[GRASS-SVN] r51768 - in grass/branches/releasebranch_6_4/gui/wxpython: core nviz
Sat May 26 06:45:35 EDT 2012
Author: annakrat
Date: 2012-05-26 03:45:34 -0700 (Sat, 26 May 2012)
New Revision: 51768
   grass/branches/releasebranch_6_4/gui/wxpython/core/settings.py
   grass/branches/releasebranch_6_4/gui/wxpython/core/workspace.py
   grass/branches/releasebranch_6_4/gui/wxpython/nviz/mapwindow.py
wxNviz: revert changes in zexag and improve its behaviour for latlon projections (merged from trunk, r51695, r51702)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/core/settings.py
--- grass/branches/releasebranch_6_4/gui/wxpython/core/settings.py	2012-05-26 10:39:51 UTC (rev 51767)
+++ grass/branches/releasebranch_6_4/gui/wxpython/core/settings.py	2012-05-26 10:45:34 UTC (rev 51768)
@@ -708,7 +708,7 @@
         self.internalSettings['nviz']['view']['height'] = {}
         self.internalSettings['nviz']['view']['height']['value'] = -1
         self.internalSettings['nviz']['view']['z-exag'] = {}
-        self.internalSettings['nviz']['view']['z-exag']['original'] = 1
+        self.internalSettings['nviz']['view']['z-exag']['llRatio'] = 1
         self.internalSettings['nviz']['view']['rotation'] = None
         self.internalSettings['nviz']['view']['focus'] = {}
         self.internalSettings['nviz']['view']['focus']['x'] = -1
Modified: grass/branches/releasebranch_6_4/gui/wxpython/core/workspace.py
--- grass/branches/releasebranch_6_4/gui/wxpython/core/workspace.py	2012-05-26 10:39:51 UTC (rev 51767)
+++ grass/branches/releasebranch_6_4/gui/wxpython/core/workspace.py	2012-05-26 10:45:34 UTC (rev 51768)
@@ -469,7 +469,7 @@
         view['z-exag']['value'] = self.__processLayerNvizNode(node_zexag, 'value', float)
         view['z-exag']['min'] = self.__processLayerNvizNode(node_zexag, 'min', int)
         view['z-exag']['max'] = self.__processLayerNvizNode(node_zexag, 'max', int)
-        iview['z-exag']['original'] = self.__processLayerNvizNode(node_zexag, 'original', float)
+        iview['z-exag']['llRatio'] = self.__processLayerNvizNode(node_zexag, 'llRatio', float)
         node_focus = node_view.find('focus')
         iview['focus'] = {}
         iview['focus']['x'] = self.__processLayerNvizNode(node_focus, 'x', int)
@@ -892,7 +892,7 @@
         self.file.write('%s<value>%.2f</value>\n' % (' ' * self.indent, view['z-exag']['value']))
         self.file.write('%s<min>%d</min>\n' % (' ' * self.indent, view['z-exag']['min']))
         self.file.write('%s<max>%d</max>\n' % (' ' * self.indent, view['z-exag']['max']))
-        self.file.write('%s<original>%.2f</original>\n' % (' ' * self.indent, iview['z-exag']['original']))
+        self.file.write('%s<llRatio>%.2f</llRatio>\n' % (' ' * self.indent, iview['z-exag']['llRatio']))
         self.indent -= 4
         self.file.write('%s</z-exag>\n' % (' ' * self.indent))
         # focus (look here)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/nviz/mapwindow.py
--- grass/branches/releasebranch_6_4/gui/wxpython/nviz/mapwindow.py	2012-05-26 10:39:51 UTC (rev 51767)
+++ grass/branches/releasebranch_6_4/gui/wxpython/nviz/mapwindow.py	2012-05-26 10:45:34 UTC (rev 51768)
@@ -1082,9 +1082,8 @@
         view = self.view
         iview = self.iview
         if zexag and 'value' in view['z-exag']:
-            self._display.SetZExag(self.iview['z-exag']['original'] * view['z-exag']['value'])
+            self._display.SetZExag(view['z-exag']['value'] / iview['z-exag']['llRatio'])
         self._display.SetView(view['position']['x'], view['position']['y'],
                               iview['height']['value'],
                               view['persp']['value'],
@@ -1756,18 +1755,29 @@
     def ResetView(self):
         """!Reset to default view"""
-        self.iview['z-exag']['original'], \
+        zexagOriginal, \
             self.iview['height']['value'], \
             self.iview['height']['min'], \
             self.iview['height']['max'] = self._display.SetViewDefault()
-        ## set initial z-exag value at 1X
-        self.view['z-exag']['value'] = 1.0
+        ## hack for latlon projection
+        ## TODO find more precise way or better rewrite it in OGSF
+        self.iview['z-exag']['llRatio'] = 1
+        if grass.locn_is_latlong():
+            self.iview['z-exag']['llRatio'] = \
+                math.pi / 180 * 6371000 * math.cos((grass.region()['n'] + grass.region()['s']) / 2)
+        self.view['z-exag']['value'] = round(zexagOriginal * self.iview['z-exag']['llRatio'])
         self.view['z-exag']['min'] = UserSettings.Get(group = 'nviz', key = 'view',
-                                                      subkey = ('z-exag', 'min'))
+                                                      subkey = ('z-exag', 'min'))
         zexagMax = UserSettings.Get(group = 'nviz', key = 'view',
-                                    subkey = ('z-exag', 'max'))
+                                    subkey = ('z-exag', 'max'))
+        if zexagMax <= self.view['z-exag']['value']:
+            self.view['z-exag']['max'] = self.view['z-exag']['value'] * 2
+        elif self.view['z-exag']['value'] < 1:
+            self.view['z-exag']['max'] = 10 * self.view['z-exag']['value']
+        else:
+            self.view['z-exag']['max'] = zexagMax
         self.view['position']['x'] = UserSettings.Get(group = 'nviz', key = 'view',
                                                  subkey = ('position', 'x'))
@@ -2395,7 +2405,7 @@
         subcmd += "height=%d " % (self.iview['height']['value'])
         subcmd += "perspective=%d " % (self.view['persp']['value'])
         subcmd += "twist=%d " % (self.view['twist']['value'])
-        subcmd += "zexag=%d " % (self.view['z-exag']['value'] * self.iview['z-exag']['original'])
+        subcmd += "zexag=%f " % (self.view['z-exag']['value'] / self.iview['z-exag']['llRatio'])
         subcmd += "focus=%d,%d,%d " % (self.iview['focus']['x'],self.iview['focus']['y'],self.iview['focus']['z'])
         cmd += subcmd
