:44:22 UTC (rev 51228)
@@ -53,11 +53,11 @@
 def main():
     # Get the options
-    maps = options["input"]
+    datasets = options["input"]
     file = options["file"]
     type = options["type"]
-    if maps and file:
+    if datasets and file:
         core.fata(_("%s= and %s= are mutually exclusive") % ("input","file"))
     # Make sure the temporal database exists
@@ -66,16 +66,16 @@
     dbif = tgis.sql_database_interface()
     dbif.connect()
-    maplist = []
+    dataset_list = []
-    # Map names as comma separated string
-    if maps:
-        if maps.find(",") == -1:
-            maplist = (maps,)
+    # Dataset names as comma separated string
+    if datasets:
+        if datasets.find(",") == -1:
+            dataset_list = (datasets,)
         else:
-            maplist = tuple(maps.split(","))
+            dataset_list = tuple(datasets.split(","))
-    # Read the map list from file
+    # Read the dataset list from file
     if file:
         fd = open(file, "r")
@@ -86,12 +86,14 @@
                 break
             line_list = line.split("\n")
-            mapname = line_list[0]
-            maplist.append(mapname)
+            dataset_name = line_list[0]
+            dataset_list.append(dataset_name)
     mapset =  grass.gisenv()["MAPSET"]
+    statement = ""
-    for name in maplist:
+    for name in dataset_list:
         name = name.strip()
         # Check for the mapset in name
         if name.find("@") < 0:
@@ -105,8 +107,20 @@
             dbif.close()
             grass.fatal(_("%s dataset <%s> not found in temporal database") % (sp.get_type(), name))
-        sp.delete(dbif)
+        statement += sp.delete(dbif=dbif, execute=False)
+    # Execute the collected SQL statenents
+    sql_script = ""
+    sql_script += "BEGIN TRANSACTION;\n"
+    sql_script += statement
+    sql_script += "END TRANSACTION;"
+    # print sql_script
+    if tgis.dbmi.__name__ == "sqlite3":
+            dbif.cursor.executescript(statement)
+    else:
+            dbif.cursor.execute(statement)
     dbif.close()
 if __name__ == "__main__":
Modified: grass/trunk/temporal/t.unregister/t.unregister.py
--- grass/trunk/temporal/t.unregister/t.unregister.py	2012-03-31 20:41:35 UTC (rev 51227)
+++ grass/trunk/temporal/t.unregister/t.unregister.py	2012-03-31 20:44:22 UTC (rev 51228)
@@ -137,31 +137,49 @@
     num_maps = len(maplist)
     update_dict = {}
     count = 0
+    statement = ""
+    # Unregister already registered maps
     for mapid in maplist:
 	grass.percent(count, num_maps, 1)
-        print mapid
         map = tgis.dataset_factory(type, mapid)
         # Unregister map if in database
         if map.is_in_db(dbif) == True:
             # Unregister from a single dataset
             if name:
-                sp.select(dbif)
-                sp.unregister_map(map, dbif)
+                sp.metadata.select(dbif)
+                # Collect SQL statements
+                statement += sp.unregister_map(map=map, dbif=dbif, execute=False)
             # Unregister from temporal database
             else:
                 # We need to update all datasets after the removement of maps
-                map.select(dbif)
+                map.metadata.select(dbif)
                 datasets = map.get_registered_datasets(dbif)
                 # Store all unique dataset ids in a dictionary
                 if datasets:
                     for dataset in datasets:
                         update_dict[dataset["id"]] = dataset["id"]
-                map.delete(dbif, update=False)
+                statement += map.delete(dbif=dbif, update=False, execute=False)
 	count += 1
+    sql_script = ""
+    else:
     # Update space time datasets
     if name:
         sp.update_from_registered_maps(dbif)
@@ -177,7 +195,7 @@
             else:
                 break
-            sp.select(dbif)
     if connect == True:
