[GRASS-SVN] r51803 - grass/trunk/locale/po
Sat May 26 11:46:05 EDT 2012
Author: neteler
Date: 2012-05-26 08:46:05 -0700 (Sat, 26 May 2012)
New Revision: 51803
   grass/trunk/locale/po/grassmods_ar.po
   grass/trunk/locale/po/grassmods_cs.po
   grass/trunk/locale/po/grassmods_de.po
   grass/trunk/locale/po/grassmods_el.po
   grass/trunk/locale/po/grassmods_es.po
   grass/trunk/locale/po/grassmods_fr.po
   grass/trunk/locale/po/grassmods_hi.po
   grass/trunk/locale/po/grassmods_it.po
   grass/trunk/locale/po/grassmods_ja.po
   grass/trunk/locale/po/grassmods_ko.po
   grass/trunk/locale/po/grassmods_lv.po
   grass/trunk/locale/po/grassmods_mr.po
   grass/trunk/locale/po/grassmods_pl.po
   grass/trunk/locale/po/grassmods_pt.po
   grass/trunk/locale/po/grassmods_pt_br.po
   grass/trunk/locale/po/grassmods_ru.po
   grass/trunk/locale/po/grassmods_sl.po
   grass/trunk/locale/po/grassmods_th.po
   grass/trunk/locale/po/grassmods_tr.po
   grass/trunk/locale/po/grassmods_vi.po
   grass/trunk/locale/po/grassmods_zh.po
remove gettext junk
Modified: grass/trunk/locale/po/grassmods_ar.po
--- grass/trunk/locale/po/grassmods_ar.po	2012-05-26 15:22:06 UTC (rev 51802)
+++ grass/trunk/locale/po/grassmods_ar.po	2012-05-26 15:46:05 UTC (rev 51803)
@@ -34742,7789 +34742,3 @@
 #, fuzzy
 msgid "Percent to brighten"
 msgstr "مقلوب فرق العزم"
-#, fuzzy
-msgid "Input raster map with specific yield in [1/m]"
-msgstr "لم تحدد خرائط مدخلة"
-#, fuzzy
-msgid "Raster map <%s> is not valid"
-msgstr "غير موجودة <%s> الخريطة الراسترية "
-#, fuzzy
-msgid "If not given read from standard input"
-msgstr "الملف  الأسكى الراسترى المطلوب ادخاله"
-#, fuzzy
-msgid "Print basic info in shell script style"
-msgstr "طباعة الأحصاء فى صورة شل سكربت"
-#, fuzzy
-msgid "Projection:"
-msgstr "التوقيع ..."
-#, fuzzy
-msgid "relative"
-msgstr "مضاهاة"
-#, fuzzy
-msgid "Join column in table"
-msgstr "نوع غير معروف"
-#, fuzzy
-msgid "Unable to parse '%s'\n"
-msgstr "%s:لم يتم إنشاء الجدول"
-#, fuzzy
-msgid "Driver <%s> doesn't support creating new fields"
-#, fuzzy
-msgid "Unable to add new field <%s>"
-msgstr "<%s> فى <%s>لم يمكن قراءة الملف للمنظر ثلاثى الأبعاد"
-#, fuzzy
-msgid "Name of raster map from which to copy color table"
-msgstr "اسم لخريطة الراسترية انسخ جدول ألوانها"
-#, fuzzy
-msgid "Name of file containing rules"
-msgstr "اسم الخريطة الراسترية الحاوية على درجات الإنحدار"
-#, fuzzy
-msgid "Creating support files for <%s>"
-msgstr "%s لم يمكن فتح ملف المدى ل"
-#, fuzzy
-msgid "Title for new raster file."
-msgstr "وصف مبسط للخريطة الراسترية الجدىدة"
-#, fuzzy
-msgid "Unable it load G3d range"
-msgstr "<%s> لم يمكن فتح"
-#, fuzzy
-msgid "Exports the color table associated with a raster3d map layer."
-msgstr "إنشاء وتعديل جدول الألوان المصاحب لطبقة الخريطة الراسترية"
-#, fuzzy
-msgid "Could not close RASTER3D map <%s>"
-msgstr "<%s>لم يتم العثور على الخريطة المدخلة\n"
-#, fuzzy
-msgid "Name for v5d output file"
-msgstr "اسم الملف المخرج"
-#, fuzzy
-msgid "Remove dangles:"
-msgstr "لم يتم حساب شبه مركز المساحة"
-#, fuzzy
-msgid "Unable to create 3D vector and attribute table at same time"
-msgstr "[%s]لم يتم فتح ملف الخلية ل "
-#, fuzzy
-msgid "Coordinates"
-msgstr "الإحداثيات للإستفهام"
-#, fuzzy
-msgid "Vector map for which to drop vector objects"
-msgstr "عدم انشاء جدول الخواص"
-#, fuzzy
-msgid "Layer of attribute table to use for selection"
-msgstr "<%s> اسم الملف المستخدم لل"
-#, fuzzy
-msgid "Overwrite existing file"
-#, fuzzy
-msgid "Name of input vector polygon map"
-msgstr "اسم الخريطة الراسترية"
-#, fuzzy
-msgid "Name of MODIS product"
-msgstr "اسم الخريطة المدخلة"
-#, fuzzy
-msgid "The names of tile/s to download"
-msgstr "عدد النقاط المطلوب تخصيصها"
-#, fuzzy
-msgid "raster, import, copying"
-msgstr "الصفر قيمة حقيقية"
-#, fuzzy
-msgid "raster, export, copying"
-msgstr "الملف الراسترى المدخل"
-#, fuzzy
-msgid "Name for output shaded relief map"
-msgstr "اسم الخريطة الراسترية المخرجة"
-#, fuzzy
-msgid "zenith"
-msgstr "%f : الطول\n"
-#, fuzzy
-msgid "topographic correction method"
-msgstr "خريطة الإتجاه المخرجة"
-#, fuzzy
-msgid "Elevation file of unknown type"
-msgstr "احداثى الشرق, الأساس هو مركز الخريطة"
-#, fuzzy
-msgid "Cannot allocate memory for auxiliar matrix.Consider changing region (resolution)"
-#, fuzzy
-#~ msgid "Input grid3 filename"
-#~ msgstr "اسم ااملف المخرج"
-#, fuzzy
-#~ msgid "Grid3 <%s> not found %s"
-#~ msgstr "غير موجودة <%s> المنطقة"
-#, fuzzy
-#~ msgid "Print raster map resolution (NS-res, EW-res) only"
-#~ msgstr "طباعة دقة الوضوح شمال-جنوب و شرق-غرب فقط"
-#~ msgid "Print raster map type only"
-#~ msgstr "طباعة نوع الملف الراسترى فقط"
-#, fuzzy
-#~ msgid "Print map region only"
-#, fuzzy
-#~ msgid "Print raster map data units only"
-#, fuzzy
-#~ msgid "Print raster map vertical datum only"
-#, fuzzy
-#~ msgid "Print map title only"
-#, fuzzy
-#~ msgid "Name for value output map"
-#~ msgstr "اسم الخريطة الراسترية المخرجة"
-#, fuzzy
-#~ msgid "Reading sites..."
-#~ msgstr "dig قراءة ملف...\n"
-#, fuzzy
-#~ msgid "Writing sites to output..."
-#~ msgstr "كتابة ملف جديد...\n"
-#, fuzzy
-#~ msgid "Reading coordinates from file."
-#~ msgstr "إحداثيات الشرق والشمال لنقطة البدء"
-#, fuzzy
-#~ msgid "ASCII file holding transform coordinates"
-#~ msgstr "استخدام احداثيات مركز الخريطة\n"
-#, fuzzy
-#~ msgid "Unable to open file with coordinates <%s>"
-#~ msgstr "%s:لم يتم فتح ملف بإحداثيات\n"
-#, fuzzy
-#~ msgid "Error reading coordinates file"
-#, fuzzy
-#~ msgid "Number of points that have been entered [%d]"
-#~ msgstr "%d: عدد النقاط التى أدخلت\n"
-#, fuzzy
-#~ msgid "Error creating transformation"
-#~ msgid "The points weren't spread out enough."
-#~ msgstr "النقاط لم تنتشر بطريقة كافية"
-#~ msgid "You need to enter at least %d points."
-#~ msgstr "نقطة %d فى حاجة لإدخال على الأقل"
-#, fuzzy
-#~ msgid "Cannot scan date: "
-#~ msgstr "لم يتم جلب البيانات"
-#, fuzzy
-#~ msgid "Cannot scan time: "
-#~ msgstr "%s:لم يتم إنشاء الجدول"
-#, fuzzy
-#~ msgid "Cannot allocate cursor."
-#~ msgstr "لم يتم فتح إختيار المؤشر"
-#, fuzzy
-#~ msgid "Cannot ad new token."
-#~ msgstr "لم بمكن قراءة معلومات الحقل"
-#, fuzzy
-#~ msgid "Cannot connect to MySQL: "
-#~ msgstr "%s:لم يتم الحشر بالجدول"
-#, fuzzy
-#~ msgid "Cannot select data: \n"
-#~ msgstr "لم يمكن اختيار البيانات من الجدول"
-#, fuzzy
-#~ msgid "Unable allocate memory for row buffer"
-#~ msgstr "لم يتم حساب شبه مركز المساحة"
-#, fuzzy
-#~ msgid "Computing means for band %d..."
-#~ msgstr "لم يتم نسخ الجدول"
-#, fuzzy
-#~ msgid "Computing row %d (of %d) of covariance matrix..."
-#~ msgstr "حساب الظلال من نموذج الإرتفاعت الرقمى"
-#, fuzzy
-#~ msgid "Unable to allocate memory for row buffer"
-#, fuzzy
-#~ msgid "Unable to allocate memory for raster row"
-#, fuzzy
-#~ msgid "Transforming <%s>..."
-#~ msgstr "التوقيع ..."
-#~ msgid "Surface area estimation for rasters."
-#~ msgstr "تعيين المساحة السطحية للراسترات"
-#~ msgid "Raster file for surface"
-#~ msgstr "الملف الراستري للسطح"
-#, fuzzy
-#~ msgid "Writing buffers..."
-#~ msgstr "وصل الفئات...\n"
-#, fuzzy
-#~ msgid "ASCII file to be converted to binary vector map"
-#~ msgstr "الملف  الأسكى الراسترى المطلوب ادخاله"
-#, fuzzy
-#~ msgid "Join column in other table"
-#~ msgstr "نوع غير معروف"
-#, fuzzy
-#~ msgid "Layer number or name with route paths or -1"
-#~ msgstr "اسم الخريطة الراسترية"
-#, fuzzy
-#~ msgid "Layer %d - no table"
-#, fuzzy
-#~ msgid "Layer %d - unable to copy table"
-#~ msgstr "<%s> لم يمكن فتح"
-#, fuzzy
-#~ msgid "Source layer number or name"
-#, fuzzy
-#~ msgid "Sink layer number or name"
-#, fuzzy
-#~ msgid "Name of Arc cost column"
-#~ msgstr "عدد الأعمدة"
-#, fuzzy
-#~ msgid "From layer number or name"
-#, fuzzy
-#~ msgid "To layer number or name"
-#, fuzzy
-#~ msgid "Name of node capacity column"
-#, fuzzy
-#~ msgid "Set1 layer number or name"
-#, fuzzy
-#~ msgid "Set2 layer number or name"
-#, fuzzy
-#~ msgid "Either mapset= or -l must be used"
-#~ msgstr "طبقتين يجب تحديدهم"
-#, fuzzy
-#~ msgid "Can't read vector map"
-#~ msgid "pg driver: column '%s', type %d  is not supported"
-#~ msgstr "غير مدعم %d نوع,'%s' عمود :pg مشغل ال "
-#~ msgid "Type of color table"
-#~ msgstr "نوع جدول الألوان"
-#, fuzzy
-#~ msgid "Save placeholder raster map for use with d.legend"
-#~ msgstr "اسم الخريطة الراسترية  للعرض كخلفية"
-#, fuzzy
-#~ msgid "Name for input source not specified"
-#, fuzzy
-#~ msgid "Name for output raster map not specified"
-#, fuzzy
-#~ msgid "Requested g3d map <%s> not found"
-#~ msgstr "غير موجودة <%s> الخريطة الراسترية "
-#~ msgid "Angular Second Moment"
-#~ msgstr "العزم الزاوى الثانى"
-#, fuzzy
-#~ msgid "Features"
-#~ msgstr "نوع المظهر"
-#, fuzzy
-#~ msgid "Contrast"
-#~ msgstr "درجة الوضوح"
-#~ msgid "Correlation"
-#~ msgstr "مضاهاة"
-#, fuzzy
-#~ msgid "Variance"
-#~ msgstr "التباين"
-#~ msgid "Inverse Diff Moment"
-#~ msgstr "مقلوب فرق العزم"
-#~ msgid "Sum Average"
-#~ msgstr "متوسط المجموع"
-#~ msgid "Sum Variance"
-#~ msgstr "تباين المجموع"
-#~ msgid "Sum Entropy"
-#~ msgstr "مجموع الإنتروبى"
-#, fuzzy
-#~ msgid "Entropy"
-#~ msgid "Difference Variance"
-#~ msgstr "تباين الفرق"
-#~ msgid "Difference Entropy"
-#~ msgstr "إنتروبى الفرق"
-#~ msgid "Measure of Correlation-1"
-#~ msgstr "قياس المضاهاة-1"
-#~ msgid "Measure of Correlation-2"
-#~ msgstr "قياس المضاهاة-2"
-#~ msgid "Max Correlation Coeff"
-#~ msgstr "عامل المضاهاة الأعظم"
-#~ msgid "Raster file to be imported"
-#~ msgstr "الملف الراسترى الطلوب إدخالة"
-#, fuzzy
-#~ msgid "Write the result to g3d map <%s>"
-#~ msgstr "وصف مبسط للخريطة الراسترية الناتجة "
-#, fuzzy
-#~ msgid "Requested 3d raster map not found"
-#~ msgstr "غير موجود <%s>الملف للمنظر ثلاثى الأبعاد "
-#, fuzzy
-#~ msgid "Requested 3d raster map <%s> not found"
-#, fuzzy
-#~ msgid "Requested g3d RGB map <%s> not found"
-#, fuzzy
-#~ msgid "Requested g3d vector map <%s> not found"
-#~ msgstr "لم توجد<%s>الخريطة الفيكتورية"
-#, fuzzy
-#~ msgid "Error closing g3d vector map."
-#~ msgstr "الخريطة الفيكتورية لنقاط الإنتهاء"
-#, fuzzy
-#~ msgid "Error closing new 3d raster map"
-#~ msgstr "dig عطل فى فتح ملف المدخل"
-#, fuzzy
-#~ msgid "Error closing ascii file"
-#~ msgstr "خطا فى محاولة قراءة ملف قاعدة البيانات dbmscap\n"
-#, fuzzy
-#~ msgid "Name for output flowline density raster map"
-#~ msgstr "الخريطة الراسترية لنقاط البدء"
-#, fuzzy
-#~ msgid "Create/Edit"
-#~ msgstr "مضاهاة"
-#, fuzzy
-#~ msgid "Print mapset names"
-#~ msgstr "اسم خريطة اتجاه الإنحدار"
-#, fuzzy
-#~ msgid "Remove duplicates:"
-#, fuzzy
-#~ msgid "Write centroids:"
-#~ msgstr "كتابة رؤوس قمم الخطوط"
-#, fuzzy
-#~ msgid "Cannot calculate centroid"
-#, fuzzy
-#~ msgid "Unknown icon marker"
-#, fuzzy
-#~ msgid "Write output to PNG image"
-#~ msgstr "تغلب على الخريطة المخرجة"
-#~ msgid "Verbose mode"
-#~ msgstr "تنفيذ باسهاب"
-#, fuzzy
-#~ msgid "Input type point, line or area"
-#~ msgstr " خط أم مساحة"
-#, fuzzy
-#~ msgid "Name for output vector map"
-#~ msgstr "اسم الملف الفيكتورى المخرج"
-#, fuzzy
-#~ msgid "Name of raster plane to be created"
-#~ msgstr "اسم الخريطة المدخلة"
-#, fuzzy
-#~ msgid "vector, interpolation, kriging"
-#~ msgstr "عدد نقاط الإستيفاء"
-#, fuzzy
-#~ msgid "Name for output raster map prefix (e.g. 'brov')"
-#~ msgstr "الملف الراسترى المخرج"
-#, fuzzy
-#~ msgid "raster input map"
-#~ msgstr "اسم الراستر المدخل"
-#, fuzzy
-#~ msgid "reclass raster output map"
-#~ msgstr "اسم الخريطة المخرجة"
-#, fuzzy
-#~ msgid "Vector map to modify"
-#, fuzzy
-#~ msgid "Layer in the vector to be modified"
-#~ msgstr "الخريطة الراسترية المطلوب استفهامها"
-#, fuzzy
-#~ msgid "Vector map to be queried"
-#, fuzzy
-#~ msgid "Layer of the query vector containing data"
-#, fuzzy
-#~ msgid "Column to be queried"
-#, fuzzy
-#~ msgid "Name of input vector map"
-#~ msgstr "اسم الخريطة الراسترية المدخلة"
-#, fuzzy
-#~ msgid "Vector map to edit the attribute table for"
-#~ msgstr "عدم انشاء جدول الخواص"
-#, fuzzy
-#~ msgid "Column to query"
-#, fuzzy
-#~ msgid "Raster map to use as mask"
-#~ msgstr "الخرائط الراسترية المطلوب قرائتها"
-#, fuzzy
-#~ msgid "Vector map for which to rename attribute column"
-#, fuzzy
-#~ msgid "Layer where to rename column"
-#, fuzzy
-#~ msgid "Field separator"
-#~ msgstr "الفاصل الحقلي للمخرج"
-#, fuzzy
-#~ msgid "display, vector, thematic, legend"
-#~ msgstr "الملف الراسترى المدخل"
-#, fuzzy
-#~ msgid "Table from which to drop attribute column"
-#, fuzzy
-#~ msgid "Raster map in which to fill nulls"
-#~ msgstr "اسم لخريطة الراسترية انسخ جدول ألوانها"
-#, fuzzy
-#~ msgid "Vector map from which to remove attribute table"
-#, fuzzy
-#~ msgid "Name of existing attribute table (default: vector map name)"
-#~ msgstr "اسم الخريطة الراسترية الموجودة"
-#, fuzzy
-#~ msgid "Layer from which to drop linked attribute table"
-#, fuzzy
-#~ msgid "Vector map for which to drop attribute column"
-#, fuzzy
-#~ msgid "Layer where to drop column"
-#, fuzzy
-#~ msgid "raster output TC maps prefix"
-#, fuzzy
-#~ msgid "Vector map for which to add new attribute table"
-#, fuzzy
-#~ msgid "vector, import, wfs"
-#, fuzzy
-#~ msgid "Name of data table"
-#~ msgstr "اسم الخريطة الراسترية الجديدة"
-#, fuzzy
-#~ msgid "Database/directory for table"
-#~ msgstr "cat = %d لا يوجد تسجيل للخط"
-#, fuzzy
-#~ msgid "Database driver"
-#~ msgstr ":اسم قاعدة البيانات"
-#, fuzzy
-#~ msgid "Cannot open file [%s] in mapset [%s]"
-#~ msgstr "<%s> فى <%s>لم يمكن فتح الملف للمنظر ثلاثى الأبعاد"
-#, fuzzy
-#~ msgid "Cannot create file <%s> in mapset <%s>"
-#, fuzzy
-#~ msgid "basemap"
-#~ msgstr "الخريطة الراسترية الغطاء"
-#, fuzzy
-#~ msgid "method"
-#~ msgstr "%c :نوع غير معروف"
-#, fuzzy
-#~ msgid "Cannot allocate memory for auxiliar matrix.Consider changing region resolution"
-#, fuzzy
-#~ msgid "Verbose module output"
-#, fuzzy
-#~ msgid "Reading file [%s]..."
-#, fuzzy
-#~ msgid "Unable to determine raster cell type"
-#, fuzzy
-#~ msgid "Unable to read color file"
-#~ msgstr "[%s]لم يتم فتح ملف الخلية ل "
-#, fuzzy
-#~ msgid "Unable to read raster row"
-#~ msgid "Raster file(s) for View%d"
-#~ msgstr "الملفات الراسترية المطلوب رؤيتها%d"
-#, fuzzy
-#~ msgid "Unable to read file header of <%s>"
-#, fuzzy
-#~ msgid "Unable to read raster map <%s> row %d"
-#~ msgstr "اسم الخريطة الراسترية الناتجة"
-#, fuzzy
-#~ msgid "Failed writing raster map <%s>"
-#~ msgstr "خريطة الراستر االناتجة"
-#, fuzzy
-#~ msgid "raster3d, voxel, import"
-#, fuzzy
-#~ msgid "Recharge raster map in m^3/s"
-#~ msgstr "%-5d dig_att قراءة ملف...\n"
-#, fuzzy
-#~ msgid "raster3d, voxel, export"
-#, fuzzy
-#~ msgid "Converts a 3D raster map layer into an ASCII text file."
-#~ msgstr "ASCII text تحويل ملف راسترى الى ملف اسكى نصى"
-#, fuzzy
-#~ msgid "Unable to write raster row"
-#, fuzzy
-#~ msgid "Unable to close output map"
-#, fuzzy
-#~ msgid "Illegal output file name"
-#, fuzzy
-#~ msgid "Raster map %d Filename: %s already exists. Will be overwritten!"
-#~ msgstr "خريطة مخرجة حيث ستكتب النقاط"
-#, fuzzy
-#~ msgid "Unable to get elevation raster row"
-#~ msgstr "خريطة الارتفاعات الراسترية المخرجة"
-#, fuzzy
-#~ msgid "Elevation map not found"
-#~ msgstr "خريطة الإرتفاعات"
-#, fuzzy
-#~ msgid "Unable to open elevation map"
-#~ msgstr "اسم ملف الإرتفاعات الراسترى"
-#, fuzzy
-#~ msgid "Unable to create raster map"
-#, fuzzy
-#~ msgid "Unable to close elevation map"
-#, fuzzy
-#~ msgid "Wrong 3D raster map datatype! Unable to create raster map."
-#~ msgstr "نوع التخزين للخريطة الراسترية الناتجة "
-#, fuzzy
-#~ msgid "Unable to close input raster map"
-#, fuzzy
-#~ msgid "Unable to read top raster row \n"
-#, fuzzy
-#~ msgid "Unable to read bottom raster row \n"
-#, fuzzy
-#~ msgid "Could not open map %s"
-#~ msgstr "المدخل لم يوجد %s\n"
-#, fuzzy
-#~ msgid "No vector data will be created"
-#, fuzzy
-#~ msgid "Unable to close top raster map"
-#, fuzzy
-#~ msgid "Unable to close bottom raster map"
-#~ msgstr "اسم خريطة الراستر المخرجة"
-#, fuzzy
-#~ msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
-#~ msgstr "(تحويل الملف الراسترى النصى الأسكى الى خريطة راسترية ثنائية (صفر,واحد"
-#, fuzzy
-#~ msgid "raster3d, voxel, statistics"
-#, fuzzy
-#~ msgid "miscellaneous, distance"
-#, fuzzy
-#~ msgid "Unable to write quant file"
-#~ msgstr "القيمة التى تعنى قيمة منعدمة"
-#, fuzzy
-#~ msgid "Link to raster map <%s> created"
-#~ msgstr "dig_att لم يمكن العثور على ملف"
-#, fuzzy
-#~ msgid "raster, import"
-#, fuzzy
-#~ msgid "Link GDAL supported raster file to a binary raster map layer."
-#~ msgstr "ادخال ملف راسترى ذو دعم  جيدال الى خريطة راسترية بينرية"
-#, fuzzy
-#~ msgid "Raster file to be linked"
-#, fuzzy
-#~ msgid "Required"
-#~ msgstr "خروج"
-#, fuzzy
-#~ msgid "Unable to set window"
-#, fuzzy
-#~ msgid "raster, resample"
-#~ msgstr "الخريطة الراسترية المطلوب تسجيلها"
-#~ msgid "Bilinear interpolation utility for raster map layers."
-#~ msgstr "وسيلة الإستيفاء ثنائى الخط للخرائط الراسترية"
-#, fuzzy
-#~ msgid "Specific input value to be assigned to the north and/or south poles for longitude-latitude grids"
-#~ msgstr "تحديد قيم الأدخال لأقطاب الشمال والجنوب لشبكات خطوط الطول والعرض"
-#, fuzzy
-#~ msgid "%s: base raster map not found"
-#~ msgstr ""
-#~ "#-#-#-#-#  grassmods_ar.po (grassmods_ar)  #-#-#-#-#\n"
-#~ "الملف الفيكتورى غير موجود %s : تحذير\n"
-#~ "غير موجودة <%s> الخريطة الراسترية \n"
-#, fuzzy
-#~ msgid "%s: cover raster map not found"
-#, fuzzy
-#~ msgid "raster, profile"
-#~ msgid "Interactively select End-Points"
-#~ msgstr "إختيار النقاط الطرفية تفاغليا"
-#, fuzzy
-#~ msgid "Use mouse to select Start Point\n"
-#, fuzzy
-#~ msgid "Buttons:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "أزرار:\n"
-#, fuzzy
-#~ msgid "Left:   Mark next point\n"
-#~ msgstr "يسار:ماذا هنا\n"
-#, fuzzy
-#~ msgid "raster, sun energy"
-#, fuzzy
-#~ msgid "Horizon file no. %d <%s> not found"
-#, fuzzy
-#~ msgid "unable to open elevation map layer"
-#, fuzzy
-#~ msgid "unable to open rill map layer"
-#, fuzzy
-#~ msgid "Close failed."
-#, fuzzy
-#~ msgid "unable to open new aspect map layer."
-#~ msgstr "اسم الملف الراسترى الموجود"
-#, fuzzy
-#~ msgid "unable to open new LS factor map layer."
-#, fuzzy
-#~ msgid "unable to open new S factor map layer."
-#, fuzzy
-#~ msgid "unable to open flow accumulation map layer"
-#, fuzzy
-#~ msgid "raster, hydrology"
-#, fuzzy
-#~ msgid "Watershed basin analysis program"
-#~ msgstr "برنامج تحليل محددات  مياه الأحواض"
-#, fuzzy
-#~ msgid "Name of input raster map with real depressions"
-#, fuzzy
-#~ msgid "Name of input raster map blocking overland surface flow"
-#~ msgstr "USLE خريطة مدخلة : التضاريس الحاجبة للسريان السطحى عبر البر, فى"
-#, fuzzy
-#~ msgid "Name for output raster map useful for visual display of results (DEPRECATED)"
-#~ msgstr "الخريطة المخرجة : مفيد للعرض المرئى للنتائج "
-#, fuzzy
-#~ msgid "raster, export, color table"
-#, fuzzy
-#~ msgid "Exports the color table associated with a raster map layer."
-#~ msgstr "إنشاء وتعديل جدول الألوان المصاحب لطبقة الخريطة الراسترية"
-#, fuzzy
-#~ msgid "Direction raster found <%s>"
-#, fuzzy
-#~ msgid "Cannot open raster map <%s>"
-#~ msgstr ""
-#~ "[%s]لم يتم فتح ملف الخلية ل \n"
-#~ "%s لم يتم فتح قاعدة البيانات"
-#, fuzzy
-#~ msgid "raster, geomorphology"
-#, fuzzy
-#~ msgid "Cannot write category file for raster map <%s>"
-#~ msgstr "%s لم يمكن فتح ملف المدى ل"
-#, fuzzy
-#~ msgid "Raster file [%s] not found. Exiting."
-#~ msgstr "غير موجود <%s> الراستر"
-#, fuzzy
-#~ msgid "History file for [%s] updated."
-#, fuzzy
-#~ msgid "Cannot open raster map [%s]!"
-#~ msgstr "%s لم يتم العثور على الخريطة الراسترية"
-#, fuzzy
-#~ msgid "Raster file [%s] is empty."
-#, fuzzy
-#~ msgid "Error reading raster map [%s]."
-#, fuzzy
-#~ msgid "Unable to write header for [%s]."
-#, fuzzy
-#~ msgid "        Number of rows"
-#~ msgstr "عدد الصفوف"
-#, fuzzy
-#~ msgid "        Number of cols"
-#, fuzzy
-#~ msgid "        Number of bytes per cell"
-#~ msgstr "عدد البيتات فى الخلية , واحدة, اثنتين, أم أربعة"
-#, fuzzy
-#~ msgid "        Floating point map"
-#~ msgstr "تقريب بيانات النقط العشرية"
-#, fuzzy
-#~ msgid "Category file for <%s> not updated"
-#, fuzzy
-#~ msgid "Category file for <%s> updated"
-#, fuzzy
-#~ msgid "raster, metadata"
-#, fuzzy
-#~ msgid "Edit the history file for [%s]? "
-#, fuzzy
-#~ msgid "Color table for <%s> updated"
-#~ msgstr " <%s> فى <%s>لم يمكن قراءة العنوان الرئيسى ل"
-#, fuzzy
-#~ msgid "Name for output direction map for depressionless elevation raster map"
-#~ msgstr "خريطة  الإتجاه مع خريطة الإرتفاعات الخالية من المنخفضات, مخرج"
-#~ msgid "Run quietly"
-#~ msgstr "تنفيذ بهدوء"
-#, fuzzy
-#~ msgid "raster, distance"
-#, fuzzy
-#~ msgid "Reading file"
-#, fuzzy
-#~ msgid "raster, export, animation"
-#~ msgstr "الصفر قيمة حقيقية"
-#, fuzzy
-#~ msgid "Raster File Series to MPEG Conversion."
-#~ msgstr "MPEG تحويل مجموعة ملفات راسترية الى"
-#~ msgid "Quiet - suppress progress report"
-#~ msgstr "خروج متخطيا تقرير التقدم"
-#, fuzzy
-#~ msgid "(requires r.out.ppm with stdout option)"
-#~ msgstr "تحويل طيارى مستخدما مساحة اقل على القرص"
-#, fuzzy
-#~ msgid "raster, geometry"
-#, fuzzy
-#~ msgid "One or more input raster maps not found"
-#, fuzzy
-#~ msgid "raster, quantization"
-#, fuzzy
-#~ msgid "Quant table not changed for %s"
-#, fuzzy
-#~ msgid "Unable to find row %d, col %d: %f"
-#~ msgstr "<%s>لم يتم العثور على الخريطة المدخلة\n"
-#, fuzzy
-#~ msgid "raster, cost surface, cumulative costs"
-#~ msgstr "طبقة السطح الراسترى المطلوب معالجتها"
-#, fuzzy
-#~ msgid "Unable to read current window parameters"
-#~ msgstr "طباعة إحداثيات الإتصال الحلى و الخروج"
-#, fuzzy
-#~ msgid "Failed to guess site file format\n"
-#~ msgstr "ملف المدخل"
-#, fuzzy
-#~ msgid "No data"
-#, fuzzy
-#~ msgid "Error writing category file for <%s>"
-#, fuzzy
-#~ msgid "Error writing color file for <%s>"
-#, fuzzy
-#~ msgid "RGB raster map <%s> not found"
-#, fuzzy
-#~ msgid "Vector cell map <%s> not found"
-#, fuzzy
-#~ msgid "raster, export"
-#, fuzzy
-#~ msgid "Converts raster maps into the VTK-Ascii format"
-#~ msgstr "تحويل خريطة راسترية إلى فيكتورية"
-#, fuzzy
-#~ msgid "raster, recode category"
-#, fuzzy
-#~ msgid "Data range of raster map <%s> is empty"
-#~ msgstr "بدء بالقيم فى الخريطة الراسترية"
-#, fuzzy
-#~ msgid "Data range of raster map <%s> is %s to %s (entire map)"
-#~ msgstr "fp: Data range is %.25f to %.25f\n"
-#, fuzzy
-#~ msgid "Unable to read range of raster map <%s>"
-#, fuzzy
-#~ msgid "Integer data range of raster map <%s> is empty"
-#, fuzzy
-#~ msgid "Integer data range of raster mao <%s> is %d to %d"
-#~ msgstr " %ld الى %ld نطاق البيانات يتراوح من\n"
-#, fuzzy
-#~ msgid "%s: unable to open temporary file"
-#~ msgstr "لم يتم تحديث الحدود"
-#~ msgid "Resultant raster map (not used with 'distribution')"
-#~ msgstr "الخريطة الراسترية الناتجة"
-#, fuzzy
-#~ msgid "Output map <%s> ignored"
-#~ msgstr "الخريطة المخرجة"
-#, fuzzy
-#~ msgid "raster, rescale"
-#, fuzzy
-#~ msgid "raster, viewshed"
-#, fuzzy
-#~ msgid "Failed writing raster map <%s> row %d"
-#, fuzzy
-#~ msgid "raster, color transformation"
-#, fuzzy
-#~ msgid "raster, buffer"
-#, fuzzy
-#~ msgid "Unable to write color table for %s"
-#~ msgid "Name of raster map to contain results"
-#, fuzzy
-#~ msgid "Number of the segment to create (segment library)"
-#~ msgstr "عدد مرات تكرار المرشح"
-#, fuzzy
-#~ msgid "Unable to find starting vector <%s> "
-#, fuzzy
-#~ msgid "Unable to find stop vector <%s>"
-#, fuzzy
-#~ msgid "Unable to read %s"
-#, fuzzy
-#~ msgid " %d rows, %d cols"
-#~ msgstr "%d راستر%s, %d فيكتور%s\n"
-#, fuzzy
-#~ msgid "Output map is: Integer cell type"
-#~ msgstr "وصف مبسط للملف الراسترى المخرج"
-#, fuzzy
-#~ msgid "Unable to allocate memory for segment fbuff == NULL"
-#, fuzzy
-#~ msgid "Raster output map <%s> not found (no start_points given)"
-#, fuzzy
-#~ msgid "Will copy input map null values into output map"
-#~ msgstr "نسخ قيم الخلية المدخلة على الخرج"
-#, fuzzy
-#~ msgid "raster, querying"
-#, fuzzy
-#~ msgid "raster, DEM, contours, vector"
-#~ msgid "Suppress single crossing error messages"
-#~ msgstr "تخطى رسائل خطأ التقاطع الفردى"
-#, fuzzy
-#~ msgid "raster, series"
-#, fuzzy
-#~ msgid "Unable to open raster map <%s> in mapset <%s>"
-#~ msgstr "<%s>فى<%s>لم يمكن فتح الملف الفيكتورى"
-#, fuzzy
-#~ msgid "<%s> is an ilegal name"
-#, fuzzy
-#~ msgid "Unable to write color table for raster map <%s>"
-#, fuzzy
-#~ msgid "raster, random, surface"
-#, fuzzy
-#~ msgid "raster, import, LIDAR"
-#, fuzzy
-#~ msgid "raster, composite"
-#, fuzzy
-#~ msgid "Error reading raster map <%s>"
-#, fuzzy
-#~ msgid "raster, volume"
-#, fuzzy
-#~ msgid "Unable to find data map"
-#, fuzzy
-#~ msgid "Unable to find clump map"
-#, fuzzy
-#~ msgid "Data or Clump file not open"
-#, fuzzy
-#~ msgid "Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
-#, fuzzy
-#~ msgid "Unable to read header of raster map <%s>"
-#, fuzzy
-#~ msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster map layer."
-#~ msgstr "(تحويل الملف الراسترى من نوع إسري آركإنفو الى خريطة راسترية ثنائية (صفر,واحد"
-#, fuzzy
-#~ msgid "Can't set window"
-#~ msgstr "لم يتم انشاء الدليل"
-#, fuzzy
-#~ msgid "Name for output elevation raster map after filling"
-#~ msgstr "خريطة الإرتفاعات المخرجة بعد الملىء"
-#, fuzzy
-#~ msgid "Name for output direction raster map"
-#, fuzzy
-#~ msgid "Cannot read raster row %d"
-#, fuzzy
-#~ msgid "raster, map algebra"
-#~ msgid "Apply filter only to zero data values"
-#~ msgstr "تطبيق المرشح على القيم الصفرية فقط"
-#, fuzzy
-#~ msgid "Raster map matrix filter."
-#~ msgstr "مصفوفة الترشيح للملف الراسترى"
-#, fuzzy
-#~ msgid "Name of filter file"
-#~ msgstr "اسم ملف المرشح"
-#~ msgid "Quietly"
-#~ msgstr "بهدوء"
-#, fuzzy
-#~ msgid "Unable to read raster map row %d "
-#, fuzzy
-#~ msgid "Failed writing raster map row %d"
-#, fuzzy
-#~ msgid "raster, statistics, reclass"
-#~ msgid "Title, in quotes"
-#~ msgstr "وصف مبسط"
-#, fuzzy
-#~ msgid "raster, color table"
-#, fuzzy
-#~ msgid "Creates/modifies the color table associated with a raster map layer."
-#, fuzzy
-#~ msgid "Path to rules file (\"-\" to read rules from stdin)"
-#~ msgstr "إدخال خريطة راسترية بينرية "
-#, fuzzy
-#~ msgid "No raster map specified"
-#~ msgstr "لم تحدد خرائط مدخلة"
-#, fuzzy
-#~ msgid "Unable to remove color table of raster map <%s>"
-#, fuzzy
-#~ msgid "Color table of raster map <%s> not found"
-#, fuzzy
-#~ msgid "Color table 'random' is not supported for floating point raster map"
-#, fuzzy
-#~ msgid "Color table 'grey.eq' is not supported for floating point raster map"
-#, fuzzy
-#~ msgid "Color table for raster map <%s> set to '%s'"
-#, fuzzy
-#~ msgid "Could not get raster row"
-#, fuzzy
-#~ msgid "raster, volume, conversion"
-#, fuzzy
-#~ msgid "Cell file not found"
-#, fuzzy
-#~ msgid "Unable to close input map"
-#~ msgstr "اسم مجموعة الخرائط للخريطة المدخلة"
-#, fuzzy
-#~ msgid "Name of the latitudes input raster map [decimal degrees]"
-#~ msgstr "اسم ملف خط العرض الراسترى"
-#, fuzzy
-#~ msgid "A single value of latitude [decimal degrees]"
-#~ msgstr "قيمة مفردة  لخط العرض"
-#, fuzzy
-#~ msgid "Name of real-sky beam radiation coefficient raster map [-]"
-#~ msgstr "ملف عامل اشعاع الأشعة المرسلة للسماء الحقيقية"
-#, fuzzy
-#~ msgid "Name of real-sky diffuse radiation coefficient raster map [-]"
-#~ msgstr "ملف عامل اشعاع الضوءالمنتشر للسماء الحقيقية"
-#, fuzzy
-#~ msgid "elevin raster map <%s> not found"
-#, fuzzy
-#~ msgid "aspin raster map <%s> not found"
-#, fuzzy
-#~ msgid "slopein raster map <%s> not found"
-#, fuzzy
-#~ msgid "linkein raster map <%s> not found"
-#, fuzzy
-#~ msgid "albedo raster map <%s> not found"
-#, fuzzy
-#~ msgid "latin raster map <%s> not found"
-#, fuzzy
-#~ msgid "coefbh raster map <%s> not found"
-#, fuzzy
-#~ msgid "coefdh raster map <%s> not found"
-#, fuzzy
-#~ msgid "Unable to create raster map %s"
-#, fuzzy
-#~ msgid "raster, interpolation"
-#~ msgid "Surface generation program from rasterized contours."
-#~ msgstr "برنامج انشاء السطح من الكنتورات الراسترية"
-#~ msgid "Name of existing raster map containing contours"
-#~ msgstr "اسم الخريطة ااراسترية الكنتورية"
-#~ msgid "Output elevation raster map"
-#, fuzzy
-#~ msgid "Import a binary raster file into a GRASS raster map."
-#~ msgstr "ادخال ملف راسترى ثنائى كطبقة خريطة راسترية جراسية"
-#, fuzzy
-#~ msgid "Illegal output file name <%s>"
-#, fuzzy
-#~ msgid "raster, export, png"
-#, fuzzy
-#~ msgid "Export GRASS raster as non-georeferenced PNG image."
-#~ msgstr "تحويل راستر جراسى الى بينرى"
-#, fuzzy
-#~ msgid "Unable to read raster map row %d"
-#, fuzzy
-#~ msgid "Cannot read ew_res value"
-#~ msgstr "لم يمكن وصف الجدول"
-#, fuzzy
-#~ msgid "Cannot read ns_res value"
-#, fuzzy
-#~ msgid "raster, map management"
-#, fuzzy
-#~ msgid "Error reading input"
-#, fuzzy
-#~ msgid "raster, projection, transformation"
-#, fuzzy
-#~ msgid "Re-projects a raster map from one location to the current location."
-#~ msgstr "إعادة توقيع خريطة راسترية من مكان إلى المكان الحالى"
-#, fuzzy
-#~ msgid "Name for output raster map (default: input)"
-#~ msgid "Resolution of output map"
-#~ msgstr "درجة وضوح الخريطة المخرجة"
-#, fuzzy
-#~ msgid "Cannot read raster row [%d] from raster map <%s>"
-#, fuzzy
-#~ msgid "Cannot read raster row [%d] from cover raster map <%s>"
-#, fuzzy
-#~ msgid "Cannot read raster row [%d]"
-#, fuzzy
-#~ msgid "Cannot read cover raster row [%d]"
-#, fuzzy
-#~ msgid "raster, random"
-#, fuzzy
-#~ msgid "raster, fire"
-#~ msgid "Run VERBOSELY"
-#~ msgstr "تنفيذ بإسهاب"
-#, fuzzy
-#~ msgid "Raster map <%s> already exists in mapset <%s>, select another name"
-#~ msgstr "الخريطة الراسترية المطلوب الضبط عليها"
-#~ msgid "Name of raster map to contain results (several new layers)"
-#, fuzzy
-#~ msgid "Percent Completed ... "
-#, fuzzy
-#~ msgid "Reading row %d"
-#, fuzzy
-#~ msgid "Unable to load 3D raster range"
-#, fuzzy
-#~ msgid "Unable to create distance map <%s>"
-#, fuzzy
-#~ msgid "Unable to create value map <%s>"
-#, fuzzy
-#~ msgid "Reading input data..."
-#, fuzzy
-#~ msgid "Writing output data..."
-#~ msgid "Converts a raster map layer into a height-field file for POVRAY."
-#~ msgstr "POVRAY تحويل ملف راسترى الى ملف حقل ارتفاعات يستخدم فى برنامج"
-#, fuzzy
-#~ msgid "Unable to open drainage pointer map"
-#, fuzzy
-#~ msgid "Unable to open new basin map"
-#, fuzzy
-#~ msgid "Unable to close new basin map layer"
-#, fuzzy
-#~ msgid "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel resolution of the currently defined region."
-#~ msgstr "PPM تحويل راستر جراسى الى صورة "
-#, fuzzy
-#~ msgid "raster, null data"
-#, fuzzy
-#~ msgid "Name of raster map for which to edit null file"
-#, fuzzy
-#~ msgid "Error writing null row %d"
-#, fuzzy
-#~ msgid "Cannot get row"
-#~ msgstr "لم يمكن حشر صف جديد: %s"
-#, fuzzy
-#~ msgid "Unable to read raster <map %d of %d> row %d"
-#, fuzzy
-#~ msgid "Unable to read header of raster map <%s@%s>"
-#, fuzzy
-#~ msgid "Unable to read region <%s> in <%s>"
-#~ msgstr "<%s> فى <%s> لم يمكن قراءة المنطقة"
-#, fuzzy
-#~ msgid "Unable to open vector map <%s> in <%s>"
-#, fuzzy
-#~ msgid "Invalid region: %s"
-#~ msgstr "%s:منطقة غير صالحة"
-#, fuzzy
-#~ msgid "Unable to update boundaries"
-#, fuzzy
-#~ msgid "%s: [%s] not found"
-#, fuzzy
-#~ msgid "raster, sun position"
-#, fuzzy
-#~ msgid "Verbose output (also print out sun position etc.)"
-#~ msgstr "إخراج بإسهاب,وأيضا طباعة مكان الشمس وغيره"
-#, fuzzy
-#~ msgid "Exports a GRASS raster map to a binary array."
-#, fuzzy
-#~ msgid "Writing raster map, row %d"
-#, fuzzy
-#~ msgid "Error opening channel %i"
-#~ msgstr "تسجيل الخرائط الراسترية "
-#, fuzzy
-#~ msgid "Cannot create %s/.r.li/ directory"
-#, fuzzy
-#~ msgid "Cannot create %s/.r.li/output/ directory"
-#, fuzzy
-#~ msgid "Cannot close %s file (PIPE)"
-#~ msgstr "dig_cats لم يتم فتح ملف"
-#, fuzzy
-#~ msgid "Cannot delete %s file (PIPE)"
-#, fuzzy
-#~ msgid "Cannot close %s file (PIPE2)"
-#, fuzzy
-#~ msgid "Cannot delete %s file (PIPE2)"
-#, fuzzy
-#~ msgid "Cannot close receive channel file"
-#, fuzzy
-#~ msgid "Cannot delete %s file"
-#, fuzzy
-#~ msgid "Cannot read raster header file"
-#, fuzzy
-#~ msgid "CHILD[pid = %i] cannot open raster map"
-#, fuzzy
-#~ msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the currently defined region."
-#, fuzzy
-#~ msgid "raster, random, cell"
-#, fuzzy
-#~ msgid "raster, metadata, timestamp"
-#~ msgid "Converts a raster map layer into an ASCII text file."
-#, fuzzy
-#~ msgid "raster, category"
-#, fuzzy
-#~ msgid "Cannot create category file for <%s>"
-#, fuzzy
-#~ msgid "Cannot read header of raster map <%s> in <%s>"
-#, fuzzy
-#~ msgid "Cannot open cell file of raster map <%s> in <%s>"
-#~ msgstr "%s لم يتم فتح قاعدة البيانات"
-#, fuzzy
-#~ msgid "raster, terrain"
-#, fuzzy
-#~ msgid "Unable to write to <%s>"
-#, fuzzy
-#~ msgid "raster, conversion, vectorization"
-#~ msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
-#~ msgstr "PPM تحويل ثلاث راسترات جراسيى ممثلة للأحمر و الأخضر والأزرق الى صورة"
-#~ msgid "Sums up the raster cell values."
-#~ msgstr "جمع قيم الخلايا الراسترية"
-#~ msgid "Name of incidence or density file."
-#~ msgstr "اسم ملف الكثافة أو مدى التاثير"
-#, fuzzy
-#~ msgid "raster, transect"
-#, fuzzy
-#~ msgid "Interpolating raster map <%s> (%d rows)... "
-#, fuzzy
-#~ msgid "Cannot read row"
-#~ msgid "Finds the median of values in a cover map within areas assigned the same category value in a user-specified base map."
-#~ msgstr "median ايجاد القيمة الوسطية فى خريطة غطاء فى مساحات لها نفس قيم الفئات فى خريطة اساس حددها المستخدم"
-#, fuzzy
-#~ msgid "Name of base raster map"
-#, fuzzy
-#~ msgid "Base raster map <%s> not found"
-#, fuzzy
-#~ msgid "Unable to read category labels of raster map <%s>"
-#, fuzzy
-#~ msgid "File containing weights"
-#~ msgstr "dig_att عطل فى فتح ملف المدخل"
-#, fuzzy
-#~ msgid "Output basic information about a raster map layer."
-#~ msgstr "اخراج المعلومات الأساسية لخرائط راسترية يحددها المستخدم"
-#, fuzzy
-#~ msgid "Cannot create category file of <%s>"
-#, fuzzy
-#~ msgid "raster, reclassification"
-#~ msgid "Raster map to be reclassified"
-#~ msgstr "الخريطة الراسترية المطلوب إعادة تصنيفها"
-#, fuzzy
-#~ msgid ""
-#~ "Enter the file name or path\n"
-#, fuzzy
-#~ msgid "The size of sliding window (odd and >= 3)"
-#~ msgstr "حجم النافذة, فردى وأكبر من أو يساوى 3"
-#, fuzzy
-#~ msgid "Nothing to compute. Use at least one of the flags."
-#~ msgstr "لم يمكن حساب شىء"
-#, fuzzy
-#~ msgid "Import GDAL supported raster file into a binary raster map layer."
-#, fuzzy
-#~ msgid "raster, sediment flow, erosion, deposition"
-#, fuzzy
-#~ msgid "raster, flow, hydrology"
-#, fuzzy
-#~ msgid "raster, thin"
-#, fuzzy
-#~ msgid "Thins non-zero cells that denote linear features in a raster map."
-#~ msgstr "ترقيق الخلايا غير الصفرية التى تميز مظاهر خطية فى خريطة راسترية "
-#, fuzzy
-#~ msgid "%s: Error reading from raster map <%s> in mapset <%s>"
-#, fuzzy
-#~ msgid "File type"
-#, fuzzy
-#~ msgid "Output file name not specified"
-#, fuzzy
-#~ msgid "Exporting to GDAL raster"
-#, fuzzy
-#~ msgid "Failed writing output raster map row %d"
-#, fuzzy
-#~ msgid "Name of input raster map with seed (at least 1 cell > 0)"
-#~ msgstr "<%s> اسم الملف المستخدم لل"
-#, fuzzy
-#~ msgid "Can't create raster map <%s>"
-#, fuzzy
-#~ msgid "raster, import, conversion"
-#, fuzzy
-#~ msgid "Converts ASCII raster file to binary raster map layer."
-#, fuzzy
-#~ msgid "raster, export, VRML"
-#, fuzzy
-#~ msgid "raster, DEM, fractal"
-#~ msgid "Finds the average of values in a cover map within areas assigned the same category value in a user-specified base map."
-#~ msgstr "ايجاد متوسط القيم فى خريطة غطاء فى مساحات لها نفس الفئات فى خريطة الأساس التى حددها المستخدم"
-#~ msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
-#~ msgstr "GRIDATB.FOR (TOPMODEL) تحويل خريطة راسترية جراسية الى خريطة من نوع"
-#~ msgid "Input map"
-#~ msgid "Overwrite output map file"
-#, fuzzy
-#~ msgid "Setting window header"
-#, fuzzy
-#~ msgid "Could not get raster row from input map"
-#, fuzzy
-#~ msgid "Could not get raster row from elev map"
-#, fuzzy
-#~ msgid "Error writing G3D double data"
-#, fuzzy
-#~ msgid "Rowio_setup failed"
-#, fuzzy
-#~ msgid "Rowio_get failed"
-#, fuzzy
-#~ msgid "Unable to open raster map <%s@%s>"
-#, fuzzy
-#~ msgid "Failed writing raster map row"
-#, fuzzy
-#~ msgid "Unable to get current region"
-#, fuzzy
-#~ msgid "Name for flowpath length raster map"
-#, fuzzy
-#~ msgid "Unable to get header for %s"
-#, fuzzy
-#~ msgid "Cannot reset current region"
-#~ msgstr "استخدام المنطقة الحالية"
-#, fuzzy
-#~ msgid "imagery, geometry"
-#, fuzzy
-#~ msgid "imagery, edges"
-#, fuzzy
-#~ msgid "Error while reading input raster map."
-#, fuzzy
-#~ msgid "imagery, classification, supervised, SMAP"
-#~ msgstr "اسم ملف ناتج التصنيف"
-#, fuzzy
-#~ msgid "imagery, landsat, acca"
-#, fuzzy
-#~ msgid "Cannot write to raster map <%s>"
-#, fuzzy
-#~ msgid "imagery, classification, MLC"
-#, fuzzy
-#~ msgid "Did not find input cell map MASK."
-#, fuzzy
-#~ msgid "Unable to open band files."
-#, fuzzy
-#~ msgid "imagery, classification"
-#, fuzzy
-#~ msgid "Unable to read cell header for first band file"
-#, fuzzy
-#~ msgid "imagery, classification, supervised, MLC"
-#, fuzzy
-#~ msgid "imagery, color transformation, RGB, HIS"
-#, fuzzy
-#~ msgid "Unable to read raster map row %ld"
-#, fuzzy
-#~ msgid "Failed writing raster map row %ld"
-#, fuzzy
-#~ msgid "Unable to allocate the input row buffer"
-#, fuzzy
-#~ msgid "imagery, rectify"
-#, fuzzy
-#~ msgid "Computes topographic correction of reflectance."
-#~ msgstr "طريقة الاستيفاء المستخدمة"
-#, fuzzy
-#~ msgid "Name of reflectance raster maps to be corrected topographically"
-#~ msgstr "اسم ملف التنعيم"
-#, fuzzy
-#~ msgid "Name (flag -i) or prefix for output raster maps"
-#, fuzzy
-#~ msgid "Name of input base raster map (elevation or illumination)"
-#, fuzzy
-#~ msgid "Output sun illumination terrain model"
-#~ msgstr "خريطة الصرف المخرجة"
-#, fuzzy
-#~ msgid "Elevation raster map of unknown type"
-#~ msgstr "احداثى الشرق, الأساس هو مركز الخريطة"
-#, fuzzy
-#~ msgid "Reflectance of raster map <%s> is not of DCELL type - ignored"
-#, fuzzy
-#~ msgid "Unable to open real-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
-#, fuzzy
-#~ msgid "Unable to open imaginary-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
-#, fuzzy
-#~ msgid "Power 2 values: %d rows %d columns"
-#, fuzzy
-#~ msgid "Writing data..."
-#, fuzzy
-#~ msgid "Range of values in output display files"
-#, fuzzy
-#~ msgid "Writing viewable versions of transformed data..."
-#, fuzzy
-#~ msgid "Unable to open file in the 'cell_misc' directory"
-#, fuzzy
-#~ msgid "Extract quality control parameters from Modis QC layers"
-#~ msgstr "خريطة الراستر الغطاء"
-#, fuzzy
-#~ msgid "Name of the surface reflectance QC layer [bit array]"
-#~ msgstr "اسم السطح الفراكتالى الراسترى"
-#, fuzzy
-#~ msgid "imagery, statistics"
-#, fuzzy
-#~ msgid "Illegal group name <%s>"
-#~ msgstr "!تم تحديد إحداثى شمال فارغ"
-#, fuzzy
-#~ msgid "Illegal subgroup name <%s>"
-#, fuzzy
-#~ msgid "Illegal signature file name <%s>"
-#, fuzzy
-#~ msgid "imagery, classification, signatures"
-#, fuzzy
-#~ msgid "imagery, image transformation, PCA"
-#, fuzzy
-#~ msgid "Calculating covariance matrix..."
-#, fuzzy
-#~ msgid "Computing means and standard deviations..."
-#, fuzzy
-#~ msgid "Computing means..."
-#, fuzzy
-#~ msgid "Rescaling <%s> to range %d,%d..."
-#, fuzzy
-#~ msgid "Calculating camera angle to local surface..."
-#, fuzzy
-#~ msgid "Could not open elevation raster"
-#, fuzzy
-#~ msgid "Error reading segment file"
-#, fuzzy
-#~ msgid "imagery, orthorectify"
-#, fuzzy
-#~ msgid "Could not read REF file for group <%s>"
-#, fuzzy
-#~ msgid "No camera reference file selected for group <%s>"
-#~ msgstr "اسم الملف الراسترى الجديد"
-#, fuzzy
-#~ msgid "Bad format in camera file for group <%s>"
-#, fuzzy
-#~ msgid "Bad format in initial exposure station file for group <%s>"
-#, fuzzy
-#~ msgid "No target elevation model selected for group <%s>"
-#, fuzzy
-#~ msgid ""
-#~ "Control Z Point file for group [%s] in [%s] \n"
-#~ " \n"
-#~ msgstr "لم يتم الثور على شيئ\n"
-#, fuzzy
-#~ msgid "Computing equations..."
-#, fuzzy
-#~ msgid "Poorly placed Control Points!\n"
-#~ msgstr "اسم الطبقة المستخدمة كدرجة لون"
-#, fuzzy
-#~ msgid "Can not generate the transformation equation.\n"
-#, fuzzy
-#~ msgid "No active Control Points!\n"
-#, fuzzy
-#~ msgid ""
-#~ "Reference Point file for group [%s] in [%s] \n"
-#~ " \n"
-#, fuzzy
-#~ msgid "Poorly placed Reference Points!\n"
-#, fuzzy
-#~ msgid "No active Reference Points!\n"
-#, fuzzy
-#~ msgid "Interactively select or modify the target elevation model."
-#, fuzzy
-#~ msgid "Name of imagery group for ortho-rectification"
-#~ msgstr "اسم الخرائط الراسترية المطلوب ترقيعها ببعضها "
-#, fuzzy
-#~ msgid "Target information for group [%s] missing\n"
-#, fuzzy
-#~ msgid "Target location [%s] not found\n"
-#, fuzzy
-#~ msgid "Mapset [%s] in target location [%s] - "
-#, fuzzy
-#~ msgid "not found\n"
-#, fuzzy
-#~ msgid "Pre-selected group <%s> not found"
-#, fuzzy
-#~ msgid "Enter imagery group for ortho-rectification"
-#, fuzzy
-#~ msgid "Group [%s] contains no files"
-#, fuzzy
-#~ msgid "Could not read REF file for group [%s]"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Rectify all images in the group? "
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Choose another extension? "
-#, fuzzy
-#~ msgid "Enter a name for the camera angle map:"
-#, fuzzy
-#~ msgid "Map name <%s> is illegal"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Overwrite maps in target location/mapset? "
-#, fuzzy
-#~ msgid "Interactively select or modify the imagery group target."
-#, fuzzy
-#~ msgid "Group [%s] targeted for location [%s], mapset [%s]"
-#, fuzzy
-#~ msgid "Group [%s] not found"
-#, fuzzy
-#~ msgid "No camera reference file selected for group [%s]"
-#, fuzzy
-#~ msgid "Bad format in camera file for group [%s]"
-#, fuzzy
-#~ msgid "No initial camera exposure station for group [%s]"
-#, fuzzy
-#~ msgid "Bad format in initial camera exposure station for group [%s]"
-#, fuzzy
-#~ msgid "No photo points for group [%s]"
-#, fuzzy
-#~ msgid "Poorly placed photo points for group [%s]"
-#, fuzzy
-#~ msgid "Computing equations ..."
-#, fuzzy
-#~ msgid "Unable to read raster header of <%s>"
-#, fuzzy
-#~ msgid "Image Group [%s] not found"
-#, fuzzy
-#~ msgid "Interactively select and modify the imagery group camera reference file."
-#, fuzzy
-#~ msgid "Name of camera reference file to use"
-#, fuzzy
-#~ msgid "Enter a camera reference file to be used with this imagery group"
-#, fuzzy
-#~ msgid "Group [%s] in location [%s] mapset [%s] now has camera file [%s]"
-#, fuzzy
-#~ msgid "display, paint labels"
-#, fuzzy
-#~ msgid "display, histogram, statistics"
-#, fuzzy
-#~ msgid "display, vector"
-#, fuzzy
-#~ msgid "Type of color table (for use with -z flag)"
-#, fuzzy
-#~ msgid "Unable to display areas, topology not available"
-#, fuzzy
-#~ msgid "Unable to display lines by id, topology not available"
-#, fuzzy
-#~ msgid "Unable to display topology, not available"
-#, fuzzy
-#~ msgid "Line width column (%s) is not numeric."
-#, fuzzy
-#~ msgid "Symbol size column not specified."
-#, fuzzy
-#~ msgid "Symbol size column (%s) is not numeric."
-#, fuzzy
-#~ msgid "Symbol rotation column not specified."
-#, fuzzy
-#~ msgid "Symbol rotation column (%s) is not numeric."
-#, fuzzy
-#~ msgid "Unable to read symbol, unable to display points"
-#, fuzzy
-#~ msgid "Error in color definition column '%s': %d features affected"
-#, fuzzy
-#~ msgid "Monitor: interactive command in redraw"
-#~ msgstr "الشاشة: أمر تفاعلى يتم إعادة رسمه\n"
-#, fuzzy
-#~ msgid "Monitor: waitpid: expected %d but got %d"
-#~ msgstr "الشاشة: ويتبد: متوقع %d ولكن تم الحصول على %d\n"
-#, fuzzy
-#~ msgid "Monitor: XGetWMName failed"
-#~ msgstr "الشاشة: XGetWMName فشل\n"
-#, fuzzy
-#~ msgid "Monitor: XGetWMName: bad result"
-#~ msgstr "الشاشة: XGetWMName: نتيجة سيئة\n"
-#, fuzzy
-#~ msgid "found %d visuals of type TrueColor"
-#~ msgstr "وجد %d مرئيات من نوع لون حقيقى\n"
-#, fuzzy
-#~ msgid "searching for highest bit depth"
-#~ msgstr "البحث عن اعلى عمق بت\n"
-#, fuzzy
-#~ msgid "selected %d bit depth"
-#~ msgstr "قد تم اختياره %d عمق البت\n"
-#, fuzzy
-#~ msgid "using default visual which is %s"
-#~ msgstr "استخدم كمرئى اساس %s\n"
-#, fuzzy
-#~ msgid "display, distance"
-#, fuzzy
-#~ msgid "Displays the rhumbline joining two user-specified points, in the active frame on the user's graphics monitor."
-#~ msgstr "اختيار الخط الذى سيعرض به النص على الشاشة"
-#~ msgid " Middle: toggle flash color\n"
-#~ msgstr " وسط: سماح بألوان سريعة\n"
-#, fuzzy
-#~ msgid "display, metadata"
-#, fuzzy
-#~ msgid "Name of frame(s) to save"
-#, fuzzy
-#~ msgid "Save current frame"
-#~ msgstr "ضبط من المنطقة الحالية"
-#, fuzzy
-#~ msgid "Unknown item type in pad: %s"
-#, fuzzy
-#~ msgid "Can't clear current graphics window"
-#, fuzzy
-#~ msgid "Cannot use current window"
-#, fuzzy
-#~ msgid "Interactively edit cell values in a raster map."
-#, fuzzy
-#~ msgid "display, raster, profile"
-#, fuzzy
-#~ msgid "Output profile data to file(s) with prefix 'name'"
-#~ msgstr "اسم ملف انحناء التضاريس"
-#, fuzzy
-#~ msgid "%s: Couldn't open raster <%s@%s>"
-#, fuzzy
-#~ msgid "Error reading raster map"
-#, fuzzy
-#~ msgid "display, map management"
-#, fuzzy
-#~ msgid "Short user prompt message"
-#, fuzzy
-#~ msgid "Getting graphics window coordinates"
-#, fuzzy
-#~ msgid "Display information about the active display monitor"
-#~ msgstr "تقرير عن الراستر المدخلة والخروج"
-#, fuzzy
-#~ msgid "Display number of colors"
-#, fuzzy
-#~ msgid "No current frame"
-#, fuzzy
-#~ msgid "display, zoom"
-#, fuzzy
-#~ msgid "ERROR: can not get \"list\" items"
-#~ msgstr "\"list\" items خطا: لم يمكن الحصول على \n"
-#, fuzzy
-#~ msgid "-j flag forced"
-#~ msgstr "-j إجبار على استخدام\n"
-#, fuzzy
-#~ msgid "No map is displayed in GRASS monitor"
-#~ msgstr "خطا: لم يتم عرض الخريطة\n"
-#~ msgid "Path to TrueType font (including file name)"
-#~ msgstr "استخدام خط ذو نوع حقيقى بما في ذلك اسم الملف "
-#, fuzzy
-#~ msgid "Invalid font: %s"
-#, fuzzy
-#~ msgid "Unable to create face"
-#, fuzzy
-#~ msgid "Unable to set size"
-#, fuzzy
-#~ msgid "Unable to write the temporary file"
-#, fuzzy
-#~ msgid "No predefined font"
-#~ msgstr "اسم ملف درجات الألوان المحددة مسبقا"
-#, fuzzy
-#~ msgid "Manages display frames on the user's graphics monitor."
-#, fuzzy
-#~ msgid "Create a new frame"
-#, fuzzy
-#~ msgid "Select a frame"
-#~ msgstr "اختر البيانات من قاعدة البيانات"
-#, fuzzy
-#~ msgid "Print name of current frame"
-#, fuzzy
-#~ msgid "Print names of all frames"
-#~ msgstr "طباعة مجموع المساحة"
-#, fuzzy
-#~ msgid "List map names displayed in GRASS monitor"
-#, fuzzy
-#~ msgid "Debugging output"
-#, fuzzy
-#~ msgid "name"
-#~ msgstr "اسم الجدول"
-#, fuzzy
-#~ msgid "Frame to be created/selected"
-#, fuzzy
-#~ msgid "Error choosing frame [%s]\n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Buttons:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "أزرار:\n"
-#, fuzzy
-#~ msgid "Left:   Select frame\n"
-#, fuzzy
-#~ msgid "Right:  Accept frame\n"
-#~ msgstr " يمين: خروج\n"
-#, fuzzy
-#~ msgid " Left:    Place text here\n"
-#, fuzzy
-#~ msgid " Right:   Quit\n"
-#, fuzzy
-#~ msgid "display, color transformation"
-#, fuzzy
-#~ msgid "Error reading hue data"
-#, fuzzy
-#~ msgid "Error reading intensity data"
-#, fuzzy
-#~ msgid "Error reading saturation data"
-#, fuzzy
-#~ msgid "Error - Locking mechanism failed"
-#, fuzzy
-#~ msgid "Name of graphics monitor to select"
-#~ msgstr "لم يتم اختيار شاشة العرض"
-#, fuzzy
-#~ msgid "List all monitors"
-#~ msgstr "عرض قائمة مستويات الكنتور"
-#, fuzzy
-#~ msgid "R_color file for [%s] not available"
-#, fuzzy
-#~ msgid "Range file for [%s] not available"
-#, fuzzy
-#~ msgid "Invalid rendering method <%s>"
-#, fuzzy
-#~ msgid "Font name or pathname of TTF file"
-#, fuzzy
-#~ msgid "Setting release of FreeType"
-#~ msgstr ""
-#~ "\n"
-#~ "ضبط تحرير نوع حر\n"
-#, fuzzy
-#~ msgid "display, raster, RGB"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Mouse Buttons:"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "أزرار:\n"
-#, fuzzy
-#~ msgid "Left:   Select From\n"
-#, fuzzy
-#~ msgid ""
-#~ "Right:  Quit\n"
-#~ "\n"
-#, fuzzy
-#~ msgid "display, menu"
-#, fuzzy
-#~ msgid "display, geometry"
-#, fuzzy
-#~ msgid "Interactively select route"
-#, fuzzy
-#~ msgid "You must select at least four points"
-#, fuzzy
-#~ msgid "No raster or vector map displayed"
-#, fuzzy
-#~ msgid "general, gui"
-#, fuzzy
-#~ msgid "Name of workspace file"
-#, fuzzy
-#~ msgid "general, transformation, GCP"
-#, fuzzy
-#~ msgid "Name of a mapset"
-#~ msgstr "اسم الخريطة الناتجة"
-#, fuzzy
-#~ msgid "general, projection"
-#, fuzzy
-#~ msgid "Can also be used to create GRASS locations."
-#, fuzzy
-#~ msgid "Georeferenced data file to read projection information from"
-#~ msgstr "الموقع المستخدم لقراءة الإسقاط منه لنقاط السيطرة الأرضية "
-#, fuzzy
-#~ msgid "Unable to open file [%s] for reading"
-#, fuzzy
-#~ msgid "Unable to create location: %s"
-#, fuzzy
-#~ msgid "Removing %s <%s>"
-#, fuzzy
-#~ msgid "couldn't be removed"
-#, fuzzy
-#~ msgid "%s: couldn't be removed"
-#, fuzzy
-#~ msgid "%s: removed"
-#~ msgstr "%-5d أشباه المراكز قرات\n"
-#, fuzzy
-#~ msgid "<%s> nothing removed"
-#, fuzzy
-#~ msgid "Remove base maps"
-#, fuzzy
-#~ msgid "%s file(s) to be removed"
-#, fuzzy
-#~ msgid "Unable to compile regular expression %s"
-#, fuzzy
-#~ msgid "general, settings"
-#, fuzzy
-#~ msgid "Changes current mapset."
-#, fuzzy
-#~ msgid "List available mapsets"
-#~ msgstr "عرض الهيئات المدعمة والخروج"
-#, fuzzy
-#~ msgid "Erasing monitors..."
-#~ msgstr "الخريطة الفيكتورية لنقاط البدء"
-#, fuzzy
-#~ msgid "general, version"
-#, fuzzy
-#~ msgid "Other"
-#~ msgstr "تهيج"
-#, fuzzy
-#~ msgid "%s file(s) to be renamed"
-#, fuzzy
-#~ msgid "%s file(s) to be copied"
-#, fuzzy
-#~ msgid "Raster map <%s@%s>: %s"
-#, fuzzy
-#~ msgid "<%s> is an illegal region name"
-#, fuzzy
-#~ msgid "format"
-#, fuzzy
-#~ msgid "Unable to open raster map <%s> in <%s>"
-#, fuzzy
-#~ msgid "Could not read from <%s>"
-#, fuzzy
-#~ msgid "Names of mask files"
-#, fuzzy
-#~ msgid "Name of output mask file"
-#~ msgstr "اسم الملف المخرج"
-#, fuzzy
-#~ msgid "general, scripts"
-#, fuzzy
-#~ msgid "Your mapset search list:\n"
-#, fuzzy
-#~ msgid "<%s> not found in mapset list"
-#, fuzzy
-#~ msgid "general, settings, search path"
-#, fuzzy
-#~ msgid "Randomly generate a 2D/3D vector points map."
-#, fuzzy
-#~ msgid "Using 'double precision' for column <%s>"
-#, fuzzy
-#~ msgid "vector, network, isolines"
-#, fuzzy
-#~ msgid "vector, network, centrality measures"
-#, fuzzy
-#~ msgid "Nothing to do"
-#, fuzzy
-#~ msgid "Not enough types"
-#, fuzzy
-#~ msgid "Odd number of types"
-#~ msgstr "مساحة: %d  عدد الجزر: %d\n"
-#, fuzzy
-#~ msgid "vector, geometry, triangulation"
-#, fuzzy
-#~ msgid "Creates a Voronoi diagram from an input vector map containing points or centroids."
-#~ msgstr "خلق طبقة خريطة راسترية وخريطة نقط فيكتورية تحتوى على اماكن عشوائية التوزيع"
-#, fuzzy
-#~ msgid "Voronoi triangulation..."
-#~ msgstr "عدد النقاط المطلوب تخصيصها"
-#, fuzzy
-#~ msgid "Cannot calculate area centroid z coordinate"
-#, fuzzy
-#~ msgid "vector, network, steiner tree"
-#, fuzzy
-#~ msgid "Copying vector objects from vector map <%s>..."
-#, fuzzy
-#~ msgid "Unknown column type '%s'"
-#, fuzzy
-#~ msgid "Unknown column type '%s' values lost"
-#, fuzzy
-#~ msgid "Network input map <%s> not found"
-#, fuzzy
-#~ msgid "Unable to read MASK"
-#, fuzzy
-#~ msgid "Convert OGR vector layers to GRASS vector map."
-#, fuzzy
-#~ msgid "List available layers in data source and exit"
-#~ msgstr "عرض ملفات الراستر للموقع والخروج"
-#, fuzzy
-#~ msgid "Counting polygons for %d features..."
-#, fuzzy
-#~ msgid "Merge boundaries:"
-#, fuzzy
-#~ msgid "Find centroids for layer: %s"
-#, fuzzy
-#~ msgid "Cannot read part of geometry"
-#, fuzzy
-#~ msgid "Cannot write part of geometry"
-#, fuzzy
-#~ msgid "%d new points written to output"
-#~ msgstr "%d نقطة كتبت للمخرج\n"
-#, fuzzy
-#~ msgid "vector, networking, maintenance"
-#, fuzzy
-#~ msgid "Name of input point vector map"
-#, fuzzy
-#~ msgid "Output vector map must be specified"
-#, fuzzy
-#~ msgid "Point vector map must be specified"
-#, fuzzy
-#~ msgid "Threshold value must be specified"
-#, fuzzy
-#~ msgid "%d arcs added to network (nlayer %d)"
-#~ msgstr "%d فئات محملة من الجدول\n"
-#, fuzzy
-#~ msgid "vector, projection, transformation"
-#, fuzzy
-#~ msgid "vector, buffer"
-#, fuzzy
-#~ msgid "Buffer distance in map units"
-#~ msgstr "المسافة العظمى بين النقاط بوحدات الخريطة"
-#, fuzzy
-#~ msgid "Unable select categories from table <%s>"
-#, fuzzy
-#~ msgid "vector, network, shortest path"
-#, fuzzy
-#~ msgid "got type %d"
-#, fuzzy
-#~ msgid "Unable to select record from table <%s> (key %s, column %s)"
-#, fuzzy
-#~ msgid "Column <%s>: unsupported data type"
-#~ msgstr "نوع العمود غير مدعم"
-#, fuzzy
-#~ msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
-#, fuzzy
-#~ msgid "Parameter '%s' ignored in standard mode"
-#, fuzzy
-#~ msgid "Offset in map units."
-#, fuzzy
-#~ msgid "vector, metadata"
-#, fuzzy
-#~ msgid "Vector map <%s> not found in the current mapset"
-#, fuzzy
-#~ msgid "Creates topology for GRASS vector map."
-#, fuzzy
-#~ msgid "If not given (or \"-\") reads from standard input"
-#, fuzzy
-#~ msgid "vector, editing, geometry"
-#, fuzzy
-#~ msgid "Error reading ASCII file: '%s'"
-#, fuzzy
-#~ msgid "Error reading categories: '%s'"
-#, fuzzy
-#~ msgid "Unexpected data in vector head: '%s'"
-#, fuzzy
-#~ msgid "db connection was not set by form"
-#~ msgstr "لم يعرف الأتصال بقاعدة البيانات\n"
-#, fuzzy
-#~ msgid "Cannot open driver"
-#, fuzzy
-#~ msgid "Cannot open database"
-#~ msgid "Cannot describe table"
-#, fuzzy
-#~ msgid "Cannot find column type"
-#, fuzzy
-#~ msgid "Cannot update table"
-#, fuzzy
-#~ msgid "Form"
-#, fuzzy
-#~ msgid "New record was created.<BR>"
-#~ msgstr "%d حدثت من التسجيلات\n"
-#, fuzzy
-#~ msgid "Record for this category already existed.<BR>"
-#, fuzzy
-#~ msgid "New point"
-#, fuzzy
-#~ msgid "Quit tool"
-#~ msgstr "بهدوء"
-#, fuzzy
-#~ msgid "Undo last point"
-#~ msgstr "%-5d فئات الخط قرات\n"
-#, fuzzy
-#~ msgid "Close line"
-#, fuzzy
-#~ msgid "New Point"
-#, fuzzy
-#~ msgid "Delete line and exit"
-#~ msgstr "طباعة الجداول والخروج"
-#, fuzzy
-#~ msgid "Select"
-#, fuzzy
-#~ msgid "New location"
-#~ msgstr "موقع قاعدة البيانات"
-#, fuzzy
-#~ msgid "Remove vertex:"
-#, fuzzy
-#~ msgid "Select vertex"
-#, fuzzy
-#~ msgid "Move vertex:"
-#, fuzzy
-#~ msgid "Cannot open driver %s"
-#~ msgid "Cannot open database %s"
-#, fuzzy
-#~ msgid "Cannot open driver "
-#~ msgid "Cannot open database %s by driver %s"
-#~ msgstr "%s بالمشغل %s لم يمكن فتح قاعدة البيانات"
-#, fuzzy
-#~ msgid "Cannot create table: "
-#, fuzzy
-#~ msgid "Cannot create index:\n"
-#, fuzzy
-#~ msgid "Cannot grant privileges on table:\n"
-#~ msgstr "%s لم يتم منح الإمتياز على الجدول"
-#, fuzzy
-#~ msgid "Cannot create new record."
-#, fuzzy
-#~ msgid "Database table for this layer is not defined"
-#~ msgstr "لم يتم الإتصال بقاعدة البيانات\n"
-#, fuzzy
-#~ msgid "Cannot select record from table %s"
-#, fuzzy
-#~ msgid "Display categories:"
-#, fuzzy
-#~ msgid "Select line"
-#, fuzzy
-#~ msgid "Copy attributes:"
-#, fuzzy
-#~ msgid "Select source object"
-#, fuzzy
-#~ msgid "Select the target object"
-#~ msgstr " اللون الأساس\n"
-#, fuzzy
-#~ msgid "Deselect Target"
-#, fuzzy
-#~ msgid "Display attributes:"
-#, fuzzy
-#~ msgid "Database connection not defined<BR>"
-#, fuzzy
-#~ msgid "driver: %s<BR>database: %s<BR>table: %s<BR>key column: %s<BR>"
-#~ msgstr ""
-#~ "المشغل: %s\n"
-#~ "قاعدة البيانات: %s\n"
-#~ "جدول: %s\n"
-#~ "عمود مفتاحى: %s\n"
-#, fuzzy
-#~ msgid "Line %d"
-#~ msgstr "%f : ارتفاع الخط\n"
-#, fuzzy
-#~ msgid "No categories"
-#, fuzzy
-#~ msgid "Cannot delete record: %s"
-#, fuzzy
-#~ msgid "Cannot open driver '%s'<BR>"
-#, fuzzy
-#~ msgid "Cannot open database '%s' by driver '%s'<BR>"
-#, fuzzy
-#~ msgid "Cannot open select cursor"
-#, fuzzy
-#~ msgid "Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>"
-#, fuzzy
-#~ msgid "Cannot fetch next record"
-#, fuzzy
-#~ msgid "No database record"
-#~ msgstr "اسم قاعدة البيانات"
-#, fuzzy
-#~ msgid "vector, editing, digitization"
-#, fuzzy
-#~ msgid "Create new file if it does not exist."
-#, fuzzy
-#~ msgid "Select tool"
-#, fuzzy
-#~ msgid "Cannot set variable code = %d"
-#, fuzzy
-#~ msgid "Cannot get type of variable %s"
-#, fuzzy
-#~ msgid "Cannot get code of variable %s"
-#, fuzzy
-#~ msgid "Cannot get name of variable %d"
-#, fuzzy
-#~ msgid "Cannot get value of variable code = %d"
-#, fuzzy
-#~ msgid "Quit"
-#~ msgstr "خروج"
-#, fuzzy
-#~ msgid "Pan"
-#~ msgstr "%s تحريك حر\n"
-#, fuzzy
-#~ msgid "New center"
-#, fuzzy
-#~ msgid "Cannot find window '%s'"
-#, fuzzy
-#~ msgid "vector, network, allocation"
-#, fuzzy
-#~ msgid "Calculating costs from centres ..."
-#, fuzzy
-#~ msgid "Cannot alter table: %s"
-#, fuzzy
-#~ msgid "vector, extract"
-#, fuzzy
-#~ msgid "Layer 0 not supported"
-#, fuzzy
-#~ msgid "Process file <%s> for category numbers"
-#~ msgstr "خلق اماكن للفئة صفر ايضا"
-#, fuzzy
-#~ msgid "%d categories loaded from table <%s>"
-#, fuzzy
-#~ msgid "vector, database, attribute table"
-#, fuzzy
-#~ msgid "Key column name"
-#, fuzzy
-#~ msgid "Print all map connection parameters and exit in shell script style"
-#, fuzzy
-#~ msgid "Vector map <%s> is connected by:"
-#, fuzzy
-#~ msgid "Calculate area centroids..."
-#, fuzzy
-#~ msgid "Creates a vector map from ASCII points file or ASCII vector file."
-#, fuzzy
-#~ msgid "ASCII file to be imported, if not given reads from standard input"
-#, fuzzy
-#~ msgid ""
-#~ "Unexpected data in vector head:\n"
-#~ "[%s]"
-#, fuzzy
-#~ msgid "Error reading ASCII file: (bad type) [%s]"
-#, fuzzy
-#~ msgid "Error reading ASCII file: (unknown type) [%s]"
-#, fuzzy
-#~ msgid "Error reading ASCII file: (bad point) [%s]"
-#, fuzzy
-#~ msgid "Unparsable longitude value: [%s]"
-#, fuzzy
-#~ msgid "Unparsable latitude value: [%s]"
-#, fuzzy
-#~ msgid "Error reading categories: [%s]"
-#, fuzzy
-#~ msgid "vector, raster, resample"
-#, fuzzy
-#~ msgid "Raster map to be sampled"
-#, fuzzy
-#~ msgid "Bilinear interpolation (default is nearest neighbor)"
-#, fuzzy
-#~ msgid "Cubic convolution interpolation (default is nearest neighbor)"
-#, fuzzy
-#~ msgid "Checking vector points..."
-#, fuzzy
-#~ msgid "Layer number (from)"
-#, fuzzy
-#~ msgid "Layer number (to)"
-#, fuzzy
-#~ msgid "Finding nearest lines..."
-#, fuzzy
-#~ msgid "Layer number (write to)"
-#, fuzzy
-#~ msgid "Query layer number (read from)"
-#, fuzzy
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)"
-#~ msgstr "أميال mi, أمتار me, كيلومترات k, افدنة a, هيكتارات h, عدات الخلية c,  p نسبة التغطية"
-#, fuzzy
-#~ msgid "Creates a GRASS vector map of a user-defined grid."
-#, fuzzy
-#~ msgid "vector, network, articulation points"
-#, fuzzy
-#~ msgid "vector, geometry, topology"
-#, fuzzy
-#~ msgid "Vector of points defining sample points"
-#~ msgstr "اسم خريطة الإرتفاعات"
-#, fuzzy
-#~ msgid "Counting sites in quadrats..."
-#, fuzzy
-#~ msgid "vector, category"
-#, fuzzy
-#~ msgid "vector, network, flow"
-#, fuzzy
-#~ msgid "vector, geometry, buffer"
-#, fuzzy
-#~ msgid "DEPRECATED Buffer distance in map units"
-#, fuzzy
-#~ msgid "Line buffers... "
-#, fuzzy
-#~ msgid "Zero area size, please clean input vector first."
-#~ msgstr "إنشاء نقاط على الخط المدخل"
-#, fuzzy
-#~ msgid "Could not get outside buffer for line id %d"
-#, fuzzy
-#~ msgid "Area buffers... "
-#, fuzzy
-#~ msgid "Selecting areas..."
-#, fuzzy
-#~ msgid "vector, interpolation"
-#, fuzzy
-#~ msgid "Use z-coordinates (3D vector only)"
-#~ msgstr "طباعة احداثيات الشبكة - الشرق والشمال"
-#, fuzzy
-#~ msgid "Output surface raster map (elevation)"
-#, fuzzy
-#~ msgid "Output slope raster map"
-#~ msgstr "اسم ملف الإنحدار المخرج"
-#, fuzzy
-#~ msgid "Output aspect raster map"
-#, fuzzy
-#~ msgid "Output profile curvature raster map"
-#, fuzzy
-#~ msgid "Output tangential curvature raster map"
-#~ msgstr "اسم ملف الإنحناء المماسى"
-#, fuzzy
-#~ msgid "Output mean curvature raster map"
-#~ msgid " Number of points that have been entered: %d\n"
-#~ msgid "Please answer yes or no"
-#~ msgstr "من فضلك أجب بنعم أم لا"
-#, fuzzy
-#~ msgid "vector, transformation"
-#, fuzzy
-#~ msgid "Suppress display of residuals or other information"
-#~ msgstr "header تخطى طباعة معلومات عن العنوان الرئيسى بأول الملف"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "New vector map <%s> boundary coordinates:"
-#~ msgstr "إحداثيات الحدود <%s> خريط فيكتورية جديدة:\n"
-#~ msgid "ask_transform_coor():  Leaving session.. \n"
-#~ msgstr " أحداثيات ( ): الخروج\n"
-#, fuzzy
-#~ msgid "<%s> has not been created in database."
-#~ msgstr "عرض كل الجداول لقعدة بيانات معطاه"
-#, fuzzy
-#~ msgid "Unable to access table <%s>"
-#, fuzzy
-#~ msgid "Layer but not column with z values given"
-#~ msgstr "اسم الخريطة الراسترية المحتوية على معلومات التكلفة لخلية الشبكة"
-#, fuzzy
-#~ msgid "vector, reclass, attributes"
-#, fuzzy
-#~ msgid "Either 'rules' or 'col' must be specified"
-#, fuzzy
-#~ msgid "Name of column name with route ids"
-#, fuzzy
-#~ msgid "Name of column name with stop timestamps"
-#, fuzzy
-#~ msgid "Name of column name with stop ids"
-#, fuzzy
-#~ msgid "Name of column name with walk lengths"
-#, fuzzy
-#~ msgid "Exports a GRASS vector map to SVG."
-#, fuzzy
-#~ msgid "Unable to open SVG file <%s>"
-#, fuzzy
-#~ msgid "vector, external, import"
-#, fuzzy
-#~ msgid "Creates a new vector as a read-only link to OGR layer."
-#, fuzzy
-#~ msgid "Output vector. If not given, available layers are printed only."
-#, fuzzy
-#~ msgid "Output vector name was not specified"
-#, fuzzy
-#~ msgid "Cannot open data source"
-#, fuzzy
-#~ msgid "Doing log transformation"
-#, fuzzy
-#~ msgid "OGR format"
-#, fuzzy
-#~ msgid "Could not determine input map's feature type(s)."
-#, fuzzy
-#~ msgid "Key column '%s' not found"
-#, fuzzy
-#~ msgid "Exporting %i geometries..."
-#, fuzzy
-#~ msgid "Create a new vector map layer by combining other vector map layers."
-#, fuzzy
-#~ msgid "Patching vector map <%s@%s>..."
-#, fuzzy
-#~ msgid "vector, network, spanning tree"
-#, fuzzy
-#~ msgid "%d features written"
-#, fuzzy
-#~ msgid "vector, spatial query"
-#, fuzzy
-#~ msgid "Unknown operator"
-#, fuzzy
-#~ msgid "vector, import, conversion"
-#, fuzzy
-#~ msgid "vector, import, sites"
-#, fuzzy
-#~ msgid "Copying vector lines..."
-#, fuzzy
-#~ msgid "%d lines / boundaries removed"
-#, fuzzy
-#~ msgid "vector, geometry, statistics"
-#~ msgstr "احصائيات ااشئ او الفئة الموجهة"
-#, fuzzy
-#~ msgid "vector, metadata, history"
-#, fuzzy
-#~ msgid "Outputs basic information about a user-specified vector map."
-#, fuzzy
-#~ msgid "Print topology information only"
-#, fuzzy
-#~ msgid "Location:        %s"
-#~ msgstr "%s لم يمكن فتح "
-#, fuzzy
-#~ msgid "Name of creator: %s"
-#, fuzzy
-#~ msgid "  Number of dblinks:      %-9ld"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "%d :عدد النقاط\n"
-#, fuzzy
-#~ msgid "vector, network, components"
-#, fuzzy
-#~ msgid "vector, transformation, 3D"
-#, fuzzy
-#~ msgid "Name of input DXF file"
-#, fuzzy
-#~ msgid "Option <%s>: <%s> exists."
-#, fuzzy
-#~ msgid "Use '%s' option to change vector map name"
-#, fuzzy
-#~ msgid "vector, raster, attribute table"
-#, fuzzy
-#~ msgid "vector, network, salesman"
-#, fuzzy
-#~ msgid "Create points along input lines in new vector with 2 layers."
-#, fuzzy
-#~ msgid "Output vector map where points will be written"
-#, fuzzy
-#~ msgid "%d points written to output vector map"
-#, fuzzy
-#~ msgid "vector, geometry, 3D"
-#, fuzzy
-#~ msgid "Name of input 2D vector map"
-#, fuzzy
-#~ msgid "Name of resulting 3D vector map"
-#~ msgstr "اسماء الخرائط الناتجة"
-#, fuzzy
-#~ msgid "Extruding vector primitives..."
-#, fuzzy
-#~ msgid "Name of input vector map containing lines"
-#~ msgstr "الخريطة المدخلة حاوية الخطوط"
-#, fuzzy
-#~ msgid "Name for output vector map where segments will be written"
-#, fuzzy
-#~ msgid "Type: %s"
-#, fuzzy
-#~ msgid "vector, querying"
-#, fuzzy
-#~ msgid "Queries a vector map layer at given locations."
-#, fuzzy
-#~ msgid "If not given reads from standard input"
-#, fuzzy
-#~ msgid "Vector based generalization."
-#, fuzzy
-#~ msgid "Cannot open %s"
-#, fuzzy
-#~ msgid "vector, volume, conversion"
-#, fuzzy
-#~ msgid "Converts a binary GRASS vector map (only points) layer into a 3D GRASS raster map layer."
-#, fuzzy
-#~ msgid "Cannot allocate %u bytes of memory"
-#, fuzzy
-#~ msgid "%s: No font definition file"
-#, fuzzy
-#~ msgid "vector, import, database, points"
-#, fuzzy
-#~ msgid "Attribute table column with values to interpolate"
-#, fuzzy
-#~ msgid "No data points found"
-#, fuzzy
-#~ msgid "Exports GRASS vector map layers to DXF file format."
-#, fuzzy
-#~ msgid "DXF output file"
-#, fuzzy
-#~ msgid "vector, geometry, sampling"
-#, fuzzy
-#~ msgid "vector, network, connectivity"
-#, fuzzy
-#~ msgid "Cannot allocate memory for row buffer"
-#, fuzzy
-#~ msgid "Unable to write categories for raster map <%s>"
-#, fuzzy
-#~ msgid "vector, raster, conversion"
-#, fuzzy
-#~ msgid "Cannot export attribute table fields for layer < 1. Skipping export"
-#~ msgstr "%d نقاط تم تحميلها\n"
-#, fuzzy
-#~ msgid "No attribute table found"
-#, fuzzy
-#~ msgid "No numerical attributes found. Skipping export"
-#, fuzzy
-#~ msgid "Error reading value of attribute '%s'"
-#, fuzzy
-#~ msgid "Converts a GRASS binary vector map to VTK ASCII output."
-#, fuzzy
-#~ msgid "vector, path, visibility"
-#~ msgid "OGR driver: column '%s', OGR type %d  is not supported"
-#~ msgstr " غير مدعم %d OGR نوع ,'%s' عمود:OGR مشغل ال "
-#, fuzzy
-#~ msgid "Cannot parse MySQL embedded database name"
-#, fuzzy
-#~ msgid "Cannot connect to MySQL embedded server: "
-#, fuzzy
-#~ msgid "Cannot scan timestamp: "
-#~ msgstr "%s:لم يتم إنشاء الجدول"
-#, fuzzy
-#~ msgid "Cannot scan datetime: "
-#, fuzzy
-#~ msgid "Cannot get list of tables:\n"
-#, fuzzy
-#~ msgid "Unknown option in database definition for "
-#~ msgstr "'%s' :mysql خيار غير معروف فى تعريف قاعدة البيانات ل"
-#~ msgid "Cannot recognize boolean value"
-#~ msgstr "لم يتم تمييز القيمة الجبريى"
-#, fuzzy
-#~ msgid "pg driver: PostGIS column '%s', type 'geometry'  will not be converted"
-#, fuzzy
-#~ msgid "database, SQL"
-#, fuzzy
-#~ msgid "Removes a table from database."
-#, fuzzy
-#~ msgid "database, attribute table"
-#, fuzzy
-#~ msgid "database, attribute table, connection settings"
-#, fuzzy
-#~ msgid "Database schema"
-#, fuzzy
-#~ msgid "database, attribute table, SQL"
-#, fuzzy
-#~ msgid "database, connection settings"
-#, fuzzy
-#~ msgid "The password was stored in file"
-#~ msgstr "حفظت كلمة المرور فى ملف"
-#, fuzzy
-#~ msgid "Resizes active display monitor"
-#, fuzzy
-#~ msgid "vector, import, gazetteer"
-#, fuzzy
-#~ msgid "Display the HTML man pages of GRASS"
-#, fuzzy
-#~ msgid "general, manual, help"
-#~ msgstr "طباعة نوع الملف الراسترى فقط"
-#, fuzzy
-#~ msgid "Calculates univariate statistics from a raster map based on vector polygons and uploads statistics to new attribute columns."
-#~ msgstr "حساب إحصائيات المتغير الأحادى من خلايا ذات قيمة بالخريطة الراسترية"
-#, fuzzy
-#~ msgid "vector, raster, statistics"
-#, fuzzy
-#~ msgid "Name of vector polygon map"
-#~ msgstr "اسم الخريطة الراسترية"
-#, fuzzy
-#~ msgid "Name of raster map to calculate statistics from"
-#, fuzzy
-#~ msgid "display, export, GPS"
-#, fuzzy
-#~ msgid "Name of the column"
-#~ msgstr "عدد الأعمدة"
-#, fuzzy
-#~ msgid "raster, elevation"
-#, fuzzy
-#~ msgid "Input elevation map"
-#~ msgstr "اسم ملف الإرتفاعات الراستري"
-#, fuzzy
-#~ msgid "Output shaded relief map name"
-#~ msgstr "سم مشغّل الإخراج"
-#, fuzzy
-#~ msgid "Redraws the current display frame in the GRASS monitor"
-#, fuzzy
-#~ msgid "Redraw all frames"
-#, fuzzy
-#~ msgid "Old schema"
-#, fuzzy
-#~ msgid "New schema"
-#, fuzzy
-#~ msgid "display, export"
-#, fuzzy
-#~ msgid "Name of PNG file"
-#, fuzzy
-#~ msgid "Import of SPOT VGT NDVI file into a raster map"
-#, fuzzy
-#~ msgid "raster, imagery, import"
-#, fuzzy
-#~ msgid "display, diagram"
-#, fuzzy
-#~ msgid "Name of optional EPS output file"
-#, fuzzy
-#~ msgid "Skip the join column in other table"
-#~ msgstr "نوع غير معروف"
-#, fuzzy
-#~ msgid "Copy all the columns from other table to map"
-#, fuzzy
-#~ msgid "Join column in map table"
-#, fuzzy
-#~ msgid "raster, mask"
-#~ msgstr "الخريطة الراسترية الأساس"
-#, fuzzy
-#~ msgid "Overwrite existing MASK"
-#, fuzzy
-#~ msgid "Exports GRASS raster into GDAL supported formats."
-#, fuzzy
-#~ msgid "Region sensitive output"
-#, fuzzy
-#~ msgid "Column on which to calculate statistics (must be numeric)"
-#, fuzzy
-#~ msgid "Reports geometry statistics for vectors."
-#~ msgstr "تقرير الإحصائيات للخرائط الراسترية"
-#, fuzzy
-#~ msgid "vector, report, statistics"
-#, fuzzy
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
-#, fuzzy
-#~ msgid "Slide show of GRASS raster/vector maps."
-#, fuzzy
-#~ msgid "display, slideshow"
-#, fuzzy
-#~ msgid "Show vector maps rather than raster maps"
-#, fuzzy
-#~ msgid "Number of seconds to pause between slides"
-#~ msgstr "<%s> عدد مستويات الألوان المستخدمة فى"
-#, fuzzy
-#~ msgid "Display manager for GRASS"
-#, fuzzy
-#~ msgid "Name of .dmrc settings file"
-#~ msgstr "MAT-File(v4) اسم الملف"
-#, fuzzy
-#~ msgid "Import E00 file into a vector map."
-#, fuzzy
-#~ msgid "GIS manager for GRASS"
-#, fuzzy
-#~ msgid "Name of GIS manager settings file (.grc)"
-#, fuzzy
-#~ msgid "raster, statistics, aggregation"
-#, fuzzy
-#~ msgid "Do not overwrite existing map"
-#, fuzzy
-#~ msgid "raster, imagery, colors"
-#~ msgstr "الملف الراسترى الطلوب إدخالة"
-#, fuzzy
-#~ msgid "Raster input maps"
-#, fuzzy
-#~ msgid "Select multiple points"
-#~ msgstr "نوع المظهر"
-#, fuzzy
-#~ msgid "Width in pixels of new display monitor"
-#, fuzzy
-#~ msgid "Height in pixels of new display monitor"
-#, fuzzy
-#~ msgid "Imports geonames.org country files into a GRASS vector points map."
-#, fuzzy
-#~ msgid "vector, import, GPS"
-#, fuzzy
-#~ msgid "Table to drop"
-#~ msgstr "<%s> لم يمكن فتح"
-#, fuzzy
-#~ msgid "Output raster map (default: input tile)"
-#, fuzzy
-#~ msgid "Saves the contents of the active display monitor to a graphics file."
-#, fuzzy
-#~ msgid "Name for output file (do NOT add extension)"
-#~ msgstr "اسم ملف التقرير"
-#, fuzzy
-#~ msgid "Images"
-#, fuzzy
-#~ msgid "Compression for PNG files"
-#, fuzzy
-#~ msgid "Paper size for PostScript output"
-#, fuzzy
-#~ msgid "PostScript"
-#, fuzzy
-#~ msgid "Set paper orientation to landscape (for PostScript output)"
-#, fuzzy
-#~ msgid "Do not crop away margins"
-#~ msgstr "لم يتم نسخ الجدول"
-#, fuzzy
-#~ msgid "Name of aspect raster map"
-#, fuzzy
-#~ msgid "Name of vector map for which to edit attribute table"
-#, fuzzy
-#~ msgid "Column to update"
-#, fuzzy
-#~ msgid "GRASS table name"
-#, fuzzy
-#~ msgid "vector, color table"
-#, fuzzy
-#~ msgid "Layer number of data column"
-#, fuzzy
-#~ msgid "Name of color column to populate"
-#~ msgstr "اسم الخريطة المدخلة"
-#, fuzzy
-#~ msgid "Manually set range (min,max)"
-#~ msgstr "min,max :المدى الصحيح"
-#~ msgid "Raster map name from which to copy color table"
-#, fuzzy
-#~ msgid "sites, vector, import"
-#, fuzzy
-#~ msgid "raster, elevation, interpolation"
-#~ msgstr "عدد نقاط الإستيفاء"
-#, fuzzy
-#~ msgid "Name of input raster map in which to fill nulls"
-#, fuzzy
-#~ msgid "Name for output raster map with nulls filled by interpolation"
-#~ msgstr "اسم الخريطة الراسترية المخرجة"
-#, fuzzy
-#~ msgid "Moves displayed maps to another monitor"
-#, fuzzy
-#~ msgid "Target monitor"
-#, fuzzy
-#~ msgid "Source monitor"
-#, fuzzy
-#~ msgid "vector, centroid, area"
-#~ msgstr "عدم انشاء جدول الخواص"
-#, fuzzy
-#~ msgid "Layer where to add new attribute table"
-#, fuzzy
-#~ msgid "A (grid3D file)"
-#~ msgstr "اسم ااملف المخرج"
-#, fuzzy
-#~ msgid "B (grid3D file)"
-#, fuzzy
-#~ msgid "C (grid3D file)"
-#, fuzzy
-#~ msgid "D (grid3D file)"
-#, fuzzy
-#~ msgid "E (grid3D file)"
-#, fuzzy
-#~ msgid "F (grid3D file)"
-#, fuzzy
-#~ msgid "Name for output grid3D volume"
-#, fuzzy
-#~ msgid "Name of raster map to generate legend from"
-#, fuzzy
-#~ msgid "Name of raster map to print in legend"
-#~ msgstr "اسم الخريطة الراسترية  للعرض كخلفية"
-#, fuzzy
-#~ msgid "miscellaneous, projection"
-#, fuzzy
-#~ msgid "Input coordinate file (omit to read from stdin)"
-#, fuzzy
-#~ msgid "Output coordinate file (omit to send to stdout)"
-#, fuzzy
-#~ msgid "raster, imagery, statistics"
-#, fuzzy
-#~ msgid "Name of the column to drop"
-#, fuzzy
-#~ msgid "Split the display into subframes."
-#, fuzzy
-#~ msgid "Number of subframes"
-#, fuzzy
-#~ msgid "Import waypoints"
-#, fuzzy
-#~ msgid "Import routes"
-#, fuzzy
-#~ msgid "Import track"
-#, fuzzy
-#~ msgid "Device or file used to import data"
-#, fuzzy
-#~ msgid "vector, export, GPS"
-#, fuzzy
-#~ msgid "GpsBabel supported output format"
-#, fuzzy
-#~ msgid "raster, imagery, mosaicking"
-#, fuzzy
-#~ msgid "calculates univariate statistics from a GRASS raster map"
-#, fuzzy
-#~ msgid "Percentile to calculate (requires -e flag)"
-#~ msgstr "اسم الخريطة الراسترية المدخلة"
-#, fuzzy
-#~ msgid "raster, tiling"
-#~ msgstr "الملف الراسترى المدخل"
-#, fuzzy
-#~ msgid "raster, imagery"
-#, fuzzy
-#~ msgid "raster input map (LANDSAT channel 1)"
-#~ msgstr "الخرائط الراسترية المدخلة"
-#, fuzzy
-#~ msgid "raster input map (LANDSAT channel 2)"
-#, fuzzy
-#~ msgid "raster input map (LANDSAT channel 3)"
-#, fuzzy
-#~ msgid "raster input map (LANDSAT channel 4)"
-#, fuzzy
-#~ msgid "raster input map (LANDSAT channel 5)"
-#, fuzzy
-#~ msgid "raster input map (LANDSAT channel 7)"
-#, fuzzy
-#~ msgid "Enter raster map to display in 1st frame"
-#, fuzzy
-#~ msgid "Enter command to execute in 1st frame"
-#, fuzzy
-#~ msgid "Enter raster map to display in 2nd frame"
-#, fuzzy
-#~ msgid "Enter command to execute in 2nd frame"
-#, fuzzy
-#~ msgid "How to split display"
-#, fuzzy
-#~ msgid "imagery, fusion, Brovey"
-#, fuzzy
-#~ msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2)"
-#, fuzzy
-#~ msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3)"
-#, fuzzy
-#~ msgid "general, extensions"
-#, fuzzy
-#~ msgid "List available modules in the GRASS Addons SVN repository"
-#, fuzzy
-#~ msgid "Configuration editor for r.li.'index'"
-#, fuzzy
-#~ msgid "raster, landscape structure analysis"
-#, fuzzy
-#~ msgid "vector, area, dissolve"
-#, fuzzy
-#~ msgid "Name of column used to dissolve common boundaries"
-#, fuzzy
-#~ msgid "Name of shaded relief or aspect map"
-#~ msgstr "اسم ملف الإنحدار الراسترى"
-#, fuzzy
-#~ msgid "Name of raster to drape over relief map"
-#, fuzzy
-#~ msgid "writing edges..."
-#~ msgstr "كتابة رؤوس قمم الخطوط"
-#, fuzzy
-#~ msgid "raster3d, statistics"
-#, fuzzy
-#~ msgid "raster, png"
-#, fuzzy
-#~ msgid "Convert all old GRASS < Ver5.7 vector maps in current mapset to current format"
-#, fuzzy
-#~ msgid "Unhandled vector feature type <%s>"
-#, fuzzy
-#~ msgid "No areas found, skipping type=area"
-#, fuzzy
-#~ msgid "No points found, skipping%s%s"
-#, fuzzy
-#~ msgid "No lines found, skipping%s%s"
-#, fuzzy
-#~ msgid "Raster value"
-#, fuzzy
-#~ msgid "GDAL datatype: %s, range: %f - %f"
-#, fuzzy
-#~ msgid "Unable to create table <%s_edge_Interpolation>"
-#, fuzzy
-#~ msgid "Rescale output raster map [0,255]"
-#, fuzzy
-#~ msgid "Converting %s..."
-#~ msgstr "كتابة ملف جديد...\n"
-#, fuzzy
-#~ msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation layer."
-#~ msgstr "ترشيح وانشاء خريطة ارتفاعات عديمة المنخفضات وخريطة اتجاه السريان من خريطة الإرتفاعات المعطاه"
-#, fuzzy
-#~ msgid "Cannot make stat of %s configuration file"
-#, fuzzy
-#~ msgid "Illegal configuration file"
-#~ msgid "Calculates cast shadow areas from sun position and DEM. Either A: exact sun position is specified, or B: date/time to calculate the sun position by r.sunmask itself."
-#~ msgstr "برنامج حساب اماكن الظلال من مكان الشمس ونموذج الإرتفاعات الرقمى"
-#~ msgid "A: altitude of the sun above horizon, degrees"
-#~ msgstr "A:ارتفاع الشمس فوق الأفق, درجات"
-#~ msgid "A: azimuth of the sun from the north, degrees"
-#~ msgstr "A: زاوية الشمس مقاسة من الشمال, درجات"
-#~ msgid "B: minutes (0..60)"
-#~ msgstr "B: (60..0) الدقيقة"
-#~ msgid "B: seconds (0..60)"
-#~ msgstr "B: (60..0) الثانية"
-#~ msgid "B: timezone (east positive, offset from GMT, also use to adjust daylight savings)"
-#~ msgstr "(النطاق الزمنى (شرق موجب,الفرق من جى ام تى,يستخدم ايضا لضبط توفير ضوء النهار"
-#~ msgid "Show the category label in the grid cell(s)"
-#~ msgstr "عرض عنوان الفئة فى خلية الشبكة"
-#, fuzzy
-#~ msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
-#~ msgstr "ln(a/tan(beta)) تعيين الدليل الطبوغرافى من خريطة الإرتفاعات"
-#, fuzzy
-#~ msgid "Unable to read symbol, unable todisplay points"
-#~ msgstr "[%s]لم يتم فتح ملف الخلية ل "
-#, fuzzy
-#~ msgid "Exporting %i points/lines..."
-#, fuzzy
-#~ msgid "vector, query"
-#, fuzzy
-#~ msgid "Name for output file (do not add extension)"
-#, fuzzy
-#~ msgid "Surface"
-#~ msgstr "تباين المجموع"
-#, fuzzy
-#~ msgid "Vector map for which to edit attribute table"
-#, fuzzy
-#~ msgid "Layer where to add column"
-#, fuzzy
-#~ msgid "Computing row %d of covariance matrix..."
-#~ msgstr "حساب الظلال من نموذج الإرتفاعت الرقمى"
-#, fuzzy
-#~ msgid "display, legend"
-#, fuzzy
-#~ msgid "Type of elements"
-#, fuzzy
-#~ msgid "Writing data to file..."
-#, fuzzy
-#~ msgid "Output hue raster map"
-#~ msgstr "اسم خريطة الراستر المخرجة"
-#, fuzzy
-#~ msgid "Database record for cat %d not found"
-#~ msgstr "cat = %d لا يوجد تسجيل للخط"
-#, fuzzy
-#~ msgid "Could not find input map <%s> in current mapset."
-#, fuzzy
-#~ msgid "Could not find input vector map %s"
-#, fuzzy
-#~ msgid "Print the current region (shell script style)"
-#~ msgstr "طباعة الأحصاء فى صورة شل سكربت"
-#, fuzzy
-#~ msgid "Name for G3d raster map"
-#, fuzzy
-#~ msgid "Illegal number of columns <%s>"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#, fuzzy
-#~ msgid "Cannot select records from database"
-#~ msgstr "لم يمكن اختيار البيانات من الجدول"
-#, fuzzy
-#~ msgid "Removed vertices"
-#~ msgstr "لم يتم حساب شبه مركز المساحة"
-#, fuzzy
-#~ msgid "Line: %d\n"
-#~ msgid "Database connection not defined\n"
-#, fuzzy
-#~ msgid "Cannot find file %s"
-#, fuzzy
-#~ msgid "Cannot get header for %s"
-#~ msgid "database location"
-#, fuzzy
-#~ msgid "Cannot open driver <%s>"
-#, fuzzy
-#~ msgid "No database updates."
-#~ msgid "%s Pan\n"
-#, fuzzy
-#~ msgid "Cannot open driver\n"
-#, fuzzy
-#~ msgid "Cannot open database\n"
-#, fuzzy
-#~ msgid "Cannot describe table\n"
-#, fuzzy
-#~ msgid "Could not write raster row"
-#, fuzzy
-#~ msgid "Could not close G3D map <%s>"
-#, fuzzy
-#~ msgid "Open rgb 3d raster map %s"
-#, fuzzy
-#~ msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
-#, fuzzy
-#~ msgid "unable to close input 3d raster map"
-#, fuzzy
-#~ msgid "Error opening g3d map <%s>"
-#~ msgid "Name of an existing raster map layer"
-#~ msgstr "اسم الملف الراسترى الموجود"
-#, fuzzy
-#~ msgid "input,cell,raster"
-#~ msgstr "ادخل خريطة الراستر"
-#, fuzzy
-#~ msgid "output,cell,raster"
-#, fuzzy
-#~ msgid "raster, vector, visualization"
-#, fuzzy
-#~ msgid "Exporting raster as double values (bytes=%d)"
-#, fuzzy
-#~ msgid "Reading map"
-#~ msgstr "خريطة الإرتفاعات"
-#~ msgid "Signed data (high bit means negative value)"
-#~ msgstr "(بيانات ذات علامة(البت العليا تعنى قيم سالبة"
-#~ msgid "Number of bytes per cell (1, 2, 4)"
-#~ msgstr "عدد البيتات فى الخلية , واحدة, اثنتين, أم أربعة"
-#, fuzzy
-#~ msgid "Parsing bytes per cell"
-#, fuzzy
-#~ msgid "You have to provide all limits of geographic region (n,s,e,w)"
-#~ msgstr "الحد الجنوبى للمنطقة الجغرافية"
-#, fuzzy
-#~ msgid "Illegal number of rows <%s>"
-#, fuzzy
-#~ msgid "Using rows=%d cols=%d\n"
-#, fuzzy
-#~ msgid "Unable to calculate centroid for area %d"
-#, fuzzy
-#~ msgid "Cannot set GRASS_VERBOSE variable."
-#, fuzzy
-#~ msgid "Reading raster map <%s in %s> ..."
-#~ msgstr "%-5d dig_att قراءة ملف...\n"
-#, fuzzy
-#~ msgid "into  <%s@%s> (location <%s>) ... %s"
-#~ msgstr "غير موجود <%s>الملف للمنظر ثلاثى الأبعاد "
-#, fuzzy
-#~ msgid "Rectified input raster map <%s> will be saved as <%s>"
-#, fuzzy
-#~ msgid "Target information for group <%s> missing.\n"
-#, fuzzy
-#~ msgid "Target location <%s> not found\n"
-#~ msgstr "غير موجودة <%s> المنطقة"
-#, fuzzy
-#~ msgid "Location of input raster map"
-#, fuzzy
-#~ msgid "Mapset of input raster map"
-#, fuzzy
-#~ msgid "Checking location <%s>, mapset <%s>..."
-#~ msgstr "خريطة الراستر االناتجة"
-#~ msgid ""
-#~ " Solar position: sun azimuth: %f,\n"
-#~ "   sun angle above horz.(refraction corrected): %f\n"
-#~ msgstr "%f : زاوية الشمس فوق الأفق حيث صحح الإنكسار \n"
-#~ msgid " Sunrise time (without refraction): %02d:%02d:%02d\n"
-#~ msgstr "%02d:%02d:%02d : زمن شروق الشمس بدون انكسار\n"
-#~ msgid " Sunset time  (without refraction): %02d:%02d:%02d\n"
-#~ msgstr "%02d:%02d:%02d : زمن غروب الشمس بدون انكسار\n"
-#~ msgid "No map calculation requested. Finished.\n"
-#~ msgstr "لم يطلب حساب للخريطة, انتهى\n"
-#, fuzzy
-#~ msgid "Can't open range file for %s"
-#~ msgstr "%s لم يمكن فتح ملف المدى ل"
-#, fuzzy
-#~ msgid "Can't read row in input elevation map"
-#~ msgstr "لم يمكن قراءة صف فى خريطة الإرتفاعات المدخلة"
-#, fuzzy
-#~ msgid "<%s> created"
-#~ msgid "Raster map to be recoded"
-#~ msgstr "الخريطة الراسترية المطلوب تسجيلها"
-#, fuzzy
-#~ msgid "Unable to open rules file <%s>"
-#, fuzzy
-#~ msgid "Displays and overlays raster map layers in the active display frame on the graphics monitor."
-#, fuzzy
-#~ msgid "Raster map to be displayed"
-#, fuzzy
-#~ msgid "Displays vector data in the active frame on the graphics monitor."
-#, fuzzy
-#~ msgid "vector, projection"
-#, fuzzy
-#~ msgid "Duplicate area centroids"
-#, fuzzy
-#~ msgid "Vector output map"
-#~ msgstr "اسم الخريطة المخرجة"
-#, fuzzy
-#~ msgid "Error while writing to temp file"
-#~ msgstr "خطا فى محاولة قراءة ملف قاعدة البيانات dbmscap\n"
-#, fuzzy
-#~ msgid "Error writing row %d"
-#~ msgstr "تغلب على الخريطة المخرجة"
-#, fuzzy
-#~ msgid "Poorly placed psuedo control points. "
-#, fuzzy
-#~ msgid "Cannot generate the transformation equation."
-#~ msgstr "طباعة مصفوفة المضاهاه"
-#, fuzzy
-#~ msgid "No active psuedo control points"
-#, fuzzy
-#~ msgid "Unable to write temp file: %s"
-#~ msgstr "القيمة التى تعنى قيمة منعدمة"
-#, fuzzy
-#~ msgid "Unable to open map %s"
-#, fuzzy
-#~ msgid "Unable to write row %d"
-#, fuzzy
-#~ msgid "%s@%s: projection doesn't match current settings"
-#~ msgstr "لم توجد<%s>الخريطة الفيكتورية"
-#, fuzzy
-#~ msgid "%s@%s: zone doesn't match current settings"
-#, fuzzy
-#~ msgid "Failed in attempt to open %s"
-#~ msgstr "اسم الملف الفيكتورى المخرج"
-#~ msgid "Generates raster map layers of slope, aspect, curvatures and partial derivatives from a raster map layer of true elevation values. Aspect is calculated counterclockwise from east."
-#~ msgstr "تعيين خواص تضاريسية كالإنحدار واتجاهة والإنحناءات بانواعها"
-#, fuzzy
-#~ msgid "Output slope filename"
-#, fuzzy
-#~ msgid "Output profile curvature filename"
-#, fuzzy
-#~ msgid "Output tangential curvature filename"
-#~ msgid "Output first order partial derivative dx (E-W slope) filename"
-#~ msgstr "(اسم ملف المشتق الجزئى من الرتبة الاولى في الاتجاه السينى (انحدار شرق-غرب "
-#~ msgid "Output first order partial derivative dy (N-S slope) filename"
-#~ msgstr "(اسم ملف المشتق الجزئى من الرتبة الاولى في الاتجاه الصادى (انحدار شمال-جنوب"
-#~ msgid "Output second order partial derivative dxx filename"
-#~ msgstr "اسم ملف المشتق الجزئى من الرتبة الثانية في الاتجاه السينى"
-#~ msgid "Output second order partial derivative dyy filename"
-#~ msgstr "اسم ملف المشتق الجزئى من الرتبة الثانية في الاتجاه ااصادى "
-#~ msgid "Output second order partial derivative dxy filename"
-#~ msgstr "اسم ملف المشتق الجزئى من الرتبة الثانية في الاتجاه السينى ااصادى"
-#, fuzzy
-#~ msgid "wrong type: %s"
-#~ msgstr "%c :نوع غير معروف"
-#, fuzzy
-#~ msgid "Creating support files..."
-#, fuzzy
-#~ msgid "Elevation products for mapset [%s] in [%s]"
-#, fuzzy
-#~ msgid "Name of vector input map containing stream(s)"
-#~ msgid "Generates a raster map layer showing watershed subbasins."
-#~ msgstr "انشاء خريطة راسترية موضحة الأحواض التحتية لمحددات المياه"
-#~ msgid "Coded stream network file name"
-#~ msgstr "اسم ملف شبكة المجارى المائية المكودة"
-#~ msgid "Thinned ridge network file name"
-#~ msgstr "اسم ملف شبكة الأسنمة الجبلية المرققة"
-#~ msgid "Name for the resultant watershed partition file"
-#~ msgstr "اسم ملف تقسيم محددات المياه الناتج"
-#, fuzzy
-#~ msgid "Name of terrain raster map (DEM)"
-#, fuzzy
-#~ msgid "Name of the elevation raster map [m]"
-#~ msgstr "اسم ملف الإرتفاعات الراسترى"
-#, fuzzy
-#~ msgid "Output water depth raster map [m]"
-#~ msgstr "وصف مبسط للملف الراسترى المخرج"
-#, fuzzy
-#~ msgid "Output topographic index map"
-#~ msgstr "خريطة الدليل الطبوغرافى"
-#, fuzzy
-#~ msgid "Input elevation raster map"
-#~ msgstr "خريطة الارتفاعات الراسترية المخرجة"
-#, fuzzy
-#~ msgid "Input aspect raster map"
-#~ msgstr "اسم خريطة اتجاه الإنحدار"
-#, fuzzy
-#~ msgid "Input barrier raster map"
-#, fuzzy
-#~ msgid "Output flowline vector map"
-#~ msgid "Output raster map having shadows"
-#~ msgstr "الخريطة الراسترية المخرجة بالظلال"
-#~ msgid "B: year (1950..2050)"
-#~ msgstr "B: (2050..1950) السنة"
-#~ msgid "B: month (0..12)"
-#~ msgstr "B: (12..0) الشهر"
-#~ msgid "B: day (0..31)"
-#~ msgstr "B: (31..0) اليوم"
-#~ msgid "B: hour (0..24)"
-#~ msgstr "B: (24..0) الساعة "
-#, fuzzy
-#~ msgid "East coordinate (point of interest, default: map center)"
-#, fuzzy
-#~ msgid "North coordinate (point of interest, default: map center)"
-#~ msgstr "احداثى الشمال, الأساس هو مركز الخريطة"
-#~ msgid "Zero is a real elevation"
-#~ msgstr "الصفر قيمة حقيقية"
-#, fuzzy
-#~ msgid "(i)   Elevation map"
-#~ msgid "(o)   Depressionless elevation map"
-#~ msgstr "خريطة الإرتفاعات الخالية من المنخفضات, مخرج"
-#, fuzzy
-#~ msgid "(o/i) Basin elevation map (MASK applied)"
-#~ msgstr "خريطة الإرتفاعات للأحواض,مخرج"
-#, fuzzy
-#~ msgid "(o)   Topographic index ln(a/tanB) map (MASK applied)"
-#~ msgstr "خريطة الدليل الطبوغرافى,مخرج"
-#~ msgid "(o)   Output file"
-#~ msgstr "ملف المخرج"
-#, fuzzy
-#~ msgid "(i)   OPTIONAL Observed flow file"
-#~ msgstr "الملحوظة Q ملف "
-#, fuzzy
-#~ msgid "(i)   OPTIONAL Output for given time step"
-#~ msgstr " إخراج لخطوة زمنية معطاه"
-#, fuzzy
-#~ msgid "(i)   OPTIONAL Output for given topographic index class"
-#~ msgstr "إخراج لصنف دليل طبوغرافى معطى"
-#~ msgid "Name of existing raster map containing elevation surface"
-#~ msgstr "اسم خريطة أسطح الإرتفاعات"
-#, fuzzy
-#~ msgid "Reading map..."
-#~ msgid "Input map: elevation on which entire analysis is based"
-#~ msgstr "خريطة الإرتفاعات المدخلة"
-#~ msgid "Input map or value: percent of disturbed land, for USLE"
-#~ msgstr "USLE خريطة مدخلة او القيمة: نسبة الأرض المتاثرة, فى"
-#~ msgid "Output map: drainage direction"
-#~ msgstr "الخريطة المخرجة : إتجاه الصرف"
-#~ msgid "Output map: stream segments"
-#~ msgstr "الخريطة المخرجة : قطع المجرى"
-#~ msgid "Watershed basin creation program."
-#~ msgstr "برنامج خلق محددات  مياه الأحواض"
-#, fuzzy
-#~ msgid "The map N grid coordinates"
-#~ msgstr "الإحداثى الشمالى للخريطة\n"
-#, fuzzy
-#~ msgid "Name of input vector points map"
-#, fuzzy
-#~ msgid "Name of output vector area map"
-#, fuzzy
-#~ msgid "Cannot open vector map <%s>"
-#~ msgstr "<%s>فى<%s>لم يمكن فتح الملف الفيكتورى"
-#, fuzzy
-#~ msgid "<Auxiliar_edge_table> created in database."
-#, fuzzy
-#~ msgid "Unable to open table <%s_edge_Interpolation>"
-#, fuzzy
-#~ msgid "Selects data from table."
-#~ msgid "Output drain raster map"
-#, fuzzy
-#~ msgid "Can't find %d,%d:%f"
-#, fuzzy
-#~ msgid "Reading %s"
-#~ msgstr "dig قراءة ملف...\n"
-#, fuzzy
-#~ msgid "Writing %s"
-#, fuzzy
-#~ msgid "Unable to open MASK"
-#, fuzzy
-#~ msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in a local text file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
-#~ msgstr "برنامج حساب الإشعاع  الشمسى الساقط والمنعكس للتضاريس فى مكان ووقت معين من السنة"
-#, fuzzy
-#~ msgid "Name of the longitude input raster map [decimal degrees]"
-#~ msgstr "اسم ملف خط العرض الراسترى"
-#, fuzzy
-#~ msgid "Spline type of interpolation"
-#~ msgstr "المخرج هو خطأ الإستيفاء"
-#, fuzzy
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares)"
-#, fuzzy
-#~ msgid "Vector map to display thematically"
-#, fuzzy
-#~ msgid "Vector map type"
-#~ msgstr "<%s>لم يتم العثور على الخريطة المدخلة\n"
-#, fuzzy
-#~ msgid "Mapset(s) to list (default: current mapset search path)"
-#~ msgstr "طباعة إحداثيات الإتصال الحلى و الخروج"
-#, fuzzy
-#~ msgid "Output separator (default: newline)"
-#~ msgstr "شكل فاصل المخرج"
-#, fuzzy
-#~ msgid "Raster to remove"
-#~ msgstr "إدخال خريطة راسترية بينرية "
-#, fuzzy
-#~ msgid "3d raster to remove"
-#, fuzzy
-#~ msgid "Vector to remove"
-#, fuzzy
-#~ msgid "Region to remove"
-#, fuzzy
-#~ msgid "Label to remove"
-#, fuzzy
-#~ msgid "3dview to remove"
-#, fuzzy
-#~ msgid "Group to remove"
-#, fuzzy
-#~ msgid "raster input maps"
-#~ msgstr "اسم الراستر المدخل"
-#, fuzzy
-#~ msgid "Output field seperator"
-#~ msgstr "الفاصل الحقلى بين بيانات المخرج"
-#, fuzzy
-#~ msgid "ERROR: Problem opening output file."
-#~ msgstr "dig عطل فى فتح ملف المدخل"
-#, fuzzy
-#~ msgid "Density of output walkers"
-#, fuzzy
-#~ msgid "File [%s] not found"
-#~ msgstr "غير موجود <%s> الراستر"
-#, fuzzy
-#~ msgid "Unable to open file [%s]"
-#, fuzzy
-#~ msgid "Reading sites map (%s) ..."
-#, fuzzy
-#~ msgid "Name of the output walkers vector points map"
-#, fuzzy
-#~ msgid "You are not outputting any raster or vector points maps"
-#, fuzzy
-#~ msgid "Unable to read current region parameters"
-#, fuzzy
-#~ msgid "Cannot open cover raster map <%s>"
-#~ msgstr ""
-#~ "#-#-#-#-#  grassmods_ar.po (grassmods_ar)  #-#-#-#-#\n"
-#~ "[%s]لم يتم فتح ملف الخلية ل \n"
-#~ "%s لم يتم فتح قاعدة البيانات"
-#, fuzzy
-#~ msgid "Cannot open database <%s> by driver <%s>"
-#, fuzzy
-#~ msgid "No map specified"
-#~ msgstr "لم تحدد خرائط مدخلة"
-#, fuzzy
-#~ msgid "%s - unable to remove color table"
-#~ msgstr "لم يتم تحديث الحدود"
-#, fuzzy
-#~ msgid "%s - color table not found"
-#~ msgstr "غير موجودة <%s> الخريطة الراسترية "
-#, fuzzy
-#~ msgid "Starting map [%s]"
-#~ msgstr "المدخل لم يوجد %s\n"
-#, fuzzy
-#~ msgid "Unable to properly read input raster map"
-#, fuzzy
-#~ msgid "Unable to properly write output raster map"
-#~ msgid "Name of raster map layer to be used for <%s>"
-#~ msgstr "<%s> اسم الخريطة المستخدمة ل"
-#~ msgid "Run verbosly"
-#~ msgstr "تنفيذ بإسهاب"
-#, fuzzy
-#~ msgid "%d points converted to centroids"
-#~ msgstr "%-5d النقاط قرأت فى الذاكرة\n"
-#, fuzzy
-#~ msgid "%d centroids converted to points"
-#~ msgstr "%-5d أشباه المراكز كتبت فى ملف المخرج\n"
-#, fuzzy
-#~ msgid "%d lines converted to boundaries"
-#, fuzzy
-#~ msgid "CrossCorrelation: %d points read in region.\n"
-#, fuzzy
-#~ msgid "CrossCorrelation: Cannot read field info"
-#~ msgstr "لم بمكن قراءة معلومات الحقل"
-#, fuzzy
-#~ msgid "CrossCorrelation: Cannot open database %s by driver %s"
-#, fuzzy
-#~ msgid "CrossCorrelation: Column type not supported"
-#, fuzzy
-#~ msgid "CrossCorrelation: Cannot select data from table"
-#, fuzzy
-#~ msgid "CrossCorrelation: %d records selected from table"
-#~ msgstr "%d التسجيلات اختيرت من الجدول"
-#, fuzzy
-#~ msgid "CrossCorrelation: No record for point (cat = %d)"
-#, fuzzy
-#~ msgid "vector, attribute table"
-#, fuzzy
-#~ msgid "Cannot fetch data"
-#~ msgstr "لم يتم جلب البيانات"
-#, fuzzy
-#~ msgid "Feature id(s)"
-#~ msgid "Input vector was not found."
-#~ msgstr "الفيكتور المخرج  غير موجود"
-#~ msgid "Cannot open dig_cats file."
-#~ msgstr "dig_cats لم يتم فتح ملف"
-#~ msgid "Cannot insert into table: %s"
-#~ msgstr "%s:لم يتم الحشر بالجدول"
-#, fuzzy
-#~ msgid "Node layer (points)"
-#, fuzzy
-#~ msgid "Reading data from the map..."
-#~ msgstr "تسجيل الخرائط الراسترية "
-#, fuzzy
-#~ msgid "%d categories read from map"
-#, fuzzy
-#~ msgid "Processing ainput lines ..."
-#, fuzzy
-#~ msgid "Writing attributes ..."
-#, fuzzy
-#~ msgid "Current region does not include the entire input vector map <%s>"
-#, fuzzy
-#~ msgid "Output inverse raster map after IFFT"
-#, fuzzy
-#~ msgid "Reading the raster maps..."
-#, fuzzy
-#~ msgid "Inverse FFT completed..."
-#~ msgstr "مقلوب فرق العزم"
-#, fuzzy
-#~ msgid "Unable to open output file."
-#, fuzzy
-#~ msgid "Hue map name"
-#, fuzzy
-#~ msgid "Intensity map name"
-#, fuzzy
-#~ msgid "Saturation map name"
-#, fuzzy
-#~ msgid "Output map representing the red"
-#~ msgstr "خريطة مخرجة حيث ستكتب النقاط"
-#, fuzzy
-#~ msgid "Output map representing the green"
-#, fuzzy
-#~ msgid "Output map representing the blue"
-#~ msgstr "طريقة تقرير الإنحدار"
-#, fuzzy
-#~ msgid "Cannot read row from raster map"
-#~ msgstr " 2-%d اسماء الخرائط المدخلة"
-#, fuzzy
-#~ msgid "Cannot write row to raster map"
-#, fuzzy
-#~ msgid "Red input raster map"
-#, fuzzy
-#~ msgid "Green input raster map"
-#, fuzzy
-#~ msgid "Blue input raster map"
-#, fuzzy
-#~ msgid "Output intensity raster map"
-#~ msgstr "الخريطة الراسترية لنقاط البدء"
-#, fuzzy
-#~ msgid "Writing [%s] ..."
-#, fuzzy
-#~ msgid "Name of imagery signaturefile"
-#, fuzzy
-#~ msgid "Subgroup [%s] not found."
-#, fuzzy
-#~ msgid "Calculating eigenvalues and eigenvectors..."
-#, fuzzy
-#~ msgid "Cannot write color table of raster map <%s>"
-#~ msgstr "بدء بالقيم فى الخريطة الراسترية"
-#, fuzzy
-#~ msgid "Calculating class mean ..."
-#, fuzzy
-#~ msgid "Imagery group"
-#, fuzzy
-#~ msgid "Subgroup containing image files"
-#, fuzzy
-#~ msgid "Resultant signature file"
-#, fuzzy
-#~ msgid "Input raster map being fft"
-#, fuzzy
-#~ msgid "Illegal file name for real part: %s"
-#~ msgstr "ملف المدخل"
-#, fuzzy
-#~ msgid "Illegal file name for imaginary part: %s"
-#, fuzzy
-#~ msgid "Reading the raster map..."
-#, fuzzy
-#~ msgid "subgroup <%s> not found"
-#, fuzzy
-#~ msgid "Unable to proceed"
-#, fuzzy
-#~ msgid "** Can't open seed singature file <%s> **"
-#~ msgstr "<%s> فى <%s>لم يمكن فتح الملف للمنظر ثلاثى الأبعاد"
-#, fuzzy
-#~ msgid "** Can't read signature file <%s> **"
-#~ msgstr "<%s> فى <%s>لم يمكن قراءة الملف للمنظر ثلاثى الأبعاد"
-#, fuzzy
-#~ msgid "Can't creat reportfile: "
-#, fuzzy
-#~ msgid "Reading image ... "
-#, fuzzy
-#~ msgid "Unable to read head of %s"
-#, fuzzy
-#~ msgid "group=[%s] - not found."
-#, fuzzy
-#~ msgid "Can't read signature file [%s]."
-#~ msgstr "%s لم يتم العثور على الخريطة الراسترية"
-#, fuzzy
-#~ msgid "Imagery group to be classified"
-#~ msgstr "الخريطة الراسترية المطلوب إعادة تصنيفها"
-#, fuzzy
-#~ msgid "Signatures to use for classification"
-#, fuzzy
-#~ msgid "Raster map to hold classification results"
-#, fuzzy
-#~ msgid "Cannot select attributes: %s"
-#, fuzzy
-#~ msgid "Keep band numbers instead of using band color names."
-#~ msgstr "الإحتفاظ بأعداد الشرائح بدلا من استخدام اسماء لون الشرائح"
-#, fuzzy
-#~ msgid "Output raster map with lake"
-#, fuzzy
-#~ msgid "Terrain raster map <%s> not found!"
-#, fuzzy
-#~ msgid "Cannot open terrain raster map <%s@%s>!"
-#~ msgstr "%s لم يتم فتح قاعدة البيانات"
-#, fuzzy
-#~ msgid "Seed map <%s> not found!"
-#, fuzzy
-#~ msgid "Cannot open seed map <%s@%s>!"
-#, fuzzy
-#~ msgid "Name of the vector points map with x,y locations"
-#~ msgstr "اسم ملف القناع"
-#, fuzzy
-#~ msgid "Number of time iterations (sec.)"
-#, fuzzy
-#~ msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
-#, fuzzy
-#~ msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
-#, fuzzy
-#~ msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
-#~ msgid "Raster input maps(s)"
-#, fuzzy
-#~ msgid "Output file name"
-#, fuzzy
-#~ msgid "%s: can't read fp range for [%s]"
-#, fuzzy
-#~ msgid ""
-#~ "Raster map [%s] already exists.\n"
-#~ "Please try another."
-#~ msgstr "الخريطة الراسترية المطلوب الضبط عليها"
-#, fuzzy
-#~ msgid "Threshold distance"
-#~ msgstr "وحدات المسافة"
-#, fuzzy
-#~ msgid "Cannot execute: %s"
-#, fuzzy
-#~ msgid "Cannot link table: %s"
-#, fuzzy
-#~ msgid "DXF input file"
-#, fuzzy
-#~ msgid "Cannot open dxf file <%s>"
-#, fuzzy
-#~ msgid "Cannot open new vector map <%s>"
-#, fuzzy
-#~ msgid "Conversion of <%s> to vector map:"
-#~ msgstr "تحويل خريطة راسترية إلى فيكتورية"
-#, fuzzy
-#~ msgid "Create 3D file"
-#, fuzzy
-#~ msgid "Raster file(s) for Elevation"
-#~ msgstr "الملفات الراسترية المطلوب رؤيتها%d"
-#, fuzzy
-#~ msgid "Raster file(s) for Color"
-#, fuzzy
-#~ msgid "Raster map to zoom into"
-#, fuzzy
-#~ msgid "Save the current region to region definition file"
-#~ msgstr "لاتضبط المنطقة الحالية على ابعاد خريطة الارتفاعات"
-#, fuzzy
-#~ msgid "Could not open input file <%s>."
-#, fuzzy
-#~ msgid "Name of the resultant map"
-#, fuzzy
-#~ msgid "Raster map not found."
-#, fuzzy
-#~ msgid "%s: can't read range for [%s]"
-#, fuzzy
-#~ msgid "Raster file [%s] not found"
-#, fuzzy
-#~ msgid "\rDuplicate area centroids: %5d"
-#, fuzzy
-#~ msgid "Cannot create table: '%s'"
-#, fuzzy
-#~ msgid "Unable to get category list <%s>, editing terminated"
-#, fuzzy
-#~ msgid "Unable to delete layer/category [%d/%d] line %d"
-#, fuzzy
-#~ msgid "Unable to write line %d"
-#, fuzzy
-#~ msgid "Unable to delete line %d"
-#, fuzzy
-#~ msgid "Unknown query tool '%s'"
-#, fuzzy
-#~ msgid "No layer database connection"
-#, fuzzy
-#~ msgid "%d categories loaded from the database"
-#, fuzzy
-#~ msgid "Cannot open OGR data source '%s'"
-#, fuzzy
-#~ msgid "Cannot create layer"
-#~ msgstr "لم يتم انشاء الدليل"
-#, fuzzy
-#~ msgid "Column type [%d] not supported"
-#, fuzzy
-#~ msgid "Cannot read map header for <%s>"
-#~ msgstr " <%s> فى <%s>لم يمكن قراءة العنوان الرئيسى ل"
-#, fuzzy
-#~ msgid "Cannot read category file for <%s>"
-#, fuzzy
-#~ msgid "Print;Shell Script"
-#~ msgstr "طباعة عدات الخلية"
-#, fuzzy
-#~ msgid "%s: <%s> raster map not found"
-#~ msgstr ""
-#~ "الملف الفيكتورى غير موجود %s : تحذير\n"
-#~ "غير موجودة <%s> الخريطة الراسترية \n"
-#, fuzzy
-#~ msgid "Cannot read category file of raster map <%s>"
-#, fuzzy
-#~ msgid "%s - map not found"
-#, fuzzy
-#~ msgid "%s not found"
-#, fuzzy
-#~ msgid "Vector map %s - not found"
-#~ msgid "Raster map containing elevation data"
-#~ msgid "Raster map name for storing results"
-#~ msgid "Height of the viewing location"
-#~ msgstr "ارتفاع مكان الرؤية"
-#, fuzzy
-#~ msgid "%s: <%s> cellfile not found"
-#, fuzzy
-#~ msgid "Cell file [%s] not found\n"
-#, fuzzy
-#~ msgid "rgb cell map [%s] not found\n"
-#, fuzzy
-#~ msgid "vector cell map [%s] not found\n"
-#, fuzzy
-#~ msgid "%s - %s not found"
-#~ msgid "can't read header for <%s> in <%s>"
-#~ msgid "can't read region <%s> in <%s>"
-#~ msgstr "<%s> فى <%s> لم يمكن قراءة المنطقة"
-#~ msgid "can't open 3dview file <%s> in <%s>"
-#~ msgid "can't read 3dview file <%s> in <%s>"
-#~ msgid "invalid region: %s"
-#~ msgstr "%s:منطقة غير صالحة"
-#, fuzzy
-#~ msgid "Unable to read category file for raster map <%s>"
-#, fuzzy
-#~ msgid "Creating support files"
-#~ msgid "can't open %s"
-#, fuzzy
-#~ msgid "%s file [%s] not found!"
-#, fuzzy
-#~ msgid "%s: %s - map not found"
-#, fuzzy
-#~ msgid "%s: unable to open %s"
-#, fuzzy
-#~ msgid "%s - not found"
-#, fuzzy
-#~ msgid "Cannot read %s"
-#, fuzzy
-#~ msgid "Reading %s ... "
-#, fuzzy
-#~ msgid "[%s] map not found."
-#, fuzzy
-#~ msgid "[%s] map not found"
-#, fuzzy
-#~ msgid "Cannot describe table <%s>"
-#~ msgstr "لم يمكن وصف الجدول"
-#, fuzzy
-#~ msgid "Cannot insert values: %s"
-#, fuzzy
-#~ msgid "%s given an illegal number of points [%d]"
-#, fuzzy
-#~ msgid "Unable to open database %s by driver %s"
-#, fuzzy
-#~ msgid "No DB connection settings defined. Set with db.connect"
-#~ msgstr "db.connect أضبط مستخدما<%s>لم يتم تعريف أوضاع الإتصال بقاعدة البيانات"
-#, fuzzy
-#~ msgid "Could not find input %s"
-#, fuzzy
-#~ msgid "Could not open input"
-#, fuzzy
-#~ msgid "Could not open output"
-#, fuzzy
-#~ msgid "Could not find input map <%s>"
-#, fuzzy
-#~ msgid "Unkown item type in pad: %s"
-#, fuzzy
-#~ msgid "Can't read header for <%s> in <%s>"
-#, fuzzy
-#~ msgid "Can't read header for 3D raster <%s> in <%s>"
-#, fuzzy
-#~ msgid "%s in %s: %s"
-#~ msgstr "%s:خط %d:%s\n"
-#, fuzzy
-#~ msgid "Can't write region <%s>"
-#, fuzzy
-#~ msgid "No graphics device selected."
-#, fuzzy
-#~ msgid "Unable to read raster row."
-#, fuzzy
-#~ msgid "%s map not found"
-#, fuzzy
-#~ msgid "cannot read head of %s"
-#, fuzzy
-#~ msgid "Illegal file name: %s"
-#, fuzzy
-#~ msgid "Cannot open raster map <%s> in <%s>"
-#~ msgstr ""
-#~ msgid "cover values extracted from the category labels of the cover map"
-#~ msgstr "قيم الغطاء المستنبطة من عناوين الفئات للخريطة الغطاء"
-#, fuzzy
-#~ msgid "%s: %s - raster map not found"
-#, fuzzy
-#~ msgid "%s: %s - not found"
-#, fuzzy
-#~ msgid "%s: %s - can't open"
-#, fuzzy
-#~ msgid "Reading input map (%s)    ... "
-#, fuzzy
-#~ msgid "%s: %s - can't create raster map"
-#, fuzzy
-#~ msgid "Writing output map (%s)   ... "
-#, fuzzy
-#~ msgid "Reading raster map... "
-#, fuzzy
-#~ msgid "Writing raster map... "
-#~ msgid "Category list: e.g. 1,3-8,13"
-#~ msgstr "قائمة الفئات"
-#~ msgid "Output separator character (default: tab)"
-#, fuzzy
-#~ msgid "Cannot read category file of raster map <%s> in <%s>"
-#, fuzzy
-#~ msgid "Cannot create raster map %s"
-#, fuzzy
-#~ msgid "Cannot create vector map %s"
-#, fuzzy
-#~ msgid "Cannot create raster map '%s'"
-#, fuzzy
-#~ msgid "Number of raster rows to hold in memory"
-#~ msgstr "عدد الصفوف التى تحفظ فى الذاكرة"
-#, fuzzy
-#~ msgid "Print raster map title only"
-#, fuzzy
-#~ msgid "unknown type: %d"
-#, fuzzy
-#~ msgid "Cannot open raster map [%s]"
-#~ msgstr ""
-#, fuzzy
-#~ msgid "Cannot get raster band."
-#~ msgstr "الخريطة الراسترية الغطاء"
-#, fuzzy
-#~ msgid "Cannot allocate buffer for reading null values."
-#, fuzzy
-#~ msgid "Cannot read GRASS raster."
-#, fuzzy
-#~ msgid "Cannot get [%s] driver"
-#, fuzzy
-#~ msgid "Cannot export [%s] raster map."
-#, fuzzy
-#~ msgid "Cannot create [%s] raster map using [%s] driver."
-#, fuzzy
-#~ msgid "Cannot read header of raster map <%s>"
-#, fuzzy
-#~ msgid "Cannot open TIFF file <%s>"
-#, fuzzy
-#~ msgid "Reading raster map"
-#, fuzzy
-#~ msgid "Cannot open output map."
-#, fuzzy
-#~ msgid "Illegal file name. Please try another."
-#, fuzzy
-#~ msgid "%s: can't open %s"
-#, fuzzy
-#~ msgid "Reading raster map <%s> ..."
-#, fuzzy
-#~ msgid "memory allocation failure"
-#, fuzzy
-#~ msgid "Can't find data map."
-#~ msgstr "لم يستطع عرض قواعد البيانات"
-#, fuzzy
-#~ msgid "Cannot open vector map <%s> at the topological level"
-#, fuzzy
-#~ msgid "Rebuilding topology ..."
-#, fuzzy
-#~ msgid "No record for cat = %d"
-#, fuzzy
-#~ msgid "Removing duplicates ..."
-#, fuzzy
-#~ msgid "Attaching islands ..."
-#~ msgstr "وصل الفئات...\n"
-#, fuzzy
-#~ msgid "Attaching centroids ..."
-#, fuzzy
-#~ msgid "Vector map <%s> not found in current mapset"
-#, fuzzy
-#~ msgid "The number of lines in the input vector map is [%d]"
-#, fuzzy
-#~ msgid "Database connection not defined for layer <%d>"
-#, fuzzy
-#~ msgid "Cannot get layer info"
-#, fuzzy
-#~ msgid "cell file [%s] not found"
-#, fuzzy
-#~ msgid "can't open raster map [%s]"
-#, fuzzy
-#~ msgid "Cannot rewrite line %d"
-#, fuzzy
-#~ msgid "Editing tool"
-#, fuzzy
-#~ msgid "Cannot copy line %d, editing terminated"
-#, fuzzy
-#~ msgid "No layer database connection."
-#, fuzzy
-#~ msgid "Cannot snap lines %d,%d"
-#, fuzzy
-#~ msgid "%d lines modified"
-#~ msgstr "%-5d تم تخطى الخطوط الميتة\n"
-#, fuzzy
-#~ msgid "Could not open ASCII file <%s>"
-#, fuzzy
-#~ msgid "Print vector map region only"
-#, fuzzy
-#~ msgid "Cannot open vector map <%s> at topo level [%d]"
-#, fuzzy
-#~ msgid "Cannot get layer info for vector map <%s>"
-#, fuzzy
-#~ msgid "Cannot select attribute."
-#, fuzzy
-#~ msgid "Creating vector grid..."
-#, fuzzy
-#~ msgid "Could not find vector map <%s> in current mapset"
-#, fuzzy
-#~ msgid "Could not find input map <%s>."
-#, fuzzy
-#~ msgid "[%d] features written"
-#, fuzzy
-#~ msgid "Output map where segments will be written"
-#, fuzzy
-#~ msgid "<%s> cellfile not found"
-#, fuzzy
-#~ msgid "Not able to open vector map <%s>"
-#~ msgid "driver name"
-#~ msgstr "اسم المشغل"
-#~ msgid "database name"
-#, fuzzy
-#~ msgid "Driver name"
-#~ msgid "Cannot list databases."
-#~ msgid "Table name, select all from this table"
-#~ msgstr "اسم الجدول, اختر الكل من هذا الجدول"
-#~ msgid "output field separator"
-#~ msgstr "الفاصل الحقلي للمخرج"
-#~ msgid "output vertical record separator"
-#~ msgstr "فاصل التسجيل الراسى للمخرج "
-#~ msgid "null value indicator"
-#~ msgstr "مؤشر القيمة المنعدمة"
-#~ msgid "do not include column names in output"
-#~ msgstr "لاتشمل اسماء الأعمدة في المخرج"
-#~ msgid "vertical output (instead of horizontal)"
-#~ msgstr "(مخرج راسي (بدلا من الافقي"
-#, fuzzy
-#~ msgid "Cannot find mapset for %s"
-#~ msgstr "لم يمكن حشر صف جديد: %s"
-#, fuzzy
-#~ msgid "Cannot open File %s"
-#, fuzzy
-#~ msgid "Not able to open file for [%s]"
-#, fuzzy
-#~ msgid "Can't open label file [%s]"
-#, fuzzy
-#~ msgid "unable to open [%s] in [%s]"
-#, fuzzy
-#~ msgid "warning: unable to open [%s] in [%s]"
-#, fuzzy
-#~ msgid "Unable to find input cell map '%s'"
-#, fuzzy
-#~ msgid "Unable to open cellfile for <%s>"
-#, fuzzy
-#~ msgid "Unable to create raster map [%s]"
-#~ msgstr "اسم الخريطة الراسترية الناتجة"
-#, fuzzy
-#~ msgid "Unable to create output <%s>"
-#, fuzzy
-#~ msgid "Input file [%s] not found."
-#, fuzzy
-#~ msgid "Unable to open output file <%s>."
-#~ msgid "Multiplier for ascii data"
-#~ msgstr "المضروب فيه للبيانات الأسكية"
-#, fuzzy
-#~ msgid "Could not open temporary file: [%s]"
-#, fuzzy
-#~ msgid "Could not open input file [%s]"
-#, fuzzy
-#~ msgid "unable to create raster"
-#, fuzzy
-#~ msgid "Unable to create output raster map <%s>"
-#~ msgid "Name of the random surface to be produced"
-#~ msgstr "اسم السطح العشوائى المطلوب إنتاجه"
-#, fuzzy
-#~ msgid "%s: Unable to find raster map <%s>"
-#, fuzzy
-#~ msgid "%s: Unable to open raster map <%s> in mapset <%s>"
-#, fuzzy
-#~ msgid "%s:  Unable to open output raster map <%s>"
-#, fuzzy
-#~ msgid "Vector <%s> could not be opened"
-#, fuzzy
-#~ msgid "No db connection for driver <%s> defined. Run db.connect."
-#~ msgstr "db.connect إتصل مستخدما<%s>لم يتم تعريف مشغل الإتصال بقاعدة البيانات"
-#, fuzzy
-#~ msgid "Table name"
-#~ msgstr "اسم الجدول"
-#, fuzzy
-#~ msgid "Cannot drop table: %s"
-#, fuzzy
-#~ msgid "Cannot open labels <%s>"
-#, fuzzy
-#~ msgid "Cannot fetch data from table"
-#, fuzzy
-#~ msgid "Cannot open file [%s]"
-#, fuzzy
-#~ msgid "SVG file <%s> cannot be opened"
-#, fuzzy
-#~ msgid "Querying input '%s' ... "
-#, fuzzy
-#~ msgid "Copying %s input lines ... "
-#, fuzzy
-#~ msgid "Cannot create table <%s>"
-#, fuzzy
-#~ msgid "no record for cat = %d"
-#, fuzzy
-#~ msgid "cannot insert row: %s"
-#, fuzzy
-#~ msgid "Cannot find line of cat %d"
-#, fuzzy
-#~ msgid "Unalbe to open vector map <%s>"
-#, fuzzy
-#~ msgid "Database connection not defined for layer [%d]. Use v.db.connect first"
-#, fuzzy
-#~ msgid "Transforms a vector map via a set of tie points."
-#~ msgstr "تحويل راستر جراسى الى بينرى"
-#, fuzzy
-#~ msgid "Raster map <%s>] not found"
-#~ msgid "Cannot start driver '%s'."
-#~ msgstr "'%s'لم يمكن بدء المشغل"
-#, fuzzy
-#~ msgid "Cannot start driver <%s>."
-#, fuzzy
-#~ msgid "Could not open <%s>"
-#, fuzzy
-#~ msgid "Cannot write to <%s>"
-#~ msgid "Not able to open cellfile for [%s]"
-#, fuzzy
-#~ msgid "Not able to find cellfile [%s]"
-#, fuzzy
-#~ msgid "Raster map [%s] not found"
-#, fuzzy
-#~ msgid "Unable to open raster map [%s]"
-#, fuzzy
-#~ msgid "<%s> illegal name"
-#, fuzzy
-#~ msgid "%s: %s - Unable to open the input raster map\n"
-#, fuzzy
-#~ msgid "%s: %s - illegal name for output raster map."
-#, fuzzy
-#~ msgid "Exports GRASS raster data into various formats (requires GDAL)."
-#~ msgid "Couldn't find raster map %s"
-#, fuzzy
-#~ msgid "%s: <%s> not found"
-#, fuzzy
-#~ msgid "%s: Cannot open <%s>"
-#, fuzzy
-#~ msgid "Cannot find %s"
-#, fuzzy
-#~ msgid "could not read range file"
-#, fuzzy
-#~ msgid "Unable to create raster map [%s]."
-#, fuzzy
-#~ msgid "Filtering [%s] in [%s]"
-#, fuzzy
-#~ msgid "Open raster map %s in %s = %d"
-#, fuzzy
-#~ msgid "Swap temp files"
-#, fuzzy
-#~ msgid "Writing [%s]"
-#, fuzzy
-#~ msgid "%s: illegal map name"
-#, fuzzy
-#~ msgid "%s: <%s> illegal file name"
-#, fuzzy
-#~ msgid "can't open raster map <%s> in mapset %s"
-#~ msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
-#~ msgstr "PPM تحويل راستر جراسى الى صورة "
-#~ msgid "Mapset of input map"
-#~ msgstr "اسم مجموعة الخرائط للخريطة المدخلة"
-#, fuzzy
-#~ msgid "Checking location %s, mapset %s:"
-#, fuzzy
-#~ msgid "Error writing output map"
-#, fuzzy
-#~ msgid "[%s] is an illegal file name"
-#, fuzzy
-#~ msgid "Can't open temp file [%s]"
-#~ msgid "Names of existing raster maps"
-#~ msgstr "اسماء الملفات الراسترية الموجودة"
-#, fuzzy
-#~ msgid "%s - illegal name "
-#, fuzzy
-#~ msgid "Couldn't find raster map [%s]"
-#, fuzzy
-#~ msgid "%s: can't create %s"
-#, fuzzy
-#~ msgid "Normalized"
-#~ msgstr "معايرة"
-#, fuzzy
-#~ msgid "Cell file [%s] not found"
-#, fuzzy
-#~ msgid "Could not open output map"
-#, fuzzy
-#~ msgid "unable to close output map"
-#, fuzzy
-#~ msgid "Cannot create output map [%s]"
-#, fuzzy
-#~ msgid "Database's name couldn't be read"
-#, fuzzy
-#~ msgid "Cannot create vector map <%s>"
-#, fuzzy
-#~ msgid "Interpolation: No database connection for driver <%s> defined. Run db.connect"
-#, fuzzy
-#~ msgid "Cannot open database <%s>"
-#, fuzzy
-#~ msgid "Cannot open table <%s>"
-#, fuzzy
-#~ msgid "Could not find input map '%s'."
-#, fuzzy
-#~ msgid "Could not find network input map '%s'."
-#, fuzzy
-#~ msgid "error opening raster map [%s]."
-#, fuzzy
-#~ msgid "Cannot describe table %s"
-#, fuzzy
-#~ msgid "Patching file <%s@%s>"
-#, fuzzy
-#~ msgid "[%d] files patched"
-#, fuzzy
-#~ msgid "Column type  not supported"
-#, fuzzy
-#~ msgid "Could not open vector map <%s>"
-#, fuzzy
-#~ msgid "Database connection not defined for layer <%d>. Use v.db.connect first."
-#, fuzzy
-#~ msgid "Can't create output map"
-#, fuzzy
-#~ msgid "%s: cellfile [%s] not found."
-#, fuzzy
-#~ msgid "Unable to open cellfile [%s]."
-#, fuzzy
-#~ msgid "Unable to open raster map [%s]."
-#, fuzzy
-#~ msgid "Unable to find raster [%s]."
-#, fuzzy
-#~ msgid "name for new raster map"
-#~ msgstr "اسم الملف الراسترى الجديد"
-#, fuzzy
-#~ msgid "Output GRASS image file"
-#, fuzzy
-#~ msgid "name for new vector map (omit for display to stdout)"
-#~ msgstr "اسم  الملف المخرج"
-#, fuzzy
-#~ msgid "Input vector map"
-#~ msgstr "الخريطة الفيكتورية لنقاط الإنتهاء"
-#, fuzzy
-#~ msgid "unable to find raster map [%s]"
-#, fuzzy
-#~ msgid "<%s> raster map not found"
-#, fuzzy
-#~ msgid "Cannot find vector map [%s]"
-#, fuzzy
-#~ msgid "%s - can't open raster map"
-#~ msgstr ""
-#~ "خريطة الراستر الغطاء\n"
-#~ "%s لم يمكن فتح ملف المدى ل"
-#, fuzzy
-#~ msgid "Can't get row %d from raster map %s"
-#, fuzzy
-#~ msgid "%s - raster map not found"
-#~ msgid "string representing no data cell value"
-#~ msgstr "الرمز الممثل لقيم خلية بدون بيانات"
-#~ msgid "File name of reference classes"
-#~ msgstr "اسم ملف الأصناف المرجعية"
-#~ msgid "wide report, 132 columns (default: 80)"
-#~ msgstr "تقرير مفصل من 132 عمود والأساس 80"
-#~ msgid "quiet"
-#~ msgstr "خروج"
-#, fuzzy
-#~ msgid "<%s> - illegal output file name"
-#, fuzzy
-#~ msgid "%s: <%s> reference map not found"
-#~ msgid "Base raster map"
-#, fuzzy
-#~ msgid "%s: raster map not found"
-#, fuzzy
-#~ msgid "Problem opening input file [%s]"
-#, fuzzy
-#~ msgid "Problem opening output file [%s]"
-#, fuzzy
-#~ msgid "can't write category file for <%s>"
-#, fuzzy
-#~ msgid "%s: can't open tempfile"
-#, fuzzy
-#~ msgid "Unable to read row %d in raster map [%s]"
-#~ msgid "Elevation map"
-#, fuzzy
-#~ msgid "Output verbosely"
-#~ msgstr "إخراج بتفصيل"
-#, fuzzy
-#~ msgid "Can't open raster map %s"
-#, fuzzy
-#~ msgid "It could not be find input map <%s>"
-#, fuzzy
-#~ msgid "It could not be found input map <%s>"
-#, fuzzy
-#~ msgid "Cannot find input map <%s>"
-#, fuzzy
-#~ msgid "Input vector map <%s> not found."
-#, fuzzy
-#~ msgid "Category ranges: e.g. 1,3-8,13"
-#, fuzzy
-#~ msgid "Writing attributes ...\n"
-#, fuzzy
-#~ msgid "Could not open ascii file <%s>"
-#, fuzzy
-#~ msgid "Could not open temp file <%s>"
-#, fuzzy
-#~ msgid "List available formats and exit"
-#~ msgstr "عرض الهيئات المدعمة والخروج"
-#, fuzzy
-#~ msgid "Vector map <%s> not fould"
-#, fuzzy
-#~ msgid "SVG output file"
-#~ msgstr "الملف الراسترى المخرج"
-#, fuzzy
-#~ msgid "Could not find vector '%s'"
-#, fuzzy
-#~ msgid "Could not find vector map %s"
-#, fuzzy
-#~ msgid "Unable to get row %d from <%s>"
-#~ msgid "Raster output file"
-#, fuzzy
-#~ msgid "Writing raster map ... "
-#~ msgid "Keep existing color table"
-#~ msgstr "بقاء جدول الألوان الحالى "
-#~ msgid "List rules"
-#~ msgstr "عرض درجات الألوان"
-#, fuzzy
-#~ msgid "Verbose mode."
-#~ msgstr "تنفيذ باسهاب"
-#, fuzzy
-#~ msgid " %d rows, %d cols."
-#~ msgstr "%d راستر%s, %d فيكتور%s\n"
-#, fuzzy
-#~ msgid "%s in %s - can't read header file"
-#, fuzzy
-#~ msgid "%s - unable to create raster map"
-#, fuzzy
-#~ msgid "%s - unable to create category file"
-#, fuzzy
-#~ msgid "verbose mode"
-#, fuzzy
-#~ msgid "Vector map with points for which to modify the attribute table"
-#, fuzzy
-#~ msgid "Layer of the vector for which to modify the attribute table"
-#, fuzzy
-#~ msgid "Path to the input file"
-#, fuzzy
-#~ msgid "Path to an output file"
-#, fuzzy
-#~ msgid "Name of existing raster map to be displayed"
-#~ msgid "driver name:"
-#~ msgstr ":اسم المشغل"
-#~ msgid "Database name:"
-#~ msgstr ":اسم قاعدة البيانات"
-#, fuzzy
-#~ msgid "could not find input map <%s>"
-#, fuzzy
-#~ msgid "unable to open raster map [%s]"
-#, fuzzy
-#~ msgid "cannot open database %s by driver %s"
-#, fuzzy
-#~ msgid "column type not supported"
-#~ msgstr "نوع العمود غير مدعم"
-#, fuzzy
-#~ msgid "cannot select data from table"
-#, fuzzy
-#~ msgid "cannot create table: %s"
-#, fuzzy
-#~ msgid "cannot create index"
-#, fuzzy
-#~ msgid "cannot grant privileges on table %s"
-#, fuzzy
-#, fuzzy
-#~ msgid "Cannot find vector map"
-#, fuzzy
-#~ msgid "Cannot find raster map"
-#, fuzzy
-#~ msgid "Cannot open raster map"
-#, fuzzy
-#~ msgid "#%s"
-#~ msgstr "%s"
-#, fuzzy
-#~ msgid "Error while reading cell map."
-#, fuzzy
-#~ msgid "Error while writing new cell map."
-#, fuzzy
-#~ msgid "Error in opening output file <%s>"
-#, fuzzy
-#~ msgid "Unable to find input cell map <%s>"
-#, fuzzy
-#~ msgid "Error in opening input file <%s>"
-#, fuzzy
-#~ msgid "Unable to open cell man <%s> for input.\n"
-#, fuzzy
-#~ msgid "Cannot find map %s"
-#, fuzzy
-#~ msgid "Cannot open map %s"
-#~ msgid "Name of predefined rules file"
-#~ msgstr "اسم ملف درجات الألوان المحددة مسبقا"
-#, fuzzy
-#~ msgid "R:G:B value(s) out of range [0..255]: %d:%d:%d"
-#~ msgstr "**[خارج النطاق  [0..255:R:G:B : %d:%d:%d : تحذير**\n"
-#, fuzzy
-#~ msgid "R G B value(s) out of range [0..255]: %d %d %d"
-#~ msgstr "**[خارج النطاق  [0..255:R:G:B ك: %d:%d:%d : تحذير**\n"
-#, fuzzy
-#~ msgid "no such value"
-#~ msgstr "** تحذير  : هذه القيم غير موجودة **\n"
-#, fuzzy
-#~ msgid "%s:line %d:%s"
-#, fuzzy
-#~ msgid "bad color specification"
-#~ msgstr "** لون غير مناسب **\n"
-#, fuzzy
-#~ msgid "%s - unknown color"
-#~ msgstr "%s - لون غير معروف\n"
-#~ msgid "Valid colors are:\n"
-#~ msgstr "الألوان المتاحة هى:\n"
-#, fuzzy
-#~ msgid "Unable to find base map <%s>"
-#, fuzzy
-#~ msgid "Unable to find cover map <%s>"
-#, fuzzy
-#~ msgid "%s: unable to open raster map [%s]"
-#, fuzzy
-#~ msgid "%s: unable to create raster map [%s]"
-#, fuzzy
-#~ msgid "Unable to open database %s with driver %s"
-#~ msgstr "%s بالمشغل %s لم يمكن فتح قاعدة البيانات"
-#, fuzzy
-#~ msgid "%s: Unable to read raster map [%s]"
-#, fuzzy
-#~ msgid "%s: unable to open raster map <%s>"
-#, fuzzy
-#~ msgid "%s: Failed to read raster row %d"
-#, fuzzy
-#~ msgid "Unable to find [%s]."
-#, fuzzy
-#~ msgid "Unable to read cats table for %s"
-#, fuzzy
-#~ msgid "Could not open raster <%s>"
-#~ msgid "Font name (not supported interactively, see also -l flag) or path to TrueType font (including file name)"
-#~ msgstr "أو خط ذو نوع حقيقى بما فيه اسم الملف -l اسم الخط عير مدعم تفاعليا استخدم "
-#, fuzzy
-#~ msgid "%s: o_open_file: raster map %s not found"
-#, fuzzy
-#~ msgid "%s: o_open_file: could not open raster map %s in %s"
-#, fuzzy
-#~ msgid "No record for category for [%d]"
-#, fuzzy
-#~ msgid "List of point coordinates. Required for add and move actions."
-#~ msgstr " خط أم مساحة"
-#, fuzzy
-#~ msgid "Could not find input vector '%s'"
-#, fuzzy
-#~ msgid "Failed opening output vector map '%s'"
-#~ msgid "Do not create attribute table."
-#~ msgid "Could not find input %s\n"
-#, fuzzy
-#~ msgid "Error reading ascii file: [%s]"
-#, fuzzy
-#~ msgid "List vector maps in input location and exit (a dummy value must be given for input)"
-#~ msgstr "عرض ملفات الراستر للموقع والخروج"
-#, fuzzy
-#~ msgid "| Tool                            | Threshold     |"
-#~ msgstr "                الخــــــــريطة الحالية        الخـــــريطة الجــــــديدة\n"
-#, fuzzy
-#~ msgid "| Prune                           |  "
-#~ msgstr "                       إختبر متبقيـــــــــــــــات الخـــــــــريطة\n"
-#, fuzzy
-#~ msgid "%s: <%s> vector map not found"
-#, fuzzy
-#~ msgid "Vector <%s> could not be open"
-#, fuzzy
-#~ msgid "CrossCorrelation()"
-#~ msgstr "مضاهاة"
-#, fuzzy
-#~ msgid "Interpolation()"
-#~ msgstr "طريقة الاستيفاء المستخدمة"
-#, fuzzy
-#~ msgid "Interpolation: Setting regions and boxes"
-#, fuzzy
-#~ msgid "Interpolation: nsply = %d"
-#, fuzzy
-#~ msgid "Interpolation: (%d,%d): Bilinear interpolation..."
-#, fuzzy
-#~ msgid "Interpolation: (%d,%d): Bicubic interpolation..."
-#, fuzzy
-#~ msgid "%s: Dropping <s>"
-#, fuzzy
-#~ msgid "Interpolation was a success!"
-#, fuzzy
-#~ msgid "CrossCorrelation: %d points read in region. "
-#, fuzzy
-#~ msgid "CrossCorrelation: It shouldn't take too long."
-#, fuzzy
-#~ msgid "%s -- illegal output file name"
-#, fuzzy
-#~ msgid "Sorry, with method '%s' you have to define an output map."
-#, fuzzy
-#~ msgid "Calculation time"
-#~ msgid "Finished.\n"
-#~ msgstr "إنتهى\n"
-#, fuzzy
-#~ msgid "Existing raster map name"
-#, fuzzy
-#~ msgid "Done!"
-#~ msgstr "انتهى\n"
-#, fuzzy
-#~ msgid "No line found."
-#~ msgstr "لم يتم الثور على شيئ\n"
-#, fuzzy
-#~ msgid "Nothing Found."
-#, fuzzy
-#~ msgid "Could not open ascii file [%s]"
-#, fuzzy
-#~ msgid "Conversion of [%s] to vector map ..."
-#, fuzzy
-#~ msgid "Finished"
-#, fuzzy
-#~ msgid "Name of output 3d raster map"
-#, fuzzy
-#~ msgid "%s: - no such database %s\n"
-#, fuzzy
-#~ msgid "ERROR: <%s> not found\n"
-#, fuzzy
-#~ msgid "Cannot open toolbox: %s"
-#, fuzzy
-#~ msgid "Cannot open toolbox."
-#~ msgid "Could not find input map <%s>\n"
-#~ msgid "'%s' has finished the transformation of the vectors.\n"
-#~ msgstr "'%s'تم الإنتهاء من تحويل الفيكتورات\n"
-#~ msgid ""
-#~ "                          CHECK MAP RESIDUALS\n"
-#~ "\n"
-#~ msgid "                Current Map                  New Map\n"
-#~ msgid " POINT      X coord    Y coord  |        X coord   Y coord    |      residuals\n"
-#~ msgstr " POINT      X coord    Y coord  |        X coord   Y coord    |      residuals\n"
-#~ msgid "  Residual mean average   : %f\n"
-#~ msgstr "%f :متوسط المتبقيات\n"
-#, fuzzy
-#~ msgid "Append files to existing file"
-#, fuzzy
-#~ msgid "Vector map '%s' not found"
-#, fuzzy
-#~ msgid "Input elevation file"
-#, fuzzy
-#~ msgid "Input aspect file"
-#, fuzzy
-#~ msgid "Input barrier file"
-#, fuzzy
-#~ msgid "Quiet operation"
-#~ msgstr "عملية التجميع"
-#, fuzzy
-#~ msgid "%s\n"
-#~ msgstr "%s"
-#, fuzzy
-#~ msgid "output layer name"
-#~ msgstr "اسم الطبقة المخرجة"
-#, fuzzy
-#~ msgid "Did not find input cell map."
-#~ msgid "L: from  M: to R: quit\n"
-#~ msgstr "خروج :R الى :M من : L\n"
-#, fuzzy
-#~ msgid "datetime, datetime1/datetime2, or none"
-#~ msgstr "الميعاد الزمنى ,الميعاد الزمنى الأولالميعاد الزمنى الثانى,أو لاشيئ"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Done\n"
-#, fuzzy
-#~ msgid "Open vector 3d raster map %s"
-#, fuzzy
-#~ msgid "Name of vector output file"
-#, fuzzy
-#~ msgid "ERROR: A line needs at least 2 points"
-#~ msgstr "نقطة %d فى حاجة لإدخال على الأقل"
-#, fuzzy
-#~ msgid "ERROR: An area needs at least 3 points"
-#, fuzzy
-#~ msgid "file type (ignored)"
-#, fuzzy
-#~ msgid "Unable to create raster map for [%s]"
-#~ msgid "Done\n"
-#~ msgid "Read fp map as integer (use map's quant rules"
-#~ msgstr "قراءة خريطة ل اف بى كخريطة صحيحة الأعداد"
-#~ msgid "Name for the resulting raster map"
-#, fuzzy
-#~ msgid "Open 3d raster map %s\n"
-#, fuzzy
-#~ msgid "Open elev raster map %s\n"
-#, fuzzy
-#~ msgid "Could not open map %s\n"
-#~ msgid "Output partial derivatives instead"
-#~ msgstr "المشتقات الجزئية المخرجة"
-#~ msgid "Region size is lower than minreg, nothing displayed.\n"
-#~ msgstr "لن يتم عرض شيئ ,minreg حجم المنطقة اقل من أصغر حجم مسجل\n"
-#~ msgid "Region size is greater than maxreg, nothing displayed.\n"
-#~ msgstr "لن يتم عرض شيئ ,maxreg حجم المنطقة اكبر من اكبرحجم مسجل\n"
-#, fuzzy
-#~ msgid "Report only selected statistics"
-#~ msgstr "طريقة احصائيات ااشئ الموجة "
-#, fuzzy
-#~ msgid "name for new binary vector map (omit for display to stdout)"
-#, fuzzy
-#~ msgid "Enter imagery group to be registered"
-#~ msgstr "اسم الخرائط الراسترية المطلوب ترقيعها ببعضها "
-#, fuzzy
-#~ msgid "Quiet mode"
-#~ msgstr "خروج\n"
-#, fuzzy
-#~ msgid "done."
-#, fuzzy
-#~ msgid "output 3d raster map"
-#~ msgstr "الخريطة المخرجة"
-#, fuzzy
-#~ msgid "input raster map not found\n"
-#, fuzzy
-#~ msgid "elev raster map not found\n"
-#~ msgid "Connect to the database through DBMI."
-#~ msgstr "DBMI اتصل بقاعدة البيانات من خلال"
-#~ msgid "column '%s' : type text is stored as varchar(250) some data may be lost"
-#~ msgstr "نوع نص خزن كحروف متغيرة 250  قد يتم فقد بعض البيانات :'%s' العمود"
-#~ msgid "Zooming finished.\n"
-#~ msgstr "انتهى التكبير\n"
-#~ msgid "%s Quit\n"
-#~ msgstr "%s خروج\n"
-#~ msgid "%s Quit menu\n"
-#~ msgstr "%s الخروج من القائمة\n"
-#~ msgid "The map E and N grid coordinates of a starting point"
-#~ msgstr "احداثيات الشرق و الشمال لنقطة البدء"
-#~ msgid ""
-#~ "Output direction type AGNPS, ANSWERS or GRASS aspect\n"
-#~ "              default: GRASS"
-#~ msgstr ""
-#~ "AGNPS, ANSWERS or GRASS aspect\n"
-#~ "  نوع الإتجاه المخرج والأساس جراس"
-#~ msgid "Name of existing input raster map"
-#~ msgstr "اسم الخريطة الراسترية الموجودة"
-#~ msgid "Aspect"
-#~ msgstr "اتجاه الإنحدار"
-#~ msgid "Profile curvature"
-#~ msgstr "انحناء التضاريس"
-#~ msgid "Tangential curvature"
-#~ msgstr "الإنحناء المماسى"
-#~ msgid "Mean curvature"
-#~ msgstr "الإنحناء المتوسط"
-#~ msgid "Output direct (beam) irradiance/irradiation file (raster)"
-#~ msgstr "إخراج ملف الإشعاع المباشر الراسترى"
-#~ msgid "Output reflected irradiance/irradiation file (raster)"
-#~ msgstr "إخراج ملف الإشعاع المنعكس الراسترى"
-#~ msgid "Invoke fast, but memory intensive operation"
-#~ msgstr "تنفيذ بسرعة ولكنها عملية مستهلكة للذاكرة"
-#~ msgid "GRASS module to create a fractal surface of a given fractal dimension. Uses spectral synthesis method. Can create intermediate layers showing the build up of different spectral coefficients (see Saupe, pp.106-107 for an example of this). Use this module to generate naturally looking synthetical elevation models (DEM)."
-#~ msgstr "برنامج أنشاء سطح فراكتالى مستخدما بعد فراكتالى معطى"
-#, fuzzy
-#~ msgid "Name of the water depth raster map [m]"
-#~ msgstr "اسم ملف إتجاه الإنحدار الراسترى"
-#, fuzzy
-#~ msgid "Name of the x-derivatives raster map [m/m]"
-#, fuzzy
-#~ msgid "Name of the y-derivatives raster map [m/m]"
-#, fuzzy
-#~ msgid "Name of the detachment capacity coefficient raster map [s/m]"
-#~ msgstr "ملف عامل اشعاع الأشعة المرسلة للسماء الحقيقية"
-#, fuzzy
-#~ msgid "Name of the transport capacity coefficient raster map [s]"
-#, fuzzy
-#~ msgid "Name of the critical shear stress raster map [Pa]"
-#, fuzzy
-#~ msgid "Name of the Mannings n raster map"
-#, fuzzy
-#~ msgid "Name of the Mannings n value"
-#, fuzzy
-#~ msgid "Output transport capacity raster map [kg/ms]"
-#, fuzzy
-#~ msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
-#, fuzzy
-#~ msgid "Output sediment concentration raster map [particle/m3]"
-#~ msgstr "خريطة الإتجاه المخرجة"
-#, fuzzy
-#~ msgid "Output sediment flux raster map [kg/ms]"
-#~ msgstr "خريطة الصرف المخرجة"
-#, fuzzy
-#~ msgid "Output erosion-deposition raster map [kg/m2s]"
-#, fuzzy
-#~ msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
-#, fuzzy
-#~ msgid "Name of the runoff infiltration rate raster map [mm/hr]"
-#, fuzzy
-#~ msgid "Name of the flow controls raster map (permeability ratio 0-1)"
-#, fuzzy
-#~ msgid "Output water discharge raster map [m3/s]"
-#, fuzzy
-#~ msgid "Output simulation error raster map [m]"
-#~ msgid "Watershed basin analysis program."
-#~ msgstr "برنامج تحليل محددات  مياه الأحواض"
-#~ msgid "Input map: amount of overland flow per cell"
-#~ msgstr "خريطة مدخلة: كمية السريان للمياه على البر لكل خلية"
-#~ msgid "Input map: terrain blocking overland surface flow, for USLE"
-#~ msgstr "USLE خريطة مدخلة : التضاريس الحاجبة للسريان السطحى عبر البر, فى"
-#~ msgid "Output map: number of cells that drain through each cell"
-#~ msgstr "الخريطة المخرجة : عدد الخلايا التى تصب فى كل خلية"
-#~ msgid "Output map: unique label for each watershed basin"
-#~ msgstr "الخريطة المخرجة: عنوان فريد لكل  حوض محددات  المياه"
-#~ msgid "Output map: each half-basin is given a unique value"
-#~ msgstr "الخريطة المخرجة : كل نصف حوض معطى قيمة فريدة "
-#~ msgid "Output map: useful for visual display of results"
-#~ msgstr "الخريطة المخرجة : مفيد للعرض المرئى للنتائج "
-#~ msgid "Output map: slope length and steepness (LS) factor for USLE"
-#~ msgstr "USLE فى (LS)الخريطة المخرجة : طول الإنحدار ووعورته, عامل"
-#~ msgid "Output map: slope steepness (S) factor for USLE"
-#~ msgstr "USLE فى (S)الخريطة المخرجة : وعورة الإنحداه, عامل "
-#~ msgid "Input value: minimum size of exterior watershed basin"
-#~ msgstr "القيمة المدخلة : أصغر حجم من محددات  مياه الأحواض الخارجية"
-#~ msgid "Input value: maximum length of surface flow, for USLE"
-#~ msgstr "USLE القيمة المدخلة : أكبر طول من للسريان السطحى, فى"
-#~ msgid "Output elevation raster map after filling"
-#~ msgstr "خريطة الإرتفاعات المخرجة بعد الملىء"
-#~ msgid "Output direction raster map"
-#~ msgid "Output raster map of problem areas"
-#~ msgstr "الخريطة الراسترية المخرجة للمساحات ذات مشكلة"
-#, fuzzy
-#~ msgid "Range to be exported: %f - %f"
-#, fuzzy
-#~ msgid "(i)   Basin map created by r.water.outlet (MASK)"
-#~ msgstr "(مدخل) r.water.outlet خريطة الأحواض الناتجة من"
-#, fuzzy
-#~ msgid "(o)   Direction map for depressionless elevation map"
-#~ msgstr "خريطة  الإتجاه مع خريطة الإرتفاعات الخالية من المنخفضات, مخرج"
-#~ msgid "(i)   Number of topographic index classes"
-#~ msgstr "عدد أصناف الدليل الطبوغرافى,مدخل"
-#~ msgid "(o/i) Topographic index statistics file"
-#~ msgstr "ملف إحصائيات لدليل الطبوغرافى,مخرجمدخل"
-#~ msgid "(i)   TOPMODEL Parameters file"
-#~ msgstr "ملف إحداثيات توبموديل,مدخل"
-#~ msgid "(i)   Rainfall and potential evapotranspiration data file"
-#~ msgstr "ملف بيانات المطر الساقط والنتح التبخرى الفعال,مدخل"
-#~ msgid "Name of elevation raster map"
-#, fuzzy
-#~ msgid "Percent done:"
-#, fuzzy
-#~ msgid "Creates a new map layer whose category values are based upon a reclassification of the categories in an existing raster map layer."
-#~ msgstr "خلق طبقة خريطة جديدة تعتمد قيم فئاتها على إعادة التصنيف لفئات خريطة راسترية أخرى"
-#~ msgid "Converts a raster map into a vector map layer."
-#, fuzzy
-#~ msgid "The map E grid coordinates"
-#~ msgstr "الإحداثى ااشرقى للخريطة\n"
-#, fuzzy
-#~ msgid "Could not read east bufferzone size. Aborting."
-#, fuzzy
-#~ msgid "Could not read west bufferzone size. Aborting."
-#, fuzzy
-#~ msgid "Could not read north bufferzone size. Aborting."
-#, fuzzy
-#~ msgid "Calculating map %01d of %01d (angle %lf, raster map <%s>)"
-#, fuzzy
-#~ msgid "Output flowpath length raster map"
-#, fuzzy
-#~ msgid "Output flowline density raster map"
-#, fuzzy
-#~ msgid "Lat/Long location is not supported"
-#, fuzzy
-#~ msgid "Name of file with sql statement"
-#~ msgstr "اسم الملف بتعبير اس.كيو.ال"
-#, fuzzy
-#~ msgid "Raster map to use as MASK"
-#~ msgstr "الخرائط الراسترية المطلوب قرائتها"
-#, fuzzy
-#~ msgid "raster, terrain analysis"
-#, fuzzy
-#~ msgid "Layer to use for thematic display"
-#, fuzzy
-#~ msgid "Icon to remove"
-#, fuzzy
-#~ msgid "%s=%s - illegal value"
-#, fuzzy
-#~ msgid "mi(les),me(ters),k(ilometers),a(cres),h(ectares),c(ell_counts),p(ercent_cover)"
-#~ msgstr "أميال mi, أمتار me, كيلومترات k, افدنة a, هيكتارات h, عدات الخلية c,  p نسبة التغطية"
-#, fuzzy
-#~ msgid "%s - unknown color request"
-#, fuzzy
-#~ msgid "Could not read range file"
-#, fuzzy
-#~ msgid "Reading data: "
-#~ msgstr "التوقيع ..."
-#, fuzzy
-#~ msgid "%d boundaries converted to lines"
-#, fuzzy
-#~ msgid "CrossCorrelation: Mean = %.5lf\n"
-#, fuzzy
-#~ msgid "CrossCorrelation: lambda_i = %.3f\n"
-#, fuzzy
-#~ msgid "From type"
-#~ msgstr "نوع غير معروف"
-#, fuzzy
-#~ msgid "To layer"
-#~ msgstr "اسم الطبقة المدخلة"
-#, fuzzy
-#~ msgid "The column must be type integer or string"
-#, fuzzy
-#~ msgid "Removed vertices: %5d"
-#, fuzzy
-#~ msgid ""
-#~ "Line: %d  \n"
-#~ "Type: %s  \n"
-#~ "Left: %d  \n"
-#~ "Right: %d  \n"
-#~ msgstr " %d:يمين %d:يسار %s:نوع %d: خط "
-#, fuzzy
-#~ msgid ""
-#~ "Node[%d]: %d  \n"
-#~ "Number of lines: %d  \n"
-#~ "Coordinates: %.6f, %.6f, %.6f\n"
-#~ msgstr "%d : عدد الخطوط %d: [%d] العقدة\n"
-#, fuzzy
-#~ msgid ""
-#~ "Line: %5d  \n"
-#~ "Angle: %.8f\n"
-#~ msgstr " Line: %5d  Angle: %.8f\n"
-#, fuzzy
-#~ msgid ""
-#~ "Area: %d  \n"
-#~ "Number of isles: %d\n"
-#~ msgstr "مساحة: %d  عدد الجزر: %d\n"
-#, fuzzy
-#~ msgid "%d update/insert errors"
-#~ msgstr "%d تحديث الخطا\n"
-#, fuzzy
-#~ msgid "Processing ainput areas ..."
-#~ msgstr "إنشاء نقاط على الخط المدخل"
-#, fuzzy
-#~ msgid "Elevation raster map <%s> does not cover the entire area of the input vector map <%s>. "
-#, fuzzy
-#~ msgid "%s: %s - Unable to find the real-image map."
-#, fuzzy
-#~ msgid "%s: %s - Unable to find the imaginary-image."
-#, fuzzy
-#~ msgid "Power 2 values : [%d] rows [%d] columns."
-#, fuzzy
-#~ msgid "Insufficent memory for allocation of data structure"
-#~ msgstr "موقع قاعدة البيانات"
-#, fuzzy
-#~ msgid "Rotating data arrays..."
-#, fuzzy
-#~ msgid "Transform successful."
-#, fuzzy
-#~ msgid "Class transition statistics."
-#, fuzzy
-#~ msgid "get_img: out of memory."
-#~ msgstr "لم يتم فتح إختيار المؤشر"
-#, fuzzy
-#~ msgid "Subgroup [%s] in group [%s] contains no files."
-#, fuzzy
-#~ msgid "Signature file [%s] is missing or not readable."
-#, fuzzy
-#~ msgid "Ordering eigenvalues in descending order..."
-#, fuzzy
-#~ msgid "Transposing eigen matrix..."
-#, fuzzy
-#~ msgid "Calculating class covariance matrix..."
-#, fuzzy
-#~ msgid "Unable to create signature file [%s] for subgroup [%s] in group [%s]."
-#, fuzzy
-#~ msgid "Initializing data...\n"
-#, fuzzy
-#~ msgid "FFT completed..."
-#, fuzzy
-#~ msgid "Subgroup [%s] doesn't have any files"
-#, fuzzy
-#~ msgid "Group of imagery files to be clustered"
-#, fuzzy
-#~ msgid "Output file to contain final report"
-#~ msgstr "اسم ملف التقرير"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "<%s> -- illegal value of min_size"
-#, fuzzy
-#~ msgid "subgroup=[%s] (of group [%s]) - not found."
-#, fuzzy
-#~ msgid "Unable to create reject layer [%s]."
-#, fuzzy
-#~ msgid "Subgroup containing image files to be classified"
-#, fuzzy
-#~ msgid "Error writing result map file!"
-#, fuzzy
-#~ msgid "Name of input raster map(s)"
-#, fuzzy
-#~ msgid "Unable to connect line id %d to line %d"
-#, fuzzy
-#~ msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
-#, fuzzy
-#~ msgid "can't open vector map <%s> in <%s>"
-#, fuzzy
-#~ msgid "elevation file [%s] not found"
-#, fuzzy
-#~ msgid "Training map [%s] not found."
-#, fuzzy
-#~ msgid "Parameter <%s> not set"
-#, fuzzy
-#~ msgid "Input map containing lines"
-#~ msgstr "الخريطة المدخلة حاوية الخطوط"
-#, fuzzy
-#~ msgid "Read coordinates from standard input"
-#~ msgstr "إحداثيات الشرق والشمال لنقطة البدء"
-#, fuzzy
-#~ msgid "%s in %s -can't open raster map"
-#~ msgstr ""
-#, fuzzy
-#~ msgid "Topology is not available"
-#~ msgstr "اسم الخريطة الراسترية"
-#~ msgid "Name of output raster map"
-#~ msgstr "اسم الخريطة الراسترية المخرجة"
-#, fuzzy
-#~ msgid "name for new vector map"
-#, fuzzy
-#~ msgid "<%s> unable to open raster map"
-#, fuzzy
-#~ msgid "File name of classification result"
-#~ msgstr "اسم ملف ناتج التصنيف"
-#, fuzzy
-#~ msgid "Cover raster map"
-#~ msgstr "الخريطة الغطاء"
-#~ msgid "Topographic index ln(a/tanB) map"
-#, fuzzy
-#~ msgid "No input coordinates provided"
-#, fuzzy
-#~ msgid "Unable to write color table to raster [%s]"
-#, fuzzy
-#~ msgid "%s: reading category file for %s"
-#, fuzzy
-#~ msgid "| Break                           |  "
-#, fuzzy
-#~ msgid "Maximum number of iteration"
-#~ msgstr "عدد نقاط الإستيفاء"
-#, fuzzy
-#~ msgid "Name of input map"
-#~ msgid "Input map: locations of real depressions"
-#~ msgstr "خريطة مدخلة: أماكن المنخفضات الحقيقية"
-#~ msgid ""
-#~ "Convert on the fly, use less disk space\n"
-#~ "\t(requires r.out.ppm with stdout option)"
-#~ msgstr "تحويل طيارى مستخدما مساحة اقل على القرص"
-#, fuzzy
-#~ msgid "fp: Data range is %.25f to %.25f\n"
-#~ msgstr "fp: Data range is %.25f to %.25f\n"
-#, fuzzy
-#~ msgid "Could not read south bufferzone size. Aborting."
-#, fuzzy
-#~ msgid "Converts GRASS vector map to one of the supported OGR vector formats."
-#, fuzzy
-#~ msgid "Lines buffers... "
-#~ msgstr "الملف الراسترى المدخل"
-#, fuzzy
-#~ msgid "Areas buffers... "
-#, fuzzy
-#~ msgid "PostScript output file"
-#, fuzzy
-#~ msgid "Reading raster maps in group <%s> ..."
-#, fuzzy
-#~ msgid ""
-#~ "Input raster map <%s> does not exist in group <%s>.\n"
-#~ " Try:\n"
-#~ msgid "Name of fractal surface raster layer"
-#~ msgstr "اسم السطح الفراكتالى الراسترى"
-#, fuzzy
-#~ msgid "Unable to open file: <%s>"
-#, fuzzy
-#~ msgid "Done"
-#, fuzzy
-#~ msgid "<%s> is illegal file name"
-#~ msgstr "اسم ااملف المخرج"
-#, fuzzy
-#~ msgid "Name of the output walkers site file"
-#, fuzzy
-#~ msgid "Name of real-sky beam radiation coefficient input raster map [-]"
-#, fuzzy
-#~ msgid "Name of real-sky diffuse radiation coefficient input raster map [-]"
-#~ msgstr "ملف عامل اشعاع الضوءالمنتشر للسماء الحقيقية"
-#, fuzzy
-#~ msgid "Generates a raster map layer of distance to features in input layer."
-#~ msgstr "انشاء خريطة راسترية بها مساحات متجاورة نمت بخلية واحدة"
-#, fuzzy
-#~ msgid "Name for distance output map"
-#~ msgstr "اسم الخريطة المدخلة"
-#~ msgid "Reports statistics for raster map layers."
-#~ msgstr "تقرير الإحصائيات للخرائط الراسترية"
-#~ msgid "Name of an output file to hold the report"
-#, fuzzy
-#~ msgid "Name for output raster map with lake"
-#, fuzzy
-#~ msgid ""
-#~ "ERROR: Required parameter <%s> not set:\n"
-#~ "\t(%s)\n"
-#, fuzzy
-#~ msgid "db connection was not set by form\n"
-#~ msgstr "لم يعرف الأتصال بقاعدة البيانات\n"
-#, fuzzy
-#~ msgid "Name of table created for output when the distance to all flag is used"
-#~ msgid "Raster elevation file name"
-#~ msgstr "اسم ملف الإرتفاعات الراستري"
-#, fuzzy
-#~ msgid "unable to open MASK"
-#~ msgstr "<%s> لم يمكن فتح"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ " group <%s> not found"
-#, fuzzy
-#~ msgid "Cannot write lake raster map <%s>!"
-#~ msgid "raster map <%s> not found"
-#, fuzzy
-#~ msgid "no rules specified"
-#, fuzzy
-#~ msgid "Adding new features to vector file ..."
-#~ msgstr "كتابة ملف جديد...\n"
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po	2012-05-26 15:22:06 UTC (rev 51802)
+++ grass/trunk/locale/po/grassmods_cs.po	2012-05-26 15:46:05 UTC (rev 51803)
@@ -34238,6890 +34238,3 @@
 #, fuzzy
 msgid "Percent to brighten"
 msgstr "Procentuální konvergence"
-#, fuzzy
-msgid "Input raster map with specific yield in [1/m]"
-msgstr "Nebyly specifikovány ¾ádné vstupní rastrové mapy."
-#, fuzzy
-msgid "Raster map <%s> is not valid"
-msgstr "Rastrová mapa <%s> nenalezena"
-#, fuzzy
-msgid "If not given read from standard input"
-msgstr "Pokud není zadán, ète se standardní vstup"
-#, fuzzy
-msgid "Print basic info in shell script style"
-msgstr "Vypi¹ výsledek ve stylu pro shell skript"
-#, fuzzy
-msgid "Projection:"
-msgstr "Pøevádím..."
-#, fuzzy
-msgid "DBMI-OGR driver error:\n"
-msgstr "Chyba ovladaèe DBMI-MySQL :\n"
-#, fuzzy
-msgid "relative"
-msgstr "Vytvoøení"
-msgid "Raster map for which to edit null file"
-msgstr "Rastrová její¾ soubor NULL bude editován"
-#, fuzzy
-msgid "Join column in table"
-msgstr "Sloupec <%s> nebyl nalezen v tabulce <%s>"
-#, fuzzy
-msgid "Path to resulting ASCII file ('-' for standard output) or ASCII vector name if '-o' is defined"
-msgstr "Cesta k výslednému souboru ASCII nebo jmenéno ASCII vektoru, pokud je zadána volba '-o'."
-#, fuzzy
-msgid "Unable to parse '%s'\n"
-msgstr "Nelze èíst %s"
-#, fuzzy
-msgid "Driver <%s> doesn't support creating new fields"
-msgstr "Ovladaè <%s> nepodporuje vytváøení rastrù"
-#, fuzzy
-msgid "Unable to add new field <%s>"
-msgstr "Nelze èíst soubor 3dview <%s> v <%s>"
-#, fuzzy
-msgid "Sets color rules for features in a vector map using a numeric attribute column."
-msgstr "Nastavit barevné pravidla pro prvky vektoru s vyu¾itím numerického sloupce atributu."
-#, fuzzy
-msgid "Name of raster map from which to copy color table"
-msgstr "Název rastrové mapy, ze které se má kopírovat tabulka barev"
-#, fuzzy
-msgid "Name of file containing rules"
-msgstr "Soubor obsahující pøíkazy SQL"
-#, fuzzy
-msgid "Creating support files for <%s>"
-msgstr "Vytváøím podpùrné soubory pro %s"
-#, fuzzy
-msgid "Title for new raster file."
-msgstr "Titulek pro novou rastrovou mapu"
-#, fuzzy
-msgid "Unable it load G3d range"
-msgstr "Nelze èíst soubor s rozsahem"
-#, fuzzy
-msgid "\raster\" and \"volume\" options are mutually exclusive"
-msgstr "\"barva\", \"pravidlo\", a \"rastr\" volby se vzájemnì vyluèují"
-#, fuzzy
-msgid "Calculating measure #%d <%s> (56 measures available)"
-msgstr "Spoèítaná míra #%d <%s> (56 mìr je dostupno)"
-#, fuzzy
-msgid "Exports the color table associated with a raster3d map layer."
-msgstr "Vytvoøí/upraví tabulku barev spojenou s rastrovou mapou."
-msgid "Could not close RASTER3D map"
-msgstr "Nemohl jsem uzavøít RASTER3D mapu"
-msgid "Could not close RASTER3D map <%s>"
-msgstr "Nemohl jsem uzavøít mapu RASTER3D <%s>"
-msgid "Name for v5d output file"
-msgstr "Název výstupního v5d souboru"
-#, fuzzy
-msgid "Converts a 3D raster map into a 3-dimensional Vis5D file."
-msgstr "Exportuje 3D rastrový soubor GRASSu do 3-dimenzionálního Vis5D souboru."
-#, fuzzy
-msgid "Remove dangles:"
-msgstr "Mazání pøívìskù"
-#, fuzzy
-msgid "Unable to create 3D vector and attribute table at same time"
-msgstr "v.random nemù¾e vytvoøit 3D vektorovou mapu a atributovou tabulku ve stejný èas"
-#, fuzzy
-msgid "Coordinates"
-msgstr "Pøesnost souøadnic"
-#, fuzzy
-msgid "maps for mosaic."
-msgstr "druhá mapa mozaiky"
-#, fuzzy
-msgid "reclass raster output map"
-msgstr "Výstupní vektorová mapa"
-#, fuzzy
-msgid "Data source for OGR access"
-msgstr "Zdroj dat obsahuje %d vrstev:"
-#, fuzzy
-msgid "A single vector map can be connected to multiple database tables. This number determines which table to use. Layer name for OGR access."
-msgstr "Jedna vektorová mapa m¾e být pøipojena k více databázovým tabulkám. toto èíslo urøuje která tabulka bude pou¾ita."
-#, fuzzy
-msgid "Vector map for which to drop vector objects"
-msgstr "Vektorová mapa, v její¾ atributové tabulce bude sloupec smazán"
-#, fuzzy
-msgid "Layer of attribute table to use for selection"
-msgstr "Název sloupce atributu, který má být pou¾it pro ¹títky"
-#, fuzzy
-msgid "WHERE conditions for vector delete, without 'where' keyword (e.g. \"elevation IS NULL\")"
-msgstr "Podmínka SQL WHERE ov¹em bez slova 'where' (napø. 'cat=1' nebo 'sloup1/sloup2>1')"
-#, fuzzy
-msgid "Overwrite existing file"
-msgstr "Pøepi¹ existující MASKu"
-#, fuzzy
-msgid "Name of input vector polygon map"
-msgstr "Název polygonové mapy"
-#, fuzzy
-msgid "Name of MODIS product"
-msgstr "Název vstupní vrstvy"
-#, fuzzy
-msgid "The names of tile/s to download"
-msgstr "Poèet bodù, které mají být rozmístìny"
-#, fuzzy
-msgid "raster, import, copying"
-msgstr "rastr, import, pøevod"
-#, fuzzy
-msgid "raster, export, copying"
-msgstr "rastr, export"
-#, fuzzy
-msgid "Name of input elevation map"
-msgstr "Název vstupní rastrové mapy elevace "
-#, fuzzy
-msgid "Name for output shaded relief map"
-msgstr "Název výstupní rastrové mapy"
-#, fuzzy
-msgid "Existing SPOT VGT NDVI HDF file (0001_NDV.HDF)"
-msgstr "existující souboru SPOT VGT NDVI HDF (0001_NDV.HDF)"
-#, fuzzy
-msgid "zenith"
-msgstr "Délka: %f\n"
-#, fuzzy
-msgid "topographic correction method"
-msgstr "Výstupní rastrová mapa orientace"
-#, fuzzy
-msgid "Elevation file of unknown type"
-msgstr "Souøadnice bodu pro zastavení (V,S)"
-#, fuzzy
-msgid "Cannot allocate memory for auxiliar matrix.Consider changing region (resolution)"
-msgstr "Nelze alokovat pamì« pro podpùrnou matici. Zva¾uji zmìnu rozli¹ení regionu "
-#, fuzzy
-msgid "resampling"
-msgstr "Typ vzorkování"
-#, fuzzy
-msgid "map algebra"
-msgstr "rastr, mapová algebra"
-#, fuzzy
-msgid "Reading file <%s> ..."
-msgstr "Ètu soubor [%s] ..."
-#, fuzzy
-msgid "OGR data source name"
-msgstr "Jmono zdroje dat OGR"
-#, fuzzy
-msgid "Data source"
-msgstr "Schéma databáze."
-#, fuzzy
-msgid "OGR layer name"
-msgstr "Jméno vstupní tabulky GRASS"
-#, fuzzy
-msgid "Name for GRASS vector map"
-msgstr "Jméno vektorové mapy"
-#, fuzzy
-msgid "List available OGR layers in dsn and exit"
-msgstr "Vypi¹ pøítomné vrstvy a ukonèi se"
-#, fuzzy
-msgid "Buffering features..."
-msgstr "Bufer ploch..."
-#, fuzzy
-msgid "connection"
-msgstr "Spojení"
-#, fuzzy
-msgid "integration"
-msgstr "Vytvoøení"
-#, fuzzy
-msgid "value, parameter"
-msgstr "Cluster parametry\n"
-#, fuzzy
-msgid "sun_elevation"
-msgstr "Výbìr"
-#, fuzzy
-msgid "Path to rules file (\"-\" to write rules to stdout)"
-msgstr "Cesta k souboru s pravidly (\"-\" pro ètení pravidel ze standartního vstupu)"
-#, fuzzy
-msgid "Can't read color table for <%s>"
-msgstr "%s: Nelze èíst tabulku barev pro <%s@%s>"
-#, fuzzy
-msgid "File containing recode rules; \"-\" to read from stdin"
-msgstr "Soubor obsahující pravidla pro ¹tíky kategorií (nebo \"-\" pro stdin)"
-#, fuzzy
-msgid "Displays raster map layer."
-msgstr "Zji¹»uje barvy rastrové mapové vrstvy."
-#, fuzzy
-msgid "overlaps;features partially or completely overlap"
-msgstr "overlap; èásteèné nebo úplné pøekrytí prvkù"
-#, fuzzy
-msgid "<%s> created."
-msgstr "<%s> vytvoøen"
-#, fuzzy
-msgid "Available drivers:\n"
-msgstr "Pou¾itelné OGR ovladaèe:"
-#, fuzzy
-msgid "Slower but more accurate (applies to FP maps only)"
-msgstr "Pomalej¹í, ale pøesnìj¹í (pou¾itelné pouze pro mapy s desetinným èíslem)"
-#, fuzzy
-msgid "List available modules in the add-ons repository"
-msgstr "Vypi¹ dostupná pravidla barev a ukonèi se"
-#, fuzzy
-msgid "Calculates univariate statistics from a GRASS raster map based on vector polygons and uploads statistics to new attribute columns."
-msgstr "Spoèítá základní statistiku rastrového souboru na základì vektorových polygonù a ulo¾í ji do nových sloupeèkù atributové tabulky."
-#, fuzzy
-msgid "Raster file to be converted."
-msgstr "Název rastrového souboru, který má být importován"
-#, fuzzy
-msgid "File containing reclass rules; \"-\" to read from stdin"
-#, fuzzy
-msgid "terrain analysis"
-msgstr "rastr, terénní analýza"
-#, fuzzy
-msgid "Open vector map without topology (level 1)"
-msgstr "Nelze otevøít vektorový soubor <%s> v úrovni topologie %d"
-#, fuzzy
-msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
-msgstr "mi(míle),f(stopy),me(metry),k(kilometery),a(akry),h(hektary),p(procenta)"
-#, fuzzy
-msgid "Print bounds and exit (shell style)"
-msgid "Band to select"
-msgstr "Výbìr vrstvy"
-#, fuzzy
-msgid "Estimate spline step value"
-msgstr "Statistika pou¾itá pro rastrové hodnoty"
-#, fuzzy
-msgid "<%s> table created in database."
-msgstr "<%s> vytvoøeno v databázi."
-#, fuzzy
-msgid ""
-"Calculate the groundwater distance velocity vector field \n"
-"and write the x, y, and z components to maps named name_[xyz].\n"
-"Name is basename for the new raster3d maps"
-msgstr "Vypoèítat prùtokovou rychlost vektorového pole a zapi¹ x,y a z èásti do map pojmenovaných jmeno_[xyz]. Jméno mapy je základ pro r3d rastrovou mapu."
-#, fuzzy
-msgid "report"
-msgstr "Rozsáhlá zpráva"
-#, fuzzy
-msgid "Unable to get cell header for <%s>"
-msgstr "Nejsem schopen zapsat hlavièku pro %s"
-#, fuzzy
-msgid "Unable to open cellfile for <%s>"
-msgstr "Nelze otevøít soubor <%s>"
-#, fuzzy
-msgid "Error reading <%s>"
-msgstr "Chyba pøi ètení rastrové mapy <%s>"
-#, fuzzy
-msgid "%s: Error reading from raster map <%s>"
-#, fuzzy
-msgid "unable to open map <%s> in <%s>"
-msgstr "Nelze otevøít rastrovou mapu <%s> v <%s>"
-#, fuzzy
-msgid "unable to read map <%s> in <%s>"
-msgstr "Nelze èíst region <%s> v <%s>"
-#, fuzzy
-msgid "Unable to open base map <%s>"
-msgstr "Nelze otevøít rastrovou mapu <%s>"
-#, fuzzy
-msgid "Unable to open cover map <%s>"
-msgstr "Nelze otevøít vektorovou mapu <%s>"
-#, fuzzy
-msgid "Unable to open output map <%s>"
-msgstr "Nelze otevøít výstupní soubor <%s>"
-#, fuzzy
-msgid "Unable to read header for <%s>"
-#, fuzzy
-msgid "Error reading row %d (error = %d)"
-msgstr "Nelze naèíst øádek %d (chyba = %d)"
-#, fuzzy
-msgid "Cannot set region to output region"
-msgstr "Nelze nastavit region zpìt na poèáteèní rozli¹ení!!!"
-#, fuzzy
-msgid "Cannot set region to back to the initial region"
-#, fuzzy
-msgid "Unable to read row %d"
-msgstr "Nelze èíst øádek %i\n"
-#, fuzzy
-msgid "Unable to read region <%s>"
-msgstr "Nelze nastavit region <%s>"
-#, fuzzy
-msgid "unable to open accumulation map layer"
-msgstr "nemohu otevøít novou mapu akumulace "
-#, fuzzy
-msgid "SECTION 4: Extracting Streams."
-msgstr "Extrahuji plochy..."
-#, fuzzy
-msgid "Error reading row <%d>"
-msgstr "Chyba pøi zápisu øádky %d."
-#, fuzzy
-msgid "Name of input raster map containing starting points"
-msgstr "Název existující rastrové mapy obsahující frikèní hodnoty"
-#, fuzzy
-msgid "Unable to open input map <%s>"
-msgstr "Nelze otevøít vstupní soubor <%s>"
-#, fuzzy
-msgid "Error reading row %d"
-#, fuzzy
-msgid "Unable to read from <%s> row %d"
-msgstr "Nelze èíst rastrovou mapu <%s> øádek %d"
-#, fuzzy
-msgid "Unable to read file header of raster map <%s>"
-msgstr "Nelze èíst hlavièku rastrové mapy <%s>"
-#, fuzzy
-msgid "Unable to write to raster map<%s>"
-msgstr "Nelze zapsat rastrové mapy"
-#, fuzzy
-msgid "Unable to open training map <%s>"
-#, fuzzy
-msgid "Unable to open training map <%s in %s>"
-#, fuzzy
-msgid "Cannot open cell file [%s]"
-msgstr "Nelze otevøít soubor s pravidly <%s>"
-#, fuzzy
-msgid "Cannot read file header of [%s])"
-msgstr "Nelze èíst hlavièku souboru <%s>"
-#, fuzzy
-msgid "Could not open <%s>"
-msgstr "Nelze otevøít mapu %s"
-#, fuzzy
-msgid "Cannot write to output raster file"
-#, fuzzy
-msgid "Unable to read header of raster map <%s> "
-#, fuzzy
-msgid "Unable to read raster map <%s> row %d >"
-#, fuzzy
-msgid "qcname"
-msgstr "jméno"
-#, fuzzy
-msgid "Name of QC"
-msgstr "Jméno mapsetu"
-#, fuzzy
-msgid "250m band number is out of allowed range [1,2]"
-msgstr "Poèet hran mimo rozsah"
-#, fuzzy
-msgid "Cannot read file header of [%s]"
-#, fuzzy
-msgid "general, region"
-msgstr "obecné, projekce"
-#, fuzzy
-msgid "raster, soil, erosion, USLE"
-msgstr "rastr, objem, pøevod"
-#, fuzzy
-msgid "raster, rainfall, erosion, USLE"
-msgstr "rastr, tok erodovaných èástic, eroze, usazování"
-msgid "tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);wxpython;wxPython based next generation GUI"
-msgstr "tcltk;Tcl/Tk grafické prostøedí - GIS Manager (gis.m);oldtcltk;Strar¹í Tcl/Tk grafické prostøedí - Display Manager (d.m);wxpython; Grafické prostøedí budoucí generace zalo¾ené na WxPyton"
-msgid "Writes Z data to column instead of 3D vector"
-msgstr "Zapí¹e y-souøadnice do sloupce místo vytvoøení 3D vektoru"
-msgid "Convex hull calculation requires at least three points"
-msgstr "Výpoèet konvexního obalu po¾aduje nejménì 3 body"
-#, fuzzy
-msgid "Output aspect filename"
-msgstr "Název výstupní tabulky"
-msgid "raster, projection"
-msgstr "raster, projekce"
-msgid "Import as Floating Point Data (default: Integer)"
-msgstr "Naimportuj jako hodnoty s plovoucí desetinnou èárkou (float) (výchozí: celoèíselné)"
-msgid "Import as Double Precision Data (default: Integer)"
-msgstr "Naimportuj jako hodnoty s plovoucí desetinnou èárkou (double) (výchozí: celoèíselné)"
-msgid "Bad number of bytes per cell"
-msgstr "Chybný poèet bytù na buòku"
-msgid "Bytes do not match File size"
-msgstr "Byty neodpovídají velikosti souboru"
-msgid "Raster File Series to MPEG Conversion Program."
-msgstr "Sada rastrových souborù pro program, vytváøející MPEG."
-msgid "Total area: %e (%d areas)"
-msgstr "Celkem ploch: %e (%d ploch)"
-msgid "Overlapping area: %e (%d areas)"
-msgstr "Pøekrytí plochy: %e (%d ploch)"
-msgid "Area without category: %e (%d areas)"
-msgstr "PPlochy bez kategorie:%e (%d ploch)"
-msgid "Duplicate area centroids: %5d"
-msgstr "Duplicitní centroidy: %5d"
-msgid "Converts a binary GRASS vector map into a GRASS raster map ."
-msgstr "Konvertuje binární GRASS vektorovu mapu na GRASS rastrovou mapu."
-msgid "Bad format in initial exposusre station file for group <%s>"
-msgstr "©patný formát souboru poèáteèní expozice postavení kamery pro skupinu <%s>"
-msgid "Converts 3D raster maps (RASTER3D) into the VTK-Ascii format"
-msgstr "Pøevede 3D rastrové mapy (RASTER3D) do formátu VTK-Ascii"
-msgid "unable to close top raster map"
-msgstr "nelze zavøít svrchní rastrovou mapu"
-msgid "unable to close bottom raster map"
-msgstr "nelze zavøít spodní rastrovou mapu"
-msgid "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
-msgstr "Pøevede 3D ASCII rastrový textový soubor na (binární) 3D rastrovou mapovou vrstvu "
-msgid "Converts a 3D raster map layer into an ASCII text file"
-msgstr "Pøevede 3D rastrovou mapovou vrstvu do ASCII textového souboru"
-msgid ""
-"Cannot create mask file: RASTER3D_MASK already exists!\n"
-" Use 'g.remove rast3d=RASTER3D_MASK' to remove the existing mask."
-msgstr ""
-"Nelze vytvoøit soubor s maskou: RASTER3D_MASK ji¾ existuje!\n"
-" Pro odstranìní existující masky pou¾ijte 'g.remove rast3d=RASTER3D_MASK'."
-#~ msgid "Input grid3 filename"
-#~ msgstr "Vstupní soubor grid3"
-#~ msgid "Grid3 <%s> not found %s"
-#~ msgstr "Grid3 <%s> nebyl nalezen %s"
-#~ msgid "Failed to guess site file format"
-#~ msgstr "Selhal jsem pøi hádání formátu bodù"
-#~ msgid "Print raster map resolution (NS-res, EW-res) only"
-#~ msgstr "Vytiskni pouze rozli¹ení (NS-roz, EW-roz)"
-#~ msgid "Print raster map type only"
-#~ msgstr "Vytiskni pouze typ rastrové mapy"
-#~ msgid "Print map region only"
-#~ msgstr "Vytiskni pouze region rastrové mapy"
-#~ msgid "Print raster map data units only"
-#~ msgstr "Vytiskni pouze jednotky rastrové mapy"
-#~ msgid "Print raster map vertical datum only"
-#~ msgstr "Vytiskni pouze vertikální datum rastrové mapy"
-#~ msgid "Print map title only"
-#~ msgstr "Vytiskni pouze titulek rastrové mapy"
-#~ msgid "Print raster map timestamp (day.month.year hour:minute:seconds) only"
-#~ msgstr "Vypsat pouze èasovou znaèku (den.mìsíc.rok hodiny:minuty:sekundy)"
-#~ msgid "Name for value output map"
-#~ msgstr "Jméno pro hodnotu výstupní mapy"
-#~ msgid "Invalid timestamp"
-#~ msgstr "Chybný èasový otisk"
-#, fuzzy
-#~ msgid "Reading sites..."
-#~ msgstr "Naèítám vstupy..."
-#, fuzzy
-#~ msgid "Writing sites to output..."
-#~ msgstr "Zapisuji výstupní vrstvu..."
-#~ msgid "Reading coordinates from file."
-#~ msgstr "Èti souøadnice ze soubru."
-#~ msgid "ASCII file holding transform coordinates"
-#~ msgstr "Soubor ASCII obsahující transformaèní souøadnice"
-#~ msgid "If not given, transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot) are used instead"
-#~ msgstr "Pokud nezadáno, budou namísto toho pou¾ity parametry transformace (xshift,yshift,zshift, xscale, yscale, zscale, zrot)"
-#~ msgid "Unable to open file with coordinates <%s>"
-#~ msgstr "Nemohl jsem otevøít soubor se souøadnicemi : <%s>"
-#~ msgid "Error reading coordinates file"
-#~ msgstr "Chyba pøi naèítání souboru se souøadnicemi"
-#~ msgid "Number of points that have been entered [%d]"
-#~ msgstr "Poèet vlo¾ených bodù [%d]"
-#~ msgid "Error creating transformation"
-#~ msgstr "Chyba pøi pøevodu"
-#~ msgid "The points weren't spread out enough."
-#~ msgstr "Body nebyly rozmístìny v dostateèných rozestupech."
-#~ msgid "You need to enter at least %d points."
-#~ msgstr "Musíte zadat alespoò %d bodù."
-#~ msgid "create;Create new (empty) vector map;add;Add new features to existing vector map;delete;Delete selected features from vector map;move;Move selected features in vector map;vertexmove;Move vertex of selected vector lines;vertexdel;Remove vertex from selected vector lines;vertexadd;Add new vertex to selected vector lines;merge;Merge selected vector lines;break;Break/split vector lines;select;Select lines and print their ID's;catadd;Set new categories to selected vector features for defined layer;catdel;Delete categories from selected vector features for defined layer;copy;Copy selected features;snap;Snap vector features in given threshold;flip;Flip direction of selected vector lines;connect;Connect two lines;zbulk;Z bulk-labeling (automated assignment of z coordinate to vector lines);chtype;Change feature type (point<->centroid, line<->boundary)"
-#~ msgstr "create;Vytvoøí novou (prázdnou) vektorovou vrstvu;add;Pøidá nový vektorový prvek do existující vektorové vrstvy;delete;Sma¾e vybrané prvky z vektorové vrstvy;move;Pøesune prvek ve vektorové vrstvì;vertexmove;Pøesune vybraný lomový bod linie;vertexdel;Sma¾e vybrané lomové body linií;vertexadd;Pøidá lomový bod do vybrané linie;merge;Spojí vybrané linie;break;Rozdìlí linii na dvì samostatné linie;select;Vybere linie a vytiskne jejich ID;catadd;Nastaví nové kategorie pro vybrané prvky a vrstvu vektorové mapy;catdel;Sma¾e kategorie pro vybrané prvky vrstvy vektorové mapy;copy; Zkopíruje vybrané prvky;snap;Spojí vybrané prvky podle daného rozmezí vzdálenosti;flip; Otoèí smìr vybrané linie;connect; Spojí dvì linie;zbulk;Popisování v¹ech prvkù souøadnicí z ( automatické pøidìlení souøadnice z linii);chtype;Zmìnit typ prvku (bod <->centroid, linie <->hranice)"
-#~ msgid "Column name (will be updated by raster values)"
-#~ msgstr "Jméno sloupce, do kterého budou ulo¾eny hodnoty rastrové mapy"
-#~ msgid "Cannot scan date: "
-#~ msgstr "Nelze získat datum: "
-#~ msgid "Cannot scan time: "
-#~ msgstr "Nelze získat èas: "
-#~ msgid "Cannot allocate cursor."
-#~ msgstr "Nelze alokovat kurzor"
-#~ msgid "Cannot ad new token."
-#~ msgstr "Nelze pøidat dal¹í token."
-#~ msgid "Cannot connect to MySQL: "
-#~ msgstr "Nelze se pøipojit k MySQL: "
-#~ msgid "DBMI-MySQL driver error:\n"
-#~ msgstr "Chyba ovladaèe DBMI-MySQL :\n"
-#~ msgid "Cannot select data: \n"
-#~ msgstr "Nelze vybrat data: \n"
-#~ msgid "Unable allocate memory for row buffer"
-#~ msgstr "Nelze alokovat pamì» pro okolí øádku"
-#~ msgid "Computing means for band %d..."
-#~ msgstr "Poèítám prùmìr pro vrstvu %d...."
-#, fuzzy
-#~ msgid "Computing row %d (of %d) of covariance matrix..."
-#~ msgstr "Poèítám øádek %d matice kovariance..."
-#~ msgid "Unable to allocate memory for row buffer"
-#~ msgid "Unable to allocate memory for raster row"
-#~ msgstr "Nelze alokovat pamì» pro øádek rastru"
-#~ msgid "Transforming <%s>..."
-#~ msgstr "Pøevádím prvky <%s>..."
-#~ msgid "Surface area estimation for rasters."
-#~ msgstr "Odhad plochy povrchù rastrových map."
-#~ msgid "Raster file for surface"
-#~ msgstr "Rastrový soubor pro povrch"
-#, fuzzy
-#~ msgid "Writing buffers..."
-#~ msgstr "Zapisuji prvky..."
-#~ msgid "ASCII file to be converted to binary vector map"
-#~ msgstr "Soubor ASCII pro konverzi na binární vektorový soubor."
-#~ msgid "If not given (or \"-\") reads from standard input"
-#~ msgstr "Pokud není zadáno (nebo\"-\"), ète se standardní vstup"
-#, fuzzy
-#~ msgid "Join column in other table"
-#~ msgstr "Poèet iterací"
-#, fuzzy
-#~ msgid "Name of arc forward/both direction(s) cost column"
-#~ msgstr "Sloupeèek nesoucí cenu pohybu ve smìru dopøedu nebo i zpìt."
-#, fuzzy
-#~ msgid "Name of arc backward direction cost column"
-#~ msgstr "Sloupeèek nesoucí cenu pohybu ve smìru zpìt."
-#, fuzzy
-#~ msgid "Layer number or name with route paths or -1"
-#~ msgstr "Èíslo vrstvy (pro zapsání)"
-#~ msgid "Layer %d - no table"
-#~ msgstr "Vrstva %d - ¾ádná tabulka"
-#~ msgid "Layer %d - unable to copy table"
-#~ msgstr "Vrstva %d - nelze kopírovat tabulku"
-#, fuzzy
-#~ msgid "Name of arc forward/both direction(s) capacity column"
-#, fuzzy
-#~ msgid "Name of arc backward direction capacity column"
-#, fuzzy
-#~ msgid "Source layer number or name"
-#~ msgstr "Èíslo dotazované vrstvy (pro naètení)"
-#, fuzzy
-#~ msgid "Sink layer number or name"
-#~ msgstr "Èíslo vrstvy (from)"
-#, fuzzy
-#~ msgid "Name of Arc cost column"
-#~ msgstr "Poèet sloupcù"
-#~ msgid "Enter -1 to keep original categories or the desired NEW category value"
-#~ msgstr "Vlo¾te -1 pro zachování pùvodní kategorie nebo po¾adovanou NOVOU hodnotu."
-#, fuzzy
-#~ msgid "From layer number or name"
-#, fuzzy
-#~ msgid "To layer number or name"
-#, fuzzy
-#~ msgid "Name of node capacity column"
-#, fuzzy
-#~ msgid "Set1 layer number or name"
-#, fuzzy
-#~ msgid "Set2 layer number or name"
-#, fuzzy
-#~ msgid "Either mapset= or -l must be used"
-#~ msgstr "Buï 'pravidlo' nebo 'sloupec' musí být zadán"
-#, fuzzy
-#~ msgid "Line width column (%s) is not numeric."
-#~ msgstr "Sloupec s ID linie musí být typu integer"
-#, fuzzy
-#~ msgid "Error in color definition column '%s', feature id %d with cat %d: colorstring '%s'"
-#~ msgstr "Chyba ve sloupci s definicí barvy (%s), kategorie %d: barevný øetìzec [%s]"
-#, fuzzy
-#~ msgid "Error in color definition column '%s', feature id %d with cat %d"
-#~ msgstr "Chyba ve sloupci s definicí barvy (%s),  kategorie %d"
-#, fuzzy
-#~ msgid "Error in symbol size column (%s), element %d with cat %d: symbol size [%f]"
-#, fuzzy
-#~ msgid "Error in color definition column '%s': %d features affected"
-#~ msgid "'layer' must be > 0 for 'where'."
-#~ msgstr "'layer' musí být . 0 pro 'where'"
-#, fuzzy
-#~ msgid "'layer' must be > 0 for 'cats'."
-#, fuzzy
-#~ msgid "Can't read vector map"
-#~ msgstr "Nelze èíst vektorovou mapu"
-#, fuzzy
-#~ msgid "Color definition column not specified."
-#~ msgstr "Název vstupního zdroje nebyl specifikován"
-#, fuzzy
-#~ msgid "Error in color definition column (%s), area %d with cat %d: colorstring [%s]"
-#~ msgid "pg driver: column '%s', type %d  is not supported"
-#~ msgstr "ovladaè pg: sloupec '%s', typu %d není podporován"
-#~ msgid "Type of color table"
-#~ msgstr "Typ tabulky barev"
-#~ msgid "Name for input source not specified"
-#~ msgid "Name for output raster map not specified"
-#~ msgstr "Název výstupní rastrové mapy nebyl specifikován"
-#~ msgid "Requested g3d map <%s> not found"
-#~ msgstr "Po¾adovaná mapa g3d <%s> nebyla nalezena"
-#~ msgid "Error opening g3d map <%s>"
-#~ msgstr "Chyba pøi otevírání mapy g3d <%s>"
-#~ msgid "\"color\", \"rules\", and \"raster\" options are mutually exclusive"
-#~ msgstr "\"barva\", \"pravidlo\", a \"rastr\" volby se vzájemnì vyluèují"
-#~ msgid "-g and -a flags are mutually exclusive"
-#~ msgstr "-g a -a volby se navzájem vyluèují"
-#~ msgid "Negative or no data pixel found. This module is not yet able to process no data holes in a map, please fill with r.fillnulls or other algorithms"
-#~ msgstr "Byl nalezen pixel se zápornou nebo ¾ádnou hodnotou. Tento modul není schopen zpracovat díry v mapì, prosím vyplòte je pomocí r.fillnulls nebo jiným algoritmem."
-#~ msgid "Too many iterations to required to find %s - giving up"
-#~ msgstr "Pøíli¹ mnoho iterací je po¾adováno pro nalezení %s - vzdávám to."
-#~ msgid "Angular Second Moment"
-#~ msgstr "Druhý íºhlový moment"
-#~ msgid "Features"
-#~ msgstr "Prvky"
-#~ msgid "Contrast"
-#~ msgstr "Kontrast"
-#~ msgid "Correlation"
-#~ msgstr "Korelace"
-#~ msgid "Variance"
-#~ msgstr "Variance"
-#~ msgid "Inverse Diff Moment"
-#~ msgstr "Inverzní diferenèní moment"
-#~ msgid "Sum Average"
-#~ msgstr "Suma prùmìru"
-#~ msgid "Sum Variance"
-#~ msgstr "Suma variance"
-#~ msgid "Sum Entropy"
-#~ msgstr "Suma entropie"
-#~ msgid "Entropy"
-#~ msgstr "Entropie"
-#~ msgid "Difference Variance"
-#~ msgstr "Diferenèní variance"
-#~ msgid "Difference Entropy"
-#~ msgstr "Diferenèní entropie"
-#~ msgid "Measure of Correlation-1"
-#~ msgstr "Korelaèní koeficient-1"
-#~ msgid "Measure of Correlation-2"
-#~ msgstr "Korelaèní koeficient-2"
-#~ msgid "Max Correlation Coeff"
-#~ msgstr "Maximální koeficient korelace"
-#~ msgid "Raster file to be imported"
-#~ msgstr "Název rastrového souboru, který má být importován"
-#~ msgid "Write the result to g3d map <%s>"
-#~ msgstr "Zapsat výsledek do g3d mapy <%s>"
-#~ msgid "Requested 3d raster map not found"
-#~ msgstr "Po¾adovaný soubor g3d nebyl nalezen"
-#~ msgid "Error closing new ASCII file"
-#~ msgstr "Chyba pøi uzavírání nového souboru ASCII"
-#~ msgid "modifyNull: error opening map"
-#~ msgstr "modifyNull: chyba pøi otevøení mapy"
-#~ msgid "modifyNull: error closing map"
-#~ msgstr "modifyNull: chyba pøi uzavøení mapy"
-#~ msgid "Adding rule: %lf - %lf"
-#~ msgstr "Pøidávám pravidlo: %lf - %lf"
-#~ msgid "makeMask: error opening map."
-#~ msgstr "makeMask: chyba pøi otevírání mapy."
-#~ msgid "makeMask: error opening g3d mask file"
-#~ msgstr "makeMask: chyba pøi otevírání souboru s maskou g3d"
-#~ msgid "makeMask: error closing g3d mask file"
-#~ msgstr "makeMask: chyba pøi uzavírání souboru g3d mask"
-#~ msgid "makeMask: error closing map"
-#~ msgstr "makeMask: chyba pøi uzavírání mapy"
-#~ msgid "Requested 3d raster map <%s> not found"
-#~ msgstr "Po¾adovaný soubor g3d <%s> nebyl nalezen"
-#~ msgid "Requested g3d RGB map <%s> not found"
-#~ msgstr "Po¾adovaná mapa g3d RGB <%s> nebyla nalezena"
-#~ msgid "Requested g3d vector map <%s> not found"
-#~ msgstr "Po¾adovaná mapa g3d vektor <%s> nebyla nalezena"
-#~ msgid "Open rgb 3d raster map %s"
-#~ msgstr "Otevøít rgb g3d rastrový soubor %s"
-#~ msgid "Error closing g3d rgb map."
-#~ msgstr "Chyba pøi zavírání g3d rgb souboru"
-#~ msgid "Error closing g3d vector map."
-#~ msgstr "Chyba pøi zavírání g3d vektorového souboru"
-#~ msgid "The 2d and 3d region settings are different. The g3d settings are used to adjust the 2d region."
-#~ msgstr "2d a 3d nastavení regionu jsou rùzná. Pou¾iji hodnoty z nastavení g3d pro zmìnu 2d regionu."
-#~ msgid "unable to close input 3d raster map"
-#~ msgstr "Nelze zavøít vstupní 3D rastr"
-#~ msgid "write_vtk_rgb_data: writing rgb data"
-#~ msgstr "write_vtk_data: Zapisuji data RGB"
-#~ msgid "write_vtk_vector_data: writing vector data"
-#~ msgstr "write_vtk_vector_data: Zapisuji data vektorová data"
-#~ msgid "Error closing new 3d raster map"
-#~ msgstr "Chyba pøi zavírání 3d rastru"
-#~ msgid "Error closing ascii file"
-#~ msgstr "Chyba pøi zavírání souboru ASCII"
-#~ msgid "Error: couldn't create %s"
-#~ msgstr "Chyba: nemohu vytvoøit %s"
-#~ msgid "Error while writing grid. Disk full?"
-#~ msgstr "Chyba pøi zapisování møí¾ky. Disk je plný?"
-#, fuzzy
-#~ msgid "Name for output flowline density raster map"
-#~ msgstr "Výstupní rastr hustoty povrchového odtoku"
-#, fuzzy
-#~ msgid "Create/Edit"
-#~ msgstr "Vytvoøení"
-#, fuzzy
-#~ msgid "Create new projection files (modifies current location unless 'location' option specified)"
-#~ msgstr "Nelze získat informaci o mapové projekci aktuální location: prosím, nastavte ¹íøkupomocí volby 'lat' nebo 'latin'!"
-#, fuzzy
-#~ msgid "Location %s created!"
-#~ msgstr "Location <%s> vytvoøena"
-#, fuzzy
-#~ msgid "Print mapset names"
-#, fuzzy
-#~ msgid "Force remove"
-#~ msgstr "%d lomových bodù smazáno"
-#~ msgid "Min-area & snap"
-#~ msgstr "Min.plocha & snap"
-#~ msgid "Layer: %s"
-#~ msgstr "Vrstva: %s"
-#~ msgid "Break polygons:"
-#~ msgstr "Zlom polygonù:"
-#~ msgid "Remove duplicates:"
-#~ msgstr "Mazání duplicit:"
-#~ msgid "Break boundaries:"
-#~ msgstr "Zlomit hranice:"
-#~ msgid "Clean boundaries at nodes:"
-#~ msgstr "Vyèistit hranice na uzlech:"
-#~ msgid "Remove bridges:"
-#~ msgstr "Mazání mostù:"
-#, fuzzy
-#~ msgid "Write centroids:"
-#~ msgstr "Zapisuji centroidy ..."
-#~ msgid "Cannot calculate centroid"
-#~ msgstr "Nelze spoèítat centroid plochy"
-#, fuzzy
-#~ msgid "Unknown icon marker"
-#~ msgstr "Neznámý typ sloupce"
-#, fuzzy
-#~ msgid "Write output to PNG image"
-#~ msgstr "Rozsah výstupních dat"
-#~ msgid "Verbose mode"
-#~ msgstr "Roz¹íøený mód"
-#, fuzzy
-#~ msgid "Input type point, line or area"
-#~ msgstr "Vyberte typ: linie nebo plocha"
-#, fuzzy
-#~ msgid "Name for output vector map"
-#~ msgstr "Název výstupní vektorové vrstvy"
-#, fuzzy
-#~ msgid "Name of raster plane to be created"
-#~ msgstr "Název rastrové mapy která bude zobrazena"
-#, fuzzy
-#~ msgid "vector, interpolation, kriging"
-#~ msgstr "vektor, interpolace"
-#, fuzzy
-#~ msgid "Verbosity level"
-#~ msgstr "Úroveò hladiny"
-#, fuzzy
-#~ msgid "Name for output raster map prefix (e.g. 'brov')"
-#~ msgstr "Název výstupní rastrové mapy(green-zelená)"
-#, fuzzy
-#~ msgid "raster input map"
-#~ msgstr "rastr, import"
-#, fuzzy
-#~ msgid "Vector map to modify"
-#~ msgstr "Vektorová mapa pro pøekrytí"
-#, fuzzy
-#~ msgid "Layer in the vector to be modified"
-#~ msgstr "Bodová vektorová mapa musí být specifikována"
-#, fuzzy
-#~ msgid "Vector map to be queried"
-#~ msgstr "Rastrová mapa, která bude dotazována"
-#, fuzzy
-#~ msgid "Layer of the query vector containing data"
-#~ msgstr "Vstupní mapa obsahující linie"
-#, fuzzy
-#~ msgid "Column to be queried"
-#~ msgstr "|Sloupec musí být èíselnéh typu"
-#, fuzzy
-#~ msgid "Output raster map (default: input tile)"
-#~ msgstr "Jméno výstupní rastrové mapy (výchozí: jméno vstupní mapy)"
-#, fuzzy
-#~ msgid "Name of input vector map"
-#~ msgstr "Jméno vstupní 2D vektorové mapy"
-#, fuzzy
-#~ msgid "Vector map to edit the attribute table for"
-#~ msgstr "vektor, rastr, tabulka atributù"
-#, fuzzy
-#~ msgid "Column to update"
-#~ msgstr "Typ sloupce není podporován"
-#, fuzzy
-#~ msgid "Column to query"
-#, fuzzy
-#~ msgid "Raster map to use as mask"
-#~ msgstr "Rastrová mapa pou¾itá jako MASKa"
-#, fuzzy
-#~ msgid "New schema"
-#~ msgstr "Schéma databáze."
-#, fuzzy
-#~ msgid "Vector map for which to rename attribute column"
-#~ msgstr "Jméno vstupní vektorové bodové mapy"
-#~ msgid "vector, import"
-#~ msgstr "vektor, import"
-#, fuzzy
-#~ msgid "Field separator"
-#~ msgstr "Výstupní oddìlovaè sloupcù"
-#, fuzzy
-#~ msgid "display, vector, thematic, legend"
-#~ msgstr "zobrazení"
-#~ msgid "vector, topology"
-#~ msgstr "vektor, topologie"
-#, fuzzy
-#~ msgid "Name of vector map for which to edit attribute table"
-#, fuzzy
-#~ msgid "Table from which to drop attribute column"
-#~ msgstr "Mìøítkový faktor pro hodnoty atributù"
-#, fuzzy
-#~ msgid "Raster map in which to fill nulls"
-#~ msgstr "Rastrová její¾ soubor NULL bude editován"
-#, fuzzy
-#~ msgid "Vector map from which to remove attribute table"
-#~ msgstr "Název rastrové mapy, ze které se má kopírovat tabulka kategorií"
-#, fuzzy
-#~ msgid "Name of existing attribute table (default: vector map name)"
-#~ msgstr "Nelze kopírovat atributovou tabulku do vektorové mapy <%s>"
-#, fuzzy
-#~ msgid "Layer from which to drop linked attribute table"
-#, fuzzy
-#~ msgid "Vector map for which to drop attribute column"
-#, fuzzy
-#~ msgid "raster output TC maps prefix"
-#~ msgstr "Pøepsat výstupní soubor mapy"
-#, fuzzy
-#~ msgid "Vector map for which to add new attribute table"
-#, fuzzy
-#~ msgid "vector, import, wfs"
-#~ msgstr "vektor, import, body"
-#, fuzzy
-#~ msgid "Name of data table"
-#~ msgstr "Název souboru s filtrem"
-#, fuzzy
-#~ msgid "Database driver"
-#~ msgstr "Vypi¹ v¹echny databázové ovladaèe."
-#, fuzzy
-#~ msgid "Cannot open file [%s] in mapset [%s]"
-#~ msgstr "nemohu otevøít soubor 3dview <%s> v <%s>"
-#, fuzzy
-#~ msgid "Cannot create file <%s> in mapset <%s>"
-#, fuzzy
-#~ msgid "input,cell,raster"
-#, fuzzy
-#~ msgid "basemap"
-#~ msgstr "Mazání pøívìskù"
-#, fuzzy
-#~ msgid "Solar zenith in degrees"
-#~ msgstr "Úhle hlavních os ve stupních"
-#, fuzzy
-#~ msgid "method"
-#~ msgstr "Neznámá metoda"
-#~ msgid "Cannot allocate memory for auxiliar matrix.Consider changing region resolution"
-#~ msgstr "Nelze alokovat pamì« pro podpùrnou matici. Zva¾uji zmìnu rozli¹ení regionu "
-#~ msgid "Raster value"
-#~ msgstr "Rastrová hodnota"
-#~ msgid "ASPECT [%s] COMPLETE"
-#~ msgstr "MAPA EXPOZICE [%s] DOKONÈENA"
-#~ msgid "SLOPE [%s] COMPLETE"
-#~ msgstr "MAPA SKLONOVÝCH POMÌRÙ [%s] DOKONÈENA"
-#~ msgid "PROFILE CURVE [%s] COMPLETE"
-#~ msgstr "PROFILOVÁ KØIVOST [%s] DOKONÈENA"
-#~ msgid "TANGENTIAL CURVE [%s] COMPLETE"
-#~ msgstr "TANGENCIÁLNÍ KØIVOST [%s] DOKONÈENA"
-#~ msgid "E-W SLOPE [%s] COMPLETE"
-#~ msgstr "MAPA V-Z SKLONOVÝCH POMÌRÙ [%s] DOKONÈENA"
-#~ msgid "N-S SLOPE [%s] COMPLETE"
-#~ msgstr "MAPA S-J SKLONOVÝCH POMÌRÙ [%s] DOKONÈENA"
-#~ msgid "DXX [%s] COMPLETE"
-#~ msgstr "MAPA DXX [%s] DOKONÈENA"
-#~ msgid "DYY [%s] COMPLETE"
-#~ msgstr "MAPA DYY [%s] DOKONÈENA"
-#~ msgid "DXY [%s] COMPLETE"
-#~ msgstr "MAPA DXY [%s] DOKONÈENA"
-#~ msgid "It was impossible to create <Auxiliar_outlier_table>."
-#~ msgstr "Bylo mo¾no vytvoøit <Auxiliar_outlier_table>."
-#~ msgid "M.Q. solution"
-#~ msgstr "Øe¹ení M.Q."
-#~ msgid "3-d data in dxf file. Polyline_flag: %d"
-#~ msgstr "3-d data v souboru dxf. Polyline_flag: %d"
-#~ msgid "<Auxiliar_edge_table> created in database."
-#~ msgstr "<pomocná_tabulka> vytvoøena v databázi."
-#, fuzzy
-#~ msgid "Pass %d:"
-#~ msgstr "Prùchod %d..."
-#~ msgid "Creating auxiliar table for archiving overlapping zones"
-#~ msgstr "Vytvoøení pomocné tabulky pro archivaci pøekrývajících se zón"
-#, fuzzy
-#~ msgid "Unable to open table <%s_edge_Interpolation>"
-#~ msgstr "Nelze otevøít databázi <%s>"
-#~ msgid "It was not possible to drop <%s> table. Nothing will be done. Try to drop it manually."
-#~ msgstr "Nelze vyjmout tabulku <%s>. Nic se nestalo. Zkuste vyjmout tabulku ruènì."
-#~ msgid "Cross Validation was success!"
-#~ msgstr "Køí¾ová validace byla íºspì¹ná!"
-#~ msgid "Interpolation: The region resolution is too high: %d cells. Consider to change it."
-#~ msgstr "Interpolace: Rozli¹ení regionu je pøíli¹ vysoké: %d bunìk. Prosím, zmìòte jej."
-#~ msgid "Script kill option"
-#~ msgstr "Volba skriptu kill"
-#~ msgid "Start in Demo mode"
-#~ msgstr "Spustit v módu Demo"
-#~ msgid "Output more comments (default=quiet)"
-#~ msgstr "Více komentáøù na výstup (výchozí=potichu)"
-#~ msgid "Spline type of interpolation"
-#~ msgstr "Spline typ interpolace"
-#~ msgid "It was impossible to open table"
-#~ msgstr "Nebylo mo¾né otevøít tabulku"
-#~ msgid "Name of output vector area map"
-#~ msgid "Do not export long colortable"
-#~ msgstr "nelze exportovat dlouhou tabulku barev"
-#~ msgid "Input raster map contains cells with NULL-value (no-data). The value %d was used to represent no-data values in the input map. You can specify nodata value by %s parameter."
-#~ msgstr "Vstupní rastrová mapa obsahující NULLové hodnoty (¾ádná data). Pro NULLové hodnoty byla pou¾ita hodnota %d. Mù¾ete urèit hodnotu reprezentující NULLové hodnoty parametrem %s."
-#~ msgid "SECTION 3: Accumulating Surface Flow."
-#~ msgstr "ÈÁST 3: Akumulace povrchového odtoku."
-#~ msgid "SECTION 4: Length Slope determination."
-#~ msgstr "ÈÁST 4: Urèuji délku svahu."
-#~ msgid "unable to open new L map layer."
-#~ msgstr "Nelze otevøít novou mapu L (faktoru délky svahu)"
-#~ msgid "unable to open new S map layer."
-#~ msgstr "nemohu otevøít novou mapu S (faktor sklonu svahu)"
-#~ msgid ""
-#~ "Sorry, if any of the following options are set:\n"
-#~ "    basin, stream, half.basin, slope, or lS\n"
-#~ "    you MUST provide a value for the basin threshold parameter."
-#~ msgstr ""
-#~ "Promiòte, pokud je zadána nìkterá z následujících voleb:\n"
-#~ "    basin, stream, half.basin, slope nebo LS\n"
-#~ "    MUSÍTE zadat prahovou hodnotu povodí (basin threshold)."
-#~ msgid "raster3d, statistics"
-#~ msgstr "rastr3d, statistika"
-#~ msgid "Illegal configuration file"
-#~ msgstr "Neplatný konfiguraèní soubor"
-#~ msgid "Feature type. Combination of types is not supported by all formats."
-#~ msgstr "Typ prvky. Kombinace typù není podporována v¹emi formáty."
-#~ msgid "vector, query"
-#~ msgstr "vektor, dotazování"
-#~ msgid "r.li.worker (pid %i) exited with abnormal status %i"
-#~ msgstr "r.li.worker (pid %i) byl ukonèen s abnormálním statusem %i"
-#~ msgid "r.li.worker (pid %i) terminated"
-#~ msgstr "r.li.worker (pid %i) ukonèen"
-#~ msgid "Cannot make stat of %s configuration file"
-#~ msgstr "Nelze vytvoøit statistiku pro konfiguraèní soubor %s"
-#~ msgid "CHILD[pid = %i]: unable to open %s mask ... continue without!!!"
-#~ msgstr "DCEØINÝ PROCES[pid = %i]: nelze otevøít soubor s maskou %s ... pokraèuji bez ní!"
-#~ msgid "Show the category label in the grid cell(s)"
-#~ msgstr "Uka¾ ¹títek kategorie v buòce rastrového souboru"
-#~ msgid "Seed [%d] larger than maximum [%d]"
-#~ msgstr "Poèátek [%d] je vìt¹í ne¾ maximum [%d]"
-#~ msgid "Seed [%d] smaller than minimum [%d]"
-#~ msgstr "Poèátek [%d] je men¹í, ne¾ minimum [%d]"
-#~ msgid "point;simple x,y[,z] list;standard;GRASS's vector ASCII format"
-#~ msgstr "point;bodový formát (x,y[,z]);standard;GRASS vektorový ASCII formát"
-#~ msgid "Number of column used as y coordinate (first column is 1) for points mode"
-#~ msgstr "Èíslo sloupce pou¾itého jako souøadnice y (první sloupec je 1) pro bodový re¾im"
-#~ msgid "Number of column used as z coordinate (first column is 1) for points mode"
-#~ msgstr "Èíslo sloupce pou¾itého jako souøadnice z (první sloupec je 1) pro bodový re¾im"
-#~ msgid "If 0, z coordinate is not used"
-#~ msgstr "Jestli 0, z souøadnice nebude pou¾ita"
-#~ msgid "Number of column used as category (first column is 1) for points mode"
-#~ msgstr "Èíslo sloupce pou¾itého jako categorie (první sloupec je 1) pro bodový re¾im"
-#~ msgid "If 0, unique category is assigned to each row and written to new column 'cat'"
-#~ msgstr "Pokud 0, bude pøiøazena ka¾dému øádku unikátní kategorie a zapsána do nového sloupce 'cat'."
-#~ msgid "Create a new empty vector map and exit. Nothing is read from input"
-#~ msgstr "Vytvoøit novou prázdnou vektorovou mapu a ukonèit se. Nic nebude èteno ze vstupu."
-#~ msgid "Converts to one of the supported OGR vector formats."
-#~ msgstr "Konvertuje mapu do jednoho z podporovaných vektorových formátù OGR."
-#~ msgid "Exporting %i points/lines..."
-#~ msgstr "Exportuji %i body/linie..."
-#~ msgid "Computing row %d of covariance matrix..."
-#~ msgid "Converting %s..."
-#~ msgstr "Pøevádím %s..."
-#~ msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)"
-#~ msgstr "Simulace transportu sedimentù a eroze/usazování za pou¾ití vzorové cesty (SIMWE)"
-#~ msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)"
-#~ msgstr "Hydrologický model povrchového odtoku s pou¾itím metody vzorové cesty (SIMWE)"
-#~ msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation layer."
-#~ msgstr "Z rastrové mapy digitálního modelu terénu odstraní umìle vytvoøené sní¾eniny a vytvoøí mapu smìru odtoku."
-#~ msgid "Calculates cast shadow areas from sun position and DEM. Either A: exact sun position is specified, or B: date/time to calculate the sun position by r.sunmask itself."
-#~ msgstr "Poèítá plnì zastínìné oblasti z polohy Slunce a DMT buï A: je-li specifikována pøesná pozice Slunce nebo B: pozice je spoèítána samostatnì z hodnoty datum/èas pomocí r.sunmask."
-#~ msgid "A: altitude of the sun above horizon, degrees"
-#~ msgstr "A: vý¹ka Slunce nad horizontem, stupnì"
-#~ msgid "B: minutes (0..60)"
-#~ msgstr "B: minuty (0..60)"
-#~ msgid "B: seconds (0..60)"
-#~ msgstr "B: vteøiny (0..60)"
-#~ msgid "B: timezone (east positive, offset from GMT, also use to adjust daylight savings)"
-#~ msgstr "B: èasová zóna (východ kladná, vzdálenost od Greewichského støedního èasu (GMT), lze také zahrnout letní/zimní èas)"
-#~ msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)"
-#~ msgstr "Konsrukce svahových køivek (drah odtoku), délek odtoku a hustoty odtoku (do svahu) z rastrové mapy elevace (DMT)"
-#~ msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
-#~ msgstr "Vytvoøí mapu topografického indexu, [ln(a/tan(beta))], z rastrové mapy digitálního modelu terénu."
-#, fuzzy
-#~ msgid "Unable to read symbol, unable todisplay points"
-#~ msgstr "Nelze èíst symbol, nemohu zobrazit body"
-#, fuzzy
-#~ msgid "Name for output file (do not add extension)"
-#~ msgstr "Jméno výstupního souboru s výsledky chybové matice a kappa index"
-#, fuzzy
-#~ msgid "Width and height of output image"
-#~ msgstr "©íøka a vá¹ka oken v møí¾ce"
-#, fuzzy
-#~ msgid "Surface"
-#, fuzzy
-#~ msgid "Volume"
-#~ msgstr "sloupec(ce)"
-#, fuzzy
-#~ msgid "Vector map for which to edit attribute table"
-#~ msgid "Raster file(s) for View%d"
-#~ msgstr "Rastrové soubor(y), které mají být zobrazeny%d"
-#~ msgid "File type"
-#~ msgstr "Typ souboru"
-#, fuzzy
-#~ msgid "%s file(s) to be copied"
-#~ msgstr "Název rastrového souboru, který má být spojen"
-#, fuzzy
-#~ msgid "%s file(s) to be removed"
-#, fuzzy
-#~ msgid "-s and -n are mutually exclusive"
-#, fuzzy
-#~ msgid "%s file(s) to be renamed"
-#, fuzzy
-#~ msgid "Name of a mapset"
-#~ msgstr "Název cílového mapsetu"
-#, fuzzy
-#~ msgid "Layer number (if -1, all layers are displayed)"
-#~ msgstr "Èíslo vrstvy (Pokud -1, jsou vyjmuty v¹echny prvky ve v¹ech vrstvách.)"
-#, fuzzy
-#~ msgid "Unable to display topology, not available"
-#~ msgstr "Nelze kopírovat tabulku"
-#~ msgid "Remove lines and areas smaller than threshold"
-#~ msgstr "Odstranit v¹echny linie a plochy men¹í ne¾ mezní hodnota"
-#~ msgid "%d boundaries were deleted, input areas are not preserved"
-#~ msgstr "%d hranic bylo vymazáno, vstupní plochy nejsou zachovány"
-#~ msgid "Unable to calculate centroid for area %d"
-#~ msgstr "Nelze spoèítat centroid pro plochu %d"
-#~ msgid "New centroids were calculated, attribute attachment may be changed"
-#~ msgstr "Nové centroidy byly vypoèteny, atributová pøíloha ml¾e být zmìnìna"
-#~ msgid "Areas may have disappeared and/or area attribute attachment may have changed"
-#~ msgstr "Plochy mohou zmizet a/nebo se mohou zmìnit jejich atributy"
-#~ msgid "Try v.clean tool=prune thresh=%f"
-#~ msgstr "Zkuste v.clean tool=prune tresh=%f"
-#~ msgid "OGR format"
-#~ msgstr "Formát OGR."
-#~ msgid "break;break lines at each intersection;rmdupl;remove duplicate geometry features (pay attention to categories!);rmdangle;remove dangles, threshold ignored if < 0;chdangle;change the type of boundary dangle to line, threshold ignored if < 0, input line type is ignored;rmbridge;remove bridges connecting area and island or 2 islands;chbridge;change the type of bridges connecting area and island or 2 islands from boundary to line;snap;snap lines to vertex in threshold;rmdac;remove duplicate area centroids ('type' option ignored);bpol;break (topologically clean) polygons (imported from non topological format, like ShapeFile). Boundaries are broken on each point shared between 2 and more polygons where angles of segments are different;prune;remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachement of centroid), first and last segment of the boundary is never changed;rmarea;remove smal
 l areas, the longest boundary with adjacent area is removed;rmline;remove all lines or boundaries of zero length, threshold is ignored;rmsa;remove small angles between lines at nodes"
-#~ msgstr "break; zlomí linie na v¹ech køí¾eních; rmdupl; sma¾e duplicitní linie (pozor na kategorie!); rmdagngle; sma¾e pøívìsky, prahová hodnota je ignorována pokud <0; chdangle; zmìní typ pøívìsku z hranice na linii, prahová hodnota je ignorována pokud < 0, vyp vstupní linie je ignorován; rmbridge; sma¾e mosty obsahující plochu a ostrov nebo dva ostrovy; chbridge; zmìò typ mostu spojujícího plochu a ostrov nebo dva ostrovy z hranice na linii; snap; spojí nespojené koncové body linií vzdálené ménì ne¾ prahová hodnota; rmdac; remove duplicitní centroidy v plo¹e (volba 'type' ignorována); bpol; zlomý (topologicky èisté) polygony (importované z netopologických formátù jako je shapefile). Hranice jsou zlomeny na ka¾dém bodì sdíleném mezi 2 a více polygny, kde úhly segmentù jsou rùzné; prune; sma¾e lomové body z linií a hranic v rámci prahové hodnoty. Hranice je vyèi¹tìna pouze pokud nedojde k naru¹ení topologie (nové køí¾ení, zmìna pøíslu¹ného centroidu), první a poslední segm
 ent linie není zmìnìn; rmarea; sma¾e malé plochy a pøiøadí je k sousední plo¹e s nejdel¹í spoleènou hranicí; rmsa; sma¾e malé úhly mezi liniemi a uzly"
-#~ msgid "Print vector history instead of info"
-#~ msgstr "Vypí¹e historii vektorové mapy namísto infa"
-#~ msgid "File containing mapping instructions (or use input=- to enter from keyboard)"
-#~ msgstr "Soubor obsahující instrukce pro vytvoøení výstupu (nebo input=- a zadat je klavesnicí)"
-#~ msgid "Scale of the output map, e.g. 1:25000 (default: Auto-sized to fit page)"
-#~ msgstr "Mìøítko výstupní mapy, napø. 1:25000 (výchozí: automatická velikost podle velikosti stránky)"
-#~ msgid "Using <%s> from the command line is depreciated. Please use the <%s> mapping instruction instead. The parameter <%s> will be removed in future versions of GRASS."
-#~ msgstr "V pøíkazovém øádku by se <%s> nemìlo pou¾ívat. Prosím pou¾ijte místo toho instrukci <%s>. V budoucích verzích GRASSu nebude parametr <%s> pøítomen."
-#~ msgid ""
-#~ "\n"
-#~ "    (%s).\n"
-#~ msgstr ""
-#~ "\n"
-#~ "CHYBA: Po¾adovaný parametr <%s> nebyl nastaven:\n"
-#~ "    (%s).\n"
-#~ msgid "GRASS environment variable GRASS_VERBOSE is overwritten by VERBOSE mapping instruction. This mapping instruction is superseded and will be removed in future versions of GRASS. Please use --verbose instead."
-#~ msgstr "Grass promìnná prostøedí GRASS_VERBOSE je pøepsána VERBOSE mapovou instrukcí. Tato mapová instrukce je vyøazena a bude odstranìna v dal¹ích verzích GRASSu. Prosím pou¾ijte radìji --verbose."
-#~ msgid "Cannot set GRASS_VERBOSE variable."
-#~ msgstr "Nemohu nastavit promìnnou prostøedí GRASS_VERBOSE."
-#~ msgid "data compression required an additional"
-#~ msgstr "Komprese dat vy¾aduje pøídavné"
-#~ msgid "Rectified input raster map <%s> will be saved as <%s>"
-#~ msgstr "Vstupní rastrová mapy <%s> vbyla rektifikována a ulo¾ena jako <%s>"
-#~ msgid "Link GDAL supported raster file to a binary raster map layer."
-#~ msgstr "Spojení GDAL podporovaného rastrovho souboru s binární rastrovou mapovou vrstvou"
-#~ msgid "Required"
-#~ msgstr "Po¾adováno"
-#~ msgid "Name of filter file"
-#~ msgid "Location of input raster map"
-#~ msgstr "Location vstupní mapy"
-#~ msgid "Mapset of input raster map"
-#~ msgstr "Mapset vstupní rastrové mapy"
-#~ msgid "Checking location <%s>, mapset <%s>..."
-#~ msgstr "Kontroluji location <%s>, mapset <%s>..."
-#~ msgid "Quiet - suppress progress report"
-#~ msgstr "Ti¹e - potlaè hlá¹ení o prùbìhu zpracování"
-#~ msgid "Output file name not specified"
-#~ msgstr "Nebylo zadáno jméno výstupního rastrového souboru"
-#, fuzzy
-#~ msgid "Exporting to GDAL raster"
-#~ msgstr "export do datového typu GDAL: %s"
-#~ msgid " %d.%02d.%02d, daynum %d, time: %02i:%02i:%02i (decimal time: %f)\n"
-#~ msgstr " %d.%02d.%02d, èíslo dne %d, èas: %02i:%02i:%02i (decimálnì: %f)\n"
-#~ msgid " long: %f, lat: %f, timezone: %f\n"
-#~ msgstr " délka: %f, ¹íøka: %f, èasová zóna: %f\n"
-#~ msgid ""
-#~ " Solar position: sun azimuth: %f,\n"
-#~ "   sun angle above horz.(refraction corrected): %f\n"
-#~ msgstr ""
-#~ " Poloha Slunce: Azimut: %f,\n"
-#~ "   vý¹ka Slunce nad horizontem. (odraz opraven): %f\n"
-#~ msgid " Sunrise time (without refraction): %02d:%02d:%02d\n"
-#~ msgstr " Èas východu Slunce (bez refrakce): %02d:%02d:%02d\n"
-#~ msgid " Sunset time  (without refraction): %02d:%02d:%02d\n"
-#~ msgstr " Èas západu Slunce (bez refrakce): %02d:%02d:%02d\n"
-#~ msgid "No map calculation requested. Finished.\n"
-#~ msgstr "Není po¾adována ¾ádný výpoèet mapy. Konèím.\n"
-#~ msgid "Can't open range file for %s"
-#~ msgstr "nemohu otevøít soubor s rozsahem pro %s"
-#~ msgid "<%s> created"
-#~ msgstr "<%s> vytvoøen"
-#~ msgid "Raster map to be recoded"
-#~ msgstr "Rastrová mapa, která má být pøekódována"
-#, fuzzy
-#~ msgid "Overlay (non-null values only)"
-#~ msgstr "Uspoøádat neNULLové hodnoty"
-#, fuzzy
-#~ msgid "Raster map to be displayed"
-#~ msgstr "Rastrová mapa, která má být vzorkována"
-#~ msgid "Change dangles to lines:"
-#~ msgstr "Zmìnit pøívìsky na linie:"
-#~ msgid "Allows projection conversion of vector maps."
-#~ msgstr "Umo¾òuje zmìnu projekce vektorových map."
-#, fuzzy
-#~ msgid "Vector output map"
-#~ msgstr "®ádné výstupní mapy"
-#~ msgid "Error while writing to temp file"
-#~ msgstr "Chyba pøi zápisu doèasného souboru"
-#, fuzzy
-#~ msgid "r.li.worker (pid %i) exited with abnormal status: %i"
-#, fuzzy
-#~ msgid "r.li.worker (pid %i) terminated successfully"
-#, fuzzy
-#~ msgid "Unable to read raster map row %ld"
-#~ msgstr "Nelze èíst rastrovou mapu, øádek %d"
-#, fuzzy
-#~ msgid "Failed writing raster map row %ld"
-#~ msgstr "Selhalo zapisování øádku %d rastrové mapy"
-#, fuzzy
-#~ msgid "raster, random, surface"
-#, fuzzy
-#~ msgid "raster, random, cell"
-#~ msgstr "rastr, pøevzorkování"
-#~ msgid "Not enough room in history file"
-#~ msgstr "Pro soubor s historií není dost místa"
-#, fuzzy
-#~ msgid "<%s> not found in mapset list"
-#~ msgstr "Sloupec <%s> nebyl nalezen v tabulce <%s>"
-#, fuzzy
-#~ msgid "Name of workspace file"
-#~ msgstr "Jméno souboru s barvou"
-#, fuzzy
-#~ msgid "List of values to be displayed (FP maps)"
-#~ msgstr "Seznam hodnot bunìk pro maskování"
-#, fuzzy
-#~ msgid "Ignoring catlist: map is floating point (please use 'val=')"
-#~ msgstr "Exportuji rastr jako mapu s hodnotami s plovoucí desetinnou èárkou"
-#~ msgid "Area size [%.1e], area not imported"
-#~ msgstr "Velikost plochy [%.1e] plocha nebude importována"
-#~ msgid "Island size [%.1e], island not imported"
-#~ msgstr "Velikost ostrova [%.1e] ostrov nebude importován"
-#~ msgid "No vector map of sparse points to interpolate was specified. Interpolation will be done with <%s> vector map"
-#~ msgstr "®ádná vektorová mapa pro interpolaci. Interpolace bude aplikována na vektorové mapì <%s>"
-#, fuzzy
-#~ msgid "Failed in attempt to open %s"
-#~ msgid "Generates raster map layers of slope, aspect, curvatures and partial derivatives from a raster map layer of true elevation values. Aspect is calculated counterclockwise from east."
-#~ msgstr "Vytvoøí rastrovou mapu sklonu, expozice, køivosti a parciálních derivací odvozenou z digitálního modelu terénu. Expozice je poèítána proti smìru hodinových ruèièek s poèátkem na východì."
-#, fuzzy
-#~ msgid "Output slope filename"
-#~ msgstr "Název výstupní tabulky"
-#, fuzzy
-#~ msgid "Output profile curvature filename"
-#~ msgstr "Název výstupního souboru profilových køivostí"
-#, fuzzy
-#~ msgid "Output tangential curvature filename"
-#~ msgstr "Název výstupního souboru tangenciálních køivostí"
-#, fuzzy
-#~ msgid "Output first order partial derivative dx (E-W slope) filename"
-#~ msgstr "Název výstupní rastrové mapy parciálních derivací prvního øádu dx (V-Z sklon svahu)"
-#, fuzzy
-#~ msgid "Output first order partial derivative dy (N-S slope) filename"
-#~ msgstr "Název výstupní rastrové mapy parciálních derivací prvního øádu dy (S-J sklon svahu)"
-#, fuzzy
-#~ msgid "Output second order partial derivative dxx filename"
-#~ msgstr "Název výstupnírastrové mapy parciálních derivací druhého øádu dxx"
-#, fuzzy
-#~ msgid "Output second order partial derivative dyy filename"
-#~ msgstr "Název výstupnírastrové mapy parciálních derivací druhého øádu dyy"
-#, fuzzy
-#~ msgid "Output second order partial derivative dxy filename"
-#~ msgstr "Název výstupní rastrové mapy parciálních derivací druhého øádu dxy"
-#~ msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead."
-#~ msgstr "Pøepínaè '-q' je zastaralý a bude v budoucnosti odstranìn. prosím, peou¾ijte pøepínaè '--quiet'."
-#, fuzzy
-#~ msgid "wrong type: %s"
-#~ msgstr "Chybný typ rastrové mapy: %s"
-#, fuzzy
-#~ msgid "Creating support files..."
-#~ msgstr "Vytváøím podpùrné soubory BIL..."
-#, fuzzy
-#~ msgid "Elevation products for mapset [%s] in [%s]"
-#~ msgstr "Vý¹kové produkty pro mapset <%s> v <%s>"
-#~ msgid "Sources and sinks in [m^3/s]"
-#~ msgstr "Prameny a jezera v [m^3/s]"
-#~ msgid "Specific yield in 1/m"
-#~ msgstr "Specifický výnos 1/m"
-#~ msgid "Input elevation map"
-#~ msgstr "Vstupní mapa elevace."
-#, fuzzy
-#~ msgid "Output shaded relief map name"
-#~ msgstr "Název výstupního ovladaèe"
-#, fuzzy
-#~ msgid "Layer number of data column"
-#~ msgid "Name of vector input map containing stream(s)"
-#~ msgstr "Název vstupní vektorové vrstvy obsahující dráhy odtoku"
-#~ msgid "Generates a raster map layer showing watershed subbasins."
-#~ msgstr "Vytvoøí rastrovou mapu ukazující dílèí povodí v povodích."
-#~ msgid "Coded stream network file name"
-#~ msgstr "Soubor øíèní sítì, obsahující kódové oznaèení øádu tokù"
-#~ msgid "Thinned ridge network file name"
-#~ msgstr "Soubor se sítí ztenèených høbetù"
-#~ msgid "Name for the resultant watershed partition file"
-#~ msgstr "Jméno výsledného souboru s rozdìlenými povodími"
-#, fuzzy
-#~ msgid "Input raster map contains cells with NULL-value (no-data). The value %f will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
-#~ msgid "Name of the elevation raster map [m]"
-#~ msgstr "Jméno rastrové mapy elevace [m]"
-#~ msgid "Output water depth raster map [m]"
-#~ msgstr "Výstupní rastrová mapa hloubky vody [m]"
-#~ msgid "Output elevation raster map"
-#~ msgstr "Název výstupního digitálního modelu terénu"
-#~ msgid "Input elevation raster map"
-#~ msgstr "Název vstupní mapy digitálního modelu terénu"
-#~ msgid "Input aspect raster map"
-#~ msgstr "Název vstupního souboru expozic svahù"
-#~ msgid "Input barrier raster map"
-#~ msgstr "Vstupní rastrová mapa bariér"
-#~ msgid "Output flowline vector map"
-#~ msgstr "Výstupní vektorový soubor drah odtoku"
-#~ msgid "Output raster map having shadows"
-#~ msgstr "Výstupní rastrová mapa obsahující plochy ve stínu"
-#~ msgid "By_position"
-#~ msgstr "Podle_pozice"
-#~ msgid "B: year (1950..2050)"
-#~ msgstr "B: rok (1950..2050)"
-#~ msgid "By_time"
-#~ msgstr "Podle_èasu"
-#~ msgid "B: month (0..12)"
-#~ msgstr "B: mìsíc (0..12)"
-#~ msgid "B: day (0..31)"
-#~ msgstr "B: den (0..31)"
-#~ msgid "B: hour (0..24)"
-#~ msgstr "B: hodina (0..24)"
-#~ msgid "East coordinate (point of interest, default: map center)"
-#~ msgstr "Východní souøadnice (bod zájmu, výchozí: støed mapy)"
-#~ msgid "North coordinate (point of interest, default: map center)"
-#~ msgstr "Severní souøadnice (bod zájmu, výchozí: støed mapy)"
-#~ msgid "Zero is a real elevation"
-#~ msgstr "Nula oznaèuje také vý¹ku nad moøem"
-#~ msgid "Verbose output (also print out sun position etc.)"
-#~ msgstr "roz¹íøený výstup (vytiskne také pozici Slunce atd.)"
-#~ msgid "(i)   Elevation map"
-#~ msgstr "(i)   Digitální model terénu"
-#~ msgid "(o)   Depressionless elevation map"
-#~ msgstr "(o)   Mapa vý¹ek zbavená depresí"
-#~ msgid "(o/i) Basin elevation map (MASK applied)"
-#~ msgstr "(i/o) Mapa vý¹ek v povodí (MASKa aplikována)"
-#~ msgid "(o)   Topographic index ln(a/tanB) map (MASK applied)"
-#~ msgstr "(i/o) Mapa topografického indexu ln(a/tanB) (MASKa aplikována)"
-#~ msgid "(o)   Output file"
-#~ msgstr "(o)   Výstupní soubor"
-#~ msgid "(i)   OPTIONAL Observed flow file"
-#~ msgstr "(i)   VOLITELNÉ pozorované dráhy odtoku"
-#~ msgid "(i)   OPTIONAL Output for given time step"
-#~ msgstr "(i)   VOLITELNÉ Výstup pro danou èasovou znaèku"
-#~ msgid "(i)   OPTIONAL Output for given topographic index class"
-#~ msgstr "(i)   VOLITELNÉ Výstup pro danou tøídu topografického indexu"
-#~ msgid "Name of existing raster map containing elevation surface"
-#~ msgstr "Jméno existujícího rastru obsahujícího digitální model terénu."
-#~ msgid "Output elevation raster map after filling"
-#~ msgstr "Výstupní rastrová mapa digitálního modelu terénu po vyplnìní sní¾enin"
-#~ msgid "Output aspect direction format (agnps, answers, or grass)"
-#~ msgstr "Výstupní formát smìru expozice (agnps, answers, or grass)("
-#~ msgid "Reading map..."
-#~ msgstr "Naèítám mapu..."
-#~ msgid "Failed to guess site file format\n"
-#~ msgstr "Selhalo hledání formátu souboru s body\n"
-#~ msgid "Watershed basin analysis program."
-#~ msgstr "Program na analýzu povodí"
-#~ msgid "Input map: elevation on which entire analysis is based"
-#~ msgstr "Vstupní mapa: digitální model terénu, na kterém je zalo¾ena celá analýza"
-#~ msgid "Input map: locations of real depressions"
-#~ msgstr "Vstupní mapa: umístìní skuteèných depresí"
-#~ msgid "Input map or value: percent of disturbed land, for USLE"
-#~ msgstr "Vstupní mapa nebo hodnota: procenta poru¹eného povrchu, pro USLE"
-#~ msgid "Output map: drainage direction"
-#~ msgstr "Výstupní mapa: smìr odtoku"
-#~ msgid "Output map: stream segments"
-#~ msgstr "Výstupní mapa: èásti tokù"
-#~ msgid "Watershed basin creation program."
-#~ msgstr "Program na vymezování povodí."
-#~ msgid "Name of raster map to contain results"
-#~ msgstr "Jméno rastrové mapy, obsahující výsledky"
-#~ msgid "The map N grid coordinates"
-#~ msgstr "Severní souøadnice mapy"
-#~ msgid "X-part of the hydraulic conductivity tensor in [m/s]"
-#~ msgstr "X-èást hydraulièkého napøimovaèe napìtí v [m/s]"
-#~ msgid "Y-part of the hydraulic conductivity tensor in [m/s]"
-#~ msgstr "Y-èást hydraulièkého napøimovaèe napìtí v [m/s]"
-#~ msgid "Decomposition failed"
-#~ msgstr "Dekompozice selhala"
-#~ msgid "<%s> created in database."
-#~ msgstr "<%s> vytvoøeno v databázi."
-#~ msgid "Unable to access table <%s>"
-#~ msgstr "Nelzepøistoupit k tabulce <%s>"
-#, fuzzy
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
-#~ msgstr "mi(míle),f(stopy),me(metry),k(kilometery),a(akry),h(hektary)"
-#, fuzzy
-#~ msgid "unable to open new LS factor map layer."
-#, fuzzy
-#~ msgid "unable to open new S factor map layer."
-#, fuzzy
-#~ msgid "Could not read from <%s>"
-#~ msgstr "Nelze otevøít mapu %s"
-#, fuzzy
-#~ msgid "Error reading row of data"
-#~ msgstr "Chyba pøi ètení divoké karty"
-#, fuzzy
-#~ msgid "Error reading intensity data"
-#~ msgstr "Chyba pøi ètení mapy intenzity"
-#, fuzzy
-#~ msgid "Error reading saturation data"
-#~ msgstr "Chyba pøi ètení mapy nasycení (saturation))"
-#, fuzzy
-#~ msgid "Error writing PROJ_INFO"
-#~ msgstr "Chuba pøi zápisu dat"
-#, fuzzy
-#~ msgid "Error writing PROJ_UNITS"
-#, fuzzy
-#~ msgid "Unable to compile regular expression %s"
-#~ msgstr "Nelze otevøít soubor s pravidly <%s>"
-#, fuzzy
-#~ msgid "Raster map <%s@%s>: %s"
-#~ msgstr "Rastrová mapa <%s> byla vytvoøena."
-#, fuzzy
-#~ msgid "Unable to open raster map <%s> in <%s>"
-#~ msgstr "Nelze otevøít rastrovou mapu <%s> v mapsetu <%s>"
-#, fuzzy
-#~ msgid "display, setup"
-#, fuzzy
-#~ msgid "display, networking"
-#~ msgstr "vektor, sí»ování"
-#, fuzzy
-#~ msgid "display, vector"
-#, fuzzy
-#~ msgid "general, transformation, GCP"
-#~ msgstr "vektor, transformace, 3D"
-#, fuzzy
-#~ msgid "general, settings"
-#~ msgstr "Opravte prosím nastavení."
-#, fuzzy
-#~ msgid "general, projection"
-#~ msgstr "raster, projekce"
-#, fuzzy
-#~ msgid "vector, import, GPS"
-#, fuzzy
-#~ msgid "Import waypoints"
-#~ msgstr "Importuji body ..."
-#, fuzzy
-#~ msgid "Import routes"
-#, fuzzy
-#~ msgid "Device or file used to import data"
-#, fuzzy
-#~ msgid "raster, imagery, colors"
-#~ msgstr "rastr, import, pøevod"
-#, fuzzy
-#~ msgid "vector, centroid, area"
-#~ msgstr "vektor, metadata"
-#, fuzzy
-#~ msgid "Configuration editor for r.li.'index'"
-#, fuzzy
-#~ msgid "vector, import, gazetteer"
-#, fuzzy
-#~ msgid "vector, export, GPS"
-#~ msgstr "vektor, export"
-#, fuzzy
-#~ msgid "raster, imagery, import"
-#, fuzzy
-#~ msgid "raster, statistics, aggregation"
-#~ msgstr "rastr, statistika, reklasifikace"
-#, fuzzy
-#~ msgid "imagery, fusion, Brovey"
-#~ msgstr "obrazová data, ortorektifikace"
-#, fuzzy
-#~ msgid "raster, imagery"
-#~ msgstr "rastr, mapová algebra"
-#, fuzzy
-#~ msgid "vector, area, dissolve"
-#~ msgstr "vektor, metadata, historie"
-#, fuzzy
-#~ msgid "raster, mask"
-#~ msgstr "rastr, metadata"
-#, fuzzy
-#~ msgid "vector, color table"
-#~ msgstr "rastr, tabulka barev"
-#, fuzzy
-#~ msgid "raster, elevation, interpolation"
-#~ msgstr "rastr, interpolace"
-#, fuzzy
-#~ msgid "vector, report, statistics"
-#~ msgstr "vektor, statistika"
-#, fuzzy
-#~ msgid "sites, vector, import"
-#, fuzzy
-#~ msgid "raster, imagery, statistics"
-#~ msgstr "rastr, statistika"
-#, fuzzy
-#~ msgid "raster, imagery, mosaicking"
-#, fuzzy
-#~ msgid "miscellaneous, projection"
-#~ msgstr "rùzné"
-#, fuzzy
-#~ msgid "visualization, raster, vector, raster3d"
-#~ msgstr "Organizace, kde byla vektorová mapa vytvoøena"
-#, fuzzy
-#~ msgid "raster, vector, visualization"
-#, fuzzy
-#~ msgid "Path to TrueType font (including file name)"
-#~ msgstr "Jméno TrueType fontu (jak je napsáno v fontcap)"
-#, fuzzy
-#~ msgid "Invalid font: %s"
-#~ msgstr "chybný region: %s"
-#, fuzzy
-#~ msgid "No current window"
-#~ msgstr "Nelze nastavit výøez"
-#, fuzzy
-#~ msgid "Current window not available"
-#~ msgstr "Soubor s tabulkou barev pro <%s> není dostupný"
-#, fuzzy
-#~ msgid "Unable to create text conversion context"
-#~ msgstr "Nelze vytvoøit index"
-#, fuzzy
-#~ msgid "Unable to write the temporary file"
-#~ msgstr "Nelze èíst doèasný soubor"
-#, fuzzy
-#~ msgid "No predefined font"
-#~ msgstr "Nelze èíst informace o vrstvì"
-#, fuzzy
-#~ msgid "%s: Unable to read font"
-#~ msgstr "Nelze èíst %s"
-#, fuzzy
-#~ msgid "%s: Unable to read FreeType definition file; use the default"
-#~ msgstr "%s: Nelze èíst definièní soubor FreeType; pou¾iji výchozí"
-#, fuzzy
-#~ msgid "%s: No FreeType definition file"
-#~ msgstr "%s: ®ádný definièní soubor FreeType"
-#, fuzzy
-#~ msgid "%s: Unable to read FreeType definition file"
-#, fuzzy
-#~ msgid "Display number of colors"
-#~ msgstr "Poèáteèní poèet tøíd"
-#, fuzzy
-#~ msgid "Setting map window"
-#~ msgstr "Nastavuji hlavièku výøezu"
-#, fuzzy
-#~ msgid "Getting screen window"
-#, fuzzy
-#~ msgid "Font name or pathname of TTF file"
-#~ msgstr "Jméno nového rastrového TIFF souboru."
-#, fuzzy
-#~ msgid "No raster or vector map displayed"
-#, fuzzy
-#~ msgid "Current window not settable"
-#~ msgstr "Nelze nastavit aktuální region."
-#, fuzzy
-#~ msgid "No raster map exists in the current window"
-#~ msgstr "Vstupní rastrová mapa je mimo aktuální region"
-#, fuzzy
-#~ msgid "Cannot use current window"
-#~ msgstr "Nelze pøenastavit aktuální region"
-#, fuzzy
-#~ msgid "Error reading raster map"
-#~ msgstr "Chyba pøi ètení rastrové mapy <%s>"
-#, fuzzy
-#~ msgid "Output profile data to file(s) with prefix 'name'"
-#~ msgstr "Prefix výstupního rastrového souboru"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Use mouse to choose action"
-#~ msgstr "Pro výbìr poèáteèního bodu pou¾ijte my¹\n"
-#, fuzzy
-#~ msgid "Error opening cell-file"
-#~ msgstr "Chyba pøi otevírání kanálu %i"
-#, fuzzy
-#~ msgid "Error reading from cell-file"
-#~ msgstr "Chyba pøi ètení doèasného souboru"
-#, fuzzy
-#~ msgid "%s: Couldn't open raster <%s@%s>"
-#~ msgstr "Nelze otevøít rastrovou mapu <%s>"
-#, fuzzy
-#~ msgid "Use mouse to size & place legend"
-#~ msgstr ""
-#~ "\n"
-#~ "Pou¾ít my¹ pro kreslení linie profilu\n"
-#, fuzzy
-#~ msgid "Interactively select route"
-#~ msgstr "Interaktivní výbìr koncových bodù"
-#, fuzzy
-#~ msgid "You must select more than one point"
-#~ msgstr "Musíte vybrat alespoò jeden nástroj"
-#, fuzzy
-#~ msgid "You must select at least four points"
-#, fuzzy
-#~ msgid "Error - Locking mechanism failed"
-#, fuzzy
-#~ msgid "Invalid rendering method <%s>"
-#~ msgstr "Neplatná metoda: %s"
-#, fuzzy
-#~ msgid "Use mouse to interactively place text"
-#~ msgstr ""
-#~ "\n"
-#, fuzzy
-#~ msgid " Left:    Place text here\n"
-#~ msgstr "Levé tlaèítko:  Oznaè dal¹í bod\n"
-#, fuzzy
-#~ msgid "ERROR: can not get \"list\" items"
-#~ msgstr "Nelze získat seznam tabulek:\n"
-#, fuzzy
-#~ msgid "Unix file containg graphing instructions, if not given reads from standard input"
-#~ msgstr "Soubor ASCII pro import, pokud není zadán, ète se standardní vstup"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Mouse Buttons:"
-#~ msgstr "Tlaèítka:\n"
-#, fuzzy
-#~ msgid "Middle: Select To\n"
-#~ msgstr "Prostøední tlaèítko: Oznaè dal¹í bod\n"
-#, fuzzy
-#~ msgid "selected %d bit depth"
-#~ msgstr "%d pixelù smazáno "
-#, fuzzy
-#~ msgid "Error choosing frame [%s]\n"
-#~ msgstr "Chyba pøi ètení rozsahu pro [%s]"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Buttons:\n"
-#, fuzzy
-#~ msgid "Create a new frame"
-#~ msgstr "Vytvoøit celoèíselnou mapu"
-#, fuzzy
-#~ msgid "Select a frame"
-#~ msgstr "Vyber data z tabulky."
-#, fuzzy
-#~ msgid "Print names of all frames"
-#~ msgstr "Vytiskni celkový rozsah ploch"
-#, fuzzy
-#~ msgid "Debugging output"
-#, fuzzy
-#~ msgid "No raster map exists in current window"
-#, fuzzy
-#~ msgid "Menu must contain a title and at least one option"
-#, fuzzy
-#~ msgid "No current frame"
-#~ msgstr "Nastav z aktuálního regionu"
-#, fuzzy
-#~ msgid "Current frame not available"
-#, fuzzy
-#~ msgid "Name of frame(s) to save"
-#~ msgstr "Tvùrce mapy: %s"
-#, fuzzy
-#~ msgid "Save current frame"
-#, fuzzy
-#~ msgid "Setting graphics window"
-#, fuzzy
-#~ msgid "Can't set current graphics window"
-#, fuzzy
-#~ msgid "Getting graphics window coordinates"
-#~ msgstr "Východní souøadnice mapy"
-#, fuzzy
-#~ msgid "Use mouse to interactively place scale"
-#~ msgstr ""
-#~ "\n"
-#, fuzzy
-#~ msgid "<%s> is an illegal region name"
-#~ msgstr "<%s> je neplatné jméno souboru"
-#, fuzzy
-#~ msgid "The projection information will not be updated."
-#~ msgstr "Pøedpona vstupní mapy s informacemi o horizontu"
-#, fuzzy
-#~ msgid "Erasing monitors..."
-#~ msgstr "Extrahuji body..."
-#, fuzzy
-#~ msgid "Removing %s <%s>"
-#~ msgstr "Naèítám <%s> v <%s>"
-#, fuzzy
-#~ msgid "<%s> nothing removed"
-#, fuzzy
-#~ msgid "Enter raster map to display in 1st frame"
-#, fuzzy
-#~ msgid "Enter raster map to display in 2nd frame"
-#, fuzzy
-#~ msgid "How to split display"
-#~ msgstr "Nelze otevøít displej"
-#, fuzzy
-#~ msgid "display, export"
-#, fuzzy
-#~ msgid "Name for output file (do NOT add extension)"
-#, fuzzy
-#~ msgid "Width and height of output image (overrides resolution setting)"
-#, fuzzy
-#~ msgid "Paper size for PostScript output"
-#~ msgstr "Výstupní soubor ve formátu PostScript"
-#, fuzzy
-#~ msgid "GeoTIFF metadata key(s) and value(s) to add"
-#~ msgstr "Klíèe metadat a hodnoty pro vlo¾ení"
-#, fuzzy
-#~ msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma."
-#~ msgstr "Ve výrazu \"NAME=VALUE\", oddìlte více polo¾ek èárkami."
-#, fuzzy
-#~ msgid "Do not crop away margins"
-#~ msgstr "Nekopírovat atributovou tabulku"
-#, fuzzy
-#~ msgid "Slide show of GRASS raster/vector maps."
-#~ msgstr "Importuje star¹í verze GRASS vektorových map."
-#, fuzzy
-#~ msgid "display, slideshow"
-#, fuzzy
-#~ msgid "Show vector maps rather than raster maps"
-#~ msgstr "Nastav region tak, aby odpovídal této rastrové mapì"
-#, fuzzy
-#~ msgid "Number of seconds to pause between slides"
-#~ msgstr "Poèet bunìk mezi drahami odtoku"
-#, fuzzy
-#~ msgid "A (grid3D file)"
-#, fuzzy
-#~ msgid "B (grid3D file)"
-#, fuzzy
-#~ msgid "C (grid3D file)"
-#, fuzzy
-#~ msgid "D (grid3D file)"
-#, fuzzy
-#~ msgid "E (grid3D file)"
-#, fuzzy
-#~ msgid "F (grid3D file)"
-#, fuzzy
-#~ msgid "Name for output grid3D volume"
-#~ msgstr "Název výstupního souboru"
-#, fuzzy
-#~ msgid "Do not overwrite existing map"
-#~ msgstr "Pou¾ijte -o k pøepsání existujícího spojení pro vrstvu <%d>"
-#, fuzzy
-#~ msgid "Display manager for GRASS"
-#, fuzzy
-#~ msgid "Name of .dmrc settings file"
-#, fuzzy
-#~ msgid "Percentile to calculate (requires -e flag)"
-#~ msgstr "Percentil, který se má spoèítat (vy¾aduje pøepínaè roz¹íøení statistiky)"
-#, fuzzy
-#~ msgid "Resizes active display monitor"
-#~ msgstr "Nahla¹ informace o vstupním rastru a ukonèi se"
-#, fuzzy
-#~ msgid "Exports GRASS raster into GDAL supported formats."
-#~ msgstr "Exportuje GRASS rastrové mapy do jednoho z formátù podporovaných knihovnou GDAL."
-#, fuzzy
-#~ msgid "Creation option to the output format driver. Multiple options may be listed"
-#~ msgstr "Vytvoøení mo¾ností pro uspì¹né projítí ovladaèem formátu výstupu"
-#, fuzzy
-#~ msgid "run non-interactively"
-#~ msgstr "Spustit interaktivnì"
-#, fuzzy
-#~ msgid "display, export, GPS"
-#, fuzzy
-#~ msgid "Run non-interactively"
-#, fuzzy
-#~ msgid "Name of GIS manager settings file (.grc)"
-#~ msgstr "Název existujícího MAT-souboru(v4)"
-#, fuzzy
-#~ msgid "Name of raster map to print in legend"
-#, fuzzy
-#~ msgid "Name of PNG file"
-#, fuzzy
-#~ msgid "Target monitor"
-#, fuzzy
-#~ msgid "Number of subframes"
-#~ msgstr "Poèet øádkù"
-#, fuzzy
-#~ msgid "Redraw all frames"
-#~ msgid "Import GDAL supported raster file into a binary raster map layer."
-#~ msgstr "Import rastrových souborù podporovaných knihovnou GDAL."
-#~ msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the currently defined region."
-#~ msgstr "Pøevede GRASS rastr do formátu PPM v rozli¹ení daném aktuálním regionem."
-#~ msgid "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel resolution of the currently defined region."
-#~ msgstr "Exportuje GRASS rastr do formátu TIFF 8/24bit v rozli¹ení daném aktuálním regionem."
-#~ msgid "If set to 0, z coordinates are used. (3D vector only)"
-#~ msgstr "Èíslo vrstvy. Pokud nastaveno na 0, jsou pou¾ity souøadnice z (pouze u 3D vektorù)"
-#~ msgid "Attribute table column with values to interpolate (if layer>0)"
-#~ msgstr "Tabulka atributù s hodnotami pro interpolaci (pokud layer>0)"
-#~ msgid ""
-#~ "\n"
-#~ "Enter database password for connection\n"
-#~ "<%s:%s:user=%s>\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Zadajte heslo k databázi pro spojení\n"
-#~ msgid "Hit RETURN to cancel request\n"
-#~ msgstr "Stisknìte RETURN pro ukonèení ¾ádosti\n"
-#~ msgid "Exiting. Not changing current settings"
-#~ msgstr "Konèím, nemìním aktuální nastavení"
-#~ msgid "New password set"
-#~ msgstr "Nové heslo bylo nastaveno."
-#~ msgid "Unable to close output map"
-#~ msgstr "Nelze zavøít výstupní mapu"
-#~ msgid "Unable to get elevation raster row"
-#~ msgstr "Nelze naèíst øádek rastru elevace"
-#~ msgid "Could not write raster row"
-#~ msgstr "Nelze zapsat øádek rastrové mapy"
-#~ msgid "Unable to open elevation map"
-#~ msgstr "nelze zavøít mapu elevace"
-#~ msgid "Unable to create raster map"
-#~ msgstr "Nelze vytvoøit rastrovou mapu"
-#~ msgid "Unable to close elevation map"
-#~ msgid "Use a sparse linear equation system, only available with iterative solvers"
-#~ msgstr "Pou¾ít lineární systém rovnic pro øídké matice, dostupný pouze pro iterativní solvery"
-#~ msgid "Could not open map %s"
-#~ msgid "Could not get top raster row \n"
-#~ msgstr "Nelze naèíst øádek svrchního rastru\n"
-#~ msgid "Could not get bottom raster row \n"
-#~ msgstr "Nelze naèít øádek spodního rastru\n"
-#~ msgid "Unable to write raster row"
-#~ msgstr "Nelze ènyní zapsat rastrovou mapu."
-#~ msgid "Unable to write quant file"
-#~ msgstr "Nelze zapisovat do souboru quant"
-#~ msgid "Unable to write color table for %s"
-#~ msgstr "Nelze zapsat barevnou tabulku pro %s"
-#~ msgid "Cannot write category file for raster map <%s>"
-#~ msgstr "Nelze soubor s kategoriemi pro <%s>"
-#~ msgid "Cannot open raster map <%s>"
-#~ msgid "Cannot create category file of <%s>"
-#~ msgstr "Nelze vytvoøit soubor s kategoriemi <%s>"
-#~ msgid "[%s]: Cannot read map header"
-#~ msgstr "Nelze èíst hlavièkový soubor mapy [%s]"
-#~ msgid "Unable to read raster map <%s> row %d"
-#~ msgstr "Nelze èíst rastrovou mapu <%s> øádek %d"
-#~ msgid "Failed writing raster map <%s> row %d"
-#~ msgstr "Nejsem zapsat rastrovou mapu <%s> øádek [%d]"
-#~ msgid "Can't set window"
-#~ msgid "Unable to read raster map row %d"
-#~ msgid "Unable to read header of raster map <%s>"
-#~ msgstr "Nelze èíst hlavièku rastrové mapy <%s>"
-#~ msgid "Reading row %d"
-#~ msgstr "Naèítám øádek %d"
-#~ msgid "Horizon file no. %d <%s> not found"
-#~ msgstr "Soubor s horizonty èíslo %d <%s> nebyl nalezen"
-#~ msgid "Data or Clump file not open"
-#~ msgstr "Datový (data) nebo shlukový (clump) soubor nebyl otevøen"
-#~ msgid "Error writing null row %d"
-#~ msgstr "Chyba pøi zápisu hodnoty null, øádek %d"
-#~ msgid "Failed writing output raster map row %d"
-#~ msgstr "Chyba pøi zápisu øádku rastrové mapy %d"
-#~ msgid "Signed data (high bit means negative value)"
-#~ msgstr "Oznaèená data (vysoký bit znamená negativní hodnotu)"
-#~ msgid "Number of bytes per cell (1, 2, 4)"
-#~ msgstr "Poèet bytù na buòku (1, 2, 4)"
-#~ msgid "Parsing bytes per cell"
-#~ msgstr "pøiøazui byty pro buòky"
-#~ msgid "Byte Swapping Turned On."
-#~ msgstr "Zapnuto dokládání bytù."
-#~ msgid ""
-#~ "Missing parameters ...\n"
-#~ "Must provide at least[north= south= east= west=] OR [r=\tc=]"
-#~ msgstr ""
-#~ "Chybìjící parametry ...\n"
-#~ "Musíte zadat alespoò [north= south= east= west=] NEBO [r=\tc=]"
-#~ msgid "You have to provide all limits of geographic region (n,s,e,w)"
-#~ msgstr "Musíte zadat v¹echny hranièní hodnoty (s,j,v,z)"
-#~ msgid "Illegal number of rows <%s>"
-#~ msgstr "Neplatné èíslo øádku <%s>"
-#~ msgid "Illegal number of columns <%s>"
-#~ msgstr "Minimální poèet sloupcù: <%s>"
-#~ msgid "Using N=%f S=%f E=%f W=%f"
-#~ msgstr "Pou¾ívám N=%f S=%f E=%f W=%f"
-#~ msgid "Using rows=%d cols=%d\n"
-#~ msgstr "Pou¾ívám øádkù=%d sloupcù=%d\n"
-#~ msgid "File Size %d ... Total Bytes %d"
-#~ msgstr "Velikost souboru %d ... Celkovì bytù %d"
-#~ msgid "Try bytes=%d or adjusting input parameters"
-#~ msgstr "Zkuste bytes=%d nebo pøenastavit vstupní parametry"
-#~ msgid "Conversion failed at row %d"
-#~ msgstr "Pøed selhal na øádku %d"
-#~ msgid "Error writing category file for <%s>"
-#~ msgstr "Chyba pøi zápisu souboru kategorií pro <%s>"
-#~ msgid "Overwrite output map file"
-#~ msgid "Setting window header"
-#~ msgid "Cannot get row"
-#~ msgstr "Nelze získat øádek"
-#~ msgid "Unable to close input map"
-#~ msgstr "Nelze zavøít vstupní mapu"
-#~ msgid "Could not get raster row from input map"
-#~ msgstr "Nelze získat øádek rastru z vstupní vrstvy"
-#~ msgid "Could not get raster row from elev map"
-#~ msgstr "Nelze získat øádek rastru z vý¹kového modelu"
-#~ msgid "%s: running %s command"
-#~ msgstr "%s: spou¹tím pøíkaz %s"
-#~ msgid "%s: unable to open temporary file"
-#~ msgstr "%s: nelze otevøít doèasný soubor"
-#~ msgid "Resultant raster map (not used with 'distribution')"
-#~ msgstr "Výsledná rastrová mapa (nelze pou¾ít s 'distribution')"
-#~ msgid "Output map <%s> ignored"
-#~ msgstr "Výstupní mapa <%s> ignorována"
-#~ msgid "Not yet implemented!"
-#~ msgstr "Zatím nebylo implementováno!"
-#~ msgid "An output raster map needs to be defined with method '%s'"
-#~ msgstr "Výstupní mapa musí být definována metodou '%s'"
-#~ msgid "One or more input raster maps not found"
-#~ msgstr "Jedna nebo více vstupních rastrových map nenalezeno"
-#~ msgid "Cannot read row"
-#~ msgstr "Nelze naèíst øádek"
-#~ msgid "Error in pipe creation"
-#~ msgstr "Chyba pøi vytváøení roury"
-#~ msgid "Error opening channel %i"
-#~ msgid "Cannot close %s file (PIPE)"
-#~ msgstr "Nelze uzavøít %s soubor (ROURA)"
-#~ msgid "Cannot delete %s file (PIPE)"
-#~ msgstr "Nelze smazat %s soubor (ROURA)"
-#~ msgid "Cannot close %s file (PIPE2)"
-#~ msgstr "Nemohou zavøít %s soubor (ROURA2)"
-#~ msgid "Cannot delete %s file (PIPE2)"
-#~ msgstr "Nelze smazat %s soubor (ROURA2)"
-#~ msgid "Cannot close receive channel file"
-#~ msgstr "Nelze ukonèit soubor s pøíjmovým kanálem"
-#~ msgid "Cannot delete %s file"
-#~ msgstr "Nelze smazat %s soubor"
-#~ msgid "Cannot read raster header file"
-#~ msgstr "Nelze èíst hlavièku rastrového souboru"
-#~ msgid "CHILD[pid = %i] cannot open raster map"
-#~ msgstr "DCERA[pid = %i] nemohu rastrovou mapu"
-#~ msgid "CHILD[pid = %i] cannot open receive channel"
-#~ msgstr "DCEØINÝ PROCES [pid = %i] nelze otevøít vstupní kanál"
-#~ msgid ""
-#~ "\t\t\t\tAREA MESSAGE: \n"
-#~ " \t\t\t\taid = %i \n"
-#~ " \t\t\t\tx = %i \n"
-#~ " \t\t\t\ty = %i \n"
-#~ " \t\t\t\trl = %i \n"
-#~ " \t\t\t\tcl = %i \n"
-#~ msgstr ""
-#~ "\t\t\t\tZPRÁVA O PLOCHÁCH: \n"
-#~ msgid ""
-#~ " \t\t\t\tMASKEDAREA MESSAGE: \n"
-#~ " \t\t\t\tmask = %s \n"
-#~ msgstr ""
-#~ " \t\t\t\tZPRÁVA O VYMASKOVANÉCH PLOCHÁCH \n"
-#~ msgid ""
-#~ " \t\t\t\tDONE MESSAGE: \n"
-#~ " \t\t\t\tpid = %i \n"
-#~ " \t\t\t\tresult = %f \n"
-#~ msgstr ""
-#~ " \t\t\t\tKONEÈNÁ ZPRÁVA: \n"
-#~ "\t\t\t\tvýsledek = %f \n"
-#~ msgid ""
-#~ " \t\t\t\tERROR MESSAGE: \n"
-#~ msgstr ""
-#~ " \t\t\t\tZPRÁVA O CHYBÁCH: \n"
-#~ msgid ""
-#~ " \t\t\t\tTERM MESSAGE: \n"
-#~ msgstr ""
-#~ " \t\t\t\tZPRÁVA O UKONÈENÍ: \n"
-#~ msgid "Cannot reset current region"
-#~ msgid "Cannot create category file for <%s>"
-#~ msgstr "Nelze vytvoøit soubor s kategoriemi pro <%s>"
-#~ msgid "Cannot read header of raster map <%s> in <%s>"
-#~ msgstr "Nelze èíst hlavièku pro rastrovou mapu <%s> v <%s>"
-#~ msgid "Cannot open cell file of raster map <%s> in <%s>"
-#~ msgstr "Nelze otevøít soubor cell rastrové mapy <%s> v <%s>"
-#~ msgid "Cannot read raster row [%d] from raster map <%s>"
-#~ msgstr "Nelze èíst øádek [%d] rastrové mapy <%s>"
-#~ msgid "Cannot read raster row [%d] from cover raster map <%s>"
-#~ msgstr "Nelze èíst øádek [%d] z krycí rastrové mapy <%s>"
-#~ msgid "Cannot read raster row [%d]"
-#~ msgstr "Nelze èíst øádek rastru [%d]"
-#~ msgid "Cannot read cover raster row [%d]"
-#~ msgstr "Nelze èíst øádek [%d] rastru"
-#~ msgid "Can't read row in input elevation map"
-#~ msgstr "nemohu èíst øádek ze vstupní mapy reliéfu"
-#~ msgid "Error reading 'hue' map"
-#~ msgstr "Chyba pøi ètení mapy odstínu (hue)"
-#~ msgid "Error reading 'intensity' map"
-#~ msgid "Error reading 'saturation' map"
-#~ msgid "Unable to read raster <map %d of %d> row %d"
-#~ msgstr "Nelze èíst rastrovou mapu <map %d of %d> øádek %d"
-#~ msgid "Writing map, row %d"
-#~ msgstr "Zapisuji mapu, øádek %d"
-#~ msgid "Unable to create distance map <%s>"
-#~ msgstr "Nelze vytvoøit mapu vzdáleností <%s>"
-#~ msgid "Unable to create value map <%s>"
-#~ msgstr "Nelze vytvoøit mapou hodnot <%s>"
-#~ msgid "Unable to write color table for raster map <%s>"
-#~ msgstr "Nelze zapsat tabulku barev pro rastrovou mapu <%s>"
-#~ msgid "Unable to read row %i\n"
-#~ msgstr "Nelze èíst øádek %i\n"
-#~ msgid "Error writing null row [%d]."
-#~ msgstr "Chyba pøi zápisu nulové øádky [%d]."
-#~ msgid "Swapping header data"
-#~ msgstr "Odkládám hlavièková data"
-#~ msgid "Exporting raster as double values (bytes=%d)"
-#~ msgstr "Exportuji rastr s neceloèíselnými hodnotami (double) (bytes=%d)"
-#~ msgid "Unable to read raster map row %d "
-#~ msgstr "Nelze naèíst øádek %d rastrové mapy"
-#~ msgid "Failed writing raster map row %d"
-#~ msgid "Invalid region: %s"
-#~ msgid "Writing raster map, row %d"
-#~ msgid "unable to open elevation map layer"
-#~ msgstr "nemohu otevøít mapu elevace"
-#~ msgid "unable to open runoff map layer"
-#~ msgstr "nemohu otevøít mapu odtoku"
-#~ msgid "unable to open depression map layer"
-#~ msgstr "nemohu otevøít mapu depresí"
-#~ msgid "unable to open blocking map layer"
-#~ msgstr "nemohu otevøít mapu pøeká¾ek"
-#~ msgid "unable to open rill map layer"
-#~ msgstr "nemohu otevøít mapu drah soustøedìného odtoku"
-#~ msgid "unable to open new accum map layer."
-#~ msgstr "nemohu otevøít novou mapu akumulace "
-#~ msgid "Close failed."
-#~ msgstr "Zavøení selhalo"
-#~ msgid "unable to open new aspect map layer."
-#~ msgstr "nemohu otevøít novou mapu expozice"
-#~ msgid "unable to open new slope length map layer."
-#~ msgstr "nemohu otevøít novou mapu LS (faktor délky a sklonu svahu)"
-#~ msgid "SECTION 2: A * Search."
-#~ msgstr "ÈÁST 2: A * Hledání."
-#~ msgid "unable to open accum file in valid_basins()"
-#~ msgstr "Nejsem schopen otevøít soubor s akumulací v valid_basins()"
-#~ msgid "Can't create raster map <%s>"
-#~ msgstr "Nelze vytvoøit rastrový soubor <%s>"
-#~ msgid "Quant table not changed for %s"
-#~ msgstr "Kvantizaèní tabulka pro %s nebyla zmìnìna"
-#~ msgid "Unable to open drainage pointer map"
-#~ msgstr "Nelze otevøít mapu povodí"
-#~ msgid "Unable to open new basin map"
-#~ msgstr "Nelze otevøít novou mapu mapu povodí"
-#~ msgid "Unable to close new basin map layer"
-#~ msgstr "Nelze uzavøít novou mapu povodí"
-#~ msgid "Number of the segment to create (segment library)"
-#~ msgstr "Poèet segmentù, které mají být vytvoøeny (segment library)"
-#~ msgid "Nseg is %d"
-#~ msgstr "Nseg je %d"
-#~ msgid "Null cells excluded from cost evaluation."
-#~ msgstr "Buòky bez hodnot jsou vylouèeny pro poèítání nákladù"
-#~ msgid "Input null cell will be retained into output map"
-#~ msgstr "Vstupní buòky neobsahující hodnotu budou pøevedeny do výstupní mapy"
-#~ msgid "Map with different projection"
-#~ msgstr "Mapa v jiné projekci"
-#~ msgid "DTM_Source map is: Integer cell type"
-#~ msgstr "Mapa DMT_Source: celoèíselný typ"
-#~ msgid "DTM_Source map is: Floating point (float) cell type"
-#~ msgstr "Mapa DTM_Source: Typ s plovoucí desetinnou èárkou (float)"
-#~ msgid "DTM_Source map is: Floating point (double) cell type"
-#~ msgstr "Mapa DTM_Source je: Typ s plovoucí desetinnou èárkou (double)"
-#~ msgid " %d rows, %d cols"
-#~ msgstr "%d øádkù, %d sloupcù"
-#~ msgid "COST_Source map is: Integer cell type"
-#~ msgstr "Mapa COST_Source: Celoèíselný typ"
-#~ msgid "COST_Source map is: Floating point (float) cell type"
-#~ msgstr "Mapa COST_Source: Typ s plovoucí desetinnou èárkou (float)"
-#~ msgid "COST_Source map is: Floating point (double) cell type"
-#~ msgstr "Mapa COST_Source: Typ s plovoucí desetinnou èárkou (double)"
-#~ msgid "Output map is: Integer cell type"
-#~ msgstr "Výstupní mapa: Celoèíselný typ"
-#~ msgid "Output map is: Floating point (float) cell type"
-#~ msgstr "Výstupní mapa: Typ s plovoucí desetinnou èárkou (float)"
-#~ msgid "Output map is: Floating point (double) cell type"
-#~ msgstr "Výstupní mapa: Typ s plovoucí desetinnou èárkou (double)"
-#~ msgid " EW resolution %s (%lf)"
-#~ msgstr "Rozli¹ení východ-západ %s (%lf)"
-#~ msgid " NS resolution %s (%lf)"
-#~ msgstr "Rozli¹ení server-jih %s (%lf)"
-#~ msgid "Initializing output "
-#~ msgstr "Inicializuji výstup"
-#~ msgid "Unable to allocate memory for segment fbuff == NULL"
-#~ msgstr "Nelze alokovat pamì» pro segment fbuff == NULL"
-#~ msgid "End of map!"
-#~ msgstr "Konec mapy!"
-#~ msgid "Will copy input map null values into output map"
-#~ msgstr "Zkopíruje buòky bez hodnoty do výstupní mapy."
-#~ msgid ""
-#~ "Integer cell type.\n"
-#~ "Writing..."
-#~ msgstr ""
-#~ "Celoèíselná mapa\n"
-#~ "Zapisuji..."
-#~ msgid ""
-#~ "Float cell type.\n"
-#~ "Writing..."
-#~ msgstr ""
-#~ "Mapa s plovoucí desetinnou èárkou (float)\n"
-#~ "Zapisuji..."
-#~ msgid ""
-#~ "Double cell type.\n"
-#~ "Writing..."
-#~ msgstr ""
-#~ "Mapa s plovoucí desetinnou èárkou (double)\n"
-#~ "Zapisuji..."
-#~ msgid "Peak cost value: %f"
-#~ msgstr "Nejvy¹¹í náklady: %f"
-#~ msgid "Unable to open raster map <%s@%s>"
-#~ msgstr "Nelze otevøít rastrovou mapu <%s@%s>"
-#~ msgid "Failed writing raster map row"
-#~ msgstr "Chyba pøi zápisu øádku rastrové mapy"
-#~ msgid "Cannot read raster row %d"
-#~ msgstr "Nelze naèíst øádek rastrové mapy %d"
-#~ msgid "Error reading raster map <%s>"
-#~ msgid "Failed writing raster map <%s>"
-#~ msgstr "Selhalo zapisování rastrové mapy <%s> "
-#~ msgid "Use a sparse matrix, only available with iterative solvers"
-#~ msgstr "Pou¾ití øídké matice, dostupné pouze pro iteraktivní solver"
-#~ msgid "Error reading input"
-#~ msgstr "Chyba pøi ètení vstupu"
-#~ msgid "Unable to write to <%s>"
-#~ msgstr "Nelze zapisovat do <%s>"
-#~ msgid "Could not get raster row"
-#~ msgstr "Nelze získat øádek rastru"
-#~ msgid "Column name (type must be numeric)"
-#~ msgstr "Jméno sloupce (musí být èíselného typu)"
-#~ msgid "Vector points to be spatially perturbed"
-#~ msgstr "Vektorové body, které budou prostorovì rozmístìny"
-#~ msgid "Finding nearest lines..."
-#~ msgstr "Hledám nejbli¾¹í linie..."
-#~ msgid "Output vector map where points will be written"
-#~ msgstr "Výstupní mapa, do které budou zapsány body"
-#~ msgid "Column name"
-#~ msgstr "Název sloupce"
-#~ msgid "Name of input 2D vector map"
-#~ msgid "Name of resulting 3D vector map"
-#~ msgstr "Jméno výsledné 3D vektorové mapy"
-#~ msgid "Extruding vector primitives..."
-#~ msgstr "Vynechávám základní vektorové prvky ..."
-#~ msgid "Unable to read MASK"
-#~ msgstr "nemohu èíst MASKU"
-#~ msgid "Vector map defining sample points"
-#~ msgstr "Vektorová mapa s body"
-#~ msgid "Raster map to be sampled"
-#~ msgid "Bilinear interpolation (default is nearest neighbor)"
-#~ msgstr "Bilineární interpolace (výchozí je nejbli¾¹í soused)"
-#~ msgid "Cubic convolution interpolation (default is nearest neighbor)"
-#~ msgstr "Interpolace kubickou konvulací (výchozí je metoda nejbli¾¹ího souseda)"
-#~ msgid "Flags -b & -c are mutually exclusive. Choose only one."
-#~ msgstr "pøepínaèe -b a -c se navzájem vyluèují. Zvolte pouze jeden z nich."
-#~ msgid "Checking vector points..."
-#~ msgstr "Kontroluji vektorové body ..."
-#~ msgid "Unable to convert input map projection to GRASS format; cannot create new location"
-#~ msgstr "Nelze pøevést vstupní mapovou projekci do formátu GRASSu; nelze vytvoøit novou location."
-#~ msgid "Cannot open %s"
-#~ msgstr "Nelze otevøít %s"
-#~ msgid "Vector of points defining sample points"
-#~ msgstr "Vektorová mapa s bodovými vzorky"
-#~ msgid "Suppress display of residuals or other information"
-#~ msgstr "Potlaè výpis zbyteèných a jiných informací"
-#~ msgid "Instead of points use transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot)"
-#~ msgstr "Místo bodù pou¾ij transformaèní volby (xshift,yshift,zshift, xscale, yscale, zscale, zrot)"
-#~ msgid "The '%c' flag is deprecated and will be removed in future. Transformation parameters are used automatically when no pointsfile is given."
-#~ msgstr "Pøepínaè '%c' je zastaralý a bude v budoucnosti odstranìn. prosím, peou¾ijte pøepínaè '--quiet'."
-#~ msgid "The '%c' flag is deprecated and will be removed in future. Please use '--quiet' instead."
-#~ msgstr "Pøepínaè '%c' je zastaralý a bude v budoucnosti odstranìn. prosím, pou¾ijte pøepínaè '--quiet'."
-#~ msgid "Column name and type (i.e. INTEGER, DOUBLE PRECISION) for z values"
-#~ msgstr "Název sloupce a typ (napø.: INTEGER, DOUBLE PRECISION) pro hodnoty z-souøadnice"
-#~ msgid "Cannot alter table: %s"
-#~ msgstr "Nelze vytvoøit tabulku: %s"
-#~ msgid "DXF output file"
-#~ msgstr "Výstupní soubor DXF"
-#~ msgid "Doing log transformation"
-#~ msgstr "Provádím logaritmickou transforamci"
-#~ msgid "Uses a GRASS vector points map to produce a convex hull vector map."
-#~ msgstr "POu¾ívám GRASS vektorovou mapu bodù pro vytvoøení vektorové mapy konvexního obalu."
-#~ msgid "Cannot open vector map <%s>"
-#~ msgstr "Nelze otevøít vektorovou mapu <%s>"
-#~ msgid "Unable to open SVG file <%s>"
-#~ msgstr "Nelze otevøít soubor SVG  <%s>"
-#~ msgid "Change the type of geometry elements."
-#~ msgstr "Zmìnit typ geometrických prvkù."
-#~ msgid "Pairs for input and output type separated by comma"
-#~ msgstr "Dvojice vstupu a výstupu oddìlené teèkou"
-#~ msgid ""
-#~ "<input_type1>,<output_type1>,<input_type2>,<output_type2>,...\n"
-#~ "\t\tExample1: line,boundary\n"
-#~ "\t\tExample2: line,boundary,point,centroid"
-#~ msgstr ""
-#~ "<vstupni_typ1>,<vystupni_typ1>,<vstupni_typ2>,<vystupni_typ2>,...\n"
-#~ "\t\t Pøíklad1: linie,hranice\n"
-#~ "\t\t Pøíklad2: linie,hranice,bod,centroid"
-#~ msgid "Nothing to do"
-#~ msgstr "Není co ukázat"
-#~ msgid "Not enough types"
-#~ msgstr "Nedostatek typù"
-#~ msgid "Odd number of types"
-#~ msgstr "Lichý poèet typù"
-#~ msgid "Output slope raster map"
-#~ msgstr "Název výstupního souboru sklonù svahù"
-#~ msgid "Output aspect raster map"
-#~ msgstr "Název výstupního souboru expozic svahù"
-#~ msgid "Output profile curvature raster map"
-#~ msgid "Output tangential curvature raster map"
-#~ msgid "Output mean curvature raster map"
-#~ msgstr "Název výstupního souboru støedních køivostí"
-#~ msgid "Cannot allocate memory for row buffer"
-#~ msgstr "Nelze alokovat pamì» pro øádek rastru"
-#~ msgid "Unable to write categories for raster map <%s>"
-#~ msgstr "Nelze zapsat kategorie pro rastrovou mapu <%s>"
-#~ msgid "Layer is only used for WHERE SQL statement"
-#~ msgstr "Vrstva je pou¾ita jenom pro dotaz SQL WHERE"
-#~ msgid "Layer 0 not supported"
-#~ msgstr "Vrstva 0 není podporována"
-#~ msgid "Layer number (if -1, all features in all layers of given type are extracted)"
-#~ msgid "Unable to read file header of <%s>"
-#~ msgstr "Nelze èíst hlavièku souboru <%s>"
-#~ msgid "Current region cannot be set."
-#~ msgid "Unable to allocate the input row buffer"
-#~ msgid "Unable to open the cell map MASK."
-#~ msgstr "Nelze otevøít rastrovou (cell) mapu MASK."
-#~ msgid "Unable to allocate the cell buffer in display_signature()."
-#~ msgstr "Nelze alokovat cell buffer v display_signature()."
-#~ msgid "Did not find input cell map MASK."
-#~ msgstr "Nemohl jsem nalézt vstupní rastrovou (cell) mapu MASK."
-#~ msgid "Error reading raster map in function readbands."
-#~ msgstr "Chyba pøi ètení rastrového (cell) souboru ve funkci readbands."
-#~ msgid "Unable to read cell header for first band file"
-#~ msgstr "Nelze èíst hlavièku prvního kanálu souboru"
-#~ msgid "Unable to open band files."
-#~ msgstr "Nelze otevøít soubory kanálù."
-#~ msgid "Error while reading input raster map."
-#~ msgstr "Chyba pøi ètení vstupní rastrové map."
-#~ msgid "Error reading cell map during transform."
-#~ msgstr "Chyba pøi ètení rastrové (cell) mapy bìhem transformace."
-#~ msgid "Error writing cell map during transform."
-#~ msgstr "Chyba pøi zápisu rastrové (cell) mapy bìhem transformace."
-#~ msgid "Unable to read region <%s> in <%s>"
-#~ msgstr "Nelze èíst region <%s> v <%s>"
-#~ msgid "Unable to read header of raster map <%s@%s>"
-#~ msgstr "Nelze èíst hlavièku rastrové mapy <%s@%s> "
-#~ msgid "database, attribute table, SQL"
-#~ msgstr "databáze, atributová tabulka, SQL"
-#~ msgid "Selects data from table."
-#~ msgid "database, attribute table"
-#~ msgstr "databáze, atributová tabulka"
-#~ msgid "Do not use this option if schemas are not supported by driver/database server"
-#~ msgstr "Tuto volbu nepou¾ívejte, pokud schémata nejsou podporována ovladaèem/databázovým serverem."
-#~ msgid "imagery, color transformation, RGB, HIS"
-#~ msgstr "obrazová data, barevná transformace, RGB, HIS"
-#~ msgid ""
-#~ "Subgroup too large.  Maximum number of bands is %d\n"
-#~ msgstr ""
-#~ "Podskupina je pøili¹ objemná. Maximální poèet kanálù je %d\n"
-#~ msgid "imagery, image transformation, PCA"
-#~ msgstr "obrazová data, transformace obrazu, PCA"
-#~ msgid "imagery, classification, MLC"
-#~ msgstr "obrazová data, klasifikace, MLC"
-#~ msgid "imagery, classification, supervised, MLC"
-#~ msgstr "obrazová data, klasifikace, øízená, MLC"
-#~ msgid "imagery, classification, supervised, SMAP"
-#~ msgstr "obrazová data, klasifikace, øízená, SMAP"
-#~ msgid "imagery, classification, signatures"
-#~ msgstr "obrazová data, klasifikace, pøíznaky"
-#~ msgid "imagery, FFT"
-#~ msgstr "obrazová data, FFT"
-#~ msgid "raster3d, voxel"
-#~ msgstr "rastr3d, voxel"
-#~ msgid "raster3d, voxel, import"
-#~ msgstr "rastr3d, voxel, import"
-#~ msgid "raster3d, voxel, export"
-#~ msgstr "rastr3d, voxel, export"
-#~ msgid "postscript, map, printing"
-#~ msgstr "postscript, mapa, tisk"
-#~ msgid "raster, import"
-#~ msgstr "rastr, import"
-#~ msgid "vector, database, attribute table"
-#~ msgstr "vektor, databáze, tabulka atributù"
-#~ msgid "vector, statistics"
-#~ msgid "raster, color table"
-#~ msgid "raster, statistics"
-#~ msgid "raster, keyword2, keyword3"
-#~ msgstr "rastr, klíèové slovo2, klíèové slovo3"
-#~ msgid "vector, keyword2, keyword3"
-#~ msgstr "vektor, klíèové slovo2, klíèové slovo3"
-#~ msgid "raster, export, VRML"
-#~ msgstr "rastr, export, VRML"
-#~ msgid "Could not read east bufferzone size. Aborting."
-#~ msgstr "Nelze naèíst velikost východní okolní zóny. Pøeru¹uji."
-#~ msgid "Could not read west bufferzone size. Aborting."
-#~ msgstr "Nelze naèíst velikost západní okolní zóny. Pøeru¹uji."
-#~ msgid "Could not read south bufferzone size. Aborting."
-#~ msgstr "Nelze naèíst velikost ji¾ní okolní zóny. Pøeru¹uji."
-#~ msgid "Could not read north bufferzone size. Aborting."
-#~ msgstr "Nelze naèíst velikost severní okolní zóny. Pøeru¹uji."
-#~ msgid "Unable to create raster map %s"
-#~ msgstr "Nejsem schopen vytvoøit rastrovou mapu %s."
-#~ msgid "raster, import, LIDAR"
-#~ msgstr "rastr, import, LIDAR"
-#~ msgid "raster, composite"
-#~ msgstr "rastr,slo¾ení obrazu"
-#~ msgid "raster, DEM, contours, vector"
-#~ msgstr "rastr, DMT, vrstevnice, vektor"
-#~ msgid "raster, volume, conversion"
-#~ msgstr "rastr, objem, pøevod"
-#~ msgid "raster, statistics, reclass"
-#~ msgid "raster, landscape structure analysis, diversity index"
-#~ msgstr "rastr, analýza krajiny, index diverzity"
-#~ msgid "raster, landscape structure analysis, patch index"
-#~ msgstr "rastr, analýza krajiny, index místa"
-#~ msgid "raster, landscape structure analysis, dominance index"
-#~ msgstr "rastr, analýza krajiny, index vlivu"
-#~ msgid "raster, metadata"
-#~ msgid "raster, raster3d, voxel, conversion"
-#~ msgstr "rastr, rastr3d, voxel, pøevod"
-#~ msgid "You have to use a different location for input than the current"
-#~ msgstr "Pro vstup musíte pou¾ít location rùznou od souèasné"
-#~ msgid "raster, DEM, fractal"
-#~ msgstr "rastr, DMT, fraktály"
-#~ msgid "Name of raster map to contain results (several new layers)"
-#~ msgstr "Název rastrové mapy pro výstup (nìkolik nových vrstev)"
-#~ msgid "The '-v' flag is superseded and will be removed in future. Please use '--verbose' instead."
-#~ msgstr "Pøepínaè '-v' byl nahrazen a bude v budoucnosti vyjmut. Prosím pou¾ijte místo nìjpøepínaè '--verbose'."
-#~ msgid "Raster map <%s> already exists in mapset <%s>, select another name"
-#~ msgstr "Rastrová mapa <%s> ji¾ existuje v mapsetu <%s>, zkuste prosím jiné jméno."
-#~ msgid "Percent Completed ... "
-#~ msgstr "Hotovo procent ... "
-#~ msgid "A single value of latitude [decimal degrees]"
-#~ msgstr "Jednotná hodnota zem. délky [stupnì]"
-#~ msgid "Name of the longitude input raster map [decimal degrees]"
-#~ msgstr "Jméno vstupní rastrové mapy zemìpisné délky (stupnì desítkovì)"
-#~ msgid "raster, series"
-#~ msgstr "rastr, série"
-#~ msgid "Name of real-sky beam radiation coefficient raster map [-]"
-#~ msgstr "Soubor s koeficientem pøímého sluneèního záøení [-]"
-#~ msgid "Name of real-sky diffuse radiation coefficient raster map [-]"
-#~ msgstr "Název rastrové mapy s koeficientem real-sky difíºzního záøení [-]"
-#~ msgid "time and insol_time are incompatible options"
-#~ msgstr "time a insol_time jsou nesluèitelné volby"
-#~ msgid "Mode 1: instantaneous solar incidence angle & irradiance given a set local time"
-#~ msgstr "Mode 1: okam¾itý solární íºhel dopadu & ozáøenost daná lokálním èasem"
-#~ msgid "rows changed from %d to %d"
-#~ msgstr "øádky zmìnìny z %d na %d"
-#~ msgid "cols changed from %d to %d"
-#~ msgstr "sloupce zmìnìny z %d na %d"
-#~ msgid "Output map: useful for visual display of results"
-#~ msgstr "Výstupní mapa: u¾iteèná pro vizuální zobrazení výsledkù"
-#~ msgid "NULL value computed (row %d, col %d)"
-#~ msgstr "Zapoèítaná hodnota NULL (øádek%d, sloupec%d)"
-#~ msgid "Unable to find row %d, col %d: %f"
-#~ msgstr "Nelze nalézt øádek %d, sloupec %d: %f"
-#~ msgid "Bad start cell"
-#~ msgstr "©patná poèáteèní buòka"
-#~ msgid "%s %f-%f lower cost higher or equal"
-#~ msgstr "%s %f-%f men¹í náklad vy¹íí nebo roven"
-#~ msgid "%s lower above pointer wrong"
-#~ msgstr "%s vý¹e nad poèátkem ¹patnì"
-#~ msgid "%s %f-%f higher cost lower"
-#~ msgstr "%s %f-%f vy¹¹í náklad"
-#~ msgid "%s higher above pointer wrong"
-#~ msgstr "%s ¹patnì vý¹e nad poèátkem"
-#~ msgid "raster, cost surface, cumulative costs"
-#~ msgstr "rastrová mapa, povrch nákladù, kumulativní náklady"
-#~ msgid "No data"
-#~ msgstr "®ádná data"
-#~ msgid "raster, sediment flow, erosion, deposition"
-#~ msgstr "rastr, tok erodovaných èástic, eroze, usazování"
-#~ msgid "raster, flow, hydrology"
-#~ msgstr "rastr, tok, hydrologie"
-#~ msgid "Input raster map contains cells with NULL-value (no-data). The value %g was used to represent no-data values in the input map. You can specify nodata value by %s parameter."
-#~ msgstr "Vstupní rastrová mapa obsahuje NULLové hodnoty (¾ádná data).  Pro NULLové hodnoty byla pou¾ita hodnota %g. Mù¾ete urèit hodnotu reprezentující NULLové hodnoty parametrem %s."
-#~ msgid "vector, export"
-#~ msgid "got type %d"
-#~ msgstr "Dotal typ %d"
-#~ msgid "Feature has more categories. Only first category (%d) is exported."
-#~ msgstr "Prvek má více kategorií. Bude exportována pouze první kategorie (%d)."
-#~ msgid "Unable to select record from table <%s> (key %s, column %s)"
-#~ msgstr "Nelze vybrat záznam z tabulky <%s> (klíè %s sloupec %s)"
-#~ msgid "Column <%s>: unsupported data type"
-#~ msgstr "Sloupec <%s>: neplatný typ dat"
-#~ msgid "Exporting %i faces (may take some time) ..."
-#~ msgstr "Exportuji %i stran (mù¾e chvilku trvat) ..."
-#~ msgid "vector, metadata, history"
-#~ msgid "Layer:           %s"
-#~ msgstr "vrstva:       %s"
-#~ msgid "Mapset:          %s"
-#~ msgstr "Mapset:       %s"
-#~ msgid "Location:        %s"
-#~ msgstr "Location:        %s"
-#~ msgid "Database:        %s"
-#~ msgstr "Databáze:        %s"
-#~ msgid "Title:           %s"
-#~ msgstr "Název:       %s"
-#~ msgid "  Type of Map:  %s (level: %i)        "
-#~ msgstr "Typ mapy:  %s (úroveò: %i)"
-#~ msgid "  Number of points:       %-9ld       Number of areas:      %-9ld"
-#~ msgstr "Poèet bodù:       %-9ld       Poèet ploch:       %-9ld"
-#~ msgid "  Number of lines:        %-9ld       Number of islands:    %-9ld"
-#~ msgstr "Poèet linií:       %-9ld       Poèet ostrovù       %-9ld"
-#~ msgid "  Number of boundaries:   %-9ld       Number of faces:      %-9ld"
-#~ msgstr "  Poèet hranic:    %-9ld       Poèet 3D polygonù:    %-9ld"
-#~ msgid "  Number of centroids:    %-9ld       Number of kernels:    %-9ld"
-#~ msgstr "  Poèet centroidù:    %-9ld       Poèet jader:    %-9ld"
-#~ msgid "  Map is 3D:              %s"
-#~ msgstr "  Mapa je 3D:       %s"
-#~ msgid "  Number of dblinks:      %-9ld"
-#~ msgstr "Poèet pøipojení k databázi:     %-9ld "
-#~ msgid "                No topology present"
-#~ msgstr "                Není vytvoøena ¾ádná topologie"
-#~ msgid "        Projection: %s (zone %d)"
-#~ msgstr "        Projekce: %s (zóna %d)"
-#~ msgid "        Projection: %s"
-#~ msgstr "        Projekce: %s"
-#~ msgid "vector, buffer"
-#~ msgstr "vektor, bufer"
-#~ msgid "vector, path, visibility"
-#~ msgstr "vektor, cesta, viditelnost"
-#~ msgid "Output vector. If not given, available layers are printed only."
-#~ msgstr "Výstupní vektor, pokud není zadán, jsou pouze vyti¹tìny pøítomné vektory"
-#~ msgid ""
-#~ "OGR layer name. If not given, available layers are printed only. Examples:\n"
-#~ "\t\tESRI Shapefile: shapefile name\n"
-#~ "\t\tMapInfo File: mapinfo file name"
-#~ msgstr ""
-#~ "Název vrstvy OGR. Pokud není zadán, vypsány budou pouze dostupné vrstvy. Pøíklady:\n"
-#~ "\t\tESRI ShapeFile: název souboru ShapeFile\n"
-#~ "\t\tSoubor MapInfo: název souboru MapInfo"
-#~ msgid "Output vector name was not specified"
-#~ msgstr "Výstupní vektorová mapa nebyla zadána"
-#~ msgid "Cannot open data source"
-#~ msgstr "Nelze otevøít datový zdroj"
-#~ msgid "vector, projection"
-#~ msgstr "vektor, projekce"
-#~ msgid "vector, reclass, attributes"
-#~ msgstr "vektor, reklasifikace, atributy"
-#~ msgid "vector, raster, aggregation"
-#~ msgstr "vektor, rastr, agregace"
-#~ msgid "vector, editing, geometry"
-#~ msgstr "vektor, editace, geometrie"
-#~ msgid "Error reading ASCII file: '%s'"
-#~ msgstr "Chyba pøi ètení ASCII souboru: '%s'"
-#~ msgid "End of ASCII file reached before end of coordinates"
-#~ msgstr "Konec souboru ASCII dosa¾en pøed koncem souøadnic"
-#~ msgid "Error reading categories: '%s'"
-#~ msgstr "Chyba pøi ètení kategorií: '%s'"
-#~ msgid "Unexpected data in vector head: '%s'"
-#~ msgstr "Neoèekávaná data v hlavièce vektorové mapy: '%s'"
-#~ msgid "Unknown keyword '%s' in vector head"
-#~ msgstr "Neznámé klíèové slovo '%s' v hlavièce vektorového souboru."
-#~ msgid "vector, import, conversion"
-#~ msgstr "vektor, import, pøevod"
-#~ msgid "Attribute column to use for buffer distances"
-#~ msgstr "Název sloupce atributu, který má být pou¾it pro vzdálenost bufferu"
-#~ msgid "Stop the process at a certain stage"
-#~ msgstr "Zastav proces na jistém místì"
-#~ msgid "The tolerance was reset to %g (map units)"
-#~ msgstr "Tolerance byla pøenastavena na %g (v jednotkách mapy)"
-#~ msgid "The tolerance was reset to %g (map units). [category %d]"
-#~ msgstr "Tolerance byla pøenastavena na %g (v jednotkách mapy) [kategorie %d]"
-#~ msgid "Areas buffers... "
-#~ msgstr "Bufery ploch..."
-#~ msgid "Create parallel line to input lines"
-#~ msgstr "Vytvoøit rovnobì¾ky ke vstupním liniím"
-#~ msgid "Offset in map units, positive for right side, negative for left side."
-#~ msgstr "Odchylka v mapových jednotkách, kladná pro pravou stranu, záporná pro levou stranu."
-#~ msgid "vector, generalization, simplification, smoothing, displacement, network generalization"
-#~ msgstr "vektor, generalizace, zjednodu¹ení, vyhladzení, nahrazení, generalizace sí»ì"
-#~ msgid "vector, volume, conversion"
-#~ msgstr "vektor, volume, pøevod"
-#~ msgid "vector, raster, conversion"
-#~ msgstr "vektor, rastr, pøevod"
-#~ msgid "vector, geometry, 3D"
-#~ msgstr "vektor, geometrie, 3D"
-#~ msgid ""
-#~ "Unexpected data in vector head:\n"
-#~ "[%s]"
-#~ msgstr ""
-#~ "Neoèekávaná data v hlavièce:\n"
-#~ "[%s]"
-#~ msgid "Unknown keyword <%s> in vector head"
-#~ msgstr "Neznámé klíèové slovo <%s> v hlavièce vektorového souboru."
-#~ msgid "Error reading ASCII file: (bad type) [%s]"
-#~ msgstr "Chyba pøi ètení ASCII souboru: (¹patný typ) [%s]"
-#~ msgid "Error reading ASCII file: (unknown type) [%s]"
-#~ msgstr "Chyba pøi ètení ASCII souboru:(neznámý typ) [%s]"
-#~ msgid "Error reading ASCII file: (bad point) [%s]"
-#~ msgstr "Chyba pøi ètení ASCII souboru: (¹patný bod) [%s]"
-#~ msgid "End of ASCII file reached before end of categories"
-#~ msgstr "Konec souboru dosa¾en pøed koncem souøadnic"
-#~ msgid "Error reading categories: [%s]"
-#~ msgstr "Chyba pøi ètení kategorií: [%s]"
-#~ msgid "vector, raster, attribute table"
-#~ msgstr "vektor, rastr, tabulka atributù"
-#~ msgid "vector, geometry, sampling"
-#~ msgstr "vektor,geometrie, vzorkování"
-#~ msgid "vector, LIDAR, edges"
-#~ msgstr "vektor, LIDAR, hrany"
-#~ msgid "vector, LIDAR"
-#~ msgstr "vektor, LIDAR"
-#~ msgid "Duplicate area centroids"
-#~ msgstr "Duplicitní centroidy plochy"
-#~ msgid "%d areas of total size %g removed"
-#~ msgstr "%d ploch o celkové plo¹e %g bylo smazáno"
-#~ msgid "%d modifications done"
-#~ msgstr "%d zmìn provedeno"
-#~ msgid "vector, LRS, networking"
-#~ msgstr "vektor, LRS, sí»ování"
-#~ msgid "vector, import, database, points"
-#~ msgstr "vektor, import, databáze, body"
-#~ msgid "vector, metadata"
-#~ msgid "vector, geometry, topology"
-#~ msgstr "vektor,geometrie, topologie"
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares)"
-#~ msgid "vector, transformation, 3D"
-#~ msgid "If set to 0, z coordinates are used (3D vector only)"
-#~ msgstr "Pokud nastaveno na 0, jsou pou¾ity souøadnice z (pouze u 3D vektorù)"
-#~ msgid "Required if layer > 0"
-#~ msgstr "Po¾adováno pokud je vrstva >0"
-#~ msgid "Illegal group name <%s>"
-#~ msgstr "Neplatné jméno skupiny <%s>"
-#~ msgid "Illegal subgroup name <%s>"
-#~ msgstr "Neplatné jméno podskupiny <%s>"
-#~ msgid "Illegal signature file name <%s>"
-#~ msgstr "Neplatný název souboru se signaturami <%s>."
-#~ msgid "Illegal output file name <%s>"
-#~ msgstr "Neplatný název výstupního souboru <%s>"
-#~ msgid "Run quietly"
-#~ msgstr "Potichu"
-#~ msgid "usage: %s file [prompt %%x %%y]\n"
-#~ msgstr "pou¾ití: %s soubor [prompt %%x %%y]\n"
-#~ msgid "name=%s\n"
-#~ msgstr "name=%s\n"
-#~ msgid "mapset=%s\n"
-#~ msgstr "mapset=%s\n"
-#~ msgid "fullname=%s\n"
-#~ msgstr "fullname=%s\n"
-#~ msgid "Poorly placed psuedo control points. "
-#~ msgstr "Slabì umístìné pseudo kontrolní body."
-#~ msgid "Cannot generate the transformation equation."
-#~ msgstr "Nelze vytvoøit transformaèní rovnici."
-#~ msgid "No active psuedo control points"
-#~ msgstr "®ádné aktivní pseudo kontrolní body"
-#~ msgid "%s@%s: projection doesn't match current settings"
-#~ msgstr "%s@%s: projekce neodpovídá souèasnému nastavení"
-#~ msgid "%s@%s: zone doesn't match current settings"
-#~ msgstr "%s@%s: zóna neodpovídá souèasnému nastavení"
-#~ msgid "Unable to write temp file: %s"
-#~ msgstr "Nelze zapsat doèasný soubor: %s"
-#~ msgid "Unable to open map %s"
-#~ msgid "Unable to write row %d"
-#~ msgstr "Nelze zapisovat do øádku %d"
-#~ msgid "Unable to write raster map. You might want to check available disk space and write permissions."
-#~ msgstr "Nelze zapsat rastrovou mapu. Prosím zkontrolujte voln místo na disku a práva k zápisu."
-#~ msgid "imagery, orthorectify"
-#~ msgid "Interactively select or modify the imagery group target."
-#~ msgstr "Interaktivnì vybrat nebo upravit cíl skupiny"
-#~ msgid "Name of imagery group for ortho-rectification"
-#~ msgstr "Jméno obrazové skupiny pro ortho-rektifikaci"
-#~ msgid "Group [%s] not found"
-#~ msgstr "Skupina [%s] nebyla nalezena"
-#~ msgid "No files in this group!"
-#~ msgstr "®ádné soubory v této skupinì!"
-#~ msgid "No camera reference file selected for group [%s]"
-#~ msgstr "Nebyl vybrán ¾ádný referenèní soubor pro skupinu [%s]"
-#~ msgid "Bad format in camera file for group [%s]"
-#~ msgstr "©patný formát souboru kamery ve skupinì [%s]"
-#~ msgid "Interactively select or modify the target elevation model."
-#~ msgstr "Interaktivnì vyber nebo uprav cílový vý¹kový model."
-#~ msgid "Target information for group [%s] missing\n"
-#~ msgstr "Chybý cíl pro skupinu [%s] \n"
-#~ msgid "Target location [%s] not found\n"
-#~ msgstr "Cílová location [%s] nebyla nalezena\n"
-#~ msgid "Mapset [%s] in target location [%s] - "
-#~ msgstr "Mapset [%s] v cílové location [%s] - "
-#~ msgid "permission denied\n"
-#~ msgstr "Pøístup odepøen\n"
-#~ msgid "not found\n"
-#~ msgstr "nenalezeno\n"
-#~ msgid "Creates control points on an image to be ortho-rectified."
-#~ msgstr "Vytvoøí vlícovací body na snímku urèeného k ortho-rektifikaci."
-#~ msgid "Name of image to be rectified which will be initially drawn on screen"
-#~ msgstr "Jméno snímku urèeného k rektifikaci, který bude po startu vykreslen"
-#~ msgid "Name of a map from target mapset which will be initially drawn on screen"
-#~ msgstr "Jméno mapy z cílového mapsetu, který bude po startu vykreslen"
-#~ msgid "No photo points for group [%s]"
-#~ msgstr "®ádná bodová data pro skupinu [%s]"
-#~ msgid "Poorly placed photo points for group [%s]"
-#~ msgstr "Mizernì umístìné foto body pro skupinu [%s]"
-#~ msgid "Computing equations ..."
-#~ msgstr "Poèítám rovnice...."
-#~ msgid "Unable to read raster header of <%s>"
-#~ msgid "Interactively select and modify the imagery group camera reference file."
-#~ msgstr "Interaktivnì vybrat a upravit referenèní soubor kamery  pro skupinu"
-#~ msgid "Name of camera reference file to use"
-#~ msgstr "jméno referenèního souboru kamery "
-#~ msgid "Enter a camera reference file to be used with this imagery group"
-#~ msgstr "Vlo¾it referenèní soubor kamery, který bude pou¾it s touto skupinou "
-#~ msgid "Group [%s] in location [%s] mapset [%s] now has camera file [%s]"
-#~ msgstr "Skupina [%s] v location [%s], mapset [%s] má nyní pøiøazen soubor kamery [%s]"
-#~ msgid "Menu driver for the photo imagery programs."
-#~ msgstr "Ovladaè menu programù pro manipulaci s obrazem."
-#~ msgid "Pre-selected group <%s> not found"
-#~ msgstr "Pøedvybraná skupina <%s> nebyla nalezena"
-#~ msgid "Enter imagery group for ortho-rectification"
-#~ msgstr "Vlo¾te jméno skupiny pro orto-rektifikaci"
-#~ msgid "Group [%s] contains no files"
-#~ msgstr "Skupina [%s] neobsahuje ¾ádné soubory."
-#~ msgid "Image Group [%s] not found"
-#~ msgid "Group [%s] targeted for location [%s], mapset [%s]"
-#~ msgstr "Skupina [%s] zacílená na location [%s], mapset [%s]"
-#~ msgid "pyramid constructed."
-#~ msgstr "sestavena pyramida."
-#~ msgid "Unable to open real-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
-#~ msgstr "Nelze otevøít reálnou èást obrazu v adresáøi cell_misc.Rastrová mapa nebyla pravdìpodobnì vytvoøena pomocí i.fft."
-#~ msgid "Unable to open imaginary-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
-#~ msgstr "Nelze otevøít imaginární èást obrazu v adresáøi cell_mics.Rastrové mapa nebyla pravdìpodobnì vytvoøena pomocí i.fft"
-#~ msgid "Power 2 values: %d rows %d columns"
-#~ msgstr "Hodnoty druhé mocniny: %d øádkù %d sloupcù"
-#~ msgid "Writing data..."
-#~ msgstr "Zapisuji data..."
-#~ msgid "Unable to open file in the 'cell_misc' directory"
-#~ msgstr "Nelze otevøít soubor v adresáøi cell_mics."
-#~ msgid "Range of values in output display files"
-#~ msgstr "Rozsah hodnot ve výstupním souboru"
-#~ msgid "Range less than or equal to zero not allowed"
-#~ msgstr "Rozsah men¹í nebo roven nule není povolen"
-#~ msgid "Writing viewable versions of transformed data..."
-#~ msgstr "Zapisuji zobrazitelnou verzi transformovaných dat..."
-#~ msgid "Elevation map not found"
-#~ msgstr "Soubor s elevací nebyl nalezen"
-#~ msgid "Illegal output file name"
-#~ msgstr "Neplatný název výstupního souboru"
-#~ msgid "Unable to open raster map <%s> in mapset <%s>"
-#~ msgid "Unable to read raster row"
-#~ msgstr "Nelze momentálnì èíst rastrovou mapu."
-#~ msgid "Name of terrain raster map (DEM)"
-#~ msgstr "Jméno rastrové mapy obsahující vý¹ky (DMT)"
-#~ msgid "Finds the average of values in a cover map within areas assigned the same category value in a user-specified base map."
-#~ msgstr "Nalezne prùmìr hodnot z pøekrývající mapy, která bude rozdìlena podle ploch se stejnými hodnotami z pokladové mapy."
-#~ msgid "%s: ERROR running %s command"
-#~ msgstr "%s: CHYBA pøi spu¹tìní pøíkazu %s"
-#~ msgid "Quiet - Do not show progress"
-#~ msgstr "Ti¹e - potlaè hlá¹ení o prùbìhu zpracování"
-#~ msgid "Quietly"
-#~ msgid "Unable to read current window parameters"
-#~ msgstr "Nelze pøeèíst parametry aktuálního okna"
-#~ msgid "Unable to find starting vector <%s> "
-#~ msgstr "Nelze nalézt poèáteèní vektor <%s> "
-#~ msgid "Raster output map <%s> not found (no start_points given)"
-#~ msgstr "Výstupní rastrová mapa <%s>  nenalezena (nebyly zadány start_points)"
-#~ msgid "Memory allocation error on reading start points from raster map %s"
-#~ msgstr "Chyba pøi alokaci pamìti pøi ètení poèáteèních bodù z rastrové mapy %s"
-#~ msgid "Apply filter only to zero data values"
-#~ msgstr "Aplikuj filtr pouze na nulové hodnoty dat"
-#~ msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead"
-#~ msgid "Enter rules interactively"
-#~ msgid "Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" options"
-#~ msgstr "Interaktivní mód nelze pou¾ít s volbami \"barva\", \"pravidlo\", a \"rastr\" "
-#~ msgid "No clump map specified and MASK not set."
-#~ msgstr "Nebyla zadána mapa spojitých oblastí a nastavena MASKa"
-#~ msgid "Unable to find data map"
-#~ msgstr "Nelze nalézt mapu s daty"
-#~ msgid "Unable to find clump map"
-#~ msgstr "Nelze nalézt mapu shlukù (clump)"
-#~ msgid "Suppress single crossing error messages"
-#~ msgstr "Potlaè chybové zprávy o pøekrytí"
-#~ msgid "The '-q' and '-n' flag is superseded and will be removed in future. Please use '--quiet' instead."
-#~ msgstr "Volby '-q' a '-n' jsou zastaralé a budou v budoucnu odstranìny. Prosím pou¾ijte pøepínaè '--quiet'."
-#~ msgid "Sums up the raster cell values."
-#~ msgstr "Seète hodnoty bunìk rastrového souboru."
-#~ msgid "Name of incidence or density file."
-#~ msgstr "Název souboru pùsobení nebo hustoty."
-#~ msgid "RGB raster map <%s> not found"
-#~ msgstr "RGB rastrová mapa <%s> nenalezena"
-#~ msgid "Cannot create RGB data, please provide three maps [r,g,b]"
-#~ msgstr "Nelze vytvoøit data RGB, prosím zadejte tøi mapy [r,g,b]"
-#~ msgid "Vector cell map <%s> not found"
-#~ msgstr "Vektorová mapa buòek <%s> nebyla nalezena"
-#~ msgid "Cannot create vector data, please provide three maps [x,y,z]"
-#~ msgstr "Nelze vytvoøit vektorová data, prosím zadejte tøi mapové vrstvy [x,y,z]"
-#~ msgid ""
-#~ "%s: saving [%s] raster map layer.\n"
-#~ "Percent complete:"
-#~ msgstr ""
-#~ "%s: ukládám [%s] rastr\n"
-#~ "Hotovo procent:"
-#~ msgid "Starting map [%s]"
-#~ msgstr "Vytváøím mapu [%s]"
-#~ msgid "Starting filter #%d, distance: %.*lf, exponent: %.*lf, flat: %.*lf"
-#~ msgstr "Zaèínám filtrovat #%d, vzdálenost: %.*lf, exponent: %.*lf, flat: % *lf"
-#~ msgid "Percent done:"
-#~ msgstr "Hotovo procent:"
-#~ msgid "Title, in quotes"
-#~ msgstr "Titulek v uvozovkách"
-#~ msgid "%s: cover raster map not found"
-#~ msgstr "%s: pøekryvná mapa nebyla nalezena"
-#~ msgid "%s: base map and output map must be different"
-#~ msgstr "%s: základní mapa a výstupní mapa musí být rùzné"
-#~ msgid "Which raster map needs a color table"
-#~ msgstr "Který rastrový soubor vy¾aduje tabulku barev"
-#~ msgid "Color table for <%s> updated"
-#~ msgstr "Tabulka barev pro <%s> byla aktualizována"
-#~ msgid "Which raster map needs an updated history? "
-#~ msgstr "Který rastrový soubor vy¾aduje aktualizovanou historii? "
-#~ msgid "Raster file [%s] not found. Exiting."
-#~ msgstr "Rastrový soubor [%s] nebyl nalezen. Ukonèuji se."
-#~ msgid "History file for [%s] updated."
-#~ msgstr "Soubor s historií pro [%s] byl aktualizován."
-#~ msgid "History file for [%s] not updated."
-#~ msgstr "Soubor s historií pro [%s] nebyl aktualizován."
-#~ msgid "Please enter the following information for [%s]:"
-#~ msgstr "Prosím, zadejte následující informace pro [%s]:"
-#~ msgid "        Number of rows"
-#~ msgstr "        Poèet øádkù"
-#~ msgid "        Number of cols"
-#~ msgstr "        Poèet sloupcù"
-#~ msgid "        Number of bytes per cell"
-#~ msgstr "        Poèet bytù na buòku (1, 2, 4)"
-#~ msgid "        Floating point map"
-#~ msgstr "        Mapa s plovoucí desetinnou èárkou"
-#~ msgid "rows * cols * bytes per cell must be same as file size (%lu)"
-#~ msgstr "øádky * sloupce * byty na buòku musí mít stejnou velikost jako soubor (%lu)"
-#~ msgid "If you need help figuring them out, just hit ESC"
-#~ msgstr "Pokud potøebujete pomoc s vyèíslením, stisknìte ESC"
-#~ msgid "** Negative values not allowed!"
-#~ msgstr "** Záporné hodnoty nejsou povoleny!"
-#~ msgid "** Positive values only please!"
-#~ msgstr "** Pouze kladné hodnoty, prosím!"
-#~ msgid "Edit header for [%s]\n"
-#~ msgstr "Edituj hlavièku pro [%s]\n"
-#~ msgid "[%s] cannot be found!"
-#~ msgstr "[%s] nemù¾e být nalezen!"
-#~ msgid "For what layer shall the header file be edited? "
-#~ msgstr "Pro kterou vrstvu má být upraven soubor s hlavièkou? "
-#~ msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
-#~ msgstr "[%s] je reklasifikací [%s] - nemohu upravit hlavièku! Spus»te r.support pro [%s]."
-#~ msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
-#~ msgstr "[%s] je reklasifikací [%s v %s] - nemohu upravit hlavièku!"
-#~ msgid "Cannot open raster map [%s]!"
-#~ msgstr "Nelze otevøít rastrový soubor [%s]!"
-#~ msgid "Raster file [%s] is empty."
-#~ msgstr "Rastrový soubor [%s] je prázdný."
-#~ msgid "Error reading raster map [%s]."
-#~ msgstr "Chyba pøi ètení rastrového souboru [%s]."
-#~ msgid "cellhd compression: %d\n"
-#~ msgstr "komprese cellhd: %d\n"
-#~ msgid "3.0 compression %sindicated\n"
-#~ msgstr "%sindikována 3.0 komprese\n"
-#~ msgid "Pre 3.0 compression %sindicated\n"
-#~ msgstr "%sindikována pøedbì¾ná 3.0 komprese\n"
-#~ msgid "[%s] appears to be compressed. Is it? "
-#~ msgstr "[%s] se jeví jako komprimovaný. Je tomu tak?"
-#~ msgid "Please indicate the type of compression:\n"
-#~ msgstr "Prosím, udejte typ komprese:\n"
-#~ msgid "  1. Pre 3.0 compression\n"
-#~ msgstr "  1. Pøedbì¾ná 3.0 komprese\n"
-#~ msgid "  2. 3.0 compression\n"
-#~ msgstr "  2. 3.0 komprese\n"
-#~ msgid "The header for [%s] says the file is not compressed. "
-#~ msgstr "Hlavièka pro [%s] øíká, ¾e soubor není komprimován. "
-#~ msgid "The file appears to be compressed.\n"
-#~ msgstr "Soubor se ukazuje být komprimován.\n"
-#~ msgid "Most likely the header is wrong, but I want you to decide.\n"
-#~ msgstr "Hlavièka je pravdìpodobnì chybná, rozhodnutí je na Vás.\n"
-#~ msgid "The header for [%s] says the file is compressed. "
-#~ msgstr "Hlavièka pro [%s] øíká, ¾e je soubor komprimován. "
-#~ msgid "The file does NOT appear to be compressed.\n"
-#~ msgstr ""
-#~ "Soubor se NEJEVÍ jako komprimovaný.\n"
-#~ "\n"
-#~ msgid "Header indicates %d row%s in the raster map, but the actual file format indicates %d row%s"
-#~ msgstr "Hlavièka uvádí %d øádkù %s v souboru, ale platný formát souboru uvádí %d øádkù %s"
-#~ msgid "Unable to write header for [%s]."
-#~ msgstr "Nejsem schopen zapsat hlavièku pro [%s]"
-#~ msgid "Header for raster map [%s] updated."
-#~ msgstr "Hlavièka rastrového souboru [%s] byla aktualizována."
-#~ msgid ""
-#~ "\n"
-#~ "hit RETURN to continue -->"
-#~ msgstr ""
-#~ "\n"
-#~ "Stisknìte RETURN pro pokraèování -->"
-#~ msgid "Which vector map needs updated categories?"
-#~ msgstr "Který vektorový soubor vy¾aduje aktualizované kategorie?"
-#~ msgid "Which raster map needs updated categories?"
-#~ msgstr "Který rastrový soubor vy¾aduje aktualizované kategorie?"
-#~ msgid "Category file for <%s> not updated"
-#~ msgstr "Soubor s kategoriemi pro <%s> nebyl aktualizován."
-#~ msgid "Category file for <%s> updated"
-#~ msgstr "Soubor s kategoriemi pro <%s> byl aktualizován."
-#~ msgid ""
-#~ "\n"
-#~ "Hit RETURN to continue -->"
-#~ msgstr ""
-#~ "\n"
-#~ "Stiknìte RETURN pro pokraèování -->"
-#~ msgid "Edit header for [%s]? "
-#~ msgstr "Editovat hlavièku pro [%s]?"
-#~ msgid ""
-#~ "\n"
-#~ "NOTE: [%s] is a reclass of [%s in %s]"
-#~ msgstr ""
-#~ "\n"
-#~ "POZNÁMKA: [%s] je reklasifikací [%s z %s]"
-#~ msgid "Canceling from edit header."
-#~ msgstr "Stornování editace hlavièky."
-#~ msgid "Edit the category file for [%s]? "
-#~ msgstr "Editace souboru s kategoriemi pro [%s]? "
-#~ msgid "Create/Update the color table for [%s]? "
-#~ msgstr "Vytvoøení/Aktualizace tabulky barev pro [%s]?"
-#~ msgid "Edit the history file for [%s]? "
-#~ msgstr "Editace souboru s historií pro [%s]?"
-#~ msgid ""
-#~ "\n"
-#~ "The null file for [%s] may indicate that some cells contain\n"
-#~ " no data. If the null file for [%s] doesn't exist, zero cells in\n"
-#~ " it are treated by GRASS application programs as no data."
-#~ msgstr ""
-#~ "\n"
-#~ "Soubor \"null\" pro [%s] mù¾e naznaèovat, ¾e nìkteré buòky obsahují\n"
-#~ " \"¾ádná data\". Pokud tento soubor pro [%s] neexistuje, pak jsou nulové buòky\n"
-#~ "interpretovány moduly GRASSu jako \"¾ádná data\"."
-#~ msgid ""
-#~ "\n"
-#~ "Do you want to create/reset the null file for [%s] so that null cell values are considered valid data? "
-#~ msgstr ""
-#~ "\n"
-#~ "Pøejete si vytvoøit/obnovit soubor \"null\" pro [%s], tak¾e hodnoty bunìk NULL budou pova¾ovány za platná data?"
-#~ msgid ""
-#~ "\n"
-#~ "Do you want to delete the null file for [%s]\n"
-#~ "(all zero cells will then be considered no data)? "
-#~ msgstr ""
-#~ "\n"
-#~ "Pøejete si odstranit soubor \"null\" pro [%s]\n"
-#~ "(v¹echny nulové buòky budou poté pova¾ovány za \"no data\")?"
-#~ msgid "%s: Error reading from raster map <%s> in mapset <%s>"
-#~ msgstr "%s: Chyba pøi ètení z rastrové mapy <%s> v mapsetu <%s>"
-#~ msgid "Not enough memory for zero_array_cell"
-#~ msgstr "Pro zero_array_cell není dostatek pamìti"
-#~ msgid "Not enough disk space -- cannot write files"
-#~ msgstr "Plné místo na disku -- nemohu zapsat soubory"
-#~ msgid "%s: [%s] not found"
-#~ msgstr "%s: [%s] nebyl nalezen"
-#~ msgid "Data range of raster map <%s> is empty"
-#~ msgstr "Rozsah hodnot pro rastrovou mapu <%s> je prázdný"
-#~ msgid "raster, recode category"
-#~ msgstr "raster, pøekódování kategorie"
-#~ msgid "Unable to open rules file <%s>"
-#~ msgstr "Nelze otevøít soubor s pravidly <%s>"
-#~ msgid "Run VERBOSELY"
-#~ msgstr "Roz¹íøený výpis"
-#~ msgid "elevin raster map <%s> not found"
-#~ msgstr "vstupní rastr s elevací <%s> nebyl nalezen"
-#~ msgid "aspin raster map <%s> not found"
-#~ msgstr "vstupní rastr s expozicí <%s> nebyl nalezen"
-#~ msgid "slopein raster map <%s> not found"
-#~ msgstr "vstupní rastr sklonu <%s> nebyl nalezen"
-#~ msgid "linkein raster map <%s> not found"
-#~ msgstr "vstupní rastr s Linkovými koeficienty <%s> nebyl nalezen"
-#~ msgid "albedo raster map <%s> not found"
-#~ msgstr "rastrový soubor albeda <%s> nebyl nalezen"
-#~ msgid "coefbh raster map <%s> not found"
-#~ msgstr "raststrový soubor s koeficientem pøímého sluneèního záøení <%s> nebyl nalezen"
-#~ msgid "coefdh raster map <%s> not found"
-#~ msgstr "rastrový soubor s koeficientem difíºzního záøení <%s> nebyl nalezen"
-#~ msgid "Bilinear interpolation utility for raster map layers."
-#~ msgstr "Nástroj pro bilineární interpolaci rastrových map."
-#~ msgid "Specific input value to be assigned to the north and/or south poles for longitude-latitude grids"
-#~ msgstr "Specifická hodnota vstupu, která bude pøiøa¾ena severnímu a/nebo ji¾nímu pólu pro rastrové mapy v systému zem. délka/¹íøka"
-#~ msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
-#~ msgstr "Tento modul je zastaralý. Prosím, pou¾ijte 'r.stats.interp'."
-#~ msgid "Unable to open MASK"
-#~ msgstr "Nemohu otevøít MASKu"
-#~ msgid "Rowio_setup failed"
-#~ msgstr "Rowio_setup selhal"
-#~ msgid "Rowio_get failed"
-#~ msgstr "Rowio_get selhal"
-#~ msgid "GIS Coincidence Tabulation Facility\n"
-#~ msgstr "Schopnost spoèítat tabulku koincidence\n"
-#~ msgid "This utility will allow you to compare the coincidence of two map layers\n"
-#~ msgstr "Tento nástroj vám umo¾ní porovnat coincidence dvou mapových vrstev\n"
-#~ msgid "The report can be made in one of 8 units."
-#~ msgstr "Zprávu lze vytvoøit za pomoci nìkteré z osmi jednotek."
-#~ msgid "Please choose a unit by entering one of the following letter codes:"
-#~ msgstr "Vyberte prosím jednotky zadáním jednoho z následujících písmen:"
-#~ msgid "     'c': cells"
-#~ msgstr "    'c': pixely"
-#~ msgid "     'p': percent cover of region"
-#~ msgstr "     'p': procenta pokryvnosti regionu"
-#~ msgid "     'x': percent of '%s' category (column)"
-#~ msgstr "     'x': procenta '%s' kategorie (sloupec)"
-#~ msgid "     'y': percent of '%s' category (row)"
-#~ msgstr "     'y': procenta '%s' kategorie (øádek)"
-#~ msgid "     'a': acres"
-#~ msgstr "     'a': akry"
-#~ msgid "     'h': hectares"
-#~ msgstr "     'h': hektary"
-#~ msgid "     'k': square kilometers"
-#~ msgstr "     'k': ètvereèní kilometry"
-#~ msgid "     'm': square miles\n"
-#~ msgstr "     'm': ètvereèní míle\n"
-#~ msgid "     'Q': quit"
-#~ msgstr "     'Q': konec"
-#~ msgid "Do you wish to save this report in a file? (y/n) [n] "
-#~ msgstr "Pøejete si ulo¾it tuto zprávu do souboru? (y/n) [n] "
-#~ msgid ""
-#~ "Enter the file name or path\n"
-#~ msgstr ""
-#~ "Zadejte jméno souboru\n"
-#~ msgid "'%s' being saved\n"
-#~ msgstr "'%s' ulo¾en\n"
-#~ msgid "Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
-#~ msgstr "Pøejete si vytisknout tuto zprávu (vy¾aduje Unixový pøíkaz lpr)? (y/n) [n] "
-#~ msgid ""
-#~ "Do you wish it printed in 80 or 132 columns?\n"
-#~ msgstr ""
-#~ "Pøejete si vytisknout ji v 80 nebo 132 sloupcích?\n"
-#~ msgid "Do you wish to run this report with a different unit of measure? (y/n) [y] "
-#~ msgstr "Pøejete si vytvoøit tuto zprávu s rùznými jednotkami? (y/n) [y]"
-#~ msgid "Unable to open vector map <%s> in <%s>"
-#~ msgstr "Nelze otevøít vektorovou mapu <%s> v  <%s>"
-#~ msgid "Interactively select End-Points"
-#~ msgstr "Interaktivní výbìr koncových bodù"
-#~ msgid "Use mouse to select Start Point\n"
-#~ msgstr "Pro výbìr poèáteèního bodu pou¾ijte my¹\n"
-#~ msgid ""
-#~ "\n"
-#~ "Use mouse to draw profile line\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Pou¾ít my¹ pro kreslení linie profilu\n"
-#~ msgid "Buttons:\n"
-#~ msgstr "Tlaèítka:\n"
-#~ msgid "Left:   Mark next point\n"
-#~ msgstr "Levé tlaèítko:  Oznaè dal¹í bod\n"
-#~ msgid "Middle: Mark next point\n"
-#~ msgstr "Prostøední tlaèítko: Oznaè dal¹í bod\n"
-#~ msgid ""
-#~ "Right:  Finish profile and exit\n"
-#~ "\n"
-#~ msgstr ""
-#~ "Pravé:  ukonèit profil a opustit\n"
-#~ "\n"
-#~ msgid "Finds the median of values in a cover map within areas assigned the same category value in a user-specified base map."
-#~ msgstr "Nalezne median hodnot z pøekrývající mapy, která bude rozdìlena podle ploch se stejnými hodnotami z pokladové mapy."
-#~ msgid "Base raster map <%s> not found"
-#~ msgstr "podkladová rastrová vrstva <%s> nebyla nalezena"
-#~ msgid "Base map and output map <%s> must be different"
-#~ msgstr "Základní mapa a výstupní <%s> mapa musí být rùzné"
-#~ msgid "Unable to read category labels of raster map <%s>"
-#~ msgstr "Nelze èíst soubor se ¹tíky kategorí mapy <%s>"
-#~ msgid "Unable to get current region"
-#~ msgstr "Nelze získat aktuální region"
-#~ msgid "Unused; retained for compatibility purposes, will be removed in future"
-#~ msgstr "Nepou¾ito; zbylo z dùvodù kompatibility, bude v budoucnosti vymazáno"
-#~ msgid "Invoke slow, but memory frugal operation (generally not needed, will be removed in future)"
-#~ msgstr "Vyvolá pomalou, ale na pamì» nenároènou operaci (obecnì není potøeba a bude v budoucnu vyjmuto)"
-#~ msgid "Cannot export attribute table fields for layer < 1. Skipping export"
-#~ msgstr "Nelze exportovat pole atributové tabulky pro vrstvy < 1. Pøeskakuji export."
-#~ msgid "No numerical attributes found. Skipping export"
-#~ msgstr "Nebyly nalezeny ¾ádné èíselné atributy. pøeskakuji export"
-#~ msgid "Error reading value of attribute '%s'"
-#~ msgstr "Chyba pøi ètení hodnoty atributu '%s'"
-#~ msgid "Export numeric attribute table fields as VTK scalar variables"
-#~ msgstr "exportuje numerické pole atributové tabulky jako VTK skalární promìné"
-#~ msgid "Quiet; No chatter"
-#~ msgstr "Ti¹e; ¾ádné zprávy"
-#~ msgid "ask_transform_coor():  Leaving session.. \n"
-#~ msgstr "ask_transform_coor():  Opou¹tím sezení...\n"
-#~ msgid " Number of points that have been entered: %d\n"
-#~ msgstr " Poèet zadaných bodù: %d\n"
-#~ msgid "Please answer yes or no"
-#~ msgstr "Odpovìzte prosím yes (ano) nebo no (ne)"
-#~ msgid "Network input map <%s> not found"
-#~ msgstr "Vstupní mapa sí»ì <%s> nebyla nalezena"
-#~ msgid "Option <%s>: <%s> exists."
-#~ msgstr "Volba <%s>: <%s> ji¾ existuje"
-#~ msgid "Use '%s' option to change vector map name"
-#~ msgstr "Pou¾ijte volbu '%s' pro zmìnu jména vektoru"
-#~ msgid "ASCII file to be imported, if not given reads from standard input"
-#~ msgstr "Soubor ASCII pro import, pokud není zadán, ète se standardní vstup"
-#~ msgid "Number of column used as x coordinate (first column is 1) for points mode"
-#~ msgstr "Èíslo sloupce pou¾itého jako souøadnice x (první sloupec je 1) pro bodový re¾im"
-#~ msgid "vector, editing, digitization"
-#~ msgstr "vektor, editace, digitalizace"
-#~ msgid "Interactive editing and digitization of vector maps."
-#~ msgstr "Interaktivní editace a digitalizace vektorových map."
-#~ msgid "Create new file if it does not exist."
-#~ msgstr "Vytvoøí nový soubor, pokud neexistuje."
-#~ msgid "New empty map created."
-#~ msgstr "Nová prázdná mapa byla vytvoøena."
-#~ msgid "Map <%s> does not exist in current mapset. Add flag -n to create a new map."
-#~ msgstr "Mapa <%s> neexistuje v souèasném mapsetu. Pøidejte pøepínaè -n pro vytvoøení nové mapy."
-#~ msgid "Region restored to original extent."
-#~ msgstr "Region nastaven na pùvodní hodnoty"
-#~ msgid "Name of input point vector map"
-#~ msgstr "Název vstupní bodové vektorové vrstvy"
-#~ msgid "Output vector map must be specified"
-#~ msgstr "Výstupní vektorová mapa musí být specifikována"
-#~ msgid "Point vector map must be specified"
-#~ msgstr "Bodová vektorová mapa musí být specifikována"
-#~ msgid "Threshold value must be specified"
-#~ msgstr "Mezní hodnota musí být zadána"
-#~ msgid "%d arcs added to network (nlayer %d)"
-#~ msgstr "%d obloukù pøidáno do sítì (nvrstva: %d)"
-#~ msgid "Cannot calculate area centroid z coordinate"
-#~ msgstr "Nelze spoèítat z-souøadnici centroidu"
-#~ msgid "Unused"
-#~ msgstr "Nepou¾itý"
-#~ msgid "Cannot load overlap weights. Column %s is not of numeric type in table <%s>"
-#~ msgstr "Nelze naèíst váhu pøekrytí. Sloupec %s v tabulce <%s> není èíselného typu."
-#~ msgid "%s: Unable to read font definition file; use the default"
-#~ msgstr "%s: Nelze èíst definièní soubor FreeType; pou¾iji výchozí"
-#~ msgid "%s: No font definition file"
-#~ msgstr "%s: ®ádný definièní soubor FreeType"
-#~ msgid "Numeric column to give precedence in case of overlapping labels. The label with a smaller weight is hidden."
-#~ msgstr "ÈÍselný sloupec pro zadání váhy v pøípadì pøekrytí. Popisek s men¹í hodnotou váhy bude schován"
-#~ msgid "Power parameter; greater values assign greater influence to closer points"
-#~ msgstr "Násobný parametr; pøiøadí vy¹¹í vliv bli¾¹ím bodùm"
-#~ msgid "database, SQL"
-#~ msgstr "databáze, SQL"
-#~ msgid "The password was stored in file"
-#~ msgstr "Heslo bylo ulo¾eno v souboru."
-#~ msgid "OGR driver: column '%s', OGR type %d  is not supported"
-#~ msgstr "Ovladaè OGR: sloupec '%s', typu %d není podporován"
-#~ msgid "Calculate the groundwater distance velocity vector field and write the x, y, and z components to maps named name_[xyz]. Name is basename for the new raster3d maps"
-#~ msgstr "Vypoèítat prùtokovou rychlost vektorového pole a zapi¹ x,y a z èásti do map pojmenovaných jmeno_[xyz]. Jméno mapy je základ pro r3d rastrovou mapu."
-#~ msgid "The direct cholesky solver do not work with sparse matrices"
-#~ msgstr "Pøímá choleskyho analýza nepracuje s øídkou maticí"
-#~ msgid "raster, resample"
-#~ msgstr "rastr, pøevzorkování"
-#~ msgid "raster, geomorphology"
-#~ msgstr "rastr, geomorfologie"
-#~ msgid "Lat/Long location is not supported"
-#~ msgstr "Location lat/long není podporována"
-#~ msgid "Calculating map %01d of %01d (angle %lf, raster map <%s>)"
-#~ msgstr "Výpoèet mapy %01d z %01d (úhel %lf, rastrová mapa <%s>)"
-#~ msgid "Converts ASCII raster file to binary raster map layer."
-#~ msgstr "Pøevede ASCII rastrový soubor na binární rastrovou mapu."
-#~ msgid "Converts a raster map layer into an ASCII text file."
-#~ msgstr "Pøevede rastrovou mapu do ASCII souboru."
-#~ msgid "raster, null data"
-#~ msgstr "rastr, noullvé data"
-#~ msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
-#~ msgstr "Exportuje rastrovou mapu GRASSu do GRIDATB.FOR souboru (TOPMODEL)"
-#~ msgid "Error writing color file for <%s>"
-#~ msgstr "Chyba pøi zápisu souboru color pro <%s>"
-#~ msgid "Interpolating raster map <%s> (%d rows)... "
-#~ msgstr "Interpoluji rastrovou mapu <%s> (%d øádkù)... "
-#~ msgid "Cannot create %s/.r.li/ directory"
-#~ msgstr "Nelze vytvoøit adresáø %s/r.li/"
-#~ msgid "Cannot create %s/.r.li/output/ directory"
-#~ msgstr "Nelze vytvoøit adresáø %s/r.li/output/"
-#~ msgid "Converts a raster map layer into a height-field file for POVRAY."
-#~ msgstr "Pøevede rastrovou mapu do souboru pro POVRAY."
-#~ msgid "Cannot read ew_res value"
-#~ msgstr "Nelze èíst hodnotu ew_res"
-#~ msgid "Cannot read ns_res value"
-#~ msgstr "Nelze èíst hodnotu ns_res"
-#~ msgid "[%s]: Map is the wrong resolution"
-#~ msgstr "[%s]: Mapa je ve ¹patném rozli¹ení"
-#~ msgid "Cannot get row %d (error = %d)"
-#~ msgstr "Nelze naèíst øádek %d (chyba = %d)"
-#~ msgid "Cannot set region to back to the initial region !!!"
-#~ msgstr "Nelze nastavit region zpìt na poèáteèní rozli¹ení!!!"
-#~ msgid "raster, terrain analysis"
-#~ msgstr "rastr, terénní analýza"
-#~ msgid "One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be specified!"
-#~ msgstr "Jeden z pøepínaèù \"-i\" nebo \"-r\" nebo voleb \"color\", \"rast\" nebo \"rules\" MUSÍ být zadána!"
-#~ msgid "%s: can only do up to %d raster maps, sorry\n"
-#~ msgstr "%s: mohu vytvoøit pouze %d rastrových map\n"
-#~ msgid "raster, map algebra"
-#~ msgstr "rastr, mapová algebra"
-#~ msgid "Converts raster maps into the VTK-Ascii format"
-#~ msgstr "Pøevede rastrové mapy do formátu VTK-Ascii"
-#~ msgid "Update the statistics (histogram, range) for [%s]? "
-#~ msgstr "Aktualizovat statistiku (histogram, rozsah) pro [%s]?"
-#~ msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
-#~ msgstr "Pøevede 3 GRASSové rastrové mapy (R,G,B) do souboru PPM s rozli¹ením pixelu podle aktuálnì definovaného regionu."
-#~ msgid "Export a raster map to the Virtual Reality Modeling Language (VRML)"
-#~ msgstr "Export rastrové mapy do Virtual Reality Modeling Language (VRML)"
-#~ msgid ""
-#~ "USAGE for basin delineation:\n"
-#~ "%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
-#~ "\n"
-#~ "USAGE for ARMSED FILE creation:\n"
-#~ "%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] ha=half_basin_map ar=ARMSED_file_name\n"
-#~ "\n"
-#~ "USAGE for slope length determination:\n"
-#~ "%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
-#~ msgstr ""
-#~ "POU®ITÍ pro vytvoøení povodí:\n"
-#~ "%s -4 el=mapa_elevace t=prahová_hodnota_bezodtokových_oblastí [ov=mapa_povrchového_odtoku] [dr=mapa_smìru_odtoku] [de=mapa_depresí] [ac=mapa_akumulace] [di=mapa_zobrazení] ba=mapa_povodí [se=mapa_segmentż_drah_povrchového_odtoku]\n"
-#~ "\n"
-#~ "POUŽITÍ pro vytvoøení souboru ARMSED:\n"
-#~ "%s [-4] el=mapa_elevace t=prahová_hodnota_bezodtokových_oblastí [ov=mapa_povrchového_odtoku] [dr=mapa_smìru_odtoku] [de=mapa_depresí] [ac=mapa_akumulace] [di=mapa_zobrazení] [ba=mapa_povodí] [se=mapa_segmentż_drah_povrchového_odtoku] ha=mapa_polopovodí(halfbasin) ar=jméno_souboru_ARMSED\n"
-#~ "\n"
-#~ "POU®ITÍ urèení délky svahu:\n"
-#~ "%s [-4] el=mapa_elevace t=prahová_hodnota_bezodtokových_oblastí [dr=mapa_smìru_odtoku] [de=mapa_depresí] [ac=mapa_akumulace] [di=mapa_zobrazení] [ms=maximální_délka_svahu] [ob=mapa_bariér] [S=mapa_faktoru_sklonu_svahu] LS=mapa_faktoru_sklonu_a_délky_svahu [r=mapa_stru¾kové_eroze] [sd=hodnota_sklonu_svahu_pøi_depozici]"
-#~ msgid "Input value: maximum length of surface flow, for USLE"
-#~ msgstr "Vstupní hodnota: maximální délka povrchového odtoku, pro USLE"
-#~ msgid "Setting quant rules for input map(s) to (%f %f) -> (%d,%d)"
-#~ msgstr "Nastavuji kvant. pravidla pro vstupní map[y] na (%f %f) -> (%d,%d)"
-#~ msgid "Raster map <%s> in mapset <%s> is a floating point map. Decimal values will be rounded to integer!"
-#~ msgstr "Mapa <%s> v mapsetu <%s> obsahuje hodnoty s plovoucí desetinnou èárkou. Tyto hodnoty budou zaokrouhleny na celé èíslo!"
-#~ msgid "Unable to find stop vector <%s>"
-#~ msgstr "Nelze nalézt koncový vektor <%s> "
-#~ msgid "Data range of raster map <%s> is %s to %s (entire map)"
-#~ msgstr "Rozsah dat rastrové mapy <%s> je %s a¾ %s (celá mapa)"
-#~ msgid "Integer data range of raster map <%s> is empty"
-#~ msgstr "Celoèíselný rozsah dat rastrové mapy <%s> je prázdný"
-#~ msgid "Integer data range of raster mao <%s> is %d to %d"
-#~ msgstr "Rozsah celoèíselných hodnot rastrové mapy <%s> je %d a¾ %d"
-#~ msgid "'%s' is not a valid rule"
-#~ msgstr "'%s' není platné pravidlo"
-#~ msgid ""
-#~ "Calculate the groundwater filter velocity vector field [m/s]\n"
-#~ "and write the x, and y components to maps named name_[xy]"
-#~ msgstr ""
-#~ "Vypoèítat filt rrychlosti pozemního toku vektorového pole [m/s]\n"
-#~ "a zapsat x a y èásti do map s názvem jmeno_mapy_[xy]"
-#~ msgid "raster, buffer"
-#~ msgstr "rastr, buffer, pásma"
-#~ msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster map layer."
-#~ msgstr "Pøevede ESRI ARC/INFO ascii rastr (GRID) na (binární) rastrovou mapu."
-#~ msgid "Converts a binary GRASS vector map (only points) layer into a 3D GRASS raster map layer."
-#~ msgstr "Pøevede binární GRASS vektorovou mapovou vrstvu (pouze body) na 3D GRASS rastrovou mapovou vrstvu."
-#~ msgid "When printing, limit to layer specified by the layer option"
-#~ msgstr "Pøi tisku je omezení urèeno nastavením vrstvy"
-#~ msgid "Creates a new vector as a read-only link to OGR layer."
-#~ msgstr "Vytvoøí novou vektorovou mapu jako odkaz na OGR vrstvu (pouze pro ètení)."
-#~ msgid "Random location perturbations of GRASS vector points"
-#~ msgstr "Náhodná odchylka location vektorových bodù"
-#~ msgid "Parameter(s) of distribution. If the distribution is uniform, only one parameter, the maximum, is needed. For a normal distribution, two parameters, the mean and standard deviation, are required."
-#~ msgstr "Parametr(y) rozdìlení. Pokud je rozdìlení uniformní, je potøebazadat pouze maximální parametr. Pro normální rozdìlení je potøeba zadatstøední hodnotu a smìrodatnou odchylku."
-#~ msgid "Calculate area centroids..."
-#~ msgstr "Vypoèítat centroidy plochy"
-#~ msgid "Vector map <%s> not found in the current mapset"
-#~ msgstr "Vektorová mapa <%s> nebyla nalezena v souèasném mapsetu"
-#~ msgid "Difference in x,y direction for moving feature or vertex"
-#~ msgstr "Rozdíl ve smìrech x,y pro posun prvku nebo lomového bodu"
-#~ msgid "Need either 3D vector or layer and column with z values"
-#~ msgstr "Je potøeba buï 3D vektorová vrstva nebo vrstva a sloupec se z souøadnicemi"
-#~ msgid "Layer but not column with z values given"
-#~ msgstr "Vrstva zadána, ale ne sloupec s z souøadnicemi"
-#~ msgid "vector, networking"
-#~ msgstr "vektor, sí»ování"
-#~ msgid "Layer number (from)"
-#~ msgstr "Èíslo vrstvy (from)"
-#~ msgid "Layer number (to)"
-#~ msgstr "Èíslo vrstvy (to)"
-#~ msgid "Either 'rules' or 'col' must be specified"
-#~ msgstr "Buï 'pravidlo' nebo 'sloupec' musí být zadán"
-#~ msgid "vector, geometry"
-#~ msgstr "vektor, geometry"
-#~ msgid "Create points along input lines in new vector with 2 layers."
-#~ msgstr "Vytvoøí body podél vstupních linií a ulo¾í do nového souboru o dvou vrstvách."
-#~ msgid "%d points written to output vector map"
-#~ msgstr "%d bodù zapsáno do výstupní vektorové mapy"
-#~ msgid "Creates a vector map from ASCII points file or ASCII vector file."
-#~ msgstr "Vytvoøí vektorovou mapu ze souboru ASCII bodù nebo ASCII vektoru"
-#~ msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
-#~ msgstr "Pøevede GRASS binární vektorovou mapu do formátu GRASS ASCII."
-#~ msgid "Parameter '%s' ignored in standard mode"
-#~ msgstr "Parametr '%s' je ignorován ve standartním módu"
-#~ msgid "Creates topology for GRASS vector map."
-#~ msgstr "Vytváøí topologii pro vektorovou mapu GRASSu."
-#~ msgid "Name for output vector map where segments will be written"
-#~ msgstr "Výstupní mapa, do které budou zapsány segmenty linií"
-#~ msgid "Calculates univariate statistics for attribute. Variance and standard deviation is calculated only for points if specified."
-#~ msgstr "Poèítá základní statistiky pro atributy. Variance a standardní odchylka jsou poèítány pouze pokud jsou zadány body."
-#~ msgid "Extrudes flat vector object to 3D with defined height."
-#~ msgstr "Vytvoøí z plo¹ného vektorového objektu 3D o zadané vý¹ce"
-#~ msgid "vector, kernel density"
-#~ msgstr "vektor, jádrová hustota"
-#~ msgid "Vector map attribute column to use for comparison"
-#~ msgstr "Název sloupce atributu, který má být pou¾it pro porovnání"
-#~ msgid "Vector map to store differences"
-#~ msgstr "Vektorová mapa, do které budou ulo¾eny rozdíly."
-#~ msgid "Option scaling factor for values read from raster map. Sampled values will be multiplied by this factor"
-#~ msgstr "Faktor mìøítka pro hodnoty pøeètené z rastrové mapy. Hodnoty budou tímto faktorem pøenásobeny."
-#~ msgid "Vector based generalization."
-#~ msgstr "Generalizace prvkù vektorové mapy"
-#~ msgid "Number of vertices was reduced from %d to %d [%d%%]"
-#~ msgstr "Poèet opìrných bodù byl sní¾en z %d na %d [%d%%]"
-#~ msgid "Outputs basic information about a user-specified vector map."
-#~ msgstr "Vypí¹e základní informace o u¾ivatelem vybrané vektorové mapì."
-#~ msgid "Displaying column types/names for database connection of layer %d:"
-#~ msgstr "Zobrazí typ/jméno sloupce z databáze pøipojené na vrstvu %d:"
-#~ msgid "Map scale:       1:%d"
-#~ msgstr "Mapové mìøítko:       1:%d"
-#~ msgid "Map format:      %s"
-#~ msgstr "Formát mapy:    %s"
-#~ msgid "Name of creator: %s"
-#~ msgstr "Tvùrce mapy: %s"
-#~ msgid "Organization:    %s"
-#~ msgstr "Organizace:    %s"
-#~ msgid "Source date:     %s"
-#~ msgstr "Zdrojová data:    %s"
-#~ msgid "  Digitization threshold: %s"
-#~ msgstr "Mezní hodnota digitalizace: %s"
-#~ msgid "  Comments:"
-#~ msgstr "Poznámky:"
-#~ msgid "Convert OGR vector layers to GRASS vector map."
-#~ msgstr "Konvertuje vektorové vrstvy OGR na GRASS vektorové mapy."
-#~ msgid "Create a new vector map layer by combining other vector map layers."
-#~ msgstr "Vytvoøí nový binární vektorovou mapu kombinací více vektorových vrstev."
-#~ msgid "Patching vector map <%s@%s>..."
-#~ msgstr "Opravuji vektorovou mapu <%s@%s>..."
-#~ msgid "Attribute table column with values to interpolate"
-#~ msgstr "Tabulka atributù s hodnotami pro interpolaci"
-#~ msgid "No data points found"
-#~ msgstr "®ádná bodová data nenalezena"
-#~ msgid "Output quadrant centres, number of points is written as category"
-#~ msgstr "Výsupní støedy kvadrantù, poèet bodù bude zapsáno jako kategorie"
-#~ msgid "Counting sites in quadrats..."
-#~ msgstr "Poèítám body v kvadrátech..."
-#~ msgid "%d features written"
-#~ msgstr "%d prvkù zapsáno"
-#~ msgid "vector, category"
-#~ msgstr "vektorová mapa, kategorie"
-#~ msgid "Attach, delete or report vector categories to map geometry."
-#~ msgstr "Pøilo¾, sma¾ nebo vypi¹ vektorové kategorie dp mapové geometrie."
-#~ msgid "add;add a new category;del;delete all categories of given layer;chlayer;change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add the value specified by cat option to the current category value;report;print report (statistics), in shell style: layer type count min max;print;print category values, more cats in the same layer are separated by '/'"
-#~ msgstr "add; pøidat novou kategorii;del; smazat v¹echny kategorie dané vrstvy;chlayer;zmìnit èíslo vrstvy(napø. layer=3,1 zmìní vrstvu 3 na 1);sum;Pøidá specifickou hodnotu podle volby cat pro souèasnou hodnotu kategorii;report;vypí¹e zprávu(statistiku), ve stylu shellu: typ vrstvy count min max;print;vytiskni hodnotu kategorie, více kategorií ve stejné vrstvì je oddìleno '/'"
-#~ msgid "Creates a GRASS vector map of a user-defined grid."
-#~ msgstr "Vytvoøí GRASS vektorovou mapu podle u¾ivatelem definované møí¾ky"
-#~ msgid "Randomly generate a 2D/3D vector points map."
-#~ msgstr "Náhodnì vytvoøit 2D/3D bodovou vektorovou vrstvu."
-#~ msgid "v.random can't create 3D vector and attribute table at same time"
-#~ msgstr "v.random nemù¾e vytvoøit 3D vektorovou mapu a atributovou tabulku ve stejný èas"
-#~ msgid "vector, paint labels"
-#~ msgstr "vektor, ¹títky"
-#~ msgid "Copying vector objects from vector map <%s>..."
-#~ msgstr "Kopírují objekty z vektorové mapy <%s> ..."
-#~ msgid "Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
-#~ msgstr "Hranièní hodnota v mapových jednotkách, jedna honota pro ka¾dý nástroj (výchozí: 0.0[,0.0,...])"
-#~ msgid "%d lines / boundaries removed"
-#~ msgstr "%d linií/hranic odstanìno"
-#~ msgid "Required for operation 'connect'"
-#~ msgstr "Po¾adováno pro operaci 'spojení'"
-#~ msgid "nodes;new point is placed on each node (line end) if doesn't exist;connect;connect still unconnected points to vector network by inserting new line(s);report;print to standard output {line_category start_point_category end_point_category};nreport;print to standard output {point_category line_category[,line_category...]}"
-#~ msgstr "nodes; nový bod je umístìn na ka¾dý uzel (konec linie) pokud neexistuje;connect; spojuje je¹tì nespojené body do vektorové sí»ì vlo¾ením nových linií ;report; Vypí¹e na standartní výstup {kategorie_linie kategorie_poèáteèního_bodu kategorie_koncového_bodu};nreport; vypí¹e na standartní výstup {kategorie_bodu kategorie:linie[,kategorie_linie...]}"
-#~ msgid "%d new points written to output"
-#~ msgstr "%d nových bodù zapsáno do výstupní mapy"
-#~ msgid "Exports GRASS vector map layers to DXF file format."
-#~ msgstr "Exportuje GRASS vektory jako soubor DXF."
-#~ msgid "Tests for normality for points."
-#~ msgstr "Test normality bodù"
-#~ msgid "vector, querying"
-#~ msgstr "vektor, dotazování"
-#~ msgid "Queries a vector map layer at given locations."
-#~ msgstr "DOtazovat vektorovou mapu v daných locations."
-#~ msgid "Exports a GRASS vector map to SVG."
-#~ msgstr "Exportuje GRASS vektory jako soubor SVG."
-#~ msgid "Layer number (write to)"
-#~ msgstr "Èíslo vrstvy (pro zapsání)"
-#~ msgid "Query layer number (read from)"
-#~ msgstr "Èíslo dotazované vrstvy (pro naètení)"
-#~ msgid "Converts a GRASS binary vector map to VTK ASCII output."
-#~ msgstr "Pøeveï GRASS vektor na formát VTK ASCII."
-#~ msgid "Output surface raster map (elevation)"
-#~ msgstr "Výstupní mapa povrchu (elevace)"
-#~ msgid "Output cross-validation errors vector point file"
-#~ msgstr "Výstupní bodový soubor obsahující výsledné chyby køí¾ové validace"
-#~ msgid "Output vector map showing quadtree segmentation"
-#~ msgstr "Výstupní vektorový soubor ukazující segmentaci kvadratické stromové struktury"
-#~ msgid "Output vector map showing overlapping windows"
-#~ msgstr "Výstupní vektorový soubor ukazující pøekryv oken"
-#~ msgid "Name of the attribute column with values to be used for approximation (if layer>0)"
-#~ msgstr "Název sloupce atributu, jeho¾ hodnoty mají být pou¾ity pøi interpolaci (pokud layer>0)"
-#~ msgid ""
-#~ "Processing all selected output files\n"
-#~ "will require %d bytes of disk space for temp files"
-#~ msgstr ""
-#~ "Zpracování v¹ech vybraných výstupních souborù\n"
-#~ "bude vy¾adovat %d bytù místa na disku pro doèasné soubory"
-#~ msgid "Cannot write raster maps -- try to increase resolution"
-#~ msgstr "Nelze zapsat rastrové soubory -- pokuste se zvý¹it rozli¹ení"
-#~ msgid "No features drapped. Check Your computational region and input raster map."
-#~ msgstr "Nejsou vyvì¹eny ¾ádné prvky. Zkontrolujte prosím vá¹ výpoèení region a vstupní rastrovou mapu."
-#~ msgid "Creates a buffer around features of given type (areas must contain centroid)."
-#~ msgstr "Vytvoøí buffer okolo prvkù zadaného typu (plochy musí obsahovat centroid)"
-#~ msgid "This does nothing. It is retained for backwards compatibility"
-#~ msgstr "Toto nedìlá nic. Je zde ponecháno pro zpìtnou kompatibilitu"
-#~ msgid "This is an alias to the distance option. It is retained for backwards compatibility"
-#~ msgstr "Toto je náhrada pro volbu vzálenosti. Je zde ponecháno pro zpìtnou kompatibilitu"
-#~ msgid "Buffer distance in map units"
-#~ msgstr "Vzdálenost bufferu v mapových jednotkách"
-#~ msgid "The buffer option has been replaced by the distance option and will be removed in future."
-#~ msgstr "Volba Buferu byla nahrazena volbou vzdálenosti  a bude v budoucnu odstranìna."
-#~ msgid "Use the distance option instead of the buffer option."
-#~ msgstr "Pou¾ít volbu vzdálenosti místo volby buferu"
-#~ msgid "Export features with category (labeled) only. Otherwise all features are exported"
-#~ msgstr "Exportovat pouze prvky s kategoriemi (o¹títkované). V opaèném pøípadì budou exportovány v¹echny prvky"
-#~ msgid "The map contains islands. To preserve them in the output map, use the -c flag"
-#~ msgstr "Mapa obsahuje ostrovy. Pro jejich zachování ve výstupní mapì pou¾ijte pøepínaè -c"
-#~ msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') to export in 3D rather than 2D (default)"
-#~ msgstr "Vektorová mapa <%s> je 3D. Pou¾ijte volby vytvoøení specifické vrstvy (parametr 'lco') pro export ve 3D radìji ne¾ 2D (pøednastaveno)"
-#~ msgid "Key column '%s' not found"
-#~ msgstr "Sloupec s klíèem '%s' nebyl nalezen"
-#~ msgid "Lines buffers... "
-#~ msgstr "Bufery linií... "
-#~ msgid "vector, extract"
-#~ msgstr "vektor, vyjmutí"
-#~ msgid "imagery, rectify"
-#~ msgstr "obrazová datsa, rektifikace"
-#~ msgid "No initial camera exposure station for group [%s]"
-#~ msgstr "Není poèáteèní expozice postavení kamery pro skupinu [%s]"
-#~ msgid "Bad format in initial camera exposure station for group [%s]"
-#~ msgstr "©patný formát v poèáteèní expozici postavení kamery pro skupinu [%s]"
-#~ msgid "Interactively creates or modifies entries in a camera initial exposure station file for imagery group referenced by a sub-block."
-#~ msgstr "Interaktivnì vytvoøí nebo upraví vstupy v souboru poèáteèní expozice postavení kamery pro skupinu obrazových dat podle podle sub-blokù."
-#~ msgid "Interactively mark fiducial or reseau points on an image."
-#~ msgstr "Interaktivnì oznaèí vzta¾né nebo sí»ové body v obraze"
-#~ msgid "Please select the file(s) you wish to rectify by naming an output file"
-#~ msgstr "Prosím vyberte soubory, které si pøejete rektifikovat pojmenováním výstupního souboru"
-#~ msgid "No target elevation model selected for group <%s>"
-#~ msgstr "Nebyl vybrán ¾ádný model terénu pro vybranou skupinu <%s>"
-#~ msgid "No camera reference file selected for group <%s>"
-#~ msgstr "Nebyl vybrán ¾ádný referenèní soubor kamery pro skupinu <%s>"
-#~ msgid "Unable to determine raster cell type"
-#~ msgstr "Nelze zjistit typ rastrové (cell) mapy."
-#~ msgid "The initial piezometric head in [m]"
-#~ msgstr "Poèáteèní piezometrická hodnota v [m]"
-#~ msgid "The status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
-#~ msgstr "Status pro ka¾dou buòku, = 0 -neaktivní, 1 - aktivní, 2 - Dirichletovo ¹íøení"
-#~ msgid "The z-part of the hydraulic conductivity tensor in [m/s]"
-#~ msgstr "souøadnice z hydraulického napøimovaèe vodivosti v [m/s]"
-#~ msgid "Recharge raster map in m^3/s"
-#~ msgstr "Mapa obohacení v m^3/s "
-#~ msgid "The piezometric head result of the numerical calculation will be written to this map"
-#~ msgstr "Výsledná piezometrická hodnota numerického výpoètu bude zapsána do mapy"
-#~ msgid "Name for output raster map with lake"
-#~ msgstr "Název výstupní rastrové mapy s jezery"
-#, fuzzy
-#~ msgid "raster, terrain"
-#~ msgstr "rastr, interpolace"
-#~ msgid "Name of the water depth raster map [m]"
-#~ msgstr "Jméno rastrové mapy s vý¹kou vodní hladiny [m]"
-#~ msgid "Name of the x-derivatives raster map [m/m]"
-#~ msgstr "Název rastrové mapy s derivací x [m/m]"
-#~ msgid "Name of the y-derivatives raster map [m/m]"
-#~ msgstr "Název rastrové mapy s derivací y [m/m]"
-#~ msgid "Name of the detachment capacity coefficient raster map [s/m]"
-#~ msgstr "Jméno rastrové mapy s koeficientem klidové kapacity [s/m]"
-#~ msgid "Name of the transport capacity coefficient raster map [s]"
-#~ msgstr "Jméno rastrové mapy koeficientu transportní kapacity [s]"
-#~ msgid "Name of the critical shear stress raster map [Pa]"
-#~ msgstr "Jméno rastrové mapy kritických støihù [Pa]"
-#~ msgid "Name of the Mannings n raster map"
-#~ msgstr "Název rastrovéhé mapy drsnosti (Manningovo n)"
-#~ msgid "Name of the Mannings n value"
-#~ msgstr "Název hodnoty Manningova n"
-#~ msgid "Output transport capacity raster map [kg/ms]"
-#~ msgstr "Výstupní rastrová mapa transportní kapacity [kg/ms]"
-#~ msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
-#~ msgstr "Výstupní rastrová mapa transportem limitované eroze-usazování [kg/m2s]"
-#~ msgid "Output sediment concentration raster map [particle/m3]"
-#~ msgstr "Výstupní rastrová mapa koncentrace sedimentu [èástice/m3]"
-#~ msgid "Output sediment flux raster map [kg/ms]"
-#~ msgstr "Výstupní rastrová mapa toku sedimentù [kg/ms]"
-#~ msgid "Output erosion-deposition raster map [kg/m2s]"
-#~ msgstr "Výstupní rastrová mapa usazování-eroze [kg/m2s]"
-#~ msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
-#~ msgstr "Jméno rastrové mapy míry nadbyteènosti srá¾ej (rein-infilt) [mm/hod]"
-#~ msgid "Name of the runoff infiltration rate raster map [mm/hr]"
-#~ msgstr "Jméno rastrové mapy pomìru odtoku a infiltrace [mm/hod]"
-#~ msgid "Name of the flow controls raster map (permeability ratio 0-1)"
-#~ msgstr "Jméno rastrového souboru kontroly proudìní (pomìr permeability 0-1)"
-#~ msgid "Output water discharge raster map [m3/s]"
-#~ msgstr "Název výstupní rastrové  mapy vypu¹tìní vody [m3/s]"
-#~ msgid "Output simulation error raster map [m]"
-#~ msgstr "Výstupní rastrová mapa chyb simulace [m]"
-#~ msgid "Threshold water depth [m] (diffusion increases after this water depth is reached)"
-#~ msgstr "Prahová hloubka vody [m] (prostupnost se zvìt¹uje, pokud je tato hloubka dosa¾ena)"
-#~ msgid "Boundary condition status, 0-inactive, 1-active, 2-dirichlet"
-#~ msgstr "Stav hranic, 0-neaktivní, 1-aktivní, 2-dirichlet"
-#~ msgid "Water sources and sinks in [m^3/s]"
-#~ msgstr "Vodní zdroje a jezera v [m^3/s]"
-#~ msgid "Specific yield in [1/m]"
-#~ msgstr "Specifický výnos v [1/m]"
-#~ msgid "Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
-#~ msgstr "Mapa doplnìní napø.: 6*10^-9 na buòku v [m^3/s*m^2]"
-#~ msgid "The map storing the numerical result [m]"
-#~ msgstr "Mpa obsahují poèetní výsledky [m]"
-#~ msgid "Water level (head) of the river with leakage connection in [m]"
-#~ msgstr "Vý¹ka vodní hladiny øeky ve spojení s prùsakem v [m]"
-#~ msgid "The leakage coefficient of the river bed in [1/s]."
-#~ msgstr "Koeficient prùsaku dna øeky v [1/s]."
-#~ msgid "The height of the drainage bed in [m]"
-#~ msgstr "Vý¹ka odvodòovacího kanálu v [m]"
-#~ msgid "The leakage coefficient of the drainage bed in [1/s]"
-#~ msgstr "Koeficient prùsaku dna odvodòovacího kanálu v [1/s]."
-#~ msgid "Input map: amount of overland flow per cell"
-#~ msgstr "Vstupní mapa: mno¾ství povrchového odtoku na buòku"
-#~ msgid "Input map: terrain blocking overland surface flow, for USLE"
-#~ msgstr "Vstupní mapa: povrchu bránícího povrchovému odtoku, pro USLE"
-#~ msgid "Output map: number of cells that drain through each cell"
-#~ msgstr "Výstupní mapa: poèet bunìk, které teèou skrz ka¾dou buòku"
-#~ msgid "Output map: unique label for each watershed basin"
-#~ msgstr "Výstupní mapa: jednoznaèný ¹títek pro ka¾dé povodí"
-#~ msgid "Output map: each half-basin is given a unique value"
-#~ msgstr "Výstupní mapa: ka¾dému sub-povodí je dána jednoznaèná hodnota"
-#~ msgid "Output map: slope length and steepness (LS) factor for USLE"
-#~ msgstr "Výstupní mapa: délka svahu a sklon, faktor (LS) pro USLE"
-#~ msgid "Output map: slope steepness (S) factor for USLE"
-#~ msgstr "Výstupní mapa: faktor sklonu svahu (S) pro USLE"
-#~ msgid "Input value: minimum size of exterior watershed basin"
-#~ msgstr "Vstupní hodnota: minimální velikost vnìj¹ího povodí"
-#, fuzzy
-#~ msgid ""
-#~ "Sorry, if any of the following options are set:\n"
-#~ "    basin, stream, half.basin, length.slope, or slope.steepness\n"
-#~ "    you MUST provide a value for the basin threshold parameter."
-#~ msgstr ""
-#~ "Promiòte, pokud je zadána nìkterá z následujících voleb:\n"
-#~ "    basin, stream, half.basin, slope nebo LS\n"
-#~ "    MUSÍTE zadat prahovou hodnotu povodí (basin threshold)."
-#, fuzzy
-#~ msgid "unable to open flow accumulation map layer"
-#~ msgstr "nemohu otevøít novou mapu akumulace "
-#~ msgid "Output direction raster map"
-#~ msgstr "Výstupní rastrová mapa orientace"
-#~ msgid "Output raster map of problem areas"
-#~ msgstr "Výstupní rastrová mapa problémových oblastí"
-#~ msgid "Surface generation program from rasterized contours."
-#~ msgstr "Program pro tvorbu povrchù z vrstevnic ulo¾ených v rastrové podobì."
-#~ msgid "Name of existing raster map containing contours"
-#~ msgstr "Název existující rastrové mapy obsahující vrstevnice"
-#~ msgid "Creates/modifies the color table associated with a raster map layer."
-#~ msgstr "Vytvoøí/upraví tabulku barev spojenou s rastrovou mapou."
-#~ msgid "Raster map name from which to copy color table"
-#~ msgstr "Název rastrové mapy, ze které se má kopírovat tabulka barev"
-#~ msgid "Path to rules file (\"-\" to read rules from stdin)"
-#~ msgstr "Cesta k souboru s pravidly (\"-\" pro ètení pravidel ze standartního vstupu)"
-#~ msgid "Generates a raster map layer of distance to features in input layer."
-#~ msgstr "Vytvoøí rastrovou mapu se vzdáleností k prvkùm ve vstupní vrstvì."
-#~ msgid "(i)   Basin map created by r.water.outlet (MASK)"
-#~ msgstr "(i)   Mapa povodí vytvoøená r.water.outlet (MASKa)"
-#~ msgid "(o)   Direction map for depressionless elevation map"
-#~ msgstr "(o)   Mapa smìrù s mapou vý¹ek bez depresí"
-#~ msgid "(i)   Number of topographic index classes"
-#~ msgstr "(i)   Poèet tøíd topografického indexu"
-#~ msgid "(o/i) Topographic index statistics file"
-#~ msgstr "(i/o) Soubor se statistikou topografického indexu"
-#~ msgid "(i)   TOPMODEL Parameters file"
-#~ msgstr "(i)   Soubor s parametry pro TOPMODEL"
-#~ msgid "(i)   Rainfall and potential evapotranspiration data file"
-#~ msgstr "(i)   Soubor srá¾ek a potenciální evapotranspirací"
-#~ msgid "Creates a new map layer whose category values are based upon a reclassification of the categories in an existing raster map layer."
-#~ msgstr "Vytvoøí novou mapovou vrstvu její¾ hodnoty budou zalo¾eny na reklasifikaci hodnot výchozí rastrové mapy."
-#~ msgid "Raster map to be reclassified"
-#~ msgstr "Rastrová mapa, která má být reklasifikována"
-#~ msgid "Converts a raster map into a vector map layer."
-#~ msgstr "Pøevede rastrovou mapu na vektorovou."
-#~ msgid "Do not build vector topology (use with care for massive point export)"
-#~ msgstr "Nevytváøej vektorovou topologii (pou¾ít opatrnì pøi importu velkého mno¾ství bodù)b"
-#~ msgid "The map E grid coordinates"
-#~ msgstr "Východní souøadnice mapy"
-#~ msgid "Stream width (in meters). Default is raster cell width"
-#~ msgstr "©íøka bystøiny (v metrech). Výchozí je ¹íøka rastrové buòky"
-#~ msgid "Output flowpath length raster map"
-#~ msgstr "Výstupní rastr délky svahu"
-#~ msgid "Output flowline density raster map"
-#~ msgstr "Výstupní rastr hustoty povrchového odtoku"
-#~ msgid "3-D lengths instead of 2-D"
-#~ msgstr "3-D délky místo 2-D"
-#~ msgid "Output topographic index map"
-#~ msgstr "Výstupní mapa topografického indexu:"
-#, fuzzy
-#~ msgid "%s: Couldn't read color table for <%s@%s>"
-#~ msgstr "Nelze èíst barevnou tabulku pro %s"
-#, fuzzy
-#~ msgid "Either text or -c should be given"
-#~ msgstr "Mìl by být zadán \"value=\" nebo \"-i\""
-#, fuzzy
-#~ msgid "Unable to create face"
-#~ msgstr "Nelze vytvoøit index"
-#, fuzzy
-#~ msgid "Error reading hue data"
-#~ msgstr "Chyba pøi ètení mapy odstínu (hue)"
-#, fuzzy
-#~ msgid "R_color file for [%s] not available"
-#~ msgstr "Soubor s tabulkou barev pro <%s> není dostupný"
-#, fuzzy
-#~ msgid "Range file for [%s] not available"
-#~ msgstr "Soubor s kategoriemi pro <%s> není dostupný"
-#, fuzzy
-#~ msgid "List of categories to be displayed (INT maps)"
-#~ msgstr "Název rastrové mapy která bude zobrazena"
-#, fuzzy
-#~ msgid "Invert catlist"
-#~ msgstr "Invertovat barvy"
-#~ msgid "vector, interpolation"
-#~ msgstr "vektor, interpolace"
-#, fuzzy
-#~ msgid "If type is not given then DOUBLE PRECISION is used. Writes Z data to column instead of 3D vector."
-#~ msgstr "Zapí¹e y-souøadnice do sloupce místo vytvoøení 3D vektoru"
-#, fuzzy
-#~ msgid "Using 'double precision' for column <%s>"
-#~ msgstr "Nelze pou¾ít sloupec <%s>"
-#, fuzzy
-#~ msgid "Convex hull calculation requires at least three points. Exiting."
-#~ msgstr "Výpoèet konvexního obalu po¾aduje nejménì 3 body"
-#~ msgid "Name of input vector map containing lines"
-#~ msgstr "Vstupní mapa obsahující linie"
-#~ msgid "Area without centroid (may be OK for island)"
-#~ msgstr "Plochy bez centroidù (mù¾e být v poøádku pro ostrovy)"
-#~ msgid "Print all map connection parameters and exit in shell script style"
-#~ msgstr "Vypi¹ parametry souèasného pøipojení ve stylu shellu a ukonèi se."
-#~ msgid "Vector map <%s> is connected by:"
-#~ msgstr "Vektorová mapa <%s> je spojena:"
-#, fuzzy
-#~ msgid "Verbose module output"
-#~ msgstr "Roz¹íøený mód"
-#~ msgid "Prints/sets general DB connection for current mapset and exits."
-#~ msgstr "Vytisknout/nastavit obecné DB pøipojení aktuálního mapsetu a ukonèit se."
-#~ msgid "Name of file with sql statement"
-#~ msgstr "Název souboru s pøíkazy sql"
-#, fuzzy
-#~ msgid "Region sensitive output"
-#~ msgstr "Ètu výstup z r.stats"
-#, fuzzy
-#~ msgid "raster, elevation"
-#~ msgstr "Sleduj terén"
-#, fuzzy
-#~ msgid "Input coordinate file (omit to read from stdin)"
-#~ msgstr "Jméno vstupního souboru, nebo \"-\" proètení ze standardního vstupu"
-#, fuzzy
-#~ msgid "Images"
-#~ msgstr "dpz, obrazové zpracování"
-#, fuzzy
-#~ msgid "Compression for PNG files"
-#~ msgstr "Hodnota izolinií"
-#, fuzzy
-#~ msgid "PostScript"
-#~ msgstr "Výstupní soubor ve formátu PostScript"
-#, fuzzy
-#~ msgid "raster, tiling"
-#, fuzzy
-#~ msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2)"
-#~ msgstr "Název vstupní rastrové mapy(red -èervená)"
-#, fuzzy
-#~ msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3)"
-#, fuzzy
-#~ msgid "display, diagram"
-#~ msgstr "zobrazení"
-#, fuzzy
-#~ msgid "Reports geometry statistics for vectors."
-#~ msgstr "Vypí¹e statistiku pro rastrovou mapu."
-#, fuzzy
-#~ msgid "Raster map to use as MASK"
-#~ msgstr "Rastrová mapa, která má být vzorkována"
-#, fuzzy
-#~ msgid "Name of color column to populate"
-#, fuzzy
-#~ msgid "Name of vector polygon map"
-#~ msgstr "Jméno vektorové mapy k editaci"
-#, fuzzy
-#~ msgid "Name of raster map to calculate statistics from"
-#~ msgstr "Název rastrové mapy pro vlo¾ení do skupiny"
-#, fuzzy
-#~ msgid "calculates univariate statistics from a GRASS raster map"
-#~ msgstr "Spoèítá univariantní statistiku z ne-nullových bunìk rastrové mapy."
-#, fuzzy
-#~ msgid "Display monitor to start"
-#~ msgstr "Jméno rastrové mapy, obsahující výsledky"
-#, fuzzy
-#~ msgid "Layer number. If -1, all layers are extracted."
-#~ msgstr "Jméno OGR vrstvy, pokud není zadán, jsou pouze vyti¹tìny pøítomné vrstvy"
-#, fuzzy
-#~ msgid "raster, landscape structure analysis"
-#~ msgstr "rastr, analýza krajiny, index místa"
-#, fuzzy
-#~ msgid "Import of SPOT VGT NDVI file into a raster map"
-#~ msgstr "Importuje binární rastrový soubor jako GRASS rastrovou mapu."
-#, fuzzy
-#~ msgid "raster3d, voxel, statistics"
-#~ msgstr "rastr3d, statistika"
-#~ msgid "raster, export"
-#~ msgstr "rastr, export"
-#, fuzzy
-#~ msgid "Exports a GRASS raster map to a binary array."
-#~ msgstr "Exportuje rastrový soubor GRASSu do binárního pole."
-#, fuzzy
-#~ msgid "raster, color transformation"
-#~ msgstr "Chyba pøi pøevodu"
-#, fuzzy
-#~ msgid "raster, hydrology"
-#~ msgstr "rastr, tok, hydrologie"
-#~ msgid "Raster map matrix filter."
-#~ msgstr "Maticový filtr rastrových map."
-#, fuzzy
-#~ msgid "raster, export, png"
-#, fuzzy
-#~ msgid "raster, sun energy"
-#~ msgid "Name of the latitudes input raster map [decimal degrees]"
-#~ msgstr "Název rastrového souboru zem. ¹íøky [stupnì]"
-#, fuzzy
-#~ msgid "Import a binary raster file into a GRASS raster map."
-#, fuzzy
-#~ msgid "raster, rescale"
-#, fuzzy
-#~ msgid "raster, export, color table"
-#~ msgstr "rastr, tabulka barev"
-#, fuzzy
-#~ msgid "raster, map management"
-#, fuzzy
-#~ msgid "raster, geometry"
-#, fuzzy
-#~ msgid "raster, quantization"
-#~ msgstr "raster, projekce"
-#~ msgid "Illegal delete request"
-#~ msgstr "Neplatná ¾ádost delete"
-#, fuzzy
-#~ msgid "raster, transect"
-#, fuzzy
-#~ msgid "raster, random"
-#, fuzzy
-#~ msgid "raster, viewshed"
-#~ msgstr "rastr, série"
-#, fuzzy
-#~ msgid "raster, fire"
-#~ msgstr "rastr, import"
-#, fuzzy
-#~ msgid "raster, profile"
-#~ msgid "Maximum memory to be used was smaller than 3 MB, set to default = 300 MB."
-#~ msgstr "Maximální velikost pou¾ité pamìti byla men¹í ne¾ 3 MB, nastavuji výchozí hodnotu = 300 MB."
-#, fuzzy
-#~ msgid "raster, projection, transformation"
-#~ msgid "Re-projects a raster map from one location to the current location."
-#~ msgstr "Zmìna projekce rastrové mapy ze zvolené location do aktuální location."
-#~ msgid "Resolution of output map"
-#~ msgstr "Rozli¹ení výstupní mapy"
-#, fuzzy
-#~ msgid "Raster File Series to MPEG Conversion."
-#~ msgstr "Sada rastrových souborù pro program, vytváøející MPEG."
-#~ msgid ""
-#~ "Convert on the fly, use less disk space\n"
-#~ "\t(requires r.out.ppm with stdout option)"
-#~ msgstr ""
-#~ "Pøevod za bìhu, pou¾ívá ménì diskového prostoru\n"
-#~ "\t(potøebuje r.out.ppm s volbou standardního výstupu)"
-#, fuzzy
-#~ msgid "CHILD[pid = %i]: unable to open <%s> mask ... continuing without!"
-#~ msgstr "DCEØINÝ PROCES[pid = %i]: nelze otevøít soubor s maskou %s ... pokraèuji bez ní!"
-#~ msgid "GIS format to write (case sensitive, see also -l flag)"
-#~ msgstr "Formát souboru (na velikosti písmen zále¾í, viz také pøepínaè -l)"
-#, fuzzy
-#~ msgid "raster, sun position"
-#, fuzzy
-#~ msgid "<%s> is an ilegal name"
-#~ msgstr "<%s> je neplatné jméno souboru"
-#, fuzzy
-#~ msgid "raster, thin"
-#, fuzzy
-#~ msgid "Thins non-zero cells that denote linear features in a raster map."
-#~ msgstr "Zmen¹í nenulové buòky tak, aby vznikly lineární struktury."
-#~ msgid "fp: Data range is %.25f to %.25f\n"
-#~ msgstr "fp: Rozsah dat je %.25f a¾ %.25f\n"
-#, fuzzy
-#~ msgid "raster, metadata, timestamp"
-#~ msgstr "rastr, metadata"
-#, fuzzy
-#~ msgid "raster, conversion, vectorization"
-#, fuzzy
-#~ msgid "raster, category"
-#, fuzzy
-#~ msgid "raster, volume"
-#~ msgstr "Rastrová hodnota"
-#, fuzzy
-#~ msgid "raster, distance"
-#, fuzzy
-#~ msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)."
-#~ msgstr "Konsrukce svahových køivek (drah odtoku), délek odtoku a hustoty odtoku (do svahu) z rastrové mapy elevace (DMT)"
-#, fuzzy
-#~ msgid "raster, querying"
-#~ msgid "raster, import, conversion"
-#~ msgstr "rastr, import, pøevod"
-#~ msgid "File containing weights"
-#~ msgstr "Soubor obsahující váhy"
-#, fuzzy
-#~ msgid "general, version"
-#~ msgstr "Opravte prosím nastavení."
-#, fuzzy
-#~ msgid "general, settings, search path"
-#, fuzzy
-#~ msgid "%s: removed"
-#~ msgstr "%d lomových bodù smazáno"
-#, fuzzy
-#~ msgid "format"
-#~ msgstr "Formát"
-#, fuzzy
-#~ msgid "display, raster, profile"
-#, fuzzy
-#~ msgid "name"
-#~ msgstr "U¾ivatel"
-#, fuzzy
-#~ msgid "display, distance"
-#, fuzzy
-#~ msgid "display, menu"
-#, fuzzy
-#~ msgid "display, map management"
-#, fuzzy
-#~ msgid "display, metadata"
-#, fuzzy
-#~ msgid "display, raster, RGB"
-#, fuzzy
-#~ msgid "display, position, querying"
-#, fuzzy
-#~ msgid "display, geometry"
-#, fuzzy
-#~ msgid "display, color transformation"
-#~ msgstr "obrazová data, barevná transformace, RGB, HIS"
-#, fuzzy
-#~ msgid "Unknown item type in pad: %s"
-#~ msgstr "Neznámý typ: %d"
-#, fuzzy
-#~ msgid "display, histogram, statistics"
-#~ msgstr "rastr, statistika"
-#, fuzzy
-#~ msgid "display, paint labels"
-#, fuzzy
-#~ msgid "display, visualization, raster, vector, raster3d"
-#~ msgstr "Organizace, kde byla vektorová mapa vytvoøena"
-#, fuzzy
-#~ msgid "display, zoom"
-#, fuzzy
-#~ msgid "vector, raster, resample"
-#, fuzzy
-#~ msgid "vector, network, allocation"
-#, fuzzy
-#~ msgid "vector, networking, maintenance"
-#~ msgstr "Provádí správu sí»ì"
-#, fuzzy
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)"
-#~ msgstr "mi(míle),f(stopy),me(metry),k(kilometery),a(akry),h(hektary)"
-#~ msgid "douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker Algorithm with reduction parameter;lang;Lang Simplification Algorithm;reduction;Vertex Reduction Algorithm eliminates points close to each other;reumann;Reumann-Witkam Algorithm;remove_small;Removes lines shorter than threshold and areas of area less than threshold;boyle;Boyle's Forward-Looking Algorithm;sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;Interpolation by Cubic Hermite Splines;snakes;Snakes method for line smoothing;network;Network generalization;displacement;Displacement of lines close to each other;"
-#~ msgstr "douglas;Douglas-Peuckerùv algoritmus;douglas_reduction;Douglas-Peuckerùv algoritmus s parametrem redukce;lang;Lang Simplification Algorithm;reduction;Algoritmus pro vylouèení opìrných bodù, elimunuje body, které se nachází pøíli¹ blízko sebe;reumann;Reumann-Witkam Algorithm;remove_small;Odstraní linie krat¹í ne¾ daná práhová hodnota a plochy s výmìrou men¹í ne¾ daná prahová hodnota;boyle;Boyle's Forward-Looking Algorithm;sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;Interpolace (Cubic Hermite Splines);snakes;Metoda pro vyhlazení liniových prvkù;network;Generalizace sítì;displacement;Posunutí liniových prvkù, které se nachází vedle sebe;"
-#, fuzzy
-#~ msgid "vector, network, isolines"
-#, fuzzy
-#~ msgid "vector, network, salesman"
-#, fuzzy
-#~ msgid "vector, geometry, statistics"
-#~ msgstr "vektor, statistika"
-#, fuzzy
-#~ msgid "vector, network, shortest path"
-#~ msgstr "vektor, import, body"
-#~ msgid "vector, import, sites"
-#~ msgid "Converts files in DXF format to GRASS vector map format."
-#~ msgstr "Pøevede soubory ve formátu DXF do formátu GRASS-vektor"
-#, fuzzy
-#~ msgid "Converts GRASS vector map to one of the supported OGR vector formats."
-#~ msgstr "Konvertuje mapu do jednoho z podporovaných vektorových formátù OGR."
-#, fuzzy
-#~ msgid "Feature type(s). Combinations not supported by all output formats. Default: first type found in input."
-#~ msgstr "Typ prvky. Kombinace typù není podporována v¹emi formáty."
-#~ msgid "%d areas found, but not requested to be exported. Verify 'type' parameter."
-#~ msgstr "Nalezeno %d ploch, nebyly v¹ak po¾adovány pro export. Ovìøte parametr 'type'."
-#, fuzzy
-#~ msgid "%d kernel(s) found, but not requested to be exported. Verify 'type' parameter."
-#~ msgstr "Nalezeno %d linií, nebyly v¹ak po¾adovány pro export. Ovìøte parametr 'type'."
-#, fuzzy
-#~ msgid "No points found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Nalezeno %d bodù, nebyly v¹ak po¾adovány pro export. Ovìøte parametr 'type'."
-#, fuzzy
-#~ msgid "No lines found, but requested to be exported. Will skip this geometry type."
-#, fuzzy
-#~ msgid "No boundaries found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Nalezeno %d hranièních linií, nebyly v¹ak po¾adovány pro export. Ovìøte parametr 'type'."
-#, fuzzy
-#~ msgid "No areas found, but requested to be exported. Will skip this geometry type."
-#, fuzzy
-#~ msgid "No centroids found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Nalezeno %d centroidù, nebyly v¹ak po¾adovány pro export. Ovìøte parametr 'type'."
-#, fuzzy
-#~ msgid "No faces found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Nalezeno %d 3D polygonù, nebyly v¹ak po¾adovány pro export. Ovìøte parametr 'type'."
-#, fuzzy
-#~ msgid "No kernels found, but requested to be exported. Will skip this geometry type."
-#, fuzzy
-#~ msgid "No volumes found, but requested to be exported. Will skip this geometry type."
-#, fuzzy
-#~ msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
-#, fuzzy
-#~ msgid "Exporting %i geometries..."
-#~ msgstr "Exportuji %i body/linie..."
-#, fuzzy
-#~ msgid "vector, projection, transformation"
-#~ msgstr "vektor, transformace"
-#, fuzzy
-#~ msgid "vector, network, articulation points"
-#~ msgstr "vektor, import, databáze, body"
-#, fuzzy
-#~ msgid "vector, network, connectivity"
-#, fuzzy
-#~ msgid "vector, spatial query"
-#, fuzzy
-#~ msgid "vector, geometry, triangulation"
-#~ msgstr "vektor,geometrie, vzorkování"
-#, fuzzy
-#~ msgid "vector, network, steiner tree"
-#~ msgid "Type: %s"
-#~ msgstr "Typ: %s"
-#~ msgid ""
-#~ "\n"
-#~ "New vector map <%s> boundary coordinates:"
-#~ msgstr ""
-#~ "\n"
-#~ "Nová vektorová mapa <%s> má hranièní souøadnice:"
-#, fuzzy
-#~ msgid "vector, network, flow"
-#, fuzzy
-#~ msgid "Calculate geometry distances instead of table data."
-#~ msgstr "%s akumuluje tyto hodnoty místo plochy.\n"
-#, fuzzy
-#~ msgid "Unable select categories from table <%s>"
-#~ msgstr "Nelze vybrat data z tabulky <%s>"
-#, fuzzy
-#~ msgid "Unparsable longitude value: [%s]"
-#~ msgstr "Nezpracovatelná hodnota zem. ¹íøky ve sloupci <%d>: %s"
-#, fuzzy
-#~ msgid "Unparsable latitude value: [%s]"
-#~ msgstr "Nezpracovatelná hodnota zem. vý¹ky ve sloiupci <%d>: %s"
-#, fuzzy
-#~ msgid "vector, external, import"
-#~ msgstr "vektor, export"
-#~ msgid ""
-#~ "\n"
-#~ "%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
-#~ msgstr ""
-#~ "\n"
-#~ "%d lomových bodù ze vstupu %d (lomové body daného typu) smazáno, tj. %.2f %%"
-#, fuzzy
-#~ msgid "vector, geometry, buffer"
-#~ msgstr "vektor, geometrie, 3D"
-#~ msgid "Print types/names of table columns for specified layer instead of info"
-#~ msgstr "Vypí¹e typy/názvy sloupcù tabulky pro specifikovanou vrstvu namísto infa"
-#, fuzzy
-#~ msgid "Use z-coordinates (3D vector only)"
-#~ msgstr "Pokud nastaveno na 0, jsou pou¾ity souøadnice z (pouze u 3D vektorù)"
-#, fuzzy
-#~ msgid "vector, network, centrality measures"
-#~ msgstr "Výpoèet polohy støedu..."
-#, fuzzy
-#~ msgid "vector, network, components"
-#, fuzzy
-#~ msgid "vector, network, spanning tree"
-#, fuzzy
-#~ msgid "miscellaneous, distance"
-#~ msgstr "rùzné"
-#~ msgid "Reading file [%s]..."
-#~ msgstr "Ètu soubor [%s] ..."
-#~ msgid "List paper formats ( name width height left right top bottom(margin) )"
-#~ msgstr "Vypsat seznam formátù (jméno ¹íøka vý¹ka levé pravé horní dolní (odsazení))"
-#~ msgid "PostScript output file"
-#~ msgid "PostScript file [%s] successfully written."
-#~ msgstr "Soubor Postscriptu [%s] byl úspì¹nì zapsán."
-#~ msgid "Reading raster maps in group <%s> ..."
-#~ msgstr "Naèítám rastrový soubor ve skupinì <%s> ..."
-#~ msgid "Scale set to %s."
-#~ msgstr "Mìøítko nastaveno na %s."
-#, fuzzy
-#~ msgid "database, attribute table, connection settings"
-#~ msgstr "databáze, atributová tabulka, SQL"
-#, fuzzy
-#~ msgid "Calculates univariate statistics from a raster map based on vector polygons and uploads statistics to new attribute columns."
-#, fuzzy
-#~ msgid "imagery, edges"
-#~ msgstr "Zapisuji body ..."
-#~ msgid ""
-#~ "Input raster map <%s> does not exist in group <%s>.\n"
-#~ " Try:\n"
-#~ msgstr ""
-#~ "Vstupní rastrová mapa <%s> neexistuje ve skupinì <%s>.\n"
-#~ " Zkuste:\n"
-#~ msgid "into  <%s@%s> (location <%s>) ... %s"
-#~ msgstr "do <%s@%s> (location <%s> ... %s"
-#, fuzzy
-#~ msgid "imagery, geometry"
-#, fuzzy
-#~ msgid "imagery, statistics"
-#, fuzzy
-#~ msgid "Calculating camera angle to local surface..."
-#, fuzzy
-#~ msgid "Could not open elevation raster"
-#~ msgstr "nemohu otevøít mapu elevace"
-#, fuzzy
-#~ msgid "Could not read REF file for group <%s>"
-#~ msgstr "Nelze otevøít mapu %s"
-#, fuzzy
-#~ msgid "Bad format in initial exposure station file for group <%s>"
-#~ msgstr "©patný formát souboru poèáteèní expozice postavení kamery pro skupinu <%s>"
-#, fuzzy
-#~ msgid "Error reading segment file"
-#~ msgstr "Chyba pøi zápisu souboru se segmenty"
-#, fuzzy
-#~ msgid ""
-#~ "Control Z Point file for group [%s] in [%s] \n"
-#~ " \n"
-#~ msgstr "Soubor s kontrolními body pro skupinu <%s@%s> - "
-#, fuzzy
-#~ msgid "Computing equations..."
-#~ msgstr "Poèítám rovnice...."
-#, fuzzy
-#~ msgid "Poorly placed Control Points!\n"
-#~ msgstr "Slabì umístìné kontrolní body."
-#, fuzzy
-#~ msgid "Can not generate the transformation equation.\n"
-#~ msgstr "NElze vytvoøit transformaèní rovnici."
-#, fuzzy
-#~ msgid "No active Control Points!\n"
-#~ msgstr "®ádné aktivní pseudo kontrolní body"
-#, fuzzy
-#~ msgid ""
-#~ "Reference Point file for group [%s] in [%s] \n"
-#~ " \n"
-#, fuzzy
-#~ msgid "Poorly placed Reference Points!\n"
-#, fuzzy
-#~ msgid "No active Reference Points!\n"
-#, fuzzy
-#~ msgid "Target information for group <%s> missing.\n"
-#~ msgstr "Informace o cílové location a mapsetu pro skupinu <%s> nejsou dostupné"
-#, fuzzy
-#~ msgid "Target location <%s> not found\n"
-#~ msgstr "Cílová location <%s> nebyla nalezena"
-#, fuzzy
-#~ msgid " %d rows, %d cols (%ld cells) completed in "
-#~ msgstr "%d øádkù, %d sloupcù, (%ld bunìk) hotovo "
-#, fuzzy
-#~ msgid " %.1f cells per minute\n"
-#~ msgstr "%.1f bunìk za minutu"
-#, fuzzy
-#~ msgid "No elevation available at row = %d, col = %d"
-#~ msgstr "Selhal pøevod dat na øádku %d a sloupce %d"
-#, fuzzy
-#~ msgid "Could not read REF file for group [%s]"
-#~ msgstr "©patný formát souboru kamery ve skupinì [%s]"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Rectify all images in the group? "
-#~ msgstr "Rektifikovat v¹echna obrazová data ve skupinì"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Choose another extension? "
-#, fuzzy
-#~ msgid "Enter a name for the camera angle map:"
-#~ msgstr "Název základní rastrové mapy"
-#, fuzzy
-#~ msgid "Map name <%s> is illegal"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Overwrite maps in target location/mapset? "
-#~ msgstr "Mapset <%s> ve vstupní location <%s> - "
-#, fuzzy
-#~ msgid "Please select one of the following interpolation methods\n"
-#~ msgstr "Prosím, zadejte následující informace pro [%s]:"
-#, fuzzy
-#~ msgid "imagery, classification"
-#~ msgstr "obrazová data, klasifikace, MLC"
-#~ msgid "Reading map"
-#~ msgstr "Naèítám mapu"
-#, fuzzy
-#~ msgid "Raster elevation file name"
-#~ msgstr "Rastrová mapa %i Název souboru: %s"
-#~ msgid "Unable to read color file"
-#~ msgstr "Nelze èíst barvy."
-#, fuzzy
-#~ msgid ""
-#~ "Calculate the groundwater distance velocity vector field \n"
-#~ "and write the x, y, and z components to maps named name_[xyz].\n"
-#~ "Name is basename for the new 3D raster maps."
-#, fuzzy
-#~ msgid "Calculates numerically transient, confined groundwater flow in three dimensions."
-#~ msgstr "Numerický výpoèet pro pøechodný uzavøený tok ve tøech dimenzích"
-#, fuzzy
-#~ msgid "The direct Cholesky solver do not work with sparse matrices"
-#, fuzzy
-#~ msgid "Converts a 3D raster map layer into an ASCII text file."
-#~ msgstr "Pøevede 3D rastrovou mapovou vrstvu do ASCII textového souboru"
-#~ msgid ""
-#~ "Cannot create mask file: G3D_MASK already exists!\n"
-#~ " Use 'g.remove rast3d=G3D_MASK' to remove the existing mask."
-#~ msgstr ""
-#~ "Nelze vytvoøit soubor s maskou: G3D_MASK ji¾ existuje!\n"
-#~ " Pro odstranìní existující masky pou¾ijte 'g.remove rast3d=G3D_MASK'."
-#, fuzzy
-#~ msgid "Use the same resolution as the input 3D raster map for the 2D outputmaps, independent of the current region settings"
-#~ msgstr "Pou¾ij stejné rozli¹ení jako je vstupní G3D mapa pro 2d výstupní mapu, nezávisle na aktuálním rozli¹ení"
-#~ msgid "Raster map %d Filename: %s already exists. Will be overwritten!"
-#~ msgstr "Rastrová mapa %d Jméno souboru: %s ji¾ existuje. Mapa bude pøepsána!"
-#, fuzzy
-#~ msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map."
-#~ msgstr "Vytvoøí prùniky 2D mapy z g3d rastru objemù na základ 2D mapy elevace"
-#, fuzzy
-#~ msgid "Wrong 3D raster map datatype! Unable to create raster map."
-#~ msgstr "Chybný G3D datový typ! Nelze vytvoøit rastrové mapy."
-#, fuzzy
-#~ msgid "Unable to close input raster map"
-#~ msgstr "Nelze zavøít vstupní rastrovou mapu"
-#, fuzzy
-#~ msgid "Unable to read top raster row \n"
-#~ msgstr "Nelze momentálnì èíst rastrovou mapu."
-#, fuzzy
-#~ msgid "Unable to read bottom raster row \n"
-#, fuzzy
-#~ msgid "Wrong 3D raster map values: Values should in between 0 and 255\n"
-#~ msgstr "Chybné hodnoty 3d raster mapy! Hodnoty by mìly být v rozmezí 0 a 255!\n"
-#~ msgid "G3D map(s) to be converted to VTK-ASCII data format"
-#~ msgstr "G3D mapa(y) pro konverzi do datového formátu VTK-ASCII"
-#, fuzzy
-#~ msgid "No 3D raster data, RGB or xyz-vector maps are provided. Will only write the geometry"
-#~ msgstr "®ádná g3d data, RGB nebo xyz-vektorová mapa jsou po¾adována! Zapí¹i pouze geometrii."
-#, fuzzy
-#~ msgid "No RGB Data will be created"
-#~ msgstr "Nebudou vytvoøena ¾ádná RGB data"
-#, fuzzy
-#~ msgid "No vector data will be created"
-#~ msgstr "®ádná vektorová data nebudou vytvoøena."
-#, fuzzy
-#~ msgid "Unable to close top raster map"
-#~ msgstr "nelze zavøít svrchní rastrovou mapu"
-#, fuzzy
-#~ msgid "Unable to close bottom raster map"
-#~ msgstr "nelze zavøít spodní rastrovou mapu"
-#, fuzzy
-#~ msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
-#~ msgstr "Pøevede 3D ASCII rastrový textový soubor na (binární) 3D rastrovou mapovou vrstvu "
-#, fuzzy
-#~ msgid "Link to raster map <%s> created"
-#~ msgstr "Rastrová mapa <%s> byla vytvoøena."
-#~ msgid "Raster file to be linked"
-#~ msgstr "Název rastrového souboru, který má být spojen"
-#~ msgid "input= and source= are mutually exclusive"
-#~ msgstr "input= a source= se vzájemnì vyluèují"
-#~ msgid "Unable to set window"
-#~ msgstr "Nelze nastavit okno"
-#~ msgid "%s: base raster map not found"
-#~ msgstr "%s: základní mapa nebyla nalezena"
-#, fuzzy
-#~ msgid "Watershed basin analysis program"
-#~ msgstr "Program na analýzu povodí"
-#, fuzzy
-#~ msgid "Name of input raster map with real depressions"
-#~ msgstr "Název vstupní rastrové mapy"
-#, fuzzy
-#~ msgid "Name of input raster map blocking overland surface flow"
-#, fuzzy
-#~ msgid "Name for output raster map useful for visual display of results (DEPRECATED)"
-#~ msgstr "Výstupní mapa: u¾iteèná pro vizuální zobrazení výsledkù"
-#, fuzzy
-#~ msgid "Exports the color table associated with a raster map layer."
-#, fuzzy
-#~ msgid "Direction raster found <%s>"
-#~ msgstr "Zapisuji rastrovou mapu <%s>"
-#, fuzzy
-#~ msgid "Name for output direction map for depressionless elevation raster map"
-#~ msgid "Reading file"
-#~ msgstr "Ètu soubor"
-#, fuzzy
-#~ msgid "raster, export, animation"
-#, fuzzy
-#~ msgid "(requires r.out.ppm with stdout option)"
-#~ msgstr ""
-#~ msgid "Unable to read range of raster map <%s>"
-#~ msgstr "Nelze naèíst rozsah hodnot rastrové mapy <%s>"
-#~ msgid "Unable to read %s"
-#~ msgstr "Nelze èíst %s"
-#~ msgid "The height of the river bed in [m]"
-#~ msgstr "Vý¹ka øeèi¹tì v [m]"
-#, fuzzy
-#~ msgid "Calculation of unconfined groundwater flow: loop %i\n"
-#~ msgstr "Výpoèet cyklu nesoustøedìného vodního toku %i\n"
-#, fuzzy
-#~ msgid "Name for output elevation raster map after filling"
-#~ msgstr "Výstupní rastrová mapa digitálního modelu terénu po vyplnìní sní¾enin"
-#, fuzzy
-#~ msgid "Name for output direction raster map"
-#~ msgstr "Název výstupní rastrové mapy orientace"
-#~ msgid "No raster map specified"
-#~ msgstr "Není specifikována rastrová mapa"
-#~ msgid "Unable to remove color table of raster map <%s>"
-#~ msgstr "Nelze odstranit barevnou tabulku rastrové mapy <%s>"
-#~ msgid "Color table of raster map <%s> not found"
-#~ msgstr "Barevná tabulka rastrové mapy <%s> nebyl nalezena"
-#~ msgid "Color table 'random' is not supported for floating point raster map"
-#~ msgstr "Barevná tabulka 'random' není podporována pro rastrové mapy s desetinnou èárkou"
-#~ msgid "Color table 'grey.eq' is not supported for floating point raster map"
-#~ msgstr "Barevná tabulka 'grey.eq' není podporována pro rastrové mapy s desetinnou èárkou"
-#~ msgid "Color table 'grey.log' is not supported for floating point raster map"
-#~ msgstr "Barevná tabulka 'grey.log' není podporována pro rastrové mapy s desetinnou èárkou"
-#~ msgid "Color table for raster map <%s> set to '%s'"
-#~ msgstr "Tabulka barev pro rastrovou mapu <%s> nastavena na %s"
-#~ msgid "Use G3D mask (if exists) with output map"
-#~ msgstr "Pou¾ít masku G3D (pokud existuje) s výstupní mapovou vrstvou"
-#~ msgid "Cell file not found"
-#~ msgstr "Rastrový (cell) soubor nebyl nalezen"
-#~ msgid "latin raster map <%s> not found"
-#~ msgstr "rastrový soubor se zem. ¹íøkou <%s> nebyl nalezen"
-#~ msgid "raster, interpolation"
-#, fuzzy
-#~ msgid "Export GRASS raster as non-georeferenced PNG image."
-#~ msgstr "Exportuje GRASS rastrové mapy do jednoho z formátù podporovaných knihovnou GDAL."
-#~ msgid "Name for output raster map (default: input)"
-#~ msgstr "Jméno výstupní rastrové mapy (výchozí: jméno vstupní mapy)"
-#, fuzzy
-#~ msgid "Unable to load 3D raster range"
-#, fuzzy
-#~ msgid "Reading input data..."
-#~ msgstr "Naèítám vstupy..."
-#, fuzzy
-#~ msgid "Writing output data..."
-#~ msgstr "Zapisuji výstupní vrstvu..."
-#, fuzzy
-#~ msgid "Name of raster map for which to edit null file"
-#~ msgstr "Rastrová její¾ soubor NULL bude editován"
-#~ msgid "Unable to update boundaries"
-#~ msgstr "Nelze aktualizovat hranice"
-#~ msgid "Write raster values as z coordinate. Table is not created. Currently supported only for points."
-#~ msgstr "Zapí¹e rastrové hodnoty jako souøadnice z. Není vytvoøena tabulka. V souèasné dobì jsou podporovány pouze body."
-#~ msgid "Name of base raster map"
-#~ msgid "Output basic information about a raster map layer."
-#~ msgstr "Vypí¹e základní informace o u¾ivatelem vybrané rastrové mapì."
-#, fuzzy
-#~ msgid "raster, reclassification"
-#~ msgstr "rastr, elevace"
-#~ msgid "The size of sliding window (odd and >= 3)"
-#~ msgstr "Velikost okna filtru (liché èíslo >= 3)"
-#~ msgid "Nothing to compute. Use at least one of the flags."
-#~ msgstr "Není co poèítat. Pou¾ijte prosím nìkterý z pøepínaèù."
-#~ msgid "Calculated measure #%d <%s> (56 measures available)"
-#~ msgstr "Spoèítaná míra #%d <%s> (56 mìr je dostupno)"
-#, fuzzy
-#~ msgid "Name of input raster map with seed (at least 1 cell > 0)"
-#~ msgstr "Rastrová mapa s poèátkem (alespoò jedna buòka > 0)"
-#~ msgid "Input map"
-#~ msgstr "Vstupní mapa"
-#~ msgid "Use G3D mask (if exists) with input map"
-#~ msgstr "Pou¾ít masku G3D (pokud existuje) s vstupní mapou"
-#~ msgid "Error writing G3D double data"
-#~ msgstr "Chyba pøi zápisu G3D dat s plovoucí desetinnou èárkou"
-#, fuzzy
-#~ msgid "Constructs flow lines."
-#, fuzzy
-#~ msgid "Name for flowpath length raster map"
-#~ msgid "Unable to get header for %s"
-#~ msgstr "Nejsem schopen zapsat hlavièku pro %s"
-#, fuzzy
-#~ msgid "imagery, landsat, acca"
-#, fuzzy
-#~ msgid "Cannot write to raster map <%s>"
-#~ msgstr "Nelze zapsat rastrové mapy"
-#, fuzzy
-#~ msgid "Creates, edits, and lists groups and subgroups of imagery data."
-#~ msgstr "Vytváøí, edituje a vypisuje skupiny a podskupiny obrazových dat."
-#, fuzzy
-#~ msgid "Computes topographic correction of reflectance."
-#~ msgstr "Interpolaèní metoda"
-#, fuzzy
-#~ msgid "Name of reflectance raster maps to be corrected topographically"
-#~ msgstr "Název rastrové mapy s povrchem pro køí¾ový výbìr"
-#, fuzzy
-#~ msgid "Name (flag -i) or prefix for output raster maps"
-#~ msgstr "Pøedpona výstupních rastrových map"
-#, fuzzy
-#~ msgid "Name of input base raster map (elevation or illumination)"
-#~ msgstr "Název vstupní rastrové mapy(saturation - sytost)"
-#, fuzzy
-#~ msgid "Output sun illumination terrain model"
-#~ msgstr "Výstup je chyba interpolace"
-#, fuzzy
-#~ msgid "Elevation raster map of unknown type"
-#~ msgstr "Souøadnice bodu pro zastavení (V,S)"
-#, fuzzy
-#~ msgid "Reflectance of raster map <%s> is not of DCELL type - ignored"
-#, fuzzy
-#~ msgid "Extract quality control parameters from Modis QC layers"
-#~ msgstr "Spoèítá parametry reliéfu z digitálního modelu terénu"
-#, fuzzy
-#~ msgid "Name of the surface reflectance QC layer [bit array]"
-#~ msgstr "Název tabulku referenèního systému"
-#~ msgid "Subsignature %d only contains %f pixels"
-#~ msgstr "subsignatura %d obsahuje pouze %f pixelù"
-#, fuzzy
-#~ msgid "The output cell map <%s.%d> has values outside the 0-255 range. Min: %d Max: %d"
-#~ msgstr "Výstupní rastrová (cell) mapa <%s.%d> obsahuje hodnoty mimo interval 0-255."
-#~ msgid "Calculating covariance matrix..."
-#~ msgstr "Poèítám matici kovariance..."
-#, fuzzy
-#~ msgid "Computing means and standard deviations..."
-#~ msgstr "Poèítám prùmìr pro vrstvu %d...."
-#, fuzzy
-#~ msgid "Computing means..."
-#~ msgid "Rescaling <%s> to range %d,%d..."
-#~ msgstr "Pøevzorkovávám <%s> do rozmezí %d,%d..."
-#~ msgid "Bad format in camera file for group <%s>"
-#~ msgstr "©patný formát souboru kamery pro skupinu <%s>"
-#~ msgid "Please select a target for group"
-#~ msgstr "Prosím vyberte cíl pro skupiny"
-#, fuzzy
-#~ msgid "Type of color table (for use with -z flag)"
-#~ msgstr "Typ tabulky barev"
-#, fuzzy
-#~ msgid "Scale factor for wcolumn"
-#~ msgstr "Mìøítkový faktor pro vý¹kový model"
-#, fuzzy
-#~ msgid "Error in color definition column (%s), area %d with cat %d"
-#~ msgstr "Chyba ve sloupci s definicí barvy (%s),  kategorie %d"
-#, fuzzy
-#~ msgid "Symbol size column not specified."
-#~ msgstr "Nelze pou¾ít zadaný sloupec"
-#, fuzzy
-#~ msgid "Symbol size column (%s) is not numeric."
-#~ msgstr "Sloupec s ID linie musí být typu integer"
-#, fuzzy
-#~ msgid "Symbol rotation column not specified."
-#~ msgstr "Název vstupního zdroje nebyl specifikován"
-#, fuzzy
-#~ msgid "Symbol rotation column (%s) is not numeric."
-#~ msgstr "Jméno sloupce s rotací musí být èíselného typu"
-#, fuzzy
-#~ msgid "Unable to read symbol, unable to display points"
-#~ msgstr "Nelze èíst symbol, nemohu zobrazit body"
-#, fuzzy
-#~ msgid "display, raster"
-#, fuzzy
-#~ msgid "Interactively edit cell values in a raster map."
-#~ msgstr "Zaèni s hodnotami v rastrové mapì"
-#, fuzzy
-#~ msgid "Display information about the active display monitor"
-#~ msgstr "Nahla¹ informace o vstupním rastru a ukonèi se"
-#, fuzzy
-#~ msgid "No font selected"
-#~ msgstr "Nebyl vybán ¾ádný záznam"
-#, fuzzy
-#~ msgid "Unable to set size"
-#~ msgstr "Nelze nastavit velikost písma"
-#, fuzzy
-#~ msgid "Name of graphics monitor to start"
-#, fuzzy
-#~ msgid "Name of graphics monitor to select"
-#~ msgstr "®ádné grafické zaøízení nebylo vybráno"
-#, fuzzy
-#~ msgid "List all monitors"
-#~ msgstr "Seznam vrstevnic (isolinií)"
-#, fuzzy
-#~ msgid "wxpython;wxPython based next generation GUI;tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);text;command line interface only"
-#~ msgstr "tcltk;Tcl/Tk grafické prostøedí - GIS Manager (gis.m);oldtcltk;Strar¹í Tcl/Tk grafické prostøedí - Display Manager (d.m);wxpython; Grafické prostøedí budoucí generace zalo¾ené na WxPyton"
-#, fuzzy
-#~ msgid "Print projection information (in conventional GRASS format)"
-#~ msgstr "Nelze pøevést informace o vstupní mapové projekci do formátu GRASSu (pro kontrolu)"
-#, fuzzy
-#~ msgid "Georeferenced data file to read projection information from"
-#~ msgstr "Název location, ze které bude naètena mapová projekce pro GCP transformaci"
-#, fuzzy
-#~ msgid "ASCII file containing a WKT projection description (- for stdin)"
-#~ msgstr "ASCII soubor obsahující vstupní data (\"-\" pro standardní vstup)"
-#, fuzzy
-#~ msgid "Unable to open file [%s] for reading"
-#~ msgstr "Nelze otevøít soubor <%s> pro psaní"
-#, fuzzy
-#~ msgid "Unable to create location: %s"
-#~ msgstr "Neschopen vytvoøit tabulku: %s"
-#, fuzzy
-#~ msgid "Remove base maps"
-#~ msgstr "Mazání pøívìskù"
-#, fuzzy
-#~ msgid "Changes current mapset."
-#~ msgstr "Název cílového mapsetu"
-#, fuzzy
-#~ msgid "List available mapsets"
-#~ msgstr "Vypi¹ pøítomné vrstvy a ukonèi se"
-#, fuzzy
-#~ msgid "The mapset does not exist. Use -c flag to create it."
-#~ msgstr "Mapa <%s> neexistuje v souèasném mapsetu. Pøidejte pøepínaè -n pro vytvoøení nové mapy."
-#, fuzzy
-#~ msgid "Other"
-#~ msgstr "Kolísání (dither)"
-#, fuzzy
-#~ msgid "Names of mask files"
-#~ msgstr "Jméno souboru s barvou"
-#, fuzzy
-#~ msgid "Name of output mask file"
-#~ msgstr "Název výstupního souboru"
-#~ msgid "Creates a Voronoi diagram from an input vector map containing points or centroids."
-#~ msgstr "Vytvoøit Voronoi diagram ze vstupní vektorové vrstvy obsahující body nebo centroidy."
-#, fuzzy
-#~ msgid "Voronoi triangulation..."
-#~ msgstr "Delaunay triangulace...."
-#~ msgid "Unknown column type '%s'"
-#~ msgstr "Neznámý typ sloupce '%s'"
-#~ msgid "Unknown column type '%s' values lost"
-#~ msgstr "Neznámý typ sloupce '%s' hodnoty ztraceny"
-#~ msgid "List available layers in data source and exit"
-#~ msgstr "Vypi¹ dostupné vrstvy z datového zdroje a ukonèi se"
-#~ msgid "Data source contains %d layers:"
-#~ msgstr "Zdroj dat obsahuje %d vrstev:"
-#, fuzzy
-#~ msgid "Counting polygons for %d features..."
-#~ msgstr "Importuji prvky mapy %d..."
-#~ msgid "Importing map %d features..."
-#~ msgid "Snap boundaries (threshold = %.3e):"
-#~ msgstr "rozdìlit hranice (mezní hodnota =%.3e)"
-#, fuzzy
-#~ msgid "Merge boundaries:"
-#~ msgstr "Zlomit hranice:"
-#~ msgid "Change boundary dangles to lines:"
-#~ msgstr "Mìním hranice pøívìskù  na linie:"
-#~ msgid "Change boundary bridges to lines:"
-#~ msgstr "Mìním hranice mostù na linie:        "
-#, fuzzy
-#~ msgid "Find centroids for layer: %s"
-#~ msgid "Input data contains 3D features. Created vector is 2D only, use -z flag to import 3D vector"
-#~ msgstr "Vstupní data obsahují 3D prvky. Vytvoøená vektorová mapa je pouze 2D, pro import 3D vektorové mapy pou¾ijte pøepínaè -z."
-#, fuzzy
-#~ msgid "Cannot read part of geometry"
-#~ msgstr "Nelze zapsat èást geometrie "
-#~ msgid "Degenerate polygon ([%d] vertices)"
-#~ msgstr "Rozklad polygonu ([%d] lomových bodù)"
-#~ msgid "Cannot write part of geometry"
-#~ msgid "Path to resulting ASCII file or ASCII vector name if '-o' is defined"
-#~ msgstr "Cesta k výslednému souboru ASCII nebo jmenéno ASCII vektoru, pokud je zadána volba '-o'."
-#, fuzzy
-#~ msgid "Offset in map units."
-#~ msgid "End of ascii file reached before end of categories"
-#~ msgstr "Konec souboru dosa¾en pøe koncem kategorií."
-#, fuzzy
-#~ msgid "Cannot open driver"
-#~ msgstr "Nelze otevøít %s"
-#, fuzzy
-#~ msgid "Cannot open database"
-#~ msgstr "Nelze otevøít datový zdroj"
-#, fuzzy
-#~ msgid "Cannot describe table"
-#~ msgstr "Nelze kopírovat tabulku"
-#, fuzzy
-#~ msgid "Cannot find column type"
-#~ msgstr "Neznámý typ sloupce"
-#, fuzzy
-#~ msgid "Cannot update table"
-#~ msgstr "Nelze vytvoøit tabulku: %s"
-#, fuzzy
-#~ msgid "Form"
-#~ msgstr "Formát"
-#, fuzzy
-#~ msgid "New record was created.<BR>"
-#~ msgstr "Nová prázdná mapa byla vytvoøena."
-#, fuzzy
-#~ msgid "Record for this category already existed.<BR>"
-#~ msgstr "Pro kategorii %d není ¾ádný záznam v tabulce <%s>"
-#, fuzzy
-#~ msgid "New point"
-#~ msgstr "Bod"
-#, fuzzy
-#~ msgid "Quit tool"
-#~ msgstr "Dotazovací nístroj"
-#, fuzzy
-#~ msgid "Undo last point"
-#~ msgstr "®ádné poèáteèní body"
-#, fuzzy
-#~ msgid "Close line"
-#~ msgstr "Zavøení selhalo"
-#, fuzzy
-#~ msgid "New Point"
-#~ msgstr "Body"
-#, fuzzy
-#~ msgid "Undo Last Point"
-#, fuzzy
-#~ msgid "Delete line and exit"
-#~ msgstr "vypi¹ tabulky a ukonèi se."
-#, fuzzy
-#~ msgid "Select"
-#~ msgstr "Výbìr"
-#, fuzzy
-#~ msgid "New location"
-#~ msgstr "Alokace metriky"
-#, fuzzy
-#~ msgid "Remove vertex:"
-#~ msgstr "Mazání mostù:"
-#, fuzzy
-#~ msgid "Select vertex"
-#~ msgstr "Vyber data z tabulky."
-#, fuzzy
-#~ msgid "Cannot open driver %s"
-#, fuzzy
-#~ msgid "Cannot open database %s"
-#, fuzzy
-#~ msgid "Cannot open driver "
-#, fuzzy
-#~ msgid "Cannot open database %s by driver %s"
-#~ msgstr "Nelze otevøít databázi <%s> ovladaèem <%s>"
-#, fuzzy
-#~ msgid "Cannot create table: "
-#, fuzzy
-#~ msgid "Cannot create index:\n"
-#, fuzzy
-#~ msgid "Cannot grant privileges on table:\n"
-#~ msgstr "Nelze poskytnou práva na tabulku %s"
-#, fuzzy
-#~ msgid "Cannot create new record."
-#~ msgstr "Nelze vytvoøit novou tabulku"
-#, fuzzy
-#~ msgid "Database table for this layer is not defined"
-#~ msgstr "Spojení s databází nebylo definováno"
-#, fuzzy
-#~ msgid "Cannot select record from table %s"
-#, fuzzy
-#~ msgid "Display categories:"
-#~ msgstr "%ld kategorií"
-#, fuzzy
-#~ msgid "Select line"
-#~ msgstr "Výbìr"
-#, fuzzy
-#~ msgid "Copy attributes:"
-#~ msgstr "Kopírovat atributy"
-#, fuzzy
-#~ msgid "Select source object"
-#, fuzzy
-#~ msgid "Select the target object"
-#~ msgstr "Barva textu"
-#, fuzzy
-#~ msgid "Conform and select next"
-#, fuzzy
-#~ msgid "Deselect Target"
-#, fuzzy
-#~ msgid "Display attributes:"
-#, fuzzy
-#~ msgid "layer: %d<BR>category: %d<BR>"
-#~ msgstr ""
-#~ "Vrstva: %d\n"
-#~ "Kategorie: %d\n"
-#, fuzzy
-#~ msgid "Database connection not defined<BR>"
-#, fuzzy
-#~ msgid "driver: %s<BR>database: %s<BR>table: %s<BR>key column: %s<BR>"
-#~ msgstr ""
-#~ "\n"
-#~ "Ovladaè: %s\n"
-#~ "Databáze: %s\n"
-#~ "Tabulka: %s\n"
-#~ "Sloupec s klíèem: %s\n"
-#, fuzzy
-#~ msgid "Line %d"
-#~ msgstr "©íøka linie textu"
-#, fuzzy
-#~ msgid "No categories"
-#, fuzzy
-#~ msgid "Cannot delete record: %s"
-#~ msgstr "Nelze vlo¾it nový záznam: %s"
-#, fuzzy
-#~ msgid "Cannot open driver '%s'<BR>"
-#~ msgstr "Nelze otevøít soubor s filtrem '%s'"
-#, fuzzy
-#~ msgid "Cannot open database '%s' by driver '%s'<BR>"
-#, fuzzy
-#~ msgid "Cannot open select cursor"
-#~ msgstr "Nelze otevøít kurzor pro výbìr: '%s'"
-#, fuzzy
-#~ msgid "Cannot fetch next record"
-#~ msgstr "Nelze pøidat øádek"
-#, fuzzy
-#~ msgid "No database record"
-#~ msgstr "Vypi¹ v¹echny databázové ovladaèe."
-#, fuzzy
-#~ msgid "Select tool"
-#~ msgstr "Výbìr"
-#, fuzzy
-#~ msgid "Cannot set variable code = %d"
-#~ msgstr "Nelze vybrat atributy pro cat= %d"
-#, fuzzy
-#~ msgid "Cannot get type of variable %s"
-#~ msgstr "Nelze získat seznam tabulek:\n"
-#, fuzzy
-#~ msgid "Cannot get code of variable %s"
-#, fuzzy
-#~ msgid "Cannot get name of variable %d"
-#, fuzzy
-#~ msgid "Cannot get value of variable code = %d"
-#, fuzzy
-#~ msgid "Quit"
-#~ msgstr "Potichu"
-#, fuzzy
-#~ msgid "New center"
-#~ msgstr "Schéma databáze."
-#, fuzzy
-#~ msgid "Cannot find window '%s'"
-#~ msgstr "Nelze vlo¾it nový øádek: %s"
-#~ msgid "Allocate subnets for nearest centres (direction from centre)."
-#~ msgstr "Urèit podsí»ì pro nejbli¾¹í stedy (smìr ze støedu)."
-#~ msgid "Centre node must be opened (costs >= 0). Costs of centre node are used in calculation"
-#~ msgstr "Støední uzel musí být otevøen (cena >= 0). cena støedního uzlu je pou¾ita ve výpoètu"
-#~ msgid "Categories of centres (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
-#~ msgstr "Kategorie støedù (body nebo uzly) pøidìlených sítí, vrstva pro tyto kategorie je urèena pomocí  volby nvrstva"
-#~ msgid "Number of centres: [%d] (nlayer: [%d])"
-#~ msgstr "POèet støedù: [%d] (nvrstva:[%d])"
-#~ msgid "Calculating costs from centres ..."
-#~ msgstr "Poèítám cenu ze støedù ..."
-#~ msgid "Selects vector objects from an existing vector map and creates a new map containing only the selected objects."
-#~ msgstr "Vybrat objekty z existující vektorové mapy a vytvoøit novou mapu obsahující jenom vybrané objekty."
-#~ msgid "Do not copy table (see also 'new' parameter)"
-#~ msgstr "Nekopíruj tabulku (viz té¾ parametr 'new')"
-#~ msgid "If new >= 0, table is not copied"
-#~ msgstr "Jestli nová >=0, tabulka nebude zkopírována"
-#~ msgid "List, file, where and random options are exclusive. Please specify only one of them"
-#~ msgstr "Seznam, soubor, a náhodnì jsou jedineèné volby. Prosím urèete pouze jednu z nich"
-#~ msgid "Process file <%s> for category numbers"
-#~ msgstr "pracuji na souboru <%s> pro èísla kategorií"
-#~ msgid "%d categories loaded from table <%s>"
-#~ msgstr "%d kategorií bylo naèteno z tabulky <%s>"
-#~ msgid "Random category count is larger or equal to uniq \"%s\" feature category count %d"
-#~ msgstr "Souèet náhodných kategoií musí být stejný nebo vìt¹í  ne¾ unikátní \"%s\" souèet kategorí prvkù %d"
-#~ msgid "Key column name"
-#~ msgstr "Jméno sloupce s klíèem"
-#, fuzzy
-#~ msgid "DEPRECATED Buffer distance in map units"
-#, fuzzy
-#~ msgid "Line buffers... "
-#, fuzzy
-#~ msgid "Zero area size, please clean input vector first."
-#~ msgstr "Vytvoøit rovnobì¾ky ke vstupním liniím."
-#, fuzzy
-#~ msgid "Could not get outside buffer for line id %d"
-#~ msgstr "Nelze naèíst velikost ji¾ní okolní zóny. Pøeru¹uji."
-#, fuzzy
-#~ msgid "Area buffers... "
-#~ msgstr "Bufery ploch..."
-#, fuzzy
-#~ msgid "Selecting areas..."
-#~ msgstr "Vybírám prvky...."
-#~ msgid "vector, transformation"
-#~ msgid "<%s> has not been created in database."
-#~ msgstr "<%s> nebyla v databázi vytvoøena."
-#, fuzzy
-#~ msgid "Name of column name with route ids"
-#, fuzzy
-#~ msgid "Name of column name with stop timestamps"
-#~ msgstr "Název sloupce obsahujícího hodnoty parametru vyhlazení"
-#, fuzzy
-#~ msgid "Name of column name with stop ids"
-#, fuzzy
-#~ msgid "Name of column name with walk lengths"
-#~ msgstr "Poèet sloupcù se li¹í."
-#, fuzzy
-#~ msgid "Unknown operator"
-#~ msgstr "Neznámá operace"
-#~ msgid "Copying vector lines..."
-#~ msgstr "Kopíruji vektorové linie ..."
-#~ msgid "Print topology information only"
-#~ msgstr "Vytiskni pouze informace o topologii"
-#~ msgid "Name of input DXF file"
-#~ msgstr "Jméno vstupního DXF souboru"
-#~ msgid "Name of input vector points map for which to edit attribute table"
-#~ msgstr "Jméno vstupní vektorové bodové mapy"
-#~ msgid "If not given reads from standard input"
-#~ msgstr "Pokud není zadán, ète se standardní vstup"
-#, fuzzy
-#~ msgid "Cannot allocate %u bytes of memory"
-#~ msgstr "Nelze pøiøadit %d bytù pamìti"
-#~ msgid "No attribute table found"
-#~ msgstr "Nebyla nalezena ¾ádná atributová tabulka"
-#~ msgid "Cannot parse MySQL embedded database name"
-#~ msgstr "Nelze parsovat MySQL pøipojené jméno databáze"
-#~ msgid "Cannot connect to MySQL embedded server: "
-#~ msgstr "Nelzese pøipojit na  MySQL server"
-#~ msgid "Cannot scan timestamp: "
-#~ msgstr "Nelze zjistit èasovou znaèku: "
-#~ msgid "Cannot scan datetime: "
-#~ msgstr "Nelze získat datumaèas: "
-#~ msgid "Cannot get list of tables:\n"
-#~ msgid "Unknown option in database definition for "
-#~ msgstr "Neznámá volba v definici databáze pro "
-#~ msgid "Cannot recognize boolean value"
-#~ msgstr "Nelze rozpoznat booleanovskou hodnotu"
-#~ msgid "pg driver: PostGIS column '%s', type 'geometry'  will not be converted"
-#~ msgstr "ovladaè pg: Sloupec PostGIS '%s', typu 'geometry' nebude pøeveden"
-#~ msgid "Removes a table from database."
-#~ msgstr "Odstraní tabulku z databáze."
-#~ msgid "Database schema"
-#, fuzzy
-#~ msgid "database, connection settings"
-#, fuzzy
-#~ msgid "vector, raster, statistics"
-#, fuzzy
-#~ msgid "Name of the column"
-#~ msgstr "Poèet sloupcù"
-#, fuzzy
-#~ msgid "Name of optional EPS output file"
-#~ msgstr "Název výstupního souboru SVG"
-#, fuzzy
-#~ msgid "Skip the join column in other table"
-#~ msgstr "Poèet iterací"
-#, fuzzy
-#~ msgid "Copy all the columns from other table to map"
-#, fuzzy
-#~ msgid "Join column in map table"
-#~ msgstr "Sloupec <%s> nebyl nalezen v tabulce <%s>"
-#, fuzzy
-#~ msgid "Column on which to calculate statistics (must be numeric)"
-#~ msgstr "Jméno sloupce (musí být èíselného typu)"
-#, fuzzy
-#~ msgid "Import E00 file into a vector map."
-#~ msgstr "Importuje star¹í verze GRASS vektorových map."
-#, fuzzy
-#~ msgid "Raster input maps"
-#~ msgstr "Nelze zavøít vstupní mapu"
-#, fuzzy
-#~ msgid "Imports geonames.org country files into a GRASS vector points map."
-#, fuzzy
-#~ msgid "Table to drop"
-#~ msgstr "Nelze vyjmout tabulku: %s"
-#, fuzzy
-#~ msgid "Name of aspect raster map"
-#, fuzzy
-#~ msgid "GRASS table name"
-#~ msgstr "Jméno vstupní tabulky"
-#, fuzzy
-#~ msgid "Manually set range (min,max)"
-#~ msgstr "Rozsah celoèíselných hodnot: min,max"
-#, fuzzy
-#~ msgid "Name of input raster map in which to fill nulls"
-#, fuzzy
-#~ msgid "Name for output raster map with nulls filled by interpolation"
-#, fuzzy
-#~ msgid "Layer where to add new attribute table"
-#~ msgstr "vektor, rastr, tabulka atributù"
-#, fuzzy
-#~ msgid "Name of raster map to generate legend from"
-#~ msgstr "Název rastrové mapy, která má být pou¾ita pro <%s>"
-#, fuzzy
-#~ msgid "Name of the column to drop"
-#, fuzzy
-#~ msgid "GpsBabel supported output format"
-#~ msgstr "Seznam podporovaných výstupních formátù"
-#, fuzzy
-#~ msgid "use transformation rules for LANDSAT-4"
-#~ msgstr "Zpìtná transformave, 3Dvektorové prvky na 2D"
-#, fuzzy
-#~ msgid "use transformation rules for LANDSAT-5"
-#, fuzzy
-#~ msgid "use transformation rules for LANDSAT-7"
-#, fuzzy
-#~ msgid "general, extensions"
-#, fuzzy
-#~ msgid "List available modules in the GRASS Addons SVN repository"
-#~ msgstr "Vypi¹ dostupná pravidla barev a ukonèi se"
-#, fuzzy
-#~ msgid "Name of column used to dissolve common boundaries"
-#~ msgstr "Název sloupce atributu, který má být pou¾it jaok ¹títky pro kategorie rastrové mapy"
-#, fuzzy
-#~ msgid "Name of shaded relief or aspect map"
-#~ msgstr "Název druhé rastrové mapy"
-#, fuzzy
-#~ msgid "Name of raster to drape over relief map"
-#, fuzzy
-#~ msgid "writing edges..."
-#, fuzzy
-#~ msgid "raster, png"
-#~ msgstr "rastr, dla¾dice"
-#~ msgid "Import Mapgen or Matlab vector maps into GRASS."
-#~ msgstr "Importuje vektory ve formátu Mapgen nebo Matlab do GRASSu"
-#~ msgid "Ascii file containing spectral signatures"
-#~ msgstr "ASCII soubor obsahující spektrální pøíznaky"
-#, fuzzy
-#~ msgid "Unhandled vector feature type <%s>"
-#~ msgstr "Nelze vytvoøit tabulku <%s>"
-#, fuzzy
-#~ msgid "No areas found, skipping type=area"
-#~ msgstr "Nic nebylo nalezeno, pøeskakuji type=poly"
-#, fuzzy
-#~ msgid "No points found, skipping%s%s"
-#~ msgstr "®ádné body nebyly nalezeny, pøeskakuji type=point"
-#, fuzzy
-#~ msgid "No lines found, skipping%s%s"
-#~ msgstr "Nic nebylo nalezeno, pøeskakuji typ=line"
-#, fuzzy
-#~ msgid "GDAL datatype: %s, range: %f - %f"
-#, fuzzy
-#~ msgid "The hight of the river bed in [m]"
-#, fuzzy
-#~ msgid "The hight of the drainage bed in [m]"
-#, fuzzy
-#~ msgid "The '-q' flag is superseded and will be removed "
-#~ msgstr "Pøepínaè '-q' je zastaralý a bude v budoucnosti odstranìn. prosím, peou¾ijte pøepínaè '--quiet'."
-#, fuzzy
-#~ msgid "Unable to create table <%s_edge_Interpolation>"
-#~ msgstr "Nelze otevøít databázi <%s>"
-#, fuzzy
-#~ msgid "Rescale output raster map [0,255]"
-#~ msgstr "Název výstupní rastrové mapy"
-#, fuzzy
-#~ msgid "Input raster map contains cells with NULL-value (no-data). The value %g was used to represent no-data values in the input map. You can specify a nodata value with the %s option."
-#~ msgstr "Vstupní rastrová mapa obsahuje NULLové hodnoty (¾ádná data).  Pro NULLové hodnoty byla pou¾ita hodnota %g. Mù¾ete urèit hodnotu reprezentující NULLové hodnoty parametrem %s."
-#~ msgid "%d faces found, but not requested to be exported. Verify 'type' parameter."
-#~ msgid "A: azimuth of the sun from the north, degrees"
-#~ msgstr "A: azimut Slunce od serveru, stupnì"
-#, fuzzy
-#~ msgid "Cannot open driver\n"
-#, fuzzy
-#~ msgid "Cannot open database\n"
-#~ msgid "Could not close G3D map"
-#~ msgstr "Nemohl jsem uzavøít G3D mapu"
-#~ msgid "Use g3d mask (if exists) with input map"
-#~ msgstr "Pou¾ít masku G3D (pokud existuje) se vstupní mapou"
-#~ msgid "Could not close G3D map <%s>"
-#~ msgstr "Nemohl jsem uzavøít mapu G3D <%s>"
-#~ msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
-#~ msgstr "Pøevede 3D rastrové mapy (G3D) do formátu VTK-Ascii"
-#~ msgid "Use g3d mask (if exists) with input maps"
-#~ msgstr "Pou¾ít masku G3D (pokud existuje) se vstupními mapami"
-#~ msgid "Use G3D mask (if exists)"
-#~ msgstr "Pou¾ít masku G3D (pokud existuje)"
-#~ msgid "Name of an existing raster map layer"
-#~ msgstr "Název existujícího rastru"
-#~ msgid "Reading raster map <%s in %s> ..."
-#~ msgstr "Naèítám rastrový soubor <%s v %s> ..."
-#~ msgid "Error writing row %d"
-#~ msgstr "Chyba pøi zápisu øádky %d."
-#~ msgid "Name of input vector points map"
-#~ msgstr "Název vstupní bodové vektorové vrstvy"
-#~ msgid "Calculation of unconfined groundwater flow loop %i\n"
-#~ msgid "Name of elevation raster map"
-#~ msgstr "Název rastrového souboru s digitálním modelem terénu"
-#~ msgid "Name of real-sky beam radiation coefficient input raster map [-]"
-#~ msgstr "Vstupní rastrová mapa s koeficientem pøímého sluneèního záøení [-]"
-#~ msgid "Name of real-sky diffuse radiation coefficient input raster map [-]"
-#~ msgstr "Název rastrové mapy s koeficientem real-sky difùzního záøení [-]"
-#~ msgid "Name for distance output map"
-#~ msgstr "Jméno výstupní vrstvy se vzdáleností"
-#~ msgid "Reports statistics for raster map layers."
-#~ msgid "Name of an output file to hold the report"
-#~ msgstr "Název výstupního souboru, pro ulo¾ení zprávy"
-#~ msgid "Creates, edits, and lists groups and subgroups of imagery files."
-#, fuzzy
-#~ msgid ""
-#~ "ERROR: Required parameter <%s> not set:\n"
-#~ "\t(%s)\n"
-#~ msgstr ""
-#~ "\n"
-#~ "CHYBA: Po¾adovaný parametr <%s> nebyl nastaven:\n"
-#~ "    (%s).\n"
-#, fuzzy
-#~ msgid "Cannot describe table\n"
-#~ msgid "Name of table created for output when the distance to all flag is used"
-#~ msgstr "Název tabulky vytvoøené pro výstup, pokud je udán pøepínaè -a (vzdálenost ke v¹em prvkùm)"
-#~ msgid "unable to open MASK"
-#~ msgstr "nemohu otevøít MASKu"
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po	2012-05-26 15:22:06 UTC (rev 51802)
+++ grass/trunk/locale/po/grassmods_de.po	2012-05-26 15:46:05 UTC (rev 51803)
@@ -33685,7191 +33685,3 @@
 #: ../locale/scriptstrings/d.shadedmap_to_translate.c:5
 msgid "Percent to brighten"
 msgstr "Prozentuale Aufhellung."
-#, fuzzy
-msgid "Input raster map with specific yield in [1/m]"
-msgstr "Keine Eingabekarte(n) angegeben."
-#, fuzzy
-msgid "Raster map <%s> is not valid"
-msgstr "Rasterkarte <%s> konnte nicht gefunden werden."
-msgid "Interpolates point data to a RASTER3D grid volume using regularized spline with tension (RST) algorithm."
-msgstr "Interpoliert Punkte zu einem RASTER3D Grid Volumen unter Verwendung des regularized spline with tension (RST) Algorithmus."
-#, fuzzy
-msgid "If not given read from standard input"
-msgstr "Wenn nicht gegeben, lese von der Standardeingabe."
-#, fuzzy
-msgid "Print basic info in shell script style"
-msgstr "Gebe im Shell-Skript-Style aus"
-#, fuzzy
-msgid "Projection:"
-msgstr "Projeziere... "
-#, fuzzy
-msgid "DBMI-OGR driver error:\n"
-msgstr "DBMI-MySQL Treiber-Fehler: \n"
-#, fuzzy
-msgid "relative"
-msgstr "Erzeuge"
-msgid "Raster map for which to edit null file"
-msgstr "Rasterkarte, bei der die NULL-Datei editiert werden soll."
-#, fuzzy
-msgid "Display the HTML man pages of GRASS GIS"
-msgstr "Zeige die HTML-Handbuchseite von GRASS."
-#, fuzzy
-msgid "Join column in table"
-msgstr "Spalte der Vektorkartentabelle, die für den Join verwendet werden soll."
-#, fuzzy
-msgid "Path to resulting ASCII file ('-' for standard output) or ASCII vector name if '-o' is defined"
-msgstr "Pfad zur resultiertenden ASCII-Datei oder ASCII-Kartenname, wenn der Schalter '-o' angegeben ist."
-#, fuzzy
-msgid "Unable to parse '%s'\n"
-msgstr "Kann <%s> nicht lesen."
-#, fuzzy
-msgid "Driver <%s> doesn't support creating new fields"
-msgstr "Der Treiber <%s> unterstützt die Erzeugung von Rasterdaten nicht."
-#, fuzzy
-msgid "Unable to add new field <%s>"
-msgstr "Kann 3Dview-Datei <%s> in <%s> nicht lesen."
-#, fuzzy
-msgid "Sets color rules for features in a vector map using a numeric attribute column."
-msgstr "Bestimme Farbregeln für Feature einer Vektorkarte unter Verwendung einer numerischen Spalte der Attributtabelle."
-#, fuzzy
-msgid "Name of raster map from which to copy color table"
-msgstr "Rasterkarte, von der die Farbtabelle kopiert werden soll."
-#, fuzzy
-msgid "Name of file containing rules"
-msgstr "Name der Datei mit den Signaturen."
-#, fuzzy
-msgid "Creating support files for <%s>"
-msgstr "Erstelle Support-Dateien für <%s>."
-#, fuzzy
-msgid "Title for new raster file."
-msgstr "Titel für die neue Rasterkarte."
-#, fuzzy
-msgid "Unable it load G3d range"
-msgstr "Kann die Ausdehnungs-Datei nicht lesen."
-#, fuzzy
-msgid "\raster\" and \"volume\" options are mutually exclusive"
-msgstr "Die Optionen \"color\", \"rules\" und \"raster\" schliessen sich gegenseitig aus."
-#, fuzzy
-msgid "Calculating measure #%d <%s> (56 measures available)"
-msgstr "Habe die Kenngröße #%d <%s> berechnet (56 Kenngrößen verfügbar)."
-#, fuzzy
-msgid "Exports the color table associated with a raster3d map layer."
-msgstr "Exportiert die Farbtabelle einer Rasterkarte."
-msgid "Could not close RASTER3D map"
-msgstr "Konnte RASTER3D Karte nicht schließen"
-msgid "Could not close RASTER3D map <%s>"
-msgstr "Konnte RASTER3D Karte <%s> nicht schließen."
-msgid "Name for v5d output file"
-msgstr "Name der v5d Ausgabedatei."
-#, fuzzy
-msgid "Converts a 3D raster map into a 3-dimensional Vis5D file."
-msgstr "Exportiert eine GRASS 3D-Rasterkarte in eine dreidimensionale Vis5D-Datei."
-#, fuzzy
-msgid "Lists available GIS elements of the user-specified data type."
-msgstr "Gibt die Daten des angegeben Typs auf die Standardausgabe."
-#, fuzzy
-msgid "Remove dangles:"
-msgstr "Entferne Überstände (dangles)"
-#, fuzzy
-msgid "Unable to create 3D vector and attribute table at same time"
-msgstr "v.random kann 3D Vektorkarten und Attributtabellen nicht zu selben Zeit erstellen."
-#, fuzzy
-msgid "Coordinates"
-msgstr "Präzision der Koordinaten"
-#, fuzzy
-msgid "maps for mosaic."
-msgstr "2. Bild für das Mosaik."
-#, fuzzy
-msgid "reclass raster output map"
-msgstr "Vektor-Ausgabekarte"
-#, fuzzy
-msgid "Data source for OGR access"
-msgstr "Datenquelle enthält %d Layer:"
-#, fuzzy
-msgid "A single vector map can be connected to multiple database tables. This number determines which table to use. Layer name for OGR access."
-msgstr "Eine einzelne Vektorkarte kann mit mehreren Datenbanktabellen verbunden sein. Diese Zahl bestimmt welche Tabelle verwendet werden soll."
-#, fuzzy
-msgid "Vector map for which to drop vector objects"
-msgstr "Vektorkarte, in deren Attributtabelle eine Spalte gelsöcht werden soll."
-#, fuzzy
-msgid "Layer of attribute table to use for selection"
-msgstr "Name der Attribut-Spalte die für die Label benutzt werden soll."
-#, fuzzy
-msgid "WHERE conditions for vector delete, without 'where' keyword (e.g. \"elevation IS NULL\")"
-msgstr "WHERE Bedingung für die Aktualisierung, ohne das Schlüsselwort 'where' (z.B. cat=1 or col1/col2>1)."
-#, fuzzy
-msgid "Overwrite existing file"
-msgstr "Ãœberschreibe existierende Maske (MASK)."
-#, fuzzy
-msgid "Name of input vector polygon map"
-msgstr "Name der Vektorkarte (Polygone)."
-#, fuzzy
-msgid "Name of MODIS product"
-msgstr "Name der Eingabekarte."
-#, fuzzy
-msgid "The names of tile/s to download"
-msgstr "Die Zahl der Punkte, die verteilt werden sollen."
-#, fuzzy
-msgid "raster, import, copying"
-msgstr "Raster, Import, Konvertierung"
-#, fuzzy
-msgid "raster, export, copying"
-msgstr "Raster, Export"
-#, fuzzy
-msgid "Name of input elevation map"
-msgstr "Eingabe-Rasterkarte, die Höhenwerte enthält."
-#, fuzzy
-msgid "Name for output shaded relief map"
-msgstr "Name der Ausgabe-Rasterkarte."
-#, fuzzy
-msgid "Existing SPOT VGT NDVI HDF file (0001_NDV.HDF)"
-msgstr "Existierende SPOT VGT NDVI HDF Datei (z.B. 0001_NDV.HDF)."
-#, fuzzy
-msgid "zenith"
-msgstr "Länge: %f\n"
-#, fuzzy
-msgid "topographic correction method"
-msgstr "Name der Ausgabe-Rasterkarte, der Fließrichtungen."
-#, fuzzy
-msgid "Elevation file of unknown type"
-msgstr "Höhe eines Punktes der Ebene."
-#, fuzzy
-msgid "Cannot allocate memory for auxiliar matrix.Consider changing region (resolution)"
-msgstr "Speicher für Hilfmatrix kann nicht bereitgestellt werden. Erwägen Sie die Auflösung der Region zu ändern."
-msgid "Converts a 3D raster map layer into an ASCII text file"
-msgstr "Konvertiert eine 3D-Rasterkarte in eine ASCII-Datei"
-msgid "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
-msgstr "Konvertiert eine 3D ASCII-Raster Textdatei in eine (binäre) 3D-Rasterkarte. "
-msgid "Converts 3D raster maps (RASTER3D) into the VTK-Ascii format"
-msgstr "Konvertiert eine 3D-Rasterkarte (RASTER3D) in das VTK-ASCII-Format."
-msgid "unable to close top raster map"
-msgstr "Kann die obere Rasterkarte nicht schließen."
-msgid "unable to close bottom raster map"
-msgstr "Kann die untere Rasterkarte nicht schließen."
-msgid ""
-"Cannot create mask file: RASTER3D_MASK already exists!\n"
-" Use 'g.remove rast3d=RASTER3D_MASK' to remove the existing mask."
-msgstr ""
-"Kann keine Maskendatei erzeugen: RASTER3D_MASK existiert bereits.\n"
-"Benutzen Sie 'g.remove rast3d=RASTER3D_MASK' um die existierende Maske zu löschen."
-msgid "also import quality map (SM status map layer) and filter NDVI map"
-msgstr "Importiere auch die Qualitätskarte (SM-Statuskarte) und filtere die NDVI-Karte."
-#, fuzzy
-msgid "Name for output flowline density raster map"
-msgstr "Ausgabe-Rasterkarte der Fließdichte."
-#, fuzzy
-msgid "vector, interpolation, kriging"
-msgstr "Vektor, Interpolation"
-#, fuzzy
-msgid "Raster map to use as mask"
-msgstr "Rasterkarte, die als Maske (MASK) verwendet werden soll."
-msgid "Calculate the groundwater distance velocity vector field and write the x, y, and z components to maps named name_[xyz]. Name is basename for the new raster3d maps"
-msgstr "Berechne das Vektorfeld der Grundwassergeschwindigkeit und schreibe die X, Y und Z Komponenten in die Karten name_[xyz]. Name ist der gemeinsame Bestandteil der neuen raster3d Karten."
-msgid "Checking GDAl data type and nodata value"
-msgstr "Prüfe GDAL Datentyp und NoData-Wert."
-msgid "douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker Algorithm with reduction parameter;lang;Lang Simplification Algorithm;reduction;Vertex Reduction Algorithm eliminates points close to each other;reumann;Reumann-Witkam Algorithm;remove_small;Removes lines shorter than threshold and areas of area less than threshold;boyle;Boyle's Forward-Looking Algorithm;sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;Interpolation by Cubic Hermite Splines;snakes;Snakes method for line smoothing;network;Network generalization;displacement;Displacement of lines close to each other;"
-msgstr "douglas;Douglas-Peucker Algorithmus;douglas_reduction;Douglas-Peucker Algorithmus mit Reduktionsparameter;lang;Lang's Vereinfachungsalgorithmus;reduction;Vertex Reduktionsalgorithmus eliminiert Punkte, die dicht beieinander liegen;reumann;Reumann-Witkam Algorithmus;remove_small;Entfernt Linien, die kürzer als der Schwellwert sind und Flächen, die kleiner als der Schwellwert sind;boyle;Boyle's Vorausschauender-Algorithmus;sliding_averaging;McMaster's Gleitender Mittelwert- Algorithmus;distance_weighting;McMaster's Distanzgewichtetungs-Algorithmus;chaiken;Chaiken's Algorithmus;hermite;Interpolation mit kubischen Hermite-Splines;snakes;Snake-Methoden zum glätten von Linien;network;Netzwerk Generalisierung;displacement;Verschieben von Linien, die dicht beieinander liegen;"
-msgid "Number of vertices was reduced from %d to %d [%d%%]"
-msgstr "Anzahl der Vertices wurden von %d auf %d [%d%%] reduziert."
-msgid ""
-"\n"
-"ERROR: Required parameter <%s> not set:\n"
-"    (%s).\n"
-msgstr ""
-"\n"
-"FEHLER: Benötigter Parameter <%s> wurde nicht angegeben:\n"
-"    (%s).\n"
-msgid "Band to select"
-msgstr "Zu selektierender Kanal"
-#, fuzzy
-msgid "Watershed basin analysis program"
-msgstr "Modul zur Analyse von Wassereinzugsgebieten."
-#, fuzzy
-msgid "Name of input raster map with real depressions"
-msgstr "Name der Eingabe-Rasterkarte, die umprojeziert werden soll."
-#, fuzzy
-msgid "Name of input raster map blocking overland surface flow"
-msgstr "Eingabekarte mit Gelände, dass den Oberflächenabfluss blockiert, für USLE."
-#, fuzzy
-msgid "Name for output raster map useful for visual display of results (DEPRECATED)"
-msgstr "Ausgabekarte die hilfreich für die visuelle Darstellung der Ergebnisse ist. VERALTET."
-#, fuzzy
-msgid "Name for output direction map for depressionless elevation raster map"
-msgstr "(o)   Richtungskarte für abflusslose Höhenkarte."
-#, fuzzy
-msgid "raster, export, animation"
-msgstr "Raster, Höhenwerte"
-#, fuzzy
-msgid "(requires r.out.ppm with stdout option)"
-msgstr ""
-"Konvertiere direkt, benutze wenig Festplattenplatz\n"
-"\t(benötigt r.out.ppm mit stdout-Option)"
-#, fuzzy
-msgid "Calculation of unconfined groundwater flow: loop %i\n"
-msgstr "Berechnung der unbeschränkten Grundwasserfluss Schleife %i\n"
-#, fuzzy
-msgid "Name for output elevation raster map after filling"
-msgstr "Ausgabehöhenkarte nach dem Füllen"
-#, fuzzy
-msgid "Name for output direction raster map"
-msgstr "Name der Ausgabe-Expositions-Rasterkarte."
-#, fuzzy
-msgid "Reading input data..."
-msgstr "Lese Eingaben..."
-#, fuzzy
-msgid "Writing output data..."
-msgstr "Schreibe Ausgabe..."
-#, fuzzy
-msgid "raster, reclassification"
-#, fuzzy
-msgid "Name of input raster map with given starting point(s) (at least 1 cell > 0)"
-msgstr "Name der Rasterkarte mit Startpunkten (mindestens eine Zelle > 0)."
-#, fuzzy
-msgid "Constructs flow lines."
-msgstr "Kosten für Isolinien."
-#, fuzzy
-msgid "Name for flowpath length raster map"
-msgstr "Ausgabe-Rasterkarte, der Hanglänge."
-#, fuzzy
-msgid "imagery, landsat, acca"
-msgstr "Bildverarbeitung, Klassifikation, MLC"
-#, fuzzy
-msgid "Cannot write to raster map <%s>"
-msgstr "Kann Rasterkarten nicht schreiben."
-#, fuzzy
-msgid "Creates, edits, and lists groups and subgroups of imagery data."
-msgstr "Erzeugt, editiert und listet Gruppen und Untergruppen von Bilddateien."
-#, fuzzy
-msgid "Extract quality control parameters from Modis QC layers"
-msgstr "Extrahiert Terrainparameter aus einem DGM."
-#, fuzzy
-msgid "Name of the surface reflectance QC layer [bit array]"
-msgstr "Name Referenzsystemtabelle."
-#, fuzzy
-msgid "The output cell map <%s.%d> has values outside the 0-255 range. Min: %d Max: %d"
-msgstr "Die Ausgabe-Rasterkarte <%s.%d> hat Werte außerhalb der Spanne 0-255."
-#, fuzzy
-msgid "Computing means and standard deviations..."
-msgstr "Berechne Mittelwerte für Kanal %d..."
-#, fuzzy
-msgid "Computing means..."
-msgstr "Berechne Gleichungen..."
-#, fuzzy
-msgid "wxpython;wxPython based next generation GUI;tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);text;command line interface only"
-msgstr "tcltk;Tcl/Tk basiertes GUI - GIS Manager (gis.m);oldtcltk;Altes Tcl/Tk basiertes GUI - Display Manager (d.m);wxpython;wxPython basiertes GUI der nächsten Generation;text;Nur Kommandozeile"
-#, fuzzy
-msgid "Other"
-msgstr "Dither"
-#, fuzzy
-msgid "Offset in map units."
-msgstr "Bufferdistanz in Karteneinheiten"
-#, fuzzy
-msgid "db connection was not set by form"
-msgstr "db Verbindung wurde nicht von Formular gesetzt\n"
-#, fuzzy
-msgid "Cannot describe table"
-msgstr "Kann Tabelle nicht beschreiben\n"
-#, fuzzy
-msgid "DEPRECATED Buffer distance in map units"
-#, fuzzy
-msgid "Line buffers... "
-msgstr "Linien-Buffer... "
-#, fuzzy
-msgid "Zero area size, please clean input vector first."
-msgstr "Erzeugt Linien parallel zu den Eingabevektorlinien."
-#, fuzzy
-msgid "Could not get outside buffer for line id %d"
-msgstr "Konnte die Süd-Bufferzonengröße nicht lesen. Breche ab."
-#, fuzzy
-msgid "Area buffers... "
-msgstr "Flächen-Buffer ..."
-#, fuzzy
-msgid "Selecting areas..."
-msgstr "Selektiere Feature..."
-msgid "Converts to one of the supported OGR vector formats."
-msgstr "Konvertiert in ein OGR unterstütztes Vektorformat."
-#, fuzzy
-msgid "Cannot allocate %u bytes of memory"
-msgstr "Kann nicht %d Byte Speicher belegen."
-#, fuzzy
-msgid "Skip the join column in other table"
-msgstr "Spalte in der anderen Tabelle, die für den Join verwendet werden soll."
-#, fuzzy
-msgid "Copy all the columns from other table to map"
-#, fuzzy
-msgid "Name of input raster map in which to fill nulls"
-msgstr "Rasterkarte, in der die NULL-Zellen gefüllt werden sollen"
-#, fuzzy
-msgid "Name for output raster map with nulls filled by interpolation"
-msgstr "Gibt eine Rasterkarte aus, in der NULL-Gebiete durch Interpolation der umgebenden Werte gefüllt wurden"
-#, fuzzy
-msgid "Mosaics up to four images, extending the color table."
-msgstr "Mosaikiert bis zu 4 Bilder und erweitert die Farbtabelle. Erzeugt *.mosaic-Karten."
-#, fuzzy
-msgid "creates map *.mosaic"
-msgstr "3. Bild für das Mosaik."
-#, fuzzy
-msgid "1st map for mosaic (top of image stack)"
-msgstr "1. Karte für das Mosaik (Spitze des Bildstapels)."
-#, fuzzy
-msgid "2nd map for mosaic"
-#, fuzzy
-msgid "3rd map for mosaic"
-#, fuzzy
-msgid "4th map for mosaic"
-msgstr "4. Bild für das Mosaik."
-#, fuzzy
-msgid "writing edges..."
-msgstr "Schreibe Vertices..."
-msgid "raster3d, statistics"
-msgstr "3D-Raster, Statistik"
-msgid "raster, png"
-msgstr "Raster, PNG"
-msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)"
-msgstr "Erzeugt Hangkurven (flowlines), Fließlängen und Flussdichte (upslope areas) aus einem angegebenen digitalen Höhenmodell (DEM)."
-msgid "Convert all old GRASS < Ver5.7 vector maps in current mapset to current format"
-msgstr "Konvertiert alle alten GRASS < Ver5.7 Vektorkarten im aktuellen Mapset in das aktuelle Format."
-#, fuzzy
-msgid "Creates a mask for limiting raster operation."
-msgstr "Erzeuge eine Maske (MASK) um Rasteroperationen zu begrenzen."
-msgid "Import Mapgen or Matlab vector maps into GRASS."
-msgstr "Importiert Mapgen oder Matlab Vektorkarten nach GRASS."
-msgid "Ascii file containing spectral signatures"
-msgstr "ASCII-Datei mit den spektralen Signaturen."
-#, fuzzy
-msgid "Unhandled vector feature type <%s>"
-msgstr "Kann die Tabelle <%s> nicht erzeugen."
-#, fuzzy
-msgid "No areas found, skipping type=area"
-msgstr "Keine Flächen gefunden, überspringe den Typ poly."
-#, fuzzy
-msgid "No points found, skipping%s%s"
-msgstr "Keine Punkte gefunden, überspringe den Typ point."
-#, fuzzy
-msgid "No lines found, skipping%s%s"
-msgstr "Keine Linien gefunden, überspringe den Typ Linie."
-msgid "The given nodata value is present in rasterband <%s> and would lead to data loss. Please specify a different nodata value with the %s parameter."
-msgstr "Der gewählte NoData-Wert ist im Rasterkanal <%s> vorhanden und würde zu Datenverlust führen. Bitte geben Sie einen anderen NoData-Wert mit dem Parameter %s an."
-msgid "Output long/lat in decimal degrees or other projections with many decimal places"
-msgstr "Gebe long/lat in Dezimalgrad oder einer anderen Projektion mit vielen Dezimalstellen aus."
-msgid "Calculates univariate statistics from a GRASS raster map based on vector polygons and uploads statistics to new attribute columns."
-msgstr "Berechnet Kennzahlen univariater Statistik einer Rasterkarte für Polygone und fügt die Ergebnisse als neue Spalte der Attributtabelle an."
-#, fuzzy
-msgid "GDAL datatype: %s, range: %f - %f"
-msgstr "Rasterkarte <%s> erzeugt."
-#, fuzzy
-msgid "The hight of the river bed in [m]"
-msgstr "Höhe des Flussbetts [m]."
-#, fuzzy
-msgid "The hight of the drainage bed in [m]"
-msgstr "Höhe der Drainage [m]."
-#, fuzzy
-msgid "Pass %d:"
-msgstr "Durchgang %d..."
-#, fuzzy
-msgid "The '-q' flag is superseded and will be removed "
-msgstr "Der Schalter '-q' wurde überflüssig gemacht und wird in der Zukunft entfernt-- Bitte verwenden Sie '--quiet' stattdessen ."
-#, fuzzy
-msgid "Unable to create table <%s_edge_Interpolation>"
-msgstr "Kann die Datenbank <%s> nicht öffnen."
-#, fuzzy
-msgid "Rescale output raster map [0,255]"
-#, fuzzy
-msgid "Input raster map contains cells with NULL-value (no-data). The value %g was used to represent no-data values in the input map. You can specify a nodata value with the %s option."
-msgstr "Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert %g wurde verwendet um Nodata-Werte in der Eingabekarte zu kennzeichnen. Sie können Nodata-Wert mit dem Parameter %s bestimmen."
-msgid "Allocation memory for bilinear interpolation"
-msgstr "Allokiere Speicher für die bilineare Interpolation."
-msgid "Allocation memory for bicubic interpolation"
-msgstr "Allokiere Speicher für die bikubische Interpolation."
-msgid ""
-"Sorry, if any of the following options are set:\n"
-"    basin, stream, half.basin, slope, or lS\n"
-"    you MUST provide a value for the basin threshold parameter."
-msgstr ""
-"Wenn eine der folgenden Optionen gesetzt wurde:\n"
-"    basin, stream, half.basin, slope oder lS\n"
-"    MÜSSEN Sie ein Wert für den Parameter 'basin threshold' angegeben."
-msgid "Do not export long colortable"
-msgstr "Exportiere keine langen Farbtabellen."
-msgid "Input raster map contains cells with NULL-value (no-data). The value %d was used to represent no-data values in the input map. You can specify nodata value by %s parameter."
-msgstr "Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert %d wurde verwendet um Nodata-Werte in der Eingabekarte zu kennzeichnen. Sie können Nodata-Wert mit dem Parameter %s bestimmen."
-msgid "Default value: GRASS_GUI if defined otherwise tcltk"
-msgstr "Standardwert: GRASS_GUI wenn definiert, ansonsten tcltk"
-msgid "tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);wxpython;wxPython based next generation GUI;text;command line interface only"
-msgid "CHILD[pid = %i]: unable to open %s mask ... continue without!!!"
-msgstr "CHILD[pid = %i]: kann %s Maske nicht öffnen ... mache ohne weiter !!!"
-msgid "r.li.worker (pid %i) exited with abnormal status %i"
-msgstr "r.li.worker (pid %i) abgebrochen mit unnormalen Status %i"
-msgid "r.li.worker (pid %i) terminated"
-msgstr "r.li.worker (pid %i) beendet."
-msgid "Cannot make stat of %s configuration file"
-msgstr "Kann stat von %s Konfigurationsdatei nicht erzeugen."
-msgid "Illegal configuration file"
-msgstr "Ungültige Konfigurationsdatei."
-msgid "Seed [%d] larger than maximum [%d]"
-msgstr "Startwert [%d] größer als das Maximum [%d]."
-msgid "Seed [%d] smaller than minimum [%d]"
-msgstr "Startwert [%d] kleiner als das Minimum [%d]."
-msgid "Show the category label in the grid cell(s)"
-msgstr "Zeige die Kategorielabel der Rasterzelle(n)."
-msgid "Unable to read symbol, unable todisplay points"
-msgstr "Kann das Symbol nicht lesen; kann die Punkte nicht darstellen."
-msgid "vector, query"
-msgstr "Vektor, Abfrage"
-msgid "point;simple x,y[,z] list;standard;GRASS's vector ASCII format"
-msgstr "Punkt; einfache x,y[,z] Liste;Standard;GRASSs Vektor-ASCII-Format"
-msgid "Number of column used as y coordinate (first column is 1) for points mode"
-msgstr "Nummer der Spalte, die als Y-Koordinate (erste Spalte ist 1)  für den Punkt-Modus genutzt wird."
-msgid "Number of column used as z coordinate (first column is 1) for points mode"
-msgstr "Nummer der Spalte, die als Z-Koordinate (erste Spalte ist 1)  für den Punkt-Modus genutzt wird."
-msgid "If 0, z coordinate is not used"
-msgstr "Wenn 0, dann wird die Z-Koordinate nicht verwendet."
-msgid "Number of column used as category (first column is 1) for points mode"
-msgstr "Nummer der Spalte, die als Kategorie (erste Spalte ist 1)  für den Punkt-Modus genutzt wird."
-msgid "If 0, unique category is assigned to each row and written to new column 'cat'"
-msgstr "Wenn 0, dann wird in die neue Spalte 'cat' in jede Zeile eine eindeutige Kategorie geschrieben."
-msgid "Create a new empty vector map and exit. Nothing is read from input"
-msgstr "Erstellt eine neue, leere Vektorkarte und beendet sich. Nichts wird eingelesen."
-msgid "Computing row %d of covariance matrix..."
-msgstr "Berechne Zeile %d der Kovarianz-Matrix..."
-msgid "Converting %s..."
-msgstr "Konvertiere %s..."
-msgid "Calculates cast shadow areas from sun position and DEM. Either A: exact sun position is specified, or B: date/time to calculate the sun position by r.sunmask itself."
-msgstr "Berechnet Schlagschattenbereiche zwischen Sonnenstand und DEM. Es können entweder A: exakte Sonnenposition, oder B: Datum/Uhrzeit zur selbständigen Berechnung durch r.sunmask, angegeben werden."
-msgid "A: altitude of the sun above horizon, degrees"
-msgstr "A: Höhe der Sonne über dem Horizont (in Grad)."
-msgid "A: azimuth of the sun from the north, degrees"
-msgstr "A: Winkel der Sonne, gemessen von der Nordrichtung (in Grad)."
-msgid "B: minutes (0..60)"
-msgstr "B: Minuten (0..60)"
-msgid "B: seconds (0..60)"
-msgstr "B: Sekunden (0..60)"
-msgid "B: timezone (east positive, offset from GMT, also use to adjust daylight savings)"
-msgstr "B: Zeitzone (Ost positiv, Abstand von GMT; wird auch zur Anpassung an die Winterzeit genutzt)."
-msgid "Name for output file (do not add extension)"
-msgstr "Name der Ausgabedatei (Fügen Sie keine Dateiendung an)."
-msgid "Surface"
-msgstr "Oberfläche"
-msgid "Volume"
-msgstr "Volumen"
-msgid "New LOCATION name (not location path)"
-msgstr "Neuer LOCATION Name (nicht der Pfad zur Location)."
-msgid "New GISDBASE (full path to the directory where the new location is)"
-msgstr "Neue GISDBASE (vollständiger Pfad zu dem Verzeichnis, in dem sich die neue L0cation befindet)."
-msgid "Width and height of output image"
-msgstr "Breite und Höhe des Ausgabe-Bildes."
-msgid "Vector map for which to edit attribute table"
-msgstr "Vektorkarte deren Attributtabelle editiert werden soll."
-msgid "Layer where to add column"
-msgstr "Layer, in dem eine Spalte hinzugefügt werden soll."
-msgid "Raster value"
-msgstr "Rasterwert"
-msgid "Slower but accurate (applies to FP maps only)"
-msgstr "Langsamer aber genau (gilt nur für Fließkomma-Karten)."
-msgid "Feature type. Combination of types is not supported by all formats."
-msgstr "Feature-Typ: Kombinationen der Typen wird nicht von allen Formaten unterstützt."
-msgid "%d faces found, but not requested to be exported. Verify 'type' parameter."
-msgstr "%d 3D-Fläche(n) gefunden, die allerdings nicht exportiert werden sollen. Überprüfen Sie bitte den 'type'-Parameter."
-msgid "Exporting %i points/lines..."
-msgstr "Exportiere %i Punkte/Linien..."
-msgid "Create a MASK for limiting raster operation"
-msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)"
-msgstr "Sedimenttransport und Erosions/Depositions Simulation unter Verwendung der \"path sampling method\" (SIMWE)."
-msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)"
-msgstr "Hydrologische Simulation des Oberflächenabfluß mittels der 'path sampling'-Methode (SIMWE)."
-msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation layer."
-msgstr "Filtere und generiere ein depressionsloses Höhenmodell und eine Fließrichtungskarte auf Basis eines gegebenen Höhenmodells."
-msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
-msgstr "Erstellt Karte mit topographischem Index [(ln(a/tan(beta)))] auf Basis einer Karte mit Höhenwerten."
-msgid "Import Mapgen or Matlab-ASCII vector maps into GRASS."
-msgstr "Importiert Mapgen oder Matlab-ASCII Vektorkarten nach GRASS."
-msgid "Raster File Series to MPEG Conversion Program."
-msgstr "Konvertiert Folgen von Rasterkarten zu einem MPEG-Film."
-msgid "Calculates linear regression from two raster maps: y = a + b*x"
-msgstr "Berechnet eine lineare Regression von zwei Rasterkarten: y = a + b*x"
-#~ msgid "Input grid3 filename"
-#~ msgstr "Eingabe-grid3D-Datei"
-#~ msgid "Grid3 <%s> not found %s"
-#~ msgstr "Grid3 <%s> wurde nicht gefunden %s"
-#~ msgid "Failed to guess site file format"
-#~ msgstr "Das Erraten des Sites-Formates ist schief gegangen"
-#~ msgid "Print raster map resolution (NS-res, EW-res) only"
-#~ msgstr "Gebe nur Rasterkartenauflösung aus (NS-res, EW-res)."
-#~ msgid "Print raster map type only"
-#~ msgstr "Gebe nur Rasterkartentyp aus."
-#~ msgid "Print map region only"
-#~ msgstr "Gebe nur die Region der Rasterkarte aus."
-#~ msgid "Print raster map data units only"
-#~ msgstr "Gebe nur die Einheit der Rasterkarte aus."
-#~ msgid "Print raster map vertical datum only"
-#~ msgstr "Gebe nur das vertikale Datum der Rasterkarte aus."
-#~ msgid "Print map title only"
-#~ msgstr "Gebe nur den Titel der Rasterkarte aus."
-#~ msgid "Print raster map timestamp (day.month.year hour:minute:seconds) only"
-#~ msgstr "Gebe Zeitstempel der Rasterkarte aus (Tag.Monat.Jahr Stunde:Minute:Sekunde)"
-#~ msgid "Name for value output map"
-#~ msgstr "Name der Wert-Ausgabekarte."
-#~ msgid "Invalid timestamp"
-#~ msgstr "Ungültiger Zeitstempel."
-#~ msgid "Reading sites..."
-#~ msgstr "Lese sites..."
-#~ msgid "Writing sites to output..."
-#~ msgstr "Schreibe sites in die Ausgabe..."
-#~ msgid "Reading coordinates from file."
-#~ msgstr "Lese Koordinaten aus Datei."
-#~ msgid "ASCII file holding transform coordinates"
-#~ msgstr "ASCII-Datei mit den Transformationskoordinaten"
-#~ msgid "If not given, transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot) are used instead"
-#~ msgstr "Wenn nicht gegeben, verwende verwende stattdessen Transformationsparameter (xshift, yshift, zshift, xscale, yscale, zscale, zrot)."
-#~ msgid "Unable to open file with coordinates <%s>"
-#~ msgstr "Kann die Datei mit den Koordinaten <%s> nicht öffnen"
-#~ msgid "Error reading coordinates file"
-#~ msgstr "Fehler beim Lesen der Koordinaten-Datei"
-#~ msgid "Number of points that have been entered [%d]"
-#~ msgstr "Anzahl der Punkte, die eingegeben wurden [%d]"
-#~ msgid "Error creating transformation"
-#~ msgstr "Fehler beim Erzeugen der Transformation"
-#~ msgid "The points weren't spread out enough."
-#~ msgstr "Die Punkte sind nicht weit genug auseinander gelegen."
-#~ msgid "You need to enter at least %d points."
-#~ msgstr "Sie müssen mindestens %d Punkte eingeben."
-#~ msgid "create;Create new (empty) vector map;add;Add new features to existing vector map;delete;Delete selected features from vector map;move;Move selected features in vector map;vertexmove;Move vertex of selected vector lines;vertexdel;Remove vertex from selected vector lines;vertexadd;Add new vertex to selected vector lines;merge;Merge selected vector lines;break;Break/split vector lines;select;Select lines and print their ID's;catadd;Set new categories to selected vector features for defined layer;catdel;Delete categories from selected vector features for defined layer;copy;Copy selected features;snap;Snap vector features in given threshold;flip;Flip direction of selected vector lines;connect;Connect two lines;zbulk;Z bulk-labeling (automated assignment of z coordinate to vector lines);chtype;Change feature type (point<->centroid, line<->boundary)"
-#~ msgstr "create;Erzeuge ein neue (leere) Vektorkarte;add;Fügt neue Feature zu einer existierenden Vektorkarte hinzu;delete;Entfernt selektierte Feature von einer Vektorkarte;move;Verschiebt selektierte Feature in einer Vektorkarte;vertexmove;Verschiebt einen Vertex selektierter Vektorlinien;vertexdel;Entfernt einen Vertex aus selektierten Vektorlinien;vertexadd;Fügt einen neuen Vertex zu selektierten Vektorlinien hinzu;merge;Vereinigt selektierte Vektorlinien;break;Teilt Vektorlinien;select;Selektiert Linien und gibt ihre ID aus;catadd;Vergiebt neue Kategorien für selektierte Vektorfeature eines bestimmten Layers;catdel;Löscht Kategorien von selektierten Vektorfeatures eines bestimmten Layers;copy;Kopiert selektierte Feature;snap;Snap Vektorfeature innerhalb des angegebenen Schwellwertes;flip;Drehe die Richtung selektierter Vektorlinien um;connect;Verbinde zwei Linien;zbulk;Z-Massen-Beschriftung (automatisierte Zuweisung der Z Koordinate zu Vektorlinien);chtype;Ändere
  den Typ des Features(Punkt<->Zentroid, Linie<->Grenze)"
-#~ msgid "Column name (will be updated by raster values)"
-#~ msgstr "Spaltenname (die mit den Rasterwerten aktualisiert wird)."
-#~ msgid "Cannot scan date: "
-#~ msgstr "Kann das Datum nicht auslesen:"
-#~ msgid "Cannot scan time: "
-#~ msgstr "Kann die Zeit nicht auslesen:"
-#~ msgid "Cannot allocate cursor."
-#~ msgstr "Kann keinen Speicher für Cursor reservieren."
-#~ msgid "Cannot ad new token."
-#~ msgstr "Kann kein neues Zeichenhinzufügen."
-#~ msgid "Cannot connect to MySQL: "
-#~ msgstr "Kann nicht zu MySQL verbinden."
-#~ msgid "DBMI-MySQL driver error:\n"
-#~ msgstr "DBMI-MySQL Treiber-Fehler: \n"
-#~ msgid "Cannot select data: \n"
-#~ msgstr "Kann die Daten nicht auswählen:\n"
-#~ msgid "Unable allocate memory for row buffer"
-#~ msgstr "Kann keinen Speicher für Zeilenbuffer reservieren."
-#~ msgid "Computing means for band %d..."
-#~ msgstr "Berechne Mittelwerte für Kanal %d..."
-#~ msgid "Computing row %d (of %d) of covariance matrix..."
-#~ msgstr "Berechne Zeile %d (von %d) der Kovarianz-Matrix..."
-#~ msgid "Unable to allocate memory for row buffer"
-#~ msgid "Unable to allocate memory for raster row"
-#~ msgstr "Kann keinen Speicher für Rasterzeilen reservieren."
-#~ msgid "Transforming <%s>..."
-#~ msgstr "Transformiere <%s>..."
-#~ msgid "Surface area estimation for rasters."
-#~ msgstr "Abschätzung der Größe der Rasteroberflächen."
-#~ msgid "Raster file for surface"
-#~ msgstr "Rasterkarte für die Oberfläche."
-#~ msgid "Writing buffers..."
-#~ msgstr "Schreibe Buffer..."
-#~ msgid "ASCII file to be converted to binary vector map"
-#~ msgstr "ASCII-Datei, die in eine Vektorkarte konvertiert werden soll."
-#~ msgid "If not given (or \"-\") reads from standard input"
-#~ msgstr "Lese von der Standardeingabe, wenn nicht angegeben (oder \"-\")."
-#~ msgid "Join column in other table"
-#~ msgstr "Spalte in der anderen Tabelle, die für den Join verwendet werden soll."
-#~ msgid "Name of arc forward/both direction(s) cost column"
-#~ msgstr "Kostenspalte für vorwärts/beide Richtungen der Kanten"
-#~ msgid "Name of arc backward direction cost column"
-#~ msgstr "Kostenspalte für die rückwärtige Richtung der Kanten"
-#~ msgid "Layer number or name with route paths or -1"
-#~ msgstr "Layer-Nummer oder -Name mit Routing-Angaben oder -1"
-#~ msgid "Layer %d - no table"
-#~ msgstr "Layer %d - keine Tabelle"
-#~ msgid "Layer %d - unable to copy table"
-#~ msgstr "iebenLayer %d - kann die Tabelle nicht kopieren"
-#~ msgid "Name of arc forward/both direction(s) capacity column"
-#~ msgstr "Spaltenname der Arc forward/both direction(s) capacity"
-#~ msgid "Name of arc backward direction capacity column"
-#~ msgstr "Spaltenname der Arc backward direction capacity"
-#~ msgid "Source layer number or name"
-#~ msgstr "Source Layer-Nummer oder -Name"
-#~ msgid "Sink layer number or name"
-#~ msgstr "Sink Layer-Nummer oder -Name"
-#~ msgid "Name of Arc cost column"
-#~ msgstr "Spaltenname mit den Arc-Kosten"
-#~ msgid "Enter -1 to keep original categories or the desired NEW category value"
-#~ msgstr "Geben Sie -1 ein, um die originalen Kategorien beizubehalten oder der erwünschte NEUE Kategoriewert."
-#~ msgid "From layer number or name"
-#~ msgstr "Abfragelayernummer oder -name"
-#~ msgid "To layer number or name"
-#~ msgstr "Ziel-Layernummer oder -name"
-#~ msgid "Name of node capacity column"
-#~ msgstr "Spaltenname der Knotenkapazität"
-#~ msgid "Set1 layer number or name"
-#~ msgstr "Set1 Layer-Nummer oder -Name"
-#~ msgid "Set2 layer number or name"
-#~ msgstr "Set2 Layer-Nummer oder -Name"
-#~ msgid "Either mapset= or -l must be used"
-#~ msgstr "Entweder mapset= oder -l muss angegeben werden."
-#~ msgid "Line width column (%s) is not numeric."
-#~ msgstr "Spalte mit der Linienbreite (%s) ist nicht numerisch."
-#~ msgid "Error in color definition column '%s', feature id %d with cat %d: colorstring '%s'"
-#~ msgstr "Fehler in der Spalte mit den Farbwerten '%s', Feature ID %d mit cat %d: Farbwert '%s'."
-#~ msgid "Error in color definition column '%s', feature id %d with cat %d"
-#~ msgstr "Fehler in der Spalte mit den Farbwerten '%s', Feature ID %d mit cat %d"
-#~ msgid "Error in symbol size column (%s), element %d with cat %d: symbol size [%f]"
-#~ msgstr "Fehler in der Symbolgrößen-Spalte (%s), Element %d mit cat %d: Symbolgröße [%f]."
-#~ msgid "Error in color definition column '%s': %d features affected"
-#~ msgstr "Fehler in der Spalte mit den Farbwerten '%s', %d Feature betroffen."
-#~ msgid "Colorize polygons according to z height"
-#~ msgstr "Färbe die Polygone gemäß ihrer Z-Höhe."
-#~ msgid "'layer' must be > 0 for 'where'."
-#~ msgstr "Parameter 'layer' muss > 0 sein, wenn der Parameter 'where' angegeben ist."
-#~ msgid "'layer' must be > 0 for 'cats'."
-#~ msgstr "'Layer' muss > 0 sein für den Parameter 'cats'."
-#~ msgid "Can't read vector map"
-#~ msgstr "Kann Vektorkarte nicht lesen."
-#~ msgid "Color definition column not specified."
-#~ msgstr "Farbspalte nicht angegeben."
-#~ msgid "Error in color definition column (%s), area %d with cat %d: colorstring [%s]"
-#~ msgstr "Fehler in der Spalten mit den Frabwerten (%s), Fläche %d mit cat %d: Farbwert [%s]."
-#~ msgid "pg driver: column '%s', type %d  is not supported"
-#~ msgstr "PG-Treiber: Spalte '%s', Typ %d wird nicht unterstützt."
-#~ msgid "Type of color table"
-#~ msgstr "Farbtabellentyp"
-#~ msgid "Save placeholder raster map for use with d.legend"
-#~ msgstr "Speichere Platzhalter Rasterkarte für Verwendung in d.legend."
-#~ msgid "Name and type of the new column(s) (types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
-#~ msgstr "Name und Art der neuen Spalten (Art hängt von der verwendeten Datenbank ab, aber alle unterstützen VARCHAR(), INT, DOUBLE PRECISION and DATE)."
-#~ msgid "Name for input source not specified"
-#~ msgstr "Name der Eingabe-Qulle nicht angegeben."
-#~ msgid "Name for output raster map not specified"
-#~ msgstr "Name der Ausgabe-Rasterkarte nicht angegeben"
-#~ msgid "Requested g3d map <%s> not found"
-#~ msgstr "Angeforderte G3D Karte <%s> nicht gefunden."
-#~ msgid "Error opening g3d map <%s>"
-#~ msgstr "Fehler beim Öffnen der G3D-Rasterkarte <%s>."
-#~ msgid "\"color\", \"rules\", and \"raster\" options are mutually exclusive"
-#~ msgstr "Die Optionen \"color\", \"rules\" und \"raster\" schliessen sich gegenseitig aus."
-#~ msgid "-g and -a flags are mutually exclusive"
-#~ msgstr "-g und -a schließen sich gegenseitig aus."
-#~ msgid "Negative or no data pixel found. This module is not yet able to process no data holes in a map, please fill with r.fillnulls or other algorithms"
-#~ msgstr "Negative oder NODATA-Pixel gefunden. Dieses Modul kann NODATA-Werte in Rasterkarten noch nicht verarbeiten. Bitte füllen Sie die Löcher z.B. mit dem Modul r.fillnulls oder anderen Füllalgorithmen."
-#~ msgid "Too many iterations to required to find %s - giving up"
-#~ msgstr "Zu viele Iterationen werden benötigt um %s zu finden - gebe auf."
-#~ msgid "Angular Second Moment"
-#~ msgstr "Bogensekunde"
-#~ msgid "Features"
-#~ msgstr "Features"
-#~ msgid "Contrast"
-#~ msgstr "Kontrast"
-#~ msgid "Correlation"
-#~ msgstr "Korrelation"
-#~ msgid "Variance"
-#~ msgstr "Varianz"
-#~ msgid "Inverse Diff Moment"
-#~ msgstr "Inverse Diff Moment"
-#~ msgid "Sum Average"
-#~ msgstr "Summe der Mittelwerte"
-#~ msgid "Sum Variance"
-#~ msgstr "Summe der Varianzen"
-#~ msgid "Sum Entropy"
-#~ msgstr "Summe der Entropie"
-#~ msgid "Entropy"
-#~ msgstr "Entropie"
-#~ msgid "Difference Variance"
-#~ msgstr "Differenz der Varianzen"
-#~ msgid "Difference Entropy"
-#~ msgstr "Differenz der Entropie"
-#~ msgid "Measure of Correlation-1"
-#~ msgstr "Korrelationskoeffizient-1"
-#~ msgid "Measure of Correlation-2"
-#~ msgstr "Korrelationskoeffizient-2"
-#~ msgid "Max Correlation Coeff"
-#~ msgstr "Max Korrelationskoeffizient"
-#~ msgid "Raster file to be imported"
-#~ msgstr "Zu importierende Rasterdatei."
-#~ msgid "Allows rendering GIS data is a 3D space."
-#~ msgstr "Ermöglicht die Darstellung von GIS-Daten im 3D-Raum."
-#~ msgid "Write the result to g3d map <%s>"
-#~ msgstr "Schreibe das Ergebnis in die G3D-Karte <%s>."
-#~ msgid "Requested 3d raster map not found"
-#~ msgstr "Angeforderte 3D-Rasterkarte nicht gefunden"
-#~ msgid "Error closing new ASCII file"
-#~ msgstr "Fehler beim Schließen der neuen ASCII-Datei"
-#~ msgid "modifyNull: error opening map"
-#~ msgstr "modifyNull: Fehler beim Öffnen der Karte."
-#~ msgid "modifyNull: error closing map"
-#~ msgstr "modifyNull: Fehler beim Schließen der Karte."
-#~ msgid "Adding rule: %lf - %lf"
-#~ msgstr "Füge Regel hinzu: %lf - %lf"
-#~ msgid "makeMask: error opening map."
-#~ msgstr "makeMask: Fehler beim Öffnen der Karte."
-#~ msgid "makeMask: error opening g3d mask file"
-#~ msgstr "makeMask: Fehler beim Öffnen der G3D-Maskendatei."
-#~ msgid "makeMask: error closing g3d mask file"
-#~ msgstr "makeMask: Fehler beim Schließen der G3D-Maskendatei."
-#~ msgid "makeMask: error closing map"
-#~ msgstr "makeMask: Fehler beim Schließen der Karte."
-#~ msgid "Requested 3d raster map <%s> not found"
-#~ msgstr "Angeforderte G3D Rasterkarte <%s> nicht gefunden."
-#~ msgid "Requested g3d RGB map <%s> not found"
-#~ msgstr "Angeforderte G3D RGB Karte <%s> nicht gefunden."
-#~ msgid "Requested g3d vector map <%s> not found"
-#~ msgstr "Angeforderte G3D Vektorkarte <%s> nicht gefunden."
-#~ msgid "Open rgb 3d raster map %s"
-#~ msgstr "Öffne RGB 3D-Rasterkarte %s."
-#~ msgid "Error closing g3d rgb map."
-#~ msgstr "Fehler beim Schließen der G3D-RGB-Datei."
-#~ msgid "Error closing g3d vector map."
-#~ msgstr "Fehler beim Schließen der G3D-Vektorkarte."
-#~ msgid "The 2d and 3d region settings are different. The g3d settings are used to adjust the 2d region."
-#~ msgstr "Die 2D und 3D Regions Parameter sind unterschiedlich. Die G3D-Parameter werden verwendet, um die 2D Region anzupassen."
-#~ msgid "unable to close input 3d raster map"
-#~ msgstr "Kann die Eingabe-3D-Rasterkarte nicht schließen."
-#~ msgid "write_vtk_rgb_data: writing rgb data"
-#~ msgstr "write_vtk_rgb_data: Schreibe RGB-Daten"
-#~ msgid "write_vtk_vector_data: writing vector data"
-#~ msgstr "write_vtk_vector_data: Schreibe Vektor-Daten"
-#~ msgid "Error closing new 3d raster map"
-#~ msgstr "Fehler beim Schließen der neuen 3D-Rasterkarte."
-#~ msgid "Error closing ascii file"
-#~ msgstr "Fehler beim Schließen der ASCII-Datei."
-#~ msgid "Error: couldn't create %s"
-#~ msgstr "Fehler: Kann %s nicht erzeugen."
-#~ msgid "Error while writing grid. Disk full?"
-#~ msgstr "Ein Fehler trat während des Lesens der Karte auf. Festplatte voll?"
-#~ msgid "Converts co-ordinate system descriptions (i.e. projection information) between various formats (including GRASS format)."
-#~ msgstr "Konvertiert Beschreibungen von Koordinatensystemen (z.B. Projektinosinformationen) in verschiedene Formate (inklusive des GRASS-Formats)."
-#~ msgid "Create/Edit"
-#~ msgstr "Erzeuge/Editiere"
-#~ msgid "Create new projection files (modifies current location unless 'location' option specified)"
-#~ msgstr "Erzeuge neue Projektionsdateien. Dies modifiziert die Projektionsinformationen der aktuellen Location, solange nicht der Parameter 'location' angegeben ist."
-#~ msgid "Location %s created!"
-#~ msgstr "Location '%s' erstellt!"
-#~ msgid "Print mapset names"
-#~ msgstr "Gebe den Namen des Mapsets aus."
-#~ msgid "Force remove"
-#~ msgstr "Erzwinge das Löschen"
-#~ msgid "Color to erase with, either a standard GRASS color or R:G:B triplet (separated by colons)"
-#~ msgstr "Farbe zum Löschen, entweder als GRASS Standard-Farbe oder als R:G:B-Tripel (Semicolon als Trennzeichen)."
-#~ msgid "Min-area & snap"
-#~ msgstr "Min-Fläche & snap"
-#~ msgid "Layer: %s"
-#~ msgstr "Layer: %s"
-#~ msgid "Break polygons:"
-#~ msgstr "Zerlege Polygone:"
-#~ msgid "Remove duplicates:"
-#~ msgstr "Lösche doppelte Vektoren:"
-#~ msgid "Break boundaries:"
-#~ msgstr "Zerlege Grenzen:"
-#~ msgid "Clean boundaries at nodes:"
-#~ msgstr "Säubere Grenzen an den Knoten:"
-#~ msgid "Remove bridges:"
-#~ msgstr "Lösche Brücken:"
-#~ msgid "Write centroids:"
-#~ msgstr "Schreibe Zentroide:"
-#~ msgid "Cannot calculate centroid"
-#~ msgstr "Kann Zentroid nicht berechnen."
-#~ msgid "Unknown icon marker"
-#~ msgstr "Unbekannter Symbolmarker"
-#~ msgid "Group input"
-#~ msgstr "Eingabe-Gruppe "
-#~ msgid "Write output to PNG image"
-#~ msgstr "Schreibe die Ausgabe in ein PNG-Bild."
-#~ msgid "Verbose mode"
-#~ msgstr "Gesprächiger Modus"
-#~ msgid "E00 file"
-#~ msgstr "E00 Datei"
-#~ msgid "Input type point, line or area"
-#~ msgstr "Eingabetyp Punkt, Linie oder Fläche."
-#~ msgid "Name for output vector map"
-#~ msgstr "Name für die Ausgabe-Vektorkarte"
-#~ msgid "Name of raster plane to be created"
-#~ msgstr "Name der zu erstellenden Ebene (Rasterkarte)."
-#~ msgid "Dip of plane. Value must be between -90 and 90 degrees"
-#~ msgstr "Neigung der Ebene. Wert muß zwischen -90 und 90 Grad liegen."
-#~ msgid "Azimuth of the plane. Value must be between 0 and 360 degrees"
-#~ msgstr "Ausrichtung der Ebene. Wert muß zwischen 0 und 360 Grad liegen"
-#~ msgid "Verbosity level"
-#~ msgstr "Gesprächigkeitsnievau"
-#~ msgid "Name for output raster map prefix (e.g. 'brov')"
-#~ msgstr "Präfix für die Ausgabe-Rasterkarten (z.B. 'brov')."
-#~ msgid "raster input map"
-#~ msgstr "Eingabe-Rasterkarte"
-#~ msgid "Vector map to modify"
-#~ msgstr "Zu ändernde Vektorkarte"
-#~ msgid "Layer in the vector to be modified"
-#~ msgstr "Zu ändernder Layer der Vektorkarte."
-#~ msgid "Vector map to be queried"
-#~ msgstr "Vektorkarte, die abgefragt werden soll."
-#~ msgid "Layer of the query vector containing data"
-#~ msgstr "Layer der Abfrage-Vektorkarte der Daten enthält."
-#~ msgid "Column to be queried"
-#~ msgstr "Spalte, die abgefragt werden soll."
-#~ msgid "Output raster map (default: input tile)"
-#~ msgstr "Ausgabe-Rasterkarte (Standard: Eingabekachel)."
-#~ msgid "Name of input vector map"
-#~ msgstr "Name der Eingabe-Vektorkarte"
-#~ msgid "Vector map to edit the attribute table for"
-#~ msgstr "Vektorkarte deren Attributtabelle edtiert werden soll."
-#~ msgid "Layer to which the table to be changed is connected"
-#~ msgstr "Layer, der die zuändernde Tabelle enthält."
-#~ msgid "Column to update"
-#~ msgstr "Spalte, die aktualisiert werden soll"
-#~ msgid "Column to query"
-#~ msgstr "Spalte, die abgefragt werden soll"
-#~ msgid "WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/col2>1)"
-#~ msgstr "WHERE Bedingung für die Aktualisierung, ohne das Schlüsselwort 'where' (z.B. cat=1 or col1/col2>1)."
-#~ msgid "Old schema"
-#~ msgstr "Altes Schema"
-#~ msgid "New schema"
-#~ msgstr "Neues Schema"
-#~ msgid "Input ASTER image to be georeferenced & rectified"
-#~ msgstr "Eingabe-ASTER-Bild, das georeferenziert und rektifiziert wird."
-#~ msgid "Vector map for which to rename attribute column"
-#~ msgstr "Vektorkarte, für die eine Spalte umbenannt werden soll."
-#~ msgid "Layer where to rename column"
-#~ msgstr "Layer, in dem der Spaltenname geändert werden soll."
-#~ msgstr "GRASS Tabellenname"
-#~ msgid "vector, import"
-#~ msgstr "Vektor, Import"
-#~ msgid "Field separator"
-#~ msgstr "Feld-Trennzeichen"
-#~ msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
-#~ msgstr "Eine einzelne Vektorkarte kann mit mehreren Datenbanktabellen verbunden sein. Diese Zahl bestimmt welche Tabelle verwendet werden soll."
-#~ msgid "WHERE conditions of SQL statement without 'where' keyword"
-#~ msgstr "WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'."
-#~ msgid "Example: income < 1000 and inhab >= 10000"
-#~ msgstr "Beispiel: Einkommen < 1000 und Einwohner >= 10000"
-#~ msgid "display, vector, thematic, legend"
-#~ msgstr "Darstellung, Vektor, thematisch, Legende"
-#~ msgid "vector, topology"
-#~ msgstr "Vektor, Topology"
-#~ msgid "Name of vector map for which to edit attribute table"
-#~ msgstr "Vektorkarte deren Attributtabelle editiert werden soll."
-#~ msgid "Table from which to drop attribute column"
-#~ msgstr "Tabelle von der eine Spalte gelöscht werden soll."
-#~ msgid "Raster map in which to fill nulls"
-#~ msgstr "Rasterkarte, in der die NULL-Zellen gefüllt werden sollen"
-#~ msgid "Output raster map with nulls filled by interpolation from surrounding values"
-#~ msgstr "Gibt eine Rasterkarte aus, in der NULL-Gebiete durch Interpolation der umgebenden Werte gefüllt wurden"
-#~ msgid "Vector map from which to remove attribute table"
-#~ msgstr "Vektorkarte, von der die Attributtabelle gelöscht werden soll."
-#~ msgid "Name of existing attribute table (default: vector map name)"
-#~ msgstr "Name einer existierenden Attributtabelle (Standard Name der Vektorkarte)."
-#~ msgid "Layer from which to drop linked attribute table"
-#~ msgstr "Layer aus dem die Attributtabelle gelöscht werden soll."
-#~ msgid "Vector map for which to drop attribute column"
-#~ msgstr "Vektorkarte, in deren Attributtabelle eine Spalte gelsöcht werden soll."
-#~ msgid "Layer where to drop column"
-#~ msgstr "Layer, in dem eine Spalte gelöscht werden soll."
-#~ msgid "raster output TC maps prefix"
-#~ msgstr "Präfix für Ausgabe TC-Rasterkarten"
-#~ msgid "Vector map for which to add new attribute table"
-#~ msgstr "Vektorkarte, zu der eine neue Attributtabelle hinzugefügt werden soll. "
-#~ msgid "vector, import, wfs"
-#~ msgstr "Vektor, Import, WFS"
-#~ msgid "Name of data table"
-#~ msgstr "Name der Datentabelle"
-#~ msgid "Database/directory for table"
-#~ msgstr "Datenbank/Verzeichnis welches die Tabelle enthält."
-#~ msgid "Database driver"
-#~ msgstr "Datenbanktreiber"
-#, fuzzy
-#~ msgid "Cannot open file [%s] in mapset [%s]"
-#~ msgstr "Kann die Label-Datei <%s> im Mapset <%s> nicht öffnen."
-#, fuzzy
-#~ msgid "Cannot create file <%s> in mapset <%s>"
-#, fuzzy
-#~ msgid "input,cell,raster"
-#~ msgstr "Darstellung, Raster"
-#, fuzzy
-#~ msgid "basemap"
-#~ msgstr "Entferne Basiskarten"
-#~ msgid "Solar zenith in degrees"
-#~ msgstr "Sonnenstand in Grad"
-#, fuzzy
-#~ msgid "method"
-#~ msgstr "Knoten Methode"
-#~ msgid "Topographic correction method"
-#~ msgstr "Methode der topographischen Korrektion"
-#~ msgid "Cannot allocate memory for auxiliar matrix.Consider changing region resolution"
-#~ msgstr "Kann keinen Speicher für Hilfsmatrix reservieren. Erwägen Sie die Auflösung der Region zu ändern."
-#~ msgid "raster3d, voxel, export"
-#~ msgstr "3D-Raster, Voxel, Export"
-#~ msgid "raster3d, voxel, import"
-#~ msgstr "3D-Raster, Voxel, Import"
-#~ msgid "Unable to close output map"
-#~ msgstr "Kann die Ausgabe-Karte nicht schließen."
-#~ msgid "Unable to get elevation raster row"
-#~ msgstr "Kann Zeile der Höhenrasterkarte nicht bekommen."
-#~ msgid "Could not write raster row"
-#~ msgstr "Kann die Zeile des Rasters nicht schreiben."
-#~ msgid "raster3d, voxel"
-#~ msgstr "3D-Raster, Voxel"
-#~ msgid "Elevation map not found"
-#~ msgstr "Höhenkarte nicht gefunden."
-#~ msgid "Unable to open elevation map"
-#~ msgstr "Kann die Höhenkarte nicht öffnen."
-#~ msgid "Illegal output file name"
-#~ msgstr "Ungültiger Ausgabedateiname."
-#~ msgid "Unable to create raster map"
-#~ msgstr "Kann die Rasterkarte nicht erzeugen."
-#~ msgid "Unable to close elevation map"
-#~ msgstr "Kann die Höhenkarte nicht schließen."
-#~ msgid "Unable to write raster row"
-#~ msgstr "Kann die Rasterzeile nicht schreiben."
-#~ msgid "Could not open map %s"
-#~ msgstr "Kann die Karte %s nicht öffnen."
-#~ msgid "Could not get top raster row \n"
-#~ msgstr "Kann die oberste Zeile des Rasters nicht bekommen.\n"
-#~ msgid "Could not get bottom raster row \n"
-#~ msgstr "Kann die untereste Zeile des Rasters nicht bekommen.\n"
-#~ msgid "The initial piezometric head in [m]"
-#~ msgstr "Das initiale piezometrisches Niveau [m]"
-#~ msgid "The status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
-#~ msgstr "Der Status jeder Zelle, = 0 - inaktiv, 1 - aktiv, 2 - dirichlet"
-#~ msgid "The z-part of the hydraulic conductivity tensor in [m/s]"
-#~ msgstr "Der Z-Anteil des hydraulischen Durchlässigkeits Tensors [m/s]."
-#~ msgid "Sources and sinks in [m^3/s]"
-#~ msgstr "Quellen und Senken in [m^3/s]"
-#~ msgid "Specific yield in 1/m"
-#~ msgstr "Spezifischer Ertrag [1/m]."
-#~ msgid "Recharge raster map in m^3/s"
-#~ msgstr "Grundwasserneubildungskarte in m^3/s"
-#~ msgid "The piezometric head result of the numerical calculation will be written to this map"
-#~ msgstr "Das resultierende piezometrisches Niveau der numerischen Berechnung wird in diese Karte geschrieben."
-#~ msgid "Use a sparse linear equation system, only available with iterative solvers"
-#~ msgstr "Verwende ein dünnbesetztes lineares Gleichungssystem, nur für iterative Lösungsverfahren verfügbar."
-#~ msgid "The direct cholesky solver do not work with sparse matrices"
-#~ msgstr "Der direkte Cholesky Löser funktioniert nicht mit dünnbesetzten Matrizen."
-#~ msgid "raster3d, voxel, statistics"
-#~ msgstr "3D-Raster, Voxel, Statistik"
-#~ msgid "raster, export"
-#~ msgstr "Raster, Export"
-#~ msgid "Exports a GRASS raster map to a binary array."
-#~ msgstr "Exportiert eine GRASS Rasterkarte als binäres Array."
-#~ msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
-#~ msgstr "Exportiert eine GRASS Rasterkarte als GRIDATB.FOR (TOPMODEL) Karte."
-#~ msgid "Overwrite output map file"
-#~ msgstr "Ãœberschreibe Ausgabedatei."
-#~ msgid "Setting window header"
-#~ msgstr "Setze Fenster-Header"
-#~ msgid "raster, statistics"
-#~ msgstr "Raster, Statistik"
-#~ msgid "Finds the median of values in a cover map within areas assigned the same category value in a user-specified base map."
-#~ msgstr "Findet den Median der Werte einer Coverkarte innerhalb der Flächen mit gleichen Werten in einer benutzerdefinierten Basiskarte."
-#~ msgid "Base raster map <%s> not found"
-#~ msgstr "Basis-Rasterkarte <%s> nicht gefunden."
-#~ msgid "Base map and output map <%s> must be different"
-#~ msgstr "Basiskarte und Ausgabekarte <%s> müssen unterschiedlich sein."
-#~ msgid "Unable to read category labels of raster map <%s>"
-#~ msgstr "Kann die Kategorietypen der Rasterkarte <%s> nicht lesen."
-#~ msgid "raster, color transformation"
-#~ msgstr "Raster, Farbtransformation"
-#~ msgid "Error reading 'hue' map"
-#~ msgstr "Fehler beim Lesen der Datei 'Farbton' (hue)."
-#~ msgid "Error reading 'intensity' map"
-#~ msgstr "Fehler beim Lesen der Datei 'Intensität' (intensity)."
-#~ msgid "Error reading 'saturation' map"
-#~ msgstr "Fehler beim Lesen der Datei 'Sättigung' (saturation)."
-#~ msgid "The '-v' flag is superseded and will be removed in future. Please use '--verbose' instead."
-#~ msgstr "Der Schalter '-v' wurde ersetzt und in Zukunft entfernt. Bitte verwenden Sie stattdessen '--verbose'."
-#~ msgid "raster, import"
-#~ msgstr "Raster, Import"
-#~ msgid "Can't create raster map <%s>"
-#~ msgstr "Kann die Rasterkarte <%s> nicht erzeugen."
-#~ msgid "raster, DEM, contours, vector"
-#~ msgstr "Raster, DGM, Konturen, Vektor"
-#~ msgid "Run quietly"
-#~ msgstr "Arbeite schweigsam."
-#~ msgid "Suppress single crossing error messages"
-#~ msgstr "Unterdrücke Fehlermeldungen für 'single crossing'."
-#~ msgid "The '-q' and '-n' flag is superseded and will be removed in future. Please use '--quiet' instead."
-#~ msgstr "Die Schalter '-q' und '-n' wurden ersetzt und werden in einer der kommenden Versionen ersatzlos gestrichen. Bitte verwenden Sie stattdessen '--quiet'."
-#~ msgid "Converts a raster map layer into a height-field file for POVRAY."
-#~ msgstr "Exportiert eine Rasterkarte in eine Höhenfeld-Datei für POVRAY."
-#~ msgid "raster, hydrology"
-#~ msgstr "Raster, Hydrologie"
-#~ msgid "raster, metadata"
-#~ msgstr "Raster, Metadaten"
-#~ msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead."
-#~ msgstr "Der Schalter '-q' wurde ersetzt und wird in einer der kommenden Versionen ersatzlos gestrichen. Bitte verwenden Sie stattdessen '--quiet'."
-#~ msgid "%s: [%s] not found"
-#~ msgstr "%s: [%s] nicht gefunden."
-#~ msgid "raster, landscape structure analysis, patch index"
-#~ msgstr "Raster, Landschaftsstruktur Analyse, Patch-Index"
-#~ msgid "raster, map algebra"
-#~ msgstr "Raster, Kartenalgebra"
-#~ msgid "Raster map matrix filter."
-#~ msgstr "Rasterkarte mit Matrix-Filter"
-#~ msgid "Name of filter file"
-#~ msgstr "Name der Filterdatei"
-#~ msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead"
-#~ msgstr "Der Schalter '-q' wurde überflüssig gemacht und wird in der Zukunft entfernt-- Bitte verwenden Sie '--quiet' stattdessen ."
-#~ msgid "Cannot read raster row %d"
-#~ msgstr "Kann die Zeile %d des Rasters nicht lesen."
-#~ msgid "Cannot open raster map <%s>"
-#~ msgstr "Kann die Rasterkarte <%s> nicht öffnen."
-#~ msgid "Converts a raster map layer into an ASCII text file."
-#~ msgstr "Exportiert eine Rasterkarte in eine ASCII-Textdatei."
-#~ msgid "raster, export, png"
-#~ msgstr "Raster, Export, PNG"
-#~ msgid "Unable to read raster map row %d"
-#~ msgstr "Kann die Zeile %d der Rasterkarte nicht lesen."
-#~ msgid "raster, cost surface, cumulative costs"
-#~ msgstr "Raster, Kostenfläche, kumulative Kosten"
-#~ msgid "Name of raster map to contain results"
-#~ msgstr "Name der Ausgabe-Rasterkarte."
-#~ msgid "Number of the segment to create (segment library)"
-#~ msgstr "Anzahl der Segmente, die erstellt werden sollen."
-#~ msgid "Unable to read current window parameters"
-#~ msgstr "Kann die aktuellen Fensterparameter nicht lesen."
-#~ msgid "Nseg is %d"
-#~ msgstr "Nseg ist %d"
-#~ msgid "Null cells excluded from cost evaluation."
-#~ msgstr "NULL-Zellen werden von der Kostenevaluation ausgeschlossen."
-#~ msgid "Input null cell will be retained into output map"
-#~ msgstr "Eingabe-NULL-Werte werden in der Ausgabe-Karte beibehalten."
-#~ msgid "Unable to find starting vector <%s> "
-#~ msgstr "Kann der Startvektor <%s> nicht finden."
-#~ msgid "Unable to find stop vector <%s>"
-#~ msgstr "Kann den Stoppvektor <%s> nicht finden."
-#~ msgid "Map with different projection"
-#~ msgstr "Karte mit unterschiedlicher Projektion."
-#~ msgid "DTM_Source map is: Integer cell type"
-#~ msgstr "DTM_Source Karte ist: Integer Typ"
-#~ msgid "DTM_Source map is: Floating point (float) cell type"
-#~ msgstr "DTM_Source Karte ist: Fließkomma (float) Typ"
-#~ msgid "DTM_Source map is: Floating point (double) cell type"
-#~ msgstr "DTM_Source Karte ist: Fließkomma (double) Typ"
-#~ msgid " %d rows, %d cols"
-#~ msgstr "%d Zeilen, %d Spalten."
-#~ msgid "COST_Source map is: Integer cell type"
-#~ msgstr "COST_Source Karte ist: Integer Typ"
-#~ msgid "COST_Source map is: Floating point (float) cell type"
-#~ msgstr "COST_Source Karte ist: Fließkomma (float) Typ"
-#~ msgid "COST_Source map is: Floating point (double) cell type"
-#~ msgstr "COST_Source Karte ist: Fließkomma (double) Typ"
-#~ msgid "Output map is: Integer cell type"
-#~ msgstr "Ausgabekarte ist: Integer Typ"
-#~ msgid "Output map is: Floating point (float) cell type"
-#~ msgstr "Ausgabekarte ist: Fließkomma (float) Typ"
-#~ msgid "Output map is: Floating point (double) cell type"
-#~ msgstr "Ausgabekarte ist: Fließkomma (double) Typ"
-#~ msgid " EW resolution %s (%lf)"
-#~ msgstr " EW Auflösung %s (%lf)"
-#~ msgid " NS resolution %s (%lf)"
-#~ msgstr " NS Auflösung %s (%lf)"
-#~ msgid "Unable to read raster map <%s> row %d"
-#~ msgstr "Kann die Rasterkarte <%s> Zeile %d nicht lesen."
-#~ msgid "Initializing output "
-#~ msgstr "Initialisiere die Ausgabe ."
-#~ msgid "Unable to allocate memory for segment fbuff == NULL"
-#~ msgstr "Kann keinen Speicher für Segment fbuff == NULL reservieren."
-#~ msgid "Raster output map <%s> not found (no start_points given)"
-#~ msgstr "Ausgabe-Rasterkarte <%s> nicht gefunden (keine Start-Punkte angegeben)"
-#~ msgid "Memory allocation error on reading start points from raster map %s"
-#~ msgstr "Fehler beim allozieren von Speicher während des Lesens der Startpunktes der Rasterkarte %s."
-#~ msgid "End of map!"
-#~ msgstr "Ende der Karte!"
-#~ msgid "Will copy input map null values into output map"
-#~ msgstr "NULL-Werte der Eingabekarte werden in die Ausgabekarte übernommen."
-#~ msgid ""
-#~ "Integer cell type.\n"
-#~ "Writing..."
-#~ msgstr ""
-#~ "Integer-Zelltype.\n"
-#~ "Schreibe..."
-#~ msgid ""
-#~ "Float cell type.\n"
-#~ "Writing..."
-#~ msgstr ""
-#~ "Fließkomma Zellentyp.\n"
-#~ "Schreibe..."
-#~ msgid ""
-#~ "Double cell type.\n"
-#~ "Writing..."
-#~ msgstr ""
-#~ "Double Zelltype.\n"
-#~ "Schreibe..."
-#~ msgid "Peak cost value: %f"
-#~ msgstr "Maximaler Kostenwert: %f"
-#~ msgid "raster, sun energy"
-#~ msgstr "Raster, Sonnenenergie"
-#~ msgid "Name of the latitudes input raster map [decimal degrees]"
-#~ msgstr "Eingabe-Rasterkarte des Breitengrads [in Grad]."
-#~ msgid "A single value of latitude [decimal degrees]"
-#~ msgstr "Ein einfacher Wert des Breitengrads [in Grad]."
-#~ msgid "Name of the longitude input raster map [decimal degrees]"
-#~ msgstr "Eingabe-Rasterkarte mit Längengraden [in Dezimal-Grad]."
-#~ msgid "Horizon file no. %d <%s> not found"
-#~ msgstr "Horizont-Datei Nr. %d <%s> nicht gefunden."
-#~ msgid "Import GDAL supported raster file into a binary raster map layer."
-#~ msgstr "Importiert Rasterdaten (aus Formaten die GDAL unterstützt) in eine GRASS Rasterkarte."
-#~ msgid "Required"
-#~ msgstr "Benötigt"
-#~ msgid "Import a binary raster file into a GRASS raster map."
-#~ msgstr "Importiert eine binäre Rasterdatei in eine GRASS Rasterkarte."
-#~ msgid "raster, rescale"
-#~ msgstr "Raster, Rescale"
-#~ msgid ""
-#~ "\n"
-#~ "Hit RETURN to continue -->"
-#~ msgstr ""
-#~ "\n"
-#~ "Drücken Sie RETURN um fortzufahren -->"
-#~ msgid "Update the statistics (histogram, range) for [%s]? "
-#~ msgstr "Wollen Sie die Statistik (Histogramm, Spannweite) für [%s] aktualisieren?"
-#~ msgid "Not enough room in history file"
-#~ msgstr "Nicht genug Platz in der History-Datei."
-#~ msgid "Edit header for [%s]? "
-#~ msgstr "Header für [%s] schreiben?"
-#~ msgid ""
-#~ "\n"
-#~ "NOTE: [%s] is a reclass of [%s in %s]"
-#~ msgstr ""
-#~ "\n"
-#~ "BEACHTE: [%s] ist eine reklassifizierte Karte von [%s in %s]."
-#~ msgid "Canceling from edit header."
-#~ msgstr "Breche das Schreiben der Headerdatei ab."
-#~ msgid "Edit the category file for [%s]? "
-#~ msgstr "Kategorie-Datei für [%s] schreiben?"
-#~ msgid "Create/Update the color table for [%s]? "
-#~ msgstr "Erzeuge/Aktualisiere die Farbtabelle für [%s]?"
-#~ msgid "Edit the history file for [%s]? "
-#~ msgstr "Wollen Sie die History-Datei für [%s] editieren?"
-#~ msgid ""
-#~ "\n"
-#~ "The null file for [%s] may indicate that some cells contain\n"
-#~ " no data. If the null file for [%s] doesn't exist, zero cells in\n"
-#~ " it are treated by GRASS application programs as no data."
-#~ msgstr ""
-#~ "\n"
-#~ "Die NULL-Datei für [%s] könnte anzeigen, dass einige Zellen\n"
-#~ " NULL-Werte enthalten. Falls die NULL-Datei für [%s] nicht existiert, \n"
-#~ "werden Zellen mit 0 von GRASS-Modulen als NULL behandelt. "
-#~ msgid ""
-#~ "\n"
-#~ "Do you want to create/reset the null file for [%s] so that null cell values are considered valid data? "
-#~ msgstr ""
-#~ "\n"
-#~ "Wollen Sie eine NULL-Datei für [%s] erzeugen/zurücksetzen, so dass Zellen mit NULL-Werten als gültige Daten angesehen werden?"
-#~ msgid "Error writing null row [%d]."
-#~ msgstr "Fehler beim Schreiben der NULL-Zeile [%d]."
-#~ msgid ""
-#~ "\n"
-#~ "Do you want to delete the null file for [%s]\n"
-#~ "(all zero cells will then be considered no data)? "
-#~ msgstr ""
-#~ "\n"
-#~ "Wollen Sie die NULL-Datei für [%s] löschen\n"
-#~ "(alle 0 (zero)-Zellen werden dann zu NULL-Werten)? "
-#~ msgid "Please enter the following information for [%s]:"
-#~ msgstr "Bitte geben Sie die folgenden Informationen für [%s] ein:"
-#~ msgid "        Number of rows"
-#~ msgstr "        Anzahl der Zeilen"
-#~ msgid "        Number of cols"
-#~ msgstr "        Anzahl der Spalten"
-#~ msgid "        Number of bytes per cell"
-#~ msgstr "        Anzahl der Bytes pro Zelle"
-#~ msgid "        Floating point map"
-#~ msgstr "        Fließkomma-Karte"
-#~ msgid "rows * cols * bytes per cell must be same as file size (%lu)"
-#~ msgstr "Zeilen * Spalten * Bytes* pro Zelle musse genauso groß sein wie die Datei (%lu)."
-#~ msgid "If you need help figuring them out, just hit ESC"
-#~ msgstr "Für Hilfe beim Herausfinden bitte ESC drücken."
-#~ msgid "** Negative values not allowed!"
-#~ msgstr "** Negative Werte sind nicht erlaubt!"
-#~ msgid "** Positive values only please!"
-#~ msgstr "** Bitte nur positive Werte!"
-#~ msgid "Edit header for [%s]\n"
-#~ msgstr "Schreibe Header für [%s].\n"
-#~ msgid "[%s] cannot be found!"
-#~ msgstr "[%s] konnte nicht gefunden werden!"
-#~ msgid "For what layer shall the header file be edited? "
-#~ msgstr "Für welchen Layer soll die Header-Datei editiert werden?"
-#~ msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
-#~ msgstr "[%s] ist eine reklassifizierte Karte von [%s] - kann den Header nicht editieren! Führen Sie support für [%s] aus."
-#~ msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
-#~ msgstr "[%s] ist eine reklassifizierte Karte von [%s in %s] - kann den Header nicht editieren!"
-#~ msgid "Cannot open raster map [%s]!"
-#~ msgstr "Kann die Rasterkarte [%s] nicht öffnen!"
-#~ msgid "Raster file [%s] is empty."
-#~ msgstr "Rasterdatei [%s] ist leer."
-#~ msgid "Error reading raster map [%s]."
-#~ msgstr "Fehler beim Lesen der Rasterkarte [%s]."
-#~ msgid "cellhd compression: %d\n"
-#~ msgstr "cellhd Kompression: %d\n"
-#~ msgid "3.0 compression %sindicated\n"
-#~ msgstr "3.0 Komprimierung %s angezeigt.\n"
-#~ msgid "Pre 3.0 compression %sindicated\n"
-#~ msgstr "Pre 3.0 Komprimierung %s angezeigt.\n"
-#~ msgid "[%s] appears to be compressed. Is it? "
-#~ msgstr "[%s] scheint komprimiert zu sein. Ist sie es?"
-#~ msgid "Please indicate the type of compression:\n"
-#~ msgstr "Bitte geben Sie den Typ der Komprimierung an:\n"
-#~ msgid "  1. Pre 3.0 compression\n"
-#~ msgstr "  1. Prä 3.0 Komprimierung\n"
-#~ msgid "  2. 3.0 compression\n"
-#~ msgstr "  2. 3.0 Komprimierung\n"
-#~ msgid "The header for [%s] says the file is not compressed. "
-#~ msgstr "Der Header von [%s] sagt, dass die Datei nicht komprimiert ist."
-#~ msgid "The file appears to be compressed.\n"
-#~ msgstr "Die Datei scheint komprimiert zu sein.\n"
-#~ msgid "Most likely the header is wrong, but I want you to decide.\n"
-#~ msgstr "Höhstwahrscheinlich ist die Information aus dem Header falsch, aber ich möchte, dass Sie entscheiden.\n"
-#~ msgid "The header for [%s] says the file is compressed. "
-#~ msgstr "Der Header von [%s] sagt, dass die Datei komprimiert ist."
-#~ msgid "The file does NOT appear to be compressed.\n"
-#~ msgstr "Die Datei scheint NICHT komprimiert zu sein.\n"
-#~ msgid "Header indicates %d row%s in the raster map, but the actual file format indicates %d row%s"
-#~ msgstr "Header gibt an, dass %d Zeile%s in der Rasterkarte enthalten sind, aber die aktuelle Datei hat %d Zeile%s."
-#~ msgid "Unable to write header for [%s]."
-#~ msgstr "Kann den Header für [%s] nicht schreiben."
-#~ msgid "Header for raster map [%s] updated."
-#~ msgstr "Header der Rasterkarte [%s] aktualisiert."
-#~ msgid ""
-#~ "\n"
-#~ "hit RETURN to continue -->"
-#~ msgstr ""
-#~ "\n"
-#~ "Bitte RETURN drücken um fortzufahren -->"
-#~ msgid "Which raster map needs a color table"
-#~ msgstr "Welche Rasterkarte braucht eine Farbtabelle"
-#~ msgid "Color table for <%s> updated"
-#~ msgstr "Farbtabelle für <%s> aktualisiert."
-#~ msgid "Which raster map needs an updated history? "
-#~ msgstr "Welche Rasterkarte benötigt eine Aktualisierung der History?"
-#~ msgid "Raster file [%s] not found. Exiting."
-#~ msgstr "Rasterkarte [%s] nicht gefunden. Beende mich. "
-#~ msgid "History file for [%s] updated."
-#~ msgstr "Die Historiedatei für [%s] wurde aktualisiert."
-#~ msgid "History file for [%s] not updated."
-#~ msgstr "Die Historiedatei für [%s] wurde nicht aktualisiert."
-#~ msgid "Which vector map needs updated categories?"
-#~ msgstr "Für welche Vektordatei sollen die Kategorien aktualisiert werden?"
-#~ msgid "Which raster map needs updated categories?"
-#~ msgstr "Für welche Rasterkarte sollen die Kategorien aktualisiert werden?"
-#~ msgid "Category file for <%s> not updated"
-#~ msgstr "Kategorie-Datei für <%s> nicht aktualisiert."
-#~ msgid "Category file for <%s> updated"
-#~ msgstr "Kategorie-Datei für <%s> aktualisiert."
-#~ msgid "Failed writing output raster map row %d"
-#~ msgstr "Schreiben der Zeile <%d> der Rasterkarte fehlgeschlagen."
-#~ msgid "Name of terrain raster map (DEM)"
-#~ msgstr "Name der Terrain Rasterkarte (DEM)."
-#~ msgid "Name for output raster map with lake"
-#~ msgstr "Name der Ausgabe-Rasterkarte mit See."
-#~ msgid "Interpolating raster map <%s> (%d rows)... "
-#~ msgstr "Interpoliere Rasterkarte <%s> (%d Zeilen)... "
-#~ msgid "Cannot read row"
-#~ msgstr "Kann die Zeile nicht lesen."
-#~ msgid "raster, export, color table"
-#~ msgstr "Raster, Export, Farbtabelle"
-#~ msgid "Unable to read raster <map %d of %d> row %d"
-#~ msgstr "Kann die Rasterkarte <map %d of %d> Zeile %d nicht lesen."
-#~ msgid "raster, map management"
-#~ msgstr "Raster, Kartenverwaltung"
-#~ msgid "raster, geometry"
-#~ msgstr "Raster, Geometrie"
-#~ msgid "Name of real-sky beam radiation coefficient raster map [-]"
-#~ msgstr "Name der Rasterkarte mit dem Koeffizient der direkten Sonneneinstrahlung [-]."
-#~ msgid "Name of real-sky diffuse radiation coefficient raster map [-]"
-#~ msgstr "Name der Rasterkarte mit dem Koeffizient der diffusen Sonneneinstrahlung [-]."
-#~ msgid "time and insol_time are incompatible options"
-#~ msgstr "time und insol_time sind nicht kompatible Optionen."
-#~ msgid "Mode 1: instantaneous solar incidence angle & irradiance given a set local time"
-#~ msgstr "Modus 1: momentaner Sonneneinfallswinkel & Strahlungsintensität bei bekannter lokaler Zeit"
-#~ msgid "elevin raster map <%s> not found"
-#~ msgstr "elevin Rasterkarte <%s> nicht gefunden."
-#~ msgid "aspin raster map <%s> not found"
-#~ msgstr "aspin Rasterkarte <%s> nicht gefunden."
-#~ msgid "slopein raster map <%s> not found"
-#~ msgstr "slopein Rasterkarte <%s> nicht gefunden."
-#~ msgid "linkein raster map <%s> not found"
-#~ msgstr "linkin Rasterkarte <%s> wurde nicht gefunden."
-#~ msgid "albedo raster map <%s> not found"
-#~ msgstr "albedo Rasterkarte <%s> wurde nicht gefunden."
-#~ msgid "coefbh raster map <%s> not found"
-#~ msgstr "coefbh Rasterkarte <%s> wurde nicht gefunden."
-#~ msgid "coefdh raster map <%s> not found"
-#~ msgstr "coefdh Rasterkarte <%s> wurde nicht gefunden."
-#~ msgid "Unable to create raster map %s"
-#~ msgstr "Kann die Rasterkarte '%s' nicht erzeugen."
-#~ msgid "rows changed from %d to %d"
-#~ msgstr "Zeilen änderten sich von %d auf %d."
-#~ msgid "cols changed from %d to %d"
-#~ msgstr "Spalten haben sich von %d auf %d geändert."
-#~ msgid "RGB raster map <%s> not found"
-#~ msgstr "RGB Rasterkarte <%s> nicht gefunden"
-#~ msgid "Cannot create RGB data, please provide three maps [r,g,b]"
-#~ msgstr "Kann RGB-Daten nicht erzeugen, bitte stellen Sie drei Karten zur Verfügung [r,g,b]"
-#~ msgid "Vector cell map <%s> not found"
-#~ msgstr "Vektor-Zellen-Karte <%s> nicht gefunden."
-#~ msgid "Cannot create vector data, please provide three maps [x,y,z]"
-#~ msgstr "Kann Vektor-Daten nicht erzeugen, bitte geben Sie drei Karten an [x,y,z]"
-#~ msgid "Converts raster maps into the VTK-Ascii format"
-#~ msgstr "Konvertiert eine Rasterkarte in das VTK-ASCII-Format."
-#~ msgid "Unable to read row %i\n"
-#~ msgstr "Kann Zeile %i nicht lesen.\n"
-#~ msgid "raster, quantization"
-#~ msgstr "Raster, Quantisierung"
-#~ msgid "Setting quant rules for input map(s) to (%f %f) -> (%d,%d)"
-#~ msgstr "Setze Quantisierungsregeln für Eingabekarte(n) auf (%f %f) -> (%d,%d)"
-#~ msgid "Quant table not changed for %s"
-#~ msgstr "Quantisierungstabelle für <%s> wurde nicht geändert."
-#~ msgid "raster, terrain"
-#~ msgstr "Raster, Terrain"
-#~ msgid "Failed to guess site file format\n"
-#~ msgstr "Erraten des Sites-Formates ist fehlgeschlagen\n"
-#~ msgid "No data"
-#~ msgstr "Keine Daten"
-#~ msgid "NULL value computed (row %d, col %d)"
-#~ msgstr "NULL Werte berechnet (Zeile %d, Spalte %d)"
-#~ msgid "Unable to find row %d, col %d: %f"
-#~ msgstr "Kann Zeile %d, Spalte %d nicht finden: %f"
-#~ msgid "Illegal delete request"
-#~ msgstr "Ungültige Löschanfrage."
-#~ msgid "Bad start cell"
-#~ msgstr "Schlechte Start-Zelle."
-#~ msgid "%s %f-%f lower cost higher or equal"
-#~ msgstr "%s %f-%f niedrigere Kosten höher oder gleich"
-#~ msgid "%s lower above pointer wrong"
-#~ msgstr "%s lower above pointer wrong"
-#~ msgid "%s %f-%f higher cost lower"
-#~ msgstr "%s %f-%f higher cost lower"
-#~ msgid "%s higher above pointer wrong"
-#~ msgstr "%s higher above pointer wrong"
-#~ msgid "raster, resample"
-#~ msgstr "Raster, Resamplen"
-#~ msgid "Bilinear interpolation utility for raster map layers."
-#~ msgstr "Bilineares Interpolationswerkzeug für Rasterkarten."
-#~ msgid "Specific input value to be assigned to the north and/or south poles for longitude-latitude grids"
-#~ msgstr "Spezieller Eingabewert, der dem Nord- und/oder Südpol in Längen- und Breitengrad-Gittern zugewiesen wird."
-#~ msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
-#~ msgstr "Dies Moduls ist veraltet. Bitte verwenden Sie stattdessen 'r.resamp.interp'."
-#~ msgid "Apply filter only to zero data values"
-#~ msgstr "Filter nur auf 0-Werte anwenden."
-#~ msgid "One or more input raster maps not found"
-#~ msgstr "Eine oder mehrere Rasterkarte nicht gefunden."
-#~ msgid "raster, sediment flow, erosion, deposition"
-#~ msgstr "Raster, Sedimenttransport, Erosion, Deposition"
-#~ msgid "Name of the elevation raster map [m]"
-#~ msgstr "Name der Rasterkartem mit Höheninformation [m]."
-#~ msgid "Name of the water depth raster map [m]"
-#~ msgstr "Name der Rasterkarte mit Wassertiefe [m]."
-#~ msgid "Name of the x-derivatives raster map [m/m]"
-#~ msgstr "Name der Rasterkarte mit Ableitung nach X [m/m]."
-#~ msgid "Name of the y-derivatives raster map [m/m]"
-#~ msgstr "Name der Rasterkarte mit Ableitung nach Y [m/m]."
-#~ msgid "Name of the detachment capacity coefficient raster map [s/m]"
-#~ msgstr "Name der Rasterkarte mit Trennungs-Kapazitätskoeffizienten [s/m]."
-#~ msgid "Name of the transport capacity coefficient raster map [s]"
-#~ msgstr "Name der Rasterkarte mit Transport-Kapazitätskoeffizienten [s/m]."
-#~ msgid "Name of the critical shear stress raster map [Pa]"
-#~ msgstr "Name der Rasterkarte mit kritische Scherrspannung [Pa]."
-#~ msgid "Name of the Mannings n raster map"
-#~ msgstr "Name der Rasterkarte mit Mannings n."
-#~ msgid "Name of the Mannings n value"
-#~ msgstr "Name des Mannings n Parameters."
-#~ msgid "Output transport capacity raster map [kg/ms]"
-#~ msgstr "Ausgabe-Rasterkarte der Transportkapazität [kg/ms]."
-#~ msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
-#~ msgstr "Ausgabe der \"transp.limited\" Erosions-Depositions Rasterkarte [kg/m2s]."
-#~ msgid "Output sediment concentration raster map [particle/m3]"
-#~ msgstr "Ausgabe-Rasterkarte der Sedimentkonzentration [Partikel/m3]"
-#~ msgid "Output sediment flux raster map [kg/ms]"
-#~ msgstr "Ausgabe-Rasterkarte des Sedimentfluß [kg/ms]."
-#~ msgid "Output erosion-deposition raster map [kg/m2s]"
-#~ msgstr "Ausgabe der Erosions-Depositions-Rasterkarte [kg/m2s]."
-#~ msgid "raster, flow, hydrology"
-#~ msgstr "Raster, Abfluss, Hydrologie"
-#~ msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
-#~ msgstr "Name der Rasterkarte der Niederschlagsüberschussrate (rain-infilt) [mm/hr]."
-#~ msgid "Name of the runoff infiltration rate raster map [mm/hr]"
-#~ msgstr "Name der Rasterkarte der Abflußinfiltrationsrate [mm/hr]."
-#~ msgid "Name of the flow controls raster map (permeability ratio 0-1)"
-#~ msgstr "Name Rasterkarte, die den Fluß kontrolliert (Permeabilität: 0-1)."
-#~ msgid "Output water depth raster map [m]"
-#~ msgstr "Ausgabe-Rasterkarte der Wassertiefe [m]"
-#~ msgid "Output water discharge raster map [m3/s]"
-#~ msgstr "Ausgabe-Rasterkarte des Wasserabfluß [m3/s]."
-#~ msgid "Output simulation error raster map [m]"
-#~ msgstr "Ausgabe-Rasterkarte des Simulationsfehlers [m]."
-#~ msgid "Threshold water depth [m] (diffusion increases after this water depth is reached)"
-#~ msgstr "Schwellwert der Wassertiefe [m] (Diffusion steigt, nachdem diese Wassertiefe erreicht wurde)."
-#~ msgid "Unable to close input map"
-#~ msgstr "Kann die Eingabekarte nicht schließen."
-#~ msgid "Could not get raster row from input map"
-#~ msgstr "Konnte die Rasterzeile der Eingabekarte nicht holen."
-#~ msgid "Could not get raster row from elev map"
-#~ msgstr "Konnte die Rasterzeile der Karte mit Höhenwerten nicht holen."
-#~ msgid "raster, raster3d, voxel, conversion"
-#~ msgstr "Raster, 3D-Raster, Voxel, Konvertieren"
-#~ msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the currently defined region."
-#~ msgstr "Konvertiert eine GRASS-Rasterkarte in eine PPM Bilddatei mit der Auflösung der aktuellen Region."
-#~ msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
-#~ msgstr "Exportiert 3 GRASS Rasterkarten (R,G,B) als PPM-Bild mit der Pixel-Auflösung der DERZEITIG EINGESTELLTEN REGION."
-#~ msgid "raster, transect"
-#~ msgstr "Raster, Transekt"
-#~ msgid "raster, random"
-#~ msgstr "Raster, Zufall"
-#~ msgid "Cannot read raster row [%d]"
-#~ msgstr "Kann die Zeile [%d] der Rasterkarte nicht lesen."
-#~ msgid "Cannot read cover raster row [%d]"
-#~ msgstr "Kann die Zeile [%d] der Bedeckungs-Rasterkarte nicht lesen."
-#~ msgid "Cannot read raster row [%d] from raster map <%s>"
-#~ msgstr "Kann die Zeile [%d] der Rasterkarte <%s> nicht lesen."
-#~ msgid "Cannot read raster row [%d] from cover raster map <%s>"
-#~ msgstr "Kann die Zeile [%d] der Bedeckungs-Rasterkarte <%s> nicht lesen."
-#~ msgid "raster, viewshed"
-#~ msgstr "Raster, Sichtbereich"
-#~ msgid "[%s]: Cannot read map header"
-#~ msgstr "[%s]: Kann den Kartenheader nicht lesen."
-#~ msgid "Failed writing raster map <%s> row %d"
-#~ msgstr "Konnte Rasterkarte <%s> Zeile %d nicht schreiben."
-#~ msgid "raster, fire"
-#~ msgstr "Raster, Feuer"
-#~ msgid "Run VERBOSELY"
-#~ msgstr "Ausführliche Ausgabe."
-#~ msgid "Raster map <%s> already exists in mapset <%s>, select another name"
-#~ msgstr "Rasterkarte <%s> existiert bereits im Mapset <%s>, wählen Sie einen anderen Namen."
-#~ msgid "Name of raster map to contain results (several new layers)"
-#~ msgstr "Name der Rasterkarten mit den Ergebnissen (mehrere Karten möglich)."
-#~ msgid "Percent Completed ... "
-#~ msgstr "Prozent fertig..."
-#~ msgid "Boundary condition status, 0-inactive, 1-active, 2-dirichlet"
-#~ msgstr "Status der Randbedingungen, 0-inaktive, 1-aktive, 2-dirichlet."
-#~ msgid "X-part of the hydraulic conductivity tensor in [m/s]"
-#~ msgstr "X-Anteil des hydraulischen Durchlässigkeits Tensors [m/s]."
-#~ msgid "Y-part of the hydraulic conductivity tensor in [m/s]"
-#~ msgstr "Y-Anteil des hydraulischen Durchlässigkeits Tensors [m/s]."
-#~ msgid "Water sources and sinks in [m^3/s]"
-#~ msgstr "Wasserquellen und -senken [m^3/s]."
-#~ msgid "Specific yield in [1/m]"
-#~ msgid "Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
-#~ msgstr "Anreicherungskarte (recharge map) z.B.: 6*10^-9 pro Zelle [m^3/s*m^2]."
-#~ msgid "The map storing the numerical result [m]"
-#~ msgstr "Karte der numerischen Ergebnisse [m]."
-#~ msgid ""
-#~ "Calculate the groundwater filter velocity vector field [m/s]\n"
-#~ "and write the x, and y components to maps named name_[xy]"
-#~ msgstr ""
-#~ "Berechne das Vektorfeld der Grundwasserfiltrationgeschwindigkeiten [m/s]\n"
-#~ "und schreibe die x- und y-Komponenten in Karten mit den Namen name_[xy]."
-#~ msgid "Water level (head) of the river with leakage connection in [m]"
-#~ msgstr "Wasserstand des Flusses (head) mit Sicker-Verbindung [m]."
-#~ msgid "The leakage coefficient of the river bed in [1/s]."
-#~ msgstr "Sicker-Koeffizient des Flussbettes [1/s]."
-#~ msgid "The height of the drainage bed in [m]"
-#~ msgstr "Höhe der Drainage [m]."
-#~ msgid "The leakage coefficient of the drainage bed in [1/s]"
-#~ msgstr "Sicker-Koeffizient der Drainage [1/s]."
-#~ msgid "Use a sparse matrix, only available with iterative solvers"
-#~ msgstr "Verwende eine dünnbesetzte Matrix, nur für iterative Lösungsverfahren verfügbar."
-#~ msgid "raster, profile"
-#~ msgstr "Raster, Profil"
-#~ msgid "Interactively select End-Points"
-#~ msgstr "End-Punkte interaktiv bestimmen."
-#~ msgid "Use mouse to select Start Point\n"
-#~ msgstr "Verwenden Sie die Maus, um den Startpunkt anzugeben.\n"
-#~ msgid ""
-#~ "\n"
-#~ "Use mouse to draw profile line\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Verwenden Sie die Maus, um das Profil abzufragen.\n"
-#~ msgid "Buttons:\n"
-#~ msgstr "Maustasten:\n"
-#~ msgid "Left:   Mark next point\n"
-#~ msgstr "Links:   Nächsten Punkt markieren.\n"
-#~ msgid "Middle: Mark next point\n"
-#~ msgstr "Mitte: Nächsten Punkt markieren.\n"
-#~ msgid ""
-#~ "Right:  Finish profile and exit\n"
-#~ "\n"
-#~ msgstr ""
-#~ "Rechts:  Beende Profil und stop\n"
-#~ "\n"
-#~ msgid "raster, buffer"
-#~ msgstr "Raster, Buffer"
-#~ msgid "raster, series"
-#~ msgstr "Raster, Serien"
-#~ msgid "Threshold to calculate for method=threshold"
-#~ msgstr "Schwellenwert für method=threshold"
-#~ msgid "Unable to open raster map <%s> in mapset <%s>"
-#~ msgstr "Kann die Rasterkarte <%s> in Mapset <%s> nicht öffnen."
-#~ msgid "Finds the average of values in a cover map within areas assigned the same category value in a user-specified base map."
-#~ msgstr "Findet den Durchschnitt der Werte in einer Ãœberlagerungskarte innerhalb gleicher Kategorien in einer benutzer-angegebenen Ausgangskarte."
-#~ msgid "%s: ERROR running %s command"
-#~ msgstr "%s: Fehler  beim Ausführen des Kommandos %s."
-#~ msgid "%s: unable to open temporary file"
-#~ msgstr "%s: Kann die temporäre Datei nicht öffnen."
-#~ msgid "Cannot get row"
-#~ msgstr "Kann Zeile nicht bekommen."
-#~ msgid "Watershed basin analysis program."
-#~ msgstr "Modul zur Analyse von Wassereinzugsgebieten."
-#~ msgid "Input map: elevation on which entire analysis is based"
-#~ msgstr "Eingabekarte mit Höheninformationen, welche die Grundlage der gesamten Analyse ist."
-#~ msgid "Input map: locations of real depressions"
-#~ msgstr "Eingabekarte mit Orten realer Senken im Gebiet."
-#~ msgid "Input map: amount of overland flow per cell"
-#~ msgstr "Eingabekarte mit der Größe des Oberflächenabfluss pro Zelle."
-#~ msgid "Input map or value: percent of disturbed land, for USLE"
-#~ msgstr "Eingabekarte oder Wert: Prozent von gestörtem Land, (für ABAG/USLE)."
-#~ msgid "Input map: terrain blocking overland surface flow, for USLE"
-#~ msgstr "Eingabekarte mit Gelände, dass den Oberflächenabfluss blockiert, für USLE."
-#~ msgid "Output map: number of cells that drain through each cell"
-#~ msgstr "Ausgabekarte mit Anzahl der Zellen, die durch jede Zelle abfließt."
-#~ msgid "Output map: drainage direction"
-#~ msgstr "Ausgabekarte mit Abflussrichtung."
-#~ msgid "Output map: unique label for each watershed basin"
-#~ msgstr "Ausgabekarte mit eindeutiger Kennzeichnung jedes Einzugsgebietes."
-#~ msgid "Output map: stream segments"
-#~ msgstr "Ausgabekarte der Flußsegmente. "
-#~ msgid "Output map: each half-basin is given a unique value"
-#~ msgstr "Ausgabekarte mit Einzugsgebietshälften mit eindeutigen Wert."
-#~ msgid "Output map: useful for visual display of results"
-#~ msgstr "Ausgabekarte: hilfreich für die visuelle Darstellung der Ergebnisse."
-#~ msgid "Output map: slope length and steepness (LS) factor for USLE"
-#~ msgstr "Ausgabekarte der Hanglängen und -Neigungsfaktoren (LS) für USLE."
-#~ msgid "Output map: slope steepness (S) factor for USLE"
-#~ msgstr "Ausgabekarte der Hangneigungsfaktoren (S) für USLE."
-#~ msgid "Input value: minimum size of exterior watershed basin"
-#~ msgstr "Eingabewert: kleinste Größe des äußeren Wassereinzugsgebiets."
-#~ msgid "Input value: maximum length of surface flow, for USLE"
-#~ msgstr "Eingabewert: maximale Länge des Oberflächenabflusses für USLE."
-#~ msgid "Enable MFD flow (default is SFD (D8))"
-#~ msgstr "Aktiviere MFD-Fluss (Standard ist SFD (D8))"
-#~ msgid ""
-#~ "Sorry, if any of the following options are set:\n"
-#~ "    basin, stream, half.basin, length.slope, or slope.steepness\n"
-#~ "    you MUST provide a value for the basin threshold parameter."
-#~ msgstr ""
-#~ "Wenn eine der folgenden Optionen gesetzt wurde:\n"
-#~ "    basin, stream, half.basin, slope oder slope.steepness\n"
-#~ "    MÜSSEN Sie ein Wert für den Parameter 'basin threshold' angegeben."
-#~ msgid "unable to open new accum map layer."
-#~ msgstr "Kann neue accum-Karte nicht öffnen."
-#~ msgid "Close failed."
-#~ msgstr "Schließen fehlgeschlagen."
-#~ msgid "unable to open new aspect map layer."
-#~ msgstr "Kann die neue Expositionskarte nicht öffnen."
-#~ msgid "unable to open new LS factor map layer."
-#~ msgstr "Kann neue LS-Faktor Karte nicht öffnen."
-#~ msgid "unable to open new slope length map layer."
-#~ msgstr "Kann neue slope-length-Karte nicht öffnen."
-#~ msgid "unable to open new S factor map layer."
-#~ msgstr "Kann neue S-Faktor Karte nicht öffnen."
-#~ msgid ""
-#~ "USAGE for basin delineation:\n"
-#~ "%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
-#~ "\n"
-#~ "USAGE for ARMSED FILE creation:\n"
-#~ "%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] ha=half_basin_map ar=ARMSED_file_name\n"
-#~ "\n"
-#~ "USAGE for slope length determination:\n"
-#~ "%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
-#~ msgstr ""
-#~ "VERWENDUNG für Einzugsgebietskartierung:\n"
-#~ "\n"
-#~ "VERWENDUNG für ARMSED-Datei Erzeugung:\n"
-#~ "\n"
-#~ "VERWENDUNG für Hanglängenberechnung:\n"
-#~ msgid "SECTION 2: A * Search."
-#~ msgstr "ABSCHNITT 2: A * Suche."
-#~ msgid "unable to open elevation map layer"
-#~ msgstr "Kann die elevation-Karte nicht öffnen."
-#~ msgid "unable to open runoff map layer"
-#~ msgstr "Kann die runoff-Karte nicht öffnen."
-#~ msgid "unable to open depression map layer"
-#~ msgstr "Kann die depression-Karte nicht öffnen."
-#~ msgid "unable to open blocking map layer"
-#~ msgstr "Kann die blocking-Karte nicht öffnen."
-#~ msgid "unable to open rill map layer"
-#~ msgstr "Kann die rill-Karte nicht öffnen."
-#~ msgid "unable to open flow accumulation map layer"
-#~ msgstr "Kann neue Fluss-Akkumulations-Karte nicht öffnen."
-#~ msgid "Maximum memory to be used was smaller than 3 MB, set to default = 300 MB."
-#~ msgstr "Maximal verwendbarer Speicher war kleiner als 3 MB; Setze es auf den Standardwert 300 MB."
-#~ msgid "unable to open accum file in valid_basins()"
-#~ msgstr "Kann die accum-Datei in valid_basins() nicht öffnen."
-#~ msgid "raster, DEM, fractal"
-#~ msgstr "Raster, DGM, Fraktale"
-#~ msgid "Quietly"
-#~ msgstr "ruhig"
-#~ msgid "Error writing category file for <%s>"
-#~ msgstr "Fehler beim Schreiben der Kategorie-Datei für <%s>."
-#~ msgid "Error writing color file for <%s>"
-#~ msgstr "Fehler beim Schreiben der Farb-Datei für <%s>."
-#~ msgid "raster, projection, transformation"
-#~ msgstr "Raster, Projektion, Transformation"
-#~ msgid "Re-projects a raster map from one location to the current location."
-#~ msgstr "Reprojiziert eine Rasterkarte von einer Location in die aktuelle Location."
-#~ msgid "Resolution of output map"
-#~ msgstr "Auflösung der Ausgabe-Karte"
-#~ msgid "Raster File Series to MPEG Conversion."
-#~ msgstr "Konvertiert Folgen von Rasterkarten zu einem MPEG-Film."
-#~ msgid "Raster file(s) for View%d"
-#~ msgstr "Rasterkarte(n) für View%d"
-#~ msgid "Quiet - suppress progress report"
-#~ msgstr "schweigsam - unterdrücke Progressreport"
-#~ msgid ""
-#~ "Convert on the fly, use less disk space\n"
-#~ "\t(requires r.out.ppm with stdout option)"
-#~ msgstr ""
-#~ "Konvertiere direkt, benutze wenig Festplattenplatz\n"
-#~ "\t(benötigt r.out.ppm mit stdout-Option)"
-#~ msgid "Name of existing raster map containing elevation surface"
-#~ msgstr "Name einer existierenden Rasterkarte mit Höheninformationen."
-#~ msgid "Output elevation raster map after filling"
-#~ msgstr "Ausgabehöhenkarte nach dem Füllen"
-#~ msgid "Output direction raster map"
-#~ msgstr "Name der Ausgabe-Rasterkarte, der Fließrichtungen."
-#~ msgid "Output raster map of problem areas"
-#~ msgstr "Name der Ausgabe-Rasterkarte mit Problemflächen."
-#~ msgid "Output aspect direction format (agnps, answers, or grass)"
-#~ msgstr "Ausgabeformat der Expositionsrichtung (agnps, answers oder grass)."
-#~ msgid "Reading map..."
-#~ msgstr "Lese Karte..."
-#~ msgid "Unable to write color table for %s"
-#~ msgstr "Kann die Farbtabelle für %s nicht schreiben."
-#~ msgid "Cannot read ew_res value"
-#~ msgstr "Kann die EW-Auflösung (ew_res) nicht lesen."
-#~ msgid "Cannot read ns_res value"
-#~ msgstr "Kann die NS-Auflösung (ns_res) nicht lesen."
-#~ msgid "[%s]: Map is the wrong resolution"
-#~ msgstr "[%s]: Karte hat die falsche Auflösung."
-#~ msgid "Cannot get row %d (error = %d)"
-#~ msgstr "Kann die Zeile %d (Fehler = %d) nicht bekommen."
-#~ msgid "Cannot set region to back to the initial region !!!"
-#~ msgstr "Kann die Region nicht mehr zur Ursprungsregion zurücksetzen!!!"
-#~ msgid "Not enough memory for zero_array_cell"
-#~ msgstr "Nicht genügend Speicher für zero_array_cell."
-#~ msgid "Not enough disk space -- cannot write files"
-#~ msgstr "Nicht genügend Speicher auf der Festplatte frei - kann die Dateien nicht schreiben."
-#~ msgid "raster, statistics, reclass"
-#~ msgstr "Raster, Statistik, Reklassifizieren"
-#~ msgid "Title, in quotes"
-#~ msgstr "Titel, in Gänsefüßchen"
-#~ msgid "Unable to read raster map row %d "
-#~ msgid "Failed writing raster map row %d"
-#~ msgstr "Schreiben der Zeile %d der Rasterkarte fehlgeschlagen."
-#~ msgid "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel resolution of the currently defined region."
-#~ msgstr "Exportiere GRASS Rasterkarte in ein 8/24 bit TIFF-Bild. Die Pixelauflösung wird aus der aktuellen Region-Einstellung übernommen."
-#~ msgid "Unable to read header of raster map <%s>"
-#~ msgstr "Kann den Header der Rasterkarte <%s> nicht lesen."
-#~ msgid "Can't set window"
-#~ msgstr "Kann das Fenster nicht setzen."
-#~ msgid "Raster map <%s> in mapset <%s> is a floating point map. Decimal values will be rounded to integer!"
-#~ msgstr "Die Rasterkarte <%s> im Mapset <%s> ist eine Fließkommakarte. Nachkommastellen werden auf ganze Zahlen gerundet!"
-#~ msgid "raster, import, LIDAR"
-#~ msgstr "Raster, Import, LIDAR"
-#~ msgid "Writing map, row %d"
-#~ msgstr "Schreibe Karte, Zeile %d."
-#~ msgid "Surface generation program from rasterized contours."
-#~ msgstr "Erzeugt eine Rasteroberfläche aus gerasterten Konturlinien mit Höheninformationen."
-#~ msgid "Name of existing raster map containing contours"
-#~ msgstr "Name der existierenden Rasterkarte, die Konturlinien enthält."
-#~ msgid "Output elevation raster map"
-#~ msgstr "Name der Ausgabe-Rasterkarte, die Höheninformationen enthält."
-#~ msgid "Unused; retained for compatibility purposes, will be removed in future"
-#~ msgstr "Unbenutzt; nur noch zu Kompatibilitätszwecken vorhanden. Diese Feature wird in der Zukunft entfernt."
-#~ msgid "Invoke slow, but memory frugal operation (generally not needed, will be removed in future)"
-#~ msgstr "Rufe langsame aber speicherschonende Operation auf (im Allgemeinen nicht benötigt, wird in Zukunft entfernt)."
-#~ msgid "raster, color table"
-#~ msgstr "Raster, Farbtabellen"
-#~ msgid "Creates/modifies the color table associated with a raster map layer."
-#~ msgstr "Erzeugt/verändert die Farbtabelle einer Rasterkarte."
-#~ msgid "Raster map name from which to copy color table"
-#~ msgstr "Rasterkarte, von der die Farbtabelle kopiert werden soll."
-#~ msgid "Path to rules file (\"-\" to read rules from stdin)"
-#~ msgstr "Pfad zur Datei mit Regeln (\"-\" um Regeln von stdin zu lesen)."
-#~ msgid "Enter rules interactively"
-#~ msgstr "Gebe Regeln interaktive ein"
-#~ msgid "One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be specified!"
-#~ msgstr "Entweder \"-i\" oder \"-r\" oder eine der Optionen \"color\", \"rast\" oder \"rules\" muss angegeben werden!"
-#~ msgid "Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" options"
-#~ msgstr "Der interaktive Modus ist inkompatibel mit den Optionen \"color\", \"rules\" und \"raster\"."
-#~ msgid "Resultant raster map (not used with 'distribution')"
-#~ msgstr "Resultierende Rasterkarte (wird nicht benutzt, wenn Methode 'Verteilung' gewählt wurde)."
-#~ msgid "Output map <%s> ignored"
-#~ msgstr "Ausgabekarte <%s> ignoriert."
-#~ msgid "Not yet implemented!"
-#~ msgstr "Noch nicht implementiert."
-#~ msgid "An output raster map needs to be defined with method '%s'"
-#~ msgstr "Eine Ausgabe-Rasterkarte muss mit der Methode '%s' definiert werden."
-#~ msgid "%s: running %s command"
-#~ msgstr "%s: verarbeite %s Anweisung"
-#~ msgid "raster, landscape structure analysis, diversity index"
-#~ msgstr "Raster, Landschaftsstruktur Analyse, Diversitäts-Index"
-#~ msgid "raster, landscape structure analysis, dominance index"
-#~ msgstr "Raster, Landschaftsstruktur Analyse, Dominanz-Index"
-#~ msgid "CHILD[pid = %i] cannot open raster map"
-#~ msgstr "CHILD[pid = %i] kann Rasterkarte nicht öffnen."
-#~ msgid "CHILD[pid = %i] cannot open receive channel"
-#~ msgstr "CHILD[pid = %i] kann den Empfangskanal nicht öffnen."
-#~ msgid "CHILD[pid = %i]: unable to open <%s> mask ... continuing without!"
-#~ msgstr "CHILD[pid = %i]: kann %s Maske nicht öffnen ... mache ohne weiter !"
-#~ msgid ""
-#~ "\t\t\t\tAREA MESSAGE: \n"
-#~ " \t\t\t\taid = %i \n"
-#~ " \t\t\t\tx = %i \n"
-#~ " \t\t\t\ty = %i \n"
-#~ " \t\t\t\trl = %i \n"
-#~ " \t\t\t\tcl = %i \n"
-#~ msgstr ""
-#~ "\t\t\t\tFLÄCHEN MELDUNG: \n"
-#~ msgid ""
-#~ " \t\t\t\tMASKEDAREA MESSAGE: \n"
-#~ " \t\t\t\tmask = %s \n"
-#~ msgstr ""
-#~ " \t\t\t\tMASKIERTE FLÄCHEN MELDUNG: \n"
-#~ msgid ""
-#~ " \t\t\t\tDONE MESSAGE: \n"
-#~ " \t\t\t\tpid = %i \n"
-#~ " \t\t\t\tresult = %f \n"
-#~ msgstr ""
-#~ " \t\t\t\tERLEDIGT MELDUNG: \n"
-#~ msgid ""
-#~ " \t\t\t\tERROR MESSAGE: \n"
-#~ msgstr ""
-#~ " \t\t\t\tFEHLER MELDUNG: \n"
-#~ msgid ""
-#~ " \t\t\t\tTERM MESSAGE: \n"
-#~ msgstr ""
-#~ " \t\t\t\tSCHLUSS MELDUNG: \n"
-#~ msgid "Error in pipe creation"
-#~ msgstr "Fehler beim Erzeugen der Weiterleitung."
-#~ msgid "Error opening channel %i"
-#~ msgstr "Fehler beim Öffnen des Kanals %i."
-#~ msgid "Cannot create %s/.r.li/ directory"
-#~ msgstr "Kann das Verzeichnis %s/.r.li/ nicht erzeugen."
-#~ msgid "Cannot create %s/.r.li/output/ directory"
-#~ msgstr "Kann das Verzeichnis %s/.r.li/output/ nicht erzeugen."
-#~ msgid "r.li.worker (pid %i) exited with abnormal status: %i"
-#~ msgstr "r.li.worker (pid %i) abgebrochen mit Status %i"
-#~ msgid "r.li.worker (pid %i) terminated successfully"
-#~ msgstr "r.li.worker (pid %i) erfolgreich beendet."
-#~ msgid "Cannot close %s file (PIPE)"
-#~ msgstr "Kann Datei %s (PIPE) nicht schließen."
-#~ msgid "Cannot delete %s file (PIPE)"
-#~ msgstr "Kann Datei %s (PIPE) nicht löschen."
-#~ msgid "Cannot close %s file (PIPE2)"
-#~ msgstr "Kann Datei %s (PIPE2) nicht schließen."
-#~ msgid "Cannot delete %s file (PIPE2)"
-#~ msgstr "Kann Datei %s (PIPE2) nicht löschen."
-#~ msgid "Cannot close receive channel file"
-#~ msgstr "Kann Empfangskanal nicht schließen."
-#~ msgid "Cannot delete %s file"
-#~ msgstr "Kann Datei %s nicht löschen."
-#~ msgid "Cannot read raster header file"
-#~ msgstr "Kann Header der Rasterkarte nicht lesen."
-#~ msgid "GIS format to write (case sensitive, see also -l flag)"
-#~ msgstr "GIS Format, dass ausgegeben werden soll (Gross- und Kleinschreibung beachten, siehe auch den Schalter -l)."
-#~ msgid "File type"
-#~ msgstr "Dateityp"
-#~ msgid "Output file name not specified"
-#~ msgstr "Name der Ausgabedatei nicht angegeben."
-#~ msgid "Exporting to GDAL raster"
-#~ msgstr "Exportiere nach GDAL-Raster."
-#~ msgid "Range to be exported: %f - %f"
-#~ msgstr "Zu exportierender Wertebereich: %f - %f"
-#~ msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %f gets converted to %d by selected GDAL datatype."
-#~ msgstr "NoData-Wert der Metadaten und der tatsächlichen Werte in den exportierten Rasterdaten stimmen nicht überein: Der angegebene NoData-Wert %f wird von dem gewählten GDAL-Datentyp nach %d konvertiert."
-#~ msgid "Input raster map contains cells with NULL-value (no-data). The value %f will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
-#~ msgstr "Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert %f wurde verwendet um Nodata-Werte in der Eingabekarte zu kennzeichnen. Sie können Nodata-Wert mit dem Parameter %s bestimmen."
-#~ msgid "raster, null data"
-#~ msgstr "Raster, NULL-Werte"
-#~ msgid "Error writing null row %d"
-#~ msgstr "Fehler beim Schreiben der NULL-Zeile %d."
-#~ msgid "raster, export, VRML"
-#~ msgstr "Raster, Export, VRML"
-#~ msgid "Export a raster map to the Virtual Reality Modeling Language (VRML)"
-#~ msgstr "Exportiere eine Rasterkarte in die Virtual Reality Modeling Language (VRML)."
-#~ msgid "Rowio_setup failed"
-#~ msgstr "Rowio_setup fehlgeschlagen"
-#~ msgid "Rowio_get failed"
-#~ msgstr "Rowio_get fehlgeschlagen"
-#~ msgid "Unable to open raster map <%s@%s>"
-#~ msgstr "Kann die Rasterkarte <%s@%s> nicht öffnen."
-#~ msgid "Failed writing raster map row"
-#~ msgstr "Schreiben der Zeile der Rasterkarte fehlgeschlagen."
-#~ msgid "Generates a raster map layer of distance to features in input layer."
-#~ msgstr "Erzeugt eine Rasterkarte mit Distanzen zu Featuren in der Eingabekarte."
-#~ msgid "Unable to create distance map <%s>"
-#~ msgstr "Kann die Distanz-Karte <%s> nicht erzeugen."
-#~ msgid "Unable to create value map <%s>"
-#~ msgstr "Kann die Wert-Karte <%s> nicht erzeugen."
-#~ msgid "(i)   Basin map created by r.water.outlet (MASK)"
-#~ msgstr "(i)   Einzugsgebietskarte wurde von r.water.outlet (MASK) erstellt."
-#~ msgid "(i)   Elevation map"
-#~ msgstr "(i)   Höhenkarte"
-#~ msgid "(o)   Depressionless elevation map"
-#~ msgstr "(o)   Senkenloses Höhenmodell"
-#~ msgid "(o)   Direction map for depressionless elevation map"
-#~ msgstr "(o)   Richtungskarte für abflusslose Höhenkarte."
-#~ msgid "(o/i) Basin elevation map (MASK applied)"
-#~ msgstr "(o/i) Höhenkarte des Einzugsgebiets (mit angewandter Maske (MASK))."
-#~ msgid "(o)   Topographic index ln(a/tanB) map (MASK applied)"
-#~ msgstr "(o)   Karte des Topographischen Index ln(a/tanB) (mit angewandter Maske (MASK))."
-#~ msgid "(i)   Number of topographic index classes"
-#~ msgstr "(i)   Anzahl der Klassen des Topgraphischen Indexes."
-#~ msgid "(o/i) Topographic index statistics file"
-#~ msgstr "(i/o) Statistik-Datei des Topographischen Indexes."
-#~ msgid "(i)   TOPMODEL Parameters file"
-#~ msgstr "(i)   Parameterdatei für TOPMODEL"
-#~ msgid "(i)   Rainfall and potential evapotranspiration data file"
-#~ msgstr "(i)    Datei mir Niederschlag und potentieller Evapotranspiration."
-#~ msgid "(o)   Output file"
-#~ msgstr "(o)   Ausgabedatei"
-#~ msgid "(i)   OPTIONAL Observed flow file"
-#~ msgstr "(i)   OPTIONALE obersvierter Fließdata."
-#~ msgid "(i)   OPTIONAL Output for given time step"
-#~ msgstr "(i)   OPTIONAL: Ausgabe für einen angegebenen Zeitabschnitt."
-#~ msgid "(i)   OPTIONAL Output for given topographic index class"
-#~ msgstr "(i)   OPTIONAL: Ausgabe für die angegebene Klasse des topgraphischen Index."
-#~ msgid "raster, sun position"
-#~ msgstr "Raster, Sonnenposition"
-#~ msgid "Verbose output (also print out sun position etc.)"
-#~ msgstr "Ausführliche Ausgabe (gibt auch die Sonnenposition etc. aus)."
-#~ msgid "raster, random, surface"
-#~ msgstr "Raster, Zufall, Oberfläche"
-#~ msgid "Unable to write color table for raster map <%s>"
-#~ msgstr "Kann die Farbtabelle der Rasterkarte <%s> nicht schreiben."
-#~ msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default: random)"
-#~ msgstr "Zufälliger Startwert (SEED_MIN >= Wert >= SEED_MAX) (Standard: zufällig)."
-#~ msgid "No (quiet) description during run"
-#~ msgstr "Keine Beschreibung während der Bearbeitung."
-#~ msgid "<%s> is an ilegal name"
-#~ msgstr "<%s> ist ein ungültiger Name."
-#~ msgid "raster, thin"
-#~ msgstr "Raster, Ausdünnung"
-#~ msgid "Thins non-zero cells that denote linear features in a raster map."
-#~ msgstr "Dünnt Zellen die nicht null sind und linienhafte Strukturen in einer Rasterkarte abbilden."
-#~ msgid "%s: Error reading from raster map <%s> in mapset <%s>"
-#~ msgstr "%s: Fehler beim Lesen der Rasterkarte <%s> im Mapset <%s>."
-#~ msgid "Creates a new map layer whose category values are based upon a reclassification of the categories in an existing raster map layer."
-#~ msgstr "Erzeugt eine neue Karte, deren Kategoriewerte auf einer Reklassifikation der Kategorien einer existierenden Rasterkarte basieren."
-#~ msgid "Raster map to be reclassified"
-#~ msgstr "Rasterkarte, die neu klassifiziert werden soll."
-#~ msgid "fp: Data range is %.25f to %.25f\n"
-#~ msgstr "fp: Datenspanne reicht von %.25f bis %.25f\n"
-#~ msgid "Cannot create category file of <%s>"
-#~ msgstr "Kann die Kategorie-Datei von <%s> nicht erzeugen."
-#~ msgid "raster, metadata, timestamp"
-#~ msgstr "Raster, Metadaten, Zeitstempel"
-#~ msgid "raster, conversion, vectorization"
-#~ msgstr "Raster, Konvertieren, Vektorisieren"
-#~ msgid "Converts a raster map into a vector map layer."
-#~ msgstr "Konvertiert eine Rasterkarte in eine Vektorkarte."
-#~ msgid "Do not build vector topology (use with care for massive point export)"
-#~ msgstr "Erzeuge keine Vektor-Topologie (Vorsichtig einsetzen für den Export von extrem großen Punktmengen)."
-#~ msgid "Quiet - Do not show progress"
-#~ msgstr "Schweigsam - keinen Fortschritt anzeigen."
-#~ msgid "raster, category"
-#~ msgstr "Raster, Kategorie"
-#~ msgid "Cannot create category file for <%s>"
-#~ msgid "Cannot read header of raster map <%s> in <%s>"
-#~ msgstr "Kann den Header der Rasterkarte <%s> in <%s> nicht lesen."
-#~ msgid "Cannot open cell file of raster map <%s> in <%s>"
-#~ msgstr "Kann die Zelldatei der Rasterkarte <%s> in <%s> nicht öffnen."
-#~ msgid "Illegal output file name <%s>"
-#~ msgstr "Ungültiger Ausgabe-Dateiname<%s>."
-#~ msgid "GIS Coincidence Tabulation Facility\n"
-#~ msgstr "GIS Koinzidenz-Tabellierungsanlage\n"
-#~ msgid "This utility will allow you to compare the coincidence of two map layers\n"
-#~ msgstr "Dieses Dienstprogramm ermöglicht Ihnen die Koinzidenz zweier Karten zu vergleichen\n"
-#~ msgid "The report can be made in one of 8 units."
-#~ msgstr "DerBericht kann in einer von 8 Einheiten erstellt werden."
-#~ msgid "Please choose a unit by entering one of the following letter codes:"
-#~ msgstr "Bitte wählen Sie eine Einheit durch Eingabe eines der folgenden Buchstaben:"
-#~ msgid "     'c': cells"
-#~ msgstr "     'c': Zellen"
-#~ msgid "     'p': percent cover of region"
-#~ msgstr "     'p': Prozent Deckung der Region"
-#~ msgid "     'x': percent of '%s' category (column)"
-#~ msgstr "     'x': Prozent der '%s' Kategorie (Spalte)"
-#~ msgid "     'y': percent of '%s' category (row)"
-#~ msgstr "     'y': Prozent der '%s' Kategorie (Zeile)"
-#~ msgid "     'a': acres"
-#~ msgstr "     'a': Acres"
-#~ msgid "     'h': hectares"
-#~ msgstr "     'h': Hektar"
-#~ msgid "     'k': square kilometers"
-#~ msgstr "     'k': Quadratkilometer"
-#~ msgid "     'm': square miles\n"
-#~ msgstr "     'm': Quadratmeilen\n"
-#~ msgid "     'Q': quit"
-#~ msgstr "     'Q': Beenden"
-#~ msgid "Do you wish to save this report in a file? (y/n) [n] "
-#~ msgstr "Möchten Sie diesen Bericht in einer Datei speichern? (y/n) [n] "
-#~ msgid ""
-#~ "Enter the file name or path\n"
-#~ msgstr ""
-#~ "Geben Sie den Dateinamen oder Pfad ein\n"
-#~ msgid "'%s' being saved\n"
-#~ msgstr "'%s' wird gespeichert\n"
-#~ msgid "Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
-#~ msgstr "Möchten Sie diesen Bericht drucken (benötigt den Unix lpr-Befehl)? (y/n) [n] "
-#~ msgid ""
-#~ "Do you wish it printed in 80 or 132 columns?\n"
-#~ msgstr ""
-#~ "Möchten Sie die Ausgabe in 80 oder 132 Spalten?\n"
-#~ msgid "Do you wish to run this report with a different unit of measure? (y/n) [y] "
-#~ msgstr "Möchten Sie diesen Bericht mit einer anderen Maßeinheit? (y/n) [y] "
-#~ msgid "Watershed basin creation program."
-#~ msgstr "Modul zur Berechnung von Wassereinzugsgebieten."
-#~ msgid "The map E grid coordinates"
-#~ msgstr "Ost Koordinaten des Austrittspunkts"
-#~ msgid "The map N grid coordinates"
-#~ msgstr "Nord Koordinaten des Austrittspunkts"
-#~ msgid "Unable to open drainage pointer map"
-#~ msgstr "Kann die Abflußkarte nicht öffnen."
-#~ msgid "Unable to open new basin map"
-#~ msgstr "Kann neue Einzugsgebietskarte nicht öffnen."
-#~ msgid "Unable to close new basin map layer"
-#~ msgstr "Kann neue Einzugsgebietskarte nicht schließen."
-#~ msgid "Could not read east bufferzone size. Aborting."
-#~ msgstr "Konnte die Ost-Bufferzonengröße nicht lesen. Breche ab."
-#~ msgid "Could not read west bufferzone size. Aborting."
-#~ msgstr "Konnte die West-Bufferzonengröße nicht lesen. Breche ab."
-#~ msgid "Could not read south bufferzone size. Aborting."
-#~ msgstr "Konnte die Süd-Bufferzonengröße nicht lesen. Breche ab."
-#~ msgid "Could not read north bufferzone size. Aborting."
-#~ msgstr "Konnte die Nord-Bufferzonengröße nicht lesen. Breche ab."
-#~ msgid "Calculating map %01d of %01d (angle %lf, raster map <%s>)"
-#~ msgstr "Berechne Karte %01d von %01d (Winkel %lf, Rasterkarte <%s>)."
-#~ msgid "Unable to write quant file"
-#~ msgstr "Kann die quant Datei nicht schreiben."
-#~ msgid "Link GDAL supported raster file to a binary raster map layer."
-#~ msgstr "Verbinde GDAL-unterstützt Rasterdaten mit einer Rasterkarte."
-#~ msgid "Error reading input"
-#~ msgstr "Fehler beim Lesen der Eingabe."
-#~ msgid "raster, recode category"
-#~ msgstr "Raster, Rekodieren der Kategorien"
-#~ msgid "Data range of raster map <%s> is empty"
-#~ msgstr "Wertebereich der Rasterkarte <%s> ist leer."
-#~ msgid "Data range of raster map <%s> is %s to %s (entire map)"
-#~ msgstr "Wertebereich der Rasterkarte <%s> reicht von %s bis %s (komplette Karte)."
-#~ msgid "Integer data range of raster map <%s> is empty"
-#~ msgstr "Integer Wertebereich der Rasterkarte <%s> ist leer."
-#~ msgid "Integer data range of raster mao <%s> is %d to %d"
-#~ msgstr "Integer Wertebereich der Rasterkarte <%s> reicht von %d bis %d."
-#~ msgid "'%s' is not a valid rule"
-#~ msgstr "'%s' ist keine gültige Regel"
-#~ msgid "raster, volume"
-#~ msgstr "Raster, Volumen"
-#~ msgid "No clump map specified and MASK not set."
-#~ msgstr "Keine Klumpen-Karte angegeben. Außerdem ist die Maske (MASK) nicht gesetzt."
-#~ msgid "Unable to find data map"
-#~ msgstr "Kann die Rasterkarte nicht finden."
-#~ msgid "Unable to find clump map"
-#~ msgstr "Kann die Rasterkarte mit Klumpen nicht finden."
-#~ msgid "Data or Clump file not open"
-#~ msgstr "Daten- oder Klumpendatei nicht geöffnet."
-#~ msgid "raster, distance"
-#~ msgstr "Raster, Distanz"
-#~ msgid "Name of vector input map containing stream(s)"
-#~ msgstr "Vektoreingabekarte mit dem Flussnetz."
-#~ msgid "Stream width (in meters). Default is raster cell width"
-#~ msgstr "Flussbreite in Meter (Standard ist die Rasterzellenbreite)."
-#~ msgid "%s: cover raster map not found"
-#~ msgstr "%s: Bedeckungs-Rasterkarte nicht gefunden."
-#~ msgid "%s: base map and output map must be different"
-#~ msgstr "%s: Basiskarte und Ausgabekarte müssen unterschiedlich sein."
-#~ msgid "raster, composite"
-#~ msgstr "Raster, Komposite"
-#~ msgid "Error reading raster map <%s>"
-#~ msgstr "Fehler beim Lesen der Rasterkarte <%s>."
-#~ msgid "Failed writing raster map <%s>"
-#~ msgstr "Schreiben der Rasterkarte <%s> ist fehlgeschlagen."
-#~ msgid "Could not get raster row"
-#~ msgstr "Kann die Rasterzeile nicht bekommen."
-#~ msgid "raster, volume, conversion"
-#~ msgstr "Raster, Volumen, Konvertierung"
-#~ msgid "Unable to get current region"
-#~ msgstr "Kann die aktuelle Region nicht bekommen."
-#~ msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)."
-#~ msgstr "Erzeugt Hangkurven (flowlines), Fließlängen und Flussdichte (upslope areas) aus einem angegebenen digitalen Höhenmodell (DEM)."
-#~ msgid "Input elevation raster map"
-#~ msgstr "Eingabe-Rasterkarte, mit Höheninformationen"
-#~ msgid "Input aspect raster map"
-#~ msgstr "Eingabe-Rasterkarte mit Expositionen."
-#~ msgid "Input barrier raster map"
-#~ msgstr "Eingabe-Rasterkarte mit den Barrieren"
-#~ msgid "Output flowline vector map"
-#~ msgstr "Ausgabekarte der Fließlinen (Vektor)"
-#~ msgid "Output flowpath length raster map"
-#~ msgstr "Ausgabe-Rasterkarte, der Hanglänge."
-#~ msgid "Output flowline density raster map"
-#~ msgstr "Ausgabe-Rasterkarte der Fließdichte."
-#~ msgid "3-D lengths instead of 2-D"
-#~ msgstr "3D-Länge anstelle von 2D."
-#~ msgid "Cannot reset current region"
-#~ msgstr "Kann die aktuelle Region nicht zurücksetzen."
-#~ msgid "raster, querying"
-#~ msgstr "Raster, Abfrage"
-#~ msgid "raster, import, conversion"
-#~ msgstr "Raster, Import, Konvertierung"
-#~ msgid "Converts ASCII raster file to binary raster map layer."
-#~ msgstr "Konvertiert eine ASCII-Rasterdatei in eine (binäre) GRASS Rasterkarte."
-#~ msgid "%s: can only do up to %d raster maps, sorry\n"
-#~ msgstr "%s: Kann nur bis zu %d Rasterkarten abfragen, sorry\n"
-#~ msgid "Sums up the raster cell values."
-#~ msgstr "Summierert die Rasterzellenwerte auf."
-#~ msgid "Name of incidence or density file."
-#~ msgstr "Name der Häufigkeits- oder Dichtedatei."
-#~ msgid "raster, random, cell"
-#~ msgstr "Raster, Zufall, Zelle"
-#~ msgid "Input elevation map"
-#~ msgstr "Eingabekarte, die Höheninformationen enthält."
-#~ msgid "Output topographic index map"
-#~ msgstr "Ausgabekarte mit topographischem Index"
-#~ msgid "Reading row %d"
-#~ msgstr "Lese Zeile %d."
-#~ msgid "Slower but accurate (applies to FP maps only"
-#~ msgstr "Langsamer aber genau (gilt nur für Fließkomma-Karten)"
-#~ msgid "Unable to read header of raster map <%s@%s>"
-#~ msgstr "Kann den Header der Rasterkarte <%s@%s> nicht lesen."
-#~ msgid "Unable to read region <%s> in <%s>"
-#~ msgstr "Kann Region <%s> in <%s> nicht lesen."
-#~ msgid "Unable to open vector map <%s> in <%s>"
-#~ msgstr "Kann die Vektorkarte <%s> in <%s> nicht öffnen."
-#~ msgid "Invalid region: %s"
-#~ msgstr "Ungültige Region: %s."
-#~ msgid "Writing raster map, row %d"
-#~ msgstr "Schreibe Rasterkarte, Zeile %d."
-#~ msgid "Lat/Long location is not supported"
-#~ msgstr "Lat/Long Location wird nicht unterstützt"
-#~ msgid "Cannot write category file for raster map <%s>"
-#~ msgstr "Kann die Kategorie-Datei der Rasterkarte <%s> nicht schreiben."
-#~ msgid "raster, geomorphology"
-#~ msgstr "Raster, Geomorphologie"
-#~ msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster map layer."
-#~ msgstr "Konvertiert ein ESRI ARC/INFO ascii Raster-Datei (GRID) in eine (binäre) GRASS Rasterkarte."
-#~ msgid "File containing weights"
-#~ msgstr "Datei die Gewichte enthält."
-#~ msgid "Unable to write to <%s>"
-#~ msgstr "Kann nicht in <%s> schreiben."
-#~ msgid "general, version"
-#~ msgstr "Allgemein, Version"
-#~ msgid "general, map management"
-#~ msgstr "Allgemein, Kartenverwaltung"
-#~ msgid "Copies available data files in the user's current mapset search path and location to the appropriate element directories under the user's current mapset."
-#~ msgstr "Kopiert die vorhandenen Daten in die aktuelle Mapset/Location."
-#~ msgid "%s file(s) to be copied"
-#~ msgstr "%s Dateien müssen kopiert werden."
-#~ msgid "[%s@%s] is a base map for [%s]. Remove forced."
-#~ msgstr "[%s@%s] ist die Ausgangskarte für [%s]. Löschen wurde erzwungen."
-#~ msgid "[%s@%s] is a base map. Remove reclassed map first: %s"
-#~ msgstr "[%s@%s] ist eine Ausgangskarte. Lösche zuerst die reklassifizierte Karte: %s"
-#~ msgid "%s file(s) to be removed"
-#~ msgstr "%s Datei(en), die entfernt werden sollen."
-#~ msgid "Mapset to list (default: current search path)"
-#~ msgstr "Aufzulistendes Mapset (Standard: aktueller Suchpfad)."
-#~ msgid "%s file(s) to be renamed"
-#~ msgstr "%s Datei(en) sollen umbenannt werden."
-#~ msgid "general, projection"
-#~ msgstr "Allgemein, Projektionen"
-#~ msgid "Enable interactive prompting (for command-line use only)"
-#~ msgstr "Aktivieren Sie die interaktive Nachfrage (nur bei Verwendung der Befehlszeile)."
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "WARNING!  A projection file already exists for this location\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "WARNUNG! Eine Projektionsinformation für diese Location existiert bereits!\n"
-#~ msgid "Would you still like to overwrite the current projection information "
-#~ msgstr "Wollen sie wirklich die aktuelle Projektionsinformation überschreiben?"
-#~ msgid "Error writing PROJ_INFO"
-#~ msgstr "Fehler beim Schreiben der Datei PROJ_INFO."
-#~ msgid "Error writing PROJ_UNITS"
-#~ msgstr "Fehler beim Schreiben der Datei PROJ_UNITS."
-#~ msgid "The projection information will not be updated."
-#~ msgstr "Die Projektionsinformationen werden nicht aktualisiert."
-#~ msgid "general, gui"
-#~ msgstr "Allgemein, GUI"
-#~ msgid "general, scripts"
-#~ msgstr "Allgemein, Skripte"
-#~ msgid "general, transformation, GCP"
-#~ msgstr "Allgemein, Transformation, GCP"
-#~ msgid "general, settings"
-#~ msgstr "Allgemein, Einstellungen"
-#~ msgid "GIS data directory (full path to the directory where the new location is)"
-#~ msgstr "Neue GISDBASE (vollständiger Pfad zu dem Verzeichnis, in dem sich die neue Location befindet)."
-#~ msgid "Erasing monitors..."
-#~ msgstr "Lösche Monitore... "
-#~ msgid "Your mapset search list:\n"
-#~ msgstr "Ihr Mapset Suchpfad:\n"
-#~ msgid "<%s> not found in mapset list"
-#~ msgstr "<%s> nicht in der Mapset-Liste gefunden."
-#~ msgid "general, settings, search path"
-#~ msgstr "Allgemein, Einstellungen, Suchpfad"
-#~ msgid "** no mapsets **\n"
-#~ msgstr "** keine Mapsets **\n"
-#~ msgid "Unable to compile regular expression %s"
-#~ msgstr "Kann den regulären Ausdruck nicht kompilieren %s"
-#~ msgid ""
-#~ "Format error: <%s>\n"
-#~ "Line: %d\n"
-#~ "%s"
-#~ msgstr ""
-#~ "Formatfehler: <%s>\n"
-#~ "Zeile: %d\n"
-#~ "%s"
-#~ msgid "Removing %s <%s>"
-#~ msgstr "Entferne %s <%s>."
-#~ msgid "couldn't be removed"
-#~ msgstr "konnte nicht entfernt werden."
-#~ msgid "%s: couldn't be removed"
-#~ msgstr "%s: konnte nicht entfernt werden."
-#~ msgid "%s: missing"
-#~ msgstr "%s: fehlt."
-#~ msgid "%s: removed"
-#~ msgstr "%s: gelöscht."
-#~ msgid "<%s> nothing removed"
-#~ msgstr "<%s> nichts gelöscht."
-#~ msgid "-s and -n are mutually exclusive"
-#~ msgstr "-s und -n schließen sich gegenseitig aus."
-#~ msgid "One-character output separator, newline, comma, space, or tab"
-#~ msgstr "Trennzeichen für die Ausgabe, Zeilenumbruch, Komma, Leerzeichen oder Tabulator."
-#~ msgid "Raster map <%s@%s>: %s"
-#~ msgstr "Rasterkarte <%s@%s>: %s"
-#~ msgid "<%s> is an illegal region name"
-#~ msgstr "<%s> ist ein ungültiger Regions-Name."
-#~ msgid "format"
-#~ msgstr "Format"
-#~ msgid "Unable to open raster map <%s> in <%s>"
-#~ msgstr "Kann Rasterkarte <%s> in <%s> nicht öffnen."
-#~ msgid "Could not read from <%s>"
-#~ msgstr "Konnte nicht von <%s> lesen."
-#~ msgid "Default value: GRASS_GUI if defined, otherwise wxpython"
-#~ msgstr "Standardwert: GRASS_GUI wenn definiert, ansonsten wxpython"
-#~ msgid "wxpython;wxPython based GUI - wxGUI;tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);text;command line interface only"
-#~ msgstr "wxpython;wxPython basiertes GUI - wxGUI;tcltk;Tcl/Tk basiertes GUI - GIS Manager (gis.m);oldtcltk;Altes Tcl/Tkbasiertes GUI - Display Manager (d.m);text;Nur Kommandozeile"
-#~ msgid "Name of workspace file"
-#~ msgstr "Name der Workspace-Datei."
-#~ msgid "The old d.m GUI is not available for WinGRASS"
-#~ msgstr "Das alte d.m GUI gibt es nicht für WinGRASS."
-#~ msgid "Name of a mapset"
-#~ msgstr "Name eines Mapsets"
-#~ msgid "display, raster, profile"
-#~ msgstr "Darstellung, Raster, Profil"
-#~ msgid "Interactive profile plotting utility with optional output."
-#~ msgstr "Interaktives Werkzeug zum Zeichnen von Profilen mit optionales Ausgabe."
-#~ msgid "Optional display raster"
-#~ msgstr "optionale Ansichts-Rasterkarte"
-#~ msgid "Output profile data to file(s) with prefix 'name'"
-#~ msgstr "Gebe Profildaten in Datei(en) mit dem Prefix 'name'."
-#~ msgid "Display raster [%s] not found. Using profile raster."
-#~ msgstr "Zu zeigendes Rasterkarte [%s] nicht gefunden. Verwende Profilraster."
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Use mouse to choose action"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Verwenden Sie die Maus, um eine Aktion auszuwählen."
-#~ msgid "Use 'd.frame -e' to remove left over frames"
-#~ msgstr "Benutzen Sie bitte 'd.frame -e' um übrig gebliebene Rahmen zu entfernen."
-#~ msgid "Error opening cell-file"
-#~ msgstr "Fehler beim Öffnen der Zell-Datei."
-#~ msgid "Error reading from cell-file"
-#~ msgstr "Fehler beim Lesen der Zell-Datei."
-#~ msgid "Mysterious window inconsistancy error"
-#~ msgstr "Mysteriöser Fenster-Inkonsistenz Fehler."
-#~ msgid "%s: Couldn't open raster <%s@%s>"
-#~ msgstr "%s: Kann die Rasterkarte <%s@%s> nicht öffnen."
-#~ msgid "%s: Couldn't read color table for <%s@%s>"
-#~ msgstr "%s: Kann die Farbtabelle für <%s@%s> nicht lesen."
-#~ msgid "Error reading raster map"
-#~ msgstr "Fehler beim Lesen der Rasterkarte."
-#~ msgid "one moment ..."
-#~ msgstr "eine Moment..."
-#~ msgid "%s: 'is_null_value()' got NULL pointer!"
-#~ msgstr "%s: 'is_null_value()' got NULL pointer!"
-#~ msgid "%s: 'is_null_value()' got negative column index"
-#~ msgstr "%s: 'is_null_value()' hat einen negativen Spalten-Index."
-#~ msgid "%s: 'is_null_value()' Unknown RASTER_MAP_TYPE '%d'"
-#~ msgstr "%s: 'is_null_value()' Unbekannter RASTER_MAP_TYPE '%d'"
-#~ msgid "display, setup"
-#~ msgstr "Darstellung, Setup"
-#~ msgid "Color for drawing X's (Null values)"
-#~ msgstr "Farbe zum Zeichnen der X (NULL-Werte)."
-#~ msgid "No current window"
-#~ msgstr "Kein aktuelles Fenster."
-#~ msgid "Current window not available"
-#~ msgstr "Aktuelles Fenster ist nicht vorhanden."
-#~ msgid "Setting map window"
-#~ msgstr "Einstellung des Kartenfensters."
-#~ msgid "Current window not settable"
-#~ msgstr "Aktuelles Fenster nicht einstellbar."
-#~ msgid "Getting screen window"
-#~ msgstr "Hole Fenster."
-#~ msgid "No raster map exists in the current window"
-#~ msgstr "Es existiert keine Rasterkarte im aktuellen Fenster. "
-#~ msgid "display, cartography"
-#~ msgstr "Darstellung, Kartographie"
-#~ msgid "Use mouse to interactively place text"
-#~ msgstr "Benutze die Maus zum Interaktiven Platzieren des Maßstabs."
-#~ msgid "Click!\n"
-#~ msgstr "Klick!\n"
-#~ msgid " Left:    Place text here\n"
-#~ msgstr " Links:    Platziere Text hier.\n"
-#~ msgid " Right:   Quit\n"
-#~ msgstr " Rechts:  Beenden\n"
-#~ msgid "Size of grid to be drawn"
-#~ msgstr "Größe des Gitters."
-#~ msgid "Manages display frames on the user's graphics monitor."
-#~ msgstr "Verwaltet Fenster im Grafikfenster des Benutzers."
-#~ msgid "Create a new frame"
-#~ msgstr "Erzeuge ein neues Fenster."
-#~ msgid "Select a frame"
-#~ msgstr "Wählen Sie ein Fenster."
-#~ msgid "Print name of current frame"
-#~ msgstr "Gebe Namen des aktuellen Fensters aus."
-#~ msgid "Print names of all frames"
-#~ msgstr "Gebe Namen aller Fenster aus."
-#~ msgid "List map names displayed in GRASS monitor"
-#~ msgstr "Gebe die Namen aller im GRASS Fenster dargestellten Karten aus."
-#~ msgid "Debugging output"
-#~ msgstr "Debugging Ausgabe"
-#~ msgid "name"
-#~ msgstr "Name"
-#~ msgid "Frame to be created/selected"
-#~ msgstr "Fenster (frame), das erstellt/ausgewählt werden soll."
-#~ msgid "bottom,top,left,right"
-#~ msgstr "unten,oben,links,rechts"
-#~ msgid "Where to place the frame, values in percent (implies -c)"
-#~ msgstr "Wo soll das Fenster platziert werden? Werte in Prozent (impliziert -c)."
-#~ msgid "Error choosing frame [%s]\n"
-#~ msgstr "Fehler beim Wählen des Fensters [%s].\n"
-#~ msgid ""
-#~ "\n"
-#~ "Buttons:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Maustasten:\n"
-#~ msgid "Left:   Select frame\n"
-#~ msgstr "Links:   Fenster selektieren\n"
-#~ msgid "Middle: Keep original frame\n"
-#~ msgstr "Middle: Behalte original Fenster\n"
-#~ msgid "Right:  Accept frame\n"
-#~ msgstr "Rechts:  Akzeptiere Fenster\n"
-#~ msgid "No current frame"
-#~ msgstr "Kein aktueller Frame."
-#~ msgid "Current frame not available"
-#~ msgstr "Aktueller Frame nicht verfügbar."
-#~ msgid "display, distance"
-#~ msgstr "Darstellung, Distanz"
-#~ msgid "display, menu"
-#~ msgstr "Darstellung, Menue"
-#~ msgid "Creates and displays a menu within the active frame on the graphics monitor."
-#~ msgstr "Erzeugt und stellt ein Menü im aktiven Frame des Grafikfensters dar."
-#~ msgid "Sets the color of the menu background"
-#~ msgstr "Bestimmt die Farbe des Menü Hintergrunds."
-#~ msgid "Sets the color of the menu text"
-#~ msgstr "Bestimmt die Farbe für den Menütext."
-#~ msgid "Sets the color dividing lines of text"
-#~ msgstr "Bestimmt die Farbe zum Trennen von Textzeilen."
-#~ msgid "Sets the menu text size (in percent)"
-#~ msgstr "Bestimmt die Menütextgröße (in Prozent)."
-#~ msgid "Menu must contain a title and at least one option"
-#~ msgstr "Das Menü muss mindestens einen Titel und eine Option enthalten."
-#~ msgid "found %d visuals of type TrueColor"
-#~ msgstr "Habe %d Ansichten vom Typ TrueColor gefunden."
-#~ msgid "searching for highest bit depth"
-#~ msgstr "Suche die höchste Bit-Tiefe"
-#~ msgid "selected %d bit depth"
-#~ msgstr "wählte %d Bit-Tiefe"
-#~ msgid "using default visual which is %s"
-#~ msgstr "Verwende Standard-Ansicht %s"
-#~ msgid "Monitor: interactive command in redraw"
-#~ msgstr "Grafikfenster: Interaktives Kommando zum erneuten Zeichnen."
-#~ msgid "Monitor: waitpid: expected %d but got %d"
-#~ msgstr "Grafikfenster: waitpid: erwartete %d, habe aber %d bekommen."
-#~ msgid "Monitor: XGetWMName failed"
-#~ msgstr "Grafikfenster: XGetWMName fehlgeschlagen."
-#~ msgid "Monitor: XGetWMName: bad result"
-#~ msgstr "Grafikfenster: XGetWMName: Schlechtes Ergebnis."
-#~ msgid "Font name or pathname of TTF file"
-#~ msgstr "Name des Fonts oder Pfad zu einer TIFF-Datei."
-#~ msgid "Setting release of FreeType"
-#~ msgstr "Einstellunge des FreeType-Releases"
-#~ msgid "display, map management"
-#~ msgstr "Darstellung, Kartenverwaltung"
-#~ msgid "Prompts the user to select a GRASS data base file from among files displayed in a menu on the graphics monitor."
-#~ msgstr "Bittet den Benutzer eine GRASS Datenbankdatei aus den im Menü präsentierten Dateien im Grafikfenster auszuwählen."
-#~ msgid "Database element, one word description"
-#~ msgstr "Datenbankelement, ein Wort Beschreibung"
-#~ msgid "Short user prompt message"
-#~ msgstr "Kurze Benutzereingabeaufforderung."
-#~ msgid "** no %s files found **\n"
-#~ msgstr "** keine %s Dateien gefunden **\n"
-#~ msgid "Click here to CONTINUE\n"
-#~ msgstr "Klicken Sie hier, um WEITERZUMACHEN\n"
-#~ msgid "display, networking"
-#~ msgstr "Darstellung, Netzwerk"
-#~ msgid ""
-#~ "\n"
-#~ "Mouse Buttons:"
-#~ msgstr ""
-#~ "\n"
-#~ "Maustasten:"
-#~ msgid "Left:   Select From\n"
-#~ msgstr "Links:   Selektiere Von\n"
-#~ msgid "Middle: Select To\n"
-#~ msgstr "Mitte: Selektiere Nach\n"
-#~ msgid ""
-#~ "Right:  Quit\n"
-#~ "\n"
-#~ msgstr ""
-#~ "Rechts:  Beenden\n"
-#~ "\n"
-#~ msgid "No raster or vector map displayed"
-#~ msgstr "Es wird keine Raster- oder Vektorkarte angezeigt."
-#~ msgid "Can't clear current graphics window"
-#~ msgstr "Kann aktuelles Grafikfenster nicht säubern."
-#~ msgid "Cannot use current window"
-#~ msgstr "Kann aktuelles Fenster nicht benutzen."
-#~ msgid "display, metadata"
-#~ msgstr "Anzeige, Metadaten"
-#~ msgid "Display number of colors"
-#~ msgstr "Stelle die Anzahl der Farben dar."
-#~ msgid "Placement as percentage of screen coordinates (0,0 is lower left)"
-#~ msgstr "Platzierung als Prozentsatz der Bildschirmkoordinaten (0,0 ist links unten)."
-#~ msgid "Use mouse to size & place legend"
-#~ msgstr "Benutze Maus zum Plazieren und zur Größeneinstellung der Legende."
-#~ msgid "display, raster, RGB"
-#~ msgstr "Darstellung, Raster, RGB"
-#~ msgid "Overlay (non-null values only)"
-#~ msgstr "Ãœberlagerung (nur nicht-NULL Werte)."
-#~ msgid "Error reading row of data"
-#~ msgstr "Fehler beim Lesen eine Datenzeile."
-#~ msgid "display, position, querying"
-#~ msgstr "Darstellung, Position, Abfrage"
-#~ msgid "Identifies the geographic coordinates associated with point locations in the active frame on the graphics monitor."
-#~ msgstr "Identifiziert geographische Koordinaten an einem gegebenen Punkt im Grafik-Fenster."
-#~ msgid "One mouse click only"
-#~ msgstr "Nur ein Mausklick."
-#~ msgid "Displays the rhumbline joining two user-specified points, in the active frame on the user's graphics monitor."
-#~ msgstr "Stellt im aktiven Grafikfenster eine Linie dar, die zwei vom Benutzer angegebene Punkte verbindet."
-#~ msgid "Generates and displays simple graphics on map layers drawn in the active graphics monitor display frame."
-#~ msgstr "Erzeugt und stellt einfache Grafiken auf Karten im aktiven Grafikfenster dar."
-#~ msgid "Unix file containg graphing instructions, if not given reads from standard input"
-#~ msgstr "Unix-Datei, die Graphik-Instruktionen enthält. Falls diese nicht angegeben ist, wird von der Standardeingabe gelesen."
-#~ msgid "Color to draw with, either a standard GRASS color or R:G:B triplet (separated by colons)"
-#~ msgstr "Farbe, die benutzt werden soll. Entweder GRASS Standardfarben oder R:G:B Tripel (durch Doppelpunkte getrennt)."
-#~ msgid "Use mouse to interactively place scale"
-#~ msgstr "Benutze die Maus zum Interaktiven Plazieren des Maßstabs."
-#~ msgid "The screen coordinates for top-left corner of label ([0,0] is top-left of frame)"
-#~ msgstr "Die Bildschirmkoordinaten für die linke obere Ecke des Labels ([0,0] ist oben links)."
-#~ msgid "display, geometry"
-#~ msgstr "Darstellung, Geometrie"
-#~ msgid "Draws text in the graphics monitor's active display frame using TrueType fonts."
-#~ msgstr "Verwende TrueType-Schriften, um Text im aktiven Rahmen des Graphik-Fensters zu zeichnen."
-#~ msgid "Screen position (percentage, [0,0] is bottom left)"
-#~ msgstr "Koordinaten (in Prozent, [0,0] ist unten links)."
-#~ msgid "Path to TrueType font (including file name)"
-#~ msgstr "Pfad zu den TrueType-Schriften (inklusive Dateiname)"
-#~ msgid "Height of letters (in percent of available frame height)"
-#~ msgstr "Höhe der Buchstaben (in Prozent von der möglichen Rahmenhöhe)."
-#~ msgid "Command mode (Compatibility with d.text)"
-#~ msgstr "Kommando-Modus (kompatibel mit d.text)."
-#~ msgid "Either text or -c should be given"
-#~ msgstr "Entweder text oder '-c' sollte angegeben werden. "
-#~ msgid "Choose only one coordinate system for placement"
-#~ msgstr "Wählen Sie nur ein Koordinatensystem für die Plazierung aus."
-#~ msgid "Invalid font: %s"
-#~ msgstr "Ungültige Schrift: %s"
-#~ msgid "Unable to create face"
-#~ msgstr "Kann kein Face erzeugen."
-#~ msgid "Unable to create text conversion context"
-#~ msgstr "Kann den Textkonvertierungszusammenhang nicht erstellen."
-#~ msgid "Text conversion error"
-#~ msgstr "Fehler beim Konvertieren von Text."
-#~ msgid "Unable to write the temporary file"
-#~ msgstr "Kann die temporäre Datei nicht schreiben."
-#~ msgid "No predefined font"
-#~ msgstr "Keine vordefinierte Schrift gefunden."
-#~ msgid "%s: Unable to read font"
-#~ msgstr "%s: Kann diese Schrift nicht lesen."
-#~ msgid "%s: Unable to read FreeType definition file; use the default"
-#~ msgstr "%s: Kann die FreeType Definitionsdatei nicht lesen; nehme den Standard."
-#~ msgid "%s: No FreeType definition file"
-#~ msgstr "%s: Keine FreeType Definitionsdatei gefunden."
-#~ msgid "%s: Unable to read FreeType definition file"
-#~ msgstr "%s: Kann die FreeType Definitionsdatei nicht lesen."
-#~ msgid "display, color transformation"
-#~ msgstr "Darstellung, Farbtransformation"
-#~ msgid "No current graphics window"
-#~ msgstr "Kein aktuelles Grafikfenster."
-#~ msgid "Current graphics window not available"
-#~ msgid "Error reading hue data"
-#~ msgstr "Fehler beim Lesen der Farbwerte (hue)."
-#~ msgid "Error reading intensity data"
-#~ msgstr "Fehler beim Lesen der Intensitätsdaten (intensity)."
-#~ msgid "Error reading saturation data"
-#~ msgstr "Fehler beim Lesen der Sättigungsdaten (saturation)."
-#~ msgid "Setting graphics window"
-#~ msgstr "Setze das Kartenfenster."
-#~ msgid "Can't set current graphics window"
-#~ msgid "Getting graphics window coordinates"
-#~ msgstr "Hole Koordinaten des Grafikfensters."
-#~ msgid "Rendering method for filled polygons"
-#~ msgstr "Render-Methode für gefüllte Polygone."
-#~ msgid "d;use the display library basic functions (features: polylines);c;use the display library clipping functions (features: clipping);l;use the display library culling functions (features: culling, polylines)"
-#~ msgstr "d;Verwende grundlegende Funktion der Displaybibliothek (Feature: Polylinien);c;Verwende die Clipping-Funkton der Displaybibliothek (Feature: abschneiden);l;Verwende die Culling-Funkton der Displaybibliothek (Feature: Beschneiden, Polylinien)"
-#~ msgid "Invalid rendering method <%s>"
-#~ msgstr "Ungültige Render-Methode <%s>."
-#~ msgid "Creates a list of commands for recreating screen graphics."
-#~ msgstr "Erstelle eine Liste von Kommandos zum Wiederherstellen der Bildschirmgrafik."
-#~ msgid "Name of frame(s) to save"
-#~ msgstr "Name der Rahmen zum speichern."
-#~ msgid "List of object numbers to remove which are displayed after \"#\". -1 for the last object."
-#~ msgstr "Liste der Objektnummer, die entfernt werden sollen, die hinter \"#\" angezeigt werden. -1 steht für das letzte Objekt."
-#~ msgid "List of object numbers to move (\"from\" to \"to\"). remove= option will be done first, if any."
-#~ msgstr "Liste der Objektnummern die verschoben werden sollen. (\"von\" nach \"nach\"). Falls eine Option angegeben wurde, wird remove= als erstes ausgeführt."
-#~ msgid "Save current frame"
-#~ msgstr "Speichere aktuellen Rahmen."
-#~ msgid "Save all the frames"
-#~ msgstr "Speichere alle Rahmen ab."
-#~ msgid "Only map objects without extra header and tailer"
-#~ msgstr "Nur Kartenobjekte ohne extra Kopf und Ende."
-#~ msgid "Unknown item type in pad: %s"
-#~ msgstr "Unbekannter Typ in pad: %s"
-#~ msgid "<%s> is a floating point map. Ignoring [lines] and drawing continuous color ramp"
-#~ msgstr "<%s> ist eine Fließkommakarte. Ignoriere [lines] und zeichne einen kontinuierlichen Farbverlauf."
-#~ msgid "<%s> is a floating point map. Ignoring [cols] and drawing continuous color ramp"
-#~ msgstr "<%s> ist eine Fließkommakarte. Ignoriere [cols] und zeichne einen kontinuierlichen Farbverlauf."
-#~ msgid "R_color file for [%s] not available"
-#~ msgstr "Farbdatei für [%s] nicht vorhanden."
-#~ msgid "Range file for [%s] not available"
-#~ msgstr "Range-Dateien für [%s] nicht vorhanden. "
-#~ msgid "display, vector"
-#~ msgstr "Darstellung, Vektor"
-#~ msgid "display, histogram, statistics"
-#~ msgstr "Darstellung, Histogramm, Statistik"
-#~ msgid "Usage:  %s monitor_name"
-#~ msgstr "Verwendung:  %s Name_des_Grafikfensters"
-#~ msgid "%s: -%c unrecognized option"
-#~ msgstr "%s: -%c unbekannte Option."
-#~ msgid "Usage: %s [-f] monitor_name"
-#~ msgstr "Verwendung:  %s [-f] Name_des_Grafikfensters"
-#~ msgid "Monitor '%s' terminated"
-#~ msgstr "Grafikfenster <%s> beendet."
-#~ msgid "No such monitor as <%s>"
-#~ msgstr "Es gibt das Grafikfenster <%s> nicht."
-#~ msgid "Error - Monitor '%s' in use by another user"
-#~ msgstr "Fehler - Grafikfenster '%s' wird von einem anderen Benutzer verwendet."
-#~ msgid "Error - Locking mechanism failed"
-#~ msgstr "Fehler - Sperrvorrichtung ist fehlgeschlagen."
-#~ msgid "Monitor <%s> in use by another user"
-#~ msgstr "Grafikfenster <%s> wird von einem anderen Benutzer verwendet."
-#~ msgid "Failed testing lock mechanism"
-#~ msgstr "Test des Sperrmechanismus fehlgeschlagen."
-#~ msgid "Usage:  %s [-fv] [name]"
-#~ msgstr "Verwendung:  %s [-fv] [Name]"
-#~ msgid "To establish and control use of a graphics display monitor."
-#~ msgstr "Erzeugt und kontrolliert ein Grafikfenster."
-#~ msgid "Name of graphics monitor to unlock"
-#~ msgstr "Name des Grafikfensters, das entriegelt werden soll."
-#~ msgid "List all monitors (with current status)"
-#~ msgstr "Liste alle Grafikfenster (mit aktuellem Status)."
-#~ msgid "Problem selecting %s. Will try once more"
-#~ msgstr "Probleme beim Auswählen von %s. Einmal versuche ich es noch..."
-#~ msgid "display, paint labels"
-#~ msgstr "Darstellung, Zeichen Label"
-#~ msgid "Enable flashing (slower)"
-#~ msgstr "Aufleuchten anschalten (ist langsamer)."
-#~ msgid " Middle: toggle flash color\n"
-#~ msgstr " Mitte: wechselt zwischen den Farben, die auf dem Bildschirm aufleuchten sollen.\n"
-#~ msgid "value [%.0f,%.0f] out of range [0-100]"
-#~ msgstr "Wert [%.0f,%.0f] außerhalb der Spanne [0-100]"
-#~ msgid "List of categories to be displayed (INT maps)"
-#~ msgstr "Liste der Werte die angezeigt werden sollen (INT-Karten)."
-#~ msgid "List of values to be displayed (FP maps)"
-#~ msgstr "Liste der Werte die angezeigt werden sollen (FP-Karten)."
-#~ msgid "Invert catlist"
-#~ msgstr "Invertiere Kategorieliste."
-#~ msgid "Don't add to list of rasters and commands in monitor"
-#~ msgstr "Nicht zu der Liste der Rasterkarten und Kommandos im Monitor hinzufügen."
-#~ msgid "Ignoring catlist: map is floating point (please use 'val=')"
-#~ msgstr "Igniriere Kategorieliste: Karte ist ein Fließkommakarte (Bitte benutzen Sie 'val=')."
-#~ msgid "Ignoring vallist: map is integer (please use 'cat=')"
-#~ msgstr "Ignoriere Vallist: Karte ist eine Integerkarte (Bitte benutzen Sie 'cat=')."
-#~ msgid "No raster map exists in current window"
-#~ msgstr "Es existiert keine Rasterkarte im aktuellen Fenster."
-#~ msgid "display, visualization, raster, vector, raster3d"
-#~ msgstr "Darstellung, Visualisierung, Raster, Vektor, 3D-Raster"
-#~ msgid "Interactively select route"
-#~ msgstr "Selectiere interaktiv eine Route."
-#~ msgid "You must select more than one point"
-#~ msgstr "Es müssen mehr als ein Punkt selektiert werden."
-#~ msgid "You must select at least four points"
-#~ msgstr "Es müssen mindestens 4 Punkte selektiert werden."
-#~ msgid "display, zoom"
-#~ msgstr "Darstellung, Zoom"
-#~ msgid "Just redraw given maps using default colors"
-#~ msgstr "Nur die angegebene Karten mit ihren Standardfarben neu zeichnen."
-#~ msgid "ERROR: can not get \"list\" items"
-#~ msgstr "FEHLER: Kann keine \"list\" Werte finden."
-#~ msgid "-j flag forced"
-#~ msgstr "Benutzung des Schalters -j erzwungen."
-#~ msgid "No map is displayed in GRASS monitor"
-#~ msgstr "Im Grafikfenster ist keine Karte dargestellt."
-#~ msgid "shape;Display geometry of features;cat;Display category numbers of features;topo;Display topology information (nodes, edges);dir;Display direction of linear features;attr;Display selected attribute based on 'attrcol';zcoor;Display z-coordinate of features (only for 3D vector maps)"
-#~ msgstr "shape;Anzeige der Geometrie der Objekte;cat;Anzeige der Kategorienummern der Objekte;topo;Anzeige der Topologieinformationen (nodes, edges);dir;Anzeige der Richtung von linearen Objekten;attr;Anzeige der ausgewählten Attribute basierend auf 'attrcol';zcoor;Anzeige der z-Kooridinate der Objekte (nur für 3D Vektorkarten)"
-#~ msgid "Layer number (if -1, all layers are displayed)"
-#~ msgstr "Layernummer (wenn -1, alle Layer werden dargestellt)."
-#~ msgid "g;use the libgis render functions (features: clipping);r;use the raster graphics library functions (features: polylines);d;use the display library basic functions (features: polylines);c;use the display library clipping functions (features: clipping);l;use the display library culling functions (features: culling, polylines)"
-#~ msgstr "g;Verwende die Render-Funktion von libgis (Feature: abschneiden);r;verwende dir Render-Funktion der Rastergrafikbibliothek (Feature: Polylinien);d;Verwende die grundlegenden Funktionen der Displaybibliothek (Feature: Polylinien);c;Verwende die Clipping-Funktion der Displaybibliothek (Feature: abschneiden);l;Verwende die Culling-Funktion der der Displaybibliothek (Feature: Beschneiden, Polylinien)"
-#~ msgid "Don't add to list of vectors and commands in monitor (it won't be drawn if the monitor is refreshed)"
-#~ msgstr "Nicht zu der Liste der Vektorkarten und Kommandos im Monitor hinzufügen (Die Vektorkarte wird nicht gezeichnet, wenn das Grafikfenster aktualisiert wird)."
-#~ msgid "Unable to display areas, topology not available"
-#~ msgstr "Kann Flächen nicht darstellen, da die Topologie nicht vorhanden ist."
-#~ msgid "Unable to display lines by id, topology not available"
-#~ msgstr "Kann die Linien nicht mittels ihrer ID darstellen, da die Topologie nicht vorhanden ist."
-#~ msgid "Unable to display topology, not available"
-#~ msgstr "Kann die Topologie nicht darstellen, da sie nicht vorhanden ist."
-#~ msgid "vector, raster, resample"
-#~ msgstr "Vektor, Raster, Resampling"
-#~ msgid "Vector map defining sample points"
-#~ msgstr "Vektordatei die Beispielpunkte enthält."
-#~ msgid "Vector map attribute column to use for comparison"
-#~ msgstr "Attributspalte der Vektorkarte, die zum Vergleich verwendet werden soll."
-#~ msgid "Vector map to store differences"
-#~ msgstr "Vektorkarte, die die Unterschiede beinhalten soll."
-#~ msgid "Raster map to be sampled"
-#~ msgstr "Rasterkarte, die abgefragt wird."
-#~ msgid "Option scaling factor for values read from raster map. Sampled values will be multiplied by this factor"
-#~ msgstr "Skalierungsfaktor für Werte der Rasterkarte. Abgefragte Werte werden mit diesem Faktor multipliziert."
-#~ msgid "Bilinear interpolation (default is nearest neighbor)"
-#~ msgstr "Bilineare Interpolation (Standard: Nächster Nachbar)."
-#~ msgid "Cubic convolution interpolation (default is nearest neighbor)"
-#~ msgstr "Interpolation mittels kubischer Faltung (Standard: Nächster Nachbar)."
-#~ msgid "Flags -b & -c are mutually exclusive. Choose only one."
-#~ msgstr "Die Schalter -b und -c schließen sich gegenseitig aus. Bitte wählen Sie nur Einen."
-#~ msgid "Checking vector points..."
-#~ msgstr "Prüfe Vektorpunkte..."
-#~ msgid "vector, database, attribute table"
-#~ msgstr "Vektor, Datenbank, Attributtabelle"
-#~ msgid "vector, network, allocation"
-#~ msgstr "Vektor, Netzwerk, Allokation"
-#~ msgid "vector, networking, maintenance"
-#~ msgstr "Vektor, Netzwerk, Wartung"
-#~ msgid "Name of input point vector map"
-#~ msgstr "Name der Eingabe-Punktvektorkarte."
-#~ msgid "Required for operation 'connect'"
-#~ msgstr "Benötigt für die Operation 'connect'."
-#~ msgid "nodes;new point is placed on each node (line end) if doesn't exist;connect;connect still unconnected points to vector network by inserting new line(s);report;print to standard output {line_category start_point_category end_point_category};nreport;print to standard output {point_category line_category[,line_category...]}"
-#~ msgstr "nodes;Neue Punkte werden auf jeden Knoten (Linienendpunkte) platziert, wenn sie nicht existieren;connect;Verbinde noch unverbundene Punkte des Netzwerks durch einfügen neuer Linien;report;Gebe auf der Standardausgabe {line_category start_point_category end_point_category} aus;nreport;Gebe auf der Standardausgabe {point_category line_category [line_category...]}aus"
-#~ msgid "Output vector map must be specified"
-#~ msgstr "Ausgabe-Vektorkarte muss angegeben werden."
-#~ msgid "Point vector map must be specified"
-#~ msgstr "Punkt-Vektorkarte muss angegeben werden."
-#~ msgid "Threshold value must be specified"
-#~ msgstr "Schwellwert muss angeben werden."
-#~ msgid "%d arcs added to network (nlayer %d)"
-#~ msgstr "%d Kanten zum Netzwerk hinzugefügt (nlayer %d)."
-#~ msgid "%d new points written to output"
-#~ msgstr "%d neue Punkte in die Ausgabe geschrieben."
-#~ msgid "Exports a GRASS vector map to SVG."
-#~ msgstr "Exportiert eine GRASS Vektorkarte nach SVG."
-#~ msgid "vector, export"
-#~ msgstr "Vektor, Export"
-#~ msgid "Unable to open SVG file <%s>"
-#~ msgstr "Kann die SVG-Datei <%s> nicht öffnen."
-#~ msgid "vector, path, visibility"
-#~ msgstr "Vektor, Pfad, Sichtbarkeit"
-#~ msgid "Layer number (write to)"
-#~ msgstr "Layernummer (schreiben)"
-#~ msgid "Query layer number (read from)"
-#~ msgstr "Abfragelayernummer (lesen)"
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)"
-#~ msgstr "mi(len),f(uß),me(ter),k(ilometer),a(cres),h(ektar),r(adians),d(egrees)"
-#~ msgid "vector, statistics"
-#~ msgstr "Vektor, Statistik"
-#~ msgid "vector, interpolation"
-#~ msgstr "Vektor, Interpolation"
-#~ msgid "If set to 0, z coordinates are used. (3D vector only)"
-#~ msgstr "Wenn 0, dann wird die Z-Koordinate genutzt (nur bei 3D-Vektoren)."
-#~ msgid "Attribute table column with values to interpolate (if layer>0)"
-#~ msgstr "Spalte der Attributtabelle, die zu interpolierende Werte enthält (wenn layer > 0)."
-#~ msgid "Need either 3D vector or layer and column with z values"
-#~ msgstr "Brauche entweder ein 3D Vektor oder ein Layer und Spalte mit Z-Werten. "
-#~ msgid "Layer but not column with z values given"
-#~ msgstr "Ein Layer aber keine Spalte mit Z-Werten erhalten."
-#~ msgid "No vector map of sparse points to interpolate was specified. Interpolation will be done with <%s> vector map"
-#~ msgstr "Keine Vektorkarte mit wenigen zu interpolierenden Punkten angegeben. Die Interpolation erfolgt mit der <%s> Vektorkarte"
-#~ msgid "vector, LIDAR, edges"
-#~ msgstr "Vektor, LIDAR, Kanten"
-#~ msgid "Decomposition failed"
-#~ msgstr "Entmischung fehlgeschlagen."
-#~ msgid "Unable to access table <%s>"
-#~ msgstr "Kann nicht auf die Tabelle <%s> zugreifen."
-#~ msgid "<%s> created in database."
-#~ msgstr "<%s> in Datenbank erzeugt."
-#~ msgid "vector, LIDAR"
-#~ msgstr "Vektor, LIDAR"
-#~ msgid "vector, generalization, simplification, smoothing, displacement, network generalization"
-#~ msgstr "Vektor, Generalisierung, Vereinfachung, Glättung, Verschiebung, Netzwerk-Generalisierung"
-#~ msgid "Vector based generalization."
-#~ msgstr "Vektorbasierte Generalisierung."
-#~ msgid "Remove lines and areas smaller than threshold"
-#~ msgstr "Entferne Linien und Flächen, die kleiner sind als der Schwellwert."
-#~ msgid "%d boundaries were deleted, input areas are not preserved"
-#~ msgstr "%d Grenzen wurden gelöscht, Flächen werden nicht erhalten."
-#~ msgid "Unable to calculate centroid for area %d"
-#~ msgstr "Kann keinen Zentroid für die Fläche %d berechnen."
-#~ msgid "New centroids were calculated, attribute attachment may be changed"
-#~ msgstr "Neue Zentroide wurden berechnet. Attributzuordnung kann sich geändert haben."
-#~ msgid "Areas may have disappeared and/or area attribute attachment may have changed"
-#~ msgstr "Flächen können verschwunden sein und/oder die Zuordnung der Attribute kann sich geändert haben."
-#~ msgid "Try v.clean tool=prune thresh=%f"
-#~ msgstr "Versuchen Sie v.clean tool=prune thresh=%f"
-#~ msgid "Creates topology for GRASS vector map."
-#~ msgstr "Erzeugt Topologie für GRASS Vektorkarten."
-#~ msgid "Vector map <%s> not found in the current mapset"
-#~ msgstr "Vektorkarte <%s> im aktuellen Mapset nicht gefunden."
-#~ msgid "Convert OGR vector layers to GRASS vector map."
-#~ msgstr "Konvertiere OGR Vektorlayer in das GRASS Vektorkarten."
-#~ msgid "Unable to convert input map projection to GRASS format; cannot create new location"
-#~ msgstr "Kann die Projektion der Eingabekarte nicht in das GRASS-Format konvertieren; kann daher keine neue Location erstellen."
-#~ msgid "Change dangles to lines:"
-#~ msgstr "Ändere Überstände zu Linien:"
-#~ msgid "vector, volume, conversion"
-#~ msgstr "Vektor, Volumen, Konvertierung"
-#~ msgid "Converts a binary GRASS vector map (only points) layer into a 3D GRASS raster map layer."
-#~ msgstr "Konvertiert eine binäre Vektorkarte (nur Punkte) in eine 3D Rasterkarte. "
-#~ msgid "Column name (type must be numeric)"
-#~ msgstr "Spaltenname (Spaltentyp muss numerisch sein)."
-#~ msgid "vector, extract"
-#~ msgstr "Vektor, extrahieren"
-#~ msgid "Layer number (if -1, all features in all layers of given type are extracted)"
-#~ msgstr "Layernummer (wenn -1, dann werden alle Feature in allen Layern des angegebenen Typs extrahiert)."
-#~ msgid "Layer 0 not supported"
-#~ msgstr "Layer 0 wird nicht unterstützt."
-#~ msgid "vector, import, database, points"
-#~ msgstr "Vektor, Import, Datenbank, Punkte"
-#~ msgid "vector, network, isolines"
-#~ msgstr "Vektor, Netzwerk, Isolinien"
-#~ msgid "vector, network, salesman"
-#~ msgstr "Vektor, Netzwerk, Salesman"
-#~ msgid "vector, geometry, statistics"
-#~ msgstr "Vektor, Geometrie, Statistik"
-#~ msgid "Random location perturbations of GRASS vector points"
-#~ msgstr "Zufällige Störung der Position von GRASS Vektorpunkten."
-#~ msgid "Vector points to be spatially perturbed"
-#~ msgstr "Vektorpunkte die räumlich gestört werden sollen."
-#~ msgid "Parameter(s) of distribution. If the distribution is uniform, only one parameter, the maximum, is needed. For a normal distribution, two parameters, the mean and standard deviation, are required."
-#~ msgstr "Parameter der Verteilung. Wenn es eine gleichförmige Verteilung ist, wird nur ein Parameter, das Maximum, benötigt. Für eine Normalverteilung sind zwei Parameter, der Mittelwert und die Standardabweichung, erforderlich."
-#~ msgid "vector, geometry"
-#~ msgstr "Vektor, Geometrie"
-#~ msgid "vector, network, shortest path"
-#~ msgstr "Vektor, Netzwerk, kürzester Pfad"
-#~ msgid "Layer number (from)"
-#~ msgstr "Layer-Nummer (from)."
-#~ msgid "Layer number (to)"
-#~ msgstr "Layer-Nummer (to)."
-#~ msgid "Finding nearest lines..."
-#~ msgstr "Finde nächste Linien..."
-#~ msgid "vector, import, sites"
-#~ msgstr "Vektor, Import, Sites"
-#~ msgid "Randomly generate a 2D/3D vector points map."
-#~ msgstr "Erzeugt zufällige 2D/3D GRASS Vektor-Punktkarten."
-#~ msgid "Column name and type (i.e. INTEGER, DOUBLE PRECISION) for z values"
-#~ msgstr "Spaltenname und -typ (z.B. INTEGER, DOUBLE PRECISION) für z Werte."
-#~ msgid "If type is not given then DOUBLE PRECISION is used. Writes Z data to column instead of 3D vector."
-#~ msgstr "Wenn kein Typ angegeben wurde, wird DOUBLE PRECISION verwendet. Schreibe Z Werte in eine Spalte an Stelle einer 3D Vektorkarte."
-#~ msgid "v.random can't create 3D vector and attribute table at same time"
-#~ msgstr "v.random kann 3D Vektorkarten und Attributtabellen nicht zu selben Zeit erstellen."
-#~ msgid "Using 'double precision' for column <%s>"
-#~ msgstr "Verwende 'double precision' für die Spalte <%s>"
-#~ msgid "Converts a GRASS binary vector map to VTK ASCII output."
-#~ msgstr "Konvertieren eine GRASS Vektorkarte zu einer VTK ASCII-Datei."
-#~ msgid "Export numeric attribute table fields as VTK scalar variables"
-#~ msgstr "Exportiere numerische Felder der Attributtabelle als VTK-Skalar-Variablen."
-#~ msgid "Cannot export attribute table fields for layer < 1. Skipping export"
-#~ msgstr "Kann Felder der Attributtabelle für Layer < 1 nicht exportieren. Überspringe den Export."
-#~ msgid "No numerical attributes found. Skipping export"
-#~ msgstr "Keine numerischen Attribute gefunden. Ãœberspringe den Export."
-#~ msgid "Error reading value of attribute '%s'"
-#~ msgstr "Fehler beim Lesen des Wertes des Attributes '%s'."
-#~ msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
-#~ msgstr "Konvertiere eine binäre GRASS-Vektordatei in eine GRASS ASCII-Vektorkarte."
-#~ msgid "Parameter '%s' ignored in standard mode"
-#~ msgstr "Parameter '%s' wird im Standard-Modus ignoriert."
-#~ msgid "got type %d"
-#~ msgstr "habe Typ '%d' erhalten."
-#~ msgid "Feature has more categories. Only first category (%d) is exported."
-#~ msgstr "Feature hat mehrere Kategorien. Nur die erste Kategorie (%d) wurde exportiert."
-#~ msgid "Unable to select record from table <%s> (key %s, column %s)"
-#~ msgstr "Kann Daten nicht aus der Tabelle selektieren<%s> (key %s, column %s)."
-#~ msgid "Column <%s>: unsupported data type"
-#~ msgstr "Spalte <%s>: nicht unterstützter Datentyp."
-#~ msgid "vector, paint labels"
-#~ msgstr "Vektor, Zeichen Label"
-#~ msgid "Numeric column to give precedence in case of overlapping labels. The label with a smaller weight is hidden."
-#~ msgstr "Numerische Spalte mit Werten, um den Vorrang bei überlappenden Beschriftungen zu kären. Die Beschriftung mit dem geringeren Gewicht wird verdeckt."
-#~ msgid "Cannot load overlap weights. Column %s is not of numeric type in table <%s>"
-#~ msgstr "Kann die Ãœberlappungsgewichte nicht laden. Die Spalte %s in der Tabelle <%s> ist nicht numerisch."
-#~ msgid "%s: Unable to read font definition file; use the default"
-#~ msgstr "%s: Kann die Font Definitionsdatei nicht lesen; nehme den Standard."
-#~ msgid "%s: No font definition file"
-#~ msgstr "%s: Keine Font Definitionsdatei."
-#~ msgid "Change the type of geometry elements."
-#~ msgstr "Ändere die Art der geometrischen Elemente."
-#~ msgid "Pairs for input and output type separated by comma"
-#~ msgstr "Paare mit Eingabe- und Ausgabe-Typ getrennt durch ein Komma."
-#~ msgid ""
-#~ "<input_type1>,<output_type1>,<input_type2>,<output_type2>,...\n"
-#~ "\t\tExample1: line,boundary\n"
-#~ "\t\tExample2: line,boundary,point,centroid"
-#~ msgstr ""
-#~ "<Eingabetyp1>,<Ausgabetyp1>,<Eingabetyp2>,<Ausgabetyp2>,...\n"
-#~ "\t\tBeispiel 1: line,boundary\n"
-#~ "\t\tBeispiel 2: line,boundary,point,centroid"
-#~ msgid "Nothing to do"
-#~ msgstr "Nichts zu tun."
-#~ msgid "Not enough types"
-#~ msgstr "Nicht ausreichend Typen."
-#~ msgid "Odd number of types"
-#~ msgstr "Ungerade Anzahl Typen."
-#~ msgid "Converts files in DXF format to GRASS vector map format."
-#~ msgstr "Konvertiert Dateien vom DXF-Format in eine GRASS Vektorkarte."
-#~ msgid "Option <%s>: <%s> exists."
-#~ msgstr "Option <%s>: <%s> existiert."
-#~ msgid "Use '%s' option to change vector map name"
-#~ msgstr "Verwende die Option '%s' um den Namen der Vektorkarte zu ändern."
-#~ msgid "Vector of points defining sample points"
-#~ msgstr "Vektorkarte mit Stichprobenpunkten."
-#~ msgid "Output quadrant centres, number of points is written as category"
-#~ msgstr "Gebe die Zentren der Quadrate aus, Anzahl der Punkte wird als Kategorie ausgegeben."
-#~ msgid "Counting sites in quadrats..."
-#~ msgstr "Zähle Sites in den Quadraten..."
-#~ msgid "Creates a GRASS vector map of a user-defined grid."
-#~ msgstr "Erzeugt eine GRASS Vektorkarte mit einem benutzerdefinierten Gitternetz."
-#~ msgid "Quiet; No chatter"
-#~ msgstr "Ruhe; Kein Geschwätz!"
-#~ msgid "vector, LRS, networking"
-#~ msgstr "Vektor, LRS, Netzwerk"
-#~ msgid "vector, reclass, attributes"
-#~ msgstr "Vektor, Re-Klassifizierung, Attribute"
-#~ msgid "Either 'rules' or 'col' must be specified"
-#~ msgstr "Entweder 'rules' oder 'col' muss angegeben werden."
-#~ msgid "vector, kernel density"
-#~ msgstr "Vektor, Kerndichte"
-#~ msgid "Network input map <%s> not found"
-#~ msgstr "Eingabekarte mit Netzwerk <%s> nicht gefunden."
-#~ msgid "Unable to read MASK"
-#~ msgstr "Kann die Maske (MASK) nicht lesen."
-#~ msgid "Converts GRASS vector map to one of the supported OGR vector formats."
-#~ msgstr "Konvertiert eine GRASS Vektorkarte in ein OGR unterstütztes Vektorformat."
-#~ msgid "Feature type(s). Combinations not supported by all output formats. Default: first type found in input."
-#~ msgstr "Feature-Typ(en): Kombinationen der Typen wird nicht von allen Formaten unterstützt. Standard: der erste in der Eingabe gefundene Typ."
-#~ msgid "OGR format"
-#~ msgstr "OGR-Format."
-#~ msgid "Export features with category (labeled) only. Otherwise all features are exported"
-#~ msgstr "Exportiert Vektorfeatures nur mit Kategoriewerten (Labeln). Ansonsten werden alle Objekte exportiert."
-#~ msgid "Skipping all boundaries that are not part of an area."
-#~ msgstr "Überspringe alle Grenzen, die nicht zu einer Fläche gehören."
-#~ msgid "Volumes will be exported as sets of faces."
-#~ msgstr "Volumen werden als Gruppe von Faces exportiert."
-#~ msgid "Could not determine input map's feature type(s)."
-#~ msgstr "Der Objekttyp der Eingabekarte konnte nicht bestimmt werden."
-#~ msgid "The map contains islands. To preserve them in the output map, use the -c flag"
-#~ msgstr "Die Karte enthält Inseln. Verwenden Sie den Schalter -c, um Inseln in der Ausgabe-Karte zu erhalten."
-#~ msgid "%d areas found, but not requested to be exported. Verify 'type' parameter."
-#~ msgstr "%d Fläche(n) gefunden, die allerdings nicht zum Export angegeben wurden. Überprüfen Sie bitte den 'type'-Parameter."
-#~ msgid "%d kernel(s) found, but not requested to be exported. Verify 'type' parameter."
-#~ msgstr "%d Kern(en) gefunden, die allerdings nicht zum Export angegeben wurden. Überprüfen Sie den Parameter 'type'."
-#~ msgid "No points found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Keine Punkte gefunden, die allerdings exportiert werden sollen. Ãœberspringe diesen Geometrie-Typ."
-#~ msgid "No lines found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Keine Linien gefunden, die allerdings exportiert werden sollen. Ãœberspringe diesen Geometry-Typ."
-#~ msgid "No boundaries found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Keine Grenzen gefunden, die allerdings exportiert werden sollen. Ãœberspringe diesen Geometry-Typ."
-#~ msgid "No areas found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Keine Flächen gefunden, die allerdings exportiert werden sollen. Überspringe diesen Geometry-Typ."
-#~ msgid "No centroids found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Keine Zentroide gefunden, die allerdings exportiert werden sollen. Ãœberspringe diesen Geometry-Typ."
-#~ msgid "No faces found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Keine Faces gefunden, die allerdings exportiert werden sollen. Ãœberspringe diesen Geometry-Typ."
-#~ msgid "No kernels found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Keine Kerne gefunden, die allerdings exportiert werden sollen. Ãœberspringe diesen Geometry-Typ."
-#~ msgid "No volumes found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Keine Volumen gefunden, obwohl sie exportiert werden sollen. Ãœberspringe diesen Geometry-Typ."
-#~ msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
-#~ msgstr "Vektorkarte <%s> ist 3D. Verwenden Sie formatspezifische Layererzeugungsoptionen (Parameter 'lco') oder '-z' Flag um nach 3D und nicht 2D (Standard) zu exportieren"
-#~ msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') to export in 3D rather than 2D (default)"
-#~ msgstr "Vektorkarte <%s> ist 3D. Verwenden Sie formatspezifische Layererzeugungsoptionen (Parameter 'lco') um nach 3D und nicht 2D (Standard) zu exportieren."
-#~ msgid "Key column '%s' not found"
-#~ msgstr "Schlüsselspalte '%s' nicht gefunden."
-#~ msgid "Exporting %i geometries..."
-#~ msgstr "Exportiere %i Gemetrien..."
-#~ msgid "Exporting %i faces (may take some time) ..."
-#~ msgstr "Exportiere %i 3D-Flächen (kann eine Weile dauern)..."
-#~ msgid "vector, projection, transformation"
-#~ msgstr "Vektor, Projektion, Transformation"
-#~ msgid "For vector lines reads their vertices"
-#~ msgstr "Liest die Vertices einer Vektorlinie"
-#~ msgid "Convex hull calculation requires at least three points. Exiting."
-#~ msgstr "Die Berechnung der konvexen Hülle erfordert mindestens drei Punkte. Beende mich."
-#~ msgid "Cannot open %s"
-#~ msgstr "Kann %s nicht öffnen."
-#~ msgid "vector, network, articulation points"
-#~ msgstr "Vektor, Netzwerk, articulation points"
-#~ msgid "Create a new vector map layer by combining other vector map layers."
-#~ msgstr "Erzeugt eine neue Vektorkarte durch Kombination anderer Vektorkarten"
-#~ msgid "Patching vector map <%s@%s>..."
-#~ msgstr "Kombiniere Vektorkarte <%s@%s>..."
-#~ msgid "vector, network, connectivity"
-#~ msgstr "Vektor, Netzwerk, Konnektivität"
-#~ msgid "Cannot alter table: %s"
-#~ msgstr "Kann die Tabelle '%s' nicht verändern"
-#~ msgid "vector, metadata"
-#~ msgstr "Vektor, Metadaten"
-#~ msgid "vector, spatial query"
-#~ msgstr "Vektor, räumliche Abfrage"
-#~ msgid "vector, buffer"
-#~ msgstr "Vektor, Buffer"
-#~ msgid "Creates a buffer around features of given type (areas must contain centroid)."
-#~ msgstr "Erzeugt einen Buffer um die Feature mit gegebenen Typ (Flächen müssen Zentroide enthalten)."
-#~ msgid "Unused"
-#~ msgstr "Nicht genutzt"
-#~ msgid "This does nothing. It is retained for backwards compatibility"
-#~ msgstr "Dies tut nichts. Es wurde nur für die Rückwärtskompatibilität erhalten"
-#~ msgid "This is an alias to the distance option. It is retained for backwards compatibility"
-#~ msgstr "Dies ist ein Alias für die Distanz-Option. Es wurde nur für rückwärts Kompatibilität erhalten"
-#~ msgid "Buffer distance in map units"
-#~ msgstr "Bufferdistanz in Karteneinheiten"
-#~ msgid "The buffer option has been replaced by the distance option and will be removed in future."
-#~ msgstr "Die Buffer-Option wurde durch die Distanz-Option ersetzt und wird in Zukunft entfernt."
-#~ msgid "Use the distance option instead of the buffer option."
-#~ msgstr "Verwende die Distanz-Option anstelle der Buffer-Option."
-#~ msgid "vector, geometry, triangulation"
-#~ msgstr "Vektor, Geometrie, Triangulation"
-#~ msgid "Cannot calculate area centroid z coordinate"
-#~ msgstr "Kann die Z-Koordinate des Zentroids nicht berechnen."
-#~ msgid "vector, network, steiner tree"
-#~ msgstr "Vektor, Netzwerk, Steiner tree"
-#~ msgid "vector, querying"
-#~ msgstr "Vektor, Abfragen"
-#~ msgid "Queries a vector map layer at given locations."
-#~ msgstr "Fraget Vektorkarten an gegebenen Positionen ab."
-#~ msgid "Type: %s"
-#~ msgstr "Typ: %s"
-#~ msgid "Suppress display of residuals or other information"
-#~ msgstr "Unterdrücke die Darstellung der Residuen oder anderer Informationen"
-#~ msgid "Instead of points use transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot)"
-#~ msgstr "Anstelle von Punkten verwende Transformationsparameter (xshift, yshift, zshift, xscale, yscale, zscale, zrot)."
-#~ msgid "The '%c' flag is deprecated and will be removed in future. Transformation parameters are used automatically when no pointsfile is given."
-#~ msgstr "Der Schalter '%c' ist veraltet und wird in Zukunft nicht mehr vorhanden sein. Transformationsparameter werden automatisch verwendet wenn kein pointsfile angegeben wurde."
-#~ msgid "The '%c' flag is deprecated and will be removed in future. Please use '--quiet' instead."
-#~ msgstr "Der Schalter '%c' ist veraltet und wird in Zukunft nicht mehr vorhanden sein. Bitte verwenden Sie stattdessen '--quiet'."
-#~ msgid ""
-#~ "\n"
-#~ "New vector map <%s> boundary coordinates:"
-#~ msgstr ""
-#~ "\n"
-#~ "Neue Vektorkarte <%s> Grenzkoordinaten:"
-#~ msgid " Number of points that have been entered: %d\n"
-#~ msgstr "Anzahl der Punkte, die eingegeben wurden: %d\n"
-#~ msgid "Please answer yes or no"
-#~ msgstr "Bitte antworten Sie mit yes oder no"
-#~ msgid "ask_transform_coor():  Leaving session.. \n"
-#~ msgstr "ask_transform_coor():  Verlasse session.. \n"
-#~ msgid "Copying vector objects from vector map <%s>..."
-#~ msgstr "Kopiere Vektorobjekte von der Vektorkarte <%s>..."
-#~ msgid "vector, geometry, topology"
-#~ msgstr "Vektor, Geometrie, Topology"
-#~ msgid "vector, import, conversion"
-#~ msgstr "Vektor, Import, Konvertierung"
-#~ msgid "vector, network, flow"
-#~ msgstr "Vektor, Netzwerk, Fluss"
-#~ msgid "Name of input vector map containing lines"
-#~ msgstr "Namde der Eingabe-Vektorkarte mit Linien."
-#~ msgid "Name for output vector map where segments will be written"
-#~ msgstr "Name der Ausgabe-Vektorkarte, in die die Segmente geschrieben werden."
-#~ msgid "Tests for normality for points."
-#~ msgstr "Test auf Normalverteilung für Punkte."
-#~ msgid "Doing log transformation"
-#~ msgstr "Führe log Transformation aus."
-#~ msgid "Calculates univariate statistics for attribute. Variance and standard deviation is calculated only for points if specified."
-#~ msgstr "Berechnet univariate Statistiken für die Attribute. Die Varianz und Standardabweichung wird nur für Punkte berechnet wenn explizit angefragt."
-#~ msgid "Column name"
-#~ msgstr "Spaltenname"
-#~ msgid "Calculate geometry distances instead of table data."
-#~ msgstr "Berechne Geometriedistanzen an Stelle der Tabellenwerte."
-#~ msgid "Unable select categories from table <%s>"
-#~ msgstr "Kann keine Kategorien aus der Tabelle <%s> selektieren."
-#~ msgid "Calculate area centroids..."
-#~ msgstr "Berechne Flächenzentroide..."
-#~ msgid "vector, raster, conversion"
-#~ msgstr "Vektor, Raster, Konvertierung"
-#~ msgid "Cannot allocate memory for row buffer"
-#~ msgstr "Kann keinen Speicher für Zeilenbuffer reservieren."
-#~ msgid "Unable to write categories for raster map <%s>"
-#~ msgstr "Kann die Kategorien für die Rasterkarte <%s> nicht schreiben."
-#~ msgid "Area without centroid (may be OK for island)"
-#~ msgstr "Fläche ohne Zentroid (kann für Inseln OK sein)."
-#~ msgid "Create points along input lines in new vector with 2 layers."
-#~ msgstr "Erzeuge Punkte entlang der Eingabelinie in eine neue Vektorkarte mit zwei Layern."
-#~ msgid "Output vector map where points will be written"
-#~ msgstr "Ausgabe-Vektorkarte, in welche die Punkten geschrieben werden"
-#~ msgid "%d points written to output vector map"
-#~ msgstr "%d Punkte in die Ausgabe-Vektorkarte geschrieben."
-#~ msgid "Error reading ASCII file: (bad type) [%s]"
-#~ msgstr "Fehler beim Lesen der ASCII-Datei: (schlechter Typ) [%s]."
-#~ msgid "Error reading ASCII file: (unknown type) [%s]"
-#~ msgstr "Fehler beim Lesen der ASCII-Datei: (unbekannter Typ) [%s]."
-#~ msgid "End of ASCII file reached before end of coordinates"
-#~ msgstr "Ende der ASCII-Datei vor dem Ende der Koordinaten erreicht."
-#~ msgid "Error reading ASCII file: (bad point) [%s]"
-#~ msgstr "Fehler beim Lesen der ASCII-Datei: (schlechter Punkt) [%s]."
-#~ msgid "Unparsable longitude value: [%s]"
-#~ msgstr "Nicht interpretierbarer Längengrad: [%s]"
-#~ msgid "Unparsable latitude value: [%s]"
-#~ msgstr "Nicht interpretierbarer Breitengrad: [%s]"
-#~ msgid "End of ASCII file reached before end of categories"
-#~ msgstr "Ende der ASCII-Datei vor dem Ende der Kategorien erreicht."
-#~ msgid "Error reading categories: [%s]"
-#~ msgstr "Fehler beim Lesen der Kategorien: [%s]."
-#~ msgid ""
-#~ "Unexpected data in vector head:\n"
-#~ "[%s]"
-#~ msgstr ""
-#~ "Unerwartete Daten im Vektorheader:\n"
-#~ "[%s]"
-#~ msgid "Unknown keyword <%s> in vector head"
-#~ msgstr "Unbekanntes Schlüsselwort <%s im Vektorheader."
-#~ msgid "Creates a vector map from ASCII points file or ASCII vector file."
-#~ msgstr "Erzeugt eine Vektorkarte aus einer ASCII-Punktdatei oder ASCII-Vektordatei."
-#~ msgid "ASCII file to be imported, if not given reads from standard input"
-#~ msgstr "ASCII-Datei, die importiert werden soll. Wenn nichts angegeben wird von der Standardeingabe gelesen."
-#~ msgid "vector, external, import"
-#~ msgstr "Vektor, External, Import"
-#~ msgid "Creates a new vector as a read-only link to OGR layer."
-#~ msgstr "Erzeugt eine neue Vektorkarte als einen ausschließlich lesbaren Link zu einem OGR-Layer."
-#~ msgid "Output vector. If not given, available layers are printed only."
-#~ msgstr "Ausgabevektor. Wenn nicht benannt, werden alle verfügbaren Layer lediglichangezeigt."
-#~ msgid ""
-#~ "OGR layer name. If not given, available layers are printed only. Examples:\n"
-#~ "\t\tESRI Shapefile: shapefile name\n"
-#~ "\t\tMapInfo File: mapinfo file name"
-#~ msgstr ""
-#~ "OGR Layer-Name. Falls nicht angegeben, werden alle vorhandenen Layernamen lediglich angezeigt. Beispiele:\n"
-#~ "\t\tESRI Shapefile: Name des Shapefiles\n"
-#~ "\t\tMapInfo File: Name der MapInfo-Datei"
-#~ msgid "Output vector name was not specified"
-#~ msgstr "Ausgabe-Vektorkarte wurde nicht angegeben."
-#~ msgid "Cannot open data source"
-#~ msgstr "Kann die Datenquelle nicht öffnen."
-#~ msgid "break;break lines at each intersection;rmdupl;remove duplicate geometry features (pay attention to categories!);rmdangle;remove dangles, threshold ignored if < 0;chdangle;change the type of boundary dangle to line, threshold ignored if < 0, input line type is ignored;rmbridge;remove bridges connecting area and island or 2 islands;chbridge;change the type of bridges connecting area and island or 2 islands from boundary to line;snap;snap lines to vertex in threshold;rmdac;remove duplicate area centroids ('type' option ignored);bpol;break (topologically clean) polygons (imported from non topological format, like ShapeFile). Boundaries are broken on each point shared between 2 and more polygons where angles of segments are different;prune;remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachement of centroid), first and last segment of the boundary is never changed;rmarea;remove smal
 l areas, the longest boundary with adjacent area is removed;rmline;remove all lines or boundaries of zero length, threshold is ignored;rmsa;remove small angles between lines at nodes"
-#~ msgstr "break;Teilt Linien an jeder Überschneidung;rmdupl;Entfernt doppelte Geometrie-Feature (Achten Sie auf die Kategorien!);rmdangle;Entfernt Überstände (dangles), Schwellwert wird ignoriert, wenn <0;chdangle;Ändert den Typ eines Überstands (dangle) zu einer Linie, Schwellwert wird ignoriert, wenn <0, Eingabe-Linien-Typ wird ignoriert;rmbridge;Entfernt Brücken, die eine Fläche und eine Insel oder 2 Inseln verbindet;chbridge;Ändert den Typ einer Brücke, die eine Fläche und eine Insel oder 2 Inseln verbindet von Grenze zu Linie;snap;Snapped Linien auf Vertices innerhalb des Schwellwertes;rmdac;Entfernt doppelte Zentroide (Option 'type' wird ignoriert);bpol;Teilt (topologisch sauber) Polygone (importiert aus nicht topologischen Formaten, wie z.B. ShapeFile). Grenzen werden an jedem Punkt geteilt, der 2 oder mehr Polygonen gemeinsam ist und die Winkel der Segmente verschieden sind.;prune;Entfernt Vertices innerhalb des Schwellwertes von Linien und Grenzen. Grenze
 n werden nur gesäubert, wenn die Topologie nicht beschädigt wird ( neue Überschneidungen, veränderte Zuordnung von Zentroiden); das erste und letzte Segment einer Grenze wird nie geändert;rmarea;Entfernt kleine Flächen, die längste Grenze mit einer benachbarten Fläche wird entfernt;rmline;Entfernt alle Linien und Grenzen mit der Länge null, Schwellwert wird ignoriert;rmsa;Entfernt spitze Winkel zwischen Linien an einem Knoten"
-#~ msgid "Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
-#~ msgstr "Schwellenwert in Karteneinheiten, einen Wert für jedes Werkzeug (Standard: 0.0[,0.0,...])."
-#~ msgid "%d areas of total size %g removed"
-#~ msgstr "%d Flächen mit der Gesamtgröße %g entfernt."
-#~ msgid "%d modifications done"
-#~ msgstr "%d Veränderungen vorgenommen."
-#~ msgid "%d lines / boundaries removed"
-#~ msgstr "%d Linien / Grenzen entfernt."
-#~ msgid ""
-#~ "\n"
-#~ "%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
-#~ msgstr ""
-#~ "\n"
-#~ "%d Vertices aus der Eingabe %d (Vertices des angegebenen Typs) entfernt, z.B. %.2f %%"
-#~ msgid "If set to 0, z coordinates are used (3D vector only)"
-#~ msgstr "Wenn auf 0 gesetzt, dann werden die Z-Koordinate genutzt (nur bei 3D-Vektoren)."
-#~ msgid "Attribute table column with values to interpolate"
-#~ msgstr "Spalte der Attributtabelle, die zu interpolierende Werte enthält."
-#~ msgid "Required if layer > 0"
-#~ msgstr "Erfordert wenn Layer >0"
-#~ msgid "Power parameter; greater values assign greater influence to closer points"
-#~ msgstr "Power-Parameter; größere Werte geben ein näheren Punkten ein stärkeres Gewicht."
-#~ msgid "No data points found"
-#~ msgstr "Keine Datenpunkte gefunden."
-#~ msgid "Create parallel line to input lines"
-#~ msgstr "Erzeuge eine parallele Linie zu der eingegebenen Linie."
-#~ msgid "Offset in map units, positive for right side, negative for left side."
-#~ msgstr "Versatz in Karteneinheiten, positiv für die rechte und negativ für die linke Seite."
-#~ msgid "vector, geometry, buffer"
-#~ msgstr "Vektor, Geometrie, Puffer"
-#~ msgid "Attribute column to use for buffer distances"
-#~ msgstr "Attributspalte mit den Bufferdistanzen."
-#~ msgid "Stop the process at a certain stage"
-#~ msgstr "Stoppt den Prozess bei einer bestimmten Stufe."
-#~ msgid "The tolerance was reset to %g (map units)"
-#~ msgstr "Die Toleranz wurde auf %g (Karteneinheiten) zurückgesetzt."
-#~ msgid "Lines buffers... "
-#~ msgstr "Linien-Buffer... "
-#~ msgid "The tolerance was reset to %g (map units). [category %d]"
-#~ msgstr "Die Toleranz wurde auf %g (Karteneinheiten) zurückgesetzt [Kategorie %d]."
-#~ msgid "Areas buffers... "
-#~ msgstr "Flächen-Buffer ..."
-#~ msgid "vector, editing, geometry"
-#~ msgstr "Vektor, Editieren, Geometrie"
-#~ msgid "Creating new DB connection based on default mapset settings..."
-#~ msgstr "Erzeuge neue DB-Verbindung, basierend auf den Mapset-Einstellungen..."
-#~ msgid "Difference in x,y direction for moving feature or vertex"
-#~ msgstr "Differenz in x,y Richtung für das Verschieben eines Features oder Vertex."
-#~ msgid "Error reading ASCII file: '%s'"
-#~ msgstr "Fehler beim Lesen der ASCII-Datei: '%s'."
-#~ msgid "Error reading categories: '%s'"
-#~ msgstr "Fehler beim Lesen der Kategorien: '%s'."
-#~ msgid "Unexpected data in vector head: '%s'"
-#~ msgstr "Unerwartete Daten im Vektorheader: '%s'"
-#~ msgid "Unknown keyword '%s' in vector head"
-#~ msgstr "Unbekanntes Schlüsselwort '%s' im Vektor-Header."
-#~ msgid "vector, metadata, history"
-#~ msgstr "Vektor, Metadaten, history"
-#~ msgid "Outputs basic information about a user-specified vector map."
-#~ msgstr "Gibt grundlegende Informationen einer bestimmten Vektorkarte aus."
-#~ msgid "Print vector history instead of info"
-#~ msgstr "Gebe den Werdegang anstelle einer Info aus."
-#~ msgid "Print types/names of table columns for specified layer instead of info"
-#~ msgstr "Gebe Typ/Name der Tabellenspalten bestimmter Layer anstatt der Info aus."
-#~ msgid "Displaying column types/names for database connection of layer %d:"
-#~ msgstr "Zeige Typ/Name der Spalten der Datenbank des Layers %d:"
-#~ msgid "Layer:           %s"
-#~ msgstr "Layer:           %s"
-#~ msgid "Mapset:          %s"
-#~ msgstr "Mapset:          %s"
-#~ msgid "Location:        %s"
-#~ msgstr "Location:        %s"
-#~ msgid "Database:        %s"
-#~ msgstr "Datenbank:       %s"
-#~ msgid "Title:           %s"
-#~ msgstr "Titel:           %s"
-#~ msgid "Map scale:       1:%d"
-#~ msgstr "Maßstab:       1:%d"
-#~ msgid "Map format:      %s"
-#~ msgstr "Kartenformat:      %s"
-#~ msgid "Name of creator: %s"
-#~ msgstr "Name des Erzeugers: %s"
-#~ msgid "Organization:    %s"
-#~ msgstr "Organisation:    %s"
-#~ msgid "Source date:     %s"
-#~ msgstr "Quelldatum:     %s"
-#~ msgid "  Type of Map:  %s (level: %i)        "
-#~ msgstr "  Typ der Karte:  %s (Level: %i)        "
-#~ msgid "  Number of points:       %-9ld       Number of areas:      %-9ld"
-#~ msgstr "  Anzahl Punkte:       %-9ld       Anzahl Flächen:      %-9ld"
-#~ msgid "  Number of lines:        %-9ld       Number of islands:    %-9ld"
-#~ msgstr "  Anzahl Linien:        %-9ld       Anzahl Inseln:    %-9ld"
-#~ msgid "  Number of boundaries:   %-9ld       Number of faces:      %-9ld"
-#~ msgstr "  Anzhal Grenzen:   %-9ld       Anzahl faces:      %-9ld"
-#~ msgid "  Number of centroids:    %-9ld       Number of kernels:    %-9ld"
-#~ msgstr "  Anzahl Zentroid:    %-9ld       Anzahl Kerne:    %-9ld"
-#~ msgid "  Map is 3D:              %s"
-#~ msgstr "  Karte ist 3D:              %s"
-#~ msgid "  Number of dblinks:      %-9ld"
-#~ msgstr "  Anzahl der dblinks:      %-9ld"
-#~ msgid "        Projection: %s (zone %d)"
-#~ msgstr "        Projektion: %s (Zone %d)"
-#~ msgid "        Projection: %s"
-#~ msgstr "        Projektion: %s"
-#~ msgid "  Digitization threshold: %s"
-#~ msgstr "  Digitalisierungs-Schwellwert: %s"
-#~ msgid "  Comments:"
-#~ msgstr "  Kommentare:"
-#~ msgid "vector, geometry, 3D"
-#~ msgstr "Vektor, Geometrie, 3D"
-#~ msgid "Extrudes flat vector object to 3D with defined height."
-#~ msgstr "Presst flache Vektorobjekte in eine 3D-Form mit definierter Höhe."
-#~ msgid "Name of input 2D vector map"
-#~ msgstr "Name der Eingabe 2D Vektorkarte."
-#~ msgid "Name of resulting 3D vector map"
-#~ msgstr "Name der resultierenden 3D Vektorkarte."
-#~ msgid "Extruding vector primitives..."
-#~ msgstr "Presse Vektor Primitive..."
-#~ msgid "vector, category"
-#~ msgstr "Vektor, Kategorie "
-#~ msgid "Attach, delete or report vector categories to map geometry."
-#~ msgstr "Füge hinzu, Lösche oder Berichte Vektorkategorien einer Kartengeometrie."
-#~ msgid "add;add a new category;del;delete all categories of given layer;chlayer;change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add the value specified by cat option to the current category value;report;print report (statistics), in shell style: layer type count min max;print;print category values, more cats in the same layer are separated by '/'"
-#~ msgstr "add;Füge eine neue Kategorie hinzu;del;Lösche alle Kategorien eines gegebenen Layers;chlayer;Ändere die Layer-Nummer (z.B. layer=3,1 ändert von Layer 3 auf Layer 1);sum;Addiert den Wert spezifiziert in der Option 'cat' zu dem aktuellen Kategoriewert;report;Gebe einen Bericht (Statistiken ) im Shell-Skript-Stil: Layer Typ Anzahl Min Max;print;Gebe Kategoriewerte aus, mehere cats im selben Layer werden durch '/' getrennt"
-#~ msgid "Use z-coordinates (3D vector only)"
-#~ msgstr "Verwende z-Koordinaten (nur bei 3D Vektorkarten)."
-#~ msgid "Output surface raster map (elevation)"
-#~ msgstr "Ausgabekarte mit den Oberflächeninformationen (Höheninformationen)."
-#~ msgid "Output slope raster map"
-#~ msgstr "Ausgabekarte mit der Hangneigung."
-#~ msgid "Output aspect raster map"
-#~ msgstr "Ausgabe-Expositionskarte."
-#~ msgid "Output profile curvature raster map"
-#~ msgstr "Ausgabekarte mit vertikaler Wölbung."
-#~ msgid "Output tangential curvature raster map"
-#~ msgstr "Ausgabekarte mit horizontaler Wölbung."
-#~ msgid "Output mean curvature raster map"
-#~ msgstr "Ausgabekarte mit mittlerer Wölbung."
-#~ msgid "Output cross-validation errors vector point file"
-#~ msgstr "Gebe eine Vektor-Punktkarte mit den Fehlern der Kreuzvalidierung aus."
-#~ msgid "Output vector map showing quadtree segmentation"
-#~ msgstr "Ausgabe-Vektorkarte mit der 'quadtree'-Segmentierung."
-#~ msgid "Output vector map showing overlapping windows"
-#~ msgstr "Ausgabe-Vektordatei, die die überlappenden Segmente beinhaltet."
-#~ msgid "Name of the attribute column with values to be used for approximation (if layer>0)"
-#~ msgstr "Name der Attributspalte mit Werten, die für die Approximation verwendet werden (wen der Layer >0)."
-#~ msgid "Both z-coordinate and zcol attribute defined, only one is allowed"
-#~ msgstr "z-Koordinate und 'zcol' wurden angegeben, aber nur eine Angabe ist erlaubt."
-#~ msgid "Only smoothing column defined, zcol or -z flag is missing"
-#~ msgstr "Nur die Spalte mit dem Glättungsfaktor wurde definiert, zcol oder -z fehlt."
-#~ msgid ""
-#~ "Processing all selected output files\n"
-#~ "will require %d bytes of disk space for temp files"
-#~ msgstr ""
-#~ "Bearbeite alle ausgewählten Ausgabedateien.\n"
-#~ "Werde %d Byte Plattenspeicher für temp-Dateien benötigen."
-#~ msgid "Cannot write raster maps -- try to increase resolution"
-#~ msgstr "Kann Rasterkarte nicht schreiben -- Versuchen Sie die Auflösung zu erhöhen."
-#~ msgid "vector, editing, digitization"
-#~ msgstr "Vektor, Editiern, Digitalisieren"
-#~ msgid "Interactive editing and digitization of vector maps."
-#~ msgstr "Interaktives Editieren und Digitalisieren von Vektorkarten."
-#~ msgid "Create new file if it does not exist."
-#~ msgstr "Erzeuge neue Datei, wenn sie noch nicht existiert."
-#~ msgid "New empty map created."
-#~ msgstr "Neue, leere Karte erstellt."
-#~ msgid "Map <%s> does not exist in current mapset. Add flag -n to create a new map."
-#~ msgstr "Karte <%s> existiert noch nicht im aktuellen Mapset. verwenden Sie den Schalter -n, um eine neue Karte zu erzeugen."
-#~ msgid "Region restored to original extent."
-#~ msgstr "Region auf die ursprünglich Ausdehnung zurückgesetzt."
-#~ msgid "vector, network, centrality measures"
-#~ msgstr "Vektor, Netzwerk, Zentralitätsmaß"
-#~ msgid "Print all map connection parameters and exit in shell script style"
-#~ msgstr "Gibt alle Verbindungsparameter im Shellskript-Stil aus und beendet sich."
-#~ msgid "When printing, limit to layer specified by the layer option"
-#~ msgstr "Beim Druck auf die Layer in der Layer-Option beschränken"
-#~ msgid "Vector map <%s> is connected by:"
-#~ msgstr "Vectorkarte <%s> ist verbunden durch:"
-#~ msgid "%d features written"
-#~ msgstr "%d Feature geschrieben."
-#~ msgid "vector, network, components"
-#~ msgstr "Vektor, Netzwerk, Komponenten"
-#~ msgid "vector, geometry, sampling"
-#~ msgstr "Vektor, Geometrie, Stichproben"
-#~ msgid "Layer is only used for WHERE SQL statement"
-#~ msgstr "Layer wird nur für WHERE SQL Ausdrücke verwendet."
-#~ msgid "No features drapped. Check Your computational region and input raster map."
-#~ msgstr "Keine Feature wurden drapiert. Überprüfen Sie die aktuelle Region und die Eingabe-Rasterkarte."
-#~ msgid "vector, raster, aggregation"
-#~ msgstr "Vektor, Raster, Aggregation"
-#~ msgid "vector, raster, attribute table"
-#~ msgstr "Vektor, Raster, Attributtabelle"
-#~ msgid "vector, transformation, 3D"
-#~ msgstr "Vektor, Transformation, 3D"
-#~ msgid "Exports GRASS vector map layers to DXF file format."
-#~ msgstr "Exportiert GRASS Vektorkarten in das DXF-Dateiformat."
-#~ msgid "DXF output file"
-#~ msgstr "DXF Ausgabedatei."
-#~ msgid "vector, network, spanning tree"
-#~ msgstr "Vektor, Netzwerk, Spanning tree"
-#~ msgid "miscellaneous, distance"
-#~ msgstr "Verschiedenes, Distanz"
-#~ msgid "Reading file [%s]..."
-#~ msgstr "Lese Datei [%s]..."
-#~ msgid "Unable to determine raster cell type"
-#~ msgstr "Kann den Rasterzelltyp nicht bestimmen."
-#~ msgid "Unable to read raster row"
-#~ msgstr "Kann Rasterzeile nicht lesen."
-#~ msgid "visualization, raster, vector, raster3d"
-#~ msgstr "Visualisierung, Raster, Vektor, 3D-Raster"
-#~ msgid "Verbose module output"
-#~ msgstr "Gesprächige Modulausgabe"
-#~ msgid "Entering script mode ..."
-#~ msgstr "Betrete den Skriptmodus ..."
-#~ msgid "raster, keyword2, keyword3"
-#~ msgstr "Raster, Schlagwort 2, Schlagwort 3"
-#~ msgid "Unable to read file header of <%s>"
-#~ msgstr "Kann die Header-Datei für <%s> nicht lesen."
-#~ msgid "vector, keyword2, keyword3"
-#~ msgstr "Vektor, Schlagwort 2, Schlagwort 3"
-#~ msgid "postscript, map, printing"
-#~ msgstr "Postscript, Karte, Drucken"
-#~ msgid "List paper formats ( name width height left right top bottom(margin) )"
-#~ msgstr "Gebe Liste der Papierformate aus (Name Breite Höhe links rechts oben unten(Rand) )."
-#~ msgid "File containing mapping instructions (or use input=- to enter from keyboard)"
-#~ msgstr "Datei die Instruktionen zum Kartenzeichnen enthält (Oder benutzen Sie input=- für eine interaktive Eingabe über die Tastatur)."
-#~ msgid "PostScript output file"
-#~ msgstr "PostScript Ausgabedatei"
-#~ msgid "Scale of the output map, e.g. 1:25000 (default: Auto-sized to fit page)"
-#~ msgstr "Maßstab der Ausgabekarte, z.B. 1:25000 (standardmäßig: Anpassung an die Seite)"
-#~ msgid "Using <%s> from the command line is depreciated. Please use the <%s> mapping instruction instead. The parameter <%s> will be removed in future versions of GRASS."
-#~ msgstr "Die Verwendung von <%s> auf der Kommandozeile ist veraltet. Bitte verwenden Sie stattdessen die Kartierungsanweisung <%s>. Der Parameter <%s> wird in zukünftigen GRASS-Versionen nicht mehr vorhanden sein."
-#~ msgid "Current region cannot be set."
-#~ msgstr "Aktuelle Region kann nicht gesetzt werden."
-#~ msgid "GRASS environment variable GRASS_VERBOSE is overwritten by VERBOSE mapping instruction. This mapping instruction is superseded and will be removed in future versions of GRASS. Please use --verbose instead."
-#~ msgstr "Die GRASS Umgebungsvariable GRASS_VERBOSE wird überschrieben von der Kartierungsanweisung VERBOSE. Diese Kartierungsanweisung wurde ersetzt und wird in zukünftigen GRASS_Versionen nicht mehr enthalten sein. Bitte verwenden Sie stattdessen '--verbose'."
-#~ msgid "Cannot set GRASS_VERBOSE variable."
-#~ msgstr "Kann die GRASS_VERBOSE Variable nicht setzen."
-#~ msgid "PostScript file [%s] successfully written."
-#~ msgstr "Die PostScript Datei [%s] wurde erfolgreich geschrieben."
-#~ msgid "Reading raster maps in group <%s> ..."
-#~ msgstr "Lese Rasterkarte der Gruppe <%s> ..."
-#~ msgid "Scale set to %s."
-#~ msgstr "Maßstab gesetzt auf %s."
-#~ msgid "OGR driver: column '%s', OGR type %d  is not supported"
-#~ msgstr "OGR-Treiber: Spalte '%s', OGR Typ %d wird nicht unterstützt."
-#~ msgid "database, attribute table"
-#~ msgstr "Datenbank, Attributtabelle"
-#~ msgid "database, attribute table, SQL"
-#~ msgstr "Datenbank, Attributtabelle, SQL"
-#~ msgid "database, attribute table, connection settings"
-#~ msgstr "Datenbank, Attributtabelle, Verbindungseinstellungen"
-#~ msgid "Prints/sets general DB connection for current mapset and exits."
-#~ msgstr "Gibt oder setzt generelle Datenbankverbindung für das aktuelle Mapset und beendet sich."
-#~ msgid "Do not use this option if schemas are not supported by driver/database server"
-#~ msgstr "Bitte benutzen Sie diese Option nicht, wenn Schemas nicht durch ihre Datenbank / Server unterstützt werden."
-#~ msgid "database, SQL"
-#~ msgstr "Datenbank, SQL"
-#~ msgid "Name of file with sql statement"
-#~ msgstr "Name der Datei, die SQL-Befehle enthält"
-#~ msgid ""
-#~ "\n"
-#~ "Enter database password for connection\n"
-#~ "<%s:%s:user=%s>\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Geben Sie das Datenbank-Passwort zum Verbinden ein\n"
-#~ "<%s:%s:Benutzer=%s>\n"
-#~ msgid "Hit RETURN to cancel request\n"
-#~ msgstr "Drücke RETURN um Anfrage abzubrechen\n"
-#~ msgid "Exiting. Not changing current settings"
-#~ msgstr "Ende, ohne aktuelle Einstellungen zu verändern."
-#~ msgid "New password set"
-#~ msgstr "Neues Passwort gesetzt."
-#~ msgid "The password was stored in file"
-#~ msgstr "Das Passwort wurde in einer Datei gespeichert."
-#~ msgid "Divides active display into two frames & displays maps/executes commands in each frame."
-#~ msgstr "Teilt das aktive Grafikfenster in zwei Fenster & zeigt Karten und führt Befehle in beiden Fenstern aus."
-#~ msgid "Enter raster map to display in 1st frame"
-#~ msgstr "Geben Sie den Name der Rasterkarte ein, die im 1. Fenster gezeigt werden soll."
-#~ msgid "Enter command to execute in 1st frame"
-#~ msgstr "Geben Sie den Befehl an, der im 1. Rahmen ausgeführt werden soll."
-#~ msgid "Enter raster map to display in 2nd frame"
-#~ msgstr "Geben Sie den Name der Rasterkarte ein, die im 2. Fenster gezeigt werden soll."
-#~ msgid "Enter command to execute in 2nd frame"
-#~ msgstr "Geben Sie den Befehl an, der im 2. Rahmen ausgeführt werden soll."
-#~ msgid "How to split display"
-#~ msgstr "Wie das Fenster geteilt werden soll"
-#~ msgid "imagery, raster, multispectral"
-#~ msgstr "Bildverarbeitung, Raster, Multispektral"
-#~ msgid "Use image list and not group"
-#~ msgstr "Verwende eine Bild-Liste und keine Gruppe."
-#~ msgid "Select multiple points"
-#~ msgstr "Selektiere mehrere Punkte."
-#~ msgid "run non-interactively"
-#~ msgstr "nicht interaktiv"
-#~ msgid "Exports GRASS raster into GDAL supported formats."
-#~ msgstr "Exportiert GRASS-Rasterkarten in GDAL-unterstütze Formate."
-#~ msgid "Region sensitive output"
-#~ msgstr "Regionsensitive Ausgabe"
-#~ msgid "Creation option to the output format driver. Multiple options may be listed"
-#~ msgstr "Erstellungs-Optionen für den Ausgabeformat-Treiber. Es können mehrere Optionen angegeben werden."
-#~ msgid "Metadata key passed on the output dataset if possible"
-#~ msgstr "Metadaten werden, wen möglich, an den Ausgabedatensatz weitergegeben."
-#~ msgid "raster, elevation"
-#~ msgstr "Raster, Höhenwerte"
-#~ msgid "Convert coordinates from one projection to another (cs2cs frontend)."
-#~ msgstr "Konvertiert Koordinaten von einer Projektion zu einer Anderen (cs2cs Frontend)."
-#~ msgid "miscellaneous, projection"
-#~ msgstr "Verschiedenes, Projektion"
-#~ msgid "Input coordinate file (omit to read from stdin)"
-#~ msgstr "Eingabe-Koordinatendatei (auslassen für lesen von stdin)."
-#~ msgid "Script style output in CSV format respecting the field separator settings"
-#~ msgstr "Ausgabe im Skript-Style im CSV-Format unter Beachtung der Feldtrenner-Einstellungen."
-#~ msgid "Verbose mode (print projection parameters and filenames to stderr)"
-#~ msgstr "Gesprächiger Modus (Gebe Projektionsparameter und Dateinamen auf stderr aus)."
-#~ msgid "Saves the contents of the active display monitor to a graphics file."
-#~ msgstr "Speichert den Inhalte des aktiven Grafikfensters in einer Grafikdatei."
-#~ msgid "display, export"
-#~ msgstr "Anzeige, Export"
-#~ msgid "Name for output file (do NOT add extension)"
-#~ msgstr "Name für die Ausgabedatei (Fügen Sie keine Dateiendung an)."
-#~ msgid "Dimensions of output file versus current window size"
-#~ msgstr "Größe der Ausgabe-Datei im Vergleich zum aktuellen Grafikfenster."
-#~ msgid "(same=1, double size=2, quadruple size=4)"
-#~ msgstr "(einfach=1, doppelte Größe=2, vierfache Größe=4)"
-#~ msgid "Images"
-#~ msgstr "Bilder"
-#~ msgid "Width and height of output image (overrides resolution setting)"
-#~ msgstr "Breite und Höhe des auszugebenden Bildes (übersteuert die Einstellung der Auflösung)."
-#~ msgid "Compression for PNG files"
-#~ msgstr "Komprimierung für PNG-Dateien."
-#~ msgid "(0=none, 1=fastest, 9=most; lossless, only time vs. filesize)"
-#~ msgstr "(0=keine, 1=schnellste, 9=am meisten; verlustfrei, nur Zeit vs. Dateigröße)."
-#~ msgid "File size/quality for JPEG files"
-#~ msgstr "Dateigröße/-qualität für JPEG-Dateien."
-#~ msgid "(10=smallest/worst, 100=largest/best)"
-#~ msgstr "(10=kleinste/schlechteste, 100=größste/beste)"
-#~ msgid "Paper size for PostScript output"
-#~ msgstr "Papiergröße für die PostScript-Ausgabe"
-#~ msgid "PostScript"
-#~ msgstr "PostScript"
-#~ msgid "PostScript level (only limits functionality!)"
-#~ msgstr "PostScript Level (Limitiert nur die Funktionalität!)."
-#~ msgid "GeoTIFF creation option(s)"
-#~ msgstr "GeoTIFF Erzeugungsoption(en)"
-#~ msgid "GeoTIFF"
-#~ msgstr "GeoTIFF"
-#~ msgid "GeoTIFF metadata key(s) and value(s) to add"
-#~ msgstr "GeoTIFF Metadaten Schlüsselwort(e) und Wert(e)"
-#~ msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma."
-#~ msgstr "In der Form \"META-TAG=WERT\", trennen Sie mehrere Paare durch Kommas voneinander."
-#~ msgid "Set background color to black (white default)"
-#~ msgstr "Setze die Hintergrundfarbe auf schwarz (Standard: weiß)."
-#~ msgid "Set transparent background"
-#~ msgstr "Stelle Hintergrund auf transparent."
-#~ msgid "Use the Cario driver to render images"
-#~ msgstr "Verwende der Cairo-Treiber um das Bild zu rendern."
-#~ msgid "Set paper orientation to landscape (for PostScript output)"
-#~ msgstr "Stelle die Orientierung der Seite auf Querformat (für die PostScript-Ausgabe)."
-#~ msgid "Do not crop away margins"
-#~ msgstr "Schneide die Ränder nicht ab."
-#~ msgid "raster, tiling"
-#~ msgstr "Raster, Kachelung"
-#~ msgid "imagery, fusion, Brovey"
-#~ msgstr "Bildverarbeitung, Fusion, Brovery"
-#~ msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2)"
-#~ msgstr "Name der Eingabe-Rasterkarte (NIR: tm4 | qbird_nir | spot2)."
-#~ msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3)"
-#~ msgstr "Name der Eingabe-Rasterkarte (MIR; tm5 | qbird_red | spot3)."
-#~ msgid "general, extensions"
-#~ msgstr "Allgemein, Erweiterungen"
-#~ msgid "display, diagram"
-#~ msgstr "Anzeige, Diagramm"
-#~ msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
-#~ msgstr "Mosaikiert bis zu 4 Bilder und erweitert die Farbtabelle. Erzeugt *.mosaic-Karten."
-#~ msgid "raster, imagery, mosaicking"
-#~ msgstr "Raster, Bildverarbeitung, Mosaikieren"
-#~ msgid "1st map for mosaic (top of image stack)."
-#~ msgstr "1. Karte für das Mosaik (Spitze des Bildstapels)."
-#~ msgid "2nd map for mosaic."
-#~ msgstr "2. Bild für das Mosaik."
-#~ msgid "3rd map for mosaic."
-#~ msgstr "3. Bild für das Mosaik."
-#~ msgid "4th map for mosaic."
-#~ msgstr "4. Bild für das Mosaik."
-#~ msgid "raster, statistics, aggregation"
-#~ msgstr "Raster, Statistik, Aggregation"
-#~ msgid "Import SRTM HGT files into GRASS"
-#~ msgstr "Importiert SRTM HGT Dateien nach GRASS."
-#~ msgid "Reports geometry statistics for vectors."
-#~ msgstr "Gibt statistische Werte für Geometrie der Vektorobjekte aus."
-#~ msgid "vector, report, statistics"
-#~ msgstr "Vektor, Bericht, Statistik"
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
-#~ msgstr "mi(len),f(uß),me(ter),k(ilometer),a(cres),h(ektar)"
-#~ msgid "Value to update the column with (varchar values have to be in single quotes, e.g. 'grass')"
-#~ msgstr "Wert mit dem die Spalte aktualisiert werden soll (varchar-Werte müssen in einfachen Anführungszeichen angegeben werden, z.B. 'grass')."
-#~ msgid "Name of raster map to print in legend"
-#~ msgstr "Name der Rasterkarte, wie er in der Legende erscheinen soll."
-#~ msgid "Position of vertical map-legend separator (in percent)"
-#~ msgstr "Position der vertikalen Legenden Trennelemente (in Prozent)."
-#~ msgid "Export display monitor to a GpsDrive compatible backdrop image"
-#~ msgstr "Exportiert das Grafikfenster in ein GpsDrive-kompatibles Hintergrundbild."
-#~ msgid "display, export, GPS"
-#~ msgstr "Anzeige, Export, GPS"
-#~ msgid "name for new map image (lives in ~/.gpsdrive/maps/)"
-#~ msgstr "Name des neuen Kartenbildes (in ~/.gpsdrive/maps/)."
-#~ msgid "Make JPEG instead of PNG image"
-#~ msgstr "Erstelle ein JPEG anstelle des PNG Bildes."
-#~ msgid "general, manual, help"
-#~ msgstr "Allgemein, Handbuch, Hilfe"
-#~ msgid "sites, vector, import"
-#~ msgstr "Sites, Vektor, Import"
-#~ msgid "Run non-interactively"
-#~ msgid "raster, mask"
-#~ msgstr "Raster, Maske"
-#~ msgid "Raster map to use as MASK"
-#~ msgstr "Rasterkarte, die als Maske (MASK) verwendet werden soll."
-#~ msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
-#~ msgstr "Kategoriewerte, die für die Maske verwendet werden (Format: 1 2 3 thru 7 *)."
-#~ msgid "Create inverse MASK from specified 'maskcats' list"
-#~ msgstr "Erzeuge eine inverse Maske aus der angegebenen 'maskcats' Liste."
-#~ msgid "Overwrite existing MASK"
-#~ msgstr "Ãœberschreibe existierende Maske (MASK)."
-#~ msgid "Remove existing MASK (overrides other options)"
-#~ msgstr "Entferne existierende Maske (MASK). Ãœbersteuert andere Optionen."
-#~ msgid "vector, export, GPS"
-#~ msgstr "Vektor, Export, GPS"
-#~ msgid "The database must be in form printed by v.db.connect -g, i.e. with substituted variables"
-#~ msgstr "Die Datenbank muß in der Form angegeben werden , wie sie von v.db.connect -g ausgegeben wird, z.B mit ersetzten Variablen."
-#~ msgid "Georeference, rectify and import Terra-ASTER imagery and relative DEM's using gdalwarp."
-#~ msgstr "Georeferenziere, rektifiziere und importiere Terra-ASTER-Bilder und relative DGMs mit Hilfe von gdalwarp."
-#~ msgid "raster, imagery, import"
-#~ msgstr "Raster, Bildverarbeitung, Import"
-#~ msgid "L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a single band"
-#~ msgstr "L1A oder L1B Kanal zum Umrechnen (1, 2, 3n, 3b, 4-14). kann nur ein einzelnen Kanal umrechnen."
-#~ msgid "Set color rules for features in a vector using a numeric attribute column."
-#~ msgstr "Bestimme Farbregeln für Feature einer Vektorkarte unter Verwendung einer numerischen Spalte der Attributtabelle."
-#~ msgid "vector, color table"
-#~ msgstr "Vektor, Farbtabellen"
-#~ msgid "Layer number of data column"
-#~ msgstr "Layernummer der Datenspalte"
-#~ msgid "Name of color column to populate"
-#~ msgstr "Name der Farbspalte, die gefüllt werden soll."
-#~ msgid "Redraws the current display frame in the GRASS monitor"
-#~ msgstr "Zeichnet aktives Fenster im GRASS Grafikfenster erneut."
-#~ msgid "Redraw all frames"
-#~ msgstr "Zeichnen aller Fenster erneut."
-#~ msgid "Do not preserve individual regions when redrawing all frames"
-#~ msgstr "Erhalte keine individuellen Regionen beim Neuzeichnen aller Fenster."
-#~ msgid "Slide show of GRASS raster/vector maps."
-#~ msgstr "Diashow der GRASS Raster- / Vektorkarten."
-#~ msgid "display, slideshow"
-#~ msgstr "Anzeige, Diashow"
-#~ msgid "Show vector maps rather than raster maps"
-#~ msgstr "Zeige eher Vektorkarten als Rasterkarten."
-#~ msgid "Map prefix. Specify character(s) to view selected maps only"
-#~ msgstr "Karten-Präfix. Bestimmen Sie Buchstaben um nur ausgewählte Karten anzusehen."
-#~ msgid "Map number show across the monitor"
-#~ msgstr "Zeige die Kartenummer waagerecht im Grafikfenster."
-#~ msgid "Map number show down the monitor"
-#~ msgstr "Zeige die Kartenummer senkrecht im Grafikfenster."
-#~ msgid "Mapsets to use. Specify multiple mapsets comma separated"
-#~ msgstr "ZU verwendendes Mapset. Geben Sie mehrere Mapsets durch Kommas getrennt an."
-#~ msgid "Number of seconds to pause between slides"
-#~ msgstr "Pause zwischen den Bildern in Sekunden."
-#~ msgid "Download waypoints, routes, and tracks from a Garmin GPS receiver into a vector map."
-#~ msgstr "Lade Wegpunkte, Routen und Tracks von einem Garmin GPS Gerät in eine Vektorkarte."
-#~ msgid "vector, import, GPS"
-#~ msgstr "Vektor, Import, GPS"
-#~ msgid "Download Waypoints from GPS"
-#~ msgstr "Lade Wegpunkte vom GPS."
-#~ msgid "Download Routes from GPS"
-#~ msgstr "Lade Routen vom GPS."
-#~ msgid "Download Track from GPS"
-#~ msgstr "Lade Track vom GPS."
-#~ msgid "Force import of track or route data as points"
-#~ msgstr "Erzwinge den Import von Tracks oder Routen als Punkte."
-#~ msgid "Use gardump instead of gpstrans as the download program"
-#~ msgstr "Verwende gardump anstelle von gpstrans zum herunterladen."
-#~ msgid "Import track in 3D (gardump only)"
-#~ msgstr "Importiere Track in 3D (nur gardump)."
-#~ msgid "Do not attempt projection transform from WGS84"
-#~ msgstr "Versuche keine Transformation der Projektion von WGS84."
-#~ msgid "Port Garmin receiver is connected to"
-#~ msgstr "Das Garmin-Gerät ist verbunden mit Port "
-#~ msgid "Split the display into subframes."
-#~ msgstr "Teile das Fenster in Unterfenster."
-#~ msgid "Number of subframes"
-#~ msgstr "Anzahl der Unterfenster."
-#~ msgid "Split horizontally not vertically"
-#~ msgstr "Teile horizontal und nicht vertikal."
-#~ msgid "vector, import, gazetteer"
-#~ msgstr "Vektor, Import, Gazetteer"
-#~ msgid "Calculates univariate statistics from a raster map based on vector polygons and uploads statistics to new attribute columns."
-#~ msgstr "Berechnet Kennzahlen univariater Statistik einer Rasterkarte für Polygone und fügt die Ergebnisse als neue Spalte der Attributtabelle an."
-#~ msgid "Name of vector polygon map"
-#~ msgstr "Name der Vektorkarte (Polygone)."
-#~ msgid "A single vector map can be connected to multiple database tables. This number determines which table to use"
-#~ msgstr "Eine einzelne Vektorkarte kann mit mehreren Datenbanktabellen verbunden sein. Diese Zahl bestimmt welche Tabelle verwendet werden soll."
-#~ msgid "Name of raster map to calculate statistics from"
-#~ msgstr "Name der Rasterkarte für die Statistiken berechnet werden sollen."
-#~ msgid "Display manager for GRASS"
-#~ msgstr "Manager der Grafikausgabe für GRASS."
-#~ msgid "Name of .dmrc settings file"
-#~ msgstr "Name der .dmrc Datei."
-#~ msgid "GIS manager for GRASS"
-#~ msgstr "GIS-Manager für GRASS."
-#~ msgid "Name of GIS manager settings file (.grc)"
-#~ msgstr "Name der Datei mit den Einstellungen des GIS-Managers (.grc)."
-#~ msgid "Resizes active display monitor"
-#~ msgstr "Ändere die Größe des aktiven Grafikfenster."
-#~ msgid "New width for window"
-#~ msgstr "Neue Fensterbreite."
-#~ msgid "New height for window"
-#~ msgstr "Neue Fensterhöhe."
-#~ msgid "calculates univariate statistics from a GRASS raster map"
-#~ msgstr "Berechnet univariate Statistiken einer GRASS Rasterkarte."
-#~ msgid "extended statistics (quartiles and percentile)"
-#~ msgstr "Mehr statistische Kennzahlen (Quartile und Perzentile)."
-#~ msgid "Percentile to calculate (requires -e flag)"
-#~ msgstr "Zu berechnendes Perzentil (erfordert den Schalter -e)."
-#~ msgid "Calculate new raster map from a r.mapcalc expression."
-#~ msgstr "Berechne eine neue Rasterkarte mit einem r.mapcalc-Ausdruck. "
-#~ msgid "A"
-#~ msgstr "A"
-#~ msgid "B"
-#~ msgstr "B"
-#~ msgid "C"
-#~ msgstr "C"
-#~ msgid "D"
-#~ msgstr "D"
-#~ msgid "E"
-#~ msgstr "E"
-#~ msgid "F"
-#~ msgstr "F"
-#~ msgid "Formula (e.g. A-B or A*C+B)"
-#~ msgstr "Formel (z.B. A-B oder A*C+B)"
-#~ msgid "Show help"
-#~ msgstr "Zeige die Hilfe an."
-#~ msgid "Expert mode (enter a set of r.mapcalc expressions)"
-#~ msgstr "Expertenmodus (Geben Sie ein Satz von r.mapcalc Ausdrücken an)."
-#~ msgid "Do not overwrite existing map"
-#~ msgstr "Ãœberschreibe nicht eine bereits existierende Karte."
-#~ msgid "raster, imagery, colors"
-#~ msgstr "Raster, Bildverarbeitung, Farben"
-#~ msgid "Selects/starts specified monitor at specified size"
-#~ msgstr "Selektiert/Startet das angegebene Grafikfenster in der angegebenen Größe."
-#~ msgid "Display monitor to start"
-#~ msgstr "Grafikfensters, das gestartet werden soll."
-#~ msgid "Width in pixels of new display monitor"
-#~ msgstr "Breite des neuen Grafikfensters in Pixel."
-#~ msgid "Height in pixels of new display monitor"
-#~ msgstr "Höhe des neuen Grafikfensters in Pixel."
-#~ msgid "Import waypoints, routes, and tracks from a GPS receiver or GPS download file into a vector map."
-#~ msgstr "Importiert Wegpunkte, Routen und Tracks von einem GPS-Gerät oder einer GPS-Download-Datei in eine Vektorkarte. "
-#~ msgid "Import waypoints"
-#~ msgstr "Importiere Wegpunkte"
-#~ msgid "Import routes"
-#~ msgstr "Importiere Routen"
-#~ msgid "Import track"
-#~ msgstr "Importiere Tracks."
-#~ msgid "Force vertices of track or route data as points"
-#~ msgid "Device or file used to import data"
-#~ msgstr "Gerät oder Datei, von der Daten importiert werden sollen.ei."
-#~ msgid "Format of GPS input data (use gpsbabel supported formats)"
-#~ msgstr "Format der GPS-Inputdaten (verwenden Sie von gpsbabel unterstützte Formate)."
-#~ msgid "Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is assumed"
-#~ msgstr "Projektion der Inputdaten (PROJ.4 Stil). Wenn nicht angegeben, wird Lat/Lon WGS84 angenommen."
-#~ msgid "Folder to save downloaded data to"
-#~ msgstr "Verzeichnis um heruntergeladene Daten zu speichern."
-#~ msgid "Additional options for wget"
-#~ msgstr "Weitere Optionen für wget"
-#~ msgid "Additional options for curl"
-#~ msgstr "Weitere Optionen für curl"
-#~ msgid "Set color rules based on stddev from a map's mean value."
-#~ msgstr "Bestimme Farbregeln basierend auf den Standardabweichungen."
-#~ msgid "raster, elevation, interpolation"
-#~ msgstr "Vektor, Höhenwerte, Interpolation"
-#~ msgid "vector, area, dissolve"
-#~ msgstr "Raster, Fläche, Dissolve"
-#~ msgid "Layer number. If -1, all layers are extracted."
-#~ msgstr "Layernummer: Wenn -1 angegeben wird, werden alle Layer ausgewählt."
-#~ msgid "vector, centroid, area"
-#~ msgstr "Vektor, Zentroid, Fläche"
-#~ msgid "Calculates new grid3D volume from r3.mapcalc expression."
-#~ msgstr "Berechnet neues grid3D Volumen mittels eines r3.mapcalc-Ausdruck."
-#~ msgid "A (grid3D file)"
-#~ msgstr "A (grid3D file)"
-#~ msgid "B (grid3D file)"
-#~ msgstr "B (grid3D file)"
-#~ msgid "C (grid3D file)"
-#~ msgstr "C (grid3D file)"
-#~ msgid "D (grid3D file)"
-#~ msgstr "D (grid3D file)"
-#~ msgid "E (grid3D file)"
-#~ msgstr "E (grid3D file)"
-#~ msgid "F (grid3D file)"
-#~ msgstr "F (grid3D file)"
-#~ msgid "Name for output grid3D volume"
-#~ msgstr "Name für das Ausgabe-grid3D-Volumen"
-#~ msgid "Expert mode (enter a set of r3.mapcalc expressions)"
-#~ msgstr "Expertenmodus (Geben Sie ein Satz von r3.mapcalc Befehlen an)."
-#~ msgid "raster, imagery"
-#~ msgstr "Raster, Bilder"
-#~ msgid "Import GetFeature from WFS"
-#~ msgstr "Importiert GetFeature eines WFS."
-#~ msgid "Output shaded relief map name"
-#~ msgstr "Name der Schummerungskarte."
-#~ msgid "Saves active display monitor to PNG file in home directory"
-#~ msgstr "Speichert den Inhalt des aktiven Grafikfensters in einer PNG-Datei im Heimat-Verzeichnis."
-#~ msgid "Name of PNG file"
-#~ msgstr "Name der PNG-Datei."
-#~ msgid "Resolution of output file (single=1, double=2, quad=4)"
-#~ msgstr "Auflösung der Ausgabe-Datei (einfach=1, doppelt=2, vierfach=4)."
-#~ msgid "raster, imagery, statistics"
-#~ msgstr "Raster, Bildverarbeitung, Statistik"
-#~ msgid "Configuration editor for r.li.'index'"
-#~ msgstr "Konfigurationseditor für r.li.'index'."
-#~ msgid "raster, landscape structure analysis"
-#~ msgstr "Raster, Landschaftsstruktur Analyse"
-#~ msgid "Import of SPOT VGT NDVI file into a raster map"
-#~ msgstr "Importiert SPOT VGT NDVI Datei in eine Rasterkarte."
-#~ msgid "existing SPOT VGT NDVI HDF file (0001_NDV.HDF)"
-#~ msgstr "Existierende SPOT VGT NDVI HDF Datei (z.B. 0001_NDV.HDF)."
-#~ msgid "Moves displayed maps to another monitor"
-#~ msgstr "Verschiebt angezeigte Karten in ein anderes Grafikfenster."
-#~ msgid "clear target monitor before moving"
-#~ msgstr "Lösche das Ziel-Fenster vor dem Verschieben."
-#~ msgid "stay with source monitor"
-#~ msgstr "Bleib im Quell -Grafikfenster."
-#~ msgid "kill source monitor after moving"
-#~ msgstr "Beende das Quell-Fenster nach dem Verschieben."
-#~ msgid "Target monitor"
-#~ msgstr "Ziel Grafikfenster."
-#~ msgid "Source monitor"
-#~ msgstr "Quell Grafikfenster."
-#~ msgid "pyramid constructed."
-#~ msgstr "Pyramide erstellt."
-#~ msgid "imagery, classification, supervised, SMAP"
-#~ msgstr "Bildverarbeitung, Klassifikation, überwacht, SMAP"
-#~ msgid "imagery, image transformation, PCA"
-#~ msgstr "Bildverarbeitung, Bildtransformation, PCA"
-#~ msgid "imagery, edges"
-#~ msgstr "Bildverarbeitung, Kanten"
-#~ msgid "Error while reading input raster map."
-#~ msgstr "Fehler beim Lesen der Eingabe-Rasterkarte."
-#~ msgid "imagery, rectify"
-#~ msgstr "Bildverarbeitung, Rektifikation"
-#~ msgid ""
-#~ "Input raster map <%s> does not exist in group <%s>.\n"
-#~ " Try:\n"
-#~ msgstr ""
-#~ "Eingabe-Rasterkarte <%s> existiert nicht in der Gruppe <%s>.\n"
-#~ " Versuche:\n"
-#~ msgid "into  <%s@%s> (location <%s>) ... %s"
-#~ msgstr "nach <%s@%s> (Location <%s>) ... %s"
-#~ msgid "data compression required an additional"
-#~ msgstr "Datenkompression erfordert einen zusätzlichen"
-#~ msgid "Error while writing to temp file"
-#~ msgstr "Fehler beim Schreiben in die temp-Datei."
-#~ msgid "Rectified input raster map <%s> will be saved as <%s>"
-#~ msgstr "Habe die Eingabe-Rasterkarte <%s> rektifiziert. Sie wird als <%s> gespeichert."
-#~ msgid "imagery, geometry"
-#~ msgstr "Bildverarbeitung, Geometrie"
-#~ msgid "Unable to allocate the input row buffer"
-#~ msgstr "Kann keinen Speicher für Eingabe-Zeilenbuffer reservieren."
-#~ msgid "imagery, color transformation, RGB, HIS"
-#~ msgstr "Bildverarbeitung, Farbtransformation, RGB, HIS"
-#~ msgid "Unable to read raster map row %ld"
-#~ msgstr "Kann die Zeile %ld der Rasterkarte nicht lesen."
-#~ msgid "Failed writing raster map row %ld"
-#~ msgstr "Schreiben der Zeile %ld der Rasterkarte fehlgeschlagen."
-#~ msgid "imagery, FFT"
-#~ msgstr "Bildverarbeitung, FFT"
-#~ msgid "Unable to open real-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
-#~ msgstr "Kann das Realteil-Bild im 'cell_misc' Ordner nicht öffnen. Rasterkarte wurde wahrscheinlich nicht mit i.fft erstellt."
-#~ msgid "Unable to open imaginary-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
-#~ msgstr "Kann das Bild mit dem imaginären Teil im 'cell_misc' Ordner nicht öffnen. Eingabekarte wurde wahrscheinlich nicht mit i.fft erstellt."
-#~ msgid "Power 2 values: %d rows %d columns"
-#~ msgstr "'hoch zwei'-Werte: %d Zeilen %d Spalten."
-#~ msgid "Writing data..."
-#~ msgstr "Schreibe Daten..."
-#~ msgid "imagery, statistics"
-#~ msgstr "Bildverarbeitung, Statistik"
-#~ msgid "Illegal group name <%s>"
-#~ msgstr "Unzulässiger Gruppen-Name <%s>."
-#~ msgid "Illegal subgroup name <%s>"
-#~ msgstr "Unzulässiger Untergruppenname <%s>."
-#~ msgid "Illegal signature file name <%s>"
-#~ msgstr "Unzulässiger Signaturdateiname <%s>."
-#~ msgid ""
-#~ "Subgroup too large.  Maximum number of bands is %d\n"
-#~ msgstr "Untergruppe ist zu groß. Die Maximalanzahl der Kanäle ist %d."
-#~ msgid "Error reading cell map during transform."
-#~ msgstr "Fehler beim Lesen der Rasterkarte während der Transformation."
-#~ msgid "Error writing cell map during transform."
-#~ msgstr "Fehler beim Schreiben der Rasterkarte während der Transformation."
-#~ msgid "imagery, orthorectify"
-#~ msgstr "Bildverarbeitung, Orthorektifikation"
-#~ msgid "Interactively creates or modifies entries in a camera initial exposure station file for imagery group referenced by a sub-block."
-#~ msgstr "Erzeugt oder ändert interaktiv Einträge in der Datei mit der Anfangsposition der Kamera für die Bildgruppe referenziert durch Unterblöcke."
-#~ msgid "Name of imagery group for ortho-rectification"
-#~ msgstr "Name der Bildgruppe für Orthorektifikation."
-#~ msgid "Group [%s] not found"
-#~ msgstr "Gruppe [%s] nicht gefunden."
-#~ msgid "Interactively select and modify the imagery group camera reference file."
-#~ msgstr "Wähle und ändere die Kamerareferenzdatei der Bildgruppe interaktiv."
-#~ msgid "Name of camera reference file to use"
-#~ msgstr "Name der zu verwendenden Kamerareferenzdatei."
-#~ msgid "Enter a camera reference file to be used with this imagery group"
-#~ msgstr "Geben Sie eine Kamerareferenzdatei ein, die mit dieser Bildgruppe verwendet werden soll."
-#~ msgid "Group [%s] in location [%s] mapset [%s] now has camera file [%s]"
-#~ msgstr "Die Gruppe [%s] in der Location [%s] Mapset [%s] hat jetzt die Kameradatei [%s]."
-#~ msgid "Interactively mark fiducial or reseau points on an image."
-#~ msgstr "Markiere Rahmenmarken oder Reseaupunkte interaktiv in einem Bild."
-#~ msgid "Image Group [%s] not found"
-#~ msgstr "Bildgruppe [%s] nicht gefunden."
-#~ msgid "No camera reference file selected for group [%s]"
-#~ msgstr "Keine Kamerareferenzdatei ausgewählt für die Gruppe [%s]."
-#~ msgid "Bad format in camera file for group [%s]"
-#~ msgstr "Schlechtes Format in der Kamerareferenzdatei der Gruppe [%s]."
-#~ msgid "Calculating camera angle to local surface..."
-#~ msgstr "Berechne Kamerawinkel zur lokalen Oberfläche..."
-#~ msgid "Could not open elevation raster"
-#~ msgstr "Kann die Rasterkarte mit Höheninformationen nicht öffnen."
-#~ msgid "Orthorectifies an image by using the image to photo coordinate transformation matrix."
-#~ msgstr "Orthorektifiziert ein Bild mittels der Foto zu Koordinaten Transformationsmatrix."
-#~ msgid "Raster map with camera angle relative to ground surface"
-#~ msgstr "Rasterkarte mit Kamerawinkel relativ zur Oberfläche"
-#~ msgid "Could not read REF file for group <%s>"
-#~ msgstr "Konnte REF-Datei der Gruppe <%s> nicht lesen."
-#~ msgid "No camera reference file selected for group <%s>"
-#~ msgstr "Keine Kamerareferenzdatei ausgewählt für die Gruppe <%s>."
-#~ msgid "Bad format in initial exposure station file for group <%s>"
-#~ msgstr "Schlechtes Format in der Anfangs-Kameraposition für die Gruppe <%s>."
-#~ msgid "No target elevation model selected for group <%s>"
-#~ msgstr "Kein Ziel-Höhenmodell ausgewählt für die Gruppe <%s>."
-#~ msgid "Error reading segment file"
-#~ msgstr "Fehler beim Lesen der Segment-Datei."
-#~ msgid ""
-#~ "Control Z Point file for group [%s] in [%s] \n"
-#~ " \n"
-#~ msgstr ""
-#~ "Datei mit Kontroll-Z-Punkten für Gruppe [%s] in [%s] \n"
-#~ "\n"
-#~ msgid "Computing equations..."
-#~ msgstr "Berechne Gleichungen..."
-#~ msgid "Poorly placed Control Points!\n"
-#~ msgstr "Schlecht platzierte Kontrollpunkte!\n"
-#~ msgid "Can not generate the transformation equation.\n"
-#~ msgstr "Kann die Transformationsgleichung nicht erstellen.\n"
-#~ msgid "Run OPTION 7 of i.ortho.photo again!\n"
-#~ msgstr "Führe OPTION 7 von i.ortho.photo noch einmal aus!\n"
-#~ msgid "No active Control Points!\n"
-#~ msgstr "Keine aktiven Kontrollpunkte!\n"
-#~ msgid "Run OPTION 7 of i.ortho.photo!\n"
-#~ msgstr "Führe OPTION 7 von i.ortho.photo aus!\n"
-#~ msgid ""
-#~ "Reference Point file for group [%s] in [%s] \n"
-#~ " \n"
-#~ msgstr ""
-#~ "Datei mit den Kontrollpunkten für Gruppe [%s] [%s]\n"
-#~ "\n"
-#~ msgid "Poorly placed Reference Points!\n"
-#~ msgid "Run OPTION 5 of i.ortho.photo again!\n"
-#~ msgstr "Führe OPTION 5 von i.ortho.photo noch einmal aus!\n"
-#~ msgid "No active Reference Points!\n"
-#~ msgid "Run OPTION 5 of i.ortho.photo!\n"
-#~ msgstr "Führe OPTION 5 von i.ortho.photo aus!\n"
-#~ msgid "Target information for group <%s> missing.\n"
-#~ msgstr "Ziel-Information für die Gruppe <%s> fehlt.\n"
-#~ msgid "Target location <%s> not found\n"
-#~ msgstr "Ziel-Location <%s> nicht gefunden\n"
-#~ msgid "permission denied\n"
-#~ msgstr "Zugriff verweigert.\n"
-#~ msgid "not found\n"
-#~ msgstr "nicht gefunden\n"
-#~ msgid " %d rows, %d cols (%ld cells) completed in "
-#~ msgstr "%d Zeilen, %d Spalten (%ld Zellen) vollständig in "
-#~ msgid " %.1f cells per minute\n"
-#~ msgstr " %.1f Zellen pro Minute\n"
-#~ msgid "No elevation available at row = %d, col = %d"
-#~ msgstr "Keine Höhe in Zeile %d, Spalte %d vorhanden."
-#~ msgid "Interactively select or modify the target elevation model."
-#~ msgstr "Wähle oder Ändere das Ziel-Höhenmodell interaktiv."
-#~ msgid "Target information for group [%s] missing\n"
-#~ msgstr "Ziel-Information für die Gruppe [%s] fehlt.\n"
-#~ msgid "Target location [%s] not found\n"
-#~ msgstr "Ziel-Location [%s] nicht gefunden.\n"
-#~ msgid "Mapset [%s] in target location [%s] - "
-#~ msgstr "Mapset [%s] in Ziel-Location [%s] - "
-#~ msgid "Creates control points on an image to be ortho-rectified."
-#~ msgstr "Erzeuge Kontrollpunkte in einem Bild, welches orthorektifiziert werden soll."
-#~ msgid "Name of image to be rectified which will be initially drawn on screen"
-#~ msgstr "Name der Karte, die rektifiziert werden soll, diese wird anfänglich auf dem Bildschirm dargestellt."
-#~ msgid "Name of a map from target mapset which will be initially drawn on screen"
-#~ msgstr "Name einer Karte im Zielmapset, welche anfänglich auf dem Bildschirm dargestellt wird."
-#~ msgid "No initial camera exposure station for group [%s]"
-#~ msgstr "Keine Anfangs-Kameraposition für die Gruppe [%s]."
-#~ msgid "Bad format in initial camera exposure station for group [%s]"
-#~ msgstr "Schlechtes Format in der Anfangs-Kameraposition für die Gruppe [%s]."
-#~ msgid "No photo points for group [%s]"
-#~ msgstr "Keine Bildpositionen für die Gruppe [%s]."
-#~ msgid "Poorly placed photo points for group [%s]"
-#~ msgstr "Schlecht platzierte Bildpositionen für die Gruppe [%s]."
-#~ msgid "Computing equations ..."
-#~ msgid "Unable to read raster header of <%s>"
-#~ msgstr "Kann den Header des Rasters <%s> nicht lesen."
-#~ msgid "Interactively select or modify the imagery group target."
-#~ msgstr "Wähle oder ändere das Ziel der Bildgruppe interaktiv."
-#~ msgid "Group [%s] targeted for location [%s], mapset [%s]"
-#~ msgstr "Gruppe [%s] zielt auf Location [%s], Mapset [%s]."
-#~ msgid "Menu driver for the photo imagery programs."
-#~ msgstr "Menü-Treiber für die Photo-/Bildverarbeitungs-Programme."
-#~ msgid "Pre-selected group <%s> not found"
-#~ msgstr "Vorher gewählte Gruppe <%s> nicht gefunden."
-#~ msgid "Enter imagery group for ortho-rectification"
-#~ msgstr "Geben Sie die Bildgruppe für die Orthorektifikation ein."
-#~ msgid "Group [%s] contains no files"
-#~ msgstr "Die Gruppe [%s] enthält keine Dateien."
-#~ msgid "Could not read REF file for group [%s]"
-#~ msgstr "Kann die REF-Datei für Gruppe [%s] nicht lesen."
-#~ msgid "Orthorectification cancelled"
-#~ msgstr "Georeferenzierung abgebrochen"
-#~ msgid "No files in this group!"
-#~ msgstr "Keine Dateien in dieser Bildgruppe."
-#~ msgid ""
-#~ "\n"
-#~ "Rectify all images in the group? "
-#~ msgstr ""
-#~ "\n"
-#~ "Rektifiziere alle Rasterkarten der Gruppe? "
-#~ msgid ""
-#~ "\n"
-#~ "Rectify image <%s>? "
-#~ msgstr ""
-#~ "\n"
-#~ "Rektifiziere Bild <%s>? "
-#~ msgid ""
-#~ "\n"
-#~ "No images selected, orthorectification cancelled."
-#~ msgstr ""
-#~ "\n"
-#~ "Kein Bild ausgewählt, Georeferenzierung abgebrochen."
-#~ msgid "Enter an extension to be appended to rectified maps:"
-#~ msgstr "Gebe Sie eine Erweiterung für die rektifizierten Karten ein:"
-#~ msgid ""
-#~ "\n"
-#~ "Choose another extension? "
-#~ msgstr ""
-#~ "\n"
-#~ "Auswahl einer anderen Erweiterung? "
-#~ msgid ""
-#~ "\n"
-#~ "Compute local camera angle? "
-#~ msgstr ""
-#~ "\n"
-#~ "Berechne lokale Kamerawinkel? "
-#~ msgid "Enter a name for the camera angle map:"
-#~ msgstr "Geben Sie einen Namen für die Karte mit den Kamera-Winkelangaben ein:"
-#~ msgid "Map name <%s> is illegal"
-#~ msgstr "Kartenname <%s> ist ein ungültiger Name."
-#~ msgid ""
-#~ "\n"
-#~ "Choose another name? "
-#~ msgstr ""
-#~ "\n"
-#~ "Wähle eine anderen Namen?"
-#~ msgid ""
-#~ "\n"
-#~ "Overwrite maps in target location/mapset? "
-#~ msgstr ""
-#~ "\n"
-#~ "Ãœberschreibe Karten in Ziel-Location/Mapset? "
-#~ msgid "Please select one of the following interpolation methods\n"
-#~ msgstr "Wählen sie eine der folgenden Interpolations-Methoden aus\n"
-#~ msgid " 1. nearest neighbor\n"
-#~ msgstr " 1. nearest neighbor\n"
-#~ msgid " 2. bilinear\n"
-#~ msgstr " 2. bilinear\n"
-#~ msgid " 3. bicubic\n"
-#~ msgstr " 3. bikubisch\n"
-#~ msgid " 4. bilinear with fallback\n"
-#~ msgstr " 4. bilinear mit Ausweichlösung\n"
-#~ msgid " 5. bicubic with fallback\n"
-#~ msgstr " 5. bicubic mit Ausweichlösung\n"
-#~ msgid "Enter amount of memory to use in MB, or\n"
-#~ msgstr "Gebe Speichergröße in MB an, oder\n"
-#~ msgid "RETURN   use %d MB to keep all data in RAM\n"
-#~ msgstr "RETURN   verwende %d MB um alle Daten im RAM zu halten\n"
-#~ msgid "RETURN   use %d MB\n"
-#~ msgstr "RETURN   verwende %d MB\n"
-#~ msgid "Range of values in output display files"
-#~ msgstr "Wertebereich in den Ausgabedateien."
-#~ msgid "Range less than or equal to zero not allowed"
-#~ msgstr "Bereich kleiner oder gleich Null ist nicht zulässig."
-#~ msgid "Writing viewable versions of transformed data..."
-#~ msgstr "Schreibe sichtbare Versionen der transformierten Daten..."
-#~ msgid "Unable to open file in the 'cell_misc' directory"
-#~ msgstr "Kann Datei im 'cell_misc' Verzeichnis nicht öffnen."
-#~ msgid "usage: %s file [prompt %%x %%y]\n"
-#~ msgstr "Verwendung: %s Datei [Prompt %%x %%y]\n"
-#~ msgid "name=%s\n"
-#~ msgstr "Name=%s\n"
-#~ msgid "mapset=%s\n"
-#~ msgstr "Mapset=%s\n"
-#~ msgid "fullname=%s\n"
-#~ msgstr "Voller Name=%s\n"
-#~ msgid "imagery, classification, supervised, MLC"
-#~ msgstr "Bildverarbeitung, Klassifikation, überwacht, MLC"
-#~ msgid "imagery, classification, signatures"
-#~ msgstr "Bildverarbeitung, Klassifikation, Signaturen"
-#~ msgid "imagery, map management"
-#~ msgstr "Bildverarbeitung, Kartenverwaltung"
-#~ msgid "imagery, classification, MLC"
-#~ msgstr "Bildverarbeitung, Klassifikation, MLC"
-#~ msgid "imagery, classification"
-#~ msgstr "Bildverarbeitung, Klassifikation"
-#~ msgid "Unable to read cell header for first band file"
-#~ msgstr "Kann den Zell-Header des ersten Kanals nicht lesen."
-#~ msgid "Unable to open band files."
-#~ msgstr "Kann die Band-Dateien nicht öffnen."
-#~ msgid "Unable to open the cell map MASK."
-#~ msgstr "Kann die Maske (MASK) der 'CELL'-Karte nicht öffnen."
-#~ msgid "Unable to allocate the cell buffer in display_signature()."
-#~ msgstr "Kann keinen Speicher für Zellbuffer in display_signature() reservieren."
-#~ msgid "Did not find input cell map MASK."
-#~ msgstr "Kann die Maske (MASK) der Input-'CELL'-Karte nicht finden."
-#~ msgid "Error reading raster map in function readbands."
-#~ msgstr "Fehler beim Lesen der Rasterkarte in der Funktion readbands."
-#~ msgid "vector, networking"
-#~ msgstr "Vektor, Netzwerk"
-#~ msgid "raster, vector, visualization"
-#~ msgstr "Raster, Vektor, Visualisierung"
-#~ msgid "Selects data from table."
-#~ msgstr "Selektiert Daten einer Tabelle."
-#~ msgid "Swapping header data"
-#~ msgstr "Tausche Headerinformationen"
-#~ msgid "Exporting raster as double values (bytes=%d)"
-#~ msgstr "Exportiere Rasterkarte als Double-Werte (Byte=%d)."
-#~ msgid "Reading map"
-#~ msgstr "Lese Karte"
-#~ msgid "Signed data (high bit means negative value)"
-#~ msgstr "Signed Daten (hohes Bit meint negative Werte)"
-#~ msgid "Number of bytes per cell (1, 2, 4)"
-#~ msgstr "Anzahl der Bytes pro Zelle (1, 2, 4)"
-#~ msgid "Parsing bytes per cell"
-#~ msgstr "Analysiere Bytes per Zelle."
-#~ msgid "Byte Swapping Turned On."
-#~ msgstr "Byte Swapping eingeschaltet."
-#~ msgid ""
-#~ "Missing parameters ...\n"
-#~ "Must provide at least[north= south= east= west=] OR [r=\tc=]"
-#~ msgstr ""
-#~ "Fehlende Parameter ...\n"
-#~ "Sie müssen zumindest [north= south= east= west=] OR [r=\tc=] angeben."
-#~ msgid "You have to provide all limits of geographic region (n,s,e,w)"
-#~ msgstr "Sie müssen alle Grenzen der geographischen Region (n,s,e,w) angeben."
-#~ msgid "Illegal number of rows <%s>"
-#~ msgstr "Ungültiger Zeilenanzahl <%s>."
-#~ msgid "Illegal number of columns <%s>"
-#~ msgstr "Ungültiger Spaltenanzahl <%s>."
-#~ msgid "Using N=%f S=%f E=%f W=%f"
-#~ msgstr "Verwende N=%f S=%f E=%f W=%f"
-#~ msgid "Using rows=%d cols=%d\n"
-#~ msgstr "Verwende Zeilen=%d Spalten=%d\n"
-#~ msgid "File Size %d ... Total Bytes %d"
-#~ msgstr "Dateigröße %d ... Gesamt-Bytes %d"
-#~ msgid "Try bytes=%d or adjusting input parameters"
-#~ msgstr "Versuchen Sie bytes=%d oder passen Sie die Eingabe-Parameter an."
-#~ msgid "Conversion failed at row %d"
-#~ msgstr "Konvertierung in Zeile %d fehlgeschlagen."
-#~ msgid "<%s> created"
-#~ msgstr "<%s> erzeugt."
-#~ msgid "Raster map to be displayed"
-#~ msgstr "Rasterkarte, die angezeigt werden soll."
-#~ msgid "Poorly placed psuedo control points. "
-#~ msgstr "Schlecht platzierte Pseudo-Kontrollpunkte."
-#~ msgid "Cannot generate the transformation equation."
-#~ msgstr "Kann die Transformationsgleichung nicht aufstellen."
-#~ msgid "No active psuedo control points"
-#~ msgstr "Keine aktiven Pseudo-Kontrollpunkte."
-#~ msgid "Unable to write temp file: %s"
-#~ msgstr "Kann die temporäre Datei <%s> nicht schreiben."
-#~ msgid "Unable to open map %s"
-#~ msgstr "Kann die Karte <%s> nicht öffnen."
-#~ msgid "Unable to write row %d"
-#~ msgstr "Kann die Zeile %d nicht schreiben."
-#~ msgid "Unable to write raster map. You might want to check available disk space and write permissions."
-#~ msgstr "Kann die Rasterkarte nicht schreiben. Sie sollten den verfügbaren Plattenplatz und die Schreibberechtigungen überprüfen."
-#~ msgid "Please select the file(s) you wish to rectify by naming an output file"
-#~ msgstr "Bitte wählen Sie die Dateie(n), die Sie rektifizieren möchten, in dem Sie eine Ausgabedatei benennen."
-#~ msgid "%s@%s: projection doesn't match current settings"
-#~ msgstr "%s@%s: Projektion passt nicht zu den aktuellen Einstellungen."
-#~ msgid "%s@%s: zone doesn't match current settings"
-#~ msgstr "%s@%s: Zone passt nicht zu den aktuellen Einstellungen."
-#~ msgid "vector, projection"
-#~ msgstr "Vektor, Projektion"
-#~ msgid "Allows projection conversion of vector maps."
-#~ msgstr "Ermöglicht die Umwandlung der Projektion von Vektorkarten."
-#~ msgid "Vector output map"
-#~ msgstr "Vektor-Ausgabekarte"
-#~ msgid "Location of input raster map"
-#~ msgstr "Location der Eingabe-Rasterkarte"
-#~ msgid "Mapset of input raster map"
-#~ msgstr "Mapset der Eingabe-Rasterkarte."
-#~ msgid "You have to use a different location for input than the current"
-#~ msgstr "Sie müssen eine andere Location als Input verwenden als die Aktuelle."
-#~ msgid "Checking location <%s>, mapset <%s>..."
-#~ msgstr "Prüfe Location <%s>, Mapset <%s>..."
-#~ msgid "Output raster map having shadows"
-#~ msgstr "Ausgabe-Rasterkarte, die die berechneten Schatten enthält."
-#~ msgid "By_position"
-#~ msgstr "By_position"
-#~ msgid "B: year (1950..2050)"
-#~ msgstr "B: Jahr (1950..2050)"
-#~ msgid "By_time"
-#~ msgstr "By_time"
-#~ msgid "B: month (0..12)"
-#~ msgstr "B: Monat (0..12)"
-#~ msgid "B: day (0..31)"
-#~ msgstr "B: Tag (0..31)"
-#~ msgid "B: hour (0..24)"
-#~ msgstr "B: Stunde (0..24)"
-#~ msgid "East coordinate (point of interest, default: map center)"
-#~ msgstr "Ost Koordinate (ausgewählter Punkt, Standard: Kartenmittelpunkt)."
-#~ msgid "North coordinate (point of interest, default: map center)"
-#~ msgstr "Nord Koordinate (ausgewählter Punkt, Standard: Kartenmittelpunkt)."
-#~ msgid "Zero is a real elevation"
-#~ msgstr "Zero (0) ist eine reale Höhenangabe"
-#~ msgid " %d.%02d.%02d, daynum %d, time: %02i:%02i:%02i (decimal time: %f)\n"
-#~ msgstr " %d.%02d.%02d, Tagnummer %d, Zeit: %02i:%02i:%02i (dezimale Zeit: %f)\n"
-#~ msgid " long: %f, lat: %f, timezone: %f\n"
-#~ msgstr "geogr. Länge: %f, geogr. Breite: %f, Zeitzone: %f\n"
-#~ msgid ""
-#~ " Solar position: sun azimuth: %f,\n"
-#~ "   sun angle above horz.(refraction corrected): %f\n"
-#~ msgstr ""
-#~ "Solare Position: Sonnenazimuth: %f,\n"
-#~ "   Sonnenwinkel über Horizont (mit Lichtbrechungskorrektur): %f\n"
-#~ msgid " Sunrise time (without refraction): %02d:%02d:%02d\n"
-#~ msgstr " Sonnenaufgang (ohne Lichtbrechungskorrektur): %02d:%02d:%02d\n"
-#~ msgid " Sunset time  (without refraction): %02d:%02d:%02d\n"
-#~ msgstr "Sonnenuntergang (ohne Lichtbrechungskorrektur): %02d:%02d:%02d\n"
-#~ msgid "No map calculation requested. Finished.\n"
-#~ msgstr "Keine Kartenberechnung gefragt. Fertig!\n"
-#~ msgid "Can't open range file for %s"
-#~ msgstr "Kann Range-Datei für %s nicht öffnen."
-#~ msgid "Can't read row in input elevation map"
-#~ msgstr "Kann Zeile der Rasterkarte mit Höhenwerten nicht lesen."
-#~ msgid "Raster map to be recoded"
-#~ msgstr "Rasterkarte, die umkodiert werden soll."
-#~ msgid "Unable to open rules file <%s>"
-#~ msgstr "Kann die Regel-Datei <%s> nicht öffnen."
-#~ msgid "Experimental NVIZ CLI prototype."
-#~ msgstr "Experimenteller Prototyp der NVIZ Kommandozeilenversion."
-#~ msgid "Generates a raster map layer showing watershed subbasins."
-#~ msgstr "Generiert eine Rasterkarte mit Wassereinzugsgebieten."
-#~ msgid "Coded stream network file name"
-#~ msgstr "Dateiname des kodierten Fließgewässernetzwerkes"
-#~ msgid "Thinned ridge network file name"
-#~ msgstr "Dateiname des ausgedünnten Grat-Netzwerkes"
-#~ msgid "Name for the resultant watershed partition file"
-#~ msgstr "Name für die resultierende Einzugsgebietsdatei"
-#~ msgid "Starting map [%s]"
-#~ msgstr "Start-Karte [%s]."
-#~ msgid "Starting filter #%d, distance: %.*lf, exponent: %.*lf, flat: %.*lf"
-#~ msgstr "Beginne Filter #%d, Distanz: %.*lf, Exponent: %.*lf, flat: %.*lf"
-#~ msgid "Percent done:"
-#~ msgstr "Prozent fertig: "
-#~ msgid ""
-#~ "%s: saving [%s] raster map layer.\n"
-#~ "Percent complete:"
-#~ msgstr ""
-#~ "%s: Speichere [%s] Rasterkarte.\n"
-#~ "Prozent fertig:"
-#~ msgid "New MAPSET name"
-#~ msgstr "Neuer Mapset Name."
-#~ msgid "Displays and overlays raster map layers in the active display frame on the graphics monitor."
-#~ msgstr "Stellt Rasterkarten im aktiven Grafikfenster dar. Überlagerung ist auch möglich."
-#~ msgid "Displays vector data in the active frame on the graphics monitor."
-#~ msgstr "Stellt GRASS Vektorkarten im aktiven Grafikfenster dar."
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares)"
-#~ msgstr "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares)"
-#~ msgid "Area size [%.1e], area not imported"
-#~ msgstr "Flächengröße [%.1e], Fläche nicht importiert."
-#~ msgid "Island size [%.1e], island not imported"
-#~ msgstr "Inselgröße [%.1e], Insel nicht importiert."
-#~ msgid "Number of column used as x coordinate (first column is 1) for points mode"
-#~ msgstr "Nummer der Spalte, die als X-Koordinate (erste Spalte ist 1)  für den Punkt-Modus genutzt wird."
-#~ msgid "Duplicate area centroids"
-#~ msgstr "Doppelte Zentroide"
-#~ msgid "                No topology present"
-#~ msgstr "                Keine Topologie vorhanden."
-#~ msgid "Failed in attempt to open %s"
-#~ msgstr "Fehlschlag beim Versuch '%s' zu öffnen."
-#~ msgid "Generates raster map layers of slope, aspect, curvatures and partial derivatives from a raster map layer of true elevation values. Aspect is calculated counterclockwise from east."
-#~ msgstr "Erzeugt Rasterkarten mit Hangneigung, Exposition, Wölbung und partiellen Ableitungen aus einer Rasterkarte mit Höheninformationen.Die Exposition werden vom Osten gegen den Uhrzeigersinn berechnet."
-#~ msgid "Raster elevation file name"
-#~ msgstr "Rasterkarte mit Höheninformationen."
-#~ msgid "Output slope filename"
-#~ msgstr "Ausgabekarte mit Hangneigung."
-#~ msgid "Output profile curvature filename"
-#~ msgstr "Dateiname für Ausgabekarte mit vertikaler Wölbung."
-#~ msgid "Output tangential curvature filename"
-#~ msgstr "Dateiname für Ausgabekarte mit horizontaler Wölbung."
-#~ msgid "Output first order partial derivative dx (E-W slope) filename"
-#~ msgstr "Ausgabekarte der ersten partiellen Ableitung dx (Ost-West Hangneigung)."
-#~ msgid "Output first order partial derivative dy (N-S slope) filename"
-#~ msgstr "Ausgabekarte der ersten partiellen Ableitung dy (Nord-Süd Hangneigung)."
-#~ msgid "Output second order partial derivative dxx filename"
-#~ msgstr "Ausgabekarte der zweiten partiellen Ableitung dxx."
-#~ msgid "Output second order partial derivative dyy filename"
-#~ msgstr "Ausgabekarte der zweiten partiellen Ableitung dyy."
-#~ msgid "Output second order partial derivative dxy filename"
-#~ msgstr "Ausgabekarte der zweiten partiellen Ableitung dxy."
-#~ msgid "wrong type: %s"
-#~ msgstr "Falscher Typ: %s"
-#~ msgid "Creating support files..."
-#~ msgstr "Erzeuge Supportdateien..."
-#~ msgid "Elevation products for mapset [%s] in [%s]"
-#~ msgstr "Höhenprodukte für Mapset [%s] in [%s]."
-#~ msgid "ASPECT [%s] COMPLETE"
-#~ msgstr "EXPOSITION [%s] KOMPLETT"
-#~ msgid "SLOPE [%s] COMPLETE"
-#~ msgstr "NEIGUNG [%s] KOMPLETT"
-#~ msgid "PROFILE CURVE [%s] COMPLETE"
-#~ msgstr "VERTIKALE WÖLBUNG [%s] KOMPLETT"
-#~ msgid "TANGENTIAL CURVE [%s] COMPLETE"
-#~ msgstr "HORIZONTALE WÖLBUNG [%s] KOMPLETT"
-#~ msgid "E-W SLOPE [%s] COMPLETE"
-#~ msgstr "O-W NEIGUNG [%s] KOMPLETT"
-#~ msgid "N-S SLOPE [%s] COMPLETE"
-#~ msgstr "N-S NEIGUNG [%s] KOMPLETT"
-#~ msgid "DXX [%s] COMPLETE"
-#~ msgstr "DXX [%s] KOMPLETT"
-#~ msgid "DYY [%s] COMPLETE"
-#~ msgstr "DYY [%s] KOMPLETT"
-#~ msgid "DXY [%s] COMPLETE"
-#~ msgstr "DXY [%s] KOMPLETT"
-#~ msgid "Input raster map contains cells with NULL-value (no-data). The value %g was used to represent no-data values in the input map. You can specify nodata value by %s parameter."
-#~ msgstr "Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert %g wurde verwendet um Nodata-Werte in der Eingabekarte zu kennzeichnen. Sie können Nodata-Wert mit dem Parameter %s bestimmen."
-#~ msgid "raster, terrain analysis"
-#~ msgstr "Raster, Geländeanalyse"
-#~ msgid "SECTION 3: Accumulating Surface Flow."
-#~ msgstr "ABSCHNITT 3: Akkumuliere Oberflächenabfluß."
-#~ msgid "SECTION 4: Length Slope determination."
-#~ msgstr "ABSCHNITT 4: Bestimme Länge der Neigung."
-#~ msgid "unable to open new L map layer."
-#~ msgstr "Kann neue L-Karte nicht öffnen."
-#~ msgid "unable to open new S map layer."
-#~ msgstr "Kann neue S-Karte nicht öffnen."
-#~ msgid "Unable to open MASK"
-#~ msgstr "Kann die Maske (MASK) nicht öffnen."
-#~ msgid "Uses a GRASS vector points map to produce a convex hull vector map."
-#~ msgstr "Verwendet eine GRASS Vektor-Punktkarte, um eine Vektorkarte mit konvexer Hülle zu erzeugen."
-#~ msgid "Name of output vector area map"
-#~ msgstr "Name der Ausgabe-Vektorkarte mit Flächen."
-#~ msgid "It was impossible to create <Auxiliar_outlier_table>."
-#~ msgstr "Kann <Auxiliar_outlier_table> nicht erzeugen"
-#~ msgid "It was not possible to drop <%s> table. Nothing will be done. Try to drop it manually."
-#~ msgstr "Es war nicht möglich die Tabelle <%s> zu löschen. Nichts wird unternommen. Versuchen Sie die Tabelle manuell zu löschen."
-#~ msgid "Cross Validation was success!"
-#~ msgstr "Die Kreuzvalidierung war erfolgreich."
-#~ msgid "Interpolation: The region resolution is too high: %d cells. Consider to change it."
-#~ msgstr "Interpolation: Die Auflösung der Region ist zu hoch: %d Zellen. Überlegen Sie die Auflösung zu ändern."
-#~ msgid "Creating auxiliar table for archiving overlapping zones"
-#~ msgstr "Erstelle Hilfstabelle um überlappende Zonen zu archivieren"
-#~ msgid "<Auxiliar_edge_table> created in database."
-#~ msgstr "<Auxiliar_edge_table> in der Datenbank erzeugt."
-#, fuzzy
-#~ msgid "Unable to open table <%s_edge_Interpolation>"
-#~ msgstr "Kann die Datenbank <%s> nicht öffnen."
-#~ msgid "M.Q. solution"
-#~ msgstr "M.Q. Lösung"
-#~ msgid "3-d data in dxf file. Polyline_flag: %d"
-#~ msgstr "3D-Daten in der DXF-Datei. Polyline_flag: %d"
-#~ msgid "Script kill option"
-#~ msgstr "Skript Kill-Option."
-#~ msgid "Start in Demo mode"
-#~ msgstr "Starte im Demo Mode."
-#~ msgid "Output more comments (default=quiet)"
-#~ msgstr "Gib mehr Kommentare aus (Standard=schweigsam)."
-#~ msgid "Direction raster found <%s>"
-#~ msgstr "Richtungskarte gefunden <%s>."
-#~ msgid "All non-NULL and non-zero cells are considered as blocking terrain"
-#~ msgstr "Alle Zellen, die nicht NULL sind oder den Wert Null haben werden als echte Hindernis aufgefasst."
-#~ msgid "It was impossible to open table"
-#~ msgstr "Es war unmöglich die Tabelle zu öffnen."
-#~ msgid "Converts a 3D raster map layer into an ASCII text file."
-#~ msgstr "Konvertiert eine 3D-Rasterkarte in eine ASCII-Datei"
-#~ msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
-#~ msgstr "Konvertiert eine 3D ASCII-Raster Textdatei in eine (binäre) 3D-Rasterkarte. "
-#~ msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map."
-#~ msgstr "Erzeugt einen Querschnitt in Form einer 2D-Rasterkarte aus einer 3D-Rasterkarte basierend auf 2D-Höhenkarte."
-#~ msgid "Wrong 3D raster map datatype! Unable to create raster map."
-#~ msgstr "Falscher 3D Rasterkarten-Datentyp. Kann die Rasterkarte nicht erzeugen."
-#~ msgid "Use the same resolution as the input 3D raster map for the 2D outputmaps, independent of the current region settings"
-#~ msgstr "Verwende dieselbe Auflösung wie die 3D-Rasterkarte für die 2D-Ausgabekarten (unabhängig von der Auflösung der aktuellen Region). "
-#~ msgid "Raster map %d Filename: %s already exists. Will be overwritten!"
-#~ msgstr "Rasterkarte %i Dateiname: %s existiert bereits. Sie wird überschrieben!"
-#~ msgid "No 3D raster data, RGB or xyz-vector maps are provided. Will only write the geometry"
-#~ msgstr "Keine 3D-Daten, RGB oder xyz-Vektorkarten wurden angegeben! Werde nur die Geometrien schreiben."
-#~ msgid "No RGB Data will be created"
-#~ msgstr "RGB-Daten werden nicht erzeugt."
-#~ msgid "No vector data will be created"
-#~ msgstr "Vektordaten werden nicht erzeugt."
-#~ msgid "Unable to close top raster map"
-#~ msgstr "Kann die obere Rasterkarte nicht schließen."
-#~ msgid "Unable to close bottom raster map"
-#~ msgstr "Kann die untere Rasterkarte nicht schließen."
-#~ msgid "Unable to close input raster map"
-#~ msgstr "Kann die Eingabe-Rasterkarte nicht schließen."
-#~ msgid "G3D map(s) to be converted to VTK-ASCII data format"
-#~ msgstr "G3D Karte(n), die in das VTL-ASCII-Format konvertiert werden."
-#~ msgid "Unable to read top raster row \n"
-#~ msgstr "Kann die oberste Rasterzeile nicht lesen.\n"
-#~ msgid "Unable to read bottom raster row \n"
-#~ msgstr "Kann die unterste Rasterzeile nicht lesen.\n"
-#~ msgid "Wrong 3D raster map values: Values should in between 0 and 255\n"
-#~ msgstr "Falsche Werte in 3D-Rasterkarte: Werte sollten zwischen 0 und 255 liegen!\n"
-#~ msgid ""
-#~ "Calculate the groundwater distance velocity vector field \n"
-#~ "and write the x, y, and z components to maps named name_[xyz].\n"
-#~ "Name is basename for the new 3D raster maps."
-#~ msgstr ""
-#~ "Berechne das Vektorfeld der Grundwassergeschwindigkeit und \n"
-#~ "schreibe die X, Y und Z Komponenten in die Karten name_[xyz].\n"
-#~ "Name ist der gemeinsame Bestandteil der neuen 3D Rasterkarten."
-#~ msgid "Calculates numerically transient, confined groundwater flow in three dimensions."
-#~ msgstr "Berechnet transienten, beschränkten Grundwasserflusses in drei Dimensionen."
-#~ msgid "The direct Cholesky solver do not work with sparse matrices"
-#~ msgstr "Der direkte Cholesky Löser funktioniert nicht mit dünnbesetzten Matrizen."
-#~ msgid "Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and 1 time step)."
-#~ msgstr "Importiert dreidimensionale Vis5D Dateien (z.B. V5D Datei mit 1 Variablen und 1 Zeitschritt)."
-#~ msgid ""
-#~ "Cannot create mask file: G3D_MASK already exists!\n"
-#~ " Use 'g.remove rast3d=G3D_MASK' to remove the existing mask."
-#~ msgstr ""
-#~ "Kann keine Maskendatei erzeugen: G3D_MASK existiert bereits.\n"
-#~ "Benutzen Sie 'g.remove rast3d=G3D_MASK' um die existierende Maske zu löschen."
-#~ msgid "Name of base raster map"
-#~ msgstr "Name der Basis-Rasterkarte."
-#~ msgid "Export GRASS raster as non-georeferenced PNG image."
-#~ msgstr "Exportiert GRASS-Rasterkarte in ein nicht georeferenziertes PNG-Bild."
-#~ msgid "Unable to read %s"
-#~ msgstr "Kann <%s> nicht lesen."
-#~ msgid "raster, interpolation"
-#~ msgstr "Raster, Interpolation"
-#~ msgid "Exports the color table associated with a raster map layer."
-#~ msgstr "Exportiert die Farbtabelle einer Rasterkarte."
-#~ msgid "latin raster map <%s> not found"
-#~ msgstr "latin Rasterkarte <%s> wurde nicht gefunden."
-#~ msgid "Use G3D mask (if exists) with input map"
-#~ msgstr "Benutzt G3D Maske (falls existent) mit der Eingabekarte"
-#~ msgid "Error writing G3D double data"
-#~ msgstr "Fehler beim Schreiben der G3D double-Daten."
-#~ msgid "Name for output raster map (default: input)"
-#~ msgstr "Name der Ausgabe-Rasterkarte (Standard: input)."
-#~ msgid "Reading file"
-#~ msgstr "Lese Datei."
-#~ msgid "The size of sliding window (odd and >= 3)"
-#~ msgstr "Die Größe des 'Moving-Windows' (ungerade und >= 3)."
-#~ msgid "Nothing to compute. Use at least one of the flags."
-#~ msgstr "Nichts zu berechnen. Verwenden Sie zumindest eine der 'Flags'."
-#~ msgid "Calculated measure #%d <%s> (56 measures available)"
-#~ msgstr "Habe die Kenngröße #%d <%s> berechnet (56 Kenngrößen verfügbar)."
-#~ msgid "No raster map specified"
-#~ msgstr "Keine Rasterkarte angegeben."
-#~ msgid "Unable to remove color table of raster map <%s>"
-#~ msgstr "Kann die Farbtabelle der Rasterkarte <%s> nicht entfernen."
-#~ msgid "Color table of raster map <%s> not found"
-#~ msgstr "Farbtabelle der Rasterkarte <%s> nicht gefunden."
-#~ msgid "Color table 'random' is not supported for floating point raster map"
-#~ msgstr "Farbtabelle 'random' wird für Fließkomma-Karten nicht unterstützt."
-#~ msgid "Color table 'grey.eq' is not supported for floating point raster map"
-#~ msgstr "Farbtabelle 'grey.eq' wird für Fließkomma-Karten nicht unterstützt."
-#~ msgid "Color table 'grey.log' is not supported for floating point raster map"
-#~ msgstr "Farbtabelle 'grey.log' wird für Fließkomma-Karten nicht unterstützt."
-#~ msgid "Color table for raster map <%s> set to '%s'"
-#~ msgstr "Farbtabelle der Rasterkarte für <%s> ist auf '%s' gesetzt."
-#~ msgid "Checking GDAL data type and nodata value"
-#~ msgstr "Prüfe GDAL Datentyp und NoData-Wert."
-#~ msgid "Raster file to be linked"
-#~ msgstr "Rasterdatei die verbunden werden soll."
-#~ msgid "Unable to read range of raster map <%s>"
-#~ msgstr "Kann den Wertebereich der Rasterkarte <%s> nicht lesen."
-#~ msgid "Use G3D mask (if exists) with output map"
-#~ msgstr "Benutzt G3D Maske (falls existent) für die Ausgabekarte."
-#~ msgid "Cell file not found"
-#~ msgstr "Cell-Datei nicht gefunden."
-#~ msgid "Unable to load 3D raster range"
-#~ msgstr "Kann den 3D Raster Wertebereich nicht laden."
-#~ msgid "Unable to update boundaries"
-#~ msgstr "Kann die Begrenzung (boundary) nicht aktualisieren."
-#~ msgid "Unable to open file [%s] for reading"
-#~ msgstr "Kann die Datei [%s] nicht zum Lesen öffnen."
-#~ msgid "Can also be used to create GRASS locations."
-#~ msgstr "Kann auch verwendet werden, um GRASS Locations zu erzeugen."
-#~ msgid "Print projection information (in conventional GRASS format)"
-#~ msgstr "Gebe die Projektionsinformationen (im konventionellen GRASS-Format) aus."
-#~ msgid "Georeferenced data file to read projection information from"
-#~ msgstr "Datei mit den Projektionsinformationen."
-#~ msgid "ASCII file containing a WKT projection description (- for stdin)"
-#~ msgstr "ASCII-Datei die eine einzige Zeile mit WKT Projektionsinformationen enthält. (- für stdin)."
-#~ msgid "PROJ.4 projection description (- for stdin)"
-#~ msgstr "PPROJ.4 Projektionsdefinition (- für Standardeingabe)."
-#~ msgid "Unable to create location: %s"
-#~ msgstr "Kann Location '%s' nicht erstellen."
-#~ msgid "You must select the PERMANENT mapset before updating the current location's projection. (Current mapset is %s)"
-#~ msgstr "Das PERMANENT-Mapset muss anstelle des aktuellen Mapsets (%s) ausgewählt werden, bevor Sie die Projektionsinformationen der Location aktualisieren können."
-#~ msgid "N.B. The default region was updated to the new projection, but if you have multiple mapsets g.region -d should be run in each to update the region from the default."
-#~ msgstr "N.B. Die Standard Region wurde auf die neue Projektion aktualisiert. Wenn Sie aber mehrere Mapsets haben g.region -d sollte in jedem ausgeführt werden, um die Regionseinstellungen von der Standardregion zu übernehmen."
-#~ msgid "Projection information updated!"
-#~ msgstr "Projektionsinformationen aktualisiert!"
-#~ msgid "Names of mask files"
-#~ msgstr "Namen der Maske-Dateien."
-#~ msgid "Name of output mask file"
-#~ msgstr "Name der Ausgabe-Maske-Datei."
-#~ msgid "Changes current mapset."
-#~ msgstr "Ändere aktuelles Mapset."
-#~ msgid "%s is currently running GRASS in selected mapset or lock file cannot be checked"
-#~ msgstr "%s führt zur Zeit GRASS in dem gewählten Mapset aus oder die Lock-Datei kann nicht überprüft werden."
-#~ msgid "Remove base maps"
-#~ msgstr "Entferne Basiskarten"
-#~ msgid "The following files would be deleted:"
-#~ msgstr "Die folgenden Karten würden gelöscht:"
-#~ msgid "You must use the force flag to actually remove them. Exiting."
-#~ msgstr "Sie müssen den Zwangs-Schalter verwenden, um tatsächlich zu Löschen. Beende mich."
-#~ msgid "display, raster"
-#~ msgstr "Darstellung, Raster"
-#~ msgid "Erase the contents of the active display frame with user defined color"
-#~ msgstr "Löscht den Inhalte des aktiven Grafikfensters mit einer benutzerdefinierten Farbe."
-#~ msgid "Don't add to list of commands in monitor"
-#~ msgstr "Nicht zu der Kommandoliste im Monitor hinzufügen."
-#~ msgid "Interactively edit cell values in a raster map."
-#~ msgstr "Editiere interaktiv Zellwerte einer Rasterkarte."
-#~ msgid "No font selected"
-#~ msgstr "Keine Schrift ausgewählt."
-#~ msgid "Error - Monitor '%s' was not running"
-#~ msgstr "Fehler - Grafikfenster '%s' ist nicht aktiv."
-#~ msgid "Name of graphics monitor to start"
-#~ msgstr "Name des Grafikfensters, das gestartet werden soll."
-#~ msgid "Name of graphics monitor to stop"
-#~ msgstr "Name des Grafikfensters, das gestoppt werden soll."
-#~ msgid "Name of graphics monitor to select"
-#~ msgstr "Name des Grafikfensters, das selektiert werden soll."
-#~ msgid "List all monitors"
-#~ msgstr "Liste aller Grafikfenster."
-#~ msgid "Print name of currently selected monitor"
-#~ msgstr "Gib den Namen des momentan selektierten Grafikfensters aus."
-#~ msgid "Release currently selected monitor"
-#~ msgstr "Gebe das aktuell ausgewählte Grafikfenster frei."
-#~ msgid "Type of color table (for use with -z flag)"
-#~ msgstr "Art der Farbtabelle (für die Verwendung mit dem Schalter -z)."
-#~ msgid "Name of column for line widths (these values will be scaled by wscale)"
-#~ msgstr "Name der Spalte für die Linienbreite (Werte werden über wscale skaliert)."
-#~ msgid "Scale factor for wcolumn"
-#~ msgstr "Skalierungsfaktor für wcolumn"
-#~ msgid "Get colors from map table column (of form RRR:GGG:BBB)"
-#~ msgstr "Hole die Farbe aus der Tabellenspalte (RRR:GGG:BBB)."
-#~ msgid "Error in color definition column (%s), area %d with cat %d"
-#~ msgstr "Fehler in der Spalten mit den Frabwerten (%s), Fläche %d mit cat %d."
-#~ msgid "Symbol size column not specified."
-#~ msgstr "Spalte für die Symbolgröße nicht angegeben."
-#~ msgid "Symbol size column (%s) is not numeric."
-#~ msgstr "Spalte für die Symbolgröße (%s) ist nicht numerisch."
-#~ msgid "Symbol rotation column not specified."
-#~ msgstr "Spalte für die Symbolrotation nicht angegeben."
-#~ msgid "Symbol rotation column (%s) is not numeric."
-#~ msgstr "Spalte für die Symbolrotation (%s) is nicht numerisch."
-#~ msgid "Unable to read symbol, unable to display points"
-#~ msgstr "Kann das Symbol nicht lesen; kann die Punkte nicht darstellen."
-#~ msgid "Allocate subnets for nearest centres (direction from centre)."
-#~ msgstr "Sammle Teilnetze für nächste Zentren (Richtung: vom Zentrum)."
-#~ msgid "Centre node must be opened (costs >= 0). Costs of centre node are used in calculation"
-#~ msgstr "Zentraler Knoten muss geöffnet sein (Kosten >= 0). Kosten des zentralen Knoten gehen im die Berechnung mit ein."
-#~ msgid "Categories of centres (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
-#~ msgstr "Kategorien der Zentren (Punkte auf Knoten) zu welchen das Netz zugewiesen wird. Der Layer für diese Kategorien wird mit der 'nlayer'-Option angegeben."
-#~ msgid "Number of centres: [%d] (nlayer: [%d])"
-#~ msgstr "Zahl der Zentren: [%d] (nlayer: [%d])."
-#~ msgid "Calculating costs from centres ..."
-#~ msgstr "Berechne die Kosten von den Zentren ..."
-#~ msgid "<%s> has not been created in database."
-#~ msgstr "<%s> wurde in Datenbank nicht erstellt."
-#~ msgid "List available layers in data source and exit"
-#~ msgstr "Zeigt die vorhandenen Layer in der Datenquelle und beendet sich."
-#~ msgid "Data source contains %d layers:"
-#~ msgstr "Datenquelle enthält %d Layer:"
-#~ msgid "Counting polygons for %d features..."
-#~ msgstr "Zähle Polygone für %d Objekte..."
-#~ msgid "Importing map %d features..."
-#~ msgstr "Importiere %d Objekte der Karte..."
-#~ msgid "Snap boundaries (threshold = %.3e):"
-#~ msgstr "Snappe Grenzen (Schwellwert = %.3e):"
-#~ msgid "Change boundary dangles to lines:"
-#~ msgstr "Ändere Grenzüberstände zu Linien:"
-#~ msgid "Change boundary bridges to lines:"
-#~ msgstr "Ändere Brücken der Grenzen zu Linien:"
-#~ msgid "Find centroids for layer: %s"
-#~ msgstr "Finde Zentroide der Layer: %s"
-#~ msgid "Input data contains 3D features. Created vector is 2D only, use -z flag to import 3D vector"
-#~ msgstr "Eingabekarte enthält 3D-Feature. Erstellte Vektorkarte ist allerdings nur 2D, verwenden Sie den Schalter '-z', um 3D-Vektordaten zu importieren."
-#~ msgid "Cannot read part of geometry"
-#~ msgstr "Kann Teil der Geometrie nicht lesen."
-#~ msgid "Degenerate polygon ([%d] vertices)"
-#~ msgstr "Degeneriere Polygon ([%d] Vertices)"
-#~ msgid "Cannot write part of geometry"
-#~ msgstr "Kann Teil der Geometrie nicht schreiben."
-#~ msgid "Selects vector objects from an existing vector map and creates a new map containing only the selected objects."
-#~ msgstr "Selektiert Vektorobjekte einer existierenden Vektorkarte und erzeugt eine neue Karte nur mit den selektierten Objekten."
-#~ msgid "Do not copy table (see also 'new' parameter)"
-#~ msgstr "Kopiere die Attributtabelle nicht mit (bitte Parameter 'new' beachten)."
-#~ msgid "If new >= 0, table is not copied"
-#~ msgstr "Wenn neu >= 0, wird die Tabelle nicht kopiert."
-#~ msgid "List, file, where and random options are exclusive. Please specify only one of them"
-#~ msgstr "Die Optionen list, file, where und random schließen sich gegenseitig aus. Bitte geben Sie nur eine von diesen an."
-#~ msgid "Process file <%s> for category numbers"
-#~ msgstr "Bearbeite Datei <%s> für Kategorienummern."
-#~ msgid "%d categories loaded from table <%s>"
-#~ msgstr "%d Kategorien von der Tabelle <%s> geladen."
-#~ msgid "Random category count is larger or equal to uniq \"%s\" feature category count %d"
-#~ msgstr "Die Zahl der zufälligen Kategorien ist größer oder gleich der Zahl der eindeutigen \"%s\" Feature Kategorien %d."
-#~ msgid "Finds the shortest paths from a feature 'to' to every feature 'from' and various information about this realtion are uploaded to the attribute table."
-#~ msgstr "Findet den kürzesten Pfad von einem Objekt 'to' zu allen Objekten 'from' und zahlreiche Informationen über diese Beziehung wird in der Attributtabelle abgespeichert"
-#~ msgid "No attribute table found"
-#~ msgstr "Keine Attributtabelle gefunden."
-#~ msgid "Path to resulting ASCII file or ASCII vector name if '-o' is defined"
-#~ msgstr "Pfad zur resultiertenden ASCII-Datei oder ASCII-Kartenname, wenn der Schalter '-o' angegeben ist."
-#~ msgid "Name of input DXF file"
-#~ msgstr "Name der Eingabe-DXF-Datei"
-#~ msgid "Name of column name with route ids"
-#~ msgstr "Spaltenname der Spalte mit den IDs der Route"
-#~ msgid "Name of column name with stop timestamps"
-#~ msgstr "Spaltenname der Spalte mit den Haltepunkte mit Zeitangaben"
-#~ msgid "Name of column name with stop ids"
-#~ msgstr "Spaltenname der Spalte mit IDs der Haltepunkte"
-#~ msgid "Name of column name with walk lengths"
-#~ msgstr "Spaltenname der Spalte mit Angabe der Walk-Länge"
-#~ msgid "End of ascii file reached before end of categories"
-#~ msgstr "Ende der ASCII-Datei vor dem Ende der Kategorien erreicht."
-#~ msgid "Zoom by window"
-#~ msgstr "Zoom mittels Fenster"
-#~ msgid "1. corner"
-#~ msgstr "1. Ecke"
-#~ msgid "Quit"
-#~ msgstr "Beenden"
-#~ msgid "2. corner"
-#~ msgstr "2. Ecke"
-#~ msgid "Pan"
-#~ msgstr "Verschieben"
-#~ msgid "New center"
-#~ msgstr "Neues Zentrum"
-#~ msgid "Cannot find window '%s'"
-#~ msgstr "Kann Fenster '%s' nicht finden."
-#~ msgid "Cannot set variable code = %d"
-#~ msgstr "Kann die Variable code = %d nicht setzen."
-#~ msgid "Cannot get type of variable %s"
-#~ msgstr "Kann den Type der Variablen %s nicht bekommen."
-#~ msgid "Cannot get code of variable %s"
-#~ msgstr "Kann den code der Variablen %s nicht bekommen."
-#~ msgid "Cannot get name of variable %d"
-#~ msgstr "Kann den Namen der Variablen %d nicht bekommen."
-#~ msgid "Cannot get value of variable code = %d"
-#~ msgstr "Kann den Wert der Variablen code = %d nicht bekommen."
-#~ msgid "Select tool"
-#~ msgstr "Selektionswerkzeug"
-#~ msgid "Cannot open driver %s"
-#~ msgstr "Kann de Treiber %s nicht öffnen."
-#~ msgid "Cannot open database %s"
-#~ msgstr "Kann die Datenbank %s nicht öffnen."
-#~ msgid "Cannot open driver "
-#~ msgstr "Kann nicht öffnen den Treiber "
-#~ msgid "Cannot open database %s by driver %s"
-#~ msgstr "Kann die Datenbank <%s> nicht mit dem Treiber <%s> öffnen."
-#~ msgid "Cannot create table: "
-#~ msgstr "Kann Tabelle nicht erzeugen: "
-#~ msgid "Cannot create index:\n"
-#~ msgstr "Kann keinen Index erstellen:\n"
-#~ msgid "Cannot grant privileges on table:\n"
-#~ msgstr "Kann Privilegien für die Tabelle nicht zuweisen:\n"
-#~ msgid "Cannot add database link to vector, link for given field probably already exists."
-#~ msgstr "Kann Datenbankverknüpfung nicht zum Vektor hinzufügen. Vermutlich besteht schon eine Verknüpfung für das Feld."
-#~ msgid "Cannot open driver"
-#~ msgstr "Kann Treiber nicht öffnen."
-#~ msgid "Cannot open driver '%s'<BR>"
-#~ msgstr "Kann Treiber '%s' nicht öffnen<BR>"
-#~ msgid "Cannot open database"
-#~ msgstr "Kann Datenbank nicht öffnen."
-#~ msgid "Cannot open database '%s' by driver '%s'<BR>"
-#~ msgstr "Kann Datenbank '%s' nicht mit dem Treiber '%s' öffnen.<BR>"
-#~ msgid "Cannot open select cursor"
-#~ msgstr "Kann den Select-Cursor nicht öffnen."
-#~ msgid "Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>"
-#~ msgstr "kann den Select-Cursor nicht öffnen:<BR>'%s'<BR>der Datenbank '%s' mit Treiber '%s'<BR>"
-#~ msgid "Cannot fetch next record"
-#~ msgstr "Kann die nächste Zeile nicht holen."
-#~ msgid "No database record"
-#~ msgstr "Kein Datenbankeintrag"
-#~ msgid "<HR>   Assume data encoding as:<BR><BR><SELECT NAME=%s SIZE=4><HR><BR>"
-#~ msgstr "<HR>   Angenommene Datenkodierung:<BR><BR><SELECT NAME=%s SIZE=4><HR><BR>"
-#~ msgid "Split line:"
-#~ msgstr "Teile Linie:"
-#~ msgid "Select"
-#~ msgstr "Selektion"
-#~ msgid "Quit tool"
-#~ msgstr "Beende Werkzeug"
-#~ msgid "Confirm and select next"
-#~ msgstr "Bestätige und selektiere Nächsten"
-#~ msgid "Unselect"
-#~ msgstr "De-Selektieren"
-#~ msgid "Remove vertex:"
-#~ msgstr "Lösche Vertex:"
-#~ msgid "Select vertex"
-#~ msgstr "Selektiere Vertex"
-#~ msgid "Add vertex:"
-#~ msgstr "Füge Vertex hinzu:"
-#~ msgid "New vertex"
-#~ msgstr "Neuer Vertex"
-#~ msgid "Move vertex:"
-#~ msgstr "Verschiebe Vertex:"
-#~ msgid "New location"
-#~ msgstr "Neue Location"
-#~ msgid "db connection was not set by form\n"
-#~ msgstr "db Verbindung wurde nicht von Formular gesetzt\n"
-#~ msgid "Cannot open driver\n"
-#~ msgstr "Kann Treiber nicht öffnen.\n"
-#~ msgid "Cannot open database\n"
-#~ msgstr "Kann Datenbank nicht öffnen.\n"
-#~ msgid "Cannot describe table\n"
-#~ msgstr "Kann Tabelle nicht beschreiben\n"
-#~ msgid "Cannot find column type"
-#~ msgstr "Kann Spaltentyp nicht finden."
-#~ msgid "Could not set Tcl system encoding to '%s' (%s)"
-#~ msgstr "Konnte die Kodierung des Tcl Systems nicht auf '%s' (%s) setzen."
-#~ msgid "Could not convert UTF to external."
-#~ msgstr "Konnte UTF nicht zu externer Kodierung konvertieren."
-#~ msgid "Cannot update table"
-#~ msgstr "Kann Tabelle nicht aktualisieren."
-#~ msgid "Form"
-#~ msgstr "Form"
-#~ msgid "New record was created.<BR>"
-#~ msgstr "Neuer Eintrag wurde angelegt.<BR>"
-#~ msgid "Record for this category already existed.<BR>"
-#~ msgstr "Eintrag für diese Kategorie existiert bereits.<BR>"
-#~ msgid "Digitize new %s:"
-#~ msgstr "Digitalisiere neu %s:"
-#~ msgid "New point"
-#~ msgstr "Neuer Punkt"
-#~ msgid "Out of memory! Point not added."
-#~ msgstr "Nicht genügend Arbeitsspeicher! Punkt nicht hinzugefügt."
-#~ msgid "Less than 2 points for line -> nothing written"
-#~ msgstr "Weniger als 2 Punkte für Linie -> nichts geschrieben."
-#~ msgid "Undo last point"
-#~ msgstr "Letzten Punkt Rückgängig"
-#~ msgid "Close line"
-#~ msgstr "Linie beenden"
-#~ msgid "New Point"
-#~ msgid "Undo Last Point"
-#~ msgid "Delete point, line, boundary, or centroid:"
-#~ msgstr "Lösche Punkt, Linie, Grenze oder Zentroid:"
-#~ msgid "Move point, line, boundary, or centroid:"
-#~ msgstr "Verschiebe Punkt, Linie, Grenze oder Zentroid.:"
-#~ msgid "Cannot create new record."
-#~ msgstr "Kann keinen neuen Eintrag anlegen."
-#~ msgid "Database table for this layer is not defined"
-#~ msgstr "Datenbankverbindung ist für diesen Layer nicht definiert."
-#~ msgid "Cannot select record from table %s"
-#~ msgstr "Kann Datensatz der Tabelle <%s> nicht selektieren."
-#~ msgid "Display categories:"
-#~ msgstr "Zeige Kategorien:"
-#~ msgid "Select line"
-#~ msgstr "Selektiere Linie"
-#~ msgid "Copy attributes:"
-#~ msgstr "Kopiere Attribute:"
-#~ msgid "Select source object"
-#~ msgstr "Selektiere Quell-Objekt"
-#~ msgid "Select the target object"
-#~ msgstr "Selektiere Ziel-Objekt"
-#~ msgid "Conform and select next"
-#~ msgid "Deselect Target"
-#~ msgstr "Selektierung des Ziels aufheben"
-#~ msgid "Deselect Source"
-#~ msgstr "Selektierung der Quelle aufheben"
-#~ msgid "Display attributes:"
-#~ msgstr "Attribute anzeigen:"
-#~ msgid "layer: %d<BR>category: %d<BR>"
-#~ msgstr "Layer: %d<BR>Kategorie: %d<BR>"
-#~ msgid "Database connection not defined<BR>"
-#~ msgstr "Datenbankverbindung nicht definiert.<BR>"
-#~ msgid "driver: %s<BR>database: %s<BR>table: %s<BR>key column: %s<BR>"
-#~ msgstr "Treiber: %s<BR>Datenbank: %s<BR>Tabelle: %s<BR>Schlüsselspalte: %s<BR>"
-#~ msgid "Line %d"
-#~ msgstr "Linie %d"
-#~ msgid "No categories"
-#~ msgstr "Keine Kategorien"
-#~ msgid "There are no more features with category %d (layer %d) in the map, but there is record in the table. Delete this record?"
-#~ msgstr "Es gibt keine weiteren Objekte mit der Kategorie %d (Layer %d) in der Karte, aber es existieren Einträge in der Tabelle. Sollen diese Tabellen-Einträge gelöscht werden?"
-#~ msgid "Cannot delete record: %s"
-#~ msgstr "Kann Eintrag nicht löschen: %s"
-#~ msgid "Unable to read color file"
-#~ msgstr "Kann die Farbdatei nicht lesen."
-#~ msgid ""
-#~ "ERROR: Required parameter <%s> not set:\n"
-#~ "\t(%s)\n"
-#~ msgstr ""
-#~ "FEHLER: Benötigter Parameter <%s> wurde nicht angegeben:\n"
-#~ "\t(%s).\n"
-#~ msgid "pg driver: PostGIS column '%s', type 'geometry'  will not be converted"
-#~ msgstr "PG-Treiber: PostGIS Spalte '%s', vom Typ 'geometry'  wird nicht konvertiert."
-#~ msgid "Database schema"
-#~ msgstr "Datenbank-Schema"
-#~ msgid "Import E00 file into a vector map."
-#~ msgstr "Importiert eine E00-Datei in eine Vektorkarte."
-#~ msgid "Output coordinate file (omit to send to stdout)"
-#~ msgstr "Ausgabe-Koordinatendatei (leer lassen, wenn nach stdout geschrieben werden soll)."
-#~ msgid "Prints a graph of the correlation between data layers (in pairs)."
-#~ msgstr "Gibt eine Graphik der Korrelation zweier Karten (paarweise) aus."
-#~ msgid "Base name for red, green and blue output maps containing the blend"
-#~ msgstr "Präfix für die rote, grüne und blaue Ausgabekarte der erstellten Mischung."
-#~ msgid "Column to be updated with the query result"
-#~ msgstr "Spalte die mit den Abfrageergebnissen aktualisiert werden soll."
-#~ msgid "SRTM input tile (file without .hgt.zip extension)"
-#~ msgstr "SRTM Eingabe-Kachel (Dateinamen ohne die Erweiterung .hgt.zip)."
-#~ msgid "Name of raster map to generate legend from"
-#~ msgstr "Name der Rasterkarte von der eine Legende erzeugt werden soll."
-#~ msgid "Column on which to calculate statistics (must be numeric)"
-#~ msgstr "Spalte, für die Statistiken berechnet werden sollen (muss numerisch sein)."
-#~ msgid "Exports a vector map to a GPS receiver or file format supported by GpsBabel."
-#~ msgstr "Exportiert eine Vektorkarte zu einem GPS Gerät oder in ein Dateiformat, das von GpsBabel unterstützt wird."
-#~ msgid "GpsBabel supported output format"
-#~ msgstr "GpsBabel unterstütze Ausgabeformate. "
-#~ msgid "Manually set range (min,max)"
-#~ msgstr "Manuell gesetzter Bereich (min,max)"
-#~ msgid "Import ASCII x,y[,z] coordinates as a series of lines."
-#~ msgstr "Importiere ASCII x,y[,z] Koordinaten als Folge von Linie(n)."
-#~ msgid "Select x11 display monitor for legend"
-#~ msgstr "Selektiere das X11-Grafikfenster für die Legende."
-#~ msgid "Table to drop"
-#~ msgstr "Tabelle die gelöscht werden soll."
-#~ msgid "Uncompressed GNS file from NGA (with .txt extension)"
-#~ msgstr "Unkomprimierte GNS-Datei von NGA (mit der Dateiendung .txt)."
-#~ msgid "vector, raster, statistics"
-#~ msgstr "Vektor, Raster, Statistik"
-#~ msgid "Imports geonames.org country files into a GRASS vector points map."
-#~ msgstr "Importiert Länderdateien von geonames.org in eine Vektorpunktkarte."
-#~ msgid "Uncompressed geonames file from (with .txt extension)"
-#~ msgstr "Unkomprimierte geonames-Datei (mit der Dateiendung .txt)."
-#~ msgid "Name of the column"
-#~ msgstr "Name der Spalte"
-#~ msgid "Export a raster map to a text file as x,y,z values based on cell centers."
-#~ msgstr "."
-#~ msgid "LANDSAT red channel"
-#~ msgstr "LANDSAT roter Kanal"
-#~ msgid "LANDSAT green channel"
-#~ msgstr "LANDSAT grüner Kanal"
-#~ msgid "LANDSAT blue channel"
-#~ msgstr "LANDSAT blauer Kanal"
-#~ msgid "Drapes a color raster over a shaded relief map using d.his"
-#~ msgstr "Drapiert eine Rasterkarte mit Farbwerten über Schummerungskarte unter Verwendung von d.his."
-#~ msgid "Name of shaded relief or aspect map"
-#~ msgstr "Name der Schummerungs- oder Expositionskarte."
-#~ msgid "Name of raster to drape over relief map"
-#~ msgstr "Name der Rasterkarte die über das Relief drapiertwird."
-#~ msgid "Fills no-data areas in raster maps using v.surf.rst splines interpolation"
-#~ msgstr "Fülle Flächen ohne Daten in Rasterkarten mit Hilfe der v.surf.rst Spline-Interpolation"
-#~ msgid "Name of column used to dissolve common boundaries"
-#~ msgstr "Name der Spalte, die für das auflösen gemeinsamer Grenzen verwendet werden soll."
-#~ msgid "Join column in map table"
-#~ msgstr "Spalte der Vektorkartentabelle, die für den Join verwendet werden soll."
-#~ msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
-#~ msgstr "Tasseled Cap (Kauth Thomas) Transformation für LANDSAT-TM Daten."
-#~ msgid "use transformation rules for LANDSAT-4"
-#~ msgstr "Verwende Transformationsregeln für LANDSAT-4."
-#~ msgid "use transformation rules for LANDSAT-5"
-#~ msgstr "Verwende Transformationsregeln für LANDSAT-5."
-#~ msgid "use transformation rules for LANDSAT-7"
-#~ msgstr "Verwende Transformationsregeln für LANDSAT-7."
-#~ msgid "raster input map (LANDSAT channel 1)"
-#~ msgstr "Eingabe-Rasterkarte (LANDSAT Kanal 1)."
-#~ msgid "raster input map (LANDSAT channel 2)"
-#~ msgstr "Eingabe-Rasterkarte (LANDSAT Kanal 2)."
-#~ msgid "raster input map (LANDSAT channel 3)"
-#~ msgstr "Eingabe-Rasterkarte (LANDSAT Kanal 3)."
-#~ msgid "raster input map (LANDSAT channel 4)"
-#~ msgstr "Eingabe-Rasterkarte (LANDSAT Kanal 4)."
-#~ msgid "raster input map (LANDSAT channel 5)"
-#~ msgstr "Eingabe-Rasterkarte (LANDSAT Kanal 5)."
-#~ msgid "raster input map (LANDSAT channel 7)"
-#~ msgstr "Eingabe-Rasterkarte (LANDSAT Kanal 7)."
-#~ msgid "Layer where to add new attribute table"
-#~ msgstr "Layer in dem die neue Attributtabelle hinzugefügt werden soll."
-#~ msgid "Name of the column to drop"
-#~ msgstr "Name der zu löschenden Spalte"
-#~ msgid "Name of optional EPS output file"
-#~ msgstr "Name der optionalen EPS-Ausgabedatei."
-#~ msgid "Computes topographic correction of reflectance."
-#~ msgstr "Berechnet topographische Korrektur der Reflektionswerte."
-#~ msgid "imagery, terrain, topographic correction"
-#~ msgstr "Bild, Terrain, topographische Korrektur"
-#~ msgid "Name of reflectance raster maps to be corrected topographically"
-#~ msgstr "Name der Reflektionskarte für topographische Korrektur"
-#~ msgid "Name (flag -i) or prefix for output raster maps"
-#~ msgstr "Name (Flag -i) oder Präfix für Ausgabe-Rasterkarten"
-#~ msgid "Name of input base raster map (elevation or illumination)"
-#~ msgstr "Name der Basis-Eingabe-Rasterkarte (Höhe oder Lichtintensität)."
-#~ msgid "Solar azimuth in degrees (only if flag -i)"
-#~ msgstr "Sonnenazimut in Grad (nur wenn Flag -i)"
-#~ msgid "Output sun illumination terrain model"
-#~ msgstr "Ausgabe des sonnenbeschienen Landschaftsmodells"
-#~ msgid "Solar azimuth is necessary to calculate illumination terrain model"
-#~ msgstr "Sonnenazimuth ist notwendig, um das beleuchtete Geländemodell zu berechnen."
-#~ msgid "Reflectance maps are necessary to make topographic correction"
-#~ msgstr "Reflektionskarten sind notwendig, um topographische Korrekturen zu berechnen."
-#~ msgid "Elevation raster map of unknown type"
-#~ msgstr "Höhen-Rasterkarte unbekanntes Typs."
-#~ msgid "Illumination model is of CELL type"
-#~ msgstr "Beleuchtungsmodell ist vom Typ CELL."
-#~ msgid "Reflectance of raster map <%s> is not of DCELL type - ignored"
-#~ msgstr "Reflektion der Rasterkarte <%s> ist nicht vom Typ DCELL - ignoriert."
-#~ msgid "Minnaert constant = %lf"
-#~ msgstr "Minnaert Konstante = %lf"
-#~ msgid "C-factor constant = %lf (a=%.4f; m=%.4f)"
-#~ msgstr "C-Faktor Konstante = %lf (a=%.4f; m=%.4f)"
-#~ msgid "Could not close G3D map"
-#~ msgstr "Konnte G3D Karte nicht schließen"
-#~ msgid "Use g3d mask (if exists) with input map"
-#~ msgstr "Benutzt G3D Maske (falls existent) mit der Eingabekarte."
-#~ msgid "Could not close G3D map <%s>"
-#~ msgstr "Konnte G3D Karte <%s> nicht schließen."
-#~ msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
-#~ msgstr "Konvertiert eine 3D-Rasterkarte (G3D) in das VTK-ASCII-Format."
-#~ msgid "Use g3d mask (if exists) with input maps"
-#~ msgstr "Benutze G3D Maske (falls existent) mit der Eingabekarte."
-#~ msgid "Use G3D mask (if exists)"
-#~ msgstr "Benutzte G3D Maske (falls existent)."
-#~ msgid "Name of elevation raster map"
-#~ msgstr "Name der Höhenkarte."
-#~ msgid "unable to open MASK"
-#~ msgid "Name of raster map for which to edit null file"
-#~ msgstr "Rasterkarte, deren NULL-Datei editiert werden soll."
-#~ msgid "Write raster values as z coordinate. Table is not created. Currently supported only for points."
-#~ msgstr "Schreibe Rasterwerte als Z-Koordinate. Attributtabelle wird nicht erzeugt. Derzeit werden nur Punkte unterstützt."
-#~ msgid "input= and source= are mutually exclusive"
-#~ msgstr "'input=' und 'source=' schließen sich gegenseitig aus."
-#~ msgid "Reports statistics for raster map layers."
-#~ msgstr "Gibt statistische Werte für eine Rasterkarte aus."
-#~ msgid "Name of an output file to hold the report"
-#~ msgstr "Name der Ausgabedatei zum Speichern des Reports."
-#~ msgid "If not given reads from standard input"
-#~ msgstr "Wenn nicht gegeben, lese von der Standardeingabe"
-#~ msgid "Removes a table from database."
-#~ msgstr "Entfernt eine Tabelle aus einer Datenbank."
-#~ msgid "database, connection settings"
-#~ msgstr "Datenbank, Verbindungseinstellungen"
-#~ msgid "Raster input maps"
-#~ msgstr "Eingabe-Rasterkarten"
-#~ msgid "Install system-wide using sudo"
-#~ msgstr "Systemweit installieren mit sudo"
-#~ msgid "Display the HTML man pages of GRASS"
-#~ msgstr "Zeige die HTML-Handbuchseite von GRASS."
-#~ msgid "Name of aspect raster map"
-#~ msgstr "Name der Expositions-Rasterkarte."
-#~ msgid "Creates, edits, and lists groups and subgroups of imagery files."
-#~ msgstr "Erzeugt, editiert und listet Gruppen und Untergruppen von Bilddateien."
-#~ msgid "Name of an existing raster map layer"
-#~ msgstr "Name einer existierenden Rasterkarte."
-#~ msgid "Link to raster map <%s> created"
-#~ msgstr "Link zur Rasterkarte <%s> erzeugt"
-#~ msgid "Unable to set window"
-#~ msgstr "Kann das Fenster nicht setzen."
-#~ msgid "%s: base raster map not found"
-#~ msgstr "%s: Basis-Rasterkarte nicht gefunden."
-#~ msgid "The height of the river bed in [m]"
-#~ msgstr "Höhe des Flussbetts [m]."
-#~ msgid "Output basic information about a raster map layer."
-#~ msgstr "Gibt grundlegende Informationen über eine Rasterkarte aus."
-#~ msgid "Input map"
-#~ msgstr "Eingabekarte"
-#~ msgid "Unable to get header for %s"
-#~ msgstr "Kann den Header von %s nicht lesen."
-#~ msgid "Subsignature %d only contains %f pixels"
-#~ msgstr "Unter-Signatur %d enthält nur %f Pixel."
-#~ msgid "Calculating covariance matrix..."
-#~ msgstr "Berechne die Kovarianz-Matrix..."
-#~ msgid "Rescaling <%s> to range %d,%d..."
-#~ msgstr "Skaliere die Daten <%s> auf den Bereich %d,%d..."
-#~ msgid "Bad format in camera file for group <%s>"
-#~ msgstr "Schlechtes Format in der Kamerareferenzdatei der Gruppe <%s>."
-#~ msgid "Please select a target for group"
-#~ msgstr "Bitte wählen Sie ein Ziel für die Gruppe"
-#~ msgid "Error in calculating conversions"
-#~ msgstr "Fehler bei der Berechnung der Umwandlung."
-#~ msgid "Display information about the active display monitor"
-#~ msgstr "Zeige Informationen über das aktive Grafikfenster."
-#~ msgid "Unable to set size"
-#~ msgstr "Kann die Größe nicht setzen."
-#~ msgid "Launching '%s' GUI in the background, please wait ..."
-#~ msgstr "Starte '%s' GUI im Hintergrund. Bitte warten Sie ..."
-#~ msgid "List available mapsets"
-#~ msgstr "Zeige alle verfügbaren Mapsets."
-#~ msgid "You don't have permission to use this mapset"
-#~ msgstr "Sie haben nicht die Berechtigung dieses Mapset zu verwenden."
-#~ msgid "The mapset does not exist. Use -c flag to create it."
-#~ msgstr "Das Mapset existiert nicht.Verwenden Sie den Schalter -c um es zu erzeugen."
-#~ msgid "Unrecognized 'ask' value in proj-parms.table: %s"
-#~ msgstr "Unbekannter Wert für 'ask' in proj-parms.table: %s"
-#~ msgid "Unrecognized default value in proj-parms.table: %s"
-#~ msgstr "Unbekannter Standardwert in proj-parms.table: %s"
-#~ msgid "Creates a Voronoi diagram from an input vector map containing points or centroids."
-#~ msgstr "Erstellt ein Voronoi Diagramm auf Basis einer Vektorkarte mit Punkten oder Zentroiden."
-#~ msgid "Voronoi triangulation..."
-#~ msgstr "Voronoi Triangulation..."
-#~ msgid "Unknown column type '%s'"
-#~ msgstr "Unbekannter Spalten-Typ '%s'"
-#~ msgid "Unknown column type '%s' values lost"
-#~ msgstr "Unbekannter Spalten-Typ '%s', Werte verloren"
-#~ msgid "Merge boundaries:"
-#~ msgstr "Verbinde Grenzen:"
-#~ msgid "Delete line and exit"
-#~ msgstr "Lösche Linie und beenden"
-#~ msgid "Key column name"
-#~ msgstr "Name der Schlüsselspalte."
-#~ msgid "vector, transformation"
-#~ msgstr "Vektor, Transformation"
-#~ msgid "Unknown operator"
-#~ msgstr "Unbekannte Operater"
-#~ msgid "Copying vector lines..."
-#~ msgstr "Kopiere Vektorlinien..."
-#~ msgid "Print topology information only"
-#~ msgstr "Gebe nur Informationen zur Topologie aus."
-#~ msgid "Name of input vector points map for which to edit attribute table"
-#~ msgstr "Name der Vektorpunktekarte, dessen Attributtabelle editiert werden soll. "
-#~ msgid "Cannot parse MySQL embedded database name"
-#~ msgstr "Kann den Name der eingebetteten MySQL-Datenbank nicht interpretieren."
-#~ msgid "Cannot connect to MySQL embedded server: "
-#~ msgstr "Kann mich nicht mit dem eingebetteten MySQL-Server verbinden."
-#~ msgid "Cannot scan timestamp: "
-#~ msgstr "Kann den Zeitstempel nicht auslesen:"
-#~ msgid "Cannot scan datetime: "
-#~ msgstr "Kann Datum und Zeit (datetime) nicht auslesen:"
-#~ msgid "Cannot get list of tables:\n"
-#~ msgstr "Kann die Liste der Tabellen nicht holen:\n"
-#~ msgid "Unknown option in database definition for "
-#~ msgstr "Unbekannte Option in der Datenbankdefinition für"
-#~ msgid "Cannot recognize boolean value"
-#~ msgstr "Kann den Boolean-Wert nicht erkennen."
-#~ msgid "Tool to maintain GRASS extensions in local GRASS installation."
-#~ msgstr "Werkzeug um GRASS-Erweiterungen in lokaler GRASS-Installation zu verwalten."
-#~ msgid "Prefix where to install extension"
-#~ msgstr "Präfix wo Erweiterungen installiert werden"
-#~ msgid "List available modules in the GRASS Addons SVN repository"
-#~ msgstr "Zeige die im GRASS Addons Repository vorhandenen Module"
-#~ msgid "Reading raster map <%s in %s> ..."
-#~ msgstr "Lese Rasterkarte <%s in %s> ..."
-#~ msgid "Error writing row %d"
-#~ msgstr "Fehler beim Schreiben der Zeile %d."
-#~ msgid "Name of input vector points map"
-#~ msgstr "Name der Eingabe-Vektorkarte mit Punkten."
-#~ msgid "Cannot open vector map <%s>"
-#~ msgstr "Kann die Vektorkarte <%s> nicht öffnen."
-#~ msgid "Calculation of unconfined groundwater flow loop %i\n"
-#~ msgstr "Berechnung der unbeschränkten Grundwasserfluss Schleife %i\n"
-#~ msgid "Name of real-sky beam radiation coefficient input raster map [-]"
-#~ msgstr "Eingabe-Rasterkarte mit dem Koeffizient der direkten 'real-sky' Sonneneinstrahlung [-]."
-#~ msgid "Name of real-sky diffuse radiation coefficient input raster map [-]"
-#~ msgstr "Eingabe-Rasterkarte mit dem Koeffizient der diffusen 'real-sky' Sonneneinstrahlung [-]."
-#~ msgid "Name for distance output map"
-#~ msgstr "Name der Distanz-Ausgabekarte."
-#~ msgid "Name of table created for output when the distance to all flag is used"
-#~ msgstr "Name der auszugebenden Tabelle, erzeugt wenn der Schalter 'Distanz zu Allen' gesetzt wurde."
Modified: grass/trunk/locale/po/grassmods_el.po
--- grass/trunk/locale/po/grassmods_el.po	2012-05-26 15:22:06 UTC (rev 51802)
+++ grass/trunk/locale/po/grassmods_el.po	2012-05-26 15:46:05 UTC (rev 51803)
@@ -33051,2110 +33051,3 @@
 #: ../locale/scriptstrings/d.shadedmap_to_translate.c:5
 msgid "Percent to brighten"
 msgstr ""
-#, fuzzy
-msgid "Input raster map with specific yield in [1/m]"
-msgstr "Specific yield in 1/m"
-#, fuzzy
-msgid "DBMI-OGR driver error:\n"
-msgstr "DBMI-MySQL óöÜëìá ïäçãïý:\n"
-#, fuzzy
-msgid "relative"
-msgstr "ñÜóôåñ 3Ä, voxel"
-#, fuzzy
-msgid "Unable to parse '%s'\n"
-msgstr "Áäõíáìßá ðåñéãñáöÞò ðßíáêá <%s>"
-#, fuzzy
-msgid "Driver <%s> doesn't support creating new fields"
-msgstr "Ï äéáíõóìáôéêüò ÷Üñôçò <%s> õðÜñ÷åé Þäç êáé èá áíôéêáôáóôáèåß (overwritten)"
-#, fuzzy
-msgid "Unable to add new field <%s>"
-msgstr "Áäõíáìßá äçìéïõñãßáò ðßíáêá <%s>"
-#, fuzzy
-msgid "Name of file containing rules"
-msgstr "¼íïìá ôïõ áñ÷åßïõ ðïõ ðåñéÝ÷åé õðïãñáöÝò (signatures)"
-#, fuzzy
-msgid "Creating support files for <%s>"
-msgstr "Áäõíáìßá áíÜãíùóçò áñ÷åßïõ ÷ñþìáôïò ãéá ôïí ñÜóôåñ ÷Üñôç <%s>"
-#, fuzzy
-msgid "Title for new raster file."
-msgstr "¼íïìá åîáãüìåíïõ ñÜóôåñ ÷Üñôç"
-#, fuzzy
-msgid "Unable it load G3d range"
-msgstr "Áäõíáìßá äéáâÜóìáôïò åýñïõò fp ãéá ôïí ñáóôåñ ÷Üñôç <%s>"
-#, fuzzy
-msgid "Exports the color table associated with a raster3d map layer."
-msgid "Error closing new ASCII file"
-msgstr "ÓöÜëìá êáôÜ ôï êëåßóéìïõ íÝïõ ASCII áñ÷åßïõ"
-msgid "Could not close RASTER3D map"
-msgstr "Äåí ãßíåôáé íá êëåßóåé ï G3Ä ÷Üñôçò"
-msgid "Could not close RASTER3D map <%s>"
-msgstr "Äåí ìðïñåß íá êëåßóåé ï RASTER3D ÷Üñôçò <%s>"
-msgid "Name for v5d output file"
-msgstr "¼íïìá ãéá ôï åîáãþìåíï v5d áñ÷åßï"
-#, fuzzy
-msgid "Converts a 3D raster map into a 3-dimensional Vis5D file."
-msgstr "ÅîáãùãÞ ôïõ GRASS 3Ä ñÜóôåñ ÷Üñôç óå 3 äéÜóôáôï Vis5D áñ÷åßï"
-#, fuzzy
-msgid "Coordinates"
-msgstr "ËÜèïò óõíôåôáãìÝíåò"
-#, fuzzy
-msgid "reclass raster output map"
-msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ åîáãüìåíïõ ÷Üñôç"
-#, fuzzy
-msgid "Name of input vector polygon map"
-msgstr "¼íïìá åéóáãþìåíùí ñÜóôåñ ÷áñôþí"
-#, fuzzy
-msgid "raster, import, copying"
-msgstr "ñÜóôåñ 3Ä, óôáôéóôéêÜ"
-#, fuzzy
-msgid "raster, export, copying"
-#, fuzzy
-msgid "Name for output shaded relief map"
-#, fuzzy
-msgid "Reading file <%s> ..."
-msgstr "×Üñôçò åðáíáöüñôéóçò óå  m^3/s"
-#, fuzzy
-msgid "OGR data source name"
-msgstr "ÅîáãùãÞ üíïìá âÜóçò äåäïìÝíùí"
-#, fuzzy
-msgid "OGR layer name"
-msgstr "ÅîáãùãÞ ïíüìáôïò ðßíáêá"
-#, fuzzy
-msgid "Name for GRASS vector map"
-msgstr "¼íïìá åîáãüìåíïõ äéáíõóìáôéêïý ÷Üñôç"
-#, fuzzy
-msgid "value, parameter"
-msgstr "ËÜèïò ðáñÜìåôñïé"
-#, fuzzy
-msgid "sun_elevation"
-#, fuzzy
-msgid "Path to rules file (\"-\" to write rules to stdout)"
-msgstr "¼íïìá åéóáãþìåíïõ äéáíõóìáôéêïý ÷Üñôç "
-#, fuzzy
-msgid "Can't read color table for <%s>"
-#, fuzzy
-msgid "Displays raster map layer."
-msgstr "Áäõíáìßá áíÜãíùóçò äéáíõóìáôéêïý ÷Üñôç"
-#, fuzzy
-msgid "<%s> created."
-msgstr "Ï ÷Üñôçò raster  <%s> äåí âñÝèçêå"
-#, fuzzy
-msgid "Available drivers:\n"
-msgstr "Äßíåé ôç ëßóôá ãéá üëïõò ôïõò ïäçãïýò âÜóåùí äåäïìÝíùí"
-#, fuzzy
-msgid "Raster file to be converted."
-msgstr "Ôï 3Ä ñÜóôåñ áñ÷åßï èá ìåôáôñáðåß óå ASCII"
-#, fuzzy
-msgid ""
-"Calculate the groundwater distance velocity vector field \n"
-"and write the x, y, and z components to maps named name_[xyz].\n"
-"Name is basename for the new raster3d maps"
-msgstr "Õðïëïãßóôå ôçí ôá÷ýôçôá ôïõ õðïãåéïõ íåñïý (äéáíõóìáôéêü ìåñïò) êáé ãñÜøôå ôá ÷ , ø êáé æ óôïé÷åßá óôï ÷Üñôç ìå üíïìá name_[xyz]. Ôï üíïìá åßíáé ôï âáóéêü üíïìá ãéá ôïõò íÝïõò ñÜóôåñ 3Ä ÷Üñôåò"
-#, fuzzy
-msgid "Unable to get cell header for <%s>"
-msgstr "Áäõíáìßá äçìéïõñãßáò raster ÷Üñôç <%s>"
-#, fuzzy
-msgid "Error reading <%s>"
-msgstr "ÓöÜëìá êáôÜ ôçí áíÜãíùóç ôïõ åýñïõò ãéá [%s]"
-#, fuzzy
-msgid "%s: Error reading from raster map <%s>"
-msgstr "ÓöÜëìá áíïßãìáôïò 3Ä ñÜóôåñ ÷Üñôç <%s>"
-#, fuzzy
-msgid "unable to open map <%s> in <%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò ôïõ ÷Üñôç raster <%s@%s>"
-#, fuzzy
-msgid "unable to read map <%s> in <%s>"
-#, fuzzy
-msgid "Unable to open base map <%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò ôïõ ÷Üñôç raster <%s>"
-#, fuzzy
-msgid "Unable to open cover map <%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò äéáíõóìáôéêïý ÷Üñôç <%s>"
-#, fuzzy
-msgid "Unable to open output map <%s>"
-#, fuzzy
-msgid "Unable to read header for <%s>"
-#, fuzzy
-msgid "Error reading row %d (error = %d)"
-#, fuzzy
-msgid "Unable to read row %d"
-msgstr "Áäõíáìßá äçìéïõñãßáò ñÜóôåñ ÷Üñôç"
-#, fuzzy
-msgid "unable to open accumulation map layer"
-msgstr "Áäõíáìßá áíïßãìáôïò ÷Üñôç õøïìÝôñùí"
-#, fuzzy
-msgid "Unable to open input map <%s>"
-#, fuzzy
-msgid "Unable to read from <%s> row %d"
-#, fuzzy
-msgid "Unable to read file header of raster map <%s>"
-#, fuzzy
-msgid "Unable to write to raster map<%s>"
-msgstr "Áäõíáìßá äçìéïõñãßáò raster ÷Üñôç <%s>."
-#, fuzzy
-msgid "Unable to open training map <%s>"
-#, fuzzy
-msgid "Unable to open training map <%s in %s>"
-#, fuzzy
-msgid "Cannot read file header of [%s])"
-#, fuzzy
-msgid "Could not open <%s>"
-#, fuzzy
-msgid "Unable to read header of raster map <%s> "
-#, fuzzy
-msgid "Unable to read raster map <%s> row %d >"
-#, fuzzy
-msgid "Name of QC"
-msgstr "¼íïìá áñ÷åßïõ åîáãùãÞò"
-#, fuzzy
-msgid "Unable to find the real-image map <%s>"
-#, fuzzy
-msgid "Unable to find the imaginary-image <%s>"
-msgstr "Áäõíáìßá öüñôùóçò äåäïìÝíùí ðßíáêá <%s>"
-#, fuzzy
-msgid "Group [%s] not found."
-msgstr "Ç óôÞëç <%s> äåí âñÝèçêå"
-#, fuzzy
-msgid "Writing viewable versions of transformed data to files..."
-msgstr "ÅããñáöÞ %s áðü %s..."
-#, fuzzy
-msgid "Unable to proceed"
-msgstr "Áäõíáìßá áíïßãìáôïò âÜóçò äåäïìåíùí <%s>"
-#, fuzzy
-msgid "Unable to read head of %s"
-#, fuzzy
-msgid "Default value: GRASS_GUI if defined otherwise tcltk"
-msgstr "ÐñïåðéëïãÞ"
-#, fuzzy
-msgid "Cannot write color table of raster map <%s>"
-#, fuzzy
-msgid "Unable to create signature file [%s] for subgroup [%s] in group [%s]."
-msgstr "Áäõíáìßá äçìéïõñãßáò êáôáëüãïõ ãéá ôïí ðßíáêá <%s>, êëåéäß <%s>"
-#, fuzzy
-msgid "Cannot read row from raster map"
-#, fuzzy
-msgid "Error while writing to temp file"
-msgstr "ÓöÜëìá êáôÜ ôçí åããñáöÞ ôïõ grid. Äßóêïò ãåìÜôïò;"
-#, fuzzy
-msgid "Cannot open cover raster map <%s>"
-#, fuzzy
-msgid "Cannot open dig_cats file."
-msgstr "Áäõíáìßá áíïßãìáôïò ðñïóùñéíïý áñ÷åßïõ"
-msgid "Converts a 3D raster map layer into an ASCII text file"
-msgstr "ÌåôáôñÝðåé Ýíá 3Ä åðßðåäï ñÜóôåñ ÷Üñôç óå Ýíá ASCII áñ÷åßï êåéìÝíïõ"
-msgid "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
-msgstr "ÌåôáôñïðÞ åíüò 3Ä ASCII ñÜóôåñ áñ÷åßïõ óå (binary) 3Ä ñÜóôåñ åðßðåäï"
-#, fuzzy
-msgid "Output saturation raster map"
-#, fuzzy
-#~ msgid "Name for value output map"
-#~ msgstr "¼íïìá åîáãüìåíïõ ñÜóôåñ ÷Üñôç"
-#, fuzzy
-#~ msgid "Reading sites..."
-#~ msgstr "×Üñôçò åðáíáöüñôéóçò óå  m^3/s"
-#, fuzzy
-#~ msgid "Writing sites to output..."
-#~ msgstr "ÅããñáöÞ %s áðü %s..."
-#~ msgid "Cannot scan date: "
-#~ msgstr "Áäõíáìßá óêáíáñßóìáôïò çìåñïìçíßáò:"
-#~ msgid "Cannot scan time: "
-#~ msgstr "Áäõíáìßá óêáíáñßóìáôïò ÷ñüíïõ: "
-#~ msgid "Cannot allocate cursor."
-#~ msgstr "Äåí ãßíåôáé ç ìåôáêßíçóç ôïõ êÝñóïñá."
-#~ msgid "Cannot ad new token."
-#~ msgstr "Áäýíáôç ç ðñïóèÞêç new token"
-#~ msgid "Cannot connect to MySQL: "
-#~ msgstr "Áäõíáìßá óýíäåóçò óôçí MySQL: "
-#~ msgid "Cannot select data: \n"
-#~ msgstr "Áäýíáôç ç åðéëïãÞ äåäïìÝíùí: \n"
-#, fuzzy
-#~ msgid "Unable to allocate memory for row buffer"
-#~ msgstr "Áäõíáìßá õðïëïãéóìïý êÝíôñùí ðïëõãþíïõ ãéá ôçí åðéöÜíåéá %d"
-#, fuzzy
-#~ msgid "Unable to allocate memory for raster row"
-#~ msgstr "Áäõíáìßá ëÞøçò ãñáììÞò õøïìÝôñùí áðü ñÜóôåñ"
-#, fuzzy
-#~ msgid "Writing buffers..."
-#, fuzzy
-#~ msgid "Join column in other table"
-#~ msgstr "Áñéèìüò ãñáììþí ðïõ èá åìöáíßæïíôáé óôï õðüìíçìá."
-#, fuzzy
-#~ msgid "Layer number or name with route paths or -1"
-#~ msgstr "Íïýìåñï åðéðÝäïõ"
-#, fuzzy
-#~ msgid "Layer %d - unable to copy table"
-#~ msgstr "Áäõíáìßá áíôéãñáöÞò ðßíáêá <%s>"
-#, fuzzy
-#~ msgid "Source layer number or name"
-#, fuzzy
-#~ msgid "Sink layer number or name"
-#, fuzzy
-#~ msgid "Name of Arc cost column"
-#, fuzzy
-#~ msgid "From layer number or name"
-#, fuzzy
-#~ msgid "To layer number or name"
-#, fuzzy
-#~ msgid "Name of node capacity column"
-#, fuzzy
-#~ msgid "Set1 layer number or name"
-#, fuzzy
-#~ msgid "Set2 layer number or name"
-#, fuzzy
-#~ msgid "Color definition column not specified."
-#~ msgstr "×ñþìá."
-#~ msgid "pg driver: column '%s', type %d  is not supported"
-#~ msgstr "pg driver: óôÞëç '%s', ôýðïò %d äåí õðïóôçñßæåôáé"
-#, fuzzy
-#~ msgid "Type of color table"
-#~ msgstr "Ôýðïò"
-#, fuzzy
-#~ msgid "Save placeholder raster map for use with d.legend"
-#~ msgstr "×ñþìá"
-#~ msgid "Requested g3d map <%s> not found"
-#~ msgstr "Ï ÷Üñôçò g3d <%s> äåí âñÝèçêå"
-#~ msgid "Error opening g3d map <%s>"
-#~ msgstr "ÓöÜëìá êáôÜ ôï Üíïéãìá ôïõ g3d ÷Üñôç <%s>"
-#~ msgid "Requested 3d raster map not found"
-#~ msgstr "Ï æçôïýìåíïò 3Ä ñÜóôåñ ÷Üñôçò äåí âñÝèçêå"
-#~ msgid "modifyNull: error opening map"
-#~ msgstr "modifyNull: óöÜëìá êáôÜ ôï Üíïéãìá ôïõ ÷Üñôç"
-#~ msgid "Adding rule: %lf - %lf"
-#~ msgstr "Ðñüóèåóç êáíüíá: %lf - %lf"
-#~ msgid "Error closing new 3d raster map"
-#~ msgstr "ÓöÜëìá êáôÜ ôï êëåßóåéìï 3Ä ñÜóôåñ ÷Üñôç"
-#~ msgid "Error closing ascii file"
-#~ msgstr "ÓöÜëìá êáôÜ ôï êëåßóïìï ascii áñ÷åßïõ"
-#~ msgid "Error: couldn't create %s"
-#~ msgstr "ÓöÜëìá: äåí Þôáí äõíáôÞ ç äçìéïõñãßá %s"
-#~ msgid "Error while writing grid. Disk full?"
-#~ msgstr "ÓöÜëìá êáôÜ ôçí åããñáöÞ ôïõ grid. Äßóêïò ãåìÜôïò;"
-#, fuzzy
-#~ msgid "Name for output flowline density raster map"
-#, fuzzy
-#~ msgid "Color to erase with, either a standard GRASS color or R:G:B triplet (separated by colons)"
-#~ msgstr "×ñþìá"
-#~ msgid "Name for output vector map"
-#~ msgstr "¼íïìá åîáãüìåíïõ äéáíõóìáôéêïý ÷Üñôç"
-#~ msgid "Name for output raster map prefix (e.g. 'brov')"
-#~ msgstr "¼íïìá åîáãüìåíïõ ñÜóôåñ ÷Üñôç prefix (e.g. 'brov')"
-#~ msgid "raster input map"
-#~ msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ ÷Üñôç input."
-#, fuzzy
-#~ msgid "Vector map to modify"
-#~ msgstr "Ascii ñÜóôåñ ÷Üñôçò ðïõ èá åéóá÷èåß"
-#, fuzzy
-#~ msgid "Layer of the query vector containing data"
-#, fuzzy
-#~ msgid "Column to be queried"
-#~ msgid "Name of input vector map"
-#~ msgstr "¼íïìá åéóáãþìåíïõ äéáíõóìáôéêïý ÷Üñôç "
-#, fuzzy
-#~ msgid "Vector map to edit the attribute table for"
-#~ msgstr "âÜóç äåäïìÝíùí, ðßíáêáò éäéïôÞôùí"
-#, fuzzy
-#~ msgid "Column to query"
-#, fuzzy
-#~ msgid "Raster map to use as mask"
-#~ msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ ÷Üñôç input"
-#, fuzzy
-#~ msgid "Old schema"
-#~ msgstr "Ç äéÜôáîç ôçò âÜóçò äåäïìÝíùí"
-#, fuzzy
-#~ msgid "New schema"
-#, fuzzy
-#~ msgid "Vector map for which to rename attribute column"
-#, fuzzy
-#~ msgid "Layer where to rename column"
-#, fuzzy
-#~ msgid "Table from which to drop attribute column"
-#, fuzzy
-#~ msgid "Vector map from which to remove attribute table"
-#, fuzzy
-#~ msgid "Name of existing attribute table (default: vector map name)"
-#~ msgstr "¼íïìá õðÜñ÷ïíôùò 3Ä ñÜóôåñ ÷Üñôç"
-#, fuzzy
-#~ msgid "Layer from which to drop linked attribute table"
-#, fuzzy
-#~ msgid "Vector map for which to drop attribute column"
-#, fuzzy
-#~ msgid "Layer where to drop column"
-#, fuzzy
-#~ msgid "raster output TC maps prefix"
-#, fuzzy
-#~ msgid "Vector map for which to add new attribute table"
-#, fuzzy
-#~ msgid "vector, import, wfs"
-#~ msgstr "raster3d, voxel, åéóÜãåôáé"
-#, fuzzy
-#~ msgid "Name of data table"
-#~ msgstr "Áäõíáìßá ëßóôáò âÜóåùí äåäïìÝíùí"
-#, fuzzy
-#~ msgid "Database driver"
-#~ msgstr "Äßíåé ôç ëßóôá ãéá üëïõò ôïõò ïäçãïýò âÜóåùí äåäïìÝíùí"
-#, fuzzy
-#~ msgid "Cannot open file [%s] in mapset [%s]"
-#~ msgstr "Áäõíáìßá áíïßãìáôïò ôïõ ÷Üñôç raster <%s>"
-#, fuzzy
-#~ msgid "Cannot create file <%s> in mapset <%s>"
-#~ msgstr "¸ëåã÷ïò location <%s>, mapset <%s>..."
-#, fuzzy
-#~ msgid "output,cell,raster"
-#, fuzzy
-#~ msgid "Pass %d:"
-#~ msgstr "Êùäéêüò"
-#, fuzzy
-#~ msgid "Writing [%s] ..."
-#~ msgid "raster3d, statistics"
-#~ msgstr "ñÜóôåñ 3Ä, óôáôéóôéêÜ"
-#, fuzzy
-#~ msgid "Vector map for which to edit attribute table"
-#, fuzzy
-#~ msgid "Layer where to add column"
-#, fuzzy
-#~ msgid "Type of elements"
-#~ msgstr "Ôýðïò"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "    (%s).\n"
-#~ msgstr ""
-#~ "\n"
-#~ "ÓÖÁËÌÁ: Ç áðáéôïýìåíç ðáñÜìåôñïò <%s> äåí Ý÷åé êáèïñéóôåß:\n"
-#~ "    (%s).\n"
-#, fuzzy
-#~ msgid "Vector output map"
-#~ msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ åîáãüìåíïõ ÷Üñôç"
-#, fuzzy
-#~ msgid "Unable to read raster map row %ld"
-#~ msgstr "Áäõíáìßá äçìéïõñãßáò ñÜóôåñ ÷Üñôç"
-#, fuzzy
-#~ msgid "Failed writing raster map row %ld"
-#~ msgstr "Äåí Þôáí äõíáôÞ ç åããñáöÞ ãñáììÞò ñÜóôåñ"
-#~ msgid "Sources and sinks in [m^3/s]"
-#~ msgstr "Sources and sinks in [m^3/s]"
-#, fuzzy
-#~ msgid "Output shaded relief map name"
-#~ msgstr "ÅîáãùãÞ üíïìá ïäçãïý"
-#, fuzzy
-#~ msgid "Unable to access table <%s>"
-#~ msgstr "Áäõíáìßá äçìéïõñãßáò ðßíáêá <%s>"
-#~ msgid ""
-#~ "\n"
-#~ "Enter database password for connection\n"
-#~ "<%s:%s:user=%s>\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Äþóôå ôïí êùäéêü ôçò âÜóçò äåäïìÝíùí ãéá ôç óýíäåóç\n"
-#~ msgid "Hit RETURN to cancel request\n"
-#~ msgstr "ÐáôÞóôå ôï ðëÞêôñï RETURN ãéá íá áêõñþóåôå ôçí åíôïëÞ\n"
-#~ msgid "Exiting. Not changing current settings"
-#~ msgstr "Êëåßóéìï åöáñìïãÞò, ÷ùñßò íá áëëÜîïõí ïé ôñÝ÷ïõóåò åðéëïãÝò"
-#~ msgid "New password set"
-#~ msgstr "Ï íÝïò êùäéêüò äçìéïõñãÞèçêå"
-#~ msgid "Unable to close output map"
-#~ msgid "Could not write raster row"
-#~ msgid "Unable to open elevation map"
-#~ msgstr "Áäõíáìßá áíïßãìáôïò ÷Üñôç õøïìÝôñùí"
-#~ msgid "Unable to close elevation map"
-#~ msgstr "Áäõíáìßá êëåéóßìáôïò ÷Üñôç õøïìÝôñùí"
-#, fuzzy
-#~ msgid "Error writing null row %d"
-#~ msgstr "ÓöÜëìá êáôÜ ôçí áíÜãíùóç ôïõ åýñïõò ãéá [%s]"
-#, fuzzy
-#~ msgid "Unable to close input map"
-#, fuzzy
-#~ msgid "Unable to read raster <map %d of %d> row %d"
-#, fuzzy
-#~ msgid "Unable to create distance map <%s>"
-#~ msgstr "Áäõíáìßá äçìéïõñãßáò raster ÷Üñôç <%s>"
-#, fuzzy
-#~ msgid "Unable to create value map <%s>"
-#, fuzzy
-#~ msgid "Unable to write color table for raster map <%s>"
-#~ msgstr "Áäõíáìßá áíÜãíùóçò áñ÷åßïõ ÷ñþìáôïò ãéá ôïí ñÜóôåñ ÷Üñôç <%s>"
-#, fuzzy
-#~ msgid "Unable to read raster map row %d "
-#, fuzzy
-#~ msgid "Failed writing raster map row %d"
-#, fuzzy
-#~ msgid "unable to open new LS factor map layer."
-#~ msgstr "Áäõíáìßá áíïßãìáôïò äéáíõóìáôéêïý ÷Üñôç <%s>"
-#, fuzzy
-#~ msgid "unable to open new S factor map layer."
-#, fuzzy
-#~ msgid "Unable to open raster map <%s@%s>"
-#~ msgstr "Áäõíáìßá áíïßãìáôïò ôïõ ÷Üñôç raster <%s@%s>"
-#, fuzzy
-#~ msgid "Could not get raster row"
-#~ msgstr "Áäõíáìßá áíÜãíùóçò ôçò ãñáììÞò (row) ôïõ ÷Üñôç"
-#, fuzzy
-#, fuzzy
-#~ msgid "Layer is only used for WHERE SQL statement"
-#~ msgstr "×ñçóéìïðïéÞóôå sb.select ãéá SELECT SQL åíôïëÝò"
-#~ msgid "raster3d, voxel, export"
-#~ msgstr "ñÜóôåñ 3D, voxel, åîáãùãÞ"
-#~ msgid "raster3d, voxel, import"
-#, fuzzy
-#~ msgid "vector, report, statistics"
-#, fuzzy
-#~ msgid "raster, statistics, aggregation"
-#, fuzzy
-#~ msgid "raster, imagery, import"
-#, fuzzy
-#~ msgid "raster, imagery"
-#~ msgstr "ñÜóôåñ 3Ä, voxel"
-#, fuzzy
-#~ msgid "raster, mask"
-#, fuzzy
-#~ msgid "raster, imagery, statistics"
-#, fuzzy
-#~ msgid "Unable to select record from table <%s> (key %s, column %s)"
-#~ msgstr "Áäõíáìßá äçìéïõñãßáò êáôáëüãïõ ãéá ôïí ðßíáêá <%s>, êëåéäß <%s>"
-#, fuzzy
-#~ msgid "Column <%s>: unsupported data type"
-#~ msgstr "Ç óôÞëç <%s> äåí âñÝèçêå"
-#, fuzzy
-#~ msgid "  Type of Map:  %s (level: %i)        "
-#~ msgstr "Ôýðïò "
-#~ msgid "database, attribute table, SQL"
-#~ msgstr "ÂÜóç äåäïìÝíùí, ðßíáêáò éäéïôÞôùí, SQL"
-#~ msgid "Use db.select for SELECT SQL statements"
-#~ msgid "Do not use this option if schemas are not supported by driver/database server"
-#~ msgstr "Ìçí ÷ñçóéìïðïéÞóåôå áõôÞ ôçí åðéëïãÞ Üí ç äéÜôáîç äåí õðïóôçñßæåôáé áðü ôïí åîõðçñåôçôÞ ïäçãü/âÜóç äåäïìÝíùí"
-#~ msgid "Selects data from table."
-#~ msgstr "ÅðéëÝãåé äåäïìÝíá áðü ôïí ðßíáêá/"
-#, fuzzy
-#~ msgid "raster, random, cell"
-#, fuzzy
-#~ msgid "raster, statistics, reclass"
-#, fuzzy
-#~ msgstr "Áäõíáìßá áíïßãìáôïò ôçò âÜóçò äåäïìÝíùí <%s> ìå ôïí ïäçãü <%s>"
-#, fuzzy
-#~ msgid "Cannot select attributes: %s"
-#, fuzzy
-#~ msgid "Output inverse raster map after IFFT"
-#, fuzzy
-#~ msgid "Saturation map name"
-#~ msgstr "¼íïìá ôïðïèåóßá"
-#, fuzzy
-#~ msgid "Cannot write row to raster map"
-#, fuzzy
-#~ msgid "Output intensity raster map"
-#, fuzzy
-#~ msgid "Class transition statistics."
-#, fuzzy
-#~ msgid "get_img: out of memory."
-#~ msgstr "G_malloc: åêôüò ìíÞìçò"
-#, fuzzy
-#~ msgid "Name of imagery signaturefile"
-#~ msgstr "¼íïìá ôïõ áñ÷åßïõ ðïõ ðåñéÝ÷åé SQL åíôïëÝò"
-#, fuzzy
-#~ msgid "Subgroup [%s] not found."
-#, fuzzy
-#~ msgid "Resultant signature file"
-#, fuzzy
-#~ msgid "Reading the raster map..."
-#~ msgstr "ÓöÜëìá áíïßãìáôïò 3Ä ñÜóôåñ ÷Üñôç <%s>"
-#, fuzzy
-#~ msgid "subgroup <%s> not found"
-#, fuzzy
-#~ msgid "Output file to contain final report"
-#, fuzzy
-#~ msgid "Can't creat reportfile: "
-#, fuzzy
-#~ msgid "group=[%s] - not found."
-#, fuzzy
-#~ msgid "Can't read signature file [%s]."
-#, fuzzy
-#~ msgid "Unable to create reject layer [%s]."
-#, fuzzy
-#~ msgid "Density of output walkers"
-#~ msgstr "¼íïìá áñ÷åßïõ åîáãùãÞò"
-#, fuzzy
-#~ msgid "Unable to read current region parameters"
-#~ msgstr "Áäõíáìßá äéáâÜóìáôïò åýñïõò fp ãéá ôïí ñáóôåñ ÷Üñôç <%s>"
-#, fuzzy
-#~ msgid "Cannot open database <%s> by driver <%s>"
-#, fuzzy
-#~ msgid "%s - color table not found"
-#~ msgstr "Ï êÝñóïñáò äåí âñÝèçêå"
-#, fuzzy
-#~ msgid "Unable to properly read input raster map"
-#, fuzzy
-#~ msgid "Unable to properly write output raster map"
-#, fuzzy
-#~ msgid "CrossCorrelation: Cannot open database %s by driver %s"
-#, fuzzy
-#~ msgid "CrossCorrelation: Column type not supported"
-#, fuzzy
-#~ msgid "CrossCorrelation: Cannot select data from table"
-#~ msgstr "Áäõíáìßá öüñôùóçò äåäïìÝíùí ðßíáêá <%s>"
-#, fuzzy
-#~ msgid "Cannot select records from database"
-#, fuzzy
-#~ msgid "Cannot fetch data"
-#, fuzzy
-#~ msgid "Input vector was not found."
-#~ msgstr "Ï äéáíõóìáôéêüò ÷Üñôçò <%s> äåí âñÝèçêå"
-#, fuzzy
-#~ msgid "Run quietly"
-#~ msgstr "ÔñÝ÷åé ÷ùñßò ìçíýìáôá"
-#~ msgid "Elevation map not found"
-#~ msgstr "Ï ÷Üñôçò õøïìÝôñùí äåí âñÝèçêå"
-#, fuzzy
-#~ msgid "%s: Unable to read font definition file; use the default"
-#~ msgstr "%s: Áäõíáìßá áíÜãíùóçò ôïõ áñ÷åßïõ ãñáììáôïóåéñÜò, ÷ñçóéìïðïéÞóôå ôï ðñïåðéëåãìÝíï"
-#, fuzzy
-#~ msgid "%s: No font definition file"
-#~ msgstr "%s: Äåí õðáñ÷åéï áñ÷åßï ãñáììáôïóåéñÜò"
-#~ msgid "Illegal output file name"
-#~ msgstr "Ìç åðéôñåðôü üíïìá åîáãþìåíïõ ÷Üñôç"
-#, fuzzy
-#~ msgid "Name for output grid3D volume"
-#, fuzzy
-#~ msgid "Color table for <%s> updated"
-#~ msgstr "×ñþìá"
-#, fuzzy
-#~ msgid "Target location [%s] not found\n"
-#, fuzzy
-#~ msgid "not found\n"
-#, fuzzy
-#~ msgid "Pre-selected group <%s> not found"
-#~ msgstr "Ï ÷Üñôçò g3d <%s> äåí âñÞèçêå"
-#, fuzzy
-#~ msgid "Image Group [%s] not found"
-#~ msgstr "Ï ÷Üñôçò raster  <%s> äåí âñÝèçêå"
-#, fuzzy
-#~ msgid "Color to draw with, either a standard GRASS color or R:G:B triplet (separated by colons)"
-#~ msgstr "×ñþìá"
-#, fuzzy
-#~ msgid "Name of raster map to print in legend"
-#~ msgstr "×ñþìá"
-#~ msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2)"
-#~ msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç (NIR: tm4 | qbird_nir | spot2"
-#~ msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3)"
-#~ msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç (MIR; tm5 | qbird_red | spot3)"
-#, fuzzy
-#~ msgid "Integer data range of raster map <%s> is empty"
-#, fuzzy
-#~ msgid "Integer data range of raster mao <%s> is %d to %d"
-#, fuzzy
-#~ msgid "Group [%s] not found"
-#, fuzzy
-#~ msgid "Unable to read raster header of <%s>"
-#, fuzzy
-#~ msgid "%s@%s: projection doesn't match current settings"
-#, fuzzy
-#~ msgid "%s@%s: zone doesn't match current settings"
-#~ msgid "raster3d, voxel"
-#~ msgid "The initial piezometric head in [m]"
-#~ msgstr "Ç áñ÷éêÞ ðéåæïìåôñéêÞ óôÞëç óå [m]"
-#~ msgid "The status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
-#~ msgstr "Ç êáôÜóôáóç êÜèå êåëéïý, = 0 - inactive, 1 - active, 2 - dirichlet"
-#~ msgid "The z-part of the hydraulic conductivity tensor in [m/s]"
-#~ msgstr "Ôï z-ìÝñïò ôçò õäñáõëéêÞò áãùãéìüôçôáò óå [m/s]"
-#~ msgid "Specific yield in 1/m"
-#~ msgstr "Specific yield in 1/m"
-#~ msgid "Recharge raster map in m^3/s"
-#~ msgid "The piezometric head result of the numerical calculation will be written to this map"
-#~ msgstr "Ç ðéåæïìåôñéêÞ óôÞëç, áðïôÝëåóìá ôùí áñéèìçôéêþí õðïëïãéóìþí èá ãñáöôåß óå áõôü ôï ÷Üñôç"
-#~ msgid "Calculate the groundwater distance velocity vector field and write the x, y, and z components to maps named name_[xyz]. Name is basename for the new raster3d maps"
-#~ msgstr "Õðïëïãßóôå ôçí ôá÷ýôçôá ôïõ õðïãåéïõ íåñïý (äéáíõóìáôéêü ìåñïò) êáé ãñÜøôå ôá ÷ , ø êáé æ óôïé÷åßá óôï ÷Üñôç ìå üíïìá name_[xyz]. Ôï üíïìá åßíáé ôï âáóéêü üíïìá ãéá ôïõò íÝïõò ñÜóôåñ 3Ä ÷Üñôåò"
-#, fuzzy
-#~ msgid "raster, terrain"
-#, fuzzy
-#~ msgid "Unable to find row %d, col %d: %f"
-#, fuzzy
-#~ msgid "unable to open flow accumulation map layer"
-#, fuzzy
-#~ msgid "Generates a raster map layer of distance to features in input layer."
-#~ msgstr "ÌåôáôñÝðåé Ýíá 3Ä åðßðåäï ñÜóôåñ ÷Üñôç óå Ýíá ASCII áñ÷åßï êåéìÝíïõ"
-#, fuzzy
-#~ msgid "(i)   TOPMODEL Parameters file"
-#~ msgstr "ÐáñÜìåôñïé"
-#, fuzzy
-#~ msgid "Calculating map %01d of %01d (angle %lf, raster map <%s>)"
-#, fuzzy
-#~ msgid "Data range of raster map <%s> is empty"
-#, fuzzy
-#~ msgid "Stream width (in meters). Default is raster cell width"
-#~ msgstr "ÐñïåðéëïãÞ"
-#, fuzzy
-#~ msgid "Default value: GRASS_GUI if defined, otherwise wxpython"
-#~ msgid "Color for drawing X's (Null values)"
-#~ msgstr "×ñþìá ãéá ôïí ó÷åäéáóìü ×'s  (Null values)"
-#, fuzzy
-#~ msgid "R_color file for [%s] not available"
-#~ msgstr "×ñþìá"
-#, fuzzy
-#~ msgid "Range file for [%s] not available"
-#~ msgstr "×ñþìá"
-#, fuzzy
-#~ msgid "Layer number (write to)"
-#, fuzzy
-#~ msgid "vector, import, database, points"
-#, fuzzy
-#~ msgid "Layer number (from)"
-#, fuzzy
-#~ msgid "Layer number (to)"
-#, fuzzy
-#~ msgid "Calculate area centroids..."
-#~ msgid "OGR driver: column '%s', OGR type %d  is not supported"
-#~ msgstr "OGR driver: óôÞëç '%s', OGR ôýðïò %d äåí õðïóôçñßæåôáé"
-#~ msgid "database, attribute table"
-#~ msgid "Prints/sets general DB connection for current mapset and exits."
-#~ msgstr "Åêôõðþíåé/óåôÜñåé ãåíéêÞ DB óýíäåóç ãéá ôï ôñÝ÷ùí maps êáé êëåßíåé"
-#~ msgid "database, SQL"
-#~ msgstr "ÂÜóç äåäïìÝíùí, SQL"
-#~ msgid "Name of file with sql statement"
-#~ msgstr "¼íïìá áñ÷åßïõ ìå sql åíôïëÞ"
-#~ msgid "The password was stored in file"
-#~ msgstr "Ï êùäéêüò áðïèçêåýôçêå óôï áñ÷åßï"
-#, fuzzy
-#~ msgid "raster, elevation"
-#, fuzzy
-#~ msgid "Compression for PNG files"
-#~ msgstr "¼íïìá áñ÷åßïõ PNG."
-#, fuzzy
-#~ msgid "Do not crop away margins"
-#, fuzzy
-#~ msgid "Reports geometry statistics for vectors."
-#~ msgstr "ÐáñÜãåé óôáôéóôéêÜ üãêïõ ãéá 3Ä ñÜóôåñ ÷Üñôåò."
-#, fuzzy
-#~ msgid "display, export, GPS"
-#, fuzzy
-#~ msgid "sites, vector, import"
-#, fuzzy
-#~ msgid "vector, export, GPS"
-#, fuzzy
-#~ msgid "Layer number of data column"
-#, fuzzy
-#~ msgid "Number of seconds to pause between slides"
-#, fuzzy
-#~ msgid "Number of subframes"
-#~ msgstr "Íïýìåñï ôùí õðïðåñéï÷þí ãéá óõëëïãÞ óôáôéóôéêþí áðü áõôÜ"
-#, fuzzy
-#~ msgid "vector, import, gazetteer"
-#, fuzzy
-#~ msgid "Name of vector polygon map"
-#~ msgstr "¼íïìá åéóáãþìåíùí ñÜóôåñ ÷áñôþí"
-#, fuzzy
-#~ msgid "Name of raster map to calculate statistics from"
-#~ msgid "Name of .dmrc settings file"
-#~ msgstr "¼íïìá áñ÷åßïõ .dmrc"
-#, fuzzy
-#~ msgid "Name of GIS manager settings file (.grc)"
-#, fuzzy
-#~ msgid "raster, imagery, colors"
-#, fuzzy
-#~ msgid "vector, area, dissolve"
-#, fuzzy
-#~ msgid "vector, centroid, area"
-#~ msgstr "äéÜíõóìá, ðßíáêáò ÷ñùìÜôùí"
-#, fuzzy
-#~ msgid "Import of SPOT VGT NDVI file into a raster map"
-#~ msgstr "Áäõíáìßá áíÜãíùóçò äéáíõóìáôéêïý ÷Üñôç"
-#, fuzzy
-#~ msgid "Writing data..."
-#, fuzzy
-#~ msgid "Name of fractal surface raster layer"
-#~ msgstr "¼íïìá ÷Üñôç õðïâÜèñïõ ñÜóôåñ"
-#, fuzzy
-#~ msgid "Reading sites map (%s) ..."
-#, fuzzy
-#~ msgstr "Áäõíáìßá áíïßãìáôïò âÜóçò äåäïìåíùí <%s>"
-#, fuzzy
-#~ msgid "Cannot insert into table: %s"
-#~ msgstr "Äåí ìðïñþ íá äù ëßóôá ôùí ðéíÜêùí:\n"
-#, fuzzy
-#~ msgid "Rotating data arrays..."
-#, fuzzy
-#~ msgid "Red input raster map"
-#~ msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç "
-#, fuzzy
-#~ msgid "<%s> is an ilegal name"
-#~ msgstr "<%s> åßíáé ìç åðéôñåðôü üíïìá áñ÷åßïõ"
-#, fuzzy
-#~ msgid "raster3d, voxel, statistics"
-#, fuzzy
-#~ msgid "Exports a GRASS raster map to a binary array."
-#~ msgstr "ÅîáãùãÞ ôïõ GRASS 3Ä ñÜóôåñ ÷Üñôç óå 3 äéÜóôáôï Vis5D áñ÷åßï"
-#, fuzzy
-#~ msgid "raster, hydrology"
-#, fuzzy
-#~ msgid "raster, export, png"
-#, fuzzy
-#~ msgid "raster, sun energy"
-#, fuzzy
-#~ msgid "Name of the longitude input raster map [decimal degrees]"
-#, fuzzy
-#~ msgid "Import a binary raster file into a GRASS raster map."
-#, fuzzy
-#~ msgid "raster, rescale"
-#, fuzzy
-#~ msgid "raster, export, color table"
-#, fuzzy
-#~ msgid "raster, map management"
-#, fuzzy
-#~ msgid "raster, geometry"
-#, fuzzy
-#~ msgid "raster, quantization"
-#, fuzzy
-#~ msgid "raster, random"
-#, fuzzy
-#~ msgid "raster, viewshed"
-#, fuzzy
-#~ msgid "raster, fire"
-#, fuzzy
-#~ msgid "raster, profile"
-#, fuzzy
-#~ msgid "raster, sun position"
-#, fuzzy
-#~ msgid "raster, random, surface"
-#, fuzzy
-#~ msgid "raster, thin"
-#, fuzzy
-#~ msgid "raster, metadata, timestamp"
-#, fuzzy
-#~ msgid "raster, conversion, vectorization"
-#, fuzzy
-#~ msgid "raster, category"
-#, fuzzy
-#~ msgid "raster, recode category"
-#, fuzzy
-#~ msgid "raster, volume"
-#, fuzzy
-#~ msgid "raster, distance"
-#, fuzzy
-#~ msgid "raster, querying"
-#, fuzzy
-#~ msgid "display, raster, profile"
-#, fuzzy
-#~ msgid "display, distance"
-#, fuzzy
-#~ msgid "display, raster, RGB"
-#, fuzzy
-#~ msgid "display, geometry"
-#, fuzzy
-#~ msgid "display, color transformation"
-#, fuzzy
-#~ msgid "display, histogram, statistics"
-#, fuzzy
-#~ msgid "display, zoom"
-#, fuzzy
-#~ msgid "vector, raster, resample"
-#, fuzzy
-#~ msgid "vector, network, allocation"
-#, fuzzy
-#~ msgid "vector, networking, maintenance"
-#, fuzzy
-#~ msgid "vector, network, salesman"
-#, fuzzy
-#~ msgid "vector, geometry, statistics"
-#, fuzzy
-#~ msgid "vector, network, shortest path"
-#, fuzzy
-#~ msgid "Exporting %i geometries..."
-#, fuzzy
-#~ msgid "vector, projection, transformation"
-#, fuzzy
-#~ msgid "vector, network, articulation points"
-#, fuzzy
-#~ msgid "vector, spatial query"
-#, fuzzy
-#~ msgid "vector, geometry, triangulation"
-#, fuzzy
-#~ msgid "vector, network, steiner tree"
-#, fuzzy
-#~ msgid "Type: %s"
-#~ msgstr "Ôýðïò"
-#, fuzzy
-#~ msgid "vector, network, flow"
-#, fuzzy
-#~ msgid "Unparsable longitude value: [%s]"
-#, fuzzy
-#~ msgid "Unparsable latitude value: [%s]"
-#, fuzzy
-#~ msgid "vector, external, import"
-#, fuzzy
-#~ msgid "vector, geometry, buffer"
-#, fuzzy
-#~ msgid "vector, network, centrality measures"
-#, fuzzy
-#~ msgid "vector, network, spanning tree"
-#, fuzzy
-#~ msgid "database, attribute table, connection settings"
-#~ msgid "Name for output file (do NOT add extension)"
-#~ msgstr "¼íïìá áñ÷åßïõ åîáãùãÞò (ÌÇÍ ðñïóèÝóåôå åðÝêôáóç áñ÷åßïõ)"
-#, fuzzy
-#~ msgid "raster, tiling"
-#, fuzzy
-#~ msgid "raster, imagery, mosaicking"
-#, fuzzy
-#~ msgid "vector, import, GPS"
-#, fuzzy
-#~ msgid "calculates univariate statistics from a GRASS raster map"
-#, fuzzy
-#~ msgid "imagery, edges"
-#, fuzzy
-#~ msgid "imagery, statistics"
-#, fuzzy
-#~ msgid "Calculating camera angle to local surface..."
-#, fuzzy
-#~ msgid "Could not open elevation raster"
-#, fuzzy
-#~ msgid "Could not read REF file for group <%s>"
-#, fuzzy
-#~ msgid "Error reading segment file"
-#, fuzzy
-#~ msgid ""
-#~ "Control Z Point file for group [%s] in [%s] \n"
-#~ " \n"
-#, fuzzy
-#~ msgid ""
-#~ "Reference Point file for group [%s] in [%s] \n"
-#~ " \n"
-#, fuzzy
-#~ msgid "Target location <%s> not found\n"
-#, fuzzy
-#~ msgid "Could not read REF file for group [%s]"
-#, fuzzy
-#~ msgid "Enter a name for the camera angle map:"
-#~ msgstr "¼íïìá ÷Üñôç ñÜóôåñ ãùíßáò"
-#, fuzzy
-#~ msgid "Map name <%s> is illegal"
-#, fuzzy
-#~ msgid "Input raster map being fft"
-#, fuzzy
-#~ msgid ""
-#~ "Calculate the groundwater distance velocity vector field \n"
-#~ "and write the x, y, and z components to maps named name_[xyz].\n"
-#~ "Name is basename for the new 3D raster maps."
-#, fuzzy
-#~ msgid "Converts a 3D raster map layer into an ASCII text file."
-#~ msgid "Unable to get elevation raster row"
-#, fuzzy
-#~ msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map."
-#~ msgstr "Äçìéïõñãåß ôïìÞ 2Ä ñÜóôåñ ÷Üñôç áðü 3Ä ñÜóôåñ ÷Üñôç âáóéóìÝíï óôïí 2Ä ÷Üñôç õøïìÝôñùí"
-#~ msgid "Unable to create raster map"
-#, fuzzy
-#~ msgid "Wrong 3D raster map datatype! Unable to create raster map."
-#~ msgstr "ËÜèïò G3D ôýðïò! Äåí ìðïñåß íá äçìéïõñãçèåß ñÜóôåñ ÷Üñôçò."
-#, fuzzy
-#~ msgid "Unable to close input raster map"
-#~ msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ ÷Üñôç åéóáãùãÞò"
-#, fuzzy
-#~ msgid "Unable to read top raster row \n"
-#, fuzzy
-#~ msgid "Unable to read bottom raster row \n"
-#, fuzzy
-#~ msgid "Unable to close top raster map"
-#, fuzzy
-#~ msgid "Unable to close bottom raster map"
-#, fuzzy
-#~ msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
-#~ msgstr "ÌåôáôñïðÞ åíüò 3Ä ASCII ñÜóôåñ áñ÷åßïõ óå (binary) 3Ä ñÜóôåñ åðßðåäï"
-#, fuzzy
-#, fuzzy
-#~ msgid "Horizon file no. %d <%s> not found"
-#, fuzzy
-#~ msgid "Name of input raster map with real depressions"
-#, fuzzy
-#~ msgid "Name of input raster map blocking overland surface flow"
-#~ msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç (blue)"
-#, fuzzy
-#~ msgid "Exports the color table associated with a raster map layer."
-#, fuzzy
-#~ msgid "Direction raster found <%s>"
-#, fuzzy
-#~ msgid "Name for output direction map for depressionless elevation raster map"
-#, fuzzy
-#~ msgid "raster, export, animation"
-#, fuzzy
-#~ msgid "Unable to read range of raster map <%s>"
-#, fuzzy
-#~ msgid "raster, color transformation"
-#, fuzzy
-#~ msgid "Name for output elevation raster map after filling"
-#, fuzzy
-#~ msgid "Name for output direction raster map"
-#, fuzzy
-#~ msgid "Unable to remove color table of raster map <%s>"
-#, fuzzy
-#~ msgid "Color table of raster map <%s> not found"
-#~ msgstr "Ï 3Ä ñÜóôåñ ÷Üñôçò <%s> äåí âñÝèçêå"
-#, fuzzy
-#~ msgid "Color table for raster map <%s> set to '%s'"
-#~ msgstr "×ñþìá"
-#, fuzzy
-#~ msgid "raster, projection, transformation"
-#, fuzzy
-#~ msgid "Unable to load 3D raster range"
-#, fuzzy
-#~ msgid "Reading input data..."
-#, fuzzy
-#~ msgid "Writing output data..."
-#, fuzzy
-#, fuzzy
-#~ msgid "raster, transect"
-#, fuzzy
-#~ msgid "Name of base raster map"
-#, fuzzy
-#~ msgid "raster, reclassification"
-#, fuzzy
-#~ msgid "Name of input raster map with seed (at least 1 cell > 0)"
-#~ msgid "Use G3D mask (if exists) with input map"
-#~ msgstr "×ñçóéìïðïéÞóôå G3D mask (áí õðÜñ÷åé) ìå åéóáãþìåíï ÷Üñôç"
-#, fuzzy
-#~ msgid "Name for flowpath length raster map"
-#, fuzzy
-#~ msgid "imagery, landsat, acca"
-#, fuzzy
-#~ msgid "Cannot write to raster map <%s>"
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#~ msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç (saturation)"
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#~ msgid "Name of the surface reflectance QC layer [bit array]"
-#, fuzzy
-#~ msgid "Computing means..."
-#, fuzzy
-#~ msgid "Type of color table (for use with -z flag)"
-#~ msgstr "Ôýðïò"
-#, fuzzy
-#~ msgstr "×ñþìá."
-#, fuzzy
-#~ msgstr "×ñþìá."
-#, fuzzy
-#, fuzzy
-#~ msgid "display, menu"
-#~ msgid "Field separator"
-#~ msgstr "Äéá÷ùñéóôÞò ðåäßùí"
-#, fuzzy
-#~ msgid "vector, network, isolines"
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#~ msgid "Unable select categories from table <%s>"
-#, fuzzy
-#~ msgstr "Äåí ìðïñþ íá áíïßîù ôçí âÜóç äåäïìÝíùí %s"
-#, fuzzy
-#, fuzzy
-#~ msgid "Cannot describe table"
-#~ msgstr "Áäõíáìßá ðåñéãñáöÞò ðßíáêá <%s>"
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#~ msgid "Form"
-#~ msgstr "Äéáìüñöùóç"
-#, fuzzy
-#~ msgstr "Ôõðþíåé ôïí ðßíáêá êáé êëåéíåé (Ýîïäïò)"
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#~ msgstr "Äåí Ý÷åé êáèïñéóôåß ç óýíäåóç ìå ôç âÜóç äåäïìÝíùí ãéá ôï åðßðåäï (layer) %d"
-#, fuzzy
-#~ msgstr "×ñþìá"
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#~ msgstr "Áäõíáìßá áíïßãìáôïò êÝñóïñá '%s'"
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#~ msgid "Selecting areas..."
-#, fuzzy
-#~ msgstr "¼íïìá ôïõ áñ÷åßïõ ðïõ ðåñéÝ÷åé õðïãñáöÝò (signatures)"
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#~ msgstr "¶ãíùóôïò ôýðïò"
-#, fuzzy
-#~ msgid "Cannot allocate %u bytes of memory"
-#~ msgid "DBMI-MySQL driver error:\n"
-#~ msgstr "DBMI-MySQL óöÜëìá ïäçãïý:\n"
-#~ msgstr "Áäõíáìßá ðåñÜóìáôïò' MySQL ïíüìáôïò âÜóçò"
-#~ msgstr "Äåí åéíáé äõíáôÞ ç óýíäåóç ìå ôïí åíóùìáôùìÝíï MySQL åîõðçñåôçôÞ"
-#~ msgstr "Áäõíáìßá óêáíáñßóìáôïò timestamp: "
-#~ msgstr "Áäõíáìßá óêáíáñßóìáôïò çìåñïìçíßáò-÷ñüíïõ: "
-#~ msgstr "¶ãíùóôç åðéëïãÞ óôïí ïñéóìüò ôçò âÜóçò äåäïìÝíùí ãéá "
-#~ msgstr "Äåí ìðïñåß íá áíáãíùñéóôÞ ç ôéìÞ boolean"
-#~ msgstr "pg driver: PostGIS óôÞëç '%s', ôýðïò 'geometry' äåí èá ìåôáôñáðåß"
-#~ msgstr "Áöáéñåß Ýíá ðßíáêá áðü ôçí âÜóç äåäïìÝíùí"
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#~ msgid "Name of PNG file"
-#~ msgstr "¼íïìá áñ÷åßïõ åîáãùãÞò EPS"
-#, fuzzy
-#~ msgid "Skip the join column in other table"
-#, fuzzy
-#~ msgid "Copy all the columns from other table to map"
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#~ msgid "Name of raster plane to be created"
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#~ msgid "Output raster map (default: input tile)"
-#~ msgstr "¼íïìá ÷Üñôç "
-#, fuzzy
-#~ msgid "Name of vector map for which to edit attribute table"
-#, fuzzy
-#~ msgid "Column to update"
-#, fuzzy
-#~ msgid "GRASS table name"
-#~ msgstr "ÅîáãùãÞ ïíüìáôïò ðßíáêá"
-#~ msgid "vector, color table"
-#, fuzzy
-#~ msgid "Name of color column to populate"
-#, fuzzy
-#~ msgid "raster, elevation, interpolation"
-#, fuzzy
-#~ msgid "Name of input raster map in which to fill nulls"
-#, fuzzy
-#~ msgid "Name for output raster map with nulls filled by interpolation"
-#~ msgstr "¼íïìá åîáãüìåíïõ ñÜóôåñ ÷Üñôç (saturation)"
-#, fuzzy
-#, fuzzy
-#~ msgid "Vector map to be queried"
-#, fuzzy
-#~ msgstr "×ñþìá"
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#~ msgstr "¼íïìá ôïõ äåýôåñïõ ñÜóôåñ ÷Üñôç ãéá blending"
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#~ msgid "writing edges..."
-#, fuzzy
-#~ msgid "raster, png"
-#, fuzzy
-#~ msgid "Unhandled vector feature type <%s>"
-#, fuzzy
-#~ msgid "GDAL datatype: %s, range: %f - %f"
-#, fuzzy
-#~ msgid "Unable to create table <%s_edge_Interpolation>"
-#, fuzzy
-#~ msgid "Rescale output raster map [0,255]"
-#, fuzzy
-#~ msgstr "¼íïìá ñÜóôåñ ÷Üñôç õøïìÝôñïõ"
-#, fuzzy
-#~ msgid "Unable to open rules file <%s>"
-#, fuzzy
-#, fuzzy
-#~ msgstr "Äåí ãßíåôáé íá êëåßóåé ï G3Ä ÷Üñôçò"
-#~ msgstr "×ñçóéìïðïéÞóôå g3d ìÜóêá (áí õðÜñ÷åé) ìå ôïí ÷Üñôç"
-#~ msgstr "Äåí ìðïñåß íá êëåßóåé ï G3D ÷Üñôçò <%s>"
-#~ msgstr "×ñçóéìïðïéÞóôå G3D ìÜóêá (åÜí õðÜñ÷åé)"
-#, fuzzy
-#~ msgid "Unable to calculate centroid for area %d"
-#, fuzzy
-#, fuzzy
-#~ msgid "File [%s] not found"
-#, fuzzy
-#~ msgid "Reading data from the map..."
-#, fuzzy
-#, fuzzy
-#~ msgid ""
-#~ "\t(%s)\n"
-#~ msgstr ""
-#~ "\n"
-#~ "    (%s).\n"
-#, fuzzy
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ " group <%s> not found"
Modified: grass/trunk/locale/po/grassmods_es.po
--- grass/trunk/locale/po/grassmods_es.po	2012-05-26 15:22:06 UTC (rev 51802)
+++ grass/trunk/locale/po/grassmods_es.po	2012-05-26 15:46:05 UTC (rev 51803)
@@ -33833,8622 +33833,3 @@
 msgstr "Porcentaje para aumentar el brilloConvergencia porcentual"
-#, fuzzy
-msgstr "Mapa(s) de entrada no especificado(s)."
-#, fuzzy
-msgid "Raster map <%s> is not valid"
-msgstr "Mapa ráster <%s> no encontrado"
-#, fuzzy
-msgid "If not given read from standard input"
-msgstr "Si no se da lee de la entrada estándar"
-#, fuzzy
-msgid "Print basic info in shell script style"
-msgstr "Imprimir información en el estilo de script de la consola de comandos de UNIX"
-#, fuzzy
-msgid "Projection:"
-msgstr "Proyectando..."
-#, fuzzy
-msgstr "Error del controlador DBMI-MySQL:\n"
-#, fuzzy
-msgid "relative"
-msgstr "Crear"
-msgid "Raster map for which to edit null file"
-msgstr "Mapa ráster para el que editar archivo nulo"
-#, fuzzy
-msgid "Display the HTML man pages of GRASS GIS"
-msgstr "Mostrar las páginas man HTML de GRASS"
-#, fuzzy
-msgid "Join column in table"
-msgstr "Columna a unir en la tabla del mapa"
-#, fuzzy
-msgid "Path to resulting ASCII file ('-' for standard output) or ASCII vector name if '-o' is defined"
-msgstr "Ruta al archivo ASCII resultante o nombre del vectorial ASCII si se define '-o'"
-#, fuzzy
-msgstr "No se puede leer %s"
-#, fuzzy
-msgstr "El controlador <%s> no soporta la creación de rásters"
-#, fuzzy
-msgstr "No se puede leer el archivo 3Dview <%s> en <%s>"
-#, fuzzy
-msgid "Name of raster map from which to copy color table"
-msgstr "Nombre del mapa ráster del que copiar la tabla de colores"
-#, fuzzy
-msgstr "Nombre del archivo que contiene sentencias SQL"
-#, fuzzy
-msgstr "Creando archivos de soporte para %s..."
-#, fuzzy
-msgstr "Título para el nuevo mapa ráster"
-#, fuzzy
-msgstr "No se puede leer el archivo de intervalo"
-#, fuzzy
-msgid "\raster\" and \"volume\" options are mutually exclusive"
-msgstr "Las opciones \"color\", \"rules\" y \"raster\" son excluyentes entre si"
-#, fuzzy
-msgid "Calculating measure #%d <%s> (56 measures available)"
-msgstr "Medida #%d calculada <%s>  (56 medidas disponibles)"
-#, fuzzy
-msgstr "Exporta la tabla de color asociada con la capa de un mapa raster."
-msgstr "No se pudo cerrar el mapa RASTER3D"
-msgstr "No se pudo cerrar el mapa RASTER3D <%s>"
-msgstr "Nombre del archivo V5D de salida"
-#, fuzzy
-msgstr "Exportar un mapa ráster 3D GRASS a archivo tridimensional Vis5D."
-#, fuzzy
-msgid "Lists available GIS elements of the user-specified data type."
-msgstr "Lista archivos de base de datos de GRASS del tipo de datos especificado por el usuario para una salida estándar."
-#, fuzzy
-msgid "Remove dangles:"
-msgstr "Eliminar balanceos"
-#, fuzzy
-msgid "Unable to create 3D vector and attribute table at same time"
-msgstr "No se pueden copuar elementos del mapa vectorial <%s>"
-#, fuzzy
-msgstr "Precisión de coordenadas"
-#, fuzzy
-msgid "maps for mosaic."
-msgstr "Segundo mapa para mosaico."
-#, fuzzy
-msgid "Data source for OGR access"
-msgstr "El origen de datos contiene %d capas:"
-#, fuzzy
-msgid "Vector map for which to drop vector objects"
-msgstr "Mapa vectorial del que eliminar una columna de atributos"
-#, fuzzy
-msgid "Layer of attribute table to use for selection"
-msgstr "Nombre de columna de atributos a usar para etiquetas"
-#, fuzzy
-msgid "WHERE conditions for vector delete, without 'where' keyword (e.g. \"elevation IS NULL\")"
-msgstr "Condiciones WHERE para actualizar, sin palabra clave 'where' (ej.: cat=1 o col1/col2>1)"
-#, fuzzy
-msgid "Overwrite existing file"
-msgstr "Sobrescribir MÁSCARA existente"
-#, fuzzy
-msgstr "Nombre del mapa de polígono vectorial"
-#, fuzzy
-msgid "Name of MODIS product"
-msgstr "Nombre de una capa de entrada"
-#, fuzzy
-msgid "The names of tile/s to download"
-msgstr "El número de puntos a situar"
-#, fuzzy
-msgstr "ráster, importar, conversión"
-#, fuzzy
-msgstr "ráster, exportar"
-#, fuzzy
-msgid "Name of input elevation map"
-msgstr "Nombre de mapa ráster de entrada de elevación"
-#, fuzzy
-msgstr "Nombre para el mapa ráster de salida"
-#, fuzzy
-msgid "Existing SPOT VGT NDVI HDF file (0001_NDV.HDF)"
-msgstr "archivo SPOT VGT NDVI HDF existente (0001_NDV.HDF)"
-#, fuzzy
-msgid "zenith"
-msgstr "Longitud: %f\n"
-#, fuzzy
-msgid "topographic correction method"
-msgstr "Producir mapa ráster de dirección"
-#, fuzzy
-msgid "Elevation file of unknown type"
-msgstr "Coordenada de elevación de un punto en el plano"
-#, fuzzy
-msgid "Cannot allocate memory for auxiliar matrix.Consider changing region (resolution)"
-msgstr "No se puede asignar memoria para la cadena"
-#, fuzzy
-msgid "resampling"
-msgstr "Método de muestreo"
-#, fuzzy
-msgid "map algebra"
-msgstr "ráster, álgebra de mapas"
-#, fuzzy
-msgstr "Leyendo archivo [%s]..."
-#, fuzzy
-msgid "Mapset to list (default: current search path"
-msgstr "Directorio de mapas a listar (predeterminado: ruta de búsqueda actual)"
-#, fuzzy
-msgstr "Nombre del origen de datos OGR"
-#, fuzzy
-msgid "Data source"
-msgstr "Esquema de la base de datos"
-#, fuzzy
-msgstr "Nombre de la tabla de GRASS"
-#, fuzzy
-msgstr "Nombre de mapa vectorial"
-#, fuzzy
-msgid "List available OGR layers in dsn and exit"
-msgstr "Listar las capas disponibles y salir"
-#, fuzzy
-msgid "Buffering features..."
-msgstr "Elevando áreas..."
-#, fuzzy
-msgid "connection"
-msgstr "Correlación"
-#, fuzzy
-msgid "Imports Mapgen or Matlab vector maps into GRASS."
-msgstr "Importar mapas vectoriales Mapgen o Matlab a GRASS."
-#, fuzzy
-msgid "integration"
-#, fuzzy
-msgstr "Parámetros de clúster\n"
-#, fuzzy
-msgstr "Resolución"
-#, fuzzy
-msgstr "Archivo de coordenadas de entrada (omitir para leer de stdin)"
-#, fuzzy
-msgstr "%s: No se pudo leer tabla de colores para <%s@%s>"
-#, fuzzy
-msgid "File containing recode rules; \"-\" to read from stdin"
-msgstr "Archivo que contiene reglas de etiquetas de categorías (o \"-\" para leer de stdin)"
-#, fuzzy
-msgstr "Consulta colores de una capa da mapa ráster."
-#, fuzzy
-msgid "Displays vector map layer in the active map display window."
-msgstr "Muestra datos vectoriales de GRASS en el marco activo de la pantalla."
-#, fuzzy
-msgstr "Archivo %s creado"
-#, fuzzy
-msgstr "Controladores OGR disponibles:"
-#, fuzzy
-msgid "List available modules in the add-ons repository"
-msgstr "Listar reglas disponibles y salir"
-#, fuzzy
-msgid "Calculates univariate statistics from a GRASS raster map based on vector polygons and uploads statistics to new attribute columns."
-msgstr "Calcular estadísticas univariantes a partir de un mapa ráster de GRASS basadas en polígonos vectoriales y carga las estadísticas en nuevas columnas de atributos."
-#, fuzzy
-msgid "Displays raster map layer in the active map display window."
-msgstr "Muestra y superpone las capas del mapa ráster en el marco activo de la pantalla."
-#, fuzzy
-msgstr "Mapa ráster a importar"
-#, fuzzy
-msgid "File containing reclass rules; \"-\" to read from stdin"
-#, fuzzy
-msgid "terrain analysis"
-msgstr "ráster, análisis de estructura del paisaje"
-#, fuzzy
-msgid "Open vector map without topology (level 1)"
-msgstr "No se puede abrir el mapa vectorial <%s> en el nivel topológico %d"
-#, fuzzy
-msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
-msgstr "mi(llas),f(pies),me(tros),k(ilómetros),a(cres),h(ectáreas),p(orcentaje)"
-#, fuzzy
-msgid "Print bounds and exit (shell style)"
-msgstr "Imprimir resultados en estilo de script de consola"
-#, fuzzy
-msgid "Estimate spline step value"
-msgstr "Estadística a utilizar para los valores ráster"
-#, fuzzy
-msgid "<%s> table created in database."
-msgstr "<%s> creado en la base de datos."
-#, fuzzy
-msgid ""
-msgstr "Calcula vectorial a nombre nombre."
-#, fuzzy
-msgid "report"
-msgstr "Informe amplio"
-#, fuzzy
-msgstr "No se puede obtener la cabecera de %s"
-#, fuzzy
-msgid "Unable to open cellfile for <%s>"
-msgstr "No se puede abrir el archivo <%s>"
-#, fuzzy
-msgstr "Error al leer el mapa ráster [%s]."
-#, fuzzy
-#, fuzzy
-msgstr "No se puede abrir el mapa ráster <%s> en <%s>"
-#, fuzzy
-msgstr "No se puede leer la región <%s> en <%s>"
-#, fuzzy
-msgstr "No se puede abrir el mapa ráster <%s>"
-#, fuzzy
-msgstr "No se puede abrir el mapa vectorial <%s>"
-#, fuzzy
-msgstr "No se puede abrir el archivo de salida <%s>"
-#, fuzzy
-#, fuzzy
-msgstr "No se puede obtener la fila %d (error = %d)"
-#, fuzzy
-msgid "Cannot set region to output region"
-msgstr "¡No se puede establecer la región para volver a la región inicial!"
-#, fuzzy
-msgid "Cannot set region to back to the initial region"
-#, fuzzy
-msgstr "No se puede leer la fila %i\n"
-#, fuzzy
-msgid "Unable to read region <%s>"
-msgstr "No se puede establacer la región <%s>"
-#, fuzzy
-msgstr "no se puede abrir nueva capa de mapa de acumulación."
-#, fuzzy
-msgid "SECTION 4: Extracting Streams."
-msgstr "Extrayendo áreas..."
-#, fuzzy
-msgid "Error reading row <%d>"
-msgstr "Error al escribir la fila nula [%d]."
-#, fuzzy
-msgid "Name of input raster map containing starting points"
-msgstr "Nombre del mapa ráster de entrada que contiene costes de fricción"
-#, fuzzy
-msgstr "No se puede abrir el archivo de entrada <%s>"
-#, fuzzy
-msgid "Error reading row %d"
-#, fuzzy
-msgstr "No se puede leer en el mapa ráster <%s> la fila %d"
-#, fuzzy
-msgstr "No se puede leer la cabecera del mapa ráster <%s>"
-#, fuzzy
-msgstr "No se pueden escribir los mapas ráster"
-#, fuzzy
-msgid "Cannot open cell file [%s]"
-msgstr "No se puede abrir el archivo de reglas <%s>"
-#, fuzzy
-msgstr "No se puede leer la cabecera del archivo <%s>"
-#, fuzzy
-msgstr "No se pudo abrir el mapa %s"
-#, fuzzy
-msgid "Cannot write to output raster file"
-msgstr "Nombre para el archivo ráster de salida"
-#, fuzzy
-#, fuzzy
-#, fuzzy
-msgid "qcname"
-msgstr "nombre"
-#, fuzzy
-msgid "Name of QC"
-msgstr "Nombre del archivo PNG"
-#, fuzzy
-msgid "250m band number is out of allowed range [1,2]"
-msgstr "Número de borde fuera de rango"
-#, fuzzy
-msgid "Cannot read file header of [%s]"
-#, fuzzy
-msgid "Converts a binary GRASS vector map layer into a GRASS raster map layer."
-msgstr "Convierte un mapa vectorial binario de GRASS en una capa de mapa ráster de GRASS."
-#, fuzzy
-msgid "%d points written to vector map"
-msgstr "%d puntos escritos en mapa vectorial"
-#, fuzzy
-msgid "Traces a flow through an elevation model on a raster map layer."
-msgstr "Traza un flujo mediante un modelo de elevación sobre una capa de mapa ráster."
-#, fuzzy
-msgid "The E and N coordinates of starting point(s)"
-msgstr "Coordenadas de cuadrícula E y N de mapa de los puntos iniciales"
-#, fuzzy
-msgid "Vector map(s) containing starting point(s)"
-msgstr "Mapa(s) vectorial que contiene el punto(s) de inicio"
-#, fuzzy
-msgid "raster, rainfall, erosion, USLE"
-msgstr "ráster, elevación, interpolación"
-#, fuzzy
-msgid "Outputs a raster map layer showing the cumulative cost of moving between different geographic locations on an input raster map layer whose cell category values represent cost."
-msgstr "Produce una capa de mapa ráster que muestre el coste acumulado de moverse entre diferentes localizaciones geográficas en una capa de mapa ráster de entrada cuyos valores de categoría de celdas representan coste."
-#, fuzzy
-msgid "Bad Start Cell"
-msgstr "Celda de inicio incorrecta"
-#, fuzzy
-msgid "SECTION 3: Accumulating Surface Flow with MFD"
-msgstr "SECCIÓN 3: acumulando flujo de superficie."
-#, fuzzy
-msgid "raster, soil, erosion, USLE"
-msgstr "ráster, volumen, conversión"
-#, fuzzy
-msgstr "%s: %s - No fue posible encontrar el mapa de imagen real."
-#, fuzzy
-msgid ""
-"Unable to open real-image in the cell_misc directory.\n"
-"Input map probably wasn't created by i.fft"
-msgstr ""
-"No fue posible abrir el mapa de imagen real en el directorio cell_misc \n"
-"El mapa de entrada posiblemente no fue creado por ifft"
-#, fuzzy
-msgstr "%s: %s - No se pudo encontrar la imagen imaginaria."
-#, fuzzy
-msgid ""
-"Unable to open imaginary-image in the cell_misc directory.\n"
-msgstr ""
-"No fue posible abrir el mapa de imagen imaginaria en el directorio cell_misc \n"
-#, fuzzy
-msgid "Range less than or equal to zero not allowed."
-msgstr "Rango menor o igual a cero no permitido."
-#, fuzzy
-msgstr "Escribiendo versiones visibles de los datos transformados a archivos..."
-#, fuzzy
-msgid "Unable to open file in the cell_misc directory."
-msgstr "No se puede abrir el archivo en el directorio cell_misc."
-#, fuzzy
-msgid "Name of image to be rectified which will  be initially drawn on screen."
-msgstr "El nombre de la imagen para rectificar que se dibujará inicialmente en pantalla."
-#, fuzzy
-msgid "Name of a map from target mapset which  will be initially drawn on screen."
-msgstr "Nombre de un mapa del conjunto de mapas de destino que se dibujará inicialmente en pantalla"
-#, fuzzy
-msgid "raster, imagery, fusion"
-msgstr "ráster, imaginería, importar"
-#, fuzzy
-msgid "Can't make random color table for floating point map"
-msgstr "No se puede hacer tabla de colores logarítmica para mapas de coma flotante"
-#, fuzzy
-msgid "Can't make grey.eq color table for floating point map"
-#, fuzzy
-msgid "%s - unknown color request"
-msgstr "%s - solicitud de color desconocido"
-#, fuzzy
-msgid "Processing ainput areas ..."
-msgstr "Procesando líneas de la entrada A..."
-#, fuzzy
-msgid "Elevation raster map <%s> does not cover the entire area of the input vector map <%s>. "
-msgstr "%d categorías con más de un elemento en el mapa vectorial <%s>"
-#, fuzzy
-msgid "name for new map image (lives in ~/.gpsdrive)"
-msgstr "nombre para el nuevo mapa de imagen (reside en ~/.gpsdrive)"
-#, fuzzy
-msgid "Displays thematic vectormap"
-msgstr "Visualizar mapa vectorial temático"
-#, fuzzy
-msgid "Terrain raster map (DEM)"
-msgstr "Mapa ráster de terreno (MDT)"
-#, fuzzy
-msgid "imagery group"
-msgstr "Grupo de imaginería"
-msgid "Output aspect filename"
-msgstr "Nombre de archivo de orientación de salida"
-msgid "raster, projection"
-msgstr "ráster, proyección"
-msgstr "No se puede crear el archivo de firma [%s] para el subgrupo [%s] en el grupo [%s]."
-msgid "defaulting to nearest neighbor sampling"
-msgstr "haciendo predeterminado el muestreo por el vecino más próximo"
-msgid "Import as Floating Point Data (default: Integer)"
-msgstr "Importar como datos de coma flotante (por omisión: entero)"
-msgid "Import as Double Precision Data (default: Integer)"
-msgstr "Importar como datos de precisión doble (por omisión; entero)"
-#, fuzzy
-msgid "Bad number of bytes per cell"
-msgstr "        Número de bytes por celda"
-msgid "Bytes do not match File size"
-msgstr "Los bytes no corresponden al tamaño de archivo"
-msgid "Total area: %e (%d areas)"
-msgstr "Áreas total: %e (%d áreas)"
-msgid "Overlapping area: %e (%d areas)"
-msgstr "Área solapada: %e (%d áreas)"
-msgid "Area without category: %e (%d areas)"
-msgstr "Área sin categoría: %e (%d áreas)"
-#, fuzzy
-msgid "Converts a binary GRASS vector map into a GRASS raster map ."
-msgid "Duplicate area centroids: %5d"
-msgstr "Centroides de área duplicados: %5d"
-#, fuzzy
-msgid "Bad format in initial exposusre station file for group <%s>"
-msgstr "¿Editar el archivo de categorías para [%s]?"
-msgid "Converts 3D raster maps (RASTER3D) into the VTK-Ascii format"
-msgstr "Convierte mapas ráster 3D (RASTER3D) en formato VTK-ASCII"
-msgid "unable to close top raster map"
-msgstr "No se puede cerrar el mapa ráster superior"
-msgid "unable to close bottom raster map"
-msgstr "No se puede cerrar el mapa ráster inferior"
-msgstr "Mapa ráster de salida de saturación"
-msgid ""
-"Cannot create mask file: RASTER3D_MASK already exists!\n"
-" Use 'g.remove rast3d=RASTER3D_MASK' to remove the existing mask."
-msgstr ""
-"No se puede crear archivo de máscara: ¡RASTER3D_MASK ya existe!\n"
-" Usa 'g.remove rast3d=RASTER3D_MASK' para eliminar la máscara existente."
-msgstr "Convierte una capa de mapa ráster 3D en un archivo de texto ASCII"
-msgstr "Convertir un archivo de texto ráster ASCII 3D en una capa de mapa ráster 3D (binaria)"
-msgid "also import quality map (SM status map layer) and filter NDVI map"
-msgstr "importar también mapa de calidad (capa de mapa de estado SM) y filtrar mapa NDVI"
-#~ msgid "Input grid3 filename"
-#~ msgstr "Nombre de archivo grid3 de entrada"
-#~ msgid "Grid3 <%s> not found %s"
-#~ msgstr "Grid3 <%s> no encontrado %s"
-#~ msgid "Failed to guess site file format"
-#~ msgstr "No se pudo averiguar el formato de archivo de lugares"
-#~ msgid "Print raster map resolution (NS-res, EW-res) only"
-#~ msgstr "Imprimir sólo resolución de mapa ráster (resolución-NS, resolución-EW)"
-#~ msgid "Print raster map type only"
-#~ msgstr "Imprimir sólo el tipo de mapa ráster"
-#~ msgid "Print map region only"
-#~ msgstr "Imprimir sólo la región del mapa"
-#~ msgid "Print raster map data units only"
-#~ msgstr "Imprimir sólo unidades de datos del mapa ráster"
-#~ msgid "Print raster map vertical datum only"
-#~ msgstr "Imprimir sólo datum vertical del mapa ráster"
-#~ msgid "Print map title only"
-#~ msgstr "Imprimir sólo el título del mapa"
-#~ msgid "Print raster map timestamp (day.month.year hour:minute:seconds) only"
-#~ msgstr "Imprimir sólo la marca de tiempo del mapa ráster (día.mes.año hora:minutos:segundos)"
-#~ msgstr "Nombre para el mapa raster de valores de salida"
-#~ msgid "Invalid timestamp"
-#~ msgstr "Marca de tiempo no válida"
-#~ msgstr "Leyendo sites..."
-#~ msgstr "Escribiendo site en la salida..."
-#~ msgid "Reading coordinates from file."
-#~ msgstr "Leyendo coordenadas del archivo."
-#~ msgid "ASCII file holding transform coordinates"
-#~ msgstr "Archivo ASCII que mantiene coordenadas de transformación"
-#~ msgid "If not given, transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot) are used instead"
-#~ msgstr "Si no se indican, los parámetros de transformación (xshift, yshift, zshift, xscale, yscale, zscale, zrot) se usan en su lugar"
-#~ msgid "Unable to open file with coordinates <%s>"
-#~ msgstr "No se puede abrir el archivo con coordenadas <%s>"
-#~ msgid "Error reading coordinates file"
-#~ msgstr "Error leyendo archivo de coordenadas"
-#~ msgid "Number of points that have been entered [%d]"
-#~ msgstr "Número de puntos que se han introducido [%d]"
-#~ msgid "Error creating transformation"
-#~ msgstr "Error creando transformación"
-#~ msgid "The points weren't spread out enough."
-#~ msgstr "Los puntos no fueron distribuidos suficientemente."
-#~ msgid "You need to enter at least %d points."
-#~ msgstr "Necesitas introducir al menos %d puntos."
-#, fuzzy
-#~ msgid "create;Create new (empty) vector map;add;Add new features to existing vector map;delete;Delete selected features from vector map;move;Move selected features in vector map;vertexmove;Move vertex of selected vector lines;vertexdel;Remove vertex from selected vector lines;vertexadd;Add new vertex to selected vector lines;merge;Merge selected vector lines;break;Break/split vector lines;select;Select lines and print their ID's;catadd;Set new categories to selected vector features for defined layer;catdel;Delete categories from selected vector features for defined layer;copy;Copy selected features;snap;Snap vector features in given threshold;flip;Flip direction of selected vector lines;connect;Connect two lines;zbulk;Z bulk-labeling (automated assignment of z coordinate to vector lines);chtype;Change feature type (point<->centroid, line<->boundary)"
-#~ msgstr "create;Crear nuevo mapa vectorial (vacío);add;Añadir nuevo(s) elemento(s) a un mapa vectorial existente;delete;Borrar los elementos seleccionados del mapa vectorial;move;Mover los elementos seleccionados en el mapa vectorial;vertexmove;Mover vértice de líneas vectoriales seleccionadas;vertexdel;Eliminar vértices de líneas vectoriales seleccionadas;vertexadd;Añadir nuevo vértice a las líneas vectoriales seleccionadas;merge;Fundir líneas vectoriales seleccionadas;break;Romper/dividir líneas vectoriales;select;Seleccionar líneas e imprimir sus ID;catadd;Establecer nuevas categorías a los elementos vectoriales seleccionados para la capa definida;catdel;Borrar categorías de los elementos vectoriales seleccionados para la capa definida;copy;Copiar elementos seleccionados;snap;Snap elementos vectoriales en el umbral dado;flip;Flip la dirección de de las líneas vectoriales seleccionadas;connect;Conectar dos líneas;zbulk;Etiquetado Z en masa (asignación automatizada de coo
 rdenada Z a líneas vectoriales)"
-#~ msgid "Column name (will be updated by raster values)"
-#~ msgstr "Nombre de columna (se actualizará por valores ráster)"
-#~ msgstr "No se puede escanear la fecha: "
-#~ msgstr "No se puede escanear la hora: "
-#~ msgstr "No se puede asignar el cursor."
-#~ msgstr "No se puede añadir nuevo marcador."
-#~ msgstr "No se puede conectar con MySQL: "
-#~ msgstr "Error del controlador DBMI-MySQL:\n"
-#~ msgstr "Imposible seleccionar datos: \n"
-#~ msgid "Unable allocate memory for row buffer"
-#~ msgstr "No se puede asignar memoria para la fila buffer"
-#~ msgid "Computing means for band %d..."
-#~ msgstr "Calculando promedios para la banda %d..."
-#~ msgid "Computing row %d (of %d) of covariance matrix..."
-#~ msgstr "Calculando  fila %d (de %d) de la matriz de covarianza..."
-#~ msgstr "No se puede asignar memoria para la fila raster"
-#~ msgid "Transforming <%s>..."
-#~ msgstr "Transformando <%s> ..."
-#~ msgid "Surface area estimation for rasters."
-#~ msgstr "Estimación del área para rásters."
-#~ msgid "Raster file for surface"
-#~ msgstr "Archivo ráster para superficie"
-#, fuzzy
-#~ msgstr "Escribiendo el archivo de firma [%s] ..."
-#~ msgid "ASCII file to be converted to binary vector map"
-#~ msgstr "Archivo ASCII a convertir en mapa vectorial binario"
-#~ msgid "If not given (or \"-\") reads from standard input"
-#~ msgstr "Si no se indica (o \"-\") lee de la entrada estándar"
-#~ msgstr "Columna a unir en la otra tabla"
-#~ msgid "Name of arc forward/both direction(s) cost column"
-#~ msgstr "Nombre de delante del arco/ambas direcciones de la columna de coste"
-#~ msgstr "Número o nombre de capa con route paths o -1"
-#~ msgid "Layer %d - no table"
-#~ msgstr "Capa %d - sin tabla"
-#~ msgstr "Capa %d - no se puede copiar la tabla"
-#~ msgstr "Número o nombre de capa de entrada"
-#, fuzzy
-#~ msgstr "Número de capa"
-#~ msgstr "Nombre de la columna Arc cost"
-#~ msgid "Enter -1 to keep original categories or the desired NEW category value"
-#~ msgstr "Introduzca -1 para mantener las categorías originales o el NUEVO valor de categoría deseado"
-#~ msgstr "Desde número de capa o nombre"
-#~ msgstr "Hasta número de capa o nombre"
-#~ msgstr "Nombre de la columna de capacidad de nodos"
-#~ msgstr "Set 1 número de capa o nombre"
-#~ msgstr "Set2 nombre o número de capa"
-#~ msgid "Either mapset= or -l must be used"
-#~ msgstr "Se tiene que utilizar o el directorio de mapas= o -1"
-#~ msgid "Line width column (%s) is not numeric."
-#~ msgstr "La columna de anchura de línea (%s) no es numérica."
-#~ msgid "Error in color definition column '%s', feature id %d with cat %d: colorstring '%s'"
-#~ msgstr "Error en la columna '%s' de definición de color, elemento id %d con cat %d: colorstring '%s'"
-#~ msgid "Error in color definition column '%s', feature id %d with cat %d"
-#~ msgstr "Error en la columna '%s' de definición de color, elemento id %d con cat %d"
-#~ msgid "Error in symbol size column (%s), element %d with cat %d: symbol size [%f]"
-#~ msgstr "Error en la columna de tamaño de símbolo (%s), elemento %d con cat %d: tamaño de símbolo  [%f]"
-#~ msgid "Error in color definition column '%s': %d features affected"
-#~ msgstr "Error en la columna de definición del color '%s':%d elementos afectados"
-#~ msgid "Colorize polygons according to z height"
-#~ msgstr "Colorear polígonos de acuerdo con la altura z"
-#~ msgid "'layer' must be > 0 for 'where'."
-#~ msgstr "'layer' (capa) debe ser >0 para 'where' (donde)."
-#~ msgid "'layer' must be > 0 for 'cats'."
-#~ msgstr "'layer' (capa) debe ser > 0 para 'cats' (categorías)."
-#~ msgid "Can't read vector map"
-#~ msgstr "No se puede leer el mapa vectorial"
-#~ msgstr "Columna de definición de color no especificada."
-#~ msgid "Error in color definition column (%s), area %d with cat %d: colorstring [%s]"
-#~ msgstr "Error en la columna (%s) de definición de color, área %d con categoría %d: cadena de color [%s]"
-#~ msgstr "Controlador pg: columna '%s', tipo %d no soportado"
-#~ msgstr "Tipo de tabla de colores"
-#, fuzzy
-#~ msgstr "Nombre del mapa ráster a usar para <%s>"
-#~ msgid "Name and type of the new column(s) (types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
-#~ msgstr "Nombre y tipo de la nueva columna(s) (los tipos dependen de la base de datos de destino, pero todas soportan  VARCHAR(), INT, DOUBLE PRECISION y FECHA)"
-#~ msgid "Name for input source not specified"
-#~ msgstr "No se ha especificado el nombre para la fuente de entrada"
-#~ msgid "Name for output raster map not specified"
-#~ msgstr "No se ha especificado el nombre para el mapa ráster de salida"
-#~ msgstr "Mapa G3D <%s> solicitado no encontrado"
-#~ msgstr "Error al abrir el mapa G3D <%s>"
-#~ msgid "\"color\", \"rules\", and \"raster\" options are mutually exclusive"
-#~ msgstr "Las opciones \"color\", \"rules\" y \"raster\" son excluyentes entre si"
-#~ msgid "-g and -a flags are mutually exclusive"
-#~ msgstr "-g y -a flags son excluyentes mutuamente"
-#~ msgid "Negative or no data pixel found. This module is not yet able to process no data holes in a map, please fill with r.fillnulls or other algorithms"
-#~ msgstr "Se han encontrado píxeles negativos o sin datos. Este módulo aún no es capaz de procesar agujeros sin datos en un mapa. Por favor, rellene con r.fillnulls u otro algoritmo"
-#~ msgid "Too many iterations to required to find %s - giving up"
-#~ msgstr "Demasiadas iteraciones requeridas para encontrar %s - abandonando"
-#~ msgid "Angular Second Moment"
-#~ msgstr "Momento segundo angular"
-#~ msgid "Features"
-#~ msgstr "Elementos"
-#~ msgid "Contrast"
-#~ msgstr "Contraste"
-#~ msgid "Correlation"
-#~ msgstr "Correlación"
-#~ msgid "Variance"
-#~ msgstr "Varianza"
-#~ msgid "Inverse Diff Moment"
-#~ msgstr "Momento diferencial inverso"
-#~ msgid "Sum Average"
-#~ msgstr "Media de la suma"
-#~ msgid "Sum Variance"
-#~ msgstr "Varianza de la suma"
-#~ msgid "Sum Entropy"
-#~ msgstr "Entropía de la suma"
-#~ msgid "Entropy"
-#~ msgstr "Entropía"
-#~ msgid "Difference Variance"
-#~ msgstr "Varianza de la diferencia"
-#~ msgid "Difference Entropy"
-#~ msgstr "Entropía de la diferencia"
-#~ msgid "Measure of Correlation-1"
-#~ msgstr "Medida de la correlación-1"
-#~ msgid "Measure of Correlation-2"
-#~ msgstr "Medida de la correlación-2"
-#~ msgid "Max Correlation Coeff"
-#~ msgstr "Coeficiente de correlación máximo"
-#~ msgid "Raster file to be imported"
-#~ msgstr "Mapa ráster a importar"
-#~ msgid "Write the result to g3d map <%s>"
-#~ msgstr "Escribir el resultado al mapa G3D <%s>"
-#~ msgstr "No se encontró en mapa ráster 3D requerido"
-#~ msgid "Error closing new ASCII file"
-#~ msgstr "Error al cerrar el nuevo archivo ASCII"
-#~ msgstr "modifyNull: error al abrir mapa"
-#~ msgid "modifyNull: error closing map"
-#~ msgstr "modifyNull: error al cerrar mapa"
-#~ msgstr "Añadiendo regla: %If - %If"
-#~ msgid "makeMask: error opening map."
-#~ msgstr "makeMask: error al abrir mapa."
-#~ msgid "makeMask: error opening g3d mask file"
-#~ msgstr "makeMask: error al abrir archivo de máscara g3d"
-#~ msgid "makeMask: error closing g3d mask file"
-#~ msgstr "makeMask: error al cerrar archivo de máscara g3d"
-#~ msgid "makeMask: error closing map"
-#~ msgstr "makeMask: error al cerrar mapa"
-#~ msgid "Requested 3d raster map <%s> not found"
-#~ msgstr "Mapa ráster 3D <%s> solicitado no encontrado"
-#~ msgid "Requested g3d RGB map <%s> not found"
-#~ msgstr "Mapa RGB G3D <%s> solicitado no encontrado"
-#~ msgid "Requested g3d vector map <%s> not found"
-#~ msgstr "Mapa vectorial G3D <%s> solicitado no encontrado"
-#~ msgid "Open rgb 3d raster map %s"
-#~ msgstr "Abrir mapa ráster 3D RGB %s"
-#~ msgid "Error closing g3d rgb map."
-#~ msgstr "Error al cerrar mapa RGB G3D."
-#~ msgid "Error closing g3d vector map."
-#~ msgstr "Error al cerrar mapa vectorial G3D."
-#~ msgid "The 2d and 3d region settings are different. The g3d settings are used to adjust the 2d region."
-#~ msgstr "Las configuraciones de la región 2D y 3D son diferentes. Se usan las configuraciones G3D para ajustar la región 2D."
-#~ msgid "unable to close input 3d raster map"
-#~ msgstr "no se puede cerrar el mapa ráster 3D de entrada"
-#~ msgid "write_vtk_rgb_data: writing rgb data"
-#~ msgstr "write_vtk_rgb_data: escribiendo datos rgb"
-#~ msgid "write_vtk_vector_data: writing vector data"
-#~ msgstr "write_vtk_vector_data: escribiendo datos vectoriales"
-#~ msgstr "Error al cerrar el nuevo mapa ráster 3D"
-#~ msgstr "Error al cerrar archivo ASCII"
-#~ msgstr "Error: no se pudo crear %s"
-#~ msgstr "Error al escribir cuadrícula. ¿Disco lleno?"
-#, fuzzy
-#~ msgstr "Mapa ráster de densidad de línea de corriente de salida"
-#~ msgid "Converts co-ordinate system descriptions (i.e. projection information) between various formats (including GRASS format)."
-#~ msgstr "Convierte descripciones del sistema de coordenadas (o sea, información de proyección) entre varios formatos (incluido el formato GRASS). "
-#~ msgid "Create/Edit"
-#~ msgstr "Crear/Editar"
-#~ msgid "Create new projection files (modifies current location unless 'location' option specified)"
-#~ msgstr "Crea nuevos archivos de proyección (modifica la localización actual salvo que se especifique la opción 'location')"
-#~ msgid "Location %s created!"
-#~ msgstr "¡Localización %s creada!"
-#~ msgid "Print mapset names"
-#~ msgstr "Imprimir los nombres del directorio de mapas"
-#~ msgid "Force remove"
-#~ msgstr "Forzar eliminar"
-#~ msgstr "Color con el que borrar: color estándar de GRASS o triplete R:G:B (separados por dos puntos)"
-#~ msgid "Min-area & snap"
-#~ msgstr "Min-area & snap"
-#~ msgid "Layer: %s"
-#~ msgstr "Capa: %s"
-#~ msgid "Break polygons:"
-#~ msgstr "Romper polígonos:"
-#~ msgid "Remove duplicates:"
-#~ msgstr "Eliminar duplicados:"
-#~ msgid "Break boundaries:"
-#~ msgstr "Romper contornos:"
-#~ msgid "Clean boundaries at nodes:"
-#~ msgstr "Limpiar contornos en los nodos:"
-#~ msgid "Remove bridges:"
-#~ msgstr "Eliminar puentes:"
-#~ msgid "Write centroids:"
-#~ msgstr "Escribir centroidese:"
-#~ msgid "Cannot calculate centroid"
-#~ msgstr "No se puede calcular el centroide"
-#~ msgid "Unknown icon marker"
-#~ msgstr "Marcador desconocido"
-#~ msgid "Group input"
-#~ msgstr "Entrada de grupo"
-#~ msgid "Write output to PNG image"
-#~ msgstr "Escribir salida a imagen PNG"
-#~ msgid "Verbose mode"
-#~ msgstr "Modo verboso"
-#~ msgid "E00 file"
-#~ msgstr "Archivo E00"
-#~ msgid "Input type point, line or area"
-#~ msgstr "Tipo de entrada: punto, línea o área"
-#~ msgstr "Nombre para el mapa vectorial de salida"
-#~ msgstr "Nombre del plano ráster a crear"
-#~ msgid "Dip of plane. Value must be between -90 and 90 degrees"
-#~ msgstr "Pendiente del plano. El valor debe estar entre -90 y 90 grados"
-#~ msgid "Azimuth of the plane. Value must be between 0 and 360 degrees"
-#~ msgstr "Azimut del plano. El valor debe estar entre 0 y 360 grados"
-#, fuzzy
-#~ msgid "vector, interpolation, kriging"
-#~ msgstr "vectorial, interpolación"
-#~ msgid "Verbosity level"
-#~ msgstr "Nivel de verbosidad"
-#~ msgstr "Nombre del prefijo del mapa ráster de salida (ej. 'brov')"
-#~ msgstr "Mapa ráster de entrada"
-#~ msgid "reclass raster output map"
-#~ msgstr "reclasificar mapa ráster de salida"
-#~ msgstr "Mapa vectorial  a modificar"
-#~ msgid "Layer in the vector to be modified"
-#~ msgstr "Capa del vectorial a modificar"
-#~ msgstr "Mapa vectorial a consultar"
-#~ msgstr "Capa de la consulta vectorial que contiene datos"
-#~ msgstr "Columna a consultar"
-#~ msgstr "Mapa ráster de salida (por omisión: tesela de entrada)"
-#~ msgstr "Nombre del mapa vectorial de entrada"
-#~ msgstr "Mapa vectorial para el que editar la tabla de atributos"
-#~ msgid "Layer to which the table to be changed is connected"
-#~ msgstr "Capa al que está conectada la tabla a cambiar"
-#~ msgstr "Columna a actualizar"
-#~ msgid "WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/col2>1)"
-#~ msgstr "Condiciones WHERE para actualizar, sin palabra clave 'where' (ej.: cat=1 o col1/col2>1)"
-#, fuzzy
-#~ msgstr "Mapa ráster a usar como MÁSCARA"
-#~ msgstr "Esquema antiguo"
-#~ msgstr "Esquema nuevo"
-#~ msgid "Input ASTER image to be georeferenced & rectified"
-#~ msgstr "Imagen ASTER de entrada a georreferenciar y rectificar"
-#~ msgstr "Mapa vectorial en el que cambiar el nombre de una columna de atributos"
-#~ msgstr "Capa en la que cambiar el nombre de una columna"
-#~ msgstr "Nombre de la tabla de GRASS"
-#~ msgid "vector, import"
-#~ msgstr "vectorial, importar"
-#~ msgstr "Separador de campos"
-#~ msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
-#~ msgstr "Un mapa vectorial puede estar conectado a muchas tablas de bases de datos. Este número determina qué tabla utilizar."
-#~ msgid "WHERE conditions of SQL statement without 'where' keyword"
-#~ msgstr "Condiciones WHERE de sentencia SQL sin palabra clave 'where'"
-#~ msgid "Example: income < 1000 and inhab >= 10000"
-#~ msgstr "Ejemplo: entrada <1000 y habitantes>= 10000"
-#~ msgid "display, vector, thematic, legend"
-#~ msgstr "mostrar,vector, temático, leyenda"
-#~ msgid "vector, topology"
-#~ msgstr "vectorial, topología"
-#~ msgstr "Nombre del mapa vectorial para el que editar la tabla de atributos"
-#~ msgstr "Tabla de la que eliminar una columna de atributos"
-#~ msgid "Raster map in which to fill nulls"
-#~ msgstr "Mapa ráster en el que rellenar los nulos"
-#~ msgid "Output raster map with nulls filled by interpolation from surrounding values"
-#~ msgstr "Producir mapa ráster con nulos rellenos por interpolación de los valores circundantes"
-#~ msgstr "Mapa vectorial del que eliminar la tabla de atributos"
-#~ msgstr "Nombre de la tabla de atributos existente (por omisión: nombre del mapa vectorial)"
-#~ msgstr "Capa de la que eliminar la tabla de atributos asociada"
-#~ msgstr "Mapa vectorial del que eliminar una columna de atributos"
-#~ msgstr "Capa de la que eliminar una columna"
-#~ msgstr "prefijo de mapas TC ráster de salida"
-#~ msgstr "Mapa vectorial al que añadir nueva tabla de atributos"
-#~ msgstr "vectorial, importar, wfs"
-#~ msgstr "Nombre de la tabla de datos"
-#~ msgid "Database/directory for table"
-#~ msgstr "Base de datos/directorio para la tabla"
-#~ msgstr "Controlador de base de datos"
-#, fuzzy
-#~ msgstr "No se puede abrir el archivo de etiquetas <%s> en el directorio de mapas <%s>"
-#, fuzzy
-#, fuzzy
-#~ msgid "input,cell,raster"
-#~ msgstr "mostrar ráster"
-#, fuzzy
-#~ msgstr "mapa de salida ráster"
-#, fuzzy
-#~ msgid "basemap"
-#~ msgstr "Eliminar mapas base"
-#, fuzzy
-#~ msgid "Solar zenith in degrees"
-#~ msgstr "Ángulo del eje mayor en grados"
-#, fuzzy
-#~ msgid "method"
-#~ msgstr "Métodode los nodos"
-#~ msgid "Cannot allocate memory for auxiliar matrix.Consider changing region resolution"
-#~ msgstr "No se puede asignar memoria para la matriz auxiliar. Considerar cambiar la resolución de la zona"
-#, fuzzy
-#~ msgid "Creates a mask for limiting raster operation."
-#~ msgstr "Crear una MÁSCARA para limitar la operación ráster"
-#~ msgid "Raster value"
-#~ msgstr "Valor ráster"
-#, fuzzy
-#~ msgstr "El mapa ráster <%s> ya existe"
-#, fuzzy
-#~ msgstr "Pase: %d\n"
-#~ msgstr "ráster3D, estadísticas"
-#~ msgid "Feature type. Combination of types is not supported by all formats."
-#~ msgstr "Tipo de elemento. La combinación de tipos no está soportada por todos los formatos."
-#~ msgid "Illegal configuration file"
-#~ msgstr "Archivo de configuración no admitido"
-#~ msgid "Converting %s..."
-#~ msgstr "Convirtiendo %s..."
-#~ msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)"
-#~ msgstr "Simulación hidrológica del flujo de superficie -overland flow- utilizando el método path sampling (SIMWE)"
-#~ msgid "Raster File Series to MPEG Conversion Program."
-#~ msgstr "Programa de conversión de series de archivos ráster a MPEG."
-#~ msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation layer."
-#~ msgstr "Filtra y genera un mapa de elevación sin depresiones y un mapa de dirección de flujo a partir de una capa de elevación dada."
-#~ msgid "CHILD[pid = %i]: unable to open %s mask ... continue without!!!"
-#~ msgstr "CHILD[pid = %i]: no se puede abrir la máscara %s ... ¡¡¡Se continúa sin ella!!!"
-#~ msgid "r.li.worker (pid %i) exited with abnormal status %i"
-#~ msgstr "r.li.worker (pid %i) salió con el estado anormal %i"
-#~ msgid "r.li.worker (pid %i) terminated"
-#~ msgstr "r.li.worker (pid %i) terminado"
-#~ msgid "Cannot make stat of %s configuration file"
-#~ msgstr "No se puede la estadística del archivo de configuración %s"
-#, fuzzy
-#~ msgid "Calculates cast shadow areas from sun position and DEM. Either A: exact sun position is specified, or B: date/time to calculate the sun position by r.sunmask itself."
-#~ msgstr "Calcula áreas a."
-#~ msgid "A: altitude of the sun above horizon, degrees"
-#~ msgstr "A: altura del sol sobre el horizonte, grados"
-#~ msgid "B: minutes (0..60)"
-#~ msgstr "B: minutos (0..60)"
-#~ msgid "B: seconds (0..60)"
-#~ msgstr "B: segundos (0..60)"
-#~ msgid "B: timezone (east positive, offset from GMT, also use to adjust daylight savings)"
-#~ msgstr "B: zona horaria (Este positivo, compensar desde GMT, también uso para ajustar ahorros de luz solar)"
-#~ msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)"
-#~ msgstr "Construcción de curvas de pendiente (líneas de flujo), longitudes de ruta de flujo y densidades de líneas de flujo (áreas pendiente arriba) a partir de un modelo de elevación digital (MDT) ráster"
-#~ msgid "Show the category label in the grid cell(s)"
-#~ msgstr "Mostrar la etiqueta de categoría en la celda(s) de cuadrícula"
-#~ msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
-#~ msgstr "Crea mapa de índices topográficos [ln(a/tan(beta))] a partir de mapa de elevación."
-#~ msgid "New LOCATION name (not location path)"
-#~ msgstr "Nombre de la nueva LOCALIZACIÓN (no ruta de la localización)"
-#, fuzzy
-#~ msgid "Unable to read symbol, unable todisplay points"
-#~ msgstr "No se puede leer el símbolo, no se pueden mostrar los puntos"
-#~ msgid "Converts to one of the supported OGR vector formats."
-#~ msgstr "Convierte a uno de los formatos vectoriales OGR soportados."
-#~ msgid "Exporting %i points/lines..."
-#~ msgstr "Exportando %i puntos/líneas..."
-#, fuzzy
-#~ msgid "Name for output file (do not add extension)"
-#~ msgstr "Nombre para el archivo de salida (NO añadir extensión)"
-#, fuzzy
-#~ msgid "Width and height of output image"
-#~ msgstr "Anchura y altura de cuadros en la cuadrícula"
-#, fuzzy
-#~ msgid "Surface"
-#, fuzzy
-#~ msgid "Volume"
-#~ msgstr "Columnas"
-#~ msgid "Convert all old GRASS < Ver5.7 vector maps in current mapset to current format"
-#~ msgstr "Convierte todos los mapas vectoriales del antiguo GRASS < Ver5.7 del directorio de mapas actual al formato actual."
-#~ msgid "Vector map for which to edit attribute table"
-#~ msgid "Layer where to add column"
-#~ msgstr "Capa a la que añadir la columna"
-#, fuzzy
-#~ msgid "Computing row %d of covariance matrix..."
-#~ msgstr "Calculando la fila %d de la matriz de covarianza:"
-#, fuzzy
-#~ msgid "Writing data to file..."
-#~ msgstr "Escribiendo los datos transformados a archivo..."
-#~ msgid "ID values"
-#~ msgstr "Valores ID"
-#, fuzzy
-#~ msgid "Type of elements"
-#~ msgstr "Nombre de un elemento"
-#~ msgid "Output hue raster map"
-#~ msgstr "Mapa ráster de salida de matiz"
-#~ msgid "Raster file(s) for View%d"
-#~ msgstr "Archivo(s) ráster para la vista%d"
-#~ msgid "File type"
-#~ msgstr "Tipo de archivo"
-#~ msgid "%s file(s) to be copied"
-#~ msgstr "%s archivo(s) a copiar"
-#~ msgid "%s file(s) to be removed"
-#~ msgstr "%s archivo(s) a eliminar"
-#~ msgid "-s and -n are mutually exclusive"
-#~ msgstr "-s y -n son excluyentes mutuamente"
-#~ msgid "%s file(s) to be renamed"
-#~ msgstr "%s archivo(s) a renombrar"
-#~ msgid "Name of a mapset"
-#~ msgstr "Nombre de un directorio de mapas"
-#~ msgid "Layer number (if -1, all layers are displayed)"
-#~ msgstr "Número de capa (si es -1, se muestran todas las capas)"
-#~ msgid "Unable to display topology, not available"
-#~ msgstr "No se puede mostrar topología, no está disponible"
-#~ msgid "Remove lines and areas smaller than threshold"
-#~ msgstr "Eliminar líneas y áreas menores que el umbral"
-#~ msgstr "No se puede calcular el centroide para el área %d"
-#~ msgid "OGR format"
-#~ msgstr "Formato OGR"
-#, fuzzy
-#~ msgid "break;break lines at each intersection;rmdupl;remove duplicate geometry features (pay attention to categories!);rmdangle;remove dangles, threshold ignored if < 0;chdangle;change the type of boundary dangle to line, threshold ignored if < 0, input line type is ignored;rmbridge;remove bridges connecting area and island or 2 islands;chbridge;change the type of bridges connecting area and island or 2 islands from boundary to line;snap;snap lines to vertex in threshold;rmdac;remove duplicate area centroids ('type' option ignored);bpol;break (topologically clean) polygons (imported from non topological format, like ShapeFile). Boundaries are broken on each point shared between 2 and more polygons where angles of segments are different;prune;remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachement of centroid), first and last segment of the boundary is never changed;rmarea;remove smal
 l areas, the longest boundary with adjacent area is removed;rmline;remove all lines or boundaries of zero length, threshold is ignored;rmsa;remove small angles between lines at nodes"
-#~ msgstr "break;romper líneas en cada intersección;rmdupl;eliminar líneas duplicadas (¡Atención a las categorías!);rmdangle;eliminar dangles, umbral ignorado si < 0;chdangle;cambiar el tipo de boundary dangle a línea, umbral ignorado si < 0, el tipo de línea de entrada es ignorado;rmbridge;eliminar puentes que conectan áreas e islas o 2 islas;chbridge;cambiar el tip de puentes que conectan áreas e islas o 2 islas de perímetro a línea;snap;ajustar líneas a vértices en el umbral; rmdac;eliminar centroides de área duplicados (opción 'tipo' ignorada);bpol;rompe (topológicamente limpios) polígonos (importados de formatos no topológicos (como shapefile). Los perímetros se rompen en cada punto compartido entre dos o más polígonos donde los ángulos de segmentos son diferentes;prune;eliminar vértices en umbral de líneas y perímetros, el perímetro sólo se recorta si no se daña la topología (nueva intersección, cambiada la vinculación de centroide), los segmentos primero y último del
 perímetro nunca se cambian;rmarea;eliminar pequeñas áreas, se elimina el perímetro más largo con el área adyacente;rmsa;eliminar ángulos pequeños entre líneas y nodos"
-#~ msgid "Print vector history instead of info"
-#~ msgstr "Imprimir histórico del vectorial en vez de información"
-#~ msgid "File containing mapping instructions (or use input=- to enter from keyboard)"
-#~ msgstr "Archivo que contiene instrucciones de mapeo (o use entrada=-para introducir desde teclado)"
-#~ msgid "Scale of the output map, e.g. 1:25000 (default: Auto-sized to fit page)"
-#~ msgstr "Escala del mapa de salida. Ej.:1:25000 (por omisión: ajustar tamaño para encajar en la página)"
-#~ msgid "Using <%s> from the command line is depreciated. Please use the <%s> mapping instruction instead. The parameter <%s> will be removed in future versions of GRASS."
-#~ msgstr "El uso de <%s> desde la línea de comandos está despreciado. Por favor, use la instrucción mapeo <%s> en su lugar. El parámetro <%s> será eliminado en futuras versiones de GRASS."
-#~ msgid ""
-#~ "\n"
-#~ "ERROR: Required parameter <%s> not set:\n"
-#~ "    (%s).\n"
-#~ msgstr ""
-#~ "\n"
-#~ "ERROR: El parámetro requerido <%s> no ha sido establecido:\n"
-#~ "    (%s).\n"
-#~ msgid "GRASS environment variable GRASS_VERBOSE is overwritten by VERBOSE mapping instruction. This mapping instruction is superseded and will be removed in future versions of GRASS. Please use --verbose instead."
-#~ msgstr "La variable de entorno de GRASS GRASS_VERBOSE es sobrescrita por la instrucción de mapeo VERBOSE. Esta instrucción de mapeo es suplantada y se eliminará en versiones futuras de GRASS. Por favor use --verbose en su lugar."
-#~ msgid "Cannot set GRASS_VERBOSE variable."
-#~ msgstr "No se puede establecer la variable GRASS_VERBOSE."
-#~ msgid "Rectified input raster map <%s> will be saved as <%s>"
-#~ msgstr "Mapa raster de entrada rectificado <%s> será guardado como <%s>"
-#, fuzzy
-#~ msgid "Link GDAL supported raster file to a binary raster map layer."
-#~ msgstr "Importar archivo ráster soportado por GDAL a una capa de mapa ráster binario."
-#~ msgid "Required"
-#~ msgstr "Requerido"
-#~ msgid "Name of filter file"
-#~ msgstr "Nombre del archivo de filtro"
-#~ msgid "Location of input raster map"
-#~ msgstr "Localización del mapa ráster de entrada"
-#~ msgid "Mapset of input raster map"
-#~ msgstr "Directorio de mapas del mapa ráster de entrada"
-#~ msgid "Checking location <%s>, mapset <%s>..."
-#~ msgstr "Comprobando localización <%s>, directorio de mapas <%s>..."
-#~ msgid "Quiet - suppress progress report"
-#~ msgstr "Silencioso - suprime el informe de progreso"
-#~ msgid "Output file name not specified"
-#~ msgstr "Nombre del vectorial de salida sin especificar"
-#~ msgid "Exporting to GDAL raster"
-#~ msgstr "Exportando a GDAL raster"
-#~ msgid " %d.%02d.%02d, daynum %d, time: %02i:%02i:%02i (decimal time: %f)\n"
-#~ msgstr " %d.%02d.%02d, daynum %d, hora: %02i:%02i:%02i (hora decimal: %f)\n"
-#~ msgid " long: %f, lat: %f, timezone: %f\n"
-#~ msgstr " longitud: %f, latitud: %f, huso horario: %f\n"
-#~ msgid ""
-#~ " Solar position: sun azimuth: %f,\n"
-#~ "   sun angle above horz.(refraction corrected): %f\n"
-#~ msgstr ""
-#~ " Posición solar: azimut solar: %f,\n"
-#~ "   ángulo del sol sobre el horizonte (corregido según refracción): %f\n"
-#~ msgid " Sunrise time (without refraction): %02d:%02d:%02d\n"
-#~ msgstr " Hora de salida del sol (sin refracción): %02d:%02d:%02d\n"
-#~ msgid " Sunset time  (without refraction): %02d:%02d:%02d\n"
-#~ msgstr " Hora de puesta de sol (sin refracción): %02d:%02d:%02d\n"
-#~ msgid "No map calculation requested. Finished.\n"
-#~ msgstr "No se ha solicitado ningún cálculo de mapa. Terminado.\n"
-#~ msgid "Can't open range file for %s"
-#~ msgstr "No se puede abrir el archivo de intervalo para %s"
-#, fuzzy
-#~ msgid "<%s> created"
-#~ msgstr "Archivo %s creado"
-#~ msgid "Raster map to be recoded"
-#~ msgstr "Mapa ráster a recodificar"
-#~ msgid "GIS data directory (full path to the directory where the new location is)"
-#~ msgstr "Directorio de datos SIG (ruta completa al directorio donde se encuentra la nueva localización)"
-#~ msgid "Overlay (non-null values only)"
-#~ msgstr "Superponer (sólo valores no nulos)"
-#~ msgid "Raster map to be displayed"
-#~ msgstr "Mapa ráster a mostrar"
-#~ msgid "Change dangles to lines:"
-#~ msgstr "Cambiar nodos colgantes a línias:"
-#~ msgid "Allows projection conversion of vector maps."
-#~ msgstr "Permite la conversión de la proyección de mapas vectoriales."
-#~ msgid "Vector output map"
-#~ msgstr "Mapa vectorial de salida"
-#~ msgid "Error while writing to temp file"
-#~ msgstr "Error mientras se escribía a archivo temporal"
-#, fuzzy
-#~ msgid "r.li.worker (pid %i) exited with abnormal status: %i"
-#~ msgid "r.li.worker (pid %i) terminated successfully"
-#~ msgstr "r.li.worker (pid %i) terminó correctamente"
-#~ msgid "Unable to read raster map row %ld"
-#~ msgstr "No se puede leer la fila %ld del mapa raster"
-#~ msgid "Failed writing raster map row %ld"
-#~ msgstr "Fallo al escribir la fila del mapa ráster %ld"
-#~ msgid "Not enough room in history file"
-#~ msgstr "Espacio insuficiente en archivo histórico"
-#~ msgid "New MAPSET name"
-#~ msgstr "Nombre del nuevo DIRECTORIO DE MAPAS"
-#~ msgid "Your mapset search list:\n"
-#~ msgstr "La lista de búsqueda del directorio de mapas:\n"
-#~ msgid "<%s> not found in mapset list"
-#~ msgstr "<%s> no encontrado en la lista del directorio de mapas"
-#, fuzzy
-#~ msgid "Name of workspace file"
-#~ msgstr "Nombre de archivo de color"
-#~ msgid "List of values to be displayed (FP maps)"
-#~ msgstr "Lista de valores a mostrar (mapas FP)"
-#~ msgid "Ignoring catlist: map is floating point (please use 'val=')"
-#~ msgstr "Ignorando lista de categorías: el mapa es coma flotante (por favor use 'val=')"
-#~ msgid "Ignoring vallist: map is integer (please use 'cat=')"
-#~ msgstr "Ignorando lista de valores: el mapa es entero (por favor user 'cat=')"
-#~ msgid "Area size [%.1e], area not imported"
-#~ msgstr "Tamaño de área [%.1e]. Área no importada"
-#~ msgid "Island size [%.1e], island not imported"
-#~ msgstr "Tamaño de isla [%.1e]. Isla no importada"
-#~ msgid "No vector map of sparse points to interpolate was specified. Interpolation will be done with <%s> vector map"
-#~ msgstr "No se especificó ningún mapa vectorial de puntos dispersos a interpolar. La interpolación se realizará con <%s> mapa vectorial"
-#~ msgid "Failed in attempt to open %s"
-#~ msgstr "Fallo al intentar de abrir %s"
-#~ msgid "Generates raster map layers of slope, aspect, curvatures and partial derivatives from a raster map layer of true elevation values. Aspect is calculated counterclockwise from east."
-#~ msgstr "Genera capas de mapa ráster de pendiente, orientación, curvaturas y derivadas parciales a partir de una capa de mapa ráster de valores reales de elevación. La orientación se calcula en sentido horario desde el Este."
-#~ msgid "Output slope filename"
-#~ msgstr "Nombre de archivo de pendiente de salida"
-#~ msgid "Output profile curvature filename"
-#~ msgstr "Nombre de archivo de curvatura de perfil de salida"
-#~ msgid "Output tangential curvature filename"
-#~ msgstr "Nombre de archivo de curvatura tangencial de salida"
-#~ msgid "Output first order partial derivative dx (E-W slope) filename"
-#~ msgstr "Nombre de archivo de derivada dx (pendiente E-W) parcial de primer orden de salida"
-#~ msgid "Output first order partial derivative dy (N-S slope) filename"
-#~ msgstr "Nombre de archivo de derivada dy (pendiente N-S) parcial de primer orden de salida"
-#~ msgid "Output second order partial derivative dxx filename"
-#~ msgstr "Nombre de archivo de derivada dxx parcial de segundo orden de salida"
-#~ msgid "Output second order partial derivative dyy filename"
-#~ msgstr "Nombre de archivo de derivada dyy parcial de segundo orden de salida"
-#~ msgid "Output second order partial derivative dxy filename"
-#~ msgstr "Nombre de archivo de derivada dxy parcial de segundo orden de salida"
-#~ msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead."
-#~ msgstr "La opción -q está suplantada y se eliminará en el futuro. Por favor, use '--quiet' en su lugar."
-#~ msgid "wrong type: %s"
-#~ msgstr "tipo incorrecto: %s"
-#~ msgid "Creating support files..."
-#~ msgstr "Creando archivos de soporte..."
-#~ msgid "Elevation products for mapset [%s] in [%s]"
-#~ msgstr "Productos de elevación para el directorio de mapas [%s] en [%s]"
-#~ msgid "ASPECT [%s] COMPLETE"
-#~ msgstr "ORIENTACIÓN [%s] COMPLETA"
-#~ msgid "SLOPE [%s] COMPLETE"
-#~ msgstr "PENDIENTE [%s] COMPLETA"
-#~ msgid "PROFILE CURVE [%s] COMPLETE"
-#~ msgstr "CURVA DE PERFIL [%s] COMPLETA"
-#~ msgid "TANGENTIAL CURVE [%s] COMPLETE"
-#~ msgstr "CURVA TANGENCIAL [%s] COMPLETA"
-#~ msgid "E-W SLOPE [%s] COMPLETE"
-#~ msgstr "PENDIENTE E-W [%s] COMPLETA"
-#~ msgid "N-S SLOPE [%s] COMPLETE"
-#~ msgstr "PENDIENTE N-S [%s] COMPLETA"
-#~ msgid "DXX [%s] COMPLETE"
-#~ msgstr "DXX [%s] COMPLETO"
-#~ msgid "DYY [%s] COMPLETE"
-#~ msgstr "DYY [%s] COMPLETO"
-#~ msgid "DXY [%s] COMPLETE"
-#~ msgstr "DXY [%s] COMPLETO"
-#, fuzzy
-#~ msgid "Name and type of the new column(s) ('name type [,name type, ...]' - types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
-#~ msgstr "Nombre y tipo de la nueva columna(s) (los tipos dependen de la base de datos de destino, pero todas soportan VARCHAR(), ENTERO, DOBLE Y FECHA)"
-#~ msgid "Sources and sinks in [m^3/s]"
-#~ msgstr "Fuentes y sumideros en [m³/s]"
-#~ msgid "Input elevation map"
-#~ msgstr "Mapa de elevación de entrada"
-#~ msgid "Output shaded relief map name"
-#~ msgstr "Nombre del mapa compartido de relieve de salida"
-#~ msgid "Layer number of data column"
-#~ msgstr "Número de capa de la columna de datos"
-#~ msgid "Generates a raster map layer showing watershed subbasins."
-#~ msgstr "Genera una capa de mapa ráster mostrando subcuencas hidrográficas."
-#~ msgid "Coded stream network file name"
-#~ msgstr "Nombre del archivo de red de corrientes codificado"
-#~ msgid "Thinned ridge network file name"
-#~ msgstr "Nombre de archivo de red de divisorias adelgazadas"
-#~ msgid "Name for the resultant watershed partition file"
-#~ msgstr "Nombre para el archivo de partición de cuenca resultante"
-#, fuzzy
-#~ msgid "Input raster map contains cells with NULL-value (no-data). The value %f will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
-#~ msgstr "El mapa ráster de entrada contiene celdas con valor NULO (sin datos). Para los valores sin datos se usó el valor %d. Puede especificar el valor para para las celdas sin datos con el parámetro %s."
-#~ msgid "Name of the elevation raster map [m]"
-#~ msgstr "Nombre del mapa raster de elevación [m]"
-#~ msgid "Output water depth raster map [m]"
-#~ msgstr "Mapa raster de salida de la profundidad del agua [m]"
-#~ msgid "Output elevation raster map"
-#~ msgstr "Producir mapa ráster de elevación"
-#~ msgid "Input elevation raster map"
-#~ msgstr "Mapa ráster de elevación de entrada"
-#~ msgid "Input aspect raster map"
-#~ msgstr "Mapa ráster de orientación de entrada"
-#~ msgid "Input barrier raster map"
-#~ msgstr "Mapa ráster de barrera de entrada"
-#~ msgid "Output flowline vector map"
-#~ msgstr "Producir mapa vectorial de líneas de flujo"
-#~ msgid "Output raster map having shadows"
-#~ msgstr "Producir mapa ráster que contiene sombras"
-#~ msgid "By_position"
-#~ msgstr "Por posición"
-#~ msgid "B: year (1950..2050)"
-#~ msgstr "B: año (1950..2050)"
-#~ msgid "By_time"
-#~ msgstr "Por tiempo"
-#~ msgid "B: month (0..12)"
-#~ msgstr "B: mes (0..12)"
-#~ msgid "B: day (0..31)"
-#~ msgstr "B: día (0..31)"
-#~ msgid "B: hour (0..24)"
-#~ msgstr "B: hora (0..24)"
-#~ msgid "East coordinate (point of interest, default: map center)"
-#~ msgstr "Coordenada Este (punto de interés, por omisión: centro del mapa)"
-#~ msgid "North coordinate (point of interest, default: map center)"
-#~ msgstr "Coordenada Norte (punto de interés, por omisión: centro del mapa)"
-#~ msgid "Zero is a real elevation"
-#~ msgstr "Cero es una elevación real"
-#~ msgid "Verbose output (also print out sun position etc.)"
-#~ msgstr "Salida verbosa (también imprime la posición solar, etc.)"
-#~ msgid "(i)   Elevation map"
-#~ msgstr "(E)   Mapa de elevación"
-#~ msgid "(o)   Depressionless elevation map"
-#~ msgstr "(S)   Mapa de elevación sin depresiones"
-#~ msgid "(o/i) Basin elevation map (MASK applied)"
-#~ msgstr "(S/E) Mapa de elevación de cuenca (MÁSCARA aplicada)"
-#~ msgid "(o)   Topographic index ln(a/tanB) map (MASK applied)"
-#~ msgstr "(S)   Mapa ln(a/tanB) de índice topográfico (MÁSCARA aplicada)"
-#~ msgid "(o)   Output file"
-#~ msgstr "(S)   Archivo de salida"
-#~ msgid "(i)   OPTIONAL Observed flow file"
-#~ msgstr "(E)   Archivo de flujo observado OPCIONAL"
-#~ msgid "(i)   OPTIONAL Output for given time step"
-#~ msgstr "(E)   Salida OPCIONAL para paso de tiempo dado"
-#~ msgid "(i)   OPTIONAL Output for given topographic index class"
-#~ msgstr "(E)   Salida OPCIONAL para clase de índice topográfico dada"
-#~ msgid "Name of existing raster map containing elevation surface"
-#~ msgstr "Nombre de mapa ráster existente que contiene superficie de elevación"
-#~ msgid "Output elevation raster map after filling"
-#~ msgstr "Producir un mapa ráster de elevación después de rellenar"
-#~ msgid "Output aspect direction format (agnps, answers, or grass)"
-#~ msgstr "Formato de salida de la dirección de la orientación (agnps, answers, or grass)"
-#~ msgid "Reading map..."
-#~ msgstr "Leyendo mapa..."
-#~ msgid "Failed to guess site file format\n"
-#~ msgstr "No se pudo averiguar el formato de archivo de lugares\n"
-#~ msgid "Watershed basin analysis program."
-#~ msgstr "Programa de análisis de cuenca hidrográfica."
-#~ msgid "Input map: elevation on which entire analysis is based"
-#~ msgstr "Mapa de entrada: elevación en la que se basa todo el análisis"
-#~ msgid "Input map: locations of real depressions"
-#~ msgstr "Mapa de entrada: localizaciones de depresiones reales"
-#~ msgid "Input map or value: percent of disturbed land, for USLE"
-#~ msgstr "Mapa o valor de entrada: porcentaje de terreno perturbado, para USLE"
-#~ msgid "Output map: drainage direction"
-#~ msgstr "Mapa de salida: dirección de drenaje"
-#~ msgid "Output map: stream segments"
-#~ msgstr "Mapa de salida: segmentos de corriente"
-#~ msgid "Watershed basin creation program."
-#~ msgstr "Programa de creación de cuenca hidrográfica."
-#~ msgid "Name of raster map to contain results"
-#~ msgstr "Nombre del mapa ráster que contendrá los resultados"
-#~ msgid "The map N grid coordinates"
-#~ msgstr "Coordenadas de cuadrícula N del mapa"
-#~ msgid "X-part of the hydraulic conductivity tensor in [m/s]"
-#~ msgstr "Parte X del tensor de conductividad hidráulica en [m/s]"
-#~ msgid "Y-part of the hydraulic conductivity tensor in [m/s]"
-#~ msgstr "Parte Y del tensor de conductividad hidráulica en [m/s]"
-#~ msgid "Decomposition failed"
-#~ msgstr "Falló la descomposición"
-#~ msgid "<%s> created in database."
-#~ msgstr "<%s> creado en la base de datos."
-#~ msgid "Unable to access table <%s>"
-#~ msgstr "No se puede acceder a la tabla <%s>"
-#~ msgid "Import GDAL supported raster file into a binary raster map layer."
-#~ msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the currently defined region."
-#~ msgstr "Convierte un mapa ráster de GRASS en un archivo de imagen PPM a la resolución de píxel de la región definida actualmente."
-#~ msgid "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel resolution of the currently defined region."
-#~ msgstr "Exporta un mapa ráster de GRASS a una imagen TIFF de 8/24 bits a la resolución de píxel de la región definida actualmente."
-#, fuzzy
-#~ msgid "Band to select"
-#~ msgstr " Ningún monitor seleccionado"
-#~ msgid "It was impossible to create <Auxiliar_outlier_table>."
-#~ msgstr "Fue imposible crear <Auxiliar_outlier_table>."
-#~ msgid "If set to 0, z coordinates are used. (3D vector only)"
-#~ msgstr "Valor de campo. Si se establece a 0, se usarán las coordenadas Z (sólo vectoriales 3D)"
-#~ msgid "Attribute table column with values to interpolate (if layer>0)"
-#~ msgstr "Columna de la tabla de atributos con valores a interpolar (si capa>0)"
-#~ msgid "M.Q. solution"
-#~ msgstr "Solución M.Q."
-#~ msgid "3-d data in dxf file. Polyline_flag: %d"
-#~ msgstr "Datos 3D en el archivo dxf. Polyline_flag: %d"
-#~ msgid "Import SRTM HGT files into GRASS"
-#~ msgstr "Importar archivos SRTM HGT a GRASS"
-#~ msgid ""
-#~ "\n"
-#~ "Enter database password for connection\n"
-#~ "<%s:%s:user=%s>\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Introducir contraseña de la base de datos para la conexión\n"
-#~ "<%s:%s:usuario=%s>\n"
-#~ msgid "Hit RETURN to cancel request\n"
-#~ msgstr "Pulsar INTRO para cancelar la solicitud\n"
-#~ msgid "Exiting. Not changing current settings"
-#~ msgstr "Saliendo. No se cambian las configuraciones actuales"
-#~ msgid "New password set"
-#~ msgstr "Establecida la nueva contraseña"
-#~ msgid "Unable to close output map"
-#~ msgstr "No se puede cerrar el mapa de salida"
-#~ msgid "Unable to get elevation raster row"
-#~ msgstr "No se puede obtener la fila ráster de elevación"
-#~ msgid "Could not write raster row"
-#~ msgstr "No fue posible escribir la fila ráster"
-#~ msgid "Unable to open elevation map"
-#~ msgstr "No se puede abrir el mapa de elevación"
-#~ msgid "Unable to create raster map"
-#~ msgstr "No se puede crear el mapa ráster"
-#~ msgid "Unable to close elevation map"
-#~ msgstr "No se puede cerrar el mapa de elevación"
-#~ msgid "Use a sparse linear equation system, only available with iterative solvers"
-#~ msgstr "Usar un sistema de ecuaciones lineal sparse, sólo disponible con solucionadores iterativos"
-#~ msgid "Could not open map %s"
-#~ msgstr "No se pudo abrir el mapa %s"
-#~ msgid "Could not get top raster row \n"
-#~ msgstr "No se pudo obtener la fila ráster superior \n"
-#~ msgid "Could not get bottom raster row \n"
-#~ msgstr "No se pudo obtener la fila ráster inferior \n"
-#~ msgid "Unable to write raster row"
-#~ msgstr "No se puede escribir la fila ráster"
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
-#~ msgstr "mi(llas),f(pies),me(tros),k(ilómetros),a(cres),h(ectáreas),p(orcentaje)"
-#~ msgid "Unable to write quant file"
-#~ msgstr "No se puede escribir el archivo quant"
-#~ msgid "Unable to write color table for %s"
-#~ msgstr "No se puede escribir la tabla de color para %s"
-#~ msgid "Cannot write category file for raster map <%s>"
-#~ msgstr "No se puede escribir el archivo de categoría para mapa ráster <%s>"
-#~ msgid "Cannot open raster map <%s>"
-#~ msgstr "No se puede abrir el mapa ráster <%s>"
-#~ msgid "Cannot create category file of <%s>"
-#~ msgstr "No se puede crear el archivo de categoría de <%s>"
-#~ msgid "[%s]: Cannot read map header"
-#~ msgstr "[%s]: no se puede leer la cabecera del mapa"
-#~ msgid "Unable to read raster map <%s> row %d"
-#~ msgstr "No se puede leer en el mapa ráster <%s> la fila %d"
-#~ msgid "Failed writing raster map <%s> row %d"
-#~ msgstr "No se puede escribir en el mapa ráster <%s> la fila %d"
-#~ msgid "Can't set window"
-#~ msgstr "No se puede establecer la ventana"
-#~ msgid "Unable to read raster map row %d"
-#~ msgstr "No se puede leer la fila %d del mapa ráster"
-#~ msgid "Unable to read header of raster map <%s>"
-#~ msgstr "No se puede leer la cabecera del mapa ráster <%s>"
-#~ msgid "Reading row %d"
-#~ msgstr "Leyendo la fila %d"
-#~ msgid "Horizon file no. %d <%s> not found"
-#~ msgstr "Archivo Horizon no. %d  <%s> no encontrado"
-#, fuzzy
-#~ msgid "Data or Clump file not open"
-#~ msgstr "No se encontró el mapa ráster"
-#~ msgid "Error writing null row %d"
-#~ msgstr "Error al escribir fila nula %d"
-#~ msgid "Failed writing output raster map row %d"
-#~ msgstr "Fallo al escribir la fila  %d del mapa raster"
-#~ msgid "Signed data (high bit means negative value)"
-#~ msgstr "Datos firmados (alto bit significa valor negativo)"
-#~ msgid "Number of bytes per cell (1, 2, 4)"
-#~ msgstr "Número de bytes por celda (1, 2, 4)"
-#~ msgid "Byte Swapping Turned On."
-#~ msgstr "Swapping de byte activado."
-#~ msgid ""
-#~ "Missing parameters ...\n"
-#~ "Must provide at least[north= south= east= west=] OR [r=\tc=]"
-#~ msgstr ""
-#~ "Faltan parámetros ...\n"
-#~ "Debe proporcionar al menos [Norte= Sur= Este= Oeste=] O [r=\tc=]"
-#~ msgid "You have to provide all limits of geographic region (n,s,e,w)"
-#~ msgstr "Tiene que proporcionar todos los límites de la región geográfica (N,S,E,O)"
-#, fuzzy
-#~ msgid "Illegal number of rows <%s>"
-#~ msgstr "Nombre de subgrupo <%s> no admitido"
-#, fuzzy
-#~ msgid "Illegal number of columns <%s>"
-#~ msgstr "Número máximo de columnas: %d"
-#~ msgid "Using N=%f S=%f E=%f W=%f"
-#~ msgstr "Usando N=%f S=%f E=%f O=%f"
-#~ msgid "Using rows=%d cols=%d\n"
-#~ msgstr "Usando filas=%d columnas=%d\n"
-#~ msgid "File Size %d ... Total Bytes %d"
-#~ msgstr "Tamaño de archivo %d ... Bytes totales %d"
-#~ msgid "Try bytes=%d or adjusting input parameters"
-#~ msgstr "Pruebe bytes=%d o ajuste los parámetros de entrada"
-#~ msgid "Conversion failed at row %d"
-#~ msgstr "La conversión falló en la fila %d"
-#~ msgid "Error writing category file for <%s>"
-#~ msgstr "Error al escribir el archivo de categorías para <%s>"
-#~ msgid "Overwrite output map file"
-#~ msgstr "Sobrescribir archivo de mapa de salida"
-#~ msgid "Setting window header"
-#~ msgstr "Estableciendo cabecera de ventana"
-#~ msgid "Cannot get row"
-#~ msgstr "No se puede obtener la fila"
-#~ msgid "Unable to close input map"
-#~ msgstr "No se puede cerrar el mapa de entrada"
-#~ msgid "Could not get raster row from input map"
-#~ msgstr "No se pudo obtener la fila del ráster del mapa de entrada"
-#~ msgid "Could not get raster row from elev map"
-#~ msgstr "No se pudo obtener la fila del ráster del mapa de elevación"
-#~ msgid "%s: running %s command"
-#~ msgstr "%s: ejecutando el comando %s"
-#~ msgid "%s: unable to open temporary file"
-#~ msgstr "%s: no se puede abrir el archivo temporal"
-#~ msgid "Resultant raster map (not used with 'distribution')"
-#~ msgstr "Mapa ráster resultante (no usado con 'distribución')"
-#~ msgid "Output map <%s> ignored"
-#~ msgstr "Mapa de salida <%s> ignorado"
-#~ msgid "Not yet implemented!"
-#~ msgstr "¡No implementado aún!"
-#~ msgid "An output raster map needs to be defined with method '%s'"
-#~ msgstr "Un mapa de salida necesita ser definido con el método '%s'"
-#~ msgid "One or more input raster maps not found"
-#~ msgstr "No se encuentran uno o más mapas de entrada"
-#~ msgid "Cannot read row"
-#~ msgstr "No se puede leer la fila"
-#~ msgid "Error in pipe creation"
-#~ msgstr "Error en la creación de tubería"
-#~ msgid "Error opening channel %i"
-#~ msgstr "Error al abrir el canal %i"
-#~ msgid "Cannot close %s file (PIPE)"
-#~ msgstr "No se puede cerrar el archivo %s (TUBERÍA)"
-#~ msgid "Cannot delete %s file (PIPE)"
-#~ msgstr "No se puede borrar el archivo %s (TUBERÍA)"
-#~ msgid "Cannot close %s file (PIPE2)"
-#~ msgstr "No se puede cerrar el archivo %s (TUBERÍA2)"
-#~ msgid "Cannot delete %s file (PIPE2)"
-#~ msgstr "No se puede borrar el archivo %s (TUBERÍA2)"
-#~ msgid "Cannot close receive channel file"
-#~ msgstr "No se puede cerrar el archivo del canal de recepción"
-#~ msgid "Cannot delete %s file"
-#~ msgstr "No se puede borrar el archivo %s"
-#~ msgid "Cannot read raster header file"
-#~ msgstr "No se  puede leer el archivo de cabecera del ráster"
-#~ msgid "CHILD[pid = %i] cannot open raster map"
-#~ msgstr "CHILD[pid = %i] no se puede abrir el mapa ráster"
-#~ msgid "CHILD[pid = %i] cannot open receive channel"
-#~ msgstr "CHILD[pid = %i] no se puede abrir el canal de recepción"
-#~ msgid ""
-#~ "\t\t\t\tAREA MESSAGE: \n"
-#~ " \t\t\t\taid = %i \n"
-#~ " \t\t\t\tx = %i \n"
-#~ " \t\t\t\ty = %i \n"
-#~ " \t\t\t\trl = %i \n"
-#~ " \t\t\t\tcl = %i \n"
-#~ msgstr ""
-#~ "\t\t\t\tMENSAJE DE ÁREA: \n"
-#~ msgid ""
-#~ " \t\t\t\tMASKEDAREA MESSAGE: \n"
-#~ " \t\t\t\tmask = %s \n"
-#~ msgstr ""
-#~ " \t\t\t\tMENSAJE DE ÁREA CON MÁSCARA: \n"
-#~ msgid ""
-#~ " \t\t\t\tDONE MESSAGE: \n"
-#~ " \t\t\t\tpid = %i \n"
-#~ " \t\t\t\tresult = %f \n"
-#~ msgstr ""
-#~ " \t\t\t\tMENSAJE HECHO: \n"
-#~ msgid ""
-#~ " \t\t\t\tERROR MESSAGE: \n"
-#~ msgstr ""
-#~ " \t\t\t\tMENSAJE DE ERROR: \n"
-#, fuzzy
-#~ msgid ""
-#~ " \t\t\t\tTERM MESSAGE: \n"
-#~ msgstr ""
-#~ msgid "Cannot reset current region"
-#~ msgstr "No se puede restablecer la región actual"
-#~ msgid "Cannot create category file for <%s>"
-#~ msgstr "No se puede crear el archivo de categoría para <%s>"
-#~ msgid "Cannot read header of raster map <%s> in <%s>"
-#~ msgstr "No se puede leer la cabecera del mapa ráster <%s> en <%s>"
-#~ msgid "Cannot open cell file of raster map <%s> in <%s>"
-#~ msgstr "No se puede abrir el archivo de celdas del mapa ráster <%s> en <%s>"
-#~ msgid "Cannot read raster row [%d] from raster map <%s>"
-#~ msgstr "No se puede leer la fila ráster [%d]del mapa ráster <%s>"
-#~ msgid "Cannot read raster row [%d] from cover raster map <%s>"
-#~ msgstr "No se puede leer la fila ráster [%d]del mapa ráster de cobertura <%s>"
-#~ msgid "Cannot read raster row [%d]"
-#~ msgstr "No se puede leer la fila [%d] del ráster"
-#~ msgid "Cannot read cover raster row [%d]"
-#~ msgstr "No se puede leer la fila [%d] del ráster de cobertura"
-#~ msgid "Can't read row in input elevation map"
-#~ msgstr "No se puede leer la fila en el mapa de elevación de entrada"
-#~ msgid "Error reading 'hue' map"
-#~ msgstr "Error al leer el mapa 'matiz'"
-#~ msgid "Error reading 'intensity' map"
-#~ msgstr "Error al leer el mapa 'intensidad'"
-#~ msgid "Error reading 'saturation' map"
-#~ msgstr "Error al leer el mapa 'saturación'"
-#~ msgid "Unable to read raster <map %d of %d> row %d"
-#~ msgstr "No se puede leer raster <map %d de %d> fila %d"
-#~ msgid "Writing map, row %d"
-#~ msgstr "Escribiendo mapa, fila %d"
-#~ msgid "Unable to create distance map <%s>"
-#~ msgstr "No se puede crear el mapa de distancia <%s>"
-#~ msgid "Unable to create value map <%s>"
-#~ msgstr "No se puede crear el mapa de valores<%s>"
-#~ msgid "Unable to write color table for raster map <%s>"
-#~ msgstr "No se puede escribir la tabla de color del mapa raster<%s>"
-#~ msgid "Unable to read row %i\n"
-#~ msgstr "No se puede leer la fila %i\n"
-#~ msgid "Error writing null row [%d]."
-#~ msgstr "Error al escribir la fila nula [%d]."
-#~ msgid "Swapping header data"
-#~ msgstr "Intercambiando datos de cabecera"
-#~ msgid "Exporting raster as double values (bytes=%d)"
-#~ msgstr "Exportando ráster como valores dobles (bytes=%d)"
-#~ msgid "Reading map"
-#~ msgstr "Leyendo mapa"
-#~ msgid "Unable to read raster map row %d "
-#~ msgstr "No se puede leer la fila %d del mapa raster"
-#~ msgid "Failed writing raster map row %d"
-#~ msgid "Invalid region: %s"
-#~ msgstr "Región no válida: %s"
-#~ msgid "Writing raster map, row %d"
-#~ msgstr "Escribiendo mapa raster, fila %d"
-#~ msgid "unable to open elevation map layer"
-#~ msgstr "no se puede abrir capa de mapa de elevación"
-#~ msgid "unable to open runoff map layer"
-#~ msgstr "No se puede abrir la capa del mapa runoff"
-#~ msgid "unable to open depression map layer"
-#~ msgstr "no se puede abrir la capa del mapa de depresión"
-#~ msgid "unable to open blocking map layer"
-#~ msgstr "no se puede abrir la capa del mapa de bloqueo"
-#~ msgid "unable to open rill map layer"
-#~ msgstr "No se puede abrir la capa del mapa rill"
-#~ msgid "unable to open new accum map layer."
-#~ msgstr "no se puede abrir nueva capa de mapa de acumulación."
-#~ msgid "Close failed."
-#~ msgstr "Fallo al cerrar."
-#~ msgid "unable to open new aspect map layer."
-#~ msgstr "no se puede abrir nueva capa de mapa de orientación."
-#~ msgid "unable to open new LS factor map layer."
-#~ msgstr "no se puede abrir nuevo factor LS de la capa del mapa."
-#~ msgid "unable to open new slope length map layer."
-#~ msgstr "no se puede abrir nueva capa de mapa de longitud de pendiente."
-#~ msgid "unable to open new S factor map layer."
-#~ msgstr "no se puede abrir nuevo factor S de la capa del mapa."
-#~ msgid "SECTION 2: A * Search."
-#~ msgstr "SECCIÓN 2: A * Buscar."
-#~ msgid "unable to open accum file in valid_basins()"
-#~ msgstr "no se puede abrir el archivo de acumulación en valid_basins()"
-#~ msgid "Can't create raster map <%s>"
-#~ msgstr "No se puede crear el mapa ráster <%s>"
-#~ msgid "Quant table not changed for %s"
-#~ msgstr "Tabla(s) de cuantización no cambiada para %s"
-#, fuzzy
-#~ msgid "Unable to open drainage pointer map"
-#~ msgstr "a"
-#~ msgid "Unable to open new basin map"
-#~ msgstr "No se puede abrir el nuevo mapa de cuenca"
-#~ msgid "Unable to close new basin map layer"
-#~ msgstr "No se puede cerrar la capa del nuevo mapa de cuenca"
-#~ msgid "Number of the segment to create (segment library)"
-#~ msgstr "Número del segmento a crear (biblioteca de segmento)"
-#~ msgid "Nseg is %d"
-#~ msgstr "Nseg es %d"
-#~ msgid "Null cells excluded from cost evaluation."
-#~ msgstr "Celdas nulas excluidas de la evaluación de costes."
-#~ msgid "Input null cell will be retained into output map"
-#~ msgstr "Las celdas nulas de entrada se retendrán en el mapa de salida"
-#~ msgid "Map with different projection"
-#~ msgstr "Mapa con diferente proyección"
-#~ msgid "DTM_Source map is: Integer cell type"
-#~ msgstr "Mapa DTM_Origen es: tipo de celda entero"
-#~ msgid "DTM_Source map is: Floating point (float) cell type"
-#~ msgstr "Mapa DTM_Origen es: tipo de celda coma flotante (flotante)"
-#~ msgid "DTM_Source map is: Floating point (double) cell type"
-#~ msgstr "Mapa DTM_Origen es: tipo de celda coma flotante (doble)"
-#~ msgid " %d rows, %d cols"
-#~ msgstr " %d filas, %d columnas"
-#~ msgid "COST_Source map is: Integer cell type"
-#~ msgstr "Mapa COST_Origen es: tipo de celda entero"
-#~ msgid "COST_Source map is: Floating point (float) cell type"
-#~ msgstr "Mapa COST_Origen es: tipo de celda coma flotante (flotante)"
-#~ msgid "COST_Source map is: Floating point (double) cell type"
-#~ msgstr "Mapa COST_Origen es: tipo de celda coma flotante (doble)"
-#~ msgid "Output map is: Integer cell type"
-#~ msgstr "El mapa de salida es: tipo de celda entero"
-#~ msgid "Output map is: Floating point (float) cell type"
-#~ msgstr "El mapa de salida es: tipo de celda de coma flotante"
-#~ msgid "Output map is: Floating point (double) cell type"
-#~ msgstr "El mapa de salida es: tipo de celda de coma flotante (doble)"
-#~ msgid " EW resolution %s (%lf)"
-#~ msgstr " Resolución EW %s (%lf)"
-#~ msgid " NS resolution %s (%lf)"
-#~ msgstr " Resolución NS %s (%lf)"
-#~ msgid "Initializing output "
-#~ msgstr "Inicializando la salida "
-#~ msgid "Unable to allocate memory for segment fbuff == NULL"
-#~ msgstr "No se puede asigna memoria para el segmento fbuff == NULO"
-#~ msgid "End of map!"
-#~ msgstr "¡Final del mapa!"
-#~ msgid "Will copy input map null values into output map"
-#~ msgstr "Copiará los valores nulos del mapa de entrada en el mapa de salida"
-#~ msgid ""
-#~ "Integer cell type.\n"
-#~ "Writing..."
-#~ msgstr ""
-#~ "Tipo de celda entero.\n"
-#~ "Escribiendo..."
-#~ msgid ""
-#~ "Float cell type.\n"
-#~ "Writing..."
-#~ msgstr ""
-#~ "Tipo de celda flotante.\n"
-#~ msgid ""
-#~ "Double cell type.\n"
-#~ "Writing..."
-#~ msgstr ""
-#~ "Tipo de celda doble.\n"
-#~ msgid "Peak cost value: %f"
-#~ msgstr "Valor de coste pico: %f"
-#~ msgid "Unable to open raster map <%s@%s>"
-#~ msgstr "No se puede abrir el mapa ráster <%s@%s>"
-#~ msgid "Failed writing raster map row"
-#~ msgstr "Fallo al escribir la fila del mapa ráster"
-#~ msgid "Cannot read raster row %d"
-#~ msgstr "No se puede leer la fila %d del ráster"
-#~ msgid "Error reading raster map <%s>"
-#~ msgstr "Error al leer el mapa ráster <%s>"
-#~ msgid "Failed writing raster map <%s>"
-#~ msgstr "Fallo al escribir el mapa ráster <%s>"
-#~ msgid "Use a sparse matrix, only available with iterative solvers"
-#~ msgstr "Utilizar matriz dispersa, solo disponible con solucionadores iterativos -iterative solvers-"
-#~ msgid "Error reading input"
-#~ msgstr "Error al leer la entrada"
-#~ msgid "Unable to write to <%s>"
-#~ msgstr "No se puede escribir en <%s>"
-#~ msgid "Could not get raster row"
-#~ msgstr "No se pudo obtener la fila ráster"
-#~ msgid "Column name (type must be numeric)"
-#~ msgstr "Nombre de columna (debe ser de tipo numérico)"
-#~ msgid "Vector points to be spatially perturbed"
-#~ msgstr "Puntos vectoriales a perturbar espacialmente"
-#~ msgid "<Auxiliar_edge_table> created in database."
-#~ msgstr "<Auxiliar_edge_table> creada en la base de datos."
-#, fuzzy
-#~ msgid "Creating auxiliar table for archiving overlapping zones"
-#~ msgstr "Creando tabla auxiliar para archivar zonas solapadas"
-#, fuzzy
-#~ msgid "Unable to open table <%s_edge_Interpolation>"
-#~ msgstr "No se puede crear la tabla <%s>"
-#~ msgid "It was not possible to drop <%s> table. Nothing will be done. Try to drop it manually."
-#~ msgstr "No fue posible quitar la tabla <%s>. No se hará nada. Intente quitarla manualmente."
-#~ msgid "Cross Validation was success!"
-#~ msgstr "¡La validación cruzada fue un éxito!"
-#~ msgid "Interpolation: The region resolution is too high: %d cells. Consider to change it."
-#~ msgstr "Interpolación: la resolución de la región es demasiado alta: %d celdas. Considere cambiarla."
-#~ msgid "Finding nearest lines..."
-#~ msgstr "Encontrando líneas más próximas..."
-#~ msgid "Output vector map where points will be written"
-#~ msgstr "Mapa vectorial de salida en el que se escribirán los puntos"
-#~ msgid "Column name"
-#~ msgstr "Nombre de columna"
-#~ msgid "Name of input 2D vector map"
-#~ msgstr "Nombre del mapa vectorial 2D de entrada"
-#~ msgid "Name of resulting 3D vector map"
-#~ msgstr "Nombre del mapa vectorial 3D resultante"
-#, fuzzy
-#~ msgid "Extruding vector primitives..."
-#~ msgstr "Elevando objetos vectoriales básicos..."
-#~ msgid "Unable to read MASK"
-#~ msgstr "No se puede leer MASK"
-#~ msgid "Vector map defining sample points"
-#~ msgstr "Mapa vectorial que define los puntos de muestreo"
-#~ msgid "Raster map to be sampled"
-#~ msgstr "Mapa ráster a muestrear"
-#~ msgid "Bilinear interpolation (default is nearest neighbor)"
-#~ msgstr "Interpolación bilineal (lo predeterminado es el vecino más próximo)"
-#, fuzzy
-#~ msgid "Cubic convolution interpolation (default is nearest neighbor)"
-#~ msgstr "Interpolación de convolución cúbica (por omisión, vecino más próximo)"
-#~ msgid "Flags -b & -c are mutually exclusive. Choose only one."
-#~ msgstr "Las opciones -b y -c son excluyentes entre sí. Elija sólo una."
-#~ msgid "Checking vector points..."
-#~ msgstr "Comprobando puntos vectoriales..."
-#~ msgid "Unable to convert input map projection to GRASS format; cannot create new location"
-#~ msgstr "No se puede convertir la proyección del mapa de entrada a formato GRASS; no se puede crear la nueva localización."
-#~ msgid "Cannot open %s"
-#~ msgstr "No se puede abrir %s"
-#~ msgid "Vector of points defining sample points"
-#~ msgstr "Vectoria de puntos que define los puntos de muestra"
-#~ msgid "Suppress display of residuals or other information"
-#~ msgstr "Suprime la visualización de residuales y otra información"
-#~ msgid "Instead of points use transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot)"
-#~ msgstr "En vez de puntos usar parámetros de transformación (xshift, yshift, zshift, xscale, yscale, zscale, zrot)"
-#~ msgid "The '%c' flag is deprecated and will be removed in future. Transformation parameters are used automatically when no pointsfile is given."
-#~ msgstr "La opción '%c' está despreciada y se eliminará en el futuro. Se usan parámetros de transformación automáticamente cuando no se da un archivo de puntos."
-#~ msgid "The '%c' flag is deprecated and will be removed in future. Please use '--quiet' instead."
-#~ msgstr "La opción '%c' está despreciada y se eliminará en el futuro. Por favor, use '--quiet' en su lugar."
-#~ msgid "Cannot alter table: %s"
-#~ msgstr "No se puede modificar la tabla: %s"
-#~ msgid "DXF output file"
-#~ msgstr "Archivo DXF de salida"
-#~ msgid "Doing log transformation"
-#~ msgstr "Haciendo transformación del registro"
-#, fuzzy
-#~ msgid "Uses a GRASS vector points map to produce a convex hull vector map."
-#~ msgstr "Usa un mapa vectorial de puntos de GRASS para producir un mapa vectorial ."
-#~ msgid "Name of output vector area map"
-#~ msgstr "Nombre del mapa de área vectorial de salida"
-#, fuzzy
-#~ msgid "Cannot open vector map <%s>"
-#~ msgstr "No se puede abrir el nuevo mapa vectorial <%s>"
-#~ msgid "Unable to open SVG file <%s>"
-#~ msgstr "No se puede abrir el archivo SVG <%s>"
-#~ msgid "Change the type of geometry elements."
-#~ msgstr "Cambiar el tipo de elementos geométricos."
-#~ msgid "Pairs for input and output type separated by comma"
-#~ msgstr "Pares de tipos de entrada y salida separados por coma."
-#~ msgid ""
-#~ "<input_type1>,<output_type1>,<input_type2>,<output_type2>,...\n"
-#~ "\t\tExample1: line,boundary\n"
-#~ "\t\tExample2: line,boundary,point,centroid"
-#~ msgstr ""
-#~ "\t\tEjemplo1: línea,contorno\n"
-#~ "\t\tEjemplo2: línea,contorno,punto,centroide"
-#~ msgid "Nothing to do"
-#~ msgstr "Nada que hacer"
-#~ msgid "Not enough types"
-#~ msgstr "Tipos insuficientes"
-#~ msgid "Odd number of types"
-#~ msgstr "Número de tipos impar"
-#~ msgid "Output slope raster map"
-#~ msgstr "Producir mapa ráster de pendiente"
-#~ msgid "Output aspect raster map"
-#~ msgstr "Producir mapa ráster de orientación"
-#~ msgid "Output profile curvature raster map"
-#~ msgstr "Producir mapa ráster de curvatura de perfil"
-#~ msgid "Output tangential curvature raster map"
-#~ msgstr "Producir mapa ráster de curvatura tangencial"
-#~ msgid "Output mean curvature raster map"
-#~ msgstr "Producir mapa ráster de curvatura media"
-#~ msgid "Cannot allocate memory for row buffer"
-#~ msgstr "No se puede asignar memoria para el buffer de filas"
-#~ msgid "Unable to write categories for raster map <%s>"
-#~ msgstr "No se pueden escribir categorías para el mapa raster <%s>"
-#~ msgid "Layer is only used for WHERE SQL statement"
-#~ msgstr "La capa sólo se utliza para la declaración oficial de SDL"
-#~ msgid "Layer 0 not supported"
-#~ msgstr "Capa 0 no soportada"
-#~ msgid "Layer number (if -1, all features in all layers of given type are extracted)"
-#~ msgstr "Número de capa (si es -1, se extraen todos los elementos del tipo dado de todas las capas)"
-#~ msgid "Unable to read file header of <%s>"
-#~ msgstr "No se puede leer la cabecera del archivo <%s>"
-#~ msgid "Current region cannot be set."
-#~ msgstr "No se puede establecer la región actual."
-#~ msgid "Unable to allocate the input row buffer"
-#~ msgstr "No se puede asignar el buffer de la fila de entrada"
-#~ msgid "Unable to open the cell map MASK."
-#~ msgstr "No se puede abrir la MÁSCARA de mapa de celdas."
-#~ msgid "Unable to allocate the cell buffer in display_signature()."
-#~ msgstr "No se puede asignar el buffer de celdas en display_signatute()."
-#~ msgid "Did not find input cell map MASK."
-#~ msgstr "No se encontró la MASCARA de mapa de celdas de entrada."
-#~ msgid "Error reading raster map in function readbands."
-#~ msgstr "Error al leer mapa ráster en la función readbands."
-#~ msgid "Unable to read cell header for first band file"
-#~ msgstr "No se puede leer la cabecera del ráster para el archivo de la primera banda"
-#~ msgid "Unable to open band files."
-#~ msgstr "No se pueden abrir los archivos de bandas."
-#~ msgid "Error while reading input raster map."
-#~ msgstr "Error al leer el mapa ráster de entrada."
-#~ msgid "Error reading cell map during transform."
-#~ msgstr "Error al leer mapa de celdas durante la transformación."
-#~ msgid "Error writing cell map during transform."
-#~ msgstr "Error al escribir el mapa de celdas durante la transformación."
-#, fuzzy
-#~ msgid "Unable to open training map <%s>"
-#, fuzzy
-#~ msgid "Unable to open training map <%s in %s>"
-#~ msgstr "No se puede abrir el mapa vectorial <%s> en <%s>"
-#~ msgid "Could not read from <%s>"
-#~ msgstr "No fue posible leer desde <%s>"
-#~ msgid "Error reading row of data"
-#~ msgstr "Error al leer la fila de datos"
-#~ msgid "Error reading intensity data"
-#~ msgstr "Error al leer datos de intensidad"
-#~ msgid "Error reading saturation data"
-#~ msgstr "Error al leer datos de saturación"
-#~ msgid "Error writing PROJ_INFO"
-#~ msgstr "Error al escribir PROJ_INFO"
-#~ msgid "Error writing PROJ_UNITS"
-#~ msgstr "Error al escribir PROJ_UNITS"
-#~ msgid "Unable to compile regular expression %s"
-#~ msgstr "No se puede compilar expresión regular %s"
-#~ msgid "Unable to read region <%s> in <%s>"
-#~ msgstr "No se puede leer la región <%s> en <%s>"
-#~ msgid "Unable to read header of raster map <%s@%s>"
-#~ msgstr "No se puede leer la cabecera del mapa ráster <%s@%s>"
-#~ msgid "Raster map <%s@%s>: %s"
-#~ msgstr "Mapa ráster <%s@%s>: %s"
-#~ msgid "Unable to open raster map <%s> in <%s>"
-#~ msgstr "No se puede abrir el mapa ráster <%s> en <%s>"
-#~ msgid "raster3d, voxel, export"
-#~ msgstr "raster3d, voxel, exportar"
-#~ msgid "raster3d, voxel"
-#~ msgstr "ráster 3D, vóxel"
-#~ msgid "raster3d, voxel, import"
-#~ msgstr "raster3d, voxel, importar"
-#~ msgid "Configuration editor for r.li.'index'"
-#~ msgstr "Editor de configuración para el índice r.li"
-#~ msgid "database, attribute table"
-#~ msgstr "base de datos, tabla de atributos"
-#~ msgid "vector, import, gazetteer"
-#~ msgstr "vectorial, importar, gazetteer"
-#~ msgid "vector, centroid, area"
-#~ msgstr "vectorial, centroide, área"
-#~ msgid "raster, elevation, interpolation"
-#~ msgstr "ráster, elevación, interpolación"
-#~ msgid "general, manual, help"
-#~ msgstr "general, manual, ayuda"
-#~ msgid "miscellaneous, projection"
-#~ msgstr "miscelánea, proyección"
-#~ msgid "vector, report, statistics"
-#~ msgstr "vectorial, informe, estadísticas"
-#~ msgid "vector, database, attribute table"
-#~ msgstr "vectorial, base de datos, tabla de atributos"
-#~ msgid "vector, color table"
-#~ msgstr "vectorial, tabla de color"
-#~ msgid "raster, statistics, aggregation"
-#~ msgstr "ráster, estadísticas, agregación"
-#~ msgid "vector, export, GPS"
-#~ msgstr "vectorial, exportar, GPS"
-#~ msgid "raster, imagery, mosaicking"
-#~ msgstr "ráster, imaginería, creación de mosaicos"
-#~ msgid "Import waypoints, routes, and tracks from a GPS receiver or GPS download file into a vector map."
-#~ msgstr "Importar waypoints, rutas y caminos desde un receptor GPS o un archivo de descarga de GPS a un mapa vectorial."
-#~ msgid "vector, import, GPS"
-#~ msgstr "vectorial, importar, GPS"
-#~ msgid "Import waypoints"
-#~ msgstr "Importar waypoints"
-#~ msgid "Import routes"
-#~ msgstr "Importar rutas"
-#~ msgid "Import track"
-#~ msgstr "Importar caminos"
-#~ msgid "Force vertices of track or route data as points"
-#~ msgstr "Forzar vértices de caminos o rutas como puntos"
-#~ msgid "Do not attempt projection transform from WGS84"
-#~ msgstr "No intentar transformar la proyección a partir de WGS84"
-#~ msgid "Device or file used to import data"
-#~ msgstr "Dispositivo o archivo usado para importar datos"
-#~ msgid "Format of GPS input data (use gpsbabel supported formats)"
-#~ msgstr "Formato de datos de entrada del GPS (usar formatos soportados por gpsbabel)"
-#~ msgid "Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is assumed"
-#~ msgstr "Proyección de los datos de entrada (en estilo PROJ.4). Si no se indica se asume Latitud/Longitud WGS84"
-#~ msgid "imagery, fusion, Brovey"
-#~ msgstr "imaginería, fusión, Brovey"
-#~ msgid "Additional options for wget"
-#~ msgstr "Opciones adicionales para wget"
-#~ msgid "Additional options for curl"
-#~ msgstr "Opciones adicionales para curl"
-#~ msgid "raster, color table"
-#~ msgstr "raster, tabla "
-#~ msgid "imagery, raster, multispectral"
-#~ msgstr "imaginería, ráster, multiespectral"
-#~ msgid "raster, imagery, import"
-#~ msgstr "ráster, imaginería, importar"
-#~ msgid "raster, imagery, colors"
-#~ msgstr "ráster, imaginería, colores"
-#~ msgid "raster, import"
-#~ msgstr "ráster, importar"
-#~ msgid "raster, imagery"
-#~ msgstr "ráster, imaginería"
-#~ msgid "raster, mask"
-#~ msgstr "ráster, máscara"
-#~ msgid "vector, area, dissolve"
-#~ msgstr "vectorial, área, disolver"
-#~ msgid "sites, vector, import"
-#~ msgstr "lugares, vectorial, importar"
-#~ msgid "vector, statistics"
-#~ msgstr "vectorial, estadísticas"
-#~ msgid "Download waypoints, routes, and tracks from a Garmin GPS receiver into a vector map."
-#~ msgstr "Descarga waypoints, rutas y caminos desde un receptor GPS Garmin a un mapa vectorial."
-#~ msgid "Download Waypoints from GPS"
-#~ msgstr "Descargar Waypoints desde GPS"
-#~ msgid "Download Routes from GPS"
-#~ msgstr "Descargar Rutas desde GPS"
-#~ msgid "Download Track from GPS"
-#~ msgstr "Descargar Caminos desde GPS"
-#~ msgid "Force import of track or route data as points"
-#~ msgstr "Forzar la importación de datos de pista o ruta como puntos"
-#~ msgid "Use gardump instead of gpstrans as the download program"
-#~ msgstr "Usar gardump en vez de gpstrans como programa de descarga"
-#~ msgid "Import track in 3D (gardump only)"
-#~ msgstr "Importar track en 3D (sólo gardump)"
-#~ msgid "Port Garmin receiver is connected to"
-#~ msgstr "Receptor Garmin conectado al puerto"
-#~ msgid "raster, imagery, statistics"
-#~ msgstr "ráster, imaginería, estadísticas"
-#~ msgid "imagery, classification, MLC"
-#~ msgstr "imaginería, clasificación, MLC"
-#~ msgid "imagery, image transformation, PCA"
-#~ msgstr "imaginería, transformación de imagen, PCA"
-#, fuzzy
-#~ msgid "Computing Means for band %d..."
-#~ msgstr "Calculando medias para la banda %d:"
-#, fuzzy
-#~ msgid "Rescaling the data <%s> to range %d,%d..."
-#~ msgstr "%s: reescalando los datos al rango [%d, %d]:"
-#~ msgid ""
-#~ "Subgroup too large.  Maximum number of bands is %d\n"
-#~ msgstr ""
-#~ "Subgrupo demasiado grande. El número máximo de bandas es %d\n"
-#~ msgid "imagery, color transformation, RGB, HIS"
-#~ msgstr "imaginería, transformación de color, RGB, HIS"
-#~ msgid "imagery, FFT"
-#~ msgstr "imaginería, FFT"
-#~ msgid "imagery, classification, supervised, SMAP"
-#~ msgstr "imaginería, clasificación, supervisado, SMAP"
-#~ msgid "Cannot calculate area centroid z coordinate"
-#~ msgstr "No se puede calcular la coordenada z del centroide del área"
-#~ msgid "vector, generalization, simplification, smoothing, displacement, network generalization"
-#~ msgstr "vectorial, generalización, simplificación, suavizado, desplazamiento, generalización de redes generalization"
-#~ msgid "vector, geometry, 3D"
-#~ msgstr "vectorial, geometría, 3D"
-#~ msgid "vector, export"
-#~ msgstr "vectorial, exportar"
-#~ msgid "vector, projection"
-#~ msgstr "vectorial, proyección"
-#~ msgid "Name of input point vector map"
-#~ msgstr "Nombre del mapa vectorial de puntos de entrada"
-#~ msgid "Output vector map must be specified"
-#~ msgstr "Se debe especificar el mapa vectorial de salida"
-#~ msgid "Point vector map must be specified"
-#~ msgstr "Se debe especificar el mapa vectorial de puntos"
-#~ msgid "Threshold value must be specified"
-#~ msgstr "Se debe especificar el valor umbral"
-#, fuzzy
-#~ msgid "%d arcs added to network (nlayer %d)"
-#~ msgstr "%d arcos añadidos a la red (nlayer: [%d])"
-#, fuzzy
-#~ msgid "vector, query"
-#~ msgstr "vectorial, consultar"
-#~ msgid "Attribute column to use for buffer distances"
-#~ msgstr "Columna de atributos a usar para distancias de buffer"
-#~ msgid "Stop the process at a certain stage"
-#~ msgstr "Detener el proceso en un estado determinado"
-#~ msgid "The tolerance was reset to %g (map units)"
-#~ msgstr "Se restableció la tolerancia a %g (unidades de mapa)"
-#~ msgid "The tolerance was reset to %g (map units). [category %d]"
-#~ msgstr "Se restableció la tolerancia a %g (unidades de mapa). [categoría %d]"
-#~ msgid "Areas buffers... "
-#~ msgstr "Buffers de áreas... "
-#~ msgid "If set to 0, z coordinates are used (3D vector only)"
-#~ msgstr "Si se establece a 0, se usarán las coordenadas Z (sólo vectoriales 3D)"
-#~ msgid "Required if layer > 0"
-#~ msgstr "Requerido si capa > 0"
-#~ msgid "Create parallel line to input lines"
-#~ msgstr "Crear línea paralela a las líneas de entrada"
-#~ msgid "Offset in map units, positive for right side, negative for left side."
-#~ msgstr "Desplazamiento en unidades de mapa, positivo hacia la derecha, negativo hacia la izquierda."
-#~ msgid "vector, geometry, sampling"
-#~ msgstr "vectorial, geometría, muestreo"
-#~ msgid "vector, import, conversion"
-#~ msgstr "vectorial, importar, conversión"
-#~ msgid "vector, reclass, attributes"
-#~ msgstr "vectorial, raster, atributos"
-#~ msgid "vector, volume, conversion"
-#~ msgstr "vectorial, volumen, conversión"
-#~ msgid "vector, buffer"
-#~ msgstr "vectorial, buffer"
-#~ msgid "vector, raster, conversion"
-#~ msgstr "vectorial, ráster, conversión"
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares)"
-#~ msgstr "mi(llas),f(pies),me(tros),k(ilómetros),a(cres),h(ectáreas)"
-#~ msgid "Exporting %i faces (may take some time) ..."
-#~ msgstr "Exportando %i caras (puede llevar algún tiempo) ..."
-#~ msgid "vector, path, visibility"
-#~ msgstr "vectorial, ruta, visibilidad"
-#, fuzzy
-#~ msgid "Duplicate area centroids"
-#~ msgstr "Centroides de área duplicados: %5d"
-#~ msgid "%d areas of total size %g removed"
-#~ msgstr "%d áreas de tamaño total %g eliminadas"
-#~ msgid "%d modifications done"
-#~ msgstr "%d modificaciones hechas"
-#~ msgid "vector, LRS, networking"
-#~ msgstr "vectorial, LRS, trabajo en red"
-#~ msgid "vector, transformation, 3D"
-#~ msgstr "vectorial, transformación, 3"
-#~ msgid "vector, raster, aggregation"
-#~ msgstr "vectorial ráster, agregacion"
-#~ msgid "got type %d"
-#~ msgstr "se obtuvo el tipo %d"
-#~ msgid "Unable to select record from table <%s> (key %s, column %s)"
-#~ msgstr "No se pueden seleccionar registros de la tabla <%s> (clave %s, columna %s)"
-#~ msgid "Column <%s>: unsupported data type"
-#~ msgstr "Columna <%s>: tipo de datos no soportado"
-#~ msgid "ASCII file to be imported, if not given reads from standard input"
-#~ msgstr "Archivo ASCII a importar (si no se indica se leerá de la entrada estándar)"
-#~ msgid "Number of column used as x coordinate (first column is 1) for points mode"
-#~ msgstr "Número de columna usada como coordenada X (la primera columna es 1) para modo de puntos"
-#, fuzzy
-#~ msgid "Number of column used as y coordinate (first column is 1) for points mode"
-#, fuzzy
-#~ msgid "Number of column used as z coordinate (first column is 1) for points mode"
-#, fuzzy
-#~ msgid "If 0, z coordinate is not used"
-#~ msgstr "Si es 0, no se usará la coordenada Z"
-#, fuzzy
-#~ msgid "Number of column used as category (first column is 1) for points mode"
-#, fuzzy
-#~ msgid "If 0, unique category is assigned to each row and written to new column 'cat'"
-#~ msgstr "Si es 0, se asignará una categoría única a cada fila y se escribirá en una nueva columna 'cat'."
-#, fuzzy
-#~ msgid "Create a new empty vector map and exit. Nothing is read from input"
-#~ msgstr "Crear un mapa nuevo vacío y salir. No se lee nada de la entrada"
-#~ msgid "Error reading ASCII file: (bad type) [%s]"
-#~ msgstr "Error al leer el archivo ASCII: (tipo incorrecto) [%s]"
-#~ msgid "Error reading ASCII file: (unknown type) [%s]"
-#~ msgstr "Error al leer el archivo ASCII: (tipo desconocido) [%s]"
-#~ msgid "End of ASCII file reached before end of coordinates"
-#~ msgstr "Se alcanzó el final del archivo ASCII antes que el final de las coordenadas"
-#~ msgid "Error reading ASCII file: (bad point) [%s]"
-#~ msgstr "Error al leer el archivo ASCII: (coma incorrecta) [%s]"
-#~ msgid "End of ASCII file reached before end of categories"
-#~ msgstr "Se alcanzó el final del archivo ASCII antes que el final de las categorías"
-#~ msgid "Error reading categories: [%s]"
-#~ msgstr "Error al leer categorías: [%s]"
-#~ msgid ""
-#~ "Unexpected data in vector head:\n"
-#~ "[%s]"
-#~ msgstr ""
-#~ "Datos inesperados en la cabecera del vectorial:\n"
-#~ "[%s]"
-#~ msgid "Unknown keyword <%s> in vector head"
-#~ msgstr "Palabra clave <%s> desconocida en la cabecera del vectorial"
-#~ msgid "vector, raster, attribute table"
-#~ msgstr "vectorial, ráster, tabla de atributos"
-#~ msgid "vector, metadata"
-#~ msgstr "vectorial, metadatos"
-#~ msgid "Tychonov regularization weight"
-#~ msgstr "Peso de regularización Tychonov "
-#~ msgid "vector, LIDAR"
-#~ msgstr "vectorial, LIDAR"
-#~ msgid "It was impossible to open table"
-#~ msgstr "Fue imposible abrir la tabla"
-#~ msgid "Find best parameters using a cross validation method"
-#~ msgstr "Encontrar los mejores parámetros usando un método de validación cruzada"
-#~ msgid "Spline type of interpolation"
-#~ msgstr "Tipo spline de interpolación"
-#, fuzzy
-#~ msgid "No vector map to interpolate. Interpolation will be done with <%s> vector map"
-#~ msgstr "Ningún mapa vectorial a interpolar. La interpolación se hará con el mapa vectorial <%s>"
-#~ msgid "vector, LIDAR, edges"
-#~ msgstr "vectorial, LIDAR, bordes"
-#~ msgid "vector, metadata, history"
-#~ msgstr "vectorial, metadatos, historial"
-#~ msgid "Layer:           %s"
-#~ msgstr "Capa:                %s"
-#~ msgid "Mapset:          %s"
-#~ msgstr "Directorio de mapas: %s"
-#~ msgid "Location:        %s"
-#~ msgstr "Localización:        %s"
-#~ msgid "Database:        %s"
-#~ msgstr "Base de datos:       %s"
-#~ msgid "Title:           %s"
-#~ msgstr "Título:              %s"
-#~ msgid "  Type of Map:  %s (level: %i)        "
-#~ msgstr "  Tipo de mapa:  %s (nivel: %i)        "
-#~ msgid "  Number of points:       %-9ld       Number of areas:      %-9ld"
-#~ msgstr "  Número de puntos:        %-9ld       Número de áreas:        %-9ld"
-#~ msgid "  Number of lines:        %-9ld       Number of islands:    %-9ld"
-#~ msgstr "  Número de líneas:        %-9ld       Número de islas:        %-9ld"
-#~ msgid "  Number of boundaries:   %-9ld       Number of faces:      %-9ld"
-#~ msgstr "  Número de contornos:     %-9ld       Número de caras:      %-9ld"
-#~ msgid "  Number of centroids:    %-9ld       Number of kernels:    %-9ld"
-#~ msgstr "  Número de centroides:    %-9ld       Número de kernels:    %-9ld"
-#~ msgid "  Map is 3D:              %s"
-#~ msgstr "  El mapa es 3D:           %s"
-#~ msgid "  Number of dblinks:      %-9ld"
-#~ msgstr "  Número de enlaces a base de datos:      %-9ld"
-#~ msgid "                No topology present"
-#~ msgstr "                Ninguna topología presente"
-#~ msgid "        Projection: %s (zone %d)"
-#~ msgstr "        Proyección: %s (zona %d)"
-#~ msgid "        Projection: %s"
-#~ msgstr "        Proyección: %s"
-#~ msgid "vector, editing, geometry"
-#~ msgstr "vectorial, edición, geometría"
-#~ msgid "Error reading categories: '%s'"
-#~ msgstr "Error al leer categorías: '%s'"
-#~ msgid "Unexpected data in vector head: '%s'"
-#~ msgstr "Datos inesperados en la cabecera del vectorial: '%s'"
-#~ msgid "Unknown keyword '%s' in vector head"
-#~ msgstr "Palabra clave '%s' desconocida en la cabecera del vectorial"
-#~ msgid "vector, geometry, topology"
-#~ msgstr "vectorial, geometría, topología"
-#~ msgid "Output vector. If not given, available layers are printed only."
-#~ msgstr "Vectorial de salida. Si no se indica, las capas disponibles sólo se imprimen."
-#~ msgid ""
-#~ "OGR layer name. If not given, available layers are printed only. Examples:\n"
-#~ "\t\tESRI Shapefile: shapefile name\n"
-#~ "\t\tMapInfo File: mapinfo file name"
-#~ msgstr ""
-#~ "Nombre de capa OGR. Si no se indica, las capas disponibles sólo se imprimen. Ejemplos:\n"
-#~ "\t\tShapefile de ESRI: nombre del shapefile\n"
-#~ "\t\tArchivo MapInfo: nombre del archivo MapInfo"
-#~ msgid "Output vector name was not specified"
-#~ msgstr "El nombre del vectorial de salida no se especificó"
-#~ msgid "Cannot open data source"
-#~ msgstr "No se puede abrir el origen de datos"
-#~ msgid "general, projection"
-#~ msgstr "general, proyección"
-#~ msgid "general, transformation, GCP"
-#~ msgstr "vectorial, transformación, GCP"
-#~ msgid "general, settings"
-#~ msgstr "general, configuraciones"
-#~ msgid "%s=%s,%s: files are the same, no rename required"
-#~ msgstr "%s=%s,%s: los archivos son iguales, no se necesita cambiar el nombre"
-#~ msgid "general, gui"
-#~ msgstr "general, gui"
-#~ msgid "display, vector"
-#~ msgstr "visualizar, vectorial"
-#~ msgid "display, networking"
-#~ msgstr "visualización, trabajo en red"
-#~ msgid "Size of grid to be drawn"
-#~ msgstr "Tamaño de la cuadrícula a dibujar"
-#~ msgid "display, setup"
-#~ msgstr "mostrar, configuración"
-#~ msgid "postscript, map, printing"
-#~ msgstr "postscript, mapa, impresión"
-#~ msgid "Your cats/ file is invalid. A cats/ file with categories and labels is required for 'colortable' when using CELL rasters. No colortable will be assigned to this output postscript file."
-#~ msgstr "Su archivo de categorías no es válido. Se requiere un archivo de categorías y etiquetas para la 'tabla de color' cuando se usan rásters CELL. No se asignará ninguna tabla de colores a este archivo PostScript de salida."
-#~ msgid "vector, keyword2, keyword3"
-#~ msgstr "vectorial, palabra clave 2, palabra clave 3"
-#~ msgid "raster, keyword2, keyword3"
-#~ msgstr "ráster, palabra clave 2, palabra clave 3"
-#~ msgid "database, attribute table, SQL"
-#~ msgstr "base de datos, tabla de atributos, SQL"
-#~ msgid "Use db.select for SELECT SQL statements"
-#~ msgstr "Usar db.select para sentencias SQL SELECT"
-#~ msgid "Do not use this option if schemas are not supported by driver/database server"
-#~ msgstr "No use esta opción si los esquemas no están soportados por el controlador/servidor de base de datos"
-#~ msgid "Selects data from table."
-#~ msgstr "Selecciona datos de una tabla."
-#~ msgid "Output drain raster map"
-#~ msgstr "Producir mapa ráster de drenaje"
-#~ msgid "Unused; retained for compatibility purposes, will be removed in future"
-#~ msgstr "No usado; retenido por motivos de compatibilidad, se eliminará en el futuro"
-#~ msgid "Invoke slow, but memory frugal operation (generally not needed, will be removed in future)"
-#~ msgstr "Invoca operación lenta, pero ligera de memoria (generalmente no es necesario, se eliminará en el futuro)"
-#~ msgid "A single value of latitude [decimal degrees]"
-#~ msgstr "Un valor único de latitud [grados decimales]"
-#, fuzzy
-#~ msgid "Name of real-sky beam radiation coefficient raster map [-]"
-#~ msgstr "Nombre ráster"
-#, fuzzy
-#~ msgid "Name of real-sky diffuse radiation coefficient raster map [-]"
-#~ msgid "time and insol_time are incompatible options"
-#~ msgstr "Hora local (time) e insol_time son opciones incompatibles"
-#~ msgid "Mode 1: instantaneous solar incidence angle & irradiance given a set local time"
-#~ msgstr "Modo 1: ángulo de incidencia solar instantáneo e irradiancia dada una hora local establecida"
-#~ msgid "Unable to create raster map %s"
-#~ msgstr "No se puede crear el mapa ráster %s"
-#~ msgid "rows changed from %d to %d"
-#~ msgstr "filas cambiadas de %d a %d"
-#~ msgid "cols changed from %d to %d"
-#~ msgstr "columnas cambiadas de %d a %d"
-#~ msgid "Lat/Long location is not supported"
-#~ msgstr "Localización Lat/Long no soportada"
-#, fuzzy
-#~ msgid "Do not export long colortable"
-#~ msgstr "Eliminar la tabla de colores existente"
-#, fuzzy
-#~ msgid "Input raster map contains cells with NULL-value (no-data). The value %d was used to represent no-data values in the input map. You can specify nodata value by %s parameter."
-#, fuzzy
-#~ msgid "Input raster map contains cells with NULL-value (no-data). The value %g was used to represent no-data values in the input map. You can specify nodata value by %s parameter."
-#~ msgid "raster, export, VRML"
-#~ msgstr "ráster, exportar, VRML"
-#~ msgid "raster, flow, hydrology"
-#~ msgstr "ráster, flujo hidrolof"
-#~ msgid "raster, sediment flow, erosion, deposition"
-#~ msgstr "raster, flujo de sedimentación, erosión, deposición"
-#~ msgid "raster, cost surface, cumulative costs"
-#~ msgstr "ráster, superficie de coste, coste acumulado"
-#~ msgid "Source map is: Integer cell type"
-#~ msgstr "El mapa de origen es: tipo de celda entero"
-#~ msgid "Source map is: Floating point (float) cell type"
-#~ msgstr "El mapa de origen es: tipo de celda de coma flotante (flotante)"
-#~ msgid "Source map is: Floating point (double) cell type"
-#~ msgstr "El mapa de origen es: tipo de celda de coma flotante (doble)"
-#~ msgid "Reading %s"
-#~ msgstr "Leyendo %s"
-#~ msgid "can't open raster map [%s] needed for input coordinates"
-#~ msgstr "no se puede abrir el mapa ráster [%s] necesario para las coordenadas de entrada"
-#~ msgid "Error getting input null cells"
-#~ msgstr "Error al obtener celdas nulas de entrada"
-#~ msgid "new_cell is NULL"
-#~ msgstr "new_cell es NULO"
-#~ msgid "Can't find %d,%d:%f"
-#~ msgstr "No se puede encontrar %d,%d:%f"
-#~ msgid "Nothing to show"
-#~ msgstr "Nada que mostrar"
-#~ msgid "%s %f-%f lower cost higher or equal"
-#~ msgstr "%s %f-%f coste inferior más alto o igual"
-#~ msgid "%s lower above pointer wrong"
-#~ msgstr "%s más bajo sobre el puntero incorrecto"
-#~ msgid "%s %f-%f higher cost lower"
-#~ msgstr "%s %f-%f coste más alto inferior"
-#~ msgid "%s higher above pointer wrong"
-#~ msgstr "%s más alto sobre el puntero incorrecto"
-#~ msgid "raster, DEM, contours, vector"
-#~ msgstr "raster, MDE, curvas de nivel, vector"
-#~ msgid "raster, random, cell"
-#~ msgstr "raster, aleatorio, celda"
-#~ msgid "raster, landscape structure analysis, patch index"
-#~ msgstr "ráster, análisis de estructura de paisaje, índice de parcheo"
-#~ msgid "raster, landscape structure analysis, diversity index"
-#~ msgstr "ráster, análisis de estructura de paisaje, índice de diversidad"
-#~ msgid "raster, landscape structure analysis, dominance index"
-#~ msgstr "ráster, análisis de estructura de paisaje, índice de dominancia"
-#~ msgid "SECTION 4: Length Slope determination."
-#~ msgstr "SECCIÓN 4: determinación de la pendiente de la longitud."
-#~ msgid "Unable to open MASK"
-#~ msgstr "No se puede abrir MÁSCARA"
-#~ msgid "unable to open new L map layer."
-#~ msgstr "no se puede abrir nueva capa de mapa L."
-#~ msgid "unable to open new S map layer."
-#~ msgstr "no se puede abrir nueva capa de mapa S."
-#~ msgid "Input value: maximum length of surface flow, for USLE"
-#~ msgstr "Valor de entrada: longitud máxima de flujo de superficie, para USLE"
-#~ msgid "Output map: useful for visual display of results"
-#~ msgstr "Mapa de salida: útil para  visualizar los resultados"
-#~ msgid ""
-#~ "Sorry, if any of the following options are set:\n"
-#~ "    basin, stream, half.basin, slope, or lS\n"
-#~ "    you MUST provide a value for the basin threshold parameter."
-#~ msgstr ""
-#~ "Lo siento, si alguna de las siguientes opciones es establecida:\n"
-#~ "    cuenca, corriente, semicuenca, pendiente o IS\n"
-#~ "    DEBE proporcionar un valor para el parámetro de umbral de cuenca."
-#~ msgid "raster, random, surface"
-#~ msgstr "raster, aleatorio, superficie"
-#~ msgid "You have to use a different location for input than the current"
-#~ msgstr "Tiene que usar una localización diferente para la entrada que la actual"
-#~ msgid "raster, import, LIDAR"
-#~ msgstr "ráster, importar, LIDAR"
-#~ msgid "raster, volume, conversion"
-#~ msgstr "ráster, volumen, conversión"
-#~ msgid "Name of raster map to contain results (several new layers)"
-#~ msgstr "Nombre del mapa ráster que contiene los resultados (varias capas nuevas)"
-#~ msgid "The '-v' flag is superseded and will be removed in future. Please use '--verbose' instead."
-#~ msgstr "La opción '-v' está suplantado y se eliminará en el futuro. Por favor use '--verbose' en su lugar."
-#~ msgid "Raster map <%s> already exists in mapset <%s>, select another name"
-#~ msgstr "El mapa ráster <%s> ya existe en el directorio de mapas <%s>, seleccione otro nombre"
-#~ msgid "Percent Completed ... "
-#~ msgstr "Porcentaje completado... "
-#, fuzzy
-#~ msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in a local text file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
-#~ msgstr "Procesa mapas ráster de irradiación solar directa (rayo), difusa y reflejada para un día, latitud, superficie y condiciones atmosféricas dados. Los parámetros solares (ej. horas de salida y puesta del sol, declinación, irradiancia extraterrestre, duración del día) se guardan en el archivo histórico del mapa. De forma alternativa, se puede especificar una hora local para procesar el ángulo de incidencia solar y/o mapas ráster de irradiancia. El efecto de sombreo de la topografía se puede incorporar opcionalmente."
-#~ msgid "Name of the longitude input raster map [decimal degrees]"
-#~ msgstr "Nombre del mapa ráster de longitudes de entrada [grados decimales]"
-#, fuzzy
-#~ msgid "incidout requres time parameter to be set"
-#~ msgstr "incidout requiere que se establezca el parámetro hora local (time)"
-#, fuzzy
-#~ msgid "Mode 2: integrated daily irradiation"
-#~ msgstr "Modo 2: irradiación diaria integrada para un día determinado del año"
-#~ msgid "raster, raster3d, voxel, conversion"
-#~ msgstr "ráster, ráster3D, vóxel, conversión"
-#~ msgid "raster, metadata"
-#~ msgstr "raster, metadatos"
-#~ msgid "raster, series"
-#~ msgstr "ráster, series"
-#~ msgid "raster, composite"
-#~ msgstr "raster, composición"
-#~ msgid "raster, statistics, reclass"
-#~ msgstr "raster, estadísticas, reclass"
-#~ msgid "raster, DEM, fractal"
-#~ msgstr "raster, MDE, fractal"
-#~ msgid "visualization, raster, vector, raster3d"
-#~ msgstr "visualización, raster, vectorial, raster3d"
-#~ msgid "raster, vector, visualization"
-#~ msgstr "raster, vectorial, visualización"
-#~ msgid "Script kill option"
-#~ msgstr "Opción de matar el script"
-#~ msgid "Start in Demo mode"
-#~ msgstr "Empezar en modo Demo"
-#~ msgid "Output more comments (default=quiet)"
-#~ msgstr "Mostrar más comentarios (por omisión=silencio)"
-#, fuzzy
-#~ msgid "Subgroup [%s] in group [%s] contains no files."
-#~ msgstr "El subgrupo [%s] en el grupo [%s] no contiene archivos."
-#, fuzzy
-#~ msgid "Transposing eigen matrix..."
-#~ msgstr "Trasponiendo la matriz de valores propios..."
-#, fuzzy
-#~ msgid "Subgroup [%s] doesn't have any files"
-#~ msgstr "El subgrupo [%s] no tiene ningún archivo"
-#, fuzzy
-#~ msgid "The subgroup must have at least 2 files to run %s"
-#~ msgstr "El subgrupo debe tener al menos dos archivos para ejecutarse"
-#, fuzzy
-#~ msgid "Can't open seed signature file <%s>"
-#~ msgstr "** No se puede abrir el archivo de firmas semilla <%s> **"
-#, fuzzy
-#~ msgid "Output file to contain final report"
-#~ msgstr "Archivo de salida para contener el informe final"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "<%s> -- illegal value of min_size"
-#~ msgstr ""
-#~ "\n"
-#~ "<%s> -- valor no admitido de tamaño mínimo"
-#, fuzzy
-#~ msgid "Name of old database. The database must be in form printed by v.db.connect -g, i.e. with substituted variables"
-#~ msgstr "Nombre de la antigua base de datos. La base de datos debe estar en la forma impresa por v.db.connect -g, esto es, con variables sustituidas"
-#, fuzzy
-#~ msgid "%d update/insert errors"
-#~ msgstr "%d errores al insertar"
-#, fuzzy
-#~ msgid "display, legend"
-#~ msgstr "Dar la vuelta a la leyenda"
-#, fuzzy
-#~ msgid "Theme_prefs"
-#~ msgstr "Preferencias de tema"
-#, fuzzy
-#~ msgid "Attribute column to use for thematic display (must be numeric)"
-#~ msgstr "Columna de atributos a usar para presentación temática (debe ser numérico)"
-#, fuzzy
-#~ msgid "Break points for custom breaks option. Separate values by spaces. (0 10 20 30 ...)"
-#~ msgstr "Puntos de ruptura para la opción de ruptura personalizada. Separar valores por espacios (0 10 20 30...)"
-#, fuzzy
-#~ msgid "Color scheme for graduated color mapping (select 'single_color' for graduated point/line display)"
-#~ msgstr "Esquema de colores para mapas en gradiente de color (seleccionar 'single_color' para mostrar gradiente de puntos/líneas)"
-#, fuzzy
-#~ msgid "Color for graduated points map (grass named color or R:G:B triplet). Set color scheme to single color."
-#~ msgstr "Color para mapa de gradiente de líneas o puntos/bordes de área (nombre de color de grass o triplete R:G:B). Establecer esquema de color a un color."
-#, fuzzy
-#~ msgid "Beginning color for custom color gradient. Must be expressed as R:G:B triplet."
-#~ msgstr "Color inicial para gradiente de color personalizado. Se debe expresar como triplete R:G:B."
-#, fuzzy
-#~ msgid "Ending color for custom color gradient. Must be expressed as R:G:B triplet"
-#~ msgstr "Color final para gradiente de color personalizado. Se debe expresar como triplete R:G:B."
-#, fuzzy
-#~ msgid "Root for the name of psmap instruction files to be in current directory (if not set, no psmap instruction files will be created)"
-#~ msgstr "Raíz para el nombre de los archivos de instrucciones psmap para estar en el directorio actual ((si no se indica, no se creará ningún archivo de instrucciones psmap)"
-#, fuzzy
-#~ msgid "raster input maps"
-#~ msgstr "Mapa ráster de entrada"
-#~ msgid "Cannot open database %s by driver %s"
-#~ msgstr "No se puede abrir la base de datos %s por el controlador %s"
-#~ msgid "Cannot select attributes: %s"
-#~ msgstr "No se pueden seleccionar los atributos: %s"
-#~ msgid "Background color, either a standard GRASS color, R:G:B triplet, or \"none\""
-#~ msgstr "Color de fondo: color estándar de GRASS, triplete R:G:B o \"ninguno\""
-#~ msgid "Removing %s <%s>"
-#~ msgstr "Eliminando %s <%s>"
-#~ msgid "couldn't be removed"
-#~ msgstr "no se pudo eliminar"
-#~ msgid "%s: couldn't be removed"
-#~ msgstr "%s: no se pudo eliminar"
-#~ msgid "<%s> nothing removed"
-#~ msgstr "<%s> nada eliminado"
-#~ msgid "Output inverse raster map after IFFT"
-#~ msgstr "Producir mapa ráster inverso después de IFFT"
-#~ msgid "Power 2 values : [%d] rows [%d] columns."
-#~ msgstr "Power 2 valores : [%d] filas [%d] columnas."
-#~ msgid "Reading the raster maps..."
-#~ msgstr "Leyendo los mapas ráster..."
-#~ msgid "Rotating data arrays..."
-#~ msgstr "Rotando el conjunto de datos..."
-#~ msgid "Inverse FFT completed..."
-#~ msgstr "Transformación inversa FFT completada..."
-#~ msgid "Unable to open output file."
-#~ msgstr "No fue posible abrir el archivo de salida"
-#~ msgid "Transform successful."
-#~ msgstr "Transformación exitosa."
-#~ msgid "Hue-intensity-saturation (his) to red-green-blue (rgb) raster map color transformation function."
-#~ msgstr "Función de transformación de color de mapa ráster de matiz-intensidad- saturación (HIS) a rojo-verde-azul (RGB)."
-#~ msgid "Hue map name"
-#~ msgstr "Nombre de mapa de matiz"
-#~ msgid "Intensity map name"
-#~ msgstr "Nombre de mapa de intensidad"
-#~ msgid "Saturation map name"
-#~ msgstr "Nombre de mapa de saturación"
-#~ msgid "Output map representing the red"
-#~ msgstr "Mapa de salida para el rojo"
-#~ msgid "Output map representing the green"
-#~ msgstr "Mapa de salida para el verde"
-#~ msgid "Output map representing the blue"
-#~ msgstr "Mapa de salida para el azul"
-#~ msgid "Cannot read row from raster map"
-#~ msgstr "No se puede leer la fila del mapa ráster"
-#~ msgid "Cannot write row to raster map"
-#~ msgstr "No se puede escribir la fila en el mapa ráster"
-#~ msgid "Red-green-blue (rgb) to hue-intensity-saturation (his) raster map color transformation function"
-#~ msgstr "Función de transformación de color de mapa ráster de rojo-verde-azul (RGB) a matiz-intensidad-saturación (HIS)"
-#~ msgid "Red input raster map"
-#~ msgstr "Mapa ráster de entrada rojo"
-#~ msgid "Green input raster map"
-#~ msgstr "Mapa ráster de entrada verde"
-#~ msgid "Blue input raster map"
-#~ msgstr "Mapa ráster de entrada azul"
-#~ msgid "Output intensity raster map"
-#~ msgstr "Mapa ráster de salida de intensidad"
-#~ msgid "pyramid constructed."
-#~ msgstr "pirámide construida."
-#~ msgid ""
-#~ "\n"
-#~ "Resolution = %d; period = %d"
-#~ msgstr ""
-#~ "\n"
-#~ "Resolución = %d; periodo = %d"
-#~ msgid "Class transition statistics."
-#~ msgstr "Estadística de transición de clases."
-#~ msgid "Transition probabilities: %f %f %f; %f"
-#~ msgstr "Probabilidades de transición: %f %f %f; %f"
-#~ msgid "get_img: out of memory."
-#~ msgstr "get_img: sin memoria"
-#~ msgid "Writing [%s] ..."
-#~ msgstr "Escribiendo [%s] ..."
-#, fuzzy
-#~ msgid "Name of imagery signaturefile"
-#~ msgstr "archivo de firma de imagen"
-#~ msgid "Run quietly"
-#~ msgstr "Ejecutar en modo silencioso"
-#~ msgid "Group [%s] not found."
-#~ msgstr "Grupo [%s] no encontrado."
-#~ msgid "Subgroup [%s] not found."
-#~ msgstr "Subgrupo [%s] no encontrado."
-#~ msgid "Signature file [%s] is missing or not readable."
-#~ msgstr "Falta el archivo de firma [%s] o no es legible."
-#~ msgid "Calculating eigenvalues and eigenvectors..."
-#~ msgstr "Calculando los valores propios (eigenvalues) y eigenvectors..."
-#~ msgid "Ordering eigenvalues in descending order..."
-#~ msgstr "Organizando los valores propios en orden descendente..."
-#~ msgid "Cannot write color table of raster map <%s>"
-#~ msgstr "No se puede escribir la tabla de colores de mapa ráster <%s>"
-#~ msgid "Calculating class mean ..."
-#~ msgstr "Calculando media de clase ..."
-#~ msgid "Calculating class covariance matrix..."
-#~ msgstr "Calculando matriz de covarianza de clase..."
-#~ msgid "Imagery group"
-#~ msgstr "Grupo de imaginería"
-#~ msgid "Subgroup containing image files"
-#~ msgstr "Subgrupo que contiene archivos de imagen"
-#~ msgid "Resultant signature file"
-#~ msgstr "Archivo de firma resultante"
-#~ msgid "%d classes."
-#~ msgstr "%d clases."
-#~ msgid "Range of values in output display files"
-#~ msgstr "Rango de valores en los archivos de visualización de salida"
-#~ msgid "Initializing data...\n"
-#~ msgstr "Inicializando datos...\n"
-#~ msgid "Reading the raster map..."
-#~ msgstr "Leyendo el mapa ráster..."
-#~ msgid "FFT completed..."
-#~ msgstr "FFT completada..."
-#~ msgid "subgroup <%s> not found"
-#~ msgstr "subgrupo <%s> no encontrado"
-#~ msgid "Unable to proceed"
-#~ msgstr "No se puede proceder"
-#, fuzzy
-#~ msgid "Can't read signature file <%s>"
-#~ msgstr "No fue posible leer el archivo de firma [%s]"
-#~ msgid "Group of imagery files to be clustered"
-#~ msgstr "Grupo de archivos de imaginería a clusterizar"
-#~ msgid "Subgroup name in the above group"
-#~ msgstr "Nombre de subgrupo en el grupo de arriba"
-#~ msgid "Can't creat reportfile: "
-#~ msgstr "No se puede crear el informe: "
-#~ msgid "Reading image ... "
-#~ msgstr "Leyendo imagen ... "
-#~ msgid "Creates control points on an image to be ortho-rectified."
-#~ msgstr "Crea puntos de control en una imagen para su orto-rectificación."
-#~ msgid "Unable to read head of %s"
-#~ msgstr "No se puede leer la cabecera de %s"
-#~ msgid "Menu driver for the photo imagery programs."
-#~ msgstr "Controlador de menús para los programas de imaginería."
-#~ msgid "Name of imagery group for ortho-rectification"
-#~ msgstr "Nombre del grupo de imágenes para ortorrectificación"
-#, fuzzy
-#~ msgid "Unable to write temp file: %s"
-#~ msgstr "No se puede escribir en el archivo"
-#, fuzzy
-#~ msgid "Unable to open map %s"
-#, fuzzy
-#~ msgid "Unable to write row %d"
-#~ msgid "group=[%s] - not found."
-#~ msgstr "no se encuentra el grupo=[%s]"
-#~ msgid "subgroup=[%s] (of group [%s]) - not found."
-#~ msgstr "no se encuentra el subgrupo=[%s] (del grupo.[%s])"
-#~ msgid "Can't read signature file [%s]."
-#~ msgid "[%s] has more than 255 signatures."
-#~ msgstr "[%s] tiene más de 255 firmas"
-#~ msgid "Unable to create reject layer [%s]."
-#~ msgstr "No fue posible crear la capa de rechazo [%s]."
-#~ msgid "Imagery group to be classified"
-#~ msgstr "Grupo imaginario para clasificar"
-#~ msgid "Subgroup containing image files to be classified"
-#~ msgstr "Subgrupo que contiene archivos de imagen por clasificar"
-#~ msgid "Signatures to use for classification"
-#~ msgstr "Firmas para clasificar"
-#~ msgid "Raster map to hold classification results"
-#~ msgstr "Mapa ráster que recoge los resultados de la clasificación"
-#~ msgid "sensor: LANDSAT"
-#~ msgstr "sensor: LANDSAT"
-#~ msgid "sensor: QuickBird"
-#~ msgstr "sensor: QuickBird"
-#~ msgid "sensor: SPOT"
-#~ msgstr "sensor: SPOT"
-#~ msgid "1st map for mosaic (top of image stack)."
-#~ msgstr "Primer mapa para mosaico (superior de la pila de imágenes)."
-#~ msgid "3rd map for mosaic."
-#~ msgstr "Tercer mapa para mosaico."
-#~ msgid "4th map for mosaic."
-#~ msgstr "Cuarto mapa para mosaico."
-#~ msgid "Verbose mode (print projection parameters and filenames to stderr)"
-#~ msgstr "Modo verboso (imprimir parámetros de proyección y nombres de archivo a stderr)"
-#~ msgid "run non-interactively"
-#~ msgstr "ejecutar de forma no interactiva"
-#~ msgid "Run non-interactively"
-#~ msgstr "Ejecutar de forma no interactiva"
-#~ msgid "GIS manager for GRASS"
-#~ msgstr "Administrador GIS de GRASS"
-#~ msgid "Name of GIS manager settings file (.grc)"
-#~ msgstr "Nombre del archivo de preferencias del Administrador GIS (.grc)"
-#~ msgid "Unable to open raster map <%s> in mapset <%s>"
-#~ msgstr "No se puede abrir el mapa ráster <%s> en el directorio de mapas <%s>"
-#~ msgid "ERROR: Problem opening output file."
-#~ msgstr "ERROR: problema al abrir el archivo de salida."
-#~ msgid "Name of fractal surface raster layer"
-#~ msgstr "Nombre de capa ráster de superficie fractal"
-#~ msgid "Steps=%d"
-#~ msgstr "Pasos=%d"
-#~ msgid "Sums up the raster cell values."
-#~ msgstr "Totaliza los valores de las celdas ráster."
-#~ msgid "Name of incidence or density file."
-#~ msgstr "Nombre del archivo de incidencia o de densidad."
-#~ msgid "Creates explicitly the NULL-value bitmap file."
-#~ msgstr "Crea de forma explícita el archivo de mapa de bits de valor NULO."
-#~ msgid "Finds the average of values in a cover map within areas assigned the same category value in a user-specified base map."
-#~ msgstr "Encuentra la media de los valores en un mapa de cobertura dentro de áreas  con el mismo valor de categoría asignado en un mapa de base especificado por el usuario."
-#~ msgid "%s: ERROR running %s command"
-#~ msgstr "%s: ERROR al ejecutar el comando %s"
-#~ msgid "Creation option to the output format driver. Multiple options may be listed."
-#~ msgstr "Opción de creación para el controlador de formato de salida. Se pueden listar múltiples opciones."
-#~ msgid "Metadata key passed on the output dataset if possible"
-#~ msgstr "Clave de metadatos pasados al conjunto de datos de salida si es posible"
-#, fuzzy
-#~ msgid "Density of output walkers"
-#~ msgstr "Densidad de los walkers de salida"
-#~ msgid "File [%s] not found"
-#~ msgstr "Archivo [%s] no encontrado"
-#~ msgid "Unable to open file [%s]"
-#~ msgstr "No se puede abrir el archivo [%s]"
-#~ msgid "Failed to guess file format"
-#~ msgstr "No se pudo averiguar el formato de archivo"
-#~ msgid "Reading sites map (%s) ..."
-#~ msgstr "Leyendo mapa de lugares (%s) ..."
-#~ msgid "You are not outputting any raster or vector points maps"
-#~ msgstr "No está produciendo ningún mapa ráster o vectorial de puntos"
-#~ msgid "%s=%s - illegal value"
-#~ msgstr "%s=%s - valor no admitido"
-#~ msgid "Unable to read current region parameters"
-#~ msgstr "No se pueden leer los parámetros de la región actual"
-#~ msgid "Unable to get current region"
-#~ msgstr "No se puede obtener la región actual"
-#~ msgid "Cannot open cover raster map <%s>"
-#~ msgstr "No se puede abrir el mapa ráster de cobertura <%s>"
-#~ msgid "Cannot open database <%s> by driver <%s>"
-#~ msgstr "El controlador <%s> no puede abrir la Base de Datos <%s>"
-#~ msgid "Finds the median of values in a cover map within areas assigned the same category value in a user-specified base map."
-#~ msgstr "Encuentra los valores medios en un mapa de cobertura dentro de áreas con el mismo valor de categoría asignado en un mapa base especificado por el usuario."
-#~ msgid "Unable to read category labels of raster map <%s>"
-#~ msgstr "No se puedenleer las etiquetas de categoría del mapa ráster <%s>"
-#~ msgid "%s - unable to remove color table"
-#~ msgstr "%s - no se puede eliminar la tabla de colores"
-#~ msgid "%s - color table not found"
-#~ msgstr "%s - tabla de colores no encontrada"
-#~ msgid "Can't make logarithmic color table for floating point map"
-#~ msgstr "No se puede hacer tabla de colores logarítmica para mapas de coma flotante"
-#~ msgid ""
-#~ "%s: saving [%s] raster map layer.\n"
-#~ "Percent complete:"
-#~ msgstr ""
-#~ "%s: guardando capa de mapa ráster [%s].\n"
-#~ "Porcentaje hecho:"
-#~ msgid "Starting map [%s]"
-#~ msgstr "Mapa de inicio [%s]"
-#~ msgid "Starting filter #%d, distance: %.*lf, exponent: %.*lf, flat: %.*lf"
-#~ msgstr "Filtro inicial #%d, distancia: %.*lf, exponencial: %.*lf, llano: %.*lff"
-#~ msgid "Percent done:"
-#~ msgstr "Porcentaje hecho:"
-#~ msgid "Unable to read current window parameters"
-#~ msgstr "No se pueden leer los parámetros de la ventana actual"
-#~ msgid "Unable to properly read input raster map"
-#~ msgstr "No se puede leer adecuadamente el mapa ráster de entrada"
-#~ msgid "Unable to properly write output raster map"
-#~ msgstr "No se puede escribir adecuadamente el mapa ráster de salida"
-#~ msgid "SECTION %d beginning: Closing Maps."
-#~ msgstr "Comenzando la SECCIÓN %d: cerrando mapas."
-#~ msgid "SECTION %d beginning: Watershed determination."
-#~ msgstr "Comenzando la SECCIÓN %d: determinación de cuenca hidrográfica."
-#~ msgid "problem w/ astar algorithm"
-#~ msgstr "problema con algoritmo astar."
-#~ msgid "Total levels: %4d"
-#~ msgstr "Niveles totales: %4d"
-#~ msgid "Reading data: "
-#~ msgstr "Leyendo datos: "
-#~ msgid "Rowio_setup failed"
-#~ msgstr "Falló rowio_setup"
-#~ msgid "Rowio_get failed"
-#~ msgstr "Falló rowio_get"
-#~ msgid "Name of raster map layer to be used for <%s>"
-#~ msgstr "Nombre de capa de mapa ráster a usar para <%s>"
-#~ msgid "Elevation map not found"
-#~ msgstr "Mapa de elevación no encontrado"
-#, fuzzy
-#~ msgid "%d points converted to centroids"
-#~ msgstr "[%d] puntos leídos en memoria"
-#, fuzzy
-#~ msgid "%d centroids converted to points"
-#~ msgstr "[%d] centroides escritos en el fichero de salida."
-#, fuzzy
-#~ msgid "%d lines converted to boundaries"
-#~ msgstr "%d líneas / contornos eliminados"
-#, fuzzy
-#~ msgid "%d boundaries converted to lines"
-#~ msgstr "Cambiar de contornos a líneas:"
-#~ msgid "CrossCorrelation: %d points read in region.\n"
-#~ msgstr "Correlación cruzada: %d puntos leídos en la región.\n"
-#~ msgid "CrossCorrelation: Cannot read field info"
-#~ msgstr "Correlación cruzada: no se puede leer la información del campo"
-#~ msgid "CrossCorrelation: Cannot open database %s by driver %s"
-#~ msgstr "Correlación cruzada: no se puede abrir la base de datos %s por el controlador %s"
-#~ msgid "CrossCorrelation: Column type not supported"
-#~ msgstr "Correlación cruzada: tipo de columna no soportado"
-#~ msgid "CrossCorrelation: Cannot select data from table"
-#~ msgstr "Correlación cruzada: no se pueden seleccionar datos de la tabla"
-#~ msgid "CrossCorrelation: %d records selected from table"
-#~ msgstr "Correlación cruzada: %d registros seleccionados de la tabla"
-#~ msgid "CrossCorrelation: No record for point (cat = %d)"
-#~ msgstr "Correlación cruzada: ningún registro para el punto (cat = %d)"
-#~ msgid "CrossCorrelation: Mean = %.5lf\n"
-#~ msgstr "Correlación cruzada: media = %.5lf\n"
-#~ msgid "CrossCorrelation: lambda_i = %.3f\n"
-#~ msgstr "Correlación cruzada: lambda_i = %.3f\n"
-#~ msgid ""
-#~ "\n"
-#~ "Results are over.\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Los resultado están terminados.\n"
-#~ msgid "From type"
-#~ msgstr "Desde el tipo"
-#~ msgid "From layer"
-#~ msgstr "Desde la capa"
-#, fuzzy
-#~ msgid "Select type"
-#~ msgstr "Tipo de archivo"
-#, fuzzy
-#~ msgid "Cannot select records from database"
-#~ msgstr "Imposible seleccionar datos de la tabla"
-#, fuzzy
-#~ msgid "Cannot fetch data"
-#~ msgstr "No se puede recuperar la fila"
-#~ msgid "Calculating costs from centres..."
-#~ msgstr "Calculando costes desde centros..."
-#~ msgid "Region restored to original extent."
-#~ msgstr "Región restaurada a la extensión original."
-#~ msgid "vector, editing, digitization"
-#~ msgstr "vectorial, edición, digitalización"
-#~ msgid "Interactive editing and digitization of vector maps."
-#~ msgstr "Edición interactiva y digitalización de mapas vectoriales."
-#~ msgid "Create new file if it does not exist."
-#~ msgstr "Crear el archivo si no existe."
-#~ msgid "New empty map created."
-#~ msgstr "Nuevo mapa vacío creado."
-#~ msgid "Map <%s> does not exist in current mapset. Add flag -n to create a new map."
-#~ msgstr "El mapa <%s> no existe en el directorio de mapas actual. Añada el opción -n para crear un nuevo mapa."
-#, fuzzy
-#~ msgid "Feature id(s)"
-#~ msgstr "Elementos"
-#~ msgid "Input vector was not found."
-#~ msgstr "Vector de entrada no ha sido especificado."
-#~ msgid "Cannot open dig_cats file."
-#~ msgstr "No fue posible encontrar el archivo dig_cats."
-#~ msgid "Cannot open database %s"
-#~ msgstr "No se puede abrir la base de datos %s"
-#~ msgid "Cannot insert into table: %s"
-#~ msgstr "No se puede insertar en la tabla: %s"
-#~ msgid "%s: Unable to read font definition file; use the default"
-#~ msgstr "%s: no se puede leer el archivo de definición de fuentes; se usa el predeterminado"
-#~ msgid "%s: No font definition file"
-#~ msgstr "%s: ningún archivo de definición de fuentes"
-#~ msgid "Removed vertices: %5d"
-#~ msgstr "Vértices eliminados %5d"
-#, fuzzy
-#~ msgid "Removed vertices"
-#~ msgid "Arc layer (network)"
-#~ msgstr "Capa de arco (red)"
-#~ msgid "Node layer (points)"
-#~ msgstr "Capa de nodos (puntos)"
-#, fuzzy
-#~ msgid "Query layer (used by 'query' option)"
-#~ msgstr "Capa de consulta. Usado por la opción 'query'."
-#~ msgid "%d categories read from map"
-#~ msgstr "%d categorías leídas del mapa"
-#~ msgid ""
-#~ "Operator defines required relation between features. A feature is written to output if the result of operation 'ainput operator binput' is true. An input feature is considered to be true, if category of given layer is defined.\n"
-#~ "\t overlap: features partially or completely overlap"
-#~ msgstr ""
-#~ "El operador defina la relación requerida entre los elementos. El elemento A se escribe en la salida si el resultado de la operación 'entrada A operador entrada B' es verdadero. Un elemento de entrada se considera verdadero si se define la categoría de la capa dada.\n"
-#~ "\t solapamiento: los elementos solapan parcial o completamente"
-#~ msgid "Processing ainput lines ..."
-#~ msgstr "Procesando líneas de la entrada A..."
-#, fuzzy
-#~ msgid "Current region does not include the entire input vector map <%s>"
-#~ msgstr "%d categorías con más de un elemento en el mapa vectorial <%s>"
-#~ msgid "Unable to read raster row"
-#~ msgstr "No se puede leer la fila ráster"
-#~ msgid ""
-#~ "Optional where condition (without WHERE key word), e.g.:\n"
-#~ "\t\tobec = 'Liptakov'"
-#~ msgstr ""
-#~ "Condición opcional dónde (sin la palabra clave WHERE), ej.:\n"
-#~ msgid "Illegal output file name"
-#~ msgstr "Nombre de archivo de salida no admitido"
-#~ msgid "Selects/starts specified monitor at specified size"
-#~ msgstr "Selecciona/lanza un monitor determinado al tamaño especificado"
-#~ msgid "Width in pixels of new display monitor"
-#~ msgstr "Anchura en pixels del nuevo monitor"
-#~ msgid "Height in pixels of new display monitor"
-#~ msgstr "Altura en pixels del nuevo monitor"
-#~ msgid "Moves displayed maps to another monitor"
-#~ msgstr "Mueve los mapas que se muestran a otro monitor"
-#~ msgid "clear target monitor before moving"
-#~ msgstr "borra el monitor de destino antes de moverlos"
-#~ msgid "stay with source monitor"
-#~ msgstr "permanecer en el monitor orginal"
-#~ msgid "kill source monitor after moving"
-#~ msgstr "eliminar el monitor original después de moverlo"
-#~ msgid "Target monitor"
-#~ msgstr "Monitor de destino"
-#~ msgid "Source monitor"
-#~ msgstr "Monitor de origen"
-#~ msgid "Export display monitor to a GpsDrive compatible backdrop image"
-#~ msgstr "Exporta el monitor visible a una imagen de fondo compatible con GpsDrive"
-#~ msgid "display, export, GPS"
-#~ msgstr "muestra, exporta, GPS"
-#~ msgid "Make JPEG instead of PNG image"
-#~ msgstr "Crea una imagen JPG en lugar de PNG"
-#~ msgid "Saves the contents of the active display monitor to a graphics file."
-#~ msgstr "Guarda el contenido del monitor activo en un fichero gráfico."
-#~ msgid "display, export"
-#~ msgstr "muestra, exporta"
-#~ msgid "Name for output file (do NOT add extension)"
-#~ msgstr "Nombre para el archivo de salida (NO añadir extensión)"
-#~ msgid "Dimensions of output file versus current window size"
-#~ msgstr "Dimensiones de archivo de salida versus tamaño de la ventana actual"
-#~ msgid "(same=1, double size=2, quadruple size=4)"
-#~ msgstr "(igual=1, doble tamaño=2, cuádruple tamaño=4)"
-#~ msgid "Width and height of output image (overrides resolution setting)"
-#~ msgstr "Anchura y altura de la imagen de salida (ignora la configuración de resolución)"
-#~ msgid "(0=none, 1=fastest, 9=most; lossless, only time vs. filesize)"
-#~ msgstr "(0=ninguna, 1=la más rápida, 9=máxima; sin pérdida, sólo tiempo vs. tamaño de archivo)"
-#~ msgid "File size/quality for JPEG files"
-#~ msgstr "Tamaño/calidad de archivo para archivos JPEG"
-#~ msgid "(10=smallest/worst, 100=largest/best)"
-#~ msgstr "(10=el más pequeño/peor, 100=el más grande/mejor)"
-#~ msgid "Paper size for PostScript output"
-#~ msgstr "Tamaño de papel para salida PostScript"
-#~ msgid "PostScript level (only limits functionality!)"
-#~ msgstr "Nivel PostScript (¡sólo limita la funcinalidad!)"
-#~ msgid "Set background color to black (white default)"
-#~ msgstr "Ajustar el color de fondo a negro (blanco por omisión)"
-#~ msgid "Set transparent background"
-#~ msgstr "Establecer fondo transparente"
-#~ msgid "Use the Cario driver to render images"
-#~ msgstr "Usar el controlador Cairo para representar las imágenes"
-#~ msgid "Set paper orientation to landscape (for PostScript output)"
-#~ msgstr "Establecer la orientación del papel a horizontal (para salida PostScript)"
-#~ msgid "Redraws the current display frame in the GRASS monitor"
-#~ msgstr "Vuelve a dibujar el marco activo en el monitor GRASS"
-#~ msgid "Redraw all frames"
-#~ msgstr "Redibujar todos los marcos"
-#~ msgid "Do not preserve individual regions when redrawing all frames"
-#~ msgstr "No preservar regiones individuales cuando se redibujan todos los marcos"
-#~ msgid "Resizes active display monitor"
-#~ msgstr "Modifica el tamaño del monitor activo"
-#~ msgid "New width for window"
-#~ msgstr "Nueva anchura de ventana"
-#~ msgid "New height for window"
-#~ msgstr "Nueva altura de ventana"
-#~ msgid "Slide show of GRASS raster/vector maps."
-#~ msgstr "Presentación de mapas ráster/vectoriales de GRASS."
-#~ msgid "display, slideshow"
-#~ msgstr "muestra, presentación"
-#~ msgid "Show vector maps rather than raster maps"
-#~ msgstr "Muestra mapas vectoriales en vez de mapas ráster"
-#~ msgid "Map prefix. Specify character(s) to view selected maps only"
-#~ msgstr "Prefijo de mapa. Especificar carácter(es) para ver sólo los mapas seleccionados"
-#~ msgid "Mapsets to use. Specify multiple mapsets comma separated"
-#~ msgstr "Directorio de mapas a usar. Especificar múltiples directorios separados por comas"
-#~ msgid "Number of seconds to pause between slides"
-#~ msgstr "Número de segundos de pausa entre diapositivas"
-#~ msgid "Split the display into subframes."
-#~ msgstr "Introducir mapa ráster a mostrar en el primer marco"
-#~ msgid "Number of subframes"
-#~ msgstr "Número de subventanas"
-#~ msgid "Vector map to display thematically"
-#~ msgstr "Mapa vectorial a mostrar temáticamente"
-#~ msgid "Vector map type"
-#~ msgstr "Tipo de mapa vectorial"
-#~ msgid "Layer to use for thematic display"
-#~ msgstr "Capa a usar para visualización temática"
-#~ msgid "Icon size for point data (minimum icon size/line width for graduated points/lines)"
-#~ msgstr "Tamaño de icono para datos de puntos (tamaño de icono mínimo/anchura de línea para gradiente de puntos/líneas)"
-#~ msgid "Color for graduated lines or point/area outlines (grass named color or R:G:B triplet). Set color scheme to single color."
-#, fuzzy
-#~ msgid "Lists data files using basic regular expressions and wildcards."
-#~ msgstr "Aplicar expressiones regulares y comodines a g.list"
-#~ msgid "Mapset(s) to list (default: current mapset search path)"
-#~ msgstr "Directorio(s) de mapas a listar (por omisión: ruta de búsqueda en el directorio actual)"
-#~ msgid "Output separator (default: newline)"
-#~ msgstr "Separador de la salida (por omisión: nueva línea)"
-#, fuzzy
-#~ msgid "Removes data files using basic regular expressions and wildcards."
-#~ msgid "3d raster to remove"
-#~ msgstr "Ráster 3D a eliminar"
-#~ msgid "Vector to remove"
-#~ msgstr "Vectorial a eliminar"
-#~ msgid "Region to remove"
-#~ msgstr "Región a eliminar"
-#~ msgid "Label to remove"
-#~ msgstr "Etiqueta a eliminar"
-#~ msgid "3dview to remove"
-#~ msgstr "Vista 3D a eliminar"
-#~ msgid "Group to remove"
-#~ msgstr "Grupo a eliminar"
-#~ msgid "Use image list and not group"
-#~ msgstr "Usar lista de imágenes y no grupo"
-#~ msgid "Select multiple points"
-#~ msgstr "Seleccionar múltiples puntos"
-#~ msgid "Calculate new raster map from a r.mapcalc expression."
-#~ msgstr "Calcular un nuevo mapa ráster a partir de una expresión r.mapcalc."
-#~ msgid "A"
-#~ msgstr "A"
-#~ msgid "B"
-#~ msgstr "B"
-#~ msgid "E"
-#~ msgstr "E"
-#~ msgid "F"
-#~ msgstr "F"
-#~ msgid "Formula (e.g. A-B or A*C+B)"
-#~ msgstr "Formula (ej. A-B o A*C+B)"
-#~ msgid "Expert mode (enter a set of r.mapcalc expressions)"
-#~ msgstr "Modo avanzado (introducir un conjunto de expressiones de r.mapcalc)"
-#~ msgid "Do not overwrite existing map"
-#~ msgstr "No sobrescribir mapas existentes"
-#~ msgid "Exports GRASS raster into GDAL supported formats."
-#~ msgstr "Exporta un ráster de GRASS a formatos soportados por GDAL."
-#~ msgid "Creation option to the output format driver. Multiple options may be listed"
-#~ msgstr "Opción de creación para el controlador de formato de salida. Se pueden indicar múltiples opciones."
-#~ msgid "Output field seperator"
-#~ msgstr "Separador de campos de salida"
-#~ msgid "Calculates new grid3D volume from r3.mapcalc expression."
-#~ msgstr "Calcula un nuevo volumen grid3D a partir de una expresión r3.mapcalc."
-#~ msgid "A (grid3D file)"
-#~ msgstr "A (archivo grid3D)"
-#~ msgid "B (grid3D file)"
-#~ msgstr "B (archivo grid3D)"
-#~ msgid "C (grid3D file)"
-#~ msgstr "C (archivo grid3D)"
-#~ msgid "D (grid3D file)"
-#~ msgstr "D (archivo grid3D)"
-#~ msgid "E (grid3D file)"
-#~ msgstr "E (archivo grid3D)"
-#~ msgid "F (grid3D file)"
-#~ msgstr "F (archivo grid3D)"
-#~ msgid "Name for output grid3D volume"
-#~ msgstr "Nombre para el volumen grid3D de salida"
-#~ msgid "Expert mode (enter a set of r3.mapcalc expressions)"
-#~ msgstr "Modo experto (introducir un conjunto de expressiones r3.mapcalc)"
-#~ msgid "%s: [%s] not found"
-#~ msgstr "%s: [%s] no encontrado"
-#~ msgid "GIS Coincidence Tabulation Facility\n"
-#~ msgstr "Utilidd de tabulación de coincidencia GIS\n"
-#~ msgid "This utility will allow you to compare the coincidence of two map layers\n"
-#~ msgstr "Esta utilidad le permitirá comparar la coincidencia de dos capas de mapa\n"
-#~ msgid "The report can be made in one of 8 units."
-#~ msgstr "El informe se puede hacer en una de 8 unidades."
-#~ msgid "Please choose a unit by entering one of the following letter codes:"
-#~ msgstr "Por favor, elija una unidad introduciendo uno de los siguientes códigos de letras:"
-#~ msgid "     'c': cells"
-#~ msgstr "     'c': celdas"
-#~ msgid "     'p': percent cover of region"
-#~ msgstr "     'p': porcentaje de cobertura de región"
-#~ msgid "     'x': percent of '%s' category (column)"
-#~ msgstr "     'x': porcentaje de categoría '%s' (columna)"
-#~ msgid "     'y': percent of '%s' category (row)"
-#~ msgstr "     'y': porcentaje de categoría '%s' (fila)"
-#~ msgid "     'a': acres"
-#~ msgstr "     'a': acres"
-#~ msgid "     'h': hectares"
-#~ msgstr "     'h': hectáreas"
-#~ msgid "     'k': square kilometers"
-#~ msgstr "     'k': kilómetros cuadrados"
-#~ msgid "     'm': square miles\n"
-#~ msgstr "     'm': millas cuadradas\n"
-#~ msgid "     'Q': quit"
-#~ msgstr "     'Q': salir"
-#~ msgid "Do you wish to save this report in a file? (y/n) [n] "
-#~ msgstr "¿Desea guardar este informe en un archivo? (y/n) [n] "
-#~ msgid ""
-#~ "Enter the file name or path\n"
-#~ msgstr ""
-#~ "Introduzca el nombre o ruta del archivo\n"
-#~ msgid "'%s' being saved\n"
-#~ msgstr "Guardando '%s?\n"
-#~ msgid "Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
-#~ msgstr "¿Desea imprimir este informe (requiere el comando Unix lpr)? (y/n) [n] "
-#~ msgid ""
-#~ "Do you wish it printed in 80 or 132 columns?\n"
-#~ msgstr ""
-#~ "¿Desea imprimirlo a 80 ó 132 columnas?\n"
-#~ msgid "Do you wish to run this report with a different unit of measure? (y/n) [y] "
-#~ msgstr "¿Desea ejecutar este informe con una unidad de medida diferente? (y/n) [y] "
-#~ msgid "Interactively select End-Points"
-#~ msgstr "Seleccionar puntos finales de forma interactiva"
-#~ msgid "Use mouse to select Start Point\n"
-#~ msgstr "Usar el ratón para seleccionar el Punto de Inicio\n"
-#~ msgid ""
-#~ "\n"
-#~ "Use mouse to draw profile line\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Usar el ratón para dibujar la línea de perfil\n"
-#~ msgid "Buttons:\n"
-#~ msgstr "Botones:\n"
-#~ msgid "Left:   Mark next point\n"
-#~ msgstr "Izquierda: marcar siguiente punto\n"
-#~ msgid "Middle: Mark next point\n"
-#~ msgstr "Centro: marcar siguiente punto\n"
-#~ msgid ""
-#~ "Right:  Finish profile and exit\n"
-#~ "\n"
-#~ msgstr ""
-#~ "Derecha: finalizar perfil y salir\n"
-#~ "\n"
-#~ msgid "elevin raster map <%s> not found"
-#~ msgstr "No se encuentra el mapa ráster de elevación de entada <%s>"
-#~ msgid "aspin raster map <%s> not found"
-#~ msgstr "No se encuentra el mapa ráster de orientación de entada <%s>"
-#~ msgid "slopein raster map <%s> not found"
-#~ msgstr "No se encuentra el mapa ráster de pendiente de entada <%s>"
-#~ msgid "linkein raster map <%s> not found"
-#~ msgstr "No se encuentra el mapa ráster de coeficiente de turbidez atmosférica de Linke de entada <%s>"
-#~ msgid "albedo raster map <%s> not found"
-#~ msgstr "No se encuentra el mapa ráster de entada de coeficiente albedo del terreno <%s>"
-#~ msgid "coefbh raster map <%s> not found"
-#~ msgstr "No se encuentra el mapa ráster coefbh <%s>"
-#~ msgid "coefdh raster map <%s> not found"
-#~ msgstr "No se encuentra el mapa ráster coefdh <%s>"
-#~ msgid "Unable to find data map"
-#~ msgstr "No se puede encontrar el mapa de datos"
-#, fuzzy
-#~ msgid "Unable to find clump map"
-#~ msgstr "No se puede abrir el archivo <%s>"
-#~ msgid "%s: cover raster map not found"
-#~ msgstr "%s: mapa ráster de cobetura no encontrado"
-#~ msgid "%s: base map and output map must be different"
-#~ msgstr "%s: los mapas de base y de salida deben ser diferentes"
-#~ msgid "%s: Error reading from raster map <%s> in mapset <%s>"
-#~ msgstr "%s: error al leer del mapa ráster <%s> en el directorio de mapas <%s>"
-#~ msgid "Illegal output file name <%s>"
-#~ msgstr "Nombre de archivo de salida <%s> no admitido"
-#~ msgid "Base raster map <%s> not found"
-#~ msgstr "No se encuentra el mapa ráster de base <%s>"
-#~ msgid "Base map and output map <%s> must be different"
-#~ msgstr "El mapa de base y de salida <%s> deben ser diferentes"
-#~ msgid "Not enough memory for zero_array_cell"
-#~ msgstr "Memoria insuficiente para zero_array_cell"
-#~ msgid "Not enough disk space -- cannot write files"
-#~ msgstr "Espacio en disco insuficiente -- no se pueden escribir archivos"
-#~ msgid "Enter rules interactively"
-#~ msgstr "Introducir reglas de forma interactiva"
-#~ msgid "Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" options"
-#~ msgstr "El modo interactivo es incompatible con las opciones \"color\", \"reglas\" y \"raster\""
-#~ msgid "RGB raster map <%s> not found"
-#~ msgstr "No se encuentra el mapa ráster RGB <%s>"
-#~ msgid "Cannot create RGB data, please provide three maps [r,g,b]"
-#~ msgstr "No se pueden crear los datos RGB. Por favor proporciones tres mapas [R,G,B]"
-#~ msgid "Vector cell map <%s> not found"
-#~ msgstr "No se encuentra el mapa de celdas vectorial <%s>"
-#~ msgid "Cannot create vector data, please provide three maps [x,y,z]"
-#~ msgstr "No se pueden crear los datos del vectorial. Por favor proporcione tres mapas [X,Y,Z]"
-#~ msgid "Which raster map needs a color table"
-#~ msgstr "Qué mapa ráster necesita una tabla de color"
-#~ msgid "Color table for <%s> updated"
-#~ msgstr "Tabla de color para <%s> actualizada"
-#~ msgid "Edit header for [%s]\n"
-#~ msgstr "Editar cabecera para [%s]\n"
-#~ msgid "[%s] cannot be found!"
-#~ msgstr "¡No se puede encontrar [%s]!"
-#~ msgid "For what layer shall the header file be edited? "
-#~ msgstr "¿Para qué capa se editará el archivo de cabecera?"
-#~ msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
-#~ msgstr "[%s] es una reclasificación de [%s] - ¡No se puede editar la cabecera! Ejecute support en [%s]."
-#~ msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
-#~ msgstr "[%s] es una reclasificación de [%s en %s] - ¡No se puede editar la cabecera!"
-#~ msgid "Cannot open raster map [%s]!"
-#~ msgstr "¡No se puede abrir el mapa ráster [%s]!"
-#~ msgid "Raster file [%s] is empty."
-#~ msgstr "El archivo ráster [%s] está vacío."
-#~ msgid "Error reading raster map [%s]."
-#~ msgstr "Error al leer el mapa ráster [%s]."
-#~ msgid "cellhd compression: %d\n"
-#~ msgstr "compresión cellhd: %d\n"
-#~ msgid "[%s] appears to be compressed. Is it? "
-#~ msgstr "[%s] parece estar comprimido. ¿Lo está? "
-#~ msgid "Please indicate the type of compression:\n"
-#~ msgstr "Por favor, indique el tipo de compresión:\n"
-#~ msgid "  1. Pre 3.0 compression\n"
-#~ msgstr "  1. Compresión pre 3.0 \n"
-#~ msgid "  2. 3.0 compression\n"
-#~ msgstr "  2. compresión 3.0\n"
-#~ msgid "The header for [%s] says the file is not compressed. "
-#~ msgstr "La cabecera de [%s] dice que el archivo no está comprimido. "
-#~ msgid "The file appears to be compressed.\n"
-#~ msgstr "El fichero parece estar comprimido.\n"
-#~ msgid "Most likely the header is wrong, but I want you to decide.\n"
-#~ msgstr "Con toda probabilidad la cabecera está equivocada, pero debe decidir.\n"
-#~ msgid "The header for [%s] says the file is compressed. "
-#~ msgstr "La cabecera de [%s] dice que el archivo está comprimido. "
-#~ msgid "The file does NOT appear to be compressed.\n"
-#~ msgstr "El archivo NO parece estar comprimido.\n"
-#~ msgid "Header indicates %d row%s in the raster map, but the actual file format indicates %d row%s"
-#~ msgstr "La cabecera indica %d filas%s en el mapa ráster, pero el formato de archivo actual indica %d filas%s"
-#~ msgid "Unable to write header for [%s]."
-#~ msgstr "No se puede escribir la cabecera para [%s]."
-#~ msgid "Header for raster map [%s] updated."
-#~ msgstr "Cabecera para el mapa ráster [%s] actualizada."
-#~ msgid ""
-#~ "\n"
-#~ "hit RETURN to continue -->"
-#~ msgstr ""
-#~ "\n"
-#~ "pulse INTRO para continuar -->"
-#~ msgid "Please enter the following information for [%s]:"
-#~ msgstr "Por favor, introduzca la siguiente información para [%s]:"
-#~ msgid "        Number of rows"
-#~ msgstr "        Número de filas"
-#~ msgid "        Number of cols"
-#~ msgstr "        Número de columnas"
-#~ msgid "        Floating point map"
-#~ msgstr "        Mapa de coma flotante"
-#~ msgid "rows * cols * bytes per cell must be same as file size (%lu)"
-#~ msgstr "filas * columnas * bytes por celda deben ser igual que el tamaño de archivo (%lu)"
-#~ msgid "If you need help figuring them out, just hit ESC"
-#~ msgstr "Si necesita ayuda para averiguarlos, presione ESC"
-#~ msgid "** Negative values not allowed!"
-#~ msgstr "** ¡No se permiten valores negativos!"
-#~ msgid "** Positive values only please!"
-#~ msgstr "** ¡Sólo valores positivos, por favor!"
-#~ msgid "Which raster map needs an updated history? "
-#~ msgstr "¿Qué mapa ráster necesita un histórico actualizado? "
-#~ msgid "Raster file [%s] not found. Exiting."
-#~ msgstr "Archivo ráster <%s> no encontrado. Saliendo."
-#~ msgid "History file for [%s] updated."
-#~ msgstr "Archivo histórico para <%s> actualizado."
-#~ msgid "History file for [%s] not updated."
-#~ msgstr "Archivo histórico para <%s> no actualizado."
-#~ msgid ""
-#~ "\n"
-#~ "Hit RETURN to continue -->"
-#~ msgstr ""
-#~ "\n"
-#~ "Pulse INTRO para continuar -->"
-#~ msgid "Edit header for [%s]? "
-#~ msgstr "¿Editar cabecera de [%s]? "
-#~ msgid ""
-#~ "\n"
-#~ "NOTE: [%s] is a reclass of [%s in %s]"
-#~ msgstr ""
-#~ "\n"
-#~ "NOTA: [%s] es una reclasificación de [%s en %s]"
-#~ msgid "Canceling from edit header."
-#~ msgstr "Cancelando desde la cabecera del editor."
-#~ msgid "Edit the category file for [%s]? "
-#~ msgstr "¿Editar el archivo de categorías para [%s]?"
-#~ msgid "Create/Update the color table for [%s]? "
-#~ msgstr "¿Crear/actualizar tabla de colores para [%s]?"
-#~ msgid "Edit the history file for [%s]? "
-#~ msgstr "¿Editar el archivo histórico de [%s]? "
-#~ msgid ""
-#~ "\n"
-#~ "The null file for [%s] may indicate that some cells contain\n"
-#~ " no data. If the null file for [%s] doesn't exist, zero cells in\n"
-#~ " it are treated by GRASS application programs as no data."
-#~ msgstr ""
-#~ "\n"
-#~ "El archivo de nulos de [%s] puede indicar que algunas celdas no contienen datos\n"
-#~ "Si el archivo de nulos de [%s] no existe, las celdas con valor cero son tratadas por\n"
-#~ " los programas de la aplicación GRASS como sin datos."
-#~ msgid ""
-#~ "\n"
-#~ "Do you want to create/reset the null file for [%s] so that null cell values are considered valid data? "
-#~ msgstr ""
-#~ "\n"
-#~ "¿Quiere crear/restablecer el archivo de nulos de [%s] de forma que los valores de celdas nulas sean considerados datos válidos?"
-#~ msgid ""
-#~ "\n"
-#~ "Do you want to delete the null file for [%s]\n"
-#~ "(all zero cells will then be considered no data)? "
-#~ msgstr ""
-#~ "\n"
-#~ "¿Quiere borrar el archivo de nulos de [%s]?\n"
-#~ "(todas las celdas con cero serán consideradas sin datos)"
-#~ msgid "Which vector map needs updated categories?"
-#~ msgstr "¿Qué mapa vectorial necesita categorías actualizadas?"
-#~ msgid "Which raster map needs updated categories?"
-#~ msgstr "¿Qué mapa ráster necesita categorías actualizadas?"
-#~ msgid "Category file for <%s> not updated"
-#~ msgstr "Archivo de categorías para <%s> no actualizado"
-#~ msgid "Category file for <%s> updated"
-#~ msgstr "Archivo de categorías para <%s> actualizado"
-#~ msgid "Title, in quotes"
-#~ msgstr "Título, entre comillas"
-#~ msgid "Unable to open vector map <%s> in <%s>"
-#~ msgstr "No se puede abrir el mapa vectorial <%s> en <%s>"
-#~ msgid "Unable to find starting vector <%s> "
-#~ msgstr "No se puede encontrar el vector de inicio <%s> "
-#~ msgid "Raster output map <%s> not found (no start_points given)"
-#~ msgstr "No se encuentra el mapa ráster de salida <%s> (no se indican puntos de inicio)"
-#~ msgid "Memory allocation error on reading start points from raster map %s"
-#~ msgstr "Error de asignación de memoria al leer los puntos de inicio del mapa ráster %s"
-#~ msgid "Apply filter only to zero data values"
-#~ msgstr "Aplicar filtro sólo a valores cero de datos"
-#~ msgid "Run verbosly"
-#~ msgstr "Ejecutar de forma verbosa"
-#~ msgid "Run VERBOSELY"
-#~ msgstr "Ejecutar de forma VERBOSA"
-#, fuzzy
-#~ msgid "Layer %d: %s / %s\n"
-#~ msgstr "Capa %d: %s\n"
-#~ msgid "Option <%s>: <%s> exists."
-#~ msgstr "Opción <%s>: <%s> existe."
-#~ msgid "Use '%s' option to change vector map name"
-#~ msgstr "Usar '%s' opción para cambiar el nombre del mapa vectorial"
-#~ msgid "Do not print polyline info"
-#~ msgstr "No imprimir información de polilíneas"
-#~ msgid "Network input map <%s> not found"
-#~ msgstr "Mapa de red de entrada <%s> no encontrado"
-#~ msgid "ask_transform_coor():  Leaving session.. \n"
-#~ msgstr "ask_transform_coord():  Terminado sesión.. \n"
-#~ msgid " Number of points that have been entered: %d\n"
-#~ msgstr "Número de puntos que han sido ingresados: %d\n"
-#~ msgid "Please answer yes or no"
-#~ msgstr "Por favor responda Si o No"
-#~ msgid "Hilight color for text"
-#~ msgstr "Color de resalte para texto"
-#~ msgid "Insufficent memory for allocation of data structure"
-#~ msgstr "Memoria insuficiente para la asignación de la estructura de los datos"
-#~ msgid "name=%s\n"
-#~ msgstr "nombre=%s\n"
-#~ msgid "mapset=%s\n"
-#~ msgstr "directorio de mapas=%s\n"
-#~ msgid "fullname=%s\n"
-#~ msgstr "nombre completo=%s\n"
-#~ msgid "usage: %s file [prompt %%x %%y]\n"
-#~ msgstr "uso: %s archivo [prompt %%x %%y]\n"
-#~ msgid "Illegal file name for real part: %s"
-#~ msgstr "Nombre de archivo no admitido para la parte real: %s"
-#~ msgid "Illegal file name for imaginary part: %s"
-#~ msgstr "Nombre de archivo no admitido para la parte imaginaria: %s"
-#~ msgid "** Can't read signature file <%s> **"
-#~ msgstr "** No se puede leer el archivo de firmas <%s> **"
-#~ msgid ""
-#~ "\n"
-#~ "<%s> -- illegal result signature file name"
-#~ msgstr ""
-#~ "\n"
-#~ "<%s> -- nombre de archivo de firmas resultante no admitido"
-#~ msgid "Illegal group name <%s>"
-#~ msgstr "Nombre de grupo <%s> no admitido"
-#~ msgid "Illegal signature file name <%s>"
-#~ msgstr "Nombre de archivo de firmas <%s> no admitido"
-#~ msgid "Setting map window"
-#~ msgstr "Configurando ventana de mapa"
-#~ msgid "Current window not settable"
-#~ msgstr "La ventana actual no es configurable"
-#~ msgid "Can't clear current graphics window"
-#~ msgstr "No se puede borrar la ventana gráfica actual"
-#~ msgid "Cannot use current window"
-#~ msgstr "No se puede usar la ventana actual"
-#~ msgid "No current frame"
-#~ msgstr "Ningún marco actual"
-#~ msgid "Current frame not available"
-#~ msgstr "Marco actual no disponible"
-#~ msgid "%s: 'is_null_value()' got NULL pointer!"
-#~ msgstr "%s: 'is_null_value()' ¡se obtuvo puntero NULL!"
-#~ msgid "%s: 'is_null_value()' got negative column index"
-#~ msgstr "%s: 'is_null_value()' obtuvo índice de columna negativo"
-#~ msgid "%s: 'is_null_value()' Unknown RASTER_MAP_TYPE '%d'"
-#~ msgstr "%s: 'is_null_value()' Tipo de mapa ráster '%d' desconocido"
-#~ msgid "Error reading raster map"
-#~ msgstr "Error leyendo mapa ráster"
-#~ msgid "Interactive profile plotting utility with optional output."
-#~ msgstr "Utilidad de ploteo de perfil interactivo con salida opcional."
-#~ msgid "Optional display raster"
-#~ msgstr "Ráster de visualización opcional"
-#~ msgid "Output profile data to file(s) with prefix 'name'"
-#~ msgstr "Sacar datos del perfil al archivo(s) con prefijo 'nombre'"
-#~ msgid "Display raster [%s] not found. Using profile raster."
-#~ msgstr "Mostrar ráster[%s] no encontrado. Usando ráster de perfil."
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Use mouse to choose action"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Usar el ratón para elegin acción"
-#, fuzzy
-#~ msgid "Use 'd.frame -e' to remove left over frames"
-#~ msgstr "Usar 'd.frame -e' para eliminar left over frames"
-#~ msgid "Error opening cell-file"
-#~ msgstr "Error al abrir el archivo de celdas"
-#~ msgid "Error reading from cell-file"
-#~ msgstr "Error al leer del archivo de celdas"
-#~ msgid "Mysterious window inconsistancy error"
-#~ msgstr "Error de inconsistencia de ventana misterioso"
-#~ msgid "%s: Couldn't open raster <%s@%s>"
-#~ msgstr "%s: No se pudo abrir el ráster<%s@%s>"
-#~ msgid "one moment ..."
-#~ msgstr "un momento..."
-#~ msgid " Middle: toggle flash color\n"
-#~ msgstr " Centro: fijar color de parpadeo\n"
-#~ msgid "Enable flashing (slower)"
-#~ msgstr "Habilitar flashing (más lento)"
-#~ msgid "No raster map exists in current window"
-#~ msgstr "No existe ningún mapa ráster en la ventana actual"
-#~ msgid "No current window"
-#~ msgstr "Ninguna ventana actual"
-#~ msgid "Current window not available"
-#~ msgstr "La ventana actual no está disponible"
-#~ msgid "Getting screen window"
-#~ msgstr "Obteniendo ventana de la pantalla"
-#~ msgid "No current graphics window"
-#~ msgstr "Ninguna ventana de gráficos actual"
-#~ msgid "Current graphics window not available"
-#~ msgstr "Ventana de gráficos actual no disponible"
-#~ msgid "Setting graphics window"
-#~ msgstr "Configurando la ventana de gráficos"
-#~ msgid "Can't set current graphics window"
-#~ msgstr "No se puede configurar la ventana de gráficos actual"
-#~ msgid "Getting graphics window coordinates"
-#~ msgstr "Obteniendo coordenadas de la ventana de gráficos"
-#~ msgid "Font name or pathname of TTF file"
-#~ msgstr "Nombre de fuente o ruta al archivo TTF"
-#~ msgid "Setting release of FreeType"
-#~ msgstr "Configurando el lanzamiento de FreeType"
-#~ msgid "Display number of colors"
-#~ msgstr "Mostrar número de colores"
-#~ msgid "Use mouse to size & place legend"
-#~ msgstr "Usar el ratón para dimensionar y situar la leyenda"
-#~ msgid "Creates a list of commands for recreating screen graphics."
-#~ msgstr "Crea una lista de comandos para recrear gráficos de pantalla."
-#~ msgid "Name of frame(s) to save"
-#~ msgstr "Nombre de marco(s) a guardar"
-#~ msgid "List of object numbers to remove which are displayed after \"#\". -1 for the last object."
-#~ msgstr "Lista de números de objeto a eliminar que son mostrados tras \"#\". -1 para el último objeto."
-#~ msgid "List of object numbers to move (\"from\" to \"to\"). remove= option will be done first, if any."
-#~ msgstr "Lista de números de objeto a mover (\"desde\" a \"a\"). eliminar= las opciones se harán primero, si las hay."
-#~ msgid "Save current frame"
-#~ msgstr "Guardar el marco actual"
-#~ msgid "Save all the frames"
-#~ msgstr "Guardar todos los marcos"
-#~ msgid "Only map objects without extra header and tailer"
-#~ msgstr "Sólo objetos de mapa sin cabecera y cola extra"
-#~ msgid "Rendering method for filled polygons"
-#~ msgstr "Método de renderizado para polígonos rellenos"
-#, fuzzy
-#~ msgid "g;use the libgis render functions (features: clipping);r;use the raster graphics library functions (features: polylines);d;use the display library basic functions (features: polylines);c;use the display library clipping functions (features: clipping);l;use the display library culling functions (features: culling, polylines)"
-#~ msgstr "g;usar las funciones de renderización de libgis (funciones: clipping);r;usar las funciones de la biblioteca de gráficos ráster (funciones: polilíneas);d;usar las funciones básicas de la biblioteca de visualización (funciones: polilíneas);c;usar las funciones de clipping de la biblioteca de visualización (funciones: clipping);l;usar las funciones de culling de la biblioteca de visualización (funciones: culling, polilíneas)"
-#~ msgid "Don't add to list of vectors and commands in monitor (it won't be drawn if the monitor is refreshed)"
-#~ msgstr "No añadir a la lista de vectoriales y comandos en el monitor (no se dibujarán si se refresca el monitor)"
-#~ msgid "No raster map exists in the current window"
-#~ msgid "Creates and displays a menu within the active frame on the graphics monitor."
-#~ msgstr "Crea y muestra un menú en el marco activo de la pantalla."
-#~ msgid "Sets the color of the menu background"
-#~ msgstr "Establece el color de fondo del menú"
-#~ msgid "Sets the color of the menu text"
-#~ msgstr "Establece el color del texto del menú"
-#~ msgid "Sets the color dividing lines of text"
-#~ msgstr "Establece el color de separación de líneas de texto"
-#~ msgid "Sets the menu text size (in percent)"
-#~ msgstr "Establece el tamaño de texto del menú (en porcentaje)"
-#~ msgid "Menu must contain a title and at least one option"
-#~ msgstr "El menú debe contener un título y al menos una opción"
-#~ msgid "Don't add to list of rasters and commands in monitor"
-#~ msgstr "No añadir a la lista de rásters y comandos en el monitor"
-#~ msgid "One mouse click only"
-#~ msgstr "Un solo clic del ratón"
-#~ msgid "Use mouse to interactively place scale"
-#~ msgstr "Usar el ratón para situar la escala de forma interactiva"
-#~ msgid "Use mouse to interactively place text"
-#~ msgstr "Usar el ratón para situar el texto de forma interactiva"
-#~ msgid "Click!\n"
-#~ msgstr "¡Clic!\n"
-#~ msgid " Left:    Place text here\n"
-#~ msgstr " Izquierda:    Sitúe el texto aquí\n"
-#~ msgid " Right:   Quit\n"
-#~ msgstr " Derecha:   Salir\n"
-#~ msgid "Just redraw given maps using default colors"
-#~ msgstr "Sólo redibujar los mapas dados usando colores predeterminados"
-#~ msgid "ERROR: can not get \"list\" items"
-#~ msgstr "ERROR: no se pueden obtener los elementos de \"lista\""
-#~ msgid "-j flag forced"
-#~ msgstr "Opción -j forzada"
-#~ msgid "No map is displayed in GRASS monitor"
-#~ msgstr "Ningún mapa está mostrado en el monitor de GRASS"
-#~ msgid "Interactively select route"
-#~ msgstr "Seleccionar ruta de forma interactiva"
-#~ msgid "You must select more than one point"
-#~ msgstr "Debe seleccionar más de un punto"
-#~ msgid "You must select at least four points"
-#~ msgstr "Debe seleccionar al menos cuatro puntos"
-#~ msgid "No raster or vector map displayed"
-#~ msgstr "Ningún mapa ráster o vectorial mostrado"
-#~ msgid "To establish and control use of a graphics display monitor."
-#~ msgstr "Para establecer y controlar el uso de una pantalla."
-#~ msgid "Name of graphics monitor to unlock"
-#~ msgstr "Nombre de la pantalla a desbloquear"
-#~ msgid "List all monitors (with current status)"
-#~ msgstr "Listar todas las pantallas (con el estado actual)"
-#~ msgid "Problem selecting %s. Will try once more"
-#~ msgstr "Problema al seleccionar %s. Se intentará otra vez"
-#~ msgid "Usage:  %s monitor_name"
-#~ msgstr "Uso: %s nombre de monitor"
-#~ msgid "No such monitor as <%s>"
-#~ msgstr "No hay tal monitor <%s>"
-#~ msgid "%s: -%c unrecognized option"
-#~ msgstr "%s: opción -%c no reconocida"
-#~ msgid "Monitor <%s> in use by another user"
-#~ msgstr "Monitor <%s> en uso por otro usuario"
-#~ msgid "Failed testing lock mechanism"
-#~ msgstr "Fallo al probar el mecanismo de bloqueo"
-#~ msgid "Usage:  %s [-fv] [name]"
-#~ msgstr "Uso: %s [-fv] [nombre]"
-#~ msgid "Usage: %s [-f] monitor_name"
-#~ msgstr "Uso: %s [-f] nombre de monitor"
-#~ msgid "Monitor '%s' terminated"
-#~ msgstr "Monitor '%s' terminado"
-#~ msgid "Error - Monitor '%s' in use by another user"
-#~ msgstr "Error - Monitor '%s' en uso por otro usuario"
-#~ msgid "Error - Locking mechanism failed"
-#~ msgstr "Error - Falló el mecanismo de bloqueo"
-#~ msgid "Error choosing frame [%s]\n"
-#~ msgstr "Error al elegir el marco [%s]\n"
-#~ msgid ""
-#~ "\n"
-#~ "Buttons:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Botones:\n"
-#~ msgid "Left:   Select frame\n"
-#~ msgstr "Izquierda:   Seleccionar marco\n"
-#~ msgid "Middle: Keep original frame\n"
-#~ msgstr "Centro: Mantener marco original\n"
-#~ msgid "Right:  Accept frame\n"
-#~ msgstr "Derecha:  Aceptar marco\n"
-#~ msgid "Manages display frames on the user's graphics monitor."
-#~ msgstr "Gestiona marcos de presentación en la pantalla del usuario."
-#~ msgid "Create a new frame"
-#~ msgstr "Crea un nuevo marco"
-#~ msgid "Select a frame"
-#~ msgstr "Seleccionar un marco"
-#~ msgid "Print names of all frames"
-#~ msgstr "Imprimir el nombre de todos los marcos"
-#~ msgid "List map names displayed in GRASS monitor"
-#~ msgstr "Listar nombres de los mapas mostrados en el monitor de GRASS"
-#~ msgid "Debugging output"
-#~ msgstr "Salida de depuración"
-#~ msgid "Frame to be created/selected"
-#~ msgstr "Marco a crear/seleccionar"
-#~ msgid "bottom,top,left,right"
-#~ msgstr "inferior,superior,izquierda,derecha"
-#~ msgid "Where to place the frame, values in percent (implies -c)"
-#~ msgstr "Dónde colocar el marco, valores en porcentaje (implica -c)"
-#~ msgid ""
-#~ "\n"
-#~ "Mouse Buttons:"
-#~ msgstr ""
-#~ "\n"
-#~ "Botones del ratón:"
-#~ msgid "Left:   Select From\n"
-#~ msgstr "Izquierda: seleccionar desde\n"
-#~ msgid "Middle: Select To\n"
-#~ msgstr "Centro: seleccionar hasta\n"
-#~ msgid ""
-#~ "Right:  Quit\n"
-#~ "\n"
-#~ msgstr ""
-#~ "Derecho: salir\n"
-#~ "\n"
-#~ msgid "Monitor: interactive command in redraw"
-#~ msgstr "Monitor: comando interactivo en redibujar"
-#~ msgid "found %d visuals of type TrueColor"
-#~ msgstr "%d visuales encontrados de tipo TrueColor"
-#~ msgid "searching for highest bit depth"
-#~ msgstr "buscando la profundidad de bit más alta"
-#~ msgid "selected %d bit depth"
-#~ msgstr "profundidad de bit %d seleccionada"
-#~ msgid "using default visual which is %s"
-#~ msgstr "utilizando el visual predeterminado, que es %s"
-#~ msgid "Monitor: XGetWMName failed"
-#~ msgstr "Monitor: XGetWMName falló"
-#~ msgid "Monitor: XGetWMName: bad result"
-#~ msgstr "Monitor: XGetWMName: mal resultado"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "WARNING!  A projection file already exists for this location\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "¡AVISO!  Ya existe un archivo de proyección para esta localización\n"
-#~ msgid "Would you still like to overwrite the current projection information "
-#~ msgstr "¿Todavía quiere sobrescribir la información de la proyección actual? "
-#~ msgid "The projection information will not be updated."
-#~ msgstr "La información de la proyección no se actualizará."
-#~ msgid "Enable interactive prompting (for command-line use only)"
-#~ msgstr "Activar introducción interactiva (sólo para línea de comandos)"
-#~ msgid "<%s> is an illegal region name"
-#~ msgstr "<%s> es un nombre de región no admitido"
-#, fuzzy
-#~ msgid "Erasing monitors..."
-#~ msgstr "Borrando monitores..."
-#~ msgid "Apply regular expressions and wildcards to g.remove"
-#~ msgstr "Aplicar expressiones regulares y comodines a g.remove"
-#~ msgid "Memory allocation error"
-#~ msgstr "Error de asignación de memoria"
-#~ msgid "Cannot execute: %s"
-#~ msgstr "No se puede ejecutar: %s"
-#~ msgid "Cannot link table: %s"
-#~ msgstr "No se puede conectar la tabla: %s"
-#~ msgid "Output file extension (inputfile(s) + extension)"
-#~ msgstr "La extensión del archivo de salida (archivo(s) de salida + extensión)"
-#~ msgid "Display manager for GRASS"
-#~ msgstr "Administrador de visualización para GRASS"
-#~ msgid "Name of .dmrc settings file"
-#~ msgstr "Nombre del archivo de configuración .dmrc"
-#~ msgid "Saves active display monitor to PNG file in home directory"
-#~ msgstr "Guarda el monitor activo a un archivo PNG en el directorio home"
-#~ msgid "Resolution of output file (single=1, double=2, quad=4)"
-#~ msgstr "Resolución del archivo de salida (único=1, doble=2, cuádruple=4)"
-#~ msgid "Divides active display into two frames & displays maps/executes commands in each frame."
-#~ msgstr "Divide la visualización activa en dos marcos y muestra los mapas/ejecuta los comandos en cada uno."
-#~ msgid "Enter command to execute in 1st frame"
-#~ msgstr "Introducir comando a ejecutar en el primer marco"
-#~ msgid "Enter raster map to display in 2nd frame"
-#~ msgstr "Introducir mapa ráster a mostrar en el segundo marco"
-#~ msgid "Enter command to execute in 2nd frame"
-#~ msgstr "Introducir comando a ejecutar en el segundo marco"
-#~ msgid "How to split display"
-#~ msgstr "Como dividir la visualización"
-#~ msgid "Keep band numbers instead of using band color names."
-#~ msgstr "Mantener números de banda en vez de usar nombres de color de las bandas."
-#~ msgid "extended statistics (quartiles and percentile)"
-#~ msgstr "estadísticas ampliadas (cuartiles y percentiles)"
-#~ msgid "Percentile to calculate (requires -e flag)"
-#~ msgstr "Percentil a calcular (requiere la opción -e)"
-#~ msgid "Saving new map"
-#~ msgstr "Guardando el nuevo mapa"
-#~ msgid "Cell area: %f"
-#~ msgstr "Área de celda: %f"
-#~ msgid "Output raster map with lake"
-#~ msgstr "Producir mapa ráster con lago"
-#~ msgid "Cannot write lake raster map <%s>!"
-#~ msgstr "¡No se puede escribir el mapa ráster de lago <%s>!"
-#~ msgid "Terrain raster map <%s> not found!"
-#~ msgstr "¡Mapa ráster de terreno <%s> no encontrado!"
-#~ msgid "Cannot open terrain raster map <%s@%s>!"
-#~ msgstr "¡No se puede abrir el mapa ráster de terreno <%s@%s>!"
-#, fuzzy
-#~ msgid "Seed map <%s> not found!"
-#~ msgstr "mapa <%s> no encontrado"
-#, fuzzy
-#~ msgid "Cannot open seed map <%s@%s>!"
-#~ msgid "Failure to allocate memory for row pointers"
-#~ msgstr "Fallo al asignar memoria para punteros de fila"
-#~ msgid "Error reading terrain raster map. Probably broken file."
-#~ msgstr "Error al leer el mapa ráster de terreno. Probablemente el archivo está corrupto."
-#, fuzzy
-#~ msgid "Error reading seed raster map. Probably broken file."
-#~ msgstr "Error al leer el mapa ráster de . Probablemente el archivo está corrupto."
-#~ msgid "Cannot write lake raster map <%s@%s>!"
-#~ msgstr "¡No se puede escribir el mapa ráster de lago <%s@%s>!"
-#~ msgid ""
-#~ "Starting lake filling at level of %8.4f in %d passes. \n"
-#~ "Percent done:"
-#~ msgstr ""
-#~ "Empezando el relleno del lago al nivel %8.4f en %d pases.\n"
-#~ msgid "Error writing color file for <%s@%s>!"
-#~ msgstr "¡Error al escribir archivo de color para <%s@%s>!"
-#~ msgid "All done."
-#~ msgstr "Todo hecho."
-#~ msgid "Calculates <simple> index on a raster map"
-#~ msgstr "Calcula el índice <simple> en un mapa ráster"
-#~ msgid "raster, landscape structure analysis, job launcher"
-#~ msgstr "ráster, análisis de estructura de paisaje, lanzador de trabajos"
-#~ msgid "Bilinear interpolation utility for raster map layers."
-#~ msgstr "Utilidad de interpolación bilineal para capas de mapa ráster."
-#~ msgid "Specific input value to be assigned to the north and/or south poles for longitude-latitude grids"
-#~ msgstr "Valores de entrada específicos a asignar a los polos Norte y/o Sur para cuadrículas longitud-latitud"
-#~ msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
-#~ msgstr "Este módulo está despreciado. Por favor, use 'r.resamp.interp' en su lugar."
-#~ msgid "Raster input maps(s)"
-#~ msgstr "Mapa(s) ráster de entrada"
-#~ msgid "Output file name"
-#~ msgstr "Nombre de archivo de salida"
-#~ msgid "%s: can't read fp range for [%s]"
-#~ msgstr "%s: no se puede leer el rango fp para [%s]"
-#~ msgid ""
-#~ "Raster map [%s] already exists.\n"
-#~ "Please try another."
-#~ msgstr ""
-#~ "El mapa ráster [%s] ya existe.\n"
-#~ "Por favor, pruebe otro."
-#~ msgid "Cannot open new vector map <%s>"
-#~ msgstr "No se puede abrir el nuevo mapa vectorial <%s>"
-#~ msgid "Conversion of <%s> to vector map:"
-#~ msgstr "Conversión de <%s> a mapa vectorial:"
-#, fuzzy
-#~ msgid "Specified group does not exist"
-#~ msgstr "El grupo especificado no existe... Saliendo."
-#~ msgid "imagery subgroup"
-#~ msgstr "subgrupo de imágenes"
-#~ msgid "Generates and displays simple graphics on map layers drawn in the active graphics monitor display frame."
-#~ msgstr "Genera y muestra gráficos sencillos en capas de mapa dibujadas en el marco de visualización del monitor activo."
-#~ msgid "Unix file containg graphing instructions, if not given reads from standard input"
-#~ msgstr "Archivo Unix que contiene instrucciones gráficas. Si no se indica lee de la entrada estándar"
-#~ msgid "Color to draw with, either a standard GRASS color or R:G:B triplet (separated by colons)"
-#~ msgstr "Color con el que dibujar: color estándar de GRASS o triplete R:G:B (separado por dos puntos)"
-#~ msgid "value [%.0f,%.0f] out of range [0-100]"
-#~ msgstr "valor [%.0f,%.0f] fuera de rango [0-100]"
-#~ msgid "Draws text in the graphics monitor's active display frame using TrueType fonts."
-#~ msgstr "Escribe texto en el marco activo de la pantalla usando fuentes TrueType."
-#~ msgid "Screen position (percentage, [0,0] is bottom left)"
-#~ msgstr "Posición de pantalla (porcentaje, [0,0] es inferior izquierda)"
-#~ msgid "Path to TrueType font (including file name)"
-#~ msgstr "Ruta del tipo de letra TrueType (incluir nombre de fichero)"
-#~ msgid "Height of letters (in percent of available frame height)"
-#~ msgstr "Altura de letras (en porcentaje de la altura del marco disponible)"
-#~ msgid "Choose only one coordinate system for placement"
-#~ msgstr "Elegir sólo un sistema de coordenadas para la ubicación"
-#~ msgid "Invalid font: %s"
-#~ msgstr "Fuente inválida: %s"
-#~ msgid "Unable to create text conversion context"
-#~ msgstr "No se puede crear el contexto de conversión de texto"
-#~ msgid "Unable to write the temporary file"
-#~ msgstr "No se puede escribir el archivo temporal"
-#~ msgid "No predefined font"
-#~ msgstr "Ninguna fuente predefinida"
-#~ msgid "%s: Unable to read font"
-#~ msgstr "%s: No se puede leer la fuente"
-#~ msgid "%s: Unable to read FreeType definition file; use the default"
-#~ msgstr "%s: no se puede leer el archivo de definición FreeType; use el predeterminado"
-#~ msgid "%s: No FreeType definition file"
-#~ msgstr "%s: ninún archivo de definición FreeType"
-#~ msgid "%s: Unable to read FreeType definition file"
-#~ msgstr "%s: no se puede leer el archivo de definición FreeType"
-#~ msgid "No LatLong information for XY-Projection"
-#~ msgstr "Sin información de latitud/longitud para la proyección XY"
-#~ msgid "Quietly"
-#~ msgstr "De forma silenciosa"
-#~ msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead"
-#~ msgstr "La opción '-q' está suplantada y se eliminará en el futuro. Por favor, use '--quiet' en su lugar"
-#~ msgid "Quiet - Do not show progress"
-#~ msgstr "Silencioso - no muestra el progreso"
-#~ msgid "Suppress single crossing error messages"
-#~ msgstr "Suprime mensaje de error de cruzamiento simple"
-#~ msgid "The '-q' and '-n' flag is superseded and will be removed in future. Please use '--quiet' instead."
-#~ msgstr "Las opciones '-q' y '-n' son suplantadas y serán eliminadas en el futuro. Por favor use '--quiet' en su lugar."
-#~ msgid "G_put_raster_row failed (file system full?)"
-#~ msgstr "G_put_raster_row falló (¿sistema de archivos lleno?)"
-#~ msgid "Quiet; No chatter"
-#~ msgstr "En silencio; Sin comentarios"
-#~ msgid "Raster file(s) for Elevation"
-#~ msgstr "Archivo(s) ráster para elevación"
-#~ msgid "Raster file(s) for Color"
-#~ msgstr "Archivo(s) ráster para color"
-#~ msgid ""
-#~ "Not enough data columns. Incorrect delimiter or column number?\n"
-#~ "[%s]"
-#~ msgstr ""
-#~ "Columnas de datos insuficientes. ¿Delimitador o número de columna incorrecto?\n"
-#~ "[%s]"
-#~ msgid "Input raster map constains cells with NULL-value (no-data). For no-data values was used value %g. You can specify nodata value by %s parameter."
-#~ msgstr "El mapa ráster de entrada contiene celdas con valor NULO (sin datos). Para los valores sin datos se usó el valor %g. Puede especificar el valor para para las celdas sin datos con el parámetro %s."
-#~ msgid "Name of the vector points map with x,y locations"
-#~ msgstr "Nombre del mapa vectorial de puntos con localizaciones X,Y"
-#~ msgid "Number of time iterations (sec.)"
-#~ msgstr "Número de repeticiones de tiempo (segundos)"
-#~ msgid "Multiscale simulation"
-#~ msgstr "Simulación multiescala"
-#~ msgid "Running MAY 10 version"
-#~ msgstr "Ejecutando la versión MAY 10"
-#~ msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
-#~ msgstr "Nombre del mapa ráster de elevaciones, en las mismas unidades que N,E: [m] o [pies]"
-#~ msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
-#~ msgstr "Nombre del mapa ráster de derivadas de Y [m/m] o [pies/pies]"
-#~ msgid "Threshold distance set to %g map units (based on 2D resolution)"
-#~ msgstr "Distancia umbral establecida a %g unidades de mapa (basado en resolución 2D)"
-#~ msgid "Raster map to zoom into"
-#~ msgstr "Mapa ráster en el que hacer zum"
-#~ msgid "Save the current region to region definition file"
-#~ msgstr "Guardar la región actual en archivo de definición de región"
-#~ msgid "Unknown query tool '%s'"
-#~ msgstr "Herramienta de consulta '%s' desconocida"
-#~ msgid "Column type [%d] not supported"
-#~ msgstr "Tipo de columna [%d] no soportado"
-#~ msgid "Only %d lines found, at least two needed"
-#~ msgstr "Sólo se han encontrado %d líneas, se necesitan el menos dos"
-#~ msgid "Unable to write line %d"
-#~ msgstr "No se puede escribir la línea %d"
-#~ msgid "Unable to connect line id %d to line %d"
-#~ msgstr "No se puede conectar la línea con ID %d a la línea %d"
-#~ msgid "Unable to connect line id %d to line %d because of threshold distance. Run v.edit with other threshold distance value."
-#~ msgstr "No se puede conectar la línea con ID %d a la línea %d por la distancia umbral. Ejecute v.edit con otro valor de distancia umbral."
-#~ msgid "Unable to get category list <%s>, editing terminated"
-#~ msgstr "No se puede obtener la lista de categorías <%s>, edición terminada"
-#~ msgid "Unable to delete layer/category [%d/%d] line %d"
-#~ msgstr "No se puede borrar la capa/categoría [%d/%d] línea %d"
-#~ msgid "\rDuplicate area centroids: %5d"
-#~ msgstr "\rCentroides de área duplicados: %5d"
-#~ msgid "\rRemoved vertices: %5d"
-#~ msgstr "\rVértices eliminados: %5d"
-#~ msgid "Load values from vector to database. For uploaded/printed category values '-1' is used for 'no category' and 'null'/'-' if category cannot be found or multiple categories were found."
-#~ msgstr "Cargar valores de vectorial a base de datos. Para valores de categorías subidos/impresos se usa '-1' para 'sin categoría' y 'null'/'-' si la categoría no se puede encontrar o se encontraron múltiples categorías."
-#~ msgid "Cannot create layer"
-#~ msgstr "No se puede crear la capa"
-#~ msgid ""
-#~ "\a\n"
-#~ "** The following raster maps in subgroup [%s] do not exist:"
-#~ msgstr ""
-#~ "\a\n"
-#~ "** Los siguientes mapas ráster en el subgrupo [%s] no existen:"
-#~ msgid "       %s"
-#~ msgstr "       %s"
-#~ msgid "Enter raster map to display in 1st frame"
-#~ msgid "        Number of bytes per cell"
-#~ msgstr "        Número de bytes por celda"
-#~ msgid "No numerical attributes found. Skipping export"
-#~ msgstr "No se encontraron atributos numéricos. Saltando exportación"
-#~ msgid "Error reading value of attribute '%s'"
-#~ msgstr "Error leyendo el valor de atributo '%s'"
-#~ msgid "Illegal subgroup name <%s>"
-#~ msgstr "Nombre de subgrupo <%s> no admitido"
-#, fuzzy
-#~ msgid "Database is not a %s"
-#~ msgstr "Nombre de la base de datos de entrada"
-#, fuzzy
-#~ msgid "d;use the display library basic functions (features: polylines);c;use the display library clipping functions (features: clipping);l;use the display library culling functions (features: culling, polylines)"
-#~ msgid "Invalid rendering method <%s>"
-#~ msgstr "Método rendering no válido  <%s>"
-#, fuzzy
-#~ msgid "Apply regular expressions and wildcards to g.list"
-#~ msgid "Name of raster map to print in legend"
-#~ msgstr "Nombre del mapa raster a imprimir en la leyenda"
-#~ msgid "Data range of raster map <%s> is empty"
-#~ msgstr "El intervalo de datos del mapa raster <%s> está vacío"
-#~ msgid "raster, recode category"
-#~ msgstr "ráster, recodificar categoría"
-#, fuzzy
-#~ msgid "Unable to open rules file <%s>"
-#~ msgstr "No se puede abrir el archivo de resultado <%s>"
-#~ msgid "Power 2 values: %d rows %d columns"
-#~ msgstr "Power 2 valores :%d filas %d columnas"
-#~ msgid "Writing data..."
-#~ msgstr "Escribiendo datos..."
-#~ msgid "Group [%s] not found"
-#~ msgstr "Grupo [%s] no encontrado"
-#~ msgid "Bad format in camera file for group [%s]"
-#~ msgstr "Mal formato en archivo cámara para grupo [%s]"
-#~ msgid "Computing equations ..."
-#~ msgstr "Calculando ecuaciones ..."
-#~ msgid "Unable to read raster header of <%s>"
-#~ msgstr "No se puede leer la cabecera raster de <%s>"
-#~ msgid "Name of camera reference file to use"
-#~ msgstr "Nombre del archivo de referencia de cámara a utilizar"
-#~ msgid "Group [%s] in location [%s] mapset [%s] now has camera file [%s]"
-#~ msgstr "El grupo [%s] en la localización [%s] directorio de mapas [%s] ahora tiene un archivo cámara [%s]"
-#~ msgid "Target location [%s] not found\n"
-#~ msgstr "Localización de salida  [%s] no encontrada\n"
-#~ msgid "Mapset [%s] in target location [%s] - "
-#~ msgstr "Directorio de mapas [%s] en localización de destino [%s] - "
-#~ msgid "permission denied\n"
-#~ msgstr "permiso denegado\n"
-#~ msgid "not found\n"
-#~ msgstr "no encontrado\n"
-#~ msgid "Pre-selected group <%s> not found"
-#~ msgstr "Grupo preseleccionado <%s> no encontrado"
-#~ msgid "Enter imagery group for ortho-rectification"
-#~ msgstr "Entrar grupo de imaginería para ortorectificación"
-#~ msgid "Group [%s] contains no files"
-#~ msgstr "El grupo [%s] no contiene archivos"
-#~ msgid "Image Group [%s] not found"
-#~ msgstr "Grupo de Imagen [%s] no encontrado"
-#, fuzzy
-#~ msgid "Poorly placed psuedo control points. "
-#~ msgstr "Ningún punto de inicio"
-#, fuzzy
-#~ msgid "No active psuedo control points"
-#, fuzzy
-#~ msgid "%s@%s: projection doesn't match current settings"
-#~ msgstr "Saliendo. No se cambian las configuraciones actuales"
-#, fuzzy
-#~ msgid "%s@%s: zone doesn't match current settings"
-#~ msgid "Interactively select or modify the imagery group target."
-#~ msgstr "Interactivamente seleccionar o modificar el grupo de imaginería de destino."
-#~ msgid "Group [%s] targeted for location [%s], mapset [%s]"
-#~ msgstr "Grupo [%s] captado para localización [%s], conjunto de mapas [%s]"
-#, fuzzy
-#~ msgid "Short user prompt message"
-#~ msgstr "Imprimir el mensaje de copyright"
-#, fuzzy
-#~ msgid "Displays the rhumbline joining two user-specified points, in the active frame on the user's graphics monitor."
-#~ msgstr "Muestra datos vectoriales de GRASS en el marco activo de la pantalla."
-#~ msgid "Unable to find row %d, col %d: %f"
-#~ msgstr "No se puede encontrar la fila %d, col %d: %f"
-#~ msgid "No data"
-#~ msgstr "No hay datos"
-#~ msgid "vector, import, database, points"
-#~ msgstr "vectorial, importar, base de datos, puntos"
-#~ msgid "No photo points for group [%s]"
-#~ msgstr "No se han encontrado puntos fotográficos para el grupo [%s]"
-#, fuzzy
-#~ msgid "Cannot generate the transformation equation."
-#~ msgstr "Imprimir la matriz de transformación a stdout"
-#~ msgid "Name of terrain raster map (DEM)"
-#~ msgstr "Nombre del mapa raster de terreno (MDT)"
-#, fuzzy
-#~ msgid "Input raster map contains cells with NULL-value (no-data). The value %g was used to represent no-data values in the input map. You can specify a nodata value with the %s option."
-#~ msgstr "El mapa ráster de entrada contiene celdas con valor NULO (sin datos). Para los valores sin datos se usó el valor %d. Puede especificar el valor para para las celdas sin datos con el parámetro %s."
-#~ msgid "Interpolating raster map <%s> (%d rows)... "
-#~ msgstr "Interpolando mapa ráster <%s> (%d filas)... "
-#~ msgid "Cannot read ew_res value"
-#~ msgstr "No se puede leer el valor ew_res (resolución EW)"
-#~ msgid "Cannot read ns_res value"
-#~ msgstr "No se puede leer el valor ns_res (resolución NS)"
-#~ msgid "[%s]: Map is the wrong resolution"
-#~ msgstr "[%s]: el mapa está en la resolución incorrecta"
-#~ msgid "Cannot get row %d (error = %d)"
-#~ msgstr "No se puede obtener la fila %d (error = %d)"
-#~ msgid "Cannot set region to back to the initial region !!!"
-#~ msgstr "¡No se puede establecer la región para volver a la región inicial!"
-#~ msgid "One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be specified!"
-#~ msgstr "¡Se debe especificar \"-i\" o \"-r\" o una de las opciones \"color\", \"ráster\" o \"reglas\"!"
-#~ msgid "%s: can only do up to %d raster maps, sorry\n"
-#~ msgstr "%s: sólo puede hacer hasta %d mapas ráster, lo siento\n"
-#~ msgid "Bad start cell"
-#~ msgstr "Celda de inicio incorrecta"
-#~ msgid "Update the statistics (histogram, range) for [%s]? "
-#~ msgstr "¿Actualizar las estadísticas (histograma, rango) de [%s]?"
-#, fuzzy
-#~ msgid "Output map: useful for visual display of results. DEPRECATED."
-#~ msgstr "Mapa de salida: útil para  visualizar los resultados"
-#~ msgid "Setting quant rules for input map(s) to (%f %f) -> (%d,%d)"
-#~ msgstr "Configurar reglar de cuantización para el(los) mapa(s) a (%f %f) -> (%d,%d)"
-#~ msgid "Raster map <%s> in mapset <%s> is a floating point map. Decimal values will be rounded to integer!"
-#~ msgstr "El mapa ráster <%s> en el directorio de mapas <%s> es de coma flotante. ¡Los valores decimales se redondearán a entero!"
-#~ msgid "Data range of raster map <%s> is %s to %s (entire map)"
-#~ msgstr "El intervalo de datos del mapa raster<%s> es %s to %s (mapa entero)"
-#~ msgid "Integer data range of raster map <%s> is empty"
-#~ msgstr "El intervalo de datos enteros dl mapa rastere %s está vacío"
-#~ msgid "Integer data range of raster mao <%s> is %d to %d"
-#~ msgstr "El intervalo de datos enteros del mapa raster <%s> es de %d a %d"
-#~ msgid "'%s' is not a valid rule"
-#~ msgstr "'%s' no es una regla válida"
-#~ msgid "Patching vector map <%s@%s>..."
-#~ msgstr "Parcheando el mapa vectorial <%s@%s>..."
-#, fuzzy
-#~ msgid "add;add a new category;del;delete all categories of given layer;chlayer;change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add the value specified by cat option to the current category value;report;print report (statistics), in shell style: layer type count min max;print;print category values, more cats in the same layer are separated by '/'"
-#~ msgstr "añadir;añadir una categoría nueva;borrar; borrar categoría;cambiar capa;cambiar número de capa (ej.: capa=3,1 cambia la capa 3 a la 1);sumar;añadir el valor especificado por la opción categoría a valor de la categoría actual;informar;imprimir informe (estadísticas) en estilo consola: capa tipo cuenta mínimo máximo;imprimir;imprimir valores de categoría, más categorías en la misma capa son separadas por '/'"
-#~ msgid "Use the distance option instead of the buffer option."
-#~ msgstr "Utilizar la opción distancia en lugar de la opción buffer."
-#~ msgid "Unable to open real-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
-#~ msgstr "No fue posible abrir una imagen real en el directorio 'cell_misc'. El mapa raster probablemente no fue creado por  i.fft"
-#~ msgid "Unable to open imaginary-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
-#~ msgstr "No fue posible abrir imagen imaginaria en el directorio 'cell_misc'. El mapa raster probablemente no fue creado por i.fft"
-#~ msgid "Range less than or equal to zero not allowed"
-#~ msgstr "Rango menor que o igual a cero no permitido"
-#~ msgid "Writing viewable versions of transformed data..."
-#~ msgstr "Escribiendo versiones visibles de datos transformados..."
-#~ msgid "Unable to open file in the 'cell_misc' directory"
-#~ msgstr "Imposible abrir el archivo en el directorio 'cell_misc'"
-#~ msgid "Name of image to be rectified which will be initially drawn on screen"
-#~ msgstr "Nombre de la imagen para rectificar que se dibujará inicialmente en pantalla"
-#~ msgid "Name of a map from target mapset which will be initially drawn on screen"
-#~ msgstr "Nombre de un mapa del directorio de mapas de destino que se dibujará inicialmente en pantalla"
-#, fuzzy
-#~ msgid "Verbose module output"
-#~ msgstr "Modo verboso"
-#~ msgid "%s: Couldn't read color table for <%s@%s>"
-#~ msgstr "%s: No se pudo leer tabla de colores para <%s@%s>"
-#~ msgid "Command mode (Compatibility with d.text)"
-#~ msgstr "Modo comando (Compatibilidad con d.text)"
-#~ msgid "Unable to create face"
-#~ msgstr "No se puede crear cara"
-#~ msgid "Identifies the geographic coordinates associated with point locations in the active frame on the graphics monitor."
-#~ msgstr "Identifica las coordenadas geográficas asociadas con las localizaciones de los puntos en el marco activo de la pantalla."
-#~ msgid "Display monitor to start"
-#~ msgstr "Muestra el monitor para lanzar"
-#~ msgid "name for new map image (lives in ~/.gpsdrive/maps/)"
-#~ msgstr "nombre para el nuevo mapa de imagen (lives in ~/.gpsdrive/maps/)"
-#~ msgid "Name of PNG file"
-#~ msgstr "Nombre del archivo PNG"
-#~ msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2)"
-#~ msgstr "Nombre del mapa raster de entrada (NIR: tm4 | qbird_nir | spot2)"
-#~ msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3)"
-#~ msgstr "Nombre del mapa raster de entrada (MIR: tm5 | qbird_red | spot3)"
-#~ msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
-#~ msgstr "Hace mosaicos de hasta 4 imágenes y extiende colormap; crea mapas *.mosaico"
-#~ msgid "2nd map for mosaic."
-#~ msgstr "Segundo mapa para mosaico."
-#~ msgid "Georeference, rectify and import Terra-ASTER imagery and relative DEM's using gdalwarp."
-#~ msgstr "Georreferenciar, rectificar e importar imaginería Terra ASTER y MDT relativos usando gdalwarp."
-#~ msgid "L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a single band"
-#~ msgstr "Banda L1A o L1B a traducir (1, 2, 3n, 3b, 4-14). Sólo se puede traducir una banda"
-#~ msgid "Overwrite existing MASK"
-#~ msgstr "Sobrescribir MÁSCARA existente"
-#~ msgid "Region sensitive output"
-#~ msgstr "Salida sensible a región"
-#, fuzzy
-#~ msgid "The database must be in form printed by v.db.connect -g, i.e. with substituted variables"
-#~ msgstr "Nombre de la antigua base de datos. La base de datos debe estar en la forma impresa por v.db.connect -g, esto es, con variables sustituidas"
-#~ msgid "Value to update the column with (varchar values have to be in single quotes, e.g. 'grass')"
-#~ msgstr "Valor con el que actualizar la columna (los valores varchar tienen que estar entre comillas simples, ej. 'grass')"
-#~ msgid "%s: %s - Unable to find the real-image map."
-#~ msgstr "%s: %s - No fue posible encontrar el mapa de imagen real."
-#~ msgid "%s: %s - Unable to find the imaginary-image."
-#~ msgstr "%s: %s - No se pudo encontrar la imagen imaginaria."
-#~ msgid "Create 3D file"
-#~ msgstr "Crear archivo 3D"
-#~ msgid "The status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
-#~ msgstr "Estado para cada celda, = 0 - inactiva,  1 - activa, 2 - dirichlet"
-#~ msgid "The z-part of the hydraulic conductivity tensor in [m/s]"
-#~ msgstr "Parte Z del tensor de conductividad hidráulica en [m/s]"
-#~ msgid "Recharge raster map in m^3/s"
-#~ msgstr "Recargar mapa ráster en m^3/s"
-#~ msgid "The piezometric head result of the numerical calculation will be written to this map"
-#~ msgstr "El resultado del cálculo numérico de la altura piezométrica se escribirá en este mapa"
-#~ msgid "Calculate the groundwater distance velocity vector field and write the x, y, and z components to maps named name_[xyz]. Name is basename for the new raster3d maps"
-#~ msgstr "Calcular "
-#~ msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
-#~ msgstr "Exporta mapa ráster de GRASS a archivo de mapa GRIDATB.FOR (TOPMODEL)"
-#~ msgid "Converts a raster map layer into a height-field file for POVRAY."
-#~ msgstr "Convierte una capa de mapa ráster en un archivo de campo altura para POVRAY."
-#~ msgid "raster, map algebra"
-#~ msgstr "ráster, álgebra de mapas"
-#~ msgid "Converts a raster map layer into an ASCII text file."
-#~ msgstr "Convierte una capa de mapa ráster a un archivo de texto ASCII."
-#~ msgid "Unable to find stop vector <%s>"
-#~ msgstr "No se puede encontrar el vector de fin <%s>"
-#~ msgid "Name for output raster map with lake"
-#~ msgstr "Nombre para el mapa raster de salida con lago"
-#~ msgid "raster, statistics"
-#~ msgstr "ráster, estadísticas"
-#~ msgid "Converts raster maps into the VTK-Ascii format"
-#~ msgstr "Convierte mapas ráster al formato VTK-ASCII"
-#~ msgid "raster, terrain"
-#~ msgstr "raster, terreno"
-#~ msgid "Name of the water depth raster map [m]"
-#~ msgstr "Nombre del mapa raster de la profundidad del agua [m]"
-#~ msgid "Name of the x-derivatives raster map [m/m]"
-#~ msgstr "Nombre del mapa raster de derivadas X  [m/m]"
-#~ msgid "Name of the y-derivatives raster map [m/m]"
-#~ msgstr "Nombre del mapa raster de derivadas Y [m/m]"
-#~ msgid "Name of the detachment capacity coefficient raster map [s/m]"
-#~ msgstr "Nombre mapa raster de erosionabilidad  [s/m]"
-#~ msgid "Name of the transport capacity coefficient raster map [s]"
-#~ msgstr "Nombre del mapa raster de coeficiente de capacidad de transporte [s]"
-#~ msgid "Name of the critical shear stress raster map [Pa]"
-#~ msgstr "Nombre del mapa raster de tensión de corte crítica  [Pa]"
-#~ msgid "Name of the Mannings n raster map"
-#~ msgstr "Nombre del mapa ráster n de Mannings"
-#~ msgid "Name of the Mannings n value"
-#~ msgstr "Nombre del valor n de Mannings"
-#~ msgid "Output transport capacity raster map [kg/ms]"
-#~ msgstr "Producir mapa raster de capacidad de transporte [kg/ms]"
-#~ msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
-#~ msgstr "Mapa raster de salida transp.limitado erosión-deposición  [kg/m2s]"
-#~ msgid "Output sediment concentration raster map [particle/m3]"
-#~ msgstr "Mapa raster de salida de concentración de sedimentos [partículas/m3]"
-#~ msgid "Output sediment flux raster map [kg/ms]"
-#~ msgstr "Mapa raster de salida de flujo de sedimentos  [kg/ms]"
-#~ msgid "Output erosion-deposition raster map [kg/m2s]"
-#~ msgstr "Mapa raster de erosión"
-#~ msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
-#~ msgstr "Nombre del mapa ráster [mm/hr] de tasa de exceso de precipitación (lluvia-infiltración)"
-#~ msgid "Name of the runoff infiltration rate raster map [mm/hr]"
-#~ msgstr "Nombre del mapa raster con la tasa de escorrentía infiltración  [mm/hr]"
-#~ msgid "Name of the flow controls raster map (permeability ratio 0-1)"
-#~ msgstr "Nombre del mapa ráster de controles de flujo (relación de permeabilidad 0-1)"
-#~ msgid "Output water discharge raster map [m3/s]"
-#~ msgstr "Mapa raster de salida de descarga de agua  [m3/s]"
-#~ msgid "Output simulation error raster map [m]"
-#~ msgstr "Producir mapa ráster de error de simulación [m]"
-#~ msgid "Threshold water depth [m] (diffusion increases after this water depth is reached)"
-#~ msgstr "Umbral de la profundidad del agua [m] (la difusión aumenta después de alcanzar esta profundidad)"
-#~ msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
-#~ msgstr "Convierte 3 capas ráster de GRASS (R,G,B) a un archivo de imagen PPM a la resolución de píxel de la REGIÓN ACTUALMENTE DEFINIDA."
-#~ msgid "Boundary condition status, 0-inactive, 1-active, 2-dirichlet"
-#~ msgstr "Estado de la condición de los contornos, 0-inactiva, 1-activa, 2-2-dirichlet"
-#~ msgid "Water sources and sinks in [m^3/s]"
-#~ msgstr "Fuentes de agua y sumideros en [m³/s]"
-#~ msgid "Specific yield in [1/m]"
-#~ msgstr "Rendimiento específico en [1/m]"
-#~ msgid "Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
-#~ msgstr "Recargar mapa; ejemplo: 6*10^-9 por celda en [m³/s*m²]"
-#~ msgid "The map storing the numerical result [m]"
-#~ msgstr "Mapa que guarda el resultado numérico [m]"
-#~ msgid "The height of the drainage bed in [m]"
-#~ msgstr "La altura de del lecho de drenaje en [m]"
-#~ msgid "raster, buffer"
-#~ msgstr "ráster, buffer"
-#~ msgid "Input map: amount of overland flow per cell"
-#~ msgstr "Mapa de entrada: cantidad de flujo superficial por celda"
-#, fuzzy
-#~ msgid "Input map: terrain blocking overland surface flow, for USLE"
-#~ msgstr "Mapa de entrada: flujo de superficie "
-#~ msgid "Output map: number of cells that drain through each cell"
-#~ msgstr "Mapa de salida: número de celdas que drenan a través de cada celda"
-#~ msgid "Output map: unique label for each watershed basin"
-#~ msgstr "Mapa de salida: etiqueta única para cada cuenca hidrográfica"
-#~ msgid "Output map: each half-basin is given a unique value"
-#~ msgstr "Mapa de salida: se da un valor único a cada semicuenca"
-#~ msgid "Output map: slope length and steepness (LS) factor for USLE"
-#~ msgstr "Mapa de salida: factor de longitud e inclinación de la pendiente (LS) para USLE"
-#~ msgid "Output map: slope steepness (S) factor for USLE"
-#~ msgstr "Mapa de salida: factor de inclinación de la pendiente (S) para USLE"
-#~ msgid "Input value: minimum size of exterior watershed basin"
-#~ msgstr "Valor de entrada: tamaño mínimo de la cuenca hidrográfica exterior"
-#~ msgid ""
-#~ "Sorry, if any of the following options are set:\n"
-#~ "    basin, stream, half.basin, length.slope, or slope.steepness\n"
-#~ "    you MUST provide a value for the basin threshold parameter."
-#~ msgstr ""
-#~ "Lo siento, si alguna de las siguientes opciones es establecida:\n"
-#~ "    cuenca, corriente, semicuenca, longitud de la pendiente o IS\n"
-#~ "    DEBE proporcionar un valor para el parámetro de umbral de cuenca."
-#, fuzzy
-#~ msgid ""
-#~ "USAGE for basin delineation:\n"
-#~ "%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
-#~ "\n"
-#~ "USAGE for ARMSED FILE creation:\n"
-#~ "%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] ha=half_basin_map ar=ARMSED_file_name\n"
-#~ "\n"
-#~ "USAGE for slope length determination:\n"
-#~ "%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
-#~ msgstr ""
-#~ "USO para delineación de cuenca:\n"
-#~ "%s -4 el= mostrar mostrar nombre mostrar máximo"
-#~ msgid "unable to open flow accumulation map layer"
-#~ msgstr "no se puede abrir la capa de acumulación de flujo del mapa"
-#~ msgid "Error writing color file for <%s>"
-#~ msgstr "Error al escribir el archivo de color para <%s>"
-#~ msgid "Output direction raster map"
-#~ msgstr "Producir mapa ráster de dirección"
-#~ msgid "Output raster map of problem areas"
-#~ msgstr "Producir mapa ráster de áreas problemáticas"
-#~ msgid "raster, resample"
-#~ msgstr "ráster, remuestrear"
-#~ msgid "Surface generation program from rasterized contours."
-#~ msgstr "Programa de generación de superficies a partir de contornos rasterizados."
-#~ msgid "Name of existing raster map containing contours"
-#~ msgstr "Nombre del mapa ráster existente que contiene los contornos"
-#~ msgid "Creates/modifies the color table associated with a raster map layer."
-#~ msgstr "Crea/modifica la tabla de colores asociada a una capa de mapa ráster."
-#~ msgid "Raster map name from which to copy color table"
-#~ msgstr "Nombre del mapa ráster del que copiar la tabla de colores"
-#, fuzzy
-#~ msgid "Path to rules file (\"-\" to read rules from stdin)"
-#~ msgstr "Archivo de coordenadas de entrada (omitir para leer de stdin)"
-#~ msgid "Cannot create %s/.r.li/ directory"
-#~ msgstr "No se puede crear el directorio %s/.r.li/"
-#~ msgid "Cannot create %s/.r.li/output/ directory"
-#~ msgstr "No se puede crear el directorio %s/.r.li/output/"
-#~ msgid "raster, null data"
-#~ msgstr "raster, datos nulos"
-#~ msgid "Export a raster map to the Virtual Reality Modeling Language (VRML)"
-#~ msgstr "Exportar un mapa ráster al Lenguaje de Modelado de Realidad Virtual (VRML)"
-#~ msgid "Generates a raster map layer of distance to features in input layer."
-#~ msgstr "Genera una capa de mapa raster de las distancias a los elementos en la capa de entrada."
-#~ msgid "(i)   Basin map created by r.water.outlet (MASK)"
-#~ msgstr "(i)   Mapa de cuenca creado por r.water.outlet (MÁSCARA)"
-#~ msgid "(o)   Direction map for depressionless elevation map"
-#~ msgstr "(S)   Mapa de dirección para mapa de elevación sin depresiones"
-#~ msgid "(i)   Number of topographic index classes"
-#~ msgstr "(E)   Número de clases de índice topográfico"
-#~ msgid "(o/i) Topographic index statistics file"
-#~ msgstr "(S/E) Archivo de estadísticas de índice topográfico"
-#~ msgid "(i)   TOPMODEL Parameters file"
-#~ msgstr "(E)   Archivo de parámetros TOPMODEL"
-#~ msgid "(i)   Rainfall and potential evapotranspiration data file"
-#~ msgstr "(E)   Archivo de datos de precipitaciones y evotranspiración potencial"
-#~ msgid "Creates a new map layer whose category values are based upon a reclassification of the categories in an existing raster map layer."
-#~ msgstr "Crea una nueva capa de mapa cuyos valores de categorías están basados en una reclasificación de las categorías de una capa de mapa ráster existente."
-#~ msgid "Raster map to be reclassified"
-#~ msgstr "Mapa por reclasificar"
-#~ msgid "Converts a raster map into a vector map layer."
-#~ msgstr "Convierte un mapa ráster en una capa de mapa vectorial."
-#~ msgid "Do not build vector topology (use with care for massive point export)"
-#~ msgstr "No construir topología vectorial (usar con cuidado para exportación masiva de puntos)"
-#~ msgid "The map E grid coordinates"
-#~ msgstr "Coordenadas de cuadrícula E del mapa"
-#~ msgid "Calculating map %01d of %01d (angle %lf, raster map <%s>)"
-#~ msgstr "Calculando mapa %01d de %01d (ángulo %lf, mapa raster<%s>)"
-#~ msgid "Name of vector input map containing stream(s)"
-#~ msgstr "Nombre del vectorial de entrada que contiene corriente(s)"
-#~ msgid "Stream width (in meters). Default is raster cell width"
-#~ msgstr "Anchura de corriente (en metros). Por defecto es la anchura de celda ráster."
-#~ msgid "Output flowpath length raster map"
-#~ msgstr "Mapa ráster de longitud de ruta de corriente de salida"
-#~ msgid "Output flowline density raster map"
-#~ msgstr "Mapa ráster de densidad de línea de corriente de salida"
-#~ msgid "3-D lengths instead of 2-D"
-#~ msgstr "Longitudes 3D en vez de 2D"
-#~ msgid "Converts ASCII raster file to binary raster map layer."
-#~ msgstr "Convierte un archivo ráster ASCII en una capa de mapa ráster binaria."
-#~ msgid "Output topographic index map"
-#~ msgstr "Producir mapa de índice topográfico"
-#~ msgid "raster, geomorphology"
-#~ msgstr "ráster, goemorfología"
-#~ msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster map layer."
-#~ msgstr "Convierte un archivo ráster ASCII ARC/INFO de ESRI (GRID) en una capa de mapa ráster (binario)."
-#~ msgid "File containing weights"
-#~ msgstr "Archivo que contiene pesos"
-#~ msgid "general, map management"
-#~ msgstr "general, gestión de mapas"
-#~ msgid "general, scripts"
-#~ msgstr "general, scripts"
-#~ msgid "Color for drawing X's (Null values)"
-#~ msgstr "Color para dibujar las X (Valores nulos)"
-#~ msgid "display, cartography"
-#~ msgstr "mostrar, cartografía"
-#~ msgid "Monitor: waitpid: expected %d but got %d"
-#~ msgstr "Monitor: waitpid: se esperaba %d pero se obtuvo %d"
-#~ msgid "Either text or -c should be given"
-#~ msgstr "Texto o se debe dar -c"
-#~ msgid "Text conversion error"
-#~ msgstr "Error en la conversión de texto"
-#~ msgid "Error reading hue data"
-#~ msgstr "Error al leer datos de tonalidad"
-#~ msgid "R_color file for [%s] not available"
-#~ msgstr "Archivo R_color para [%s]  no disponible"
-#~ msgid "Range file for [%s] not available"
-#~ msgstr "Archivo range para [%s] no disponible"
-#~ msgid "Displays and overlays raster map layers in the active display frame on the graphics monitor."
-#~ msgstr "Muestra y superpone las capas del mapa ráster en el marco activo de la pantalla."
-#~ msgid "List of categories to be displayed (INT maps)"
-#~ msgstr "Lista de categorías para mostrar (mapas INT)"
-#~ msgid "Invert catlist"
-#~ msgstr "Invertir lista de categorías"
-#, fuzzy
-#~ msgid "Displays vector data in the active frame on the graphics monitor."
-#~ msgid "Vector map attribute column to use for comparison"
-#~ msgstr "Columna de atributos del mapa vectorial a usar para comparación"
-#~ msgid "Vector map to store differences"
-#~ msgstr "Mapa vectorial para guardar las diferencias"
-#~ msgid "Option scaling factor for values read from raster map. Sampled values will be multiplied by this factor"
-#~ msgstr "Opción factor de escala para valores leídos de un mapa ráster. Los valores muestrados se multiplicarán por este factor"
-#~ msgid "vector, networking"
-#~ msgstr "vectorial, trabajo en red"
-#~ msgid "Required for operation 'connect'"
-#~ msgstr "Requerido para la operación 'conectar'"
-#~ msgid "nodes;new point is placed on each node (line end) if doesn't exist;connect;connect still unconnected points to vector network by inserting new line(s);report;print to standard output {line_category start_point_category end_point_category};nreport;print to standard output {point_category line_category[,line_category...]}"
-#~ msgstr "nodos;el nuevo punto es situado en cada nodo (final de línea) si no existe;conectar;conecta puntos aún si conectar a la red vectorial insertando nueva línea(s);informar;imprimir a la salida estándar {line_category start_point_category end_point_category};nreport;imprimir a la salida estándar {point_category line_category[,line_category...]}"
-#~ msgid "%d new points written to output"
-#~ msgstr "%d puntos nuevos escritos en la salida"
-#~ msgid "Exports a GRASS vector map to SVG."
-#~ msgstr "Exporta un mapa vectorial de GRASS a SVG."
-#~ msgid "Layer number (write to)"
-#~ msgstr "Nombre de capa (escribir a)"
-#~ msgid "vector, interpolation"
-#~ msgstr "vectorial, interpolación"
-#~ msgid "Layer but not column with z values given"
-#~ msgstr "Capa pero con columna sin valores z facilitados"
-#~ msgid "Vector based generalization."
-#~ msgstr "Generalización basada en vectoriales."
-#~ msgid "Number of vertices was reduced from %d to %d [%d%%]"
-#~ msgstr "El número de vértices se redujo de %d a %d [%d%%]"
-#~ msgid "Creates topology for GRASS vector map."
-#~ msgstr "Crea topología para mapa vectorial de GRASS."
-#~ msgid "Vector map <%s> not found in the current mapset"
-#~ msgstr "No se encuentra el mapa vectorial <%s> en el directorio de mapas actual"
-#~ msgid "Convert OGR vector layers to GRASS vector map."
-#~ msgstr "Convertir capas vectoriales OGR a mapas vectoriales de GRASS."
-#~ msgid "Converts a binary GRASS vector map (only points) layer into a 3D GRASS raster map layer."
-#~ msgstr "Convierte un mapa vectorial binario de GRASS (sólo puntos) en una capa de mapa ráster 3D de GRASS."
-#~ msgid "vector, extract"
-#~ msgstr "vectorial, extraer"
-#~ msgid "Random location perturbations of GRASS vector points"
-#~ msgstr "Perturbaciones de localizaciones aleatorias de puntos vectoriales de GRASS"
-#~ msgid "Parameter(s) of distribution. If the distribution is uniform, only one parameter, the maximum, is needed. For a normal distribution, two parameters, the mean and standard deviation, are required."
-#~ msgstr "Parámetro(s) de distribución. Se la distribución es uniforme, sólo se necesita un parámetro, el máximo. Para una distribución normal se requieren dos parámetros, la media y la desviación estándar."
-#~ msgid "Layer number (from)"
-#~ msgstr "Número de capa (desde)"
-#~ msgid "Layer number (to)"
-#~ msgstr "Número de capa (hasta)"
-#~ msgid "Randomly generate a 2D/3D vector points map."
-#~ msgstr "Genera un mapa de puntos vectorial 2D/3D de GRASS de forma aleatoria."
-#~ msgid "Using 'double precision' for column <%s>"
-#~ msgstr "Utilizar 'double precision' para columna <%s>"
-#~ msgid "Converts a GRASS binary vector map to VTK ASCII output."
-#~ msgstr "Convierte un mapa vectorial binario de GRASS a salida ASCII VTK."
-#~ msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
-#~ msgstr "Convierte un mapa vectorial binario de GRASS a un mapa vectorial ASCII de GRASS"
-#~ msgid "vector, paint labels"
-#~ msgstr "vectorial, etiquetas de pintura"
-#~ msgid "vector, geometry"
-#~ msgstr "vectorial, geometría"
-#, fuzzy
-#~ msgid "Output quadrant centres, number of points is written as category"
-#~ msgstr "Salida puntos"
-#, fuzzy
-#~ msgid "Counting sites in quadrats..."
-#~ msgstr "lugares."
-#~ msgid "Creates a GRASS vector map of a user-defined grid."
-#~ msgstr "Crea un mapa vectorial de GRASS de una cuadrícula definida por el usuario."
-#~ msgid "Either 'rules' or 'col' must be specified"
-#~ msgstr "Tanto 'rules'om 'col' tienen que estar especificados"
-#~ msgid "vector, kernel density"
-#~ msgstr "vectorial, densidad de kernel"
-#~ msgid "Export features with category (labeled) only. Otherwise all features are exported"
-#~ msgstr "Exportar sólo elementos con categoría (etiquetados). En caso contrario se exportarán todos."
-#~ msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') to export in 3D rather than 2D (default)"
-#~ msgstr "El mapa vectorial <%s> es 3D. Use opciones de creación de capa específicas para el formato (parámetro 'Ico') para exportar en 3D en vez de 2D (predeterminado)."
-#~ msgid "Key column '%s' not found"
-#~ msgstr "Columna clave '%s' no encontrada"
-#~ msgid "%d features written"
-#~ msgstr "%d elementos escritos"
-#~ msgid "Convex hull calculation requires at least three points. Exiting."
-#~ msgstr "El cálculo de convex hull requiere como mínimode tres puntos. Saliendo."
-#~ msgid "Create a new vector map layer by combining other vector map layers."
-#~ msgstr "Crear una capa de mapa vectorial nueva combinando otras capas de mapas vectoriales."
-#~ msgid "Creates a buffer around features of given type (areas must contain centroid)."
-#~ msgstr "Crear un buffer alrededor de los elementos de tipo dado (las áreas deben contener centroide)."
-#~ msgid "Buffer distance in map units"
-#~ msgstr "Distancia de buffer en unidades de mapa"
-#~ msgid "vector, querying"
-#~ msgstr "vectorial, consultar"
-#~ msgid "Queries a vector map layer at given locations."
-#~ msgstr "Consulta una capa de mapa vectorial en las localizaciones dadas."
-#~ msgid "Copying vector objects from vector map <%s>..."
-#~ msgstr "Copiando objetos vectoriales del mapa vectorial <%s>..."
-#~ msgid "Name of input vector map containing lines"
-#~ msgstr "Nombre del mapa vectorial de entrada que contiene líneas"
-#~ msgid "Name for output vector map where segments will be written"
-#~ msgstr "Nombre del mapa vectorial de salida en el que se escribirán los segmentos"
-#~ msgid "Tests for normality for points."
-#~ msgstr "Test de normalidad para puntos."
-#~ msgid "Calculates univariate statistics for attribute. Variance and standard deviation is calculated only for points if specified."
-#~ msgstr "Calcula estadísticas univariante para atributos. La varianza y la desviación estándar sólo se calculan para puntos si se especifica."
-#~ msgid "Calculate area centroids..."
-#~ msgstr "Calcular centroides de las áreas..."
-#~ msgid "Area without centroid (may be OK for island)"
-#~ msgstr "Área sin centroide (puede ser correcto para islas)"
-#~ msgid "Create points along input lines in new vector with 2 layers."
-#~ msgstr "Creaa puntos a lo largo de líneas de entrada en un nuevo vectorial con 2 capas."
-#~ msgid "%d points written to output vector map"
-#~ msgstr "%d puntos escritos en el mapa vectorial de salida"
-#~ msgid "Creates a vector map from ASCII points file or ASCII vector file."
-#~ msgstr "Crea un mapa vectorial a partir de archivo de puntos ASCII o archivo ASCII vectorial."
-#~ msgid "Creates a new vector as a read-only link to OGR layer."
-#~ msgstr "Crea un nuevo vectorial como un enlace de sólo lectura a una capa OGR."
-#~ msgid "Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
-#~ msgstr "Umbral en unidades de mapa, un valor para cada herramienta (por omisión: 0.0[,0.0,...])"
-#~ msgid "%d lines / boundaries removed"
-#~ msgstr "%d líneas / contornos eliminados"
-#~ msgid "Attribute table column with values to interpolate"
-#~ msgstr "Columna de la tabla de atributos con valores a interpolar"
-#~ msgid "No data points found"
-#~ msgstr "No se han encontrado puntos de datos"
-#~ msgid "Lines buffers... "
-#~ msgstr "Buffers de líneas... "
-#~ msgid "Difference in x,y direction for moving feature or vertex"
-#~ msgstr "Diferencia en dirección X, Y para mover elemento o vértice"
-#~ msgid "Error reading ASCII file: '%s'"
-#~ msgstr "Error al leer el archivo ASCII: '%s'"
-#~ msgid "Outputs basic information about a user-specified vector map."
-#~ msgstr "Muestra información básica sobre un mapa vectorial especificado por el usuario."
-#~ msgid "Displaying column types/names for database connection of layer %d:"
-#~ msgstr "Mostrando tipos/nombres de columna para la conexión a base de datos de la capa %d:"
-#~ msgid "Map scale:       1:%d"
-#~ msgstr "Escala del mapa:     1:%d"
-#~ msgid "Map format:      %s"
-#~ msgstr "Formato del mapa:    %s"
-#~ msgid "Name of creator: %s"
-#~ msgstr "Nombre del creador:  %s"
-#~ msgid "Organization:    %s"
-#~ msgstr "Organización:        %s"
-#~ msgid "Source date:     %s"
-#~ msgstr "Fecha del origen:    %s"
-#~ msgid "  Digitization threshold: %s"
-#~ msgstr "  Umbral de digitalización: %s"
-#~ msgid "  Comments:"
-#~ msgstr "  Comentarios:"
-#~ msgid "Extrudes flat vector object to 3D with defined height."
-#~ msgstr "Eleva objetos vectoriales planos a 3D con alturas definidas."
-#~ msgid "vector, category"
-#~ msgstr "vectorial, categroria"
-#~ msgid "Attach, delete or report vector categories to map geometry."
-#~ msgstr "Acjuntar, borrar o informar categorías del vectorial a la geometría del mapa."
-#~ msgid "Output surface raster map (elevation)"
-#~ msgstr "Producir mapa ráster de superficie (elevación)"
-#~ msgid "Output cross-validation errors vector point file"
-#~ msgstr "Producir archivo de puntos vectorial de errores de validación cruzada"
-#~ msgid "Output vector map showing quadtree segmentation"
-#~ msgstr "Mapa vectorial de salida que muestre segmentación quadtree"
-#~ msgid "Output vector map showing overlapping windows"
-#~ msgstr "Producir mapa vectorial que muestre ventanas solapadas"
-#~ msgid "Name of the attribute column with values to be used for approximation (if layer>0)"
-#~ msgstr "Nombre de la columna de atributos con valores a usar para la aproximación (si capa>0)"
-#~ msgid ""
-#~ "Processing all selected output files\n"
-#~ "will require %d bytes of disk space for temp files"
-#~ msgstr ""
-#~ "Procesar todos los archivos de salida seleccionados\n"
-#~ "necesitará %d bytes en disco para archivos temporales"
-#~ msgid "Cannot write raster maps -- try to increase resolution"
-#~ msgstr "No se pueden escribir los mapas ráster -- intente aumentar la resolución"
-#~ msgid "Print all map connection parameters and exit in shell script style"
-#~ msgstr "Imprimir todos los parámetros de conexión del mapa y salir en estilo de script de consola"
-#~ msgid "Vector map <%s> is connected by:"
-#~ msgstr "El mapa vectorial <%s> está conectado por:"
-#~ msgid "Exports GRASS vector map layers to DXF file format."
-#~ msgstr "Exporta capas vectoriales de GRASS a formato de archivo DXF."
-#~ msgid "Unable to determine raster cell type"
-#~ msgstr "No se puede determinar el tipo de celda ráster"
-#~ msgid "OGR driver: column '%s', OGR type %d  is not supported"
-#~ msgstr "Controlador OGR: columna '%s', tipo OGR %d no soportado"
-#~ msgid "Prints/sets general DB connection for current mapset and exits."
-#~ msgstr "Imprime/establece la conexión general a la base de datos para el directorio de mapas actual y sale."
-#~ msgid "database, SQL"
-#~ msgstr "base de datos, SQL"
-#~ msgid "Name of file with sql statement"
-#~ msgstr "Nombre de archivo con sentencia SQL"
-#~ msgid "The password was stored in file"
-#~ msgstr "La contraseña se guardó en archivo"
-#~ msgid "raster, elevation"
-#~ msgstr "ráster, elevación"
-#~ msgid "Convert coordinates from one projection to another (cs2cs frontend)."
-#~ msgstr "Convierte coordenadas de una proyección a otra (interfaz cs2cs)."
-#~ msgid "Input coordinate file (omit to read from stdin)"
-#~ msgid "Images"
-#~ msgstr "Imágenes"
-#~ msgid "Compression for PNG files"
-#~ msgstr "Compresión para archivos PNG"
-#~ msgid "PostScript"
-#~ msgstr "PostScript"
-#~ msgid "Do not crop away margins"
-#~ msgstr "No cortar los márgenes"
-#~ msgid "raster, tiling"
-#~ msgstr "ráster, teselado"
-#~ msgid "general, extensions"
-#~ msgstr "general, extensiones"
-#~ msgid "display, diagram"
-#~ msgstr "mostrar, diagrama"
-#~ msgid "Reports geometry statistics for vectors."
-#~ msgstr "Informa estadísticas de geometría para vectoriales."
-#~ msgid "Raster map to use as MASK"
-#~ msgstr "Mapa ráster a usar como MÁSCARA"
-#~ msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
-#~ msgstr "Valores de categoría a usar para MÁSCARA (formato: 1 2 3 thru 7 *)"
-#~ msgid "Create inverse MASK from specified 'maskcats' list"
-#~ msgstr "Crear MASK inversa a partir de la lista 'maskcats' especificada"
-#~ msgid "Remove existing MASK (overrides other options)"
-#~ msgstr "Eliminar MÁSCARA existente (ignora otras opciones)"
-#~ msgid "Name of color column to populate"
-#~ msgstr "Nombre de la columna de color a mostrar"
-#~ msgid "Name of vector polygon map"
-#~ msgstr "Nombre del mapa de polígono vectorial"
-#~ msgid "Name of raster map to calculate statistics from"
-#~ msgstr "Nombre del mapa ráster del que calcular estadísticas"
-#~ msgid "calculates univariate statistics from a GRASS raster map"
-#~ msgstr "Calcula estadísticas univariantes a partir de un mapa ráster de GRASS."
-#~ msgid "C"
-#~ msgstr "C"
-#~ msgid "Show help"
-#~ msgstr "Mostrar ayuda"
-#~ msgid "Folder to save downloaded data to"
-#~ msgstr "Carpeta en la que guardar los datos descargados"
-#~ msgid "Layer number. If -1, all layers are extracted."
-#~ msgstr "Número de capa. Si es -1, se extraen todas las capas."
-#~ msgid "Import GetFeature from WFS"
-#~ msgstr "Importar GetFeature desde WFS"
-#~ msgid "raster, landscape structure analysis"
-#~ msgstr "ráster, análisis de estructura del paisaje"
-#~ msgid "Import of SPOT VGT NDVI file into a raster map"
-#~ msgstr "Importar archivo SPOT VGT NDVI a un mapa ráster"
-#~ msgid "existing SPOT VGT NDVI HDF file (0001_NDV.HDF)"
-#~ msgstr "archivo SPOT VGT NDVI HDF existente (0001_NDV.HDF)"
-#~ msgid "imagery, rectify"
-#~ msgstr "imaginería, rectificar"
-#~ msgid "No camera reference file selected for group <%s>"
-#~ msgstr "No se ha seleccionado archivo de referencia de cámara para el grupo <%s>"
-#, fuzzy
-#~ msgid "raster, terrain analysis"
-#~ msgid "SECTION 3: Accumulating Surface Flow."
-#~ msgstr "SECCIÓN 3: acumulando flujo de superficie."
-#~ msgid "Eigen values:"
-#~ msgstr "Valores Eigen:"
-#, fuzzy
-#~ msgid "<%s> vector map will be interpolated"
-#~ msgstr "No se creará ningún dato vectorial."
-#, fuzzy
-#~ msgid "Auto-balancing of colors for LANDSAT images"
-#~ msgstr "Balance automático de colores para imágenes LANDSAT"
-#, fuzzy
-#~ msgid "displays spectral response at user specified locations in group or images"
-#~ msgstr "muestra la respuesta espectral en localizaciones especificadas por el usuario en grupo o imágenes"
-#, fuzzy
-#~ msgid "group input"
-#~ msgstr "entrada de grupo"
-#, fuzzy
-#~ msgid "write output to PNG image"
-#~ msgstr "escribir la salida a imagen PNG"
-#, fuzzy
-#~ msgid "label with coordinates instead of numbering"
-#~ msgstr "Etiquetar con coordenadas en vez de numeración"
-#, fuzzy
-#~ msgid "Reclasses a raster map greater or less than user specified area size (in hectares)"
-#~ msgstr "Reclasifica un mapa ráster mayor o menor que la superficie indicada por el usuario (en hectáreas)"
-#, fuzzy
-#~ msgid "lesser val option that sets the <= area size limit [hectares]"
-#~ msgstr "Opción de valor menor que establece el <= límite de tamaño de área (hectáreas)"
-#, fuzzy
-#~ msgid "greater val option that sets the >= area size limit [hectares]"
-#~ msgstr "Opción de valor mayor que establece el >= límite de tamaño de área (hectáreas)"
-#, fuzzy
-#~ msgid "1 class."
-#~ msgstr "%d clases."
-#~ msgid "Writing %s"
-#~ msgstr "Escribiendo %s"
-#~ msgid "To_map"
-#~ msgstr "A_mapa"
-#~ msgid "To layer"
-#~ msgstr "A la capa"
-#~ msgid "vector, attribute table"
-#~ msgstr "vectorial, tabla de atributos"
-#~ msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
-#~ msgstr "Nombre del mapa ráster de derivadas de X [m/m] o [pies/pies]"
-#~ msgid "Multiplier"
-#~ msgstr "Multiplicador"
-#~ msgid "Column(s)"
-#~ msgstr "Columna(s)"
-#~ msgid "Cannot open OGR data source '%s'"
-#~ msgstr "No se puede abrir el origen de datos OGR '%s'"
-#~ msgid "<%s> is an ilegal name"
-#~ msgstr "<%s> es un nombre no admitido"
-#, fuzzy
-#~ msgid "Direction raster found <%s>"
-#~ msgstr "Escribiendo mapa ráster <%s>"
-#, fuzzy
-#~ msgid "Input value: maximum length of surface flow in map units, for USLE"
-#~ msgstr "Valor de entrada: longitud máxima de flujo de superficie, para USLE"
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)"
-#~ msgstr "mi(llas),f(pies),me(tros),k(ilómetros),a(cres),h(ectáreas),d(grados)"
-#~ msgid "vector, spatial query"
-#~ msgstr "vectorial, consulta espacial"
-#, fuzzy
-#~ msgid "raster3d, voxel, statistics"
-#~ msgstr "ráster3D, estadísticas"
-#~ msgid "raster, export"
-#~ msgstr "ráster, exportar"
-#~ msgid "Exports a GRASS raster map to a binary array."
-#~ msgstr "Exporta un mapa raster de GRASS a una secuencia binaria."
-#, fuzzy
-#~ msgid "raster, color transformation"
-#~ msgstr "Haciendo transformación del registro"
-#~ msgid "raster, hydrology"
-#~ msgstr "raster, hidrología"
-#~ msgid "Raster map matrix filter."
-#~ msgstr "Filtro de matrices de mapas ráster."
-#, fuzzy
-#~ msgid "raster, export, png"
-#, fuzzy
-#~ msgid "raster, sun energy"
-#~ msgid "Name of the latitudes input raster map [decimal degrees]"
-#~ msgstr "Nombre del mapa ráster de latitudes de entrada [grados decimales]"
-#~ msgid "Import a binary raster file into a GRASS raster map."
-#~ msgstr "Importar un archivo raster binario a una mapa raster de GRASS."
-#, fuzzy
-#~ msgid "raster, rescale"
-#~ msgid "raster, export, color table"
-#~ msgstr "raster, exportar, color de tabla"
-#, fuzzy
-#~ msgid "raster, map management"
-#, fuzzy
-#~ msgid "raster, geometry"
-#~ msgstr "ráster, imaginería"
-#, fuzzy
-#~ msgid "raster, quantization"
-#~ msgstr "ráster, proyección"
-#~ msgid "Illegal delete request"
-#~ msgstr "Solicitud de borrado no permitida"
-#, fuzzy
-#~ msgid "raster, transect"
-#~ msgid "raster, random"
-#~ msgstr "raster, aleatorio"
-#, fuzzy
-#~ msgid "raster, viewshed"
-#~ msgstr "ráster, series"
-#, fuzzy
-#~ msgid "raster, fire"
-#~ msgstr "ráster, importar"
-#, fuzzy
-#~ msgid "raster, profile"
-#~ msgid "raster, projection, transformation"
-#~ msgstr "raster, proyección,transformación"
-#~ msgid "Re-projects a raster map from one location to the current location."
-#~ msgstr "Reproyecta un mapa ráster desde una localización a la localización actual."
-#~ msgid "Resolution of output map"
-#~ msgstr "Resolución del mapa de salida"
-#, fuzzy
-#~ msgid "Raster File Series to MPEG Conversion."
-#~ msgstr "Programa de conversión de series de archivos ráster a MPEG."
-#~ msgid ""
-#~ "Convert on the fly, use less disk space\n"
-#~ "\t(requires r.out.ppm with stdout option)"
-#~ msgstr ""
-#~ "Convertir al vuelo, usar menos espacio de disco\n"
-#~ "\t(requiere r.out.ppm con la opción stdout)"
-#, fuzzy
-#~ msgid "CHILD[pid = %i]: unable to open <%s> mask ... continuing without!"
-#~ msgstr "CHILD[pid = %i]: no se puede abrir la máscara %s ... ¡¡¡Se continúa sin ella!!!"
-#~ msgid "GIS format to write (case sensitive, see also -l flag)"
-#~ msgstr "Formato GIS a escribir (sensible a mayúsculas, ver también la opción -l)"
-#~ msgid "raster, sun position"
-#~ msgstr "raster, posición del sol"
-#~ msgid "raster, thin"
-#~ msgstr "raster, teselado"
-#, fuzzy
-#~ msgid "Thins non-zero cells that denote linear features in a raster map."
-#~ msgstr "Adelgaza celdas no cero que indican elementos lineales en una capa de mapa ráster."
-#~ msgid "fp: Data range is %.25f to %.25f\n"
-#~ msgstr "fp: el rango de datos es %.25f a %.25f\n"
-#~ msgid "raster, metadata, timestamp"
-#~ msgstr "raster, metadatos, timestamp"
-#~ msgid "raster, conversion, vectorization"
-#~ msgstr "raster, conversión, vectorización"
-#, fuzzy
-#~ msgid "raster, category"
-#, fuzzy
-#~ msgid "raster, volume"
-#~ msgstr "Valor ráster"
-#, fuzzy
-#~ msgid "raster, distance"
-#, fuzzy
-#~ msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)."
-#~ msgstr "Construcción de curvas de pendiente (líneas de flujo), longitudes de ruta de flujo y densidades de líneas de flujo (áreas pendiente arriba) a partir de un modelo de elevación digital (MDT) ráster"
-#, fuzzy
-#~ msgid "raster, querying"
-#~ msgid "raster, import, conversion"
-#~ msgstr "ráster, importar, conversión"
-#~ msgid "general, version"
-#~ msgstr "general, versión"
-#~ msgid "Copies available data files in the user's current mapset search path and location to the appropriate element directories under the user's current mapset."
-#~ msgstr "Copia archivos de datos disponibles en la ruta de búsqueda del directorio de datos y localización actuales del usuario a los directorios de elementos adecuados bajo el directorio de mapas actual de usuario."
-#~ msgid "[%s@%s] is a base map for [%s]. Remove forced."
-#~ msgstr "[%s@%s] es un mapa base para [%s]. Eliminar forzado."
-#~ msgid "[%s@%s] is a base map. Remove reclassed map first: %s"
-#~ msgstr "[%s@%s] es un mapa base. Eliminar mapas reclasificados primero: %s"
-#~ msgid "Mapset to list (default: current search path)"
-#~ msgstr "Directorio de mapas a listar (predeterminado: ruta de búsqueda actual)"
-#~ msgid "general, settings, search path"
-#~ msgstr "general, configuraciones, ruta de búsqueda"
-#~ msgid "%s: removed"
-#~ msgstr "%s: eliminado"
-#~ msgid "format"
-#~ msgstr "formato"
-#, fuzzy
-#~ msgid "display, raster, profile"
-#~ msgstr "mostrar ráster"
-#~ msgid "Print name of current frame"
-#~ msgstr "Imprimir el nombre del marco actual"
-#~ msgid "name"
-#~ msgstr "nombre"
-#, fuzzy
-#~ msgid "display, distance"
-#, fuzzy
-#~ msgid "display, menu"
-#~ msgstr "mostrar, configuración"
-#, fuzzy
-#~ msgid "display, map management"
-#, fuzzy
-#~ msgid "display, metadata"
-#~ msgid "Placement as percentage of screen coordinates (0,0 is lower left)"
-#~ msgstr "Ubicación como porcentaje de coordenadas de pantalla (0,0 es abajo a la izquierda)"
-#~ msgid "display, raster, RGB"
-#~ msgstr "mostrar, raster, RGB"
-#, fuzzy
-#~ msgid "display, position, querying"
-#~ msgstr "visualización, trabajo en red"
-#~ msgid "The screen coordinates for top-left corner of label ([0,0] is top-left of frame)"
-#~ msgstr "Las coordenadas de pantalla para la esquina superior izquierda de la etiqueta ([0,0] es superior izquierda del marco)"
-#, fuzzy
-#~ msgid "display, geometry"
-#~ msgstr "muestra, exporta"
-#, fuzzy
-#~ msgid "display, color transformation"
-#~ msgstr "vectorial, transformación"
-#, fuzzy
-#~ msgid "Unknown item type in pad: %s"
-#~ msgstr "Tipo de objeto desconocido en : %s"
-#, fuzzy
-#~ msgid "display, histogram, statistics"
-#, fuzzy
-#~ msgid "display, paint labels"
-#, fuzzy
-#~ msgid "display, visualization, raster, vector, raster3d"
-#~ msgstr "visualización"
-#, fuzzy
-#~ msgid "display, zoom"
-#~ msgid "Unable to display areas, topology not available"
-#~ msgstr "No se pueden mostrar areas, topología no disponible"
-#~ msgid "Unable to display lines by id, topology not available"
-#~ msgstr "No se pueden mostrar líneas por id, topología no disponible"
-#, fuzzy
-#~ msgid "vector, raster, resample"
-#, fuzzy
-#~ msgid "vector, network, allocation"
-#, fuzzy
-#~ msgid "vector, networking, maintenance"
-#~ msgstr "Mantenimiento de redes."
-#, fuzzy
-#~ msgid "vector, network, isolines"
-#, fuzzy
-#~ msgid "vector, network, salesman"
-#, fuzzy
-#~ msgid "vector, geometry, statistics"
-#~ msgstr "vectorial, informe, estadísticas"
-#~ msgid "vector, network, shortest path"
-#~ msgstr "vectorial, red, ruta más corta"
-#~ msgid "vector, import, sites"
-#~ msgstr "vectorial, importar, sites"
-#~ msgid "Converts files in DXF format to GRASS vector map format."
-#~ msgstr "Convierte archivos en formato DXF a formato de mapa vectorial de GRASS."
-#~ msgid "Converts GRASS vector map to one of the supported OGR vector formats."
-#~ msgstr "Convierte un mapa vectorial de GRASS a uno de los formatos vectoriales soportados por OGR."
-#~ msgid "Feature type(s). Combinations not supported by all output formats. Default: first type found in input."
-#~ msgstr "Tipo(s) de elemento. Las combinaciones no están soportadas para todos los formatos de salida. Por defecto: Primer tipo encontrado en entrada. "
-#~ msgid "%d areas found, but not requested to be exported. Verify 'type' parameter."
-#~ msgstr "%d area(s) encontrada, pero no se ha solicitado exportarlas. Verificar el parámetro 'tipo'."
-#~ msgid "%d kernel(s) found, but not requested to be exported. Verify 'type' parameter."
-#~ msgstr "%d kernel(s) encontrado, pero no se ha solicitado exportarlos. Verificar el parámetro 'tipo'."
-#~ msgid "No points found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "%d punto(s) encontrado, pero se ha solicitado exportarlos. Se omitirá este tipo de geometría."
-#~ msgid "No lines found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "%d línea(s) encontrada, pero se ha solicitado exportarlas. Se omitirá este tipo de geometría."
-#~ msgid "No boundaries found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "No se han encontrado contornos, pero se ha solicitado exportarlos. Se omitirá este tipo de geometría."
-#~ msgid "No areas found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "No se han encontrado áreas, pero se ha solicitado exportarlas. Se omitirá este tipo de geometría."
-#~ msgid "No centroids found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "No se han encontrado centroides, pero se ha solicitado exportarlos. Se omitirá esta geometría."
-#~ msgid "No faces found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "No se han encontrado caras, pero se ha solicitado exportarlas. Se omitirá este tipo de geometría."
-#~ msgid "No kernels found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "No se han encontrado kernels, pero se ha solicitado exportarlos. Se omitirá este tipo de geometría."
-#~ msgid "No volumes found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "No se han encontrado volúmenes, pero se ha solicitado exportarlos. Se omitirá este tipo de geometría."
-#~ msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
-#~ msgstr "El mapa vectorial <%s> es 3D. Use opciones de creación de capa específicas para el formato (parámetro 'Ico') o etiqueta '-z' para exportar en 3D en vez de 2D (predeterminado)"
-#~ msgid "Exporting %i geometries..."
-#~ msgstr "Exportando %i geometrías..."
-#~ msgid "vector, projection, transformation"
-#~ msgstr "vectorial, proyección, transformación"
-#~ msgid "vector, network, articulation points"
-#~ msgstr "vectorial, red, puntos de articulación"
-#~ msgid "vector, network, connectivity"
-#~ msgstr "vector, red, conectividad"
-#, fuzzy
-#~ msgid "vector, geometry, triangulation"
-#~ msgstr "vectorial, geometría, topología"
-#, fuzzy
-#~ msgid "vector, network, steiner tree"
-#~ msgid "Type: %s"
-#~ msgstr "Tipo: %s"
-#~ msgid ""
-#~ "\n"
-#~ "New vector map <%s> boundary coordinates:"
-#~ msgstr ""
-#~ "\n"
-#~ "Coordenadas del contorno del nuevo mapa vectorial <%s>:"
-#~ msgid "vector, network, flow"
-#~ msgstr "vectorial, red, flujo"
-#~ msgid "Calculate geometry distances instead of table data."
-#~ msgstr "Calculando distancias geométricas en lugar de los datos de la tabla."
-#~ msgid "Unable select categories from table <%s>"
-#~ msgstr "No se pueden seleccionar registros de la tabla <%s>"
-#~ msgid "Unparsable longitude value: [%s]"
-#~ msgstr "Valor de longitud no analizable:[%s]"
-#~ msgid "Unparsable latitude value: [%s]"
-#~ msgstr "Valor de latitud no analizable:  [%s]"
-#, fuzzy
-#~ msgid "vector, external, import"
-#~ msgstr "vectorial, exportar"
-#~ msgid ""
-#~ "\n"
-#~ "%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
-#~ msgstr ""
-#~ "\n"
-#~ "%d vértices de la entrada %d (vértices del tipo dado) eliminados, esto es %.2f %%"
-#, fuzzy
-#~ msgid "vector, geometry, buffer"
-#~ msgstr "vectorial, geometría, 3D"
-#~ msgid "Print types/names of table columns for specified layer instead of info"
-#~ msgstr "Imprimir tipos/nombre de columnas de tabla para la capa especificada, en vez de información"
-#~ msgid "Use z-coordinates (3D vector only)"
-#~ msgstr "Utilizar coordenadas-z (sólo 3D vectorial)"
-#~ msgid "vector, network, centrality measures"
-#~ msgstr "vectorial, red, medidas de centralidad"
-#~ msgid "vector, network, components"
-#~ msgstr "vectorial, red, componentes"
-#~ msgid "vector, network, spanning tree"
-#~ msgstr "vectorial, red, spanning tree"
-#, fuzzy
-#~ msgid "miscellaneous, distance"
-#~ msgstr "miscelánea"
-#~ msgid "Reading file [%s]..."
-#~ msgstr "Leyendo archivo [%s]..."
-#~ msgid "List paper formats ( name width height left right top bottom(margin) )"
-#~ msgstr "Listar formatos de papel ( nombre anchura altura izquierda derecha arriba abajo (margen) )"
-#~ msgid "PostScript output file"
-#~ msgstr "Archivo PostScript de salida"
-#~ msgid "PostScript file [%s] successfully written."
-#~ msgstr "Archivo PostScript [%s] escrito con éxito."
-#~ msgid "Reading raster maps in group <%s> ..."
-#~ msgstr "Leyendo mapas ráster en el grupo <%s> ..."
-#~ msgid "Scale set to %s."
-#~ msgstr "Escala fijada a %s."
-#, fuzzy
-#~ msgid "database, attribute table, connection settings"
-#~ msgstr "base de datos, tabla de atributos"
-#~ msgid "Calculates univariate statistics from a raster map based on vector polygons and uploads statistics to new attribute columns."
-#~ msgstr "Calcula estadísticas univariantes a partir de un mapa raster basadas en polígonos vectoriales y carga las estadísticas en nuevas columnas de atributos."
-#~ msgid "D"
-#~ msgstr "D"
-#, fuzzy
-#~ msgid "imagery, edges"
-#~ msgstr "Escribiendo vértices..."
-#~ msgid ""
-#~ "Input raster map <%s> does not exist in group <%s>.\n"
-#~ " Try:\n"
-#~ msgstr ""
-#~ "El mapa ráster de entrada <%s> no existe en el grupo. <%s>.\n"
-#~ "Intentar:\n"
-#~ msgid "into  <%s@%s> (location <%s>) ... %s"
-#~ msgstr "en  <%s@%s> (localización <%s>) ... %s"
-#, fuzzy
-#~ msgid "imagery, geometry"
-#, fuzzy
-#~ msgid "imagery, statistics"
-#~ msgstr "ráster, imaginería, estadísticas"
-#~ msgid "Calculating camera angle to local surface..."
-#~ msgstr "Calculando ángulo de la cámara a la superficie local..."
-#~ msgid "Could not open elevation raster"
-#~ msgstr "No se pudo abrir raster de elevaciones"
-#~ msgid "Could not read REF file for group <%s>"
-#~ msgstr "No fue posible leer archivo REF para el grupo <%s>"
-#~ msgid "Error reading segment file"
-#~ msgstr "Error leyendo el archivo de segmentos"
-#~ msgid ""
-#~ "Control Z Point file for group [%s] in [%s] \n"
-#~ " \n"
-#~ msgstr ""
-#~ "Archivo de Punto de Control Z [%s] en [%s]\n"
-#~ " \n"
-#~ msgid "Computing equations..."
-#~ msgstr "Calculando ecuaciones..."
-#~ msgid "Poorly placed Control Points!\n"
-#~ msgstr "Puntos de Control mal colocados!\n"
-#~ msgid "Can not generate the transformation equation.\n"
-#~ msgstr "No se puede generar la ecuación de transformación.\n"
-#~ msgid "No active Control Points!\n"
-#~ msgstr "Puntos de Control no activos!\n"
-#~ msgid ""
-#~ "Reference Point file for group [%s] in [%s] \n"
-#~ " \n"
-#~ msgstr ""
-#~ "Archivo de Punto de Referencia para grupo [%s] en [%s]  \n"
-#~ " \n"
-#~ msgid "Poorly placed Reference Points!\n"
-#~ msgstr "Puntos de Referencia mal colocados!\n"
-#~ msgid "No active Reference Points!\n"
-#~ msgstr "No hay Puntos de referencia activos!\n"
-#~ msgid "Target information for group <%s> missing.\n"
-#~ msgstr "Falta información de destino para el grupo <%s>.\n"
-#~ msgid "Target location <%s> not found\n"
-#~ msgstr "Región <%s> no encontrada \n"
-#~ msgid "No elevation available at row = %d, col = %d"
-#~ msgstr "No hay elevaciones disponibles en la fila= %d, col = %d"
-#~ msgid "Could not read REF file for group [%s]"
-#~ msgstr "No se pudo leer archivo REF para el grupo [%s]"
-#~ msgid ""
-#~ "\n"
-#~ "Rectify all images in the group? "
-#~ msgstr ""
-#~ "\n"
-#~ "Rectificar todas las imágenes del grupo?"
-#~ msgid ""
-#~ "\n"
-#~ "Choose another extension? "
-#~ msgstr ""
-#~ "\n"
-#~ "¿Escoger otra extensión?"
-#~ msgid "Enter a name for the camera angle map:"
-#~ msgstr "Entrar un nombre para el mapa del ángulo de la cámara:"
-#~ msgid "Map name <%s> is illegal"
-#~ msgstr "Nombre de mapa <%s> no admitido"
-#~ msgid ""
-#~ "\n"
-#~ "Overwrite maps in target location/mapset? "
-#~ msgstr ""
-#~ "\n"
-#~ "Sobrescribir mapas en localización/directorio de mapas destino?"
-#~ msgid "Please select one of the following interpolation methods\n"
-#~ msgstr "Por favor seleccione uno de los siguientes métodos de interpolación\n"
-#~ msgid " 1. nearest neighbor\n"
-#~ msgstr "1. vecino más próximo\n"
-#, fuzzy
-#~ msgid "imagery, map management"
-#, fuzzy
-#~ msgid "imagery, classification"
-#~ msgstr "Clasificación de puntos"
-#~ msgid "Raster elevation file name"
-#~ msgstr "Nombre del archivo de elevación ráster"
-#, fuzzy
-#~ msgid "File containing initial signatures"
-#~ msgstr "Archivo que contiene las firmas iniciales"
-#~ msgid "Input raster map being fft"
-#~ msgstr "Mapa ráster de entrada transformándose (FFT)"
-#, fuzzy
-#~ msgid "Name of the output walkers vector points map"
-#~ msgstr "Nombre vectorial puntos"
-#~ msgid "Raster to remove"
-#~ msgstr "Ráster a eliminar"
-#~ msgid "Loading maps: "
-#~ msgstr "Cargando mapas: "
-#~ msgid "The initial piezometric head in [m]"
-#~ msgstr "La altura piezométrica inicial en [m]"
-#~ msgid "Specific yield in 1/m"
-#~ msgstr "Rendimiento específico de 1/m"
-#~ msgid "NULL value computed (row %d, col %d)"
-#~ msgstr "Calculado valor NULO (fila %d, col %d)"
-#~ msgid "The leakage coefficient of the river bed in [1/s]."
-#~ msgstr "El coeficiente de goteo del lecho del río en [1/s]."
-#~ msgid "The leakage coefficient of the drainage bed in [1/s]"
-#~ msgstr "El coeficiente de goteo del lecho de drenaje en [1/s]"
-#~ msgid "Threshold to calculate for method=threshold"
-#~ msgstr "Umbral a calcular con el método=umbral"
-#~ msgid "Enable MFD flow (default is SFD (D8))"
-#~ msgstr "Permitir flujo MFD (por defecto es SFD (D8))"
-#~ msgid "Maximum memory to be used was smaller than 3 MB, set to default = 300 MB."
-#~ msgstr "La memoria máxima a utilizar es más pequeña que 3MB, definir por defecto = 300 MB."
-#~ msgid "Checking GDAl data type and nodata value"
-#~ msgstr "Comprobando tipos de datos GDAl y valores sin datos"
-#~ msgid "Range to be exported: %f - %f"
-#~ msgstr "Rango a exportar: %f - %f"
-#~ msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default: random)"
-#~ msgstr "Seed aleatorio (SEED_MIN >= valor >= SEED_MAX) (por defecto: aleatorio)"
-#~ msgid "No (quiet) description during run"
-#~ msgstr "No (quiet) tiene lugar descripción durante la ejecución"
-#~ msgid "Could not read east bufferzone size. Aborting."
-#~ msgstr "No se pudo leer el tamaño de la zona buffer este. Cancelando."
-#~ msgid "Could not read west bufferzone size. Aborting."
-#~ msgstr "No se pudo leer el tamaño de la zona buffer oeste. Cancelando."
-#~ msgid "Could not read south bufferzone size. Aborting."
-#~ msgstr "No se pudo leer el tamaño de la zona buffer sud. Cancelando."
-#~ msgid "Could not read north bufferzone size. Aborting."
-#~ msgstr "No se pudo leer el tamaño de la zona buffer norte. Cancelando."
-#~ msgid "** no mapsets **\n"
-#~ msgstr "** no hay directorios de mapas **\n"
-#~ msgid ""
-#~ "Format error: <%s>\n"
-#~ "Line: %d\n"
-#~ "%s"
-#~ msgstr ""
-#~ "Error de formato:  <%s>\n"
-#~ "Línea: %d\n"
-#~ "%s"
-#~ msgid "%s: missing"
-#~ msgstr "%s: falta"
-#~ msgid "One-character output separator, newline, comma, space, or tab"
-#~ msgstr "Separador de salida de un caracter, nueva línea, coma, espacio o tab"
-#~ msgid "Default value: GRASS_GUI if defined, otherwise wxpython"
-#~ msgstr "Valor por defecto: GRASS_GUI si está definido, en caso contrario wxpython"
-#~ msgid "The old d.m GUI is not available for WinGRASS"
-#~ msgstr "La antigua d.m GUI no está disponible para WinGRASS"
-#~ msgid "Prompts the user to select a GRASS data base file from among files displayed in a menu on the graphics monitor."
-#~ msgstr "Induce al usuario a seleccionar un archivo de la base de datos de GRASS de los archivos mostrados en un menú del monitor gráfico"
-#~ msgid "Database element, one word description"
-#~ msgstr "Elemento de la base de dados, una descripción de una palabra"
-#~ msgid "** no %s files found **\n"
-#~ msgstr "** no %s se encontraron archivos **\n"
-#~ msgid "Click here to CONTINUE\n"
-#~ msgstr "Clicar aquí para CONTINUAR\n"
-#~ msgid "<%s> is a floating point map. Ignoring [lines] and drawing continuous color ramp"
-#~ msgstr "<%s> es un mapa de coma flotante. Ignorando [línes] y dibujando continuamente el gradiente de colores"
-#~ msgid "<%s> is a floating point map. Ignoring [cols] and drawing continuous color ramp"
-#~ msgstr "<%s> es un mapa de coma flotante. Ignorando [cols] y dibujando rampa de color continua"
-#~ msgid "shape;Display geometry of features;cat;Display category numbers of features;topo;Display topology information (nodes, edges);dir;Display direction of linear features;attr;Display selected attribute based on 'attrcol';zcoor;Display z-coordinate of features (only for 3D vector maps)"
-#~ msgstr "forma;Mostrar geometria de los elementos;cat;Mostrar los números de categoria de los elementos;topo;Mostrar información topológica (nodos, bordes);dir;Mostrar dirección de los elementos lineales;atr;Mostrar los atributos seleccionados basados en 'attrcol';zcoor;Mostrar coordenada-z de los elementos (sólo para mapas vectoriales 3D)"
-#~ msgid "Query layer number (read from)"
-#~ msgstr "Número de capa de consulta (leer de)"
-#~ msgid "Need either 3D vector or layer and column with z values"
-#~ msgstr "Se necesita o vector 3D o capa y columna con los valores z"
-#~ msgid "%d boundaries were deleted, input areas are not preserved"
-#~ msgstr "%d contornos fueron eliminados, las áreas de entrada no se conservan"
-#~ msgid "New centroids were calculated, attribute attachment may be changed"
-#~ msgstr "Se han calculado nuevos centroides, el documento adjunto de atributos -attribute attachment- puede haber cambiado"
-#~ msgid "Areas may have disappeared and/or area attribute attachment may have changed"
-#~ msgstr "Las áreas pueden haber desaparecido y/o el documento adjunto de atributos -attribute attachment- puede haber cambiado"
-#~ msgid "Column name and type (i.e. INTEGER, DOUBLE PRECISION) for z values"
-#~ msgstr "Column name y tipo (por ejemplo: INTEGER, DOUBLE PRECISION) para valores z"
-#~ msgid "If type is not given then DOUBLE PRECISION is used. Writes Z data to column instead of 3D vector."
-#~ msgstr "Si no se facilita el tipo, entonces se utiliza el tipo DOUBLE PRECISION. Escribe los datos Z a la columna en lugar del vector 3D."
-#~ msgid "v.random can't create 3D vector and attribute table at same time"
-#~ msgstr "v.random no puede crear al mismo tiempo un vector 3D y una tabla de atributos"
-#~ msgid "Export numeric attribute table fields as VTK scalar variables"
-#~ msgstr "Exportar campos de la tabla de atributos numéricos como variables escalares VTK"
-#~ msgid "Cannot export attribute table fields for layer < 1. Skipping export"
-#~ msgstr "No se puede exportar los campos de atributos de la capa <1. Saliendo de la exportación. "
-#~ msgid "Parameter '%s' ignored in standard mode"
-#~ msgstr "Parámetro '%s' ignorado en el modo estándar"
-#~ msgid "Feature has more categories. Only first category (%d) is exported."
-#~ msgstr "El elemento tiene más categorías. Sólo la primera categoría (%d) se exporta."
-#~ msgid "Numeric column to give precedence in case of overlapping labels. The label with a smaller weight is hidden."
-#~ msgstr "Columna numérica a la que dar prioridad en el caso de etiquetas que se solapen. La etiqueta con menor peso se oculta."
-#~ msgid "Skipping all boundaries that are not part of an area."
-#~ msgstr "Obviando todos los límites que no son parte de un área."
-#~ msgid "Volumes will be exported as sets of faces."
-#~ msgstr "Los volúmenes se exportarán como conjuntos de caras."
-#~ msgid "Could not determine input map's feature type(s)."
-#~ msgstr "No se ha podido determinar el tipo(s) de elemento(s) del mapa de entrada."
-#~ msgid "The map contains islands. To preserve them in the output map, use the -c flag"
-#~ msgstr "El mapa tiene islas. Para mantenerlas en el mapa de salida, utilizar la -c flag"
-#~ msgid "For vector lines reads their vertices"
-#~ msgstr "Para líneas vectoriales lee sus vértices"
-#~ msgid "Unused"
-#~ msgstr "No utilizado/a"
-#~ msgid "This does nothing. It is retained for backwards compatibility"
-#~ msgstr "Esto no hace nada. Se retiene para compatibilidad hacia atrás"
-#~ msgid "This is an alias to the distance option. It is retained for backwards compatibility"
-#~ msgstr "Es un alias a la opción distancia. Es retenido para conservar compatibilidad hacia atrás"
-#~ msgid "The buffer option has been replaced by the distance option and will be removed in future."
-#~ msgstr "La opción buffer se ha reemplazado por la opción distancia y será eleminada en el futuro."
-#~ msgid "Power parameter; greater values assign greater influence to closer points"
-#~ msgstr "Parámetro power; los valores más altos asignan una mayor influencia a los puntos más próximos"
-#~ msgid "Creating new DB connection based on default mapset settings..."
-#~ msgstr "Creando nueva conexión DB basada en las configuraciones por defecto del directorio de mapas..."
-#~ msgid "Both z-coordinate and zcol attribute defined, only one is allowed"
-#~ msgstr "Se ha definido tanto la z-coordenada como el atributo zcol, solo se permite definir uno"
-#~ msgid "Only smoothing column defined, zcol or -z flag is missing"
-#~ msgstr "Solo la columna smoothing está definida, falta zcol o -z flag"
-#~ msgid "When printing, limit to layer specified by the layer option"
-#~ msgstr "Cuando se imprime, límite de la capa especificado por la opción de capa"
-#~ msgid "Entering script mode ..."
-#~ msgstr "Entrando modo de script..."
-#~ msgid "Script style output in CSV format respecting the field separator settings"
-#~ msgstr "Estilo del script de salida en formato CSV respetando las configuraciones del separador de campos"
-#~ msgid "GeoTIFF creation option(s)"
-#~ msgstr "Opción(es) de creación de GeoTIFF"
-#~ msgid "GeoTIFF"
-#~ msgstr "GeoTIFF"
-#~ msgid "GeoTIFF metadata key(s) and value(s) to add"
-#~ msgstr "Clave(s) y valor(es) de metadatos GeoTIFF a añadir"
-#~ msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma."
-#~ msgstr "En la expresión  \"META-TAG=VALUE\", separar entradas múltiples con una coma."
-#~ msgid "Position of vertical map-legend separator (in percent)"
-#~ msgstr "Posición del separador vertical mapa-leyenda (en porcentaje)"
-#~ msgid "Set color rules for features in a vector using a numeric attribute column."
-#~ msgstr "Establecer normas de color para elementos vectoriales utilizando una columna de atributo numérico."
-#~ msgid "Map number show across the monitor"
-#~ msgstr "Número de mapa mostrado a través del monitor"
-#~ msgid "Map number show down the monitor"
-#~ msgstr "Número de mapa mostrado debajo del monitor"
-#~ msgid "Split horizontally not vertically"
-#~ msgstr "Dividir horizontalmente no verticalmente"
-#~ msgid "A single vector map can be connected to multiple database tables. This number determines which table to use"
-#~ msgstr "Un simple mapa vectorial puede estar cnectada a múltiples tablas de bases de datos. Este número determina qué tabla utilizar"
-#~ msgid "imagery, orthorectify"
-#~ msgstr "imaginería,ortorectificación"
-#~ msgid "Enter a camera reference file to be used with this imagery group"
-#~ msgstr "Entrar un archivo de referencia de cámara para ser utilizado en este grupo de imaginería"
-#~ msgid "Interactively mark fiducial or reseau points on an image."
-#~ msgstr "Interactivamente marca puntos fiduciales o Réseau sobre una imagen."
-#~ msgid "No camera reference file selected for group [%s]"
-#~ msgstr "No se ha seleccionada archivo de refeencia de cámara para group [%s]"
-#~ msgid "Raster map with camera angle relative to ground surface"
-#~ msgstr "Mapa raster con el ángulo de cámara en relación con la superficie del suelo"
-#~ msgid "No target elevation model selected for group <%s>"
-#~ msgstr "No hay modelo de elevación destino seleccionado para el grupo <%s>"
-#~ msgid "Run OPTION 7 of i.ortho.photo again!\n"
-#~ msgstr "Ejecutar otra vez OPTION 7 de  i.ortho.photo n!\n"
-#~ msgid "Run OPTION 7 of i.ortho.photo!\n"
-#~ msgstr "Ejecutar OPTION 7 de  i.ortho.photo!\n"
-#~ msgid "Run OPTION 5 of i.ortho.photo again!\n"
-#~ msgstr "Ejecutar OPTION 5 de i.ortho.photo otra vez!\n"
-#~ msgid "Run OPTION 5 of i.ortho.photo!\n"
-#~ msgstr "Ejecutar OPTION 5 de  i.ortho.photo!\n"
-#~ msgid " %d rows, %d cols (%ld cells) completed in "
-#~ msgstr " %d filas, %d cols (%ld celdas) terminadas en"
-#~ msgid " %.1f cells per minute\n"
-#~ msgstr "%.1f celdas por minuto\n"
-#~ msgid "Interactively select or modify the target elevation model."
-#~ msgstr "Interactivamente seleccionar o modificar el modelo de elevaciones objetivo"
-#~ msgid "Target information for group [%s] missing\n"
-#~ msgstr "Se perdió la información para group [%s]\n"
-#~ msgid "Poorly placed photo points for group [%s]"
-#~ msgstr "PUntos de la foto mal colocados para group [%s]"
-#~ msgid "Orthorectification cancelled"
-#~ msgstr "Ortorectificación cancelada"
-#~ msgid "No files in this group!"
-#~ msgstr "No hay archivos en este grupo!"
-#~ msgid ""
-#~ "\n"
-#~ "Rectify image <%s>? "
-#~ msgstr ""
-#~ "\n"
-#~ "Rectificar imagen <%s>? "
-#~ msgid ""
-#~ "\n"
-#~ "No images selected, orthorectification cancelled."
-#~ msgstr ""
-#~ "\n"
-#~ "No se han seleccionado imágenes, ortorectificación cancelada."
-#~ msgid "Enter an extension to be appended to rectified maps:"
-#~ msgstr "Entrar una extensión para agregar a los mapas rectificados:"
-#~ msgid ""
-#~ "\n"
-#~ "Compute local camera angle? "
-#~ msgstr ""
-#~ "\n"
-#~ "Calcular el ángulo de la cámara local? "
-#~ msgid ""
-#~ "\n"
-#~ "Choose another name? "
-#~ msgstr ""
-#~ "\n"
-#~ "Escoger otro nombre?"
-#~ msgid " 2. bilinear\n"
-#~ msgstr " 2. bilineal\n"
-#~ msgid " 3. bicubic\n"
-#~ msgstr " 3. bicúbico\n"
-#~ msgid " 4. bilinear with fallback\n"
-#~ msgstr "4. bilinear con retroceso\n"
-#~ msgid " 5. bicubic with fallback\n"
-#~ msgstr " 5. bicúbico con retroceso\n"
-#~ msgid "Enter amount of memory to use in MB, or\n"
-#~ msgstr "Introducir cantidad de memoria a utilizar en MB, o \n"
-#~ msgid "RETURN   use %d MB to keep all data in RAM\n"
-#~ msgstr "RETURN   utiliza %d MB para mantener todos los datos en RAM\n"
-#~ msgid "RETURN   use %d MB\n"
-#~ msgstr "RETURN   utiliza %d MB\n"
-#~ msgid "imagery, classification, supervised, MLC"
-#~ msgstr "imaginería, clasificación, supervisado, MLC"
-#~ msgid "imagery, classification, signatures"
-#~ msgstr "imaginería, clasificación, firmas"
-#~ msgid "raster, png"
-#~ msgstr "raster, png"
-#~ msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)"
-#~ msgstr "Simulación del transporte de sedimentos y de la erosión/deposición utilizando el método de la ruta de muestreo (SIMWE)"
-#~ msgid "Hardcopy PostScript map output utility."
-#~ msgstr "Utilidad de salida de mapas PostScript Hardcopy."
-#~ msgid "Calculates linear regression from two raster maps: y = a + b*x"
-#~ msgstr "Calcula la regresión lineal de dos mapas ráster: y = a + b*x"
-#~ msgid "Slower but accurate (applies to FP maps only)"
-#~ msgstr "Más lento pero exacto (se aplica solo a mapas FP)"
-#~ msgid "Create a MASK for limiting raster operation"
-#~ msgstr "Crear una MÁSCARA para limitar la operación ráster"
-#~ msgid "Import Mapgen or Matlab-ASCII vector maps into GRASS."
-#~ msgstr "Importar mapas vectoriales Mapgen o Matlab-ASCII a GRASS."
-#~ msgid "Ascii file containing spectral signatures"
-#~ msgstr "Archivo ASCII que contiene firmas espectrales"
-#~ msgid "Unable to read color file"
-#~ msgstr "No se puede leer el archivo de color"
-#, fuzzy
-#~ msgid ""
-#~ "Calculate the groundwater distance velocity vector field \n"
-#~ "and write the x, y, and z components to maps named name_[xyz].\n"
-#~ "Name is basename for the new 3D raster maps."
-#~ msgstr "Calcular "
-#, fuzzy
-#~ msgid "Calculates numerically transient, confined groundwater flow in three dimensions."
-#~ msgstr "Programa de cálculo numérico para flujos transientes de aguas subterráneas confinadas en tres dimensiones"
-#, fuzzy
-#~ msgid "The direct Cholesky solver do not work with sparse matrices"
-#~ msgstr "El solucionador directo cholesky no funciona con matrices dispersas"
-#, fuzzy
-#~ msgid "Converts a 3D raster map layer into an ASCII text file."
-#~ msgstr "Convierte una capa de mapa ráster 3D en un archivo de texto ASCII"
-#~ msgid ""
-#~ "Cannot create mask file: G3D_MASK already exists!\n"
-#~ " Use 'g.remove rast3d=G3D_MASK' to remove the existing mask."
-#~ msgstr ""
-#~ "No se puede crear archivo de máscara: ¡G3D_MASK ya existe!\n"
-#~ " Usa 'g.remove rast3d=G3D_MASK' para eliminar la máscara existente."
-#, fuzzy
-#~ msgid "Use the same resolution as the input 3D raster map for the 2D outputmaps, independent of the current region settings"
-#~ msgstr "Usar la misma resolución que en mapa G3D de entrada para los mapas 2D de salida, independientemente de la configuración de la región actual"
-#~ msgid "Raster map %d Filename: %s already exists. Will be overwritten!"
-#~ msgstr "Nombre de archivo del mapa ráster %i: %s ya existe. ¡Se sobrescribirá!"
-#, fuzzy
-#~ msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map."
-#~ msgstr "Crea un mapa ráster 2D de sección cruzada a partir de un mapa ráster 3D basado en mapa 2D de elevación"
-#, fuzzy
-#~ msgid "Wrong 3D raster map datatype! Unable to create raster map."
-#~ msgstr "¡Tipo de datos G3D incorrecto! No se puede crear el mapa ráster."
-#, fuzzy
-#~ msgid "Unable to close input raster map"
-#~ msgstr "no se puede cerrar el mapa ráster de entrada"
-#, fuzzy
-#~ msgid "Unable to read top raster row \n"
-#~ msgstr "No se puede leer la fila ráster"
-#, fuzzy
-#~ msgid "Unable to read bottom raster row \n"
-#, fuzzy
-#~ msgid "Wrong 3D raster map values: Values should in between 0 and 255\n"
-#~ msgstr "¡Valores de mapa ráster 3D incorrectos! Los valores deben estar entre 0 y 255\n"
-#~ msgid "G3D map(s) to be converted to VTK-ASCII data format"
-#~ msgstr "Mapa(s) G3D a convertir al formato de datos VTK-ASCII"
-#, fuzzy
-#~ msgid "No 3D raster data, RGB or xyz-vector maps are provided. Will only write the geometry"
-#~ msgstr "¡No se ha proporcionado ningún mapa de datos G3D, RGB o vectorial xyz! Sólo se escribirá la geometría."
-#, fuzzy
-#~ msgid "No RGB Data will be created"
-#~ msgstr "No se creará ningún dato RGB."
-#, fuzzy
-#~ msgid "No vector data will be created"
-#, fuzzy
-#~ msgid "Unable to close top raster map"
-#~ msgstr "No se puede cerrar el mapa ráster superior"
-#, fuzzy
-#~ msgid "Unable to close bottom raster map"
-#~ msgstr "No se puede cerrar el mapa ráster inferior"
-#, fuzzy
-#~ msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
-#~ msgstr "Convertir un archivo de texto ráster ASCII 3D en una capa de mapa ráster 3D (binaria)"
-#~ msgid "Link to raster map <%s> created"
-#~ msgstr "Link al mapa raster <%s> creado"
-#~ msgid "Raster file to be linked"
-#~ msgstr "Archivo raster a ser enlazado"
-#~ msgid "input= and source= are mutually exclusive"
-#~ msgstr "enntrada= y fuente= son mutuamente excluyentes"
-#~ msgid "Unable to set window"
-#~ msgstr "No se puede establecer ventana"
-#~ msgid "%s: base raster map not found"
-#~ msgstr "%s: mapa ráster de base no encontrado"
-#, fuzzy
-#~ msgid "Watershed basin analysis program"
-#~ msgstr "Programa de análisis de cuenca hidrográfica."
-#, fuzzy
-#~ msgid "Name of input raster map with real depressions"
-#~ msgstr "Nombre del mapa ráster a reproyectar"
-#, fuzzy
-#~ msgid "Name of input raster map blocking overland surface flow"
-#~ msgstr "Mapa de entrada: flujo de superficie "
-#, fuzzy
-#~ msgid "Name for output raster map useful for visual display of results (DEPRECATED)"
-#~ msgstr "Mapa de salida: útil para  visualizar los resultados"
-#~ msgid "Exports the color table associated with a raster map layer."
-#~ msgstr "Exporta la tabla de color asociada con la capa de un mapa raster."
-#, fuzzy
-#~ msgid "Name for output direction map for depressionless elevation raster map"
-#~ msgid "Reading file"
-#~ msgstr "Archivo de lectura"
-#, fuzzy
-#~ msgid "raster, export, animation"
-#, fuzzy
-#~ msgid "(requires r.out.ppm with stdout option)"
-#~ msgstr ""
-#~ msgid "Unable to read range of raster map <%s>"
-#~ msgstr "No se puede leer el intervalo del mapa raster <%s>"
-#~ msgid "Unable to read %s"
-#~ msgstr "No se puede leer %s"
-#~ msgid "The height of the river bed in [m]"
-#~ msgstr "La altura del lecho del río en [m]"
-#~ msgid "Water level (head) of the river with leakage connection in [m]"
-#~ msgstr "Nivel del agua (altura) del río con conexión de goteo en [m]"
-#~ msgid "The direct cholesky solver do not work with sparse matrices"
-#, fuzzy
-#~ msgid "Name for output elevation raster map after filling"
-#~ msgstr "Producir un mapa ráster de elevación después de rellenar"
-#, fuzzy
-#~ msgid "Name for output direction raster map"
-#~ msgstr "Nombre para el mapa ráster de salida"
-#~ msgid "No raster map specified"
-#~ msgstr "No se ha especificado ningún mapa raster"
-#~ msgid "Unable to remove color table of raster map <%s>"
-#~ msgstr "No se puede eliminar tabla de color del mapa raster <%s>"
-#~ msgid "Color table of raster map <%s> not found"
-#~ msgstr "No se encuentra la tabla de color del mapa raster <%s>"
-#~ msgid "Color table 'random' is not supported for floating point raster map"
-#~ msgstr "La tabla de color 'aleatoria' no está soportada por una mapa raster de unidad de coma flotante"
-#~ msgid "Color table 'grey.eq' is not supported for floating point raster map"
-#~ msgstr "La tabla de color 'grey.equ' no está soportada por una mapa raster de unidad de coma flotante"
-#~ msgid "Color table 'grey.log' is not supported for floating point raster map"
-#~ msgstr "La tabla de color 'grey.log' no está soportada por un mapa raster de unidad de coma flotante"
-#~ msgid "Color table for raster map <%s> set to '%s'"
-#~ msgstr "Tabla de colores para mapa raster <%s> establecida a '%s'"
-#~ msgid "Use G3D mask (if exists) with output map"
-#~ msgstr "Usar máscara G3D (si existe) con el mapa de salida"
-#~ msgid "Cell file not found"
-#~ msgstr "No se encontró el mapa ráster"
-#~ msgid "latin raster map <%s> not found"
-#~ msgstr "No se encuentra el mapa ráster de latitudes de entada <%s>"
-#~ msgid "raster, interpolation"
-#~ msgstr "raster, interpolación"
-#~ msgid "Export GRASS raster as non-georeferenced PNG image."
-#~ msgstr "Exporta un ráster de GRASS como una images PNG no georeferenciada."
-#~ msgid "Name for output raster map (default: input)"
-#~ msgstr "Nombre para el mapa ráster de salida (por omisión: el de entrada)"
-#, fuzzy
-#~ msgid "Unable to load 3D raster range"
-#, fuzzy
-#~ msgid "Reading input data..."
-#~ msgstr "Leyendo entradas..."
-#, fuzzy
-#~ msgid "Writing output data..."
-#~ msgstr "Escribiendo salida..."
-#, fuzzy
-#~ msgid "Name of raster map for which to edit null file"
-#~ msgstr "Mapa ráster para el que editar archivo nulo"
-#~ msgid "Unable to update boundaries"
-#~ msgstr "No se pueden actualizar los contornos"
-#~ msgid "Write raster values as z coordinate. Table is not created. Currently supported only for points."
-#~ msgstr "Escribir valores ráster como coordenada Z. No se crea la tabla. Actualmente sólo soportado para puntos."
-#~ msgid "Name of base raster map"
-#~ msgstr "Nombre de mapa ráster de base"
-#~ msgid "Output basic information about a raster map layer."
-#~ msgstr "Muestra información básica sobre una capa de mapa ráster."
-#, fuzzy
-#~ msgid "raster, reclassification"
-#~ msgid "The size of sliding window (odd and >= 3)"
-#~ msgstr "El tamaño de la ventana deslizante (impar y >= 3)"
-#~ msgid "Nothing to compute. Use at least one of the flags."
-#~ msgstr "Nada que procesar. Use al menos una de las opciones."
-#~ msgid "Calculated measure #%d <%s> (56 measures available)"
-#~ msgstr "Medida #%d calculada <%s>  (56 medidas disponibles)"
-#~ msgid "Checking GDAL data type and nodata value"
-#~ msgstr "Comprobando tipos de datos GDAL y valores sin datos"
-#, fuzzy
-#~ msgid "Name of input raster map with seed (at least 1 cell > 0)"
-#~ msgstr "Nombre del mapa ráster a utilizar como máscara"
-#~ msgid "Input map"
-#~ msgstr "Mapa de entrada"
-#~ msgid "Use G3D mask (if exists) with input map"
-#~ msgstr "Usar máscara G3D (si existe) con el mapa de entrada"
-#~ msgid "Error writing G3D double data"
-#~ msgstr "Error al escribir datos dobles G3D"
-#, fuzzy
-#~ msgid "Constructs flow lines."
-#~ msgstr "Costes para isolíneas"
-#, fuzzy
-#~ msgid "Name for flowpath length raster map"
-#~ msgstr "Mapa ráster de longitud de ruta de corriente de salida"
-#~ msgid "Unable to get header for %s"
-#~ msgstr "No se puede obtener la cabecera de %s"
-#, fuzzy
-#~ msgid "imagery, landsat, acca"
-#~ msgstr "imaginería, clasificación, MLC"
-#, fuzzy
-#~ msgid "Cannot write to raster map <%s>"
-#~ msgstr "¡No se puede escribir el mapa ráster de lago <%s>!"
-#, fuzzy
-#~ msgid "Creates, edits, and lists groups and subgroups of imagery data."
-#~ msgstr "Crea, edita y lista grupos y subgrupos de archivos de imaginería."
-#, fuzzy
-#~ msgid "Computes topographic correction of reflectance."
-#~ msgstr "Método de interpolación"
-#, fuzzy
-#~ msgid "Name of reflectance raster maps to be corrected topographically"
-#~ msgstr "Nombre del mapa ráster de superficie para sección cruzada"
-#, fuzzy
-#~ msgid "Name (flag -i) or prefix for output raster maps"
-#~ msgstr "Prefijo para el mapa(s) raster de salida"
-#, fuzzy
-#~ msgid "Name of input base raster map (elevation or illumination)"
-#~ msgstr "Nombre del mapa raster de entrada (saturación)"
-#, fuzzy
-#~ msgid "Output sun illumination terrain model"
-#~ msgstr "Mapa ráster de salida de saturación"
-#, fuzzy
-#~ msgid "Elevation raster map of unknown type"
-#~ msgstr "Coordenada de elevación de un punto en el plano"
-#, fuzzy
-#~ msgid "Reflectance of raster map <%s> is not of DCELL type - ignored"
-#, fuzzy
-#~ msgid "Extract quality control parameters from Modis QC layers"
-#~ msgstr "Extrae parámetros del terreno a partir de un DEM."
-#, fuzzy
-#~ msgid "Name of the surface reflectance QC layer [bit array]"
-#~ msgstr "Nombre de capa ráster de superficie fractal"
-#~ msgid "Subsignature %d only contains %f pixels"
-#~ msgstr "La subsignatura %d sólo contiene %f píxeles"
-#, fuzzy
-#~ msgid "The output cell map <%s.%d> has values outside the 0-255 range. Min: %d Max: %d"
-#~ msgstr "El mapa de celdas de salida <%s.%d> tiene valores fuera del rango 0-255."
-#~ msgid "Calculating covariance matrix..."
-#~ msgstr "Calculando la covarianza de la matriz..."
-#, fuzzy
-#~ msgid "Computing means and standard deviations..."
-#~ msgstr "Calculando promedios para la banda %d..."
-#, fuzzy
-#~ msgid "Computing means..."
-#~ msgid "Rescaling <%s> to range %d,%d..."
-#~ msgstr "Rescalando <%s> al intervalo %d,%d..."
-#~ msgid "Bad format in camera file for group <%s>"
-#~ msgstr "Mal formato en archivo cámara para grupo <%s>"
-#~ msgid "Please select a target for group"
-#~ msgstr "Por favor exigir el destino paara group."
-#~ msgid "Error in calculating conversions"
-#~ msgstr "Error calculando conversiones"
-#~ msgid "Type of color table (for use with -z flag)"
-#~ msgstr "Tipo de tabla de color (para usar con -z flag)"
-#~ msgid "Name of column for line widths (these values will be scaled by wscale)"
-#~ msgstr "Nombre de columna para anchuras de línea (estos valores se escalarán por wscale)"
-#~ msgid "Scale factor for wcolumn"
-#~ msgstr "Factor de escala para columna de anchura (wcolumn)"
-#~ msgid "Get colors from map table column (of form RRR:GGG:BBB)"
-#~ msgstr "Tomar colores de columna de la tabla del mapa (en forma RRR:GGG:BBB)"
-#~ msgid "Error in color definition column (%s), area %d with cat %d"
-#~ msgstr "Error en la columna (%s) de definición de color, área %d con categoría %d"
-#~ msgid "Symbol size column not specified."
-#~ msgstr "Columna de tamaño de símbolo no especificada."
-#~ msgid "Symbol size column (%s) is not numeric."
-#~ msgstr "La columna de tamaño de símbolo (%s) no es numérica."
-#~ msgid "Symbol rotation column not specified."
-#~ msgstr "Columna de rotación de símbolo no especificada."
-#~ msgid "Symbol rotation column (%s) is not numeric."
-#~ msgstr "La columna de rotación de símbolo (%s) no es numérica. "
-#~ msgid "Unable to read symbol, unable to display points"
-#~ msgstr "No se puede leer símbolo, no se pueden mostrar puntos"
-#~ msgid "display, raster"
-#~ msgid "Interactively edit cell values in a raster map."
-#~ msgstr "Editar valores de celda de forma interactiva en un mapa ráster."
-#~ msgid "Display information about the active display monitor"
-#~ msgstr "Mostrar información sobre la pantalla activa"
-#~ msgid "Erase the contents of the active display frame with user defined color"
-#~ msgstr "Borrar el contenido del marco de pantalla activa con colores definidos por el usuario"
-#~ msgid "Don't add to list of commands in monitor"
-#~ msgstr "No añadir a la lista de comandos en el monitor"
-#~ msgid "No font selected"
-#~ msgstr "Ninguna fuente seleccionada"
-#~ msgid "Unable to set size"
-#~ msgstr "No se puede establecer el tamaño"
-#~ msgid "Error - Monitor '%s' was not running"
-#~ msgstr "Error - El monitor '%s' no estaba funcionando"
-#~ msgid "Name of graphics monitor to start"
-#~ msgstr "Nombre de la pantalla a iniciar"
-#~ msgid "Name of graphics monitor to stop"
-#~ msgstr "Nombre de la pantalla a detener"
-#~ msgid "Name of graphics monitor to select"
-#~ msgstr "Nombre de la pantalla a seleccionar"
-#~ msgid "List all monitors"
-#~ msgstr "Listar todas las pantallas"
-#~ msgid "Print name of currently selected monitor"
-#~ msgstr "Impirmir el nombre de la pantalla seleccionada actualmente"
-#~ msgid "Release currently selected monitor"
-#~ msgstr "Libera la pantalla seleccionada actualmente"
-#~ msgid "Can also be used to create GRASS locations."
-#~ msgstr "También puede ser utilizado para crear localizaciones GRASS."
-#~ msgid "Print projection information (in conventional GRASS format)"
-#~ msgstr "Imprimir información de proyección (en formato convencional GRASS)"
-#~ msgid "Georeferenced data file to read projection information from"
-#~ msgstr "Archivo georreferenciado del que leer la información de proyección"
-#~ msgid "ASCII file containing a WKT projection description (- for stdin)"
-#~ msgstr "Archivo ASCII que contiene una descripción de proyección WKT (- para stdin)"
-#~ msgid "PROJ.4 projection description (- for stdin)"
-#~ msgstr "Descripción de proyección PROJ.4 (- para stdin)"
-#~ msgid "Unable to open file [%s] for reading"
-#~ msgstr "No se puede abrir el archivo [%s] para lectura"
-#~ msgid "Unable to create location: %s"
-#~ msgstr "No se puede crear la localización: %s"
-#~ msgid "You must select the PERMANENT mapset before updating the current location's projection. (Current mapset is %s)"
-#~ msgstr "Debe seleccionar el directorio de mapas PERMANENT antes de actualizar la proyección de la localización actual. (El directorio de mapas actual es %s)"
-#~ msgid "N.B. The default region was updated to the new projection, but if you have multiple mapsets g.region -d should be run in each to update the region from the default."
-#~ msgstr "N.B. La región por omisión se actualizó a la nueva proyección, pero si tiene múltiples directorios de mapas debería ejecutar g.mapset -d en cada uno para actualizar la región a partir de la predeterminada."
-#~ msgid "Projection information updated!"
-#~ msgstr "¡Información de la proyección actualizada!"
-#~ msgid "Remove base maps"
-#~ msgstr "Eliminar mapas base"
-#~ msgid "The following files would be deleted:"
-#~ msgstr "Los siguientes archivos serán eliminados:"
-#~ msgid "Changes current mapset."
-#~ msgstr "Cambia el directorio de mapas actual."
-#~ msgid "List available mapsets"
-#~ msgstr "Listar los directorios de mapas disponibles"
-#~ msgid "You don't have permission to use this mapset"
-#~ msgstr "No tiene permiso para usar este directorio de mapas"
-#~ msgid "The mapset does not exist. Use -c flag to create it."
-#~ msgstr "El directorio de mapas no existe. Use la opción -c para crearlo."
-#, fuzzy
-#~ msgid "%s is currently running GRASS in selected mapset or lock file cannot be checked"
-#~ msgstr "%s está ejecutando actualmente GRASS en el directorio de mapas seleccionado o no se puede comprobar el archivo de bloqueo."
-#, fuzzy
-#~ msgid "Other"
-#~ msgstr "Vacilar"
-#~ msgid "Unrecognized 'ask' value in proj-parms.table: %s"
-#~ msgstr "Valor 'ask' desconocido en proj-parms.table: %s"
-#~ msgid "Unrecognized default value in proj-parms.table: %s"
-#~ msgstr "No se reconoce el valor por defecto en proj-parms.table: %s"
-#~ msgid "Names of mask files"
-#~ msgstr "Nombre de los archivos de máscara"
-#~ msgid "Name of output mask file"
-#~ msgstr "Nombre del archivo de máscara de salida"
-#~ msgid "Creates a Voronoi diagram from an input vector map containing points or centroids."
-#~ msgstr "Crea un diagrama de Voronoi  a partir de un mapa vectorial de entrada que contiene puntos o centroides."
-#~ msgid "Voronoi triangulation..."
-#~ msgstr "Triangulación Voronoi..."
-#~ msgid "Unknown column type '%s'"
-#~ msgstr "Tipo de columna '%s' desconocido"
-#~ msgid "Unknown column type '%s' values lost"
-#~ msgstr "Valores del tipo de columna '%s' desconocido perdidos"
-#~ msgid "List available layers in data source and exit"
-#~ msgstr "Listar las capas disponibles en la fuente de datos y salir"
-#~ msgid "Data source contains %d layers:"
-#~ msgstr "El origen de datos contiene %d capas:"
-#~ msgid "Counting polygons for %d features..."
-#~ msgstr "Contando polígons para %d elementos..."
-#~ msgid "Importing map %d features..."
-#~ msgstr "Importando elementos %d del mapa..."
-#~ msgid "Snap boundaries (threshold = %.3e):"
-#~ msgstr "Ajustar contornos (umbral = %.3e):"
-#~ msgid "Merge boundaries:"
-#~ msgstr "Unir contornos:"
-#~ msgid "Change boundary dangles to lines:"
-#~ msgstr "Cambiar nodos colgantes de los contornos a líneas:"
-#~ msgid "Change boundary bridges to lines:"
-#~ msgstr "Cambiar puentes de contornos a líneas:"
-#~ msgid "Find centroids for layer: %s"
-#~ msgstr "Encontrar centroides para capa: %s"
-#~ msgid "Input data contains 3D features. Created vector is 2D only, use -z flag to import 3D vector"
-#~ msgstr "Los datos de entrada contienen elementos 3D. El vectorial creado es 2D. Use la opción -z para importar vectoriales 3D."
-#~ msgid "Cannot read part of geometry"
-#~ msgstr "No se puede leer parte de la geometría"
-#~ msgid "Degenerate polygon ([%d] vertices)"
-#~ msgstr "Degenerar polígono ([%d] vértices)"
-#~ msgid "Cannot write part of geometry"
-#~ msgstr "No se puede escribir parte de la geometría"
-#~ msgid "Finds the shortest paths from a feature 'to' to every feature 'from' and various information about this realtion are uploaded to the attribute table."
-#~ msgstr "Encuentra las rutas más cortas entre un elemento 'a' a cada elemento 'desde' y se carga varia información sobre esta relación a la tabla de atributos."
-#~ msgid "Path to resulting ASCII file or ASCII vector name if '-o' is defined"
-#~ msgstr "Ruta al archivo ASCII resultante o nombre del vectorial ASCII si se define '-o'"
-#, fuzzy
-#~ msgid "Offset in map units."
-#~ msgstr "Distancia de buffer en unidades de mapa"
-#~ msgid "End of ascii file reached before end of categories"
-#~ msgstr "Se alcanzó el final del archivo ASCII antes que el final de las categorías"
-#, fuzzy
-#~ msgid "Cannot open driver"
-#~ msgstr "No se puede abrir %s"
-#, fuzzy
-#~ msgid "Cannot open database"
-#~ msgstr "No se puede abrir la base de datos %s"
-#, fuzzy
-#~ msgid "Cannot describe table"
-#~ msgstr "Imposible copiar la tabla"
-#, fuzzy
-#~ msgid "Cannot find column type"
-#~ msgstr "Tipo de columna desconocido"
-#, fuzzy
-#~ msgid "Cannot update table"
-#~ msgstr "No se puede modificar la tabla: %s"
-#, fuzzy
-#~ msgid "Form"
-#~ msgstr "Formato"
-#, fuzzy
-#~ msgid "New record was created.<BR>"
-#~ msgstr "Nuevo mapa vacío creado."
-#, fuzzy
-#~ msgid "Record for this category already existed.<BR>"
-#~ msgstr "No hay registro para la categoría %d en la tabla <%s>"
-#, fuzzy
-#~ msgid "New point"
-#~ msgstr "Punto de vista"
-#, fuzzy
-#~ msgid "Quit tool"
-#~ msgstr "Herramienta consulta"
-#, fuzzy
-#~ msgid "Undo last point"
-#~ msgstr "Ningún punto de inicio"
-#, fuzzy
-#~ msgid "Close line"
-#~ msgstr "Fallo al cerrar."
-#, fuzzy
-#~ msgid "New Point"
-#~ msgstr "Puntos"
-#, fuzzy
-#~ msgid "Undo Last Point"
-#, fuzzy
-#~ msgid "Delete line and exit"
-#~ msgstr "Imprimir tablas y salir"
-#, fuzzy
-#~ msgid "Select"
-#~ msgstr "Selección"
-#, fuzzy
-#~ msgid "Unselect"
-#~ msgstr " Ningún monitor seleccionado"
-#, fuzzy
-#~ msgid "New location"
-#~ msgstr "Asignación de métricas"
-#, fuzzy
-#~ msgid "Remove vertex:"
-#~ msgstr "Vértices eliminados %5d"
-#, fuzzy
-#~ msgid "Select vertex"
-#~ msgstr "Tipo de archivo"
-#, fuzzy
-#~ msgid "Move vertex:"
-#, fuzzy
-#~ msgid "Cannot open driver %s"
-#, fuzzy
-#~ msgid "Cannot open driver "
-#, fuzzy
-#~ msgid "Cannot create table: "
-#~ msgstr "No se puede crear la tabla: %s"
-#, fuzzy
-#~ msgid "Cannot create index:\n"
-#~ msgstr "No se puede crear el índice"
-#, fuzzy
-#~ msgid "Cannot grant privileges on table:\n"
-#~ msgstr "No se pueden otorgar privilegios sobre la tabla %s"
-#, fuzzy
-#~ msgid "Cannot create new record."
-#~ msgstr "No se puede crear la nueva tabla"
-#, fuzzy
-#~ msgid "Database table for this layer is not defined"
-#~ msgstr "Conexión a la base de datos no definida"
-#, fuzzy
-#~ msgid "Cannot select record from table %s"
-#~ msgstr "Imposible seleccionar datos de la tabla"
-#, fuzzy
-#~ msgid "Display categories:"
-#~ msgstr "%ld categorías"
-#, fuzzy
-#~ msgid "Select line"
-#, fuzzy
-#~ msgid "Copy attributes:"
-#~ msgstr "Copiar atributos"
-#, fuzzy
-#~ msgid "Select source object"
-#~ msgstr "Proyeccion del origen"
-#, fuzzy
-#~ msgid "Select the target object"
-#~ msgstr "Establece el color de texto"
-#, fuzzy
-#~ msgid "Conform and select next"
-#, fuzzy
-#~ msgid "Deselect Target"
-#~ msgstr "Seleccionar un marco"
-#, fuzzy
-#~ msgid "Display attributes:"
-#, fuzzy
-#~ msgid "layer: %d<BR>category: %d<BR>"
-#~ msgstr ""
-#~ "Capa: %d\n"
-#~ "categoría: %d\n"
-#, fuzzy
-#~ msgid "Database connection not defined<BR>"
-#, fuzzy
-#~ msgid "driver: %s<BR>database: %s<BR>table: %s<BR>key column: %s<BR>"
-#~ msgstr ""
-#~ "controlador: %s\n"
-#~ "base de datos: %s\n"
-#~ "tabla: %s\n"
-#~ "columna de clave: %s\n"
-#, fuzzy
-#~ msgid "Line %d"
-#~ msgstr "Línea: %d\n"
-#, fuzzy
-#~ msgid "No categories"
-#, fuzzy
-#~ msgid "Cannot delete record: %s"
-#~ msgstr "No se puede insertar el nuevo registro: %s"
-#, fuzzy
-#~ msgid "Cannot open driver '%s'<BR>"
-#~ msgstr "No se puede abrir el archivo dxf <%s>"
-#, fuzzy
-#~ msgid "Cannot open database '%s' by driver '%s'<BR>"
-#~ msgstr "No se puede abrir la base de datos %s por el controlador %s"
-#, fuzzy
-#~ msgid "Cannot open select cursor"
-#~ msgstr "No se puede abrir el cursor de selección: '%s'"
-#, fuzzy
-#~ msgid "Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>"
-#, fuzzy
-#~ msgid "Cannot fetch next record"
-#~ msgstr "No se puede recuperar la fila"
-#, fuzzy
-#~ msgid "No database record"
-#~ msgstr "Controlador de base de datos"
-#, fuzzy
-#~ msgid "Select tool"
-#, fuzzy
-#~ msgid "Cannot set variable code = %d"
-#~ msgstr "No se pueden seleccionar atributos para la categoría = %d"
-#, fuzzy
-#~ msgid "Cannot get type of variable %s"
-#~ msgstr "No se puede obtener la lista de tablas:\n"
-#, fuzzy
-#~ msgid "Cannot get code of variable %s"
-#, fuzzy
-#~ msgid "Cannot get name of variable %d"
-#, fuzzy
-#~ msgid "Cannot get value of variable code = %d"
-#, fuzzy
-#~ msgid "Quit"
-#~ msgstr "Silencioso"
-#, fuzzy
-#~ msgid "New center"
-#~ msgstr "Esquema nuevo"
-#, fuzzy
-#~ msgid "Cannot find window '%s'"
-#~ msgstr "No se puede insertar nueva línea: %s"
-#~ msgid "Allocate subnets for nearest centres (direction from centre)."
-#~ msgstr "Asigna subredes para los centros más próximos (dirección desde el centro)."
-#~ msgid "Centre node must be opened (costs >= 0). Costs of centre node are used in calculation"
-#~ msgstr "El nodo central debe estar abierto (costes >=0). Los costes del nodo central se usan en los cálculos."
-#~ msgid "Categories of centres (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
-#~ msgstr "Categorías de los centros (puntos en nodos) a los que se asignará la red. La capa para estas categorías es dada por la opción nlayer"
-#~ msgid "Number of centres: [%d] (nlayer: [%d])"
-#~ msgstr "Número de centros: [%d] (nlayer: [%d])"
-#~ msgid "Calculating costs from centres ..."
-#~ msgstr "Calculando costes desde centros..."
-#~ msgid "Selects vector objects from an existing vector map and creates a new map containing only the selected objects."
-#~ msgstr "Selecciona objetos vectoriales de un vectorial existente y crea un nuevo mapa que contiene sólo los objetos seleccionados."
-#~ msgid "Do not copy table (see also 'new' parameter)"
-#~ msgstr "No copiar tabla (ver también el parámetro 'nuevo')"
-#~ msgid "If new >= 0, table is not copied"
-#~ msgstr "Si nuevo >=0, la tabla no se copia"
-#~ msgid "List, file, where and random options are exclusive. Please specify only one of them"
-#~ msgstr "Las opciones lista, archivo, dónde y azar son exclusivas. Por favor especifica solo una de ellas"
-#~ msgid "Process file <%s> for category numbers"
-#~ msgstr "Procesar archivo <%s> para los números de categoría"
-#~ msgid "%d categories loaded from table <%s>"
-#~ msgstr "%d categorías cargadas de la tabla <%s>"
-#~ msgid "Random category count is larger or equal to uniq \"%s\" feature category count %d"
-#~ msgstr "La categoría aleatoria count es mayor o igual que uniq \"%s\" elemento categoría count %d"
-#~ msgid "Key column name"
-#~ msgstr "Nombre de la columna clave"
-#, fuzzy
-#~ msgid "DEPRECATED Buffer distance in map units"
-#, fuzzy
-#~ msgid "Line buffers... "
-#~ msgstr "Buffers de líneas... "
-#, fuzzy
-#~ msgid "Zero area size, please clean input vector first."
-#~ msgstr "Crear línea paralela a las líneas de entrada"
-#, fuzzy
-#~ msgid "Could not get outside buffer for line id %d"
-#~ msgstr "No se pudo obtener la fila del ráster del mapa de elevación"
-#, fuzzy
-#~ msgid "Area buffers... "
-#~ msgstr "Buffers de áreas... "
-#, fuzzy
-#~ msgid "Selecting areas..."
-#~ msgstr "Recopilando estadísticas..."
-#~ msgid "vector, transformation"
-#~ msgid "<%s> has not been created in database."
-#~ msgstr "<%s> no ha sido creado en la base de datos."
-#~ msgid "Name of column name with route ids"
-#~ msgstr "Nombre de la column name con los ids de la ruta"
-#~ msgid "Name of column name with stop timestamps"
-#~ msgstr "Nombre de la columna con parámetros de suavizado"
-#, fuzzy
-#~ msgid "Name of column name with stop ids"
-#~ msgstr "Nombre de la columna a mostrar"
-#, fuzzy
-#~ msgid "Name of column name with walk lengths"
-#~ msgstr "Número de columnas en la nueva región"
-#~ msgid "Unknown operator"
-#~ msgstr "Operador desconocido"
-#~ msgid "Copying vector lines..."
-#~ msgstr "Copiando líneas vectoriales..."
-#~ msgid "Print topology information only"
-#~ msgstr "Imprimir sólo información de topología"
-#~ msgid "Name of input DXF file"
-#~ msgstr "Nombres de los archivos DXF de entrada"
-#~ msgid "Name of input vector points map for which to edit attribute table"
-#~ msgstr "Nombre del mapa vectorial de puntos para el que editar la tabla de atributos"
-#~ msgid "If not given reads from standard input"
-#~ msgstr "Si no se da lee de la entrada estándar"
-#, fuzzy
-#~ msgid "Cannot allocate %u bytes of memory"
-#~ msgstr "No se pueden asignar %d de memoria"
-#~ msgid "No attribute table found"
-#~ msgstr "No se ha encontrado atributo de la tabla"
-#~ msgid "Cannot parse MySQL embedded database name"
-#~ msgstr "No se puede analizar el nombre de la base de datos empotrada en MySQL"
-#~ msgid "Cannot connect to MySQL embedded server: "
-#~ msgstr "No se puede conectar al servidor empotrado en MySQL: "
-#~ msgid "Cannot scan timestamp: "
-#~ msgstr "No se puede escanear el indicador de tiempo: "
-#~ msgid "Cannot scan datetime: "
-#~ msgstr "No se pueden escanear fecha y hora: "
-#~ msgid "Cannot get list of tables:\n"
-#~ msgid "Unknown option in database definition for "
-#~ msgstr "Opción desconocida en la definición de la base de datos para "
-#~ msgid "Cannot recognize boolean value"
-#~ msgstr "No se puede reconocer el valor booleano"
-#~ msgid "pg driver: PostGIS column '%s', type 'geometry'  will not be converted"
-#~ msgstr "Controlador pg: columna PostGIS '%s', el tipo 'geometría' no se convertirá"
-#~ msgid "Removes a table from database."
-#~ msgstr "Elimina una tabla de la base de datos."
-#~ msgid "Database schema"
-#~ msgstr "Esquema de la base de datos"
-#, fuzzy
-#~ msgid "database, connection settings"
-#~ msgid "Uncompressed GNS file from NGA (with .txt extension)"
-#~ msgstr "Archivo GNS sin comprimir de NGA (con extensión .txt)"
-#~ msgid "Display the HTML man pages of GRASS"
-#~ msgstr "Mostrar las páginas man HTML de GRASS"
-#~ msgid "vector, raster, statistics"
-#~ msgstr "vectorial, ráster, estadísticas"
-#, fuzzy
-#~ msgid "Base name for red, green and blue output maps containing the blend"
-#~ msgstr "Nombre base para los mapas de salida rojo, verde y azul que contendrán la mezcla"
-#~ msgid "Select x11 display monitor for legend"
-#~ msgstr "Seleccionar monitor x11 para la leyenda"
-#~ msgid "Name of the column"
-#~ msgstr "Nombre de la columna"
-#~ msgid "Set color rules based on stddev from a map's mean value."
-#~ msgstr "Establecer normas de color basadas en stddev a partir de un valor medio del mapa."
-#~ msgid "Name of optional EPS output file"
-#~ msgstr "Nombre del archivo de salida EPS opcional"
-#, fuzzy
-#~ msgid "Skip the join column in other table"
-#~ msgstr "Columna a unir en la otra tabla"
-#, fuzzy
-#~ msgid "Copy all the columns from other table to map"
-#~ msgid "Join column in map table"
-#~ msgstr "Columna a unir en la tabla del mapa"
-#~ msgid "Column on which to calculate statistics (must be numeric)"
-#~ msgstr "Columna sobre la que calcular las estadísticas (debe ser numérica)"
-#~ msgid "Import ASCII x,y[,z] coordinates as a series of lines."
-#~ msgstr "Importar coordenadas x,y[,z]  ASCII como series de líneas."
-#~ msgid "Import E00 file into a vector map."
-#~ msgstr "Importar archivo E00 a mapa vectorial."
-#~ msgid "LANDSAT red channel"
-#~ msgstr "Canal rojo LANDSAT"
-#~ msgid "LANDSAT green channel"
-#~ msgstr "Canal verde LANDSAT"
-#~ msgid "LANDSAT blue channel"
-#~ msgstr "Canal azul LANDSAT"
-#~ msgid "Raster input maps"
-#~ msgstr "Mapas raster de entrada"
-#~ msgid "Export a raster map to a text file as x,y,z values based on cell centers."
-#~ msgstr "Exportar un mapa ráster a un archivo de texto como valores X, Y, Z basados en los centros de las celdas."
-#~ msgid "Imports geonames.org country files into a GRASS vector points map."
-#~ msgstr "Importa archivos de país geonames.org a un mapa vectorial de puntos de GRASS."
-#~ msgid "Uncompressed geonames file from (with .txt extension)"
-#~ msgstr "Archivo geonames sin comprimir de (con extensión .txt)"
-#~ msgid "Table to drop"
-#~ msgstr "Tabla a quitar"
-#~ msgid "SRTM input tile (file without .hgt.zip extension)"
-#~ msgstr "Archivo de entrada SRTM (archivo sin extensión .hgt.zip)"
-#~ msgid "Name of aspect raster map"
-#~ msgstr "Nombre de mapa ráster de orientación"
-#~ msgid "Manually set range (min,max)"
-#~ msgstr "Asignar rango manualmente (min,max)"
-#, fuzzy
-#~ msgid "Name of input raster map in which to fill nulls"
-#~ msgstr "Mapa ráster en el que rellenar los nulos"
-#, fuzzy
-#~ msgid "Name for output raster map with nulls filled by interpolation"
-#~ msgstr "Producir mapa ráster con nulos rellenos por interpolación de los valores circundantes"
-#~ msgid "Layer where to add new attribute table"
-#~ msgstr "Capa a la que añadir la nueva tabla de atributos"
-#~ msgid "Column to be updated with the query result"
-#~ msgstr "Columna a actualizar con el resultado de la consulta"
-#~ msgid "Name of raster map to generate legend from"
-#~ msgstr "Nombre del mapa raster para generar leyenda de"
-#~ msgid "Output coordinate file (omit to send to stdout)"
-#~ msgstr "Archivo de coordenadas de salida (omitir para enviar a stdout)"
-#, fuzzy
-#~ msgid "Name of the column to drop"
-#~ msgid "Exports a vector map to a GPS receiver or file format supported by GpsBabel."
-#~ msgstr "Exporta un mapa vectorial a un receptor GPS o a un formato de archivos soportado por GpsBabel."
-#~ msgid "GpsBabel supported output format"
-#~ msgstr "Formato de salida soportado por GpsBabel"
-#~ msgid "Prints a graph of the correlation between data layers (in pairs)."
-#~ msgstr "Imprime un gráfico de la correlación entre dos capas de datos (en pares)."
-#, fuzzy
-#~ msgid "Mosaics up to four images, extending the color table."
-#~ msgstr "Hace mosaicos de hasta 4 imágenes y extiende colormap; crea mapas *.mosaico"
-#, fuzzy
-#~ msgid "creates map *.mosaic"
-#~ msgstr "Tercer mapa para mosaico."
-#, fuzzy
-#~ msgid "1st map for mosaic (top of image stack)"
-#~ msgstr "Primer mapa para mosaico (superior de la pila de imágenes)."
-#, fuzzy
-#~ msgid "2nd map for mosaic"
-#~ msgstr "Segundo mapa para mosaico."
-#, fuzzy
-#~ msgid "3rd map for mosaic"
-#, fuzzy
-#~ msgid "4th map for mosaic"
-#~ msgstr "Cuarto mapa para mosaico."
-#~ msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
-#~ msgstr "Transformación Tasseled Cap (Kauth Thomas) para datos LANDSAT-TM"
-#~ msgid "use transformation rules for LANDSAT-4"
-#~ msgstr "usar reglas de transformación para LANDSAT-4"
-#~ msgid "use transformation rules for LANDSAT-5"
-#~ msgstr "usar reglas de transformación para LANDSAT-5"
-#~ msgid "use transformation rules for LANDSAT-7"
-#~ msgstr "usar reglas de transformación para LANDSAT-7"
-#~ msgid "raster input map (LANDSAT channel 1)"
-#~ msgstr "mapa ráster de entrada (canal LANDSAT 1)"
-#~ msgid "raster input map (LANDSAT channel 2)"
-#~ msgstr "mapa ráster de entrada (canal LANDSAT 2)"
-#~ msgid "raster input map (LANDSAT channel 3)"
-#~ msgstr "mapa ráster de entrada (canal LANDSAT 3)"
-#~ msgid "raster input map (LANDSAT channel 4)"
-#~ msgstr "mapa ráster de entrada (canal LANDSAT 4)"
-#~ msgid "raster input map (LANDSAT channel 5)"
-#~ msgstr "mapa ráster de entrada (canal LANDSAT 5)"
-#~ msgid "raster input map (LANDSAT channel 7)"
-#~ msgstr "mapa ráster de entrada (canal LANDSAT 7)"
-#~ msgid "Tool to maintain GRASS extensions in local GRASS installation."
-#~ msgstr "Herramienta para mantener las extensiones GRASS en una instalación local GRASS"
-#~ msgid "Prefix where to install extension"
-#~ msgstr "Prefijo donde instalar la extensión"
-#~ msgid "List available modules in the GRASS Addons SVN repository"
-#~ msgstr "Listar los módulos disponibles en el respositorio GRASS Addons SVN"
-#~ msgid "Name of column used to dissolve common boundaries"
-#~ msgstr "Nombre de columna usada para disolver contornos comunes"
-#~ msgid "Name of shaded relief or aspect map"
-#~ msgstr "Nombre del mapa compartido de relieve u orientación"
-#~ msgid "Name of raster to drape over relief map"
-#~ msgstr "Nombre del ráster superponer sobre mapa de relieve"
-#, fuzzy
-#~ msgid "writing edges..."
-#~ msgid "Import Mapgen or Matlab vector maps into GRASS."
-#~ msgstr "Importar mapas vectoriales Mapgen o Matlab a GRASS."
-#, fuzzy
-#~ msgid "Unhandled vector feature type <%s>"
-#~ msgstr "No se puede crear la tabla <%s>"
-#, fuzzy
-#~ msgid "No areas found, skipping type=area"
-#~ msgstr "No se encontraron áreas, se salta el tipo=polígono"
-#, fuzzy
-#~ msgid "No points found, skipping%s%s"
-#~ msgstr "No se encontraron puntos, se salta el tipo=punto"
-#, fuzzy
-#~ msgid "No lines found, skipping%s%s"
-#~ msgstr "No se encontraron líneas, se salta el tipo=línea"
-#, fuzzy
-#~ msgid "The '-q' flag is superseded and will be removed "
-#~ msgstr "La opción '-q' está suplantada y se eliminará en el futuro. Por favor, use '--quiet' en su lugar"
-#, fuzzy
-#~ msgid "Unable to create table <%s_edge_Interpolation>"
-#, fuzzy
-#~ msgid "Rescale output raster map [0,255]"
-#~ msgstr "mapa de salida ráster"
-#~ msgid "A: azimuth of the sun from the north, degrees"
-#~ msgstr "A: azimut del sol desde el Norte, grados"
-#~ msgid "New GISDBASE (full path to the directory where the new location is)"
-#~ msgstr "Nueva BASE DE DATOS (ruta completa al directorio donde se encuentra la nueva localización)"
-#, fuzzy
-#~ msgid "%d faces found, but not requested to be exported. Verify 'type' parameter."
-#~ msgstr "%d cara(s) encontrada(s), pero no se ha solicitado exportarlas. Verificar el parámetro 'tipo'."
-#~ msgid "Line: %d\n"
-#~ msgid "Cannot open dxf file <%s>"
-#, fuzzy
-#~ msgid "Cannot open driver\n"
-#, fuzzy
-#~ msgid "Cannot open database\n"
-#~ msgid "Could not close G3D map"
-#~ msgstr "No se pudo cerrar el mapa G3D"
-#~ msgid "Use g3d mask (if exists) with input map"
-#~ msgstr "Usar máscara G3D (si existe) con el mapar de entrada"
-#~ msgid "Could not close G3D map <%s>"
-#~ msgstr "No se pudo cerrar el mapa G3D <%s>"
-#~ msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
-#~ msgstr "Convierte mapas ráster 3D (G3D) en formato VTK-ASCII"
-#~ msgid "Use g3d mask (if exists) with input maps"
-#~ msgstr "Usar máscara G3D (si existe) con los mapas de entrada"
-#~ msgid "Use G3D mask (if exists)"
-#~ msgstr "Usar máscara G3D (si existe)"
-#~ msgid "Name of an existing raster map layer"
-#~ msgstr "Nombre de una capa de mapa ráster existente"
-#~ msgid "Reading raster map <%s in %s> ..."
-#~ msgstr "Leyendo mapa ráster <%s en %s> ..."
-#~ msgid "Error writing row %d"
-#~ msgstr "Error escribiendo fila %d"
-#~ msgid "Name of input vector points map"
-#~ msgstr "Nombre del mapa vectorial de puntos de entrada"
-#~ msgid "Reading data from the map..."
-#~ msgstr "Leyendo datos del mapa..."
-#~ msgid "No map specified"
-#~ msgstr "Ningún mapa especificado"
-#~ msgid "Writing attributes ..."
-#~ msgstr "Escribiendo atributos..."
-#~ msgid "DXF input file"
-#~ msgstr "Archivo DXF de entrada"
-#~ msgid "Unable to delete line %d"
-#~ msgstr "No se puede borrar la línea %d"
-#~ msgid "Name of elevation raster map"
-#~ msgstr "Nombre del mapa ráster de elevaciones"
-#, fuzzy
-#~ msgid "Could not read range file"
-#~ msgstr "No se puede leer el archivo de intervalo"
-#~ msgid "Calculation of unconfined groundwater flow loop %i\n"
-#~ msgstr "Cálculo del bucle de caudal de agua subterránea no confinada %i\n"
-#, fuzzy
-#~ msgid "Name of real-sky beam radiation coefficient input raster map [-]"
-#~ msgstr "Nombre ráster"
-#, fuzzy
-#~ msgid "Name of real-sky diffuse radiation coefficient input raster map [-]"
-#~ msgid "Name for distance output map"
-#~ msgstr "Nombre para el mapa de distancia de salida"
-#~ msgid "Reports statistics for raster map layers."
-#~ msgstr "Informa estadísticas para capas de mapas ráster."
-#~ msgid "Name of an output file to hold the report"
-#~ msgstr "Nombre de un archivo de salida para albergar el informe"
-#~ msgid "Creates, edits, and lists groups and subgroups of imagery files."
-#, fuzzy
-#~ msgid ""
-#~ "ERROR: Required parameter <%s> not set:\n"
-#~ "\t(%s)\n"
-#~ msgstr ""
-#~ "\n"
-#~ "ERROR: El parámetro requerido <%s> no ha sido establecido:\n"
-#~ "    (%s).\n"
-#, fuzzy
-#~ msgid "Cannot describe table\n"
-#~ msgid "Name of table created for output when the distance to all flag is used"
-#~ msgstr "Nombre de la tabla creada para la salida cuando se usa la opción distancia a todos"
-#~ msgid "Fills no-data areas in raster maps using v.surf.rst splines interpolation"
-#~ msgstr "Rellenar áreas sin datos de los mapas ráster usando la interpolación splines de v.sufr.rst"
-#~ msgid "unable to open MASK"
-#~ msgstr "no se puede abrir MÁSCARA"
-#~ msgid ""
-#~ "\n"
-#~ " group <%s> not found"
-#~ msgstr ""
-#~ "\n"
-#~ " grupo <%s> no encontrado"
Modified: grass/trunk/locale/po/grassmods_fr.po
--- grass/trunk/locale/po/grassmods_fr.po	2012-05-26 15:22:06 UTC (rev 51802)
+++ grass/trunk/locale/po/grassmods_fr.po	2012-05-26 15:46:05 UTC (rev 51803)
@@ -36033,11354 +36033,3 @@
 #, fuzzy
 msgid "Percent to brighten"
 msgstr "Pourcentage de convergence"
-#, fuzzy
-msgid "Input raster map with specific yield in [1/m]"
-msgstr "Aucune couche spécifiée en entrée."
-#, fuzzy
-msgid "Raster map <%s> is not valid"
-msgstr "couche raster <%s> non trouvée"
-#, fuzzy
-msgid "If not given read from standard input"
-msgstr "Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué prendreles paramètres saisis en ligne de commande"
-#, fuzzy
-msgid "Print basic info in shell script style"
-msgstr "Produit les statistiques à la façon d'un script shell"
-#, fuzzy
-msgid "Projection:"
-msgstr "Traçage ... "
-#, fuzzy
-msgid "DBMI-OGR driver error:\n"
-msgstr "Erreur de pilote DBMI-MySQL:\n"
-#, fuzzy
-msgid "relative"
-msgstr "Corrélation"
-#, fuzzy
-msgid "Raster map for which to edit null file"
-msgstr "couche raster où remplacer les valeurs null"
-#, fuzzy
-msgid "Display the HTML man pages of GRASS GIS"
-msgstr "Afficher les pages de manuel GRASS au format HTML"
-#, fuzzy
-msgid "Join column in table"
-msgstr "Type de colonne inconnu"
-#, fuzzy
-msgid "Path to resulting ASCII file ('-' for standard output) or ASCII vector name if '-o' is defined"
-msgstr "Chemin vers le fichier ASCII résultat ou nom du fichier vecteur ASCII si '-o' est défini"
-# c-format
-#, fuzzy
-msgid "Unable to parse '%s'\n"
-msgstr "impossible de créer %s"
-#, fuzzy
-msgid "Driver <%s> doesn't support creating new fields"
-msgstr "le format 'point' b'est pas géré par l'ancienne version"
-#, fuzzy
-msgid "Unable to add new field <%s>"
-msgstr "impossible de lire le fichier 3dview <%s> dans <%s>"
-#, fuzzy
-msgid "Name of raster map from which to copy color table"
-msgstr "couche raster source pour la table de couleurs"
-#, fuzzy
-msgid "Name of file containing rules"
-msgstr "Fichier contenant les requêtes SQL"
-# c-format
-#, fuzzy
-msgid "Creating support files for <%s>"
-msgstr "impossible d'ouvrir le fichier pour %s"
-#, fuzzy
-msgid "Title for new raster file."
-msgstr "Nom de la nouvelle couche raster"
-#, fuzzy
-msgid "Unable it load G3d range"
-msgstr "Impossible de lire le fichier couleur"
-#, fuzzy
-msgid "\raster\" and \"volume\" options are mutually exclusive"
-msgstr "les drapeaux -B & - C sont mutuellement exclusifs. Veuillez n'en choisir qu'un seul."
-#, fuzzy
-msgid "Exports the color table associated with a raster3d map layer."
-msgstr "Creer/Modifier la table de couleurs associée à une couche raster."
-msgid "Could not close RASTER3D map"
-msgstr "Impossible de fermer la couche RASTER3D"
-msgid "Could not close RASTER3D map <%s>"
-msgstr "Impossible de fermer la couche RASTER3D <%s>"
-msgid "Name for v5d output file"
-msgstr "Nom du fichier de sortie v5d"
-#, fuzzy
-msgid "Converts a 3D raster map into a 3-dimensional Vis5D file."
-msgstr "Exporter une couche raster 3D GRASS vers un fichier 3D VIS-5D"
-#, fuzzy
-msgid "Lists available GIS elements of the user-specified data type."
-msgstr "Lister les fichiers de base de données GRASS disponibles du type spécifié par l'utilisateur vers la sortie standard."
-#, fuzzy
-msgid "Remove dangles:"
-msgstr "Suppression des centroïdes en doublons..."
-# c-format
-#, fuzzy
-msgid "Unable to create 3D vector and attribute table at same time"
-msgstr "Impossible de créer la couche raster <%s>"
-#, fuzzy
-msgid "Coordinates"
-msgstr "Coordonnées pour la requête"
-#, fuzzy
-msgid "maps for mosaic."
-msgstr "2nde couche pour la mosaïque."
-#, fuzzy
-msgid "Vector map for which to drop vector objects"
-msgstr "Nom de la couche de points vecteurs en entrée pour laquelle éditer la table attributaire"
-#, fuzzy
-msgid "Layer of attribute table to use for selection"
-msgstr "Nom du champ attributaire à utiliser pour les étiquettes"
-#, fuzzy
-msgid "WHERE conditions for vector delete, without 'where' keyword (e.g. \"elevation IS NULL\")"
-msgstr "Conditions WHERE de la requête SQL sans le mot clef 'where'"
-#, fuzzy
-msgid "Overwrite existing file"
-msgstr "Ecraser le MASK existant"
-#, fuzzy
-msgid "Name of input vector polygon map"
-msgstr "Nom de la couche vecteur"
-#, fuzzy
-msgid "Name of MODIS product"
-msgstr "Nom de la couche source"
-#, fuzzy
-msgid "The names of tile/s to download"
-msgstr "Nombre de points à placer"
-#, fuzzy
-msgid "raster, import, copying"
-msgstr "Importation vecteur complète"
-#, fuzzy
-msgid "raster, export, copying"
-#, fuzzy
-msgid "Name of input elevation map"
-msgstr "Nom de la couche raster source d'altitude"
-#, fuzzy
-msgid "Name for output shaded relief map"
-msgstr ""
-"#-#-#-#-#  grassmods_fr.po (grassmods_fr)  #-#-#-#-#\n"
-"Nom de la couche raster cible\n"
-"Nom de la couche raster de sortie"
-#, fuzzy
-msgid "Existing SPOT VGT NDVI HDF file (0001_NDV.HDF)"
-msgstr "Fichier SPOT VGT NDVI HDF existant (0001_NDV.HDF)"
-#, fuzzy
-msgid "zenith"
-msgstr "Longueur: %f\n"
-#, fuzzy
-msgid "topographic correction method"
-msgstr "couche raster de direction à créer"
-#, fuzzy
-msgid "Elevation file of unknown type"
-msgstr "Coordonnée d'altitude d'un point sur le plan."
-#, fuzzy
-msgid "Cannot allocate memory for auxiliar matrix.Consider changing region (resolution)"
-msgstr "Impossible d'allouer de la mémoire"
-#, fuzzy
-msgid "resampling"
-msgstr "Méthode d'échantillonnage"
-#, fuzzy
-msgid "map algebra"
-#, fuzzy
-msgid "Reading file <%s> ..."
-msgstr "Lecture du fichier [%s]..."
-#, fuzzy
-msgid "Mapset to list (default: current search path"
-msgstr "jeu de données à lister (par défaut : chemin de recherche courant)"
-#, fuzzy
-msgid "OGR data source name"
-msgstr "nom de la base de donnée"
-#, fuzzy
-msgid "Data source"
-msgstr "Nom de la base de données"
-#, fuzzy
-msgid "OGR layer name"
-#, fuzzy
-msgid "Name for GRASS vector map"
-msgstr "Nom du nouveau fichier vecteur binaire"
-#, fuzzy
-msgid "List available OGR layers in dsn and exit"
-msgstr "Lister les couches disponibles et quitter"
-# c-format
-#, fuzzy
-msgid "Buffering features..."
-msgstr "Écriture %s..."
-#, fuzzy
-msgid "connection"
-#, fuzzy
-msgid "Imports Mapgen or Matlab vector maps into GRASS."
-msgstr "Importer les couches vectorielles Mapgen ou Matlab dans GRASS"
-#, fuzzy
-msgid "integration"
-msgstr "Méthode d'interpolation à utiliser"
-#, fuzzy
-msgid "value, parameter"
-msgstr "Paramètres du cluster\n"
-#, fuzzy
-msgid "sun_elevation"
-msgstr "Résolution"
-#, fuzzy
-msgid "Path to rules file (\"-\" to write rules to stdout)"
-msgstr "Fichier de coordonnées en entrée (ne pas lire à partir de stdin)"
-#, fuzzy
-msgid "Can't read color table for <%s>"
-msgstr "Impossible de lire la table de couleur %s"
-#, fuzzy
-msgid "File containing recode rules; \"-\" to read from stdin"
-msgstr "Fichier ascii contenant les signatures spectrales"
-#, fuzzy
-msgid "Displays raster map layer."
-msgstr "Statistique de couches raster."
-#, fuzzy
-msgid "Displays vector map layer in the active map display window."
-msgstr "Afficher les données vectorielles GRASS dans le moniteur actif"
-# c-format
-#, fuzzy
-msgid "<%s> created."
-msgstr "Secteur %s créé!"
-#, fuzzy
-msgid "Available drivers:\n"
-msgstr "Lister les formats disponibles et quitter"
-#, fuzzy
-msgid "List available modules in the add-ons repository"
-#, fuzzy
-msgid "Calculates univariate statistics from a GRASS raster map based on vector polygons and uploads statistics to new attribute columns."
-msgstr "Calcule des statistiques univariées à partir d'une couche raster GRASS basée sur des objets vecteurs"
-#, fuzzy
-msgid "Displays raster map layer in the active map display window."
-msgstr "Affiche et superpose les couches rasters dans le moniteur actif"
-#, fuzzy
-msgid "Name and type of the new column(s) ('name type [,name type, ...]' - types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
-msgstr "nom et type de(s) nouvelle(s) colonne(s) (les types dépendent de la base de données utilisée, mais toutes gèrent VARCHAR(), INT, DOUBLE/REAL et DATE)"
-#, fuzzy
-msgid "Raster file to be converted."
-msgstr "Fichier raster à importer"
-#, fuzzy
-msgid "File containing reclass rules; \"-\" to read from stdin"
-#, fuzzy
-msgid "terrain analysis"
-msgstr "Statistiques de transition de classe."
-#, fuzzy
-msgid "Unable to open vector map <%s> on level 2"
-msgstr "impossible d'ouvrir le fichier vecteur <%s> dans <%s>"
-#, fuzzy
-msgid "Open vector map without topology (level 1)"
-#, fuzzy
-msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
-msgstr "mi(les), f(pieds), me(tres), k(ilomètres), a(cres), h(ectares)"
-#, fuzzy
-msgid "Print bounds and exit (shell style)"
-#, fuzzy
-msgid "Estimate spline step value"
-#, fuzzy
-msgid "<%s> table created in database."
-msgstr "La table <%s> n'existe pas dans la base de données <%s>"
-#, fuzzy
-msgid "report"
-msgstr "Importer"
-# c-format
-#, fuzzy
-msgid "Unable to get cell header for <%s>"
-msgstr "Impossible d'écrire l'en-tête de [%s]"
-#, fuzzy
-msgid "Error reading <%s>"
-msgstr "Erreur de lecture de la couche %s"
-# c-format
-#, fuzzy
-msgid "%s: Error reading from raster map <%s>"
-msgstr "Erreur de lecture du fichier raster [%s]"
-#, fuzzy
-msgid "unable to open map <%s> in <%s>"
-msgstr "Impossible d'ouvrir la couche raster [%s] dans [%s]"
-#, fuzzy
-msgid "unable to read map <%s> in <%s>"
-msgstr "impossible de lire la région <%s> dans <%s>"
-# c-format
-#, fuzzy
-msgid "Unable to open base map <%s>"
-msgstr "Impossible d'ouvrir la couche raster <%s>"
-# c-format
-#, fuzzy
-msgid "Unable to open cover map <%s>"
-msgstr "Impossible d'ouvrir la couche vecteur [%s]"
-# c-format
-#, fuzzy
-msgid "Unable to open output map <%s>"
-msgstr "impossible d'ouvrir le fichier en sortie <%s>"
-# c-format
-#, fuzzy
-msgid "Unable to read header for <%s>"
-#, fuzzy
-msgid "Error reading row %d (error = %d)"
-msgstr "Impossible de récupérer la ligne %d (erreur =%d)"
-#, fuzzy
-msgid "Cannot set region to output region"
-msgstr "Impossible de reconfigurer la région sur la région initiale !!!"
-#, fuzzy
-msgid "Cannot set region to back to the initial region"
-#, fuzzy
-msgid "Unable to read row %d"
-msgstr "Impossible de lire la ligne %i\n"
-#, fuzzy
-msgid "Unable to read region <%s>"
-msgstr "Impossible d'insérer une nouvelle ligne : %s"
-#, fuzzy
-msgid "unable to open accumulation map layer"
-msgstr "Impossible d'ouvrir la nouvelle couche d'accumulation."
-# c-format
-#, fuzzy
-msgid "SECTION 4: Extracting Streams."
-#, fuzzy
-msgid "Error reading row <%d>"
-msgstr "Erreur de lecture de la ligne de données"
-#, fuzzy
-msgid "Name of input raster map containing starting points"
-msgstr "Nom de la couche en entrée contenant les coûts de rugosité"
-# c-format
-#, fuzzy
-msgid "Unable to open input map <%s>"
-msgstr "impossible d'ouvrir le fichier en entrée <%s>"
-#, fuzzy
-msgid "Error reading row %d"
-# c-format
-#, fuzzy
-msgid "Unable to read from <%s> row %d"
-# c-format
-#, fuzzy
-msgid "Unable to read file header of raster map <%s>"
-msgstr "Impossible d'écrire la couche raster lac <%s>!"
-# c-format
-#, fuzzy
-msgid "Unable to write to raster map<%s>"
-msgstr "Impossible de créer la couche raster %s"
-# c-format
-#, fuzzy
-msgid "Unable to open training map <%s>"
-#, fuzzy
-msgid "Unable to open training map <%s in %s>"
-# c-format
-#, fuzzy
-msgid "Cannot open cell file [%s]"
-msgstr "Impossible d'ouvrir le fichier [%s]"
-# c-format
-#, fuzzy
-msgid "Cannot read file header of [%s])"
-msgstr "Impossible de lire les informations de l'en-tête de fichier [%s]"
-# c-format
-#, fuzzy
-msgid "Cannot write to output raster file"
-# c-format
-#, fuzzy
-msgid "Unable to read header of raster map <%s> "
-# c-format
-#, fuzzy
-msgid "Unable to read raster map <%s> row %d >"
-#, fuzzy
-msgid "qcname"
-msgstr "nom =%s\n"
-#, fuzzy
-msgid "Name of QC"
-msgstr "Nom du fichier PNG"
-#, fuzzy
-msgid "250m band number is out of allowed range [1,2]"
-msgstr "Nombre de cadres de l'animation"
-# c-format
-#, fuzzy
-msgid "Cannot read file header of [%s]"
-#, fuzzy
-msgid "raster, rainfall, erosion, USLE"
-msgstr "Nombre de points d'interpolation"
-#, fuzzy
-msgid "raster, soil, erosion, USLE"
-#, fuzzy
-msgid "SECTION 3: Accumulating Surface Flow with MFD"
-msgstr ""
-"\n"
-"SECTION 3: Accumulation du courant de surface.       Achevé (pourcentage):"
-#, fuzzy
-msgid "Unable to find the real-image map <%s>"
-msgstr "%s: %s - impossible de trouver l'image (partie réelle)"
-msgid ""
-"Unable to open real-image in the cell_misc directory.\n"
-"Input map probably wasn't created by i.fft"
-msgstr ""
-"Impossible d'ouvrir l'image (partie réelle) dans le répertoire cell_misc.\n"
-"La couche en entrée n'a pas été créée par i.fft"
-#, fuzzy
-msgid "Unable to find the imaginary-image <%s>"
-msgstr "%s: %s - impossible de trouver l'image (partie imaginaire)"
-msgid ""
-"Unable to open imaginary-image in the cell_misc directory.\n"
-msgstr ""
-"Impossible d'ouvrir l'image (partie imaginaire) dans le répertoire cell_misc.\n"
-msgid "Group [%s] not found."
-msgstr "Groupe [%s] non trouvé"
-msgid "Range less than or equal to zero not allowed."
-msgstr "Intervalle inférieur ou égal à zéro non valide"
-msgid "Writing viewable versions of transformed data to files..."
-msgstr "Ecriture des versions visualisables des données transformées dans les fichiers..."
-msgid "Unable to open file in the cell_misc directory."
-msgstr "Impossible d'ouvrir le fichier dans le répertoire cell_misc"
-#, fuzzy
-msgid "Name of image to be rectified which will  be initially drawn on screen."
-msgstr "Nom de l'image à recaler à afficher à l'écran"
-#, fuzzy
-msgid "Name of a map from target mapset which  will be initially drawn on screen."
-msgstr "Nom de la couche de données du jeu de données cible à afficher à l'écran."
-#, fuzzy
-msgid "Name of old database. The database must be in form printed by v.db.connect -g, i.e. with substituted variables"
-msgstr "Nom de l'ancienne base de données, la base de données doit être sous à la forme affichée par v.db.connect -c'est-à-dire en substituant les variables"
-msgid "name for new map image (lives in ~/.gpsdrive)"
-msgstr "nom pour une nouvelle couche image (dans ~/.gpsdrive)"
-# c-format
-msgid "Terrain raster map (DEM)"
-msgstr "Couche raster de terrain (MNT)"
-msgid "Use output= option to change vector map name"
-msgstr "Utilisez l'option output= pour changer le nom de la couche vectorielle"
-# c-format
-#, fuzzy
-msgid "Erasing monitors ..."
-msgid "Category file for [%s] not available"
-msgstr "Le fichier de catégorie pour [%s] n'est pas disponible"
-msgid "color file for [%s] not available"
-msgstr "Fichier de couleur de [%s] non disponible"
-msgid "Output aspect filename"
-msgstr "Nom de fichier de sortie pour l'aspect"
-#, fuzzy
-msgid "raster, projection"
-msgstr "Projection source"
-msgid "defaulting to nearest neighbor sampling"
-msgstr "Retour à l'échantillonnage au plus propre voisin par défaut"
-# c-format
-#, fuzzy
-msgid "Could not open elevation map"
-msgstr "Impossible d'ouvrir la couche de relief\n"
-msgid "Import as Floating Point Data (default: Integer)"
-msgstr "Importer comme données à virgule flottante (par défaut : entier)"
-msgid "Import as Double Precision Data (default: Integer)"
-msgstr "Importer comme virgule flottante en double précision (par défaut : entier)"
-#, fuzzy
-msgid "Bad number of bytes per cell"
-msgstr "\t\tNombre de bits par cellule"
-msgid "Raster File Series to MPEG Conversion Program."
-msgstr "Programme de conversion d'une série de fichiers raster vers MPEG."
-# c-format
-#, fuzzy
-msgid "Total area: %e (%d areas)"
-# c-format
-#, fuzzy
-msgid "Area without category: %e (%d areas)"
-msgstr "%d points sans catégorie"
-#, fuzzy
-msgid "Converts a binary GRASS vector map into a GRASS raster map ."
-msgstr "Convertit une couche vecteur binaire GRASS en couche raster GRASS"
-#, fuzzy
-msgid "Duplicate area centroids: %5d"
-msgstr "Impossible de calculer le centroïde de la surface"
-#, fuzzy
-msgid "Bad format in initial exposusre station file for group <%s>"
-msgstr "Ajouter les fichiers au groupe [%s]"
-#, fuzzy
-msgid "Close boundaries"
-msgstr "impossible de mettre à jour les limites"
-msgid "Converts 3D raster maps (RASTER3D) into the VTK-Ascii format"
-msgstr "Convertit une couche raster 3D au format VTK-ASCII"
-#, fuzzy
-msgid "unable to close top raster map"
-msgstr "Impossible de fermer la couche de sortie"
-#, fuzzy
-msgid "unable to close bottom raster map"
-#, fuzzy
-msgid "Output saturation raster map"
-msgstr "couche raster de sortie"
-#, fuzzy
-msgid "Unable to read map raster row %d"
-msgstr "Impossible de lire la ligne raster."
-msgid "Converts a 3D raster map layer into an ASCII text file"
-msgstr "Convertit une couche raster 3D en fichier texte ASCII."
-#, fuzzy
-msgid "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
-msgstr "Convertir un fichier raster ASCII en couche raster 3D (binaire)."
-msgid ""
-"Cannot create mask file: RASTER3D_MASK already exists!\n"
-" Use 'g.remove rast3d=RASTER3D_MASK' to remove the existing mask."
-msgstr ""
-"Impossible de créer un fichier masque : RASTER3D_MASK existe déjà!\n"
-"Utilisez 'g.remove rast3d=RASTER3D_MASK' pour supprimer le masque existant."
-msgid "also import quality map (SM status map layer) and filter NDVI map"
-msgstr "importer aussi la couche de qualité (couche du statut SM) et couche filtre NDVI"
-#, fuzzy
-msgid "Name for output flowline density raster map"
-msgstr "Fichier raster en sortie pour la densité des courants"
-#, fuzzy
-msgid "vector, interpolation, kriging"
-#, fuzzy
-msgid "Raster map to use as mask"
-msgstr "couche raster à utiliser comme MASK"
-#, fuzzy
-msgid "Creates a mask for limiting raster operation."
-msgstr "Créer un MASKER pour limiter l'opération sur le raster"
-msgid "Raster value"
-msgstr "Valeur raster"
-#, fuzzy
-msgid "Pass %d:"
-msgstr "Masque: %s\n"
-msgid "Use db.select for SELECT SQL statements"
-msgstr "Utiliser db.select pour les déclarations SELECT SQL"
-#, fuzzy
-msgid "raster3d, statistics"
-#, fuzzy
-msgid "vector, query"
-msgstr "Couche vecteur à supprimer"
-msgid "Feature type. Combination of types is not supported by all formats."
-msgstr "Type d'objet. Le mélange de types n'est pas géré par tous les format."
-msgid "Illegal configuration file"
-msgstr "Nom du fichier de configuration illégal"
-# c-format
-#, fuzzy
-msgid "Could not find input map <%s> in current mapset."
-msgstr "couche d'entrée introuvable <%s>"
-msgid "Print the current region (shell script style)"
-msgstr "Affiche les paramètres de la région courante (à la façon d'un script shell)"
-# c-format
-#, fuzzy
-msgid "Converting %s..."
-msgstr "Écriture [%s]..."
-#, fuzzy
-msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation layer."
-msgstr "Filtrer et générer une couche d'altitude sans dépressions et une couche de direction d'écoulement depuis une couche d'altitude donnée"
-msgid "CHILD[pid = %i]: unable to open %s mask ... continue without!!!"
-msgstr "CHILD[pid = %i] : impossible d'ouvrir le mask %s... continuer sans!!!"
-msgid "r.li.worker (pid %i) exited with abnormal status %i"
-msgstr "r.li.worker (pid %i) interrompu avec un statut anormal %i"
-#, fuzzy
-msgid "r.li.worker (pid %i) terminated"
-msgstr "r.li.worker (pid %i) achevé\n"
-#, fuzzy
-msgid "Cannot make stat of %s configuration file"
-msgstr "Impossible de faire les stats du fichier de configuration %s"
-msgid "Calculates cast shadow areas from sun position and DEM. Either A: exact sun position is specified, or B: date/time to calculate the sun position by r.sunmask itself."
-msgstr "Calculer des zones d'ombre portée à partir de la position du soleil et d'un MNT. A : la position exacte du soleil est donnée. B : date/heure pour calculer la position du soleil grâce à r.sunmask."
-msgid "A: altitude of the sun above horizon, degrees"
-msgstr "A : altitude du soleil au dessus de l'horizon, en degrés"
-msgid "B: minutes (0..60)"
-msgstr "B : minutes (0..60)"
-msgid "B: seconds (0..60)"
-msgstr "B : secondes (0..60)"
-msgid "B: timezone (east positive, offset from GMT, also use to adjust daylight savings)"
-msgstr "B : fuseau horaire (positif vers l'est, différence par rapport à GMT)"
-msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)"
-msgstr "Constructon de courbes de terrain (lignes du courant), longueur des courants, et densité de lignes de courants (zones amont) à partir d'un modèle numérique de terrain (MNT) raster"
-msgid "Show the category label in the grid cell(s)"
-msgstr "Montre l'étiquette de catégorie dans la(les) cellule(s) de grille"
-#, fuzzy
-msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
-msgstr "Crée une couche d'indice topographique ln(a/tan(beta)) à partir d'une couche d'altitude."
-#, fuzzy
-msgid "Unable to read symbol, unable todisplay points"
-msgstr "Impossible de lire le symbole, impossible d'afficher les points"
-#, fuzzy
-msgid "Converts to one of the supported OGR vector formats."
-msgstr "Convertir vers un des formats vecteurs gérés par OGR"
-#, fuzzy
-msgid "Exporting %i points/lines..."
-msgstr "Importation des objets de la couche %d..."
-msgid "Number of column used as y coordinate (first column is 1) for points mode"
-msgstr "Nombre de colonnes utilisées comme coordonnées y (la première colonne est 1) en mode points"
-#, fuzzy
-msgid "Number of column used as z coordinate (first column is 1) for points mode"
-msgstr "Nombre de colonnes utilisées comme coordonnées x (la première colonne est 1) en mode points"
-#, fuzzy
-msgid "Number of column used as category (first column is 1) for points mode"
-#, fuzzy
-msgid "If 0, unique category is assigned to each row and written to new column 'cat'"
-msgstr "Nombre de colonne utilisé comme catégorie (la première colonne est 1) en mode pointsSi la valeur est 0, une catégorie unique est assignée à chaque ligne et écrit dans la nouvelle colonne 'cat'."
-#, fuzzy
-msgid "Create a new empty vector map and exit. Nothing is read from input"
-msgstr "Crée une nouvelle couche vide et quitte. Rien n'est lu en entrée."
-#, fuzzy
-msgid "Name for output file (do not add extension)"
-msgstr "Nom du fichier en sortie (ne PAS ajouter l'extension)"
-#, fuzzy
-msgid "Width and height of output image"
-msgstr "Largeur de la couleur de mise en valeur"
-#, fuzzy
-msgid "Surface"
-msgstr "Variance de la somme"
-#, fuzzy
-msgid "Volume"
-msgstr "colonne(s)"
-#, fuzzy
-msgid "Convert all old GRASS < Ver5.7 vector maps in current mapset to current format"
-msgstr "convertit toutes les anciennes couches vectorielles GRASS (versions antérieures à 5.7) du jeu de données courant au format récent"
-#, fuzzy
-msgid "Vector map for which to edit attribute table"
-msgid "Layer where to add column"
-msgstr "Couche à laquelle ajouter la colonne"
-#, fuzzy
-msgid "Computing row %d of covariance matrix..."
-msgstr "Calcul de la matrice de covariance de classe"
-#, fuzzy
-msgid "ID values"
-msgstr "Valeur de la chaîne de bit"
-#, fuzzy
-msgid "Type of elements"
-msgstr "Nom d'un élément"
-msgid "Writing data to file..."
-msgstr "Écriture des données dans le fichier..."
-#, fuzzy
-msgid "Output hue raster map"
-msgstr "couche raster en sortie"
-#, fuzzy
-msgid "display, legend"
-msgstr "Faire pivoter le cartouche de légende"
-# c-format
-#, fuzzy
-msgid "Database record for cat %d not found"
-msgstr "Aucun enregistrement pour la catégorie (cat = %d)"
-# c-format
-msgid "Could not find input vector map %s"
-msgstr "Couche d'entrée vecteur introuvable %s"
-msgid "Number of column used as z coordinate (first column is 1) for points mode. If 0, z coordinate is not used."
-msgstr "Nombre de colonnes utilisées comme coordonnées x (la première colonne est 1) en mode pointsSi la valeur est 0, les coordonnées z ne sont pas utilisées."
-msgid "Name of the column with tree height"
-msgstr "Nom de la colonne contenant la hauteur de l'arbre"
-msgid "Name of the column with tree species"
-msgstr "Nom de la colonne contenant les essences d'arbres"
-#, fuzzy
-msgid "Column name (will be updated by qvector values)"
-msgstr "Nom de la colonne (qui sera mise à jour par les valeurs rasters)"
-#, fuzzy
-msgid ""
-"\n"
-"ERROR: Required parameter <%s> not set:\n"
-"    (%s).\n"
-msgstr "incidout demande de fixer le paramètre d'heure"
-#, fuzzy
-msgid "Band to select"
-msgstr "Pas de moniteur sélectionné"
-#, fuzzy
-msgid "Select type"
-msgstr "Type de donnée vectorielle"
-#, fuzzy
-msgid "Cannot select records from database"
-msgstr "Impossible de sélectionner des données dans la table"
-#, fuzzy
-msgid "Removed vertices"
-msgid "Database connection not defined\n"
-msgstr "La connexion à la base de données n'a pas été définie\n"
-# c-format
-msgid "Cannot find file %s"
-msgstr "Impossible de trouver le fichier %s"
-# c-format
-msgid "Cannot get header for %s"
-msgstr "Impossible de trouver l'en-tête de fichier %s"
-msgid "Cannot describe table"
-msgstr "Impossible de décrire la table"
-#, fuzzy
-msgid "Out of memory!"
-msgstr "Mémoire insuffisante"
-# c-format
-#, fuzzy
-msgid "Cannot open driver <%s>"
-msgstr "Impossible d'utiliser le pilote %s"
-msgid "New vector composite"
-msgstr "Nom du fichier vecoriel composite"
-#, fuzzy
-msgid "No database updates."
-# c-format
-#, fuzzy
-msgid "%s Pan\n"
-msgstr "%s\n"
-#, fuzzy
-msgid "Watershed basin analysis program"
-msgstr "Programme d'analyse de bassin versant."
-#, fuzzy
-msgid "Name of input raster map with real depressions"
-msgstr "Nom de la couche raster source"
-#, fuzzy
-msgid "Name of input raster map blocking overland surface flow"
-msgstr "couche d'entrée : terrain bloquant l'écoulement de surface, pour USLE"
-#, fuzzy
-msgid "Name for output raster map useful for visual display of results (DEPRECATED)"
-msgstr "Couche de sortie : pratique pour visualiser les résultats"
-# c-format
-#, fuzzy
-msgid "Direction raster found <%s>"
-msgstr "Couche raster %i créée \n"
-#, fuzzy
-msgid "Name for output direction map for depressionless elevation raster map"
-msgstr "(o) Couche de gradient à partir d'une couche d'altitudes positives"
-#, fuzzy
-msgid "raster, export, animation"
-msgstr "Tracer le relief"
-#, fuzzy
-msgid "(requires r.out.ppm with stdout option)"
-msgstr ""
-"Convertir à la volée, en économisant l'espace disque\n"
-"\t(nécessite r.out.ppm avec l'option stdout)"
-#, fuzzy
-msgid "Name for output elevation raster map after filling"
-msgstr "couche raster d'altitude après remplissage"
-#, fuzzy
-msgid "Name for output direction raster map"
-msgstr ""
-# c-format
-#, fuzzy
-msgid "Reading input data..."
-msgstr "Lecture du fichier %s..."
-# c-format
-#, fuzzy
-msgid "Writing output data..."
-#, fuzzy
-msgid "raster, reclassification"
-#, fuzzy
-msgid "Name of input raster map with given starting point(s) (at least 1 cell > 0)"
-msgstr "Couche raster avec le germe (au moins 1 cellule > 0)"
-#, fuzzy
-msgid "Name for flowpath length raster map"
-msgstr "Fichier raster en sortie pour la longueur des courants"
-#, fuzzy
-msgid "imagery, landsat, acca"
-msgstr "Nom de fichier de signatures à utiliser pour la classification"
-# c-format
-#, fuzzy
-msgid "Cannot write to raster map <%s>"
-#, fuzzy
-msgid "Creates, edits, and lists groups and subgroups of imagery data."
-msgstr "Crée et édite des groupes et sous-groupes de fichiers images"
-# c-format
-#, fuzzy
-msgid "Extract quality control parameters from Modis QC layers"
-#, fuzzy
-msgid "Name of the surface reflectance QC layer [bit array]"
-msgstr "Nom de la couche qui contiendra la surface fractale"
-#, fuzzy
-msgid "The output cell map <%s.%d> has values outside the 0-255 range. Min: %d Max: %d"
-msgstr "La couche de sortie <%s.%d> possède des valeurs en dehors de l'intervalle 0-255.\n"
-#, fuzzy
-msgid "Computing means and standard deviations..."
-msgstr "La copie de table a échoué"
-#, fuzzy
-msgid "Computing means..."
-msgstr "Recherche des classes d'apprentissage..."
-#, fuzzy
-msgid "Other"
-msgstr "Confirmation?"
-#, fuzzy
-msgid "Offset in map units."
-msgstr "Distance de zone-tampon en unités carte."
-#, fuzzy
-msgid "db connection was not set by form"
-#, fuzzy
-msgid "DEPRECATED Buffer distance in map units"
-#, fuzzy
-msgid "Line buffers... "
-#, fuzzy
-msgid "Zero area size, please clean input vector first."
-msgstr "Créer des points le long des lignes en entrée."
-#, fuzzy
-msgid "Could not get outside buffer for line id %d"
-msgstr "Impossible de lire le fichier d'intervalle"
-#, fuzzy
-msgid "Area buffers... "
-msgstr "couche raster source"
-#, fuzzy
-msgid "Selecting areas..."
-msgstr "Calcul des moyennes de classes..."
-#, fuzzy
-msgid "Cannot allocate %u bytes of memory"
-msgstr "Impossible d'allouer le curseur"
-#, fuzzy
-msgid "Skip the join column in other table"
-#, fuzzy
-msgid "Copy all the columns from other table to map"
-#, fuzzy
-msgid "Name of input raster map in which to fill nulls"
-#, fuzzy
-msgid "Name for output raster map with nulls filled by interpolation"
-msgstr "Couche raster de sortie où remplacer les nulls par interpolation des valeurs voisines"
-#, fuzzy
-msgid "Mosaics up to four images, extending the color table."
-msgstr "Faire une mosaïque comprenant jusqu'à 4 images et étendre la table de couleurs; créer une couche *.mosaic"
-#, fuzzy
-msgid "creates map *.mosaic"
-msgstr "3ème couche pour la mosaïque."
-#, fuzzy
-msgid "1st map for mosaic (top of image stack)"
-msgstr "1ère couche pour la mosaïque (au somment de la pile d'images)"
-#, fuzzy
-msgid "2nd map for mosaic"
-#, fuzzy
-msgid "3rd map for mosaic"
-#, fuzzy
-msgid "4th map for mosaic"
-msgstr "4ème couche pour la mosaïque."
-#, fuzzy
-msgid "writing edges..."
-msgstr "Écrire les sommets de lignes."
-#, fuzzy
-msgid "raster, png"
-msgid "Import Mapgen or Matlab vector maps into GRASS."
-msgid "Ascii file containing spectral signatures"
-# c-format
-#, fuzzy
-msgid "Unhandled vector feature type <%s>"
-msgstr "impossible de créer la sortie <%s>"
-# c-format
-#, fuzzy
-msgid "No areas found, skipping type=area"
-msgstr "%d points en dehors de la région courante"
-# c-format
-#, fuzzy
-msgid "No points found, skipping%s%s"
-# c-format
-#, fuzzy
-msgid "No lines found, skipping%s%s"
-#, fuzzy
-msgid "GDAL datatype: %s, range: %f - %f"
-#, fuzzy
-msgid "The '-q' flag is superseded and will be removed "
-msgstr "Couche raster %i le nom de fichier %s existe déjà. Ce fichier va être écrasé!\n"
-# c-format
-#, fuzzy
-msgid "Unable to create table <%s_edge_Interpolation>"
-#, fuzzy
-msgid "Rescale output raster map [0,255]"
-msgstr ""
-# c-format
-msgid "** Can't open seed singature file <%s> **"
-msgstr "impossible d'ouvrir le fichier signature germe <%s>"
-msgid "A: azimuth of the sun from the north, degrees"
-msgstr "A : angle du soleil par rapport au nord, en degrés"
-#, fuzzy
-msgid "%d faces found, but not requested to be exported. Verify 'type' parameter."
-msgstr "%d Entités surfacique(s) trouvée(s), mais impossible de les exporter. Vérifiez le paramètre 'type'"
-msgid "Create a MASK for limiting raster operation"
-#, fuzzy
-msgid "Import Mapgen or Matlab-ASCII vector maps into GRASS."
-msgid "Name of the new raster map"
-msgstr "Nom du nouveau fichier raster"
-#, fuzzy
-msgid "Line: %d\n"
-msgstr "Hauteur de la ligne: %f\n"
-msgid "database location"
-msgstr "Secteur (location) de la base de données"
-#, fuzzy
-#~ msgid "Input grid3 filename"
-#~ msgstr "Nom du fichier 3D de sortie"
-# c-format
-#, fuzzy
-#~ msgid "Grid3 <%s> not found %s"
-#~ msgstr "couche 3D <%s> non trouvée %s\n"
-#~ msgid "Failed to guess site file format"
-#~ msgstr "Echec pour définir le format du fichier de sites"
-#~ msgid "Print raster map resolution (NS-res, EW-res) only"
-#~ msgstr "Afficher seulement la résolution raster (NS-res, EW-res)"
-#~ msgid "Print raster map type only"
-#~ msgstr "Écrire uniquement le type de couche"
-#, fuzzy
-#~ msgid "Print map region only"
-#~ msgstr "Afficher seulement la région de la couche raster"
-#, fuzzy
-#~ msgid "Print raster map data units only"
-#, fuzzy
-#~ msgid "Print raster map vertical datum only"
-#, fuzzy
-#~ msgid "Print map title only"
-#~ msgid "Print raster map timestamp (day.month.year hour:minute:seconds) only"
-#~ msgstr "Afficher l'étiquette date&heure de la couche raster (sous la forme jour.mois.année heure:minute:secondes)"
-#, fuzzy
-#~ msgid "Name for value output map"
-#~ msgstr ""
-#~ "#-#-#-#-#  grassmods_fr.po (grassmods_fr)  #-#-#-#-#\n"
-#~ "Nom de la couche raster cible\n"
-#~ "Nom de la couche raster de sortie"
-# c-format
-#~ msgid "Invalid timestamp"
-#~ msgstr "Etiquette date&heure invalide"
-# c-format
-#, fuzzy
-#~ msgid "Reading sites..."
-#~ msgstr "Lecture du fichier %s..."
-# c-format
-#, fuzzy
-#~ msgid "Writing sites to output..."
-#~ msgstr "Écriture %s..."
-#, fuzzy
-#~ msgid "Reading coordinates from file."
-#~ msgstr "Les coordonnées XY du/des foyer(s) initial(aux)"
-#, fuzzy
-#~ msgid "ASCII file holding transform coordinates"
-#~ msgstr "Facteur d'échelle pour les coordonnées x"
-#, fuzzy
-#~ msgid "If not given, transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot) are used instead"
-#~ msgstr "A la place des points, utilisez les options de transformation (xshift, yshift, zshift, xscale, yscale, zscale, zrot)"
-#, fuzzy
-#~ msgid "Unable to open file with coordinates <%s>"
-#~ msgstr "Impossible d'ouvrir le fichier avec les coordonnées : %s\n"
-#, fuzzy
-#~ msgid "Error reading coordinates file"
-#, fuzzy
-#~ msgid "Number of points that have been entered [%d]"
-#~ msgstr "Nombre de points ayant été entrés: %d\n"
-#, fuzzy
-#~ msgid "Error creating transformation"
-#~ msgstr "Erreur de lecture des cellules de données"
-#~ msgid "The points weren't spread out enough."
-#~ msgstr "Les points ne sont pas suffisamment disséminés."
-#~ msgid "You need to enter at least %d points."
-#~ msgstr "Vous devez entrer au moins %d points."
-#~ msgid "Column name (will be updated by raster values)"
-#~ msgstr "Nom de la colonne (qui sera mise à jour par les valeurs rasters)"
-#~ msgid "Cannot scan date: "
-#~ msgstr "Impossible de scanner la date: "
-#~ msgid "Cannot scan time: "
-#~ msgstr "Impossible de scanner le temps: "
-#~ msgid "Cannot allocate cursor."
-#~ msgstr "Impossible d'allouer le curseur"
-#~ msgid "Cannot ad new token."
-#~ msgstr "Impossible d'ajouter la nouvelle entrée"
-#~ msgid "Cannot connect to MySQL: "
-#~ msgstr "Impossible de se connecter à MySQL"
-#~ msgid "DBMI-MySQL driver error:\n"
-#~ msgstr "Erreur de pilote DBMI-MySQL:\n"
-#~ msgid "Cannot select data: \n"
-#~ msgstr "Impossible de sélectionner des données : \n"
-#, fuzzy
-#~ msgid "Unable allocate memory for row buffer"
-#~ msgstr "Impossible d'allouer de la mémoire pour les pointeurs de ligne"
-#, fuzzy
-#~ msgid "Computing means for band %d..."
-#~ msgstr "La copie de table a échoué"
-#, fuzzy
-#~ msgid "Computing row %d (of %d) of covariance matrix..."
-#~ msgstr "Calcul de la matrice de covariance de classe"
-#, fuzzy
-#~ msgid "Unable to allocate memory for row buffer"
-#, fuzzy
-#~ msgid "Unable to allocate memory for raster row"
-#~ msgstr "Impossible d'allouer de la mémoire"
-#, fuzzy
-#~ msgid "Transforming <%s>..."
-#~ msgstr "Rotation des données ... "
-#~ msgid "Surface area estimation for rasters."
-#~ msgstr "Estimation de surface pour raster."
-#~ msgid "Raster file for surface"
-#~ msgstr "Fichier raster à utiliser comme surface"
-#, fuzzy
-#~ msgid "Writing buffers..."
-#~ msgstr "Écriture des attributs..."
-#, fuzzy
-#~ msgid "ASCII file to be converted to binary vector map"
-#~ msgstr "Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué prendreles paramètres saisis en ligne de commande"
-#, fuzzy
-#~ msgid "If not given (or \"-\") reads from standard input"
-#, fuzzy
-#~ msgid "Join column in other table"
-#~ msgstr "Type de colonne inconnu"
-#, fuzzy
-#~ msgid "Layer number or name with route paths or -1"
-#~ msgstr "Code de couche"
-#, fuzzy
-#~ msgid "Layer %d - no table"
-#~ msgstr "La couche '%s' n'est pas disponible"
-#, fuzzy
-#~ msgid "Layer %d - unable to copy table"
-#~ msgstr "Impossible d'ouvrir le fichier de sortie"
-#, fuzzy
-#~ msgid "Source layer number or name"
-#, fuzzy
-#~ msgid "Sink layer number or name"
-#, fuzzy
-#~ msgid "Name of Arc cost column"
-#~ msgstr "Nombre de colonnes"
-#, fuzzy
-#~ msgid "Enter -1 to keep original categories or the desired NEW category value"
-#~ msgstr "Saisir -1 pour conserver la catégorie originale ou la valeur de la NOUVELLE catégorie souhaitée. Si la nouvelle est >= 0, la table n'est pas copiée."
-#, fuzzy
-#~ msgstr "Nom de la colonne y"
-#, fuzzy
-#~ msgid "From layer number or name"
-#, fuzzy
-#~ msgid "To layer number or name"
-#, fuzzy
-#~ msgid "Name of node capacity column"
-#, fuzzy
-#~ msgid "Set1 layer number or name"
-#, fuzzy
-#~ msgid "Set2 layer number or name"
-#, fuzzy
-#~ msgid "Either mapset= or -l must be used"
-#~ msgstr "L'une des options, soit texte soit -c, doit être sélectionnée."
-#, fuzzy
-#~ msgid "Line width column (%s) is not numeric."
-#~ msgstr "la colonne de largeur de ligne (%s) n'est pas de type nombre"
-#, fuzzy
-#~ msgid "Error in color definition column '%s', feature id %d with cat %d: colorstring '%s'"
-#~ msgstr "Erreur dans la colonne de définition de couleur (%s), entité surfacique %d avec la catégorie %d: code couleur [%s]"
-#, fuzzy
-#~ msgid "Error in color definition column '%s', feature id %d with cat %d"
-#~ msgstr "Erreur dans la colonne de définition de couleur (%s), entité surfacique %d avec la catégorie %d"
-#, fuzzy
-#~ msgid "Error in symbol size column (%s), element %d with cat %d: symbol size [%f]"
-#~ msgstr "Erreur dans la colonne de définition de couleur (%s), élément %d avec la catégorie %d: largeur de ligne [%d]"
-#, fuzzy
-#~ msgid "Error in color definition column '%s': %d features affected"
-#~ msgid "'layer' must be > 0 for 'where'."
-#~ msgstr "'layer' doit être > 0 pour 'where'."
-#~ msgid "'layer' must be > 0 for 'cats'."
-#~ msgstr "'layer' doit être >0 pour 'cats'."
-#, fuzzy
-#~ msgid "Can't read vector map"
-#~ msgstr "Impossible de lire la couche vecteur"
-#~ msgid "Color definition column not specified."
-#~ msgstr "La colonne de définition de couleur n'est pas spécifiée."
-#~ msgid "Error in color definition column (%s), area %d with cat %d: colorstring [%s]"
-#~ msgid "pg driver: column '%s', type %d  is not supported"
-#~ msgstr "Pilote pg: colonne '%s', type de donnée %d non géré"
-#~ msgid "Type of color table"
-#~ msgstr "Type de la table de couleur"
-#, fuzzy
-#~ msgid "Save placeholder raster map for use with d.legend"
-#~ msgstr "Nom de la couche raster d'aspect à afficher"
-#, fuzzy
-#~ msgid "Name and type of the new column(s) (types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
-#~ msgstr "nom et type de(s) nouvelle(s) colonne(s) (les types dépendent de la base de données utilisée, mais toutes gèrent VARCHAR(), INT, DOUBLE/REAL et DATE)"
-#, fuzzy
-#~ msgid "Name for input source not specified"
-#~ msgstr "Aucune couche spécifiée en entrée."
-#, fuzzy
-#~ msgid "Name for output raster map not specified"
-#~ msgstr ""
-#, fuzzy
-#~ msgid "Requested g3d map <%s> not found"
-#~ msgstr "Le fichier raster g3d RGB <%s> n'a pas été trouvé"
-#, fuzzy
-#~ msgid "Error opening g3d map <%s>"
-#~ msgstr ""
-#~ "Erreur à l'ouverture de la couche g3d <%s>\n"
-#~ "Erreur à l'ouverture du fichier raster 3D <%s>"
-#, fuzzy
-#~ msgid "-g and -a flags are mutually exclusive"
-#~ msgstr "les drapeaux -B & - C sont mutuellement exclusifs. Veuillez n'en choisir qu'un seul."
-#, fuzzy
-#~ msgid "Negative or no data pixel found. This module is not yet able to process no data holes in a map, please fill with r.fillnulls or other algorithms"
-#~ msgstr "Valeur négative ou pixel sans données trouvé. Ce module n'est pour l'instant pas capable de traiter les trous de données dans une couche, veuillez compléter la couche avec r.fillbulls ou d'autres algorithmes."
-#~ msgid "Angular Second Moment"
-#~ msgstr "Second temps angulaire"
-#, fuzzy
-#~ msgid "Features"
-#~ msgstr "Type de donnée vectorielle"
-#~ msgid "Contrast"
-#~ msgstr "Contraste"
-#~ msgid "Correlation"
-#~ msgstr "Corrélation"
-#~ msgid "Variance"
-#~ msgstr "Variance"
-#~ msgid "Inverse Diff Moment"
-#~ msgstr "Moment Diff Inverse "
-#~ msgid "Sum Average"
-#~ msgstr "Moyenne de la somme"
-#~ msgid "Sum Variance"
-#~ msgstr "Variance de la somme"
-#~ msgid "Sum Entropy"
-#~ msgstr "Entropie de la somme"
-#~ msgid "Entropy"
-#~ msgstr "Entropie"
-#~ msgid "Difference Variance"
-#~ msgstr "Variance de la soustraction"
-#~ msgid "Difference Entropy"
-#~ msgstr "Entropie de la soustraction"
-#~ msgid "Measure of Correlation-1"
-#~ msgstr "Mesure de corrélation moins 1"
-#~ msgid "Measure of Correlation-2"
-#~ msgstr "Mesure de corrélation moins 2"
-#~ msgid "Max Correlation Coeff"
-#~ msgstr "Coefficient de corrélation maximum"
-#~ msgid "Raster file to be imported"
-#~ msgstr "Fichier raster à importer"
-#, fuzzy
-#~ msgid "Write the result to g3d map <%s>"
-#~ msgstr "Titre de la nouvelle couche raster"
-#~ msgid "Requested 3d raster map not found"
-#~ msgstr "Le fichier raster 3D <%s> n'a pas été trouvé"
-#, fuzzy
-#~ msgid "Error closing new ASCII file"
-#~ msgstr "Erreur de fermeture du fichier VTK-ASCII"
-#~ msgid "modifyNull: error opening map"
-#~ msgstr "modifyNull (modification des valeurs nulles) : erreur d'ouverture de la couche"
-#~ msgid "modifyNull: error closing map"
-#~ msgstr "modifyNull (modification des valeurs nulles) : erreur dans la fermeture de la couche"
-#~ msgid "makeMask: error opening map."
-#~ msgstr "makeMask (définition d'un masque) : erreur d'ouverture de la couche"
-#~ msgid "makeMask: error opening g3d mask file"
-#~ msgstr "makeMask (définition d'un masque) : erreur d'ouverture du fichier de masque raster 3D"
-#~ msgid "makeMask: error closing g3d mask file"
-#~ msgstr "makeMask (définition d'un masque) : erreur de fermeture du fichier de masque raster 3D"
-#~ msgid "makeMask: error closing map"
-#~ msgstr "makeMask (définition d'un masque) : erreur de fermeture de la couche"
-#, fuzzy
-#~ msgid "Requested 3d raster map <%s> not found"
-#~ msgstr ""
-#~ "La couche g3d <%s> demandé n'a pas été trouvé\n"
-#~ "Le fichier g3d <%s> demandé n'a pas été trouvé"
-#~ msgid "Requested g3d RGB map <%s> not found"
-#~ msgid "Please provide three g3d RGB maps"
-#~ msgstr "Veuillez indiquer trois couches g3d RGB"
-#~ msgid "Requested g3d vector map <%s> not found"
-#~ msgstr "Couche vecteur g3d <%s> introuvable"
-# c-format
-#, fuzzy
-#~ msgid "Open rgb 3d raster map %s"
-#~ msgstr "Ouvrir le fichier raster 3D %s"
-#, fuzzy
-#~ msgid "Error closing g3d rgb map."
-#~ msgstr "Erreur de fermeture du fichier raster 3D"
-#, fuzzy
-#~ msgid "Error closing g3d vector map."
-#~ msgstr "Erreur de fermeture du fichier vecteur 3D"
-#, fuzzy
-#~ msgid "unable to close input 3d raster map"
-#~ msgstr "Impossible de fermer la couche source"
-#, fuzzy
-#~ msgid "write_vtk_rgb_data: writing rgb data"
-#~ msgstr "writeVTKData: Ecriture de données VTK"
-#, fuzzy
-#~ msgid "Error closing new 3d raster map"
-#, fuzzy
-#~ msgid "Error closing ascii file"
-#~ msgid "Error: couldn't create %s"
-#~ msgstr "Erreur : impossible de créer %s"
-#~ msgid "Error while writing grid. Disk full?"
-#~ msgstr "Erreur au cours de l'écriture de la grille 3D. Espace mémoire insuffisant?"
-#, fuzzy
-#~ msgid "Create/Edit"
-#~ msgid "Create new projection files (modifies current location unless 'location' option specified)"
-#~ msgstr "Créer de nouveaux fichiers de projection (modifie le Secteur courant à moins quel'option 'location' soit utilisée"
-# c-format
-#~ msgid "Location %s created!"
-#~ msgstr "Secteur %s créé!"
-#, fuzzy
-#~ msgid "Print mapset names"
-#~ msgstr "Afficher le nom du jeu de données"
-#, fuzzy
-#~ msgid "Force remove"
-#~ msgstr "Couche raster à supprimer"
-#~ msgid "Color to erase with, either a standard GRASS color or R:G:B triplet (separated by colons)"
-#~ msgstr "Couleur pour effacer, soit une couleur GRASS standard soit un triplet R:G:B(séparé par le signe :)"
-#, fuzzy
-#~ msgid "Layer: %s"
-#~ msgstr "couche %d"
-#, fuzzy
-#~ msgid "Break polygons:"
-#~ msgstr "Exporter les lignes en tant que polygones"
-#, fuzzy
-#~ msgid "Remove duplicates:"
-#~ msgstr "Suppression des centroïdes en doublons..."
-#, fuzzy
-#~ msgid "Write centroids:"
-#~ msgstr "Écrire les sommets de lignes."
-#, fuzzy
-#~ msgid "Cannot calculate centroid"
-#~ msgstr "Impossible de calculer le centroïde de la surface"
-#, fuzzy
-#~ msgid "Unknown icon marker"
-#, fuzzy
-#~ msgid "Group input"
-#~ msgstr "Groupe en entrée"
-#, fuzzy
-#~ msgid "Write output to PNG image"
-#~ msgstr "Écraser et réécrire le fichier de sortie"
-#~ msgid "Verbose mode"
-#~ msgstr "Détails de l'exécution"
-#~ msgid "E00 file"
-#~ msgstr "Fichier E00"
-#~ msgid "Input type point, line or area"
-#~ msgstr "Type en entrée: point, ligne ou entité surfacique"
-#, fuzzy
-#~ msgid "Name for output vector map"
-#~ msgstr "Nom du fichier vecteur de sortie"
-#, fuzzy
-#~ msgid "Name of raster plane to be created"
-#~ msgstr "Nom de la couche raster plane à créer."
-#, fuzzy
-#~ msgid "Dip of plane. Value must be between -90 and 90 degrees"
-#~ msgstr "Angle du plan. La valeur doit être comprise entre -90 et 90 degrés."
-#, fuzzy
-#~ msgid "Azimuth of the plane. Value must be between 0 and 360 degrees"
-#~ msgstr "Azimut du plan. La valeur doit être comprise entre 0 et 360 degrés."
-#~ msgid "Verbosity level"
-#~ msgstr "Niveau de détail"
-#, fuzzy
-#~ msgid "Name for output raster map prefix (e.g. 'brov')"
-#~ msgstr "Préfixe pour la couche raster en sortie (par ex. 'brov')"
-#~ msgid "raster input map"
-#~ msgstr "couche raster en entrée"
-#~ msgid "reclass raster output map"
-#~ msgstr "Reclasser la couche raster en sortie"
-#, fuzzy
-#~ msgid "Vector map to modify"
-#~ msgstr "Afficher seulement la région de la couche vecteur"
-#, fuzzy
-#~ msgid "Layer in the vector to be modified"
-#~ msgstr "Nom de(s) la couche(s) raster existante à requêter"
-#, fuzzy
-#~ msgid "Vector map to be queried"
-#~ msgstr "Couche raster à requèter"
-#, fuzzy
-#~ msgid "Layer of the query vector containing data"
-#~ msgstr "Nom du fichier vecteur contenant les données en entrée"
-#, fuzzy
-#~ msgid "Column to be queried"
-#, fuzzy
-#~ msgid "Output raster map (default: input tile)"
-#~ msgstr "Titre du fichier raster de sortie"
-#, fuzzy
-#~ msgid "Name of input vector map"
-#~ msgstr "Nom de la couche vecteur 2D source"
-#, fuzzy
-#~ msgid "Vector map to edit the attribute table for"
-#~ msgstr "Nom de la couche de points vecteurs en entrée pour laquelle éditer la table attributaire"
-#, fuzzy
-#~ msgid "Column to update"
-#~ msgstr "colonne à mettre à jour"
-#, fuzzy
-#~ msgid "Column to query"
-#, fuzzy
-#~ msgid "WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/col2>1)"
-#~ msgstr "Conditions WHERE de la requête SQL sans le mot clef 'where'"
-#~ msgid "Old schema"
-#~ msgstr "Ancien schéma"
-#~ msgid "New schema"
-#~ msgstr "Nouveau schéma"
-#, fuzzy
-#~ msgid "Input ASTER image to be georeferenced & rectified"
-#~ msgstr "Image ASTER en entrée devant être géoréférencée & recalée"
-#, fuzzy
-#~ msgid "Vector map for which to rename attribute column"
-#, fuzzy
-#~ msgid "Layer where to rename column"
-#~ msgstr "Couche à laquelle ajouter la colonne"
-#, fuzzy
-#~ msgid "GRASS table name"
-#~ msgstr "nom de la table"
-#, fuzzy
-#~ msgid "vector, import"
-#~ msgstr "Importation vecteur complète"
-#~ msgid "Field separator"
-#~ msgstr "Caractère de séparation de champs"
-#~ msgid "WHERE conditions of SQL statement without 'where' keyword"
-#, fuzzy
-#~ msgid "display, vector, thematic, legend"
-#~ msgstr "Faire pivoter le cartouche de légende"
-#, fuzzy
-#~ msgid "vector, topology"
-#~ msgstr "Boîte à outil pour nettoyer la topologie vectorielle"
-#, fuzzy
-#~ msgid "Name of vector map for which to edit attribute table"
-#, fuzzy
-#~ msgid "Table from which to drop attribute column"
-#, fuzzy
-#~ msgid "Raster map in which to fill nulls"
-#~ msgstr "couche raster où remplacer les valeurs null"
-#~ msgid "Output raster map with nulls filled by interpolation from surrounding values"
-#~ msgstr "Couche raster de sortie où remplacer les nulls par interpolation des valeurs voisines"
-#, fuzzy
-#~ msgid "Vector map from which to remove attribute table"
-#~ msgstr "Nom de la couche vecteur dont il faut supprimer la table attributaire"
-#, fuzzy
-#~ msgid "Name of existing attribute table (default: vector map name)"
-#~ msgstr "nom de la table attributaire existante (par défaut : nom de la couche vecteur)"
-#~ msgid "Layer from which to drop linked attribute table"
-#~ msgstr "Couche pour laquelle supprimer le lien à la table attributaire"
-#, fuzzy
-#~ msgid "Vector map for which to drop attribute column"
-#, fuzzy
-#~ msgid "Layer where to drop column"
-#~ msgid "raster output TC maps prefix"
-#~ msgstr "préfixe de couche raster TC en sortie"
-#~ msgid "Vector map for which to add new attribute table"
-#~ msgstr "Couche vecteur à laquelle ajouter une nouvelle table attributaire"
-#, fuzzy
-#~ msgid "vector, import, wfs"
-#~ msgid "Name of data table"
-#~ msgstr "Nom de la table de données"
-# c-format
-#~ msgid "Database/directory for table"
-#~ msgstr "Base de données/répertoire d la table"
-#~ msgid "Database driver"
-#~ msgstr "Pilote de la base de donnée"
-# c-format
-#, fuzzy
-#~ msgid "Cannot open file [%s] in mapset [%s]"
-#~ msgstr "impossible d'ouvrir le fichier d'étiquettes <%s> dans le jeu de données <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Cannot create file <%s> in mapset <%s>"
-#, fuzzy
-#~ msgid "input,cell,raster"
-#~ msgstr "couche raster source"
-#, fuzzy
-#~ msgid "output,cell,raster"
-#~ msgstr "couche raster en sortie"
-#, fuzzy
-#~ msgid "basemap"
-#~ msgstr "couche raster de couverture"
-#, fuzzy
-#~ msgid "method"
-#~ msgstr "Méthode inconnue <%s>"
-#, fuzzy
-#~ msgid "Cannot allocate memory for auxiliar matrix.Consider changing region resolution"
-#~ msgid "Raster file(s) for View%d"
-#~ msgstr "Fichier(s) raster pour la Vue%d"
-#, fuzzy
-#~ msgid "File type"
-#~ msgid "%s file(s) to be copied"
-#~ msgstr "%s fichier(s) à copier"
-#~ msgid "%s file(s) to be removed"
-#~ msgstr "%s fichier(s) à supprimer"
-#, fuzzy
-#~ msgid "-s and -n are mutually exclusive"
-#~ msgid "%s file(s) to be renamed"
-#~ msgstr "%s fichier(s) à renommer"
-#, fuzzy
-#~ msgid "Name of a mapset"
-#~ msgstr "Nom du jeu de données en sortie"
-#, fuzzy
-#~ msgid "Layer number (if -1, all layers are displayed)"
-#~ msgstr "Code de couche. Si fixé à -1, toutes les couches sont affichées."
-#, fuzzy
-#~ msgid "Unable to display topology, not available"
-#~ msgstr "Impossible d'afficher la topologie, topologie non disponible"
-#, fuzzy
-#~ msgid "Unable to calculate centroid for area %d"
-#, fuzzy
-#~ msgid "OGR format"
-#~ msgstr "format OGR"
-#~ msgid "Print vector history instead of info"
-#~ msgstr "Afficher l'historique de la couche vecteur à la place des informations"
-#~ msgid "File containing mapping instructions (or use input=- to enter from keyboard)"
-#~ msgstr "Fichier contenant les instructions de mise en page cartographique (ou utilisez input=- pour les saisir à partir du clavier)"
-#~ msgid "Scale of the output map, e.g. 1:25000 (default: Auto-sized to fit page)"
-#~ msgstr "Echelle de la carte en sortie, par exemple 1:25000 (par défaut, ajusté à la page)"
-#, fuzzy
-#~ msgid "Using <%s> from the command line is depreciated. Please use the <%s> mapping instruction instead. The parameter <%s> will be removed in future versions of GRASS."
-#~ msgstr "Utiliser \"scale\" à partir de la console est obsolète. Veuillez utilisez l'instruction de mise en page cartographique \"scale\" à la place."
-#, fuzzy
-#~ msgid "Cannot set GRASS_VERBOSE variable."
-#~ msgstr "Impossible de lire la couche raster"
-#, fuzzy
-#~ msgid "Rectified input raster map <%s> will be saved as <%s>"
-#~ msgstr "Impossible d'ouvrir la couche raster [%s] dans [%s]"
-#, fuzzy
-#~ msgid "Link GDAL supported raster file to a binary raster map layer."
-#~ msgstr "Importer un fichier raster géré par GDAL."
-#, fuzzy
-#~ msgid "Required"
-#~ msgstr "Requête"
-#, fuzzy
-#~ msgid "Name of filter file"
-#~ msgstr "Nom du fichier de filtre"
-#, fuzzy
-#~ msgid "Location of input raster map"
-#~ msgstr "Secteur (location) de la couche source"
-#, fuzzy
-#~ msgid "Mapset of input raster map"
-#~ msgstr "Nom de la couche raster source"
-#, fuzzy
-#~ msgid "Checking location <%s>, mapset <%s>..."
-#~ msgid "Quiet - suppress progress report"
-#~ msgstr "Silencieux - supprime le rapport de progression"
-#, fuzzy
-#~ msgid "Output file name not specified"
-#~ msgstr "2 couches doivent être spécifiées"
-# c-format
-#, fuzzy
-#~ msgid "Exporting to GDAL raster"
-#~ msgstr "Impossible d'écrire la couche raster lac <%s>!"
-#~ msgid " %d.%02d.%02d, daynum %d, time: %02i:%02i:%02i (decimal time: %f)\n"
-#~ msgstr " %d.%02d.%02d, numéro de jour %d, heure : %02i:%02i:%02i (heure décimale : %f)\n"
-#~ msgid " long: %f, lat: %f, timezone: %f\n"
-#~ msgstr " long : %f, lat : %f, fuseau horaire : %f\n"
-#~ msgid ""
-#~ " Solar position: sun azimuth: %f,\n"
-#~ "   sun angle above horz.(refraction corrected): %f\n"
-#~ msgstr ""
-#~ " Position du soleil : azimut: %f,\n"
-#~ "   angle du soleil au dessus de l'horizon.(réfraction corrigée) : %f\n"
-#~ msgid " Sunrise time (without refraction): %02d:%02d:%02d\n"
-#~ msgstr " Lever du soleil (sans réfraction) : %02d:%02d:%02d\n"
-#~ msgid " Sunset time  (without refraction): %02d:%02d:%02d\n"
-#~ msgstr " Coucher du soleil  (sans réfraction) : %02d:%02d:%02d\n"
-#~ msgid "No map calculation requested. Finished.\n"
-#~ msgstr "Pas de calcul de couche demandé. Terminé.\n"
-#, fuzzy
-#~ msgid "Can't open range file for %s"
-#~ msgstr "impossible d'ouvrir le fichier pour %s"
-# c-format
-#, fuzzy
-#~ msgid "<%s> created"
-#~ msgid "Raster map to be recoded"
-#~ msgstr "Couche raster à recoder"
-#~ msgid "Overlay (non-null values only)"
-#~ msgstr "Superposer (seulement sur les valeurs non-null)"
-#~ msgid "Raster map to be displayed"
-#~ msgstr "couche raster à afficher"
-#, fuzzy
-#~ msgid "Vector output map"
-#~ msgstr "Aucune couche créée en sortie"
-#, fuzzy
-#~ msgid "Error while writing to temp file"
-#~ msgstr "Erreur à la lecture du fichier de signatures."
-#, fuzzy
-#~ msgid "r.li.worker (pid %i) exited with abnormal status: %i"
-#~ msgstr "r.li.worker (pid %i) interrompu avec un statut anormal %i"
-#, fuzzy
-#~ msgid "r.li.worker (pid %i) terminated successfully"
-#~ msgstr "r.li.worker (pid %i) achevé\n"
-# c-format
-#, fuzzy
-#~ msgid "Unable to read raster map row %ld"
-#~ msgstr "Impossible de créer la couche raster <%s>"
-#, fuzzy
-#~ msgid "Failed writing raster map row %ld"
-#~ msgstr "Lecteur du fichier raster..."
-#, fuzzy
-#~ msgid "Not enough room in history file"
-#~ msgstr "Pas assez de place dans le fichier historique"
-#, fuzzy
-#~ msgid "Your mapset search list:\n"
-#~ msgstr "Jeu(x) de données à lister (par défaut le jeu de données courant)"
-# c-format
-#, fuzzy
-#~ msgid "<%s> not found in mapset list"
-#~ msgstr "Colonne <%s> non trouvée"
-#, fuzzy
-#~ msgid "Name of workspace file"
-#~ msgstr "Nom du fichier d'étiquettes"
-#~ msgid "List of values to be displayed (FP maps)"
-#~ msgstr "Liste de valeurs à afficher (couche en flottants FP)"
-#~ msgid "Ignoring catlist: map is floating point (please use 'val=')"
-#~ msgstr "Catlist ignorée : la couche est en valeurs flottantes (veuillez utiliser 'val=')"
-#~ msgid "Ignoring vallist: map is integer (please use 'cat=')"
-#~ msgstr "Vallist ignorée : la couche est en entier (veuillez utiliser 'cat=')"
-#, fuzzy
-#~ msgid "Failed in attempt to open %s"
-#~ msgid "Generates raster map layers of slope, aspect, curvatures and partial derivatives from a raster map layer of true elevation values. Aspect is calculated counterclockwise from east."
-#~ msgstr "Produit des couches raster de pente, aspect, courbures et dérivées partielles à partir d'une couche raster de valeurs réelles d'altitude. L'aspect est calculé dans le sens contraire des aiguilles d'une montre à partir de l'est."
-#~ msgid "Output slope filename"
-#~ msgstr "Fichier sortie pour la pente"
-#~ msgid "Output profile curvature filename"
-#~ msgstr "Nom de fichier de sortie pour la courbure du profil"
-#~ msgid "Output tangential curvature filename"
-#~ msgstr "Nom de fichier de sortie pour la courbure tangentielle"
-#~ msgid "Output first order partial derivative dx (E-W slope) filename"
-#~ msgstr "Nom de fichier de sortie pour la dérivée partielle d'ordre un en dx (gradient E-W)"
-#~ msgid "Output first order partial derivative dy (N-S slope) filename"
-#~ msgstr "Nom de fichier de sortie pour la dérivée partielle d'ordre un en dy (gradient N-S)"
-#~ msgid "Output second order partial derivative dxx filename"
-#~ msgstr "Nom de fichier de sortie pour la dérivée partielle d'ordre deux en dxx"
-#~ msgid "Output second order partial derivative dyy filename"
-#~ msgstr "Nom de fichier de sortie pour la dérivée partielle d'ordre deux en dyy"
-#~ msgid "Output second order partial derivative dxy filename"
-#~ msgstr "Nom de fichier de sortie pour la dérivée partielle d'ordre deux en dxy"
-# c-format
-#~ msgid "wrong type: %s"
-#~ msgstr "Type erroné: %s"
-# c-format
-#, fuzzy
-#~ msgid "Creating support files..."
-#, fuzzy
-#~ msgid "Elevation products for mapset [%s] in [%s]"
-#~ msgid "ASPECT [%s] COMPLETE"
-#~ msgstr "ASPECT [%s] TERMINE"
-#~ msgid "SLOPE [%s] COMPLETE"
-#~ msgstr "PENTE [%s] TERMINEE"
-#~ msgid "PROFILE CURVE [%s] COMPLETE"
-#~ msgstr "COURBE DE PROFIL [%s] TERMINEE"
-#~ msgid "TANGENTIAL CURVE [%s] COMPLETE"
-#~ msgstr "COURBE TANGENTIELLE [%s] TERMINEE"
-#~ msgid "E-W SLOPE [%s] COMPLETE"
-#~ msgstr "PENTE E-W [%s] TERMINEE"
-#~ msgid "N-S SLOPE [%s] COMPLETE"
-#~ msgstr "PENTE N-S [%s] TERMINEE"
-#~ msgid "DXX [%s] COMPLETE"
-#~ msgstr "DXX [%s] TERMINEE"
-#~ msgid "DYY [%s] COMPLETE"
-#~ msgstr "DYY [%s] TERMINEE"
-#~ msgid "DXY [%s] COMPLETE"
-#~ msgstr "DXY [%s] TERMINEE"
-#, fuzzy
-#~ msgid "Input elevation map"
-#~ msgstr "Fichier d'altitude en entrée"
-#~ msgid "Output shaded relief map name"
-#~ msgstr "Nom de la couche de relief estompé en sortie"
-#, fuzzy
-#~ msgid "Layer number of data column"
-#~ msgid "Generates a raster map layer showing watershed subbasins."
-#~ msgstr "Génère une couche raster montrant les sous-bassins versants."
-#~ msgid "Coded stream network file name"
-#~ msgstr "Nom du fichier réseau codant les cours d'eau"
-#~ msgid "Thinned ridge network file name"
-#~ msgstr "Nom de fichier du réseau d'arêtes amincies"
-#~ msgid "Name for the resultant watershed partition file"
-#~ msgstr "Nom de la couche de délimitation des bassins versants"
-#, fuzzy
-#~ msgid "Name of the elevation raster map [m]"
-#~ msgstr "Nom du fichier raster source"
-#, fuzzy
-#~ msgid "Output water depth raster map [m]"
-#~ msgstr "Fichier raster en sortie pour la longueur des courants"
-#, fuzzy
-#~ msgid "Output topographic index map"
-#~ msgstr "couche d'indice topographique ln(a/tan(beta))"
-#~ msgid "Output elevation raster map"
-#~ msgstr "Nom de la couche d'altitude résultante"
-#, fuzzy
-#~ msgid "Input elevation raster map"
-#, fuzzy
-#~ msgid "Input aspect raster map"
-#~ msgstr "Nom du fichier raster en sortie pour l'aspect"
-#, fuzzy
-#~ msgid "Input barrier raster map"
-#~ msgid "Output flowline vector map"
-#~ msgstr "Fichier vecteur de sortie pour les courants"
-#~ msgid "Output raster map having shadows"
-#~ msgstr "couche à créer contenant les ombres"
-#~ msgid "B: year (1950..2050)"
-#~ msgstr "B : année (1950..2050)"
-#~ msgid "B: month (0..12)"
-#~ msgstr "B : mois (0..12)"
-#~ msgid "B: day (0..31)"
-#~ msgstr "B : jour (0..31)"
-#~ msgid "B: hour (0..24)"
-#~ msgstr "B : heure (0..24)"
-#, fuzzy
-#~ msgid "East coordinate (point of interest, default: map center)"
-#~ msgstr "coordonnée Est (point d'intérêt, défaut : centre de la couche)"
-#, fuzzy
-#~ msgid "North coordinate (point of interest, default: map center)"
-#~ msgstr "coordonnée Nord (point d'intérêt, défaut : centre de la couche)"
-#~ msgid "Zero is a real elevation"
-#~ msgstr "Zéro est une vraie altitude"
-#, fuzzy
-#~ msgid "Verbose output (also print out sun position etc.)"
-#~ msgstr "Détails de l'exécution (done également la position du soleil etc.)"
-#~ msgid "(i)   Elevation map"
-#~ msgstr "(i) couche d'altitudes"
-#~ msgid "(o)   Depressionless elevation map"
-#~ msgstr "(o) Couche d'altitudes positives"
-#~ msgid "(o/i) Basin elevation map (MASK applied)"
-#~ msgstr "(o/i) Couche d'altitude de bassin versant (MASK activé)"
-#~ msgid "(o)   Topographic index ln(a/tanB) map (MASK applied)"
-#~ msgstr "(o) Couche d'index topographique ln(a/tanB) (MASK activé)"
-#~ msgid "(o)   Output file"
-#~ msgstr "(o) Fichier en sortie"
-#~ msgid "(i)   OPTIONAL Observed flow file"
-#~ msgstr "(i)\tOPTIONNEL Fichier de flux observé"
-#~ msgid "(i)   OPTIONAL Output for given time step"
-#~ msgstr "(i) OPTIONNEL Sortie pour un pas temporel donné"
-#~ msgid "(i)   OPTIONAL Output for given topographic index class"
-#~ msgstr "(i)\tOPTIONNEL sortie pour une classe de valeurs topographiques indexées données"
-#~ msgid "Name of existing raster map containing elevation surface"
-#~ msgstr "Nom de la couche raster contenant les informations d'altitude"
-#~ msgid "Output elevation raster map after filling"
-#~ msgstr "couche raster d'altitude après remplissage"
-#~ msgid "Output aspect direction format (agnps, answers, or grass)"
-#~ msgstr "Format de la direction de la couche d'aspect en sortie (agnps, answers, ou grass)"
-#, fuzzy
-#~ msgid "Reading map..."
-#~ msgstr "Lecture de la couche"
-#, fuzzy
-#~ msgid "Failed to guess site file format\n"
-#~ msgid "Watershed basin analysis program."
-#~ msgstr "Programme d'analyse de bassin versant."
-#~ msgid "Input map: elevation on which entire analysis is based"
-#~ msgstr "couche d'entrée : altitude sur lesquelles sont basée l'étude entière"
-#~ msgid "Input map or value: percent of disturbed land, for USLE"
-#~ msgstr "couche ou valeur d'entrée : pourcentage de terrain impacté par le glissement, pour USLE"
-#~ msgid "Output map: drainage direction"
-#~ msgstr "Couche de sortie : direction de l'écoulement"
-#~ msgid "Output map: stream segments"
-#~ msgstr "Couche de sortie : segments de cours d'eau"
-#~ msgid "Watershed basin creation program."
-#~ msgstr "Programme de création de bassin versant."
-#~ msgid "Name of raster map to contain results"
-#~ msgstr "Nom de la couche raster qui contiendra les résultats"
-#~ msgid "The map N grid coordinates"
-#~ msgstr "Coordonnée nord"
-# c-format
-#, fuzzy
-#~ msgid "Unable to access table <%s>"
-#~ msgstr "impossible de créer la sortie <%s>"
-#, fuzzy
-#~ msgid "Import GDAL supported raster file into a binary raster map layer."
-#, fuzzy
-#~ msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the currently defined region."
-#~ msgstr "Exporte une couche Raster GRASS en un fichier TIFF 8/24 bits à la résolution de la région actuelle."
-#~ msgid "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel resolution of the currently defined region."
-#~ msgid "If set to 0, z coordinates are used. (3D vector only)"
-#~ msgstr "Si fixée à 0, les coordonnées z sont utilisées (vecteur 3D seulement)"
-#~ msgid "Attribute table column with values to interpolate (if layer>0)"
-#~ msgstr "Colonne de la table attributaire avec les valeurs à interpoler (si la couche>0)"
-#, fuzzy
-#~ msgid "M.Q. solution"
-#~ msgstr "Résolution"
-#~ msgid "3-d data in dxf file. Polyline_flag: %d"
-#~ msgstr "Données 3-D dans le fichier dxf. Polyline_flag: %d"
-#~ msgid "Import SRTM HGT files into GRASS"
-#~ msgstr "Importer les fichiers SRTM HGT dans GRASS"
-#~ msgid ""
-#~ "\n"
-#~ "Enter database password for connection\n"
-#~ "<%s:%s:user=%s>\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Entrer le mot de passe  de la base de données pour la connexion\n"
-#, fuzzy
-#~ msgid "Hit RETURN to cancel request\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Taper ENTREE pour poursuivre -->"
-#~ msgid "Exiting. Not changing current settings"
-#~ msgstr "Sortie. Ne pas changer les paramètres actuels"
-#~ msgid "New password set"
-#~ msgstr "Nouveau mot de passe"
-#, fuzzy
-#~ msgid "Unable to close output map"
-#~ msgstr "Impossible de fermer la couche de sortie"
-#, fuzzy
-#~ msgid "Unable to get elevation raster row"
-#~ msgstr "Impossible de trouver la ligne du raster de relief\n"
-#~ msgid "Could not write raster row"
-#~ msgstr "Impossible d'écrire la ligne du raster : %s"
-#, fuzzy
-#~ msgid "Unable to open elevation map"
-#~ msgstr "Impossible de fermer la couche de relief"
-# c-format
-#, fuzzy
-#~ msgid "Unable to create raster map"
-#~ msgstr "Impossible de créer la couche raster %s"
-#, fuzzy
-#~ msgid "Unable to close elevation map"
-# c-format
-#~ msgid "Could not open map %s"
-#~ msgstr "Impossible d'ouvrir la couche %s"
-#~ msgid "Could not get top raster row \n"
-#~ msgstr "Ligne de début de fichier raster introuvable\n"
-#~ msgid "Could not get bottom raster row \n"
-#~ msgstr "Ligne de fin de fichier raster introuvable\n"
-#, fuzzy
-#~ msgid "Unable to write raster row"
-#~ msgstr "Impossible de lire la ligne raster."
-#, fuzzy
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
-#~ msgstr "mi(les), f(pieds), me(tres), k(ilomètres), a(cres), h(ectares)"
-#, fuzzy
-#~ msgid "Unable to write quant file"
-#~ msgstr "Impossible d'écrire le fichier temporaire"
-#, fuzzy
-#~ msgid "Unable to write color table for %s"
-#~ msgstr "Impossible de lire la table de couleur %s"
-#, fuzzy
-#~ msgid "Cannot write category file for raster map <%s>"
-#~ msgstr "Editer le fichier de catégorie de [%s]?"
-# c-format
-#, fuzzy
-#~ msgid "Cannot open raster map <%s>"
-#~ msgstr ""
-#~ "Impossible d'ouvrir le fichier de cellules pour [%s]\n"
-#~ "Impossible d'ouvrir la couche raster [%s]"
-# c-format
-#, fuzzy
-#~ msgid "Unable to open cellfile for <%s>"
-#~ msgstr "Impossible d'ouvrir le fichier de cellules pour [%s]"
-#, fuzzy
-#~ msgid "Cannot create category file of <%s>"
-#~ msgid "[%s]: Cannot read map header"
-#~ msgstr "[%s]: impossible de lire l'en-tête de couche"
-# c-format
-#, fuzzy
-#~ msgid "Unable to read raster map <%s> row %d"
-# c-format
-#, fuzzy
-#~ msgid "Failed writing raster map <%s> row %d"
-#~ msgid "Can't set window"
-#~ msgstr "Impossible de paramétrer la fenêtre"
-# c-format
-#, fuzzy
-#~ msgid "Unable to read raster map row %d"
-# c-format
-#, fuzzy
-#~ msgid "Unable to read header of raster map <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Reading row %d"
-# c-format
-#, fuzzy
-#~ msgid "Horizon file no. %d <%s> not found"
-#~ msgstr "fichier graphique <%s> non trouvé"
-#, fuzzy
-#~ msgid "Data or Clump file not open"
-#~ msgstr "Donnée ou fichier 'flaques' non ouvert."
-#, fuzzy
-#~ msgid "Error writing null row %d"
-#~ msgstr "Erreur d'écriture de la ligne null [%d]"
-#, fuzzy
-#~ msgid "Failed writing output raster map row %d"
-#~ msgid "Signed data (high bit means negative value)"
-#~ msgstr "Les données sont signées (le bit le plus haut marque le signe négatif)"
-#~ msgid "Number of bytes per cell (1, 2, 4)"
-#~ msgstr "Nombre de bits par pixel (1,2,4)"
-#, fuzzy
-#~ msgid "You have to provide all limits of geographic region (n,s,e,w)"
-#~ msgstr "Limite Sud de la région géographique (extrémité)"
-#, fuzzy
-#~ msgid "Illegal number of rows <%s>"
-#~ msgstr "Attention : nom de sous-groupe illégal <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Illegal number of columns <%s>"
-#~ msgstr "  Nombre maximum d'itérations: %d\n"
-# c-format
-#, fuzzy
-#~ msgid "Using rows=%d cols=%d\n"
-#~ msgstr "%d lignes, %d colonnes"
-#, fuzzy
-#~ msgid "Conversion failed at row %d"
-#~ msgstr "Echec de la conversion de données à la ligne %d, colonne %d"
-#, fuzzy
-#~ msgid "Error writing category file for <%s>"
-#~ msgstr "Erreur d'écriture du fichier cats de <%s>"
-#~ msgid "Overwrite output map file"
-#, fuzzy
-#~ msgid "Setting window header"
-#~ msgstr "couche vecteur des points de départ"
-#, fuzzy
-#~ msgid "Cannot get row"
-#~ msgstr "Impossible de récupérer la ligne"
-#, fuzzy
-#~ msgid "Unable to close input map"
-#, fuzzy
-#~ msgid "Could not get raster row from input map"
-#~ msgstr "Ligne du fichier raster introuvable\n"
-#, fuzzy
-#~ msgid "Could not get raster row from elev map"
-#, fuzzy
-#~ msgid "%s: running %s command"
-#~ msgstr "%s: ERREUR d'exécution de la commande %s"
-#, fuzzy
-#~ msgid "%s: unable to open temporary file"
-#~ msgstr "Impossible d'ouvrir le fichier temporaire"
-#~ msgid "Resultant raster map (not used with 'distribution')"
-#~ msgstr "Couche raster résultat (non disponible avec 'distribution')"
-#, fuzzy
-#~ msgid "Output map <%s> ignored"
-#~ msgstr "couche de sortie"
-# c-format
-#, fuzzy
-#~ msgid "One or more input raster maps not found"
-#~ msgstr "%s - couche raster non trouvée"
-# c-format
-#, fuzzy
-#~ msgid "Cannot read row"
-#~ msgstr "Impossible de lire %s"
-#~ msgid "Error in pipe creation"
-#~ msgstr "Erreur dans la création du pipe"
-#~ msgid "Error opening channel %i"
-#~ msgstr "Erreur à l'ouverture du canal %i"
-# c-format
-#, fuzzy
-#~ msgid "Cannot close %s file (PIPE)"
-#~ msgstr "Impossible de ferme le fichier %s\n"
-# c-format
-#, fuzzy
-#~ msgid "Cannot delete %s file (PIPE)"
-#~ msgstr "Impossible d'effacer le fichier %s\n"
-# c-format
-#, fuzzy
-#~ msgid "Cannot close %s file (PIPE2)"
-# c-format
-#, fuzzy
-#~ msgid "Cannot delete %s file (PIPE2)"
-#, fuzzy
-#~ msgid "Cannot close receive channel file"
-#~ msgstr "Impossible de fermer le canal de réception\n"
-# c-format
-#, fuzzy
-#~ msgid "Cannot delete %s file"
-# c-format
-#~ msgid "Cannot read raster header file"
-#~ msgstr "Impossible de lire l'en-tête de fichier"
-#, fuzzy
-#~ msgid "CHILD[pid = %i] cannot open raster map"
-#~ msgstr "CHILD[pid = %i] impossible de lire le fichier raster"
-#~ msgid "CHILD[pid = %i] cannot open receive channel"
-#~ msgstr "CHILD[pid = %i] impossible d'ouvrir le canal de réception"
-#~ msgid ""
-#~ "\t\t\t\tAREA MESSAGE: \n"
-#~ " \t\t\t\taid = %i \n"
-#~ " \t\t\t\tx = %i \n"
-#~ " \t\t\t\ty = %i \n"
-#~ " \t\t\t\trl = %i \n"
-#~ " \t\t\t\tcl = %i \n"
-#~ msgstr ""
-#~ "\t\t\t\tMESSAGE ENTITE SURFACIQUE: \n"
-#~ msgid ""
-#~ " \t\t\t\tMASKEDAREA MESSAGE: \n"
-#~ " \t\t\t\tmask = %s \n"
-#~ msgstr ""
-#~ " \t\t\t\tMESSAGE ENTITE SURFACIQUE MASQUEE: \n"
-#~ msgid ""
-#~ " \t\t\t\tDONE MESSAGE: \n"
-#~ " \t\t\t\tpid = %i \n"
-#~ " \t\t\t\tresult = %f \n"
-#~ msgstr ""
-#~ " \t\t\t\tMESSAGE TERMINE: \n"
-#~ msgid ""
-#~ " \t\t\t\tERROR MESSAGE: \n"
-#~ msgstr ""
-#~ " \t\t\t\tMESSAGE D ERREUR: \n"
-#~ msgid ""
-#~ " \t\t\t\tTERM MESSAGE: \n"
-#~ msgstr ""
-#~ " \t\t\t\tMESSAGE TERMINAL: \n"
-#~ msgid "Cannot reset current region"
-#~ msgstr "Impossible de réinitialiser la région courante"
-#, fuzzy
-#~ msgid "Cannot create category file for <%s>"
-#, fuzzy
-#~ msgid "Cannot read header of raster map <%s> in <%s>"
-#~ msgstr "impossible de trouver les en-tête de raster 3D <%s> dans <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Cannot open cell file of raster map <%s> in <%s>"
-#~ msgstr "Impossible d'ouvrir la couche raster terrain <%s@%s>!"
-# c-format
-#, fuzzy
-#~ msgid "Cannot read raster row [%d] from raster map <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Cannot read raster row [%d] from cover raster map <%s>"
-#, fuzzy
-#~ msgid "Cannot read raster row [%d]"
-#, fuzzy
-#~ msgid "Cannot read cover raster row [%d]"
-#, fuzzy
-#~ msgid "Can't read row in input elevation map"
-#~ msgstr "impossible de lire les lignes de la couche d'altitude"
-#~ msgid "Error reading 'hue' map"
-#~ msgstr "Erreur de lecture de la couche Teinte"
-#~ msgid "Error reading 'intensity' map"
-#~ msgstr "Erreur de lecture de le couche Intensité"
-#~ msgid "Error reading 'saturation' map"
-#~ msgstr "Erreur de lecture de la couche Saturation"
-# c-format
-#, fuzzy
-#~ msgid "Unable to read raster <map %d of %d> row %d"
-#~ msgid "Writing map, row %d"
-#~ msgstr "Ecriture de la couche, ligne %d"
-# c-format
-#, fuzzy
-#~ msgid "Unable to create distance map <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Unable to create value map <%s>"
-#, fuzzy
-#~ msgid "Unable to write color table for raster map <%s>"
-#~ msgid "Unable to read row %i\n"
-#~ msgstr "Impossible de lire la ligne %i\n"
-#~ msgid "Error writing null row [%d]."
-#, fuzzy
-#~ msgid "Exporting raster as double values (bytes=%d)"
-#~ msgstr "La colonne %d définie comme entier ne contient que des valeurs doubles"
-#~ msgid "Reading map"
-# c-format
-#, fuzzy
-#~ msgid "Unable to read raster map row %d "
-#, fuzzy
-#~ msgid "Failed writing raster map row %d"
-#, fuzzy
-#~ msgid "Invalid region: %s"
-#~ msgstr "région incorrecte : %s"
-#, fuzzy
-#~ msgid "Writing raster map, row %d"
-# c-format
-#~ msgid "unable to open elevation map layer"
-#~ msgstr "Impossible d'ouvrir la couche raster d'altitude"
-#~ msgid "unable to open runoff map layer"
-#~ msgstr "Impossible d'ouvrir le fichier bilan de sortie"
-#~ msgid "unable to open depression map layer"
-#~ msgstr "Impossible d'ouvrir la couche de dépressions"
-#~ msgid "unable to open blocking map layer"
-#~ msgstr "Impossible d'ouvrir la couche d'obstacles"
-#~ msgid "unable to open rill map layer"
-#~ msgstr "Impossible d'ouvrir la couche de ruissellement"
-#~ msgid "unable to open new accum map layer."
-#~ msgstr "Impossible d'ouvrir la nouvelle couche d'accumulation."
-#~ msgid "Close failed."
-#~ msgstr "Echec de la fermeture."
-# c-format
-#~ msgid "unable to open new aspect map layer."
-#~ msgstr "Impossible d'ouvrir la nouvelle couche d'aspect"
-#, fuzzy
-#~ msgid "unable to open new LS factor map layer."
-#~ msgstr "Impossible d'ouvrir la nouvelle couche L."
-#~ msgid "unable to open new slope length map layer."
-#~ msgstr "Impossible d'ouvrir la nouvelle couche de longueur de pentes."
-#, fuzzy
-#~ msgid "unable to open new S factor map layer."
-#~ msgstr "Impossible d'ouvrir la nouvelle couche S."
-# c-format
-#~ msgid "unable to open accum file in valid_basins()"
-#~ msgstr "Impossible d'ouvrir le fichier d'accumulation dans valid_basins()"
-# c-format
-#, fuzzy
-#~ msgid "Can't create raster map <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Quant table not changed for %s"
-#~ msgstr "Impossible de trouver l'en-tête de fichier %s"
-#, fuzzy
-#~ msgid "Unable to open drainage pointer map"
-#~ msgstr "Impossible d'ouvrir la couche bassin/demi-bassin"
-#, fuzzy
-#~ msgid "Unable to open new basin map"
-#, fuzzy
-#~ msgid "Unable to close new basin map layer"
-#~ msgid "Number of the segment to create (segment library)"
-#~ msgstr "Nombre de segments à créer (bibliothèque segment)"
-#~ msgid "Nseg is %d"
-#~ msgstr "Nseg est %d"
-#~ msgid "Null cells excluded from cost evaluation."
-#~ msgstr "Les cellules nulles sont exclues de l'évaluation de coût"
-#~ msgid "Input null cell will be retained into output map"
-#~ msgstr "Les cellules null en entrée seront conservées dans la couche en sortie"
-#~ msgid "Map with different projection"
-#~ msgstr "Couche possédant une projection différente"
-#~ msgid "DTM_Source map is: Integer cell type"
-#~ msgstr "DTM_Source map est : type de cellule entier"
-#~ msgid "DTM_Source map is: Floating point (float) cell type"
-#~ msgstr "DTM_Source map est : type de cellule flottant (float)"
-#~ msgid "DTM_Source map is: Floating point (double) cell type"
-#~ msgstr "DTM_Source map est : type de cellule double flottant"
-# c-format
-#~ msgid " %d rows, %d cols"
-#~ msgid "COST_Source map is: Integer cell type"
-#~ msgstr "COST_Source map est : type de cellule entier"
-#~ msgid "COST_Source map is: Floating point (float) cell type"
-#~ msgstr "COST_Source map est : type de cellule flottant (float)"
-#~ msgid "COST_Source map is: Floating point (double) cell type"
-#~ msgstr "COST_Source map est : type de cellule double flottant"
-#~ msgid "Output map is: Integer cell type"
-#~ msgstr "Couche de sortie : type de cellule entier"
-#~ msgid "Output map is: Floating point (float) cell type"
-#~ msgstr "Couche de sortie : type de cellule flottant (float)"
-#~ msgid "Output map is: Floating point (double) cell type"
-#~ msgstr "Couche de sortie : type de cellule double flottant"
-#~ msgid " EW resolution %s (%lf)"
-#~ msgstr "EO résolution %s (%lf)"
-#~ msgid " NS resolution %s (%lf)"
-#~ msgstr "NS résolution %s (%lf)"
-#~ msgid "Initializing output "
-#~ msgstr "Initialisation de la sortie"
-#, fuzzy
-#~ msgid "Unable to allocate memory for segment fbuff == NULL"
-#~ msgstr "Impossible d'allouer de la mémoire au segment fbuff == NULL"
-#~ msgid "End of map!"
-#~ msgstr "Fin de la couche!"
-#~ msgid "Will copy input map null values into output map"
-#~ msgstr "Copier les cellules null de la couche en entrée dans la couche de sortie"
-#~ msgid ""
-#~ "Integer cell type.\n"
-#~ "Writing..."
-#~ msgstr ""
-#~ "Type de cellule entier.\n"
-#~ "Ecriture..."
-#~ msgid ""
-#~ "Float cell type.\n"
-#~ "Writing..."
-#~ msgstr ""
-#~ "Type de cellule flottant.\n"
-#~ "Ecriture..."
-#~ msgid ""
-#~ "Double cell type.\n"
-#~ "Writing..."
-#~ msgstr ""
-#~ "Type de cellule double.\n"
-#~ "Ecriture..."
-#~ msgid "Peak cost value: %f"
-#~ msgstr "Valeur de coût maximum :%f"
-# c-format
-#, fuzzy
-#~ msgid "Unable to open raster map <%s@%s>"
-#~ msgstr "Impossible d'ouvrir la couche raster <%s>"
-#, fuzzy
-#~ msgid "Failed writing raster map row"
-#, fuzzy
-#~ msgid "Cannot read raster row %d"
-# c-format
-#, fuzzy
-#~ msgid "Error reading raster map <%s>"
-#~ msgstr "Erreur de lecture du fichier raster [%s]"
-# c-format
-#, fuzzy
-#~ msgid "Failed writing raster map <%s>"
-#~ msgstr "Couche raster %i créée \n"
-#, fuzzy
-#~ msgid "Error reading input"
-#, fuzzy
-#~ msgid "Unable to write to <%s>"
-#, fuzzy
-#~ msgid "Could not get raster row"
-#~ msgid "Column name (type must be numeric)"
-#~ msgstr "Nom de la colonne (le type doit être numérique)"
-#~ msgid "Vector points to be spatially perturbed"
-#~ msgstr "Points vectoriels dont les positions vont être perturbées"
-#, fuzzy
-#~ msgid "<Auxiliar_edge_table> created in database."
-#~ msgstr "La table <%s> n'existe pas dans la base de données <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Unable to open table <%s_edge_Interpolation>"
-#, fuzzy
-#~ msgid "Finding nearest lines..."
-#~ msgstr "Recherche des classes d'apprentissage..."
-#, fuzzy
-#~ msgid "Output vector map where points will be written"
-#~ msgstr "Couche en sortie où les points seront écrits"
-#~ msgid "Column name"
-#~ msgstr "Nom de colonne"
-#~ msgid "Name of input 2D vector map"
-#~ msgid "Name of resulting 3D vector map"
-#~ msgstr "Nom de la couche vecteur 3D en sortie"
-# c-format
-#, fuzzy
-#~ msgid "Extruding vector primitives..."
-#, fuzzy
-#~ msgid "Unable to read MASK"
-#~ msgstr "impossible de lire le MASK"
-#~ msgid "Vector map defining sample points"
-#~ msgstr "Couche de vecteur donnant les points d'échantillonnage"
-#~ msgid "Raster map to be sampled"
-#~ msgstr "couche raster à échantillonner"
-#, fuzzy
-#~ msgid "Bilinear interpolation (default is nearest neighbor)"
-#~ msgstr "Outil d'interpolation bilinéaire [par défaut plus proche voisin]."
-#, fuzzy
-#~ msgid "Cubic convolution interpolation (default is nearest neighbor)"
-#~ msgstr "Outil d'interpolation par convolution cubique [par défaut plus proche voisin]"
-#, fuzzy
-#~ msgid "Flags -b & -c are mutually exclusive. Choose only one."
-#, fuzzy
-#~ msgid "Checking vector points..."
-#~ msgstr "Vérification des points vecteurs..."
-#, fuzzy
-#~ msgid "Unable to convert input map projection to GRASS format; cannot create new location"
-#~ msgstr "Impossible de convertir la projection de la couche en entrée au format GRASS ; impossible de créer le nouveau Secteur"
-# c-format
-#~ msgid "Cannot open %s"
-#~ msgstr "Impossible d'ouvrir %s"
-#, fuzzy
-#~ msgid "Vector of points defining sample points"
-#~ msgid "Suppress display of residuals or other information"
-#~ msgstr "Supprimer l'affichage des résidus ou d'autres informations"
-#, fuzzy
-#~ msgid "Instead of points use transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot)"
-#, fuzzy
-#~ msgid "The '%c' flag is deprecated and will be removed in future. Please use '--quiet' instead."
-#~ msgstr "Couche raster %i le nom de fichier %s existe déjà. Ce fichier va être écrasé!\n"
-#, fuzzy
-#~ msgid "Cannot alter table: %s"
-#~ msgstr "Impossible de créer la table : %s"
-#, fuzzy
-#~ msgid "DXF output file"
-#~ msgstr "Fichier DXF source"
-#, fuzzy
-#~ msgid "Doing log transformation"
-#~ msgstr "Affiche l'information topologique (déboguage)"
-#, fuzzy
-#~ msgid "Name of output vector area map"
-#, fuzzy
-#~ msgid "Cannot open vector map <%s>"
-#~ msgstr "Impossible d'ouvrir la couche vectorielle de centroïdes"
-# c-format
-#, fuzzy
-#~ msgid "Unable to open SVG file <%s>"
-#, fuzzy
-#~ msgid "Nothing to do"
-#~ msgstr "Rien n'a été trouvé.\n"
-#, fuzzy
-#~ msgid "Not enough types"
-#~ msgstr "Nom de colonne de catégorie"
-#, fuzzy
-#~ msgid "Odd number of types"
-#~ msgstr "Nombre invalide d'étapes: %s"
-#~ msgid "Output slope raster map"
-#~ msgstr "Fichier raster en sortie pour la pente"
-#~ msgid "Output aspect raster map"
-#~ msgid "Output profile curvature raster map"
-#~ msgstr "Nom du fichier raster en sortie pour la courbure de profil"
-#~ msgid "Output tangential curvature raster map"
-#~ msgstr "Nom du fichier raster en sortie pour la courbure tangentielle"
-#~ msgid "Output mean curvature raster map"
-#~ msgstr "Nom du fichier raster en sortie pour la courbure moyenne du profil"
-#, fuzzy
-#~ msgid "Cannot allocate memory for row buffer"
-# c-format
-#, fuzzy
-#~ msgid "Unable to write categories for raster map <%s>"
-#, fuzzy
-#~ msgid "Layer is only used for WHERE SQL statement"
-#~ msgstr "Utiliser db.select pour les déclarations SELECT SQL"
-#~ msgid "Layer 0 not supported"
-#~ msgstr "Couche 0 non gérée"
-#, fuzzy
-#~ msgid "Layer number (if -1, all features in all layers of given type are extracted)"
-#~ msgstr "Code de couche. Si fixé à -1, tous les objets de toutes les couches du type donné sont extraites."
-# c-format
-#, fuzzy
-#~ msgid "Unable to read file header of <%s>"
-#~ msgstr "Impossible de lire les informations de l'en-tête de fichier [%s]"
-#~ msgid "Current region cannot be set."
-#~ msgstr "La région courante ne peut être modifiée"
-#, fuzzy
-#~ msgid "Unable to allocate the input row buffer"
-#~ msgid "Unable to open the cell map MASK."
-#~ msgstr "Impossible d'ouvrir la couche de cellule MASK."
-#~ msgid "Unable to allocate the cell buffer in display_signature()."
-#~ msgstr "Impossible d'allouer la mémoire tampon des cellules dans display_signature()."
-#~ msgid "Did not find input cell map MASK."
-#~ msgstr "Couche de cellules en entrée MASK introuvable."
-#~ msgid "Error reading raster map in function readbands."
-#~ msgstr "Erreur de lecture du fichier de cellules dans la fonction readbands."
-#, fuzzy
-#~ msgid "Unable to read cell header for first band file"
-#~ msgstr "Impossible de lire l'en-tête de cellule pour le fichier de première bande"
-#~ msgid "Unable to open band files."
-#~ msgstr "impossible d'ouvrir les fichiers de bandes spectrales"
-#~ msgid "Error while reading input raster map."
-#~ msgstr "Erreur de lecture de la couche raster en entrée"
-#~ msgid "Error reading cell map during transform."
-#~ msgstr "Erreur dans la lecture de la couche de cellules durant la transformée"
-#~ msgid "Error writing cell map during transform."
-#~ msgstr "Erreur dans l'écriture de la couche de cellules durant la transformée"
-# c-format
-#~ msgid "Could not open <%s>"
-#~ msgstr "impossible d'ouvrir <%s>"
-# c-format
-#~ msgid "Could not read from <%s>"
-#~ msgstr "Impossible de lire <%s>"
-#~ msgid "Error reading row of data"
-#~ msgstr "Erreur de lecture de la ligne de données"
-#, fuzzy
-#~ msgid "Error reading intensity data"
-#, fuzzy
-#~ msgid "Error reading saturation data"
-#~ msgid "Error writing PROJ_INFO"
-#~ msgstr "Erreur d'écriture de PROJ_INFO"
-#~ msgid "Error writing PROJ_UNITS"
-#~ msgstr "Erreur d'écriture de PROJ_UNITS"
-# c-format
-#, fuzzy
-#~ msgid "Unable to compile regular expression %s"
-#, fuzzy
-#~ msgid "Unable to read region <%s> in <%s>"
-#~ msgstr "impossible de lire la région <%s> dans <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Unable to read header of raster map <%s@%s>"
-# c-format
-#, fuzzy
-#~ msgid "Raster map <%s@%s>: %s"
-#~ msgstr "Ajouter la couche raster [%s]."
-#, fuzzy
-#~ msgid "Unable to open raster map <%s> in <%s>"
-#, fuzzy
-#~ msgid "raster3d, voxel, export"
-#~ msgstr "Niveau d'eau"
-#, fuzzy
-#~ msgid "raster3d, voxel"
-#, fuzzy
-#~ msgid "raster3d, voxel, import"
-#, fuzzy
-#~ msgid "database, attribute table"
-#~ msgstr "Ne pas créer de table attributaire"
-#, fuzzy
-#~ msgid "vector, import, gazetteer"
-#, fuzzy
-#~ msgid "vector, centroid, area"
-#~ msgstr "Affiche les attributs des vecteurs"
-#, fuzzy
-#~ msgid "raster, elevation, interpolation"
-#~ msgstr "Nombre de points d'interpolation"
-#, fuzzy
-#~ msgid "vector, report, statistics"
-#~ msgstr "Statistiques de transition de classe."
-#, fuzzy
-#~ msgid "vector, database, attribute table"
-#, fuzzy
-#~ msgid "vector, color table"
-#, fuzzy
-#~ msgid "raster, statistics, aggregation"
-#, fuzzy
-#~ msgid "vector, export, GPS"
-#, fuzzy
-#~ msgid "Import waypoints, routes, and tracks from a GPS receiver or GPS download file into a vector map."
-#~ msgstr "Télécharger des Waypoints, Routes, et Tracks depuis un récepteur GPS ou un fichier GPS ASCII dans une couche vectorielle."
-#, fuzzy
-#~ msgid "vector, import, GPS"
-#, fuzzy
-#~ msgid "Import waypoints"
-#~ msgstr "Importation des objets de la couche %d..."
-#, fuzzy
-#~ msgid "Import routes"
-#~ msgstr "Importer"
-#, fuzzy
-#~ msgid "Import track"
-#, fuzzy
-#~ msgid "Force vertices of track or route data as points"
-#~ msgstr "Changer les arcs de données track ou route pour en faire des points"
-#, fuzzy
-#~ msgid "Do not attempt projection transform from WGS84"
-#~ msgstr "Ne pas essayer de faire une transformation de projection à partir de WGS84"
-#, fuzzy
-#~ msgid "Device or file used to import data"
-#~ msgstr "Dispositif ou fichier utilisé pour importer les données"
-#, fuzzy
-#~ msgid "Format of GPS input data (use gpsbabel supported formats)"
-#~ msgstr "Format de données GPS en entrée (utiliser les formats gérés par gpsbabel)"
-#, fuzzy
-#~ msgid "Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is assumed"
-#~ msgstr "projection des données en entrées (utiliser les options de PROJ.4), si rien n'est indiqué Lat/Lon WGS84 sera utilisée"
-#, fuzzy
-#~ msgid "imagery, fusion, Brovey"
-#~ msgstr "groupes d'images"
-#~ msgid "Additional options for wget"
-#~ msgstr "Options additionnelles pour wget"
-#, fuzzy
-#~ msgid "Additional options for curl"
-#, fuzzy
-#~ msgid "display, raster"
-#~ msgstr "Afficher l'index"
-#, fuzzy
-#~ msgid "raster, color table"
-#, fuzzy
-#~ msgid "raster, imagery, import"
-#, fuzzy
-#~ msgid "raster, imagery, colors"
-#, fuzzy
-#~ msgid "raster, import"
-#, fuzzy
-#~ msgid "raster, imagery"
-# c-format
-#, fuzzy
-#~ msgid "raster, mask"
-#, fuzzy
-#~ msgid "vector, area, dissolve"
-#, fuzzy
-#~ msgid "sites, vector, import"
-#, fuzzy
-#~ msgid "Download waypoints, routes, and tracks from a Garmin GPS receiver into a vector map."
-#~ msgstr "Charger des Waypoints, Routes et Tracks à partir d'un récepteur GPS Garmin dans une couche vecteur."
-#, fuzzy
-#~ msgid "Download Waypoints from GPS"
-#~ msgstr "Télécharger des Waypoints à partir d'un GPS"
-#, fuzzy
-#~ msgid "Download Routes from GPS"
-#~ msgstr "Télécharger des Routes à partir d'un GPS"
-#, fuzzy
-#~ msgid "Download Track from GPS"
-#~ msgstr "Télécharger des Tracks à partir d'un GPS"
-#, fuzzy
-#~ msgid "Force import of track or route data as points"
-#~ msgstr "forcer l'import de données track ou routes sous forme de points"
-#, fuzzy
-#~ msgid "Port Garmin receiver is connected to"
-#~ msgstr "Le récepteur Garmin est connecté au port"
-#, fuzzy
-#~ msgid "raster, imagery, statistics"
-#, fuzzy
-#~ msgid "imagery, classification, MLC"
-#~ msgstr "Nom de fichier de signatures à utiliser pour la classification"
-#, fuzzy
-#~ msgid "imagery, image transformation, PCA"
-#~ msgid ""
-#~ "Subgroup too large.  Maximum number of bands is %d\n"
-#~ msgstr ""
-#~ "Sous-groupe trop grand. Le nombre maximum de bandes est %d\n"
-#, fuzzy
-#~ msgid "imagery, classification, signatures"
-#~ msgstr "Nom de fichier du résultat de la classification"
-#, fuzzy
-#~ msgid "imagery, classification, supervised, MLC"
-#, fuzzy
-#~ msgid "imagery, color transformation, RGB, HIS"
-#, fuzzy
-#~ msgid "imagery, FFT"
-#, fuzzy
-#~ msgid "imagery, classification, supervised, SMAP"
-#, fuzzy
-#~ msgid "vector, geometry, 3D"
-#~ msgstr "Couche vecteur à supprimer"
-#, fuzzy
-#~ msgid "vector, projection"
-#~ msgstr "Projection source"
-#~ msgid "Attribute column to use for buffer distances"
-#~ msgstr "Colonne attributaire à utiliser pour la distance de zone-tampons"
-#~ msgid "Stop the process at a certain stage"
-#~ msgstr "Arrêter la procédure à une étape donnée"
-#~ msgid "The tolerance was reset to %g (map units)"
-#~ msgstr "La tolérance a été réinitialisée à %g (en unités carte)"
-#~ msgid "The tolerance was reset to %g (map units). [category %d]"
-#~ msgstr "La tolérance a été réinitialisée à %g (en unités cartes). [catégorie %d]"
-#, fuzzy
-#~ msgid "Areas buffers... "
-#, fuzzy
-#~ msgid "If set to 0, z coordinates are used (3D vector only)"
-#~ msgstr "Valeur du champ. Si fixée à 0, les coordonnées z sont utilisées (vecteur 3D seulement)"
-#, fuzzy
-#~ msgid "vector, geometry, sampling"
-#, fuzzy
-#~ msgid "vector, reclass, attributes"
-#, fuzzy
-#~ msgid "vector, buffer"
-#, fuzzy
-#~ msgid "vector, raster, conversion"
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares)"
-#, fuzzy
-#~ msgid "vector, path, visibility"
-#, fuzzy
-#~ msgid "Duplicate area centroids"
-#, fuzzy
-#~ msgid "vector, transformation, 3D"
-#, fuzzy
-#~ msgid "got type %d"
-#~ msgstr "Type inconnu"
-#, fuzzy
-#~ msgid "Unable to select record from table <%s> (key %s, column %s)"
-#~ msgstr "Impossible de sélectionner des données dans la table"
-# c-format
-#, fuzzy
-#~ msgid "Column <%s>: unsupported data type"
-#, fuzzy
-#~ msgid "Error reading ASCII file: (bad type) [%s]"
-#~ msgstr "Erreur de lecture du fichier cats de <%s>"
-#, fuzzy
-#~ msgid "Error reading ASCII file: (unknown type) [%s]"
-#, fuzzy
-#~ msgid "End of ASCII file reached before end of coordinates"
-#~ msgstr "Fichier ASCII conservant les coordonnées de transformation"
-#, fuzzy
-#~ msgid "Error reading ASCII file: (bad point) [%s]"
-#, fuzzy
-#~ msgid "End of ASCII file reached before end of categories"
-#, fuzzy
-#~ msgid "Error reading categories: [%s]"
-# c-format
-#, fuzzy
-#~ msgid ""
-#~ "Unexpected data in vector head:\n"
-#~ "[%s]"
-#~ msgstr "Impossible d'ouvrir la couche vecteur [%s]"
-#, fuzzy
-#~ msgid "Unknown keyword <%s> in vector head"
-#~ msgstr "Mot-clef inconnu [%s] dans l'en-tête de vecteur"
-#, fuzzy
-#~ msgid "vector, category"
-#, fuzzy
-#~ msgid "vector, import, database, points"
-#, fuzzy
-#~ msgid "vector, raster, attribute table"
-#, fuzzy
-#~ msgid "Spline type of interpolation"
-#~ msgstr "La valeur en sortie est l'erreur d'interpolation"
-#, fuzzy
-#~ msgid "vector, metadata, history"
-#, fuzzy
-#~ msgstr "Terminé\t\t"
-#, fuzzy
-#~ msgid "Mapset:          %s"
-#~ msgstr "Jeu de données : \t%s\n"
-# c-format
-#, fuzzy
-#~ msgid "Location:        %s"
-#~ msgstr "Secteur : %s\n"
-#, fuzzy
-#~ msgid "Database:        %s"
-#~ msgstr "\t\t%s"
-#, fuzzy
-#~ msgid "Title:           %s"
-#, fuzzy
-#~ msgid "  Map is 3D:              %s"
-#~ msgstr "Taille minimum de classe :    \t%d\n"
-#, fuzzy
-#~ msgid "  Number of dblinks:      %-9ld"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "  Nombre de points: %d\n"
-#, fuzzy
-#~ msgid "vector, editing, geometry"
-#, fuzzy
-#~ msgid "Error reading ASCII file: '%s'"
-#, fuzzy
-#~ msgid "Error reading categories: '%s'"
-# c-format
-#, fuzzy
-#~ msgid "Unexpected data in vector head: '%s'"
-#, fuzzy
-#~ msgid "Unknown keyword '%s' in vector head"
-#, fuzzy
-#~ msgid "vector, geometry, topology"
-#, fuzzy
-#~ msgid "Output vector. If not given, available layers are printed only."
-#~ msgstr "Couche vectorielle cible, si elle n'est pas indiquée, les couches disponibles seront seulement affichées"
-#~ msgid ""
-#~ "OGR layer name. If not given, available layers are printed only. Examples:\n"
-#~ "\t\tESRI Shapefile: shapefile name\n"
-#~ "\t\tMapInfo File: mapinfo file name"
-#~ msgstr ""
-#~ "nom de la couche OGR. Si elle n'est pas indiquée, les couches disponibles seront seulement affichées. Exemples:\n"
-#~ "\t\tShapefile ESRI : nom du shapefile\n"
-#~ "\t\tFichier MapInfo : nom du fichier mapinfo"
-#, fuzzy
-#~ msgid "Output vector name was not specified"
-# c-format
-#, fuzzy
-#~ msgid "Cannot open data source"
-#~ msgstr "Impossible d'ouvrir la source de données : %s"
-#, fuzzy
-#~ msgid "general, projection"
-#, fuzzy
-#~ msgid "general, transformation, GCP"
-#, fuzzy
-#~ msgid "general, gui"
-#, fuzzy
-#~ msgid "display, vector"
-#~ msgid "Size of grid to be drawn"
-#~ msgstr "Taille de la grille à tracer"
-#, fuzzy
-#~ msgid "display, setup"
-#~ msgid "vector, keyword2, keyword3"
-#~ msgstr "couche vectorielle, mot-clé2, mot-clé3"
-#~ msgid "raster, keyword2, keyword3"
-#~ msgstr "couche matricielle, mot-clé2, mot-clé3"
-#, fuzzy
-#~ msgid "database, attribute table, SQL"
-#, fuzzy
-#~ msgid "Do not use this option if schemas are not supported by driver/database server"
-#~ msgstr "Schéma de la base de données. Ne pas utiliser cette option si le pilote ou le serveur ne gèrent pas les schémas de BD."
-#, fuzzy
-#~ msgid "Selects data from table."
-#~ msgstr "Sélectionner les données depuis une base de données."
-#~ msgid "Unused; retained for compatibility purposes, will be removed in future"
-#~ msgstr "Inutile; conservé pour des questions de compatibilité, sera supprimé dans le futur"
-#~ msgid "Invoke slow, but memory frugal operation (generally not needed, will be removed in future)"
-#~ msgstr "Lance une opération lente, mais économe en mémoire (généralement ce n'est pas nécessaire, sera supprimé dans le futur)"
-#~ msgid "A single value of latitude [decimal degrees]"
-#~ msgstr "Valeur unique de latitude [degrés décimaux]"
-#~ msgid "Name of real-sky beam radiation coefficient raster map [-]"
-#~ msgstr "Couche raster du coefficient de rayonnement en plein ciel [-]"
-#~ msgid "Name of real-sky diffuse radiation coefficient raster map [-]"
-#~ msgstr "Couche raster du coefficient de rayonnement diffus en plein ciel [-]"
-#~ msgid "time and insol_time are incompatible options"
-#~ msgstr "time et insol_time ne sont pas compatibles"
-#~ msgid "Mode 1: instantaneous solar incidence angle & irradiance given a set local time"
-#~ msgstr "Mode 1 : angle d'incidence solaire instantanné & irradiance pour une heure locale donnée"
-# c-format
-#~ msgid "Unable to create raster map %s"
-#~ msgid "rows changed from %d to %d"
-#~ msgstr "lignes changées de %d vers %d"
-#~ msgid "cols changed from %d to %d"
-#~ msgstr "colonnes changées de %d vers %d"
-#, fuzzy
-#~ msgid "raster, flow, hydrology"
-#, fuzzy
-#~ msgid "raster, sediment flow, erosion, deposition"
-#, fuzzy
-#~ msgid "raster, cost surface, cumulative costs"
-#~ msgstr "Couche relief raster à traiter"
-#, fuzzy
-#~ msgid "No data"
-#~ msgstr "Pas de table."
-# c-format
-#, fuzzy
-#~ msgid "Unable to find row %d, col %d: %f"
-#~ msgstr "Vecteur d'arrivée introuvable %s"
-#, fuzzy
-#~ msgid "%s higher above pointer wrong"
-#~ msgstr "Hauteur de la caméra au-dessus du sol"
-#, fuzzy
-#~ msgid "raster, DEM, contours, vector"
-#, fuzzy
-#~ msgid "raster, random, cell"
-#~ msgid "Output map: useful for visual display of results"
-#~ msgstr "Couche de sortie : pratique pour visualiser les résultats"
-#, fuzzy
-#~ msgid "raster, random, surface"
-#~ msgstr "Fichier raster à utiliser comme surface"
-#, fuzzy
-#~ msgid "raster, import, LIDAR"
-#~ msgid "Name of raster map to contain results (several new layers)"
-#~ msgstr "Nom de la couche raster des résultats en sortie (plusieurs nouvelles couches)"
-# c-format
-#, fuzzy
-#~ msgid "Raster map <%s> already exists in mapset <%s>, select another name"
-#~ msgstr "La couche raster [%s] existe dans le groupe."
-#, fuzzy
-#~ msgid "Percent Completed ... "
-#~ msgstr "Pourcentage effectué..."
-#, fuzzy
-#~ msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in a local text file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
-#~ msgstr "Calcule des couches de rayonnement solaire direct (beam), diffus et réfléchi pour un jour donné, une latitude; des propriétés de surface et des conditions atmosphériques. Les paramètres solaires (par exemple, le lever du soleil, le coucher du soleil, la déclinaison, les radiations extra-terrestres, la durée du jour) sont sauvegardées dans un fichier texte local. Sinon, une heure locale peut être indiquée pour calculer des angles d'incidence ou d'irradiance du rayonnement solaire. Les effets d'ombres portées par la topographie peuvent être pris en compte de façon optionnelle."
-#, fuzzy
-#~ msgid "Name of the longitude input raster map [decimal degrees]"
-#~ msgstr "Nom de la couche vecteur de latitudes (degrés décimaux)"
-#, fuzzy
-#~ msgid "incidout requres time parameter to be set"
-#~ msgstr "incidout demande de fixer le paramètre d'heure"
-#, fuzzy
-#~ msgid "Mode 2: integrated daily irradiation"
-#~ msgstr "Mode 2 : irradiation journalière cumulée pour un jour donné de l'année"
-#, fuzzy
-#~ msgid "raster, metadata"
-#, fuzzy
-#~ msgid "raster, composite"
-#, fuzzy
-#~ msgid "Could not read east bufferzone size. Aborting."
-#~ msgstr "Impossible de lire le fichier d'intervalle"
-#, fuzzy
-#~ msgid "Could not read west bufferzone size. Aborting."
-#, fuzzy
-#~ msgid "Could not read south bufferzone size. Aborting."
-#, fuzzy
-#~ msgid "Could not read north bufferzone size. Aborting."
-#, fuzzy
-#~ msgid "raster, statistics, reclass"
-#, fuzzy
-#~ msgid "raster, DEM, fractal"
-#, fuzzy
-#~ msgid "Output more comments (default=quiet)"
-#~ msgstr "Couche raster en sortie (par défaut : tuile en entrée)"
-# c-format
-#, fuzzy
-#~ msgid "%d arcs added to network (nlayer %d)"
-#~ msgstr "%d catégories chargées depuis la table"
-#, fuzzy
-#~ msgid "%d boundaries converted to lines"
-#~ msgstr "%-5d centroïdes écrits dans le fichier de sortie.\n"
-# c-format
-#, fuzzy
-#~ msgid "Elevation raster map <%s> does not cover the entire area of the input vector map <%s>. "
-#~ msgstr "Couche vectorielle <%s> en entrée introuvable"
-#~ msgid "Species <%s> not known. I'll use parameters for spruce instead"
-#~ msgstr "L'essence <%s> est inconnue. J'utilise les paramètres pour les sapins à la place"
-#~ msgid "Draw geographic grid"
-#~ msgstr "Trace la grille géographique"
-#~ msgid ""
-#~ "\n"
-#~ "SECTION 2: A * Search.                      Percent complete: "
-#~ msgstr ""
-#~ "\n"
-#~ "SECTION 2: A * Recherche.                      Achevé (pourcentage): "
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "SECTION 2: A * Search.                      Percent complete:"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "SECTION 2: A * Recherche.                      Achevé (pourcentage):"
-#~ msgid "    segments in row:\t%d"
-#~ msgstr "\tsegments en ligne:\t%d"
-#~ msgid "segments in columns:\t%d"
-#~ msgstr "segments en colonnes:\t%d"
-#~ msgid "     total segments:\t%d"
-#~ msgstr "\ttotal des segments:\t%d"
-#~ msgid "      open segments:\t%d"
-#~ msgstr "\touvrir des segments:\t%d"
-#~ msgid "GRASS module to create a fractal surface of a given fractal dimension. Uses spectral synthesis method. Can create intermediate layers showing the build up of different spectral coefficients (see Saupe, pp.106-107 for an example of this). Use this module to generate naturally looking synthetical elevation models (DEM)."
-#~ msgstr "Module GRASS pour créer une surface fractale de dimension fractale donnée. Utilise la méthode de synthèse spectrale. Peut créer des couches intermédiaires pour montrer la construction des différents coefficients spectraux (voir Saupe, pp.106-107 pour un example). Utiliser ce module pour générer des modèles numériques de terrain artificiels mais à l'aspect naturel."
-#~ msgid "Save graphic legend output in tlegend.txt file for d.graph display in GIS Manager"
-#~ msgstr "Sauvegarder la sortie graphique de légende dans un fichier tlegend.txt pour l'affichage de d.graph dans le Gestionnaire SIG"
-#~ msgid "force removal (use only if you know what you are doing)"
-#~ msgstr "Forcer la suppression (à n'utiliser que si vous êtes sûr de vous)"
-#~ msgid "Print all, inclusive range"
-#~ msgstr "Afficher toutes les valeurs sur l'intervalle, bornes incluses"
-#~ msgid "Resolution of raster and raster3d maps should be equal!"
-#~ msgstr "Attention, la résolution des couches rasters et rasters 3D doit être identique!"
-#~ msgid "Connect to the database through DBMI."
-#~ msgstr "Connexion à la base de données via DBMI."
-#~ msgid "Invoke fast, but memory intensive operation"
-#~ msgstr "Utiliser une méthode rapide, mais gourmande en mémoire"
-#~ msgid ""
-#~ "Output direction type AGNPS, ANSWERS or GRASS aspect\n"
-#~ "              default: GRASS"
-#~ msgstr ""
-#~ "Type de direction en sortie : AGNPS, ANSWERS ou GRASS\n"
-#~ "              défaut: GRASS"
-#~ msgid "Aspect"
-#~ msgstr "Aspect"
-#~ msgid "Mean curvature"
-#~ msgstr "Courbure moyenne"
-#, fuzzy
-#~ msgid "Poorly placed psuedo control points. "
-#~ msgstr "Pas de points de départ"
-#, fuzzy
-#~ msgid "No active psuedo control points"
-#, fuzzy
-#~ msgid "Cannot calculate area centroid z coordinate"
-#, fuzzy
-#~ msgid "Name of input point vector map"
-#, fuzzy
-#~ msgid "Output vector map must be specified"
-#, fuzzy
-#~ msgid "Point vector map must be specified"
-#, fuzzy
-#~ msgid "Threshold value must be specified"
-#, fuzzy
-#~ msgid "ASCII file to be imported, if not given reads from standard input"
-#~ msgstr "Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué prendreles paramètres saisis en ligne de commande"
-#~ msgid "Number of column used as x coordinate (first column is 1) for points mode"
-#~ msgstr "Nombre de colonnes utilisées comme coordonnées x (la première colonne est 1) en mode points"
-#~ msgid "Output drain raster map"
-#~ msgstr "couche raster de sortie"
-#~ msgid "Source map is: Integer cell type"
-#~ msgstr "La couche en entrée : cellules de type entier"
-#~ msgid "Source map is: Floating point (float) cell type"
-#~ msgstr "La couche en entrée : cellules de type flottant"
-#~ msgid "Source map is: Floating point (double) cell type"
-#~ msgstr "La couche en entrée : cellules de type double flottant"
-# c-format
-#, fuzzy
-#~ msgid "Reading %s"
-#~ msgstr "Lecture du fichier %s..."
-#~ msgid "can't open raster map [%s] needed for input coordinates"
-#~ msgstr "Impossible d'ouvrir le fichier raster [%s] nécessaire pour obtenir les coordonnées en entrée"
-# c-format
-#, fuzzy
-#~ msgid "Writing %s"
-#~ msgstr "Écriture %s..."
-#~ msgid "Error getting input null cells"
-#~ msgstr "Erreur de récupération des cellules null en entrée"
-# c-format
-#, fuzzy
-#~ msgid "Can't find %d,%d:%f"
-#~ msgstr "Impossible d'ouvrir la base de données %s"
-#, fuzzy
-#~ msgid "Unable to open MASK"
-#~ msgstr "impossible d'ouvrir le MASK"
-#~ msgid "Cannot open database %s by driver %s"
-#~ msgstr "Impossible d'ouvrir la base de données %s avec le pilote %s"
-#, fuzzy
-#~ msgid "Cannot select attributes: %s"
-#~ msgstr "Impossible de sélectionner des données dans la table attributaire"
-#~ msgid "Background color, either a standard GRASS color, R:G:B triplet, or \"none\""
-#~ msgstr "Couleur de fond, soit une couleur GRASS standard, soit un triplet R:G:B, soit aucune \"none\""
-# c-format
-#, fuzzy
-#~ msgid "Removing %s <%s>"
-#, fuzzy
-#~ msgid "couldn't be removed"
-#~ msgstr "Icone à supprimer"
-#, fuzzy
-#~ msgid "%s: couldn't be removed"
-# c-format
-#, fuzzy
-#~ msgid "<%s> nothing removed"
-#~ msgstr "<%s> non trouvé\n"
-#, fuzzy
-#~ msgid "Output inverse raster map after IFFT"
-#~ msgstr "Fichier raster inverse en sortie après ifft"
-#~ msgid "Power 2 values : [%d] rows [%d] columns."
-#~ msgstr "2 valeurs : [%d] lignes [%d] colonnes."
-#~ msgid "Reading the raster maps..."
-#~ msgstr "Lecture des couches raster..."
-#~ msgid "Rotating data arrays..."
-#~ msgstr "Rotation des vecteurs de données..."
-#~ msgid "Inverse FFT completed..."
-#~ msgstr "FFT inverse terminée..."
-#~ msgid "Unable to open output file."
-#~ msgstr "Impossible d'ouvrir le fichier de sortie"
-#~ msgid "Transform successful."
-#~ msgstr "Transformée réussie."
-#, fuzzy
-#~ msgid "Intensity map name"
-#~ msgstr "Afficher le nom du jeu de données"
-#, fuzzy
-#~ msgid "Saturation map name"
-#, fuzzy
-#~ msgid "Output map representing the red"
-#, fuzzy
-#~ msgid "Output map representing the green"
-#, fuzzy
-#~ msgid "Output map representing the blue"
-#~ msgstr "Format de sortie pour la pente"
-# c-format
-#, fuzzy
-#~ msgid "Cannot read row from raster map"
-#~ msgstr "Impossible d'accéder à la ligne %d de la couche raster %s"
-# c-format
-#, fuzzy
-#~ msgid "Cannot write row to raster map"
-#, fuzzy
-#~ msgid "Green input raster map"
-#, fuzzy
-#~ msgid "Blue input raster map"
-#, fuzzy
-#~ msgid "Output intensity raster map"
-#~ msgstr "Fichier raster en sortie pour la densité des courants"
-#~ msgid "pyramid constructed."
-#~ msgstr "Pyramide construite."
-#~ msgid "Class transition statistics."
-#~ msgid "Transition probabilities: %f %f %f; %f"
-#~ msgstr "Probabilités de transition : %f %f %f; %f"
-#~ msgid "get_img: out of memory."
-#~ msgstr "get_img : mémoire insuffisante."
-#~ msgid "Subgroup [%s] in group [%s] contains no files."
-#~ msgstr "Le sous-groupe [%s] du groupe [%s] ne contient pas de fichier."
-#~ msgid "Writing [%s] ..."
-#~ msgstr "Écriture [%s]..."
-#, fuzzy
-#~ msgid "Name of imagery signaturefile"
-#~ msgstr "Fichier de signatures image"
-#~ msgid "Run quietly"
-#~ msgstr "Mode silencieux"
-#~ msgid "Subgroup [%s] not found."
-#~ msgstr "Sous-groupe [%s] non trouvé"
-#~ msgid "Signature file [%s] is missing or not readable."
-#~ msgstr "Fichier signature [%s] manquant ou impossible à lire."
-#, fuzzy
-#~ msgid "Calculating eigenvalues and eigenvectors..."
-#~ msgstr "Calcul de la moyenne de classe..."
-# c-format
-#, fuzzy
-#~ msgid "Cannot write color table of raster map <%s>"
-#~ msgid "Calculating class mean ..."
-#~ msgid "Calculating class covariance matrix..."
-#~ msgstr "Calcul de la matrice de covariance de classe"
-#, fuzzy
-#~ msgid "Imagery group"
-#, fuzzy
-#~ msgid "Subgroup containing image files"
-#~ msgstr "sous-groupe contenant les fichiers image"
-#, fuzzy
-#~ msgid "Resultant signature file"
-#~ msgstr "fichier signature résultat"
-#~ msgid "%d classes."
-#~ msgstr "%d classes."
-#~ msgid "Unable to create signature file [%s] for subgroup [%s] in group [%s]."
-#~ msgstr "Impossible de créer le fichier signature [%s] du sous-groupe [%s] dans le groupe [%s]."
-#~ msgid "Range of values in output display files"
-#~ msgstr "Intervalle de valeurs dans les fichiers d'affichage en sortie"
-#~ msgid "Initializing data...\n"
-#~ msgstr "Initialisation des données...\n"
-#~ msgid "Reading the raster map..."
-#~ msgstr "Lecture de la couche raster."
-#~ msgid "FFT completed..."
-#~ msgstr "FFT terminée..."
-# c-format
-#~ msgid "subgroup <%s> not found"
-#~ msgstr "sous-groupe <%s> non trouvé"
-#~ msgid "Subgroup [%s] doesn't have any files"
-#~ msgstr "Le sous-groupe [%s] ne contient aucun fichier"
-#~ msgid "The subgroup must have at least 2 files to run %s"
-#~ msgstr "Le sous-groupe doit avoir au moins 2 fichiers pour pouvoir exécuter %s"
-#~ msgid "Unable to proceed"
-#~ msgstr "impossible de poursuivre"
-# c-format
-#, fuzzy
-#~ msgid "Can't open seed signature file <%s>"
-#~ msgstr "impossible d'ouvrir le fichier signature germe <%s>"
-#, fuzzy
-#~ msgid "Can't read signature file <%s>"
-#~ msgstr "Impossible de lire le fichier de signature [%s]."
-#~ msgid "Group of imagery files to be clustered"
-#~ msgstr "Groupe de fichier images à clusteriser"
-#~ msgid "Subgroup name in the above group"
-#~ msgstr "Nom du sous-groupe dans le groupe ci-dessus"
-#, fuzzy
-#~ msgid "Output file to contain final report"
-#~ msgstr "Nom du fichier en sortie contenant le rapport final"
-#~ msgid ""
-#~ "\n"
-#~ "<%s> -- illegal value of min_size"
-#~ msgstr ""
-#~ "\n"
-#~ "<%s> -- valeur illégale de min_size"
-#~ msgid "Can't creat reportfile: "
-#~ msgstr "Impossible de créer le fichier de rapport: "
-#~ msgid "Reading image ... "
-#~ msgstr "Lecture de l'image..."
-#, fuzzy
-#~ msgid "Creates control points on an image to be ortho-rectified."
-#~ msgstr "Placer des points de contrôle sur une image pour le recalage de l'orthophoto."
-# c-format
-#, fuzzy
-#~ msgid "Unable to read head of %s"
-#, fuzzy
-#~ msgid "Name of imagery group for ortho-rectification"
-#~ msgstr "Nom du Secteur de destination du groupe d'images"
-#, fuzzy
-#~ msgid "Unable to write temp file: %s"
-# c-format
-#, fuzzy
-#~ msgid "Unable to open map %s"
-#, fuzzy
-#~ msgid "Unable to write row %d"
-# c-format
-#~ msgid "group=[%s] - not found."
-#~ msgstr "groupe=[%s] non trouvé"
-#~ msgid "subgroup=[%s] (of group [%s]) - not found."
-#~ msgstr "sous-groupe=[%s] (du groupe [%s]) - non trouvé."
-#~ msgid "Can't read signature file [%s]."
-#~ msgid "[%s] has more than 255 signatures."
-#~ msgstr "[%s] a plus de 255 signatures."
-#~ msgid "Unable to create reject layer [%s]."
-#~ msgstr "Impossible de créer la couche de rejet [%s]."
-#~ msgid "Imagery group to be classified"
-#~ msgstr "Groupe d'images sur lequel lancer une classification"
-#~ msgid "Subgroup containing image files to be classified"
-#~ msgstr "Sous-groupe contenant les fichiers images pour la classification"
-#~ msgid "Signatures to use for classification"
-#~ msgid "Raster map to hold classification results"
-#~ msgstr "Nom de fichier raster devant contenir les résultat de la classification"
-#~ msgid "sensor: LANDSAT"
-#~ msgstr "Capteur: LANDSAT"
-#~ msgid "sensor: QuickBird"
-#~ msgstr "Capteur: QuickBird"
-#~ msgid "sensor: SPOT"
-#~ msgstr "Capteur: SPOT"
-#~ msgid "1st map for mosaic (top of image stack)."
-#~ msgstr "1ère couche pour la mosaïque (au somment de la pile d'images)"
-#~ msgid "3rd map for mosaic."
-#~ msgstr "3ème couche pour la mosaïque."
-#~ msgid "4th map for mosaic."
-#~ msgstr "4ème couche pour la mosaïque."
-#~ msgid "Verbose mode (print projection parameters and filenames to stderr)"
-#~ msgstr "Mode détaillé (affiche les paramètres de projection et les noms de fichiers vers stderr)"
-#~ msgid "run non-interactively"
-#~ msgstr "Exécuter de façon non-interactive"
-#, fuzzy
-#~ msgid "Run non-interactively"
-#, fuzzy
-#~ msgid "Name of GIS manager settings file (.grc)"
-#~ msgstr "Nom du fichier MAT-File(v4) à importer"
-#, fuzzy
-#~ msgid "Unable to open raster map <%s> in mapset <%s>"
-# c-format
-#, fuzzy
-#~ msgid "ERROR: Problem opening output file."
-#~ msgstr "impossible d'ouvrir le fichier en sortie <%s>"
-#~ msgid "Name of fractal surface raster layer"
-#~ msgstr "Nom de la couche qui contiendra la surface fractale"
-#~ msgid "Sums up the raster cell values."
-#~ msgstr "Additionne les valeurs de cellule raster"
-#~ msgid "Name of incidence or density file."
-#~ msgstr "Nom du fichier d'incidence ou de densité"
-#, fuzzy
-#~ msgid "Creates explicitly the NULL-value bitmap file."
-#~ msgstr "Créer de façon explicite le fichier bitmap 3D de valeur-NULL"
-#~ msgid "Finds the average of values in a cover map within areas assigned the same category value in a user-specified base map."
-#~ msgstr "Trouve la moyenne des valeurs d'une couche de couverture à partir des zones ayant la même catégorie dans une couche de base spécifiée par l'utilisateur."
-#~ msgid "%s: ERROR running %s command"
-#, fuzzy
-#~ msgid "Creation option to the output format driver. Multiple options may be listed."
-#~ msgstr "option de création du pilote de format de sortie. De multiples options peuvent être disponibles"
-#, fuzzy
-#~ msgid "Metadata key passed on the output dataset if possible"
-#~ msgstr "clef de métadonnées passées aux données en sortie si possible"
-#, fuzzy
-#~ msgid "Density of output walkers"
-#~ msgstr "Nom du fichier de sortie"
-#, fuzzy
-#~ msgid "File [%s] not found"
-#~ msgstr "raster <%s> non trouvé"
-# c-format
-#, fuzzy
-#~ msgid "Unable to open file [%s]"
-#, fuzzy
-#~ msgid "Failed to guess file format"
-#~ msgstr "Echec pour définir le format du fichier de sites"
-#, fuzzy
-#~ msgid "Reading sites map (%s) ..."
-#, fuzzy
-#~ msgid "You are not outputting any raster or vector points maps"
-#~ msgstr "Vous ne fabriquez aucun fichier raster ou vecteur en sortie"
-#, fuzzy
-#~ msgid "%s=%s - illegal value"
-#~ msgstr "%s=%s - nom illégal"
-#, fuzzy
-#~ msgid "Unable to read current region parameters"
-#~ msgstr "Impossible de lire les paramètres de la fenêtre courante"
-#, fuzzy
-#~ msgid "Unable to get current region"
-#~ msgstr "impossible de mettre à jour l'emprise de la région courante"
-# c-format
-#, fuzzy
-#~ msgid "Cannot open cover raster map <%s>"
-#~ msgstr ""
-#~ "#-#-#-#-#  grassmods_fr.po (grassmods_fr)  #-#-#-#-#\n"
-# c-format
-#~ msgid "Cannot open database <%s> by driver <%s>"
-#~ msgstr "Impossible d'ouvrir la base de données <%s> avec le pilote <%s>"
-#~ msgid "Finds the median of values in a cover map within areas assigned the same category value in a user-specified base map."
-#~ msgstr "Trouve la médiane des valeurs d'une couche de couverture dans les zones définies par les catégories d'une couche de base."
-#, fuzzy
-#~ msgid "Unable to read category labels of raster map <%s>"
-#, fuzzy
-#~ msgid "%s - unable to remove color table"
-#~ msgstr "Impossible d'écrire les fichiers temporaires"
-# c-format
-#, fuzzy
-#~ msgid "%s - color table not found"
-#~ msgstr "%s - couche non trouvée"
-#~ msgid "Can't make random color table for floating point map"
-#~ msgstr "Impossible de construire une table de couleurs aléatoire pour les couches en valeurs flottantes"
-#~ msgid "Can't make grey.eq color table for floating point map"
-#~ msgstr "Impossible de construire une table en valeurs de gris pour les couches en valeurs flottantes"
-#~ msgid "Can't make logarithmic color table for floating point map"
-#~ msgstr "Impossible de construire une table de couleurs logarithmique pour les couches en valeurs flottantes"
-#~ msgid "%s - unknown color request"
-#~ msgstr "%s - couleur demandée inconnue"
-# c-format
-#, fuzzy
-#~ msgid "Starting map [%s]"
-#, fuzzy
-#~ msgid "Percent done:"
-#~ msgstr "Pourcentage complet :"
-#, fuzzy
-#~ msgid "Unable to read current window parameters"
-# c-format
-#, fuzzy
-#~ msgid "Unable to properly read input raster map"
-#~ msgstr "<%s> impossible d'ouvrir le fichier raster"
-#, fuzzy
-#~ msgid "Unable to properly write output raster map"
-#~ msgstr "Impossible d'ouvrir le fichier de signature en sortie"
-#, fuzzy
-#~ msgid "SECTION %d beginning: Closing Maps."
-#~ msgstr ""
-#~ "\n"
-#~ "SECTION %d démarrage: Fermeture des couches."
-#, fuzzy
-#~ msgid "SECTION %d beginning: Watershed determination."
-#~ msgstr ""
-#~ "\n"
-#~ "SECTION %d démarrage: détermination du bassin versant."
-#~ msgid "problem w/ astar algorithm"
-#~ msgstr "problème avec l'algorithme astar"
-#~ msgid "Could not read range file"
-#, fuzzy
-#~ msgid "Reading data: "
-#~ msgstr "Rotation des données ... "
-#, fuzzy
-#~ msgid "Rowio_setup failed"
-#, fuzzy
-#~ msgid "Rowio_get failed"
-#~ msgid "Name of raster map layer to be used for <%s>"
-#~ msgstr "Nom de la couche raster qui sera utilisée pour <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Elevation map not found"
-#~ msgstr "fichier d'altitude non trouvé\n"
-#, fuzzy
-#~ msgid "%d points converted to centroids"
-#~ msgstr "%-5d points lus en mémoire\n"
-#, fuzzy
-#~ msgid "%d centroids converted to points"
-#, fuzzy
-#~ msgid "%d lines converted to boundaries"
-#~ msgstr "%s fichier(s) à supprimer"
-# c-format
-#, fuzzy
-#~ msgid "CrossCorrelation: %d points read in region.\n"
-#~ msgstr "%d points en dehors de la région courante"
-#, fuzzy
-#~ msgid "CrossCorrelation: Cannot read field info"
-#~ msgstr "Impossible de lire les informations du champ"
-#, fuzzy
-#~ msgid "CrossCorrelation: Cannot open database %s by driver %s"
-#, fuzzy
-#~ msgid "CrossCorrelation: Column type not supported"
-#~ msgstr "Type de colonne non géré"
-#, fuzzy
-#~ msgid "CrossCorrelation: Cannot select data from table"
-#, fuzzy
-#~ msgid "CrossCorrelation: %d records selected from table"
-#~ msgstr "%d enregistrements sélectionnés dans le tableau"
-#, fuzzy
-#~ msgid "CrossCorrelation: No record for point (cat = %d)"
-#~ msgstr "Aucun enregistrement pour la ligne (cat = %d)"
-#, fuzzy
-#~ msgid "From type"
-#~ msgstr "Type de donnée vectorielle"
-#, fuzzy
-#~ msgid "From layer"
-#~ msgstr "Requêter la couche"
-#~ msgid "Cannot fetch data"
-#~ msgstr "Impossible de rapatrier les données"
-#, fuzzy
-#~ msgid "Calculating costs from centres..."
-#~ msgstr "Calcul des moyennes de classes..."
-#, fuzzy
-#~ msgid "vector, editing, digitization"
-#~ msgid "Interactive editing and digitization of vector maps."
-#~ msgstr "Edition et numérisation interactive de couches vectorielles."
-#~ msgid "Create new file if it does not exist."
-#~ msgstr "Créer le nouveau fichier s'il n'existe pas."
-#~ msgid "New empty map created."
-#~ msgstr "Nouvelle couche vide créée."
-#, fuzzy
-#~ msgid "Map <%s> does not exist in current mapset. Add flag -n to create a new map."
-#~ msgstr "La couche n'existe pas. Ajouter le drapeau -n pour créer la nouvelle couche."
-#, fuzzy
-#~ msgid "Feature id(s)"
-#~ msgid "Input vector was not found."
-#~ msgstr "Le vecteur en entrée n'a pas été trouvé."
-#~ msgid "Cannot open dig_cats file."
-#~ msgstr "Impossible d'ouvrir le fichier dig_cats."
-#~ msgid "Cannot open database %s"
-#~ msgid "Cannot insert into table: %s"
-#~ msgstr "Impossible d'insérer dans la table: %s"
-#, fuzzy
-#~ msgid "%s: Unable to read font definition file; use the default"
-#~ msgstr "%s : impossible de lire le fichier de définition FreeType; on utilise les paramètres par défaut"
-#, fuzzy
-#~ msgid "%s: No font definition file"
-#~ msgstr "%s : pas de fichier de définition FreeType"
-#, fuzzy
-#~ msgid "Arc layer (network)"
-#, fuzzy
-#~ msgid "Node layer (points)"
-#~ msgstr "Nom de la couche utilisée pour la teinte"
-#, fuzzy
-#~ msgid "Query layer (used by 'query' option)"
-#~ msgstr "Lancer une requête sur la couche grâce à l'option 'query'"
-# c-format
-#, fuzzy
-#~ msgid "%d categories read from map"
-# c-format
-#, fuzzy
-#~ msgid "%d update/insert errors"
-#~ msgstr "%d erreurs de mise à jour"
-#~ msgid ""
-#~ "Operator defines required relation between features. A feature is written to output if the result of operation 'ainput operator binput' is true. An input feature is considered to be true, if category of given layer is defined.\n"
-#~ "\t overlap: features partially or completely overlap"
-#~ msgstr ""
-#~ "Opérateur qui définit la relation requise entre objets. Un objet est écrit dansla couche de sortie si le résultat de l'opération 'ainput opérateur binput' est vrai. Un objeten entrée est considéré vrai, si la catégorie de la couche est définie.\n"
-#~ "\t recouvrement : les objets se recouvrent totalement ou partiellement"
-#~ msgid "Processing ainput lines ..."
-#~ msgstr "Traitement des lignes ainput..."
-#~ msgid "Processing ainput areas ..."
-#~ msgstr "Traitement des entités surfaciques ainput..."
-# c-format
-#, fuzzy
-#~ msgid "Current region does not include the entire input vector map <%s>"
-#, fuzzy
-#~ msgid "Unable to read raster row"
-#~ msgid ""
-#~ "Optional where condition (without WHERE key word), e.g.:\n"
-#~ "\t\tobec = 'Liptakov'"
-#~ msgstr ""
-#~ "Condition optionnelle (sans le mot-clef WHERE), ex: \n"
-#~ msgid "Illegal output file name"
-#~ msgstr "Nom du fichier de sortie illégal"
-#, fuzzy
-#~ msgid "Display manager for GRASS"
-#~ msgstr "Afficher les pages de manuel GRASS au format HTML"
-#, fuzzy
-#~ msgid "Name of .dmrc settings file"
-#~ msgid "Selects/starts specified monitor at specified size"
-#~ msgstr "Sélectionne/démarre le moniteut désigné à la taille spécifiée"
-#~ msgid "Width in pixels of new display monitor"
-#~ msgstr "Largeur en pixels du nouveau moniteur d'affichage"
-#~ msgid "Height in pixels of new display monitor"
-#~ msgstr "Hauteur en pixels du nouveau moniteur d'affichage"
-#, fuzzy
-#~ msgid "Moves displayed maps to another monitor"
-#~ msgstr "Déplacer les couches affichée vers un autre moniteur"
-#~ msgid "clear target monitor before moving"
-#~ msgstr "Nettoyer le moniteur cible avant de déplacer les couches"
-#~ msgid "stay with source monitor"
-#~ msgstr "Conserver le moniteur source"
-#~ msgid "kill source monitor after moving"
-#~ msgstr "tuer le moniteur source après le déplacement"
-#~ msgid "Target monitor"
-#~ msgstr "Cibler un moniteur"
-#~ msgid "Export display monitor to a GpsDrive compatible backdrop image"
-#~ msgstr "Exporter le moniteur d'affichage vers une image compatible avec un récepteur GPS"
-#, fuzzy
-#~ msgid "display, export, GPS"
-#~ msgid "Make JPEG instead of PNG image"
-#~ msgstr "Faire un JPEG à la place d'une image PNG"
-#~ msgid "Saves active display monitor to PNG file in home directory"
-#~ msgstr "Sauvegarder l'affichage du moniteur actif en fichier PNG dans le répertoire home"
-#~ msgid "Resolution of output file (single=1, double=2, quad=4)"
-#~ msgstr "Résolution du fichier en sortie (simple=1, double=2, quad=4)"
-#, fuzzy
-#~ msgid "Saves the contents of the active display monitor to a graphics file."
-#~ msgstr "Sauvegarder le moniteur actif en fichier graphique dans le répertoire home"
-#, fuzzy
-#~ msgid "(10=smallest/worst, 100=largest/best)"
-#~ msgstr "Taille/qualité pour les fichiers JPEG (10=plus petit/très dégradée, 100=plus grande/moins dégradée)"
-#, fuzzy
-#~ msgid "Paper size for PostScript output"
-#~ msgstr "Produit un script shell en sortie"
-#~ msgid "Set background color to black (white default)"
-#~ msgstr "Ajuster la couleur de fond en noir (par défaut blanc)"
-#, fuzzy
-#~ msgid "Set transparent background"
-#~ msgstr "Fond transparent"
-#, fuzzy
-#~ msgid "Redraws the current display frame in the GRASS monitor"
-#~ msgstr "Rafraîchir les couches affichées dans le moniteur GRASS"
-#, fuzzy
-#~ msgid "Redraw all frames"
-#~ msgstr "Sauvegarder tous les cadres graphiques"
-#~ msgid "Resizes active display monitor"
-#~ msgstr "Redimensionner le moniteur actif"
-#~ msgid "New width for window"
-#~ msgstr "Nouvelle largeur pour la fenêtre"
-#~ msgid "New height for window"
-#~ msgstr "Nouvelle hauteur pour la fenêtre"
-#, fuzzy
-#~ msgid "Slide show of GRASS raster/vector maps."
-#~ msgstr "Diaporama de couches GRASS raster/vecteur"
-#, fuzzy
-#~ msgid "display, slideshow"
-#, fuzzy
-#~ msgid "Show vector maps rather than raster maps"
-#~ msgstr "Convertit des couches rasters 3D en couches rasters 2D"
-#, fuzzy
-#~ msgid "Map prefix. Specify character(s) to view selected maps only"
-#~ msgstr "préfixe de couche. Spécifier les caractère(s) pour voir les couches sélectionnées seulement"
-#, fuzzy
-#~ msgid "Map number show across the monitor"
-#~ msgstr "Nombre de couches affichées en travers du moniteur"
-#, fuzzy
-#~ msgid "Map number show down the monitor"
-#~ msgstr "Nombres de couches affichées en bas du moniteur"
-#, fuzzy
-#~ msgid "Mapsets to use. Specify multiple mapsets comma separated"
-#~ msgstr "Jeux de données à utiliser. Spécifier de multiples jeux de données en les séparant par des virgules"
-#, fuzzy
-#~ msgid "Number of seconds to pause between slides"
-#~ msgstr "Nombre de cellules entre les courants"
-#~ msgid "Divides active display into two frames & displays maps/executes commands in each frame."
-#~ msgstr "Divise l'affichage actif en deux cadres & affiche des couches/exécute des commandes dans chaque cadre."
-#~ msgid "Enter raster map to display in 1st frame"
-#~ msgstr "Entrer la couche raster à afficher dans le 1er cadre"
-#~ msgid "Enter command to execute in 1st frame"
-#~ msgstr "Entrer la commande à exécuter dans le 1er cadre"
-#~ msgid "Enter raster map to display in 2nd frame"
-#~ msgstr "Entrer la couche raster à afficher dans le 2ème cadre"
-#~ msgid "Enter command to execute in 2nd frame"
-#~ msgstr "Entrer la commande à exécuter dans le 2ème cadre"
-#~ msgid "How to split display"
-#~ msgstr "Comment partager l'affichage"
-#~ msgid "Vector map to display thematically"
-#~ msgstr "couche vecteur à afficher (thématique)"
-#, fuzzy
-#~ msgid "Vector map type"
-#~ msgstr "Type de couche vecteur"
-#~ msgid "Layer to use for thematic display"
-#~ msgstr "Couche à utiliser pour l'affichage thématique"
-#~ msgid "Icon size for point data (minimum icon size/line width for graduated points/lines)"
-#~ msgstr "Taille de l'icone pour des données ponctuelles (taille minimale de l'icone/largeur de ligne pour les points gradués/lignes)"
-#, fuzzy
-#~ msgid "Color for graduated points map (grass named color or R:G:B triplet). Set color scheme to single color."
-#~ msgstr "Couleur pour les lignes graduées ou les contours de points/entités surfaciques (nom de couleur GRASS ou triplet R:G:B). Fixer le schéma de couleur pour couleur simple."
-#~ msgid "Color for graduated lines or point/area outlines (grass named color or R:G:B triplet). Set color scheme to single color."
-#~ msgid "Apply regular expressions and wildcards to g.list"
-#~ msgstr "Appliquer des expressions régulières et des wildcards à g.list"
-#, fuzzy
-#~ msgid "Mapset(s) to list (default: current mapset search path)"
-#~ msgstr "jeu de données à lister (par défaut : chemin de recherche courant)"
-#, fuzzy
-#~ msgid "Output separator (default: newline)"
-#~ msgstr "Caractère de séparation en sortie (par défaut : nouvelle ligne)"
-#~ msgid "Apply regular expressions and wildcards to g.remove"
-#~ msgstr "Appliquer des expressions régulières et des wildcards à g.remove"
-#~ msgid "3d raster to remove"
-#~ msgstr "Couche raster 3D à supprimer"
-#, fuzzy
-#~ msgid "Vector to remove"
-#, fuzzy
-#~ msgid "Region to remove"
-#~ msgstr "Région à supprimer"
-#, fuzzy
-#~ msgid "Label to remove"
-#~ msgstr "Etiquette à supprimer"
-#~ msgid "3dview to remove"
-#~ msgstr "3dview à supprimer"
-#, fuzzy
-#~ msgid "Group to remove"
-#~ msgstr "groupe à supprimer"
-#, fuzzy
-#~ msgid "raster input maps"
-#~ msgstr "couche raster en entrée"
-#~ msgid "Use image list and not group"
-#~ msgstr "Utilisez une liste d'image et pas un groupe"
-#~ msgid "Select multiple points"
-#~ msgstr "Sélectionner des points multiples"
-#~ msgid "Keep band numbers instead of using band color names."
-#~ msgstr "Conserver les numéros de bande plutôt que d'utiliser les noms de couleur des bandes"
-#, fuzzy
-#~ msgid "Calculate new raster map from a r.mapcalc expression."
-#~ msgstr "r.mapcalculator - calcule une nouvelle couche raster à partir d'une expression r.mapcalc"
-#, fuzzy
-#~ msgid "A"
-#~ msgstr "A :"
-#, fuzzy
-#~ msgid "B"
-#~ msgstr "B :"
-#, fuzzy
-#~ msgid "E"
-#~ msgstr "E :"
-#, fuzzy
-#~ msgid "F"
-#~ msgstr "F :"
-#, fuzzy
-#~ msgid "Formula (e.g. A-B or A*C+B)"
-#~ msgstr "Formule (par exemple A-B ou A*C+B"
-#~ msgid "Expert mode (enter a set of r.mapcalc expressions)"
-#~ msgstr "Mode expert (entrer un ensemble d'expressions r.mapcalc)"
-#, fuzzy
-#~ msgid "Do not overwrite existing map"
-#~ msgstr "Ne pas écraser la couche existante"
-#, fuzzy
-#~ msgid "Exports GRASS raster into GDAL supported formats."
-#~ msgstr "Exporte un raster GRASS vers un tableau binaire."
-#, fuzzy
-#~ msgid "Creation option to the output format driver. Multiple options may be listed"
-#~ msgid "Output field seperator"
-#~ msgstr "Séparateur de champ en sortie"
-#~ msgid "extended statistics (quartiles and percentile)"
-#~ msgstr "Statistiques étendues (quartiles et centile)"
-#, fuzzy
-#~ msgid "Percentile to calculate (requires -e flag)"
-#~ msgstr "Centile à calculer (requiert le drapeau -e)"
-#, fuzzy
-#~ msgid "Calculates new grid3D volume from r3.mapcalc expression."
-#, fuzzy
-#~ msgid "A (grid3D file)"
-#~ msgstr "Nom du fichier 3D de sortie"
-#, fuzzy
-#~ msgid "B (grid3D file)"
-#, fuzzy
-#~ msgid "C (grid3D file)"
-#, fuzzy
-#~ msgid "D (grid3D file)"
-#, fuzzy
-#~ msgid "E (grid3D file)"
-#, fuzzy
-#~ msgid "F (grid3D file)"
-#, fuzzy
-#~ msgid "Name for output grid3D volume"
-#, fuzzy
-#~ msgid "Expert mode (enter a set of r3.mapcalc expressions)"
-#~ msgid "Name and type of the new column(s) (types depend on database backend, but all support VARCHAR(), INT, DOUBLE and DATE)"
-#~ msgstr "Nom et type de(s) nouvelle(s) colonne(s) (les types dépendent de la base de données utilisée, mais toutes gèrent VARCHAR(), INT, DOUBLE et DATE)"
-# c-format
-#~ msgid "%s: [%s] not found"
-#~ msgstr "%s: [%s] non trouvé"
-#, fuzzy
-#~ msgid "Please choose a unit by entering one of the following letter codes:"
-#~ msgstr "Veuillez choisir l'une des options suivantes\n"
-# c-format
-#, fuzzy
-#~ msgid ""
-#~ "Enter the file name or path\n"
-#~ msgstr "Le nom du fichier raster existe déjà"
-#~ msgid "Interactively select End-Points"
-#~ msgstr "Sélectionner de façon interactive les points de début et de fin du profil"
-#, fuzzy
-#~ msgid "Use mouse to select Start Point\n"
-#~ msgstr "Utiliser la souris pour dimensionner et positionner le cartouche de légende"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Use mouse to draw profile line\n"
-#, fuzzy
-#~ msgid "Buttons:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Boutons:\n"
-#, fuzzy
-#~ msgid "Left:   Mark next point\n"
-#~ msgstr "Gauche: "
-#, fuzzy
-#~ msgid "Middle: Mark next point\n"
-#~ msgstr "Milieu:"
-# c-format
-#~ msgid "elevin raster map <%s> not found"
-#~ msgstr "fichier de cellules elevin <%s> non trouvé"
-# c-format
-#~ msgid "aspin raster map <%s> not found"
-#~ msgstr "fichier de cellules aspin <%s> non trouvé"
-# c-format
-#~ msgid "linkein raster map <%s> not found"
-#~ msgstr "fichier de cellules linkein <%s> non trouvé"
-# c-format
-#~ msgid "albedo raster map <%s> not found"
-#~ msgstr "fichier de cellules albedo <%s> non trouvé"
-# c-format
-#~ msgid "coefbh raster map <%s> not found"
-#~ msgstr "fichier de cellules coefbh <%s> non trouvé"
-# c-format
-#~ msgid "coefdh raster map <%s> not found"
-#~ msgstr "fichier de cellules coefdh <%s> non trouvé"
-#~ msgid "No clump map specified and MASK not set."
-#~ msgstr "Pas de couche de 'flaques' spécifiée et MASK n'est pas activé"
-# c-format
-#, fuzzy
-#~ msgid "Unable to find data map"
-#~ msgstr "Fichier raster introuvable : %s"
-# c-format
-#, fuzzy
-#~ msgid "Unable to find clump map"
-#~ msgid "Memory allocation error"
-#~ msgstr "Erreur d'allocation mémoire"
-#~ msgid "Saving new map"
-#~ msgstr "Sauvegarde de la nouvelle couche"
-#~ msgid "Output raster map with lake"
-#~ msgstr "couche raster en sortie contenant le lac"
-# c-format
-#~ msgid "Cannot write lake raster map <%s>!"
-#~ msgstr "Impossible d'écrire la couche raster lac <%s>!"
-#~ msgid "Terrain raster map <%s> not found!"
-#~ msgstr "couche raster terrain <%s> non trouvée!"
-# c-format
-#~ msgid "Cannot open terrain raster map <%s@%s>!"
-#~ msgstr "Impossible d'ouvrir la couche raster terrain <%s@%s>!"
-#~ msgid "Seed map <%s> not found!"
-#~ msgstr "couche de germes <%s> non trouvée!"
-# c-format
-#~ msgid "Cannot open seed map <%s@%s>!"
-#~ msgstr "Impossible d'ouvrir la couche de germes <%s@%s>!"
-#~ msgid "Failure to allocate memory for row pointers"
-#~ msgstr "Impossible d'allouer de la mémoire pour les pointeurs de ligne"
-#, fuzzy
-#~ msgid "Error reading terrain raster map. Probably broken file."
-# c-format
-#, fuzzy
-#~ msgid "Error reading seed raster map. Probably broken file."
-# c-format
-#~ msgid "Cannot write lake raster map <%s@%s>!"
-#~ msgstr "Impossible d'écrire la couche raster lac <%s@%s>!"
-#~ msgid ""
-#~ "Starting lake filling at level of %8.4f in %d passes. \n"
-#~ "Percent done:"
-#~ msgstr ""
-#~ "Commence le remplissage du lac au niveau de %8.4f en %d passages. \n"
-#~ "pourcentage achevé:"
-#~ msgid "Error writing color file for <%s@%s>!"
-#~ msgstr "Erreur d'écriture du fichier couleur pour <%s@%s>!"
-#~ msgid "All done."
-#~ msgstr "Complètement terminé."
-# c-format
-#, fuzzy
-#~ msgid "%s: base raster map not found"
-#~ msgstr "%s : fichier de cellules <%s> non trouvé"
-# c-format
-#, fuzzy
-#~ msgid "%s: cover raster map not found"
-#~ msgstr "%s - couche raster non trouvée"
-#, fuzzy
-#~ msgid "%s: base map and output map must be different"
-#~ msgstr "Les coordonnées des germes et la couche de sortie= doivent être fixées!"
-#, fuzzy
-#~ msgid "Name of the vector points map with x,y locations"
-#~ msgstr "Nom du fichier vecteur contenant les données en entrée"
-#, fuzzy
-#~ msgid "Number of time iterations (sec.)"
-#, fuzzy
-#~ msgid "Multiscale simulation"
-#~ msgstr "Allocation métrique"
-#, fuzzy
-#~ msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
-#~ msgstr "Nom de la couche raster d'altitude (mètres)"
-#, fuzzy
-#~ msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
-#~ msgstr "Nom du fichier raster source"
-#~ msgid "Calculates <simple> index on a raster map"
-#~ msgstr "Calcule un <simple> index sur un fichier raster"
-#~ msgid "Quietly"
-#~ msgstr "Silencieux"
-#~ msgid "Bilinear interpolation utility for raster map layers."
-#~ msgstr "Outil d'interpolation bilinéaire pour couches raster."
-#, fuzzy
-#~ msgid "Specific input value to be assigned to the north and/or south poles for longitude-latitude grids"
-#~ msgstr "valeurs spécifiques qui seront assignées aux pôles nord et/ou sud pour des grilles données en latitude-longitude"
-#, fuzzy
-#~ msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
-#~ msgstr "Utiliser \"scale\" à partir de la console est obsolète. Veuillez utilisez l'instruction de mise en page cartographique \"scale\" à la place."
-#, fuzzy
-#~ msgid "Illegal output file name <%s>"
-#, fuzzy
-#~ msgid "Base map and output map <%s> must be different"
-#~ msgid "Not enough memory for zero_array_cell"
-#~ msgstr "Mémoire insuffisante pour zero_array_cell"
-#~ msgid "Not enough disk space -- cannot write files"
-#~ msgstr "Espace disque insuffisant -- impossible d'écrire les fichiers"
-#~ msgid "Raster input maps(s)"
-#~ msgstr "Couche raster en entrée"
-#~ msgid "Output file name"
-# c-format
-#~ msgid "%s: can't read fp range for [%s]"
-#~ msgstr "%s: impossible de lire l'intervalle en nombre à virgule flottante pour [%s]"
-# c-format
-#, fuzzy
-#~ msgid ""
-#~ "Raster map [%s] already exists.\n"
-#~ "Please try another."
-#, fuzzy
-#~ msgid "Enter rules interactively"
-#, fuzzy
-#~ msgid "RGB raster map <%s> not found"
-#~ msgstr "couche raster <%s> non trouvée"
-#, fuzzy
-#~ msgid "Vector cell map <%s> not found"
-#~ msgstr "couche vecteur <%s> introuvable"
-#, fuzzy
-#~ msgid "Cannot create vector data, please provide three maps [x,y,z]"
-#~ msgstr "Veuillez indiquer trois couches vecteurs g3d [x,y,z]"
-#~ msgid "Which raster map needs a color table"
-#~ msgstr "Quel fichier raster a besoin d'une table de couleurs?"
-#~ msgid "Edit header for [%s]\n"
-#~ msgstr "Editer l'en-tête pour [%s]\n"
-#~ msgid "[%s] cannot be found!"
-#~ msgstr "Impossible de trouver [%s]!"
-#~ msgid "For what layer shall the header file be edited? "
-#~ msgstr "Quelle est la couche dont l'en-tête de fichier doit être édité?"
-#~ msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
-#~ msgstr "[%s] est une reclassification de [%s] - impossible d'éditer l'en-tête! Exécutez r.support sur [%s]."
-#~ msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
-#~ msgstr "[%s] est une reclassification de [%s in %s] - impossible d'éditer l'en-tête!"
-# c-format
-#~ msgid "Cannot open raster map [%s]!"
-#~ msgstr "Impossible d'ouvrir le fichier raster [%s]!"
-# c-format
-#~ msgid "Raster file [%s] is empty."
-#~ msgstr "Le fichier raster [%s] est vide"
-#~ msgid "cellhd compression: %d\n"
-#~ msgstr "Compression cellhd : %d\n"
-#~ msgid "3.0 compression %sindicated\n"
-#~ msgstr "Compression 3.0 %s indiquée \n"
-#~ msgid "Pre 3.0 compression %sindicated\n"
-#~ msgstr "Pré-compression 3.0 %s indiquée \n"
-#~ msgid "[%s] appears to be compressed. Is it? "
-#~ msgstr "[%s] semble compressé. Est-ce le cas?"
-#~ msgid "Please indicate the type of compression:\n"
-#~ msgstr "Veuillez indiquer le type de compression:\n"
-#~ msgid "  1. Pre 3.0 compression\n"
-#~ msgstr " 1. Pré compression 3.0\n"
-#~ msgid "  2. 3.0 compression\n"
-#~ msgstr " 2. 3.0 compression\n"
-#~ msgid "The header for [%s] says the file is not compressed. "
-#~ msgstr "L'en-tête de [%s] indique que le fichier n'est pas compressé."
-#~ msgid "The file appears to be compressed.\n"
-#~ msgstr "Le fichier semble compressé.\n"
-#~ msgid "Most likely the header is wrong, but I want you to decide.\n"
-#~ msgstr "Il est probable que l'en-tête soit faux, mais vous devez confirmer.\n"
-#~ msgid "The header for [%s] says the file is compressed. "
-#~ msgstr "L'en-tête de [%s] indique que le fichier est compressé."
-#~ msgid "The file does NOT appear to be compressed.\n"
-#~ msgstr "Le fichier ne semble PAS compressé.\n"
-#~ msgid "Header indicates %d row%s in the raster map, but the actual file format indicates %d row%s"
-#~ msgstr "L'en-tête indique %d ligne%s dans le fichier de cellule, mais le format de fichier actuel indique %d ligne%s"
-# c-format
-#~ msgid "Unable to write header for [%s]."
-#~ msgstr "Impossible d'écrire l'en-tête de [%s]"
-#~ msgid "Header for raster map [%s] updated."
-#~ msgstr "En-tête du fichier raster [%s] mis à jour"
-#~ msgid ""
-#~ "\n"
-#~ "hit RETURN to continue -->"
-#~ msgstr ""
-#~ "\n"
-#~ "Tapez ENTREE pour poursuivre -->"
-#~ msgid "Please enter the following information for [%s]:"
-#~ msgstr "Veuillez entrer l'information suivante pour [%s]:"
-#~ msgid "        Number of rows"
-#~ msgstr "\t\tNombre de lignes"
-#~ msgid "        Number of cols"
-#~ msgstr "\t\tNombre de colonnes"
-#~ msgid "        Floating point map"
-#~ msgstr "\t\tCouche de valeurs en virgule flottante"
-#, fuzzy
-#~ msgid "rows * cols * bytes per cell must be same as file size (%lu)"
-#~ msgstr "Lignes * colonnes * bits par cellule doivent être identique à la taille de fichier (%ld)"
-#~ msgid "If you need help figuring them out, just hit ESC"
-#~ msgstr "Si vous avez besoin de les connaître, tapez simplement ECHAP"
-#~ msgid "** Negative values not allowed!"
-#~ msgstr "** Les valeurs négatives ne sont pas autorisées!"
-#~ msgid "** Positive values only please!"
-#~ msgstr "** Veuillez vous servir uniquement de valeurs positives!"
-#~ msgid "Which raster map needs an updated history? "
-#~ msgstr "Quel fichier raster a besoin d'une mise à jour de l'historique?"
-# c-format
-#~ msgid "Raster file [%s] not found. Exiting."
-#~ msgstr "Fichier raster [%s] non trouvé. Sortie."
-# c-format
-#~ msgid "History file for [%s] updated."
-#~ msgstr "Fichier d'historique pour [%s] mis à jour"
-#~ msgid "History file for [%s] not updated."
-#~ msgstr "Fichier d'historique pour [%s] non mis à jour"
-#~ msgid ""
-#~ "\n"
-#~ "Hit RETURN to continue -->"
-#~ msgstr ""
-#~ "\n"
-#~ "Taper ENTREE pour poursuivre -->"
-#~ msgid "Edit header for [%s]? "
-#~ msgstr "Editer l'en-tête de [%s]?"
-#~ msgid ""
-#~ "\n"
-#~ "NOTE: [%s] is a reclass of [%s in %s]"
-#~ msgstr ""
-#~ "\n"
-#~ "NOTE: [%s] est une reclassification de [%s dans %s]"
-#~ msgid "Canceling from edit header."
-#~ msgstr "Annulation de l'édition de l'en-tête"
-#~ msgid "Edit the category file for [%s]? "
-#~ msgstr "Editer le fichier de catégorie de [%s]?"
-#~ msgid "Create/Update the color table for [%s]? "
-#~ msgstr "Créer/mettre à jour la table de couleurs de [%s]?"
-# c-format
-#~ msgid "Edit the history file for [%s]? "
-#~ msgstr "Editer l'historique de fichier de [%s]"
-#~ msgid ""
-#~ "\n"
-#~ "The null file for [%s] may indicate that some cells contain\n"
-#~ " no data. If the null file for [%s] doesn't exist, zero cells in\n"
-#~ " it are treated by GRASS application programs as no data."
-#~ msgstr ""
-#~ "\n"
-#~ "le fichier null de [%s] semble indiquer que certaines cellules ne contiennent\n"
-#~ " pas de données. Si le fichier null de [%s] n'existe pas, les cellules de valeur zéro\n"
-#~ " sont traitées par les programmes GRASS comme sans données."
-#~ msgid ""
-#~ "\n"
-#~ "Do you want to create/reset the null file for [%s] so that null cell values are considered valid data? "
-#~ msgstr ""
-#~ "\n"
-#~ "Voulez-vous créer/réinitialiser le fichir null de [%s] pour que les cellules de valeur null soient considérées comme des données valides? "
-#~ msgid ""
-#~ "\n"
-#~ "Do you want to delete the null file for [%s]\n"
-#~ "(all zero cells will then be considered no data)? "
-#~ msgstr ""
-#~ "\n"
-#~ "Voulez-vous effacer les fichiers null pour [%s]\n"
-#~ "(toutes les cellules null seront alors considérées comme sans données)? "
-#~ msgid "Which vector map needs updated categories?"
-#~ msgstr "Quel fichier vectoriel a besoin d'une mise à jour des catégories?"
-#~ msgid "Which raster map needs updated categories?"
-#~ msgstr "Quel fichier raster a besoin d'une mise à jour des catégories?"
-# c-format
-#, fuzzy
-#~ msgid "Category file for <%s> not updated"
-#~ msgstr "Fichier de catégorie pour [%s] non mis à jour"
-# c-format
-#, fuzzy
-#~ msgid "Category file for <%s> updated"
-#~ msgstr "Fichier de catégorie pour [%s] mis à jour"
-#~ msgid "Title, in quotes"
-#~ msgstr "Titre, entre guillemets"
-#~ msgid "Quiet - Do not show progress"
-#~ msgstr "Silencieux - ne pas montrer la progression"
-#~ msgid "Suppress single crossing error messages"
-#~ msgstr "Supprimer les messages d'erreur de croisement simple"
-# c-format
-#, fuzzy
-#~ msgid "Unable to find starting vector <%s> "
-#~ msgstr "Vecteur de départ introuvable %s"
-#, fuzzy
-#~ msgid "Raster output map <%s> not found (no start_points given)"
-#~ msgstr "Couche raster en sortie %s - introuvable (aucun point de départ spécifié)"
-#~ msgid "Memory allocation error on reading start points from raster map %s"
-#~ msgstr "Erreur d'allocation mémoire à la lecture des points de la couche raster %s"
-#~ msgid "Apply filter only to zero data values"
-#~ msgstr "Appliquer le filtre uniquement aux valeurs de données zéro"
-#~ msgid "Error reading '%s' map"
-#~ msgstr "Erreur de lecture de la couche '%s'"
-#~ msgid "G_put_raster_row failed (file system full?)"
-#~ msgstr "Echec de G_put_raster_row (système de fichier surchargé?)"
-#~ msgid "Run verbosly"
-#~ msgstr "Détails de l'exécution"
-#~ msgid "Run VERBOSELY"
-#, fuzzy
-#~ msgid "Vector map <%s> not found in the current mapset"
-#~ msgid "Cannot execute: %s"
-#~ msgstr "Impossible d'exécuter: %s"
-#, fuzzy
-#~ msgid "Cannot link table: %s"
-#~ msgstr "Impossible d'ouvrir la table <%s>"
-#, fuzzy
-#~ msgid "Cannot open new vector map <%s>"
-#~ msgstr "%s: impossible d'ouvrir le nouveau fichier vectoriel"
-#, fuzzy
-#~ msgid "Conversion of <%s> to vector map:"
-#~ msgstr ""
-#~ "\n"
-#~ "Conversion de %s en couche vectorielle:  "
-#~ msgid "Create 3D file"
-#~ msgstr "Crée fichier 3D"
-#, fuzzy
-#~ msgid "Do not print polyline info"
-#~ msgstr "Ne construit pas de topologie en mode points"
-#, fuzzy
-#~ msgid "Network input map <%s> not found"
-#~ msgid "ask_transform_coor():  Leaving session.. \n"
-#~ msgstr "ask_transform_coord():  Fermeture de la session.. \n"
-#~ msgid " Number of points that have been entered: %d\n"
-#~ msgstr "Nombre de points ayant été entrés: %d\n"
-#~ msgid "Please answer yes or no"
-#~ msgstr "Veuillez répondre par oui ou non"
-#, fuzzy
-#~ msgid "Hilight color for text"
-#~ msgstr "Couleur de mise en valeur du texte"
-#, fuzzy
-#~ msgid "Insufficent memory for allocation of data structure"
-#~ msgstr "Mémoire insuffisante pour allouer la structure de données."
-#~ msgid "imagery group"
-#~ msgid "imagery subgroup"
-#~ msgstr "sous-groupe d'images"
-#~ msgid "Output file extension (inputfile(s) + extension)"
-#~ msgstr "Extension du fichier de sortie (Fichiers en entrée + extension)"
-#~ msgid "name=%s\n"
-#~ msgstr "nom =%s\n"
-#~ msgid "mapset=%s\n"
-#~ msgstr "jeu de données =%s\n"
-#~ msgid "fullname=%s\n"
-#~ msgstr "nom complet =%s\n"
-#~ msgid "usage: %s file [prompt %%x %%y]\n"
-#~ msgstr "Utilisation :  fichier %s [prompt %%x %%y]\n"
-#, fuzzy
-#~ msgid "Illegal file name for real part: %s"
-#~ msgstr "%s : %s - nom de fichier illégal pour la partie réelle\n"
-#, fuzzy
-#~ msgid "Illegal file name for imaginary part: %s"
-#~ msgstr "%s : %s - nom de fichier illégale pour la partie imaginaire\n"
-# c-format
-#~ msgid "** Can't read signature file <%s> **"
-#~ msgstr "impossible de lire le fichier signature <%s> **"
-#~ msgid ""
-#~ "\n"
-#~ "<%s> -- illegal result signature file name"
-#~ msgstr ""
-#~ "\n"
-#~ "<%s> -- nom du fichier de signature résultat illégal"
-#, fuzzy
-#~ msgid "Illegal group name <%s>"
-#~ msgstr "Nom en sortie illégale : '%s'"
-#, fuzzy
-#~ msgid "Illegal signature file name <%s>"
-#~ msgstr "Attention : nom de fichier de signatures illégal <%s>"
-#, fuzzy
-#~ msgid "Raster file(s) for Elevation"
-#~ msgstr "Fichier(s) raster pour la Vue%d"
-#, fuzzy
-#~ msgid "Raster file(s) for Color"
-#~ msgid "Setting map window"
-#~ msgstr "Paramétrage de la fenêtre d'affichage de la couche"
-#~ msgid "Current window not settable"
-#~ msgstr "Impossible de configurer la fenêtre actuelle"
-#, fuzzy
-#~ msgid "Can't clear current graphics window"
-#~ msgstr "Impossible de créer la fenêtre graphique courante"
-#~ msgid "Cannot use current window"
-#~ msgstr "Impossible de créer la fenêtre courante"
-#~ msgid "Generates and displays simple graphics on map layers drawn in the active graphics monitor display frame."
-#~ msgstr "Génére et affiche des graphiques sur les couches de données affichées dans le moniteur actif."
-#~ msgid "Unix file containg graphing instructions, if not given reads from standard input"
-#~ msgstr "Le fichier Unix contient les instruction de dessin, s'il n'y en a pas partir des instructions de la ligne de commande"
-#~ msgid "Color to draw with, either a standard GRASS color or R:G:B triplet (separated by colons)"
-#~ msgstr "Couleur de traçage, soit une couleur GRASS standard soit un triplet R:G:B (séparé par le signe :)"
-#~ msgid "No current frame"
-#~ msgstr "Pas de cadre graphique actif"
-#~ msgid "Current frame not available"
-#~ msgstr "Cadre graphique courant non disponible"
-#, fuzzy
-#~ msgid "Error reading raster map"
-#~ msgstr "Erreur de lecture des cellules de données"
-#, fuzzy
-#~ msgid "Output profile data to file(s) with prefix 'name'"
-#~ msgstr "Nom du préfixe du fichier raster en sortie"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Use mouse to choose action"
-#, fuzzy
-#~ msgid "Error opening cell-file"
-#~ msgstr "Erreur à l'ouverture du fichier raster 3D"
-#, fuzzy
-#~ msgid "Error reading from cell-file"
-#~ msgstr "Erreur de lecture de la ligne de données"
-# c-format
-#, fuzzy
-#~ msgid "%s: Couldn't open raster <%s@%s>"
-#~ msgstr "impossible d'ouvrir <%s>"
-#~ msgid " Middle: toggle flash color\n"
-#~ msgstr " Milieu: couleur flash enclenchée\n"
-#~ msgid "Enable flashing (slower)"
-#~ msgstr "Permet le flashing (plus lent)"
-#~ msgid "No raster map exists in current window"
-#~ msgstr "Il n'y aucune couche raster dans la fenêtre active"
-#~ msgid "No current window"
-#~ msgstr "Pas de fenêtre active"
-#~ msgid "Current window not available"
-#~ msgstr "Fenêtre courante non disponible"
-#~ msgid "Getting screen window"
-#~ msgstr "Récupération de la fenêtre"
-#~ msgid "No current graphics window"
-#~ msgstr "Pas de fenêtre graphique active"
-#~ msgid "Current graphics window not available"
-#~ msgstr "Fenêtre graphique courante non disponible"
-#~ msgid "Setting graphics window"
-#~ msgstr "Paramétrage de la fenêtre graphique"
-#~ msgid "Can't set current graphics window"
-#~ msgid "Getting graphics window coordinates"
-#~ msgstr "Prendre les coordonnées de la fenêtre graphique"
-#~ msgid "value [%.0f,%.0f] out of range [0-100]"
-#~ msgstr "valeur [%.0f,%.0f] hors de l'intervalle [0-100]"
-#, fuzzy
-#~ msgid "Font name or pathname of TTF file"
-#~ msgstr "Nom du nouveau fichier TIFF"
-#, fuzzy
-#~ msgid "Setting release of FreeType"
-#~ msgstr ""
-#~ "\n"
-#~ "Paramétrage du nettoyage de FreeType\n"
-#~ msgid "Display number of colors"
-#~ msgstr "Afficher le nombre de couleurs"
-#~ msgid "Use mouse to size & place legend"
-#, fuzzy
-#~ msgid "Creates a list of commands for recreating screen graphics."
-#~ msgstr "Créer une liste de commande pour recréer les effets graphiques à l'écran"
-#~ msgid "Name of frame(s) to save"
-#~ msgstr "Nom du/des cadre(s) graphique(s) à sauvegarder"
-#~ msgid "Save current frame"
-#~ msgstr "Sauvegarder cadre graphique actif"
-#~ msgid "Save all the frames"
-#~ msgid "Only map objects without extra header and tailer"
-#~ msgstr "Seulement les objets de la carte sans compléments"
-#~ msgid "Don't add to list of vectors and commands in monitor (it won't be drawn if the monitor is refreshed)"
-#~ msgstr "Ne pas ajouter la liste des vecteurs dans le moniteur (cela ne sera pas afficher sile moniteur est rafraîchi"
-#~ msgid "No raster map exists in the current window"
-#~ msgstr "Il n'y a pas de couche raster dans la fenêtre active"
-#, fuzzy
-#~ msgid "Creates and displays a menu within the active frame on the graphics monitor."
-#~ msgstr "Afficher les données vectorielles GRASS dans le moniteur actif"
-#, fuzzy
-#~ msgid "Sets the color of the menu text"
-#~ msgstr "Fixe la couleur du texte de la légende"
-#, fuzzy
-#~ msgid "Menu must contain a title and at least one option"
-#~ msgstr "Vous devez sélectionner au moins un outil"
-#~ msgid "Draws text in the graphics monitor's active display frame using TrueType fonts."
-#~ msgstr "Affiche du texte dans le moniteur actif en utilisant des polices TrueType"
-#, fuzzy
-#~ msgid "Screen position (percentage, [0,0] is bottom left)"
-#~ msgstr "Les coordonnées sont en pourcentage du cadre graphique ([0,0] est en bas à gauche)"
-#~ msgid "Path to TrueType font (including file name)"
-#~ msgstr "Chemin pour la police TrueType (nom de fichier inclus)"
-#~ msgid "Height of letters (in percent of available frame height)"
-#~ msgstr "Hauteur des caractères (en pourcentage de la hauteur disponible du cadre graphique)"
-#~ msgid "Choose only one coordinate system for placement"
-#~ msgstr "Choisissez un seul système de coordonnées pour déterminer le placement"
-# c-format
-#~ msgid "Invalid font: %s"
-#~ msgstr "Police invalide : %s"
-#~ msgid "Unable to create text conversion context"
-#~ msgstr "Impossible de créer le contexte de conversion du texte"
-#~ msgid "Unable to write the temporary file"
-#~ msgstr "Impossible d'écrire le fichier temporaire"
-#~ msgid "No predefined font"
-#~ msgstr "Pas de police pré-définie"
-#~ msgid "%s: Unable to read font"
-#~ msgstr "%s : impossible de lire la police"
-#~ msgid "%s: Unable to read FreeType definition file; use the default"
-#~ msgid "%s: No FreeType definition file"
-#~ msgid "%s: Unable to read FreeType definition file"
-#~ msgstr "%s : impossible de lire le fichier FreeType de définition"
-#~ msgid "Don't add to list of rasters and commands in monitor"
-#~ msgstr "Ne pas ajouter à la liste des rasters du moniteur"
-#~ msgid "One mouse click only"
-#~ msgstr "Cliquer une seule fois"
-#~ msgid "Use mouse to interactively place scale"
-#~ msgstr "Utilisez la souris pour positionner l'échelle graphique de façon interactive"
-#, fuzzy
-#~ msgid "Use mouse to interactively place text"
-#, fuzzy
-#~ msgid " Left:    Place text here\n"
-#~ msgstr " Gauche:  qu'y a-t-il ici?\n"
-#, fuzzy
-#~ msgid " Right:   Quit\n"
-#~ msgstr " Droite: quitter\n"
-#~ msgid "Just redraw given maps using default colors"
-#~ msgstr "Redessiner simplement les couches concernées en utilisant les couleurs par défaut"
-#~ msgid "ERROR: can not get \"list\" items"
-#~ msgstr "ERREUR: impossible de récupérer les éléments de \"list\" "
-#~ msgid "-j flag forced"
-#~ msgstr "Drapeau -j forcé"
-#~ msgid "No map is displayed in GRASS monitor"
-#~ msgstr "ERREUR: Aucune couche n'est affichée dans le moniteur GRASS"
-#~ msgid "Interactively select route"
-#~ msgstr "Sélectionner de façon interactive l'itinéraire"
-#~ msgid "You must select more than one point"
-#~ msgstr "Vous devez sélectionner au moins un point"
-#~ msgid "You must select at least four points"
-#~ msgstr "Vous devez sélectionner au moins quatre points."
-#, fuzzy
-#~ msgid "No raster or vector map displayed"
-#~ msgstr "Nom de la couche raster d'aspect à afficher"
-#~ msgid "To establish and control use of a graphics display monitor."
-#~ msgstr "Pour gérer et contrôler l'utilisation des moniteurs graphiques d'affichage"
-#~ msgid "Name of graphics monitor to unlock"
-#~ msgstr "Nom du moniteur graphique à déverrouiller"
-#~ msgid "List all monitors (with current status)"
-#~ msgstr "Lister tous les moniteurs (actifs)"
-#~ msgid "Problem selecting %s. Will try once more"
-#~ msgstr "Problème pour sélectionner %s. Nouvelle tentative."
-#, fuzzy
-#~ msgid "No such monitor as <%s>"
-#~ msgstr "[%s] ne correspond pas à une couleur connue"
-#, fuzzy
-#~ msgid "Error - Locking mechanism failed"
-#~ msgstr "Erreur de fermeture du fichier VTK-ASCII"
-#, fuzzy
-#~ msgid "Error choosing frame [%s]\n"
-#~ msgstr "Erreur de lecture de l'intervalle pour [%s]"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Buttons:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Boutons:\n"
-#, fuzzy
-#~ msgid "Left:   Select frame\n"
-#, fuzzy
-#~ msgid "Right:  Accept frame\n"
-#~ msgstr "%s Quitter le menu\n"
-#, fuzzy
-#~ msgid "Manages display frames on the user's graphics monitor."
-#, fuzzy
-#~ msgid "Create a new frame"
-#, fuzzy
-#~ msgid "Select a frame"
-#~ msgstr "Sélectionner les données depuis une base de données."
-#, fuzzy
-#~ msgid "Print names of all frames"
-#~ msgstr "Affiche les totaux par surface"
-#, fuzzy
-#~ msgid "List map names displayed in GRASS monitor"
-#, fuzzy
-#~ msgid "Frame to be created/selected"
-#~ msgstr "Fichier vecteur à créer"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Mouse Buttons:"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Boutons:\n"
-#, fuzzy
-#~ msgid "Left:   Select From\n"
-#, fuzzy
-#~ msgid "Middle: Select To\n"
-#, fuzzy
-#~ msgid ""
-#~ "Right:  Quit\n"
-#~ "\n"
-#, fuzzy
-#~ msgid "Monitor: interactive command in redraw"
-#~ msgstr "Moniteur: commande interactive dans redraw\n"
-#, fuzzy
-#~ msgid "found %d visuals of type TrueColor"
-#~ msgstr "%d visuels de type TrueColor\n"
-#, fuzzy
-#~ msgid "searching for highest bit depth"
-#~ msgstr "recherche du plus haut bit de profondeur\n"
-#, fuzzy
-#~ msgid "selected %d bit depth"
-#~ msgstr "profondeur %d bit sélectionnée\n"
-#, fuzzy
-#~ msgid "using default visual which is %s"
-#~ msgstr "utilisation du visuel %s par défaut\n"
-#, fuzzy
-#~ msgid "Monitor: XGetWMName failed"
-#~ msgstr "Moniteur: XGetWMName a échoué\n"
-#, fuzzy
-#~ msgid "Monitor: XGetWMName: bad result"
-#~ msgstr "Moniteur: XGetWMName: mauvais résultat\n"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "WARNING!  A projection file already exists for this location\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "ATTENTION! Un fichier de projection existe déjà pour ce Secteur\n"
-#~ msgid "Would you still like to overwrite the current projection information "
-#~ msgstr "Voulez-vous vraiment écraser les informations de projection courante "
-#~ msgid "The projection information will not be updated."
-#~ msgstr "Les informations de projection ne seront pas mises à jour."
-#~ msgid "Raster map to zoom into"
-#~ msgstr "Couche raster sur laquelle zoomer"
-#~ msgid "Save the current region to region definition file"
-#~ msgstr "Sauvegarder la région courante dans le fichier de définition de la région"
-#, fuzzy
-#~ msgid "<%s> is an illegal region name"
-#~ msgstr "<%s> - nom de région illégal"
-#, fuzzy
-#~ msgid "No LatLong information for XY-Projection"
-#~ msgstr "L'option Geo-Grid n'est pas disponible en projection XY"
-#, fuzzy
-#~ msgid "Could not open input file <%s>."
-#~ msgstr "impossible d'ouvrir le fichier vecteur <%s>"
-#, fuzzy
-#~ msgid "No such monitor as '%s'"
-#, fuzzy
-#~ msgid "Error - No such monitor as '%s'"
-#~ msgid ""
-#~ "\a\n"
-#~ "** The following raster maps in subgroup [%s] do not exist:"
-#~ msgstr ""
-#~ "\a\n"
-#~ "** Les fichiers rasters dans le sous-groupe [%s] n'existent pas :"
-#~ msgid "       %s"
-#~ msgstr "\t\t%s"
-#~ msgid "Adding files to group [%s]"
-#~ msgstr "Ajouter les fichiers au groupe [%s]"
-#~ msgid "Adding files to subgroup [%s]"
-#~ msgstr "Ajouter les fichiers au sous-groupe [%s]"
-#~ msgid "Writing group REF"
-#~ msgstr "Ecriture du groupe REF"
-#~ msgid "Writing subgroup REF"
-#~ msgstr "Ecriture du sous-groupe REF"
-#~ msgid "Found file <%s@%s> in group."
-#~ msgstr "Fichier <%s@%s> trouvé dans le groupe"
-#~ msgid "Found file <%s@%s> in subgroup."
-#~ msgstr "Fichier <%s@%s> trouvé dans le sous-groupe"
-#~ msgid ""
-#~ "Projection of input dataset and current location appear to match.\n"
-#~ "Proceeding with import...\n"
-#~ msgstr ""
-#~ "La projection des données en entrée et le Secteur (location) courant semblent correspondre.\n"
-#~ "Poursuite de la procédure d'importation...\n"
-# c-format
-#, fuzzy
-#~ msgid "not found\n"
-#~ msgstr "%s non trouvé"
-#~ msgid "%s: percent complete: "
-#~ msgstr "%s : pourcentage effectué :"
-# c-format
-#~ msgid "Raster map not found."
-#~ msgstr "couche raster non trouvée"
-# c-format
-#~ msgid "%s: can't read range for [%s]"
-#~ msgstr "%s: impossible de lire l'intervalle pour [%s]"
-# c-format
-#, fuzzy
-#~ msgid "Raster file [%s] not found"
-#~ msgstr "Fichier raster <%s> non trouvé"
-# c-format
-#, fuzzy
-#~ msgid "It was not possible writing in <%s>."
-#~ msgstr "impossible de créer %s"
-#, fuzzy
-#~ msgid "\rDuplicate area centroids: %5d"
-#~ msgstr "Impossible de calculer le centroïde de la surface"
-#, fuzzy
-#~ msgid "Cannot create table: '%s'"
-#~ msgstr "Impossible de créer la table : %s"
-# c-format
-#, fuzzy
-#~ msgid "Unable to get category list <%s>, editing terminated"
-#~ msgstr "Impossible de lire <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Unable to delete layer/category [%d/%d] line %d"
-#~ msgstr "Impossible d'ouvrir le fichier ascii : [%s]"
-#, fuzzy
-#~ msgid "Unable to write line %d"
-#, fuzzy
-#~ msgid "Unknown query tool '%s'"
-#~ msgstr "Type inconnu"
-#, fuzzy
-#~ msgid "If 'list', 'file' and 'where' options are not specified, all features of given type and layer are extracted. Categories are not changed in that case."
-#~ msgstr "Sélectionne les objets vectoriels d'une couche vectorielle existante et crée une nouvelle couche contenant seulement les objets sélectionnés. Si les options 'list', 'file' et 'where' ne sont pas spécifiées, tous les objets d'un type et d'une couche données sont extraits,dans ce cas, les catégories sont inchangées."
-#, fuzzy
-#~ msgid "No layer database connection"
-#~ msgstr "Pas de connexion de la couche à la base de données"
-#, fuzzy
-#~ msgid "Load categories from the database (table = %s, db = %s)."
-#~ msgstr "Charger les catégories à partir de la base de données (table = %s, db = %s).\n"
-# c-format
-#, fuzzy
-#~ msgid "%d categories loaded from the database"
-#~ msgstr "%d catégories chargées depuis la base de données\n"
-#~ msgid "Cannot create layer"
-#~ msgstr "Impossible de créer la couche"
-#, fuzzy
-#~ msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
-#~ msgstr "Le fichier vecteur [%s] n'est pas disponible"
-#, fuzzy
-#~ msgid "Load values from vector to database. For uploaded/printed category values '-1' is used for 'no category' and 'null'/'-' if category cannot be found or multiple categories were found."
-#~ msgstr "Charge les valeurs de vecteurs dans la base de données. Parmi les valeurs de catégories chargées/affichées '-1est utilisé pour 'pas de catégorie' et 'null'/'-' si la catégorie n'a pas été trouvée ouque de multiples catégories ont été trouvées."
-#, fuzzy
-#~ msgid "Column type [%d] not supported"
-# c-format
-#, fuzzy
-#~ msgid "Cannot read map header for <%s>"
-#~ msgstr "Impossible de trouver l'en-tête de fichier %s"
-#, fuzzy
-#~ msgid "Cannot read category file for <%s>"
-#~ msgid "Print;Shell Script"
-#~ msgstr "Afficher;Shell Script"
-#~ msgid "Creating support files for [%s]."
-#~ msgstr "Créer des fichiers supports pour [%s]."
-# c-format
-#~ msgid "%s: <%s> raster map not found"
-#~ msgid "%s: <%s> raster map exists already"
-#~ msgstr "%s : <%s> le fichier raster existe déjà"
-#, fuzzy
-#~ msgid "Cannot read category file of raster map <%s>"
-# c-format
-#~ msgid "%s - map not found"
-# c-format
-#~ msgid "%s not found"
-#~ msgid "Could not access %s layer"
-#~ msgstr "Impossible d'accéder à la couche %s"
-# c-format
-#~ msgid "Vector map %s - not found"
-#~ msgstr "Couche vecteur %s introuvable"
-#~ msgid "Raster map containing elevation data"
-#~ msgstr "couche raster contenant les données d'altitude"
-#~ msgid "Raster map name for storing results"
-#~ msgstr "couche raster où écrire les résultats"
-#~ msgid "Height of the viewing location"
-#~ msgstr "Altitude du point d'observation"
-# c-format
-#~ msgid "%s: <%s> cellfile not found"
-#~ msgstr "%s: fichier de cellules <%s> non trouvé"
-# c-format
-#~ msgid "Cell file [%s] not found\n"
-#~ msgstr "Fichier de cellules [%s] non trouvé\n"
-# c-format
-#~ msgid "rgb cell map [%s] not found\n"
-#~ msgstr "fichier de cellules 3dview <%s> non trouvé\n"
-# c-format
-#, fuzzy
-#~ msgid "vector cell map [%s] not found\n"
-# c-format
-#, fuzzy
-#~ msgid "%s - %s not found"
-#~ msgid "can't read header for <%s> in <%s>"
-#~ msgstr "impossible de trouver les en-tête pour <%s> dans <%s>"
-#~ msgid "region <%s> not found"
-#~ msgstr "région <%s> non trouvée"
-#~ msgid "can't read region <%s> in <%s>"
-#~ msgstr "impossible de lire la région <%s> dans <%s>"
-#~ msgid "can't open 3dview file <%s> in <%s>"
-#~ msgstr "impossible d'ouvrir le fichier 3dview <%s> dans <%s>"
-#~ msgid "can't read 3dview file <%s> in <%s>"
-#~ msgstr "impossible de lire le fichier 3dview <%s> dans <%s>"
-#~ msgid "can't open vector map <%s> in <%s>"
-#~ msgstr "impossible d'ouvrir le fichier vecteur <%s> dans <%s>"
-#~ msgid "invalid region: %s"
-#~ msgstr "région incorrecte : %s"
-# c-format
-#, fuzzy
-#~ msgid "Creating support files"
-#~ msgstr "impossible d'ouvrir le fichier pour %s"
-#~ msgid "can't open %s"
-#~ msgstr "Impossible d'ouvrir %s"
-#~ msgid "%s file [%s] not found!"
-#~ msgstr "%s fichier [%s] non trouvé!"
-# c-format
-#, fuzzy
-#~ msgid "%s: %s - map not found"
-#~ msgstr "%s: %s - non trouvé"
-#, fuzzy
-#~ msgid "%s: unable to open %s"
-# c-format
-#~ msgid "%s - not found"
-# c-format
-#~ msgid "Cannot read %s"
-#~ msgstr "Impossible de lire %s"
-#~ msgid "map layer [%s] not legal for GRASS"
-#~ msgstr "la couche [%s] n'est pas légal pour GRASS"
-# c-format
-#~ msgid "[%s] map not found."
-#~ msgstr "[%s] couche non trouvée"
-# c-format
-#~ msgid "[%s] map not found"
-# c-format
-#~ msgid "elevation file [%s] not found"
-#~ msgstr "fichier d'altitude [%s] non trouvé"
-#~ msgid "min computed aspect %.4f  max computed aspect %.4f"
-#~ msgstr "aspect minimum calculé %.4f aspect maximum calculé %.4f"
-#~ msgid "min computed slope %.4f  max computed slope %.4f"
-#~ msgstr "pente minimum calculée %.4f pente maximum calculée %.4f"
-# c-format
-#, fuzzy
-#~ msgid "Cannot describe table <%s>"
-#~ msgstr "Impossible de décrire la table %s"
-#, fuzzy
-#~ msgid "Cannot insert values: %s"
-#, fuzzy
-#~ msgid "%s given an illegal number of points [%d]"
-#~ msgstr "%s donne un nombre illégal de sites [%d]"
-#, fuzzy
-#~ msgid "Unable to open database %s by driver %s"
-#~ msgstr "Impossible d'ouvrir la base de données %s avec le pilote %s"
-#, fuzzy
-#~ msgid "No DB connection settings defined. Set with db.connect"
-#~ msgstr "Pas de paramètres définis pour la connexion à la base de données. Faites-le avec db.connect"
-# c-format
-#~ msgid "Could not find input %s"
-#~ msgstr "Impossible de trouver l'entrée %s"
-#~ msgid "Could not open input"
-#~ msgstr "Impossible d'ouvrir l'entrée %s"
-#~ msgid "Could not open output"
-#~ msgstr "Impossible d'ouvrir la sortie"
-# c-format
-#~ msgid "Could not find input map <%s>"
-#~ msgstr "couche d'entrée introuvable <%s>"
-#~ msgid "Unkown item type in pad: %s"
-#~ msgstr "Type d'objet inconnu: %s"
-#, fuzzy
-#~ msgid "Can't read header for <%s> in <%s>"
-#, fuzzy
-#~ msgid "Can't read header for 3D raster <%s> in <%s>"
-#~ msgstr "impossible de trouver les en-tête de raster 3D <%s> dans <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Can't write region <%s>"
-#~ msgstr "impossible d'écrire la région <%s>"
-# c-format
-#~ msgid "<%s=%s> ** invalid input **"
-#~ msgstr "<%s=%s> ** valeur entrée invalide **"
-#~ msgid "Unable to read raster row."
-#~ msgstr "Impossible de lire la ligne raster."
-#~ msgid "Training map [%s] not found."
-#~ msgstr "couche d'apprentissage raster [%s] non trouvée"
-# c-format
-#~ msgid "%s map not found"
-#~ msgstr "%s couche non trouvée"
-#, fuzzy
-#~ msgid "Illegal file name: %s"
-#~ msgstr "nom de fichier illégal [%s]"
-#, fuzzy
-#~ msgid "Condition for update (everything after the 'where' sql statement; ex: cat=1 or col1/col2>1)"
-#~ msgstr "conditionnelle pour la mise à jour (tout ce qui se trouve après la clause 'where'; ex : cat=1 ou col1/col2>1)"
-#~ msgid "Cannot get layer info for vector map"
-#~ msgstr "Impossible de récupérer les informations de la couche pour cette couche vectorielle"
-# c-format
-#, fuzzy
-#~ msgid "Cannot open raster map <%s> in <%s>"
-#~ msgstr ""
-#~ "Impossible d'ouvrir le fichier de cellules pour [%s]\n"
-#~ "Impossible d'ouvrir la couche raster [%s]"
-#~ msgid "cover values extracted from the category labels of the cover map"
-#~ msgstr "valeurs de couverture extraites des étiquettes de catégorie de la couche de couverture"
-# c-format
-#~ msgid "%s: %s - raster map not found"
-#~ msgstr "%s : %s - couche raster non trouvée"
-#~ msgid "%s: %s - illegal name"
-#~ msgstr "%s: %s - nom illégal"
-#~ msgid "%s: ERROR reading category file for %s"
-#~ msgstr "%s: ERREUR de lecture du fichier de catégorie pour %s"
-# c-format
-#~ msgid "%s: %s - not found"
-#~ msgid "%s: %s - illegal units"
-#~ msgstr "%s: %s - unités illégales"
-# c-format
-#, fuzzy
-#~ msgid "%s: %s - can't open"
-#, fuzzy
-#~ msgid "Reading input map (%s)    ... "
-#, fuzzy
-#~ msgid "%s - ERROR reading %s"
-#~ msgstr "%s: ERREUR d'exécution de la commande %s"
-#, fuzzy
-#~ msgid "%s: %s - can't create raster map"
-#~ msgstr "%s: %s dans %s - impossible de lire le fichier de catégorie"
-# c-format
-#, fuzzy
-#~ msgid "Writing output map (%s)   ... "
-#~ msgstr "Ecriture de la couche raster en sortie %s..."
-#, fuzzy
-#~ msgid "%s - ERROR re-reading %s"
-#, fuzzy
-#~ msgid "%s - ERROR writing %s"
-#~ msgid "Reading raster map... "
-#~ msgstr "Lecteur du fichier raster..."
-# c-format
-#, fuzzy
-#~ msgid "Writing raster map... "
-#~ msgstr ""
-#~ "\n"
-#~ "Écriture du nouveau fichier raster..."
-#~ msgid "Category list: e.g. 1,3-8,13"
-#~ msgstr "Liste de catégories. Exemple : 1,3-8,13"
-#~ msgid "Output separator character (default: tab)"
-#~ msgstr "Caractère de séparation en sortie (par défaut : tabulation)"
-#, fuzzy
-#~ msgid "Cannot read category file of raster map <%s> in <%s>"
-# c-format
-#~ msgid "Cannot create raster map %s"
-#~ msgstr "Impossible de créer la couche raster %s"
-# c-format
-#~ msgid "Cannot create vector map %s"
-#~ msgstr "Impossible de créer la couche vecteur %s"
-# c-format
-#, fuzzy
-#~ msgid "Cannot create raster map '%s'"
-#, fuzzy
-#~ msgid "Number of raster rows to hold in memory"
-#~ msgstr "Nombre de lignes à garder en mémoire"
-#, fuzzy
-#~ msgid "Print raster map title only"
-#~ msgstr "Écrire uniquement le type de couche"
-#, fuzzy
-#~ msgid "unknown type: %d"
-#~ msgstr "Type inconnu: %c"
-# c-format
-#, fuzzy
-#~ msgid "Cannot open raster map [%s]"
-#~ msgstr ""
-#, fuzzy
-#~ msgid "Cannot get raster band."
-#~ msgstr "Impossible d'ouvrir la couche raster"
-#, fuzzy
-#~ msgid "Cannot allocate buffer for reading null values."
-#~ msgstr "Impossible de calculer le centroïde de la surface (problème d'allocation mémoire)"
-#, fuzzy
-#~ msgid "Cannot read GRASS raster."
-#~ msgstr "Impossible de lire la couche raster"
-#, fuzzy
-#~ msgid "Cannot get [%s] driver"
-#~ msgstr "Impossible de créer l'arborescence"
-#, fuzzy
-#~ msgid "Couldn't set geo transform."
-#~ msgstr "Ligne de début de fichier raster introuvable\n"
-#, fuzzy
-#~ msgid "Couldn't set projection."
-#~ msgstr "Projection source"
-# c-format
-#, fuzzy
-#~ msgid "Cannot export [%s] raster map."
-# c-format
-#, fuzzy
-#~ msgid "Cannot create [%s] raster map using [%s] driver."
-# c-format
-#, fuzzy
-#~ msgid "Cannot read header of raster map <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Cannot open TIFF file <%s>"
-#~ msgstr "Impossible d'ouvrir le fichier %s"
-#, fuzzy
-#~ msgid "Reading raster map"
-#~ msgid "Cannot open output map."
-#~ msgstr "Impossible d'ouvrir la couche de sortie"
-#, fuzzy
-#~ msgid "Illegal file name. Please try another."
-#, fuzzy
-#~ msgid "%s: can't open %s"
-#, fuzzy
-#~ msgid "memory allocation failure"
-#~ msgid "Can't find data map."
-#~ msgstr "Impossible de trouver la couche de données."
-#~ msgid "Can't find clump map."
-#~ msgstr "Impossible de trouver la couche de 'flaques'"
-#, fuzzy
-#~ msgid "Output terrain only vector map name"
-#~ msgstr "Nom de fichier de sortie pour la courbure tangentielle"
-#, fuzzy
-#~ msgid "Cannot open vector map <%s> at the topological level"
-#, fuzzy
-#~ msgid "Rebuilding topology ..."
-#, fuzzy
-#~ msgid "Removing duplicates ..."
-#~ msgstr "Suppression des centroïdes en doublons..."
-#, fuzzy
-#~ msgid "Attaching islands ..."
-#~ msgstr "Rattachement des catégories...\n"
-#, fuzzy
-#~ msgid "Attaching centroids ..."
-#, fuzzy
-#~ msgid "The number of lines in the input vector map is [%d]"
-#~ msgstr "Le nombre minimum de couches spécifiées en entrée est de deux."
-#~ msgid "Cannot open select cursor"
-#~ msgstr "Impossible d'ouvrir le curseur sélectionné"
-#, fuzzy
-#~ msgid "Cannot get layer info"
-#~ msgstr "Impossible de lire les informations de liaison à la base de données"
-# c-format
-#~ msgid "cell file [%s] not found"
-#~ msgstr "fichier de cellules 3dview <%s> non trouvé"
-# c-format
-#~ msgid "can't open raster map [%s]"
-#~ msgstr "impossible d'ouvrir le fichier de cellule [%s]"
-#, fuzzy
-#~ msgid "Cannot rewrite line %d"
-#~ msgstr "Impossible de créer l'index"
-#, fuzzy
-#~ msgid "Editing tool"
-#~ msgstr "Existant"
-#, fuzzy
-#~ msgid "For tool 'add', see also 'thresh' parameter"
-#~ msgstr "Ne pas copier la table (voir aussi le paramètre 'new')"
-# c-format
-#, fuzzy
-#~ msgid "Cannot copy line %d, editing terminated"
-#~ msgid "No layer database connection."
-# c-format
-#, fuzzy
-#~ msgid "Cannot snap lines %d,%d"
-#~ msgstr "Impossible d'ouvrir le fichier [%s]"
-#, fuzzy
-#~ msgid "%d lines modified"
-#~ msgstr "%-5d lignes mortes sautées\n"
-# c-format
-#, fuzzy
-#~ msgid "Could not open ASCII file <%s>"
-#~ msgid "Print vector map region only"
-#~ msgstr "Afficher seulement la région de la couche vecteur"
-#, fuzzy
-#~ msgid "Cannot get layer info for vector map <%s>"
-#~ msgid "Cannot select attribute."
-#~ msgstr "Impossible de sélectionner des données dans la table attributaire"
-#, fuzzy
-#~ msgid "Creating vector grid..."
-#~ msgstr "Écriture du nouveau fichier cats..."
-# c-format
-#, fuzzy
-#~ msgid "Could not find vector map <%s> in current mapset"
-#~ msgstr "Fichier vecteur introuvable : %s"
-# c-format
-#, fuzzy
-#~ msgid "Could not find input map <%s>."
-# c-format
-#, fuzzy
-#~ msgid "[%d] features written"
-#~ msgstr "%d points  écrits dans la couche vecteur"
-#, fuzzy
-#~ msgid "Parameter <%s> not set"
-#~ msgstr "incidout demande de fixer le paramètre d'heure"
-#, fuzzy
-#~ msgid "Input map containing lines"
-#~ msgstr "Couche en entrée contenant les lignes"
-#, fuzzy
-#~ msgid "Output map where segments will be written"
-#~ msgstr "Couche en sortie où les points seront écrits"
-#~ msgid "Cannot get layer information for vector map"
-#~ msgstr "Impossible de trouver les informations sur la couche vectorielle"
-# c-format
-#~ msgid "<%s> cellfile not found"
-#~ msgstr "fichier de cellules <%s> non trouvé"
-#~ msgid "No table."
-#~ msgstr "Pas de table."
-#~ msgid "Can't read raster"
-#~ msgid "driver name"
-#~ msgstr "nom du pilote (driver)"
-#~ msgid "Driver name"
-#~ msgstr "Nom du pilote (driver)"
-#~ msgid "Cannot list databases."
-#~ msgstr "Impossible de lister les bases de données."
-#~ msgid "Table name, select all from this table"
-#~ msgstr "Nom de table, tout sélectionner dans cette table"
-#~ msgid "output field separator"
-#~ msgstr "caractère de séparation de champs en sortie"
-#~ msgid "output vertical record separator"
-#~ msgstr "caractère de séparation vertical d'enregistrements en sortie"
-#~ msgid "null value indicator"
-#~ msgstr "indicateur de valeur vide ('null')"
-#~ msgid "do not include column names in output"
-#~ msgstr "ne pas inclure de nom de colonnes en sortie"
-#~ msgid "vertical output (instead of horizontal)"
-#~ msgstr "sortie verticale (à la place d'horizontale)"
-# c-format
-#~ msgid "Cannot find mapset for %s"
-#~ msgstr "Impossible de trouver le jeu de données (mapset) de %s"
-# c-format
-#~ msgid "Cannot open File %s"
-# c-format
-#~ msgid "Not able to open file for [%s]"
-#~ msgstr "Impossible d'ouvrir le fichier de cellules pour [%s]"
-#~ msgid "Label file [%s] not available"
-#~ msgstr "Fichier d'étiquette [%s] non disponible"
-# c-format
-#~ msgid "Can't open label file [%s]"
-#~ msgstr "impossible d'ouvrir le fichier d'étiquettes pour %s"
-#, fuzzy
-#~ msgid "unable to open [%s] in [%s]"
-#~ msgstr "Impossible d'ouvrir la couche raster [%s] dans [%s]"
-#, fuzzy
-#~ msgid "warning: unable to open [%s] in [%s]"
-#~ msgid "Unable to open raster map [%s] in [%s]"
-# c-format
-#, fuzzy
-#~ msgid "Unable to find input cell map '%s'"
-#~ msgstr "Impossible d'ouvrir la couche raster <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Unable to create raster map [%s]"
-#~ msgstr "Impossible de créer la couche raster [%s]"
-# c-format
-#~ msgid "Unable to create output <%s>"
-#~ msgstr "impossible de créer la sortie <%s>"
-# c-format
-#~ msgid "Input file [%s] not found."
-#~ msgstr "Le fichier en entrée [%s] n'a pas été trouvé."
-# c-format
-#~ msgid "Unable to open output file <%s>."
-#~ msgstr "impossible d'ouvrir le fichier en sortie <%s>"
-#~ msgid "Multiplier for ascii data"
-#~ msgstr "Multiplicateur pour les données ASCII"
-# c-format
-#, fuzzy
-#~ msgid "Could not open temporary file: [%s]"
-# c-format
-#, fuzzy
-#~ msgid "unable to create raster"
-#~ msgstr "impossible de créer raster\n"
-# c-format
-#, fuzzy
-#~ msgid "Unable to create output raster map <%s>"
-#~ msgstr "Impossible de créer la couche raster <%s>"
-# c-format
-#, fuzzy
-#~ msgid "%s: Unable to find raster map <%s>"
-#, fuzzy
-#~ msgid "%s: Unable to open raster map <%s> in mapset <%s>"
-# c-format
-#, fuzzy
-#~ msgid "%s:  Unable to open output raster map <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Vector <%s> could not be opened"
-#, fuzzy
-#~ msgid "No db connection for driver <%s> defined. Run db.connect."
-#~ msgstr "Pas de connexion définie pour le pilote <%s>. Exécutez db.connect"
-#~ msgid "Table name"
-#~ msgstr "Nom de la table"
-#~ msgid ""
-#~ "Print current map connection parameters and exit (shell script style)\n"
-#~ "\tformat:  layer[/layer name] table key database driver"
-#~ msgstr ""
-#~ "Affiche les paramètres de connexion courants et quitte (style script shell)\n"
-#~ "\tformat:  couche[/nom de la couche] Table Clef primaire Base de données PilotePilote"
-#~ msgid "z column name"
-#~ msgstr "Nom de la colonne z"
-#, fuzzy
-#~ msgid "Cannot drop table: %s"
-#, fuzzy
-#~ msgid "Cannot open labels <%s>"
-#, fuzzy
-#~ msgid "Cannot fetch data from table"
-#~ msgstr "Impossible de sélectionner des données dans la table"
-#, fuzzy
-#~ msgid ""
-#~ "OGR output datasource name. For example:\n"
-#~ "\t\tESRI Shapefile: filename or directory for storage\n"
-#~ "\t\tMapInfo File: filename or directory for storage"
-#~ msgstr ""
-#~ "nom de la source de données OGR. Exemples\n"
-#~ "\t\t Shapefile ESRI : répertoire contenant des shapefiles\n"
-#~ "\t\tFichier MapInfo : répertoire contenant des fichiers mapinfo"
-# c-format
-#, fuzzy
-#~ msgid "Querying input '%s' ... "
-#~ msgstr "Lecture du fichier %s..."
-#, fuzzy
-#~ msgid "Copying %s input lines ... "
-#~ msgstr "Vérification des points vecteurs..."
-#, fuzzy
-#~ msgid "Cannot create table <%s>"
-# c-format
-#~ msgid "no record for cat = %d"
-#~ msgstr "Aucun enregistrement pour cat = %d"
-#~ msgid "cannot insert row: %s"
-#~ msgstr "Impossible d'insérer une nouvelle ligne : %s"
-# c-format
-#, fuzzy
-#~ msgid "Cannot find line of cat %d"
-#~ msgstr "couche vectorielle d'entrée introuvable [%s]"
-# c-format
-#, fuzzy
-#~ msgid "Unalbe to open vector map <%s>"
-#~ msgstr "Impossible d'ouvrir la couche vecteur [%s]"
-# c-format
-#, fuzzy
-#~ msgid "Database connection not defined for layer [%d]. Use v.db.connect first"
-#~ msgstr "La connexion à la base de données n'a pas été définie pour la couche <%d>. Utilisez d'abord v.db.connect."
-#, fuzzy
-#~ msgid "Transforms a vector map via a set of tie points."
-#~ msgstr "Transforme une couche vectorielle d'un système de coordonnées vers un autre système de coordonnées."
-#, fuzzy
-#~ msgid "ASCII file holding transform coordinates (if not given transformation options [xshift, yshift, zshift, xscale, yscale, zscale, zrot] will be used instead)"
-#~ msgstr "A la place des points, utilisez les options de transformation (xshift, yshift, zshift, xscale, yscale, zscale, zrot)"
-#, fuzzy
-#~ msgid "Raster map <%s>] not found"
-#~ msgid "Cannot start driver '%s'."
-#~ msgstr "Impossible de lancer le pilote '%s'."
-# c-format
-#~ msgid "Cannot start driver <%s>."
-#~ msgid "[%s] is an illegal name"
-#~ msgstr "[%s] n'est pas un nom légal"
-# c-format
-#~ msgid "Cannot write to <%s>"
-#~ msgstr "Impossible d'écrire dans : %s"
-#~ msgid "Not able to open cellfile for [%s]"
-#~ msgid "Not able to find cellfile [%s]"
-# c-format
-#~ msgid "Raster map [%s] not available"
-#~ msgstr "La couche raster [%s] n'est pas disponible"
-# c-format
-#~ msgid "Raster file [%s] not available"
-#~ msgstr "Fichier(s) raster [%s] non disponible"
-# c-format
-#~ msgid "Raster map [%s] not found"
-#~ msgstr "Couche raster [%s] non trouvée"
-# c-format
-#~ msgid "Unable to open raster map [%s]"
-#~ msgstr "Impossible d'ouvrir la couche raster [%s]"
-#~ msgid "Vector file [%s] not available"
-# c-format
-#~ msgid "Cannot open driver %s"
-#~ msgstr "Impossible d'utiliser le pilote %s"
-#, fuzzy
-#~ msgid "<%s> illegal name"
-#~ msgstr "%s: <%s> nom illégal"
-#~ msgid "Out of Memory!\n"
-#~ msgstr "Mémoire insuffisante!\n"
-#~ msgid "%s: %s - Unable to open the input raster map\n"
-#~ msgstr "%s: %s - impossible d'ouvrir la couche raster en entrée\n"
-#~ msgid "Insufficent memory for allocation of data sturcture"
-#~ msgstr "Mémoire insuffisante pour l'allocation de la structure de données"
-#~ msgid "%s: %s - illegal name for output raster map."
-#~ msgstr "%s: %s - nom illégal de la couche raster en sortie"
-#~ msgid "Insufficent memory for allocation of data structure."
-#, fuzzy
-#~ msgid "Exports GRASS raster data into various formats (requires GDAL)."
-#~ msgstr "Exporte un raster GRASS en différents formats (requiert GDAL)"
-#~ msgid "Couldn't find raster map %s"
-# c-format
-#~ msgid "%s: <%s> not found"
-#~ msgstr "%s: <%s> non trouvé"
-#~ msgid "%s: <%s> illegal name"
-# c-format
-#~ msgid "%s: Cannot open <%s>"
-#~ msgstr "%s: Impossible d'ouvrir <%s>"
-#~ msgid "CREATING SUPPORT FILES ..."
-#~ msgstr "CREATION DE FICHIERS DE SUPPORT..."
-#~ msgid "<%s> is not a valid GRASS map name"
-#~ msgstr "<%s> n'est pas un nom valide pour une couche GRASS"
-# c-format
-#~ msgid "Cannot find %s"
-#~ msgstr "Impossible d'ouvrir la base de données %s"
-#~ msgid "could not read range file"
-#~ msgstr "Impossible de lire le fichier d'intervalle"
-#~ msgid "OUT OF MEMORY !!!\n"
-#~ msgstr "MEMOIRE INSUFFISANTE !!!\n"
-# c-format
-#~ msgid "Unable to create raster map [%s]."
-#, fuzzy
-#~ msgid "Filtering [%s] in [%s]"
-# c-format
-#, fuzzy
-#~ msgid "Open raster map %s in %s = %d"
-#~ msgstr "Ouvrir le fichier raster 3D %s"
-# c-format
-#, fuzzy
-#~ msgid "Swap temp files"
-#~ msgstr "Impossible d'ouvrir le fichier temporaire %s"
-# c-format
-#, fuzzy
-#~ msgid "Writing [%s]"
-#~ msgstr "Écriture %s..."
-#, fuzzy
-#~ msgid "%s: illegal map name"
-#~ msgstr "%s - nom illégal"
-#, fuzzy
-#~ msgid "%s: <%s> illegal file name"
-# c-format
-#, fuzzy
-#~ msgid "can't open raster map <%s> in mapset %s"
-#~ msgstr "impossible d'ouvrir le fichier d'étiquettes <%s> dans le jeu de données <%s>"
-#~ msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
-#~ msgstr "Convertit une couche Raster GRASS en un fichier d'image PPM où la résolution est celle de la région actuelle."
-#~ msgid "Mapset of input map"
-#~ msgstr "Jeu de données (mapset) de la couche source"
-#, fuzzy
-#~ msgid "Checking location %s, mapset %s:"
-#, fuzzy
-#~ msgid "Input map [%s] in location [%s] in mapset [%s] not found."
-#~ msgstr "groupe [%s] ciblé dans le Secteur [%s], jeu de données [%s]\n"
-#, fuzzy
-#~ msgid "Error writing output map"
-#~ msgstr "Couche résultat en sortie"
-#, fuzzy
-#~ msgid "<%s> is illegal file name"
-#, fuzzy
-#~ msgid "[%s] is an illegal file name"
-# c-format
-#~ msgid "Can't open temp file [%s]"
-#~ msgstr "impossible d'ouvrir le fichier temporaire %s"
-#~ msgid "Names of existing raster maps"
-#~ msgstr "Noms de fichiers raster existants"
-#~ msgid "Unable to open input map <%s> in mapset <%s>"
-#~ msgstr "Impossible d'ouvrir la couche en entrée <%s> dans le jeu de données <%s>"
-#, fuzzy
-#~ msgid "%s - illegal name "
-#, fuzzy
-#~ msgid "Couldn't find raster map [%s]"
-# c-format
-#, fuzzy
-#~ msgid "%s in %s -can't open raster map"
-#~ msgstr "%s - impossible d'ouvrir le fichier raster"
-# c-format
-#, fuzzy
-#~ msgid "%s - can't create raster map"
-#~ msgstr "%s - impossible d'ouvrir le fichier raster cellhd"
-#~ msgid "%s=%s - illegal name"
-#~ msgstr "%s=%s - nom illégal"
-# c-format
-#~ msgid "%s: can't create %s"
-#~ msgstr "%s : Impossible de créer %s"
-#~ msgid "Normalized"
-#~ msgstr "Normalisé"
-# c-format
-#, fuzzy
-#~ msgid "Cell file [%s] not found"
-#~ msgid "Can't read current window parameters"
-#~ msgstr "Impossible de lire les paramètres de la fenêtre courante"
-#~ msgid "Error getting input null cells at row %d from %s"
-#~ msgstr "Erreur de récupération des cellules nulles en entrée à la ligne %d de %s"
-#~ msgid "[%s] file name not legal"
-#~ msgid "[%s] file name not legal\n"
-#~ msgstr "[%s] n'est pas un nom légal\n"
-#~ msgid "Requested 3d raster map not found <%s>"
-#~ msgstr "Le fichier raster G3D <%s> demandé n'a pas été trouvé"
-#, fuzzy
-#~ msgid "Could not open output map"
-#~ msgstr "Impossible d'ouvrir la couche en sortie\n"
-#~ msgid "unable to close output map"
-#~ msgstr "Impossible de fermer la couche de sortie"
-# c-format
-#, fuzzy
-#~ msgid "Cannot create output map [%s]"
-#~ msgstr "Impossible de créer la couche cible : [%s]"
-#, fuzzy
-#~ msgid "Database's name couldn't be read"
-#~ msgstr "La connexion à la base de données n'a pas été définie"
-#, fuzzy
-#~ msgid "Cannot open vector points map <%s>"
-#~ msgstr "Impossible d'ouvrir la couche vectorielle de centroïdes"
-# c-format
-#, fuzzy
-#~ msgid "Cannot create vector map <%s>"
-#, fuzzy
-#~ msgid "Interpolation: No database connection for driver <%s> defined. Run db.connect"
-#~ msgid "Vector file [%s] not available in search list"
-#~ msgstr "Le fichier vecteur [%s] n'est pas disponible dans la liste de recherche"
-#~ msgid "Cannot open database <%s>"
-#~ msgstr "Impossible d'ouvrir la base de données <%s>"
-#~ msgid "Cannot open table <%s>"
-#~ msgid ""
-#~ "OGR layer name. If not given, all available layers are imported. Examples:\n"
-#~ "\t\tESRI Shapefile: shapefile name\n"
-#~ "\t\tMapInfo File: mapinfo file name"
-#~ msgstr ""
-#~ "nom de la couche OGR. Si elle n'est pas spécifiée, toutes les couches disponibles sont importées. Exemples:\n"
-#~ "\t\tShapefile ESRI : nom du shapefile\n"
-#~ "\t\tFichier MapInfo : nom du fichier mapinfo"
-#~ msgid "The vector '%s' already exists."
-#~ msgstr "Le vecteur '%s' existe déjà."
-# c-format
-#~ msgid "Could not find input map '%s'."
-#~ msgstr "couche d'entrée '%s' introuvable "
-# c-format
-#~ msgid "Could not find network input map '%s'."
-#~ msgstr "couche réseau d'entrée '%s' introuvable "
-# c-format
-#~ msgid "error opening raster map [%s]."
-#~ msgstr "Erreur d'ouverture de la couche raster [%s]."
-#, fuzzy
-#~ msgid "Topology is not available"
-#~ msgstr "La couche '%s' n'est pas disponible"
-# c-format
-#~ msgid "Cannot describe table %s"
-#, fuzzy
-#~ msgid "Patching file <%s@%s>"
-#~ msgstr "\tFichier du collage (patch) %s"
-# c-format
-#, fuzzy
-#~ msgid "[%d] files patched"
-#, fuzzy
-#~ msgid "Column type  not supported"
-#~ msgstr "Type de colonne non géré"
-#~ msgid "Could not open vector map <%s>"
-#, fuzzy
-#~ msgid "Name of output raster map"
-#~ msgstr ""
-#~ "#-#-#-#-#  grassmods_fr.po (grassmods_fr)  #-#-#-#-#\n"
-#~ "Nom de la couche raster cible\n"
-#~ "Nom de la couche raster de sortie"
-#~ msgid "Done          "
-#~ msgstr "Terminé\t\t"
-# c-format
-#~ msgid "Database connection not defined for layer <%d>. Use v.db.connect first."
-#, fuzzy
-#~ msgid "Pass [%d] of [%d]:"
-#~ msgstr "classe %d (%d)\n"
-#~ msgid "Illegal output name: '%s'"
-#~ msgid "Could not close new 3d raster map"
-#~ msgstr "Impossible de fermer la nouvelle couche g3d"
-#~ msgid "%s: cellfile [%s] not found."
-#~ msgstr "%s: fichier de cellules [%s] non trouvé"
-#~ msgid "Unable to open cellfile [%s]."
-#~ msgid "Error reading wildcard."
-#~ msgstr "Erreur de lecture de la wildcard"
-#~ msgid "Sets the grid color, either a standard GRASS color or R:G:B triplet (separated by colons)"
-#~ msgstr "Fixe la couleur de la grille, soit une couleur GRASS standard, soit un triplet R:G:B(séparé par le signe :)"
-#~ msgid "Sets the border color, either a standard GRASS color or R:G:B triplet"
-#~ msgstr "Fixe la couleur de la bordure, soit une couleur GRASS standard soit un triplet R:G:B"
-#~ msgid "Border not yet implemented for LatLong locations: border not drawn."
-#~ msgstr "La bordure n'est pas encore implémentée dans les Secteurs latitude/longitude : la bordure n'est pas tracée"
-#~ msgid "Unable to open the temporary file."
-#~ msgstr "Impossible d'ouvrir le fichier temporaire"
-#~ msgid "Unable to open raster map [%s]."
-# c-format
-#~ msgid "Unable to find raster [%s]."
-#~ msgstr "Fichier raster introuvable [%s]"
-#~ msgid "use regular expression instead of wildcard"
-#~ msgstr "utiliser une expression régulière à la place d'une wildcard"
-#~ msgid "name for new raster map"
-#~ msgstr "Nom de la nouvelle couche raster"
-#~ msgid "Output GRASS image file"
-#~ msgstr "Fichier d'image GRASS en sortie"
-#~ msgid "name for new vector map (omit for display to stdout)"
-#~ msgstr "Nom de la nouvelle couche vecteur (ne rien mettre pour l'affichage sur stdout)"
-#~ msgid "Input vector map"
-#~ msgstr "couche vecteur en entrée"
-#~ msgid "%s: ERROR can't open tempfile"
-#~ msgstr "%s: ERREUR impossible d'ouvrir le fichier temporaire"
-# c-format
-#, fuzzy
-#~ msgid "unable to find raster map [%s]"
-#, fuzzy
-#~ msgid "Both \"-i\" AND \"color\" specified - ignoring color"
-#~ msgstr "L'une des options \"color\", \"rast\" OU \"rules\" DOIT être spécifiée!"
-#, fuzzy
-#~ msgid "Both \"-i\" AND \"rules\" specified - ignoring rules"
-#, fuzzy
-#~ msgid "Both \"-i\" AND \"raster\" specified - ignoring raster"
-#, fuzzy
-#~ msgid "Both options \"color\" AND \"raster\" specified - ignoring raster"
-#, fuzzy
-#~ msgid "Both options \"color\" AND \"rules\" specified - ignoring rules"
-#, fuzzy
-#~ msgid "Both options \"raster\" AND \"rules\" specified - ignoring raster"
-#~ msgid "<%s> raster map not found"
-#~ msgstr "<%s> fichier raster introuvable"
-# c-format
-#~ msgid "<%s> unable to open raster map"
-#~ msgstr "<%s> impossible d'ouvrir le fichier raster"
-# c-format
-#~ msgid "Cannot find vector map [%s]"
-# c-format
-#~ msgid "%s - can't open raster map"
-# c-format
-#~ msgid "Can't get row %d from raster map %s"
-#~ msgstr "Impossible d'accéder à la ligne %d de la couche raster %s"
-# c-format
-#~ msgid "%s - raster map not found"
-#~ msgid "string representing no data cell value"
-#~ msgstr "chaîne représentant les cellules sans données"
-#~ msgid "File name of classification result"
-#~ msgstr "Nom de fichier du résultat de la classification"
-#~ msgid "File name of reference classes"
-#~ msgstr "Nom de fichier des classes de référence"
-#~ msgid "wide report, 132 columns (default: 80)"
-#~ msgstr "rapport étendu, 132 colonnes (80 par défaut)"
-#~ msgid "quiet"
-#~ msgstr "silencieux"
-#, fuzzy
-#~ msgid "<%s> - illegal output file name"
-#~ msgstr "%s -- Nom du fichier de sortie illégal"
-# c-format
-#~ msgid "%s: <%s> reference map not found"
-#~ msgstr "%s: couche de référence <%s> introuvable"
-#~ msgid "Base raster map"
-#~ msgstr "couche raster de base"
-#~ msgid "Raster map that represents the elevation, used for the 3D information"
-#~ msgstr "La couche raster qui représente l'altitude, utilisée pour l'information 3D"
-#, fuzzy
-#~ msgid "Problem opening input file [%s]"
-#~ msgstr "Erreur d'ouverture du fichier d'affichage [%s]"
-# c-format
-#, fuzzy
-#~ msgid "Problem opening output file [%s]"
-#, fuzzy
-#~ msgid "can't write category file for <%s>"
-#, fuzzy
-#~ msgid "%s: can't open tempfile"
-# c-format
-#, fuzzy
-#~ msgid "Unable to read row %d in raster map [%s]"
-#~ msgid "Elevation map"
-#~ msgstr "couche d'altitude"
-#~ msgid "Output verbosely"
-# c-format
-#~ msgid "Can't open raster map %s"
-#~ msgstr "Impossible d'ouvrir le fichier raster %s"
-#~ msgid "CREATING SUPPORT FILES"
-#~ msgstr "CREATION DE FICHIERS DE SUPPORT"
-#~ msgid "ELEVATION PRODUCTS for mapset [%s] in [%s]"
-#~ msgstr "ALTITUDE pour le jeu de données [%s] dans [%s]"
-# c-format
-#, fuzzy
-#~ msgid "It could not be find input map <%s>"
-# c-format
-#, fuzzy
-#~ msgid "It could not be found input map <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Cannot find input map <%s>"
-#, fuzzy
-#~ msgid "Input vector map <%s> not found."
-#~ msgstr "Le vecteur en entrée n'a pas été trouvé."
-#~ msgid "Category ranges: e.g. 1,3-8,13"
-#~ msgstr "Intervalle de catégories. Exemple : 1,3-8,13"
-#~ msgid "Writing attributes ...\n"
-#~ msgstr "Écriture des attributs...\n"
-# c-format
-#, fuzzy
-#~ msgid "Could not open ascii file <%s>"
-#, fuzzy
-#~ msgid "Could not open temp file <%s>"
-#, fuzzy
-#~ msgid "Vector map <%s> not fould"
-#, fuzzy
-#~ msgid "SVG output file"
-#~ msgstr "Fichier DXF source"
-# c-format
-#~ msgid "Could not find vector map %s"
-# c-format
-#, fuzzy
-#~ msgid "Unable to get row %d from <%s>"
-#~ msgid "Raster output file"
-#~ msgstr "couche raster de sortie"
-#, fuzzy
-#~ msgid "Pass #%d (of %d) ... "
-# c-format
-#, fuzzy
-#~ msgid "Writing raster map ... "
-#~ msgstr "Couche raster %i créée \n"
-#~ msgid "Keep existing color table"
-#~ msgstr "Garder la table de couleurs existante"
-#~ msgid "List rules"
-#~ msgstr "Lister les règles"
-#~ msgid "Verbose mode."
-#~ msgstr "Détails de l'exécution."
-# c-format
-#~ msgid " %d rows, %d cols."
-#~ msgstr "%d lignes, %d colonnes"
-#, fuzzy
-#~ msgid ""
-#~ "Integer cell type.\n"
-#~ "Writing"
-#~ msgstr ""
-#~ "Type de cellule entier.\n"
-#~ "Ecriture..."
-#, fuzzy
-#~ msgid ""
-#~ "Float cell type.\n"
-#~ "Writing"
-#~ msgstr ""
-#~ "Type de cellule flottant.\n"
-#~ "Ecriture..."
-#, fuzzy
-#~ msgid ""
-#~ "Double cell type.\n"
-#~ "Writing"
-#~ msgstr ""
-#~ "Type de cellule double.\n"
-#~ "Ecriture..."
-#, fuzzy
-#~ msgid "%s in %s - can't read header file"
-# c-format
-#, fuzzy
-#~ msgid "%s - unable to create raster map"
-#, fuzzy
-#~ msgid "%s - unable to create category file"
-#~ msgstr "Impossible d'écrire les fichiers temporaires"
-#~ msgid "verbose mode"
-#, fuzzy
-#~ msgid "Vector map with points for which to modify the attribute table"
-#~ msgstr "Nom de la couche de points vecteurs en entrée pour laquelle éditer la table attributaire"
-#, fuzzy
-#~ msgid "Layer of the vector for which to modify the attribute table"
-#~ msgstr "Nom de la couche de points vecteurs en entrée pour laquelle mettre à jour la table attributaire"
-#, fuzzy
-#~ msgid "Path to an output file"
-#~ msgstr "Impossible d'ouvrir le fichier de sortie"
-#~ msgid "Name of existing raster map to be displayed"
-#~ msgstr "Nom de la couche raster existante à afficher"
-#~ msgid "driver name:"
-#~ msgstr "nom du pilote :"
-#, fuzzy
-#~ msgid "ASCII file to be converted to binary vector map, if not given (or \"-\") reads from standard input"
-#~ msgstr "Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué prendreles paramètres saisis en ligne de commande"
-# c-format
-#~ msgid "could not find input map <%s>"
-# c-format
-#~ msgid "unable to open raster map [%s]"
-#~ msgstr "Impossible d'ouvrir le fichier de cellules [%s]"
-#~ msgid "cannot get layer info for vector map"
-#~ msgid "cannot open database %s by driver %s"
-#~ msgid "cannot select data from table"
-#~ msgid "cannot create table: %s"
-#~ msgstr "Impossible de créer la table: %s"
-#~ msgid "cannot create index"
-#~ msgid "cannot grant privileges on table %s"
-#~ msgstr "Impossible d'accorder des privilèges sur la table: %s"
-#~ msgid "column type  not supported"
-#~ msgid "Cannot find vector map"
-#~ msgstr "Impossible de trouver la couche vecteur"
-#~ msgid "Cannot find raster map"
-#~ msgstr "Impossible de trouver la couche raster"
-#~ msgid "Cannot open raster map"
-#~ msgid "Unknown keyword [%s] in vector head."
-#~ msgstr "Mot-clef inconnu [%s] dans l'en-tête de vecteur"
-#~ msgid "#%s"
-#~ msgstr "#%s"
-#, fuzzy
-#~ msgid "Error while reading cell map."
-#~ msgstr "Erreur de lecture de la couche raster en entrée"
-#, fuzzy
-#~ msgid "Error while writing new cell map."
-#~ msgstr "Erreur de suppression de l'ancienne couche MASK."
-#, fuzzy
-#~ msgid "Error in opening output file <%s>"
-#, fuzzy
-#~ msgid "Unable to find input cell map <%s>"
-#, fuzzy
-#~ msgid "Error in opening input file <%s>"
-#~ msgid "Unable to open cell man <%s> for input.\n"
-#~ msgstr "impossible d'ouvrir le fichier de cellule <%s> en entrée.\n"
-#~ msgid "Unable to open cell map <%s> for output.\n"
-#~ msgstr "Impossible d'ouvrir la couche de cellule <%s> en sortie.\n"
-#, fuzzy
-#~ msgid "Unable to write color table to raster [%s]"
-#~ msgstr "Impossible de lire la table de couleur %s"
-# c-format
-#, fuzzy
-#~ msgid "Cannot find map %s"
-# c-format
-#, fuzzy
-#~ msgid "Cannot open map %s"
-#~ msgid "Name of predefined rules file"
-#~ msgstr "Nom du fichier de règles prédéfinies"
-#, fuzzy
-#~ msgid "R G B value(s) out of range [0..255]: %d %d %d"
-#~ msgstr "** attention: la(es) valeur(s) R V B est(sont) en dehors des limites [0..255]: %d %d %d **\n"
-#, fuzzy
-#~ msgid "no such value"
-#~ msgstr "** attention: aucune valeur **\n"
-#, fuzzy
-#~ msgid "%s:line %d:%s"
-#~ msgstr "%s:ligne %d:%s\n"
-#, fuzzy
-#~ msgid "bad color specification"
-#~ msgstr "** mauvaise indication de couleur **\n"
-#, fuzzy
-#~ msgid "%s - unknown color"
-#~ msgstr "%s - couleur inconnue\n"
-#~ msgid "Valid colors are:\n"
-#~ msgstr "Les couleurs valides sont:\n"
-# c-format
-#, fuzzy
-#~ msgid "Unable to find base map <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Unable to find cover map <%s>"
-#, fuzzy
-#~ msgid "%s: reading category file for %s"
-# c-format
-#, fuzzy
-#~ msgid "%s: unable to open raster map [%s]"
-# c-format
-#, fuzzy
-#~ msgid "%s: unable to create raster map [%s]"
-# c-format
-#, fuzzy
-#~ msgid "%s: Unable to read raster map [%s]"
-# c-format
-#, fuzzy
-#~ msgid "%s: unable to open raster map <%s>"
-#, fuzzy
-#~ msgid "%s: Failed to read raster row %d"
-# c-format
-#~ msgid "Unable to find [%s]."
-#~ msgstr "impossible de trouver [%s]"
-#, fuzzy
-#~ msgid "Unable to read cats table for %s"
-# c-format
-#, fuzzy
-#~ msgid "Could not open raster <%s>"
-#~ msgstr "Impossible d'ouvrir la couche %s"
-#~ msgid "Screen coordinates to place the legend (as percentage)"
-#~ msgstr "Coordonnées de l'écran pour le placement de la légende (exprimées en pourcentage)"
-#~ msgid "Font name (not supported interactively, see also -l flag) or path to TrueType font (including file name)"
-#~ msgstr "Nom de police (non géré en mode interactif, voir aussi le drapeau -l) ou chemin vers une police TrueType (nom de fichier inclus)"
-# c-format
-#, fuzzy
-#~ msgid "%s: o_open_file: raster map %s not found"
-#~ msgstr "fichier de cellules slopein <%s> non trouvé"
-#, fuzzy
-#~ msgid "%s: o_open_file: could not open raster map %s in %s"
-# c-format
-#, fuzzy
-#~ msgid "No record for category for [%d]"
-#~ msgstr "Aucun enregistrement pour la ligne (cat = %d)"
-#, fuzzy
-#~ msgid "Error reading ASCII file <%s>"
-#~ msgstr "Erreur de lecture du fichier cats de <%s>"
-#, fuzzy
-#~ msgid "Error reading categories: <%s>"
-#, fuzzy
-#~ msgid "List of point coordinates. Required for add and move actions."
-#~ msgstr "Sélectionner le type: ligne ou surface"
-# c-format
-#, fuzzy
-#~ msgid "Could not find input vector '%s'"
-#~ msgstr "Couche d'entrée vecteur introuvable %s"
-#, fuzzy
-#~ msgid "Failed opening output vector map '%s'"
-#~ msgstr "Nom du fichier vecteur de sortie"
-#~ msgid "Do not create attribute table."
-#~ msgstr "Ne pas créer de table attributaire."
-#~ msgid "Could not find input %s\n"
-#~ msgstr "Entrée introuvable %s\n"
-#, fuzzy
-#~ msgid "Error reading ascii file: [%s]"
-#, fuzzy
-#~ msgid "List vector maps in input location and exit (a dummy value must be given for input)"
-#~ msgstr "Lister les couches raster de l'emplacement source et quitter"
-#~ msgid "Allows the user to interactively query a vector map layer at user-selected locations within the current geographic region"
-#~ msgstr "Permet à l'utilisateur de requêter de façon interactive une couche vectorielle sur des positions choisies par l'utilisateur dans la région géographique courante"
-#, fuzzy
-#~ msgid "| Tool                            | Threshold     |"
-#~ msgstr "                couche courante                  Nouvelle couche\n"
-#, fuzzy
-#~ msgid "| Break                           |  "
-#~ msgstr ""
-#~ "                          VÉRIFICATION DES RÉSIDUS DE LA COUCHE\n"
-#~ "\n"
-#, fuzzy
-#~ msgid "| Prune                           |  "
-#~ msgstr ""
-#~ "\n"
-#~ msgid "Patch complete. %d files patched."
-#~ msgstr "Collage achevé. Les fichiers %d sont collés."
-# c-format
-#~ msgid "%s: <%s> vector map not found"
-#~ msgstr "%s : couche vecteur <%s> introuvable"
-# c-format
-#, fuzzy
-#~ msgid "Vector <%s> could not be open"
-#~ msgstr "couche vecteur <%s> introuvable"
-#, fuzzy
-#~ msgid "Raster <%s> could not be open."
-#~ msgstr "raster <%s> non trouvé"
-#, fuzzy
-#~ msgid "CrossCorrelation()"
-#~ msgstr "Corrélation"
-#, fuzzy
-#~ msgid "Interpolation: Setting regions and boxes"
-#, fuzzy
-#~ msgid "Interpolation: nsply = %d"
-#~ msgstr "Méthode d'interpolation à utiliser"
-#, fuzzy
-#~ msgid "Interpolation: (%d,%d): Bicubic interpolation..."
-#~ msgstr "Nombre de points d'interpolation"
-# c-format
-#, fuzzy
-#~ msgid "%s: Dropping <s>"
-#, fuzzy
-#~ msgid "Interpolation was a success!"
-# c-format
-#, fuzzy
-#~ msgid "CrossCorrelation: %d points read in region. "
-#~ msgstr "%d points en dehors de la région courante"
-#, fuzzy
-#~ msgid "CrossCorrelation: It shouldn't take too long."
-#~ msgid "Subgroup [%s] doesn't have any files."
-#~ msgstr "Le sous-groupe [%s] ne comprend aucun fichier"
-#~ msgid "Subgroup [%s] only has 1 file."
-#~ msgstr "Le sous-groupe [%s] ne comprend qu'un seul fichier"
-#~ msgid "%s -- illegal output file name"
-#, fuzzy
-#~ msgid "Sorry, with method '%s' you have to define an output map."
-#~ msgstr ""
-#~ "\n"
-#~ "Désolé, vous devez choisir une couche en sortie."
-#~ msgid "%s: %s in %s - can't read category file"
-#, fuzzy
-#~ msgid "Maximum number of iteration"
-#~ msgstr "Nombre maximum d'itération"
-#~ msgid "Finished.\n"
-#~ msgstr "Terminé.\n"
-# c-format
-#~ msgid "Existing raster map name"
-#~ msgstr "Le nom du fichier raster existe déjà"
-# c-format
-#~ msgid "%s - can't read raster cellhd"
-#~ msgid "error reading cell data"
-#, fuzzy
-#~ msgid "Done!"
-#~ msgstr "Terminé"
-#, fuzzy
-#~ msgid "No line found."
-#~ msgstr "Rien n'a été trouvé.\n"
-#, fuzzy
-#~ msgid "Nothing Found."
-#, fuzzy
-#~ msgid "Do not build topology."
-# c-format
-#~ msgid "Could not open ascii file [%s]"
-#~ msgid "vector map to be created"
-#~ msgid "%s: Cannot open dxf file"
-#~ msgstr "%s: impossible d'ouvrir le fichier dxf"
-#, fuzzy
-#~ msgid "Conversion of [%s] to vector map ..."
-#~ msgstr ""
-#~ "\n"
-#~ msgid ""
-#~ "\n"
-#~ "Where %s is one of:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Où %s est un des:\n"
-#~ msgid "%s: - no such database %s\n"
-#~ msgstr "%s: - cette base de données n'existe pas %s\n"
-#~ msgid "must be even number of names"
-#~ msgstr "Les noms doivent être en nombre pair"
-# c-format
-#~ msgid "ERROR: <%s> not found\n"
-#~ msgstr "ERREUR: <%s> non trouvé\n"
-#~ msgid "ERROR: <%s> illegal name\n"
-#~ msgstr "ERREUR: <%s> - nom illégal\n"
-# c-format
-#~ msgid "Cannot open toolbox: %s"
-#~ msgstr "Impossible d'ouvrir la boîte à outils %s"
-# c-format
-#~ msgid "Cannot open toolbox."
-#~ msgstr "Impossible d'ouvrir la boîte à outils."
-#~ msgid "Could not find input map <%s>\n"
-#~ msgstr "couche d'entrée introuvable <%s>\n"
-#~ msgid "'%s' has finished the transformation of the vectors.\n"
-#~ msgstr "'%s' a terminé la transformation des vecteurs.\n"
-#~ msgid ""
-#~ "                          CHECK MAP RESIDUALS\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ msgid "                Current Map                  New Map\n"
-#~ msgid " POINT      X coord    Y coord  |        X coord   Y coord    |      residuals\n"
-#~ msgstr " POINT      coord X   coordY |       coord X   coord Y    |      résidus\n"
-#~ msgid "  Residual mean average   : %f\n"
-#~ msgstr "  Moyenne résiduelle   : %f\n"
-#~ msgid "Vector map(s) -- source for composite"
-#~ msgstr "Couche(s) vectorielles -- source pour la composite"
-#~ msgid "Append files to existing file"
-#~ msgstr "Modifie les fichier par rapport à un fichier existant"
-# c-format
-#~ msgid "Vector map '%s' not found"
-#~ msgstr "Couche vecteur '%s' introuvable"
-#~ msgid "Input aspect file"
-#~ msgstr "Fichier d'aspect en entrée"
-#~ msgid "Input barrier file"
-#~ msgstr "Fichier source d'obstacles"
-#~ msgid "Quiet operation"
-#~ msgstr "Mode silencieux"
-#~ msgid "Display Reference Information"
-#~ msgstr "Afficher la position de référence"
-#~ msgid "Aspect file's resolution differs from                        current region resolution"
-#~ msgstr "Résolution de la couche en entrée ne correspond pas à la résolution de la région courante!"
-#, fuzzy
-#~ msgid ""
-#~ "Calculates Simpson's diversity index on a raster map.\n"
-#~ "Return -1 if all the cells in the area are null"
-#~ msgstr "Calcule un index de densité de patch sur un fichier raster, en utilisant un algorithme de voisinage quatre"
-#, fuzzy
-#~ msgid ""
-#~ "Calculates Shannon's diversity index on a raster map\n"
-#, fuzzy
-#~ msgid ""
-#~ "Calculates dominance's diversity index on a raster map\n"
-# c-format
-#~ msgid "%s\n"
-#~ msgstr "%s\n"
-#, fuzzy
-#~ msgid ""
-#~ "Calculates dominance's diversity index on a raster map.\n"
-#, fuzzy
-#~ msgid "ILLEGAL Resolution!"
-#~ msgstr "Résolution"
-#, fuzzy
-#~ msgid "output layer name"
-#~ msgstr "Nom de la couche de sortie"
-#~ msgid "Hit RETURN -->"
-#~ msgstr "Tapez ENTREE -->"
-#~ msgid ""
-#~ "\a\n"
-#~ "** The following raster maps in subgroup [%s] do not exist."
-#~ msgstr ""
-#~ "\a\n"
-#~ "** Les fichiers suivants du sous-groupe [%s] n'existent pas."
-#~ msgid "The subgroup must have at least 2 files to run %s."
-#~ msgstr "Le sous-groupe doit comprendre au moins 2 fichiers pour exécuter %s."
-#~ msgid ""
-#~ "\n"
-#~ "If you continue the mask will be removed."
-#~ msgstr ""
-#~ "\n"
-#~ "Si vous continuez, le masque sera supprimé."
-#~ msgid "Did not find input cell map."
-#~ msgstr "couche de cellules en entrée introuvable."
-#~ msgid "Imagery files subgroup"
-#~ msgstr "Sous-groupe de fichiers image"
-#~ msgid "Warning: illegal group name <%s>."
-#~ msgstr "Attention : nom de groupe illégal <%s>"
-#~ msgid "Warning: illegal output file name <%s>."
-#~ msgstr "Attention : nom de fichier de sortie illégal <%s>"
-#~ msgid "An output cell map name is required."
-#~ msgstr "Un nom de couche de cellule en sortie est requis."
-#~ msgid "The output cell map name can not be longer than 12 characters."
-#~ msgstr "Le nom de la couche de cellule en sortie ne peut dépasser 12 caractères."
-#~ msgid "L: from  M: to R: quit\n"
-#~ msgstr "L: depuis  M: vers R: quitter\n"
-#~ msgid "Category <%d>: Area fill color and background color are the same!"
-#~ msgstr "Catégories <%d>: la couleur de remplissage et la couleur de fond sont identiques!"
-#~ msgid "Category <%d>: Line color and background color are the same!"
-#~ msgstr "Catégorie <%d>: la couleur de ligne et la couleur de fond sont identiques!"
-#~ msgid "Line color and background color are the same!"
-#~ msgstr "La couleur des lignes et du fond est identique!"
-#~ msgid "Area fill color and background color are the same!"
-#~ msgstr "La couleur de remplissage des entités surfaciques et la couleur de fond sont identiques!"
-#~ msgid "datetime, datetime1/datetime2, or none"
-#~ msgstr "Date&heure, date&heure1/date&heure2, ou aucune"
-# c-format
-#, fuzzy
-#~ msgid "g3d_to_raster: Writing %i raster maps with rows %i cols."
-#~ msgstr "G3dToRaster (Raster 3D en raster) : écrire %i couches rasters de dimensions lignes %i colonnes"
-#~ msgid ""
-#~ "\n"
-#~ "Done\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Terminé\n"
-#~ msgid "Writing VTK VoxelData\n"
-#~ msgstr "Ecriture des données Voxel VTK\n"
-# c-format
-#, fuzzy
-#~ msgid "Open vector 3d raster map %s"
-# c-format
-#~ msgid "Open 3d raster map %s"
-#~ msgid ""
-#~ "OGR datasource name.\n"
-#~ "\t\tESRI Shapefile: directory containing shapefiles\n"
-#~ "\t\tMapInfo File: directory containing mapinfo files"
-#~ msgstr ""
-#~ "nom de la source de données OGR. \n"
-#~ msgid "Vector import complete"
-#~ msgstr "Importation vecteur complète"
-#, fuzzy
-#~ msgid "Required parameter <points> not set"
-#~ msgstr "signature : points hors du périmètre"
-#, fuzzy
-#~ msgid "ERROR: A line needs at least 2 points"
-#~ msgstr "Vous devez entrer au moins %d points."
-#, fuzzy
-#~ msgid "ERROR: An area needs at least 3 points"
-#, fuzzy
-#~ msgid "Unknown GIS formats"
-#~ msgstr "Format d'étiquette date&heure inconnu: "
-#, fuzzy
-#~ msgid "file type (ignored)"
-#~ msgstr "type de fichier"
-# c-format
-#, fuzzy
-#~ msgid "Unable to create raster map for [%s]"
-#~ msgstr "Impossible de créer le fichier de cellules pour [%s]"
-#, fuzzy
-#~ msgid "raster_to_g3d: Writing %i raster maps with rows %i cols."
-#~ msgstr "RasterToG3D(Raster vers Raster 3D) : créer %i couches rasters de dimensions lignes %i colonnes"
-#~ msgid "Writing g3d slice %i\n"
-#~ msgstr "Ecriture de la tranche raster %i à partir du raster 3D \n"
-#~ msgid "error opening 3d raster map"
-#~ msgstr "Échec à l'ouverture du fichier raster 3D"
-#~ msgid "Done\n"
-#~ msgstr "Terminé\n"
-#~ msgid "Read fp map as integer (use map's quant rules"
-#~ msgstr "Lire les couches en nombres à virgule flottante comme étant en nombres entiers (utilise les règles de quantification de la couche)"
-#~ msgid "Name for the resulting raster map"
-#, fuzzy
-#~ msgid "Open Raster file %s in Mapset %s"
-#~ msgstr "Ouvrir le fichier raster %s dans le jeu de données (mapset) %s\n"
-#, fuzzy
-#~ msgid "elev_raster_to_g3d: Writing 3D raster map with depths %i rows %i cols %i and count %i."
-# c-format
-#, fuzzy
-#~ msgid "Open 3d raster map %s\n"
-#, fuzzy
-#~ msgid "Open elev raster map %s\n"
-#~ msgstr "Nom de la couche d'altitude résultante"
-# c-format
-#~ msgid "Could not open map %s\n"
-#~ msgstr "Impossible d'ouvrir la couche %s\n"
-#, fuzzy
-#~ msgid "Either -i flag and/or profile parameter must be used."
-#~ msgstr "Il faut utiliser soit le drapeau -i et/ou le paramètre itinéraire"
-#~ msgid "Bin raster map to be imported"
-#~ msgstr "Fichier binaire à importer"
-#~ msgid "Output partial derivatives instead"
-#~ msgstr "Sortie des dérivées partielles "
-#~ msgid "Region size is lower than minreg, nothing displayed.\n"
-#~ msgstr "La taille de la région est plus petite que minreg, rien n'a été affiché.\n"
-#~ msgid "Region size is greater than maxreg, nothing displayed.\n"
-#~ msgstr "La taille de la région est plus grande que maxreg, rien n'a été affiché.\n"
-#~ msgid "Maximum distance"
-#~ msgstr "Distance maximale"
-#~ msgid "Do not rebuild and store the topology at the end"
-#~ msgstr "Ne pas reconstruire et stocker la topologie à la fin"
-#~ msgid "Makes 3D trees from input point vector map"
-#~ msgstr "Construit des arbres 3D à partir du fichier source de vecteurs points"
-#~ msgid "Diameter of the tree crown in map units"
-#~ msgstr "Diamètre du feuillage de l'arbre en unités carte"
-#~ msgid "Height of tree trunk in meters"
-#~ msgstr "Hauteur du tronc d'arbre (en mètres)"
-#~ msgid "Name of the column with tree crown width"
-#~ msgstr "Nom de la colonne contenant la largeur du feuillage de l'arbre"
-#~ msgid "Representation of spruce in percent"
-#~ msgstr "Représentation des sapins en pourcentage"
-#~ msgid "Representation of fir in percent"
-#~ msgstr "Représentation des pins pignons en pourcentage"
-#~ msgid "Representation of pine in percent"
-#~ msgstr "Représentation des pins en pourcentage"
-#~ msgid "Representation of larch in percent"
-#~ msgstr "Représentation des mélèzes en pourcentage"
-#~ msgid "Representation of beech in percent"
-#~ msgstr "Représentation des hêtres en pourcentage"
-#~ msgid "Representation of oak in percent"
-#~ msgstr "Représentation des chênes en pourcentage"
-#~ msgid "Representation of douglas in percent"
-#~ msgstr "Représentation des pins douglas en pourcentage"
-#~ msgid "Representation of maple in percent"
-#~ msgstr "Représentation des érables en pourcentage"
-#~ msgid "Representation of alder in percent"
-#~ msgstr "Représentation des vernes/aulnes en pourcentage"
-#~ msgid "Vertical variability of tree heights [% of height]"
-#~ msgstr "Variabilité verticale des hauteurs d'arbres [% de hauteur]"
-#~ msgid "Horizontal variability of tree position in map units"
-#~ msgstr "Variabilité horizontale de la position des arbres en unités cartes"
-#~ msgid "Crown length [% of tree height]"
-#~ msgstr "Epaisseur du feuillage [en % de la hauteur de l'arbre]"
-#~ msgid "Total species representation is > 100"
-#~ msgstr "Le total de représentation des essences est > 100"
-#~ msgid "Total species representation is < 100"
-#~ msgstr "Le total de représentation des essences est < 100"
-#, fuzzy
-#~ msgid "Display active frame dimensions"
-#~ msgstr "Afficher le rectangle écran"
-#, fuzzy
-#~ msgid "Right: "
-#, fuzzy
-#~ msgid "%s Quit\n"
-#~ msgstr "Silencieux"
-#, fuzzy
-#~ msgid "output 3d raster map which will be filled with the 2D raster slices"
-#~ msgstr "Couche(s) raster 3D à convertir en tranches raster 2D"
-#, fuzzy
-#~ msgid "Quiet mode"
-#, fuzzy
-#~ msgid "3 raster maps (r,g,b) which are used to create rgb values [redmap,greenmap,bluemap]"
-#~ msgstr "3 couches rasters g3d (r,g,b) utilisées pour créer les valeurs RGB [redmap,greenmap,bluemap]"
-# c-format
-#, fuzzy
-#~ msgid "Running: %s"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "SECTION %d: Closing Maps."
-#~ msgstr ""
-#~ "\n"
-#~ "SECTION %d: Fermeture des couches."
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "SECTION 3: Accumulating Surface Flow.       Percent complete: "
-#~ msgstr ""
-#~ "\n"
-#~ "SECTION 3: Accumulation du courant de surface.       Achevé (pourcentage):"
-#, fuzzy
-#~ msgid "CREATING SUPPORT FILES FOR %s"
-#, fuzzy
-#~ msgid "%s[%d]: No raster map specified."
-#~ msgstr "Aucune couche de données spécifiée"
-#, fuzzy
-#~ msgid "Width of stream (in meters)"
-#~ msgstr "Profondeur additionnelle du cours d'eau"
-#, fuzzy
-#~ msgid "done."
-#~ msgstr "Terminé."
-#, fuzzy
-#~ msgid "Query column name"
-#~ msgstr "Nom de la colonne y"
-#, fuzzy
-#~ msgid "convert all old GRASS < V5.7 sites maps to vector maps in current mapset"
-#~ msgstr "convertit toutes les anciennes couches vectorielles GRASS (versions antérieures à 5.7) du jeu de données courant au format récent"
-#, fuzzy
-#~ msgid "name for new binary vector map (omit for display to stdout)"
-#, fuzzy
-#~ msgid "any,grid3,3d raster"
-#, fuzzy
-#~ msgid "Name for G3d raster map"
-#~ msgstr "Nom de la couche raster"
-#, fuzzy
-#~ msgid "No output maps"
-#~ msgstr "Aucune couche créée en sortie"
-#, fuzzy
-#~ msgid "Error opening 3d raster map <%s>. No Vector Data will be created."
-#~ msgstr ""
-#~ "Erreur à l'ouverture de la couche g3d <%s>\n"
-#~ "Erreur à l'ouverture du fichier raster 3D <%s>"
-#, fuzzy
-#~ msgid "Wrong rgb map values! Values should in between 0 and 255!\n"
-#~ msgstr "Valeurs de couches erronnées! Les valeurs doivent être comprises entre 0 et 255!\n"
-#, fuzzy
-#~ msgid "The resolution of raster and raster3d maps should be equal!"
-#~ msgstr "Nom de la couche raster dont on veut rééchelonner les valeurs"
-#, fuzzy
-#~ msgid "Feature type. Possible combinations of more types: point,centroid or line,boundary."
-#~ msgstr "Type d'objet. Le mélange de types n'est pas géré par tous les format."
-#, fuzzy
-#~ msgid "Line width of highlight color (only for ps.map output)"
-#~ msgstr "Taille de la bordure (seulement pour la sortie ps.map)"
-#, fuzzy
-#~ msgid "unknown interpolation method"
-#, fuzzy
-#~ msgid "The map E and N grid coordinates of a starting point"
-#~ msgstr "Les coordonnées XY de la grille des foyers initiaux"
-#, fuzzy
-#~ msgid "Name of existing raster map."
-#~ msgstr ""
-#~ "Nom du fichier raster existant\n"
-#~ "Nom de la couche raster existante"
-#, fuzzy
-#~ msgid "Name of output map"
-#, fuzzy
-#~ msgid "Name of existing input raster map"
-#~ msgstr ""
-#, fuzzy
-#~ msgid "Wrong RGB maps. RGB output not added!"
-#~ msgstr "Couches RGB erronées. Les couches doivent être de même type! La sortie RGB n'est pas créée!"
-#, fuzzy
-#~ msgid "cover raster map"
-#~ msgstr "couche raster de couverture"
-#, fuzzy
-#~ msgid "resultant raster map"
-#~ msgstr "couche raster résultante"
-#, fuzzy
-#~ msgid "(i)   Rectangular elevation map"
-#~ msgstr "(i) couche d'altitudes"
-#, fuzzy
-#~ msgid "Fill areas with random colors according to category number"
-#~ msgstr "Nom de la colonne contenant l'attribut w à interpoler"
-#, fuzzy
-#~ msgid "Done.\n"
-#, fuzzy
-#~ msgid "Zooming finished.\n"
-#, fuzzy
-#~ msgid "column '%s' : type text is stored as varchar(250) some data may be lost"
-#~ msgstr "colonne '%s' : type character varying enregistré comme varchar(250) des données peuvent être tronquées"
-#, fuzzy
-#~ msgid "Profile curvature"
-#~ msgstr "Nom de fichier de sortie pour la courbure du profil"
-#, fuzzy
-#~ msgid "Tangential curvature"
-# c-format
-#~ msgid "slopein raster map <%s> not found"
-# c-format
-#, fuzzy
-#~ msgid "%s: Error reading from raster map <%s> in mapset <%s>"
-#~ msgstr "Erreur de lecture du fichier raster [%s]"
-# c-format
-#, fuzzy
-#~ msgid "Base raster map <%s> not found"
-#~ msgstr "fichier de cellules aspin <%s> non trouvé"
-#, fuzzy
-#~ msgid "Color table for <%s> updated"
-#~ msgstr "Table de couleur de [%s] mise à jour"
-# c-format
-#~ msgid "Error reading raster map [%s]."
-#~ msgid "        Number of bytes per cell"
-#~ msgstr "\t\tNombre de bits par cellule"
-#, fuzzy
-#~ msgid "Option <%s>: <%s> exists."
-# c-format
-#, fuzzy
-#~ msgid "No numerical attributes found. Skipping export"
-#, fuzzy
-#~ msgid "Error reading value of attribute '%s'"
-#, fuzzy
-#~ msgid "Illegal subgroup name <%s>"
-#~ msgstr "Attention : nom de sous-groupe illégal <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Invalid rendering method <%s>"
-#~ msgstr "Police invalide : %s"
-#, fuzzy
-#~ msgid "Displays the rhumbline joining two user-specified points, in the active frame on the user's graphics monitor."
-#~ msgstr "Superpose une grille dont le pas est spécifié par l'utilisateur dans le moniteuractif."
-#, fuzzy
-#~ msgid "display, export"
-#~ msgstr "Afficher l'index"
-#~ msgid "Name of PNG file"
-#~ msgstr "Nom du fichier PNG"
-#, fuzzy
-#~ msgid "Name for output file (do NOT add extension)"
-#~ msgstr "Nom du fichier en sortie (ne PAS ajouter l'extension)"
-#, fuzzy
-#~ msgid "Split the display into subframes."
-#~ msgstr "Entrer la couche raster à afficher dans le 1er cadre"
-#, fuzzy
-#~ msgid "Number of subframes"
-#~ msgstr "Nombre de cadres de l'animation"
-#, fuzzy
-#~ msgid "Data range of raster map <%s> is empty"
-#~ msgstr "L'intervalle va de %ld à %ld\n"
-#, fuzzy
-#~ msgid "raster, recode category"
-# c-format
-#, fuzzy
-#~ msgid "Unable to open rules file <%s>"
-#, fuzzy
-#~ msgid "Power 2 values: %d rows %d columns"
-#~ msgstr "2 valeurs : [%d] lignes [%d] colonnes."
-#, fuzzy
-#~ msgid "Writing data..."
-#~ msgstr "Écriture des données dans le fichier..."
-#, fuzzy
-#~ msgid "Bad format in camera file for group [%s]"
-#~ msgstr "Ajouter les fichiers au groupe [%s]"
-#, fuzzy
-#~ msgid "No photo points for group [%s]"
-#~ msgstr "%s : pas de données points trouvées"
-# c-format
-#, fuzzy
-#~ msgid "Unable to read raster header of <%s>"
-#~ msgstr "Impossible de lire les informations de l'en-tête de fichier [%s]"
-#, fuzzy
-#~ msgid "Name of camera reference file to use"
-#~ msgstr "Nom du nouveau fichier raster"
-#, fuzzy
-#~ msgid "Group [%s] in location [%s] mapset [%s] now has camera file [%s]"
-# c-format
-#, fuzzy
-#~ msgid "Target location [%s] not found\n"
-#, fuzzy
-#~ msgid "Mapset [%s] in target location [%s] - "
-# c-format
-#, fuzzy
-#~ msgid "Pre-selected group <%s> not found"
-#~ msgstr ""
-#~ "\n"
-#~ "groupe <%s> non trouvé"
-#, fuzzy
-#~ msgid "Enter imagery group for ortho-rectification"
-#~ msgstr "Nom du Secteur de destination du groupe d'images"
-#, fuzzy
-#~ msgid "Group [%s] contains no files"
-#~ msgstr "Le sous-groupe [%s] du groupe [%s] ne contient pas de fichier."
-#, fuzzy
-#~ msgid "Image Group [%s] not found"
-#~ msgstr "Groupe [%s] non trouvé"
-#, fuzzy
-#~ msgid "Interactively select or modify the imagery group target."
-#~ msgstr "Sélectionner de façon interactive l'itinéraire"
-#, fuzzy
-#~ msgid "No files in this group!"
-#~ msgstr "Fichier <%s@%s> trouvé dans le sous-groupe"
-#, fuzzy
-#~ msgid "Group [%s] targeted for location [%s], mapset [%s]"
-#, fuzzy
-#~ msgid "Short user prompt message"
-#~ msgstr "Afficher également le message de copyright"
-#~ msgid "Debugging output"
-#~ msgstr "Sortie de débogage"
-# c-format
-#~ msgid "creating support files for %s"
-#, fuzzy
-#~ msgid "Unable to connect line id %d to line %d"
-#~ msgstr "Ne pas afficher les codes de catégories"
-#, fuzzy
-#~ msgid "Recharge raster map in m^3/s"
-#~ msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
-#~ msgstr "Exporter une couche raster GRASS en fichier GRIDATB.FOR (TOPMODEL)"
-#~ msgid "Converts a raster map layer into a height-field file for POVRAY."
-#~ msgstr "Conertit une couche raster en fichier pour POVRAY"
-#, fuzzy
-#~ msgid "raster, map algebra"
-#~ msgid "Converts a raster map layer into an ASCII text file."
-#~ msgstr "Convertit une couche raster en fichier texte ASCII."
-# c-format
-#, fuzzy
-#~ msgid "Unable to find stop vector <%s>"
-#~ msgstr "Vecteur d'arrivée introuvable %s"
-#~ msgid "Update the statistics (histogram, range) for [%s]? "
-#~ msgstr "Mettre à jour les statistiques (histogramme, intervalle) pour [%s]?"
-# c-format
-#, fuzzy
-#~ msgid "Name of terrain raster map (DEM)"
-#~ msgstr "Couche raster de terrain (MNT)"
-#, fuzzy
-#~ msgid "Name for output raster map with lake"
-#~ msgstr ""
-#, fuzzy
-#~ msgid "Interpolating raster map <%s> (%d rows)... "
-#~ msgstr "Interpolation de la couche raster <%s>... ligne %d ..."
-#, fuzzy
-#~ msgid "raster, statistics"
-#~ msgstr "Statistiques de transition de classe."
-#~ msgid "Converts raster maps into the VTK-Ascii format"
-#~ msgstr "Convertit une couche raster au format VTK-Ascii"
-#, fuzzy
-#~ msgid "raster, terrain"
-#, fuzzy
-#~ msgid "Name of the water depth raster map [m]"
-#~ msgstr ""
-#~ "Nom du fichier raster source\n"
-#~ "Nom de la couche raster source"
-#, fuzzy
-#~ msgid "Name of the x-derivatives raster map [m/m]"
-#~ msgstr "Nom du fichier raster source"
-#, fuzzy
-#~ msgid "Name of the y-derivatives raster map [m/m]"
-#, fuzzy
-#~ msgid "Name of the detachment capacity coefficient raster map [s/m]"
-#~ msgstr "Couche raster du coefficient de rayonnement en plein ciel [-]"
-#, fuzzy
-#~ msgid "Name of the transport capacity coefficient raster map [s]"
-#~ msgstr "Nom de la couche raster source pour le coefficient d'albedo"
-#, fuzzy
-#~ msgid "Name of the critical shear stress raster map [Pa]"
-#, fuzzy
-#~ msgid "Name of the Mannings n raster map"
-#, fuzzy
-#~ msgid "Name of the Mannings n value"
-#, fuzzy
-#~ msgid "Output transport capacity raster map [kg/ms]"
-#~ msgstr "Nom du fichier raster en sortie pour l'aspect"
-#, fuzzy
-#~ msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
-#~ msgstr "Nom de fichier de sortie pour la section croisée"
-#, fuzzy
-#~ msgid "Output sediment concentration raster map [particle/m3]"
-#~ msgstr "couche raster de direction à créer"
-#, fuzzy
-#~ msgid "Output sediment flux raster map [kg/ms]"
-#, fuzzy
-#~ msgid "Output erosion-deposition raster map [kg/m2s]"
-#, fuzzy
-#~ msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
-#, fuzzy
-#~ msgid "Name of the runoff infiltration rate raster map [mm/hr]"
-#, fuzzy
-#~ msgid "Name of the flow controls raster map (permeability ratio 0-1)"
-#, fuzzy
-#~ msgid "Output water discharge raster map [m3/s]"
-#~ msgstr "Nom du fichier raster en sortie pour la courbure moyenne du profil"
-#, fuzzy
-#~ msgid "Output simulation error raster map [m]"
-#~ msgstr "Fichier raster en sortie pour la pente"
-#~ msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
-#~ msgstr "Convertit trois couches raster R,G,B en un fichier image au format PPM, avec la résolution de la région actuelle."
-# c-format
-#, fuzzy
-#~ msgid "Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
-#, fuzzy
-#~ msgid "raster, buffer"
-#~ msgstr "couche raster source"
-#, fuzzy
-#~ msgid "raster, series"
-#~ msgstr "couche raster à échantillonner"
-#~ msgid "Input map: amount of overland flow per cell"
-#~ msgstr "couche d'entrée : quantité de ruissellement par cellule"
-#~ msgid "Input map: terrain blocking overland surface flow, for USLE"
-#~ msgstr "couche d'entrée : terrain bloquant l'écoulement de surface, pour USLE"
-#~ msgid "Output map: number of cells that drain through each cell"
-#~ msgstr "Couche de sortie : nombre de cellules qui s'écoulent dans d'autres cellules"
-#~ msgid "Output map: unique label for each watershed basin"
-#~ msgstr "Couche de sortie : étiquette unique pour chaque bassin versant"
-#~ msgid "Output map: each half-basin is given a unique value"
-#~ msgstr "Couche de sortie : valeur unique pour chaque demi-bassin versant"
-#~ msgid "Output map: slope length and steepness (LS) factor for USLE"
-#~ msgstr "Couche de sortie : facteur de longueur de la pente et d'escarpement (LS) pour USLE"
-#~ msgid "Output map: slope steepness (S) factor for USLE"
-#~ msgstr "Couche de sortie : facteur d'escarpement (S) pour USLE "
-#~ msgid "Input value: minimum size of exterior watershed basin"
-#~ msgstr "Valeur d'entrée : taille minimum de bassin versant"
-#~ msgid "Input value: maximum length of surface flow, for USLE"
-#~ msgstr "Valeur d'entrée : longueur maximum d'un écoulement de surface, pour USLE"
-#, fuzzy
-#~ msgid ""
-#~ "Sorry, if any of the following options are set:\n"
-#~ "    basin, stream, half.basin, length.slope, or slope.steepness\n"
-#~ "    you MUST provide a value for the basin threshold parameter."
-#~ msgstr ""
-#~ "\n"
-#~ "Désolé, si aucune des options suivantes n'est fixée:\n"
-#~ "\tbasin (bassin), stream (courant), half.basin (demi-bassin), slope (pente), ou 1s\n"
-#~ "\tvous DEVEZ fournir une valeur pour le seuil du bassin (basin.threshold)."
-#~ msgid ""
-#~ "USAGE for basin delineation:\n"
-#~ "%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
-#~ "\n"
-#~ "USAGE for ARMSED FILE creation:\n"
-#~ "%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] ha=half_basin_map ar=ARMSED_file_name\n"
-#~ "\n"
-#~ "USAGE for slope length determination:\n"
-#~ "%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
-#~ msgstr ""
-#~ "USAGE pour la délimitation du bassin versant:\n"
-#~ "%s -4 el=couche_altitude t=seuil_depression_marecageuse [ov=couche_courants] [dr=couche_direction_drainage] [de=couche_depression] [ac=couche_accumulation] [di=couche_affichage] ba=couche_bassin_versant [se=couche_segment_cours_d_eau]\n"
-#~ "\n"
-#~ "USAGE pour la création du fichier ARMSED:\n"
-#~ "%s [-4] el=couche_altitude t=seuil_depression_marecageuse [ov=couche_courants] [dr=couche_direction_drainage] [de=couche_depression] [ac=couche_accumulation] [di=couche_affichage] [ba=couche_bassin_versant] [se=couche_segment_cours_d_eau] ha=couche_demi_bassin ar=nom_fichier_ARMSED\n"
-#~ "\n"
-#~ "USAGE pour la détermination de longueur de pentes:\n"
-#~ "%s [-4] el=couche_altitude t=seuil_depression_marecageuse [dr=couche_direction_drainage] [de=couche_depression] [ac=couche_accumulation] [di=couche_affichage] [ms=longueur_max_pente] [ob=couche_obstacles] [S=couche_escarpement_pente] LS=couche_longueur_pentes [r=couche_erosion_ruissellement] [sd=depot_pente valeur ou couche]"
-#, fuzzy
-#~ msgid "unable to open flow accumulation map layer"
-#~ msgstr "Impossible d'ouvrir la nouvelle couche d'accumulation."
-#, fuzzy
-#~ msgid "Error writing color file for <%s>"
-#~ msgstr "Erreur d'écriture du fichier colr de <%s>"
-#~ msgid "Output direction raster map"
-#~ msgid "Output raster map of problem areas"
-#~ msgstr "couche raster des zones à problèmes"
-#, fuzzy
-#~ msgid "raster, resample"
-#~ msgid "Cannot read ew_res value"
-#~ msgstr "Impossible de lire la valeur ew_res"
-#~ msgid "Cannot read ns_res value"
-#~ msgstr "Impossible de lire la valeur ns_res"
-#~ msgid "[%s]: Map is the wrong resolution"
-#~ msgstr "[%s] : la couche n'a pas la bonne résolution"
-#~ msgid "Cannot get row %d (error = %d)"
-#~ msgstr "Impossible de récupérer la ligne %d (erreur =%d)"
-#~ msgid "Cannot set region to back to the initial region !!!"
-#~ msgstr "Impossible de reconfigurer la région sur la région initiale !!!"
-#, fuzzy
-#~ msgid "Raster map <%s> in mapset <%s> is a floating point map. Decimal values will be rounded to integer!"
-#~ msgstr "La couche <%s> du jeu de données <%s> est une couche en point flottant. Les valeurs décimales seront arrondies à l'entier!"
-#~ msgid "Surface generation program from rasterized contours."
-#~ msgstr "Programme de génération de surface à partir de contours rasterisés."
-#~ msgid "Name of existing raster map containing contours"
-#~ msgstr "Nom de la couche existante contenant les contours"
-#, fuzzy
-#~ msgid "Creates/modifies the color table associated with a raster map layer."
-#~ msgstr "Creer/Modifier la table de couleurs associée à une couche raster."
-#~ msgid "Raster map name from which to copy color table"
-#~ msgstr "couche raster source pour la table de couleurs"
-#, fuzzy
-#~ msgid "Path to rules file (\"-\" to read rules from stdin)"
-#~ msgstr "Fichier de coordonnées en entrée (ne pas lire à partir de stdin)"
-#, fuzzy
-#~ msgid "One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be specified!"
-#, fuzzy
-#~ msgid "Cannot create %s/.r.li/ directory"
-#~ msgstr "Impossible de créer le répertoire .r.li"
-#, fuzzy
-#~ msgid "Cannot create %s/.r.li/output/ directory"
-#~ msgstr "Impossible de créer le répertoire .r/li/en sortie"
-#, fuzzy
-#~ msgid "Range to be exported: %f - %f"
-#~ msgstr "Fichier raster à importer"
-#, fuzzy
-#~ msgid "raster, null data"
-#~ msgstr "couche raster en entrée"
-#, fuzzy
-#~ msgid "Generates a raster map layer of distance to features in input layer."
-#~ msgstr "Produit une couche raster où les aires contiguës ont été agrandies d'une cellule."
-#~ msgid "(i)   Basin map created by r.water.outlet (MASK)"
-#~ msgstr "(i)  Couche de bassin versant créée par r.water.outlet (MASK)"
-#~ msgid "(o)   Direction map for depressionless elevation map"
-#~ msgstr "(o) Couche de gradient à partir d'une couche d'altitudes positives"
-#~ msgid "(i)   Number of topographic index classes"
-#~ msgstr "(i) Nombre de classes topographiques indexées"
-#~ msgid "(o/i) Topographic index statistics file"
-#~ msgstr "(o/i) Fichier de statistiques topographiques indexées"
-#~ msgid "(i)   TOPMODEL Parameters file"
-#~ msgstr "(i) Fichier de paramètres TOPMODEL"
-#~ msgid "(i)   Rainfall and potential evapotranspiration data file"
-#~ msgstr "(i) Fichier de données de précipitations et d'évapo-transpiration prévue"
-#, fuzzy
-#~ msgid "Creates a new map layer whose category values are based upon a reclassification of the categories in an existing raster map layer."
-#~ msgstr "Crée une nouvelle couche dont les catégories sont basées sur la reclassification des catégories d'une couche raster existante."
-#~ msgid "Raster map to be reclassified"
-#~ msgstr "couche à reclassifier"
-#~ msgid "Converts a raster map into a vector map layer."
-#~ msgstr "Convertit une couche raster en couche vectorielle"
-#, fuzzy
-#~ msgid "The map E grid coordinates"
-#~ msgstr "Coordonnée est"
-# c-format
-#, fuzzy
-#~ msgid "Calculating map %01d of %01d (angle %lf, raster map <%s>)"
-#~ msgstr "Impossible d'écrire la couche raster lac <%s>!"
-#, fuzzy
-#~ msgid "Data range of raster map <%s> is %s to %s (entire map)"
-#~ msgstr "fp: L'intervalle va de %.25f à %.25f\n"
-#, fuzzy
-#~ msgid "Integer data range of raster map <%s> is empty"
-#, fuzzy
-#~ msgid "Integer data range of raster mao <%s> is %d to %d"
-#, fuzzy
-#~ msgid "'%s' is not a valid rule"
-#, fuzzy
-#~ msgid "Name of vector input map containing stream(s)"
-#~ msgstr "Nom de la couche vecteur en entrée contenant les cours d'eau"
-#~ msgid "Output flowpath length raster map"
-#~ msgstr "Fichier raster en sortie pour la longueur des courants"
-#~ msgid "Output flowline density raster map"
-#~ msgstr "Fichier raster en sortie pour la densité des courants"
-#~ msgid "3-D lengths instead of 2-D"
-#~ msgstr "Longueurs 3D plutôt que 2D"
-#, fuzzy
-#~ msgid "Converts ASCII raster file to binary raster map layer."
-#~ msgstr "Convertir un fichier raster ASCII en couche raster (binaire)."
-# c-format
-#, fuzzy
-#~ msgid "Unable to open vector map <%s> in <%s>"
-#, fuzzy
-#~ msgid "Lat/Long location is not supported"
-#, fuzzy
-#~ msgid "raster, geomorphology"
-#, fuzzy
-#~ msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster map layer."
-#~ msgstr "Convertir un fichier raster ESRI ARC/INFO ASCII GRID en une couche raster."
-#, fuzzy
-#~ msgid "File containing weights"
-#~ msgstr "Fichier contenant les requêtes SQL"
-#, fuzzy
-#~ msgid "general, scripts"
-#~ msgstr "Afficher également les paramètres 3D"
-#, fuzzy
-#~ msgid "general, settings"
-# c-format
-#, fuzzy
-#~ msgid "Erasing monitors..."
-#, fuzzy
-#~ msgid "%s: Couldn't read color table for <%s@%s>"
-#~ msgid "Color for drawing X's (Null values)"
-#~ msgstr "Couleur pour tracer les X (valeurs Null)"
-#~ msgid "display, cartography"
-#~ msgstr "affichage, cartoraphie"
-#, fuzzy
-#~ msgid "Monitor: waitpid: expected %d but got %d"
-#~ msgstr "Moniteur: waitpid: attendu %d mais reçu %d\n"
-#, fuzzy
-#~ msgid "display, networking"
-#~ msgid "Identifies the geographic coordinates associated with point locations in the active frame on the graphics monitor."
-#~ msgstr "Identifie les coordonnées géographiques associées à l'emplacement d'un point dans le moniteur actif."
-#~ msgid "Command mode (Compatibility with d.text)"
-#~ msgstr "Mode ligne de commande (compatible avec d.text)"
-#~ msgid "Either text or -c should be given"
-#~ msgstr "L'une des options, soit texte soit -c, doit être sélectionnée."
-#~ msgid "Unable to create face"
-#~ msgstr "Impossible de créer le texte"
-#~ msgid "Text conversion error"
-#~ msgstr "Erreur de conversion du texte"
-#, fuzzy
-#~ msgid "Error reading hue data"
-#~ msgstr "Erreur de lecture de la couche Teinte"
-#, fuzzy
-#~ msgid "R_color file for [%s] not available"
-#~ msgstr "Fichier de couleur de [%s] non disponible"
-#, fuzzy
-#~ msgid "Range file for [%s] not available"
-#~ msgstr "Le fichier de catégorie pour [%s] n'est pas disponible"
-#, fuzzy
-#~ msgid "Displays and overlays raster map layers in the active display frame on the graphics monitor."
-#~ msgstr "Affiche et superpose les couches rasters dans le moniteur actif"
-#~ msgid "List of categories to be displayed (INT maps)"
-#~ msgstr "Liste de catégories à afficher (couche en entiers INT)"
-#~ msgid "Invert catlist"
-#~ msgstr "Inverser la catlist"
-#, fuzzy
-#~ msgid "Displays vector data in the active frame on the graphics monitor."
-#~ msgstr "Afficher les données vectorielles GRASS dans le moniteur actif"
-#~ msgid "Vector map attribute column to use for comparison"
-#~ msgstr "Nom du champ attributaire de la couche vectorielle à utiliser pour la comparaison"
-#~ msgid "Vector map to store differences"
-#~ msgstr "Couche vectorielle servant au stockage des différences"
-#~ msgid "Option scaling factor for values read from raster map. Sampled values will be multiplied by this factor"
-#~ msgstr "Option de facteur d'échelle pour les valeurs lues dans la couche raster. Les valeurs échantillonnées seront multipliées par ce facteur"
-#, fuzzy
-#~ msgid "%d new points written to output"
-#~ msgstr "%d points  écrits vers la couche cible\n"
-#, fuzzy
-#~ msgid "Exports a GRASS vector map to SVG."
-#~ msgstr "Exporte un raster GRASS vers un tableau binaire."
-#, fuzzy
-#~ msgid "Layer number (write to)"
-#~ msgstr "Code de couche"
-#, fuzzy
-#~ msgid "Query layer number (read from)"
-#, fuzzy
-#~ msgid "vector, interpolation"
-#, fuzzy
-#~ msgid "Layer but not column with z values given"
-#~ msgstr "Colonne de la table attributaire avec les valeurs à interpoler (si la couche>0)"
-#, fuzzy
-#~ msgid "Vector based generalization."
-#, fuzzy
-#~ msgid "Creates topology for GRASS vector map."
-#~ msgstr "Créer des icones pour le fichier vecteur GRASS et les attributs liés"
-#, fuzzy
-#~ msgid "Convert OGR vector layers to GRASS vector map."
-#~ msgstr "Convertit des fichiers vecteurs OGR dans GRASS. Pilotes disponibles:\n"
-#~ msgid "Converts a binary GRASS vector map (only points) layer into a 3D GRASS raster map layer."
-#~ msgstr "Convertit une couche vecteur GRASS binaire (points seulement) en couche raster 3D GRASS"
-#, fuzzy
-#~ msgid "vector, extract"
-#~ msgid "Random location perturbations of GRASS vector points"
-#~ msgstr "Génère des perturbations aléatoires sur la position de points vectoriels GRASS"
-#~ msgid "Parameter(s) of distribution. If the distribution is uniform, only one parameter, the maximum, is needed. For a normal distribution, two parameters, the mean and standard deviation, are required."
-#~ msgstr "Paramètre(s) de distribution. Si la distribution est uniforme, seul un paramètre, le maximum, est nécessaire. Pour une distribution normale, deux paramètres, la moyenne et l'écart-type, sont nécessaires."
-#, fuzzy
-#~ msgid "Layer number (from)"
-#, fuzzy
-#~ msgid "Layer number (to)"
-#, fuzzy
-#~ msgid "Randomly generate a 2D/3D vector points map."
-#~ msgstr "Génère de façon aléatoire des couches vectorielles points GRASS 2D/3D"
-# c-format
-#, fuzzy
-#~ msgid "Using 'double precision' for column <%s>"
-#~ msgstr "Impossible d'ouvrir le fichier de cellules pour [%s]"
-#, fuzzy
-#~ msgid "Converts a GRASS binary vector map to VTK ASCII output."
-#~ msgstr "Convertit une couche vectorielle binaire GRASS en sortie ASCII VTK"
-#, fuzzy
-#~ msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
-#~ msgstr "Convertit une couche vecteur binaire GRASS en couche vecteur ASCII GRASS"
-#, fuzzy
-#~ msgid "Parameter '%s' ignored in standard mode"
-#~ msgstr "incidout demande de fixer le paramètre d'heure"
-#, fuzzy
-#~ msgid "vector, geometry"
-#~ msgstr "Couche vecteur à supprimer"
-#, fuzzy
-#~ msgid "Use '%s' option to change vector map name"
-#~ msgstr "Utilisez l'option output= pour changer le nom de la couche vectorielle"
-#, fuzzy
-#~ msgid "Counting sites in quadrats..."
-#~ msgstr "Recherche des classes d'apprentissage..."
-#, fuzzy
-#~ msgid "Creates a GRASS vector map of a user-defined grid."
-#~ msgstr "Convertit une couche vecteur binaire GRASS en couche raster GRASS"
-#, fuzzy
-#~ msgid "Either 'rules' or 'col' must be specified"
-#~ msgstr "2 couches doivent être spécifiées"
-#~ msgid "Export features with category (labeled) only. Otherwise all features are exported"
-#~ msgstr "Exporter seulement les objets dotés de catégorie (étiquette). Sinon tous les objets sontexportés"
-# c-format
-#~ msgid "Key column '%s' not found"
-#~ msgstr "Clef primaire <%s> non trouvée"
-# c-format
-#, fuzzy
-#~ msgid "%d features written"
-#~ msgstr "%d points  écrits dans la couche vecteur"
-#, fuzzy
-#~ msgid "Convex hull calculation requires at least three points. Exiting."
-#~ msgstr "Cette option requiert au moins 2 colonnes"
-#, fuzzy
-#~ msgid "Create a new vector map layer by combining other vector map layers."
-#~ msgstr "Convertit une couche vecteur binaire GRASS en la combinant avec d'autres couches vectorielles binaires."
-# c-format
-#, fuzzy
-#~ msgid "Patching vector map <%s@%s>..."
-#, fuzzy
-#~ msgid "vector, metadata"
-#, fuzzy
-#~ msgid "Creates a buffer around features of given type (areas must contain centroid)."
-#~ msgstr "crée une zone-tampon autour d'objet d'un type donné (les entités surfaciques doivent contenir un centroïde)."
-#~ msgid "Buffer distance in map units"
-#~ msgstr "Distance de zone-tampon en unités carte."
-#, fuzzy
-#~ msgid "Use the distance option instead of the buffer option."
-#~ msgstr "Utilisez des radians à la place de degrés pour définir l'angle de rotation"
-#, fuzzy
-#~ msgid "vector, querying"
-#, fuzzy
-#~ msgid "Queries a vector map layer at given locations."
-#, fuzzy
-#~ msgid "Copying vector objects from vector map <%s>..."
-#~ msgstr "Lecteur du fichier raster..."
-#, fuzzy
-#~ msgid "Name of input vector map containing lines"
-#~ msgstr "Couche en entrée contenant les lignes"
-#, fuzzy
-#~ msgid "Name for output vector map where segments will be written"
-#~ msgstr "Couche en sortie où les points seront écrits"
-#, fuzzy
-#~ msgid "Tests for normality for points."
-#~ msgstr "Trop de points de départ."
-#, fuzzy
-#~ msgid "Calculates univariate statistics for attribute. Variance and standard deviation is calculated only for points if specified."
-#~ msgstr "Calcule des statistiques univariées pour un attribut. La variance et l'écart-type sont calculés uniquement pour les points si cela est spécifié."
-#, fuzzy
-#~ msgid "Calculate area centroids..."
-#~ msgstr "Impossible de calculer le centroïde de l'entité surfacique"
-#, fuzzy
-#~ msgid "Create points along input lines in new vector with 2 layers."
-#~ msgstr "Créer des points le long des lignes en entrée."
-# c-format
-#, fuzzy
-#~ msgid "%d points written to output vector map"
-#, fuzzy
-#~ msgid "Creates a vector map from ASCII points file or ASCII vector file."
-#, fuzzy
-#~ msgid "Creates a new vector as a read-only link to OGR layer."
-#~ msgid "Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
-#~ msgstr "Seuillage en unités de la carte, une valeur pour chaque outil (par défaut : 0.0[,0.0,...])"
-#, fuzzy
-#~ msgid "%d lines / boundaries removed"
-#~ msgstr "%s fichier(s) à supprimer"
-#, fuzzy
-#~ msgid "Attribute table column with values to interpolate"
-#, fuzzy
-#~ msgid "No data points found"
-#, fuzzy
-#~ msgid "Lines buffers... "
-#, fuzzy
-#~ msgid "Outputs basic information about a user-specified vector map."
-#~ msgstr "Afficher des informations générales à propos d'une couche vecteur spécifiée par l'utilisateur."
-#, fuzzy
-#~ msgid "Map format:      %s"
-#~ msgstr "\t\t%s"
-#, fuzzy
-#~ msgid "Name of creator: %s"
-#, fuzzy
-#~ msgid "  Comments:"
-#~ msgstr "moyennes"
-#, fuzzy
-#~ msgid "Extrudes flat vector object to 3D with defined height."
-#~ msgstr "Mettre en relief des objets vecteurs plats en fonction d'une hauteur définie"
-#~ msgid "Output surface raster map (elevation)"
-#~ msgstr "Fichier raster de relief Z (altitude) à créer"
-#~ msgid "Output cross-validation errors vector point file"
-#~ msgstr "Fichier en sortie de validation croisée des erreurs sur vecteurs points"
-#~ msgid "Output vector map showing quadtree segmentation"
-#~ msgstr "Fichier vecteur en sortie montrant la segmentation en quadtree"
-#~ msgid "Output vector map showing overlapping windows"
-#~ msgstr "Fichier vecteur en sortie montrant le recouvrement des fenêtres"
-#~ msgid "Name of the attribute column with values to be used for approximation (if layer>0)"
-#~ msgstr "Nom de la colonne attributaire où prendre les valeurs à utiliser pour calculer les valeurs approchées(si couche>0)"
-#~ msgid "Cannot write raster maps -- try to increase resolution"
-#~ msgstr "Impossible d'écrire les fichiers de cellules -- essayez d'augmenter la résolution"
-#, fuzzy
-#~ msgid "Print all map connection parameters and exit in shell script style"
-#~ msgstr "Affiche les paramètres de connexion courants et quitte"
-#, fuzzy
-#~ msgid "Vector map <%s> is connected by:"
-#, fuzzy
-#~ msgid "Exports GRASS vector map layers to DXF file format."
-#, fuzzy
-#~ msgid "Unable to determine raster cell type"
-#~ msgstr "Impossible de déterminer le type de cellule raster"
-#, fuzzy
-#~ msgid "raster, vector, visualization"
-#, fuzzy
-#~ msgid "Verbose module output"
-#~ msgstr "Détails de l'exécution"
-#~ msgid "OGR driver: column '%s', OGR type %d  is not supported"
-#~ msgstr "Pilote OGR : colonne '%s', le type OGR %d n'est pas géré"
-#, fuzzy
-#~ msgid "Prints/sets general DB connection for current mapset and exits."
-#~ msgstr "Affiche/configure la connexion à la base de données du jeu de données courant"
-#, fuzzy
-#~ msgid "database, SQL"
-#~ msgstr "nom de la base de donnée"
-#, fuzzy
-#~ msgid "Name of file with sql statement"
-#~ msgstr "nom du fichier contenant une commande SQL"
-#, fuzzy
-#~ msgid "The password was stored in file"
-#~ msgstr "Le mot de passe a été stocké dans un fichier."
-#, fuzzy
-#~ msgid "Region sensitive output"
-#~ msgstr "Problème de lecture de r.stats en sortie"
-#, fuzzy
-#~ msgid "raster, elevation"
-#~ msgstr "Tracer le relief"
-#~ msgid "Convert coordinates from one projection to another (cs2cs frontend)."
-#~ msgstr "Convertit les coordonnées d'une projection à une autre (interface de cs2cs)."
-#, fuzzy
-#~ msgid "miscellaneous, projection"
-#~ msgstr "Projection source"
-#~ msgid "Input coordinate file (omit to read from stdin)"
-#, fuzzy
-#~ msgid "Images"
-#~ msgstr "Groupe de fichiers image"
-#, fuzzy
-#~ msgid "Width and height of output image (overrides resolution setting)"
-#~ msgstr "Largeur de la couleur de mise en valeur"
-#, fuzzy
-#~ msgid "Compression for PNG files"
-#~ msgstr "Compression des fichiers PNG (0=aucun, 1=rapide, 9=maximale)"
-#, fuzzy
-#~ msgid "PostScript"
-#~ msgstr "couche PostScript en sortie"
-#, fuzzy
-#~ msgid "Set paper orientation to landscape (for PostScript output)"
-#~ msgstr "Produit un script shell en sortie"
-#, fuzzy
-#~ msgid "Do not crop away margins"
-#~ msgstr "Impossible de copier la table"
-#, fuzzy
-#~ msgid "raster, tiling"
-#, fuzzy
-#~ msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2)"
-#~ msgstr "Couche raster en entrée (Proche Infra Rouge: tm4 | qbird_nir | spot2)"
-#, fuzzy
-#~ msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3)"
-#~ msgstr "Couche raster en entrée (Moyen Infra Rouge: tm5 | qbird_red | spot3)"
-#, fuzzy
-#~ msgid "display, diagram"
-#~ msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
-#~ msgstr "Faire une mosaïque comprenant jusqu'à 4 images et étendre la table de couleurs; créer une couche *.mosaic"
-#, fuzzy
-#~ msgid "raster, imagery, mosaicking"
-#~ msgid "2nd map for mosaic."
-#~ msgstr "2nde couche pour la mosaïque."
-#, fuzzy
-#~ msgid "Reports geometry statistics for vectors."
-#~ msgstr "Affiche les statistiques géométriques sur les vecteurs."
-#, fuzzy
-#~ msgid "Value to update the column with (varchar values have to be in single quotes, e.g. 'grass')"
-#~ msgstr "nouvelle valeur à affecter à la colonne (les valeurs varchar doivent être entre simples guillemets, par exemple : 'grass')"
-#, fuzzy
-#~ msgid "Name of raster map to print in legend"
-#~ msgstr "Nom de la couche raster d'aspect à afficher"
-#, fuzzy
-#~ msgid "name for new map image (lives in ~/.gpsdrive/maps/)"
-#~ msgstr "nom pour une nouvelle couche image (dans ~/.gpsdrive)"
-#, fuzzy
-#~ msgid "general, manual, help"
-#~ msgid "Raster map to use as MASK"
-#~ msgstr "couche raster à utiliser comme MASK"
-#, fuzzy
-#~ msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
-#~ msgstr "Valeur de catégorie à utiliser comme MASK (format: 1 2 3 jusqu'à 7 *)"
-#~ msgid "Overwrite existing MASK"
-#~ msgstr "Ecraser le MASK existant"
-#~ msgid "Remove existing MASK (overrides other options)"
-#~ msgstr "Supprimer le MASK existant (supplante les autres options)"
-#, fuzzy
-#~ msgid "The database must be in form printed by v.db.connect -g, i.e. with substituted variables"
-#~ msgstr "Nom de l'ancienne base de données, la base de données doit être sous à la forme affichée par v.db.connect -c'est-à-dire en substituant les variables"
-#, fuzzy
-#~ msgid "Georeference, rectify and import Terra-ASTER imagery and relative DEM's using gdalwarp."
-#~ msgstr "r.in.aster - georéférencement, recalage, et import d'images Terra-ASTER et de MNT en utilisant gdalwarp"
-#, fuzzy
-#~ msgid "L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a single band"
-#~ msgstr "canal L1A ou L1B à traduire (1, 2,3n,3b,4-14). Il n'est possible de traduire qu'un seul canal"
-#, fuzzy
-#~ msgid "Name of color column to populate"
-#~ msgstr "Nom de la colonne à afficher"
-#, fuzzy
-#~ msgid "Name of vector polygon map"
-#~ msgstr "Nom de la couche vecteur"
-#, fuzzy
-#~ msgid "Name of raster map to calculate statistics from"
-#~ msgstr "Nom de la couche raster qui contiendra les résultats"
-#, fuzzy
-#~ msgid "GIS manager for GRASS"
-#~ msgstr "Afficher les pages de manuel GRASS au format HTML"
-#, fuzzy
-#~ msgid "calculates univariate statistics from a GRASS raster map"
-#~ msgstr "Calcule des statistiques univariées à partir d'une couche raster GRASS basée sur des objets vecteurs"
-#, fuzzy
-#~ msgid "C"
-#~ msgstr "C :"
-#~ msgid "Show help"
-#~ msgstr "Montrer l'aide"
-#~ msgid "Display monitor to start"
-#~ msgstr "Moniteur d'affichage à démarrer"
-#~ msgid "Folder to save downloaded data to"
-#~ msgstr "Répertoire dans lequel sauvegarder les données téléchargées"
-#, fuzzy
-#~ msgid "Layer number. If -1, all layers are extracted."
-#~ msgstr "Code de couche. Si fixé à -1, toutes les couches sont affichées."
-#, fuzzy
-#~ msgid "Configuration editor for r.li.'index'"
-#~ msgstr "Nom du fichier de configuration illégal"
-#, fuzzy
-#~ msgid "raster, landscape structure analysis"
-#~ msgid "Import of SPOT VGT NDVI file into a raster map"
-#~ msgstr "Importer du fichier SPOT VGT NDVI sous forme de couche raster."
-#~ msgid "existing SPOT VGT NDVI HDF file (0001_NDV.HDF)"
-#~ msgstr "Fichier SPOT VGT NDVI HDF existant (0001_NDV.HDF)"
-#~ msgid "Source monitor"
-#~ msgstr "Moniteur source"
-#, fuzzy
-#~ msgid "imagery, rectify"
-#~ msgstr "groupes d'images"
-#, fuzzy
-#~ msgid "Unable to open real-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
-#~ msgstr ""
-#~ "Impossible d'ouvrir l'image (partie réelle) dans le répertoire cell_misc.\n"
-#~ "La couche en entrée n'a pas été créée par i.fft"
-#, fuzzy
-#~ msgid "Unable to open imaginary-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
-#~ msgstr ""
-#~ "Impossible d'ouvrir l'image (partie imaginaire) dans le répertoire cell_misc.\n"
-#, fuzzy
-#~ msgid "imagery, orthorectify"
-#, fuzzy
-#~ msgid "Name of image to be rectified which will be initially drawn on screen"
-#~ msgstr "Nom de l'image à recaler à afficher à l'écran"
-#, fuzzy
-#~ msgid "Name of a map from target mapset which will be initially drawn on screen"
-#~ msgstr "Nom de la couche de données du jeu de données cible à afficher à l'écran."
-#, fuzzy
-#~ msgid "Group [%s] not found"
-#, fuzzy
-#~ msgid "No camera reference file selected for group [%s]"
-#, fuzzy
-#~ msgid "No initial camera exposure station for group [%s]"
-#, fuzzy
-#~ msgid "Bad format in initial camera exposure station for group [%s]"
-#, fuzzy
-#~ msgid "Poorly placed photo points for group [%s]"
-#, fuzzy
-#~ msgid "Computing equations ..."
-#, fuzzy
-#~ msgid "No target elevation model selected for group <%s>"
-#, fuzzy
-#~ msgid "No camera reference file selected for group <%s>"
-#, fuzzy
-#~ msgid "Cannot generate the transformation equation."
-#~ msgstr "Impossible de trouver les informations sur la couche vectorielle"
-#, fuzzy
-#~ msgid "%s@%s: projection doesn't match current settings"
-#~ msgstr "Sortie. Ne pas changer les paramètres actuels"
-#, fuzzy
-#~ msgid "%s@%s: zone doesn't match current settings"
-#, fuzzy
-#~ msgid "Interactively select or modify the target elevation model."
-#, fuzzy
-#~ msgid "Target information for group [%s] missing\n"
-#~ msgstr "Information sur l'intervalle des valeurs pour [%s] n'est pas disponible"
-#, fuzzy
-#~ msgid "Interactively select and modify the imagery group camera reference file."
-#, fuzzy
-#~ msgid "Enter a camera reference file to be used with this imagery group"
-#, fuzzy
-#~ msgid "Range less than or equal to zero not allowed"
-#~ msgstr "Intervalle inférieur ou égal à zéro non valide"
-#, fuzzy
-#~ msgid "Writing viewable versions of transformed data..."
-#~ msgstr "Ecriture des versions visualisables des données transformées dans les fichiers..."
-#, fuzzy
-#~ msgid "Unable to open file in the 'cell_misc' directory"
-#~ msgstr "Impossible d'ouvrir le fichier dans le répertoire cell_misc"
-#, fuzzy
-#~ msgid "Eigen values:"
-#~ msgstr "Valeur de la chaîne de bit"
-#, fuzzy
-#~ msgid "To layer"
-#~ msgstr "Requêter la couche"
-#, fuzzy
-#~ msgid "vector, attribute table"
-#~ msgstr "Affiche les attributs des vecteurs"
-#~ msgid "%s: %s - Unable to find the real-image map."
-#~ msgstr "%s: %s - impossible de trouver l'image (partie réelle)"
-#~ msgid "%s: %s - Unable to find the imaginary-image."
-#~ msgstr "%s: %s - impossible de trouver l'image (partie imaginaire)"
-#, fuzzy
-#~ msgid "Hue map name"
-#~ msgstr "%s - nom illégal"
-#, fuzzy
-#~ msgid "Red input raster map"
-#~ msgid "1 class."
-#~ msgstr "1 classe."
-#, fuzzy
-#~ msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
-#~ msgid "Skipping [%s]..."
-#~ msgstr "Saut de [%s]..."
-#~ msgid "Multiplier"
-#~ msgstr "Multiplicateur"
-#~ msgid "Name of the resultant map"
-#~ msgstr "Nom de la couche en sortie"
-#~ msgid "Done"
-# c-format
-#~ msgid "Cannot open OGR data source '%s'"
-#~ msgstr "Impossible d'ouvrir la source de données OGR %s"
-#, fuzzy
-#~ msgid "Column(s)"
-#~ msgstr "colonne(s)"
-#, fuzzy
-#~ msgid "Unable to read category file for raster map <%s>"
-#~ msgstr "Editer le fichier de catégorie de [%s]?"
-# c-format
-#~ msgid "Reading %s ... "
-#~ msgstr "Lecture de %s..."
-# c-format
-#~ msgid "%s in %s: %s"
-#~ msgstr "%s ligne %s: %s"
-# c-format
-#~ msgid "cannot read head of %s"
-#, fuzzy
-#~ msgid "Reading raster map <%s> ..."
-# c-format
-#~ msgid "No record for cat = %d"
-#, fuzzy
-#~ msgid "Vector map <%s> not found in current mapset"
-#~ msgid "Database connection not defined for layer <%d>"
-#~ msgstr "La connexion à la base de données n'a pas été définie pour la couche <%d>"
-# c-format
-#, fuzzy
-#~ msgid "Cannot open file for <%s>"
-#~ msgstr "Impossible d'ouvrir le fichier [%s]"
-#~ msgid "Name of the random surface to be produced"
-#~ msgstr "Nom du relief aléatoire à produire"
-# c-format
-#~ msgid "Cannot open file [%s]"
-#, fuzzy
-#~ msgid "Read coordinates from standard input"
-#~ msgstr "Les coordonnées XY du/des foyer(s) initial(aux)"
-#~ msgid "Error reading map %s"
-#~ msgstr "Erreur de lecture de la couche %s"
-#, fuzzy
-#~ msgid "Closing raster map"
-#, fuzzy
-#~ msgid "Could not close the 3d raster map"
-#~ msgstr "Impossible de fermer la nouvelle couche g3d"
-#~ msgid "Can't create output map"
-#~ msgstr "Impossible de créer la couche en sortie"
-#, fuzzy
-#~ msgid "name for new vector map"
-#~ msgstr "Nom du nouveau fichier vecteur binaire"
-#~ msgid "Topographic index ln(a/tanB) map"
-#~ msgstr "couche d'indice topographique ln(a/tan(beta))"
-#, fuzzy
-#~ msgid "Name of the output walkers site file"
-#~ msgstr "Nom de la nouvelle couche raster"
-#~ msgid "Database name:"
-#~ msgstr "Nom de la base de donnée :"
-#~ msgid "column type not supported"
-#~ msgstr "Type de colonne non géré"
-#~ msgid "%s - too many patch files. only %d allowed"
-#~ msgstr "%s - trop de fichiers patch. Seul(s) %d autorisé(s)"
-#, fuzzy
-#~ msgid "category [%d]"
-#~ msgstr ""
-#~ "couche: %d\n"
-#~ "catégorie: %d\n"
-#, fuzzy
-#~ msgid "Interpolation()"
-# c-format
-#, fuzzy
-#~ msgid "Writing "
-#~ msgstr "Écriture %s..."
-#, fuzzy
-#~ msgid "Calculation time"
-#~ msgstr "Calcul des moyennes de classes..."
-#~ msgid "History line too long: truncating to %d characters"
-#~ msgstr "Ligne d'historique trop longue : tronquée à %d caractères"
-#~ msgid "Name of output 3d raster map"
-#~ msgstr "Nom du fichier grille G3D en sortie"
-#, fuzzy
-#~ msgid "input layer name"
-#~ msgstr "Nom de la couche source"
-#, fuzzy
-#~ msgid "Name of the resulting map"
-#, fuzzy
-#~ msgid "<%s> is an ilegal name"
-#~ msgstr "[%s] n'est pas un nom légal"
-#, fuzzy
-#~ msgid "raster3d, voxel, statistics"
-#, fuzzy
-#~ msgid "Exports a GRASS raster map to a binary array."
-#, fuzzy
-#~ msgid "raster, color transformation"
-#~ msgstr "Erreur de lecture des cellules de données"
-#, fuzzy
-#~ msgid "raster, hydrology"
-#, fuzzy
-#~ msgid "Raster map matrix filter."
-#~ msgstr "Filtre matriciel de fichier raster"
-#, fuzzy
-#~ msgid "raster, export, png"
-#, fuzzy
-#~ msgid "raster, sun energy"
-#~ msgid "Name of the latitudes input raster map [decimal degrees]"
-#~ msgstr "Nom de la couche vecteur de latitudes (degrés décimaux)"
-#, fuzzy
-#~ msgid "Import a binary raster file into a GRASS raster map."
-#~ msgstr "Importer un fichier raster binaire."
-#, fuzzy
-#~ msgid "raster, rescale"
-#, fuzzy
-#~ msgid "raster, export, color table"
-#, fuzzy
-#~ msgid "raster, map management"
-#, fuzzy
-#~ msgid "raster, geometry"
-#, fuzzy
-#~ msgid "raster, quantization"
-#, fuzzy
-#~ msgid "raster, transect"
-#, fuzzy
-#~ msgid "raster, random"
-#, fuzzy
-#~ msgid "raster, viewshed"
-#, fuzzy
-#~ msgid "raster, fire"
-#, fuzzy
-#~ msgid "raster, profile"
-#~ msgid "Input map: locations of real depressions"
-#~ msgstr "couche d'entrée : emplacement des dépressions réelles"
-#, fuzzy
-#~ msgid "raster, projection, transformation"
-#, fuzzy
-#~ msgid "Re-projects a raster map from one location to the current location."
-#~ msgstr "Re-projeter une couche raster depuis un Secteur (location) vers le Secteur courant."
-#~ msgid "Resolution of output map"
-#~ msgstr "Résolution de la nouvelle couche"
-#, fuzzy
-#~ msgid "Raster File Series to MPEG Conversion."
-#~ msgstr "Programme de conversion d'une série de fichiers raster vers MPEG."
-#~ msgid ""
-#~ "Convert on the fly, use less disk space\n"
-#~ "\t(requires r.out.ppm with stdout option)"
-#~ msgstr ""
-#~ "Convertir à la volée, en économisant l'espace disque\n"
-#~ "\t(nécessite r.out.ppm avec l'option stdout)"
-#, fuzzy
-#~ msgid "CHILD[pid = %i]: unable to open <%s> mask ... continuing without!"
-#~ msgstr "CHILD[pid = %i] : impossible d'ouvrir le mask %s... continuer sans!!!"
-#~ msgid "GIS format to write (case sensitive, see also -l flag)"
-#~ msgstr "Format SIG à écrire (sensible à la casse, voir aussi le drapeau -l)"
-#, fuzzy
-#~ msgid "raster, sun position"
-#, fuzzy
-#~ msgid "raster, thin"
-#, fuzzy
-#~ msgid "Thins non-zero cells that denote linear features in a raster map."
-#~ msgstr "'Amincit' les cellules de valeur non-nulles qui semblent appartenir à des entités linéaires dans une couche raster"
-#, fuzzy
-#~ msgid "fp: Data range is %.25f to %.25f\n"
-#, fuzzy
-#~ msgid "raster, metadata, timestamp"
-#, fuzzy
-#~ msgid "raster, conversion, vectorization"
-#, fuzzy
-#~ msgid "raster, category"
-#, fuzzy
-#~ msgid "raster, volume"
-#~ msgstr "Valeur raster"
-#, fuzzy
-#~ msgid "raster, distance"
-#, fuzzy
-#~ msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)."
-#~ msgstr "Constructon de courbes de terrain (lignes du courant), longueur des courants, et densité de lignes de courants (zones amont) à partir d'un modèle numérique de terrain (MNT) raster"
-#, fuzzy
-#~ msgid "raster, querying"
-#, fuzzy
-#~ msgid "raster, import, conversion"
-#, fuzzy
-#~ msgid "general, version"
-#~ msgid "Copies available data files in the user's current mapset search path and location to the appropriate element directories under the user's current mapset."
-#~ msgstr "Copier les fichiers de données disponibles dans le chemin de recherche et le Secteur vers le répertoire approprié sous le jeu de données courant de l'utilisateur."
-#, fuzzy
-#~ msgid "Mapset to list (default: current search path)"
-#~ msgstr "jeu de données à lister (par défaut : chemin de recherche courant)"
-#, fuzzy
-#~ msgid "general, settings, search path"
-#, fuzzy
-#~ msgid "%s: removed"
-#~ msgstr "%-5d centroïdes lus\n"
-#, fuzzy
-#~ msgid "format"
-#~ msgstr "format OGR"
-#, fuzzy
-#~ msgid "display, raster, profile"
-#, fuzzy
-#~ msgid "Print name of current frame"
-#~ msgstr "Sauvegarder cadre graphique actif"
-#, fuzzy
-#~ msgid "name"
-#~ msgstr "nom =%s\n"
-#, fuzzy
-#~ msgid "display, distance"
-#, fuzzy
-#~ msgid "display, menu"
-#, fuzzy
-#~ msgid "display, map management"
-#~ msgstr "Faire pivoter le cartouche de légende"
-#, fuzzy
-#~ msgid "display, metadata"
-#, fuzzy
-#~ msgid "display, raster, RGB"
-#, fuzzy
-#~ msgid "display, position, querying"
-#~ msgid "The screen coordinates for top-left corner of label ([0,0] is top-left of frame)"
-#~ msgstr "Les coordonnées écran pour le coin supérieur gauche de l'étiquette ([0,0] est le coin supérieurgauche du cadre graphique)"
-#, fuzzy
-#~ msgid "display, geometry"
-#, fuzzy
-#~ msgid "display, color transformation"
-#~ msgstr "Affiche l'information topologique (déboguage)"
-#~ msgid "Unknown item type in pad: %s"
-#~ msgstr "Type d'objet inconnu: %s"
-#, fuzzy
-#~ msgid "display, histogram, statistics"
-#, fuzzy
-#~ msgid "display, paint labels"
-#, fuzzy
-#~ msgid "display, zoom"
-#, fuzzy
-#~ msgid "Unable to display areas, topology not available"
-#~ msgstr "Impossible d'afficher les entités surfaciques, topologie non disponible"
-#, fuzzy
-#~ msgid "Unable to display lines by id, topology not available"
-#~ msgstr "Impossible d'afficher les lignes par id, topologie non disponible"
-#, fuzzy
-#~ msgid "vector, raster, resample"
-#, fuzzy
-#~ msgid "vector, network, allocation"
-#, fuzzy
-#~ msgid "vector, networking, maintenance"
-#~ msgstr "Boîte à outil pour nettoyer la topologie vectorielle"
-#, fuzzy
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)"
-#~ msgstr "mi(les), f(pieds), me(tres), k(ilomètres), a(cres), h(ectares)"
-#, fuzzy
-#~ msgid "Remove lines and areas smaller than threshold"
-#~ msgstr "Supprimer tous les cadres graphiques et effacer l'écran"
-#, fuzzy
-#~ msgid "vector, network, isolines"
-#, fuzzy
-#~ msgid "vector, network, salesman"
-#, fuzzy
-#~ msgid "vector, geometry, statistics"
-#, fuzzy
-#~ msgid "vector, network, shortest path"
-#, fuzzy
-#~ msgid "vector, import, sites"
-#~ msgid "Converts files in DXF format to GRASS vector map format."
-#~ msgstr "Convertir les fichiers au formats DXF vers le format de fichier vectoriel GRASS"
-#, fuzzy
-#~ msgid "Converts GRASS vector map to one of the supported OGR vector formats."
-#~ msgstr "Convertir vers un des formats vecteurs gérés par OGR"
-#, fuzzy
-#~ msgid "Feature type(s). Combinations not supported by all output formats. Default: first type found in input."
-#, fuzzy
-#~ msgid "Volumes will be exported as sets of faces."
-#~ msgstr "Nom de la colonne (qui sera mise à jour par les valeurs rasters)"
-# c-format
-#, fuzzy
-#~ msgid "Could not determine input map's feature type(s)."
-#~ msgstr "couche d'entrée introuvable <%s>"
-#, fuzzy
-#~ msgid "%d areas found, but not requested to be exported. Verify 'type' parameter."
-#~ msgstr "%d Entités surfacique(s) trouvée(s), mais impossible de les exporter. Vérifiez le paramètre 'type'"
-#, fuzzy
-#~ msgid "%d kernel(s) found, but not requested to be exported. Verify 'type' parameter."
-#~ msgstr "%d Ligne(s) trouvée(s), mais impossible de les exporter. Vérifiez le paramètre 'type'"
-#, fuzzy
-#~ msgid "No points found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "%d Point(s) trouvé(s), mais impossible de les exporter. Vérifiez le paramètre 'type'"
-#, fuzzy
-#~ msgid "No lines found, but requested to be exported. Will skip this geometry type."
-#, fuzzy
-#~ msgid "No boundaries found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "%d Contours(s) trouvé(s), mais impossible de les exporter. Vérifiez le paramètre 'type'"
-#, fuzzy
-#~ msgid "No areas found, but requested to be exported. Will skip this geometry type."
-#, fuzzy
-#~ msgid "No centroids found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "%d Centroïde(s) trouvé(s), mais impossible de les exporter. Vérifiez le paramètre 'type'"
-#, fuzzy
-#~ msgid "No faces found, but requested to be exported. Will skip this geometry type."
-#, fuzzy
-#~ msgid "No kernels found, but requested to be exported. Will skip this geometry type."
-#, fuzzy
-#~ msgid "No volumes found, but requested to be exported. Will skip this geometry type."
-#, fuzzy
-#~ msgid "Exporting %i geometries..."
-#~ msgstr "Importation des objets de la couche %d..."
-#, fuzzy
-#~ msgid "vector, projection, transformation"
-#~ msgstr "Nombre de points d'interpolation"
-#, fuzzy
-#~ msgid "vector, network, articulation points"
-#, fuzzy
-#~ msgid "vector, network, connectivity"
-#, fuzzy
-#~ msgid "vector, spatial query"
-#, fuzzy
-#~ msgid "vector, geometry, triangulation"
-#, fuzzy
-#~ msgid "vector, network, steiner tree"
-#, fuzzy
-#~ msgid "Type: %s"
-#~ msgstr "couche %d"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "New vector map <%s> boundary coordinates:"
-#~ msgstr "Nouvelle couche vecteur <%s> coordonnées des limites:\n"
-#, fuzzy
-#~ msgid "vector, network, flow"
-#, fuzzy
-#~ msgid "Calculate geometry distances instead of table data."
-#~ msgstr "%s va stocker ces valeurs à la place de la zone.\n"
-#, fuzzy
-#~ msgid "Unable select categories from table <%s>"
-#~ msgstr "Impossible de sélectionner des données dans la table"
-# c-format
-#, fuzzy
-#~ msgid "Unparsable longitude value: [%s]"
-#~ msgstr "Impossible de trouver le fichier [%s]"
-# c-format
-#, fuzzy
-#~ msgid "Unparsable latitude value: [%s]"
-#, fuzzy
-#~ msgid "vector, external, import"
-#, fuzzy
-#~ msgid "vector, geometry, buffer"
-#~ msgid "Print types/names of table columns for specified layer instead of info"
-#~ msgstr "Afficher les types/noms des colonnes de la table pour une couche spécifiée à la place des informations"
-#, fuzzy
-#~ msgid "Use z-coordinates (3D vector only)"
-#~ msgstr "Valeur du champ. Si fixée à 0, les coordonnées z sont utilisées (vecteur 3D seulement)"
-#, fuzzy
-#~ msgid "vector, network, centrality measures"
-#, fuzzy
-#~ msgid "vector, network, components"
-#, fuzzy
-#~ msgid "vector, network, spanning tree"
-#, fuzzy
-#~ msgid "miscellaneous, distance"
-#, fuzzy
-#~ msgid "Reading file [%s]..."
-#~ msgstr "Lecture du fichier [%s]..."
-#, fuzzy
-#~ msgid "List paper formats ( name width height left right top bottom(margin) )"
-#~ msgstr "Afficher le format papier (nom largeur hauteur gauche droite haut bas (marges) )"
-#~ msgid "PostScript output file"
-#, fuzzy
-#~ msgid "Reading raster maps in group <%s> ..."
-#, fuzzy
-#~ msgid "database, attribute table, connection settings"
-#~ msgstr "Ne pas créer de table attributaire"
-#, fuzzy
-#~ msgid "Calculates univariate statistics from a raster map based on vector polygons and uploads statistics to new attribute columns."
-#, fuzzy
-#~ msgid "D"
-#~ msgstr "D :"
-#, fuzzy
-#~ msgid "imagery, edges"
-#~ msgstr "Écrire les sommets de lignes."
-# c-format
-#, fuzzy
-#~ msgid ""
-#~ "Input raster map <%s> does not exist in group <%s>.\n"
-#~ " Try:\n"
-#~ msgstr "La couche raster [%s] existe dans le groupe."
-#, fuzzy
-#~ msgid "into  <%s@%s> (location <%s>) ... %s"
-#~ msgstr "groupe [%s] ciblé dans le Secteur [%s], jeu de données [%s]\n"
-#, fuzzy
-#~ msgid "imagery, geometry"
-#, fuzzy
-#~ msgid "imagery, statistics"
-#, fuzzy
-#~ msgid "Calculating camera angle to local surface..."
-# c-format
-#, fuzzy
-#~ msgid "Could not open elevation raster"
-#~ msgstr "Impossible d'ouvrir la couche de relief\n"
-# c-format
-#, fuzzy
-#~ msgid "Could not read REF file for group <%s>"
-#~ msgstr "Impossible de lire <%s>"
-#, fuzzy
-#~ msgid "Bad format in initial exposure station file for group <%s>"
-#, fuzzy
-#~ msgid "Error reading segment file"
-#~ msgstr "Erreur lors de la lecture du fichier dbmscap\n"
-# c-format
-#, fuzzy
-#~ msgid ""
-#~ "Control Z Point file for group [%s] in [%s] \n"
-#~ " \n"
-#, fuzzy
-#~ msgid "Computing equations..."
-#, fuzzy
-#~ msgid "Poorly placed Control Points!\n"
-#~ msgstr "Pas de points de départ"
-#, fuzzy
-#~ msgid "Can not generate the transformation equation.\n"
-#, fuzzy
-#~ msgid "No active Control Points!\n"
-# c-format
-#, fuzzy
-#~ msgid ""
-#~ "Reference Point file for group [%s] in [%s] \n"
-#~ " \n"
-#, fuzzy
-#~ msgid "Poorly placed Reference Points!\n"
-#, fuzzy
-#~ msgid "No active Reference Points!\n"
-#, fuzzy
-#~ msgid "Target information for group <%s> missing.\n"
-#, fuzzy
-#~ msgid "Target location <%s> not found\n"
-#~ msgstr "région <%s> non trouvée"
-#, fuzzy
-#~ msgid "No elevation available at row = %d, col = %d"
-#~ msgstr "Echec de la conversion de données à la ligne %d, colonne %d"
-#, fuzzy
-#~ msgid "Could not read REF file for group [%s]"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Rectify all images in the group? "
-#~ msgstr "Recaler toutes les images du groupe"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Choose another extension? "
-#, fuzzy
-#~ msgid "Enter a name for the camera angle map:"
-#~ msgstr "Nom de la couche raster d'angle"
-#, fuzzy
-#~ msgid "Map name <%s> is illegal"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Overwrite maps in target location/mapset? "
-#, fuzzy
-#~ msgid "Please select one of the following interpolation methods\n"
-#~ msgstr "Veuillez entrer l'information suivante pour [%s]:"
-#, fuzzy
-#~ msgid " 1. nearest neighbor\n"
-#~ msgstr "Retour à l'échantillonnage au plus propre voisin par défaut"
-#, fuzzy
-#~ msgid "imagery, classification"
-#~ msgstr "Nom de fichier de signatures à utiliser pour la classification"
-#~ msgid "Raster elevation file name"
-#~ msgstr "Fichier raster d'altitude"
-#, fuzzy
-#~ msgid "Name of the output walkers vector points map"
-#~ msgstr "Nom de la couche vecteur 2D source"
-#, fuzzy
-#~ msgid "Input raster map being fft"
-#~ msgstr "Fichier raster en entrée pour la FFT"
-#, fuzzy
-#~ msgid "File containing initial signatures"
-#~ msgstr "Fichier contenant les signatures initiales"
-#, fuzzy
-#~ msgid "Raster to remove"
-#~ msgstr "Couche raster 3D à supprimer"
-#~ msgid "Loading maps: "
-#~ msgstr "Chargement des couches"
-#~ msgid "Name of input raster map(s)"
-#~ msgstr "Nom de(s) (la) couche(s) raster(s) en entrée"
-# c-format
-#, fuzzy
-#~ msgid "Unable to open file: <%s>"
-#~ msgid "Attribute column(s)"
-#~ msgstr "Colonne(s) attributaire(s)"
-#~ msgid "database name"
-#~ msgid "Finished"
-#~ msgstr "Terminé"
-#, fuzzy
-#~ msgid "Unable to read color file"
-#~ msgstr "Impossible de lire le fichier couleur"
-#, fuzzy
-#~ msgid "Converts a 3D raster map layer into an ASCII text file."
-#~ msgstr "Convertit une couche raster 3D en fichier texte ASCII."
-#~ msgid ""
-#~ "Cannot create mask file: G3D_MASK already exists!\n"
-#~ " Use 'g.remove rast3d=G3D_MASK' to remove the existing mask."
-#~ msgstr ""
-#~ "Impossible de créer un fichier masque : G3D_MASK existe déjà!\n"
-#~ "Utilisez 'g.remove rast3d=G3D_MASK' pour supprimer le masque existant."
-#, fuzzy
-#~ msgid "Raster map %d Filename: %s already exists. Will be overwritten!"
-#~ msgstr "Couche raster %i le nom de fichier %s existe déjà. Ce fichier va être écrasé!\n"
-#, fuzzy
-#~ msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map."
-#~ msgstr "Crée une couche raster de coupe 2D à partir du raster volumique G3D à partir d'une couche de relief 2D"
-#, fuzzy
-#~ msgid "Wrong 3D raster map datatype! Unable to create raster map."
-#~ msgstr "Erreur sur le type de raster G3D! Impossible de créer la couche raster."
-#, fuzzy
-#~ msgid "Unable to close input raster map"
-#~ msgstr "Impossible de fermer la couche source"
-#, fuzzy
-#~ msgid "Unable to read top raster row \n"
-#~ msgstr "Impossible de lire la ligne raster."
-#, fuzzy
-#~ msgid "Unable to read bottom raster row \n"
-#, fuzzy
-#~ msgid "Wrong 3D raster map values: Values should in between 0 and 255\n"
-#~ msgstr "Valeurs de couches G3D erronées! Les valeurs doivent être comprises entre 0 et 255!\n"
-#~ msgid "G3D map(s) to be converted to VTK-ASCII data format"
-#~ msgstr "Couche(s) G3D à convertir au format de données VTK-ASCII"
-#, fuzzy
-#~ msgid "No 3D raster data, RGB or xyz-vector maps are provided. Will only write the geometry"
-#~ msgstr "Aucune données g3d, couches RGB ou vecteur xyz n'ont été indiquées! On écrira uniquement la géométrie."
-#, fuzzy
-#~ msgid "No RGB Data will be created"
-#~ msgstr "Erreur d'ouverture du fichier G3D <%s>. Aucune données RGB ne sera créée."
-#, fuzzy
-#~ msgid "No vector data will be created"
-#~ msgstr "Fichier vecteur à créer"
-#, fuzzy
-#~ msgid "Unable to close top raster map"
-#~ msgstr "Impossible de fermer la couche de sortie"
-#, fuzzy
-#~ msgid "Unable to close bottom raster map"
-#, fuzzy
-#~ msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
-#~ msgstr "Convertir un fichier raster ASCII en couche raster 3D (binaire)."
-#, fuzzy
-#~ msgid "Link to raster map <%s> created"
-#~ msgstr "couche raster <%s> non trouvée"
-#, fuzzy
-#~ msgid "Raster file to be linked"
-#, fuzzy
-#~ msgid "input= and source= are mutually exclusive"
-#~ msgstr "les drapeaux -B & - C sont mutuellement exclusifs. Veuillez n'en choisir qu'un seul."
-#, fuzzy
-#~ msgid "Unable to set window"
-#~ msgstr "Impossible de paramétrer la taille"
-#, fuzzy
-#~ msgid "Exports the color table associated with a raster map layer."
-# c-format
-#, fuzzy
-#~ msgid "Reading file"
-#~ msgstr "\rLecture du fichier '%s'"
-# c-format
-#, fuzzy
-#~ msgid "Unable to read range of raster map <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Unable to read %s"
-#~ msgstr "impossible de créer %s"
-#, fuzzy
-#~ msgid "No raster map specified"
-#~ msgstr "Aucune couche de données spécifiée"
-# c-format
-#, fuzzy
-#~ msgid "Unable to remove color table of raster map <%s>"
-#~ msgstr "Impossible de créer la couche raster <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Color table of raster map <%s> not found"
-#~ msgstr "fichier de cellules albedo <%s> non trouvé"
-#, fuzzy
-#~ msgid "Color table 'random' is not supported for floating point raster map"
-#~ msgstr "Impossible de construire une table de couleurs aléatoire pour les couches en valeurs flottantes"
-#, fuzzy
-#~ msgid "Color table 'grey.eq' is not supported for floating point raster map"
-#~ msgstr "Impossible de construire une table en valeurs de gris pour les couches en valeurs flottantes"
-#, fuzzy
-#~ msgid "Color table 'grey.log' is not supported for floating point raster map"
-#, fuzzy
-#~ msgid "Color table for raster map <%s> set to '%s'"
-#~ msgstr "Table de couleur de [%s] mise à jour à %s"
-#, fuzzy
-#~ msgid "Use G3D mask (if exists) with output map"
-#~ msgstr "Utilisez le masque raster 3D (s'il existe) sur la couche en entrée"
-#, fuzzy
-#~ msgid "Cell file not found"
-#~ msgstr "fichier de cellules non trouvé\n"
-# c-format
-#~ msgid "latin raster map <%s> not found"
-#~ msgstr "fichier de cellules latin <%s> non trouvé"
-#, fuzzy
-#~ msgid "raster, interpolation"
-#, fuzzy
-#~ msgid "Export GRASS raster as non-georeferenced PNG image."
-#, fuzzy
-#~ msgid "Name for output raster map (default: input)"
-#~ msgstr "Titre du fichier raster de sortie"
-#, fuzzy
-#~ msgid "Unable to load 3D raster range"
-#, fuzzy
-#~ msgid "Name of raster map for which to edit null file"
-#~ msgstr "couche raster où remplacer les valeurs null"
-#, fuzzy
-#~ msgid "Unable to update boundaries"
-#~ msgstr "impossible de mettre à jour les limites"
-#, fuzzy
-#~ msgid "Write raster values as z coordinate. Table is not created. Currently supported only for points."
-#~ msgstr "Ecrit les valeurs rasters comme des coordonnées z. La table n'est pas créée. Pour le moment n'existe que pour les points."
-#, fuzzy
-#~ msgid "Name of base raster map"
-#~ msgstr "Nom d'une couche raster"
-#, fuzzy
-#~ msgid "Output basic information about a raster map layer."
-#~ msgstr "Obtenir des informations basiques à propos d'une couche raster donnée."
-#, fuzzy
-#~ msgid "The size of sliding window (odd and >= 3)"
-#~ msgstr "Taille de la fenêtre glissante (impair et >=3)"
-#, fuzzy
-#~ msgid "Nothing to compute. Use at least one of the flags."
-#~ msgstr "Rien à calculer. Veuillez vérifier les paramètres."
-#~ msgid "Input map"
-#~ msgstr "couche source"
-#~ msgid "Use G3D mask (if exists) with input map"
-#, fuzzy
-#~ msgid "Error writing G3D double data"
-# c-format
-#, fuzzy
-#~ msgid "Unable to get header for %s"
-#~ msgstr "Impossible d'écrire l'en-tête de [%s]"
-#, fuzzy
-#~ msgid "Computes topographic correction of reflectance."
-#~ msgstr "Méthode d'interpolation à utiliser"
-#, fuzzy
-#~ msgid "Name of reflectance raster maps to be corrected topographically"
-#~ msgstr "Nom du fichier de relief pour la section croisée"
-#, fuzzy
-#~ msgid "Name (flag -i) or prefix for output raster maps"
-#~ msgstr "Nom de la couche raster cible"
-#, fuzzy
-#~ msgid "Name of input base raster map (elevation or illumination)"
-#, fuzzy
-#~ msgid "Output sun illumination terrain model"
-#~ msgstr "couche raster de sortie"
-#, fuzzy
-#~ msgid "Elevation raster map of unknown type"
-#~ msgstr "Coordonnée d'altitude d'un point sur le plan."
-# c-format
-#, fuzzy
-#~ msgid "Reflectance of raster map <%s> is not of DCELL type - ignored"
-#, fuzzy
-#~ msgid "Calculating covariance matrix..."
-#~ msgstr "Calcul de la matrice de covariance de classe"
-#, fuzzy
-#~ msgid "Rescaling <%s> to range %d,%d..."
-#, fuzzy
-#~ msgid "Bad format in camera file for group <%s>"
-#~ msgid "Error in calculating conversions"
-#~ msgstr "Erreur dans le calcul de conversion"
-#, fuzzy
-#~ msgid "Type of color table (for use with -z flag)"
-#~ msgstr "Nom de la colonne de définition de couleur (pour l'utilisation d'un drapeau -a)"
-#~ msgid "Name of column for line widths (these values will be scaled by wscale)"
-#~ msgstr "Nom de la colonne pour l'épaisseur de la ligne (ces valeurs seront mise à l'échelle par wscale)"
-#~ msgid "Scale factor for wcolumn"
-#~ msgstr "Facteur d'échelle pour wcolumn"
-#~ msgid "Get colors from map table column (of form RRR:GGG:BBB)"
-#~ msgstr "Prendre les couleurs dans la table de la couche (sous forme RRR:GGG:BBB)"
-#~ msgid "Error in color definition column (%s), area %d with cat %d"
-#~ msgstr "Erreur dans la colonne de définition de couleur (%s), entité surfacique %d avec la catégorie %d"
-#, fuzzy
-#~ msgid "Symbol size column not specified."
-#~ msgstr "La colonne de la largeur de ligne n'est pas spécifiée."
-#, fuzzy
-#~ msgid "Symbol size column (%s) is not numeric."
-#~ msgstr "la colonne de largeur de ligne (%s) n'est pas de type nombre"
-#, fuzzy
-#~ msgid "Symbol rotation column not specified."
-#~ msgstr "La colonne de définition de couleur n'est pas spécifiée."
-#, fuzzy
-#~ msgid "Symbol rotation column (%s) is not numeric."
-#~ msgstr "Nom de la colonne (le type doit être numérique)"
-#, fuzzy
-#~ msgid "Unable to read symbol, unable to display points"
-#~ msgstr "Impossible de lire le symbole, impossible d'afficher les points"
-#, fuzzy
-#~ msgid "Interactively edit cell values in a raster map."
-#~ msgstr "Démarrer avec les valeurs de la couche raster"
-#~ msgid "Display information about the active display monitor"
-#~ msgstr "Afficher les informations sur le moniteur actif"
-#~ msgid "Erase the contents of the active display frame with user defined color"
-#~ msgstr "Efface le contenu du moniteur actif avec la couleur choisie par l'utilisateur"
-#~ msgid "Don't add to list of commands in monitor"
-#~ msgstr "Ne pas ajouter à la liste des commandes dans le moniteur"
-#~ msgid "No font selected"
-#~ msgstr "Pas de police sélectionnée"
-#~ msgid "Unable to set size"
-#~ msgid "Name of graphics monitor to start"
-#~ msgstr "Nom du moniteur graphique à démarrer"
-#~ msgid "Name of graphics monitor to stop"
-#~ msgstr "Nom du moniteur graphique à arrêter"
-#~ msgid "Name of graphics monitor to select"
-#~ msgstr "Nom du moniteur graphique à sélectionner"
-#~ msgid "List all monitors"
-#~ msgstr "Lister tous les moniteurs"
-#~ msgid "Print name of currently selected monitor"
-#~ msgstr "Afficher le nom du moniteur sélectionné"
-#~ msgid "Release currently selected monitor"
-#~ msgstr "Désélectionner le moniteur actif"
-#, fuzzy
-#~ msgid "Can also be used to create GRASS locations."
-#~ msgstr "Impossible de créer la table : %s"
-#~ msgid "Print projection information (in conventional GRASS format)"
-#~ msgstr "Afficher l'information de projection (au format conventionnel GRASS)"
-#~ msgid "Georeferenced data file to read projection information from"
-#~ msgstr "Fichier de données géoréférencé où lire la projection"
-#, fuzzy
-#~ msgid "ASCII file containing a WKT projection description (- for stdin)"
-#~ msgstr "Fichier ASCII contenant une description de projection WKT en une ligne (- pour stdin)"
-#~ msgid "PROJ.4 projection description (- for stdin)"
-#~ msgstr "Description de projection PROJ.4 (- pour stdin)"
-# c-format
-#~ msgid "Unable to open file [%s] for reading"
-#~ msgstr "Impossible d'ouvrir le fichier [%s] en lecture"
-#, fuzzy
-#~ msgid "Unable to create location: %s"
-#~ msgid "You must select the PERMANENT mapset before updating the current location's projection. (Current mapset is %s)"
-#~ msgstr "Vous devez sélectionner le jeu de données PERMANENT avant de mettre à jour la projectiondu Secteur courant. (Le jeu de données courant est %s)"
-#, fuzzy
-#~ msgid "Projection information updated!"
-#~ msgstr ""
-#~ "\n"
-#~ "Information de projection mise à jour!\n"
-#~ "\n"
-#, fuzzy
-#~ msgid "Remove base maps"
-#~ msgstr "couche raster de couverture"
-#, fuzzy
-#~ msgid "Changes current mapset."
-#, fuzzy
-#~ msgid "List available mapsets"
-#~ msgstr "Lister les formats disponibles et quitter"
-#, fuzzy
-#~ msgid "The mapset does not exist. Use -c flag to create it."
-#~ msgstr "La couche n'existe pas. Ajouter le drapeau -n pour créer la nouvelle couche."
-#, fuzzy
-#~ msgid "Names of mask files"
-#~ msgstr "Nom du fichier d'étiquettes"
-#, fuzzy
-#~ msgid "Name of output mask file"
-#~ msgstr "Nom de la couche raster cible à afficher"
-#, fuzzy
-#~ msgid "Creates a Voronoi diagram from an input vector map containing points or centroids."
-#~ msgstr "Crée une couche raster et une couche vectorielle contenant des points placés au hasard."
-#, fuzzy
-#~ msgid "Voronoi triangulation..."
-#~ msgstr "Nombre de points à placer"
-#, fuzzy
-#~ msgid "Unknown column type '%s'"
-#~ msgstr "Type de colonne inconnu"
-#, fuzzy
-#~ msgid "Unknown column type '%s' values lost"
-#~ msgid "List available layers in data source and exit"
-#~ msgstr "Lister les couches disponibles dans l'emplacement source et quitter"
-#, fuzzy
-#~ msgid "Counting polygons for %d features..."
-#~ msgid "Importing map %d features..."
-#, fuzzy
-#~ msgid "Merge boundaries:"
-#, fuzzy
-#~ msgid "Find centroids for layer: %s"
-#, fuzzy
-#~ msgid "Input data contains 3D features. Created vector is 2D only, use -z flag to import 3D vector"
-#~ msgstr "Les données en entrée contiennent des objets 3D. Les objets vecteurs créés sont uniquement 2D utilisez le drapeau -z pour importer des objets vectoriels 3D"
-# c-format
-#, fuzzy
-#~ msgid "Cannot read part of geometry"
-#~ msgstr "Impossible d'écrire dans : %s"
-# c-format
-#, fuzzy
-#~ msgid "Cannot write part of geometry"
-#~ msgid "Path to resulting ASCII file or ASCII vector name if '-o' is defined"
-#~ msgstr "Chemin vers le fichier ASCII résultat ou nom du fichier vecteur ASCII si '-o' est défini"
-#, fuzzy
-#~ msgid "End of ascii file reached before end of categories"
-#~ msgstr "Fichier ASCII conservant les coordonnées de transformation"
-# c-format
-#, fuzzy
-#~ msgid "Cannot open driver"
-#~ msgstr "Impossible d'utiliser le pilote %s"
-#, fuzzy
-#~ msgid "Cannot open database"
-#~ msgstr "Impossible d'ouvrir la base de données %s"
-#, fuzzy
-#~ msgid "Cannot find column type"
-#, fuzzy
-#~ msgid "Cannot update table"
-#, fuzzy
-#~ msgid "Form"
-#, fuzzy
-#~ msgid "New record was created.<BR>"
-#~ msgstr "Nouvelle couche vide créée."
-#, fuzzy
-#~ msgid "Record for this category already existed.<BR>"
-#~ msgstr "Pas d'enregistrement pour la catégorie '%d' dans la table"
-#, fuzzy
-#~ msgid "New point"
-#~ msgstr "Afficher"
-#, fuzzy
-#~ msgid "Quit tool"
-#~ msgstr "Silencieux"
-#, fuzzy
-#~ msgid "Out of memory! Point not added."
-#~ msgstr "Mémoire insuffisante"
-#, fuzzy
-#~ msgid "Undo last point"
-#, fuzzy
-#~ msgid "Close line"
-#~ msgstr "Echec de la fermeture."
-#, fuzzy
-#~ msgid "New Point"
-#, fuzzy
-#~ msgid "Undo Last Point"
-#, fuzzy
-#~ msgid "Delete line and exit"
-#~ msgstr "affiche les tables et quitte"
-#, fuzzy
-#~ msgid "Select"
-#~ msgstr "Résolution"
-#, fuzzy
-#~ msgid "Unselect"
-#~ msgstr "Pas de moniteur sélectionné"
-#, fuzzy
-#~ msgid "New location"
-#~ msgstr "Secteur (location) de la base de données"
-#, fuzzy
-#~ msgid "Remove vertex:"
-#~ msgstr "Suppression des centroïdes en doublons..."
-#, fuzzy
-#~ msgid "Select vertex"
-#~ msgstr "Type de donnée vectorielle"
-#, fuzzy
-#~ msgid "New vertex"
-#~ msgstr "Nom du fichier vecoriel composite"
-#, fuzzy
-#~ msgid "Move vertex:"
-# c-format
-#, fuzzy
-#~ msgid "Cannot open driver "
-#, fuzzy
-#~ msgid "Cannot create table: "
-#, fuzzy
-#~ msgid "Cannot create index:\n"
-#~ msgstr "Impossible de créer l'index"
-#, fuzzy
-#~ msgid "Cannot grant privileges on table:\n"
-#~ msgstr "Impossible d'accorder des privilèges sur la table : %s"
-#, fuzzy
-#~ msgid "Cannot create new record."
-#~ msgstr "Impossible de créer la nouvelle table"
-#, fuzzy
-#~ msgid "Database table for this layer is not defined"
-#~ msgstr "La connexion à la base de données n'a pas été définie"
-#, fuzzy
-#~ msgid "Cannot select record from table %s"
-#, fuzzy
-#~ msgid "Display categories:"
-#~ msgstr "%-5d catégories de la ligne lues\n"
-#, fuzzy
-#~ msgid "Select line"
-#, fuzzy
-#~ msgid "Copy attributes:"
-#, fuzzy
-#~ msgid "Select source object"
-#, fuzzy
-#~ msgid "Select the target object"
-#~ msgstr "Fixe la couleur du texte de la légende"
-#, fuzzy
-#~ msgid "Conform and select next"
-#, fuzzy
-#~ msgid "Deselect Target"
-#~ msgstr "Sélectionner les données depuis une base de données."
-#, fuzzy
-#~ msgid "Display attributes:"
-#, fuzzy
-#~ msgid "layer: %d<BR>category: %d<BR>"
-#~ msgstr ""
-#~ "couche: %d\n"
-#, fuzzy
-#~ msgid "Database connection not defined<BR>"
-#, fuzzy
-#~ msgid "driver: %s<BR>database: %s<BR>table: %s<BR>key column: %s<BR>"
-#~ msgstr ""
-#~ "pilote: %s\n"
-#~ "base de données: %s\n"
-#~ "tableau: %s\n"
-#~ "clé primaire : %s\n"
-#, fuzzy
-#~ msgid "Line %d"
-#~ msgstr "Hauteur de la ligne: %f\n"
-#, fuzzy
-#~ msgid "No categories"
-#, fuzzy
-#~ msgid "Cannot delete record: %s"
-#~ msgstr "Impossible d'insérer un nouvel enregistrement : %s"
-# c-format
-#, fuzzy
-#~ msgid "Cannot open driver '%s'<BR>"
-#, fuzzy
-#~ msgid "Cannot open database '%s' by driver '%s'<BR>"
-#~ msgstr "Impossible d'ouvrir la base de données %s avec le pilote %s"
-#, fuzzy
-#~ msgid "Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>"
-#, fuzzy
-#~ msgid "Cannot fetch next record"
-#~ msgstr "Impossible de récupérer la ligne"
-#, fuzzy
-#~ msgid "No database record"
-#, fuzzy
-#~ msgid "Select tool"
-# c-format
-#, fuzzy
-#~ msgid "Cannot set variable code = %d"
-#~ msgstr "Impossible de sélectionner les attributs pour cat = %d"
-#, fuzzy
-#~ msgid "Cannot get type of variable %s"
-#~ msgstr "Impossible d'obtenir la liste des tables: \n"
-# c-format
-#, fuzzy
-#~ msgid "Cannot get code of variable %s"
-#~ msgstr "Impossible de trouver l'en-tête de fichier %s"
-#, fuzzy
-#~ msgid "Cannot get name of variable %d"
-#, fuzzy
-#~ msgid "Cannot get value of variable code = %d"
-#, fuzzy
-#~ msgid "Quit"
-# c-format
-#, fuzzy
-#~ msgid "Pan"
-#~ msgstr "%s\n"
-#, fuzzy
-#~ msgid "New center"
-#~ msgstr "Nouveau schéma"
-# c-format
-#, fuzzy
-#~ msgid "Cannot find window '%s'"
-#~ msgstr "Impossible de trouver le fichier %s"
-#, fuzzy
-#~ msgid "Calculating costs from centres ..."
-#~ msgid "Do not copy table (see also 'new' parameter)"
-#~ msgstr "Ne pas copier la table (voir aussi le paramètre 'new')"
-#, fuzzy
-#~ msgid "Process file <%s> for category numbers"
-#~ msgstr "Traitement du fichier <%s> pour les codes de catégories\n"
-# c-format
-#, fuzzy
-#~ msgid "%d categories loaded from table <%s>"
-#~ msgstr "%d catégories chargées depuis la table"
-#, fuzzy
-#~ msgid "vector, transformation"
-#, fuzzy
-#~ msgid "<%s> has not been created in database."
-#~ msgstr "La table <%s> n'existe pas dans la base de données <%s>"
-#, fuzzy
-#~ msgid "Name of column name with route ids"
-#~ msgstr "Nom de la colonne contenant les essences d'arbres"
-#, fuzzy
-#~ msgid "Name of column name with stop timestamps"
-#~ msgstr "Nom de la colonne contenant les paramètres de lissage"
-#, fuzzy
-#~ msgid "Name of column name with stop ids"
-#, fuzzy
-#~ msgid "Name of column name with walk lengths"
-#~ msgstr "Nom de la colonne contenant la hauteur de l'arbre"
-#, fuzzy
-#~ msgid "Unknown operator"
-#~ msgstr "Type inconnu"
-#, fuzzy
-#~ msgid "vector, import, conversion"
-#~ msgstr "Importation vecteur complète"
-#, fuzzy
-#~ msgid "Copying vector lines..."
-#~ msgstr "Vérification des points vecteurs..."
-#, fuzzy
-#~ msgid "Print topology information only"
-#, fuzzy
-#~ msgid "Name of input DXF file"
-#~ msgid "Name of input vector points map for which to edit attribute table"
-#~ msgstr "Nom de la couche de points vecteurs en entrée pour laquelle mettre à jour la table attributaire"
-#, fuzzy
-#~ msgid "If not given reads from standard input"
-#~ msgstr "Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué prendreles paramètres saisis en ligne de commande"
-#, fuzzy
-#~ msgid "No attribute table found"
-#, fuzzy
-#~ msgid "Cannot parse MySQL embedded database name"
-#~ msgstr "Impossible de parser le nom de la base de données embarquée"
-#, fuzzy
-#~ msgid "Cannot connect to MySQL embedded server: "
-#~ msgstr "Impossible d'initialiser le serveur MySQL embarqué"
-#~ msgid "Cannot scan timestamp: "
-#~ msgstr "Impossible de scanner l'étiquette date&heure: "
-#~ msgid "Cannot scan datetime: "
-#~ msgstr "Impossible de scanner dateheure :"
-#~ msgid "Cannot get list of tables:\n"
-#~ msgid "Unknown option in database definition for "
-#~ msgstr "Option inconnue dans la définition de base de données pour "
-#~ msgid "Cannot recognize boolean value"
-#~ msgstr "Impossible de reconnaître la valeur booléenne"
-#, fuzzy
-#~ msgid "pg driver: PostGIS column '%s', type 'geometry'  will not be converted"
-#~ msgstr "Pilote pg: colonne '%s', type de donnée %d non géré"
-#, fuzzy
-#~ msgid "Removes a table from database."
-#, fuzzy
-#~ msgid "Database schema"
-#~ msgstr "Nom de la base de données"
-#, fuzzy
-#~ msgid "database, connection settings"
-#~ msgid "Uncompressed GNS file from NGA (with .txt extension)"
-#~ msgstr "Fichier GNS décompressé provenant de NGA (avec extension .txt)"
-#, fuzzy
-#~ msgid "Display the HTML man pages of GRASS"
-#, fuzzy
-#~ msgid "vector, raster, statistics"
-#~ msgstr "Statistiques de transition de classe."
-#, fuzzy
-#~ msgid "Base name for red, green and blue output maps containing the blend"
-#~ msgstr "Nom de base pour les couches de sortie rouge, vert, bleu contenant le mélange"
-#, fuzzy
-#~ msgid "Select x11 display monitor for legend"
-#~ msgstr "Sélectionner le moniteur d'affichage de la légende"
-#, fuzzy
-#~ msgid "Name of the column"
-#~ msgstr "Nombre de colonnes"
-#, fuzzy
-#~ msgid "Name of optional EPS output file"
-#~ msgstr "Nom du fichier vecteur de sortie"
-#, fuzzy
-#~ msgid "Join column in map table"
-#, fuzzy
-#~ msgid "Column on which to calculate statistics (must be numeric)"
-#~ msgstr "Nom de la colonne sur laquelle calculée les statistiques (le type doit être numérique)"
-#, fuzzy
-#~ msgid "Import E00 file into a vector map."
-#~ msgstr "Import du fichier E00 en couche vectorielle"
-#~ msgid "LANDSAT red channel"
-#~ msgstr "Canal rouge LANDSAT"
-#~ msgid "LANDSAT green channel"
-#~ msgstr "Canal vert LANDSAT"
-#~ msgid "LANDSAT blue channel"
-#~ msgstr "Canal bleu LANDSAT"
-#, fuzzy
-#~ msgid "Raster input maps"
-#~ msgstr "couche raster d'entrée"
-#, fuzzy
-#~ msgid "Imports geonames.org country files into a GRASS vector points map."
-#~ msgstr "Importer les fichiers pays US-NGA GEOnet Names Server (GNS) dans une couche de points vectoriels GRASS"
-#, fuzzy
-#~ msgid "Uncompressed geonames file from (with .txt extension)"
-#, fuzzy
-#~ msgid "Table to drop"
-#~ msgstr "impossible de poursuivre"
-#~ msgid "SRTM input tile (file without .hgt.zip extension)"
-#~ msgstr "Tuile SRTM en entrée (fichier sans extension .hgt.zip)"
-#, fuzzy
-#~ msgid "Name of aspect raster map"
-#, fuzzy
-#~ msgid "Manually set range (min,max)"
-#~ msgstr "Rang des valeurs entières: min,max"
-#~ msgid "Layer where to add new attribute table"
-#~ msgstr "Couche où ajouter la nouvelle table attributaire"
-#, fuzzy
-#~ msgid "Name of raster map to generate legend from"
-#~ msgstr "Nom de la couche raster à utiliser pour <%s>"
-#~ msgid "Output coordinate file (omit to send to stdout)"
-#~ msgstr "Fichier de coordonnées en sortie (ne pas envoyer vers stdout)"
-#, fuzzy
-#~ msgid "Name of the column to drop"
-#, fuzzy
-#~ msgid "GpsBabel supported output format"
-#~ msgstr "Lister les formats gérés en sor"
-#, fuzzy
-#~ msgid "Prints a graph of the correlation between data layers (in pairs)."
-#~ msgstr "Affiche un graphe de corrélation entre les couches de données (par paires)"
-#~ msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
-#~ msgstr "Tranformation Tasseled Cap (Kauth Thomas) pour les données LANDSAT-TM"
-#~ msgid "use transformation rules for LANDSAT-4"
-#~ msgstr "utiliser les règles de transformation pour LANDSAT-4"
-#~ msgid "use transformation rules for LANDSAT-5"
-#~ msgstr "utiliser les règles de transformation pour LANDSAT-5"
-#~ msgid "use transformation rules for LANDSAT-7"
-#~ msgstr "utiliser les règles de transformation pour LANDSAT-7"
-#~ msgid "raster input map (LANDSAT channel 1)"
-#~ msgstr "Couche raster en entrée (LANDSAT canal 1)"
-#~ msgid "raster input map (LANDSAT channel 2)"
-#~ msgstr "Couche raster en entrée (LANDSAT canal 2)"
-#~ msgid "raster input map (LANDSAT channel 3)"
-#~ msgstr "Couche raster en entrée (LANDSAT canal 3)"
-#~ msgid "raster input map (LANDSAT channel 4)"
-#~ msgstr "Couche raster en entrée (LANDSAT canal 4)"
-#~ msgid "raster input map (LANDSAT channel 5)"
-#~ msgstr "Couche raster en entrée (LANDSAT canal 5)"
-#~ msgid "raster input map (LANDSAT channel 7)"
-#~ msgstr "Couche raster en entrée (LANDSAT canal 7)"
-#, fuzzy
-#~ msgid "general, extensions"
-#~ msgstr "Afficher également les paramètres 3D"
-#, fuzzy
-#~ msgid "List available modules in the GRASS Addons SVN repository"
-#~ msgstr "Lister les couches disponibles et quitter"
-#, fuzzy
-#~ msgid "Name of column used to dissolve common boundaries"
-#~ msgstr "Nom du champ attributaire à utiliser pour les étiquettes"
-#, fuzzy
-#~ msgid "Name of shaded relief or aspect map"
-#~ msgstr "Nom du nouveau fichier raster"
-#, fuzzy
-#~ msgid "Name of raster to drape over relief map"
-# c-format
-#, fuzzy
-#~ msgid "Cannot open driver\n"
-#, fuzzy
-#~ msgid "Cannot open database\n"
-#, fuzzy
-#~ msgid "Cannot describe table\n"
-#~ msgstr "Impossible de décrire la table"
-#~ msgid "Could not close G3D map"
-#~ msgstr "Impossible de fermer la couche G3D"
-#~ msgid "Use g3d mask (if exists) with input map"
-#~ msgid "Could not close G3D map <%s>"
-#~ msgstr "Impossible de fermer la couche G3D <%s>"
-#~ msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
-#~ msgstr "Convertit une couche raster 3D au format VTK-ASCII"
-#~ msgid "Use g3d mask (if exists) with input maps"
-#~ msgstr "Utiliser le masque raster 3D (s'il existe) sur les couches de données en entrée"
-#, fuzzy
-#~ msgid "Use G3D mask (if exists)"
-#~ msgid "Name of an existing raster map layer"
-#~ msgstr "Nom de la couche raster existante"
-#, fuzzy
-#~ msgid "Reading raster map <%s in %s> ..."
-#, fuzzy
-#~ msgid "Error writing row %d"
-#~ msgstr "Erreur d'écriture de la ligne null [%d]"
-#, fuzzy
-#~ msgid "Name of input vector points map"
-#~ msgid "No map specified"
-#, fuzzy
-#~ msgid "Reading data from the map..."
-#~ msgstr "Lecture de la couche raster."
-#~ msgid "Writing attributes ..."
-#~ msgstr "Écriture des attributs..."
-#, fuzzy
-#~ msgid "Threshold distance"
-#~ msgstr "Unités de distance"
-#~ msgid "DXF input file"
-#~ msgstr "Fichier DXF source"
-# c-format
-#, fuzzy
-#~ msgid "Cannot open dxf file <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Unable to delete line %d"
-#~ msgstr "Impossible d'effacer le fichier %s\n"
-#~ msgid "No graphics device selected."
-#~ msgstr "Aucune sortie graphique n'est sélectionnée"
-#, fuzzy
-#~ msgid "Cannot open vector map <%s> at topo level [%d]"
-#~ msgstr "impossible d'ouvrir le fichier vecteur <%s> dans <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Not able to open vector map <%s>"
-#~ msgstr "Impossible d'ouvrir la couche vecteur [%s]"
-# c-format
-#, fuzzy
-#~ msgid "Could not open input file [%s]"
-#~ msgstr "Impossible d'ouvrir le fichier ascii : [%s]"
-#~ msgid "x column name"
-#~ msgstr "Nom de la colonne x"
-# c-format
-#, fuzzy
-#~ msgid "SVG file <%s> cannot be opened"
-#~ msgstr "couche vecteur <%s> introuvable"
-# c-format
-#, fuzzy
-#~ msgid "%s: raster map not found"
-#~ msgstr "%s - couche raster non trouvée"
-#~ msgid "List available formats and exit"
-# c-format
-#~ msgid "Could not find vector '%s'"
-#~ msgstr "Impossible de trouver la couche vecteur %s"
-#~ msgid "Unable to allocate memory."
-#~ msgstr "Impossible d'allouer la mémoire."
-#, fuzzy
-#~ msgid "Path to the input file"
-#~ msgstr "couche raster source"
-#, fuzzy
-#~ msgid "R:G:B value(s) out of range [0..255]: %d:%d:%d"
-#~ msgstr "** attention: la(es) valeur(s) R:V:B est(sont) en dehors des limites [0..255]: %d:%d:%d **\n"
-#, fuzzy
-#~ msgid "Unable to open database %s with driver %s"
-#, fuzzy
-#~ msgid "No lines found"
-#~ msgstr ""
-#~ "\n"
-#~ "Aucune couche DXF trouvée!\n"
-#, fuzzy
-#~ msgid "Interpolation: (%d,%d): Bilinear interpolation..."
-# c-format
-#, fuzzy
-#~ msgid "Cannot select attributes for point #%d"
-#~ msgstr "Impossible de sélectionner des attributs pour l'entité surfacique #%d"
-#, fuzzy
-#~ msgid "Name of input map"
-#~ msgstr "Jeu de données (mapset) de la couche source"
-#~ msgid "Name of elevation raster map"
-#~ msgstr "Nom de la couche raster d'altitude"
-#, fuzzy
-#~ msgid "The column must be type integer or string"
-#~ msgstr "La clef primaire doit être un entier"
-#, fuzzy
-#~ msgid "No input coordinates provided"
-#~ msgstr "Coordonnées de la carte"
-#, fuzzy
-#~ msgid "No features found"
-#~ msgstr ""
-#~ "\n"
-#, fuzzy
-#~ msgid "Name of real-sky beam radiation coefficient input raster map [-]"
-#~ msgstr "Couche raster du coefficient de rayonnement en plein ciel [-]"
-#, fuzzy
-#~ msgid "Name of real-sky diffuse radiation coefficient input raster map [-]"
-#~ msgstr "Couche raster du coefficient de rayonnement diffus en plein ciel [-]"
-#, fuzzy
-#~ msgid "Name for distance output map"
-#~ msgstr "Nom de la couche cible"
-#~ msgid "Reports statistics for raster map layers."
-#~ msgstr "Statistique de couches raster."
-#~ msgid "Name of an output file to hold the report"
-#~ msgstr "Nom du fichier où stocker le résultat"
-#, fuzzy
-#~ msgid "Creates, edits, and lists groups and subgroups of imagery files."
-#~ msgstr "Crée et édite des groupes et sous-groupes de fichiers images"
-#, fuzzy
-#~ msgid ""
-#~ "ERROR: Required parameter <%s> not set:\n"
-#~ "\t(%s)\n"
-#~ msgstr "incidout demande de fixer le paramètre d'heure"
-#, fuzzy
-#~ msgid "db connection was not set by form\n"
-#~ msgstr "La connexion à la base de données n'a pas été définie\n"
-#, fuzzy
-#~ msgid "Name of table created for output when the distance to all flag is used"
-#~ msgstr "Nom de la couche raster dont on veut rééchelonner les valeurs"
-#~ msgid "Fills no-data areas in raster maps using v.surf.rst splines interpolation"
-#~ msgstr "Remplir les zones sans données des couches rasters en utilisant l'interpolation par splines v.surf.rst"
-#~ msgid "unable to open MASK"
-#~ msgstr "impossible d'ouvrir le MASK"
-# c-format
-#~ msgid ""
-#~ "\n"
-#~ " group <%s> not found"
-#~ msgstr ""
-#~ "\n"
-#~ "groupe <%s> non trouvé"
-#~ msgid "raster map <%s> not found"
-#, fuzzy
-#~ msgid "no rules specified"
-#, fuzzy
-#~ msgid "Adding new features to vector file ..."
-#~ msgstr "Écriture du nouveau fichier cats..."
-#~ msgid "visualization, raster, vector, raster3d"
-#~ msgstr "visualisation, raster, vecteur, raster 3D"
-#~ msgid "The '-v' flag is superseded and will be removed in future. Please use '--verbose' instead."
-#~ msgstr "Le drapeau '-v' est caduque et sera supprimé à l'avenir. Merci d'utiliser '--verbose' à la place."
-#~ msgid "Entering script mode ..."
-#~ msgstr "Entrant dans le mode script..."
-#~ msgid "Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and 1 time step)."
-#~ msgstr "Importe des fichiers 3D Vis5D (c.-à-d. des fichiers V5D avec une variable et un pas de temps)."
-#~ msgid "Adding rule: %lf - %lf"
-#~ msgstr "Ajout de la règle : %lf - %lf"
-#~ msgid "Use the same resolution as the input 3D raster map for the 2D outputmaps, independent of the current region settings"
-#~ msgstr "Utiliser la même résolution que la carte raster 3D en entrée pour les cartes 2D en sortie, indépendamment des réglages de la région courante"
-#~ msgid ""
-#~ "Right:  Finish profile and exit\n"
-#~ "\n"
-#~ msgstr "Droit : finir le profil et sortir\n"
-#~ msgid "This does nothing. It is retained for backwards compatibility"
-#~ msgstr "Ceci ne fait rien. C'est maintenu pour la rétrocompatibilité "
-#~ msgid "Unused"
-#~ msgstr "Inutilisé"
-#~ msgid "Maximum memory to be used was smaller than 3 MB, set to default = 300 MB."
-#~ msgstr "La mémoire maximale allouée était inférieure à 3 MB, fixée par défaut à 300 MB."
-#~ msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead."
-#~ msgstr "Le drapeau '-q' est caduque et sera supprimé à l'avenir. Merci d'utiliser '--quiet' à la place."
-#~ msgid "raster, export"
-#~ msgstr "raster, exportation"
-#~ msgid "NULL value computed (row %d, col %d)"
-#~ msgstr "valeurs NULL calculées (ligne%d,  col %d)"
-#~ msgid "Illegal delete request"
-#~ msgstr "Requête de suppression illégale"
-#~ msgid "Bad start cell"
-#~ msgstr "Mauvaise cellule de départ"
-#~ msgid "Not yet implemented!"
-#~ msgstr "Pas encore implanté !"
-#~ msgid "An output raster map needs to be defined with method '%s'"
-#~ msgstr "Une carte raster de sortie doit être définie avec la méthode '%s'"
-#~ msgid "Stream width (in meters). Default is raster cell width"
-#~ msgstr "Largeur du courant (en mètres). Largeur de cellule raster par défaut"
-#~ msgid "Do not build vector topology (use with care for massive point export)"
-#~ msgstr "Ne pas construire la topologie de vecteur (à utiliser avec précaution pour l'export massif de points)"
Modified: grass/trunk/locale/po/grassmods_hi.po
--- grass/trunk/locale/po/grassmods_hi.po	2012-05-26 15:22:06 UTC (rev 51802)
+++ grass/trunk/locale/po/grassmods_hi.po	2012-05-26 15:46:05 UTC (rev 51803)
@@ -35302,10117 +35302,3 @@
 #, fuzzy
 msgid "Percent to brighten"
 msgstr "पूर्ण."
-#, fuzzy
-msgid "Input raster map with specific yield in [1/m]"
-msgstr "नहीं."
-#, fuzzy
-msgid "Raster map <%s> is not valid"
-msgstr "नहीं"
-#, fuzzy
-msgid "If not given read from standard input"
-msgstr "नहीं"
-#, fuzzy
-msgid "Print basic info in shell script style"
-msgstr "छापें"
-#, fuzzy
-msgid "Projection:"
-msgstr "नक़ल"
-#, fuzzy
-msgid "relative"
-msgstr "का"
-#, fuzzy
-msgid "Raster map for which to edit null file"
-msgstr "के लिए"
-#, fuzzy
-msgid "Join column in table"
-msgstr "अज्ञात क़िस्म"
-#, fuzzy
-msgid "Unable to parse '%s'\n"
-msgstr "फ़ाइल"
-#, fuzzy
-msgid "Driver <%s> doesn't support creating new fields"
-msgstr "समूह नहीं बनाया जा रहा है."
-#, fuzzy
-msgid "Unable to add new field <%s>"
-msgstr "के लिए"
-#, fuzzy
-msgid "Name of raster map from which to copy color table"
-msgstr "नक़ल"
-#, fuzzy
-msgid "Name of file containing rules"
-msgstr "फ़ाइल"
-#, fuzzy
-msgid "Creating support files for <%s>"
-msgstr "बनाया जा रहा है के लिए"
-#, fuzzy
-msgid "Title for new raster file."
-msgstr "के लिए"
-#, fuzzy
-msgid "Unable it load G3d range"
-msgstr "का"
-#, fuzzy
-msgid "Exports the color table associated with a raster3d map layer."
-msgstr "a."
-#, fuzzy
-msgid "Could not close RASTER3D map"
-msgstr "नहीं"
-#, fuzzy
-msgid "Could not close RASTER3D map <%s>"
-msgstr "नहीं"
-#, fuzzy
-msgid "Name for v5d output file"
-msgstr "के लिए"
-#, fuzzy
-msgid "Lists available GIS elements of the user-specified data type."
-msgstr "बेस का."
-#, fuzzy
-msgid "Remove dangles:"
-msgstr "के लिए n"
-#, fuzzy
-msgid "Unable to create 3D vector and attribute table at same time"
-msgstr "के लिए"
-#, fuzzy
-msgid "Coordinates"
-msgstr "के लिए"
-#, fuzzy
-msgid "Vector map for which to drop vector objects"
-msgstr "का के लिए संपादन (_E)"
-#, fuzzy
-msgid "Layer of attribute table to use for selection"
-msgstr "का के लिए"
-#, fuzzy
-msgid "Overwrite existing file"
-msgstr "डाटाटाइप."
-#, fuzzy
-msgid "Name of input vector polygon map"
-msgstr "का"
-#, fuzzy
-msgid "Name of MODIS product"
-msgstr "का"
-#, fuzzy
-msgid "The names of tile/s to download"
-msgstr "संख्या का"
-#, fuzzy
-msgid "raster, import, copying"
-msgstr "ट्रेस"
-#, fuzzy
-msgid "raster, export, copying"
-msgstr "का"
-#, fuzzy
-msgid "Name for output shaded relief map"
-msgstr "का"
-#, fuzzy
-msgid "zenith"
-msgstr "f n"
-#, fuzzy
-msgid "topographic correction method"
-msgstr "है n"
-#, fuzzy
-msgid "Elevation file of unknown type"
-msgstr "एक."
-#, fuzzy
-msgid "Cannot allocate memory for auxiliar matrix.Consider changing region (resolution)"
-msgstr "के लिए"
-#, fuzzy
-#~ msgid "Input grid3 filename"
-#~ msgstr "फ़ाइलनाम "
-#, fuzzy
-#~ msgid "Grid3 <%s> not found %s"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Print raster map resolution (NS-res, EW-res) only"
-#~ msgstr "छापें"
-#, fuzzy
-#~ msgid "Print raster map type only"
-#~ msgstr "छापें"
-#, fuzzy
-#~ msgid "Print map region only"
-#~ msgstr "छापें"
-#, fuzzy
-#~ msgid "Print raster map data units only"
-#~ msgstr "छापें"
-#, fuzzy
-#~ msgid "Print raster map vertical datum only"
-#~ msgstr "छापें"
-#, fuzzy
-#~ msgid "Print map title only"
-#~ msgstr "छापें"
-#, fuzzy
-#~ msgid "Print raster map timestamp (day.month.year hour:minute:seconds) only"
-#~ msgstr "छापें माह वर्ष घंटा"
-#, fuzzy
-#~ msgid "Name for value output map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Invalid timestamp"
-#~ msgstr "के लिए थीटा"
-#, fuzzy
-#~ msgid "Reading sites..."
-#~ msgstr "छवि "
-#, fuzzy
-#~ msgid "Writing sites to output..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Reading coordinates from file."
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "ASCII file holding transform coordinates"
-#~ msgstr "के लिए ज़ेड"
-#, fuzzy
-#~ msgid "Unable to open file with coordinates <%s>"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Error reading coordinates file"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Number of points that have been entered [%d]"
-#~ msgstr "का n"
-#, fuzzy
-#~ msgid "Error creating transformation"
-#~ msgstr "संख्या के लिए"
-#, fuzzy
-#~ msgid "You need to enter at least %d points."
-#~ msgstr "पर."
-#, fuzzy
-#~ msgid "Cannot scan date: "
-#~ msgstr "स्रोत"
-#, fuzzy
-#~ msgid "Cannot scan time: "
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Cannot allocate cursor."
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Cannot ad new token."
-#~ msgstr "फील्ड"
-#, fuzzy
-#~ msgid "Cannot select data: \n"
-#~ msgstr "स्रोत"
-#, fuzzy
-#~ msgid "Unable allocate memory for row buffer"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Computing means for band %d..."
-#~ msgstr "नक़ल"
-#, fuzzy
-#~ msgid "Computing row %d (of %d) of covariance matrix..."
-#~ msgstr "माट्रिक्स."
-#, fuzzy
-#~ msgid "Unable to allocate memory for row buffer"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Unable to allocate memory for raster row"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Transforming <%s>..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Surface area estimation for rasters."
-#~ msgstr "सतह के लिए."
-#, fuzzy
-#~ msgid "Raster file for surface"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Writing buffers..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "ASCII file to be converted to binary vector map"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Join column in other table"
-#~ msgstr "अज्ञात क़िस्म"
-#, fuzzy
-#~ msgid "Layer number or name with route paths or -1"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Layer %d - no table"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Layer %d - unable to copy table"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Source layer number or name"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Sink layer number or name"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Name of Arc cost column"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "From layer number or name"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "To layer number or name"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Name of node capacity column"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Set1 layer number or name"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Set2 layer number or name"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Either mapset= or -l must be used"
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Line width column (%s) is not numeric."
-#~ msgstr "है नहीं का संख्या"
-#, fuzzy
-#~ msgid "Can't read vector map"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "pg driver: column '%s', type %d  is not supported"
-#~ msgstr "है नहीं"
-#, fuzzy
-#~ msgid "Type of color table"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Save placeholder raster map for use with d.legend"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name for input source not specified"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name for output raster map not specified"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Requested g3d map <%s> not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Error opening g3d map <%s>"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "Negative or no data pixel found. This module is not yet able to process no data holes in a map, please fill with r.fillnulls or other algorithms"
-#~ msgstr "ऋणात्मक मॉडयूल है नहीं a अन्य."
-#, fuzzy
-#~ msgid "Features"
-#~ msgstr "विशेषता"
-#, fuzzy
-#~ msgid "Measure of Correlation-1"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Measure of Correlation-2"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Write the result to g3d map <%s>"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Requested 3d raster map not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Error closing new ASCII file"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "modifyNull: error opening map"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "modifyNull: error closing map"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "makeMask: error opening map."
-#~ msgstr "त्रुटि."
-#, fuzzy
-#~ msgid "makeMask: error opening g3d mask file"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "makeMask: error closing g3d mask file"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "makeMask: error closing map"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "Requested 3d raster map <%s> not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Requested g3d RGB map <%s> not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Requested g3d vector map <%s> not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Open rgb 3d raster map %s"
-#~ msgstr "खोलें"
-#, fuzzy
-#~ msgid "Error closing g3d rgb map."
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "Error closing g3d vector map."
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "write_vtk_rgb_data: writing rgb data"
-#~ msgstr "बिन्दु"
-#, fuzzy
-#~ msgid "write_vtk_vector_data: writing vector data"
-#~ msgstr "बिन्दु"
-#, fuzzy
-#~ msgid "Error closing new 3d raster map"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "Error closing ascii file"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "Error: couldn't create %s"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "Error while writing grid. Disk full?"
-#~ msgstr "त्रुटि?"
-#, fuzzy
-#~ msgid "Name for output flowline density raster map"
-#~ msgstr "घनत्व"
-#, fuzzy
-#~ msgid "Create/Edit"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Create new projection files (modifies current location unless 'location' option specified)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Location %s created!"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Print mapset names"
-#, fuzzy
-#~ msgid "Force remove"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Color to erase with, either a standard GRASS color or R:G:B triplet (separated by colons)"
-#~ msgstr "a R जी"
-#, fuzzy
-#~ msgid "Layer: %s"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Break polygons:"
-#~ msgstr "प्लाट"
-#, fuzzy
-#~ msgid "Remove duplicates:"
-#~ msgstr "के लिए n"
-#, fuzzy
-#~ msgid "Write centroids:"
-#~ msgstr "छापें"
-#, fuzzy
-#~ msgid "Cannot calculate centroid"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Unknown icon marker"
-#, fuzzy
-#~ msgid "Verbose mode"
-#~ msgstr "बड़बोला"
-#, fuzzy
-#~ msgid "Input type point, line or area"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name for output vector map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of raster plane to be created"
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "vector, interpolation, kriging"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Verbosity level"
-#~ msgstr "बड़बोला."
-#, fuzzy
-#~ msgid "Name for output raster map prefix (e.g. 'brov')"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "raster input map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "reclass raster output map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Vector map to modify"
-#~ msgstr "छापें"
-#, fuzzy
-#~ msgid "Layer in the vector to be modified"
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Vector map to be queried"
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Layer of the query vector containing data"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Column to be queried"
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Name of input vector map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Vector map to edit the attribute table for"
-#~ msgstr "का के लिए संपादन (_E)"
-#, fuzzy
-#~ msgid "Column to update"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Column to query"
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Raster map to use as mask"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Vector map for which to rename attribute column"
-#, fuzzy
-#~ msgid "Layer where to rename column"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "GRASS table name"
-#~ msgstr "डाटाबेस नाम"
-#, fuzzy
-#~ msgid "vector, import"
-#~ msgstr "सदिश"
-#, fuzzy
-#~ msgid "Field separator"
-#~ msgstr "फील्ड"
-#, fuzzy
-#~ msgid "display, vector, thematic, legend"
-#~ msgstr "गामा."
-#, fuzzy
-#~ msgid "vector, topology"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Name of vector map for which to edit attribute table"
-#, fuzzy
-#~ msgid "Table from which to drop attribute column"
-#, fuzzy
-#~ msgid "Raster map in which to fill nulls"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Vector map from which to remove attribute table"
-#, fuzzy
-#~ msgid "Name of existing attribute table (default: vector map name)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Layer from which to drop linked attribute table"
-#, fuzzy
-#~ msgid "Vector map for which to drop attribute column"
-#, fuzzy
-#~ msgid "Layer where to drop column"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "raster output TC maps prefix"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Vector map for which to add new attribute table"
-#, fuzzy
-#~ msgid "vector, import, wfs"
-#~ msgstr "सदिश"
-#, fuzzy
-#~ msgid "Name of data table"
-#~ msgstr "का a"
-#, fuzzy
-#~ msgid "Database/directory for table"
-#~ msgstr "नहीं के लिए"
-#, fuzzy
-#~ msgid "Database driver"
-#, fuzzy
-#~ msgid "Cannot open file [%s] in mapset [%s]"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Cannot create file <%s> in mapset <%s>"
-#~ msgstr "डाटाटाइप."
-#, fuzzy
-#~ msgid "basemap"
-#, fuzzy
-#~ msgid "method"
-#, fuzzy
-#~ msgid "Cannot allocate memory for auxiliar matrix.Consider changing region resolution"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Verbose module output"
-#~ msgstr "बड़बोला चालू."
-#, fuzzy
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Unable to determine raster cell type"
-#~ msgstr "का a"
-#, fuzzy
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Unable to read raster row"
-#~ msgstr "का a"
-#, fuzzy
-#~ msgid "Raster file(s) for View%d"
-#~ msgstr "के लिए दृश्य"
-#, fuzzy
-#~ msgid "Unable to read file header of <%s>"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Unable to read raster map <%s> row %d"
-#~ msgstr "के लिए."
-#, fuzzy
-#~ msgid "Failed writing raster map <%s>"
-#~ msgstr "i n"
-#, fuzzy
-#~ msgid "raster3d, voxel, import"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Recharge raster map in m^3/s"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "raster3d, voxel, export"
-#~ msgstr "Bin"
-#, fuzzy
-#~ msgstr "a पाठ"
-#, fuzzy
-#~ msgid ""
-#~ msgstr ""
-#~ "\n"
-#~ " जी."
-#, fuzzy
-#~ msgid "Unable to write raster row"
-#~ msgstr "का a"
-#, fuzzy
-#~ msgid "Unable to close output map"
-#~ msgstr "i n"
-#, fuzzy
-#~ msgstr "i n"
-#, fuzzy
-#~ msgid "Unable to get elevation raster row"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Elevation map not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Unable to open elevation map"
-#~ msgstr "ज़ेड"
-#, fuzzy
-#~ msgid "Unable to create raster map"
-#~ msgstr "का a"
-#, fuzzy
-#~ msgid "Unable to close elevation map"
-#~ msgstr "ज़ेड"
-#, fuzzy
-#, fuzzy
-#~ msgstr "का"
-#, fuzzy
-#~ msgstr "का a"
-#, fuzzy
-#~ msgstr "का a"
-#, fuzzy
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Could not open map %s"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgstr "का."
-#, fuzzy
-#~ msgstr "का"
-#, fuzzy
-#~ msgstr "का a"
-#, fuzzy
-#~ msgstr "का a"
-#, fuzzy
-#~ msgstr "a पाठ a "
-#, fuzzy
-#~ msgid "raster3d, voxel, statistics"
-#~ msgstr "वस्तु."
-#, fuzzy
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Unable to write quant file"
-#~ msgstr "बनाया जा रहा है."
-#, fuzzy
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "raster, import"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Link GDAL supported raster file to a binary raster map layer."
-#~ msgstr "आयात a."
-#, fuzzy
-#~ msgstr "सदिश"
-#, fuzzy
-#~ msgstr "सेट आकार "
-#, fuzzy
-#~ msgid "raster, resample"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Bilinear interpolation utility for raster map layers."
-#~ msgstr "द्विरेखीय के लिए."
-#, fuzzy
-#~ msgid "Specific input value to be assigned to the north and/or south poles for longitude-latitude grids"
-#~ msgstr "उत्तर दक्षिण के लिए"
-#, fuzzy
-#~ msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
-#~ msgstr "स्केल है स्केल."
-#, fuzzy
-#~ msgid "%s: base raster map not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "%s: cover raster map not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "raster, profile"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Use mouse to select Start Point\n"
-#~ msgstr "आकार "
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Use mouse to draw profile line\n"
-#~ msgstr "आकार "
-#, fuzzy
-#~ msgid "Buttons:\n"
-#~ msgstr "n n"
-#, fuzzy
-#~ msgid "Left:   Mark next point\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "raster, sun energy"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Horizon file no. %d <%s> not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "unable to open elevation map layer"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "unable to open runoff map layer"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "unable to open depression map layer"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "unable to open blocking map layer"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "unable to open rill map layer"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "unable to open new accum map layer."
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Close failed."
-#~ msgstr "नक़ल"
-#, fuzzy
-#~ msgid "unable to open new aspect map layer."
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "unable to open new LS factor map layer."
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "unable to open new S factor map layer."
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "unable to open flow accumulation map layer"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "unable to open accum file in valid_basins()"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "raster, hydrology"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Watershed basin analysis program"
-#~ msgstr "प्रोग्राम."
-#, fuzzy
-#~ msgid "Name of input raster map with real depressions"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of input raster map blocking overland surface flow"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Name for output raster map useful for visual display of results (DEPRECATED)"
-#~ msgstr "के लिए का"
-#, fuzzy
-#~ msgid "raster, export, color table"
-#~ msgstr "का"
-#, fuzzy
-#~ msgstr "a."
-#, fuzzy
-#~ msgid "Direction raster found <%s>"
-#~ msgstr "i n"
-#, fuzzy
-#~ msgid "Cannot open raster map <%s>"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "raster, geomorphology"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Cannot write category file for raster map <%s>"
-#~ msgstr "संपादन के लिए "
-#, fuzzy
-#~ msgid "Raster file [%s] not found. Exiting."
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "History file for [%s] updated."
-#, fuzzy
-#~ msgid "History file for [%s] not updated."
-#~ msgstr "के लिए नहीं."
-#, fuzzy
-#~ msgid "Edit header for [%s]\n"
-#~ msgstr "संपादन के लिए n"
-#, fuzzy
-#~ msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
-#~ msgstr "है a का संपादन (_E) चालू."
-#, fuzzy
-#~ msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
-#~ msgstr "है a का संपादन (_E)!"
-#, fuzzy
-#~ msgid "Raster file [%s] is empty."
-#~ msgstr "है."
-#, fuzzy
-#~ msgid "Error reading raster map [%s]."
-#, fuzzy
-#~ msgid "cellhd compression: %d\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "3.0 compression %sindicated\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Pre 3.0 compression %sindicated\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "[%s] appears to be compressed. Is it? "
-#~ msgstr "है "
-#, fuzzy
-#~ msgid "Please indicate the type of compression:\n"
-#~ msgstr "का n"
-#, fuzzy
-#~ msgid "  1. Pre 3.0 compression\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "  2. 3.0 compression\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "The header for [%s] says the file is not compressed. "
-#~ msgstr "के लिए है नहीं "
-#, fuzzy
-#~ msgid "The file appears to be compressed.\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Most likely the header is wrong, but I want you to decide.\n"
-#~ msgstr "है n"
-#, fuzzy
-#~ msgid "The header for [%s] says the file is compressed. "
-#~ msgstr "के लिए है "
-#, fuzzy
-#~ msgid "The file does NOT appear to be compressed.\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Unable to write header for [%s]."
-#, fuzzy
-#~ msgid "Header for raster map [%s] updated."
-#, fuzzy
-#~ msgid "Please enter the following information for [%s]:"
-#~ msgstr "के लिए:"
-#, fuzzy
-#~ msgid "        Number of rows"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "        Number of cols"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "        Number of bytes per cell"
-#~ msgstr "का बाइट्स"
-#, fuzzy
-#~ msgid "        Floating point map"
-#~ msgstr "फ्लोटिंग बिन्दु"
-#, fuzzy
-#~ msgid "rows * cols * bytes per cell must be same as file size (%lu)"
-#~ msgstr "बाइट्स आकार "
-#, fuzzy
-#~ msgid "** Negative values not allowed!"
-#~ msgstr "ऋणात्मक नहीं!"
-#, fuzzy
-#~ msgid "** Positive values only please!"
-#~ msgstr "धनात्मक!"
-#, fuzzy
-#~ msgid "Category file for <%s> not updated"
-#, fuzzy
-#~ msgid "Category file for <%s> updated"
-#, fuzzy
-#~ msgid "Update the statistics (histogram, range) for [%s]? "
-#~ msgstr "के लिए "
-#, fuzzy
-#~ msgid "raster, metadata"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Not enough room in history file"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Edit header for [%s]? "
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "NOTE: [%s] is a reclass of [%s in %s]"
-#~ msgstr "है a का"
-#, fuzzy
-#~ msgid "Canceling from edit header."
-#~ msgstr "संपादन (_E)."
-#, fuzzy
-#~ msgid "Edit the category file for [%s]? "
-#, fuzzy
-#~ msgid "Create/Update the color table for [%s]? "
-#, fuzzy
-#~ msgid "Edit the history file for [%s]? "
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "The null file for [%s] may indicate that some cells contain\n"
-#~ " no data. If the null file for [%s] doesn't exist, zero cells in\n"
-#~ " it are treated by GRASS application programs as no data."
-#~ msgstr ""
-#~ "के लिए रखे हुए\n"
-#~ " के लिए\n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Do you want to create/reset the null file for [%s] so that null cell values are considered valid data? "
-#, fuzzy
-#~ msgid "Error writing null row [%d]."
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Do you want to delete the null file for [%s]\n"
-#~ "(all zero cells will then be considered no data)? "
-#~ msgstr "के लिए n सभी "
-#, fuzzy
-#~ msgid "Which raster map needs a color table"
-#~ msgstr "a"
-#, fuzzy
-#~ msgid "Color table for <%s> updated"
-#, fuzzy
-#~ msgid "Name for output direction map for depressionless elevation raster map"
-#~ msgstr "i आयताकार"
-#, fuzzy
-#~ msgid "raster, distance"
-#~ msgstr "का"
-#, fuzzy
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "raster, export, animation"
-#~ msgstr "ट्रेस"
-#, fuzzy
-#~ msgid "Raster File Series to MPEG Conversion."
-#~ msgstr "फ़ाइल."
-#, fuzzy
-#~ msgid "Quiet - suppress progress report"
-#~ msgstr "शांत"
-#, fuzzy
-#~ msgid "(requires r.out.ppm with stdout option)"
-#~ msgstr "चालू कम डिस्क n"
-#, fuzzy
-#~ msgid "raster, geometry"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "One or more input raster maps not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "raster, quantization"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Quant table not changed for %s"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Unable to find row %d, col %d: %f"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "%s higher above pointer wrong"
-#~ msgstr "ऊंचाई"
-#, fuzzy
-#~ msgid "Unable to read current window parameters"
-#~ msgstr "छापें"
-#, fuzzy
-#~ msgid "Failed to guess site file format\n"
-#~ msgstr "है n"
-#, fuzzy
-#~ msgid "No data"
-#~ msgstr "का a"
-#, fuzzy
-#~ msgid "Error writing category file for <%s>"
-#~ msgstr "त्रुटि के लिए."
-#, fuzzy
-#~ msgid "Error writing color file for <%s>"
-#, fuzzy
-#~ msgid "Unable to read row %i\n"
-#~ msgstr "i n"
-#, fuzzy
-#~ msgid "RGB raster map <%s> not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Vector cell map <%s> not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "raster, recode category"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Data range of raster map <%s> is empty"
-#, fuzzy
-#~ msgid "Data range of raster map <%s> is %s to %s (entire map)"
-#~ msgstr "है n"
-#, fuzzy
-#, fuzzy
-#~ msgid "Integer data range of raster map <%s> is empty"
-#, fuzzy
-#~ msgid "Integer data range of raster mao <%s> is %d to %d"
-#~ msgstr "है n"
-#, fuzzy
-#~ msgid "'%s' is not a valid rule"
-#~ msgstr "सीमा कम के बराबर नहीं."
-#, fuzzy
-#~ msgid "%s: running %s command"
-#~ msgstr "त्रुटि चल रहा है..."
-#, fuzzy
-#~ msgid "%s: unable to open temporary file"
-#, fuzzy
-#~ msgid "Resultant raster map (not used with 'distribution')"
-#~ msgstr "नहीं वितरण"
-#, fuzzy
-#~ msgid "raster, rescale"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "raster, viewshed"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Failed writing raster map <%s> row %d"
-#, fuzzy
-#~ msgid "raster, color transformation"
-#, fuzzy
-#~ msgid "Error reading 'hue' map"
-#, fuzzy
-#~ msgid "Error reading 'intensity' map"
-#, fuzzy
-#~ msgid "Error reading 'saturation' map"
-#, fuzzy
-#~ msgid "Unable to write color table for %s"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Name of raster map to contain results"
-#~ msgstr "का रखे हुए"
-#, fuzzy
-#~ msgid "Number of the segment to create (segment library)"
-#~ msgstr "का खण्ड खण्ड"
-#, fuzzy
-#~ msgid "Nseg is %d"
-#~ msgstr "है"
-#, fuzzy
-#~ msgid "Null cells excluded from cost evaluation."
-#~ msgstr "शून्य (Null)."
-#, fuzzy
-#~ msgid "Unable to find starting vector <%s> "
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Unable to find stop vector <%s>"
-#, fuzzy
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "DTM_Source map is: Integer cell type"
-#~ msgstr "है पूर्णांक"
-#, fuzzy
-#~ msgid "DTM_Source map is: Floating point (float) cell type"
-#~ msgstr "है फ्लोटिंग बिन्दु"
-#, fuzzy
-#~ msgid "DTM_Source map is: Floating point (double) cell type"
-#, fuzzy
-#~ msgid "COST_Source map is: Integer cell type"
-#, fuzzy
-#~ msgid "COST_Source map is: Floating point (float) cell type"
-#, fuzzy
-#~ msgid "COST_Source map is: Floating point (double) cell type"
-#, fuzzy
-#~ msgid "Output map is: Integer cell type"
-#, fuzzy
-#~ msgid "Output map is: Floating point (float) cell type"
-#, fuzzy
-#~ msgid "Output map is: Floating point (double) cell type"
-#, fuzzy
-#~ msgid "Unable to allocate memory for segment fbuff == NULL"
-#~ msgstr "के लिए खण्ड"
-#, fuzzy
-#~ msgid "Raster output map <%s> not found (no start_points given)"
-#~ msgstr "नहीं प्रारंभ"
-#, fuzzy
-#~ msgid "Memory allocation error on reading start points from raster map %s"
-#~ msgstr "त्रुटि चालू प्रारंभ"
-#, fuzzy
-#~ msgid "End of map!"
-#~ msgstr "का!"
-#, fuzzy
-#~ msgid "Will copy input map null values into output map"
-#~ msgstr "नक़ल"
-#, fuzzy
-#~ msgid ""
-#~ "Integer cell type.\n"
-#~ "Writing..."
-#~ msgstr "पूर्णांक."
-#, fuzzy
-#~ msgid ""
-#~ "Float cell type.\n"
-#~ "Writing..."
-#~ msgstr "फ्लोट."
-#, fuzzy
-#~ msgid ""
-#~ "Double cell type.\n"
-#~ "Writing..."
-#~ msgstr "दोगुना."
-#, fuzzy
-#~ msgid "Peak cost value: %f"
-#~ msgstr "f"
-#, fuzzy
-#~ msgid "raster, querying"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "raster, DEM, contours, vector"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Suppress single crossing error messages"
-#~ msgstr "एकल त्रुटि"
-#, fuzzy
-#~ msgid "raster, series"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Unable to open raster map <%s> in mapset <%s>"
-#, fuzzy
-#~ msgid "<%s> is an ilegal name"
-#~ msgstr "है"
-#, fuzzy
-#~ msgid "Unable to write color table for raster map <%s>"
-#, fuzzy
-#~ msgid "raster, random, surface"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "raster, import, LIDAR"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Writing map, row %d"
-#~ msgstr "i n"
-#, fuzzy
-#~ msgid "raster, composite"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Error reading raster map <%s>"
-#, fuzzy
-#~ msgid "raster, volume"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Unable to find data map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Unable to find clump map"
-#, fuzzy
-#~ msgid "Data or Clump file not open"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Unable to read header of raster map <%s>"
-#, fuzzy
-#~ msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster map layer."
-#~ msgstr "a."
-#, fuzzy
-#~ msgid "Can't set window"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Name for output elevation raster map after filling"
-#~ msgstr "का मीटर्स"
-#, fuzzy
-#~ msgid "Name for output direction raster map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Cannot read raster row %d"
-#~ msgstr "i n"
-#, fuzzy
-#~ msgid "raster, map algebra"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Apply filter only to zero data values"
-#~ msgstr "लागू करें फ़िल्टर"
-#, fuzzy
-#~ msgid "Raster map matrix filter."
-#~ msgstr "माट्रिक्स फ़िल्टर."
-#, fuzzy
-#~ msgid "Name of filter file"
-#~ msgstr "का फ़िल्टर"
-#, fuzzy
-#~ msgid "Unable to read raster map row %d "
-#, fuzzy
-#~ msgid "Failed writing raster map row %d"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "raster, statistics, reclass"
-#~ msgstr "वस्तु."
-#, fuzzy
-#~ msgid "raster, color table"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Creates/modifies the color table associated with a raster map layer."
-#~ msgstr "a."
-#, fuzzy
-#~ msgid "Path to rules file (\"-\" to read rules from stdin)"
-#~ msgstr "उत्तर पूर्व"
-#, fuzzy
-#~ msgstr "नहीं."
-#, fuzzy
-#, fuzzy
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgstr "है के लिए बिन्दु!"
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#~ msgid "Could not get raster row"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "raster, volume, conversion"
-#~ msgstr "ट्रेस"
-#, fuzzy
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Unable to close input map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of the latitudes input raster map [decimal degrees]"
-#~ msgstr "का कोण"
-#, fuzzy
-#~ msgid "A single value of latitude [decimal degrees]"
-#~ msgstr "एकल का कोण"
-#, fuzzy
-#~ msgid "Name of real-sky beam radiation coefficient raster map [-]"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of real-sky diffuse radiation coefficient raster map [-]"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "elevin raster map <%s> not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "aspin raster map <%s> not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "slopein raster map <%s> not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "linkein raster map <%s> not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "albedo raster map <%s> not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "coefbh raster map <%s> not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "coefdh raster map <%s> not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Unable to create raster map %s"
-#~ msgstr "का a"
-#, fuzzy
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Surface generation program from rasterized contours."
-#~ msgstr "सतह प्रोग्राम."
-#, fuzzy
-#~ msgid "Name of existing raster map containing contours"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Import a binary raster file into a GRASS raster map."
-#~ msgstr "आयात a a."
-#, fuzzy
-#~ msgid "Illegal output file name <%s>"
-#~ msgstr "चेतावनी."
-#, fuzzy
-#~ msgid "raster, export, png"
-#~ msgstr "का"
-#, fuzzy
-#~ msgstr "आयात छवि."
-#, fuzzy
-#~ msgid "Unable to read raster map row %d"
-#, fuzzy
-#~ msgid "[%s]: Map is the wrong resolution"
-#~ msgstr "है"
-#, fuzzy
-#~ msgid "Cannot get row %d (error = %d)"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "Cannot set region to back to the initial region !!!"
-#~ msgstr "सेट पृष्ठ!"
-#, fuzzy
-#~ msgid "Not enough memory for zero_array_cell"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Not enough disk space -- cannot write files"
-#~ msgstr "डिस्क"
-#, fuzzy
-#~ msgid "raster, map management"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Error reading input"
-#, fuzzy
-#~ msgid "raster, projection, transformation"
-#, fuzzy
-#~ msgid "Re-projects a raster map from one location to the current location."
-#~ msgstr "a एक."
-#, fuzzy
-#~ msgstr "शीर्षक"
-#, fuzzy
-#~ msgid "Resolution of output map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Cannot read raster row [%d] from raster map <%s>"
-#, fuzzy
-#~ msgid "Cannot read raster row [%d] from cover raster map <%s>"
-#, fuzzy
-#~ msgid "Cannot read raster row [%d]"
-#~ msgstr "i n"
-#, fuzzy
-#~ msgid "Cannot read cover raster row [%d]"
-#~ msgstr "i n"
-#, fuzzy
-#~ msgid "raster, random"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "raster, fire"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Raster map <%s> already exists in mapset <%s>, select another name"
-#~ msgstr "समूह."
-#, fuzzy
-#~ msgid "Name of raster map to contain results (several new layers)"
-#, fuzzy
-#~ msgid "Percent Completed ... "
-#~ msgstr "पूर्ण."
-#, fuzzy
-#~ msgid "Reading row %d"
-#~ msgstr "n"
-#, fuzzy
-#~ msgstr "का a"
-#, fuzzy
-#~ msgid "Unable to create distance map <%s>"
-#, fuzzy
-#~ msgid "Unable to create value map <%s>"
-#, fuzzy
-#~ msgid "Reading input data..."
-#~ msgstr "छवि "
-#, fuzzy
-#~ msgid "Writing output data..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Converts a raster map layer into a height-field file for POVRAY."
-#~ msgstr "a a ऊंचाई फील्ड के लिए."
-#, fuzzy
-#~ msgid "Unable to open drainage pointer map"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Unable to open new basin map"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Unable to close new basin map layer"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel resolution of the currently defined region."
-#~ msgstr "a a छवि पर का."
-#, fuzzy
-#~ msgid "raster, null data"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Name of raster map for which to edit null file"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Error writing null row %d"
-#, fuzzy
-#~ msgid "Cannot get row"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Unable to read raster <map %d of %d> row %d"
-#, fuzzy
-#~ msgid "Unable to read header of raster map <%s@%s>"
-#, fuzzy
-#~ msgid "Unable to read region <%s> in <%s>"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Unable to open vector map <%s> in <%s>"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Invalid region: %s"
-#~ msgstr "अवैध"
-#, fuzzy
-#~ msgid "Unable to update boundaries"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "%s: [%s] not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "raster, sun position"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Exports a GRASS raster map to a binary array."
-#~ msgstr "a a."
-#, fuzzy
-#~ msgid "Writing raster map, row %d"
-#~ msgstr "i n"
-#, fuzzy
-#~ msgid "Error in pipe creation"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "Error opening channel %i"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "Cannot create %s/.r.li/ directory"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Cannot create %s/.r.li/output/ directory"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Cannot close %s file (PIPE)"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Cannot delete %s file (PIPE)"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Cannot close %s file (PIPE2)"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Cannot delete %s file (PIPE2)"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Cannot close receive channel file"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Cannot delete %s file"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Cannot read raster header file"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "CHILD[pid = %i] cannot open raster map"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the currently defined region."
-#, fuzzy
-#~ msgid "raster, random, cell"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "raster, metadata, timestamp"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Converts a raster map layer into an ASCII text file."
-#~ msgstr "a पाठ."
-#, fuzzy
-#~ msgid "raster, category"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Cannot create category file for <%s>"
-#, fuzzy
-#~ msgid "Cannot read header of raster map <%s> in <%s>"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Cannot open cell file of raster map <%s> in <%s>"
-#, fuzzy
-#~ msgid "raster, terrain"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Unable to write to <%s>"
-#, fuzzy
-#~ msgid "raster, conversion, vectorization"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Write raster values as z coordinate. Table is not created. Currently supported only for points."
-#~ msgstr "ज़ेड है नहीं के लिए"
-#, fuzzy
-#~ msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
-#~ msgstr "R जी a छवि पर का."
-#, fuzzy
-#~ msgid "Name of incidence or density file."
-#~ msgstr "का घनत्व."
-#, fuzzy
-#~ msgid "raster, transect"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Interpolating raster map <%s> (%d rows)... "
-#~ msgstr "i n"
-#, fuzzy
-#~ msgid "Cannot read row"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Finds the median of values in a cover map within areas assigned the same category value in a user-specified base map."
-#~ msgstr "का a कवर a बेस."
-#, fuzzy
-#~ msgid "Name of base raster map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Base raster map <%s> not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Unable to read category labels of raster map <%s>"
-#, fuzzy
-#~ msgid "File containing weights"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Output basic information about a raster map layer."
-#~ msgstr "a."
-#, fuzzy
-#~ msgid "Cannot create category file of <%s>"
-#, fuzzy
-#~ msgid "raster, reclassification"
-#~ msgstr "ट्रेस"
-#, fuzzy
-#~ msgid ""
-#~ "Enter the file name or path\n"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "The size of sliding window (odd and >= 3)"
-#~ msgstr "आकार  का"
-#, fuzzy
-#~ msgid "Import GDAL supported raster file into a binary raster map layer."
-#, fuzzy
-#~ msgid "raster, sediment flow, erosion, deposition"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "raster, flow, hydrology"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "raster, thin"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Thins non-zero cells that denote linear features in a raster map."
-#~ msgstr "a."
-#, fuzzy
-#~ msgid "%s: Error reading from raster map <%s> in mapset <%s>"
-#, fuzzy
-#~ msgid "File type"
-#, fuzzy
-#~ msgid "Output file name not specified"
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Exporting to GDAL raster"
-#, fuzzy
-#~ msgid "Failed writing output raster map row %d"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Name of input raster map with seed (at least 1 cell > 0)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Can't create raster map <%s>"
-#, fuzzy
-#~ msgid "raster, import, conversion"
-#~ msgstr "ट्रेस"
-#, fuzzy
-#~ msgid "Converts ASCII raster file to binary raster map layer."
-#~ msgstr "पाठ a."
-#, fuzzy
-#~ msgid "raster, export, VRML"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "raster, DEM, fractal"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Finds the average of values in a cover map within areas assigned the same category value in a user-specified base map."
-#, fuzzy
-#~ msgid "%s: ERROR running %s command"
-#, fuzzy
-#~ msgid "Could not get raster row from input map"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Could not get raster row from elev map"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Error writing G3D double data"
-#, fuzzy
-#~ msgid "Rowio_setup failed"
-#~ msgstr "नक़ल"
-#, fuzzy
-#~ msgid "Rowio_get failed"
-#~ msgstr "नक़ल"
-#, fuzzy
-#~ msgid "Unable to open raster map <%s@%s>"
-#, fuzzy
-#~ msgid "Failed writing raster map row"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Unable to get current region"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Constructs flow lines."
-#~ msgstr "गणना करें"
-#, fuzzy
-#~ msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)."
-#~ msgstr "का ढाल a."
-#, fuzzy
-#~ msgid "Name for flowpath length raster map"
-#~ msgstr "ढाल"
-#, fuzzy
-#~ msgid "Unable to get header for %s"
-#, fuzzy
-#~ msgid "Cannot reset current region"
-#~ msgstr "छापें"
-#, fuzzy
-#~ msgid "imagery, geometry"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "imagery, edges"
-#~ msgstr "छापें"
-#, fuzzy
-#~ msgid "Error while reading input raster map."
-#, fuzzy
-#~ msgid "imagery, classification, supervised, SMAP"
-#~ msgstr "फ़ाइल का"
-#, fuzzy
-#~ msgid "imagery, landsat, acca"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Cannot write to raster map <%s>"
-#, fuzzy
-#~ msgid "imagery, classification, MLC"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Did not find input cell map MASK."
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "Error reading raster map in function readbands."
-#~ msgstr "त्रुटि फंक्शन."
-#, fuzzy
-#~ msgid "imagery, classification"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Unable to read cell header for first band file"
-#, fuzzy
-#~ msgid "Creates, edits, and lists groups and subgroups of imagery data."
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "imagery, classification, supervised, MLC"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "imagery, color transformation, RGB, HIS"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Unable to read raster map row %ld"
-#, fuzzy
-#~ msgid "Failed writing raster map row %ld"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Unable to allocate the input row buffer"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "imagery, rectify"
-#~ msgstr "समूह"
-#, fuzzy
-#~ msgid "Computes topographic correction of reflectance."
-#~ msgstr "पद्धति"
-#, fuzzy
-#~ msgid "Name of reflectance raster maps to be corrected topographically"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name (flag -i) or prefix for output raster maps"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of input base raster map (elevation or illumination)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Output sun illumination terrain model"
-#~ msgstr "ढाल"
-#, fuzzy
-#~ msgid "Elevation raster map of unknown type"
-#~ msgstr "एक."
-#, fuzzy
-#~ msgid "Reflectance of raster map <%s> is not of DCELL type - ignored"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "imagery, FFT"
-#~ msgstr "समूह"
-#, fuzzy
-#~ msgid "Unable to open real-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
-#~ msgstr "छवि i"
-#, fuzzy
-#~ msgid "Unable to open imaginary-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
-#~ msgstr "छवि i"
-#, fuzzy
-#~ msgid "Power 2 values: %d rows %d columns"
-#~ msgstr "पावर."
-#, fuzzy
-#~ msgid "Writing data..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Range of values in output display files"
-#~ msgstr "सीमा का"
-#, fuzzy
-#~ msgid "Range less than or equal to zero not allowed"
-#, fuzzy
-#~ msgid "Writing viewable versions of transformed data..."
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Unable to open file in the 'cell_misc' directory"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Extract quality control parameters from Modis QC layers"
-#~ msgstr "i n"
-#, fuzzy
-#~ msgid "Name of the surface reflectance QC layer [bit array]"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "imagery, statistics"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Illegal group name <%s>"
-#, fuzzy
-#~ msgid "Illegal subgroup name <%s>"
-#, fuzzy
-#~ msgid "Illegal signature file name <%s>"
-#, fuzzy
-#~ msgid "The output cell map <%s.%d> has values outside the 0-255 range. Min: %d Max: %d"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Error reading cell map during transform."
-#, fuzzy
-#~ msgid "Error writing cell map during transform."
-#, fuzzy
-#~ msgid "imagery, classification, signatures"
-#, fuzzy
-#~ msgid "name=%s\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "mapset=%s\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "fullname=%s\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "usage: %s file [prompt %%x %%y]\n"
-#~ msgstr "संकेत n"
-#, fuzzy
-#~ msgid "imagery, image transformation, PCA"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Calculating covariance matrix..."
-#, fuzzy
-#~ msgid "Computing means and standard deviations..."
-#~ msgstr "नक़ल"
-#, fuzzy
-#~ msgid "Computing means..."
-#~ msgstr "नक़ल"
-#, fuzzy
-#~ msgid "Calculating camera angle to local surface..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Could not open elevation raster"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Error reading segment file"
-#~ msgstr "त्रुटि n"
-#, fuzzy
-#~ msgid "imagery, orthorectify"
-#~ msgstr "समूह"
-#, fuzzy
-#~ msgid "Could not read REF file for group <%s>"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "No camera reference file selected for group <%s>"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Bad format in camera file for group <%s>"
-#~ msgstr "समूह"
-#, fuzzy
-#~ msgid "Bad format in initial exposure station file for group <%s>"
-#~ msgstr "समूह"
-#, fuzzy
-#~ msgid "No target elevation model selected for group <%s>"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid ""
-#~ "Control Z Point file for group [%s] in [%s] \n"
-#~ " \n"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Computing equations..."
-#~ msgstr "नक़ल"
-#, fuzzy
-#~ msgid "Poorly placed Control Points!\n"
-#~ msgstr "घुमाएँ"
-#, fuzzy
-#~ msgid "Can not generate the transformation equation.\n"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "No active Control Points!\n"
-#~ msgstr "घुमाएँ"
-#, fuzzy
-#~ msgid ""
-#~ "Reference Point file for group [%s] in [%s] \n"
-#~ " \n"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Poorly placed Reference Points!\n"
-#~ msgstr "घुमाएँ"
-#, fuzzy
-#~ msgid "No active Reference Points!\n"
-#~ msgstr "घुमाएँ"
-#, fuzzy
-#~ msgid "Name of imagery group for ortho-rectification"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Target information for group [%s] missing\n"
-#~ msgstr "सीमा के लिए नहीं"
-#, fuzzy
-#~ msgid "Target location [%s] not found\n"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Mapset [%s] in target location [%s] - "
-#~ msgstr "समूह के लिए n"
-#, fuzzy
-#~ msgid "not found\n"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Pre-selected group <%s> not found"
-#~ msgstr ""
-#~ "\n"
-#~ " समूह नहीं"
-#, fuzzy
-#~ msgid "Enter imagery group for ortho-rectification"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Group [%s] contains no files"
-#~ msgstr "समूह."
-#, fuzzy
-#~ msgid "Could not read REF file for group [%s]"
-#~ msgstr "समूह"
-#, fuzzy
-#~ msgid "No files in this group!"
-#~ msgstr "समूह."
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Rectify all images in the group? "
-#~ msgstr "सभी छवियाँ समूह"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Choose another extension? "
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Enter a name for the camera angle map:"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Map name <%s> is illegal"
-#~ msgstr "है"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Overwrite maps in target location/mapset? "
-#, fuzzy
-#~ msgid "Please select one of the following interpolation methods\n"
-#, fuzzy
-#~ msgid "Group [%s] targeted for location [%s], mapset [%s]"
-#, fuzzy
-#~ msgid "Group [%s] not found"
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "Creates control points on an image to be ortho-rectified."
-#~ msgstr "चिह्नित चालू छवि."
-#, fuzzy
-#~ msgid "No camera reference file selected for group [%s]"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Bad format in camera file for group [%s]"
-#~ msgstr "समूह"
-#, fuzzy
-#~ msgid "No initial camera exposure station for group [%s]"
-#~ msgstr "समूह"
-#, fuzzy
-#~ msgid "Bad format in initial camera exposure station for group [%s]"
-#~ msgstr "समूह"
-#, fuzzy
-#~ msgid "No photo points for group [%s]"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Poorly placed photo points for group [%s]"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Computing equations ..."
-#~ msgstr "नक़ल"
-#, fuzzy
-#~ msgid "Unable to read raster header of <%s>"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Image Group [%s] not found"
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "Name of camera reference file to use"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Enter a camera reference file to be used with this imagery group"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Group [%s] in location [%s] mapset [%s] now has camera file [%s]"
-#, fuzzy
-#~ msgid "Scale of the output map, e.g. 1:25000 (default: Auto-sized to fit page)"
-#~ msgstr "का जी"
-#, fuzzy
-#~ msgid "Using <%s> from the command line is depreciated. Please use the <%s> mapping instruction instead. The parameter <%s> will be removed in future versions of GRASS."
-#, fuzzy
-#~ msgid "Current region cannot be set."
-#~ msgstr "सेट."
-#, fuzzy
-#~ msgid "display, paint labels"
-#~ msgstr "गामा."
-#, fuzzy
-#~ msgid "No current window"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Current window not available"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Current window not settable"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Error in calculating conversions"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "display, histogram, statistics"
-#~ msgstr "वस्तु."
-#, fuzzy
-#~ msgid "display, vector"
-#~ msgstr "गामा."
-#, fuzzy
-#~ msgid "Layer number (if -1, all layers are displayed)"
-#~ msgstr "नहीं सभी n n फ़ाइल"
-#, fuzzy
-#~ msgid "Type of color table (for use with -z flag)"
-#~ msgstr "का स्थिर"
-#, fuzzy
-#~ msgid "Scale factor for wcolumn"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Get colors from map table column (of form RRR:GGG:BBB)"
-#~ msgstr "पाएं"
-#, fuzzy
-#~ msgid "Don't add to list of vectors and commands in monitor (it won't be drawn if the monitor is refreshed)"
-#~ msgstr "का है"
-#, fuzzy
-#~ msgid "Unable to display areas, topology not available"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Unable to display lines by id, topology not available"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Unable to display topology, not available"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Symbol size column not specified."
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "Symbol size column (%s) is not numeric."
-#, fuzzy
-#~ msgid "Symbol rotation column not specified."
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "Symbol rotation column (%s) is not numeric."
-#~ msgstr "ज़ेड"
-#, fuzzy
-#~ msgid "Unable to read symbol, unable to display points"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Error in color definition column '%s': %d features affected"
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "Generates and displays simple graphics on map layers drawn in the active graphics monitor display frame."
-#~ msgstr "चालू."
-#, fuzzy
-#~ msgid "Unix file containg graphing instructions, if not given reads from standard input"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Color to draw with, either a standard GRASS color or R:G:B triplet (separated by colons)"
-#~ msgstr "a R जी"
-#, fuzzy
-#~ msgid "Monitor: interactive command in redraw"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Monitor: waitpid: expected %d but got %d"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Monitor: XGetWMName failed"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Monitor: XGetWMName: bad result"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "found %d visuals of type TrueColor"
-#~ msgstr "का n"
-#, fuzzy
-#~ msgid "searching for highest bit depth"
-#, fuzzy
-#~ msgid "selected %d bit depth"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "using default visual which is %s"
-#~ msgstr "है n"
-#, fuzzy
-#~ msgid "display, distance"
-#~ msgstr "गामा."
-#, fuzzy
-#~ msgid "Displays the rhumbline joining two user-specified points, in the active frame on the user's graphics monitor."
-#~ msgstr "दो चालू."
-#, fuzzy
-#~ msgid "display, position, querying"
-#~ msgstr "गामा."
-#, fuzzy
-#~ msgid "Identifies the geographic coordinates associated with point locations in the active frame on the graphics monitor."
-#~ msgstr "बिन्दु चालू."
-#, fuzzy
-#~ msgid "One mouse click only"
-#~ msgstr "एक"
-#, fuzzy
-#~ msgid " Middle: toggle flash color\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "value [%.0f,%.0f] out of range [0-100]"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "display, metadata"
-#~ msgstr "गामा."
-#, fuzzy
-#~ msgid "Name of frame(s) to save"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Save current frame"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Save all the frames"
-#~ msgstr "a"
-#, fuzzy
-#~ msgid "Unknown item type in pad: %s"
-#, fuzzy
-#~ msgid "Can't clear current graphics window"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Cannot use current window"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "display, raster"
-#~ msgstr "गामा."
-#, fuzzy
-#~ msgid "Interactively edit cell values in a raster map."
-#~ msgstr "छवियाँ a"
-#, fuzzy
-#~ msgid "display, raster, profile"
-#~ msgstr "गामा."
-#, fuzzy
-#~ msgid "Output profile data to file(s) with prefix 'name'"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Use mouse to choose action"
-#~ msgstr "आकार "
-#, fuzzy
-#~ msgid "Error opening cell-file"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "Error reading from cell-file"
-#, fuzzy
-#~ msgid "%s: Couldn't open raster <%s@%s>"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "%s: Couldn't read color table for <%s@%s>"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Error reading raster map"
-#, fuzzy
-#~ msgid "display, map management"
-#~ msgstr "गामा."
-#, fuzzy
-#~ msgid "Prompts the user to select a GRASS data base file from among files displayed in a menu on the graphics monitor."
-#~ msgstr "का a चालू."
-#, fuzzy
-#~ msgid "Short user prompt message"
-#~ msgstr "छापें"
-#, fuzzy
-#~ msgid "No current graphics window"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Current graphics window not available"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Can't set current graphics window"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Getting graphics window coordinates"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Display number of colors"
-#~ msgstr "संख्या का"
-#, fuzzy
-#~ msgid "Use mouse to interactively place scale"
-#~ msgstr "स्केल"
-#, fuzzy
-#~ msgid "The screen coordinates for top-left corner of label ([0,0] is top-left of frame)"
-#~ msgstr "के लिए शीर्ष बायाँ का है शीर्ष बायाँ का"
-#, fuzzy
-#~ msgid "Erase the contents of the active display frame with user defined color"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Don't add to list of commands in monitor"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "No current frame"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Current frame not available"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "display, zoom"
-#~ msgstr "गामा."
-#, fuzzy
-#~ msgid "ERROR: can not get \"list\" items"
-#~ msgstr "त्रुटि नहीं n"
-#, fuzzy
-#~ msgid "-j flag forced"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "No map is displayed in GRASS monitor"
-#~ msgstr "त्रुटि नहीं है n"
-#, fuzzy
-#~ msgid "No raster map exists in current window"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Draws text in the graphics monitor's active display frame using TrueType fonts."
-#~ msgstr "पाठ."
-#, fuzzy
-#~ msgid "Screen position (percentage, [0,0] is bottom left)"
-#~ msgstr "का है तल बायाँ"
-#, fuzzy
-#~ msgid "Height of letters (in percent of available frame height)"
-#~ msgstr "ऊंचाई का का ऊंचाई"
-#, fuzzy
-#~ msgid "Command mode (Compatibility with d.text)"
-#~ msgstr "पाठ"
-#, fuzzy
-#~ msgid "Either text or -c should be given"
-#~ msgstr "पाठ"
-#, fuzzy
-#~ msgid "Choose only one coordinate system for placement"
-#~ msgstr "एक के लिए"
-#, fuzzy
-#~ msgid "No font selected"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Unable to set size"
-#, fuzzy
-#~ msgid "Unable to create text conversion context"
-#~ msgstr "पाठ"
-#, fuzzy
-#~ msgid "Text conversion error"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "No predefined font"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "%s: Unable to read FreeType definition file; use the default"
-#~ msgstr "फ्री-टाइप"
-#, fuzzy
-#~ msgid "%s: No FreeType definition file"
-#~ msgstr "नहीं फ्री-टाइप"
-#, fuzzy
-#~ msgid "%s: Unable to read FreeType definition file"
-#, fuzzy
-#~ msgid "Size of grid to be drawn"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Manages display frames on the user's graphics monitor."
-#~ msgstr "फ्रेम्स चालू."
-#, fuzzy
-#~ msgid "Create a new frame"
-#~ msgstr "a"
-#, fuzzy
-#~ msgid "Select a frame"
-#~ msgstr "a"
-#, fuzzy
-#~ msgid "Print name of current frame"
-#~ msgstr "छापें का"
-#, fuzzy
-#~ msgid "Print names of all frames"
-#, fuzzy
-#~ msgid "List map names displayed in GRASS monitor"
-#, fuzzy
-#~ msgid "Debugging output"
-#~ msgstr "डिबगिंग"
-#, fuzzy
-#~ msgid "name"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Frame to be created/selected"
-#~ msgstr "ढांचा"
-#, fuzzy
-#~ msgid "Error choosing frame [%s]\n"
-#~ msgstr "त्रुटि के लिए"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Buttons:\n"
-#~ msgstr "n n"
-#, fuzzy
-#~ msgid "Left:   Select frame\n"
-#~ msgstr "a"
-#, fuzzy
-#~ msgid "Right:  Accept frame\n"
-#~ msgstr "बाहर जाएँ n"
-#, fuzzy
-#~ msgid "Use mouse to interactively place text"
-#~ msgstr "स्केल"
-#, fuzzy
-#~ msgid " Left:    Place text here\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid " Right:   Quit\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "display, color transformation"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Error reading hue data"
-#, fuzzy
-#~ msgid "Error reading intensity data"
-#, fuzzy
-#~ msgid "Error reading saturation data"
-#, fuzzy
-#~ msgid "No such monitor as <%s>"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Error - Locking mechanism failed"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "To establish and control use of a graphics display monitor."
-#~ msgstr "का a."
-#, fuzzy
-#~ msgid "Name of graphics monitor to start"
-#~ msgstr "का प्रारंभ"
-#, fuzzy
-#~ msgid "Name of graphics monitor to stop"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of graphics monitor to select"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of graphics monitor to unlock"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "List all monitors"
-#~ msgstr "सभी"
-#, fuzzy
-#~ msgid "List all monitors (with current status)"
-#~ msgstr "सभी स्थिति"
-#, fuzzy
-#~ msgid "Print name of currently selected monitor"
-#, fuzzy
-#~ msgid "Release currently selected monitor"
-#, fuzzy
-#~ msgid "R_color file for [%s] not available"
-#~ msgstr "के लिए नहीं"
-#, fuzzy
-#~ msgid "Range file for [%s] not available"
-#, fuzzy
-#~ msgid "List of categories to be displayed (INT maps)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "List of values to be displayed (FP maps)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Overlay (non-null values only)"
-#~ msgstr "ओवरले"
-#, fuzzy
-#~ msgid "Don't add to list of rasters and commands in monitor"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Invalid rendering method <%s>"
-#~ msgstr "अवैध"
-#, fuzzy
-#~ msgid "Font name or pathname of TTF file"
-#~ msgstr "फ़ाइल के लिए."
-#, fuzzy
-#~ msgid "Setting release of FreeType"
-#~ msgstr "रिलीज का फ्री-टाइप n"
-#, fuzzy
-#~ msgid "display, raster, RGB"
-#~ msgstr "गामा."
-#, fuzzy
-#~ msgid "Error reading row of data"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Mouse Buttons:"
-#~ msgstr "n n"
-#, fuzzy
-#~ msgid "Left:   Select From\n"
-#~ msgstr "a"
-#, fuzzy
-#~ msgid ""
-#~ "Right:  Quit\n"
-#~ "\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Color for drawing X's (Null values)"
-#~ msgstr "के लिए शून्य (Null)"
-#, fuzzy
-#~ msgid "No raster map exists in the current window"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Use mouse to size & place legend"
-#~ msgstr "आकार "
-#, fuzzy
-#~ msgid "display, menu"
-#~ msgstr "गामा."
-#, fuzzy
-#~ msgid "Creates and displays a menu within the active frame on the graphics monitor."
-#~ msgstr "पाठ चालू."
-#, fuzzy
-#~ msgid "Sets the color of the menu background"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Sets the color of the menu text"
-#~ msgstr "का पाठ"
-#, fuzzy
-#~ msgid "Sets the color dividing lines of text"
-#~ msgstr "का पाठ"
-#, fuzzy
-#~ msgid "Sets the menu text size (in percent)"
-#~ msgstr "पाठ आकार  संख्या"
-#, fuzzy
-#~ msgid "Menu must contain a title and at least one option"
-#~ msgstr "पर एक"
-#, fuzzy
-#~ msgid "display, geometry"
-#~ msgstr "गामा."
-#, fuzzy
-#~ msgid "You must select more than one point"
-#~ msgstr "अधिक एक बिन्दु"
-#, fuzzy
-#~ msgid "You must select at least four points"
-#~ msgstr "पर"
-#, fuzzy
-#~ msgid "No raster or vector map displayed"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "general, gui"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Name of workspace file"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "general, transformation, GCP"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of a mapset"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "general, projection"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Can also be used to create GRASS locations."
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Print projection information (in conventional GRASS format)"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Georeferenced data file to read projection information from"
-#~ msgstr "का के लिए"
-#, fuzzy
-#~ msgid "ASCII file containing a WKT projection description (- for stdin)"
-#, fuzzy
-#~ msgid "Unable to open file [%s] for reading"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Unable to create location: %s"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Removing %s <%s>"
-#~ msgstr "छवि "
-#, fuzzy
-#~ msgid "couldn't be removed"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "%s: couldn't be removed"
-#~ msgstr "नाम बदला गया"
-#, fuzzy
-#~ msgid "%s: removed"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "<%s> nothing removed"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Remove base maps"
-#, fuzzy
-#~ msgid "%s file(s) to be removed"
-#, fuzzy
-#~ msgid "Unable to compile regular expression %s"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "general, settings"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Changes current mapset."
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "List available mapsets"
-#~ msgstr "सभी"
-#, fuzzy
-#~ msgid "Erasing monitors..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Mapset to list (default: current search path)"
-#~ msgstr "का डिफ़ॉल्ट"
-#, fuzzy
-#~ msgid "general, version"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Other"
-#~ msgstr "डिथर"
-#, fuzzy
-#~ msgid "%s file(s) to be renamed"
-#, fuzzy
-#~ msgid "Copies available data files in the user's current mapset search path and location to the appropriate element directories under the user's current mapset."
-#~ msgstr "अन्य."
-#, fuzzy
-#~ msgid "%s file(s) to be copied"
-#, fuzzy
-#~ msgid "Raster map <%s@%s>: %s"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "<%s> is an illegal region name"
-#~ msgstr "है"
-#, fuzzy
-#~ msgid "Unable to open raster map <%s> in <%s>"
-#, fuzzy
-#~ msgid "Could not read from <%s>"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Names of mask files"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of output mask file"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "general, scripts"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Your mapset search list:\n"
-#~ msgstr "छापें"
-#, fuzzy
-#~ msgid "<%s> not found in mapset list"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "general, settings, search path"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Randomly generate a 2D/3D vector points map."
-#~ msgstr "a."
-#, fuzzy
-#~ msgid "Using 'double precision' for column <%s>"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "vector, network, isolines"
-#~ msgstr "ट्रेस"
-#, fuzzy
-#~ msgid "vector, network, centrality measures"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "vector, geometry"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Nothing to do"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Not enough types"
-#~ msgstr "ज़ेड"
-#, fuzzy
-#~ msgid "Odd number of types"
-#, fuzzy
-#~ msgid "vector, geometry, triangulation"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Creates a Voronoi diagram from an input vector map containing points or centroids."
-#~ msgstr "a बिन्दु."
-#, fuzzy
-#~ msgid "Voronoi triangulation..."
-#, fuzzy
-#~ msgid "Cannot calculate area centroid z coordinate"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "vector, network, steiner tree"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Copying vector objects from vector map <%s>..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Unknown column type '%s'"
-#, fuzzy
-#~ msgid "Unknown column type '%s' values lost"
-#, fuzzy
-#~ msgid "Network input map <%s> not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Unable to read MASK"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Convert OGR vector layers to GRASS vector map."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "List available layers in data source and exit"
-#~ msgstr "स्रोत"
-#, fuzzy
-#~ msgid "Unable to convert input map projection to GRASS format; cannot create new location"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Counting polygons for %d features..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Merge boundaries:"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Find centroids for layer: %s"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Input data contains 3D features. Created vector is 2D only, use -z flag to import 3D vector"
-#~ msgstr "है ज़ेड."
-#, fuzzy
-#~ msgid "Cannot read part of geometry"
-#, fuzzy
-#~ msgid "Cannot write part of geometry"
-#, fuzzy
-#~ msgid "%d new points written to output"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "vector, networking, maintenance"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Name of input point vector map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Output vector map must be specified"
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Point vector map must be specified"
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Threshold value must be specified"
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "%d arcs added to network (nlayer %d)"
-#~ msgstr "लोड हो गया"
-#, fuzzy
-#~ msgid "vector, projection, transformation"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "vector, buffer"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Creates a buffer around features of given type (areas must contain centroid)."
-#~ msgstr "a का रखे हुए."
-#, fuzzy
-#~ msgid "Use the distance option instead of the buffer option."
-#~ msgstr "का कोण के लिए"
-#, fuzzy
-#~ msgid "Calculate geometry distances instead of table data."
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Unable select categories from table <%s>"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "vector, network, shortest path"
-#~ msgstr "सदिश"
-#, fuzzy
-#~ msgid "got type %d"
-#, fuzzy
-#~ msgid "Unable to select record from table <%s> (key %s, column %s)"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Column <%s>: unsupported data type"
-#, fuzzy
-#~ msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
-#~ msgstr "a."
-#, fuzzy
-#~ msgid "Parameter '%s' ignored in standard mode"
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Offset in map units."
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "vector, metadata"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Vector map <%s> not found in the current mapset"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Creates topology for GRASS vector map."
-#, fuzzy
-#~ msgid "If not given (or \"-\") reads from standard input"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "vector, editing, geometry"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Error reading ASCII file: '%s'"
-#, fuzzy
-#~ msgid "End of ASCII file reached before end of coordinates"
-#~ msgstr "के लिए ज़ेड"
-#, fuzzy
-#~ msgid "End of ascii file reached before end of categories"
-#, fuzzy
-#~ msgid "Error reading categories: '%s'"
-#, fuzzy
-#~ msgid "Unexpected data in vector head: '%s'"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "db connection was not set by form"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Cannot open driver"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Cannot open database"
-#~ msgstr "स्रोत"
-#, fuzzy
-#~ msgid "Cannot describe table"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Cannot find column type"
-#~ msgstr "अज्ञात क़िस्म"
-#, fuzzy
-#~ msgid "Cannot update table"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Form"
-#~ msgstr "फ़ॉन्ट"
-#, fuzzy
-#~ msgid "New record was created.<BR>"
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Record for this category already existed.<BR>"
-#, fuzzy
-#~ msgid "New point"
-#~ msgstr "फ़ॉन्ट"
-#, fuzzy
-#~ msgid "Quit tool"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Out of memory! Point not added."
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Undo last point"
-#~ msgstr "घुमाएँ"
-#, fuzzy
-#~ msgid "Close line"
-#~ msgstr "नक़ल"
-#, fuzzy
-#~ msgid "New Point"
-#~ msgstr "फ़ॉन्ट"
-#, fuzzy
-#~ msgid "Undo Last Point"
-#~ msgstr "घुमाएँ"
-#, fuzzy
-#~ msgid "Delete line and exit"
-#~ msgstr "स्रोत"
-#, fuzzy
-#~ msgid "Select"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Unselect"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "New location"
-#~ msgstr "है a"
-#, fuzzy
-#~ msgid "Remove vertex:"
-#, fuzzy
-#~ msgid "Select vertex"
-#~ msgstr "a"
-#, fuzzy
-#~ msgid "New vertex"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Move vertex:"
-#, fuzzy
-#~ msgid "Cannot open driver %s"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Cannot open database %s"
-#~ msgstr "स्रोत"
-#, fuzzy
-#~ msgid "Cannot open driver "
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Cannot open database %s by driver %s"
-#~ msgstr "स्रोत"
-#, fuzzy
-#~ msgid "Cannot create table: "
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Cannot create index:\n"
-#~ msgstr "फील्ड"
-#, fuzzy
-#~ msgid "Cannot grant privileges on table:\n"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Cannot create new record."
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Database table for this layer is not defined"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Cannot select record from table %s"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Display categories:"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Select line"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Copy attributes:"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Select source object"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Select the target object"
-#~ msgstr "पाठ"
-#, fuzzy
-#~ msgid "Conform and select next"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Deselect Target"
-#~ msgstr "a"
-#, fuzzy
-#~ msgid "Display attributes:"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "layer: %d<BR>category: %d<BR>"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Database connection not defined<BR>"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "driver: %s<BR>database: %s<BR>table: %s<BR>key column: %s<BR>"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Line %d"
-#~ msgstr "ऊंचाई f n"
-#, fuzzy
-#~ msgid "No categories"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Cannot delete record: %s"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Cannot open driver '%s'<BR>"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Cannot open database '%s' by driver '%s'<BR>"
-#~ msgstr "स्रोत"
-#, fuzzy
-#~ msgid "Cannot open select cursor"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>"
-#~ msgstr "स्रोत"
-#, fuzzy
-#~ msgid "Cannot fetch next record"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "No database record"
-#~ msgstr "सभी."
-#, fuzzy
-#~ msgid "vector, editing, digitization"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "New empty map created."
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Select tool"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Cannot set variable code = %d"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Cannot get type of variable %s"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Cannot get code of variable %s"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Cannot get name of variable %d"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Cannot get value of variable code = %d"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Quit"
-#~ msgstr "शांत"
-#, fuzzy
-#~ msgid "Pan"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "New center"
-#, fuzzy
-#~ msgid "Cannot find window '%s'"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "vector, network, allocation"
-#~ msgstr "सदिश"
-#, fuzzy
-#~ msgid "Calculating costs from centres ..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Cannot alter table: %s"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "vector, extract"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Layer number (if -1, all features in all layers of given type are extracted)"
-#, fuzzy
-#~ msgid "Layer 0 not supported"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Process file <%s> for category numbers"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "%d categories loaded from table <%s>"
-#, fuzzy
-#~ msgid "vector, database, attribute table"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Key column name"
-#~ msgstr "ज़ेड"
-#, fuzzy
-#~ msgid "Print all map connection parameters and exit in shell script style"
-#~ msgstr "छापें"
-#, fuzzy
-#~ msgid "Vector map <%s> is connected by:"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Calculate area centroids..."
-#~ msgstr "के लिए n"
-#, fuzzy
-#~ msgid "Creates a vector map from ASCII points file or ASCII vector file."
-#~ msgstr "a अन्य."
-#, fuzzy
-#~ msgid "ASCII file to be imported, if not given reads from standard input"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid ""
-#~ "Unexpected data in vector head:\n"
-#~ "[%s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Error reading ASCII file: (bad type) [%s]"
-#, fuzzy
-#~ msgid "Error reading ASCII file: (unknown type) [%s]"
-#, fuzzy
-#~ msgid "Error reading ASCII file: (bad point) [%s]"
-#, fuzzy
-#~ msgid "Unparsable longitude value: [%s]"
-#, fuzzy
-#~ msgid "Unparsable latitude value: [%s]"
-#, fuzzy
-#~ msgid "End of ASCII file reached before end of categories"
-#, fuzzy
-#~ msgid "Error reading categories: [%s]"
-#, fuzzy
-#~ msgid "vector, raster, resample"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Vector map attribute column to use for comparison"
-#, fuzzy
-#~ msgid "Vector map to store differences"
-#~ msgstr "सदिश"
-#, fuzzy
-#~ msgid "Raster map to be sampled"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Bilinear interpolation (default is nearest neighbor)"
-#, fuzzy
-#~ msgid "Cubic convolution interpolation (default is nearest neighbor)"
-#, fuzzy
-#~ msgid "Checking vector points..."
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Layer number (from)"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Layer number (to)"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Finding nearest lines..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Layer number (write to)"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Query layer number (read from)"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)"
-#~ msgstr "f a h"
-#, fuzzy
-#~ msgid "Creates a GRASS vector map of a user-defined grid."
-#~ msgstr "a का a."
-#, fuzzy
-#~ msgid "Quiet; No chatter"
-#~ msgstr "शांत नहीं"
-#, fuzzy
-#~ msgid "vector, network, articulation points"
-#~ msgstr "सदिश"
-#, fuzzy
-#~ msgid "vector, geometry, topology"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Vector of points defining sample points"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Counting sites in quadrats..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "vector, category"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "vector, network, flow"
-#~ msgstr "सदिश"
-#, fuzzy
-#~ msgid "vector, geometry, buffer"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "DEPRECATED Buffer distance in map units"
-#~ msgstr "f"
-#, fuzzy
-#~ msgid "Attribute column to use for buffer distances"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Stop the process at a certain stage"
-#~ msgstr "रूकें पर a"
-#, fuzzy
-#~ msgid "The tolerance was reset to %g (map units)"
-#~ msgstr "जी"
-#, fuzzy
-#~ msgid "Line buffers... "
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "The tolerance was reset to %g (map units). [category %d]"
-#~ msgstr "जी"
-#, fuzzy
-#~ msgid "Could not get outside buffer for line id %d"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Selecting areas..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "vector, interpolation"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Use z-coordinates (3D vector only)"
-#~ msgstr "फील्ड सेट ज़ेड"
-#, fuzzy
-#~ msgid "If set to 0, z coordinates are used. (3D vector only)"
-#, fuzzy
-#~ msgid "Output slope raster map"
-#~ msgstr "ढाल"
-#, fuzzy
-#~ msgid "Output cross-validation errors vector point file"
-#~ msgstr "का बिन्दु"
-#, fuzzy
-#~ msgid "Name of the attribute column with values to be used for approximation (if layer>0)"
-#, fuzzy
-#~ msgid " Number of points that have been entered: %d\n"
-#~ msgstr "का n"
-#, fuzzy
-#~ msgid "vector, transformation"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Suppress display of residuals or other information"
-#~ msgstr "का अन्य"
-#, fuzzy
-#~ msgid "The '%c' flag is deprecated and will be removed in future. Please use '--quiet' instead."
-#~ msgstr "i n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "New vector map <%s> boundary coordinates:"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "ask_transform_coor():  Leaving session.. \n"
-#~ msgstr "पूछें n"
-#, fuzzy
-#~ msgid "<%s> has not been created in database."
-#~ msgstr "सभी के लिए a."
-#, fuzzy
-#~ msgid "Unable to access table <%s>"
-#~ msgstr "i n"
-#, fuzzy
-#~ msgid "Attribute table column with values to interpolate (if layer>0)"
-#, fuzzy
-#~ msgid "Layer but not column with z values given"
-#, fuzzy
-#~ msgid "vector, reclass, attributes"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Either 'rules' or 'col' must be specified"
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Name of column name with route ids"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of column name with stop timestamps"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of column name with stop ids"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of column name with walk lengths"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Exports a GRASS vector map to SVG."
-#~ msgstr "a a."
-#, fuzzy
-#~ msgid "Unable to open SVG file <%s>"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "vector, external, import"
-#~ msgstr "सदिश"
-#, fuzzy
-#~ msgid "Creates a new vector as a read-only link to OGR layer."
-#, fuzzy
-#~ msgid "Output vector. If not given, available layers are printed only."
-#~ msgstr "का"
-#, fuzzy
-#~ msgid ""
-#~ "OGR layer name. If not given, available layers are printed only. Examples:\n"
-#~ "\t\tESRI Shapefile: shapefile name\n"
-#~ "\t\tMapInfo File: mapinfo file name"
-#, fuzzy
-#~ msgid "Output vector name was not specified"
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Cannot open data source"
-#~ msgstr "स्रोत"
-#, fuzzy
-#~ msgid "Tests for normality for points."
-#~ msgstr "घुमाएँ"
-#, fuzzy
-#~ msgid "Doing log transformation"
-#~ msgstr "संख्या के लिए"
-#, fuzzy
-#~ msgid "Converts to one of the supported OGR vector formats."
-#~ msgstr "एक का."
-#, fuzzy
-#~ msgid "Feature type(s). Combinations not supported by all output formats. Default: first type found in input."
-#~ msgstr "का है नहीं."
-#, fuzzy
-#~ msgid "Export features with category (labeled) only. Otherwise all features are exported"
-#~ msgstr "निर्यात सभी"
-#, fuzzy
-#~ msgid "Could not determine input map's feature type(s)."
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "%d areas found, but not requested to be exported. Verify 'type' parameter."
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "%d kernel(s) found, but not requested to be exported. Verify 'type' parameter."
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "No points found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "बिंदु नहीं."
-#, fuzzy
-#~ msgid "No lines found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "No boundaries found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "No areas found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "No centroids found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "No faces found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "No kernels found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "No volumes found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "Key column '%s' not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Exporting %i geometries..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Create a new vector map layer by combining other vector map layers."
-#, fuzzy
-#~ msgid "Patching vector map <%s@%s>..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "vector, network, spanning tree"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "vector, spatial query"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Unknown operator"
-#, fuzzy
-#~ msgid "vector, import, conversion"
-#~ msgstr "ट्रेस"
-#, fuzzy
-#~ msgid "vector, import, sites"
-#~ msgstr "सदिश"
-#, fuzzy
-#~ msgid "Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
-#, fuzzy
-#~ msgid "Copying vector lines..."
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "%d lines / boundaries removed"
-#, fuzzy
-#~ msgid "vector, geometry, statistics"
-#~ msgstr "वस्तु."
-#, fuzzy
-#~ msgid "Random location perturbations of GRASS vector points"
-#~ msgstr "a."
-#, fuzzy
-#~ msgid "vector, metadata, history"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Outputs basic information about a user-specified vector map."
-#~ msgstr "a."
-#, fuzzy
-#~ msgid "Print vector history instead of info"
-#, fuzzy
-#~ msgid "Print types/names of table columns for specified layer instead of info"
-#~ msgstr "छापें का के लिए का"
-#, fuzzy
-#~ msgid "Print topology information only"
-#, fuzzy
-#~ msgid "Layer:           %s"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Mapset:          %s"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Location:        %s"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Title:           %s"
-#~ msgstr "आकार  n"
-#, fuzzy
-#~ msgid "Map format:      %s"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Name of creator: %s"
-#, fuzzy
-#~ msgid "  Map is 3D:              %s"
-#~ msgstr "आकार  n"
-#, fuzzy
-#~ msgid "  Number of dblinks:      %-9ld"
-#~ msgstr ""
-#~ "n\n"
-#~ " का n"
-#, fuzzy
-#~ msgid "vector, network, components"
-#~ msgstr "ट्रेस"
-#, fuzzy
-#~ msgid "vector, transformation, 3D"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Converts files in DXF format to GRASS vector map format."
-#~ msgstr "एक का."
-#, fuzzy
-#~ msgid "Name of input DXF file"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Option <%s>: <%s> exists."
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Use '%s' option to change vector map name"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "vector, raster, attribute table"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Name of input vector points map for which to edit attribute table"
-#~ msgstr "का के लिए संपादन (_E)"
-#, fuzzy
-#~ msgid "vector, network, salesman"
-#~ msgstr "सदिश"
-#, fuzzy
-#~ msgid "Output vector map where points will be written"
-#~ msgstr "i n"
-#, fuzzy
-#~ msgid "%d points written to output vector map"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "vector, geometry, 3D"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Extrudes flat vector object to 3D with defined height."
-#~ msgstr "वस्तु ऊंचाई"
-#, fuzzy
-#~ msgid "Name of input 2D vector map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of resulting 3D vector map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Extruding vector primitives..."
-#~ msgstr "ऊंचाई का वस्तु"
-#, fuzzy
-#~ msgid "Name of input vector map containing lines"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name for output vector map where segments will be written"
-#~ msgstr "i n"
-#, fuzzy
-#~ msgid "Type: %s"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "vector, querying"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Queries a vector map layer at given locations."
-#~ msgstr "क्वैरी का a पर."
-#, fuzzy
-#~ msgid "If not given reads from standard input"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Vector based generalization."
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "vector, volume, conversion"
-#~ msgstr "ट्रेस"
-#, fuzzy
-#~ msgid "Converts a binary GRASS vector map (only points) layer into a 3D GRASS raster map layer."
-#~ msgstr "a a."
-#, fuzzy
-#~ msgid "Cannot allocate %u bytes of memory"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "%s: Unable to read font definition file; use the default"
-#, fuzzy
-#~ msgid "%s: No font definition file"
-#, fuzzy
-#~ msgid "vector, import, database, points"
-#~ msgstr "सदिश"
-#, fuzzy
-#~ msgid "If set to 0, z coordinates are used (3D vector only)"
-#, fuzzy
-#~ msgid "Attribute table column with values to interpolate"
-#, fuzzy
-#~ msgid "No data points found"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Convex hull calculation requires at least three points. Exiting."
-#~ msgstr "पर"
-#, fuzzy
-#~ msgid "Exports GRASS vector map layers to DXF file format."
-#~ msgstr "a a."
-#, fuzzy
-#~ msgid "DXF output file"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "vector, geometry, sampling"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "vector, network, connectivity"
-#~ msgstr "ट्रेस"
-#, fuzzy
-#~ msgid "Cannot allocate memory for row buffer"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Unable to write categories for raster map <%s>"
-#~ msgstr "के लिए."
-#, fuzzy
-#~ msgid "vector, raster, conversion"
-#~ msgstr "ट्रेस"
-#, fuzzy
-#~ msgid "Cannot export attribute table fields for layer < 1. Skipping export"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "No attribute table found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "No numerical attributes found. Skipping export"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Error reading value of attribute '%s'"
-#~ msgstr "त्रुटि के लिए."
-#, fuzzy
-#~ msgid "Converts a GRASS binary vector map to VTK ASCII output."
-#~ msgstr "a."
-#, fuzzy
-#~ msgid "vector, path, visibility"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "OGR driver: column '%s', OGR type %d  is not supported"
-#~ msgstr "है नहीं"
-#, fuzzy
-#~ msgid "Cannot parse MySQL embedded database name"
-#~ msgstr "स्रोत"
-#, fuzzy
-#~ msgid "Cannot scan datetime: "
-#~ msgstr "स्रोत"
-#, fuzzy
-#~ msgid "Cannot get list of tables:\n"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Unknown option in database definition for "
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "pg driver: PostGIS column '%s', type 'geometry'  will not be converted"
-#, fuzzy
-#~ msgid "database, SQL"
-#~ msgstr "डाटाबेस नाम"
-#, fuzzy
-#~ msgid "Removes a table from database."
-#, fuzzy
-#~ msgid "database, attribute table"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "database, attribute table, connection settings"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Prints/sets general DB connection for current mapset and exits."
-#~ msgstr "के लिए a"
-#, fuzzy
-#~ msgid "Database schema"
-#, fuzzy
-#~ msgid "Do not use this option if schemas are not supported by driver/database server"
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "database, attribute table, SQL"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "database, connection settings"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "vector, import, gazetteer"
-#~ msgstr "सदिश"
-#, fuzzy
-#~ msgid "Display the HTML man pages of GRASS"
-#, fuzzy
-#~ msgid "general, manual, help"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Calculates univariate statistics from a raster map based on vector polygons and uploads statistics to new attribute columns."
-#~ msgstr "का a."
-#, fuzzy
-#~ msgid "vector, raster, statistics"
-#~ msgstr "वस्तु."
-#, fuzzy
-#~ msgid "Name of vector polygon map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of raster map to calculate statistics from"
-#~ msgstr "का रखे हुए"
-#, fuzzy
-#~ msgid "display, export, GPS"
-#~ msgstr "गामा."
-#, fuzzy
-#~ msgid "Name of the column"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "raster, elevation"
-#~ msgstr "ट्रेस"
-#, fuzzy
-#~ msgid "Input elevation map"
-#~ msgstr "ज़ेड"
-#, fuzzy
-#~ msgid "Output shaded relief map name"
-#~ msgstr "ढाल फ़ाइलनाम "
-#, fuzzy
-#~ msgid "Redraws the current display frame in the GRASS monitor"
-#, fuzzy
-#~ msgid "Redraw all frames"
-#~ msgstr "a"
-#, fuzzy
-#~ msgid "Old schema"
-#, fuzzy
-#~ msgid "New schema"
-#, fuzzy
-#~ msgid "Saves active display monitor to PNG file in home directory"
-#, fuzzy
-#~ msgid "display, export"
-#~ msgstr "गामा."
-#, fuzzy
-#~ msgid "Name of PNG file"
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Import of SPOT VGT NDVI file into a raster map"
-#~ msgstr "a a"
-#, fuzzy
-#~ msgid "raster, imagery, import"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "display, diagram"
-#~ msgstr "गामा."
-#, fuzzy
-#~ msgid "Name of optional EPS output file"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Skip the join column in other table"
-#, fuzzy
-#~ msgid "Copy all the columns from other table to map"
-#, fuzzy
-#~ msgid "Join column in map table"
-#, fuzzy
-#~ msgid "raster, mask"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Overwrite existing MASK"
-#~ msgstr "डाटाटाइप."
-#, fuzzy
-#~ msgid "Exports GRASS raster into GDAL supported formats."
-#~ msgstr "a a."
-#, fuzzy
-#~ msgid "Column on which to calculate statistics (must be numeric)"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Reports geometry statistics for vectors."
-#, fuzzy
-#~ msgid "vector, report, statistics"
-#~ msgstr "वस्तु."
-#, fuzzy
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
-#~ msgstr "f a h"
-#, fuzzy
-#~ msgid "Slide show of GRASS raster/vector maps."
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "display, slideshow"
-#~ msgstr "गामा."
-#, fuzzy
-#~ msgid "Show vector maps rather than raster maps"
-#~ msgstr "सेट जोड़ा"
-#, fuzzy
-#~ msgid "Map number show across the monitor"
-#~ msgstr "संख्या का खण्ड"
-#, fuzzy
-#~ msgid "Map number show down the monitor"
-#, fuzzy
-#~ msgid "Number of seconds to pause between slides"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Display manager for GRASS"
-#, fuzzy
-#~ msgid "Name of .dmrc settings file"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Import E00 file into a vector map."
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "GIS manager for GRASS"
-#, fuzzy
-#~ msgid "Name of GIS manager settings file (.grc)"
-#~ msgstr "का फ़ाइल"
-#, fuzzy
-#~ msgid "raster, statistics, aggregation"
-#~ msgstr "वस्तु."
-#, fuzzy
-#~ msgid "Do not overwrite existing map"
-#, fuzzy
-#~ msgid "raster, imagery, colors"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Raster input maps"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Select multiple points"
-#~ msgstr "विशेषता"
-#, fuzzy
-#~ msgid "Display monitor to start"
-#, fuzzy
-#~ msgid "Imports geonames.org country files into a GRASS vector points map."
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "vector, import, GPS"
-#~ msgstr "सदिश"
-#, fuzzy
-#~ msgid "Table to drop"
-#, fuzzy
-#~ msgid "Output raster map (default: input tile)"
-#~ msgstr "शीर्षक"
-#, fuzzy
-#~ msgid "Saves the contents of the active display monitor to a graphics file."
-#, fuzzy
-#~ msgid "Name for output file (do NOT add extension)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Images"
-#~ msgstr "समूह"
-#, fuzzy
-#~ msgid "Width and height of output image (overrides resolution setting)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Compression for PNG files"
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Paper size for PostScript output"
-#~ msgstr "छापें"
-#, fuzzy
-#~ msgid "Set transparent background"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Do not crop away margins"
-#~ msgstr "नक़ल"
-#, fuzzy
-#~ msgid "Name of aspect raster map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "vector, color table"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Layer number of data column"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Name of color column to populate"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Manually set range (min,max)"
-#~ msgstr "पूर्णांक"
-#, fuzzy
-#~ msgid "Raster map name from which to copy color table"
-#~ msgstr "नक़ल"
-#, fuzzy
-#~ msgid "sites, vector, import"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "raster, elevation, interpolation"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of input raster map in which to fill nulls"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Name for output raster map with nulls filled by interpolation"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Moves displayed maps to another monitor"
-#, fuzzy
-#~ msgid "stay with source monitor"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Target monitor"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Source monitor"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "vector, centroid, area"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Layer where to add new attribute table"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "A (grid3D file)"
-#~ msgstr "फ़ाइलनाम "
-#, fuzzy
-#~ msgid "B (grid3D file)"
-#, fuzzy
-#~ msgid "C (grid3D file)"
-#, fuzzy
-#~ msgid "D (grid3D file)"
-#, fuzzy
-#~ msgid "E (grid3D file)"
-#, fuzzy
-#~ msgid "F (grid3D file)"
-#, fuzzy
-#~ msgid "Name for output grid3D volume"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Name of raster map to generate legend from"
-#, fuzzy
-#~ msgid "Name of raster map to print in legend"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "miscellaneous, projection"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Input coordinate file (omit to read from stdin)"
-#~ msgstr "उत्तर पूर्व"
-#, fuzzy
-#~ msgid "Output coordinate file (omit to send to stdout)"
-#, fuzzy
-#~ msgid "raster, imagery, statistics"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of the column to drop"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Split the display into subframes."
-#~ msgstr "का a"
-#, fuzzy
-#~ msgid "Number of subframes"
-#~ msgstr "का फ्रेम्स"
-#, fuzzy
-#~ msgid "Import waypoints"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Import routes"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Import track"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Device or file used to import data"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "vector, export, GPS"
-#~ msgstr "सदिश"
-#, fuzzy
-#~ msgid "GpsBabel supported output format"
-#, fuzzy
-#~ msgid "raster, imagery, mosaicking"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "calculates univariate statistics from a GRASS raster map"
-#~ msgstr "का a."
-#, fuzzy
-#~ msgid "Percentile to calculate (requires -e flag)"
-#~ msgstr "छापें"
-#, fuzzy
-#~ msgid "raster, tiling"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
-#~ msgstr "ऊंचाई के लिए"
-#, fuzzy
-#~ msgid "raster, imagery"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "use transformation rules for LANDSAT-4"
-#, fuzzy
-#~ msgid "use transformation rules for LANDSAT-5"
-#, fuzzy
-#~ msgid "use transformation rules for LANDSAT-7"
-#, fuzzy
-#~ msgid "raster input map (LANDSAT channel 1)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "raster input map (LANDSAT channel 2)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "raster input map (LANDSAT channel 3)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "raster input map (LANDSAT channel 4)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "raster input map (LANDSAT channel 5)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "raster input map (LANDSAT channel 7)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Enter raster map to display in 1st frame"
-#~ msgstr "का a"
-#, fuzzy
-#~ msgid "Enter command to execute in 1st frame"
-#~ msgstr "का a"
-#, fuzzy
-#~ msgid "Enter raster map to display in 2nd frame"
-#~ msgstr "का a"
-#, fuzzy
-#~ msgid "Enter command to execute in 2nd frame"
-#~ msgstr "का a"
-#, fuzzy
-#~ msgid "How to split display"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "imagery, fusion, Brovey"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "general, extensions"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "List available modules in the GRASS Addons SVN repository"
-#~ msgstr "स्रोत"
-#, fuzzy
-#~ msgid "Configuration editor for r.li.'index'"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "raster, landscape structure analysis"
-#~ msgstr "वस्तु."
-#, fuzzy
-#~ msgid "vector, area, dissolve"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Layer number. If -1, all layers are extracted."
-#, fuzzy
-#~ msgid "Name of column used to dissolve common boundaries"
-#, fuzzy
-#~ msgid "Name of shaded relief or aspect map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of raster to drape over relief map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "writing edges..."
-#~ msgstr "छापें"
-#, fuzzy
-#~ msgid "raster3d, statistics"
-#~ msgstr "वस्तु."
-#, fuzzy
-#~ msgid "raster, png"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)"
-#, fuzzy
-#~ msgid "Convert all old GRASS < Ver5.7 vector maps in current mapset to current format"
-#~ msgstr "a a."
-#, fuzzy
-#~ msgid "Unhandled vector feature type <%s>"
-#~ msgstr "i n"
-#, fuzzy
-#~ msgid "No areas found, skipping type=area"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "No points found, skipping%s%s"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "No lines found, skipping%s%s"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "GDAL datatype: %s, range: %f - %f"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Pass %d:"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "The '-q' flag is superseded and will be removed "
-#~ msgstr "i n"
-#, fuzzy
-#~ msgid "Unable to create table <%s_edge_Interpolation>"
-#, fuzzy
-#~ msgid "Rescale output raster map [0,255]"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Converting %s..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation layer."
-#~ msgstr "a a a"
-#, fuzzy
-#~ msgid "Cannot make stat of %s configuration file"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Calculates cast shadow areas from sun position and DEM. Either A: exact sun position is specified, or B: date/time to calculate the sun position by r.sunmask itself."
-#~ msgstr "है."
-#, fuzzy
-#~ msgid "A: altitude of the sun above horizon, degrees"
-#~ msgstr "का कोण"
-#, fuzzy
-#~ msgid "A: azimuth of the sun from the north, degrees"
-#~ msgstr "का उत्तर कोण"
-#, fuzzy
-#~ msgid "B: timezone (east positive, offset from GMT, also use to adjust daylight savings)"
-#~ msgstr "पूर्व जीएमटी"
-#, fuzzy
-#~ msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
-#~ msgstr "a बीटा."
-#, fuzzy
-#~ msgid "Unable to read symbol, unable todisplay points"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Feature type. Combination of types is not supported by all formats."
-#, fuzzy
-#~ msgid "%d faces found, but not requested to be exported. Verify 'type' parameter."
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "Exporting %i points/lines..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "vector, query"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Number of column used as y coordinate (first column is 1) for points mode"
-#~ msgstr "का है के लिए"
-#, fuzzy
-#~ msgid "Number of column used as z coordinate (first column is 1) for points mode"
-#, fuzzy
-#~ msgid "Number of column used as category (first column is 1) for points mode"
-#, fuzzy
-#~ msgid "If 0, unique category is assigned to each row and written to new column 'cat'"
-#~ msgstr "का है के लिए है."
-#, fuzzy
-#~ msgid "Create a new empty vector map and exit. Nothing is read from input"
-#~ msgstr "a है."
-#, fuzzy
-#~ msgid "Name for output file (do not add extension)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Width and height of output image"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Volume"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Vector map for which to edit attribute table"
-#, fuzzy
-#~ msgid "Layer where to add column"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Computing row %d of covariance matrix..."
-#~ msgstr "माट्रिक्स."
-#, fuzzy
-#~ msgid "display, legend"
-#~ msgstr "गामा."
-#, fuzzy
-#~ msgid "Output field seperator"
-#~ msgstr "फील्ड"
-#, fuzzy
-#~ msgid "ID values"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Type of elements"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Database record for cat %d not found"
-#~ msgstr "नहीं के लिए"
-#, fuzzy
-#~ msgid "Could not find input map <%s> in current mapset."
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Could not find input vector map %s"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Number of column used as z coordinate (first column is 1) for points mode. If 0, z coordinate is not used."
-#~ msgstr "का ज़ेड है के लिए ज़ेड है नहीं."
-#, fuzzy
-#~ msgid "Print the current region (shell script style)"
-#~ msgstr "छापें"
-#, fuzzy
-#~ msgid "Name of the column with tree height"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of the column with tree species"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Use category data instead of attribute"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Import non-georeferenced PNG format image."
-#~ msgstr "आयात छवि."
-#, fuzzy
-#~ msgid "Name of spheroid to use"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "ERROR: Required parameter <%s> not set:\n"
-#~ "    (%s).\n"
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "output field separator"
-#~ msgstr "फील्ड"
-#, fuzzy
-#~ msgid "Name for G3d raster map"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Band to select"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Cannot select records from database"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Removed vertices"
-#, fuzzy
-#~ msgid "Line: %d\n"
-#, fuzzy
-#~ msgid "Cannot create table: '%s'"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Cannot describe table <%s>"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Database connection not defined\n"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Cannot find file %s"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Cannot get header for %s"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Editing tool"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Out of memory!"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Cannot open driver <%s>"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "cannot create index"
-#~ msgstr "फील्ड"
-#, fuzzy
-#~ msgid "New vector composite"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "No database updates."
-#~ msgstr "सभी."
-#, fuzzy
-#~ msgid "%s Pan\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Cannot open driver\n"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Cannot open database\n"
-#~ msgstr "स्रोत"
-#, fuzzy
-#~ msgid "Could not close G3D map"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Could not write raster row"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Could not close G3D map <%s>"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "unable to close input 3d raster map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Could not get top raster row \n"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Could not get bottom raster row \n"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Name of an existing raster map layer"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "input,cell,raster"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "output,cell,raster"
-#~ msgstr "फील्ड"
-#, fuzzy
-#~ msgid "raster, vector, visualization"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Exporting raster as double values (bytes=%d)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Number of bytes per cell (1, 2, 4)"
-#~ msgstr "का बाइट्स"
-#, fuzzy
-#~ msgid "Parsing bytes per cell"
-#~ msgstr "संख्या का बाइट्स"
-#, fuzzy
-#~ msgid "You have to provide all limits of geographic region (n,s,e,w)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Illegal number of rows <%s>"
-#~ msgstr "चेतावनी."
-#, fuzzy
-#~ msgid "Illegal number of columns <%s>"
-#~ msgstr "संख्या का n"
-#, fuzzy
-#~ msgid "Remove lines and areas smaller than threshold"
-#~ msgstr "हटाएँ सभी फ्रेम्स"
-#, fuzzy
-#~ msgid "Unable to calculate centroid for area %d"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "File containing mapping instructions (or use input=- to enter from keyboard)"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Cannot set GRASS_VERBOSE variable."
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Reading raster map <%s in %s> ..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "into  <%s@%s> (location <%s>) ... %s"
-#, fuzzy
-#~ msgid "Rectified input raster map <%s> will be saved as <%s>"
-#, fuzzy
-#~ msgid "Target information for group <%s> missing.\n"
-#, fuzzy
-#~ msgid "Target location <%s> not found\n"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Location of input raster map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Mapset of input raster map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Checking location <%s>, mapset <%s>..."
-#~ msgstr "का"
-#, fuzzy
-#~ msgid " %d.%02d.%02d, daynum %d, time: %02i:%02i:%02i (decimal time: %f)\n"
-#~ msgstr "f n"
-#, fuzzy
-#~ msgid " long: %f, lat: %f, timezone: %f\n"
-#~ msgstr "f f f n"
-#, fuzzy
-#~ msgid ""
-#~ " Solar position: sun azimuth: %f,\n"
-#~ "   sun angle above horz.(refraction corrected): %f\n"
-#~ msgstr ""
-#~ "f\n"
-#~ " कोण f n"
-#, fuzzy
-#~ msgid " Sunrise time (without refraction): %02d:%02d:%02d\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid " Sunset time  (without refraction): %02d:%02d:%02d\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "No map calculation requested. Finished.\n"
-#~ msgstr "नहीं पूर्ण n"
-#, fuzzy
-#~ msgid "Can't open range file for %s"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Can't read row in input elevation map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "<%s> created"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Unable to open rules file <%s>"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Displays and overlays raster map layers in the active display frame on the graphics monitor."
-#~ msgstr "चालू."
-#, fuzzy
-#~ msgid "Displays vector data in the active frame on the graphics monitor."
-#~ msgstr "चालू."
-#, fuzzy
-#~ msgid "vector, projection"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Allows projection conversion of vector maps."
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Duplicate area centroids"
-#, fuzzy
-#~ msgid "Vector output map"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Error while writing to temp file"
-#~ msgstr "त्रुटि."
-#, fuzzy
-#~ msgid "Error writing row %d"
-#, fuzzy
-#~ msgid "Poorly placed psuedo control points. "
-#~ msgstr "घुमाएँ"
-#, fuzzy
-#~ msgid "Cannot generate the transformation equation."
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "No active psuedo control points"
-#~ msgstr "घुमाएँ"
-#, fuzzy
-#~ msgid "Unable to write temp file: %s"
-#~ msgstr "बनाया जा रहा है."
-#, fuzzy
-#~ msgid "Unable to open map %s"
-#, fuzzy
-#~ msgid "Unable to write row %d"
-#, fuzzy
-#~ msgid "%s@%s: projection doesn't match current settings"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "%s@%s: zone doesn't match current settings"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Failed in attempt to open %s"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Generates raster map layers of slope, aspect, curvatures and partial derivatives from a raster map layer of true elevation values. Aspect is calculated counterclockwise from east."
-#~ msgstr "का ढाल a का है पूर्व."
-#, fuzzy
-#~ msgid "Output profile curvature filename"
-#, fuzzy
-#~ msgid "Output tangential curvature filename"
-#, fuzzy
-#~ msgid "Output first order partial derivative dx (E-W slope) filename"
-#~ msgstr "प ढाल फ़ाइलनाम "
-#, fuzzy
-#~ msgid "Output first order partial derivative dy (N-S slope) filename"
-#, fuzzy
-#~ msgid "Output second order partial derivative dxx filename"
-#, fuzzy
-#~ msgid "Output second order partial derivative dyy filename"
-#, fuzzy
-#~ msgid "Output second order partial derivative dxy filename"
-#, fuzzy
-#~ msgid "Creating support files..."
-#~ msgstr "बनाया जा रहा है के लिए"
-#, fuzzy
-#~ msgid "Elevation products for mapset [%s] in [%s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "E-W SLOPE [%s] COMPLETE"
-#~ msgstr "प"
-#, fuzzy
-#~ msgid "Name of vector input map containing stream(s)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Generates a raster map layer showing watershed subbasins."
-#~ msgstr "a."
-#, fuzzy
-#~ msgid "Name for the resultant watershed partition file"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Name of terrain raster map (DEM)"
-#~ msgstr "i n"
-#, fuzzy
-#~ msgid "Name of the elevation raster map [m]"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Output water depth raster map [m]"
-#~ msgstr "ढाल"
-#, fuzzy
-#~ msgid "Output topographic index map"
-#~ msgstr "a"
-#, fuzzy
-#~ msgid "Input elevation raster map"
-#~ msgstr "ज़ेड"
-#, fuzzy
-#~ msgid "Input aspect raster map"
-#~ msgstr "ढाल"
-#, fuzzy
-#~ msgid "Input barrier raster map"
-#, fuzzy
-#~ msgid "B: year (1950..2050)"
-#~ msgstr "वर्ष"
-#, fuzzy
-#~ msgid "B: month (0..12)"
-#~ msgstr "माह"
-#, fuzzy
-#~ msgid "B: hour (0..24)"
-#~ msgstr "घंटा"
-#, fuzzy
-#~ msgid "East coordinate (point of interest, default: map center)"
-#~ msgstr "पूर्व बिन्दु का"
-#, fuzzy
-#~ msgid "North coordinate (point of interest, default: map center)"
-#~ msgstr "उत्तर बिन्दु का"
-#, fuzzy
-#~ msgid "Zero is a real elevation"
-#~ msgstr "है a"
-#, fuzzy
-#~ msgid "(i)   Elevation map"
-#~ msgstr "i आयताकार"
-#, fuzzy
-#~ msgid "(o)   Topographic index ln(a/tanB) map (MASK applied)"
-#~ msgstr "a"
-#, fuzzy
-#~ msgid "(i)   OPTIONAL Output for given time step"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "(i)   OPTIONAL Output for given topographic index class"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Name of existing raster map containing elevation surface"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Reading map..."
-#~ msgstr "छवि "
-#, fuzzy
-#~ msgid "Input map: elevation on which entire analysis is based"
-#~ msgstr "चालू है"
-#, fuzzy
-#~ msgid "Input map or value: percent of disturbed land, for USLE"
-#, fuzzy
-#~ msgid "Watershed basin creation program."
-#~ msgstr "प्रोग्राम."
-#, fuzzy
-#~ msgid "Name of input vector points map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of output vector area map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Cannot open vector map <%s>"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "<Auxiliar_edge_table> created in database."
-#, fuzzy
-#~ msgid "Unable to open table <%s_edge_Interpolation>"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Selects data from table."
-#~ msgstr "सभी"
-#, fuzzy
-#~ msgid "Source map is: Integer cell type"
-#~ msgstr "है पूर्णांक"
-#, fuzzy
-#~ msgid "Source map is: Floating point (float) cell type"
-#~ msgstr "है फ्लोटिंग बिन्दु"
-#, fuzzy
-#~ msgid "Source map is: Floating point (double) cell type"
-#, fuzzy
-#~ msgid "Reading %s"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Writing %s"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Error getting input null cells"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "Unable to open MASK"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in a local text file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
-#~ msgstr "के लिए जी a पाठ a कोण का है."
-#, fuzzy
-#~ msgid "Name of the longitude input raster map [decimal degrees]"
-#~ msgstr "का कोण"
-#, fuzzy
-#~ msgid "Spline type of interpolation"
-#, fuzzy
-#~ msgid "Number of column used as x coordinate (first column is 1) for points mode"
-#, fuzzy
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares)"
-#~ msgstr "f a h"
-#, fuzzy
-#~ msgid ""
-#~ "Subgroup too large.  Maximum number of bands is %d\n"
-#~ msgstr "बड़ा संख्या का है n."
-#, fuzzy
-#~ msgid "Script kill option"
-#~ msgstr "स्क्रिप्ट"
-#, fuzzy
-#~ msgid "Output more comments (default=quiet)"
-#~ msgstr "शीर्षक"
-#, fuzzy
-#~ msgid "Vector map to display thematically"
-#~ msgstr "सदिश"
-#, fuzzy
-#~ msgid "Vector map type"
-#~ msgstr "सदिश"
-#, fuzzy
-#~ msgid "Layer to use for thematic display"
-#, fuzzy
-#~ msgid "Mapset(s) to list (default: current mapset search path)"
-#~ msgstr "छापें"
-#, fuzzy
-#~ msgid "Output separator (default: newline)"
-#~ msgstr "शीर्षक"
-#, fuzzy
-#~ msgid "Raster to remove"
-#~ msgstr "Bin"
-#, fuzzy
-#~ msgid "3d raster to remove"
-#~ msgstr "Bin"
-#, fuzzy
-#~ msgid "Vector to remove"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Region to remove"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Label to remove"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "3dview to remove"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Group to remove"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "ERROR: Problem opening output file."
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Density of output walkers"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "File [%s] not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Unable to open file [%s]"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Reading sites map (%s) ..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Name of the output walkers vector points map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "You are not outputting any raster or vector points maps"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "%s=%s - illegal value"
-#~ msgstr "है"
-#, fuzzy
-#~ msgid "Unable to read current region parameters"
-#~ msgstr "छापें"
-#, fuzzy
-#~ msgid "Cannot open cover raster map <%s>"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "No map specified"
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "%s - unable to remove color table"
-#, fuzzy
-#~ msgid "%s - color table not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Can't make logarithmic color table for floating point map"
-#~ msgstr "है के लिए बिन्दु!"
-#, fuzzy
-#~ msgid "Starting map [%s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Unable to properly read input raster map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Unable to properly write output raster map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of raster map layer to be used for <%s>"
-#, fuzzy
-#~ msgid "%d points converted to centroids"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "%d centroids converted to points"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "CrossCorrelation: %d points read in region.\n"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "CrossCorrelation: Cannot read field info"
-#~ msgstr "फील्ड"
-#, fuzzy
-#~ msgid "CrossCorrelation: Cannot open database %s by driver %s"
-#~ msgstr "स्रोत"
-#, fuzzy
-#~ msgid "CrossCorrelation: Column type not supported"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "CrossCorrelation: Cannot select data from table"
-#~ msgstr "सभी"
-#, fuzzy
-#~ msgid "CrossCorrelation: No record for point (cat = %d)"
-#, fuzzy
-#~ msgid "vector, attribute table"
-#~ msgstr "छापें"
-#, fuzzy
-#~ msgid "Cannot fetch data"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Do not print polyline info"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Feature id(s)"
-#, fuzzy
-#~ msgid "Input vector was not found."
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "Hilight color for text"
-#~ msgstr "उभारें के लिए पाठ के लिए"
-#, fuzzy
-#~ msgid "Node layer (points)"
-#, fuzzy
-#~ msgid "Reading data from the map..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Query layer (used by 'query' option)"
-#~ msgstr "क्वैरी उपयोग में."
-#, fuzzy
-#~ msgid "%d categories read from map"
-#, fuzzy
-#~ msgid "Writing attributes ..."
-#~ msgstr "छापें"
-#, fuzzy
-#~ msgid "Current region does not include the entire input vector map <%s>"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Output inverse raster map after IFFT"
-#~ msgstr "घनत्व"
-#, fuzzy
-#~ msgid "%s: %s - Unable to find the real-image map."
-#~ msgstr "छवि."
-#, fuzzy
-#~ msgid "%s: %s - Unable to find the imaginary-image."
-#~ msgstr "छवि."
-#, fuzzy
-#~ msgid "Power 2 values : [%d] rows [%d] columns."
-#~ msgstr "पावर."
-#, fuzzy
-#~ msgid "Insufficent memory for allocation of data structure"
-#~ msgstr "के लिए का."
-#, fuzzy
-#~ msgid "Inverse FFT completed..."
-#~ msgstr "पूर्ण."
-#, fuzzy
-#~ msgid "Hue map name"
-#~ msgstr "है"
-#, fuzzy
-#~ msgid "Intensity map name"
-#, fuzzy
-#~ msgid "Saturation map name"
-#, fuzzy
-#~ msgid "Output map representing the red"
-#~ msgstr "के लिए ढाल"
-#, fuzzy
-#~ msgid "Output map representing the green"
-#, fuzzy
-#~ msgid "Output map representing the blue"
-#, fuzzy
-#~ msgid "Cannot read row from raster map"
-#, fuzzy
-#~ msgid "Cannot write row to raster map"
-#, fuzzy
-#~ msgid "Red input raster map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Green input raster map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Blue input raster map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Output intensity raster map"
-#~ msgstr "घनत्व"
-#, fuzzy
-#~ msgid "Transition probabilities: %f %f %f; %f"
-#~ msgstr "f f f f"
-#, fuzzy
-#~ msgid "get_img: out of memory."
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Name of imagery signaturefile"
-#~ msgstr "का समूह"
-#, fuzzy
-#~ msgid "Subgroup [%s] not found."
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "Signature file [%s] is missing or not readable."
-#~ msgstr "हस्ताक्षर है नहीं."
-#, fuzzy
-#~ msgid "Cannot write color table of raster map <%s>"
-#, fuzzy
-#~ msgid "Calculating class covariance matrix..."
-#, fuzzy
-#~ msgid "Imagery group"
-#~ msgstr "समूह"
-#, fuzzy
-#~ msgid "Subgroup containing image files"
-#~ msgstr "छवि"
-#, fuzzy
-#~ msgid "Resultant signature file"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Unable to create signature file [%s] for subgroup [%s] in group [%s]."
-#~ msgstr "के लिए समूह."
-#, fuzzy
-#~ msgid "Input raster map being fft"
-#~ msgstr "शीर्षक"
-#, fuzzy
-#~ msgid "Illegal file name for real part: %s"
-#~ msgstr "के लिए भाग n"
-#, fuzzy
-#~ msgid "Illegal file name for imaginary part: %s"
-#, fuzzy
-#~ msgid "Initializing data...\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "FFT completed..."
-#~ msgstr "पूर्ण."
-#, fuzzy
-#~ msgid "subgroup <%s> not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Group of imagery files to be clustered"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Subgroup name in the above group"
-#~ msgstr "समूह"
-#, fuzzy
-#~ msgid "Reading image ... "
-#~ msgstr "छवि "
-#, fuzzy
-#~ msgid "Unable to read head of %s"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "group=[%s] - not found."
-#~ msgstr "समूह नहीं."
-#, fuzzy
-#~ msgid "subgroup=[%s] (of group [%s]) - not found."
-#~ msgstr "का समूह नहीं."
-#, fuzzy
-#~ msgid "[%s] has more than 255 signatures."
-#~ msgstr "अधिक."
-#, fuzzy
-#~ msgid "Imagery group to be classified"
-#~ msgstr "समूह"
-#, fuzzy
-#~ msgid "Subgroup containing image files to be classified"
-#~ msgstr "छवि"
-#, fuzzy
-#~ msgid "Signatures to use for classification"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Cannot select attributes: %s"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Background color, either a standard GRASS color, R:G:B triplet, or \"none\""
-#~ msgstr "a R जी"
-#, fuzzy
-#~ msgid ""
-#~ "Optional where condition (without WHERE key word), e.g.:\n"
-#~ "\t\tobec = 'Liptakov'"
-#~ msgstr "जी n"
-#, fuzzy
-#~ msgid "Keep band numbers instead of using band color names."
-#~ msgstr "रखें का"
-#, fuzzy
-#~ msgid "Output raster map with lake"
-#~ msgstr "शीर्षक"
-#, fuzzy
-#~ msgid "Terrain raster map <%s> not found!"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Cannot open terrain raster map <%s@%s>!"
-#, fuzzy
-#~ msgid "Seed map <%s> not found!"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Cannot open seed map <%s@%s>!"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Failure to allocate memory for row pointers"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Loading maps: "
-#~ msgstr "त्रुटि के लिए"
-#, fuzzy
-#~ msgid "Error reading terrain raster map. Probably broken file."
-#, fuzzy
-#~ msgid "Error reading seed raster map. Probably broken file."
-#, fuzzy
-#~ msgid "Cannot write lake raster map <%s@%s>!"
-#, fuzzy
-#~ msgid "Error writing color file for <%s@%s>!"
-#, fuzzy
-#~ msgid "All done."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Name of the vector points map with x,y locations"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Number of time iterations (sec.)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Multiscale simulation"
-#~ msgstr "है a"
-#, fuzzy
-#~ msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
-#~ msgstr "का मीटर्स"
-#, fuzzy
-#~ msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Calculates <simple> index on a raster map"
-#~ msgstr "a"
-#, fuzzy
-#~ msgid "%s: can't read fp range for [%s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid ""
-#~ "Raster map [%s] already exists.\n"
-#~ "Please try another."
-#~ msgstr "समूह."
-#, fuzzy
-#~ msgid "Error reading '%s' map"
-#, fuzzy
-#~ msgid "Threshold distance"
-#~ msgstr "सेट इंचेस"
-#, fuzzy
-#~ msgid "Cannot execute: %s"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "Cannot link table: %s"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Cannot open dxf file <%s>"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Cannot open new vector map <%s>"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Conversion of <%s> to vector map:"
-#~ msgstr "a a."
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "<%s> -- illegal result signature file name"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Raster file(s) for Elevation"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Raster file(s) for Color"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Save the current region to region definition file"
-#~ msgstr "सहेजें"
-#, fuzzy
-#~ msgid "No LatLong information for XY-Projection"
-#~ msgstr "है नहीं के लिए"
-#, fuzzy
-#~ msgid "Could not open input file <%s>."
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "No such monitor as '%s'"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Error - No such monitor as '%s'"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid ""
-#~ "\a\n"
-#~ "** The following raster maps in subgroup [%s] do not exist:"
-#~ msgstr "n नहीं:"
-#, fuzzy
-#~ msgid "Writing group REF"
-#~ msgstr "समूह"
-#, fuzzy
-#~ msgid "Multiplier"
-#, fuzzy
-#~ msgid ""
-#~ "Projection of input dataset and current location appear to match.\n"
-#~ "Proceeding with import...\n"
-#~ msgstr "का जोड़ा n"
-#, fuzzy
-#~ msgid "Name of the resultant map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "%s: can't read range for [%s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Raster file [%s] not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "It was not possible writing in <%s>."
-#~ msgstr "i n"
-#, fuzzy
-#~ msgid "\rDuplicate area centroids: %5d"
-#, fuzzy
-#~ msgid "Unable to get category list <%s>, editing terminated"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Unable to delete layer/category [%d/%d] line %d"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Unable to write line %d"
-#, fuzzy
-#~ msgid "Unable to delete line %d"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Unknown query tool '%s'"
-#, fuzzy
-#~ msgid "No layer database connection"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "%d categories loaded from the database"
-#, fuzzy
-#~ msgid "Cannot open OGR data source '%s'"
-#~ msgstr "स्रोत"
-#, fuzzy
-#~ msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
-#~ msgstr "सदिश नहीं"
-#, fuzzy
-#~ msgid "Load values from vector to database. For uploaded/printed category values '-1' is used for 'no category' and 'null'/'-' if category cannot be found or multiple categories were found."
-#~ msgstr "है के लिए."
-#, fuzzy
-#~ msgid "Column type [%d] not supported"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Cannot read map header for <%s>"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Cannot read category file for <%s>"
-#~ msgstr "संपादन के लिए "
-#, fuzzy
-#~ msgid "Print;Shell Script"
-#~ msgstr "छापें"
-#, fuzzy
-#~ msgid "Creating support files for [%s]."
-#~ msgstr "बनाया जा रहा है के लिए."
-#, fuzzy
-#~ msgid "%s: <%s> raster map not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Cannot read category file of raster map <%s>"
-#, fuzzy
-#~ msgid "%s - map not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "%s not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Could not access %s layer"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Vector map %s - not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Raster map name for storing results"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Height of the viewing location"
-#~ msgstr "ऊंचाई का"
-#, fuzzy
-#~ msgid "%s: <%s> cellfile not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Cell file [%s] not found\n"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "rgb cell map [%s] not found\n"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "vector cell map [%s] not found\n"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "%s - %s not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "can't read header for <%s> in <%s>"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "invalid region: %s"
-#~ msgstr "अवैध"
-#, fuzzy
-#~ msgid "Unable to read category file for raster map <%s>"
-#, fuzzy
-#~ msgid "Creating support files"
-#, fuzzy
-#~ msgid "%s file [%s] not found!"
-#~ msgstr "नहीं!"
-#, fuzzy
-#~ msgid "%s: %s - map not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "%s: unable to open %s"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "%s - not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "[%s] map not found."
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "[%s] map not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "min computed slope %.4f  max computed slope %.4f"
-#~ msgstr "ढाल ढाल"
-#, fuzzy
-#~ msgid "Cannot insert values: %s"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "%s given an illegal number of points [%d]"
-#~ msgstr "संख्या का"
-#, fuzzy
-#~ msgid "Unable to open database %s by driver %s"
-#~ msgstr "स्रोत"
-#, fuzzy
-#~ msgid "No DB connection settings defined. Set with db.connect"
-#~ msgstr "नहीं सेट"
-#, fuzzy
-#~ msgid "Could not find input %s"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Could not open input"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Could not open output"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Could not find input map <%s>"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Can't read header for <%s> in <%s>"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Can't read header for 3D raster <%s> in <%s>"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Can't write region <%s>"
-#, fuzzy
-#~ msgid "<%s=%s> ** invalid input **"
-#~ msgstr "अवैध"
-#, fuzzy
-#~ msgid "No graphics device selected."
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "%s map not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "cannot read head of %s"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Illegal file name: %s"
-#, fuzzy
-#~ msgid "Cannot get layer info for vector map"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Cannot open raster map <%s> in <%s>"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "cover values extracted from the category labels of the cover map"
-#~ msgstr "कवर का कवर"
-#, fuzzy
-#~ msgid "%s: %s - raster map not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "%s: ERROR reading category file for %s"
-#, fuzzy
-#~ msgid "%s: %s - not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "%s: %s - illegal units"
-#~ msgstr "है"
-#, fuzzy
-#~ msgid "%s: %s - can't open"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Reading input map (%s)    ... "
-#~ msgstr "छवि "
-#, fuzzy
-#~ msgid "%s - ERROR reading %s"
-#~ msgstr "त्रुटि चल रहा है..."
-#, fuzzy
-#~ msgid "%s: %s - can't create raster map"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Writing output map (%s)   ... "
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "%s - ERROR re-reading %s"
-#, fuzzy
-#~ msgid "%s - ERROR writing %s"
-#, fuzzy
-#~ msgid "Reading raster map... "
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Writing raster map... "
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Category list: e.g. 1,3-8,13"
-#~ msgstr "जी 13"
-#, fuzzy
-#~ msgid "Cannot read category file of raster map <%s> in <%s>"
-#, fuzzy
-#~ msgid "Cannot create raster map %s"
-#, fuzzy
-#~ msgid "Cannot create vector map %s"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Cannot create raster map '%s'"
-#, fuzzy
-#~ msgid "Number of raster rows to hold in memory"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Print raster map title only"
-#~ msgstr "छापें"
-#, fuzzy
-#~ msgid "unknown type: %d"
-#, fuzzy
-#~ msgid "Cannot get raster band."
-#~ msgstr "फील्ड"
-#, fuzzy
-#~ msgid "Cannot allocate buffer for reading null values."
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Cannot read GRASS raster."
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Cannot get [%s] driver"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Couldn't set geo transform."
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Couldn't set projection."
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Cannot export [%s] raster map."
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Cannot create [%s] raster map using [%s] driver."
-#, fuzzy
-#~ msgid "Cannot read header of raster map <%s>"
-#, fuzzy
-#~ msgid "Cannot open TIFF file <%s>"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Reading raster map"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Cannot open output map."
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Illegal file name. Please try another."
-#, fuzzy
-#~ msgid "%s: can't open %s"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Reading raster map <%s> ..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "memory allocation failure"
-#~ msgstr "के लिए का"
-#, fuzzy
-#~ msgid "Can't find clump map."
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "Cannot open vector map <%s> at the topological level"
-#, fuzzy
-#~ msgid "Rebuilding topology ..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "No record for cat = %d"
-#, fuzzy
-#~ msgid "Removing duplicates ..."
-#, fuzzy
-#~ msgid "Attaching islands ..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Attaching centroids ..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Vector map <%s> not found in current mapset"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "The number of lines in the input vector map is [%d]"
-#~ msgstr "संख्या का पिक्सेल्स a"
-#, fuzzy
-#~ msgid "Database connection not defined for layer <%d>"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Cannot get layer info"
-#~ msgstr "फील्ड"
-#, fuzzy
-#~ msgid "cell file [%s] not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "can't open raster map [%s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Cannot rewrite line %d"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Cannot copy line %d, editing terminated"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "No layer database connection."
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Cannot snap lines %d,%d"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "%d lines modified"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Could not open ASCII file <%s>"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Print vector map region only"
-#~ msgstr "छापें"
-#, fuzzy
-#~ msgid "Cannot open vector map <%s> at topo level [%d]"
-#, fuzzy
-#~ msgid "Cannot get layer info for vector map <%s>"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Number of ROWS and COLUMNS in grid"
-#, fuzzy
-#~ msgid "Creating vector grid..."
-#, fuzzy
-#~ msgid "Could not find vector map <%s> in current mapset"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Could not find input map <%s>."
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Output map where segments will be written"
-#~ msgstr "i n"
-#, fuzzy
-#~ msgid "<%s> cellfile not found"
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "Not able to open vector map <%s>"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Table name, select all from this table"
-#~ msgstr "सभी"
-#, fuzzy
-#~ msgid "do not include column names in output"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "vertical output (instead of horizontal)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Cannot find mapset for %s"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Cannot open File %s"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Not able to open file for [%s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Label file [%s] not available"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "unable to open [%s] in [%s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "warning: unable to open [%s] in [%s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Unable to find input cell map '%s'"
-#, fuzzy
-#~ msgid "Unable to open cellfile for <%s>"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Unable to create raster map [%s]"
-#~ msgstr "का a"
-#, fuzzy
-#~ msgid "Unable to create output <%s>"
-#~ msgstr "i n"
-#, fuzzy
-#~ msgid "Input file [%s] not found."
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "Multiplier for ascii data"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Could not open temporary file: [%s]"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Could not open input file [%s]"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Unable to create output raster map <%s>"
-#, fuzzy
-#~ msgid "Name of the random surface to be produced"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "%s: Unable to find raster map <%s>"
-#, fuzzy
-#~ msgid "%s: Unable to open raster map <%s> in mapset <%s>"
-#, fuzzy
-#~ msgid "%s:  Unable to open output raster map <%s>"
-#, fuzzy
-#~ msgid "Vector <%s> could not be opened"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "No db connection for driver <%s> defined. Run db.connect."
-#, fuzzy
-#~ msgid ""
-#~ "Print current map connection parameters and exit (shell script style)\n"
-#~ "\tformat:  layer[/layer name] table key database driver"
-#~ msgstr "छापें n"
-#, fuzzy
-#~ msgid "z column name"
-#~ msgstr "ज़ेड"
-#, fuzzy
-#~ msgid "Cannot drop table: %s"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Cannot open labels <%s>"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid ""
-#~ "OGR output datasource name. For example:\n"
-#~ "\t\tESRI Shapefile: filename or directory for storage\n"
-#~ "\t\tMapInfo File: filename or directory for storage"
-#~ msgstr "n n फ़ाइल"
-#, fuzzy
-#~ msgid "SVG file <%s> cannot be opened"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Querying input '%s' ... "
-#~ msgstr "छवि "
-#, fuzzy
-#~ msgid "Copying %s input lines ... "
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Cannot create table <%s>"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "no record for cat = %d"
-#, fuzzy
-#~ msgid "cannot insert row: %s"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Cannot find line of cat %d"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Unalbe to open vector map <%s>"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Database connection not defined for layer [%d]. Use v.db.connect first"
-#~ msgstr "नहीं के लिए."
-#, fuzzy
-#~ msgid "Transforms a vector map via a set of tie points."
-#~ msgstr "एक."
-#, fuzzy
-#~ msgid "Raster map <%s>] not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Cannot start driver '%s'."
-#~ msgstr "प्रारंभ."
-#, fuzzy
-#~ msgid "Cannot start driver <%s>."
-#, fuzzy
-#~ msgid "Could not open <%s>"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Not able to open cellfile for [%s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Not able to find cellfile [%s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Raster map [%s] not available"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Raster file [%s] not available"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Raster map [%s] not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Unable to open raster map [%s]"
-#~ msgstr "का a"
-#, fuzzy
-#~ msgid "Vector file [%s] not available"
-#, fuzzy
-#~ msgid "<%s> illegal name"
-#~ msgstr "है"
-#, fuzzy
-#~ msgid "Out of Memory!\n"
-#~ msgstr "का n"
-#, fuzzy
-#~ msgid "%s: %s - Unable to open the input raster map\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Insufficent memory for allocation of data sturcture"
-#, fuzzy
-#~ msgid "%s: %s - illegal name for output raster map."
-#, fuzzy
-#~ msgid "Insufficent memory for allocation of data structure."
-#, fuzzy
-#~ msgid "Exports GRASS raster data into various formats (requires GDAL)."
-#~ msgstr "a a."
-#, fuzzy
-#~ msgid "%s: <%s> not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "%s: Cannot open <%s>"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "could not read range file"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Filtering [%s] in [%s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Open raster map %s in %s = %d"
-#~ msgstr "खोलें"
-#, fuzzy
-#~ msgid "Closing raster map"
-#~ msgstr "बनाया जा रहा है n"
-#, fuzzy
-#~ msgid "Swap temp files"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Writing [%s]"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "%s: illegal map name"
-#~ msgstr "है"
-#, fuzzy
-#~ msgid "%s: <%s> illegal file name"
-#~ msgstr "है"
-#, fuzzy
-#~ msgid "can't open raster map <%s> in mapset %s"
-#, fuzzy
-#~ msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
-#~ msgstr "a a छवि पर का."
-#, fuzzy
-#~ msgid "Mapset of input map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Checking location %s, mapset %s:"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Error writing output map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "[%s] is an illegal file name"
-#~ msgstr "है"
-#, fuzzy
-#~ msgid "Names of existing raster maps"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Unable to open input map <%s> in mapset <%s>"
-#~ msgstr "के लिए n"
-#, fuzzy
-#~ msgid "%s - illegal name "
-#~ msgstr "है"
-#, fuzzy
-#~ msgid "Couldn't find raster map [%s]"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "%s - can't create raster map"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Normalized"
-#~ msgstr "सामान्य किया"
-#, fuzzy
-#~ msgid "Cell file [%s] not found"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Error getting input null cells at row %d from %s"
-#~ msgstr "त्रुटि पर"
-#, fuzzy
-#~ msgid "[%s] file name not legal"
-#~ msgstr "है"
-#, fuzzy
-#~ msgid "[%s] file name not legal\n"
-#~ msgstr "है"
-#, fuzzy
-#~ msgid "Requested 3d raster map not found <%s>"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Could not open output map"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Could not close the 3d raster map"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Cannot create output map [%s]"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Database's name couldn't be read"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Cannot open vector points map <%s>"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Cannot create vector map <%s>"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Interpolation: No database connection for driver <%s> defined. Run db.connect"
-#, fuzzy
-#~ msgid "Vector file [%s] not available in search list"
-#, fuzzy
-#~ msgid "Cannot open database <%s>"
-#~ msgstr "स्रोत"
-#, fuzzy
-#~ msgid "Cannot open table <%s>"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Could not find input map '%s'."
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "Could not find network input map '%s'."
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "error opening raster map [%s]."
-#, fuzzy
-#~ msgid "Topology is not available"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Patching file <%s@%s>"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Column type  not supported"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Could not open vector map <%s>"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Database connection not defined for layer <%d>. Use v.db.connect first."
-#, fuzzy
-#~ msgid "Pass [%d] of [%d]:"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Illegal output name: '%s'"
-#, fuzzy
-#~ msgid "Can't create output map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Could not close new 3d raster map"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "%s: cellfile [%s] not found."
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "Error reading wildcard."
-#, fuzzy
-#~ msgid "Sets the grid color, either a standard GRASS color or R:G:B triplet (separated by colons)"
-#~ msgstr "a R जी"
-#, fuzzy
-#~ msgid "Sets the border color, either a standard GRASS color or R:G:B triplet"
-#~ msgstr "a R जी"
-#, fuzzy
-#~ msgid "Border not yet implemented for LatLong locations: border not drawn."
-#~ msgstr "किनारा नहीं के लिए नहीं."
-#, fuzzy
-#~ msgid "name for new raster map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Output GRASS image file"
-#~ msgstr "छवि."
-#, fuzzy
-#~ msgid "Resulting output grid3D volume"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "name for new vector map (omit for display to stdout)"
-#~ msgstr "के लिए के लिए"
-#, fuzzy
-#~ msgid "Input vector map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "%s: ERROR can't open tempfile"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "<%s> raster map not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Cannot find vector map [%s]"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "%s - can't open raster map"
-#~ msgstr ""
-#~ "#-#-#-#-#  grassmods_hi.po (grassmods_hi)  #-#-#-#-#\n"
-#~ "त्रुटि\n"
-#, fuzzy
-#~ msgid "%s - raster map not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "File name of reference classes"
-#~ msgstr "फ़ाइल का"
-#, fuzzy
-#~ msgid "<%s> - illegal output file name"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "%s: <%s> reference map not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "%s: raster map not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Raster map that represents the elevation, used for the 3D information"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Problem opening input file [%s]"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "Problem opening output file [%s]"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "can't write category file for <%s>"
-#, fuzzy
-#~ msgid "Unable to read row %d in raster map [%s]"
-#~ msgstr "का a"
-#, fuzzy
-#~ msgid "ELEVATION PRODUCTS for mapset [%s] in [%s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "It could not be find input map <%s>"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "It could not be found input map <%s>"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Cannot find input map <%s>"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Input vector map <%s> not found."
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "Category ranges: e.g. 1,3-8,13"
-#~ msgstr "जी 13"
-#, fuzzy
-#~ msgid "Writing attributes ...\n"
-#~ msgstr "छापें"
-#, fuzzy
-#~ msgid "Could not open ascii file <%s>"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Could not open temp file <%s>"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Vector map <%s> not fould"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "SVG output file"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Could not find vector '%s'"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Could not find vector map %s"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Unable to get row %d from <%s>"
-#~ msgstr "का a"
-#, fuzzy
-#~ msgid "No input coordinates provided"
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "Pass #%d (of %d) ... "
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Keep existing color table"
-#~ msgstr "रखें"
-#, fuzzy
-#~ msgid "Name of the output walkers site file"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Verbose mode."
-#~ msgstr "बड़बोला."
-#, fuzzy
-#~ msgid ""
-#~ "Integer cell type.\n"
-#~ "Writing"
-#~ msgstr "पूर्णांक."
-#, fuzzy
-#~ msgid ""
-#~ "Float cell type.\n"
-#~ "Writing"
-#~ msgstr "फ्लोट."
-#, fuzzy
-#~ msgid ""
-#~ "Double cell type.\n"
-#~ "Writing"
-#~ msgstr "दोगुना."
-#, fuzzy
-#~ msgid "%s in %s - can't read header file"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "%s - unable to create raster map"
-#~ msgstr "का a"
-#, fuzzy
-#~ msgid "%s - unable to create category file"
-#, fuzzy
-#~ msgid "verbose mode"
-#~ msgstr "बड़बोला"
-#, fuzzy
-#~ msgid "Vector map with points for which to modify the attribute table"
-#, fuzzy
-#~ msgid "Layer of the vector for which to modify the attribute table"
-#, fuzzy
-#~ msgid "Path to the input file"
-#~ msgstr "का फ़िल्टर"
-#, fuzzy
-#~ msgid "Path to an output file"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of existing raster map to be displayed"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Database name:"
-#~ msgstr "डाटाबेस का नामः"
-#, fuzzy
-#~ msgid "ASCII file to be converted to binary vector map, if not given (or \"-\") reads from standard input"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "could not find input map <%s>"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "unable to open raster map [%s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "cannot get layer info for vector map"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "cannot open database %s by driver %s"
-#~ msgstr "स्रोत"
-#, fuzzy
-#~ msgid "column type not supported"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "cannot create table: %s"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "cannot grant privileges on table %s"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Error while reading cell map."
-#, fuzzy
-#~ msgid "Error while writing new cell map."
-#, fuzzy
-#~ msgid "Error in opening output file <%s>"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Unable to find input cell map <%s>"
-#, fuzzy
-#~ msgid "Error in opening input file <%s>"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Unable to open cell man <%s> for input.\n"
-#, fuzzy
-#~ msgid "Unable to open cell map <%s> for output.\n"
-#, fuzzy
-#~ msgid "Cannot find map %s"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Cannot open map %s"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Name of predefined rules file"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "R:G:B value(s) out of range [0..255]: %d:%d:%d"
-#~ msgstr "R जी का n"
-#, fuzzy
-#~ msgid "R G B value(s) out of range [0..255]: %d %d %d"
-#, fuzzy
-#~ msgid "no such value"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "%s:line %d:%s"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "bad color specification"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "%s - unknown color"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Valid colors are:\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Unable to find base map <%s>"
-#, fuzzy
-#~ msgid "%s: reading category file for %s"
-#, fuzzy
-#~ msgid "%s: unable to open raster map [%s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "%s: unable to create raster map [%s]"
-#~ msgstr "का a"
-#, fuzzy
-#~ msgid "Unable to open database %s with driver %s"
-#~ msgstr "स्रोत"
-#, fuzzy
-#~ msgid "%s: Unable to read raster map [%s]"
-#~ msgstr "का a"
-#, fuzzy
-#~ msgid "%s: unable to open raster map <%s>"
-#, fuzzy
-#~ msgid "%s: Failed to read raster row %d"
-#~ msgstr "i n"
-#, fuzzy
-#~ msgid "Unable to read cats table for %s"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Could not open raster <%s>"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Screen coordinates to place the legend (as percentage)"
-#~ msgstr "स्क्रीन"
-#, fuzzy
-#~ msgid "Font name (not supported interactively, see also -l flag) or path to TrueType font (including file name)"
-#~ msgstr "फ़ॉन्ट नहीं"
-#, fuzzy
-#~ msgid "%s: o_open_file: raster map %s not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "%s: o_open_file: could not open raster map %s in %s"
-#, fuzzy
-#~ msgid "No record for category for [%d]"
-#, fuzzy
-#~ msgid "Error reading ASCII file <%s>"
-#, fuzzy
-#~ msgid "Error reading categories: <%s>"
-#, fuzzy
-#~ msgid "category [%d]"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Could not find input vector '%s'"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Failed opening output vector map '%s'"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Do not create attribute table."
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "Could not find input %s\n"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Error reading ascii file: [%s]"
-#, fuzzy
-#~ msgid "Allows the user to interactively query a vector map layer at user-selected locations within the current geographic region"
-#~ msgstr "a पर."
-#, fuzzy
-#~ msgid "| Tool                            | Threshold     |"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "| Prune                           |  "
-#~ msgstr "n n"
-#, fuzzy
-#~ msgid "%s: <%s> vector map not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Vector <%s> could not be open"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Raster <%s> could not be open."
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Interpolation()"
-#~ msgstr "पद्धति"
-#, fuzzy
-#~ msgid "Interpolation: Setting regions and boxes"
-#~ msgstr "पद्धति"
-#, fuzzy
-#~ msgid "Interpolation: nsply = %d"
-#~ msgstr "पद्धति"
-#, fuzzy
-#~ msgid "Interpolation: (%d,%d): Bilinear interpolation..."
-#, fuzzy
-#~ msgid "Interpolation: (%d,%d): Bicubic interpolation..."
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "%s: Dropping <s>"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Interpolation was a success!"
-#~ msgstr "पद्धति"
-#, fuzzy
-#~ msgid "CrossCorrelation: %d points read in region. "
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "CrossCorrelation: It shouldn't take too long."
-#~ msgstr "सभी"
-#, fuzzy
-#~ msgid "%s -- illegal output file name"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Sorry, with method '%s' you have to define an output map."
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Calculation time"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Finished.\n"
-#~ msgstr "पूर्ण n"
-#, fuzzy
-#~ msgid "%s - can't read raster cellhd"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "error reading cell data"
-#, fuzzy
-#~ msgid "Done!"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "No line found."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Nothing Found."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Do not build topology."
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Could not open ascii file [%s]"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "%s: Cannot open dxf file"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Conversion of [%s] to vector map ..."
-#~ msgstr "a a."
-#, fuzzy
-#~ msgid "Finished"
-#, fuzzy
-#~ msgid "Name of output 3d raster map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Where %s is one of:\n"
-#~ msgstr "है एक का n"
-#, fuzzy
-#~ msgid "ERROR: <%s> not found\n"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "ERROR: <%s> illegal name\n"
-#~ msgstr "है"
-#, fuzzy
-#~ msgid "Cannot open toolbox: %s"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Cannot open toolbox."
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Could not find input map <%s>\n"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "'%s' has finished the transformation of the vectors.\n"
-#~ msgstr "पूर्ण का n"
-#, fuzzy
-#~ msgid ""
-#~ "                          CHECK MAP RESIDUALS\n"
-#~ "\n"
-#~ msgstr "n n"
-#, fuzzy
-#~ msgid "                Current Map                  New Map\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid " POINT      X coord    Y coord  |        X coord   Y coord    |      residuals\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "  Residual mean average   : %f\n"
-#~ msgstr "f n"
-#, fuzzy
-#~ msgid "Vector map(s) -- source for composite"
-#~ msgstr "स्रोत के लिए"
-#, fuzzy
-#~ msgid "Append files to existing file"
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Vector map '%s' not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Quiet operation"
-#~ msgstr "शांत"
-#, fuzzy
-#~ msgid "Display Reference Information"
-#~ msgstr "जानकारी"
-#, fuzzy
-#~ msgid "%s\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "output layer name"
-#~ msgstr "ढाल फ़ाइलनाम "
-#, fuzzy
-#~ msgid ""
-#~ "\a\n"
-#~ "** The following raster maps in subgroup [%s] do not exist."
-#~ msgstr "n नहीं."
-#, fuzzy
-#~ msgid "The subgroup must have at least 2 files to run %s."
-#~ msgstr "पर."
-#, fuzzy
-#~ msgid "Did not find input cell map."
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "Warning: illegal group name <%s>."
-#~ msgstr "चेतावनी समूह."
-#, fuzzy
-#~ msgid "Warning: illegal output file name <%s>."
-#, fuzzy
-#~ msgid "An output cell map name is required."
-#~ msgstr "है."
-#, fuzzy
-#~ msgid "The output cell map name can not be longer than 12 characters."
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "L: from  M: to R: quit\n"
-#~ msgstr "R n"
-#, fuzzy
-#~ msgid "g3d_to_raster: Writing %i raster maps with rows %i cols."
-#~ msgstr "i i."
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Done\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Writing VTK VoxelData\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Open vector 3d raster map %s"
-#~ msgstr "खोलें"
-#, fuzzy
-#~ msgid "Open 3d raster map %s"
-#~ msgstr "खोलें"
-#, fuzzy
-#~ msgid ""
-#~ "OGR datasource name.\n"
-#~ "\t\tESRI Shapefile: directory containing shapefiles\n"
-#~ "\t\tMapInfo File: directory containing mapinfo files"
-#, fuzzy
-#~ msgid "Name of vector output file"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Vector import complete"
-#~ msgstr "सदिश"
-#, fuzzy
-#~ msgid "ERROR: A line needs at least 2 points"
-#~ msgstr "पर."
-#, fuzzy
-#~ msgid "ERROR: An area needs at least 3 points"
-#~ msgstr "पर."
-#, fuzzy
-#~ msgid "Unable to create raster map for [%s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "raster_to_g3d: Writing %i raster maps with rows %i cols."
-#~ msgstr "i i."
-#, fuzzy
-#~ msgid "Writing g3d slice %i\n"
-#~ msgstr "i n"
-#, fuzzy
-#~ msgid "error opening 3d raster map"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "Done\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Name for the resulting raster map"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Open Raster file %s in Mapset %s"
-#~ msgstr "खोलें n"
-#, fuzzy
-#~ msgid "elev_raster_to_g3d: Writing 3D raster map with depths %i rows %i cols %i and count %i."
-#~ msgstr "i i."
-#, fuzzy
-#~ msgid "Open 3d raster map %s\n"
-#~ msgstr "खोलें"
-#, fuzzy
-#~ msgid "Open elev raster map %s\n"
-#~ msgstr "डाटाटाइप."
-#, fuzzy
-#~ msgid "Could not open map %s\n"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Either -i flag and/or profile parameter must be used."
-#~ msgstr "i"
-#, fuzzy
-#~ msgid "Region size is lower than minreg, nothing displayed.\n"
-#~ msgstr "आकार  है कुछ नहीं n"
-#, fuzzy
-#~ msgid "Region size is greater than maxreg, nothing displayed.\n"
-#, fuzzy
-#~ msgid "Do not rebuild and store the topology at the end"
-#~ msgstr "नहीं पर"
-#, fuzzy
-#~ msgid "QGIS vector output"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Makes 3D trees from input point vector map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Diameter of the tree crown in mapunits"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "Height of tree trunk"
-#~ msgstr "ऊंचाई मीटर्स"
-#, fuzzy
-#~ msgid "Name of the column with tree crown width"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Horizontal variability in map units"
-#~ msgstr "का बिन्दु"
-#, fuzzy
-#~ msgid "Cannot select attributes for point #%d"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Calculate statistics for vector points within each raster cell of the current region"
-#~ msgstr "का a के लिए सभी का."
-#, fuzzy
-#~ msgid "Name of output vector points map (if not specified, the program writes to standard output)"
-#~ msgstr "का के लिए संपादन (_E)"
-#, fuzzy
-#~ msgid "Report only selected statistics"
-#~ msgstr "का वस्तु"
-#, fuzzy
-#~ msgid "Quiet mode"
-#~ msgstr "शांत"
-#, fuzzy
-#~ msgid "Print the input data extent in shell script style"
-#~ msgstr "छापें"
-#, fuzzy
-#~ msgid "done."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "name for new binary vector map (omit for display to stdout)"
-#, fuzzy
-#~ msgid "Mark or search ground control points on image to be rectified."
-#~ msgstr "चिह्नित चालू छवि."
-#, fuzzy
-#~ msgid "Enter imagery group to be registered"
-#~ msgstr "समूह"
-#, fuzzy
-#~ msgid "Maximum distance"
-#~ msgstr "आइसोसरफेस"
-#, fuzzy
-#~ msgid "%s Quit\n"
-#~ msgstr "बाहर जाएँ n"
-#, fuzzy
-#~ msgid "Draw geographic grid"
-#~ msgstr "निकालें"
-#, fuzzy
-#~ msgid "3 raster maps (r,g,b) which are used to create rgb values [redmap,greenmap,bluemap]"
-#~ msgstr "जी"
-#, fuzzy
-#~ msgid "%s[%d]: No raster map specified."
-#~ msgstr "के लिए."
-#, fuzzy
-#~ msgid "GRASS module to create a fractal surface of a given fractal dimension. Uses spectral synthesis method. Can create intermediate layers showing the build up of different spectral coefficients (see Saupe, pp.106-107 for an example of this). Use this module to generate naturally looking synthetical elevation models (DEM)."
-#~ msgstr "मॉडयूल a का a पद्धति का के लिए का मॉडयूल."
-#, fuzzy
-#~ msgid "Wrong rgb map values! Values should in between 0 and 255!\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Resolution of raster and raster3d maps should be equal!"
-#~ msgstr "का के बराबर!"
-#, fuzzy
-#~ msgid "The resolution of raster and raster3d maps should be equal!"
-#, fuzzy
-#~ msgid "The map E and N grid coordinates of a starting point"
-#~ msgstr "का a बिन्दु"
-#, fuzzy
-#~ msgid "Wrong RGB maps. RGB output not added!"
-#~ msgstr "नहीं!"
-#, fuzzy
-#~ msgid "Done.\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Zooming finished.\n"
-#, fuzzy
-#~ msgid "name of resulting vector map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "\"Extrudes\" flat vector object to 3D with defined height."
-#~ msgstr "वस्तु ऊंचाई."
-#, fuzzy
-#~ msgid "Column from attribute table with object height attribute"
-#~ msgstr "वस्तु ऊंचाई"
-#, fuzzy
-#~ msgid "You first need to run v.build on vector map <%s>"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "height of vector object"
-#~ msgstr "ऊंचाई का वस्तु"
-#, fuzzy
-#~ msgid "Either a height column or a fixed height value have to be specified"
-#~ msgstr "a ऊंचाई a स्थिर ऊंचाई"
-#, fuzzy
-#~ msgid "String column cannot be used for object heights"
-#~ msgstr "के लिए वस्तु"
-#, fuzzy
-#~ msgid "DateTime column cannot be used for object heights"
-#, fuzzy
-#~ msgid "Feature type. Possible combinations of more types: point,centroid or line,boundary."
-#~ msgstr "विशेषता का अधिक बिन्दु."
-#, fuzzy
-#~ msgid "Don't understand: [%s]\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Name of existing input raster map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of existing raster map."
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Name of new raster map."
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Name of the resulting map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of input map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Write an Arc-Info line/polygon coverage in e00 format."
-#~ msgstr "बहुभुज."
-#, fuzzy
-#~ msgid "Mapset holding vector map to be exported (Default = current)"
-#~ msgstr "डिफ़ॉल्ट"
-#, fuzzy
-#~ msgid "Prompt user for threshold"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid ""
-#~ "Set line types to:   \n"
-#~ "             source        same as in binary vector map\n"
-#~ "             line          lines\n"
-#~ "             area          area edges\n"
-#~ "             point         points (sites)\n"
-#~ msgstr ""
-#~ "सेट\n"
-#~ " स्रोत\n"
-#~ "\n"
-#~ "\n"
-#~ " बिन्दु n"
-#, fuzzy
-#~ msgid "Output file is ASCII map"
-#~ msgstr "है"
-#, fuzzy
-#~ msgid "Copy attributes and category files"
-#~ msgstr "नक़ल"
-#, fuzzy
-#~ msgid "Converts point data in a binary GRASS vector map layer into a GRASS site_lists file."
-#~ msgstr "बिन्दु a a."
-#, fuzzy
-#~ msgid "Use Category NUMERIC data instead of attribute"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Use Category TEXT data instead of attribute"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Test routine for developing MIF import."
-#, fuzzy
-#~ msgid "Debugging level : 0 (silent) - 3 (verbose)"
-#~ msgstr "डिबगिंग"
-#, fuzzy
-#~ msgid "Name of file where to log operations"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Snap distance in ground units (Default = 10^-10)"
-#, fuzzy
-#~ msgid "Set initial scale [1:2400]"
-#~ msgstr "सेट स्केल"
-#, fuzzy
-#~ msgid "Name of attribute to use as category"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Allow overwrite of existing vector map with the same name"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Force writing  polygon coverage as a line coverage"
-#~ msgstr "बहुभुज a"
-#, fuzzy
-#~ msgid "Create unique value for parts of compound object"
-#~ msgstr "के लिए का वस्तु"
-#, fuzzy
-#~ msgid "List fields of DBF file"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "new categories table title"
-#~ msgstr "शीर्षक"
-#, fuzzy
-#~ msgid "Build topology info (default) OR Edit categories"
-#~ msgstr "संपादन"
-#, fuzzy
-#~ msgid "Prompt user for threshold         (Valid only with Build option)"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Set map region from data          (Valid only with Build option)"
-#~ msgstr "सेट"
-#, fuzzy
-#~ msgid "Suppress drawing of text outlines"
-#~ msgstr "का पाठ"
-#, fuzzy
-#~ msgid "Prefix for dig or dig_ascii and dig_att output files"
-#~ msgstr "उपसर्ग के लिए"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Where lines and labels are one or more of:\n"
-#~ "\n"
-#~ msgstr "n एक अधिक का n n"
-#, fuzzy
-#~ msgid ""
-#~ "    layername1[,layername2,layername3,...]\n"
-#~ "\n"
-#~ msgstr "n n"
-#, fuzzy
-#~ msgid ""
-#~ "      and/or   \n"
-#~ "\n"
-#~ msgstr "n n"
-#, fuzzy
-#~ msgid "    in_layername1:out_layername1[,inlayername2:outlayername2,.....]\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "angle of rotation"
-#~ msgstr "कोण का"
-#, fuzzy
-#~ msgid "provide attributes of type: const,rows,cols"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectacres)"
-#~ msgstr "f a h"
-#, fuzzy
-#~ msgid "Prints information about a binary GRASS vector map layer."
-#~ msgstr "a."
-#, fuzzy
-#~ msgid "input vector map for ARC/INFO conversion"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "prefix for ARC/INFO output filenames"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "field separator"
-#~ msgstr "फील्ड"
-#, fuzzy
-#~ msgid "Interpolation and topographic analysis from given contour data in vector format to GRASS floating point raster format using regularized spline with tension."
-#~ msgstr "बिन्दु."
-#, fuzzy
-#~ msgid "Version: GRASS5.0 beta,  update: Novemebr 1999"
-#~ msgstr "बीटा"
-#, fuzzy
-#~ msgid "Authors: original version -  H.Mitasova, L.Mitas"
-#~ msgstr "असली संस्करण एच"
-#, fuzzy
-#~ msgid "Methods used in this program are described in the following papers:"
-#~ msgstr "पद्धति प्रोग्राम:"
-#, fuzzy
-#~ msgid "Mitasova, H., and  Mitas, L., 1993,"
-#~ msgstr "एच"
-#, fuzzy
-#~ msgid "Mitasova, H., and Hofierka, L., 1993"
-#~ msgstr "एच"
-#, fuzzy
-#~ msgid "Mitasova, H., Mitas, L., Brown, W.M., Gerdes, D.P., Kosinovsky, I.,"
-#~ msgstr "एच प"
-#, fuzzy
-#~ msgid "Baker, T., 1995, Modeling spatially and temporally"
-#~ msgstr "T"
-#, fuzzy
-#~ msgid "distributed phenomena: New methods and tools for GRASS GIS."
-#, fuzzy
-#~ msgid "International Journal of Geographic Information Systems,V(9), No(4)."
-#~ msgstr "का जियोग्राफिक जानकारी V नहीं."
-#, fuzzy
-#~ msgid "(special issue on Integration of GIS and Environmental Modeling)"
-#~ msgstr "चालू का"
-#, fuzzy
-#~ msgid "The postscript versions of these papers are available via Internet at"
-#~ msgstr "का पर"
-#, fuzzy
-#~ msgid "Please cite these references in publications where the results of this"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Output z-file (elevation)"
-#~ msgstr "ज़ेड"
-#, fuzzy
-#~ msgid "Mean curvature"
-#~ msgstr "औसत"
-#, fuzzy
-#~ msgid "Min number of points for interpolation(>segmax)"
-#~ msgstr "संख्या का के लिए"
-#, fuzzy
-#~ msgid "path to GRASS database of input location"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Automatically run \"v.support\" on newly created vector map."
-#~ msgstr "चालू."
-#, fuzzy
-#~ msgid "Type of object to extract (area, line or both)"
-#, fuzzy
-#~ msgid "Polygon Cookie Cutter  (Boolean AND Overlay)."
-#~ msgstr "बूलिये ओवरले."
-#, fuzzy
-#~ msgid "ARC/INFO label-text file"
-#~ msgstr "पाठ"
-#, fuzzy
-#~ msgid "resultant Vector output file"
-#~ msgstr "सदिश"
-#, fuzzy
-#~ msgid "ID Number column in label-text file"
-#~ msgstr "पाठ"
-#, fuzzy
-#~ msgid "GRASS category column in label-text file"
-#~ msgstr "पाठ"
-#, fuzzy
-#~ msgid "GRASS attribute column in label-text file"
-#~ msgstr "पाठ"
-#, fuzzy
-#~ msgid "reports attribute, label, and other information about a sites file"
-#~ msgstr "अन्य a"
-#, fuzzy
-#~ msgid "Name of sites file."
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Only count sites in current window for min/max."
-#, fuzzy
-#~ msgid "Show quartiles for decimal attributes"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Name of input sites map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Surface interpolation from sites data by Inverse Distance Weighted algorithm."
-#~ msgstr "सतह."
-#, fuzzy
-#~ msgid "Name of sites file to filter"
-#, fuzzy
-#~ msgid "Converts a GRASS site list file into an ASCII listing of site locations and their descriptions."
-#~ msgstr "a का."
-#, fuzzy
-#~ msgid "Name of input site list"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Number of cells to surround site cell"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Attribute field type to use for operation"
-#~ msgstr "फील्ड के लिए"
-#, fuzzy
-#~ msgid "Attribute field number to use for operation"
-#~ msgstr "फील्ड संख्या के लिए"
-#, fuzzy
-#~ msgid "Create a single-valued (0/1) raster map"
-#~ msgstr "a एकल"
-#, fuzzy
-#~ msgid "Index of attribute type (ignored for cat)"
-#~ msgstr "का के लिए"
-#, fuzzy
-#~ msgid "Output in g.gnuplot format (overrides -z and writes to stdout)"
-#~ msgstr "जी ज़ेड"
-#, fuzzy
-#~ msgid "Convert an ASCII listing of site locations into a GRASS site list file."
-#~ msgstr "का a."
-#, fuzzy
-#~ msgid "number of dimensions (default=2)"
-#, fuzzy
-#~ msgid "input field separator"
-#~ msgstr "फील्ड"
-#, fuzzy
-#~ msgid "Allows the user to re-project a sites file from one location to the current location (no datum transformation yet)."
-#~ msgstr "a एक."
-#, fuzzy
-#~ msgid "location of input sites list"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "mapset of input sites list"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Don't prompt for Map header information"
-#~ msgstr "संकेत के लिए"
-#, fuzzy
-#~ msgid "Field type (\"string\", \"dim\", or \"decimal\") and index to use for category value (uses \"cat\" by default)"
-#, fuzzy
-#~ msgid "Allows the user to interactively adjust the settings (zoom  and  pan) of the current geographic region using a pointing device such as a mouse."
-#~ msgstr "पैन का a a."
-#, fuzzy
-#~ msgid "Displays text labels formatted for use with GRASS paint (p.labels, p.map) output to the active frame on the graphics monitor."
-#~ msgstr "पाठ के लिए चालू."
-#, fuzzy
-#~ msgid "Displays points, as icons, at user-defined locations in the active display frame on the graphics monitor."
-#~ msgstr "प्रतीक पर चालू."
-#, fuzzy
-#~ msgid "Name of existing sites file"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Identify just one site"
-#~ msgstr "पहचानें एक"
-#, fuzzy
-#~ msgid "one mouse click only"
-#~ msgstr "एक"
-#, fuzzy
-#~ msgid "Name of a spheroid (for lat/lon coordinate conversion)"
-#~ msgstr "का a के लिए"
-#, fuzzy
-#~ msgid "Displays three-dimensional images based on raster map layers"
-#~ msgstr "छवियाँ चालू"
-#, fuzzy
-#~ msgid "coordinates of center of view"
-#~ msgstr "का का"
-#, fuzzy
-#~ msgid "Frequency of vector lines in output"
-#~ msgstr "आवृत्ति का"
-#, fuzzy
-#~ msgid "Field of view"
-#~ msgstr "फील्ड का"
-#, fuzzy
-#~ msgid "Color of bounding box"
-#~ msgstr "का बक्सा"
-#, fuzzy
-#~ msgid "Displays  a  legend  for a raster map layer in the active frame on the graphics monitor."
-#~ msgstr "a के लिए a चालू."
-#, fuzzy
-#~ msgid "Use a subset of the map range for the legend"
-#~ msgstr "a का के लिए"
-#, fuzzy
-#~ msgid "Draw labelled vector lines to the current display device"
-#, fuzzy
-#~ msgid "Name of existing vector map to draw"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Draw all lines using either a GRASS standard color or R:G:B triplet (separated by colons)"
-#~ msgstr "निकालें सभी a R जी"
-#, fuzzy
-#~ msgid "Only draw areas with a matching category number (for constant color option only)"
-#~ msgstr "a संख्या के लिए"
-#, fuzzy
-#~ msgid "Draw lines according to a legend file (<cat> <R> <G> <B>)"
-#~ msgstr "निकालें a<cat><R><G><B>"
-#, fuzzy
-#~ msgid "Line color -- a GRASS named color, an R:G:B triplet, or \"none\""
-#~ msgstr "a R जी"
-#, fuzzy
-#~ msgid "Limit to matching category number(s) (constant color option only)"
-#~ msgstr "संख्या"
-#, fuzzy
-#~ msgid "Use a legend file: (<cat> <R> <G> <B> [<R> <G> <B>])"
-#~ msgstr "a<cat><R><G><B><R><G><B>"
-#, fuzzy
-#~ msgid "Displays site markers in the active display frame on the graphics monitor."
-#~ msgstr "चालू."
-#, fuzzy
-#~ msgid "Size, in pixels, in which the icon is to be drawn"
-#~ msgstr "पिक्सेल्स है"
-#, fuzzy
-#~ msgid "Specify the type of the icon"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Color used for the background, or \"none\""
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "the screen coordinates for top-left corner of label"
-#~ msgstr "के लिए शीर्ष बायाँ का"
-#, fuzzy
-#~ msgid "Interactively label sites using a string or double attribute value or the category value on the current graphics monitor."
-#~ msgstr "a चालू."
-#, fuzzy
-#~ msgid "Name of sites file"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Type of attribute to use for labels"
-#, fuzzy
-#~ msgid "Index of attribute. Ignored when attr=cat or attr=coords."
-#~ msgstr "का उपेक्षित."
-#, fuzzy
-#~ msgid "Relative horizontal position 'left|center|right'"
-#~ msgstr "बायाँ दायाँ"
-#, fuzzy
-#~ msgid "Relative vertical position 'top|center|bottom'"
-#~ msgstr "शीर्ष तल"
-#, fuzzy
-#~ msgid "Size of text (pixels)"
-#~ msgstr "का पाठ पिक्सेल्स"
-#, fuzzy
-#~ msgid "Vector category number(s) to be displayed"
-#~ msgstr "सदिश संख्या"
-#, fuzzy
-#~ msgid "Draws text in the active display frame on the graphics monitor."
-#~ msgstr "पाठ चालू."
-#, fuzzy
-#~ msgid "Height of letters in percent of available frame height"
-#~ msgstr "ऊंचाई का का ऊंचाई"
-#, fuzzy
-#~ msgid "Color desired for drawing text"
-#~ msgstr "के लिए पाठ"
-#, fuzzy
-#~ msgid "The screen line number on which text will begin to be drawn "
-#~ msgstr "संख्या चालू पाठ "
-#, fuzzy
-#~ msgid "Displays point graphics in the active frame on the graphics display monitor."
-#~ msgstr "बिन्दु चालू."
-#, fuzzy
-#~ msgid "Input is a UNIX file name"
-#~ msgstr "है a"
-#, fuzzy
-#~ msgid "Allows the user to establish whether a map will be displayed using its own color table or the fixed color table of the graphics monitor."
-#~ msgstr "a स्थिर का."
-#, fuzzy
-#~ msgid "Creates and modifies icons for use with ps.map."
-#~ msgstr "प्रतीक के लिए."
-#, fuzzy
-#~ msgid "scale of the output map, e.g. 1:25000 (default: 1panel)"
-#~ msgstr "स्केल का जी"
-#, fuzzy
-#~ msgid "number of copies to print"
-#, fuzzy
-#~ msgid "Selects a PostScript device for GRASS hardcopy output."
-#~ msgstr "a के लिए."
-#, fuzzy
-#~ msgid "name of PostScript painter to select"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "list all available PostScript painters"
-#~ msgstr "सभी"
-#, fuzzy
-#~ msgid "print name of currently selected PostScript painter"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "An imagery function that performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
-#~ msgstr "फंक्शन छवि a."
-#, fuzzy
-#~ msgid "Force Swapping (overrides default auto)"
-#~ msgstr "स्वचालित"
-#, fuzzy
-#~ msgid "Use \"Map Coordinates\" for coordinates"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "output prefix of the GRASS raster maps to be created."
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Number of rows to extract."
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Number of columns to extract."
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Output 16-bit image (default 8)"
-#~ msgstr "छवि"
-#, fuzzy
-#~ msgid "Use symbols (instead of graphics)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Create floating-point maps (0.0 - 1.0)."
-#, fuzzy
-#~ msgid "Enable extend memory option: Operation is slow"
-#~ msgstr "विस्तार दें है"
-#, fuzzy
-#~ msgid "Name of an output binary map (use out=- for stdout)"
-#, fuzzy
-#~ msgid "Converts point data in a GRASS raster map layer into a GRASS site_lists file."
-#, fuzzy
-#~ msgid "Output as third dimension rather than cat"
-#~ msgstr "तृतीय"
-#, fuzzy
-#~ msgid "Name of raster map."
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Creates a new binary GRASS vector (v.digit) file by extracting linear features from a thinned raster map."
-#~ msgstr "a a."
-#, fuzzy
-#~ msgid "Creates a raster map layer and site list file containing randomly located sites."
-#~ msgstr "a."
-#, fuzzy
-#~ msgid "Generate sites for category zero also"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Imports a TIFF (8 or 24 bit) raster map into GRASS raster map(s)"
-#~ msgstr "a"
-#, fuzzy
-#~ msgid "Name on TIFF file to input."
-#~ msgstr "चालू."
-#, fuzzy
-#~ msgid "Bayesian expert system development program."
-#~ msgstr "प्रोग्राम."
-#, fuzzy
-#~ msgid "mi(les),me(ters),k(ilometers),a(cres),h(ectacres),c(ell_counts),p(ercent_cover)"
-#~ msgstr "a h कवर"
-#, fuzzy
-#~ msgid "name of an output file to hold the report"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "number of fp subranges to collect stats from"
-#, fuzzy
-#~ msgid "filter out all no data cells"
-#~ msgstr "फ़िल्टर सभी"
-#, fuzzy
-#~ msgid "filter out cells where all maps have no data"
-#, fuzzy
-#~ msgid "report for cats fp ranges (fp maps only)"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Generates an output raster map layer with contiguous areas grown by one cell (pixel)."
-#~ msgstr "एक."
-#, fuzzy
-#~ msgid "re-project a raster map from one location to the current location (no datum transformation yet)"
-#~ msgstr "a एक"
-#, fuzzy
-#~ msgid "interpolation method to use"
-#~ msgstr "पद्धति"
-#, fuzzy
-#~ msgid "resolution of output map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Print grid coordinates (east and north) (requires -1 flag)"
-#~ msgstr "छापें पूर्व उत्तर"
-#, fuzzy
-#~ msgid "output is the interpolation error"
-#~ msgstr "है त्रुटि"
-#, fuzzy
-#~ msgid "format for reporting the slope"
-#, fuzzy
-#~ msgid "type of output aspect and slope maps"
-#~ msgstr "का ढाल"
-#, fuzzy
-#~ msgid "Output E-W slope filename"
-#~ msgstr "प ढाल फ़ाइलनाम "
-#, fuzzy
-#~ msgid "Output N-S slope filename"
-#, fuzzy
-#~ msgid "Output partial derivative dxx filename"
-#~ msgstr "फ़ाइलनाम "
-#, fuzzy
-#~ msgid "Output partial derivative dyy filename"
-#, fuzzy
-#~ msgid "Output partial derivative dxy filename"
-#, fuzzy
-#~ msgid "Name of file for output (use out=- for stdout)"
-#~ msgstr "का के लिए के लिए"
-#, fuzzy
-#~ msgid "Converts raster data referenced using latitude and longitude coordinates to a UTM-referenced map layer in GRASS raster format."
-#~ msgstr "a."
-#, fuzzy
-#~ msgid ""
-#~ "one corner latitude and longitude of the input\n"
-#~ "format: {nw|ne|sw|se},%s,%s"
-#~ msgstr "एक का"
-#, fuzzy
-#~ msgid "resolution of the input (in arc seconds)"
-#~ msgstr "का चाप"
-#, fuzzy
-#~ msgid "Stop points site file"
-#~ msgstr "रूकें"
-#, fuzzy
-#~ msgid "Extracts area edges from a raster map layer and converts data to GRASS vector format."
-#~ msgstr "a."
-#, fuzzy
-#~ msgid "Number of values printed before wrapping a line"
-#~ msgstr "का a"
-#, fuzzy
-#~ msgid "raster map name from which to copy color table"
-#~ msgstr "नक़ल"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Where color type is one of:\n"
-#, fuzzy
-#~ msgid "  aspect    (aspect oriented grey colors)\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "  grey      (linear grey scale)\n"
-#~ msgstr "स्केल n"
-#, fuzzy
-#~ msgid "  grey.eq   (histogram equalized grey scale)\n"
-#, fuzzy
-#~ msgid "  grey.log  (histogram logarithmic transformed grey scale)\n"
-#, fuzzy
-#~ msgid "  byg       (blue through yellow to green colors)\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "  byr       (blue through yellow to red colors)\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "  gyr       (green through yellow to red colors)\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "  rainbow   (rainbow color table)\n"
-#~ msgstr "इंद्रधनुष इंद्रधनुष n"
-#, fuzzy
-#~ msgid "  ramp      (color ramp)\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "  ryg       (red through yellow to green colors)\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "  random    (random color table)\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "  wave      (color wave)\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "  rules     (create new color table by rules)\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "method of object-based statistic"
-#~ msgstr "पद्धति का वस्तु"
-#, fuzzy
-#~ msgid "resultant raster map (not used with 'distribution')"
-#~ msgstr "नहीं वितरण"
-#, fuzzy
-#~ msgid "Northern limit of geographic region"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Eastern limit of geographic region"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Western limit of geographic region"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Extend location extents based on new dataset."
-#~ msgstr "चालू."
-#, fuzzy
-#~ msgid "Maximum magnitude of random grid point offset"
-#, fuzzy
-#~ msgid "Outputs a raster map layer whose category values represent the application of user-specified criteria (rules statements) to other raster map layers' category values."
-#~ msgstr "a किसका का अन्य."
-#, fuzzy
-#~ msgid "Converts a PPM image file to GRASS raster map(s)."
-#~ msgstr "a छवि."
-#, fuzzy
-#~ msgid "Converts Universal Transverse Mercator (UTM) coordinates to geographic (latitude/longitude) coordinates."
-#~ msgstr "यूनिवर्सल."
-#, fuzzy
-#~ msgid "Specified zone is in the southern hemisphere"
-#~ msgstr "है"
-#, fuzzy
-#~ msgid "Input is reversed: north,east"
-#~ msgstr "है उत्तर पूर्व"
-#, fuzzy
-#~ msgid "Do not flag invalid east,north input lines as errors"
-#~ msgstr "नहीं अवैध पूर्व उत्तर"
-#, fuzzy
-#~ msgid "Flag other input lines as errors"
-#~ msgstr "ध्वज अन्य"
-#, fuzzy
-#~ msgid "Output in decimal degrees"
-#~ msgstr "कोण"
-#, fuzzy
-#~ msgid "Converts geographic coordinates to Universal Transverse Mercator (UTM) coordinates."
-#, fuzzy
-#~ msgid "Input is reversed: lat,lon"
-#~ msgstr "है"
-#, fuzzy
-#~ msgid "Do not flag invalid lon,lat input lines as errors"
-#~ msgstr "नहीं अवैध"
-#, fuzzy
-#~ msgid "Rotates elevation data extracted by either m.dted.extract or m.dmaUSGSread."
-#~ msgstr "मी मी."
-#, fuzzy
-#~ msgid "Number of bytes per cell (i.e. per data value)"
-#~ msgstr "का बाइट्स i"
-#, fuzzy
-#~ msgid "Provides a terse description of level 1 and 2 digital terrain elevation data (DTED) files produced and distributed by the Defense Mapping Agency (DMA) on 1/2-inch magnetic tapes."
-#~ msgstr "a का चालू इंच."
-#, fuzzy
-#~ msgid "Name of tape drive device"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Datum shift program. Return geographic coordinates based on a different datum that the one used to obtain the original coordinates. "
-#~ msgstr "प्रोग्राम चालू a एक असली "
-#, fuzzy
-#~ msgid "use block shift transformation (default)"
-#~ msgstr "ब्लॉक"
-#, fuzzy
-#~ msgid "use bursa wolf 3d similarity transformation (not implemented)"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "height above ellipsoid"
-#~ msgstr "ऊंचाई"
-#, fuzzy
-#~ msgid "z shift"
-#~ msgstr "ज़ेड"
-#, fuzzy
-#~ msgid "Converts UTM coordinates falling within the current geographic region to geographic (latitude/longitude) coordinates. "
-#~ msgstr "गिरता "
-#, fuzzy
-#~ msgid "Flips elevation data extracted from systems that retrieve data by rows from south to north."
-#~ msgstr "दक्षिण उत्तर."
-#, fuzzy
-#~ msgid "Number of bytes per cell (ie, per data value)"
-#~ msgstr "का बाइट्स"
-#, fuzzy
-#~ msgid "Finds geographic region information for U.S. Census Bureau TIGER input data."
-#, fuzzy
-#~ msgid "Filename for raw tiger data (type 1)"
-#~ msgstr "के लिए कच्चा"
-#, fuzzy
-#~ msgid "UTM zone for this county"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Provides a terse description of USGS Digital Elevation Model (DEM) data files stored on 1/2-inch magnetic tape."
-#, fuzzy
-#~ msgid "Blocksize of tape data"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Extracts digital terrain elevation data (DTED - levels 1 and 2) produced and supplied by the Defense Mapping Agency (DMA) on 1/2-inch magnetic tapes."
-#~ msgstr "चालू इंच."
-#, fuzzy
-#~ msgid "Name of header output file"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "North latitude of region to extract (format: %s)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "South latitude of region to extract (format: %s)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "East longitude of region to extract (format: %s)"
-#~ msgstr "पूर्व का"
-#, fuzzy
-#~ msgid "West longitude of region to extract (format: %s)"
-#~ msgstr "पश्चिम का"
-#, fuzzy
-#~ msgid "Read the entire tape in all cases"
-#~ msgstr "सभी"
-#, fuzzy
-#~ msgid "Extracts USGS Digital Elevation Model (DEM) data from 1/2-inch magnetic tape."
-#~ msgstr "इंच."
-#, fuzzy
-#~ msgid "First file to look at"
-#~ msgstr "पर"
-#, fuzzy
-#~ msgid "Last file to look at"
-#~ msgstr "पर"
-#, fuzzy
-#~ msgid "Selects a device (printer) for GRASS hardcopy output."
-#, fuzzy
-#~ msgid "list all available painters"
-#~ msgstr "सभी"
-#, fuzzy
-#~ msgid "print name of currently selected painter"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Align region to resolution [default = align to bounds]"
-#~ msgstr "पंक्तिबद्ध करें"
-#, fuzzy
-#~ msgid "Set region to match this sites map"
-#~ msgstr "सेट जोड़ा"
-#, fuzzy
-#~ msgid "Value for the eastern edge "
-#~ msgstr "के लिए "
-#, fuzzy
-#~ msgid "Value for the western edge "
-#, fuzzy
-#~ msgid "Grid resolution (both north-south and east-west)"
-#~ msgstr "उत्तर दक्षिण पूर्व पश्चिम"
-#, fuzzy
-#~ msgid "  vect   (binary vector maps)\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "  icon   (paint icon files)\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "  labels (paint label files)\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "  sites  (site list files)\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "  region (region definition files)\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "  group  (imagery group files)\n"
-#~ msgstr "समूह समूह n"
-#, fuzzy
-#~ msgid "  3dview (3D view parameters)\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Print all, inclusive range"
-#~ msgstr "छापें सभी"
-#, fuzzy
-#~ msgid "Name of the water depth raster map [m]"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of the x-derivatives raster map [m/m]"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of the y-derivatives raster map [m/m]"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of the detachment capacity coefficient raster map [s/m]"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of the transport capacity coefficient raster map [s]"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of the critical shear stress raster map [Pa]"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of the Mannings n raster map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of the Mannings n value"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Output transport capacity raster map [kg/ms]"
-#~ msgstr "ढाल"
-#, fuzzy
-#~ msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
-#, fuzzy
-#~ msgid "Output sediment concentration raster map [particle/m3]"
-#~ msgstr "ढाल"
-#, fuzzy
-#~ msgid "Output sediment flux raster map [kg/ms]"
-#~ msgstr "ढाल"
-#, fuzzy
-#~ msgid "Output erosion-deposition raster map [kg/m2s]"
-#, fuzzy
-#~ msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of the runoff infiltration rate raster map [mm/hr]"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of the flow controls raster map (permeability ratio 0-1)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Output water discharge raster map [m3/s]"
-#~ msgstr "ढाल"
-#, fuzzy
-#~ msgid "Output simulation error raster map [m]"
-#~ msgstr "ढाल"
-#, fuzzy
-#~ msgid "Watershed basin analysis program."
-#, fuzzy
-#~ msgid "Input map: amount of overland flow per cell"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Input map: terrain blocking overland surface flow, for USLE"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Output map: number of cells that drain through each cell"
-#, fuzzy
-#~ msgid "Output map: unique label for each watershed basin"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Output map: each half-basin is given a unique value"
-#~ msgstr "है a"
-#, fuzzy
-#~ msgid "Output map: useful for visual display of results"
-#, fuzzy
-#~ msgid "Output map: slope length and steepness (LS) factor for USLE"
-#~ msgstr "ढाल के लिए"
-#, fuzzy
-#~ msgid "Output map: slope steepness (S) factor for USLE"
-#, fuzzy
-#~ msgid "Input value: minimum size of exterior watershed basin"
-#~ msgstr "आकार  का"
-#, fuzzy
-#~ msgid "Input value: maximum length of surface flow, for USLE"
-#, fuzzy
-#~ msgid "Output raster map of problem areas"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Range to be exported: %f - %f"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "(i)   Basin map created by r.water.outlet (MASK)"
-#~ msgstr "i"
-#, fuzzy
-#~ msgid "(o)   Direction map for depressionless elevation map"
-#~ msgstr "i आयताकार"
-#, fuzzy
-#~ msgid "(i)   Number of topographic index classes"
-#~ msgstr "i का"
-#, fuzzy
-#~ msgid "(o/i) Topographic index statistics file"
-#~ msgstr "i"
-#, fuzzy
-#~ msgid "(i)   TOPMODEL Parameters file"
-#~ msgstr "i"
-#, fuzzy
-#~ msgid "(i)   Rainfall and potential evapotranspiration data file"
-#~ msgstr "i"
-#, fuzzy
-#~ msgid "Name of elevation raster map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Percent done:"
-#~ msgstr "पूर्ण."
-#, fuzzy
-#~ msgid "Creates a new map layer whose category values are based upon a reclassification of the categories in an existing raster map layer."
-#~ msgstr "a किसका का."
-#, fuzzy
-#~ msgid "Converts a raster map into a vector map layer."
-#~ msgstr "a a."
-#, fuzzy
-#~ msgid "The map E grid coordinates"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Could not read east bufferzone size. Aborting."
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Could not read west bufferzone size. Aborting."
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Could not read north bufferzone size. Aborting."
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Calculating map %01d of %01d (angle %lf, raster map <%s>)"
-#, fuzzy
-#~ msgid "Output flowpath length raster map"
-#~ msgstr "ढाल"
-#, fuzzy
-#~ msgid "Output flowline density raster map"
-#~ msgstr "घनत्व"
-#, fuzzy
-#~ msgid "3-D lengths instead of 2-D"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Lat/Long location is not supported"
-#~ msgstr "है नहीं"
-#, fuzzy
-#~ msgid "Name of file with sql statement"
-#, fuzzy
-#~ msgid "Raster map to use as MASK"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "raster, terrain analysis"
-#~ msgstr "वस्तु."
-#, fuzzy
-#~ msgid "Color for graduated lines or point/area outlines (grass named color or R:G:B triplet). Set color scheme to single color."
-#~ msgstr "a R जी"
-#, fuzzy
-#~ msgid "Icon to remove"
-#~ msgstr "चालू"
-#, fuzzy
-#~ msgid "raster, imagery, fusion"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "raster input maps"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "mi(les),me(ters),k(ilometers),a(cres),h(ectares),c(ell_counts),p(ercent_cover)"
-#, fuzzy
-#~ msgid "Cannot open database <%s> by driver <%s>"
-#~ msgstr "स्रोत"
-#, fuzzy
-#~ msgid "Can't make random color table for floating point map"
-#~ msgstr "है के लिए बिन्दु!"
-#, fuzzy
-#~ msgid "Can't make grey.eq color table for floating point map"
-#, fuzzy
-#~ msgid "%s - unknown color request"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Could not read range file"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Reading data: "
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Run verbosly"
-#~ msgstr "सभी"
-#, fuzzy
-#~ msgid "%d boundaries converted to lines"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "CrossCorrelation: %d records selected from table"
-#~ msgstr "सभी"
-#, fuzzy
-#~ msgid "CrossCorrelation: Mean = %.5lf\n"
-#~ msgstr "फील्ड"
-#, fuzzy
-#~ msgid "CrossCorrelation: lambda_i = %.3f\n"
-#~ msgstr "फील्ड"
-#, fuzzy
-#~ msgid "From type"
-#~ msgstr "अज्ञात क़िस्म"
-#, fuzzy
-#~ msgid "To layer"
-#, fuzzy
-#~ msgid "The column must be type integer or string"
-#~ msgstr "ज़ेड"
-#, fuzzy
-#~ msgid "Cannot open dig_cats file."
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Cannot insert into table: %s"
-#~ msgstr "i n"
-#, fuzzy
-#~ msgid "Removed vertices: %5d"
-#, fuzzy
-#~ msgid ""
-#~ "Node[%d]: %d  \n"
-#~ "Number of lines: %d  \n"
-#~ "Coordinates: %.6f, %.6f, %.6f\n"
-#~ msgstr "का n"
-#, fuzzy
-#~ msgid ""
-#~ "Line: %5d  \n"
-#~ "Angle: %.8f\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid ""
-#~ "Area: %d  \n"
-#~ "Number of isles: %d\n"
-#~ msgstr "का n"
-#, fuzzy
-#~ msgid "Processing ainput lines ..."
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Processing ainput areas ..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Elevation raster map <%s> does not cover the entire area of the input vector map <%s>. "
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Reading the raster maps..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Rotating data arrays..."
-#~ msgstr "नक़ल"
-#, fuzzy
-#~ msgid "Unable to open output file."
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Transform successful."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Class transition statistics."
-#~ msgstr "वस्तु."
-#, fuzzy
-#~ msgid "Subgroup [%s] in group [%s] contains no files."
-#~ msgstr "समूह."
-#, fuzzy
-#~ msgid "Writing [%s] ..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Calculating eigenvalues and eigenvectors..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Transposing eigen matrix..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Calculating class mean ..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Reading the raster map..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Subgroup [%s] doesn't have any files"
-#~ msgstr "समूह."
-#, fuzzy
-#~ msgid "The subgroup must have at least 2 files to run %s"
-#~ msgstr "पर."
-#, fuzzy
-#~ msgid "Unable to proceed"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "** Can't open seed singature file <%s> **"
-#~ msgstr "बनाया जा रहा है."
-#, fuzzy
-#~ msgid "** Can't read signature file <%s> **"
-#~ msgstr "i n"
-#, fuzzy
-#~ msgid "Output file to contain final report"
-#~ msgstr "का रखे हुए"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "<%s> -- illegal value of min_size"
-#~ msgstr "n का आकार "
-#, fuzzy
-#~ msgid "Can't creat reportfile: "
-#~ msgstr "i n"
-#, fuzzy
-#~ msgid "Can't read signature file [%s]."
-#~ msgstr "i n"
-#, fuzzy
-#~ msgid "Unable to create reject layer [%s]."
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Raster map to hold classification results"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Error writing result map file!"
-#~ msgstr "त्रुटि n"
-#, fuzzy
-#~ msgid "imagery group"
-#~ msgstr "समूह"
-#, fuzzy
-#~ msgid "Name of input raster map(s)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Adding files to group [%s]"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Unable to connect line id %d to line %d"
-#~ msgstr "सभी"
-#, fuzzy
-#~ msgid "region <%s> not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "elevation file [%s] not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Training map [%s] not found."
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Parameter <%s> not set"
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Input map containing lines"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Cannot get layer information for vector map"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Cannot open file for <%s>"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Read coordinates from standard input"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "[%s] is an illegal name"
-#~ msgstr "है"
-#, fuzzy
-#~ msgid "Error reading map %s"
-#~ msgstr "त्रुटि."
-#, fuzzy
-#~ msgid "Input map [%s] in location [%s] in mapset [%s] not found."
-#~ msgstr "सदिश नहीं"
-#, fuzzy
-#~ msgid "%s in %s -can't open raster map"
-#~ msgstr ""
-#~ "त्रुटि\n"
-#, fuzzy
-#~ msgid "Name of output raster map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "name for new vector map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "<%s> unable to open raster map"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "File name of classification result"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Topographic index ln(a/tanB) map"
-#~ msgstr "a"
-#, fuzzy
-#~ msgid "Unable to write color table to raster [%s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "| Break                           |  "
-#~ msgstr "n n"
-#, fuzzy
-#~ msgid "Maximum number of iteration"
-#~ msgstr "संख्या का"
-#, fuzzy
-#~ msgid "Right: "
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "top raster map not found\n"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Compute upslope flowlines"
-#~ msgstr "गणना करें"
-#, fuzzy
-#~ msgid "Allows the user to interactively change the color table of a raster map layer displayed on the graphics monitor."
-#~ msgstr "चालू a."
-#, fuzzy
-#~ msgid "Fill color -- a GRASS named color, an R:G:B triplet, or \"none\""
-#~ msgstr "a R जी"
-#, fuzzy
-#~ msgid "Color desired for drawing map"
-#, fuzzy
-#~ msgid "Name of the output sites map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "spheroid geographic coordinates to base on. "
-#~ msgstr "ज़ेड"
-#, fuzzy
-#~ msgid "name of painter to select"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Input map: locations of real depressions"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid ""
-#~ "Convert on the fly, use less disk space\n"
-#~ "\t(requires r.out.ppm with stdout option)"
-#~ msgstr "चालू कम डिस्क n"
-#, fuzzy
-#~ msgid "fp: Data range is %.25f to %.25f\n"
-#~ msgstr "है n"
-#, fuzzy
-#~ msgid "Could not read south bufferzone size. Aborting."
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Converts GRASS vector map to one of the supported OGR vector formats."
-#~ msgstr "एक का."
-#, fuzzy
-#~ msgid "List paper formats ( name width height left right top bottom(margin) )"
-#~ msgstr "छापें ऊंचाई बायाँ दायाँ शीर्ष तल"
-#, fuzzy
-#~ msgid "Reading raster maps in group <%s> ..."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid ""
-#~ "Input raster map <%s> does not exist in group <%s>.\n"
-#~ " Try:\n"
-#~ msgstr "समूह."
-#, fuzzy
-#~ msgid "Name of fractal surface raster layer"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Unable to open file: <%s>"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Done"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "%s: <%s> illegal name"
-#~ msgstr "है"
-#, fuzzy
-#~ msgid "<%s> is illegal file name"
-#~ msgstr "है"
-#, fuzzy
-#~ msgid "Name of the output deviations site file"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of real-sky beam radiation coefficient input raster map [-]"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of real-sky diffuse radiation coefficient input raster map [-]"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Generates a raster map layer of distance to features in input layer."
-#~ msgstr "a एक."
-#, fuzzy
-#~ msgid "Name for distance output map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Reports statistics for raster map layers."
-#, fuzzy
-#~ msgid "Name of an output file to hold the report"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name for output raster map with lake"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Creates, edits, and lists groups and subgroups of imagery files."
-#~ msgstr "का."
-#, fuzzy
-#~ msgid ""
-#~ "ERROR: Required parameter <%s> not set:\n"
-#~ "\t(%s)\n"
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "db connection was not set by form\n"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Cannot describe table\n"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Name of table created for output when the distance to all flag is used"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "unable to open MASK"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ " group <%s> not found"
-#~ msgstr ""
-#~ "\n"
-#~ " समूह नहीं"
-#, fuzzy
-#~ msgid "Cannot write lake raster map <%s>!"
-#, fuzzy
-#~ msgid "raster map <%s> not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "no rules specified"
-#~ msgstr "नहीं."
-#, fuzzy
-#~ msgid "Adding new features to vector file ..."
-#, fuzzy
-#~ msgid "Fill areas of selected polygons"
-#~ msgstr "का"
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po	2012-05-26 15:22:06 UTC (rev 51802)
+++ grass/trunk/locale/po/grassmods_it.po	2012-05-26 15:46:05 UTC (rev 51803)
@@ -33374,6485 +33374,3 @@
 msgid "Percent to brighten"
 msgstr ""
-#, fuzzy
-msgid "Input raster map with specific yield in [1/m]"
-msgstr "Nessuna mappa in input specificata"
-#, fuzzy
-msgid "Raster map <%s> is not valid"
-msgstr "Mappa raster <%s> non trovata"
-#, fuzzy
-msgid "If not given read from standard input"
-msgstr "File raster ascii da importare"
-#, fuzzy
-msgid "Print basic info in shell script style"
-msgstr "Stampa in stile script per la shell"
-#, fuzzy
-msgid "Projection:"
-msgstr "Sto disegnando ..."
-#, fuzzy
-msgid "DBMI-OGR driver error:\n"
-msgstr "Errore del driver DBMI-MySQL:\n"
-#, fuzzy
-msgid "relative"
-msgstr "Creazione"
-#, fuzzy
-msgid "Display the HTML man pages of GRASS GIS"
-msgstr "Visualizza la pagina di supporto HTML di GRASS "
-#, fuzzy
-msgid "Join column in table"
-msgstr "Colonna sconosciuta <%s> nella tabella <%s>"
-#, fuzzy
-msgid "Unable to parse '%s'\n"
-msgstr "impossibile leggere %s"
-#, fuzzy
-msgid "Driver <%s> doesn't support creating new fields"
-msgstr "Gruppo <%s> non esiste ancora. Sto creandolo..."
-#, fuzzy
-msgid "Unable to add new field <%s>"
-msgstr "Impossibile aprire il file label <%s> nel mapset <%s>"
-#, fuzzy
-msgid "Name of raster map from which to copy color table"
-msgstr "Nome della mappa raster da cui copiare la tabella colore"
-#, fuzzy
-msgid "Name of file containing rules"
-msgstr "Nome del file contenente i comandi SQL"
-#, fuzzy
-msgid "Creating support files for <%s>"
-msgstr "Errore nella lettura del file dbmscap\n"
-#, fuzzy
-msgid "Title for new raster file."
-msgstr "Titolo per la nuova mappa raster"
-#, fuzzy
-msgid "Unable it load G3d range"
-msgstr "Impossibile leggere il file range"
-#, fuzzy
-msgid "\raster\" and \"volume\" options are mutually exclusive"
-msgstr "Le opzioni \"color\", \"rules\", e \"raster\" sono mutualmente esclusive"
-#, fuzzy
-msgid "Exports the color table associated with a raster3d map layer."
-msgstr "Esporta la tavola dei colori associata ad un tematismo raster"
-#, fuzzy
-msgid "Could not close RASTER3D map"
-msgstr "Impossibile chiudere la mappa RASTER3D"
-#, fuzzy
-msgid "Could not close RASTER3D map <%s>"
-msgstr "impossibile chiudere la mappa RASTER3D <%s>"
-#, fuzzy
-msgid "Name for v5d output file"
-msgstr "Nome del file v5d di output"
-#, fuzzy
-msgid "Converts a 3D raster map into a 3-dimensional Vis5D file."
-msgstr "Esporta raster GRASS 3D in un file Vis5D tridimensionale"
-#, fuzzy
-msgid "Name for output flowline density raster map"
-msgstr "Nome della tabella in output"
-#, fuzzy
-msgid "Remove dangles:"
-msgstr "Rimuovi i doppi"
-#, fuzzy
-msgid "Unable to create 3D vector and attribute table at same time"
-msgstr "impossibile aprire <%s>"
-#, fuzzy
-msgid "Coordinates"
-msgstr "Coordinate non validi"
-#, fuzzy
-msgid "vector, interpolation, kriging"
-msgstr "Mostra il titolo del file raster"
-#, fuzzy
-msgid "reclass raster output map"
-msgstr "Nome della mappa di output"
-#, fuzzy
-msgid "Vector map for which to drop vector objects"
-msgstr "Non riesco a descrivere la tabella"
-#, fuzzy
-msgid "Layer of attribute table to use for selection"
-msgstr "Nome della mappa raster da utilizzare per <%s>"
-#, fuzzy
-msgid "Raster map to use as mask"
-msgstr "Mappa(e) raster da leggere"
-#, fuzzy
-msgid "Overwrite existing file"
-msgstr "Sovrascrivi la MASK esistente"
-#, fuzzy
-msgid "Name of input vector polygon map"
-msgstr "Nome di un file vettoriale in output"
-#, fuzzy
-msgid "raster, import, copying"
-msgstr "File di input"
-#, fuzzy
-msgid "raster, export, copying"
-#, fuzzy
-msgid "Name of input elevation map"
-msgstr "Nome di  2-%d mappe raster in input"
-#, fuzzy
-msgid "zenith"
-msgstr "Lunghezza: %f\n"
-#, fuzzy
-msgid "topographic correction method"
-msgstr "Visualizza il raster della direzione"
-#, fuzzy
-msgid "Elevation file of unknown type"
-msgstr "Coordinate dell'altezza di un punto nel piano"
-msgid "Converts a 3D raster map layer into an ASCII text file"
-msgstr "Converte un raster 3D in un file di testo ASCII"
-msgid "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
-msgstr "Converte un file testuale raster ASCII 3D in un layer raster 3D (binario)"
-msgid "Converts 3D raster maps (RASTER3D) into the VTK-Ascii format"
-msgstr "Converte una mappa raster 3D (RASTER3D) nel formato VTK-Ascii"
-#, fuzzy
-msgid "unable to close top raster map"
-msgstr "impossibile chiudere la mappa raster superiore"
-#, fuzzy
-msgid "unable to close bottom raster map"
-msgstr "impossibile chiudere la mappa raster inferiore"
-msgid ""
-"Cannot create mask file: RASTER3D_MASK already exists!\n"
-" Use 'g.remove rast3d=RASTER3D_MASK' to remove the existing mask."
-msgstr ""
-"Impossibile creare la mask. MASK RASTER3D già esistente!\n"
-"Usa il comando 'g.remove rast3d=RASTER3D MASK' per rimuovere la maschera esistente"
-msgid "Name of input base raster map (elevation or ilumination)"
-msgstr "Nome del raster in input (elevazione o illuminazione)"
-#, fuzzy
-msgid "Watershed basin analysis program"
-#, fuzzy
-msgid "Name of input raster map with real depressions"
-#, fuzzy
-msgid "Name of input raster map blocking overland surface flow"
-msgstr "Nome di una mappa raster contenente una superfice di altezze"
-#, fuzzy
-msgid "Name for output raster map useful for visual display of results (DEPRECATED)"
-msgstr "Nome del nuovo file PPM. (use out=- per lo standard output)"
-#, fuzzy
-msgid "Direction raster found <%s>"
-msgstr "Nome del driver in input"
-#, fuzzy
-msgid "Name for output direction map for depressionless elevation raster map"
-msgstr "Nome del file raster in input"
-#, fuzzy
-msgid "raster, export, animation"
-#, fuzzy
-msgid "Name for output elevation raster map after filling"
-msgstr "Visualizza il raster delle altezze dopo il riempimento"
-#, fuzzy
-msgid "Name for output direction raster map"
-#, fuzzy
-msgid "Reading input data..."
-msgstr "Lettura dell'input in corso ..."
-#, fuzzy
-msgid "Writing output data..."
-msgstr "Scrittura dell'output in corso ..."
-#, fuzzy
-msgid "raster, reclassification"
-#, fuzzy
-msgid "Name of input raster map with given starting point(s) (at least 1 cell > 0)"
-#, fuzzy
-msgid "Name for flowpath length raster map"
-#, fuzzy
-msgid "imagery, landsat, acca"
-msgstr "immagini, statistiche"
-#, fuzzy
-msgid "Cannot write to raster map <%s>"
-msgstr "Non riesco a trovare il file raster %s"
-#, fuzzy
-msgid "Creates, edits, and lists groups and subgroups of imagery data."
-msgstr "Crea, modifica ed elenca gruppi e sottogruppi di file di immagini."
-#, fuzzy
-msgid "Extract quality control parameters from Modis QC layers"
-msgstr "Estrae parametri del terreno da un DEM."
-#, fuzzy
-msgid "Name of the surface reflectance QC layer [bit array]"
-msgstr "Nome di un nuovo file raster"
-#, fuzzy
-msgid "Computing means and standard deviations..."
-msgstr "Calcolo delle medie per la banda %d in corso..."
-#, fuzzy
-msgid "Computing means..."
-msgstr "Calcolo delle equazioni in corso......"
-#, fuzzy
-msgid "Other"
-msgstr "Retino"
-#, fuzzy
-msgid "Offset in map units."
-msgstr "Offset lungo l'asse maggiore in unità di mappa"
-#, fuzzy
-msgid "Cannot describe table"
-msgstr "Non posso copiare la tabella"
-#, fuzzy
-msgid "DEPRECATED Buffer distance in map units"
-msgstr "La tolleranza in unità di mappa: %g"
-#, fuzzy
-msgid "Line buffers... "
-msgstr "Ricerca delle zone di buffer in corso ..."
-#, fuzzy
-msgid "Zero area size, please clean input vector first."
-msgstr "Crea linee parallele di un vettore lineare di input."
-#, fuzzy
-msgid "Could not get outside buffer for line id %d"
-msgstr "Impossibile ottenere la riga raster per la mappa di elevazione"
-#, fuzzy
-msgid "Area buffers... "
-msgstr "raster, buffer"
-#, fuzzy
-msgid "Selecting areas..."
-msgstr "Selezione degli elementi in corso..."
-msgid "Converts to one of the supported OGR vector formats."
-msgstr "Converte in uno dei formati vettoriali supportati da OGR"
-#, fuzzy
-msgid "Cannot allocate %u bytes of memory"
-msgstr "Non riesco ad impostare user/password"
-# della quale/per la quale
-#, fuzzy
-msgid "Name of input raster map in which to fill nulls"
-msgstr "Nome della mappa raster della quale modificare il valore null"
-#, fuzzy
-msgid "Name for output raster map with nulls filled by interpolation"
-msgstr "Nome per la mappa raster di output con il lago"
-#, fuzzy
-msgid "input,cell,raster"
-#, fuzzy
-msgid "output,cell,raster"
-msgstr "campo separatore in output"
-msgid "Convert all old GRASS < Ver5.7 vector maps in current mapset to current format"
-msgstr "Converte tutte le vecchie mappe vettoriali di GRASS < Ver5.7 del mapset corrente nel formato corrente"
-msgid "Import Mapgen or Matlab vector maps into GRASS."
-msgstr "Importa vettori Mapgen o Matlab in GRASS"
-#, fuzzy
-msgid "raster, projection"
-msgstr "Nome del raster"
-#, fuzzy
-msgid "Create an integer map"
-msgstr "Mappa raster risultante"
-msgid "Empty east coordinate specified!"
-msgstr "Sono state specificate delle coordinate ovest vuote."
-msgid "Empty north coordinate specified!"
-msgstr "Sono state specificate delle coordinate nord vuote."
-msgid "Either define sun position or location/date/time parameters."
-msgstr "Definisci la posizione del sole oppure i parametri di luogo/data/tempo"
-#, fuzzy
-msgid "Calculating sun position... (using solpos (V. %s) from NREL)\n"
-msgstr "Calcolo la posizione del sole (utilizzando solpos(V %S) da NREL)\n"
-msgid "Change current mapset."
-msgstr "Cambia il mapset corrente."
-#, fuzzy
-msgid "Modifies the user's current mapset search path, affecting the user's access to data existing under the other GRASS mapsets in the current location."
-msgstr "Copia i file disponibili nell'attuale percorso di ricerca del mapset e della location in uso dall'utente nelle appropriate cartelle del mapset corrente"
-#, fuzzy
-msgid "Name(s) of existing mapset(s) to add to search list"
-msgstr "Nome di una mappa raster esistente"
-#, fuzzy
-msgid "Name(s) of existing mapset(s) to remove from search list"
-#, fuzzy
-msgid "Unhandled vector feature type <%s>"
-msgstr "Nome della mappa raster risultante"
-#, fuzzy
-msgid "No areas found, skipping type=area"
-msgstr "Utilizza la regione corrente"
-#, fuzzy
-msgid "No points found, skipping%s%s"
-#, fuzzy
-msgid "No lines found, skipping%s%s"
-msgid "Total area: %e (%d areas)"
-msgstr "Area totale: %e (%d areas)"
-msgid "Area without category: %e (%d areas)"
-msgstr "Aree senza categoria: %e (%d areas)"
-msgid "Converts a binary GRASS vector map into a GRASS raster map ."
-msgstr "Converte vettore binario GRASS in raster GRASS"
-msgid "Name of column for attr parameter (data type must be numeric)"
-msgstr "Nome della colonna per il parametro attr (tipo di dato dovrà essere numerico)"
-msgid "Duplicate area centroids"
-msgstr "Centroidi dell'area duplicati"
-#, fuzzy
-msgid "GDAL datatype: %s, range: %f - %f"
-msgstr "ERRORE: <%s> esiste già\n"
-#, fuzzy
-msgid "The hight of the river bed in [m]"
-msgstr "Nome del driver in output"
-#, fuzzy
-msgid "The hight of the drainage bed in [m]"
-#, fuzzy
-msgid "Pass %d:"
-msgstr "Password"
-#, fuzzy
-msgid "The '-q' flag is superseded and will be removed "
-msgstr "Mappa in uscita già esistente. Sarà sovrascritta!\n"
-#, fuzzy
-msgid "Unable to create table <%s_edge_Interpolation>"
-msgstr "Impossibile aprire il database <%s>"
-#, fuzzy
-msgid "Rescale output raster map [0,255]"
-msgid "Use db.select for SELECT SQL statements"
-msgstr "Usa db.select per i comandi SELECT SQL"
-#, fuzzy
-msgid "Can't find %d,%d:%f"
-msgstr "Non riesco a mostrare i database"
-msgid "Nothing to show"
-msgstr "Niente da mostrare"
-#, fuzzy
-msgid "Reading %s"
-#, fuzzy
-msgid "Writing %s"
-#, fuzzy
-msgid "Output more comments (default=quiet)"
-#, fuzzy
-msgid "Vector map to display thematically"
-#, fuzzy
-msgid "Vector map type"
-#, fuzzy
-msgid "Layer to use for thematic display"
-#, fuzzy
-msgid "Mapset(s) to list (default: current mapset search path)"
-msgstr "Mapset del quale fornire la lista (default: percorso corrente)"
-#, fuzzy
-msgid "Output separator (default: newline)"
-msgstr "Carattere di separatore in output (predefinito: tab)"
-#, fuzzy
-msgid "Raster to remove"
-#, fuzzy
-msgid "3d raster to remove"
-#, fuzzy
-msgid "Vector to remove"
-#, fuzzy
-msgid "Region to remove"
-#, fuzzy
-msgid "Label to remove"
-#, fuzzy
-msgid "3dview to remove"
-#, fuzzy
-msgid "Group to remove"
-msgid "sensor: LANDSAT"
-msgstr "sensore: LANDSAT"
-msgid "sensor: QuickBird"
-msgstr "sensore: QuickBird"
-msgid "sensor: SPOT"
-msgstr "sensore: SPOT"
-#, fuzzy
-msgid "raster input maps"
-msgstr "Mappa raster in input"
-#, fuzzy
-msgid "Output field seperator"
-msgstr "Campo separatore in output"
-msgid "Steps=%d"
-msgstr "Scala=%d"
-#, fuzzy
-msgid "ERROR: Problem opening output file."
-#, fuzzy
-msgid "Creates explicitly the NULL-value bitmap file."
-msgstr "Crea separatamente un file bitmap 3D di valori nulli"
-#, fuzzy
-msgid "Density of output walkers"
-msgstr "Nome del file in output"
-#, fuzzy
-msgid "File [%s] not found"
-msgstr "raster <%s> non trovato"
-#, fuzzy
-msgid "Unable to open file [%s]"
-msgstr "Non riesco ad aprire il cellfile per [%s]"
-#, fuzzy
-msgid "Reading sites map (%s) ..."
-#, fuzzy
-msgid "Name of the output walkers vector points map"
-msgstr "Nome della mappa di input"
-#, fuzzy
-msgid "You are not outputting any raster or vector points maps"
-#, fuzzy
-msgid "%s=%s - illegal value"
-msgstr "Nome del raster map in output"
-#, fuzzy
-msgid "Unable to read current region parameters"
-#, fuzzy
-msgid "Cannot open cover raster map <%s>"
-msgstr "Non riesco ad aprire il cellfile [%s]"
-#, fuzzy
-msgid "Cannot open database <%s> by driver <%s>"
-msgstr "Non riesco ad eseguire il driver '%s'"
-#, fuzzy
-msgid "No map specified"
-#, fuzzy
-msgid "%s - unable to remove color table"
-msgstr "Valore da scrivere per null"
-#, fuzzy
-msgid "%s - color table not found"
-#, fuzzy
-msgid "Unable to properly read input raster map"
-#, fuzzy
-msgid "Unable to properly write output raster map"
-msgstr "Nome del raster in output"
-msgid "Name of raster map layer to be used for <%s>"
-#, fuzzy
-msgid "%d points converted to centroids"
-msgstr "Punti di blocco della mappa vettoriale"
-#, fuzzy
-msgid "%d centroids converted to points"
-#, fuzzy
-msgid "%d lines converted to boundaries"
-msgstr "%d linee / confini rimossi"
-#, fuzzy
-msgid "CrossCorrelation: %d points read in region.\n"
-#, fuzzy
-msgid "CrossCorrelation: Cannot open database %s by driver %s"
-msgstr "Non riesco ad aprire il database %s col driver %s"
-#, fuzzy
-msgid "CrossCorrelation: Column type not supported"
-msgstr "Tipo di colonna non supportata"
-#, fuzzy
-msgid "CrossCorrelation: Cannot select data from table"
-msgstr "Non riesco a selezionare dati dalla tabella"
-#, fuzzy
-msgid "CrossCorrelation: No record for point (cat = %d)"
-msgstr "Nessun record per la cat = %d"
-#, fuzzy
-msgid "vector, attribute table"
-#, fuzzy
-msgid "Cannot fetch data"
-#, fuzzy
-msgid "Hilight color for text"
-msgstr "Colore di evidenziazione del testo"
-msgid "Reading data from the map..."
-msgstr "Sto leggendo dati dalla mappa"
-#, fuzzy
-msgid "Query layer (used by 'query' option)"
-msgid "%d categories read from map"
-msgstr "%d categorie caricate dalla mappa"
-msgid "Writing attributes ..."
-msgstr "Sto scrivendo gli attributi ..."
-#, fuzzy
-msgid "Current region does not include the entire input vector map <%s>"
-#, fuzzy
-msgid "Output inverse raster map after IFFT"
-msgid "Reading the raster maps..."
-msgstr "Leggendo la mappa raster"
-msgid "Unable to open output file."
-msgstr "Impossibile aprire il file di output"
-#, fuzzy
-msgid "Hue map name"
-#, fuzzy
-msgid "Intensity map name"
-msgstr "Nome mappa raster"
-#, fuzzy
-msgid "Saturation map name"
-#, fuzzy
-msgid "Output map representing the red"
-msgstr "strighe che rappresentano le celle prive di valori"
-#, fuzzy
-msgid "Output map representing the green"
-#, fuzzy
-msgid "Output map representing the blue"
-msgid "Cannot read row from raster map"
-msgstr "Non posso leggere la riga dalla mappa raster"
-msgid "Cannot write row to raster map"
-msgstr "Non posso scrivere la riga alla mappa raster"
-#, fuzzy
-msgid "Red input raster map"
-#, fuzzy
-msgid "Green input raster map"
-#, fuzzy
-msgid "Blue input raster map"
-#, fuzzy
-msgid "Output intensity raster map"
-msgid "Writing [%s] ..."
-msgstr "Sto scrivendo [%s] ..."
-#, fuzzy
-msgid "Name of imagery signaturefile"
-msgstr "Nome della mappa raster"
-msgid "Subgroup [%s] not found."
-msgstr "Sottogruppo <%s> non trovato"
-#, fuzzy
-msgid "Cannot write color table of raster map <%s>"
-msgid "Imagery group"
-msgstr "Gruppo di immagini"
-#, fuzzy
-msgid "Subgroup containing image files"
-#, fuzzy
-msgid "Resultant signature file"
-msgstr "mappa raster con il risultato"
-#, fuzzy
-msgid "Input raster map being fft"
-#, fuzzy
-msgid "Illegal file name for real part: %s"
-#, fuzzy
-msgid "Illegal file name for imaginary part: %s"
-#, fuzzy
-msgid "Reading the raster map..."
-msgid "subgroup <%s> not found"
-msgstr "sottogruppo <%s> non trovato"
-#, fuzzy
-msgid "Unable to proceed"
-#, fuzzy
-msgid "Unable to read head of %s"
-msgstr "Non riesco ad aprire il file header di [%s]"
-msgid "group=[%s] - not found."
-msgstr "gruppo=[%s] - non trovato"
-#, fuzzy
-msgid "subgroup=[%s] (of group [%s]) - not found."
-#, fuzzy
-msgid "Can't read signature file [%s]."
-#, fuzzy
-msgid "Unable to create reject layer [%s]."
-#, fuzzy
-msgid "Signatures to use for classification"
-msgstr "Nome del file con il risultato della classificazione"
-#, fuzzy
-msgid "Raster map to hold classification results"
-#, fuzzy
-msgid "Cannot select attributes: %s"
-msgid ""
-"Optional where condition (without WHERE key word), e.g.:\n"
-"\t\tobec = 'Liptakov'"
-msgstr ""
-"Condizione opzionale where (senza la parola chiave WHERE), e.s.:\n"
-#, fuzzy
-msgid "Keep band numbers instead of using band color names."
-msgstr "Usa i numeri delle bande invece che i nomi dei colori"
-#, fuzzy
-msgid "Saving new map"
-#, fuzzy
-msgid "Output raster map with lake"
-#, fuzzy
-msgid "Terrain raster map <%s> not found!"
-#, fuzzy
-msgid "Cannot open terrain raster map <%s@%s>!"
-#, fuzzy
-msgid "Seed map <%s> not found!"
-#, fuzzy
-msgid "Cannot open seed map <%s@%s>!"
-#, fuzzy
-msgid "Failure to allocate memory for row pointers"
-#, fuzzy
-msgid "Loading maps: "
-#, fuzzy
-msgid "Error reading terrain raster map. Probably broken file."
-#, fuzzy
-msgid "Error reading seed raster map. Probably broken file."
-#, fuzzy
-msgid "Cannot write lake raster map <%s@%s>!"
-#, fuzzy
-msgid "Error writing color file for <%s@%s>!"
-#, fuzzy
-msgid "All done."
-msgstr "Fatto.\n"
-#, fuzzy
-msgid "Name of the vector points map with x,y locations"
-#, fuzzy
-msgid "Number of time iterations (sec.)"
-msgstr "Numero di passi attraverso il dataset"
-#, fuzzy
-msgid "Multiscale simulation"
-msgstr "locazione del database"
-#, fuzzy
-msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
-#, fuzzy
-msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
-#, fuzzy
-msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
-msgid "Raster input maps(s)"
-msgstr "Mappe raster in input"
-#, fuzzy
-msgid "Output file name"
-msgstr "Nome del file di output"
-#, fuzzy
-msgid ""
-"Raster map [%s] already exists.\n"
-"Please try another."
-#, fuzzy
-msgid "Error reading '%s' map"
-#, fuzzy
-msgid "Threshold distance"
-msgstr "Unità della distanza"
-#, fuzzy
-msgid "Cannot execute: %s"
-#, fuzzy
-msgid "Cannot link table: %s"
-msgstr "Non posso scrivere i collegamenti del database"
-#, fuzzy
-msgid "DXF input file"
-#, fuzzy
-msgid "Cannot open dxf file <%s>"
-#, fuzzy
-msgid "Cannot open new vector map <%s>"
-#, fuzzy
-msgid "Conversion of <%s> to vector map:"
-#, fuzzy
-msgid "Raster file(s) for Elevation"
-msgstr "file raster per la Vista%d"
-#, fuzzy
-msgid "Raster file(s) for Color"
-#, fuzzy
-msgid "Raster map to zoom into"
-msgid "Save the current region to region definition file"
-msgstr "Salva le impostazione della region corrente in un file di definizione della region"
-#, fuzzy
-msgid "Could not open input file <%s>."
-#, fuzzy
-msgid "Name of the resultant map"
-msgstr "Nome della mappa con il risultato"
-#, fuzzy
-msgid "Raster map not found."
-#, fuzzy
-msgid "Raster file [%s] not found"
-#, fuzzy
-msgid "It was not possible writing in <%s>."
-#, fuzzy
-msgid "Cannot create table: '%s'"
-#, fuzzy
-msgid "Unable to get category list <%s>, editing terminated"
-msgstr "Non riesco a leggere da <%s>"
-#, fuzzy
-msgid "Unable to delete layer/category [%d/%d] line %d"
-#, fuzzy
-msgid "Unable to write line %d"
-#, fuzzy
-msgid "Unable to delete line %d"
-#, fuzzy
-msgid "Unknown query tool '%s'"
-#, fuzzy
-msgid "No layer database connection"
-#, fuzzy
-msgid "%d categories loaded from the database"
-msgstr "Estrae dati dal database."
-#, fuzzy
-msgid "Cannot create layer"
-#, fuzzy
-msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
-msgstr "Impossibile trovare il vettoriale [%s]"
-#, fuzzy
-msgid "Column type [%d] not supported"
-#, fuzzy
-msgid "Cannot read map header for <%s>"
-#, fuzzy
-msgid "Cannot read category file for <%s>"
-msgstr "Impossibile salvare la region <%s>"
-msgid "Print;Shell Script"
-msgstr "Stampa; script per la shell"
-#, fuzzy
-msgid "%s: <%s> raster map not found"
-#, fuzzy
-msgid "%s: <%s> raster map exists already"
-#, fuzzy
-msgid "Cannot read category file of raster map <%s>"
-#, fuzzy
-msgid "%s - map not found"
-#, fuzzy
-msgid "%s not found"
-#, fuzzy
-msgid "Could not access %s layer"
-#, fuzzy
-msgid "Vector map %s - not found"
-msgid "Raster map containing elevation data"
-msgstr "Mappa raster che contiene i valori delle altezze"
-msgid "Raster map name for storing results"
-msgstr "Mappa raster con il nome dei risultati archiviati"
-msgid "Height of the viewing location"
-msgstr "Altezza della locazione visualizzata"
-#, fuzzy
-msgid "%s: <%s> cellfile not found"
-#, fuzzy
-msgid "Cell file [%s] not found\n"
-#, fuzzy
-msgid "rgb cell map [%s] not found\n"
-#, fuzzy
-msgid "vector cell map [%s] not found\n"
-#, fuzzy
-msgid "%s - %s not found"
-#, fuzzy
-msgid "Unable to read category file for raster map <%s>"
-#, fuzzy
-msgid "Creating support files"
-#, fuzzy
-msgid "%s file [%s] not found!"
-#, fuzzy
-msgid "%s: %s - map not found"
-#, fuzzy
-msgid "%s: unable to open %s"
-#, fuzzy
-msgid "%s - not found"
-#, fuzzy
-msgid "Cannot read %s"
-#, fuzzy
-msgid "Reading %s ... "
-#, fuzzy
-msgid "[%s] map not found."
-#, fuzzy
-msgid "[%s] map not found"
-#, fuzzy
-msgid "Cannot describe table <%s>"
-#, fuzzy
-msgid "Cannot insert values: %s"
-#, fuzzy
-msgid "%s given an illegal number of points [%d]"
-msgstr "%s ha dato un numero non valido di sites [%d]"
-#, fuzzy
-msgid "Unable to open database %s by driver %s"
-#, fuzzy
-msgid "No DB connection settings defined. Set with db.connect"
-msgstr "Nessuna impostazione definita per il database. Fallo usando db.connect"
-msgid "Could not find input %s"
-msgstr "Non riesco a trovare l'input %s"
-msgid "Could not open input"
-msgstr "Non riesco ad aprire l'input"
-msgid "Could not open output"
-msgstr "Non riesco ad aprire l'output"
-#, fuzzy
-msgid "Could not find input map <%s>"
-#, fuzzy
-msgid "Can't read header for <%s> in <%s>"
-msgstr "Impossibile leggere l'intestazione del raster 3D <%s> in <%s>"
-#, fuzzy
-msgid "Can't read header for 3D raster <%s> in <%s>"
-msgid "%s in %s: %s"
-msgstr "%s in %s: %s"
-#, fuzzy
-msgid "Can't write region <%s>"
-msgid "<%s=%s> ** invalid input **"
-msgstr "<%s=%s> ** input non valido **"
-#, fuzzy
-msgid "No graphics device selected."
-msgstr "Nessun device grafico selezionato"
-#, fuzzy
-msgid "Unable to read raster row."
-#, fuzzy
-msgid "%s map not found"
-#, fuzzy
-msgid "cannot read head of %s"
-#, fuzzy
-msgid "Illegal file name: %s"
-msgstr "Nome file non valido [%s]."
-msgid "Cannot get layer info for vector map"
-msgstr "Impossibile ottenere informazioni sul layer vettoriale"
-#, fuzzy
-msgid "Cannot open raster map <%s> in <%s>"
-#, fuzzy
-msgid "%s: %s - raster map not found"
-#, fuzzy
-msgid "%s: %s - illegal name"
-#, fuzzy
-msgid "%s: ERROR reading category file for %s"
-#, fuzzy
-msgid "%s: %s - not found"
-#, fuzzy
-msgid "%s: %s - illegal units"
-#, fuzzy
-msgid "%s: %s - can't open"
-#, fuzzy
-msgid "Reading input map (%s)    ... "
-#, fuzzy
-msgid "%s - ERROR reading %s"
-#, fuzzy
-msgid "%s: %s - can't create raster map"
-#, fuzzy
-msgid "Writing output map (%s)   ... "
-#, fuzzy
-msgid "%s - ERROR re-reading %s"
-#, fuzzy
-msgid "Reading raster map... "
-#, fuzzy
-msgid "Writing raster map... "
-msgstr "Nome del raster map esistente"
-msgid "Category list: e.g. 1,3-8,13"
-msgstr "Categoria lista: es. 1,3-8,13"
-msgid "Output separator character (default: tab)"
-#, fuzzy
-msgid "Cannot read category file of raster map <%s> in <%s>"
-#, fuzzy
-msgid "Cannot create raster map %s"
-#, fuzzy
-msgid "Cannot create vector map %s"
-#, fuzzy
-msgid "Cannot create raster map '%s'"
-#, fuzzy
-msgid "Number of raster rows to hold in memory"
-msgstr "Nume di righe da tenere in memoria"
-#, fuzzy
-msgid "Print raster map title only"
-msgstr "Stampa solo il tipo di mappa raster"
-#, fuzzy
-msgid "unknown type: %d"
-msgstr "Tipo sconosciuto"
-msgid "Cannot open raster map [%s]"
-#, fuzzy
-msgid "Cannot get raster band."
-#, fuzzy
-msgid "Cannot read GRASS raster."
-#, fuzzy
-msgid "Cannot write GDAL raster."
-#, fuzzy
-msgid "Cannot get [%s] driver"
-#, fuzzy
-msgid "Couldn't set geo transform."
-#, fuzzy
-msgid "Couldn't set projection."
-#, fuzzy
-msgid "Cannot export [%s] raster map."
-#, fuzzy
-msgid "Cannot create [%s] raster map using [%s] driver."
-#, fuzzy
-msgid "Cannot read header of raster map <%s>"
-#, fuzzy
-msgid "Cannot open TIFF file <%s>"
-#, fuzzy
-msgid "Reading raster map"
-#, fuzzy
-msgid "Cannot open output map."
-#, fuzzy
-msgid "Illegal file name. Please try another."
-#, fuzzy
-msgid "%s: can't open %s"
-#, fuzzy
-msgid "Reading raster map <%s> ..."
-#, fuzzy
-msgid "memory allocation failure"
-#, fuzzy
-msgid "Can't find data map."
-#, fuzzy
-msgid "Cannot open vector map <%s> at the topological level"
-#, fuzzy
-msgid "Rebuilding topology ..."
-msgid "No record for cat = %d"
-#, fuzzy
-msgid "Removing duplicates ..."
-#, fuzzy
-msgid "Attaching islands ..."
-#, fuzzy
-msgid "Attaching centroids ..."
-#, fuzzy
-msgid "Vector map <%s> not found in current mapset"
-#, fuzzy
-msgid "The number of lines in the input vector map is [%d]"
-#, fuzzy
-msgid "The number of polylines in the output vector map is [%d]"
-#, fuzzy
-msgid "Database connection not defined for layer <%d>"
-msgstr "Connessione al database non definita\n"
-#, fuzzy
-msgid "Cannot get layer info"
-#, fuzzy
-msgid "cell file [%s] not found"
-#, fuzzy
-msgid "can't open raster map [%s]"
-#, fuzzy
-msgid "Cannot rewrite line %d"
-msgstr "Impossibile creare l'indice"
-#, fuzzy
-msgid "Editing tool"
-msgstr "Esistente"
-#, fuzzy
-msgid "Close boundaries"
-msgstr "Non riesco a copiare la tabella"
-#, fuzzy
-msgid "Cannot copy line %d, editing terminated"
-#, fuzzy
-msgid "No layer database connection."
-#, fuzzy
-msgid "Cannot snap lines %d,%d"
-#, fuzzy
-msgid "%d lines modified"
-msgstr "%d categorie duplicate nel vettoriale"
-#, fuzzy
-msgid "Could not open ASCII file <%s>"
-#, fuzzy
-msgid "Print vector map region only"
-#, fuzzy
-msgid "Cannot open vector map <%s> at topo level [%d]"
-#, fuzzy
-msgid "Cannot get layer info for vector map <%s>"
-#, fuzzy
-msgid "Cannot select attribute."
-#, fuzzy
-msgid "Creating vector grid..."
-#, fuzzy
-msgid "Could not find vector map <%s> in current mapset"
-#, fuzzy
-msgid "Could not find input map <%s>."
-#, fuzzy
-msgid "Output map where segments will be written"
-#, fuzzy
-msgid "<%s> cellfile not found"
-#, fuzzy
-msgid "Not able to open vector map <%s>"
-#, fuzzy
-msgid "Can't read raster"
-msgid "driver name"
-msgstr "nome driver"
-msgid "database name"
-msgstr "nome database"
-#, fuzzy
-msgid "Driver name"
-msgid "Cannot list databases."
-msgid "Table name, select all from this table"
-msgstr "Nome tabella, seleziona tutto da questa tabella"
-msgid "output vertical record separator"
-msgstr "output verticale del separatore di record "
-msgid "null value indicator"
-msgstr "indicatore di valore nullo"
-msgid "do not include column names in output"
-msgstr "non includere i nomi delle colonne nell'output"
-msgid "vertical output (instead of horizontal)"
-msgstr "output verticale (invece che orizzontale)"
-#, fuzzy
-msgid "Cannot find mapset for %s"
-#, fuzzy
-msgid "Cannot open File %s"
-#, fuzzy
-msgid "Not able to open file for [%s]"
-#, fuzzy
-msgid "Can't open label file [%s]"
-#, fuzzy
-msgid "unable to open [%s] in [%s]"
-#, fuzzy
-msgid "warning: unable to open [%s] in [%s]"
-#, fuzzy
-msgid "Unable to open raster map [%s] in [%s]"
-#, fuzzy
-msgid "Unable to find input cell map '%s'"
-#, fuzzy
-msgid "Unable to open cellfile for <%s>"
-#, fuzzy
-msgid "Unable to create raster map [%s]"
-#, fuzzy
-msgid "Unable to create output <%s>"
-#, fuzzy
-msgid "Input file [%s] not found."
-#, fuzzy
-msgid "Unable to open output file <%s>."
-#, fuzzy
-msgid "Could not open temporary file: [%s]"
-#, fuzzy
-msgid "Could not open input file [%s]"
-#, fuzzy
-msgid "Unable to create output raster map <%s>"
-#, fuzzy
-msgid "%s: Unable to find raster map <%s>"
-#, fuzzy
-msgid "%s: Unable to open raster map <%s> in mapset <%s>"
-#, fuzzy
-msgid "%s:  Unable to open output raster map <%s>"
-#, fuzzy
-msgid "Vector <%s> could not be opened"
-#, fuzzy
-msgid "No db connection for driver <%s> defined. Run db.connect."
-#, fuzzy
-msgid "Table name"
-msgstr "nome tabella"
-msgid ""
-"Print current map connection parameters and exit (shell script style)\n"
-"\tformat:  layer[/layer name] table key database driver"
-msgstr ""
-"Stampa i parametri di connessione correnti ed esce (stile shell script)\n"
-#, fuzzy
-msgid "x column name"
-#, fuzzy
-msgid "z column name"
-#, fuzzy
-msgid "Cannot drop table: %s"
-#, fuzzy
-msgid "Cannot open labels <%s>"
-#, fuzzy
-msgid "Cannot fetch data from table"
-#, fuzzy
-msgid "Cannot open file [%s]"
-#, fuzzy
-msgid "SVG file <%s> cannot be opened"
-#, fuzzy
-msgid "Querying input '%s' ... "
-#, fuzzy
-msgid "Copying %s input lines ... "
-#, fuzzy
-msgid "Cannot create table <%s>"
-#, fuzzy
-msgid "cannot insert row: %s"
-#, fuzzy
-msgid "Cannot find line of cat %d"
-#, fuzzy
-msgid "Unalbe to open vector map <%s>"
-#, fuzzy
-msgid "Database connection not defined for layer [%d]. Use v.db.connect first"
-#, fuzzy
-msgid "Transforms a vector map via a set of tie points."
-msgstr "Esporta un raster grass come array binario"
-#, fuzzy
-msgid "Raster map <%s>] not found"
-msgid "Cannot start driver '%s'."
-msgid "Cannot start driver <%s>."
-msgstr "Non riesco ad eseguire il driver <%s>."
-msgid "Could not open <%s>"
-msgstr "Impossibile aprire <%s>"
-msgid "Cannot write to <%s>"
-msgstr "Non riesco a scrivere su <%s>"
-msgid "Not able to open cellfile for [%s]"
-#, fuzzy
-msgid "Not able to find cellfile [%s]"
-#, fuzzy
-msgid "Raster file [%s] not available"
-#, fuzzy
-msgid "Raster map [%s] not found"
-#, fuzzy
-msgid "Unable to open raster map [%s]"
-msgid "Vector file [%s] not available"
-#, fuzzy
-msgid "<%s> illegal name"
-msgid "Out of Memory!\n"
-msgstr "Memoria esaurita!\n"
-#, fuzzy
-msgid "%s: %s - illegal name for output raster map."
-#, fuzzy
-msgid "Exports GRASS raster data into various formats (requires GDAL)."
-msgid "Couldn't find raster map %s"
-#, fuzzy
-msgid "%s: <%s> not found"
-#, fuzzy
-msgid "%s: <%s> illegal name"
-#, fuzzy
-msgid "%s: Cannot open <%s>"
-#, fuzzy
-msgid "could not read range file"
-#, fuzzy
-msgid "Unable to create raster map [%s]."
-#, fuzzy
-msgid "Filtering [%s] in [%s]"
-#, fuzzy
-msgid "Open raster map %s in %s = %d"
-#, fuzzy
-msgid "Closing raster map"
-#, fuzzy
-msgid "Swap temp files"
-#, fuzzy
-msgid "Writing [%s]"
-#, fuzzy
-msgid "%s: illegal map name"
-#, fuzzy
-msgid "%s: <%s> illegal file name"
-#, fuzzy
-msgid "can't open raster map <%s> in mapset %s"
-#, fuzzy
-msgid "Checking location %s, mapset %s:"
-#, fuzzy
-msgid "Error writing output map"
-#, fuzzy
-msgid "<%s> is illegal file name"
-msgstr "[%s] è un nome illegale"
-#, fuzzy
-msgid "[%s] is an illegal file name"
-#, fuzzy
-msgid "Can't open temp file [%s]"
-#, fuzzy
-msgid "Unable to open input map <%s> in mapset <%s>"
-#, fuzzy
-msgid "%s - illegal name "
-#, fuzzy
-msgid "Couldn't find raster map [%s]"
-#, fuzzy
-msgid "%s - can't create raster map"
-#, fuzzy
-msgid "Normalized"
-msgstr "Normalizzata"
-#, fuzzy
-msgid "Cell file [%s] not found"
-#, fuzzy
-msgid "Requested 3d raster map not found <%s>"
-#, fuzzy
-msgid "Could not open output map"
-#, fuzzy
-msgid "unable to close output map"
-#, fuzzy
-msgid "Could not close the 3d raster map"
-#, fuzzy
-msgid "Cannot create output map [%s]"
-#, fuzzy
-msgid "Database's name couldn't be read"
-#, fuzzy
-msgid "Cannot open vector points map <%s>"
-#, fuzzy
-msgid "Cannot create vector map <%s>"
-#, fuzzy
-msgid "Interpolation: No database connection for driver <%s> defined. Run db.connect"
-#, fuzzy
-msgid "Vector file [%s] not available in search list"
-#, fuzzy
-msgid "Cannot open database <%s>"
-#, fuzzy
-msgid "Cannot open table <%s>"
-#, fuzzy
-msgid "Could not find input map '%s'."
-#, fuzzy
-msgid "Could not find network input map '%s'."
-#, fuzzy
-msgid "error opening raster map [%s]."
-msgstr "Nome di mappa(e) raster esistente(i)"
-#, fuzzy
-msgid "Topology is not available"
-#, fuzzy
-msgid "Cannot describe table %s"
-#, fuzzy
-msgid "Patching file <%s@%s>"
-#, fuzzy
-msgid "[%d] files patched"
-msgstr "%d records aggiornati"
-#, fuzzy
-msgid "Column type  not supported"
-#, fuzzy
-msgid "Could not open vector map <%s>"
-#, fuzzy
-msgid "Database connection not defined for layer <%d>. Use v.db.connect first."
-#, fuzzy
-msgid "Can't create output map"
-#, fuzzy
-msgid "Could not close new 3d raster map"
-#, fuzzy
-msgid "%s: cellfile [%s] not found."
-#, fuzzy
-msgid "Unable to open cellfile [%s]."
-#, fuzzy
-msgid "Unable to open the temporary file."
-#, fuzzy
-msgid "Unable to open raster map [%s]."
-#, fuzzy
-msgid "Unable to find raster [%s]."
-#, fuzzy
-msgid "name for new raster map"
-#, fuzzy
-msgid "Output GRASS image file"
-#, fuzzy
-msgid "name for new vector map (omit for display to stdout)"
-#, fuzzy
-msgid "Input vector map"
-#, fuzzy
-msgid "%s: ERROR can't open tempfile"
-#, fuzzy
-msgid "unable to find raster map [%s]"
-#, fuzzy
-msgid "<%s> raster map not found"
-#, fuzzy
-msgid "<%s> unable to open raster map"
-#, fuzzy
-msgid "Cannot find vector map [%s]"
-#, fuzzy
-msgid "%s - can't open raster map"
-#, fuzzy
-msgid "Can't get row %d from raster map %s"
-#, fuzzy
-msgid "%s - raster map not found"
-msgid "string representing no data cell value"
-msgid "quiet"
-msgstr "silenzioso"
-#, fuzzy
-msgid "<%s> - illegal output file name"
-#, fuzzy
-msgid "%s: <%s> reference map not found"
-msgid "Base raster map"
-msgstr "Mappa raster di base"
-#, fuzzy
-msgid "%s: raster map not found"
-#, fuzzy
-msgid "Problem opening input file [%s]"
-#, fuzzy
-msgid "Problem opening output file [%s]"
-#, fuzzy
-msgid "can't write category file for <%s>"
-#, fuzzy
-msgid "%s: can't open tempfile"
-#, fuzzy
-msgid "Unable to read row %d in raster map [%s]"
-#, fuzzy
-msgid "Output verbosely"
-#, fuzzy
-msgid "Can't open raster map %s"
-#, fuzzy
-msgid "It could not be find input map <%s>"
-#, fuzzy
-msgid "It could not be found input map <%s>"
-#, fuzzy
-msgid "Cannot find input map <%s>"
-#, fuzzy
-msgid "Input vector map <%s> not found."
-#, fuzzy
-msgid "Category ranges: e.g. 1,3-8,13"
-#, fuzzy
-msgid "Writing attributes ...\n"
-#, fuzzy
-msgid "Could not open ascii file <%s>"
-#, fuzzy
-msgid "Could not open temp file <%s>"
-#, fuzzy
-msgid "List available formats and exit"
-msgstr "Visualizza i formati supportati ed esci"
-#, fuzzy
-msgid "Vector map <%s> not fould"
-#, fuzzy
-msgid "SVG output file"
-#, fuzzy
-msgid "Could not find vector '%s'"
-#, fuzzy
-msgid "Could not find vector map %s"
-#, fuzzy
-msgid "Unable to get row %d from <%s>"
-msgid "Raster output file"
-msgstr "File raster in output"
-#, fuzzy
-msgid "Writing raster map ... "
-msgid "Keep existing color table"
-msgstr "Mantieni la tabella colore esistente"
-msgid "List rules"
-msgstr "Mostra regole"
-#, fuzzy
-msgid " %d rows, %d cols."
-msgstr "%d raster%s, %d vettoriale%s\n"
-#, fuzzy
-msgid "%s in %s - can't read header file"
-#, fuzzy
-msgid "%s - unable to create category file"
-#, fuzzy
-msgid "Vector map with points for which to modify the attribute table"
-#, fuzzy
-msgid "Layer of the vector for which to modify the attribute table"
-msgstr "Nome della mappa vettoriale di punti della quale editare la tabella attributi"
-#, fuzzy
-msgid "Path to the input file"
-msgstr "Nome del filtro file"
-#, fuzzy
-msgid "Path to an output file"
-#, fuzzy
-msgid "Name of existing raster map to be displayed"
-msgid "driver name:"
-msgstr "nome del driver:"
-msgid "Database name:"
-msgstr "Nome del database:"
-#, fuzzy
-msgid "could not find input map <%s>"
-#, fuzzy
-msgid "unable to open raster map [%s]"
-#, fuzzy
-msgid "cannot get layer info for vector map"
-#, fuzzy
-msgid "cannot open database %s by driver %s"
-#, fuzzy
-msgid "column type not supported"
-msgstr "driver pg: colonna '%s', di tipo %d non supportata"
-#, fuzzy
-msgid "cannot select data from table"
-#, fuzzy
-msgid "cannot create table: %s"
-#, fuzzy
-msgid "cannot create index"
-#, fuzzy
-msgid "cannot grant privileges on table %s"
-#, fuzzy
-#, fuzzy
-msgid "Cannot find vector map"
-#, fuzzy
-msgid "Cannot find raster map"
-#, fuzzy
-msgid "Cannot open raster map"
-#, fuzzy
-msgid "Error while reading cell map."
-#, fuzzy
-msgid "Error while writing new cell map."
-msgstr "Errore nella scrittura della grid. Disco pieno?"
-#, fuzzy
-msgid "Error in opening output file <%s>"
-#, fuzzy
-msgid "Unable to find input cell map <%s>"
-#, fuzzy
-msgid "Error in opening input file <%s>"
-#, fuzzy
-msgid "Unable to open cell man <%s> for input.\n"
-#, fuzzy
-msgid "Unable to open cell map <%s> for output.\n"
-#, fuzzy
-msgid "Cannot find map %s"
-#, fuzzy
-msgid "Cannot open map %s"
-msgid "Name of predefined rules file"
-msgstr "Nome del file con le regole predefinite"
-#, fuzzy
-msgid "R:G:B value(s) out of range [0..255]: %d:%d:%d"
-msgstr "** attenzione: valore(i) R:G:B al di fuori dell'intervallo [0..255]: %d:%d:%d **\n"
-#, fuzzy
-msgid "R G B value(s) out of range [0..255]: %d %d %d"
-msgstr "** attenzione: valore(i) R G B al di fuori dell'intervallo [0..255]: %d %d %d **\n"
-#, fuzzy
-msgid "no such value"
-msgstr "** attenzione: non trovo il valore **\n"
-#, fuzzy
-msgid "%s:line %d:%s"
-msgstr "%s:linea %d:%s\n"
-#, fuzzy
-msgid "bad color specification"
-msgstr "** definizione errata del colore **\n"
-#, fuzzy
-msgid "%s - unknown color"
-msgstr "%s - colore sconosciuto\n"
-msgid "Valid colors are:\n"
-msgstr "I colori validi sono:\n"
-#, fuzzy
-msgid "Unable to find base map <%s>"
-#, fuzzy
-msgid "Unable to find cover map <%s>"
-#, fuzzy
-msgid "%s: unable to open raster map [%s]"
-#, fuzzy
-msgid "%s: unable to create raster map [%s]"
-#, fuzzy
-msgid "Unable to open database %s with driver %s"
-#, fuzzy
-msgid "%s: Unable to read raster map [%s]"
-#, fuzzy
-msgid "%s: unable to open raster map <%s>"
-#, fuzzy
-msgid "%s: Failed to read raster row %d"
-#, fuzzy
-msgid "Unable to find [%s]."
-#, fuzzy
-msgid "Unable to read cats table for %s"
-#, fuzzy
-msgid "Could not open raster <%s>"
-msgid "Font name (not supported interactively, see also -l flag) or path to TrueType font (including file name)"
-msgstr "Nome del tipo carattere (non supportato in maniera interattiva, in tal caso vedi il flag -l) oppure percorso del font TrueType (completo del nome del file)"
-#, fuzzy
-msgid "%s: o_open_file: raster map %s not found"
-#, fuzzy
-msgid "%s: o_open_file: could not open raster map %s in %s"
-#, fuzzy
-msgid "No record for category for [%d]"
-#, fuzzy
-msgid "Error reading ASCII file <%s>"
-#, fuzzy
-msgid "Error reading categories: <%s>"
-#, fuzzy
-msgid "category [%d]"
-msgstr ""
-"Layer: %d\n"
-"categoria: %d\n"
-#, fuzzy
-msgid "Could not find input vector '%s'"
-#, fuzzy
-msgid "Failed opening output vector map '%s'"
-#, fuzzy
-msgid "Error reading ascii file: [%s]"
-#, fuzzy
-msgid "%s: <%s> vector map not found"
-#, fuzzy
-msgid "Vector <%s> could not be open"
-#, fuzzy
-msgid "Raster <%s> could not be open."
-#, fuzzy
-msgid "Interpolation()"
-#, fuzzy
-msgid "Interpolation: nsply = %d"
-#, fuzzy
-msgid "%s: Dropping <s>"
-#, fuzzy
-msgid "Interpolation was a success!"
-#, fuzzy
-msgid "CrossCorrelation: %d points read in region. "
-#, fuzzy
-msgid "CrossCorrelation: It shouldn't take too long."
-#, fuzzy
-msgid "%s -- illegal output file name"
-#, fuzzy
-msgid "Sorry, with method '%s' you have to define an output map."
-#, fuzzy
-msgid "Writing "
-#, fuzzy
-msgid "Existing raster map name"
-#, fuzzy
-msgid "%s - can't read raster cellhd"
-#, fuzzy
-msgid "error reading cell data"
-#, fuzzy
-msgid "Done!"
-msgstr "Fatto.\n"
-#, fuzzy
-msgid "No line found."
-msgstr "Non ho trovato nulla.\n"
-#, fuzzy
-msgid "Nothing Found."
-#, fuzzy
-msgid "Could not open ascii file [%s]"
-msgid "vector map to be created"
-msgstr "file vettoriale da creare"
-#, fuzzy
-msgid "Conversion of [%s] to vector map ..."
-#, fuzzy
-msgid "EPSG code of projection to be created"
-msgid "must be even number of names"
-msgstr "deve essere un numero pari di nomi"
-msgid "ERROR: <%s> not found\n"
-msgstr "ERRORE: <%s> non trovato\n"
-msgid "ERROR: <%s> illegal name\n"
-msgstr "ERRORE: <%s> nome illegale\n"
-#, fuzzy
-msgid "Cannot open toolbox: %s"
-#, fuzzy
-msgid "Cannot open toolbox."
-#, fuzzy
-msgid "Vector map(s) -- source for composite"
-#, fuzzy
-msgid "Name of output vector points map (if not specified, the program writes to standard output)"
-#, fuzzy
-msgid "Vector map '%s' not found"
-#, fuzzy
-msgid "vector, segment, curvature"
-msgstr "vettore da rimuovere"
-#, fuzzy
-msgid "More lines with category %d found"
-#, fuzzy
-msgid "%s\n"
-msgstr "%s Sposta\n"
-#, fuzzy
-msgid "Raster '%s' not found"
-#, fuzzy
-msgid "Cold not get raster row"
-#, fuzzy
-msgid "ILLEGAL Resolution!"
-msgstr "Risoluzione"
-#, fuzzy
-msgid "Error opening raster map %s"
-#, fuzzy
-msgid "Copy raster map <%s> into the memory"
-#, fuzzy
-msgid "Query layer"
-#, fuzzy
-msgid "Query column name"
-#, fuzzy
-msgid "Enter imagery group to be registered"
-#, fuzzy
-msgid "output layer name"
-msgid "L: from  M: to R: quit\n"
-msgstr "L: da  M: a R: esci\n"
-msgid ""
-"\n"
-"Where %s is one of:\n"
-msgstr ""
-"\n"
-"Dove %s è uno di:\n"
-#, fuzzy
-msgid "%s: - no such database %s\n"
-#, fuzzy
-msgid "Input aspect file"
-#, fuzzy
-msgid "Input barrier file"
-#, fuzzy
-msgid "Quiet operation"
-msgstr "%s Esce dal menu\n"
-#, fuzzy
-msgid "datetime, datetime1/datetime2, or none"
-msgstr "nessuno"
-#, fuzzy
-msgid ""
-"\n"
-"Done\n"
-msgstr "Fatto\n"
-#, fuzzy
-msgid "Open vector 3d raster map %s"
-#, fuzzy
-msgid "Open 3d raster map %s"
-#, fuzzy
-msgid "Vector import complete"
-#, fuzzy
-msgid "Unable to create raster map for [%s]"
-msgid "Done\n"
-msgstr "Fatto\n"
-#, fuzzy
-msgid "Open Raster file %s in Mapset %s"
-#, fuzzy
-msgid "Open 3d raster map %s\n"
-#, fuzzy
-msgid "Open elev raster map %s\n"
-#, fuzzy
-msgid "Could not open map %s\n"
-msgid "Bin raster map to be imported"
-msgstr "Il file raster bin è stato importato"
-msgid "Region size is lower than minreg, nothing displayed.\n"
-msgstr "La dimensione della regione è inferiore rispetto al valore di minreg, non verrà visualizzato nulla.\n"
-msgid "Region size is greater than maxreg, nothing displayed.\n"
-msgstr "La dimensione della regione è superiore rispetto al valore di maxreg, non verrà visualizzato nulla.\n"
-#, fuzzy
-msgid "Makes 3D trees from input point vector map"
-#, fuzzy
-msgid "Name of the column with tree crown width"
-#, fuzzy
-msgid "Cannot select attributes for point #%d"
-msgid "%s Quit\n"
-msgstr "%s Esce\n"
-msgid "Draw geographic grid"
-msgstr "Disegna griglia geografica"
-#, fuzzy
-msgid "Quiet mode"
-#, fuzzy
-msgid "%s[%d]: No raster map specified."
-#, fuzzy
-msgid "done."
-msgstr "Fatto.\n"
-#, fuzzy
-msgid "name for new binary vector map (omit for display to stdout)"
-#, fuzzy
-msgid "Name for G3d raster map"
-#, fuzzy
-msgid "No output maps"
-#, fuzzy
-msgid "Wrong rgb map values! Values should in between 0 and 255!\n"
-msgstr "Valori della mappa g3d errati! I valori devono essere compresi tra 0 e 255!\n"
-#, fuzzy
-msgid "unable to open new L map layer."
-#, fuzzy
-msgid "unable to open new S map layer."
-#, fuzzy
-msgid "Do not export long colortable"
-#, fuzzy
-msgid "Vector map for which to edit attribute table"
-#, fuzzy
-msgid "Cannot make stat of %s configuration file"
-#, fuzzy
-msgid "Illegal configuration file"
-#, fuzzy
-msgid "vector, query"
-#, fuzzy
-msgid "Computing row %d of covariance matrix..."
-#, fuzzy
-msgid "Converting %s..."
-msgid "New LOCATION name (not location path)"
-msgstr "Nome della nuova LOCATION (non il percorso della location)"
-msgid "New GISDBASE (full path to the directory where the new location is)"
-msgstr "Nuovo GISDBASE (percorso intero della directory dove la nuova location è situata)"
-#, fuzzy
-msgid "Name for output file (do not add extension)"
-#, fuzzy
-msgid "Width and height of output image"
-msgstr "Spessore dell'evidenziazione"
-msgid "Surface"
-msgstr "Superficie"
-#, fuzzy
-msgid "Volume"
-msgstr "colonne: %d"
-#, fuzzy
-msgid "Layer where to add column"
-#, fuzzy
-msgid "Unable to read symbol, unable todisplay points"
-msgid "Raster value"
-msgstr "Valore del raster"
-msgid "Exporting %i points/lines..."
-msgstr "Esportando %i punti/linee..."
-#, fuzzy
-msgid "Import Mapgen or Matlab-ASCII vector maps into GRASS."
-msgstr "Importa mappe vettoriali Mapgen o Matlab-ASCII in GRASS"
-msgid "Raster File Series to MPEG Conversion Program."
-msgstr "Programma di conversione per serie di file raster in MPEG"
-msgid "Calculates linear regression from two raster maps: y = a + b*x"
-msgstr "Calcola la regressione lineare per due raster: y = a + b*x"
-msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)"
-msgstr "Simulazione del trasporto e dell'erosione/deposizione di sedimenti usando il metodo path sampling (SIMWE)"
-msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)"
-msgstr "Simulazione del ruscellamento superficiale usando il metodo path sampling (SIMWE)"
-#, fuzzy
-msgid ""
-"\n"
-"ERROR: Required parameter <%s> not set:\n"
-"    (%s).\n"
-msgstr ""
-"\n"
-"ERRORE: Il parametro richiesto <%s> non è stato impostato:\n"
-"    (%s).\n"
-#, fuzzy
-msgid "Band to select"
-msgstr "Nessun monitor selezionato"
-#~ msgid "Input grid3 filename"
-#~ msgstr "Nome del file grid3 di input"
-#~ msgid "Grid3 <%s> not found %s"
-#~ msgstr "Grid3 <%s> non trovato %s"
-#~ msgid "Print raster map resolution (NS-res, EW-res) only"
-#~ msgstr "Stampa solo la risoluzione della mappa raster (NS-ris, EO-ris)"
-#~ msgid "Print raster map type only"
-#~ msgstr "Stampa solo il tipo di mappa raster"
-#~ msgid "Print map region only"
-#~ msgstr "Stampa solo la regione della mappa"
-#~ msgid "Print map title only"
-#~ msgstr "Stampa solo il titolo della mappa"
-#~ msgid "Reading coordinates from file."
-#~ msgstr "Lettura delle coordinate dal file"
-#~ msgid "Unable to open file with coordinates <%s>"
-#~ msgstr "Non è possibile trovare il file con le coordinate <%s>"
-#~ msgid "Error reading coordinates file"
-#~ msgstr "Errore nella lettura del file delle coordinate"
-#~ msgid "Number of points that have been entered [%d]"
-#~ msgstr "Numero di punti che sono stati inseriti [%d]"
-#~ msgid "Error creating transformation"
-#~ msgstr "Errore nel creare la trasformazione"
-#~ msgid "Column name (will be updated by raster values)"
-#~ msgstr "Nome della colonna (che sarà aggiornata con i valori raster)"
-#~ msgid "DBMI-MySQL driver error:\n"
-#~ msgstr "Errore del driver DBMI-MySQL:\n"
-#~ msgid "Cannot select data: \n"
-#~ msgstr "Non riesco a seleziona i dati:\n"
-#~ msgid "Computing means for band %d..."
-#~ msgstr "Calcolo delle medie per la banda %d in corso..."
-#~ msgid "Unable to allocate memory for raster row"
-#~ msgstr "Impossibile allocare memoria per la riga raster"
-#~ msgid "Transforming <%s>..."
-#~ msgstr "Trasformazione di <%s> in corso..."
-#~ msgid "Surface area estimation for rasters."
-#~ msgstr "Stima della superfice per raster"
-#~ msgid "Raster file for surface"
-#~ msgstr "File raster per superficie"
-#~ msgid "Writing buffers..."
-#~ msgstr "Scrittura dei buffer in corso ..."
-#~ msgid "ASCII file to be converted to binary vector map"
-#~ msgstr "File ASCII da convertire in una mappa vettoriale binaria"
-#~ msgid "If not given (or \"-\") reads from standard input"
-#~ msgstr "Se non è dato (o \"-\") legge dallo standard input"
-#~ msgid "Name of arc forward/both direction(s) cost column"
-#~ msgstr "Colonna costo direzione avanti/entrambe per gli archi"
-#~ msgid "Name of arc backward direction cost column"
-#~ msgstr "Colonna costo direzione indietro per gli archi"
-#, fuzzy
-#~ msgid "Layer number or name with route paths or -1"
-#~ msgstr "Numero del layer (su cui scrivere)"
-#~ msgid "Layer %d - no table"
-#~ msgstr "Layer %d - nessuna tabella"
-#~ msgid "Layer %d - unable to copy table"
-#~ msgstr "Layer %d - impossibile copiare la tabella"
-#~ msgid "Name of arc forward/both direction(s) capacity column"
-#~ msgstr "Nome della colonna capacità direzione avanti/entrambe per gli archi"
-#~ msgid "Name of arc backward direction capacity column"
-#~ msgstr "Nome della colonna capacità direzione indietro per gli archi"
-#~ msgid "Source layer number or name"
-#~ msgstr "Numero del layer delle sorgenti o nome"
-#~ msgid "Sink layer number or name"
-#~ msgstr "Numero del layer dei pozzi o nome"
-#~ msgid "Name of Arc cost column"
-#~ msgstr "Nome della colonna dei costi per gli archi"
-#~ msgid "From layer number or name"
-#~ msgstr "Numero o nome del layer 'from'"
-#~ msgid "To layer number or name"
-#~ msgstr "Numero o nome del layer 'to'"
-#~ msgid "Name of node capacity column"
-#~ msgstr "Nome della colonna capacità per i nodi"
-#~ msgid "Set1 layer number or name"
-#~ msgstr "Numero del layer o nome di set1"
-#~ msgid "Set2 layer number or name"
-#~ msgstr "Numero del layer o nome di set2"
-#~ msgid "Can't read vector map"
-#~ msgstr "Impossibile leggere la mappa vettoriale"
-#~ msgid "pg driver: column '%s', type %d  is not supported"
-#~ msgstr "driver pg: colonna '%s', di tipo %d non supportata"
-#~ msgid "Type of color table"
-#~ msgstr "Tipo di tavola dei colori"
-#~ msgid "Name for output raster map not specified"
-#~ msgstr "Nome per la mappa raster di output non specificato"
-#, fuzzy
-#~ msgid "Requested g3d map <%s> not found"
-#~ msgstr "La mappa g3d richiesta <%s> non è stata trovata"
-#, fuzzy
-#~ msgid "Error opening g3d map <%s>"
-#~ msgstr "Errore nell'apertura della mappa g3d <%s>"
-#~ msgid "\"color\", \"rules\", and \"raster\" options are mutually exclusive"
-#~ msgstr "Le opzioni \"color\", \"rules\", e \"raster\" sono mutualmente esclusive"
-#~ msgid "-g and -a flags are mutually exclusive"
-#~ msgstr "I flag -g e -a sono mutualmente esclusivi"
-#~ msgid "Contrast"
-#~ msgstr "Contrasto"
-#~ msgid "Variance"
-#~ msgstr "Varianza"
-#~ msgid "Raster file to be imported"
-#~ msgstr "Il file raster da importare"
-#, fuzzy
-#~ msgid "Write the result to g3d map <%s>"
-#~ msgstr "Scrive il risultato nella mappa g3d"
-#~ msgid "Requested 3d raster map not found"
-#~ msgstr "File g3d richiesto non trovato"
-#, fuzzy
-#~ msgid "Error closing new ASCII file"
-#~ msgstr "Errore nella chiusura del nuovo file ASCII"
-#~ msgid "modifyNull: error opening map"
-#~ msgstr "modifyNull: errore nell'apertura della mappa"
-#~ msgid "modifyNull: error closing map"
-#~ msgstr "Errore nell'istruzione modifyNull. Chiudo la mappa"
-#~ msgid "Adding rule: %lf - %lf"
-#~ msgstr "Aggiunta della regola: %lf - %lf"
-#~ msgid "makeMask: error opening map."
-#~ msgstr "makeMask: errore nell'apertura della mappa"
-#~ msgid "makeMask: error opening g3d mask file"
-#~ msgstr "makeMask. Errore nell'apertura del file mask g3d"
-#~ msgid "makeMask: error closing g3d mask file"
-#~ msgstr "makeMask. Errore nel chiudere il file mask g3d"
-#~ msgid "makeMask: error closing map"
-#~ msgstr "makeMask. Errore nella chiusura della mappa"
-#, fuzzy
-#~ msgid "Requested 3d raster map <%s> not found"
-#~ msgstr "Raster 3d richiesto <%s> non trovato"
-#, fuzzy
-#~ msgid "Requested g3d RGB map <%s> not found"
-#~ msgstr "Raster g3d RGB richiesto <%s> non trovato"
-#, fuzzy
-#~ msgid "Requested g3d vector map <%s> not found"
-#~ msgstr "Mappa vettoriale g3d <%s> non trovata"
-#, fuzzy
-#~ msgid "Open rgb 3d raster map %s"
-#~ msgstr "Apre la mappa raster 3d rgb %s"
-#, fuzzy
-#~ msgid "Error closing g3d rgb map."
-#~ msgstr "Errore nella chiusura della mappa rgb g3d."
-#, fuzzy
-#~ msgid "Error closing g3d vector map."
-#~ msgstr "Errore nella chiusura della mappa vettoriale g3d."
-#~ msgid "The 2d and 3d region settings are different. The g3d settings are used to adjust the 2d region."
-#~ msgstr "La regione 2D e 3D hanno impostazioni differenti. Saranno usate le impostazioni g3d per aggiustare la regione 2D"
-#, fuzzy
-#~ msgid "unable to close input 3d raster map"
-#~ msgstr "impossibile chiudere la mappa raster 3d di input"
-#~ msgid "write_vtk_rgb_data: writing rgb data"
-#~ msgstr "write_vtk_rgb_data: scrittura in corso dei dati rgb"
-#, fuzzy
-#~ msgid "Error closing new 3d raster map"
-#~ msgstr "Errore nella chiusura della nuova mappa raster 3d"
-#, fuzzy
-#~ msgid "Error closing ascii file"
-#~ msgstr "Errore nella chiusura del file ascii"
-#~ msgid "Error: couldn't create %s"
-#~ msgstr "Errore: non riesco a creare %s"
-#~ msgid "Error while writing grid. Disk full?"
-#~ msgstr "Errore nella scrittura della grid. Disco pieno?"
-#~ msgid "Converts co-ordinate system descriptions (i.e. projection information) between various formats (including GRASS format)."
-#~ msgstr "Converte le descrizioni del sistema di coordinate (es. informazioni sulla proiezione) utilizzando diversi formati (incluso quello di GRASS)."
-#~ msgid "Create/Edit"
-#~ msgstr "Crea/Modifica"
-#~ msgid "Create new projection files (modifies current location unless 'location' option specified)"
-#~ msgstr "Crea un nuovo file contenente le informazioni sulla proiezione (modifica la location attuale a meno che l'opzione 'location' venga specificata)"
-#~ msgid "Location %s created!"
-#~ msgstr "Location %s creata!"
-#, fuzzy
-#~ msgid "Print mapset names"
-#~ msgstr "Stampa i nomi dei mapset"
-#~ msgid "Force remove"
-#~ msgstr "Forza la rimozione"
-#~ msgid "Layer: %s"
-#~ msgstr "Layer: %s"
-#~ msgid "Cannot calculate centroid"
-#~ msgstr "Non posso calcolare i centroidi"
-#~ msgid "Input type point, line or area"
-#~ msgstr "Tipo di input punto, linea o area"
-#~ msgid "Name for output vector map"
-#~ msgstr "Nome della mappa vettoriale di output"
-#~ msgid "Name for output raster map prefix (e.g. 'brov')"
-#~ msgstr "Prefisso per il raster di output (e.g. 'brov')"
-#~ msgid "raster input map"
-#~ msgstr "Raster in input"
-#~ msgid "Vector map to modify"
-#~ msgstr "Vettoriale da modificare"
-#~ msgid "Vector map to be queried"
-#~ msgstr "Mappa vettoriale da interrogare"
-#~ msgid "Column to be queried"
-#~ msgstr "Colonna da interrogare"
-#~ msgid "Name of input vector map"
-#~ msgstr "Nome della mappa vettoriale di input"
-#~ msgid "Column to update"
-#~ msgstr "Colonna da aggiornare"
-#~ msgid "Column to query"
-#~ msgid "Old schema"
-#~ msgstr "Vecchio schema"
-#~ msgid "New schema"
-#~ msgstr "Nuovo schema"
-#~ msgid "GRASS table name"
-#~ msgstr "Nome tabella di GRASS"
-#~ msgid "Field separator"
-#~ msgstr "Separatore di campo"
-#~ msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
-#~ msgstr "Una singola mappa vettoriale può essere connessa a più tabelle di un database. Questo numero determina quale tabella viene utilizzata."
-#~ msgid "Vector map from which to remove attribute table"
-#~ msgstr "Mappa vettoriale dalla quale rimuovere la tabella degli attributi"
-#~ msgid "Name of existing attribute table (default: vector map name)"
-#~ msgstr "Nome della tabella degli attributi esistente (predefinito: nome della mappa vettoriale)"
-#~ msgid "Name of data table"
-#~ msgstr "Nome della tabella dei dati"
-#~ msgid "Database driver"
-#~ msgstr "Driver del database"
-#, fuzzy
-#~ msgid "Cannot open file [%s] in mapset [%s]"
-#~ msgstr "Impossibile aprire il file label <%s> nel mapset <%s>"
-#, fuzzy
-#~ msgid "Cannot create file <%s> in mapset <%s>"
-#, fuzzy
-#~ msgid "basemap"
-#~ msgstr "Rimuove le mappe di base"
-#, fuzzy
-#~ msgid "method"
-#~ msgstr "Metodo sconosciuto"
-#~ msgid "Unable to close output map"
-#~ msgstr "Non è possibile chiudere la mappa di output"
-#~ msgid "Could not write raster row"
-#~ msgstr "Non è possibile scrivere la riga del raster"
-#~ msgid "Elevation map not found"
-#~ msgstr "Mappa di elevazione non trovata"
-#~ msgid "Unable to open elevation map"
-#~ msgstr "Impossibile aprire la mappa di elevazione"
-#~ msgid "Illegal output file name"
-#~ msgstr "Nome del file di output non valido"
-#~ msgid "Unable to close elevation map"
-#~ msgstr "Impossibile chiudere la mappa di elevazione"
-#~ msgid "Unable to write raster row"
-#~ msgid "Could not open map %s"
-#~ msgstr "Impossibile aprire la mappa %s"
-#, fuzzy
-#~ msgid "Could not get bottom raster row \n"
-#~ msgstr "Impossibile acquisire la riga del raster inferiore \n"
-#~ msgid "raster3d, voxel, statistics"
-#~ msgstr "raster3d, voxel, statistica"
-#~ msgid "raster, export"
-#~ msgstr "raster, esportazione"
-#~ msgid "Exports a GRASS raster map to a binary array."
-#~ msgstr "Esporta un raster GRASS in un array binario"
-#~ msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
-#~ msgstr "Esporta una mappa raster GRASS in un file GRIDATB.FOR (TOPMODEL)"
-#~ msgid "Overwrite output map file"
-#~ msgstr "Sovrascrive file mappa in output"
-#~ msgid "raster, statistics"
-#~ msgstr "raster, statistiche"
-#~ msgid "Base raster map <%s> not found"
-#~ msgstr "Mappa raster di base <%s> non trovata"
-#~ msgid "Base map and output map <%s> must be different"
-#~ msgstr "La mappa di origine <%s> e quella di output devono essere differenti"
-#~ msgid "Unable to read category labels of raster map <%s>"
-#~ msgstr "Impossibile leggere le etichette di categoria della mappa raster <%s>"
-#~ msgid "raster, color transformation"
-#~ msgstr "raster, trasformazione del colore"
-#~ msgid "Error reading 'hue' map"
-#~ msgstr "Errore nella lettura della mappa 'tonalità'"
-#~ msgid "Error reading 'intensity' map"
-#~ msgstr "Errore nella lettura della mappa 'intensità'"
-#~ msgid "Error reading 'saturation' map"
-#~ msgstr "Errore nella lettura della mappa 'saturazione'"
-#~ msgid "The '-v' flag is superseded and will be removed in future. Please use '--verbose' instead."
-#~ msgstr "Il flag '-v' è superato e in futuro verrà rimosso. Al suo posto usare '--verbose'."
-#~ msgid "raster, import"
-#~ msgstr "raster, importazione"
-#~ msgid "Can't create raster map <%s>"
-#~ msgstr "Impossibile creare la mappa raster <%s>"
-#~ msgid "raster, DEM, contours, vector"
-#~ msgstr "raster, DEM, curve di livello, vettoriale"
-#~ msgid "Run quietly"
-#~ msgstr "Avvia in maniera silenziosa"
-#~ msgid "The '-q' and '-n' flag is superseded and will be removed in future. Please use '--quiet' instead."
-#~ msgstr "I flag '-q' and '-n sono superati e in futuro verranno rimossi. Al loro posto usare '--quiet'."
-#~ msgid "Converts a raster map layer into a height-field file for POVRAY."
-#~ msgstr "Converte una mappa raster in un file height field per POVRAY"
-#~ msgid "raster, hydrology"
-#~ msgstr "raster, idrologia"
-#~ msgid "raster, metadata"
-#~ msgstr "raster, metadati"
-#~ msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead."
-#~ msgstr "Il flag '-q' è superato e in futuro verrà rimosso. Al suo posto usare '--quiet'."
-#~ msgid "%s: [%s] not found"
-#~ msgstr "%s: [%s] non trovato"
-#~ msgid "raster, map algebra"
-#~ msgstr "raster, map algebra"
-#~ msgid "Name of filter file"
-#~ msgstr "Nome del file filtro"
-#~ msgid "Cannot read raster row %d"
-#~ msgstr "Impossibile leggere la riga %d del raster"
-#~ msgid "Cannot open raster map <%s>"
-#~ msgstr "Impossibile aprire la mappa raster <%s>"
-#~ msgid "Converts a raster map layer into an ASCII text file."
-#~ msgstr "Converte un raster in un file di testo ASCII"
-#~ msgid "raster, export, png"
-#~ msgstr "raster, esportazione, png"
-#~ msgid "Unable to read raster map row %d"
-#~ msgstr "Impossibile leggere la riga %d della mappa raster"
-#~ msgid "raster, cost surface, cumulative costs"
-#~ msgstr "raster, superficie di costo, costi cumulativi"
-#~ msgid "Name of raster map to contain results"
-#~ msgstr "Nome della mappa raster che contiene i risultati"
-#~ msgid "Unable to read current window parameters"
-#~ msgstr "Non è possibile leggere i parametri correnti per la finestra"
-#~ msgid "Nseg is %d"
-#~ msgstr "Nseg è %d"
-#~ msgid "Null cells excluded from cost evaluation."
-#~ msgstr "Le celle nulle sono escluse dal calcolo del costo"
-#~ msgid "Input null cell will be retained into output map"
-#~ msgstr "Le celle nulle di input saranno ritornate nella mappa di output"
-#~ msgid "Unable to find starting vector <%s> "
-#~ msgstr "Non è possibile trovare il vettore di partenza <%s>"
-#~ msgid "Unable to find stop vector <%s>"
-#~ msgstr "Non è possibile trovare il vettore di arrivo <%s>"
-#~ msgid "Map with different projection"
-#~ msgstr "Mappa con proiezione differente"
-#~ msgid "DTM_Source map is: Integer cell type"
-#~ msgstr "La mappa DTM_Source è: celle intere"
-#~ msgid "DTM_Source map is: Floating point (float) cell type"
-#~ msgstr "La mappa DTM_Source è: celle floating point (float)"
-#~ msgid "DTM_Source map is: Floating point (double) cell type"
-#~ msgstr "La mappa DTM_Source è: celle floating point (double)"
-#~ msgid " %d rows, %d cols"
-#~ msgstr "%d righe, %d colonne"
-#~ msgid "COST_Source map is: Integer cell type"
-#~ msgstr "La mappa COST_Source è: celle intere"
-#~ msgid "COST_Source map is: Floating point (float) cell type"
-#~ msgstr "La mappa COST_Source è: celle floating point (float)"
-#~ msgid "COST_Source map is: Floating point (double) cell type"
-#~ msgstr "La mappa COST_Source è: celle floating point (double)"
-#~ msgid "Output map is: Integer cell type"
-#~ msgstr "La mappa di output è: cella di tipo a valori interi"
-#~ msgid "Output map is: Floating point (float) cell type"
-#~ msgstr "La mappa di output è: cella di tipo con valori a virgola mobile (float)"
-#~ msgid "Output map is: Floating point (double) cell type"
-#~ msgstr "La mappa di output è: cella di tipo con valori a virgola mobile con precisione doppia (double)"
-#~ msgid " EW resolution %s (%lf)"
-#~ msgstr " Risoluzione E-O %s (%lf)"
-#~ msgid " NS resolution %s (%lf)"
-#~ msgstr "Risoluzione N-S %s (%lf)"
-#~ msgid "Unable to read raster map <%s> row %d"
-#~ msgstr "Non è possibile leggere la mappa raster <%s> riga %d"
-#~ msgid "Initializing output "
-#~ msgstr "Inizializzando l'output"
-#~ msgid "Unable to allocate memory for segment fbuff == NULL"
-#~ msgstr "Impossibile allocare memoria per il segmento fbuff == NULL"
-#~ msgid "Raster output map <%s> not found (no start_points given)"
-#~ msgstr "Mappa raster di output <%s> non trovata (nessun punto di partenza definito)"
-#~ msgid "Memory allocation error on reading start points from raster map %s"
-#~ msgstr "Errore nell'allocazione della memoria nel leggere i punti di partenza dalla mappa raster %s"
-#~ msgid "End of map!"
-#~ msgstr "Fine della mappa!"
-# copierà
-#, fuzzy
-#~ msgid "Will copy input map null values into output map"
-#~ msgstr "Copia i valori null della mappa in input sulla mappa di output"
-#~ msgid ""
-#~ "Integer cell type.\n"
-#~ "Writing..."
-#~ msgstr ""
-#~ "Celle intere.\n"
-#~ "Sto scrivendo..."
-#~ msgid ""
-#~ "Float cell type.\n"
-#~ "Writing..."
-#~ msgstr ""
-#~ "Celle float.\n"
-#~ msgid ""
-#~ "Double cell type.\n"
-#~ "Writing..."
-#~ msgstr ""
-#~ "Celle double.\n"
-#~ msgid "raster, sun energy"
-#~ msgstr "raster, energia solare"
-#~ msgid "Name of the latitudes input raster map [decimal degrees]"
-#~ msgstr "Nome della mappa raster di input delle latitudini [gradi decimali]"
-#~ msgid "A single value of latitude [decimal degrees]"
-#~ msgstr "Un singolo valore di latitudine [gradi decimali]"
-#, fuzzy
-#~ msgid "Name of the longitude input raster map [decimal degrees]"
-#~ msgstr "Nome della mappa raster di input delle longitudini [gradi decimali]"
-#~ msgid "Import GDAL supported raster file into a binary raster map layer."
-#~ msgstr "Importa un file raster supportato da GDAL in un layer raster binario"
-#~ msgid "Required"
-#~ msgstr "Richiesto"
-#~ msgid "Import a binary raster file into a GRASS raster map."
-#~ msgstr "Importa un file raster binario in una mappa raster GRASS."
-#~ msgid "raster, rescale"
-#~ msgstr "raster, riscalatura"
-#~ msgid ""
-#~ "\n"
-#~ "Hit RETURN to continue -->"
-#~ msgstr ""
-#~ "\n"
-#~ "Premere INVIO per continuare -->"
-#~ msgid "Update the statistics (histogram, range) for [%s]? "
-#~ msgstr "Aggiorna le statistiche (istogramma, range) per [%s]?"
-#~ msgid "Not enough room in history file"
-#~ msgstr "Spazio insufficiente nel file della cronologia"
-#~ msgid ""
-#~ "\n"
-#~ "NOTE: [%s] is a reclass of [%s in %s]"
-#~ msgstr ""
-#~ "\n"
-#~ "NOTE: [%s] è una riclassificazione di [%s in %s]"
-#~ msgid "Edit the category file for [%s]? "
-#~ msgstr "Modificare il file delle categorie per [%s]?"
-#~ msgid "Create/Update the color table for [%s]? "
-#~ msgstr "Crea/Aggiorna la tabella dei colori per [%s]?"
-#~ msgid "Edit the history file for [%s]? "
-#~ msgstr "Modificare il file della cronologia per [%s]? "
-#~ msgid ""
-#~ "\n"
-#~ "Do you want to create/reset the null file for [%s] so that null cell values are considered valid data? "
-#~ msgstr ""
-#~ "\n"
-#~ "Si vuole creare/ricreare il file dei nulli per [%s] affinché i valori null siano considerati dati validi?"
-#~ msgid "Error writing null row [%d]."
-#~ msgstr "Errore scrivendo una riga nulla [%d]."
-#~ msgid ""
-#~ "\n"
-#~ "Do you want to delete the null file for [%s]\n"
-#~ "(all zero cells will then be considered no data)? "
-#~ msgstr ""
-#~ "\n"
-#~ "Vuoi eliminare il file dei null per [%s]\n"
-#~ "(tutte le celle zero saranno considerate no data)?"
-#~ msgid "Please enter the following information for [%s]:"
-#~ msgstr "Inserire le seguenti informazioni per [%s]:"
-#~ msgid "        Number of rows"
-#~ msgstr "        Numero di righe"
-#~ msgid "        Number of cols"
-#~ msgstr "        Numero di colonne"
-#~ msgid "        Number of bytes per cell"
-#~ msgstr "        Numero di byte per cella"
-#~ msgid "        Floating point map"
-#~ msgstr "        Mappa floating point"
-#~ msgid "rows * cols * bytes per cell must be same as file size (%lu)"
-#~ msgstr "righe * colonne * bytes per cella devone essere gli stessi della dimensione del file (%lu)"
-#~ msgid "** Negative values not allowed!"
-#~ msgstr "** Valori negativi non permessi!"
-#~ msgid "** Positive values only please!"
-#~ msgstr "** Solo valori positivi"
-#~ msgid "Edit header for [%s]\n"
-#~ msgstr "Modifica l'intestazione per [%s]\n"
-#~ msgid "[%s] cannot be found!"
-#~ msgstr "[%s] non può essere trovato"
-#~ msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
-#~ msgstr "[%s] è una riclassificazione di [%s] - non è possibile editare l'intestazione! Eseguire supporto su [%s]"
-#~ msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
-#~ msgstr "[%s] è una riclassificazione di [%s in %s] - l'intestazione non può essere editata!"
-#~ msgid "Cannot open raster map [%s]!"
-#~ msgstr "Impossibile aprire la mapa raster [%s]!"
-#~ msgid "Raster file [%s] is empty."
-#~ msgstr "Il file raster [%s] è vuoto."
-#~ msgid "Error reading raster map [%s]."
-#~ msgstr "Errore nella lettura della mappa raster [%s]."
-#~ msgid "cellhd compression: %d\n"
-#~ msgstr "compressione delle celle: %d\n"
-#~ msgid "[%s] appears to be compressed. Is it? "
-#~ msgstr "[%s] sembra essere compressa. È così?"
-#~ msgid "Please indicate the type of compression:\n"
-#~ msgstr "Indicare la tipologia di compressione:\n"
-#~ msgid "The header for [%s] says the file is not compressed. "
-#~ msgstr "L'intestazione per [%s] dice the il file non è compresso"
-#~ msgid "The file appears to be compressed.\n"
-#~ msgstr "Il file appare essere compresso.\n"
-#~ msgid "The header for [%s] says the file is compressed. "
-#~ msgstr "L'intestazione per [%s] dice che il file è compresso"
-#~ msgid "The file does NOT appear to be compressed.\n"
-#~ msgstr "Il file non sembra essere compresso.\n"
-#~ msgid "Unable to write header for [%s]."
-#~ msgstr "Impossibile scrivere l'intestazione per [%s]"
-#~ msgid "Header for raster map [%s] updated."
-#~ msgstr "Intestazione per il raster [%s] aggiornato."
-#~ msgid ""
-#~ "\n"
-#~ "hit RETURN to continue -->"
-#~ msgstr ""
-#~ "\n"
-#~ msgid "Color table for <%s> updated"
-#~ msgstr "Tavola dei colori per <%s> aggiornata"
-#~ msgid "Which raster map needs an updated history? "
-#~ msgstr "Quale raster necessita un'aggiornamento della storia?"
-#~ msgid "Raster file [%s] not found. Exiting."
-#~ msgstr "File raster [%s] non trovato. Uscita."
-#~ msgid "History file for [%s] updated."
-#~ msgstr "File della storia per [%s] aggiornato."
-#~ msgid "History file for [%s] not updated."
-#~ msgstr "File della cronologia per [%s] non aggiornato."
-#~ msgid "Which vector map needs updated categories?"
-#~ msgstr "Quale vettoriale necessità un aggiornamento delle categorie?"
-#~ msgid "Which raster map needs updated categories?"
-#~ msgstr "Quale raster necessità un aggiornamento delle categorie?"
-#~ msgid "Category file for <%s> not updated"
-#~ msgstr "File delle categorie per <%s> non aggiornato"
-#~ msgid "Category file for <%s> updated"
-#~ msgstr "File delle categorie per <%s> aggiornato"
-#~ msgid "Failed writing output raster map row %d"
-#~ msgstr "Scrittura del raster di output non riuscita alla riga %d"
-#~ msgid "Name of terrain raster map (DEM)"
-#~ msgstr "Nome della mappa raster del terreno (DEM)"
-#~ msgid "Name for output raster map with lake"
-#~ msgstr "Nome per la mappa raster di output con il lago"
-#~ msgid "raster, interpolation"
-#~ msgstr "raster, interpolazione"
-#~ msgid "Interpolating raster map <%s> (%d rows)... "
-#~ msgstr "Interpolazione della mappa raster <%s> (%d righe) in corso..."
-#~ msgid "Cannot read row"
-#~ msgstr "Impossibile leggere la riga"
-#~ msgid "raster, export, color table"
-#~ msgstr "raster, esportazione, tabella dei colori"
-# verificare
-#~ msgid "Unable to read raster <map %d of %d> row %d"
-#~ msgstr "Non è possibile leggere la mappa raster <mappa %d di %d> riga %d"
-#~ msgid "raster, map management"
-#~ msgstr "raster, gestione delle mappe"
-#~ msgid "raster, geometry"
-#~ msgstr "raster, geometria"
-#~ msgid "time and insol_time are incompatible options"
-#~ msgstr "time e insol_time sono opzioni incompatibili"
-#~ msgid "elevin raster map <%s> not found"
-#~ msgstr "mappa raster elevin <%s> non trovata"
-#~ msgid "aspin raster map <%s> not found"
-#~ msgstr "mappa raster aspin <%s> non trovata"
-#~ msgid "slopein raster map <%s> not found"
-#~ msgstr "mappa raster slopein <%s> non trovata"
-#~ msgid "linkein raster map <%s> not found"
-#~ msgstr "mappa raster linkein <%s> non trovata"
-#~ msgid "albedo raster map <%s> not found"
-#~ msgstr "mappa raster albedo <%s> non trovata"
-#~ msgid "coefbh raster map <%s> not found"
-#~ msgstr "mappa raster coefbh <%s> non trovata"
-#~ msgid "coefdh raster map <%s> not found"
-#~ msgstr "mappa raster coefdh <%s> non trovata"
-#~ msgid "Unable to create raster map %s"
-#~ msgstr "Non è possibile creare la mappa raster %s"
-#~ msgid "RGB raster map <%s> not found"
-#~ msgstr "Mappa raster RGB <%s> non trovata"
-#~ msgid "Cannot create RGB data, please provide three maps [r,g,b]"
-#~ msgstr "Impossibile creare dati RGB, fornire tre mappe [r,g,b]"
-#~ msgid "Converts raster maps into the VTK-Ascii format"
-#~ msgstr "Converte un raster in formato VTK-Ascii"
-#~ msgid "Unable to read row %i\n"
-#~ msgstr "Non è possibile leggere la riga  %i\n"
-#~ msgid "raster, quantization"
-#~ msgstr "raster, quantizzazione"
-#~ msgid "No data"
-#~ msgstr "Nessun dato"
-#~ msgid "Unable to find row %d, col %d: %f"
-#~ msgstr "Non è possibile trovare la riga %d, la colonna %d: %f"
-#~ msgid "raster, resample"
-#~ msgstr "raster, ricampionamento"
-#~ msgid "Bilinear interpolation utility for raster map layers."
-#~ msgstr "Strumento per l'interpolazione bilineare per layer raster."
-#~ msgid "Specific input value to be assigned to the north and/or south poles for longitude-latitude grids"
-#~ msgstr "Specifica un valore di input da assegnare ai poli nord e/o sud per le griglie di longitudine-latitudine"
-#~ msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
-#~ msgstr "Questo modulo è deprecato. Al suo posto usare 'r.resamp.interp'."
-#~ msgid "Apply filter only to zero data values"
-#~ msgstr "Applica soltanto il filtro per i valori uguali a zero"
-#~ msgid "One or more input raster maps not found"
-#~ msgstr "Una o più mappe raster di input non è stata trovata"
-#~ msgid "Name of the elevation raster map [m]"
-#~ msgstr "Nome della mappa raster di elevazione [m]"
-#~ msgid "Name of the water depth raster map [m]"
-#~ msgstr "Nome della mappa raster delle altezze d'acqua [m]"
-#~ msgid "Name of the x-derivatives raster map [m/m]"
-#~ msgstr "Nome della mappa raster delle derivate rispetto a x [m/m]"
-#~ msgid "Name of the y-derivatives raster map [m/m]"
-#~ msgstr "Nome della mappa raster delle derivate rispetto a y [m/m]"
-#~ msgid "Name of the detachment capacity coefficient raster map [s/m]"
-#~ msgstr "Nome della mappa raster del coefficiente della capacità di distacco [s/m]"
-#~ msgid "Name of the transport capacity coefficient raster map [s]"
-#~ msgstr "Nome della mappa raster del coefficiente della capacità di trasporto [s]"
-#~ msgid "Name of the Mannings n raster map"
-#~ msgstr "Nome della mappa raster dei coefficienti n di Manning"
-#~ msgid "Name of the Mannings n value"
-#~ msgstr "Nome del valore del coefficiente n di Manning"
-#~ msgid "Output transport capacity raster map [kg/ms]"
-#~ msgstr "Mappa raster di output della capacità di trasporto [kg/ms]"
-#~ msgid "Output sediment concentration raster map [particle/m3]"
-#~ msgstr "Mappa raster di output della concentrazione di sedimenti [particelle/m3]"
-#~ msgid "Output sediment flux raster map [kg/ms]"
-#~ msgstr "Mappa raster di output del flusso dei sedimenti [kg/ms]"
-#~ msgid "Output erosion-deposition raster map [kg/m2s]"
-#~ msgstr "Mappa raster di output di erosione-deposizione [kg/m2s]"
-#~ msgid "raster, flow, hydrology"
-#~ msgstr "raster, flusso, idrologia"
-#~ msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
-#~ msgstr "Nome della mappa raster del tasso di pioggia eccedente (intensità di pioggia - velocità di infiltrazione) [mm/h]"
-#~ msgid "Name of the runoff infiltration rate raster map [mm/hr]"
-#~ msgstr "Nome della mappa raster della velocità di infiltrazione del deflusso superficiale [mm/h]"
-#~ msgid "Name of the flow controls raster map (permeability ratio 0-1)"
-#~ msgstr "Nome della mappa raster delle strutture per il controllo del flusso (coeff. di permeabilità 0-1)"
-#~ msgid "Output water depth raster map [m]"
-#~ msgstr "Mappa raster di output delle altezze d'acqua"
-#~ msgid "Output water discharge raster map [m3/s]"
-#~ msgstr "Mappa raster di output delle portate [m3/s]"
-#~ msgid "Output simulation error raster map [m]"
-#~ msgstr "Mappa raster di output degli errori di simulazione [m]"
-#~ msgid "Threshold water depth [m] (diffusion increases after this water depth is reached)"
-#~ msgstr "Altezza d'acqua di soglia [m] (la diffusione aumenta una volta raggiuntaquesta altezza)"
-#~ msgid "Unable to close input map"
-#~ msgstr "Non è possibile chiudere la mappa di input"
-#~ msgid "Could not get raster row from input map"
-#~ msgstr "Impossibile ottenere la riga raster per la mappa di input"
-#~ msgid "Could not get raster row from elev map"
-#~ msgstr "Impossibile ottenere la riga raster per la mappa di elevazione"
-#~ msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the currently defined region."
-#~ msgstr "Converte un raster GRASS in un'immagine PPM con una risoluzione dei pixel della region corrente"
-#~ msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
-#~ msgstr "Converte 3 raster GRASS (R,G,B) in un'immagine PPM con la risoluzione del pixel della region corrente"
-# transetto?
-#~ msgid "raster, transect"
-#~ msgstr "raster, transetto"
-#~ msgid "raster, random"
-#~ msgstr "raster, random"
-#~ msgid "Cannot read raster row [%d]"
-#~ msgstr "Impossibile leggere la riga [%d] del raster"
-#~ msgid "Cannot read raster row [%d] from raster map <%s>"
-#~ msgstr "Impossibile leggere la riga [%d] del raster dalla mappa raster <%s>"
-#~ msgid "Cannot read raster row [%d] from cover raster map <%s>"
-#~ msgstr "Impossibile leggere la riga [%d] del raster dal raster di copertura <%s>"
-#~ msgid "raster, viewshed"
-#~ msgstr "raster, intervisibilità"
-#~ msgid "[%s]: Cannot read map header"
-#~ msgstr "[%s]: Impossibile leggere l'intestazione della mappa"
-#~ msgid "Failed writing raster map <%s> row %d"
-#~ msgstr "Scrittura della mappa raster <%s> riga %d non riuscita"
-#~ msgid "raster, fire"
-#~ msgstr "raster, incendi"
-#~ msgid "Raster map <%s> already exists in mapset <%s>, select another name"
-#~ msgstr "La mappa raster <%s> esiste già nel mapset <%s>, selezionare un altro nome"
-#~ msgid "Name of raster map to contain results (several new layers)"
-#~ msgstr "Nome del raster contenente i risultati (diversi layers nuovi)"
-#~ msgid "Percent Completed ... "
-#~ msgstr "Percentuale completata"
-#~ msgid "raster, profile"
-#~ msgstr "raster, profilo"
-#~ msgid "Use mouse to select Start Point\n"
-#~ msgstr "Usare il mouse per selezionare Punto di inizio\n"
-#~ msgid ""
-#~ "\n"
-#~ "Use mouse to draw profile line\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Usare il mouse per disegnare la linea di profilo\n"
-#~ msgid "Buttons:\n"
-#~ msgstr "Bottoni:\n"
-#~ msgid "Left:   Mark next point\n"
-#~ msgstr "Sinistro:  Segna il prossimo punto\n"
-#~ msgid "Middle: Mark next point\n"
-#~ msgstr "Centrale: Segna il prossimo punto\n"
-#~ msgid ""
-#~ "Right:  Finish profile and exit\n"
-#~ "\n"
-#~ msgstr ""
-#~ "Destro: Finisci profilo ed esci\n"
-#~ "\n"
-#~ msgid "raster, buffer"
-#~ msgstr "raster, buffer"
-#~ msgid "raster, series"
-#~ msgstr "raster, serie"
-#~ msgid "Threshold to calculate for method=threshold"
-#~ msgstr "Soglia da calcolare per method==threshold"
-#~ msgid "Unable to open raster map <%s> in mapset <%s>"
-#~ msgstr "Impossibile aprire la mappa raster <%s> nel mapset <%s>"
-#~ msgid "Finds the average of values in a cover map within areas assigned the same category value in a user-specified base map."
-#~ msgstr "Trova la media dei valori in una mappa di copertura all'interno di aree che hanno lo stesso valore di categoria in una mappa di base definita dall'utente."
-#~ msgid "%s: ERROR running %s command"
-#~ msgstr "%s: ERRORE nell'eseguire il comando %s"
-#~ msgid "%s: unable to open temporary file"
-#~ msgstr "%s: non è possibile aprire il file temporaneo"
-#~ msgid "Cannot get row"
-#~ msgstr "Impossibile ottenere la riga"
-#~ msgid "Watershed basin analysis program."
-#~ msgstr "Programma per l'analisi dei bacini idrografici."
-#~ msgid "unable to open new accum map layer."
-#~ msgstr "impossibile aprire nuovo tematismo accumulazione"
-#~ msgid "Close failed."
-#~ msgstr "Chiusura non riuscita."
-#~ msgid "unable to open new aspect map layer."
-#~ msgstr "impossibile aprire nuovo tematismo esposizione."
-#~ msgid "unable to open new LS factor map layer."
-#~ msgstr "impossibile aprire nuovo tematismo fattore LS."
-#~ msgid "unable to open new slope length map layer."
-#~ msgstr "impossibile aprire nuovo tematismo lunghezza dei versanti."
-#~ msgid "unable to open new S factor map layer."
-#~ msgstr "impossibile aprire nuovo tematismo fattore S."
-#~ msgid "unable to open elevation map layer"
-#~ msgstr "impossibile aprire il tematismo elevazione"
-#~ msgid "unable to open runoff map layer"
-#~ msgstr "impossibile aprire il tematismo deflusso"
-#~ msgid "unable to open depression map layer"
-#~ msgstr "impossibile aprire il tematismo depressioni"
-#~ msgid "unable to open rill map layer"
-#~ msgstr "Impossibile aprire il tematismo rill"
-#~ msgid "raster, DEM, fractal"
-#~ msgstr "raster, DEM, frattale"
-#~ msgid "Quietly"
-#~ msgstr "Silenziosamente"
-#~ msgid "Error writing category file for <%s>"
-#~ msgstr "Errore nella scrittura del file delle categorie per <%s>"
-#~ msgid "Error writing color file for <%s>"
-#~ msgstr "Errore nella scrittura del file dei colori per <%s>"
-#~ msgid "raster, projection, transformation"
-#~ msgstr "raster, proiezione, trasformazione"
-#~ msgid "Re-projects a raster map from one location to the current location."
-#~ msgstr "Riproietta un raster da una location alla location corrente"
-#~ msgid "Resolution of output map"
-#~ msgstr "Risoluzione della mappa di output"
-#~ msgid "Raster File Series to MPEG Conversion."
-#~ msgstr "Programma di conversione per serie di file raster in MPEG"
-#~ msgid "Raster file(s) for View%d"
-#~ msgstr "file raster per la Vista%d"
-#~ msgid "Quiet - suppress progress report"
-#~ msgstr "Silenzioso - sopprime il rapporto sullo stato di avanzamento"
-#~ msgid "Name of existing raster map containing elevation surface"
-#~ msgstr "Nome di una mappa raster contenente una superfice di altezze"
-#~ msgid "Output elevation raster map after filling"
-#~ msgstr "Visualizza il raster delle altezze dopo il riempimento"
-#~ msgid "Output direction raster map"
-#~ msgstr "Visualizza il raster della direzione"
-#~ msgid "Output raster map of problem areas"
-#~ msgstr "Visualizza il raster delle aree problematiche"
-#~ msgid "Reading map..."
-#~ msgstr "Lettura della mappa in corso..."
-#~ msgid "Unable to write color table for %s"
-#~ msgstr "Impossibile scrivere la tavola dei colori per %s"
-#~ msgid "Cannot read ew_res value"
-#~ msgstr "Impossibile leggere il valore ew_res (risoluzione E-O)"
-#~ msgid "Cannot read ns_res value"
-#~ msgstr "Impossibile leggere il valore ns_res (risoluzione N-S)"
-#~ msgid "[%s]: Map is the wrong resolution"
-#~ msgstr "[%s]: La mappa ha risoluzione sbagliata"
-#~ msgid "Not enough disk space -- cannot write files"
-#~ msgstr "Spazio nel disco insufficiente -- impossibile scrivere i file"
-#~ msgid "raster, statistics, reclass"
-#~ msgstr "raster, statistica, riclassificazione"
-#~ msgid "Title, in quotes"
-#~ msgstr "Titolo, fra virgolette"
-#~ msgid "Unable to read raster map row %d "
-#~ msgid "Failed writing raster map row %d"
-#~ msgstr "Scrittura della riga %d della mappa raster non riuscita"
-#~ msgid "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel resolution of the currently defined region."
-#~ msgstr "Esporta un raster GRASS in un'immagine TIFF 8/24bit con la risoluzione del pixel definita della regione corrente"
-#~ msgid "Unable to read header of raster map <%s>"
-#~ msgstr "Impossibile leggere l'intestazione della mappa raster <%s>"
-#~ msgid "raster, import, LIDAR"
-#~ msgstr "raster, importazione, LIDAR"
-#~ msgid "Surface generation program from rasterized contours."
-#~ msgstr "Comando per la generazione di superfice da contorni rasterizzati"
-#~ msgid "Output elevation raster map"
-#~ msgstr "Output mappa raster dell'elevazione"
-#~ msgid "raster, color table"
-#~ msgstr "raster, tavola dei colori"
-#~ msgid "Creates/modifies the color table associated with a raster map layer."
-#~ msgstr "Crea/modifica la tavola dei colori associata a un raster"
-#~ msgid "Raster map name from which to copy color table"
-#~ msgstr "Nome della mappa raster da cui copiare la tavola dei colori"
-#~ msgid "Path to rules file (\"-\" to read rules from stdin)"
-#~ msgstr "Percorso del file delle regole (\"-\" per leggere le regole dallo stdin)"
-#~ msgid "Enter rules interactively"
-#~ msgstr "Immissione delle regole in modo interattivo"
-#~ msgid "Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" options"
-#~ msgstr "La modalità interattiva è incompatibile con le opzioni \"color\", \"rules\" e \"raster\""
-#~ msgid "Output map <%s> ignored"
-#~ msgstr "Mappa di output <%s> ignorata"
-#~ msgid "Not yet implemented!"
-#~ msgstr "Non ancora implementato!"
-#~ msgid "CHILD[pid = %i] cannot open raster map"
-#~ msgstr "CHILD[pid = %i] impossibile aprire la mappa raster"
-#~ msgid "Cannot create %s/.r.li/ directory"
-#~ msgstr "Impossibile creare la directory  %s/.r.li/"
-#~ msgid "Cannot create %s/.r.li/output/ directory"
-#~ msgstr "Impossibile creare la directory  %s/.r.li/output/"
-#~ msgid "Cannot close %s file (PIPE)"
-#~ msgstr "Impossibile chiudere il file %s (PIPE)"
-#~ msgid "Cannot delete %s file (PIPE)"
-#~ msgstr "Impossibile eliminare il file %s (PIPE)"
-#~ msgid "Cannot close %s file (PIPE2)"
-#~ msgstr "Impossibile chiudere il file %s (PIPE2)"
-#~ msgid "Cannot delete %s file (PIPE2)"
-#~ msgstr "Impossibile eliminare il file %s (PIPE2)"
-#~ msgid "Cannot delete %s file"
-#~ msgstr "Impossibile eliminare il file %s"
-#~ msgid "Cannot read raster header file"
-#~ msgstr "Impossibile leggere il file delle intestazioni del raster"
-#~ msgid "File type"
-#~ msgstr "Tipo di file"
-#~ msgid "Output file name not specified"
-#~ msgstr "Nome del file di output non specificato"
-#~ msgid "raster, export, VRML"
-#~ msgstr "raster, esportazione, VRML"
-#~ msgid "Export a raster map to the Virtual Reality Modeling Language (VRML)"
-#~ msgstr "Esporta raster in Virtual Reality Modeling Language (VRML)"
-#~ msgid "Unable to open raster map <%s@%s>"
-#~ msgstr "Non è possibile aprire la mappa raster <%s@%s>"
-#~ msgid "Generates a raster map layer of distance to features in input layer."
-#~ msgstr "Genera un raster della distanza dagli elementi del layer di input"
-#~ msgid "Unable to create distance map <%s>"
-#~ msgstr "Impossibile creare la mappa delle distanze <%s>"
-#~ msgid "(i)   Elevation map"
-#~ msgstr "(i)   Mappa di elevazione"
-#~ msgid "Unable to write color table for raster map <%s>"
-#~ msgstr "Non è possibile scrivere la tavola dei colori per la mappa raster <%s>"
-#~ msgid "<%s> is an ilegal name"
-#~ msgstr "<%s> è un nome non valido"
-#~ msgid "%s: Error reading from raster map <%s> in mapset <%s>"
-#~ msgstr "%s: Errore nel leggere dalla mappa raster <%s> nel mapset <%s>"
-#~ msgid "Creates a new map layer whose category values are based upon a reclassification of the categories in an existing raster map layer."
-#~ msgstr "Crea un nuovo layer dove i valori delle categorie sono basati sulla riclassificazione delle categorie esistenti in un altro raster"
-#~ msgid "Raster map to be reclassified"
-#~ msgstr "Mappa raster da riclassificare"
-#~ msgid "fp: Data range is %.25f to %.25f\n"
-#~ msgstr "fp: l'intervallo di dati è da %.25f a %.25f\n"
-#~ msgid "Cannot create category file of <%s>"
-#~ msgstr "Impossibile creare il file delle categorie di <%s>"
-#~ msgid "raster, conversion, vectorization"
-#~ msgstr "raster, conversione, vettorializzazione"
-#~ msgid "Converts a raster map into a vector map layer."
-#~ msgstr "Converte un raster in un vettore"
-#~ msgid "Quiet - Do not show progress"
-#~ msgstr "Silenzioso - Non mostra lo stato di avanzamento"
-#~ msgid "raster, category"
-#~ msgstr "raster, categoria"
-#~ msgid "Cannot create category file for <%s>"
-#~ msgstr "Impossibile creare il file delle categorie per <%s>"
-#~ msgid "Cannot read header of raster map <%s> in <%s>"
-#~ msgstr "Impossibile leggere l'intestazione del raster <%s> in <%s>"
-#~ msgid "Cannot open cell file of raster map <%s> in <%s>"
-#~ msgstr "Impossibile aprire il file di celle della mappa raster <%s> in <%s>"
-#~ msgid "Illegal output file name <%s>"
-#~ msgstr "Nome del file di output <%s> non valido"
-#~ msgid "This utility will allow you to compare the coincidence of two map layers\n"
-#~ msgstr "Questo programma di utilità consente di confrontare le coincidenze di due tematismi raster\n"
-#~ msgid "The report can be made in one of 8 units."
-#~ msgstr "Il rapporto può essere fatto in una delle 8 unità di misura"
-#~ msgid "Please choose a unit by entering one of the following letter codes:"
-#~ msgstr "Scegliere un'unità di misura immettendo uno dei seguenti codici letterali:"
-#~ msgid "     'c': cells"
-#~ msgstr "     'c': celle"
-#~ msgid "     'p': percent cover of region"
-#~ msgstr "     'p': percentuale di regione coperta"
-#~ msgid "     'x': percent of '%s' category (column)"
-#~ msgstr "     'x': percentuale sulla categoria di '%s' (colonna)"
-#~ msgid "     'y': percent of '%s' category (row)"
-#~ msgstr "     'y': percentuale sulla categoria di '%s' (riga)"
-#~ msgid "     'a': acres"
-#~ msgstr "     'a': acri"
-#~ msgid "     'h': hectares"
-#~ msgstr "     'h': ettari"
-#~ msgid "     'k': square kilometers"
-#~ msgstr "     'k': chilometri quadrati"
-#~ msgid "     'm': square miles\n"
-#~ msgstr "     'm': miglia quadrate\n"
-#~ msgid "     'Q': quit"
-#~ msgstr "     'Q': uscita"
-#~ msgid "Do you wish to save this report in a file? (y/n) [n] "
-#~ msgstr "Si vuol salvare questo rapporto in un file? (y/n) [n] "
-#~ msgid ""
-#~ "Enter the file name or path\n"
-#~ msgstr ""
-#~ "Inserire il nome del file o il persorso\n"
-#~ msgid "Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
-#~ msgstr "Si vuol stampare questo rapporto (richiede il comando Unix lpr (y/n) [n] "
-#~ msgid "Do you wish to run this report with a different unit of measure? (y/n) [y] "
-#~ msgstr "Si vuole generare questo rapporto con una diversa unità di misurà? (y/n) [y] "
-#~ msgid "Error reading input"
-#~ msgstr "Errore nella lettura dell'input"
-#~ msgid "Data range of raster map <%s> is empty"
-#~ msgstr "L'intervallo dati della mappa raster <%s> è vuoto"
-#~ msgid "Data range of raster map <%s> is %s to %s (entire map)"
-#~ msgstr "L'intervallo dati della mappa raster <%s> è da %s a %s (l'intera mappa)"
-#~ msgid "Integer data range of raster map <%s> is empty"
-#~ msgstr "L'intervallo dati dei valori interi della mappa raster <%s> è vuoto"
-#~ msgid "Integer data range of raster mao <%s> is %d to %d"
-#~ msgstr "L'intervallo dati dei valori interi della mappa raster <%s> è da %d a %d"
-#~ msgid "raster, volume"
-#~ msgstr "raster, volume"
-#~ msgid "Unable to find data map"
-#~ msgstr "Non è possibile trovare la mappa dei dati"
-#~ msgid "Unable to find clump map"
-#~ msgstr "Non è possibile trovare la mappa dei gruppi"
-#~ msgid "raster, distance"
-#~ msgstr "raster, distanza"
-#~ msgid "Name of vector input map containing stream(s)"
-#~ msgstr "Nome della mappa vettoriale che contiene il corso/i d'acqua"
-#~ msgid "Stream width (in meters). Default is raster cell width"
-#~ msgstr "Ampiezza del corso d'acqua (in metri). Il valore predefinito è l'ampiezza della cella del raster"
-#~ msgid "%s: cover raster map not found"
-#~ msgstr "%s: mappa raster di copertura non trovata"
-#~ msgid "Error reading raster map <%s>"
-#~ msgstr "Errore nella lettura della mappa raster <%s>"
-#~ msgid "Failed writing raster map <%s>"
-#~ msgstr "Scrittura della mappa raster <%s> non riuscita"
-#~ msgid "Unable to get current region"
-#~ msgstr "Non è possibile ottenere la regione corrente"
-#~ msgid "Input elevation raster map"
-#~ msgstr "Mappa raster di elevazione in input"
-#~ msgid "Input aspect raster map"
-#~ msgstr "Mappa raster delle esposizioni in input"
-#~ msgid "Cannot reset current region"
-#~ msgstr "Impossibile reimpostare la regione corrente"
-#~ msgid "raster, querying"
-#~ msgstr "raster, interrogazioni"
-#~ msgid "raster, import, conversion"
-#~ msgstr "raster, importazione, conversione"
-#~ msgid "Converts ASCII raster file to binary raster map layer."
-#~ msgstr "Converte un file raster ASCII in un raster binario"
-#~ msgid "raster, random, cell"
-#~ msgstr "raster, casuale, cella"
-#~ msgid "Input elevation map"
-#~ msgstr "Mappa di elevazione di input"
-#~ msgid "Reading row %d"
-#~ msgstr "Lettura della riga %d"
-#~ msgid "Unable to read header of raster map <%s@%s>"
-#~ msgstr "Non è possibile leggere l'intestazione della mappa raster <%s@%s>"
-#~ msgid "Unable to read region <%s> in <%s>"
-#~ msgstr "Impossibile leggere la regione <%s> in <%s>"
-#~ msgid "Unable to open vector map <%s> in <%s>"
-#~ msgstr "Impossibile aprire la mappa vettoriale <%s> in <%s>"
-#~ msgid "Invalid region: %s"
-#~ msgstr "Regione non valida: %s"
-#~ msgid "Writing raster map, row %d"
-#~ msgstr "Scrittura della mappa raster, riga %d"
-#~ msgid "Lat/Long location is not supported"
-#~ msgstr "La location Lat/Long non è supportata"
-#~ msgid "Cannot write category file for raster map <%s>"
-#~ msgstr "Impossibile scrivere il file delle categorie per la mappa raster <%s>"
-#~ msgid "raster, geomorphology"
-#~ msgstr "raster, geomorfologia"
-#~ msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster map layer."
-#~ msgstr "Converte un file raster ESRI ARC/INFO ascii (GRID) in un raster (binario)"
-#~ msgid "File containing weights"
-#~ msgstr "File contenente i pesi"
-#~ msgid "Unable to write to <%s>"
-#~ msgstr "Non è possibile scrivere su <%s>"
-#~ msgid "%s file(s) to be copied"
-#~ msgstr "%s file da copiare"
-#~ msgid "%s file(s) to be removed"
-#~ msgstr "%s file da rimuovere"
-#~ msgid "Mapset to list (default: current search path)"
-#~ msgstr "Mapset del quale fornire la lista (predefinito: percorso di ricerca corrente)"
-#~ msgid "%s file(s) to be renamed"
-#~ msgstr "%s file da rinominare"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "WARNING!  A projection file already exists for this location\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "ATTENZIONE!  Un file della proiezione esiste già per questa location\n"
-#~ msgid "Would you still like to overwrite the current projection information "
-#~ msgstr "Vuoi ancora sovrascrivere le attuali informazioni sulla proiezione"
-#~ msgid "Error writing PROJ_INFO"
-#~ msgstr "Errore durante la scrittura di PROJ_INFO"
-#~ msgid "Error writing PROJ_UNITS"
-#~ msgstr "Errore durante la scrittura di PROJ_UNITS"
-#~ msgid "The projection information will not be updated."
-#~ msgstr "Le informazioni sulla proiezione non saranno aggiornate"
-#~ msgid "GIS data directory (full path to the directory where the new location is)"
-#~ msgstr "Directory dei dati GIS (percorso intero della directory dove la nuova location è situata)"
-#~ msgid "Erasing monitors..."
-#~ msgstr "Cancellazione dei monitor in corso ..."
-#~ msgid "<%s> not found in mapset list"
-#~ msgstr "<%s> non trovato nella lista dei mapset"
-#~ msgid "general, settings, search path"
-#~ msgstr "general, impostazioni, percorso di ricerca"
-#~ msgid "Removing %s <%s>"
-#~ msgstr "Rimozione di %s <%s>"
-#~ msgid "couldn't be removed"
-#~ msgstr "non può essere rimosso"
-#~ msgid "%s: couldn't be removed"
-#~ msgstr "%s: non può essere rimosso"
-#~ msgid "%s: removed"
-#~ msgstr "%s: rimosso"
-#~ msgid "<%s> nothing removed"
-#~ msgstr "<%s> non è stato rimosso nulla"
-#~ msgid "Raster map <%s@%s>: %s"
-#~ msgstr "Mappa raster <%s@%s>: %s"
-#~ msgid "<%s> is an illegal region name"
-#~ msgstr "<%s> è un nome di regione illegale"
-#~ msgid "format"
-#~ msgstr "formato"
-#~ msgid "Unable to open raster map <%s> in <%s>"
-#~ msgstr "impossibile aprire la mappa raster <%s> in <%s>"
-#~ msgid "Could not read from <%s>"
-#~ msgstr "Non riesco a leggere da <%s>"
-#~ msgid "Name of workspace file"
-#~ msgstr "Nome del file dello spazio di lavoro (workspace)"
-#~ msgid "Name of a mapset"
-#~ msgstr "Nome di un mapset"
-#~ msgid "Error opening cell-file"
-#~ msgstr "Errore nell'apertura del file di celle"
-#~ msgid "Error reading from cell-file"
-#~ msgstr "Errore nella lettura del file di celle"
-#~ msgid "%s: Couldn't open raster <%s@%s>"
-#~ msgstr "%s: Impossibile aprire il raster <%s@%s>"
-#~ msgid "%s: Couldn't read color table for <%s@%s>"
-#~ msgstr "%s: Impossibile leggere la tavola dei colori per <%s@%s>"
-#~ msgid "Error reading raster map"
-#~ msgstr "Errore leggendo la mappa raster"
-#~ msgid " Right:   Quit\n"
-#~ msgstr " Destro:  Esce\n"
-#~ msgid "Size of grid to be drawn"
-#~ msgstr "Dimensione griglia da disegnare"
-#~ msgid "List map names displayed in GRASS monitor"
-#~ msgstr "Elenca i nomi di mappa visualizzati nel monitor GRASS"
-#~ msgid "name"
-#~ msgstr "nome"
-#~ msgid ""
-#~ "\n"
-#~ "Buttons:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Bottoni:\n"
-#~ msgid "display, distance"
-#~ msgstr "visualizzazione, distanza"
-#, fuzzy
-#~ msgid "display, menu"
-#~ msgstr "mostra"
-#, fuzzy
-#~ msgid "found %d visuals of type TrueColor"
-#~ msgstr "trovate %d viste per il tipo TrueColor"
-#~ msgid "searching for highest bit depth"
-#~ msgstr "ricerca del valore massimo di bit depth"
-#, fuzzy
-#~ msgid "selected %d bit depth"
-#~ msgstr "bit depth %d selezionata"
-#~ msgid "using default visual which is %s"
-#~ msgstr "si sta usando la vista predefinita che è %s"
-#~ msgid "Monitor: interactive command in redraw"
-#~ msgstr "Monitor: comandi interattivi per il ridisegnamento"
-#~ msgid "Monitor: waitpid: expected %d but got %d"
-#~ msgstr "Monitor: waitpid: atteso %d ma ricevuto %d"
-#~ msgid "Monitor: XGetWMName failed"
-#~ msgstr "Monitor: XGetWMName fallito"
-#~ msgid "Monitor: XGetWMName: bad result"
-#~ msgstr "Monitor: XGetWMName: risultato sbagliato"
-#~ msgid "Setting release of FreeType"
-#~ msgstr "Imposta la versione di FreeType"
-#~ msgid ""
-#~ "\n"
-#~ "Mouse Buttons:"
-#~ msgstr ""
-#~ "\n"
-#~ "Tasti del mouse"
-#~ msgid ""
-#~ "Right:  Quit\n"
-#~ "\n"
-#~ msgstr ""
-#~ " Destro: esce\n"
-#~ "\n"
-#~ msgid "No raster or vector map displayed"
-#~ msgstr "Nessuna mappa raster o vettoriale visualizzata"
-#~ msgid "Cannot use current window"
-#~ msgstr "Non è possibile uilizzare la finestra corrente"
-#~ msgid "Display number of colors"
-#~ msgstr "Mostra numero di colori"
-#~ msgid "Error reading row of data"
-#~ msgstr "Errore nella lettura della riga dei dati"
-#~ msgid "Path to TrueType font (including file name)"
-#~ msgstr "Percorso del carattere TrueType (nome del file incluso)"
-#~ msgid "Unable to write the temporary file"
-#~ msgstr "Non è possibile scrivere il file temporaneo"
-#~ msgid "No predefined font"
-#~ msgstr "Nessun font predefinito"
-#~ msgid "display, color transformation"
-#~ msgstr "visualizzazione, trasformazione di colore"
-#~ msgid "Error reading hue data"
-#~ msgstr "Errore nella lettura dei dati di tonalità"
-#~ msgid "Error reading intensity data"
-#~ msgstr "Errore nella lettura dei dati di intensità"
-#~ msgid "Error reading saturation data"
-#~ msgstr "Errore nella lettura dei dati di saturazione"
-#~ msgid "Can't set current graphics window"
-#~ msgstr "Impossibile impostare la finestra grafica corrente"
-#~ msgid "Invalid rendering method <%s>"
-#~ msgstr "Metodo di rendering <%s> non valido"
-#~ msgid "display, histogram, statistics"
-#~ msgstr "visualizzazione, istogramma, statistica"
-#~ msgid "Error - Monitor '%s' in use by another user"
-#~ msgstr "Errore - Il monitor '%s' è in uso da un altro utente"
-#~ msgid "Name of graphics monitor to unlock"
-#~ msgstr "Nome del monitor grafico da sbloccare"
-#~ msgid "List all monitors (with current status)"
-#~ msgstr "Mostra tutti i monitor (con lo stato corrente)"
-#~ msgid " Middle: toggle flash color\n"
-#~ msgstr " Centrale: abilita colore flash\n"
-#~ msgid "List of values to be displayed (FP maps)"
-#~ msgstr "Lista dei valori da visualizzare (mappe di valori a virgola mobile [FP])"
-#~ msgid "You must select more than one point"
-#~ msgstr "Devi selezionare più di un punto"
-#~ msgid "You must select at least four points"
-#~ msgstr "Devi selezionare almeno quattro punti"
-#, fuzzy
-#~ msgid "display, zoom"
-#~ msgstr "mostra"
-#, fuzzy
-#~ msgid "ERROR: can not get \"list\" items"
-#~ msgstr "ERRORE: non riesco ad ottenere la \"lista\" degli oggetti"
-#~ msgid "-j flag forced"
-#~ msgstr "flag -j forzato"
-#~ msgid "No map is displayed in GRASS monitor"
-#~ msgstr "Non è mostrata nessuna mappa nel monitor GRASS"
-#~ msgid "Layer number (if -1, all layers are displayed)"
-#~ msgstr "Numero del layer (se -1, tutti i layer sono visualizzati)"
-#~ msgid "Unable to display areas, topology not available"
-#~ msgstr "Non è possibile mostrare le aree, topologia non disponibile"
-#~ msgid "Unable to display lines by id, topology not available"
-#~ msgstr "Non è possibile mostrare le linee per id, topologia non disponibile"
-#~ msgid "Unable to display topology, not available"
-#~ msgstr "Non è possibile mostrare la topologia, non è disponibile"
-#~ msgid "vector, raster, resample"
-#~ msgstr "vettore, raster, ricampionamento"
-#~ msgid "Raster map to be sampled"
-#~ msgstr "Mappa raster da leggere"
-#~ msgid "Checking vector points..."
-#~ msgstr "Controllo dei punti vettoriali in corso ..."
-#~ msgid "vector, database, attribute table"
-#~ msgstr "vettoriale, database, tabella degli attributi"
-#~ msgid "vector, network, allocation"
-#~ msgstr "vettore, rete, allocazione"
-#~ msgid "vector, networking, maintenance"
-#~ msgstr "vettore, rete, manutenzione"
-#~ msgid "Name of input point vector map"
-#~ msgstr "Nome della mappa vettoriale di punti di input"
-#~ msgid "Required for operation 'connect'"
-#~ msgstr "Richiesto per l'operazione 'connect'"
-#~ msgid "Output vector map must be specified"
-#~ msgstr "Mappa vettoriale di output dev'essere specificata"
-#~ msgid "Point vector map must be specified"
-#~ msgstr "La mappa vettoriale dei punti dev'essere specificata"
-#~ msgid "Threshold value must be specified"
-#~ msgstr "Il valore di soglia dev'essere specificato"
-#~ msgid "%d arcs added to network (nlayer %d)"
-#~ msgstr "%d archi aggiunti alla rete (nlayer %d)"
-#~ msgid "%d new points written to output"
-#~ msgstr "%d nuovi punti scritti all'output"
-#~ msgid "Exports a GRASS vector map to SVG."
-#~ msgstr "Esporta vettore GRASS in un SVG"
-#~ msgid "Unable to open SVG file <%s>"
-#~ msgstr "Non posso aprire il file SVG <%s>"
-#~ msgid "Layer number (write to)"
-#~ msgid "Query layer number (read from)"
-#~ msgstr "Numero del layer da interrogare (da cui leggere)"
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)"
-#~ msgstr ""
-#~ "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)\n"
-#~ "(miglia, piedi, metri, chilometri, acri, ettari, radianti, gradi)"
-#~ msgid "Attribute table column with values to interpolate (if layer>0)"
-#~ msgstr "Colonna della tabella degli attributi coi valori da interpolare (se layer>0)"
-#~ msgid "Unable to access table <%s>"
-#~ msgstr "Non è possibile accedere alla tabella <%s>"
-#~ msgid "<%s> has not been created in database."
-#~ msgstr "<%s> non è stata creata nel database"
-#~ msgid "Vector based generalization."
-#~ msgstr "Generalizzazione vettoriale"
-#~ msgid "Remove lines and areas smaller than threshold"
-#~ msgstr "Rimuove linee e aree più piccole del valore di soglia"
-#, fuzzy
-#~ msgid "Unable to calculate centroid for area %d"
-#~ msgstr "Non è possibile calcolare il centroide per l'area %d"
-#~ msgid "Creates topology for GRASS vector map."
-#~ msgstr "Crea la topologia per una mappa vettoriale di GRASS"
-#~ msgid "Vector map <%s> not found in the current mapset"
-#~ msgstr "La mappa vettoriale <%s> non è stata trovata nel mapset corrente"
-#~ msgid "Convert OGR vector layers to GRASS vector map."
-#~ msgstr "Converte vettore OGR in vettore GRASS"
-#~ msgid "Layer 0 not supported"
-#~ msgstr "Layer 0 non supportato"
-#~ msgid "vector, network, isolines"
-#~ msgstr "vettore, rete, isolinee"
-#~ msgid "vector, network, salesman"
-#~ msgstr "vettoriale, rete, salesman"
-#~ msgid "vector, geometry, statistics"
-#~ msgstr "vettore, geometria, statistica"
-#~ msgid "Random location perturbations of GRASS vector points"
-#~ msgstr "Disturbo casuale del posizionamento di punti vettoriali"
-#~ msgid "vector, network, shortest path"
-#~ msgstr "vettore, rete, persorso minimo"
-#~ msgid "Layer number (from)"
-#~ msgstr "Numero del layer (from)"
-#~ msgid "Layer number (to)"
-#~ msgstr "Numero del layer (to)"
-#~ msgid "Randomly generate a 2D/3D vector points map."
-#~ msgstr "Genera casualmente un mappa vettoriale di punti 2D/3D"
-#~ msgid "Converts a GRASS binary vector map to VTK ASCII output."
-#~ msgstr "Converte un vettore GRASS in un VTK ASCII"
-#~ msgid "Error reading value of attribute '%s'"
-#~ msgstr "Errore nella lettura del valore dell'attributo '%s'"
-#~ msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
-#~ msgstr "Converte un vettore GRASS binario in un vettore GRASS ASCII"
-#~ msgid "Parameter '%s' ignored in standard mode"
-#~ msgstr "Parametro '%s' ignorato in modalità standard"
-#~ msgid "Column <%s>: unsupported data type"
-#~ msgstr "Colonna <%s>: tipo di dati non supportato"
-#~ msgid "Nothing to do"
-#~ msgstr "Non c'è nulla da fare"
-#~ msgid "Converts files in DXF format to GRASS vector map format."
-#~ msgstr "Converte file in formato DXF in un vettore in formato GRASS"
-#~ msgid "Creates a GRASS vector map of a user-defined grid."
-#~ msgstr "Crea un vettoriale di una griglia definita dall'utente"
-#~ msgid "Either 'rules' or 'col' must be specified"
-#~ msgstr "Dev'essere specificato il parametro 'rules' o 'col'"
-#~ msgid "Network input map <%s> not found"
-#~ msgstr "Mappa di input della rete <%s> non trovata"
-#~ msgid "Unable to read MASK"
-#~ msgstr "Impossibile leggere MASK"
-#~ msgid "Converts GRASS vector map to one of the supported OGR vector formats."
-#~ msgstr "Converte una mappa vettoriale GRASS in uno dei formati vettoriali supportati da OGR"
-#~ msgid "OGR format"
-#~ msgstr "Formato OGR"
-#~ msgid "Key column '%s' not found"
-#~ msgstr "Colonna chiave '%s' non trovata"
-#~ msgid "Exporting %i geometries..."
-#~ msgstr "Esportazione di %i geometrie in corso..."
-#~ msgid "Cannot open %s"
-#~ msgstr "Impossibile aprire %s"
-#, fuzzy
-#~ msgid "vector, network, articulation points"
-#~ msgstr "N"
-#~ msgid "Create a new vector map layer by combining other vector map layers."
-#~ msgstr "Crea un nuovo tematismo vettoriale combinando altri tematismi vettoriali."
-#~ msgid "Cannot alter table: %s"
-#~ msgstr "Non posso modificare la tabella: %s"
-#~ msgid "Creates a buffer around features of given type (areas must contain centroid)."
-#~ msgstr "Crea un buffer intorno agli elementi di un dato tipo (aree devono contenere centroide)."
-#~ msgid "vector, geometry, triangulation"
-#~ msgstr "vettore, geometria, triangolazione"
-#~ msgid "vector, network, steiner tree"
-#~ msgstr "vettore, rete, albero di steiner"
-#~ msgid "Queries a vector map layer at given locations."
-#~ msgstr "Interroga un vettoriale a una certa posizione."
-#~ msgid "Type: %s"
-#~ msgstr "Tipo: %s"
-#~ msgid "The '%c' flag is deprecated and will be removed in future. Please use '--quiet' instead."
-#~ msgstr "Il flag '%c' è deprecato e in futuro verrà rimosso. Al suo posto usare '--quiet'"
-#~ msgid "Copying vector objects from vector map <%s>..."
-#~ msgstr "Copia in corso degli oggetti vettoriali dalla mappa vettoriale <%s>..."
-#~ msgid "Name of input vector map containing lines"
-#~ msgstr "Nome della mappa vettoriale di input contenente le linee"
-#~ msgid "Name for output vector map where segments will be written"
-#~ msgstr "Nome della mappa vettoriale di output su cui scrivere i segmenti"
-#~ msgid "Doing log transformation"
-#~ msgstr "Si sta effettuando la trasformazione logaritmica"
-#~ msgid "Calculates univariate statistics for attribute. Variance and standard deviation is calculated only for points if specified."
-#~ msgstr "Calcola statistiche univariate per gli attributi. Varianza e deviazione standard è calcolate solo per punti se specificato."
-#~ msgid "Column name"
-#~ msgstr "Nome della colonna"
-#~ msgid "Unable select categories from table <%s>"
-#~ msgstr "Non è possibile selezionare le categorie dalla tabella <%s>"
-#~ msgid "Calculate area centroids..."
-#~ msgstr "Calcolo dei centroidi dell'area in corso..."
-#~ msgid "Unable to write categories for raster map <%s>"
-#~ msgstr "Impossibile scrivere le categorie per la mappa rster <%s>"
-#~ msgid "Create points along input lines in new vector with 2 layers."
-#~ msgstr "Crea punti lungo una linea di input in un nuovo vettoriale con 2 layer"
-#~ msgid "Output vector map where points will be written"
-#~ msgstr "Mappa vettoriale di output su cui scrivere i punti"
-#~ msgid "%d points written to output vector map"
-#~ msgstr "Scritti %d punti nella mappa vettoriale di output"
-#~ msgid "Error reading ASCII file: (bad type) [%s]"
-#~ msgstr "Errore nella lettura del file ASCII: (tipo non corretto) [%s]"
-#~ msgid "Error reading ASCII file: (unknown type) [%s]"
-#~ msgstr "Errore nella lettura del file ASCII: (tipo sconosciuto) [%s]"
-#~ msgid "Error reading categories: [%s]"
-#~ msgstr "Errore nella lettura delle categorie : [%s]"
-#~ msgid "Creates a vector map from ASCII points file or ASCII vector file."
-#~ msgstr "Crea una mappa vettoriale da un file ASCII di punti o da un file ASCII vettoriale."
-#~ msgid "ASCII file to be imported, if not given reads from standard input"
-#~ msgstr "File ASCII da importare, se non viene fornito legge dallo standard input"
-#~ msgid "Creates a new vector as a read-only link to OGR layer."
-#~ msgstr "Crea nuovo vettore come link in sola lettura a un layer OGR"
-#~ msgid "%d lines / boundaries removed"
-#~ msgstr "%d linee / confini rimossi"
-#~ msgid "Attribute table column with values to interpolate"
-#~ msgstr "Colonna della tabella degli attributi coi valori da interpolare"
-#~ msgid "Error reading ASCII file: '%s'"
-#~ msgstr "Errore nella lettura del file ASCII: '%s'"
-#~ msgid "Error reading categories: '%s'"
-#~ msgstr "Errore nella lettura delle categorie: '%s'"
-#~ msgid "Print vector history instead of info"
-#~ msgstr "Stampa la cronologia del vettoriale invece delle informazioni"
-#~ msgid "Mapset:          %s"
-#~ msgstr "Mapset:          %s"
-#~ msgid "Location:        %s"
-#~ msgstr "Location:        %s"
-#~ msgid "Database:        %s"
-#~ msgstr "Database:        %s"
-#~ msgid "Title:           %s"
-#~ msgstr "Titolo:           %s"
-#~ msgid "Map scale:       1:%d"
-#~ msgstr "Scala della mappa:       1:%d"
-#~ msgid "Map format:      %s"
-#~ msgstr "Formato della mappa:      %s"
-#~ msgid "Source date:     %s"
-#~ msgstr "Dati di origine:     %s"
-#~ msgid "  Number of points:       %-9ld       Number of areas:      %-9ld"
-#~ msgstr "  Numero di punti:       %-9ld       Numero di aree:      %-9ld"
-#~ msgid "  Number of lines:        %-9ld       Number of islands:    %-9ld"
-#~ msgstr "  Numero di linee:       %-9ld       Numero di isole:      %-9ld"
-#~ msgid "  Number of boundaries:   %-9ld       Number of faces:      %-9ld"
-#~ msgstr "  Numero di confini:       %-9ld       Numero di facce:      %-9ld"
-#~ msgid "  Number of centroids:    %-9ld       Number of kernels:    %-9ld"
-#~ msgstr "  Numero di centroidi:       %-9ld      Numero di facce:      %-9ld"
-#~ msgid "  Map is 3D:              %s"
-#~ msgstr "  La mappa è 3D:              %s"
-#~ msgid "        Projection: %s (zone %d)"
-#~ msgstr "        Proiezione: %s (zona %d)"
-#~ msgid "        Projection: %s"
-#~ msgstr "        Proiezione: %s"
-#~ msgid "Name of input 2D vector map"
-#~ msgstr "Nome della mappa vettoriale 2D di input"
-#~ msgid "Name of resulting 3D vector map"
-#~ msgstr "Nome della mappa vettoriale 3D risultante"
-#~ msgid "Extruding vector primitives..."
-#~ msgstr "Estrusione delle primitive vettoriali in corso..."
-#~ msgid "Attach, delete or report vector categories to map geometry."
-#~ msgstr "Attacca, elimina o visualizza le categorie per geometrie della mappa."
-#~ msgid "Output slope raster map"
-#~ msgstr "Mappa raster di output delle pendenze"
-#~ msgid "Output aspect raster map"
-#~ msgstr "Mappa raster di output delle esposizioni"
-#~ msgid "Output profile curvature raster map"
-#~ msgstr "Mappa raster di output della curvatura del profilo"
-#~ msgid "Output tangential curvature raster map"
-#~ msgstr "Mappa raster di output della curvatura tangenziale"
-#~ msgid "Output mean curvature raster map"
-#~ msgstr "Mappa raster di output della curvatura media"
-#~ msgid "Quit"
-#~ msgstr "Uscita"
-#~ msgid "New center"
-#~ msgstr "Nuovo centro"
-#~ msgid "Cannot find window '%s'"
-#~ msgstr "Non è possibile trovare la finestra '%s'"
-#, fuzzy
-#~ msgid "Cannot set variable code = %d"
-#~ msgstr "Impossibile impostare la variabile code = %d"
-#~ msgid "Cannot get type of variable %s"
-#~ msgstr "Non è possibile ottenere il tipo della variabile %s"
-#~ msgid "Cannot get code of variable %s"
-#~ msgstr "Non è possibile ottenere il codice della variabile %s"
-#~ msgid "Cannot get name of variable %d"
-#~ msgstr "Non è possibile ottenere il nome della variabile %d"
-#~ msgid "Cannot get value of variable code = %d"
-#~ msgstr "Non è possibile ottenere il valore della variabile = %d"
-#~ msgid "Select tool"
-#~ msgstr "Strumento di selezione"
-#~ msgid "Cannot open driver %s"
-#~ msgstr "Impossibile aprire il driver %s"
-#~ msgid "Cannot open database %s"
-#~ msgstr "Impossibile aprire il database %s"
-#~ msgid "Cannot open driver "
-#~ msgstr "Impossibile aprire il driver"
-#~ msgid "Cannot open database %s by driver %s"
-#~ msgstr "Non è possibile aprire il database <%s> col driver <%s>"
-#~ msgid "Cannot create table: "
-#~ msgstr "Impossibile creare la tabella:"
-#~ msgid "Cannot create index:\n"
-#~ msgstr "Impossibile creare l'indice:\n"
-#~ msgid "Cannot grant privileges on table:\n"
-#~ msgstr "Non è possibile assegnare i permessi sulla tabella:\n"
-#~ msgid "Cannot open driver"
-#~ msgid "Cannot open driver '%s'<BR>"
-#~ msgstr "mpossibile aprire il driver '%s'<BR>"
-#~ msgid "Cannot open database"
-#~ msgstr "Impossibile aprire il database"
-#~ msgid "Cannot open database '%s' by driver '%s'<BR>"
-#~ msgstr "Non è possibile aprire il database '%s' col driver '%s'<BR>"
-#~ msgid "Cannot open select cursor"
-#~ msgstr "Impossibile aprire il cursore selezionato"
-#, fuzzy
-#~ msgid "Cannot fetch next record"
-#~ msgstr "Impossibile inserire il nuovo record: %s"
-# di database
-#~ msgid "No database record"
-#~ msgstr "Nessun record nel database"
-#~ msgid "Select"
-#~ msgstr "Seleziona"
-#~ msgid "Quit tool"
-#~ msgstr "Strumento di uscita"
-#~ msgid "Unselect"
-#~ msgstr "Deseleziona"
-#~ msgid "Cannot open driver\n"
-#~ msgstr "Impossibile aprire il driver\n"
-#~ msgid "Cannot open database\n"
-#~ msgstr "Impossibile aprire il database\n"
-#~ msgid "Cannot describe table\n"
-#~ msgstr "Impossibile descrivere la tabella\n"
-#~ msgid "Cannot find column type"
-#~ msgstr "Impossibile trovare il tipo di colonna"
-#~ msgid "Cannot update table"
-#~ msgstr "Impossibile aggiornare la tabella"
-#~ msgid "New record was created.<BR>"
-#~ msgstr "È stato creato un nuovo record.<BR>"
-#~ msgid "Record for this category already existed.<BR>"
-#~ msgstr "Record per questa categoria già esistente .<BR>"
-#~ msgid "New point"
-#~ msgstr "Nuovo punto"
-#~ msgid "Undo last point"
-#~ msgstr "Annulla l'ultimo punto"
-#~ msgid "Close line"
-#~ msgstr "Concludi la linea"
-#~ msgid "New Point"
-#~ msgstr "Nuovo Punto"
-#~ msgid "Undo Last Point"
-#~ msgstr "Annulla ultimo punto"
-#~ msgid "Cannot create new record."
-#~ msgstr "Impossibile creare un nuovo record"
-# layer: tematismo
-#~ msgid "Database table for this layer is not defined"
-#~ msgstr "La connessione al database non è definita per questo layer"
-#~ msgid "Cannot select record from table %s"
-#~ msgstr "Non è possibile selezionare il record dalla tabella <%s>"
-#~ msgid "Display categories:"
-#~ msgstr "Mostra le categorie:"
-#~ msgid "Select line"
-#~ msgstr "Seleziona linea"
-#~ msgid "Copy attributes:"
-#~ msgstr "Copia gli attributi:"
-#~ msgid "Select the target object"
-#~ msgstr "Seleziona oggetto destinazione"
-#~ msgid "Display attributes:"
-#~ msgstr "Mostra gli attributi"
-#~ msgid "layer: %d<BR>category: %d<BR>"
-#~ msgstr "Layer: %d<BR>categoria: %d<BR>"
-#~ msgid "Database connection not defined<BR>"
-#~ msgstr "Connessione al database non definita<BR>"
-#~ msgid "driver: %s<BR>database: %s<BR>table: %s<BR>key column: %s<BR>"
-#~ msgstr "driver: %s<BR>database: %s<BR>tabella: %s<BR>colonna chiave: %s<BR>"
-#~ msgid "Line %d"
-#~ msgstr "Linea %d"
-#~ msgid "Cannot delete record: %s"
-#~ msgstr "Impossibile eliminare il record: %s"
-# di shell
-#~ msgid "Print all map connection parameters and exit in shell script style"
-#~ msgstr "Stampa tutti i parametri di connessione della mappa ed esce in stile script per la shell"
-#~ msgid "Exports GRASS vector map layers to DXF file format."
-#~ msgstr "Esporta vettore GRASS in un file DXF"
-#~ msgid "DXF output file"
-#~ msgstr "File di output DXF"
-#, fuzzy
-#~ msgid "vector, network, spanning tree"
-#~ msgstr "Esegue la manutenzione della rete."
-#~ msgid "miscellaneous, distance"
-#~ msgstr "Miscellanea, distanza"
-#~ msgid "Reading file [%s]..."
-#~ msgstr "Lettura del file [%s] in corso..."
-#~ msgid "Unable to determine raster cell type"
-#~ msgstr "Impossibile determinare il tipo di cella raster"
-#~ msgid "Unable to read raster row"
-#~ msgstr "Impossibile leggere la riga del raster"
-#, fuzzy
-#~ msgid "List paper formats ( name width height left right top bottom(margin) )"
-#~ msgstr "Elenco dei formati di pagina per la stampa (nome largh. altezza sinistra destra alto basso[margine])"
-#~ msgid "File containing mapping instructions (or use input=- to enter from keyboard)"
-#~ msgstr "File contenente le istruzioni (o usa input=- per inserire da tastiera)"
-#~ msgid "PostScript output file"
-#~ msgstr "File PostScript di output"
-#~ msgid "Scale of the output map, e.g. 1:25000 (default: Auto-sized to fit page)"
-#~ msgstr "Scala della mappa in output, e.g. 1:25000 (default: Adatta alla pagina)"
-#~ msgid ""
-#~ "ERROR: Required parameter <%s> not set:\n"
-#~ "\t(%s)\n"
-#~ msgstr ""
-#~ "ERRORE: Il parametro richiesto <%s> non è stato impostato:\n"
-#~ "\t(%s)\n"
-#~ msgid "Current region cannot be set."
-#~ msgstr "La regione corrente non può essere impostata."
-#~ msgid "Cannot set GRASS_VERBOSE variable."
-#~ msgstr "Impossibile impostare la variabile GRASS_VERBOSE."
-#~ msgid "Reading raster maps in group <%s> ..."
-#~ msgstr "Lettura della mappa raster nel gruppo <%s> in corso ..."
-#~ msgid "OGR driver: column '%s', OGR type %d  is not supported"
-#~ msgstr "driver OGR: colonna '%s', il tipo %d non è supportato"
-#~ msgid "database, attribute table"
-#~ msgstr "database, tabella degli attributi"
-#~ msgid "database, attribute table, SQL"
-#~ msgstr "database, tabella degli attributi, SQL"
-#~ msgid "database, attribute table, connection settings"
-#~ msgstr "database, tabella degli attributi, impostazioni di connessione"
-#~ msgid "Prints/sets general DB connection for current mapset and exits."
-#~ msgstr "Stampa/imposta la connessione generale al DB per il mapset corrente ed esce."
-#~ msgid "Do not use this option if schemas are not supported by driver/database server"
-#~ msgstr "Non utilizzare questa opzione se lo schema non è supportato dal driver/database server"
-#~ msgid "database, SQL"
-#~ msgstr "database, SQL"
-#~ msgid "Name of file with sql statement"
-#~ msgstr "Nome del file con l'istruzione sql"
-#~ msgid ""
-#~ "\n"
-#~ "Enter database password for connection\n"
-#~ "<%s:%s:user=%s>\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Inserisci la password del database per la connessione\n"
-#~ msgid "Exiting. Not changing current settings"
-#~ msgstr "Sto uscendo. Senza cambiare le impostazioni correnti"
-#~ msgid "New password set"
-#~ msgstr "Nuova password impostata"
-#~ msgid "The password was stored in file"
-#~ msgstr "La password è stata archiviata nel file"
-#~ msgid "Select multiple points"
-#~ msgstr "Seleziona punti multipli"
-#~ msgid "Exports GRASS raster into GDAL supported formats."
-#~ msgstr "Esporta un raster GRASS nei formati supportati da GDAL"
-#~ msgid "raster, elevation"
-#~ msgstr "raster, elevazione"
-#~ msgid "Images"
-#~ msgstr "Immagini"
-#~ msgid "Width and height of output image (overrides resolution setting)"
-#~ msgstr "Larghezza e altezza dell'immagine di output (sovrascrive le impostazioni della risoluzione)"
-#~ msgid "Compression for PNG files"
-#~ msgstr "Compressione per i file PNG"
-#~ msgid "File size/quality for JPEG files"
-#~ msgstr "Dimensione/qualità del file per JPEG"
-#~ msgid "PostScript"
-#~ msgstr "PostScript"
-#~ msgid "Set background color to black (white default)"
-#~ msgstr "Imposta il colore dello sfondo nero (default bianco)"
-#~ msgid "Set transparent background"
-#~ msgstr "Imposta sfondo trasparente"
-#~ msgid "Use the Cario driver to render images"
-#~ msgstr "Usa il driver Cario per restituire immagini"
-#~ msgid "Set paper orientation to landscape (for PostScript output)"
-#~ msgstr "Imposta l'orientazione del foglio in orizzontale (per uscita PostScript)"
-#~ msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2)"
-#~ msgstr "Nome del raster di input (NIR: tm4 | qbird_nir | spot2)"
-#~ msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3)"
-#~ msgstr "Nome del raster di input (MIR; tm5 | qbird_red | spot3)"
-#~ msgid "Import SRTM HGT files into GRASS"
-#~ msgstr "Importa file SRTM HGT in GRASS"
-#~ msgid "Reports geometry statistics for vectors."
-#~ msgstr "Riporta le statistiche delle geometrie per i vettoriali"
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
-#~ msgstr "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
-#~ msgid "Raster map to use as MASK"
-#~ msgstr "Mappa raster da usare come MASK"
-#~ msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
-#~ msgstr "Categorie dei valori da usare per la MASK (formato: 1 2 3 thru 7 *)"
-#~ msgid "Create inverse MASK from specified 'maskcats' list"
-#~ msgstr "Crea una MASK inversa da un specificata lista di 'maskcats'"
-#~ msgid "Overwrite existing MASK"
-#~ msgstr "Sovrascrivi la MASK esistente"
-#~ msgid "Layer number of data column"
-#~ msgstr "Numero del layer della colonna dei dati"
-#~ msgid "Slide show of GRASS raster/vector maps."
-#~ msgstr "Slide show delle mappe raster e vettoriali."
-#~ msgid "Show vector maps rather than raster maps"
-#~ msgstr "Mostra i vettoriali piuttosto che i raster"
-#~ msgid "Mapsets to use. Specify multiple mapsets comma separated"
-#~ msgstr "Mapset da usare. Specificare multipli mapset separati dalla virgola"
-#~ msgid "Download waypoints, routes, and tracks from a Garmin GPS receiver into a vector map."
-#~ msgstr "Scarica punti di interesse, rotte e tracce da un GPS Garmin in un vettore"
-#~ msgid "Download Waypoints from GPS"
-#~ msgstr "Scarica punti di rilevamento da un GPS"
-#~ msgid "Download Routes from GPS"
-#~ msgstr "Scarica Rotte da un GPS"
-#~ msgid "Download Track from GPS"
-#~ msgstr "Scarica Traccia da un GPS"
-#~ msgid "Port Garmin receiver is connected to"
-#~ msgstr "La porta del ricevitore Garmin è connessa a"
-#~ msgid "Calculates univariate statistics from a raster map based on vector polygons and uploads statistics to new attribute columns."
-#~ msgstr "Calcola statistiche univariate da un raster basandosi su poligoni vettoriali e carica le statistiche in una nuova colonna della tabella degli attributi."
-#~ msgid "Name of .dmrc settings file"
-#~ msgstr "Nome del file di impostazioni .dmrc"
-#~ msgid "Resizes active display monitor"
-#~ msgstr "Ridimensiona il monitor attivo visualizzato"
-#~ msgid "Percentile to calculate (requires -e flag)"
-#~ msgstr "Percentuale da calcolare (richiede il flag -e)"
-#~ msgid "Calculate new raster map from a r.mapcalc expression."
-#~ msgstr "Calcola una nuova mappa raster da un'espressione di r.mapcalc"
-#~ msgid "A"
-#~ msgstr "A"
-#~ msgid "B"
-#~ msgstr "B"
-#~ msgid "C"
-#~ msgstr "C"
-#~ msgid "D"
-#~ msgstr "D"
-#~ msgid "E"
-#~ msgstr "E"
-#~ msgid "F"
-#~ msgstr "F"
-#~ msgid "Formula (e.g. A-B or A*C+B)"
-#~ msgstr "Formula (p.e. A-B o A*C+B)"
-#~ msgid "Show help"
-#~ msgstr "Mostra help"
-#~ msgid "Expert mode (enter a set of r.mapcalc expressions)"
-#~ msgstr "Modo esperto (inserisci un set di espressioni di r.mapcalc)"
-#~ msgid "Do not overwrite existing map"
-#~ msgstr "Non sovrascrive la mappa esistente"
-#~ msgid "Selects/starts specified monitor at specified size"
-#~ msgstr "Selezione/avvia il monitor specificato alla dimensione specificata"
-#~ msgid "Display monitor to start"
-#~ msgstr "Mostra monitor all'avvio"
-#~ msgid "Import waypoints, routes, and tracks from a GPS receiver or GPS download file into a vector map."
-#~ msgstr "Scarica punti di interesse, rotte e tracce da un GPS o da un file di dati scaricati da un GPS in un vettore"
-#~ msgid "Import track"
-#~ msgstr "Importa tracce"
-#~ msgid "Device or file used to import data"
-#~ msgstr "Dispositivo o file utilizzato per l'importazione dei dati"
-#~ msgid "Format of GPS input data (use gpsbabel supported formats)"
-#~ msgstr "Formato dei dati di input del GPS (usare formati supportati da gpsbabel)"
-#~ msgid "Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is assumed"
-#~ msgstr "Proiezione dei dati in input (modello PROJ.4), se non impostato è utilizzato WGS84 Lat/Lon"
-#~ msgid "Layer number. If -1, all layers are extracted."
-#~ msgstr "Numero del layer. Se -1, tutti i layer sono estratti."
-#~ msgid "Expert mode (enter a set of r3.mapcalc expressions)"
-#~ msgstr "Modo esperto (inserisci un set di espressioni r3.mapcalc)"
-#~ msgid "Import GetFeature from WFS"
-#~ msgstr "Importa GetFeature da WFS"
-#~ msgid "Saves active display monitor to PNG file in home directory"
-#~ msgstr "Salva il monitor attivo visualizzato in un file PNG nella directory home"
-#~ msgid "Name of PNG file"
-#~ msgstr "Nome del file PNG"
-#~ msgid "Resolution of output file (single=1, double=2, quad=4)"
-#~ msgstr "Risoluzione del file di uscita (singolo=1, doppio=2, quadruplo=4)"
-#~ msgid "raster, landscape structure analysis"
-#~ msgstr "raster, analisi della struttura del paesaggio"
-#~ msgid "Import of SPOT VGT NDVI file into a raster map"
-#~ msgstr "Importa file SPOT VGT NDVI in un raster"
-#~ msgid "Moves displayed maps to another monitor"
-#~ msgstr "Sposta le mappe visualizzate su un altro monitor"
-#~ msgid "Target monitor"
-#~ msgstr "Monitor di destinazione"
-#~ msgid "Source monitor"
-#~ msgstr "Monitor di origine"
-#~ msgid "Unable to read raster map row %ld"
-#~ msgstr "Impossibile leggere la riga %ld del raster"
-#~ msgid "Failed writing raster map row %ld"
-#~ msgstr "Scrittura della riga %ld del raster non riuscita"
-#~ msgid "Writing data..."
-#~ msgstr "Scrittura dei dati in corso..."
-#~ msgid "imagery, statistics"
-#~ msgstr "immagini, statistiche"
-#~ msgid "Group [%s] not found"
-#~ msgstr "Gruppo [%s] non trovato"
-#~ msgid "Could not open elevation raster"
-#~ msgstr "Impossibile aprire il raster dell'elevazione"
-#~ msgid "Could not read REF file for group <%s>"
-#~ msgstr "Impossibile leggere il file REF per il gruppo <%s>"
-#~ msgid "Computing equations..."
-#~ msgstr "Calcolo delle equazioni in corso......"
-#~ msgid "Can not generate the transformation equation.\n"
-#~ msgstr "Impossibile generare l'equazione di trasformazione.\n"
-#~ msgid "Target location <%s> not found\n"
-#~ msgstr "Location di destinazione <%s> non trovata\n"
-#~ msgid "permission denied\n"
-#~ msgstr "permesso negato\n"
-#~ msgid "not found\n"
-#~ msgstr "non trovato\n"
-#~ msgid "Rectified input raster map <%s> will be saved as <%s>"
-#~ msgstr "Il raster di input rettificata <%s> verrà salvata come <%s>"
-# target?
-#~ msgid "Target location [%s] not found\n"
-#~ msgstr "Location di destinazione [%s] non trovata\n"
-#~ msgid "Mapset [%s] in target location [%s] - "
-#~ msgstr "Mapset [%s] nella location di destinazione [%s] - "
-#~ msgid "Computing equations ..."
-#~ msgstr "Calcolo delle equazioni in corso..."
-#~ msgid "Unable to read raster header of <%s>"
-#~ msgstr "Impossibile leggere l'intestazione del raster di <%s>"
-#~ msgid "Pre-selected group <%s> not found"
-#~ msgstr "Il gruppo preselezionato <%s> non è stato trovato"
-#~ msgid "Group [%s] contains no files"
-#~ msgstr "Il gruppo [%s] non contiene file"
-#~ msgid "Could not read REF file for group [%s]"
-#~ msgstr "Impossibile leggere il file REF per il gruppo [%s]"
-#~ msgid ""
-#~ "\n"
-#~ "Rectify all images in the group? "
-#~ msgstr ""
-#~ "\n"
-#~ "Rettificare tutte le immagini del gruppo? "
-#~ msgid "Map name <%s> is illegal"
-#~ msgstr "Il nome della mappa <%s> non è valido"
-#~ msgid ""
-#~ "\n"
-#~ "Choose another name? "
-#~ msgstr ""
-#~ "\n"
-#~ "Si vuol scegliere un altro nome? "
-#~ msgid "Please select one of the following interpolation methods\n"
-#~ msgstr "Selezionare uno dei seguenti metodi di interpolazione\n"
-#~ msgid "usage: %s file [prompt %%x %%y]\n"
-#~ msgstr "uso: %s file [prompt %%x %%y]\n"
-#~ msgid "name=%s\n"
-#~ msgstr "name=%s\n"
-#~ msgid "mapset=%s\n"
-#~ msgstr "mapset=%s\n"
-#~ msgid "fullname=%s\n"
-#~ msgstr "fullname=%s\n"
-#~ msgid "Name (flag -i) or prefix for output raster maps"
-#~ msgstr "Nome (flag -i) o prefisso per il raster di output"
-#~ msgid "Elevation raster map of unknown type"
-#~ msgstr "Raster dell'elevazione di tipologia sconosciuta"
-#~ msgid "Reflectance of raster map <%s> is not of DCELL type - ignored"
-#~ msgstr "La riflettanza della mappa raster <%s> non è di tipo DCELL - ignorato"
-#~ msgid "imagery, classification"
-#~ msgstr "immagini, classificazione"
-#, fuzzy
-#~ msgid ""
-#~ "Input raster map <%s> does not exist in group <%s>.\n"
-#~ " Try:\n"
-#~ msgstr ""
-#~ "La mappa raster <%s> non esiste nel gruppo <%s>.\n"
-#~ " Provare:\n"
-#, fuzzy
-#~ msgid "Error while writing to temp file"
-#~ msgstr "Errore durante la scrittura sul file temporaneo"
-#~ msgid "Selects data from table."
-#~ msgstr "Seleziona dati dalla tabella"
-#, fuzzy
-#~ msgid "Exporting raster as double values (bytes=%d)"
-#~ msgstr "Esportazione in corso del raster come valori a precisione doppia (double) (bytes=%d)"
-#, fuzzy
-#~ msgid "Reading map"
-#~ msgstr "Lettura della mappa"
-#~ msgid "Signed data (high bit means negative value)"
-#~ msgstr "Dati costituiti da numeri relativi (un bit alto significa valore negativo)"
-#~ msgid "Number of bytes per cell (1, 2, 4)"
-#~ msgstr "Numero di byte per cella (1, 2, 4)"
-#~ msgid ""
-#~ "Missing parameters ...\n"
-#~ "Must provide at least[north= south= east= west=] OR [r=\tc=]"
-#~ msgstr "Si deve fornire almeno [north= south= east= west=] O [r=\tc=]"
-#, fuzzy
-#~ msgid "You have to provide all limits of geographic region (n,s,e,w)"
-#~ msgstr "Si devono fornire tutti i limiti della regione geografica (n,s,e,o)"
-#, fuzzy
-#~ msgid "Illegal number of rows <%s>"
-#~ msgstr "Numero di righe <%s> non valido"
-#, fuzzy
-#~ msgid "Illegal number of columns <%s>"
-#~ msgstr "Numero di colonne <%s> non valido"
-#~ msgid "Using N=%f S=%f E=%f W=%f"
-#~ msgstr "Si sta usando N=%f S=%f E=%f O=%f"
-#, fuzzy
-#~ msgid "Using rows=%d cols=%d\n"
-#~ msgstr "Si sta usando righe=%d cols=%d\n"
-#~ msgid "Conversion failed at row %d"
-#~ msgstr "Conversione non riuscita alla riga %d"
-#, fuzzy
-#~ msgid "<%s> created"
-#~ msgstr "Location %s creata!"
-#, fuzzy
-#~ msgid "Raster map to be displayed"
-#~ msgstr "Mappa(e) raster da leggere"
-#, fuzzy
-#~ msgid "Cannot generate the transformation equation."
-#~ msgstr "Stampa matrice di correlazione"
-#~ msgid "Unable to write temp file: %s"
-#~ msgstr "Impossibile scrivere il file temp: %s"
-#~ msgid "Unable to open map %s"
-#~ msgstr "Impossibile aprire la mappa %s"
-#~ msgid "Unable to write row %d"
-#~ msgstr "Impossibile scrivere la riga %d"
-#, fuzzy
-#~ msgid "%s@%s: projection doesn't match current settings"
-#, fuzzy
-#~ msgid "%s@%s: zone doesn't match current settings"
-#, fuzzy
-#~ msgid "vector, projection"
-#~ msgstr "Nome del raster"
-#~ msgid "Allows projection conversion of vector maps."
-#~ msgstr "Permette la conversione di proiezione per vettoriali"
-#, fuzzy
-#~ msgid "Vector output map"
-#~ msgstr "Mappa vettoriale in uscita"
-#, fuzzy
-#~ msgid "Location of input raster map"
-#~ msgstr "Nome di  2-%d mappe raster in input"
-#, fuzzy
-#~ msgid "Mapset of input raster map"
-#, fuzzy
-#~ msgid "Checking location <%s>, mapset <%s>..."
-#~ msgstr "Mappa raster in input"
-#, fuzzy
-#~ msgid "Can't open range file for %s"
-#~ msgstr "Non riesco ad impostare user/password"
-#, fuzzy
-#~ msgid "Can't read row in input elevation map"
-#, fuzzy
-#~ msgid "Unable to open rules file <%s>"
-#~ msgstr "Non riesco ad aprire il cellfile per [%s]"
-#, fuzzy
-#~ msgid "Starting map [%s]"
-#~ msgstr "Non riesco a trovare il file raster %s"
-#~ msgid "Percent done:"
-#~ msgstr "Percentuale fatta:"
-#~ msgid "New MAPSET name"
-#~ msgstr "Nome del nuovo MAPSET"
-#, fuzzy
-#~ msgid "Displays and overlays raster map layers in the active display frame on the graphics monitor."
-#~ msgstr "Seleziona il tipo di carattere con cui il testo deve essere rappresentato nel monitor grafico dell'utente."
-#~ msgid "                No topology present"
-#~ msgstr "                Nessuna topologia presente"
-#, fuzzy
-#~ msgid "Failed in attempt to open %s"
-#~ msgstr "impossibile aprire <%s>"
-#~ msgid "Generates raster map layers of slope, aspect, curvatures and partial derivatives from a raster map layer of true elevation values. Aspect is calculated counterclockwise from east."
-#~ msgstr "Genera raster della pendenza, esposizione, curvature e le derivate parziali da un raster con valori dell'elevazione. Esposizione è calcolata in senso antiorario partendo dall'est."
-#, fuzzy
-#~ msgid "Output slope filename"
-#~ msgstr "Nome della tabella in output"
-#, fuzzy
-#~ msgid "Output profile curvature filename"
-#~ msgstr "Nome del driver in output"
-#, fuzzy
-#~ msgid "Output tangential curvature filename"
-#~ msgstr "Nome del database in output"
-#, fuzzy
-#~ msgid "Creating support files..."
-#~ msgstr "Errore nella lettura del file dbmscap\n"
-#, fuzzy
-#~ msgid "Elevation products for mapset [%s] in [%s]"
-#, fuzzy
-#~ msgid "raster, terrain analysis"
-#~ msgstr "Nome della mappa raster da utilizzare per <%s>"
-#, fuzzy
-#~ msgid "Unable to open MASK"
-#~ msgid "Uses a GRASS vector points map to produce a convex hull vector map."
-#~ msgstr "Usa un vettoriale di punti per produrre un vettoriale di poligoni convessi."
-#, fuzzy
-#~ msgid "Name of output vector area map"
-#~ msgstr "Nome della mappa di input"
-#, fuzzy
-#~ msgid "<Auxiliar_edge_table> created in database."
-#~ msgstr "La tabella <%s> non esiste nel database <%s>"
-#, fuzzy
-#~ msgid "Unable to open table <%s_edge_Interpolation>"
-#~ msgstr "Impossibile copiare la tabella <%s>"
-#, fuzzy
-#~ msgid "M.Q. solution"
-#~ msgstr "Risoluzione"
-#~ msgid ""
-#~ "Do you wish it printed in 80 o 132 columns?\n"
-#~ msgstr ""
-#~ "Lo si vuol sampare in 80 o 132 colonne?\n"
-#~ msgid "Converts a 3D raster map layer into an ASCII text file."
-#~ msgstr "Converte un tematismo raster 3D in un file di testo ASCII"
-# tematismo raster
-#~ msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
-#~ msgstr "Converte un file testuale raster ASCII 3D in un tematismo raster 3D (binario)"
-#~ msgid "Wrong 3D raster map datatype! Unable to create raster map."
-#~ msgstr "Il tipo di dati della mappa raster 3D è errato! Non è possibile creare la mappa raster."
-#~ msgid "Use the same resolution as the input 3D raster map for the 2D outputmaps, independent of the current region settings"
-#~ msgstr "Utilizza la stessa risoluzione della mappa raster 3D di input per le mappe di output 2D, indipendentemente dalle impostazioni attuali della regione"
-#~ msgid "Raster map %d Filename: %s already exists. Will be overwritten!"
-#~ msgstr "Mappa raster %d Nome del file: %s già esistente. Sarà sovrascritto!"
-#~ msgid "No RGB Data will be created"
-#~ msgstr "Non verrà creato nessun dato RGB."
-#~ msgid "No vector data will be created"
-#~ msgstr "Non verrà creato nessun dato vettoriale."
-#~ msgid "Unable to close top raster map"
-#~ msgstr "impossibile chiudere la mappa raster superiore"
-#~ msgid "Unable to close bottom raster map"
-#~ msgstr "impossibile chiudere la mappa raster inferiore"
-#~ msgid "Unable to close input raster map"
-#~ msgstr "impossibile chiudere la mappa raster di input"
-#~ msgid "G3D map(s) to be converted to VTK-ASCII data format"
-#~ msgstr "Mappa/e G3D da convertire nel formato VTK-ASCII"
-#~ msgid "Unable to read top raster row \n"
-#~ msgstr "Impossibile leggere la riga del raster superiore \n"
-#~ msgid "Unable to read bottom raster row \n"
-#~ msgstr "Impossibile leggere la riga del raster inferiore \n"
-#~ msgid "Wrong 3D raster map values: Values should in between 0 and 255\n"
-#~ msgstr "Valori della mappa raster 3D errati! I valori devono essere compresi tra 0 e 255\n"
-#~ msgid ""
-#~ "Cannot create mask file: G3D_MASK already exists!\n"
-#~ " Use 'g.remove rast3d=G3D_MASK' to remove the existing mask."
-#~ msgstr ""
-#~ "Impossibile creare la mask. MASK G3D già esistente!\n"
-#~ "Usa il comando 'g.remove rast3d=G3D MASK' per rimuovere la maschera esistente"
-#~ msgid "Name of base raster map"
-#~ msgstr "Nome della mappa raster di base"
-#~ msgid "Export GRASS raster as non-georeferenced PNG image."
-#~ msgstr "Esporta raster GRASS come immagine PNG non georeferenziata"
-#~ msgid "Unable to read %s"
-#~ msgstr "impossibile leggere %s"
-#~ msgid "Which raster map needs a color table"
-#~ msgstr "Quale raster necessita una tabella dei colori"
-#~ msgid "Exports the color table associated with a raster map layer."
-#~ msgstr "Esporta la tavola dei colori associata ad un tematismo raster"
-#~ msgid "latin raster map <%s> not found"
-#~ msgstr "mappa raster latin <%s> non trovata"
-#~ msgid "Name for output raster map (default: input)"
-#~ msgstr "Nome per la mappa raster di output (predefinito: input)"
-#~ msgid "Reading file"
-#~ msgstr "Lettura del file"
-#~ msgid "No raster map specified"
-#~ msgstr "Nessuna mappa raster specificata"
-#~ msgid "One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be specified!"
-#~ msgstr "Dev'essere specificato \"-i\" o \"-r\", o le opzioni \"color\", \"rast\" o \"rules\"!"
-#~ msgid "Unable to remove color table of raster map <%s>"
-#~ msgstr "Non è possibile rimuovere la tavola dei colori della mappa raster <%s>"
-#~ msgid "Color table of raster map <%s> not found"
-#~ msgstr "Tavola dei colori della mappa raster <%s> non trovata"
-#~ msgid "Color table 'random' is not supported for floating point raster map"
-#~ msgstr "La tavola dei colori 'random' non è supportata dai raster con valori a virgola mobile"
-#~ msgid "Color table 'grey.eq' is not supported for floating point raster map"
-#~ msgstr "La tavola dei colori 'grey.eq' non è supportata dai raster con valori a virgola mobile"
-#~ msgid "Color table 'grey.log' is not supported for floating point raster map"
-#~ msgstr "La tavola dei colori 'grey.log' non è supportata dai raster con valori a virgola mobile"
-#~ msgid "Color table for raster map <%s> set to '%s'"
-#~ msgstr "Tavola dei colori per la mappa raster <%s> impostata a '%s'"
-# della quale/per la quale
-#~ msgid "Name of raster map for which to edit null file"
-#~ msgstr "Nome della mappa raster della quale modificare il valore null"
-#~ msgid "Raster file to be linked"
-#~ msgstr "Il file raster da collegare"
-#~ msgid "Unable to read range of raster map <%s>"
-#~ msgstr "Non è possibile leggere l'intervallo dati della mappa raster <%s>"
-#~ msgid "Reports statistics for raster map layers."
-#~ msgstr "Statistiche per raster"
-#~ msgid "Use G3D mask (if exists) with output map"
-#~ msgstr "Usa una mask G3D (se esiste) con la mappa di output"
-#~ msgid "Cell file not found"
-#~ msgstr "File di celle non trovato"
-#~ msgid "Unable to load 3D raster range"
-#~ msgstr "Non è possibile caricare il campo di variazione del raster 3D"
-#~ msgid "Unable to open file [%s] for reading"
-#~ msgstr "Impossibile aprire il file [%s] per la lettura"
-#~ msgid "Can also be used to create GRASS locations."
-#~ msgstr "Può essere usato anche per creare le location di GRASS"
-#~ msgid "Print projection information (in conventional GRASS format)"
-#~ msgstr "Stampa le informazioni di proiezione in formato GRASS"
-#~ msgid "Georeferenced data file to read projection information from"
-#~ msgstr "File di dati georeferenziati dai quali leggere le informazioni di proiezione"
-#~ msgid "ASCII file containing a WKT projection description (- for stdin)"
-#~ msgstr "File ASCII contenente la descrizione di una proiezione WKT (- per stdin)"
-#~ msgid "PROJ.4 projection description (- for stdin)"
-#~ msgstr "Descrizione della proiezione in stile PROJ4 (- per sdin)"
-#~ msgid "Unable to create location: %s"
-#~ msgstr "Non è possibile creare la location: %s"
-#~ msgid "You must select the PERMANENT mapset before updating the current location's projection. (Current mapset is %s)"
-#~ msgstr "Devi selezionare il mapset PERMANENT prima di aggiornare la proioezione corrente della localtion. (Il mapset corrente è %s)"
-#~ msgid "Projection information updated!"
-#~ msgstr "Informazioni sulla proiezione aggiornate!"
-#~ msgid "Names of mask files"
-#~ msgstr "Nome del file MASK"
-#~ msgid "Changes current mapset."
-#~ msgstr "Cambia il mapset corrente."
-#~ msgid "Remove base maps"
-#~ msgstr "Rimuove le mappe di base"
-#~ msgid "Interactively edit cell values in a raster map."
-#~ msgstr "Modifica interattivamente i valori delle celle in un raster."
-#~ msgid "Monitor '%s' terminated"
-#~ msgstr "Monitor '%s' chiuso"
-#~ msgid "Error - Monitor '%s' was not running"
-#~ msgstr "Errore - Il monitor '%s' non è avviato"
-#~ msgid "Monitor <%s> in use by another user"
-#~ msgstr "Monitor <%s> è in uso da un altro utente"
-#~ msgid "Name of graphics monitor to start"
-#~ msgstr "Nome del monitor grafico da avviare"
-#~ msgid "Name of graphics monitor to stop"
-#~ msgstr "Nome del monitor grafico da chiudere"
-#~ msgid "Name of graphics monitor to select"
-#~ msgstr "Nome del monitor grafico da selezionare"
-#~ msgid "List all monitors"
-#~ msgstr "Mostra di tutti i monitor"
-#~ msgid "Print name of currently selected monitor"
-#~ msgstr "Stampa il nome del monitor attualmente selezionato"
-#~ msgid "Type of color table (for use with -z flag)"
-#~ msgstr "Tipo di tavola dei colori (da usare con il flag -z)"
-#~ msgid "Line width column (%s) is not numeric."
-#~ msgstr "La colonna dello spessore di linea (%s) non è numerica."
-#~ msgid "Symbol size column not specified."
-#~ msgstr "Colonna delle dimensioni dei simboli non specificata"
-#~ msgid "Symbol size column (%s) is not numeric."
-#~ msgstr "La colonna delle dimensioni dei simboli (%s) non è numerica."
-#~ msgid "Symbol rotation column not specified."
-#~ msgstr "Colonna della rotazione dei simboli non specificata"
-#~ msgid "Symbol rotation column (%s) is not numeric."
-#~ msgstr "La colonna della rotazione dei simboli (%s) non è numerica."
-#~ msgid "Allocate subnets for nearest centres (direction from centre)."
-#~ msgstr "Assegna sottoreti per i centri più vicini (direzione dal centro)."
-#~ msgid "Centre node must be opened (costs >= 0). Costs of centre node are used in calculation"
-#~ msgstr "Il nodo definito come centro dev'essere aperto (costi >= 0). I costi del nodo centrale vengono utilizzati nel calcolo"
-#~ msgid "Categories of centres (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
-#~ msgstr "Categorie dei centri (punti o nodi) ai quali dev'essere assegnata la rete, il layer per queste categorie è dato dall'opzione nlayer"
-#~ msgid "Number of centres: [%d] (nlayer: [%d])"
-#~ msgstr "Numero di centri: [%d] (nlayer: [%d])"
-#~ msgid "Calculating costs from centres ..."
-#~ msgstr "Calcolo dei costi dai centri in corso ..."
-#~ msgid "Counting polygons for %d features..."
-#~ msgstr "Conteggio dei poligoni per %d elementi in corso..."
-#~ msgid "Cannot read part of geometry"
-#~ msgstr "Non è possibile leggere parte della geometria"
-#~ msgid "Cannot write part of geometry"
-#~ msgstr "Non posso scrivere parte della geometria"
-#~ msgid "Selects vector objects from an existing vector map and creates a new map containing only the selected objects."
-#~ msgstr "Seleziona oggetti vettoriali da una mappa esistente e crea una nuova mappa contenento solo gli oggetti selezionati."
-#~ msgid "%d categories loaded from table <%s>"
-#~ msgstr "%d categrie caricate dalla tabella <%s>"
-#~ msgid "No attribute table found"
-#~ msgstr "Non è stata trovata nessuna tabella degli attributi"
-#~ msgid "Name of input DXF file"
-#~ msgstr "Nomi del file DXF di input"
-#, fuzzy
-#~ msgid "Name of column name with route ids"
-#~ msgstr "Nome della colonna da visualizzare"
-#, fuzzy
-#~ msgid "Name of column name with stop timestamps"
-#~ msgstr "Nome della colonna coi parametri di smoothing"
-#, fuzzy
-#~ msgid "Name of column name with stop ids"
-#, fuzzy
-#~ msgid "Name of column name with walk lengths"
-#~ msgstr "Numero di colonne nella nuova regione"
-#~ msgid "If not given reads from standard input"
-#~ msgstr "Se non è dato legge dallo tandard input"
-#~ msgid "New location"
-#~ msgstr "Nuova posizione"
-#~ msgid "No categories"
-#~ msgstr "Nessuna categoria"
-#~ msgid "Unable to read color file"
-#~ msgstr "Impossibile leggere il file dei colori"
-#~ msgid "Database schema"
-#~ msgstr "Schema del database"
-#~ msgid "Removes a table from database."
-#~ msgstr "Elimina una tabella da un database"
-#~ msgid "database, connection settings"
-#~ msgstr "database, impostazioni di connessione"
-#~ msgid "Raster input maps"
-#~ msgstr "Mappe raster in input"
-#~ msgid "Import E00 file into a vector map."
-#~ msgstr "Importa file E00 in un vettore"
-#~ msgid "Name for output file (do NOT add extension)"
-#~ msgstr "Nome del file di output (senza aggiungere l'estensione)"
-#~ msgid "Column to be updated with the query result"
-#~ msgstr "Colonna da aggiornare con il risultato della query"
-#~ msgid "vector, report, statistics"
-#~ msgstr "vettoriale, reportistica, statistiche"
-#~ msgid "Name of raster map to generate legend from"
-#~ msgstr "Nome della mappa raster da cui generare la legenda"
-#~ msgid "Display the HTML man pages of GRASS"
-#~ msgstr "Visualizza la pagina di supporto HTML di GRASS "
-#~ msgid "Exports a vector map to a GPS receiver or file format supported by GpsBabel."
-#~ msgstr "Esporta un vettore in un GPS o un file con un formato supportato da GPSBabel"
-#~ msgid "GpsBabel supported output format"
-#~ msgstr "Formato di output supportato da GpsBabel"
-#~ msgid "Name of the column"
-#~ msgid "Export a raster map to a text file as x,y,z values based on cell centers."
-#~ msgstr "Esporta un raster in un file di testo come valori x,y,z basato sui centri delle celle"
-#~ msgid "Fills no-data areas in raster maps using v.surf.rst splines interpolation"
-#~ msgstr "Riempi aree senza dati di un raster usando interpolazione spline v.surf.rst "
-#~ msgid "raster input map (LANDSAT channel 1)"
-#~ msgstr "raster di input (LANDSAT canale 1)"
-#~ msgid "raster input map (LANDSAT channel 2)"
-#~ msgstr "raster di input (LANDSAT canale 2)"
-#~ msgid "raster input map (LANDSAT channel 3)"
-#~ msgstr "raster di input (LANDSAT canale 3)"
-#~ msgid "raster input map (LANDSAT channel 4)"
-#~ msgstr "raster di input (LANDSAT canale 4)"
-#~ msgid "raster input map (LANDSAT channel 5)"
-#~ msgstr "raster di input (LANDSAT canale 5)"
-#~ msgid "raster input map (LANDSAT channel 7)"
-#~ msgstr "raster di input (LANDSAT canale 7)"
-#~ msgid "Vector map for which to add new attribute table"
-#~ msgstr "Mappa vettoriale per la quale aggiungere una nuova tabella degli attributi"
-#~ msgid "Name of aspect raster map"
-#~ msgstr "Nome della mappa raster delle esposizioni"
-#~ msgid "Name of the column to drop"
-#~ msgstr "Nome della colonna da eliminare"
-#~ msgid "Name of optional EPS output file"
-#~ msgstr "Nome del file EPS opzionale di output"
-#~ msgid "Creates, edits, and lists groups and subgroups of imagery files."
-#~ msgstr "Crea, modifica ed elenca gruppi e sottogruppi di file di immagini."
-#~ msgid "Name of reflectance raster maps to be corrected topographically"
-#~ msgstr "Nome delle mappe raster di riflettanza da correggere topograficamente"
-#~ msgid "Name of input base raster map (elevation or illumination)"
-#~ msgstr "Nome della mappa raster di base in input (elevazione o illuminazione)"
-# terrain model ?
-#~ msgid "Output sun illumination terrain model"
-#~ msgstr "Produce un modello di illuminazione del terreno"
-#, fuzzy
-#~ msgid "Could not close G3D map"
-#~ msgstr "Impossibile chiudere la mappa G3D"
-#, fuzzy
-#~ msgid "Could not close G3D map <%s>"
-#~ msgstr "impossibile chiudere la mappa G3D <%s>"
-#~ msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
-#~ msgstr "Converte una mappa raster 3D (G3D) nel formato VTK-Ascii"
-#, fuzzy
-#~ msgid "Use G3D mask (if exists)"
-#~ msgstr "Usa una mask G3D (se esiste)"
-#~ msgid "Name of an existing raster map layer"
-#~ msgstr "Nome di una mappa raster esistente"
-#~ msgid "Name of elevation raster map"
-#~ msgstr "Nome della mappa raster dell'elevazione"
-#, fuzzy
-#~ msgid "unable to open MASK"
-#~ msgid "visualization, raster, vector, raster3d"
-#~ msgstr "visualizzazione, raster, vettore, raster3d"
-#~ msgid "This does nothing. It is retained for backwards compatibility"
-#~ msgstr "Non fa nulla.È mantenuto per retrocompatibilità"
-#~ msgid "Unused"
-#~ msgstr "Non usato"
-# row%s : singolare/plurale?
-#~ msgid "Header indicates %d row%s in the raster map, but the actual file format indicates %d row%s"
-#~ msgstr "L'intestazione indica n. %d righe (row%s) nella mappa raster, ma il formato reale del file indica n. %d righe (row%s)"
-#~ msgid "Edit header for [%s]? "
-#~ msgstr "Modificare l'intestazione per [%s]?"
-#~ msgid ""
-#~ "\n"
-#~ "The null file for [%s] may indicate that some cells contain\n"
-#~ " no data. If the null file for [%s] doesn't exist, zero cells in\n"
-#~ " it are treated by GRASS application programs as no data."
-#~ msgstr ""
-#~ "\n"
-#~ "Il file null per [%s] può indicare che alcune celle non contengono\n"
-#~ " dati. Se non esiste il file null per [%s], questo verrà trattato\n"
-#~ " dai programmi applicativi di GRASS come se avesse zero celle senza dati"
-#~ msgid "Quant table not changed for %s"
-#~ msgstr "Tabella di quantizzazione invariata per %s"
-#~ msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead"
-#~ msgstr "Il flag '-q' è superato e in futuro verrà rimosso. Usare invece '--quiet"
-#~ msgid "Mode 1: instantaneous solar incidence angle & irradiance given a set local time"
-#~ msgstr "Modalità 1: angolo di incidenza e radiazione istantanei usando un'ora locale definita"
-#~ msgid "rows changed from %d to %d"
-#~ msgstr "righe cambiate da %d a %d"
-#~ msgid "cols changed from %d to %d"
-#~ msgstr "colonne cambiate da %d a %d"
-#~ msgid "raster, landscape structure analysis, patch index"
-#~ msgstr "raster, analisi della struttura del paesaggio, indice di patch"
-#~ msgid "Verbose mode"
-#~ msgstr "Modalità verbosa"
-#~ msgid "Finds the median of values in a cover map within areas assigned the same category value in a user-specified base map."
-#~ msgstr "Trova la mediana dei valori di una mappa di copertura all'interno di aree di una mappa di base definita dall'utente appartenenti alla stessa categoria."
-#~ msgid "raster, mask"
-#~ msgstr "raster, maschera"
-#~ msgid "E00 file"
-#~ msgstr "File E00"
-#~ msgid "GeoTIFF"
-#~ msgstr "GeoTIFF"
-#~ msgid "Unable to create raster map"
-#~ msgstr "Impossibile creare la mappa raster"
-#~ msgid "Link to raster map <%s> created"
-#~ msgstr "Collegamento alla mappa raster <%s> creato"
-#~ msgid "Unable to set window"
-#~ msgstr "Non è possibile impostare la finestra"
-#~ msgid "%s: base raster map not found"
-#~ msgstr "%s: mappa raster di base non trovata"
-#~ msgid "NULL value computed (row %d, col %d)"
-#~ msgstr "Valore NULL calcolato (riga %d colonna %d)"
-#~ msgid "Illegal delete request"
-#~ msgstr "Richiesta di cancellazione non valida"
-#~ msgid "Bad start cell"
-#~ msgstr "Cella iniziale non corretta"
-#~ msgid "The height of the river bed in [m]"
-#~ msgstr "L'altezza del letto del fiume in [m]"
-#~ msgid "Name of real-sky beam radiation coefficient raster map [-]"
-#~ msgstr "Nome della mappa raster del coefficiente di radiazione diretta in condizioni di cielo reali [-]"
-#~ msgid "Name of real-sky diffuse radiation coefficient raster map [-]"
-#~ msgstr "Nome della mappa raster del coefficiente di radiazione diffusa in condizioni di cielo reali [-]"
-#~ msgid "Name for distance output map"
-#~ msgstr "Nome della mappa di output delle distanze"
-#~ msgid "Unable to update boundaries"
-#~ msgstr "Non è possibile aggiornare i confini"
-#~ msgid "raster, sun position"
-#~ msgstr "raster, posizione del sole"
-#~ msgid "Output basic information about a raster map layer."
-#~ msgstr "Stampa informazioni basi di un raster."
-#~ msgid "Input map"
-#~ msgstr "Mappa di input"
-#~ msgid "Error writing G3D double data"
-#~ msgstr "Errore nella scrittura dei dati a precisione doppia G3D"
-#~ msgid "raster, raster3d, voxel, conversion"
-#~ msgstr "raster, raster3d, voxel, conversione"
-#~ msgid "Calculating covariance matrix..."
-#~ msgstr "Calcolo della matrice di covarianza in corso..."
-#~ msgid " 1. nearest neighbor\n"
-#~ msgstr " 1. vicino più prossimo\n"
-#~ msgid " 2. bilinear\n"
-#~ msgstr " 2. bilineare\n"
-# bicubica/bicubico?
-#~ msgid " 3. bicubic\n"
-#~ msgstr " 3. bicubica\n"
-#~ msgid "Reading raster map <%s in %s> ..."
-#~ msgstr "Lettura della mappa raster <%s in %s> in corso ..."
-#~ msgid "Unable to set size"
-#~ msgstr "impossibile impostare la dimensione"
-#~ msgid "List available mapsets"
-#~ msgstr "Elenco dei mapset disponibili"
-#~ msgid "You don't have permission to use this mapset"
-#~ msgstr "Non hai i permessi per usare questo mapset"
-#~ msgid "The mapset does not exist. Use -c flag to create it."
-#~ msgstr "Il mapset non esiste. Usa l'opzione -c per crearlo"
-#~ msgid "Creates a Voronoi diagram from an input vector map containing points or centroids."
-#~ msgstr "Crea un diagramma di Voronoi da un vettoriale contenente punti o centroidi."
-#~ msgid "Unknown column type '%s'"
-#~ msgstr "Tipo di colonna sconosciuto '%s'"
-#~ msgid "Delete line and exit"
-#~ msgstr "Cancella la linea ed esci"
-#~ msgid "Key column name"
-#~ msgstr "Nome della colonna chiave"
-#~ msgid "%d features written"
-#~ msgstr "%d elementi scritti"
-#~ msgid "Unknown operator"
-#~ msgstr "Operatore sconosciuto"
-#~ msgid "Copying vector lines..."
-#~ msgstr "Sto copiando linee vettoriali..."
-#~ msgid "Print topology information only"
-#~ msgstr "Stampa solo le informazioni sulla topologia"
-#~ msgid "Name of input vector points map for which to edit attribute table"
-#~ msgstr "Nome della mappa vettoriale di punti della quale editare la tabella attributi"
-#~ msgid "Cannot connect to MySQL: "
-#~ msgstr "Non riesco a connettermi a MySQL"
-#~ msgid "Cannot get list of tables:\n"
-#~ msgstr "Non riesco a mostrare i database:\n"
-#~ msgid "Cannot recognize boolean value"
-#~ msgstr "Non riesco ad individuare il valore booleano"
-#~ msgid "List available modules in the GRASS Addons SVN repository"
-#~ msgstr "Elenca i moduli disponibili nel repository SVN Addons di GRASS "
-#, fuzzy
-#~ msgid "Error writing row %d"
-#~ msgstr "Errore durante la scrittura della riga %d"
-#, fuzzy
-#~ msgid "Displays vector data in the active frame on the graphics monitor."
-#, fuzzy
-#~ msgid "Name of input vector points map"
-#, fuzzy
-#~ msgid "Cannot open vector map <%s>"
-#~ msgid "Entropy"
-#~ msgstr "Entropia"
-#~ msgid "vector, import"
-#~ msgstr "vettoriale, importazione"
-#~ msgid "List available layers in data source and exit"
-#~ msgstr "Elenca i tematismi disponibili nell'origine dati ed esce"
-#~ msgid "Data source contains %d layers:"
-#~ msgstr "L'origine dati contiene %d tematismi"
-#~ msgid "Unable to convert input map projection to GRASS format; cannot create new location"
-#~ msgstr "Non è possibile convertire la proiezione della mappa di input nel formato GRASS; impossibile creare una nuova location"
-#~ msgid "Input data contains 3D features. Created vector is 2D only, use -z flag to import 3D vector"
-#~ msgstr "I dati di input contengono elementi 3D. Il vettoriale creato è solo 2D; usare il flag -z per importare il vettoriale 3D"
-#~ msgid "vector, buffer"
-#~ msgstr "vettoriale, buffer"
-#~ msgid "vector, export"
-#~ msgstr "vettoriale, esportazione"
-#~ msgid "vector, metadata"
-#~ msgstr "vettoriale, metadati"
-#~ msgid "vector, topology"
-#~ msgstr "vettoriale, topologia"
-#~ msgid "Name of table created for output when the distance to all flag is used"
-#~ msgstr "Nome della tabella creata per l'output quando è utilizzato il flag della distanza da tutti (-a)"
-#~ msgid "Finding nearest lines..."
-#~ msgstr "Ricerca delle linee più vicine in corso ..."
-#~ msgid "vector, statistics"
-#~ msgstr "vettoriale, statistica"
-#~ msgid "Column name and type (i.e. INTEGER, DOUBLE PRECISION) for z values"
-#~ msgstr "Nomi di colonna e tipo (i.e. INTEGER, DOUBLE PRECISION) per i valori z"
-#~ msgid "vector, geometry"
-#~ msgstr "vettoriale, geometria"
-#~ msgid "Cannot calculate area centroid z coordinate"
-#~ msgstr "Non è possibile calcolare la coordinata z del centroide dell'area"
-#~ msgid "nodes;new point is placed on each node (line end) if doesn't exist;connect;connect still unconnected points to vector network by inserting new line(s);report;print to standard output {line_category start_point_category end_point_category};nreport;print to standard output {point_category line_category[,line_category...]}"
-#~ msgstr "nodes;viene inserito un nuovo punto, se non esiste già, su ogni nodo (fine linea); connect;connette i punti non ancora connessi alla rete vettoriale inserendo nuove linee; report;stampa sullo standard output {line_category start_point_category end_point_category}; nreport;stampa sullo standard output {point_category line_category[,line_category...]}"
-#~ msgid "When printing, limit to layer specified by the layer option"
-#~ msgstr "Limita la stampa al layer specificato dall'opzione layer"
-#~ msgid "vector, spatial query"
-#~ msgstr "vettoriale, interrogazioni spaziali"
-#~ msgid "vector, network, connectivity"
-#~ msgstr "vettoriale, rete, connettività"
-#~ msgid "vector, path, visibility"
-#~ msgstr "vettoriale, percorso, visibilità"
-# FINIRE
-#~ msgid "got type %d"
-#~ msgstr "ottenuto il tipo %d"
-#~ msgid "Feature has more categories. Only first category (%d) is exported."
-#~ msgstr "L'elemento ha più categorie. Viene esportata solo la prima categoria (%d)."
-#~ msgid "Unable to select record from table <%s> (key %s, column %s)"
-#~ msgstr "Non è possibile selezionare il record dalla tabella <%s> (chiave %s, colonna %s)"
-#~ msgid "Path to resulting ASCII file or ASCII vector name if '-o' is defined"
-#~ msgstr "Percorso del file ASCII risultante o, se è definito '-o', il nome del vettoriale ASCII"
-#~ msgid "Create parallel line to input lines"
-#~ msgstr "Crea un linea parallela alle linee in input"
-#~ msgid "New vertex"
-#~ msgstr "Nuovo vertice"
-#~ msgid ""
-#~ "Unexpected data in vector head:\n"
-#~ "[%s]"
-#~ msgstr ""
-#~ "Dati inattesi nell'intestazione del vettoriale:\n"
-#~ "[%s]"
-#~ msgid "Unknown keyword <%s> in vector head"
-#~ msgstr "Parola chiave <%s> sconosciuta nell'intestazione del vettoriale"
-#~ msgid "Error reading ASCII file: (bad point) [%s]"
-#~ msgstr "Errore nella lettura del file ASCII: (punto non corretto) [%s]"
-#~ msgid "Unparsable longitude value: [%s]"
-#~ msgstr "Valore di longitudine non analizzabile: [%s]"
-#~ msgid "Unparsable latitude value: [%s]"
-#~ msgstr "Valore di latitudine non analizzabile: [%s]"
-#~ msgid "End of ASCII file reached before end of categories"
-#~ msgstr "Raggiunta la fine del file ASCII prima della fine delle categorie"
-#~ msgid "Feature type(s). Combinations not supported by all output formats. Default: first type found in input."
-#~ msgstr "Tipo/i di elemento. Le combinazioni non sono supportate da tutti i formati di output. Predefinito: il primo tipo trovato nell'input."
-#~ msgid "Export features with category (labeled) only. Otherwise all features are exported"
-#~ msgstr "Esporta solo gli elementi con categoria (etichettati). Altrimenti verranno esportati tutti gli elementi"
-#~ msgid "Skipping all boundaries that are not part of an area."
-#~ msgstr "Si stannno tralasciando tutti i confini che non fanno parte di un'area."
-#~ msgid "Volumes will be exported as sets of faces."
-#~ msgstr "I volumi verranno esportati come insiemi di facce"
-#~ msgid "Could not determine input map's feature type(s)."
-#~ msgstr "Non è possibile determinare il tipo/i di elemento della mappa di input."
-#~ msgid "The map contains islands. To preserve them in the output map, use the -c flag"
-#~ msgstr "La mappa contiene isole. Per preservarle nella mapa di output usare il flag -c"
-#~ msgid "%d areas found, but not requested to be exported. Verify 'type' parameter."
-#~ msgstr "Trovate %d aree, ma non ne è stata chiesta l'esportazione. Verificare il parametro 'type'."
-#~ msgid "%d kernel(s) found, but not requested to be exported. Verify 'type' parameter."
-#~ msgstr "Trovati %d kernel, ma non ne è stata richiesta l'esportazione. Verificare il parametro 'type'."
-#~ msgid "No points found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Nessun punto trovato, anche se ne è stata chiesta l'esportazione. Questo tipo di geometria verrà ignorato."
-#~ msgid "No lines found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Nessuna linea trovata, anche se ne è stata chiesta l'esportazione. Questo tipo di geometria verrà ignorato."
-#~ msgid "No boundaries found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Nessun confine trovato, anche se ne è stata chiesta l'esportazione. Questo tipo di geometria verrà ignorato."
-#~ msgid "No areas found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Nessun'area trovata, anche se ne è stata chiesta l'esportazione. Questo tipo di geometria verrà ignorato."
-#~ msgid "No centroids found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Nessun centroide trovato, anche se ne è stata chiesta l'esportazione. Questo tipo di geometria verrà ignorato."
-#~ msgid "No faces found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Nessuna faccia trovata, anche se ne è stata chiesta l'esportazione. Questo tipo di geometria verrà ignorato."
-#~ msgid "No kernels found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Nessun kernel trovato, anche se ne è stata chiesta l'esportazione. Questo tipo di geometria verrà ignorato."
-#~ msgid "No volumes found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Nessun volume trovato, anche se ne è stata chiesta l'esportazione. Questo tipo di geometria verrà ignorato."
-#~ msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
-#~ msgstr "La mappa vettoriale <%s> è 3D. Usare le opzioni di creazione del tematismo specifiche per il formato (parametro 'lco') o il flag -z per esportare in 3D anziché in 2D (predefinito)"
-#~ msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') to export in 3D rather than 2D (default)"
-#~ msgstr "La mappa vettoriale <%s> è 3D. Usare le opzioni di creazione del tematismo specifiche per il formato (parametro 'lco') per esportare in 3D anziché in 2D (predefinito)"
-#~ msgid "Exporting %i faces (may take some time) ..."
-#~ msgstr "Esportazione di %i facce in corso (può richiedere del tempo)..."
-#~ msgid "Verbose module output"
-#~ msgstr "Output verboso del modulo"
-#~ msgid "Unable to read file header of <%s>"
-#~ msgstr "Non è possibile leggere l'intestazione del file di <%s>"
-#~ msgid "raster3d, voxel, import"
-#~ msgstr "raster3d, voxel, importazione"
-#~ msgid "Sources and sinks in [m^3/s]"
-#~ msgstr "Sorgenti e pozzi in [m^3/s]"
-#~ msgid "raster3d, voxel"
-#~ msgstr "raster3d, voxel"
-#~ msgid "raster3d, voxel, export"
-#~ msgstr "raster3d, voxel, esportazione"
-#~ msgid "%s: base map and output map must be different"
-#~ msgstr "%s: la mappa di base e la mappa di output devono essere differenti"
-#~ msgid "Name of real-sky beam radiation coefficient input raster map [-]"
-#~ msgstr "Nome della mappa raster di input dei coefficienti di radiazione diretta in condizioni di cielo reali [-]"
-#~ msgid "Name of real-sky diffuse radiation coefficient input raster map [-]"
-#~ msgstr "Nome della mappa raster di input dei coefficienti di radiazione diffusa in condizioni di cielo reali [-]"
-#~ msgid "Input map: elevation on which entire analysis is based"
-#~ msgstr "Mappa di input: il modello altimetrico su cui si basa l'intera analisi"
-#~ msgid "Input map: locations of real depressions"
-#~ msgstr "Mappa di input: ubicazione delle depressioni reali"
-#~ msgid "Input map: amount of overland flow per cell"
-#~ msgstr "Mappa di input: la quantità di deflusso superficiale per cella"
-#~ msgid "Input map or value: percent of disturbed land, for USLE"
-#~ msgstr "Mappa di input o valore: percentuale di territorio antropizzato, per USLE"
-#~ msgid "Input map: terrain blocking overland surface flow, for USLE"
-#~ msgstr "Mappa di input: terreno che ostacola lo scorrimento superficiale, per USLE"
-#~ msgid "Output map: number of cells that drain through each cell"
-#~ msgstr "Mappa di output: numero di celle che defluiscono attraverso ciascuna cella"
-#~ msgid "Output map: drainage direction"
-#~ msgstr "Mappa di output: direzione di drenaggio"
-# FINIRE
-#~ msgid "Output map: unique label for each watershed basin"
-#~ msgstr "Mappa di output: un'etichetta univoca per ogni bacino idrografico"
-#~ msgid "Output map: stream segments"
-#~ msgstr "Mappa di output: segmenti dei corsi d'acqua"
-#~ msgid "Output map: each half-basin is given a unique value"
-#~ msgstr "Mappa di output: a ogni semibacino è assegnato un valore univoco"
-#~ msgid "Output map: useful for visual display of results"
-#~ msgstr "Mappa di output: utile per la visualizzazione dei risultati"
-#~ msgid "Output map: slope length and steepness (LS) factor for USLE"
-#~ msgstr "Mappa di output: fattore lunghezza e inclinazione del pendio (LS) per USLE"
-#~ msgid "Output map: slope steepness (S) factor for USLE"
-#~ msgstr "Mappa di output: fattore pendenza (S) per USLE"
-#~ msgid "Input value: minimum size of exterior watershed basin"
-#~ msgstr "Valore in input: dimensione minima del bacino idrografico esterno"
-#~ msgid "Input value: maximum length of surface flow, for USLE"
-#~ msgstr "Valore in input: lunghezza massima dello scorrimento superficiale, per USLE"
-#~ msgid "Enable MFD flow (default is SFD (D8))"
-#~ msgstr "Abilitare flusso MDF (quello predefinito è SFD (D8))"
-#~ msgid "Input raster map contains cells with NULL-value (no-data). The value %f will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
-#~ msgstr "La mappa raster di input contiene celle con valore NULL (nessun dato). Il valore %f verrà usato per rappresentare i valori delle celle senza dati nella mappa di input. È possibile specificare un valore per le celle senza dati con l'opzione %s."
-# FINIRE
-#~ msgid "GIS format to write (case sensitive, see also -l flag)"
-#~ msgstr "Formato GIS da scrivere (sensibile alle maiuscole; vedi anche il flag -l)"
-#~ msgid "Checking GDAL data type and nodata value"
-#~ msgstr "Controllo del tipo di dati GDAL e del valore 'nessun dato'"
-#~ msgid "Exporting to GDAL raster"
-#~ msgstr "Esportazione nel raster GDAL"
-#~ msgid "Range to be exported: %f - %f"
-#~ msgstr "Intervallo dati da esportare: %f - %f"
-# FINIRE
-#~ msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %f gets converted to %d by selected GDAL datatype."
-#~ msgstr "Discordanza fra il valore 'nessun dato' dei metadati e quello reale nel raster esportato: il valore 'nessun dato %f specificato viene convertito a %d dal tipo di dati GDAL selezionato."
-#~ msgid "imagery, geometry"
-#~ msgstr "immagine, geometria"
-#~ msgid "imagery, classification, MLC"
-#~ msgstr "immagini, classificazione, MLC"
-#~ msgid "imagery, map management"
-#~ msgstr "immagini, gestione delle mappe"
-#~ msgid "imagery, color transformation, RGB, HIS"
-#~ msgstr "immagini, trasformazione di colore, RGB, HIS"
-#~ msgid "imagery, rectify"
-#~ msgstr "immagini, rettificare"
-#~ msgid "Minnaert constant = %lf"
-#~ msgstr "Costante di Minnaert = %lf"
-#~ msgid "imagery, terrain, topographic correction"
-#~ msgstr "immagini, terreno, correzione topografica"
-#~ msgid "Solar zenith in degrees"
-#~ msgstr "Zenit del sole in gradi"
-#~ msgid "Solar azimuth in degrees (only if flag -i)"
-#~ msgstr "Azimut del sole in gradi (solo col flag -i)"
-#~ msgid "Topographic correction method"
-#~ msgstr "Metodo di correzione topografica"
-#~ msgid "Solar azimuth is necessary to calculate illumination terrain model"
-#~ msgstr "L'azimut del sole è necessario per calcolre il modello di illuminazione del terreno"
-#~ msgid "Reflectance maps are necessary to make topographic correction"
-#~ msgstr "Le mappe di riflettanza son necessarie per effettuare la correzione topografica"
-#~ msgid "Illumination model is of CELL type"
-#~ msgstr "Il modello di illuminazione è di tipo CELL"
-#~ msgid "imagery, FFT"
-#~ msgstr "immagini, FFT"
-#~ msgid "Computing row %d (of %d) of covariance matrix..."
-#~ msgstr "Calcolo della riga %d (di %d) della matrice di covarianza in corso..."
-#~ msgid "imagery, orthorectify"
-#~ msgstr "immagini, ortorettificare"
-#~ msgid "Interactively select or modify the target elevation model."
-#~ msgstr "Seleziona o modifica interattivamente il modello di elevazione di destinazione."
-#~ msgid "Name of imagery group for ortho-rectification"
-#~ msgstr "Nome del gruppo di immagini per l'ortorettificazione"
-#~ msgid "Target information for group [%s] missing\n"
-#~ msgstr "Informazione mancante per il gruppo [%s]\n"
-#~ msgid "Please select a target for group"
-#~ msgstr "Selezionare una destinazione per il gruppo"
-#~ msgid "Enter imagery group for ortho-rectification"
-#~ msgstr "Inserire il gruppo di immagini per l'ortorettificazione"
-#~ msgid "Orthorectification cancelled"
-#~ msgstr "Ortorettificazione annulata"
-#~ msgid "No files in this group!"
-#~ msgstr "Nessun file in questo gruppo!"
-#~ msgid ""
-#~ "\n"
-#~ "Rectify image <%s>? "
-#~ msgstr ""
-#~ "\n"
-#~ "Rettificare l'immagine <%s>? "
-#~ msgid ""
-#~ "\n"
-#~ "No images selected, orthorectification cancelled."
-#~ msgstr ""
-#~ "\n"
-#~ "Nessuna immagine selezionata, ortorettificazione annullata."
-#~ msgid "Enter an extension to be appended to rectified maps:"
-#~ msgstr "Inserire un'estensione da aggiungere alle mappe rettificate:"
-#~ msgid ""
-#~ "\n"
-#~ "Choose another extension? "
-#~ msgstr ""
-#~ "\n"
-#~ "Scegliere un'altra estensione? "
-#~ msgid ""
-#~ "\n"
-#~ "Compute local camera angle? "
-#~ msgstr ""
-#~ "\n"
-#~ "Calcorare l'angolo di ripresa locale? "
-#~ msgid "Enter a name for the camera angle map:"
-#~ msgstr "Inserire un nome per la mappa degli angoli di ripresa:"
-#~ msgid ""
-#~ "\n"
-#~ "Overwrite maps in target location/mapset? "
-#~ msgstr ""
-#~ "\n"
-#~ "Sovrascrivere le mappe in location/mapset di destinazione? "
-#~ msgid "Difference in x,y direction for moving feature or vertex"
-#~ msgstr "Differenza nella direzione x, y per lo spostamento di un elemento o vertice"
-#~ msgid "vector, editing, geometry"
-#~ msgstr "vettoriale, modifica, geometria"
-#~ msgid "Creating new DB connection based on default mapset settings..."
-#~ msgstr "Creazione di una nuova connessione al DB basata sulle impostazioni del mapset predefinito in corso..."
-#~ msgid "End of ASCII file reached before end of coordinates"
-#~ msgstr "È stata raggiunta la fine del file ACII prima della fine delle coordinate"
-#~ msgid "End of ascii file reached before end of categories"
-#~ msgstr "È stata raggiunta la fine del file ACII prima della fine delle categorie"
-#~ msgid "Unexpected data in vector head: '%s'"
-#~ msgstr "Dati inattesi nell'intestazione del vettore: '%s' "
-#~ msgid "Unknown keyword '%s' in vector head"
-#~ msgstr "Parola chiave '%s' sconosciuta nell'intestazione del vettoriale"
-#~ msgid "Digitize new %s:"
-#~ msgstr "Digitalizza nuovo %s:"
-#~ msgid "Out of memory! Point not added."
-#~ msgstr "Memoria insufficiente! Punto non aggiunto."
-#~ msgid "Less than 2 points for line -> nothing written"
-#~ msgstr "La linea ha meno di 2 punti --> nessun elemento disegnato"
-#~ msgid "Delete point, line, boundary, or centroid:"
-#~ msgstr "Cancella punto, linea, confine o centroide:"
-#~ msgid "Confirm and select next"
-#~ msgstr "Conferma e seleziona il prossimo"
-#~ msgid "Move point, line, boundary, or centroid:"
-#~ msgstr "Muovi punto, linea, confine o centroide:"
-#~ msgid "Split line:"
-#~ msgstr "Spezza la linea:"
-#~ msgid "Remove vertex:"
-#~ msgstr "Rimuovi vertice:"
-#~ msgid "Select vertex"
-#~ msgstr "Seleziona vertice"
-#~ msgid "Add vertex:"
-#~ msgstr "Aggiungi vertice:"
-#~ msgid "Move vertex:"
-#~ msgstr "Muovi vertice:"
-#~ msgid "Select source object"
-#~ msgstr "Seleziona oggetto origine"
-#~ msgid "Deselect Target"
-#~ msgstr "Deseleziona Destinazione"
-#~ msgid "Deselect Source"
-#~ msgstr "Deselezione Origine"
-#~ msgid "There are no more features with category %d (layer %d) in the map, but there is record in the table. Delete this record?"
-#~ msgstr "Non ci sono altri elementi con categoria %d (layer %d) nella mappa, ma c'è la riga nella tabella. Eliminare la riga?"
-#~ msgid "Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>"
-#~ msgstr "Non è possibile aprire il cursore selezionato:<BR>'%s'<BR>sul database '%s' col driver '%s'<BR>"
-# editing ?
-#~ msgid "vector, editing, digitization"
-#~ msgstr "vettoriale, editing, digitalizzazione"
-#~ msgid "Interactive editing and digitization of vector maps."
-#~ msgstr "Modifica interattiva e digitalizzazione di mappe vettoriali."
-#~ msgid "Create new file if it does not exist."
-#~ msgstr "Crea un nuovo file se non esiste."
-#~ msgid "New empty map created."
-#~ msgstr "Creata una nuova mappa vuota."
-#~ msgid "Map <%s> does not exist in current mapset. Add flag -n to create a new map."
-#~ msgstr "La mappa <%s> non esiste nel mapset corrente. Aggiungere il flag -n per creare una nuova mappa."
-#~ msgid "Region restored to original extent."
-#~ msgstr "Regione ripristinata all'estensione originale."
-#~ msgid "Zoom by window"
-#~ msgstr "Ingrandisci l'area con un riquadro"
-#~ msgid "1. corner"
-#~ msgstr "1. angolo"
-#~ msgid "2. corner"
-#~ msgstr "2. angolo"
-#~ msgid "Pan"
-#~ msgstr "Sposta finestra"
-#~ msgid "vector, reclass, attributes"
-#~ msgstr "vettoriale, riclassificazione, attributi"
-#~ msgid "vector, raster, aggregation"
-#~ msgstr "vettoriale, raster, aggregazione"
Modified: grass/trunk/locale/po/grassmods_ja.po
--- grass/trunk/locale/po/grassmods_ja.po	2012-05-26 15:22:06 UTC (rev 51802)
+++ grass/trunk/locale/po/grassmods_ja.po	2012-05-26 15:46:05 UTC (rev 51803)
@@ -33587,10797 +33587,3 @@
 #: ../locale/scriptstrings/d.shadedmap_to_translate.c:5
 msgid "Percent to brighten"
 msgstr "明度"
-#, fuzzy
-msgid "Input raster map with specific yield in [1/m]"
-msgstr "入力するラスターマップが特定されていません。"
-#, fuzzy
-msgid "Raster map <%s> is not valid"
-msgstr "ラスタマップ <%s> が見つかりません"
-msgid "Interpolates point data to a RASTER3D grid volume using regularized spline with tension (RST) algorithm."
-msgstr "テンション (RST) アルゴリズムの正規化スプライン曲線を使って,ポイントデータを3Dグリッドボリュームへ挿入"
-#, fuzzy
-msgid "If not given read from standard input"
-msgstr "���"
-#, fuzzy
-msgid "Print basic info in shell script style"
-msgstr "シェルスクリプト形式で表示"
-#, fuzzy
-msgid "Projection:"
-msgstr "線に沿って点を補間"
-#, fuzzy
-msgid "relative"
-msgstr "作成"
-msgid "Raster map for which to edit null file"
-msgstr "NULLファイルを編集するためのラスターマップ"
-#, fuzzy
-msgid "Join column in table"
-msgstr "マップテーブルに列を結合"
-#, fuzzy
-msgid "Unable to parse '%s'\n"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Driver <%s> doesn't support creating new fields"
-msgstr "ドライバ <%s> はラスターの作成をサポートしていません"
-#, fuzzy
-msgid "Unable to add new field <%s>"
-msgstr "���"
-#, fuzzy
-msgid "Sets color rules for features in a vector map using a numeric attribute column."
-msgstr "数値属性の列でのベクトルの特徴の色ルール"
-#, fuzzy
-msgid "Name of raster map from which to copy color table"
-msgstr "カラーテーブルに用いるラスターマップ"
-#, fuzzy
-msgid "Name of file containing rules"
-msgstr "推論規則ファイル"
-#, fuzzy
-msgid "Creating support files for <%s>"
-msgstr "%s のサポートファイルを作成しています"
-#, fuzzy
-msgid "Title for new raster file."
-msgstr "新しいラスターマップのタイトル "
-msgid "Requested g3d map <%s> not found"
-msgstr "要求された3Dグリッドマップ <%s> が見つかりません"
-msgid "Error opening g3d map <%s>"
-msgstr "エラー:3Dグリッドマップ <%s> を開けません"
-#, fuzzy
-msgid "Unable it load G3d range"
-msgstr "範囲ファイルが読み込めません"
-#, fuzzy
-msgid "\raster\" and \"volume\" options are mutually exclusive"
-msgstr "\"color\"、\"rules\"、\"raster\" のオプションは同時には使用できません"
-#, fuzzy
-msgid "Calculating measure #%d <%s> (56 measures available)"
-msgstr "計算量 #%d <%s> (56 項目が可能)  "
-#, fuzzy
-msgid "Exports the color table associated with a raster3d map layer."
-msgstr "ラスターマップレイヤーに関するカラーテーブルを表示します"
-msgid "Write the result to g3d map <%s>"
-msgstr "結果を 3Dグリッドに出力 <%s>"
-msgid "Requested 3d raster map not found"
-msgstr "要求された 3D ラスターマップが見つかりません"
-msgid "Error closing new ASCII file"
-msgstr "エラー:新規ASCIIファイルを閉じれません"
-msgid "Could not close RASTER3D map"
-msgstr "3Dグリッドマップを閉じれません"
-msgid "Could not close RASTER3D map <%s>"
-msgstr "3Dグリッドマップ <%s> が閉じれません"
-msgid "modifyNull: error opening map"
-msgstr "modifyNull:マップオープンエラー"
-msgid "modifyNull: error closing map"
-msgstr "modifyNull: エラー マップのクローズ"
-msgid "makeMask: error opening map."
-msgstr "makeMask: マップオープンエラー"
-msgid "makeMask: error opening g3d mask file"
-msgstr "makeMask:3Dグリッドマスクファイルオープンエラー"
-msgid "makeMask: error closing g3d mask file"
-msgstr "makeMask:3Dグリッドマスクファイルクローズエラー"
-msgid "makeMask: error closing map"
-msgstr "makeMask: マップクローズエラー"
-msgid "Requested 3d raster map <%s> not found"
-msgstr "要求された3Dラスターマップ <%s> が見つかりません"
-msgid "Requested g3d RGB map <%s> not found"
-msgstr "要求された 3DグリッドRGBマップ <%s> が見つかりません"
-msgid "Requested g3d vector map <%s> not found"
-msgstr "要求された3Dグリッドベクトルマップ <%s> が見つかりません"
-msgid "Open rgb 3d raster map %s"
-msgstr "RBG 3Dラスターマップ %s "
-msgid "Error closing g3d rgb map."
-msgstr "エラー:3DグリッドRBGマップを閉じれません"
-msgid "Error closing g3d vector map."
-msgstr "エラー:3Dグリッドベクターマップを閉じれません"
-msgid "The 2d and 3d region settings are different. The g3d settings are used to adjust the 2d region."
-msgstr "2Dと3Dで領域の設定が異なります。3Dグリッドの設定を2D領域の調整に使用します"
-msgid "write_vtk_rgb_data: writing rgb data"
-msgstr "write_vtk_rgb_data: RGBデータに書き込み"
-msgid "write_vtk_vector_data: writing vector data"
-msgstr "write_vtk_vector_data: ベクトルデータ出力"
-msgid "Error closing new 3d raster map"
-msgstr "エラー:新規3Dラスターマップを閉じれません"
-msgid "Error closing ascii file"
-msgstr "エラー:ASCIIファイルを閉じれません"
-msgid "Name for v5d output file"
-msgstr "v5d 出力ファイル名"
-msgid "Error: couldn't create %s"
-msgstr "エラー: 作成できません %s "
-msgid "Error while writing grid. Disk full?"
-msgstr "グリッドが出力できません.ディスクが一杯ではありませんか?"
-#, fuzzy
-msgid "Name for output flowline density raster map"
-msgstr "出力流線の密度を示すラスターファイル"
-#, fuzzy
-msgid "Lists available GIS elements of the user-specified data type."
-msgstr "現在使用できるマップの一覧を表示します"
-msgid "Print mapset names"
-msgstr "マップセット名を出力します"
-#, fuzzy
-msgid "Remove dangles:"
-msgstr "ぶら下がりを削除"
-#, fuzzy
-msgid "Unable to create 3D vector and attribute table at same time"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Coordinates"
-msgstr "Y座標値"
-#, fuzzy
-msgid "vector, interpolation, kriging"
-msgstr "補間に用いる近傍点"
-#, fuzzy
-msgid "reclass raster output map"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Vector map for which to drop vector objects"
-msgstr "���"
-#, fuzzy
-msgid "Layer of attribute table to use for selection"
-msgstr "文字型属性番号"
-#, fuzzy
-msgid "Raster map to use as mask"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Overwrite existing file"
-msgstr "上書き"
-#, fuzzy
-msgid "Name of input vector polygon map"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Name of MODIS product"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "The names of tile/s to download"
-msgstr "割り当てるポイントの数"
-#, fuzzy
-msgid "raster, import, copying"
-msgstr "ラスター, インポート, 変換"
-#, fuzzy
-msgid "raster, export, copying"
-msgstr "ラスター、エクスポート"
-#, fuzzy
-msgid "Name for output shaded relief map"
-msgstr "出力ラスターマップ名"
-#, fuzzy
-msgid "Existing SPOT VGT NDVI HDF file (0001_NDV.HDF)"
-msgstr "存在する SPOT VGT NDVI HDF ファイル (0001_NDV.HDF)  "
-#, fuzzy
-msgid "Cannot open file [%s] in mapset [%s]"
-msgstr "ラベル ファイル <%s> を開けません(マップセット <%s>)"
-#, fuzzy
-msgid "Cannot create file <%s> in mapset <%s>"
-#, fuzzy
-msgid "basemap"
-msgstr "ベースマップを取り除きます"
-#, fuzzy
-msgid "zenith"
-msgstr "長さ:%f\n"
-#, fuzzy
-msgid "method"
-msgstr "未詳のメソッド"
-#, fuzzy
-msgid "topographic correction method"
-msgstr "出力に指数を使用"
-#, fuzzy
-msgid "Elevation file of unknown type"
-msgstr "平面上のポイントの標高座標"
-#, fuzzy
-msgid "Cannot allocate memory for auxiliar matrix.Consider changing region (resolution)"
-msgstr "auxiliarマトリックスにメモリーを割り当てられません.領域の解像度を変更してみてください  "
-#, fuzzy
-msgid "Watershed basin analysis program"
-msgstr "分水域の解析を行います "
-#, fuzzy
-msgid "Name of input raster map with real depressions"
-msgstr "再投影するラスターマップ名"
-#, fuzzy
-msgid "Name of input raster map blocking overland surface flow"
-msgstr "入力:曲面流でブロック化した地形を示すファイル "
-#, fuzzy
-msgid "Name for output raster map useful for visual display of results (DEPRECATED)"
-msgstr "出力:結果を可視化したファイル"
-#, fuzzy
-msgid "Direction raster found <%s>"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Name for output direction map for depressionless elevation raster map"
-msgstr "(o)   凹みのない標高マップの方向マップ"
-#, fuzzy
-msgid "raster, export, animation"
-msgstr "ラスター、標高"
-#, fuzzy
-msgid "(requires r.out.ppm with stdout option)"
-msgstr ""
-"オン・ザ・フライで変換、省ディスクスペース\n"
-"\t(r.out.ppm の stdout オプションが必要)  "
-#, fuzzy
-msgid "Name for output elevation raster map after filling"
-msgstr "充填後にラスターマップを出力"
-#, fuzzy
-msgid "Name for output direction raster map"
-msgstr "出力する傾斜方位ラスターマップ名"
-#, fuzzy
-msgid "Reading input data..."
-msgstr "読込中 ... "
-#, fuzzy
-msgid "Writing output data..."
-msgstr "出力中..."
-#, fuzzy
-msgid "raster, reclassification"
-msgstr "ラスター、標高"
-#, fuzzy
-msgid "Name of input raster map with given starting point(s) (at least 1 cell > 0)"
-msgstr "シード付きラスターマップ名 (少なくとも 1セル>0)"
-#, fuzzy
-msgid "Constructs flow lines."
-msgstr "等値線のコスト "
-#, fuzzy
-msgid "Name for flowpath length raster map"
-msgstr "出力フローパス長さラスターマップ"
-#, fuzzy
-msgid "imagery, landsat, acca"
-msgstr "画像, 分類, MLC"
-#, fuzzy
-msgid "Cannot write to raster map <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Creates, edits, and lists groups and subgroups of imagery data."
-msgstr "グループと画像ファイルサブグループの作成、編集、入力"
-#, fuzzy
-msgid "Extract quality control parameters from Modis QC layers"
-msgstr "DEM から地形パラメーターを抽出します"
-#, fuzzy
-msgid "Name of the surface reflectance QC layer [bit array]"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Computing means and standard deviations..."
-msgstr "バンドの演算手段 %d..."
-#, fuzzy
-msgid "Computing means..."
-msgstr "方程式を計算中..."
-#, fuzzy
-msgid "Other"
-msgstr "ディザ"
-#, fuzzy
-msgid "Offset in map units."
-msgstr "マップユニットのバッファー距離"
-#, fuzzy
-msgid "Cannot describe table"
-msgstr "表をコピーできません\n"
-#, fuzzy
-msgid "DEPRECATED Buffer distance in map units"
-#, fuzzy
-msgid "Line buffers... "
-msgstr "ラインバッファー、、、"
-#, fuzzy
-msgid "Zero area size, please clean input vector first."
-msgstr "指定したベクトルラインに平行な線を作成"
-#, fuzzy
-msgid "Could not get outside buffer for line id %d"
-msgstr "南の緩衝地帯をよみこめませんでした. 中断しています"
-#, fuzzy
-msgid "Area buffers... "
-msgstr "エリアバッファー、、、"
-#, fuzzy
-msgid "Selecting areas..."
-msgstr "フィーチャーを選択中、、、"
-msgid "Converts to one of the supported OGR vector formats."
-msgstr "サポートするOGRベクトルフォーマットのひとつに変換"
-#, fuzzy
-msgid "Cannot allocate %u bytes of memory"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Skip the join column in other table"
-msgstr "他のテーブルに列を結合"
-#, fuzzy
-msgid "Copy all the columns from other table to map"
-#, fuzzy
-msgid "Name of input raster map in which to fill nulls"
-msgstr "nullで埋められたラスターマップ"
-#, fuzzy
-msgid "Name for output raster map with nulls filled by interpolation"
-msgstr "周囲の値からの補間によって埋められたnullで出力するラスターマップ"
-#, fuzzy
-msgid "Mosaics up to four images, extending the color table."
-msgstr "モザイクは最大4つの画像まで、 カラーマップを拡張する; マップ *.mosaicを作成する  "
-#, fuzzy
-msgid "creates map *.mosaic"
-msgstr "第3モザイクマップ"
-#, fuzzy
-msgid "1st map for mosaic (top of image stack)"
-msgstr "第1モザイクマップ (画像スタックの上部).  "
-#, fuzzy
-msgid "2nd map for mosaic"
-msgstr "第2モザイクマップ"
-#, fuzzy
-msgid "3rd map for mosaic"
-msgstr "第3モザイクマップ"
-#, fuzzy
-msgid "4th map for mosaic"
-msgstr "第4モザイクマップ"
-msgid "Could not close G3D map"
-msgid "Use g3d mask (if exists) with input map"
-msgstr "入力マップに3Dグリッドマスクを使う"
-msgid "Could not write raster row"
-msgstr "ラスター行が書き込めません"
-msgid "Could not close G3D map <%s>"
-msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
-msgstr "3Dラスターマップ(3Dグリッド)をVTK-Ascii フォーマットに変換する"
-msgid "unable to close input 3d raster map"
-msgstr "入力3Dラスターマップを閉じれません"
-msgid "Use g3d mask (if exists) with input maps"
-msgstr "3Dグリッドマスク(存在する時に限る)を入力マップに使用します"
-msgid "Could not get top raster row \n"
-msgstr "ラスターの先頭行を取得できない\n"
-msgid "Could not get bottom raster row \n"
-msgstr "ラスターの最終行を取得できない\n"
-msgid "Use G3D mask (if exists)"
-msgstr "(可能であれば)3Dグリッドマスクの使用"
-msgid "Name of an existing raster map layer"
-msgstr "既存のラスターマップ レイヤー名"
-#, fuzzy
-msgid "writing edges..."
-msgstr "入力するファイル"
-#, fuzzy
-msgid "input,cell,raster"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "output,cell,raster"
-msgstr "出力するファイル"
-msgid "raster3d, statistics"
-msgstr "ラスター3D、統計"
-#, fuzzy
-msgid "raster, png"
-msgstr "ラスター、タイル表示"
-msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)"
-msgstr "傾斜カーブの建築(フローライン)、フローパスの長さ、そしてラスターデジタル標高モデル(DEM)からのフローライン密度(上り坂エリア) "
-msgid "vector, networking"
-msgstr "ベクトル, ネットワーク"
-msgid "raster, vector, visualization"
-msgstr "ラスター,ベクトル,可視化"
-msgid "Convert all old GRASS < Ver5.7 vector maps in current mapset to current format"
-msgstr "現在のマップセット内のすべての前のGRASS < Ver5.7 ベクトルマップ を現在のフォーマットに変換する"
-msgid "Import Mapgen or Matlab vector maps into GRASS."
-msgstr "MapgenあるいはMatlabベクトルマップをGRASSにインポート"
-msgid "Ascii file containing spectral signatures"
-msgstr "スペクトルシグネチャを含むASCIIファイル"
-#, fuzzy
-msgid "Unhandled vector feature type <%s>"
-msgstr "NULL値に代入する値"
-#, fuzzy
-msgid "No areas found, skipping type=area"
-msgstr "現在の設定を表示"
-#, fuzzy
-msgid "No points found, skipping%s%s"
-msgstr "現在の設定を表示"
-#, fuzzy
-msgid "No lines found, skipping%s%s"
-msgstr "現在の設定を表示"
-msgid "Raster value"
-msgstr "ラスター値"
-msgid "Slower but accurate (applies to FP maps only)"
-msgstr "遅いですが正確です (FPマップのみ適用)  "
-msgid "Rescaling range for output maps (for no rescaling use 0,0)"
-msgstr "出力マップの範囲を再計測 (0,0を使う再計測はありません)"
-#, fuzzy
-msgid "GDAL datatype: %s, range: %f - %f"
-msgstr "���."
-#, fuzzy
-msgid "The '-q' flag is superseded and will be removed "
-msgstr "���."
-#, fuzzy
-msgid "Unable to create table <%s_edge_Interpolation>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Rescale output raster map [0,255]"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Output drain raster map"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Can't find %d,%d:%f"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Reading %s"
-msgstr "���%s ..."
-#, fuzzy
-msgid "Writing %s"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in a local text file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
-msgstr "緯度 (dd:mm:ss{N|S})."
-#, fuzzy
-msgid "It was impossible to open table"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Spline type of interpolation"
-msgstr "アイコンの種類"
-#, fuzzy
-msgid "Script kill option"
-msgstr "スクリプトの終了"
-#, fuzzy
-msgid "Start in Demo mode"
-msgstr "デモモード"
-#, fuzzy
-msgid "Output more comments (default=quiet)"
-msgstr "タイトル"
-#, fuzzy
-msgid "Vector map to display thematically"
-msgstr "対象マップ"
-#, fuzzy
-msgid "Vector map type"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Layer to use for thematic display"
-msgstr "タイトル"
-#, fuzzy
-msgid "Mapset(s) to list (default: current mapset search path)"
-msgstr "対象マップセット(デフォルト=現在のマップセット)"
-#, fuzzy
-msgid "Output separator (default: newline)"
-msgstr "区切り(デフォルト:タブ)"
-#, fuzzy
-msgid "Raster to remove"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "3d raster to remove"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Vector to remove"
-msgstr "対象ファイル<%s>"
-#, fuzzy
-msgid "Region to remove"
-#, fuzzy
-msgid "Label to remove"
-#, fuzzy
-msgid "3dview to remove"
-#, fuzzy
-msgid "Group to remove"
-#, fuzzy
-msgid "raster input maps"
-msgstr "目的ファイルを含むマップセット"
-#, fuzzy
-msgid "Output field seperator"
-msgstr "区切り"
-#, fuzzy
-msgid "ERROR: Problem opening output file."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Density of output walkers"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "File [%s] not found"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Unable to open file [%s]"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Reading sites map (%s) ..."
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Name of the output walkers vector points map"
-msgstr "���"
-#, fuzzy
-msgid "You are not outputting any raster or vector points maps"
-msgstr "���"
-#, fuzzy
-msgid "%s=%s - illegal value"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Unable to read current region parameters"
-msgstr "現在の設定を表示"
-#, fuzzy
-msgid "Cannot open cover raster map <%s>"
-msgstr ""
-"#-#-#-#-#  grassmods_ja.po (grassmods_ja)  #-#-#-#-#\n"
-"出力するファイル"
-#, fuzzy
-msgid "No map specified"
-msgstr "傾斜方位を示すファイル(入力)"
-#, fuzzy
-msgid "%s - unable to remove color table"
-msgstr "シグネチャファイル"
-#, fuzzy
-msgid "%s - color table not found"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Unable to properly read input raster map"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Unable to properly write output raster map"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Name of raster map layer to be used for <%s>"
-msgstr "<%s>に対応させるラスターマップ"
-#, fuzzy
-msgid "Run verbosly"
-msgstr "説明つき表示"
-#, fuzzy
-msgid "%d points converted to centroids"
-msgstr "タイトル"
-#, fuzzy
-msgid "%d centroids converted to points"
-msgstr "出力ファイルの上書き"
-#, fuzzy
-msgid "%d lines converted to boundaries"
-#, fuzzy
-msgid "CrossCorrelation: %d points read in region.\n"
-msgstr "現在の設定を表示"
-#, fuzzy
-msgid "CrossCorrelation: Cannot open database %s by driver %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "CrossCorrelation: Cannot select data from table"
-msgstr "統一する属性の値"
-#, fuzzy
-msgid "vector, attribute table"
-msgstr "���"
-#, fuzzy
-msgid "Cannot fetch data"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Do not print polyline info"
-msgstr "統一する属性の値"
-#, fuzzy
-msgid "Feature id(s)"
-msgstr "ファイルの種類"
-#, fuzzy
-msgid "Input vector was not found."
-msgstr "���."
-#, fuzzy
-msgid "Node layer (points)"
-msgstr "色相ファイル"
-#, fuzzy
-msgid "Reading data from the map..."
-msgstr "カバーマップ"
-#, fuzzy
-msgid "Query layer (used by 'query' option)"
-msgstr "ラベルの属性"
-#, fuzzy
-msgid "%d categories read from map"
-msgstr "タイトル"
-#, fuzzy
-msgid "Processing ainput lines ..."
-msgstr "線に沿って点を補間"
-#, fuzzy
-msgid "Writing attributes ..."
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Current region does not include the entire input vector map <%s>"
-msgstr "���"
-#, fuzzy
-msgid "Output inverse raster map after IFFT"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "%s: %s - Unable to find the real-image map."
-msgstr "入力するファイル"
-#, fuzzy
-msgid "%s: %s - Unable to find the imaginary-image."
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Reading the raster maps..."
-msgstr "カバーマップ"
-#, fuzzy
-msgid "Rotating data arrays..."
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Unable to open output file."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Hue map name"
-msgstr "対象マップ"
-#, fuzzy
-msgid "Intensity map name"
-msgstr "対象マップ"
-#, fuzzy
-msgid "Saturation map name"
-msgstr "対象マップ"
-#, fuzzy
-msgid "Output map representing the red"
-msgstr "出力:排出方向を示すファイル"
-#, fuzzy
-msgid "Output map representing the green"
-#, fuzzy
-msgid "Output map representing the blue"
-msgstr "���"
-#, fuzzy
-msgid "Cannot read row from raster map"
-msgstr "対象マップ1"
-#, fuzzy
-msgid "Cannot write row to raster map"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Red input raster map"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Green input raster map"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Blue input raster map"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Output intensity raster map"
-msgstr "流線の密度を示すファイル(出力)"
-#, fuzzy
-msgid "Name of imagery signaturefile"
-msgstr "シグネチャファイル"
-#, fuzzy
-msgid "Subgroup [%s] not found."
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Signature file [%s] is missing or not readable."
-msgstr "������."
-#, fuzzy
-msgid "Cannot write color table of raster map <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Imagery group"
-msgstr "画像グループ"
-#, fuzzy
-msgid "Subgroup containing image files"
-msgstr "サブ画像グループ"
-#, fuzzy
-msgid "Resultant signature file"
-msgstr "シグネチャファイル"
-#, fuzzy
-msgid "Input raster map being fft"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Illegal file name for real part: %s"
-msgstr "虚部を含む入力ファイル"
-#, fuzzy
-msgid "Illegal file name for imaginary part: %s"
-#, fuzzy
-msgid "Reading the raster map..."
-msgstr "カバーマップ"
-#, fuzzy
-msgid "subgroup <%s> not found"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "** Can't open seed singature file <%s> **"
-msgstr "���"
-#, fuzzy
-msgid "** Can't read signature file <%s> **"
-msgstr "シグネチャファイル"
-#, fuzzy
-msgid "Group of imagery files to be clustered"
-msgstr "画像グループ"
-#, fuzzy
-msgid "Subgroup name in the above group"
-msgstr "サブ画像グループ"
-#, fuzzy
-msgid "Reading image ... "
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Unable to read head of %s"
-#, fuzzy
-msgid "group=[%s] - not found."
-msgstr "入力するファイル"
-#, fuzzy
-msgid "subgroup=[%s] (of group [%s]) - not found."
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Can't read signature file [%s]."
-msgstr "シグネチャファイル"
-#, fuzzy
-msgid "Unable to create reject layer [%s]."
-#, fuzzy
-msgid "Imagery group to be classified"
-msgstr "画像グループ"
-#, fuzzy
-msgid "Subgroup containing image files to be classified"
-msgstr "サブ画像グループ"
-#, fuzzy
-msgid "Signatures to use for classification"
-msgstr "シグネチャファイル"
-#, fuzzy
-msgid "Raster map to hold classification results"
-msgstr "分類結果を出力するファイル"
-#, fuzzy
-msgid "Cannot select attributes: %s"
-msgstr "統一する属性の値"
-#, fuzzy
-msgid "Background color, either a standard GRASS color, R:G:B triplet, or \"none\""
-msgstr "線の色"
-#, fuzzy
-msgid "Saving new map"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Output raster map with lake"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Terrain raster map <%s> not found!"
-msgstr "対象マップ"
-#, fuzzy
-msgid "Cannot open terrain raster map <%s@%s>!"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Seed map <%s> not found!"
-msgstr "対象マップ"
-#, fuzzy
-msgid "Cannot open seed map <%s@%s>!"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Failure to allocate memory for row pointers"
-msgstr "マップのカテゴリー値について統計解析を行います"
-#, fuzzy
-msgid "Loading maps: "
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Error reading terrain raster map. Probably broken file."
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Error reading seed raster map. Probably broken file."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cannot write lake raster map <%s@%s>!"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Error writing color file for <%s@%s>!"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Name of the vector points map with x,y locations"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Number of time iterations (sec.)"
-msgstr "補間に用いる近傍点"
-#, fuzzy
-msgid "Multiscale simulation"
-msgstr "ロケーション"
-#, fuzzy
-msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Calculates <simple> index on a raster map"
-msgstr "サイトマップにラスター形式のマスクをかけ新しいマップを作成します"
-#, fuzzy
-msgid "Raster input maps(s)"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Output file name"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "%s: can't read fp range for [%s]"
-msgstr "出力するファイル"
-#, fuzzy
-msgid ""
-"Raster map [%s] already exists.\n"
-"Please try another."
-msgstr "対象マップ"
-#, fuzzy
-msgid "Error reading '%s' map"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Threshold distance"
-msgstr "閾値"
-#, fuzzy
-msgid "Cannot execute: %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cannot link table: %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "DXF input file"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Cannot open dxf file <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cannot open new vector map <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Conversion of <%s> to vector map:"
-msgstr "���."
-#, fuzzy
-msgid "Create 3D file"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "imagery subgroup"
-msgstr "サブ画像グループ"
-#, fuzzy
-msgid ""
-"\n"
-"<%s> -- illegal result signature file name"
-msgstr "シグネチャファイル"
-#, fuzzy
-msgid "Raster file(s) for Elevation"
-msgstr "色に用いるラスターマップ"
-#, fuzzy
-msgid "Raster file(s) for Color"
-#, fuzzy
-msgid "Raster map to zoom into"
-msgstr "ズームするラスターマップ"
-#, fuzzy
-msgid "Save the current region to region definition file"
-msgstr "  region (地域定義ファイル)\n"
-#, fuzzy
-msgid "Could not open input file <%s>."
-msgstr "���"
-#, fuzzy
-msgid "Adding files to subgroup [%s]"
-msgstr "サブ画像グループ"
-#, fuzzy
-msgid "Writing subgroup REF"
-msgstr "サブ画像グループ"
-#, fuzzy
-msgid "Multiplier"
-msgstr "高さの強調"
-#, fuzzy
-msgid "Name of the resultant map"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Raster map not found."
-msgstr "対象マップ"
-#, fuzzy
-msgid "%s: can't read range for [%s]"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Raster file [%s] not found"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "It was not possible writing in <%s>."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cannot create table: '%s'"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Unable to get category list <%s>, editing terminated"
-msgstr "���"
-#, fuzzy
-msgid "Unable to delete layer/category [%d/%d] line %d"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Unable to write line %d"
-msgstr "シグネチャファイル"
-#, fuzzy
-msgid "Unable to delete line %d"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Unknown query tool '%s'"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "No layer database connection"
-msgstr "ロケーション"
-#, fuzzy
-msgid "%d categories loaded from the database"
-msgstr "タイトル"
-#, fuzzy
-msgid "Cannot open OGR data source '%s'"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cannot create layer"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
-msgstr "対象マップ"
-#, fuzzy
-msgid "Load values from vector to database. For uploaded/printed category values '-1' is used for 'no category' and 'null'/'-' if category cannot be found or multiple categories were found."
-msgstr "���."
-#, fuzzy
-msgid "Column(s)"
-msgstr "更新するカラム1"
-#, fuzzy
-msgid "Cannot read map header for <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cannot read category file for <%s>"
-msgstr "���"
-#, fuzzy
-msgid "Print;Shell Script"
-msgstr "総セル数の出力"
-#, fuzzy
-msgid "Creating support files for [%s]."
-#, fuzzy
-msgid "%s: <%s> raster map not found"
-msgstr ""
-"対象マップ\n"
-"入力するファイル"
-#, fuzzy
-msgid "%s: <%s> raster map exists already"
-msgstr "対象マップ"
-#, fuzzy
-msgid "Cannot read category file of raster map <%s>"
-msgstr "���"
-#, fuzzy
-msgid "%s - map not found"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "%s not found"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Vector map %s - not found"
-msgstr "���"
-#, fuzzy
-msgid "Raster map containing elevation data"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Raster map name for storing results"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Height of the viewing location"
-msgstr "視点の高さ"
-#, fuzzy
-msgid "%s: <%s> cellfile not found"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Cell file [%s] not found\n"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "rgb cell map [%s] not found\n"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "vector cell map [%s] not found\n"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "%s - %s not found"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Unable to read category file for raster map <%s>"
-msgstr "���"
-#, fuzzy
-msgid "Creating support files"
-#, fuzzy
-msgid "%s file [%s] not found!"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "%s: %s - map not found"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "%s: unable to open %s"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "%s - not found"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Cannot read %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Reading %s ... "
-msgstr "入力するファイル"
-#, fuzzy
-msgid "[%s] map not found."
-msgstr "入力するファイル"
-#, fuzzy
-msgid "[%s] map not found"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "min computed aspect %.4f  max computed aspect %.4f"
-msgstr "����� �����"
-#, fuzzy
-msgid "min computed slope %.4f  max computed slope %.4f"
-msgstr "��� ���"
-#, fuzzy
-msgid "Cannot describe table <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cannot insert values: %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "%s given an illegal number of points [%d]"
-msgstr "初期のクラスター数"
-#, fuzzy
-msgid "Unable to open database %s by driver %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Could not find input %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Could not find input map <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Can't read header for <%s> in <%s>"
-msgstr "���"
-#, fuzzy
-msgid "Can't read header for 3D raster <%s> in <%s>"
-msgstr "���"
-#, fuzzy
-msgid "Can't write region <%s>"
-msgstr "���"
-#, fuzzy
-msgid "No graphics device selected."
-msgstr "グラフィックデバイスが選択されていない"
-#, fuzzy
-msgid "Unable to read raster row."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "%s map not found"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "cannot read head of %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Illegal file name: %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cannot get layer info for vector map"
-msgstr "���"
-#, fuzzy
-msgid "Cannot open raster map <%s> in <%s>"
-msgstr ""
-"出力するファイル"
-#, fuzzy
-msgid "cover values extracted from the category labels of the cover map"
-msgstr "カテゴリー値の代わりにカテゴリーラベルを使用"
-#, fuzzy
-msgid "%s: %s - raster map not found"
-msgstr "対象マップ"
-#, fuzzy
-msgid "%s: %s - illegal name"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "%s: ERROR reading category file for %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "%s: %s - not found"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "%s: %s - illegal units"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "%s: %s - can't open"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Reading input map (%s)    ... "
-msgstr "入力するファイル"
-#, fuzzy
-msgid "%s - ERROR reading %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "%s: %s - can't create raster map"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Writing output map (%s)   ... "
-msgstr "出力するファイル"
-#, fuzzy
-msgid "%s - ERROR re-reading %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Reading raster map... "
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Writing raster map... "
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Category list: e.g. 1,3-8,13"
-msgstr "カテゴリーラベルのリスト(例 1,3-8,13)"
-#, fuzzy
-msgid "Output separator character (default: tab)"
-#, fuzzy
-msgid "Cannot read category file of raster map <%s> in <%s>"
-msgstr "���"
-#, fuzzy
-msgid "Cannot create raster map %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cannot create vector map %s"
-msgstr "���"
-#, fuzzy
-msgid "Cannot create raster map '%s'"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Number of raster rows to hold in memory"
-msgstr "メモリに残す行"
-#, fuzzy
-msgid "Print raster map title only"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "unknown type: %d"
-msgstr "ファイルの種類"
-#, fuzzy
-msgid "Cannot open raster map [%s]"
-msgstr ""
-"出力するファイル"
-#, fuzzy
-msgid "Cannot get raster band."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cannot read GRASS raster."
-msgstr "���"
-#, fuzzy
-msgid "Cannot get [%s] driver"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Couldn't set geo transform."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Couldn't set projection."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cannot export [%s] raster map."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cannot create [%s] raster map using [%s] driver."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cannot read header of raster map <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cannot open TIFF file <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Reading raster map"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Cannot open output map."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Illegal file name. Please try another."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "%s: can't open %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Reading raster map <%s> ..."
-msgstr "入力するファイル"
-#, fuzzy
-msgid "memory allocation failure"
-msgstr "ロケーション"
-#, fuzzy
-msgid "Cannot open vector map <%s> at the topological level"
-msgstr "���"
-#, fuzzy
-msgid "Rebuilding topology ..."
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Removing duplicates ..."
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Attaching islands ..."
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Attaching centroids ..."
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Vector map <%s> not found in current mapset"
-msgstr "���"
-#, fuzzy
-msgid "The number of lines in the input vector map is [%d]"
-msgstr "ピクセルの最小値"
-#, fuzzy
-msgid "Cannot get layer info"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "cell file [%s] not found"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "can't open raster map [%s]"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cannot rewrite line %d"
-msgstr "���"
-#, fuzzy
-msgid "Editing tool"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Cannot copy line %d, editing terminated"
-msgstr "���"
-#, fuzzy
-msgid "No layer database connection."
-msgstr "ロケーション"
-#, fuzzy
-msgid "Cannot snap lines %d,%d"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "%d lines modified"
-msgstr "タイトル"
-#, fuzzy
-msgid "Could not open ASCII file <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Print vector map region only"
-msgstr "���"
-#, fuzzy
-msgid "Cannot open vector map <%s> at topo level [%d]"
-msgstr "���"
-#, fuzzy
-msgid "Cannot get layer info for vector map <%s>"
-msgstr "���"
-#, fuzzy
-msgid "Cannot select attribute."
-msgstr "統一する属性の値"
-#, fuzzy
-msgid "Number of ROWS and COLUMNS in grid"
-msgstr "格子数"
-#, fuzzy
-msgid "Creating vector grid..."
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Could not find vector map <%s> in current mapset"
-msgstr "���"
-#, fuzzy
-msgid "Could not find input map <%s>."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "[%d] features written"
-msgstr "���"
-#, fuzzy
-msgid "Output map where segments will be written"
-msgstr "���."
-#, fuzzy
-msgid "<%s> cellfile not found"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Not able to open vector map <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "No table."
-msgstr "テーブル"
-#, fuzzy
-msgid "Can't read raster"
-msgstr "���"
-#, fuzzy
-msgid "driver name"
-msgstr "ドライバ"
-#, fuzzy
-msgid "database name"
-msgstr "データベース"
-#, fuzzy
-msgid "Driver name"
-msgstr "ドライバ"
-#, fuzzy
-msgid "output field separator"
-msgstr "区切り"
-#, fuzzy
-msgid "output vertical record separator"
-msgstr "上下方向の区切り"
-#, fuzzy
-msgid "null value indicator"
-msgstr "NULL値の識別子"
-#, fuzzy
-msgid "do not include column names in output"
-msgstr "ルートに沿ってセル値をコピー"
-#, fuzzy
-msgid "vertical output (instead of horizontal)"
-msgstr "8bitで出力"
-#, fuzzy
-msgid "Cannot find mapset for %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Label file [%s] not available"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Can't open label file [%s]"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "unable to open [%s] in [%s]"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "warning: unable to open [%s] in [%s]"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Unable to open raster map [%s] in [%s]"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Unable to find input cell map '%s'"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Unable to open cellfile for <%s>"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Unable to create raster map [%s]"
-#, fuzzy
-msgid "Unable to create output <%s>"
-#, fuzzy
-msgid "Input file [%s] not found."
-msgstr "���."
-#, fuzzy
-msgid "Unable to open output file <%s>."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Multiplier for ascii data"
-msgstr "高さの強調"
-#, fuzzy
-msgid "Could not open temporary file: [%s]"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Could not open input file [%s]"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "unable to create raster"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Unable to create output raster map <%s>"
-#, fuzzy
-msgid "Name of the random surface to be produced"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "%s: Unable to find raster map <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "%s: Unable to open raster map <%s> in mapset <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "%s:  Unable to open output raster map <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Vector <%s> could not be opened"
-msgstr "���"
-#, fuzzy
-msgid "Table name"
-msgstr "テーブル"
-#, fuzzy
-msgid "x column name"
-msgstr "キーカラム"
-#, fuzzy
-msgid "z column name"
-msgstr "キーカラム"
-#, fuzzy
-msgid "Cannot drop table: %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cannot open labels <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cannot open file [%s]"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "SVG file <%s> cannot be opened"
-msgstr "���"
-#, fuzzy
-msgid "Querying input '%s' ... "
-msgstr "���%s ..."
-#, fuzzy
-msgid "Copying %s input lines ... "
-msgstr "���."
-#, fuzzy
-msgid "Cannot create table <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "cannot insert row: %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cannot find line of cat %d"
-msgstr "���"
-#, fuzzy
-msgid "Unalbe to open vector map <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Transforms a vector map via a set of tie points."
-msgstr "ベクトルマップの座標変換を行います"
-#, fuzzy
-msgid "Raster map <%s>] not found"
-msgstr "対象マップ"
-#, fuzzy
-msgid "Cannot start driver <%s>."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Not able to find cellfile [%s]"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Raster map [%s] not found"
-msgstr "対象マップ"
-#, fuzzy
-msgid "Unable to open raster map [%s]"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Vector file [%s] not available"
-msgstr "対象マップ"
-#, fuzzy
-msgid "<%s> illegal name"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "%s: %s - Unable to open the input raster map\n"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "%s: %s - illegal name for output raster map."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Exports GRASS raster data into various formats (requires GDAL)."
-msgstr "ラスターマップをバイナリーファイルとしてエクスポートします"
-#, fuzzy
-msgid "Couldn't find raster map %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "%s: <%s> not found"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "%s: Cannot open <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cannot find %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "could not read range file"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Unable to create raster map [%s]."
-#, fuzzy
-msgid "Filtering [%s] in [%s]"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Open raster map %s in %s = %d"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Closing raster map"
-msgstr "カバーマップ"
-#, fuzzy
-msgid "Swap temp files"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Writing [%s]"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "%s: illegal map name"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "%s: <%s> illegal file name"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "can't open raster map <%s> in mapset %s"
-msgstr "���"
-#, fuzzy
-msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
-msgstr "ラスターマップをPPMファイルとしてエクスポートします"
-#, fuzzy
-msgid "Mapset of input map"
-#, fuzzy
-msgid "Checking location %s, mapset %s:"
-#, fuzzy
-msgid "Error writing output map"
-msgstr "解像度"
-#, fuzzy
-msgid "[%s] is an illegal file name"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Can't open temp file [%s]"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Names of existing raster maps"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Unable to open input map <%s> in mapset <%s>"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "%s - illegal name "
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Couldn't find raster map [%s]"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "%s - can't create raster map"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cell file [%s] not found"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Requested 3d raster map not found <%s>"
-msgstr "���."
-#, fuzzy
-msgid "Could not open output map"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "unable to close output map"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Could not close the 3d raster map"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cannot create output map [%s]"
-#, fuzzy
-msgid "Cannot open vector points map <%s>"
-msgstr "���."
-#, fuzzy
-msgid "Cannot create vector map <%s>"
-msgstr "���"
-#, fuzzy
-msgid "Vector file [%s] not available in search list"
-msgstr "対象マップ"
-#, fuzzy
-msgid "Cannot open table <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "The vector '%s' already exists."
-msgstr "���."
-#, fuzzy
-msgid "Could not find input map '%s'."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Could not find network input map '%s'."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "error opening raster map [%s]."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Patching file <%s@%s>"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "[%d] files patched"
-msgstr "���"
-#, fuzzy
-msgid "Could not open vector map <%s>"
-msgstr "���"
-#, fuzzy
-msgid "Illegal output name: '%s'"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Can't create output map"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "%s: cellfile [%s] not found."
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Unable to open cellfile [%s]."
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Error reading wildcard."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Sets the grid color, either a standard GRASS color or R:G:B triplet (separated by colons)"
-msgstr "線の色"
-#, fuzzy
-msgid "Sets the border color, either a standard GRASS color or R:G:B triplet"
-msgstr "線の色"
-#, fuzzy
-msgid "Unable to open the temporary file."
-msgstr "シグネチャファイル"
-#, fuzzy
-msgid "Unable to open raster map [%s]."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Unable to find raster [%s]."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "name for new raster map"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Output GRASS image file"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "name for new vector map (omit for display to stdout)"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Input vector map"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "%s: ERROR can't open tempfile"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "unable to find raster map [%s]"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "<%s> raster map not found"
-msgstr "対象マップ"
-#, fuzzy
-msgid "<%s> unable to open raster map"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cannot find vector map [%s]"
-msgstr "���"
-#, fuzzy
-msgid "%s - can't open raster map"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Can't get row %d from raster map %s"
-msgstr "対象マップ1"
-#, fuzzy
-msgid "%s - raster map not found"
-msgstr "対象マップ"
-#, fuzzy
-msgid "string representing no data cell value"
-msgstr "データのないセルに代入する記号"
-#, fuzzy
-msgid "File name of reference classes"
-msgstr "初期のクラスター数"
-#, fuzzy
-msgid "wide report, 132 columns (default: 80)"
-msgstr "レポート幅の拡大"
-#, fuzzy
-msgid "quiet"
-msgstr "説明なし"
-#, fuzzy
-msgid "<%s> - illegal output file name"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "%s: <%s> reference map not found"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Base raster map"
-msgstr "ベースマップ"
-#, fuzzy
-msgid "%s: raster map not found"
-msgstr "対象マップ"
-#, fuzzy
-msgid "Problem opening input file [%s]"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Problem opening output file [%s]"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "can't write category file for <%s>"
-msgstr "���"
-#, fuzzy
-msgid "%s: can't open tempfile"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Unable to read row %d in raster map [%s]"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Output verbosely"
-msgstr "説明つき表示"
-#, fuzzy
-msgid "Can't open raster map %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "It could not be find input map <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "It could not be found input map <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cannot find input map <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Input vector map <%s> not found."
-msgstr "���."
-#, fuzzy
-msgid "Category ranges: e.g. 1,3-8,13"
-#, fuzzy
-msgid "Writing attributes ...\n"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Could not open ascii file <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Could not open temp file <%s>"
-msgstr "���"
-#, fuzzy
-msgid "Vector map <%s> not fould"
-msgstr "���"
-#, fuzzy
-msgid "SVG output file"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Could not find vector '%s'"
-msgstr "���"
-#, fuzzy
-msgid "Could not find vector map %s"
-msgstr "���"
-#, fuzzy
-msgid "Unable to get row %d from <%s>"
-msgstr "対象マップ1"
-#, fuzzy
-msgid "No input coordinates provided"
-msgstr "X座標値"
-#, fuzzy
-msgid "Unable to allocate memory."
-#, fuzzy
-msgid "Raster output file"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Writing raster map ... "
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Keep existing color table"
-msgstr "カラーテーブルを上書きしない"
-#, fuzzy
-msgid "Name of the output walkers site file"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Verbose mode."
-msgstr "説明付き表示"
-#, fuzzy
-msgid " %d rows, %d cols."
-msgstr "���"
-#, fuzzy
-msgid "%s in %s - can't read header file"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "%s - unable to create raster map"
-#, fuzzy
-msgid "%s - unable to create category file"
-msgstr "シグネチャファイル"
-#, fuzzy
-msgid "verbose mode"
-msgstr "説明付き表示"
-#, fuzzy
-msgid "Vector map with points for which to modify the attribute table"
-msgstr "���"
-#, fuzzy
-msgid "Layer of the vector for which to modify the attribute table"
-msgstr "���"
-#, fuzzy
-msgid "Path to the input file"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Path to an output file"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Name of existing raster map to be displayed"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Database name:"
-msgstr "データベース"
-#, fuzzy
-msgid "ASCII file to be converted to binary vector map, if not given (or \"-\") reads from standard input"
-msgstr "���"
-#, fuzzy
-msgid "could not find input map <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "unable to open raster map [%s]"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "cannot get layer info for vector map"
-msgstr "���"
-#, fuzzy
-msgid "cannot create table: %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "cannot create index"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "cannot grant privileges on table %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cannot find vector map"
-msgstr "���"
-#, fuzzy
-msgid "Cannot find raster map"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cannot open raster map"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Unknown keyword [%s] in vector head."
-msgstr "���."
-#, fuzzy
-msgid "Error while reading cell map."
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Error while writing new cell map."
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Error in opening output file <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Unable to find input cell map <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Error in opening input file <%s>"
-msgstr "���"
-#, fuzzy
-msgid "Cannot find map %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cannot open map %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Name of predefined rules file"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "no such value"
-msgstr "閾値"
-#, fuzzy
-msgid "Unable to find base map <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Unable to find cover map <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "%s: reading category file for %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "%s: unable to open raster map [%s]"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "%s: unable to create raster map [%s]"
-#, fuzzy
-msgid "Unable to open database %s with driver %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "%s: Unable to read raster map [%s]"
-#, fuzzy
-msgid "%s: unable to open raster map <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "%s: Failed to read raster row %d"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Unable to read cats table for %s"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Could not open raster <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Screen coordinates to place the legend (as percentage)"
-msgstr "下,上,左,右の値(パーセンテージ)"
-#, fuzzy
-msgid "%s: o_open_file: raster map %s not found"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "%s: o_open_file: could not open raster map %s in %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "No record for category for [%d]"
-msgstr "���"
-#, fuzzy
-msgid "Error reading ASCII file <%s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "List of point coordinates. Required for add and move actions."
-msgstr "タイプ"
-#, fuzzy
-msgid "Could not find input vector '%s'"
-msgstr "���"
-#, fuzzy
-msgid "Failed opening output vector map '%s'"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Do not create attribute table."
-msgstr "統一する属性の値"
-#, fuzzy
-msgid "Error reading ascii file: [%s]"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "List vector maps in input location and exit (a dummy value must be given for input)"
-msgstr "目的ロケーション内のベクトルマップ一覧表示"
-#, fuzzy
-msgid "Allows the user to interactively query a vector map layer at user-selected locations within the current geographic region"
-msgstr "マウスで指定した位置でのベクトルマップのカテゴリー情報を表示します(ここはどこ?なに?)"
-#, fuzzy
-msgid "%s: <%s> vector map not found"
-msgstr "���"
-#, fuzzy
-msgid "Vector <%s> could not be open"
-msgstr "���"
-#, fuzzy
-msgid "Raster <%s> could not be open."
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Interpolation()"
-msgstr "補間方法"
-#, fuzzy
-msgid "Interpolation: Setting regions and boxes"
-msgstr "補間方法"
-#, fuzzy
-msgid "Interpolation: nsply = %d"
-msgstr "補間方法"
-#, fuzzy
-msgid "Interpolation: (%d,%d): Bilinear interpolation..."
-msgstr "補間に用いる近傍点"
-#, fuzzy
-msgid "Interpolation: (%d,%d): Bicubic interpolation..."
-msgstr "補間に用いる近傍点"
-#, fuzzy
-msgid "%s: Dropping <s>"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Interpolation was a success!"
-msgstr "補間方法"
-#, fuzzy
-msgid "CrossCorrelation: %d points read in region. "
-msgstr "現在の設定を表示"
-#, fuzzy
-msgid "CrossCorrelation: It shouldn't take too long."
-msgstr "統一する属性の値"
-#, fuzzy
-msgid "%s -- illegal output file name"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Sorry, with method '%s' you have to define an output map."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Existing raster map name"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "%s - can't read raster cellhd"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "error reading cell data"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "No line found."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Do not build topology."
-msgstr "統一する属性の値"
-#, fuzzy
-msgid "Could not open ascii file [%s]"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "%s: Cannot open dxf file"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Conversion of [%s] to vector map ..."
-msgstr "���."
-#, fuzzy
-msgid "Name of output 3d raster map"
-msgstr "出力するファイル"
-#, fuzzy
-msgid ""
-"\n"
-"Where %s is one of:\n"
-msgstr ""
-"\n"
-"ここでの %s は次のうちのいずれかです:\n"
-#, fuzzy
-msgid "ERROR: <%s> not found\n"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "ERROR: <%s> illegal name\n"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cannot open toolbox: %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Cannot open toolbox."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Vector map(s) -- source for composite"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Append files to existing file"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Vector map '%s' not found"
-msgstr "���"
-#, fuzzy
-msgid "Input elevation file"
-msgstr "標高を示すファイル(入力)"
-#, fuzzy
-msgid "Input aspect file"
-#, fuzzy
-msgid "Input barrier file"
-msgstr "バリアを示すファイル(入力)"
-#, fuzzy
-msgid "Quiet operation"
-msgstr "説明なし"
-#, fuzzy
-msgid "Display Reference Information"
-msgstr "ヘッダーの表示"
-#, fuzzy
-msgid "Aspect file's resolution differs from                        current region resolution"
-msgstr "値の読みとり間隔(デフォルト:現在の解像度)"
-#, fuzzy
-msgid "output layer name"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Imagery files subgroup"
-msgstr "サブ画像グループ"
-#, fuzzy
-msgid "Warning: illegal output file name <%s>."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Category <%d>: Line color and background color are the same!"
-msgstr "���!"
-#, fuzzy
-msgid "Line color and background color are the same!"
-msgstr "���!"
-#, fuzzy
-msgid "datetime, datetime1/datetime2, or none"
-msgstr "タイムスタンプ"
-#, fuzzy
-msgid "Open vector 3d raster map %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Open 3d raster map %s"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Vector import complete"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Unable to create raster map for [%s]"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "error opening 3d raster map"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Read fp map as integer (use map's quant rules"
-msgstr "実数を整数に変換して使用"
-#, fuzzy
-msgid "Name for the resulting raster map"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Open Raster file %s in Mapset %s"
-msgstr "���"
-#, fuzzy
-msgid "Open 3d raster map %s\n"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Open elev raster map %s\n"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Could not open map %s\n"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Bin raster map to be imported"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Output partial derivatives instead"
-msgstr "傾斜値、傾斜方位、曲率の代わりに偏導関数を出力"
-#, fuzzy
-msgid "Maximum distance"
-msgstr "最大値"
-#, fuzzy
-msgid "Makes 3D trees from input point vector map"
-msgstr "���"
-#, fuzzy
-msgid "Diameter of the tree crown in map units"
-msgstr "視点座標"
-#, fuzzy
-msgid "Height of tree trunk in meters"
-msgstr "地表からの高さ(単位:メートル)"
-#, fuzzy
-msgid "Name of the column with tree crown width"
-msgstr "最終レポートを出力するファイル"
-#, fuzzy
-msgid "Cannot select attributes for point #%d"
-msgstr "統一する属性の値"
-#, fuzzy
-msgid "Map coordinates"
-msgstr "Z座標値"
-#, fuzzy
-msgid "%s Quit\n"
-msgstr "説明なし"
-#, fuzzy
-msgid "Quiet mode"
-msgstr "説明なし"
-#, fuzzy
-msgid "%s[%d]: No raster map specified."
-msgstr "対象マップ"
-#, fuzzy
-msgid "Query column name"
-msgstr "キーカラム"
-#, fuzzy
-msgid "name for new binary vector map (omit for display to stdout)"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Name for G3d raster map"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "No output maps"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Connect to the database through DBMI."
-msgstr "データベースに接続します"
-#, fuzzy
-msgid "The resolution of raster and raster3d maps should be equal!"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Compute upslope flowlines"
-msgstr "流路を遡って計算"
-#, fuzzy
-msgid "The map E and N grid coordinates of a starting point"
-msgstr "始点の座標値"
-#, fuzzy
-msgid "Invoke fast, but memory intensive operation"
-msgstr "高速計算(大きなメモリが必要)"
-#, fuzzy
-msgid "You first need to run v.build on vector map <%s>"
-msgstr "���"
-#, fuzzy
-msgid "unknown interpolation method"
-msgstr "補間方法"
-#, fuzzy
-msgid "Name of existing raster map."
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Name of new raster map."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Name of input map"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Name of existing input raster map"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "cover raster map"
-msgstr "カバーマップ"
-#, fuzzy
-msgid "resultant raster map"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Input layer name"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Output layer name"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Name of the resulting map"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Aspect"
-msgstr "傾斜方位またはdy値を出力するファイル"
-#, fuzzy
-msgid "Profile curvature"
-msgstr "断面曲率またはdxx値を出力するファイル"
-#, fuzzy
-msgid "Tangential curvature"
-msgstr "正接曲率またはdyy値を出力するファイル"
-#, fuzzy
-msgid "Mean curvature"
-msgstr "平均曲率またはdxy値を出力するファイル"
-#, fuzzy
-msgid "Enter name for the resulting signature file"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "page length (default: %d lines)"
-msgstr "1ページの行数"
-#, fuzzy
-msgid "page width (default: %d characters)"
-msgstr "1行の文字数"
-#, fuzzy
-msgid "suppress page headers"
-msgstr "ヘッダーの削除"
-#, fuzzy
-msgid "use formfeeds between pages"
-msgstr "フォームフィードの使用"
-#, fuzzy
-msgid "Write an Arc-Info line/polygon coverage in e00 format."
-msgstr "ベクトルマップをARC/INFO E00ファイルとしてエクスポートします"
-#, fuzzy
-msgid "Mapset holding vector map to be exported (Default = current)"
-msgstr "入力するファイルを含むマップセット(デフォルト=現在のマップセット)"
-#, fuzzy
-msgid "Name of .e00 output file (Default: stdout)"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Process spaghetti-digitized binary vector map."
-msgstr "スパゲッティデータ(バイナリー形式)の編集を行います"
-#, fuzzy
-msgid "Only run identical line tests"
-msgstr "指定したラインのみで実行"
-#, fuzzy
-msgid "Snap nodes"
-msgstr "端点をスナップ"
-#, fuzzy
-msgid ""
-"Set line types to:   \n"
-"             source        same as in binary vector map\n"
-"             line          lines\n"
-"             area          area edges\n"
-"             point         points (sites)\n"
-msgstr ""
-"線の種類:   \n"
-"             source        元のベクトルマップと同じ\n"
-"             line          ç·š\n"
-"             area          エリアエッジ\n"
-"             point         点(サイトデータ)\n"
-#, fuzzy
-msgid "Output file is ASCII map"
-msgstr "ASCII形式のベクトルマップを出力"
-#, fuzzy
-msgid "Copy attributes and category files"
-msgstr "属性およびカテゴリーファイルをコピー"
-#, fuzzy
-msgid "Converts point data in a binary GRASS vector map layer into a GRASS site_lists file."
-msgstr "ベクトルマップからデータを抽出してサイトマップに変換します"
-#, fuzzy
-msgid "Use Category NUMERIC data instead of attribute"
-msgstr "属性の代わりに数値データを使用"
-#, fuzzy
-msgid "Use Category TEXT data instead of attribute"
-msgstr "属性の代わりにテキストデータを使用"
-#, fuzzy
-msgid "Test routine for developing MIF import."
-msgstr " ESRI シェープファイルをベクトルマップとしてインポートします"
-#, fuzzy
-msgid "Debugging level : 0 (silent) - 3 (verbose)"
-msgstr "デバッグレベル"
-#, fuzzy
-msgid "Name of file where to log operations"
-msgstr "ログファイル"
-#, fuzzy
-msgid "Snap distance in ground units (Default = 10^-10)"
-msgstr "端点のスナップ距離"
-#, fuzzy
-msgid "Set initial scale [1:2400]"
-msgstr "スケール"
-#, fuzzy
-msgid "Name of attribute to use as category"
-msgstr "属性番号のフィールド名"
-#, fuzzy
-msgid "Allow overwrite of existing vector map with the same name"
-msgstr "上書き"
-#, fuzzy
-msgid "Force writing  polygon coverage as a line coverage"
-msgstr "強制インポート"
-#, fuzzy
-msgid "Create unique value for parts of compound object"
-msgstr "ID番号を属性として使用"
-#, fuzzy
-msgid "List fields of DBF file"
-msgstr "データベースのフィールド一覧を表示して終了"
-#, fuzzy
-msgid "new categories table title"
-msgstr "タイトル"
-#, fuzzy
-msgid "Build topology info (default) OR Edit categories"
-msgstr "トポロジーの構築かカテゴリーの編集"
-#, fuzzy
-msgid "Prompt user for threshold         (Valid only with Build option)"
-msgstr "閾値のユーザ定義"
-#, fuzzy
-msgid "read data into memory"
-msgstr "タイトル"
-#, fuzzy
-msgid "Set map region from data          (Valid only with Build option)"
-msgstr "データから地域を設定"
-#, fuzzy
-msgid "Snap Threshold value       (Valid only with Build option and -s)"
-msgstr "スナップの閾値"
-#, fuzzy
-msgid "Suppress drawing of text outlines"
-msgstr "テキストのアウトラインを非表示"
-#, fuzzy
-msgid "DXF layers with line data"
-msgstr "ラインデータを含むファイル"
-#, fuzzy
-msgid "DXF layers with label data"
-msgstr "ラベルデータを含むファイル"
-#, fuzzy
-msgid "Prefix for dig or dig_ascii and dig_att output files"
-msgstr "出力するファイル"
-#, fuzzy
-msgid ""
-"\n"
-"\n"
-"Where lines and labels are one or more of:\n"
-"\n"
-msgstr ""
-"\n"
-"\n"
-"ここでのlines,labelsの入力形式は以下の通りです:\n"
-"\n"
-#, fuzzy
-msgid ""
-"      and/or   \n"
-"\n"
-msgstr ""
-"      または   \n"
-"\n"
-#, fuzzy
-msgid "angle of rotation"
-msgstr "回転角度"
-#, fuzzy
-msgid "provide attributes of type: const,rows,cols"
-msgstr "属性タイプ"
-#, fuzzy
-msgid "binary vector map to be converted to ascii"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Converts ASCII vector map layers into binary vector map layers."
-msgstr " ASCII形式のファイルをベクトルマップとしてインポートします"
-#, fuzzy
-msgid "what load"
-msgstr "更新する対象"
-#, fuzzy
-msgid "key column"
-msgstr "キーカラム"
-#, fuzzy
-msgid "Prints information about a binary GRASS vector map layer."
-msgstr "ベクトルマップについての情報を表示します"
-#, fuzzy
-msgid "Cleans out dead lines in GRASS vector maps."
-msgstr "ベクトルマップのデータ中で削除マークの付いた線を全て取り除きます"
-#, fuzzy
-msgid "Key (id) column name"
-msgstr "キーカラム"
-#, fuzzy
-msgid "Select area, line, or site "
-msgstr "タイプ"
-#, fuzzy
-msgid "input vector map for ARC/INFO conversion"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "coverage type"
-msgstr "抽出するタイプ"
-#, fuzzy
-msgid "prefix for ARC/INFO output filenames"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "The postscript versions of these papers are available via Internet at"
-msgstr "これらの文献はポストスクリプト形式で下のURLから入手できます"
-#, fuzzy
-msgid "Please cite these references in publications where the results of this"
-msgstr "このプログラムの結果を論文等に公表する場合, "
-#, fuzzy
-msgid "Do zero attributes/cats represent elevation?"
-msgstr "入力ファイルの値0を標高に置き換える"
-#, fuzzy
-msgid "path to GRASS database of input location"
-msgstr "目的ロケーションを含むデータベース"
-#, fuzzy
-msgid "Automatically run \"v.support\" on newly created vector map."
-msgstr "'v.support'コマンドを自動的に実行"
-#, fuzzy
-msgid "Type of object to extract (area, line or both)"
-msgstr "抽出する線のタイプ"
-#, fuzzy
-msgid "Limit line output to area-edge arcs"
-msgstr "エリアエッジのみ抽出"
-#, fuzzy
-msgid "Limit line output to line arcs"
-msgstr "線のみ抽出"
-#, fuzzy
-msgid "Polygon Cookie Cutter  (Boolean AND Overlay)."
-msgstr "2つの既存するベクトルマップの交差関係にもとづいた演算(ブール代数のANDオーバーレイ)を行い、新しいマップを作成します"
-#, fuzzy
-msgid "ARC/INFO ungenerate lines file"
-msgstr "入力するラインファイル"
-#, fuzzy
-msgid "ARC/INFO ungenerate label-points file"
-msgstr "入力するラベル(ポイント)ファイル"
-#, fuzzy
-msgid "ARC/INFO label-text file"
-msgstr "入力するラベル(テキスト)ファイル"
-#, fuzzy
-msgid "resultant Vector output file"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "ID Number column in label-text file"
-msgstr "テキストの列数(ID番号)"
-#, fuzzy
-msgid "GRASS category column in label-text file"
-msgstr "テキストの列数(カテゴリー値)"
-#, fuzzy
-msgid "GRASS attribute column in label-text file"
-msgstr "テキストの列数(属性)"
-#, fuzzy
-msgid "new pruned vector map"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "reports attribute, label, and other information about a sites file"
-msgstr "サイトマップの基礎情報を出力します"
-#, fuzzy
-msgid "Name of sites file."
-msgstr "対象マップ"
-#, fuzzy
-msgid "Load quietly"
-msgstr "説明なし"
-#, fuzzy
-msgid "Only count sites in current window for min/max."
-msgstr "最大値と最小値のみ出力"
-#, fuzzy
-msgid "Show quartiles for decimal attributes"
-msgstr "属性番号の出力"
-#, fuzzy
-msgid "Name of input sites map"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "which decimal attribute (if multiple)"
-msgstr "属性番号"
-#, fuzzy
-msgid "Use raster's region vs. current region"
-msgstr "ラスターマップの領域の使用"
-#, fuzzy
-msgid "Name of sites file to filter"
-msgstr "入力するファイル(サイト)"
-#, fuzzy
-msgid "Converts a GRASS site list file into an ASCII listing of site locations and their descriptions."
-msgstr "サイトマップをASCII形式のサイトリストとしてエクスポートします"
-#, fuzzy
-msgid "Include site attributes in the output"
-msgstr "カテゴリーラベルも出力"
-#, fuzzy
-msgid "Include site attribute identifiers in the output"
-msgstr "属性識別子も出力"
-#, fuzzy
-msgid "Name of input site list"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Number of cells to surround site cell"
-msgstr "考慮する周辺のセル数"
-#, fuzzy
-msgid "Attribute field type to use for operation"
-msgstr "属性タイプ"
-#, fuzzy
-msgid "Attribute field number to use for operation"
-msgstr "属性番号"
-#, fuzzy
-msgid "String attribute number to use for description"
-msgstr "文字型属性番号"
-#, fuzzy
-msgid "Create a single-valued (0/1) raster map"
-msgstr "0と1のみで構成されるラスターマップを出力"
-#, fuzzy
-msgid "Average an attribute of a site_list for all the sites within each cell of the current region."
-msgstr "サイトマップ全体から属性の平均を出力します"
-#, fuzzy
-msgid "Attribute to average values over"
-msgstr "属性タイプ"
-#, fuzzy
-msgid "Index of attribute type (ignored for cat)"
-msgstr "属性番号"
-#, fuzzy
-msgid "sites list to store means"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Suppress windows with zero averages"
-msgstr "データのないセルは出力しない"
-#, fuzzy
-msgid "Output in g.gnuplot format (overrides -z and writes to stdout)"
-msgstr "'g.gnuplot'コマンド形式で出力"
-#, fuzzy
-msgid "Convert an ASCII listing of site locations into a GRASS site list file."
-#, fuzzy
-msgid "sites file to be created"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "number of dimensions (default=2)"
-msgstr "配列の数(デフォルト2)"
-#, fuzzy
-msgid "input field separator"
-msgstr "区切り"
-#, fuzzy
-msgid "datetime or datetime1/datetime2"
-msgstr "タイムスタンプ"
-#, fuzzy
-msgid "Allows the user to re-project a sites file from one location to the current location (no datum transformation yet)."
-msgstr "サイトマップの投影変換を行います"
-#, fuzzy
-msgid "input sites list"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "location of input sites list"
-msgstr "再投影を行うロケーション"
-#, fuzzy
-msgid "mapset of input sites list"
-#, fuzzy
-msgid "output sites list"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "List sites files in input location and exit"
-msgstr "目的ロケーション内のサイトマップ一覧表示"
-#, fuzzy
-msgid "Don't prompt for Map header information"
-msgstr "ヘッダーを削除"
-#, fuzzy
-msgid "Field type (\"string\", \"dim\", or \"decimal\") and index to use for category value (uses \"cat\" by default)"
-msgstr "属性タイプまたは属性番号"
-#, fuzzy
-msgid "Allows the user to interactively adjust the settings (zoom  and  pan) of the current geographic region using a pointing device such as a mouse."
-msgstr "対象地域のズーム/パンをマウスにより行います"
-#, fuzzy
-msgid "Displays points, as icons, at user-defined locations in the active display frame on the graphics monitor."
-msgstr "アイコンでポイントマーカーを表示します"
-#, fuzzy
-msgid "Name of existing sites file"
-msgstr "対象マップ"
-#, fuzzy
-msgid "Identify just one site"
-msgstr "1度のみ実行"
-#, fuzzy
-msgid "For parsing by programs: Terse output"
-msgstr "簡易表示"
-#, fuzzy
-msgid "Allows the user to interactively query site list descriptions. "
-msgstr "マウスで指定した位置でのサイトマップのカテゴリー情報を表示します(ここはどこ?なに?)"
-#, fuzzy
-msgid "Color to erase with"
-msgstr "塗りつぶす色"
-#, fuzzy
-msgid "Name of a spheroid (for lat/lon coordinate conversion)"
-msgstr "変換先の楕円体"
-#, fuzzy
-msgid "Displays three-dimensional images based on raster map layers"
-msgstr "ラスターマップを3次元で表示します"
-#, fuzzy
-msgid "The raster map used to generate the color"
-msgstr "色のラスターマップ"
-#, fuzzy
-msgid "The raster map used to generate the 3-d texture"
-msgstr "標高のラスターマップ"
-#, fuzzy
-msgid "coordinates of center of view"
-msgstr "視野の中心座標"
-#, fuzzy
-msgid "Frequency of vector lines in output"
-msgstr "格子間隔"
-#, fuzzy
-msgid "Field of view"
-msgstr "視野の角度"
-#, fuzzy
-msgid "Color of bounding box"
-msgstr "枠の色"
-#, fuzzy
-msgid "Show null elevations"
-msgstr "NULL値を表示"
-#, fuzzy
-msgid "Draw labelled vector lines to the current display device"
-msgstr "ベクトルラインを表示します"
-#, fuzzy
-msgid "Name of existing vector map to draw"
-msgstr "対象マップ"
-#, fuzzy
-msgid "Draw all lines using either a GRASS standard color or R:G:B triplet (separated by colons)"
-msgstr "線の色"
-#, fuzzy
-msgid "Only draw areas with a matching category number (for constant color option only)"
-msgstr "表示するカテゴリー番号"
-#, fuzzy
-msgid "Draw lines according to a legend file (<cat> <R> <G> <B>)"
-msgstr "凡例用ファイル"
-#, fuzzy
-msgid "Use random colors"
-msgstr "ランダムな色を使用"
-#, fuzzy
-msgid "Line color -- a GRASS named color, an R:G:B triplet, or \"none\""
-msgstr "境界線の色"
-#, fuzzy
-msgid "Limit to matching category number(s) (constant color option only)"
-msgstr "表示するカテゴリー番号(色が指定されているときのみ有効)"
-#, fuzzy
-msgid "Use a legend file: (<cat> <R> <G> <B> [<R> <G> <B>])"
-msgstr "凡例用ファイル"
-#, fuzzy
-msgid "Sets the current color to that stated"
-msgstr "色"
-#, fuzzy
-msgid "Size, in pixels, in which the icon is to be drawn"
-msgstr "アイコンのサイズ(ピクセル)"
-#, fuzzy
-msgid "Interactively label sites using a string or double attribute value or the category value on the current graphics monitor."
-msgstr "サイトラベルを表示します"
-#, fuzzy
-msgid "Name of sites file"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Index of attribute. Ignored when attr=cat or attr=coords."
-msgstr "属性番号"
-#, fuzzy
-msgid "Relative horizontal position 'left|center|right'"
-msgstr "位置(水平方向)"
-#, fuzzy
-msgid "Relative vertical position 'top|center|bottom'"
-msgstr "位置(鉛直方向)"
-#, fuzzy
-msgid "Size of text (pixels)"
-msgstr "テキストのサイズ"
-#, fuzzy
-msgid "Sets the font"
-msgstr "フォント"
-#, fuzzy
-msgid "Sets the current grid color"
-msgstr "線の色"
-#, fuzzy
-msgid "displays vector maps, optionally only selected categories in current monitor window."
-msgstr "ベクトルマップを表示します"
-#, fuzzy
-msgid "Vector category number(s) to be displayed"
-#, fuzzy
-msgid "Input is a UNIX file name"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Allows the user to establish whether a map will be displayed using its own color table or the fixed color table of the graphics monitor."
-msgstr "モニターに用いるカラーテーブルを設定します"
-#, fuzzy
-msgid "Creates and modifies icons for use with ps.map."
-msgstr "ポストスクリプトマップに使用するアイコンの作成/編集を行います"
-#, fuzzy
-msgid "icon filename"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "file containing mapping instructions (or use input=- to enter from keyboard)"
-msgstr "設定ファイル"
-#, fuzzy
-msgid "scale of the output map, e.g. 1:25000 (default: 1panel)"
-msgstr "スケール (例: 1:25000)"
-#, fuzzy
-msgid "number of copies to print"
-msgstr "部数"
-#, fuzzy
-msgid "Selects a PostScript device for GRASS hardcopy output."
-msgstr "ハードコピーを出力するデバイスを選択します"
-#, fuzzy
-msgid "name of PostScript painter to select"
-msgstr "使用するデバイス"
-#, fuzzy
-msgid "list all available PostScript painters"
-msgstr "ポストスクリプトペインタの一覧表示"
-#, fuzzy
-msgid "print name of currently selected PostScript painter"
-msgstr "現在選択されているペインタ名を表示"
-#, fuzzy
-msgid "quietly select PostScript painter"
-msgstr "説明なし"
-#, fuzzy
-msgid "Creates raster maps from ERDAS files."
-msgstr "ERDAS/LANファイルをラスターマップとしてインポートします"
-#, fuzzy
-msgid "List the ERDAS header only"
-msgstr "ヘッダーのみ一覧表示"
-#, fuzzy
-msgid "Disable autoswap detection"
-msgstr "自動でビット反転しない"
-#, fuzzy
-msgid "Force Swapping (overrides default auto)"
-msgstr "強制ビット反転"
-#, fuzzy
-msgid "output prefix of the GRASS raster maps to be created."
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Erdas trailer input file name"
-msgstr "ERDASトレイラーファイル"
-#, fuzzy
-msgid "Starting row."
-msgstr "開始行"
-#, fuzzy
-msgid "Starting column."
-msgstr "開始列"
-#, fuzzy
-msgid "Number of rows to extract."
-msgstr "抽出する行数"
-#, fuzzy
-msgid "Number of columns to extract."
-msgstr "抽出する列数"
-#, fuzzy
-msgid "Creates ERDAS files from raster maps."
-msgstr "GRASSの画像ファイルをERDAS/LANファイルとしてエクスポートします"
-#, fuzzy
-msgid "Output 16-bit image (default 8)"
-msgstr "16bitイメージで出力"
-#, fuzzy
-msgid "Force byte swapping"
-msgstr "強制ビット反転"
-#, fuzzy
-msgid "Erdas output file name"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Allows category values from several raster map layers to be combined."
-msgstr "ラスターマップのカテゴリー値を論理操作します"
-#, fuzzy
-msgid "Use symbols (instead of graphics)"
-msgstr "シンボルを使用"
-#, fuzzy
-msgid "Create floating-point maps (0.0 - 1.0)."
-msgstr "実数形式のマップを作成"
-#, fuzzy
-msgid "Output image file header only."
-msgstr "ヘッダーのみ出力"
-#, fuzzy
-msgid "Enable extend memory option: Operation is slow"
-msgstr "仮想メモリを使用"
-#, fuzzy
-msgid "Name of an output binary map (use out=- for stdout)"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Converts point data in a GRASS raster map layer into a GRASS site_lists file."
-msgstr "ラスターマップからデータを抽出してサイトマップに変換します"
-#, fuzzy
-msgid "Output as decimal attribute rather than cat"
-msgstr "属性番号として出力"
-#, fuzzy
-msgid "Output as third dimension rather than cat"
-msgstr "標高値として出力"
-#, fuzzy
-msgid "Name of raster map."
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Creates a new binary GRASS vector (v.digit) file by extracting linear features from a thinned raster map."
-msgstr "細線化したラスターマップからベクトルマップを作成します"
-#, fuzzy
-msgid "Creates a raster map layer and site list file containing randomly located sites."
-msgstr "任意抽出を行います"
-#, fuzzy
-msgid "Name of the output sites map"
-msgstr "出力するファイル(サイトマップ)"
-#, fuzzy
-msgid "Imports a TIFF (8 or 24 bit) raster map into GRASS raster map(s)"
-msgstr "TIFFファイルをラスターマップとしてインポートします"
-#, fuzzy
-msgid "Name on TIFF file to input."
-msgstr "入力するファイル"
-#, fuzzy
-msgid "Bayesian expert system development program."
-msgstr "ベイズの統計に基づいた推論規則を適用し新しいラスターマップを作成します"
-#, fuzzy
-msgid "Run verbosely with debugging output"
-msgstr "説明付き表示"
-#, fuzzy
-msgid "The site list"
-msgstr "出力:クランプの重心を示すファイル"
-#, fuzzy
-msgid "raster map(s) to report on"
-msgstr "対象マップ"
-#, fuzzy
-msgid "mi(les),me(ters),k(ilometers),a(cres),h(ectacres),c(ell_counts),p(ercent_cover)"
-msgstr "単位"
-#, fuzzy
-msgid "name of an output file to hold the report"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "number of fp subranges to collect stats from"
-msgstr "誤差の桁数"
-#, fuzzy
-msgid "filter out all no data cells"
-msgstr "NULL値を対象に含まない"
-#, fuzzy
-msgid "filter out cells where all maps have no data"
-msgstr "すべてのマップでNULL値となっているセルを除く"
-#, fuzzy
-msgid "report for cats fp ranges (fp maps only)"
-msgstr "実数でレポートを出力"
-#, fuzzy
-msgid "Generates an output raster map layer with contiguous areas grown by one cell (pixel)."
-msgstr "エリアを拡大したラスターマップを作成します"
-#, fuzzy
-msgid "re-project a raster map from one location to the current location (no datum transformation yet)"
-msgstr "ラスターマップの投影変換を行います"
-#, fuzzy
-msgid "mapset of input map"
-#, fuzzy
-msgid "resolution of output map"
-msgstr "解像度"
-#, fuzzy
-msgid "Don't attempt to crop output map"
-msgstr "投影後の不要部分を削除しない"
-#, fuzzy
-msgid "Print grid coordinates (east and north) (requires -1 flag)"
-msgstr "格子点の座標を出力"
-#, fuzzy
-msgid "output is the interpolation error"
-msgstr "誤差を出力"
-#, fuzzy
-msgid "read fp map as integer"
-#, fuzzy
-msgid "format for reporting the slope"
-msgstr "傾斜の単位"
-#, fuzzy
-msgid "type of output aspect and slope maps"
-msgstr "出力する値の型"
-#, fuzzy
-msgid "Output E-W slope filename"
-msgstr "東西方向の傾斜を出力するファイル"
-#, fuzzy
-msgid "Output N-S slope filename"
-msgstr "南北方向の傾斜を出力するファイル"
-#, fuzzy
-msgid "Output partial derivative dxx filename"
-msgstr "dxx値の偏導関数を出力するファイル"
-#, fuzzy
-msgid "Output partial derivative dyy filename"
-msgstr "dyy値の偏導関数を出力するファイル"
-#, fuzzy
-msgid "Output partial derivative dxy filename"
-msgstr "dxy値の偏導関数を出力するファイル"
-#, fuzzy
-msgid "Name of file for output (use out=- for stdout)"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "print range only."
-#, fuzzy
-msgid "Converts raster data referenced using latitude and longitude coordinates to a UTM-referenced map layer in GRASS raster format."
-msgstr "緯度/経度座標ファイルから UTM座標ファイルを作成します"
-#, fuzzy
-msgid "input file"
-msgstr "入力するファイル"
-#, fuzzy
-msgid ""
-"one corner latitude and longitude of the input\n"
-"format: {nw|ne|sw|se},%s,%s"
-msgstr "領域の端の座標値 入力形式: {nw|ne|sw|se},%s,%s"
-#, fuzzy
-msgid "resolution of the input (in arc seconds)"
-msgstr "解像度(秒角)"
-#, fuzzy
-msgid "Starting points site file"
-msgstr "始点を示すサイトマップ"
-#, fuzzy
-msgid "Stop points site file"
-msgstr "終点を示すサイトマップ"
-#, fuzzy
-msgid "Extracts area edges from a raster map layer and converts data to GRASS vector format."
-msgstr "ラスターマップからエリアエッジを抽出してベクトルマップを作成します"
-#, fuzzy
-msgid "Output only area borders as vector lines"
-msgstr "ベクトルラインを出力"
-#, fuzzy
-msgid "Number of values printed before wrapping a line"
-msgstr "読み込む桁数"
-#, fuzzy
-msgid "raster map name from which to copy color table"
-msgstr "カラーテーブルに用いるラスターマップ"
-#, fuzzy
-msgid ""
-"\n"
-"Where color type is one of:\n"
-msgstr ""
-"\n"
-"ここでのカラーテーブル(colorパラメータ)は次のうちのいずれかです:\n"
-#, fuzzy
-msgid "  aspect    (aspect oriented grey colors)\n"
-msgstr "  aspect    (グレーカラー)\n"
-#, fuzzy
-msgid "  grey      (linear grey scale)\n"
-msgstr "  grey      (グレースケール)\n"
-#, fuzzy
-msgid "  grey.eq   (histogram equalized grey scale)\n"
-msgstr "  grey.eq   (ヒストグラムを平滑化したグレースケール)\n"
-#, fuzzy
-msgid "  grey.log  (histogram logarithmic transformed grey scale)\n"
-msgstr "  grey.log  (ヒストグラムを対数化したグレースケール)\n"
-#, fuzzy
-msgid "  byg       (blue through yellow to green colors)\n"
-msgstr "  byg       (青→黄→緑)\n"
-#, fuzzy
-msgid "  byr       (blue through yellow to red colors)\n"
-msgstr "  byr       (青→黄→赤)\n"
-#, fuzzy
-msgid "  gyr       (green through yellow to red colors)\n"
-msgstr "  gyr       (緑→黄→赤)\n"
-#, fuzzy
-msgid "  rainbow   (rainbow color table)\n"
-msgstr "  rainbow   (レインボー)\n"
-#, fuzzy
-msgid "  ramp      (color ramp)\n"
-msgstr "  ramp      (ランプ)\n"
-#, fuzzy
-msgid "  ryg       (red through yellow to green colors)\n"
-msgstr "  ryg       (赤→黄→緑)\n"
-#, fuzzy
-msgid "  random    (random color table)\n"
-msgstr "  random    (ランダム)\n"
-#, fuzzy
-msgid "  wave      (color wave)\n"
-msgstr "  wave      (カラーウェーブ)\n"
-#, fuzzy
-msgid "  rules     (create new color table by rules)\n"
-msgstr "  rules     (ルールの新規作成)\n"
-#, fuzzy
-msgid "method of object-based statistic"
-msgstr "統計解析方法"
-#, fuzzy
-msgid "resultant raster map (not used with 'distribution')"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Northern limit of geographic region"
-msgstr "領域の北端"
-#, fuzzy
-msgid "Eastern limit of geographic region"
-msgstr "領域の東端"
-#, fuzzy
-msgid "Western limit of geographic region"
-msgstr "領域の西端"
-#, fuzzy
-msgid "Override projection (use locations projection)"
-msgstr "現在のロケーションの投影法を使用"
-#, fuzzy
-msgid "Extend location extents based on new dataset."
-msgstr "データセットをもとにロケーションを拡張"
-#, fuzzy
-msgid "Maximum magnitude of random grid point offset"
-msgstr "ランダムにとるオフセットの最大値"
-#, fuzzy
-msgid "Outputs a raster map layer whose category values represent the application of user-specified criteria (rules statements) to other raster map layers' category values."
-msgstr "指定した推論規則を適用し新しいラスターマップを作成します"
-#, fuzzy
-msgid "Converts a PPM image file to GRASS raster map(s)."
-msgstr "PPMファイルをラスターマップとしてインポートします"
-#, fuzzy
-msgid "Create separate red/green/blue maps."
-msgstr "赤/緑/青に対応するラスターマップを出力"
-#, fuzzy
-msgid "Create composite color map."
-msgstr "合成した色のラスターマップを出力"
-#, fuzzy
-msgid "Converts Universal Transverse Mercator (UTM) coordinates to geographic (latitude/longitude) coordinates."
-msgstr "UTM座標値から緯度/経度座標値に変換します"
-#, fuzzy
-msgid "reference spheroid (ellipsoid)"
-msgstr "楕円体"
-#, fuzzy
-msgid "Specified zone is in the southern hemisphere"
-msgstr "領域を南半球で指定"
-#, fuzzy
-msgid "Input is reversed: north,east"
-msgstr "入力する座標値を反転(north,east)"
-#, fuzzy
-msgid "Do not flag invalid east,north input lines as errors"
-msgstr "領域外の座標が入力されても続行"
-#, fuzzy
-msgid "Flag other input lines as errors"
-msgstr "他の形式で入力があった場合は中止"
-#, fuzzy
-msgid "Output in decimal degrees"
-msgstr "10進数で出力"
-#, fuzzy
-msgid "Converts geographic coordinates to Universal Transverse Mercator (UTM) coordinates."
-msgstr "緯度/経度座標値からUTM座標値に変換します"
-#, fuzzy
-msgid "utm zone (results will be forced into this zone)"
-msgstr "UTMゾーン"
-#, fuzzy
-msgid "Input is reversed: lat,lon"
-msgstr "入力する座標値を反転(経度,緯度)"
-#, fuzzy
-msgid "Do not flag invalid lon,lat input lines as errors"
-#, fuzzy
-msgid "Suppress printing the utm zone"
-msgstr "UTMゾーンを出力しない"
-#, fuzzy
-msgid "Rotates elevation data extracted by either m.dted.extract or m.dmaUSGSread."
-msgstr "抽出した標高データを90度回転します"
-#, fuzzy
-msgid "Output file"
-msgstr "出力するファイル"
-#, fuzzy
-msgid "Number of bytes per cell (i.e. per data value)"
-msgstr "1セルのバイト数"
-#, fuzzy
-msgid "Provides a terse description of level 1 and 2 digital terrain elevation data (DTED) files produced and distributed by the Defense Mapping Agency (DMA) on 1/2-inch magnetic tapes."
-msgstr "1/2インチ磁気テープのデータからDTEDを簡易表示します"
-#, fuzzy
-msgid "Name of tape drive device"
-msgstr "入力するデバイス"
-#, fuzzy
-msgid "Datum shift program. Return geographic coordinates based on a different datum that the one used to obtain the original coordinates. "
-msgstr "楕円体間のデータシフトを行います"
-#, fuzzy
-msgid "use block shift transformation (default)"
-msgstr "ブロック変換によるシフト(デフォルト)"
-#, fuzzy
-msgid "use bursa wolf 3d similarity transformation (not implemented)"
-msgstr "BURSA変換によるシフト(未実装)"
-#, fuzzy
-msgid "height above ellipsoid"
-msgstr "長円からの高さ"
-#, fuzzy
-msgid "input spheroid"
-msgstr "元の楕円体"
-#, fuzzy
-msgid "output spheroid"
-msgstr "シフト先の楕円体"
-#, fuzzy
-msgid "input datum"
-msgstr "元のデータ"
-#, fuzzy
-msgid "output datum"
-msgstr "シフト先のデータ"
-#, fuzzy
-msgid "x shift"
-msgstr "X方向のシフト"
-#, fuzzy
-msgid "y shift"
-msgstr "Y方向のシフト"
-#, fuzzy
-msgid "z shift"
-msgstr "Z方向のシフト"
-#, fuzzy
-msgid "Rx rotational parameter"
-msgstr "スムージングパラメータ"
-#, fuzzy
-msgid "Ry rotational parameter"
-#, fuzzy
-msgid "Rz rotational parameter"
-#, fuzzy
-msgid "Converts UTM coordinates falling within the current geographic region to geographic (latitude/longitude) coordinates. "
-msgstr "現在の領域をUTM座標から緯度/経度座標に変換します"
-#, fuzzy
-msgid "Flips elevation data extracted from systems that retrieve data by rows from south to north."
-msgstr "抽出した標高データを180度回転します180度回転します"
-#, fuzzy
-msgid "Number of bytes per cell (ie, per data value)"
-msgstr "1セルのバイト数"
-#, fuzzy
-msgid "Finds geographic region information for U.S. Census Bureau TIGER input data."
-msgstr "TMS(TIGER MAPPING SERVISE)に入力する地域情報データを検索します"
-#, fuzzy
-msgid "Filename for raw tiger data (type 1)"
-msgstr "入力するファイル"
-#, fuzzy
-msgid "UTM zone for this county"
-msgstr "UTMゾーン"
-#, fuzzy
-msgid "Provides a terse description of USGS Digital Elevation Model (DEM) data files stored on 1/2-inch magnetic tape."
-msgstr "1/2インチ磁気テープのデータからDEMを簡易表示します"
-#, fuzzy
-msgid "Tape input device"
-msgstr "入力するデバイス"
-#, fuzzy
-msgid "Blocksize of tape data"
-msgstr "データのブロックサイズ"
-#, fuzzy
-msgid "First file to examine"
-msgstr "開始ファイル"
-#, fuzzy
-msgid "Last file to examine"
-msgstr "終了ファイル"
-#, fuzzy
-msgid "y coordinate"
-msgstr "Y座標値"
-#, fuzzy
-msgid "max iterations"
-msgstr "最大反復回数"
-#, fuzzy
-msgid "Extracts digital terrain elevation data (DTED - levels 1 and 2) produced and supplied by the Defense Mapping Agency (DMA) on 1/2-inch magnetic tapes."
-msgstr "1/2インチ磁気テープのデータからDTEDを抽出します"
-#, fuzzy
-msgid "Name of header output file"
-msgstr "ヘッダーを出力するファイル"
-#, fuzzy
-msgid "North latitude of region to extract (format: %s)"
-msgstr "北端(入力形式: %s)"
-#, fuzzy
-msgid "South latitude of region to extract (format: %s)"
-msgstr "南端(入力形式: %s)"
-#, fuzzy
-msgid "East longitude of region to extract (format: %s)"
-msgstr "東端(入力形式: %s)"
-#, fuzzy
-msgid "West longitude of region to extract (format: %s)"
-msgstr "西端(入力形式: %s)"
-#, fuzzy
-msgid "Read the entire tape in all cases"
-msgstr "すべてのテープを読み込む"
-#, fuzzy
-msgid "Extracts USGS Digital Elevation Model (DEM) data from 1/2-inch magnetic tape."
-msgstr "1/2インチ磁気テープのデータからDEMデータを抽出します"
-#, fuzzy
-msgid "Input device or file"
-msgstr "入力するデバイスまたはファイル"
-#, fuzzy
-msgid "Output raster map (examine only if none specified)"
-msgstr "出力するファイル(未入力の場合はチェックのみ)"
-#, fuzzy
-msgid "First file to look at"
-msgstr "開始ファイル"
-#, fuzzy
-msgid "Last file to look at"
-msgstr "終了ファイル"
-#, fuzzy
-msgid "Selects a device (printer) for GRASS hardcopy output."
-#, fuzzy
-msgid "list all available painters"
-msgstr "ペインタの一覧表示"
-#, fuzzy
-msgid "print name of currently selected painter"
-#, fuzzy
-msgid "quietly select painter"
-msgstr "説明なし"
-#, fuzzy
-msgid "Color map output utility."
-msgstr "ハードコピー出力の設定を行います"
-#, fuzzy
-msgid "Align region to resolution [default = align to bounds]"
-msgstr "境界を分解能に合わせる"
-#, fuzzy
-msgid "Set region to match this sites map"
-msgstr "設定に用いるサイトマップ"
-#, fuzzy
-msgid "Value for the eastern edge "
-msgstr "南端"
-#, fuzzy
-msgid "Value for the western edge "
-msgstr "西端"
-#, fuzzy
-msgid "Grid resolution (both north-south and east-west)"
-msgstr "格子の分解能"
-#, fuzzy
-msgid "Overwrite <to> file(s)"
-msgstr "上書き"
-#, fuzzy
-msgid "Overwrite <new> file(s)"
-msgstr "上書き"
-#, fuzzy
-msgid "  vect   (binary vector maps)\n"
-msgstr "  vect   (ベクトルマップ)\n"
-#, fuzzy
-msgid "  icon   (paint icon files)\n"
-msgstr "  icon   (ペイントアイコンファイル)\n"
-#, fuzzy
-msgid "  labels (paint label files)\n"
-msgstr "  labels (ペイントラベルファイル)\n"
-#, fuzzy
-msgid "  sites  (site list files)\n"
-msgstr "  sites  (サイトマップ)\n"
-#, fuzzy
-msgid "  group  (imagery group files)\n"
-msgstr "  group  (画像グループ)\n"
-#, fuzzy
-msgid "  3dview (3D view parameters)\n"
-msgstr "  3dview (3次元表示パラメータファイル)\n"
-msgid "Do not export long colortable"
-msgstr "大きいサイズのカラーテーブルをエクスポートしない"
-msgid "unable to open new L map layer."
-msgstr "新規の Lマップレイヤーが開けません"
-msgid "unable to open new S map layer."
-msgstr "新規の S マップレイヤーが開けません"
-msgid ""
-"Sorry, if any of the following options are set:\n"
-"    basin, stream, half.basin, slope, or lS\n"
-"    you MUST provide a value for the basin threshold parameter."
-msgstr ""
-"次のオプションのいずれかがセットされています:\n"
-"    basin, stream, half.basin, slope, lS\n"
-"    盆地境界パラメータの値を必ずしていする必要があります  "
-msgid "SECTION 4: Length Slope determination."
-msgstr "セクション 4: 長さ・傾斜の決定"
-msgid "SECTION 3: Accumulating Surface Flow."
-msgstr "セクション 3: 表層流の累計"
-msgid "Default value: GRASS_GUI if defined otherwise tcltk"
-msgstr "既定値: 定義されていればGRASS_GUI そうでなければtcltk  "
-msgid "tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);wxpython;wxPython based next generation GUI;text;command line interface only"
-msgstr "tcltk;GUI に基づく Tcl/Tk - GIS管理者 (gis.m);oldtcltk;GUI に基づく Old Tcl/Tk - 表示管理者 (d.m);wxpython;次世代 GUIに基づくwxPython;テキスト;コマンドラインインターフェースのみ"
-msgid "Input raster map contains cells with NULL-value (no-data). The value %d was used to represent no-data values in the input map. You can specify nodata value by %s parameter."
-msgstr "入力したラスターマップはNULL値(データ無し)セルを含んでいます.この指定されたマップで値 %d はデータ無し値を示します.%s パラメーターでデータ無し値を指定できます"
-msgid "Output aspect filename"
-msgstr "方位を出力するファイル名"
-msgid "vector, query"
-msgstr "ベクトル,検索"
-msgid "Exporting %i points/lines..."
-msgstr "%i のポイント/ラインをエクスポート中、、、"
-msgid "Computing row %d of covariance matrix..."
-msgstr "共分散マトリックスの計算をしている行 %d..."
-msgid "Feature type. Combination of types is not supported by all formats."
-msgstr "地物の型. 複合型は全てのフォーマットでサポートされる訳ではありません"
-msgid "%d faces found, but not requested to be exported. Verify 'type' parameter."
-msgstr "%d の面がありますがエクスポートの指定がありません.'type' パラメーターを確認して下さい"
-msgid "Create a MASK for limiting raster operation"
-msgstr "制限ラスターオプションのMASKを作成する"
-msgid "Cannot make stat of %s configuration file"
-msgstr "%s 設定ファイルの統計を作成できません"
-msgid "Illegal configuration file"
-msgstr "不正な設定ファイル"
-msgid "CHILD[pid = %i]: unable to open %s mask ... continue without!!!"
-msgstr "CHILD[pid = %i]: %s マスクを開けません、、、何もしません!!!  "
-msgid "r.li.worker (pid %i) exited with abnormal status %i"
-msgstr "r.li.worker (pid %i) が異常状態 %i で終了"
-msgid "r.li.worker (pid %i) terminated"
-msgstr "r.li.worker (pid %i) は終了しました"
-msgid "Seed [%d] larger than maximum [%d]"
-msgstr "シード [%d] は最大値 [%d] より大きい"
-msgid "Seed [%d] smaller than minimum [%d]"
-msgstr "シード [%d] が最小値 [%d] より小さい"
-msgid "point;simple x,y[,z] list;standard;GRASS's vector ASCII format"
-msgstr "ポイント;単に x,y [,z] リスト;標準;GRASSのベクトルASCIIフォーマット"
-msgid "Number of column used as y coordinate (first column is 1) for points mode"
-msgstr "ポイントモードで y 座標に使う列の数(最初の列は1)"
-msgid "Number of column used as z coordinate (first column is 1) for points mode"
-msgstr "ポイントモードで z 座標に使う列の数(最初の列は1)"
-msgid "If 0, z coordinate is not used"
-msgstr "0の場合,z 座標は使用しない"
-msgid "Number of column used as category (first column is 1) for points mode"
-msgstr "ポイントモードでカテゴリーに使う列の数(最初の列は1)"
-msgid "If 0, unique category is assigned to each row and written to new column 'cat'"
-msgstr "0の場合,各行に1つだけのカテゴリーが指定されて新規に「cat」列が書き込まれます"
-msgid "Create a new empty vector map and exit. Nothing is read from input"
-msgstr "新規に空のベクトルマップを作成し、入力から読み込まない"
-msgid "Show the category label in the grid cell(s)"
-msgstr "グリッドセルでカテゴリーラベルを表示します"
-msgid "Unable to read symbol, unable todisplay points"
-msgstr "記号を読み込めません、ポイントを表示できません"
-msgid "Converting %s..."
-msgstr "%s を変換中... "
-msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)"
-msgstr "経路サンプリングメソッド (SIMWE) を用いた土砂流送、侵食/堆積のシミュレーション"
-msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)"
-msgstr "経路サンプリングメソッド(SIMWE)を用いた地表流の水文学シミュレーション"
-msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation layer."
-msgstr "指定された標高レイヤーをフィルタリングし,凹みのない標高マップと流れ方向マップを作成"
-msgid "Calculates cast shadow areas from sun position and DEM. Either A: exact sun position is specified, or B: date/time to calculate the sun position by r.sunmask itself."
-msgstr "太陽位置と DEM をもとに陰影領域を計算.r.sunmask 自身から,A: 正確な太陽位置の指定,または B: 太陽位置を計算するための日付/時刻を指定"
-msgid "A: altitude of the sun above horizon, degrees"
-msgstr "A: 水平からの太陽の高度、単位は度"
-msgid "A: azimuth of the sun from the north, degrees"
-msgstr "A: 北からの太陽の方位角 単位は度  "
-msgid "B: minutes (0..60)"
-msgstr "B: 分(0..60)  "
-msgid "B: seconds (0..60)"
-msgstr "B: 秒(0..60)  "
-msgid "B: timezone (east positive, offset from GMT, also use to adjust daylight savings)"
-msgstr "B: タイムゾーン(東が正, GMTオフセット、 サマータイム調整あり)  "
-msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
-msgstr "標高マップからトポグラフィックインデックス [ln(a/tan(beta))] マップ を作成します.  "
-msgid "New LOCATION name (not location path)"
-msgstr "新しいロケーション名 (ロケーションパスではありません)  "
-msgid "New GISDBASE (full path to the directory where the new location is)"
-msgstr "新しいGISDBASE (新しいロケーションのあるディレクトリーへのフルパス)  "
-msgid "Name for output file (do not add extension)"
-msgstr "出力ファイル名(拡張を追加しないように)"
-msgid "Width and height of output image"
-msgstr "出力画像の幅と高さ"
-msgid "Surface"
-msgstr "曲面"
-msgid "Volume"
-msgstr "ボリューム"
-#, fuzzy
-msgid "Import Mapgen or Matlab-ASCII vector maps into GRASS."
-msgstr "MapgenあるいはMatlabベクトルマップをGRASSにインポート"
-msgid "Vector map for which to edit attribute table"
-msgstr "属性テーブルを編集するためのベクトルマップ"
-msgid "Layer where to add column"
-msgstr "列を追加するレイヤー"
-msgid "Swapping header data"
-msgstr "ヘッダデータの交換"
-msgid "Exporting raster as double values (bytes=%d)"
-msgstr "倍精度値としてラスターをエクスポート(バイト=%d)"
-msgid "Reading map"
-msgstr "マップの読み込み"
-msgid "Signed data (high bit means negative value)"
-msgstr "負の値を含む(最上位ビットが符号ビット) "
-msgid "Number of bytes per cell (1, 2, 4)"
-msgstr "1セルのバイト数(1, 2, 4) "
-msgid "Parsing bytes per cell"
-msgstr "1セルのバイト数 "
-msgid "Byte Swapping Turned On."
-msgstr "バイトスワップが有効です  "
-msgid ""
-"Missing parameters ...\n"
-"Must provide at least[north= south= east= west=] OR [r=\tc=]"
-msgstr ""
-"パラメータが不足しています ...\n"
-"[north= south= east= west=]の内の一つ以上、または[r=\tc=] を指定してください "
-msgid "You have to provide all limits of geographic region (n,s,e,w)"
-msgstr "地理領域の全ての制限設定をする必要があります(n, s, e, w)"
-msgid "Illegal number of rows <%s>"
-msgstr "無効な行の数 <%s> "
-msgid "Illegal number of columns <%s>"
-msgstr "無効な列の数 <%s> "
-msgid "Using N=%f S=%f E=%f W=%f"
-msgstr "使用する値 N=%f S=%f E=%f W=%f  "
-msgid "Using rows=%d cols=%d\n"
-msgstr "使用する値 rows=%d cols=%d\n"
-msgid "File Size %d ... Total Bytes %d"
-msgstr "ファイルサイズ %d ... Total Bytes %d  "
-msgid "Try bytes=%d or adjusting input parameters"
-msgstr "試行するbyte値=%d または、補正値の指定"
-msgid "Conversion failed at row %d"
-msgstr "行の変換に失敗 %d  "
-msgid "Remove lines and areas smaller than threshold"
-msgstr "閾値より小さいラインとエリアを除去"
-msgid "%d boundaries were deleted, input areas are not preserved"
-msgstr "%d 境界は削除されました, 入力領域は保存されていません"
-msgid "Unable to calculate centroid for area %d"
-msgstr "エリア %d のセントロイドを計算できません"
-msgid "New centroids were calculated, attribute attachment may be changed"
-msgstr "新しいセントロイドが計算されました, 属性添付が変更されている可能性があります"
-msgid "Areas may have disappeared and/or area attribute attachment may have changed"
-msgstr "エリアが消失しそして/もしくはエリア属性添付が変更している可能性があります"
-msgid "Try v.clean tool=prune thresh=%f"
-msgstr "v.clean tool=prune thresh=%f を試みます "
-msgid ""
-"\n"
-"ERROR: Required parameter <%s> not set:\n"
-"    (%s).\n"
-msgstr ""
-"\n"
-"エラー: 要求されたパラメーター <%s> は設定されません:\n"
-"    (%s).\n"
-msgid "into  <%s@%s> (location <%s>) ... %s"
-msgstr "へ  <%s@%s> (ロケーション <%s>) ... %s"
-msgid "data compression required an additional"
-msgstr "追加を要求されたデータ圧縮"
-msgid "Rectified input raster map <%s> will be saved as <%s>"
-msgstr "修正されたラスターマップ <%s>は <%s>として保存されます"
-#, fuzzy
-msgid "Target information for group <%s> missing.\n"
-msgstr "グループのターゲット情報 <%s>が見つかりません"
-#, fuzzy
-msgid "Target location <%s> not found\n"
-msgstr "ターゲットロケーション <%s> は見つかりません"
-#, fuzzy
-msgid " %d rows, %d cols (%ld cells) completed in "
-msgstr "%d 行, %d 列 (%ld セル) は完成しました "
-#, fuzzy
-msgid " %.1f cells per minute\n"
-msgstr "1分ごとの%.1f セル"
-msgid "Location of input raster map"
-msgstr "入力ラスターマップのロケーション "
-msgid "Mapset of input raster map"
-msgstr "入力するラスターマップのマップセット "
-msgid "Checking location <%s>, mapset <%s>..."
-msgstr "ロケーション <%s>、マップセット <%s> をチェックしています..."
-msgid " %d.%02d.%02d, daynum %d, time: %02i:%02i:%02i (decimal time: %f)\n"
-msgstr " %d.%02d.%02d, 日付 %d, 時間: %02i:%02i:%02i (小数以下の時間: %f)\n"
-msgid " long: %f, lat: %f, timezone: %f\n"
-msgstr "経度: %f, 緯度: %f, タイムゾーン: %f\n"
-msgid ""
-" Solar position: sun azimuth: %f,\n"
-"   sun angle above horz.(refraction corrected): %f\n"
-msgstr ""
-" 太陽位置: 太陽方位: %f,\n"
-"   地平線からの太陽高度.(屈折補正済み): %f\n"
-msgid " Sunrise time (without refraction): %02d:%02d:%02d\n"
-msgstr " 日の出時刻 (大気差を含まない): %02d:%02d:%02d\n"
-msgid " Sunset time  (without refraction): %02d:%02d:%02d\n"
-msgstr " 日の入時刻 (大気差を含まない):: %02d:%02d:%02d\n"
-msgid "No map calculation requested. Finished.\n"
-msgstr "マップ計算が要求されませんでした。終了します.\n"
-msgid "Can't open range file for %s"
-msgstr " %s に対する範囲fileが開けません"
-msgid "Can't read row in input elevation map"
-msgstr "入力した標高マップから行を読み取れません"
-msgid "<%s> created"
-msgstr "<%s> 作成されました"
-msgid "You have to use a different location for input than the current"
-msgstr "入力には現在とは違ったロケーションを使用してください"
-msgid "Raster map to be recoded"
-msgstr "記録するラスターマップ"
-msgid "Unable to open rules file <%s>"
-msgstr "ルールファイル <%s> を開けません"
-msgid "Displays and overlays raster map layers in the active display frame on the graphics monitor."
-msgstr "グラフィックモニターでアクティブな表示フレームに、ラスターマップレイヤーを重ねて表示します"
-msgid "Raster map to be displayed"
-msgstr "表示するラスターマップ"
-msgid "Displays vector data in the active frame on the graphics monitor."
-msgstr "グラフィックモニター上で動作中のフレームにベクトルデータを表示します"
-msgid "Area size [%.1e], area not imported"
-msgstr "領域サイズ [%.1e], 領域はインポートされていません"
-msgid "Island size [%.1e], island not imported"
-msgstr "島のサイズ [%.1e], 島はインポートされていません"
-msgid "vector, projection"
-msgstr "ベクトル,投影"
-msgid "Allows projection conversion of vector maps."
-msgstr "ベクトルマップの矢の投影変換"
-msgid "Duplicate area centroids"
-msgstr "重複するエリアセントロイド"
-msgid "Vector output map"
-msgstr "ベクトル出力マップ"
-msgid "Error while writing to temp file"
-msgstr "一時ファイルに書き込み中のエラー"
-msgid "Error writing row %d"
-msgstr "行の書き込みエラー %d"
-msgid "Poorly placed psuedo control points. "
-msgstr "不完全に設置された疑似コントロールポイント"
-msgid "Cannot generate the transformation equation."
-msgstr "変換方程式が作成できません"
-msgid "No active psuedo control points"
-msgstr "アクティブな疑似コントロールマップはありません"
-msgid "Unable to write temp file: %s"
-msgstr "一時ファイルに書き込みできません: %s"
-msgid "Unable to open map %s"
-msgstr "マップが開けません %s"
-msgid "Unable to write row %d"
-msgstr "行に書き込みできません %d"
-msgid "Unable to write raster map. You might want to check available disk space and write permissions."
-msgstr "ラスターマップを書き込めません。利用できるディスクを確認し、許可を書き込んでください。"
-msgid "Please select the file(s) you wish to rectify by naming an output file"
-msgstr "出力ファイルに名づけて修正したいファイルを選択してください"
-msgid "%s@%s: projection doesn't match current settings"
-msgstr "%s@%s: 投影は現在の設定と一致していません"
-msgid "%s@%s: zone doesn't match current settings"
-msgstr "%s@%s: ゾーンは現在の設定と一致していません"
-msgid "New MAPSET name"
-msgstr "新しいマップセット名"
-msgid "Failed in attempt to open %s"
-msgstr "%s を開けませんでした"
-msgid "Generates raster map layers of slope, aspect, curvatures and partial derivatives from a raster map layer of true elevation values. Aspect is calculated counterclockwise from east."
-msgstr "真の標高値ラスターマップレイヤーから、斜面、方位、曲面、偏導関数のラスターマップを作成します. 方位は東から反時計回りに計算します"
-msgid "Output slope filename"
-msgstr "傾斜を出力するファイル名"
-msgid "Output profile curvature filename"
-msgstr "断面曲率を出力するファイル名"
-msgid "Output tangential curvature filename"
-msgstr "正接曲率を出力するファイル名"
-msgid "Output first order partial derivative dx (E-W slope) filename"
-msgstr "一次の偏導関数 dx (E-W 傾斜) を出力するファイル名"
-msgid "Output first order partial derivative dy (N-S slope) filename"
-msgstr "一次の偏導関数 dy (N-S 傾斜) を出力するファイル名"
-msgid "Output second order partial derivative dxx filename"
-msgstr "二次の偏導関数 dxx を出力するファイル名"
-msgid "Output second order partial derivative dyy filename"
-msgstr "二次の偏導関数 dyy を出力するファイル名"
-msgid "Output second order partial derivative dxy filename"
-msgstr "二次の偏導関数 dxy を出力するファイル名"
-msgid "wrong type: %s"
-msgstr "間違ったタイプ: %s"
-msgid "Creating support files..."
-msgstr "サポートファイルを作成中..."
-msgid "Elevation products for mapset [%s] in [%s]"
-msgstr "マップセット [%s] ([%s] 内)の標高のプロダクト"
-msgid "ASPECT [%s] COMPLETE"
-msgstr "方位 [%s] 完了"
-msgid "SLOPE [%s] COMPLETE"
-msgstr "傾斜 [%s] 完了"
-msgid "PROFILE CURVE [%s] COMPLETE"
-msgstr "プロファイル曲線 [%s] 完了"
-msgid "TANGENTIAL CURVE [%s] COMPLETE"
-msgstr "正接曲線 [%s] 完了"
-msgid "E-W SLOPE [%s] COMPLETE"
-msgstr "E-W 傾斜 [%s] 完了"
-msgid "N-S SLOPE [%s] COMPLETE"
-msgstr "N-S 傾斜 [%s] 完了"
-msgid "DXX [%s] COMPLETE"
-msgstr "DXX [%s] 完了"
-msgid "DYY [%s] COMPLETE"
-msgstr "DYY [%s] 完了"
-msgid "DXY [%s] COMPLETE"
-msgstr "DXY [%s] 完了"
-msgid "Generates a raster map layer showing watershed subbasins."
-msgstr "分水域を示すラスターマップを作成します "
-msgid "Coded stream network file name"
-msgstr "河川ファイル"
-msgid "Thinned ridge network file name"
-msgstr "分水稜ファイル "
-msgid "Name for the resultant watershed partition file"
-msgstr "出力する分水界ファイル "
-msgid "Output raster map having shadows"
-msgstr "出力する影のラスターマップ名"
-msgid "By_position"
-msgstr "位置を使う  "
-msgid "B: year (1950..2050)"
-msgstr "B: å¹´(1950..2050)  "
-msgid "By_time"
-msgstr "By_time  "
-msgid "B: month (0..12)"
-msgstr "B: 月(0..12)  "
-msgid "B: day (0..31)"
-msgstr "B: æ—¥(0..31)  "
-msgid "B: hour (0..24)"
-msgstr "B: 時(0..24)  "
-msgid "East coordinate (point of interest, default: map center)"
-msgstr "東西座標(POI、既定値はマップ中心)"
-msgid "North coordinate (point of interest, default: map center)"
-msgstr "南北座標(POI、既定値はマップ中心)"
-msgid "Zero is a real elevation"
-msgstr "ゼロは実際の標高"
-msgid "raster, terrain analysis"
-msgstr "ラスター、地形分析"
-msgid "                No topology present"
-msgstr "地形がありません"
-msgid "Uses a GRASS vector points map to produce a convex hull vector map."
-msgstr "GRASSのベクトルポイントマップを使用して凸包ベクトルマップを作成"
-msgid "Name of input vector points map"
-msgstr "指定するベクトルポイントマップ名"
-msgid "Name of output vector area map"
-msgstr "出力するベクトルエリアマップ名"
-msgid "Cannot open vector map <%s>"
-msgstr "ベクトルマップ <%s> を開けません"
-msgid "Experimental NVIZ CLI prototype."
-msgstr "実験段階の NVIZ CLI 試作品"
-msgid "It was impossible to create <Auxiliar_outlier_table>."
-msgstr "<Auxiliar_outlier_table>は作成できませんでひた.  "
-msgid "It was not possible to drop <%s> table. Nothing will be done. Try to drop it manually."
-msgstr "<%s> 表をドロップできませんでした. 何も変更されません. 手動でドロップしてください.  "
-msgid "Cross Validation was success!"
-msgstr "交差検証は成功しました!  "
-msgid "Interpolation: The region resolution is too high: %d cells. Consider to change it."
-msgstr "補間: この領域の解像度は高すぎます: %d セル. 変更してください."
-msgid "Creating auxiliar table for archiving overlapping zones"
-msgstr "重複する地域のためauxiliar表を作成しています"
-msgid "<Auxiliar_edge_table> created in database."
-msgstr "<Auxiliar_edge_table> はデータベースに作成されました."
-msgid "Unable to open table <%s_edge_Interpolation>"
-msgstr "表 <%s_edge_Interpolation> を開けません"
-msgid "M.Q. solution"
-msgstr "M.Q.ソリューション"
-msgid "3-d data in dxf file. Polyline_flag: %d"
-msgstr " dxf fileの3-d データ. Polyline_flag: %d  "
-msgid "Selects data from table."
-msgstr "テーブルからデータを選択"
-msgid "Unable to open MASK"
-msgstr "マスクを開けません"
-msgid "Name of the longitude input raster map [decimal degrees]"
-msgstr "経度入力ラスターマップ名(小数点付の度) "
-msgid "Starting map [%s]"
-msgstr "マップを開始 [%s]"
-msgid "Percent done:"
-msgstr "完了率(パーセント)"
-msgid "Starting filter #%d, distance: %.*lf, exponent: %.*lf, flat: %.*lf"
-msgstr "フィルタリングを開始 #%d, 距離: %.*lf,指数: %.*lf,均一: %.*lf  "
-msgid ""
-"%s: saving [%s] raster map layer.\n"
-"Percent complete:"
-msgstr ""
-"%s: 保存しています・・・[%s] ラスタマップレイヤー.\n"
-"パーセント終了:  "
-msgid "Number of column used as x coordinate (first column is 1) for points mode"
-msgstr "ポイントモードで x 座標に使う列の数(最初の列は1)"
-msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares)"
-msgstr "単位 "
-msgid "Allocation memory for bilinear interpolation"
-msgstr "双線形補間のための割り当てメモリー"
-msgid "Allocation memory for bicubic interpolation"
-msgstr "バイキュービック補間のための割り当てメモリー  "
-msgid "No raster nor vector output"
-msgstr "ラスターもベクトル出力もありません"
-msgid "No data within this subzone. Consider changing the spline step."
-msgstr "このサブゾーン内にデータはありません. スプラインステップを変更してみてください.  "
-msgid "Mean's calculation"
-msgstr "平均値の計算"
-msgid "Bad format in initial exposusre station file for group [%s]"
-msgstr "グループ [%s]の初期暴露駅ファイルの不正なフォーマット"
-msgid "Name of elevation raster map"
-msgstr "標高ラスターマップ名"
-msgid "Input raster map contains cells with NULL-value (no-data). The value %g was used to represent no-data values in the input map. You can specify nodata value by %s parameter."
-msgstr "入力したラスターマップはNULL値(データ無し)セルを含んでいます.この指定されたマップで値 %g はデータ無し値を示します.%s パラメーターでデータ無し値を指定できます"
-msgid "douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker Algorithm with reduction parameter;lang;Lang Simplification Algorithm;reduction;Vertex Reduction Algorithm eliminates points close to each other;reumann;Reumann-Witkam Algorithm;remove_small;Removes lines shorter than threshold and areas of area less than threshold;boyle;Boyle's Forward-Looking Algorithm;sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;Interpolation by Cubic Hermite Splines;snakes;Snakes method for line smoothing;network;Network generalization;displacement;Displacement of lines close to each other;"
-msgstr "douglas;Douglas-Peucker アルゴリズム;douglas_reduction;縮小パラメーターをもつDouglas-Peucker アルゴリズム;lang;Lang Simplification アルゴリズム;縮小;Vertex Reduction アルゴリズムは互いに近いポイントを削除します;reumann;Reumann-Witkam アルゴリズム;remove_small;閾値と閾値より小さいエリアより短いラインを除去;boyle;Boyle's Forward-Looking アルゴリズム;sliding_averaging;McMaster's Sliding Averaging アルゴリズム;distance_weighting;McMaster's Distance-Weighting アルゴリズム;chaiken;Chaiken's アルゴリズム;hermite;Cubic Hermite Splinesによる補間;snakes;ラインスムージングのスネークメソッド;ネットワーク;ネットワーク汎化;置換;互いに近いラインの置換;"
-msgid "Number of vertices was reduced from %d to %d [%d%%]"
-msgstr "頂点の数は %d から %d [%d%%] に減少されました"
-msgid ""
-"Input raster map <%s> does not exist in group <%s>.\n"
-" Try:\n"
-msgstr ""
-"入力するラスターマップ <%s> はグループ <%s>にありません\n"
-" 再試行:\n"
-msgid "Band to select"
-msgstr "選択するバンド"
-#~ msgid "Input grid3 filename"
-#~ msgstr "3Dグリッドファイル名入力"
-#~ msgid "Grid3 <%s> not found %s"
-#~ msgstr "Grid3 <%s> が見つかりません %s"
-#~ msgid "Failed to guess site file format"
-#~ msgstr "サイトファイルフォーマットの予測に失敗 "
-#~ msgid "Print raster map resolution (NS-res, EW-res) only"
-#~ msgstr "ラスターマップの解像度(東西方向、南北方向)のみ出力します"
-#~ msgid "Print raster map type only"
-#~ msgstr "ラスターマップ型のみ出力します"
-#~ msgid "Print map region only"
-#~ msgstr "マップ領域のみ出力します"
-#~ msgid "Print raster map data units only"
-#~ msgstr "ラスターマップのデータユニットのみ出力します"
-#~ msgid "Print raster map vertical datum only"
-#~ msgstr "ラスターマップの鉛直測地系のみ出力します"
-#~ msgid "Print map title only"
-#~ msgstr "マップタイトルのみ出力します"
-#~ msgid "Print raster map timestamp (day.month.year hour:minute:seconds) only"
-#~ msgstr "ラスターマップのタイムスタンプ(日.月.年 時:分:秒)のみを出力します"
-#~ msgid "Name for value output map"
-#~ msgstr "値出力マップ名"
-#~ msgid "Invalid timestamp"
-#~ msgstr "無効なタイムスタンプ"
-#~ msgid "Reading sites..."
-#~ msgstr "読込中 ... "
-#~ msgid "Writing sites to output..."
-#~ msgstr "出力中..."
-#~ msgid "Reading coordinates from file."
-#~ msgstr "座標をファイルから読み込み中"
-#~ msgid "ASCII file holding transform coordinates"
-#~ msgstr "変換座標を保持するASCIIファイル"
-#~ msgid "If not given, transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot) are used instead"
-#~ msgstr "指定しない場合,変換パラメーター (xshift, yshift, zshift, xscale, yscale, zscale, zrot) が使用されます"
-#~ msgid "Unable to open file with coordinates <%s>"
-#~ msgstr "ファイルが座標 <%s> と開くことができません"
-#~ msgid "Error reading coordinates file"
-#~ msgstr "エラー:座標ファイルの読み込み中"
-#~ msgid "Number of points that have been entered [%d]"
-#~ msgstr "入力されたポイント数: [%d]"
-#~ msgid "Error creating transformation"
-#~ msgstr "変換を作成中にエラー"
-#~ msgid "The points weren't spread out enough."
-#~ msgstr "ポイントの広がりが不十分"
-#~ msgid "You need to enter at least %d points."
-#~ msgstr "少なくとも %d のポイントを入力する必要があります"
-#~ msgid "create;Create new (empty) vector map;add;Add new features to existing vector map;delete;Delete selected features from vector map;move;Move selected features in vector map;vertexmove;Move vertex of selected vector lines;vertexdel;Remove vertex from selected vector lines;vertexadd;Add new vertex to selected vector lines;merge;Merge selected vector lines;break;Break/split vector lines;select;Select lines and print their ID's;catadd;Set new categories to selected vector features for defined layer;catdel;Delete categories from selected vector features for defined layer;copy;Copy selected features;snap;Snap vector features in given threshold;flip;Flip direction of selected vector lines;connect;Connect two lines;zbulk;Z bulk-labeling (automated assignment of z coordinate to vector lines);chtype;Change feature type (point<->centroid, line<->boundary)"
-#~ msgstr "create;新規に(中身のない)ベクトルマップを作成;add;今あるベクトルマップへ新規にフィーチャーを加える;delete;ベクトルマップから選択したフィーチャーを削除;move;ベクトルマップ中の選択したフィーチャーを移動;vertexmove;選択したベクトルラインの交点を移動;vertexdel;選択したベクトルラインから交点を削除;vertexadd;選択したベクトルラインへ新規に交点を追加;merge;選択したベクトルラインをマージ;break;ベクトルラインを切断/分割;select;ラインを選択しそのIDを出力;catadd;指定したレイヤーの選択したベクトルフィーチャーに新規カテゴリーを設定;catdel;指定したレイヤーの選択したベクトルフィーチャーのカテゴリーを削除;copy;選択したフィーチャーを削除;snap;指定した閾値内のベク
 トルフィーチャーを接合;flip;選択したベクトルラインの方向を分割;connect;2本のラインを繋げる;zbulk;Z バルクラベリング (ベクトルラインへ z 座標を自動設定);chtype;フィーチャータイプを変更 (ポイント <-> セントロイド,ライン <-> 境界)  "
-#~ msgid "Column name (will be updated by raster values)"
-#~ msgstr "列名(ラスター値により変更されます)"
-#~ msgid "Cannot scan date: "
-#~ msgstr "日付をスキャンできません:"
-#~ msgid "Cannot scan time: "
-#~ msgstr "時間をスキャンできません:"
-#~ msgid "Cannot allocate cursor."
-#~ msgstr "カーソル位置が決まりません"
-#~ msgid "Cannot ad new token."
-#~ msgstr "トークンを表示できません"
-#~ msgid "Cannot connect to MySQL: "
-#~ msgstr "MySQLに接続できません:   "
-#~ msgid "DBMI-MySQL driver error:\n"
-#~ msgstr "DBMI-MySQL ドライバーエラー:\n"
-#~ msgid "Cannot select data: \n"
-#~ msgstr "データを選択できません: \n"
-#~ msgid "Unable allocate memory for row buffer"
-#~ msgstr "行バッファーのメモリを確保できません"
-#~ msgid "Computing means for band %d..."
-#~ msgstr "バンドの演算手段 %d..."
-#~ msgid "Computing row %d (of %d) of covariance matrix..."
-#~ msgstr "共分散マトリックスの計算をしている行 %d (全体 %d) ..."
-#~ msgid "Unable to allocate memory for row buffer"
-#~ msgid "Unable to allocate memory for raster row"
-#~ msgstr "ラスター行のメモリを確保できません"
-#~ msgid "Transforming <%s>..."
-#~ msgstr "変換中 <%s>..."
-#~ msgid "'layer' must be > 0 for 'where'."
-#~ msgstr "'場所' には 'レイヤー' は > 0 でなければなりません."
-#~ msgid "'layer' must be > 0 for 'cats'."
-#~ msgstr "'cats' には 'レイヤー' は > 0 でなければなりません."
-#~ msgid "Surface area estimation for rasters."
-#~ msgstr "ラスターの曲面エリアを推定します"
-#~ msgid "Raster file for surface"
-#~ msgstr "曲面に用いるラスターファイル "
-#~ msgid "Writing buffers..."
-#~ msgstr "フィーチャーを書き込んでいます"
-#~ msgid "ASCII file to be converted to binary vector map"
-#~ msgstr "バイナリーベクトルマップに変換される ASCII ファイル"
-#~ msgid "Join column in other table"
-#~ msgstr "他のテーブルに列を結合"
-#~ msgid "Name of arc forward/both direction(s) cost column"
-#~ msgstr "Arc 前方/両方向の コスト列  "
-#~ msgid "Name of arc backward direction cost column"
-#~ msgstr "Arc 後方のコスト列"
-#~ msgid "Layer number or name with route paths or -1"
-#~ msgstr "レイヤー数 (書き込み)"
-#~ msgid "Layer %d - no table"
-#~ msgstr "レイヤー %d - 表がありません"
-#~ msgid "Layer %d - unable to copy table"
-#~ msgstr "レイヤー %d - 表をコピーできません"
-#~ msgid "Name of arc forward/both direction(s) capacity column"
-#~ msgid "Name of arc backward direction capacity column"
-#~ msgid "Source layer number or name"
-#~ msgstr "検索レイヤー数 (から読み込み)"
-#~ msgid "Sink layer number or name"
-#~ msgstr "レイヤー数 (from)"
-#~ msgid "Name of Arc cost column"
-#~ msgstr "列名"
-#~ msgid "Enter -1 to keep original categories or the desired NEW category value"
-#~ msgstr "最初のカテゴリーまたは指定する新しいカテゴリー値の保存には -1 を入力してください  "
-#~ msgid "From layer number or name"
-#~ msgid "To layer number or name"
-#~ msgid "Name of node capacity column"
-#~ msgstr "列名"
-#~ msgid "Set1 layer number or name"
-#~ msgid "Set2 layer number or name"
-#~ msgid "Either mapset= or -l must be used"
-#~ msgstr "マップセット= または -l を使用してください"
-#~ msgid "Line width column (%s) is not numeric."
-#~ msgstr "数ではなくライン幅列 (%s) .  "
-#~ msgid "Error in color definition column '%s', feature id %d with cat %d: colorstring '%s'"
-#~ msgstr "カラー定義列におけるエラー '%s', cat %d をもつフィーチャー id %d : カラーストリング '%s'"
-#~ msgid "Error in color definition column '%s', feature id %d with cat %d"
-#~ msgstr "カラー定義列 '%s' におけるエラー, cat %d を含むフィーチャー id %d "
-#~ msgid "Error in symbol size column (%s), element %d with cat %d: symbol size [%f]"
-#~ msgstr "シンボルサイズのエラーです。列(%s)、要素 %d、cat %d を含む: シンボルサイズ [%f]"
-#~ msgid "Error in color definition column '%s': %d features affected"
-#~ msgstr "カラー定義列 '%s におけるエラー': %d フィーチャーは影響されています"
-#~ msgid "Colorize polygons according to z height"
-#~ msgstr "z高度に準じてポリゴンをカラー化してください  "
-#~ msgid "Can't read vector map"
-#~ msgstr "ベクトルマップを読み込めません"
-#~ msgid "Color definition column not specified."
-#~ msgstr "色定義列は指定されていません.  "
-#~ msgid "Error in color definition column (%s), area %d with cat %d: colorstring [%s]"
-#~ msgstr "カラー定義列におけるエラー (%s), cat %d を含むエリア %d : カラーストリング [%s]"
-#~ msgid "pg driver: column '%s', type %d  is not supported"
-#~ msgstr "pg ドライバー: 列 '%s', %d 型はサポートされません"
-#~ msgid "Type of color table"
-#~ msgstr "カラーテーブルのタイプ"
-#~ msgid "Save placeholder raster map for use with d.legend"
-#~ msgstr "d.legendと使用するプレイスホルダーラスターマップを保存"
-#~ msgid "Name and type of the new column(s) (types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
-#~ msgstr "新しい列名とタイプ(タイプはデータベースの後部に依存しますが、VARCHAR(), INT, DOUBLE PRECISION and DATEのすべてをサポートします)"
-#~ msgid "Name for input source not specified"
-#~ msgstr "入力ソース名は指定されていません"
-#~ msgid "Name for output raster map not specified"
-#~ msgstr "出力ラスターマップ名が指定されていません"
-#~ msgid "\"color\", \"rules\", and \"raster\" options are mutually exclusive"
-#~ msgstr "\"color\"、\"rules\"、\"raster\" のオプションは同時には使用できません"
-#~ msgid "-g and -a flags are mutually exclusive"
-#~ msgstr "-g と -a フラッグは同時には使えません"
-#~ msgid "Negative or no data pixel found. This module is not yet able to process no data holes in a map, please fill with r.fillnulls or other algorithms"
-#~ msgstr "負値またはデータ無しのピクセルが見つかりました.データ無しのホールがマップ内にあり,このモジュールはまだ処理できません,r.fillnulls または他のアルゴリズムを使用してデータを詰めてください"
-#~ msgid "Too many iterations to required to find %s - giving up"
-#~ msgstr "検索の繰り返し要求が多すぎます %s - できませんでした"
-#~ msgid "Angular Second Moment"
-#~ msgstr "角度別二次モーメント  "
-#~ msgid "Features"
-#~ msgstr "フィーチャー"
-#~ msgid "Contrast"
-#~ msgstr "コントラスト"
-#~ msgid "Correlation"
-#~ msgstr "相関 "
-#~ msgid "Variance"
-#~ msgstr "分散 "
-#~ msgid "Inverse Diff Moment"
-#~ msgstr "逆差分モーメント"
-#~ msgid "Sum Average"
-#~ msgstr "和平均"
-#~ msgid "Sum Variance"
-#~ msgstr "和変動"
-#~ msgid "Sum Entropy"
-#~ msgstr "総エントロピー  "
-#~ msgid "Entropy"
-#~ msgstr "エントロピー "
-#~ msgid "Difference Variance"
-#~ msgstr "分散差"
-#~ msgid "Difference Entropy"
-#~ msgstr "エントロピー差"
-#~ msgid "Measure of Correlation-1"
-#~ msgstr "相関関係-1 の測定"
-#~ msgid "Measure of Correlation-2"
-#~ msgstr "相関関係-2 の測定"
-#~ msgid "Max Correlation Coeff"
-#~ msgstr "最大相関係数"
-#~ msgid "Raster file to be imported"
-#~ msgstr "インポートするラスターファイル"
-#~ msgid "Adding rule: %lf - %lf"
-#~ msgstr "ルールの追加: %lf - %lf "
-#~ msgid "Converts co-ordinate system descriptions (i.e. projection information) between various formats (including GRASS format)."
-#~ msgstr "様々なフォーマット間 (GRASS フォーマットを含む) の座標システム記述 (例 投影情報) を変換します.  "
-#~ msgid "Create/Edit"
-#~ msgstr "作成/編集"
-#~ msgid "Create new projection files (modifies current location unless 'location' option specified)"
-#~ msgstr "新しい投影ファイルを作成できません ('ロケーション' オプションが指定されていない限り現ロケーションを修正)  "
-#~ msgid "Location %s created!"
-#~ msgstr "ロケーション %s は作成されました!  "
-#~ msgid "Force remove"
-#~ msgstr "強制削除"
-#~ msgid "Color to erase with, either a standard GRASS color or R:G:B triplet (separated by colons)"
-#~ msgstr "標準GRASSカラーまたはR:G:B triplet (コロンで区別) のいずれかを用いて消去するカラー"
-#~ msgid "Min-area & snap"
-#~ msgstr "最小区域とスナップ"
-#~ msgid "Layer: %s"
-#~ msgstr "レイヤー: %s"
-#~ msgid "Break polygons:"
-#~ msgstr "ポリゴンを崩します:"
-#~ msgid "Remove duplicates:"
-#~ msgstr "複写を除去します:"
-#~ msgid "Break boundaries:"
-#~ msgstr "境界をくずします:"
-#~ msgid "Clean boundaries at nodes:"
-#~ msgstr "ノードにある境界を除去します:"
-#~ msgid "Remove bridges:"
-#~ msgstr "ブリッジを除去します:"
-#~ msgid "Write centroids:"
-#~ msgstr "セントロイドを書き込み中、、、"
-#~ msgid "Cannot calculate centroid"
-#~ msgstr "セントロイドを計算できません"
-#~ msgid "Unknown icon marker"
-#~ msgstr "不明なアイコンマーカー"
-#~ msgid "Group input"
-#~ msgstr "グループ入力"
-#~ msgid "Write output to PNG image"
-#~ msgstr "PNG画像に出力を書き込む"
-#~ msgid "Verbose mode"
-#~ msgstr "説明付き表示"
-#~ msgid "E00 file"
-#~ msgstr "E00ファイル"
-#~ msgid "Input type point, line or area"
-#~ msgstr "ポイント、ライン、エリアの入力タイプ"
-#~ msgid "Name for output vector map"
-#~ msgstr "出力するベクトルマップ名"
-#~ msgid "Name of raster plane to be created"
-#~ msgstr "作成したラスター平面マップ名"
-#~ msgid "Dip of plane. Value must be between -90 and 90 degrees"
-#~ msgstr "平面のくぼみ。 値は-90から90度の間でなくてはなりません。  "
-#~ msgid "Azimuth of the plane. Value must be between 0 and 360 degrees"
-#~ msgstr "平面の方位(アジマス)。 値は0から360度の間でなくてはなりません。"
-#~ msgid "Verbosity level"
-#~ msgstr "詳細レベル"
-#~ msgid "Name for output raster map prefix (e.g. 'brov')"
-#~ msgstr "出力するラスターマッププリフィックス名 (例 'brov')"
-#~ msgid "raster input map"
-#~ msgstr "ラスター入力マップ"
-#~ msgid "Vector map to modify"
-#~ msgstr "修正するベクトルマップ"
-#~ msgid "Layer in the vector to be modified"
-#~ msgstr "修正されたベクトル内のレイヤー"
-#~ msgid "Vector map to be queried"
-#~ msgstr "問い合わせされたベクトルマップ"
-#~ msgid "Layer of the query vector containing data"
-#~ msgstr "データを含む検索ベクトルレイヤー"
-#~ msgid "Column to be queried"
-#~ msgstr "検索された列"
-#~ msgid "Name of input vector map"
-#~ msgstr "入力するベクトルマップ名"
-#~ msgid "Vector map to edit the attribute table for"
-#~ msgstr "属性テーブルを編集するベクトルマップ"
-#~ msgid "Layer to which the table to be changed is connected"
-#~ msgstr "変更されたテーブルのレイヤーは接続されました"
-#~ msgid "Column to update"
-#~ msgstr "アップデートする列"
-#~ msgid "Column to query"
-#~ msgstr "検索する列"
-#~ msgid "WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/col2>1)"
-#~ msgstr "where' 句なしのアップデートのWHEREコンディション (例 cat=1 or col1/col2>1)  "
-#~ msgid "Input ASTER image to be georeferenced & rectified"
-#~ msgstr "地理参照・修正するASTER画像"
-#~ msgid "Vector map for which to rename attribute column"
-#~ msgstr "属性列名を変更するベクトルマップ"
-#~ msgid "Layer where to rename column"
-#~ msgstr "列名を変更するレイヤー"
-#~ msgid "GRASS table name"
-#~ msgstr "GRASSテーブル名"
-#~ msgid "vector, import"
-#~ msgstr "ベクトル、インポート"
-#~ msgid "Field separator"
-#~ msgstr "フィールドセパレーター"
-#~ msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
-#~ msgstr "単独のベクトルマップは多数のデータベーステーブルに接続されていなければなりません。この数値はどのテーブルを使用しているか決定します"
-#~ msgid "WHERE conditions of SQL statement without 'where' keyword"
-#~ msgstr "where' 句なしのSQL文のWHEREコンディション"
-#~ msgid "Example: income < 1000 and inhab >= 10000"
-#~ msgstr "例: 収入 < 1000 かつ 住人 >= 10000"
-#~ msgid "display, vector, thematic, legend"
-#~ msgstr "ディスプレイ、ベクトル、テーマ、凡例"
-#~ msgid "vector, topology"
-#~ msgstr "ベクトル、トポロジー"
-#~ msgid "Name of vector map for which to edit attribute table"
-#~ msgstr "属性テーブルを編集するためのベクトルマップ"
-#~ msgid "Table from which to drop attribute column"
-#~ msgstr "属性列を消去するテーブル"
-#~ msgid "Raster map in which to fill nulls"
-#~ msgstr "nullで埋められたラスターマップ"
-#~ msgid "Output raster map with nulls filled by interpolation from surrounding values"
-#~ msgstr "周囲の値からの補間によって埋められたnullで出力するラスターマップ"
-#~ msgid "Vector map from which to remove attribute table"
-#~ msgstr "属性テーブルを削除するベクトルマップ"
-#~ msgid "Name of existing attribute table (default: vector map name)"
-#~ msgstr "既存の属性テーブル名(デフォルト:ベクトルマップ名)"
-#~ msgid "Layer from which to drop linked attribute table"
-#~ msgstr "属性テーブルのリンクを削除するレイヤー"
-#~ msgid "Vector map for which to drop attribute column"
-#~ msgstr "属性列を削除するベクトルマップ"
-#~ msgid "Layer where to drop column"
-#~ msgstr "列を削除するレイヤー"
-#~ msgid "raster output TC maps prefix"
-#~ msgstr "ラスターアウトプットTCマッププリフィックス"
-#~ msgid "Vector map for which to add new attribute table"
-#~ msgstr "新しい属性テーブルを追加するベクトルマップ"
-#~ msgid "vector, import, wfs"
-#~ msgstr "ベクトル、インポート、サイト"
-#~ msgid "Name of data table"
-#~ msgstr "データテーブル名"
-#~ msgid "Database/directory for table"
-#~ msgstr "テーブルのデータベース/ディレクトリ"
-#~ msgid "Database driver"
-#~ msgstr "データベースドライバー"
-#~ msgid "Solar zenith in degrees"
-#~ msgstr "長軸の角度 [度]"
-#~ msgid "Cannot allocate memory for auxiliar matrix.Consider changing region resolution"
-#~ msgstr "auxiliarマトリックスにメモリーを割り当てられません.領域の解像度を変更してみてください  "
-#~ msgid "raster3d, voxel, export"
-#~ msgstr "ラスター3D、ボクセル、エクスポート"
-#~ msgid "Converts a 3D raster map layer into an ASCII text file."
-#~ msgstr "3DラスターマップをASCII形式のファイルとしてエクスポートします"
-#~ msgid "raster3d, voxel, import"
-#~ msgstr "ラスター3D、ボクセル、インポート"
-#~ msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
-#~ msgstr "3DASCII形式ラスターファイルを(バイナリ)3Dラスターマップレイヤーに変換します"
-#~ msgid "Unable to close output map"
-#~ msgstr "出力マップを閉じれません"
-#~ msgid "Unable to get elevation raster row"
-#~ msgstr "標高ラスターの行が取得できません"
-#~ msgid "Unable to write raster row"
-#~ msgstr "ラスター行を書き込めません"
-#~ msgid "raster3d, voxel"
-#~ msgstr "ラスター3D、ボクセル"
-#~ msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map."
-#~ msgstr "2D標高マップに基づいた3Dラスターマップから、クロスセクション2Dラスターマップを作成しました"
-#~ msgid "Elevation map not found"
-#~ msgstr "標高マップが見つかりません"
-#~ msgid "Unable to open elevation map"
-#~ msgstr "標高マップが開けません"
-#~ msgid "Illegal output file name"
-#~ msgstr "不正な出力ファイル名"
-#~ msgid "Unable to create raster map"
-#~ msgstr "ラスターマップを作成できません"
-#~ msgid "Unable to close elevation map"
-#~ msgstr "標高マップを閉じれません"
-#~ msgid "Wrong 3D raster map datatype! Unable to create raster map."
-#~ msgstr "3Dグリッドのデータタイプが不正です。ラスターマップが作成できません"
-#~ msgid "Use the same resolution as the input 3D raster map for the 2D outputmaps, independent of the current region settings"
-#~ msgstr "現在の領域の設定とは無関係に、出力する2Dマップに入力3Dグリッドマップと同じ解像度を使います。"
-#~ msgid "Raster map %d Filename: %s already exists. Will be overwritten!"
-#~ msgstr "ラスターマップ %d ファイル名: %s が存在します。上書きされます!"
-#~ msgid "Could not open map %s"
-#~ msgstr "マップ %s を開けません"
-#~ msgid "No 3D raster data, RGB or xyz-vector maps are provided. Will only write the geometry"
-#~ msgstr "3Dグリッドデータ、RGB、xyzベクトルマップのいずれも提供されていません。ジオメトリーのみを書出します"
-#~ msgid "No RGB Data will be created"
-#~ msgstr "RGBデータは作成されません"
-#~ msgid "No vector data will be created"
-#~ msgstr "ベクトルデータは作成されません"
-#~ msgid "Unable to close top raster map"
-#~ msgstr "上のラスターマップを閉じれません"
-#~ msgid "Unable to close bottom raster map"
-#~ msgstr "下のラスターマップを閉じれません"
-#~ msgid "Unable to close input raster map"
-#~ msgstr "入力ラスターマップを閉じれません"
-#~ msgid "G3D map(s) to be converted to VTK-ASCII data format"
-#~ msgstr " VTK-ASCII データフォーマットに変換する3Dグリッドマップ"
-#~ msgid "Unable to read top raster row \n"
-#~ msgstr "ラスター行を読み込めません \n"
-#~ msgid "Unable to read bottom raster row \n"
-#~ msgid "Wrong 3D raster map values: Values should in between 0 and 255\n"
-#~ msgstr "3Dラスターマップの値が正しくありません(値は 0 から 255 まで)!\n"
-#~ msgid "The status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
-#~ msgstr "各セルのステータス = 0 - インアクティブ, 1 - アクティブ, 2 - ディリクレ "
-#~ msgid "The z-part of the hydraulic conductivity tensor in [m/s]"
-#~ msgstr "透水係数テンソル Z-軸成分 [m/s] "
-#~ msgid "Sources and sinks in [m^3/s]"
-#~ msgstr "流入物と容積 [m^3/s] "
-#~ msgid "Specific yield in 1/m"
-#~ msgstr "特定の収率 1/m "
-#~ msgid "Recharge raster map in m^3/s"
-#~ msgstr "ラスターマップへの再投入m^3/s"
-#~ msgid "The piezometric head result of the numerical calculation will be written to this map"
-#~ msgstr "ピエゾ水頭の数値計算結果がこのマップに書き込まれます"
-#~ msgid ""
-#~ "Calculate the groundwater distance velocity vector field \n"
-#~ "and write the x, y, and z components to maps named name_[xyz].\n"
-#~ "Name is basename for the new 3D raster maps."
-#~ msgstr "地下水の距離の速度ベクトル情報を計算し、x、y、z構成要素として 名前_ [xyz]で出力されます。名前は、新しいラスター3Dマップのベース名です"
-#~ msgid "Use a sparse linear equation system, only available with iterative solvers"
-#~ msgstr "疎行列連立一次方程式を使用, 繰り返しソルバーでのみ利用可能"
-#~ msgid "Calculates numerically transient, confined groundwater flow in three dimensions."
-#~ msgstr "3次元の地下水の流れに限定した一時的な数値計算プログラム"
-#~ msgid "The direct Cholesky solver do not work with sparse matrices"
-#~ msgstr "ダイレクト cholesky ソルバーではスパース行列処理は処理出来ません"
-#~ msgid "raster3d, voxel, statistics"
-#~ msgstr "ラスター3D、統計"
-#~ msgid ""
-#~ "Cannot create mask file: G3D_MASK already exists!\n"
-#~ " Use 'g.remove rast3d=G3D_MASK' to remove the existing mask."
-#~ msgstr ""
-#~ "マスクファイル作成エラー: G3D_MASK はすでに存在します!\n"
-#~ "現在のマスクを削除するには 'g.remove rast3d=G3D_MASK'"
-#~ msgid "raster, export"
-#~ msgstr "ラスター、エクスポート"
-#~ msgid "Exports a GRASS raster map to a binary array."
-#~ msgstr "ラスターマップをバイナリーファイルとしてエクスポートします"
-#~ msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
-#~ msgstr "GRASS ラスタマップをGRIDATB.FOR(TOPMODEL) へエクスポート"
-#~ msgid "Overwrite output map file"
-#~ msgstr "マップファイルの上書き"
-#~ msgid "Setting window header"
-#~ msgstr "画面ヘッダのセット"
-#~ msgid "raster, statistics"
-#~ msgstr "ラスター、統計"
-#~ msgid "Finds the median of values in a cover map within areas assigned the same category value in a user-specified base map."
-#~ msgstr "ユーザー指定ベースマップと同じカテゴリー値をもつカバーマップの平均値を求める"
-#~ msgid "Name of base raster map"
-#~ msgstr "基本ラスターマップ名"
-#~ msgid "Base raster map <%s> not found"
-#~ msgstr "基本ラスターマップ <%s> が見つかりません"
-#~ msgid "Base map and output map <%s> must be different"
-#~ msgstr "ベースマップと出力ファイル <%s> は同じには出来ません"
-#~ msgid "Unable to read category labels of raster map <%s>"
-#~ msgstr "ラスターマップのカテゴリーラベルを読み込むことが出来ません <%s> "
-#~ msgid "raster, color transformation"
-#~ msgid "Error reading 'hue' map"
-#~ msgstr "色相マップ読み込みエラー"
-#~ msgid "Error reading 'intensity' map"
-#~ msgstr "照度マップ読み込みエラー"
-#~ msgid "Error reading 'saturation' map"
-#~ msgstr "彩度マップ読み込みエラー"
-#~ msgid "The '-v' flag is superseded and will be removed in future. Please use '--verbose' instead."
-#~ msgstr "オプション '-v'は、もうすぐ使えなくなります '--verbose' を使用してください "
-#~ msgid "raster, import"
-#~ msgstr "ラスター、インポート"
-#~ msgid "Can't create raster map <%s>"
-#~ msgstr "ラスターマップ<%s>が作成できません "
-#~ msgid "raster, DEM, contours, vector"
-#~ msgstr "ラスター、DEM、コンター、ベクトル "
-#~ msgid "Run quietly"
-#~ msgstr "説明なしで実行"
-#~ msgid "Suppress single crossing error messages"
-#~ msgstr "単一交差に関するエラーメッセージを出力しない "
-#~ msgid "The '-q' and '-n' flag is superseded and will be removed in future. Please use '--quiet' instead."
-#~ msgstr "-q' フラッグ、'-n' フラッグは将来廃止されます。'--quiet' フラッグを使用してください。 "
-#~ msgid "Converts a raster map layer into a height-field file for POVRAY."
-#~ msgstr "ラスターマップをPOVRAY用の高度フィールドファイルとしてエクスポートします "
-#~ msgid "raster, hydrology"
-#~ msgstr "ラスター、水流、水文学"
-#~ msgid "raster, metadata"
-#~ msgstr "ラスター、メタデータ "
-#~ msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead."
-#~ msgstr "-q' フラッグは将来廃止されます。'--quiet' フラッグを使用してください。"
-#~ msgid "%s: [%s] not found"
-#~ msgstr "%s: [%s] が見つかりません "
-#~ msgid "raster, landscape structure analysis, patch index"
-#~ msgstr "ラスター, 地形構造解析,パッチインデックス "
-#~ msgid "raster, map algebra"
-#~ msgstr "ラスター、マップ代数"
-#~ msgid "Raster map matrix filter."
-#~ msgstr "フィルタをかけたラスターマップを作成します "
-#~ msgid "Name of filter file"
-#~ msgstr "フィルタファイル名 "
-#~ msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead"
-#~ msgid "Cannot read raster row %d"
-#~ msgstr "ラスターの %d 行目が読込みできません "
-#~ msgid "Cannot open raster map <%s>"
-#~ msgstr "ラスターマップ <%s> が開けません "
-#~ msgid "Converts a raster map layer into an ASCII text file."
-#~ msgstr "ラスターマップをASCII形式のファイルとしてエクスポートします "
-#~ msgid "raster, export, png"
-#~ msgid "Export GRASS raster as non-georeferenced PNG image."
-#~ msgstr "GRASS ラスターマップを GDAL サポートのフォーマットへエクスポート"
-#~ msgid "Unable to read raster map row %d"
-#~ msgstr "ラスターマップの行 %d が読み込めません"
-#~ msgid "raster, cost surface, cumulative costs"
-#~ msgstr "ラスター、コスト曲面、累積コスト"
-#~ msgid "Name of raster map to contain results"
-#~ msgstr "結果を出力するラスターマップ名 "
-#~ msgid "Number of the segment to create (segment library)"
-#~ msgstr "作成するセグメント数 (セグメントライブラリー)"
-#~ msgid "Unable to read current window parameters"
-#~ msgstr "現在のウィンドウのパラメータが読み取れません "
-#~ msgid "Nseg is %d"
-#~ msgstr "Nseg は %d です  "
-#~ msgid "Null cells excluded from cost evaluation."
-#~ msgstr "NULL値セルはコスト評価から除外されました "
-#~ msgid "Input null cell will be retained into output map"
-#~ msgstr "入力されたNULL値セルは、そのまま出力マップに出力されます "
-#~ msgid "Unable to find starting vector <%s> "
-#~ msgstr " 開始ベクトル <%s> が見つかりません。 "
-#~ msgid "Unable to find stop vector <%s>"
-#~ msgstr " 終了ベクトル <%s> が見つかりません。 "
-#~ msgid "Unable to read %s"
-#~ msgstr "%s を読み込めません "
-#~ msgid "Map with different projection"
-#~ msgstr "異なる投影でのマップ "
-#~ msgid "DTM_Source map is: Integer cell type"
-#~ msgstr "DTMソースマップは整数セル型です  "
-#~ msgid "DTM_Source map is: Floating point (float) cell type"
-#~ msgstr "DTMソースマップは浮動小数点型です  "
-#~ msgid "DTM_Source map is: Floating point (double) cell type"
-#~ msgstr "DTMソースマップは倍精度浮動小数点型です  "
-#~ msgid " %d rows, %d cols"
-#~ msgstr " %d 行, %d 列  "
-#~ msgid "COST_Source map is: Integer cell type"
-#~ msgstr "コスト ソースマップは整数セル型  "
-#~ msgid "COST_Source map is: Floating point (float) cell type"
-#~ msgstr "コスト ソースマップは浮動小数点セル型 "
-#~ msgid "COST_Source map is: Floating point (double) cell type"
-#~ msgstr "コスト ソースマップは倍精度浮動小数点セル型 "
-#~ msgid "Output map is: Integer cell type"
-#~ msgstr "出力マップは整数セル型です "
-#~ msgid "Output map is: Floating point (float) cell type"
-#~ msgstr "出力マップはポイント(浮動小数点)セル型 "
-#~ msgid "Output map is: Floating point (double) cell type"
-#~ msgstr "出力マップはポイント(倍精度浮動小数点)セル型 "
-#~ msgid " EW resolution %s (%lf)"
-#~ msgstr " EW 解像度 %s (%lf)  "
-#~ msgid " NS resolution %s (%lf)"
-#~ msgstr " NS 解像度 %s (%lf)  "
-#~ msgid "Unable to read raster map <%s> row %d"
-#~ msgstr "ラスターマップ <%s> 行 %d が読み込めません"
-#~ msgid "Initializing output "
-#~ msgstr "出力を初期化 "
-#~ msgid "Unable to allocate memory for segment fbuff == NULL"
-#~ msgstr "セグメント fbuff のメモリ領域が確保できません"
-#~ msgid "Raster output map <%s> not found (no start_points given)"
-#~ msgstr "ラスタ-出力マップ <%s> が見つかりません(開始点がありません)"
-#~ msgid "Memory allocation error on reading start points from raster map %s"
-#~ msgstr "ラスターマップ %s の開始点読込中に メモリーアロケーションエラー"
-#~ msgid "End of map!"
-#~ msgstr "マップの終端です!  "
-#~ msgid "Will copy input map null values into output map"
-#~ msgstr "入力マップのNULL値セルを出力マップにコピーします "
-#~ msgid ""
-#~ "Integer cell type.\n"
-#~ "Writing..."
-#~ msgstr ""
-#~ "整数セルタイプ\n"
-#~ "書込中...  "
-#~ msgid ""
-#~ "Float cell type.\n"
-#~ "Writing..."
-#~ msgstr ""
-#~ "浮動小数点数セルタイプ\n"
-#~ "書込中...  "
-#~ msgid ""
-#~ "Double cell type.\n"
-#~ "Writing..."
-#~ msgstr ""
-#~ "倍精度浮動小数点セルタイプ\n"
-#~ "書き込中...  "
-#~ msgid "Peak cost value: %f"
-#~ msgstr "ピークコスト値: %f  "
-#~ msgid "raster, sun energy"
-#~ msgstr "ラスター、タイル表示"
-#~ msgid "This does nothing. It is retained for backwards compatibility"
-#~ msgstr "何もしないで下位互換性を残します"
-#~ msgid "Unused"
-#~ msgstr "不使用"
-#~ msgid "Horizon file no. %d <%s> not found"
-#~ msgstr "水平ファイル%d 番 <%s> が見つかりません "
-#~ msgid "Import GDAL supported raster file into a binary raster map layer."
-#~ msgstr "GDALでサポートされているラスターファイルをバイナリラスターマップレイヤーにインポートします"
-#~ msgid "Required"
-#~ msgstr "å¿…é ˆ"
-#~ msgid "Import a binary raster file into a GRASS raster map."
-#~ msgstr "バイナリーファイルをラスターマップとしてインポートします "
-#~ msgid "raster, rescale"
-#~ msgstr "ラスター,再サンプリング"
-#~ msgid ""
-#~ "\n"
-#~ "Hit RETURN to continue -->"
-#~ msgstr ""
-#~ "\n"
-#~ "リターンを押して続行 -->  "
-#~ msgid "Update the statistics (histogram, range) for [%s]? "
-#~ msgstr "統計情報(ヒストグラム、範囲) [%s] 更新しますか?   "
-#~ msgid "Not enough room in history file"
-#~ msgstr "履歴ファイルが一杯です "
-#~ msgid "Edit header for [%s]? "
-#~ msgstr "[%s] のヘッダーを編集しますか?   "
-#~ msgid ""
-#~ "\n"
-#~ "NOTE: [%s] is a reclass of [%s in %s]"
-#~ msgstr ""
-#~ "\n"
-#~ "注意: [%s] は [%s 中の %s] の再分類 "
-#~ msgid "Canceling from edit header."
-#~ msgstr "ヘッダーの編集をキャンセル  "
-#~ msgid "Edit the category file for [%s]? "
-#~ msgstr "[%s]のカテゴリーファイルを編集しますか?   "
-#~ msgid "Create/Update the color table for [%s]? "
-#~ msgstr "[%s] のカラーテーブルを作成(更新)しますか?   "
-#~ msgid "Edit the history file for [%s]? "
-#~ msgstr "[%s] の履歴を編集しますか?   "
-#~ msgid ""
-#~ "\n"
-#~ "The null file for [%s] may indicate that some cells contain\n"
-#~ " no data. If the null file for [%s] doesn't exist, zero cells in\n"
-#~ " it are treated by GRASS application programs as no data."
-#~ msgstr ""
-#~ "\n"
-#~ "[%s] の null ファイルは空のセルを含んでいると表示されるかもしれません\n"
-#~ "もし [%s]  の null ファイルがない場合、GRASSはゼロ値のセルを\n"
-#~ "データが無いと判断します"
-#~ msgid ""
-#~ "\n"
-#~ "Do you want to create/reset the null file for [%s] so that null cell values are considered valid data? "
-#~ msgstr ""
-#~ "\n"
-#~ "null セルの値を有効値にするために、[%s] の null ファイルを作成(リセット)しますか? "
-#~ msgid "Error writing null row [%d]."
-#~ msgstr "エラーを null 行 [%d] に書き込み中  "
-#~ msgid ""
-#~ "\n"
-#~ "Do you want to delete the null file for [%s]\n"
-#~ "(all zero cells will then be considered no data)? "
-#~ msgstr ""
-#~ "\n"
-#~ "[%s] の null ファイルを消去\n"
-#~ "(ゼロ値のセルはデータ無しとして処理)?   "
-#~ msgid "Please enter the following information for [%s]:"
-#~ msgstr "[%s] のための情報を順次入力してください "
-#~ msgid "        Number of rows"
-#~ msgstr "行数 "
-#~ msgid "        Number of cols"
-#~ msgstr "列の数 "
-#~ msgid "        Number of bytes per cell"
-#~ msgstr "1セルのバイト数 "
-#~ msgid "        Floating point map"
-#~ msgstr "浮動小数点でのマップ"
-#~ msgid "rows * cols * bytes per cell must be same as file size (%lu)"
-#~ msgstr "セルごとの行 * 列 * のバイト数はファイルサイズと一致させる (%lu)  "
-#~ msgid "If you need help figuring them out, just hit ESC"
-#~ msgstr "ヘルプが必要なときは ESC を押します "
-#~ msgid "** Negative values not allowed!"
-#~ msgstr "** 負(-)の値は無効!  "
-#~ msgid "** Positive values only please!"
-#~ msgstr "** 正(+)の値だけです!  "
-#~ msgid "Edit header for [%s]\n"
-#~ msgstr "[%s] のヘッダーを編集\n"
-#~ msgid "[%s] cannot be found!"
-#~ msgstr "[%s] が見つかりません "
-#~ msgid "For what layer shall the header file be edited? "
-#~ msgstr "どのレイヤーのヘッダーファイルを編集しますか?   "
-#~ msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
-#~ msgstr "[%s] は [%s] の再分類 - ヘッダーを編集できません!  [%s] 上で動作 "
-#~ msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
-#~ msgstr "[%s] は [%s 中の %s] の再分類 - ヘッダーを編集できません!  "
-#~ msgid "Cannot open raster map [%s]!"
-#~ msgstr "ラスターマップ [%s]を開けません! "
-#~ msgid "Raster file [%s] is empty."
-#~ msgstr "ラスターファイル [%s] が空です  "
-#~ msgid "Error reading raster map [%s]."
-#~ msgstr "ラスターマップ [%s] を読めません "
-#~ msgid "cellhd compression: %d\n"
-#~ msgstr "cellhd 圧縮: %d\n"
-#~ msgid "3.0 compression %sindicated\n"
-#~ msgstr "3.0 圧縮 %sindicated\n"
-#~ msgid "Pre 3.0 compression %sindicated\n"
-#~ msgstr "プレ3.0圧縮 %s が指示されました\n"
-#~ msgid "[%s] appears to be compressed. Is it? "
-#~ msgstr "[%s] は圧縮済みのようです   "
-#~ msgid "Please indicate the type of compression:\n"
-#~ msgstr "圧縮形式を選択してください:\n"
-#~ msgid "  1. Pre 3.0 compression\n"
-#~ msgstr "1. Pre 3.0 圧縮\n"
-#~ msgid "  2. 3.0 compression\n"
-#~ msgstr "2. 3.0 圧縮 \n"
-#~ msgid "The header for [%s] says the file is not compressed. "
-#~ msgstr "[%s] のヘッダーによればこのファイルは圧縮されていません "
-#~ msgid "The file appears to be compressed.\n"
-#~ msgstr "このファイルは圧縮されています\n"
-#~ msgid "Most likely the header is wrong, but I want you to decide.\n"
-#~ msgstr "ヘッダーが不適切ですが、決断が必要\n"
-#~ msgid "The header for [%s] says the file is compressed. "
-#~ msgstr "[%s] のヘッダーによれば、このファイルは圧縮済み "
-#~ msgid "The file does NOT appear to be compressed.\n"
-#~ msgstr "このファイルは圧縮されていないようです.\n"
-#~ msgid "Header indicates %d row%s in the raster map, but the actual file format indicates %d row%s"
-#~ msgstr "ラスターマップのヘッダーは %d 行 %s ですが、実際のファイルフォーマットは %d 行 %s "
-#~ msgid "Unable to write header for [%s]."
-#~ msgstr "[%s] のヘッダーを書き込めません "
-#~ msgid "Header for raster map [%s] updated."
-#~ msgstr "ラスターマップ [%s] のヘッダーが更新されました "
-#~ msgid ""
-#~ "\n"
-#~ "hit RETURN to continue -->"
-#~ msgstr ""
-#~ "\n"
-#~ msgid "Which raster map needs a color table"
-#~ msgstr "どのラスターマップにカラーテーブルに必要ですか? "
-#~ msgid "Color table for <%s> updated"
-#~ msgstr "<%s> のカラーテーブルが更新されました "
-#~ msgid "Which raster map needs an updated history? "
-#~ msgstr "どのラスターマップに更新履歴が必要ですか? "
-#~ msgid "Raster file [%s] not found. Exiting."
-#~ msgstr "ラスターファイル [%s] がありません,終了中 "
-#~ msgid "History file for [%s] updated."
-#~ msgstr "[%s] の変更履歴ファイルが更新されました "
-#~ msgid "History file for [%s] not updated."
-#~ msgstr "[%s] の変更履歴ファイルは更新されませんでした "
-#~ msgid "Which vector map needs updated categories?"
-#~ msgstr "どのベクトルマップに更新されたカテゴリーが必要ですか? "
-#~ msgid "Which raster map needs updated categories?"
-#~ msgstr "どのラスターマップに更新されたカテゴリーが必要ですか? "
-#~ msgid "Category file for <%s> not updated"
-#~ msgstr "<%s> のカテゴリーファイルは更新されません "
-#~ msgid "Category file for <%s> updated"
-#~ msgstr "<%s> のカテゴリーファイルは更新されました "
-#~ msgid "Failed writing output raster map row %d"
-#~ msgstr "指定したラスターマップの行 %d は書き込み失敗しました"
-#~ msgid "Name of terrain raster map (DEM)"
-#~ msgstr "地形のラスターマップ名 (DEM) "
-#~ msgid "Name for output raster map with lake"
-#~ msgstr "湖付きで出力するラスターマップ名 "
-#~ msgid "raster, interpolation"
-#~ msgstr "補間に用いる近傍点 "
-#~ msgid "Interpolating raster map <%s> (%d rows)... "
-#~ msgstr "ラスターマップ <%s> (%d 行) を補間中"
-#~ msgid "Cannot read row"
-#~ msgstr "行を読めません "
-#~ msgid "raster, export, color table"
-#~ msgstr "ラスター,カラーテーブル"
-#~ msgid "Exports the color table associated with a raster map layer."
-#~ msgstr "ラスターマップレイヤーに関するカラーテーブルを表示します"
-#~ msgid "%s' must be greater than zero; using %s=255"
-#~ msgstr "%s はゼロ以上が条件; %s=255 を使用中 "
-#~ msgid "Unable to read raster <map %d of %d> row %d"
-#~ msgstr "ラスターマップ <%d の %d> 行 %d を読めません"
-#~ msgid "raster, map management"
-#~ msgstr "一般的な, マップ管理"
-#~ msgid "raster, geometry"
-#~ msgstr "ラスター、画像"
-#~ msgid "Name of the latitudes input raster map [decimal degrees]"
-#~ msgstr "緯度入力ラスターマップ名(小数点付の度) "
-#~ msgid "A single value of latitude [decimal degrees]"
-#~ msgstr "緯度の単体値 (単位は小数点付きの度) "
-#~ msgid "Name of real-sky beam radiation coefficient raster map [-]"
-#~ msgstr "日射の放射係数ラスターマップ名 [-]"
-#~ msgid "Name of real-sky diffuse radiation coefficient raster map [-]"
-#~ msgstr "日射の拡散放射係数ラスターマップ名 [-]"
-#~ msgid "time and insol_time are incompatible options"
-#~ msgstr "Time' と 'insol_time' は併用できません"
-#~ msgid "Mode 1: instantaneous solar incidence angle & irradiance given a set local time"
-#~ msgstr "モード 1: 瞬間の太陽入射角と照度をローカルタイムから取得"
-#~ msgid "elevin raster map <%s> not found"
-#~ msgstr "elevin ラスターマップ <%s> がありません"
-#~ msgid "aspin raster map <%s> not found"
-#~ msgstr "aspin ラスターマップ <%s> がありません"
-#~ msgid "slopein raster map <%s> not found"
-#~ msgstr "ラスターマップ (slopein) <%s> がありません"
-#~ msgid "linkein raster map <%s> not found"
-#~ msgstr "linkein ラスターマップ <%s> がありません"
-#~ msgid "albedo raster map <%s> not found"
-#~ msgstr "albedo ラスターマップ <%s> がありません"
-#~ msgid "latin raster map <%s> not found"
-#~ msgstr "latin ラスターマップ <%s>がありません"
-#~ msgid "coefbh raster map <%s> not found"
-#~ msgstr "coefbh ラスターマップ <%s> がありません"
-#~ msgid "coefdh raster map <%s> not found"
-#~ msgstr "coefdh ラスターマップ <%s> がありません"
-#~ msgid "Unable to create raster map %s"
-#~ msgstr "ラスターマップを作成できません %s"
-#~ msgid "rows changed from %d to %d"
-#~ msgstr "行を %d から %d へ変更"
-#~ msgid "cols changed from %d to %d"
-#~ msgstr "列を %d から %d へ変更"
-#~ msgid "RGB raster map <%s> not found"
-#~ msgstr "RGBラスターマップ<%s>がありません "
-#~ msgid "Cannot create RGB data, please provide three maps [r,g,b]"
-#~ msgstr "RGBデータを作成できません, 3つのマップ [r,g,b] を用意してください"
-#~ msgid "Vector cell map <%s> not found"
-#~ msgstr "ベクトルセルマップ <%s> がありません  "
-#~ msgid "Cannot create vector data, please provide three maps [x,y,z]"
-#~ msgstr "ベクトルデータを作成できません, 3つのマップ [x,y,z] を用意してください"
-#~ msgid "Converts raster maps into the VTK-Ascii format"
-#~ msgstr "ラスターマップを VTK-Asciiフォーマットへ変換"
-#~ msgid "Unable to read row %i\n"
-#~ msgstr "行を読めません%i\n"
-#~ msgid "raster, quantization"
-#~ msgstr "ラスター、投影法"
-#~ msgid "Setting quant rules for input map(s) to (%f %f) -> (%d,%d)"
-#~ msgstr "入力マップの量子化ルールを設定します  (%f %f) -> (%d,%d)  "
-#~ msgid "Quant table not changed for %s"
-#~ msgstr "%s 用に量子テーブルは変更されません "
-#~ msgid "raster, terrain"
-#~ msgstr "ラスター、地形"
-#~ msgid "Failed to guess site file format\n"
-#~ msgstr "サイトファイルのフォーマットが不明です\n"
-#~ msgid "No data"
-#~ msgstr "データがありません"
-#~ msgid "NULL value computed (row %d, col %d)"
-#~ msgstr "ヌル値が計算されました (行 %d、 列 %d)  "
-#~ msgid "Unable to find row %d, col %d: %f"
-#~ msgstr "行 %d、 列%d がみつかりません: %f  "
-#~ msgid "Illegal delete request"
-#~ msgstr "不正な削除要求です"
-#~ msgid "Bad start cell"
-#~ msgstr "不正な開始セル  "
-#~ msgid "%s %f-%f lower cost higher or equal"
-#~ msgstr "%s %f-%f 下部コストが同じか高すぎます"
-#~ msgid "%s lower above pointer wrong"
-#~ msgstr "%s はポインタ上より下で不正です"
-#~ msgid "%s %f-%f higher cost lower"
-#~ msgstr "%s %f-%f 上部コストが低すぎます"
-#~ msgid "%s higher above pointer wrong"
-#~ msgstr "%s はポインタ上より上で不正です"
-#~ msgid "raster, resample"
-#~ msgid "Bilinear interpolation utility for raster map layers."
-#~ msgstr "ラスターマップ用の双線補完ユーティリティ"
-#~ msgid "Specific input value to be assigned to the north and/or south poles for longitude-latitude grids"
-#~ msgstr "緯度経度グリッドでは、特定の入力値は北極または南極に割り当てられます"
-#~ msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
-#~ msgstr "このモジュールは将来廃止される予定です. 'r.resamp.interp' を使用してください"
-#~ msgid "Apply filter only to zero data values"
-#~ msgstr "値0にのみフィルタを適用 "
-#~ msgid "One or more input raster maps not found"
-#~ msgstr "入力ラスターマップが見つかりません"
-#~ msgid "raster, sediment flow, erosion, deposition"
-#~ msgstr "ラスター, 土砂流, 侵食, 堆積"
-#~ msgid "Name of the elevation raster map [m]"
-#~ msgstr "標高ラスターマップ名 [m]"
-#~ msgid "Name of the water depth raster map [m]"
-#~ msgstr "水深ラスターマップ名 [m]"
-#~ msgid "Name of the x-derivatives raster map [m/m]"
-#~ msgstr "x-導関数ラスターマップ名 [m/m]"
-#~ msgid "Name of the y-derivatives raster map [m/m]"
-#~ msgstr "y-導関数ラスターマップ名 [m/m]"
-#~ msgid "Name of the detachment capacity coefficient raster map [s/m]"
-#~ msgstr "分離容積係数ラスターマップ名 [s/m]"
-#~ msgid "Name of the transport capacity coefficient raster map [s]"
-#~ msgstr "移動容積係数ラスターマップ名 [s]"
-#~ msgid "Name of the critical shear stress raster map [Pa]"
-#~ msgstr "重大せん断応力ラスターマップ名 [Pa]"
-#~ msgid "Name of the Mannings n raster map"
-#~ msgstr "マニングn値ラスターマップ名"
-#~ msgid "Name of the Mannings n value"
-#~ msgstr "マニングn値名"
-#~ msgid "Output transport capacity raster map [kg/ms]"
-#~ msgstr "出力する移動容積ラスタマップ [kg/ms]  "
-#~ msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
-#~ msgstr "透過制限侵食-堆積ラスターマップを出力 [kg/m2s]"
-#~ msgid "Output sediment concentration raster map [particle/m3]"
-#~ msgstr "堆積物濃度ラスターマップを出力 [particle/m3]"
-#~ msgid "Output sediment flux raster map [kg/ms]"
-#~ msgstr "堆積物フラックスラスターマップを出力 [kg/ms]"
-#~ msgid "Output erosion-deposition raster map [kg/m2s]"
-#~ msgstr "侵食-堆積ラスターマップを出力 [kg/m2s]"
-#~ msgid "raster, flow, hydrology"
-#~ msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
-#~ msgstr "降雨過剰(雨水浸入)ラスターマップ [mm/hr]"
-#~ msgid "Name of the runoff infiltration rate raster map [mm/hr]"
-#~ msgstr "流出水侵入率ラスターマップ [mm/hr]"
-#~ msgid "Name of the flow controls raster map (permeability ratio 0-1)"
-#~ msgstr "流量コントロールラスターマップ名 (浸透率 0-1)"
-#~ msgid "Output water depth raster map [m]"
-#~ msgstr "水深ラスターマップを出力する [m]  "
-#~ msgid "Output water discharge raster map [m3/s]"
-#~ msgstr "排水ラスターマップを出力する [m3/s]"
-#~ msgid "Output simulation error raster map [m]"
-#~ msgstr "シミュレーションエラーラスタマップを出力する [m]  "
-#~ msgid "Threshold water depth [m] (diffusion increases after this water depth is reached)"
-#~ msgstr "閾値水深 [m] (この水深に達すると拡散が増えます)  "
-#~ msgid "Unable to close input map"
-#~ msgstr "入力マップが閉じれません"
-#~ msgid "Use G3D mask (if exists) with input map"
-#~ msgstr "入力マップに3Dグリッドマスクを使う"
-#~ msgid "Could not get raster row from input map"
-#~ msgstr "入力マップからラスター行を取得できません"
-#~ msgid "Could not get raster row from elev map"
-#~ msgstr "標高マップからラスター行を取得できません"
-#~ msgid "Error writing G3D double data"
-#~ msgstr "エラー:3Dグリッド倍精度浮動小数点値データを書き込めません"
-#~ msgid "raster, raster3d, voxel, conversion"
-#~ msgstr "ラスター、ラスター3D、ボクセル、変換"
-#~ msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the currently defined region."
-#~ msgstr "ラスターマップを、現在の定義領域のピクセル解像度のPPM画像ファイルにエクスポートします"
-#~ msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
-#~ msgstr "ラスターマップをPPMファイルとしてエクスポートします "
-#~ msgid "raster, transect"
-#~ msgid "raster, random"
-#~ msgid "Cannot read raster row [%d]"
-#~ msgstr "ラスター行 [%d] が読み込めません"
-#~ msgid "Cannot read cover raster row [%d]"
-#~ msgstr "カバーラスター行 [%d] を読み込めません"
-#~ msgid "Cannot read raster row [%d] from raster map <%s>"
-#~ msgstr "ラスター行 [%d] (ラスターマップ <%s> )が読み込めません"
-#~ msgid "Cannot read raster row [%d] from cover raster map <%s>"
-#~ msgstr "ラスター行 [%d] (カバーラスターマップ <%s> )が読み込めません"
-#~ msgid "raster, viewshed"
-#~ msgstr "ラスター、シリーズ"
-#~ msgid "[%s]: Cannot read map header"
-#~ msgstr "[%s]: マップヘッダーが読み込めません"
-#~ msgid "Failed writing raster map <%s> row %d"
-#~ msgstr "ラスターマップ <%s> 行 %d を書き込めません"
-#~ msgid "raster, fire"
-#~ msgid "Run VERBOSELY"
-#~ msgstr "説明つき表示 "
-#~ msgid "Raster map <%s> already exists in mapset <%s>, select another name"
-#~ msgstr "ラスターマップ<%s>既にマップセット<%s>に存在します. 別の名前を付けて下さい"
-#~ msgid "Name of raster map to contain results (several new layers)"
-#~ msgstr "結果(複数の新規レイヤー)を出力するラスターマップ名"
-#~ msgid "Percent Completed ... "
-#~ msgstr "完了率(%)"
-#~ msgid "The initial piezometric head in [m]"
-#~ msgstr "初期ピエゾメーター水頭 [m] "
-#~ msgid "Boundary condition status, 0-inactive, 1-active, 2-dirichlet"
-#~ msgstr "境界条件のステータス, 0-不活性、 1-活性、2-ディリクレ"
-#~ msgid "X-part of the hydraulic conductivity tensor in [m/s]"
-#~ msgstr "透水係数テンソルのX成分 [m/s]  "
-#~ msgid "Y-part of the hydraulic conductivity tensor in [m/s]"
-#~ msgstr "透水係数テンソルのY成分 [m/s]  "
-#~ msgid "Water sources and sinks in [m^3/s]"
-#~ msgstr "水源と沈降[m^3/s]  "
-#~ msgid "Specific yield in [1/m]"
-#~ msgstr "特定イールド[1/m]  "
-#~ msgid "Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
-#~ msgstr "マップを再チャージする 例:セルあたり 6*10^-9  [m^3/s*m^2]"
-#~ msgid "The map storing the numerical result [m]"
-#~ msgstr "数値結果[m]を保存するマップ  "
-#~ msgid ""
-#~ "Calculate the groundwater filter velocity vector field [m/s]\n"
-#~ "and write the x, and y components to maps named name_[xy]"
-#~ msgstr ""
-#~ "地下水フィルター速度ベクトルフィールド[m/s]を計算し\n"
-#~ "指定名_[xy] というマップに x、y コンポーネントを書き込みます   "
-#~ msgid "Water level (head) of the river with leakage connection in [m]"
-#~ msgstr "漏出と接続された河川の水位 (水頭)[m]  "
-#~ msgid "The leakage coefficient of the river bed in [1/s]."
-#~ msgstr "河床の漏出量係数 [1/s].  "
-#~ msgid "The height of the drainage bed in [m]"
-#~ msgstr "排水床の高さ [m]  "
-#~ msgid "The leakage coefficient of the drainage bed in [1/s]"
-#~ msgstr "排水床の漏出量係数 [1/s]  "
-#~ msgid "Use a sparse matrix, only available with iterative solvers"
-#~ msgstr "疎行列を使う. インタラクティブなソルバーでのみ使用できます"
-#~ msgid "The direct cholesky solver do not work with sparse matrices"
-#~ msgid "raster, profile"
-#~ msgid "Interactively select End-Points"
-#~ msgstr "対話形式で終点を選択 "
-#~ msgid "Use mouse to select Start Point\n"
-#~ msgstr "マウスで開始ポイントを決定\n"
-#~ msgid ""
-#~ "\n"
-#~ "Use mouse to draw profile line\n"
-#~ msgstr ""
-#~ "\n"
-#~ "マウスでプロファイルラインを引く\n"
-#~ msgid "Buttons:\n"
-#~ msgstr "ボタン:\n"
-#~ msgid "Left:   Mark next point\n"
-#~ msgstr "左:   次のポイントをマーク\n"
-#~ msgid "Middle: Mark next point\n"
-#~ msgstr "中央: 次のポイントをマーク\n"
-#~ msgid ""
-#~ "Right:  Finish profile and exit\n"
-#~ "\n"
-#~ msgstr ""
-#~ "右:  プロファイルを終了\n"
-#~ "\n"
-#~ msgid "raster, buffer"
-#~ msgstr "ラスター、バッファ"
-#~ msgid "raster, series"
-#~ msgid "Unable to open raster map <%s> in mapset <%s>"
-#~ msgstr "ラスターマップ <%s> (マップセット <%s> 中)が開けません"
-#~ msgid "Finds the average of values in a cover map within areas assigned the same category value in a user-specified base map."
-#~ msgstr "ベースマップにおける同一カテゴリー内でのカバーマップの平均値を計算します "
-#~ msgid "%s: ERROR running %s command"
-#~ msgstr "%s: エラー: %s コマンドの実行中"
-#~ msgid "%s: unable to open temporary file"
-#~ msgstr "%s: 一時ファイルをオープン出来ません"
-#~ msgid "Cannot get row"
-#~ msgstr "行を取得できません"
-#~ msgid "Watershed basin analysis program."
-#~ msgstr "分水域の解析を行います "
-#~ msgid "Input map: elevation on which entire analysis is based"
-#~ msgstr "入力:標高を示すファイル "
-#~ msgid "Input map: locations of real depressions"
-#~ msgstr "入力:地盤沈下量を示すファイル "
-#~ msgid "Input map: amount of overland flow per cell"
-#~ msgstr "入力:1セルの流量を示すファイル "
-#~ msgid "Input map or value: percent of disturbed land, for USLE"
-#~ msgstr "入力:開発地域の割合を示すファイル "
-#~ msgid "Input map: terrain blocking overland surface flow, for USLE"
-#~ msgstr "入力:曲面流でブロック化した地形を示すファイル "
-#~ msgid "Output map: number of cells that drain through each cell"
-#~ msgstr "出力:流れ出るセル数を示すファイル "
-#~ msgid "Output map: drainage direction"
-#~ msgstr "出力:排出方向を示すファイル "
-#~ msgid "Output map: unique label for each watershed basin"
-#~ msgstr "出力:分水域のラベルファイル "
-#~ msgid "Output map: stream segments"
-#~ msgstr "出力:河川を示すファイル "
-#~ msgid "Output map: each half-basin is given a unique value"
-#~ msgstr "出力:半盆地のラベルファイル "
-#~ msgid "Output map: useful for visual display of results"
-#~ msgstr "出力:結果を可視化したファイル "
-#~ msgid "Output map: slope length and steepness (LS) factor for USLE"
-#~ msgstr "出力:傾斜長と傾斜勾配(LSファクター)を示すファイル "
-#~ msgid "Output map: slope steepness (S) factor for USLE"
-#~ msgstr "出力:RUSLE用の傾斜勾配(Sファクター)を示すファイル "
-#~ msgid "Input value: minimum size of exterior watershed basin"
-#~ msgstr "外側の分水域の最小セル数 "
-#~ msgid "Input value: maximum length of surface flow, for USLE"
-#~ msgstr "曲面流の最大長(単位:メートル) "
-#~ msgid "Enable MFD flow (default is SFD (D8))"
-#~ msgstr "有効なMFD 流動 (デフォルトはSFD (D8))"
-#~ msgid ""
-#~ "Sorry, if any of the following options are set:\n"
-#~ "    basin, stream, half.basin, length.slope, or slope.steepness\n"
-#~ "    you MUST provide a value for the basin threshold parameter."
-#~ msgstr ""
-#~ "次のオプションのいずれかがセットされています:\n"
-#~ "    盆地、水路、半盆地、傾斜長、傾斜勾配\n"
-#~ "    盆地閾値パラメータの値を指定しなければなりません  "
-#~ msgid "unable to open new accum map layer."
-#~ msgstr "新規の累積マップレイヤーが開けません"
-#~ msgid "Close failed."
-#~ msgstr "閉じれません"
-#~ msgid "unable to open new aspect map layer."
-#~ msgstr "新規の方位マップレイヤーが開けません"
-#~ msgid "unable to open new LS factor map layer."
-#~ msgstr "新規のLSファクターマップレイヤーが開けません"
-#~ msgid "unable to open new slope length map layer."
-#~ msgstr "新規の傾斜長マップレイヤーが開けません"
-#~ msgid "unable to open new S factor map layer."
-#~ msgstr "新規の S ファクターマップレイヤーが開けません"
-#~ msgid "SECTION 2: A * Search."
-#~ msgstr "セクション 2: A * 検索  "
-#~ msgid "unable to open elevation map layer"
-#~ msgstr "標高マップレイヤーが開けません"
-#~ msgid "unable to open runoff map layer"
-#~ msgstr "流出水マップレイヤーが開けません"
-#~ msgid "unable to open depression map layer"
-#~ msgstr "地盤沈下マップレイヤーが開けません"
-#~ msgid "unable to open blocking map layer"
-#~ msgstr "社団マップレイヤーが開けません"
-#~ msgid "unable to open rill map layer"
-#~ msgstr "小川マップレイヤーが開けません"
-#~ msgid "unable to open flow accumulation map layer"
-#~ msgstr "流動累積マップレイヤーが開けません"
-#~ msgid "Maximum memory to be used was smaller than 3 MB, set to default = 300 MB."
-#~ msgstr "使用される最大メモリーが3MBより少ないです。既定値の300MBにセットします"
-#~ msgid "unable to open accum file in valid_basins()"
-#~ msgstr "valid_basins() で累積ファイルが開けません"
-#~ msgid "raster, DEM, fractal"
-#~ msgstr "ラスター、DEM、フラクタル"
-#~ msgid "Quietly"
-#~ msgstr "説明なし "
-#~ msgid "Error writing category file for <%s>"
-#~ msgstr "エラー: カテゴリーファイル <%s> が読み込めません"
-#~ msgid "Error writing color file for <%s>"
-#~ msgstr "エラー: 色ファイル <%s> が書き込めません"
-#~ msgid "raster, projection, transformation"
-#~ msgid "Re-projects a raster map from one location to the current location."
-#~ msgstr "ラスターマップの投影変換を行います "
-#~ msgid "Name for output raster map (default: input)"
-#~ msgstr "出力ラスターマップ名"
-#~ msgid "Resolution of output map"
-#~ msgstr "出力マップの解像度 "
-#~ msgid "Reading file"
-#~ msgstr "ファイルを読み込み中"
-#~ msgid "Raster File Series to MPEG Conversion."
-#~ msgstr "ラスターファイルシリーズをMPEG変換するプログラム"
-#~ msgid "Raster file(s) for View%d"
-#~ msgstr "ビュー %d に使うラスターマップ"
-#~ msgid "Quiet - suppress progress report"
-#~ msgstr "説明なし "
-#~ msgid ""
-#~ "Convert on the fly, use less disk space\n"
-#~ "\t(requires r.out.ppm with stdout option)"
-#~ msgstr ""
-#~ "オン・ザ・フライで変換、省ディスクスペース\n"
-#~ "\t(r.out.ppm の stdout オプションが必要)  "
-#~ msgid "Name of existing raster map containing elevation surface"
-#~ msgstr "標高曲面を含むラスターマップ名"
-#~ msgid "Output elevation raster map after filling"
-#~ msgstr "充填後にラスターマップを出力"
-#~ msgid "Output direction raster map"
-#~ msgstr "方向ラスターマップを出力"
-#~ msgid "Output raster map of problem areas"
-#~ msgstr "課題エリアのラスターマップを出力"
-#~ msgid "Output aspect direction format (agnps, answers, or grass)"
-#~ msgstr "方位方向フォーマット (agnps, answers, または grass) を出力"
-#~ msgid "Reading map..."
-#~ msgstr "マップを読み込み中..."
-#~ msgid "Unable to write color table for %s"
-#~ msgstr " %s の色テーブルを書き込めません"
-#~ msgid "Cannot read ew_res value"
-#~ msgstr "東西方向解像度の値が読み取れません"
-#~ msgid "Cannot read ns_res value"
-#~ msgstr "南北方向解像度の値が読み取れません "
-#~ msgid "[%s]: Map is the wrong resolution"
-#~ msgstr "[%s]: マップの解像度が不正です"
-#~ msgid "Cannot get row %d (error = %d)"
-#~ msgstr "行 %d を取得できません(エラー = %d)  "
-#~ msgid "Cannot set region to back to the initial region !!!"
-#~ msgstr "初期領域へ戻るための領域設定ができません !!!  "
-#~ msgid "Not enough memory for zero_array_cell"
-#~ msgstr "zero_array_cell のためのメモリーが足りません"
-#~ msgid "Not enough disk space -- cannot write files"
-#~ msgstr "ディスクスペース不足です -- ファイルを書き込めません"
-#~ msgid "raster, statistics, reclass"
-#~ msgstr "ラスター,統計,再分類"
-#~ msgid "Title, in quotes"
-#~ msgstr "タイトル(クォーテーション付き)"
-#~ msgid "Unable to read raster map row %d "
-#~ msgid "Failed writing raster map row %d"
-#~ msgstr "ラスターマップの行 %d が書き込めません"
-#~ msgid "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel resolution of the currently defined region."
-#~ msgstr "GRASS ラスターマップを 8/24 ビットの TIFF 画像ファイルへエクスポート"
-#~ msgid "Unable to read header of raster map <%s>"
-#~ msgstr "ラスターマップ<%s>のヘッダーが読み込めません"
-#~ msgid "Can't set window"
-#~ msgstr "ウィンドウをセットできません"
-#~ msgid "Raster map <%s> in mapset <%s> is a floating point map. Decimal values will be rounded to integer!"
-#~ msgstr "ラスタマップ <%s> (マップセット <%s> 内の) は 浮動小数点ポイントマップです.小数点以下の数値は丸められて整数型にされます!"
-#~ msgid "raster, import, LIDAR"
-#~ msgstr "ラスター、インポート、LIDAR"
-#~ msgid "Writing map, row %d"
-#~ msgstr "マップの %d 行を書出し中"
-#~ msgid "The size of sliding window (odd and >= 3)"
-#~ msgstr "変動するウィンドウのサイズ (3以上の奇数)  "
-#~ msgid "Nothing to compute. Use at least one of the flags."
-#~ msgstr "計算すべきものがありません。フラッグを少なくても一つ使用して下さい"
-#~ msgid "Calculated measure #%d <%s> (56 measures available)"
-#~ msgstr "計算量 #%d <%s> (56 項目が可能)  "
-#~ msgid "Surface generation program from rasterized contours."
-#~ msgstr "ラスター形式の等高線から曲面を作成"
-#~ msgid "Name of existing raster map containing contours"
-#~ msgstr "等高線を含む既存のラスターマップ名"
-#~ msgid "Output elevation raster map"
-#~ msgstr "標高ラスターマップを出力"
-#~ msgid "Unused; retained for compatibility purposes, will be removed in future"
-#~ msgstr "使用されません; 互換性を保持のため,これは将来削除されます"
-#~ msgid "Invoke slow, but memory frugal operation (generally not needed, will be removed in future)"
-#~ msgstr "処理が遅くなります, しかしメモリーを節約する演算です (通常は必要ないため,将来削除されます)  "
-#~ msgid "raster, color table"
-#~ msgid "Creates/modifies the color table associated with a raster map layer."
-#~ msgstr "ラスターマップ レイヤーのカラーテーブルを作成/編集します"
-#~ msgid "Raster map name from which to copy color table"
-#~ msgstr "カラーテーブルからコピーされるラスターマップ名"
-#~ msgid "Path to rules file (\"-\" to read rules from stdin)"
-#~ msgstr "ルールファイルへのパス (標準入力から読み込むときは \"-\" )"
-#~ msgid "Enter rules interactively"
-#~ msgstr "インタラクティブにルールを入力"
-#~ msgid "No raster map specified"
-#~ msgstr "ラスターマップが指定されていません"
-#~ msgid "One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be specified!"
-#~ msgstr "\"-i\" または \"-r\" フラッグか、\"color\"、\"rast\"、\"rules\" オプションの指定が必要です"
-#~ msgid "Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" options"
-#~ msgstr "対話モードでは \"color\"、\"rules\"、\"raster\"、オプションは使えません"
-#~ msgid "Unable to remove color table of raster map <%s>"
-#~ msgstr "ラスターマップ <%s> のカラーテーブルを削除できません"
-#~ msgid "Color table of raster map <%s> not found"
-#~ msgstr "ラスターマップ <%s> のカラーテーブルが見つかりません"
-#~ msgid "Color table 'random' is not supported for floating point raster map"
-#~ msgstr "カラーテーブル「ランダム」は,浮動小数のラスターマップではサポートされていません"
-#~ msgid "Color table 'grey.eq' is not supported for floating point raster map"
-#~ msgstr "カラーテーブル「グレイスケール」は浮動小数のラスターマップではサポートされていません"
-#~ msgid "Color table 'grey.log' is not supported for floating point raster map"
-#~ msgstr "色テーブル 'grey.log' は浮動小数点値ラスターマップではサポートされていません"
-#~ msgid "Color table for raster map <%s> set to '%s'"
-#~ msgstr "ラスターマップ <%s> のカラーテーブルが '%s' に設定されました"
-#~ msgid "Resultant raster map (not used with 'distribution')"
-#~ msgstr "結果のラスターマップ ('distribution' と同時に使用できません)"
-#~ msgid "Output map <%s> ignored"
-#~ msgstr "出力マップ <%s> は無視されました"
-#~ msgid "Not yet implemented!"
-#~ msgstr "まだ実装されていません!"
-#~ msgid "An output raster map needs to be defined with method '%s'"
-#~ msgstr "出力するラスタマップは指定方法 '%s'  に従う必要があります"
-#~ msgid "%s: running %s command"
-#~ msgstr "%s: 実行中の %s コマンド"
-#~ msgid "raster, landscape structure analysis, diversity index"
-#~ msgstr "ラスター,地形構造解析, 多様性インデックス"
-#~ msgid "raster, landscape structure analysis, dominance index"
-#~ msgstr "ラスター,地形構造解析,優先度インデックス"
-#~ msgid "CHILD[pid = %i] cannot open raster map"
-#~ msgstr "CHILD[pid = %i] がラスターマップを開けません"
-#~ msgid "CHILD[pid = %i] cannot open receive channel"
-#~ msgstr "CHILD[pid = %i] が受信チャンネルを開けません"
-#~ msgid "CHILD[pid = %i]: unable to open <%s> mask ... continuing without!"
-#~ msgstr "CHILD[pid = %i]: %s マスクを開けません、、、何もしません!!!  "
-#~ msgid ""
-#~ "\t\t\t\tAREA MESSAGE: \n"
-#~ " \t\t\t\taid = %i \n"
-#~ " \t\t\t\tx = %i \n"
-#~ " \t\t\t\ty = %i \n"
-#~ " \t\t\t\trl = %i \n"
-#~ " \t\t\t\tcl = %i \n"
-#~ msgstr ""
-#~ "\t\t\t\t エリア メッセージ: \n"
-#~ msgid ""
-#~ " \t\t\t\tMASKEDAREA MESSAGE: \n"
-#~ " \t\t\t\tmask = %s \n"
-#~ msgstr ""
-#~ " \t\t\t\t マスクエリア メッセージ: \n"
-#~ msgid ""
-#~ " \t\t\t\tDONE MESSAGE: \n"
-#~ " \t\t\t\tpid = %i \n"
-#~ " \t\t\t\tresult = %f \n"
-#~ msgstr ""
-#~ " \t\t\t\t 完了メッセージ: \n"
-#~ msgid ""
-#~ " \t\t\t\tERROR MESSAGE: \n"
-#~ msgstr ""
-#~ " \t\t\t\t エラー メッセージ: \n"
-#~ msgid ""
-#~ " \t\t\t\tTERM MESSAGE: \n"
-#~ msgstr ""
-#~ " \t\t\t\t ターミナル メッセージ: \n"
-#~ msgid "Error in pipe creation"
-#~ msgstr "パイプの作成エラー"
-#~ msgid "Error opening channel %i"
-#~ msgstr "エラー,チャンネル %i を開けません"
-#~ msgid "Cannot create %s/.r.li/ directory"
-#~ msgstr "%s/.r.li/ ディレクトリが作成出来ません"
-#~ msgid "Cannot create %s/.r.li/output/ directory"
-#~ msgstr "%s/.r.li/output/ ディレクトリが作成出来ません"
-#~ msgid "r.li.worker (pid %i) exited with abnormal status: %i"
-#~ msgstr "r.li.worker (pid %i) が異常状態 %i で終了"
-#~ msgid "r.li.worker (pid %i) terminated successfully"
-#~ msgstr "r.li.worker (pid %i) は終了しました"
-#~ msgid "Cannot close %s file (PIPE)"
-#~ msgstr "%s ファイル (PIPE) が閉じれません"
-#~ msgid "Cannot delete %s file (PIPE)"
-#~ msgstr " %s ファイル (PIPE)が削除出来ません"
-#~ msgid "Cannot close %s file (PIPE2)"
-#~ msgstr "%s ファイル (PIPE2) が閉じれません"
-#~ msgid "Cannot delete %s file (PIPE2)"
-#~ msgstr "%s ファイル (PIPE2) を削除できません"
-#~ msgid "Cannot close receive channel file"
-#~ msgstr "受信チャンネルファイルを閉じることができません"
-#~ msgid "Cannot delete %s file"
-#~ msgstr "%s ファイルを消去できません"
-#~ msgid "Cannot read raster header file"
-#~ msgstr "ラスターヘッダーファイルを読み込めません"
-#~ msgid "GIS format to write (case sensitive, see also -l flag)"
-#~ msgstr "書き出すGISフォーマット(大文字小文字を区別、 -l フラッグの説明を参照)"
-#~ msgid "File type"
-#~ msgstr "ファイルタイプ"
-#~ msgid "Checking GDAL data type and nodata value"
-#~ msgstr "GDAlデータタイプとデータ無しの値を確認中"
-#~ msgid "Output file name not specified"
-#~ msgstr "出力ファイル名が指定されていません"
-#~ msgid "Exporting to GDAL raster"
-#~ msgstr "GDALラスターにエクスポート: %s"
-#~ msgid "Range to be exported: %f - %f"
-#~ msgstr "エクスポートされる領域: %f - %f"
-#~ msgid "Input raster map contains cells with NULL-value (no-data). The value %f will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
-#~ msgstr "入力したラスターマップはNULL値(データ無し)セルを含んでいます.この指定されたマップで値 %f はデータ無し値を示します.%s パラメーターでデータ無し値を指定できます"
-#~ msgid "raster, null data"
-#~ msgstr "ラスター、NULLデータ "
-#~ msgid "Name of raster map for which to edit null file"
-#~ msgstr "NULLファイルを編集するためのラスターマップ"
-#~ msgid "Error writing null row %d"
-#~ msgstr "NULL行l row %d の書出し中にエラー"
-#~ msgid "raster, export, VRML"
-#~ msgstr "ラスター、エクスポート、VRML"
-#~ msgid "Export a raster map to the Virtual Reality Modeling Language (VRML)"
-#~ msgstr "ラスターマップをVRML(Virtual Reality Modeling Language)へエクスポート"
-#~ msgid "Rowio_setup failed"
-#~ msgstr "Rowio_setup に失敗しました"
-#~ msgid "Rowio_get failed"
-#~ msgstr "Rowio_get に失敗しました"
-#~ msgid "Unable to open raster map <%s@%s>"
-#~ msgstr "ラスターマップ <%s@%s> を開けません"
-#~ msgid "Failed writing raster map row"
-#~ msgstr "ラスターマップの行を書き込めません"
-#~ msgid "Generates a raster map layer of distance to features in input layer."
-#~ msgstr "指定レイヤーで,フィーチャーへの距離のラスターマップレイヤーを作成"
-#~ msgid "Unable to create distance map <%s>"
-#~ msgstr "距離マップ <%s> が作成できません"
-#~ msgid "Unable to create value map <%s>"
-#~ msgstr "値マップ <%s> が作成せきません"
-#~ msgid "(i)   Basin map created by r.water.outlet (MASK)"
-#~ msgstr "(i)   r.water.outlet (MASK) で作成された盆地マップ"
-#~ msgid "(i)   Elevation map"
-#~ msgstr "(i)   標高マップ"
-#~ msgid "(o)   Depressionless elevation map"
-#~ msgstr "(o)   凹みのない標高マップ  "
-#~ msgid "(o)   Direction map for depressionless elevation map"
-#~ msgstr "(o)   凹みのない標高マップの方向マップ"
-#~ msgid "(o/i) Basin elevation map (MASK applied)"
-#~ msgstr "(o/i) 盆地標高マップ (MASK を適用)  "
-#~ msgid "(o)   Topographic index ln(a/tanB) map (MASK applied)"
-#~ msgstr "(o)   地形学的インデックス ln(a/tanB) マップ (MASK 適用)  "
-#~ msgid "(i)   Number of topographic index classes"
-#~ msgstr "(i)   地形学的インデックスクラス数"
-#~ msgid "(o/i) Topographic index statistics file"
-#~ msgstr "(o/i) 地形学的インデックス統計ファイル  "
-#~ msgid "(i)   TOPMODEL Parameters file"
-#~ msgstr "(i)   TOPMODEL パラメーターファイル"
-#~ msgid "(i)   Rainfall and potential evapotranspiration data file"
-#~ msgstr "(i)   降雨と蒸発散位データ ファイル  "
-#~ msgid "(o)   Output file"
-#~ msgstr "(o)   出力ファイル"
-#~ msgid "(i)   OPTIONAL Observed flow file"
-#~ msgstr "(i)   任意: 実測流量ファイル  "
-#~ msgid "(i)   OPTIONAL Output for given time step"
-#~ msgstr "(i)   任意: 指定された時間ステップの出力"
-#~ msgid "(i)   OPTIONAL Output for given topographic index class"
-#~ msgstr "(i)   任意: 指定された地形学的インデックスクラスの出力"
-#~ msgid "raster, sun position"
-#~ msgid "Verbose output (also print out sun position etc.)"
-#~ msgstr "詳細を出力する (太陽の位置等も出力する)  "
-#~ msgid "raster, random, surface"
-#~ msgid "Unable to write color table for raster map <%s>"
-#~ msgstr "ラスターマップにカラーテーブル名が書き込めません<%s>"
-#~ msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default: random)"
-#~ msgstr "乱数のシード (SEED_MIN >= value >= SEED_MAX) (デフォルト: random)"
-#~ msgid "<%s> is an ilegal name"
-#~ msgstr "<%s> は不正なファイル名です"
-#~ msgid "raster, thin"
-#~ msgid "Thins non-zero cells that denote linear features in a raster map."
-#~ msgstr "ラスターマップレイヤーにおける線型フィーチャを表示するノンゼロセルを細線化します"
-#~ msgid "%s: Error reading from raster map <%s> in mapset <%s>"
-#~ msgstr "%s: マップセット <%s>のラスターマップ <%s> から読み込み中のエラー"
-#~ msgid "Creates a new map layer whose category values are based upon a reclassification of the categories in an existing raster map layer."
-#~ msgstr "存在するラスターマップレイヤーのカテゴリー再分類に基づくカテゴリー値の新しいマップレイヤー作成します"
-#~ msgid "Raster map to be reclassified"
-#~ msgstr "再分類されるラスターマップ"
-#~ msgid "fp: Data range is %.25f to %.25f\n"
-#~ msgstr "fp: データ範囲は %.25f から %.25f までです\n"
-#~ msgid "Cannot create category file of <%s>"
-#~ msgstr "<%s> のカテゴリーファイルを作成できません "
-#~ msgid "raster, metadata, timestamp"
-#~ msgid "raster, conversion, vectorization"
-#~ msgstr "ラスター,ベクトル,可視化"
-#~ msgid "Converts a raster map into a vector map layer."
-#~ msgstr "ラスターマップをベクトルマップレイヤーに変換します. "
-#~ msgid "Write raster values as z coordinate. Table is not created. Currently supported only for points."
-#~ msgstr "ラスタ値をz座標として書き込む. テーブルは作成されていません. 現在はポイントのみサポートされています.  "
-#~ msgid "Do not build vector topology (use with care for massive point export)"
-#~ msgstr "ベクトルトポロジーを作成しない(大量ポイント出力に使用)  "
-#~ msgid "Quiet - Do not show progress"
-#~ msgstr "Quiet - 進行を表示しません"
-#~ msgid "raster, category"
-#~ msgstr "ラスター、再コードカテゴリー"
-#~ msgid "Cannot create category file for <%s>"
-#~ msgstr " <%s> のカテゴリーファイルを作成できません "
-#~ msgid "Cannot read header of raster map <%s> in <%s>"
-#~ msgstr "<%s> におけるラスターマップ <%s> のヘッダーを読めません "
-#~ msgid "Cannot open cell file of raster map <%s> in <%s>"
-#~ msgstr "<%s> におけるラスターマップ <%s> のセルファイルを開けません"
-#~ msgid "Illegal output file name <%s>"
-#~ msgstr "不正な出力ファイル名 <%s>"
-#~ msgid "GIS Coincidence Tabulation Facility\n"
-#~ msgstr "GISコインシデンス作表設備\n"
-#~ msgid "This utility will allow you to compare the coincidence of two map layers\n"
-#~ msgstr "このユーティリティーで2つのマップレイヤーの一致を比較できます\n"
-#~ msgid "The report can be made in one of 8 units."
-#~ msgstr "レポートは8ユニットのうちの1つを用いて作成可能です "
-#~ msgid "Please choose a unit by entering one of the following letter codes:"
-#~ msgstr "次の文字コードを入力しユニットを選択してください:  "
-#~ msgid "     'c': cells"
-#~ msgstr "     'c': セル"
-#~ msgid "     'p': percent cover of region"
-#~ msgstr "     'p': 領域リージョンのパーセントカバー"
-#~ msgid "     'x': percent of '%s' category (column)"
-#~ msgstr "     'x': '%s' カテゴリーのパーセント (列)  "
-#~ msgid "     'y': percent of '%s' category (row)"
-#~ msgstr "     'y': '%s' カテゴリーのパーセント (行)  "
-#~ msgid "     'a': acres"
-#~ msgstr "     'a': エーカー"
-#~ msgid "     'h': hectares"
-#~ msgstr "     'h': ヘクタール"
-#~ msgid "     'k': square kilometers"
-#~ msgstr "     'k': 平方キロメートル"
-#~ msgid "     'm': square miles\n"
-#~ msgstr "     'm': 平方マイル\n"
-#~ msgid "     'Q': quit"
-#~ msgstr "     'Q': 中止"
-#~ msgid "Do you wish to save this report in a file? (y/n) [n] "
-#~ msgstr "ファイルにこのレポートを保存しますか? (はい/いいえ) [いいえ]   "
-#~ msgid ""
-#~ "Enter the file name or path\n"
-#~ msgstr ""
-#~ "ファイル名またはパスを入力してください\n"
-#~ msgid "%s' being saved\n"
-#~ msgstr "%s' が保存されています\n"
-#~ msgid "Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
-#~ msgstr "このレポートを出力しますか (UNIX lpr コマンドを必要とします)? (y/n) [n]   "
-#~ msgid ""
-#~ "Do you wish it printed in 80 or 132 columns?\n"
-#~ msgstr ""
-#~ "80 または 132 列で出力しますか?\n"
-#~ msgid "Do you wish to run this report with a different unit of measure? (y/n) [y] "
-#~ msgstr "このレポートを別の計測単位で実行しますか? (y/n) [y]   "
-#~ msgid "Watershed basin creation program."
-#~ msgstr "流域作成プログラム."
-#~ msgid "The map E grid coordinates"
-#~ msgstr "マップEグリッド座標"
-#~ msgid "The map N grid coordinates"
-#~ msgstr "マップNグリッド座標"
-#~ msgid "Unable to open drainage pointer map"
-#~ msgstr "排水路ポインターマップを開けません"
-#~ msgid "Unable to open new basin map"
-#~ msgstr "新しい盆地マップを開けません"
-#~ msgid "Unable to close new basin map layer"
-#~ msgstr "新しい盆地マップレイヤーを閉じれません"
-#~ msgid "Could not read east bufferzone size. Aborting."
-#~ msgstr "東の緩衝地帯を読み込めません. 中断しています"
-#~ msgid "Could not read west bufferzone size. Aborting."
-#~ msgstr "西の緩衝地帯を読み込めませんでした. 中断しています"
-#~ msgid "Could not read south bufferzone size. Aborting."
-#~ msgstr "南の緩衝地帯をよみこめませんでした. 中断しています"
-#~ msgid "Could not read north bufferzone size. Aborting."
-#~ msgstr "北の緩衝地帯を読み込めませんでした. 中断しています"
-#~ msgid "Calculating map %01d of %01d (angle %lf, raster map <%s>)"
-#~ msgstr " %01dのマップ %01d を計算しています (角度 %lf, ラスターマップ <%s>)"
-#~ msgid "Unable to write quant file"
-#~ msgstr "定量ファイルを書き込めません"
-#~ msgid "Link GDAL supported raster file to a binary raster map layer."
-#~ msgstr "GDALサポートされているラスターファイルをバイナリラスターマップレイヤーにリンクします"
-#~ msgid "Raster file to be linked"
-#~ msgstr "リンクするラスターファイル"
-#~ msgid "input= and source= are mutually exclusive"
-#~ msgstr "入力= そしてソース= は相互排他的です"
-#~ msgid "Error reading input"
-#~ msgstr "入力読み込みのエラー"
-#~ msgid "raster, recode category"
-#~ msgid "Data range of raster map <%s> is empty"
-#~ msgstr "ラスターマップ <%s> のデータ範囲は空です"
-#~ msgid "Data range of raster map <%s> is %s to %s (entire map)"
-#~ msgstr "ラスターマップ <%s> の範囲は %s から %s です(全マップ)"
-#~ msgid "Unable to read range of raster map <%s>"
-#~ msgstr "ラスターマップ <%s> の範囲を読み込めません"
-#~ msgid "Integer data range of raster map <%s> is empty"
-#~ msgstr "ラスターマップ <%s> の整数データ範囲は空です"
-#~ msgid "Integer data range of raster mao <%s> is %d to %d"
-#~ msgstr "ラスターマップ <%s> の整数データ範囲は %d から %d です"
-#~ msgid "%s' is not a valid rule"
-#~ msgstr "%s' は有効なルールではありません"
-#~ msgid "raster, volume"
-#~ msgstr "ラスター値"
-#~ msgid "No clump map specified and MASK not set."
-#~ msgstr "クランプマップやMASKは設定されていません.  "
-#~ msgid "Unable to find data map"
-#~ msgstr "データマップを見つけられません"
-#~ msgid "Unable to find clump map"
-#~ msgstr "クランプマップが見つかりません"
-#~ msgid "Data or Clump file not open"
-#~ msgstr "データまたはクランプファイルを開けません"
-#~ msgid "raster, distance"
-#~ msgid "Name of vector input map containing stream(s)"
-#~ msgstr "小川を含むベクトル入力マップ名"
-#~ msgid "Stream width (in meters). Default is raster cell width"
-#~ msgstr "水流幅 (メートル). デフォルトはラスターセル幅です  "
-#~ msgid "%s: cover raster map not found"
-#~ msgstr "%s: カバーラスターマップはみつかりませんでした"
-#~ msgid "%s: base map and output map must be different"
-#~ msgstr "%s: ベースマップと出力マップは別々でなければなりません"
-#~ msgid "Reports statistics for raster map layers."
-#~ msgstr "ラスターマップレイヤーの統計値を報告します"
-#~ msgid "Name of an output file to hold the report"
-#~ msgstr "レポートを保有する出力ファイルの名前"
-#~ msgid "raster, composite"
-#~ msgstr "ラスター、複合物"
-#~ msgid "Error reading raster map <%s>"
-#~ msgstr "ラスターマップ <%s> 読み込みのエラー"
-#~ msgid "Failed writing raster map <%s>"
-#~ msgstr "ラスターマップ <%s> の書き込みは失敗しました"
-#~ msgid "Use G3D mask (if exists) with output map"
-#~ msgstr "出力マップとともにG3Dマスク(もしあれば)を使用してください"
-#~ msgid "Could not get raster row"
-#~ msgstr "ラスター行を取得できませんでした"
-#~ msgid "raster, volume, conversion"
-#~ msgstr "ラスター, ボリューム, 換算"
-#~ msgid "Cell file not found"
-#~ msgstr "セルファイルは見つかりません"
-#~ msgid "Unable to get current region"
-#~ msgstr "現在の領域を取得できません"
-#~ msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)."
-#~ msgstr "傾斜カーブの建築(フローライン)、フローパスの長さ、そしてラスターデジタル標高モデル(DEM)からのフローライン密度(上り坂エリア) "
-#~ msgid "Input elevation raster map"
-#~ msgstr "入力標高ラスターマップ"
-#~ msgid "Input aspect raster map"
-#~ msgstr "入力方位ラスターマップ"
-#~ msgid "Input barrier raster map"
-#~ msgstr "入力バリアーラスターマップ"
-#~ msgid "Output flowline vector map"
-#~ msgstr "出力フローラインベクトルマップ"
-#~ msgid "Outpu
