[GRASS-SVN] r51800 - grass/trunk/lib/vector/diglib
Sat May 26 11:21:35 EDT 2012
Author: mmetz
Date: 2012-05-26 08:21:35 -0700 (Sat, 26 May 2012)
New Revision: 51800
   grass/trunk/lib/vector/diglib/spindex.c
   grass/trunk/lib/vector/diglib/spindex_rw.c
adjust diglib to changed rtree
Modified: grass/trunk/lib/vector/diglib/spindex.c
--- grass/trunk/lib/vector/diglib/spindex.c	2012-05-26 15:20:58 UTC (rev 51799)
+++ grass/trunk/lib/vector/diglib/spindex.c	2012-05-26 15:21:35 UTC (rev 51800)
@@ -38,7 +38,9 @@
     ndims = (Plus->with_z != 0) ? 3 : 2;
     Plus->spidx_with_z = (Plus->with_z != 0);
+    G_debug(1, "dig_spidx_init(), %d dims", ndims);
     if (Plus->Spidx_file) {
 	int fd;
 	char *filename;
@@ -253,8 +255,15 @@
 dig_spidx_add_node(struct Plus_head *Plus, int node,
 		   double x, double y, double z)
-    struct RTree_Rect rect;
+    static struct RTree_Rect rect;
+    static int rect_init = 0;
+    if (!rect_init) {
+	/* always 6 sides for 3D */
+	rect.boundary = G_malloc(6 * sizeof(RectReal));
+	rect_init = 6;
     G_debug(3, "dig_spidx_add_node(): node = %d, x,y,z = %f, %f, %f", node, x,
 	    y, z);
@@ -280,8 +289,15 @@
 int dig_spidx_add_line(struct Plus_head *Plus, int line, struct bound_box * box)
+    if (!rect_init) {
+	rect_init = 6;
     G_debug(3, "dig_spidx_add_line(): line = %d", line);
     rect.boundary[0] = box->W;
@@ -306,8 +322,15 @@
 int dig_spidx_add_area(struct Plus_head *Plus, int area, struct bound_box * box)
+    if (!rect_init) {
+	rect_init = 6;
     G_debug(3, "dig_spidx_add_area(): area = %d", area);
@@ -333,8 +356,15 @@
 int dig_spidx_add_isle(struct Plus_head *Plus, int isle, struct bound_box * box)
+    if (!rect_init) {
+	rect_init = 6;
     G_debug(3, "dig_spidx_add_isle(): isle = %d", isle);
@@ -362,8 +392,15 @@
     int ret;
     struct P_node *Node;
+    if (!rect_init) {
+	rect_init = 6;
     G_debug(3, "dig_spidx_del_node(): node = %d", node);
     Node = Plus->Node[node];
@@ -395,10 +432,17 @@
 int dig_spidx_del_line(struct Plus_head *Plus, int line, double x, double y, double z)
+    int ret;
     struct P_line *Line;
-    int ret;
+    if (!rect_init) {
+	rect_init = 6;
     G_debug(3, "dig_spidx_del_line(): line = %d", line);
     Line = Plus->Line[line];
@@ -437,8 +481,15 @@
     struct P_topo_b *topo;
+    if (!rect_init) {
+	rect_init = 6;
     G_debug(3, "dig_spidx_del_area(): area = %d", area);
     Area = Plus->Area[area];
@@ -483,8 +534,15 @@
+    if (!rect_init) {
+	rect_init = 6;
     G_debug(3, "dig_spidx_del_isle(): isle = %d", isle);
     Isle = Plus->Isle[isle];
@@ -565,8 +623,15 @@
 dig_select_nodes(struct Plus_head *Plus, const struct bound_box * box,
 		 struct ilist *list)
+    if (!rect_init) {
+	rect_init = 6;
     G_debug(3, "dig_select_nodes()");
     list->n_values = 0;
@@ -604,9 +669,16 @@
 int dig_find_node(struct Plus_head *Plus, double x, double y, double z)
     int node;
+    if (!rect_init) {
+	rect_init = 6;
     G_debug(3, "dig_find_node()");
     rect.boundary[0] = x;
@@ -638,8 +710,15 @@
 int dig_select_lines(struct Plus_head *Plus, const struct bound_box *box,
 		      struct boxlist *list)
+    if (!rect_init) {
+	rect_init = 6;
     G_debug(3, "dig_select_lines_with_box()");
     list->n_values = 0;
@@ -670,9 +749,16 @@
 int dig_find_line_box(struct Plus_head *Plus, struct boxlist *list)
     int ret;
+    if (!rect_init) {
+	rect_init = 6;
     G_debug(3, "dig_find_line_box()");
     if (list->n_values < 1)
@@ -706,8 +792,15 @@
 dig_select_areas(struct Plus_head *Plus, const struct bound_box * box,
+    if (!rect_init) {
+	rect_init = 6;
     G_debug(3, "dig_select_areas_with_box()");
     list->n_values = 0;
@@ -738,9 +831,16 @@
 int dig_find_area_box(struct Plus_head *Plus, struct boxlist *list)
     int ret;
+    if (!rect_init) {
+	rect_init = 6;
@@ -774,8 +874,15 @@
 dig_select_isles(struct Plus_head *Plus, const struct bound_box * box,
+    if (!rect_init) {
+	rect_init = 6;
     list->n_values = 0;
@@ -806,9 +913,16 @@
 int dig_find_isle_box(struct Plus_head *Plus, struct boxlist *list)
     int ret;
+    if (!rect_init) {
+	rect_init = 6;
Modified: grass/trunk/lib/vector/diglib/spindex_rw.c
--- grass/trunk/lib/vector/diglib/spindex_rw.c	2012-05-26 15:20:58 UTC (rev 51799)
+++ grass/trunk/lib/vector/diglib/spindex_rw.c	2012-05-26 15:21:35 UTC (rev 51800)
@@ -22,6 +22,26 @@
 #include <grass/vector.h>
 #include <grass/glocale.h>
+/* TODO: only write out actually used sides */
+#ifndef NUMSIDES
+#define NUMSIDES 6
+#endif
+/* TODO: merge these two */
+struct spidxstack
+    off_t pos[MAXCARD];		/* file position of child node, object ID on level 0 */
+    struct RTree_Node sn;	/* stack node */
+    int branch_id;		/* branch no to follow down */
+struct spidxpstack
+    struct RTree_Node *sn;	/* stack node pointer */
    \brief Write spatial index header to file
@@ -590,7 +610,13 @@
 int rtree_dump_node_file(FILE * fp, off_t pos, int with_z, struct RTree *t)
     int i;
-    struct RTree_Node n;
+    static struct RTree_Node n;
+    static int node_init = 0;
+    if (!node_init) {
+	for (i = 0; i < MAXCARD; i++)
+	    RTreeNewRect(&(n.branch[i].rect), t);
     /* recursive nearly-but-a-bit-messy depth-first pre-order traversal
      * potentially filling up memory */
@@ -660,12 +686,7 @@
     int sidx_nodesize, sidx_leafsize;
     struct RTree_Node *n;
     int i, j, writeout, maxcard;
-    struct spidxstack
-	off_t pos[MAXCARD];	/* file position of child node, object ID on level 0 */
-	struct RTree_Node *sn;	/* stack node */
-	int branch_id;		/* branch no to follow down */
-    } s[50];
+    struct spidxpstack s[MAXLEVEL];
     int top = 0;
     /* should be foolproof */
@@ -765,14 +786,21 @@
-    struct spidxstack
-	struct RTree_Node sn;	/* stack node */
-    } s[MAXLEVEL];
+    static struct spidxstack s[MAXLEVEL];
+    static int stack_init = 0;
     int top = 0;
+    if (!stack_init) {
+	for (i = 0; i < MAXLEVEL; i++) {
+	    for (j = 0; j < MAXCARD; j++) {
+		s[i].sn.branch[j].rect.boundary = G_malloc(6 * sizeof(RectReal));
+	stack_init = 1;
     /* write pending changes to file */
     RTreeFlushBuffer(t);
@@ -879,14 +907,20 @@
     struct RTree_Node *newnode = NULL;
     int i, j, loadnode, maxcard;
-    struct spidxstack
-    } s[50], *last;
+    struct spidxstack *last;
     int top = 0;
+	stack_init = 1;
     /* stack size of t->rootlevel + 1 would be enough because of
      * depth-first postorder traversal:
      * only one node per level on stack at any given time */
@@ -1005,14 +1039,20 @@
     struct RTree_Node newnode;
     off_t newnode_pos = -1;
-    struct spidxstack
-    } s[MAXLEVEL], *last;
     int top = 0;
+	stack_init = 1;
@@ -1284,17 +1324,25 @@
     int hitCount = 0, found, maxcard;
     int i, j;
-    struct spidxstack
-    } s[50], *last;
     int top = 0;
     assert(r);
     assert(t);
+	struct Rect_Real *r;
+	stack_init = 1;
     /* stack size of t->rootlevel + 1 is enough because of depth first search */
     /* only one node per level on stack at any given time */
