[GRASS-SVN] r51756 - in grass/trunk: locale/po raster/r.lake
Fri May 25 10:51:51 EDT 2012
Author: neteler
Date: 2012-05-25 07:51:51 -0700 (Fri, 25 May 2012)
New Revision: 51756
   grass/trunk/locale/po/grassmods_ar.po
   grass/trunk/locale/po/grassmods_cs.po
   grass/trunk/locale/po/grassmods_de.po
   grass/trunk/locale/po/grassmods_el.po
   grass/trunk/locale/po/grassmods_es.po
   grass/trunk/locale/po/grassmods_fr.po
   grass/trunk/locale/po/grassmods_hi.po
   grass/trunk/locale/po/grassmods_it.po
   grass/trunk/locale/po/grassmods_ja.po
   grass/trunk/locale/po/grassmods_ko.po
   grass/trunk/locale/po/grassmods_lv.po
   grass/trunk/locale/po/grassmods_mr.po
   grass/trunk/locale/po/grassmods_pl.po
   grass/trunk/locale/po/grassmods_pt.po
   grass/trunk/locale/po/grassmods_pt_br.po
   grass/trunk/locale/po/grassmods_ru.po
   grass/trunk/locale/po/grassmods_sl.po
   grass/trunk/locale/po/grassmods_th.po
   grass/trunk/locale/po/grassmods_tr.po
   grass/trunk/locale/po/grassmods_vi.po
   grass/trunk/locale/po/grassmods_zh.po
   grass/trunk/raster/r.lake/main.c
improve module description
Modified: grass/trunk/locale/po/grassmods_ar.po
--- grass/trunk/locale/po/grassmods_ar.po	2012-05-25 14:48:33 UTC (rev 51755)
+++ grass/trunk/locale/po/grassmods_ar.po	2012-05-25 14:51:51 UTC (rev 51756)
@@ -13392,7 +13392,7 @@
 msgstr ""
 #: ../raster/r.lake/main.c:152
-msgid "Fills lake from seed at given level."
+msgid "Fills lake at given point to given level."
 msgstr ""
 #: ../raster/r.lake/main.c:158
@@ -13406,7 +13406,7 @@
 #: ../raster/r.lake/main.c:177
 #, fuzzy
-msgid "Name of raster map with seed (at least 1 cell > 0)"
+msgid "Name of input raster map with given starting point(s) (at least 1 cell > 0)"
 msgstr "<%s> اسم الملف المستخدم لل"
 #: ../raster/r.lake/main.c:183
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po	2012-05-25 14:48:33 UTC (rev 51755)
+++ grass/trunk/locale/po/grassmods_cs.po	2012-05-25 14:51:51 UTC (rev 51756)
@@ -13228,7 +13228,7 @@
 msgstr ""
 msgstr "Vytvoøí jezero ze zadaného bodu dané hloubky"
@@ -13240,7 +13240,7 @@
 msgstr "Poèáteèní mapové souøadnice"
 msgstr "Rastrová mapa s poèátkem (alespoò jedna buòka > 0)"
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po	2012-05-25 14:48:33 UTC (rev 51755)
+++ grass/trunk/locale/po/grassmods_de.po	2012-05-25 14:51:51 UTC (rev 51756)
@@ -13014,7 +13014,7 @@
 msgstr "GDAL-Datentyp: %s, gültiger Wertebereich: %g - %g"
 msgstr "Fülle den See vom Startpunkt am definierten Level."
@@ -13026,7 +13026,7 @@
 msgstr "Koordinaten der Startpunkte"
 msgstr "Name der Rasterkarte mit Startpunkten (mindestens eine Zelle > 0)."
@@ -34005,7 +34005,7 @@
 msgstr "Raster, Höhenwerte"
 #, fuzzy
-msgid "Name of input raster map with seed (at least 1 cell > 0)"
 #, fuzzy
Modified: grass/trunk/locale/po/grassmods_el.po
--- grass/trunk/locale/po/grassmods_el.po	2012-05-25 14:48:33 UTC (rev 51755)
+++ grass/trunk/locale/po/grassmods_el.po	2012-05-25 14:51:51 UTC (rev 51756)
@@ -12825,7 +12825,7 @@
 msgstr ""
 msgstr ""
@@ -12837,7 +12837,7 @@
 msgstr ""
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_es.po
--- grass/trunk/locale/po/grassmods_es.po	2012-05-25 14:48:33 UTC (rev 51755)
+++ grass/trunk/locale/po/grassmods_es.po	2012-05-25 14:51:51 UTC (rev 51756)
@@ -13078,7 +13078,7 @@
 msgstr "Tipo de datos GDAL: %s, rango válido: %g - %g"
 msgstr ""
@@ -13090,7 +13090,7 @@
 msgstr "Coordenadas de puntos seed"
 msgstr "Nombre del mapa ráster con seed (como mínimo 1 celda>0)"
Modified: grass/trunk/locale/po/grassmods_fr.po
--- grass/trunk/locale/po/grassmods_fr.po	2012-05-25 14:48:33 UTC (rev 51755)
+++ grass/trunk/locale/po/grassmods_fr.po	2012-05-25 14:51:51 UTC (rev 51756)
@@ -13865,7 +13865,7 @@
 #, fuzzy
 msgstr "Remplit le lac à partir du germe jusqu'à un niveau donné"
@@ -13878,7 +13878,7 @@
 #, fuzzy
 msgstr "Couche raster avec le germe (au moins 1 cellule > 0)"
@@ -37012,7 +37012,7 @@
 msgstr "Tracer le relief"
 #, fuzzy
 #, fuzzy
Modified: grass/trunk/locale/po/grassmods_hi.po
--- grass/trunk/locale/po/grassmods_hi.po	2012-05-25 14:48:33 UTC (rev 51755)
+++ grass/trunk/locale/po/grassmods_hi.po	2012-05-25 14:51:51 UTC (rev 51756)
@@ -13698,7 +13698,7 @@
 msgstr ""
 msgstr ""
@@ -13712,7 +13712,7 @@
 #, fuzzy
 msgstr "का"
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po	2012-05-25 14:48:33 UTC (rev 51755)
+++ grass/trunk/locale/po/grassmods_it.po	2012-05-25 14:51:51 UTC (rev 51756)
@@ -12903,7 +12903,7 @@
 msgstr "Tipo di dati GDAL: %s, intervallo valido: %g - %g"
 msgstr "Riempie un lago a parire da un punto seed ad un dato livello"
@@ -12915,7 +12915,7 @@
 msgstr "Coordinate del punto seed"
 msgstr "Nome della mappa raster con seed (almeno 1 cella > 0)"
@@ -33610,7 +33610,7 @@
 msgstr "Mappa(e) raster da leggere"
 #, fuzzy
 msgstr "Nome della mappa raster da utilizzare per <%s>"
 #, fuzzy
Modified: grass/trunk/locale/po/grassmods_ja.po
--- grass/trunk/locale/po/grassmods_ja.po	2012-05-25 14:48:33 UTC (rev 51755)
+++ grass/trunk/locale/po/grassmods_ja.po	2012-05-25 14:51:51 UTC (rev 51756)
@@ -12973,7 +12973,7 @@
 msgstr "GDALデータタイプ: %s, 有効な領域: %g - %g"
 msgstr "指定レベルの面識別点から湖水までを満たす "
@@ -12985,7 +12985,7 @@
 msgstr "シードポイント座標"
 msgstr "シード付きラスターマップ名 (少なくとも 1セル>0)"
@@ -33913,7 +33913,7 @@
 msgstr "ラスター、標高"
 #, fuzzy
 #, fuzzy
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po	2012-05-25 14:48:33 UTC (rev 51755)
+++ grass/trunk/locale/po/grassmods_ko.po	2012-05-25 14:51:51 UTC (rev 51756)
@@ -12953,7 +12953,7 @@
 msgstr ""
 msgstr ""
@@ -12966,7 +12966,7 @@
 #, fuzzy
 msgstr "출력할 래스터맵"
Modified: grass/trunk/locale/po/grassmods_lv.po
--- grass/trunk/locale/po/grassmods_lv.po	2012-05-25 14:48:33 UTC (rev 51755)
+++ grass/trunk/locale/po/grassmods_lv.po	2012-05-25 14:51:51 UTC (rev 51756)
@@ -13266,7 +13266,7 @@
 #, fuzzy
 msgstr "Piepilda ezeru no viena punkta līdz norādītajam līmenim"
@@ -13279,7 +13279,7 @@
 #, fuzzy
 msgstr "Rastra karte ar sākuma punktu (vismaz 1 šūnu > 0)"
Modified: grass/trunk/locale/po/grassmods_mr.po
--- grass/trunk/locale/po/grassmods_mr.po	2012-05-25 14:48:33 UTC (rev 51755)
+++ grass/trunk/locale/po/grassmods_mr.po	2012-05-25 14:51:51 UTC (rev 51756)
@@ -13036,7 +13036,7 @@
 msgstr ""
 msgstr ""
@@ -13049,7 +13049,7 @@
 #, fuzzy
 msgstr "'%s'. ड्राइवर चालू होत नाही"
Modified: grass/trunk/locale/po/grassmods_pl.po
--- grass/trunk/locale/po/grassmods_pl.po	2012-05-25 14:48:33 UTC (rev 51755)
+++ grass/trunk/locale/po/grassmods_pl.po	2012-05-25 14:51:51 UTC (rev 51756)
@@ -13058,7 +13058,7 @@
 msgstr ""
 msgstr "Wypełnia jeziora z wartości próbki na zadanym poziomie."
@@ -13070,7 +13070,7 @@
 msgstr "Podaj współrzędne punktu"
 msgstr "Nazwa mapy rastrowej która ma być użyta jako maska (co najmniej 1 komórka >0)"
Modified: grass/trunk/locale/po/grassmods_pt.po
--- grass/trunk/locale/po/grassmods_pt.po	2012-05-25 14:48:33 UTC (rev 51755)
+++ grass/trunk/locale/po/grassmods_pt.po	2012-05-25 14:51:51 UTC (rev 51756)
@@ -13681,7 +13681,7 @@
 #, fuzzy
 msgstr "nível"
@@ -13696,7 +13696,7 @@
 #, fuzzy
 msgstr "Varredura mapear célula"
Modified: grass/trunk/locale/po/grassmods_pt_br.po
--- grass/trunk/locale/po/grassmods_pt_br.po	2012-05-25 14:48:33 UTC (rev 51755)
+++ grass/trunk/locale/po/grassmods_pt_br.po	2012-05-25 14:51:51 UTC (rev 51756)
@@ -13524,7 +13524,7 @@
 msgstr ""
 msgstr "Preenche lago a partir da origem num dado nível."
@@ -13537,7 +13537,7 @@
 msgstr "Coordenadas do ponto de origem"
 msgstr "Nome do mapa raster com origem (pelo menos uma célula > 0)"
Modified: grass/trunk/locale/po/grassmods_ru.po
--- grass/trunk/locale/po/grassmods_ru.po	2012-05-25 14:48:33 UTC (rev 51755)
+++ grass/trunk/locale/po/grassmods_ru.po	2012-05-25 14:51:51 UTC (rev 51756)
@@ -13181,7 +13181,7 @@
 msgstr "Растровый слой <%s> создан."
 msgstr "Заполнение озера из затравки до заданного уровня"
@@ -13193,7 +13193,7 @@
 msgstr "Координаты затравки"
 msgstr "Имя растрового слоя с затравкой (по крайней мере одна ячейка > 0)"
Modified: grass/trunk/locale/po/grassmods_sl.po
--- grass/trunk/locale/po/grassmods_sl.po	2012-05-25 14:48:33 UTC (rev 51755)
+++ grass/trunk/locale/po/grassmods_sl.po	2012-05-25 14:51:51 UTC (rev 51756)
@@ -13534,7 +13534,7 @@
 msgstr ""
 msgstr ""
@@ -13549,7 +13549,7 @@
 #, fuzzy
 msgstr "Ime rastrskega sloja, ki bo uporabljen za <%s>"
Modified: grass/trunk/locale/po/grassmods_th.po
--- grass/trunk/locale/po/grassmods_th.po	2012-05-25 14:48:33 UTC (rev 51755)
+++ grass/trunk/locale/po/grassmods_th.po	2012-05-25 14:51:51 UTC (rev 51756)
@@ -13318,7 +13318,7 @@
 #, fuzzy
 msgstr "เติม lake จาก seed ที่ระดับ ที่ต้องการ"
@@ -13331,7 +13331,7 @@
 #, fuzzy
 msgstr "แผนที่เชิงภาพ ที่มี  seed (อย่างน้อย 1 cell > 0)"
Modified: grass/trunk/locale/po/grassmods_tr.po
--- grass/trunk/locale/po/grassmods_tr.po	2012-05-25 14:48:33 UTC (rev 51755)
+++ grass/trunk/locale/po/grassmods_tr.po	2012-05-25 14:51:51 UTC (rev 51756)
@@ -12987,7 +12987,7 @@
 msgstr ""
 msgstr ""
@@ -12999,7 +12999,7 @@
 msgstr "Kaynak noktası koordinatları"
 msgstr "Kaynağı içeren raster haritanın adı (en az 1 hücre >0)"
Modified: grass/trunk/locale/po/grassmods_vi.po
--- grass/trunk/locale/po/grassmods_vi.po	2012-05-25 14:48:33 UTC (rev 51755)
+++ grass/trunk/locale/po/grassmods_vi.po	2012-05-25 14:51:51 UTC (rev 51756)
@@ -13169,7 +13169,7 @@
 msgstr "Kiểu dữ liệu GDAL: %s, miền hợp lệ: %g - %g"
 msgstr "Lấp đầy hồ từ 'hạt gieo' tại mức cho trước."
 msgstr "Tọa độ điểm 'gieo'"
 msgstr "Bản đồ raster với 'hạt gieo' (ít nhất là 1 ô > 0)"
Modified: grass/trunk/locale/po/grassmods_zh.po
--- grass/trunk/locale/po/grassmods_zh.po	2012-05-25 14:48:33 UTC (rev 51755)
+++ grass/trunk/locale/po/grassmods_zh.po	2012-05-25 14:51:51 UTC (rev 51756)
@@ -13471,7 +13471,7 @@
 msgstr ""
 msgstr ""
@@ -13486,7 +13486,7 @@
 #, fuzzy
 msgstr "栅格地图的名称 <%s>"
Modified: grass/trunk/raster/r.lake/main.c
--- grass/trunk/raster/r.lake/main.c	2012-05-25 14:48:33 UTC (rev 51755)
+++ grass/trunk/raster/r.lake/main.c	2012-05-25 14:51:51 UTC (rev 51756)
@@ -149,7 +149,7 @@
     module = G_define_module();
     G_add_keyword(_("raster"));
     G_add_keyword(_("hydrology"));
-    module->description = _("Fills lake from seed at given level.");
+    module->description = _("Fills lake at given point to given level.");
     tmap_opt = G_define_standard_option(G_OPT_R_ELEV);
@@ -174,7 +174,7 @@
     smap_opt = G_define_standard_option(G_OPT_R_MAP);
     smap_opt->key = "seed";
     smap_opt->description =
-	_("Name of raster map with seed (at least 1 cell > 0)");
+	_("Name of input raster map with given starting point(s) (at least 1 cell > 0)");
     smap_opt->required = NO;
     negative_flag = G_define_flag();
