[GRASS-SVN] r51862 - grass/trunk/locale/po
Tue May 29 02:28:23 PDT 2012
Author: neteler
Date: 2012-05-29 02:28:22 -0700 (Tue, 29 May 2012)
New Revision: 51862
Removed:
   grass/trunk/locale/po/grasslibs_hi.po
   grass/trunk/locale/po/grasslibs_mr.po
   grass/trunk/locale/po/grassmods_hi.po
   grass/trunk/locale/po/grassmods_mr.po
delete untranslated files
Deleted: grass/trunk/locale/po/grasslibs_hi.po
--- grass/trunk/locale/po/grasslibs_hi.po	2012-05-29 07:08:35 UTC (rev 51861)
+++ grass/trunk/locale/po/grasslibs_hi.po	2012-05-29 09:28:22 UTC (rev 51862)
@@ -1,8309 +0,0 @@
-# translation of grasslibs_hi.po to Hindi
-# This file is distributed under the same license as the GRASS package.
-# Copyright (C) 2005, GRASS Development Team
-# Markus Neteler <neteler at itc.it>, 2005.
-msgid ""
-msgstr ""
-"Project-Id-Version: grasslibs_hi\n"
-"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2012-01-28 11:12+0100\n"
-"PO-Revision-Date: 2005-12-22 14:34+0100\n"
-"Last-Translator: Markus Neteler <neteler at itc.it>\n"
-"Language-Team: Hindi <grass-translations at lists.osgeo.org>\n"
-"Language: hi\n"
-"MIME-Version: 1.0\n"
-"Content-Type: text/plain; charset=UTF-8\n"
-"Content-Transfer-Encoding: 8bit\n"
-"X-Generator: KBabel 1.9.1\n"
-#: ../lib/nviz/render.c:104
-msgid "Bad server connection"
-msgstr ""
-#: ../lib/nviz/render.c:113
-#, fuzzy
-msgid "Unable to create rendering context"
-msgstr "a"
-#: ../lib/nviz/position.c:56
-#, fuzzy
-msgid "Unable to set focus"
-msgstr "का"
-#: ../lib/nviz/map_obj.c:59
-msgid "Maximum surfaces loaded!"
-msgstr ""
-#: ../lib/nviz/map_obj.c:88
-msgid "Maximum vector line maps loaded!"
-msgstr ""
-#: ../lib/nviz/map_obj.c:97 ../lib/nviz/map_obj.c:128
-#, fuzzy, c-format
-msgid "Error loading vector map <%s>"
-msgstr "के लिए"
-#: ../lib/nviz/map_obj.c:116
-msgid "Maximum vector point maps loaded!"
-msgstr ""
-#: ../lib/nviz/map_obj.c:143
-msgid "Maximum volumes loaded!"
-msgstr ""
-#: ../lib/nviz/map_obj.c:152
-#, fuzzy, c-format
-msgid "Error loading 3d raster map <%s>"
-msgstr "के लिए"
-#: ../lib/nviz/map_obj.c:160
-msgid "Nviz_new_map_obj(): unsupported data type"
-msgstr ""
-#: ../lib/nviz/nviz.c:128
-#, c-format
-msgid "Invalid color (%s), using \"white\" as default"
-msgstr ""
-#: ../lib/nviz/lights.c:171
-#, fuzzy
-msgid "Unable to define new light"
-msgstr "का"
-#: ../lib/symbol/read.c:211
-#, c-format
-msgid "Cannot read symbol line coordinates: %s"
-msgstr ""
-#: ../lib/symbol/read.c:260
-#, c-format
-msgid "Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
-msgstr ""
-#: ../lib/symbol/read.c:284
-#, c-format
-msgid "Cannot find/open symbol: '%s'"
-msgstr ""
-#: ../lib/symbol/read.c:389 ../lib/symbol/read.c:407 ../lib/symbol/read.c:417
-#: ../lib/symbol/read.c:435
-#, c-format
-msgid "Incorrect symbol color: '%s', using default."
-msgstr ""
-#: ../lib/htmldriver/Graph_Set.c:97
-#, fuzzy, c-format
-msgid "html: collecting to file '%s'"
-msgstr "नहीं"
-#: ../lib/htmldriver/Graph_Set.c:98
-#, c-format
-msgid "html: image size %dx%d"
-msgstr ""
-#: ../lib/htmldriver/Graph_Set.c:111 ../lib/htmldriver/Graph_Set.c:115
-#: ../lib/htmldriver/Graph_Set.c:119
-#, c-format
-msgid "html: type '%s'"
-msgstr ""
-#: ../lib/sites/sites.c:106
-#, fuzzy, c-format
-msgid "Attributes for category %d not found"
-msgstr "के लिए नहीं"
-#: ../lib/sites/sites.c:151
-msgid "Category must be integer"
-msgstr ""
-#: ../lib/sites/sites.c:226
-msgid "Memory error in writing timestamp"
-msgstr ""
-#: ../lib/sites/sites.c:228
-msgid "Illegal TimeStamp string"
-msgstr ""
-#: ../lib/sites/sites.c:255 ../lib/sites/sites.c:385
-msgid "Dev note: Adapted sites library used for vector points. (module should be updated to GRASS 6 vector library)"
-msgstr ""
-#: ../lib/sites/sites.c:279 ../lib/ogsf/Gv3.c:342 ../lib/ogsf/Gp3.c:206
-#: ../lib/vector/neta/utils.c:119 ../lib/vector/neta/timetables.c:133
-#: ../lib/vector/Vlib/map.c:367 ../lib/vector/Vlib/map.c:506
-#: ../lib/vector/Vlib/map.c:728 ../lib/vector/Vlib/net.c:180
-#: ../lib/vector/Vlib/net.c:351 ../lib/vector/Vlib/open_ogr.c:425
-#: ../lib/vector/Vlib/array.c:282 ../lib/vector/Vlib/ascii.c:355
-#: ../lib/rst/interp_float/vinput2d.c:88 ../lib/db/dbmi_client/db.c:46
-#: ../lib/db/dbmi_client/copy_tab.c:112 ../lib/db/dbmi_client/copy_tab.c:133
-#, fuzzy, c-format
-msgid "Unable to open database <%s> by driver <%s>"
-msgstr "के लिए"
-#: ../lib/sites/sites.c:288 ../lib/vector/Vlib/open_ogr.c:438
-#: ../lib/db/dbmi_client/copy_tab.c:218 ../lib/db/dbmi_client/copy_tab.c:295
-#: ../lib/db/dbmi_client/table.c:110
-#, fuzzy, c-format
-msgid "Unable to open select cursor: '%s'"
-msgstr "के लिए"
-#: ../lib/sites/sites.c:304
-#, fuzzy
-msgid "Cannot fetch row"
-msgstr "के लिए n"
-#: ../lib/sites/sites.c:440
-msgid "G_oldsite_new_struct: invalid # dims or fields"
-msgstr ""
-#: ../lib/sites/sites.c:668
-msgid "G_oldsite_describe() must be called immediately after G_fopen_sites_old()."
-msgstr ""
-#: ../lib/ogsf/gsd_label.c:58
-msgid "Max. number of labels reached!"
-msgstr ""
-#: ../lib/ogsf/gk.c:320
-msgid "Need at least 3 keyframes for spline"
-msgstr ""
-#: ../lib/ogsf/gk.c:622
-msgid "Need at least 2 keyframes for interpolation"
-msgstr ""
-#: ../lib/ogsf/GS2.c:1212
-#, c-format
-msgid "no category info"
-msgstr ""
-#: ../lib/ogsf/GS2.c:1231
-#, c-format
-msgid "no data"
-msgstr ""
-#: ../lib/ogsf/GS2.c:1656
-#, fuzzy, c-format
-msgid "Raster map <%s> is outside of current region. Load failed."
-msgstr "है नहीं."
-#: ../lib/ogsf/GS2.c:1734 ../lib/ogsf/GS2.c:1740 ../lib/ogsf/GS2.c:1748
-#: ../lib/ogsf/GS2.c:1757 ../lib/ogsf/GS2.c:1765 ../lib/ogsf/GS2.c:1775
-#: ../lib/ogsf/GS2.c:1823
-msgid "GS_load_att_map(): Out of memory. Unable to load map"
-msgstr ""
-#: ../lib/ogsf/GS2.c:1851
-#, fuzzy
-msgid "Loading failed"
-msgstr "n"
-#: ../lib/ogsf/GS2.c:1855
-msgid "Error finding range"
-msgstr ""
-#: ../lib/ogsf/Gvl3.c:40 ../lib/ogsf/gvl_file.c:427
-#: ../lib/manage/do_remove.c:78 ../lib/manage/do_rename.c:76
-#: ../lib/gpde/N_arrays_io.c:273
-#, fuzzy, c-format
-msgid "3D raster map <%s> not found"
-msgstr "नहीं"
-#: ../lib/ogsf/gs_bm.c:124
-msgid "Bitmap mismatch"
-msgstr ""
-#: ../lib/ogsf/Gv3.c:60 ../lib/ogsf/Gv3.c:325 ../lib/ogsf/Gp3.c:56
-#: ../lib/ogsf/Gp3.c:189 ../lib/manage/do_remove.c:57
-#: ../lib/manage/do_rename.c:54 ../lib/vector/Vlib/legal_vname.c:121
-#: ../lib/vector/Vlib/legal_vname.c:124 ../lib/vector/Vlib/map.c:429
-#: ../lib/vector/Vlib/open.c:202
-#, fuzzy, c-format
-msgid "Vector map <%s> not found"
-msgstr "नहीं"
-#: ../lib/ogsf/Gv3.c:66 ../lib/ogsf/Gv3.c:330 ../lib/ogsf/Gp3.c:62
-#: ../lib/ogsf/Gp3.c:194 ../lib/vector/Vlib/open.c:240
-#, fuzzy, c-format
-msgid "Unable to open vector map <%s>"
-msgstr "के लिए"
-#: ../lib/ogsf/Gv3.c:261
-#, c-format
-msgid "No features from vector map <%s> fall within current region"
-msgstr ""
-#: ../lib/ogsf/Gv3.c:266
-#, fuzzy, c-format
-msgid "Vector map <%s> loaded (%d features)"
-msgstr "नहीं"
-#: ../lib/ogsf/Gv3.c:336 ../lib/ogsf/Gp3.c:200 ../lib/vector/Vlib/map.c:338
-#: ../lib/vector/Vlib/map.c:465 ../lib/vector/Vlib/map.c:577
-#: ../lib/vector/Vlib/map.c:695 ../lib/vector/Vlib/map.c:793
-#: ../lib/vector/Vlib/net.c:174 ../lib/vector/Vlib/net.c:346
-#: ../lib/vector/Vlib/array.c:276 ../lib/vector/Vlib/ascii.c:343
-#: ../lib/rst/interp_float/vinput2d.c:79
-#, c-format
-msgid "Database connection not defined for layer %d"
-msgstr ""
-#: ../lib/ogsf/Gv3.c:345
-#, fuzzy, c-format
-msgid "Loading thematic vector layer <%s>..."
-msgstr "है"
-#: ../lib/ogsf/Gv3.c:369 ../lib/ogsf/Gp3.c:233
-#, fuzzy, c-format
-msgid "No color rule defined for category %d"
-msgstr "के लिए"
-#: ../lib/ogsf/Gv3.c:384 ../lib/ogsf/Gp3.c:247
-#, c-format
-msgid "Invalid color definition (%s)"
-msgstr ""
-#: ../lib/ogsf/Gv3.c:406
-#, c-format
-msgid "%d features without category. Unable to determine color rules for features without category."
-msgstr ""
-#: ../lib/ogsf/Gp3.c:92 ../lib/vector/Vlib/map.c:87
-#: ../lib/vector/Vlib/map.c:166
-#, fuzzy, c-format
-msgid "Unable to read vector map <%s>"
-msgstr "के लिए"
-#: ../lib/ogsf/Gp3.c:146
-#, c-format
-msgid "No points from vector map <%s> fall within current region"
-msgstr ""
-#: ../lib/ogsf/Gp3.c:151
-#, fuzzy, c-format
-msgid "Vector map <%s> loaded (%d points)"
-msgstr "नहीं"
-#: ../lib/ogsf/Gp3.c:209
-#, fuzzy, c-format
-msgid "Loading thematic points layer <%s>..."
-msgstr "है"
-#: ../lib/ogsf/Gp3.c:286
-#, c-format
-msgid "%d points without category. Unable to determine color rules for features without category."
-msgstr ""
-#: ../lib/ogsf/gsd_prim.c:146
-#, c-format
-msgid "Color Material: %d"
-msgstr ""
-#: ../lib/ogsf/gsd_prim.c:630
-#, c-format
-msgid "gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please advise GRASS developers of this error"
-msgstr ""
-#: ../lib/ogsf/gsd_img_tif.c:64 ../lib/ogsf/GK2.c:216
-#: ../lib/ogsf/gsd_img_ppm.c:52 ../lib/ogsf/gsd_img_ppm.c:95
-#, fuzzy, c-format
-msgid "Unable to open file <%s> for writing"
-msgstr "के लिए"
-#: ../lib/ogsf/trans.c:180
-msgid "Out of matrix stack space"
-msgstr ""
-#: ../lib/ogsf/trans.c:200
-msgid "Tried to pop an empty stack"
-msgstr ""
-#: ../lib/ogsf/gsd_surf.c:1742
-msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
-msgstr ""
-#: ../lib/ogsf/gsdrape.c:207
-#, fuzzy
-msgid "Unable to process vector map - out of memory"
-msgstr "के लिए"
-#: ../lib/ogsf/gsd_img_mpeg.c:62
-#, fuzzy
-msgid "Unable to allocate stream"
-msgstr "n"
-#: ../lib/ogsf/gsd_img_mpeg.c:155
-#, fuzzy
-msgid "Video codec not found"
-msgstr "नहीं"
-#: ../lib/ogsf/gsd_img_mpeg.c:161
-#, fuzzy
-msgid "Unable to open codec"
-msgstr "के लिए"
-#: ../lib/ogsf/gsd_img_mpeg.c:180
-#, fuzzy
-msgid "Unable to allocate picture"
-msgstr "n"
-#: ../lib/ogsf/gsd_img_mpeg.c:191
-#, fuzzy
-msgid "Unable to allocate temporary picture"
-msgstr "n"
-#: ../lib/ogsf/gsd_img_mpeg.c:251
-#, fuzzy
-msgid "Error while writing video frame"
-msgstr "त्रुटि n"
-#: ../lib/ogsf/gsd_img_mpeg.c:297
-#, c-format
-msgid "Opening MPEG stream <%s>..."
-msgstr ""
-#: ../lib/ogsf/gsd_img_mpeg.c:305
-msgid "Unable to deduce output format from file extension: using MPEG"
-msgstr ""
-#: ../lib/ogsf/gsd_img_mpeg.c:309
-#, fuzzy
-msgid "Unable to find suitable output format"
-msgstr "के लिए"
-#: ../lib/ogsf/gsd_img_mpeg.c:316 ../lib/rowio/setup.c:61
-#: ../lib/rowio/setup.c:67 ../lib/vector/neta/centrality.c:63
-#: ../lib/vector/neta/centrality.c:145 ../lib/vector/neta/path.c:134
-#: ../lib/vector/neta/components.c:46 ../lib/vector/neta/components.c:113
-#: ../lib/vector/neta/bridge.c:59 ../lib/vector/neta/flow.c:64
-#: ../lib/vector/neta/flow.c:178 ../lib/vector/neta/timetables.c:69
-#: ../lib/vector/neta/timetables.c:168 ../lib/vector/neta/timetables.c:178
-#: ../lib/vector/neta/timetables.c:191 ../lib/vector/neta/timetables.c:278
-#: ../lib/vector/neta/timetables.c:413 ../lib/vector/neta/timetables.c:425
-#: ../lib/vector/neta/allpairs.c:50 ../lib/vector/neta/spanningtree.c:99
-#: ../lib/vector/neta/articulation_point.c:60 ../lib/vector/Vlib/line.c:48
-#: ../lib/vector/Vlib/ascii.c:201 ../lib/rst/interp_float/segmen2d.c:182
-#: ../lib/rst/interp_float/segmen2d.c:188
-#: ../lib/rst/interp_float/segmen2d.c:194
-#: ../lib/rst/interp_float/segmen2d.c:204
-#: ../lib/rst/interp_float/interp2d.c:121
-#: ../lib/rst/interp_float/interp2d.c:127
-msgid "Out of memory"
-msgstr ""
-#: ../lib/ogsf/gsd_img_mpeg.c:336
-#, fuzzy
-msgid "Invalid output format parameters"
-msgstr "के लिए"
-#: ../lib/ogsf/gsd_img_mpeg.c:350
-#, fuzzy, c-format
-msgid "Unable to open <%s>"
-msgstr "का"
-#: ../lib/ogsf/gsd_img_mpeg.c:360
-msgid "NVIZ has not been built with MPEG output support"
-msgstr ""
-#: ../lib/ogsf/GP2.c:705
-msgid "Unknown icon marker, using \"sphere\""
-msgstr ""
-#: ../lib/ogsf/gsd_legend.c:239 ../lib/ogsf/Gs3.c:125 ../lib/ogsf/Gs3.c:189
-#: ../lib/ogsf/Gs3.c:264 ../lib/ogsf/Gs3.c:336 ../lib/ogsf/Gs3.c:442
-#: ../lib/ogsf/Gs3.c:529 ../lib/ogsf/Gs3.c:588 ../lib/ogsf/Gs3.c:645
-#: ../lib/ogsf/Gs3.c:716 ../lib/ogsf/Gs3.c:786 ../lib/raster/open.c:175
-#: ../lib/raster/open.c:748 ../lib/raster/open.c:785 ../lib/raster/open.c:837
-#: ../lib/manage/do_remove.c:73 ../lib/manage/do_rename.c:71
-#: ../lib/rst/interp_float/output2d.c:236
-#: ../lib/rst/interp_float/output2d.c:317
-#: ../lib/rst/interp_float/output2d.c:386
-#: ../lib/rst/interp_float/output2d.c:436
-#: ../lib/rst/interp_float/output2d.c:450
-#: ../lib/rst/interp_float/output2d.c:464
-#: ../lib/rst/interp_float/output2d.c:480
-#: ../lib/rst/interp_float/resout2d.c:205
-#: ../lib/rst/interp_float/resout2d.c:253
-#: ../lib/rst/interp_float/resout2d.c:296
-#: ../lib/rst/interp_float/resout2d.c:327
-#: ../lib/rst/interp_float/resout2d.c:377
-#: ../lib/rst/interp_float/resout2d.c:395
-#: ../lib/rst/interp_float/resout2d.c:410
-#: ../lib/rst/interp_float/resout2d.c:426 ../lib/gis/legal_name.c:91
-#: ../lib/gis/legal_name.c:94
-#, fuzzy, c-format
-msgid "Raster map <%s> not found"
-msgstr "नहीं"
-#: ../lib/ogsf/gsd_legend.c:246
-#, fuzzy, c-format
-msgid "Unable to read color file of raster map <%s>"
-msgstr "के लिए"
-#: ../lib/ogsf/gsd_legend.c:252
-#, fuzzy, c-format
-msgid "Unable to read category file of raster map <%s>"
-msgstr "के लिए"
-#: ../lib/ogsf/gsd_legend.c:269
-#, fuzzy, c-format
-msgid "Unable to read fp range of raster map <%s>"
-msgstr "के लिए"
-#: ../lib/ogsf/gsd_legend.c:281
-#, fuzzy, c-format
-msgid "Unable to read range of raster map <%s>"
-msgstr "के लिए"
-#: ../lib/ogsf/gsd_legend.c:295
-msgid "Range request error for legend"
-msgstr ""
-#: ../lib/ogsf/gsd_legend.c:385
-#, fuzzy
-msgid "Unable to show discrete FP range (use list"
-msgstr "a"
-#: ../lib/ogsf/gsd_legend.c:501
-#, fuzzy
-msgid "Too many categories to show as discrete!"
-msgstr "के लिए"
-#: ../lib/ogsf/gsd_legend.c:503
-msgid "Try using smaller font!"
-msgstr ""
-#: ../lib/ogsf/gvl_file.c:103
-msgid "Maximum number of datafiles exceeded"
-msgstr ""
-#: ../lib/ogsf/gvl_file.c:436 ../lib/gpde/N_arrays_io.c:281
-#, fuzzy, c-format
-msgid "Unable to open 3D raster map <%s>"
-msgstr "के लिए"
-#: ../lib/ogsf/gvl_file.c:442
-#, fuzzy, c-format
-msgid "Unable to read range of 3D raster map <%s>"
-msgstr "के लिए"
-#: ../lib/ogsf/gvl_file.c:470 ../lib/raster3d/close.c:120
-#: ../lib/raster3d/close.c:130 ../lib/raster3d/close.c:159
-#, fuzzy, c-format
-msgid "Unable to close 3D raster map <%s>"
-msgstr "के लिए"
-#: ../lib/ogsf/GK2.c:272 ../lib/ogsf/GK2.c:285
-msgid "Check no. of frames requested and keyframes marked"
-msgstr ""
-#: ../lib/ogsf/Gs3.c:132 ../lib/ogsf/Gs3.c:196 ../lib/ogsf/Gs3.c:348
-#: ../lib/ogsf/Gs3.c:454 ../lib/ogsf/Gs3.c:540
-#, fuzzy, c-format
-msgid "Loading raster map <%s>..."
-msgstr "है"
-#: ../lib/ogsf/Gs3.c:596
-#, c-format
-msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
-msgstr ""
-#: ../lib/ogsf/Gs3.c:658 ../lib/ogsf/Gs3.c:730
-#, fuzzy, c-format
-msgid "Translating colors from raster map <%s>..."
-msgstr "के लिए"
-#: ../lib/ogsf/Gs3.c:967
-msgid "View not saved by this program,there may be some inconsistancies"
-msgstr ""
-#: ../lib/ogsf/gsds.c:109
-msgid "Maximum number of datasets exceeded"
-msgstr ""
-#: ../lib/ogsf/GVL2.c:267
-#, fuzzy, c-format
-msgid "Loading 3d raster map <%s>..."
-msgstr "है"
-#: ../lib/proj/convert.c:82 ../lib/vector/Vlib/build_ogr.c:485
-#: ../lib/vector/Vlib/open_ogr.c:129 ../lib/vector/Vlib/open_ogr.c:218
-#: ../lib/vector/Vlib/open_ogr.c:290 ../lib/vector/Vlib/open_ogr.c:392
-#: ../lib/vector/Vlib/rewind_ogr.c:43 ../lib/vector/Vlib/rewind_ogr.c:67
-#: ../lib/vector/Vlib/close_ogr.c:70 ../lib/vector/Vlib/close_ogr.c:144
-#: ../lib/vector/Vlib/field.c:584 ../lib/vector/Vlib/read_ogr.c:242
-#: ../lib/vector/Vlib/read_ogr.c:339 ../lib/vector/Vlib/read_ogr.c:553
-#: ../lib/vector/Vlib/read_ogr.c:624 ../lib/vector/Vlib/write_ogr.c:274
-#: ../lib/vector/Vlib/write_ogr.c:360 ../lib/vector/Vlib/write_ogr.c:394
-#: ../lib/vector/Vlib/write_ogr.c:425 ../lib/vector/Vlib/write_ogr.c:457
-#: ../lib/vector/Vlib/write_ogr.c:538
-msgid "GRASS is not compiled with OGR support"
-msgstr ""
-#: ../lib/proj/convert.c:120
-msgid "Unable parse GRASS PROJ_INFO file"
-msgstr ""
-#: ../lib/proj/convert.c:125
-msgid "Unable get PROJ.4-style parameter string"
-msgstr ""
-#: ../lib/proj/convert.c:139
-#, c-format
-msgid "OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
-msgstr ""
-#: ../lib/proj/convert.c:146
-#, c-format
-msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
-msgstr ""
-#: ../lib/proj/convert.c:406
-msgid "No projection name! Projection parameters likely to be meaningless."
-msgstr ""
-#: ../lib/proj/convert.c:442
-#, c-format
-msgid "Datum <%s> not recognised by GRASS and no parameters found"
-msgstr ""
-#: ../lib/proj/convert.c:458
-#, c-format
-msgid "Datum <%s> apparently recognised by GRASS but no parameters found. You may want to look into this."
-msgstr ""
-#: ../lib/proj/convert.c:462
-#, c-format
-msgid "Invalid transformation number %d; valid range is 1 to %d. Leaving datum transform parameters unspecified."
-msgstr ""
-#: ../lib/proj/datum.c:270 ../lib/proj/datum.c:350
-#, fuzzy, c-format
-msgid "Unable to open datum table file <%s>"
-msgstr "का"
-#: ../lib/proj/datum.c:283 ../lib/proj/datum.c:364
-#, fuzzy, c-format
-msgid "Error in datum table file <%s>, line %d"
-msgstr "त्रुटि"
-#: ../lib/proj/get_proj.c:148
-#, fuzzy, c-format
-msgid "Invalid zone %s specified"
-msgstr "अवैध"
-#: ../lib/proj/get_proj.c:228
-msgid "Unable to initialise PROJ.4 with the following parameter list:"
-msgstr ""
-#: ../lib/proj/get_proj.c:236
-#, c-format
-msgid "The error message: %s"
-msgstr ""
-#: ../lib/proj/get_proj.c:294
-msgid "Option input overflowed option table"
-msgstr ""
-#: ../lib/proj/get_proj.c:325
-#, fuzzy, c-format
-msgid "Unable to initialize pj cause: %s"
-msgstr "का"
-#: ../lib/proj/get_proj.c:401
-msgid "Input Projection Parameters"
-msgstr ""
-#: ../lib/proj/get_proj.c:404
-msgid "Input Unit Factor"
-msgstr ""
-#: ../lib/proj/get_proj.c:414
-msgid "Output Projection Parameters"
-msgstr ""
-#: ../lib/proj/get_proj.c:417
-msgid "Output Unit Factor"
-msgstr ""
-#: ../lib/proj/do_proj.c:106 ../lib/proj/do_proj.c:180
-#, c-format
-msgid "pj_transform() failed: %s"
-msgstr ""
-#: ../lib/proj/ellipse.c:76
-#, fuzzy, c-format
-msgid "Invalid ellipsoid <%s> in file"
-msgstr "अवैध"
-#: ../lib/proj/ellipse.c:100
-msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
-msgstr ""
-#: ../lib/proj/ellipse.c:104
-#, fuzzy
-msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
-msgstr "अवैध"
-#: ../lib/proj/ellipse.c:117
-#, fuzzy
-msgid "No ellipsoid info given in file"
-msgstr "नहीं"
-#: ../lib/proj/ellipse.c:217 ../lib/gis/get_ellipse.c:263
-#, fuzzy, c-format
-msgid "Unable to open ellipsoid table file <%s>"
-msgstr "का"
-#: ../lib/proj/ellipse.c:270 ../lib/gis/get_ellipse.c:322
-#, fuzzy, c-format
-msgid "Line%s of ellipsoid table file <%s> is invalid"
-msgstr "का है अवैध"
-#: ../lib/proj/ellipse.c:271 ../lib/gis/get_ellipse.c:321
-#, fuzzy, c-format
-msgid "Lines%s of ellipsoid table file <%s> are invalid"
-msgstr "का अवैध"
-#: ../lib/raster3d/range.c:76
-#, fuzzy, c-format
-msgid "Unable to open range file for [%s in %s]"
-msgstr "के लिए"
-#: ../lib/raster3d/range.c:91 ../lib/raster3d/range.c:100
-#, fuzzy, c-format
-msgid "Error reading range file for [%s in %s]"
-msgstr "के लिए"
-#: ../lib/raster3d/range.c:165
-#, fuzzy, c-format
-msgid "Unable to open range file for <%s>"
-msgstr "के लिए"
-#: ../lib/raster3d/history.c:43
-#, fuzzy, c-format
-msgid "can't get history information for [%s] in mapset [%s]"
-msgstr "के लिए"
-#: ../lib/raster3d/param.c:86
-msgid "Rast3d_get_standard3d_params: precision value invalid"
-msgstr ""
-#: ../lib/raster3d/param.c:119
-msgid "Rast3d_get_standard3d_params: tile dimension value invalid"
-msgstr ""
-#: ../lib/raster3d/param.c:143
-msgid "Window replacing the default"
-msgstr ""
-#: ../lib/raster3d/close.c:47
-#, fuzzy, c-format
-msgid "Unable to write history for 3D raster map <%s>"
-msgstr "के लिए"
-#: ../lib/raster3d/close.c:62
-#, fuzzy, c-format
-msgid "Unable to move temp raster map <%s> to 3d data file <%s>"
-msgstr "नक़ल"
-#: ../lib/raster3d/close.c:79
-#, fuzzy
-msgid "Unable to flush all tiles"
-msgstr "का"
-#: ../lib/raster3d/close.c:84
-#, fuzzy
-msgid "Unable to flush index"
-msgstr "का"
-#: ../lib/raster3d/close.c:94
-#, fuzzy
-msgid "Unable to position file"
-msgstr "का"
-#: ../lib/raster3d/close.c:99 ../lib/raster3d/close.c:105
-#: ../lib/raster3d/close.c:191
-#, fuzzy, c-format
-msgid "Unable to write header for 3D raster map <%s>"
-msgstr "के लिए"
-#: ../lib/raster3d/close.c:110 ../lib/raster3d/close.c:153
-#, fuzzy, c-format
-msgid "Unable to create 3D raster map <%s>"
-msgstr "के लिए"
-#: ../lib/raster3d/close.c:169
-msgid "Error in cache"
-msgstr ""
-#: ../lib/raster3d/test/test_coordinate_transform.c:17
-msgid ""
-"\n"
-"++ Running g3d coordinate transform unit tests ++"
-msgstr ""
-#: ../lib/raster3d/test/test_coordinate_transform.c:23
-msgid ""
-"\n"
-"-- g3d coordinate transform unit tests failure --"
-msgstr ""
-#: ../lib/raster3d/test/test_coordinate_transform.c:25
-msgid ""
-"\n"
-"-- g3d coordinate transform unit tests finished successfully --"
-msgstr ""
-#: ../lib/raster3d/test/test_put_get_value.c:37
-msgid ""
-"\n"
-"++ Running g3d put/get value unit tests ++"
-msgstr ""
-#: ../lib/raster3d/test/test_put_get_value.c:45
-msgid ""
-"\n"
-"-- g3d put/get value unit tests failure --"
-msgstr ""
-#: ../lib/raster3d/test/test_put_get_value.c:47
-msgid ""
-"\n"
-"-- g3d put/get value unit tests finished successfully --"
-msgstr ""
-#: ../lib/raster3d/test/test_main.c:43 ../lib/gmath/test/test_main.c:47
-#: ../lib/gpde/test/test_main.c:50 ../lib/db/dbmi_base/test/test_main.c:47
-msgid "Choose the unit tests to run"
-msgstr ""
-#: ../lib/raster3d/test/test_main.c:50 ../lib/gmath/test/test_main.c:54
-#: ../lib/gpde/test/test_main.c:57 ../lib/db/dbmi_base/test/test_main.c:54
-msgid "Choose the integration tests to run"
-msgstr ""
-#: ../lib/raster3d/test/test_main.c:54 ../lib/gmath/test/test_main.c:79
-#: ../lib/gpde/test/test_main.c:62 ../lib/db/dbmi_base/test/test_main.c:58
-msgid "Run all unit tests"
-msgstr ""
-#: ../lib/raster3d/test/test_main.c:58 ../lib/gmath/test/test_main.c:83
-#: ../lib/gpde/test/test_main.c:66 ../lib/db/dbmi_base/test/test_main.c:62
-msgid "Run all integration tests"
-msgstr ""
-#: ../lib/raster3d/test/test_main.c:62 ../lib/gmath/test/test_main.c:87
-#: ../lib/gpde/test/test_main.c:70 ../lib/db/dbmi_base/test/test_main.c:66
-msgid "Run all unit and integration tests"
-msgstr ""
-#: ../lib/raster3d/test/test_main.c:79
-msgid "Performs unit and integration tests for the g3d library"
-msgstr ""
-#: ../lib/raster3d/open.c:20
-msgid "Rast3d_open_cell_old_no_header: error in Rast3d_mask_open_old"
-msgstr ""
-#: ../lib/raster3d/open.c:26
-msgid "Rast3d_open_cell_old_no_header: error in Rast3d_malloc"
-msgstr ""
-#: ../lib/raster3d/open.c:37
-msgid "Rast3d_open_cell_old_no_header: error in G_open_old"
-msgstr ""
-#: ../lib/raster3d/open.c:91
-msgid "Rast3d_open_cell_old: error in Rast3d_open_cell_old_no_header"
-msgstr ""
-#: ../lib/raster3d/open.c:96
-msgid "Rast3d_open_cell_old: can't rewind file"
-msgstr ""
-#: ../lib/raster3d/open.c:108
-msgid "Rast3d_open_cell_old: error in Rast3d_read_header"
-msgstr ""
-#: ../lib/raster3d/open.c:116
-msgid "Rast3d_open_cell_old: projection does not match window projection"
-msgstr ""
-#: ../lib/raster3d/open.c:120
-msgid "Rast3d_open_cell_old: zone does not match window zone"
-msgstr ""
-#: ../lib/raster3d/open.c:132 ../lib/raster3d/open.c:149
-msgid "Rast3d_open_cell_old: can't read header"
-msgstr ""
-#: ../lib/raster3d/open.c:138
-msgid "Rast3d_open_cell_old: index does not fit into long"
-msgstr ""
-#: ../lib/raster3d/open.c:142
-msgid "Rast3d_open_cell_old: error in Rast3d_malloc"
-msgstr ""
-#: ../lib/raster3d/open.c:168
-msgid "Rast3d_open_cell_old: error in Rast3d_fill_header"
-msgstr ""
-#: ../lib/raster3d/open.c:215
-msgid "Rast3d_open_cell_new: error in Rast3d_mask_open_old"
-msgstr ""
-#: ../lib/raster3d/open.c:224
-msgid "Rast3d_open_cell_new: error in Rast3d_malloc"
-msgstr ""
-#: ../lib/raster3d/open.c:229
-#, fuzzy, c-format
-msgid "map <%s> is not in the current mapset"
-msgstr "है नहीं."
-#: ../lib/raster3d/open.c:239
-msgid "Rast3d_open_cell_new: could not open file"
-msgstr ""
-#: ../lib/raster3d/open.c:284 ../lib/raster3d/open.c:289
-msgid "Rast3d_open_cell_new: can't write header"
-msgstr ""
-#: ../lib/raster3d/open.c:312
-msgid "Rast3d_open_cell_new: error in Rast3d_fill_header"
-msgstr ""
-#: ../lib/raster3d/maskfn.c:77
-#, c-format
-msgid "Adding rule: %lf - %lf"
-msgstr ""
-#: ../lib/raster3d/maskfn.c:95
-#, fuzzy, c-format
-msgid "%s: illegal value spec"
-msgstr "n n"
-#: ../lib/raster3d/color.c:333
-#, fuzzy, c-format
-msgid "mapset <%s> is not the current mapset"
-msgstr "है नहीं."
-#: ../lib/init/prompt.py:20
-msgid "[Raster and Volume MASKs present]"
-msgstr ""
-#: ../lib/init/prompt.py:22
-msgid "[Raster MASK present]"
-msgstr ""
-#: ../lib/init/prompt.py:24
-msgid "[Volume MASK present]"
-msgstr ""
-#: ../lib/init/lock.c:38
-#, c-format
-msgid "Usage: %s file pid"
-msgstr ""
-#: ../lib/init/lock.c:42
-msgid "Concurrent mapset locking is not supported on Windows"
-msgstr ""
-#: ../lib/init/lock.c:60
-#, c-format
-msgid "Unable to write lockfile %s (disk full? Permissions?)"
-msgstr ""
-#: ../lib/init/grass.py:69
-msgid "WARNING"
-msgstr ""
-#: ../lib/init/grass.py:173
-#, fuzzy
-msgid "Usage"
-msgstr "n "
-#: ../lib/init/grass.py:174 ../lib/gis/parser_html.c:126
-#, fuzzy
-msgid "Flags"
-msgstr "n"
-#: ../lib/init/grass.py:175
-msgid "print this help message"
-msgstr ""
-#: ../lib/init/grass.py:176
-msgid "show version information and exit"
-msgstr ""
-#: ../lib/init/grass.py:177
-msgid "create given database, location or mapset if it doesn't exist"
-msgstr ""
-#: ../lib/init/grass.py:178
-msgid "use text based interface"
-msgstr ""
-#: ../lib/init/grass.py:179 ../lib/init/grass.py:181
-msgid "and set as default"
-msgstr ""
-#: ../lib/init/grass.py:180
-msgid "use $DEFAULT_GUI graphical user interface"
-msgstr ""
-#: ../lib/init/grass.py:182
-msgid "print GRASS configuration parameters"
-msgstr ""
-#: ../lib/init/grass.py:183
-msgid "options: arch,build,compiler,path,revision"
-msgstr ""
-#: ../lib/init/grass.py:184 ../lib/gis/parser_html.c:164
-#, fuzzy
-msgid "Parameters"
-msgstr "n"
-#: ../lib/init/grass.py:185
-msgid "initial database (path to GIS data)"
-msgstr ""
-#: ../lib/init/grass.py:186
-#, fuzzy
-msgid "initial location"
-msgstr "n"
-#: ../lib/init/grass.py:187
-msgid "initial mapset"
-msgstr ""
-#: ../lib/init/grass.py:188
-msgid "fully qualified initial mapset directory"
-msgstr ""
-#: ../lib/init/grass.py:189
-msgid "Environment variables relevant for startup"
-msgstr ""
-#: ../lib/init/grass.py:190
-msgid "select GUI (text, gui)"
-msgstr ""
-#: ../lib/init/grass.py:191
-msgid "set wish shell name to override 'wish'"
-msgstr ""
-#: ../lib/init/grass.py:192
-msgid "set html web browser for help pages"
-msgstr ""
-#: ../lib/init/grass.py:193
-msgid "set additional path(s) to local GRASS modules or user scripts"
-msgstr ""
-#: ../lib/init/grass.py:194
-msgid "set additional GISBASE for locally installed GRASS Addons"
-msgstr ""
-#: ../lib/init/grass.py:195
-msgid "shell script to be processed as batch job"
-msgstr ""
-#: ../lib/init/grass.py:196
-msgid "set python shell name to override 'python'"
-msgstr ""
-#: ../lib/init/grass.py:216
-#, fuzzy, python-format
-msgid "Unable to create temporary directory <%s>! Exiting."
-msgstr "n"
-#: ../lib/init/grass.py:294
-msgid "GUI <%s> not supported in this version"
-msgstr "है नहीं संस्करण"
-#: ../lib/init/grass.py:414
-msgid "Searched for a web browser, but none found"
-msgstr ""
-#: ../lib/init/grass.py:438
-#, fuzzy
-msgid "Hit RETURN to continue"
-msgstr "n"
-#: ../lib/init/grass.py:467
-msgid ""
-"The python command does not work as expected!\n"
-"Please check your GRASS_PYTHON environment variable.\n"
-"Use the -help option for details.\n"
-"Switching to text based interface mode.\n"
-"\n"
-"Hit RETURN to continue.\n"
-msgstr ""
-#: ../lib/init/grass.py:479
-msgid ""
-"It appears that the X Windows system is not active.\n"
-"A graphical based user interface is not supported.\n"
-"\n"
-"Hit RETURN to continue"
-msgstr ""
-#: ../lib/init/grass.py:521 ../lib/init/grass.py:552
-msgid "<%s> is not a valid GRASS location"
-msgstr "खेद है है नहीं a n"
-#: ../lib/init/grass.py:533
-#, python-format
-msgid "Failed to create new location. The location <%s> already exists."
-msgstr ""
-#: ../lib/init/grass.py:550
-msgid "Missing WIND file fixed"
-msgstr ""
-#: ../lib/init/grass.py:564
-msgid ""
-"GISDBASE, LOCATION_NAME and MAPSET variables not set properly.\n"
-"Interactive startup needed."
-msgstr ""
-#: ../lib/init/grass.py:578
-#, python-format
-msgid ""
-"Invalid user interface specified - <%s>.\n"
-"Use the --help option to see valid interface names."
-msgstr ""
-#: ../lib/init/grass.py:591
-msgid ""
-"Error in GUI startup. If necessary, please report this error to the GRASS developers.\n"
-"Switching to text mode now.\n"
-"\n"
-"Hit RETURN to continue..."
-msgstr ""
-#: ../lib/init/grass.py:601
-msgid ""
-"Received EXIT message from GUI.\n"
-"GRASS is not started. Bye."
-msgstr ""
-#: ../lib/init/grass.py:604
-#, fuzzy
-msgid ""
-"Invalid return code from GUI startup script.\n"
-"Please advise GRASS developers of this error."
-msgstr "का त्रुटि n"
-#: ../lib/init/grass.py:614
-msgid ""
-"Error reading data path information from g.gisenv.\n"
-"GISDBASE=%(gisbase)s\n"
-"LOCATION_NAME=%(location)s\n"
-"MAPSET=%(mapset)s\n"
-"\n"
-"Check the <%s(file)> file."
-msgstr ""
-#: ../lib/init/grass.py:642
-#, python-format
-msgid "Path '%s' doesn't exist"
-msgstr ""
-#: ../lib/init/grass.py:653
-#, python-format
-msgid "%(user)s is currently running GRASS in selected mapset (file %(file)s found). Concurrent use not allowed."
-msgstr ""
-#: ../lib/init/grass.py:657
-#, python-format
-msgid ""
-"Unable to properly access '%s'.\n"
-"Please notify system personel."
-msgstr ""
-#: ../lib/init/grass.py:671
-#, fuzzy
-msgid "Building user fontcap..."
-msgstr "n"
-#: ../lib/init/grass.py:700
-#, fuzzy
-msgid "The SHELL variable is not set"
-msgstr "चर नहीं सेट"
-#: ../lib/init/grass.py:710
-#, python-format
-msgid ""
-"Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not found. Exiting.\n"
-"\n"
-"Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
-msgstr ""
-#: ../lib/init/grass.py:715
-#, python-format
-msgid "Change file permission to 'executable' for '%s'"
-msgstr ""
-#: ../lib/init/grass.py:717
-#, python-format
-msgid "Executing '%s' ..."
-msgstr ""
-#: ../lib/init/grass.py:722
-#, python-format
-msgid "Execution of '%s' finished."
-msgstr ""
-#: ../lib/init/grass.py:727
-#, python-format
-msgid "GRASS GUI should be <%s>"
-msgstr ""
-#: ../lib/init/grass.py:755
-#, python-format
-msgid "Welcome to GRASS %s"
-msgstr ""
-#: ../lib/init/grass.py:764
-msgid "GRASS homepage:"
-msgstr ""
-#: ../lib/init/grass.py:765
-msgid "This version running through:"
-msgstr ""
-#: ../lib/init/grass.py:767
-#, fuzzy
-msgid "Help is available with the command:"
-msgstr "नहीं के लिए n"
-#: ../lib/init/grass.py:768
-msgid "See the licence terms with:"
-msgstr ""
-#: ../lib/init/grass.py:771
-msgid "If required, restart the GUI with:"
-msgstr ""
-#: ../lib/init/grass.py:773
-msgid "Start the GUI with:"
-msgstr ""
-#: ../lib/init/grass.py:775
-msgid "When ready to quit enter:"
-msgstr ""
-#: ../lib/init/grass.py:874
-msgid "Failed to start shell '%s'"
-msgstr "का"
-#: ../lib/init/grass.py:878
-#, python-format
-msgid "Batch job '%s' (defined in GRASS_BATCH_JOB variable) was executed."
-msgstr ""
-#: ../lib/init/grass.py:879 ../lib/init/grass.py:884
-msgid "Goodbye from GRASS GIS"
-msgstr ""
-#: ../lib/init/grass.py:882
-msgid "Done."
-msgstr ""
-#: ../lib/init/grass.py:888
-msgid "Cleaning up temporary files..."
-msgstr ""
-#: ../lib/init/grass.py:930
-msgid "Parameter <%s> not supported"
-msgstr "विशेषता नहीं"
-#: ../lib/init/grass.py:1071
-#, python-format
-msgid ""
-"Unable to start GRASS. You can:\n"
-" - Launch GRASS with '-gui' switch (`grass70 -gui`)\n"
-" - Create manually GISRC file (%s)\n"
-" - Launch GRASS with path to the location/mapset as an argument (`grass70 /path/to/location/mapset`)"
-msgstr ""
-#: ../lib/init/grass.py:1080
-msgid "Starting GRASS GIS..."
-msgstr ""
-#: ../lib/init/grass.py:1137
-#, python-format
-msgid "Launching <%s> GUI in the background, please wait..."
-msgstr ""
-#: ../lib/raster/range.c:103 ../lib/raster/range.c:118
-#, fuzzy, c-format
-msgid "Unable to read fp range file for <%s>"
-msgstr "के लिए"
-#: ../lib/raster/range.c:174
-#, fuzzy, c-format
-msgid "Unable to read quant rules for raster map <%s>"
-msgstr "के लिए"
-#: ../lib/raster/range.c:211 ../lib/raster/range.c:228
-#, fuzzy, c-format
-msgid "Unable to read range file for <%s>"
-msgstr "के लिए"
-#: ../lib/raster/range.c:266 ../lib/raster/range.c:272
-#: ../lib/raster/range.c:301 ../lib/raster/range.c:315
-#: ../lib/raster/range.c:320
-#, fuzzy, c-format
-msgid "Unable to write range file for <%s>"
-msgstr "के लिए"
-#: ../lib/raster/history.c:115 ../lib/raster/history.c:123
-#, fuzzy, c-format
-msgid "Unable to get history information for <%s@%s>"
-msgstr "के लिए"
-#: ../lib/raster/history.c:162
-#, fuzzy, c-format
-msgid "Unable to write history information for <%s>"
-msgstr "के लिए"
-#: ../lib/raster/history.c:235
-#, c-format
-msgid "generated by %s"
-msgstr ""
-#: ../lib/raster/put_title.c:28
-#, fuzzy, c-format
-msgid "category information for [%s] in [%s] missing or invalid"
-msgstr "के लिए अवैध"
-#: ../lib/raster/put_title.c:37
-#, fuzzy
-msgid "G_put_title - can't create a temp file"
-msgstr "जी शीर्षक a"
-#: ../lib/raster/put_title.c:53
-#, fuzzy, c-format
-msgid "category information for [%s] in [%s] invalid"
-#: ../lib/raster/put_title.c:60
-#, fuzzy
-msgid "G_put_title - can't reopen temp file"
-msgstr "जी शीर्षक"
-#: ../lib/raster/put_title.c:67
-#, fuzzy, c-format
-msgid "can't write category information for [%s] in [%s]"
-msgstr "के लिए"
-#: ../lib/raster/color_rand.c:33
-#, c-format
-msgid "Rast_make_random_colors: min (%d) > max (%d)"
-msgstr ""
-#: ../lib/raster/init.c:62
-#, fuzzy
-msgid "Raster library not initialized. Programmer forgot to call Rast_init()."
-msgstr "त्रुटि नहीं जी n"
-#: ../lib/raster/color_read.c:103
-#, fuzzy
-msgid "missing"
-msgstr "है"
-#: ../lib/raster/color_read.c:106
-#, fuzzy
-msgid "invalid"
-msgstr "है अवैध n"
-#: ../lib/raster/color_read.c:112
-#, fuzzy, c-format
-msgid "Color support for <%s@%s> %s"
-msgstr "के लिए"
-#: ../lib/raster/close.c:74 ../lib/raster/close.c:107
-#, fuzzy, c-format
-msgid "Invalid descriptor: %d"
-msgstr "के लिए"
-#: ../lib/raster/close.c:374
-#, fuzzy, c-format
-msgid "Unable to rename null file '%s'"
-msgstr "का"
-#: ../lib/raster/close.c:440
-#, fuzzy, c-format
-msgid "Unable to rename cell file '%s'"
-msgstr "का"
-#: ../lib/raster/close.c:475
-#, fuzzy
-msgid "unable to write f_format file for CELL maps"
-msgstr "के लिए"
-#: ../lib/raster/auto_mask.c:69
-#, fuzzy
-msgid "Unable to open automatic MASK file"
-msgstr "स्वचालित"
-#: ../lib/raster/gdal.c:88
-#, fuzzy, c-format
-msgid "Unable to locate symbol <%s>"
-msgstr "का"
-#: ../lib/raster/gdal.c:135
-#, fuzzy
-msgid "Unable to load GDAL library"
-msgstr "के लिए"
-#: ../lib/raster/gdal.c:365
-#, fuzzy
-msgid "Unable to open GDAL file"
-msgstr "का"
-#: ../lib/raster/gdal.c:469 ../lib/raster/open.c:573
-#, fuzzy, c-format
-msgid "Invalid map type <%d>"
-msgstr "के लिए"
-#: ../lib/raster/gdal.c:475
-#, fuzzy, c-format
-msgid "Unable to get <%s> driver"
-msgstr "का"
-#: ../lib/raster/gdal.c:484
-#, fuzzy, c-format
-msgid "Unable to create <%s> dataset using <%s> driver"
-msgstr "का"
-#: ../lib/raster/gdal.c:492
-#, c-format
-msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
-msgstr ""
-#: ../lib/raster/gdal.c:498
-#, fuzzy
-msgid "Unable to get in-memory raster driver"
-msgstr "a"
-#: ../lib/raster/gdal.c:505
-#, fuzzy, c-format
-msgid "Unable to create <%s> dataset using memory driver"
-msgstr "के लिए"
-#: ../lib/raster/gdal.c:509
-#, c-format
-msgid "Driver <%s> does not support creating rasters"
-msgstr ""
-#: ../lib/raster/gdal.c:525
-#, fuzzy
-msgid "Unable to set geo transform"
-msgstr "का"
-#: ../lib/raster/gdal.c:529
-#, fuzzy
-msgid "Unable to set projection"
-msgstr "का"
-#: ../lib/raster/gdal.c:533
-#, fuzzy, c-format
-msgid "Unable to create cell_misc/%s/gdal file"
-msgstr "के लिए n"
-#: ../lib/raster/gdal.c:549
-#, fuzzy, c-format
-msgid "Error writing cell_misc/%s/gdal file"
-msgstr "त्रुटि n"
-#: ../lib/raster/gdal.c:597
-#, fuzzy, c-format
-msgid "Unable to create output file <%s> using driver <%s>"
-msgstr "का"
-#: ../lib/raster/window.c:18
-msgid "Internal error: Rast_get_window() called with split window.Use Rast_get_input_window() or Rast_get_output_window() instead."
-msgstr ""
-#: ../lib/raster/window.c:77
-msgid "Internal error: Rast_window_rows() called with split window.Use Rast_input_window_rows() or Rast_output_window_rows() instead."
-msgstr ""
-#: ../lib/raster/window.c:112
-msgid "Internal error: Rast_window_cols() called with split window.Use Rast_input_window_cols() or Rast_output_window_cols() instead."
-msgstr ""
-#: ../lib/raster/color_rules.c:125
-msgid "syntax error"
-msgstr ""
-#: ../lib/raster/color_rules.c:127
-msgid "R/G/B not in range 0-255"
-msgstr ""
-#: ../lib/raster/color_rules.c:129
-#, fuzzy
-msgid "invalid color name"
-msgstr "n"
-#: ../lib/raster/color_rules.c:131
-msgid "percentage not in range 0-100"
-msgstr ""
-#: ../lib/raster/color_rules.c:133
-#, fuzzy
-msgid "invalid value"
-msgstr "n"
-#: ../lib/raster/color_rules.c:135
-msgid "unknown error"
-msgstr ""
-#: ../lib/raster/color_rules.c:181
-#, c-format
-msgid "bad rule (%s): [%s]"
-msgstr ""
-#: ../lib/raster/color_rules.c:326
-#, fuzzy, c-format
-msgid "Unable to load color rules <%s>"
-msgstr "के लिए"
-#: ../lib/raster/set_window.c:48
-msgid "Rast_set_window() called while window split"
-msgstr ""
-#: ../lib/raster/set_window.c:131
-#, fuzzy
-msgid "Rast_set_read_window(): projection/zone differs from that of currently open raster maps"
-msgstr "जी सेट का"
-#: ../lib/raster/set_window.c:158
-msgid "Input window changed while maps are open for read"
-msgstr ""
-#: ../lib/raster/set_window.c:176
-msgid "Output window changed while maps are open for write"
-msgstr ""
-#: ../lib/raster/color_write.c:81 ../lib/vector/Vlib/color_write.c:71
-#, c-format
-msgid "Qualified name <%s> doesn't match mapset <%s>"
-msgstr ""
-#: ../lib/raster/color_write.c:96 ../lib/vector/Vlib/color_write.c:91
-#, fuzzy, c-format
-msgid "Unable to create <%s> file for map <%s>"
-msgstr "के लिए"
-#: ../lib/raster/reclass.c:168
-#, fuzzy, c-format
-msgid "Too many reclass categories for <%s@%s>"
-msgstr "के लिए"
-#: ../lib/raster/reclass.c:171
-#, fuzzy, c-format
-msgid "Illegal reclass format in header file for <%s@%s>"
-msgstr "के लिए"
-#: ../lib/raster/reclass.c:273
-msgid "Illegal reclass request"
-msgstr ""
-#: ../lib/raster/reclass.c:278
-msgid "Illegal reclass type"
-msgstr ""
-#: ../lib/raster/reclass.c:284
-#, fuzzy, c-format
-msgid "Unable to create header file for <%s@%s>"
-msgstr "के लिए"
-#: ../lib/raster/reclass.c:332
-#, fuzzy, c-format
-msgid "Unable to create dependency file in <%s@%s>"
-msgstr "के लिए"
-#: ../lib/raster/get_row.c:37 ../lib/raster/get_row.c:882
-#, fuzzy, c-format
-msgid "Reading raster map <%s@%s> request for row %d is outside region"
-msgstr "के लिए है"
-#: ../lib/raster/get_row.c:96 ../lib/raster/get_row.c:101
-#: ../lib/raster/get_row.c:134 ../lib/raster/get_row.c:140
-#: ../lib/raster/get_row.c:174 ../lib/raster/get_row.c:177
-#, fuzzy
-msgid "Error reading raster data"
-msgstr "के लिए"
-#: ../lib/raster/get_row.c:212
-#, fuzzy
-msgid "Error reading raster data via GDAL"
-msgstr "के लिए"
-#: ../lib/raster/get_row.c:313
-#, fuzzy, c-format
-msgid "cell_values_float: xdr_float failed for index %d"
-msgstr "के लिए."
-#: ../lib/raster/get_row.c:352
-#, fuzzy, c-format
-msgid "cell_values_double: xdr_double failed for index %d"
-msgstr "के लिए."
-#: ../lib/raster/get_row.c:866 ../lib/raster/get_row.c:869
-#, fuzzy, c-format
-msgid "Error reading null row %d"
-msgstr "त्रुटि"
-#: ../lib/raster/open.c:190
-#, fuzzy, c-format
-msgid "Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%s> which does not exist"
-msgstr "है a का नहीं"
-#: ../lib/raster/open.c:195
-#, fuzzy, c-format
-msgid "Error reading reclass file for raster map <%s>"
-msgstr "के लिए"
-#: ../lib/raster/open.c:206
-#, fuzzy, c-format
-msgid "Error reading map type for raster map <%s>"
-msgstr "के लिए"
-#: ../lib/raster/open.c:214
-#, fuzzy, c-format
-msgid "Raster map <%s@%s>: format field in header file invalid"
-msgstr "फील्ड अवैध"
-#: ../lib/raster/open.c:219
-#, fuzzy, c-format
-msgid "Raster map <%s> is in different projection than current region. Found <%s>, should be <%s>."
-msgstr "है नहीं."
-#: ../lib/raster/open.c:226
-#, fuzzy, c-format
-msgid "Raster map <%s> is in different zone (%d) than current region (%d)"
-msgstr "है नहीं."
-#: ../lib/raster/open.c:231
-#, fuzzy, c-format
-msgid "Raster map <%s>: bytes per cell (%d) too large"
-msgstr "बाइट्स बड़ा"
-#: ../lib/raster/open.c:256
-#, c-format
-msgid "Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
-msgstr ""
-#: ../lib/raster/open.c:264
-#, fuzzy, c-format
-msgid "Unable to open %s file for raster map <%s@%s>"
-msgstr "के लिए"
-#: ../lib/raster/open.c:301
-#, fuzzy, c-format
-msgid "Error reading format for <%s@%s>"
-msgstr "त्रुटि"
-#: ../lib/raster/open.c:502
-#, fuzzy
-msgid "Unable to create GDAL link"
-msgstr "का"
-#: ../lib/raster/open.c:578
-#, fuzzy, c-format
-msgid "Raster map <%s> is not in the current mapset (%s)"
-msgstr "है नहीं."
-#: ../lib/raster/open.c:585
-#, fuzzy, c-format
-msgid "<%s> is an illegal file name"
-msgstr "n n"
-#: ../lib/raster/open.c:599
-#, fuzzy
-msgid "No temp files available"
-msgstr "नहीं"
-#: ../lib/raster/open.c:671
-#, fuzzy
-msgid "no temp files available"
-msgstr "n"
-#: ../lib/raster/open.c:724
-msgid "Rast_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
-msgstr ""
-#: ../lib/raster/open.c:782
-#, fuzzy, c-format
-msgid "Raster map <%s> not found in mapset <%s>"
-msgstr "नहीं"
-#: ../lib/raster/open.c:843
-#, fuzzy, c-format
-msgid "Unable to find '%s'"
-msgstr "का"
-#: ../lib/raster/open.c:854
-#, fuzzy, c-format
-msgid "Invalid type: field '%s' in file '%s'"
-msgstr "अवैध फील्ड "
-#: ../lib/raster/open.c:859
-#, fuzzy, c-format
-msgid "Missing type: field in file '%s'"
-#: ../lib/raster/open.c:864
-#, fuzzy, c-format
-msgid "Raster map <%s> is not xdr: byte_order: %s"
-msgstr "नहीं"
-#: ../lib/raster/open.c:933
-msgid "Rast_set_quant_rules() can be called only for raster maps opened for reading"
-msgstr ""
-#: ../lib/raster/null_val.c:64
-#, fuzzy
-msgid "EmbedGivenNulls: wrong data type"
-msgstr "जी सेट!"
-#: ../lib/raster/null_val.c:114
-#, fuzzy
-msgid "Rast_set_null_value: wrong data type!"
-msgstr "जी सेट!"
-#: ../lib/raster/put_row.c:120
-#, fuzzy, c-format
-msgid "Error writing uncompressed FP data for row %d of <%s>"
-msgstr "त्रुटि"
-#: ../lib/raster/put_row.c:130
-#, fuzzy, c-format
-msgid "Error writing compressed FP data for row %d of <%s>"
-msgstr "त्रुटि"
-#: ../lib/raster/put_row.c:158
-#, c-format
-msgid "xdr_float failed for index %d of row %d"
-msgstr ""
-#: ../lib/raster/put_row.c:179
-#, fuzzy, c-format
-msgid "xdr_double failed for index %d of row %d"
-msgstr "के लिए."
-#: ../lib/raster/put_row.c:397 ../lib/raster/put_row.c:403
-#, fuzzy, c-format
-msgid "Error writing compressed data for row %d of <%s>"
-msgstr "त्रुटि"
-#: ../lib/raster/put_row.c:413
-#, fuzzy, c-format
-msgid "Error writing uncompressed data for row %d of <%s>"
-msgstr "त्रुटि"
-#: ../lib/raster/put_row.c:472
-#, fuzzy, c-format
-msgid "Error writing data via GDAL for row %d of <%s>"
-msgstr "त्रुटि n"
-#: ../lib/raster/put_row.c:496
-#, fuzzy, c-format
-msgid "No null file for <%s>"
-msgstr "के लिए"
-#: ../lib/raster/put_row.c:510
-msgid "GDAL output doesn't support writing null rows separately"
-msgstr ""
-#: ../lib/raster/put_row.c:530
-#, fuzzy, c-format
-msgid "Unable to find a temporary null file <%s>"
-msgstr "का"
-#: ../lib/raster/put_row.c:535
-#, fuzzy, c-format
-msgid "Unable to open null file <%s>"
-msgstr "जी"
-#: ../lib/raster/put_row.c:562 ../lib/raster/put_row.c:565
-#, fuzzy, c-format
-msgid "Error writing null row %d"
-msgstr "त्रुटि"
-#: ../lib/raster/put_row.c:690
-#, fuzzy, c-format
-msgid "put_raster_row: raster map <%s> not open for write - request ignored"
-msgstr "नहीं"
-#: ../lib/raster/put_row.c:697
-#, fuzzy
-msgid "put_raster_row: unopened file descriptor - request ignored"
-msgstr "नहीं"
-#: ../lib/raster/quant_rw.c:88
-#, fuzzy, c-format
-msgid "Unable to read fp range for raster map <%s>"
-msgstr "के लिए"
-#: ../lib/raster/quant_rw.c:92
-#, fuzzy, c-format
-msgid "Raster map <%s> is empty"
-msgstr "है"
-#: ../lib/raster/quant_rw.c:157
-#, fuzzy, c-format
-msgid "Unable to write quant rules: raster map <%s> is integer"
-msgstr "है"
-#: ../lib/raster/quant_rw.c:166
-#, fuzzy, c-format
-msgid "Unable to write quant rules for raster map <%s>"
-msgstr "के लिए"
-#: ../lib/raster/cats.c:109
-#, fuzzy, c-format
-msgid "Category support for <%s@%s> missing"
-msgstr "के लिए"
-#: ../lib/raster/cats.c:112
-#, fuzzy, c-format
-msgid "Category support for <%s@%s> invalid"
-#: ../lib/raster/cats.c:145
-#, fuzzy, c-format
-msgid "Category support for vector map <%s@%s> missing"
-msgstr "के लिए"
-#: ../lib/raster/cats.c:149
-#, fuzzy, c-format
-msgid "Category support for vector map <%s@%s> invalid"
-msgstr "के लिए"
-#: ../lib/raster/cats.c:964
-#, fuzzy, c-format
-msgid "Unable to open %s file for map <%s>"
-msgstr "के लिए"
-#: ../lib/raster/sample.c:70
-msgid "Unknown interpolation type"
-msgstr ""
-#: ../lib/raster/sample.c:327
-msgid "\"no data\" label found; setting to zero"
-msgstr ""
-#: ../lib/raster/format.c:154
-#, fuzzy, c-format
-msgid "Fail of initial read of compressed file [%s in %s]"
-msgstr "का का"
-#: ../lib/raster/mask_info.c:43
-#, c-format
-msgid "<%s> in mapset <%s>"
-msgstr ""
-#: ../lib/raster/mask_info.c:46
-msgid "none"
-msgstr ""
-#: ../lib/raster/mask_info.c:49
-#, fuzzy
-msgid "not known"
-msgstr "नहीं"
-#: ../lib/raster/raster_metadata.c:110
-#, fuzzy, c-format
-msgid "Unable to read <%s> for raster map <%s@%s>"
-msgstr "के लिए"
-#: ../lib/raster/raster_metadata.c:120 ../lib/raster/raster_metadata.c:149
-#, fuzzy, c-format
-msgid "Error closing <%s> metadata file for raster map <%s@%s>"
-msgstr "के लिए"
-#: ../lib/raster/raster_metadata.c:143
-#, fuzzy, c-format
-msgid "Unable to create <%s> metadata file for raster map <%s@%s>"
-msgstr "के लिए"
-#: ../lib/raster/put_cellhd.c:34
-#, fuzzy, c-format
-msgid "Unable to create header file for <%s>"
-msgstr "के लिए"
-#: ../lib/raster/quant_io.c:43
-#, fuzzy, c-format
-msgid "Floating data range for raster map <%s> is empty"
-msgstr "के लिए है"
-#: ../lib/raster/quant_io.c:52
-#, fuzzy, c-format
-msgid "Integer data range for raster map <%s> is empty"
-msgstr "के लिए है"
-#: ../lib/raster/quant_io.c:105
-#, fuzzy, c-format
-msgid "Attempt to open quantization table for CELL raster map <%s>"
-msgstr "के लिए"
-#: ../lib/raster/quant_io.c:135
-#, fuzzy, c-format
-msgid "Quantization file for raster map <%s> is missing"
-msgstr "के लिए"
-#: ../lib/raster/quant_io.c:145
-#, fuzzy, c-format
-msgid "Quantization file for raster map <%s> is empty"
-msgstr "के लिए"
-#: ../lib/raster/get_cellhd.c:66
-#, fuzzy, c-format
-msgid "Unable to read header file for raster map <%s@%s>.It is a reclass of raster map <%s@%s> %s"
-#: ../lib/raster/get_cellhd.c:70
-#, fuzzy
-msgid "which is missing."
-msgstr "है"
-#: ../lib/raster/get_cellhd.c:71
-#, fuzzy
-msgid "whose header file can't be opened."
-msgstr "किसका"
-#: ../lib/raster/get_cellhd.c:76
-#, fuzzy, c-format
-msgid "Unable to open header file for raster map <%s@%s>"
-msgstr "के लिए"
-#: ../lib/raster/histogram.c:55
-#, fuzzy, c-format
-msgid "Histogram for [%s in %s] missing (run r.support)"
-msgstr "के लिए"
-#: ../lib/raster/histogram.c:62
-#, fuzzy, c-format
-msgid "Can't read histogram for [%s in %s]"
-msgstr "के लिए"
-#: ../lib/raster/histogram.c:66 ../lib/raster/histogram.c:73
-#, fuzzy, c-format
-msgid "Invalid histogram file for [%s in %s]"
-msgstr "के लिए"
-#: ../lib/raster/histogram.c:331
-#, fuzzy, c-format
-msgid "Unable to create histogram file for <%s>"
-msgstr "के लिए"
-#: ../lib/raster/alloc_cell.c:151
-#, c-format
-msgid "Rast__null_bitstream_size: cols (%d) is negative"
-msgstr ""
-#: ../lib/imagery/iclass_perimeter.c:110
-#, c-format
-msgid "Get area %d failed"
-msgstr ""
-#: ../lib/imagery/iclass_perimeter.c:117
-msgid "Perimeter computation failed"
-msgstr ""
-#: ../lib/imagery/iclass_perimeter.c:197
-msgid "Absurd polygon."
-msgstr ""
-#: ../lib/imagery/iclass_perimeter.c:242
-msgid "Outlined area is too large."
-msgstr ""
-#: ../lib/imagery/iclass_statistics.c:219
-msgid "prepare_signature: outline has odd number of points."
-msgstr ""
-#: ../lib/imagery/iclass_statistics.c:228
-#, c-format
-msgid "prepare_signature: scan line %d has odd number of points."
-msgstr ""
-#: ../lib/imagery/iclass_statistics.c:238
-msgid "signature: perimeter points out of order."
-msgstr ""
-#: ../lib/imagery/iclass_statistics.c:248
-msgid "prepare_signature: data error."
-msgstr ""
-#: ../lib/imagery/iclass_statistics.c:560
-#: ../lib/imagery/iclass_statistics.c:583
-#: ../lib/imagery/iclass_statistics.c:606
-#: ../lib/imagery/iclass_statistics.c:629
-#: ../lib/imagery/iclass_statistics.c:652
-#: ../lib/imagery/iclass_statistics.c:679
-#: ../lib/imagery/iclass_statistics.c:711
-#: ../lib/imagery/iclass_statistics.c:734
-#: ../lib/imagery/iclass_statistics.c:757
-#, fuzzy
-msgid "Band index out of range"
-msgstr "दोगुना का"
-#: ../lib/imagery/iclass_statistics.c:683
-#, fuzzy
-msgid "Cell category value out of range"
-msgstr "दोगुना का"
-#: ../lib/imagery/iclass_signatures.c:120
-#, fuzzy, c-format
-msgid "Unable to open output signature file '%s'"
-msgstr "का"
-#: ../lib/imagery/list_gp.c:34
-#, c-format
-msgid "group <%s> is empty\n"
-msgstr ""
-#: ../lib/imagery/list_gp.c:44
-#, c-format
-msgid "group <%s> references the following raster maps\n"
-msgstr ""
-#: ../lib/imagery/sigsetfile.c:41
-#, fuzzy, c-format
-msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> is not current mapset"
-msgstr "के लिए"
-#: ../lib/imagery/sigsetfile.c:57
-#, fuzzy, c-format
-msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
-msgstr "के लिए"
-#: ../lib/imagery/sigsetfile.c:86
-#, fuzzy, c-format
-msgid "Unable to open signature file <%s> for subgroup <%s> of group <%s@%s>"
-msgstr "के लिए"
-#: ../lib/imagery/fopen.c:23
-#, fuzzy, c-format
-msgid "Unable to create file [%s] of group [%s in %s]"
-msgstr "के लिए"
-#: ../lib/imagery/fopen.c:36 ../lib/imagery/fopen.c:57
-#, fuzzy, c-format
-msgid "Unable to open file [%s] of group [%s in %s]"
-msgstr "के लिए"
-#: ../lib/imagery/fopen.c:49
-#, fuzzy, c-format
-msgid "Unable to find file [%s] of group [%s in %s]"
-msgstr "के लिए"
-#: ../lib/imagery/fopen.c:79
-#, fuzzy, c-format
-msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr "के लिए"
-#: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
-#, c-format
-msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-#: ../lib/imagery/fopen.c:116
-#, c-format
-msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-#: ../lib/imagery/iclass.c:112
-#, fuzzy, c-format
-msgid "Raster map <%s@%s> in group <%s> do not exist"
-msgstr "के लिए"
-#: ../lib/imagery/iclass.c:121
-#, c-format
-msgid "Group <%s> does not have enough files (it has %d files)"
-msgstr ""
-#: ../lib/imagery/list_subgp.c:36
-#, c-format
-msgid "subgroup <%s> of group <%s> is empty\n"
-msgstr ""
-#: ../lib/imagery/list_subgp.c:48
-#, c-format
-msgid "subgroup <%s> of group <%s> references the following raster maps\n"
-msgstr ""
-#: ../lib/imagery/target.c:38
-#, fuzzy, c-format
-msgid "Unable to read target file for group [%s]"
-msgstr "के लिए"
-#: ../lib/imagery/points.c:124
-#, fuzzy, c-format
-msgid "Unable to open control point file for group [%s in %s]"
-msgstr "के लिए"
-#: ../lib/imagery/points.c:132
-#, fuzzy, c-format
-msgid "Bad format in control point file for group [%s in %s]"
-msgstr "के लिए"
-#: ../lib/imagery/points.c:159
-#, fuzzy, c-format
-msgid "Unable to create control point file for group [%s in %s]"
-msgstr "के लिए"
-#: ../lib/gmath/la.c:64 ../lib/gmath/la.c:120
-#, fuzzy
-msgid "Matrix dimensions out of range"
-msgstr "का"
-#: ../lib/gmath/la.c:153
-msgid "Matrix is not initialised fully."
-msgstr ""
-#: ../lib/gmath/la.c:158
-#, fuzzy
-msgid "Unable to allocate space for matrix copy"
-msgstr "n"
-#: ../lib/gmath/la.c:247
-msgid "First scalar multiplier must be non-zero"
-msgstr ""
-#: ../lib/gmath/la.c:253 ../lib/gmath/la.c:261 ../lib/gmath/la.c:326
-msgid "One or both input matrices uninitialised"
-msgstr ""
-#: ../lib/gmath/la.c:266 ../lib/gmath/la.c:331
-msgid "Matrix order does not match"
-msgstr ""
-#: ../lib/gmath/la.c:272
-#, fuzzy
-msgid "Unable to allocate space for matrix sum"
-msgstr "n"
-#: ../lib/gmath/la.c:336
-#, fuzzy
-msgid "Unable to allocate space for matrix product"
-msgstr "n"
-#: ../lib/gmath/la.c:448
-msgid "Input: one or both data matrices uninitialised"
-msgstr ""
-#: ../lib/gmath/la.c:453
-msgid "Principal matrix is not properly dimensioned"
-msgstr ""
-#: ../lib/gmath/la.c:458
-msgid "Input: you must have at least one array to solve"
-msgstr ""
-#: ../lib/gmath/la.c:464
-msgid "Could not allocate space for solution matrix"
-msgstr ""
-#: ../lib/gmath/la.c:470 ../lib/gmath/la.c:478
-msgid "Could not allocate space for working matrix"
-msgstr ""
-#: ../lib/gmath/la.c:531
-msgid "Matrix (or submatrix is singular). Solution undetermined"
-msgstr ""
-#: ../lib/gmath/la.c:535
-msgid "Problem in LA routine."
-msgstr ""
-#: ../lib/gmath/la.c:542
-msgid "Procedure not yet available for selected matrix type"
-msgstr ""
-#: ../lib/gmath/la.c:576
-msgid "Matrix is not square. Cannot determine inverse"
-msgstr ""
-#: ../lib/gmath/la.c:581
-#, fuzzy
-msgid "Unable to allocate space for matrix"
-msgstr "n"
-#: ../lib/gmath/la.c:598
-msgid "Matrix is singular"
-msgstr ""
-#: ../lib/gmath/la.c:603
-msgid "Problem in LA procedure."
-msgstr ""
-#: ../lib/gmath/la.c:691
-msgid "Element array has not been allocated"
-msgstr ""
-#: ../lib/gmath/la.c:696
-msgid "Specified element is outside array bounds"
-msgstr ""
-#: ../lib/gmath/la.c:750
-msgid "Specified matrix column index is outside range"
-msgstr ""
-#: ../lib/gmath/la.c:755 ../lib/gmath/la.c:796 ../lib/gmath/la.c:1109
-#: ../lib/gmath/la.c:1161 ../lib/gmath/la.c:1236
-msgid "Matrix is not initialised"
-msgstr ""
-#: ../lib/gmath/la.c:760 ../lib/gmath/la.c:801
-msgid "Could not allocate space for vector structure"
-msgstr ""
-#: ../lib/gmath/la.c:791
-msgid "Specified matrix row index is outside range"
-msgstr ""
-#: ../lib/gmath/la.c:831
-msgid "Specified row index is outside range"
-msgstr ""
-#: ../lib/gmath/la.c:836
-msgid "Specified column index is outside range"
-msgstr ""
-#: ../lib/gmath/la.c:856
-msgid "Unknown vector type."
-msgstr ""
-#: ../lib/gmath/la.c:981
-msgid "Output vector is uninitialized"
-msgstr ""
-#: ../lib/gmath/la.c:986
-msgid "Vectors are not of the same type"
-msgstr ""
-#: ../lib/gmath/la.c:991
-msgid "Output vector is of incorrect type"
-msgstr ""
-#: ../lib/gmath/la.c:996
-msgid "Matrices not allowed"
-msgstr ""
-#: ../lib/gmath/la.c:1002
-msgid "Vectors have differing dimensions"
-msgstr ""
-#: ../lib/gmath/la.c:1008
-msgid "Output vector has incorrect dimension"
-msgstr ""
-#: ../lib/gmath/la.c:1054
-#, fuzzy
-msgid "Vector dimensions out of range"
-msgstr "का"
-#: ../lib/gmath/la.c:1059
-msgid "Row/column out of range"
-msgstr ""
-#: ../lib/gmath/la.c:1274
-msgid "Vector structure is not initialised"
-msgstr ""
-#: ../lib/gmath/la.c:1395 ../lib/gmath/la.c:1403 ../lib/gmath/la.c:1408
-msgid "Input format error"
-msgstr ""
-#: ../lib/gmath/solvers_direct_cholesky_band.c:33
-#, c-format
-msgid "Decomposition failed at row %i and col %i"
-msgstr ""
-#: ../lib/gmath/solvers_classic_iter.c:84
-#, c-format
-msgid "sparse Jacobi -- iteration %5i error %g\n"
-msgstr ""
-#: ../lib/gmath/solvers_classic_iter.c:156
-#, c-format
-msgid "sparse SOR -- iteration %5i error %g\n"
-msgstr ""
-#: ../lib/gmath/solvers_classic_iter.c:218
-#, c-format
-msgid "Jacobi -- iteration %5i error %g\n"
-msgstr ""
-#: ../lib/gmath/solvers_classic_iter.c:275
-#, c-format
-msgid "SOR -- iteration %5i error %g\n"
-msgstr ""
-#: ../lib/gmath/del2g.c:50
-msgid "    taking FFT of image..."
-msgstr ""
-#: ../lib/gmath/del2g.c:56
-msgid "    computing del**2 g..."
-msgstr ""
-#: ../lib/gmath/del2g.c:59
-msgid "    taking FFT of del**2 g..."
-msgstr ""
-#: ../lib/gmath/del2g.c:63
-msgid "    multiplying transforms..."
-msgstr ""
-#: ../lib/gmath/del2g.c:66
-msgid "    taking inverse FFT..."
-msgstr ""
-#: ../lib/gmath/test/bench_blas2.c:35
-msgid ""
-"\n"
-"++ Running blas level 2 benchmark ++"
-msgstr ""
-#: ../lib/gmath/test/bench_blas3.c:34
-msgid ""
-"\n"
-"++ Running blas level 3 benchmark ++"
-msgstr ""
-#: ../lib/gmath/test/test_solvers.c:37
-msgid ""
-"\n"
-"++ Running solver unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_solvers.c:42
-msgid ""
-"\n"
-"-- Solver unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_solvers.c:44
-msgid ""
-"\n"
-"-- Solver unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/test_matrix_conversion.c:37
-msgid ""
-"\n"
-"++ Running matrix conversion unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_matrix_conversion.c:42
-msgid ""
-"\n"
-"-- Matrix conversion unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_matrix_conversion.c:44
-msgid ""
-"\n"
-"-- Matrix conversion unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/bench_solver_direct.c:34
-msgid ""
-"\n"
-"++ Running direct solver benchmark ++"
-msgstr ""
-#: ../lib/gmath/test/test_blas1.c:40
-msgid ""
-"\n"
-"++ Running blas level 1 unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_blas1.c:47
-msgid ""
-"\n"
-"-- blas level 1 unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_blas1.c:49
-msgid ""
-"\n"
-"-- blas level 1 unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:61
-msgid "The size of the matrices and vectors for benchmarking"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:68
-msgid "Choose solver benchmark"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:75
-msgid "Choose blas benchmark"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:106
-msgid "Performs benchmarks, unit and integration tests for the gmath library"
-msgstr ""
-#: ../lib/gmath/test/test_ccmath_wrapper.c:37
-msgid ""
-"\n"
-"++ Running ccmath wrapper unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_ccmath_wrapper.c:42
-msgid ""
-"\n"
-"-- ccmath wrapper unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_ccmath_wrapper.c:44
-msgid ""
-"\n"
-"-- ccmath wrapper unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/bench_solver_krylov.c:34
-msgid ""
-"\n"
-"++ Running krylov solver benchmark ++"
-msgstr ""
-#: ../lib/gmath/test/test_blas3.c:38
-msgid ""
-"\n"
-"++ Running blas level 3 unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_blas3.c:44
-msgid ""
-"\n"
-"-- blas level 3 unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_blas3.c:46
-msgid ""
-"\n"
-"-- blas level 3 unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/test_blas2.c:38
-msgid ""
-"\n"
-"++ Running blas level 2 unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_blas2.c:44
-msgid ""
-"\n"
-"-- blas level 2 unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_blas2.c:46
-msgid ""
-"\n"
-"-- blas level 2 unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/solvers_direct.c:45
-msgid "Starting direct gauss elimination solver"
-msgstr ""
-#: ../lib/gmath/solvers_direct.c:73
-msgid "Starting direct lu decomposition solver"
-msgstr ""
-#: ../lib/gmath/solvers_direct.c:131
-msgid "Starting cholesky decomposition solver"
-msgstr ""
-#: ../lib/gmath/solvers_direct.c:134 ../lib/gmath/solvers_krylov.c:254
-#: ../lib/gmath/solvers_krylov.c:482 ../lib/gmath/solvers_krylov.c:646
-msgid "Unable to solve the linear equation system"
-msgstr ""
-#: ../lib/gmath/solvers_krylov.c:262
-#, c-format
-msgid "Sparse PCG -- iteration %i error  %g\n"
-msgstr ""
-#: ../lib/gmath/solvers_krylov.c:264
-#, c-format
-msgid "PCG -- iteration %i error  %g\n"
-msgstr ""
-#: ../lib/gmath/solvers_krylov.c:490
-#, c-format
-msgid "Sparse CG -- iteration %i error  %g\n"
-msgstr ""
-#: ../lib/gmath/solvers_krylov.c:492
-#, c-format
-msgid "CG -- iteration %i error  %g\n"
-msgstr ""
-#: ../lib/gmath/solvers_krylov.c:695
-#, c-format
-msgid "Sparse BiCGStab -- iteration %i error  %g\n"
-msgstr ""
-#: ../lib/gmath/solvers_krylov.c:698
-#, c-format
-msgid "BiCGStab -- iteration %i error  %g\n"
-msgstr ""
-#: ../lib/lidar/zones.c:473 ../lib/lidar/zones.c:510
-#, fuzzy, c-format
-msgid "<%s> created in database."
-msgstr "का"
-#: ../lib/lidar/zones.c:477 ../lib/lidar/zones.c:514
-#, c-format
-msgid "<%s> has not been created in database."
-msgstr ""
-#: ../lib/lidar/raster.c:74 ../lib/lidar/raster.c:89 ../lib/lidar/raster.c:102
-#: ../lib/lidar/raster.c:119 ../lib/lidar/raster.c:134
-#: ../lib/lidar/raster.c:147 ../lib/lidar/raster.c:162
-#: ../lib/lidar/raster.c:175
-#, fuzzy, c-format
-msgid "Unable to access table <%s>"
-msgstr "का"
-#: ../lib/segment/format.c:144
-msgid "Segment format: file size too large"
-msgstr ""
-#: ../lib/segment/format.c:145
-msgid "Please recompile with Large File Support (LFS)"
-msgstr ""
-#: ../lib/temporal/lib/default_name.c:74
-#: ../lib/db/dbmi_base/default_name.c:127
-msgid "Programmer error"
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:38
-msgid "database"
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:39
-msgid "attribute table"
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:40
-msgid "connection settings"
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:42
-msgid "Prints/sets general TGIS DB connection for current mapset."
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:46
-msgid "Print current connection parameters and exit"
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:47
-msgid "Print"
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:52
-msgid "Check connection parameters, set if uninitialized, and exit"
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:53 ../lib/temporal/t.connect/main.c:59
-#: ../lib/temporal/t.connect/main.c:64 ../lib/temporal/t.connect/main.c:69
-#: ../lib/temporal/t.connect/main.c:73
-msgid "Set"
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:57
-msgid "Set from default settings and exit"
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:58
-msgid "Overwrite current settings if initialized"
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:63
-msgid "Print current connection parameter in shell style and exit"
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:87 ../lib/temporal/t.connect/main.c:99
-msgid "Temporal GIS database connection not defined. Run t.connect."
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:115
-#, fuzzy, c-format
-msgid ""
-"Default TGIS driver / database set to:\n"
-"driver: %s\n"
-"database: %s"
-msgstr "डिफ़ॉल्ट सेट"
-#: ../lib/temporal/t.connect/main.c:122
-#, fuzzy
-msgid "Default TGIS driver is not set"
-msgstr "डिफ़ॉल्ट है नहीं सेट"
-#: ../lib/temporal/t.connect/main.c:125
-#, fuzzy
-msgid "Default TGIS database is not set"
-#: ../lib/temporal/t.connect/main.c:137 ../lib/vector/Vlib/field.c:340
-#, fuzzy, c-format
-msgid ""
-"Default driver / database set to:\n"
-"driver: %s\n"
-"database: %s"
-#: ../lib/display/r_raster.c:115
-#, c-format
-msgid "%s variable defined, %s ignored"
-msgstr ""
-#: ../lib/display/r_raster.c:150
-#, fuzzy, c-format
-msgid "Unknown display driver <%s>"
-msgstr "का"
-#: ../lib/display/r_raster.c:151
-#, fuzzy, c-format
-msgid "Using display driver <%s>..."
-msgstr "का"
-#: ../lib/display/r_raster.c:217
-#, fuzzy, c-format
-msgid "Unable to open file '%s'"
-msgstr "का"
-#: ../lib/display/tran_colr.c:107 ../lib/display/tran_colr.c:109
-#, c-format
-msgid "[%s]: No such color"
-msgstr ""
-#: ../lib/cairodriver/Raster.c:68
-msgid "Cairo_begin_raster: Failed to create surface"
-msgstr ""
-#: ../lib/cairodriver/read_xid.c:14 ../lib/gis/key_value3.c:61
-#, fuzzy, c-format
-msgid "Unable to open input file <%s>"
-msgstr "जी"
-#: ../lib/cairodriver/read_xid.c:17
-#, fuzzy, c-format
-msgid "Unable to read input file <%s>"
-msgstr "का"
-#: ../lib/cairodriver/read_xid.c:20
-#, fuzzy, c-format
-msgid "Unable to parse input file <%s>"
-msgstr "का"
-#: ../lib/cairodriver/write_ppm.c:27 ../lib/cairodriver/write_bmp.c:72
-#, fuzzy, c-format
-msgid "Cairo: unable to open output file <%s>"
-msgstr "का"
-#: ../lib/cairodriver/write_ppm.c:34
-#, fuzzy, c-format
-msgid "Cairo: unable to open mask file <%s>"
-msgstr "जी"
-#: ../lib/cairodriver/write_xid.c:14 ../lib/gis/key_value3.c:34
-#, fuzzy, c-format
-msgid "Unable to open output file <%s>"
-msgstr "का"
-#: ../lib/cairodriver/write_xid.c:19
-#, fuzzy, c-format
-msgid "Unable to write output file <%s>"
-msgstr "का"
-#: ../lib/cairodriver/read_bmp.c:88 ../lib/cairodriver/read_ppm.c:28
-#, fuzzy, c-format
-msgid "Cairo: unable to open input file <%s>"
-msgstr "जी"
-#: ../lib/cairodriver/read_bmp.c:92 ../lib/cairodriver/read_ppm.c:32
-#, c-format
-msgid "Cairo: invalid input file <%s>"
-msgstr ""
-#: ../lib/cairodriver/read_bmp.c:96
-#, c-format
-msgid "Cairo: Invalid BMP header for <%s>"
-msgstr ""
-#: ../lib/cairodriver/Graph.c:67
-#, fuzzy
-msgid "Unable to open display"
-msgstr "का"
-#: ../lib/cairodriver/Graph.c:82
-#, fuzzy
-msgid "Unable to obtain visual"
-msgstr "का"
-#: ../lib/cairodriver/Graph.c:156
-#, c-format
-msgid "Unknown file extension: %s"
-msgstr ""
-#: ../lib/cairodriver/Graph.c:184
-#, fuzzy, c-format
-msgid "cairo: collecting to file '%s'"
-msgstr "जी"
-#: ../lib/cairodriver/Graph.c:186
-#, c-format
-msgid "cairo: image size %dx%d"
-msgstr ""
-#: ../lib/cairodriver/Graph.c:353
-msgid "Unknown Cairo surface type"
-msgstr ""
-#: ../lib/cairodriver/Graph.c:358
-#, fuzzy
-msgid "Failed to initialize Cairo surface"
-msgstr "का"
-#: ../lib/cairodriver/Text.c:46
-#, fuzzy, c-format
-msgid "Unable to convert from <%s> to UTF-8"
-msgstr "नक़ल"
-#: ../lib/cairodriver/Text.c:56
-msgid "Some characters could not be converted to UTF-8"
-msgstr ""
-#: ../lib/cairodriver/read_ppm.c:38
-#, c-format
-msgid "Cairo: input file has incorrect dimensions: expected: %dx%d got: %dx%d"
-msgstr ""
-#: ../lib/cairodriver/read_ppm.c:46
-#, fuzzy, c-format
-msgid "Cairo: unable to open input mask file <%s>"
-msgstr "का"
-#: ../lib/cairodriver/read_ppm.c:50
-#, c-format
-msgid "Cairo: invalid input mask file <%s>"
-msgstr ""
-#: ../lib/cairodriver/read_ppm.c:56
-#, c-format
-msgid "Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
-msgstr ""
-#: ../lib/cairodriver/Draw_bitmap.c:47
-msgid "Cairo_Bitmap: Failed to create source"
-msgstr ""
-#: ../lib/driver/parse_ftcap.c:84
-#, c-format
-msgid "%s: Unable to read font definition file; use the default"
-msgstr ""
-#: ../lib/driver/parse_ftcap.c:90
-#, c-format
-msgid "%s: No font definition file"
-msgstr ""
-#: ../lib/python/raster.py:46
-msgid "Unable to write history for <%(map)s>. Raster map <%(map)s> not found in current mapset."
-msgstr "है नहीं"
-#: ../lib/python/raster.py:101
-msgid "An error occurred while running r.mapcalc"
-msgstr ""
-#: ../lib/python/core.py:727
-#, python-format
-msgid "Invalid element '%s'"
-msgstr ""
-#: ../lib/python/core.py:897
-#, fuzzy
-msgid "Unable to list mapsets"
-msgstr "n"
-#: ../lib/python/temporal/core.py:42
-msgid "Unable to initialize the temporal DBMI interface. Use t.connect to specify the driver and the database string"
-msgstr ""
-#: ../lib/python/temporal/core.py:60 ../lib/python/temporal/core.py:66
-msgid "Unable to initialize the temporal GIS DBMI interface. Use t.connect to specify the driver and the database string"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets_tools.py:57
-#: ../lib/python/temporal/space_time_datasets_tools.py:60
-#: ../lib/python/temporal/space_time_datasets_tools.py:253
-#: ../lib/python/temporal/space_time_datasets_tools.py:403
-#: ../lib/python/temporal/space_time_datasets_tools.py:406
-#, python-format
-msgid "%s= and %s= are mutually exclusive"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets_tools.py:63
-#: ../lib/python/temporal/space_time_datasets_tools.py:409
-msgid "Please specify %s= and %s="
-msgstr "n"
-#: ../lib/python/temporal/space_time_datasets_tools.py:66
-#: ../lib/python/temporal/space_time_datasets_tools.py:412
-msgid "Please specify %s= or %s="
-msgstr "n"
-#: ../lib/python/temporal/space_time_datasets_tools.py:102
-msgid "Space time %s dataset <%s> no found"
-msgstr "नहीं"
-#: ../lib/python/temporal/space_time_datasets_tools.py:124
-#: ../lib/python/temporal/space_time_datasets_tools.py:305
-#: ../lib/python/temporal/space_time_datasets_tools.py:455
-#, python-format
-msgid "Number of %s= and %s= must be equal"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets_tools.py:194
-#, python-format
-msgid "Unable to register %s map <%s> with layer %s. The map has no valid time and the start time is not set."
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets_tools.py:197
-#, python-format
-msgid "Unable to register %s map <%s>. The map has no valid time and the start time is not set."
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets_tools.py:214
-#, python-format
-msgid "Unable to register %s map <%s> with layer. The temporal types are different."
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets_tools.py:216
-msgid "Unable to register %s map <%s>. The temporal types are different."
-msgstr "नक़ल"
-#: ../lib/python/temporal/space_time_datasets_tools.py:397
-msgid "Valid end time and increment are mutual exclusive"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets_tools.py:585
-#: ../lib/python/temporal/space_time_datasets_tools.py:592
-#, python-format
-msgid "Unable to convert string \"%s\"into a datetime object"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets_tools.py:600
-msgid "Set absolute valid time for map <%s> with layer %s to %s - %s"
-msgstr "नक़ल"
-#: ../lib/python/temporal/space_time_datasets_tools.py:602
-#, python-format
-msgid "Set absolute valid time for map <%s> to %s - %s"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets_tools.py:618
-msgid "Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
-msgstr "नक़ल"
-#: ../lib/python/temporal/space_time_datasets_tools.py:620
-msgid "Set relative valid time for map <%s> to %i - %s with unit %s"
-msgstr "नक़ल"
-#: ../lib/python/temporal/space_time_datasets_tools.py:648
-msgid "Unknown dataset type: %s"
-msgstr "का"
-#: ../lib/python/temporal/space_time_datasets_tools.py:682
-#: ../lib/python/temporal/space_time_datasets_tools.py:839
-#: ../lib/python/temporal/space_time_datasets_tools.py:842
-msgid "Dataset <%s> not found in temporal database"
-msgstr "नक़ल"
-#: ../lib/python/temporal/aggregation.py:99
-msgid "Aggregate %s raster maps"
-msgstr "का"
-#: ../lib/python/temporal/aggregation.py:113
-msgid "Raster map <%s> is already in temporal database, use overwrite flag to overwrite"
-msgstr "का"
-#: ../lib/python/temporal/aggregation.py:116
-#, python-format
-msgid "Compute aggregation of maps between %s - %s"
-msgstr ""
-#: ../lib/python/temporal/aggregation.py:132
-msgid "Error while r.series computation"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:167
-msgid "Start time must be of type datetime for %s map <%s> with layer: %s"
-msgstr "के लिए"
-#: ../lib/python/temporal/abstract_map_dataset.py:169
-msgid "Start time must be of type datetime for %s map <%s>"
-msgstr "के लिए"
-#: ../lib/python/temporal/abstract_map_dataset.py:173
-msgid "End time must be of type datetime for %s map <%s> with layer: %s"
-msgstr "के लिए"
-#: ../lib/python/temporal/abstract_map_dataset.py:175
-msgid "End time must be of type datetime for %s map <%s>"
-msgstr "के लिए"
-#: ../lib/python/temporal/abstract_map_dataset.py:180
-msgid "End time must be greater than start time for %s map <%s> with layer: %s"
-msgstr "पूर्व पश्चिम"
-#: ../lib/python/temporal/abstract_map_dataset.py:182
-#: ../lib/python/temporal/abstract_map_dataset.py:255
-msgid "End time must be greater than start time for %s map <%s>"
-#: ../lib/python/temporal/abstract_map_dataset.py:244
-msgid "Unsupported relative time unit type for %s map <%s> with layer %s: %s"
-msgstr "के लिए"
-#: ../lib/python/temporal/abstract_map_dataset.py:246
-msgid "Unsupported relative time unit type for %s map <%s>: %s"
-msgstr "के लिए"
-#: ../lib/python/temporal/abstract_map_dataset.py:253
-msgid "End time must be greater than start time for %s map <%s> with layer %s"
-#: ../lib/python/temporal/abstract_map_dataset.py:333
-#, python-format
-msgid "Map <%s> with layer %s has incorrect time interval, start time is greater than end time"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:335
-#, python-format
-msgid "Map <%s> has incorrect time interval, start time is greater than end time"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:338
-#, python-format
-msgid "Map <%s> has incorrect start time"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:375
-msgid "Unable to remove space time dataset register table <%s>"
-msgstr "का"
-#: ../lib/python/temporal/abstract_map_dataset.py:377
-#, python-format
-msgid "Delete %s dataset <%s> from temporal database"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:406
-msgid "Unregister %s map <%s> with layer %s from space time datasets"
-msgstr "नहीं"
-#: ../lib/python/temporal/abstract_map_dataset.py:409
-msgid "Unregister %s map <%s> from space time datasets"
-msgstr "नहीं"
-#: ../lib/python/temporal/abstract_map_dataset.py:467
-msgid "Unable to select space time dataset register table <%s>"
-msgstr "का"
-#: ../lib/python/temporal/base.py:308
-msgid "Object <%s> not found in the temporal database"
-msgstr "नक़ल"
-#: ../lib/python/temporal/spatial_extent.py:38
-msgid "Projections are different. Unable to compute overlap_2d for spatial extents"
-msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:161
-msgid "Volume computation is not supported for LL projections"
-msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:178
-msgid "Area computation is not supported for LL projections"
-msgstr ""
-#: ../lib/python/temporal/datetime_math.py:96
-msgid "Wrong increment format: %s"
-msgstr "n"
-#: ../lib/python/temporal/datetime_math.py:191
-msgid "Wrong granularity format: %s"
-msgstr "n"
-#: ../lib/python/temporal/datetime_math.py:227
-#, python-format
-msgid "Adjust datetime from %s to %s with granularity %s"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:127
-#: ../lib/python/temporal/abstract_space_time_dataset.py:170
-msgid "Unknown temporal type \"%s\""
-msgstr "का"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:182
-msgid "Unsupported temporal unit: %s"
-msgstr "का"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:496
-msgid "The space time datasets must be of the same temporal type"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:500
-msgid "The temporal map type of the sample dataset must be interval"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:611
-msgid "More than one map found in a granule. Temporal granularity seems to be invalid or the chosen granularity is not a greatest common divider of all intervals and gaps in the dataset."
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:776
-msgid "Unable to get map ids from register table <%s>"
-msgstr "का"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:794
-#, python-format
-msgid "Delete space time %s  dataset <%s> from temporal database"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:806
-msgid "Drop map register table: %s"
-msgstr "का"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:828
-msgid "Unable to drop table <%s>"
-msgstr "का"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:858
-msgid "Only maps with absolute or relative valid time can be registered"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:860
-msgid "Register %s map <%s> with layer %s in space time %s dataset <%s>"
-msgstr "नहीं"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:862
-msgid "Register %s map <%s> in space time %s dataset <%s>"
-msgstr "नहीं"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:869
-#, python-format
-msgid "Map <%s> with layer %s has invalid time"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:871
-#, python-format
-msgid "Map <%s> has invalid time"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:891
-#, python-format
-msgid "Temporal type of space time dataset <%s> and map <%s> with layer %s are different"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:893
-#, python-format
-msgid "Temporal type of space time dataset <%s> and map <%s> are different"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:899
-msgid "Set temporal unit for space time %s dataset <%s> to %s"
-msgstr "नहीं"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:906
-#, python-format
-msgid "Relative time units of space time dataset <%s> and map <%s> with layer %s are different"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:908
-#, python-format
-msgid "Relative time units of space time dataset <%s> and map <%s> are different"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:914
-msgid "Only maps from the same mapset can be registered"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:930
-#, python-format
-msgid "Map <%s> with layer %s is already registered."
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:932
-#, python-format
-msgid "Map <%s> is already registered."
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:962
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1007
-msgid "Unable to create the space time %s dataset register table for map <%s> with layer %s"
-msgstr "के लिए"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:965
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1010
-msgid "Unable to create the space time %s dataset register table for <%s>"
-msgstr "के लिए"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:974
-msgid "Created register table <%s> for %s map <%s> with layer %s"
-msgstr "के लिए"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:977
-msgid "Created register table <%s> for %s map <%s>"
-msgstr "के लिए"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1018
-#, python-format
-msgid "Created register table <%s> for space time %s  dataset <%s>"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1075
-msgid "Unable to find map <%s> with layer %s in temporal database"
-msgstr "नक़ल"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1077
-msgid "Unable to find map <%s> in temporal database"
-msgstr "नक़ल"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1080
-msgid "Unregister %s map <%s> with layer %s"
-msgstr "है"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1082
-msgid "Unregister %s map <%s>"
-msgstr "है"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1101
-msgid "Map <%s> with layer %s is not registered in space time dataset <%s>"
-msgstr "है नहीं."
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1103
-msgid "Map <%s> is not registered in space time dataset <%s>"
-msgstr "है नहीं."
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1146
-#, python-format
-msgid "Update metadata, spatial and temporal extent from all registered maps of <%s>"
-msgstr ""
-#: ../lib/python/raster3d.py:86
-msgid "An error occurred while running r3.mapcalc"
-msgstr ""
-#: ../lib/python/task.py:52
-#, fuzzy
-msgid "unknown"
-msgstr "नहीं"
-#: ../lib/python/task.py:155
-#, python-format
-msgid "Parameter element '%(element)s' not found: '%(value)s'"
-msgstr ""
-#: ../lib/python/task.py:170
-msgid "Flag not found: %s"
-msgstr "नहीं"
-#: ../lib/python/task.py:189
-#, python-format
-msgid "Parameter '%(name)s' (%(desc)s) is missing."
-msgstr ""
-#: ../lib/python/task.py:220
-#, fuzzy
-msgid "<required>"
-msgstr "n"
-#: ../lib/python/task.py:445
-#, python-format
-msgid ""
-"Unable to fetch interface description for command '%(cmd)s'.\n"
-"\n"
-"Details: %(det)s"
-msgstr ""
-#: ../lib/python/db.py:48 ../lib/db/dbmi_client/column.c:136
-#, fuzzy, c-format, python-format
-msgid "Unable to describe table <%s>"
-msgstr "का"
-#: ../lib/python/db.py:122
-msgid "Fetching data from table <%s> failed"
-msgstr "का"
-#: ../lib/python/vector.py:87
-#, python-format
-msgid "Database connection not defined for layer %s"
-msgstr ""
-#: ../lib/python/vector.py:233
-msgid "Missing layer %(layer)d in vector map <%(map)s>"
-msgstr "के लिए"
-#: ../lib/python/vector.py:249
-msgid "vector_select() failed"
-msgstr ""
-#: ../lib/pngdriver/Graph_set.c:84
-#, c-format
-msgid "png: truecolor status %s"
-msgstr ""
-#: ../lib/pngdriver/Graph_set.c:85 ../lib/psdriver/Graph_set.c:200
-msgid "enabled"
-msgstr ""
-msgid "disabled"
-msgstr ""
-#: ../lib/pngdriver/Graph_set.c:132
-#, c-format
-msgid "png: collecting to file '%s'"
-msgstr ""
-#: ../lib/pngdriver/Graph_set.c:133
-#, c-format
-msgid "png: image size %dx%d"
-msgstr ""
-#: ../lib/manage/read_list.c:73
-#, fuzzy, c-format
-msgid "Unable to open data base element list '%s'"
-msgstr "चालू"
-#: ../lib/manage/read_list.c:134
-#, c-format
-msgid "Format error: file ('%s') line (%d) - %s"
-msgstr ""
-#: ../lib/manage/do_remove.c:42
-#, fuzzy, c-format
-msgid "Removing %s <%s>"
-msgstr "का"
-#: ../lib/manage/do_remove.c:65
-#, fuzzy
-msgid "Unable to delete vector map"
-msgstr "के लिए"
-#: ../lib/manage/do_remove.c:85
-#, fuzzy, c-format
-msgid "Unable to remove %s element"
-msgstr "के लिए"
-#: ../lib/manage/do_remove.c:89 ../lib/manage/do_remove.c:109
-#: ../lib/manage/do_copy.c:63 ../lib/manage/do_rename.c:87
-#: ../lib/manage/do_rename.c:107
-#, fuzzy, c-format
-msgid "%s is missing"
-msgstr "है"
-#: ../lib/manage/do_remove.c:92 ../lib/manage/do_remove.c:112
-#, c-format
-msgid "%s removed"
-msgstr ""
-#: ../lib/manage/do_remove.c:105
-#, fuzzy, c-format
-msgid "Unable to remove %s"
-msgstr "का"
-#: ../lib/manage/do_remove.c:121
-#, c-format
-msgid "<%s> nothing removed"
-msgstr ""
-#: ../lib/manage/do_copy.c:43
-#, fuzzy, c-format
-msgid "Copy %s <%s> to current mapset as <%s>"
-msgstr "n"
-#: ../lib/manage/do_copy.c:52
-#, fuzzy, c-format
-msgid "Unable to copy <%s> to current mapset as <%s>"
-msgstr "n"
-#: ../lib/manage/do_copy.c:72
-#, c-format
-msgid "%s copied"
-msgstr ""
-#: ../lib/manage/option.c:47
-#, fuzzy, c-format
-msgid "%s to be %s"
-msgstr "n"
-#: ../lib/manage/option.c:51
-msgid "Raster"
-msgstr ""
-#: ../lib/manage/option.c:55
-msgid "Vector"
-msgstr ""
-#: ../lib/manage/option.c:57
-msgid "Region"
-msgstr ""
-#: ../lib/manage/option.c:59
-msgid "Group"
-msgstr ""
-#: ../lib/manage/do_rename.c:42
-#, fuzzy, c-format
-msgid "Rename %s <%s> to <%s>"
-msgstr "के लिए"
-#: ../lib/manage/do_rename.c:62
-#, fuzzy, c-format
-msgid "Unable to rename vector map <%s> to <%s>"
-msgstr "नक़ल"
-#: ../lib/manage/do_rename.c:83 ../lib/manage/do_rename.c:103
-#, fuzzy, c-format
-msgid "Unable to rename %s"
-msgstr "का"
-#: ../lib/manage/do_rename.c:90 ../lib/manage/do_rename.c:110
-#, c-format
-msgid "%s renamed"
-msgstr ""
-#: ../lib/manage/do_rename.c:119
-#, c-format
-msgid "<%s> nothing renamed"
-msgstr ""
-#: ../lib/gpde/N_parse_options.c:106
-msgid "The calculation time in seconds"
-msgstr ""
-#: ../lib/gpde/test/test_assemble.c:42
-msgid ""
-"\n"
-"++ Running assembling unit tests ++"
-msgstr ""
-#: ../lib/gpde/test/test_assemble.c:44
-msgid "\t 1. testing 2d assembling"
-msgstr ""
-#: ../lib/gpde/test/test_assemble.c:47
-msgid "\t 2. testing 3d assembling"
-msgstr ""
-#: ../lib/gpde/test/test_assemble.c:51
-msgid ""
-"\n"
-"-- Assembling unit tests failure --"
-msgstr ""
-#: ../lib/gpde/test/test_assemble.c:53
-msgid ""
-"\n"
-"-- Assembling unit tests finished successfully --"
-msgstr ""
-#: ../lib/gpde/test/test_les.c:35
-msgid ""
-"\n"
-"++ Running les creation unit tests ++"
-msgstr ""
-#: ../lib/gpde/test/test_les.c:40
-msgid ""
-"\n"
-"-- les creation unit tests failure --"
-msgstr ""
-#: ../lib/gpde/test/test_les.c:42
-msgid ""
-"\n"
-"-- les creation unit tests finished successfully --"
-msgstr ""
-#: ../lib/gpde/test/test_les.c:96
-msgid "\t * testing les creation in parallel\n"
-msgstr ""
-#: ../lib/gpde/test/test_les.c:127
-msgid "\t * testing les creation in serial\n"
-msgstr ""
-#: ../lib/gpde/test/test_arrays.c:48
-msgid ""
-"\n"
-"++ Running array unit tests ++"
-msgstr ""
-#: ../lib/gpde/test/test_arrays.c:50
-msgid "\t 1. testing 2d arrays"
-msgstr ""
-#: ../lib/gpde/test/test_arrays.c:53
-msgid "\t 2. testing 3d arrays"
-msgstr ""
-#: ../lib/gpde/test/test_arrays.c:57
-msgid ""
-"\n"
-"-- Array unit tests failure --"
-msgstr ""
-#: ../lib/gpde/test/test_arrays.c:59
-msgid ""
-"\n"
-"-- Array unit tests finished successfully --"
-msgstr ""
-#: ../lib/gpde/test/test_geom.c:36
-msgid ""
-"\n"
-"++ Running geom_data unit tests ++"
-msgstr ""
-#: ../lib/gpde/test/test_geom.c:41
-msgid ""
-"\n"
-"-- geom_data unit tests failure --"
-msgstr ""
-#: ../lib/gpde/test/test_geom.c:43
-msgid ""
-"\n"
-"-- geom_data unit tests finished successfully --"
-msgstr ""
-#: ../lib/gpde/test/test_gwflow.c:47
-msgid ""
-"\n"
-"++ Running gwflow integration tests ++"
-msgstr ""
-#: ../lib/gpde/test/test_gwflow.c:49
-msgid "\t 1. testing 2d gwflow"
-msgstr ""
-#: ../lib/gpde/test/test_gwflow.c:52
-msgid "\t 2. testing 3d gwflow"
-msgstr ""
-#: ../lib/gpde/test/test_gwflow.c:56
-msgid ""
-"\n"
-"-- gwflow integration tests failure --"
-msgstr ""
-#: ../lib/gpde/test/test_gwflow.c:58
-msgid ""
-"\n"
-"-- gwflow integration tests finished successfully --"
-msgstr ""
-#: ../lib/gpde/test/test_main.c:89
-msgid "Performs unit and integration tests for gpde library"
-msgstr ""
-#: ../lib/gpde/test/test_tools.c:34
-msgid ""
-"\n"
-"++ Running math tool unit tests ++"
-msgstr ""
-#: ../lib/gpde/test/test_tools.c:39
-msgid ""
-"\n"
-"-- math tool unit tests failure --"
-msgstr ""
-#: ../lib/gpde/test/test_tools.c:41
-msgid ""
-"\n"
-"-- math tool unit tests finished successfully --"
-msgstr ""
-#: ../lib/gpde/test/test_solute_transport.c:43
-msgid ""
-"\n"
-"++ Running solute_transport integration tests ++"
-msgstr ""
-#: ../lib/gpde/test/test_solute_transport.c:45
-msgid "\t 1. testing 2d solute_transport"
-msgstr ""
-#: ../lib/gpde/test/test_solute_transport.c:48
-msgid "\t 2. testing 3d solute_transport"
-msgstr ""
-#: ../lib/gpde/test/test_solute_transport.c:52
-msgid ""
-"\n"
-"-- solute_transport integration tests failure --"
-msgstr ""
-#: ../lib/gpde/test/test_solute_transport.c:55
-msgid ""
-"\n"
-"-- solute_transport integration tests finished successfully --"
-msgstr ""
-#: ../lib/gpde/test/test_gradient.c:42
-msgid ""
-"\n"
-"++ Running gradient unit tests ++"
-msgstr ""
-#: ../lib/gpde/test/test_gradient.c:44
-msgid "\t 1. testing 2d gradient"
-msgstr ""
-#: ../lib/gpde/test/test_gradient.c:47
-msgid "\t 2. testing 3d gradient"
-msgstr ""
-#: ../lib/gpde/test/test_gradient.c:51
-msgid ""
-"\n"
-"-- Gradient unit tests failure --"
-msgstr ""
-#: ../lib/gpde/test/test_gradient.c:53
-msgid ""
-"\n"
-"-- Gradient unit tests finished successfully --"
-msgstr ""
-#: ../lib/gpde/test/test_heat.c:33
-msgid ""
-"\n"
-"++ Running heat flow integration tests ++"
-msgstr ""
-#: ../lib/gpde/test/test_heat.c:35
-msgid "\t 1. testing 2d heat flow"
-msgstr ""
-#: ../lib/gpde/test/test_heat.c:37
-msgid "\t 2. testing 3d heat flow"
-msgstr ""
-#: ../lib/gpde/test/test_heat.c:40
-msgid ""
-"\n"
-"-- heat flow integration tests failure --"
-msgstr ""
-#: ../lib/gpde/test/test_heat.c:42
-msgid ""
-"\n"
-"-- heat flow integration tests finished successfully --"
-msgstr ""
-#: ../lib/gpde/N_arrays_io.c:93
-#, fuzzy, c-format
-msgid "Reading raster map <%s> into memory"
-msgstr "है"
-#: ../lib/gpde/N_arrays_io.c:183
-msgid "N_array_2d * array is empty"
-msgstr ""
-#: ../lib/gpde/N_arrays_io.c:202
-#, c-format
-msgid "Write 2d array to raster map <%s>"
-msgstr ""
-#: ../lib/gpde/N_arrays_io.c:309
-#, c-format
-msgid "Read g3d map <%s> into the memory"
-msgstr ""
-#: ../lib/gpde/N_arrays_io.c:364 ../lib/gpde/N_arrays_io.c:464
-msgid "Error closing g3d file"
-msgstr ""
-#: ../lib/gpde/N_arrays_io.c:420
-#, c-format
-msgid "Error opening g3d map <%s>"
-msgstr ""
-#: ../lib/gpde/N_arrays_io.c:422
-#, c-format
-msgid "Write 3d array to g3d map <%s>"
-msgstr ""
-#: ../lib/gpde/N_gwflow.c:436 ../lib/gpde/N_gwflow.c:715
-#, c-format
-msgid "The total sum of the water budget: %g\n"
-msgstr ""
-#: ../lib/gpde/N_gwflow.c:438 ../lib/gpde/N_gwflow.c:717
-#, c-format
-msgid "The total sum of the water budget is significant larger then 0: %g\n"
-msgstr ""
-#: ../lib/arraystats/class.c:21
-msgid "Discont algorithm currently not available because of bugs"
-msgstr ""
-#: ../lib/arraystats/class.c:23
-#, c-format
-msgid "%s: Unknown algorithm"
-msgstr ""
-#: ../lib/arraystats/class.c:26
-#, c-format
-msgid "%s: Error in classification algorithm"
-msgstr ""
-#: ../lib/arraystats/class.c:221
-#, c-format
-msgid "There are classbreaks outside the range min-max. Number of classes reduced to %i, but using probabilities for %i classes."
-msgstr ""
-#: ../lib/vector/neta/utils.c:222 ../lib/vector/neta/utils.c:235
-#, c-format
-msgid "'%s' must be > 0 for '%s'"
-msgstr ""
-#: ../lib/vector/neta/utils.c:224
-msgid "'where' and 'cats' parameters were supplied, cat will be ignored"
-msgstr ""
-#: ../lib/vector/neta/utils.c:228
-#, fuzzy
-msgid "Unable to load data from database"
-msgstr "लिंक ."
-#: ../lib/vector/neta/utils.c:239
-#, fuzzy
-msgid "Problem loading category values"
-msgstr "के लिए"
-#: ../lib/vector/neta/flow.c:309 ../lib/vector/Vlib/net.c:428
-#: ../lib/vector/Vlib/graph.c:105
-msgid "GngFlatten error"
-msgstr ""
-#: ../lib/vector/neta/timetables.c:46 ../lib/vector/neta/timetables.c:203
-#: ../lib/vector/neta/timetables.c:244 ../lib/vector/neta/timetables.c:286
-#, fuzzy, c-format
-msgid "Unable to open select cursor: %s"
-msgstr "के लिए"
-#: ../lib/vector/neta/allpairs.c:53
-msgid "Computing all pairs shortest paths..."
-msgstr ""
-#: ../lib/vector/neta/spanningtree.c:104
-msgid "Computing minimum spanning tree..."
-msgstr ""
-#: ../lib/vector/diglib/plus_node.c:217
-#, c-format
-msgid "Attempt to read line angle for the line which is not connected to the node: node %d, line %d"
-msgstr ""
-#: ../lib/vector/diglib/file.c:159
-msgid "Writing to file loaded to memory not supported"
-msgstr ""
-#: ../lib/vector/diglib/file.c:203
-#, fuzzy
-msgid "Unable to load file to memory, file not open"
-msgstr "का"
-#: ../lib/vector/diglib/file.c:218
-msgid "Vector memory mode not supported, using 'AUTO'"
-msgstr ""
-#: ../lib/vector/diglib/spindex_rw.c:277
-#, c-format
-msgid "Spatial index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
-msgstr ""
-#: ../lib/vector/diglib/spindex_rw.c:284
-#, c-format
-msgid "Your GRASS version does not fully support spatial index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
-msgstr ""
-#: ../lib/vector/diglib/spindex_rw.c:293
-#, c-format
-msgid "Spatial index format version %d.%d is not supported by this release. Please rebuild topology."
-msgstr ""
-#: ../lib/vector/diglib/spindex_rw.c:824
-msgid "Writing sidx: wrong node position in file"
-msgstr ""
-#: ../lib/vector/diglib/plus.c:275
-#, fuzzy
-msgid "Unable read topology for nodes"
-msgstr "के लिए"
-#: ../lib/vector/diglib/plus.c:280
-#, fuzzy, c-format
-msgid "Unable to read topology for node %d"
-msgstr "के लिए"
-#: ../lib/vector/diglib/plus.c:285
-#, fuzzy
-msgid "Unable read topology for lines"
-msgstr "के लिए"
-#: ../lib/vector/diglib/plus.c:290
-#, fuzzy, c-format
-msgid "Unable to read topology for line %d"
-msgstr "के लिए n"
-#: ../lib/vector/diglib/plus.c:295
-#, fuzzy
-msgid "Unable to read topo for areas"
-msgstr "के लिए"
-#: ../lib/vector/diglib/plus.c:300
-#, fuzzy, c-format
-msgid "Unable read topology for area %d"
-msgstr "के लिए"
-#: ../lib/vector/diglib/plus.c:305
-#, fuzzy
-msgid "Unable to read topology for isles"
-msgstr "के लिए"
-#: ../lib/vector/diglib/plus.c:310
-#, fuzzy, c-format
-msgid "Unable to read topology for isle %d"
-msgstr "के लिए"
-#: ../lib/vector/diglib/plus.c:332 ../lib/vector/diglib/plus.c:358
-#, fuzzy
-msgid "Unable to write head to plus file"
-msgstr "के लिए n"
-#: ../lib/vector/diglib/plus.c:337
-#, fuzzy
-msgid "Unable to write nodes to plus file"
-msgstr "a"
-#: ../lib/vector/diglib/plus.c:342
-#, fuzzy
-msgid "Unable to write lines to plus file"
-msgstr "a"
-#: ../lib/vector/diglib/plus.c:347
-#, fuzzy
-msgid "Unable to write areas to plus file"
-msgstr "a"
-#: ../lib/vector/diglib/plus.c:352
-#, fuzzy
-msgid "Unable to write isles to plus file"
-msgstr "a"
-#: ../lib/vector/diglib/port_init.c:158
-#, fuzzy, c-format
-msgid "Unable to find '%x' in %s"
-msgstr "का"
-#: ../lib/vector/diglib/spindex.c:381
-#, fuzzy, c-format
-msgid "Unable to delete node %d from spatial index"
-msgstr "का"
-#: ../lib/vector/diglib/spindex.c:418
-#, fuzzy, c-format
-msgid "Unable to delete line %d from spatial index"
-msgstr "का"
-#: ../lib/vector/diglib/spindex.c:447
-#, fuzzy
-msgid "Attempt to delete sidx for dead area"
-msgstr "के लिए"
-#: ../lib/vector/diglib/spindex.c:464
-#, fuzzy, c-format
-msgid "Unable to delete area %d from spatial index"
-msgstr "का"
-#: ../lib/vector/diglib/spindex.c:506
-#, fuzzy, c-format
-msgid "Unable to delete isle %d from spatial index"
-msgstr "का"
-#: ../lib/vector/diglib/spindex.c:679 ../lib/vector/diglib/spindex.c:747
-#: ../lib/vector/diglib/spindex.c:815
-msgid "No line id given"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:216 ../lib/vector/diglib/plus_area.c:694
-#, c-format
-msgid "Line %d already has area/isle %d to left"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:226 ../lib/vector/diglib/plus_area.c:702
-#, c-format
-msgid "Line %d already has area/isle %d to right"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:303
-msgid "Attempt to delete isle from dead area"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:320
-#, c-format
-msgid "Attempt to delete not registered isle %d from area %d"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:359
-msgid "Attempt to delete dead area"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:400
-#, c-format
-msgid "Dead centroid %d registered for area (bug in the vector library)"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:425
-#, fuzzy, c-format
-msgid "Attempt to delete area %d info from dead isle %d"
-msgstr "के लिए"
-#: ../lib/vector/diglib/plus_area.c:762
-#, fuzzy, c-format
-msgid "Attempt to delete isle %d info from dead area %d"
-msgstr "के लिए"
-#: ../lib/vector/diglib/portable.c:210 ../lib/vector/diglib/portable.c:243
-#: ../lib/vector/diglib/portable.c:690 ../lib/vector/diglib/plus_struct.c:560
-msgid "Vector exceeds supported file size limit"
-msgstr ""
-#: ../lib/vector/diglib/test.c:58
-#, fuzzy
-msgid "Unable to open test.tmp file"
-msgstr "का"
-#: ../lib/vector/diglib/test.c:75
-#, c-format
-msgid "Error in read/write portable double, byte_order = %d Written: %.16e3E Read: %.16e3E"
-msgstr ""
-#: ../lib/vector/diglib/test.c:89
-#, c-format
-msgid "Error in read/write portable float, byte_order = %d Written: %.8e3E Read: %.8e3E"
-msgstr ""
-#: ../lib/vector/diglib/test.c:104
-#, c-format
-msgid "Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
-msgstr ""
-#: ../lib/vector/diglib/test.c:119
-#, c-format
-msgid "Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
-msgstr ""
-#: ../lib/vector/diglib/test.c:134
-#, c-format
-msgid "Error in read/write portable int, byte_order = %d Written: %d Read: %d"
-msgstr ""
-#: ../lib/vector/diglib/test.c:150
-#, c-format
-msgid "Error in read/write portable short, byte_order = %d Written: %d Read: %d"
-msgstr ""
-#: ../lib/vector/diglib/test.c:165
-#, c-format
-msgid "Error in read/write portable char, byte_order = %d Written: %d Read: %d"
-msgstr ""
-#: ../lib/vector/diglib/plus_struct.c:520
-#, c-format
-msgid "Topology format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
-msgstr ""
-#: ../lib/vector/diglib/plus_struct.c:526
-#, c-format
-msgid "Your GRASS version does not fully support topology format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
-msgstr ""
-#: ../lib/vector/diglib/plus_struct.c:536
-#, c-format
-msgid "Old topology format version %d.%d is not supported by this release. Try to rebuild topology."
-msgstr ""
-#: ../lib/vector/Vlib/write_nat.c:52 ../lib/vector/Vlib/write_nat.c:86
-#, c-format
-msgid "%s: Area %d does not exist"
-msgstr ""
-#: ../lib/vector/Vlib/write_nat.c:678 ../lib/vector/Vlib/write_ogr.c:490
-#, fuzzy
-msgid "Attempt to delete dead feature"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/write_nat.c:789
-#, fuzzy, c-format
-msgid "Attempt to access dead area (%d)"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/write_nat.c:929
-#, fuzzy
-msgid "Attempt to restore alive feature"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/legal_vname.c:43
-#, fuzzy, c-format
-msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
-msgstr "नहीं रखे हुए n"
-#: ../lib/vector/Vlib/legal_vname.c:50
-#, fuzzy, c-format
-msgid "Illegal vector map name <%s>. Must start with a letter."
-msgstr "प्रारंभ a n"
-#: ../lib/vector/Vlib/legal_vname.c:58
-#, fuzzy, c-format
-msgid "Illegal vector map name <%s>. Character '%c' not allowed."
-msgstr "नहीं n"
-#: ../lib/vector/Vlib/legal_vname.c:65
-#, fuzzy, c-format
-msgid "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
-msgstr "नहीं n"
-#: ../lib/vector/Vlib/legal_vname.c:97 ../lib/vector/Vlib/legal_vname.c:101
-#, fuzzy, c-format
-msgid "Output vector map name <%s> is not valid map name"
-msgstr "है नहीं."
-#: ../lib/vector/Vlib/legal_vname.c:144 ../lib/vector/Vlib/legal_vname.c:148
-#, fuzzy, c-format
-msgid "Output vector map <%s> is used as input"
-msgstr "है"
-#: ../lib/vector/Vlib/merge_lines.c:246
-#, c-format
-msgid "%d boundaries merged"
-msgstr ""
-#: ../lib/vector/Vlib/merge_lines.c:247
-#, c-format
-msgid "%d new boundaries"
-msgstr ""
-#: ../lib/vector/Vlib/snap.c:133
-msgid "Snap vertices Pass 1: select points"
-msgstr ""
-#: ../lib/vector/Vlib/snap.c:187
-msgid "Snap vertices Pass 2: assign anchor vertices"
-msgstr ""
-#: ../lib/vector/Vlib/snap.c:256
-msgid "Snap vertices Pass 3: snap to assigned points"
-msgstr ""
-#: ../lib/vector/Vlib/snap.c:438
-#, c-format
-msgid "Snapped vertices: %d"
-msgstr ""
-#: ../lib/vector/Vlib/snap.c:439
-#, fuzzy, c-format
-msgid "New vertices: %d"
-msgstr "का n"
-#: ../lib/vector/Vlib/build.c:28 ../lib/vector/Vlib/close.c:34
-#: ../lib/vector/Vlib/rewind.c:32 ../lib/vector/Vlib/read.c:29
-#: ../lib/vector/Vlib/open.c:46 ../lib/vector/Vlib/write.c:50
-#: ../lib/vector/Vlib/write.c:56
-#, fuzzy
-msgid "Requested format is not compiled in this version"
-msgstr "है नहीं संस्करण"
-#: ../lib/vector/Vlib/build.c:120
-msgid "Unable to add area (map closed, topo saved)"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:129
-msgid "Unable to add isle (map closed, topo saved)"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:139
-#, fuzzy
-msgid "Area of size = 0.0 ignored"
-msgstr "का आकार "
-#: ../lib/vector/Vlib/build.c:176
-msgid "Request to find area outside nonexistent isle"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:510
-msgid "Checking for topological errors..."
-msgstr ""
-#: ../lib/vector/Vlib/build.c:544
-#, fuzzy, c-format
-msgid "Number of lines of length zero: %d"
-msgstr "रेखाओ की िगनती  े  :   %d\n"
-#: ../lib/vector/Vlib/build.c:546
-#, fuzzy, c-format
-msgid "Number of boundaries of length zero: %d"
-msgstr "का n"
-#: ../lib/vector/Vlib/build.c:555
-#, fuzzy, c-format
-msgid "Number of boundary intersections: %d"
-msgstr "का n"
-#: ../lib/vector/Vlib/build.c:579
-#, fuzzy
-msgid "Skipping further checks because of incorrect boundaries"
-msgstr "का n"
-#: ../lib/vector/Vlib/build.c:629
-#, fuzzy, c-format
-msgid "Number of redundant holes: %d"
-msgstr "का n"
-#: ../lib/vector/Vlib/build.c:707
-#, fuzzy, c-format
-msgid "Building topology for vector map <%s>..."
-msgstr "के लिए"
-#: ../lib/vector/Vlib/build.c:725
-#, fuzzy
-msgid "Topology was built"
-msgstr "n"
-#: ../lib/vector/Vlib/build.c:737
-#, fuzzy, c-format
-msgid "Number of nodes: %d"
-msgstr "का n"
-#: ../lib/vector/Vlib/build.c:738
-#, fuzzy, c-format
-msgid "Number of primitives: %d"
-msgstr "का n"
-#: ../lib/vector/Vlib/build.c:739
-#, fuzzy, c-format
-msgid "Number of points: %d"
-msgstr "िबनदूओाओ की िगनती    :   %d\n"
-#: ../lib/vector/Vlib/build.c:740
-#, fuzzy, c-format
-msgid "Number of lines: %d"
-#: ../lib/vector/Vlib/build.c:741
-#, fuzzy, c-format
-msgid "Number of boundaries: %d"
-msgstr "का n"
-#: ../lib/vector/Vlib/build.c:742
-#, fuzzy, c-format
-msgid "Number of centroids: %d"
-msgstr "का n"
-#: ../lib/vector/Vlib/build.c:745
-#, fuzzy, c-format
-msgid "Number of faces: %d"
-msgstr "का n"
-#: ../lib/vector/Vlib/build.c:748
-#, fuzzy, c-format
-msgid "Number of kernels: %d"
-msgstr "का n"
-#: ../lib/vector/Vlib/build.c:794
-#, fuzzy, c-format
-msgid "Number of areas: %d"
-msgstr "का n"
-#: ../lib/vector/Vlib/build.c:795
-#, fuzzy, c-format
-msgid "Number of isles: %d"
-msgstr "का n"
-#: ../lib/vector/Vlib/build.c:800
-#, fuzzy, c-format
-msgid "Number of areas without centroid: %d"
-msgstr "का n"
-#: ../lib/vector/Vlib/build.c:805
-#, fuzzy, c-format
-msgid "Number of centroids exceeds number of areas: %d > %d"
-msgstr "का n"
-#: ../lib/vector/Vlib/build.c:809
-#, fuzzy, c-format
-msgid "Number of incorrect boundaries: %d"
-msgstr "का n"
-#: ../lib/vector/Vlib/build.c:813
-#, fuzzy, c-format
-msgid "Number of centroids outside area: %d"
-msgstr "का n"
-#: ../lib/vector/Vlib/build.c:817
-#, fuzzy, c-format
-msgid "Number of duplicate centroids: %d"
-msgstr "का अनुकृति n"
-#: ../lib/vector/Vlib/build.c:821
-#, fuzzy
-msgid "Number of areas: -"
-msgstr "का n"
-#: ../lib/vector/Vlib/build.c:822
-#, fuzzy
-msgid "Number of isles: -"
-msgstr "का n"
-#: ../lib/vector/Vlib/build.c:852
-#, fuzzy, c-format
-msgid "Unable to open topo file for write <%s>"
-msgstr "के लिए n"
-#: ../lib/vector/Vlib/build.c:860
-#, fuzzy
-msgid "Error writing out topo file"
-msgstr "त्रुटि n"
-#: ../lib/vector/Vlib/build.c:1027
-#, fuzzy
-msgid "Unable to build spatial index from topology, vector map is not opened at topology level 2"
-msgstr "है नहीं चालू"
-#: ../lib/vector/Vlib/build.c:1050
-#, c-format
-msgid "%s is no longer supported"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:1087
-#, fuzzy, c-format
-msgid "Unable open spatial index file for write <%s>"
-msgstr "के लिए n"
-#: ../lib/vector/Vlib/build.c:1096
-#, fuzzy
-msgid "Error writing out spatial index file"
-msgstr "त्रुटि n"
-#: ../lib/vector/Vlib/overlay.c:70
-msgid "unknown operator"
-msgstr ""
-#: ../lib/vector/Vlib/overlay.c:120
-msgid "Overlay: line/boundary types not supported by AND operator"
-msgstr ""
-#: ../lib/vector/Vlib/overlay.c:123
-msgid "Overlay: area x area types not supported by AND operator"
-msgstr ""
-#: ../lib/vector/Vlib/level.c:34
-msgid "Map structure was never initialized"
-msgstr ""
-#: ../lib/vector/Vlib/level.c:36
-msgid "Map structure has been closed"
-msgstr ""
-#: ../lib/vector/Vlib/line.c:178 ../lib/vector/Vlib/line.c:211
-#: ../lib/vector/Vlib/line.c:244
-#, fuzzy
-msgid "Index out of range in"
-msgstr "दोगुना का"
-#: ../lib/vector/Vlib/line.c:544
-msgid "Segment outside line, no segment created"
-msgstr ""
-#: ../lib/vector/Vlib/close.c:138
-#, fuzzy, c-format
-msgid "Unable to close vector <%s>"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/read_nat.c:134 ../lib/vector/Vlib/geos.c:65
-#: ../lib/vector/Vlib/geos.c:255
-#, fuzzy
-msgid "Attempt to read dead line"
-msgstr "के लिए n"
-#: ../lib/vector/Vlib/map.c:73
-#, fuzzy
-msgid "input vector map is not open"
-msgstr "नहीं"
-#: ../lib/vector/Vlib/map.c:160
-msgid "Topology not available. Polygons will be skipped."
-msgstr ""
-#: ../lib/vector/Vlib/map.c:267 ../lib/vector/Vlib/map.c:411
-#: ../lib/vector/Vlib/open.c:636
-#, fuzzy
-msgid "Vector map name is not SQL compliant"
-msgstr "है नहीं."
-#: ../lib/vector/Vlib/map.c:271
-#, fuzzy, c-format
-msgid "Unable to find vector map <%s> in <%s>"
-msgstr "नक़ल"
-#: ../lib/vector/Vlib/map.c:283 ../lib/vector/Vlib/map.c:415
-#: ../lib/vector/Vlib/open.c:672
-#, c-format
-msgid "Vector map <%s> already exists and will be overwritten"
-msgstr ""
-#: ../lib/vector/Vlib/map.c:287 ../lib/vector/Vlib/open.c:677
-#, fuzzy, c-format
-msgid "Unable to delete vector map <%s>"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/map.c:307 ../lib/vector/Vlib/map.c:433
-#, fuzzy, c-format
-msgid "Unable to copy vector map <%s> to <%s>"
-msgstr "नक़ल"
-#: ../lib/vector/Vlib/map.c:356 ../lib/vector/Vlib/map.c:482
-#: ../lib/vector/Vlib/map.c:720 ../lib/vector/Vlib/map.c:827
-#, fuzzy, c-format
-msgid "Unable to copy table <%s>"
-msgstr "का"
-#: ../lib/vector/Vlib/map.c:372 ../lib/vector/Vlib/map.c:511
-#: ../lib/vector/Vlib/map.c:733
-#, fuzzy, c-format
-msgid "Unable to create index for table <%s>, key <%s>"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/map.c:496 ../lib/vector/Vlib/map.c:597
-#, fuzzy, c-format
-msgid "Unable to delete table <%s>"
-msgstr "का"
-#: ../lib/vector/Vlib/map.c:551
-#, fuzzy, c-format
-msgid "Invalid vector map name <%s>"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/map.c:565
-#, fuzzy, c-format
-msgid "Unable to open header file for vector map <%s>"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/map.c:587
-#, fuzzy, c-format
-msgid "Unable to find table <%s> linked to vector map <%s>"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/map.c:604
-#, fuzzy, c-format
-msgid "Table <%s> linked to vector map <%s> does not exist"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/map.c:617
-#, fuzzy, c-format
-msgid "Unable to open directory '%s'"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/map.c:631
-#, fuzzy, c-format
-msgid "Unable to delete file '%s'"
-msgstr "का"
-#: ../lib/vector/Vlib/map.c:648
-#, fuzzy, c-format
-msgid "Unable to rename directory '%s' to '%s'"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/map.c:656
-#, fuzzy, c-format
-msgid "Unable to remove directory '%s'"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/map.c:711 ../lib/vector/Vlib/map.c:812
-#, fuzzy, c-format
-msgid "Unable to add database link for vector map <%s>"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/poly.c:225
-#, fuzzy
-msgid "Unable to find point in polygon"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/poly.c:644
-#, fuzzy
-msgid "conditions failed"
-msgstr "n"
-#: ../lib/vector/Vlib/geos.c:52 ../lib/vector/Vlib/read.c:129
-#, fuzzy
-msgid "vector map is not opened"
-msgstr "नहीं"
-#: ../lib/vector/Vlib/geos.c:55
-#, c-format
-msgid "Vect_read_line_geos(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
-msgstr ""
-#: ../lib/vector/Vlib/geos.c:60
-#, fuzzy
-msgid "only native format supported"
-msgstr "विशेषता नहीं"
-#: ../lib/vector/Vlib/geos.c:90
-#, c-format
-msgid "Vect_read_area_geos(): unable to read area id %d"
-msgstr ""
-#: ../lib/vector/Vlib/geos.c:104
-#, c-format
-msgid "Vect_read_area_geos(): unable to read isle id %d of area id %d"
-msgstr ""
-#: ../lib/vector/Vlib/geos.c:202
-#, fuzzy, c-format
-msgid "Unable to read line offset %ld"
-msgstr "के लिए n"
-#: ../lib/vector/Vlib/geos.c:409
-#, fuzzy, c-format
-msgid "Attempt to read points of nonexistent area id %d"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/geos.c:469
-#, fuzzy, c-format
-msgid "Unable to read feature id %d"
-msgstr "का"
-#: ../lib/vector/Vlib/box.c:261
-#, fuzzy, c-format
-msgid "Unable to find bbox for featured %d"
-msgstr "का"
-#: ../lib/vector/Vlib/box.c:335 ../lib/vector/Vlib/box.c:401
-#, fuzzy
-msgid "Could not find area box"
-msgstr "नहीं"
-#: ../lib/vector/Vlib/read.c:132
-#, c-format
-msgid "Vect_read_line(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
-msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:290
-#, fuzzy, c-format
-msgid "Unable to calculate centroid for area %d"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/build_ogr.c:328 ../lib/vector/Vlib/read_ogr.c:122
-#: ../lib/vector/Vlib/read_ogr.c:469
-#, fuzzy, c-format
-msgid "OGR feature type %d not supported"
-#: ../lib/vector/Vlib/build_ogr.c:378
-msgid "Empty OGR layer, nothing to build"
-msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:387
-msgid "Random read is not supported by OGR for this layer, unable to build topology"
-msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:392
-#, c-format
-msgid "Using external data format '%s' (feature type '%s')"
-msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:455
-#, fuzzy, c-format
-msgid "Feature %d without geometry ignored"
-msgstr "विशेषता"
-#: ../lib/vector/Vlib/build_ogr.c:462
-#, fuzzy, c-format
-msgid "OGR feature %d without ID ignored"
-msgstr "विशेषता."
-#: ../lib/vector/Vlib/net.c:116
-#, fuzzy
-msgid "Building graph..."
-msgstr "n"
-#: ../lib/vector/Vlib/net.c:158
-#, fuzzy
-msgid "Unable to build network graph"
-msgstr "n"
-#: ../lib/vector/Vlib/net.c:164
-msgid "Forward costs column not specified"
-msgstr ""
-#: ../lib/vector/Vlib/net.c:171
-msgid "Arc field < 1"
-msgstr ""
-#: ../lib/vector/Vlib/net.c:185 ../lib/vector/Vlib/net.c:202
-#: ../lib/vector/Vlib/net.c:356 ../lib/vector/Vlib/ascii.c:582
-#, fuzzy, c-format
-msgid "Column <%s> not found in table <%s>"
-msgstr "नहीं के लिए n"
-#: ../lib/vector/Vlib/net.c:191 ../lib/vector/Vlib/net.c:208
-#: ../lib/vector/Vlib/net.c:362
-#, fuzzy, c-format
-msgid "Data type of column <%s> not supported (must be numeric)"
-msgstr "का ज़ेड है नहीं"
-#: ../lib/vector/Vlib/net.c:221
-msgid "Registering arcs..."
-msgstr ""
-#: ../lib/vector/Vlib/net.c:250
-#, c-format
-msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (forward/both direction(s) of line skipped)"
-msgstr ""
-#: ../lib/vector/Vlib/net.c:269
-#, c-format
-msgid "Database record for line %d (cat = %d, backword direction) not found(direction of line skipped)"
-msgstr ""
-#: ../lib/vector/Vlib/net.c:318
-#, fuzzy
-msgid "Cannot add network arc"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/net.c:342
-msgid "Setting node costs..."
-msgstr ""
-#: ../lib/vector/Vlib/net.c:398
-#, fuzzy, c-format
-msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
-msgstr "के लिए नहीं"
-#: ../lib/vector/Vlib/net.c:425
-#, fuzzy
-msgid "Flattening the graph..."
-msgstr "n"
-#: ../lib/vector/Vlib/net.c:434
-#, fuzzy
-msgid "Graph was built"
-msgstr "n"
-#: ../lib/vector/Vlib/net.c:517 ../lib/vector/Vlib/graph.c:226
-#, c-format
-msgid "dglShortestPath error: %s"
-msgstr ""
-#: ../lib/vector/Vlib/net.c:600
-msgid "Wrong line direction in Vect_net_get_line_cost()"
-msgstr ""
-#: ../lib/vector/Vlib/dangles.c:148
-msgid "Changed"
-msgstr ""
-#: ../lib/vector/Vlib/dangles.c:151
-msgid "Removed"
-msgstr ""
-#: ../lib/vector/Vlib/dangles.c:154
-msgid "Selected"
-msgstr ""
-#: ../lib/vector/Vlib/dangles.c:262
-#, fuzzy, c-format
-msgid "%s lines: %d"
-#: ../lib/vector/Vlib/dangles.c:263
-#, c-format
-msgid "%s dangles: %d"
-msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:116
-#, fuzzy
-msgid "Registering primitives..."
-msgstr "का n"
-#: ../lib/vector/Vlib/build_nat.c:125
-#, fuzzy
-msgid "Unable to read vector map"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/build_nat.c:158
-#, fuzzy, c-format
-msgid "%d primitives registered"
-msgstr "n"
-#: ../lib/vector/Vlib/build_nat.c:159
-#, fuzzy, c-format
-msgid "%d vertices registered"
-msgstr "n"
-#: ../lib/vector/Vlib/build_nat.c:170
-#, fuzzy
-msgid "Building areas..."
-msgstr "n"
-#: ../lib/vector/Vlib/build_nat.c:193
-#, fuzzy, c-format
-msgid "%d areas built"
-msgstr "n"
-#: ../lib/vector/Vlib/build_nat.c:194
-#, fuzzy, c-format
-msgid "%d isles built"
-msgstr "n"
-#: ../lib/vector/Vlib/build_nat.c:203
-msgid "Attaching islands..."
-msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:219
-msgid "Attaching centroids..."
-msgstr ""
-#: ../lib/vector/Vlib/level_two.c:23
-#, fuzzy, c-format
-msgid "Vector map <%s> is not open at topological level"
-msgstr "नहीं"
-#: ../lib/vector/Vlib/level_two.c:305
-#, fuzzy, c-format
-msgid "Nodes not available for line %d"
-#: ../lib/vector/Vlib/level_two.c:343
-#, fuzzy, c-format
-msgid "Areas not available for line %d"
-msgstr "के लिए n"
-#: ../lib/vector/Vlib/level_two.c:346
-#, fuzzy, c-format
-msgid "Line %d is not a boundary"
-msgstr "नहीं"
-#: ../lib/vector/Vlib/level_two.c:427
-#, fuzzy, c-format
-msgid "Topology info not available for feature %d"
-#: ../lib/vector/Vlib/open_ogr.c:61
-#, fuzzy
-msgid "OGR datasource not defined"
-msgstr "विशेषता."
-#: ../lib/vector/Vlib/open_ogr.c:66 ../lib/vector/Vlib/write_ogr.c:445
-msgid "OGR layer not defined"
-msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:78 ../lib/vector/Vlib/field.c:599
-#, fuzzy, c-format
-msgid "Unable to open OGR data source '%s'"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/open_ogr.c:98
-#, fuzzy, c-format
-msgid "OGR layer <%s> not found"
-msgstr "नहीं"
-#: ../lib/vector/Vlib/open_ogr.c:158
-#, fuzzy, c-format
-msgid "Unable to open fidx file for vector map <%s@%s>"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/open_ogr.c:175
-#, c-format
-msgid "Feature index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
-msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:180
-#, c-format
-msgid "Your GRASS version does not fully support feature index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
-msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:250
-#, fuzzy, c-format
-msgid "Unable to get OGR driver <%s>"
-msgstr "का"
-#: ../lib/vector/Vlib/open_ogr.c:258
-#, fuzzy, c-format
-msgid "Unable to create OGR data source '%s'"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/open_ogr.c:270
-#, c-format
-msgid "OGR layer <%s> already exists and will be overwritten"
-msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:274
-#, fuzzy, c-format
-msgid "Unable to delete OGR layer <%s>"
-msgstr "का"
-#: ../lib/vector/Vlib/open_ogr.c:280
-#, fuzzy, c-format
-msgid "OGR layer <%s> already exists in datasource '%s'"
-msgstr "का"
-#: ../lib/vector/Vlib/open_ogr.c:346
-#, c-format
-msgid "Unsupported geometry type (%d)"
-msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:365
-#, fuzzy, c-format
-msgid "Unable to create OGR layer <%s> in '%s'"
-msgstr "का"
-#: ../lib/vector/Vlib/open_ogr.c:377
-#, c-format
-msgid "More layers defined, using driver <%s> and database <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:383
-msgid "Database connection not defined. Unable to write attributes."
-msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:420 ../lib/vector/Vlib/ascii.c:349
-#: ../lib/db/dbmi_client/db.c:41 ../lib/db/dbmi_client/copy_tab.c:107
-#: ../lib/db/dbmi_client/copy_tab.c:127
-#, fuzzy, c-format
-msgid "Unable to start driver <%s>"
-msgstr "का"
-#: ../lib/vector/Vlib/open_ogr.c:467
-#, fuzzy, c-format
-msgid "Creating field <%s> failed"
-msgstr "का"
-#: ../lib/vector/Vlib/open_nat.c:55
-#, fuzzy, c-format
-msgid "Unable to open coor file for vector map <%s>"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/open_nat.c:152
-#, c-format
-msgid "Coor file of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
-msgstr ""
-#: ../lib/vector/Vlib/open_nat.c:156
-#, c-format
-msgid "Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
-msgstr ""
-#: ../lib/vector/Vlib/open.c:111
-#, fuzzy, c-format
-msgid "Programmer requested unknown access level %d"
-msgstr "चेतावनी n"
-#: ../lib/vector/Vlib/open.c:199
-#, fuzzy, c-format
-msgid "Vector map <%s> not found in current mapset"
-msgstr "है नहीं."
-#: ../lib/vector/Vlib/open.c:213
-#, fuzzy
-msgid "Vector map which is not in the current mapset cannot be opened for update"
-msgstr "है नहीं के लिए."
-#: ../lib/vector/Vlib/open.c:250
-#, fuzzy, c-format
-msgid "Unable to read header file of vector map <%s>"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/open.c:280
-#, fuzzy, c-format
-msgid "Unable to open topology file for vector map <%s>"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/open.c:292
-#, fuzzy, c-format
-msgid "Unable to open spatial index file for vector map <%s>"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/open.c:316 ../lib/vector/Vlib/cindex.c:510
-#, fuzzy, c-format
-msgid "Unable to open category index file for vector map <%s>"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/open.c:334 ../lib/vector/Vlib/open.c:353
-#, fuzzy, c-format
-msgid "Unable to open vector map <%s> on level %d. Try to rebuild vector topology by v.build."
-msgstr "चालू"
-#: ../lib/vector/Vlib/open.c:362
-#, fuzzy, c-format
-msgid "Building topology for OGR layer <%s> from datasource '%s'..."
-msgstr "के लिए"
-#: ../lib/vector/Vlib/open.c:370
-#, fuzzy, c-format
-msgid "Unable to open vector map <%s> on level %d"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/open.c:418
-#, fuzzy, c-format
-msgid "Unable to open history file for vector map <%s>"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/open.c:627
-#, fuzzy, c-format
-msgid "<%s> is not the current mapset (%s)"
-msgstr "n"
-#: ../lib/vector/Vlib/open.c:652
-#, fuzzy
-msgid "Unable to open OGR file"
-msgstr "का"
-#: ../lib/vector/Vlib/open.c:692
-#, fuzzy, c-format
-msgid "Unable to create vector map <%s>"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/open.c:702
-#, fuzzy, c-format
-msgid "Unable to open history file of vector map <%s>"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/open.c:753
-#, fuzzy, c-format
-msgid "Unable to stat file <%s>"
-msgstr "का"
-#: ../lib/vector/Vlib/open.c:812
-#, c-format
-msgid "unknown %d (update Vect_maptype_info)"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:888
-#, fuzzy
-msgid "Size of 'coor' file differs from value saved in topology file"
-msgstr "का."
-#: ../lib/vector/Vlib/open.c:899 ../lib/vector/Vlib/open.c:993
-#, fuzzy, c-format
-msgid "Please rebuild topology for vector map <%s@%s>"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/open.c:982
-#, fuzzy
-msgid "Size of 'coor' file differs from value saved in sidx file"
-msgstr "का."
-#: ../lib/vector/Vlib/dgraph.c:430
-msgid "Trying to add more edges to the planar_graph than the initial allocation size allows"
-msgstr ""
-#: ../lib/vector/Vlib/area.c:47
-#, fuzzy
-msgid "Attempt to read points of nonexistent area"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/area.c:63
-#, fuzzy, c-format
-msgid "Unable to read read line %d"
-msgstr "के लिए n"
-#: ../lib/vector/Vlib/area.c:119
-#, fuzzy, c-format
-msgid "Unable to read line %d"
-msgstr "के लिए n"
-#: ../lib/vector/Vlib/area.c:158 ../lib/vector/Vlib/area.c:190
-#: ../lib/vector/Vlib/area.c:256 ../lib/vector/Vlib/area.c:285
-#, fuzzy, c-format
-msgid "Attempt to read topo for dead area (%d)"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/area.c:226 ../lib/vector/Vlib/area.c:312
-#, fuzzy, c-format
-msgid "Attempt to read topo for dead isle (%d)"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/cats.c:42
-msgid "Vect_new_cats_struct(): Out of memory"
-msgstr ""
-#: ../lib/vector/Vlib/cats.c:124
-#, c-format
-msgid "Too many categories (%d), unable to set cat %d (layer %d)"
-msgstr ""
-#: ../lib/vector/Vlib/cats.c:403
-#, c-format
-msgid "Unable to convert category string '%s' (from '%s') to category range"
-msgstr ""
-#: ../lib/vector/Vlib/graph.c:138
-#, fuzzy
-msgid "Unable to add network arc"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/intersect.c:125
-msgid "3D not supported by Vect_segment_intersection()"
-msgstr ""
-#: ../lib/vector/Vlib/intersect.c:320
-msgid "Vect_segment_intersection() ERROR (collinear vertical segments)"
-msgstr ""
-#: ../lib/vector/Vlib/intersect.c:446
-msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
-msgstr ""
-#: ../lib/vector/Vlib/intersect.c:1098 ../lib/vector/Vlib/intersect.c:1104
-#: ../lib/vector/Vlib/intersect.c:1106 ../lib/vector/Vlib/intersect.c:1154
-#: ../lib/vector/Vlib/intersect.c:1163 ../lib/vector/Vlib/intersect.c:1184
-#: ../lib/vector/Vlib/intersect.c:1201
-msgid "Error while adding point to array. Out of memory"
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:102
-msgid "Break polygons: Bug in binary tree!"
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:150
-msgid "Break polygons Pass 1: select break points"
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:280
-msgid "Break polygons Pass 2: break at selected points"
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:392
-#: ../lib/vector/Vlib/break_polygons.c:644
-#, c-format
-msgid "Breaks: %d"
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:429
-msgid "Breaking polygons (pass 1: select break points)..."
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:546
-msgid "Breaking polygons (pass 2: break at selected points)..."
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:586
-msgid "Point not in search tree!"
-msgstr ""
-#: ../lib/vector/Vlib/simple_features.c:179
-#, c-format
-msgid "Unknown Simple Features type (%d)"
-msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:361
-#, fuzzy
-msgid "Line is not looped"
-msgstr "नहीं"
-#: ../lib/vector/Vlib/buffer2.c:443
-#, c-format
-msgid "Unexpected result of line_intersection() res = %d"
-msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:589
-msgid "Next edge was visited (right) but it is not the first one !!! breaking loop"
-msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:600
-msgid "Next edge was visited (left) but it is not the first one !!! breaking loop"
-msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:648
-msgid "side != 0 feature not implemented"
-msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:890 ../lib/vector/Vlib/buffer2.c:937
-msgid "zero area size"
-msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:896 ../lib/vector/Vlib/buffer2.c:943
-#, fuzzy
-msgid "Line was not closed"
-msgstr "नहीं"
-#: ../lib/vector/Vlib/buffer2.c:909 ../lib/vector/Vlib/buffer2.c:960
-msgid "Vect_get_point_in_poly() failed"
-msgstr ""
-#: ../lib/vector/Vlib/array.c:96
-#, c-format
-msgid "%d errors in category string"
-msgstr ""
-#: ../lib/vector/Vlib/array.c:142 ../lib/vector/Vlib/array.c:267
-msgid "Mixed area and other type requested for vector array"
-msgstr ""
-#: ../lib/vector/Vlib/array.c:152 ../lib/vector/Vlib/array.c:175
-#: ../lib/vector/Vlib/array.c:304 ../lib/vector/Vlib/array.c:336
-msgid "Not enough space in vector array"
-msgstr ""
-#: ../lib/vector/Vlib/array.c:292
-#, fuzzy, c-format
-msgid "Unable to select record from table <%s> (key %s, where %s)"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/write.c:24 ../lib/vector/Vlib/write.c:30
-#: ../lib/vector/Vlib/write.c:36 ../lib/vector/Vlib/write.c:43
-#, fuzzy
-msgid "for this format/level not supported"
-#: ../lib/vector/Vlib/write.c:150
-#, fuzzy
-msgid "Unable to write feature, vector map is not opened"
-msgstr "है नहीं"
-#: ../lib/vector/Vlib/write.c:161
-#, fuzzy
-msgid "Unable to write feature (negative offset)"
-msgstr "a"
-#: ../lib/vector/Vlib/write.c:194
-#, fuzzy
-msgid "Unable to rewrite feature, vector map is not opened"
-msgstr "है नहीं"
-#: ../lib/vector/Vlib/write.c:207
-#, fuzzy, c-format
-msgid "Unable to rewrite feature %d"
-msgstr "का"
-#: ../lib/vector/Vlib/write.c:232
-#, fuzzy, c-format
-msgid "Unable to delete feature %d, vector map <%s> is not opened on topology level"
-#: ../lib/vector/Vlib/write.c:238
-#, fuzzy, c-format
-msgid "Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr "है नहीं"
-#: ../lib/vector/Vlib/write.c:250
-#, fuzzy, c-format
-msgid "Unable to delete feature id %d from vector map <%s>"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/write.c:276
-#, fuzzy, c-format
-msgid "Unable to restore feature %d, vector map <%s> is not opened on topology level"
-#: ../lib/vector/Vlib/write.c:282
-#, fuzzy, c-format
-msgid "Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr "है नहीं"
-#: ../lib/vector/Vlib/write.c:294
-#, fuzzy, c-format
-msgid "Unable to restore feature %d from vector map <%s>"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/break_lines.c:438
-#, c-format
-msgid "Intersections: %d"
-msgstr ""
-#: ../lib/vector/Vlib/close_ogr.c:105
-#, fuzzy, c-format
-msgid "Unable to open fidx file for write <%s>"
-msgstr "के लिए n"
-#: ../lib/vector/Vlib/cindex.c:29
-msgid "Category index is not up to date"
-msgstr ""
-#: ../lib/vector/Vlib/cindex.c:61 ../lib/vector/Vlib/cindex.c:127
-#: ../lib/vector/Vlib/cindex.c:147 ../lib/vector/Vlib/cindex.c:169
-msgid "Invalid layer index (index >= number of layers)"
-msgstr ""
-#: ../lib/vector/Vlib/cindex.c:109
-msgid "Invalid layer index (index < 0 or index >= number of layers)"
-msgstr ""
-#: ../lib/vector/Vlib/cindex.c:234
-#, fuzzy
-msgid "Layer or category index out of range"
-msgstr "दोगुना का"
-#: ../lib/vector/Vlib/cindex.c:284
-#, fuzzy
-msgid "Layer index out of range"
-msgstr "दोगुना का"
-#: ../lib/vector/Vlib/cindex.c:460
-#, fuzzy, c-format
-msgid "Unable to open cidx file <%s> for write"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/cindex.c:468
-#, fuzzy, c-format
-msgid "Error writing out category index file <%s>"
-msgstr "त्रुटि n"
-#: ../lib/vector/Vlib/field.c:87
-#, fuzzy
-msgid "Layer number must be 1 or greater"
-msgstr "फील्ड संख्या."
-#: ../lib/vector/Vlib/field.c:92
-#, fuzzy
-msgid "Unable to add attribute link, vector map is not opened in WRITE mode"
-msgstr "लिंक  है नहीं."
-#: ../lib/vector/Vlib/field.c:99
-#, fuzzy
-msgid "Unable to add attribute link"
-msgstr "लिंक ."
-#: ../lib/vector/Vlib/field.c:105
-#, fuzzy
-msgid "Unable to write attribute links"
-msgstr "a"
-#: ../lib/vector/Vlib/field.c:150
-#, fuzzy
-msgid "Unable to write database links"
-msgstr "a"
-#: ../lib/vector/Vlib/field.c:174
-msgid "Database connection not defined. Skipping."
-msgstr ""
-#: ../lib/vector/Vlib/field.c:181
-msgid "More DB links defined for input vector map. Using only first DB link for output."
-msgstr ""
-#: ../lib/vector/Vlib/field.c:256
-#, fuzzy, c-format
-msgid "Layer number %d or name <%s> already exists"
-msgstr "फील्ड संख्या"
-#: ../lib/vector/Vlib/field.c:347
-#, fuzzy
-msgid "Default driver is not set"
-msgstr "डिफ़ॉल्ट है नहीं सेट"
-#: ../lib/vector/Vlib/field.c:350
-#, fuzzy
-msgid "Default database is not set"
-#: ../lib/vector/Vlib/field.c:407
-#, fuzzy, c-format
-msgid "Requested dblink %d, maximum link number %d"
-msgstr "लिंक  संख्या"
-#: ../lib/vector/Vlib/field.c:614
-#, fuzzy, c-format
-msgid "Unable to open OGR layer <%s>"
-msgstr "का"
-#: ../lib/vector/Vlib/field.c:640
-#, fuzzy
-msgid "Unable to open OGR DBMI driver"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/field.c:679
-msgid "All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' available in OGR DB table"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:735
-#, fuzzy, c-format
-msgid "Don't know how to read links for format %d"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/field.c:769 ../lib/vector/Vlib/field.c:777
-#, fuzzy, c-format
-msgid "Error in rule on row %d in <%s>"
-msgstr "त्रुटि चालू"
-#: ../lib/vector/Vlib/field.c:852
-#, fuzzy, c-format
-msgid "Unable to open vector database definition file '%s'"
-msgstr "चालू"
-#: ../lib/vector/Vlib/field.c:947
-#, fuzzy
-msgid "Bug: attempt to update map which is not in current mapset"
-msgstr "है नहीं."
-#: ../lib/vector/Vlib/remove_areas.c:89
-msgid "Area is composed of dead boundary"
-msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:176
-#, c-format
-msgid "%d areas of total size %g removed"
-msgstr ""
-#: ../lib/vector/Vlib/read_ogr.c:165
-#, fuzzy
-msgid "OGR feature without ID"
-msgstr "विशेषता."
-#: ../lib/vector/Vlib/read_ogr.c:410
-#, fuzzy, c-format
-msgid "OGR feature type '%s' not supported"
-#: ../lib/vector/Vlib/read_ogr.c:528 ../lib/vector/Vlib/read_ogr.c:536
-#, c-format
-msgid "Unable to get feature geometry, FID %ld"
-msgstr ""
-#: ../lib/vector/Vlib/read_ogr.c:582
-#, fuzzy, c-format
-msgid "Attempt to read dead feature %d"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/write_ogr.c:57 ../lib/vector/Vlib/write_ogr.c:214
-msgid "Boundary is not closed. Skipping."
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:153
-#, c-format
-msgid "No category defined for layer %d"
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:155
-#, c-format
-msgid "Feature has more categories, using category %d (from layer %d)"
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:170
-msgid "Feature is not a point. Skipping."
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:178
-msgid "Feature is not a line. Skipping."
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:185
-msgid "Feature is not a polygon. Skipping."
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:192
-msgid "Feature is not a face. Skipping."
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:198
-#, fuzzy, c-format
-msgid "Unsupported feature type (%d)"
-msgstr "का"
-#: ../lib/vector/Vlib/write_ogr.c:345
-#, fuzzy
-msgid "Unable to calculate centroid for area"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/write_ogr.c:385 ../lib/vector/Vlib/write_ogr.c:417
-#, fuzzy
-msgid "Unable to rewrite feature (incompatible feature types)"
-msgstr "a"
-#: ../lib/vector/Vlib/write_ogr.c:562
-#, fuzzy, c-format
-msgid "Feature without category of layer %d"
-msgstr "विशेषता"
-#: ../lib/vector/Vlib/write_ogr.c:576
-#, fuzzy, c-format
-msgid "Unable to select attributes for category %d"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/write_ogr.c:581 ../lib/db/dbmi_client/copy_tab.c:314
-#, fuzzy, c-format
-msgid "Unable to fetch data from table <%s>"
-msgstr "का"
-#: ../lib/vector/Vlib/write_ogr.c:586
-#, fuzzy, c-format
-msgid "No database record for category %d, no attributes will be written"
-#: ../lib/vector/Vlib/write_ogr.c:619
-#, fuzzy, c-format
-msgid "Unable to create field <%s>"
-msgstr "का"
-#: ../lib/vector/Vlib/header.c:87 ../lib/vector/Vlib/header.c:137
-#, fuzzy, c-format
-msgid "Unable to open header file of vector <%s>"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/header.c:145
-#, c-format
-msgid "Corrupted row in head: %s"
-msgstr ""
-#: ../lib/vector/Vlib/header.c:183
-#, c-format
-msgid "Unknown keyword '%s' in vector head"
-msgstr ""
-#: ../lib/vector/Vlib/header.c:633 ../lib/gis/proj3.c:105
-msgid "Unknown projection"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:81
-#, fuzzy, c-format
-msgid "Error reading ASCII file: (bad type) [%s]"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/ascii.c:119
-#, fuzzy, c-format
-msgid "Error reading ASCII file: (unknown type) [%s]"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/ascii.c:132
-msgid "End of ASCII file reached before end of coordinates"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:143
-#, fuzzy, c-format
-msgid "Error reading ASCII file: (bad point) [%s]"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/ascii.c:147
-#, fuzzy, c-format
-msgid "Unparsable longitude value: [%s]"
-msgstr "का"
-#: ../lib/vector/Vlib/ascii.c:150
-#, c-format
-msgid "Unparsable latitude value: [%s]"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:183
-msgid "End of ASCII file reached before end of categories"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:193
-#, fuzzy, c-format
-msgid "Error reading categories: [%s]"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/ascii.c:240
-#, c-format
-msgid ""
-"Unexpected data in vector head:\n"
-"[%s]"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:274
-#, c-format
-msgid "Unknown keyword <%s> in vector head"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:482
-#, fuzzy, c-format
-msgid "Unknown feature type %d"
-msgstr "का"
-#: ../lib/vector/Vlib/ascii.c:517 ../lib/vector/Vlib/ascii.c:557
-#, fuzzy, c-format
-msgid "Unable to select record from table <%s> (key %s, column %s)"
-msgstr "के लिए"
-#: ../lib/vector/Vlib/ascii.c:547
-#, c-format
-msgid "Feature has more categories. Only first category (%d) is exported."
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:584
-#, fuzzy, c-format
-msgid "Column <%s>: unsupported data type"
-#: ../lib/vector/Vlib/ascii.c:664
-msgid "Unknown format"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:673
-msgid "Topology not available, unable to process areas"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:686
-#, fuzzy, c-format
-msgid "Unable to get boundary of area id %d"
-msgstr "के लिए n"
-#: ../lib/vector/Vlib/ascii.c:698
-#, fuzzy, c-format
-msgid "Unable to get boundary of isle id %d (area id %d)"
-msgstr "के लिए n"
-#: ../lib/vector/Vlib/select.c:104
-#, fuzzy, c-format
-msgid "Unable to delete item %d from spatial index"
-msgstr "का"
-#: ../lib/vector/vedit/delete.c:40
-#, fuzzy, c-format
-msgid "Attempt to delete dead feature (%d)"
-msgstr "के लिए"
-#: ../lib/vector/vedit/delete.c:72
-#, fuzzy, c-format
-msgid "No area found for centroid %d"
-msgstr "का n"
-#: ../lib/vector/vedit/delete.c:76
-#, c-format
-msgid "Duplicate centroid %d, unable to delete area"
-msgstr ""
-#: ../lib/vector/vedit/delete.c:105
-#, fuzzy, c-format
-msgid "Area %d without centroid"
-msgstr "का n"
-#: ../lib/vector/vedit/delete.c:121
-#, fuzzy, c-format
-msgid "Area %d has no boundaries"
-msgstr "नहीं"
-#: ../lib/vector/vedit/cats.c:63
-#, fuzzy, c-format
-msgid "Unable to set category %d for (feature id %d)"
-msgstr "के लिए n"
-#: ../lib/vector/vedit/select.c:231
-msgid "Unknown query tool"
-msgstr ""
-#: ../lib/cluster/c_exec.c:42
-#, c-format
-msgid "Not enough data points (%d) in cluster"
-msgstr ""
-#: ../lib/cluster/c_begin.c:57
-#, c-format
-msgid "produced by i.cluster"
-msgstr ""
-#: ../lib/psdriver/Graph_set.c:199
-#, c-format
-msgid "ps: truecolor status %s"
-msgstr ""
-#: ../lib/psdriver/Graph_set.c:214
-#, c-format
-msgid "ps: collecting to file '%s'"
-msgstr ""
-#: ../lib/psdriver/Graph_set.c:215
-#, c-format
-msgid "ps: image size %dx%d"
-msgstr ""
-#: ../lib/rst/interp_float/segmen2d.c:118
-#, fuzzy
-msgid "Taking too long to find points for interpolation - please change the region to area where your points are. Continuing calculations..."
-msgstr "के लिए."
-#: ../lib/rst/interp_float/interp2d.c:214
-#, c-format
-msgid "Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) cell. Z-value %f, zmin %f, zmax %f."
-msgstr ""
-#: ../lib/rst/interp_float/input2d.c:48
-#, fuzzy, c-format
-msgid "Mask raster map <%s> not found"
-msgstr "नहीं"
-#: ../lib/rst/interp_float/input2d.c:70
-msgid "Bitmap mask created"
-msgstr ""
-#: ../lib/rst/interp_float/write2d.c:40 ../lib/rst/interp_float/write2d.c:51
-#: ../lib/rst/interp_float/write2d.c:66 ../lib/rst/interp_float/write2d.c:75
-#: ../lib/rst/interp_float/write2d.c:83 ../lib/rst/interp_float/write2d.c:91
-#, fuzzy
-msgid "Cannot write files"
-msgstr "के लिए n"
-#: ../lib/rst/interp_float/output2d.c:106
-#, c-format
-msgid "First change your rows number to nsizr! %d %d"
-msgstr ""
-#: ../lib/rst/interp_float/output2d.c:113
-#, c-format
-msgid "First change your cols number to nsizc %d %d"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:73
-#, fuzzy, c-format
-msgid "Vector map <%s> is not 3D"
-msgstr "नहीं"
-#: ../lib/rst/interp_float/vinput2d.c:76
-msgid "Loading data from attribute table ..."
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:94
-#: ../lib/rst/interp_float/vinput2d.c:108 ../lib/db/dbmi_client/copy_tab.c:267
-#, fuzzy, c-format
-msgid "Column <%s> not found"
-#: ../lib/rst/interp_float/vinput2d.c:97
-#: ../lib/rst/interp_float/vinput2d.c:110
-#, fuzzy, c-format
-msgid "Data type of column <%s> must be numeric"
-#: ../lib/rst/interp_float/vinput2d.c:121
-#, fuzzy
-msgid "Reading features from vector map ..."
-msgstr "के लिए"
-#: ../lib/rst/interp_float/vinput2d.c:153
-#, fuzzy, c-format
-msgid "Database record for cat %d not found"
-#: ../lib/rst/interp_float/vinput2d.c:171
-msgid "Negative value of smoothing detected: sm must be >= 0"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:235
-msgid "Strip exists with insufficient data"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:249
-#, fuzzy, c-format
-msgid "There are points outside specified 2D/3D region - %d points ignored"
-msgstr "का."
-#: ../lib/rst/interp_float/vinput2d.c:252
-#, c-format
-msgid "Ignoring %d points (too dense)"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:256
-#, fuzzy, c-format
-msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
-msgstr "के लिए है कम"
-#: ../lib/rst/interp_float/vinput2d.c:261
-msgid "Zero points in the given region"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:266
-#, c-format
-msgid "Segmentation parameters set to invalid values: npmin= %d, segmax= %d for smooth connection of segments, npmin > segmax (see manual)"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:272
-#, fuzzy, c-format
-msgid "There are less than %d points for interpolation. No segmentation is necessary, to run the program faster set segmax=%d (see manual)"
-msgstr "कम के लिए नहीं है प्रोग्राम सेट"
-#: ../lib/rst/interp_float/vinput2d.c:276
-#, fuzzy, c-format
-msgid "Number of points from vector map %d"
-msgstr "का"
-#: ../lib/rst/interp_float/vinput2d.c:277
-#, fuzzy, c-format
-msgid "Number of points outside of 2D/3D region %d"
-msgstr "का n"
-#: ../lib/rst/interp_float/vinput2d.c:279
-#, fuzzy, c-format
-msgid "Number of points being used %d"
-#: ../lib/rst/interp_float/vinput2d.c:312
-#, fuzzy
-msgid "Some points outside of region (ignored)"
-msgstr "का."
-#: ../lib/rst/interp_float/vinput2d.c:318
-#, fuzzy
-msgid "Unable to allocate memory"
-msgstr "n"
-#: ../lib/rst/interp_float/vinput2d.c:326
-#, fuzzy, c-format
-msgid "Unable to insert %f,%f,%f a = %d"
-msgstr "का"
-#: ../lib/rst/interp_float/resout2d.c:77
-msgid "Temporarily changing the region to desired resolution..."
-msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:103
-#, c-format
-msgid "First change your rows number(%d) to %d"
-msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:110
-#, c-format
-msgid "First change your columns number(%d) to %d"
-msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:264
-msgid "No color table for input raster map -- will not create color table"
-msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:458
-msgid "Changing the region back to initial..."
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:139 ../lib/gis/rd_cellhd.c:150
-#: ../lib/gis/rd_cellhd.c:160 ../lib/gis/rd_cellhd.c:177
-#: ../lib/gis/rd_cellhd.c:193 ../lib/gis/rd_cellhd.c:201
-#: ../lib/gis/rd_cellhd.c:209 ../lib/gis/rd_cellhd.c:217
-#: ../lib/gis/rd_cellhd.c:225 ../lib/gis/rd_cellhd.c:233
-#: ../lib/gis/rd_cellhd.c:241 ../lib/gis/rd_cellhd.c:243
-#: ../lib/gis/rd_cellhd.c:251 ../lib/gis/rd_cellhd.c:253
-#: ../lib/gis/rd_cellhd.c:261 ../lib/gis/rd_cellhd.c:263
-#: ../lib/gis/rd_cellhd.c:271 ../lib/gis/rd_cellhd.c:273
-#: ../lib/gis/rd_cellhd.c:281 ../lib/gis/rd_cellhd.c:283
-#: ../lib/gis/rd_cellhd.c:291 ../lib/gis/rd_cellhd.c:293
-#: ../lib/gis/rd_cellhd.c:301 ../lib/gis/rd_cellhd.c:303
-#: ../lib/gis/rd_cellhd.c:311 ../lib/gis/rd_cellhd.c:313
-#: ../lib/gis/rd_cellhd.c:321 ../lib/gis/rd_cellhd.c:323
-#: ../lib/gis/rd_cellhd.c:331 ../lib/gis/rd_cellhd.c:333
-#: ../lib/gis/rd_cellhd.c:341 ../lib/gis/rd_cellhd.c:349
-#: ../lib/gis/rd_cellhd.c:353
-msgid "Syntax error in cell header"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:147
-#, fuzzy
-msgid "Duplicate projection field"
-msgstr "अनुकृति फील्ड"
-#: ../lib/gis/rd_cellhd.c:157
-#, fuzzy
-msgid "Duplicate zone field"
-#: ../lib/gis/rd_cellhd.c:167 ../lib/gis/rd_cellhd.c:169
-#: ../lib/gis/rd_cellhd.c:358 ../lib/gis/rd_cellhd.c:360
-#: ../lib/gis/rd_cellhd.c:362 ../lib/gis/rd_cellhd.c:364
-#: ../lib/gis/rd_cellhd.c:366 ../lib/gis/rd_cellhd.c:368
-#: ../lib/gis/rd_cellhd.c:379 ../lib/gis/rd_cellhd.c:381
-#: ../lib/gis/rd_cellhd.c:383 ../lib/gis/rd_cellhd.c:385
-#, fuzzy, c-format
-msgid "Field <%s> missing"
-msgstr "फील्ड"
-#: ../lib/gis/rd_cellhd.c:191
-#, fuzzy
-msgid "Duplicate north field"
-msgstr "अनुकृति उत्तर फील्ड"
-#: ../lib/gis/rd_cellhd.c:199
-#, fuzzy
-msgid "Duplicate south field"
-msgstr "अनुकृति दक्षिण फील्ड"
-#: ../lib/gis/rd_cellhd.c:207
-#, fuzzy
-msgid "Duplicate east field"
-msgstr "अनुकृति पूर्व फील्ड"
-#: ../lib/gis/rd_cellhd.c:215
-#, fuzzy
-msgid "Duplicate west field"
-msgstr "अनुकृति पश्चिम फील्ड"
-#: ../lib/gis/rd_cellhd.c:223
-#, fuzzy
-msgid "Duplicate top field"
-msgstr "अनुकृति शीर्ष फील्ड"
-#: ../lib/gis/rd_cellhd.c:231
-#, fuzzy
-msgid "Duplicate bottom field"
-msgstr "अनुकृति तल फील्ड"
-#: ../lib/gis/rd_cellhd.c:239
-#, fuzzy
-msgid "Duplicate e-w resolution field"
-#: ../lib/gis/rd_cellhd.c:249
-#, fuzzy
-msgid "Duplicate 3D e-w resolution field"
-#: ../lib/gis/rd_cellhd.c:259
-#, fuzzy
-msgid "Duplicate n-s resolution field"
-msgstr "अनुकृति n फील्ड"
-#: ../lib/gis/rd_cellhd.c:269
-#, fuzzy
-msgid "Duplicate 3D n-s resolution field"
-#: ../lib/gis/rd_cellhd.c:279
-#, fuzzy
-msgid "Duplicate t-b resolution field"
-#: ../lib/gis/rd_cellhd.c:289
-#, fuzzy
-msgid "Duplicate rows field"
-#: ../lib/gis/rd_cellhd.c:299
-#, fuzzy
-msgid "Duplicate 3D rows field"
-#: ../lib/gis/rd_cellhd.c:309
-#, fuzzy
-msgid "Duplicate cols field"
-#: ../lib/gis/rd_cellhd.c:319
-#, fuzzy
-msgid "Duplicate 3D cols field"
-#: ../lib/gis/rd_cellhd.c:329
-#, fuzzy
-msgid "Duplicate depths field"
-#: ../lib/gis/rd_cellhd.c:339
-#, fuzzy
-msgid "Duplicate format field"
-#: ../lib/gis/rd_cellhd.c:347
-#, fuzzy
-msgid "Duplicate compressed field"
-#: ../lib/gis/parser_help.c:79
-#, fuzzy
-msgid "Description:"
-msgstr "n"
-#: ../lib/gis/parser_help.c:89
-msgid "Keywords:"
-msgstr ""
-#: ../lib/gis/parser_help.c:97
-#, fuzzy
-msgid "Usage:"
-msgstr "n "
-#: ../lib/gis/parser_help.c:127
-#, fuzzy
-msgid "ERROR: Option key not defined"
-msgstr "विशेषता."
-#: ../lib/gis/parser_help.c:171
-#, fuzzy
-msgid "Flags:"
-msgstr "n"
-#: ../lib/gis/parser_help.c:194 ../lib/gis/parser_interface.c:329
-#: ../lib/gis/parser_html.c:149
-msgid "Allow output files to overwrite existing files"
-msgstr ""
-#: ../lib/gis/parser_help.c:196 ../lib/gis/parser_interface.c:337
-#: ../lib/gis/parser_html.c:153
-msgid "Verbose module output"
-msgstr ""
-#: ../lib/gis/parser_help.c:197 ../lib/gis/parser_interface.c:344
-#: ../lib/gis/parser_html.c:156
-msgid "Quiet module output"
-msgstr ""
-#: ../lib/gis/parser_help.c:205
-#, fuzzy
-msgid "Parameters:"
-msgstr "n"
-#: ../lib/gis/parser_help.c:228
-#, fuzzy, c-format
-msgid "  %*s   default: %s\n"
-msgstr "n"
-#: ../lib/gis/parser_help.c:254
-#, c-format
-msgid "  %*s   options: "
-msgstr ""
-#: ../lib/gis/get_ellipse.c:343 ../lib/gis/get_ellipse.c:366
-#, fuzzy, c-format
-msgid "Invalid a: field '%s' in file %s in <%s>"
-msgstr "अवैध a फील्ड"
-#: ../lib/gis/get_ellipse.c:355
-#, fuzzy, c-format
-msgid "Invalid ellipsoid '%s' in file %s in <%s>"
-msgstr "अवैध"
-#: ../lib/gis/get_ellipse.c:369
-#, fuzzy, c-format
-msgid "Invalid es: field '%s' in file %s in <%s>"
-msgstr "अवैध फील्ड"
-#: ../lib/gis/get_ellipse.c:382
-#, fuzzy, c-format
-msgid "No ellipsoid info given in file %s in <%s>"
-msgstr "नहीं"
-#: ../lib/gis/legal_name.c:38
-#, fuzzy, c-format
-msgid "Illegal filename <%s>. Cannot be '.' or 'NULL'."
-msgstr "फ़ाइलनाम  n"
-#: ../lib/gis/legal_name.c:45
-#, fuzzy, c-format
-msgid "Illegal filename <%s>. Character <%c> not allowed.\n"
-msgstr "फ़ाइलनाम  नहीं."
-#: ../lib/gis/legal_name.c:74 ../lib/gis/legal_name.c:78
-#, fuzzy, c-format
-msgid "Output raster map name <%s> is not valid map name"
-msgstr "है नहीं."
-#: ../lib/gis/legal_name.c:115 ../lib/gis/legal_name.c:119
-#, fuzzy, c-format
-msgid "Output raster map <%s> is used as input"
-msgstr "है"
-#: ../lib/gis/ls.c:99
-#, fuzzy, c-format
-msgid "Unable to open directory %s"
-msgstr "के लिए"
-#: ../lib/gis/env.c:260
-#, fuzzy
-msgid "GISRC - variable not set"
-msgstr "चर नहीं सेट"
-#: ../lib/gis/env.c:292 ../lib/gis/env.c:318
-#, fuzzy, c-format
-msgid "Variable '%s' not set"
-#: ../lib/gis/gisinit.c:50 ../lib/gis/gisinit.c:82
-msgid "Incompatible library version for module. You need to rebuild GRASS or untangle multiple installations."
-msgstr ""
-#: ../lib/gis/gisinit.c:60
-#, c-format
-msgid "MAPSET %s - permission denied"
-msgstr ""
-#: ../lib/gis/gisinit.c:63
-#, fuzzy, c-format
-msgid "MAPSET %s not found"
-msgstr "नहीं"
-#: ../lib/gis/gisinit.c:96
-#, fuzzy
-msgid "System not initialized. Programmer forgot to call G_gisinit()."
-msgstr "त्रुटि नहीं जी n"
-#: ../lib/gis/seek.c:52 ../lib/gis/seek.c:58
-#, fuzzy
-msgid "Unable to seek"
-msgstr "का"
-#: ../lib/gis/seek.c:56
-#, fuzzy
-msgid "Seek offset out of range"
-msgstr "दोगुना का"
-#: ../lib/gis/adj_cellhd.c:44 ../lib/gis/adj_cellhd.c:192
-#, fuzzy
-msgid "Illegal n-s resolution value"
-msgstr "n"
-#: ../lib/gis/adj_cellhd.c:48 ../lib/gis/adj_cellhd.c:198
-msgid "Illegal row value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:52 ../lib/gis/adj_cellhd.c:204
-msgid "Illegal e-w resolution value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:56 ../lib/gis/adj_cellhd.c:210
-msgid "Illegal col value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:76 ../lib/gis/adj_cellhd.c:240
-#, c-format
-msgid "Fixing subtle input data rounding error of north boundary (%g>%g)"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:81 ../lib/gis/adj_cellhd.c:245
-#, fuzzy
-msgid "Illegal latitude for North"
-msgstr "के लिए"
-#: ../lib/gis/adj_cellhd.c:87 ../lib/gis/adj_cellhd.c:251
-#, c-format
-msgid "Fixing subtle input data rounding error of south boundary (%g>%g)"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:92 ../lib/gis/adj_cellhd.c:256
-#, fuzzy
-msgid "Illegal latitude for South"
-msgstr "के लिए"
-#: ../lib/gis/adj_cellhd.c:104 ../lib/gis/adj_cellhd.c:268
-#, c-format
-msgid "Fixing subtle input data rounding error of west boundary (%g>%g)"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:115 ../lib/gis/adj_cellhd.c:279
-#, c-format
-msgid "Fixing subtle input data rounding error of east boundary (%g>%g)"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:128 ../lib/gis/adj_cellhd.c:292
-#, fuzzy
-msgid "North must be north of South"
-msgstr "उत्तर का"
-#: ../lib/gis/adj_cellhd.c:130 ../lib/gis/adj_cellhd.c:294
-msgid "North must be larger than South"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:133 ../lib/gis/adj_cellhd.c:297
-#, fuzzy
-msgid "East must be larger than West"
-msgstr "पूर्व पश्चिम"
-#: ../lib/gis/adj_cellhd.c:152 ../lib/gis/adj_cellhd.c:341
-msgid "Invalid coordinates"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:194
-#, fuzzy
-msgid "Illegal n-s3 resolution value"
-msgstr "n"
-#: ../lib/gis/adj_cellhd.c:200
-msgid "Illegal row3 value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:206
-msgid "Illegal e-w3 resolution value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:212
-msgid "Illegal col3 value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:216
-msgid "Illegal t-b3 resolution value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:220
-msgid "Illegal depths value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:299
-#, fuzzy
-msgid "Top must be larger than Bottom"
-#: ../lib/gis/color_rules.c:88
-#, fuzzy
-msgid "no description"
-msgstr "n"
-#: ../lib/gis/error.c:342
-msgid "WARNING: "
-msgstr ""
-#: ../lib/gis/error.c:343
-#, fuzzy
-msgid "ERROR: "
-msgstr "त्रुटि "
-#: ../lib/gis/mapset_msc.c:61
-#, fuzzy, c-format
-msgid "Unable to make mapset element %s (%s): %s"
-msgstr "का"
-#: ../lib/gis/mapset_msc.c:65
-#, fuzzy, c-format
-msgid "Unable to access mapset element %s (%s): %s"
-msgstr "का"
-#: ../lib/gis/parser.c:376
-#, c-format
-msgid "BUG in descriptions, option '%s' in <%s> does not exist"
-msgstr ""
-#: ../lib/gis/parser.c:484
-msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
-msgstr ""
-#: ../lib/gis/parser.c:498
-msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
-msgstr ""
-#: ../lib/gis/parser.c:529
-#, fuzzy, c-format
-msgid "Sorry <%s> is not a valid option"
-msgstr "खेद है है नहीं a n"
-#: ../lib/gis/parser.c:561
-#, fuzzy
-msgid "ERROR"
-msgstr "त्रुटि "
-#: ../lib/gis/parser.c:788
-#, fuzzy
-msgid "Unable to determine program name"
-msgstr "a"
-#: ../lib/gis/parser.c:804 ../lib/gis/parser.c:821
-#, fuzzy, c-format
-msgid "Sorry, <%c> is not a valid flag"
-#: ../lib/gis/parser.c:920
-#, fuzzy, c-format
-msgid "Sorry, <%s=> is ambiguous"
-msgstr "खेद है है n"
-#: ../lib/gis/parser.c:927
-#, fuzzy, c-format
-msgid "Sorry, <%s> is not a valid parameter"
-#: ../lib/gis/parser.c:935
-#, c-format
-msgid "Option <%s> does not accept multiple answers"
-msgstr ""
-#: ../lib/gis/parser.c:1006
-#, fuzzy, c-format
-msgid ""
-"Illegal range syntax for parameter <%s>\n"
-"\tPresented as: %s"
-msgstr "के लिए n"
-#: ../lib/gis/parser.c:1012
-#, fuzzy, c-format
-msgid ""
-"Value <%s> out of range for parameter <%s>\n"
-"\tLegal range: %s"
-msgstr "का के लिए n"
-#: ../lib/gis/parser.c:1018
-#, fuzzy, c-format
-msgid "Missing value for parameter <%s>"
-msgstr "गुमा के लिए n"
-#: ../lib/gis/parser.c:1024
-#, fuzzy, c-format
-msgid ""
-"Value <%s> ambiguous for parameter <%s>\n"
-"\tValid options: %s"
-#: ../lib/gis/parser.c:1168
-#, fuzzy, c-format
-msgid ""
-"Required parameter <%s> not set:\n"
-"\t(%s)"
-msgstr ""
-"नहीं सेट\n"
-" n"
-#: ../lib/gis/parser.c:1260
-#, fuzzy, c-format
-msgid ""
-"Option <%s> must be provided in multiples of %d\n"
-"\tYou provided %d item(s): %s"
-msgstr "का n"
-#: ../lib/gis/parser.c:1334
-#, fuzzy, c-format
-msgid "ERROR: option <%s>: <%s> exists.\n"
-msgstr "त्रुटि n"
-#: ../lib/gis/home.c:35
-#, fuzzy
-msgid "Unable to determine user's home directory"
-msgstr "a"
-#: ../lib/gis/home.c:112
-#, fuzzy, c-format
-msgid "Failed to create directory [%s]"
-msgstr "के लिए"
-#: ../lib/gis/list.c:83
-#, fuzzy, c-format
-msgid "no %s files available in current mapset\n"
-msgstr "n"
-#: ../lib/gis/list.c:86
-#, fuzzy, c-format
-msgid "no %s files available in mapset <%s>\n"
-msgstr "n"
-#: ../lib/gis/list.c:132
-#, fuzzy, c-format
-msgid "%s files available in mapset <%s>:\n"
-msgstr "n"
-#: ../lib/gis/list.c:204
-msgid "G_list: Unknown element type"
-msgstr ""
-#: ../lib/gis/timestamp.c:292
-#, fuzzy, c-format
-msgid "Unable to create timestamp file for %s map <%s@%s>"
-msgstr "के लिए"
-#: ../lib/gis/timestamp.c:301
-#, fuzzy, c-format
-msgid "Invalid timestamp specified for %s map <%s@%s>"
-msgstr "के लिए"
-#: ../lib/gis/timestamp.c:331
-#, fuzzy, c-format
-msgid "Unable to open timestamp file for %s map <%s@%s>"
-msgstr "के लिए"
-#: ../lib/gis/timestamp.c:340
-#, fuzzy, c-format
-msgid "Invalid timestamp file for %s map <%s@%s>"
-msgstr "के लिए"
-#: ../lib/gis/timestamp.c:479
-#, fuzzy, c-format
-msgid "Unable to open timestamp file for vector map <%s@%s>"
-msgstr "के लिए"
-#: ../lib/gis/timestamp.c:488
-#, fuzzy, c-format
-msgid "Invalid timestamp file for vector map <%s@%s>"
-msgstr "के लिए"
-#: ../lib/gis/timestamp.c:524
-#, fuzzy, c-format
-msgid "Unable to create timestamp file for vector map <%s@%s>"
-msgstr "के लिए"
-#: ../lib/gis/timestamp.c:533
-#, fuzzy, c-format
-msgid "Invalid timestamp specified for vector map <%s@%s>"
-msgstr "के लिए"
-#: ../lib/gis/datum.c:160
-#, c-format
-msgid "unable to open datum table file: %s"
-msgstr ""
-#: ../lib/gis/datum.c:182
-#, fuzzy, c-format
-msgid "error in datum table file, line %d"
-msgstr "त्रुटि"
-#: ../lib/gis/open.c:62
-#, c-format
-msgid "G__open(read): mapset <%s> doesn't match xmapset <%s>"
-msgstr ""
-#: ../lib/gis/open.c:84
-#, c-format
-msgid "G__open(write): xmapset <%s> != G_mapset() <%s>"
-msgstr ""
-#: ../lib/gis/units.c:139
-msgid "square units"
-msgstr ""
-msgid "square unit"
-msgstr ""
-#: ../lib/gis/units.c:141 ../lib/gis/proj3.c:58
-msgid "units"
-msgstr ""
-msgid "unit"
-msgstr ""
-#: ../lib/gis/units.c:146
-#, fuzzy
-msgid "square meters"
-msgstr "n"
-#, fuzzy
-msgid "square meter"
-msgstr "n"
-#: ../lib/gis/units.c:148
-#, fuzzy
-msgid "meters"
-msgstr "n"
-#, fuzzy
-msgid "meter"
-msgstr "n"
-#: ../lib/gis/units.c:153
-msgid "square kilometers"
-msgstr ""
-msgid "square kilometer"
-msgstr ""
-#: ../lib/gis/units.c:155
-#, fuzzy
-msgid "kilometers"
-msgstr "n"
-msgid "kilometer"
-msgstr ""
-#: ../lib/gis/units.c:160
-msgid "acres"
-msgstr ""
-msgid "acre"
-msgstr ""
-#: ../lib/gis/units.c:168
-msgid "hectares"
-msgstr ""
-msgid "hectare"
-msgstr ""
-#: ../lib/gis/units.c:176
-msgid "square miles"
-msgstr ""
-msgid "square mile"
-msgstr ""
-#: ../lib/gis/units.c:178
-msgid "miles"
-msgstr ""
-msgid "mile"
-msgstr ""
-#: ../lib/gis/units.c:183
-msgid "square feet"
-msgstr ""
-msgid "square foot"
-msgstr ""
-#: ../lib/gis/units.c:185
-msgid "feet"
-msgstr ""
-msgid "foot"
-msgstr ""
-#: ../lib/gis/units.c:190
-msgid "square degrees"
-msgstr ""
-msgid "square degree"
-msgstr ""
-#: ../lib/gis/units.c:192
-msgid "degrees"
-msgstr ""
-msgid "degree"
-msgstr ""
-#: ../lib/gis/spawn.c:385
-#, c-format
-msgid "CreateProcess() failed: error = %d"
-msgstr ""
-#: ../lib/gis/spawn.c:416
-#, fuzzy, c-format
-msgid "G_spawn: unable to redirect descriptor %d"
-msgstr "जी अनुकृति"
-#: ../lib/gis/spawn.c:424 ../lib/gis/spawn.c:611
-#, fuzzy, c-format
-msgid "G_spawn: unable to open file %s"
-msgstr "जी"
-#: ../lib/gis/spawn.c:495 ../lib/gis/spawn.c:681
-#, fuzzy
-msgid "Unable to execute command"
-msgstr "n"
-#: ../lib/gis/spawn.c:520 ../lib/gis/spawn.c:528
-#, fuzzy, c-format
-msgid "G_spawn: unable to restore signal %d"
-msgstr "जी"
-#: ../lib/gis/spawn.c:559
-#, fuzzy, c-format
-msgid "G_spawn: unable to reset signal %d"
-msgstr "जी"
-#: ../lib/gis/spawn.c:568
-#, fuzzy, c-format
-msgid "G_spawn: unable to ignore signal %d"
-msgstr "जी"
-#: ../lib/gis/spawn.c:579
-#, fuzzy, c-format
-msgid "G_spawn: unable to block signal %d"
-msgstr "जी ब्लॉक"
-#: ../lib/gis/spawn.c:587
-#, fuzzy, c-format
-msgid "G_spawn: unable to unblock signal %d"
-msgstr "जी"
-#: ../lib/gis/spawn.c:616 ../lib/gis/spawn.c:625
-#, fuzzy, c-format
-msgid "G_spawn: unable to duplicate descriptor %d to %d"
-#: ../lib/gis/spawn.c:658
-#, fuzzy
-msgid "Unable to create a new process"
-msgstr "a"
-#: ../lib/gis/spawn.c:673
-#, fuzzy, c-format
-msgid "Unable to change directory to %s"
-msgstr "के लिए"
-#: ../lib/gis/key_value3.c:37
-#, fuzzy, c-format
-msgid "Error writing file <%s>"
-msgstr "त्रुटि n"
-#: ../lib/gis/key_value3.c:40
-#, fuzzy, c-format
-msgid "Error closing output file <%s>"
-msgstr "का"
-#: ../lib/gis/key_value3.c:65
-#, fuzzy, c-format
-msgid "Error reading file <%s>"
-msgstr "के लिए"
-#: ../lib/gis/key_value3.c:68
-#, fuzzy, c-format
-msgid "Error closing input file <%s>"
-msgstr "जी"
-#: ../lib/gis/paths.c:205
-#, fuzzy, c-format
-msgid "Unable to open file <%s> for reading"
-msgstr "के लिए"
-#: ../lib/gis/paths.c:221
-#, fuzzy, c-format
-msgid "Unable to fetch security info for <%s>"
-msgstr "के लिए"
-#: ../lib/gis/paths.c:237
-#, fuzzy
-msgid "Unable to look up account id"
-msgstr "के लिए"
-#: ../lib/gis/paths.c:244
-#, fuzzy
-msgid "Unable to allocate memory for account name"
-msgstr "n"
-#: ../lib/gis/paths.c:250
-#, fuzzy
-msgid "Unable to allocate memory for domain name"
-msgstr "n"
-#: ../lib/gis/location.c:60
-#, fuzzy, c-format
-msgid "LOCATION << %s >> not available"
-msgstr "नहीं"
-#: ../lib/gis/myname.c:46
-msgid "This location has no description."
-msgstr ""
-#: ../lib/gis/proj2.c:64
-msgid "State Plane"
-msgstr ""
-#: ../lib/gis/proj2.c:66
-msgid "Latitude-Longitude"
-msgstr ""
-#: ../lib/gis/proj2.c:68
-msgid "Other Projection"
-msgstr ""
-#: ../lib/gis/alloc.c:41
-#, c-format
-msgid "G_malloc: unable to allocate %lu bytes of memory at %s:%d"
-msgstr ""
-#: ../lib/gis/alloc.c:76
-#, c-format
-msgid "G_calloc: unable to allocate %lu * %lu bytes of memory at %s:%d"
-msgstr ""
-#: ../lib/gis/alloc.c:115
-#, c-format
-msgid "G_realloc: unable to allocate %lu bytes of memory at %s:%d"
-msgstr ""
-#: ../lib/gis/open_misc.c:45
-#, c-format
-msgid "G__open_misc(read): mapset <%s> doesn't match xmapset <%s>"
-msgstr ""
-#: ../lib/gis/open_misc.c:67
-#, c-format
-msgid "G__open_misc(write): xmapset <%s> != G_mapset() <%s>"
-msgstr ""
-#: ../lib/gis/get_window.c:117
-#, fuzzy, c-format
-msgid "Unable to open element file <%s> for <%s@%s>"
-msgstr "के लिए"
-#: ../lib/gis/get_projinfo.c:34 ../lib/gis/get_projinfo.c:60
-#, fuzzy, c-format
-msgid "<%s> file not found for location <%s>"
-#: ../lib/gis/parser_standard_options.c:111
-#, fuzzy
-msgid "WHERE conditions of SQL statement without 'where' keyword"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:112
-msgid "Example: income < 1000 and inhab >= 10000"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:120
-msgid "Table name"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:129
-msgid "Driver name"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:138
-msgid "Database name"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:147
-msgid "Database schema"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:148
-msgid "Do not use this option if schemas are not supported by driver/database server"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:157
-#, fuzzy
-msgid "Name of attribute column"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:166
-#, fuzzy
-msgid "Name of attribute column(s)"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:175
-#, fuzzy
-msgid "Name of key column"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:176
-msgid "Must refer to an integer column"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:188
-#, fuzzy
-msgid "Name of input imagery group"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:196
-#, fuzzy
-msgid "Name of input imagery subgroup"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:206
-#, fuzzy
-msgid "Name of input raster map"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:215
-#, fuzzy
-msgid "Name of input raster map(s)"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:223
-#, fuzzy
-msgid "Name for output raster map"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:231
-#, fuzzy
-msgid "Name of raster map"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:240
-#, fuzzy
-msgid "Name of raster map(s)"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:248
-#, fuzzy
-msgid "Name of base raster map"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:256
-#, fuzzy
-msgid "Name of cover raster map"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:264
-#, fuzzy
-msgid "Name of input elevation raster map"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:273
-#, fuzzy
-msgid "Name of input elevation raster map(s)"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:283
-#, fuzzy
-msgid "Name of input 3D raster map"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:292
-#, fuzzy
-msgid "Name of input 3D raster map(s)"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:300
-#, fuzzy
-msgid "Name for output 3D raster map"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:308
-#, fuzzy
-msgid "Name of 3D raster map"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:317
-#, fuzzy
-msgid "Name of 3D raster map(s)"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:326
-#, fuzzy
-msgid "Data type used in the output raster3d map"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:335
-msgid "Number of digits used as mantissa in the internal map storage, 0 -23 for float, 0 - 52 for double, max or default"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:345
-msgid "The compression method used in the output raster3d map"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:355
-msgid "The dimensions of the tiles used in the output raster3d map (XxYxZ or default: 16x16x8)"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:365
-#, fuzzy
-msgid "Name of input vector map"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:366
-#: ../lib/gis/parser_standard_options.c:393
-msgid "Or data source for direct OGR access"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:375
-#, fuzzy
-msgid "Name of input vector map(s)"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:376
-msgid "Or data source(s) for direct OGR access"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:384
-#, fuzzy
-msgid "Name for output vector map"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:392
-#, fuzzy
-msgid "Name of vector map"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:402
-#, fuzzy
-msgid "Name of vector map(s)"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:411
-#: ../lib/gis/parser_standard_options.c:420
-msgid "Feature type"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:427
-#, fuzzy
-msgid "Layer number or name"
-msgstr "संख्या"
-#: ../lib/gis/parser_standard_options.c:429
-#: ../lib/gis/parser_standard_options.c:441
-msgid "A single vector map can be connected to multiple database tables. This number determines which table to use. When used with direct OGR access this is the layer name."
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:439
-#, fuzzy
-msgid "Layer number or name ('-1' for all layers)"
-#: ../lib/gis/parser_standard_options.c:450
-msgid "Category value"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:457
-msgid "Category values"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:458
-#: ../lib/gis/parser_standard_options.c:472
-#, fuzzy
-msgid "Example: 1,3,7-9,13"
-msgstr "13"
-#: ../lib/gis/parser_standard_options.c:464
-msgid "Feature id"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:471
-msgid "Feature ids"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:482
-#, fuzzy
-msgid "Name of input file"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:490
-#, fuzzy
-msgid "Name for output file"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:498
-msgid "Field separator"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:499
-msgid "Special characters: newline, space, comma, tab"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:510
-msgid "Color"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:511
-msgid "Either a standard color name or R:G:B triplet"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:520
-msgid "Background color"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:522
-msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:533
-#, fuzzy
-msgid "Name to input directory"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:543
-msgid "Units"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:552
-msgid "Data type(s)"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:562
-msgid "Name of mapset (default: current search path)"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:563
-msgid "'.' for current mapset"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:572
-msgid "Coordinates"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:581
-#, fuzzy
-msgid "Name of color table"
-msgstr "का"
-#: ../lib/gis/parser_standard_options.c:614
-#, fuzzy
-msgid "Do not create attribute table"
-msgstr "a"
-#: ../lib/gis/done_msg.c:38
-#, fuzzy, c-format
-msgid "%s complete. %s"
-msgstr "n"
-#: ../lib/gis/view.c:176
-#, fuzzy, c-format
-msgid "Unable to open %s for writing"
-msgstr "के लिए"
-#: ../lib/gis/view.c:262 ../lib/gis/view.c:479
-#, fuzzy, c-format
-msgid "Unable to open %s for reading"
-msgstr "के लिए"
-#: ../lib/gis/view.c:465
-#, fuzzy, c-format
-msgid "GRASS window when view was saved:\n"
-msgstr "n"
-#: ../lib/gis/view.c:545
-#, fuzzy, c-format
-msgid " Window saved in \"%s\" is completely outside of current GRASS window."
-msgstr "है का."
-#: ../lib/gis/view.c:549
-#, fuzzy, c-format
-msgid " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
-msgstr "का."
-#: ../lib/gis/parser_html.c:40
-msgid "NAME"
-msgstr ""
-#: ../lib/gis/parser_html.c:53
-msgid "KEYWORDS"
-msgstr ""
-#: ../lib/gis/parser_html.c:58
-msgid "SYNOPSIS"
-msgstr ""
-#: ../lib/gis/parser_html.c:204
-#, fuzzy
-msgid "Options"
-msgstr "n"
-#: ../lib/gis/parser_html.c:210
-#, fuzzy
-msgid "Default"
-msgstr "n"
-#: ../lib/gis/mapset.c:37
-#, fuzzy
-msgid "MAPSET is not set"
-msgstr "है नहीं सेट"
-#: ../lib/gis/distance.c:154
-#, c-format
-msgid "%s: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
-msgstr ""
-#: ../lib/gis/debug.c:81
-#, c-format
-msgid "Cannot open debug file '%s'"
-msgstr ""
-#: ../lib/gis/find_file.c:80
-#, c-format
-msgid "'%s/%s' was found in more mapsets (also found in <%s>)"
-msgstr ""
-#: ../lib/gis/find_file.c:88
-#, fuzzy, c-format
-msgid "Using <%s@%s>"
-msgstr "का"
-#: ../lib/gis/worker.c:72
-msgid "Task already has a worker"
-msgstr ""
-#: ../lib/db/dbmi_client/delete_tab.c:40 ../lib/db/dbmi_client/table.c:46
-#, fuzzy, c-format
-msgid "Unable open database <%s> by driver <%s>"
-msgstr "के लिए"
-#: ../lib/db/dbmi_client/delete_tab.c:53
-#, fuzzy, c-format
-msgid "Unable to drop table: '%s'"
-msgstr "का"
-#: ../lib/db/dbmi_client/copy_tab.c:91
-#, c-format
-msgid "Array of values to select from column <%s> is empty"
-msgstr ""
-#: ../lib/db/dbmi_client/copy_tab.c:151
-#, fuzzy, c-format
-msgid "Unable to get list tables in database <%s>"
-msgstr "का"
-#: ../lib/db/dbmi_client/copy_tab.c:167
-#, fuzzy, c-format
-msgid "Table <%s> already exists in database and will be overwritten"
-msgstr "का"
-#: ../lib/db/dbmi_client/copy_tab.c:172
-#, fuzzy, c-format
-msgid "Table <%s> already exists in database <%s>"
-msgstr "का"
-#: ../lib/db/dbmi_client/copy_tab.c:250
-#, fuzzy, c-format
-msgid "Column <%s> is not integer"
-#: ../lib/db/dbmi_client/copy_tab.c:270
-#, fuzzy, c-format
-msgid "Unable to create table <%s>"
-msgstr "का"
-#: ../lib/db/dbmi_client/copy_tab.c:370
-#, fuzzy, c-format
-msgid "Unknown column type (column <%s>)"
-msgstr "का"
-#: ../lib/db/dbmi_client/select.c:119 ../lib/db/dbmi_client/select.c:220
-#: ../lib/db/dbmi_client/select.c:286
-msgid "Missing column name"
-msgstr ""
-#: ../lib/db/dbmi_client/select.c:215 ../lib/db/dbmi_client/select.c:281
-msgid "Missing key column name"
-msgstr ""
-#: ../lib/db/dbmi_client/select.c:314
-#, fuzzy, c-format
-msgid "Unable select records from table <%s>"
-msgstr "के लिए"
-#: ../lib/db/dbmi_client/select.c:330
-#, fuzzy
-msgid "Key column type is not integer"
-#: ../lib/db/dbmi_driver/d_error.c:57
-#, c-format
-msgid "DBMI-%s driver error:"
-msgstr ""
-#: ../lib/db/dbmi_base/valuefmt.c:52
-msgid "db_convert_Cstring_to_value(): unrecognized sqltype"
-msgstr ""
-#: ../lib/db/dbmi_base/valuefmt.c:91
-msgid "db_convert_value_into_string(): unrecongized sqltype-type"
-msgstr ""
-#: ../lib/db/dbmi_base/login.c:111
-msgid "Login file corrupted"
-msgstr ""
-#: ../lib/db/dbmi_base/error.c:72
-msgid "<NULL error message>"
-msgstr ""
-#: ../lib/db/dbmi_base/error.c:91
-msgid "dbmi: Protocol error"
-msgstr ""
-#: ../lib/db/dbmi_base/error.c:136
-msgid "dbmi: Out of Memory"
-msgstr ""
-#: ../lib/db/dbmi_base/error.c:149
-#, c-format
-msgid "dbmi: %s() not implemented"
-msgstr ""
-#: ../lib/db/dbmi_base/error.c:163
-#, c-format
-msgid "dbmi: Invalid procedure %d"
-msgstr ""
-#: ../lib/db/dbmi_base/index.c:180
-msgid "db_set_index_column_name(): invalid column number"
-msgstr ""
-#: ../lib/db/dbmi_base/index.c:197
-msgid "db_get_index_column_name(): invalid column number"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_table.c:38
-msgid ""
-"\n"
-"++ Running table unit tests ++"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_table.c:43
-msgid ""
-"\n"
-"-- Table unit tests failure --"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_table.c:45
-msgid ""
-"\n"
-"-- Table unit tests finished successfully --"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:37
-msgid ""
-"\n"
-"++ Running column unit tests ++"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:42
-msgid ""
-"\n"
-"-- column unit tests failure --"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:44
-msgid ""
-"\n"
-"-- column unit tests finished successfully --"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:57
-msgid ""
-"\n"
-"++ Run test copy column ++"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:150
-msgid ""
-"\n"
-"++ Test copy column finished ++"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_main.c:83
-msgid "Performs unit and integration tests for the dbmi base library"
-msgstr ""
-#: ../lib/db/dbmi_base/xdrtable.c:109
-msgid "fetch: table has wrong number of columns"
-msgstr ""
-#: ../lib/db/dbmi_base/legal_dbname.c:38
-#, fuzzy, c-format
-msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'."
-msgstr "नहीं रखे हुए n"
-#: ../lib/db/dbmi_base/legal_dbname.c:45
-#, fuzzy, c-format
-msgid "Illegal table map name <%s>. Must start with a letter."
-msgstr "प्रारंभ a n"
-#: ../lib/db/dbmi_base/legal_dbname.c:54
-#, fuzzy, c-format
-msgid "Illegal table map name <%s>. Character <%c> not allowed."
-msgstr "नहीं n"
-#: ../lib/db/dbmi_base/xdrvalue.c:82
-msgid "send data: invalid C-type"
-msgstr ""
-#, fuzzy
-msgid "Unable to open null device"
-msgstr "के लिए"
-#, fuzzy
-msgid "The support for OGR vector maps wasn't compiled in"
-msgstr "के लिए"
-#, fuzzy
-msgid "End time must be later than start time"
-#, fuzzy
-msgid "Unknown"
-msgstr "नहीं"
-#, fuzzy
-msgid "Could not find line box"
-msgstr "नहीं"
-#, fuzzy
-msgid "Uknown column <%s>"
-msgstr "का"
-#, fuzzy
-msgid "       valid options: %s\n"
-msgstr "n"
-#, fuzzy
-msgid "Raster map <%s> - unable to write row %d"
-msgstr "नहीं"
-#, fuzzy
-msgid "Error writing floating point format file for map <%s>"
-msgstr "के लिए"
-#, fuzzy
-msgid "Unable to write feature, OGR layer not defined"
-msgstr "है नहीं"
-#, fuzzy
-msgid "Unable to create a new process!"
-msgstr "a"
-#, fuzzy
-msgid "Region for current mapset %s. Run \"g.region\" to fix the current region."
-msgstr "के लिए जी"
-#, fuzzy
-msgid "Default region %s"
-#, fuzzy
-msgid "Unable to set region"
-msgstr "का"
-#, fuzzy
-msgid "Failed writing raster map"
-msgstr "के लिए"
-#, fuzzy
-msgid "Unable to write color file of raster map <%s>"
-msgstr "के लिए"
-#, fuzzy
-msgid "Unable to query drawable"
-msgstr "का"
-#, fuzzy
-msgid "Failed to initialize Xlib surface"
-msgstr "का"
-#, fuzzy
-#~ msgid "Cannot open database %s by driver %s"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "projection field missing"
-#~ msgstr "फील्ड"
-#, fuzzy
-#~ msgid "north field missing"
-#~ msgstr "उत्तर फील्ड"
-#, fuzzy
-#~ msgid "south field missing"
-#~ msgstr "दक्षिण फील्ड"
-#, fuzzy
-#~ msgid "west field missing"
-#~ msgstr "पश्चिम फील्ड"
-#, fuzzy
-#~ msgid "east field missing"
-#~ msgstr "पूर्व फील्ड"
-#, fuzzy
-#~ msgid "cols field missing"
-#~ msgstr "फील्ड"
-#, fuzzy
-#~ msgid "rows field missing"
-#~ msgstr "फील्ड"
-#, fuzzy
-#~ msgid "ewres3 field missing"
-#~ msgstr "फील्ड"
-#, fuzzy
-#~ msgid "nsres3 field missing"
-#~ msgstr "फील्ड"
-#, fuzzy
-#~ msgid "cols3 field missing"
-#~ msgstr "फील्ड"
-#, fuzzy
-#~ msgid "rows3 field missing"
-#~ msgstr "फील्ड"
-#, fuzzy
-#~ msgid "Unable to open driver <%s>"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "%s not set"
-#~ msgstr "नहीं सेट"
-#, fuzzy
-#~ msgid "Reading nodes from vector map ..."
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "taking too long to find points for interpolation--please change the region to area where your points are. Continuing calculations..."
-#~ msgstr "के लिए."
-#, fuzzy
-#~ msgid "some points outside of region -- will ignore..."
-#~ msgstr "का."
-#, fuzzy
-#~ msgid "Column type not supported"
-#~ msgstr "विशेषता नहीं"
-#, fuzzy
-#~ msgid "       Presented as: %s\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "       Legal range: %s\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "       You provided %d items:\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Flags:\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Parameters:\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Unable to open raster map <%s>"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Unable to write raster row %i"
-#~ msgstr "a"
-#, fuzzy
-#~ msgid "Unable to open raster map <%s@%s>"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Unable to find <%s@%s>"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Unable to open '%s'"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "unable to write quant file!"
-#~ msgstr "a"
-#, fuzzy
-#~ msgid "Unable to read header file for raster map <%s@%s>."
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid " It is a reclass of raster map <%s@%s> "
-#~ msgstr "है a का "
-#, fuzzy
-#~ msgid "Unable to realloc buffer"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "can't create histogram for [%s in %s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Unable to open file %s in <%s>"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "ERROR in reading <%s> file for location <%s>"
-#~ msgstr "त्रुटि के लिए n"
-#, fuzzy
-#~ msgid "Name of input raster3d map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of input raster3d map(s)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "is not set"
-#~ msgstr "है नहीं सेट"
-#, fuzzy
-#~ msgid ""
-#~ "is invalid\n"
-#~ "%s"
-#~ msgstr "है अवैध n"
-#, fuzzy
-#~ msgid "Vector is not 3D"
-#~ msgstr "सदिश है नहीं"
-#, fuzzy
-#~ msgid "Cannot find z column <%s> (please verify name, e.g. with v.info)"
-#~ msgstr "ज़ेड जी"
-#, fuzzy
-#~ msgid "Column type of z column is not supported (must be integer or double)"
-#~ msgstr "का ज़ेड है नहीं"
-#, fuzzy
-#~ msgid "Cannot read column type of smooth column"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Column type of smooth column (datetime) is not supported"
-#~ msgstr "का है नहीं"
-#, fuzzy
-#~ msgid "Column type of s column is not supported (must be integer or double)"
-#, fuzzy
-#~ msgid "Unable to open category index file for vector map <%s@%s>"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Unable to read head file"
-#~ msgstr "के लिए n"
-#, fuzzy
-#~ msgid "Unable to create header file for [%s in %s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "can't read f_range file for [%s in %s]"
-#~ msgstr "f के लिए"
-#, fuzzy
-#~ msgid "can't read range file for [%s in %s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "can't write range file for [%s in %s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Can not create a new process!"
-#~ msgstr "नहीं a!"
-#, fuzzy
-#~ msgid "Can't open timestamp file for %s map %s in mapset %s"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Can't read %s for [%s in %s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Can't create %s metadata file for [%s in %s]"
-#, fuzzy
-#~ msgid "Matrix is not symmetric!"
-#~ msgstr "डिफ़ॉल्ट है नहीं सेट"
-#, fuzzy
-#~ msgid "Duplicates"
-#~ msgstr "अनुकृति पूर्व फील्ड"
-#, fuzzy
-#~ msgid "Unable to write embedded null values for raster map open for random access"
-#~ msgstr "के लिए के लिए"
-#, fuzzy
-#~ msgid " It is a reclass of raster map <%s@%s> whose header file is invalid."
-#~ msgstr "है a का किसका है अवैध n"
-#, fuzzy
-#~ msgid " Invalid format."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Null values have not been initialized. "
-#~ msgstr "शून्य (Null) नहीं "
-#, fuzzy
-#~ msgid "G_gisinit() must be called first. "
-#~ msgstr "जी "
-#, fuzzy
-#~ msgid "Unable to spawn the 'wish' program"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Cannot open database %s"
-#~ msgstr "लिंक ."
-#, fuzzy
-#~ msgid "ERROR %s from graphics driver.\n"
-#~ msgstr "त्रुटि n"
-#, fuzzy
-#~ msgid "ERROR - eof from graphics monitor.\n"
-#, fuzzy
-#~ msgid "Warning - no response from graphics monitor <%s>.\n"
-#~ msgstr "चेतावनी n"
-#, fuzzy
-#~ msgid "Check to see if the mouse is still active.\n"
-#~ msgstr "है n"
-#, fuzzy
-#~ msgid "ERROR - no response from graphics monitor <%s>.\n"
-#, fuzzy
-#~ msgid "No graphics monitor has been selected for output."
-#~ msgstr "नहीं के लिए n"
-#, fuzzy
-#~ msgid "Please run \"d.mon\" to select a graphics monitor."
-#~ msgstr "a n"
-#, fuzzy
-#~ msgid "Failed to get socket name for monitor <%s>."
-#, fuzzy
-#~ msgid "No socket to connect to for monitor <%s>."
-#, fuzzy
-#~ msgid "Socket is already in use or not accepting connections."
-#~ msgstr "है नहीं a n"
-#, fuzzy
-#~ msgid "Use d.mon to select a monitor"
-#~ msgstr "a n"
-#, fuzzy
-#~ msgid "Trying to connect to something not a socket."
-#~ msgstr "नहीं a प्रोग्राम त्रुटि n"
-#, fuzzy
-#~ msgid "Probably an error with the server."
-#, fuzzy
-#~ msgid "Connection failed."
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Cannot read topo for line [%d]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Enter 'list' for the list of available ellipsoids\n"
-#~ msgstr "के लिए का n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "invalid ellipsoid\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Output name '%s' is not valid rast name."
-#~ msgstr "है नहीं."
-#, fuzzy
-#~ msgid "Output map '%s' is used as input"
-#~ msgstr "है"
-#, fuzzy
-#~ msgid "Enter 'list' for the list of available datums\n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "invalid datum\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "one moment...\n"
-#~ msgstr "एक n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Color table needed for file [%s] in mapset [%s].\n"
-#~ msgstr "n के लिए n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Please identify the type desired:\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "    1:  Random colors\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "    2:  Red, green, and blue color ramps\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "    3:  Color wave\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "    4:  Gray scale\n"
-#~ msgstr "स्केल n"
-#, fuzzy
-#~ msgid "    5:  Aspect\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "    6:  Rainbow colors\n"
-#~ msgstr "इंद्रधनुष n"
-#, fuzzy
-#~ msgid "    7:  Red through yellow to green\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "    8:  Green through yellow to red\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "RETURN  quit\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "%s invalid; Try again > "
-#~ msgstr "n अवैध कोशिश करें "
-#, fuzzy
-#~ msgid "ERROR in reading %s"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Please specify projection name\n"
-#~ msgstr "n n"
-#, fuzzy
-#~ msgid "Enter 'list' for the list of available projections\n"
-#, fuzzy
-#~ msgid "(no title)"
-#~ msgstr "शीर्षक"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "FLAG: Set the following flag?\n"
-#~ msgstr "सेट n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "OPTION:   %s\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "     key: %s\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid " default: %s\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "multiple: %s\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "   Try again? "
-#~ msgstr "कोशिश करें "
-#, fuzzy
-#~ msgid "Sorry, %s is not accepted.\n"
-#~ msgstr "खेद है है नहीं n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "You have chosen:\n"
-#~ "  %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ " n"
-#, fuzzy
-#~ msgid "Is this correct? "
-#~ msgstr "है "
-#, fuzzy
-#~ msgid "Enter a new %s file name"
-#~ msgstr "a"
-#, fuzzy
-#~ msgid "Enter the name of an existing %s file"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Enter 'list' for a list of existing %s files\n"
-#~ msgstr "के लिए a का n"
-#, fuzzy
-#~ msgid "Enter 'list -f' for "
-#~ msgstr "f के लिए "
-#, fuzzy
-#~ msgid "a list %s"
-#~ msgstr "a"
-#, fuzzy
-#~ msgid "Hit RETURN %s\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "** %s - not found **\n"
-#~ msgstr "n नहीं n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "** %s exists. ok to overwrite? "
-#~ msgstr "n "
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "** %s - illegal request **\n"
-#~ msgstr "n n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "** %s - exists, select another name **\n"
-#~ msgstr "n n"
-#, fuzzy
-#~ msgid "ask: can't happen"
-#~ msgstr "पूछें"
-#, fuzzy
-#~ msgid "Can't read header file for [%s in %s]\n"
-#, fuzzy
-#~ msgid "Can't open header file for [%s in %s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Cannot open database"
-#~ msgstr "लिंक ."
-#, fuzzy
-#~ msgid "Building topology ...\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid ""
-#~ "\r%d areas built      \n"
-#~ "%d isles built\n"
-#~ msgstr "n n"
-#, fuzzy
-#~ msgid "OGR feature type [%d] not supported"
-#, fuzzy
-#~ msgid "Vect_rewrite_line() for this format/level not supported"
-#~ msgstr "के लिए नहीं"
-#, fuzzy
-#~ msgid "Vect_delete_line() for this format/level not supported"
-#, fuzzy
-#~ msgid "Output name '%s' is not valid vector name."
-#, fuzzy
-#~ msgid "Cannot open existing vector map <%s>"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Cannot delete existing vector <%s>"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Cannot open history file for vector '%s'"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Can't open directory %s"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "No such graphics monitor as <%s>.\n"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Please run \"d.mon\" to select a valid graphics monitor.\n"
-#~ msgstr "a n"
-#, fuzzy
-#~ msgid "Can't stat %s\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Error - Monitor <%s> is in use.\n"
-#~ msgstr "त्रुटि है n"
-#, fuzzy
-#~ msgid "Error - Monitor <%s> is in use by %s.\n"
-#, fuzzy
-#~ msgid "Error - Could not complete locking process for monitor <%s>.\n"
-#~ msgstr "त्रुटि नहीं के लिए n"
-#, fuzzy
-#~ msgid "Error - Can't set up pipe to graphics device.\n"
-#~ msgstr "त्रुटि सेट n"
-#, fuzzy
-#~ msgid "Error - Graphics monitor <%s> not running!\n"
-#~ msgstr "त्रुटि नहीं चल रहा है... n"
-#, fuzzy
-#~ msgid "Please start graphics monitor <%s>.\n"
-#~ msgstr "प्रारंभ n"
-#, fuzzy
-#~ msgid "Not connected...\n"
-#~ msgstr "कनेक्टेड n"
-#, fuzzy
-#~ msgid "Couldn't connect to monitor. Will try once more.\n"
-#~ msgstr "अधिक n"
-#, fuzzy
-#~ msgid "G_dump: memory allocated to G__"
-#~ msgstr "जी जी"
-#, fuzzy
-#~ msgid "Size of cell in fp maps = %d"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "type for writing floating maps = %d"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Flag: window set? %d"
-#~ msgstr "ध्वज सेट"
-#, fuzzy
-#~ msgid "File descriptor for automatic mask %d"
-#~ msgstr "फ़ाइल के लिए स्वचालित"
-#, fuzzy
-#~ msgid "Flag denoting automatic masking %d"
-#~ msgstr "ध्वज स्वचालित"
-#, fuzzy
-#~ msgid "buffer for reading null rows %p"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "G_dump: file #%d"
-#~ msgstr "जी"
-#, fuzzy
-#~ msgid "Range structure %p"
-#~ msgstr "सीमा"
-#, fuzzy
-#~ msgid "float Range structure %p"
-#~ msgstr "सीमा"
-#, fuzzy
-#~ msgid "File row addresses %p"
-#~ msgstr "फ़ाइल"
-#, fuzzy
-#~ msgid "Data to window row constants %f,%f"
-#~ msgstr "f f"
-#, fuzzy
-#~ msgid "nbytes per cell for current row %d"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "bytes per cell %d"
-#~ msgstr "बाइट्स"
-#, fuzzy
-#~ msgid "Temporary name for NEW files %s"
-#~ msgstr "अस्थायी के लिए"
-#, fuzzy
-#~ msgid "Temporary name for NEW NULL files %s"
-#, fuzzy
-#~ msgid "Mapset of open file %s"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "io error warning given %d"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "xdr stream for reading fp %p"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "data buffer for reading null rows %p"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Minimum row null row number in memory %d"
-#~ msgstr "संख्या"
-#, fuzzy
-#~ msgid "G_dump: end"
-#~ msgstr "जी"
-#, fuzzy
-#~ msgid "Not able to open cellfile for [%s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "ERROR: GISBASE not set\n"
-#~ msgstr "त्रुटि नहीं सेट n"
-#, fuzzy
-#~ msgid "Error reading datum shift parameters for %s from table"
-#~ msgstr "त्रुटि के लिए"
-#, fuzzy
-#~ msgid "Error reading ellipsoid parameters for %s from table"
-#, fuzzy
-#~ msgid "No ellipsoid field %s in file %s in %s"
-#~ msgstr "नहीं फील्ड"
-#, fuzzy
-#~ msgid "invalid value: field %s in file %s in %s"
-#~ msgstr "अवैध फील्ड"
-#, fuzzy
-#~ msgid "decimal field %i not present in sites file"
-#~ msgstr "फील्ड i नहीं वर्तमान"
-#, fuzzy
-#~ msgid "I'm finding records that do not have a floating point attributes (fields prefixed with '%')."
-#~ msgstr "मी नहीं a बिन्दु."
-#, fuzzy
-#~ msgid "No n-dims in site_list"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "No double attributes in site_list"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "No string attributes in site_list"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "String attribute index out of range"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Unknown attribute type in call to G_readsites_xyz()!\n"
-#~ msgstr "जी n"
-#, fuzzy
-#~ msgid "Unable to allocate memory\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Unable to open temporary file"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Hit RETURN to cancel request\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Problem reading raster map"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid " The raster map %s@%s is empty"
-#~ msgstr "है"
-#, fuzzy
-#~ msgid "Cannot write quant rules: map %s is integer"
-#~ msgstr "है"
-#, fuzzy
-#~ msgid "G_set_window(): projection/zone differs from that of currently open raster maps"
-#~ msgstr "जी सेट का"
-#, fuzzy
-#~ msgid "The floating data range for %s@%s is empty"
-#~ msgstr "के लिए है"
-#, fuzzy
-#~ msgid "The integer data range for %s@%s is empty"
-#, fuzzy
-#~ msgid "error writing null row %d"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "category support for [%s] in mapset [%s] %s"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "category support for vector map [%s] in mapset [%s] %s"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "invalid projection\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Please advise GRASS developers of this error.\n"
-#~ msgstr "का त्रुटि n"
-#, fuzzy
-#~ msgid "G_set_null_value: wrong data type!"
-#~ msgstr "जी सेट!"
-#, fuzzy
-#~ msgid "Name of elevation raster map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Name of elevation raster map(s)"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Layer number"
-#~ msgstr "संख्या"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Description:\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Usage:\n"
-#~ msgstr "n "
-#, fuzzy
-#~ msgid " options: %s\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "color support for [%s] in mapset [%s] %s"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Invalid timestamp specified for %s map %s in mapset %s"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Error reading compressed map <%s@%s>, row %d"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "Error reading map <%s@%s>, row %d"
-#~ msgstr "त्रुटि"
-#, fuzzy
-#~ msgid "Unable to create header file for [%s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid ""
-#~ "region for current mapset %s\n"
-#~ "run \"g.region\""
-#~ msgstr "के लिए जी"
-#, fuzzy
-#~ msgid "Illegal filename.  Cannot be '.' or 'NULL'\n"
-#~ msgstr "फ़ाइलनाम  n"
-#, fuzzy
-#~ msgid "Illegal filename. Character <%c> not allowed.\n"
-#~ msgstr "फ़ाइलनाम  नहीं."
-#, fuzzy
-#~ msgid "Too many reclass categories for [%s in %s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Illegal reclass format in header file for [%s in %s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Raster map <%s@%s>: bytes per cell (%d) too large"
-#~ msgstr "बाइट्स बड़ा"
-#, fuzzy
-#~ msgid "Unable to find '%s' in '%s'"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "can't write history information for [%s]"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Unable to add database link, map is not opened in WRITE mode"
-#~ msgstr "लिंक  है नहीं."
-#, fuzzy
-#~ msgid "Unable to add database link"
-#~ msgstr "लिंक ."
-#, fuzzy
-#~ msgid "Error in rule on row %d in %s"
-#~ msgstr "त्रुटि चालू"
-#, fuzzy
-#~ msgid "Unable to feature %d from vector map <%s>"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Programmer requested unknown open level %d"
-#, fuzzy
-#~ msgid "Unable to open layer <%s>"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "OGR feature without ID ignored"
-#~ msgstr "विशेषता."
-#, fuzzy
-#~ msgid "Unable to delete layer/category %d/%d line %d"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Unable to open vector map <%s> on topology level %d"
-#~ msgstr "नक़ल"
-#, fuzzy
-#~ msgid "Attempt to delete dead line"
-#, fuzzy
-#~ msgid "Unable to rewrite line %d"
-#, fuzzy
-#~ msgid "Unable to delete line %d, vector map <%s> is not opened on topo level 2"
-#~ msgstr "है नहीं चालू"
-#, fuzzy
-#~ msgid "Unable to delete line %d, vector map <%s> is not opened in 'write' mode"
-#~ msgstr "है नहीं"
-#, fuzzy
-#~ msgid "Unable to delete line %d from vector map <%s>"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Cannot get field info"
-#, fuzzy
-#~ msgid "Color file for [%s] not available"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Sorry <%s> is not a valid option\n"
-#~ msgstr "खेद है है नहीं a n"
-#, fuzzy
-#~ msgid "Sorry, <%c> is not a valid flag\n"
-#, fuzzy
-#~ msgid "Sorry, <%s=> is ambiguous\n"
-#~ msgstr "खेद है है n"
-#, fuzzy
-#~ msgid "Sorry, <%s> is not a valid parameter\n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "ERROR: illegal range syntax for parameter <%s>\n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "ERROR: value <%s> out of range for parameter <%s>\n"
-#~ msgstr "का के लिए n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "ERROR: Missing value for parameter <%s>\n"
-#~ msgstr "गुमा के लिए n"
-#, fuzzy
-#~ msgid ""
-#~ "ERROR: Required parameter <%s> not set:\n"
-#~ "\t(%s)\n"
-#~ msgstr ""
-#~ "नहीं सेट\n"
-#~ " n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "ERROR: option <%s> must be provided in multiples of %d\n"
-#~ msgstr "का n"
-#, fuzzy
-#~ msgid "Unable to delete feature %d from vector map <%s>"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Unable to close input map"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'.\n"
-#~ msgstr "नहीं रखे हुए n"
-#, fuzzy
-#~ msgid "Illegal table map name <%s>. Must start with a letter.\n"
-#~ msgstr "प्रारंभ a n"
-#, fuzzy
-#~ msgid "Illegal table map name <%s>. Character <%c> not allowed.\n"
-#~ msgstr "नहीं n"
-#, fuzzy
-#~ msgid "Unable to allocate memory for a null buffer"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Unable to open file %s"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Could not get raster row"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "Unable to create raster map <%s>"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Unable to delete file '%s'. Reason: %s"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Unable to rename directory '%s' to '%s'. Reason: %s"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Unable to remove directory '%s'. Reason: %s"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Vector map <%s> is not open on level >= 2"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "%s is not in the current mapset (%s)"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "duplicate projection field"
-#~ msgstr "अनुकृति फील्ड"
-#, fuzzy
-#~ msgid "duplicate zone field"
-#, fuzzy
-#~ msgid "zone field missing"
-#~ msgstr "फील्ड"
-#, fuzzy
-#~ msgid "duplicate north field"
-#~ msgstr "अनुकृति उत्तर फील्ड"
-#, fuzzy
-#~ msgid "duplicate south field"
-#~ msgstr "अनुकृति दक्षिण फील्ड"
-#, fuzzy
-#~ msgid "duplicate east field"
-#, fuzzy
-#~ msgid "duplicate west field"
-#~ msgstr "अनुकृति पश्चिम फील्ड"
-#, fuzzy
-#~ msgid "duplicate top field"
-#~ msgstr "अनुकृति शीर्ष फील्ड"
-#, fuzzy
-#~ msgid "duplicate bottom field"
-#~ msgstr "अनुकृति तल फील्ड"
-#, fuzzy
-#~ msgid "duplicate e-w resolution field"
-#, fuzzy
-#~ msgid "duplicate 3D e-w resolution field"
-#, fuzzy
-#~ msgid "duplicate n-s resolution field"
-#~ msgstr "अनुकृति n फील्ड"
-#, fuzzy
-#~ msgid "duplicate 3D n-s resolution field"
-#, fuzzy
-#~ msgid "duplicate t-b resolution field"
-#, fuzzy
-#~ msgid "duplicate rows field"
-#, fuzzy
-#~ msgid "duplicate 3D rows field"
-#, fuzzy
-#~ msgid "duplicate cols field"
-#, fuzzy
-#~ msgid "duplicate 3D cols field"
-#, fuzzy
-#~ msgid "duplicate depths field"
-#, fuzzy
-#~ msgid "duplicate format field"
-#, fuzzy
-#~ msgid "duplicate compressed field"
-#, fuzzy
-#~ msgid "G_getenv(): Variable %s not set"
-#~ msgstr "चर नहीं सेट"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Please specify ellipsoid name\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Name for output raster3d map"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "  format: %s\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "required: %s\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "%s not found"
-#~ msgstr "नहीं"
-#, fuzzy
-#~ msgid "No help available for command [%s]\n"
-#, fuzzy
-#~ msgid "Can't create timestamp file for %s map %s in mapset %s"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Invalid timestamp file for %s map %s in mapset %s"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Cannot write quant rules for map %s"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "**<%s> illegal name **\n"
-#~ msgstr "n n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Please specify datum name\n"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Unable to delete prior null-cells file"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Unable to close the null-cells file"
-#, fuzzy
-#~ msgid "Unable to delete the temporary null-cells file"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Unable to delete the empty temporary null-cells file"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Unable to delete the prior null-cells file"
-#, fuzzy
-#~ msgid "Unable to close the 'cell' file"
-#, fuzzy
-#~ msgid "Unable to delete prior 'fcell' file"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Unable to delete the prior %s file"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Unable to close file"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Unable to delete the prior 'cell' file"
-#, fuzzy
-#~ msgid "Unable to delete the temporary 'cell' file"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Unable to write quant file!"
-#~ msgstr "a"
-#, fuzzy
-#~ msgid "Unable to delete the %s file"
-#~ msgstr "का"
-#, fuzzy
-#~ msgid "Unable to write f_format file for CELL maps"
-#~ msgstr "के लिए"
-#, fuzzy
-#~ msgid "Could not stat file '%s'"
-#~ msgstr "नहीं"
Deleted: grass/trunk/locale/po/grasslibs_mr.po
--- grass/trunk/locale/po/grasslibs_mr.po	2012-05-29 07:08:35 UTC (rev 51861)
+++ grass/trunk/locale/po/grasslibs_mr.po	2012-05-29 09:28:22 UTC (rev 51862)
@@ -1,7288 +0,0 @@
-# Marathi Localization of Grass 6.0.0
-# Copyright (C) 2005 GRASS Development Team
-# This file is distributed under the same license as the GRASS package.
-# Sheetal Nepte <sheetal_nepte at yahoo.co.in>, 2005.
-msgid ""
-msgstr ""
-"Project-Id-Version: Grass 6.0\n"
-"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2012-01-28 11:12+0100\n"
-"PO-Revision-Date: 2005-06-02 18:00+0530\n"
-"Last-Translator: Swapnil Hajare <dreamil at gmail.com>\n"
-"Language-Team: Marathi <www.janabhaaratii.org.in>\n"
-"Language: mr\n"
-"MIME-Version: 1.0\n"
-"Content-Type: text/plain; charset=UTF-8\n"
-"Content-Transfer-Encoding: 8bit\n"
-#: ../lib/nviz/render.c:104
-msgid "Bad server connection"
-msgstr ""
-#: ../lib/nviz/render.c:113
-#, fuzzy
-msgid "Unable to create rendering context"
-msgstr "%s उघडता आले नाही"
-#: ../lib/nviz/position.c:56
-#, fuzzy
-msgid "Unable to set focus"
-#: ../lib/nviz/map_obj.c:59
-msgid "Maximum surfaces loaded!"
-msgstr ""
-#: ../lib/nviz/map_obj.c:88
-msgid "Maximum vector line maps loaded!"
-msgstr ""
-#: ../lib/nviz/map_obj.c:97 ../lib/nviz/map_obj.c:128
-#, fuzzy, c-format
-msgid "Error loading vector map <%s>"
-#: ../lib/nviz/map_obj.c:116
-msgid "Maximum vector point maps loaded!"
-msgstr ""
-#: ../lib/nviz/map_obj.c:143
-msgid "Maximum volumes loaded!"
-msgstr ""
-#: ../lib/nviz/map_obj.c:152
-#, fuzzy, c-format
-msgid "Error loading 3d raster map <%s>"
-#: ../lib/nviz/map_obj.c:160
-msgid "Nviz_new_map_obj(): unsupported data type"
-msgstr ""
-#: ../lib/nviz/nviz.c:128
-#, c-format
-msgid "Invalid color (%s), using \"white\" as default"
-msgstr ""
-#: ../lib/nviz/lights.c:171
-#, fuzzy
-msgid "Unable to define new light"
-#: ../lib/symbol/read.c:211
-#, c-format
-msgid "Cannot read symbol line coordinates: %s"
-msgstr ""
-#: ../lib/symbol/read.c:260
-#, c-format
-msgid "Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
-msgstr ""
-#: ../lib/symbol/read.c:284
-#, c-format
-msgid "Cannot find/open symbol: '%s'"
-msgstr ""
-#: ../lib/symbol/read.c:389 ../lib/symbol/read.c:407 ../lib/symbol/read.c:417
-#: ../lib/symbol/read.c:435
-#, c-format
-msgid "Incorrect symbol color: '%s', using default."
-msgstr ""
-#: ../lib/htmldriver/Graph_Set.c:97
-#, c-format
-msgid "html: collecting to file '%s'"
-msgstr ""
-#: ../lib/htmldriver/Graph_Set.c:98
-#, c-format
-msgid "html: image size %dx%d"
-msgstr ""
-#: ../lib/htmldriver/Graph_Set.c:111 ../lib/htmldriver/Graph_Set.c:115
-#: ../lib/htmldriver/Graph_Set.c:119
-#, c-format
-msgid "html: type '%s'"
-msgstr ""
-#: ../lib/sites/sites.c:106
-#, c-format
-msgid "Attributes for category %d not found"
-msgstr ""
-#: ../lib/sites/sites.c:151
-msgid "Category must be integer"
-msgstr ""
-#: ../lib/sites/sites.c:226
-msgid "Memory error in writing timestamp"
-msgstr ""
-#: ../lib/sites/sites.c:228
-msgid "Illegal TimeStamp string"
-msgstr ""
-#: ../lib/sites/sites.c:255 ../lib/sites/sites.c:385
-msgid "Dev note: Adapted sites library used for vector points. (module should be updated to GRASS 6 vector library)"
-msgstr ""
-#: ../lib/sites/sites.c:279 ../lib/ogsf/Gv3.c:342 ../lib/ogsf/Gp3.c:206
-#: ../lib/vector/neta/utils.c:119 ../lib/vector/neta/timetables.c:133
-#: ../lib/vector/Vlib/map.c:367 ../lib/vector/Vlib/map.c:506
-#: ../lib/vector/Vlib/map.c:728 ../lib/vector/Vlib/net.c:180
-#: ../lib/vector/Vlib/net.c:351 ../lib/vector/Vlib/open_ogr.c:425
-#: ../lib/vector/Vlib/array.c:282 ../lib/vector/Vlib/ascii.c:355
-#: ../lib/rst/interp_float/vinput2d.c:88 ../lib/db/dbmi_client/db.c:46
-#: ../lib/db/dbmi_client/copy_tab.c:112 ../lib/db/dbmi_client/copy_tab.c:133
-#, fuzzy, c-format
-msgid "Unable to open database <%s> by driver <%s>"
-msgstr "temp फाइल उघडता आली नाही"
-#: ../lib/sites/sites.c:288 ../lib/vector/Vlib/open_ogr.c:438
-#: ../lib/db/dbmi_client/copy_tab.c:218 ../lib/db/dbmi_client/copy_tab.c:295
-#: ../lib/db/dbmi_client/table.c:110
-#, fuzzy, c-format
-msgid "Unable to open select cursor: '%s'"
-#: ../lib/sites/sites.c:304
-#, fuzzy
-msgid "Cannot fetch row"
-msgstr "सध्याची विंडो = %p\n"
-#: ../lib/sites/sites.c:440
-msgid "G_oldsite_new_struct: invalid # dims or fields"
-msgstr ""
-#: ../lib/sites/sites.c:668
-msgid "G_oldsite_describe() must be called immediately after G_fopen_sites_old()."
-msgstr ""
-#: ../lib/ogsf/gsd_label.c:58
-msgid "Max. number of labels reached!"
-msgstr ""
-#: ../lib/ogsf/gk.c:320
-msgid "Need at least 3 keyframes for spline"
-msgstr ""
-#: ../lib/ogsf/gk.c:622
-msgid "Need at least 2 keyframes for interpolation"
-msgstr ""
-#: ../lib/ogsf/GS2.c:1212
-#, c-format
-msgid "no category info"
-msgstr ""
-#: ../lib/ogsf/GS2.c:1231
-#, c-format
-msgid "no data"
-msgstr ""
-#: ../lib/ogsf/GS2.c:1656
-#, c-format
-msgid "Raster map <%s> is outside of current region. Load failed."
-msgstr ""
-#: ../lib/ogsf/GS2.c:1734 ../lib/ogsf/GS2.c:1740 ../lib/ogsf/GS2.c:1748
-#: ../lib/ogsf/GS2.c:1757 ../lib/ogsf/GS2.c:1765 ../lib/ogsf/GS2.c:1775
-#: ../lib/ogsf/GS2.c:1823
-msgid "GS_load_att_map(): Out of memory. Unable to load map"
-msgstr ""
-#: ../lib/ogsf/GS2.c:1851
-msgid "Loading failed"
-msgstr ""
-#: ../lib/ogsf/GS2.c:1855
-msgid "Error finding range"
-msgstr ""
-#: ../lib/ogsf/Gvl3.c:40 ../lib/ogsf/gvl_file.c:427
-#: ../lib/manage/do_remove.c:78 ../lib/manage/do_rename.c:76
-#: ../lib/gpde/N_arrays_io.c:273
-#, fuzzy, c-format
-msgid "3D raster map <%s> not found"
-msgstr "%s मिळाले नाही"
-#: ../lib/ogsf/gs_bm.c:124
-msgid "Bitmap mismatch"
-msgstr ""
-#: ../lib/ogsf/Gv3.c:60 ../lib/ogsf/Gv3.c:325 ../lib/ogsf/Gp3.c:56
-#: ../lib/ogsf/Gp3.c:189 ../lib/manage/do_remove.c:57
-#: ../lib/manage/do_rename.c:54 ../lib/vector/Vlib/legal_vname.c:121
-#: ../lib/vector/Vlib/legal_vname.c:124 ../lib/vector/Vlib/map.c:429
-#: ../lib/vector/Vlib/open.c:202
-#, fuzzy, c-format
-msgid "Vector map <%s> not found"
-#: ../lib/ogsf/Gv3.c:66 ../lib/ogsf/Gv3.c:330 ../lib/ogsf/Gp3.c:62
-#: ../lib/ogsf/Gp3.c:194 ../lib/vector/Vlib/open.c:240
-#, fuzzy, c-format
-msgid "Unable to open vector map <%s>"
-#: ../lib/ogsf/Gv3.c:261
-#, c-format
-msgid "No features from vector map <%s> fall within current region"
-msgstr ""
-#: ../lib/ogsf/Gv3.c:266
-#, fuzzy, c-format
-msgid "Vector map <%s> loaded (%d features)"
-#: ../lib/ogsf/Gv3.c:336 ../lib/ogsf/Gp3.c:200 ../lib/vector/Vlib/map.c:338
-#: ../lib/vector/Vlib/map.c:465 ../lib/vector/Vlib/map.c:577
-#: ../lib/vector/Vlib/map.c:695 ../lib/vector/Vlib/map.c:793
-#: ../lib/vector/Vlib/net.c:174 ../lib/vector/Vlib/net.c:346
-#: ../lib/vector/Vlib/array.c:276 ../lib/vector/Vlib/ascii.c:343
-#: ../lib/rst/interp_float/vinput2d.c:79
-#, c-format
-msgid "Database connection not defined for layer %d"
-msgstr ""
-#: ../lib/ogsf/Gv3.c:345
-#, fuzzy, c-format
-msgid "Loading thematic vector layer <%s>..."
-msgstr "%s@%s हा रास्टर नकाशा रिक्त आहे"
-#: ../lib/ogsf/Gv3.c:369 ../lib/ogsf/Gp3.c:233
-#, fuzzy, c-format
-msgid "No color rule defined for category %d"
-#: ../lib/ogsf/Gv3.c:384 ../lib/ogsf/Gp3.c:247
-#, fuzzy, c-format
-msgid "Invalid color definition (%s)"
-msgstr "अवैध निर्देशक"
-#: ../lib/ogsf/Gv3.c:406
-#, c-format
-msgid "%d features without category. Unable to determine color rules for features without category."
-msgstr ""
-#: ../lib/ogsf/Gp3.c:92 ../lib/vector/Vlib/map.c:87
-#: ../lib/vector/Vlib/map.c:166
-#, fuzzy, c-format
-msgid "Unable to read vector map <%s>"
-#: ../lib/ogsf/Gp3.c:146
-#, c-format
-msgid "No points from vector map <%s> fall within current region"
-msgstr ""
-#: ../lib/ogsf/Gp3.c:151
-#, fuzzy, c-format
-msgid "Vector map <%s> loaded (%d points)"
-#: ../lib/ogsf/Gp3.c:209
-#, fuzzy, c-format
-msgid "Loading thematic points layer <%s>..."
-#: ../lib/ogsf/Gp3.c:286
-#, c-format
-msgid "%d points without category. Unable to determine color rules for features without category."
-msgstr ""
-#: ../lib/ogsf/gsd_prim.c:146
-#, c-format
-msgid "Color Material: %d"
-msgstr ""
-#: ../lib/ogsf/gsd_prim.c:630
-#, c-format
-msgid "gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please advise GRASS developers of this error"
-msgstr ""
-#: ../lib/ogsf/gsd_img_tif.c:64 ../lib/ogsf/GK2.c:216
-#: ../lib/ogsf/gsd_img_ppm.c:52 ../lib/ogsf/gsd_img_ppm.c:95
-#, fuzzy, c-format
-msgid "Unable to open file <%s> for writing"
-#: ../lib/ogsf/trans.c:180
-msgid "Out of matrix stack space"
-msgstr ""
-#: ../lib/ogsf/trans.c:200
-msgid "Tried to pop an empty stack"
-msgstr ""
-#: ../lib/ogsf/gsd_surf.c:1742
-msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
-msgstr ""
-#: ../lib/ogsf/gsdrape.c:207
-#, fuzzy
-msgid "Unable to process vector map - out of memory"
-#: ../lib/ogsf/gsd_img_mpeg.c:62
-#, fuzzy
-msgid "Unable to allocate stream"
-#: ../lib/ogsf/gsd_img_mpeg.c:155
-#, fuzzy
-msgid "Video codec not found"
-#: ../lib/ogsf/gsd_img_mpeg.c:161
-#, fuzzy
-msgid "Unable to open codec"
-#: ../lib/ogsf/gsd_img_mpeg.c:180
-#, fuzzy
-msgid "Unable to allocate picture"
-#: ../lib/ogsf/gsd_img_mpeg.c:191
-#, fuzzy
-msgid "Unable to allocate temporary picture"
-#: ../lib/ogsf/gsd_img_mpeg.c:251
-#, fuzzy
-msgid "Error while writing video frame"
-#: ../lib/ogsf/gsd_img_mpeg.c:297
-#, c-format
-msgid "Opening MPEG stream <%s>..."
-msgstr ""
-#: ../lib/ogsf/gsd_img_mpeg.c:305
-msgid "Unable to deduce output format from file extension: using MPEG"
-msgstr ""
-#: ../lib/ogsf/gsd_img_mpeg.c:309
-#, fuzzy
-msgid "Unable to find suitable output format"
-#: ../lib/ogsf/gsd_img_mpeg.c:316 ../lib/rowio/setup.c:61
-#: ../lib/rowio/setup.c:67 ../lib/vector/neta/centrality.c:63
-#: ../lib/vector/neta/centrality.c:145 ../lib/vector/neta/path.c:134
-#: ../lib/vector/neta/components.c:46 ../lib/vector/neta/components.c:113
-#: ../lib/vector/neta/bridge.c:59 ../lib/vector/neta/flow.c:64
-#: ../lib/vector/neta/flow.c:178 ../lib/vector/neta/timetables.c:69
-#: ../lib/vector/neta/timetables.c:168 ../lib/vector/neta/timetables.c:178
-#: ../lib/vector/neta/timetables.c:191 ../lib/vector/neta/timetables.c:278
-#: ../lib/vector/neta/timetables.c:413 ../lib/vector/neta/timetables.c:425
-#: ../lib/vector/neta/allpairs.c:50 ../lib/vector/neta/spanningtree.c:99
-#: ../lib/vector/neta/articulation_point.c:60 ../lib/vector/Vlib/line.c:48
-#: ../lib/vector/Vlib/ascii.c:201 ../lib/rst/interp_float/segmen2d.c:182
-#: ../lib/rst/interp_float/segmen2d.c:188
-#: ../lib/rst/interp_float/segmen2d.c:194
-#: ../lib/rst/interp_float/segmen2d.c:204
-#: ../lib/rst/interp_float/interp2d.c:121
-#: ../lib/rst/interp_float/interp2d.c:127
-msgid "Out of memory"
-msgstr ""
-#: ../lib/ogsf/gsd_img_mpeg.c:336
-#, fuzzy
-msgid "Invalid output format parameters"
-#: ../lib/ogsf/gsd_img_mpeg.c:350
-#, fuzzy, c-format
-msgid "Unable to open <%s>"
-#: ../lib/ogsf/gsd_img_mpeg.c:360
-msgid "NVIZ has not been built with MPEG output support"
-msgstr ""
-#: ../lib/ogsf/GP2.c:705
-msgid "Unknown icon marker, using \"sphere\""
-msgstr ""
-#: ../lib/ogsf/gsd_legend.c:239 ../lib/ogsf/Gs3.c:125 ../lib/ogsf/Gs3.c:189
-#: ../lib/ogsf/Gs3.c:264 ../lib/ogsf/Gs3.c:336 ../lib/ogsf/Gs3.c:442
-#: ../lib/ogsf/Gs3.c:529 ../lib/ogsf/Gs3.c:588 ../lib/ogsf/Gs3.c:645
-#: ../lib/ogsf/Gs3.c:716 ../lib/ogsf/Gs3.c:786 ../lib/raster/open.c:175
-#: ../lib/raster/open.c:748 ../lib/raster/open.c:785 ../lib/raster/open.c:837
-#: ../lib/manage/do_remove.c:73 ../lib/manage/do_rename.c:71
-#: ../lib/rst/interp_float/output2d.c:236
-#: ../lib/rst/interp_float/output2d.c:317
-#: ../lib/rst/interp_float/output2d.c:386
-#: ../lib/rst/interp_float/output2d.c:436
-#: ../lib/rst/interp_float/output2d.c:450
-#: ../lib/rst/interp_float/output2d.c:464
-#: ../lib/rst/interp_float/output2d.c:480
-#: ../lib/rst/interp_float/resout2d.c:205
-#: ../lib/rst/interp_float/resout2d.c:253
-#: ../lib/rst/interp_float/resout2d.c:296
-#: ../lib/rst/interp_float/resout2d.c:327
-#: ../lib/rst/interp_float/resout2d.c:377
-#: ../lib/rst/interp_float/resout2d.c:395
-#: ../lib/rst/interp_float/resout2d.c:410
-#: ../lib/rst/interp_float/resout2d.c:426 ../lib/gis/legal_name.c:91
-#: ../lib/gis/legal_name.c:94
-#, fuzzy, c-format
-msgid "Raster map <%s> not found"
-#: ../lib/ogsf/gsd_legend.c:246
-#, fuzzy, c-format
-msgid "Unable to read color file of raster map <%s>"
-#: ../lib/ogsf/gsd_legend.c:252
-#, fuzzy, c-format
-msgid "Unable to read category file of raster map <%s>"
-#: ../lib/ogsf/gsd_legend.c:269
-#, fuzzy, c-format
-msgid "Unable to read fp range of raster map <%s>"
-#: ../lib/ogsf/gsd_legend.c:281
-#, fuzzy, c-format
-msgid "Unable to read range of raster map <%s>"
-#: ../lib/ogsf/gsd_legend.c:295
-msgid "Range request error for legend"
-msgstr ""
-#: ../lib/ogsf/gsd_legend.c:385
-#, fuzzy
-msgid "Unable to show discrete FP range (use list"
-#: ../lib/ogsf/gsd_legend.c:501
-msgid "Too many categories to show as discrete!"
-msgstr ""
-#: ../lib/ogsf/gsd_legend.c:503
-msgid "Try using smaller font!"
-msgstr ""
-#: ../lib/ogsf/gvl_file.c:103
-msgid "Maximum number of datafiles exceeded"
-msgstr ""
-#: ../lib/ogsf/gvl_file.c:436 ../lib/gpde/N_arrays_io.c:281
-#, fuzzy, c-format
-msgid "Unable to open 3D raster map <%s>"
-#: ../lib/ogsf/gvl_file.c:442
-#, fuzzy, c-format
-msgid "Unable to read range of 3D raster map <%s>"
-#: ../lib/ogsf/gvl_file.c:470 ../lib/raster3d/close.c:120
-#: ../lib/raster3d/close.c:130 ../lib/raster3d/close.c:159
-#, fuzzy, c-format
-msgid "Unable to close 3D raster map <%s>"
-#: ../lib/ogsf/GK2.c:272 ../lib/ogsf/GK2.c:285
-msgid "Check no. of frames requested and keyframes marked"
-msgstr ""
-#: ../lib/ogsf/Gs3.c:132 ../lib/ogsf/Gs3.c:196 ../lib/ogsf/Gs3.c:348
-#: ../lib/ogsf/Gs3.c:454 ../lib/ogsf/Gs3.c:540
-#, fuzzy, c-format
-msgid "Loading raster map <%s>..."
-#: ../lib/ogsf/Gs3.c:596
-#, c-format
-msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
-msgstr ""
-#: ../lib/ogsf/Gs3.c:658 ../lib/ogsf/Gs3.c:730
-#, fuzzy, c-format
-msgid "Translating colors from raster map <%s>..."
-#: ../lib/ogsf/Gs3.c:967
-msgid "View not saved by this program,there may be some inconsistancies"
-msgstr ""
-#: ../lib/ogsf/gsds.c:109
-msgid "Maximum number of datasets exceeded"
-msgstr ""
-#: ../lib/ogsf/GVL2.c:267
-#, fuzzy, c-format
-msgid "Loading 3d raster map <%s>..."
-#: ../lib/proj/convert.c:82 ../lib/vector/Vlib/build_ogr.c:485
-#: ../lib/vector/Vlib/open_ogr.c:129 ../lib/vector/Vlib/open_ogr.c:218
-#: ../lib/vector/Vlib/open_ogr.c:290 ../lib/vector/Vlib/open_ogr.c:392
-#: ../lib/vector/Vlib/rewind_ogr.c:43 ../lib/vector/Vlib/rewind_ogr.c:67
-#: ../lib/vector/Vlib/close_ogr.c:70 ../lib/vector/Vlib/close_ogr.c:144
-#: ../lib/vector/Vlib/field.c:584 ../lib/vector/Vlib/read_ogr.c:242
-#: ../lib/vector/Vlib/read_ogr.c:339 ../lib/vector/Vlib/read_ogr.c:553
-#: ../lib/vector/Vlib/read_ogr.c:624 ../lib/vector/Vlib/write_ogr.c:274
-#: ../lib/vector/Vlib/write_ogr.c:360 ../lib/vector/Vlib/write_ogr.c:394
-#: ../lib/vector/Vlib/write_ogr.c:425 ../lib/vector/Vlib/write_ogr.c:457
-#: ../lib/vector/Vlib/write_ogr.c:538
-msgid "GRASS is not compiled with OGR support"
-msgstr ""
-#: ../lib/proj/convert.c:120
-msgid "Unable parse GRASS PROJ_INFO file"
-msgstr ""
-#: ../lib/proj/convert.c:125
-msgid "Unable get PROJ.4-style parameter string"
-msgstr ""
-#: ../lib/proj/convert.c:139
-#, c-format
-msgid "OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
-msgstr ""
-#: ../lib/proj/convert.c:146
-#, c-format
-msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
-msgstr ""
-#: ../lib/proj/convert.c:406
-msgid "No projection name! Projection parameters likely to be meaningless."
-msgstr ""
-#: ../lib/proj/convert.c:442
-#, c-format
-msgid "Datum <%s> not recognised by GRASS and no parameters found"
-msgstr ""
-#: ../lib/proj/convert.c:458
-#, c-format
-msgid "Datum <%s> apparently recognised by GRASS but no parameters found. You may want to look into this."
-msgstr ""
-#: ../lib/proj/convert.c:462
-#, c-format
-msgid "Invalid transformation number %d; valid range is 1 to %d. Leaving datum transform parameters unspecified."
-msgstr ""
-#: ../lib/proj/datum.c:270 ../lib/proj/datum.c:350
-#, fuzzy, c-format
-msgid "Unable to open datum table file <%s>"
-#: ../lib/proj/datum.c:283 ../lib/proj/datum.c:364
-#, c-format
-msgid "Error in datum table file <%s>, line %d"
-msgstr ""
-#: ../lib/proj/get_proj.c:148
-#, c-format
-msgid "Invalid zone %s specified"
-msgstr ""
-#: ../lib/proj/get_proj.c:228
-msgid "Unable to initialise PROJ.4 with the following parameter list:"
-msgstr ""
-#: ../lib/proj/get_proj.c:236
-#, c-format
-msgid "The error message: %s"
-msgstr ""
-#: ../lib/proj/get_proj.c:294
-msgid "Option input overflowed option table"
-msgstr ""
-#: ../lib/proj/get_proj.c:325
-#, fuzzy, c-format
-msgid "Unable to initialize pj cause: %s"
-#: ../lib/proj/get_proj.c:401
-msgid "Input Projection Parameters"
-msgstr ""
-#: ../lib/proj/get_proj.c:404
-msgid "Input Unit Factor"
-msgstr ""
-#: ../lib/proj/get_proj.c:414
-msgid "Output Projection Parameters"
-msgstr ""
-#: ../lib/proj/get_proj.c:417
-msgid "Output Unit Factor"
-msgstr ""
-#: ../lib/proj/do_proj.c:106 ../lib/proj/do_proj.c:180
-#, c-format
-msgid "pj_transform() failed: %s"
-msgstr ""
-#: ../lib/proj/ellipse.c:76
-#, c-format
-msgid "Invalid ellipsoid <%s> in file"
-msgstr ""
-#: ../lib/proj/ellipse.c:100
-msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
-msgstr ""
-#: ../lib/proj/ellipse.c:104
-msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
-msgstr ""
-#: ../lib/proj/ellipse.c:117
-msgid "No ellipsoid info given in file"
-msgstr ""
-#: ../lib/proj/ellipse.c:217 ../lib/gis/get_ellipse.c:263
-#, fuzzy, c-format
-msgid "Unable to open ellipsoid table file <%s>"
-#: ../lib/proj/ellipse.c:270 ../lib/gis/get_ellipse.c:322
-#, c-format
-msgid "Line%s of ellipsoid table file <%s> is invalid"
-msgstr ""
-#: ../lib/proj/ellipse.c:271 ../lib/gis/get_ellipse.c:321
-#, c-format
-msgid "Lines%s of ellipsoid table file <%s> are invalid"
-msgstr ""
-#: ../lib/raster3d/range.c:76
-#, fuzzy, c-format
-msgid "Unable to open range file for [%s in %s]"
-#: ../lib/raster3d/range.c:91 ../lib/raster3d/range.c:100
-#, fuzzy, c-format
-msgid "Error reading range file for [%s in %s]"
-#: ../lib/raster3d/range.c:165
-#, fuzzy, c-format
-msgid "Unable to open range file for <%s>"
-#: ../lib/raster3d/history.c:43
-#, c-format
-msgid "can't get history information for [%s] in mapset [%s]"
-msgstr ""
-#: ../lib/raster3d/param.c:86
-msgid "Rast3d_get_standard3d_params: precision value invalid"
-msgstr ""
-#: ../lib/raster3d/param.c:119
-msgid "Rast3d_get_standard3d_params: tile dimension value invalid"
-msgstr ""
-#: ../lib/raster3d/param.c:143
-msgid "Window replacing the default"
-msgstr ""
-#: ../lib/raster3d/close.c:47
-#, fuzzy, c-format
-msgid "Unable to write history for 3D raster map <%s>"
-#: ../lib/raster3d/close.c:62
-#, fuzzy, c-format
-msgid "Unable to move temp raster map <%s> to 3d data file <%s>"
-#: ../lib/raster3d/close.c:79
-#, fuzzy
-msgid "Unable to flush all tiles"
-#: ../lib/raster3d/close.c:84
-#, fuzzy
-msgid "Unable to flush index"
-#: ../lib/raster3d/close.c:94
-#, fuzzy
-msgid "Unable to position file"
-#: ../lib/raster3d/close.c:99 ../lib/raster3d/close.c:105
-#: ../lib/raster3d/close.c:191
-#, fuzzy, c-format
-msgid "Unable to write header for 3D raster map <%s>"
-#: ../lib/raster3d/close.c:110 ../lib/raster3d/close.c:153
-#, fuzzy, c-format
-msgid "Unable to create 3D raster map <%s>"
-#: ../lib/raster3d/close.c:169
-msgid "Error in cache"
-msgstr ""
-#: ../lib/raster3d/test/test_coordinate_transform.c:17
-msgid ""
-"\n"
-"++ Running g3d coordinate transform unit tests ++"
-msgstr ""
-#: ../lib/raster3d/test/test_coordinate_transform.c:23
-msgid ""
-"\n"
-"-- g3d coordinate transform unit tests failure --"
-msgstr ""
-#: ../lib/raster3d/test/test_coordinate_transform.c:25
-msgid ""
-"\n"
-"-- g3d coordinate transform unit tests finished successfully --"
-msgstr ""
-#: ../lib/raster3d/test/test_put_get_value.c:37
-msgid ""
-"\n"
-"++ Running g3d put/get value unit tests ++"
-msgstr ""
-#: ../lib/raster3d/test/test_put_get_value.c:45
-msgid ""
-"\n"
-"-- g3d put/get value unit tests failure --"
-msgstr ""
-#: ../lib/raster3d/test/test_put_get_value.c:47
-msgid ""
-"\n"
-"-- g3d put/get value unit tests finished successfully --"
-msgstr ""
-#: ../lib/raster3d/test/test_main.c:43 ../lib/gmath/test/test_main.c:47
-#: ../lib/gpde/test/test_main.c:50 ../lib/db/dbmi_base/test/test_main.c:47
-msgid "Choose the unit tests to run"
-msgstr ""
-#: ../lib/raster3d/test/test_main.c:50 ../lib/gmath/test/test_main.c:54
-#: ../lib/gpde/test/test_main.c:57 ../lib/db/dbmi_base/test/test_main.c:54
-msgid "Choose the integration tests to run"
-msgstr ""
-#: ../lib/raster3d/test/test_main.c:54 ../lib/gmath/test/test_main.c:79
-#: ../lib/gpde/test/test_main.c:62 ../lib/db/dbmi_base/test/test_main.c:58
-msgid "Run all unit tests"
-msgstr ""
-#: ../lib/raster3d/test/test_main.c:58 ../lib/gmath/test/test_main.c:83
-#: ../lib/gpde/test/test_main.c:66 ../lib/db/dbmi_base/test/test_main.c:62
-msgid "Run all integration tests"
-msgstr ""
-#: ../lib/raster3d/test/test_main.c:62 ../lib/gmath/test/test_main.c:87
-#: ../lib/gpde/test/test_main.c:70 ../lib/db/dbmi_base/test/test_main.c:66
-msgid "Run all unit and integration tests"
-msgstr ""
-#: ../lib/raster3d/test/test_main.c:79
-msgid "Performs unit and integration tests for the g3d library"
-msgstr ""
-#: ../lib/raster3d/open.c:20
-msgid "Rast3d_open_cell_old_no_header: error in Rast3d_mask_open_old"
-msgstr ""
-#: ../lib/raster3d/open.c:26
-msgid "Rast3d_open_cell_old_no_header: error in Rast3d_malloc"
-msgstr ""
-#: ../lib/raster3d/open.c:37
-msgid "Rast3d_open_cell_old_no_header: error in G_open_old"
-msgstr ""
-#: ../lib/raster3d/open.c:91
-msgid "Rast3d_open_cell_old: error in Rast3d_open_cell_old_no_header"
-msgstr ""
-#: ../lib/raster3d/open.c:96
-msgid "Rast3d_open_cell_old: can't rewind file"
-msgstr ""
-#: ../lib/raster3d/open.c:108
-msgid "Rast3d_open_cell_old: error in Rast3d_read_header"
-msgstr ""
-#: ../lib/raster3d/open.c:116
-msgid "Rast3d_open_cell_old: projection does not match window projection"
-msgstr ""
-#: ../lib/raster3d/open.c:120
-msgid "Rast3d_open_cell_old: zone does not match window zone"
-msgstr ""
-#: ../lib/raster3d/open.c:132 ../lib/raster3d/open.c:149
-msgid "Rast3d_open_cell_old: can't read header"
-msgstr ""
-#: ../lib/raster3d/open.c:138
-msgid "Rast3d_open_cell_old: index does not fit into long"
-msgstr ""
-#: ../lib/raster3d/open.c:142
-msgid "Rast3d_open_cell_old: error in Rast3d_malloc"
-msgstr ""
-#: ../lib/raster3d/open.c:168
-msgid "Rast3d_open_cell_old: error in Rast3d_fill_header"
-msgstr ""
-#: ../lib/raster3d/open.c:215
-msgid "Rast3d_open_cell_new: error in Rast3d_mask_open_old"
-msgstr ""
-#: ../lib/raster3d/open.c:224
-msgid "Rast3d_open_cell_new: error in Rast3d_malloc"
-msgstr ""
-#: ../lib/raster3d/open.c:229
-#, fuzzy, c-format
-msgid "map <%s> is not in the current mapset"
-#: ../lib/raster3d/open.c:239
-msgid "Rast3d_open_cell_new: could not open file"
-msgstr ""
-#: ../lib/raster3d/open.c:284 ../lib/raster3d/open.c:289
-msgid "Rast3d_open_cell_new: can't write header"
-msgstr ""
-#: ../lib/raster3d/open.c:312
-msgid "Rast3d_open_cell_new: error in Rast3d_fill_header"
-msgstr ""
-#: ../lib/raster3d/maskfn.c:77
-#, c-format
-msgid "Adding rule: %lf - %lf"
-msgstr ""
-#: ../lib/raster3d/maskfn.c:95
-#, c-format
-msgid "%s: illegal value spec"
-msgstr ""
-#: ../lib/raster3d/color.c:333
-#, c-format
-msgid "mapset <%s> is not the current mapset"
-msgstr ""
-#: ../lib/init/prompt.py:20
-msgid "[Raster and Volume MASKs present]"
-msgstr ""
-#: ../lib/init/prompt.py:22
-msgid "[Raster MASK present]"
-msgstr ""
-#: ../lib/init/prompt.py:24
-msgid "[Volume MASK present]"
-msgstr ""
-#: ../lib/init/lock.c:38
-#, c-format
-msgid "Usage: %s file pid"
-msgstr ""
-#: ../lib/init/lock.c:42
-msgid "Concurrent mapset locking is not supported on Windows"
-msgstr ""
-#: ../lib/init/lock.c:60
-#, c-format
-msgid "Unable to write lockfile %s (disk full? Permissions?)"
-msgstr ""
-#: ../lib/init/grass.py:69
-#, fuzzy
-msgid "WARNING"
-msgstr "ताकिद: "
-#: ../lib/init/grass.py:173
-msgid "Usage"
-msgstr ""
-#: ../lib/init/grass.py:174 ../lib/gis/parser_html.c:126
-msgid "Flags"
-msgstr ""
-#: ../lib/init/grass.py:175
-msgid "print this help message"
-msgstr ""
-#: ../lib/init/grass.py:176
-msgid "show version information and exit"
-msgstr ""
-#: ../lib/init/grass.py:177
-msgid "create given database, location or mapset if it doesn't exist"
-msgstr ""
-#: ../lib/init/grass.py:178
-msgid "use text based interface"
-msgstr ""
-#: ../lib/init/grass.py:179 ../lib/init/grass.py:181
-msgid "and set as default"
-msgstr ""
-#: ../lib/init/grass.py:180
-msgid "use $DEFAULT_GUI graphical user interface"
-msgstr ""
-#: ../lib/init/grass.py:182
-msgid "print GRASS configuration parameters"
-msgstr ""
-#: ../lib/init/grass.py:183
-msgid "options: arch,build,compiler,path,revision"
-msgstr ""
-#: ../lib/init/grass.py:184 ../lib/gis/parser_html.c:164
-msgid "Parameters"
-msgstr ""
-#: ../lib/init/grass.py:185
-msgid "initial database (path to GIS data)"
-msgstr ""
-#: ../lib/init/grass.py:186
-msgid "initial location"
-msgstr ""
-#: ../lib/init/grass.py:187
-msgid "initial mapset"
-msgstr ""
-#: ../lib/init/grass.py:188
-msgid "fully qualified initial mapset directory"
-msgstr ""
-#: ../lib/init/grass.py:189
-msgid "Environment variables relevant for startup"
-msgstr ""
-#: ../lib/init/grass.py:190
-msgid "select GUI (text, gui)"
-msgstr ""
-#: ../lib/init/grass.py:191
-msgid "set wish shell name to override 'wish'"
-msgstr ""
-#: ../lib/init/grass.py:192
-msgid "set html web browser for help pages"
-msgstr ""
-#: ../lib/init/grass.py:193
-msgid "set additional path(s) to local GRASS modules or user scripts"
-msgstr ""
-#: ../lib/init/grass.py:194
-msgid "set additional GISBASE for locally installed GRASS Addons"
-msgstr ""
-#: ../lib/init/grass.py:195
-msgid "shell script to be processed as batch job"
-msgstr ""
-#: ../lib/init/grass.py:196
-msgid "set python shell name to override 'python'"
-msgstr ""
-#: ../lib/init/grass.py:216
-#, fuzzy, python-format
-msgid "Unable to create temporary directory <%s>! Exiting."
-#: ../lib/init/grass.py:294
-#, python-format
-msgid "GUI <%s> not supported in this version"
-msgstr ""
-#: ../lib/init/grass.py:414
-msgid "Searched for a web browser, but none found"
-msgstr ""
-#: ../lib/init/grass.py:438
-#, fuzzy
-msgid "Hit RETURN to continue"
-msgstr "पुढे जाण्यासाठी RETURN टाइप करा -->"
-#: ../lib/init/grass.py:467
-msgid ""
-"The python command does not work as expected!\n"
-"Please check your GRASS_PYTHON environment variable.\n"
-"Use the -help option for details.\n"
-"Switching to text based interface mode.\n"
-"\n"
-"Hit RETURN to continue.\n"
-msgstr ""
-#: ../lib/init/grass.py:479
-msgid ""
-"It appears that the X Windows system is not active.\n"
-"A graphical based user interface is not supported.\n"
-"\n"
-"Hit RETURN to continue"
-msgstr ""
-#: ../lib/init/grass.py:521 ../lib/init/grass.py:552
-#, python-format
-msgid "<%s> is not a valid GRASS location"
-msgstr ""
-#: ../lib/init/grass.py:533
-#, python-format
-msgid "Failed to create new location. The location <%s> already exists."
-msgstr ""
-#: ../lib/init/grass.py:550
-msgid "Missing WIND file fixed"
-msgstr ""
-#: ../lib/init/grass.py:564
-msgid ""
-"GISDBASE, LOCATION_NAME and MAPSET variables not set properly.\n"
-"Interactive startup needed."
-msgstr ""
-#: ../lib/init/grass.py:578
-#, python-format
-msgid ""
-"Invalid user interface specified - <%s>.\n"
-"Use the --help option to see valid interface names."
-msgstr ""
-#: ../lib/init/grass.py:591
-msgid ""
-"Error in GUI startup. If necessary, please report this error to the GRASS developers.\n"
-"Switching to text mode now.\n"
-"\n"
-"Hit RETURN to continue..."
-msgstr ""
-#: ../lib/init/grass.py:601
-msgid ""
-"Received EXIT message from GUI.\n"
-"GRASS is not started. Bye."
-msgstr ""
-#: ../lib/init/grass.py:604
-msgid ""
-"Invalid return code from GUI startup script.\n"
-"Please advise GRASS developers of this error."
-msgstr ""
-#: ../lib/init/grass.py:614
-msgid ""
-"Error reading data path information from g.gisenv.\n"
-"GISDBASE=%(gisbase)s\n"
-"LOCATION_NAME=%(location)s\n"
-"MAPSET=%(mapset)s\n"
-"\n"
-"Check the <%s(file)> file."
-msgstr ""
-#: ../lib/init/grass.py:642
-#, python-format
-msgid "Path '%s' doesn't exist"
-msgstr ""
-#: ../lib/init/grass.py:653
-#, python-format
-msgid "%(user)s is currently running GRASS in selected mapset (file %(file)s found). Concurrent use not allowed."
-msgstr ""
-#: ../lib/init/grass.py:657
-#, python-format
-msgid ""
-"Unable to properly access '%s'.\n"
-"Please notify system personel."
-msgstr ""
-#: ../lib/init/grass.py:671
-msgid "Building user fontcap..."
-msgstr ""
-#: ../lib/init/grass.py:700
-msgid "The SHELL variable is not set"
-msgstr ""
-#: ../lib/init/grass.py:710
-#, python-format
-msgid ""
-"Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not found. Exiting.\n"
-"\n"
-"Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
-msgstr ""
-#: ../lib/init/grass.py:715
-#, python-format
-msgid "Change file permission to 'executable' for '%s'"
-msgstr ""
-#: ../lib/init/grass.py:717
-#, python-format
-msgid "Executing '%s' ..."
-msgstr ""
-#: ../lib/init/grass.py:722
-#, python-format
-msgid "Execution of '%s' finished."
-msgstr ""
-#: ../lib/init/grass.py:727
-#, python-format
-msgid "GRASS GUI should be <%s>"
-msgstr ""
-#: ../lib/init/grass.py:755
-#, python-format
-msgid "Welcome to GRASS %s"
-msgstr ""
-#: ../lib/init/grass.py:764
-msgid "GRASS homepage:"
-msgstr ""
-#: ../lib/init/grass.py:765
-msgid "This version running through:"
-msgstr ""
-#: ../lib/init/grass.py:767
-#, fuzzy
-msgid "Help is available with the command:"
-msgstr "[%s] या कमांडसाठी कोणतीही मदत उपलब्ध नाही\n"
-#: ../lib/init/grass.py:768
-msgid "See the licence terms with:"
-msgstr ""
-#: ../lib/init/grass.py:771
-msgid "If required, restart the GUI with:"
-msgstr ""
-#: ../lib/init/grass.py:773
-msgid "Start the GUI with:"
-msgstr ""
-#: ../lib/init/grass.py:775
-msgid "When ready to quit enter:"
-msgstr ""
-#: ../lib/init/grass.py:874
-msgid "Failed to start shell '%s'"
-#: ../lib/init/grass.py:878
-#, python-format
-msgid "Batch job '%s' (defined in GRASS_BATCH_JOB variable) was executed."
-msgstr ""
-#: ../lib/init/grass.py:879 ../lib/init/grass.py:884
-msgid "Goodbye from GRASS GIS"
-msgstr ""
-#: ../lib/init/grass.py:882
-#, fuzzy
-msgid "Done."
-msgstr "काही नाही"
-#: ../lib/init/grass.py:888
-msgid "Cleaning up temporary files..."
-msgstr ""
-#: ../lib/init/grass.py:930
-msgid "Parameter <%s> not supported"
-#: ../lib/init/grass.py:1071
-#, python-format
-msgid ""
-"Unable to start GRASS. You can:\n"
-" - Launch GRASS with '-gui' switch (`grass70 -gui`)\n"
-" - Create manually GISRC file (%s)\n"
-" - Launch GRASS with path to the location/mapset as an argument (`grass70 /path/to/location/mapset`)"
-msgstr ""
-#: ../lib/init/grass.py:1080
-msgid "Starting GRASS GIS..."
-msgstr ""
-#: ../lib/init/grass.py:1137
-#, python-format
-msgid "Launching <%s> GUI in the background, please wait..."
-msgstr ""
-#: ../lib/raster/range.c:103 ../lib/raster/range.c:118
-#, fuzzy, c-format
-msgid "Unable to read fp range file for <%s>"
-#: ../lib/raster/range.c:174
-#, fuzzy, c-format
-msgid "Unable to read quant rules for raster map <%s>"
-#: ../lib/raster/range.c:211 ../lib/raster/range.c:228
-#, fuzzy, c-format
-msgid "Unable to read range file for <%s>"
-#: ../lib/raster/range.c:266 ../lib/raster/range.c:272
-#: ../lib/raster/range.c:301 ../lib/raster/range.c:315
-#: ../lib/raster/range.c:320
-#, fuzzy, c-format
-msgid "Unable to write range file for <%s>"
-#: ../lib/raster/history.c:115 ../lib/raster/history.c:123
-#, fuzzy, c-format
-msgid "Unable to get history information for <%s@%s>"
-#: ../lib/raster/history.c:162
-#, fuzzy, c-format
-msgid "Unable to write history information for <%s>"
-#: ../lib/raster/history.c:235
-#, c-format
-msgid "generated by %s"
-msgstr ""
-#: ../lib/raster/put_title.c:28
-#, c-format
-msgid "category information for [%s] in [%s] missing or invalid"
-msgstr ""
-#: ../lib/raster/put_title.c:37
-msgid "G_put_title - can't create a temp file"
-msgstr ""
-#: ../lib/raster/put_title.c:53
-#, c-format
-msgid "category information for [%s] in [%s] invalid"
-msgstr ""
-#: ../lib/raster/put_title.c:60
-msgid "G_put_title - can't reopen temp file"
-msgstr ""
-#: ../lib/raster/put_title.c:67
-#, c-format
-msgid "can't write category information for [%s] in [%s]"
-msgstr ""
-#: ../lib/raster/color_rand.c:33
-#, c-format
-msgid "Rast_make_random_colors: min (%d) > max (%d)"
-msgstr ""
-#: ../lib/raster/init.c:62
-msgid "Raster library not initialized. Programmer forgot to call Rast_init()."
-msgstr ""
-#: ../lib/raster/color_read.c:103
-msgid "missing"
-msgstr ""
-#: ../lib/raster/color_read.c:106
-msgid "invalid"
-msgstr ""
-#: ../lib/raster/color_read.c:112
-#, c-format
-msgid "Color support for <%s@%s> %s"
-msgstr ""
-#: ../lib/raster/close.c:74 ../lib/raster/close.c:107
-#, fuzzy, c-format
-msgid "Invalid descriptor: %d"
-#: ../lib/raster/close.c:374
-#, fuzzy, c-format
-msgid "Unable to rename null file '%s'"
-#: ../lib/raster/close.c:440
-#, fuzzy, c-format
-msgid "Unable to rename cell file '%s'"
-#: ../lib/raster/close.c:475
-msgid "unable to write f_format file for CELL maps"
-msgstr ""
-#: ../lib/raster/auto_mask.c:69
-msgid "Unable to open automatic MASK file"
-msgstr ""
-#: ../lib/raster/gdal.c:88
-#, fuzzy, c-format
-msgid "Unable to locate symbol <%s>"
-#: ../lib/raster/gdal.c:135
-#, fuzzy
-msgid "Unable to load GDAL library"
-#: ../lib/raster/gdal.c:365
-#, fuzzy
-msgid "Unable to open GDAL file"
-#: ../lib/raster/gdal.c:469 ../lib/raster/open.c:573
-#, fuzzy, c-format
-msgid "Invalid map type <%d>"
-#: ../lib/raster/gdal.c:475
-#, fuzzy, c-format
-msgid "Unable to get <%s> driver"
-#: ../lib/raster/gdal.c:484
-#, fuzzy, c-format
-msgid "Unable to create <%s> dataset using <%s> driver"
-#: ../lib/raster/gdal.c:492
-#, c-format
-msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
-msgstr ""
-#: ../lib/raster/gdal.c:498
-#, fuzzy
-msgid "Unable to get in-memory raster driver"
-#: ../lib/raster/gdal.c:505
-#, fuzzy, c-format
-msgid "Unable to create <%s> dataset using memory driver"
-#: ../lib/raster/gdal.c:509
-#, c-format
-msgid "Driver <%s> does not support creating rasters"
-msgstr ""
-#: ../lib/raster/gdal.c:525
-#, fuzzy
-msgid "Unable to set geo transform"
-#: ../lib/raster/gdal.c:529
-#, fuzzy
-msgid "Unable to set projection"
-#: ../lib/raster/gdal.c:533
-#, fuzzy, c-format
-msgid "Unable to create cell_misc/%s/gdal file"
-#: ../lib/raster/gdal.c:549
-#, fuzzy, c-format
-msgid "Error writing cell_misc/%s/gdal file"
-#: ../lib/raster/gdal.c:597
-#, fuzzy, c-format
-msgid "Unable to create output file <%s> using driver <%s>"
-#: ../lib/raster/window.c:18
-msgid "Internal error: Rast_get_window() called with split window.Use Rast_get_input_window() or Rast_get_output_window() instead."
-msgstr ""
-#: ../lib/raster/window.c:77
-msgid "Internal error: Rast_window_rows() called with split window.Use Rast_input_window_rows() or Rast_output_window_rows() instead."
-msgstr ""
-#: ../lib/raster/window.c:112
-msgid "Internal error: Rast_window_cols() called with split window.Use Rast_input_window_cols() or Rast_output_window_cols() instead."
-msgstr ""
-#: ../lib/raster/color_rules.c:125
-msgid "syntax error"
-msgstr ""
-#: ../lib/raster/color_rules.c:127
-msgid "R/G/B not in range 0-255"
-msgstr ""
-#: ../lib/raster/color_rules.c:129
-#, fuzzy
-msgid "invalid color name"
-#: ../lib/raster/color_rules.c:131
-msgid "percentage not in range 0-100"
-msgstr ""
-#: ../lib/raster/color_rules.c:133
-msgid "invalid value"
-msgstr ""
-#: ../lib/raster/color_rules.c:135
-msgid "unknown error"
-msgstr ""
-#: ../lib/raster/color_rules.c:181
-#, c-format
-msgid "bad rule (%s): [%s]"
-msgstr ""
-#: ../lib/raster/color_rules.c:326
-#, fuzzy, c-format
-msgid "Unable to load color rules <%s>"
-#: ../lib/raster/set_window.c:48
-msgid "Rast_set_window() called while window split"
-msgstr ""
-#: ../lib/raster/set_window.c:131
-msgid "Rast_set_read_window(): projection/zone differs from that of currently open raster maps"
-msgstr ""
-#: ../lib/raster/set_window.c:158
-msgid "Input window changed while maps are open for read"
-msgstr ""
-#: ../lib/raster/set_window.c:176
-msgid "Output window changed while maps are open for write"
-msgstr ""
-#: ../lib/raster/color_write.c:81 ../lib/vector/Vlib/color_write.c:71
-#, c-format
-msgid "Qualified name <%s> doesn't match mapset <%s>"
-msgstr ""
-#: ../lib/raster/color_write.c:96 ../lib/vector/Vlib/color_write.c:91
-#, fuzzy, c-format
-msgid "Unable to create <%s> file for map <%s>"
-#: ../lib/raster/reclass.c:168
-#, fuzzy, c-format
-msgid "Too many reclass categories for <%s@%s>"
-#: ../lib/raster/reclass.c:171
-#, fuzzy, c-format
-msgid "Illegal reclass format in header file for <%s@%s>"
-#: ../lib/raster/reclass.c:273
-msgid "Illegal reclass request"
-msgstr ""
-#: ../lib/raster/reclass.c:278
-msgid "Illegal reclass type"
-msgstr ""
-#: ../lib/raster/reclass.c:284
-#, fuzzy, c-format
-msgid "Unable to create header file for <%s@%s>"
-#: ../lib/raster/reclass.c:332
-#, fuzzy, c-format
-msgid "Unable to create dependency file in <%s@%s>"
-#: ../lib/raster/get_row.c:37 ../lib/raster/get_row.c:882
-#, c-format
-msgid "Reading raster map <%s@%s> request for row %d is outside region"
-msgstr ""
-#: ../lib/raster/get_row.c:96 ../lib/raster/get_row.c:101
-#: ../lib/raster/get_row.c:134 ../lib/raster/get_row.c:140
-#: ../lib/raster/get_row.c:174 ../lib/raster/get_row.c:177
-#, fuzzy
-msgid "Error reading raster data"
-#: ../lib/raster/get_row.c:212
-#, fuzzy
-msgid "Error reading raster data via GDAL"
-#: ../lib/raster/get_row.c:313
-#, c-format
-msgid "cell_values_float: xdr_float failed for index %d"
-msgstr ""
-#: ../lib/raster/get_row.c:352
-#, c-format
-msgid "cell_values_double: xdr_double failed for index %d"
-msgstr ""
-#: ../lib/raster/get_row.c:866 ../lib/raster/get_row.c:869
-#, c-format
-msgid "Error reading null row %d"
-msgstr ""
-#: ../lib/raster/open.c:190
-#, c-format
-msgid "Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%s> which does not exist"
-msgstr ""
-#: ../lib/raster/open.c:195
-#, fuzzy, c-format
-msgid "Error reading reclass file for raster map <%s>"
-#: ../lib/raster/open.c:206
-#, fuzzy, c-format
-msgid "Error reading map type for raster map <%s>"
-#: ../lib/raster/open.c:214
-#, c-format
-msgid "Raster map <%s@%s>: format field in header file invalid"
-msgstr ""
-#: ../lib/raster/open.c:219
-#, c-format
-msgid "Raster map <%s> is in different projection than current region. Found <%s>, should be <%s>."
-msgstr ""
-#: ../lib/raster/open.c:226
-#, c-format
-msgid "Raster map <%s> is in different zone (%d) than current region (%d)"
-msgstr ""
-#: ../lib/raster/open.c:231
-#, c-format
-msgid "Raster map <%s>: bytes per cell (%d) too large"
-msgstr ""
-#: ../lib/raster/open.c:256
-#, c-format
-msgid "Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
-msgstr ""
-#: ../lib/raster/open.c:264
-#, fuzzy, c-format
-msgid "Unable to open %s file for raster map <%s@%s>"
-#: ../lib/raster/open.c:301
-#, fuzzy, c-format
-msgid "Error reading format for <%s@%s>"
-#: ../lib/raster/open.c:502
-#, fuzzy
-msgid "Unable to create GDAL link"
-#: ../lib/raster/open.c:578
-#, c-format
-msgid "Raster map <%s> is not in the current mapset (%s)"
-msgstr ""
-#: ../lib/raster/open.c:585
-#, c-format
-msgid "<%s> is an illegal file name"
-msgstr ""
-#: ../lib/raster/open.c:599
-msgid "No temp files available"
-msgstr ""
-#: ../lib/raster/open.c:671
-msgid "no temp files available"
-msgstr ""
-#: ../lib/raster/open.c:724
-msgid "Rast_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
-msgstr ""
-#: ../lib/raster/open.c:782
-#, fuzzy, c-format
-msgid "Raster map <%s> not found in mapset <%s>"
-#: ../lib/raster/open.c:843
-#, fuzzy, c-format
-msgid "Unable to find '%s'"
-#: ../lib/raster/open.c:854
-#, c-format
-msgid "Invalid type: field '%s' in file '%s'"
-msgstr ""
-#: ../lib/raster/open.c:859
-#, c-format
-msgid "Missing type: field in file '%s'"
-msgstr ""
-#: ../lib/raster/open.c:864
-#, fuzzy, c-format
-msgid "Raster map <%s> is not xdr: byte_order: %s"
-#: ../lib/raster/open.c:933
-msgid "Rast_set_quant_rules() can be called only for raster maps opened for reading"
-msgstr ""
-#: ../lib/raster/null_val.c:64
-msgid "EmbedGivenNulls: wrong data type"
-msgstr ""
-#: ../lib/raster/null_val.c:114
-msgid "Rast_set_null_value: wrong data type!"
-msgstr ""
-#: ../lib/raster/put_row.c:120
-#, fuzzy, c-format
-msgid "Error writing uncompressed FP data for row %d of <%s>"
-#: ../lib/raster/put_row.c:130
-#, fuzzy, c-format
-msgid "Error writing compressed FP data for row %d of <%s>"
-#: ../lib/raster/put_row.c:158
-#, c-format
-msgid "xdr_float failed for index %d of row %d"
-msgstr ""
-#: ../lib/raster/put_row.c:179
-#, c-format
-msgid "xdr_double failed for index %d of row %d"
-msgstr ""
-#: ../lib/raster/put_row.c:397 ../lib/raster/put_row.c:403
-#, fuzzy, c-format
-msgid "Error writing compressed data for row %d of <%s>"
-#: ../lib/raster/put_row.c:413
-#, fuzzy, c-format
-msgid "Error writing uncompressed data for row %d of <%s>"
-#: ../lib/raster/put_row.c:472
-#, fuzzy, c-format
-msgid "Error writing data via GDAL for row %d of <%s>"
-#: ../lib/raster/put_row.c:496
-#, fuzzy, c-format
-msgid "No null file for <%s>"
-#: ../lib/raster/put_row.c:510
-msgid "GDAL output doesn't support writing null rows separately"
-msgstr ""
-#: ../lib/raster/put_row.c:530
-#, fuzzy, c-format
-msgid "Unable to find a temporary null file <%s>"
-#: ../lib/raster/put_row.c:535
-#, fuzzy, c-format
-msgid "Unable to open null file <%s>"
-#: ../lib/raster/put_row.c:562 ../lib/raster/put_row.c:565
-#, fuzzy, c-format
-msgid "Error writing null row %d"
-#: ../lib/raster/put_row.c:690
-#, fuzzy, c-format
-msgid "put_raster_row: raster map <%s> not open for write - request ignored"
-#: ../lib/raster/put_row.c:697
-#, fuzzy
-msgid "put_raster_row: unopened file descriptor - request ignored"
-#: ../lib/raster/quant_rw.c:88
-#, fuzzy, c-format
-msgid "Unable to read fp range for raster map <%s>"
-#: ../lib/raster/quant_rw.c:92
-#, fuzzy, c-format
-msgid "Raster map <%s> is empty"
-#: ../lib/raster/quant_rw.c:157
-#, fuzzy, c-format
-msgid "Unable to write quant rules: raster map <%s> is integer"
-#: ../lib/raster/quant_rw.c:166
-#, fuzzy, c-format
-msgid "Unable to write quant rules for raster map <%s>"
-#: ../lib/raster/cats.c:109
-#, c-format
-msgid "Category support for <%s@%s> missing"
-msgstr ""
-#: ../lib/raster/cats.c:112
-#, c-format
-msgid "Category support for <%s@%s> invalid"
-msgstr ""
-#: ../lib/raster/cats.c:145
-#, fuzzy, c-format
-msgid "Category support for vector map <%s@%s> missing"
-#: ../lib/raster/cats.c:149
-#, fuzzy, c-format
-msgid "Category support for vector map <%s@%s> invalid"
-#: ../lib/raster/cats.c:964
-#, fuzzy, c-format
-msgid "Unable to open %s file for map <%s>"
-#: ../lib/raster/sample.c:70
-msgid "Unknown interpolation type"
-msgstr ""
-#: ../lib/raster/sample.c:327
-msgid "\"no data\" label found; setting to zero"
-msgstr ""
-#: ../lib/raster/format.c:154
-#, c-format
-msgid "Fail of initial read of compressed file [%s in %s]"
-msgstr ""
-#: ../lib/raster/mask_info.c:43
-#, c-format
-msgid "<%s> in mapset <%s>"
-msgstr ""
-#: ../lib/raster/mask_info.c:46
-msgid "none"
-msgstr "काही नाही"
-#: ../lib/raster/mask_info.c:49
-msgid "not known"
-msgstr "अज्ञात"
-#: ../lib/raster/raster_metadata.c:110
-#, fuzzy, c-format
-msgid "Unable to read <%s> for raster map <%s@%s>"
-#: ../lib/raster/raster_metadata.c:120 ../lib/raster/raster_metadata.c:149
-#, fuzzy, c-format
-msgid "Error closing <%s> metadata file for raster map <%s@%s>"
-#: ../lib/raster/raster_metadata.c:143
-#, fuzzy, c-format
-msgid "Unable to create <%s> metadata file for raster map <%s@%s>"
-#: ../lib/raster/put_cellhd.c:34
-#, fuzzy, c-format
-msgid "Unable to create header file for <%s>"
-#: ../lib/raster/quant_io.c:43
-#, fuzzy, c-format
-msgid "Floating data range for raster map <%s> is empty"
-#: ../lib/raster/quant_io.c:52
-#, fuzzy, c-format
-msgid "Integer data range for raster map <%s> is empty"
-#: ../lib/raster/quant_io.c:105
-#, fuzzy, c-format
-msgid "Attempt to open quantization table for CELL raster map <%s>"
-#: ../lib/raster/quant_io.c:135
-#, fuzzy, c-format
-msgid "Quantization file for raster map <%s> is missing"
-#: ../lib/raster/quant_io.c:145
-#, fuzzy, c-format
-msgid "Quantization file for raster map <%s> is empty"
-#: ../lib/raster/get_cellhd.c:66
-#, fuzzy, c-format
-msgid "Unable to read header file for raster map <%s@%s>.It is a reclass of raster map <%s@%s> %s"
-#: ../lib/raster/get_cellhd.c:70
-msgid "which is missing."
-msgstr ""
-#: ../lib/raster/get_cellhd.c:71
-msgid "whose header file can't be opened."
-msgstr ""
-#: ../lib/raster/get_cellhd.c:76
-#, fuzzy, c-format
-msgid "Unable to open header file for raster map <%s@%s>"
-#: ../lib/raster/histogram.c:55
-#, c-format
-msgid "Histogram for [%s in %s] missing (run r.support)"
-msgstr ""
-#: ../lib/raster/histogram.c:62
-#, c-format
-msgid "Can't read histogram for [%s in %s]"
-msgstr ""
-#: ../lib/raster/histogram.c:66 ../lib/raster/histogram.c:73
-#, c-format
-msgid "Invalid histogram file for [%s in %s]"
-msgstr ""
-#: ../lib/raster/histogram.c:331
-#, fuzzy, c-format
-msgid "Unable to create histogram file for <%s>"
-#: ../lib/raster/alloc_cell.c:151
-#, c-format
-msgid "Rast__null_bitstream_size: cols (%d) is negative"
-msgstr ""
-#: ../lib/imagery/iclass_perimeter.c:110
-#, c-format
-msgid "Get area %d failed"
-msgstr ""
-#: ../lib/imagery/iclass_perimeter.c:117
-msgid "Perimeter computation failed"
-msgstr ""
-#: ../lib/imagery/iclass_perimeter.c:197
-msgid "Absurd polygon."
-msgstr ""
-#: ../lib/imagery/iclass_perimeter.c:242
-msgid "Outlined area is too large."
-msgstr ""
-#: ../lib/imagery/iclass_statistics.c:219
-msgid "prepare_signature: outline has odd number of points."
-msgstr ""
-#: ../lib/imagery/iclass_statistics.c:228
-#, c-format
-msgid "prepare_signature: scan line %d has odd number of points."
-msgstr ""
-#: ../lib/imagery/iclass_statistics.c:238
-msgid "signature: perimeter points out of order."
-msgstr ""
-#: ../lib/imagery/iclass_statistics.c:248
-msgid "prepare_signature: data error."
-msgstr ""
-#: ../lib/imagery/iclass_statistics.c:560
-#: ../lib/imagery/iclass_statistics.c:583
-#: ../lib/imagery/iclass_statistics.c:606
-#: ../lib/imagery/iclass_statistics.c:629
-#: ../lib/imagery/iclass_statistics.c:652
-#: ../lib/imagery/iclass_statistics.c:679
-#: ../lib/imagery/iclass_statistics.c:711
-#: ../lib/imagery/iclass_statistics.c:734
-#: ../lib/imagery/iclass_statistics.c:757
-msgid "Band index out of range"
-msgstr ""
-#: ../lib/imagery/iclass_statistics.c:683
-msgid "Cell category value out of range"
-msgstr ""
-#: ../lib/imagery/iclass_signatures.c:120
-#, fuzzy, c-format
-msgid "Unable to open output signature file '%s'"
-#: ../lib/imagery/list_gp.c:34
-#, c-format
-msgid "group <%s> is empty\n"
-msgstr ""
-#: ../lib/imagery/list_gp.c:44
-#, c-format
-msgid "group <%s> references the following raster maps\n"
-msgstr ""
-#: ../lib/imagery/sigsetfile.c:41
-#, c-format
-msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> is not current mapset"
-msgstr ""
-#: ../lib/imagery/sigsetfile.c:57
-#, fuzzy, c-format
-msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
-#: ../lib/imagery/sigsetfile.c:86
-#, fuzzy, c-format
-msgid "Unable to open signature file <%s> for subgroup <%s> of group <%s@%s>"
-#: ../lib/imagery/fopen.c:23
-#, c-format
-msgid "Unable to create file [%s] of group [%s in %s]"
-msgstr ""
-#: ../lib/imagery/fopen.c:36 ../lib/imagery/fopen.c:57
-#, fuzzy, c-format
-msgid "Unable to open file [%s] of group [%s in %s]"
-msgstr "उघडलेल्या फाइलचे नाव %s\n"
-#: ../lib/imagery/fopen.c:49
-#, c-format
-msgid "Unable to find file [%s] of group [%s in %s]"
-msgstr ""
-#: ../lib/imagery/fopen.c:79
-#, c-format
-msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-#: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
-#, c-format
-msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-#: ../lib/imagery/fopen.c:116
-#, c-format
-msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-#: ../lib/imagery/iclass.c:112
-#, fuzzy, c-format
-msgid "Raster map <%s@%s> in group <%s> do not exist"
-#: ../lib/imagery/iclass.c:121
-#, c-format
-msgid "Group <%s> does not have enough files (it has %d files)"
-msgstr ""
-#: ../lib/imagery/list_subgp.c:36
-#, c-format
-msgid "subgroup <%s> of group <%s> is empty\n"
-msgstr ""
-#: ../lib/imagery/list_subgp.c:48
-#, c-format
-msgid "subgroup <%s> of group <%s> references the following raster maps\n"
-msgstr ""
-#: ../lib/imagery/target.c:38
-#, fuzzy, c-format
-msgid "Unable to read target file for group [%s]"
-#: ../lib/imagery/points.c:124
-#, fuzzy, c-format
-msgid "Unable to open control point file for group [%s in %s]"
-#: ../lib/imagery/points.c:132
-#, fuzzy, c-format
-msgid "Bad format in control point file for group [%s in %s]"
-#: ../lib/imagery/points.c:159
-#, fuzzy, c-format
-msgid "Unable to create control point file for group [%s in %s]"
-#: ../lib/gmath/la.c:64 ../lib/gmath/la.c:120
-msgid "Matrix dimensions out of range"
-msgstr ""
-#: ../lib/gmath/la.c:153
-msgid "Matrix is not initialised fully."
-msgstr ""
-#: ../lib/gmath/la.c:158
-msgid "Unable to allocate space for matrix copy"
-msgstr ""
-#: ../lib/gmath/la.c:247
-msgid "First scalar multiplier must be non-zero"
-msgstr ""
-#: ../lib/gmath/la.c:253 ../lib/gmath/la.c:261 ../lib/gmath/la.c:326
-msgid "One or both input matrices uninitialised"
-msgstr ""
-#: ../lib/gmath/la.c:266 ../lib/gmath/la.c:331
-msgid "Matrix order does not match"
-msgstr ""
-#: ../lib/gmath/la.c:272
-msgid "Unable to allocate space for matrix sum"
-msgstr ""
-#: ../lib/gmath/la.c:336
-msgid "Unable to allocate space for matrix product"
-msgstr ""
-#: ../lib/gmath/la.c:448
-msgid "Input: one or both data matrices uninitialised"
-msgstr ""
-#: ../lib/gmath/la.c:453
-msgid "Principal matrix is not properly dimensioned"
-msgstr ""
-#: ../lib/gmath/la.c:458
-msgid "Input: you must have at least one array to solve"
-msgstr ""
-#: ../lib/gmath/la.c:464
-msgid "Could not allocate space for solution matrix"
-msgstr ""
-#: ../lib/gmath/la.c:470 ../lib/gmath/la.c:478
-msgid "Could not allocate space for working matrix"
-msgstr ""
-#: ../lib/gmath/la.c:531
-msgid "Matrix (or submatrix is singular). Solution undetermined"
-msgstr ""
-#: ../lib/gmath/la.c:535
-msgid "Problem in LA routine."
-msgstr ""
-#: ../lib/gmath/la.c:542
-msgid "Procedure not yet available for selected matrix type"
-msgstr ""
-#: ../lib/gmath/la.c:576
-msgid "Matrix is not square. Cannot determine inverse"
-msgstr ""
-#: ../lib/gmath/la.c:581
-msgid "Unable to allocate space for matrix"
-msgstr ""
-#: ../lib/gmath/la.c:598
-msgid "Matrix is singular"
-msgstr ""
-#: ../lib/gmath/la.c:603
-msgid "Problem in LA procedure."
-msgstr ""
-#: ../lib/gmath/la.c:691
-msgid "Element array has not been allocated"
-msgstr ""
-#: ../lib/gmath/la.c:696
-msgid "Specified element is outside array bounds"
-msgstr ""
-#: ../lib/gmath/la.c:750
-msgid "Specified matrix column index is outside range"
-msgstr ""
-#: ../lib/gmath/la.c:755 ../lib/gmath/la.c:796 ../lib/gmath/la.c:1109
-#: ../lib/gmath/la.c:1161 ../lib/gmath/la.c:1236
-msgid "Matrix is not initialised"
-msgstr ""
-#: ../lib/gmath/la.c:760 ../lib/gmath/la.c:801
-msgid "Could not allocate space for vector structure"
-msgstr ""
-#: ../lib/gmath/la.c:791
-msgid "Specified matrix row index is outside range"
-msgstr ""
-#: ../lib/gmath/la.c:831
-msgid "Specified row index is outside range"
-msgstr ""
-#: ../lib/gmath/la.c:836
-msgid "Specified column index is outside range"
-msgstr ""
-#: ../lib/gmath/la.c:856
-msgid "Unknown vector type."
-msgstr ""
-#: ../lib/gmath/la.c:981
-msgid "Output vector is uninitialized"
-msgstr ""
-#: ../lib/gmath/la.c:986
-msgid "Vectors are not of the same type"
-msgstr ""
-#: ../lib/gmath/la.c:991
-msgid "Output vector is of incorrect type"
-msgstr ""
-#: ../lib/gmath/la.c:996
-msgid "Matrices not allowed"
-msgstr ""
-#: ../lib/gmath/la.c:1002
-msgid "Vectors have differing dimensions"
-msgstr ""
-#: ../lib/gmath/la.c:1008
-msgid "Output vector has incorrect dimension"
-msgstr ""
-#: ../lib/gmath/la.c:1054
-msgid "Vector dimensions out of range"
-msgstr ""
-#: ../lib/gmath/la.c:1059
-msgid "Row/column out of range"
-msgstr ""
-#: ../lib/gmath/la.c:1274
-msgid "Vector structure is not initialised"
-msgstr ""
-#: ../lib/gmath/la.c:1395 ../lib/gmath/la.c:1403 ../lib/gmath/la.c:1408
-msgid "Input format error"
-msgstr ""
-#: ../lib/gmath/solvers_direct_cholesky_band.c:33
-#, c-format
-msgid "Decomposition failed at row %i and col %i"
-msgstr ""
-#: ../lib/gmath/solvers_classic_iter.c:84
-#, c-format
-msgid "sparse Jacobi -- iteration %5i error %g\n"
-msgstr ""
-#: ../lib/gmath/solvers_classic_iter.c:156
-#, c-format
-msgid "sparse SOR -- iteration %5i error %g\n"
-msgstr ""
-#: ../lib/gmath/solvers_classic_iter.c:218
-#, c-format
-msgid "Jacobi -- iteration %5i error %g\n"
-msgstr ""
-#: ../lib/gmath/solvers_classic_iter.c:275
-#, c-format
-msgid "SOR -- iteration %5i error %g\n"
-msgstr ""
-#: ../lib/gmath/del2g.c:50
-msgid "    taking FFT of image..."
-msgstr ""
-#: ../lib/gmath/del2g.c:56
-msgid "    computing del**2 g..."
-msgstr ""
-#: ../lib/gmath/del2g.c:59
-msgid "    taking FFT of del**2 g..."
-msgstr ""
-#: ../lib/gmath/del2g.c:63
-msgid "    multiplying transforms..."
-msgstr ""
-#: ../lib/gmath/del2g.c:66
-msgid "    taking inverse FFT..."
-msgstr ""
-#: ../lib/gmath/test/bench_blas2.c:35
-msgid ""
-"\n"
-"++ Running blas level 2 benchmark ++"
-msgstr ""
-#: ../lib/gmath/test/bench_blas3.c:34
-msgid ""
-"\n"
-"++ Running blas level 3 benchmark ++"
-msgstr ""
-#: ../lib/gmath/test/test_solvers.c:37
-msgid ""
-"\n"
-"++ Running solver unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_solvers.c:42
-msgid ""
-"\n"
-"-- Solver unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_solvers.c:44
-msgid ""
-"\n"
-"-- Solver unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/test_matrix_conversion.c:37
-msgid ""
-"\n"
-"++ Running matrix conversion unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_matrix_conversion.c:42
-msgid ""
-"\n"
-"-- Matrix conversion unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_matrix_conversion.c:44
-msgid ""
-"\n"
-"-- Matrix conversion unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/bench_solver_direct.c:34
-msgid ""
-"\n"
-"++ Running direct solver benchmark ++"
-msgstr ""
-#: ../lib/gmath/test/test_blas1.c:40
-msgid ""
-"\n"
-"++ Running blas level 1 unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_blas1.c:47
-msgid ""
-"\n"
-"-- blas level 1 unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_blas1.c:49
-msgid ""
-"\n"
-"-- blas level 1 unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:61
-msgid "The size of the matrices and vectors for benchmarking"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:68
-msgid "Choose solver benchmark"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:75
-msgid "Choose blas benchmark"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:106
-msgid "Performs benchmarks, unit and integration tests for the gmath library"
-msgstr ""
-#: ../lib/gmath/test/test_ccmath_wrapper.c:37
-msgid ""
-"\n"
-"++ Running ccmath wrapper unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_ccmath_wrapper.c:42
-msgid ""
-"\n"
-"-- ccmath wrapper unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_ccmath_wrapper.c:44
-msgid ""
-"\n"
-"-- ccmath wrapper unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/bench_solver_krylov.c:34
-msgid ""
-"\n"
-"++ Running krylov solver benchmark ++"
-msgstr ""
-#: ../lib/gmath/test/test_blas3.c:38
-msgid ""
-"\n"
-"++ Running blas level 3 unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_blas3.c:44
-msgid ""
-"\n"
-"-- blas level 3 unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_blas3.c:46
-msgid ""
-"\n"
-"-- blas level 3 unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/test_blas2.c:38
-msgid ""
-"\n"
-"++ Running blas level 2 unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_blas2.c:44
-msgid ""
-"\n"
-"-- blas level 2 unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_blas2.c:46
-msgid ""
-"\n"
-"-- blas level 2 unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/solvers_direct.c:45
-msgid "Starting direct gauss elimination solver"
-msgstr ""
-#: ../lib/gmath/solvers_direct.c:73
-msgid "Starting direct lu decomposition solver"
-msgstr ""
-#: ../lib/gmath/solvers_direct.c:131
-msgid "Starting cholesky decomposition solver"
-msgstr ""
-#: ../lib/gmath/solvers_direct.c:134 ../lib/gmath/solvers_krylov.c:254
-#: ../lib/gmath/solvers_krylov.c:482 ../lib/gmath/solvers_krylov.c:646
-msgid "Unable to solve the linear equation system"
-msgstr ""
-#: ../lib/gmath/solvers_krylov.c:262
-#, c-format
-msgid "Sparse PCG -- iteration %i error  %g\n"
-msgstr ""
-#: ../lib/gmath/solvers_krylov.c:264
-#, c-format
-msgid "PCG -- iteration %i error  %g\n"
-msgstr ""
-#: ../lib/gmath/solvers_krylov.c:490
-#, c-format
-msgid "Sparse CG -- iteration %i error  %g\n"
-msgstr ""
-#: ../lib/gmath/solvers_krylov.c:492
-#, c-format
-msgid "CG -- iteration %i error  %g\n"
-msgstr ""
-#: ../lib/gmath/solvers_krylov.c:695
-#, c-format
-msgid "Sparse BiCGStab -- iteration %i error  %g\n"
-msgstr ""
-#: ../lib/gmath/solvers_krylov.c:698
-#, c-format
-msgid "BiCGStab -- iteration %i error  %g\n"
-msgstr ""
-#: ../lib/lidar/zones.c:473 ../lib/lidar/zones.c:510
-#, fuzzy, c-format
-msgid "<%s> created in database."
-#: ../lib/lidar/zones.c:477 ../lib/lidar/zones.c:514
-#, c-format
-msgid "<%s> has not been created in database."
-msgstr ""
-#: ../lib/lidar/raster.c:74 ../lib/lidar/raster.c:89 ../lib/lidar/raster.c:102
-#: ../lib/lidar/raster.c:119 ../lib/lidar/raster.c:134
-#: ../lib/lidar/raster.c:147 ../lib/lidar/raster.c:162
-#: ../lib/lidar/raster.c:175
-#, fuzzy, c-format
-msgid "Unable to access table <%s>"
-#: ../lib/segment/format.c:144
-msgid "Segment format: file size too large"
-msgstr ""
-#: ../lib/segment/format.c:145
-msgid "Please recompile with Large File Support (LFS)"
-msgstr ""
-#: ../lib/temporal/lib/default_name.c:74
-#: ../lib/db/dbmi_base/default_name.c:127
-msgid "Programmer error"
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:38
-msgid "database"
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:39
-msgid "attribute table"
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:40
-msgid "connection settings"
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:42
-msgid "Prints/sets general TGIS DB connection for current mapset."
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:46
-msgid "Print current connection parameters and exit"
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:47
-msgid "Print"
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:52
-msgid "Check connection parameters, set if uninitialized, and exit"
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:53 ../lib/temporal/t.connect/main.c:59
-#: ../lib/temporal/t.connect/main.c:64 ../lib/temporal/t.connect/main.c:69
-#: ../lib/temporal/t.connect/main.c:73
-msgid "Set"
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:57
-msgid "Set from default settings and exit"
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:58
-msgid "Overwrite current settings if initialized"
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:63
-msgid "Print current connection parameter in shell style and exit"
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:87 ../lib/temporal/t.connect/main.c:99
-msgid "Temporal GIS database connection not defined. Run t.connect."
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:115
-#, c-format
-msgid ""
-"Default TGIS driver / database set to:\n"
-"driver: %s\n"
-"database: %s"
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:122
-msgid "Default TGIS driver is not set"
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:125
-msgid "Default TGIS database is not set"
-msgstr ""
-#: ../lib/temporal/t.connect/main.c:137 ../lib/vector/Vlib/field.c:340
-#, c-format
-msgid ""
-"Default driver / database set to:\n"
-"driver: %s\n"
-"database: %s"
-msgstr ""
-#: ../lib/display/r_raster.c:115
-#, c-format
-msgid "%s variable defined, %s ignored"
-msgstr ""
-#: ../lib/display/r_raster.c:150
-#, fuzzy, c-format
-msgid "Unknown display driver <%s>"
-msgstr "%s उघडता आले नाही"
-#: ../lib/display/r_raster.c:151
-#, fuzzy, c-format
-msgid "Using display driver <%s>..."
-#: ../lib/display/r_raster.c:217
-#, fuzzy, c-format
-msgid "Unable to open file '%s'"
-#: ../lib/display/tran_colr.c:107 ../lib/display/tran_colr.c:109
-#, c-format
-msgid "[%s]: No such color"
-msgstr ""
-#: ../lib/cairodriver/Raster.c:68
-msgid "Cairo_begin_raster: Failed to create surface"
-msgstr ""
-#: ../lib/cairodriver/read_xid.c:14 ../lib/gis/key_value3.c:61
-#, fuzzy, c-format
-msgid "Unable to open input file <%s>"
-#: ../lib/cairodriver/read_xid.c:17
-#, fuzzy, c-format
-msgid "Unable to read input file <%s>"
-#: ../lib/cairodriver/read_xid.c:20
-#, fuzzy, c-format
-msgid "Unable to parse input file <%s>"
-#: ../lib/cairodriver/write_ppm.c:27 ../lib/cairodriver/write_bmp.c:72
-#, fuzzy, c-format
-msgid "Cairo: unable to open output file <%s>"
-#: ../lib/cairodriver/write_ppm.c:34
-#, fuzzy, c-format
-msgid "Cairo: unable to open mask file <%s>"
-#: ../lib/cairodriver/write_xid.c:14 ../lib/gis/key_value3.c:34
-#, fuzzy, c-format
-msgid "Unable to open output file <%s>"
-#: ../lib/cairodriver/write_xid.c:19
-#, fuzzy, c-format
-msgid "Unable to write output file <%s>"
-#: ../lib/cairodriver/read_bmp.c:88 ../lib/cairodriver/read_ppm.c:28
-#, fuzzy, c-format
-msgid "Cairo: unable to open input file <%s>"
-#: ../lib/cairodriver/read_bmp.c:92 ../lib/cairodriver/read_ppm.c:32
-#, c-format
-msgid "Cairo: invalid input file <%s>"
-msgstr ""
-#: ../lib/cairodriver/read_bmp.c:96
-#, c-format
-msgid "Cairo: Invalid BMP header for <%s>"
-msgstr ""
-#: ../lib/cairodriver/Graph.c:67
-#, fuzzy
-msgid "Unable to open display"
-#: ../lib/cairodriver/Graph.c:82
-#, fuzzy
-msgid "Unable to obtain visual"
-#: ../lib/cairodriver/Graph.c:156
-#, c-format
-msgid "Unknown file extension: %s"
-msgstr ""
-#: ../lib/cairodriver/Graph.c:184
-#, fuzzy, c-format
-msgid "cairo: collecting to file '%s'"
-#: ../lib/cairodriver/Graph.c:186
-#, c-format
-msgid "cairo: image size %dx%d"
-msgstr ""
-#: ../lib/cairodriver/Graph.c:353
-msgid "Unknown Cairo surface type"
-msgstr ""
-#: ../lib/cairodriver/Graph.c:358
-#, fuzzy
-msgid "Failed to initialize Cairo surface"
-#: ../lib/cairodriver/Text.c:46
-#, fuzzy, c-format
-msgid "Unable to convert from <%s> to UTF-8"
-#: ../lib/cairodriver/Text.c:56
-msgid "Some characters could not be converted to UTF-8"
-msgstr ""
-#: ../lib/cairodriver/read_ppm.c:38
-#, c-format
-msgid "Cairo: input file has incorrect dimensions: expected: %dx%d got: %dx%d"
-msgstr ""
-#: ../lib/cairodriver/read_ppm.c:46
-#, fuzzy, c-format
-msgid "Cairo: unable to open input mask file <%s>"
-#: ../lib/cairodriver/read_ppm.c:50
-#, c-format
-msgid "Cairo: invalid input mask file <%s>"
-msgstr ""
-#: ../lib/cairodriver/read_ppm.c:56
-#, c-format
-msgid "Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
-msgstr ""
-#: ../lib/cairodriver/Draw_bitmap.c:47
-msgid "Cairo_Bitmap: Failed to create source"
-msgstr ""
-#: ../lib/driver/parse_ftcap.c:84
-#, c-format
-msgid "%s: Unable to read font definition file; use the default"
-msgstr ""
-#: ../lib/driver/parse_ftcap.c:90
-#, c-format
-msgid "%s: No font definition file"
-msgstr ""
-#: ../lib/python/raster.py:46
-msgid "Unable to write history for <%(map)s>. Raster map <%(map)s> not found in current mapset."
-#: ../lib/python/raster.py:101
-msgid "An error occurred while running r.mapcalc"
-msgstr ""
-#: ../lib/python/core.py:727
-#, python-format
-msgid "Invalid element '%s'"
-msgstr ""
-#: ../lib/python/core.py:897
-#, fuzzy
-msgid "Unable to list mapsets"
-#: ../lib/python/temporal/core.py:42
-msgid "Unable to initialize the temporal DBMI interface. Use t.connect to specify the driver and the database string"
-msgstr ""
-#: ../lib/python/temporal/core.py:60 ../lib/python/temporal/core.py:66
-msgid "Unable to initialize the temporal GIS DBMI interface. Use t.connect to specify the driver and the database string"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets_tools.py:57
-#: ../lib/python/temporal/space_time_datasets_tools.py:60
-#: ../lib/python/temporal/space_time_datasets_tools.py:253
-#: ../lib/python/temporal/space_time_datasets_tools.py:403
-#: ../lib/python/temporal/space_time_datasets_tools.py:406
-#, python-format
-msgid "%s= and %s= are mutually exclusive"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets_tools.py:63
-#: ../lib/python/temporal/space_time_datasets_tools.py:409
-#, python-format
-msgid "Please specify %s= and %s="
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets_tools.py:66
-#: ../lib/python/temporal/space_time_datasets_tools.py:412
-#, python-format
-msgid "Please specify %s= or %s="
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets_tools.py:102
-msgid "Space time %s dataset <%s> no found"
-msgstr "%s मिळाले नाही"
-#: ../lib/python/temporal/space_time_datasets_tools.py:124
-#: ../lib/python/temporal/space_time_datasets_tools.py:305
-#: ../lib/python/temporal/space_time_datasets_tools.py:455
-#, python-format
-msgid "Number of %s= and %s= must be equal"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets_tools.py:194
-#, python-format
-msgid "Unable to register %s map <%s> with layer %s. The map has no valid time and the start time is not set."
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets_tools.py:197
-#, python-format
-msgid "Unable to register %s map <%s>. The map has no valid time and the start time is not set."
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets_tools.py:214
-#, python-format
-msgid "Unable to register %s map <%s> with layer. The temporal types are different."
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets_tools.py:216
-msgid "Unable to register %s map <%s>. The temporal types are different."
-#: ../lib/python/temporal/space_time_datasets_tools.py:397
-msgid "Valid end time and increment are mutual exclusive"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets_tools.py:585
-#: ../lib/python/temporal/space_time_datasets_tools.py:592
-#, python-format
-msgid "Unable to convert string \"%s\"into a datetime object"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets_tools.py:600
-msgid "Set absolute valid time for map <%s> with layer %s to %s - %s"
-#: ../lib/python/temporal/space_time_datasets_tools.py:602
-#, python-format
-msgid "Set absolute valid time for map <%s> to %s - %s"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets_tools.py:618
-msgid "Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
-#: ../lib/python/temporal/space_time_datasets_tools.py:620
-msgid "Set relative valid time for map <%s> to %i - %s with unit %s"
-#: ../lib/python/temporal/space_time_datasets_tools.py:648
-msgid "Unknown dataset type: %s"
-#: ../lib/python/temporal/space_time_datasets_tools.py:682
-#: ../lib/python/temporal/space_time_datasets_tools.py:839
-#: ../lib/python/temporal/space_time_datasets_tools.py:842
-msgid "Dataset <%s> not found in temporal database"
-#: ../lib/python/temporal/aggregation.py:99
-msgid "Aggregate %s raster maps"
-#: ../lib/python/temporal/aggregation.py:113
-msgid "Raster map <%s> is already in temporal database, use overwrite flag to overwrite"
-#: ../lib/python/temporal/aggregation.py:116
-#, python-format
-msgid "Compute aggregation of maps between %s - %s"
-msgstr ""
-#: ../lib/python/temporal/aggregation.py:132
-msgid "Error while r.series computation"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:167
-#, python-format
-msgid "Start time must be of type datetime for %s map <%s> with layer: %s"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:169
-msgid "Start time must be of type datetime for %s map <%s>"
-msgstr "temp फाइल उघडता आली नाही"
-#: ../lib/python/temporal/abstract_map_dataset.py:173
-#, python-format
-msgid "End time must be of type datetime for %s map <%s> with layer: %s"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:175
-msgid "End time must be of type datetime for %s map <%s>"
-#: ../lib/python/temporal/abstract_map_dataset.py:180
-#, python-format
-msgid "End time must be greater than start time for %s map <%s> with layer: %s"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:182
-#: ../lib/python/temporal/abstract_map_dataset.py:255
-msgid "End time must be greater than start time for %s map <%s>"
-#: ../lib/python/temporal/abstract_map_dataset.py:244
-msgid "Unsupported relative time unit type for %s map <%s> with layer %s: %s"
-#: ../lib/python/temporal/abstract_map_dataset.py:246
-msgid "Unsupported relative time unit type for %s map <%s>: %s"
-#: ../lib/python/temporal/abstract_map_dataset.py:253
-#, python-format
-msgid "End time must be greater than start time for %s map <%s> with layer %s"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:333
-#, python-format
-msgid "Map <%s> with layer %s has incorrect time interval, start time is greater than end time"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:335
-#, python-format
-msgid "Map <%s> has incorrect time interval, start time is greater than end time"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:338
-#, python-format
-msgid "Map <%s> has incorrect start time"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:375
-msgid "Unable to remove space time dataset register table <%s>"
-#: ../lib/python/temporal/abstract_map_dataset.py:377
-#, python-format
-msgid "Delete %s dataset <%s> from temporal database"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:406
-msgid "Unregister %s map <%s> with layer %s from space time datasets"
-#: ../lib/python/temporal/abstract_map_dataset.py:409
-msgid "Unregister %s map <%s> from space time datasets"
-#: ../lib/python/temporal/abstract_map_dataset.py:467
-msgid "Unable to select space time dataset register table <%s>"
-#: ../lib/python/temporal/base.py:308
-msgid "Object <%s> not found in the temporal database"
-#: ../lib/python/temporal/spatial_extent.py:38
-msgid "Projections are different. Unable to compute overlap_2d for spatial extents"
-msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:161
-msgid "Volume computation is not supported for LL projections"
-msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:178
-msgid "Area computation is not supported for LL projections"
-msgstr ""
-#: ../lib/python/temporal/datetime_math.py:96
-#, python-format
-msgid "Wrong increment format: %s"
-msgstr ""
-#: ../lib/python/temporal/datetime_math.py:191
-#, python-format
-msgid "Wrong granularity format: %s"
-msgstr ""
-#: ../lib/python/temporal/datetime_math.py:227
-#, python-format
-msgid "Adjust datetime from %s to %s with granularity %s"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:127
-#: ../lib/python/temporal/abstract_space_time_dataset.py:170
-msgid "Unknown temporal type \"%s\""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:182
-msgid "Unsupported temporal unit: %s"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:496
-msgid "The space time datasets must be of the same temporal type"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:500
-msgid "The temporal map type of the sample dataset must be interval"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:611
-msgid "More than one map found in a granule. Temporal granularity seems to be invalid or the chosen granularity is not a greatest common divider of all intervals and gaps in the dataset."
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:776
-msgid "Unable to get map ids from register table <%s>"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:794
-#, python-format
-msgid "Delete space time %s  dataset <%s> from temporal database"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:806
-msgid "Drop map register table: %s"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:828
-msgid "Unable to drop table <%s>"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:858
-msgid "Only maps with absolute or relative valid time can be registered"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:860
-msgid "Register %s map <%s> with layer %s in space time %s dataset <%s>"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:862
-msgid "Register %s map <%s> in space time %s dataset <%s>"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:869
-#, python-format
-msgid "Map <%s> with layer %s has invalid time"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:871
-#, python-format
-msgid "Map <%s> has invalid time"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:891
-#, python-format
-msgid "Temporal type of space time dataset <%s> and map <%s> with layer %s are different"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:893
-#, python-format
-msgid "Temporal type of space time dataset <%s> and map <%s> are different"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:899
-msgid "Set temporal unit for space time %s dataset <%s> to %s"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:906
-#, python-format
-msgid "Relative time units of space time dataset <%s> and map <%s> with layer %s are different"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:908
-#, python-format
-msgid "Relative time units of space time dataset <%s> and map <%s> are different"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:914
-msgid "Only maps from the same mapset can be registered"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:930
-#, python-format
-msgid "Map <%s> with layer %s is already registered."
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:932
-#, python-format
-msgid "Map <%s> is already registered."
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:962
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1007
-msgid "Unable to create the space time %s dataset register table for map <%s> with layer %s"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:965
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1010
-msgid "Unable to create the space time %s dataset register table for <%s>"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:974
-msgid "Created register table <%s> for %s map <%s> with layer %s"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:977
-msgid "Created register table <%s> for %s map <%s>"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1018
-#, python-format
-msgid "Created register table <%s> for space time %s  dataset <%s>"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1075
-msgid "Unable to find map <%s> with layer %s in temporal database"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1077
-msgid "Unable to find map <%s> in temporal database"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1080
-msgid "Unregister %s map <%s> with layer %s"
-msgstr "%s@%s हा रास्टर नकाशा रिक्त आहे"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1082
-msgid "Unregister %s map <%s>"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1101
-msgid "Map <%s> with layer %s is not registered in space time dataset <%s>"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1103
-msgid "Map <%s> is not registered in space time dataset <%s>"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1146
-#, python-format
-msgid "Update metadata, spatial and temporal extent from all registered maps of <%s>"
-msgstr ""
-#: ../lib/python/raster3d.py:86
-msgid "An error occurred while running r3.mapcalc"
-msgstr ""
-#: ../lib/python/task.py:52
-#, fuzzy
-msgid "unknown"
-msgstr "अज्ञात"
-#: ../lib/python/task.py:155
-#, python-format
-msgid "Parameter element '%(element)s' not found: '%(value)s'"
-msgstr ""
-#: ../lib/python/task.py:170
-msgid "Flag not found: %s"
-#: ../lib/python/task.py:189
-#, python-format
-msgid "Parameter '%(name)s' (%(desc)s) is missing."
-msgstr ""
-#: ../lib/python/task.py:220
-msgid "<required>"
-msgstr ""
-#: ../lib/python/task.py:445
-#, python-format
-msgid ""
-"Unable to fetch interface description for command '%(cmd)s'.\n"
-"\n"
-"Details: %(det)s"
-msgstr ""
-#: ../lib/python/db.py:48 ../lib/db/dbmi_client/column.c:136
-#, fuzzy, c-format, python-format
-msgid "Unable to describe table <%s>"
-#: ../lib/python/db.py:122
-msgid "Fetching data from table <%s> failed"
-#: ../lib/python/vector.py:87
-#, python-format
-msgid "Database connection not defined for layer %s"
-msgstr ""
-#: ../lib/python/vector.py:233
-msgid "Missing layer %(layer)d in vector map <%(map)s>"
-#: ../lib/python/vector.py:249
-msgid "vector_select() failed"
-msgstr ""
-#: ../lib/pngdriver/Graph_set.c:84
-#, c-format
-msgid "png: truecolor status %s"
-msgstr ""
-#: ../lib/pngdriver/Graph_set.c:85 ../lib/psdriver/Graph_set.c:200
-msgid "enabled"
-msgstr ""
-msgid "disabled"
-msgstr ""
-#: ../lib/pngdriver/Graph_set.c:132
-#, c-format
-msgid "png: collecting to file '%s'"
-msgstr ""
-#: ../lib/pngdriver/Graph_set.c:133
-#, c-format
-msgid "png: image size %dx%d"
-msgstr ""
-#: ../lib/manage/read_list.c:73
-#, fuzzy, c-format
-msgid "Unable to open data base element list '%s'"
-#: ../lib/manage/read_list.c:134
-#, c-format
-msgid "Format error: file ('%s') line (%d) - %s"
-msgstr ""
-#: ../lib/manage/do_remove.c:42
-#, fuzzy, c-format
-msgid "Removing %s <%s>"
-#: ../lib/manage/do_remove.c:65
-#, fuzzy
-msgid "Unable to delete vector map"
-#: ../lib/manage/do_remove.c:85
-#, fuzzy, c-format
-msgid "Unable to remove %s element"
-#: ../lib/manage/do_remove.c:89 ../lib/manage/do_remove.c:109
-#: ../lib/manage/do_copy.c:63 ../lib/manage/do_rename.c:87
-#: ../lib/manage/do_rename.c:107
-#, c-format
-msgid "%s is missing"
-msgstr ""
-#: ../lib/manage/do_remove.c:92 ../lib/manage/do_remove.c:112
-#, c-format
-msgid "%s removed"
-msgstr ""
-#: ../lib/manage/do_remove.c:105
-#, fuzzy, c-format
-msgid "Unable to remove %s"
-#: ../lib/manage/do_remove.c:121
-#, c-format
-msgid "<%s> nothing removed"
-msgstr ""
-#: ../lib/manage/do_copy.c:43
-#, fuzzy, c-format
-msgid "Copy %s <%s> to current mapset as <%s>"
-#: ../lib/manage/do_copy.c:52
-#, fuzzy, c-format
-msgid "Unable to copy <%s> to current mapset as <%s>"
-#: ../lib/manage/do_copy.c:72
-#, c-format
-msgid "%s copied"
-msgstr ""
-#: ../lib/manage/option.c:47
-#, c-format
-msgid "%s to be %s"
-msgstr ""
-#: ../lib/manage/option.c:51
-msgid "Raster"
-msgstr ""
-#: ../lib/manage/option.c:55
-msgid "Vector"
-msgstr ""
-#: ../lib/manage/option.c:57
-msgid "Region"
-msgstr ""
-#: ../lib/manage/option.c:59
-msgid "Group"
-msgstr ""
-#: ../lib/manage/do_rename.c:42
-#, fuzzy, c-format
-msgid "Rename %s <%s> to <%s>"
-#: ../lib/manage/do_rename.c:62
-#, fuzzy, c-format
-msgid "Unable to rename vector map <%s> to <%s>"
-#: ../lib/manage/do_rename.c:83 ../lib/manage/do_rename.c:103
-#, fuzzy, c-format
-msgid "Unable to rename %s"
-#: ../lib/manage/do_rename.c:90 ../lib/manage/do_rename.c:110
-#, c-format
-msgid "%s renamed"
-msgstr ""
-#: ../lib/manage/do_rename.c:119
-#, c-format
-msgid "<%s> nothing renamed"
-msgstr ""
-#: ../lib/gpde/N_parse_options.c:106
-msgid "The calculation time in seconds"
-msgstr ""
-#: ../lib/gpde/test/test_assemble.c:42
-msgid ""
-"\n"
-"++ Running assembling unit tests ++"
-msgstr ""
-#: ../lib/gpde/test/test_assemble.c:44
-msgid "\t 1. testing 2d assembling"
-msgstr ""
-#: ../lib/gpde/test/test_assemble.c:47
-msgid "\t 2. testing 3d assembling"
-msgstr ""
-#: ../lib/gpde/test/test_assemble.c:51
-msgid ""
-"\n"
-"-- Assembling unit tests failure --"
-msgstr ""
-#: ../lib/gpde/test/test_assemble.c:53
-msgid ""
-"\n"
-"-- Assembling unit tests finished successfully --"
-msgstr ""
-#: ../lib/gpde/test/test_les.c:35
-msgid ""
-"\n"
-"++ Running les creation unit tests ++"
-msgstr ""
-#: ../lib/gpde/test/test_les.c:40
-msgid ""
-"\n"
-"-- les creation unit tests failure --"
-msgstr ""
-#: ../lib/gpde/test/test_les.c:42
-msgid ""
-"\n"
-"-- les creation unit tests finished successfully --"
-msgstr ""
-#: ../lib/gpde/test/test_les.c:96
-msgid "\t * testing les creation in parallel\n"
-msgstr ""
-#: ../lib/gpde/test/test_les.c:127
-msgid "\t * testing les creation in serial\n"
-msgstr ""
-#: ../lib/gpde/test/test_arrays.c:48
-msgid ""
-"\n"
-"++ Running array unit tests ++"
-msgstr ""
-#: ../lib/gpde/test/test_arrays.c:50
-msgid "\t 1. testing 2d arrays"
-msgstr ""
-#: ../lib/gpde/test/test_arrays.c:53
-msgid "\t 2. testing 3d arrays"
-msgstr ""
-#: ../lib/gpde/test/test_arrays.c:57
-msgid ""
-"\n"
-"-- Array unit tests failure --"
-msgstr ""
-#: ../lib/gpde/test/test_arrays.c:59
-msgid ""
-"\n"
-"-- Array unit tests finished successfully --"
-msgstr ""
-#: ../lib/gpde/test/test_geom.c:36
-msgid ""
-"\n"
-"++ Running geom_data unit tests ++"
-msgstr ""
-#: ../lib/gpde/test/test_geom.c:41
-msgid ""
-"\n"
-"-- geom_data unit tests failure --"
-msgstr ""
-#: ../lib/gpde/test/test_geom.c:43
-msgid ""
-"\n"
-"-- geom_data unit tests finished successfully --"
-msgstr ""
-#: ../lib/gpde/test/test_gwflow.c:47
-msgid ""
-"\n"
-"++ Running gwflow integration tests ++"
-msgstr ""
-#: ../lib/gpde/test/test_gwflow.c:49
-msgid "\t 1. testing 2d gwflow"
-msgstr ""
-#: ../lib/gpde/test/test_gwflow.c:52
-msgid "\t 2. testing 3d gwflow"
-msgstr ""
-#: ../lib/gpde/test/test_gwflow.c:56
-msgid ""
-"\n"
-"-- gwflow integration tests failure --"
-msgstr ""
-#: ../lib/gpde/test/test_gwflow.c:58
-msgid ""
-"\n"
-"-- gwflow integration tests finished successfully --"
-msgstr ""
-#: ../lib/gpde/test/test_main.c:89
-msgid "Performs unit and integration tests for gpde library"
-msgstr ""
-#: ../lib/gpde/test/test_tools.c:34
-msgid ""
-"\n"
-"++ Running math tool unit tests ++"
-msgstr ""
-#: ../lib/gpde/test/test_tools.c:39
-msgid ""
-"\n"
-"-- math tool unit tests failure --"
-msgstr ""
-#: ../lib/gpde/test/test_tools.c:41
-msgid ""
-"\n"
-"-- math tool unit tests finished successfully --"
-msgstr ""
-#: ../lib/gpde/test/test_solute_transport.c:43
-msgid ""
-"\n"
-"++ Running solute_transport integration tests ++"
-msgstr ""
-#: ../lib/gpde/test/test_solute_transport.c:45
-msgid "\t 1. testing 2d solute_transport"
-msgstr ""
-#: ../lib/gpde/test/test_solute_transport.c:48
-msgid "\t 2. testing 3d solute_transport"
-msgstr ""
-#: ../lib/gpde/test/test_solute_transport.c:52
-msgid ""
-"\n"
-"-- solute_transport integration tests failure --"
-msgstr ""
-#: ../lib/gpde/test/test_solute_transport.c:55
-msgid ""
-"\n"
-"-- solute_transport integration tests finished successfully --"
-msgstr ""
-#: ../lib/gpde/test/test_gradient.c:42
-msgid ""
-"\n"
-"++ Running gradient unit tests ++"
-msgstr ""
-#: ../lib/gpde/test/test_gradient.c:44
-msgid "\t 1. testing 2d gradient"
-msgstr ""
-#: ../lib/gpde/test/test_gradient.c:47
-msgid "\t 2. testing 3d gradient"
-msgstr ""
-#: ../lib/gpde/test/test_gradient.c:51
-msgid ""
-"\n"
-"-- Gradient unit tests failure --"
-msgstr ""
-#: ../lib/gpde/test/test_gradient.c:53
-msgid ""
-"\n"
-"-- Gradient unit tests finished successfully --"
-msgstr ""
-#: ../lib/gpde/test/test_heat.c:33
-msgid ""
-"\n"
-"++ Running heat flow integration tests ++"
-msgstr ""
-#: ../lib/gpde/test/test_heat.c:35
-msgid "\t 1. testing 2d heat flow"
-msgstr ""
-#: ../lib/gpde/test/test_heat.c:37
-msgid "\t 2. testing 3d heat flow"
-msgstr ""
-#: ../lib/gpde/test/test_heat.c:40
-msgid ""
-"\n"
-"-- heat flow integration tests failure --"
-msgstr ""
-#: ../lib/gpde/test/test_heat.c:42
-msgid ""
-"\n"
-"-- heat flow integration tests finished successfully --"
-msgstr ""
-#: ../lib/gpde/N_arrays_io.c:93
-#, fuzzy, c-format
-msgid "Reading raster map <%s> into memory"
-#: ../lib/gpde/N_arrays_io.c:183
-msgid "N_array_2d * array is empty"
-msgstr ""
-#: ../lib/gpde/N_arrays_io.c:202
-#, c-format
-msgid "Write 2d array to raster map <%s>"
-msgstr ""
-#: ../lib/gpde/N_arrays_io.c:309
-#, c-format
-msgid "Read g3d map <%s> into the memory"
-msgstr ""
-#: ../lib/gpde/N_arrays_io.c:364 ../lib/gpde/N_arrays_io.c:464
-msgid "Error closing g3d file"
-msgstr ""
-#: ../lib/gpde/N_arrays_io.c:420
-#, c-format
-msgid "Error opening g3d map <%s>"
-msgstr ""
-#: ../lib/gpde/N_arrays_io.c:422
-#, c-format
-msgid "Write 3d array to g3d map <%s>"
-msgstr ""
-#: ../lib/gpde/N_gwflow.c:436 ../lib/gpde/N_gwflow.c:715
-#, c-format
-msgid "The total sum of the water budget: %g\n"
-msgstr ""
-#: ../lib/gpde/N_gwflow.c:438 ../lib/gpde/N_gwflow.c:717
-#, c-format
-msgid "The total sum of the water budget is significant larger then 0: %g\n"
-msgstr ""
-#: ../lib/arraystats/class.c:21
-msgid "Discont algorithm currently not available because of bugs"
-msgstr ""
-#: ../lib/arraystats/class.c:23
-#, c-format
-msgid "%s: Unknown algorithm"
-msgstr ""
-#: ../lib/arraystats/class.c:26
-#, c-format
-msgid "%s: Error in classification algorithm"
-msgstr ""
-#: ../lib/arraystats/class.c:221
-#, c-format
-msgid "There are classbreaks outside the range min-max. Number of classes reduced to %i, but using probabilities for %i classes."
-msgstr ""
-#: ../lib/vector/neta/utils.c:222 ../lib/vector/neta/utils.c:235
-#, c-format
-msgid "'%s' must be > 0 for '%s'"
-msgstr ""
-#: ../lib/vector/neta/utils.c:224
-msgid "'where' and 'cats' parameters were supplied, cat will be ignored"
-msgstr ""
-#: ../lib/vector/neta/utils.c:228
-#, fuzzy
-msgid "Unable to load data from database"
-#: ../lib/vector/neta/utils.c:239
-#, fuzzy
-msgid "Problem loading category values"
-#: ../lib/vector/neta/flow.c:309 ../lib/vector/Vlib/net.c:428
-#: ../lib/vector/Vlib/graph.c:105
-msgid "GngFlatten error"
-msgstr ""
-#: ../lib/vector/neta/timetables.c:46 ../lib/vector/neta/timetables.c:203
-#: ../lib/vector/neta/timetables.c:244 ../lib/vector/neta/timetables.c:286
-#, fuzzy, c-format
-msgid "Unable to open select cursor: %s"
-#: ../lib/vector/neta/allpairs.c:53
-msgid "Computing all pairs shortest paths..."
-msgstr ""
-#: ../lib/vector/neta/spanningtree.c:104
-msgid "Computing minimum spanning tree..."
-msgstr ""
-#: ../lib/vector/diglib/plus_node.c:217
-#, c-format
-msgid "Attempt to read line angle for the line which is not connected to the node: node %d, line %d"
-msgstr ""
-#: ../lib/vector/diglib/file.c:159
-msgid "Writing to file loaded to memory not supported"
-msgstr ""
-#: ../lib/vector/diglib/file.c:203
-#, fuzzy
-msgid "Unable to load file to memory, file not open"
-#: ../lib/vector/diglib/file.c:218
-msgid "Vector memory mode not supported, using 'AUTO'"
-msgstr ""
-#: ../lib/vector/diglib/spindex_rw.c:277
-#, c-format
-msgid "Spatial index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
-msgstr ""
-#: ../lib/vector/diglib/spindex_rw.c:284
-#, c-format
-msgid "Your GRASS version does not fully support spatial index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
-msgstr ""
-#: ../lib/vector/diglib/spindex_rw.c:293
-#, c-format
-msgid "Spatial index format version %d.%d is not supported by this release. Please rebuild topology."
-msgstr ""
-#: ../lib/vector/diglib/spindex_rw.c:824
-msgid "Writing sidx: wrong node position in file"
-msgstr ""
-#: ../lib/vector/diglib/plus.c:275
-#, fuzzy
-msgid "Unable read topology for nodes"
-#: ../lib/vector/diglib/plus.c:280
-#, fuzzy, c-format
-msgid "Unable to read topology for node %d"
-#: ../lib/vector/diglib/plus.c:285
-#, fuzzy
-msgid "Unable read topology for lines"
-#: ../lib/vector/diglib/plus.c:290
-#, fuzzy, c-format
-msgid "Unable to read topology for line %d"
-#: ../lib/vector/diglib/plus.c:295
-#, fuzzy
-msgid "Unable to read topo for areas"
-#: ../lib/vector/diglib/plus.c:300
-#, fuzzy, c-format
-msgid "Unable read topology for area %d"
-#: ../lib/vector/diglib/plus.c:305
-#, fuzzy
-msgid "Unable to read topology for isles"
-#: ../lib/vector/diglib/plus.c:310
-#, fuzzy, c-format
-msgid "Unable to read topology for isle %d"
-#: ../lib/vector/diglib/plus.c:332 ../lib/vector/diglib/plus.c:358
-#, fuzzy
-msgid "Unable to write head to plus file"
-#: ../lib/vector/diglib/plus.c:337
-#, fuzzy
-msgid "Unable to write nodes to plus file"
-#: ../lib/vector/diglib/plus.c:342
-#, fuzzy
-msgid "Unable to write lines to plus file"
-#: ../lib/vector/diglib/plus.c:347
-#, fuzzy
-msgid "Unable to write areas to plus file"
-#: ../lib/vector/diglib/plus.c:352
-#, fuzzy
-msgid "Unable to write isles to plus file"
-#: ../lib/vector/diglib/port_init.c:158
-#, fuzzy, c-format
-msgid "Unable to find '%x' in %s"
-#: ../lib/vector/diglib/spindex.c:381
-#, fuzzy, c-format
-msgid "Unable to delete node %d from spatial index"
-#: ../lib/vector/diglib/spindex.c:418
-#, fuzzy, c-format
-msgid "Unable to delete line %d from spatial index"
-#: ../lib/vector/diglib/spindex.c:447
-#, fuzzy
-msgid "Attempt to delete sidx for dead area"
-#: ../lib/vector/diglib/spindex.c:464
-#, fuzzy, c-format
-msgid "Unable to delete area %d from spatial index"
-#: ../lib/vector/diglib/spindex.c:506
-#, fuzzy, c-format
-msgid "Unable to delete isle %d from spatial index"
-#: ../lib/vector/diglib/spindex.c:679 ../lib/vector/diglib/spindex.c:747
-#: ../lib/vector/diglib/spindex.c:815
-msgid "No line id given"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:216 ../lib/vector/diglib/plus_area.c:694
-#, c-format
-msgid "Line %d already has area/isle %d to left"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:226 ../lib/vector/diglib/plus_area.c:702
-#, c-format
-msgid "Line %d already has area/isle %d to right"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:303
-msgid "Attempt to delete isle from dead area"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:320
-#, c-format
-msgid "Attempt to delete not registered isle %d from area %d"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:359
-msgid "Attempt to delete dead area"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:400
-#, c-format
-msgid "Dead centroid %d registered for area (bug in the vector library)"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:425
-#, fuzzy, c-format
-msgid "Attempt to delete area %d info from dead isle %d"
-#: ../lib/vector/diglib/plus_area.c:762
-#, fuzzy, c-format
-msgid "Attempt to delete isle %d info from dead area %d"
-#: ../lib/vector/diglib/portable.c:210 ../lib/vector/diglib/portable.c:243
-#: ../lib/vector/diglib/portable.c:690 ../lib/vector/diglib/plus_struct.c:560
-msgid "Vector exceeds supported file size limit"
-msgstr ""
-#: ../lib/vector/diglib/test.c:58
-#, fuzzy
-msgid "Unable to open test.tmp file"
-#: ../lib/vector/diglib/test.c:75
-#, c-format
-msgid "Error in read/write portable double, byte_order = %d Written: %.16e3E Read: %.16e3E"
-msgstr ""
-#: ../lib/vector/diglib/test.c:89
-#, c-format
-msgid "Error in read/write portable float, byte_order = %d Written: %.8e3E Read: %.8e3E"
-msgstr ""
-#: ../lib/vector/diglib/test.c:104
-#, c-format
-msgid "Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
-msgstr ""
-#: ../lib/vector/diglib/test.c:119
-#, c-format
-msgid "Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
-msgstr ""
-#: ../lib/vector/diglib/test.c:134
-#, c-format
-msgid "Error in read/write portable int, byte_order = %d Written: %d Read: %d"
-msgstr ""
-#: ../lib/vector/diglib/test.c:150
-#, c-format
-msgid "Error in read/write portable short, byte_order = %d Written: %d Read: %d"
-msgstr ""
-#: ../lib/vector/diglib/test.c:165
-#, c-format
-msgid "Error in read/write portable char, byte_order = %d Written: %d Read: %d"
-msgstr ""
-#: ../lib/vector/diglib/plus_struct.c:520
-#, c-format
-msgid "Topology format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
-msgstr ""
-#: ../lib/vector/diglib/plus_struct.c:526
-#, c-format
-msgid "Your GRASS version does not fully support topology format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
-msgstr ""
-#: ../lib/vector/diglib/plus_struct.c:536
-#, c-format
-msgid "Old topology format version %d.%d is not supported by this release. Try to rebuild topology."
-msgstr ""
-#: ../lib/vector/Vlib/write_nat.c:52 ../lib/vector/Vlib/write_nat.c:86
-#, c-format
-msgid "%s: Area %d does not exist"
-msgstr ""
-#: ../lib/vector/Vlib/write_nat.c:678 ../lib/vector/Vlib/write_ogr.c:490
-#, fuzzy
-msgid "Attempt to delete dead feature"
-#: ../lib/vector/Vlib/write_nat.c:789
-#, fuzzy, c-format
-msgid "Attempt to access dead area (%d)"
-#: ../lib/vector/Vlib/write_nat.c:929
-#, fuzzy
-msgid "Attempt to restore alive feature"
-#: ../lib/vector/Vlib/legal_vname.c:43
-#, c-format
-msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
-msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:50
-#, c-format
-msgid "Illegal vector map name <%s>. Must start with a letter."
-msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:58
-#, c-format
-msgid "Illegal vector map name <%s>. Character '%c' not allowed."
-msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:65
-#, c-format
-msgid "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
-msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:97 ../lib/vector/Vlib/legal_vname.c:101
-#, c-format
-msgid "Output vector map name <%s> is not valid map name"
-msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:144 ../lib/vector/Vlib/legal_vname.c:148
-#, c-format
-msgid "Output vector map <%s> is used as input"
-msgstr ""
-#: ../lib/vector/Vlib/merge_lines.c:246
-#, c-format
-msgid "%d boundaries merged"
-msgstr ""
-#: ../lib/vector/Vlib/merge_lines.c:247
-#, c-format
-msgid "%d new boundaries"
-msgstr ""
-#: ../lib/vector/Vlib/snap.c:133
-msgid "Snap vertices Pass 1: select points"
-msgstr ""
-#: ../lib/vector/Vlib/snap.c:187
-msgid "Snap vertices Pass 2: assign anchor vertices"
-msgstr ""
-#: ../lib/vector/Vlib/snap.c:256
-msgid "Snap vertices Pass 3: snap to assigned points"
-msgstr ""
-#: ../lib/vector/Vlib/snap.c:438
-#, c-format
-msgid "Snapped vertices: %d"
-msgstr ""
-#: ../lib/vector/Vlib/snap.c:439
-#, fuzzy, c-format
-msgid "New vertices: %d"
-#: ../lib/vector/Vlib/build.c:28 ../lib/vector/Vlib/close.c:34
-#: ../lib/vector/Vlib/rewind.c:32 ../lib/vector/Vlib/read.c:29
-#: ../lib/vector/Vlib/open.c:46 ../lib/vector/Vlib/write.c:50
-#: ../lib/vector/Vlib/write.c:56
-msgid "Requested format is not compiled in this version"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:120
-msgid "Unable to add area (map closed, topo saved)"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:129
-msgid "Unable to add isle (map closed, topo saved)"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:139
-msgid "Area of size = 0.0 ignored"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:176
-msgid "Request to find area outside nonexistent isle"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:510
-msgid "Checking for topological errors..."
-msgstr ""
-#: ../lib/vector/Vlib/build.c:544
-#, fuzzy, c-format
-msgid "Number of lines of length zero: %d"
-#: ../lib/vector/Vlib/build.c:546
-#, fuzzy, c-format
-msgid "Number of boundaries of length zero: %d"
-#: ../lib/vector/Vlib/build.c:555
-#, fuzzy, c-format
-msgid "Number of boundary intersections: %d"
-#: ../lib/vector/Vlib/build.c:579
-#, fuzzy
-msgid "Skipping further checks because of incorrect boundaries"
-#: ../lib/vector/Vlib/build.c:629
-#, fuzzy, c-format
-msgid "Number of redundant holes: %d"
-#: ../lib/vector/Vlib/build.c:707
-#, fuzzy, c-format
-msgid "Building topology for vector map <%s>..."
-#: ../lib/vector/Vlib/build.c:725
-msgid "Topology was built"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:737
-#, fuzzy, c-format
-msgid "Number of nodes: %d"
-#: ../lib/vector/Vlib/build.c:738
-#, fuzzy, c-format
-msgid "Number of primitives: %d"
-#: ../lib/vector/Vlib/build.c:739
-#, fuzzy, c-format
-msgid "Number of points: %d"
-#: ../lib/vector/Vlib/build.c:740
-#, fuzzy, c-format
-msgid "Number of lines: %d"
-#: ../lib/vector/Vlib/build.c:741
-#, fuzzy, c-format
-msgid "Number of boundaries: %d"
-#: ../lib/vector/Vlib/build.c:742
-#, fuzzy, c-format
-msgid "Number of centroids: %d"
-#: ../lib/vector/Vlib/build.c:745
-#, fuzzy, c-format
-msgid "Number of faces: %d"
-#: ../lib/vector/Vlib/build.c:748
-#, fuzzy, c-format
-msgid "Number of kernels: %d"
-#: ../lib/vector/Vlib/build.c:794
-#, fuzzy, c-format
-msgid "Number of areas: %d"
-#: ../lib/vector/Vlib/build.c:795
-#, fuzzy, c-format
-msgid "Number of isles: %d"
-#: ../lib/vector/Vlib/build.c:800
-#, fuzzy, c-format
-msgid "Number of areas without centroid: %d"
-#: ../lib/vector/Vlib/build.c:805
-#, fuzzy, c-format
-msgid "Number of centroids exceeds number of areas: %d > %d"
-#: ../lib/vector/Vlib/build.c:809
-#, fuzzy, c-format
-msgid "Number of incorrect boundaries: %d"
-#: ../lib/vector/Vlib/build.c:813
-#, fuzzy, c-format
-msgid "Number of centroids outside area: %d"
-#: ../lib/vector/Vlib/build.c:817
-#, fuzzy, c-format
-msgid "Number of duplicate centroids: %d"
-#: ../lib/vector/Vlib/build.c:821
-#, fuzzy
-msgid "Number of areas: -"
-#: ../lib/vector/Vlib/build.c:822
-#, fuzzy
-msgid "Number of isles: -"
-#: ../lib/vector/Vlib/build.c:852
-#, fuzzy, c-format
-msgid "Unable to open topo file for write <%s>"
-#: ../lib/vector/Vlib/build.c:860
-#, fuzzy
-msgid "Error writing out topo file"
-#: ../lib/vector/Vlib/build.c:1027
-#, fuzzy
-msgid "Unable to build spatial index from topology, vector map is not opened at topology level 2"
-#: ../lib/vector/Vlib/build.c:1050
-#, c-format
-msgid "%s is no longer supported"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:1087
-#, fuzzy, c-format
-msgid "Unable open spatial index file for write <%s>"
-#: ../lib/vector/Vlib/build.c:1096
-#, fuzzy
-msgid "Error writing out spatial index file"
-#: ../lib/vector/Vlib/overlay.c:70
-msgid "unknown operator"
-msgstr ""
-#: ../lib/vector/Vlib/overlay.c:120
-msgid "Overlay: line/boundary types not supported by AND operator"
-msgstr ""
-#: ../lib/vector/Vlib/overlay.c:123
-msgid "Overlay: area x area types not supported by AND operator"
-msgstr ""
-#: ../lib/vector/Vlib/level.c:34
-msgid "Map structure was never initialized"
-msgstr ""
-#: ../lib/vector/Vlib/level.c:36
-msgid "Map structure has been closed"
-msgstr ""
-#: ../lib/vector/Vlib/line.c:178 ../lib/vector/Vlib/line.c:211
-#: ../lib/vector/Vlib/line.c:244
-msgid "Index out of range in"
-msgstr ""
-#: ../lib/vector/Vlib/line.c:544
-msgid "Segment outside line, no segment created"
-msgstr ""
-#: ../lib/vector/Vlib/close.c:138
-#, fuzzy, c-format
-msgid "Unable to close vector <%s>"
-#: ../lib/vector/Vlib/read_nat.c:134 ../lib/vector/Vlib/geos.c:65
-#: ../lib/vector/Vlib/geos.c:255
-#, fuzzy
-msgid "Attempt to read dead line"
-#: ../lib/vector/Vlib/map.c:73
-#, fuzzy
-msgid "input vector map is not open"
-#: ../lib/vector/Vlib/map.c:160
-msgid "Topology not available. Polygons will be skipped."
-msgstr ""
-#: ../lib/vector/Vlib/map.c:267 ../lib/vector/Vlib/map.c:411
-#: ../lib/vector/Vlib/open.c:636
-#, fuzzy
-msgid "Vector map name is not SQL compliant"
-#: ../lib/vector/Vlib/map.c:271
-#, fuzzy, c-format
-msgid "Unable to find vector map <%s> in <%s>"
-#: ../lib/vector/Vlib/map.c:283 ../lib/vector/Vlib/map.c:415
-#: ../lib/vector/Vlib/open.c:672
-#, c-format
-msgid "Vector map <%s> already exists and will be overwritten"
-msgstr ""
-#: ../lib/vector/Vlib/map.c:287 ../lib/vector/Vlib/open.c:677
-#, fuzzy, c-format
-msgid "Unable to delete vector map <%s>"
-#: ../lib/vector/Vlib/map.c:307 ../lib/vector/Vlib/map.c:433
-#, fuzzy, c-format
-msgid "Unable to copy vector map <%s> to <%s>"
-#: ../lib/vector/Vlib/map.c:356 ../lib/vector/Vlib/map.c:482
-#: ../lib/vector/Vlib/map.c:720 ../lib/vector/Vlib/map.c:827
-#, fuzzy, c-format
-msgid "Unable to copy table <%s>"
-#: ../lib/vector/Vlib/map.c:372 ../lib/vector/Vlib/map.c:511
-#: ../lib/vector/Vlib/map.c:733
-#, c-format
-msgid "Unable to create index for table <%s>, key <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/map.c:496 ../lib/vector/Vlib/map.c:597
-#, fuzzy, c-format
-msgid "Unable to delete table <%s>"
-#: ../lib/vector/Vlib/map.c:551
-#, fuzzy, c-format
-msgid "Invalid vector map name <%s>"
-#: ../lib/vector/Vlib/map.c:565
-#, fuzzy, c-format
-msgid "Unable to open header file for vector map <%s>"
-#: ../lib/vector/Vlib/map.c:587
-#, fuzzy, c-format
-msgid "Unable to find table <%s> linked to vector map <%s>"
-#: ../lib/vector/Vlib/map.c:604
-#, fuzzy, c-format
-msgid "Table <%s> linked to vector map <%s> does not exist"
-#: ../lib/vector/Vlib/map.c:617
-#, fuzzy, c-format
-msgid "Unable to open directory '%s'"
-#: ../lib/vector/Vlib/map.c:631
-#, fuzzy, c-format
-msgid "Unable to delete file '%s'"
-#: ../lib/vector/Vlib/map.c:648
-#, fuzzy, c-format
-msgid "Unable to rename directory '%s' to '%s'"
-#: ../lib/vector/Vlib/map.c:656
-#, fuzzy, c-format
-msgid "Unable to remove directory '%s'"
-#: ../lib/vector/Vlib/map.c:711 ../lib/vector/Vlib/map.c:812
-#, fuzzy, c-format
-msgid "Unable to add database link for vector map <%s>"
-#: ../lib/vector/Vlib/poly.c:225
-msgid "Unable to find point in polygon"
-msgstr ""
-#: ../lib/vector/Vlib/poly.c:644
-msgid "conditions failed"
-msgstr ""
-#: ../lib/vector/Vlib/geos.c:52 ../lib/vector/Vlib/read.c:129
-#, fuzzy
-msgid "vector map is not opened"
-#: ../lib/vector/Vlib/geos.c:55
-#, c-format
-msgid "Vect_read_line_geos(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
-msgstr ""
-#: ../lib/vector/Vlib/geos.c:60
-msgid "only native format supported"
-msgstr ""
-#: ../lib/vector/Vlib/geos.c:90
-#, c-format
-msgid "Vect_read_area_geos(): unable to read area id %d"
-msgstr ""
-#: ../lib/vector/Vlib/geos.c:104
-#, c-format
-msgid "Vect_read_area_geos(): unable to read isle id %d of area id %d"
-msgstr ""
-#: ../lib/vector/Vlib/geos.c:202
-#, fuzzy, c-format
-msgid "Unable to read line offset %ld"
-#: ../lib/vector/Vlib/geos.c:409
-#, fuzzy, c-format
-msgid "Attempt to read points of nonexistent area id %d"
-#: ../lib/vector/Vlib/geos.c:469
-#, fuzzy, c-format
-msgid "Unable to read feature id %d"
-#: ../lib/vector/Vlib/box.c:261
-#, fuzzy, c-format
-msgid "Unable to find bbox for featured %d"
-#: ../lib/vector/Vlib/box.c:335 ../lib/vector/Vlib/box.c:401
-msgid "Could not find area box"
-msgstr ""
-#: ../lib/vector/Vlib/read.c:132
-#, c-format
-msgid "Vect_read_line(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
-msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:290
-#, fuzzy, c-format
-msgid "Unable to calculate centroid for area %d"
-#: ../lib/vector/Vlib/build_ogr.c:328 ../lib/vector/Vlib/read_ogr.c:122
-#: ../lib/vector/Vlib/read_ogr.c:469
-#, c-format
-msgid "OGR feature type %d not supported"
-msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:378
-msgid "Empty OGR layer, nothing to build"
-msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:387
-msgid "Random read is not supported by OGR for this layer, unable to build topology"
-msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:392
-#, c-format
-msgid "Using external data format '%s' (feature type '%s')"
-msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:455
-#, c-format
-msgid "Feature %d without geometry ignored"
-msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:462
-#, c-format
-msgid "OGR feature %d without ID ignored"
-msgstr ""
-#: ../lib/vector/Vlib/net.c:116
-msgid "Building graph..."
-msgstr ""
-#: ../lib/vector/Vlib/net.c:158
-#, fuzzy
-msgid "Unable to build network graph"
-#: ../lib/vector/Vlib/net.c:164
-msgid "Forward costs column not specified"
-msgstr ""
-#: ../lib/vector/Vlib/net.c:171
-msgid "Arc field < 1"
-msgstr ""
-#: ../lib/vector/Vlib/net.c:185 ../lib/vector/Vlib/net.c:202
-#: ../lib/vector/Vlib/net.c:356 ../lib/vector/Vlib/ascii.c:582
-#, fuzzy, c-format
-msgid "Column <%s> not found in table <%s>"
-#: ../lib/vector/Vlib/net.c:191 ../lib/vector/Vlib/net.c:208
-#: ../lib/vector/Vlib/net.c:362
-#, c-format
-msgid "Data type of column <%s> not supported (must be numeric)"
-msgstr ""
-#: ../lib/vector/Vlib/net.c:221
-msgid "Registering arcs..."
-msgstr ""
-#: ../lib/vector/Vlib/net.c:250
-#, c-format
-msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (forward/both direction(s) of line skipped)"
-msgstr ""
-#: ../lib/vector/Vlib/net.c:269
-#, c-format
-msgid "Database record for line %d (cat = %d, backword direction) not found(direction of line skipped)"
-msgstr ""
-#: ../lib/vector/Vlib/net.c:318
-#, fuzzy
-msgid "Cannot add network arc"
-#: ../lib/vector/Vlib/net.c:342
-msgid "Setting node costs..."
-msgstr ""
-#: ../lib/vector/Vlib/net.c:398
-#, c-format
-msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
-msgstr ""
-#: ../lib/vector/Vlib/net.c:425
-msgid "Flattening the graph..."
-msgstr ""
-#: ../lib/vector/Vlib/net.c:434
-msgid "Graph was built"
-msgstr ""
-#: ../lib/vector/Vlib/net.c:517 ../lib/vector/Vlib/graph.c:226
-#, c-format
-msgid "dglShortestPath error: %s"
-msgstr ""
-#: ../lib/vector/Vlib/net.c:600
-msgid "Wrong line direction in Vect_net_get_line_cost()"
-msgstr ""
-#: ../lib/vector/Vlib/dangles.c:148
-msgid "Changed"
-msgstr ""
-#: ../lib/vector/Vlib/dangles.c:151
-msgid "Removed"
-msgstr ""
-#: ../lib/vector/Vlib/dangles.c:154
-msgid "Selected"
-msgstr ""
-#: ../lib/vector/Vlib/dangles.c:262
-#, fuzzy, c-format
-msgid "%s lines: %d"
-#: ../lib/vector/Vlib/dangles.c:263
-#, c-format
-msgid "%s dangles: %d"
-msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:116
-msgid "Registering primitives..."
-msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:125
-#, fuzzy
-msgid "Unable to read vector map"
-#: ../lib/vector/Vlib/build_nat.c:158
-#, c-format
-msgid "%d primitives registered"
-msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:159
-#, c-format
-msgid "%d vertices registered"
-msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:170
-msgid "Building areas..."
-msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:193
-#, c-format
-msgid "%d areas built"
-msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:194
-#, c-format
-msgid "%d isles built"
-msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:203
-msgid "Attaching islands..."
-msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:219
-msgid "Attaching centroids..."
-msgstr ""
-#: ../lib/vector/Vlib/level_two.c:23
-#, fuzzy, c-format
-msgid "Vector map <%s> is not open at topological level"
-#: ../lib/vector/Vlib/level_two.c:305
-#, fuzzy, c-format
-msgid "Nodes not available for line %d"
-msgstr "[%s] या कमांडसाठी कोणतीही मदत उपलब्ध नाही\n"
-#: ../lib/vector/Vlib/level_two.c:343
-#, fuzzy, c-format
-msgid "Areas not available for line %d"
-#: ../lib/vector/Vlib/level_two.c:346
-#, fuzzy, c-format
-msgid "Line %d is not a boundary"
-#: ../lib/vector/Vlib/level_two.c:427
-#, fuzzy, c-format
-msgid "Topology info not available for feature %d"
-#: ../lib/vector/Vlib/open_ogr.c:61
-msgid "OGR datasource not defined"
-msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:66 ../lib/vector/Vlib/write_ogr.c:445
-msgid "OGR layer not defined"
-msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:78 ../lib/vector/Vlib/field.c:599
-#, fuzzy, c-format
-msgid "Unable to open OGR data source '%s'"
-#: ../lib/vector/Vlib/open_ogr.c:98
-#, fuzzy, c-format
-msgid "OGR layer <%s> not found"
-#: ../lib/vector/Vlib/open_ogr.c:158
-#, fuzzy, c-format
-msgid "Unable to open fidx file for vector map <%s@%s>"
-#: ../lib/vector/Vlib/open_ogr.c:175
-#, c-format
-msgid "Feature index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
-msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:180
-#, c-format
-msgid "Your GRASS version does not fully support feature index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
-msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:250
-#, fuzzy, c-format
-msgid "Unable to get OGR driver <%s>"
-#: ../lib/vector/Vlib/open_ogr.c:258
-#, fuzzy, c-format
-msgid "Unable to create OGR data source '%s'"
-#: ../lib/vector/Vlib/open_ogr.c:270
-#, c-format
-msgid "OGR layer <%s> already exists and will be overwritten"
-msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:274
-#, fuzzy, c-format
-msgid "Unable to delete OGR layer <%s>"
-#: ../lib/vector/Vlib/open_ogr.c:280
-#, fuzzy, c-format
-msgid "OGR layer <%s> already exists in datasource '%s'"
-#: ../lib/vector/Vlib/open_ogr.c:346
-#, c-format
-msgid "Unsupported geometry type (%d)"
-msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:365
-#, fuzzy, c-format
-msgid "Unable to create OGR layer <%s> in '%s'"
-#: ../lib/vector/Vlib/open_ogr.c:377
-#, c-format
-msgid "More layers defined, using driver <%s> and database <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:383
-msgid "Database connection not defined. Unable to write attributes."
-msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:420 ../lib/vector/Vlib/ascii.c:349
-#: ../lib/db/dbmi_client/db.c:41 ../lib/db/dbmi_client/copy_tab.c:107
-#: ../lib/db/dbmi_client/copy_tab.c:127
-#, fuzzy, c-format
-msgid "Unable to start driver <%s>"
-#: ../lib/vector/Vlib/open_ogr.c:467
-#, fuzzy, c-format
-msgid "Creating field <%s> failed"
-#: ../lib/vector/Vlib/open_nat.c:55
-#, fuzzy, c-format
-msgid "Unable to open coor file for vector map <%s>"
-#: ../lib/vector/Vlib/open_nat.c:152
-#, c-format
-msgid "Coor file of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
-msgstr ""
-#: ../lib/vector/Vlib/open_nat.c:156
-#, c-format
-msgid "Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
-msgstr ""
-#: ../lib/vector/Vlib/open.c:111
-#, c-format
-msgid "Programmer requested unknown access level %d"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:199
-#, fuzzy, c-format
-msgid "Vector map <%s> not found in current mapset"
-#: ../lib/vector/Vlib/open.c:213
-msgid "Vector map which is not in the current mapset cannot be opened for update"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:250
-#, fuzzy, c-format
-msgid "Unable to read header file of vector map <%s>"
-#: ../lib/vector/Vlib/open.c:280
-#, fuzzy, c-format
-msgid "Unable to open topology file for vector map <%s>"
-#: ../lib/vector/Vlib/open.c:292
-#, fuzzy, c-format
-msgid "Unable to open spatial index file for vector map <%s>"
-#: ../lib/vector/Vlib/open.c:316 ../lib/vector/Vlib/cindex.c:510
-#, fuzzy, c-format
-msgid "Unable to open category index file for vector map <%s>"
-#: ../lib/vector/Vlib/open.c:334 ../lib/vector/Vlib/open.c:353
-#, fuzzy, c-format
-msgid "Unable to open vector map <%s> on level %d. Try to rebuild vector topology by v.build."
-#: ../lib/vector/Vlib/open.c:362
-#, fuzzy, c-format
-msgid "Building topology for OGR layer <%s> from datasource '%s'..."
-#: ../lib/vector/Vlib/open.c:370
-#, fuzzy, c-format
-msgid "Unable to open vector map <%s> on level %d"
-#: ../lib/vector/Vlib/open.c:418
-#, fuzzy, c-format
-msgid "Unable to open history file for vector map <%s>"
-#: ../lib/vector/Vlib/open.c:627
-#, fuzzy, c-format
-msgid "<%s> is not the current mapset (%s)"
-#: ../lib/vector/Vlib/open.c:652
-#, fuzzy
-msgid "Unable to open OGR file"
-#: ../lib/vector/Vlib/open.c:692
-#, fuzzy, c-format
-msgid "Unable to create vector map <%s>"
-#: ../lib/vector/Vlib/open.c:702
-#, fuzzy, c-format
-msgid "Unable to open history file of vector map <%s>"
-#: ../lib/vector/Vlib/open.c:753
-#, fuzzy, c-format
-msgid "Unable to stat file <%s>"
-#: ../lib/vector/Vlib/open.c:812
-#, c-format
-msgid "unknown %d (update Vect_maptype_info)"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:888
-msgid "Size of 'coor' file differs from value saved in topology file"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:899 ../lib/vector/Vlib/open.c:993
-#, fuzzy, c-format
-msgid "Please rebuild topology for vector map <%s@%s>"
-#: ../lib/vector/Vlib/open.c:982
-msgid "Size of 'coor' file differs from value saved in sidx file"
-msgstr ""
-#: ../lib/vector/Vlib/dgraph.c:430
-msgid "Trying to add more edges to the planar_graph than the initial allocation size allows"
-msgstr ""
-#: ../lib/vector/Vlib/area.c:47
-#, fuzzy
-msgid "Attempt to read points of nonexistent area"
-#: ../lib/vector/Vlib/area.c:63
-#, fuzzy, c-format
-msgid "Unable to read read line %d"
-#: ../lib/vector/Vlib/area.c:119
-#, fuzzy, c-format
-msgid "Unable to read line %d"
-#: ../lib/vector/Vlib/area.c:158 ../lib/vector/Vlib/area.c:190
-#: ../lib/vector/Vlib/area.c:256 ../lib/vector/Vlib/area.c:285
-#, fuzzy, c-format
-msgid "Attempt to read topo for dead area (%d)"
-#: ../lib/vector/Vlib/area.c:226 ../lib/vector/Vlib/area.c:312
-#, fuzzy, c-format
-msgid "Attempt to read topo for dead isle (%d)"
-#: ../lib/vector/Vlib/cats.c:42
-msgid "Vect_new_cats_struct(): Out of memory"
-msgstr ""
-#: ../lib/vector/Vlib/cats.c:124
-#, c-format
-msgid "Too many categories (%d), unable to set cat %d (layer %d)"
-msgstr ""
-#: ../lib/vector/Vlib/cats.c:403
-#, c-format
-msgid "Unable to convert category string '%s' (from '%s') to category range"
-msgstr ""
-#: ../lib/vector/Vlib/graph.c:138
-#, fuzzy
-msgid "Unable to add network arc"
-#: ../lib/vector/Vlib/intersect.c:125
-msgid "3D not supported by Vect_segment_intersection()"
-msgstr ""
-#: ../lib/vector/Vlib/intersect.c:320
-msgid "Vect_segment_intersection() ERROR (collinear vertical segments)"
-msgstr ""
-#: ../lib/vector/Vlib/intersect.c:446
-msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
-msgstr ""
-#: ../lib/vector/Vlib/intersect.c:1098 ../lib/vector/Vlib/intersect.c:1104
-#: ../lib/vector/Vlib/intersect.c:1106 ../lib/vector/Vlib/intersect.c:1154
-#: ../lib/vector/Vlib/intersect.c:1163 ../lib/vector/Vlib/intersect.c:1184
-#: ../lib/vector/Vlib/intersect.c:1201
-msgid "Error while adding point to array. Out of memory"
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:102
-msgid "Break polygons: Bug in binary tree!"
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:150
-msgid "Break polygons Pass 1: select break points"
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:280
-msgid "Break polygons Pass 2: break at selected points"
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:392
-#: ../lib/vector/Vlib/break_polygons.c:644
-#, c-format
-msgid "Breaks: %d"
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:429
-msgid "Breaking polygons (pass 1: select break points)..."
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:546
-msgid "Breaking polygons (pass 2: break at selected points)..."
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:586
-msgid "Point not in search tree!"
-msgstr ""
-#: ../lib/vector/Vlib/simple_features.c:179
-#, c-format
-msgid "Unknown Simple Features type (%d)"
-msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:361
-#, fuzzy
-msgid "Line is not looped"
-#: ../lib/vector/Vlib/buffer2.c:443
-#, c-format
-msgid "Unexpected result of line_intersection() res = %d"
-msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:589
-msgid "Next edge was visited (right) but it is not the first one !!! breaking loop"
-msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:600
-msgid "Next edge was visited (left) but it is not the first one !!! breaking loop"
-msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:648
-msgid "side != 0 feature not implemented"
-msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:890 ../lib/vector/Vlib/buffer2.c:937
-msgid "zero area size"
-msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:896 ../lib/vector/Vlib/buffer2.c:943
-#, fuzzy
-msgid "Line was not closed"
-#: ../lib/vector/Vlib/buffer2.c:909 ../lib/vector/Vlib/buffer2.c:960
-msgid "Vect_get_point_in_poly() failed"
-msgstr ""
-#: ../lib/vector/Vlib/array.c:96
-#, c-format
-msgid "%d errors in category string"
-msgstr ""
-#: ../lib/vector/Vlib/array.c:142 ../lib/vector/Vlib/array.c:267
-msgid "Mixed area and other type requested for vector array"
-msgstr ""
-#: ../lib/vector/Vlib/array.c:152 ../lib/vector/Vlib/array.c:175
-#: ../lib/vector/Vlib/array.c:304 ../lib/vector/Vlib/array.c:336
-msgid "Not enough space in vector array"
-msgstr ""
-#: ../lib/vector/Vlib/array.c:292
-#, fuzzy, c-format
-msgid "Unable to select record from table <%s> (key %s, where %s)"
-#: ../lib/vector/Vlib/write.c:24 ../lib/vector/Vlib/write.c:30
-#: ../lib/vector/Vlib/write.c:36 ../lib/vector/Vlib/write.c:43
-msgid "for this format/level not supported"
-msgstr ""
-#: ../lib/vector/Vlib/write.c:150
-#, fuzzy
-msgid "Unable to write feature, vector map is not opened"
-#: ../lib/vector/Vlib/write.c:161
-#, fuzzy
-msgid "Unable to write feature (negative offset)"
-#: ../lib/vector/Vlib/write.c:194
-#, fuzzy
-msgid "Unable to rewrite feature, vector map is not opened"
-#: ../lib/vector/Vlib/write.c:207
-#, fuzzy, c-format
-msgid "Unable to rewrite feature %d"
-#: ../lib/vector/Vlib/write.c:232
-#, fuzzy, c-format
-msgid "Unable to delete feature %d, vector map <%s> is not opened on topology level"
-#: ../lib/vector/Vlib/write.c:238
-#, fuzzy, c-format
-msgid "Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
-#: ../lib/vector/Vlib/write.c:250
-#, fuzzy, c-format
-msgid "Unable to delete feature id %d from vector map <%s>"
-#: ../lib/vector/Vlib/write.c:276
-#, fuzzy, c-format
-msgid "Unable to restore feature %d, vector map <%s> is not opened on topology level"
-#: ../lib/vector/Vlib/write.c:282
-#, fuzzy, c-format
-msgid "Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
-#: ../lib/vector/Vlib/write.c:294
-#, fuzzy, c-format
-msgid "Unable to restore feature %d from vector map <%s>"
-#: ../lib/vector/Vlib/break_lines.c:438
-#, c-format
-msgid "Intersections: %d"
-msgstr ""
-#: ../lib/vector/Vlib/close_ogr.c:105
-#, fuzzy, c-format
-msgid "Unable to open fidx file for write <%s>"
-#: ../lib/vector/Vlib/cindex.c:29
-msgid "Category index is not up to date"
-msgstr ""
-#: ../lib/vector/Vlib/cindex.c:61 ../lib/vector/Vlib/cindex.c:127
-#: ../lib/vector/Vlib/cindex.c:147 ../lib/vector/Vlib/cindex.c:169
-msgid "Invalid layer index (index >= number of layers)"
-msgstr ""
-#: ../lib/vector/Vlib/cindex.c:109
-msgid "Invalid layer index (index < 0 or index >= number of layers)"
-msgstr ""
-#: ../lib/vector/Vlib/cindex.c:234
-msgid "Layer or category index out of range"
-msgstr ""
-#: ../lib/vector/Vlib/cindex.c:284
-msgid "Layer index out of range"
-msgstr ""
-#: ../lib/vector/Vlib/cindex.c:460
-#, fuzzy, c-format
-msgid "Unable to open cidx file <%s> for write"
-#: ../lib/vector/Vlib/cindex.c:468
-#, fuzzy, c-format
-msgid "Error writing out category index file <%s>"
-#: ../lib/vector/Vlib/field.c:87
-msgid "Layer number must be 1 or greater"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:92
-#, fuzzy
-msgid "Unable to add attribute link, vector map is not opened in WRITE mode"
-#: ../lib/vector/Vlib/field.c:99
-#, fuzzy
-msgid "Unable to add attribute link"
-#: ../lib/vector/Vlib/field.c:105
-#, fuzzy
-msgid "Unable to write attribute links"
-#: ../lib/vector/Vlib/field.c:150
-#, fuzzy
-msgid "Unable to write database links"
-#: ../lib/vector/Vlib/field.c:174
-msgid "Database connection not defined. Skipping."
-msgstr ""
-#: ../lib/vector/Vlib/field.c:181
-msgid "More DB links defined for input vector map. Using only first DB link for output."
-msgstr ""
-#: ../lib/vector/Vlib/field.c:256
-#, c-format
-msgid "Layer number %d or name <%s> already exists"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:347
-msgid "Default driver is not set"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:350
-msgid "Default database is not set"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:407
-#, c-format
-msgid "Requested dblink %d, maximum link number %d"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:614
-#, fuzzy, c-format
-msgid "Unable to open OGR layer <%s>"
-#: ../lib/vector/Vlib/field.c:640
-#, fuzzy
-msgid "Unable to open OGR DBMI driver"
-#: ../lib/vector/Vlib/field.c:679
-msgid "All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' available in OGR DB table"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:735
-#, c-format
-msgid "Don't know how to read links for format %d"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:769 ../lib/vector/Vlib/field.c:777
-#, fuzzy, c-format
-msgid "Error in rule on row %d in <%s>"
-#: ../lib/vector/Vlib/field.c:852
-#, fuzzy, c-format
-msgid "Unable to open vector database definition file '%s'"
-#: ../lib/vector/Vlib/field.c:947
-msgid "Bug: attempt to update map which is not in current mapset"
-msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:89
-msgid "Area is composed of dead boundary"
-msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:176
-#, c-format
-msgid "%d areas of total size %g removed"
-msgstr ""
-#: ../lib/vector/Vlib/read_ogr.c:165
-msgid "OGR feature without ID"
-msgstr ""
-#: ../lib/vector/Vlib/read_ogr.c:410
-#, c-format
-msgid "OGR feature type '%s' not supported"
-msgstr ""
-#: ../lib/vector/Vlib/read_ogr.c:528 ../lib/vector/Vlib/read_ogr.c:536
-#, c-format
-msgid "Unable to get feature geometry, FID %ld"
-msgstr ""
-#: ../lib/vector/Vlib/read_ogr.c:582
-#, fuzzy, c-format
-msgid "Attempt to read dead feature %d"
-#: ../lib/vector/Vlib/write_ogr.c:57 ../lib/vector/Vlib/write_ogr.c:214
-msgid "Boundary is not closed. Skipping."
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:153
-#, c-format
-msgid "No category defined for layer %d"
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:155
-#, c-format
-msgid "Feature has more categories, using category %d (from layer %d)"
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:170
-msgid "Feature is not a point. Skipping."
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:178
-msgid "Feature is not a line. Skipping."
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:185
-msgid "Feature is not a polygon. Skipping."
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:192
-msgid "Feature is not a face. Skipping."
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:198
-#, fuzzy, c-format
-msgid "Unsupported feature type (%d)"
-msgstr "%s उघडता आले नाही"
-#: ../lib/vector/Vlib/write_ogr.c:345
-#, fuzzy
-msgid "Unable to calculate centroid for area"
-#: ../lib/vector/Vlib/write_ogr.c:385 ../lib/vector/Vlib/write_ogr.c:417
-#, fuzzy
-msgid "Unable to rewrite feature (incompatible feature types)"
-#: ../lib/vector/Vlib/write_ogr.c:562
-#, c-format
-msgid "Feature without category of layer %d"
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:576
-#, fuzzy, c-format
-msgid "Unable to select attributes for category %d"
-#: ../lib/vector/Vlib/write_ogr.c:581 ../lib/db/dbmi_client/copy_tab.c:314
-#, fuzzy, c-format
-msgid "Unable to fetch data from table <%s>"
-#: ../lib/vector/Vlib/write_ogr.c:586
-#, c-format
-msgid "No database record for category %d, no attributes will be written"
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:619
-#, fuzzy, c-format
-msgid "Unable to create field <%s>"
-#: ../lib/vector/Vlib/header.c:87 ../lib/vector/Vlib/header.c:137
-#, fuzzy, c-format
-msgid "Unable to open header file of vector <%s>"
-#: ../lib/vector/Vlib/header.c:145
-#, c-format
-msgid "Corrupted row in head: %s"
-msgstr ""
-#: ../lib/vector/Vlib/header.c:183
-#, c-format
-msgid "Unknown keyword '%s' in vector head"
-msgstr ""
-#: ../lib/vector/Vlib/header.c:633 ../lib/gis/proj3.c:105
-msgid "Unknown projection"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:81
-#, fuzzy, c-format
-msgid "Error reading ASCII file: (bad type) [%s]"
-#: ../lib/vector/Vlib/ascii.c:119
-#, fuzzy, c-format
-msgid "Error reading ASCII file: (unknown type) [%s]"
-#: ../lib/vector/Vlib/ascii.c:132
-msgid "End of ASCII file reached before end of coordinates"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:143
-#, fuzzy, c-format
-msgid "Error reading ASCII file: (bad point) [%s]"
-#: ../lib/vector/Vlib/ascii.c:147
-#, fuzzy, c-format
-msgid "Unparsable longitude value: [%s]"
-#: ../lib/vector/Vlib/ascii.c:150
-#, c-format
-msgid "Unparsable latitude value: [%s]"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:183
-msgid "End of ASCII file reached before end of categories"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:193
-#, fuzzy, c-format
-msgid "Error reading categories: [%s]"
-#: ../lib/vector/Vlib/ascii.c:240
-#, c-format
-msgid ""
-"Unexpected data in vector head:\n"
-"[%s]"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:274
-#, c-format
-msgid "Unknown keyword <%s> in vector head"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:482
-#, fuzzy, c-format
-msgid "Unknown feature type %d"
-#: ../lib/vector/Vlib/ascii.c:517 ../lib/vector/Vlib/ascii.c:557
-#, fuzzy, c-format
-msgid "Unable to select record from table <%s> (key %s, column %s)"
-#: ../lib/vector/Vlib/ascii.c:547
-#, c-format
-msgid "Feature has more categories. Only first category (%d) is exported."
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:584
-#, fuzzy, c-format
-msgid "Column <%s>: unsupported data type"
-#: ../lib/vector/Vlib/ascii.c:664
-msgid "Unknown format"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:673
-msgid "Topology not available, unable to process areas"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:686
-#, fuzzy, c-format
-msgid "Unable to get boundary of area id %d"
-#: ../lib/vector/Vlib/ascii.c:698
-#, fuzzy, c-format
-msgid "Unable to get boundary of isle id %d (area id %d)"
-#: ../lib/vector/Vlib/select.c:104
-#, fuzzy, c-format
-msgid "Unable to delete item %d from spatial index"
-#: ../lib/vector/vedit/delete.c:40
-#, fuzzy, c-format
-msgid "Attempt to delete dead feature (%d)"
-#: ../lib/vector/vedit/delete.c:72
-#, fuzzy, c-format
-msgid "No area found for centroid %d"
-#: ../lib/vector/vedit/delete.c:76
-#, c-format
-msgid "Duplicate centroid %d, unable to delete area"
-msgstr ""
-#: ../lib/vector/vedit/delete.c:105
-#, fuzzy, c-format
-msgid "Area %d without centroid"
-#: ../lib/vector/vedit/delete.c:121
-#, fuzzy, c-format
-msgid "Area %d has no boundaries"
-msgstr "%s मिळाले नाही"
-#: ../lib/vector/vedit/cats.c:63
-#, fuzzy, c-format
-msgid "Unable to set category %d for (feature id %d)"
-#: ../lib/vector/vedit/select.c:231
-msgid "Unknown query tool"
-msgstr ""
-#: ../lib/cluster/c_exec.c:42
-#, c-format
-msgid "Not enough data points (%d) in cluster"
-msgstr ""
-#: ../lib/cluster/c_begin.c:57
-#, c-format
-msgid "produced by i.cluster"
-msgstr ""
-#: ../lib/psdriver/Graph_set.c:199
-#, c-format
-msgid "ps: truecolor status %s"
-msgstr ""
-#: ../lib/psdriver/Graph_set.c:214
-#, c-format
-msgid "ps: collecting to file '%s'"
-msgstr ""
-#: ../lib/psdriver/Graph_set.c:215
-#, c-format
-msgid "ps: image size %dx%d"
-msgstr ""
-#: ../lib/rst/interp_float/segmen2d.c:118
-msgid "Taking too long to find points for interpolation - please change the region to area where your points are. Continuing calculations..."
-msgstr ""
-#: ../lib/rst/interp_float/interp2d.c:214
-#, c-format
-msgid "Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) cell. Z-value %f, zmin %f, zmax %f."
-msgstr ""
-#: ../lib/rst/interp_float/input2d.c:48
-#, fuzzy, c-format
-msgid "Mask raster map <%s> not found"
-#: ../lib/rst/interp_float/input2d.c:70
-msgid "Bitmap mask created"
-msgstr ""
-#: ../lib/rst/interp_float/write2d.c:40 ../lib/rst/interp_float/write2d.c:51
-#: ../lib/rst/interp_float/write2d.c:66 ../lib/rst/interp_float/write2d.c:75
-#: ../lib/rst/interp_float/write2d.c:83 ../lib/rst/interp_float/write2d.c:91
-#, fuzzy
-msgid "Cannot write files"
-#: ../lib/rst/interp_float/output2d.c:106
-#, c-format
-msgid "First change your rows number to nsizr! %d %d"
-msgstr ""
-#: ../lib/rst/interp_float/output2d.c:113
-#, c-format
-msgid "First change your cols number to nsizc %d %d"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:73
-#, fuzzy, c-format
-msgid "Vector map <%s> is not 3D"
-#: ../lib/rst/interp_float/vinput2d.c:76
-msgid "Loading data from attribute table ..."
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:94
-#: ../lib/rst/interp_float/vinput2d.c:108 ../lib/db/dbmi_client/copy_tab.c:267
-#, fuzzy, c-format
-msgid "Column <%s> not found"
-#: ../lib/rst/interp_float/vinput2d.c:97
-#: ../lib/rst/interp_float/vinput2d.c:110
-#, c-format
-msgid "Data type of column <%s> must be numeric"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:121
-#, fuzzy
-msgid "Reading features from vector map ..."
-#: ../lib/rst/interp_float/vinput2d.c:153
-#, c-format
-msgid "Database record for cat %d not found"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:171
-msgid "Negative value of smoothing detected: sm must be >= 0"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:235
-msgid "Strip exists with insufficient data"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:249
-#, c-format
-msgid "There are points outside specified 2D/3D region - %d points ignored"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:252
-#, c-format
-msgid "Ignoring %d points (too dense)"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:256
-#, c-format
-msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:261
-msgid "Zero points in the given region"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:266
-#, c-format
-msgid "Segmentation parameters set to invalid values: npmin= %d, segmax= %d for smooth connection of segments, npmin > segmax (see manual)"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:272
-#, c-format
-msgid "There are less than %d points for interpolation. No segmentation is necessary, to run the program faster set segmax=%d (see manual)"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:276
-#, fuzzy, c-format
-msgid "Number of points from vector map %d"
-#: ../lib/rst/interp_float/vinput2d.c:277
-#, fuzzy, c-format
-msgid "Number of points outside of 2D/3D region %d"
-#: ../lib/rst/interp_float/vinput2d.c:279
-#, fuzzy, c-format
-msgid "Number of points being used %d"
-#: ../lib/rst/interp_float/vinput2d.c:312
-msgid "Some points outside of region (ignored)"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:318
-#, fuzzy
-msgid "Unable to allocate memory"
-#: ../lib/rst/interp_float/vinput2d.c:326
-#, fuzzy, c-format
-msgid "Unable to insert %f,%f,%f a = %d"
-#: ../lib/rst/interp_float/resout2d.c:77
-msgid "Temporarily changing the region to desired resolution..."
-msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:103
-#, c-format
-msgid "First change your rows number(%d) to %d"
-msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:110
-#, c-format
-msgid "First change your columns number(%d) to %d"
-msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:264
-msgid "No color table for input raster map -- will not create color table"
-msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:458
-msgid "Changing the region back to initial..."
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:139 ../lib/gis/rd_cellhd.c:150
-#: ../lib/gis/rd_cellhd.c:160 ../lib/gis/rd_cellhd.c:177
-#: ../lib/gis/rd_cellhd.c:193 ../lib/gis/rd_cellhd.c:201
-#: ../lib/gis/rd_cellhd.c:209 ../lib/gis/rd_cellhd.c:217
-#: ../lib/gis/rd_cellhd.c:225 ../lib/gis/rd_cellhd.c:233
-#: ../lib/gis/rd_cellhd.c:241 ../lib/gis/rd_cellhd.c:243
-#: ../lib/gis/rd_cellhd.c:251 ../lib/gis/rd_cellhd.c:253
-#: ../lib/gis/rd_cellhd.c:261 ../lib/gis/rd_cellhd.c:263
-#: ../lib/gis/rd_cellhd.c:271 ../lib/gis/rd_cellhd.c:273
-#: ../lib/gis/rd_cellhd.c:281 ../lib/gis/rd_cellhd.c:283
-#: ../lib/gis/rd_cellhd.c:291 ../lib/gis/rd_cellhd.c:293
-#: ../lib/gis/rd_cellhd.c:301 ../lib/gis/rd_cellhd.c:303
-#: ../lib/gis/rd_cellhd.c:311 ../lib/gis/rd_cellhd.c:313
-#: ../lib/gis/rd_cellhd.c:321 ../lib/gis/rd_cellhd.c:323
-#: ../lib/gis/rd_cellhd.c:331 ../lib/gis/rd_cellhd.c:333
-#: ../lib/gis/rd_cellhd.c:341 ../lib/gis/rd_cellhd.c:349
-#: ../lib/gis/rd_cellhd.c:353
-msgid "Syntax error in cell header"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:147
-msgid "Duplicate projection field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:157
-msgid "Duplicate zone field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:167 ../lib/gis/rd_cellhd.c:169
-#: ../lib/gis/rd_cellhd.c:358 ../lib/gis/rd_cellhd.c:360
-#: ../lib/gis/rd_cellhd.c:362 ../lib/gis/rd_cellhd.c:364
-#: ../lib/gis/rd_cellhd.c:366 ../lib/gis/rd_cellhd.c:368
-#: ../lib/gis/rd_cellhd.c:379 ../lib/gis/rd_cellhd.c:381
-#: ../lib/gis/rd_cellhd.c:383 ../lib/gis/rd_cellhd.c:385
-#, c-format
-msgid "Field <%s> missing"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:191
-msgid "Duplicate north field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:199
-msgid "Duplicate south field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:207
-msgid "Duplicate east field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:215
-msgid "Duplicate west field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:223
-msgid "Duplicate top field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:231
-msgid "Duplicate bottom field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:239
-msgid "Duplicate e-w resolution field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:249
-msgid "Duplicate 3D e-w resolution field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:259
-msgid "Duplicate n-s resolution field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:269
-msgid "Duplicate 3D n-s resolution field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:279
-msgid "Duplicate t-b resolution field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:289
-msgid "Duplicate rows field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:299
-msgid "Duplicate 3D rows field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:309
-msgid "Duplicate cols field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:319
-msgid "Duplicate 3D cols field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:329
-msgid "Duplicate depths field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:339
-msgid "Duplicate format field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:347
-#, fuzzy
-msgid "Duplicate compressed field"
-msgstr "compressed_buf चा आकार %d\n"
-#: ../lib/gis/parser_help.c:79
-msgid "Description:"
-msgstr ""
-#: ../lib/gis/parser_help.c:89
-msgid "Keywords:"
-msgstr ""
-#: ../lib/gis/parser_help.c:97
-msgid "Usage:"
-msgstr ""
-#: ../lib/gis/parser_help.c:127
-msgid "ERROR: Option key not defined"
-msgstr ""
-#: ../lib/gis/parser_help.c:171
-msgid "Flags:"
-msgstr ""
-#: ../lib/gis/parser_help.c:194 ../lib/gis/parser_interface.c:329
-#: ../lib/gis/parser_html.c:149
-msgid "Allow output files to overwrite existing files"
-msgstr ""
-#: ../lib/gis/parser_help.c:196 ../lib/gis/parser_interface.c:337
-#: ../lib/gis/parser_html.c:153
-msgid "Verbose module output"
-msgstr ""
-#: ../lib/gis/parser_help.c:197 ../lib/gis/parser_interface.c:344
-#: ../lib/gis/parser_html.c:156
-msgid "Quiet module output"
-msgstr ""
-#: ../lib/gis/parser_help.c:205
-msgid "Parameters:"
-msgstr ""
-#: ../lib/gis/parser_help.c:228
-#, c-format
-msgid "  %*s   default: %s\n"
-msgstr ""
-#: ../lib/gis/parser_help.c:254
-#, c-format
-msgid "  %*s   options: "
-msgstr ""
-#: ../lib/gis/get_ellipse.c:343 ../lib/gis/get_ellipse.c:366
-#, c-format
-msgid "Invalid a: field '%s' in file %s in <%s>"
-msgstr ""
-#: ../lib/gis/get_ellipse.c:355
-#, c-format
-msgid "Invalid ellipsoid '%s' in file %s in <%s>"
-msgstr ""
-#: ../lib/gis/get_ellipse.c:369
-#, c-format
-msgid "Invalid es: field '%s' in file %s in <%s>"
-msgstr ""
-#: ../lib/gis/get_ellipse.c:382
-#, c-format
-msgid "No ellipsoid info given in file %s in <%s>"
-msgstr ""
-#: ../lib/gis/legal_name.c:38
-#, c-format
-msgid "Illegal filename <%s>. Cannot be '.' or 'NULL'."
-msgstr ""
-#: ../lib/gis/legal_name.c:45
-#, c-format
-msgid "Illegal filename <%s>. Character <%c> not allowed.\n"
-msgstr ""
-#: ../lib/gis/legal_name.c:74 ../lib/gis/legal_name.c:78
-#, c-format
-msgid "Output raster map name <%s> is not valid map name"
-msgstr ""
-#: ../lib/gis/legal_name.c:115 ../lib/gis/legal_name.c:119
-#, fuzzy, c-format
-msgid "Output raster map <%s> is used as input"
-msgstr "%s@%s हा रास्टर नकाशा रिक्त आहे"
-#: ../lib/gis/ls.c:99
-#, fuzzy, c-format
-msgid "Unable to open directory %s"
-#: ../lib/gis/env.c:260
-msgid "GISRC - variable not set"
-msgstr ""
-#: ../lib/gis/env.c:292 ../lib/gis/env.c:318
-#, c-format
-msgid "Variable '%s' not set"
-msgstr ""
-#: ../lib/gis/gisinit.c:50 ../lib/gis/gisinit.c:82
-msgid "Incompatible library version for module. You need to rebuild GRASS or untangle multiple installations."
-msgstr ""
-#: ../lib/gis/gisinit.c:60
-#, c-format
-msgid "MAPSET %s - permission denied"
-msgstr ""
-#: ../lib/gis/gisinit.c:63
-#, c-format
-msgid "MAPSET %s not found"
-msgstr ""
-#: ../lib/gis/gisinit.c:96
-msgid "System not initialized. Programmer forgot to call G_gisinit()."
-msgstr ""
-#: ../lib/gis/seek.c:52 ../lib/gis/seek.c:58
-#, fuzzy
-msgid "Unable to seek"
-#: ../lib/gis/seek.c:56
-msgid "Seek offset out of range"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:44 ../lib/gis/adj_cellhd.c:192
-msgid "Illegal n-s resolution value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:48 ../lib/gis/adj_cellhd.c:198
-msgid "Illegal row value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:52 ../lib/gis/adj_cellhd.c:204
-msgid "Illegal e-w resolution value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:56 ../lib/gis/adj_cellhd.c:210
-msgid "Illegal col value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:76 ../lib/gis/adj_cellhd.c:240
-#, c-format
-msgid "Fixing subtle input data rounding error of north boundary (%g>%g)"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:81 ../lib/gis/adj_cellhd.c:245
-msgid "Illegal latitude for North"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:87 ../lib/gis/adj_cellhd.c:251
-#, c-format
-msgid "Fixing subtle input data rounding error of south boundary (%g>%g)"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:92 ../lib/gis/adj_cellhd.c:256
-msgid "Illegal latitude for South"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:104 ../lib/gis/adj_cellhd.c:268
-#, c-format
-msgid "Fixing subtle input data rounding error of west boundary (%g>%g)"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:115 ../lib/gis/adj_cellhd.c:279
-#, c-format
-msgid "Fixing subtle input data rounding error of east boundary (%g>%g)"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:128 ../lib/gis/adj_cellhd.c:292
-msgid "North must be north of South"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:130 ../lib/gis/adj_cellhd.c:294
-msgid "North must be larger than South"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:133 ../lib/gis/adj_cellhd.c:297
-msgid "East must be larger than West"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:152 ../lib/gis/adj_cellhd.c:341
-msgid "Invalid coordinates"
-msgstr "अवैध निर्देशक"
-#: ../lib/gis/adj_cellhd.c:194
-msgid "Illegal n-s3 resolution value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:200
-msgid "Illegal row3 value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:206
-msgid "Illegal e-w3 resolution value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:212
-msgid "Illegal col3 value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:216
-msgid "Illegal t-b3 resolution value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:220
-msgid "Illegal depths value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:299
-msgid "Top must be larger than Bottom"
-msgstr ""
-#: ../lib/gis/color_rules.c:88
-#, fuzzy
-msgid "no description"
-#: ../lib/gis/error.c:342
-msgid "WARNING: "
-msgstr "ताकिद: "
-#: ../lib/gis/error.c:343
-msgid "ERROR: "
-msgstr "त्रुटी: "
-#: ../lib/gis/mapset_msc.c:61
-#, fuzzy, c-format
-msgid "Unable to make mapset element %s (%s): %s"
-#: ../lib/gis/mapset_msc.c:65
-#, fuzzy, c-format
-msgid "Unable to access mapset element %s (%s): %s"
-#: ../lib/gis/parser.c:376
-#, c-format
-msgid "BUG in descriptions, option '%s' in <%s> does not exist"
-msgstr ""
-#: ../lib/gis/parser.c:484
-msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
-msgstr ""
-#: ../lib/gis/parser.c:498
-msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
-msgstr ""
-#: ../lib/gis/parser.c:529
-#, c-format
-msgid "Sorry <%s> is not a valid option"
-msgstr ""
-#: ../lib/gis/parser.c:561
-#, fuzzy
-msgid "ERROR"
-msgstr "त्रुटी: "
-#: ../lib/gis/parser.c:788
-msgid "Unable to determine program name"
-msgstr ""
-#: ../lib/gis/parser.c:804 ../lib/gis/parser.c:821
-#, c-format
-msgid "Sorry, <%c> is not a valid flag"
-msgstr ""
-#: ../lib/gis/parser.c:920
-#, c-format
-msgid "Sorry, <%s=> is ambiguous"
-msgstr ""
-#: ../lib/gis/parser.c:927
-#, c-format
-msgid "Sorry, <%s> is not a valid parameter"
-msgstr ""
-#: ../lib/gis/parser.c:935
-#, c-format
-msgid "Option <%s> does not accept multiple answers"
-msgstr ""
-#: ../lib/gis/parser.c:1006
-#, c-format
-msgid ""
-"Illegal range syntax for parameter <%s>\n"
-"\tPresented as: %s"
-msgstr ""
-#: ../lib/gis/parser.c:1012
-#, c-format
-msgid ""
-"Value <%s> out of range for parameter <%s>\n"
-"\tLegal range: %s"
-msgstr ""
-#: ../lib/gis/parser.c:1018
-#, fuzzy, c-format
-msgid "Missing value for parameter <%s>"
-#: ../lib/gis/parser.c:1024
-#, c-format
-msgid ""
-"Value <%s> ambiguous for parameter <%s>\n"
-"\tValid options: %s"
-msgstr ""
-#: ../lib/gis/parser.c:1168
-#, c-format
-msgid ""
-"Required parameter <%s> not set:\n"
-"\t(%s)"
-msgstr ""
-#: ../lib/gis/parser.c:1260
-#, c-format
-msgid ""
-"Option <%s> must be provided in multiples of %d\n"
-"\tYou provided %d item(s): %s"
-msgstr ""
-#: ../lib/gis/parser.c:1334
-#, c-format
-msgid "ERROR: option <%s>: <%s> exists.\n"
-msgstr ""
-#: ../lib/gis/home.c:35
-#, fuzzy
-msgid "Unable to determine user's home directory"
-#: ../lib/gis/home.c:112
-#, fuzzy, c-format
-msgid "Failed to create directory [%s]"
-#: ../lib/gis/list.c:83
-#, c-format
-msgid "no %s files available in current mapset\n"
-msgstr ""
-#: ../lib/gis/list.c:86
-#, c-format
-msgid "no %s files available in mapset <%s>\n"
-msgstr ""
-#: ../lib/gis/list.c:132
-#, c-format
-msgid "%s files available in mapset <%s>:\n"
-msgstr ""
-#: ../lib/gis/list.c:204
-msgid "G_list: Unknown element type"
-msgstr ""
-#: ../lib/gis/timestamp.c:292
-#, fuzzy, c-format
-msgid "Unable to create timestamp file for %s map <%s@%s>"
-#: ../lib/gis/timestamp.c:301
-#, fuzzy, c-format
-msgid "Invalid timestamp specified for %s map <%s@%s>"
-#: ../lib/gis/timestamp.c:331
-#, fuzzy, c-format
-msgid "Unable to open timestamp file for %s map <%s@%s>"
-msgstr "temp फाइल उघडता आली नाही"
-#: ../lib/gis/timestamp.c:340
-#, fuzzy, c-format
-msgid "Invalid timestamp file for %s map <%s@%s>"
-#: ../lib/gis/timestamp.c:479
-#, fuzzy, c-format
-msgid "Unable to open timestamp file for vector map <%s@%s>"
-#: ../lib/gis/timestamp.c:488
-#, fuzzy, c-format
-msgid "Invalid timestamp file for vector map <%s@%s>"
-#: ../lib/gis/timestamp.c:524
-#, fuzzy, c-format
-msgid "Unable to create timestamp file for vector map <%s@%s>"
-#: ../lib/gis/timestamp.c:533
-#, fuzzy, c-format
-msgid "Invalid timestamp specified for vector map <%s@%s>"
-#: ../lib/gis/datum.c:160
-#, c-format
-msgid "unable to open datum table file: %s"
-msgstr ""
-#: ../lib/gis/datum.c:182
-#, c-format
-msgid "error in datum table file, line %d"
-msgstr ""
-#: ../lib/gis/open.c:62
-#, c-format
-msgid "G__open(read): mapset <%s> doesn't match xmapset <%s>"
-msgstr ""
-#: ../lib/gis/open.c:84
-#, c-format
-msgid "G__open(write): xmapset <%s> != G_mapset() <%s>"
-msgstr ""
-#: ../lib/gis/units.c:139
-msgid "square units"
-msgstr ""
-msgid "square unit"
-msgstr ""
-#: ../lib/gis/units.c:141 ../lib/gis/proj3.c:58
-msgid "units"
-msgstr ""
-msgid "unit"
-msgstr ""
-#: ../lib/gis/units.c:146
-msgid "square meters"
-msgstr ""
-msgid "square meter"
-msgstr ""
-#: ../lib/gis/units.c:148
-msgid "meters"
-msgstr ""
-msgid "meter"
-msgstr ""
-#: ../lib/gis/units.c:153
-msgid "square kilometers"
-msgstr ""
-msgid "square kilometer"
-msgstr ""
-#: ../lib/gis/units.c:155
-msgid "kilometers"
-msgstr ""
-msgid "kilometer"
-msgstr ""
-#: ../lib/gis/units.c:160
-msgid "acres"
-msgstr ""
-msgid "acre"
-msgstr ""
-#: ../lib/gis/units.c:168
-msgid "hectares"
-msgstr ""
-msgid "hectare"
-msgstr ""
-#: ../lib/gis/units.c:176
-msgid "square miles"
-msgstr ""
-msgid "square mile"
-msgstr ""
-#: ../lib/gis/units.c:178
-msgid "miles"
-msgstr ""
-msgid "mile"
-msgstr ""
-#: ../lib/gis/units.c:183
-msgid "square feet"
-msgstr ""
-msgid "square foot"
-msgstr ""
-#: ../lib/gis/units.c:185
-msgid "feet"
-msgstr ""
-msgid "foot"
-msgstr ""
-#: ../lib/gis/units.c:190
-msgid "square degrees"
-msgstr ""
-msgid "square degree"
-msgstr ""
-#: ../lib/gis/units.c:192
-msgid "degrees"
-msgstr ""
-msgid "degree"
-msgstr ""
-#: ../lib/gis/spawn.c:385
-#, c-format
-msgid "CreateProcess() failed: error = %d"
-msgstr ""
-#: ../lib/gis/spawn.c:416
-#, c-format
-msgid "G_spawn: unable to redirect descriptor %d"
-msgstr ""
-#: ../lib/gis/spawn.c:424 ../lib/gis/spawn.c:611
-#, c-format
-msgid "G_spawn: unable to open file %s"
-msgstr ""
-#: ../lib/gis/spawn.c:495 ../lib/gis/spawn.c:681
-msgid "Unable to execute command"
-msgstr ""
-#: ../lib/gis/spawn.c:520 ../lib/gis/spawn.c:528
-#, c-format
-msgid "G_spawn: unable to restore signal %d"
-msgstr ""
-#: ../lib/gis/spawn.c:559
-#, c-format
-msgid "G_spawn: unable to reset signal %d"
-msgstr ""
-#: ../lib/gis/spawn.c:568
-#, c-format
-msgid "G_spawn: unable to ignore signal %d"
-msgstr ""
-#: ../lib/gis/spawn.c:579
-#, c-format
-msgid "G_spawn: unable to block signal %d"
-msgstr ""
-#: ../lib/gis/spawn.c:587
-#, c-format
-msgid "G_spawn: unable to unblock signal %d"
-msgstr ""
-#: ../lib/gis/spawn.c:616 ../lib/gis/spawn.c:625
-#, c-format
-msgid "G_spawn: unable to duplicate descriptor %d to %d"
-msgstr ""
-#: ../lib/gis/spawn.c:658
-msgid "Unable to create a new process"
-msgstr ""
-#: ../lib/gis/spawn.c:673
-#, c-format
-msgid "Unable to change directory to %s"
-msgstr ""
-#: ../lib/gis/key_value3.c:37
-#, fuzzy, c-format
-msgid "Error writing file <%s>"
-#: ../lib/gis/key_value3.c:40
-#, fuzzy, c-format
-msgid "Error closing output file <%s>"
-#: ../lib/gis/key_value3.c:65
-#, fuzzy, c-format
-msgid "Error reading file <%s>"
-#: ../lib/gis/key_value3.c:68
-#, fuzzy, c-format
-msgid "Error closing input file <%s>"
-#: ../lib/gis/paths.c:205
-#, fuzzy, c-format
-msgid "Unable to open file <%s> for reading"
-#: ../lib/gis/paths.c:221
-#, fuzzy, c-format
-msgid "Unable to fetch security info for <%s>"
-#: ../lib/gis/paths.c:237
-#, fuzzy
-msgid "Unable to look up account id"
-#: ../lib/gis/paths.c:244
-#, fuzzy
-msgid "Unable to allocate memory for account name"
-#: ../lib/gis/paths.c:250
-#, fuzzy
-msgid "Unable to allocate memory for domain name"
-#: ../lib/gis/location.c:60
-#, c-format
-msgid "LOCATION << %s >> not available"
-msgstr ""
-#: ../lib/gis/myname.c:46
-msgid "This location has no description."
-msgstr ""
-#: ../lib/gis/proj2.c:64
-msgid "State Plane"
-msgstr ""
-#: ../lib/gis/proj2.c:66
-msgid "Latitude-Longitude"
-msgstr ""
-#: ../lib/gis/proj2.c:68
-msgid "Other Projection"
-msgstr ""
-#: ../lib/gis/alloc.c:41
-#, c-format
-msgid "G_malloc: unable to allocate %lu bytes of memory at %s:%d"
-msgstr ""
-#: ../lib/gis/alloc.c:76
-#, c-format
-msgid "G_calloc: unable to allocate %lu * %lu bytes of memory at %s:%d"
-msgstr ""
-#: ../lib/gis/alloc.c:115
-#, c-format
-msgid "G_realloc: unable to allocate %lu bytes of memory at %s:%d"
-msgstr ""
-#: ../lib/gis/open_misc.c:45
-#, c-format
-msgid "G__open_misc(read): mapset <%s> doesn't match xmapset <%s>"
-msgstr ""
-#: ../lib/gis/open_misc.c:67
-#, c-format
-msgid "G__open_misc(write): xmapset <%s> != G_mapset() <%s>"
-msgstr ""
-#: ../lib/gis/get_window.c:117
-#, fuzzy, c-format
-msgid "Unable to open element file <%s> for <%s@%s>"
-#: ../lib/gis/get_projinfo.c:34 ../lib/gis/get_projinfo.c:60
-#, c-format
-msgid "<%s> file not found for location <%s>"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:111
-msgid "WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:112
-msgid "Example: income < 1000 and inhab >= 10000"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:120
-msgid "Table name"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:129
-msgid "Driver name"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:138
-msgid "Database name"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:147
-msgid "Database schema"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:148
-msgid "Do not use this option if schemas are not supported by driver/database server"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:157
-msgid "Name of attribute column"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:166
-msgid "Name of attribute column(s)"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:175
-#, fuzzy
-msgid "Name of key column"
-msgstr "उघडलेल्या फाइलचे नाव %s\n"
-#: ../lib/gis/parser_standard_options.c:176
-msgid "Must refer to an integer column"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:188
-msgid "Name of input imagery group"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:196
-#, fuzzy
-msgid "Name of input imagery subgroup"
-#: ../lib/gis/parser_standard_options.c:206
-msgid "Name of input raster map"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:215
-msgid "Name of input raster map(s)"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:223
-msgid "Name for output raster map"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:231
-#, fuzzy
-msgid "Name of raster map"
-#: ../lib/gis/parser_standard_options.c:240
-#, fuzzy
-msgid "Name of raster map(s)"
-#: ../lib/gis/parser_standard_options.c:248
-msgid "Name of base raster map"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:256
-msgid "Name of cover raster map"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:264
-#, fuzzy
-msgid "Name of input elevation raster map"
-#: ../lib/gis/parser_standard_options.c:273
-#, fuzzy
-msgid "Name of input elevation raster map(s)"
-#: ../lib/gis/parser_standard_options.c:283
-#, fuzzy
-msgid "Name of input 3D raster map"
-#: ../lib/gis/parser_standard_options.c:292
-#, fuzzy
-msgid "Name of input 3D raster map(s)"
-#: ../lib/gis/parser_standard_options.c:300
-#, fuzzy
-msgid "Name for output 3D raster map"
-#: ../lib/gis/parser_standard_options.c:308
-#, fuzzy
-msgid "Name of 3D raster map"
-#: ../lib/gis/parser_standard_options.c:317
-#, fuzzy
-msgid "Name of 3D raster map(s)"
-#: ../lib/gis/parser_standard_options.c:326
-#, fuzzy
-msgid "Data type used in the output raster3d map"
-#: ../lib/gis/parser_standard_options.c:335
-msgid "Number of digits used as mantissa in the internal map storage, 0 -23 for float, 0 - 52 for double, max or default"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:345
-msgid "The compression method used in the output raster3d map"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:355
-msgid "The dimensions of the tiles used in the output raster3d map (XxYxZ or default: 16x16x8)"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:365
-msgid "Name of input vector map"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:366
-#: ../lib/gis/parser_standard_options.c:393
-msgid "Or data source for direct OGR access"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:375
-msgid "Name of input vector map(s)"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:376
-msgid "Or data source(s) for direct OGR access"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:384
-msgid "Name for output vector map"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:392
-#, fuzzy
-msgid "Name of vector map"
-#: ../lib/gis/parser_standard_options.c:402
-#, fuzzy
-msgid "Name of vector map(s)"
-#: ../lib/gis/parser_standard_options.c:411
-#: ../lib/gis/parser_standard_options.c:420
-msgid "Feature type"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:427
-msgid "Layer number or name"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:429
-#: ../lib/gis/parser_standard_options.c:441
-msgid "A single vector map can be connected to multiple database tables. This number determines which table to use. When used with direct OGR access this is the layer name."
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:439
-msgid "Layer number or name ('-1' for all layers)"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:450
-msgid "Category value"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:457
-msgid "Category values"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:458
-#: ../lib/gis/parser_standard_options.c:472
-msgid "Example: 1,3,7-9,13"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:464
-msgid "Feature id"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:471
-msgid "Feature ids"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:482
-#, fuzzy
-msgid "Name of input file"
-#: ../lib/gis/parser_standard_options.c:490
-#, fuzzy
-msgid "Name for output file"
-#: ../lib/gis/parser_standard_options.c:498
-msgid "Field separator"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:499
-msgid "Special characters: newline, space, comma, tab"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:510
-msgid "Color"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:511
-msgid "Either a standard color name or R:G:B triplet"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:520
-msgid "Background color"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:522
-msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:533
-#, fuzzy
-msgid "Name to input directory"
-#: ../lib/gis/parser_standard_options.c:543
-msgid "Units"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:552
-msgid "Data type(s)"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:562
-msgid "Name of mapset (default: current search path)"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:563
-msgid "'.' for current mapset"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:572
-#, fuzzy
-msgid "Coordinates"
-#: ../lib/gis/parser_standard_options.c:581
-#, fuzzy
-msgid "Name of color table"
-#: ../lib/gis/parser_standard_options.c:614
-#, fuzzy
-msgid "Do not create attribute table"
-#: ../lib/gis/done_msg.c:38
-#, c-format
-msgid "%s complete. %s"
-msgstr ""
-#: ../lib/gis/view.c:176
-#, c-format
-msgid "Unable to open %s for writing"
-msgstr ""
-#: ../lib/gis/view.c:262 ../lib/gis/view.c:479
-#, c-format
-msgid "Unable to open %s for reading"
-msgstr ""
-#: ../lib/gis/view.c:465
-#, c-format
-msgid "GRASS window when view was saved:\n"
-msgstr ""
-#: ../lib/gis/view.c:545
-#, c-format
-msgid " Window saved in \"%s\" is completely outside of current GRASS window."
-msgstr ""
-#: ../lib/gis/view.c:549
-#, c-format
-msgid " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
-msgstr ""
-#: ../lib/gis/parser_html.c:40
-msgid "NAME"
-msgstr ""
-#: ../lib/gis/parser_html.c:53
-msgid "KEYWORDS"
-msgstr ""
-#: ../lib/gis/parser_html.c:58
-msgid "SYNOPSIS"
-msgstr ""
-#: ../lib/gis/parser_html.c:204
-msgid "Options"
-msgstr ""
-#: ../lib/gis/parser_html.c:210
-msgid "Default"
-msgstr ""
-#: ../lib/gis/mapset.c:37
-msgid "MAPSET is not set"
-msgstr ""
-#: ../lib/gis/distance.c:154
-#, c-format
-msgid "%s: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
-msgstr ""
-#: ../lib/gis/debug.c:81
-#, fuzzy, c-format
-msgid "Cannot open debug file '%s'"
-#: ../lib/gis/find_file.c:80
-#, c-format
-msgid "'%s/%s' was found in more mapsets (also found in <%s>)"
-msgstr ""
-#: ../lib/gis/find_file.c:88
-#, fuzzy, c-format
-msgid "Using <%s@%s>"
-#: ../lib/gis/worker.c:72
-msgid "Task already has a worker"
-msgstr ""
-#: ../lib/db/dbmi_client/delete_tab.c:40 ../lib/db/dbmi_client/table.c:46
-#, fuzzy, c-format
-msgid "Unable open database <%s> by driver <%s>"
-#: ../lib/db/dbmi_client/delete_tab.c:53
-#, fuzzy, c-format
-msgid "Unable to drop table: '%s'"
-#: ../lib/db/dbmi_client/copy_tab.c:91
-#, c-format
-msgid "Array of values to select from column <%s> is empty"
-msgstr ""
-#: ../lib/db/dbmi_client/copy_tab.c:151
-#, fuzzy, c-format
-msgid "Unable to get list tables in database <%s>"
-#: ../lib/db/dbmi_client/copy_tab.c:167
-#, fuzzy, c-format
-msgid "Table <%s> already exists in database and will be overwritten"
-#: ../lib/db/dbmi_client/copy_tab.c:172
-#, fuzzy, c-format
-msgid "Table <%s> already exists in database <%s>"
-#: ../lib/db/dbmi_client/copy_tab.c:250
-#, fuzzy, c-format
-msgid "Column <%s> is not integer"
-#: ../lib/db/dbmi_client/copy_tab.c:270
-#, fuzzy, c-format
-msgid "Unable to create table <%s>"
-#: ../lib/db/dbmi_client/copy_tab.c:370
-#, c-format
-msgid "Unknown column type (column <%s>)"
-msgstr ""
-#: ../lib/db/dbmi_client/select.c:119 ../lib/db/dbmi_client/select.c:220
-#: ../lib/db/dbmi_client/select.c:286
-msgid "Missing column name"
-msgstr ""
-#: ../lib/db/dbmi_client/select.c:215 ../lib/db/dbmi_client/select.c:281
-msgid "Missing key column name"
-msgstr ""
-#: ../lib/db/dbmi_client/select.c:314
-#, fuzzy, c-format
-msgid "Unable select records from table <%s>"
-#: ../lib/db/dbmi_client/select.c:330
-#, fuzzy
-msgid "Key column type is not integer"
-#: ../lib/db/dbmi_driver/d_error.c:57
-#, c-format
-msgid "DBMI-%s driver error:"
-msgstr ""
-#: ../lib/db/dbmi_base/valuefmt.c:52
-msgid "db_convert_Cstring_to_value(): unrecognized sqltype"
-msgstr ""
-#: ../lib/db/dbmi_base/valuefmt.c:91
-msgid "db_convert_value_into_string(): unrecongized sqltype-type"
-msgstr ""
-#: ../lib/db/dbmi_base/login.c:111
-msgid "Login file corrupted"
-msgstr ""
-#: ../lib/db/dbmi_base/error.c:72
-msgid "<NULL error message>"
-msgstr ""
-#: ../lib/db/dbmi_base/error.c:91
-msgid "dbmi: Protocol error"
-msgstr ""
-#: ../lib/db/dbmi_base/error.c:136
-msgid "dbmi: Out of Memory"
-msgstr ""
-#: ../lib/db/dbmi_base/error.c:149
-#, c-format
-msgid "dbmi: %s() not implemented"
-msgstr ""
-#: ../lib/db/dbmi_base/error.c:163
-#, c-format
-msgid "dbmi: Invalid procedure %d"
-msgstr ""
-#: ../lib/db/dbmi_base/index.c:180
-msgid "db_set_index_column_name(): invalid column number"
-msgstr ""
-#: ../lib/db/dbmi_base/index.c:197
-msgid "db_get_index_column_name(): invalid column number"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_table.c:38
-msgid ""
-"\n"
-"++ Running table unit tests ++"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_table.c:43
-msgid ""
-"\n"
-"-- Table unit tests failure --"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_table.c:45
-msgid ""
-"\n"
-"-- Table unit tests finished successfully --"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:37
-msgid ""
-"\n"
-"++ Running column unit tests ++"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:42
-msgid ""
-"\n"
-"-- column unit tests failure --"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:44
-msgid ""
-"\n"
-"-- column unit tests finished successfully --"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:57
-msgid ""
-"\n"
-"++ Run test copy column ++"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:150
-msgid ""
-"\n"
-"++ Test copy column finished ++"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_main.c:83
-msgid "Performs unit and integration tests for the dbmi base library"
-msgstr ""
-#: ../lib/db/dbmi_base/xdrtable.c:109
-msgid "fetch: table has wrong number of columns"
-msgstr ""
-#: ../lib/db/dbmi_base/legal_dbname.c:38
-#, c-format
-msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'."
-msgstr ""
-#: ../lib/db/dbmi_base/legal_dbname.c:45
-#, c-format
-msgid "Illegal table map name <%s>. Must start with a letter."
-msgstr ""
-#: ../lib/db/dbmi_base/legal_dbname.c:54
-#, c-format
-msgid "Illegal table map name <%s>. Character <%c> not allowed."
-msgstr ""
-#: ../lib/db/dbmi_base/xdrvalue.c:82
-msgid "send data: invalid C-type"
-msgstr ""
-#, fuzzy
-msgid "Unable to open null device"
-#, fuzzy
-msgid "None"
-msgstr "काही नाही"
-#, fuzzy
-msgid "Unknown"
-msgstr "अज्ञात"
-#, fuzzy
-msgid "Raster map <%s> - unable to write row %d"
-#, fuzzy
-msgid "Error writing floating point format file for map <%s>"
-#, fuzzy
-msgid "Unable to write feature, OGR layer not defined"
-#, fuzzy
-msgid "Unable to create a new process!"
-#, fuzzy
-msgid "Unable to set region"
-#, fuzzy
-msgid "Failed writing raster map"
-#, fuzzy
-msgid "Unable to write color file of raster map <%s>"
-#, fuzzy
-msgid "Unable to query drawable"
-#, fuzzy
-msgid "Failed to initialize Xlib surface"
-#, fuzzy
-#~ msgid "Cannot open database %s by driver %s"
-#~ msgstr "temp फाइल उघडता आली नाही"
-#, fuzzy
-#~ msgid "Unable to open driver <%s>"
-#~ msgstr "%s उघडता आले नाही"
-#, fuzzy
-#~ msgid "Reading nodes from vector map ..."
-#, fuzzy
-#~ msgid "Unable to open raster map <%s>"
-#, fuzzy
-#~ msgid "Unable to write raster row %i"
-#, fuzzy
-#~ msgid "Unable to open raster map <%s@%s>"
-#, fuzzy
-#~ msgid "Unable to find <%s@%s>"
-#, fuzzy
-#~ msgid "Unable to open '%s'"
-#, fuzzy
-#~ msgid " It is a reclass of raster map <%s@%s> "
-#, fuzzy
-#~ msgid "Unable to realloc buffer"
-#, fuzzy
-#~ msgid "Unable to open file %s in <%s>"
-#, fuzzy
-#~ msgid "ERROR in reading <%s> file for location <%s>"
-#~ msgstr "%s वाचताना त्रुटी"
-#, fuzzy
-#~ msgid "Unable to open category index file for vector map <%s@%s>"
-#, fuzzy
-#~ msgid "Unable to read head file"
-#, fuzzy
-#~ msgid "Can't read %s for [%s in %s]"
-#, fuzzy
-#~ msgid " Invalid format."
-#~ msgstr "अवैध निर्देशक"
-#, fuzzy
-#~ msgid "Unable to spawn the 'wish' program"
-#, fuzzy
-#~ msgid "Cannot get layer info"
-#, fuzzy
-#~ msgid "Cannot open database %s"
-#, fuzzy
-#~ msgid "Cannot describe table <%s>"
-#, fuzzy
-#~ msgid "Cannot read topo for line [%d]"
-#~ msgid "Hit RETURN to cancel request\n"
-#~ msgstr "विनंती रद्द करण्यासाठी RETURN बटण दाबा\n"
-#~ msgid "one moment...\n"
-#~ msgstr "क्षणभर थांबा...\n"
-#~ msgid "ERROR in reading %s"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Please specify projection name\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "कृपया प्रोजेक्शनचे नाव द्या\n"
-#~ msgid "Enter 'list' for the list of available projections\n"
-#~ msgstr "उपलब्ध प्रोजेक्शनची यादी पाहण्यासाठी 'list' टाइप करा\n"
-#~ msgid "with titles"
-#~ msgstr "शिर्षकांसह"
-#~ msgid "(no title)"
-#~ msgstr "(शिर्षक विरहित)"
-#~ msgid "Enter a new %s file name"
-#~ msgstr "एक नवीन %s फाइलचे नाव द्या"
-#~ msgid "a list %s"
-#~ msgstr "%s यादी"
-#~ msgid ""
-#~ "\n"
-#~ "** %s - not found **\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - मिळाली नाही **\n"
-#, fuzzy
-#~ msgid "Cannot get field info"
-#, fuzzy
-#~ msgid "Cannot open database"
-#, fuzzy
-#~ msgid "Cannot get column info"
-#, fuzzy
-#~ msgid "Cannot open existing vector map <%s>"
-#, fuzzy
-#~ msgid "Can't open directory %s"
-#, fuzzy
-#~ msgid "current window = %p"
-#~ msgstr "सध्याची विंडो = %p\n"
-#, fuzzy
-#~ msgid "Flag: window set? %d"
-#~ msgstr "निशाणी: विंडो सेट?  %d\n"
-#, fuzzy
-#~ msgid "Pre/post compressed data buffer %p"
-#~ msgstr "compressed_buf चा आकार %d\n"
-#, fuzzy
-#~ msgid "sizeof work_buf %d"
-#~ msgstr "work_buf चा आकार %d\n"
-#, fuzzy
-#~ msgid "sizeof null_buf %d"
-#~ msgstr "null_buf चा आकार %d\n"
-#, fuzzy
-#~ msgid "sizeof mask_buf %d"
-#~ msgstr "mask_buf चा आकार %d\n"
-#, fuzzy
-#~ msgid "Histogram request %d"
-#~ msgstr "हिस्टोग्रामसाठी विनंती  %d\n"
-#, fuzzy
-#~ msgid "G_dump: file #%d"
-#~ msgstr "G_dump: फाइल #%d\n"
-#, fuzzy
-#~ msgid "open mode = %d"
-#~ msgstr "उघडण्याची पद्धत = %d\n"
-#, fuzzy
-#~ msgid "Cell header %p"
-#~ msgstr "सेल शिर्षक %p\n"
-#, fuzzy
-#~ msgid "Cell stats %p"
-#~ msgstr "सेल आकडेवारी %p\n"
-#, fuzzy
-#~ msgid "Range structure %p"
-#~ msgstr "रांगाची रचना %p\n"
-#, fuzzy
-#~ msgid "float Range structure %p"
-#, fuzzy
-#~ msgid "want histogram?  %d"
-#~ msgstr "हिस्टोग्राम हवा आहे काय?  %d\n"
-#, fuzzy
-#~ msgid "File row addresses %p"
-#~ msgstr "फाइलमधील ओळींचा पत्ता %p\n"
-#, fuzzy
-#~ msgid "Decompressed data buffer %s"
-#, fuzzy
-#~ msgid "Temporary name for NEW files %s"
-#~ msgstr "नवीन फाइलसाठी तात्पुरते नाव %s\n"
-#, fuzzy
-#~ msgid "Temporary name for NEW NULL files %s"
-#~ msgstr "नवीन नल-फाइलसाठी तात्पुरते नाव %s\n"
-#, fuzzy
-#~ msgid "Mapset of open file %s"
-#~ msgstr "उघडलेल्या फाइलचे नाव %s\n"
-#, fuzzy
-#~ msgid "G_dump: end"
-#, fuzzy
-#~ msgid "Current window not settable"
-#, fuzzy
-#~ msgid "Not able to open cellfile for [%s]"
-#, fuzzy
-#~ msgid "Unable to open temporary file"
-#, fuzzy
-#~ msgid "Problem reading raster map"
-#~ msgid " The raster map %s@%s is empty"
-#~ msgstr "%s@%s हा रास्टर नकाशा रिक्त आहे"
-#~ msgid "Cannot open temp file"
-#~ msgid "hit RETURN to continue -->"
-#~ msgstr "पुढे जाण्यासाठी RETURN टाइप करा -->"
-#, fuzzy
-#~ msgid "Unable to find '%s' in '%s'"
-#, fuzzy
-#~ msgid "Unable to read header file for raster map <%s@%s>."
-#, fuzzy
-#~ msgid "Unable to add database link, map is not opened in WRITE mode"
-#, fuzzy
-#~ msgid "Unable to add database link"
-#, fuzzy
-#~ msgid "Unable to feature %d from vector map <%s>"
-#, fuzzy
-#~ msgid "Unable to open layer <%s>"
-#, fuzzy
-#~ msgid "Unable to delete layer/category %d/%d line %d"
-#, fuzzy
-#~ msgid "Attempt to delete dead line"
-#, fuzzy
-#~ msgid "Unable to rewrite line %d"
-#, fuzzy
-#~ msgid "Unable to delete line %d, vector map <%s> is not opened on topo level 2"
-#, fuzzy
-#~ msgid "Unable to delete line %d, vector map <%s> is not opened in 'write' mode"
-#, fuzzy
-#~ msgid "Unable to delete line %d from vector map <%s>"
-#, fuzzy
-#~ msgid "Unable to delete feature %d from vector map <%s>"
-#, fuzzy
-#~ msgid "Unable to close input map"
-#, fuzzy
-#~ msgid "Cannot select attributes"
-#, fuzzy
-#~ msgid "Unable to allocate memory for a null buffer"
-#, fuzzy
-#~ msgid "Unable to open file %s"
-#, fuzzy
-#~ msgid "Unable to create raster map <%s>"
-#, fuzzy
-#~ msgid "Unable to delete file '%s'. Reason: %s"
-#, fuzzy
-#~ msgid "Unable to rename directory '%s' to '%s'. Reason: %s"
-#, fuzzy
-#~ msgid "Unable to remove directory '%s'. Reason: %s"
-#, fuzzy
-#~ msgid "Vector map <%s> is not open on level >= 2"
-#~ msgstr "%s मिळाले नाही"
-#~ msgid "%s not found"
-#~ msgid "No help available for command [%s]\n"
-#~ msgstr "[%s] या कमांडसाठी कोणतीही मदत उपलब्ध नाही\n"
-#, fuzzy
-#~ msgid "Unable to delete prior null-cells file"
-#, fuzzy
-#~ msgid "Unable to close the null-cells file"
-#, fuzzy
-#~ msgid "Unable to delete the temporary null-cells file"
-#, fuzzy
-#~ msgid "Unable to delete the empty temporary null-cells file"
-#, fuzzy
-#~ msgid "Unable to delete the prior null-cells file"
-#, fuzzy
-#~ msgid "Unable to close the 'cell' file"
-#, fuzzy
-#~ msgid "Unable to delete prior 'fcell' file"
-#, fuzzy
-#~ msgid "Unable to delete the prior %s file"
-#, fuzzy
-#~ msgid "Unable to close file"
-#, fuzzy
-#~ msgid "Unable to delete the prior 'cell' file"
-#, fuzzy
-#~ msgid "Unable to delete the temporary 'cell' file"
-#, fuzzy
-#~ msgid "Unable to write quant file!"
-#, fuzzy
-#~ msgid "Unable to delete the %s file"
-#, fuzzy
-#~ msgid "Unable to write f_format file for CELL maps"
-#, fuzzy
-#~ msgid "sizeof compressed_buf %d"
Deleted: grass/trunk/locale/po/grassmods_hi.po
--- grass/trunk/locale/po/grassmods_hi.po	2012-05-29 07:08:35 UTC (rev 51861)
+++ grass/trunk/locale/po/grassmods_hi.po	2012-05-29 09:28:22 UTC (rev 51862)
@@ -1,35304 +0,0 @@
-# translation of grassmods_hi.po to Hindi
-# This file is distributed under the same license as the GRASS package.
-# Copyright (C) 2005, GRASS Development Team
-# Markus Neteler <neteler at itc.it>, 2005.
-msgid ""
-msgstr ""
-"Project-Id-Version: grassmods_hi\n"
-"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2012-01-28 11:12+0100\n"
-"PO-Revision-Date: 2005-12-20 22:29+0100\n"
-"Last-Translator: Markus Neteler <neteler at itc.it>\n"
-"Language-Team: Hindi <grass-translations at lists.osgeo.org>\n"
-"Language: hi\n"
-"MIME-Version: 1.0\n"
-"Content-Type: text/plain; charset=UTF-8\n"
-"Content-Transfer-Encoding: 8bit\n"
-"X-Generator: KBabel 1.10.2\n"
-#: ../visualization/nviz/src/nvizMain.c:71
-#: ../visualization/ximgview/main.c:293 ../misc/m.nviz.script/main.c:73
-#: ../misc/m.nviz.image/main.c:50
-#, fuzzy
-msgid "visualization"
-msgstr "का"
-#: ../visualization/nviz/src/nvizMain.c:72
-#: ../visualization/ximgview/main.c:291 ../doc/raster/r.example/main.c:83
-#: ../raster3d/r3.to.rast/main.c:207 ../raster3d/r3.cross.rast/main.c:229
-#: ../misc/m.nviz.script/main.c:70 ../misc/m.nviz.image/main.c:51
-#: ../raster/r.external/main.c:55 ../raster/r.uslek/main.c:53
-#: ../raster/r.mode/main.c:54 ../raster/r.profile/main.c:50
-#: ../raster/r.category/main.c:52 ../raster/r.watershed/front/main.c:71
-#: ../raster/r.colors.out/raster_main.c:45 ../raster/r.drain/main.c:107
-#: ../raster/r.param.scale/interface.c:54 ../raster/r.in.gridatb/main.c:45
-#: ../raster/r.support/main.c:55 ../raster/r.topmodel/main.c:62
-#: ../raster/r.external.out/main.c:214 ../raster/r.cross/main.c:73
-#: ../raster/r.usler/main.c:51 ../raster/r.distance/main.c:38
-#: ../raster/r.out.mpeg/main.c:102 ../raster/r.patch/main.c:52
-#: ../raster/r.quant/main.c:47 ../raster/r.spread/main.c:102
-#: ../raster/r.cost/main.c:139 ../raster/r.out.vtk/main.c:59
-#: ../raster/r.recode/main.c:48 ../raster/r.statistics/main.c:55
-#: ../raster/r.rescale.eq/main.c:51 ../raster/r.in.png/main.c:519
-#: ../raster/r.los/main.c:93 ../raster/r.his/main.c:62
-#: ../raster/r.buffer/main.c:66 ../raster/r.resamp.stats/main.c:256
-#: ../raster/r.circle/main.c:51 ../raster/r.walk/main.c:179
-#: ../raster/r.what/main.c:91 ../raster/r.contour/main.c:86
-#: ../raster/r.series/main.c:132 ../raster/r.random.surface/main.c:57
-#: ../raster/r.statistics3/main.c:389 ../raster/r.in.xyz/main.c:160
-#: ../raster/r.composite/main.c:72 ../raster/r.solute.transport/main.c:229
-#: ../raster/r.volume/main.c:58 ../raster/r.gwflow/main.c:205
-#: ../raster/r.topidx/main.c:39 ../raster/r.ros/main.c:211
-#: ../raster/r.in.arc/main.c:60 ../raster/r.fill.dir/main.c:85
-#: ../raster/r.mfilter/main.c:56 ../raster/r.statistics2/main.c:101
-#: ../raster/r.out.arc/main.c:60 ../raster/r.rescale/main.c:48
-#: ../raster/r.clump/main.c:46 ../raster/r.colors/edit_colors.c:60
-#: ../raster/r.to.rast3/main.c:197 ../raster/r.sun/main.c:229
-#: ../raster/r.le/r.le.patch/main.c:48 ../raster/r.le/r.le.trace/main.c:56
-#: ../raster/r.le/r.le.setup/main.c:57 ../raster/r.le/r.le.pixel/main.c:45
-#: ../raster/r.digit/main.c:44 ../raster/r.surf.contour/main.c:60
-#: ../raster/r.in.bin/main.c:235 ../raster/r.kappa/main.c:68
-#: ../raster/r.out.png/main.c:112 ../raster/r.resamp.rst/main.c:148
-#: ../raster/r.quantile/main.c:255 ../raster/r.compress/main.c:62
-#: ../raster/r.support.stats/main.c:38 ../raster/r.spreadpath/main.c:89
-#: ../raster/r.random/main.c:51 ../raster/r.grow.distance/main.c:149
-#: ../raster/r.report/main.c:66 ../raster/r.out.pov/main.c:121
-#: ../raster/r.water.outlet/main.c:65 ../raster/r.carve/main.c:74
-#: ../raster/r.out.tiff/main.c:91 ../raster/r.null/main.c:59
-#: ../raster/r.basins.fill/main.c:54 ../raster/r.surf.idw2/main.c:61
-#: ../raster/r.stats/main.c:102 ../raster/r.region/main.c:51
-#: ../raster/r.univar/r.univar_main.c:96 ../raster/r.describe/main.c:54
-#: ../raster/r.out.mat/main.c:62 ../raster/r.in.lidar/main.c:161
-#: ../raster/r.sunmask/main.c:116 ../raster/r.regression.line/main.c:46
-#: ../raster/r.out.bin/main.c:279 ../raster/r.surf.random/main.c:36
-#: ../raster/r.resample/main.c:54 ../raster/r.in.mat/main.c:91
-#: ../raster/r.li/r.li.shape/main.c:34 ../raster/r.li/r.li.cwed/cwed.c:46
-#: ../raster/r.li/r.li.patchnum/main.c:36
-#: ../raster/r.li/r.li.simpson/simpson.c:39
-#: ../raster/r.li/r.li.dominance/dominance.c:41
-#: ../raster/r.li/r.li.pielou/pielou.c:58 ../raster/r.li/r.li.mps/mps.c:40
-#: ../raster/r.li/r.li.shannon/shannon.c:38
-#: ../raster/r.li/r.li.richness/richness.c:39
-#: ../raster/r.li/r.li.renyi/renyi.c:45
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:39
-#: ../raster/r.li/r.li.padrange/padrange.c:39
-#: ../raster/r.li/r.li.padsd/padsd.c:37 ../raster/r.li/r.li.mpa/mpa.c:39
-#: ../raster/r.li/r.li.padcv/padcv.c:39
-#: ../raster/r.li/r.li.patchdensity/main.c:35 ../raster/r.out.ppm/main.c:53
-#: ../raster/r.random.cells/main.c:45 ../raster/r.timestamp/main.c:35
-#: ../raster/r.out.ascii/main.c:59 ../raster/r.slope.aspect/main.c:152
-#: ../raster/r.bitpattern/main.c:63 ../raster/r.to.vect/main.c:70
-#: ../raster/r.series.interp/main.c:64 ../raster/r.out.ppm3/main.c:56
-#: ../raster/r.resamp.bspline/main.c:81 ../raster/r.transect/main.c:103
-#: ../raster/r.surf.idw/main.c:103 ../raster/r.surf.area/main.c:76
-#: ../raster/r.grow/main.c:122 ../raster/r.neighbors/main.c:117
-#: ../raster/r.resamp.interp/main.c:76 ../raster/r.proj/main.c:146
-#: ../raster/r.info/main.c:69 ../raster/r.reclass/main.c:50
-#: ../raster/r.coin/main.c:66 ../raster/r.texture/main.c:101
-#: ../raster/r.in.gdal/main.c:81 ../raster/r.horizon/main.c:177
-#: ../raster/simwe/r.sim.sediment/main.c:111
-#: ../raster/simwe/r.sim.water/main.c:110 ../raster/r.thin/main.c:56
-#: ../raster/r.covar/main.c:51 ../raster/r.out.gdal/main.c:129
-#: ../raster/r.lake/main.c:150 ../raster/r.surf.gauss/main.c:38
-#: ../raster/r.in.poly/main.c:29 ../raster/r.in.ascii/main.c:69
-#: ../raster/r.what.color/main.c:88 ../raster/r.out.vrml/main.c:47
-#: ../raster/r.surf.fractal/main.c:38 ../raster/r.out.gridatb/main.c:67
-#: ../raster/r.resamp.filter/main.c:384 ../raster/r.to.rast3elev/main.c:361
-#: ../raster/r.mapcalc/main.c:111 ../raster/r.flow/main.c:421
-#: ../display/d.profile/main.c:192 ../display/d.what.rast/main.c:49
-#: ../display/d.rast.num/main.c:72 ../display/d.colortable/main.c:61
-#: ../display/d.colors/main.c:41 ../display/d.rast/main.c:54
-#: ../display/d.rgb/main.c:54 ../display/d.rast.arrow/main.c:96
-#: ../vector/v.sample/main.c:76 ../vector/v.neighbors/main.c:50
-#: ../vector/v.what.rast/main.c:69 ../vector/v.to.rast/main.c:41
-#: ../locale/scriptstrings/t.time.abs_to_translate.c:4
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:3
-#: ../locale/scriptstrings/r.blend_to_translate.c:2
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:2
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:2
-#: ../locale/scriptstrings/tr.aggregate.ds_to_translate.c:3
-#: ../locale/scriptstrings/tr.import_to_translate.c:4
-#: ../locale/scriptstrings/r.unpack_to_translate.c:2
-#: ../locale/scriptstrings/r.mask_to_translate.c:2
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:2
-#: ../locale/scriptstrings/tr.extract_to_translate.c:3
-#: ../locale/scriptstrings/tr.aggregate_to_translate.c:3
-#: ../locale/scriptstrings/v.krige_to_translate.c:3
-#: ../locale/scriptstrings/r.pack_to_translate.c:2
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:2
-#: ../locale/scriptstrings/i.spectral_to_translate.c:3
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
-#: ../locale/scriptstrings/r.plane_to_translate.c:2
-#: ../locale/scriptstrings/t.time.rel_to_translate.c:4
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:2
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:2
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:3
-#: ../locale/scriptstrings/tr.out.vtk_to_translate.c:4
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:2
-#: ../locale/scriptstrings/tr.unregister_to_translate.c:3
-#: ../locale/scriptstrings/tr.list_to_translate.c:4
-#: ../locale/scriptstrings/tr.univar_to_translate.c:3
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:3
-#: ../locale/scriptstrings/i.oif_to_translate.c:2
-#: ../locale/scriptstrings/r.grow_to_translate.c:2
-#: ../locale/scriptstrings/r.buffer_to_translate.c:2
-#: ../locale/scriptstrings/d.correlate_to_translate.c:3
-#: ../locale/scriptstrings/tr.series_to_translate.c:3
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:2
-#: ../locale/scriptstrings/r.tileset_to_translate.c:2
-#: ../locale/scriptstrings/tr.export_to_translate.c:4
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:2
-#: ../locale/scriptstrings/tr.register_to_translate.c:3
-#: ../locale/scriptstrings/tr.to.rast3_to_translate.c:4
-#: ../locale/scriptstrings/t.sample_to_translate.c:4
-msgid "raster"
-msgstr ""
-#: ../visualization/nviz/src/nvizMain.c:73 ../raster3d/r3.mask/main.c:132
-#: ../raster3d/r3.retile/main.c:101
-#: ../raster3d/r3.timestamp/r3.timestamp.main.c:43
-#: ../raster3d/r3.null/main.c:185 ../raster3d/r3.in.v5d/main.c:192
-#: ../raster3d/r3.info/r3.info.main.c:79 ../raster3d/r3.gwflow/main.c:159
-#: ../raster3d/r3.mkdspf/main.c:79 ../raster3d/r3.out.ascii/main.c:308
-#: ../raster3d/r3.out.v5d/main.c:286 ../raster3d/r3.to.rast/main.c:206
-#: ../raster3d/r3.cross.rast/main.c:228 ../raster3d/r3.out.vtk/main.c:376
-#: ../raster3d/r3.in.ascii/main.c:325 ../raster3d/r3.stats/main.c:568
-#: ../misc/m.nviz.script/main.c:71 ../misc/m.nviz.image/main.c:53
-#: ../raster/r.colors.out/raster3d_main.c:46
-#: ../raster/r.colors/edit_colors.c:56 ../raster/r.univar/r3.univar_main.c:99
-#: ../raster/r.to.rast3elev/main.c:362
-#: ../locale/scriptstrings/t.time.abs_to_translate.c:6
-#: ../locale/scriptstrings/t.time.rel_to_translate.c:6
-#: ../locale/scriptstrings/tr3.register_to_translate.c:3
-#: ../locale/scriptstrings/tr3.unregister_to_translate.c:3
-#: ../locale/scriptstrings/tr.to.rast3_to_translate.c:5
-#: ../locale/scriptstrings/tr3.extract_to_translate.c:3
-#: ../locale/scriptstrings/tr3.list_to_translate.c:4
-#, fuzzy
-msgid "raster3d"
-msgstr "का"
-#: ../visualization/nviz/src/nvizMain.c:74
-#: ../visualization/ximgview/main.c:292 ../doc/vector/v.example/main.c:50
-#: ../misc/m.nviz.script/main.c:72 ../misc/m.nviz.image/main.c:52
-#: ../raster/r.contour/main.c:89 ../raster/r.random/main.c:53
-#: ../display/d.vect/main.c:71 ../display/d.what.vect/main.c:57
-#: ../display/d.extract/main.c:50 ../vector/v.random/main.c:85
-#: ../vector/v.net.iso/main.c:72 ../vector/v.net.centrality/main.c:96
-#: ../vector/v.type/main.c:39 ../vector/v.colors.out/main.c:49
-#: ../vector/v.voronoi/main.c:120 ../vector/v.net.steiner/main.c:345
-#: ../vector/v.overlay/main.c:58 ../vector/v.kernel/main.c:106
-#: ../vector/v.in.ogr/main.c:121 ../vector/v.net/main.c:45
-#: ../vector/v.proj/main.c:66 ../vector/v.label/main.c:59
-#: ../vector/v.univar/main.c:63 ../vector/v.net.distance/main.c:61
-#: ../vector/v.lrs/v.lrs.segment/main.c:70
-#: ../vector/v.lrs/v.lrs.where/main.c:57
-#: ../vector/v.lrs/v.lrs.create/main.c:121
-#: ../vector/v.lrs/v.lrs.label/main.c:102 ../vector/v.out.ascii/main.c:45
-#: ../vector/v.parallel/main.c:47 ../vector/v.support/main.c:39
-#: ../vector/v.outlier/main.c:68 ../vector/v.build/main.c:37
-#: ../vector/v.edit/main.c:55 ../vector/v.in.dwg/main.c:82
-#: ../vector/v.net.alloc/main.c:60 ../vector/v.kcv/main.c:67
-#: ../vector/v.extract/main.c:78 ../vector/v.db.connect/main.c:51
-#: ../vector/v.in.ascii/main.c:48 ../vector/v.colors/main.c:55
-#: ../vector/v.sample/main.c:75 ../vector/v.distance/main.c:83
-#: ../vector/v.to.db/main.c:36 ../vector/v.mkgrid/main.c:64
-#: ../vector/v.net.bridge/main.c:46 ../vector/v.build.polylines/main.c:111
-#: ../vector/v.delaunay/main.c:85 ../vector/v.qcount/main.c:60
-#: ../vector/v.category/main.c:73 ../vector/v.net.flow/main.c:58
-#: ../vector/v.in.region/main.c:38 ../vector/v.buffer/main.c:210
-#: ../vector/v.surf.rst/main.c:142 ../vector/v.transform/main.c:69
-#: ../vector/v.reclass/main.c:67 ../vector/v.neighbors/main.c:49
-#: ../vector/v.net.timetable/main.c:260 ../vector/v.out.svg/main.c:73
-#: ../vector/v.external/main.c:48 ../vector/v.normal/main.c:74
-#: ../vector/v.lidar.edgedetection/main.c:72 ../vector/v.out.ogr/main.c:82
-#: ../vector/v.patch/main.c:68 ../vector/v.net.spanningtree/main.c:46
-#: ../vector/v.out.pov/main.c:46 ../vector/v.select/main.c:47
-#: ../vector/v.convert/main.c:36 ../vector/v.in.sites/main.c:57
-#: ../vector/v.clean/test/topocheck.c:42 ../vector/v.clean/main.c:49
-#: ../vector/v.external.out/main.c:34 ../vector/v.perturb/main.c:61
-#: ../vector/v.vect.stats/main.c:128 ../vector/v.class/main.c:44
-#: ../vector/v.net.allpairs/main.c:56 ../vector/v.info/main.c:37
-#: ../vector/v.info/print.c:319 ../vector/v.net.components/main.c:70
-#: ../vector/v.lidar.correction/main.c:68 ../vector/v.to.3d/main.c:37
-#: ../vector/v.db.select/main.c:52 ../vector/v.in.dxf/main.c:64
-#: ../vector/v.split/main.c:52 ../vector/v.what.rast/main.c:68
-#: ../vector/v.net.salesman/main.c:104 ../vector/v.to.points/main.c:172
-#: ../vector/v.extrude/main.c:69 ../vector/v.segment/main.c:54
-#: ../vector/v.what/main.c:60 ../vector/v.generalize/main.c:76
-#: ../vector/v.vol.rst/main.c:240 ../vector/v.to.rast3/main.c:48
-#: ../vector/v.label.sa/main.c:38 ../vector/v.in.db/main.c:52
-#: ../vector/v.surf.idw/main.c:85 ../vector/v.hull/main.c:50
-#: ../vector/v.out.dxf/main.c:56 ../vector/v.drape/main.c:140
-#: ../vector/v.net.path/main.c:40 ../vector/v.rectify/main.c:63
-#: ../vector/v.timestamp/main.c:36 ../vector/v.net.connectivity/main.c:53
-#: ../vector/v.surf.bspline/main.c:91 ../vector/v.lidar.growing/main.c:75
-#: ../vector/v.to.rast/main.c:40 ../vector/v.out.vtk/main.c:47
-#: ../vector/v.net.visibility/main.c:45 ../vector/v.in.lidar/main.c:153
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:2
-#: ../locale/scriptstrings/tv.list_to_translate.c:4
-#: ../locale/scriptstrings/t.time.abs_to_translate.c:5
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:2
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:3
-#: ../locale/scriptstrings/v.db.droprow_to_translate.c:2
-#: ../locale/scriptstrings/tv.unregister_to_translate.c:3
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:2
-#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:2
-#: ../locale/scriptstrings/v.db.join_to_translate.c:2
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:2
-#: ../locale/scriptstrings/v.report_to_translate.c:2
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:2
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:2
-#: ../locale/scriptstrings/tv.register_to_translate.c:3
-#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:2
-#: ../locale/scriptstrings/v.krige_to_translate.c:2
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:2
-#: ../locale/scriptstrings/t.time.rel_to_translate.c:5
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:2
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:2
-#: ../locale/scriptstrings/v.db.update_to_translate.c:2
-#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:3
-#: ../locale/scriptstrings/v.centroids_to_translate.c:2
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:2
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:2
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:2
-#: ../locale/scriptstrings/v.convert.all_to_translate.c:2
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:2
-#: ../locale/scriptstrings/v.build.all_to_translate.c:2
-#: ../locale/scriptstrings/v.out.gps_to_translate.c:2
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:2
-msgid "vector"
-msgstr ""
-#: ../visualization/nviz/src/nvizMain.c:75
-#: ../visualization/ximgview/main.c:290 ../misc/m.nviz.script/main.c:69
-#: ../display/d.histogram/main.c:84 ../display/d.vect/main.c:70
-#: ../display/d.rhumbline/main.c:43 ../display/d.where/main.c:43
-#: ../display/d.what.vect/main.c:56 ../display/d.text/main.c:139
-#: ../display/d.linegraph/main.c:119 ../display/d.profile/main.c:191
-#: ../display/d.what.rast/main.c:48 ../display/d.info/main.c:31
-#: ../display/d.vect.chart/main.c:63 ../display/d.barscale/main.c:53
-#: ../display/d.erase/main.c:29 ../display/d.zoom/main.c:61
-#: ../display/d.rast.num/main.c:71 ../display/d.grid/main.c:51
-#: ../display/d.colorlist/main.c:35 ../display/d.his/main.c:62
-#: ../display/d.geodesic/main.c:43 ../display/d.labels/main.c:43
-#: ../display/d.mon/main.c:37 ../display/d.colortable/main.c:60
-#: ../display/d.colors/main.c:40 ../display/d.rast/main.c:53
-#: ../display/d.thematic.area/main.c:76 ../display/d.fontlist/main.c:38
-#: ../display/d.graph/main.c:58 ../display/d.rgb/main.c:53
-#: ../display/d.path/main.c:48 ../display/d.rast.arrow/main.c:95
-#: ../display/d.extract/main.c:49 ../display/d.legend/main.c:84
-#: ../display/d.measure/main.c:46 ../display/d.title/main.c:49
-#: ../display/d.font/main.c:46
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:2
-#: ../locale/scriptstrings/d.redraw_to_translate.c:2
-#: ../locale/scriptstrings/d.polar_to_translate.c:2
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:2
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:2
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:2
-#: ../locale/scriptstrings/d.correlate_to_translate.c:2
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:2
-msgid "display"
-msgstr ""
-#: ../visualization/nviz/src/nvizMain.c:77
-#, fuzzy
-msgid "nviz - Visualization and animation tool for GRASS data."
-msgstr "के लिए"
-#: ../visualization/nviz/src/nvizMain.c:82
-#, fuzzy
-msgid "Name of raster map(s) for Elevation"
-msgstr "का"
-#: ../visualization/nviz/src/nvizMain.c:83
-#: ../visualization/nviz/src/nvizMain.c:92
-#: ../visualization/nviz/src/nvizMain.c:119 ../general/g.mremove/main.c:86
-msgid "Raster"
-msgstr ""
-#: ../visualization/nviz/src/nvizMain.c:91
-#, fuzzy
-msgid "Name of raster map(s) for Color"
-msgstr "का."
-#: ../visualization/nviz/src/nvizMain.c:100
-#, fuzzy
-msgid "Name of vector lines/areas overlay map(s)"
-msgstr "सदिश"
-#: ../visualization/nviz/src/nvizMain.c:101
-#: ../visualization/nviz/src/nvizMain.c:110
-msgid "Vector"
-msgstr ""
-#: ../visualization/nviz/src/nvizMain.c:109
-#, fuzzy
-msgid "Name of vector points overlay file(s)"
-msgstr "सदिश"
-#: ../visualization/nviz/src/nvizMain.c:118
-#, fuzzy
-msgid "Name of existing 3d raster map"
-msgstr "का"
-#: ../visualization/nviz/src/nvizMain.c:123
-#, fuzzy
-msgid "Quickstart - Do not load any data"
-msgstr "नहीं"
-#: ../visualization/nviz/src/nvizMain.c:128
-msgid "Exit after completing script launched from the command line"
-msgstr ""
-#: ../visualization/nviz/src/nvizMain.c:133
-msgid "Start in Demo mode (skip the \"please wait\" message)"
-msgstr ""
-#: ../visualization/nviz/src/nvizMain.c:139
-#, fuzzy
-msgid "Set alternative panel path"
-msgstr "सेट"
-#: ../visualization/nviz/src/nvizMain.c:145
-#, fuzzy
-msgid "Execute script file at startup"
-msgstr "पर"
-#: ../visualization/nviz/src/nvizMain.c:151
-msgid "Load previously saved state file"
-msgstr ""
-#: ../visualization/nviz/src/nviz_init.c:148
-#, fuzzy
-msgid "Number of elevation files does not match number of colors files"
-msgstr "का नहीं जोड़ा संख्या का."
-#: ../visualization/nviz/src/nviz_init.c:159
-#, fuzzy
-msgid "Loading data failed"
-msgstr "n"
-#: ../visualization/ximgview/main.c:64 ../general/g.cairocomp/main.c:88
-#: ../general/g.cairocomp/main.c:260
-#, fuzzy
-msgid "Unable to open display"
-msgstr "के लिए"
-#: ../visualization/ximgview/main.c:84
-#, fuzzy
-msgid "Unable to get window attributes"
-msgstr "के लिए"
-#: ../visualization/ximgview/main.c:258
-#, fuzzy
-msgid "Unable to open image file"
-msgstr "का"
-#: ../visualization/ximgview/main.c:261
-#, fuzzy
-msgid "Unable to read BMP header"
-msgstr "का a"
-#: ../visualization/ximgview/main.c:264
-#, fuzzy
-msgid "Invalid BMP header"
-msgstr "का a"
-#: ../visualization/ximgview/main.c:270
-#, fuzzy
-msgid "Unable to map image file"
-msgstr "का"
-#: ../visualization/ximgview/main.c:294
-msgid "View BMP images from the PNG driver."
-msgstr ""
-#: ../visualization/ximgview/main.c:302
-#, fuzzy
-msgid "Image file"
-msgstr "समूह"
-#: ../visualization/ximgview/main.c:309
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:5
-msgid "Percentage of CPU time to use"
-msgstr ""
-#: ../visualization/ximgview/color.c:90 ../visualization/ximgview/color.c:288
-#, c-format
-msgid "Unknown visual class [%d]."
-msgstr ""
-#: ../visualization/ximgview/color.c:239
-msgid "Unable to get sufficient gray shades."
-msgstr ""
-#: ../visualization/ximgview/color.c:256
-msgid "Unable to get sufficient colors."
-msgstr ""
-#: ../visualization/ximgview/color.c:269
-#, fuzzy
-msgid "Using private colormap for DirectColor visual."
-msgstr "निजी के लिए."
-#: ../doc/raster/r.example/main.c:84 ../doc/vector/v.example/main.c:51
-msgid "keyword2"
-msgstr ""
-#: ../doc/raster/r.example/main.c:85 ../doc/vector/v.example/main.c:52
-msgid "keyword3"
-msgstr ""
-#: ../doc/raster/r.example/main.c:86
-#, fuzzy
-msgid "My first raster module"
-msgstr "मॉडयूल."
-#: ../doc/raster/r.example/main.c:105 ../misc/m.nviz.image/surface.c:50
-#: ../misc/m.nviz.image/surface.c:107 ../raster/r.category/main.c:127
-#: ../raster/r.category/main.c:148 ../raster/r.cross/main.c:110
-#: ../raster/r.distance/parse.c:64 ../raster/r.distance/parse.c:71
-#: ../raster/r.spread/main.c:358 ../raster/r.spread/main.c:361
-#: ../raster/r.spread/main.c:364 ../raster/r.spread/main.c:368
-#: ../raster/r.spread/main.c:371 ../raster/r.spread/main.c:374
-#: ../raster/r.cost/main.c:356 ../raster/r.cost/main.c:673
-#: ../raster/r.los/main.c:174 ../raster/r.los/main.c:180
-#: ../raster/r.buffer/main.c:112 ../raster/r.walk/main.c:447
-#: ../raster/r.walk/main.c:452 ../raster/r.walk/main.c:854
-#: ../raster/r.ros/main.c:291 ../raster/r.ros/main.c:302
-#: ../raster/r.ros/main.c:307 ../raster/r.ros/main.c:312
-#: ../raster/r.ros/main.c:317 ../raster/r.ros/main.c:331
-#: ../raster/r.ros/main.c:335 ../raster/r.ros/main.c:350
-#: ../raster/r.ros/main.c:354 ../raster/r.ros/main.c:365
-#: ../raster/r.colors/edit_colors.c:268 ../raster/r.kappa/main.c:144
-#: ../raster/r.kappa/stats.c:33 ../raster/r.kappa/stats.c:38
-#: ../raster/r.report/parse.c:245 ../raster/r.carve/main.c:164
-#: ../raster/r.null/main.c:121 ../raster/r.univar/r.univar_main.c:215
-#: ../raster/r.info/main.c:99 ../raster/r.reclass/main.c:79
-#: ../raster/r.coin/main.c:127 ../raster/r.coin/main.c:129
-#: ../raster/simwe/simlib/output.c:346 ../raster/simwe/simlib/output.c:355
-#: ../raster/simwe/simlib/output.c:386 ../raster/simwe/simlib/output.c:395
-#: ../raster/simwe/simlib/output.c:441 ../raster/simwe/simlib/output.c:458
-#: ../raster/simwe/simlib/output.c:480 ../raster/simwe/simlib/output.c:519
-#: ../raster/simwe/simlib/output.c:556 ../raster/simwe/simlib/output.c:723
-#: ../raster/r.mapcalc/map.c:506 ../raster/r.flow/io.c:65
-#: ../imagery/i.group/main.c:204 ../imagery/i.group/main.c:243
-#: ../imagery/i.gensig/parse.c:36 ../imagery/i.gensigset/parse.c:42
-#: ../display/d.what.rast/main.c:118 ../display/d.what.rast/opencell.c:13
-#: ../general/g.region/main.c:463 ../general/g.region/main.c:787
-#: ../general/g.region/main.c:795 ../vector/v.colors/main.c:264
-#: ../vector/v.vol.rst/main.c:649
-#, fuzzy, c-format
-msgid "Raster map <%s> not found"
-msgstr "नहीं"
-#: ../doc/vector/v.example/main.c:53
-#, fuzzy
-msgid "My first vector module"
-msgstr "मॉडयूल."
-#: ../doc/vector/v.example/main.c:75 ../misc/m.nviz.image/vector.c:83
-#: ../raster/r.cost/main.c:331 ../raster/r.walk/main.c:422
-#: ../raster/r.carve/main.c:158 ../display/d.what.vect/main.c:133
-#: ../display/d.extract/main.c:98 ../general/g.region/main.c:512
-#: ../vector/v.lrs/v.lrs.segment/main.c:139
-#: ../vector/v.lrs/v.lrs.where/main.c:127
-#: ../vector/v.lrs/v.lrs.where/main.c:135
-#: ../vector/v.lrs/v.lrs.create/main.c:251
-#: ../vector/v.lrs/v.lrs.create/main.c:258
-#: ../vector/v.lrs/v.lrs.label/main.c:287 ../vector/v.outlier/main.c:152
-#: ../vector/v.edit/main.c:140 ../vector/v.colors/main.c:202
-#: ../vector/v.lidar.edgedetection/main.c:213 ../vector/v.convert/att.c:31
-#: ../vector/v.convert/old2new.c:26 ../vector/v.clean/test/topocheck.c:63
-#: ../vector/v.vect.stats/main.c:254 ../vector/v.vect.stats/main.c:261
-#: ../vector/v.lidar.correction/main.c:178 ../vector/v.surf.bspline/main.c:251
-#: ../vector/v.surf.bspline/main.c:311 ../vector/v.lidar.growing/main.c:126
-#, fuzzy, c-format
-msgid "Vector map <%s> not found"
-msgstr "नहीं"
-#: ../doc/vector/v.example/main.c:81
-#, fuzzy
-msgid "Unable to set predetermined vector open level"
-msgstr "का"
-#: ../doc/vector/v.example/main.c:87 ../misc/m.nviz.image/vector.c:246
-#: ../raster/r.drain/main.c:270 ../raster/r.cost/main.c:546
-#: ../raster/r.cost/main.c:614 ../raster/r.walk/main.c:729
-#: ../raster/r.walk/main.c:795 ../raster/r.region/main.c:202
-#: ../raster/simwe/simlib/observation_points.c:39
-#: ../display/d.what.vect/main.c:111 ../vector/v.net.centrality/main.c:209
-#: ../vector/v.net/main.c:66 ../vector/v.net/main.c:90
-#: ../vector/v.net.distance/main.c:156 ../vector/v.out.ascii/main.c:83
-#: ../vector/v.support/main.c:130 ../vector/v.edit/main.c:155
-#: ../vector/v.net.bridge/main.c:113 ../vector/v.net.flow/main.c:143
-#: ../vector/v.surf.rst/main.c:535 ../vector/v.surf.rst/main.c:618
-#: ../vector/v.net.timetable/main.c:354
-#: ../vector/v.lidar.edgedetection/main.c:219
-#: ../vector/v.net.spanningtree/main.c:101 ../vector/v.net.allpairs/main.c:127
-#: ../vector/v.info/main.c:60 ../vector/v.net.components/main.c:142
-#: ../vector/v.lidar.correction/main.c:182 ../vector/v.to.3d/main.c:73
-#: ../vector/v.generalize/main.c:293 ../vector/v.hull/main.c:81
-#: ../vector/v.net.connectivity/main.c:132
-#: ../vector/v.lidar.growing/main.c:138 ../vector/v.lidar.growing/main.c:142
-#: ../vector/v.net.visibility/main.c:78 ../vector/v.net.visibility/main.c:87
-#, fuzzy, c-format
-msgid "Unable to open vector map <%s>"
-msgstr "के लिए"
-#: ../doc/vector/v.example/main.c:98 ../raster/r.drain/main.c:202
-#: ../raster/r.resamp.bspline/main.c:484 ../raster/r.flow/io.c:175
-#: ../vector/v.net.centrality/main.c:215 ../vector/v.net.distance/main.c:162
-#: ../vector/v.outlier/main.c:201 ../vector/v.outlier/main.c:206
-#: ../vector/v.outlier/main.c:212 ../vector/v.edit/main.c:108
-#: ../vector/v.mkgrid/main.c:211 ../vector/v.net.bridge/main.c:119
-#: ../vector/v.delaunay/main.c:125 ../vector/v.net.flow/main.c:149
-#: ../vector/v.net.flow/main.c:155 ../vector/v.surf.rst/main.c:712
-#: ../vector/v.net.timetable/main.c:360
-#: ../vector/v.lidar.edgedetection/main.c:241
-#: ../vector/v.net.spanningtree/main.c:107 ../vector/v.net.allpairs/main.c:133
-#: ../vector/v.net.components/main.c:148
-#: ../vector/v.lidar.correction/main.c:205
-#: ../vector/v.lidar.correction/main.c:211 ../vector/v.to.3d/main.c:89
-#: ../vector/v.in.dxf/main.c:148 ../vector/v.generalize/main.c:299
-#: ../vector/v.hull/main.c:106 ../vector/v.drape/main.c:296
-#: ../vector/v.drape/main.c:336 ../vector/v.net.path/main.c:134
-#: ../vector/v.net.connectivity/main.c:138 ../vector/v.surf.bspline/main.c:331
-#: ../vector/v.net.visibility/main.c:82
-#, fuzzy, c-format
-msgid "Unable to create vector map <%s>"
-msgstr "के लिए."
-#: ../doc/vector/v.example/main.c:105 ../display/d.vect/shape.c:31
-#: ../display/d.vect.chart/plot.c:37 ../display/d.thematic.area/plot1.c:105
-#: ../vector/v.overlay/main.c:285 ../vector/v.edit/select.c:499
-#: ../vector/v.colors/scan_attr.c:26 ../vector/v.colors/write_rgb.c:20
-#: ../vector/v.colors/read_rgb.c:23 ../vector/v.distance/main.c:423
-#: ../vector/v.buffer/main.c:366 ../vector/v.vect.stats/main.c:305
-#: ../vector/v.vect.stats/main.c:381 ../vector/v.what.rast/main.c:111
-#: ../vector/v.extrude/main.c:166 ../vector/v.generalize/misc.c:162
-#: ../vector/v.drape/main.c:228 ../vector/v.surf.bspline/crosscorr.c:109
-#: ../vector/v.to.rast/support.c:127 ../vector/v.to.rast/support.c:284
-#, fuzzy, c-format
-msgid "Database connection not defined for layer %d"
-msgstr "नहीं"
-#: ../doc/vector/v.example/main.c:126 ../display/d.vect/opt.c:147
-#: ../display/d.thematic.area/main.c:200 ../vector/v.edit/select.c:506
-#: ../vector/v.db.connect/main.c:215 ../vector/v.db.connect/main.c:281
-#: ../vector/v.out.svg/main.c:137 ../vector/v.in.sites/main.c:160
-#: ../vector/v.drape/main.c:245 ../db/db.select/main.c:66
-#: ../db/db.databases/main.c:51 ../db/db.execute/main.c:65
-#: ../db/db.tables/main.c:45 ../db/db.dropdb/main.c:42
-#: ../db/db.describe/main.c:51 ../db/db.columns/main.c:44
-#: ../db/db.createdb/main.c:42
-#, fuzzy, c-format
-msgid "Unable to start driver <%s>"
-msgstr "प्रारंभ"
-#: ../doc/vector/v.example/main.c:131 ../misc/m.nviz.image/vector.c:252
-#: ../raster/r.contour/main.c:161 ../raster/r.random/random.c:73
-#: ../raster/r.to.vect/main.c:168 ../ps/ps.map/catval.c:54
-#: ../ps/ps.map/catval.c:116 ../ps/ps.map/catval.c:182
-#: ../display/d.vect/attr.c:43 ../display/d.vect/shape.c:37
-#: ../display/d.vect.chart/plot.c:43 ../display/d.thematic.area/plot1.c:111
-#: ../vector/v.random/main.c:177 ../vector/v.net.centrality/main.c:243
-#: ../vector/v.colors.out/make_colors.c:35 ../vector/v.overlay/main.c:188
-#: ../vector/v.overlay/main.c:293 ../vector/v.label/main.c:277
-#: ../vector/v.net.distance/main.c:213 ../vector/v.lrs/v.lrs.create/main.c:288
-#: ../vector/v.lrs/v.lrs.create/main.c:296 ../vector/v.edit/select.c:513
-#: ../vector/v.in.dwg/main.c:212 ../vector/v.kcv/main.c:166
-#: ../vector/v.extract/main.c:259 ../vector/v.db.connect/main.c:221
-#: ../vector/v.db.connect/main.c:329 ../vector/v.in.ascii/main.c:316
-#: ../vector/v.colors/scan_attr.c:31 ../vector/v.colors/write_rgb.c:25
-#: ../vector/v.colors/read_rgb.c:28 ../vector/v.sample/main.c:180
-#: ../vector/v.distance/main.c:393 ../vector/v.distance/main.c:429
-#: ../vector/v.to.db/query.c:89 ../vector/v.to.db/update.c:46
-#: ../vector/v.mkgrid/main.c:225 ../vector/v.net.flow/main.c:169
-#: ../vector/v.buffer/main.c:371 ../vector/v.surf.rst/main.c:573
-#: ../vector/v.transform/trans_digit.c:38 ../vector/v.reclass/main.c:130
-#: ../vector/v.net.timetable/main.c:93 ../vector/v.out.svg/main.c:144
-#: ../vector/v.normal/main.c:121 ../vector/v.out.ogr/main.c:571
-#: ../vector/v.patch/main.c:138 ../vector/v.patch/main.c:168
-#: ../vector/v.patch/main.c:282 ../vector/v.patch/main.c:339
-#: ../vector/v.in.sites/main.c:165 ../vector/v.class/main.c:106
-#: ../vector/v.net.allpairs/main.c:160 ../vector/v.info/print.c:147
-#: ../vector/v.net.components/main.c:173 ../vector/v.to.3d/trans3.c:56
-#: ../vector/v.to.3d/trans2.c:54 ../vector/v.db.select/main.c:148
-#: ../vector/v.in.dxf/write_vect.c:211 ../vector/v.what.rast/main.c:117
-#: ../vector/v.to.points/main.c:283 ../vector/v.extrude/main.c:171
-#: ../vector/v.vol.rst/main.c:633 ../vector/v.vol.rst/user1.c:99
-#: ../vector/v.to.rast3/main.c:82 ../vector/v.label.sa/labels.c:77
-#: ../vector/v.in.db/main.c:122 ../vector/v.surf.idw/read_sites.c:41
-#: ../vector/v.drape/main.c:250 ../vector/v.net.path/path.c:96
-#: ../vector/v.surf.bspline/main.c:371
-#: ../vector/v.surf.bspline/crosscorr.c:118 ../vector/v.to.rast/support.c:132
-#: ../vector/v.to.rast/support.c:290 ../vector/v.to.rast/vect2rast.c:53
-#, fuzzy, c-format
-msgid "Unable to open database <%s> by driver <%s>"
-msgstr "स्रोत"
-#: ../doc/vector/v.example/main.c:137 ../vector/v.random/main.c:216
-#: ../vector/v.db.connect/main.c:226 ../vector/v.in.ascii/main.c:407
-#: ../vector/v.reclass/main.c:177 ../vector/v.out.svg/main.c:150
-#: ../vector/v.out.ogr/main.c:576 ../vector/v.patch/main.c:145
-#: ../vector/v.patch/main.c:183 ../vector/v.info/print.c:152
-#: ../vector/v.drape/main.c:256 ../db/db.describe/main.c:62
-#, fuzzy, c-format
-msgid "Unable to describe table <%s>"
-msgstr "फ़ाइल"
-#: ../doc/vector/v.example/main.c:170
-#, fuzzy, c-format
-msgid "Unable to get attribute data for cat %d"
-msgstr "के लिए"
-#: ../doc/vector/v.example/main.c:179
-#, fuzzy, c-format
-msgid "Error while retrieving database record for cat %d"
-msgstr "नहीं के लिए"
-#: ../doc/vector/v.example/main.c:212
-#, fuzzy, c-format
-msgid "Unable to copy attribute table to vector map <%s>"
-msgstr "के लिए"
-#: ../raster3d/r3.mask/main.c:57 ../raster3d/r3.null/main.c:102
-#: ../raster3d/r3.out.ascii/main.c:330 ../raster3d/r3.out.v5d/main.c:309
-#: ../raster3d/r3.to.rast/main.c:221 ../raster3d/r3.cross.rast/main.c:244
-#: ../raster3d/r3.out.vtk/main.c:142 ../raster3d/r3.stats/main.c:612
-#: ../raster/r.colors/edit_colors.c:275
-#: ../raster/r.univar/r3.univar_main.c:147
-#: ../raster/r.univar/r3.univar_main.c:185 ../general/g.region/main.c:489
-#: ../vector/v.colors/main.c:271
-#, fuzzy, c-format
-msgid "3D raster map <%s> not found"
-msgstr "नहीं"
-#: ../raster3d/r3.mask/main.c:63 ../raster3d/r3.null/main.c:109
-#: ../raster3d/r3.info/r3.info.main.c:135 ../raster3d/r3.out.v5d/main.c:314
-#: ../raster3d/r3.cross.rast/main.c:278 ../raster3d/r3.out.vtk/main.c:207
-#: ../raster3d/r3.out.vtk/main.c:292 ../raster3d/r3.out.vtk/main.c:512
-#: ../raster3d/r3.stats/main.c:619 ../raster/r.univar/r3.univar_main.c:154
-#: ../raster/r.univar/r3.univar_main.c:192
-#, fuzzy, c-format
-msgid "Unable to open 3D raster map <%s>"
-msgstr "के लिए."
-#: ../raster3d/r3.mask/main.c:74
-#, fuzzy
-msgid "Unable to open 3D raster mask file"
-msgstr "के लिए."
-#: ../raster3d/r3.mask/main.c:103
-#, fuzzy
-msgid "makeMask: error flushing tiles in cube"
-msgstr "त्रुटि"
-#: ../raster3d/r3.mask/main.c:108
-#, fuzzy
-msgid "makeMask: error flushing all tiles"
-msgstr "त्रुटि"
-#: ../raster3d/r3.mask/main.c:116
-#, fuzzy
-msgid "Unable to close 3D raster mask file"
-msgstr "का a"
-#: ../raster3d/r3.mask/main.c:118
-#, fuzzy, c-format
-msgid "Unable to close raster map <%s>"
-msgstr "के लिए."
-#: ../raster3d/r3.mask/main.c:133 ../raster3d/r3.retile/main.c:103
-#: ../raster3d/r3.timestamp/r3.timestamp.main.c:44
-#: ../raster3d/r3.null/main.c:186 ../raster3d/r3.in.v5d/main.c:193
-#: ../raster3d/r3.info/r3.info.main.c:80 ../raster3d/r3.gwflow/main.c:160
-#: ../raster3d/r3.mkdspf/main.c:80 ../raster3d/r3.out.ascii/main.c:309
-#: ../raster3d/r3.out.v5d/main.c:287 ../raster3d/r3.to.rast/main.c:208
-#: ../raster3d/r3.cross.rast/main.c:230 ../raster3d/r3.out.vtk/main.c:377
-#: ../raster3d/r3.in.ascii/main.c:326 ../raster/r.to.rast3elev/main.c:363
-msgid "voxel"
-msgstr ""
-#: ../raster3d/r3.mask/main.c:135
-msgid "Establishes the current working 3D raster mask."
-msgstr ""
-#: ../raster3d/r3.mask/main.c:143
-#, fuzzy
-msgid "3D raster map with reference values"
-msgstr "का"
-#: ../raster3d/r3.mask/main.c:151
-#, fuzzy
-msgid "List of cell values to be masked out"
-msgstr "का"
-#: ../raster3d/r3.mask/main.c:157
-#, fuzzy
-msgid "Cannot create mask file: RASTER3D_MASK already exists"
-msgstr ""
-"\n"
-" जी."
-#: ../raster3d/r3.retile/main.c:54
-#, fuzzy
-msgid "Unable to close the 3d raster map"
-msgstr "का"
-#: ../raster3d/r3.retile/main.c:76
-#, fuzzy
-msgid "Name of the retiled 3D raster map"
-msgstr "का"
-#: ../raster3d/r3.retile/main.c:102
-msgid "retile"
-msgstr ""
-#: ../raster3d/r3.retile/main.c:104
-msgid "Retiles an existing RASTER3D map with user defined x, y and z tile size"
-msgstr ""
-#: ../raster3d/r3.retile/main.c:113
-#, fuzzy, c-format
-msgid "Open 3d raster map <%s>"
-msgstr "खोलें n"
-#: ../raster3d/r3.retile/main.c:118 ../misc/m.nviz.image/volume.c:42
-#: ../misc/m.nviz.image/volume.c:125
-#, fuzzy, c-format
-msgid "3d raster map <%s> not found"
-msgstr "नहीं"
-#: ../raster3d/r3.retile/main.c:132
-#, fuzzy, c-format
-msgid "Unable to open 3d raster map <%s>"
-msgstr "के लिए."
-#: ../raster3d/r3.retile/main.c:140
-msgid "Rast3d_get_standard3d_params: tile dimension value invalid"
-msgstr ""
-#: ../raster3d/r3.retile/main.c:153 ../raster/r.to.rast3/main.c:326
-#: ../raster/r.to.rast3elev/main.c:501
-#, fuzzy
-msgid "Error closing 3d raster map"
-msgstr "त्रुटि"
-#: ../raster3d/r3.timestamp/r3.timestamp.main.c:46
-#, fuzzy
-msgid "Print/add/remove a timestamp for a 3D raster map"
-msgstr "a के लिए a"
-#: ../raster3d/r3.timestamp/r3.timestamp.main.c:55
-msgid "Datetime, datetime1/datetime2, or none"
-msgstr ""
-#: ../raster3d/r3.timestamp/r3.timestamp.main.c:70
-#, fuzzy, c-format
-msgid "Raster3d map <%s> not found %s"
-msgstr "नहीं"
-#: ../raster3d/r3.null/main.c:54
-#, fuzzy
-msgid "3d raster map for which to modify null values"
-msgstr "के लिए"
-#: ../raster3d/r3.null/main.c:62 ../raster/r.null/main.c:72
-#, fuzzy
-msgid "List of cell values to be set to NULL"
-msgstr "का सेट"
-#: ../raster3d/r3.null/main.c:69 ../raster/r.null/main.c:80
-#, fuzzy
-msgid "The value to replace the null value by"
-msgstr "बदलें"
-#: ../raster3d/r3.null/main.c:84
-#, fuzzy
-msgid "Illegal value for null"
-msgstr "के लिए"
-#: ../raster3d/r3.null/main.c:121
-#, fuzzy
-msgid "modifyNull: error opening tmp file"
-msgstr "त्रुटि"
-#: ../raster3d/r3.null/main.c:155
-#, fuzzy
-msgid "modifyNull: error flushing tiles in cube"
-msgstr "त्रुटि"
-#: ../raster3d/r3.null/main.c:160
-#, fuzzy
-msgid "modifyNull: error flushing all tiles"
-msgstr "त्रुटि"
-#: ../raster3d/r3.null/main.c:168
-#, fuzzy
-msgid "Unable to close raster map"
-msgstr "का a"
-#: ../raster3d/r3.null/main.c:170
-#, fuzzy
-msgid "modifyNull: Unable to close tmp file"
-msgstr "त्रुटि"
-#: ../raster3d/r3.null/main.c:188
-msgid "Explicitly create the 3D NULL-value bitmap file."
-msgstr ""
-#: ../raster3d/r3.in.v5d/main.c:195
-#, fuzzy
-msgid "Import 3-dimensional Vis5D files."
-msgstr "निर्यात का."
-#: ../raster3d/r3.in.v5d/main.c:215 ../raster3d/r3.in.ascii/main.c:357
-#, fuzzy
-msgid "Unable to open 3D raster map"
-msgstr "के लिए."
-#: ../raster3d/r3.in.v5d/main.c:220 ../raster3d/r3.out.ascii/main.c:62
-#: ../raster3d/r3.out.ascii/main.c:371 ../raster3d/r3.out.v5d/main.c:54
-#: ../raster3d/r3.out.v5d/main.c:328 ../raster3d/r3.to.rast/main.c:55
-#: ../raster3d/r3.to.rast/main.c:382 ../raster3d/r3.cross.rast/main.c:55
-#: ../raster3d/r3.out.vtk/main.c:252 ../raster3d/r3.out.vtk/main.c:338
-#: ../raster3d/r3.in.ascii/main.c:363
-#, fuzzy
-msgid "Unable to close 3D raster map"
-msgstr "का a"
-#: ../raster3d/r3.info/r3.info.main.c:82
-#, fuzzy
-msgid "Outputs basic information about a user-specified 3D raster map layer."
-msgstr "a."
-#: ../raster3d/r3.info/r3.info.main.c:89
-#, fuzzy
-msgstr "का"
-#: ../raster3d/r3.info/r3.info.main.c:93 ../raster/r.info/main.c:83
-#, fuzzy
-msgid "Print range only"
-msgstr "छापें"
-#: ../raster3d/r3.info/r3.info.main.c:98
-#, fuzzy
-msgid "Print 3D raster map resolution (NS-res, EW-res, TB-res) only"
-msgstr "छापें"
-#: ../raster3d/r3.info/r3.info.main.c:102
-#, fuzzy
-msgid "Print 3D raster map type (float/double) only"
-msgstr "छापें"
-#: ../raster3d/r3.info/r3.info.main.c:106
-#, fuzzy
-msgid "Print 3D raster map region only"
-msgstr "छापें"
-#: ../raster3d/r3.info/r3.info.main.c:110
-#, fuzzy
-msgid "Print 3D raster tile number and size information only"
-msgstr "छापें"
-#: ../raster3d/r3.info/r3.info.main.c:114
-#, fuzzy
-msgid "Print 3D raster history instead of info"
-msgstr "छापें का"
-#: ../raster3d/r3.info/r3.info.main.c:119
-#, fuzzy
-msgid "Print 3D raster map timestamp (day.month.year hour:minute:seconds) only"
-msgstr "छापें माह वर्ष घंटा"
-#: ../raster3d/r3.info/r3.info.main.c:128
-#, fuzzy, c-format
-msgid "3D Raster map <%s> not found"
-msgstr "नहीं"
-#: ../raster3d/r3.info/r3.info.main.c:164
-#: ../raster3d/r3.info/r3.info.main.c:171
-#: ../raster3d/r3.info/r3.info.main.c:177
-#: ../raster3d/r3.info/r3.info.main.c:182
-#: ../raster3d/r3.info/r3.info.main.c:188
-#: ../raster3d/r3.info/r3.info.main.c:199
-#: ../raster3d/r3.info/r3.info.main.c:205
-#: ../raster3d/r3.info/r3.info.main.c:220
-#: ../raster3d/r3.info/r3.info.main.c:227
-#: ../raster3d/r3.info/r3.info.main.c:234
-#: ../raster3d/r3.info/r3.info.main.c:239
-#: ../raster3d/r3.info/r3.info.main.c:244
-#: ../raster3d/r3.info/r3.info.main.c:251
-#: ../raster3d/r3.info/r3.info.main.c:261
-#: ../raster3d/r3.info/r3.info.main.c:267
-#: ../raster3d/r3.info/r3.info.main.c:273
-#: ../raster3d/r3.info/r3.info.main.c:289
-#: ../raster3d/r3.info/r3.info.main.c:296
-#: ../raster3d/r3.info/r3.info.main.c:303
-#: ../raster3d/r3.info/r3.info.main.c:312
-#: ../raster3d/r3.info/r3.info.main.c:322
-#: ../raster3d/r3.info/r3.info.main.c:332
-#: ../raster3d/r3.info/r3.info.main.c:342
-#: ../raster3d/r3.info/r3.info.main.c:362
-#: ../raster3d/r3.info/r3.info.main.c:372
-#: ../raster3d/r3.info/r3.info.main.c:377
-#: ../raster3d/r3.info/r3.info.main.c:385
-#: ../raster3d/r3.info/r3.info.main.c:398 ../raster/r.info/main.c:285
-#: ../raster/r.info/main.c:408
-#, fuzzy
-msgid "Cannot allocate memory for string"
-msgstr "के लिए"
-#: ../raster3d/r3.info/r3.info.main.c:344
-#: ../raster3d/r3.info/r3.info.main.c:413
-#, fuzzy, c-format
-msgid "Unable to read range of 3D raster map <%s>"
-msgstr "डाटाटाइप."
-#: ../raster3d/r3.info/r3.info.main.c:482
-#, fuzzy
-msgid "Error while reading history file"
-msgstr "त्रुटि."
-#: ../raster3d/r3.info/r3.info.main.c:503 ../raster3d/r3.cross.rast/main.c:342
-#: ../raster3d/r3.out.vtk/errorHandling.c:65
-#, fuzzy, c-format
-msgid "Unable to close 3D raster map <%s>"
-msgstr "के लिए."
-#: ../raster3d/r3.gwflow/main.c:54
-msgid "Input 3D raster map with initial piezometric heads in [m]"
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:60
-msgid "Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:65
-#, fuzzy
-msgid "Input 3D raster map with the x-part of the hydraulic conductivity tensor in [m/s]"
-msgstr "बेस"
-#: ../raster3d/r3.gwflow/main.c:70
-#, fuzzy
-msgid "Input 3D raster map with the y-part of the hydraulic conductivity tensor in [m/s]"
-msgstr "बेस"
-#: ../raster3d/r3.gwflow/main.c:75
-#, fuzzy
-msgid "Input 3D raster map with the z-part of the hydraulic conductivity tensor in [m/s]"
-msgstr "बेस"
-#: ../raster3d/r3.gwflow/main.c:80
-#, fuzzy
-msgid "Input 3D raster map with sources and sinks in [m^3/s]"
-msgstr "नहीं."
-#: ../raster3d/r3.gwflow/main.c:84
-#, fuzzy
-msgid "Specific yield [1/m] input 3D raster map"
-msgstr "का"
-#: ../raster3d/r3.gwflow/main.c:89
-#, fuzzy
-msgid "Recharge input 3D raster map in m^3/s"
-msgstr "n"
-#: ../raster3d/r3.gwflow/main.c:93
-#, fuzzy
-msgid "Output 3D raster map storing the piezometric head result of the numerical calculation"
-msgstr "शीर्षक"
-#: ../raster3d/r3.gwflow/main.c:99
-#, fuzzy
-msgid "Output 3D raster map storing the groundwater filter velocity vector part in x direction [m/s]"
-msgstr "शीर्षक"
-#: ../raster3d/r3.gwflow/main.c:105
-#, fuzzy
-msgid "Output 3D raster map storing the groundwater filter velocity vector part in y direction [m/s]"
-msgstr "शीर्षक"
-#: ../raster3d/r3.gwflow/main.c:111
-#, fuzzy
-msgid "Output 3D raster map storing the groundwater filter velocity vector part in z direction [m/s]"
-msgstr "शीर्षक"
-#: ../raster3d/r3.gwflow/main.c:117
-#, fuzzy
-msgid "Output 3D raster map Storing the groundwater budget for each cell [m^3/s]\n"
-msgstr "शीर्षक"
-#: ../raster3d/r3.gwflow/main.c:127
-msgid "Use RASTER3D mask (if exists)"
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:131 ../raster/r.solute.transport/main.c:192
-msgid "Use a full filled quadratic linear equation system, default is a sparse linear equation system."
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:161 ../raster/r.uslek/main.c:54
-#: ../raster/r.watershed/front/main.c:72 ../raster/r.drain/main.c:108
-#: ../raster/r.topmodel/main.c:63 ../raster/r.usler/main.c:52
-#: ../raster/r.solute.transport/main.c:230 ../raster/r.topidx/main.c:40
-#: ../raster/r.fill.dir/main.c:86 ../raster/r.water.outlet/main.c:66
-#: ../raster/r.carve/main.c:75 ../raster/r.basins.fill/main.c:55
-#: ../raster/simwe/r.sim.sediment/main.c:112
-#: ../raster/simwe/r.sim.water/main.c:111 ../raster/r.lake/main.c:151
-#: ../raster/r.flow/main.c:422
-msgid "hydrology"
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:162
-#, fuzzy
-msgid "groundwater"
-msgstr "नक़ल"
-#: ../raster3d/r3.gwflow/main.c:163
-msgid "numeric"
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:164
-#, fuzzy
-msgid "simulation"
-msgstr "के लिए"
-#: ../raster3d/r3.gwflow/main.c:165
-msgid "Numerical calculation program for transient, confined groundwater flow in three dimensions"
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:182
-msgid ""
-"The cholesky solver does not work with sparse matrices.\n"
-"Consider to choose a full filled quadratic matrix with flag -f "
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:281 ../raster/r.gwflow/main.c:542
-#, fuzzy
-msgid "Unable to create and solve the linear equation system"
-msgstr "का a"
-#: ../raster3d/r3.gwflow/main.c:367
-#, fuzzy, c-format
-msgid "Unable to create 3D raster map <%s>"
-msgstr "के लिए."
-#: ../raster3d/r3.gwflow/main.c:414
-#, fuzzy
-msgid "Error closing g3d file"
-msgstr "त्रुटि"
-#: ../raster3d/r3.mkdspf/main.c:82
-#, fuzzy
-msgid "Creates a display file from an existing grid3 file according to specified threshold levels."
-msgstr "a."
-#: ../raster3d/r3.mkdspf/main.c:90
-#, fuzzy
-msgid "Name of an existing 3d raster map"
-msgstr "का"
-#: ../raster3d/r3.mkdspf/main.c:97
-#, fuzzy
-msgid "Name of output display file"
-msgstr "का"
-#: ../raster3d/r3.mkdspf/main.c:104
-#, fuzzy
-msgid "List of thresholds for isosurfaces"
-msgstr "का के लिए"
-#: ../raster3d/r3.mkdspf/main.c:110
-#, fuzzy
-msgid "Minimum isosurface level"
-msgstr "आइसोसरफेस"
-#: ../raster3d/r3.mkdspf/main.c:116
-#, fuzzy
-msgid "Maximum isosurface level"
-msgstr "आइसोसरफेस"
-#: ../raster3d/r3.mkdspf/main.c:122
-#, fuzzy
-msgid "Positive increment between isosurface levels"
-msgstr "धनात्मक आइसोसरफेस"
-#: ../raster3d/r3.mkdspf/main.c:129
-#, fuzzy
-msgid "Number of isosurface threshold levels"
-msgstr "का आइसोसरफेस"
-#: ../raster3d/r3.mkdspf/main.c:133
-msgid "Suppress progress report & min/max information"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:137
-msgid "Use flat shading rather than gradient"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:145
-#, c-format
-msgid "Region from getWindow: %d %d %d"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:157
-#, fuzzy, c-format
-msgid "Not able to find grid3 file for [%s]"
-msgstr "के लिए"
-#: ../raster3d/r3.mkdspf/main.c:169
-#, fuzzy, c-format
-msgid "Error opening grid3 file [%s]"
-msgstr "त्रुटि"
-#: ../raster3d/r3.mkdspf/main.c:172
-#, fuzzy, c-format
-msgid "Error reading range for [%s]"
-msgstr "त्रुटि के लिए"
-#: ../raster3d/r3.mkdspf/main.c:201
-#, fuzzy, c-format
-msgid "Error opening display file [%s]"
-msgstr "त्रुटि"
-#: ../raster3d/r3.mkdspf/main.c:222
-#, c-format
-msgid "Writing %s from %s..."
-msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:81
-#, fuzzy
-msgid "3D raster map to be converted to ASCII"
-msgstr "का"
-#: ../raster3d/r3.out.ascii/main.c:88
-#, fuzzy
-msgid "Name for ASCII output file"
-msgstr "के लिए"
-#: ../raster3d/r3.out.ascii/main.c:97
-#, fuzzy
-msgid "Number of decimal places for floats"
-msgstr "का के लिए"
-#: ../raster3d/r3.out.ascii/main.c:103 ../raster/r.what/main.c:119
-#: ../raster/r.transect/main.c:125
-msgid "Char string to represent no data cell"
-msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:108 ../raster/r.out.arc/main.c:82
-#: ../raster/r.out.ascii/main.c:105
-#, fuzzy
-msgid "Suppress printing of header information"
-msgstr "का"
-#: ../raster3d/r3.out.ascii/main.c:112
-msgid "Switch the row order in output from north->south to south->north"
-msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:116
-msgid "Switch the depth order in output from bottom->top to top->bottom"
-msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:120
-msgid "Print grass6 compatible format. Flags -d and -r are ignored."
-msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:124 ../raster3d/r3.to.rast/main.c:91
-#: ../raster3d/r3.cross.rast/main.c:109
-msgid "Use 3D raster mask (if exists) with input map"
-msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:310 ../raster3d/r3.out.v5d/main.c:288
-#: ../raster3d/r3.out.vtk/main.c:378 ../raster/r.colors.out/raster_main.c:47
-#: ../raster/r.colors.out/raster3d_main.c:48
-#: ../raster/r.external.out/main.c:215 ../raster/r.out.mpeg/main.c:103
-#: ../raster/r.out.vtk/main.c:60 ../raster/r.out.arc/main.c:61
-#: ../raster/r.out.png/main.c:113 ../raster/r.out.pov/main.c:122
-#: ../raster/r.out.tiff/main.c:92 ../raster/r.out.mat/main.c:63
-#: ../raster/r.out.bin/main.c:280 ../raster/r.out.ppm/main.c:54
-#: ../raster/r.out.ascii/main.c:60 ../raster/r.out.ppm3/main.c:57
-#: ../raster/r.out.gdal/main.c:130 ../raster/r.out.vrml/main.c:48
-#: ../raster/r.out.gridatb/main.c:68 ../vector/v.colors.out/main.c:51
-#: ../vector/v.out.ascii/main.c:46 ../vector/v.out.svg/main.c:74
-#: ../vector/v.out.ogr/main.c:83 ../vector/v.out.pov/main.c:47
-#: ../vector/v.external.out/main.c:35 ../vector/v.out.dxf/main.c:57
-#: ../vector/v.out.vtk/main.c:48
-#: ../locale/scriptstrings/r.pack_to_translate.c:3
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:3
-#: ../locale/scriptstrings/tr.out.vtk_to_translate.c:5
-#: ../locale/scriptstrings/v.out.gps_to_translate.c:3
-#: ../locale/scriptstrings/tr.export_to_translate.c:5
-msgid "export"
-msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:312
-#, fuzzy
-msgid "Converts a 3D raster map layer into a ASCII text file."
-msgstr "a पाठ"
-#: ../raster3d/r3.out.ascii/main.c:343
-#, fuzzy, c-format
-msgid "Error opening 3d raster map <%s>"
-msgstr "त्रुटि"
-#: ../raster3d/r3.out.ascii/main.c:375
-#, fuzzy
-msgid "Unable to close new ASCII file"
-msgstr "के लिए"
-#: ../raster3d/r3.out.v5d/main.c:72
-msgid "3D raster map to be converted to Vis5D (V5D) file"
-msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:79
-#, fuzzy
-msgid "Name for V5D output file"
-msgstr "के लिए"
-#: ../raster3d/r3.out.v5d/main.c:149
-#, c-format
-msgid "Vis5D allows %d columns, %d columns found"
-msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:152
-#, c-format
-msgid "Vis5D allows %d rows, %d rows found"
-msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:259
-#, fuzzy, c-format
-msgid "Unable to create V5D file <%s>"
-msgstr "i n"
-#: ../raster3d/r3.out.v5d/main.c:264
-#, fuzzy
-msgid "Failed writing V5D file"
-msgstr "का"
-#: ../raster3d/r3.out.v5d/main.c:290
-#, fuzzy
-msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
-#: ../raster3d/r3.out.v5d/main.c:297
-#, fuzzy
-msgid "Use map coordinates instead of xyz coordinates"
-msgstr "का"
-#: ../raster3d/r3.to.rast/main.c:80
-#, fuzzy
-msgid "3D raster map(s) to be converted to 2D raster slices"
-msgstr "संरचना"
-#: ../raster3d/r3.to.rast/main.c:86
-#, fuzzy
-msgid "Basename for resultant raster slice maps"
-msgstr "के लिए"
-#: ../raster3d/r3.to.rast/main.c:96
-msgid "Use the same resolution as the input 3D raster map for the 2D output maps, independent of the current region settings"
-msgstr ""
-#: ../raster3d/r3.to.rast/main.c:209
-msgid "Converts 3D raster maps to 2D raster maps"
-msgstr ""
-#: ../raster3d/r3.to.rast/main.c:218
-#, fuzzy, c-format
-msgid "Open 3D raster map <%s>"
-msgstr "खोलें n"
-#: ../raster3d/r3.to.rast/main.c:236 ../raster3d/r3.to.rast/main.c:260
-#, fuzzy, c-format
-msgid "Error opening 3D raster map <%s>"
-msgstr "त्रुटि"
-#: ../raster3d/r3.to.rast/main.c:270 ../raster3d/r3.out.vtk/main.c:450
-msgid "The 2D and 3D region settings are different. Using the 2D window settings to adjust the 2D part of the 3D region."
-msgstr ""
-#: ../raster3d/r3.to.rast/main.c:294 ../raster/r.gwflow/main.c:366
-#: ../raster/r.to.rast3/main.c:244 ../raster/r.li/r.li.daemon/list.c:49
-#: ../imagery/i.smap/multialloc.c:115 ../vector/v.net.centrality/main.c:288
-#: ../vector/v.net.centrality/main.c:293 ../vector/v.net.centrality/main.c:299
-#: ../vector/v.net.centrality/main.c:305 ../vector/v.net.centrality/main.c:311
-#: ../vector/v.net.distance/main.c:184 ../vector/v.mapcalc/list.c:54
-#: ../vector/v.mapcalc/list.c:501 ../vector/v.mkgrid/write_grid.c:131
-#: ../vector/v.net.flow/main.c:227 ../vector/v.surf.rst/main.c:786
-#: ../vector/v.net.timetable/main.c:390 ../vector/v.net.timetable/main.c:400
-#: ../vector/v.net.allpairs/main.c:194 ../vector/v.net.allpairs/main.c:198
-#: ../vector/v.net.components/main.c:163 ../vector/v.generalize/matrix.c:145
-#: ../vector/v.generalize/network.c:94 ../vector/v.generalize/network.c:129
-#: ../vector/v.generalize/smoothing.c:95
-#: ../vector/v.generalize/smoothing.c:152
-#: ../vector/v.generalize/smoothing.c:253
-#: ../vector/v.generalize/smoothing.c:377
-#: ../vector/v.generalize/smoothing.c:406
-#: ../vector/v.generalize/smoothing.c:410
-#: ../vector/v.generalize/smoothing.c:414
-#: ../vector/v.generalize/smoothing.c:418
-#: ../vector/v.generalize/smoothing.c:422
-#: ../vector/v.generalize/smoothing.c:426
-#: ../vector/v.generalize/smoothing.c:430
-#: ../vector/v.generalize/simplification.c:33
-#: ../vector/v.generalize/simplification.c:40
-#: ../vector/v.generalize/simplification.c:309
-#: ../vector/v.generalize/simplification.c:317
-#: ../vector/v.generalize/simplification.c:341
-#: ../vector/v.net.connectivity/main.c:184
-#: ../vector/v.net.connectivity/main.c:200 ../db/drivers/postgres/listdb.c:73
-#: ../db/drivers/postgres/listtab.c:90
-#, fuzzy
-msgid "Out of memory"
-msgstr "का"
-#: ../raster3d/r3.to.rast/main.c:296
-#, fuzzy, c-format
-msgid "Creating %i raster maps"
-msgstr "बनाया जा रहा है i n"
-#: ../raster3d/r3.to.rast/main.c:302
-#, fuzzy, c-format
-msgid "Raster map %i Filename: %s"
-msgstr "i n"
-#: ../raster3d/r3.to.rast/main.c:307
-#, fuzzy, c-format
-msgid "Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
-msgstr "i n"
-#: ../raster3d/r3.cross.rast/main.c:90
-#, fuzzy
-msgid "Input 3D raster map for cross section."
-msgstr "छापें"
-#: ../raster3d/r3.cross.rast/main.c:97
-msgid "2D elevation map used to create the cross section map"
-msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:104
-#, fuzzy
-msgid "Resulting cross section 2D raster map"
-msgstr "का"
-#: ../raster3d/r3.cross.rast/main.c:232
-msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map"
-msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:258
-msgid "The 2D and 3D region settings are different. Using the 3D raster map settings to adjust the 2D region."
-msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:301
-#, fuzzy
-msgid "Output map already exists. Will be overwritten!"
-msgstr "i n"
-#: ../raster3d/r3.cross.rast/main.c:337
-#, fuzzy
-msgid "Wrong 3D raster datatype! Cannot create raster map"
-msgstr "डाटाटाइप."
-#: ../raster3d/r3.out.vtk/errorHandling.c:105
-#, fuzzy
-msgid "Unable to close input raster maps"
-msgstr "का"
-#: ../raster3d/r3.out.vtk/writeVTKData.c:122
-#, fuzzy
-msgid "write_vtk_points: Writing point coordinates"
-msgstr "बिन्दु"
-#: ../raster3d/r3.out.vtk/writeVTKData.c:256
-#, fuzzy
-msgid "write_vtk_unstructured_grid_cells: Writing the cells"
-msgstr "बिन्दु"
-#: ../raster3d/r3.out.vtk/writeVTKData.c:335
-#, fuzzy, c-format
-msgid "write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-ascii file"
-msgstr "i i i"
-#: ../raster3d/r3.out.vtk/writeVTKData.c:441
-#, fuzzy
-msgid "Wrong 3d raster map values! Values should in between 0 and 255!\n"
-msgstr "n"
-#: ../raster3d/r3.out.vtk/parameters.c:30
-msgid "RASTER3D map(s) to be converted to VTK-ASCII data format"
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:34 ../raster/r.out.vtk/parameters.c:41
-#, fuzzy
-msgid "Name for VTK-ASCII output file"
-msgstr "के लिए"
-#: ../raster3d/r3.out.vtk/parameters.c:41
-#, fuzzy
-msgid "Float value to represent no data cell/points"
-msgstr "फ्लोट"
-#: ../raster3d/r3.out.vtk/parameters.c:47
-#, fuzzy
-msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
-msgstr "का है"
-#: ../raster3d/r3.out.vtk/parameters.c:56
-#, fuzzy
-msgid "top surface 2D raster map"
-msgstr "का"
-#: ../raster3d/r3.out.vtk/parameters.c:65
-#, fuzzy
-msgid "bottom surface 2D raster map"
-msgstr "बेस"
-#: ../raster3d/r3.out.vtk/parameters.c:71
-msgid "Create 3d elevation output with a top and a bottom surface, both raster maps are required."
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:82
-#, fuzzy
-msgid "Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
-msgstr "जी"
-#: ../raster3d/r3.out.vtk/parameters.c:92
-#, fuzzy
-msgid "Three (x,y,z) 3D raster maps to create vector values [xmap,ymap,zmap]"
-msgstr "जी"
-#: ../raster3d/r3.out.vtk/parameters.c:98 ../raster/r.out.vtk/parameters.c:96
-#: ../vector/v.out.vtk/main.c:77
-#, fuzzy
-msgid "Scale factor for elevation"
-msgstr "के लिए"
-#: ../raster3d/r3.out.vtk/parameters.c:111
-#: ../raster/r.out.vtk/parameters.c:108 ../raster/r.out.ascii/main.c:86
-#: ../display/d.rast.num/main.c:104 ../vector/v.out.ascii/args.c:67
-#: ../vector/v.out.vtk/main.c:71
-#, fuzzy
-msgid "Number of significant digits (floating point only)"
-msgstr "का बिन्दु"
-#: ../raster3d/r3.out.vtk/parameters.c:116
-msgid "Use 3D raster mask (if exists) with input maps"
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:121
-#, fuzzy
-msgid "Scale factor effects the origin"
-msgstr "ओरिजिन"
-#: ../raster3d/r3.out.vtk/parameters.c:127
-#: ../raster/r.out.vtk/parameters.c:138 ../vector/v.out.vtk/main.c:90
-#: ../locale/scriptstrings/tr.out.vtk_to_translate.c:13
-msgid "Correct the coordinates to fit the VTK-OpenGL precision"
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:133
-msgid "Do not convert the top-bottom resolution in case of lat long projection to meters"
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:117
-msgid "Specify top and bottom map"
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:124
-#, fuzzy, c-format
-msgid "Top cell map <%s> not found"
-msgstr "नहीं"
-#: ../raster3d/r3.out.vtk/main.c:133
-#, fuzzy, c-format
-msgid "Bottom cell map <%s> not found"
-msgstr "नहीं n"
-#: ../raster3d/r3.out.vtk/main.c:152
-#, fuzzy, c-format
-msgid "3D raster map RGB map <%s> not found"
-msgstr "नहीं"
-#: ../raster3d/r3.out.vtk/main.c:155
-#, fuzzy
-msgid "Please provide three RGB 3D raster maps"
-msgstr "के लिए"
-#: ../raster3d/r3.out.vtk/main.c:165
-#, fuzzy, c-format
-msgid "3D vector map <%s> not found"
-msgstr "नहीं"
-#: ../raster3d/r3.out.vtk/main.c:168
-msgid "Please provide three G3D vector maps [x,y,z]"
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:175
-msgid "No 3D raster data, RGB or xyz-vector maps are provided! Will only write the geometry."
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:209
-#, fuzzy
-msgid "No RGB Data will be created."
-msgstr "का."
-#: ../raster3d/r3.out.vtk/main.c:294
-#, fuzzy
-msgid "No vector data will be created."
-msgstr "का"
-#: ../raster3d/r3.out.vtk/main.c:380
-#, fuzzy
-msgid "Converts 3D raster maps into the VTK-ASCII format."
-msgstr "a पाठ"
-#: ../raster3d/r3.out.vtk/main.c:391
-msgid "failed to interpret dp as an integer"
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:393 ../raster/r.out.ascii/main.c:126
-msgid "dp has to be from 0 to 20"
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:541
-#, fuzzy
-msgid "Unable to close 3D raster map, the VTK file may be incomplete"
-msgstr "के लिए."
-#: ../raster3d/r3.out.vtk/main.c:556
-#, fuzzy
-msgid "Unable to close VTK-ASCII file"
-msgstr "के लिए"
-#: ../raster3d/r3.out.vtk/writeVTKHead.c:40
-#, fuzzy
-msgid "write_vtk_structured_point_header: Writing VTKStructuredPoint-Header"
-msgstr "बिन्दु"
-#: ../raster3d/r3.out.vtk/writeVTKHead.c:96
-#, fuzzy
-msgid "write_vtk_structured_grid_header: Writing VTKStructuredGrid-Header"
-msgstr "बिन्दु"
-#: ../raster3d/r3.out.vtk/writeVTKHead.c:118
-#, fuzzy
-msgid "write_vtk_unstructured_grid_header: Writing VTKUnstructuredGrid-Header"
-msgstr "बिन्दु"
-#: ../raster3d/r3.in.ascii/main.c:87
-#, fuzzy
-msgid "ASCII raster map to be imported"
-msgstr "का"
-#: ../raster3d/r3.in.ascii/main.c:98
-msgid "String representing NULL value data cell (use 'none' if no such value)"
-msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:188
-#, fuzzy, c-format
-msgid "Unsupported GRASS version %s"
-msgstr "अज्ञात क़िस्म"
-#: ../raster3d/r3.in.ascii/main.c:231
-#, c-format
-msgid "Loading data ...  (%dx%dx%d)"
-msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:264
-msgid "End of file reached while still loading data."
-msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:276
-#, fuzzy
-msgid "Invalid value detected."
-msgstr "के लिए थीटा"
-#: ../raster3d/r3.in.ascii/main.c:293
-#, c-format
-msgid "Data exists in input file after fully importing expected data.  [%.4f ...]"
-msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:327 ../raster/r.external/main.c:56
-#: ../raster/r.in.gridatb/main.c:46 ../raster/r.in.png/main.c:520
-#: ../raster/r.in.xyz/main.c:161 ../raster/r.in.arc/main.c:61
-#: ../raster/r.in.bin/main.c:236 ../raster/r.in.lidar/main.c:162
-#: ../raster/r.in.mat/main.c:92 ../raster/r.in.gdal/main.c:82
-#: ../raster/r.in.poly/main.c:30 ../raster/r.in.ascii/main.c:70
-#: ../vector/v.in.ogr/main.c:122 ../vector/v.in.dwg/main.c:83
-#: ../vector/v.in.ascii/main.c:49 ../vector/v.external/main.c:49
-#: ../vector/v.convert/main.c:37 ../vector/v.in.sites/main.c:58
-#: ../vector/v.in.dxf/main.c:65 ../vector/v.in.db/main.c:53
-#: ../vector/v.in.lidar/main.c:154
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:3
-#: ../locale/scriptstrings/tr.import_to_translate.c:5
-#: ../locale/scriptstrings/r.unpack_to_translate.c:3
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:3
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:3
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:3
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:3
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:3
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:4
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:3
-#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:4
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:3
-#: ../locale/scriptstrings/v.convert.all_to_translate.c:3
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:3
-#, fuzzy
-msgid "import"
-msgstr "सदिश"
-#: ../raster3d/r3.in.ascii/main.c:329
-#, fuzzy
-msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
-msgstr "a पाठ a "
-#: ../raster3d/r3.in.ascii/main.c:372
-#, fuzzy
-msgid "Unable to close ASCII file"
-msgstr "के लिए"
-#: ../raster3d/r3.stats/main.c:569 ../raster/r.mode/main.c:56
-#: ../raster/r.cross/main.c:74 ../raster/r.quant/main.c:49
-#: ../raster/r.statistics/main.c:56 ../raster/r.statistics3/main.c:390
-#: ../raster/r.mfilter/main.c:58 ../raster/r.statistics2/main.c:102
-#: ../raster/r.clump/main.c:47 ../raster/r.kappa/main.c:69
-#: ../raster/r.quantile/main.c:257 ../raster/r.support.stats/main.c:39
-#: ../raster/r.report/main.c:67 ../raster/r.stats/main.c:103
-#: ../raster/r.univar/r.univar_main.c:97
-#: ../raster/r.univar/r3.univar_main.c:100
-#: ../raster/r.regression.line/main.c:47 ../raster/r.surf.area/main.c:78
-#: ../raster/r.neighbors/main.c:119 ../raster/r.coin/main.c:67
-#: ../raster/r.texture/main.c:103 ../raster/r.covar/main.c:52
-#: ../imagery/i.cca/main.c:85 ../display/d.histogram/main.c:86
-#: ../vector/v.random/main.c:86 ../vector/v.univar/main.c:64
-#: ../vector/v.outlier/main.c:69 ../vector/v.kcv/main.c:68
-#: ../vector/v.qcount/main.c:61 ../vector/v.normal/main.c:75
-#: ../vector/v.perturb/main.c:63 ../vector/v.class/main.c:46
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:4
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:3
-#: ../locale/scriptstrings/v.report_to_translate.c:4
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:3
-#: ../locale/scriptstrings/tr.univar_to_translate.c:4
-#: ../locale/scriptstrings/i.oif_to_translate.c:4
-#, fuzzy
-msgid "statistics"
-msgstr "वस्तु."
-#: ../raster3d/r3.stats/main.c:570
-#, fuzzy
-msgid "Generates volume statistics for 3D raster maps."
-msgstr "के लिए."
-#: ../raster3d/r3.stats/main.c:581
-#, fuzzy
-msgid "Number of subranges to collect stats from"
-msgstr "का"
-#: ../raster3d/r3.stats/main.c:587
-msgid "Calculate statistics based on equal value groups"
-msgstr ""
-#: ../raster3d/r3.stats/main.c:607
-#, fuzzy
-msgid "The number of subranges has to be equal or greater than 1"
-msgstr "संख्या का"
-#: ../raster3d/r3.stats/main.c:666
-#, fuzzy
-msgid "Sort non-null values"
-msgstr "ओवरले"
-#: ../misc/m.nviz.script/main.c:74
-msgid "Creates fly-through script to run in NVIZ."
-msgstr ""
-#: ../misc/m.nviz.script/main.c:79
-#, fuzzy
-msgid "Name of output script"
-msgstr "का"
-#: ../misc/m.nviz.script/main.c:85
-#, fuzzy
-msgid "Prefix of output images (default = NVIZ)"
-msgstr "उपसर्ग का छवियाँ"
-#: ../misc/m.nviz.script/main.c:93
-#, fuzzy
-msgid "Route coordinates (east,north)"
-msgstr "पूर्व उत्तर"
-#: ../misc/m.nviz.script/main.c:99
-msgid "Camera layback distance (in map units)"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:105
-#, fuzzy
-msgid "Camera height above terrain"
-msgstr "ऊंचाई"
-#: ../misc/m.nviz.script/main.c:111
-#, fuzzy
-msgid "Number of frames"
-msgstr "का फ्रेम्स"
-#: ../misc/m.nviz.script/main.c:117
-#, fuzzy
-msgid "Start frame number (default=0)"
-msgstr "संख्या"
-#: ../misc/m.nviz.script/main.c:122
-#, fuzzy
-msgid "Full render -- Save images"
-msgstr "सहेजें छवियाँ"
-#: ../misc/m.nviz.script/main.c:126
-#, fuzzy
-msgid "Fly at constant elevation (ht)"
-msgstr "पर"
-#: ../misc/m.nviz.script/main.c:131
-msgid "Include command in the script to output a KeyFrame file"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:135
-#, fuzzy
-msgid "Render images off-screen"
-msgstr "रेंडर छवियाँ"
-#: ../misc/m.nviz.script/main.c:139
-msgid "Enable vector and sites drawing"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:147
-#, fuzzy
-msgid "Either -i flag and/or route parameter must be used"
-msgstr "i"
-#: ../misc/m.nviz.script/main.c:171
-#, fuzzy
-msgid "Off-screen only available with full render mode"
-msgstr "बंद"
-#: ../misc/m.nviz.script/main.c:201 ../misc/m.transform/main.c:276
-#: ../raster/r.profile/main.c:146 ../raster/r.category/main.c:178
-#: ../raster/r.recode/main.c:89 ../raster/r.out.arc/main.c:129
-#: ../raster/r.out.ascii/main.c:167 ../raster/r.out.ppm3/main.c:127
-#: ../general/g.pnmcomp/main.c:241 ../general/g.pnmcomp/main.c:258
-#: ../vector/v.net/main.c:98 ../vector/v.out.ascii/main.c:100
-#: ../vector/v.edit/main.c:76 ../vector/v.out.vtk/main.c:167
-#, fuzzy, c-format
-msgid "Unable to open file <%s>"
-msgstr "का"
-#: ../misc/m.nviz.script/main.c:249
-#, fuzzy, c-format
-msgid "You must provide at least four points %d"
-msgstr "पर"
-#: ../misc/m.nviz.script/main.c:323
-#, c-format
-msgid "Created NVIZ script <%s>."
-msgstr ""
-#: ../misc/m.nviz.script/main.c:439
-msgid "Skipping this point, selected point is outside region. Perhaps the camera setback distance puts it beyond the edge?"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:51
-msgid "Use draw mode for all loaded surfaces"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:52 ../misc/m.nviz.image/args.c:130
-#: ../misc/m.nviz.image/args.c:139 ../misc/m.nviz.image/args.c:146
-#: ../misc/m.nviz.image/args.c:152 ../misc/m.nviz.image/args.c:160
-#: ../misc/m.nviz.image/args.c:169 ../misc/m.nviz.image/args.c:179
-#: ../misc/m.nviz.image/args.c:187 ../misc/m.nviz.image/args.c:197
-#: ../misc/m.nviz.image/args.c:205 ../misc/m.nviz.image/args.c:215
-msgid "Surfaces"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:89
-#, fuzzy
-msgid "Name for output image file (without extension)"
-msgstr "का"
-#: ../misc/m.nviz.image/args.c:90 ../misc/m.nviz.image/args.c:104
-#: ../misc/m.nviz.image/args.c:114
-#, fuzzy
-msgid "Image"
-msgstr "समूह"
-#: ../misc/m.nviz.image/args.c:102
-#, fuzzy
-msgid "Graphics file format"
-msgstr "है n"
-#: ../misc/m.nviz.image/args.c:112
-#, fuzzy
-msgid "Size (width, height) of output image"
-msgstr "का"
-#: ../misc/m.nviz.image/args.c:129
-#, fuzzy
-msgid "Name of raster map(s) for elevation"
-msgstr "का"
-#: ../misc/m.nviz.image/args.c:138
-#, fuzzy
-msgid "Elevation value(s)"
-msgstr "का"
-#: ../misc/m.nviz.image/args.c:145
-#, fuzzy
-msgid "Name of raster map(s) for color"
-msgstr "का समूह"
-#: ../misc/m.nviz.image/args.c:151
-#, fuzzy
-msgid "Color value(s)"
-msgstr "नहीं"
-#: ../misc/m.nviz.image/args.c:159
-#, fuzzy
-msgid "Name of raster map(s) for mask"
-msgstr "का"
-#: ../misc/m.nviz.image/args.c:168
-#, fuzzy
-msgid "Name of raster map(s) for transparency"
-msgstr "का"
-#: ../misc/m.nviz.image/args.c:178
-msgid "Transparency value(s)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:186
-#, fuzzy
-msgid "Name of raster map(s) for shininess"
-msgstr "का रखे हुए"
-#: ../misc/m.nviz.image/args.c:196
-msgid "Shininess value(s)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:204
-#, fuzzy
-msgid "Name of raster map(s) for emission"
-msgstr "का"
-#: ../misc/m.nviz.image/args.c:214
-msgid "Emission value(s)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:228
-#, fuzzy
-msgid "Draw mode"
-msgstr "हैंडहेल्ड"
-#: ../misc/m.nviz.image/args.c:231 ../misc/m.nviz.image/args.c:242
-#: ../misc/m.nviz.image/args.c:253 ../misc/m.nviz.image/args.c:265
-#: ../misc/m.nviz.image/args.c:277 ../misc/m.nviz.image/args.c:286
-#: ../misc/m.nviz.image/args.c:296 ../misc/m.nviz.image/args.c:584
-#: ../misc/m.nviz.image/args.c:596
-msgid "Draw"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:240
-#, fuzzy
-msgid "Fine resolution"
-msgstr "पूर्व पश्चिम "
-#: ../misc/m.nviz.image/args.c:251
-#, fuzzy
-msgid "Coarse resolution"
-#: ../misc/m.nviz.image/args.c:262
-#, fuzzy
-msgid "Draw style"
-msgstr "विशेषता"
-#: ../misc/m.nviz.image/args.c:274
-msgid "Shading"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:283
-#, fuzzy
-msgid "Wire color"
-msgstr "किनारा"
-#: ../misc/m.nviz.image/args.c:295
-#, fuzzy
-msgid "Surface position"
-msgstr "नहीं n"
-#: ../misc/m.nviz.image/args.c:307
-#, fuzzy
-msgid "Name of line vector overlay map(s)"
-msgstr "का"
-#: ../misc/m.nviz.image/args.c:308 ../misc/m.nviz.image/args.c:315
-#: ../misc/m.nviz.image/args.c:327 ../misc/m.nviz.image/args.c:336
-#: ../misc/m.nviz.image/args.c:345 ../misc/m.nviz.image/args.c:352
-#: ../misc/m.nviz.image/args.c:364 ../misc/m.nviz.image/args.c:374
-#: ../misc/m.nviz.image/args.c:386
-#, fuzzy
-msgid "Vector lines"
-msgstr "नहीं"
-#: ../misc/m.nviz.image/args.c:314 ../misc/m.nviz.image/args.c:404
-#, fuzzy
-msgid "Layer number or name for thematic mapping"
-msgstr "का"
-#: ../misc/m.nviz.image/args.c:326
-#, fuzzy
-msgid "Vector line width"
-msgstr "लकीर की चौड़ाई"
-#: ../misc/m.nviz.image/args.c:334 ../misc/m.nviz.image/args.c:443
-#, fuzzy
-msgid "Name of width definition column"
-msgstr "का"
-#: ../misc/m.nviz.image/args.c:342
-#, fuzzy
-msgid "Vector line color"
-msgstr "सेट"
-#: ../misc/m.nviz.image/args.c:350 ../misc/m.nviz.image/args.c:459
-#, fuzzy
-msgid "Name of color definition column"
-msgstr "का"
-#: ../misc/m.nviz.image/args.c:361
-msgid "Vector line display mode"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:373
-msgid "Vector line height"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:385
-#, fuzzy
-msgid "Vector lines position"
-#: ../misc/m.nviz.image/args.c:397
-#, fuzzy
-msgid "Name of point vector overlay map(s)"
-msgstr "का"
-#: ../misc/m.nviz.image/args.c:398 ../misc/m.nviz.image/args.c:405
-#: ../misc/m.nviz.image/args.c:417 ../misc/m.nviz.image/args.c:426
-#: ../misc/m.nviz.image/args.c:436 ../misc/m.nviz.image/args.c:445
-#: ../misc/m.nviz.image/args.c:454 ../misc/m.nviz.image/args.c:461
-#: ../misc/m.nviz.image/args.c:474 ../misc/m.nviz.image/args.c:481
-#: ../misc/m.nviz.image/args.c:491
-#, fuzzy
-msgid "Vector points"
-msgstr "नहीं"
-#: ../misc/m.nviz.image/args.c:416
-#, fuzzy
-msgid "Icon size"
-msgstr "आकार "
-#: ../misc/m.nviz.image/args.c:424
-#, fuzzy
-msgid "Name of size definition column"
-msgstr "का"
-#: ../misc/m.nviz.image/args.c:435
-#, fuzzy
-msgid "Icon width"
-#: ../misc/m.nviz.image/args.c:451
-#, fuzzy
-msgid "Icon color"
-msgstr "n"
-#: ../misc/m.nviz.image/args.c:470
-#, fuzzy
-msgid "Icon marker"
-msgstr "आकार "
-#: ../misc/m.nviz.image/args.c:479
-#, fuzzy
-msgid "Name of marker definition column"
-msgstr "का"
-#: ../misc/m.nviz.image/args.c:490
-#, fuzzy
-msgid "Vector points position"
-msgstr "नहीं"
-#: ../misc/m.nviz.image/args.c:507
-#, fuzzy
-msgid "Viewpoint position (x,y model coordinates)"
-msgstr "ज़ेड"
-#: ../misc/m.nviz.image/args.c:508 ../misc/m.nviz.image/args.c:519
-#: ../misc/m.nviz.image/args.c:529 ../misc/m.nviz.image/args.c:541
-#: ../misc/m.nviz.image/args.c:562
-msgid "Viewpoint"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:518
-#, fuzzy
-msgid "Viewpoint height (in map units)"
-msgstr "त्रुटि"
-#: ../misc/m.nviz.image/args.c:528
-msgid "Viewpoint field of view (in degrees)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:540
-#, fuzzy
-msgid "Viewpoint twist angle (in degrees)"
-msgstr "कोण कोण"
-#: ../misc/m.nviz.image/args.c:552 ../raster/r.out.vrml/main.c:72
-#, fuzzy
-msgid "Vertical exaggeration"
-msgstr "खड़ा"
-#: ../misc/m.nviz.image/args.c:561
-#, fuzzy
-msgid "Focus to point on surface (from SW corner in map units)"
-msgstr "का के लिए"
-#: ../misc/m.nviz.image/args.c:571 ../misc/m.nviz.image/args.c:606
-#: ../misc/m.nviz.image/args.c:618 ../misc/m.nviz.image/args.c:628
-#: ../misc/m.nviz.image/args.c:636 ../misc/m.nviz.image/args.c:644
-#: ../misc/m.nviz.image/args.c:653 ../misc/m.nviz.image/args.c:663
-#: ../misc/m.nviz.image/args.c:671 ../misc/m.nviz.image/args.c:681
-#: ../misc/m.nviz.image/args.c:693 ../misc/m.nviz.image/args.c:703
-#: ../misc/m.nviz.image/args.c:714
-#, fuzzy
-msgid "Volumes"
-msgstr "नहीं"
-#: ../misc/m.nviz.image/args.c:581
-msgid "Volume draw mode"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:593
-msgid "Volume shading"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:605
-#, fuzzy
-msgid "Volume position"
-msgstr "नहीं n"
-#: ../misc/m.nviz.image/args.c:616
-msgid "Volume resolution"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:627
-#, fuzzy
-msgid "Isosurface level"
-msgstr "आइसोसरफेस"
-#: ../misc/m.nviz.image/args.c:635
-#, fuzzy
-msgid "Name of volume for isosurface color"
-msgstr "के लिए"
-#: ../misc/m.nviz.image/args.c:643
-#, fuzzy
-msgid "Isosurface color"
-msgstr "आइसोसरफेस"
-#: ../misc/m.nviz.image/args.c:652
-#, fuzzy
-msgid "Name of 3D raster map(s) for isosurface transparency"
-msgstr "का"
-#: ../misc/m.nviz.image/args.c:662
-msgid "Transparency value(s)for isosurfaces"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:670
-#, fuzzy
-msgid "Name of 3D raster map(s) for shininess"
-#: ../misc/m.nviz.image/args.c:680
-#, fuzzy
-msgid "Shininess value(s) for isosurfaces"
-msgstr "के लिए ज़ेड"
-#: ../misc/m.nviz.image/args.c:692
-msgid "Volume slice parallel to given axis (x, y, z)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:702
-#, fuzzy
-msgid "Volume slice position"
-msgstr "नहीं n"
-#: ../misc/m.nviz.image/args.c:713
-msgid "Volume slice transparency"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:730
-#, fuzzy
-msgid "Light position (x,y,z model coordinates)"
-msgstr "ज़ेड"
-#: ../misc/m.nviz.image/args.c:731 ../misc/m.nviz.image/args.c:737
-#: ../misc/m.nviz.image/args.c:746 ../misc/m.nviz.image/args.c:756
-msgid "Lighting"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:736
-#, fuzzy
-msgid "Light color"
-msgstr "उभारें के लिए पाठ के लिए"
-#: ../misc/m.nviz.image/args.c:745
-msgid "Light brightness"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:755
-msgid "Light ambient"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:769
-msgid "Cutting plane index (0-5)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:770 ../misc/m.nviz.image/args.c:779
-#: ../misc/m.nviz.image/args.c:788 ../misc/m.nviz.image/args.c:799
-#: ../misc/m.nviz.image/args.c:810
-#, fuzzy
-msgid "Cutting planes"
-msgstr "नक़ल"
-#: ../misc/m.nviz.image/args.c:778
-#, fuzzy
-msgid "Cutting plane x,y,z coordinates"
-msgstr "n"
-#: ../misc/m.nviz.image/args.c:789
-msgid "Cutting plane rotation along the vertical axis"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:800
-#, fuzzy
-msgid "Cutting plane tilt"
-msgstr "नक़ल"
-#: ../misc/m.nviz.image/args.c:811
-msgid "Cutting plane color (between two surfaces)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:822
-msgid "nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:826
-#, fuzzy
-msgid "Fringe edges"
-msgstr "छापें"
-#: ../misc/m.nviz.image/args.c:827 ../misc/m.nviz.image/args.c:833
-#: ../misc/m.nviz.image/args.c:842
-msgid "Fringe"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:832
-#, fuzzy
-msgid "Fringe color"
-msgstr "सेट"
-#: ../misc/m.nviz.image/args.c:841
-#, fuzzy
-msgid "Fringe elevation"
-msgstr "ट्रेस"
-#: ../misc/m.nviz.image/args.c:854
-msgid "Place north arrow at given position \t(in screen coordinates from bottom left corner)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:856 ../misc/m.nviz.image/args.c:865
-#: ../misc/m.nviz.image/args.c:872
-#, fuzzy
-msgid "Decoration"
-msgstr "का"
-#: ../misc/m.nviz.image/args.c:864
-#, fuzzy
-msgid "North arrow size (in map units)"
-msgstr "आकार "
-#: ../misc/m.nviz.image/args.c:871
-#, fuzzy
-msgid "North arrow color"
-msgstr "किनारा"
-#: ../misc/m.nviz.image/args.c:921
-#, c-format
-msgid "At least one <%s> or <%s> required"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:935 ../misc/m.nviz.image/args.c:965
-#: ../misc/m.nviz.image/args.c:977 ../misc/m.nviz.image/args.c:983
-#: ../misc/m.nviz.image/args.c:989 ../misc/m.nviz.image/args.c:995
-#, c-format
-msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:971
-#, c-format
-msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:1005
-#, c-format
-msgid "Inconsistent number of attributes (<%s> %d: <%s> %d x 3)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:1010 ../misc/m.nviz.image/args.c:1015
-#: ../misc/m.nviz.image/args.c:1026 ../misc/m.nviz.image/args.c:1040
-#: ../misc/m.nviz.image/args.c:1047 ../misc/m.nviz.image/args.c:1054
-#: ../misc/m.nviz.image/args.c:1093
-#, c-format
-msgid "Inconsistent number of attributes (<%s> %d: <%s> %d)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:1033
-#, c-format
-msgid "Inconsistent number of attributes (<%s> %d: <%s> %d"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:1077 ../misc/m.nviz.image/args.c:1086
-#, c-format
-msgid "Inconsistent number of attributes (<%s> %d: <%s> %d, <%s> %d"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:1099
-#, c-format
-msgid "Inconsistent number of attributes (<%s> %d: <%s> %d x 6)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:1110
-#, c-format
-msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d, <%s> %d)"
-msgstr ""
-#: ../misc/m.nviz.image/volume.c:92 ../misc/m.nviz.image/volume.c:231
-#, fuzzy, c-format
-msgid "Error tokenize '%s'"
-msgstr "त्रुटि"
-#: ../misc/m.nviz.image/volume.c:99 ../misc/m.nviz.image/volume.c:247
-#, fuzzy, c-format
-msgid "Volume set number %d is not available"
-msgstr "सदिश नहीं"
-#: ../misc/m.nviz.image/volume.c:105
-#, fuzzy, c-format
-msgid "Unable to add isosurface (volume set %d)"
-msgstr "i n"
-#: ../misc/m.nviz.image/volume.c:113 ../misc/m.nviz.image/volume.c:131
-#: ../misc/m.nviz.image/volume.c:139 ../misc/m.nviz.image/volume.c:155
-#: ../misc/m.nviz.image/volume.c:162 ../misc/m.nviz.image/volume.c:173
-#: ../misc/m.nviz.image/volume.c:180
-#, fuzzy, c-format
-msgid "Unable to set isosurface (%d) attribute (%d) of volume %d)"
-msgstr "के लिए"
-#: ../misc/m.nviz.image/volume.c:144 ../misc/m.nviz.image/surface.c:128
-#, fuzzy, c-format
-msgid "Color attribute not defined, using default <%s>"
-msgstr "नहीं"
-#: ../misc/m.nviz.image/volume.c:242
-#, fuzzy, c-format
-msgid "Wrong name for axis: %s"
-msgstr "i n"
-#: ../misc/m.nviz.image/volume.c:253
-#, fuzzy, c-format
-msgid "Unable to add slice (volume set %d)"
-msgstr "i n"
-#: ../misc/m.nviz.image/volume.c:266
-#, fuzzy, c-format
-msgid "Unable to set slice (%d) position of volume %d"
-msgstr "के लिए"
-#: ../misc/m.nviz.image/volume.c:271
-#, fuzzy, c-format
-msgid "Unable to set slice (%d) transparency of volume %d"
-msgstr "के लिए"
-#: ../misc/m.nviz.image/cplane.c:40
-#, fuzzy, c-format
-msgid "Cutting plane number <%d> not found"
-msgstr "नहीं"
-#: ../misc/m.nviz.image/main.c:54
-msgid "Creates a 3D rendering of GIS data."
-msgstr ""
-#: ../misc/m.nviz.image/main.c:55
-msgid "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in 3D."
-msgstr ""
-#: ../misc/m.nviz.image/main.c:138
-#, c-format
-msgid "Vertical exaggeration not given, using calculated value %.0f"
-msgstr ""
-#: ../misc/m.nviz.image/main.c:150
-#, c-format
-msgid "Viewpoint height not given, using calculated value %.0f"
-msgstr ""
-#: ../misc/m.nviz.image/main.c:232
-#, fuzzy
-msgid "Unsupported output format"
-#: ../misc/m.nviz.image/main.c:234 ../imagery/i.cluster/main.c:335
-#, fuzzy, c-format
-msgid "File <%s> created."
-msgstr "n"
-#: ../misc/m.nviz.image/surface.c:67
-#, c-format
-msgid "Missing topography attribute for surface %d"
-msgstr ""
-#: ../misc/m.nviz.image/surface.c:133
-#, fuzzy, c-format
-msgid "Missing color attribute for surface %d"
-msgstr "के लिए"
-#: ../misc/m.nviz.image/surface.c:210
-#, fuzzy, c-format
-msgid "Surface id %d doesn't exist"
-msgstr "नहीं"
-#: ../misc/m.nviz.image/surface.c:257 ../misc/m.nviz.image/surface.c:264
-#, fuzzy, c-format
-msgid "Unable to set draw mode for surface id %d"
-msgstr "का a"
-#: ../misc/m.nviz.image/vector.c:258 ../misc/m.nviz.image/vector.c:267
-#: ../misc/m.nviz.image/vector.c:277 ../misc/m.nviz.image/vector.c:287
-#, fuzzy, c-format
-msgid "Column <%s> in table <%s> not found"
-msgstr "नहीं"
-#: ../misc/m.nviz.image/vector.c:262
-#, fuzzy
-msgid "Data type of color column must be character"
-msgstr "ज़ेड"
-#: ../misc/m.nviz.image/vector.c:272
-#, fuzzy
-msgid "Data type of size column must be numeric"
-msgstr "ज़ेड"
-#: ../misc/m.nviz.image/vector.c:282
-#, fuzzy
-msgid "Data type of width column must be numeric"
-msgstr "ज़ेड"
-#: ../misc/m.nviz.image/vector.c:292
-#, fuzzy
-msgid "Data type of marker column must be character"
-msgstr "ज़ेड"
-#: ../misc/m.cogo/main.c:225 ../misc/m.measure/main.c:46
-#: ../locale/scriptstrings/m.proj_to_translate.c:2
-msgid "miscellaneous"
-msgstr ""
-#: ../misc/m.cogo/main.c:226 ../raster/r.distance/main.c:39
-#: ../raster/r.grow.distance/main.c:150 ../display/d.rhumbline/main.c:44
-#: ../display/d.geodesic/main.c:44
-#, fuzzy
-msgid "distance"
-#: ../misc/m.cogo/main.c:227
-msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
-msgstr ""
-#: ../misc/m.cogo/main.c:229
-msgid "It assumes a cartesian coordinate system"
-msgstr ""
-#: ../misc/m.cogo/main.c:233
-msgid "Lines are labelled"
-msgstr ""
-#: ../misc/m.cogo/main.c:237
-msgid "Suppress warnings"
-msgstr ""
-#: ../misc/m.cogo/main.c:242
-msgid "Convert from coordinates to bearing and distance"
-msgstr ""
-#: ../misc/m.cogo/main.c:257
-#, fuzzy
-msgid "Starting coordinate pair"
-msgstr "निर्देशांक"
-#: ../misc/m.cogo/main.c:267
-#, fuzzy, c-format
-msgid "Couldn't open COGO file <%s>"
-msgstr "नहीं"
-#: ../misc/m.cogo/main.c:276
-#, fuzzy, c-format
-msgid "Couldn't open output file <%s>"
-msgstr "नहीं"
-#: ../misc/m.cogo/main.c:306 ../misc/m.cogo/main.c:309
-#, fuzzy
-msgid "Converting starting coordinate pair"
-msgstr "n"
-#: ../misc/m.cogo/main.c:325
-#, c-format
-msgid "Input parse error on line %d"
-msgstr ""
-#: ../misc/m.transform/main.c:92
-#, fuzzy, c-format
-msgid "Not enough points, %d are required"
-msgstr "के लिए"
-#: ../misc/m.transform/main.c:96
-#, fuzzy, c-format
-msgid "Error conducting transform (%d)"
-msgstr "संख्या के लिए"
-#: ../misc/m.transform/main.c:194
-msgid "Poorly placed control points"
-msgstr ""
-#: ../misc/m.transform/main.c:196
-msgid "Insufficient memory"
-msgstr ""
-#: ../misc/m.transform/main.c:198
-#, fuzzy
-msgid "Parameter error"
-msgstr "n"
-#: ../misc/m.transform/main.c:200
-#, fuzzy
-msgid "No active control points"
-msgstr "घुमाएँ"
-#: ../misc/m.transform/main.c:295
-#, fuzzy, c-format
-msgid "Invalid coordinates: [%s]"
-msgstr "के लिए"
-#: ../misc/m.transform/main.c:315 ../general/g.filename/main.c:39
-#: ../general/g.gui/main.c:36 ../general/g.access/main.c:37
-#: ../general/g.tempfile/main.c:38 ../general/g.findfile/main.c:38
-#: ../general/g.proj/main.c:62 ../general/g.mremove/main.c:61
-#: ../general/g.mapset/main.c:49 ../general/g.pnmcat/main.c:121
-#: ../general/g.cairocomp/main.c:193 ../general/g.mlist/main.c:62
-#: ../general/g.version/main.c:43 ../general/g.gisenv/main.c:38
-#: ../general/g.region/main.c:63 ../general/g.list/main.c:44
-#: ../general/g.mkfontcap/main.c:70 ../general/g.findetc/main.c:28
-#: ../general/g.setproj/main.c:78 ../general/g.remove/main.c:101
-#: ../general/g.pnmcomp/main.c:281 ../general/g.ppmtopng/main.c:117
-#: ../general/g.message/main.c:33 ../general/g.dirseps/main.c:34
-#: ../general/g.mapsets/main.c:59 ../general/g.rename/main.c:43
-#: ../general/g.copy/main.c:41
-#: ../locale/scriptstrings/g.manual_to_translate.c:2
-#: ../locale/scriptstrings/g.extension.rebuild.all_to_translate.c:3
-#: ../locale/scriptstrings/g.extension_to_translate.c:3
-msgid "general"
-msgstr ""
-#: ../misc/m.transform/main.c:316 ../raster/r.proj/main.c:148
-#: ../vector/v.proj/main.c:68 ../vector/v.transform/main.c:70
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:3
-#, fuzzy
-msgid "transformation"
-msgstr "का"
-#: ../misc/m.transform/main.c:317
-msgid "GCP"
-msgstr ""
-#: ../misc/m.transform/main.c:319
-#, fuzzy
-msgid "Computes a coordinate transformation based on the control points."
-msgstr "छवि a के लिए छवि चालू"
-#: ../misc/m.transform/main.c:328
-#, fuzzy
-msgid "Rectification polynomial order"
-msgstr "पॉलीनॉम"
-#: ../misc/m.transform/main.c:336
-msgid "idx;point index;src;source coordinates;dst;destination coordinates;fwd;forward coordinates (destination);rev;reverse coordinates (source);fxy;forward coordinates difference (destination);rxy;reverse coordinates difference (source);fd;forward error (destination);rd;reverse error (source)"
-msgstr ""
-#: ../misc/m.transform/main.c:346 ../vector/v.out.ascii/args.c:51
-msgid "Output format"
-msgstr ""
-#: ../misc/m.transform/main.c:350
-#, fuzzy
-msgid "Display summary information"
-msgstr "जानकारी"
-#: ../misc/m.transform/main.c:356
-#, fuzzy
-msgid "File containing coordinates to transform (\"-\" to read from stdin)"
-msgstr "उत्तर पूर्व"
-#: ../misc/m.transform/main.c:357
-#, fuzzy
-msgid "Local x,y coordinates to target east,north"
-#: ../misc/m.transform/main.c:361
-#, fuzzy
-msgid "Reverse transform of coords file or coeff. dump"
-msgstr "ऊंचाई के लिए"
-#: ../misc/m.transform/main.c:362
-#, fuzzy
-msgid "Target east,north coordinates to local x,y"
-msgstr "बायाँ का"
-#: ../misc/m.transform/main.c:366
-msgid "Display transform matrix coefficients"
-msgstr ""
-#: ../misc/m.measure/main.c:45
-msgid "Measures the lengths and areas of features."
-msgstr ""
-#: ../misc/m.measure/main.c:47
-msgid "measurement"
-msgstr ""
-#: ../misc/m.measure/main.c:51
-#, fuzzy
-msgid "Vertex coordinates"
-#: ../misc/m.measure/main.c:58 ../raster/r.report/parse.c:45
-msgid "Units"
-msgstr ""
-#: ../misc/m.measure/main.c:59
-#, fuzzy
-msgid "Default: location map units"
-msgstr "त्रुटि"
-#: ../misc/m.measure/main.c:63
-#, fuzzy
-msgid "Shell script style"
-msgstr "छापें"
-#: ../misc/m.measure/main.c:106
-#, fuzzy
-msgid "Length:"
-msgstr "f n"
-#: ../misc/m.measure/main.c:117
-#, fuzzy
-msgid "Area:"
-msgstr "n"
-#: ../raster/r.external/proj.c:18 ../raster/r.in.gdal/main.c:356
-#, fuzzy
-msgid "Unable to convert input raster map projection information to GRASS format for checking"
-msgstr "के लिए"
-#: ../raster/r.external/proj.c:34 ../raster/r.in.lidar/main.c:297
-#: ../raster/r.in.gdal/main.c:372 ../vector/v.in.ogr/main.c:553
-#: ../vector/v.in.lidar/main.c:381
-#, fuzzy
-msgid "Over-riding projection check"
-msgstr "नहीं n"
-#: ../raster/r.external/proj.c:42 ../raster/r.in.lidar/main.c:306
-#: ../raster/r.in.gdal/main.c:382 ../vector/v.in.ogr/main.c:562
-#: ../vector/v.in.lidar/main.c:390
-#, fuzzy
-msgid ""
-"Projection of dataset does not appear to match current location.\n"
-"\n"
-msgstr "का जोड़ा n"
-#: ../raster/r.external/proj.c:47 ../raster/r.in.gdal/main.c:387
-#, fuzzy
-msgid "Location PROJ_INFO is:\n"
-msgstr "n"
-#: ../raster/r.external/proj.c:58 ../raster/r.in.gdal/main.c:398
-msgid "Dataset PROJ_INFO is:\n"
-msgstr ""
-#: ../raster/r.external/proj.c:85 ../raster/r.in.lidar/main.c:322
-#: ../raster/r.in.lidar/main.c:329 ../raster/r.in.gdal/main.c:425
-#: ../vector/v.in.ogr/main.c:578 ../vector/v.in.ogr/main.c:585
-#: ../vector/v.in.lidar/main.c:406 ../vector/v.in.lidar/main.c:413
-#, fuzzy
-msgid "Import dataset PROJ_INFO is:\n"
-msgstr "n"
-#: ../raster/r.external/proj.c:107
-#, fuzzy
-msgid ""
-"\n"
-"You can use the -o flag to r.external to override this check and use the location definition for the dataset.\n"
-msgstr "n"
-#: ../raster/r.external/proj.c:110 ../raster/r.in.gdal/main.c:450
-#, fuzzy
-msgid "Consider generating a new location from the input dataset using the 'location' parameter.\n"
-msgstr "a सेट n"
-#: ../raster/r.external/proj.c:115 ../raster/r.in.lidar/main.c:380
-#: ../raster/r.in.gdal/main.c:455 ../vector/v.in.ogr/main.c:636
-#: ../vector/v.in.lidar/main.c:464
-#, fuzzy
-msgid "Projection of input dataset and current location appear to match"
-#: ../raster/r.external/window.c:23
-msgid "Input raster map is rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
-msgstr ""
-#: ../raster/r.external/window.c:26
-msgid "Applying horizontal flip"
-msgstr ""
-#: ../raster/r.external/window.c:30
-msgid "Applying vertical flip"
-msgstr ""
-#: ../raster/r.external/window.c:93 ../raster/r.in.gdal/main.c:635
-#: ../vector/v.in.ogr/main.c:1257
-msgid "Default region for this location updated"
-msgstr ""
-#: ../raster/r.external/window.c:96 ../raster/r.in.gdal/main.c:638
-#: ../vector/v.in.ogr/main.c:1260
-#, fuzzy
-msgid "Region for the current mapset updated"
-msgstr "के लिए."
-#: ../raster/r.external/list.c:22
-#, fuzzy
-msgid "Supported formats:"
-#: ../raster/r.external/main.c:57 ../vector/v.external/main.c:50
-#, fuzzy
-msgid "input"
-msgstr "का"
-#: ../raster/r.external/main.c:58 ../raster/r.external.out/main.c:217
-#: ../vector/v.external/main.c:51 ../vector/v.external.out/main.c:37
-msgid "external"
-msgstr ""
-#: ../raster/r.external/main.c:60
-#, fuzzy
-msgid "Links GDAL supported raster data as a pseudo GRASS raster map."
-msgstr "आयात a."
-#: ../raster/r.external/main.c:63
-#, fuzzy
-msgid "Name of raster file to be linked"
-msgstr "सदिश"
-#: ../raster/r.external/main.c:65 ../raster/r.external/main.c:73
-#: ../raster/r.external/main.c:82 ../raster/r.topmodel/main.c:70
-#: ../raster/r.topmodel/main.c:78 ../raster/r.in.xyz/main.c:191
-#: ../raster/r.in.xyz/main.c:200 ../raster/r.in.xyz/main.c:208
-#: ../raster/r.in.xyz/main.c:216 ../raster/simwe/r.sim.sediment/main.c:153
-#: ../raster/simwe/r.sim.sediment/main.c:161
-#: ../raster/simwe/r.sim.water/main.c:131
-#: ../raster/simwe/r.sim.water/main.c:140
-#: ../raster/simwe/r.sim.water/main.c:147
-#: ../raster/simwe/r.sim.water/main.c:156
-#: ../raster/simwe/r.sim.water/main.c:162
-#: ../raster/simwe/r.sim.water/main.c:170
-#: ../raster/simwe/r.sim.water/main.c:177 ../vector/v.edit/args.c:90
-#: ../vector/v.edit/args.c:199
-#, fuzzy
-msgid "Input"
-msgstr "का"
-#: ../raster/r.external/main.c:69
-#, fuzzy
-msgid "Name of non-file GDAL data source"
-msgstr "का"
-#: ../raster/r.external/main.c:81
-#, fuzzy
-msgid "Band to select (default: all)"
-msgstr "है सभी"
-#: ../raster/r.external/main.c:89 ../raster/r.in.arc/main.c:88
-#: ../raster/r.in.bin/main.c:279 ../raster/r.in.gdal/main.c:119
-#: ../raster/r.in.poly/main.c:45 ../raster/r.in.ascii/main.c:88
-#, fuzzy
-msgid "Title for resultant raster map"
-msgstr "के लिए"
-#: ../raster/r.external/main.c:90 ../raster/r.in.gdal/main.c:120
-#: ../raster/r.in.gdal/main.c:128 ../imagery/i.landsat.toar/main.c:92
-#: ../imagery/i.landsat.toar/main.c:108 ../imagery/i.landsat.toar/main.c:118
-#: ../imagery/i.landsat.toar/main.c:127 ../imagery/i.landsat.toar/main.c:135
-#: ../imagery/i.landsat.toar/main.c:144 ../imagery/i.landsat.toar/main.c:200
-msgid "Metadata"
-msgstr ""
-#: ../raster/r.external/main.c:94 ../raster/r.external.out/main.c:250
-#: ../raster/r.in.gdal/main.c:150 ../vector/v.in.ogr/main.c:226
-#: ../vector/v.external.out/args.c:33
-msgid "List supported formats and exit"
-msgstr ""
-#: ../raster/r.external/main.c:95 ../raster/r.external.out/main.c:251
-#: ../raster/r.external.out/main.c:262 ../raster/r.colors/edit_colors.c:110
-#: ../raster/r.stats/main.c:147 ../raster/r.stats/main.c:152
-#: ../raster/r.stats/main.c:157 ../raster/r.stats/main.c:163
-#: ../raster/r.stats/main.c:168 ../raster/r.stats/main.c:173
-#: ../raster/r.stats/main.c:178 ../raster/r.stats/main.c:183
-#: ../raster/r.sunmask/main.c:229 ../raster/r.sunmask/main.c:235
-#: ../raster/r.in.gdal/main.c:151 ../raster/r.out.gdal/main.c:135
-#: ../imagery/i.group/main.c:80 ../imagery/i.group/main.c:86
-#: ../display/d.mon/main.c:90 ../display/d.mon/main.c:95
-#: ../display/d.mon/main.c:100 ../general/g.proj/main.c:78
-#: ../general/g.proj/main.c:84 ../general/g.proj/main.c:90
-#: ../general/g.proj/main.c:96 ../general/g.proj/main.c:102
-#: ../general/g.proj/main.c:113 ../general/g.proj/main.c:118
-#: ../general/g.mapset/main.c:89 ../general/g.mapset/main.c:95
-#: ../general/g.mlist/main.c:114 ../general/g.mlist/main.c:119
-#: ../general/g.mlist/main.c:124 ../general/g.mlist/main.c:129
-#: ../general/g.region/main.c:83 ../general/g.region/main.c:89
-#: ../general/g.region/main.c:94 ../general/g.region/main.c:100
-#: ../general/g.region/main.c:106 ../general/g.region/main.c:112
-#: ../general/g.region/main.c:118 ../general/g.region/main.c:126
-#: ../general/g.region/main.c:131 ../general/g.region/main.c:137
-#: ../general/g.region/main.c:142 ../general/g.mapsets/main.c:98
-#: ../general/g.mapsets/main.c:103 ../vector/v.in.ogr/main.c:215
-#: ../vector/v.in.ogr/main.c:222 ../vector/v.in.ogr/main.c:228
-#: ../vector/v.db.connect/main.c:82 ../vector/v.db.connect/main.c:87
-#: ../vector/v.db.connect/main.c:94 ../vector/v.db.connect/main.c:101
-#: ../vector/v.colors/main.c:120 ../vector/v.to.db/parse.c:94
-#: ../vector/v.to.db/parse.c:99 ../vector/v.to.db/parse.c:105
-#: ../vector/v.external/args.c:42 ../vector/v.external/args.c:48
-#: ../vector/v.external/args.c:55 ../vector/v.external.out/args.c:34
-#: ../vector/v.external.out/args.c:46 ../vector/v.external.out/args.c:52
-#: ../vector/v.info/parse.c:25 ../vector/v.info/parse.c:31
-#: ../vector/v.info/parse.c:36 ../vector/v.info/parse.c:41
-#: ../vector/v.info/parse.c:46 ../vector/v.what/main.c:86
-#: ../vector/v.what/main.c:91 ../vector/v.what/main.c:96
-#: ../db/db.connect/main.c:53
-#: ../locale/scriptstrings/g.extension_to_translate.c:11
-#: ../locale/scriptstrings/g.extension_to_translate.c:13
-#: ../locale/scriptstrings/g.extension_to_translate.c:15
-#: ../locale/scriptstrings/g.extension_to_translate.c:17
-msgid "Print"
-msgstr ""
-#: ../raster/r.external/main.c:101 ../raster/r.in.gdal/main.c:140
-msgid "Override projection (use location's projection)"
-msgstr ""
-#: ../raster/r.external/main.c:105 ../raster/r.in.gdal/main.c:144
-#: ../vector/v.in.ogr/main.c:259 ../vector/v.in.lidar/main.c:213
-#, fuzzy
-msgid "Extend region extents based on new dataset"
-msgstr "चालू"
-#: ../raster/r.external/main.c:106 ../raster/r.in.gdal/main.c:146
-#: ../vector/v.in.ogr/main.c:261
-msgid "Also updates the default region if in the PERMANENT mapset"
-msgstr ""
-#: ../raster/r.external/main.c:110
-msgid "Require exact range"
-msgstr ""
-#: ../raster/r.external/main.c:114
-msgid "Flip horizontally"
-msgstr ""
-#: ../raster/r.external/main.c:118
-msgid "Flip vertically"
-msgstr ""
-#: ../raster/r.external/main.c:148
-#, fuzzy, c-format
-msgid "One of options <%s> or <%s> must be given"
-msgstr "पाठ"
-#: ../raster/r.external/main.c:152
-#, c-format
-msgid "Option <%s> and <%s> are mutually exclusive"
-msgstr ""
-#: ../raster/r.external/main.c:181 ../raster/r.in.gdal/main.c:461
-#, fuzzy
-msgid "Proceeding with import..."
-msgstr "n"
-#: ../raster/r.external/main.c:185
-#, fuzzy, c-format
-msgid "Imagery group <%s> already exists and will be overwritten."
-msgstr "i n"
-#: ../raster/r.external/main.c:192
-#, fuzzy, c-format
-msgid "Reading band %d of %d..."
-msgstr "छवि "
-#: ../raster/r.external/main.c:197 ../raster/r.in.gdal/main.c:486
-#, fuzzy, c-format
-msgid "Selected band (%d) does not exist"
-msgstr "नहीं"
-#: ../raster/r.external/main.c:226
-#, fuzzy, c-format
-msgid "Imagery group <%s> created"
-msgstr "नहीं"
-#: ../raster/r.external/link.c:48
-#, fuzzy
-msgid "Complex types not supported"
-msgstr "नहीं"
-#: ../raster/r.external/link.c:63
-#, fuzzy, c-format
-msgid "Copying color table for %s"
-msgstr "बनाया जा रहा है के लिए."
-#: ../raster/r.external/link.c:81
-#, fuzzy, c-format
-msgid "Setting grey color table for <%s> (full 8bit range)"
-#: ../raster/r.external/link.c:87
-#, fuzzy, c-format
-msgid "Setting grey color table for <%s> (data range)"
-#: ../raster/r.external/link.c:101
-#, fuzzy, c-format
-msgid "Unable to create cell/%s file"
-msgstr "के लिए"
-#: ../raster/r.external/link.c:110
-#, fuzzy, c-format
-msgid "Unable to create fcell/%s file"
-msgstr "के लिए"
-#: ../raster/r.external/link.c:146
-#, fuzzy, c-format
-msgid "Unable to create cell_misc/%s/gdal file"
-msgstr "बनाया जा रहा है."
-#: ../raster/r.external/link.c:149
-#, fuzzy, c-format
-msgid "Error writing cell_misc/%s/gdal file"
-msgstr "त्रुटि n"
-#: ../raster/r.external/link.c:174
-#, fuzzy, c-format
-msgid "Unable to create cell_misc/%s/f_format file"
-#: ../raster/r.external/link.c:177
-#, fuzzy, c-format
-msgid "Error writing cell_misc/%s/f_format file"
-msgstr "त्रुटि n"
-#: ../raster/r.external/link.c:224
-#, fuzzy, c-format
-msgid "Creating support files for %s"
-msgstr "बनाया जा रहा है के लिए"
-#: ../raster/r.external/link.c:236
-#, fuzzy, c-format
-msgid "Link to raster map <%s> created."
-msgstr "नहीं"
-#: ../raster/r.uslek/main.c:55
-msgid "soil"
-msgstr ""
-#: ../raster/r.uslek/main.c:56 ../raster/r.usler/main.c:54
-#: ../raster/simwe/r.sim.sediment/main.c:114
-#, fuzzy
-msgid "erosion"
-msgstr "नहीं n"
-#: ../raster/r.uslek/main.c:57
-msgid "Computes USLE Soil Erodibility Factor (K)."
-msgstr ""
-#: ../raster/r.uslek/main.c:62
-#, fuzzy
-msgid "Name of soil sand fraction raster map [0.0-1.0]"
-msgstr "का"
-#: ../raster/r.uslek/main.c:66
-#, fuzzy
-msgid "Name of soil clay fraction raster map [0.0-1.0]"
-msgstr "का"
-#: ../raster/r.uslek/main.c:70
-#, fuzzy
-msgid "Name of soil silt fraction raster map [0.0-1.0]"
-msgstr "का"
-#: ../raster/r.uslek/main.c:74
-#, fuzzy
-msgid "Name of soil organic matter raster map [0.0-1.0]"
-msgstr "का"
-#: ../raster/r.uslek/main.c:77
-#, fuzzy
-msgid "Name for output USLE K factor raster map [t.ha.hr/ha.MJ.mm]"
-msgstr "का"
-#: ../raster/r.mode/main.c:55 ../raster/r.mfilter/main.c:57
-#: ../raster/r.quantile/main.c:256 ../raster/r.bitpattern/main.c:64
-#: ../raster/r.neighbors/main.c:118 ../raster/r.texture/main.c:102
-#: ../raster/r.mapcalc/main.c:112
-#, fuzzy
-msgid "algebra"
-msgstr "का"
-#: ../raster/r.mode/main.c:58
-#, fuzzy
-msgid "Finds the mode of values in a cover map within areas assigned the same category value in a user-specified base map."
-msgstr "का a कवर a बेस."
-#: ../raster/r.mode/main.c:64
-msgid "Base map to be reclassified"
-msgstr ""
-#: ../raster/r.mode/main.c:71
-msgid "Coverage map"
-msgstr ""
-#: ../raster/r.mode/main.c:78
-msgid "Output map"
-msgstr ""
-#: ../raster/r.mode/main.c:91
-#, fuzzy, c-format
-msgid "%s: Unable to read category labels"
-msgstr "के लिए"
-#: ../raster/r.mode/read_stats.c:14
-msgid "reading r.stats output"
-msgstr ""
-#: ../raster/r.profile/main.c:51 ../display/d.profile/main.c:193
-#, fuzzy
-msgid "profile"
-msgstr "नक़ल"
-#: ../raster/r.profile/main.c:53
-#, fuzzy
-msgid "Outputs the raster map layer values lying on user-defined line(s)."
-msgstr "चालू."
-#: ../raster/r.profile/main.c:64
-#, fuzzy
-msgid "Name of file for output (use output=- for stdout)"
-msgstr "का के लिए के लिए"
-#: ../raster/r.profile/main.c:72 ../display/d.profile/main.c:206
-#, fuzzy
-msgid "Profile coordinate pairs"
-#: ../raster/r.profile/main.c:79
-msgid "Resolution along profile (default = current region resolution)"
-msgstr ""
-#: ../raster/r.profile/main.c:86
-msgid "Character to represent no data cell"
-msgstr ""
-#: ../raster/r.profile/main.c:91 ../raster/r.transect/main.c:130
-#, fuzzy
-msgid "Output easting and northing in first two columns of four column output"
-msgstr "दो का"
-#: ../raster/r.profile/main.c:96
-#, fuzzy
-msgid "Output RRR:GGG:BBB color values for each profile point"
-msgstr "के लिए बिन्दु"
-#: ../raster/r.profile/main.c:115
-#, c-format
-msgid "Illegal resolution! [%g]"
-msgstr ""
-#: ../raster/r.profile/main.c:122
-#, fuzzy, c-format
-msgid "Using resolution [%g]"
-#: ../raster/r.profile/main.c:153
-msgid "Output Format:"
-msgstr ""
-#: ../raster/r.profile/main.c:156
-#, c-format
-msgid "[Easting] [Northing] [Along Track Dist.(m)] [Elevation]"
-msgstr ""
-#: ../raster/r.profile/main.c:158
-#, c-format
-msgid "[Along Track Dist.(m)] [Elevation]"
-msgstr ""
-#: ../raster/r.profile/main.c:160
-msgid " [RGB Color]"
-msgstr ""
-#: ../raster/r.profile/main.c:170
-#, c-format
-msgid "Invalid coordinates %s %s"
-msgstr ""
-#: ../raster/r.profile/main.c:238
-#, c-format
-msgid "Approx. transect length [%f] m"
-msgstr ""
-#: ../raster/r.profile/main.c:241
-#, fuzzy
-msgid "Endpoint coordinates are outside of current region settings"
-msgstr "नहीं"
-#: ../raster/r.profile/input.c:29 ../raster/r.profile/input.c:46
-#: ../raster/r.profile/input.c:59
-#, fuzzy
-msgid "One coordinate pair per line, please"
-msgstr "एक."
-#: ../raster/r.category/main.c:53 ../vector/v.category/main.c:74
-#, fuzzy
-msgid "category"
-msgstr "n"
-#: ../raster/r.category/main.c:55
-#, fuzzy
-msgid "Manages category values and labels associated with user-specified raster map layers."
-msgstr "a."
-#: ../raster/r.category/main.c:68
-#, fuzzy
-msgid "Comma separated value list"
-msgstr "विराम चिह्न जी 13"
-#: ../raster/r.category/main.c:69
-msgid "Example: 1.4,3.8,13"
-msgstr ""
-#: ../raster/r.category/main.c:74 ../raster/r.distance/parse.c:47
-#: ../raster/r.stats/main.c:119 ../vector/v.vect.stats/main.c:203
-#: ../vector/v.db.select/main.c:65 ../db/db.select/main.c:218
-#: ../locale/scriptstrings/r.tileset_to_translate.c:14
-#, fuzzy
-msgid "Output field separator"
-msgstr "फील्ड"
-#: ../raster/r.category/main.c:80 ../raster/r.support/main.c:116
-#, fuzzy
-msgid "Raster map from which to copy category table"
-msgstr "नक़ल"
-#: ../raster/r.category/main.c:86
-#, fuzzy
-msgid "File containing category label rules (or \"-\" to read from stdin)"
-#: ../raster/r.category/main.c:93
-msgid "Default label or format string for dynamic labeling"
-msgstr ""
-#: ../raster/r.category/main.c:95
-msgid "Used when no explicit label exists for the category"
-msgstr ""
-#: ../raster/r.category/main.c:103
-msgid "Dynamic label coefficients"
-msgstr ""
-#: ../raster/r.category/main.c:105
-msgid "Two pairs of category multiplier and offsets, for $1 and $2"
-msgstr ""
-#: ../raster/r.category/main.c:138 ../raster/r.support/main.c:148
-#, fuzzy, c-format
-msgid "Raster map <%s> not found in current mapset"
-msgstr "नहीं"
-#: ../raster/r.category/main.c:156 ../raster/r.category/main.c:212
-#: ../raster/r.report/parse.c:266 ../raster/r.mapcalc/map.c:216
-#: ../raster/r.mapcalc/map3.c:188
-#, fuzzy, c-format
-msgid "Unable to read category file of raster map <%s@%s>"
-msgstr "संपादन के लिए "
-#: ../raster/r.category/main.c:160
-#, fuzzy, c-format
-msgid "Category table for <%s> set from <%s>"
-msgstr "के लिए."
-#: ../raster/r.category/main.c:249
-#, fuzzy, c-format
-msgid "Unable to read category file of raster map <%s> in <%s>"
-#: ../raster/r.category/main.c:265
-#, fuzzy
-msgid "The map is floating point! Ignoring cats list, using vals list"
-msgstr "है बिन्दु"
-#: ../raster/r.category/main.c:282
-#, fuzzy
-msgid "vals argument is required for floating point map!"
-msgstr "है के लिए बिन्दु!"
-#: ../raster/r.category/cats.c:47
-#, fuzzy, c-format
-msgid "Reading <%s> in <%s>"
-msgstr "छवि "
-#: ../raster/r.watershed/ram/init_vars.c:109
-#, c-format
-msgid "SECTION 1a (of %1d): Initiating Memory."
-msgstr ""
-#: ../raster/r.watershed/ram/init_vars.c:284
-#, c-format
-msgid "SECTION 1b (of %1d): Determining Offmap Flow."
-msgstr ""
-#: ../raster/r.watershed/ram/sg_factor.c:14
-msgid "SECTION 4: RUSLE LS and/or S factor determination."
-msgstr ""
-#: ../raster/r.watershed/ram/do_astar.c:27
-#: ../raster/r.watershed/seg/do_astar.c:33
-msgid "SECTION 2: A* Search."
-msgstr ""
-#: ../raster/r.watershed/ram/do_astar.c:220
-msgid "heapsize too large"
-msgstr ""
-#: ../raster/r.watershed/ram/do_cum.c:16 ../raster/r.watershed/seg/do_cum.c:20
-msgid "SECTION 3: Accumulating Surface Flow with SFD."
-msgstr ""
-#: ../raster/r.watershed/ram/do_cum.c:111
-#: ../raster/r.watershed/seg/do_cum.c:132
-msgid "SECTION 3: Accumulating Surface Flow with MFD."
-msgstr ""
-#: ../raster/r.watershed/ram/do_cum.c:306
-#: ../raster/r.watershed/seg/do_cum.c:352
-#, c-format
-msgid "MFD: cumulative proportion of flow distribution not 1.0 but %f"
-msgstr ""
-#: ../raster/r.watershed/ram/do_cum.c:354
-#: ../raster/r.watershed/seg/do_cum.c:410
-#, c-format
-msgid "MFD: A * path already processed when distributing flow: %d of %d cells"
-msgstr ""
-#: ../raster/r.watershed/ram/main.c:82 ../raster/r.watershed/ram/main.c:98
-#: ../raster/r.watershed/seg/main.c:90 ../raster/r.watershed/seg/main.c:105
-#, c-format
-msgid "SECTION %d: Closing Maps."
-msgstr ""
-#: ../raster/r.watershed/ram/main.c:96 ../raster/r.watershed/seg/main.c:103
-#, c-format
-msgid "SECTION %d: Watershed determination."
-msgstr ""
-#: ../raster/r.watershed/ram/usage.c:9 ../raster/r.watershed/seg/usage.c:9
-#, c-format
-msgid ""
-"USAGE for basin delineation:\n"
-"%s -4 elevation=elevation_map threshold=swale_threshold [flow=overland_flow_map] [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [basin=watershed_basin_map] [stream=stream_segment_map]\n"
-"\n"
-"USAGE for slope length determination:\n"
-"%s [-4] elevation=elevation_map threshold=swale_threshold [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [max_slope_length=max_slope_length] [blocking=overland_blocking_map] [slope_steepness=slope_steepness_map] length_slope=length_slope_map [disturbed_land=rill_erosion_map] [slope_deposition=slope_deposition value or map]USAGE for ARMSED FILE creation:\n"
-"%s [-4] elevation=elevation_map threshold=swale_threshold [flow=overland_flow_map] [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [basin=watershed_basin_map] [stream=stream_segment_map] [half_basin=half_basin_map] ar=ARMSED_file_name\n"
-"\n"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:56
-msgid "Beautify flat areas: priority queue error"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:229
-msgid "flat cell escaped for uphill correction"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:235
-#, c-format
-msgid "queue error: last uphill order %d > current uphill order %d"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:240
-msgid "uphill order not set"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:266
-msgid "flat cell escaped in uphill correction"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:302
-msgid "downhill order: no more points in down queue"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:310
-msgid "flat cell escaped for downhill correction"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:316
-#, c-format
-msgid "queue error: last downhill order %d > current downhill order %d"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:321
-msgid "downhill order: downhill order not set"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:344
-msgid "flat cell escaped in downhill correction"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:382
-msgid "flat cell escaped for adjustment"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:389
-msgid "adjustment: uphill order not set"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:391
-msgid "adjustment: downhill order not set"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:417
-msgid "flat cell escaped in adjustment"
-msgstr ""
-#: ../raster/r.watershed/seg/init_vars.c:124
-#, c-format
-msgid "SECTION 1 beginning: Initiating Variables. %d sections total."
-msgstr ""
-#: ../raster/r.watershed/seg/init_vars.c:158
-msgid "Maximum memory to be used was smaller than 3 MB, set to 3 MB."
-msgstr ""
-#: ../raster/r.watershed/seg/init_vars.c:233
-#, c-format
-msgid "Will need up to %.2f MB of disk space"
-msgstr ""
-#: ../raster/r.watershed/seg/init_vars.c:235
-#, c-format
-msgid "Will need up to %.2f GB (%.0f MB) of disk space"
-msgstr ""
-#: ../raster/r.watershed/seg/init_vars.c:447
-msgid "SECTION 1b: Determining Offmap Flow."
-msgstr ""
-#: ../raster/r.watershed/seg/sg_factor.c:14
-msgid "SECTION 5: RUSLE LS and/or S factor determination."
-msgstr ""
-#: ../raster/r.watershed/seg/do_astar.c:51
-msgid "No seeds for A* Search"
-msgstr ""
-#: ../raster/r.watershed/seg/do_astar.c:163
-#, c-format
-msgid "bug in A* Search: doer %d heap size %d count %d"
-msgstr ""
-#: ../raster/r.watershed/seg/close_maps2.c:82
-#, fuzzy
-msgid "Closing stream segments map"
-msgstr "बनाया जा रहा है n"
-#: ../raster/r.watershed/seg/close_maps2.c:105
-#, fuzzy
-msgid "Closing basins map"
-#: ../raster/r.watershed/seg/close_maps2.c:112
-#, fuzzy
-msgid "Closing half basins map"
-#: ../raster/r.watershed/seg/close_maps.c:20
-#, fuzzy
-msgid "Closing accumulation map"
-#: ../raster/r.watershed/seg/close_maps.c:128
-#, fuzzy
-msgid "Closing flow direction map"
-#: ../raster/r.watershed/seg/close_maps.c:136
-#, fuzzy
-msgid "Closing LS map"
-#: ../raster/r.watershed/seg/close_maps.c:141
-#, fuzzy
-msgid "Closing SL map"
-#: ../raster/r.watershed/shed/com_line.c:23
-msgid ""
-"\n"
-"This set of questions will organize the command line for the"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:24
-#, c-format
-msgid "%s program to run properly for your application."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:26
-#, c-format
-msgid "The first question is whether you want %s to run"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:28
-#, c-format
-msgid "in its fast mode or its slow mode.  If you run %s"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:30
-msgid "in the fast mode, the computer will finish about 10 times faster"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:31
-msgid "than in the slow mode, but will not allow other programs to run"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:32
-msgid "at the same time.  The fast mode also places all of the data into"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:33
-msgid "RAM, which limits the size of window that can be run.  The slow"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:34
-msgid "mode uses disk space in the same hard disk partition as where GRASS is"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:35
-msgid "stored.  Thus, if the program does not work in the slow mode, you will"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:36
-msgid "need to remove unnecessary files from that partition.  The slow mode"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:37
-#, c-format
-msgid "will allow other processes to run concurrently with %s.\n"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:69
-#: ../raster/r.watershed/shed/com_line.c:182
-msgid ""
-"\n"
-"If you hit <return> by itself for the next question, this"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:70
-#: ../raster/r.watershed/shed/com_line.c:183
-#, fuzzy
-msgid "program will terminate."
-msgstr "प्रोग्राम."
-#: ../raster/r.watershed/shed/com_line.c:81
-#, c-format
-msgid ""
-"\n"
-"One of the options for %s is a `depression map'.  A"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:83
-msgid "depression map indicates all the locations in the current map window where"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:84
-msgid "water accumulates and does not leave by the edge of the map. Lakes without"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:85
-msgid "outlet streams and sinkholes are examples of `depressions'.  If you wish to"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:86
-msgid "have a depression map, prepare a map where non-zero values indicate the"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:87
-#, fuzzy
-msgid "locations where depressions occur.\n"
-msgstr "का"
-#: ../raster/r.watershed/shed/com_line.c:88
-msgid "Hit <return> by itself for the next question if there is no depression map."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:99
-#, c-format
-msgid ""
-"\n"
-"The %s program will divide the elevation map into a number of"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:101
-msgid "watershed basins.  The number of watershed basins is indirectly determined"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:102
-msgid "by the `basin threshold' value.  The basin threshold is the area necessary for"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:103
-#, c-format
-msgid "%s to define a unique watershed basin.  This area only applies to"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:105
-msgid "`exterior drainage basins'.  An exterior drainage basin does not have any"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:106
-msgid "drainage basins flowing into it.  Interior drainage basin size is determined"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:107
-msgid "by the surface flow going into stream segments between stream interceptions."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:108
-#, c-format
-msgid "Thus interior drainage basins can be of any size.  The %s program"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:110
-msgid "also allows the user to relate basin size to potential overland flow"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:111
-msgid "(i.e., areas with low infiltration capacities will need smaller areas to"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:112
-msgid "develop stream channels than neighboring areas with high infiltration rates)."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:113
-msgid "The user can create a map layer with potential overland flow values, and"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:114
-#, c-format
-msgid "%s will accumulate those values instead of area.\n"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:116
-msgid "What unit of measure will you use for the basin threshold:"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:119
-msgid " 1) acres,          2) meters sq., 3) miles sq., 4) hectares,"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:120
-msgid " 5) kilometers sq., 6) map cells,  7) overland flow units"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:121
-#, c-format
-msgid "Choose 1-7 or 0 to exit this program: "
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:131
-msgid ""
-"\n"
-"How large an area (or how many overland flow units) must a drainage basin"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:132
-#, c-format
-msgid "be for it to be an exterior drainage basin: "
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:201
-#, fuzzy, c-format
-msgid ""
-"\n"
-"%s must create a map layer of watershed basins"
-msgstr "a."
-#: ../raster/r.watershed/shed/com_line.c:203
-#: ../raster/r.watershed/shed/com_line.c:224
-#, c-format
-msgid "before %s can run properly."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:222
-#, c-format
-msgid ""
-"\n"
-"%s must create a file of watershed basin relationships"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:228
-#: ../raster/r.watershed/shed/com_line.c:263
-#, c-format
-msgid ""
-"\n"
-"Please name this file:"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:231
-#: ../raster/r.watershed/shed/com_line.c:266 ../raster/r.drain/main.c:199
-#: ../imagery/i.landsat.acca/main.c:189 ../imagery/i.landsat.toar/main.c:498
-#: ../general/g.rename/main.c:79 ../general/g.copy/main.c:81
-#, fuzzy, c-format
-msgid "<%s> is an illegal file name"
-msgstr "है"
-#: ../raster/r.watershed/shed/com_line.c:257
-#, c-format
-msgid ""
-"\n"
-"%s will generate a lot of output.  Indicate a file"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:259
-#, fuzzy, c-format
-msgid "name for %s to send the output to."
-msgstr "का a"
-#: ../raster/r.watershed/shed/com_line.c:277
-#, c-format
-msgid ""
-"\n"
-"The accumulation map from %s must be present for"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:279
-#, c-format
-msgid "%s to work properly."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:290
-#, c-format
-msgid ""
-"\n"
-"%s can produce several maps not necessary for"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:292
-#, c-format
-msgid "%s to function (stream channels, overland flow aspect, and"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:294
-#, c-format
-msgid "a display version of the accumulation map).  %s also has the"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:296
-msgid "ability to generate several variables in the Revised Universal Soil Loss"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:297
-msgid "Equation (Rusle): Slope Length (LS), and Slope Steepness (S).\n"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:348
-msgid ""
-"\n"
-"The Slope Length factor (LS) and Slope Steepness (S) are influenced by"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:349
-#, c-format
-msgid "disturbed land.  %s reflects this with an optional map layer or value"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:351
-msgid "where the value indicates the percent of disturbed (barren) land in that cell."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:352
-msgid "Type <return> if you do not have a disturbed land map layer."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:364
-msgid ""
-"\n"
-"Type the value indicating the percent of disturbed land.  This value will"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:365
-#, fuzzy
-msgid "be used for every cell in the current region."
-msgstr "छापें"
-#: ../raster/r.watershed/shed/com_line.c:368
-#, c-format
-msgid ""
-"\n"
-"Input value here [0-100]: "
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:379
-msgid ""
-"\n"
-"Overland surface flow only occurs for a set distance before swales form."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:380
-#, c-format
-msgid "Because of digital terrain model limitations, %s cannot pick up"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:382
-#, c-format
-msgid "these swales.  %s allows for an input (warning: kludge factor)"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:384
-msgid "that prevents the surface flow distance from getting too long.  Normally,"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:385
-msgid "maximum slope length is around 600 feet (about 183 meters)."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:400
-msgid ""
-"\n"
-"Roads, ditches, changes in ground cover, and other factors will stop"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:401
-msgid "slope length.  You may input a raster map indicating the locations of these"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:402
-msgid "blocking factors.\n"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:403
-msgid "Hit <return> by itself for the next question if there is no blocking map."
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:12
-msgid ""
-"\n"
-"\n"
-"Please indicate which map layers you wish to use in the lumped"
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:13
-msgid "parameter hydrologic/soil erosion model.  Continue inputing cell map"
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:14
-msgid "layers, one at a time, until all desired map layers are in."
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:15
-#, c-format
-msgid "You can have %s include a list of categories in each."
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:17
-#, c-format
-msgid ""
-"\n"
-"Hit <return> at the map prompt to continue with %s"
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:36
-#, c-format
-msgid ""
-"\n"
-"The output from %s will be divided into watershed"
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:38
-msgid "basins.  There are two possible methods of tabulating the information:"
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:39
-msgid "1) by only including data pertaining to the basin itself, or 2) using"
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:40
-msgid "data from the basin, and all basins upstream of it."
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:43
-msgid ""
-"\n"
-"Would you like the data organized:"
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:44
-msgid ""
-"1) Basin only\n"
-"2) Upstream only\n"
-"3) Both\n"
-"OR 0) to cancel program"
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:45
-#, c-format
-msgid ""
-"\n"
-"Your choice: "
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:69
-#: ../raster/r.watershed/shed/basin_maps.c:73
-#, c-format
-msgid ""
-"\n"
-"OK, %s should start running now using the following form:\n"
-"%s"
-msgstr ""
-#: ../raster/r.watershed/shed/read.c:23
-#, fuzzy
-msgid "unable to open basin/half basin map"
-msgstr "के लिए"
-#: ../raster/r.watershed/shed/intro.c:8
-#, c-format
-msgid "%s provides a text-based user-interface to the %s program."
-msgstr ""
-#: ../raster/r.watershed/shed/intro.c:10
-#, c-format
-msgid "%s also allows the user to prepare a report of map layers for each"
-msgstr ""
-#: ../raster/r.watershed/shed/intro.c:12
-#, fuzzy, c-format
-msgid "watershed basin determined in %s.\n"
-#: ../raster/r.watershed/shed/intro.c:14
-#, c-format
-msgid "%s will help the user determine which options to use for the"
-msgstr ""
-#: ../raster/r.watershed/shed/intro.c:16
-#, c-format
-msgid "%s program.  %s will then ask for map layers that will be"
-msgstr ""
-#: ../raster/r.watershed/shed/intro.c:18
-#, c-format
-msgid "divided by basin. %s will then run %s and create the report."
-msgstr ""
-#: ../raster/r.watershed/shed/valid.c:24
-msgid "accum file missing in valid_basins()"
-msgstr ""
-#: ../raster/r.watershed/shed/file_in.c:15
-#, fuzzy
-msgid "unable to open ARMSED file"
-msgstr "का"
-#: ../raster/r.watershed/shed/main.c:41
-msgid "Slow version of water analysis program starting now"
-msgstr ""
-#: ../raster/r.watershed/shed/main.c:46 ../raster/r.watershed/shed/main.c:55
-#, c-format
-msgid "<<%s>> command line failed"
-msgstr ""
-#: ../raster/r.watershed/shed/main.c:72
-#, fuzzy
-msgid "unable to open output file"
-msgstr "का"
-#: ../raster/r.watershed/front/main.c:73
-msgid "Calculates hydrological parameters and RUSLE factors."
-msgstr ""
-#: ../raster/r.watershed/front/main.c:76 ../raster/r.watershed/front/main.c:83
-#: ../raster/r.watershed/front/main.c:89 ../raster/r.watershed/front/main.c:96
-#: ../raster/r.watershed/front/main.c:105
-#: ../raster/r.watershed/front/main.c:113
-#: ../raster/r.watershed/front/main.c:122
-#, fuzzy
-msgid "Inputs"
-msgstr "का"
-#: ../raster/r.watershed/front/main.c:80
-#, fuzzy
-msgid "Name of input depressions raster map"
-msgstr "का"
-#: ../raster/r.watershed/front/main.c:81
-msgid "All non-NULL and non-zero cells are considered as real depressions"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:87
-#, fuzzy
-msgid "Name of input raster representing amount of overland flow per cell"
-msgstr "का"
-#: ../raster/r.watershed/front/main.c:93
-#, fuzzy
-msgid "Name of input raster map percent of disturbed land"
-msgstr "का"
-#: ../raster/r.watershed/front/main.c:94
-#: ../raster/r.watershed/front/main.c:119
-msgid "For USLE"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:101
-#, fuzzy
-msgid "IName of input raster map blocking overland surface flow"
-msgstr "के लिए"
-#: ../raster/r.watershed/front/main.c:103
-msgid "For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
-msgstr ""
-#: ../raster/r.watershed/front/main.c:110
-#, fuzzy
-msgid "Minimum size of exterior watershed basin"
-msgstr "आकार  का"
-#: ../raster/r.watershed/front/main.c:118
-#, fuzzy
-msgid "Maximum length of surface flow in map units"
-msgstr "का के लिए"
-#: ../raster/r.watershed/front/main.c:127
-#, fuzzy
-msgid "Name for output accumulation raster map"
-msgstr "का"
-#: ../raster/r.watershed/front/main.c:129
-#, fuzzy
-msgid "Number of cells that drain through each cell"
-msgstr "संख्या का"
-#: ../raster/r.watershed/front/main.c:131
-#: ../raster/r.watershed/front/main.c:137
-#: ../raster/r.watershed/front/main.c:145
-#: ../raster/r.watershed/front/main.c:151
-#: ../raster/r.watershed/front/main.c:159
-#: ../raster/r.watershed/front/main.c:167
-#: ../raster/r.watershed/front/main.c:174 ../raster/r.slope.aspect/main.c:164
-#: ../raster/r.slope.aspect/main.c:170 ../raster/r.slope.aspect/main.c:196
-#: ../raster/r.slope.aspect/main.c:203 ../raster/r.slope.aspect/main.c:210
-#: ../raster/r.slope.aspect/main.c:217 ../raster/r.slope.aspect/main.c:224
-#: ../raster/r.slope.aspect/main.c:231 ../raster/r.slope.aspect/main.c:238
-#: ../vector/v.surf.rst/main.c:166 ../vector/v.surf.rst/main.c:193
-#: ../vector/v.surf.rst/main.c:199 ../vector/v.surf.rst/main.c:205
-#: ../vector/v.surf.rst/main.c:211 ../vector/v.surf.rst/main.c:217
-#: ../vector/v.surf.rst/main.c:223 ../vector/v.surf.rst/main.c:229
-#: ../vector/v.surf.rst/main.c:236 ../vector/v.surf.rst/main.c:243
-#: ../vector/v.surf.rst/main.c:250
-#, fuzzy
-msgid "Outputs"
-msgstr "नहीं"
-#: ../raster/r.watershed/front/main.c:135
-#, fuzzy
-msgid "Name for output drainage direction raster map"
-msgstr "का"
-#: ../raster/r.watershed/front/main.c:142
-#, fuzzy
-msgid "Name for basins raster map"
-msgstr "का"
-#: ../raster/r.watershed/front/main.c:143
-#, fuzzy
-msgid "Unique label for each watershed basin"
-msgstr "के लिए"
-#: ../raster/r.watershed/front/main.c:149
-#, fuzzy
-msgid "Name for output stream segments raster map"
-msgstr "का"
-#: ../raster/r.watershed/front/main.c:155
-#, fuzzy
-msgid "Name for output half basins raster map"
-msgstr "का"
-#: ../raster/r.watershed/front/main.c:157
-#, fuzzy
-msgid "Each half-basin is given a unique value"
-msgstr "है a"
-#: ../raster/r.watershed/front/main.c:163
-#, fuzzy
-msgid "Name for output slope length raster map"
-msgstr "का"
-#: ../raster/r.watershed/front/main.c:165
-#, fuzzy
-msgid "Slope length and steepness (LS) factor for USLE"
-msgstr "ढाल के लिए"
-#: ../raster/r.watershed/front/main.c:171
-#, fuzzy
-msgid "Name for output slope steepness raster map"
-msgstr "का"
-#: ../raster/r.watershed/front/main.c:172
-#, fuzzy
-msgid "Slope steepness (S) factor for USLE"
-#: ../raster/r.watershed/front/main.c:181
-#, fuzzy
-msgid "Convergence factor for MFD (1-10)"
-#: ../raster/r.watershed/front/main.c:183
-msgid "1 = most diverging flow, 10 = most converging flow. Recommended: 5"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:190
-msgid "Maximum memory to be used with -m flag (in MB)"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:194
-msgid "SFD (D8) flow (default is MFD)"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:196
-msgid "SFD: single flow direction, MFD: multiple flow direction"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:201
-#, fuzzy
-msgid "Allow only horizontal and vertical flow of water"
-msgstr "का"
-#: ../raster/r.watershed/front/main.c:206
-#, fuzzy
-msgid "Enable disk swap memory option: Operation is slow"
-msgstr "डिस्क है"
-#: ../raster/r.watershed/front/main.c:208
-msgid "Only needed if memory requirements exceed available RAM; see manual on how to calculate memory requirements"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:213
-msgid "Use positive flow accumulation even for likely underestimates"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:215
-msgid "See manual for a detailed description of flow accumulation output"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:220
-msgid "Beautify flat areas"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:222
-msgid "Flow direction in flat areas is modified to look prettier"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:238
-#, fuzzy
-msgid "Sorry, you must choose an output map."
-msgstr "नहीं"
-#: ../raster/r.watershed/front/main.c:254
-msgid ""
-"Sorry, if any of the following options are set:\n"
-"    basin, stream, half_basin, length_slope, or slope_steepness\n"
-"    you MUST provide a value for the basin threshold parameter."
-msgstr ""
-#: ../raster/r.watershed/front/main.c:281
-#, fuzzy
-msgid "Beautify flat areas is not yet supported for disk swap mode"
-msgstr "है नहीं"
-#: ../raster/r.watershed/front/main.c:307
-#, c-format
-msgid "Subprocess failed with exit code %d"
-msgstr ""
-#: ../raster/r.colors.out/raster_main.c:46
-#: ../raster/r.colors.out/raster3d_main.c:47
-#: ../raster/r.colors/edit_colors.c:64 ../raster/r.what.color/main.c:90
-#: ../vector/v.colors.out/main.c:50 ../vector/v.colors/main.c:56
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:3
-#, fuzzy
-msgid "color table"
-msgstr "का a"
-#: ../raster/r.colors.out/raster_main.c:49
-#, fuzzy
-msgid "Exports the color table associated with a raster map."
-msgstr "a."
-#: ../raster/r.colors.out/raster_main.c:55
-#: ../raster/r.colors.out/raster3d_main.c:56 ../vector/v.colors.out/main.c:61
-#, fuzzy
-msgid "Path to output rules file"
-msgstr "का"
-#: ../raster/r.colors.out/raster_main.c:56
-#: ../raster/r.colors.out/raster3d_main.c:57 ../vector/v.colors.out/main.c:62
-#, fuzzy
-msgid "\"-\" to write to stdout"
-#: ../raster/r.colors.out/raster_main.c:61
-#: ../raster/r.colors.out/raster3d_main.c:62 ../vector/v.colors.out/main.c:72
-#, fuzzy
-msgid "Output values as percentages"
-msgstr "फ़ाइलनाम "
-#: ../raster/r.colors.out/raster_main.c:69
-#: ../raster/r.colors/edit_colors.c:271 ../raster/r.grow.distance/main.c:357
-#: ../vector/v.colors/main.c:267
-#, fuzzy, c-format
-msgid "Unable to read color table for raster map <%s>"
-msgstr "के लिए."
-#: ../raster/r.colors.out/raster_main.c:79
-#: ../raster/r.colors.out/raster3d_main.c:80 ../raster/r.support/main.c:166
-#: ../raster/r.out.png/main.c:205 ../raster/r.out.pov/main.c:173
-#: ../raster/r.out.mat/main.c:93 ../raster/r.out.vrml/main.c:141
-#: ../general/g.pnmcat/main.c:174 ../general/g.cairocomp/main.c:65
-#: ../vector/v.colors.out/main.c:103
-#, fuzzy, c-format
-msgid "Unable to open output file <%s>"
-msgstr "का"
-#: ../raster/r.colors.out/raster3d_main.c:50
-#, fuzzy
-msgid "Exports the color table associated with a 3D raster map."
-msgstr "a."
-#: ../raster/r.colors.out/raster3d_main.c:70
-#, fuzzy, c-format
-msgid "Unable to read color table for raster3d map <%s>"
-msgstr "के लिए."
-#: ../raster/r.drain/main.c:110
-#, fuzzy
-msgid "Traces a flow through an elevation model on a raster map."
-msgstr "ट्रेसेस a चालू a."
-#: ../raster/r.drain/main.c:120
-msgid "Name of movement direction map associated with the cost surface"
-msgstr ""
-#: ../raster/r.drain/main.c:130
-msgid "Output drain vector map (recommended for cost surface made using knight's move)"
-msgstr ""
-#: ../raster/r.drain/main.c:138
-#, fuzzy
-msgid "Map coordinates of starting point(s) (E,N)"
-msgstr "का"
-#: ../raster/r.drain/main.c:139 ../raster/r.drain/main.c:145
-#: ../raster/r.cost/main.c:172 ../raster/r.cost/main.c:184
-#: ../raster/r.cost/main.c:193 ../raster/r.cost/main.c:243
-msgid "Start"
-msgstr ""
-#: ../raster/r.drain/main.c:144
-#, fuzzy
-msgid "Name of vector map(s) containing starting point(s)"
-msgstr "का"
-#: ../raster/r.drain/main.c:149
-#, fuzzy
-msgid "Copy input cell values on output"
-msgstr "नक़ल चालू"
-#: ../raster/r.drain/main.c:153
-msgid "Accumulate input values along the path"
-msgstr ""
-#: ../raster/r.drain/main.c:157
-msgid "Count cell numbers along the path"
-msgstr ""
-#: ../raster/r.drain/main.c:162
-msgid "The input surface is a cost surface (if checked, a direction surface must also be specified"
-msgstr ""
-#: ../raster/r.drain/main.c:174
-msgid "Directional drain selected... checking for direction raster"
-msgstr ""
-#: ../raster/r.drain/main.c:177
-msgid "Surface/Hydrology drain selected"
-msgstr ""
-#: ../raster/r.drain/main.c:183
-msgid "Direction raster not specified, if direction flag is on, a direction raster must be given"
-msgstr ""
-#: ../raster/r.drain/main.c:191
-#, c-format
-msgid "Direction map <%s> should not be specified for Surface/Hydrology drains"
-msgstr ""
-#: ../raster/r.drain/main.c:197
-#, fuzzy
-msgid "Outputting a vector path"
-msgstr "ढाल"
-#: ../raster/r.drain/main.c:214
-msgid "Specify just one of the -c, -a and -n flags"
-msgstr ""
-#: ../raster/r.drain/main.c:233
-#, fuzzy
-msgid "Metrics allocation"
-msgstr "है a"
-#: ../raster/r.drain/main.c:244
-#, fuzzy, c-format
-msgid "Starting point %d is outside the current region"
-msgstr "नहीं"
-#: ../raster/r.drain/main.c:252 ../raster/r.drain/main.c:303
-#, fuzzy
-msgid "Too many start points"
-msgstr "घुमाएँ"
-#: ../raster/r.drain/main.c:262 ../raster/r.cost/main.c:538
-#: ../raster/r.walk/main.c:721
-#, fuzzy, c-format
-msgid "Reading vector map <%s> with start points..."
-msgstr "n"
-#: ../raster/r.drain/main.c:282 ../raster/r.cost/main.c:558
-#: ../raster/r.cost/main.c:626 ../raster/r.walk/main.c:741
-#: ../raster/r.walk/main.c:807 ../display/d.vect/dir.c:27
-#: ../display/d.vect/lines.c:143 ../display/d.vect/attr.c:51
-#: ../display/d.vect/topo.c:49 ../display/d.vect/label.c:39
-#: ../vector/v.colors.out/scan_cats.c:30 ../vector/v.label/main.c:292
-#: ../vector/v.colors/scan_cats.c:24 ../vector/v.perturb/main.c:178
-#: ../vector/v.info/level1.c:37 ../vector/v.to.3d/trans3.c:84
-#: ../vector/v.to.3d/trans2.c:83 ../vector/v.label.sa/labels.c:139
-#, fuzzy
-msgid "Unable to read vector map"
-msgstr "के लिए."
-#: ../raster/r.drain/main.c:310
-#, fuzzy, c-format
-msgid "Starting vector map <%s> contains no points in the current region"
-msgstr "नहीं"
-#: ../raster/r.drain/main.c:318
-#, fuzzy
-msgid "No start/stop point(s) specified"
-msgstr "नहीं."
-#: ../raster/r.drain/main.c:393
-#, fuzzy
-msgid "Calculating flow directions..."
-msgstr "n"
-#: ../raster/r.drain/main.c:462 ../raster/r.drain/main.c:515
-#: ../raster/r.cost/main.c:1033 ../raster/r.random.surface/save.c:98
-#: ../raster/r.composite/main.c:190 ../raster/r.random.cells/indep.c:134
-#: ../imagery/i.smap/write_img.c:13 ../imagery/i.ifft/main.c:207
-#, fuzzy, c-format
-msgid "Writing raster map <%s>..."
-msgstr "i n"
-#: ../raster/r.drain/main.c:682
-#, c-format
-msgid "direction read: %lf, neighbour found: %i"
-msgstr ""
-#: ../raster/r.param.scale/process.c:74
-msgid "E-W and N-S grid resolutions are different. Taking average."
-msgstr ""
-#: ../raster/r.param.scale/main.c:42
-#, fuzzy
-msgid "Lat/Long locations are not supported by this module"
-msgstr "है नहीं"
-#: ../raster/r.param.scale/interface.c:55
-#, fuzzy
-msgid "geomorphology"
-msgstr "का"
-#: ../raster/r.param.scale/interface.c:56
-#, fuzzy
-msgid "Extracts terrain parameters from a DEM."
-msgstr "i n"
-#: ../raster/r.param.scale/interface.c:57
-#, fuzzy
-msgid "Uses a multi-scale approach by taking fitting quadratic parameters to any size window (via least squares)."
-msgstr "a a आकार "
-#: ../raster/r.param.scale/interface.c:75
-msgid "Output raster layer containing morphometric parameter"
-msgstr ""
-#: ../raster/r.param.scale/interface.c:79
-#, fuzzy
-msgid "Slope tolerance that defines a 'flat' surface (degrees)"
-msgstr "a कोण"
-#: ../raster/r.param.scale/interface.c:86
-#, fuzzy
-msgid "Curvature tolerance that defines 'planar' surface"
-msgstr "गोलाई"
-#: ../raster/r.param.scale/interface.c:91
-#, fuzzy, c-format
-msgid "Size of processing window (odd number only, max: %i)"
-msgstr "का संख्या i"
-#: ../raster/r.param.scale/interface.c:101
-#, fuzzy
-msgid "Morphometric parameter in 'size' window to calculate"
-msgstr "आकार "
-#: ../raster/r.param.scale/interface.c:109
-#, fuzzy
-msgid "Exponent for distance weighting (0.0-4.0)"
-msgstr "एक्सपोनेंट के लिए"
-#: ../raster/r.param.scale/interface.c:115 ../raster/r.out.pov/main.c:150
-#, fuzzy
-msgid "Vertical scaling factor"
-msgstr "खड़ा"
-#: ../raster/r.param.scale/interface.c:121
-msgid "Constrain model through central window cell"
-msgstr ""
-#: ../raster/r.param.scale/interface.c:164
-#, fuzzy
-msgid "Morphometric parameter not recognised. Assuming 'Elevation'"
-msgstr "आकार "
-#: ../raster/r.param.scale/interface.c:172
-msgid "Inappropriate window size (too big or even)"
-msgstr ""
-#: ../raster/r.in.gridatb/main.c:48
-msgid "Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map"
-msgstr ""
-#: ../raster/r.in.gridatb/main.c:52
-#, fuzzy
-msgid "GRIDATB i/o map file"
-msgstr "i"
-#: ../raster/r.in.gridatb/main.c:58 ../imagery/i.ifft/main.c:93
-#: ../locale/scriptstrings/v.krige_to_translate.c:8
-#, fuzzy
-msgid "Name for output raster map"
-msgstr "का"
-#: ../raster/r.in.gridatb/main.c:72
-#, fuzzy, c-format
-msgid "File not found: %s"
-msgstr "नहीं n"
-#: ../raster/r.in.gridatb/file_io.c:35
-msgid "Setting window header failed"
-msgstr ""
-#: ../raster/r.in.gridatb/file_io.c:38
-msgid "Rows changed"
-msgstr ""
-#: ../raster/r.in.gridatb/file_io.c:41
-msgid "Cols changed"
-msgstr ""
-#: ../raster/r.support/check.c:26
-#, fuzzy, c-format
-msgid ""
-"\n"
-"  Updating statistics for [%s]"
-msgstr ""
-"\n"
-" के लिए"
-#: ../raster/r.support/check.c:69
-#, fuzzy, c-format
-msgid ""
-"   Updating the number of categories for [%s]\n"
-"\n"
-msgstr "संख्या का के लिए n n"
-#: ../raster/r.support/main.c:56 ../raster/r.region/main.c:52
-#: ../raster/r.describe/main.c:55 ../raster/r.timestamp/main.c:36
-#: ../raster/r.info/main.c:70 ../vector/v.support/main.c:40
-#: ../vector/v.info/main.c:38 ../vector/v.timestamp/main.c:37
-#, fuzzy
-msgid "metadata"
-msgstr "चालू"
-#: ../raster/r.support/main.c:57
-#, fuzzy
-msgid "Allows creation and/or modification of raster map layer support files."
-msgstr "का."
-#: ../raster/r.support/main.c:67
-#, fuzzy
-msgid "Text to use for map title"
-msgstr "के लिए."
-#: ../raster/r.support/main.c:75
-msgid "Text to append to the next line of the map's metadata file"
-msgstr ""
-#: ../raster/r.support/main.c:81
-#, fuzzy
-msgid "Text to use for map data units"
-msgstr "के लिए."
-#: ../raster/r.support/main.c:87
-#, fuzzy
-msgid "Text to use for map vertical datum"
-msgstr "के लिए."
-#: ../raster/r.support/main.c:94
-#, fuzzy
-msgid "Text to use for data source, line 1"
-msgstr "के लिए."
-#: ../raster/r.support/main.c:101
-#, fuzzy
-msgid "Text to use for data source, line 2"
-msgstr "के लिए."
-#: ../raster/r.support/main.c:109
-msgid "Text to use for data description or keyword(s)"
-msgstr ""
-#: ../raster/r.support/main.c:121
-msgid "Text file from which to load history"
-msgstr ""
-#: ../raster/r.support/main.c:126
-msgid "Text file in which to save history"
-msgstr ""
-#: ../raster/r.support/main.c:130
-#, fuzzy
-msgid "Update statistics (histogram, range)"
-msgstr "के लिए "
-#: ../raster/r.support/main.c:134
-#, fuzzy
-msgid "Create/reset the null file"
-msgstr "का फ़िल्टर"
-#: ../raster/r.support/main.c:138
-#, fuzzy
-msgid "Delete the null file"
-#: ../raster/r.support/main.c:180 ../raster/r.series/main.c:209
-#: ../raster/r.in.xyz/main.c:475 ../raster/r.in.arc/main.c:125
-#: ../raster/r.in.mat/main.c:130 ../raster/r.mapcalc/main.c:91
-#: ../display/d.where/main.c:162 ../display/d.text/main.c:371
-#: ../display/d.linegraph/main.c:200 ../display/d.linegraph/main.c:211
-#: ../display/d.linegraph/main.c:346 ../general/g.cairocomp/main.c:45
-#: ../vector/v.lrs/v.lrs.segment/main.c:132 ../vector/v.segment/main.c:87
-#: ../vector/v.net.path/path.c:49
-#, fuzzy, c-format
-msgid "Unable to open input file <%s>"
-msgstr "के लिए"
-#: ../raster/r.support/main.c:249 ../raster/r.statistics/main.c:98
-#: ../display/d.title/main.c:110
-#, fuzzy, c-format
-msgid "Unable to read category file of raster map <%s>"
-#: ../raster/r.support/main.c:253
-#, fuzzy, c-format
-msgid "cats table for [%s] set to %s"
-msgstr "के लिए."
-#: ../raster/r.support/main.c:277 ../raster/r.support/main.c:305
-#, fuzzy, c-format
-msgid "[%s] is a reclass of another map. Exiting."
-msgstr "है a का."
-#: ../raster/r.support/main.c:288
-#, fuzzy, c-format
-msgid "Writing new null file for [%s]... "
-msgstr "के लिए "
-#: ../raster/r.support/main.c:309
-#, fuzzy, c-format
-msgid "Removing null file for [%s]...\n"
-msgstr "के लिए n"
-#: ../raster/r.support/main.c:316 ../display/d.what.vect/main.c:156
-msgid "Done."
-msgstr ""
-#: ../raster/r.topmodel/main.c:65
-#, fuzzy
-msgid "Simulates TOPMODEL which is a physically based hydrologic model."
-msgstr "है a."
-#: ../raster/r.topmodel/main.c:75
-#, fuzzy
-msgid "Name of input basin raster map"
-msgstr "का"
-#: ../raster/r.topmodel/main.c:76
-#, fuzzy
-msgid "Created by r.water.outlet (MASK)"
-msgstr "i"
-#: ../raster/r.topmodel/main.c:82 ../raster/r.fill.dir/main.c:95
-#, fuzzy
-msgid "Name for output depressionless elevation raster map"
-msgstr "का"
-#: ../raster/r.topmodel/main.c:84 ../raster/r.topmodel/main.c:91
-#: ../raster/r.topmodel/main.c:98 ../raster/r.topmodel/main.c:106
-#: ../raster/r.topmodel/main.c:137 ../raster/r.resamp.rst/main.c:176
-#: ../raster/r.resamp.rst/main.c:184 ../raster/r.resamp.rst/main.c:192
-#: ../raster/r.resamp.rst/main.c:200 ../raster/r.resamp.rst/main.c:208
-#: ../raster/r.resamp.rst/main.c:216 ../raster/r.resamp.rst/main.c:280
-#: ../raster/r.grow.distance/main.c:160 ../raster/r.grow.distance/main.c:166
-#: ../raster/simwe/r.sim.sediment/main.c:182
-#: ../raster/simwe/r.sim.sediment/main.c:188
-#: ../raster/simwe/r.sim.sediment/main.c:195
-#: ../raster/simwe/r.sim.sediment/main.c:202
-#: ../raster/simwe/r.sim.sediment/main.c:208
-#: ../raster/simwe/r.sim.sediment/main.c:215
-#: ../raster/simwe/r.sim.water/main.c:191
-#: ../raster/simwe/r.sim.water/main.c:197
-#: ../raster/simwe/r.sim.water/main.c:203
-#: ../raster/simwe/r.sim.water/main.c:209 ../vector/v.in.ogr/main.c:148
-#: ../vector/v.in.ogr/main.c:234 ../vector/v.in.ogr/main.c:239
-#, fuzzy
-msgid "Output"
-msgstr "नहीं"
-#: ../raster/r.topmodel/main.c:89 ../raster/r.fill.dir/main.c:99
-#, fuzzy
-msgid "Name for output flow direction map for depressionless elevation raster map"
-msgstr "i आयताकार"
-#: ../raster/r.topmodel/main.c:95
-#, fuzzy
-msgid "Name for output basin elevation raster map (o/i)"
-msgstr "का"
-#: ../raster/r.topmodel/main.c:96 ../raster/r.topmodel/main.c:104
-msgid "MASK applied"
-msgstr ""
-#: ../raster/r.topmodel/main.c:103
-#, fuzzy
-msgid "Name for output topographic index ln(a/tanB) raster map"
-msgstr "a"
-#: ../raster/r.topmodel/main.c:111
-#, fuzzy
-msgid "Number of topographic index classes"
-msgstr "i का"
-#: ../raster/r.topmodel/main.c:115 ../raster/r.topmodel/main.c:145
-#: ../raster/r.topmodel/main.c:153 ../raster/simwe/r.sim.sediment/main.c:222
-#: ../raster/simwe/r.sim.sediment/main.c:230
-#: ../raster/simwe/r.sim.sediment/main.c:239
-#: ../raster/simwe/r.sim.sediment/main.c:257
-#: ../raster/simwe/r.sim.water/main.c:224
-#: ../raster/simwe/r.sim.water/main.c:232
-#: ../raster/simwe/r.sim.water/main.c:241
-#: ../raster/simwe/r.sim.water/main.c:259
-#: ../raster/simwe/r.sim.water/main.c:269
-#: ../raster/simwe/r.sim.water/main.c:277
-#: ../raster/simwe/r.sim.water/main.c:286 ../imagery/i.eb.h_SEBAL01/main.c:118
-#: ../imagery/i.eb.h_SEBAL01/main.c:126 ../imagery/i.eb.h_SEBAL01/main.c:133
-#: ../imagery/i.eb.h_SEBAL01/main.c:140 ../imagery/i.eb.h_SEBAL01/main.c:147
-#: ../imagery/i.eb.h_SEBAL01/main.c:154 ../vector/v.surf.rst/main.c:155
-#: ../vector/v.surf.rst/main.c:160 ../vector/v.surf.rst/main.c:171
-#: ../vector/v.surf.rst/main.c:184 ../vector/v.surf.rst/main.c:256
-#: ../vector/v.surf.rst/main.c:264 ../vector/v.surf.rst/main.c:271
-#: ../vector/v.surf.rst/main.c:279 ../vector/v.surf.rst/main.c:287
-#: ../vector/v.surf.rst/main.c:296 ../vector/v.surf.rst/main.c:304
-#: ../vector/v.surf.rst/main.c:312 ../vector/v.surf.rst/main.c:321
-#: ../vector/v.surf.rst/main.c:329 ../vector/v.surf.rst/main.c:336
-#, fuzzy
-msgid "Parameters"
-msgstr "n"
-#: ../raster/r.topmodel/main.c:120
-#, fuzzy
-msgid "Name of topographic index statistics file (o/i)"
-msgstr "i"
-#: ../raster/r.topmodel/main.c:124
-#, fuzzy
-msgid "Name of TOPMODEL parameters file"
-msgstr "i"
-#: ../raster/r.topmodel/main.c:128
-#, fuzzy
-msgid "Name of rainfall and potential evapotranspiration data file"
-msgstr "i"
-#: ../raster/r.topmodel/main.c:131 ../raster/r.out.mpeg/main.c:121
-#, fuzzy
-msgid "Name for output file"
-msgstr "के लिए"
-#: ../raster/r.topmodel/main.c:135
-#, fuzzy
-msgid "Name for observed flow file"
-msgstr "के लिए"
-#: ../raster/r.topmodel/main.c:142
-msgid "Time step"
-msgstr ""
-#: ../raster/r.topmodel/main.c:150
-#, fuzzy
-msgid "Topographic index class"
-msgstr "a"
-#: ../raster/r.topmodel/main.c:158
-#, fuzzy
-msgid "Input data given for (o/i)"
-msgstr "के लिए i"
-#: ../raster/r.external.out/main.c:38
-#, c-format
-msgid "Supported Formats:\n"
-msgstr ""
-#: ../raster/r.external.out/main.c:111
-#, fuzzy
-msgid "Unable to open GDAL file"
-msgstr "i n"
-#: ../raster/r.external.out/main.c:135 ../vector/v.external.out/format.c:14
-#, fuzzy, c-format
-msgid "Format <%s> not supported"
-msgstr "है नहीं"
-#: ../raster/r.external.out/main.c:141
-#, c-format
-msgid "Format <%s> does not support direct write"
-msgstr ""
-#: ../raster/r.external.out/main.c:145 ../vector/v.external.out/format.c:19
-#, fuzzy, c-format
-msgid "Format <%s> does not support writing"
-msgstr "समूह नहीं बनाया जा रहा है."
-#: ../raster/r.external.out/main.c:193
-#, fuzzy
-msgid "Unable to create GDAL file"
-msgstr "i n"
-#: ../raster/r.external.out/main.c:196
-#, fuzzy
-msgid "Error writing GDAL file"
-msgstr "त्रुटि n"
-#: ../raster/r.external.out/main.c:216 ../vector/v.external.out/main.c:36
-#, fuzzy
-msgid "output"
-msgstr "नहीं"
-#: ../raster/r.external.out/main.c:219
-msgid "Defines raster output format utilizing GDAL library."
-msgstr ""
-#: ../raster/r.external.out/main.c:223
-#, fuzzy
-msgid "Name of output directory"
-msgstr "के लिए"
-#: ../raster/r.external.out/main.c:230
-#, fuzzy
-msgid "Extension for output files"
-msgstr "के लिए"
-#: ../raster/r.external.out/main.c:236 ../vector/v.external.out/args.c:19
-#, fuzzy
-msgid "Format of output files"
-msgstr "के लिए"
-#: ../raster/r.external.out/main.c:243 ../vector/v.external.out/args.c:26
-#, fuzzy
-msgid "Creation options"
-msgstr "का"
-#: ../raster/r.external.out/main.c:256
-msgid "Cease using GDAL and revert to native output"
-msgstr ""
-#: ../raster/r.external.out/main.c:261 ../vector/v.external.out/args.c:45
-#, fuzzy
-msgid "Print current status"
-msgstr "छापें"
-#: ../raster/r.cross/cross.c:53
-#, c-format
-msgid "%s: STEP 1 ... "
-msgstr ""
-#: ../raster/r.cross/main.c:76
-#, fuzzy
-msgid "Creates a cross product of the category values from multiple raster map layers."
-msgstr "a का."
-#: ../raster/r.cross/main.c:85
-#, fuzzy, c-format
-msgid "Names of 2-%d input raster maps"
-msgstr "का"
-#: ../raster/r.cross/main.c:94
-msgid "Non-zero data only"
-msgstr ""
-#: ../raster/r.cross/main.c:107
-#, fuzzy, c-format
-msgid "More than %d files not allowed"
-msgstr "सीमा कम के बराबर नहीं."
-#: ../raster/r.cross/main.c:123
-msgid "Must specify 2 or more input maps"
-msgstr ""
-#: ../raster/r.cross/main.c:140
-#, c-format
-msgid "%s: STEP 2 ..."
-msgstr ""
-#: ../raster/r.cross/main.c:173 ../raster/r.in.png/main.c:485
-#: ../raster/r.basins.fill/main.c:145 ../raster/r.resample/main.c:125
-#, fuzzy, c-format
-msgid "Creating support files for <%s>..."
-#: ../raster/r.cross/main.c:183
-#, fuzzy, c-format
-msgid "%ld categories"
-msgstr "n"
-#: ../raster/r.cross/renumber.c:33
-#, c-format
-msgid "%s: STEP 3 ... "
-msgstr ""
-#: ../raster/r.usler/main.c:53
-msgid "rainfall"
-msgstr ""
-#: ../raster/r.usler/main.c:55
-msgid "Computes USLE R factor, Rainfall erosivity index."
-msgstr ""
-#: ../raster/r.usler/main.c:58
-#, fuzzy
-msgid "Name of annual precipitation raster map [mm/year]"
-msgstr "का मीटर्स"
-#: ../raster/r.usler/main.c:61
-#, fuzzy
-msgid "Name for output USLE R raster map [MJ.mm/ha.hr.year]"
-msgstr "का"
-#: ../raster/r.usler/main.c:68
-#, fuzzy
-msgid "Name of USLE R equation"
-msgstr "का"
-#: ../raster/r.usler/main.c:70
-msgid "roose;Roosle (1975);morgan;Morgan (1974);foster;Foster (1981);elswaify;El-Swaify (1985)"
-msgstr ""
-#: ../raster/r.distance/edges.c:46
-#, fuzzy, c-format
-msgid "Reading map %s ..."
-msgstr "छवि "
-#: ../raster/r.distance/main.c:41
-#, fuzzy
-msgid "Locates the closest points between objects in two raster maps."
-msgstr "दो."
-#: ../raster/r.distance/parse.c:38
-#, fuzzy
-msgid "Maps for computing inter-class distances"
-msgstr "नक्शे के लिए"
-#: ../raster/r.distance/parse.c:51
-msgid "Include category labels in the output"
-msgstr ""
-#: ../raster/r.distance/parse.c:56
-msgid "Report zero distance if rasters are overlapping"
-msgstr ""
-#: ../raster/r.distance/report.c:43
-msgid "Processing..."
-msgstr ""
-#: ../raster/r.distance/distance.c:101
-#, c-format
-msgid "Reading maps  <%s,%s> while finding 0 distance ..."
-msgstr ""
-#: ../raster/r.out.mpeg/main.c:104
-#, fuzzy
-msgid "animation"
-msgstr "के लिए"
-#: ../raster/r.out.mpeg/main.c:107
-#, fuzzy
-msgid "Converts raster map series to MPEG movie."
-msgstr "फ़ाइल."
-#: ../raster/r.out.mpeg/main.c:115
-#, fuzzy, c-format
-msgid "Name of input raster map(s) for view no.%d"
-msgstr "का"
-#: ../raster/r.out.mpeg/main.c:131
-msgid "Quality factor (1 = highest quality, lowest compression)"
-msgstr ""
-#: ../raster/r.out.mpeg/main.c:135
-#, fuzzy
-msgid "Convert on the fly, uses less disk space"
-msgstr "चालू कम डिस्क n"
-#: ../raster/r.out.mpeg/main.c:136
-#, fuzzy
-msgid "Requires r.out.ppm with stdout option"
-#: ../raster/r.out.mpeg/main.c:159
-msgid "Either mpeg_encode or ppmtompeg must be installed"
-msgstr ""
-#: ../raster/r.out.mpeg/main.c:285 ../raster/r.colors/stats.c:36
-#: ../raster/r.grow.distance/main.c:252 ../raster/r.surf.idw2/read_cell.c:27
-#: ../raster/r.surf.idw/main.c:707 ../ps/ps.map/ps_raster.c:102
-#, fuzzy, c-format
-msgid "Reading raster map <%s>..."
-msgstr "n"
-#: ../raster/r.out.mpeg/main.c:290
-#, fuzzy, c-format
-msgid "Unable to read color table for <%s>"
-msgstr "के लिए"
-#: ../raster/r.out.mpeg/main.c:340 ../raster/r.out.mpeg/main.c:373
-msgid "mpeg_encode ERROR"
-msgstr ""
-#: ../raster/r.out.mpeg/main.c:416
-#, fuzzy
-msgid "Error reading wildcard"
-msgstr "त्रुटि."
-#: ../raster/r.out.mpeg/write.c:81 ../raster/r.out.mpeg/write.c:178
-msgid "Size mismatch error!"
-msgstr ""
-#: ../raster/r.out.mpeg/write.c:139 ../raster/r.out.mpeg/write.c:181
-#, fuzzy
-msgid "Unable to open output file"
-msgstr "का"
-#: ../raster/r.out.mpeg/write.c:215
-#, fuzzy
-msgid "Unable to create temporary files."
-#: ../raster/r.patch/main.c:53 ../raster/r.circle/main.c:52
-#: ../raster/r.to.vect/main.c:72 ../raster/r.thin/main.c:57
-#: ../imagery/i.points/main.c:97 ../imagery/i.vpoints/main.c:95
-#: ../display/d.measure/main.c:47 ../vector/v.type/main.c:40
-#: ../vector/v.voronoi/main.c:121 ../vector/v.overlay/main.c:59
-#: ../vector/v.parallel/main.c:48 ../vector/v.build/main.c:38
-#: ../vector/v.edit/main.c:57 ../vector/v.mkgrid/main.c:65
-#: ../vector/v.build.polylines/main.c:112 ../vector/v.delaunay/main.c:86
-#: ../vector/v.in.region/main.c:39 ../vector/v.buffer/main.c:211
-#: ../vector/v.patch/main.c:69 ../vector/v.perturb/main.c:62
-#: ../vector/v.to.3d/main.c:38 ../vector/v.split/main.c:53
-#: ../vector/v.to.points/main.c:173 ../vector/v.extrude/main.c:70
-#: ../vector/v.segment/main.c:55 ../vector/v.hull/main.c:51
-#: ../vector/v.drape/main.c:141
-#: ../locale/scriptstrings/v.report_to_translate.c:3
-#, fuzzy
-msgid "geometry"
-msgstr "चालू"
-#: ../raster/r.patch/main.c:55
-#, fuzzy
-msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
-msgstr "a एक अधिक का."
-#: ../raster/r.patch/main.c:62
-#, fuzzy
-msgid "Name of raster maps to be patched together"
-msgstr "का"
-#: ../raster/r.patch/main.c:65
-#, fuzzy
-msgid "Name for resultant raster map"
-msgstr "के लिए"
-#: ../raster/r.patch/main.c:72
-#, fuzzy
-msgid "Use zero (0) for transparency instead of NULL"
-msgstr "के लिए ट्रांसपेरेंसी का"
-#: ../raster/r.patch/main.c:88
-#, fuzzy
-msgid "The minimum number of input raster maps is two"
-msgstr "संख्या का पिक्सेल्स a"
-#: ../raster/r.patch/main.c:119 ../raster/r.series/main.c:335
-#: ../raster/r.slope.aspect/main.c:544 ../raster/r.series.interp/main.c:329
-#, fuzzy
-msgid "Percent complete..."
-msgstr "पूर्ण."
-#: ../raster/r.patch/main.c:144
-#, fuzzy, c-format
-msgid "Creating support files for raster map <%s>"
-#: ../raster/r.quant/main.c:48
-#, fuzzy
-msgid "quantization"
-msgstr "के लिए"
-#: ../raster/r.quant/main.c:51
-#, fuzzy
-msgid "Produces the quantization file for a floating-point map."
-msgstr "के लिए a बिन्दु."
-#: ../raster/r.quant/main.c:59
-msgid "Raster map(s) to be quantized"
-msgstr ""
-#: ../raster/r.quant/main.c:64
-#, fuzzy
-msgid "Path to rules file (\"-\" to read from stdin)"
-msgstr "उत्तर पूर्व"
-#: ../raster/r.quant/main.c:70
-msgid "Base map to take quant rules from"
-msgstr ""
-#: ../raster/r.quant/main.c:75
-#, fuzzy
-msgid "Floating point range: dmin,dmax"
-msgstr "फ्लोटिंग बिन्दु"
-#: ../raster/r.quant/main.c:81
-#, fuzzy
-msgid "Integer range: min,max"
-msgstr "पूर्णांक"
-#: ../raster/r.quant/main.c:86
-#, fuzzy
-msgid "Truncate floating point data"
-msgstr "छोटा करें बिन्दु"
-#: ../raster/r.quant/main.c:90
-#, fuzzy
-msgid "Round floating point data"
-msgstr "बिन्दु"
-#: ../raster/r.quant/main.c:111
-msgid "-t, -r, rules=, basemap= and fprange= are mutually exclusive"
-msgstr ""
-#: ../raster/r.quant/main.c:119
-#, fuzzy
-msgid "fprange= and range= must be used together"
-msgstr "का"
-#: ../raster/r.quant/main.c:129
-#, c-format
-msgid "%s is integer map, it can't be quantized"
-msgstr ""
-#: ../raster/r.quant/main.c:137
-msgid "Truncating..."
-msgstr ""
-#: ../raster/r.quant/main.c:142
-#, fuzzy
-msgid "Rounding..."
-msgstr "छवि "
-#: ../raster/r.quant/main.c:150
-#, fuzzy, c-format
-msgid "%s is integer map, it can't be used as basemap"
-msgstr "का"
-#: ../raster/r.quant/main.c:154
-#, fuzzy, c-format
-msgid "unable to read quant rules for basemap <%s>"
-msgstr "के लिए"
-#: ../raster/r.quant/main.c:161
-#, fuzzy, c-format
-msgid "invalid value for fprange= <%s>"
-msgstr "के लिए"
-#: ../raster/r.quant/main.c:163
-#, fuzzy, c-format
-msgid "invalid value for range= <%s>"
-msgstr "के लिए"
-#: ../raster/r.quant/main.c:164
-#, c-format
-msgid "Setting quant rules for input map(s) to (%f,%f) -> (%d,%d)"
-msgstr ""
-#: ../raster/r.quant/main.c:177
-#, fuzzy
-msgid "No rules specified. Quant table(s) not changed."
-msgstr "नहीं"
-#: ../raster/r.quant/main.c:179 ../raster/r.recode/main.c:98
-#: ../raster/r.reclass/main.c:142
-#, fuzzy
-msgid "No rules specified"
-msgstr "नहीं."
-#: ../raster/r.quant/main.c:185
-#, c-format
-msgid "New quant table created for %s"
-msgstr ""
-#: ../raster/r.quant/read_rules.c:50
-msgid "Old data range is empty"
-msgstr ""
-#: ../raster/r.quant/read_rules.c:56
-#, fuzzy, c-format
-msgid "Old data range is %s to %s"
-msgstr "है n"
-#: ../raster/r.quant/read_rules.c:59
-msgid "Old integer data range is empty"
-msgstr ""
-#: ../raster/r.quant/read_rules.c:61
-#, fuzzy, c-format
-msgid "Old integer data range is %d to %d"
-msgstr "है n"
-#: ../raster/r.quant/read_rules.c:83
-#, fuzzy, c-format
-msgid "unable to open input file <%s>"
-msgstr "के लिए"
-#: ../raster/r.quant/read_rules.c:89
-#, fuzzy, c-format
-msgid ""
-"\n"
-"Enter the rule or 'help' for the format description or 'end' to exit:\n"
-msgstr "a एक का n"
-#: ../raster/r.quant/read_rules.c:112
-#, fuzzy
-msgid "quant rules do not cover the whole range map"
-msgstr "नहीं"
-#: ../raster/r.quant/read_rules.c:158 ../raster/r.recode/read_rules.c:131
-#, fuzzy, c-format
-msgid "%s is not a valid rule"
-#: ../raster/r.spread/main.c:103 ../raster/r.ros/main.c:212
-#: ../raster/r.spreadpath/main.c:90
-#, fuzzy
-msgid "fire"
-msgstr "n"
-#: ../raster/r.spread/main.c:105
-#, fuzzy
-msgid "Simulates elliptically anisotropic spread on a graphics window and generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins."
-msgstr "चालू a a का का का रखे हुए के लिए."
-#: ../raster/r.spread/main.c:110
-msgid "It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths."
-msgstr ""
-#: ../raster/r.spread/main.c:118 ../raster/r.spread/main.c:127
-#: ../raster/r.spread/main.c:136 ../raster/r.spread/main.c:145
-#: ../raster/r.spread/main.c:153 ../raster/r.spread/main.c:161
-#: ../raster/r.spread/main.c:169
-#, fuzzy
-msgid "Input_maps"
-msgstr "का"
-#: ../raster/r.spread/main.c:120
-#, fuzzy
-msgid "Name of raster map containing MAX rate of spread (ROS) (cm/min)"
-msgstr "का का"
-#: ../raster/r.spread/main.c:129
-#, fuzzy
-msgid "Name of raster map containing DIRections of max ROS (degree)"
-msgstr "का का"
-#: ../raster/r.spread/main.c:138
-#, fuzzy
-msgid "Name of raster map containing BASE ROS (cm/min)"
-msgstr "का"
-#: ../raster/r.spread/main.c:147
-#, fuzzy
-msgid "Name of raster map containing STARTing sources"
-msgstr "का"
-#: ../raster/r.spread/main.c:155
-#, fuzzy
-msgid "Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
-msgstr "का मी"
-#: ../raster/r.spread/main.c:163
-#, fuzzy
-msgid "Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
-msgstr "का हवा"
-#: ../raster/r.spread/main.c:171
-#, fuzzy
-msgid "Name of raster map containing fine Fuel MOISture of the cell receiving a spotting firebrand (%) (required w/ -s)"
-msgstr "का ईंधन का a"
-#: ../raster/r.spread/main.c:179
-msgid "Basic sampling window SIZE needed to meet certain accuracy (3)"
-msgstr ""
-#: ../raster/r.spread/main.c:186
-#, fuzzy
-msgid "Sampling DENSity for additional COMPutin (range: 0.0 - 1.0 (0.5))"
-msgstr "के लिए"
-#: ../raster/r.spread/main.c:193
-#, fuzzy
-msgid "INITial TIME for current simulation (0) (min)"
-msgstr "समय के लिए"
-#: ../raster/r.spread/main.c:200
-msgid "Simulating time duration LAG (fill the region) (min)"
-msgstr ""
-#: ../raster/r.spread/main.c:207
-#, fuzzy
-msgid "Name of raster map as a display backdrop"
-msgstr "का a"
-#: ../raster/r.spread/main.c:214 ../raster/r.spread/main.c:222
-#: ../raster/r.spread/main.c:230
-#, fuzzy
-msgid "Output_maps"
-msgstr "नहीं"
-#: ../raster/r.spread/main.c:216
-#, fuzzy
-msgid "Name of raster map to contain OUTPUT spread time (min)"
-msgstr "का रखे हुए आउटपुट"
-#: ../raster/r.spread/main.c:224
-#, fuzzy
-msgid "Name of raster map to contain X_BACK coordinates"
-msgstr "का रखे हुए"
-#: ../raster/r.spread/main.c:232
-#, fuzzy
-msgid "Name of raster map to contain Y_BACK coordinates"
-#: ../raster/r.spread/main.c:237
-#, fuzzy
-msgid "DISPLAY 'live' spread process on screen"
-msgstr "लाइव चालू"
-#: ../raster/r.spread/main.c:239
-msgid "Live display - currently DISABLED"
-msgstr ""
-#: ../raster/r.spread/main.c:244
-msgid "For wildfires: consider SPOTTING effect"
-msgstr ""
-#: ../raster/r.spread/main.c:256
-#, fuzzy
-msgid "The display feature is disabled"
-msgstr "n"
-#: ../raster/r.spread/main.c:421
-#, fuzzy
-msgid "Reading inputs..."
-msgstr "छवि "
-#: ../raster/r.spread/main.c:463
-#, fuzzy, c-format
-msgid "Reading %s..."
-msgstr "n"
-#: ../raster/r.cost/main.c:140 ../raster/r.walk/main.c:180
-msgid "cost surface"
-msgstr ""
-#: ../raster/r.cost/main.c:141 ../raster/r.walk/main.c:181
-#: ../raster/r.spreadpath/main.c:91
-msgid "cumulative costs"
-msgstr ""
-#: ../raster/r.cost/main.c:143
-#, fuzzy
-msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
-msgstr "a का चालू किसका."
-#: ../raster/r.cost/main.c:150
-#, fuzzy
-msgid "Name of raster map containing grid cell cost information"
-msgstr "का"
-#: ../raster/r.cost/main.c:158
-#, fuzzy
-msgid "Name of output raster map with nearest start point"
-msgstr "का"
-#: ../raster/r.cost/main.c:166 ../raster/r.walk/main.c:212
-#, fuzzy
-msgid "Name of output raster map to contain movement directions"
-msgstr "का"
-#: ../raster/r.cost/main.c:171
-#, fuzzy
-msgid "Name of starting vector points map"
-msgstr "का"
-#: ../raster/r.cost/main.c:177
-#, fuzzy
-msgid "Name of stop vector points map"
-msgstr "का"
-#: ../raster/r.cost/main.c:178 ../raster/r.cost/main.c:202
-msgid "Stop"
-msgstr ""
-#: ../raster/r.cost/main.c:183
-#, fuzzy
-msgid "Name of starting raster points map"
-msgstr "का"
-#: ../raster/r.cost/main.c:192
-#, fuzzy
-msgid "Map grid coordinates of a starting point (E,N)"
-msgstr "का a बिन्दु"
-#: ../raster/r.cost/main.c:201
-#, fuzzy
-msgid "Map grid coordinates of a stopping point (E,N)"
-#: ../raster/r.cost/main.c:211
-msgid "Optional maximum cumulative cost"
-msgstr ""
-#: ../raster/r.cost/main.c:220 ../raster/r.walk/main.c:266
-#, fuzzy
-msgid "Cost assigned to null cells. By default, null cells are excluded"
-msgstr "खर्च"
-#: ../raster/r.cost/main.c:229 ../raster/r.walk/main.c:274
-#: ../raster/r.in.xyz/main.c:238 ../raster/r.in.lidar/main.c:211
-#, fuzzy
-msgid "Percent of map to keep in memory"
-msgstr "का"
-#: ../raster/r.cost/main.c:234 ../raster/r.walk/main.c:307
-#, fuzzy
-msgid "Use the 'Knight's move'; slower, but more accurate"
-msgstr "अधिक"
-#: ../raster/r.cost/main.c:238
-#, fuzzy
-msgid "Keep null values in output raster map"
-msgstr "रखें"
-#: ../raster/r.cost/main.c:242 ../raster/r.walk/main.c:315
-msgid "Start with values in raster map"
-msgstr ""
-#: ../raster/r.cost/main.c:247 ../raster/r.walk/main.c:319
-msgid "Only print info about disk space and memory requirements"
-msgstr ""
-#: ../raster/r.cost/main.c:302 ../raster/r.walk/main.c:368
-msgid "Must specify exactly one of start_points, start_rast or coordinate"
-msgstr ""
-#: ../raster/r.cost/main.c:307 ../raster/r.cost/main.c:720
-#: ../raster/r.walk/main.c:373
-#, fuzzy
-msgid "No start points"
-msgstr "घुमाएँ"
-#: ../raster/r.cost/main.c:314 ../raster/r.walk/main.c:380
-#, c-format
-msgid "Inappropriate maximum cost: %d"
-msgstr ""
-#: ../raster/r.cost/main.c:318 ../raster/r.walk/main.c:384
-#, c-format
-msgid "Inappropriate percent memory: %d"
-msgstr ""
-#: ../raster/r.cost/main.c:336
-#, fuzzy
-msgid "Assigning negative cost to null cell. Null cells excluded."
-msgstr "चेतावनी शून्य (Null)."
-#: ../raster/r.cost/main.c:409 ../raster/r.cost/main.c:419
-#: ../raster/r.walk/main.c:562 ../raster/r.walk/main.c:572
-#, c-format
-msgid "Will need at least %.2f MB of disk space"
-msgstr ""
-#: ../raster/r.cost/main.c:410 ../raster/r.cost/main.c:420
-#: ../raster/r.walk/main.c:563 ../raster/r.walk/main.c:573
-#, c-format
-msgid "Will need at least %.2f MB of memory"
-msgstr ""
-#: ../raster/r.cost/main.c:430 ../raster/r.walk/main.c:584
-#, fuzzy
-msgid "Creating some temporary files..."
-msgstr "बनाया जा रहा है."
-#: ../raster/r.cost/main.c:458
-#, fuzzy, c-format
-msgid "Reading raster map <%s>, initializing output..."
-msgstr "n"
-#: ../raster/r.cost/main.c:514 ../raster/r.walk/main.c:697
-#, fuzzy
-msgid "Initializing directional output "
-msgstr "n"
-#: ../raster/r.cost/main.c:594 ../raster/r.walk/main.c:775
-#, fuzzy, c-format
-msgid "No start points found in vector <%s>"
-msgstr "नहीं"
-#: ../raster/r.cost/main.c:606 ../raster/r.walk/main.c:787
-#, fuzzy, c-format
-msgid "Reading vector map <%s> with stop points..."
-msgstr "n"
-#: ../raster/r.cost/main.c:660 ../raster/r.walk/main.c:841
-#, fuzzy, c-format
-msgid "No stop points found in vector <%s>"
-msgstr "नहीं"
-#: ../raster/r.cost/main.c:681 ../raster/r.walk/main.c:861
-#: ../raster/r.texture/h_measure.c:594 ../imagery/i.smap/interp.c:66
-#, fuzzy
-msgid "Unable to allocate memory"
-msgstr "के लिए"
-#: ../raster/r.cost/main.c:683
-#, fuzzy, c-format
-msgid "Reading raster map <%s> with start points..."
-msgstr "n"
-#: ../raster/r.cost/main.c:734 ../raster/r.walk/main.c:914
-msgid "Specified starting location outside database window"
-msgstr ""
-#: ../raster/r.cost/main.c:755
-#, fuzzy
-msgid "Finding cost path..."
-msgstr "n"
-#: ../raster/r.cost/main.c:1009 ../raster/r.walk/main.c:1393
-#, fuzzy
-msgid "Error, ct == pres_cell"
-msgstr "त्रुटि"
-#: ../raster/r.cost/main.c:1035
-#, fuzzy, c-format
-msgid "Writing raster map with nearest start point <%s>..."
-msgstr "n"
-#: ../raster/r.cost/main.c:1128 ../raster/r.walk/main.c:1468
-#, fuzzy, c-format
-msgid "Writing movement direction file %s..."
-msgstr "छापें"
-#: ../raster/r.cost/main.c:1204 ../raster/r.walk/main.c:1516
-#, fuzzy, c-format
-msgid "Peak cost value: %f."
-msgstr "f"
-#: ../raster/r.cost/main.c:1226 ../raster/r.walk/main.c:1541
-#, c-format
-msgid "Illegal x coordinate <%s>"
-msgstr ""
-#: ../raster/r.cost/main.c:1228 ../raster/r.walk/main.c:1543
-#, c-format
-msgid "Illegal y coordinate <%s>"
-msgstr ""
-#: ../raster/r.cost/main.c:1232 ../raster/r.walk/main.c:1547
-#, fuzzy, c-format
-msgid "Warning, ignoring point outside window: %.4f,%.4f"
-msgstr "चेतावनी बिन्दु"
-#: ../raster/r.out.vtk/writeascii.c:75
-msgid "write_vtk_normal_header: Writing VTK-Header"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:108
-msgid "write_vtk_structured_elevation_header: Writing VTK-Header"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:124
-msgid "write_vtk_polygonal_elevation_header: Writing VTK-Header"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:139
-msgid "write_vtk_celldata_header: Writing VTK-DataHeader"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:148
-msgid "writeVTKPointHeader: Writing VTK-DataHeader"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:169
-#, fuzzy
-msgid "write_vtk_structured_coordinates: Writing Coordinates"
-msgstr "बिन्दु"
-#: ../raster/r.out.vtk/writeascii.c:225
-msgid "write_vtk_polygonal_coordinates: Writing VTK Polygonal data"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:334
-msgid "write_vtk_data: Writing VTK-Data"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:384
-msgid "write_vtk_rgb_image_data: Writing VTK-ImageData"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:412
-#, fuzzy
-msgid "Wrong map values! Values should in between 0 and 255!\n"
-msgstr "n"
-#: ../raster/r.out.vtk/writeascii.c:442
-msgid "write_vtk_vector_data: Writing VTK-vector data"
-msgstr ""
-#: ../raster/r.out.vtk/parameters.c:34
-#, fuzzy
-msgid "Raster map(s) to be converted to VTK-ASCII data format"
-msgstr "a."
-#: ../raster/r.out.vtk/parameters.c:49
-#: ../locale/scriptstrings/tr.out.vtk_to_translate.c:9
-#, fuzzy
-msgid "Elevation raster map"
-msgstr "का"
-#: ../raster/r.out.vtk/parameters.c:55
-#: ../locale/scriptstrings/tr.out.vtk_to_translate.c:11
-msgid "Value to represent no data cell"
-msgstr ""
-#: ../raster/r.out.vtk/parameters.c:63
-#, fuzzy
-msgid "Elevation (if no elevation map is specified)"
-msgstr "है"
-#: ../raster/r.out.vtk/parameters.c:69
-#: ../locale/scriptstrings/tr.out.vtk_to_translate.c:12
-#, fuzzy
-msgid "Create VTK point data instead of VTK cell data (if no elevation map is given)"
-msgstr "बिन्दु का है"
-#: ../raster/r.out.vtk/parameters.c:79
-#, fuzzy
-msgid "Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
-msgstr "जी"
-#: ../raster/r.out.vtk/parameters.c:89
-#, fuzzy
-msgid "Three (x,y,z) raster maps to create vector values [xmap,ymap,zmap]"
-msgstr "जी"
-#: ../raster/r.out.vtk/parameters.c:114
-#, fuzzy
-msgid "Use structured grid for elevation (not recommended)"
-msgstr "के लिए नहीं"
-#: ../raster/r.out.vtk/parameters.c:120
-#, fuzzy
-msgid "Use polydata-trianglestrips for elevation grid creation"
-msgstr "के लिए"
-#: ../raster/r.out.vtk/parameters.c:126
-#, fuzzy
-msgid "Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
-msgstr "के लिए"
-#: ../raster/r.out.vtk/parameters.c:132
-#, fuzzy
-msgid "Scale factor effects the origin (if no elevation map is given)"
-msgstr "ओरिजिन है"
-#: ../raster/r.out.vtk/main.c:61
-#, fuzzy
-msgid "Converts raster maps into the VTK-ASCII format."
-msgstr "a."
-#: ../raster/r.out.vtk/main.c:72
-msgid "No input maps specified. You need to specify at least one input map or three vector maps or three rgb maps."
-msgstr ""
-#: ../raster/r.out.vtk/main.c:130 ../raster/r.out.vtk/main.c:190
-#: ../raster/r.out.vtk/main.c:211 ../raster/r.out.vtk/main.c:250
-#, fuzzy, c-format
-msgid "Open Raster file %s"
-msgstr "खोलें"
-#: ../raster/r.out.vtk/main.c:221
-#, fuzzy
-msgid "Writing VTK ImageData\n"
-msgstr "n"
-#: ../raster/r.out.vtk/main.c:231
-#, fuzzy
-msgid "Wrong RGB maps. Maps should have the same type! RGB output not added!"
-msgstr "नक्शे नहीं!"
-#: ../raster/r.out.vtk/main.c:260
-#, fuzzy
-msgid "Writing VTK Vector Data\n"
-msgstr "n"
-#: ../raster/r.out.vtk/main.c:270
-#, fuzzy
-msgid "Wrong vector maps. Maps should have the same type! Vector output not added!"
-#: ../raster/r.out.vtk/main.c:282
-#, fuzzy
-msgid "Error closing VTK-ASCII file"
-msgstr "त्रुटि"
-#: ../raster/r.recode/main.c:49
-#, fuzzy
-msgid "recode categories"
-msgstr "n"
-#: ../raster/r.recode/main.c:50
-#, fuzzy
-msgid "Recodes categorical raster maps."
-msgstr "कवर"
-#: ../raster/r.recode/main.c:53
-#, fuzzy
-msgid "Name of raster map to be recoded"
-msgstr "का"
-#: ../raster/r.recode/main.c:59
-#, fuzzy
-msgid "File containing recode rules"
-msgstr "फ़ाइल"
-#: ../raster/r.recode/main.c:60 ../raster/r.reclass/main.c:66
-#, fuzzy
-msgid "\"-\" to read from stdin"
-msgstr "i n"
-#: ../raster/r.recode/main.c:66
-#, fuzzy
-msgid "Title for output raster map"
-msgstr "का"
-#: ../raster/r.recode/main.c:70
-#, fuzzy
-msgid "Align the current region to the input raster map"
-msgstr "पंक्तिबद्ध करें"
-#: ../raster/r.recode/main.c:74
-msgid "Force output to 'double' raster map type (DCELL)"
-msgstr ""
-#: ../raster/r.recode/main.c:95
-#, fuzzy, c-format
-msgid "No rules specified. Raster map <%s> not created."
-msgstr "नहीं"
-#: ../raster/r.recode/read_rules.c:20
-#, fuzzy, c-format
-msgid "Unable to read f_range for map %s"
-msgstr "के लिए"
-#: ../raster/r.recode/read_rules.c:24 ../display/d.colortable/main.c:149
-#, fuzzy
-msgid "Data range is empty"
-msgstr "है n"
-#: ../raster/r.recode/read_rules.c:30
-#, fuzzy, c-format
-msgid "Data range of %s is %s to %s (entire map)"
-msgstr "है n"
-#: ../raster/r.recode/read_rules.c:35 ../raster/r.stats/main.c:334
-#, fuzzy, c-format
-msgid "Unable to read range for map <%s>"
-msgstr "के लिए"
-#: ../raster/r.recode/read_rules.c:39
-#, fuzzy, c-format
-msgid "Integer data range of %s is empty"
-msgstr "है n"
-#: ../raster/r.recode/read_rules.c:41
-#, fuzzy, c-format
-msgid "Integer data range of %s is %d to %d"
-msgstr "है n"
-#: ../raster/r.recode/read_rules.c:60
-#, fuzzy
-msgid "Enter the rule or 'help' for the format description"
-msgstr "a एक का n"
-#: ../raster/r.recode/read_rules.c:84
-#, fuzzy
-msgid "Enter a rule in one of these formats:"
-msgstr "a एक का n"
-#: ../raster/r.recode/read_rules.c:86
-msgid "old_low:old_high:new_low:new_high"
-msgstr ""
-#: ../raster/r.recode/read_rules.c:87
-msgid "old_low:old_high:new_val      (i.e. new_high == new_low)"
-msgstr ""
-#: ../raster/r.recode/read_rules.c:88
-msgid "*:old_val:new_val             (interval [inf, old_val])"
-msgstr ""
-#: ../raster/r.recode/read_rules.c:89
-msgid "old_val:*:new_val             (interval [old_val, inf])"
-msgstr ""
-#: ../raster/r.recode/read_rules.c:91
-msgid "When finished type \"end\"."
-msgstr ""
-#: ../raster/r.statistics/o_skew.c:91
-msgid "o_skew: No data in array"
-msgstr ""
-#: ../raster/r.statistics/o_adev.c:93
-msgid "o_adev: No data in array"
-msgstr ""
-#: ../raster/r.statistics/o_kurt.c:91
-msgid "o_kurto: No data in array"
-msgstr ""
-#: ../raster/r.statistics/main.c:58
-#, fuzzy
-msgid "Calculates category or object oriented statistics."
-msgstr "वस्तु."
-#: ../raster/r.statistics/main.c:76 ../raster/r.statistics2/main.c:114
-#, fuzzy
-msgid "Method of object-based statistic"
-msgstr "का वस्तु"
-#: ../raster/r.statistics/main.c:80 ../raster/r.statistics2/main.c:137
-#, fuzzy
-msgid "Resultant raster map"
-msgstr "n"
-#: ../raster/r.statistics/main.c:86 ../raster/r.statistics2/main.c:143
-#, fuzzy
-msgid "Cover values extracted from the category labels of the cover map"
-msgstr "का कवर"
-#: ../raster/r.statistics/main.c:92 ../raster/r.statistics/main.c:95
-msgid "This module currently only works for integer (CELL) maps"
-msgstr ""
-#: ../raster/r.statistics/main.c:106 ../raster/r.statistics2/main.c:164
-#: ../raster/r.neighbors/main.c:233 ../raster/r.proj/main.c:244
-#: ../imagery/i.rectify/main.c:163 ../vector/v.vect.stats/main.c:278
-#, c-format
-msgid "<%s=%s> unknown %s"
-msgstr ""
-#: ../raster/r.statistics/read_stats.c:20
-msgid "Reading r.stats output"
-msgstr ""
-#: ../raster/r.statistics/o_var.c:95 ../raster/r.statistics/o_sdev.c:94
-msgid "o_var: No data in array"
-msgstr ""
-#: ../raster/r.rescale.eq/main.c:52 ../raster/r.rescale/main.c:49
-#, fuzzy
-msgid "rescale"
-msgstr "का"
-#: ../raster/r.rescale.eq/main.c:54
-#, fuzzy
-msgid "Rescales histogram equalized the range of category values in a raster map layer."
-msgstr "का a."
-#: ../raster/r.rescale.eq/main.c:64 ../raster/r.rescale/main.c:60
-#, fuzzy
-msgid "The name of the raster map to be rescaled"
-msgstr "का"
-#: ../raster/r.rescale.eq/main.c:72 ../raster/r.rescale/main.c:68
-#, fuzzy
-msgid "The input data range to be rescaled (default: full range of input map)"
-msgstr "का"
-#: ../raster/r.rescale.eq/main.c:79 ../raster/r.rescale/main.c:75
-msgid "The resulting raster map name"
-msgstr ""
-#: ../raster/r.rescale.eq/main.c:86 ../raster/r.rescale/main.c:82
-msgid "The output data range"
-msgstr ""
-#: ../raster/r.rescale.eq/main.c:93 ../raster/r.rescale/main.c:89
-#, fuzzy
-msgid "Title for new raster map"
-msgstr "के लिए"
-#: ../raster/r.rescale.eq/main.c:122
-#, c-format
-msgid "Rescale %s[%d,%d] to %s[%d,%d]"
-msgstr ""
-#: ../raster/r.rescale.eq/get_stats.c:19 ../raster/r.rescale/get_range.c:24
-#, c-format
-msgid "Reading %s ..."
-msgstr ""
-#: ../raster/r.in.png/main.c:297
-#, fuzzy, c-format
-msgid "Unable to open PNG file '%s'"
-msgstr "का"
-#: ../raster/r.in.png/main.c:300
-#, fuzzy
-msgid "Input file empty or too short"
-msgstr "है n"
-#: ../raster/r.in.png/main.c:303
-#, fuzzy
-msgid "Input file not a PNG file"
-msgstr "है n"
-#: ../raster/r.in.png/main.c:307 ../raster/r.in.png/main.c:311
-#, fuzzy
-msgid "Unable to allocate PNG structure"
-msgstr "के लिए"
-#: ../raster/r.in.png/main.c:314
-#, fuzzy
-msgid "PNG error"
-msgstr "n"
-#: ../raster/r.in.png/main.c:521
-#, fuzzy
-msgid "Imports non-georeferenced PNG format image."
-msgstr "a a."
-#: ../raster/r.in.png/main.c:531
-#, fuzzy
-msgid "Title for created raster map"
-msgstr "के लिए"
-#: ../raster/r.in.png/main.c:537
-#, fuzzy
-msgid "Display gamma"
-msgstr "n"
-#: ../raster/r.in.png/main.c:543
-#, fuzzy
-msgid "Alpha threshold"
-msgstr "अल्फा."
-#: ../raster/r.in.png/main.c:547
-#, fuzzy
-msgid "Create floating-point map (0.0 - 1.0)"
-msgstr "बिन्दु."
-#: ../raster/r.in.png/main.c:551
-#, fuzzy
-msgid "Output image file header only and exit"
-msgstr "मीटर्स"
-#: ../raster/r.los/main.c:94
-#, fuzzy
-msgid "viewshed"
-msgstr "पूर्ण n"
-#: ../raster/r.los/main.c:95
-#, fuzzy
-msgid "Line-of-sight raster analysis program."
-msgstr "का प्रोग्राम."
-#: ../raster/r.los/main.c:109
-#, fuzzy
-msgid "Coordinate identifying the viewing position"
-msgstr "निर्देशांक"
-#: ../raster/r.los/main.c:114
-#, fuzzy
-msgid "Binary (1/0) raster map to use as a mask"
-msgstr "का"
-#: ../raster/r.los/main.c:121
-msgid "Viewing position height above the ground"
-msgstr ""
-#: ../raster/r.los/main.c:129
-#, fuzzy
-msgid "Maximum distance from the viewing point (meters)"
-msgstr "बिन्दु मीटर्स"
-#: ../raster/r.los/main.c:135
-msgid "Consider earth curvature (current ellipsoid)"
-msgstr ""
-#: ../raster/r.los/main.c:162
-msgid "Lat/Long support is not (yet) implemented for this module."
-msgstr ""
-#: ../raster/r.los/main.c:167
-#, fuzzy
-msgid "Specified observer coordinate is outside current region bounds."
-msgstr "नहीं"
-#: ../raster/r.los/main.c:211
-msgid "Pattern map should be a binary 0/1 CELL map"
-msgstr ""
-#: ../raster/r.los/main.c:245
-msgid "Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
-msgstr ""
-#: ../raster/r.los/main.c:250
-#, fuzzy, c-format
-msgid "Using maximum distance from the viewing point (meters): %f"
-#: ../raster/r.his/main.c:63 ../imagery/i.his.rgb/main.c:47
-#: ../imagery/i.rgb.his/main.c:47 ../display/d.his/main.c:63
-#, fuzzy
-msgid "color transformation"
-msgstr "का"
-#: ../raster/r.his/main.c:64 ../imagery/i.his.rgb/main.c:48
-#: ../imagery/i.rgb.his/main.c:48 ../display/d.his/main.c:64
-#: ../display/d.rgb/main.c:55
-msgid "RGB"
-msgstr ""
-#: ../raster/r.his/main.c:65 ../imagery/i.his.rgb/main.c:49
-#: ../imagery/i.rgb.his/main.c:49 ../display/d.his/main.c:65
-msgid "HIS"
-msgstr ""
-#: ../raster/r.his/main.c:67
-msgid "Generates red, green and blue raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
-msgstr ""
-#: ../raster/r.his/main.c:76 ../display/d.his/main.c:76
-#, fuzzy
-msgid "Name of layer to be used for HUE"
-msgstr "का के लिए"
-#: ../raster/r.his/main.c:83 ../display/d.his/main.c:83
-#, fuzzy
-msgid "Name of layer to be used for INTENSITY"
-msgstr "का के लिए"
-#: ../raster/r.his/main.c:90 ../display/d.his/main.c:90
-#, fuzzy
-msgid "Name of layer to be used for SATURATION"
-msgstr "का के लिए"
-#: ../raster/r.his/main.c:97
-#, fuzzy
-msgid "Name of output layer to be used for RED"
-msgstr "का के लिए"
-#: ../raster/r.his/main.c:104
-#, fuzzy
-msgid "Name of output layer to be used for GREEN"
-msgstr "का के लिए"
-#: ../raster/r.his/main.c:111
-#, fuzzy
-msgid "Name of output layer to be used for BLUE"
-msgstr "का के लिए"
-#: ../raster/r.his/main.c:115 ../display/d.his/main.c:101
-msgid "Respect NULL values while drawing"
-msgstr ""
-#: ../raster/r.his/main.c:139 ../raster/r.his/main.c:155
-#: ../raster/r.his/main.c:173 ../raster/r.out.ppm3/main.c:109
-#: ../display/d.histogram/main.c:174 ../display/d.rast.num/main.c:222
-#: ../display/d.his/main.c:139 ../display/d.his/main.c:156
-#: ../display/d.his/main.c:174 ../display/d.colortable/main.c:137
-#: ../display/d.rast/display.c:23 ../display/d.rgb/main.c:100
-#: ../display/d.legend/main.c:273
-#, fuzzy, c-format
-msgid "Color file for <%s> not available"
-#: ../raster/r.buffer/read_map.c:52
-#, fuzzy, c-format
-msgid "Reading input raster map <%s>..."
-msgstr "n"
-#: ../raster/r.buffer/main.c:67 ../vector/v.buffer/main.c:212
-#: ../locale/scriptstrings/r.buffer_to_translate.c:3
-#, fuzzy
-msgid "buffer"
-msgstr "चालू"
-#: ../raster/r.buffer/main.c:69
-#, fuzzy
-msgid "Creates a raster map layer showing buffer zones surrounding cells that contain non-NULL category values."
-msgstr "a रखे हुए."
-#: ../raster/r.buffer/main.c:81
-#: ../locale/scriptstrings/r.buffer_to_translate.c:5
-msgid "Distance zone(s)"
-msgstr ""
-#: ../raster/r.buffer/main.c:88
-#: ../locale/scriptstrings/r.buffer_to_translate.c:6
-#, fuzzy
-msgid "Units of distance"
-msgstr "का"
-#: ../raster/r.buffer/main.c:94
-#: ../locale/scriptstrings/r.buffer_to_translate.c:4
-#, fuzzy
-msgid "Ignore zero (0) data cells instead of NULL cells"
-msgstr "का"
-#: ../raster/r.buffer/main.c:131
-msgid "Parse distances error"
-msgstr ""
-#: ../raster/r.buffer/main.c:150
-#, fuzzy, c-format
-msgid "Pass %d (of %d)"
-msgstr "n"
-#: ../raster/r.buffer/write_map.c:45
-#, fuzzy, c-format
-msgid "Writing output raster map <%s>..."
-msgstr "i n"
-#: ../raster/r.buffer/parse_dist.c:54
-#, fuzzy, c-format
-msgid "%s: %s - illegal distance specification"
-msgstr "है"
-#: ../raster/r.buffer/execute.c:34
-#, fuzzy
-msgid "Finding buffer zones..."
-msgstr "n"
-#: ../raster/r.resamp.stats/main.c:257 ../raster/r.resamp.rst/main.c:149
-#: ../raster/r.resample/main.c:55 ../raster/r.resamp.bspline/main.c:83
-#: ../raster/r.resamp.interp/main.c:77 ../raster/r.resamp.filter/main.c:385
-#: ../vector/v.sample/main.c:77
-#, fuzzy
-msgid "resample"
-msgstr "का"
-#: ../raster/r.resamp.stats/main.c:259
-#, fuzzy
-msgid "Resamples raster map layers to a coarser grid using aggregation."
-msgstr "a."
-#: ../raster/r.resamp.stats/main.c:269
-#, fuzzy
-msgid "Aggregation method"
-msgstr "पद्धति"
-#: ../raster/r.resamp.stats/main.c:277 ../raster/r.series/main.c:162
-#: ../raster/r.neighbors/main.c:182
-#, fuzzy
-msgid "Quantile to calculate for method=quantile"
-msgstr "के लिए"
-#: ../raster/r.resamp.stats/main.c:283 ../raster/r.series/main.c:181
-#: ../raster/r.resamp.filter/main.c:424
-msgid "Propagate NULLs"
-msgstr ""
-#: ../raster/r.resamp.stats/main.c:287
-msgid "Weight according to area (slower)"
-msgstr ""
-#: ../raster/r.resamp.stats/main.c:296 ../raster/r.series/main.c:101
-#, c-format
-msgid "Unknown method <%s>"
-msgstr ""
-#: ../raster/r.resamp.stats/main.c:370 ../raster/r.resamp.interp/main.c:355
-#: ../raster/r.resamp.filter/main.c:552
-#, fuzzy, c-format
-msgid "Unable to read color table for %s"
-msgstr "के लिए"
-#: ../raster/r.circle/main.c:54
-#, fuzzy
-msgid "Creates a raster map containing concentric rings around a given point."
-msgstr "का पृष्ठ"
-#: ../raster/r.circle/main.c:64
-#, fuzzy
-msgid "The coordinate of the center (east,north)"
-msgstr "पूर्व उत्तर"
-#: ../raster/r.circle/main.c:70
-msgid "Minimum radius for ring/circle map (in meters)"
-msgstr ""
-#: ../raster/r.circle/main.c:76
-msgid "Maximum radius for ring/circle map (in meters)"
-msgstr ""
-#: ../raster/r.circle/main.c:82
-msgid "Data value multiplier"
-msgstr ""
-#: ../raster/r.circle/main.c:86
-#, fuzzy
-msgid "Generate binary raster map"
-msgstr "बनाया जा रहा है n"
-#: ../raster/r.circle/main.c:109
-#, fuzzy
-msgid "Please specify a radius in which min < max"
-msgstr "a"
-#: ../raster/r.circle/main.c:117
-msgid "Please specify min and/or max radius when using the binary flag"
-msgstr ""
-#: ../raster/r.circle/main.c:154 ../raster/r.composite/main.c:261
-#: ../raster/r.in.gdal/main.c:973 ../raster/r.surf.fractal/main.c:85
-#, fuzzy, c-format
-msgid "Raster map <%s> created."
-msgstr "नहीं"
-#: ../raster/r.walk/main.c:183
-#, fuzzy
-msgid "Outputs a raster map layer showing the anisotropic cumulative cost of moving between different geographic locations on an input elevation raster map layer whose cell category values represent elevation combined with an input raster map layer whose cell values represent friction cost."
-msgstr "a का चालू किसका किसका."
-#: ../raster/r.walk/main.c:193
-#, fuzzy
-msgid "Name of elevation input raster map"
-msgstr "का"
-#: ../raster/r.walk/main.c:199
-#, fuzzy
-msgid "Name of input raster map containing friction costs"
-msgstr "का"
-#: ../raster/r.walk/main.c:203
-#, fuzzy
-msgid "output map with walking costs"
-msgstr "नहीं"
-#: ../raster/r.walk/main.c:204
-#, fuzzy
-msgid "Name of output raster map to contain walking costs"
-msgstr "का"
-#: ../raster/r.walk/main.c:219
-msgid "Starting points vector map"
-msgstr ""
-#: ../raster/r.walk/main.c:226
-#, fuzzy
-msgid "Stop points vector map"
-msgstr "रूकें"
-#: ../raster/r.walk/main.c:234
-#, fuzzy
-msgid "Starting points raster map"
-msgstr "का"
-#: ../raster/r.walk/main.c:242
-#, fuzzy
-msgid "The map E and N grid coordinates of a starting point (E,N)"
-#: ../raster/r.walk/main.c:250
-#, fuzzy
-msgid "The map E and N grid coordinates of a stopping point (E,N)"
-#: ../raster/r.walk/main.c:258
-msgid "An optional maximum cumulative cost"
-msgstr ""
-#: ../raster/r.walk/main.c:284
-#, fuzzy
-msgid "Coefficients for walking energy formula parameters a,b,c,d"
-msgstr "के लिए a"
-#: ../raster/r.walk/main.c:293
-#, fuzzy
-msgid "Lambda coefficients for combining walking energy and friction cost"
-msgstr "के लिए"
-#: ../raster/r.walk/main.c:302
-#, fuzzy
-msgid "Slope factor determines travel energy cost per height step"
-msgstr "ऊंचाई"
-#: ../raster/r.walk/main.c:311
-#, fuzzy
-msgid "Keep null values in output map"
-msgstr "रखें"
-#: ../raster/r.walk/main.c:389
-#, fuzzy, c-format
-msgid "Missing required value: got %d instead of 4"
-msgstr "गुमा का"
-#: ../raster/r.walk/main.c:392
-#, fuzzy, c-format
-msgid "Walking costs are a=%lf b=%lf c=%lf d=%lf"
-msgstr "a"
-#: ../raster/r.walk/main.c:397 ../raster/r.walk/main.c:405
-#, fuzzy, c-format
-msgid "Missing required value: %d"
-msgstr "गुमा"
-#: ../raster/r.walk/main.c:400
-#, fuzzy, c-format
-msgid "Lambda is %lf"
-msgstr "है"
-#: ../raster/r.walk/main.c:408
-#, fuzzy, c-format
-msgid "Slope_factor is %lf"
-msgstr "है"
-#: ../raster/r.walk/main.c:427
-#, fuzzy
-msgid "Warning: assigning negative cost to null cell. Null cells excluded."
-#: ../raster/r.walk/main.c:612
-#, fuzzy, c-format
-msgid "Reading raster maps <%s> and <%s>, initializing output..."
-msgstr "n"
-#: ../raster/r.walk/main.c:863
-#, fuzzy, c-format
-msgid "Reading %s... "
-msgstr "n"
-#: ../raster/r.walk/main.c:900
-#, fuzzy, c-format
-msgid "No start points found in raster <%s>"
-msgstr "नहीं"
-#: ../raster/r.walk/main.c:934
-msgid "Finding cost path"
-msgstr ""
-#: ../raster/r.walk/main.c:1405
-#, fuzzy, c-format
-msgid "Writing output raster map %s... "
-msgstr "i n"
-#: ../raster/r.what/main.c:92 ../display/d.where/main.c:44
-#: ../display/d.what.vect/main.c:58 ../display/d.what.rast/main.c:50
-#: ../vector/v.what.rast/main.c:70 ../vector/v.what/main.c:61
-#, fuzzy
-msgid "position"
-msgstr "नहीं n"
-#: ../raster/r.what/main.c:93 ../raster/r.what.color/main.c:89
-#: ../display/d.where/main.c:45 ../display/d.what.vect/main.c:59
-#: ../display/d.what.rast/main.c:51 ../vector/v.what.rast/main.c:71
-#: ../vector/v.what/main.c:62
-#, fuzzy
-msgid "querying"
-msgstr "चालू"
-#: ../raster/r.what/main.c:95
-#, fuzzy
-msgid "Queries raster map layers on their category values and category labels."
-msgstr "क्वैरीज़ चालू."
-#: ../raster/r.what/main.c:103
-#, fuzzy
-msgid "Name of existing raster map(s) to query"
-msgstr "का"
-#: ../raster/r.what/main.c:110
-#, fuzzy
-msgid "Size of point cache"
-msgstr "का बिन्दु"
-#: ../raster/r.what/main.c:112 ../raster/r.what/main.c:150
-#: ../display/d.legend/main.c:107 ../display/d.legend/main.c:116
-#: ../display/d.legend/main.c:124 ../display/d.legend/main.c:145
-#: ../display/d.legend/main.c:154 ../display/d.legend/main.c:161
-#: ../display/d.legend/main.c:169 ../display/d.legend/main.c:177
-#: ../display/d.legend/main.c:182 ../display/d.legend/main.c:187
-#: ../display/d.legend/main.c:192 ../display/d.legend/main.c:197
-#: ../display/d.legend/main.c:202
-msgid "Advanced"
-msgstr ""
-#: ../raster/r.what/main.c:129 ../vector/v.what/main.c:72
-#, fuzzy
-msgid "Coordinates for query"
-msgstr "के लिए"
-#: ../raster/r.what/main.c:133
-#, fuzzy
-msgid "Output header row"
-msgstr "ढाल"
-#: ../raster/r.what/main.c:137
-#, fuzzy
-msgid "Show the category labels of the grid cell(s)"
-msgstr "संपादन के लिए "
-#: ../raster/r.what/main.c:141
-msgid "Output color values as RRR:GGG:BBB"
-msgstr ""
-#: ../raster/r.what/main.c:145
-#, fuzzy
-msgid "Output integer category values, not cell values"
-msgstr "नहीं"
-#: ../raster/r.what/main.c:149
-#, fuzzy
-msgid "Turn on cache reporting"
-msgstr "चालू"
-#: ../raster/r.what/main.c:196
-#, fuzzy, c-format
-msgid "can only do up to %d raster maps"
-msgstr "का"
-#: ../raster/r.what/main.c:212
-#, fuzzy, c-format
-msgid "Unable to read category file for <%s>"
-#: ../raster/r.contour/main.c:87
-msgid "DEM"
-msgstr ""
-#: ../raster/r.contour/main.c:88
-msgid "contours"
-msgstr ""
-#: ../raster/r.contour/main.c:90
-#, fuzzy
-msgid "Produces a vector map of specified contours from a raster map."
-msgstr "a का."
-#: ../raster/r.contour/main.c:101
-#, fuzzy
-msgid "List of contour levels"
-msgstr "का"
-#: ../raster/r.contour/main.c:107
-msgid "Minimum contour level"
-msgstr ""
-#: ../raster/r.contour/main.c:113
-msgid "Maximum contour level"
-msgstr ""
-#: ../raster/r.contour/main.c:119
-msgid "Increment between contour levels"
-msgstr ""
-#: ../raster/r.contour/main.c:127
-#, fuzzy
-msgid "Minimum number of points for a contour line (0 -> no limit)"
-msgstr "संख्या का के लिए a"
-#: ../raster/r.contour/main.c:133
-msgid "Neither \"levels\" nor \"step\" parameter specified."
-msgstr ""
-#: ../raster/r.contour/main.c:141 ../raster/r.stats/main.c:307
-#, fuzzy, c-format
-msgid "Unable to read fp range of raster map <%s>"
-msgstr "डाटाटाइप."
-#: ../raster/r.contour/main.c:172 ../vector/v.net.centrality/main.c:263
-#: ../vector/v.overlay/main.c:465 ../vector/v.in.ogr/main.c:863
-#: ../vector/v.net.distance/main.c:225 ../vector/v.in.dwg/main.c:237
-#: ../vector/v.distance/main.c:955 ../vector/v.net.flow/main.c:180
-#: ../vector/v.surf.rst/main.c:579 ../vector/v.net.timetable/main.c:103
-#: ../vector/v.convert/att.c:81 ../vector/v.net.allpairs/main.c:172
-#: ../vector/v.net.components/main.c:183 ../vector/v.to.points/main.c:293
-#: ../vector/v.net.path/path.c:109 ../vector/v.in.lidar/main.c:598
-#, fuzzy, c-format
-msgid "Unable to create table: '%s'"
-msgstr "के लिए"
-#: ../raster/r.contour/main.c:177 ../vector/v.in.ogr/main.c:868
-#: ../vector/v.in.dwg/main.c:241 ../vector/v.in.ascii/main.c:504
-#: ../vector/v.reclass/main.c:300 ../vector/v.convert/att.c:86
-#: ../vector/v.in.sites/main.c:176 ../vector/v.in.dxf/write_vect.c:240
-#: ../vector/v.to.points/main.c:298 ../vector/v.in.lidar/main.c:603
-#, fuzzy, c-format
-msgid "Unable to create index for table <%s>, key <%s>"
-msgstr "i n"
-#: ../raster/r.contour/main.c:182 ../raster/r.to.vect/main.c:218
-#: ../vector/v.random/main.c:206 ../vector/v.overlay/main.c:475
-#: ../vector/v.in.ogr/main.c:874 ../vector/v.in.dwg/main.c:246
-#: ../vector/v.in.ascii/main.c:394 ../vector/v.sample/main.c:196
-#: ../vector/v.distance/main.c:960 ../vector/v.mkgrid/main.c:251
-#: ../vector/v.reclass/main.c:305 ../vector/v.convert/att.c:91
-#: ../vector/v.in.sites/main.c:181 ../vector/v.in.dxf/write_vect.c:237
-#: ../vector/v.to.points/main.c:304 ../vector/v.in.lidar/main.c:609
-#, fuzzy, c-format
-msgid "Unable to grant privileges on table <%s>"
-msgstr "चालू"
-#: ../raster/r.contour/main.c:200 ../vector/v.overlay/area_area.c:238
-#: ../vector/v.overlay/line_area.c:217 ../vector/v.convert/att.c:111
-#: ../vector/v.to.points/main.c:63
-#, fuzzy, c-format
-msgid "Unable to insert new record: '%s'"
-msgstr "के लिए"
-#: ../raster/r.contour/main.c:220 ../vector/v.generalize/displacement.c:79
-#, fuzzy
-msgid "Reading data..."
-msgstr "n"
-#: ../raster/r.contour/main.c:246
-#, fuzzy, c-format
-msgid "Range of data: min=%f, max=%f"
-msgstr "पूर्णांक"
-#: ../raster/r.contour/main.c:248
-#, fuzzy
-msgid "Range of data: empty"
-msgstr "n"
-#: ../raster/r.contour/main.c:276 ../raster/r.contour/main.c:279
-#, fuzzy
-msgid "This step value is not allowed"
-#: ../raster/r.contour/main.c:304
-#, fuzzy, c-format
-msgid "Range of levels: min = %f, max = %f"
-msgstr "पूर्णांक"
-#: ../raster/r.contour/main.c:333
-#, fuzzy
-msgid "Displacing data..."
-msgstr "n"
-#: ../raster/r.contour/cont.c:82
-#, fuzzy, c-format
-msgid "Writing vector contours (total levels %d)..."
-msgstr "n"
-#: ../raster/r.contour/cont.c:212
-#, fuzzy, c-format
-msgid "%d crossings founds"
-msgstr "नहीं"
-#: ../raster/r.contour/cont.c:263
-#, fuzzy
-msgid "Illegal edge number"
-msgstr "चेतावनी."
-#: ../raster/r.contour/cont.c:371
-#, fuzzy
-msgid "Edge number out of range"
-msgstr "का फ्रेम्स"
-#: ../raster/r.series/main.c:133 ../raster/r.series.interp/main.c:65
-#, fuzzy
-msgid "series"
-msgstr "का"
-#: ../raster/r.series/main.c:135
-#, fuzzy
-msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
-msgstr "a फंक्शन का."
-#: ../raster/r.series/main.c:144
-msgid "Input file with raster map names and optional weights per line, field separator between name and weight is |"
-msgstr ""
-#: ../raster/r.series/main.c:155
-msgid "Aggregate operation"
-msgstr ""
-#: ../raster/r.series/main.c:170
-msgid "Weighting factor for each input map, default value is 1.0 for each input map"
-msgstr ""
-#: ../raster/r.series/main.c:177
-msgid "Ignore values outside this range"
-msgstr ""
-#: ../raster/r.series/main.c:185
-#, fuzzy
-msgid "Don't keep files open"
-msgstr "फ़ाइल"
-#: ../raster/r.series/main.c:196
-msgid "input= and file= are mutually exclusive"
-msgstr ""
-#: ../raster/r.series/main.c:199
-#, fuzzy
-msgid "Please specify input= or file="
-msgstr "ज़ेड."
-#: ../raster/r.series/main.c:249 ../raster/r.series/main.c:292
-#, fuzzy, c-format
-msgid "Reading raster map <%s> using weight %f..."
-msgstr "n"
-#: ../raster/r.series/main.c:256
-#, fuzzy
-msgid "No raster map name found in input file"
-msgstr "का"
-#: ../raster/r.series/main.c:266 ../raster/r.stats/main.c:261
-#, fuzzy
-msgid "Raster map not found"
-msgstr "नहीं"
-#: ../raster/r.series/main.c:278
-msgid "input= and weights= must have the same number of values"
-msgstr ""
-#: ../raster/r.series/main.c:307
-msgid "output= and method= must have the same number of values"
-msgstr ""
-#: ../raster/r.random.surface/init.c:73
-#, c-format
-msgid "High (%d) must be greater than 1"
-msgstr ""
-#: ../raster/r.random.surface/init.c:82
-#, fuzzy, c-format
-msgid "Rastar map <%s> repeated, maps must be unique"
-msgstr "i n"
-#: ../raster/r.random.surface/init.c:92
-#, fuzzy
-msgid "Output raster map required"
-msgstr "शीर्षक"
-#: ../raster/r.random.surface/init.c:108
-#, c-format
-msgid "Seed (%d) larger than maximum (%d)"
-msgstr ""
-#: ../raster/r.random.surface/init.c:111 ../raster/r.random.surface/init.c:120
-#, c-format
-msgid " seed is set to %d"
-msgstr ""
-#: ../raster/r.random.surface/init.c:116
-#, c-format
-msgid "Seed (%d) smaller than minimum (%d)"
-msgstr ""
-#: ../raster/r.random.surface/init.c:159
-#, c-format
-msgid "Distance value (%d): %lf must be >= 0.0"
-msgstr ""
-#: ../raster/r.random.surface/init.c:187
-#, c-format
-msgid "Exponent value (%lf) must be > 0.0"
-msgstr ""
-#: ../raster/r.random.surface/init.c:211
-#, c-format
-msgid "Flat value (%lf) must be less than distance value (%lf)"
-msgstr ""
-#: ../raster/r.random.surface/init.c:232
-msgid "Must have a distance value for each filter"
-msgstr ""
-#: ../raster/r.random.surface/init.c:264
-msgid "Must have a exponent value for each filter"
-msgstr ""
-#: ../raster/r.random.surface/init.c:281
-msgid "Must have a weight value for each filter"
-msgstr ""
-#: ../raster/r.random.surface/main.c:58 ../raster/r.random/main.c:52
-#: ../raster/r.surf.random/main.c:38 ../raster/r.random.cells/main.c:46
-#: ../raster/r.surf.gauss/main.c:40 ../vector/v.random/main.c:87
-#, fuzzy
-msgid "random"
-msgstr "विशेषता"
-#: ../raster/r.random.surface/main.c:59 ../raster/r.surf.contour/main.c:61
-#: ../raster/r.surf.idw2/main.c:62 ../raster/r.surf.random/main.c:37
-#: ../raster/r.resamp.bspline/main.c:82 ../raster/r.surf.idw/main.c:104
-#: ../raster/r.surf.area/main.c:77 ../raster/r.surf.gauss/main.c:39
-#: ../raster/r.surf.fractal/main.c:39 ../vector/v.surf.rst/main.c:143
-#: ../vector/v.vol.rst/main.c:241 ../vector/v.surf.idw/main.c:86
-#: ../vector/v.surf.bspline/main.c:92
-#, fuzzy
-msgid "surface"
-msgstr "आइसोसरफेस"
-#: ../raster/r.random.surface/main.c:61
-msgid "Generates random surface(s) with spatial dependence."
-msgstr ""
-#: ../raster/r.random.surface/main.c:68
-#, fuzzy
-msgid "Name for output raster map(s)"
-msgstr "का"
-#: ../raster/r.random.surface/main.c:77
-#, fuzzy
-msgid "Maximum distance of spatial correlation (value >= 0.0)"
-msgstr "बिन्दु"
-#: ../raster/r.random.surface/main.c:85
-msgid "Distance decay exponent (value > 0.0)"
-msgstr ""
-#: ../raster/r.random.surface/main.c:94
-msgid "Distance filter remains flat before beginning exponent"
-msgstr ""
-#: ../raster/r.random.surface/main.c:102
-msgid "Random seed (SEED_MIN >= value >= SEED_MAX), default [random]"
-msgstr ""
-#: ../raster/r.random.surface/main.c:108
-#, fuzzy
-msgid "Maximum cell value of distribution"
-msgstr "संख्या का"
-#: ../raster/r.random.surface/main.c:113
-msgid "Uniformly distributed cell values"
-msgstr ""
-#: ../raster/r.random.surface/main.c:128 ../raster/r.random.cells/init.c:89
-#, fuzzy, c-format
-msgid "Generating raster map <%s>..."
-msgstr "n"
-#: ../raster/r.statistics3/main.c:76
-#, fuzzy
-msgid "Computing histograms"
-msgstr "n"
-#: ../raster/r.statistics3/main.c:111 ../raster/r.quantile/main.c:97
-#, fuzzy
-msgid "Computing bins"
-msgstr "n"
-#: ../raster/r.statistics3/main.c:166 ../raster/r.quantile/main.c:134
-#, fuzzy
-msgid "Binning data"
-msgstr "n"
-#: ../raster/r.statistics3/main.c:218 ../raster/r.quantile/main.c:179
-#, fuzzy
-msgid "Sorting bins"
-msgstr "n"
-#: ../raster/r.statistics3/main.c:242
-#, fuzzy
-msgid "Printing quantiles"
-msgstr "नक़ल"
-#: ../raster/r.statistics3/main.c:257 ../raster/r.quantile/main.c:189
-#, fuzzy
-msgid "Computing quantiles"
-msgstr "नक़ल"
-#: ../raster/r.statistics3/main.c:294
-#, fuzzy
-msgid "Generating reclass maps"
-msgstr "बनाया जा रहा है i n"
-#: ../raster/r.statistics3/main.c:309 ../raster/r.statistics2/main.c:480
-#: ../raster/r.proj/readcell.c:58 ../imagery/i.rectify/readcell.c:56
-#, fuzzy
-msgid "Unable to open temporary file"
-#: ../raster/r.statistics3/main.c:333
-#, fuzzy
-msgid "Writing output maps"
-msgstr "n"
-#: ../raster/r.statistics3/main.c:391
-msgid "Compute category quantiles using two passes."
-msgstr ""
-#: ../raster/r.statistics3/main.c:401 ../raster/r.quantile/main.c:266
-#, fuzzy
-msgid "Number of quantiles"
-#: ../raster/r.statistics3/main.c:407 ../raster/r.quantile/main.c:274
-#, fuzzy
-msgid "List of percentiles"
-msgstr "का"
-#: ../raster/r.statistics3/main.c:414 ../raster/r.quantile/main.c:280
-#, fuzzy
-msgid "Number of bins to use"
-msgstr "संख्या का"
-#: ../raster/r.statistics3/main.c:418
-#, fuzzy
-msgid "Resultant raster map(s)"
-msgstr "n"
-#: ../raster/r.statistics3/main.c:425 ../raster/r.statistics2/main.c:148
-msgid "Create reclass map with statistics as category labels"
-msgstr ""
-#: ../raster/r.statistics3/main.c:430
-#, fuzzy
-msgid "Don't create output maps; just print statistics"
-msgstr "का"
-#: ../raster/r.statistics3/main.c:442
-#, fuzzy
-msgid "Either -p or output= must be given"
-msgstr "पाठ"
-#: ../raster/r.statistics3/main.c:445
-msgid "-p and output= are mutually exclusive"
-msgstr ""
-#: ../raster/r.statistics3/main.c:469
-#, fuzzy, c-format
-msgid "Number of quantiles (%d) does not match number of output maps (%d)"
-msgstr "का नहीं जोड़ा संख्या का."
-#: ../raster/r.statistics3/main.c:478 ../raster/r.statistics2/main.c:180
-#, fuzzy
-msgid "The base map must be an integer (CELL) map"
-#: ../raster/r.statistics3/main.c:481 ../raster/r.statistics2/main.c:183
-#, fuzzy, c-format
-msgid "Unable to read range of base map <%s>"
-msgstr "डाटाटाइप."
-#: ../raster/r.statistics3/main.c:486
-#, fuzzy, c-format
-msgid "Base map <%s> has too many categories (max: %d)"
-msgstr "है"
-#: ../raster/r.in.xyz/main.c:162 ../raster/r.in.lidar/main.c:163
-#: ../vector/v.lidar.edgedetection/main.c:73
-#: ../vector/v.lidar.correction/main.c:69 ../vector/v.surf.bspline/main.c:94
-#: ../vector/v.lidar.growing/main.c:76
-msgid "LIDAR"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:164
-msgid "Create a raster map from an assemblage of many coordinates using univariate statistics."
-msgstr ""
-#: ../raster/r.in.xyz/main.c:168
-#, fuzzy
-msgid "ASCII file containing input data (or \"-\" to read from stdin)"
-#: ../raster/r.in.xyz/main.c:176 ../raster/r.in.lidar/main.c:177
-#, fuzzy
-msgid "Statistic to use for raster values"
-msgstr "के लिए."
-#: ../raster/r.in.xyz/main.c:180 ../raster/r.in.xyz/main.c:248
-#: ../raster/r.in.xyz/main.c:257 ../raster/r.in.lidar/main.c:181
-#: ../raster/r.in.lidar/main.c:221 ../raster/r.in.lidar/main.c:230
-msgid "Statistic"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:188 ../raster/r.in.arc/main.c:81
-#: ../raster/r.in.lidar/main.c:189
-#, fuzzy
-msgid "Storage type for resultant raster map"
-msgstr "के लिए"
-#: ../raster/r.in.xyz/main.c:199
-#, fuzzy
-msgid "Column number of x coordinates in input file (first column is 1)"
-msgstr "का है के लिए"
-#: ../raster/r.in.xyz/main.c:207
-#, fuzzy
-msgid "Column number of y coordinates in input file"
-msgstr "का"
-#: ../raster/r.in.xyz/main.c:215
-#, fuzzy
-msgid "Column number of data values in input file"
-msgstr "का"
-#: ../raster/r.in.xyz/main.c:223 ../raster/r.in.lidar/main.c:196
-#, fuzzy
-msgid "Filter range for z data (min,max)"
-msgstr "पूर्णांक"
-#: ../raster/r.in.xyz/main.c:230 ../raster/r.in.lidar/main.c:203
-msgid "Scale to apply to z data"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:247 ../raster/r.in.lidar/main.c:220
-#, fuzzy
-msgid "pth percentile of the values"
-msgstr "के लिए ढाल"
-#: ../raster/r.in.xyz/main.c:256 ../raster/r.in.lidar/main.c:229
-msgid "Discard <trim> percent of the smallest and <trim> percent of the largest observations"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:261 ../raster/r.in.lidar/main.c:239
-msgid "Scan data file for extent then exit"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:266 ../raster/r.in.lidar/main.c:245
-#, fuzzy
-msgid "In scan mode, print using shell script style"
-msgstr "छापें"
-#: ../raster/r.in.xyz/main.c:270
-msgid "Ignore broken lines"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:296
-#, fuzzy
-msgid "Please specify a reasonable column number."
-msgstr "ज़ेड."
-#: ../raster/r.in.xyz/main.c:307 ../raster/r.in.lidar/main.c:392
-#, fuzzy
-msgid "Invalid zrange"
-msgstr "के लिए थीटा"
-#: ../raster/r.in.xyz/main.c:394 ../raster/r.in.lidar/main.c:486
-msgid "Unable to calculate percentile without the pth option specified!"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:406 ../raster/r.in.lidar/main.c:498
-msgid "Unable to calculate trimmed mean without the trim option specified!"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:482
-msgid "If input is not from a file it is only possible to perform a single pass."
-msgstr ""
-#: ../raster/r.in.xyz/main.c:488 ../raster/r.in.lidar/main.c:561
-msgid "zrange will not be taken into account during scan"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:524 ../raster/r.in.lidar/main.c:580
-#, fuzzy
-msgid "Reading data ..."
-msgstr "n"
-#: ../raster/r.in.xyz/main.c:531 ../raster/r.in.lidar/main.c:592
-#: ../raster/r.in.poly/poly2rast.c:55
-#, fuzzy, c-format
-msgid "Pass #%d (of %d) ..."
-msgstr "n"
-#: ../raster/r.in.xyz/main.c:602 ../raster/r.in.xyz/main.c:610
-#: ../raster/r.in.xyz/main.c:1101 ../raster/r.in.xyz/main.c:1109
-#, c-format
-msgid ""
-"Not enough data columns. Incorrect delimiter or column number? Found the following character(s) in row %lu:\n"
-"[%s]"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:606 ../raster/r.in.xyz/main.c:1105
-msgid "Line ignored as requested"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:625 ../raster/r.in.xyz/main.c:1139
-#, c-format
-msgid "Bad y-coordinate line %lu column %d. <%s>"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:632 ../raster/r.in.xyz/main.c:1124
-#, c-format
-msgid "Bad x-coordinate line %lu column %d. <%s>"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:639 ../raster/r.in.xyz/main.c:1154
-#, c-format
-msgid "Bad z-coordinate line %lu column %d. <%s>"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:721 ../raster/r.in.lidar/main.c:758
-#, fuzzy
-msgid "Writing to map ..."
-msgstr "n"
-#: ../raster/r.in.xyz/main.c:1059 ../raster/r.in.lidar/main.c:1104
-#, fuzzy, c-format
-msgid "%lu points found in region."
-msgstr "नहीं"
-#: ../raster/r.in.xyz/main.c:1086 ../raster/r.in.lidar/main.c:1128
-#, fuzzy
-msgid "Scanning data ..."
-msgstr "n"
-#: ../raster/r.in.xyz/main.c:1174 ../raster/r.in.lidar/main.c:1179
-#, c-format
-msgid "Range:     min         max\n"
-msgstr ""
-#: ../raster/r.composite/main.c:73
-#, fuzzy
-msgid "composite"
-msgstr "अज्ञात क़िस्म"
-#: ../raster/r.composite/main.c:75
-#, fuzzy
-msgid "Combines red, green and blue raster maps into a single composite raster map."
-msgstr "a एकल."
-#: ../raster/r.composite/main.c:89 ../raster/r.out.ppm3/main.c:63
-#, fuzzy, c-format
-msgid "Name of raster map to be used for <%s>"
-msgstr "का के लिए"
-#: ../raster/r.composite/main.c:101
-#, fuzzy
-msgid "Number of levels to be used for each component"
-msgstr "का के लिए"
-#: ../raster/r.composite/main.c:102 ../raster/r.composite/main.c:120
-msgid "Levels"
-msgstr ""
-#: ../raster/r.composite/main.c:117
-#, fuzzy, c-format
-msgid "Number of levels to be used for <%s>"
-msgstr "का के लिए"
-#: ../raster/r.composite/main.c:127
-#, fuzzy
-msgid "Dither"
-msgstr "डिथर"
-#: ../raster/r.composite/main.c:131
-msgid "Use closest color"
-msgstr ""
-#: ../raster/r.composite/main.c:163
-#, fuzzy, c-format
-msgid "Unable to read color file of raster map <%s>"
-msgstr "के लिए."
-#: ../raster/r.composite/main.c:285
-#, fuzzy
-msgid "Creating color table for output raster map..."
-msgstr "बनाया जा रहा है के लिए."
-#: ../raster/r.solute.transport/main.c:59
-msgid "The initial concentration in [kg/m^3]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:63
-msgid "The piezometric head in [m]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:68
-msgid "The x-part of the hydraulic conductivity tensor in [m/s]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:73
-msgid "The y-part of the hydraulic conductivity tensor in [m/s]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:79
-msgid "The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - dirichlet- and 3 - transfer boundary condition"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:85
-msgid "The x-part of the diffusion tensor in [m^2/s]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:90
-msgid "The y-part of the diffusion tensor in [m^2/s]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:94
-#: ../raster/r.solute.transport/main.c:102
-#: ../raster/r.solute.transport/main.c:138
-#: ../raster/r.solute.transport/main.c:145
-#, fuzzy
-msgid "Water flow"
-msgstr "किनारा"
-#: ../raster/r.solute.transport/main.c:96
-msgid "Groundwater sources and sinks in [m^3/s]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:103
-msgid "Concentration sources and sinks bounded to a water source or sink in [kg/s]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:112
-msgid "Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical reaction)"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:117
-msgid "Retardation factor [-]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:121
-msgid "Effective porosity [-]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:125
-msgid "Top surface of the aquifer in [m]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:129
-#, fuzzy
-msgid "Bottom surface of the aquifer in [m]"
-msgstr "बेस"
-#: ../raster/r.solute.transport/main.c:132
-msgid "The resulting concentration of the numerical solute transport calculation will be written to this map. [kg/m^3]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:140
-msgid "Calculate and store the groundwater filter velocity vector part in x direction [m/s]\n"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:147
-msgid "Calculate and store the groundwater filter velocity vector part in y direction [m/s]\n"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:161
-msgid "The longditudinal dispersivity length. [m]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:169
-msgid "The transversal dispersivity length. [m]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:177
-msgid "Use this number of time loops if the CFL flag is off. The timestep will become dt/loops."
-msgstr ""
-#: ../raster/r.solute.transport/main.c:187
-msgid "Set the flow stabilizing scheme (full or exponential upwinding)."
-msgstr ""
-#: ../raster/r.solute.transport/main.c:199
-msgid "Use the Courant-Friedrichs-Lewy criteria for time step calculation"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:231
-#, fuzzy
-msgid "solute transport"
-msgstr "का"
-#: ../raster/r.solute.transport/main.c:233
-msgid "Numerical calculation program for transient, confined and unconfined solute transport in two dimensions"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:244 ../raster/r.gwflow/main.c:218
-#: ../raster/r.topidx/main.c:53
-#, fuzzy, c-format
-msgid "Lat/Long location is not supported by %s. Please reproject map first."
-msgstr "है नहीं"
-#: ../raster/r.solute.transport/main.c:258
-msgid "The direct LU solver do not work with sparse matrices"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:260
-msgid "The direct Gauss solver do not work with sparse matrices"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:370
-#, c-format
-msgid "The Courant-Friedrichs-Lewy criteria is %g it should be within [0:1]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:371
-#, c-format
-msgid "The largest stable time step is %g"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:380
-#, fuzzy, c-format
-msgid "Number of inner loops is %g"
-msgstr "का"
-#: ../raster/r.solute.transport/main.c:381
-#, c-format
-msgid "Time step for each loop %g"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:385
-#, c-format
-msgid "The time step is to large: %gs. The largest time step should be of size %gs."
-msgstr ""
-#: ../raster/r.solute.transport/main.c:397
-#, c-format
-msgid "Time step %i with time sum %g"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:543
-#, fuzzy
-msgid "Could not create and solve the linear equation system"
-msgstr "का a"
-#: ../raster/r.volume/main.c:59 ../raster/r.to.rast3/main.c:198
-#: ../vector/v.to.rast3/main.c:49
-#, fuzzy
-msgid "volume"
-msgstr "नहीं"
-#: ../raster/r.volume/main.c:61
-#, fuzzy
-msgid "Calculates the volume of data \"clumps\", and (optionally) produces a GRASS vector points map containing the calculated centroids of these clumps."
-msgstr "आवाज़ निर्धारक का a का."
-#: ../raster/r.volume/main.c:67
-msgid "Existing raster map representing data that will be summed within clumps"
-msgstr ""
-#: ../raster/r.volume/main.c:73
-#, fuzzy
-msgid "Existing raster map, preferably the output of r.clump"
-msgstr "का"
-#: ../raster/r.volume/main.c:78
-msgid "Vector points map to contain clump centroids"
-msgstr ""
-#: ../raster/r.volume/main.c:82
-msgid "Generate unformatted report"
-msgstr ""
-#: ../raster/r.volume/main.c:110
-#, fuzzy
-msgid "No data map specified"
-msgstr "नहीं."
-#: ../raster/r.volume/main.c:133
-#, fuzzy
-msgid "Unable to open centroids vector points map"
-msgstr "का"
-#: ../raster/r.gwflow/main.c:57
-#, fuzzy
-msgid "Name of input raster map with initial piezometric head in [m]"
-msgstr "नहीं."
-#: ../raster/r.gwflow/main.c:62
-msgid "Name of input raster map providing Boundary condition status: 0-inactive, 1-active, 2-dirichlet"
-msgstr ""
-#: ../raster/r.gwflow/main.c:67
-#, fuzzy
-msgid "Name of input raster map with x-part of the hydraulic conductivity tensor in [m/s]"
-msgstr "बेस"
-#: ../raster/r.gwflow/main.c:72
-#, fuzzy
-msgid "Name of input raster map with y-part of the hydraulic conductivity tensor in [m/s]"
-msgstr "बेस"
-#: ../raster/r.gwflow/main.c:77
-#, fuzzy
-msgid "Name of input raster map with water sources and sinks in [m^3/s]"
-msgstr "नहीं."
-#: ../raster/r.gwflow/main.c:81
-msgid "Name of input raster map with storativity for confined or effective porosity for unconfined groundwater flow booth in [-] "
-msgstr ""
-#: ../raster/r.gwflow/main.c:86
-msgid "Recharge"
-msgstr ""
-#: ../raster/r.gwflow/main.c:88
-#, fuzzy
-msgid "Recharge input raster map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
-msgstr "के लिए"
-#: ../raster/r.gwflow/main.c:92
-#, fuzzy
-msgid "Name of input raster map describing the top surface of the aquifer in [m]"
-msgstr "बेस"
-#: ../raster/r.gwflow/main.c:96
-#, fuzzy
-msgid "Name of input raster map describing the bottom surface of the aquifer in [m]"
-msgstr "बेस"
-#: ../raster/r.gwflow/main.c:100
-#, fuzzy
-msgid "Output raster map storing the numerical result [m]"
-msgstr "शीर्षक"
-#: ../raster/r.gwflow/main.c:106
-#, fuzzy
-msgid "Output raster map to store the groundwater filter velocity vector part in x direction [m/s]"
-msgstr "शीर्षक"
-#: ../raster/r.gwflow/main.c:112
-#, fuzzy
-msgid "Output raster map to store the groundwater filter velocity vector part in y direction [m/s]"
-msgstr "शीर्षक"
-#: ../raster/r.gwflow/main.c:118
-#, fuzzy
-msgid "Output raster map to store the groundwater budget for each cell [m^3/s]"
-msgstr "शीर्षक"
-#: ../raster/r.gwflow/main.c:126
-msgid "The type of groundwater flow"
-msgstr ""
-#: ../raster/r.gwflow/main.c:132
-#, fuzzy
-msgid "Name of input raster map providing the height of the river bed in [m]"
-msgstr "का"
-#: ../raster/r.gwflow/main.c:140
-msgid "Name of input raster map providing the water level (head) of the river with leakage connection in [m]"
-msgstr ""
-#: ../raster/r.gwflow/main.c:147
-#, fuzzy
-msgid "Name of input raster map providing the leakage coefficient of the river bed in [1/s]."
-msgstr "बेस"
-#: ../raster/r.gwflow/main.c:155
-#, fuzzy
-msgid "Name of input raster map providing the height of the drainage bed in [m]"
-msgstr "बेस"
-#: ../raster/r.gwflow/main.c:162
-#, fuzzy
-msgid "Name of input raster map providing the leakage coefficient of the drainage bed in [1/s]"
-msgstr "बेस"
-#: ../raster/r.gwflow/main.c:173
-msgid "Allocate a full quadratic linear equation system, default is a sparse linear equation system."
-msgstr ""
-#: ../raster/r.gwflow/main.c:206
-#, fuzzy
-msgid "groundwater flow"
-msgstr "किनारा"
-#: ../raster/r.gwflow/main.c:208
-msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
-msgstr ""
-#: ../raster/r.gwflow/main.c:233
-msgid "Please provide river_head, river_leak and river_bed maps"
-msgstr ""
-#: ../raster/r.gwflow/main.c:245
-msgid "Please provide drain_head and drain_leak maps"
-msgstr ""
-#: ../raster/r.gwflow/main.c:257
-msgid "The cholesky solver dos not work with sparse matrices. You may choose a full filled quadratic matrix, flag -f."
-msgstr ""
-#: ../raster/r.gwflow/main.c:287
-#, fuzzy, c-format
-msgid "Calculation time: %g"
-msgstr "n"
-#: ../raster/r.gwflow/main.c:376
-#, c-format
-msgid "Calculation of unconfined groundwater flow loop %i"
-msgstr ""
-#: ../raster/r.gwflow/main.c:399
-#, fuzzy, c-format
-msgid "Maximum difference between this and last increment: %g"
-msgstr "के लिए a i "
-#: ../raster/r.topidx/topidx.c:42 ../imagery/i.landsat.toar/main.c:472
-#, fuzzy
-msgid "Calculating..."
-msgstr "n"
-#: ../raster/r.topidx/topidx.c:278
-#, fuzzy, c-format
-msgid "Number of sinks or boundaries: %d"
-msgstr "का."
-#: ../raster/r.topidx/main.c:42
-#, fuzzy
-msgid "Creates topographic index map from elevation raster map."
-msgstr "a बीटा."
-#: ../raster/r.topidx/file_io.c:30
-#, c-format
-msgid "Current region resolution [%.2fx%.2f] lower than input map resolution [%.2fx%.2f]! Needs to be at least identical or the current region resolution lower than the input map resolution"
-msgstr ""
-#: ../raster/r.topidx/file_io.c:32 ../raster/r.fill.dir/main.c:184
-#, fuzzy
-msgid "Reading elevation map..."
-msgstr "ज़ेड"
-#: ../raster/r.topidx/file_io.c:78
-#, fuzzy
-msgid "Writing topographic index map..."
-msgstr "a"
-#: ../raster/r.ros/main.c:213
-#, fuzzy
-msgid "Generates rate of spread raster map layers."
-msgstr "के लिए."
-#: ../raster/r.ros/main.c:215
-#, fuzzy
-msgid "Generates three, or four raster map layers showing 1) the base (perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the direction of the maximum ROS, and optionally 4) the maximum potential spotting distance."
-msgstr "बेस का का."
-#: ../raster/r.ros/main.c:222
-#, fuzzy
-msgid "Name of raster map containing fuel MODELs"
-msgstr "का"
-#: ../raster/r.ros/main.c:228
-#, fuzzy
-msgid "Name of raster map containing the 1-HOUR fuel MOISTURE (%)"
-msgstr "का"
-#: ../raster/r.ros/main.c:234
-#, fuzzy
-msgid "Name of raster map containing the 10-HOUR fuel MOISTURE (%)"
-msgstr "का"
-#: ../raster/r.ros/main.c:240
-#, fuzzy
-msgid "Name of raster map containing the 100-HOUR fuel MOISTURE (%)"
-msgstr "का"
-#: ../raster/r.ros/main.c:245
-#, fuzzy
-msgid "Name of raster map containing LIVE fuel MOISTURE (%)"
-msgstr "का"
-#: ../raster/r.ros/main.c:251
-#, fuzzy
-msgid "Name of raster map containing midflame wind VELOCITYs (ft/min)"
-msgstr "का"
-#: ../raster/r.ros/main.c:257
-#, fuzzy
-msgid "Name of raster map containing wind DIRECTIONs (degree)"
-msgstr "का"
-#: ../raster/r.ros/main.c:263
-#, fuzzy
-msgid "Name of raster map containing SLOPE (degree)"
-msgstr "का"
-#: ../raster/r.ros/main.c:269
-#, fuzzy
-msgid "Name of raster map containing ASPECT (degree, anti-clockwise from E)"
-msgstr "का"
-#: ../raster/r.ros/main.c:274
-#, fuzzy
-msgid "Name of raster map containing ELEVATION (m) (required w/ -s)"
-msgstr "का मी"
-#: ../raster/r.ros/main.c:277
-#, fuzzy
-msgid "Name prefix for output raster maps (.base, .max, .maxdir)"
-msgstr "का"
-#: ../raster/r.ros/main.c:281
-msgid "Also produce maximum SPOTTING distance"
-msgstr ""
-#: ../raster/r.ros/main.c:296
-msgid "No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h moisture layers is required."
-msgstr ""
-#: ../raster/r.ros/main.c:320
-#, c-format
-msgid "A wind direction layer should be given if the wind velocity layer <%s> has been given"
-msgstr ""
-#: ../raster/r.ros/main.c:325
-#, c-format
-msgid "A wind velocity layer should be given if the wind direction layer <%s> has been given"
-msgstr ""
-#: ../raster/r.ros/main.c:339
-#, c-format
-msgid "An aspect layer should be given if the slope layer <%s> has been given"
-msgstr ""
-#: ../raster/r.ros/main.c:344
-#, c-format
-msgid "A slope layer should be given if the aspect layer <%s> has been given"
-msgstr ""
-#: ../raster/r.ros/main.c:360
-msgid "An elevation layer should be given if considering spotting"
-msgstr ""
-#: ../raster/r.ros/main.c:378 ../raster/r.ros/main.c:382
-#: ../raster/r.ros/main.c:386 ../raster/r.ros/main.c:393
-#, fuzzy, c-format
-msgid "Raster map <%s> already exists in mapset <%s>"
-msgstr "के लिए."
-#: ../raster/r.ros/main.c:815
-#, fuzzy, c-format
-msgid "Raster maps <%s>, <%s> and <%s> created."
-msgstr "नहीं"
-#: ../raster/r.in.arc/main.c:63
-#, fuzzy
-msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map."
-msgstr "a."
-#: ../raster/r.in.arc/main.c:70
-#, fuzzy
-msgid "ARC/INFO ASCII raster file (GRID) to be imported"
-msgstr "Bin"
-#: ../raster/r.in.arc/main.c:95 ../raster/r.in.ascii/main.c:95
-#, fuzzy
-msgid "Multiplier for ASCII data"
-msgstr "के लिए"
-#: ../raster/r.in.arc/main.c:115 ../raster/r.resamp.rst/main.c:553
-#: ../raster/r.in.ascii/main.c:131 ../raster/r.in.ascii/main.c:158
-#: ../display/d.title/main.c:117 ../general/g.setproj/get_stp.c:162
-#: ../general/g.setproj/get_stp.c:165 ../general/g.setproj/get_stp.c:282
-#: ../general/g.setproj/get_stp.c:286 ../vector/v.in.ascii/main.c:247
-#: ../vector/v.surf.rst/main.c:807
-#, fuzzy, c-format
-msgid "Unable to open temporary file <%s>"
-#: ../raster/r.in.arc/main.c:128 ../raster/r.in.ascii/main.c:188
-msgid "Can't get cell header"
-msgstr ""
-#: ../raster/r.in.arc/main.c:135 ../raster/r.horizon/main.c:594
-#: ../raster/r.in.ascii/main.c:195
-#, c-format
-msgid "OOPS: rows changed from %d to %d"
-msgstr ""
-#: ../raster/r.in.arc/main.c:138 ../raster/r.horizon/main.c:598
-#: ../raster/r.in.ascii/main.c:198
-#, c-format
-msgid "OOPS: cols changed from %d to %d"
-msgstr ""
-#: ../raster/r.in.arc/main.c:159 ../raster/r.in.ascii/main.c:210
-#, c-format
-msgid "Data conversion failed at row %d, col %d"
-msgstr ""
-#: ../raster/r.in.arc/main.c:226
-#, fuzzy
-msgid "Failed to copy file"
-msgstr "का"
-#: ../raster/r.in.arc/gethead.c:88
-msgid "Illegal line in header"
-msgstr ""
-#: ../raster/r.in.arc/gethead.c:157 ../raster/r.in.ascii/gethead.c:248
-#, c-format
-msgid "Duplicate \"%s\" field in header"
-msgstr ""
-#: ../raster/r.in.arc/gethead.c:162
-#, c-format
-msgid "Illegal \"%s\" value in header: \"%s\""
-msgstr ""
-#: ../raster/r.in.arc/gethead.c:170 ../raster/r.in.ascii/gethead.c:261
-#, c-format
-msgid "\"%s\" field missing from header"
-msgstr ""
-#: ../raster/r.fill.dir/wtrshed.c:95
-#, c-format
-msgid "wtrshed pass %d"
-msgstr ""
-#: ../raster/r.fill.dir/main.c:88
-#, fuzzy
-msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
-msgstr "a a a"
-#: ../raster/r.fill.dir/main.c:104
-#, fuzzy
-msgid "Name for output raster map of problem areas"
-msgstr "का"
-#: ../raster/r.fill.dir/main.c:111
-#, fuzzy
-msgid "Aspect direction format"
-msgstr "है n"
-#: ../raster/r.fill.dir/main.c:117
-msgid "Find unresolved areas only"
-msgstr ""
-#: ../raster/r.fill.dir/main.c:123
-#, fuzzy, c-format
-msgid "The '%c' flag requires '%s'to be specified"
-msgstr "का."
-#: ../raster/r.fill.dir/main.c:144
-msgid "Direction map is D8 resolution, i.e. 45 degrees"
-msgstr ""
-#: ../raster/r.fill.dir/main.c:194
-#, fuzzy
-msgid "Filling sinks..."
-msgstr "छवि "
-#: ../raster/r.fill.dir/main.c:198
-msgid "Determining flow directions for ambiguous cases..."
-msgstr ""
-#: ../raster/r.fill.dir/main.c:211
-msgid "Repeat to get the final directions..."
-msgstr ""
-#: ../raster/r.fill.dir/dopolys.c:84
-#, c-format
-msgid "Found %d unresolved areas"
-msgstr ""
-#: ../raster/r.fill.dir/resolve.c:136
-#, c-format
-msgid "Downward pass %d"
-msgstr ""
-#: ../raster/r.fill.dir/resolve.c:173
-#, c-format
-msgid "Upward pass %d"
-msgstr ""
-#: ../raster/r.mfilter/getrow.c:23
-#, fuzzy
-msgid "Error reading temporary file"
-msgstr "त्रुटि n"
-#: ../raster/r.mfilter/perform.c:40 ../raster/r.mfilter/perform.c:51
-#, fuzzy
-msgid "Unable to create temporary file"
-#: ../raster/r.mfilter/perform.c:81
-#, fuzzy, c-format
-msgid "Writing raster map <%s>"
-msgstr "i n"
-#: ../raster/r.mfilter/main.c:59
-#, fuzzy
-msgid "Performs raster map matrix filter."
-msgstr "माट्रिक्स फ़िल्टर."
-#: ../raster/r.mfilter/main.c:70
-#, fuzzy
-msgid "Path to filter file"
-msgstr "का"
-#: ../raster/r.mfilter/main.c:78
-#, fuzzy
-msgid "Number of times to repeat the filter"
-msgstr "का फ़िल्टर"
-#: ../raster/r.mfilter/main.c:79 ../raster/r.mfilter/main.c:98
-#, fuzzy
-msgid "Filter"
-msgstr "विशेषता"
-#: ../raster/r.mfilter/main.c:85
-#, fuzzy
-msgid "Output raster map title"
-msgstr "शीर्षक"
-#: ../raster/r.mfilter/main.c:97
-#, fuzzy
-msgid "Apply filter only to null data values"
-msgstr "लागू करें फ़िल्टर"
-#: ../raster/r.mfilter/main.c:124
-#, fuzzy
-msgid "Raster map too small for the size of the filter"
-msgstr "के लिए"
-#: ../raster/r.mfilter/getfilt.c:27
-#, fuzzy, c-format
-msgid "Cannot open filter file '%s'"
-msgstr "फ़ाइल"
-#: ../raster/r.mfilter/getfilt.c:47
-msgid "Illegal filter matrix size specified"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:50
-msgid "Even filter matrix size specified"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:72
-#, fuzzy
-msgid "Illegal filter matrix"
-msgstr "चेतावनी."
-#: ../raster/r.mfilter/getfilt.c:80 ../raster/r.mfilter/getfilt.c:107
-#: ../raster/r.mfilter/getfilt.c:124
-#, fuzzy
-msgid "Filter file format error"
-msgstr "है n"
-#: ../raster/r.mfilter/getfilt.c:83
-msgid "Duplicate filter divisor specified"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:101
-msgid "Illegal divisor matrix"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:110
-msgid "Duplicate filter type specified"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:117
-#, fuzzy
-msgid "Illegal filter type specified"
-msgstr "चेतावनी."
-#: ../raster/r.mfilter/getfilt.c:127
-msgid "Duplicate filter start specified"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:135
-#, c-format
-msgid "Filter start %s ignored, using UL"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:157
-#, fuzzy
-msgid "Illegal filter file format"
-msgstr "है n"
-#: ../raster/r.statistics2/main.c:104
-#, fuzzy
-msgid "Calculates category or object oriented statistics (accumulator-based statistics)."
-msgstr "वस्तु."
-#: ../raster/r.statistics2/main.c:177
-#, fuzzy, c-format
-msgid "Unable to read category file of cover map <%s>"
-#: ../raster/r.statistics2/main.c:247
-msgid "First pass"
-msgstr ""
-#: ../raster/r.statistics2/main.c:326
-msgid "Second pass"
-msgstr ""
-#: ../raster/r.statistics2/main.c:472
-#, fuzzy
-msgid "Generating reclass map"
-#: ../raster/r.statistics2/main.c:494
-#, fuzzy
-msgid "Writing output map"
-msgstr "n"
-#: ../raster/r.out.arc/main.c:63
-#, fuzzy
-msgid "Converts a raster map layer into an ESRI ARCGRID file."
-msgstr "a."
-#: ../raster/r.out.arc/main.c:71
-#, fuzzy
-msgid "Name of an output ARC-GRID map (use out=- for stdout)"
-msgstr "का के लिए"
-#: ../raster/r.out.arc/main.c:78
-#, fuzzy
-msgid "Number of decimal places"
-msgstr "का"
-#: ../raster/r.out.arc/main.c:88
-#, fuzzy
-msgid "List one entry per line instead of full row"
-msgstr "एक प्रविष्टि का"
-#: ../raster/r.out.arc/main.c:94
-#, fuzzy
-msgid "Use cell center reference in header instead of cell corner"
-#: ../raster/r.rescale/main.c:51
-#, fuzzy
-msgid "Rescales the range of category values in a raster map layer."
-msgstr "का a."
-#: ../raster/r.rescale/main.c:118
-#, c-format
-msgid "Rescale %s[%ld,%ld] to %s[%ld,%ld]"
-msgstr ""
-#: ../raster/r.clump/clump.c:99
-#, fuzzy, c-format
-msgid "Pass %d..."
-msgstr "n"
-#: ../raster/r.clump/main.c:48 ../vector/v.reclass/main.c:68
-msgid "reclass"
-msgstr ""
-#: ../raster/r.clump/main.c:50
-#, fuzzy
-msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
-msgstr "a."
-#: ../raster/r.clump/main.c:61
-msgid "Title"
-msgstr ""
-#: ../raster/r.clump/main.c:96
-#, fuzzy, c-format
-msgid "%d clumps."
-msgstr "नहीं"
-#: ../raster/r.colors/edit_colors.c:58
-#, fuzzy
-msgid "Creates/modifies the color table associated with a 3D raster map."
-msgstr "a."
-#: ../raster/r.colors/edit_colors.c:62
-#, fuzzy
-msgid "Creates/modifies the color table associated with a raster map."
-msgstr "a."
-#: ../raster/r.colors/edit_colors.c:73 ../raster/r.colors/edit_colors.c:80
-#: ../raster/r.colors/edit_colors.c:87 ../raster/r.colors/edit_colors.c:94
-#: ../raster/r.colors/edit_colors.c:115 ../raster/r.colors/edit_colors.c:120
-#: ../raster/r.colors/edit_colors.c:125 ../raster/r.colors/edit_colors.c:130
-#: ../vector/v.colors/main.c:67 ../vector/v.colors/main.c:78
-#: ../vector/v.colors/main.c:85 ../vector/v.colors/main.c:92
-#: ../vector/v.colors/main.c:99 ../vector/v.colors/main.c:125
-#: ../vector/v.colors/main.c:130 ../vector/v.colors/main.c:135
-#, fuzzy
-msgid "Define"
-msgstr "n"
-#: ../raster/r.colors/edit_colors.c:79 ../vector/v.colors/main.c:84
-#, fuzzy
-msgid "Raster map from which to copy color table"
-msgstr "नक़ल"
-#: ../raster/r.colors/edit_colors.c:86 ../vector/v.colors/main.c:91
-#, fuzzy
-msgid "3D raster map from which to copy color table"
-msgstr "नक़ल"
-#: ../raster/r.colors/edit_colors.c:92 ../vector/v.colors/main.c:97
-#, fuzzy
-msgid "Path to rules file"
-msgstr "का"
-#: ../raster/r.colors/edit_colors.c:93 ../vector/v.colors/main.c:98
-#, fuzzy
-msgid "\"-\" to read rules from stdin"
-msgstr "उत्तर पूर्व"
-#: ../raster/r.colors/edit_colors.c:98 ../vector/v.colors/main.c:108
-#, fuzzy
-msgid "Remove existing color table"
-msgstr "रखें"
-#: ../raster/r.colors/edit_colors.c:99 ../raster/r.null/main.c:107
-#: ../vector/v.colors/main.c:109
-#: ../locale/scriptstrings/r.mask_to_translate.c:10
-#: ../locale/scriptstrings/g.extension_to_translate.c:25
-#, fuzzy
-msgid "Remove"
-msgstr "के लिए n"
-#: ../raster/r.colors/edit_colors.c:104 ../vector/v.colors/main.c:114
-msgid "Only write new color table if one doesn't already exist"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:108 ../vector/v.colors/main.c:118
-#, fuzzy
-msgid "List available rules then exit"
-msgstr "स्रोत"
-#: ../raster/r.colors/edit_colors.c:114 ../vector/v.colors/main.c:124
-#, fuzzy
-msgid "Invert colors"
-msgstr "n"
-#: ../raster/r.colors/edit_colors.c:119 ../vector/v.colors/main.c:129
-msgid "Logarithmic scaling"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:124 ../vector/v.colors/main.c:134
-msgid "Logarithmic-absolute scaling"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:129
-msgid "Histogram equalization"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:147
-#, fuzzy, c-format
-msgid "No %s map specified"
-msgstr "नहीं."
-#: ../raster/r.colors/edit_colors.c:150
-#, c-format
-msgid "Options <%s> and <%s> options are mutually exclusive"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:159
-#, fuzzy, c-format
-msgid "One of -%c or options <%s>, <%s> or <%s> must be specified"
-msgstr "पाठ"
-#: ../raster/r.colors/edit_colors.c:164
-#, c-format
-msgid "Options <%s>, <%s>, and <%s> options are mutually exclusive"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:169 ../vector/v.colors/main.c:189
-#, c-format
-msgid "Flags -%c and -%c flags are mutually exclusive"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:182
-#, fuzzy, c-format
-msgid "%s map <%s> not found"
-msgstr "नहीं"
-#: ../raster/r.colors/edit_colors.c:192
-#, fuzzy, c-format
-msgid "Unable to remove color table of %s map <%s>"
-msgstr "के लिए."
-#: ../raster/r.colors/edit_colors.c:194
-#, fuzzy, c-format
-msgid "Color table of %s map <%s> not found"
-msgstr "नहीं"
-#: ../raster/r.colors/edit_colors.c:210 ../vector/v.colors/main.c:218
-msgid "Color table exists. Exiting."
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:233
-#, fuzzy, c-format
-msgid "Color table 'random' is not supported for floating point %s map"
-msgstr "है के लिए बिन्दु!"
-#: ../raster/r.colors/edit_colors.c:237
-#, fuzzy, c-format
-msgid "Color table 'grey.eq' is not supported for floating point %s map"
-#: ../raster/r.colors/edit_colors.c:243
-#, fuzzy, c-format
-msgid "Color table 'grey.log' is not supported for floating point %s map"
-#: ../raster/r.colors/edit_colors.c:251
-#, fuzzy, c-format
-msgid "Unknown color request '%s'"
-msgstr "n"
-#: ../raster/r.colors/edit_colors.c:261 ../vector/v.colors/make_colors.c:51
-#, fuzzy, c-format
-msgid "Unable to load rules file <%s>"
-msgstr "के लिए"
-#: ../raster/r.colors/edit_colors.c:278 ../vector/v.colors/main.c:274
-#, fuzzy, c-format
-msgid "Unable to read color table for 3D raster map <%s>"
-msgstr "के लिए."
-#: ../raster/r.colors/edit_colors.c:318
-#, fuzzy, c-format
-msgid "Color table for %s map <%s> set to '%s'"
-msgstr "के लिए."
-#: ../raster/r.colors/rules.c:40
-#, fuzzy, c-format
-msgid "Enter rules, \"end\" when done, \"help\" if you need it.\n"
-msgstr "सम्पन्न n"
-#: ../raster/r.colors/rules.c:49
-#, fuzzy, c-format
-msgid "fp: Data range is %s to %s\n"
-msgstr "है n"
-#: ../raster/r.colors/rules.c:53
-#, fuzzy, c-format
-msgid "Data range is %ld to %ld\n"
-msgstr "है n"
-#: ../raster/r.colors/rules.c:64
-#, fuzzy, c-format
-msgid ""
-"Your color rules do not cover the whole range of data!\n"
-" (rules %f to %f but data %f to %f)"
-msgstr "नहीं कवर का!"
-#: ../raster/r.colors/rules.c:104 ../raster/r.reclass/parse.c:41
-#, fuzzy, c-format
-msgid "Enter a rule in one of these formats:\n"
-msgstr "a एक का n"
-#: ../raster/r.colors/rules.c:105
-#, fuzzy, c-format
-msgid " val color\n"
-msgstr "n"
-#: ../raster/r.colors/rules.c:106
-#, fuzzy, c-format
-msgid " n%% color\n"
-msgstr "n n"
-#: ../raster/r.colors/rules.c:107
-#, fuzzy, c-format
-msgid " nv color\n"
-msgstr "n"
-#: ../raster/r.colors/rules.c:108
-#, fuzzy, c-format
-msgid " default color\n"
-msgstr "n"
-#: ../raster/r.colors/rules.c:109
-#, fuzzy, c-format
-msgid "color can be one of:\n"
-msgstr "एक का n"
-#: ../raster/r.colors/rules.c:111
-#, fuzzy, c-format
-msgid "or an R:G:B triplet, e.g.: 0:127:255\n"
-msgstr "R जी जी n"
-#: ../raster/r.colors/rules.c:132
-#, fuzzy, c-format
-msgid "bad rule (%s); rule not added"
-msgstr "है नहीं n"
-#: ../raster/r.colors/rules.c:134
-#, c-format
-msgid "bad rule (%s): [%s]"
-msgstr ""
-#: ../raster/r.colors/stats.c:71 ../raster/r.to.rast3/main.c:291
-#: ../raster/r.to.rast3elev/main.c:443
-#, fuzzy
-msgid "Error opening 3d raster map"
-msgstr "त्रुटि"
-#: ../raster/r.colors/stats.c:84
-msgid "Unable to use logarithmic scaling if range includes zero"
-msgstr ""
-#: ../raster/r.colors/stats.c:112
-#, fuzzy, c-format
-msgid "Reading map <%s>..."
-msgstr "छवि "
-#: ../raster/r.to.rast3/main.c:59 ../raster/r.to.rast3elev/main.c:136
-#, fuzzy
-msgid "Could not close the map"
-msgstr "नहीं"
-#: ../raster/r.to.rast3/main.c:79
-msgid "2d raster maps which represent the slices"
-msgstr ""
-#: ../raster/r.to.rast3/main.c:84 ../raster/r.to.rast3elev/main.c:175
-msgid "The maximum tile size in kilo bytes. Default is 32KB."
-msgstr ""
-#: ../raster/r.to.rast3/main.c:93
-msgid "Use RASTER3D mask (if exists) with output map"
-msgstr ""
-#: ../raster/r.to.rast3/main.c:199 ../raster/r.to.vect/main.c:71
-#: ../raster/r.in.ascii/main.c:71 ../raster/r.to.rast3elev/main.c:364
-#: ../vector/v.convert/main.c:38 ../vector/v.to.rast3/main.c:50
-#: ../vector/v.to.rast/main.c:42
-#: ../locale/scriptstrings/v.convert.all_to_translate.c:4
-#, fuzzy
-msgid "conversion"
-msgstr "त्रुटि"
-#: ../raster/r.to.rast3/main.c:201
-#, fuzzy
-msgid "Converts 2D raster map slices to one 3D raster volume map."
-msgstr "एक"
-#: ../raster/r.to.rast3/main.c:213
-#, fuzzy
-msgid "No output map"
-msgstr "नहीं"
-#: ../raster/r.to.rast3/main.c:230 ../raster/r.to.rast3elev/main.c:427
-msgid "The 2d and 3d region settings are different. I will use the g3d settings to adjust the 2d region."
-msgstr ""
-#: ../raster/r.to.rast3/main.c:262
-#, c-format
-msgid "Open raster map %s - one time for each depth (%d/%d)"
-msgstr ""
-#: ../raster/r.to.rast3/main.c:275
-msgid "Input maps have to be from the same type. CELL, FCELL or DCELL!"
-msgstr ""
-#: ../raster/r.to.rast3/main.c:279 ../raster/r.to.rast3elev/main.c:457
-#, fuzzy
-msgid "Creating 3D raster map"
-#: ../raster/r.sun/main.c:230
-msgid "sun energy"
-msgstr ""
-#: ../raster/r.sun/main.c:231
-msgid "Solar irradiance and irradiation model."
-msgstr ""
-#: ../raster/r.sun/main.c:233
-#, fuzzy
-msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
-msgstr "के लिए जी a पाठ a कोण का है."
-#: ../raster/r.sun/main.c:247 ../raster/r.horizon/main.c:196
-#, fuzzy
-msgid "Name of the input elevation raster map [meters]"
-msgstr "का मीटर्स"
-#: ../raster/r.sun/main.c:248 ../raster/r.sun/main.c:257
-#: ../raster/r.sun/main.c:266 ../raster/r.sun/main.c:275
-#: ../raster/r.sun/main.c:283 ../raster/r.sun/main.c:292
-#: ../raster/r.sun/main.c:302 ../raster/r.sun/main.c:312
-#: ../raster/r.sun/main.c:322 ../raster/r.sun/main.c:332
-#: ../raster/r.sun/main.c:341 ../raster/r.sun/main.c:350
-#: ../raster/r.sun/main.c:359 ../raster/r.sun/main.c:367
-#: ../raster/r.sun/main.c:375 ../raster/r.horizon/main.c:197
-#: ../raster/r.horizon/main.c:206 ../raster/r.horizon/main.c:214
-#: ../raster/r.horizon/main.c:222 ../raster/r.horizon/main.c:230
-#: ../raster/r.horizon/main.c:238 ../raster/r.horizon/main.c:246
-#: ../raster/r.horizon/main.c:254 ../raster/r.horizon/main.c:262
-#: ../raster/simwe/r.sim.sediment/main.c:175
-#: ../raster/simwe/r.sim.water/main.c:184
-msgid "Input_options"
-msgstr ""
-#: ../raster/r.sun/main.c:256
-#, fuzzy
-msgid "Name of the input aspect map (terrain aspect or azimuth of the solar panel) [decimal degrees]"
-msgstr "का का कोण"
-#: ../raster/r.sun/main.c:265
-#, fuzzy
-msgid "A single value of the orientation (aspect), 270 is south"
-msgstr "एकल का कोण"
-#: ../raster/r.sun/main.c:274
-#, fuzzy
-msgid "Name of the input slope raster map (terrain slope or solar panel inclination) [decimal degrees]"
-msgstr "का ढाल ढाल कोण"
-#: ../raster/r.sun/main.c:282
-#, fuzzy
-msgid "A single value of inclination (slope)"
-#: ../raster/r.sun/main.c:291
-#, fuzzy
-msgid "Name of the Linke atmospheric turbidity coefficient input raster map [-]"
-msgstr "का"
-#: ../raster/r.sun/main.c:301
-#, fuzzy
-msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
-msgstr "एकल का"
-#: ../raster/r.sun/main.c:311
-#, fuzzy
-msgid "Name of the ground albedo coefficient input raster map [-]"
-msgstr "का"
-#: ../raster/r.sun/main.c:321
-#, fuzzy
-msgid "A single value of the ground albedo coefficient [-]"
-msgstr "एकल का"
-#: ../raster/r.sun/main.c:331
-#, fuzzy
-msgid "Name of input raster map containing latitudes [decimal degrees]"
-msgstr "का"
-#: ../raster/r.sun/main.c:340
-#, fuzzy
-msgid "Name of input raster map containing longitudes [decimal degrees]"
-msgstr "का"
-#: ../raster/r.sun/main.c:349
-#, fuzzy
-msgid "Name of real-sky beam radiation coefficient (thick cloud) input raster map [0-1]"
-msgstr "का"
-#: ../raster/r.sun/main.c:358
-#, fuzzy
-msgid "Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
-msgstr "का"
-#: ../raster/r.sun/main.c:366
-#, fuzzy
-msgid "The horizon information input map prefix"
-msgstr "सीमा नहीं."
-#: ../raster/r.sun/main.c:374 ../raster/r.horizon/main.c:213
-msgid "Angle step size for multidirectional horizon [degrees]"
-msgstr ""
-#: ../raster/r.sun/main.c:383
-#, fuzzy
-msgid "Output incidence angle raster map (mode 1 only)"
-msgstr "कोण"
-#: ../raster/r.sun/main.c:384 ../raster/r.sun/main.c:393
-#: ../raster/r.sun/main.c:402 ../raster/r.sun/main.c:411
-#: ../raster/r.sun/main.c:420 ../raster/r.sun/main.c:429
-#: ../raster/r.horizon/main.c:271 ../raster/r.horizon/main.c:281
-#: ../raster/r.horizon/main.c:289 ../raster/simwe/r.sim.sediment/main.c:168
-#: ../raster/simwe/r.sim.water/main.c:216 ../vector/v.vol.rst/main.c:377
-#: ../vector/v.vol.rst/main.c:394 ../vector/v.vol.rst/main.c:404
-#: ../vector/v.vol.rst/main.c:413 ../vector/v.vol.rst/main.c:422
-#: ../vector/v.vol.rst/main.c:431 ../vector/v.vol.rst/main.c:440
-msgid "Output_options"
-msgstr ""
-#: ../raster/r.sun/main.c:392
-#, fuzzy
-msgid "Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
-msgstr "प मी मी"
-#: ../raster/r.sun/main.c:401
-#, fuzzy
-msgid "Output insolation time raster map [h] (mode 2 only)"
-msgstr "h"
-#: ../raster/r.sun/main.c:410
-#, fuzzy
-msgid "Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
-msgstr "प मी मी"
-#: ../raster/r.sun/main.c:419
-#, fuzzy
-msgid "Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
-msgstr "प मी मी"
-#: ../raster/r.sun/main.c:428
-#, fuzzy
-msgid "Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)"
-msgstr "प मी मी"
-#: ../raster/r.sun/main.c:435
-#, fuzzy
-msgid "No. of day of the year (1-365)"
-msgstr "नहीं का का वर्ष"
-#: ../raster/r.sun/main.c:444
-#, fuzzy
-msgid "Time step when computing all-day radiation sums [decimal hours]"
-msgstr "सभी"
-#: ../raster/r.sun/main.c:451
-#, fuzzy
-msgid "Declination value (overriding the internally computed value) [radians]"
-msgstr "उतार"
-#: ../raster/r.sun/main.c:459
-#, fuzzy
-msgid "Local (solar) time (to be set for mode 1 only) [decimal hours]"
-msgstr "सेट के लिए"
-#: ../raster/r.sun/main.c:482 ../raster/r.horizon/main.c:288
-msgid "Sampling distance step coefficient (0.5-1.5)"
-msgstr ""
-#: ../raster/r.sun/main.c:490
-msgid "Read the input files in this number of chunks"
-msgstr ""
-#: ../raster/r.sun/main.c:497
-msgid "Civil time zone value, if none, the time will be local solar time"
-msgstr ""
-#: ../raster/r.sun/main.c:503
-#, fuzzy
-msgid "Incorporate the shadowing effect of terrain"
-msgstr "का"
-#: ../raster/r.sun/main.c:508
-msgid "Use the low-memory version of the program"
-msgstr ""
-#: ../raster/r.sun/main.c:555
-msgid "You must give the longitude raster if you use civil time"
-msgstr ""
-#: ../raster/r.sun/main.c:558
-#, fuzzy
-msgid "Error reading civil time zone value"
-msgstr "त्रुटि के लिए"
-#: ../raster/r.sun/main.c:561
-#, fuzzy
-msgid "Invalid civil time zone value"
-msgstr "के लिए"
-#: ../raster/r.sun/main.c:586
-msgid "insol_time and incidout are incompatible options"
-msgstr ""
-#: ../raster/r.sun/main.c:591
-#, fuzzy
-msgid "Error reading time step size"
-#: ../raster/r.sun/main.c:593
-#, fuzzy
-msgid "Invalid time step size"
-#: ../raster/r.sun/main.c:597
-#, fuzzy
-msgid "Error reading horizon step size"
-msgstr "त्रुटि."
-#: ../raster/r.sun/main.c:601
-msgid "The horizon step size must be greater than 0."
-msgstr ""
-#: ../raster/r.sun/main.c:604
-msgid "If you use the horizon option you must also set the 'horizonstep' parameter."
-msgstr ""
-#: ../raster/r.sun/main.c:610
-msgid "Time and insol_time are incompatible options"
-msgstr ""
-#: ../raster/r.sun/main.c:612
-msgid "Mode 1: instantaneous solar incidence angle & irradiance using a set local time"
-msgstr ""
-#: ../raster/r.sun/main.c:617
-msgid "incidout requires time parameter to be set"
-msgstr ""
-#: ../raster/r.sun/main.c:619
-msgid "Mode 2: integrated daily irradiation for a given day of the year"
-msgstr ""
-#: ../raster/r.sun/main.c:665
-msgid "If you use -s and no horizon rasters, numpartitions must be =1"
-msgstr ""
-#: ../raster/r.sun/main.c:678
-msgid "If you want to save memory and to use shadows, you must use pre-calculated horizons."
-msgstr ""
-#: ../raster/r.sun/main.c:723 ../imagery/i.latlong/main.c:102
-#: ../display/d.where/main.c:106 ../general/g.region/printwindow.c:247
-#: ../general/g.region/printwindow.c:503 ../general/g.region/printwindow.c:622
-#, fuzzy
-msgid "Can't get projection info of current location"
-msgstr "का"
-#: ../raster/r.sun/main.c:727 ../raster/r.horizon/main.c:475
-#: ../imagery/i.latlong/main.c:104 ../display/d.where/main.c:109
-#: ../general/g.region/printwindow.c:250 ../general/g.region/printwindow.c:506
-#: ../general/g.region/printwindow.c:625
-#, fuzzy
-msgid "Can't get projection units of current location"
-msgstr "का"
-#: ../raster/r.sun/main.c:731 ../raster/r.horizon/main.c:479
-#: ../imagery/i.latlong/main.c:106 ../ps/ps.map/do_geogrid.c:271
-#: ../display/d.where/main.c:112 ../display/d.grid/plot.c:335
-#: ../general/g.region/printwindow.c:253 ../general/g.region/printwindow.c:509
-#: ../general/g.region/printwindow.c:628
-#, fuzzy
-msgid "Can't get projection key values of current location"
-msgstr "का"
-#: ../raster/r.sun/main.c:741 ../raster/r.horizon/main.c:489
-#: ../imagery/i.latlong/main.c:115 ../ps/ps.map/do_geogrid.c:277
-#: ../display/d.where/main.c:119 ../display/d.where/main.c:145
-#: ../display/d.grid/plot.c:342 ../display/d.grid/plot.c:369
-#, fuzzy
-msgid "Unable to set up lat/long projection parameters"
-msgstr "सेट"
-#: ../raster/r.sun/main.c:745
-msgid "latin and longin raster maps have no effect when in a Lat/Lon location"
-msgstr ""
-#: ../raster/r.sun/main.c:750
-msgid "Both latin and longin raster maps must be given, or neither"
-msgstr ""
-#: ../raster/r.le/r.le.patch/main.c:50
-msgid "Calculates attribute, patch size, core (interior) size, shape, fractal dimension, and perimeter measures for sets of patches in a landscape."
-msgstr ""
-#: ../raster/r.le/r.le.trace/main.c:58
-msgid "Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file."
-msgstr ""
-#: ../raster/r.le/r.le.setup/main.c:59
-msgid "Interactive tool used to setup the sampling and analysis framework that will be used by the other r.le programs."
-msgstr ""
-#: ../raster/r.le/r.le.setup/main.c:63
-#, fuzzy
-msgid "Raster map to use to setup sampling"
-msgstr "का"
-#: ../raster/r.le/r.le.setup/main.c:67
-#, fuzzy
-msgid "Vector map to overlay"
-msgstr "सदिश"
-#: ../raster/r.le/r.le.setup/sample.c:1049
-#, fuzzy
-msgid "Cannot read vector"
-msgstr "के लिए"
-#: ../raster/r.le/r.le.pixel/main.c:47
-msgid "Contains a set of measures for attributes, diversity, texture, juxtaposition, and edge."
-msgstr ""
-#: ../raster/r.digit/get_label.c:31
-#, fuzzy, c-format
-msgid "Enter the category number for this %s: "
-#: ../raster/r.digit/get_label.c:46
-#, fuzzy, c-format
-msgid "Enter a label for category %ld [%s] "
-#: ../raster/r.digit/get_label.c:68
-msgid "Look ok? "
-msgstr ""
-#: ../raster/r.digit/main.c:46
-#, fuzzy
-msgid "Interactive tool used to draw and save vector features on a graphics monitor using a pointing device (mouse) and save to a raster map."
-msgstr "चालू a a."
-#: ../raster/r.digit/main.c:55
-msgid "Display commands to be used for canvas backdrop (separated by ';')"
-msgstr ""
-#: ../raster/r.digit/main.c:78
-#, fuzzy
-msgid "No graphics device selected!"
-msgstr "नहीं"
-#: ../raster/r.digit/main.c:97
-msgid "No map created"
-msgstr ""
-#: ../raster/r.digit/get_type.c:31
-#, c-format
-msgid "Please choose one of the following\n"
-msgstr ""
-#: ../raster/r.digit/get_type.c:32
-#, c-format
-msgid "   A define an area\n"
-msgstr ""
-#: ../raster/r.digit/get_type.c:33
-#, c-format
-msgid "   C define a circle\n"
-msgstr ""
-#: ../raster/r.digit/get_type.c:34
-#, c-format
-msgid "   L define a line\n"
-msgstr ""
-#: ../raster/r.digit/get_type.c:35
-#, c-format
-msgid "   X exit (and create map)\n"
-msgstr ""
-#: ../raster/r.digit/get_type.c:36
-#, c-format
-msgid "   Q quit (without creating map)\n"
-msgstr ""
-#: ../raster/r.digit/digitize.c:49
-msgid "Quit without creating a map?? "
-msgstr ""
-#: ../raster/r.surf.contour/main.c:62 ../raster/r.surf.idw2/main.c:63
-#: ../raster/r.series.interp/main.c:66 ../raster/r.resamp.bspline/main.c:84
-#: ../raster/r.surf.idw/main.c:105 ../vector/v.surf.rst/main.c:144
-#: ../vector/v.vol.rst/main.c:242 ../vector/v.surf.idw/main.c:87
-#: ../vector/v.surf.bspline/main.c:93
-#: ../locale/scriptstrings/v.krige_to_translate.c:4
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:4
-#, fuzzy
-msgid "interpolation"
-msgstr "पद्धति"
-#: ../raster/r.surf.contour/main.c:64
-#, fuzzy
-msgid "Generates surface raster map from rasterized contours."
-msgstr "सतह प्रोग्राम."
-#: ../raster/r.surf.contour/main.c:67
-#, fuzzy
-msgid "Name of input raster map containing contours"
-msgstr "का"
-#: ../raster/r.in.bin/main.c:50 ../raster/r.in.bin/main.c:59
-#: ../raster/r.in.bin/main.c:512
-#, fuzzy
-msgid "Error reading data"
-msgstr "त्रुटि."
-#: ../raster/r.in.bin/main.c:238
-#, fuzzy
-msgid "Import a binary raster file into a GRASS raster map layer."
-msgstr "आयात a a."
-#: ../raster/r.in.bin/main.c:243
-#, fuzzy
-msgid "Import as floating-point data (default: integer)"
-msgstr "आयात फ्लोटिंग बिंदु पूर्णांक"
-#: ../raster/r.in.bin/main.c:248
-#, fuzzy
-msgid "Import as double-precision floating-point data (default: integer)"
-msgstr "आयात दोगुना पूर्णांक"
-#: ../raster/r.in.bin/main.c:252
-msgid "Signed data (two's complement)"
-msgstr ""
-#: ../raster/r.in.bin/main.c:253 ../raster/r.in.bin/main.c:258
-#: ../raster/r.in.bin/main.c:287 ../raster/r.in.bin/main.c:348
-#: ../raster/r.resamp.rst/main.c:224 ../raster/r.resamp.rst/main.c:232
-#: ../raster/r.resamp.rst/main.c:240 ../raster/r.resamp.rst/main.c:248
-#: ../raster/r.resamp.rst/main.c:256 ../raster/r.slope.aspect/main.c:179
-#: ../raster/r.slope.aspect/main.c:189 ../raster/r.slope.aspect/main.c:247
-#: ../raster/r.slope.aspect/main.c:256 ../raster/r.slope.aspect/main.c:262
-#: ../raster/r.resamp.bspline/main.c:109 ../raster/r.resamp.bspline/main.c:117
-#: ../raster/r.resamp.bspline/main.c:126 ../raster/r.resamp.bspline/main.c:134
-#: ../raster/r.resamp.bspline/main.c:139 ../imagery/i.landsat.toar/main.c:152
-#: ../imagery/i.landsat.toar/main.c:160 ../imagery/i.landsat.toar/main.c:169
-#: ../imagery/i.landsat.toar/main.c:177 ../imagery/i.landsat.toar/main.c:185
-#: ../imagery/i.landsat.toar/main.c:195 ../imagery/i.cluster/main.c:102
-#: ../imagery/i.cluster/main.c:118 ../imagery/i.cluster/main.c:126
-#: ../imagery/i.cluster/main.c:135 ../imagery/i.cluster/main.c:143
-#: ../imagery/i.cluster/main.c:151 ../display/d.mon/main.c:69
-#: ../display/d.mon/main.c:76 ../display/d.mon/main.c:79
-#: ../display/d.mon/main.c:85 ../general/g.access/main.c:50
-#: ../general/g.access/main.c:58 ../general/g.mapset/main.c:57
-#: ../general/g.mapset/main.c:67 ../general/g.mapset/main.c:77
-#: ../vector/v.colors.out/main.c:68 ../vector/v.colors.out/main.c:73
-#: ../vector/v.db.connect/main.c:64 ../vector/v.db.connect/main.c:70
-#: ../vector/v.lidar.edgedetection/main.c:95
-#: ../vector/v.lidar.edgedetection/main.c:104
-#: ../vector/v.lidar.edgedetection/main.c:113
-#: ../vector/v.lidar.edgedetection/main.c:122
-#: ../vector/v.lidar.edgedetection/main.c:131
-#: ../vector/v.lidar.edgedetection/main.c:139
-#: ../vector/v.lidar.edgedetection/main.c:148 ../vector/v.vol.rst/main.c:277
-#: ../vector/v.vol.rst/main.c:285 ../vector/v.vol.rst/main.c:293
-#: ../vector/v.vol.rst/main.c:326 ../vector/v.vol.rst/main.c:335
-#: ../vector/v.vol.rst/main.c:344 ../vector/v.vol.rst/main.c:352
-#: ../vector/v.vol.rst/main.c:361 ../vector/v.vol.rst/main.c:369
-#: ../vector/v.surf.idw/main.c:111 ../vector/v.surf.idw/main.c:119
-#: ../vector/v.surf.bspline/main.c:112 ../vector/v.surf.bspline/main.c:142
-#: ../vector/v.surf.bspline/main.c:151 ../vector/v.surf.bspline/main.c:160
-#: ../vector/v.surf.bspline/main.c:168 ../vector/v.surf.bspline/main.c:172
-#: ../vector/v.surf.bspline/main.c:179
-msgid "Settings"
-msgstr ""
-#: ../raster/r.in.bin/main.c:257
-#, fuzzy
-msgid "Byte Swap the Data During Import"
-msgstr "बाइट स्वेप आयात"
-#: ../raster/r.in.bin/main.c:262
-#, fuzzy
-msgid "Get region info from GMT style header"
-msgstr "पाएं जीएमटी"
-#: ../raster/r.in.bin/main.c:263 ../raster/r.in.bin/main.c:303
-#: ../raster/r.in.bin/main.c:311 ../raster/r.in.bin/main.c:319
-#: ../raster/r.in.bin/main.c:327 ../raster/r.in.bin/main.c:334
-#: ../raster/r.in.bin/main.c:341 ../general/g.region/main.c:149
-#: ../general/g.region/main.c:208 ../general/g.region/main.c:217
-#: ../general/g.region/main.c:226 ../general/g.region/main.c:235
-#: ../general/g.region/main.c:244 ../general/g.region/main.c:253
-#: ../general/g.region/main.c:329 ../general/g.region/main.c:340
-msgid "Bounds"
-msgstr ""
-#: ../raster/r.in.bin/main.c:269
-#, fuzzy
-msgid "Binary raster file to be imported"
-msgstr "Bin"
-#: ../raster/r.in.bin/main.c:286 ../raster/r.out.bin/main.c:311
-#, fuzzy
-msgid "Number of bytes per cell"
-msgstr "संख्या का बाइट्स"
-#: ../raster/r.in.bin/main.c:294 ../raster/r.out.bin/main.c:318
-#, fuzzy
-msgid "Output byte order"
-msgstr "ढाल फ़ाइलनाम "
-#: ../raster/r.in.bin/main.c:302
-#, fuzzy
-msgid "Northern limit of geographic region (outer edge)"
-msgstr "का"
-#: ../raster/r.in.bin/main.c:310
-#, fuzzy
-msgid "Southern limit of geographic region (outer edge)"
-msgstr "का"
-#: ../raster/r.in.bin/main.c:318
-#, fuzzy
-msgid "Eastern limit of geographic region (outer edge)"
-msgstr "का"
-#: ../raster/r.in.bin/main.c:326
-#, fuzzy
-msgid "Western limit of geographic region (outer edge)"
-msgstr "का"
-#: ../raster/r.in.bin/main.c:333 ../general/g.pnmcat/main.c:141
-#, fuzzy
-msgid "Number of rows"
-msgstr "का"
-#: ../raster/r.in.bin/main.c:340 ../general/g.pnmcat/main.c:147
-#, fuzzy
-msgid "Number of columns"
-msgstr "का"
-#: ../raster/r.in.bin/main.c:347
-#, fuzzy
-msgid "Set Value to NULL"
-msgstr "सेट"
-#: ../raster/r.in.bin/main.c:368
-msgid "order= and -b are mutually exclusive"
-msgstr ""
-#: ../raster/r.in.bin/main.c:383
-msgid "-f and -d are mutually exclusive"
-msgstr ""
-#: ../raster/r.in.bin/main.c:387
-#, c-format
-msgid "-f incompatible with bytes=%d; must be 4 or 8"
-msgstr ""
-#: ../raster/r.in.bin/main.c:395
-#, c-format
-msgid "-d incompatible with bytes=%d; must be 8"
-msgstr ""
-#: ../raster/r.in.bin/main.c:402
-msgid "bytes= required for integer data"
-msgstr ""
-#: ../raster/r.in.bin/main.c:406
-msgid "Integer input doesn't support size=8 in this build"
-msgstr ""
-#: ../raster/r.in.bin/main.c:410
-msgid "bytes= must be 1, 2, 4 or 8"
-msgstr ""
-#: ../raster/r.in.bin/main.c:423
-#, fuzzy
-msgid "Either -h or rows= and cols= must be given"
-msgstr "पाठ"
-#: ../raster/r.in.bin/main.c:428
-#, fuzzy
-msgid "Either all or none of north=, south=, east= and west= must be given"
-msgstr "थीटा"
-#: ../raster/r.in.bin/main.c:435 ../display/d.grid/main.c:224
-#, fuzzy, c-format
-msgid "Illegal north coordinate <%s>"
-msgstr "उत्तर"
-#: ../raster/r.in.bin/main.c:437
-#, fuzzy, c-format
-msgid "Illegal south coordinate <%s>"
-msgstr "उत्तर"
-#: ../raster/r.in.bin/main.c:439 ../display/d.grid/main.c:218
-#, fuzzy, c-format
-msgid "Illegal east coordinate <%s>"
-msgstr "पूर्व"
-#: ../raster/r.in.bin/main.c:441
-#, fuzzy, c-format
-msgid "Illegal west coordinate <%s>"
-msgstr "पूर्व"
-#: ../raster/r.in.bin/main.c:447
-#, fuzzy, c-format
-msgid "Unable to open <%s>"
-msgstr "का"
-#: ../raster/r.in.bin/main.c:466
-#, c-format
-msgid "East-West (ewres: %f) and North-South (nwres: %f) resolution differ significantly. Did you assign east= and west= correctly?"
-msgstr ""
-#: ../raster/r.in.bin/main.c:489
-#, fuzzy
-msgid "File Size %"
-msgstr "विशेषता"
-#: ../raster/r.in.bin/main.c:491
-msgid "Bytes do not match file size"
-msgstr ""
-#: ../raster/r.kappa/prt_hdr.c:18
-#, fuzzy, c-format
-msgid "Cannot open file <%s> to write header"
-msgstr "के लिए"
-#: ../raster/r.kappa/prt_label.c:17
-#, fuzzy, c-format
-msgid "Can't open file <%s> to write label"
-msgstr "के लिए"
-#: ../raster/r.kappa/main.c:71
-#, fuzzy
-msgid "Calculate error matrix and kappa parameter for accuracy assessment of classification result."
-msgstr "गणना त्रुटि माट्रिक्स काप्पा के लिए का."
-#: ../raster/r.kappa/main.c:77
-#, fuzzy
-msgid "Name of raster map containing classification result"
-msgstr "का"
-#: ../raster/r.kappa/main.c:82
-#, fuzzy
-msgid "Name of raster map containing reference classes"
-msgstr "का"
-#: ../raster/r.kappa/main.c:87
-#, fuzzy
-msgid "Name for output file containing error matrix and kappa"
-msgstr "का का त्रुटि माट्रिक्स काप्पा"
-#: ../raster/r.kappa/main.c:93
-#, fuzzy
-msgid "Title for error matrix and kappa"
-msgstr "के लिए त्रुटि माट्रिक्स काप्पा"
-#: ../raster/r.kappa/main.c:98
-msgid "Wide report"
-msgstr ""
-#: ../raster/r.kappa/main.c:99
-msgid "132 columns (default: 80)"
-msgstr ""
-#: ../raster/r.kappa/main.c:103
-msgid "No header in the report"
-msgstr ""
-#: ../raster/r.kappa/stats.c:14 ../raster/r.report/stats.c:123
-msgid "Problem reading r.stats output"
-msgstr ""
-#: ../raster/r.kappa/calc_kappa.c:32
-#, fuzzy, c-format
-msgid "Cannot open file <%s> to write kappa and relevant parameters"
-msgstr "के लिए"
-#: ../raster/r.kappa/prt_mat.c:39
-#, fuzzy, c-format
-msgid "Cannot open file <%s> to write cats and counts (error matrix)"
-msgstr "के लिए"
-#: ../raster/r.out.png/main.c:116
-#, fuzzy
-msgid "Export a GRASS raster map as a non-georeferenced PNG image."
-msgstr "a a."
-#: ../raster/r.out.png/main.c:122
-#, fuzzy
-msgid "Name for new PNG file (use out=- for stdout)"
-msgstr "के लिए के लिए"
-#: ../raster/r.out.png/main.c:130
-#, fuzzy
-msgid "Compression level of PNG file"
-msgstr "का."
-#: ../raster/r.out.png/main.c:131
-msgid "(0 = none, 1 = fastest, 9 = best)"
-msgstr ""
-#: ../raster/r.out.png/main.c:138
-msgid "Make NULL cells transparent"
-msgstr ""
-#: ../raster/r.out.png/main.c:142
-#, fuzzy
-msgid "Output world file"
-#: ../raster/r.out.png/main.c:175 ../raster/r.out.tiff/main.c:163
-#: ../display/d.labels/color.c:68 ../display/d.rast/display.c:27
-#: ../display/d.graph/do_graph.c:105 ../display/d.graph/do_graph.c:355
-#: ../display/d.graph/do_graph.c:370 ../display/d.graph/main.c:109
-#, fuzzy, c-format
-msgid "[%s]: No such color"
-msgstr "नहीं"
-#: ../raster/r.out.png/main.c:257
-#, fuzzy, c-format
-msgid "Converting <%s>..."
-msgstr "n"
-#: ../raster/r.out.png/main.c:272 ../raster/r.univar/r.univar_main.c:182
-#, fuzzy, c-format
-msgid "Raster <%s> type mismatch"
-msgstr "नहीं"
-#: ../raster/r.out.png/main.c:422
-#, fuzzy
-msgid "Writing world file"
-msgstr "n"
-#: ../raster/r.out.png/main.c:425 ../raster/r.out.tiff/main.c:422
-#, fuzzy
-msgid "Got null file name"
-msgstr "फ़ाइलनाम "
-#: ../raster/r.out.png/main.c:427 ../raster/r.out.tiff/main.c:424
-msgid "Got null region struct"
-msgstr ""
-#: ../raster/r.out.png/main.c:429
-#, fuzzy
-msgid "Unable to open world file for writing"
-msgstr "के लिए"
-#: ../raster/r.resamp.rst/main.c:151
-#, fuzzy
-msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
-msgstr "a."
-#: ../raster/r.resamp.rst/main.c:162
-#, fuzzy
-msgid "Desired east-west resolution"
-msgstr "पूर्व पश्चिम"
-#: ../raster/r.resamp.rst/main.c:168
-#, fuzzy
-msgid "Desired north-south resolution"
-msgstr "उत्तर दक्षिण"
-#: ../raster/r.resamp.rst/main.c:175
-#, fuzzy
-msgid "Output z-file (elevation) map"
-msgstr "ज़ेड"
-#: ../raster/r.resamp.rst/main.c:183
-#, fuzzy
-msgid "Output slope map (or fx)"
-msgstr "ढाल"
-#: ../raster/r.resamp.rst/main.c:191
-msgid "Output aspect map (or fy)"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:199
-msgid "Output profile curvature map (or fxx)"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:207
-msgid "Output tangential curvature map (or fyy)"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:215
-msgid "Output mean curvature map (or fxy)"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:223
-#, fuzzy
-msgid "Name of raster map containing smoothing"
-msgstr "का"
-#: ../raster/r.resamp.rst/main.c:231
-#, fuzzy
-msgid "Name of raster map to be used as mask"
-msgstr "का"
-#: ../raster/r.resamp.rst/main.c:239
-#, fuzzy
-msgid "Rows/columns overlap for segmentation"
-msgstr "के लिए"
-#: ../raster/r.resamp.rst/main.c:247
-#, fuzzy
-msgid "Multiplier for z-values"
-msgstr "के लिए ज़ेड"
-#: ../raster/r.resamp.rst/main.c:255
-msgid "Spline tension value"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:262
-#, fuzzy
-msgid "Anisotropy angle (in degrees)"
-msgstr "कोण कोण"
-#: ../raster/r.resamp.rst/main.c:263 ../raster/r.resamp.rst/main.c:270
-msgid "Anisotropy"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:269 ../vector/v.surf.rst/main.c:335
-msgid "Anisotropy scaling factor"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:274
-msgid "Use dnorm independent tension"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:279 ../vector/v.surf.rst/main.c:165
-#, fuzzy
-msgid "Output partial derivatives instead of topographic parameters"
-msgstr "का"
-#: ../raster/r.resamp.rst/main.c:313
-#, fuzzy
-msgid "Unable to read ew_res value"
-msgstr "का"
-#: ../raster/r.resamp.rst/main.c:316
-#, fuzzy
-msgid "Unable to read ns_res value"
-msgstr "का"
-#: ../raster/r.resamp.rst/main.c:319
-#, fuzzy
-msgid "Invalid value for tension"
-msgstr "के लिए"
-#: ../raster/r.resamp.rst/main.c:322
-#, fuzzy
-msgid "Invalid value for zmult"
-msgstr "के लिए"
-#: ../raster/r.resamp.rst/main.c:325
-#, fuzzy
-msgid "Invalid value for overlap"
-msgstr "के लिए"
-#: ../raster/r.resamp.rst/main.c:329
-#, fuzzy
-msgid "Invalid value for theta"
-#: ../raster/r.resamp.rst/main.c:333
-#, fuzzy
-msgid "Invalid value for scalex"
-msgstr "के लिए"
-#: ../raster/r.resamp.rst/main.c:335
-#, fuzzy
-msgid "When using anisotropy both theta and scalex must be specified"
-msgstr "थीटा"
-#: ../raster/r.resamp.rst/main.c:375
-#, fuzzy, c-format
-msgid "Map <%s> is the wrong resolution"
-msgstr "है"
-#: ../raster/r.resamp.rst/main.c:383
-#, fuzzy
-msgid "Smoothing values can not be negative or NULL"
-msgstr "चिकना नहीं"
-#: ../raster/r.resamp.rst/main.c:389
-msgid "Input map resolution differs from current region resolution!"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:407
-msgid "Processing all selected output files will require"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:411
-#, fuzzy, c-format
-msgid "%.2f GB of disk space for temp files."
-msgstr "डिस्क"
-#: ../raster/r.resamp.rst/main.c:414
-#, fuzzy, c-format
-msgid "%.2f MB of disk space for temp files."
-msgstr "डिस्क"
-#: ../raster/r.resamp.rst/main.c:417
-#, fuzzy, c-format
-msgid "%.2f KB of disk space for temp files."
-msgstr "डिस्क"
-#: ../raster/r.resamp.rst/main.c:420
-#, fuzzy, c-format
-msgid "%d bytes of disk space for temp files."
-msgstr "डिस्क"
-#: ../raster/r.resamp.rst/main.c:451
-#, fuzzy
-msgid "Maximum value of a raster map is NULL."
-msgstr "का a है."
-#: ../raster/r.resamp.rst/main.c:479
-msgid "Temporarily changing the region to desired resolution ..."
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:484
-#, fuzzy
-msgid "Changing back to the original region ..."
-msgstr "पृष्ठ असली."
-#: ../raster/r.resamp.rst/main.c:489 ../raster/r.resample/main.c:112
-msgid "Percent complete: "
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:501
-#, c-format
-msgid "dnorm in mainc after grid before out1= %f"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:505
-msgid "split_and_interpolate() failed"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:520
-#, c-format
-msgid "dnorm in mainc after grid before out2= %f"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:526
-#, fuzzy
-msgid "Unable to write raster maps -- try increasing cell size"
-msgstr "का a"
-#: ../raster/r.resamp.rst/main.c:558 ../vector/v.surf.rst/main.c:812
-#, fuzzy, c-format
-msgid "Error writing temporary file <%s>"
-msgstr "त्रुटि n"
-#: ../raster/r.quantile/main.c:63
-msgid "Computing histogram"
-msgstr ""
-#: ../raster/r.quantile/main.c:258
-msgid "Compute quantiles using two passes."
-msgstr ""
-#: ../raster/r.quantile/main.c:285
-msgid "Generate recode rules based on quantile-defined intervals."
-msgstr ""
-#: ../raster/r.compress/main.c:63 ../imagery/i.group/main.c:53
-#: ../imagery/i.target/main.c:46 ../general/g.filename/main.c:40
-#: ../general/g.access/main.c:38 ../general/g.findfile/main.c:39
-#: ../general/g.mremove/main.c:62 ../general/g.mlist/main.c:63
-#: ../general/g.list/main.c:45 ../general/g.findetc/main.c:29
-#: ../general/g.remove/main.c:102 ../general/g.dirseps/main.c:35
-#: ../general/g.rename/main.c:44 ../general/g.copy/main.c:42
-#, fuzzy
-msgid "map management"
-msgstr "है"
-#: ../raster/r.compress/main.c:64
-msgid "Compresses and decompresses raster maps."
-msgstr ""
-#: ../raster/r.compress/main.c:72 ../display/d.what.rast/main.c:66
-#, fuzzy
-msgid "Name of existing raster map(s)"
-msgstr "का"
-#: ../raster/r.compress/main.c:76
-msgid "Uncompress the map"
-msgstr ""
-#: ../raster/r.compress/main.c:104
-#, fuzzy, c-format
-msgid "[%s] not found"
-msgstr "नहीं"
-#: ../raster/r.compress/main.c:110
-#, fuzzy, c-format
-msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't uncompress"
-msgstr "है a का संपादन (_E)!"
-#: ../raster/r.compress/main.c:112
-#, fuzzy, c-format
-msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't compress"
-#: ../raster/r.compress/main.c:117
-#, fuzzy, c-format
-msgid "[%s] is a GDAL-linked map - can't (un)compress"
-#: ../raster/r.compress/main.c:159
-#, c-format
-msgid "DONE: uncompressed file is %lu bytes smaller"
-msgstr ""
-#: ../raster/r.compress/main.c:160
-#, c-format
-msgid "DONE: compressed file is %lu bytes smaller"
-msgstr ""
-#: ../raster/r.compress/main.c:164
-#, c-format
-msgid "DONE: uncompressed file is %lu bytes bigger"
-msgstr ""
-#: ../raster/r.compress/main.c:165
-#, c-format
-msgid "DONE: compressed file is %lu bytes bigger"
-msgstr ""
-#: ../raster/r.compress/main.c:183
-#, fuzzy, c-format
-msgid "[%s] already uncompressed"
-msgstr "पूर्ण."
-#: ../raster/r.compress/main.c:187
-#, fuzzy, c-format
-msgid "[%s] already compressed"
-msgstr "पूर्ण."
-#: ../raster/r.compress/main.c:191
-#, c-format
-msgid ""
-"\n"
-"%sCOMPRESS [%s]"
-msgstr ""
-#: ../raster/r.support.stats/check.c:43
-#, fuzzy, c-format
-msgid "Updating statistics for [%s]..."
-msgstr ""
-"\n"
-" के लिए"
-#: ../raster/r.support.stats/check.c:56
-msgid "Updating histogram range..."
-msgstr ""
-#: ../raster/r.support.stats/check.c:88
-#, fuzzy, c-format
-msgid "Updating the number of categories for [%s]..."
-msgstr "संख्या का के लिए n n"
-#: ../raster/r.support.stats/main.c:37
-#, fuzzy
-msgid "Update raster map statistics"
-msgstr "का"
-#: ../raster/r.support.stats/main.c:49
-#, fuzzy, c-format
-msgid "Statistics for <%s> updated"
-msgstr "के लिए."
-#: ../raster/r.spreadpath/main.c:93
-msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
-msgstr ""
-#: ../raster/r.spreadpath/main.c:102
-#, fuzzy
-msgid "Name of raster map containing back-path easting information"
-msgstr "का पृष्ठ"
-#: ../raster/r.spreadpath/main.c:110
-#, fuzzy
-msgid "Name of raster map containing back-path northing information"
-msgstr "का पृष्ठ"
-#: ../raster/r.spreadpath/main.c:118
-#, fuzzy
-msgid "The map E and N grid coordinates of starting points"
-msgstr "का"
-#: ../raster/r.spreadpath/main.c:125
-#, fuzzy
-msgid "Name of spread path raster map"
-msgstr "का"
-#: ../raster/r.spreadpath/main.c:129
-msgid "Run verbosely"
-msgstr ""
-#: ../raster/r.random/random.c:42 ../raster/r.random/random.c:46
-#: ../raster/r.mapcalc/map3.c:513 ../imagery/i.landsat.acca/main.c:57
-#: ../imagery/i.landsat.acca/algorithm.c:380
-#: ../imagery/i.landsat.acca/tools.c:126 ../imagery/i.landsat.toar/main.c:350
-#: ../imagery/i.landsat.toar/main.c:478
-#, fuzzy, c-format
-msgid "Unable to open raster map <%s>"
-msgstr "के लिए."
-#: ../raster/r.random/random.c:99
-#, fuzzy
-msgid "Cannot create new table"
-msgstr "चालू"
-#: ../raster/r.random/random.c:109
-#, fuzzy, c-format
-msgid "Writing raster map <%s> and vector map <%s> ..."
-msgstr "n"
-#: ../raster/r.random/random.c:112
-#, fuzzy, c-format
-msgid "Writing raster map <%s> ..."
-msgstr "i n"
-#: ../raster/r.random/random.c:114
-#, fuzzy, c-format
-msgid "Writing vector map <%s> ..."
-msgstr "n"
-#: ../raster/r.random/random.c:181 ../vector/v.net.centrality/main.c:69
-#: ../vector/v.net.distance/main.c:280 ../vector/v.net.flow/main.c:257
-#: ../vector/v.net.timetable/main.c:134 ../vector/v.net.timetable/main.c:156
-#: ../vector/v.net.allpairs/main.c:252 ../vector/v.net.components/main.c:38
-#: ../vector/v.net.path/path.c:313
-#, fuzzy, c-format
-msgid "Cannot insert new record: %s"
-msgstr "के लिए"
-#: ../raster/r.random/random.c:233
-#, fuzzy, c-format
-msgid "Only [%ld] random points created"
-msgstr "n"
-#: ../raster/r.random/count.c:68
-#, fuzzy
-msgid "Collecting Stats..."
-msgstr "n"
-#: ../raster/r.random/count.c:123
-msgid "Programmer error in get_stats/switch"
-msgstr ""
-#: ../raster/r.random/main.c:55
-#, fuzzy
-msgid "Creates a raster map layer and vector point map containing randomly located points."
-msgstr "a बिन्दु."
-#: ../raster/r.random/main.c:59 ../raster/r.out.bin/main.c:290
-#: ../imagery/i.zc/main.c:65
-#, fuzzy
-msgid "Name of input raster map"
-msgstr "का"
-#: ../raster/r.random/main.c:64
-#, fuzzy
-msgid "Name of cover raster map"
-msgstr "का"
-#: ../raster/r.random/main.c:71
-#, fuzzy
-msgid "The number of points to allocate"
-msgstr "संख्या का"
-#: ../raster/r.random/main.c:83
-#, fuzzy
-msgid "Generate points also for NULL category"
-msgstr "के लिए"
-#: ../raster/r.random/main.c:88
-msgid "Report information about input raster and exit"
-msgstr ""
-#: ../raster/r.random/main.c:92
-msgid "Generate vector points as 3D points"
-msgstr ""
-#: ../raster/r.random/main.c:96 ../vector/v.in.ascii/main.c:160
-#, fuzzy
-msgid "Do not build topology in points mode"
-msgstr "नहीं"
-#: ../raster/r.random/main.c:97 ../vector/v.out.ascii/args.c:36
-#: ../vector/v.out.ascii/args.c:58 ../vector/v.out.ascii/args.c:68
-#: ../vector/v.out.ascii/args.c:77 ../vector/v.out.ascii/args.c:83
-#: ../vector/v.in.ascii/main.c:83 ../vector/v.in.ascii/main.c:90
-#: ../vector/v.in.ascii/main.c:102 ../vector/v.in.ascii/main.c:112
-#: ../vector/v.in.ascii/main.c:122 ../vector/v.in.ascii/main.c:132
-#: ../vector/v.in.ascii/main.c:156 ../vector/v.in.ascii/main.c:161
-#: ../vector/v.in.ascii/main.c:167
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:15
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:18
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:20
-#, fuzzy
-msgid "Points"
-msgstr "फ़ॉन्ट"
-#: ../raster/r.random/main.c:133
-#, fuzzy, c-format
-msgid "Note: one (or both) of %s and %s must be specified"
-msgstr "थीटा"
-#: ../raster/r.random/main.c:141
-#, fuzzy, c-format
-msgid "<%s=%s> invalid percentage"
-msgstr "अवैध"
-#: ../raster/r.random/main.c:148
-#, fuzzy, c-format
-msgid "<%s=%s> invalid number of points"
-msgstr "संख्या का"
-#: ../raster/r.random/main.c:161
-#, fuzzy, c-format
-msgid "There aren't [%ld] cells in the current region"
-msgstr "छापें"
-#: ../raster/r.random/main.c:164
-#, fuzzy, c-format
-msgid "There aren't [%ld] non-NULL cells in the current region"
-msgstr "छापें"
-#: ../raster/r.random/main.c:169
-#, fuzzy
-msgid "There are no valid locations in the current region"
-msgstr "नहीं"
-#: ../raster/r.grow.distance/main.c:152
-#, fuzzy
-msgid "Generates a raster map of distance to features in input raster map."
-msgstr "a एक."
-#: ../raster/r.grow.distance/main.c:159
-#, fuzzy
-msgid "Name for distance output raster map"
-msgstr "का"
-#: ../raster/r.grow.distance/main.c:165
-#, fuzzy
-msgid "Name for value output raster map"
-msgstr "का"
-#: ../raster/r.grow.distance/main.c:172 ../raster/r.grow/main.c:142
-#: ../locale/scriptstrings/r.grow_to_translate.c:5
-msgid "Metric"
-msgstr ""
-#: ../raster/r.grow.distance/main.c:178
-#, fuzzy
-msgid "Output distances in meters instead of map units"
-msgstr "f"
-#: ../raster/r.grow.distance/main.c:188
-#, fuzzy
-msgid "At least one of distance= and value= must be given"
-msgstr "थीटा"
-#: ../raster/r.grow.distance/main.c:203
-msgid "metric=geodesic is only valid for lat/lon"
-msgstr ""
-#: ../raster/r.grow.distance/main.c:209
-#, fuzzy, c-format
-msgid "Unknown metric: '%s'"
-msgstr "अज्ञात क़िस्म"
-#: ../raster/r.grow.distance/main.c:225
-#, fuzzy, c-format
-msgid "Unable to create temporary file <%s>"
-msgstr "बनाया जा रहा है."
-#: ../raster/r.grow.distance/main.c:300
-#, fuzzy
-msgid "Writing output raster maps..."
-msgstr "i n"
-#: ../raster/r.report/main.c:68
-#, fuzzy
-msgid "Reports statistics for raster maps."
-msgstr "के लिए."
-#: ../raster/r.report/parse.c:38
-#, fuzzy
-msgid "Raster map(s) to report on"
-msgstr "चालू"
-#: ../raster/r.report/parse.c:47
-#, fuzzy
-msgid "mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;percent cover"
-msgstr "a h कवर"
-#: ../raster/r.report/parse.c:50 ../raster/r.report/parse.c:86
-#: ../ps/ps.map/main.c:101 ../ps/ps.map/main.c:114 ../ps/ps.map/main.c:136
-#, fuzzy
-msgid "Output settings"
-msgstr "नहीं"
-#: ../raster/r.report/parse.c:58
-msgid "Character representing no data cell value"
-msgstr ""
-#: ../raster/r.report/parse.c:59 ../raster/r.report/parse.c:68
-#: ../raster/r.report/parse.c:77 ../raster/r.report/parse.c:101
-#: ../raster/r.report/parse.c:106 ../raster/r.report/parse.c:111
-msgid "Formatting"
-msgstr ""
-#: ../raster/r.report/parse.c:65
-#, fuzzy, c-format
-msgid "Page length (default: %d lines)"
-msgstr "पृष्ठ"
-#: ../raster/r.report/parse.c:74
-#, fuzzy, c-format
-msgid "Page width (default: %d characters)"
-msgstr "पृष्ठ"
-#: ../raster/r.report/parse.c:83
-#, fuzzy
-msgid "Name for output file to hold the report"
-msgstr "का"
-#: ../raster/r.report/parse.c:85
-#, fuzzy
-msgid "If no output given report is printed to standard output"
-msgstr "नहीं"
-#: ../raster/r.report/parse.c:95 ../raster/r.stats/main.c:136
-#, fuzzy
-msgid "Number of fp subranges to collect stats from"
-msgstr "का"
-#: ../raster/r.report/parse.c:96 ../raster/r.report/parse.c:124
-#: ../raster/r.report/parse.c:130
-msgid "FP maps"
-msgstr ""
-#: ../raster/r.report/parse.c:100
-msgid "Suppress page headers"
-msgstr ""
-#: ../raster/r.report/parse.c:105
-msgid "Use formfeeds between pages"
-msgstr ""
-#: ../raster/r.report/parse.c:110
-msgid "Scientific format"
-msgstr ""
-#: ../raster/r.report/parse.c:115
-#, fuzzy
-msgid "Filter out all no data cells"
-msgstr "सभी"
-#: ../raster/r.report/parse.c:119
-#, fuzzy
-msgid "Filter out cells where all maps have no data"
-msgstr "सभी"
-#: ../raster/r.report/parse.c:123 ../raster/r.stats/main.c:196
-#, fuzzy
-msgid "Report for cats fp ranges (fp maps only)"
-msgstr "के लिए"
-#: ../raster/r.report/parse.c:129 ../raster/r.stats/main.c:200
-msgid "Read fp map as integer (use map's quant rules)"
-msgstr ""
-#: ../raster/r.report/parse.c:172
-msgid "nsteps has to be > 0; using nsteps=255"
-msgstr ""
-#: ../raster/r.report/parse.c:179
-msgid "Illegal page length"
-msgstr ""
-#: ../raster/r.report/parse.c:186
-msgid "Illegal page width"
-msgstr ""
-#: ../raster/r.report/parse.c:225
-#, c-format
-msgid "Only %d unit%s allowed"
-msgstr ""
-#: ../raster/r.report/parse.c:258
-#, fuzzy, c-format
-msgid "Unable to read fp range for raster map <%s>"
-msgstr "डाटाटाइप."
-#: ../raster/r.report/stats.c:88
-#, fuzzy, c-format
-msgid "Unable to open result file <%s>"
-msgstr "का"
-#: ../raster/r.out.pov/main.c:124
-#, fuzzy
-msgid "Converts a raster map layer into a height-field file for POV-Ray."
-msgstr "a a ऊंचाई फील्ड के लिए."
-#: ../raster/r.out.pov/main.c:131
-#, fuzzy
-msgid "Name of output povray file (TGA height field file)"
-msgstr "का ऊंचाई फील्ड"
-#: ../raster/r.out.pov/main.c:138
-#, fuzzy
-msgid "Height-field type (0=actual heights 1=normalized)"
-msgstr "ऊंचाई फील्ड"
-#: ../raster/r.out.pov/main.c:144
-msgid "Elevation bias"
-msgstr ""
-#: ../raster/r.out.pov/main.c:170
-#, fuzzy, c-format
-msgid "Invalid output filename <%s>"
-msgstr "चेतावनी."
-#: ../raster/r.out.pov/main.c:180
-#, c-format
-msgid "Raster map is too big! Exceeds %d columns or %d rows"
-msgstr ""
-#: ../raster/r.out.pov/main.c:201
-msgid "Negative elevation values in input"
-msgstr ""
-#: ../raster/r.water.outlet/main.c:64
-#, fuzzy
-msgid "Creates watershed basins."
-msgstr "a."
-#: ../raster/r.water.outlet/main.c:78
-#, fuzzy
-msgid "Easting grid coordinates"
-msgstr "का"
-#: ../raster/r.water.outlet/main.c:86
-#, fuzzy
-msgid "Northing grid coordinates"
-msgstr "का"
-#: ../raster/r.water.outlet/main.c:97
-#, fuzzy, c-format
-msgid "Illegal east coordinate <%s>\n"
-msgstr "पूर्व"
-#: ../raster/r.water.outlet/main.c:102
-#, fuzzy, c-format
-msgid "Illegal north coordinate <%s>\n"
-msgstr "उत्तर"
-#: ../raster/r.water.outlet/main.c:109
-#, fuzzy, c-format
-msgid ""
-"Warning, ignoring point outside window: \n"
-"    %.4f,%.4f\n"
-msgstr "चेतावनी बिन्दु"
-#: ../raster/r.carve/raster.c:13 ../raster/r.texture/main.c:292
-#: ../imagery/i.zc/main.c:152
-#, fuzzy
-msgid "Reading raster map..."
-msgstr "n"
-#: ../raster/r.carve/raster.c:33 ../raster/r.in.poly/poly2rast.c:77
-#: ../vector/v.to.rast/vect2rast.c:175
-#, fuzzy
-msgid "Writing raster map..."
-msgstr "n"
-#: ../raster/r.carve/enforce_ds.c:82
-msgid "Processing lines... "
-msgstr ""
-#: ../raster/r.carve/enforce_ds.c:174
-msgid "Vect runs out of region and re-enters - this case is not yet implemented."
-msgstr ""
-#: ../raster/r.carve/lobf.c:74
-msgid "trying to divide by zero...no unique solution for system...skipping..."
-msgstr ""
-#: ../raster/r.carve/main.c:76
-msgid "Generates stream channels."
-msgstr ""
-#: ../raster/r.carve/main.c:77
-msgid "Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
-msgstr ""
-#: ../raster/r.carve/main.c:82
-#, fuzzy
-msgid "Name of input raster elevation map"
-msgstr "का"
-#: ../raster/r.carve/main.c:87
-#, fuzzy
-msgid "Name of input vector map containing stream(s)"
-msgstr "का"
-#: ../raster/r.carve/main.c:95
-#, fuzzy
-msgid "Name for output vector map for adjusted stream points"
-msgstr "का"
-#: ../raster/r.carve/main.c:100
-#, fuzzy
-msgid "Stream width (in meters)"
-msgstr "ऊंचाई मीटर्स"
-#: ../raster/r.carve/main.c:101
-msgid "Default is raster cell width"
-msgstr ""
-#: ../raster/r.carve/main.c:106
-#, fuzzy
-msgid "Additional stream depth (in meters)"
-#: ../raster/r.carve/main.c:110
-msgid "No flat areas allowed in flow direction"
-msgstr ""
-#: ../raster/r.carve/main.c:134
-#, c-format
-msgid "Invalid width value '%s' - using default."
-msgstr ""
-#: ../raster/r.carve/main.c:148
-#, c-format
-msgid "Invalid depth value '%s' - using default."
-msgstr ""
-#: ../raster/r.carve/main.c:212
-msgid "lat/lon projection not supported at this time."
-msgstr ""
-#: ../raster/r.out.tiff/main.c:94
-#, fuzzy
-msgid "Exports a GRASS raster map to a 8/24bit TIFF image file."
-msgstr "a a फ़ाइल."
-#: ../raster/r.out.tiff/main.c:103
-#, fuzzy
-msgid "Name for new TIFF file"
-msgstr "फ़ाइल के लिए."
-#: ../raster/r.out.tiff/main.c:110
-msgid "TIFF file compression"
-msgstr ""
-#: ../raster/r.out.tiff/main.c:115
-#, fuzzy
-msgid "TIFF Palette output (8bit instead of 24bit)."
-msgstr "का."
-#: ../raster/r.out.tiff/main.c:124
-msgid "Output TIFF world file"
-msgstr ""
-#: ../raster/r.out.tiff/main.c:128
-msgid "Output Tiled TIFF"
-msgstr ""
-#: ../raster/r.out.tiff/main.c:176
-#, c-format
-msgid "Raster map <%s>> is a floating point map. Fractional values will be rounded to integer"
-msgstr ""
-#: ../raster/r.out.tiff/main.c:182
-msgid "Color map for palette must have less than 256 colors for the available range of data"
-msgstr ""
-#: ../raster/r.out.tiff/main.c:196
-#, fuzzy, c-format
-msgid "Unable to open TIFF file <%s>"
-msgstr "का"
-#: ../raster/r.out.tiff/main.c:419
-#, fuzzy
-msgid "Writing TIFF World file"
-msgstr "n"
-#: ../raster/r.out.tiff/main.c:427
-#, fuzzy
-msgid "Unable to open TIFF world file for writing"
-msgstr "के लिए"
-#: ../raster/r.null/main.c:60
-#, fuzzy
-msgid "null data"
-msgstr "चालू"
-#: ../raster/r.null/main.c:61
-#, fuzzy
-msgid "Manages NULL-values of given raster map."
-msgstr "का"
-#: ../raster/r.null/main.c:64
-#, fuzzy
-msgid "Name of raster map for which to edit null values"
-msgstr "के लिए"
-#: ../raster/r.null/main.c:73 ../raster/r.null/main.c:81
-#: ../general/g.proj/main.c:178
-msgid "Modify"
-msgstr ""
-#: ../raster/r.null/main.c:85
-msgid "Only do the work if the map is floating-point"
-msgstr ""
-#: ../raster/r.null/main.c:86 ../raster/r.null/main.c:91
-#: ../raster/r.null/main.c:97
-msgid "Check"
-msgstr ""
-#: ../raster/r.null/main.c:90
-msgid "Only do the work if the map is integer"
-msgstr ""
-#: ../raster/r.null/main.c:96
-msgid "Only do the work if the map doesn't have a NULL-value bitmap file"
-msgstr ""
-#: ../raster/r.null/main.c:102
-msgid "Create NULL-value bitmap file validating all data cells"
-msgstr ""
-#: ../raster/r.null/main.c:106
-msgid "Remove NULL-value bitmap file"
-msgstr ""
-#: ../raster/r.null/main.c:125
-#, c-format
-msgid "Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy with r.mapcalc. Exiting."
-msgstr ""
-#: ../raster/r.null/main.c:131
-#, fuzzy, c-format
-msgid "Raster map <%s> is not in your mapset <%s>"
-msgstr "नहीं"
-#: ../raster/r.null/main.c:138
-#, fuzzy, c-format
-msgid "%s is illegal entry for null"
-msgstr "के लिए"
-#: ../raster/r.null/main.c:145
-#, fuzzy, c-format
-msgid "Raster map <%s> already has a null bitmap file"
-msgstr "i n"
-#: ../raster/r.null/main.c:149
-#, fuzzy, c-format
-msgid "<%s> is integer raster map (CELL)"
-msgstr "त्रुटि"
-#: ../raster/r.null/main.c:153
-#, fuzzy, c-format
-msgid "<%s> is integer raster map (CELL). Using null=%d."
-msgstr "त्रुटि"
-#: ../raster/r.null/main.c:159
-#, fuzzy, c-format
-msgid "<%s> is floating pointing raster map"
-msgstr "त्रुटि"
-#: ../raster/r.null/main.c:175
-#, fuzzy, c-format
-msgid "Writing new null file for raster map <%s>..."
-msgstr "के लिए "
-#: ../raster/r.null/main.c:185 ../raster/r.null/main.c:198
-#, fuzzy, c-format
-msgid "Raster map <%s> modified."
-msgstr "नहीं"
-#: ../raster/r.null/main.c:192
-#, fuzzy, c-format
-msgid "Removing null file for raster map <%s>..."
-msgstr "के लिए n"
-#: ../raster/r.null/main.c:262
-#, fuzzy, c-format
-msgid "%s: %s: illegal value spec"
-msgstr "है"
-#: ../raster/r.null/main.c:264
-#, fuzzy, c-format
-msgid "%s: illegal value spec"
-msgstr "है"
-#: ../raster/r.null/main.c:325
-#, fuzzy, c-format
-msgid "Writing new data for raster map <%s>..."
-msgstr "i n"
-#: ../raster/r.basins.fill/read_map.c:39
-#, fuzzy, c-format
-msgid "Reading <%s> ... "
-msgstr "n"
-#: ../raster/r.basins.fill/main.c:57
-#, fuzzy
-msgid "Generates watershed subbasins raster map."
-msgstr "के लिए."
-#: ../raster/r.basins.fill/main.c:61
-#, fuzzy
-msgid "Name of input coded stream network raster map"
-msgstr "का"
-#: ../raster/r.basins.fill/main.c:65
-#, fuzzy
-msgid "Name of input thinned ridge network raster map"
-msgstr "का"
-#: ../raster/r.basins.fill/main.c:73
-#, fuzzy
-msgid "Number of passes through the dataset"
-msgstr "का"
-#: ../raster/r.basins.fill/main.c:121
-msgid "Forward sweep complete"
-msgstr ""
-#: ../raster/r.basins.fill/main.c:138
-#, fuzzy
-msgid "Reverse sweep complete"
-msgstr "ट्रेस"
-#: ../raster/r.surf.idw2/main.c:64 ../raster/r.surf.idw/main.c:106
-#: ../vector/v.surf.idw/main.c:88
-msgid "IDW"
-msgstr ""
-#: ../raster/r.surf.idw2/main.c:65
-#, fuzzy
-msgid "Surface generation program."
-#: ../raster/r.surf.idw2/main.c:76 ../raster/r.surf.idw/main.c:118
-#: ../vector/v.surf.idw/main.c:109
-#, fuzzy
-msgid "Number of interpolation points"
-msgstr "का"
-#: ../raster/r.surf.idw2/main.c:84
-#, fuzzy
-msgid "Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
-msgstr "नहीं के लिए."
-#: ../raster/r.surf.idw2/main.c:88
-#, fuzzy, c-format
-msgid "%s=%s - illegal number of interpolation points"
-msgstr "संख्या का"
-#: ../raster/r.surf.idw2/main.c:97
-#, c-format
-msgid "%s: no data points found"
-msgstr ""
-#: ../raster/r.surf.idw2/main.c:112
-#, fuzzy, c-format
-msgid "Interpolating raster map <%s>... %d rows... "
-msgstr "i n"
-#: ../raster/r.stats/main.c:105
-#, fuzzy
-msgid "Generates area statistics for raster map layers."
-msgstr "के लिए."
-#: ../raster/r.stats/main.c:114 ../raster/r.univar/r.univar_main.c:41
-#: ../raster/r.univar/r3.univar_main.c:42 ../vector/v.db.select/main.c:85
-#: ../db/db.select/main.c:237
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
-#, fuzzy
-msgid "Name for output file (if omitted or \"-\" output to stdout)"
-#: ../raster/r.stats/main.c:127 ../raster/r.describe/main.c:68
-msgid "String representing no data cell value"
-msgstr ""
-#: ../raster/r.stats/main.c:142
-#, fuzzy
-msgid "One cell (range) per line"
-msgstr "एक"
-#: ../raster/r.stats/main.c:146
-#, fuzzy
-msgid "Print averaged values instead of intervals"
-msgstr "छापें का"
-#: ../raster/r.stats/main.c:151
-#, fuzzy
-msgid "Print area totals"
-msgstr "छापें"
-#: ../raster/r.stats/main.c:156
-#, fuzzy
-msgid "Print cell counts"
-msgstr "छापें"
-#: ../raster/r.stats/main.c:162
-#, fuzzy
-msgid "Print APPROXIMATE percents (total percent may not be 100%)"
-msgstr "छापें नहीं"
-#: ../raster/r.stats/main.c:167
-#, fuzzy
-msgid "Print category labels"
-msgstr "छापें"
-#: ../raster/r.stats/main.c:172
-#, fuzzy
-msgid "Print grid coordinates (east and north)"
-msgstr "छापें पूर्व उत्तर"
-#: ../raster/r.stats/main.c:177
-#, fuzzy
-msgid "Print x and y (column and row)"
-msgstr "छापें"
-#: ../raster/r.stats/main.c:182
-#, fuzzy
-msgid "Print raw indexes of fp ranges (fp maps only)"
-msgstr "छापें कच्चा का"
-#: ../raster/r.stats/main.c:187 ../raster/r.describe/main.c:90
-#, fuzzy
-msgid "Suppress reporting of any NULLs"
-msgstr "का"
-#: ../raster/r.stats/main.c:192
-#, fuzzy
-msgid "Suppress reporting of NULLs when all values are NULL"
-msgstr "का सभी"
-#: ../raster/r.stats/main.c:208 ../raster/r.univar/r.univar_main.c:110
-#: ../raster/r.univar/r3.univar_main.c:123
-#: ../raster/r.regression.line/main.c:76 ../vector/v.db.select/main.c:110
-#: ../db/db.select/main.c:129
-#, fuzzy, c-format
-msgid "Unable to open file <%s> for writing"
-msgstr "के लिए"
-#: ../raster/r.stats/main.c:214
-#, c-format
-msgid "'%s' must be greater than zero; using %s=255"
-msgstr ""
-#: ../raster/r.stats/main.c:279
-#, fuzzy, c-format
-msgid "Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option will be ignored."
-msgstr "i"
-#: ../raster/r.stats/main.c:295
-#, fuzzy, c-format
-msgid "Cats for raster map <%s> are either missing or have no explicit labels. Using %s=%d."
-msgstr "के लिए"
-#: ../raster/r.stats/main.c:301
-#, fuzzy, c-format
-msgid "Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' option"
-msgstr "का"
-#: ../raster/r.region/main.c:54
-#, fuzzy
-msgid "Sets the boundary definitions for a raster map."
-msgstr "के लिए a."
-#: ../raster/r.region/main.c:60
-#, fuzzy
-msgid "Set from current region"
-msgstr "सेट"
-#: ../raster/r.region/main.c:64 ../general/g.region/main.c:72
-#, fuzzy
-msgid "Set from default region"
-msgstr "सेट"
-#: ../raster/r.region/main.c:75
-msgid "Raster map to change"
-msgstr ""
-#: ../raster/r.region/main.c:83
-#, fuzzy
-msgid "Set region from named region"
-msgstr "सेट"
-#: ../raster/r.region/main.c:90 ../general/g.region/main.c:172
-#, fuzzy
-msgid "Set region to match this raster map"
-msgstr "सेट जोड़ा"
-#: ../raster/r.region/main.c:96 ../general/g.region/main.c:188
-#, fuzzy
-msgid "Set region to match this vector map"
-msgstr "सेट जोड़ा"
-#: ../raster/r.region/main.c:104 ../general/g.region/main.c:197
-#, fuzzy
-msgid "Set region to match this 3dview file"
-msgstr "सेट जोड़ा"
-#: ../raster/r.region/main.c:113 ../general/g.region/main.c:207
-#, fuzzy
-msgid "Value for the northern edge"
-msgstr "के लिए"
-#: ../raster/r.region/main.c:121 ../general/g.region/main.c:216
-#, fuzzy
-msgid "Value for the southern edge"
-msgstr "के लिए"
-#: ../raster/r.region/main.c:129 ../general/g.region/main.c:225
-#, fuzzy
-msgid "Value for the eastern edge"
-msgstr "के लिए"
-#: ../raster/r.region/main.c:137 ../general/g.region/main.c:234
-#, fuzzy
-msgid "Value for the western edge"
-msgstr "के लिए"
-#: ../raster/r.region/main.c:143
-msgid "Raster map to align to"
-msgstr ""
-#: ../raster/r.region/main.c:174
-#, fuzzy, c-format
-msgid "Unable to open 3dview file <%s>"
-msgstr "फ़ाइल"
-#: ../raster/r.region/main.c:178
-#, fuzzy, c-format
-msgid "Unable to read 3dview file <%s>"
-msgstr "के लिए"
-#: ../raster/r.region/main.c:180
-#, fuzzy, c-format
-msgid "Old 3dview file. Region <%s> not found"
-msgstr "नहीं"
-#: ../raster/r.univar/r.univar_main.c:36
-msgid "Raster map used for zoning, must be of type CELL"
-msgstr ""
-#: ../raster/r.univar/r.univar_main.c:51
-#: ../raster/r.univar/r3.univar_main.c:52 ../vector/v.univar/main.c:89
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:9
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
-#, fuzzy
-msgid "Percentile to calculate (requires extended statistics flag)"
-msgstr "छापें"
-#: ../raster/r.univar/r.univar_main.c:54
-#: ../raster/r.univar/r3.univar_main.c:55
-msgid "Special characters: space, comma, tab"
-msgstr ""
-#: ../raster/r.univar/r.univar_main.c:59
-#: ../raster/r.univar/r3.univar_main.c:60 ../vector/v.univar/main.c:93
-#: ../vector/v.what/main.c:95
-#, fuzzy
-msgid "Print the stats in shell script style"
-msgstr "छापें"
-#: ../raster/r.univar/r.univar_main.c:63
-#: ../raster/r.univar/r3.univar_main.c:64 ../vector/v.univar/main.c:97
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:6
-#: ../locale/scriptstrings/tr.univar_to_translate.c:7
-#, fuzzy
-msgid "Calculate extended statistics"
-msgstr "वस्तु."
-#: ../raster/r.univar/r.univar_main.c:67
-#: ../raster/r.univar/r3.univar_main.c:68
-msgid "Table output format instead of standard output format"
-msgstr ""
-#: ../raster/r.univar/r.univar_main.c:99
-#, fuzzy
-msgid "Calculates univariate statistics from the non-null cells of a raster map."
-msgstr "का a."
-#: ../raster/r.univar/r3.univar_main.c:37
-msgid "3D Raster map used for zoning, must be of type CELL"
-msgstr ""
-#: ../raster/r.univar/r3.univar_main.c:102
-#, fuzzy
-msgid "Calculates univariate statistics from the non-null 3d cells of a raster3d map."
-msgstr "का a."
-#: ../raster/r.describe/main.c:57
-#, fuzzy
-msgid "Prints terse list of category values found in a raster map layer."
-msgstr "का a."
-#: ../raster/r.describe/main.c:76
-#, fuzzy
-msgid "Number of quantization steps"
-msgstr "संख्या का"
-#: ../raster/r.describe/main.c:82
-#, fuzzy
-msgid "Print the output one value per line"
-msgstr "छापें एक"
-#: ../raster/r.describe/main.c:86
-#, fuzzy
-msgid "Only print the range of the data"
-msgstr "का"
-#: ../raster/r.describe/main.c:94
-msgid "Use the current region"
-msgstr ""
-#: ../raster/r.describe/main.c:98
-msgid "Read fp map as integer"
-msgstr ""
-#: ../raster/r.describe/main.c:110
-#, c-format
-msgid "%s = %s -- must be greater than zero"
-msgstr ""
-#: ../raster/r.describe/describe.c:94
-#, fuzzy, c-format
-msgid "Reading <%s> ..."
-msgstr "n"
-#: ../raster/r.out.mat/main.c:64
-#, fuzzy
-msgid "Exports a GRASS raster to a binary MAT-File."
-#: ../raster/r.out.mat/main.c:75
-#, fuzzy
-msgid "Name for the output binary MAT-File"
-msgstr "के लिए फ़ाइल"
-#: ../raster/r.out.mat/main.c:115
-#, fuzzy, c-format
-msgid "Exporting <%s>"
-msgstr "n"
-#: ../raster/r.out.mat/main.c:175
-#, fuzzy
-msgid "Using the Current Region settings:"
-msgstr "छापें"
-#: ../raster/r.out.mat/main.c:176 ../raster/r.in.mat/main.c:397
-#, fuzzy, c-format
-msgid "northern edge=%f"
-msgstr "के लिए"
-#: ../raster/r.out.mat/main.c:177 ../raster/r.in.mat/main.c:398
-#, fuzzy, c-format
-msgid "southern edge=%f"
-msgstr "के लिए"
-#: ../raster/r.out.mat/main.c:178 ../raster/r.in.mat/main.c:399
-#, c-format
-msgid "eastern edge=%f"
-msgstr ""
-#: ../raster/r.out.mat/main.c:179 ../raster/r.in.mat/main.c:400
-#, c-format
-msgid "western edge=%f"
-msgstr ""
-#: ../raster/r.out.mat/main.c:180 ../raster/r.in.mat/main.c:401
-#, c-format
-msgid "nsres=%f"
-msgstr ""
-#: ../raster/r.out.mat/main.c:181 ../raster/r.in.mat/main.c:402
-#, c-format
-msgid "ewres=%f"
-msgstr ""
-#: ../raster/r.out.mat/main.c:182 ../raster/r.in.mat/main.c:403
-#, fuzzy, c-format
-msgid "rows=%d"
-msgstr "n"
-#: ../raster/r.out.mat/main.c:183 ../raster/r.in.mat/main.c:404
-#, fuzzy, c-format
-msgid "cols=%d"
-msgstr "नहीं"
-#: ../raster/r.out.mat/main.c:250
-#, fuzzy
-msgid "Exporting raster as integer values"
-msgstr "का"
-#: ../raster/r.out.mat/main.c:255
-#, fuzzy
-msgid "Exporting raster as floating point values"
-msgstr "छोटा करें बिन्दु"
-#: ../raster/r.out.mat/main.c:260
-msgid "Exporting raster as double FP values"
-msgstr ""
-#: ../raster/r.out.mat/main.c:303
-#, fuzzy
-msgid "Reading in map ... "
-msgstr "छवि "
-#: ../raster/r.out.mat/main.c:316
-#, fuzzy
-msgid "Writing out map..."
-msgstr "n"
-#: ../raster/r.out.mat/main.c:376
-#, fuzzy, c-format
-msgid "%ld bytes written to '%s'"
-#: ../raster/r.in.lidar/main.c:165
-msgid "Create a raster map from LAS LiDAR points using univariate statistics."
-msgstr ""
-#: ../raster/r.in.lidar/main.c:169
-#, fuzzy
-msgid "LiDAR LAS input file"
-msgstr "है n"
-#: ../raster/r.in.lidar/main.c:235 ../vector/v.in.ogr/main.c:249
-#: ../vector/v.in.lidar/main.c:203
-msgid "Override dataset projection (use location's projection)"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:264 ../vector/v.in.lidar/main.c:239
-#, c-format
-msgid "Input file <%s> is not a LAS LiDAR point cloud"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:282 ../vector/v.in.ogr/main.c:538
-#: ../vector/v.in.lidar/main.c:366
-#, fuzzy
-msgid "Unable to convert input map projection information to GRASS format for checking"
-msgstr "के लिए"
-#: ../raster/r.in.lidar/main.c:312 ../vector/v.in.ogr/main.c:568
-#: ../vector/v.in.lidar/main.c:396
-#, fuzzy
-msgid "GRASS LOCATION PROJ_INFO is:\n"
-msgstr "n"
-#: ../raster/r.in.lidar/main.c:372 ../vector/v.in.ogr/main.c:628
-#: ../vector/v.in.lidar/main.c:456
-#, fuzzy, c-format
-msgid ""
-"\n"
-"You can use the -o flag to %s to override this projection check.\n"
-msgstr "n"
-#: ../raster/r.in.lidar/main.c:375 ../vector/v.in.ogr/main.c:631
-#: ../vector/v.in.lidar/main.c:459
-#, fuzzy
-msgid "Consider generating a new location with 'location' parameter from input data set.\n"
-msgstr "a सेट n"
-#: ../raster/r.in.lidar/main.c:597
-#, fuzzy
-msgid "Could not rewind input file"
-msgstr "नहीं"
-#: ../raster/r.sunmask/g_solposition.c:66
-msgid "Unable to calculate sun position in un-projected locations. Specify sunposition directly."
-msgstr ""
-#: ../raster/r.sunmask/g_solposition.c:88
-#, c-format
-msgid "Specified point %f, %f outside of current region, is that intended? Anyway, it will be used."
-msgstr ""
-#: ../raster/r.sunmask/g_solposition.c:98
-#, fuzzy
-msgid "Unable to get projection info of current location"
-msgstr "का"
-#: ../raster/r.sunmask/g_solposition.c:101
-#, fuzzy
-msgid "Unable to get projection units of current location"
-msgstr "का"
-#: ../raster/r.sunmask/g_solposition.c:104
-#, fuzzy
-msgid "Unable to get projection key values of current location"
-msgstr "का"
-#: ../raster/r.sunmask/g_solposition.c:127 ../raster/r.proj/main.c:360
-#: ../raster/r.proj/main.c:362 ../general/g.region/printwindow.c:281
-#: ../general/g.region/printwindow.c:289 ../general/g.region/printwindow.c:297
-#: ../general/g.region/printwindow.c:305 ../general/g.region/printwindow.c:534
-#: ../general/g.region/printwindow.c:542 ../general/g.region/printwindow.c:550
-#: ../general/g.region/printwindow.c:558 ../general/g.region/printwindow.c:676
-#: ../general/g.region/printwindow.c:684 ../general/g.region/printwindow.c:692
-#: ../general/g.region/printwindow.c:700
-#, fuzzy
-msgid "Error in pj_do_proj (projection of input coordinate pair)"
-msgstr "त्रुटि का"
-#: ../raster/r.sunmask/main.c:117 ../raster/r.horizon/main.c:178
-#, fuzzy
-msgid "sun position"
-msgstr "नहीं n"
-#: ../raster/r.sunmask/main.c:118
-#, fuzzy
-msgid "Calculates cast shadow areas from sun position and elevation raster map."
-msgstr "नहीं"
-#: ../raster/r.sunmask/main.c:119
-#, fuzzy
-msgid "Either exact sun position (A) is specified, or date/time to calculate the sun position (B) by r.sunmask itself."
-msgstr "है."
-#: ../raster/r.sunmask/main.c:133
-#, fuzzy
-msgid "Altitude of the sun above horizon, degrees (A)"
-msgstr "का कोण"
-#: ../raster/r.sunmask/main.c:134 ../raster/r.sunmask/main.c:143
-#: ../raster/r.sunmask/main.c:210 ../raster/r.sunmask/main.c:220
-#, fuzzy
-msgid "Position"
-msgstr "नहीं n"
-#: ../raster/r.sunmask/main.c:142
-#, fuzzy
-msgid "Azimuth of the sun from the north, degrees (A)"
-msgstr "का उत्तर कोण"
-#: ../raster/r.sunmask/main.c:149
-msgid "Year (B)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:151 ../raster/r.sunmask/main.c:159
-#: ../raster/r.sunmask/main.c:167 ../raster/r.sunmask/main.c:175
-#: ../raster/r.sunmask/main.c:183 ../raster/r.sunmask/main.c:191
-#: ../raster/r.sunmask/main.c:200
-msgid "Time"
-msgstr ""
-#: ../raster/r.sunmask/main.c:157
-msgid "Month (B)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:165
-msgid "Day (B)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:173
-msgid "Hour (B)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:181
-msgid "Minutes (B)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:189
-msgid "Seconds (B)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:198
-msgid "Timezone"
-msgstr ""
-#: ../raster/r.sunmask/main.c:199
-#, fuzzy
-msgid "East positive, offset from GMT, also use to adjust daylight savings"
-msgstr "पूर्व जीएमटी"
-#: ../raster/r.sunmask/main.c:208
-#, fuzzy
-msgid "Easting coordinate (point of interest)"
-msgstr "एक."
-#: ../raster/r.sunmask/main.c:209 ../raster/r.sunmask/main.c:219
-msgid "Default: map center"
-msgstr ""
-#: ../raster/r.sunmask/main.c:218
-#, fuzzy
-msgid "Northing coordinate (point of interest)"
-msgstr "एक."
-#: ../raster/r.sunmask/main.c:224
-msgid "Don't ignore zero elevation"
-msgstr ""
-#: ../raster/r.sunmask/main.c:228
-msgid "Calculate sun position only and exit"
-msgstr ""
-#: ../raster/r.sunmask/main.c:234
-#, fuzzy
-msgid "Print the sun position output in shell script style"
-msgstr "छापें"
-#: ../raster/r.sunmask/main.c:248
-#, fuzzy, c-format
-msgid "Using map center coordinates: %f %f"
-msgstr "n"
-#: ../raster/r.sunmask/main.c:255
-#, fuzzy
-msgid "Empty east coordinate specified"
-msgstr "पूर्व!"
-#: ../raster/r.sunmask/main.c:257
-#, fuzzy
-msgid "Empty north coordinate specified"
-msgstr "उत्तर!"
-#: ../raster/r.sunmask/main.c:276
-#, fuzzy
-msgid "Either define sun position or location/date/time parameters"
-msgstr "पारिभाषित करें."
-#: ../raster/r.sunmask/main.c:279
-#, fuzzy
-msgid "Neither sun position nor east/north, date/time/timezone definition are complete"
-msgstr "पूर्व उत्तर."
-#: ../raster/r.sunmask/main.c:283
-#, fuzzy, c-format
-msgid "Calculating sun position... (using solpos (V. %s) from NREL)"
-msgstr "V n"
-#: ../raster/r.sunmask/main.c:288
-#, fuzzy
-msgid "Using user defined sun azimuth, altitude settings (ignoring eventual other values)"
-msgstr "अन्य n"
-#: ../raster/r.sunmask/main.c:396
-#, fuzzy
-msgid "Please correct settings"
-msgstr "का"
-#: ../raster/r.sunmask/main.c:410
-#, fuzzy, c-format
-msgid "Time (%02i:%02i:%02i) is before sunrise (%02d:%02d:%02d)"
-msgstr "है n"
-#: ../raster/r.sunmask/main.c:414
-#, fuzzy, c-format
-msgid "Time (%02i:%02i:%02i) is before sunrise"
-msgstr "है n"
-#: ../raster/r.sunmask/main.c:417 ../raster/r.sunmask/main.c:427
-msgid "Nothing to calculate. Please verify settings."
-msgstr ""
-#: ../raster/r.sunmask/main.c:421
-#, fuzzy, c-format
-msgid "Time (%02i:%02i:%02i) is after sunset (%02d:%02d:%02d)"
-msgstr "है n"
-#: ../raster/r.sunmask/main.c:425
-#, fuzzy, c-format
-msgid "Time (%02i:%02i:%02i) is after sunset"
-msgstr "है n"
-#: ../raster/r.sunmask/main.c:436
-#, fuzzy
-msgid "You already know the sun position"
-msgstr "n"
-#: ../raster/r.sunmask/main.c:441
-#, fuzzy, c-format
-msgid "Option <%s> required"
-msgstr "n"
-#: ../raster/r.sunmask/main.c:453
-#, fuzzy, c-format
-msgid "Unable to open range file for raster map <%s>"
-msgstr "डाटाटाइप."
-#: ../raster/r.sunmask/main.c:469
-msgid "Calculating shadows from DEM..."
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:949
-#, c-format
-msgid "S_decode ==> Please fix the year: %d [1950-2050]"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:952
-#, c-format
-msgid "S_decode ==> Please fix the month: %d"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:954
-#, c-format
-msgid "S_decode ==> Please fix the day-of-month: %d"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:957
-#, c-format
-msgid "S_decode ==> Please fix the day-of-year: %d"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:960
-#, c-format
-msgid "S_decode ==> Please fix the hour: %d"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:962
-#, c-format
-msgid "S_decode ==> Please fix the minute: %d"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:964
-#, c-format
-msgid "S_decode ==> Please fix the second: %d"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:966
-#, c-format
-msgid "S_decode ==> Please fix the time zone: %f"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:969
-#, c-format
-msgid "S_decode ==> Please fix the interval: %d"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:972
-#, c-format
-msgid "S_decode ==> Please fix the latitude: %f"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:975
-#, c-format
-msgid "S_decode ==> Please fix the longitude: %f"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:978
-#, c-format
-msgid "S_decode ==> Please fix the temperature: %f"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:981
-#, c-format
-msgid "S_decode ==> Please fix the pressure: %f"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:983
-#, c-format
-msgid "S_decode ==> Please fix the tilt: %f"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:985
-#, c-format
-msgid "S_decode ==> Please fix the aspect: %f"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:987
-#, c-format
-msgid "S_decode ==> Please fix the shadowband width: %f"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:990
-#, c-format
-msgid "S_decode ==> Please fix the shadowband radius: %f"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:993
-#, c-format
-msgid "S_decode ==> Please fix the shadowband sky factor: %f"
-msgstr ""
-#: ../raster/r.regression.line/main.c:49
-msgid "Calculates linear regression from two raster maps: y = a + b*x."
-msgstr ""
-#: ../raster/r.regression.line/main.c:54
-msgid "Map for x coefficient"
-msgstr ""
-#: ../raster/r.regression.line/main.c:58
-msgid "Map for y coefficient"
-msgstr ""
-#: ../raster/r.regression.line/main.c:64
-msgid "ASCII file for storing regression coefficients (output to screen if file not specified)."
-msgstr ""
-#: ../raster/r.regression.line/main.c:68 ../general/g.region/main.c:141
-#: ../locale/scriptstrings/i.oif_to_translate.c:11
-#, fuzzy
-msgid "Print in shell script style"
-msgstr "छापें"
-#: ../raster/r.out.bin/main.c:53 ../raster/r.out.bin/main.c:62
-#: ../raster/r.out.bin/main.c:462 ../raster/r.mapcalc/map3.c:126
-#: ../raster/r.mapcalc/map3.c:140 ../raster/r.mapcalc/map3.c:154
-#, fuzzy
-msgid "Error writing data"
-msgstr "त्रुटि."
-#: ../raster/r.out.bin/main.c:139
-#, fuzzy, c-format
-msgid "Header File = %s"
-msgstr "खोलें"
-#: ../raster/r.out.bin/main.c:144 ../raster/r.out.bin/main.c:228
-#: ../raster/r.out.bin/main.c:408
-#, fuzzy, c-format
-msgid "Unable to create file <%s>"
-msgstr "i n"
-#: ../raster/r.out.bin/main.c:223
-#, c-format
-msgid "World File = %s"
-msgstr ""
-#: ../raster/r.out.bin/main.c:281
-#, fuzzy
-msgid "Exports a GRASS raster to a binary array."
-msgstr "a a."
-#: ../raster/r.out.bin/main.c:297
-#, fuzzy
-msgid "Name for output binary map (use output=- for stdout)"
-#: ../raster/r.out.bin/main.c:304
-#, fuzzy
-msgid "Value to write out for null"
-msgstr "के लिए"
-#: ../raster/r.out.bin/main.c:323
-#, fuzzy
-msgid "Generate integer output"
-msgstr "बनाया जा रहा है n"
-#: ../raster/r.out.bin/main.c:327
-#, fuzzy
-msgid "Generate floating-point output"
-#: ../raster/r.out.bin/main.c:331
-#, fuzzy
-msgid "Export array with GMT compatible header"
-msgstr "निर्यात ऐरे जीएमटी"
-#: ../raster/r.out.bin/main.c:335
-msgid "Generate BIL world and header files"
-msgstr ""
-#: ../raster/r.out.bin/main.c:339
-#, fuzzy
-msgid "Byte swap output"
-msgstr "बाइट स्वेप"
-#: ../raster/r.out.bin/main.c:345
-#, fuzzy
-msgid "Invalid value for null (integers only)"
-msgstr "के लिए"
-#: ../raster/r.out.bin/main.c:367
-msgid "order= and -s are mutually exclusive"
-msgstr ""
-#: ../raster/r.out.bin/main.c:376
-msgid "-i and -f are mutually exclusive"
-msgstr ""
-#: ../raster/r.out.bin/main.c:395
-msgid "Floating-point output requires bytes=4 or bytes=8"
-msgstr ""
-#: ../raster/r.out.bin/main.c:399
-msgid "Integer output doesn't support bytes=8 in this build"
-msgstr ""
-#: ../raster/r.out.bin/main.c:413
-msgid "GMT grid doesn't support 64-bit integers"
-msgstr ""
-#: ../raster/r.out.bin/main.c:419
-#, fuzzy
-msgid "Creating BIL support files..."
-msgstr "बनाया जा रहा है के लिए."
-#: ../raster/r.out.bin/main.c:436
-#, fuzzy, c-format
-msgid "Exporting raster as floating values (bytes=%d)"
-#: ../raster/r.out.bin/main.c:438
-msgid "Writing GMT float format ID=1"
-msgstr ""
-#: ../raster/r.out.bin/main.c:441
-#, fuzzy, c-format
-msgid "Exporting raster as integer values (bytes=%d)"
-msgstr "का"
-#: ../raster/r.out.bin/main.c:443
-msgid "Writing GMT integer format ID=2"
-msgstr ""
-#: ../raster/r.out.bin/main.c:446
-#, fuzzy
-msgid "Using the current region settings..."
-msgstr "छापें"
-#: ../raster/r.out.bin/main.c:447
-#, c-format
-msgid "north=%f"
-msgstr ""
-#: ../raster/r.out.bin/main.c:448
-#, c-format
-msgid "south=%f"
-msgstr ""
-#: ../raster/r.out.bin/main.c:449
-#, c-format
-msgid "east=%f"
-msgstr ""
-#: ../raster/r.out.bin/main.c:450
-#, c-format
-msgid "west=%f"
-msgstr ""
-#: ../raster/r.out.bin/main.c:451
-#, c-format
-msgid "r=%d"
-msgstr ""
-#: ../raster/r.out.bin/main.c:452
-#, c-format
-msgid "c=%d"
-msgstr ""
-#: ../raster/r.surf.random/main.c:40
-#, fuzzy
-msgid "Produces a raster map of uniform random deviates whose range can be expressed by the user."
-msgstr "a का किसका."
-#: ../raster/r.surf.random/main.c:47
-msgid "Minimum random value"
-msgstr ""
-#: ../raster/r.surf.random/main.c:53
-msgid "Maximum random value"
-msgstr ""
-#: ../raster/r.surf.random/main.c:59
-#, fuzzy
-msgid "Create an integer raster map"
-msgstr "बनाया जा रहा है i n"
-#: ../raster/r.surf.random/main.c:67
-#, fuzzy, c-format
-msgid "Raster map <%s> generated."
-msgstr "नहीं"
-#: ../raster/r.resample/main.c:57
-msgid "GRASS raster map layer data resampling capability."
-msgstr ""
-#: ../raster/r.resample/main.c:66
-#, fuzzy
-msgid "Name of an input layer"
-msgstr "का"
-#: ../raster/r.resample/main.c:73
-#, fuzzy
-msgid "Name of an output layer"
-msgstr "का"
-#: ../raster/r.resample/main.c:138
-#, fuzzy
-msgid "Creating new cats file..."
-#: ../raster/r.in.mat/main.c:94
-#, fuzzy
-msgid "Imports a binary MAT-File(v4) to a GRASS raster."
-msgstr "आयात a फ़ाइल a."
-#: ../raster/r.in.mat/main.c:103
-#, fuzzy
-msgid "Name of an existing MAT-File(v4)"
-msgstr "का फ़ाइल"
-#: ../raster/r.in.mat/main.c:110
-#, fuzzy
-msgid "Name for the output raster map (override)"
-msgstr "के लिए"
-#: ../raster/r.in.mat/main.c:154
-#, fuzzy
-msgid "Reading MAT-File..."
-msgstr "छवि "
-#: ../raster/r.in.mat/main.c:180
-msgid "Array contains no data"
-msgstr ""
-#: ../raster/r.in.mat/main.c:185
-msgid "Array contains imaginary data"
-msgstr ""
-#: ../raster/r.in.mat/main.c:191
-#, fuzzy
-msgid "Invalid array name"
-msgstr "के लिए"
-#: ../raster/r.in.mat/main.c:211
-msgid "Invalid 'map_name' array"
-msgstr ""
-#: ../raster/r.in.mat/main.c:221
-#, fuzzy
-msgid "Error reading 'map_name' array"
-msgstr "त्रुटि के लिए"
-#: ../raster/r.in.mat/main.c:232
-msgid "Invalid 'map_northern_edge' array"
-msgstr ""
-#: ../raster/r.in.mat/main.c:241
-msgid "Invalid 'map_southern_edge' array"
-msgstr ""
-#: ../raster/r.in.mat/main.c:250
-msgid "Invalid 'map_eastern_edge' array"
-msgstr ""
-#: ../raster/r.in.mat/main.c:259
-msgid "Invalid 'map_western_edge' array"
-msgstr ""
-#: ../raster/r.in.mat/main.c:267
-msgid "Invalid 'map_title' array"
-msgstr ""
-#: ../raster/r.in.mat/main.c:277
-#, fuzzy
-msgid "Error reading 'map_title' array"
-msgstr "त्रुटि."
-#: ../raster/r.in.mat/main.c:290
-msgid "Invalid 'map_data' array"
-msgstr ""
-#: ../raster/r.in.mat/main.c:316 ../raster/r.in.mat/main.c:448
-#: ../raster/r.in.mat/main.c:527
-msgid "Please contact the GRASS development team"
-msgstr ""
-#: ../raster/r.in.mat/main.c:321
-#, c-format
-msgid "Skipping unknown array '%s'"
-msgstr ""
-#: ../raster/r.in.mat/main.c:349
-#, c-format
-msgid "No 'map_data' array found in <%s>"
-msgstr ""
-#: ../raster/r.in.mat/main.c:356
-#, c-format
-msgid "Setting map name to <%s> which overrides <%s>"
-msgstr ""
-#: ../raster/r.in.mat/main.c:363
-#, fuzzy, c-format
-msgid "Setting map name to <%s>"
-msgstr "चेतावनी."
-#: ../raster/r.in.mat/main.c:367
-msgid "No 'map_name' array found; using <MatFile>"
-msgstr ""
-#: ../raster/r.in.mat/main.c:378
-msgid "Missing bound"
-msgstr ""
-#: ../raster/r.in.mat/main.c:382
-msgid "Using default bounds"
-msgstr ""
-#: ../raster/r.in.mat/main.c:396
-#, c-format
-msgid "Map <%s> bounds set to:"
-msgstr ""
-#: ../raster/r.in.mat/main.c:413
-#, fuzzy
-msgid "Writing new raster map..."
-msgstr "i n"
-#: ../raster/r.li/r.li.shape/main.c:33
-#, fuzzy
-msgid "Calculates shape index on a raster map"
-msgstr "नहीं"
-#: ../raster/r.li/r.li.shape/main.c:35 ../raster/r.li/r.li.cwed/cwed.c:47
-#: ../raster/r.li/r.li.patchnum/main.c:37
-#: ../raster/r.li/r.li.simpson/simpson.c:40
-#: ../raster/r.li/r.li.dominance/dominance.c:42
-#: ../raster/r.li/r.li.pielou/pielou.c:59 ../raster/r.li/r.li.mps/mps.c:41
-#: ../raster/r.li/r.li.shannon/shannon.c:39
-#: ../raster/r.li/r.li.richness/richness.c:40
-#: ../raster/r.li/r.li.renyi/renyi.c:46
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:40
-#: ../raster/r.li/r.li.padrange/padrange.c:40
-#: ../raster/r.li/r.li.padsd/padsd.c:38 ../raster/r.li/r.li.mpa/mpa.c:40
-#: ../raster/r.li/r.li.padcv/padcv.c:40
-#: ../raster/r.li/r.li.patchdensity/main.c:36
-#, fuzzy
-msgid "landscape structure analysis"
-msgstr "वस्तु."
-#: ../raster/r.li/r.li.shape/main.c:36 ../raster/r.li/r.li.cwed/cwed.c:48
-#: ../raster/r.li/r.li.patchnum/main.c:38 ../raster/r.li/r.li.mps/mps.c:42
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:41
-#: ../raster/r.li/r.li.padrange/padrange.c:41
-#: ../raster/r.li/r.li.padsd/padsd.c:39 ../raster/r.li/r.li.mpa/mpa.c:41
-#: ../raster/r.li/r.li.padcv/padcv.c:41
-#: ../raster/r.li/r.li.patchdensity/main.c:37
-#, fuzzy
-msgid "patch index"
-msgstr "n"
-#: ../raster/r.li/r.li.shape/main.c:44 ../raster/r.li/r.li.cwed/cwed.c:56
-#: ../raster/r.li/r.li.patchnum/main.c:46
-#: ../raster/r.li/r.li.simpson/simpson.c:49
-#: ../raster/r.li/r.li.dominance/dominance.c:51
-#: ../raster/r.li/r.li.pielou/pielou.c:68 ../raster/r.li/r.li.mps/mps.c:49
-#: ../raster/r.li/r.li.shannon/shannon.c:48
-#: ../raster/r.li/r.li.richness/richness.c:49
-#: ../raster/r.li/r.li.renyi/renyi.c:55
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:49
-#: ../raster/r.li/r.li.padrange/padrange.c:48
-#: ../raster/r.li/r.li.padsd/padsd.c:46 ../raster/r.li/r.li.mpa/mpa.c:48
-#: ../raster/r.li/r.li.padcv/padcv.c:48
-#: ../raster/r.li/r.li.patchdensity/main.c:45
-#, fuzzy
-msgid "Configuration file"
-msgstr "फ़ाइल"
-#: ../raster/r.li/r.li.cwed/cwed.c:45
-#, fuzzy
-msgid "Calculates contrast weighted edge density index on a raster map"
-msgstr "नहीं"
-#: ../raster/r.li/r.li.patchnum/main.c:35
-#, fuzzy
-msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
-msgstr "गणना"
-#: ../raster/r.li/r.li.simpson/simpson.c:38
-#, fuzzy
-msgid "Calculates Simpson's diversity index on a raster map"
-msgstr "a"
-#: ../raster/r.li/r.li.simpson/simpson.c:41
-#: ../raster/r.li/r.li.dominance/dominance.c:43
-#: ../raster/r.li/r.li.pielou/pielou.c:60
-#: ../raster/r.li/r.li.shannon/shannon.c:40
-#: ../raster/r.li/r.li.renyi/renyi.c:47
-#, fuzzy
-msgid "diversity index"
-msgstr "n"
-#: ../raster/r.li/r.li.dominance/dominance.c:40
-#: ../raster/r.li/r.li.richness/richness.c:38
-#, fuzzy
-msgid "Calculates dominance's diversity index on a raster map"
-msgstr "नहीं"
-#: ../raster/r.li/r.li.pielou/pielou.c:57
-#, fuzzy
-msgid "Calculates Pielou's diversity index on a raster map"
-msgstr "a"
-#: ../raster/r.li/r.li.mps/mps.c:39
-msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
-#: ../raster/r.li/r.li.shannon/shannon.c:37
-#, fuzzy
-msgid "Calculates Shannon's diversity index on a raster map"
-msgstr "नहीं"
-#: ../raster/r.li/r.li.richness/richness.c:41
-msgid "dominance index"
-msgstr ""
-#: ../raster/r.li/r.li.renyi/renyi.c:44
-#, fuzzy
-msgid "Calculates Renyi's diversity index on a raster map"
-msgstr "a"
-#: ../raster/r.li/r.li.renyi/renyi.c:63
-msgid "Alpha value is the order of the generalized entropy"
-msgstr ""
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:38
-msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
-#: ../raster/r.li/r.li.padrange/padrange.c:38
-#, fuzzy
-msgid "Calculates range of patch area size on a raster map"
-msgstr "का a."
-#: ../raster/r.li/r.li.padsd/padsd.c:36
-#, fuzzy
-msgid "Calculates standard deviation of patch area a raster map"
-msgstr "का a."
-#: ../raster/r.li/r.li.daemon/daemon.c:101
-#, fuzzy
-msgid "Cannot create random access file"
-msgstr "फ़ाइल"
-#: ../raster/r.li/r.li.daemon/daemon.c:108
-#, fuzzy, c-format
-msgid "Cannot create %s/.grass7/ directory"
-msgstr "का"
-#: ../raster/r.li/r.li.daemon/daemon.c:114
-#, fuzzy, c-format
-msgid "Cannot create %s/.grass7/r.li/ directory"
-msgstr "का"
-#: ../raster/r.li/r.li.daemon/daemon.c:121
-#, fuzzy, c-format
-msgid "Cannot create %s/.grass7/r.li/output/ directory"
-msgstr "का"
-#: ../raster/r.li/r.li.daemon/daemon.c:196
-#, fuzzy, c-format
-msgid "Cannot find configuration file <%s>"
-msgstr "फ़ाइल"
-#: ../raster/r.li/r.li.daemon/daemon.c:203
-#: ../raster/r.li/r.li.daemon/daemon.c:207
-#, fuzzy
-msgid "Cannot read setup file"
-msgstr "फ़ाइल"
-#: ../raster/r.li/r.li.daemon/daemon.c:211
-#, fuzzy
-msgid "Unable to parse configuration file"
-msgstr "फ़ाइल"
-#: ../raster/r.li/r.li.daemon/daemon.c:362
-msgid "Irregular maskedoverlay areas definition"
-msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:365
-#, c-format
-msgid "The configuration file can be used only with \t\t\t%s rasterfile"
-msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:372
-msgid "Illegal configuration file (sample area)"
-msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:406
-#, fuzzy
-msgid "Too many units to place"
-msgstr "ज़ेड"
-#: ../raster/r.li/r.li.daemon/daemon.c:475
-#, fuzzy
-msgid "Too many strats for raster map"
-msgstr "n"
-#: ../raster/r.li/r.li.daemon/daemon.c:509
-msgid "Illegal areas disposition"
-msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:578
-#, fuzzy
-msgid "Cannot make lseek"
-msgstr "के लिए"
-#: ../raster/r.li/r.li.daemon/worker.c:125
-#: ../raster/r.li/r.li.daemon/worker.c:135
-#, c-format
-msgid "unable to open <%s> mask ... continuing without!"
-msgstr ""
-#: ../raster/r.li/r.li.mpa/mpa.c:38
-#, fuzzy
-msgid "Calculates mean pixel attribute index on a raster map"
-msgstr "नहीं"
-#: ../raster/r.li/r.li.padcv/padcv.c:38
-#, fuzzy
-msgid "Calculates coefficient of variation of patch area on a raster map"
-msgstr "का a."
-#: ../raster/r.li/r.li.patchdensity/main.c:34
-msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
-#: ../raster/r.out.ppm/main.c:55
-#, fuzzy
-msgid "Converts a GRASS raster map to a PPM image file."
-msgstr "a a."
-#: ../raster/r.out.ppm/main.c:63
-#, fuzzy
-msgid "Name for new PPM file (use '-' for stdout)"
-#: ../raster/r.out.ppm/main.c:67
-#, fuzzy
-msgid "Output greyscale instead of color"
-msgstr "का"
-#: ../raster/r.out.ppm/main.c:96 ../raster/r.out.ppm3/main.c:94
-#, fuzzy, c-format
-msgid "rows = %d, cols = %d"
-msgstr "n"
-#: ../raster/r.out.ppm/main.c:115
-#, fuzzy, c-format
-msgid "Unable to open file <%s> for write"
-msgstr "के लिए"
-#: ../raster/r.out.ppm/main.c:144
-#, fuzzy
-msgid "Converting..."
-msgstr "का"
-#: ../raster/r.out.ppm/main.c:224
-#, fuzzy, c-format
-msgid "File <%s> created"
-msgstr "n"
-#: ../raster/r.random.cells/init.c:70
-msgid "Distance must be >= 0.0"
-msgstr ""
-#: ../raster/r.random.cells/random.c:50
-#, c-format
-msgid "RAN1: j == %d shouldn't happen"
-msgstr ""
-#: ../raster/r.random.cells/main.c:47
-msgid "cell"
-msgstr ""
-#: ../raster/r.random.cells/main.c:49
-msgid "Generates random cell values with spatial dependence."
-msgstr ""
-#: ../raster/r.random.cells/main.c:59
-#, fuzzy
-msgid "Maximum distance of spatial correlation (value(s) >= 0.0)"
-msgstr "बिन्दु"
-#: ../raster/r.random.cells/main.c:66
-msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default [random])"
-msgstr ""
-#: ../raster/r.timestamp/main.c:37 ../vector/v.timestamp/main.c:38
-#, fuzzy
-msgid "timestamp"
-msgstr "के लिए थीटा"
-#: ../raster/r.timestamp/main.c:38
-#, fuzzy
-msgid "Modifies a timestamp for a raster map."
-msgstr "छापें a के लिए a."
-#: ../raster/r.timestamp/main.c:39
-#, fuzzy
-msgid "Print/add/remove a timestamp for a raster map."
-#: ../raster/r.timestamp/main.c:48 ../vector/v.timestamp/main.c:50
-msgid "Datetime, datetime1/datetime2, or 'none' to remove"
-msgstr ""
-#: ../raster/r.timestamp/main.c:49 ../vector/v.timestamp/main.c:51
-msgid "Format: '15 jan 1994' (absolute) or '2 years' (relative)"
-msgstr ""
-#: ../raster/r.timestamp/main.c:64
-#, fuzzy, c-format
-msgid "Raster map <%s> not found %s"
-msgstr "नहीं"
-#: ../raster/r.out.ascii/main.c:62
-#, fuzzy
-msgid "Converts a raster map layer into a GRASS ASCII text file."
-msgstr "a पाठ."
-#: ../raster/r.out.ascii/main.c:71
-#, fuzzy
-msgid "Name of an existing raster map"
-msgstr "का"
-#: ../raster/r.out.ascii/main.c:79
-#, fuzzy
-msgid "Name for output ASCII grid map (use out=- for stdout)"
-msgstr "का के लिए"
-#: ../raster/r.out.ascii/main.c:93
-#, fuzzy
-msgid "Number of values printed before wrapping a line (only SURFER or MODFLOW format)"
-msgstr "का a"
-#: ../raster/r.out.ascii/main.c:101
-msgid "String to represent null cell (GRASS grid only)"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:109
-msgid "Write SURFER (Golden Software) ASCII grid"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:113
-msgid "Write MODFLOW (USGS) ASCII array"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:117
-#, fuzzy
-msgid "Force output of integer values"
-msgstr "का"
-#: ../raster/r.out.ascii/main.c:124
-msgid "Failed to interpret dp as an integer"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:132
-msgid "Failed to interpret width as an integer"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:138
-msgid "Both -s and -h doesn't make sense"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:141
-msgid "Use -M or -s, not both"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:176
-#, fuzzy, c-format
-msgid "Unable to read fp range for <%s>"
-msgstr "के लिए"
-#: ../raster/r.out.ascii/main.c:192
-#, fuzzy, c-format
-msgid "Read failed at row %d"
-msgstr "n"
-#: ../raster/r.slope.aspect/main.c:153
-#, fuzzy
-msgid "terrain"
-msgstr "पद्धति"
-#: ../raster/r.slope.aspect/main.c:154
-#, fuzzy
-msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from a elevation raster map."
-msgstr "का ढाल a का है पूर्व."
-#: ../raster/r.slope.aspect/main.c:156
-#, fuzzy
-msgid "Aspect is calculated counterclockwise from east."
-msgstr "कोण कोण पूर्व"
-#: ../raster/r.slope.aspect/main.c:163 ../vector/v.surf.rst/main.c:198
-#, fuzzy
-msgid "Name for output slope raster map"
-msgstr "का"
-#: ../raster/r.slope.aspect/main.c:169 ../vector/v.surf.rst/main.c:204
-#, fuzzy
-msgid "Name for output aspect raster map"
-msgstr "का"
-#: ../raster/r.slope.aspect/main.c:178
-#, fuzzy
-msgid "Format for reporting the slope"
-msgstr "के लिए ढाल"
-#: ../raster/r.slope.aspect/main.c:188
-#, fuzzy
-msgid "Type of output aspect and slope maps"
-msgstr "का ढाल"
-#: ../raster/r.slope.aspect/main.c:195 ../vector/v.surf.rst/main.c:210
-#, fuzzy
-msgid "Name for output profile curvature raster map"
-msgstr "का"
-#: ../raster/r.slope.aspect/main.c:202 ../vector/v.surf.rst/main.c:216
-#, fuzzy
-msgid "Name for output tangential curvature raster map"
-msgstr "का"
-#: ../raster/r.slope.aspect/main.c:209
-#, fuzzy
-msgid "Name for output first order partial derivative dx (E-W slope) raster map"
-msgstr "प ढाल फ़ाइलनाम "
-#: ../raster/r.slope.aspect/main.c:216
-#, fuzzy
-msgid "Name for output first order partial derivative dy (N-S slope) raster map"
-msgstr "ढाल फ़ाइलनाम "
-#: ../raster/r.slope.aspect/main.c:223
-#, fuzzy
-msgid "Name for output second order partial derivative dxx raster map"
-msgstr "फ़ाइलनाम "
-#: ../raster/r.slope.aspect/main.c:230
-#, fuzzy
-msgid "Name for output second order partial derivative dyy raster map"
-msgstr "फ़ाइलनाम "
-#: ../raster/r.slope.aspect/main.c:237
-#, fuzzy
-msgid "Name for output second order partial derivative dxy raster map"
-msgstr "फ़ाइलनाम "
-#: ../raster/r.slope.aspect/main.c:243
-#, fuzzy
-msgid "Multiplicative factor to convert elevation units to meters"
-msgstr "मीटर्स"
-#: ../raster/r.slope.aspect/main.c:252
-#, fuzzy
-msgid "Minimum slope val. (in percent) for which aspect is computed"
-msgstr "ढाल के लिए है"
-#: ../raster/r.slope.aspect/main.c:261
-#, fuzzy
-msgid "Do not align the current region to the elevation layer"
-msgstr "नहीं"
-#: ../raster/r.slope.aspect/main.c:313
-#, c-format
-msgid "%s=%s - must be a positive number"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:319
-#, c-format
-msgid "%s=%s - must be a non-negative number"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:334
-#, c-format
-msgid "You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> or <%s>"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:358
-#, fuzzy, c-format
-msgid "Wrong raster type: %s"
-msgstr "i n"
-#: ../raster/r.slope.aspect/main.c:388
-#, c-format
-msgid "Converting units to meters, factor=%.6f"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:968
-#, fuzzy, c-format
-msgid "Elevation products for mapset <%s> in <%s>"
-msgstr "के लिए"
-#: ../raster/r.slope.aspect/main.c:987
-#, fuzzy, c-format
-msgid "Min computed aspect %.4f, max computed aspect %.4f"
-msgstr "ढाल ढाल"
-#: ../raster/r.slope.aspect/main.c:1051
-#, fuzzy, c-format
-msgid "Aspect raster map <%s> complete"
-msgstr "नहीं"
-#: ../raster/r.slope.aspect/main.c:1108
-#, fuzzy, c-format
-msgid "Min computed slope %.4f, max computed slope %.4f"
-msgstr "ढाल ढाल"
-#: ../raster/r.slope.aspect/main.c:1161
-#, fuzzy, c-format
-msgid "Slope raster map <%s> complete"
-msgstr "नहीं"
-#: ../raster/r.slope.aspect/main.c:1233
-#, fuzzy, c-format
-msgid "Profile curve raster map <%s> complete"
-msgstr "के लिए."
-#: ../raster/r.slope.aspect/main.c:1260
-#, fuzzy, c-format
-msgid "Tangential curve raster map <%s> complete"
-msgstr "डाटाटाइप."
-#: ../raster/r.slope.aspect/main.c:1285
-#, fuzzy, c-format
-msgid "E-W slope raster map <%s> complete"
-msgstr "नहीं"
-#: ../raster/r.slope.aspect/main.c:1310
-#, fuzzy, c-format
-msgid "N-S slope raster map <%s> complete"
-msgstr "नहीं"
-#: ../raster/r.slope.aspect/main.c:1335
-#, fuzzy, c-format
-msgid "Dxx raster map <%s> complete"
-msgstr "नहीं"
-#: ../raster/r.slope.aspect/main.c:1360
-#, fuzzy, c-format
-msgid "Dyy raster map <%s> complete"
-msgstr "नहीं"
-#: ../raster/r.slope.aspect/main.c:1385
-#, fuzzy, c-format
-msgid "Dxy raster map <%s> complete"
-msgstr "नहीं"
-#: ../raster/r.bitpattern/main.c:65
-#, fuzzy
-msgid "Compares bit patterns with a raster map."
-msgstr "a"
-#: ../raster/r.bitpattern/main.c:77
-msgid "Bit pattern position(s)"
-msgstr ""
-#: ../raster/r.bitpattern/main.c:83
-msgid "Bit pattern value"
-msgstr ""
-#: ../raster/r.bitpattern/main.c:89
-#, fuzzy
-msgid "Quiet"
-msgstr "शांत"
-#: ../raster/r.to.vect/lines_io.c:76
-msgid "write_line:  found half a loop!"
-msgstr ""
-#: ../raster/r.to.vect/lines_io.c:128
-#, c-format
-msgid ""
-"write_line: line terminated unexpectedly\n"
-"  previous (%d) point %p (%d,%d,%d) %p %p"
-msgstr ""
-#: ../raster/r.to.vect/lines.c:70
-#, fuzzy
-msgid "Extracting lines..."
-msgstr "n"
-#: ../raster/r.to.vect/lines.c:494
-msgid ""
-"Raster map is not thinned properly.\n"
-"Please run r.thin."
-msgstr ""
-#: ../raster/r.to.vect/lines.c:568
-msgid "join_lines: p front pointer not NULL!"
-msgstr ""
-#: ../raster/r.to.vect/lines.c:574
-msgid "join_lines: q front pointer not NULL!"
-msgstr ""
-#: ../raster/r.to.vect/lines.c:592
-msgid "extend line:  p is NULL"
-msgstr ""
-#: ../raster/r.to.vect/lines.c:618
-msgid "extend_lines: p front pointer not NULL!"
-msgstr ""
-#: ../raster/r.to.vect/lines.c:625
-msgid "extend_lines: q back pointer not NULL!"
-msgstr ""
-#: ../raster/r.to.vect/util.c:157 ../raster/r.to.vect/areas_io.c:370
-#: ../vector/v.random/main.c:305 ../vector/v.in.ogr/main.c:968
-#: ../vector/v.in.lidar/main.c:757
-#, c-format
-msgid "Cannot insert new row: %s"
-msgstr ""
-#: ../raster/r.to.vect/main.c:73
-#, fuzzy
-msgid "vectorization"
-msgstr "ट्रेस"
-#: ../raster/r.to.vect/main.c:74
-#, fuzzy
-msgid "Converts a raster map into a vector map."
-msgstr "a a."
-#: ../raster/r.to.vect/main.c:87
-#, fuzzy
-msgid "Name of attribute column to store value"
-msgstr "का के लिए"
-#: ../raster/r.to.vect/main.c:88
-msgid "Name must be SQL compliant"
-msgstr ""
-#: ../raster/r.to.vect/main.c:93
-#, fuzzy
-msgid "Smooth corners of area features"
-msgstr "किनारे"
-#: ../raster/r.to.vect/main.c:98
-#, fuzzy
-msgid "Use raster values as categories instead of unique sequence (CELL only)"
-msgstr "का"
-#: ../raster/r.to.vect/main.c:99 ../raster/r.to.vect/main.c:106
-#: ../vector/v.in.ogr/main.c:209 ../vector/v.in.ogr/main.c:244
-#: ../vector/v.in.ogr/main.c:267 ../vector/v.extract/main.c:91
-#: ../vector/v.extract/main.c:143 ../vector/v.to.rast/main.c:74
-#: ../vector/v.to.rast/main.c:80 ../vector/v.to.rast/main.c:86
-#: ../vector/v.in.lidar/main.c:198
-#, fuzzy
-msgid "Attributes"
-msgstr "नहीं"
-#: ../raster/r.to.vect/main.c:103
-#, fuzzy
-msgid "Write raster values as z coordinate"
-msgstr "के लिए ज़ेड"
-#: ../raster/r.to.vect/main.c:104
-#, fuzzy
-msgid "Table is not created. Currently supported only for points."
-msgstr "ज़ेड है नहीं के लिए"
-#: ../raster/r.to.vect/main.c:110
-#, fuzzy
-msgid "Do not build vector topology"
-msgstr "नहीं"
-#: ../raster/r.to.vect/main.c:111
-msgid "Recommended for massive point conversion"
-msgstr ""
-#: ../raster/r.to.vect/main.c:121
-msgid "z flag is supported only for points"
-msgstr ""
-#: ../raster/r.to.vect/main.c:131
-msgid "Raster is not CELL, '-v' flag ignored, raster values will be written to the table."
-msgstr ""
-#: ../raster/r.to.vect/main.c:209 ../vector/v.random/main.c:195
-#: ../vector/v.lrs/v.lrs.create/main.c:327 ../vector/v.in.ascii/main.c:385
-#: ../vector/v.mkgrid/main.c:243 ../vector/v.in.sites/main.c:172
-#: ../vector/v.in.dxf/write_vect.c:232
-#, fuzzy, c-format
-msgid "Unable to create table: %s"
-msgstr "के लिए"
-#: ../raster/r.to.vect/main.c:213 ../vector/v.overlay/main.c:470
-#: ../vector/v.mkgrid/main.c:247
-#, fuzzy
-msgid "Unable to create index"
-msgstr "का a"
-#: ../raster/r.to.vect/main.c:288
-#, fuzzy, c-format
-msgid "Unable to insert into table: %s"
-msgstr "i n"
-#: ../raster/r.to.vect/areas_io.c:106
-#, c-format
-msgid ""
-"Line terminated unexpectedly\n"
-"previous (%d) point %p (%d,%d,%d) %p %p"
-msgstr ""
-#: ../raster/r.to.vect/areas.c:120
-#, fuzzy
-msgid "Extracting areas..."
-msgstr "n"
-#: ../raster/r.to.vect/points.c:36
-#, fuzzy
-msgid "Extracting points..."
-msgstr "n"
-#: ../raster/r.series.interp/main.c:68
-msgid "Interpolate raster maps located (temporal or spatial) in between input raster maps at specific sampling positions."
-msgstr ""
-#: ../raster/r.series.interp/main.c:78
-#, fuzzy
-msgid "Data point position for each input map"
-msgstr "का"
-#: ../raster/r.series.interp/main.c:83
-msgid "Input file with an input raster map name and data point position per line, field separator between name and sample point is |"
-msgstr ""
-#: ../raster/r.series.interp/main.c:95
-#, fuzzy
-msgid "Sampling point position for each output map"
-msgstr "n"
-#: ../raster/r.series.interp/main.c:99
-msgid "Input infile with an output raster map name and sample point position per line, field separator between name and sample point is |"
-msgstr ""
-#: ../raster/r.series.interp/main.c:109
-msgid "Interpolation method, currently only linear interpolation is supported"
-msgstr ""
-#: ../raster/r.series.interp/main.c:116
-msgid "output= and outfile= are mutually exclusive"
-msgstr ""
-#: ../raster/r.series.interp/main.c:119
-msgid "samplingpos= and outfile= are mutually exclusive"
-msgstr ""
-#: ../raster/r.series.interp/main.c:122
-#, fuzzy
-msgid "Please specify output= or outfile="
-msgstr "ज़ेड."
-#: ../raster/r.series.interp/main.c:125
-#, fuzzy
-msgid "Please specify output= and samplingpos="
-msgstr "ज़ेड."
-#: ../raster/r.series.interp/main.c:128
-msgid "input= and infile= are mutually exclusive"
-msgstr ""
-#: ../raster/r.series.interp/main.c:131
-msgid "datapos= and infile= are mutually exclusive"
-msgstr ""
-#: ../raster/r.series.interp/main.c:134
-#, fuzzy
-msgid "Please specify input= or infile="
-msgstr "ज़ेड."
-#: ../raster/r.series.interp/main.c:137
-#, fuzzy
-msgid "Please specify input= and datapos="
-msgstr "ज़ेड."
-#: ../raster/r.series.interp/main.c:170
-#, fuzzy, c-format
-msgid "Unable to open %s file <%s>"
-msgstr "का"
-#: ../raster/r.series.interp/main.c:203
-#, c-format
-msgid "Missing point position for %s map <%s> in file <%s> near line %i"
-msgstr ""
-#: ../raster/r.series.interp/main.c:218 ../raster/r.series.interp/main.c:252
-#, fuzzy, c-format
-msgid "Preparing %s map <%s> at position %g"
-msgstr "n"
-#: ../raster/r.series.interp/main.c:222
-#, fuzzy, c-format
-msgid "No raster map name found in %s file <%s>"
-msgstr "का"
-#: ../raster/r.series.interp/main.c:233
-#, fuzzy, c-format
-msgid "No %s raster map not found"
-msgstr "नहीं"
-#: ../raster/r.series.interp/main.c:240
-#, fuzzy, c-format
-msgid "The number of %s maps and %s point positions must be equal"
-msgstr "का"
-#: ../raster/r.series.interp/main.c:269
-#, c-format
-msgid "Start interpolation run with %i input maps and %i output maps"
-msgstr ""
-#: ../raster/r.series.interp/main.c:289
-#, c-format
-msgid "map <%s> at position %g was not interpolated. Check the interpolation interval."
-msgstr ""
-#: ../raster/r.series.interp/main.c:309
-#, fuzzy
-msgid "At least 2 input maps are required for linear interpolation"
-msgstr "के लिए"
-#: ../raster/r.series.interp/main.c:327
-#, c-format
-msgid "Interpolate map <%s> at position %g in interval (%g;%g)"
-msgstr ""
-#: ../raster/r.out.ppm3/main.c:58
-#, fuzzy
-msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
-msgstr "R जी a छवि पर का."
-#: ../raster/r.out.ppm3/main.c:83
-#, fuzzy
-msgid "Name for new PPM file. (use out=- for stdout)"
-msgstr "के लिए के लिए"
-#: ../raster/r.out.ppm3/main.c:87
-#, fuzzy
-msgid "Add comments to describe the region"
-msgstr "जोड़ें"
-#: ../raster/r.out.ppm3/main.c:154
-#, fuzzy
-msgid "Converting ... "
-msgstr "का"
-#: ../raster/r.resamp.bspline/main.c:86 ../vector/v.surf.bspline/main.c:96
-msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:94
-#, fuzzy
-msgid "Output vector with interpolation grid"
-msgstr "है त्रुटि"
-#: ../raster/r.resamp.bspline/main.c:99
-#, fuzzy
-msgid "Raster map to use for masking"
-msgstr "का"
-#: ../raster/r.resamp.bspline/main.c:100 ../vector/v.surf.bspline/main.c:132
-msgid "Only cells that are not NULL and not zero are interpolated"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:108
-msgid "Length of each spline step in the east-west direction. Default: 1.5 * ewres."
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:116
-msgid "Length of each spline step in the north-south direction. Default: 1.5 * nsres."
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:123 ../vector/v.surf.bspline/main.c:157
-#, fuzzy
-msgid "Spline interpolation algorithm"
-msgstr "संख्या का"
-#: ../raster/r.resamp.bspline/main.c:132 ../vector/v.surf.bspline/main.c:166
-msgid "Tykhonov regularization parameter (affects smoothing)"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:138
-#, fuzzy
-msgid "Only interpolate null cells in input raster map"
-msgstr "रखें"
-#: ../raster/r.resamp.bspline/main.c:144 ../vector/v.surf.bspline/main.c:101
-msgid "Find the best Tykhonov regularizing parameter using a \"leave-one-out\" cross validation method"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:151
-#, fuzzy
-msgid "Maximum memory to be used (in MB)"
-msgstr "का!"
-#: ../raster/r.resamp.bspline/main.c:186
-#, fuzzy
-msgid "se must be positive"
-msgstr "आकार "
-#: ../raster/r.resamp.bspline/main.c:194
-#, fuzzy
-msgid "sn must be positive"
-msgstr "आकार "
-#: ../raster/r.resamp.bspline/main.c:221
-#, fuzzy, c-format
-msgid "spline step in ew direction %g"
-#: ../raster/r.resamp.bspline/main.c:222
-#, c-format
-msgid "spline step in ns direction %g"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:223 ../vector/v.outlier/main.c:272
-#: ../vector/v.lidar.edgedetection/main.c:294
-#: ../vector/v.lidar.correction/main.c:274 ../vector/v.surf.bspline/main.c:530
-#, c-format
-msgid "adjusted EW splines %d"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:224 ../vector/v.outlier/main.c:273
-#: ../vector/v.lidar.edgedetection/main.c:295
-#: ../vector/v.lidar.correction/main.c:275 ../vector/v.surf.bspline/main.c:531
-#, c-format
-msgid "adjusted NS splines %d"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:291 ../vector/v.surf.bspline/main.c:436
-msgid "Memory in MB must be >= 3"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:307 ../raster/r.resamp.bspline/main.c:393
-#: ../raster/r.resamp.bspline/main.c:464 ../vector/v.surf.bspline/main.c:450
-#: ../vector/v.surf.bspline/main.c:478
-#, fuzzy
-msgid "Can not create temporary file"
-msgstr "बनाया जा रहा है."
-#: ../raster/r.resamp.bspline/main.c:312 ../raster/r.resamp.bspline/main.c:398
-#: ../raster/r.resamp.bspline/main.c:469 ../vector/v.surf.bspline/main.c:455
-#: ../vector/v.surf.bspline/main.c:483
-#, fuzzy
-msgid "Can not initialize temporary file"
-msgstr "नहीं"
-#: ../raster/r.resamp.bspline/main.c:318
-#, fuzzy, c-format
-msgid "Loading input raster <%s>"
-msgstr "n"
-#: ../raster/r.resamp.bspline/main.c:338
-#, fuzzy
-msgid "Only NULL cells in input raster"
-msgstr "रखें"
-#: ../raster/r.resamp.bspline/main.c:362 ../vector/v.surf.bspline/main.c:292
-msgid "Cross validation didn't finish correctly"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:366
-#, c-format
-msgid "Cross validation finished for se = %f and sn = %f"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:386
-#, fuzzy
-msgid "Mark cells for interpolation"
-msgstr "संख्या का"
-#: ../raster/r.resamp.bspline/main.c:457
-msgid "No NULL cells found in input raster."
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:472 ../vector/v.surf.bspline/main.c:458
-#, fuzzy
-msgid "Initializing output..."
-msgstr "n"
-#: ../raster/r.resamp.bspline/main.c:545 ../vector/v.outlier/main.c:328
-#: ../vector/v.lidar.edgedetection/main.c:350
-#: ../vector/v.lidar.correction/main.c:330 ../vector/v.surf.bspline/main.c:599
-#: ../vector/v.lidar.growing/main.c:246
-#, fuzzy, c-format
-msgid "subregion %d of %d"
-msgstr "n"
-#: ../raster/r.resamp.bspline/main.c:719
-msgid "No data within this subregion. Consider increasing the spline step."
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:735 ../vector/v.surf.bspline/main.c:856
-#, fuzzy
-msgid "Writing output..."
-msgstr "n"
-#: ../raster/r.resamp.bspline/crosscorr.c:160
-#, c-format
-msgid "%d are too many cells, recommended are < 100 cells. The cross validation would take too much time."
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:169
-#: ../vector/v.surf.bspline/crosscorr.c:81
-#, fuzzy, c-format
-msgid "%d points read in region"
-msgstr "नहीं"
-#: ../raster/r.resamp.bspline/crosscorr.c:173
-msgid "Maybe it takes too long.Consider reducing the region extends."
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:193
-#: ../vector/v.surf.bspline/crosscorr.c:146
-#, c-format
-msgid "Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:211
-#: ../vector/v.surf.bspline/crosscorr.c:164
-#, c-format
-msgid "Beginning cross validation with lambda_i=%.4f..."
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:296
-#: ../vector/v.surf.bspline/crosscorr.c:284
-#, c-format
-msgid "Mean = %.5lf"
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:297
-#: ../vector/v.surf.bspline/crosscorr.c:285
-#, fuzzy, c-format
-msgid "Root Means Square (RMS) = %.5lf"
-msgstr "नहीं"
-#: ../raster/r.resamp.bspline/crosscorr.c:313
-#: ../vector/v.surf.bspline/crosscorr.c:301
-msgid "Different number of splines and lambda_i values have been taken for the cross correlation"
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:315
-#: ../vector/v.surf.bspline/crosscorr.c:303
-#, c-format
-msgid "The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:323
-#: ../vector/v.surf.bspline/crosscorr.c:311
-#, fuzzy
-msgid "Results into a table:"
-msgstr "का"
-#: ../raster/r.resamp.bspline/crosscorr.c:324
-#: ../vector/v.surf.bspline/crosscorr.c:312
-#, fuzzy
-msgid " lambda    | mean        | rms         |"
-msgstr "n n"
-#: ../raster/r.resamp.bspline/crosscorr.c:326
-#: ../vector/v.surf.bspline/crosscorr.c:314
-#, c-format
-msgid " %-10.5f| %-12.4f| %-12.4f|"
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:334
-#: ../vector/v.surf.bspline/crosscorr.c:322
-#, fuzzy
-msgid "No point lies into the current region"
-msgstr "नहीं"
-#: ../raster/r.transect/main.c:84
-#, c-format
-msgid "End coordinate: %.15g, %.15g"
-msgstr ""
-#: ../raster/r.transect/main.c:104
-#, fuzzy
-msgid "transect"
-msgstr "चालू"
-#: ../raster/r.transect/main.c:106
-msgid "Outputs raster map layer values lying along user defined transect line(s)."
-msgstr ""
-#: ../raster/r.transect/main.c:110
-msgid "Raster map to be queried"
-msgstr ""
-#: ../raster/r.transect/main.c:116
-msgid "Transect definition"
-msgstr ""
-#: ../raster/r.surf.idw/main.c:108
-#, fuzzy
-msgid "Surface interpolation utility for raster map."
-msgstr "सतह के लिए."
-#: ../raster/r.surf.idw/main.c:123
-#, fuzzy
-msgid "Output is the interpolation error"
-msgstr "है त्रुटि"
-#: ../raster/r.surf.idw/main.c:129
-#, fuzzy, c-format
-msgid "Illegal value for '%s' (%s)"
-msgstr "के लिए"
-#: ../raster/r.surf.idw/main.c:255
-#, fuzzy, c-format
-msgid "Interpolating raster map <%s> (%d rows)..."
-msgstr "i n"
-#: ../raster/r.surf.area/main.c:79
-#, fuzzy
-msgid "area estimation"
-msgstr "ट्रेस"
-#: ../raster/r.surf.area/main.c:80
-#, fuzzy
-msgid "Prints estimation of surface area for raster map."
-msgstr "का a."
-#: ../raster/r.surf.area/main.c:89
-#, fuzzy
-msgid "Vertical scale"
-msgstr "खड़ा स्केल"
-#: ../raster/r.surf.area/main.c:93
-#, fuzzy
-msgid "Output units"
-msgstr "नहीं"
-#: ../raster/r.surf.area/main.c:94
-#, fuzzy
-msgid "Default: square map units"
-msgstr "त्रुटि"
-#: ../raster/r.surf.area/main.c:102
-#, fuzzy, c-format
-msgid "Output in '%s'"
-msgstr "नहीं"
-#: ../raster/r.surf.area/main.c:106
-#, fuzzy
-msgid "Output in 'square map units'"
-msgstr "शीर्षक"
-#: ../raster/r.surf.area/main.c:151
-#, fuzzy
-msgid "Null value area ignored in calculation:"
-msgstr "शून्य (Null)"
-#: ../raster/r.surf.area/main.c:153
-#, fuzzy
-msgid "Plan area used in calculation:"
-msgstr "है a"
-#: ../raster/r.surf.area/main.c:156
-msgid "Surface area calculation(low, high, avg):"
-msgstr ""
-#: ../raster/r.surf.area/main.c:161
-#, fuzzy
-msgid "Current region plan area:"
-msgstr "सेट."
-#: ../raster/r.surf.area/main.c:163
-msgid "Estimated region Surface Area:"
-msgstr ""
-#: ../raster/r.grow/main.c:124 ../locale/scriptstrings/r.grow_to_translate.c:1
-#, fuzzy
-msgid "Generates a raster map layer with contiguous areas grown by one cell."
-msgstr "a एक."
-#: ../raster/r.grow/main.c:135 ../locale/scriptstrings/r.grow_to_translate.c:4
-#, fuzzy
-msgid "Radius of buffer in raster cells"
-msgstr "का"
-#: ../raster/r.grow/main.c:151 ../locale/scriptstrings/r.grow_to_translate.c:6
-#, fuzzy
-msgid "Value to write for input cells which are non-NULL (-1 => NULL)"
-msgstr "के लिए"
-#: ../raster/r.grow/main.c:157 ../locale/scriptstrings/r.grow_to_translate.c:7
-#, fuzzy
-msgid "Value to write for \"grown\" cells"
-msgstr "के लिए"
-#: ../raster/r.grow/main.c:183
-#, c-format
-msgid "Unknown metric: [%s]."
-msgstr ""
-#: ../raster/r.grow/main.c:192
-#, fuzzy, c-format
-msgid "Error reading category file for <%s>"
-msgstr "त्रुटि के लिए."
-#: ../raster/r.grow/main.c:197
-#, fuzzy, c-format
-msgid "Error in reading color file for <%s>"
-#: ../raster/r.neighbors/main.c:121
-#, fuzzy
-msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
-msgstr "a फंक्शन का."
-#: ../raster/r.neighbors/main.c:131
-#, fuzzy
-msgid "Name of an input raster map to select the cells which should be processed"
-msgstr "का रखे हुए"
-#: ../raster/r.neighbors/main.c:149 ../vector/v.neighbors/main.c:69
-msgid "Neighborhood operation"
-msgstr ""
-#: ../raster/r.neighbors/main.c:150 ../raster/r.neighbors/main.c:158
-#: ../raster/r.neighbors/main.c:193
-#, fuzzy
-msgid "Neighborhood"
-msgstr "आकार "
-#: ../raster/r.neighbors/main.c:156
-#, fuzzy
-msgid "Neighborhood size"
-msgstr "आकार "
-#: ../raster/r.neighbors/main.c:165
-#, fuzzy
-msgid "Title of the output raster map"
-msgstr "का"
-#: ../raster/r.neighbors/main.c:170
-#, fuzzy
-msgid "Text file containing weights"
-msgstr "फ़ाइल"
-#: ../raster/r.neighbors/main.c:176
-#, fuzzy
-msgid "Sigma (in cells) for Gaussian filter"
-msgstr "का फ़िल्टर"
-#: ../raster/r.neighbors/main.c:188
-#, fuzzy
-msgid "Do not align output with the input"
-msgstr "नहीं"
-#: ../raster/r.neighbors/main.c:192
-msgid "Use circular neighborhood"
-msgstr ""
-#: ../raster/r.neighbors/main.c:200
-#, fuzzy
-msgid "Neighborhood size must be positive"
-msgstr "आकार "
-#: ../raster/r.neighbors/main.c:202
-#, fuzzy
-msgid "Neighborhood size must be odd"
-msgstr "आकार "
-#: ../raster/r.neighbors/main.c:206
-msgid "weight= and -c are mutually exclusive"
-msgstr ""
-#: ../raster/r.neighbors/main.c:209
-msgid "weight= and gauss= are mutually exclusive"
-msgstr ""
-#: ../raster/r.neighbors/main.c:267
-#, fuzzy, c-format
-msgid "Method %s not compatible with Gaussian filter"
-#: ../raster/r.neighbors/main.c:293
-#, fuzzy, c-format
-msgid "Opening selection map <%s>"
-msgstr "n"
-#: ../raster/r.neighbors/readweights.c:18
-#, fuzzy, c-format
-msgid "Unable to open weights file %s"
-msgstr "के लिए"
-#: ../raster/r.neighbors/readweights.c:23
-#, fuzzy, c-format
-msgid "Error reading weights file %s"
-#: ../raster/r.resamp.interp/main.c:79
-#, fuzzy
-msgid "Resamples raster map layers to a finer grid using interpolation."
-msgstr "a."
-#: ../raster/r.resamp.interp/main.c:88 ../vector/v.sample/main.c:102
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:7
-#, fuzzy
-msgid "Interpolation method"
-msgstr "पद्धति"
-#: ../raster/r.resamp.interp/main.c:104
-#, fuzzy, c-format
-msgid "Invalid method: %s"
-msgstr "अवैध"
-#: ../raster/r.proj/readcell.c:64 ../imagery/i.rectify/readcell.c:62
-#, fuzzy
-msgid "Allocating memory and reading input map..."
-msgstr "का"
-#: ../raster/r.proj/readcell.c:90 ../raster/r.proj/readcell.c:129
-#: ../imagery/i.rectify/readcell.c:88 ../imagery/i.rectify/readcell.c:127
-#, fuzzy
-msgid "Error writing segment file"
-msgstr "त्रुटि n"
-#: ../raster/r.proj/readcell.c:117 ../imagery/i.rectify/readcell.c:115
-msgid "Internal error: cache miss on fully-cached map"
-msgstr ""
-#: ../raster/r.proj/readcell.c:126 ../imagery/i.rectify/readcell.c:124
-#, fuzzy
-msgid "Error seeking on segment file"
-msgstr "त्रुटि"
-#: ../raster/r.proj/main.c:147 ../imagery/i.latlong/main.c:59
-#: ../general/g.proj/main.c:63 ../general/g.setproj/main.c:79
-#: ../vector/v.proj/main.c:67 ../locale/scriptstrings/m.proj_to_translate.c:3
-#, fuzzy
-msgid "projection"
-msgstr "नहीं n"
-#: ../raster/r.proj/main.c:150
-#, fuzzy
-msgid "Re-projects a raster map from given location to the current location."
-msgstr "a एक."
-#: ../raster/r.proj/main.c:153
-#, fuzzy
-msgid "Name of input raster map to re-project"
-msgstr "का"
-#: ../raster/r.proj/main.c:155 ../raster/r.proj/main.c:168
-#: ../raster/r.proj/main.c:177 ../vector/v.proj/main.c:75
-#: ../vector/v.proj/main.c:92 ../vector/v.proj/main.c:101
-#: ../vector/v.net.flow/main.c:108 ../vector/v.net.flow/main.c:114
-#, fuzzy
-msgid "Source"
-msgstr "नहीं n"
-#: ../raster/r.proj/main.c:161
-#, fuzzy
-msgid "Location containing input raster map"
-msgstr "का"
-#: ../raster/r.proj/main.c:166
-#, fuzzy
-msgid "Mapset containing input raster map"
-msgstr "का"
-#: ../raster/r.proj/main.c:167
-#, fuzzy
-msgid "default: name of current mapset"
-msgstr "छापें का"
-#: ../raster/r.proj/main.c:174 ../vector/v.proj/main.c:98
-#, fuzzy
-msgid "Path to GRASS database of input location"
-msgstr "का"
-#: ../raster/r.proj/main.c:181
-#, fuzzy
-msgid "Name for output raster map (default: same as 'input')"
-msgstr "शीर्षक"
-#: ../raster/r.proj/main.c:182 ../raster/r.proj/main.c:193
-#: ../raster/r.proj/main.c:207 ../raster/r.proj/main.c:221
-#: ../raster/r.proj/main.c:227 ../vector/v.proj/main.c:106
-#: ../vector/v.proj/main.c:118 ../vector/v.proj/main.c:125
-#, fuzzy
-msgid "Target"
-msgstr "n"
-#: ../raster/r.proj/main.c:192 ../imagery/i.rectify/main.c:143
-#, fuzzy
-msgid "Interpolation method to use"
-msgstr "पद्धति"
-#: ../raster/r.proj/main.c:200 ../raster/r.in.gdal/main.c:104
-#, fuzzy
-msgid "Cache size (MiB)"
-msgstr "आकार  पिक्सेल्स"
-#: ../raster/r.proj/main.c:206
-#, fuzzy
-msgid "Resolution of output raster map"
-msgstr "का"
-#: ../raster/r.proj/main.c:211
-msgid "List raster maps in input location and exit"
-msgstr ""
-#: ../raster/r.proj/main.c:215
-#, fuzzy
-msgid "Do not perform region cropping optimization"
-msgstr "नहीं"
-#: ../raster/r.proj/main.c:220
-#, fuzzy
-msgid "Print input map's bounds in the current projection and exit"
-msgstr "स्रोत"
-#: ../raster/r.proj/main.c:226
-#, fuzzy
-msgid "Print input map's bounds in the current projection and exit (shell style)"
-msgstr "छापें"
-#: ../raster/r.proj/main.c:251 ../vector/v.proj/main.c:144
-#: ../vector/v.external/main.c:87
-#, fuzzy, c-format
-msgid "option <%s>: <%s> exists."
-msgstr "नहीं"
-#: ../raster/r.proj/main.c:257 ../vector/v.proj/main.c:161
-msgid "Input and output locations can not be the same"
-msgstr ""
-#: ../raster/r.proj/main.c:259
-#, fuzzy
-msgid "Input and output locations are the same"
-msgstr "का"
-#: ../raster/r.proj/main.c:269
-#, fuzzy
-msgid "Unable to get projection info of output raster map"
-msgstr "का"
-#: ../raster/r.proj/main.c:272
-#, fuzzy
-msgid "Unable to get projection units of output raster map"
-msgstr "का"
-#: ../raster/r.proj/main.c:275
-#, fuzzy
-msgid "Unable to get projection key values of output raster map"
-msgstr "का"
-#: ../raster/r.proj/main.c:284
-#, fuzzy, c-format
-msgid "Mapset <%s> in input location <%s> - %s"
-msgstr "समूह के लिए n"
-#: ../raster/r.proj/main.c:286 ../raster/r.in.gdal/main.c:691
-#: ../imagery/i.rectify/target.c:33 ../vector/v.rectify/target.c:38
-msgid "permission denied"
-msgstr ""
-#: ../raster/r.proj/main.c:287 ../raster/r.in.gdal/main.c:692
-#, fuzzy
-msgid "not found"
-msgstr "नहीं"
-#: ../raster/r.proj/main.c:293 ../vector/v.proj/main.c:185
-#, fuzzy, c-format
-msgid "Checking location <%s> mapset <%s>"
-msgstr "का"
-#: ../raster/r.proj/main.c:305 ../vector/v.in.ogr/main.c:310
-#: ../vector/v.net/args.c:111 ../vector/v.net/args.c:117
-#: ../vector/v.net/args.c:123 ../vector/v.net/args.c:127
-#: ../vector/v.net/args.c:137 ../vector/v.proj/main.c:197
-#: ../vector/v.edit/main.c:84 ../vector/v.external/main.c:66
-#: ../vector/v.select/main.c:86
-#, fuzzy, c-format
-msgid "Required parameter <%s> not set"
-msgstr "का."
-#: ../raster/r.proj/main.c:308
-#, fuzzy, c-format
-msgid "Raster map <%s> in location <%s> in mapset <%s> not found"
-msgstr "सदिश नहीं"
-#: ../raster/r.proj/main.c:316
-#, fuzzy
-msgid "Unable to get projection info of input map"
-msgstr "का"
-#: ../raster/r.proj/main.c:319
-#, fuzzy
-msgid "Unable to get projection units of input map"
-msgstr "का"
-#: ../raster/r.proj/main.c:322
-#, fuzzy
-msgid "Unable to get projection key values of input map"
-msgstr "का"
-#: ../raster/r.proj/main.c:337
-msgid "Unable to work with unprojected data (xy location)"
-msgstr ""
-#: ../raster/r.proj/main.c:356
-#, fuzzy, c-format
-msgid "Input map <%s@%s> in location <%s>:"
-#: ../raster/r.proj/main.c:445
-msgid "Input:"
-msgstr ""
-#: ../raster/r.proj/main.c:446 ../raster/r.proj/main.c:457
-#, fuzzy, c-format
-msgid "Cols: %d (%d)"
-msgstr "n"
-#: ../raster/r.proj/main.c:447 ../raster/r.proj/main.c:458
-#, fuzzy, c-format
-msgid "Rows: %d (%d)"
-msgstr "n"
-#: ../raster/r.proj/main.c:448 ../raster/r.proj/main.c:459
-#, fuzzy, c-format
-msgid "North: %f (%f)"
-msgstr "f f n"
-#: ../raster/r.proj/main.c:449 ../raster/r.proj/main.c:460
-#, c-format
-msgid "South: %f (%f)"
-msgstr ""
-#: ../raster/r.proj/main.c:450 ../raster/r.proj/main.c:461
-#, fuzzy, c-format
-msgid "West: %f (%f)"
-msgstr "f f n"
-#: ../raster/r.proj/main.c:451 ../raster/r.proj/main.c:462
-#, fuzzy, c-format
-msgid "East: %f (%f)"
-msgstr "f f n"
-#: ../raster/r.proj/main.c:452 ../raster/r.proj/main.c:463
-#, c-format
-msgid "EW-res: %f"
-msgstr ""
-#: ../raster/r.proj/main.c:453 ../raster/r.proj/main.c:464
-#, c-format
-msgid "NS-res: %f"
-msgstr ""
-#: ../raster/r.proj/main.c:456
-msgid "Output:"
-msgstr ""
-#: ../raster/r.proj/main.c:492
-#, fuzzy
-msgid "Projecting..."
-msgstr "नक़ल"
-#: ../raster/r.proj/bordwalk.c:183
-#, fuzzy
-msgid "Input raster map is outside current region"
-msgstr "नहीं"
-#: ../raster/r.info/main.c:71 ../vector/v.info/main.c:41
-msgid "history"
-msgstr ""
-#: ../raster/r.info/main.c:73
-#, fuzzy
-msgid "Outputs basic information about a raster map."
-msgstr "a."
-#: ../raster/r.info/main.c:79
-#, fuzzy
-msgid "Print raster array information only"
-msgstr "छापें"
-#: ../raster/r.info/main.c:87
-#, fuzzy
-msgid "Print extended metadata information only"
-msgstr "छापें"
-#: ../raster/r.info/main.c:91
-#, fuzzy
-msgid "Print raster history instead of info"
-msgstr "छापें का"
-#: ../raster/r.info/main.c:122
-#, fuzzy
-msgid "Unable to read range file"
-msgstr "का"
-#: ../raster/r.reclass/reclass.c:50 ../raster/r.reclass/reclass.c:110
-#, fuzzy
-msgid "Too many categories"
-msgstr "घुमाएँ"
-#: ../raster/r.reclass/reclass.c:215
-#, fuzzy, c-format
-msgid "Cannot read header file of <%s@%s>"
-msgstr "का"
-#: ../raster/r.reclass/reclass.c:230
-#, fuzzy, c-format
-msgid "Cannot create reclass file of <%s>"
-msgstr "डाटाटाइप."
-#: ../raster/r.reclass/reclass.c:238
-#, fuzzy, c-format
-msgid "Cannot create raster map <%s>"
-msgstr "डाटाटाइप."
-#: ../raster/r.reclass/main.c:51
-#, fuzzy
-msgid "reclassification"
-msgstr "के लिए"
-#: ../raster/r.reclass/main.c:52
-#, fuzzy
-msgid "Reclassify raster map based on category values."
-msgstr "क्वैरीज़ चालू."
-#: ../raster/r.reclass/main.c:54
-#, fuzzy
-msgid "Creates a new raster map whose category values are based upon a reclassification of the categories in an existing raster map."
-msgstr "a किसका का."
-#: ../raster/r.reclass/main.c:59
-#, fuzzy
-msgid "Name of raster map to be reclassified"
-msgstr "का"
-#: ../raster/r.reclass/main.c:65
-#, fuzzy
-msgid "File containing reclass rules"
-msgstr "फ़ाइल"
-#: ../raster/r.reclass/main.c:72
-#, fuzzy
-msgid "Title for the resulting raster map"
-msgstr "के लिए"
-#: ../raster/r.reclass/main.c:83
-msgid "Input map can NOT be the same as output map"
-msgstr ""
-#: ../raster/r.reclass/main.c:89
-#, fuzzy, c-format
-msgid "Cannot open rules file <%s>"
-msgstr "फ़ाइल"
-#: ../raster/r.reclass/main.c:103
-#, fuzzy, c-format
-msgid "Enter rule(s), \"end\" when done, \"help\" if you need it\n"
-msgstr "सम्पन्न n"
-#: ../raster/r.reclass/main.c:105
-#, fuzzy, c-format
-msgid "FCELL: Data range is %.7g to %.7g\n"
-msgstr "है n"
-#: ../raster/r.reclass/main.c:108
-#, fuzzy, c-format
-msgid "DCELL: Data range is %.15g to %.15g\n"
-msgstr "है n"
-#: ../raster/r.reclass/main.c:111
-#, fuzzy, c-format
-msgid "CELL: Data range is %ld to %ld\n"
-msgstr "है n"
-#: ../raster/r.reclass/main.c:119
-#, fuzzy, c-format
-msgid "Illegal reclass rule -"
-msgstr "पूर्व"
-#: ../raster/r.reclass/main.c:120
-#, c-format
-msgid " ignored\n"
-msgstr ""
-#: ../raster/r.reclass/main.c:123
-msgid " - invalid reclass rule"
-msgstr ""
-#: ../raster/r.reclass/main.c:139
-#, fuzzy, c-format
-msgid "No rules specified. Raster map <%s> not created"
-msgstr "नहीं"
-#: ../raster/r.reclass/parse.c:42
-msgid "poor quality"
-msgstr ""
-#: ../raster/r.reclass/parse.c:44
-msgid "medium quality"
-msgstr ""
-#: ../raster/r.reclass/parse.c:59
-msgid "Can't have null on the left-hand side of the rule"
-msgstr ""
-#: ../raster/r.reclass/parse.c:88 ../raster/r.reclass/parse.c:100
-msgid "Can't have null on the right-hand side of the rule"
-msgstr ""
-#: ../raster/r.reclass/parse.c:196
-#, c-format
-msgid "%f rounded up to %d\n"
-msgstr ""
-#: ../raster/r.coin/main.c:69
-#, fuzzy
-msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
-msgstr "का के लिए दो."
-#: ../raster/r.coin/main.c:77
-#, fuzzy
-msgid "Name of first raster map"
-msgstr "का"
-#: ../raster/r.coin/main.c:84
-#, fuzzy
-msgid "Name of second raster map"
-msgstr "का"
-#: ../raster/r.coin/main.c:90
-#, fuzzy
-msgid "Unit of measure"
-msgstr "का"
-#: ../raster/r.coin/main.c:92
-msgid "c(ells), p(ercent), x(percent of category [column]), y(percent of category [row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
-msgstr ""
-#: ../raster/r.coin/main.c:99
-msgid "Wide report, 132 columns (default: 80)"
-msgstr ""
-#: ../raster/r.coin/make_coin.c:48
-#, c-format
-msgid "Tabulating Coincidence between '%s' and '%s'"
-msgstr ""
-#: ../raster/r.coin/make_coin.c:61
-#, fuzzy
-msgid "Unable to create any tempfiles"
-#: ../raster/r.coin/make_coin.c:65
-#, fuzzy
-msgid "Unable to run r.stats"
-msgstr "सेट आकार "
-#: ../raster/r.coin/make_coin.c:72
-msgid "Unexpected output from r.stats"
-msgstr ""
-#: ../raster/r.coin/make_coin.c:84
-#, fuzzy
-msgid "Unable to open tempfile"
-msgstr "का"
-#: ../raster/r.coin/print_coin.c:44
-#, fuzzy, c-format
-msgid "Preparing report ..."
-msgstr "n"
-#: ../raster/r.texture/h_measure.c:123
-#, fuzzy, c-format
-msgid "Too many categories (found: %i, max: %i). Try to rescale or reclassify the map"
-msgstr "i i कोशिश करें"
-#: ../raster/r.texture/main.c:67
-#, fuzzy, c-format
-msgid "Unknown measure <%s>"
-msgstr "अज्ञात क़िस्म"
-#: ../raster/r.texture/main.c:104
-#, fuzzy
-msgid "texture"
-msgstr "विशेषता"
-#: ../raster/r.texture/main.c:106
-#, fuzzy
-msgid "Generate images with textural features from a raster map."
-msgstr "छवियाँ a"
-#: ../raster/r.texture/main.c:117
-#, fuzzy
-msgid "Prefix for output raster map(s)"
-msgstr "का"
-#: ../raster/r.texture/main.c:124
-#, fuzzy
-msgid "The size of moving window (odd and >= 3)"
-msgstr "आकार  का"
-#: ../raster/r.texture/main.c:134
-#, fuzzy
-msgid "The distance between two samples (>= 1)"
-msgstr "दो नमूने"
-#: ../raster/r.texture/main.c:150
-#, fuzzy
-msgid "Textural measurement method"
-msgstr "n"
-#: ../raster/r.texture/main.c:154
-msgid "Separate output for each angle (0, 45, 90, 135)"
-msgstr ""
-#: ../raster/r.texture/main.c:158
-#, fuzzy
-msgid "Calculate all textural measurements"
-msgstr "n"
-#: ../raster/r.texture/main.c:167
-msgid "Size of the moving window must be > 0"
-msgstr ""
-#: ../raster/r.texture/main.c:169
-msgid "Size of the moving window must be odd"
-msgstr ""
-#: ../raster/r.texture/main.c:172
-#, fuzzy
-msgid "The distance between two samples must be > 0"
-msgstr "दो नमूने"
-#: ../raster/r.texture/main.c:193
-msgid "Nothing to compute. Use at least one textural measure."
-msgstr ""
-#: ../raster/r.texture/main.c:331
-#, fuzzy, c-format
-msgid "Calculating %d texture measures"
-msgstr "n"
-#: ../raster/r.texture/main.c:333
-#, fuzzy, c-format
-msgid "Calculating %s"
-msgstr "n"
-#: ../raster/r.in.gdal/main.c:84
-#, fuzzy
-msgid "Imports raster data into a GRASS raster map using GDAL library."
-msgstr "आयात a a."
-#: ../raster/r.in.gdal/main.c:90
-#, fuzzy
-msgid "Name of raster file to be imported"
-msgstr "का"
-#: ../raster/r.in.gdal/main.c:98
-#, fuzzy
-msgid "Band to select (default is all bands)"
-msgstr "है सभी"
-#: ../raster/r.in.gdal/main.c:111
-#, fuzzy
-msgid "Name of location to read projection from for GCPs transformation"
-msgstr "का के लिए"
-#: ../raster/r.in.gdal/main.c:127
-msgid "The offset will be added to the band number while output raster map name creation"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:134 ../vector/v.in.ogr/main.c:198
-#: ../vector/v.in.lidar/main.c:178
-#, fuzzy
-msgid "Name for new location to create"
-msgstr "के लिए"
-#: ../raster/r.in.gdal/main.c:157
-#, fuzzy
-msgid "Force Lat/Lon maps to fit into geographic coordinates (90N,S; 180E,W)"
-msgstr "ज़ेड"
-#: ../raster/r.in.gdal/main.c:162
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:13
-#, fuzzy
-msgid "Keep band numbers instead of using band color names"
-msgstr "रखें का"
-#: ../raster/r.in.gdal/main.c:167
-msgid "Create the location specified by the \"location\" parameter and exit. Do not import the raster file."
-msgstr ""
-#: ../raster/r.in.gdal/main.c:192
-msgid "You have to specify a target location different from output location"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:196
-msgid "You need to specify valid location name."
-msgstr ""
-#: ../raster/r.in.gdal/main.c:200
-msgid "The '-l' flag only works in Lat/Lon locations"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:218
-#, fuzzy
-msgid "Available GDAL Drivers:"
-msgstr "सभी"
-#: ../raster/r.in.gdal/main.c:240 ../imagery/i.landsat.toar/main.c:482
-#, fuzzy, c-format
-msgid "Raster map <%s> already exists and will be overwritten"
-msgstr "i n"
-#: ../raster/r.in.gdal/main.c:243
-#, fuzzy, c-format
-msgid "Raster map <%s> already exists"
-msgstr "नहीं"
-#: ../raster/r.in.gdal/main.c:260
-msgid "The polynomial rectification used in i.rectify does not work well with NOAA/AVHRR data. Try using gdalwarp with thin plate spline rectification instead. (-tps)"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:276
-msgid "Input raster map is flipped or rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
-msgstr ""
-#: ../raster/r.in.gdal/main.c:317
-msgid "Map bounds have been constrained to geographic coordinates. You will almost certainly want to check map bounds and resolution with r.info and reset them with r.region before going any further."
-msgstr ""
-#: ../raster/r.in.gdal/main.c:337 ../vector/v.in.ogr/main.c:517
-#: ../vector/v.in.lidar/main.c:341
-msgid "Unable to convert input map projection to GRASS format; cannot create new location."
-msgstr ""
-#: ../raster/r.in.gdal/main.c:343 ../general/g.proj/create.c:15
-#: ../vector/v.in.ogr/main.c:523 ../vector/v.in.lidar/main.c:347
-#, fuzzy, c-format
-msgid "Location <%s> created"
-msgstr "n"
-#: ../raster/r.in.gdal/main.c:447
-#, fuzzy
-msgid ""
-"\n"
-"You can use the -o flag to r.in.gdal to override this check and use the location definition for the dataset.\n"
-msgstr "n"
-#: ../raster/r.in.gdal/main.c:565
-#, fuzzy, c-format
-msgid "Copying %d GCPS in points file for <%s>"
-#: ../raster/r.in.gdal/main.c:570
-msgid "GCPs have the following OpenGIS WKT Coordinate System:"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:577
-#, fuzzy
-msgid "Re-projecting GCPs table:"
-#: ../raster/r.in.gdal/main.c:578
-#, c-format
-msgid "* Input projection for GCP table: %s"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:580
-#, c-format
-msgid "* Output projection for GCP table: %s"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:597
-#, fuzzy, c-format
-msgid "Error in pj_do_proj (can't re-projection GCP %i)"
-msgstr "त्रुटि का"
-#: ../raster/r.in.gdal/main.c:666
-#, fuzzy
-msgid "Unable to translate projection key values of input GCPs"
-msgstr "का"
-#: ../raster/r.in.gdal/main.c:682
-#, fuzzy
-msgid "Unable to get projection info of target location"
-msgstr "का"
-#: ../raster/r.in.gdal/main.c:684
-#, fuzzy
-msgid "Unable to get projection units of target location"
-msgstr "का"
-#: ../raster/r.in.gdal/main.c:686
-#, fuzzy
-msgid "Unable to get projection key values of target location"
-msgstr "का"
-#: ../raster/r.in.gdal/main.c:689 ../imagery/i.rectify/target.c:32
-#: ../vector/v.rectify/target.c:37
-#, fuzzy, c-format
-msgid "Mapset <%s> in target location <%s> - "
-#: ../raster/r.in.gdal/main.c:949
-#, fuzzy, c-format
-msgid "Setting grey color table for <%s> (8bit, full range)"
-#: ../raster/r.in.gdal/main.c:962
-#, fuzzy, c-format
-msgid "Setting grey color table for <%s> (16bit, image range)"
-#: ../raster/r.horizon/main.c:180
-msgid "Horizon angle computation from a digital elevation model."
-msgstr ""
-#: ../raster/r.horizon/main.c:182
-msgid "Computes horizon angle height from a digital elevation model. The module has two different modes of operation:  1. Computes the entire horizon around a single point whose coordinates are given with the 'coord' option. The horizon height (in radians). 2. Computes one or more raster maps of the horizon height in a single direction.  The input for this is the angle (in degrees), which is measured  counterclockwise with east=0, north=90 etc. The output is the horizon height in radians."
-msgstr ""
-#: ../raster/r.horizon/main.c:205
-msgid "Direction in which you want to know the horizon height"
-msgstr ""
-#: ../raster/r.horizon/main.c:221
-msgid "For horizon rasters, read from the DEM an extra buffer around the present region"
-msgstr ""
-#: ../raster/r.horizon/main.c:229
-msgid "For horizon rasters, read from the DEM an extra buffer eastward the present region"
-msgstr ""
-#: ../raster/r.horizon/main.c:237
-msgid "For horizon rasters, read from the DEM an extra buffer westward the present region"
-msgstr ""
-#: ../raster/r.horizon/main.c:245
-msgid "For horizon rasters, read from the DEM an extra buffer northward the present region"
-msgstr ""
-#: ../raster/r.horizon/main.c:253
-msgid "For horizon rasters, read from the DEM an extra buffer southward the present region"
-msgstr ""
-#: ../raster/r.horizon/main.c:261
-msgid "The maximum distance to consider when finding the horizon height"
-msgstr ""
-#: ../raster/r.horizon/main.c:270
-#, fuzzy
-msgid "Prefix of the horizon raster output maps"
-msgstr "का"
-#: ../raster/r.horizon/main.c:280
-msgid "Coordinate for which you want to calculate the horizon"
-msgstr ""
-#: ../raster/r.horizon/main.c:295
-#, fuzzy
-msgid "Write output in degrees (default is radians)"
-msgstr "उपसर्ग का छवियाँ"
-#: ../raster/r.horizon/main.c:343
-#, fuzzy
-msgid "Can't read the coordinates from the \"coord\" option."
-msgstr "का"
-#: ../raster/r.horizon/main.c:361
-msgid "You didn't specify a direction value or step size. Aborting."
-msgstr ""
-#: ../raster/r.horizon/main.c:366
-msgid "You didn't specify a horizon raster name. Aborting."
-msgstr ""
-#: ../raster/r.horizon/main.c:376
-#, fuzzy
-msgid "You didn't specify an angle step size. Aborting."
-msgstr "नहीं"
-#: ../raster/r.horizon/main.c:389
-#, fuzzy
-msgid "Could not read bufferzone size. Aborting."
-msgstr "नहीं"
-#: ../raster/r.horizon/main.c:394 ../raster/r.horizon/main.c:400
-#: ../raster/r.horizon/main.c:407 ../raster/r.horizon/main.c:414
-#, fuzzy, c-format
-msgid "Could not read %s bufferzone size. Aborting."
-msgstr "नहीं"
-#: ../raster/r.horizon/main.c:395
-msgid "east"
-msgstr ""
-#: ../raster/r.horizon/main.c:401
-msgid "west"
-msgstr ""
-#: ../raster/r.horizon/main.c:408
-msgid "south"
-msgstr ""
-#: ../raster/r.horizon/main.c:415
-msgid "north"
-msgstr ""
-#: ../raster/r.horizon/main.c:420
-#, fuzzy
-msgid "Could not read maximum distance. Aborting."
-msgstr "नहीं"
-#: ../raster/r.horizon/main.c:471
-#, fuzzy
-msgid "Can't get projection info of current location: please set latitude via 'lat' or 'latin' option!"
-msgstr "का"
-#: ../raster/r.horizon/main.c:786 ../raster/r.horizon/main.c:804
-#: ../imagery/i.latlong/main.c:134 ../ps/ps.map/do_geogrid.c:86
-#: ../ps/ps.map/do_geogrid.c:91 ../ps/ps.map/do_geogrid.c:115
-#: ../ps/ps.map/do_geogrid.c:120 ../ps/ps.map/do_geogrid.c:190
-#: ../ps/ps.map/do_geogrid.c:229 ../ps/ps.map/do_geogrid.c:305
-#: ../ps/ps.map/do_geogrid.c:321 ../ps/ps.map/do_geogrid.c:338
-#: ../ps/ps.map/do_geogrid.c:355 ../ps/ps.map/do_geogrid.c:411
-#: ../ps/ps.map/do_geogrid.c:417 ../ps/ps.map/do_geogrid.c:421
-#: ../ps/ps.map/do_geogrid.c:429 ../ps/ps.map/do_geogrid.c:433
-#: ../display/d.grid/plot.c:196 ../display/d.grid/plot.c:202
-#: ../display/d.grid/plot.c:254 ../display/d.grid/plot.c:260
-#: ../display/d.grid/plot.c:420 ../display/d.grid/plot.c:436
-#: ../display/d.grid/plot.c:453 ../display/d.grid/plot.c:470
-#, fuzzy
-msgid "Error in pj_do_proj"
-msgstr "त्रुटि"
-#: ../raster/r.horizon/main.c:1106
-#, fuzzy, c-format
-msgid "Calculating map %01d of %01d (angle %.2f, raster map <%s>)"
-msgstr "डाटाटाइप."
-#: ../raster/simwe/r.sim.sediment/main.c:113
-msgid "sediment flow"
-msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:115
-#, fuzzy
-msgid "deposition"
-msgstr "नहीं n"
-#: ../raster/simwe/r.sim.sediment/main.c:117
-msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
-msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:124
-#, fuzzy
-msgid "Name of water depth raster map [m]"
-msgstr "का"
-#: ../raster/simwe/r.sim.sediment/main.c:128
-#: ../raster/simwe/r.sim.water/main.c:120
-#, fuzzy
-msgid "Name of x-derivatives raster map [m/m]"
-msgstr "का"
-#: ../raster/simwe/r.sim.sediment/main.c:132
-#: ../raster/simwe/r.sim.water/main.c:124
-#, fuzzy
-msgid "Name of y-derivatives raster map [m/m]"
-msgstr "का"
-#: ../raster/simwe/r.sim.sediment/main.c:137
-#, fuzzy
-msgid "Name of detachment capacity coefficient raster map [s/m]"
-msgstr "का"
-#: ../raster/simwe/r.sim.sediment/main.c:142
-#, fuzzy
-msgid "Name of transport capacity coefficient raster map [s]"
-msgstr "का"
-#: ../raster/simwe/r.sim.sediment/main.c:147
-#, fuzzy
-msgid "Name of critical shear stress raster map [Pa]"
-msgstr "का"
-#: ../raster/simwe/r.sim.sediment/main.c:152
-#: ../raster/simwe/r.sim.water/main.c:161
-#, fuzzy
-msgid "Name of mannings n raster map"
-msgstr "का"
-#: ../raster/simwe/r.sim.sediment/main.c:160
-#, fuzzy
-msgid "Name of mannings n value"
-msgstr "का"
-#: ../raster/simwe/r.sim.sediment/main.c:167
-#: ../raster/simwe/r.sim.water/main.c:215
-#, fuzzy
-msgid "Base name of the output walkers vector points map"
-msgstr "का"
-#: ../raster/simwe/r.sim.sediment/main.c:174
-#: ../raster/simwe/r.sim.water/main.c:183
-#, fuzzy
-msgid "Name of the sampling locations vector points map"
-msgstr "का"
-#: ../raster/simwe/r.sim.sediment/main.c:181
-msgid "Name of the sampling points output text file. For each observation vector point the time series of sediment transport is stored."
-msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:187
-#, fuzzy
-msgid "Name for output transport capacity raster map [kg/ms]"
-msgstr "ढाल"
-#: ../raster/simwe/r.sim.sediment/main.c:194
-#, fuzzy
-msgid "Name for output transp.limited erosion-deposition raster map [kg/m2s]"
-msgstr "फ़ाइलनाम "
-#: ../raster/simwe/r.sim.sediment/main.c:201
-#, fuzzy
-msgid "Name for output sediment concentration raster map [particle/m3]"
-msgstr "ढाल"
-#: ../raster/simwe/r.sim.sediment/main.c:207
-#, fuzzy
-msgid "Name for output sediment flux raster map [kg/ms]"
-msgstr "ढाल"
-#: ../raster/simwe/r.sim.sediment/main.c:214
-#, fuzzy
-msgid "Name for output erosion-deposition raster map [kg/m2s]"
-msgstr "फ़ाइलनाम "
-#: ../raster/simwe/r.sim.sediment/main.c:221
-#, fuzzy
-msgid "Number of walkers"
-msgstr "का"
-#: ../raster/simwe/r.sim.sediment/main.c:229
-#: ../raster/simwe/r.sim.water/main.c:231
-msgid "Time used for iterations [minutes]"
-msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:238
-#: ../raster/simwe/r.sim.water/main.c:240
-msgid "Time interval for creating output maps [minutes]"
-msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:256
-#: ../raster/simwe/r.sim.water/main.c:258
-msgid "Water diffusion constant"
-msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:336
-#: ../raster/simwe/r.sim.water/main.c:432
-msgid "More than 100 files are going to be created !!!!!"
-msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:342
-#: ../raster/simwe/r.sim.water/main.c:438
-#, c-format
-msgid "default nwalk=%d, rwalk=%f"
-msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:351
-#: ../raster/simwe/r.sim.water/main.c:448
-#, c-format
-msgid "Using metric conversion factor %f, step=%f"
-msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:357
-#, fuzzy
-msgid "You are not outputting any raster or site files"
-msgstr "नहीं"
-#: ../raster/simwe/r.sim.sediment/main.c:360
-#: ../raster/simwe/r.sim.water/main.c:455 ../vector/v.surf.rst/main.c:609
-#: ../vector/v.surf.rst/main.c:664
-msgid "Input failed"
-msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:384
-#: ../raster/simwe/r.sim.water/main.c:474
-#, fuzzy
-msgid "Cannot write raster maps"
-msgstr "डाटाटाइप."
-#: ../raster/simwe/r.sim.water/main.c:113
-msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
-msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:130
-#, fuzzy
-msgid "Name of rainfall excess rate (rain-infilt) raster map [mm/hr]"
-msgstr "का"
-#: ../raster/simwe/r.sim.water/main.c:139
-#, fuzzy
-msgid "Rainfall excess rate unique value [mm/hr]"
-msgstr "का"
-#: ../raster/simwe/r.sim.water/main.c:146
-#, fuzzy
-msgid "Name of runoff infiltration rate raster map [mm/hr]"
-msgstr "का"
-#: ../raster/simwe/r.sim.water/main.c:155
-#, fuzzy
-msgid "Runoff infiltration rate unique value [mm/hr]"
-msgstr "का"
-#: ../raster/simwe/r.sim.water/main.c:169
-msgid "Mannings n unique value"
-msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:176
-#, fuzzy
-msgid "Name of flow controls raster map (permeability ratio 0-1)"
-msgstr "का"
-#: ../raster/simwe/r.sim.water/main.c:190
-msgid "Name of the sampling points output text file. For each observation vector point the time series of water depth is stored."
-msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:196
-#, fuzzy
-msgid "Name for output water depth raster map [m]"
-msgstr "का"
-#: ../raster/simwe/r.sim.water/main.c:202
-#, fuzzy
-msgid "Name for output water discharge raster map [m3/s]"
-msgstr "ढाल"
-#: ../raster/simwe/r.sim.water/main.c:208
-#, fuzzy
-msgid "Name for output simulation error raster map [m]"
-msgstr "ढाल"
-#: ../raster/simwe/r.sim.water/main.c:223
-msgid "Number of walkers, default is twice the no. of cells"
-msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:267
-msgid "Threshold water depth [m]"
-msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:268
-msgid "Diffusion increases after this water depth is reached"
-msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:276
-msgid "Diffusion increase constant"
-msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:285
-msgid "Weighting factor for water flow velocity vector"
-msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:290
-msgid "Time-series output"
-msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:452
-#, fuzzy
-msgid "You are not outputting any raster maps"
-msgstr "नहीं"
-#: ../raster/simwe/simlib/hydro.c:205
-#, c-format
-msgid "nwalk (%d) > maxw (%d)!"
-msgstr ""
-#: ../raster/simwe/simlib/hydro.c:400
-#, fuzzy
-msgid "Unable to write raster maps"
-msgstr "का a"
-#: ../raster/simwe/simlib/observation_points.c:59
-#, fuzzy, c-format
-msgid "Unable to read points from map %s"
-msgstr "i n"
-#: ../raster/simwe/simlib/observation_points.c:80
-#, fuzzy, c-format
-msgid "Unable to open observation logfile %s for writing"
-msgstr "के लिए"
-#: ../raster/simwe/simlib/input.c:58
-#, c-format
-msgid "Raster map <%s> not found, and manin_val undefined, choose one to be allowed to process"
-msgstr ""
-#: ../raster/simwe/simlib/input.c:171
-msgid "Zero value in Mannings n"
-msgstr ""
-#: ../raster/simwe/simlib/input.c:222
-msgid "Infiltration exceeds the rainfall rate everywhere! No overland flow."
-msgstr ""
-#: ../raster/simwe/simlib/input.c:246
-#, c-format
-msgid ""
-"Min elevation \t= %.2f m\n"
-"Max elevation \t= %.2f m\n"
-msgstr ""
-#: ../raster/simwe/simlib/input.c:248
-#, c-format
-msgid "Mean Source Rate (rainf. excess or sediment) \t= %f m/s or kg/m2s \n"
-msgstr ""
-#: ../raster/simwe/simlib/input.c:250
-#, c-format
-msgid "Mean flow velocity \t= %f m/s\n"
-msgstr ""
-#: ../raster/simwe/simlib/input.c:251
-#, c-format
-msgid "Mean Mannings \t= %f\n"
-msgstr ""
-#: ../raster/simwe/simlib/input.c:255
-#, fuzzy, c-format
-msgid "Number of iterations \t= %d cells\n"
-msgstr "का"
-#: ../raster/simwe/simlib/input.c:256
-#, c-format
-msgid "Time step \t= %.2f s\n"
-msgstr ""
-#: ../raster/simwe/simlib/input.c:258
-#, c-format
-msgid ""
-"Sigmax \t= %f\n"
-"Max velocity \t= %f m/s\n"
-msgstr ""
-#: ../raster/simwe/simlib/input.c:260
-#, c-format
-msgid "Time step used \t= %.2f s\n"
-msgstr ""
-#: ../raster/simwe/simlib/input.c:312
-#, fuzzy
-msgid "Unable to write et file"
-#: ../raster/simwe/simlib/output.c:304 ../raster/simwe/simlib/output.c:312
-#, fuzzy, c-format
-msgid "FP raster map <%s> not found"
-msgstr "नहीं"
-#: ../raster/r.thin/main.c:59
-#, fuzzy
-msgid "Thins non-zero cells that denote linear features in a raster map layer."
-msgstr "a."
-#: ../raster/r.thin/main.c:71
-#, fuzzy
-msgid "Maximal number of iterations"
-msgstr "संख्या का"
-#: ../raster/r.thin/io.c:96
-#, fuzzy
-msgid "Input raster must be of type CELL."
-msgstr "शीर्षक"
-#: ../raster/r.thin/io.c:101
-#, fuzzy, c-format
-msgid "File %s -- %d rows X %d columns"
-msgstr "पावर."
-#: ../raster/r.thin/io.c:111
-#, fuzzy, c-format
-msgid "%s: Unable to create temporary file <%s> -- errno = %d"
-#: ../raster/r.thin/io.c:120 ../raster/r.thin/io.c:128
-#: ../raster/r.thin/io.c:138
-#, fuzzy, c-format
-msgid "%s: Error writing temporary file"
-msgstr "त्रुटि n"
-#: ../raster/r.thin/io.c:161
-#, fuzzy, c-format
-msgid "Output file %d rows X %d columns"
-msgstr "पावर."
-#: ../raster/r.thin/io.c:162
-#, fuzzy, c-format
-msgid "Window %d rows X %d columns"
-msgstr "पावर."
-#: ../raster/r.thin/thin_lines.c:68
-#, c-format
-msgid "%s: Unable to find bounding box for lines"
-msgstr ""
-#: ../raster/r.thin/thin_lines.c:71
-#, c-format
-msgid "Bounding box:  l = %d, r = %d, t = %d, b = %d"
-msgstr ""
-#: ../raster/r.thin/thin_lines.c:118
-#, fuzzy, c-format
-msgid "Pass number %d"
-msgstr "n"
-#: ../raster/r.thin/thin_lines.c:169
-#, c-format
-msgid "Deleted %d  pixels "
-msgstr ""
-#: ../raster/r.thin/thin_lines.c:173
-msgid "Thinning completed successfully."
-msgstr ""
-#: ../raster/r.thin/thin_lines.c:175
-msgid "Thinning not completed, consider to increase 'iterations' parameter."
-msgstr ""
-#: ../raster/r.covar/main.c:54
-#, fuzzy
-msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
-msgstr "a माट्रिक्स के लिए."
-#: ../raster/r.covar/main.c:61
-#, fuzzy
-msgid "Print correlation matrix"
-msgstr "छापें माट्रिक्स"
-#: ../raster/r.covar/main.c:86
-#, fuzzy, c-format
-msgid "%s: complete ... "
-msgstr "पूर्ण."
-#: ../raster/r.covar/main.c:110 ../imagery/i.pca/main.c:143
-#, fuzzy
-msgid "No non-null values"
-msgstr "ओवरले"
-#: ../raster/r.out.gdal/export_band.c:63
-#: ../raster/r.out.gdal/export_band.c:354
-#, fuzzy
-msgid "Unable to allocate buffer for reading raster map"
-msgstr "के लिए"
-#: ../raster/r.out.gdal/export_band.c:171
-#, c-format
-msgid "Input raster map contains cells with NULL-value (no-data). The value %d will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
-msgstr ""
-#: ../raster/r.out.gdal/export_band.c:176
-#, c-format
-msgid "Input raster map contains cells with NULL-value (no-data). The value %g will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
-msgstr ""
-#: ../raster/r.out.gdal/export_band.c:186
-#, c-format
-msgid "The default nodata value is present in rasterband <%s> and would lead to data loss. Please specify a custom nodata value with the %s parameter."
-msgstr ""
-#: ../raster/r.out.gdal/export_band.c:193
-#, c-format
-msgid "The user given nodata value %g is present in rasterband <%s> and would lead to data loss. Please specify a different nodata value with the %s parameter."
-msgstr ""
-#: ../raster/r.out.gdal/export_band.c:235
-#, fuzzy
-msgid "Unable to get raster band"
-msgstr "का a"
-#: ../raster/r.out.gdal/export_band.c:391
-#: ../raster/r.out.gdal/export_band.c:420
-#: ../raster/r.out.gdal/export_band.c:449
-#, fuzzy
-msgid "Unable to write GDAL raster file"
-#: ../raster/r.out.gdal/export_band.c:468
-#: ../raster/r.out.gdal/export_band.c:480
-#: ../raster/r.out.gdal/export_band.c:493
-#: ../raster/r.out.gdal/export_band.c:506
-#: ../raster/r.out.gdal/export_band.c:518
-#: ../raster/r.out.gdal/export_band.c:531
-#: ../raster/r.out.gdal/export_band.c:545 ../raster/r.out.gdal/main.c:625
-#: ../raster/r.out.gdal/main.c:637 ../raster/r.out.gdal/main.c:650
-#: ../raster/r.out.gdal/main.c:663 ../raster/r.out.gdal/main.c:675
-#: ../raster/r.out.gdal/main.c:688
-msgid "Selected GDAL datatype does not cover data range."
-msgstr ""
-#: ../raster/r.out.gdal/export_band.c:469
-#: ../raster/r.out.gdal/export_band.c:481
-#: ../raster/r.out.gdal/export_band.c:494
-#: ../raster/r.out.gdal/export_band.c:507 ../raster/r.out.gdal/main.c:626
-#: ../raster/r.out.gdal/main.c:638 ../raster/r.out.gdal/main.c:651
-#: ../raster/r.out.gdal/main.c:664
-#, c-format
-msgid "GDAL datatype: %s, range: %d - %d"
-msgstr ""
-#: ../raster/r.out.gdal/export_band.c:472
-#: ../raster/r.out.gdal/export_band.c:484
-#: ../raster/r.out.gdal/export_band.c:497
-#: ../raster/r.out.gdal/export_band.c:510
-#: ../raster/r.out.gdal/export_band.c:522
-#: ../raster/r.out.gdal/export_band.c:535
-#: ../raster/r.out.gdal/export_band.c:549
-#, fuzzy, c-format
-msgid "Raster map <%s> range: %g - %g"
-msgstr "नहीं"
-#: ../raster/r.out.gdal/export_band.c:519 ../raster/r.out.gdal/main.c:676
-#, c-format
-msgid "GDAL datatype: %s, range: %u - %u"
-msgstr ""
-#: ../raster/r.out.gdal/export_band.c:532
-#: ../raster/r.out.gdal/export_band.c:546 ../raster/r.out.gdal/main.c:689
-#, c-format
-msgid "GDAL datatype: %s, range: %g - %g"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:50
-#, c-format
-msgid "Supported formats:\n"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:128
-#, fuzzy
-msgid "Exports GRASS raster maps into GDAL supported formats."
-msgstr "a a."
-#: ../raster/r.out.gdal/main.c:134
-msgid "List supported output formats"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:140
-#, fuzzy
-msgid "Do not write GDAL standard colortable"
-msgstr "रखें"
-#: ../raster/r.out.gdal/main.c:141
-msgid "Only applicable to Byte or UInt16 data types."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:142 ../raster/r.out.gdal/main.c:184
-#: ../raster/r.out.gdal/main.c:195 ../raster/r.out.gdal/main.c:206
-#: ../raster/r.out.gdal/main.c:215 ../vector/v.out.ogr/args.c:40
-#: ../vector/v.out.ogr/args.c:59 ../vector/v.out.ogr/args.c:69
-#: ../vector/v.out.ogr/args.c:83 ../vector/v.out.ogr/args.c:96
-#: ../vector/v.out.ogr/args.c:102 ../vector/v.out.ogr/args.c:107
-#: ../vector/v.out.ogr/args.c:114
-#, fuzzy
-msgid "Creation"
-msgstr "का"
-#: ../raster/r.out.gdal/main.c:146
-msgid "Force raster export despite any warnings of data loss"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:147
-msgid "Overrides nodata safety check."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:150
-#, fuzzy
-msgid "Name of raster map (or group) to export"
-#: ../raster/r.out.gdal/main.c:153
-#, fuzzy
-msgid "Name for output raster file"
-msgstr "का"
-#: ../raster/r.out.gdal/main.c:159
-msgid "Raster data format to write (case sensitive, see also -l flag)"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:180
-#, fuzzy
-msgid "Data type"
-msgstr "विशेषता"
-#: ../raster/r.out.gdal/main.c:190
-msgid "Creation option(s) to pass to the output format driver"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:192
-msgid "In the form of \"NAME=VALUE\", separate multiple entries with a comma."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:200
-msgid "Metadata key(s) and value(s) to include"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:202
-msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. Not supported by all output format drivers."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:212
-msgid "Assign a specified nodata value to output bands"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:242
-#, fuzzy, c-format
-msgid "Raster map or group <%s> not found"
-msgstr "नहीं"
-#: ../raster/r.out.gdal/main.c:246
-#, fuzzy, c-format
-msgid "No raster maps in group <%s>"
-msgstr "समूह."
-#: ../raster/r.out.gdal/main.c:260
-#, fuzzy, c-format
-msgid "Unable to get <%s> driver"
-msgstr "सेट आकार "
-#: ../raster/r.out.gdal/main.c:266
-#, c-format
-msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:271
-#, fuzzy
-msgid "Unable to get in-memory raster driver"
-msgstr "के लिए"
-#: ../raster/r.out.gdal/main.c:275
-#, c-format
-msgid "Driver <%s> does not support creating rasters"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:351
-#, fuzzy, c-format
-msgid "Could not read data range of raster <%s>"
-msgstr "डाटाटाइप."
-#: ../raster/r.out.gdal/main.c:408
-#, c-format
-msgid "Exporting to GDAL data type: %s"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:423
-msgid "Raster export would result in complete data loss, aborting."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:434
-#, c-format
-msgid "Precision loss: Raster map <%s> of type %s to be exported as %s. This can be avoided by using %s."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:445
-#, c-format
-msgid "Precision loss: The range of <%s> can not be accurately preserved with GDAL datatype Float32. This can be avoided by exporting to Int32 or Float64."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:453
-#, c-format
-msgid "Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. This can be avoided by using Float64"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:462 ../raster/r.out.gdal/main.c:505
-msgid "Forcing raster export."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:464 ../raster/r.out.gdal/main.c:478
-#: ../raster/r.out.gdal/main.c:507 ../raster/r.out.gdal/main.c:511
-#, fuzzy
-msgid "Raster export aborted."
-msgstr "नहीं"
-#: ../raster/r.out.gdal/main.c:488
-msgid "Checking GDAL data type and nodata value..."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:491
-#, c-format
-msgid "Checking options for raster map <%s> (band %d)..."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:536
-#, fuzzy
-msgid "Unable to create dataset using memory raster driver"
-msgstr "के लिए"
-#: ../raster/r.out.gdal/main.c:545
-#, fuzzy, c-format
-msgid "Unable to create <%s> dataset using <%s> driver"
-msgstr "i n"
-#: ../raster/r.out.gdal/main.c:560
-#, fuzzy
-msgid "Unable to set geo transform"
-msgstr "सेट"
-#: ../raster/r.out.gdal/main.c:568
-#, fuzzy
-msgid "Unable to set projection"
-msgstr "फ़ाइल"
-#: ../raster/r.out.gdal/main.c:574
-#, fuzzy, c-format
-msgid "Exporting raster data to %s format..."
-msgstr "i n"
-#: ../raster/r.out.gdal/main.c:577
-#, fuzzy, c-format
-msgid "Exporting raster map <%s> (band %d)..."
-msgstr "i n"
-#: ../raster/r.out.gdal/main.c:590
-#, fuzzy, c-format
-msgid "Unable to export raster map <%s>"
-msgstr "के लिए."
-#: ../raster/r.out.gdal/main.c:602
-#, fuzzy, c-format
-msgid "Unable to create raster map <%s> using driver <%s>"
-msgstr "के लिए."
-#: ../raster/r.out.gdal/main.c:629 ../raster/r.out.gdal/main.c:641
-#: ../raster/r.out.gdal/main.c:654 ../raster/r.out.gdal/main.c:667
-#: ../raster/r.out.gdal/main.c:679 ../raster/r.out.gdal/main.c:692
-#, fuzzy, c-format
-msgid "Range to be exported: %g - %g"
-msgstr "फ़ाइल"
-#: ../raster/r.out.gdal/main.c:716 ../raster/r.out.gdal/main.c:729
-#: ../raster/r.out.gdal/main.c:743 ../raster/r.out.gdal/main.c:756
-#: ../raster/r.out.gdal/main.c:771
-#, c-format
-msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %d by selected GDAL datatype."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:719 ../raster/r.out.gdal/main.c:746
-#: ../raster/r.out.gdal/main.c:774
-#, c-format
-msgid "GDAL datatype: %s, valid range: %d - %d"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:732 ../raster/r.out.gdal/main.c:759
-#, c-format
-msgid "GDAL datatype: %s, valid range: %u - %u"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:785
-#, c-format
-msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %g by selected GDAL datatype."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:788
-#, c-format
-msgid "GDAL datatype: %s, valid range: %g - %g"
-msgstr ""
-#: ../raster/r.lake/main.c:152
-msgid "Fills lake at given point to given level."
-msgstr ""
-#: ../raster/r.lake/main.c:158
-msgid "Water level"
-msgstr ""
-#: ../raster/r.lake/main.c:168
-#, fuzzy
-msgid "Seed point coordinates"
-msgstr "ज़ेड"
-#: ../raster/r.lake/main.c:177
-#, fuzzy
-msgid "Name of input raster map with given starting point(s) (at least 1 cell > 0)"
-msgstr "का"
-#: ../raster/r.lake/main.c:183
-#, fuzzy
-msgid "Use negative depth values for lake raster map"
-msgstr "छवियाँ a"
-#: ../raster/r.lake/main.c:188
-msgid "Overwrite seed map with result (lake) map"
-msgstr ""
-#: ../raster/r.lake/main.c:194
-#, fuzzy
-msgid "Both seed map and coordinates cannot be specified"
-msgstr "पूर्व!"
-#: ../raster/r.lake/main.c:197
-#, fuzzy
-msgid "Seed map or seed coordinates must be set!"
-msgstr "एक का सेट"
-#: ../raster/r.lake/main.c:200
-msgid "Seed coordinates and output map lake= must be set!"
-msgstr ""
-#: ../raster/r.lake/main.c:203
-#, fuzzy
-msgid "Both lake and overwrite cannot be specified"
-msgstr "पूर्व!"
-#: ../raster/r.lake/main.c:206
-msgid "Output lake map or overwrite flag must be set!"
-msgstr ""
-#: ../raster/r.lake/main.c:233
-#, fuzzy
-msgid "Seed point outside the current region"
-msgstr "नहीं"
-#: ../raster/r.lake/main.c:247
-#, fuzzy
-msgid "G_malloc: out of memory"
-msgstr "का."
-#: ../raster/r.lake/main.c:269
-msgid "Given water level at seed point is below earth surface. Increase water level or move seed point."
-msgstr ""
-#: ../raster/r.lake/main.c:348
-#, c-format
-msgid "Lake depth from %f to %f"
-msgstr ""
-#: ../raster/r.lake/main.c:349
-#, c-format
-msgid "Lake area %f square meters"
-msgstr ""
-#: ../raster/r.lake/main.c:350
-#, c-format
-msgid "Lake volume %f cubic meters"
-msgstr ""
-#: ../raster/r.lake/main.c:351
-msgid "Volume is correct only if lake depth (terrain raster map) is in meters"
-msgstr ""
-#: ../raster/r.surf.gauss/main.c:42
-#, fuzzy
-msgid "GRASS module to produce a raster map layer of gaussian deviates whose mean and standard deviation can be expressed by the user. It uses a gaussian random number generator."
-msgstr "मॉडयूल a का किसका a संख्या."
-#: ../raster/r.surf.gauss/main.c:48
-#, fuzzy
-msgid "Name of the output random surface"
-msgstr "का"
-#: ../raster/r.surf.gauss/main.c:52
-#, fuzzy
-msgid "Distribution mean"
-msgstr "वितरण"
-#: ../raster/r.surf.gauss/main.c:58
-#, fuzzy
-msgid "Standard deviation"
-msgstr "मानक विचलन"
-#: ../raster/r.in.poly/get_item.c:76
-#, fuzzy, c-format
-msgid "Illegal coordinate <%s, %s>, skipping."
-msgstr "पूर्व"
-#: ../raster/r.in.poly/get_item.c:81
-#, fuzzy, c-format
-msgid "Illegal north coordinate <%s>, skipping."
-msgstr "उत्तर"
-#: ../raster/r.in.poly/get_item.c:86
-#, fuzzy, c-format
-msgid "Illegal east coordinate <%s>, skipping."
-msgstr "पूर्व"
-#: ../raster/r.in.poly/main.c:32
-#, fuzzy
-msgid "Creates raster maps from ASCII polygon/line/point data files."
-msgstr "बहुभुज."
-#: ../raster/r.in.poly/main.c:36
-#, fuzzy
-msgid "Name of input file; or \"-\" to read from stdin"
-msgstr "उत्तर पूर्व"
-#: ../raster/r.in.poly/main.c:51 ../vector/v.to.rast/main.c:102
-#, fuzzy
-msgid "Number of rows to hold in memory"
-msgstr "का"
-#: ../raster/r.in.poly/main.c:60
-#, fuzzy
-msgid "Minimum number of rows to hold in memory is 1"
-msgstr "संख्या का"
-#: ../raster/r.in.ascii/main.c:73
-#, fuzzy
-msgid "Converts a GRASS ASCII raster file to binary raster map."
-msgstr "पाठ a."
-#: ../raster/r.in.ascii/main.c:77
-#, fuzzy
-msgid "ASCII raster file to be imported. If not given reads from standard input"
-msgstr "नहीं"
-#: ../raster/r.in.ascii/main.c:103
-msgid "String representing NULL value data cell"
-msgstr ""
-#: ../raster/r.in.ascii/main.c:107
-#, fuzzy
-msgid "Integer values are imported"
-msgstr "बिन्दु"
-#: ../raster/r.in.ascii/main.c:111
-#, fuzzy
-msgid "Floating point values are imported"
-msgstr "बिन्दु"
-#: ../raster/r.in.ascii/main.c:115
-#, fuzzy
-msgid "Double floating point values are imported"
-msgstr "बिन्दु"
-#: ../raster/r.in.ascii/main.c:120
-msgid "SURFER (Golden Software) ASCII file will be imported"
-msgstr ""
-#: ../raster/r.in.ascii/main.c:138
-#, c-format
-msgid "Wrong entry for multiplier: %s"
-msgstr ""
-#: ../raster/r.in.ascii/main.c:161
-#, fuzzy
-msgid "Unable to read input from stdin"
-msgstr "i n"
-#: ../raster/r.in.ascii/main.c:168
-#, fuzzy, c-format
-msgid "Unable to read input from <%s>"
-msgstr "i n"
-#: ../raster/r.in.ascii/main.c:283
-#, fuzzy
-msgid "Unable to write to file"
-#: ../raster/r.in.ascii/gethead.c:35
-msgid "input file is not a Surfer ascii grid file"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:41
-msgid "error reading the column and row dimension from the Surfer grid file"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:47
-msgid "error reading the X range from the Surfer grid file"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:53
-msgid "error reading the Y range from the Surfer grid file"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:59
-msgid "error reading the Z range from the Surfer grid file"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:105
-#, fuzzy
-msgid "error getting file position"
-msgstr "त्रुटि"
-#: ../raster/r.in.ascii/gethead.c:164
-msgid "illegal type field: using type int"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:169
-msgid "ignoring type filed in header, type is set on command line"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:176
-msgid "illegal multiplier field: using 1.0"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:181
-msgid "ignoring multiplier filed in header, multiplier is set on command line"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:189
-msgid "ignoring null filed in header, null string is set on command line"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:218
-#, fuzzy
-msgid "error in ascii data format"
-msgstr "त्रुटि."
-#: ../raster/r.in.ascii/gethead.c:253
-#, c-format
-msgid "Illegal \"%s\" value in header: %s"
-msgstr ""
-#: ../raster/r.what.color/main.c:91
-#, fuzzy
-msgid "Queries colors for a raster map layer."
-msgstr "के लिए."
-#: ../raster/r.what.color/main.c:99
-#, fuzzy
-msgid "Name of existing raster map to query colors"
-msgstr "का"
-#: ../raster/r.what.color/main.c:106
-#, fuzzy
-msgid "Values to query colors for"
-msgstr "के लिए"
-#: ../raster/r.what.color/main.c:113
-#, fuzzy
-msgid "Output format (printf-style)"
-msgstr "शीर्षक"
-#: ../raster/r.what.color/main.c:117
-#, fuzzy
-msgid "Read values from stdin"
-msgstr "का"
-#: ../raster/r.what.color/main.c:123
-#, fuzzy
-msgid "Either \"-i\" or \"value=\" must be given"
-msgstr "पाठ"
-#: ../raster/r.out.vrml/main.c:49
-msgid "VRML"
-msgstr ""
-#: ../raster/r.out.vrml/main.c:51
-msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
-msgstr ""
-#: ../raster/r.out.vrml/main.c:58
-#, fuzzy
-msgid "Name of elevation map"
-msgstr "का"
-#: ../raster/r.out.vrml/main.c:65
-#, fuzzy
-msgid "Name of color file"
-msgstr "का"
-#: ../raster/r.out.vrml/main.c:79
-#, fuzzy
-msgid "Name for new VRML file"
-msgstr "का."
-#: ../raster/r.out.vrml/main.c:98
-#, fuzzy, c-format
-msgid "Range info for [%s] not available (run r.support)"
-msgstr "सीमा के लिए नहीं"
-#: ../raster/r.out.vrml/main.c:107
-#, fuzzy, c-format
-msgid "Range info for <%s> not available (run r.support)"
-#: ../raster/r.out.vrml/main.c:139
-#, c-format
-msgid "Opening %s for writing... "
-msgstr ""
-#: ../raster/r.out.vrml/put_grid.c:38
-#, fuzzy
-msgid "Writing vertices..."
-msgstr "छापें"
-#: ../raster/r.out.vrml/put_grid.c:83
-#, fuzzy
-msgid "Writing color file..."
-msgstr "n"
-#: ../raster/r.surf.fractal/process.c:54
-#, fuzzy
-msgid "Unable to allocate data buffer. Check current region with g.region."
-msgstr "के लिए"
-#: ../raster/r.surf.fractal/main.c:40
-msgid "fractal"
-msgstr ""
-#: ../raster/r.surf.fractal/main.c:42
-msgid "Creates a fractal surface of a given fractal dimension."
-msgstr ""
-#: ../raster/r.surf.fractal/main.c:48
-#, fuzzy
-msgid "Fractal dimension of surface (2 < D < 3)"
-msgstr "का"
-#: ../raster/r.surf.fractal/main.c:55
-#, fuzzy
-msgid "Number of intermediate images to produce"
-msgstr "का छवियाँ"
-#: ../raster/r.surf.fractal/main.c:79
-#, fuzzy, c-format
-msgid "Fractal dimension of %.2lf must be between 2 and 3."
-msgstr "का"
-#: ../raster/r.surf.fractal/spec_syn.c:61
-msgid "Preliminary surface calculations..."
-msgstr ""
-#: ../raster/r.surf.fractal/spec_syn.c:120
-#, fuzzy, c-format
-msgid "Calculating surface %d (of %d)..."
-msgstr "n"
-#: ../raster/r.out.gridatb/main.c:70
-#, fuzzy
-msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)."
-msgstr "a a."
-#: ../raster/r.resamp.filter/main.c:142
-#, fuzzy, c-format
-msgid "Filter <%s> not found"
-msgstr "नहीं"
-#: ../raster/r.resamp.filter/main.c:387
-#, fuzzy
-msgid "Resamples raster map layers using an analytic kernel."
-msgstr "a."
-#: ../raster/r.resamp.filter/main.c:398
-msgid "Filter kernel(s)"
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:406
-msgid "Filter radius"
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:413
-msgid "Filter radius (horizontal)"
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:420
-msgid "Filter radius (vertical)"
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:431
-msgid "radius= and x_radius=/y_radius= are mutually exclusive"
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:435
-msgid "Either radius= or x_radius=/y_radius= required"
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:437
-msgid "Both x_radius= and y_radius= required"
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:459
-msgid "Differing number of values for filter= and [xy_]radius="
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:462
-#, fuzzy, c-format
-msgid "Too many filters (max: %d)"
-msgstr "है"
-#: ../raster/r.resamp.filter/main.c:480
-#, fuzzy
-msgid "At least one filter must be finite"
-msgstr "थीटा"
-#: ../raster/r.to.rast3elev/main.c:99
-#, fuzzy
-msgid "The number of input and elevation maps is not equal"
-msgstr "का"
-#: ../raster/r.to.rast3elev/main.c:165
-msgid "The value to fill the upper cells, default is null"
-msgstr ""
-#: ../raster/r.to.rast3elev/main.c:172
-msgid "The value to fill the lower cells, default is null"
-msgstr ""
-#: ../raster/r.to.rast3elev/main.c:185
-msgid "Use the input map values to fill the upper cells"
-msgstr ""
-#: ../raster/r.to.rast3elev/main.c:190
-msgid "Use the input map values to fill the lower cells"
-msgstr ""
-#: ../raster/r.to.rast3elev/main.c:194
-msgid "Use RASTER3D mask (if exists) with input map"
-msgstr ""
-#: ../raster/r.to.rast3elev/main.c:287 ../raster/r.to.rast3elev/main.c:320
-#, fuzzy
-msgid "Error writing RASTER3D double data"
-msgstr "त्रुटि."
-#: ../raster/r.to.rast3elev/main.c:366
-msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
-msgstr ""
-#: ../raster/r.to.rast3elev/main.c:400
-#, fuzzy
-msgid "The upper value is not valid"
-msgstr "के लिए नहीं"
-#: ../raster/r.to.rast3elev/main.c:410
-#, fuzzy
-msgid "The lower value is not valid"
-#: ../raster/r.mapcalc/map.c:207 ../raster/r.mapcalc/map3.c:179
-#, fuzzy, c-format
-msgid "Unable to read color file for raster map <%s@%s>"
-msgstr "के लिए."
-#: ../raster/r.mapcalc/map.c:220 ../raster/r.mapcalc/map3.c:192
-#, fuzzy, c-format
-msgid "Unable to create btree for raster map <%s@%s>"
-msgstr "के लिए."
-#: ../raster/r.mapcalc/map.c:269 ../raster/r.mapcalc/map.c:481
-#: ../raster/r.mapcalc/map.c:525 ../raster/r.mapcalc/map.c:621
-#: ../raster/r.mapcalc/map3.c:237 ../raster/r.mapcalc/map3.c:420
-#: ../raster/r.mapcalc/map3.c:464 ../raster/r.mapcalc/map3.c:555
-#: ../raster/r.mapcalc/expression.c:353
-#, fuzzy, c-format
-msgid "Invalid map modifier: '%c'"
-msgstr "संख्या का"
-#: ../raster/r.mapcalc/map.c:412 ../raster/r.mapcalc/evaluate.c:94
-#: ../raster/r.mapcalc/evaluate.c:234 ../raster/r.mapcalc/map3.c:351
-#, fuzzy, c-format
-msgid "Unknown type: %d"
-#: ../raster/r.mapcalc/evaluate.c:140
-#, fuzzy, c-format
-msgid "Invalid type: %d"
-msgstr "अवैध"
-#: ../raster/r.mapcalc/evaluate.c:179
-#, c-format
-msgid "Too few arguments for function '%s'"
-msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:183
-#, fuzzy, c-format
-msgid "Too many arguments for function '%s'"
-msgstr "के लिए<reference>"
-#: ../raster/r.mapcalc/evaluate.c:187
-#, fuzzy, c-format
-msgid "Invalid argument type for function '%s'"
-msgstr "के लिए"
-#: ../raster/r.mapcalc/evaluate.c:191
-#, fuzzy, c-format
-msgid "Invalid return type for function '%s'"
-msgstr "के लिए"
-#: ../raster/r.mapcalc/evaluate.c:195
-#, fuzzy, c-format
-msgid "Unknown type for function '%s'"
-#: ../raster/r.mapcalc/evaluate.c:198
-#, fuzzy, c-format
-msgid "Number of arguments for function '%s'"
-msgstr "का"
-#: ../raster/r.mapcalc/evaluate.c:202
-#, fuzzy, c-format
-msgid "Unknown error for function '%s'"
-#: ../raster/r.mapcalc/evaluate.c:303
-#, fuzzy, c-format
-msgid "output map <%s> exists"
-msgstr "नहीं"
-#: ../raster/r.mapcalc/map3.c:370
-#, fuzzy, c-format
-msgid "Unable to close raster map <%s@%s>"
-msgstr "के लिए."
-#: ../raster/r.mapcalc/map3.c:586 ../imagery/i.landsat.acca/algorithm.c:234
-#: ../imagery/i.landsat.acca/algorithm.c:388
-#: ../imagery/i.landsat.acca/tools.c:136 ../imagery/i.landsat.toar/main.c:501
-#, fuzzy, c-format
-msgid "Unable to create raster map <%s>"
-msgstr "के लिए."
-#: ../raster/r.mapcalc/map3.c:611
-#, fuzzy
-msgid "Unable to close output raster map"
-msgstr "का"
-#: ../raster/r.mapcalc/main.c:113
-#, fuzzy
-msgid "Raster map calculator."
-msgstr "माट्रिक्स फ़िल्टर."
-#: ../raster/r.mapcalc/main.c:120
-msgid "Expression to evaluate"
-msgstr ""
-#: ../raster/r.mapcalc/main.c:121 ../raster/r.mapcalc/main.c:127
-#, fuzzy
-msgid "Expression"
-msgstr "पाठ रंग"
-#: ../raster/r.mapcalc/main.c:126
-#, fuzzy
-msgid "File containing expression(s) to evaluate"
-msgstr "फ़ाइल"
-#: ../raster/r.mapcalc/main.c:145
-msgid "file= and expression= are mutually exclusive"
-msgstr ""
-#: ../raster/r.mapcalc/main.c:155
-#, fuzzy
-msgid "parse error"
-msgstr "n"
-#: ../raster/r.mapcalc/main.c:164
-msgid "Floating point error(s) occured in the calculation"
-msgstr ""
-#: ../raster/r.mapcalc/main.c:169
-msgid "Overflow occured in the calculation"
-msgstr ""
-#: ../raster/r.mapcalc/expression.c:202
-#, c-format
-msgid "Undefined variable '%s'"
-msgstr ""
-#: ../raster/r.mapcalc/expression.c:217
-#, fuzzy, c-format
-msgid "Invalid map <%s>"
-msgstr "अवैध"
-#: ../raster/r.mapcalc/expression.c:258
-#, fuzzy, c-format
-msgid "Undefined function '%s'"
-#: ../raster/r.mapcalc/expression.c:263
-#, c-format
-msgid "Too few arguments (%d) to function %s()"
-msgstr ""
-#: ../raster/r.mapcalc/expression.c:267
-#, c-format
-msgid "Too many arguments (%d) to function %s()"
-msgstr ""
-#: ../raster/r.mapcalc/expression.c:271
-#, fuzzy, c-format
-msgid "Incorrect argument types to function %s()"
-msgstr "फ़ाइल"
-#: ../raster/r.mapcalc/expression.c:274
-#, c-format
-msgid "Internal error for function %s()"
-msgstr ""
-#: ../raster/r.mapcalc/expression.c:444
-#, c-format
-msgid "Illegal number of arguments (%d) for operator '%s'"
-msgstr ""
-#: ../raster/r.mapcalc/expression.c:484
-#, c-format
-msgid "Format_expression_prec: unknown type: %d"
-msgstr ""
-#: ../raster/r.mapcalc/function.c:94
-#, c-format
-msgid "Known functions:"
-msgstr ""
-#: ../raster/r.flow/precomp.c:48
-#, fuzzy
-msgid "Precomputing: e/w distances"
-msgstr "नक्शे के लिए"
-#: ../raster/r.flow/precomp.c:50
-msgid "Precomputing: quantization tolerances"
-msgstr ""
-#: ../raster/r.flow/precomp.c:53
-msgid "Precomputing: inverted elevations"
-msgstr ""
-#: ../raster/r.flow/precomp.c:57
-msgid "Precomputing: interpolated border elevations"
-msgstr ""
-#: ../raster/r.flow/precomp.c:63
-msgid "Precomputing: re-oriented aspects"
-msgstr ""
-#: ../raster/r.flow/precomp.c:67
-#, fuzzy
-msgid "Precomputing: aspects"
-#: ../raster/r.flow/precomp.c:111
-#, c-format
-msgid ""
-"Resolution too unbalanced:\n"
-"atan2(%f deg, %f deg) =%f < %f tolerance\n"
-"please resample input map"
-msgstr ""
-#: ../raster/r.flow/precomp.c:116
-#, c-format
-msgid "Resolution too unbalanced (%f x %f); please resample input map"
-msgstr ""
-#: ../raster/r.flow/main.c:316
-#, fuzzy
-msgid "Calculating maps ..."
-msgstr "n"
-#: ../raster/r.flow/main.c:423
-#, fuzzy
-msgid "Constructs flowlines."
-msgstr "गणना करें"
-#: ../raster/r.flow/main.c:425
-#, fuzzy
-msgid "Computes flowlines, flowpath lengths, and flowaccumulation (contributing areas) from a elevation raster map."
-msgstr "का ढाल a."
-#: ../raster/r.flow/main.c:434
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:5
-#, fuzzy
-msgid "Name of input aspect raster map"
-msgstr "का"
-#: ../raster/r.flow/main.c:439
-#, fuzzy
-msgid "Name of input barrier raster map"
-msgstr "का"
-#: ../raster/r.flow/main.c:445
-#, fuzzy
-msgid "Number of cells between flowlines"
-msgstr "का"
-#: ../raster/r.flow/main.c:451
-#, fuzzy
-msgid "Maximum number of segments per flowline"
-msgstr "संख्या का"
-#: ../raster/r.flow/main.c:456
-#, fuzzy
-msgid "Name for output flowline vector map"
-msgstr "का"
-#: ../raster/r.flow/main.c:461
-#, fuzzy
-msgid "Name for output flowpath length raster map"
-msgstr "ढाल"
-#: ../raster/r.flow/main.c:466
-#, fuzzy
-msgid "Name for output flowaccumulation raster map"
-msgstr "का"
-#: ../raster/r.flow/main.c:471
-msgid "Compute upslope flowlines instead of default downhill flowlines"
-msgstr ""
-#: ../raster/r.flow/main.c:475
-#, fuzzy
-msgid "3D lengths instead of 2D"
-msgstr "का"
-#: ../raster/r.flow/main.c:479
-#, fuzzy
-msgid "Use less memory, at a performance penalty"
-msgstr "कम पर a"
-#: ../raster/r.flow/main.c:534
-msgid "You must select one or more output maps (flout, lgout, dsout)"
-msgstr ""
-#: ../raster/r.flow/main.c:550
-#, fuzzy
-msgid "lat/long projection not supported by r.flow. Please use 'r.watershed' for calculating flow accumulation."
-msgstr "नहीं के लिए."
-#: ../raster/r.flow/io.c:85
-#, fuzzy
-msgid "Reading input files: elevation"
-msgstr "n"
-#: ../raster/r.flow/io.c:89
-msgid "Elevation file's resolution differs from current region resolution"
-msgstr ""
-#: ../raster/r.flow/io.c:101
-#, fuzzy
-msgid "Reading input files: aspect"
-msgstr "n"
-#: ../raster/r.flow/io.c:104
-msgid "Resolution of aspect file differs from current region resolution"
-msgstr ""
-#: ../raster/r.flow/io.c:118
-#, fuzzy
-msgid "Reading input files: barrier"
-msgstr "n"
-#: ../raster/r.flow/io.c:146
-#, fuzzy, c-format
-msgid "Cannot create segment file %s"
-msgstr "फ़ाइल"
-#: ../raster/r.flow/io.c:151
-#, fuzzy, c-format
-msgid "Cannot format segment file %s"
-msgstr "फ़ाइल"
-#: ../raster/r.flow/io.c:157
-#, fuzzy, c-format
-msgid "Cannot open segment file %s"
-msgstr "फ़ाइल"
-#: ../raster/r.flow/io.c:204
-#, fuzzy
-msgid "Writing density file"
-msgstr "n"
-#: ../raster/r.flow/io.c:237
-#, fuzzy, c-format
-msgid "Unable to find file %s"
-msgstr "का"
-#: ../raster/r.flow/mem.c:40
-#, fuzzy, c-format
-msgid "Unable to write segment file for %s"
-msgstr "बनाया जा रहा है."
-#: ../imagery/i.evapo.pt/main.c:66 ../imagery/i.points/main.c:96
-#: ../imagery/i.latlong/main.c:56 ../imagery/i.zc/main.c:52
-#: ../imagery/i.smap/main.c:38 ../imagery/i.eb.eta/main.c:43
-#: ../imagery/i.vi/main.c:83 ../imagery/i.landsat.acca/main.c:105
-#: ../imagery/i.maxlik/main.c:61 ../imagery/i.eb.h_SEBAL01/main.c:83
-#: ../imagery/i.landsat.toar/main.c:67 ../imagery/i.class/main.c:91
-#: ../imagery/i.group/main.c:52 ../imagery/i.aster.toar/main.c:97
-#: ../imagery/i.gensig/main.c:39 ../imagery/i.his.rgb/main.c:46
-#: ../imagery/i.evapo.mh/main.c:69 ../imagery/i.rectify/main.c:94
-#: ../imagery/i.target/main.c:45 ../imagery/i.vpoints/main.c:94
-#: ../imagery/i.albedo/main.c:88 ../imagery/i.ifft/main.c:77
-#: ../imagery/i.fft/main.c:78 ../imagery/i.gensigset/main.c:40
-#: ../imagery/i.cca/main.c:84 ../imagery/i.cluster/main.c:75
-#: ../imagery/i.biomass/main.c:50 ../imagery/i.eb.netrad/main.c:56
-#: ../imagery/i.eb.evapfr/main.c:47 ../imagery/i.evapo.time/main.c:77
-#: ../imagery/i.pca/main.c:67 ../imagery/i.rgb.his/main.c:46
-#: ../imagery/i.evapo.pm/main.c:58 ../imagery/i.eb.soilheatflux/main.c:49
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:2
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:3
-#: ../locale/scriptstrings/i.spectral_to_translate.c:2
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:3
-#: ../locale/scriptstrings/i.oif_to_translate.c:3
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:3
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:2
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:2
-#, fuzzy
-msgid "imagery"
-msgstr "समूह"
-#: ../imagery/i.evapo.pt/main.c:67 ../imagery/i.evapo.mh/main.c:70
-#: ../imagery/i.evapo.time/main.c:78 ../imagery/i.evapo.pm/main.c:59
-#, fuzzy
-msgid "evapotranspiration"
-msgstr "का"
-#: ../imagery/i.evapo.pt/main.c:69
-msgid "Computes evapotranspiration calculation Prestley and Taylor formulation, 1972."
-msgstr ""
-#: ../imagery/i.evapo.pt/main.c:75
-#, fuzzy
-msgid "Name of input net radiation raster map [W/m2]"
-msgstr "का"
-#: ../imagery/i.evapo.pt/main.c:79
-#, fuzzy
-msgid "Name of input soil heat flux raster map [W/m2]"
-msgstr "का"
-#: ../imagery/i.evapo.pt/main.c:83
-#, fuzzy
-msgid "Name of input air temperature raster map [K]"
-msgstr "का"
-#: ../imagery/i.evapo.pt/main.c:87
-#, fuzzy
-msgid "Name of input atmospheric pressure raster map [millibars]"
-msgstr "का"
-#: ../imagery/i.evapo.pt/main.c:93
-msgid "Prestley-Taylor coefficient"
-msgstr ""
-#: ../imagery/i.evapo.pt/main.c:97
-#, fuzzy
-msgid "Name of output evapotranspiration raster map [mm/d]"
-msgstr "का"
-#: ../imagery/i.evapo.pt/main.c:102 ../imagery/i.evapo.mh/main.c:105
-msgid "Set negative ETa to zero"
-msgstr ""
-#: ../imagery/i.points/main.c:99
-#, fuzzy
-msgid "Mark ground control points on image to be rectified."
-msgstr "चिह्नित चालू छवि."
-#: ../imagery/i.points/main.c:106 ../imagery/i.vpoints/main.c:105
-#, fuzzy
-msgid "Name of imagery group to be registered"
-msgstr "का समूह"
-#: ../imagery/i.points/main.c:124 ../imagery/i.class/main.c:129
-#: ../display/d.what.vect/main.c:145 ../display/d.what.rast/main.c:98
-#: ../display/d.zoom/main.c:218 ../display/d.zoom/redraw.c:38
-#: ../display/d.extract/main.c:79 ../display/d.measure/main.c:85
-#: ../vector/v.label/main.c:233
-#, fuzzy
-msgid "No graphics device selected"
-msgstr "नहीं"
-#: ../imagery/i.points/main.c:131 ../imagery/i.vpoints/main.c:128
-#, c-format
-msgid "[%s] Only local groups may be used"
-msgstr ""
-#: ../imagery/i.points/main.c:140 ../imagery/i.points/main.c:144
-#: ../imagery/i.vpoints/main.c:137 ../imagery/i.vpoints/main.c:141
-#, c-format
-msgid "Group [%s] contains no maps, run i.group"
-msgstr ""
-#: ../imagery/i.points/main.c:250 ../imagery/i.vpoints/main.c:256
-#, c-format
-msgid "ERROR: %s"
-msgstr ""
-#: ../imagery/i.points/main.c:252 ../imagery/i.vpoints/main.c:258
-#, c-format
-msgid "WARNING: %s (click mouse to continue)"
-msgstr ""
-#: ../imagery/i.latlong/main.c:57 ../imagery/i.sunhours/main.c:57
-msgid "latitude"
-msgstr ""
-#: ../imagery/i.latlong/main.c:58
-msgid "longitude"
-msgstr ""
-#: ../imagery/i.latlong/main.c:60
-#, fuzzy
-msgid "Creates a latitude/longitude map."
-msgstr "बनाया जा रहा है i n"
-#: ../imagery/i.latlong/main.c:64
-#, fuzzy
-msgid "Name of the input map"
-msgstr "का"
-#: ../imagery/i.latlong/main.c:67
-#, fuzzy
-msgid "Name of the output latitude or longitude layer"
-msgstr "का"
-#: ../imagery/i.latlong/main.c:71
-msgid "Longitude output"
-msgstr ""
-#: ../imagery/i.zc/main.c:53 ../vector/v.lidar.edgedetection/main.c:74
-msgid "edges"
-msgstr ""
-#: ../imagery/i.zc/main.c:55
-#, fuzzy
-msgid "Zero-crossing \"edge detection\" raster function for image processing."
-msgstr "फंक्शन के लिए छवि."
-#: ../imagery/i.zc/main.c:73
-#, fuzzy
-msgid "Zero crossing raster map"
-msgstr "त्रुटि."
-#: ../imagery/i.zc/main.c:80
-#, fuzzy
-msgid "x-y extent of the Gaussian filter"
-msgstr "का फ़िल्टर"
-#: ../imagery/i.zc/main.c:88
-#, fuzzy
-msgid "Sensitivity of Gaussian filter"
-#: ../imagery/i.zc/main.c:96
-#, fuzzy
-msgid "Number of azimuth directions categorized"
-msgstr "संख्या का"
-#: ../imagery/i.zc/main.c:108
-#, fuzzy
-msgid "Threshold less than or equal to zero not allowed"
-msgstr "सीमा कम के बराबर नहीं."
-#: ../imagery/i.zc/main.c:114
-#, fuzzy
-msgid "Width less than or equal to zero not allowed"
-#: ../imagery/i.zc/main.c:118
-#, fuzzy
-msgid "Fewer than 1 orientation classes not allowed"
-#: ../imagery/i.zc/main.c:132
-#, fuzzy, c-format
-msgid "Power 2 values : %d rows %d columns"
-msgstr "पावर."
-#: ../imagery/i.zc/main.c:142
-#, fuzzy
-msgid "Initializing data..."
-msgstr "n"
-#: ../imagery/i.zc/main.c:172
-msgid "Writing transformed data to file..."
-msgstr ""
-#: ../imagery/i.zc/main.c:192
-msgid "Transform successful"
-msgstr ""
-#: ../imagery/i.smap/interp.c:225
-#, fuzzy
-msgid "Invalid parameter values"
-msgstr "अवैध."
-#: ../imagery/i.smap/read_sig.c:13 ../imagery/i.smap/openfiles.c:18
-#: ../imagery/i.gensig/openfiles.c:19 ../imagery/i.gensigset/openfiles.c:18
-#, fuzzy, c-format
-msgid "Unable to read REF file for subgroup <%s> in group <%s>"
-msgstr "के लिए समूह."
-#: ../imagery/i.smap/read_sig.c:17 ../imagery/i.smap/openfiles.c:22
-#, fuzzy, c-format
-msgid "Subgroup <%s> in group <%s> contains no raster maps"
-msgstr "समूह."
-#: ../imagery/i.smap/read_sig.c:23 ../imagery/i.maxlik/open.c:53
-#: ../imagery/i.cluster/open_files.c:70
-#, fuzzy, c-format
-msgid "Unable to read signature file <%s>"
-msgstr "i n"
-#: ../imagery/i.smap/read_sig.c:27
-#, fuzzy, c-format
-msgid "Signature file <%s> is invalid"
-msgstr "हस्ताक्षर है अवैध."
-#: ../imagery/i.smap/read_sig.c:30
-#, fuzzy, c-format
-msgid "Signature file <%s> is empty"
-#: ../imagery/i.smap/model.c:43
-#, fuzzy, c-format
-msgid "Nonsymetric covariance for class %d subclass %d"
-msgstr "के लिए."
-#: ../imagery/i.smap/model.c:55
-#, fuzzy, c-format
-msgid "Nonpositive eigenvalues for class %d subclass %d"
-msgstr "के लिए."
-#: ../imagery/i.smap/main.c:39 ../imagery/i.maxlik/main.c:62
-#: ../imagery/i.class/main.c:92 ../imagery/i.gensig/main.c:40
-#: ../imagery/i.gensigset/main.c:41 ../imagery/i.cluster/main.c:76
-#, fuzzy
-msgid "classification"
-msgstr "के लिए"
-#: ../imagery/i.smap/main.c:40 ../imagery/i.gensig/main.c:41
-#: ../imagery/i.gensigset/main.c:42
-msgid "supervised"
-msgstr ""
-#: ../imagery/i.smap/main.c:41 ../imagery/i.gensigset/main.c:43
-msgid "SMAP"
-msgstr ""
-#: ../imagery/i.smap/main.c:43
-#, fuzzy
-msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
-msgstr "छवि a."
-#: ../imagery/i.smap/parse.c:20 ../imagery/i.maxlik/main.c:79
-#, fuzzy
-msgid "Name of file containing signatures"
-msgstr "फ़ाइल"
-#: ../imagery/i.smap/parse.c:21
-msgid "Generated by i.gensigset"
-msgstr ""
-#: ../imagery/i.smap/parse.c:30
-#, fuzzy
-msgid "Size of submatrix to process at one time"
-msgstr "आकार  का पर एक"
-#: ../imagery/i.smap/parse.c:38
-#, fuzzy
-msgid "Use maximum likelihood estimation (instead of smap)"
-msgstr "का"
-#: ../imagery/i.smap/parse.c:52 ../imagery/i.maxlik/open.c:17
-#: ../imagery/i.gensig/parse.c:39 ../imagery/i.gensigset/parse.c:45
-#: ../imagery/i.cluster/open_files.c:18
-#, fuzzy, c-format
-msgid "Group <%s> not found"
-msgstr ""
-"\n"
-" समूह नहीं"
-#: ../imagery/i.smap/parse.c:55 ../imagery/i.gensig/parse.c:42
-#: ../imagery/i.gensigset/parse.c:48
-#, fuzzy, c-format
-msgid "Subgroup <%s> not found"
-msgstr "नहीं"
-#: ../imagery/i.smap/segment.c:66
-#, fuzzy
-msgid "Number of classes must be < 256"
-msgstr "का!"
-#: ../imagery/i.smap/segment.c:91
-#, fuzzy, c-format
-msgid "Processing rows %d-%d (of %d)..."
-msgstr "का का"
-#: ../imagery/i.eb.eta/main.c:44 ../imagery/i.eb.h_SEBAL01/main.c:84
-#: ../imagery/i.emissivity/main.c:46 ../imagery/i.eb.netrad/main.c:57
-#: ../imagery/i.eb.evapfr/main.c:48 ../imagery/i.eb.soilheatflux/main.c:50
-msgid "energy balance"
-msgstr ""
-#: ../imagery/i.eb.eta/main.c:45
-msgid "actual evapotranspiration"
-msgstr ""
-#: ../imagery/i.eb.eta/main.c:46 ../imagery/i.eb.h_SEBAL01/main.c:87
-#: ../imagery/i.eb.netrad/main.c:59 ../imagery/i.eb.evapfr/main.c:51
-#: ../imagery/i.eb.soilheatflux/main.c:52
-msgid "SEBAL"
-msgstr ""
-#: ../imagery/i.eb.eta/main.c:48
-msgid "Actual evapotranspiration for diurnal period (Bastiaanssen, 1995)."
-msgstr ""
-#: ../imagery/i.eb.eta/main.c:53
-#, fuzzy
-msgid "Name of the diurnal Net Radiation map [W/m2]"
-msgstr "का मीटर्स"
-#: ../imagery/i.eb.eta/main.c:58
-#, fuzzy
-msgid "Name of the evaporative fraction map [-]"
-msgstr "का"
-#: ../imagery/i.eb.eta/main.c:63
-#, fuzzy
-msgid "Name of the surface skin temperature [K]"
-msgstr "का"
-#: ../imagery/i.eb.eta/main.c:68
-#, fuzzy
-msgid "Name of the output actual evapotranspiration layer [mm/d]"
-msgstr "का"
-#: ../imagery/i.vi/main.c:84
-#, fuzzy
-msgid "vegetation index"
-msgstr "का"
-#: ../imagery/i.vi/main.c:85
-#, fuzzy
-msgid "biophysical parameters"
-msgstr "चिकना"
-#: ../imagery/i.vi/main.c:87
-msgid "Calculates different types of vegetation indices."
-msgstr ""
-#: ../imagery/i.vi/main.c:88
-msgid "Uses red and nir bands mostly, and some indices require additional bands."
-msgstr ""
-#: ../imagery/i.vi/main.c:93
-#, fuzzy
-msgid "viname"
-msgstr "n"
-#: ../imagery/i.vi/main.c:96
-#, fuzzy
-msgid "Name of vegetation index"
-msgstr "का"
-#: ../imagery/i.vi/main.c:97
-msgid "arvi;Atmospherically Resistant Vegetation Indices;dvi;Difference Vegetation Index;evi;Enhanced Vegetation Index;gvi;Green Vegetation Index;gari;Green atmospherically resistant vegetation index;gemi;Global Environmental Monitoring Index;ipvi;Infrared Percentage Vegetation Index;msavi;Modified Soil Adjusted Vegetation Index;msavi2;second Modified Soil Adjusted Vegetation Index;ndvi;Normalized Difference Vegetation Index;pvi;Perpendicular Vegetation Index;savi;Soil Adjusted Vegetation Index;sr;Simple Ratio;vari;Visible Atmospherically Resistant Index;wdvi;Weighted Difference Vegetation Index;"
-msgstr ""
-#: ../imagery/i.vi/main.c:118
-#, fuzzy
-msgid "Name of the red channel surface reflectance map"
-msgstr "का"
-#: ../imagery/i.vi/main.c:119 ../imagery/i.vi/main.c:126
-#: ../imagery/i.vi/main.c:133 ../imagery/i.vi/main.c:140
-#: ../imagery/i.vi/main.c:147 ../imagery/i.vi/main.c:154
-msgid "Range: [0.0;1.0]"
-msgstr ""
-#: ../imagery/i.vi/main.c:125
-#, fuzzy
-msgid "Name of the nir channel surface reflectance map"
-msgstr "का"
-#: ../imagery/i.vi/main.c:132
-#, fuzzy
-msgid "Name of the green channel surface reflectance map"
-msgstr "का"
-#: ../imagery/i.vi/main.c:139
-#, fuzzy
-msgid "Name of the blue channel surface reflectance map"
-msgstr "का"
-#: ../imagery/i.vi/main.c:146
-#, fuzzy
-msgid "Name of the chan5 channel surface reflectance map"
-msgstr "का"
-#: ../imagery/i.vi/main.c:153
-#, fuzzy
-msgid "Name of the chan7 channel surface reflectance map"
-msgstr "का"
-#: ../imagery/i.vi/main.c:160
-msgid "MSAVI2: Value of the slope of the soil line"
-msgstr ""
-#: ../imagery/i.vi/main.c:166
-msgid "MSAVI2: Value of the intercept of the soil line"
-msgstr ""
-#: ../imagery/i.vi/main.c:172
-msgid "MSAVI2: Value of the factor of reduction of soil noise"
-msgstr ""
-#: ../imagery/i.vi/main.c:178
-msgid "If your data is in Digital Numbers (i.e. integer type), give the max bits (i.e. 8 for Landsat -> [0-255])"
-msgstr ""
-#: ../imagery/i.vi/main.c:205
-msgid "sr index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:208
-msgid "ndvi index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:211
-msgid "ipvi index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:214
-msgid "dvi index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:217
-msgid "pvi index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:220
-msgid "wdvi index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:223
-msgid "savi index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:226
-msgid "msavi index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:229
-msgid "msavi2 index requires red and nir maps, and 3 parameters related to soil line"
-msgstr ""
-#: ../imagery/i.vi/main.c:232
-msgid "gemi index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:236
-msgid "arvi index requires blue, red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:240
-msgid "evi index requires blue, red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:244
-msgid "vari index requires blue, green and red maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:248
-msgid "gari index requires blue, green, red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:253
-msgid "gvi index requires blue, green, red, nir, chan5 and chan7 maps"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:70
-#, c-format
-msgid "Input raster map <%s> is not floating point (process DN using i.landsat.toar to radiance first)"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:104
-msgid "Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)."
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:106 ../imagery/i.landsat.toar/main.c:68
-msgid "landsat"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:107
-msgid "acca"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:111 ../imagery/i.landsat.toar/main.c:76
-#, fuzzy
-msgid "Base name of input raster bands"
-msgstr "का"
-#: ../imagery/i.landsat.acca/main.c:112 ../imagery/i.landsat.toar/main.c:77
-msgid "Example: 'B.' for B.1, B.2, ..."
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:122
-msgid "B56composite (step 6)"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:129
-msgid "B45ratio: Desert detection (step 10)"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:137
-#, fuzzy
-msgid "Number of classes in the cloud temperature histogram"
-#: ../imagery/i.landsat.acca/main.c:139 ../imagery/i.landsat.acca/main.c:154
-#: ../imagery/i.landsat.acca/main.c:160 ../imagery/i.landsat.acca/main.c:165
-#, fuzzy
-msgid "Cloud settings"
-msgstr "नहीं"
-#: ../imagery/i.landsat.acca/main.c:143
-msgid "Data is Landsat-5 TM"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:144
-msgid "I.e. Thermal band is '.6' not '.61')"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:149
-msgid "Apply post-processing filter to remove small holes"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:153
-msgid "Always use cloud signature (step 14)"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:159
-msgid "Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:164
-msgid "Include a category for cloud shadows"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:124
-msgid "Preliminary scene analysis:"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:125
-#, c-format
-msgid "* Desert index: %.2lf"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:126
-#, c-format
-msgid "* Snow cover: %.2lf %%"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:127
-#, c-format
-msgid "* Cloud cover: %.2lf %%"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:128
-msgid "* Temperature of clouds:"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:129
-#, c-format
-msgid "** Maximum: %.2lf K"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:130
-#, c-format
-msgid "** Mean (%s cloud): %.2lf K"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:132
-#, c-format
-msgid "** Minimum: %.2lf K"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:142
-msgid "Histogram cloud signature:"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:148
-#, c-format
-msgid "* Mean temperature: %.2lf K"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:149
-#, fuzzy, c-format
-msgid "* Standard deviation: %.2lf"
-#: ../imagery/i.landsat.acca/algorithm.c:150
-#, c-format
-msgid "* Skewness: %.2lf"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:151
-#, c-format
-msgid "* Histogram classes: %d"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:163
-#, c-format
-msgid "* 98.75 percentile: %.2lf K"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:164
-#, c-format
-msgid "* 97.50 percentile: %.2lf K"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:165
-#, c-format
-msgid "* 83.50 percentile: %.2lf K"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:186
-#, fuzzy
-msgid "Maximum temperature:"
-msgstr "विशेषता"
-#: ../imagery/i.landsat.acca/algorithm.c:187
-#, c-format
-msgid "* Cold cloud: %.2lf K"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:188
-#, c-format
-msgid "* Warm cloud: %.2lf K"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:193
-msgid "Result: Scene with clouds"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:200
-msgid "Result: Scene cloud free"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:237
-#, fuzzy
-msgid "Processing first pass..."
-msgstr "n"
-#: ../imagery/i.landsat.acca/algorithm.c:391
-#, fuzzy
-msgid "Removing ambiguous pixels..."
-msgstr "के लिए n"
-#: ../imagery/i.landsat.acca/algorithm.c:393
-#, fuzzy
-msgid "Pass two processing..."
-msgstr "n"
-#: ../imagery/i.landsat.acca/tools.c:138
-#, fuzzy
-msgid "Filling small holes in clouds..."
-msgstr "छवि "
-#: ../imagery/i.maxlik/main.c:63 ../imagery/i.gensig/main.c:42
-msgid "MLC"
-msgstr ""
-#: ../imagery/i.maxlik/main.c:65
-msgid "Classifies the cell spectral reflectances in imagery data."
-msgstr ""
-#: ../imagery/i.maxlik/main.c:67
-#, fuzzy
-msgid "Classification is based on the spectral signature information generated by either i.cluster, i.class, or i.gensig."
-msgstr "फंक्शन चालू i i i."
-#: ../imagery/i.maxlik/main.c:80
-#, fuzzy
-msgid "Generated by either i.cluster, i.class, or i.gensig"
-#: ../imagery/i.maxlik/main.c:85
-#, fuzzy
-msgid "Name for raster map holding classification results"
-msgstr "का"
-#: ../imagery/i.maxlik/main.c:91
-#, fuzzy
-msgid "Name for raster map holding reject threshold results"
-msgstr "का रखे हुए"
-#: ../imagery/i.maxlik/open.c:20 ../imagery/i.cluster/open_files.c:22
-#, fuzzy, c-format
-msgid "Subgroup <%s> in group <%s> not found"
-msgstr "नहीं"
-#: ../imagery/i.maxlik/open.c:27
-#, fuzzy, c-format
-msgid "Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must have at least 2 raster maps."
-msgstr "का समूह पर."
-#: ../imagery/i.maxlik/open.c:30
-#, fuzzy, c-format
-msgid "Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at least 2 raster maps."
-#: ../imagery/i.maxlik/open.c:47
-#, fuzzy, c-format
-msgid "Unable to open signature file <%s>"
-msgstr "के लिए"
-#: ../imagery/i.maxlik/open.c:57 ../imagery/i.cluster/open_files.c:74
-#, fuzzy, c-format
-msgid "<%s> has too many signatures (limit is 255)"
-msgstr "है"
-#: ../imagery/i.maxlik/invert.c:28
-#, fuzzy, c-format
-msgid "Signature %d is not valid (ill-conditioned) - ignored"
-msgstr "है नहीं."
-#: ../imagery/i.maxlik/invert.c:31
-#, fuzzy, c-format
-msgid "Signature %d is not valid (singular) - ignored"
-msgstr "है नहीं एक वचन."
-#: ../imagery/i.eb.h_SEBAL01/main.c:85 ../imagery/i.eb.evapfr/main.c:49
-msgid "soil moisture"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:86 ../imagery/i.eb.evapfr/main.c:50
-msgid "evaporative fraction"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:88
-msgid "Computes sensible heat flux iteration SEBAL 01."
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:94
-#, fuzzy
-msgid "Name of instantaneous Net Radiation raster map [W/m2]"
-msgstr "का"
-#: ../imagery/i.eb.h_SEBAL01/main.c:99
-#, fuzzy
-msgid "Name of instantaneous soil heat flux raster map [W/m2]"
-msgstr "का"
-#: ../imagery/i.eb.h_SEBAL01/main.c:104
-#, fuzzy
-msgid "Name of aerodynamic resistance to heat momentum raster map [s/m]"
-msgstr "का"
-#: ../imagery/i.eb.h_SEBAL01/main.c:109
-#, fuzzy
-msgid "Name of altitude corrected surface temperature raster map [K]"
-msgstr "का"
-#: ../imagery/i.eb.h_SEBAL01/main.c:117
-msgid "Value of the height independent friction velocity (u*) [m/s]"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:125
-#, fuzzy
-msgid "Value of the actual vapour pressure (e_act) [KPa]"
-msgstr "का"
-#: ../imagery/i.eb.h_SEBAL01/main.c:132
-#, fuzzy
-msgid "Row value of the wet pixel"
-msgstr "के लिए"
-#: ../imagery/i.eb.h_SEBAL01/main.c:139
-#, fuzzy
-msgid "Column value of the wet pixel"
-msgstr "के लिए पाठ"
-#: ../imagery/i.eb.h_SEBAL01/main.c:146
-msgid "Row value of the dry pixel"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:153
-#, fuzzy
-msgid "Column value of the dry pixel"
-#: ../imagery/i.eb.h_SEBAL01/main.c:157
-#, fuzzy
-msgid "Name for output sensible heat flux raster map [W/m2]"
-msgstr "का"
-#: ../imagery/i.eb.h_SEBAL01/main.c:162
-msgid "Automatic wet/dry pixel (careful!)"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:167
-msgid "Dry/Wet pixels coordinates are in image projection, not row/col"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:195
-msgid "Either auto-mode either wet/dry pixels coordinates should be provided!"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:198
-msgid "Manual wet/dry pixels in image coordinates"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:199
-#, c-format
-msgid "Wet Pixel=> x:%f y:%f"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:200
-#, c-format
-msgid "Dry Pixel=> x:%f y:%f"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:204
-#, fuzzy
-msgid "Automatic mode selected"
-msgstr "नहीं"
-#: ../imagery/i.eb.h_SEBAL01/main.c:206
-#, c-format
-msgid "Wet Pixel=> row:%.0f col:%.0f"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:207
-#, c-format
-msgid "Dry Pixel=> row:%.0f col:%.0f"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:212
-#, fuzzy, c-format
-msgid "<%s> is an illegal name"
-msgstr "है"
-#: ../imagery/i.landsat.toar/landsat_met.c:57
-#: ../imagery/i.landsat.toar/landsat_met.c:146
-#: ../imagery/i.landsat.toar/landsat_met.c:234
-#, fuzzy, c-format
-msgid "Metadata file <%s> not found"
-msgstr "नहीं"
-#: ../imagery/i.landsat.toar/landsat_met.c:160
-#, c-format
-msgid "Product creation date not in metadata file <%s>"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:66
-msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+."
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:69
-#, fuzzy
-msgid "top-of-atmosphere reflectance"
-msgstr "आइसोसरफेस"
-#: ../imagery/i.landsat.toar/main.c:70
-msgid "dos-type simple atmospheric correction"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:83
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:13
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:15
-#, fuzzy
-msgid "Prefix for output raster maps"
-msgstr "का"
-#: ../imagery/i.landsat.toar/main.c:84
-msgid "Example: 'B.toar.' generates B.toar.1, B.toar.2, ..."
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:91
-msgid "Name of Landsat ETM+ or TM5 header file (.met/MTL.txt)"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:97
-msgid "Spacecraft sensor"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:98 ../imagery/i.landsat.toar/main.c:116
-#: ../imagery/i.landsat.toar/main.c:126 ../imagery/i.landsat.toar/main.c:134
-#: ../imagery/i.landsat.toar/main.c:143
-msgid "Required only if 'metfile' not given"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:101
-msgid "mss1;Landsat-1 MSS;mss2;Landsat-2 MSS;mss3;Landsat-3 MSS;tm4;Landsat-4 TM;tm5;Landsat-5 TM;tm7;Landsat-7 ETM+"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:115
-#, fuzzy
-msgid "Atmospheric correction method"
-msgstr "है n"
-#: ../imagery/i.landsat.toar/main.c:125
-msgid "Image acquisition date (yyyy-mm-dd)"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:133
-msgid "Solar elevation in degrees"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:142
-msgid "Image creation date (yyyy-mm-dd)"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:151
-msgid "Gain (H/L) of all Landsat ETM+ bands (1-5,61,62,7,8)"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:158
-msgid "Percent of solar radiance in path radiance"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:167
-msgid "Minimum pixels to consider digital number as dark object"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:175
-msgid "Satellite zenith in degrees"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:183
-msgid "Rayleigh atmosphere"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:190
-msgid "Output at-sensor radiance for all bands"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:194
-msgid "Set sensor of Landsat TM4/5 to MSS"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:199
-msgid "Landsat ETM+/TM5 has a MTL.txt file instead of .met"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:224 ../imagery/i.landsat.toar/main.c:234
-#, fuzzy, c-format
-msgid "Illegal date format: [%s] (yyyy-mm-dd)"
-msgstr "के लिए"
-#: ../imagery/i.landsat.toar/main.c:258
-msgid "Failed to identify satellite"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:267
-#, c-format
-msgid "Lacking '%s' or '%s' for this satellite"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:277
-msgid "Landsat-7 requires band gain with 9 (H/L) data"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:308
-#, fuzzy, c-format
-msgid "Unknown satellite type (defined by '%s')"
-msgstr "अज्ञात क़िस्म"
-#: ../imagery/i.landsat.toar/main.c:414
-#, fuzzy, c-format
-msgid "Unknown production date (defined by '%s')"
-msgstr "के लिए"
-#: ../imagery/i.landsat.toar/main.c:485
-#, fuzzy, c-format
-msgid "Raster map <%s> exists. Skipping."
-msgstr "समूह."
-#: ../imagery/i.landsat.toar/main.c:510
-#, fuzzy, c-format
-msgid "Writing %s of <%s> to <%s>..."
-msgstr "n"
-#: ../imagery/i.landsat.toar/main.c:511 ../imagery/i.aster.toar/main.c:100
-#, fuzzy
-msgid "radiance"
-msgstr "का"
-#: ../imagery/i.landsat.toar/main.c:513 ../imagery/i.eb.netrad/main.c:75
-#, fuzzy
-msgid "temperature"
-msgstr "विशेषता"
-#: ../imagery/i.landsat.toar/main.c:513 ../imagery/i.aster.toar/main.c:101
-#, fuzzy
-msgid "reflectance"
-msgstr "नहीं n"
-#: ../imagery/i.class/signature.c:50 ../imagery/i.class/signature.c:55
-#, fuzzy
-msgid "Unable to allocate space for signature statistics."
-msgstr "के लिए."
-#: ../imagery/i.class/signature.c:82
-#, fuzzy
-msgid "prepare_signature: outline has odd number of points."
-msgstr "संख्या का."
-#: ../imagery/i.class/signature.c:113
-#, fuzzy, c-format
-msgid "prepare_signature: scan line %d has odd number of points."
-#: ../imagery/i.class/signature.c:123
-#, fuzzy
-msgid "signature: perimeter points out of order."
-msgstr "का."
-#: ../imagery/i.class/signature.c:132
-#, fuzzy
-msgid "prepare_signature: data error."
-msgstr "त्रुटि."
-#: ../imagery/i.class/signature.c:234
-msgid "Unknown Menu selection in show_signature()."
-msgstr ""
-#: ../imagery/i.class/add_point.c:22
-#, fuzzy, c-format
-msgid "Can't mark another point.  Only %d points allowed.  Sorry."
-msgstr "बिन्दु खेद है."
-#: ../imagery/i.class/draw_reg.c:89
-#, c-format
-msgid ""
-"\n"
-"Orig:(x1 y1), (x2 y2) = (%d %d), (%d %d)"
-msgstr ""
-#: ../imagery/i.class/draw_reg.c:97
-#, c-format
-msgid ""
-"\n"
-"New:(x1 y1), (x2 y2) = (%d %d), (%d %d)"
-msgstr ""
-#: ../imagery/i.class/analyze_sig.c:12
-#, fuzzy
-msgid "Cannot analyze until region is completed."
-msgstr "है पूर्ण."
-#: ../imagery/i.class/redisplay.c:56
-#, fuzzy
-msgid "No zoom window is defined."
-msgstr "नहीं है."
-#: ../imagery/i.class/curses.c:22
-#, c-format
-msgid "make_window(%d,%d,%d,%d): illegal screen values."
-msgstr ""
-#: ../imagery/i.class/curses.c:153
-#, c-format
-msgid "%s"
-msgstr ""
-#: ../imagery/i.class/remove_mask.c:15
-#, fuzzy
-msgid "Error while removing the old MASK cell map."
-msgstr "त्रुटि."
-#: ../imagery/i.class/main.c:94
-msgid "Generates spectral signatures for an image by allowing the user to outline regions of interest."
-msgstr ""
-#: ../imagery/i.class/main.c:97
-#, fuzzy
-msgid "The resulting signature file can be used as input for i.maxlik or as a seed signature file for i.cluster."
-msgstr "फंक्शन के लिए छवि का के लिए i a के लिए i."
-#: ../imagery/i.class/main.c:101 ../display/d.rast/main.c:60
-#, fuzzy
-msgid "Name of raster map to be displayed"
-msgstr "का"
-#: ../imagery/i.class/main.c:111 ../imagery/i.cca/main.c:95
-#, fuzzy
-msgid "Name of input imagery subgroup"
-msgstr "का समूह"
-#: ../imagery/i.class/main.c:116
-#, fuzzy
-msgid "File to contain result signatures"
-msgstr "फ़ाइल"
-#: ../imagery/i.class/main.c:121
-#, fuzzy
-msgid "File containing input signatures (seed)"
-msgstr "फ़ाइल"
-#: ../imagery/i.class/main.c:133
-#, fuzzy
-msgid "You have a mask set. Unset mask and run again"
-msgstr "a सेट."
-#: ../imagery/i.class/main.c:142 ../imagery/i.group/main.c:113
-#: ../imagery/i.target/main.c:80
-#, fuzzy
-msgid "Group must exist in the current mapset"
-msgstr "के लिए."
-#: ../imagery/i.class/main.c:251
-#, fuzzy, c-format
-msgid "** The following raster maps in subgroup [%s] do not exist:"
-msgstr "n नहीं:"
-#: ../imagery/i.class/main.c:260
-#, fuzzy, c-format
-msgid "Subgroup [%s] does not have any files"
-msgstr "समूह."
-#: ../imagery/i.class/main.c:261 ../imagery/i.class/main.c:265
-#, fuzzy
-msgid "The subgroup must have at least 2 files to run"
-msgstr "पर"
-#: ../imagery/i.class/main.c:264
-#, c-format
-msgid "Subgroup [%s] only has 1 file"
-msgstr ""
-#: ../imagery/i.class/main.c:273
-msgid ""
-"\n"
-"RESULT SIGNATURE"
-msgstr ""
-#: ../imagery/i.class/main.c:278
-#, fuzzy, c-format
-msgid "Unable to open output signature file '%s'"
-msgstr "का"
-#: ../imagery/i.class/main.c:284
-msgid ""
-"\n"
-"SEED SIGNATURES"
-msgstr ""
-#: ../imagery/i.class/main.c:290
-#, fuzzy, c-format
-msgid "Unable to read signature file [%s]"
-msgstr "i n"
-#: ../imagery/i.class/main.c:293
-#, fuzzy, c-format
-msgid "** Unable to read signature file [%s] **"
-msgstr "i n"
-#: ../imagery/i.class/main.c:300
-#, fuzzy, c-format
-msgid "%s has too many signatures"
-msgstr "अधिक."
-#: ../imagery/i.class/outline.c:57
-#, fuzzy
-msgid "Absurd polygon."
-msgstr "बहुभुज."
-#: ../imagery/i.class/outline.c:99
-#, fuzzy
-msgid "Outlined area is too large."
-msgstr "है बड़ा."
-#: ../imagery/i.class/save_reg.c:14
-#, fuzzy
-msgid "Region is not complete, can not save."
-msgstr "है नहीं नहीं."
-#: ../imagery/i.class/restore_reg.c:15
-#, fuzzy
-msgid "No region is saved, can not restore."
-msgstr "नहीं है नहीं."
-#: ../imagery/i.class/complete_reg.c:12
-#, fuzzy
-msgid "Too few points for region.  Must have at least 3 points."
-msgstr "कुछ के लिए पर."
-#: ../imagery/i.class/complete_reg.c:14
-#, fuzzy
-msgid "Area already completed."
-msgstr "पूर्ण."
-#: ../imagery/i.class/erase_reg.c:10
-#, fuzzy
-msgid "Can not erase an undefined region."
-msgstr "नहीं अपारिभाषित."
-#: ../imagery/i.group/main.c:55
-#, fuzzy
-msgid "Creates, edits, and lists groups of imagery data."
-msgstr "का."
-#: ../imagery/i.group/main.c:59
-#, fuzzy
-msgid "Name of imagery group"
-msgstr "का समूह"
-#: ../imagery/i.group/main.c:65
-#, fuzzy
-msgid "Name of imagery sub-group"
-msgstr "का समूह"
-#: ../imagery/i.group/main.c:69
-#, fuzzy
-msgid "Name of raster map(s) to include in group"
-msgstr "का समूह"
-#: ../imagery/i.group/main.c:70 ../imagery/i.group/main.c:75
-msgid "Maps"
-msgstr ""
-#: ../imagery/i.group/main.c:74
-#, fuzzy
-msgid "Remove selected files from specified group"
-msgstr "हटाएँ समूह"
-#: ../imagery/i.group/main.c:79
-#, fuzzy
-msgid "List files from specified (sub)group (fancy)"
-msgstr "समूह"
-#: ../imagery/i.group/main.c:85
-#, fuzzy
-msgid "List files from specified (sub)group (shell script style)"
-msgstr "समूह"
-#: ../imagery/i.group/main.c:105
-#, fuzzy
-msgid "No input raster map(s) specified"
-msgstr "नहीं."
-#: ../imagery/i.group/main.c:123 ../imagery/i.group/main.c:144
-#, fuzzy
-msgid "Specified group does not exist in current mapset"
-msgstr "समूह नहीं."
-#: ../imagery/i.group/main.c:127
-#, fuzzy, c-format
-msgid "Removing raster maps from subgroup <%s>..."
-msgstr "n"
-#: ../imagery/i.group/main.c:132
-#, fuzzy, c-format
-msgid "Removing raster maps from group <%s>..."
-msgstr "n"
-#: ../imagery/i.group/main.c:167
-#, fuzzy, c-format
-msgid "Group <%s> does not yet exist. Creating..."
-msgstr "समूह नहीं बनाया जा रहा है."
-#: ../imagery/i.group/main.c:171 ../imagery/i.group/main.c:180
-#, fuzzy, c-format
-msgid "Adding raster maps to group <%s>..."
-msgstr "n"
-#: ../imagery/i.group/main.c:175
-#, fuzzy, c-format
-msgid "Adding raster maps to subgroup <%s>..."
-msgstr "n"
-#: ../imagery/i.group/main.c:206
-#, fuzzy, c-format
-msgid "Adding raster map <%s> to group"
-msgstr "नहीं"
-#: ../imagery/i.group/main.c:212
-#, fuzzy, c-format
-msgid "Raster map <%s> exists in group. Skipping..."
-msgstr "समूह."
-#: ../imagery/i.group/main.c:246
-#, fuzzy, c-format
-msgid "Adding raster map <%s> to subgroup"
-msgstr "नहीं"
-#: ../imagery/i.group/main.c:252
-#, fuzzy, c-format
-msgid "Raster map <%s> exists in subgroup. Skipping..."
-msgstr "समूह."
-#: ../imagery/i.group/main.c:301
-#, fuzzy, c-format
-msgid "Removing raster map <%s> from group"
-msgstr "नहीं"
-#: ../imagery/i.group/main.c:318 ../imagery/i.group/main.c:377
-#, fuzzy
-msgid "No raster map removed"
-msgstr "Bin"
-#: ../imagery/i.group/main.c:360
-#, fuzzy, c-format
-msgid "Removing raster map <%s> from subgroup"
-msgstr "नहीं"
-#: ../imagery/i.aster.toar/main.c:98
-msgid "Terra-ASTER"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:99
-msgid "DN"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:102
-msgid "brightness temperature"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:104
-msgid "Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature from ASTER DN.\n"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:108
-msgid "Names of ASTER DN layers (15 layers)"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:115
-#, fuzzy
-msgid "Day of Year of satellite overpass [0-366]"
-msgstr "का"
-#: ../imagery/i.aster.toar/main.c:122
-msgid "Sun elevation angle (degrees, < 90.0)"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:125
-#, fuzzy
-msgid "Base name of the output layers (will add .x)"
-msgstr "का"
-#: ../imagery/i.aster.toar/main.c:130
-msgid "Output is radiance (W/m2)"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:134
-msgid "VNIR is High Gain"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:138
-msgid "SWIR is High Gain"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:142
-msgid "VNIR is Low Gain 1"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:146
-msgid "SWIR is Low Gain 1"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:150
-msgid "SWIR is Low Gain 2"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:229 ../imagery/i.albedo/main.c:150
-#, c-format
-msgid "Too many input maps. Only %d allowed."
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:244
-msgid "The input band number should be 15"
-msgstr ""
-#: ../imagery/i.gensig/check.c:21
-#, fuzzy, c-format
-msgid "Signature %d not invertible"
-msgstr "हस्ताक्षर नहीं."
-#: ../imagery/i.gensig/check.c:27
-#, fuzzy, c-format
-msgid "Signature %d unable to get eigen values"
-msgstr "हस्ताक्षर."
-#: ../imagery/i.gensig/check.c:33
-#, fuzzy, c-format
-msgid "Signature %d not positive definite"
-#: ../imagery/i.gensig/covariance.c:30
-msgid "Calculating class covariance matrices..."
-msgstr ""
-#: ../imagery/i.gensig/means.c:26
-#, fuzzy
-msgid "Calculating class means..."
-msgstr "n"
-#: ../imagery/i.gensig/main.c:44
-#, fuzzy
-msgid "Generates statistics for i.maxlik from raster map."
-msgstr "के लिए i."
-#: ../imagery/i.gensig/get_train.c:32 ../imagery/i.gensigset/get_train.c:35
-#, fuzzy
-msgid "Finding training classes..."
-msgstr "फ़ाइल"
-#: ../imagery/i.gensig/get_train.c:55 ../imagery/i.gensigset/get_train.c:58
-#, fuzzy, c-format
-msgid "Training class %d only has one cell - this class will be ignored"
-msgstr "एक."
-#: ../imagery/i.gensig/get_train.c:60 ../imagery/i.gensigset/get_train.c:63
-#, fuzzy
-msgid "Training map has no classes"
-msgstr "नहीं."
-#: ../imagery/i.gensig/get_train.c:75 ../imagery/i.gensigset/get_train.c:79
-#, fuzzy
-msgid "1 class found"
-msgstr "नहीं"
-#: ../imagery/i.gensig/get_train.c:77 ../imagery/i.gensigset/get_train.c:81
-#, fuzzy, c-format
-msgid "%d classes found"
-msgstr "नहीं"
-#: ../imagery/i.gensig/parse.c:14 ../imagery/i.gensigset/parse.c:13
-msgid "Ground truth training map"
-msgstr ""
-#: ../imagery/i.gensig/parse.c:22 ../imagery/i.gensigset/parse.c:21
-#: ../imagery/i.cluster/main.c:94
-#, fuzzy
-msgid "Name for output file containing result signatures"
-msgstr "का का त्रुटि माट्रिक्स काप्पा"
-#: ../imagery/i.gensig/write_sig.c:15 ../imagery/i.gensigset/write_sig.c:13
-#, fuzzy, c-format
-msgid "Unable to create signature file <%s>"
-msgstr "i n"
-#: ../imagery/i.gensig/write_sig.c:18 ../imagery/i.gensigset/write_sig.c:16
-#, fuzzy
-msgid "Writing signatures..."
-msgstr "छापें"
-#: ../imagery/i.gensig/openfiles.c:23 ../imagery/i.gensigset/openfiles.c:22
-#, fuzzy, c-format
-msgid "Subgroup <%s> in group <%s> contains no raster maps."
-msgstr "समूह."
-#: ../imagery/i.his.rgb/main.c:51
-msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
-msgstr ""
-#: ../imagery/i.his.rgb/main.c:57
-#, fuzzy
-msgid "Name of input raster map (hue)"
-msgstr "का"
-#: ../imagery/i.his.rgb/main.c:61
-#, fuzzy
-msgid "Name of input raster map (intensity)"
-msgstr "का"
-#: ../imagery/i.his.rgb/main.c:65
-#, fuzzy
-msgid "Name of input raster map (saturation)"
-msgstr "का"
-#: ../imagery/i.his.rgb/main.c:69
-#, fuzzy
-msgid "Name for output raster map (red)"
-msgstr "का"
-#: ../imagery/i.his.rgb/main.c:73
-#, fuzzy
-msgid "Name for output raster map (green)"
-msgstr "का"
-#: ../imagery/i.his.rgb/main.c:77
-#, fuzzy
-msgid "Name for output raster map (blue)"
-msgstr "का"
-#: ../imagery/i.evapo.mh/main.c:72
-msgid "Computes evapotranspiration calculation modified or original Hargreaves formulation, 2001."
-msgstr ""
-#: ../imagery/i.evapo.mh/main.c:78
-#, fuzzy
-msgid "Name of input diurnal net radiation raster map [W/m2/d]"
-msgstr "का मीटर्स"
-#: ../imagery/i.evapo.mh/main.c:82
-#, fuzzy
-msgid "Name of input average air temperature raster map [C]"
-msgstr "का"
-#: ../imagery/i.evapo.mh/main.c:86
-#, fuzzy
-msgid "Name of input minimum air temperature raster map [C]"
-msgstr "का"
-#: ../imagery/i.evapo.mh/main.c:90
-#, fuzzy
-msgid "Name of input maximum air temperature raster map [C]"
-msgstr "का"
-#: ../imagery/i.evapo.mh/main.c:96
-#, fuzzy
-msgid "Name of precipitation raster map [mm/month]"
-msgstr "का मीटर्स"
-#: ../imagery/i.evapo.mh/main.c:97
-msgid "Disabled for original Hargreaves (1985)"
-msgstr ""
-#: ../imagery/i.evapo.mh/main.c:100
-#, fuzzy
-msgid "Name for output raster map [mm/d]"
-msgstr "का"
-#: ../imagery/i.evapo.mh/main.c:109
-msgid "Use original Hargreaves (1985)"
-msgstr ""
-#: ../imagery/i.evapo.mh/main.c:113
-msgid "Use Hargreaves-Samani (1985)"
-msgstr ""
-#: ../imagery/i.rectify/rectify.c:41
-#, fuzzy, c-format
-msgid "Rectify <%s@%s> (location <%s>)"
-msgstr "छवि "
-#: ../imagery/i.rectify/rectify.c:44
-#, fuzzy, c-format
-msgid "into  <%s@%s> (location <%s>) ..."
-msgstr "समूह के लिए n"
-#: ../imagery/i.rectify/rectify.c:105
-#, fuzzy, c-format
-msgid "Raster map <%s@%s>: projection don't match current settings"
-msgstr "नहीं"
-#: ../imagery/i.rectify/rectify.c:111
-#, fuzzy, c-format
-msgid "Raster map <%s@%s>: zone don't match current settings"
-msgstr "नहीं"
-#: ../imagery/i.rectify/main.c:95 ../vector/v.rectify/main.c:64
-#, fuzzy
-msgid "rectify"
-msgstr "समूह"
-#: ../imagery/i.rectify/main.c:97
-#, fuzzy
-msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
-msgstr "छवि a के लिए छवि चालू"
-#: ../imagery/i.rectify/main.c:111
-#, fuzzy
-msgid "Output raster map(s) suffix"
-msgstr "शीर्षक"
-#: ../imagery/i.rectify/main.c:119 ../vector/v.rectify/main.c:90
-#, fuzzy
-msgid "Rectification polynom order (1-3)"
-msgstr "पॉलीनॉम"
-#: ../imagery/i.rectify/main.c:125
-msgid "Target resolution (ignored if -c flag used)"
-msgstr ""
-#: ../imagery/i.rectify/main.c:133
-#, fuzzy
-msgid "Amount of memory to use in MB"
-msgstr "का!"
-#: ../imagery/i.rectify/main.c:148
-#, fuzzy
-msgid "Use current region settings in target location (def.=calculate smallest area)"
-msgstr "सेट"
-#: ../imagery/i.rectify/main.c:152
-#, fuzzy
-msgid "Rectify all raster maps in group"
-msgstr "सभी छवियाँ समूह"
-#: ../imagery/i.rectify/main.c:190 ../vector/v.rectify/main.c:130
-#, c-format
-msgid "Invalid order (%d); please enter 1 to %d"
-msgstr ""
-#: ../imagery/i.rectify/main.c:195
-#, fuzzy, c-format
-msgid "Location: %s"
-msgstr "n"
-#: ../imagery/i.rectify/main.c:196
-#, fuzzy, c-format
-msgid "Mapset: %s"
-msgstr "n"
-#: ../imagery/i.rectify/main.c:197
-#, fuzzy, c-format
-msgid "Group <%s> does not exist"
-msgstr "नहीं"
-#: ../imagery/i.rectify/main.c:201
-#, c-format
-msgid "Group <%s> contains no raster maps; run i.group"
-msgstr ""
-#: ../imagery/i.rectify/main.c:276
-#, fuzzy, c-format
-msgid "Extension <%s> is illegal"
-msgstr "है"
-#: ../imagery/i.rectify/main.c:279
-#, fuzzy
-msgid "The following raster map already exists in"
-msgstr "नहीं"
-#: ../imagery/i.rectify/main.c:280 ../vector/v.rectify/main.c:182
-#, c-format
-msgid "target LOCATION %s, MAPSET %s:"
-msgstr ""
-#: ../imagery/i.rectify/main.c:283
-msgid "Orthorectification cancelled."
-msgstr ""
-#: ../imagery/i.rectify/main.c:298
-msgid "Target resolution must be > 0, ignored"
-msgstr ""
-#: ../imagery/i.rectify/main.c:309
-#, c-format
-msgid "Using region: N=%f S=%f, E=%f W=%f"
-msgstr ""
-#: ../imagery/i.rectify/main.c:324
-#, fuzzy, c-format
-msgid "Input raster map <%s> does not exist in group <%s>."
-msgstr "समूह."
-#: ../imagery/i.rectify/main.c:326
-msgid "Try:"
-msgstr ""
-#: ../imagery/i.rectify/main.c:331
-msgid "Exit!"
-msgstr ""
-#: ../imagery/i.rectify/report.c:10
-#, fuzzy
-msgid "complete"
-#: ../imagery/i.rectify/report.c:10 ../db/db.select/main.c:92
-#, fuzzy
-msgid "failed"
-msgstr "नक़ल"
-#: ../imagery/i.rectify/report.c:20
-#, c-format
-msgid "%d rows, %d cols (%ld cells) completed in"
-msgstr ""
-#: ../imagery/i.rectify/report.c:23
-#, c-format
-msgid "%d:%02d:%02ld hours"
-msgstr ""
-#: ../imagery/i.rectify/report.c:25
-#, c-format
-msgid "%d:%02ld minutes"
-msgstr ""
-#: ../imagery/i.rectify/report.c:27
-#, c-format
-msgid "%.1f cells per minute"
-msgstr ""
-#: ../imagery/i.rectify/get_wind.c:112
-#, c-format
-msgid "Region N=%f S=%f E=%f W=%f"
-msgstr ""
-#: ../imagery/i.rectify/get_wind.c:114
-#, c-format
-msgid "Resolution EW=%f NS=%f"
-msgstr ""
-#: ../imagery/i.rectify/cp.c:15 ../vector/v.rectify/cp.c:327
-#, fuzzy, c-format
-msgid "Control Point file for group <%s@%s> - "
-msgstr "फ़ाइल"
-#: ../imagery/i.rectify/cp.c:21 ../vector/v.rectify/cp.c:336
-#, fuzzy, c-format
-msgid "Not enough active control points for current order, %d are required."
-msgstr "के लिए"
-#: ../imagery/i.rectify/cp.c:25 ../vector/v.rectify/cp.c:340
-#, fuzzy
-msgid "Poorly placed control points."
-msgstr "घुमाएँ"
-#: ../imagery/i.rectify/cp.c:26 ../vector/v.rectify/cp.c:341
-#, fuzzy
-msgid " Can not generate the transformation equation."
-msgstr "के लिए"
-#: ../imagery/i.rectify/cp.c:29 ../vector/v.rectify/cp.c:344
-#, fuzzy
-msgid "Not enough memory to solve for transformation equation"
-msgstr "के लिए"
-#: ../imagery/i.rectify/cp.c:32 ../vector/v.rectify/cp.c:347
-#, fuzzy
-msgid "Invalid order"
-msgstr "के लिए"
-#: ../imagery/i.rectify/target.c:14 ../vector/v.rectify/target.c:15
-#, fuzzy, c-format
-msgid "Target information for group <%s> missing"
-#: ../imagery/i.rectify/target.c:20 ../vector/v.rectify/target.c:26
-#, fuzzy, c-format
-msgid "Target location <%s> not found"
-msgstr "नहीं"
-#: ../imagery/i.rectify/target.c:35 ../vector/v.rectify/target.c:40
-msgid "Please run i.target for group."
-msgstr ""
-#: ../imagery/i.target/main.c:48
-#, fuzzy
-msgid "Targets an imagery group to a GRASS location and mapset."
-msgstr "समूह a."
-#: ../imagery/i.target/main.c:57
-#, fuzzy
-msgid "Name of imagery target location"
-msgstr "का"
-#: ../imagery/i.target/main.c:63
-#, fuzzy
-msgid "Name of target mapset"
-msgstr "का"
-#: ../imagery/i.target/main.c:68
-#, fuzzy
-msgid "Set current location and mapset as target for of imagery group"
-msgstr "सेट के लिए का समूह"
-#: ../imagery/i.target/main.c:90 ../imagery/i.target/main.c:107
-#: ../imagery/i.target/main.c:116
-#, fuzzy, c-format
-msgid "Group <%s> targeted for location [%s], mapset [%s]"
-#: ../imagery/i.target/main.c:93
-#, c-format
-msgid "Group <%s> has no target"
-msgstr ""
-#: ../imagery/i.target/main.c:101
-#, fuzzy
-msgid ""
-"Use either the Current Mapset and Location Flag (-c)\n"
-" OR\n"
-" manually enter the variables"
-msgstr ""
-"ध्वज\n"
-"\n"
-#: ../imagery/i.vpoints/plot.c:56 ../imagery/i.vpoints/plot.c:126
-#: ../display/d.graph/do_graph.c:377
-msgid "Cannot read symbol, cannot display points"
-msgstr ""
-#: ../imagery/i.vpoints/main.c:97
-msgid "Set registration points for an imagery group from a vector map or keyboard entry."
-msgstr ""
-#: ../imagery/i.albedo/main.c:89 ../imagery/i.eb.netrad/main.c:65
-#: ../imagery/i.eb.netrad/main.c:67
-#, fuzzy
-msgid "albedo"
-msgstr "नक़ल"
-#: ../imagery/i.albedo/main.c:90
-#, fuzzy
-msgid "surface reflectance"
-msgstr "आइसोसरफेस"
-#: ../imagery/i.albedo/main.c:91
-#, fuzzy
-msgid "Computes broad band albedo from surface reflectance."
-msgstr "का"
-#: ../imagery/i.albedo/main.c:104
-msgid "Modis (7 input bands:1,2,3,4,5,6,7)"
-msgstr ""
-#: ../imagery/i.albedo/main.c:108
-msgid "NOAA AVHRR (2 input bands:1,2)"
-msgstr ""
-#: ../imagery/i.albedo/main.c:112
-msgid "Landsat (6 input bands:1,2,3,4,5,7)"
-msgstr ""
-#: ../imagery/i.albedo/main.c:116
-msgid "Aster (6 input bands:1,3,5,6,8,9)"
-msgstr ""
-#: ../imagery/i.albedo/main.c:120
-msgid "Agressive mode (Landsat)"
-msgstr ""
-#: ../imagery/i.albedo/main.c:122 ../imagery/i.albedo/main.c:129
-msgid "Albedo dry run to calculate some water to beach/sand/desert stretching, a kind of simple atmospheric correction"
-msgstr ""
-#: ../imagery/i.albedo/main.c:127
-msgid "Soft mode (Modis)"
-msgstr ""
-#: ../imagery/i.albedo/main.c:164
-#, fuzzy
-msgid "At least two raster maps are required"
-msgstr "शीर्षक"
-#: ../imagery/i.ifft/main.c:78 ../imagery/i.fft/main.c:79
-msgid "FFT"
-msgstr ""
-#: ../imagery/i.ifft/main.c:80
-#, fuzzy
-msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
-msgstr "के लिए छवि."
-#: ../imagery/i.ifft/main.c:85
-#, fuzzy
-msgid "Name of input raster map (image fft, real part)"
-msgstr "छवि भाग"
-#: ../imagery/i.ifft/main.c:89
-#, fuzzy
-msgid "Name of input raster map (image fft, imaginary part"
-msgstr "छवि भाग"
-#: ../imagery/i.ifft/main.c:115
-#, fuzzy
-msgid "The real and imaginary original windows did not match"
-msgstr "असली नहीं जोड़ा."
-#: ../imagery/i.ifft/main.c:141 ../imagery/i.gensigset/read_data.c:22
-#: ../imagery/i.cluster/main.c:276
-#, fuzzy
-msgid "Reading raster maps..."
-msgstr "n"
-#: ../imagery/i.ifft/main.c:157
-#, fuzzy
-msgid "Masking raster maps..."
-msgstr "n"
-#: ../imagery/i.ifft/main.c:191 ../imagery/i.fft/main.c:166
-msgid "Rotating data..."
-msgstr ""
-#: ../imagery/i.ifft/main.c:200
-msgid "Starting Inverse FFT..."
-msgstr ""
-#: ../imagery/i.fft/main.c:81
-#, fuzzy
-msgid "Fast Fourier Transform (FFT) for image processing."
-#: ../imagery/i.fft/main.c:90
-#, fuzzy
-msgid "Name for output real part arrays stored as raster map"
-msgstr "भाग"
-#: ../imagery/i.fft/main.c:94
-#, fuzzy
-msgid "Name for output imaginary part arrays stored as raster map"
-msgstr "भाग"
-#: ../imagery/i.fft/main.c:106
-msgid "Raster MASK found, consider to remove (see man-page). Will continue..."
-msgstr ""
-#: ../imagery/i.fft/main.c:129
-#, fuzzy, c-format
-msgid "Reading the raster map <%s>..."
-msgstr "n"
-#: ../imagery/i.fft/main.c:145
-msgid "Starting FFT..."
-msgstr ""
-#: ../imagery/i.fft/main.c:174
-#, fuzzy
-msgid "Writing transformed data..."
-msgstr "n"
-#: ../imagery/i.fft/main.c:200
-msgid " "
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:117
-msgid "QC"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:118
-msgid "Quality Control"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:119
-#, fuzzy
-msgid "Surface Reflectance"
-msgstr "आइसोसरफेस"
-#: ../imagery/i.modis.qc/main.c:120
-msgid "Land Surface Temperature"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:121
-#, fuzzy
-msgid "Vegetation"
-msgstr "नहीं n"
-#: ../imagery/i.modis.qc/main.c:122
-msgid "Modis"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:124
-#, fuzzy
-msgid "Extract quality control parameters from Modis QC layers."
-msgstr "i n"
-#: ../imagery/i.modis.qc/main.c:131
-#, fuzzy
-msgid "Name of MODIS product type"
-msgstr "का"
-#: ../imagery/i.modis.qc/main.c:132
-msgid "mod09Q1;surf. refl. 250m 8-days;mod09A1;surf. refl. 500m 8-days;mod09A1s;surf. refl. 500m 8-days, State QA;mod11A1;LST 1Km daily (Day/Night);mod11A2;LST 1Km 8-days (Day/Night);mod13A2;VI 1Km 16-days;mcd43B2;Brdf-Albedo Quality (Ancillary SDS) 1Km 8-days;mcd43B2q;Brdf-Albedo Quality (BRDF SDS) 1Km 8-days;"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:147
-#, fuzzy
-msgid "Name of QC type to extract"
-msgstr "का."
-#: ../imagery/i.modis.qc/main.c:148
-msgid "adjcorr;mod09: Adjacency Correction;atcorr;mod09: Atmospheric Correction;cloud;mod09: Cloud State;data_quality;mod09: Band-Wise Data Quality Flag;diff_orbit_from_500m;mod09: 250m Band is at Different Orbit than 500m;modland_qa;mod09: MODIS Land General Quality Assessment;mandatory_qa_11A1;mod11A1: MODIS Land General Quality Assessment;data_quality_flag_11A1;mod11A1: Detailed Quality Indications;emis_error_11A1;mod11A1: Average Emissivity Error Classes;lst_error_11A1;mod11A1: Average LST Error Classes;data_quality_flag_11A2;mod11A2: Detailed Quality Indications;emis_error_11A2;mod11A2: Average Emissivity Error Classes;mandatory_qa_11A2;mod11A2: MODIS Land General Quality Assessment;lst_error_11A2;mod11A2: Average LST Error Classes;aerosol_quantity;mod09A1s: StateQA Internal Snow Maskbrdf_correction_performed;mod09A1s: StateQA Internal Snow Maskcirrus_detected;mod09A1s: StateQA Internal Snow Maskcloud_shadow;mod09A1s: StateQA Internal Snow Maskcloud_state;mod09A1s: Stat
 eQA Internal Snow Maskinternal_cloud_algorithm;mod09A1s: StateQA Internal Snow Maskinternal_fire_algorithm;mod09A1s: StateQA Internal Snow Maskinternal_snow_mask;mod09A1s: StateQA Internal Snow Maskland_water;mod09A1s: StateQA Internal Snow Maskmod35_snow_ice;mod09A1s: StateQA Internal Snow Maskpixel_adjacent_to_cloud;mod09A1s: StateQA Internal Snow Maskmodland_qa;mod13A2: MODIS Land General Quality Assessmentvi_usefulness;mod13A2: Quality estimation of the pixelaerosol_quantity;mod13A2: Quantity range of Aerosolpixel_adjacent_to_cloud;mod13A2: if pixel is a cloud neighbourbrdf_correction_performed;mod13A2: if BRDF correction performedmixed_clouds;mod13A2: if pixel mixed with cloudsland_water;mod13A2: separate land from various water objectspossible_snow_ice;mod13A2: if snow/ice present in pixelpossible_shadow;mod13A2: if shadow is present in pixelplatform;mcd43B2: Quality of BRDF correction performedland_water;mcd43B2: Quality of BRDF correction performedsun_z_angle_at_loca
 l_noon;mcd43B2: Quality of BRDF correction performedbrdf_correction_performed;mcd43B2q: Quality of BRDF correction performed"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:191
-#, fuzzy
-msgid "Name of the input QC layer [bit array]"
-msgstr "का"
-#: ../imagery/i.modis.qc/main.c:199
-msgid "Band number of Modis product mod09Q1=[1,2],mod09A1=[1-7], mcd43B2q=[1-7]"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:200
-msgid "1;Band 1: Red;2;Band 2: NIR;3;Band 3: Blue;4;Band 4: Green;5;Band 5: SWIR 1;6;Band 6: SWIR 2;7;Band 7: SWIR 3;"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:211
-#, fuzzy
-msgid "Name of the output QC type classification layer"
-msgstr "का"
-#: ../imagery/i.modis.qc/main.c:229
-msgid "This flag is only available for MOD09Q1 @ 250m products"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:233 ../imagery/i.modis.qc/main.c:263
-#, fuzzy
-msgid "Band number out of allowed range [1-7]"
-msgstr "का फ्रेम्स"
-#: ../imagery/i.modis.qc/main.c:235
-msgid "mod09Q1 product only has 2 bands"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:246
-msgid "This flag is only available for MOD09A1s @ 500m products"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:253
-msgid "This flag is only available for MOD13A2 @ 1Km products"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:259
-msgid "This flag is only available for MCD43B2 @ 1Km products"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:448
-msgid "Unknown names and/or combination, please check spelling"
-msgstr ""
-#: ../imagery/i.sunhours/main.c:46
-msgid "sunshine"
-msgstr ""
-#: ../imagery/i.sunhours/main.c:47
-msgid "hours"
-msgstr ""
-#: ../imagery/i.sunhours/main.c:48
-msgid "daytime"
-msgstr ""
-#: ../imagery/i.sunhours/main.c:49
-#, fuzzy
-msgid "Creates a sunshine hours map."
-#: ../imagery/i.sunhours/main.c:53 ../imagery/i.eb.netrad/main.c:104
-msgid "dayofyear"
-msgstr ""
-#: ../imagery/i.sunhours/main.c:54
-#, fuzzy
-msgid "Name of the day of year input map"
-msgstr "का"
-#: ../imagery/i.sunhours/main.c:58
-#, fuzzy
-msgid "Name of the latitude input map"
-msgstr "का"
-#: ../imagery/i.sunhours/main.c:61
-#, fuzzy
-msgid "Name of the output sunshine hours map"
-msgstr "का"
-#: ../imagery/i.gensigset/main.c:45
-#, fuzzy
-msgid "Generates statistics for i.smap from raster map."
-msgstr "के लिए i."
-#: ../imagery/i.gensigset/main.c:55
-#, fuzzy, c-format
-msgid "Clustering class %d (%d pixels)..."
-msgstr "n"
-#: ../imagery/i.gensigset/main.c:58
-#, fuzzy, c-format
-msgid "Number of subclasses is %d"
-msgstr "का"
-#: ../imagery/i.gensigset/parse.c:27
-#, fuzzy
-msgid "Maximum number of sub-signatures in any class"
-msgstr "संख्या का"
-#: ../imagery/i.gensigset/parse.c:52
-#, fuzzy, c-format
-msgid "Illegal number of sub-signatures (%s)"
-msgstr "संख्या का"
-#: ../imagery/i.gensigset/subcluster.c:76
-#, fuzzy, c-format
-msgid "Not enough pixels in class %d"
-msgstr "ज़ेड"
-#: ../imagery/i.gensigset/subcluster.c:86
-#, fuzzy, c-format
-msgid "Too many subclasses for class index %d"
-msgstr "n"
-#: ../imagery/i.gensigset/subcluster.c:88
-#, fuzzy, c-format
-msgid "Number of subclasses set to %d"
-msgstr "का"
-#: ../imagery/i.gensigset/subcluster.c:106
-#, c-format
-msgid "Combining subclasses (%d,%d)..."
-msgstr ""
-#: ../imagery/i.gensigset/subcluster.c:318
-#, c-format
-msgid "Subsignature %d only contains %.0f pixels"
-msgstr ""
-#: ../imagery/i.gensigset/subcluster.c:552
-msgid "Unreliable clustering. Try a smaller initial number of clusters"
-msgstr ""
-#: ../imagery/i.gensigset/subcluster.c:561
-#, c-format
-msgid "Removed a singular subsignature number %d (%d remain)"
-msgstr ""
-#: ../imagery/i.emissivity/main.c:44 ../imagery/i.eb.netrad/main.c:93
-#: ../imagery/i.eb.netrad/main.c:95
-msgid "emissivity"
-msgstr ""
-#: ../imagery/i.emissivity/main.c:45
-msgid "land flux"
-msgstr ""
-#: ../imagery/i.emissivity/main.c:48
-msgid "Computes emissivity from NDVI, generic method for spares land."
-msgstr ""
-#: ../imagery/i.emissivity/main.c:52
-#, fuzzy
-msgid "Name of the NDVI map [-]"
-msgstr "का"
-#: ../imagery/i.emissivity/main.c:55
-#, fuzzy
-msgid "Name of the output emissivity layer"
-msgstr "का"
-#: ../imagery/i.cca/main.c:86
-msgid "CCA"
-msgstr ""
-#: ../imagery/i.cca/main.c:88
-#, fuzzy
-msgid "Canonical components analysis (cca) program for image processing."
-msgstr "प्रोग्राम के लिए छवि."
-#: ../imagery/i.cca/main.c:102
-#, fuzzy
-msgid "File containing spectral signatures"
-msgstr "फ़ाइल"
-#: ../imagery/i.cca/main.c:105
-msgid "Output raster map prefix name"
-msgstr ""
-#: ../imagery/i.cca/main.c:113
-#, fuzzy
-msgid "Unknown imagery group."
-msgstr "समूह."
-#: ../imagery/i.cca/main.c:116
-msgid "Unable to find subgroup reference information."
-msgstr ""
-#: ../imagery/i.cca/main.c:122
-#, fuzzy
-msgid "Unable to open the signature file"
-#: ../imagery/i.cca/main.c:126
-#, fuzzy
-msgid "Error while reading the signatures file."
-msgstr "त्रुटि."
-#: ../imagery/i.cca/main.c:131
-#, fuzzy
-msgid "Need at least two signatures in signature file."
-msgstr "पर दो."
-#: ../imagery/i.cca/main.c:225
-#, fuzzy, c-format
-msgid "The output cell map <%s.%d> has values outside the 0-255 range."
-msgstr "n"
-#: ../imagery/i.cca/transform.c:24
-msgid "Unable to allocate cell buffers."
-msgstr ""
-#: ../imagery/i.cca/transform.c:58
-#, fuzzy
-msgid "Transform completed.\n"
-msgstr "पूर्ण n"
-#: ../imagery/i.cluster/print1.c:12
-#, fuzzy, c-format
-msgid ""
-"means and standard deviations for %d band%s\n"
-"\n"
-msgstr "के लिए n n"
-#: ../imagery/i.cluster/print1.c:14
-#, c-format
-msgid " means  "
-msgstr ""
-#: ../imagery/i.cluster/print1.c:18
-#, c-format
-msgid " stddev "
-msgstr ""
-#: ../imagery/i.cluster/print4.c:16
-#, fuzzy, c-format
-msgid "class centroids (sum/count=mean)\n"
-msgstr "n"
-#: ../imagery/i.cluster/print4.c:18
-#, c-format
-msgid "band %d"
-msgstr ""
-#: ../imagery/i.cluster/print6.c:11
-#, fuzzy, c-format
-msgid "class distribution"
-msgstr "वितरण"
-#: ../imagery/i.cluster/print3.c:16
-#, fuzzy, c-format
-msgid ""
-"\n"
-"initial means for each band\n"
-"\n"
-#: ../imagery/i.cluster/print3.c:19
-#, c-format
-msgid "class %-3d "
-msgstr ""
-#: ../imagery/i.cluster/checkpt.c:16
-#, fuzzy, c-format
-msgid "using seed means (%d files)\n"
-msgstr "n"
-#: ../imagery/i.cluster/checkpt.c:28
-#, fuzzy, c-format
-msgid ""
-"\n"
-"######## iteration %d ###########\n"
-msgstr "n n"
-#: ../imagery/i.cluster/checkpt.c:30
-#, fuzzy, c-format
-msgid "%d classes, %.2f%% points stable\n"
-msgstr "n"
-#: ../imagery/i.cluster/checkpt.c:40
-#, fuzzy, c-format
-msgid "Iteration %.2d: convergence %.2f%% (%s elapsed, %s left)"
-msgstr "बायाँ"
-#: ../imagery/i.cluster/print2.c:18
-#, fuzzy, c-format
-msgid ""
-"\n"
-"class means/stddev for each band\n"
-"\n"
-#: ../imagery/i.cluster/print2.c:22
-#, fuzzy, c-format
-msgid "class %d (%d)\n"
-msgstr "n"
-#: ../imagery/i.cluster/print2.c:23
-#, c-format
-msgid "  means "
-msgstr ""
-#: ../imagery/i.cluster/print2.c:28
-#, c-format
-msgid "  stddev"
-msgstr ""
-#: ../imagery/i.cluster/open_files.c:34
-#, fuzzy, c-format
-msgid "Raster map <%s> do not exists in subgroup <%s>"
-msgstr "समूह."
-#: ../imagery/i.cluster/open_files.c:39
-#, fuzzy
-msgid "No raster maps found"
-msgstr "नहीं n"
-#: ../imagery/i.cluster/open_files.c:43
-#, fuzzy, c-format
-msgid "Subgroup <%s> doesn't have any raster maps"
-msgstr "समूह."
-#: ../imagery/i.cluster/open_files.c:46
-#, fuzzy, c-format
-msgid "Subgroup <%s> only has 1 raster map"
-msgstr "का"
-#: ../imagery/i.cluster/open_files.c:47
-#, fuzzy
-msgid "Subgroup must have at least 2 raster maps"
-msgstr "पर"
-#: ../imagery/i.cluster/open_files.c:64
-#, fuzzy, c-format
-msgid "Unable to open seed signature file <%s>"
-msgstr "के लिए"
-#: ../imagery/i.cluster/main.c:77
-#, fuzzy
-msgid "signatures"
-msgstr "विशेषता"
-#: ../imagery/i.cluster/main.c:79
-msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm."
-msgstr ""
-#: ../imagery/i.cluster/main.c:82
-#, fuzzy
-msgid "The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification."
-msgstr "फंक्शन के लिए कवर छवि a है के लिए i छवि."
-#: ../imagery/i.cluster/main.c:101
-#, fuzzy
-msgid "Initial number of classes"
-msgstr "संख्या का"
-#: ../imagery/i.cluster/main.c:109
-#, fuzzy
-msgid "Name of file containing initial signatures"
-msgstr "फ़ाइल"
-#: ../imagery/i.cluster/main.c:117
-#, fuzzy
-msgid "Sampling intervals (by row and col); default: ~10,000 pixels"
-msgstr "पिक्सेल्स"
-#: ../imagery/i.cluster/main.c:124
-#, fuzzy
-msgid "Maximum number of iterations"
-msgstr "संख्या का"
-#: ../imagery/i.cluster/main.c:133
-msgid "Percent convergence"
-msgstr ""
-#: ../imagery/i.cluster/main.c:141
-msgid "Cluster separation"
-msgstr ""
-#: ../imagery/i.cluster/main.c:149
-#, fuzzy
-msgid "Minimum number of pixels in a class"
-msgstr "संख्या का पिक्सेल्स a"
-#: ../imagery/i.cluster/main.c:156
-#, fuzzy
-msgid "Name for output file containing final report"
-#: ../imagery/i.cluster/main.c:175
-#, fuzzy, c-format
-msgid "Illegal number of initial classes (%s)"
-msgstr "n संख्या का"
-#: ../imagery/i.cluster/main.c:186
-#, fuzzy, c-format
-msgid "Illegal value(s) of sample intervals (%s)"
-msgstr "n का"
-#: ../imagery/i.cluster/main.c:200
-#, fuzzy, c-format
-msgid "Illegal value of iterations (%s>)"
-msgstr "n का"
-#: ../imagery/i.cluster/main.c:206
-#, fuzzy, c-format
-msgid "Illegal value of convergence (%s)"
-msgstr "n का"
-#: ../imagery/i.cluster/main.c:211
-#, fuzzy, c-format
-msgid "Illegal value of separation (%s)"
-msgstr "n का"
-#: ../imagery/i.cluster/main.c:216
-#, fuzzy, c-format
-msgid "Illegal value of min_size (%s)"
-msgstr "के लिए"
-#: ../imagery/i.cluster/main.c:225
-#, fuzzy, c-format
-msgid "Unable to create report file <%s>"
-msgstr "बनाया जा रहा है."
-#: ../imagery/i.cluster/main.c:233
-#, fuzzy, c-format
-msgid ""
-"#################### CLUSTER (%s) ####################\n"
-"\n"
-msgstr "n n"
-#: ../imagery/i.cluster/main.c:235
-#, fuzzy, c-format
-msgid "Location: %s\n"
-msgstr "n"
-#: ../imagery/i.cluster/main.c:236
-#, fuzzy, c-format
-msgid "Mapset:   %s\n"
-msgstr "n"
-#: ../imagery/i.cluster/main.c:237
-#, fuzzy, c-format
-msgid "Group:    %s\n"
-msgstr "n"
-#: ../imagery/i.cluster/main.c:238
-#, fuzzy, c-format
-msgid "Subgroup: %s\n"
-msgstr "n"
-#: ../imagery/i.cluster/main.c:240
-#, fuzzy, c-format
-msgid " %s\n"
-msgstr "n"
-#: ../imagery/i.cluster/main.c:243
-#, fuzzy, c-format
-msgid "Result signature file: %s\n"
-msgstr "n"
-#: ../imagery/i.cluster/main.c:245
-#, fuzzy, c-format
-msgid "Region\n"
-msgstr "n"
-#: ../imagery/i.cluster/main.c:246
-#, fuzzy, c-format
-msgid "  North: %12.2f  East: %12.2f\n"
-msgstr "पूर्व n"
-#: ../imagery/i.cluster/main.c:248
-#, fuzzy, c-format
-msgid "  South: %12.2f  West: %12.2f\n"
-msgstr "पश्चिम n"
-#: ../imagery/i.cluster/main.c:250
-#, fuzzy, c-format
-msgid "  Res:   %12.2f  Res:  %12.2f\n"
-msgstr "n"
-#: ../imagery/i.cluster/main.c:252
-#, fuzzy, c-format
-msgid "  Rows:  %12d  Cols: %12d  Cells: %d\n"
-msgstr "n"
-#: ../imagery/i.cluster/main.c:254
-#, fuzzy, c-format
-msgid "Mask: %s\n"
-msgstr "n"
-#: ../imagery/i.cluster/main.c:256
-#, fuzzy, c-format
-msgid "Cluster parameters\n"
-msgstr "n"
-#: ../imagery/i.cluster/main.c:257
-#, fuzzy, c-format
-msgid " Number of initial classes:    %d"
-msgstr "का"
-#: ../imagery/i.cluster/main.c:259
-#, c-format
-msgid " [from signature file %s]"
-msgstr ""
-#: ../imagery/i.cluster/main.c:261
-#, fuzzy, c-format
-msgid " Minimum class size:           %d\n"
-msgstr "आकार  n"
-#: ../imagery/i.cluster/main.c:262
-#, fuzzy, c-format
-msgid " Minimum class separation:     %f\n"
-msgstr "f n"
-#: ../imagery/i.cluster/main.c:263
-#, fuzzy, c-format
-msgid " Percent convergence:          %f\n"
-msgstr "f n"
-#: ../imagery/i.cluster/main.c:264
-#, fuzzy, c-format
-msgid " Maximum number of iterations: %d\n"
-msgstr "संख्या का n"
-#: ../imagery/i.cluster/main.c:266
-#, fuzzy, c-format
-msgid " Row sampling interval:        %d\n"
-msgstr "n"
-#: ../imagery/i.cluster/main.c:267
-#, fuzzy, c-format
-msgid " Col sampling interval:        %d\n"
-msgstr "n"
-#: ../imagery/i.cluster/main.c:286
-#, fuzzy
-msgid "Out of Memory. Please run again and choose a smaller sample size."
-msgstr "का a आकार "
-#: ../imagery/i.cluster/main.c:292
-#, fuzzy, c-format
-msgid "Sample size: %d points\n"
-msgstr "आकार  n"
-#: ../imagery/i.cluster/main.c:295
-#, fuzzy
-msgid "Not enough sample points. Please run again and choose a larger sample size."
-msgstr "a आकार "
-#: ../imagery/i.cluster/main.c:299
-msgid "Not enough non-zero sample data points. Check your current region (and mask)."
-msgstr ""
-#: ../imagery/i.cluster/main.c:312
-#, fuzzy, c-format
-msgid ""
-"\n"
-"########## final results #############\n"
-msgstr "n n"
-#: ../imagery/i.cluster/main.c:313
-#, fuzzy, c-format
-msgid "%d classes (convergence=%.1f%%)\n"
-msgstr "n"
-#: ../imagery/i.cluster/main.c:324
-#, fuzzy, c-format
-msgid "Unable to create signature file <%s> for group <%s>, subsgroup <%s>"
-msgstr "नहीं के लिए समूह"
-#: ../imagery/i.cluster/main.c:329
-#, fuzzy, c-format
-msgid ""
-"\n"
-"\n"
-"#################### CLASSES ####################\n"
-msgstr "n n n"
-#: ../imagery/i.cluster/main.c:330
-#, fuzzy, c-format
-msgid ""
-"\n"
-"%d classes, %.2f%% points stable\n"
-msgstr "n n"
-#: ../imagery/i.cluster/main.c:332
-#, fuzzy, c-format
-msgid ""
-"\n"
-"######## CLUSTER END (%s) ########\n"
-msgstr "n n"
-#: ../imagery/i.cluster/print5.c:15
-#, fuzzy, c-format
-msgid ""
-"\n"
-"class separability matrix\n"
-"\n"
-msgstr "माट्रिक्स n n"
-#: ../imagery/i.biomass/main.c:51
-msgid "biomass"
-msgstr ""
-#: ../imagery/i.biomass/main.c:52
-msgid "fpar"
-msgstr ""
-#: ../imagery/i.biomass/main.c:53
-msgid "yield"
-msgstr ""
-#: ../imagery/i.biomass/main.c:55
-msgid "Computes biomass growth, precursor of crop yield calculation."
-msgstr ""
-#: ../imagery/i.biomass/main.c:60
-#, fuzzy
-msgid "Name of fPAR raster map"
-msgstr "का"
-#: ../imagery/i.biomass/main.c:65
-#, fuzzy
-msgid "Name of light use efficiency raster map (UZB:cotton=1.9)"
-msgstr "का"
-#: ../imagery/i.biomass/main.c:69
-#, fuzzy
-msgid "Name of degree latitude raster map [dd.ddd]"
-msgstr "का"
-#: ../imagery/i.biomass/main.c:73
-#, fuzzy
-msgid "Name of Day of Year raster map [1-366]"
-msgstr "का"
-#: ../imagery/i.biomass/main.c:78
-#, fuzzy
-msgid "Name of single-way transmissivity raster map [0.0-1.0]"
-msgstr "का"
-#: ../imagery/i.biomass/main.c:83
-#, fuzzy
-msgid "Value of water availability raster map [0.0-1.0]"
-msgstr "का"
-#: ../imagery/i.biomass/main.c:87
-#, fuzzy
-msgid "Name for output daily biomass growth raster map [kg/ha/d]"
-msgstr "का"
-#: ../imagery/i.eb.netrad/main.c:58
-#, fuzzy
-msgid "net radiation"
-msgstr "n"
-#: ../imagery/i.eb.netrad/main.c:61
-msgid "Net radiation approximation (Bastiaanssen, 1995)."
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:66
-#, fuzzy
-msgid "Name of the Albedo map [0.0;1.0]"
-msgstr "का"
-#: ../imagery/i.eb.netrad/main.c:70 ../imagery/i.eb.netrad/main.c:72
-msgid "ndvi"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:71
-#, fuzzy
-msgid "Name of the ndvi map [-1.0;+1.0]"
-msgstr "का."
-#: ../imagery/i.eb.netrad/main.c:77
-#, fuzzy
-msgid "Name of the Surface temperature map [degree Kelvin]"
-msgstr "का"
-#: ../imagery/i.eb.netrad/main.c:78
-msgid "tempk"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:81
-msgid "localutctime"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:83
-#, fuzzy
-msgid "Name of the map of local UTC time of satellite overpass [hh.hhh]"
-msgstr "का"
-#: ../imagery/i.eb.netrad/main.c:84
-#: ../locale/scriptstrings/t.time.abs_to_translate.c:2
-#: ../locale/scriptstrings/t.time.rel_to_translate.c:2
-#, fuzzy
-msgid "time"
-msgstr "n"
-#: ../imagery/i.eb.netrad/main.c:87
-#, fuzzy
-msgid "temperaturedifference2m"
-msgstr "विशेषता"
-#: ../imagery/i.eb.netrad/main.c:89
-msgid "Name of the difference of temperature from surface skin to about 2 m height [K]"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:90
-msgid "dtair"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:94
-#, fuzzy
-msgid "Name of the emissivity map [-]"
-msgstr "का"
-#: ../imagery/i.eb.netrad/main.c:98
-msgid "transmissivitysingleway"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:100
-#, fuzzy
-msgid "Name of the single-way atmospheric transmissivitymap [-]"
-msgstr "का"
-#: ../imagery/i.eb.netrad/main.c:101
-msgid "tsw"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:105
-#, fuzzy
-msgid "Name of the Day Of Year (DOY) map [-]"
-msgstr "का"
-#: ../imagery/i.eb.netrad/main.c:106
-msgid "doy"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:109
-msgid "sunzenithangle"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:110
-#, fuzzy
-msgid "Name of the sun zenith angle map [degrees]"
-msgstr "का कोण"
-#: ../imagery/i.eb.netrad/main.c:111
-msgid "sunzangle"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:114
-#, fuzzy
-msgid "Name of the output net radiation layer"
-msgstr "का"
-#: ../imagery/i.find/main.c:63
-#, c-format
-msgid "usage: %s location mapset element file."
-msgstr ""
-#: ../imagery/i.find/main.c:83
-#, fuzzy
-msgid "Unable to open temp file."
-msgstr "का"
-#: ../imagery/i.eb.evapfr/main.c:53
-msgid "Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil moisture (Makin, Molden and Bastiaanssen, 2001)."
-msgstr ""
-#: ../imagery/i.eb.evapfr/main.c:59 ../imagery/i.eb.soilheatflux/main.c:71
-#, fuzzy
-msgid "Name of Net Radiation raster map [W/m2]"
-msgstr "का"
-#: ../imagery/i.eb.evapfr/main.c:63
-#, fuzzy
-msgid "Name of soil heat flux raster map [W/m2]"
-msgstr "का"
-#: ../imagery/i.eb.evapfr/main.c:67
-#, fuzzy
-msgid "Name of sensible heat flux raster map [W/m2]"
-msgstr "का"
-#: ../imagery/i.eb.evapfr/main.c:72
-#, fuzzy
-msgid "Name for output evaporative fraction raster map"
-msgstr "का"
-#: ../imagery/i.eb.evapfr/main.c:78
-#, fuzzy
-msgid "Name for output root zone soil moisture raster map"
-msgstr "का"
-#: ../imagery/i.eb.evapfr/main.c:83
-msgid "Root zone soil moisture output (Makin, Molden and Bastiaanssen, 2001)"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:79
-msgid "Computes temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s)."
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:86
-#, fuzzy
-msgid "Names of satellite ETa raster maps [mm/d or cm/d]"
-msgstr "का"
-#: ../imagery/i.evapo.time/main.c:91
-msgid "Names of satellite ETa Day of Year (DOY) raster maps [0-400] [-]"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:96
-#, fuzzy
-msgid "Names of meteorological station ETo raster maps [0-400] [mm/d or cm/d]"
-msgstr "का"
-#: ../imagery/i.evapo.time/main.c:102
-msgid "Value of DOY for ETo first day"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:108
-msgid "Value of DOY for the first day of the period studied"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:114
-msgid "Value of DOY for the last day of the period studied"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:142
-msgid "The DOY for end_period can not be smaller than start_period"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:146
-msgid "The DOY for start_period can not be smaller than eto_doy_min"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:151
-#, fuzzy, c-format
-msgid "Too many ETa files. Only %d allowed."
-msgstr "सीमा कम के बराबर नहीं."
-#: ../imagery/i.evapo.time/main.c:162 ../imagery/i.evapo.time/main.c:178
-#: ../imagery/i.evapo.time/main.c:200
-#, fuzzy
-msgid "The min specified input map is two"
-#: ../imagery/i.evapo.time/main.c:167
-#, fuzzy, c-format
-msgid "Too many ETa_doy files. Only %d allowed."
-#: ../imagery/i.evapo.time/main.c:183
-msgid "ETa and ETa_DOY file numbers are not equal!"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:189
-#, fuzzy, c-format
-msgid "Too many ETo files. Only %d allowed."
-#: ../imagery/i.pca/support.c:44
-msgid "Eigen values, (vectors), and [percent importance]:"
-msgstr ""
-#: ../imagery/i.pca/main.c:68
-#, fuzzy
-msgid "image transformation"
-msgstr "संख्या के लिए"
-#: ../imagery/i.pca/main.c:69
-msgid "PCA"
-msgstr ""
-#: ../imagery/i.pca/main.c:70
-#, fuzzy
-msgid "Principal components analysis (PCA) for image processing."
-#: ../imagery/i.pca/main.c:75
-#, fuzzy
-msgid "Name of two or more input raster maps"
-msgstr "का"
-#: ../imagery/i.pca/main.c:78
-#, fuzzy
-msgid "Base name for output raster maps"
-msgstr "का"
-#: ../imagery/i.pca/main.c:80
-#, fuzzy
-msgid "A numerical suffix will be added for each component map"
-msgstr "का के लिए"
-#: ../imagery/i.pca/main.c:93
-#, fuzzy
-msgid "Rescaling range for output maps"
-msgstr "का"
-#: ../imagery/i.pca/main.c:95
-msgid "For no rescaling use 0,0"
-msgstr ""
-#: ../imagery/i.pca/main.c:96
-msgid "Rescale"
-msgstr ""
-#: ../imagery/i.pca/main.c:100
-msgid "Normalize (center and scale) input maps"
-msgstr ""
-#: ../imagery/i.pca/main.c:110
-#, fuzzy
-msgid "Sorry, at least 2 input bands must be provided"
-msgstr "पर"
-#: ../imagery/i.pca/main.c:215
-msgid "Scale range length should be > 0. Using default values: 0,255."
-msgstr ""
-#: ../imagery/i.pca/main.c:261
-#, fuzzy
-msgid "Computing covariance matrix..."
-msgstr "माट्रिक्स."
-#: ../imagery/i.pca/main.c:370
-#, fuzzy, c-format
-msgid "Rescaling to range %d,%d..."
-msgstr "छवि "
-#: ../imagery/i.pca/main.c:378
-#, fuzzy
-msgid "Calculating principal components..."
-msgstr "n"
-#: ../imagery/i.rgb.his/main.c:51
-msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
-msgstr ""
-#: ../imagery/i.rgb.his/main.c:57
-#, fuzzy
-msgid "Name of input raster map (red)"
-msgstr "का"
-#: ../imagery/i.rgb.his/main.c:61
-#, fuzzy
-msgid "Name of input raster map (green)"
-msgstr "का"
-#: ../imagery/i.rgb.his/main.c:65
-#, fuzzy
-msgid "Name of input raster map (blue)"
-msgstr "का"
-#: ../imagery/i.rgb.his/main.c:69
-#, fuzzy
-msgid "Name for output raster map (hue)"
-msgstr "का"
-#: ../imagery/i.rgb.his/main.c:73
-#, fuzzy
-msgid "Name for output raster map (intensity)"
-msgstr "का"
-#: ../imagery/i.rgb.his/main.c:77
-#, fuzzy
-msgid "Name for output raster map (saturation)"
-msgstr "शीर्षक"
-#: ../imagery/i.evapo.pm/main.c:61
-msgid "Computes potential evapotranspiration calculation with hourly Penman-Monteith."
-msgstr ""
-#: ../imagery/i.evapo.pm/main.c:65
-#, fuzzy
-msgid "Name of input elevation raster map [m a.s.l.]"
-msgstr "का मीटर्स"
-#: ../imagery/i.evapo.pm/main.c:69
-#, fuzzy
-msgid "Name of input temperature raster map [C]"
-msgstr "का"
-#: ../imagery/i.evapo.pm/main.c:73
-#, fuzzy
-msgid "Name of input relative humidity raster map [%]"
-msgstr "का"
-#: ../imagery/i.evapo.pm/main.c:77
-#, fuzzy
-msgid "Name of input wind speed raster map [m/s]"
-msgstr "का"
-#: ../imagery/i.evapo.pm/main.c:82
-#, fuzzy
-msgid "Name of input net solar radiation raster map [MJ/m2/h]"
-msgstr "का"
-#: ../imagery/i.evapo.pm/main.c:86
-#, fuzzy
-msgid "Name of input crop height raster map [m]"
-msgstr "का"
-#: ../imagery/i.evapo.pm/main.c:89
-#, fuzzy
-msgid "Name for output raster map [mm/h]"
-msgstr "का"
-#: ../imagery/i.evapo.pm/main.c:93
-#, fuzzy
-msgid "Set negative evapotranspiration to zero"
-msgstr "का"
-#: ../imagery/i.evapo.pm/main.c:97
-msgid "Use Night-time"
-msgstr ""
-#: ../imagery/i.eb.soilheatflux/main.c:51
-msgid "soil heat flux"
-msgstr ""
-#: ../imagery/i.eb.soilheatflux/main.c:53
-msgid "Soil heat flux approximation (Bastiaanssen, 1995)."
-msgstr ""
-#: ../imagery/i.eb.soilheatflux/main.c:58
-#, fuzzy
-msgid "Name of Albedo raster map [0.0;1.0]"
-msgstr "का"
-#: ../imagery/i.eb.soilheatflux/main.c:62
-#, fuzzy
-msgid "Name of NDVI raster map [-1.0;+1.0]"
-msgstr "का."
-#: ../imagery/i.eb.soilheatflux/main.c:67
-#, fuzzy
-msgid "Name of Surface temperature raster map [K]"
-msgstr "का"
-#: ../imagery/i.eb.soilheatflux/main.c:76
-#, fuzzy
-msgid "Name of time of satellite overpass raster map [local time in UTC]"
-msgstr "का"
-#: ../imagery/i.eb.soilheatflux/main.c:83
-msgid "HAPEX-Sahel empirical correction (Roerink, 1995)"
-msgstr ""
-#: ../ps/ps.map/r_info.c:48 ../ps/ps.map/r_colortable.c:62
-#: ../ps/ps.map/r_vlegend.c:49
-#, fuzzy
-msgid "illegal where request"
-msgstr "पूर्व"
-#: ../ps/ps.map/r_info.c:67 ../ps/ps.map/ps_outline.c:87
-#: ../ps/ps.map/getgrid.c:61 ../ps/ps.map/getgrid.c:85
-#: ../ps/ps.map/getgrid.c:171 ../ps/ps.map/getgrid.c:195
-#: ../ps/ps.map/r_header.c:65
-#, fuzzy
-msgid "Unsupported color request"
-msgstr "n"
-#: ../ps/ps.map/r_info.c:69 ../ps/ps.map/r_instructions.c:131
-#: ../ps/ps.map/r_instructions.c:446 ../ps/ps.map/ps_outline.c:89
-#: ../ps/ps.map/getgrid.c:63 ../ps/ps.map/getgrid.c:87
-#: ../ps/ps.map/getgrid.c:173 ../ps/ps.map/getgrid.c:197
-#: ../ps/ps.map/r_header.c:67
-#, fuzzy
-msgid "illegal color request"
-msgstr "पूर्व"
-#: ../ps/ps.map/r_info.c:81
-msgid "illegal bgcolor request"
-msgstr ""
-#: ../ps/ps.map/r_info.c:93 ../ps/ps.map/r_vlegend.c:86
-#, fuzzy
-msgid "illegal border color request"
-msgstr "पूर्व"
-#: ../ps/ps.map/r_info.c:103
-msgid "illegal mapinfo sub-request"
-msgstr ""
-#: ../ps/ps.map/ps_vpoints.c:72 ../ps/ps.map/ps_vareas.c:164
-#: ../ps/ps.map/ps_vlines.c:56
-#, fuzzy
-msgid "Cannot load data from table"
-msgstr "सभी"
-#: ../ps/ps.map/ps_vpoints.c:88 ../ps/ps.map/do_plt.c:147
-msgid "Cannot read symbol, using default icon"
-msgstr ""
-#: ../ps/ps.map/ps_vpoints.c:128 ../ps/ps.map/ps_vareas.c:67
-#: ../ps/ps.map/ps_vareas.c:78 ../ps/ps.map/ps_vlines.c:84
-#, fuzzy
-msgid "Read error in vector map"
-msgstr "त्रुटि"
-#: ../ps/ps.map/ps_vpoints.c:165 ../ps/ps.map/ps_vpoints.c:176
-#: ../ps/ps.map/ps_vpoints.c:200 ../ps/ps.map/ps_vpoints.c:241
-#: ../ps/ps.map/ps_vpoints.c:251 ../ps/ps.map/ps_vareas.c:102
-#: ../ps/ps.map/ps_vlines.c:119
-#, fuzzy, c-format
-msgid "No record for category [%d]"
-msgstr "नहीं के लिए"
-#: ../ps/ps.map/ps_vpoints.c:182
-#, fuzzy, c-format
-msgid "Attribute is of invalid size [%.3f] for category [%d]"
-msgstr "है का अवैध आकार  के लिए."
-#: ../ps/ps.map/ps_vpoints.c:206 ../ps/ps.map/ps_vareas.c:108
-#: ../ps/ps.map/ps_vlines.c:125
-#, c-format
-msgid "Invalid RGB color definition in column <%s> for category [%d]"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:48
-msgid "Data exists after final 'end' instruction!"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:62
-#, fuzzy
-msgid "no file specified"
-msgstr "नहीं."
-#: ../ps/ps.map/r_instructions.c:66
-#, fuzzy
-msgid "unable to open"
-msgstr "के लिए"
-#: ../ps/ps.map/r_instructions.c:97
-#, fuzzy
-msgid "illegal maploc request"
-msgstr "पूर्व"
-#: ../ps/ps.map/r_instructions.c:111 ../ps/ps.map/main.c:220
-msgid "illegal copies request"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:126 ../ps/ps.map/r_instructions.c:322
-#, fuzzy
-msgid "no raster map selected yet"
-msgstr "नहीं."
-#: ../ps/ps.map/r_instructions.c:142
-#, fuzzy
-msgid "illegal value list"
-msgstr "है"
-#: ../ps/ps.map/r_instructions.c:178
-#, fuzzy
-msgid "scalebar is not appropriate for this projection"
-msgstr "है नहीं के लिए"
-#: ../ps/ps.map/r_instructions.c:186
-msgid "Bad scalebar length"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:202
-#, fuzzy
-msgid "illegal text request"
-msgstr "पूर्व"
-#: ../ps/ps.map/r_instructions.c:216
-#, fuzzy
-msgid "illegal point request"
-msgstr "पूर्व"
-#: ../ps/ps.map/r_instructions.c:230
-#, fuzzy
-msgid "illegal eps request"
-msgstr "पूर्व"
-#: ../ps/ps.map/r_instructions.c:247
-#, fuzzy
-msgid "illegal line request"
-msgstr "पूर्व"
-#: ../ps/ps.map/r_instructions.c:264
-#, fuzzy
-msgid "illegal rectangle request"
-msgstr "पूर्व"
-#: ../ps/ps.map/r_instructions.c:275
-#, fuzzy
-msgid "illegal comments request"
-msgstr "पूर्व"
-#: ../ps/ps.map/r_instructions.c:291
-#, fuzzy
-msgid "illegal scale request"
-msgstr "पूर्व"
-#: ../ps/ps.map/r_instructions.c:351
-#, fuzzy
-msgid "group not found"
-msgstr ""
-"\n"
-" समूह नहीं"
-#: ../ps/ps.map/r_instructions.c:393
-msgid "illegal grid spacing"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:404
-#, fuzzy
-msgid "geogrid is not available for this projection"
-#: ../ps/ps.map/r_instructions.c:414
-msgid "illegal geo-grid spacing"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:451
-#, fuzzy
-msgid "illegal request"
-msgstr "पूर्व"
-#: ../ps/ps.map/catval.c:49 ../ps/ps.map/catval.c:111
-#: ../ps/ps.map/catval.c:177 ../vector/v.label/main.c:273
-#: ../vector/v.class/main.c:100 ../vector/v.vol.rst/user1.c:95
-#: ../vector/v.label.sa/labels.c:74
-#, fuzzy
-msgid "Unable to get layer info for vector map"
-msgstr "के लिए"
-#: ../ps/ps.map/catval.c:64
-#, fuzzy
-msgid "Column type not supported (must be string)"
-msgstr "नहीं"
-#: ../ps/ps.map/catval.c:67 ../ps/ps.map/catval.c:132
-#: ../ps/ps.map/catval.c:199 ../vector/v.univar/main.c:154
-#: ../vector/v.sample/main.c:158 ../vector/v.normal/main.c:133
-#: ../vector/v.class/main.c:121 ../vector/v.to.rast3/main.c:92
-#: ../vector/v.surf.idw/read_sites.c:54 ../vector/v.surf.bspline/main.c:384
-#, fuzzy
-msgid "Unable to select data from table"
-msgstr "सभी"
-#: ../ps/ps.map/catval.c:129
-#, fuzzy
-msgid "Size column type must be numeric"
-msgstr "ज़ेड"
-#: ../ps/ps.map/catval.c:196
-#, fuzzy
-msgid "Rotation column type must be numeric"
-msgstr "ज़ेड"
-#: ../ps/ps.map/ps_raster.c:42
-#, fuzzy
-msgid "Can't create temporary PostScript mask file."
-#: ../ps/ps.map/ps_raster.c:105
-#, fuzzy, c-format
-msgid "Reading raster maps in group <%s>..."
-msgstr "n"
-#: ../ps/ps.map/do_psfiles.c:20
-#, fuzzy, c-format
-msgid "Reading PostScript include file <%s> ..."
-msgstr "छवि "
-#: ../ps/ps.map/r_vpoints.c:244
-#, c-format
-msgid "The mapping instruction <%s> will be renamed to <%s> in future versions of GRASS. Please use <%s> instead."
-msgstr ""
-#: ../ps/ps.map/ps_outline.c:43
-#, fuzzy, c-format
-msgid "Outlining areas in raster map <%s in %s> ..."
-msgstr "n"
-#: ../ps/ps.map/ps_outline.c:100 ../ps/ps.map/r_colortable.c:70
-msgid "illegal width request"
-msgstr ""
-#: ../ps/ps.map/ps_outline.c:107
-#, fuzzy
-msgid "illegal outline sub-request"
-msgstr "चेतावनी."
-#: ../ps/ps.map/r_group.c:29
-#, fuzzy
-msgid "Can't get group information"
-#: ../ps/ps.map/scale.c:136
-msgid "PSmap: do_scale(): shouldn't happen"
-msgstr ""
-#: ../ps/ps.map/r_colortable.c:78
-msgid "illegal height request"
-msgstr ""
-#: ../ps/ps.map/r_colortable.c:95
-#, fuzzy
-msgid "illegal range request"
-msgstr "पूर्व"
-#: ../ps/ps.map/r_colortable.c:111
-#, fuzzy
-msgid "illegal columns request"
-msgstr "पूर्व"
-#: ../ps/ps.map/r_colortable.c:130
-#, fuzzy
-msgid "Unsupported color request (colortable)"
-#: ../ps/ps.map/r_colortable.c:132
-msgid "illegal color request (colortable)"
-msgstr ""
-#: ../ps/ps.map/r_colortable.c:159
-msgid "illegal colortabe sub-request"
-msgstr ""
-#: ../ps/ps.map/r_colortable.c:170
-#, fuzzy
-msgid "No raster selected for colortable!"
-msgstr "नहीं"
-#: ../ps/ps.map/do_scalebar.c:194
-#, fuzzy
-msgid "meters"
-msgstr "n"
-#: ../ps/ps.map/do_scalebar.c:196
-#, fuzzy
-msgid "kilometers"
-msgstr "विशेषता"
-#: ../ps/ps.map/do_scalebar.c:198
-msgid "feet"
-msgstr ""
-#: ../ps/ps.map/do_scalebar.c:200
-#, fuzzy
-msgid "miles"
-msgstr "नहीं"
-#: ../ps/ps.map/do_scalebar.c:202
-msgid "nautical miles"
-msgstr ""
-#: ../ps/ps.map/ps_fclrtbl.c:46 ../ps/ps.map/ps_clrtbl.c:35
-#, fuzzy, c-format
-msgid "Creating color table for <%s in %s>..."
-msgstr "बनाया जा रहा है के लिए."
-#: ../ps/ps.map/ps_fclrtbl.c:51
-#, fuzzy
-msgid "Range information not available (run r.support)"
-msgstr "सीमा नहीं."
-#: ../ps/ps.map/ps_fclrtbl.c:64
-#, fuzzy
-msgid "A floating point colortable must contain a range of values"
-msgstr "बिन्दु रखे हुए a का."
-#: ../ps/ps.map/ps_fclrtbl.c:69 ../ps/ps.map/ps_clrtbl.c:44
-#, fuzzy
-msgid "Unable to read colors for colorbar"
-msgstr "के लिए"
-#: ../ps/ps.map/ps_fclrtbl.c:92 ../ps/ps.map/ps_fclrtbl.c:97
-#: ../ps/ps.map/ps_clrtbl.c:69
-msgid "Colorbar y location beyond page margins. Adjusting."
-msgstr ""
-#: ../ps/ps.map/ps_fclrtbl.c:103 ../ps/ps.map/ps_fclrtbl.c:108
-#: ../ps/ps.map/ps_clrtbl.c:75
-msgid "Colorbar x location beyond page margins. Adjusting."
-msgstr ""
-#: ../ps/ps.map/getgrid.c:95 ../ps/ps.map/getgrid.c:206
-#, fuzzy
-msgid "illegal numbers request"
-msgstr "पूर्व"
-#: ../ps/ps.map/getgrid.c:126 ../ps/ps.map/getgrid.c:234
-#, fuzzy
-msgid "illegal grid width request"
-msgstr "पूर्व"
-#: ../ps/ps.map/getgrid.c:132
-#, fuzzy
-msgid "illegal request (grid)"
-msgstr "पूर्व"
-#: ../ps/ps.map/getgrid.c:240
-#, fuzzy
-msgid "illegal request (geogrid)"
-msgstr "पूर्व"
-#: ../ps/ps.map/r_plt.c:174
-#, fuzzy
-msgid "Can't open eps file"
-msgstr "त्रुटि"
-#: ../ps/ps.map/map_setup.c:86
-#, fuzzy, c-format
-msgid "Scale set to %s"
-msgstr "के लिए."
-#: ../ps/ps.map/do_vectors.c:33
-#, fuzzy, c-format
-msgid "Reading vector map <%s in %s> ..."
-msgstr "n"
-#: ../ps/ps.map/do_vectors.c:137
-#, fuzzy, c-format
-msgid "Reading vector points file <%s in %s> ..."
-msgstr "छवि "
-#: ../ps/ps.map/r_header.c:77
-#, fuzzy
-msgid "illegal header sub-request"
-msgstr "चेतावनी."
-#: ../ps/ps.map/do_labels.c:44
-#, c-format
-msgid "Can't open label file <%s> in mapset <%s>"
-msgstr ""
-#: ../ps/ps.map/do_labels.c:48
-#, fuzzy, c-format
-msgid "Reading labels file <%s in %s> ..."
-msgstr "छवि "
-#: ../ps/ps.map/do_labels.c:66
-#, c-format
-msgid "Can't open temporary label file <%s>"
-msgstr ""
-#: ../ps/ps.map/do_labels.c:69
-#, fuzzy
-msgid "Reading text file ..."
-msgstr "n"
-#: ../ps/ps.map/do_labels.c:162
-#, fuzzy
-msgid "Text labels: 'fontsize' given so ignoring 'size'"
-msgstr "आकार "
-#: ../ps/ps.map/main.c:93
-msgid "postscript"
-msgstr ""
-#: ../ps/ps.map/main.c:94
-msgid "map"
-msgstr ""
-#: ../ps/ps.map/main.c:95
-#, fuzzy
-msgid "printing"
-msgstr "n"
-#: ../ps/ps.map/main.c:96
-#, fuzzy
-msgid "Produces hardcopy PostScript map output."
-msgstr "छापें"
-#: ../ps/ps.map/main.c:100
-#, fuzzy
-msgid "Rotate plot 90 degrees"
-msgstr "कोण"
-#: ../ps/ps.map/main.c:106
-#, fuzzy
-msgid "List paper formats (name width height left right top bottom(margin))"
-msgstr "छापें ऊंचाई बायाँ दायाँ शीर्ष तल"
-#: ../ps/ps.map/main.c:108 ../ps/ps.map/main.c:121
-msgid "Utility"
-msgstr ""
-#: ../ps/ps.map/main.c:113
-#, fuzzy
-msgid "Create EPS (Encapsulated PostScript) instead of PostScript file"
-msgstr "का"
-#: ../ps/ps.map/main.c:119
-msgid "Describe map-box's position on the page and exit (inches from top-left of paper)"
-msgstr ""
-#: ../ps/ps.map/main.c:124
-#, fuzzy
-msgid "File containing mapping instructions"
-msgstr "फ़ाइल"
-#: ../ps/ps.map/main.c:125
-msgid "Use '-' to enter instructions from keyboard)"
-msgstr ""
-#: ../ps/ps.map/main.c:128
-#, fuzzy
-msgid "Name for PostScript output file"
-msgstr "के लिए"
-#: ../ps/ps.map/main.c:134
-#, fuzzy
-msgid "Number of copies to print"
-msgstr "का"
-#: ../ps/ps.map/main.c:205
-#, fuzzy, c-format
-msgid "Unable to open file '%s': %s"
-msgstr "का"
-#: ../ps/ps.map/main.c:213 ../ps/ps.map/main.c:232
-#, fuzzy, c-format
-msgid ""
-"Required parameter <%s> not set:\n"
-"\t(%s)"
-msgstr "का."
-#: ../ps/ps.map/main.c:265
-#, c-format
-msgid "PostScript file '%s' successfully written."
-msgstr ""
-#: ../ps/ps.map/do_masking.c:23
-#, fuzzy
-msgid "Can't open temporary PostScript mask file."
-#: ../ps/ps.map/read_cfg.c:64
-#, fuzzy, c-format
-msgid "Paper '%s' not found, using defaults"
-msgstr "नहीं"
-#: ../ps/ps.map/makeprocs.c:29
-#, fuzzy, c-format
-msgid "Unable to open prolog <%s>"
-msgstr "के लिए"
-#: ../ps/ps.map/r_vlegend.c:97
-#, fuzzy
-msgid "illegal vlegend sub-request"
-msgstr "चेतावनी."
-#: ../ps/ps.map/eps.c:18
-#, fuzzy, c-format
-msgid "Can't open eps file <%s>"
-msgstr "फ़ाइल"
-#: ../ps/ps.map/eps.c:37
-#, fuzzy, c-format
-msgid "Bounding box in eps file <%s> was not found"
-msgstr "नहीं"
-#: ../ps/ps.map/ps_clrtbl.c:39 ../display/d.histogram/main.c:177
-#: ../display/d.legend/main.c:283
-#, fuzzy, c-format
-msgid "Category file for <%s> not available"
-msgstr "के लिए नहीं"
-#: ../ps/ps.map/ps_clrtbl.c:54
-#, fuzzy
-msgid "Your cats/ file is invalid. A cats/ file with categories and labels is required for 'colortable' when using categorical legends; see the r.category help page. Colortable creation has been skipped."
-msgstr "है अवैध है के लिए नहीं."
-#: ../ps/ps.map/do_plt.c:40
-#, fuzzy
-msgid "Reading point/line file ..."
-msgstr "n"
-#: ../display/d.histogram/main.c:85
-#, fuzzy
-msgid "histogram"
-msgstr "गामा."
-#: ../display/d.histogram/main.c:88
-#, fuzzy
-msgid "Displays a histogram in the form of a pie or bar chart for a user-specified raster map."
-msgstr "a का a के लिए a."
-#: ../display/d.histogram/main.c:92
-#, fuzzy
-msgid "Raster map for which histogram will be displayed"
-msgstr "के लिए"
-#: ../display/d.histogram/main.c:96
-#, fuzzy
-msgid "Indicate if a pie or bar chart is desired"
-msgstr "a है"
-#: ../display/d.histogram/main.c:105
-#, fuzzy
-msgid "Color for text and axes"
-msgstr "के लिए शीर्षक"
-#: ../display/d.histogram/main.c:113
-#, fuzzy
-msgid "Indicate if cell counts or map areas should be displayed"
-msgstr "का"
-#: ../display/d.histogram/main.c:123
-#, fuzzy
-msgid "Number of steps to divide the data range into (fp maps only)"
-msgstr "का"
-#: ../display/d.histogram/main.c:130
-#, fuzzy
-msgid "Display information for null cells"
-msgstr "के लिए"
-#: ../display/d.histogram/main.c:134
-#, fuzzy
-msgid "Gather the histogram quietly"
-msgstr "एकत्रित"
-#: ../display/d.histogram/main.c:139
-#, fuzzy
-msgid "Report for ranges defined in cats file (fp maps only)"
-msgstr "के लिए"
-#: ../display/d.histogram/main.c:163
-#, fuzzy, c-format
-msgid "Invalid number of steps: %s"
-msgstr "संख्या का"
-#: ../display/d.histogram/main.c:168
-msgid "When -C flag is set, the nsteps argument is ignored"
-msgstr ""
-#: ../display/d.histogram/main.c:180 ../display/d.legend/main.c:521
-#, fuzzy, c-format
-msgid "Range information for <%s> not available"
-msgstr "सीमा के लिए नहीं"
-#: ../display/d.histogram/main.c:190 ../display/d.vect/main.c:328
-#: ../display/d.rhumbline/main.c:96 ../display/d.where/main.c:169
-#: ../display/d.text/main.c:291 ../display/d.linegraph/main.c:258
-#: ../display/d.profile/main.c:263 ../display/d.info/main.c:69
-#: ../display/d.vect.chart/main.c:253 ../display/d.barscale/main.c:128
-#: ../display/d.erase/main.c:46 ../display/d.rast.num/main.c:193
-#: ../display/d.grid/main.c:230 ../display/d.his/main.c:117
-#: ../display/d.geodesic/main.c:96 ../display/d.labels/main.c:117
-#: ../display/d.colortable/main.c:141 ../display/d.rast/main.c:96
-#: ../display/d.thematic.area/main.c:366 ../display/d.fontlist/main.c:54
-#: ../display/d.graph/main.c:101 ../display/d.rgb/main.c:81
-#: ../display/d.path/main.c:153 ../display/d.rast.arrow/main.c:224
-#: ../display/d.legend/main.c:288 ../display/d.font/main.c:87
-msgid "No graphics device selected. Use d.mon to select graphics device."
-msgstr ""
-#: ../display/d.vect/opt.c:126
-#, fuzzy, c-format
-msgid "Unknown color: '%s'"
-msgstr "अज्ञात क़िस्म"
-#: ../display/d.vect/opt.c:143 ../display/d.what.vect/what.c:409
-#: ../display/d.thematic.area/main.c:196 ../vector/v.db.connect/main.c:175
-#, fuzzy, c-format
-msgid "Database connection not defined"
-msgstr "नहीं"
-#: ../display/d.vect/opt.c:152 ../display/d.thematic.area/main.c:205
-#: ../vector/v.convert/att.c:74 ../db/db.select/main.c:72
-#: ../db/db.execute/main.c:71 ../db/db.tables/main.c:50
-#: ../db/db.describe/main.c:56
-#, fuzzy, c-format
-msgid "Unable to open database <%s>"
-msgstr "के लिए."
-#: ../display/d.vect/lines.c:107 ../display/d.vect/lines.c:329
-#, fuzzy, c-format
-msgid "Unable to read symbol <%s>, unable to display points"
-msgstr "के लिए"
-#: ../display/d.vect/lines.c:121
-#, fuzzy
-msgid "Unable to display features by id, topology not available. Please try to rebuild topology using v.build or v.build.all."
-msgstr "नहीं"
-#: ../display/d.vect/lines.c:169
-#, fuzzy, c-format
-msgid "%d points plotted"
-msgstr "लोड हो गया n"
-#: ../display/d.vect/lines.c:171
-#, fuzzy, c-format
-msgid "%d lines plotted"
-msgstr "n"
-#: ../display/d.vect/lines.c:173
-#, fuzzy, c-format
-msgid "%d centroids plotted"
-msgstr "n"
-#: ../display/d.vect/lines.c:175
-#, fuzzy, c-format
-msgid "%d boundaries plotted"
-msgstr "n"
-#: ../display/d.vect/lines.c:177
-#, fuzzy, c-format
-msgid "%d faces plotted"
-msgstr "n"
-#: ../display/d.vect/attr.c:28
-msgid "attrcol not specified, cannot display attributes"
-msgstr ""
-#: ../display/d.vect/attr.c:110 ../display/d.vect.chart/plot.c:84
-#: ../vector/v.in.db/main.c:166
-#, fuzzy, c-format
-msgid "Unable to open select cursor: '%s'"
-msgstr "का"
-#: ../display/d.vect/attr.c:129
-#, fuzzy, c-format
-msgid "No attribute found for cat %d: %s"
-#: ../display/d.vect/topo.c:17
-msgid "Unable to display topology, not available.Please try to rebuild topology using v.build or v.build.all."
-msgstr ""
-#: ../display/d.vect/main.c:72
-#, fuzzy
-msgid "Displays user-specified vector map in the active graphics frame."
-msgstr "चालू."
-#: ../display/d.vect/main.c:86
-msgid "Display"
-msgstr ""
-#: ../display/d.vect/main.c:87
-msgid "shape;Display geometry of features;cat;Display category numbers of features;topo;Display topology information (nodes, edges);dir;Display direction of linear features;attr;Display selected attribute based on 'attrcolumn';zcoor;Display z-coordinate of features (only for 3D vector maps)"
-msgstr ""
-#: ../display/d.vect/main.c:98 ../display/d.vect/main.c:101
-#: ../display/d.vect/main.c:104 ../display/d.vect/main.c:307
-#: ../display/d.rast/main.c:69 ../display/d.rast/main.c:86
-#: ../display/d.thematic.area/main.c:130 ../display/d.thematic.area/main.c:133
-#: ../vector/v.net.centrality/main.c:121 ../vector/v.net.centrality/main.c:123
-#: ../vector/v.in.ogr/main.c:144 ../vector/v.in.ogr/main.c:157
-#: ../vector/v.in.ogr/main.c:162 ../vector/v.in.ogr/main.c:171
-#: ../vector/v.in.ogr/main.c:184 ../vector/v.in.ogr/main.c:253
-#: ../vector/v.out.ascii/args.c:22 ../vector/v.out.ascii/args.c:25
-#: ../vector/v.out.ascii/args.c:39 ../vector/v.out.ascii/args.c:42
-#: ../vector/v.edit/args.c:24 ../vector/v.edit/args.c:29
-#: ../vector/v.edit/args.c:112 ../vector/v.edit/args.c:116
-#: ../vector/v.edit/args.c:125 ../vector/v.edit/args.c:134
-#: ../vector/v.edit/args.c:143 ../vector/v.edit/args.c:146
-#: ../vector/v.edit/args.c:160 ../vector/v.edit/args.c:189
-#: ../vector/v.extract/main.c:96 ../vector/v.extract/main.c:101
-#: ../vector/v.extract/main.c:107 ../vector/v.extract/main.c:110
-#: ../vector/v.extract/main.c:113 ../vector/v.extract/main.c:123
-#: ../vector/v.extract/main.c:133 ../vector/v.category/main.c:82
-#: ../vector/v.category/main.c:85 ../vector/v.category/main.c:89
-#: ../vector/v.buffer/main.c:219 ../vector/v.buffer/main.c:224
-#: ../vector/v.surf.rst/main.c:177 ../vector/v.surf.rst/main.c:187
-#: ../vector/v.reclass/main.c:77 ../vector/v.reclass/main.c:82
-#: ../vector/v.out.ogr/args.c:19 ../vector/v.out.ogr/args.c:22
-#: ../vector/v.out.ogr/args.c:90 ../vector/v.select/args.c:16
-#: ../vector/v.select/args.c:21 ../vector/v.select/args.c:30
-#: ../vector/v.select/args.c:35 ../vector/v.select/args.c:88
-#: ../vector/v.clean/main.c:57 ../vector/v.clean/main.c:60
-#: ../vector/v.net.allpairs/main.c:70 ../vector/v.net.allpairs/main.c:76
-#: ../vector/v.net.allpairs/main.c:79 ../vector/v.net.allpairs/main.c:81
-#: ../vector/v.to.3d/args.c:20 ../vector/v.to.3d/args.c:25
-#: ../vector/v.to.points/main.c:184 ../vector/v.to.points/main.c:188
-#: ../vector/v.to.rast/main.c:53
-#, fuzzy
-msgid "Selection"
-msgstr "नहीं n"
-#: ../display/d.vect/main.c:112
-#, fuzzy
-msgid "Feature color"
-msgstr "सेट"
-#: ../display/d.vect/main.c:113 ../display/d.vect/main.c:123
-#: ../display/d.vect/main.c:130 ../display/d.vect/main.c:138
-#: ../display/d.vect/main.c:293 ../display/d.vect/main.c:299
-#: ../display/d.vect/main.c:313 ../display/d.rast.arrow/main.c:119
-#: ../display/d.rast.arrow/main.c:128 ../display/d.rast.arrow/main.c:137
-#: ../display/d.rast.arrow/main.c:146 ../vector/v.label/main.c:152
-#: ../vector/v.label/main.c:176 ../vector/v.label/main.c:189
-#: ../vector/v.label/main.c:195 ../vector/v.label/main.c:205
-#: ../vector/v.label.sa/main.c:103 ../vector/v.label.sa/main.c:113
-#: ../vector/v.label.sa/main.c:120 ../vector/v.label.sa/main.c:130
-#: ../vector/v.label.sa/main.c:140 ../vector/v.label.sa/main.c:150
-#: ../vector/v.label.sa/main.c:157
-msgid "Colors"
-msgstr ""
-#: ../display/d.vect/main.c:116 ../display/d.vect/main.c:126
-#: ../display/d.vect/main.c:227 ../display/d.vect/main.c:237
-#, fuzzy
-msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
-msgstr "a R जी"
-#: ../display/d.vect/main.c:122
-msgid "Area fill color"
-msgstr ""
-#: ../display/d.vect/main.c:131
-msgid "Name of color definition column (for use with -a flag)"
-msgstr ""
-#: ../display/d.vect/main.c:136
-#, fuzzy
-msgid "Name of color table (for use with -z flag)"
-msgstr "का स्थिर"
-#: ../display/d.vect/main.c:145 ../display/d.vect/main.c:150
-#: ../display/d.vect/main.c:158
-msgid "Lines"
-msgstr ""
-#: ../display/d.vect/main.c:146
-#, fuzzy
-msgid "Line width"
-msgstr "लकीर की चौड़ाई"
-#: ../display/d.vect/main.c:151
-#, fuzzy
-msgid "Name of numeric column containing line width"
-msgstr "का"
-#: ../display/d.vect/main.c:152
-msgid "These values will be scaled by width_scale"
-msgstr ""
-#: ../display/d.vect/main.c:159
-#, fuzzy
-msgid "Scale factor for width_column"
-msgstr "के लिए"
-#: ../display/d.vect/main.c:167 ../display/d.vect/main.c:177
-#: ../display/d.vect/main.c:184 ../display/d.vect/main.c:190
-#: ../display/d.vect/main.c:321
-msgid "Symbols"
-msgstr ""
-#: ../display/d.vect/main.c:171
-#, fuzzy
-msgid "Point and centroid symbol"
-msgstr "बिंदु"
-#: ../display/d.vect/main.c:178
-msgid "Symbol size"
-msgstr ""
-#: ../display/d.vect/main.c:180
-msgid "When used with the size_column option this becomes the scale factor"
-msgstr ""
-#: ../display/d.vect/main.c:186
-#, fuzzy
-msgid "Name of numeric column containing symbol size"
-msgstr "का"
-#: ../display/d.vect/main.c:192
-#, fuzzy
-msgid "Name of numeric column containing symbol rotation angle"
-msgstr "का"
-#: ../display/d.vect/main.c:194
-msgid "Measured in degrees CCW from east"
-msgstr ""
-#: ../display/d.vect/main.c:200 ../display/d.vect/main.c:207
-#: ../display/d.vect/main.c:215 ../display/d.vect/main.c:223
-#: ../display/d.vect/main.c:233 ../display/d.vect/main.c:243
-#: ../display/d.vect/main.c:249 ../display/d.vect/main.c:255
-#: ../display/d.vect/main.c:261 ../display/d.vect/main.c:269
-msgid "Labels"
-msgstr ""
-#: ../display/d.vect/main.c:202
-msgid "Layer number for labels (default: the given layer number)"
-msgstr ""
-#: ../display/d.vect/main.c:208
-#, fuzzy
-msgid "Name of column to be displayed"
-msgstr "का"
-#: ../display/d.vect/main.c:214
-msgid "Label color"
-msgstr ""
-#: ../display/d.vect/main.c:217 ../display/d.rast/main.c:75
-#, fuzzy
-msgid "Either a standard color name or R:G:B triplet"
-msgstr "a R जी"
-#: ../display/d.vect/main.c:224
-msgid "Label background color"
-msgstr ""
-#: ../display/d.vect/main.c:234
-msgid "Label border color"
-msgstr ""
-#: ../display/d.vect/main.c:244
-#, fuzzy
-msgid "Label size (pixels)"
-msgstr "आकार  पिक्सेल्स"
-#: ../display/d.vect/main.c:250 ../display/d.text/main.c:219
-#: ../display/d.legend/main.c:160 ../vector/v.label/main.c:122
-#, fuzzy
-msgid "Font name"
-msgstr "फ़ॉन्ट"
-#: ../display/d.vect/main.c:256
-#, fuzzy
-msgid "Text encoding"
-msgstr "पाठ रंग"
-#: ../display/d.vect/main.c:264
-msgid "Label horizontal justification"
-msgstr ""
-#: ../display/d.vect/main.c:272
-msgid "Label vertical justification"
-msgstr ""
-#: ../display/d.vect/main.c:279
-#, fuzzy
-msgid "Minimum region size (average from height and width) when map is displayed"
-msgstr "आकार  ऊंचाई है"
-#: ../display/d.vect/main.c:287
-#, fuzzy
-msgid "Maximum region size (average from height and width) when map is displayed"
-#: ../display/d.vect/main.c:295
-#, fuzzy
-msgid "Get colors from attribute table (see 'rgb_column' option)"
-msgstr "पाएं"
-#: ../display/d.vect/main.c:301
-#, fuzzy
-msgid "Random colors according to category number (or layer number if 'layer=-1' is given)"
-msgstr "संख्या"
-#: ../display/d.vect/main.c:308
-msgid "Use values from 'cats' option as feature id"
-msgstr ""
-#: ../display/d.vect/main.c:312
-msgid "Colorize features according to z-coordinate (only for 3D vector maps)"
-msgstr ""
-#: ../display/d.vect/main.c:317
-msgid "Use square root of the value of size_column"
-msgstr ""
-#: ../display/d.vect/main.c:319
-msgid "This makes circle areas proportionate to the size_column values instead of circle radius"
-msgstr ""
-#: ../display/d.vect/main.c:339
-#, fuzzy
-msgid "Region size is lower than minreg, nothing displayed"
-msgstr "आकार  है कुछ नहीं."
-#: ../display/d.vect/main.c:347
-#, fuzzy
-msgid "Region size is greater than maxreg, nothing displayed"
-#: ../display/d.vect/main.c:361
-msgid "The '-c' and '-a' flags cannot be used together, the '-c' flag will be ignored!"
-msgstr ""
-#: ../display/d.vect/main.c:383 ../display/d.vect/main.c:389
-#: ../vector/v.out.ascii/args.c:138
-#, fuzzy, c-format
-msgid "Option <%s> must be > 0"
-msgstr "n"
-#: ../display/d.vect/main.c:393 ../vector/v.out.ascii/args.c:141
-#, c-format
-msgid "%d errors in cat option"
-msgstr ""
-#: ../display/d.vect/main.c:409
-#, fuzzy
-msgid "Plotting..."
-msgstr "नक़ल"
-#: ../display/d.vect/main.c:417
-#, fuzzy
-msgid "The bounding box of the map is outside the current region, nothing drawn"
-msgstr "बक्सा का कुछ नहीं n"
-#: ../display/d.vect/main.c:480
-#, fuzzy
-msgid "Rendering failed"
-msgstr "n"
-#: ../display/d.vect/area.c:37
-#, fuzzy
-msgid "Unable to display areas, topology not available. Please try to rebuild topology using v.build or v.build.all."
-msgstr "नहीं"
-#: ../display/d.vect/label.c:28
-#, fuzzy
-msgid "Topology level required for drawing centroids for OGR layers"
-msgstr "n"
-#: ../display/d.vect/zcoor.c:19
-#, fuzzy
-msgid "Vector map is not 3D. Unable to display z-coordinates."
-msgstr "का"
-#: ../display/d.vect/shape.c:48 ../display/d.thematic.area/plot1.c:119
-#, fuzzy
-msgid "Color definition column not specified"
-msgstr "नहीं."
-#: ../display/d.vect/shape.c:58 ../display/d.thematic.area/plot1.c:129
-#, c-format
-msgid "Color definition column (%s) not a string. Column must be of form RRR:GGG:BBB where RGB values range 0-255."
-msgstr ""
-#: ../display/d.vect/shape.c:63 ../display/d.vect/shape.c:92
-#: ../display/d.vect/shape.c:123 ../display/d.vect/shape.c:154
-#, fuzzy, c-format
-msgid "Unable to select data (%s) from table"
-msgstr "सभी"
-#: ../display/d.vect/shape.c:77
-#, fuzzy
-msgid "Line width column not specified"
-msgstr "नहीं."
-#: ../display/d.vect/shape.c:88
-#, fuzzy, c-format
-msgid "Line width column (%s) not a number"
-msgstr "है नहीं का संख्या"
-#: ../display/d.vect/shape.c:108
-#, fuzzy
-msgid "Symbol size column not specified"
-msgstr "नहीं."
-#: ../display/d.vect/shape.c:119
-#, fuzzy, c-format
-msgid "Symbol size column (%s) is not numeric"
-#: ../display/d.vect/shape.c:139
-#, fuzzy
-msgid "Symbol rotation column not specified"
-msgstr "नहीं."
-#: ../display/d.vect/shape.c:150
-#, fuzzy, c-format
-msgid "Symbol rotation column (%s) is not numeric"
-msgstr "ज़ेड"
-#: ../display/d.vect/shape.c:173
-msgid "Vector map is not 3D. Unable to colorize features based on z-coordinates."
-msgstr ""
-#: ../display/d.vect/shape.c:244 ../display/d.vect/shape.c:249
-#, fuzzy, c-format
-msgid "Error in color definition (%s) - feature %d with category %d"
-msgstr "नहीं."
-#: ../display/d.vect/shape.c:315
-#, fuzzy, c-format
-msgid "Invalid negative value - feature %d with category %d"
-msgstr "के लिए"
-#: ../display/d.rhumbline/main.c:46
-msgid "Displays the rhumbline joining two longitude/latitude coordinates."
-msgstr ""
-#: ../display/d.rhumbline/main.c:53 ../display/d.geodesic/main.c:55
-#: ../display/d.path/main.c:65
-#, fuzzy
-msgid "Starting and ending coordinates"
-msgstr "n"
-#: ../display/d.rhumbline/main.c:59 ../display/d.geodesic/main.c:61
-msgid "Line color"
-msgstr ""
-#: ../display/d.rhumbline/main.c:68 ../display/d.barscale/main.c:82
-#: ../display/d.grid/main.c:93 ../vector/v.label/main.c:151
-#: ../vector/v.lrs/v.lrs.label/main.c:194 ../vector/v.label.sa/main.c:98
-#, fuzzy
-msgid "Text color"
-msgstr "पाठ रंग"
-#: ../display/d.rhumbline/main.c:76 ../display/d.geodesic/main.c:77
-#, fuzzy, c-format
-msgid "Location is not %s"
-msgstr "n"
-#: ../display/d.rhumbline/main.c:80 ../display/d.geodesic/main.c:80
-#: ../display/d.path/main.c:140
-#, fuzzy
-msgid "No coordinates given"
-msgstr "नहीं."
-#: ../display/d.rhumbline/main.c:83 ../display/d.rhumbline/main.c:86
-#: ../display/d.rhumbline/main.c:89 ../display/d.rhumbline/main.c:92
-#: ../display/d.geodesic/main.c:83 ../display/d.geodesic/main.c:86
-#: ../display/d.geodesic/main.c:89 ../display/d.geodesic/main.c:92
-#, fuzzy, c-format
-msgid "%s - illegal longitude"
-msgstr "है"
-#: ../display/d.where/main.c:47
-#, fuzzy
-msgid "Identifies the geographic coordinates associated with point locations given in display coordinates."
-msgstr "बिन्दु चालू."
-#: ../display/d.where/main.c:57
-#, fuzzy
-msgid "Display coordinates to convert"
-msgstr "का प्रारंभ"
-#: ../display/d.where/main.c:62
-#, fuzzy
-msgid "File from which to read coordinates (\"-\" to read from stdin)"
-msgstr "उत्तर पूर्व"
-#: ../display/d.where/main.c:66
-msgid "Output lat/long in decimal degree"
-msgstr ""
-#: ../display/d.where/main.c:71
-msgid "Output lat/long referenced to current ellipsoid"
-msgstr ""
-#: ../display/d.where/main.c:76
-msgid "Output lat/long referenced to WGS84 ellipsoid using datum transformation parameters defined in current location (if available)"
-msgstr ""
-#: ../display/d.where/main.c:82
-#, fuzzy
-msgid "Output frame coordinates of current display monitor (percentage)"
-msgstr "का"
-#: ../display/d.where/main.c:90
-#, fuzzy
-msgid "Ambiguous request for lat/long ellipsoids"
-msgstr "के लिए"
-#: ../display/d.where/main.c:93
-#, fuzzy
-msgid "Please specify a lat/long ellipsoid with -l or -w"
-msgstr "a"
-#: ../display/d.where/main.c:135
-#, fuzzy
-msgid ""
-"WGS84 output not possible as this location does not contain\n"
-"datum transformation parameters. Try running g.setproj."
-msgstr "नहीं नहीं रखे हुए कोशिश करें चल रहा है... जी."
-#: ../display/d.where/where.c:29
-#, fuzzy, c-format
-msgid "Invalid coordinates <%s,%s>"
-msgstr "के लिए"
-#: ../display/d.what.vect/what.c:152 ../display/d.what.vect/what.c:154
-#: ../vector/v.what/what.c:191 ../vector/v.what/what.c:193
-#, fuzzy, c-format
-msgid "Nothing Found.\n"
-msgstr "n"
-#: ../display/d.what.vect/what.c:210
-#, c-format
-msgid "Line: %d  Type: %s  Left: %d  Right: %d  "
-msgstr ""
-#: ../display/d.what.vect/what.c:214 ../vector/v.what/what.c:252
-#: ../vector/v.what/what.c:307
-#, fuzzy, c-format
-msgid "Length: %f\n"
-msgstr "f n"
-#: ../display/d.what.vect/what.c:230
-#, fuzzy, c-format
-msgid "  Node[%d]: %d  Number of lines: %d  Coordinates: %.6f, %.6f, %.6f\n"
-msgstr "का n"
-#: ../display/d.what.vect/what.c:239
-#, fuzzy, c-format
-msgid "    Line: %5d  Angle: %.8f\n"
-msgstr "n"
-#: ../display/d.what.vect/what.c:248
-#, fuzzy, c-format
-msgid "length %f\n"
-msgstr "f n"
-#: ../display/d.what.vect/what.c:268 ../vector/v.what/what.c:321
-#, fuzzy, c-format
-msgid "Point height: %f\n"
-msgstr "बिंदु ऊंचाई f n"
-#: ../display/d.what.vect/what.c:286 ../vector/v.what/what.c:338
-#, fuzzy, c-format
-msgid "Line height: %f\n"
-msgstr "ऊंचाई f n"
-#: ../display/d.what.vect/what.c:295
-#, fuzzy, c-format
-msgid "Line height min: %f max: %f\n"
-msgstr "ऊंचाई f f n"
-#: ../display/d.what.vect/what.c:311
-#, fuzzy, c-format
-msgid "Area height: %f\n"
-msgstr "ऊंचाई f n"
-#: ../display/d.what.vect/what.c:320
-#, fuzzy, c-format
-msgid "Area\n"
-msgstr "n"
-#: ../display/d.what.vect/what.c:342
-#, fuzzy, c-format
-msgid "Area: %d  Number of isles: %d\n"
-msgstr "का n"
-#: ../display/d.what.vect/what.c:347
-#, fuzzy, c-format
-msgid "  Isle[%d]: %d\n"
-msgstr "n"
-#: ../display/d.what.vect/what.c:354
-#, fuzzy, c-format
-msgid "Island: %d  In area: %d\n"
-msgstr "n"
-#: ../display/d.what.vect/what.c:361 ../display/d.what.vect/what.c:369
-#, fuzzy, c-format
-msgid "Size - Sq Meters: %.3f\t\tHectares: %.3f\n"
-msgstr "n"
-#: ../display/d.what.vect/what.c:365 ../display/d.what.vect/what.c:373
-#, fuzzy, c-format
-msgid "           Acres: %.3f\t\tSq Miles: %.4f\n"
-msgstr "n"
-#: ../display/d.what.vect/what.c:396
-#, fuzzy, c-format
-msgid ""
-"Layer: %d\n"
-"category: %d\n"
-msgstr "n"
-#: ../display/d.what.vect/what.c:421
-#, fuzzy, c-format
-msgid ""
-"driver: %s\n"
-"database: %s\n"
-"table: %s\n"
-"key column: %s\n"
-msgstr "n"
-#: ../display/d.what.vect/what.c:475
-#, fuzzy, c-format
-msgid ""
-"\n"
-"Click mouse button on desired location\n"
-"\n"
-msgstr "चालू n n"
-#: ../display/d.what.vect/what.c:480
-#, fuzzy, c-format
-msgid "Buttons\n"
-msgstr "बटन्स n"
-#: ../display/d.what.vect/what.c:481
-#, fuzzy, c-format
-msgid " Left:  what's here\n"
-msgstr "n"
-#: ../display/d.what.vect/what.c:482
-#, fuzzy, c-format
-msgid " Right: quit\n"
-msgstr "n"
-#: ../display/d.what.vect/openvect.c:11
-#, fuzzy, c-format
-msgid "warning: %s - vector map not found\n"
-msgstr "नहीं n"
-#: ../display/d.what.vect/main.c:61
-#, fuzzy
-msgid "Allows the user to interactively query a vector map layer at user-selected locations within the current geographic region."
-msgstr "a पर."
-#: ../display/d.what.vect/main.c:68 ../display/d.what.rast/main.c:79
-#, fuzzy
-msgid "Identify just one location"
-msgstr "पहचानें एक"
-#: ../display/d.what.vect/main.c:77
-#, fuzzy
-msgid "Name of existing vector map"
-msgstr "का"
-#: ../display/d.what.vect/main.c:81 ../display/d.what.rast/main.c:83
-msgid "Terse output. For parsing by programs"
-msgstr ""
-#: ../display/d.what.vect/main.c:86
-msgid "Print information as plain text to terminal window"
-msgstr ""
-#: ../display/d.what.vect/main.c:90 ../vector/v.what/main.c:85
-msgid "Print topological information (debugging)"
-msgstr ""
-#: ../display/d.what.vect/main.c:94
-msgid "Open form in edit mode"
-msgstr ""
-#: ../display/d.what.vect/main.c:136
-#, fuzzy, c-format
-msgid "%s: You must build topology on vector map"
-msgstr "नहीं"
-#: ../display/d.what.vect/main.c:139
-msgid "Building spatial index..."
-msgstr ""
-#: ../display/d.text/main.c:140 ../display/d.linegraph/main.c:120
-#: ../display/d.vect.chart/main.c:64 ../display/d.barscale/main.c:54
-#: ../display/d.grid/main.c:52 ../display/d.thematic.area/main.c:77
-#: ../display/d.graph/main.c:59 ../display/d.legend/main.c:85
-#: ../display/d.title/main.c:50
-msgid "cartography"
-msgstr ""
-#: ../display/d.text/main.c:142
-#, fuzzy
-msgid "Draws text in the active display frame on the graphics monitor using the current font."
-msgstr "पाठ चालू."
-#: ../display/d.text/main.c:148
-msgid "Text to display"
-msgstr ""
-#: ../display/d.text/main.c:157
-#, fuzzy
-msgid "Height of letters in percentage of available frame height"
-msgstr "ऊंचाई का का ऊंचाई"
-#: ../display/d.text/main.c:165
-#, fuzzy
-msgid "Text color, either a standard GRASS color or R:G:B triplet"
-msgstr "a R जी"
-#: ../display/d.text/main.c:173
-#, fuzzy
-msgid "Text background color, either a standard GRASS color or R:G:B triplet"
-msgstr "a R जी"
-#: ../display/d.text/main.c:182
-#, fuzzy
-msgid "The screen line number on which text will begin to be drawn"
-msgstr "संख्या चालू पाठ"
-#: ../display/d.text/main.c:190
-#, fuzzy
-msgid "Screen position at which text will begin to be drawn (percentage, [0,0] is lower left)"
-msgstr "स्क्रीन पर पाठ है बायाँ"
-#: ../display/d.text/main.c:198
-msgid "Text alignment"
-msgstr ""
-#: ../display/d.text/main.c:206
-#, fuzzy
-msgid "Rotation angle in degrees (counter-clockwise)"
-msgstr "कोण कोण"
-#: ../display/d.text/main.c:213
-msgid "Line spacing"
-msgstr ""
-#: ../display/d.text/main.c:225 ../display/d.legend/main.c:167
-#, fuzzy
-msgid "Path to font file"
-msgstr "का"
-#: ../display/d.text/main.c:233 ../display/d.legend/main.c:176
-msgid "Text encoding (only applicable to TrueType fonts)"
-msgstr ""
-#: ../display/d.text/main.c:237
-#, fuzzy
-msgid "Input file"
-msgstr "है n"
-#: ../display/d.text/main.c:241
-#, fuzzy
-msgid "Screen position in pixels ([0,0] is top left)"
-msgstr "पिक्सेल्स है शीर्ष बायाँ"
-#: ../display/d.text/main.c:245
-#, fuzzy
-msgid "Screen position in geographic coordinates"
-msgstr "ज़ेड"
-#: ../display/d.text/main.c:249
-#, fuzzy
-msgid "Use bold text"
-msgstr "पाठ"
-#: ../display/d.text/main.c:253
-#, fuzzy
-msgid "Use radians instead of degrees for rotation"
-msgstr "का कोण के लिए"
-#: ../display/d.text/main.c:257 ../display/d.legend/main.c:206
-#, fuzzy
-msgid "Font size is height in pixels"
-msgstr "फ़ॉन्ट आकार  है ऊंचाई पिक्सेल्स"
-#: ../display/d.text/main.c:261
-#, fuzzy
-msgid "Ignored (compatibility with d.text.freetype)"
-msgstr "पाठ"
-#: ../display/d.text/main.c:271
-#, fuzzy
-msgid "Please choose only one placement method"
-msgstr "एक पद्धति"
-#: ../display/d.text/main.c:332
-#, fuzzy
-msgid "Invalid coordinates"
-msgstr "के लिए"
-#: ../display/d.text/main.c:376
-#, c-format
-msgid ""
-"\n"
-"Please enter text instructions.  Enter EOF (ctrl-d) on last line to quit\n"
-msgstr ""
-#: ../display/d.text/main.c:567
-#, fuzzy, c-format
-msgid "[%s]: No such color. Use '%s'"
-msgstr "नहीं"
-#: ../display/d.linegraph/main.c:122
-#, fuzzy
-msgid "Generates and displays simple line graphs in the active graphics monitor display frame."
-msgstr "चालू."
-#: ../display/d.linegraph/main.c:126
-#, fuzzy
-msgid "Name of data file for X axis of graph"
-msgstr "का रखे हुए"
-#: ../display/d.linegraph/main.c:132
-msgid "Name of data file(s) for Y axis of graph"
-msgstr ""
-#: ../display/d.linegraph/main.c:139
-#, fuzzy
-msgid "Path to file location"
-msgstr "का"
-#: ../display/d.linegraph/main.c:146
-#, fuzzy
-msgid "Color for Y data"
-msgstr "के लिए पाठ"
-#: ../display/d.linegraph/main.c:155
-#, fuzzy
-msgid "Color for axis, tics, numbers, and title"
-#: ../display/d.linegraph/main.c:163
-#, fuzzy
-msgid "Title for X data"
-msgstr "के लिए"
-#: ../display/d.linegraph/main.c:170
-#, fuzzy
-msgid "Title for Y data"
-msgstr "के लिए"
-#: ../display/d.linegraph/main.c:177
-#, fuzzy
-msgid "Title for Graph"
-msgstr "के लिए"
-#: ../display/d.linegraph/main.c:216
-msgid "Maximum of 10 Y data files exceeded"
-msgstr ""
-#: ../display/d.linegraph/main.c:245
-#, c-format
-msgid "Only <%d> colors given for <%d> lines"
-msgstr ""
-#: ../display/d.linegraph/main.c:299
-#, c-format
-msgid "Y input file <%s> contains %s data points than the X input file"
-msgstr ""
-#: ../display/d.linegraph/main.c:304
-#, fuzzy, c-format
-msgid "The last %d point(s) will be ignored"
-msgstr "अन्य"
-#: ../display/d.linegraph/main.c:365
-#, fuzzy, c-format
-msgid "Problem reading X data file at line %d"
-msgstr "त्रुटि"
-#: ../display/d.linegraph/main.c:375
-#, c-format
-msgid "Problem reading <%s> data file at line %d"
-msgstr ""
-#: ../display/d.profile/main.c:68
-#, fuzzy, c-format
-msgid "Unable to read range for %s"
-msgstr "के लिए"
-#: ../display/d.profile/main.c:79
-#, fuzzy, c-format
-msgid "Unable to read FP range for %s"
-msgstr "के लिए"
-#: ../display/d.profile/main.c:194
-msgid "Plots profile of a transect."
-msgstr ""
-#: ../display/d.profile/main.c:198
-#, fuzzy
-msgid "Raster map to be profiled"
-msgstr "का"
-#: ../display/d.profile/main.c:210
-msgid "Use map's range recorded range"
-msgstr ""
-#: ../display/d.profile/main.c:259
-#, fuzzy
-msgid "At least two points are required"
-msgstr "के लिए"
-#: ../display/d.what.rast/what.c:56
-#, fuzzy
-msgid "You are clicking outside the map"
-msgstr "नहीं"
-#: ../display/d.what.rast/main.c:53
-#, fuzzy
-msgid "Allows the user to interactively query the category contents of multiple raster map layers at user specified locations within the current geographic region."
-msgstr "का पर "
-#: ../display/d.what.rast/main.c:74
-#, fuzzy
-msgid "Field separator (terse mode only)"
-msgstr "फील्ड"
-#: ../display/d.what.rast/main.c:88
-#, fuzzy
-msgid "Print out col/row for the entire map in grid resolution of the region"
-msgstr "छापें के लिए का"
-#: ../display/d.info/main.c:32 ../display/d.erase/main.c:31
-#: ../display/d.mon/main.c:39
-#: ../locale/scriptstrings/d.redraw_to_translate.c:4
-msgid "monitors"
-msgstr ""
-#: ../display/d.info/main.c:34
-#, fuzzy
-msgid "Displays information about the active display monitor."
-msgstr "a."
-#: ../display/d.info/main.c:36
-msgid "Display monitors are maintained by d.mon."
-msgstr ""
-#: ../display/d.info/main.c:41
-msgid "Display screen rectangle (left, right, top, bottom)"
-msgstr ""
-#: ../display/d.info/main.c:45
-msgid "Display screen dimensions (width, height)"
-msgstr ""
-#: ../display/d.info/main.c:49
-msgid "Display active frame rectangle"
-msgstr ""
-#: ../display/d.info/main.c:53
-#, fuzzy
-msgid "Display screen rectangle of current region"
-msgstr "छापें"
-#: ../display/d.info/main.c:58
-#, fuzzy
-msgid "Display geographic coordinates and resolution of entire screen"
-msgstr "बेस चालू "
-#: ../display/d.info/main.c:65
-#, fuzzy
-msgid "No flag given"
-msgstr "नहीं."
-#: ../display/d.vect.chart/main.c:66
-#, fuzzy
-msgid "Displays charts of vector data in the active frame on the graphics monitor."
-msgstr "चालू."
-#: ../display/d.vect.chart/main.c:83
-#, fuzzy
-msgid "Chart type"
-msgstr "विशेषता"
-#: ../display/d.vect.chart/main.c:84 ../display/d.vect.chart/main.c:98
-#: ../display/d.vect.chart/main.c:106 ../display/d.vect.chart/main.c:113
-#: ../display/d.vect.chart/main.c:121 ../display/d.vect.chart/main.c:130
-#: ../display/d.vect.chart/main.c:136
-#, fuzzy
-msgid "Chart properties"
-msgstr "विशेषता"
-#: ../display/d.vect.chart/main.c:91
-msgid "Attribute columns containing data"
-msgstr ""
-#: ../display/d.vect.chart/main.c:97
-#, fuzzy
-msgid "Column used for pie chart size"
-#: ../display/d.vect.chart/main.c:105
-msgid "Size of chart (diameter for pie, total width for bar)"
-msgstr ""
-#: ../display/d.vect.chart/main.c:112
-msgid "Scale for size (to get size in pixels)"
-msgstr ""
-#: ../display/d.vect.chart/main.c:119
-#, fuzzy
-msgid "Outline color"
-msgstr "सेट"
-#: ../display/d.vect.chart/main.c:128
-#, fuzzy
-msgid "Colors used to fill charts"
-#: ../display/d.vect.chart/main.c:135
-msgid "Center the bar chart around a data point"
-msgstr ""
-#: ../display/d.vect.chart/main.c:144
-msgid "Maximum value used for bar plot reference"
-msgstr ""
-#: ../display/d.vect.chart/main.c:149 ../display/d.thematic.area/main.c:159
-msgid "Create legend information and send to stdout"
-msgstr ""
-#: ../display/d.barscale/main.c:55
-#, fuzzy
-msgid "Displays a barscale on the graphics monitor."
-msgstr "a चालू."
-#: ../display/d.barscale/main.c:59
-#, fuzzy
-msgid "Use feet/miles instead of meters"
-msgstr "फीट मील का मीटर्स"
-#: ../display/d.barscale/main.c:63
-#, fuzzy
-msgid "Draw a line scale instead of a bar scale"
-msgstr "निकालें a स्केल का a स्केल"
-#: ../display/d.barscale/main.c:67
-#, fuzzy
-msgid "Write text on top of the scale, not to the right"
-msgstr "पाठ चालू शीर्ष का स्केल नहीं दायाँ"
-#: ../display/d.barscale/main.c:71
-msgid "Draw a north arrow only"
-msgstr ""
-#: ../display/d.barscale/main.c:75
-msgid "Draw a scale bar only"
-msgstr ""
-#: ../display/d.barscale/main.c:92
-#, fuzzy
-msgid "The screen coordinates for top-left corner of label ([0,0] is lower-left of frame)"
-msgstr "के लिए शीर्ष बायाँ का है शीर्ष बायाँ का"
-#: ../display/d.barscale/main.c:100
-#, fuzzy
-msgid "Font size"
-msgstr "आकार "
-#: ../display/d.barscale/main.c:108
-#, fuzzy, c-format
-msgid "%s does not work with a latitude-longitude location"
-msgstr "नहीं a"
-#: ../display/d.barscale/main.c:116
-msgid "Choose either -n or -s flag"
-msgstr ""
-#: ../display/d.erase/main.c:30 ../display/d.mon/main.c:38
-#: ../locale/scriptstrings/d.redraw_to_translate.c:3
-msgid "graphics"
-msgstr ""
-#: ../display/d.erase/main.c:32 ../display/d.mon/main.c:40
-#: ../locale/scriptstrings/d.redraw_to_translate.c:5
-msgid "CLI"
-msgstr ""
-#: ../display/d.erase/main.c:34
-#, fuzzy
-msgid "Erases the contents of the active graphics display frame with user defined color."
-msgstr "का"
-#: ../display/d.erase/main.c:40
-#, fuzzy
-msgid "Remove all frames and erase the screen"
-msgstr "हटाएँ सभी फ्रेम्स"
-#: ../display/d.zoom/main.c:62
-msgid "zoom"
-msgstr ""
-#: ../display/d.zoom/main.c:64
-#, fuzzy
-msgid "Allows the user to change the current geographic region settings interactively, with a mouse."
-msgstr "a."
-#: ../display/d.zoom/main.c:76 ../display/d.legend/main.c:91
-#, fuzzy
-msgid "Name of raster map"
-msgstr "का"
-#: ../display/d.zoom/main.c:84 ../vector/v.build/main.c:44
-#, fuzzy
-msgid "Name of vector map"
-msgstr "का"
-#: ../display/d.zoom/main.c:92
-msgid "Magnification: >1.0 zooms in, <1.0 zooms out"
-msgstr ""
-#: ../display/d.zoom/main.c:102
-#, fuzzy
-msgid "Full menu (zoom + pan) & Quit menu"
-msgstr "पैन"
-#: ../display/d.zoom/main.c:106
-#, fuzzy
-msgid "Pan mode"
-msgstr "हैंडहेल्ड"
-#: ../display/d.zoom/main.c:110
-#, fuzzy
-msgid "Handheld mode"
-msgstr "हैंडहेल्ड"
-#: ../display/d.zoom/main.c:114
-msgid "Return to previous zoom"
-msgstr ""
-#: ../display/d.zoom/main.c:120
-#, fuzzy
-msgid "Please choose only one mode of operation"
-msgstr "एक पद्धति"
-#: ../display/d.zoom/main.c:223
-#, fuzzy, c-format
-msgid "%d raster%s, %d vector%s\n"
-msgstr "n"
-#: ../display/d.zoom/main.c:232
-#, fuzzy
-msgid "No previous zoom available"
-msgstr "है n"
-#: ../display/d.zoom/main.c:236
-msgid "Returning to previous zoom"
-msgstr ""
-#: ../display/d.zoom/main.c:271
-#, fuzzy
-msgid "Zooming complete."
-msgstr "पूर्ण n"
-#: ../display/d.zoom/zoom.c:14 ../display/d.zoom/pan.c:16
-#, fuzzy, c-format
-msgid ""
-"\n"
-"\n"
-"Buttons:\n"
-msgstr "n n"
-#: ../display/d.zoom/zoom.c:15
-#, fuzzy, c-format
-msgid "Left:   Zoom menu\n"
-msgstr "n"
-#: ../display/d.zoom/zoom.c:16
-#, c-format
-msgid "Middle: Pan\n"
-msgstr ""
-#: ../display/d.zoom/zoom.c:17
-#, fuzzy, c-format
-msgid "Right:  Quit menu\n"
-msgstr "बाहर जाएँ n"
-#: ../display/d.zoom/zoom.c:39
-#, fuzzy, c-format
-msgid ""
-"This region now saved as current region.\n"
-"\n"
-msgstr "n n"
-#: ../display/d.zoom/zoom.c:41
-#, fuzzy, c-format
-msgid "Note: run 'd.erase' for the new region to affect the graphics.\n"
-msgstr "के लिए n"
-#: ../display/d.zoom/pan.c:17
-#, c-format
-msgid "Left:   Pan\n"
-msgstr ""
-#: ../display/d.zoom/pan.c:18
-#, fuzzy, c-format
-msgid "Right:  Quit\n"
-msgstr "n"
-#: ../display/d.rast.num/main.c:74
-#, fuzzy
-msgid "Overlays cell category values on a raster map layer displayed to the graphics monitor."
-msgstr "चालू a."
-#: ../display/d.rast.num/main.c:86
-#, fuzzy
-msgid "Color for drawing grid, or \"none\""
-msgstr "के लिए"
-#: ../display/d.rast.num/main.c:95
-#, fuzzy
-msgid "Color for drawing text"
-#: ../display/d.rast.num/main.c:108 ../display/d.rast.arrow/main.c:173
-msgid "Align grids with raster cells"
-msgstr ""
-#: ../display/d.rast.num/main.c:112
-#, fuzzy
-msgid "Get text color from cell color value"
-msgstr "पाएं पाठ"
-#: ../display/d.rast.num/main.c:177
-#, fuzzy
-msgid "Current window size:"
-msgstr "नहीं"
-#: ../display/d.rast.num/main.c:178
-#, fuzzy, c-format
-msgid "rows:    %d"
-msgstr "n"
-#: ../display/d.rast.num/main.c:179
-#, c-format
-msgid "columns: %d"
-msgstr ""
-#: ../display/d.rast.num/main.c:181
-msgid ""
-"\n"
-"Your current window setting may be too large. Cells displayed on your graphics window may be too small for cell category number to be visible."
-msgstr ""
-#: ../display/d.rast.num/main.c:187
-msgid "Aborting."
-msgstr ""
-#: ../display/d.grid/plot.c:356
-#, fuzzy
-msgid ""
-"WGS84 grid output not possible as this location does not contain\n"
-#: ../display/d.grid/plot.c:528
-#, fuzzy
-msgid "Error in pj_do_proj1"
-msgstr "त्रुटि"
-#: ../display/d.grid/plot.c:534
-#, fuzzy
-msgid "Error in pj_do_proj2"
-msgstr "त्रुटि"
-#: ../display/d.grid/plot.c:538
-#, fuzzy
-msgid "Error in pj_do_proj3"
-msgstr "त्रुटि"
-#: ../display/d.grid/plot.c:546
-#, fuzzy
-msgid "Error in pj_do_proj5"
-msgstr "त्रुटि"
-#: ../display/d.grid/plot.c:550
-#, fuzzy
-msgid "Error in pj_do_proj6"
-msgstr "त्रुटि"
-#: ../display/d.grid/main.c:54
-#, fuzzy
-msgid "Overlays a user-specified grid in the active display frame on the graphics monitor."
-msgstr "a चालू."
-#: ../display/d.grid/main.c:62
-msgid "Size of grid to be drawn (0: north-south resolution of the current region)"
-msgstr ""
-#: ../display/d.grid/main.c:63
-msgid "In map units or DDD:MM:SS format. Example: \"1000\" or \"0:10\""
-msgstr ""
-#: ../display/d.grid/main.c:72
-#, fuzzy
-msgid "Lines of the grid pass through this coordinate"
-msgstr "का"
-#: ../display/d.grid/main.c:78
-#, fuzzy
-msgid "Grid line width"
-#: ../display/d.grid/main.c:82
-#, fuzzy
-msgid "Grid color"
-msgstr "किनारा"
-#: ../display/d.grid/main.c:83 ../display/d.grid/main.c:88
-#: ../display/d.grid/main.c:94
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:25
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:28
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:31
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:34
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:37
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:50
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:52
-msgid "Color"
-msgstr ""
-#: ../display/d.grid/main.c:87 ../vector/v.label/main.c:193
-#: ../vector/v.lrs/v.lrs.label/main.c:238 ../vector/v.label.sa/main.c:144
-#, fuzzy
-msgid "Border color"
-msgstr "किनारा"
-#: ../display/d.grid/main.c:102
-msgid "Font size for gridline coordinate labels"
-msgstr ""
-#: ../display/d.grid/main.c:106
-#, fuzzy
-msgid "Align the origin to the east-north corner of the current region"
-msgstr "नहीं"
-#: ../display/d.grid/main.c:111
-msgid "Draw geographic grid (referenced to current ellipsoid)"
-msgstr ""
-#: ../display/d.grid/main.c:116
-msgid "Draw geographic grid (referenced to WGS84 ellipsoid)"
-msgstr ""
-#: ../display/d.grid/main.c:120
-#, fuzzy
-msgid "Draw '+' marks instead of grid lines"
-#: ../display/d.grid/main.c:124
-#, fuzzy
-msgid "Draw '.' marks instead of grid lines"
-#: ../display/d.grid/main.c:128
-#, fuzzy
-msgid "Draw fiducial marks instead of grid lines"
-#: ../display/d.grid/main.c:132
-msgid "Disable grid drawing"
-msgstr ""
-#: ../display/d.grid/main.c:133 ../display/d.grid/main.c:138
-#: ../display/d.grid/main.c:143
-msgid "Disable"
-msgstr ""
-#: ../display/d.grid/main.c:137
-msgid "Disable border drawing"
-msgstr ""
-#: ../display/d.grid/main.c:142
-#, fuzzy
-msgid "Disable text drawing"
-msgstr "पाठ"
-#: ../display/d.grid/main.c:152
-#, fuzzy
-msgid "Both grid and border drawing are disabled"
-msgstr "अक्षम"
-#: ../display/d.grid/main.c:156
-#, fuzzy
-msgid "Geo-Grid option is not available for LL projection"
-#: ../display/d.grid/main.c:158
-#, fuzzy
-msgid "Geo-Grid option is not available for XY projection"
-#: ../display/d.grid/main.c:177
-msgid "Choose a single mark style"
-msgstr ""
-#: ../display/d.grid/main.c:198
-#, fuzzy, c-format
-msgid "Invalid geo-grid size <%s>"
-msgstr "आकार "
-#: ../display/d.grid/main.c:203
-#, fuzzy, c-format
-msgid "Invalid grid size <%s>"
-msgstr "आकार "
-#: ../display/d.grid/fiducial.c:61
-#, fuzzy
-msgid "Reading symbol"
-msgstr "n"
-#: ../display/d.colorlist/main.c:36 ../display/d.fontlist/main.c:39
-#: ../display/d.font/main.c:47
-msgid "setup"
-msgstr ""
-#: ../display/d.his/main.c:67
-msgid "Displays the result obtained by combining hue, intensity, and saturation (his) values from user-specified input raster map layers."
-msgstr ""
-#: ../display/d.his/main.c:95
-msgid "Percent to brighten intensity channel"
-msgstr ""
-#: ../display/d.geodesic/main.c:46
-#, fuzzy
-msgid "Displays a geodesic line, tracing the shortest distance between two geographic points along a great circle, in a longitude/latitude data set."
-msgstr "a दो a वृत्त a सेट."
-#: ../display/d.geodesic/main.c:69
-#, fuzzy
-msgid "Text color or \"none\""
-msgstr "पाठ रंग"
-#: ../display/d.labels/do_labels.c:142
-#, fuzzy, c-format
-msgid "Error: %s\n"
-msgstr "त्रुटि n"
-#: ../display/d.labels/main.c:44 ../vector/v.label/main.c:60
-#: ../vector/v.label.sa/main.c:39
-#, fuzzy
-msgid "paint labels"
-msgstr "फ़ाइलनाम "
-#: ../display/d.labels/main.c:46
-#, fuzzy
-msgid "Displays text labels (created with v.label) to the active frame on the graphics monitor."
-msgstr "पाठ चालू."
-#: ../display/d.labels/main.c:52
-msgid "Ignore rotation setting and draw horizontally"
-msgstr ""
-#: ../display/d.labels/main.c:59
-#, fuzzy
-msgid "Name of label file"
-msgstr "का"
-#: ../display/d.labels/main.c:66
-#, fuzzy
-msgid "Minimum region size (diagonal) when labels are displayed"
-msgstr "आकार "
-#: ../display/d.labels/main.c:73
-#, fuzzy
-msgid "Maximum region size (diagonal) when labels are displayed"
-msgstr "आकार "
-#: ../display/d.labels/main.c:85
-#, fuzzy, c-format
-msgid "Label file <%s> not found"
-msgstr "नहीं"
-#: ../display/d.labels/main.c:97
-#, fuzzy
-msgid "Region size is lower than minreg, nothing displayed."
-#: ../display/d.labels/main.c:105
-#, fuzzy
-msgid "Region size is greater than maxreg, nothing displayed."
-#: ../display/d.labels/main.c:114 ../vector/v.lrs/v.lrs.label/main.c:300
-#, fuzzy, c-format
-msgid "Unable to open label file <%s>"
-msgstr "का"
-#: ../display/d.mon/start.c:58
-#, fuzzy, c-format
-msgid "Monitor <%s> already running"
-msgstr "नहीं"
-#: ../display/d.mon/start.c:68
-#, fuzzy, c-format
-msgid "Unable to create file '%s'"
-msgstr "i n"
-#: ../display/d.mon/start.c:96
-#, c-format
-msgid "Staring monitor <%s> with env file '%s'"
-msgstr ""
-#: ../display/d.mon/stop.c:18 ../display/d.mon/select.c:30
-#, fuzzy, c-format
-msgid "Monitor <%s> is not running"
-msgstr "नहीं"
-#: ../display/d.mon/stop.c:37
-#, fuzzy
-msgid "Env file not found"
-msgstr "नहीं"
-#: ../display/d.mon/stop.c:55
-#, fuzzy
-msgid "PID file not found"
-msgstr "नहीं n"
-#: ../display/d.mon/list.c:45
-#, fuzzy
-msgid "List of running monitors:"
-msgstr "ज़ेड"
-#: ../display/d.mon/list.c:47
-msgid "No monitors running"
-msgstr ""
-#: ../display/d.mon/list.c:82
-#, fuzzy
-msgid "Command file not found"
-msgstr "नहीं"
-#: ../display/d.mon/list.c:86
-#, fuzzy
-msgid "Unable to read command file"
-msgstr "का"
-#: ../display/d.mon/main.c:41
-msgid "Controls graphics display monitors which can be controlled from the command line."
-msgstr ""
-#: ../display/d.mon/main.c:46
-#, fuzzy
-msgid "Name of monitor to start"
-msgstr "का"
-#: ../display/d.mon/main.c:48 ../display/d.mon/main.c:55
-#: ../display/d.mon/main.c:62 ../display/d.mon/main.c:105
-#: ../display/d.mon/main.c:110 ../display/d.mon/main.c:115
-msgid "Manage"
-msgstr ""
-#: ../display/d.mon/main.c:53
-#, fuzzy
-msgid "Name of monitor to stop"
-msgstr "का"
-#: ../display/d.mon/main.c:60
-#, fuzzy
-msgid "Name of monitor to select"
-msgstr "का"
-#: ../display/d.mon/main.c:66
-msgid "Width for display monitor if not set by GRASS_WIDTH"
-msgstr ""
-#: ../display/d.mon/main.c:73
-msgid "Height for display monitor if not set by GRASS_HEIGHT"
-msgstr ""
-#: ../display/d.mon/main.c:83
-#, fuzzy
-msgid "Name for output file (when starting new monitor)"
-msgstr "का का त्रुटि माट्रिक्स काप्पा"
-#: ../display/d.mon/main.c:84
-msgid "Ignored for 'wx' monitors"
-msgstr ""
-#: ../display/d.mon/main.c:89
-#, fuzzy
-msgid "List running monitors and exit"
-msgstr "स्रोत"
-#: ../display/d.mon/main.c:94
-#, fuzzy
-msgid "Print name of currently selected monitor and exit"
-msgstr "छापें"
-#: ../display/d.mon/main.c:99
-#, fuzzy
-msgid "Print commands for currently selected monitor and exit"
-msgstr "स्रोत"
-#: ../display/d.mon/main.c:104
-#, fuzzy
-msgid "Do not automatically select when starting"
-msgstr "नहीं"
-#: ../display/d.mon/main.c:109
-msgid "Release currently selected monitor and exit"
-msgstr ""
-#: ../display/d.mon/main.c:114
-#, fuzzy
-msgid "Disable true colors"
-msgstr "के लिए"
-#: ../display/d.mon/main.c:122
-#, c-format
-msgid "Flag -%c ignored"
-msgstr ""
-#: ../display/d.mon/main.c:126
-msgid "Currently selected monitor:"
-msgstr ""
-#: ../display/d.mon/main.c:130
-#, c-format
-msgid "List of commands for monitor <%s>:"
-msgstr ""
-#: ../display/d.mon/main.c:135
-#, fuzzy, c-format
-msgid "Monitor <%s> released"
-msgstr "नहीं"
-#: ../display/d.mon/main.c:139
-#, fuzzy
-msgid "No monitor selected"
-msgstr "नहीं"
-#: ../display/d.mon/main.c:158
-#, fuzzy, c-format
-msgid "Either <%s>, <%s> or <%s> must be given"
-msgstr "पाठ"
-#: ../display/d.mon/main.c:163
-#, fuzzy, c-format
-msgid "Option <%s> ignored"
-msgstr "n"
-#: ../display/d.mon/select.c:14
-#, fuzzy, c-format
-msgid "Monitor <%s> is already selected"
-msgstr "नहीं"
-#: ../display/d.colortable/main.c:63
-#, fuzzy
-msgid "Displays the color table associated with a raster map layer."
-msgstr "a."
-#: ../display/d.colortable/main.c:67
-#, fuzzy
-msgid "Name of raster map whose color table is to be displayed"
-msgstr "का"
-#: ../display/d.colortable/main.c:75
-#, fuzzy
-msgid "Color of lines separating the colors of the color table"
-msgstr "का का"
-#: ../display/d.colortable/main.c:81
-#, fuzzy
-msgid "Number of lines to appear in the color table"
-msgstr "का फ़िल्टर"
-#: ../display/d.colortable/main.c:87
-#, fuzzy
-msgid "Number of columns to appear in the color table"
-#: ../display/d.colortable/main.c:92
-msgid "Don't draw a collar showing the NULL color in FP maps"
-msgstr ""
-#: ../display/d.colortable/main.c:114
-#, c-format
-msgid "<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
-msgstr ""
-#: ../display/d.colortable/main.c:128
-#, c-format
-msgid "<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
-msgstr ""
-#: ../display/d.colortable/main.c:139
-#, fuzzy, c-format
-msgid "Range file for <%s> not available"
-#: ../display/d.rast/main.c:55
-#, fuzzy
-msgid "Displays user-specified raster map in the active graphics frame."
-msgstr "a के लिए a का."
-#: ../display/d.rast/main.c:68
-#, fuzzy
-msgid "List of categories or values to be displayed"
-msgstr "का"
-#: ../display/d.rast/main.c:74
-#, fuzzy
-msgid "Background color (for null)"
-msgstr "के लिए"
-#: ../display/d.rast/main.c:76 ../display/d.rast/main.c:81
-#: ../display/d.rgb/main.c:63
-msgid "Null cells"
-msgstr ""
-#: ../display/d.rast/main.c:80 ../display/d.rgb/main.c:62
-msgid "Make null cells opaque"
-msgstr ""
-#: ../display/d.rast/main.c:85
-#, fuzzy
-msgid "Invert value list"
-msgstr "विराम चिह्न जी 13"
-#: ../display/d.rast/main.c:205
-#, fuzzy, c-format
-msgid "[%s]: illegal category specified"
-msgstr "है"
-#: ../display/d.rast/main.c:236
-#, fuzzy, c-format
-msgid "[%s]: illegal value specified"
-msgstr "है"
-#: ../display/d.thematic.area/main.c:79
-#, fuzzy
-msgid "Displays a thematic vector area map in the active frame on the graphics monitor."
-msgstr "चालू."
-#: ../display/d.thematic.area/main.c:89
-msgid "Data to be classified: column name or expression"
-msgstr ""
-#: ../display/d.thematic.area/main.c:96
-msgid "Class breaks, without minimum and maximum"
-msgstr ""
-#: ../display/d.thematic.area/main.c:104 ../vector/v.class/main.c:66
-#, fuzzy
-msgid "Algorithm to use for classification"
-msgstr "के लिए"
-#: ../display/d.thematic.area/main.c:105 ../vector/v.class/main.c:67
-msgid "int;simple intervals;std;standard deviations;qua;quantiles;equ;equiprobable (normal distribution);"
-msgstr ""
-#: ../display/d.thematic.area/main.c:116 ../vector/v.class/main.c:78
-#, fuzzy
-msgid "Number of classes to define"
-msgstr "का"
-#: ../display/d.thematic.area/main.c:123
-msgid "Colors (one per class)."
-msgstr ""
-#: ../display/d.thematic.area/main.c:129
-msgid "Layer number. If -1, all layers are displayed."
-msgstr ""
-#: ../display/d.thematic.area/main.c:139 ../display/d.thematic.area/main.c:147
-#, fuzzy
-msgid "Boundaries"
-msgstr "नक़ल"
-#: ../display/d.thematic.area/main.c:140
-#, fuzzy
-msgid "Boundary width"
-#: ../display/d.thematic.area/main.c:146
-#, fuzzy
-msgid "Boundary color"
-msgstr "किनारा"
-#: ../display/d.thematic.area/main.c:153
-msgid "File in which to save d.graph instructions for legend display"
-msgstr ""
-#: ../display/d.thematic.area/main.c:164
-msgid "When printing legend info , include extended statistical info from classification algorithm"
-msgstr ""
-#: ../display/d.thematic.area/main.c:168
-#, fuzzy
-msgid "Do not draw map, only output the legend"
-msgstr "नहीं"
-#: ../display/d.thematic.area/main.c:187
-#, fuzzy, c-format
-msgid "%s: You must build topology on vector map. Run v.build."
-msgstr "नहीं"
-#: ../display/d.thematic.area/main.c:194
-msgid "'layer' must be > 0"
-msgstr ""
-#: ../display/d.thematic.area/main.c:220
-#, fuzzy, c-format
-msgid "Data (%s) not numeric. Column must be numeric."
-msgstr "ज़ेड"
-#: ../display/d.thematic.area/main.c:224
-#: ../display/d.thematic.area/plot1.c:134
-#: ../display/d.thematic.area/plot1.c:162
-#, fuzzy, c-format
-msgid "Cannot select data (%s) from table"
-msgstr "के लिए"
-#: ../display/d.thematic.area/main.c:287
-#, c-format
-msgid "Unknown color: [%s]"
-msgstr ""
-#: ../display/d.thematic.area/main.c:298
-msgid "You gave both manual breaks and a classification algorithm or a number of classes. The manual breaks have precedence and will thus be used."
-msgstr ""
-#: ../display/d.thematic.area/main.c:335
-msgid "You must either give classbreaks or a classification algorithm"
-msgstr ""
-#: ../display/d.thematic.area/main.c:348
-#, c-format
-msgid ""
-"Not enough colors or error in color specifications.\n"
-"Need %i colors."
-msgstr ""
-#: ../display/d.thematic.area/main.c:353
-#, fuzzy, c-format
-msgid "Error interpreting color %s"
-msgstr "त्रुटि के लिए."
-#: ../display/d.thematic.area/main.c:372
-#, fuzzy
-msgid "Plotting ..."
-msgstr "नक़ल"
-#: ../display/d.thematic.area/main.c:379
-#, fuzzy
-msgid "The bounding box of the map is outside the current region, nothing drawn."
-#: ../display/d.thematic.area/main.c:429
-#, fuzzy, c-format
-msgid ""
-"\n"
-"Total number of records: %.0f\n"
-msgstr "संख्या का"
-#: ../display/d.thematic.area/main.c:431
-#, c-format
-msgid "Classification of %s into %i classes\n"
-msgstr ""
-#: ../display/d.thematic.area/main.c:433 ../vector/v.class/main.c:192
-#, c-format
-msgid "Using algorithm: *** %s ***\n"
-msgstr ""
-#: ../display/d.thematic.area/main.c:435 ../vector/v.class/main.c:193
-#, fuzzy, c-format
-msgid "Mean: %f\tStandard deviation = %f\n"
-msgstr "मानक विचलन"
-#: ../display/d.thematic.area/main.c:439
-#, c-format
-msgid "Last chi2 = %f\n"
-msgstr ""
-#: ../display/d.thematic.area/main.c:442 ../vector/v.class/main.c:200
-#, c-format
-msgid "Stdev multiplied by %.4f to define step\n"
-msgstr ""
-#: ../display/d.thematic.area/plot1.c:147
-msgid "Line width column not specified."
-msgstr ""
-#: ../display/d.thematic.area/plot1.c:158
-#, fuzzy, c-format
-msgid "Line width column (%s) not a number."
-#: ../display/d.thematic.area/plot1.c:203
-#, fuzzy, c-format
-msgid ""
-"\n"
-"ERROR: vector map - can't read\n"
-msgstr "n"
-#: ../display/d.thematic.area/plot1.c:278
-#, c-format
-msgid "Error in color definition column (%s), element %d with cat %d: colorstring [%s]"
-msgstr ""
-#: ../display/d.thematic.area/plot1.c:285
-#, c-format
-msgid "Error in color definition column (%s), element %d with cat %d"
-msgstr ""
-#: ../display/d.thematic.area/plot1.c:353
-#, c-format
-msgid "Error in line width column (%s), element %d with cat %d: line width [%d]"
-msgstr ""
-#: ../display/d.fontlist/main.c:40
-#, fuzzy
-msgid "Lists the available fonts."
-msgstr "सभी"
-#: ../display/d.fontlist/main.c:44
-#, fuzzy
-msgid "List fonts (default; provided for compatibility with d.font)"
-msgstr "पाठ"
-#: ../display/d.fontlist/main.c:48 ../display/d.font/main.c:80
-#, fuzzy
-msgid "List fonts verbosely"
-msgstr "सभी"
-#: ../display/d.graph/do_graph.c:65 ../display/d.graph/do_graph.c:81
-#, c-format
-msgid "Problem parsing coordinates [%s]"
-msgstr ""
-#: ../display/d.graph/do_graph.c:98
-msgid "Unable to read color"
-msgstr ""
-#: ../display/d.graph/do_graph.c:129 ../display/d.graph/do_graph.c:195
-#: ../display/d.graph/do_graph.c:216 ../display/d.graph/do_graph.c:267
-#: ../display/d.graph/do_graph.c:334 ../display/d.graph/graphics.c:60
-#, c-format
-msgid "Problem parsing command [%s]"
-msgstr ""
-#: ../display/d.graph/main.c:61
-#, fuzzy
-msgid "Program for generating and displaying simple graphics on the display monitor."
-msgstr "के लिए बनाया जा रहा है चालू."
-#: ../display/d.graph/main.c:68
-#, fuzzy
-msgid "Name of file containing graphics commands, if not given reads from standard input"
-msgstr "का नहीं"
-#: ../display/d.graph/main.c:76
-#, fuzzy
-msgid "Color to draw with, either a standard GRASS color or R:G:B triplet"
-msgstr "a R जी"
-#: ../display/d.graph/main.c:83
-#, fuzzy
-msgid "Coordinates are given in map units"
-msgstr "का बिन्दु"
-#: ../display/d.graph/main.c:94
-#, fuzzy, c-format
-msgid "Graph file <%s> not found"
-msgstr "नहीं"
-#: ../display/d.rgb/main.c:57
-msgid "Displays three user-specified raster maps as red, green, and blue overlays in the active graphics frame."
-msgstr ""
-#: ../display/d.rgb/main.c:68
-#, fuzzy, c-format
-msgid "Name of raster map to be used for '%s'"
-msgstr "का के लिए"
-#: ../display/d.path/main.c:49 ../vector/v.lrs/v.lrs.segment/main.c:72
-#: ../vector/v.lrs/v.lrs.where/main.c:59
-#: ../vector/v.lrs/v.lrs.create/main.c:123
-#: ../vector/v.lrs/v.lrs.label/main.c:104
-#, fuzzy
-msgid "networking"
-msgstr "n"
-#: ../display/d.path/main.c:51
-msgid "Finds shortest path for selected starting and ending node."
-msgstr ""
-#: ../display/d.path/main.c:58 ../vector/v.net.iso/main.c:86
-#: ../vector/v.net.steiner/main.c:361 ../vector/v.net.alloc/main.c:76
-#: ../vector/v.net.salesman/main.c:119 ../vector/v.net.path/main.c:51
-#, fuzzy
-msgid "Arc type"
-msgstr "विशेषता"
-#: ../display/d.path/main.c:70 ../vector/v.net.iso/main.c:90
-#: ../vector/v.net.centrality/main.c:109 ../vector/v.net.steiner/main.c:366
-#: ../vector/v.net/args.c:55 ../vector/v.net.distance/main.c:77
-#: ../vector/v.net.alloc/main.c:81 ../vector/v.net.bridge/main.c:59
-#: ../vector/v.net.flow/main.c:70 ../vector/v.net.timetable/main.c:274
-#: ../vector/v.net.spanningtree/main.c:59 ../vector/v.net.allpairs/main.c:69
-#: ../vector/v.net.components/main.c:82 ../vector/v.net.salesman/main.c:123
-#: ../vector/v.net.path/main.c:56 ../vector/v.net.connectivity/main.c:65
-msgid "Arc layer"
-msgstr ""
-#: ../display/d.path/main.c:75 ../vector/v.net.iso/main.c:95
-#: ../vector/v.net.centrality/main.c:115 ../vector/v.net/args.c:62
-#: ../vector/v.net.distance/main.c:83 ../vector/v.net.alloc/main.c:86
-#: ../vector/v.net.bridge/main.c:65 ../vector/v.net.flow/main.c:76
-#: ../vector/v.net.timetable/main.c:280 ../vector/v.net.spanningtree/main.c:65
-#: ../vector/v.net.allpairs/main.c:75 ../vector/v.net.components/main.c:88
-#: ../vector/v.net.path/main.c:61 ../vector/v.net.connectivity/main.c:71
-msgid "Node layer"
-msgstr ""
-#: ../display/d.path/main.c:81 ../vector/v.net.path/main.c:74
-msgid "Arc forward/both direction(s) cost column"
-msgstr ""
-#: ../display/d.path/main.c:87 ../vector/v.net.path/main.c:80
-msgid "Arc backward direction cost column"
-msgstr ""
-#: ../display/d.path/main.c:93 ../vector/v.net.path/main.c:86
-#, fuzzy
-msgid "Node cost column"
-msgstr "का"
-#: ../display/d.path/main.c:99 ../display/d.extract/main.c:65
-#, fuzzy
-msgid "Original line color"
-msgstr "सेट"
-#: ../display/d.path/main.c:101 ../display/d.path/main.c:109
-#: ../display/d.path/main.c:117 ../display/d.path/main.c:127
-#, fuzzy
-msgid "Rendering"
-msgstr "n"
-#: ../display/d.path/main.c:107 ../display/d.extract/main.c:71
-#, fuzzy
-msgid "Highlight color"
-msgstr "उभारें के लिए पाठ के लिए"
-#: ../display/d.path/main.c:115 ../general/g.cairocomp/main.c:245
-#: ../vector/v.label/main.c:187 ../vector/v.lrs/v.lrs.label/main.c:229
-#: ../vector/v.label.sa/main.c:124
-msgid "Background color"
-msgstr ""
-#: ../display/d.path/main.c:122 ../vector/v.net.iso/main.c:128
-#: ../vector/v.net.centrality/main.c:188 ../vector/v.net.steiner/main.c:396
-#: ../vector/v.net.distance/main.c:139 ../vector/v.net.alloc/main.c:118
-#: ../vector/v.net.spanningtree/main.c:84 ../vector/v.net.allpairs/main.c:106
-#: ../vector/v.net.salesman/main.c:152 ../vector/v.net.path/main.c:103
-#, fuzzy
-msgid "Use geodesic calculation for longitude-latitude locations"
-msgstr "नहीं a"
-#: ../display/d.path/main.c:126
-msgid "Render bold lines"
-msgstr ""
-#: ../display/d.path/main.c:143 ../display/d.path/main.c:147
-#, fuzzy, c-format
-msgid "%s - illegal x value"
-msgstr "है"
-#: ../display/d.path/main.c:145 ../display/d.path/main.c:149
-#, fuzzy, c-format
-msgid "%s - illegal y value"
-msgstr "है"
-#: ../display/d.path/main.c:180 ../vector/v.net.centrality/main.c:222
-#: ../vector/v.net.distance/main.c:169 ../vector/v.net.spanningtree/main.c:113
-#: ../vector/v.net.allpairs/main.c:139 ../vector/v.net.path/main.c:121
-msgid "The current projection is not longitude-latitude"
-msgstr ""
-#: ../display/d.path/select.c:84 ../display/d.path/select.c:101
-#, fuzzy, c-format
-msgid "Node %d: %f %f\n"
-msgstr "f f n"
-#: ../display/d.path/select.c:122
-#, fuzzy, c-format
-msgid "Destination unreachable\n"
-msgstr "n"
-#: ../display/d.path/select.c:125
-#, fuzzy, c-format
-msgid "Costs on the network = %f\n"
-msgstr "खर्च चालू f n"
-#: ../display/d.path/select.c:126
-#, fuzzy, c-format
-msgid ""
-"  Distance to the network = %f, distance from the network = %f\n"
-"\n"
-msgstr "f f n"
-#: ../display/d.rast.arrow/main.c:98
-#, fuzzy
-msgid "Draws arrows representing cell aspect direction for a raster map containing aspect data."
-msgstr "के लिए a."
-#: ../display/d.rast.arrow/main.c:102
-#, fuzzy
-msgid "Name of raster aspect map to be displayed"
-msgstr "का"
-#: ../display/d.rast.arrow/main.c:110
-#, fuzzy
-msgid "Type of existing raster aspect map"
-msgstr "का"
-#: ../display/d.rast.arrow/main.c:118
-#, fuzzy
-msgid "Color for drawing arrows"
-msgstr "के लिए"
-#: ../display/d.rast.arrow/main.c:127
-#, fuzzy
-msgid "Color for drawing grid or \"none\""
-msgstr "के लिए"
-#: ../display/d.rast.arrow/main.c:136
-#, fuzzy
-msgid "Color for drawing X's (null values)"
-msgstr "के लिए शून्य (Null)"
-#: ../display/d.rast.arrow/main.c:145
-#, fuzzy
-msgid "Color for showing unknown information"
-msgstr "के लिए"
-#: ../display/d.rast.arrow/main.c:153
-#, fuzzy
-msgid "Draw arrow every Nth grid cell"
-msgstr "निकालें"
-#: ../display/d.rast.arrow/main.c:162
-#, fuzzy
-msgid "Raster map containing values used for arrow length"
-msgstr "के लिए"
-#: ../display/d.rast.arrow/main.c:169
-#, fuzzy
-msgid "Scale factor for arrows (magnitude map)"
-msgstr "के लिए"
-#: ../display/d.rast.arrow/main.c:205
-#, fuzzy
-msgid "Illegal value for scale factor"
-msgstr "के लिए स्केल."
-#: ../display/d.rast.arrow/main.c:209
-#, fuzzy
-msgid "Illegal value for skip factor"
-msgstr "के लिए."
-#: ../display/d.rast.arrow/main.c:214
-#, fuzzy
-msgid "Magnitude is only supported for GRASS and compass aspect maps."
-msgstr "है के लिए."
-#: ../display/d.rast.arrow/main.c:219
-#, fuzzy
-msgid "Scale option requires magnitude_map"
-msgstr "स्केल"
-#: ../display/d.rast.arrow/main.c:272
-#, fuzzy
-msgid "Problem reading range file"
-msgstr "का"
-#: ../display/d.extract/extract.c:43
-msgid "Select vector(s) with mouse"
-msgstr ""
-#: ../display/d.extract/extract.c:44
-msgid " - L: draw box with left mouse button to select"
-msgstr ""
-#: ../display/d.extract/extract.c:45
-msgid " - M: draw box with middle mouse button to remove from display"
-msgstr ""
-#: ../display/d.extract/extract.c:46
-msgid " - R: quit and save selected vectors to new map\n"
-msgstr ""
-#: ../display/d.extract/extract.c:48
-#, fuzzy
-msgid "L: add  M: remove  R: quit and save\n"
-msgstr "R n"
-#: ../display/d.extract/main.c:52
-msgid "Selects and extracts vectors with mouse into new vector map."
-msgstr ""
-#: ../display/d.extract/main.c:117
-#, fuzzy
-msgid "Copying tables..."
-msgstr "नक़ल"
-#: ../display/d.extract/main.c:125
-#, fuzzy
-msgid "Cannot get db link info -> cannot copy table."
-msgstr "फील्ड"
-#: ../display/d.legend/main.c:87
-#, fuzzy
-msgid "Displays a legend for a raster map in the active frame of the graphics monitor."
-#: ../display/d.legend/main.c:98
-#, fuzzy
-msgid "Sets the legend's text color"
-msgstr "पाठ"
-#: ../display/d.legend/main.c:106
-#, fuzzy
-msgid "Number of text lines (useful for truncating long legends)"
-msgstr "का पाठ के लिए"
-#: ../display/d.legend/main.c:115
-msgid "Thinning factor (thin=10 gives cats 0,10,20...)"
-msgstr ""
-#: ../display/d.legend/main.c:123
-#, fuzzy
-msgid "Number of text labels for smooth gradient legend"
-#: ../display/d.legend/main.c:133
-msgid "Size and placement as percentage of screen coordinates (0,0 is lower left)"
-msgstr ""
-#: ../display/d.legend/main.c:143
-#, fuzzy
-msgid "List of discrete category numbers/values for legend"
-msgstr "का के लिए"
-#: ../display/d.legend/main.c:153
-#, fuzzy
-msgid "Use a subset of the map range for the legend (min,max)"
-msgstr "a का के लिए"
-#: ../display/d.legend/main.c:181
-#, fuzzy
-msgid "Do not show category labels"
-msgstr "नहीं"
-#: ../display/d.legend/main.c:186
-#, fuzzy
-msgid "Do not show category numbers"
-msgstr "नहीं"
-#: ../display/d.legend/main.c:191
-msgid "Skip categories with no label"
-msgstr ""
-#: ../display/d.legend/main.c:196
-#, fuzzy
-msgid "Draw smooth gradient"
-msgstr "निकालें"
-#: ../display/d.legend/main.c:201
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:3
-msgid "Flip legend"
-msgstr ""
-#: ../display/d.legend/main.c:224
-#, c-format
-msgid "Don't know the color %s"
-msgstr ""
-#: ../display/d.legend/main.c:342
-#, fuzzy
-msgid "Legend box lies outside of frame. Text may not display properly."
-msgstr "लीजेंड बक्सा का नहीं."
-#: ../display/d.legend/main.c:346
-#, fuzzy
-msgid "Drawing horizontal legend as box width exceeds height"
-msgstr "बक्सा ऊंचाई n"
-#: ../display/d.legend/main.c:357
-#, fuzzy, c-format
-msgid "Range information for <%s> not available (run r.support)"
-msgstr "सीमा के लिए नहीं"
-#: ../display/d.legend/main.c:362
-#, fuzzy
-msgid "Input map contains no data"
-msgstr "का"
-#: ../display/d.legend/main.c:375 ../display/d.legend/main.c:535
-#, fuzzy
-msgid "Color range exceeds lower limit of actual data"
-msgstr "का"
-#: ../display/d.legend/main.c:381 ../display/d.legend/main.c:539
-#, fuzzy
-msgid "Color range exceeds upper limit of actual data"
-msgstr "का"
-#: ../display/d.legend/main.c:440
-#, fuzzy, c-format
-msgid "use=%s out of range [%d,%d] (extend with range= ?)"
-msgstr "का विस्तार दें"
-#: ../display/d.legend/main.c:481
-#, fuzzy
-msgid "Nothing to draw! (no categories with labels? out of range?)"
-msgstr "का"
-#: ../display/d.legend/main.c:491
-#, fuzzy
-msgid "Forcing a smooth legend: too many categories for current window height"
-msgstr "a के लिए ऊंचाई n"
-#: ../display/d.legend/main.c:546
-#, fuzzy, c-format
-msgid "use=%s out of range [%.3f, %.3f] (extend with range= ?)"
-#: ../display/d.legend/main.c:917
-msgid "Nothing to draw! (no categories with labels?)"
-msgstr ""
-#: ../display/d.measure/main.c:49
-#, fuzzy
-msgid "Measures the lengths and areas of features drawn by the user in the active display frame on the graphics monitor."
-msgstr "का चालू."
-#: ../display/d.measure/main.c:55
-#, fuzzy
-msgid "Line color 1"
-msgstr "सेट"
-#: ../display/d.measure/main.c:63
-#, fuzzy
-msgid "Line color 2"
-msgstr "सेट"
-#: ../display/d.measure/main.c:71
-msgid "Suppress clear screen"
-msgstr ""
-#: ../display/d.measure/main.c:75
-#, fuzzy
-msgid "Output in meters only"
-msgstr "मीटर्स"
-#: ../display/d.measure/main.c:79
-#, fuzzy
-msgid "Output in kilometers as well"
-msgstr "मीटर्स"
-#: ../display/d.title/main.c:52
-#, fuzzy
-msgid "Create a TITLE for a raster map in a form suitable for display with d.text."
-msgstr "a के लिए a a के लिए पाठ."
-#: ../display/d.title/main.c:63
-#, fuzzy
-msgid "Sets the text color"
-msgstr "पाठ"
-#: ../display/d.title/main.c:71
-#, fuzzy
-msgid "Sets the text size as percentage of the frame's height"
-msgstr "पाठ आकार  का ऊंचाई"
-#: ../display/d.title/main.c:75
-#, fuzzy
-msgid "Draw title on current display"
-msgstr "के लिए"
-#: ../display/d.title/main.c:79
-#, fuzzy
-msgid "Do a fancier title"
-msgstr "a शीर्षक"
-#: ../display/d.title/main.c:84
-#, fuzzy
-msgid "Do a simple title"
-msgstr "a शीर्षक"
-#: ../display/d.title/main.c:102
-msgid "Title can be fancy or simple, not both"
-msgstr ""
-#: ../display/d.title/main.c:105
-#, fuzzy
-msgid "No map name given"
-msgstr "नहीं."
-#: ../display/d.font/main.c:49
-#, fuzzy
-msgid "Selects the font in which text will be displayed on the user's graphics monitor."
-msgstr "पाठ चालू."
-#: ../display/d.font/main.c:57
-msgid "Choose new current font"
-msgstr ""
-#: ../display/d.font/main.c:64
-msgid "Path to Freetype-compatible font including file name"
-msgstr ""
-#: ../display/d.font/main.c:72
-msgid "Character encoding"
-msgstr ""
-#: ../display/d.font/main.c:76
-#, fuzzy
-msgid "List fonts"
-msgstr "सभी"
-#: ../display/d.font/main.c:107
-#, fuzzy, c-format
-msgid "Unable to access font path %s: %s"
-msgstr "i n"
-#: ../display/d.font/main.c:111
-#, fuzzy, c-format
-msgid "Font path %s is not a file"
-msgstr "सीमा कम के बराबर नहीं."
-#: ../display/d.font/main.c:128
-#, c-format
-msgid "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
-msgstr ""
-#: ../general/g.filename/main.c:41
-msgid "Prints GRASS data base file names."
-msgstr ""
-#: ../general/g.filename/main.c:49 ../general/g.findfile/main.c:53
-#, fuzzy
-msgid "Name of an element"
-msgstr "का"
-#: ../general/g.filename/main.c:55
-#, fuzzy
-msgid "Name of a database file"
-msgstr "का a"
-#: ../general/g.filename/main.c:61
-#, fuzzy
-msgid "Name of a mapset (default: current)"
-msgstr "का डिफ़ॉल्ट"
-#: ../general/g.gui/main.c:37 ../general/g.cairocomp/main.c:194
-#: ../general/g.mkfontcap/main.c:71 ../general/g.pnmcomp/main.c:283
-#: ../general/g.ppmtopng/main.c:118
-msgid "gui"
-msgstr ""
-#: ../general/g.gui/main.c:39
-msgid "Launches a GRASS graphical user interface (GUI) session."
-msgstr ""
-#: ../general/g.gui/main.c:44
-#, fuzzy
-msgid "GUI type"
-msgstr "अज्ञात क़िस्म"
-#: ../general/g.gui/main.c:45
-msgid "Default value: GRASS_GUI if defined otherwise wxpython"
-msgstr ""
-#: ../general/g.gui/main.c:46
-msgid "wxpython;wxPython based GUI (wxGUI);text;command line interface only"
-msgstr ""
-#: ../general/g.gui/main.c:53
-msgid "Name of workspace file to load on start-up (valid only for wxGUI)"
-msgstr ""
-#: ../general/g.gui/main.c:57
-msgid "Update default GUI setting"
-msgstr ""
-#: ../general/g.gui/main.c:62
-msgid "Do not launch GUI after updating the default GUI setting"
-msgstr ""
-#: ../general/g.gui/main.c:89
-#, c-format
-msgid "<%s> is now the default GUI"
-msgstr ""
-#: ../general/g.gui/main.c:103
-#, c-format
-msgid "Launching <%s> GUI in the background, please wait..."
-msgstr ""
-#: ../general/g.access/set_perms.c:26
-#, fuzzy
-msgid "Unable to change mapset permissions"
-msgstr "का a"
-#: ../general/g.access/main.c:39
-#, fuzzy
-msgid "permission"
-msgstr "नहीं n"
-#: ../general/g.access/main.c:41
-msgid "Controls access to the current mapset for other users on the system."
-msgstr ""
-#: ../general/g.access/main.c:42
-#, fuzzy
-msgid "If no option given, prints current status."
-msgstr "रखें"
-#: ../general/g.access/main.c:49
-msgid "Access for group"
-msgstr ""
-#: ../general/g.access/main.c:57
-msgid "Access for others"
-msgstr ""
-#: ../general/g.access/main.c:64
-msgid "UNIX filesystem access controls are not supported by MS-Windows"
-msgstr ""
-#: ../general/g.access/main.c:72
-msgid "Access to the PERMANENT mapset must be open, nothing changed"
-msgstr ""
-#: ../general/g.access/main.c:76
-#, fuzzy
-msgid "Unable to determine mapset permissions"
-msgstr "का a"
-#: ../general/g.access/exp_perms.c:11 ../general/g.access/exp_perms.c:29
-msgid "have"
-msgstr ""
-#: ../general/g.access/exp_perms.c:12
-msgid "read "
-msgstr ""
-#: ../general/g.access/exp_perms.c:15
-msgid "Everyone"
-msgstr ""
-#: ../general/g.access/exp_perms.c:16
-msgid "has"
-msgstr ""
-#: ../general/g.access/exp_perms.c:19
-msgid "Only users in your group"
-msgstr ""
-#: ../general/g.access/exp_perms.c:22
-msgid "Only users outside your group"
-msgstr ""
-#: ../general/g.access/exp_perms.c:25
-msgid "Only you"
-msgstr ""
-#: ../general/g.access/exp_perms.c:31
-#, c-format
-msgid "%s %s %s %saccess to mapset %s"
-msgstr ""
-#: ../general/g.access/exp_perms.c:32
-msgid "will"
-msgstr ""
-msgid "now"
-msgstr ""
-#: ../general/g.tempfile/main.c:39 ../general/g.pnmcomp/main.c:282
-#, fuzzy
-msgid "support"
-msgstr "सदिश"
-#: ../general/g.tempfile/main.c:41
-msgid "Creates a temporary file and prints it's file name."
-msgstr ""
-#: ../general/g.tempfile/main.c:47
-msgid "Process id to use when naming the tempfile"
-msgstr ""
-#: ../general/g.tempfile/main.c:51
-msgid "Dry run - don't create a file, just prints it's file name"
-msgstr ""
-#: ../general/g.findfile/element.c:7
-#, fuzzy
-msgid "List of available elements:"
-msgstr "सभी"
-#: ../general/g.findfile/main.c:40
-#, fuzzy
-msgid "data base files"
-msgstr "डाटाबेस नाम"
-#: ../general/g.findfile/main.c:42
-msgid "Searches for GRASS data base files and sets variables for the shell."
-msgstr ""
-#: ../general/g.findfile/main.c:59
-#, fuzzy
-msgid "Name of an existing map"
-msgstr "का"
-#: ../general/g.findfile/main.c:65
-#, fuzzy
-msgid "Name of a mapset (default: search path)"
-#: ../general/g.findfile/main.c:66
-#, fuzzy
-msgid "'.' for current mapset"
-msgstr "नहीं"
-#: ../general/g.findfile/main.c:70
-msgid "Don't add quotes"
-msgstr ""
-#: ../general/g.findfile/main.c:74
-#, fuzzy
-msgid "List available elements and exit"
-msgstr "स्रोत"
-#: ../general/g.findfile/main.c:97
-#, c-format
-msgid "Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%s> does not correspond"
-msgstr ""
-#: ../general/g.proj/create.c:17
-#, fuzzy, c-format
-msgid "Unable to create location <%s>: %s"
-msgstr "के लिए"
-#: ../general/g.proj/create.c:20
-#, fuzzy, c-format
-msgid "Unable to create projection files: %s"
-msgstr "फ़ाइल"
-#: ../general/g.proj/create.c:24
-msgid "Unspecified error while creating new location"
-msgstr ""
-#: ../general/g.proj/create.c:26
-#, c-format
-msgid ""
-"You can switch to the new location by\n"
-"`%s=%s`"
-msgstr ""
-#: ../general/g.proj/create.c:36
-#, c-format
-msgid "You must select the PERMANENT mapset before updating the current location's projection (current mapset is <%s>)."
-msgstr ""
-#: ../general/g.proj/create.c:62
-msgid "Default region was updated to the new projection, but if you have multiple mapsets `g.region -d` should be run in each to update the region from the default"
-msgstr ""
-#: ../general/g.proj/create.c:66
-#, fuzzy
-msgid "Projection information updated"
-msgstr "सीमा नहीं."
-#: ../general/g.proj/main.c:64
-#, fuzzy
-msgid "create location"
-msgstr "n"
-#: ../general/g.proj/main.c:67
-msgid "Prints and manipulates GRASS projection information files (in various co-ordinate system descriptions)."
-msgstr ""
-#: ../general/g.proj/main.c:70
-#, fuzzy
-msgid "Can also be used to create new GRASS locations."
-msgstr "के लिए"
-#: ../general/g.proj/main.c:73
-msgid "Prints and manipulates GRASS projection information files."
-msgstr ""
-#: ../general/g.proj/main.c:80
-#, fuzzy
-msgid "Print projection information in conventional GRASS format"
-msgstr "के लिए"
-#: ../general/g.proj/main.c:86
-#, fuzzy
-msgid "Print projection information in shell script style"
-msgstr "छापें"
-#: ../general/g.proj/main.c:92
-msgid "Verify datum information and print transformation parameters"
-msgstr ""
-#: ../general/g.proj/main.c:98
-msgid "Print projection information in PROJ.4 format"
-msgstr ""
-#: ../general/g.proj/main.c:104
-msgid "Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
-msgstr ""
-#: ../general/g.proj/main.c:114
-msgid "Print projection information in WKT format"
-msgstr ""
-#: ../general/g.proj/main.c:120
-msgid "Use ESRI-style format (applies to WKT output only)"
-msgstr ""
-#: ../general/g.proj/main.c:127 ../general/g.proj/main.c:136
-#: ../general/g.proj/main.c:146 ../general/g.proj/main.c:155
-#, fuzzy
-msgid "Specification"
-msgstr "के लिए"
-#: ../general/g.proj/main.c:128
-#, fuzzy
-msgid "Name of georeferenced data file to read projection information from"
-msgstr "का के लिए"
-#: ../general/g.proj/main.c:137
-#, fuzzy
-msgid "Name of ASCII file containing a WKT projection description"
-msgstr "त्रुटि."
-#: ../general/g.proj/main.c:139 ../general/g.proj/main.c:148
-#: ../vector/v.segment/main.c:69
-#, fuzzy
-msgid "'-' for standard input"
-msgstr "नहीं"
-#: ../general/g.proj/main.c:147
-#, fuzzy
-msgid "PROJ.4 projection description"
-msgstr "त्रुटि."
-#: ../general/g.proj/main.c:156
-#, fuzzy
-msgid "EPSG projection code"
-msgstr "पद्धति"
-#: ../general/g.proj/main.c:165 ../general/g.proj/main.c:171
-msgid "Datum"
-msgstr ""
-#: ../general/g.proj/main.c:166
-#, fuzzy
-msgid "Index number of datum transform parameters"
-msgstr "का"
-#: ../general/g.proj/main.c:167
-msgid "\"0\" for unspecified or \"-1\" to list and exit"
-msgstr ""
-#: ../general/g.proj/main.c:173
-msgid "Force override of datum transformation information in input co-ordinate system"
-msgstr ""
-#: ../general/g.proj/main.c:179
-#, fuzzy
-msgid "Create new projection files (modifies current location)"
-msgstr "का"
-#: ../general/g.proj/main.c:187 ../general/g.mapset/main.c:83
-#: ../locale/scriptstrings/r.mask_to_translate.c:6
-#: ../locale/scriptstrings/r.mask_to_translate.c:8
-#, fuzzy
-msgid "Create"
-msgstr "का"
-#: ../general/g.proj/main.c:188
-#, fuzzy
-msgid "Name of new location to create"
-msgstr "के लिए"
-#: ../general/g.proj/main.c:204
-#, c-format
-msgid "Only one of '%s', '%s', '%s' or '%s' options may be specified"
-msgstr ""
-#: ../general/g.proj/main.c:233
-msgid "Projection files missing"
-msgstr ""
-#: ../general/g.proj/main.c:249
-#, c-format
-msgid "Only one of -%c, -%c, -%c, -%c, -%c or -%c flags may be specified"
-msgstr ""
-#: ../general/g.proj/main.c:276
-#, c-format
-msgid "No output format specified, define one of flags -%c, -%c, -%c, or -%c"
-msgstr ""
-#: ../general/g.proj/main.c:280
-#, c-format
-msgid "No output format specified, define one of flags -%c, -%c, or -%c"
-msgstr ""
-#: ../general/g.proj/input.c:91
-#, fuzzy
-msgid "Error reading WKT projection description"
-msgstr "त्रुटि."
-#: ../general/g.proj/input.c:98
-#, fuzzy, c-format
-msgid "Unable to open file '%s' for reading"
-msgstr "के लिए"
-#: ../general/g.proj/input.c:143
-msgid "Can't parse PROJ.4-style parameter string"
-msgstr ""
-#: ../general/g.proj/input.c:181
-#, fuzzy
-msgid "Unable to translate EPSG code"
-msgstr "का a"
-#: ../general/g.proj/input.c:218
-msgid "Trying to open with OGR..."
-msgstr ""
-#: ../general/g.proj/input.c:226 ../general/g.proj/input.c:245
-msgid "...succeeded."
-msgstr ""
-#: ../general/g.proj/input.c:239
-msgid "Trying to open with GDAL..."
-msgstr ""
-#: ../general/g.proj/input.c:254
-#, c-format
-msgid "Could not read georeferenced file %s using either OGR nor GDAL"
-msgstr ""
-#: ../general/g.proj/input.c:259
-#, c-format
-msgid "Read of file %s was successful, but it did not contain projection information. 'XY (unprojected)' will be used"
-msgstr ""
-#: ../general/g.proj/output.c:181
-#, c-format
-msgid "%s: Unable to convert to WKT"
-msgstr ""
-#: ../general/g.mremove/check_reclass.c:18 ../general/g.remove/main.c:38
-#, fuzzy, c-format
-msgid "Raster map <%s@%s> is a base map for <%s>. Remove forced."
-msgstr "सदिश नहीं"
-#: ../general/g.mremove/check_reclass.c:22
-#, fuzzy, c-format
-msgid "Raster map <%s@%s> is a base map. Remove reclassed map first: %s"
-msgstr "नहीं"
-#: ../general/g.mremove/check_reclass.c:45
-#: ../general/g.mremove/check_reclass.c:59
-#, c-format
-msgid "Removing information about reclassed map from [%s@%s] failed"
-msgstr ""
-#: ../general/g.mremove/main.c:63 ../general/g.remove/main.c:103
-#: ../locale/scriptstrings/t.topology_to_translate.c:3
-#: ../locale/scriptstrings/t.remove_to_translate.c:4
-#: ../locale/scriptstrings/t.info_to_translate.c:3
-#, fuzzy
-msgid "remove"
-msgstr "के लिए n"
-#: ../general/g.mremove/main.c:64
-#, fuzzy
-msgid "multi"
-msgstr "के लिए"
-#: ../general/g.mremove/main.c:66
-#, fuzzy
-msgid "Removes data base element files from the user's current mapset using regular expressions."
-msgstr "बेस."
-#: ../general/g.mremove/main.c:71 ../general/g.mlist/main.c:102
-msgid "Use basic regular expressions instead of wildcards"
-msgstr ""
-#: ../general/g.mremove/main.c:76 ../general/g.mlist/main.c:108
-msgid "Use extended regular expressions instead of wildcards"
-msgstr ""
-#: ../general/g.mremove/main.c:81
-#: ../locale/scriptstrings/db.droptable_to_translate.c:4
-#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:4
-msgid "Force removal (required for actual deletion of files)"
-msgstr ""
-#: ../general/g.mremove/main.c:85
-#, fuzzy
-msgid "Remove base raster maps"
-msgstr "के लिए n"
-#: ../general/g.mremove/main.c:93
-#, fuzzy
-msgid "removed"
-msgstr "n"
-#: ../general/g.mremove/main.c:100
-#, c-format
-msgid "-%c and -%c are mutually exclusive"
-msgstr ""
-#: ../general/g.mremove/main.c:104
-msgid "The following data base element files would be deleted:"
-msgstr ""
-#: ../general/g.mremove/main.c:128
-#, fuzzy, c-format
-msgid "Unable to compile pattern <%s>"
-msgstr "का"
-#: ../general/g.mremove/main.c:153
-#, c-format
-msgid "You must use the force flag (-%c) to actually remove them. Exiting."
-msgstr ""
-#: ../general/g.mapset/main.c:50 ../general/g.gisenv/main.c:39
-#: ../general/g.region/main.c:64 ../general/g.mapsets/main.c:60
-#, fuzzy
-msgid "settings"
-msgstr "नहीं n"
-#: ../general/g.mapset/main.c:51
-#, fuzzy
-msgid "Changes/reports current mapset."
-msgstr "नहीं"
-#: ../general/g.mapset/main.c:52
-msgid "Optionally create new mapset or list available mapsets in given location."
-msgstr ""
-#: ../general/g.mapset/main.c:56
-#, fuzzy
-msgid "Name of mapset where to switch"
-msgstr "का"
-#: ../general/g.mapset/main.c:66
-msgid "Location name (not location path)"
-msgstr ""
-#: ../general/g.mapset/main.c:75
-msgid "GIS data directory"
-msgstr ""
-#: ../general/g.mapset/main.c:76
-msgid "Full path to the directory where the new location is"
-msgstr ""
-#: ../general/g.mapset/main.c:81
-#, fuzzy
-msgid "Create mapset if it doesn't exist"
-msgstr "नहीं"
-#: ../general/g.mapset/main.c:88
-#, fuzzy
-msgid "List available mapsets and exit"
-msgstr "स्रोत"
-#: ../general/g.mapset/main.c:94
-#, fuzzy
-msgid "Print current mapset and exit"
-msgstr "छापें"
-#: ../general/g.mapset/main.c:149
-#, fuzzy, c-format
-msgid "<%s> is already the current mapset"
-msgstr "के लिए."
-#: ../general/g.mapset/main.c:158
-#, c-format
-msgid "You don't have permission to use the mapset <%s>"
-msgstr ""
-#: ../general/g.mapset/main.c:168
-#, fuzzy, c-format
-msgid "Mapset <%s> does not exist. Use -c flag to create it."
-msgstr "समूह नहीं बनाया जा रहा है."
-#: ../general/g.mapset/main.c:178
-#, fuzzy
-msgid "Unable to read GIS_LOCK environment variable"
-msgstr "का"
-#: ../general/g.mapset/main.c:194
-#, c-format
-msgid "Lock file of mapset <%s> cannot be checked"
-msgstr ""
-#: ../general/g.mapset/main.c:197
-#, c-format
-msgid "<%s> is currently running GRASS in selected mapset <%s>"
-msgstr ""
-#: ../general/g.mapset/main.c:203
-#, fuzzy
-msgid "Cleaning up temporary files..."
-msgstr "बनाया जा रहा है."
-#: ../general/g.mapset/main.c:217
-msgid "Your shell continues to use the history for the old mapset"
-msgstr ""
-#: ../general/g.mapset/main.c:222
-#, c-format
-msgid ""
-"You can switch the history by commands:\n"
-"history -w; history -r %s/.bash_history; HISTFILE=%s/.bash_history"
-msgstr ""
-#: ../general/g.mapset/main.c:227
-#, c-format
-msgid ""
-"history -S; history -L %s/.history; setenv histfile=%s/.history"
-msgstr ""
-#: ../general/g.mapset/main.c:233
-#, fuzzy, c-format
-msgid "Your current mapset is <%s>"
-msgstr "छापें"
-#: ../general/g.pnmcat/main.c:30 ../general/g.pnmcomp/main.c:53
-#, fuzzy
-msgid "Error reading PPM file"
-msgstr "त्रुटि."
-#: ../general/g.pnmcat/main.c:46 ../general/g.pnmcat/main.c:54
-#: ../general/g.pnmcat/main.c:59 ../general/g.pnmcomp/main.c:68
-#: ../general/g.pnmcomp/main.c:73 ../general/g.pnmcomp/main.c:82
-#: ../general/g.pnmcomp/main.c:133 ../general/g.pnmcomp/main.c:146
-#, fuzzy
-msgid "Invalid PPM file"
-msgstr "के लिए थीटा"
-#: ../general/g.pnmcat/main.c:49
-msgid "Unsupported PPM file (format = P6 required)"
-msgstr ""
-#: ../general/g.pnmcat/main.c:62
-msgid "Unsupported PPM file (maxval = 255 required)"
-msgstr ""
-#: ../general/g.pnmcat/main.c:83 ../general/g.pnmcomp/main.c:95
-#, fuzzy, c-format
-msgid "File <%s> not found"
-msgstr "नहीं"
-#: ../general/g.pnmcat/main.c:93
-#, c-format
-msgid "File <%s> has wrong height (expected %d, got %d"
-msgstr ""
-#: ../general/g.pnmcat/main.c:128
-#, fuzzy
-msgid "Base name of input files"
-msgstr "का"
-#: ../general/g.pnmcat/main.c:134 ../general/g.cairocomp/main.c:209
-#: ../general/g.ppmtopng/main.c:133
-#, fuzzy
-msgid "Name of output file"
-msgstr "के लिए"
-#: ../general/g.pnmcat/main.c:153 ../general/g.cairocomp/main.c:234
-#: ../general/g.pnmcomp/main.c:311
-#, fuzzy
-msgid "Image width"
-msgstr "लकीर की चौड़ाई"
-#: ../general/g.pnmcat/main.c:159 ../general/g.cairocomp/main.c:240
-#: ../general/g.pnmcomp/main.c:317
-msgid "Image height"
-msgstr ""
-#: ../general/g.pnmcat/main.c:185
-#, c-format
-msgid "Row <%d> has wrong width (expected %d, got %d"
-msgstr ""
-#: ../general/g.pnmcat/main.c:190
-#, fuzzy, c-format
-msgid "Invalid height (expected %d, got %d"
-msgstr "n"
-#: ../general/g.pnmcat/main.c:198
-#, fuzzy, c-format
-msgid "Error reading PPM file for tile <%d,%d> at row <%d>"
-#: ../general/g.pnmcat/main.c:204
-#, fuzzy, c-format
-msgid "Error writing PPM file for tile row <%d> at row <%d>"
-#: ../general/g.pnmcat/main.c:213
-#, fuzzy, c-format
-msgid "Incorrect height (expected %d, got %d"
-msgstr "n"
-#: ../general/g.cairocomp/main.c:48
-#, fuzzy, c-format
-msgid "Unable to read input file <%s>"
-msgstr "के लिए"
-#: ../general/g.cairocomp/main.c:51
-#, fuzzy, c-format
-msgid "Unable to parse input file <%s>"
-msgstr "के लिए"
-#: ../general/g.cairocomp/main.c:70
-#, fuzzy, c-format
-msgid "Unable to write output file <%s>"
-msgstr "का"
-#: ../general/g.cairocomp/main.c:112
-#, fuzzy
-msgid "Unable to obtain visual"
-msgstr "के लिए"
-#: ../general/g.cairocomp/main.c:128
-#, fuzzy
-msgid "Failed to initialize output surface"
-msgstr "का"
-#: ../general/g.cairocomp/main.c:147 ../general/g.pnmcomp/main.c:37
-#, fuzzy, c-format
-msgid "Invalid color: %s"
-msgstr "अवैध"
-#: ../general/g.cairocomp/main.c:168
-#, fuzzy
-msgid "Failed to initialize input surface"
-msgstr "के लिए"
-#: ../general/g.cairocomp/main.c:195
-#, fuzzy
-msgid "Overlays multiple X Pixmaps"
-msgstr "का "
-#: ../general/g.cairocomp/main.c:202
-#, fuzzy
-msgid "Names of input files"
-msgstr "का"
-#: ../general/g.cairocomp/main.c:216
-msgid "Output Visual XID"
-msgstr ""
-#: ../general/g.cairocomp/main.c:222
-#, fuzzy
-msgid "Output screen"
-msgstr "नहीं"
-#: ../general/g.cairocomp/main.c:228 ../general/g.pnmcomp/main.c:298
-msgid "Layer opacities"
-msgstr ""
-#: ../general/g.cairocomp/main.c:249
-msgid "Don't composite; just delete input Pixmaps"
-msgstr ""
-#: ../general/g.cairocomp/main.c:281
-msgid "input= and opacity= must have the same number of values"
-msgstr ""
-#: ../general/g.mlist/main.c:64 ../general/g.list/main.c:46
-#: ../locale/scriptstrings/tv.list_to_translate.c:5
-#: ../locale/scriptstrings/tr.list_to_translate.c:5
-#: ../locale/scriptstrings/t.list_to_translate.c:4
-#: ../locale/scriptstrings/tr3.list_to_translate.c:5
-msgid "list"
-msgstr ""
-#: ../general/g.mlist/main.c:66
-#, fuzzy
-msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
-msgstr "बेस का."
-#: ../general/g.mlist/main.c:81
-#, fuzzy
-msgid "Map name search pattern (default: all)"
-msgstr "शीर्षक"
-#: ../general/g.mlist/main.c:82 ../general/g.mlist/main.c:90
-#: ../general/g.mlist/main.c:103 ../general/g.mlist/main.c:109
-#, fuzzy
-msgid "Pattern"
-msgstr "n"
-#: ../general/g.mlist/main.c:89
-#, fuzzy
-msgid "Map name exclusion pattern (default: none)"
-msgstr "शीर्षक"
-#: ../general/g.mlist/main.c:94
-#, fuzzy
-msgid "Name of mapset to list (default: current search path)"
-#: ../general/g.mlist/main.c:113
-#, fuzzy
-msgid "Print data types"
-msgstr "छापें"
-#: ../general/g.mlist/main.c:118
-msgid "Print fully-qualified map names (including mapsets)"
-msgstr ""
-#: ../general/g.mlist/main.c:123
-#, fuzzy
-msgid "Pretty printing in human readable format"
-msgstr "का"
-#: ../general/g.mlist/main.c:128 ../general/g.list/main.c:59
-msgid "Verbose listing (also list map titles)"
-msgstr ""
-#: ../general/g.mlist/main.c:135
-msgid "-r and -e are mutually exclusive"
-msgstr ""
-#: ../general/g.mlist/main.c:254
-#, fuzzy, c-format
-msgid "%s available in mapset <%s>:"
-msgstr "सभी"
-#: ../general/g.version/main.c:44
-#, fuzzy
-msgid "version"
-msgstr "नहीं n"
-#: ../general/g.version/main.c:45
-#, fuzzy
-msgid "Displays version and copyright information."
-msgstr "जानकारी"
-#: ../general/g.version/main.c:49
-#, fuzzy
-msgid "Print also the copyright message"
-msgstr "छापें"
-#: ../general/g.version/main.c:53
-#, fuzzy
-msgid "Print also the GRASS build information"
-msgstr "संख्या के लिए"
-#: ../general/g.version/main.c:58
-msgid "Print also the GIS library revision number and time"
-msgstr ""
-#: ../general/g.version/main.c:62
-#, fuzzy
-msgid "Print info in shell script style"
-msgstr "छापें"
-#: ../general/g.parser/revoke.c:63
-#, fuzzy
-msgid "G_spawn() failed"
-msgstr "नक़ल"
-#: ../general/g.parser/revoke.c:71
-#, fuzzy
-msgid "execl() failed"
-msgstr "नक़ल"
-#: ../general/g.parser/main.c:63
-msgid "Usage"
-msgstr ""
-#: ../general/g.parser/main.c:73
-#, fuzzy
-msgid "Unable to open script file"
-msgstr "का"
-#: ../general/g.parser/main.c:88
-#, c-format
-msgid "Line too long or missing newline at line %d\n"
-msgstr ""
-#: ../general/g.parser/main.c:125
-#, fuzzy
-msgid "Error closing script file"
-msgstr "त्रुटि"
-#: ../general/g.parser/parse.c:22
-#, c-format
-msgid "Unknown boolean value \"%s\" at line %d\n"
-msgstr ""
-#: ../general/g.parser/parse.c:65
-#, fuzzy, c-format
-msgid "Unknown command \"%s\" at line %d\n"
-#: ../general/g.parser/parse.c:92
-#, c-format
-msgid "Unknown module parameter \"%s\" at line %d\n"
-msgstr ""
-#: ../general/g.parser/parse.c:134
-#, c-format
-msgid "Unknown flag parameter \"%s\" at line %d\n"
-msgstr ""
-#: ../general/g.parser/parse.c:149
-#, fuzzy, c-format
-msgid "Unknown type \"%s\" at line %d\n"
-#: ../general/g.parser/parse.c:227
-#, c-format
-msgid "Unknown option parameter \"%s\" at line %d\n"
-msgstr ""
-#: ../general/g.gisenv/main.c:40
-#, fuzzy
-msgid "variables"
-msgstr "चर सेट"
-#: ../general/g.gisenv/main.c:42
-#, fuzzy
-msgid "Outputs and modifies the user's current GRASS variable settings."
-msgstr "चर."
-#: ../general/g.gisenv/main.c:43
-msgid "Prints all defined GRASS variables if no option is given."
-msgstr ""
-#: ../general/g.gisenv/main.c:48
-#, fuzzy
-msgid "GRASS variable to get"
-msgstr "चर"
-#: ../general/g.gisenv/main.c:51
-msgid "Get"
-msgstr ""
-#: ../general/g.gisenv/main.c:56
-#, fuzzy
-msgid "GRASS variable to set"
-msgstr "चर सेट"
-#: ../general/g.gisenv/main.c:59 ../general/g.gisenv/main.c:67
-#: ../general/g.gisenv/main.c:76 ../db/db.connect/main.c:59
-#: ../db/db.connect/main.c:65 ../db/db.connect/main.c:70
-#: ../db/db.connect/main.c:74 ../db/db.connect/main.c:78
-#: ../db/db.connect/main.c:88
-msgid "Set"
-msgstr ""
-#: ../general/g.gisenv/main.c:64
-#, fuzzy
-msgid "GRASS variable to unset"
-msgstr "चर सेट"
-#: ../general/g.gisenv/main.c:74
-#, fuzzy
-msgid "Where GRASS variable is stored"
-msgstr "चर है"
-#: ../general/g.gisenv/main.c:80
-msgid "Use shell syntax (for \"eval\")"
-msgstr ""
-#: ../general/g.gisenv/main.c:81 ../general/g.gisenv/main.c:86
-#: ../vector/v.db.select/main.c:66 ../vector/v.db.select/main.c:72
-#: ../vector/v.db.select/main.c:79 ../vector/v.db.select/main.c:95
-#: ../vector/v.db.select/main.c:100 ../db/db.select/main.c:219
-#: ../db/db.select/main.c:225 ../db/db.select/main.c:232
-#: ../db/db.select/main.c:242 ../db/db.select/main.c:252
-#, fuzzy
-msgid "Format"
-msgstr "फ़ॉन्ट"
-#: ../general/g.gisenv/main.c:85
-msgid "Don't use shell syntax"
-msgstr ""
-#: ../general/g.gisenv/main.c:92
-#, c-format
-msgid "Flags -%c and -%c are mutually exclusive"
-msgstr ""
-#: ../general/g.gisenv/main.c:126 ../vector/v.colors/main.c:184
-#, c-format
-msgid "Options <%s>, <%s>, and <%s> are mutually exclusive"
-msgstr ""
-#: ../general/g.region/main.c:66
-#, fuzzy
-msgid "Manages the boundary definitions for the geographic region."
-msgstr "के लिए."
-#: ../general/g.region/main.c:73 ../general/g.region/main.c:78
-#: ../general/g.region/main.c:166 ../general/g.region/main.c:173
-#: ../general/g.region/main.c:182 ../general/g.region/main.c:189
-#: ../general/g.region/main.c:199
-msgid "Existing"
-msgstr ""
-#: ../general/g.region/main.c:77
-#, fuzzy
-msgid "Save as default region"
-msgstr "सेट"
-#: ../general/g.region/main.c:82
-#, fuzzy
-msgid "Print the current region"
-msgstr "छापें"
-#: ../general/g.region/main.c:87
-#, fuzzy
-msgid "Print the current region in lat/long using the current ellipsoid/datum"
-msgstr "छापें"
-#: ../general/g.region/main.c:93
-#, fuzzy
-msgid "Print the current region extent"
-msgstr "छापें"
-#: ../general/g.region/main.c:99
-#, fuzzy
-msgid "Print the current region map center coordinates"
-msgstr "छापें"
-#: ../general/g.region/main.c:105
-#, fuzzy
-msgid "Print the current region in GMT style"
-msgstr "छापें"
-#: ../general/g.region/main.c:111
-#, fuzzy
-msgid "Print the current region in WMS style"
-msgstr "छापें"
-#: ../general/g.region/main.c:117
-#, fuzzy
-msgid "Print region resolution in meters (geodesic)"
-msgstr "छापें मीटर्स"
-#: ../general/g.region/main.c:122
-msgid "Print the convergence angle (degrees CCW)"
-msgstr ""
-#: ../general/g.region/main.c:124
-msgid "The difference between the projection's grid north and true north, measured at the center coordinates of the current region."
-msgstr ""
-#: ../general/g.region/main.c:130
-#, fuzzy
-msgid "Print also 3D settings"
-msgstr "छापें"
-#: ../general/g.region/main.c:136
-msgid "Print the maximum bounding box in lat/long on WGS84"
-msgstr ""
-#: ../general/g.region/main.c:147
-#, fuzzy
-msgid "Align region to resolution (default = align to bounds, works only for 2D resolution)"
-msgstr "पंक्तिबद्ध करें के लिए"
-#: ../general/g.region/main.c:153
-#, fuzzy
-msgid "Do not update the current region"
-msgstr "नहीं"
-#: ../general/g.region/main.c:154 ../general/g.region/main.c:351
-#: ../vector/v.label/main.c:90 ../vector/v.label/main.c:95
-#: ../vector/v.label/main.c:170 ../vector/v.label/main.c:183
-msgid "Effects"
-msgstr ""
-#: ../general/g.region/main.c:164
-#, fuzzy
-msgid "Set current region from named region"
-msgstr "सेट"
-#: ../general/g.region/main.c:180
-#, fuzzy
-msgid "Set region to match this 3D raster map (both 2D and 3D values)"
-msgstr "सेट जोड़ा"
-#: ../general/g.region/main.c:243
-#, fuzzy
-msgid "Value for the top edge"
-msgstr "के लिए शीर्ष"
-#: ../general/g.region/main.c:252
-#, fuzzy
-msgid "Value for the bottom edge"
-msgstr "के लिए तल"
-#: ../general/g.region/main.c:261
-#, fuzzy
-msgid "Number of rows in the new region"
-msgstr "का"
-#: ../general/g.region/main.c:262 ../general/g.region/main.c:271
-#: ../general/g.region/main.c:281 ../general/g.region/main.c:291
-#: ../general/g.region/main.c:300 ../general/g.region/main.c:309
-#: ../general/g.region/main.c:318
-msgid "Resolution"
-msgstr ""
-#: ../general/g.region/main.c:270
-#, fuzzy
-msgid "Number of columns in the new region"
-msgstr "का"
-#: ../general/g.region/main.c:280
-#, fuzzy
-msgid "Grid resolution 2D (both north-south and east-west)"
-msgstr "उत्तर दक्षिण पूर्व पश्चिम"
-#: ../general/g.region/main.c:290
-#, fuzzy
-msgid "3D grid resolution (north-south, east-west and top-bottom)"
-msgstr "उत्तर दक्षिण पूर्व पश्चिम शीर्ष तल"
-#: ../general/g.region/main.c:299
-#, fuzzy
-msgid "North-south grid resolution 2D"
-msgstr "दक्षिण"
-#: ../general/g.region/main.c:308
-#, fuzzy
-msgid "East-west grid resolution 2D"
-msgstr "दक्षिण"
-#: ../general/g.region/main.c:317
-#, fuzzy
-msgid "Top-bottom grid resolution 3D"
-msgstr "ऊपर तल"
-#: ../general/g.region/main.c:327
-#, fuzzy
-msgid "Shrink region until it meets non-NULL data from this raster map"
-msgstr "सेट जोड़ा"
-#: ../general/g.region/main.c:338
-#, fuzzy
-msgid "Adjust region cells to cleanly align with this raster map"
-msgstr "सेट जोड़ा"
-#: ../general/g.region/main.c:349
-#, fuzzy
-msgid "Save current region settings in named region file"
-msgstr "सेट"
-#: ../general/g.region/main.c:408
-#, fuzzy, c-format
-msgid "Region <%s> not found"
-msgstr "नहीं"
-#: ../general/g.region/main.c:420
-#, fuzzy, c-format
-msgid "3dview file <%s> not found"
-msgstr "नहीं"
-#: ../general/g.region/main.c:425
-#, fuzzy, c-format
-msgid "Unable to open 3dview file <%s> in <%s>"
-msgstr "फ़ाइल"
-#: ../general/g.region/main.c:431
-#, fuzzy, c-format
-msgid "Unable to read 3dview file <%s> in <%s>"
-msgstr "के लिए"
-#: ../general/g.region/main.c:434
-#, fuzzy, c-format
-msgid "Old 3dview file. Region <%s> not found in <%s>"
-msgstr "नहीं"
-#: ../general/g.region/main.c:492
-#, fuzzy, c-format
-msgid "Unable to read header of 3D raster map <%s@%s>"
-msgstr "डाटाटाइप."
-#: ../general/g.region/main.c:518
-#, fuzzy, c-format
-msgid "Unable to open vector map <%s@%s>"
-msgstr "के लिए"
-#: ../general/g.region/main.c:805
-#, fuzzy, c-format
-msgid "Unable to set region <%s>"
-msgstr "i n"
-#: ../general/g.region/main.c:811
-#, fuzzy
-msgid "Unable to update current region"
-msgstr "नहीं"
-#: ../general/g.region/main.c:819
-msgid "Unable to change default region. The current mapset is not <PERMANENT>."
-msgstr ""
-#: ../general/g.region/main.c:836
-#, fuzzy, c-format
-msgid "Invalid input <%s=%s>"
-msgstr "अवैध"
-#: ../general/g.region/printwindow.c:263 ../general/g.region/printwindow.c:516
-#: ../general/g.region/printwindow.c:647
-#, fuzzy
-msgid "Unable to update lat/long projection parameters"
-msgstr "सेट"
-#: ../general/g.region/printwindow.c:410
-msgid "You are already in Lat/Long. Use the -p flag instead."
-msgstr ""
-#: ../general/g.region/printwindow.c:412
-msgid "You are in a simple XY location, projection to Lat/Lon is not possible. Use the -p flag instead."
-msgstr ""
-#: ../general/g.region/printwindow.c:637
-#, fuzzy
-msgid "WGS84 output not possible as this location does not contain datum transformation parameters. Try running g.setproj."
-msgstr "नहीं नहीं रखे हुए कोशिश करें चल रहा है... जी."
-#: ../general/g.region/printwindow.c:783
-msgid "Lat/Long calculations are not possible from a simple XY system"
-msgstr ""
-#: ../general/g.list/main.c:48
-#, fuzzy
-msgid "Lists available GRASS data base files of the user-specified data type."
-msgstr "बेस का."
-#: ../general/g.mkfontcap/main.c:73
-msgid "Generates the font configuration file by scanning various directories for fonts"
-msgstr ""
-#: ../general/g.mkfontcap/main.c:79
-msgid "Overwrite font configuration file if already existing"
-msgstr ""
-#: ../general/g.mkfontcap/main.c:84
-msgid "Write font configuration file to standard output instead of $GISBASE/etc"
-msgstr ""
-#: ../general/g.mkfontcap/main.c:92
-msgid "Comma-separated list of extra directories to scan for Freetype-compatible fonts as well as the defaults (see documentation)"
-msgstr ""
-#: ../general/g.mkfontcap/main.c:109
-#, fuzzy, c-format
-msgid "Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
-msgstr "i n"
-#: ../general/g.mkfontcap/main.c:121
-msgid "This GRASS installation was compiled without Freetype support, extradirs parameter ignored"
-msgstr ""
-#: ../general/g.mkfontcap/main.c:148
-#, fuzzy, c-format
-msgid "Cannot open %s for writing: %s"
-msgstr "फ़ाइल"
-#: ../general/g.setproj/proj.c:168
-#, c-format
-msgid "Unrecognized 'ask' value in parms.table: %s"
-msgstr ""
-#: ../general/g.setproj/proj.c:178
-#, c-format
-msgid "Unrecognized default value in parms.table: %s"
-msgstr ""
-#: ../general/g.setproj/main.c:81
-msgid "Interactively reset the location's projection settings."
-msgstr ""
-#: ../general/g.setproj/main.c:88
-msgid "You must be in the PERMANENT mapset to run g.setproj"
-msgstr ""
-#: ../general/g.setproj/main.c:101
-msgid "PERMANENT: permission denied"
-msgstr ""
-#: ../general/g.setproj/main.c:105
-#, fuzzy
-msgid "Current region cannot be set"
-msgstr "सेट."
-#: ../general/g.setproj/main.c:108
-msgid "Retrieving and setting region failed"
-msgstr ""
-#: ../general/g.setproj/main.c:135
-msgid "Would you still like to change some of the parameters?"
-msgstr ""
-#: ../general/g.setproj/main.c:137
-#, fuzzy
-msgid "The projection information will not be updated"
-#: ../general/g.setproj/main.c:148
-#, c-format
-msgid ""
-"Zone in default geographic region definition: %d\n"
-" is different from zone in PROJ_INFO file: %d"
-msgstr ""
-#: ../general/g.setproj/main.c:158
-msgid "XY-location cannot be projected"
-msgstr ""
-#: ../general/g.setproj/main.c:192
-#, fuzzy
-msgid "Unknown projection"
-#: ../general/g.setproj/main.c:198
-#, c-format
-msgid "Projection %s is not specified in the file 'proj-parms.table'"
-msgstr ""
-#: ../general/g.setproj/main.c:205
-msgid "Do you wish to specify a geodetic datum for this location?"
-msgstr ""
-#: ../general/g.setproj/main.c:214
-#, c-format
-msgid "The current datum is %s (%s)"
-msgstr ""
-#: ../general/g.setproj/main.c:217
-msgid "Do you wish to change the datum (or datum transformation parameters)?"
-msgstr ""
-#: ../general/g.setproj/main.c:225
-#, fuzzy
-msgid "The datum information has not been changed"
-#: ../general/g.setproj/main.c:288
-#, c-format
-msgid "The current ellipsoid is %s"
-msgstr ""
-#: ../general/g.setproj/main.c:290
-msgid "Do you want to change ellipsoid parameter?"
-msgstr ""
-#: ../general/g.setproj/main.c:294
-#, fuzzy
-msgid "The ellipse information has not been changed"
-#: ../general/g.setproj/main.c:311
-#, c-format
-msgid "The radius is currently %f"
-msgstr ""
-#: ../general/g.setproj/main.c:312
-msgid "Do you want to change the radius?"
-msgstr ""
-#: ../general/g.setproj/main.c:314 ../general/g.setproj/main.c:320
-msgid "Enter radius for the sphere in meters"
-msgstr ""
-#: ../general/g.setproj/main.c:336
-#, fuzzy
-msgid "Invalid input ellipsoid"
-msgstr "के लिए"
-#: ../general/g.setproj/main.c:447
-#, c-format
-msgid "The UTM zone is now set to %d"
-msgstr ""
-#: ../general/g.setproj/main.c:450
-msgid "Do you want to change the UTM zone?"
-msgstr ""
-#: ../general/g.setproj/main.c:451
-#, fuzzy
-msgid "UTM zone information has not been updated"
-#: ../general/g.setproj/main.c:456
-msgid "But if you change zone, all the existing data will be interpreted by projection software. GRASS will not automatically re-project or even change the headers for existing maps."
-msgstr ""
-#: ../general/g.setproj/main.c:461
-msgid "Would you still like to change the UTM zone?"
-msgstr ""
-#: ../general/g.setproj/main.c:497
-#, fuzzy, c-format
-msgid "Error writing PROJ_INFO file <%s>"
-msgstr "त्रुटि n"
-#: ../general/g.setproj/main.c:571
-#, c-format
-msgid "Enter plural form of units [meters]: "
-msgstr ""
-#: ../general/g.setproj/main.c:603
-#, c-format
-msgid "Enter singular for unit: "
-msgstr ""
-#: ../general/g.setproj/main.c:611
-#, fuzzy, c-format
-msgid "Enter conversion factor from %s to meters: "
-msgstr "के लिए के लिए"
-#: ../general/g.setproj/main.c:636
-#, fuzzy, c-format
-msgid "Error writing into UNITS output file <%s>"
-msgstr "का"
-#: ../general/g.setproj/main.c:643
-#, fuzzy
-msgid "Unable to write to DEFAULT_WIND region file"
-#: ../general/g.setproj/main.c:645
-#, c-format
-msgid ""
-"\n"
-"Projection information has been recorded for this location\n"
-"\n"
-msgstr ""
-#: ../general/g.setproj/main.c:647
-msgid "The geographic region information in WIND is now obsolete"
-msgstr ""
-#: ../general/g.setproj/main.c:648
-msgid "Run g.region -d to update it"
-msgstr ""
-#: ../general/g.setproj/get_stp.c:43
-msgid "This should not happen see your system admin"
-msgstr ""
-#: ../general/g.setproj/get_stp.c:99
-#, fuzzy
-msgid "Unable to open FIPS code file"
-msgstr "का"
-#: ../general/g.setproj/get_stp.c:125
-#, c-format
-msgid "No match of fips state %d county %d"
-msgstr ""
-#: ../general/g.setproj/get_stp.c:179
-#, fuzzy
-msgid "Reading sf key_value temp file"
-#: ../general/g.setproj/get_stp.c:212
-#, fuzzy
-msgid "Invalid State FIPS code"
-msgstr "अवैध"
-#: ../general/g.setproj/get_stp.c:302
-#, fuzzy
-msgid "Reading cf key_value temp file"
-msgstr "n"
-#: ../general/g.setproj/get_stp.c:336
-#, fuzzy
-msgid "Invalid County FIPS code"
-msgstr "अवैध"
-#: ../general/g.remove/main.c:41
-#, c-format
-msgid "Raster <%s@%s> is a base map. Remove reclassed map <%s> first."
-msgstr ""
-#: ../general/g.remove/main.c:63 ../general/g.remove/main.c:76
-#, c-format
-msgid "Removing information about reclassed map from <%s@%s> failed"
-msgstr ""
-#: ../general/g.remove/main.c:105
-#, fuzzy
-msgid "Removes data base element files from the user's current mapset."
-msgstr "बेस."
-#: ../general/g.remove/main.c:110
-#, fuzzy
-msgid "Force removal for base raster maps"
-msgstr "का"
-#: ../general/g.pnmcomp/main.c:103
-msgid "Expecting PPM but got PGM"
-msgstr ""
-#: ../general/g.pnmcomp/main.c:108
-msgid "Expecting PGM but got PPM"
-msgstr ""
-#: ../general/g.pnmcomp/main.c:111
-#, fuzzy, c-format
-msgid "Invalid magic number: 'P%c'"
-msgstr "संख्या का"
-#: ../general/g.pnmcomp/main.c:124 ../general/g.pnmcomp/main.c:141
-#, fuzzy
-msgid "Invalid PGM file"
-#: ../general/g.pnmcomp/main.c:246
-#, fuzzy
-msgid "Error writing PPM file"
-msgstr "त्रुटि n"
-#: ../general/g.pnmcomp/main.c:263
-#, fuzzy
-msgid "Error writing PGM file"
-msgstr "त्रुटि n"
-#: ../general/g.pnmcomp/main.c:285
-#, fuzzy
-msgid "Overlays multiple PPM image files,"
-msgstr "का "
-#: ../general/g.pnmcomp/main.c:292
-#, fuzzy
-msgid "Name of mask files"
-msgstr "का"
-#: ../general/g.pnmcomp/main.c:305
-#, fuzzy
-msgid "Name for output mask file"
-msgstr "के लिए"
-#: ../general/g.ppmtopng/main.c:34
-#, fuzzy, c-format
-msgid "unable to open input file %s"
-msgstr "के लिए"
-#: ../general/g.ppmtopng/main.c:37
-#, fuzzy, c-format
-msgid "invalid input file %s"
-msgstr "चेतावनी."
-#: ../general/g.ppmtopng/main.c:70 ../general/g.ppmtopng/main.c:74
-#, fuzzy
-msgid "unable to allocate PNG structure"
-msgstr "के लिए"
-#: ../general/g.ppmtopng/main.c:77
-#, fuzzy
-msgid "error writing PNG file"
-msgstr "त्रुटि n"
-#: ../general/g.ppmtopng/main.c:81
-#, fuzzy, c-format
-msgid "unable to open output file %s"
-msgstr "का"
-#: ../general/g.ppmtopng/main.c:126 ../vector/v.net/args.c:76
-#, fuzzy
-msgid "Name of input file"
-msgstr "का"
-#: ../general/g.message/main.c:34
-#, fuzzy
-msgid "scripts"
-msgstr "का"
-#: ../general/g.message/main.c:36
-msgid "Prints a message, warning, progress info, or fatal error in the GRASS way."
-msgstr ""
-#: ../general/g.message/main.c:38
-msgid "This module should be used in scripts for messages served to user."
-msgstr ""
-#: ../general/g.message/main.c:42 ../general/g.message/main.c:47
-#: ../general/g.message/main.c:52 ../general/g.message/main.c:57
-#, fuzzy
-msgid "Type"
-#: ../general/g.message/main.c:43
-msgid "Print message as warning"
-msgstr ""
-#: ../general/g.message/main.c:48
-msgid "Print message as fatal error"
-msgstr ""
-#: ../general/g.message/main.c:53
-#, fuzzy
-msgid "Print message as debug message"
-msgstr "के लिए."
-#: ../general/g.message/main.c:58
-msgid "Print message as progress info"
-msgstr ""
-#: ../general/g.message/main.c:62 ../general/g.message/main.c:67
-#: ../general/g.message/main.c:81
-msgid "Level"
-msgstr ""
-#: ../general/g.message/main.c:63
-msgid "Print message in all but full quiet mode"
-msgstr ""
-#: ../general/g.message/main.c:68
-msgid "Print message only in verbose mode"
-msgstr ""
-#: ../general/g.message/main.c:75
-#, fuzzy
-msgid "Text of the message to be printed"
-msgstr "का"
-#: ../general/g.message/main.c:84
-#, fuzzy
-msgid "Level to use for debug messages"
-msgstr "के लिए."
-#: ../general/g.message/main.c:91
-msgid "Select only one message level"
-msgstr ""
-#: ../general/g.message/main.c:104
-#, fuzzy
-msgid "Unable to parse input message"
-msgstr "का"
-#: ../general/g.dirseps/main.c:37
-msgid "Internal GRASS utility for converting directory separator characters."
-msgstr ""
-#: ../general/g.mapsets/list.c:10
-#, fuzzy
-msgid "Available mapsets:"
-msgstr "सभी"
-#: ../general/g.mapsets/list.c:35
-#, fuzzy
-msgid "Accessible mapsets:"
-msgstr "सभी"
-#: ../general/g.mapsets/main.c:61
-msgid "search path"
-msgstr ""
-#: ../general/g.mapsets/main.c:62
-#, fuzzy
-msgid "Modifies the user's current mapset search path."
-msgstr "छापें"
-#: ../general/g.mapsets/main.c:63
-#, fuzzy
-msgid "Affects the user's access to data existing under the other mapsets in the current location."
-msgstr "अन्य."
-#: ../general/g.mapsets/main.c:71
-#, fuzzy
-msgid "Name(s) of existing mapset(s)"
-msgstr "का"
-#: ../general/g.mapsets/main.c:72 ../general/g.mapsets/main.c:81
-#: ../general/g.mapsets/main.c:90
-msgid "Search path"
-msgstr ""
-#: ../general/g.mapsets/main.c:80
-#, fuzzy
-msgid "Name(s) of existing mapset(s) to add to search path"
-msgstr "का"
-#: ../general/g.mapsets/main.c:89
-#, fuzzy
-msgid "Name(s) of existing mapset(s) to remove from search path"
-msgstr "का"
-#: ../general/g.mapsets/main.c:97
-#, fuzzy
-msgid "List all available mapsets in alphabetical order"
-msgstr "सभी"
-#: ../general/g.mapsets/main.c:102
-#, fuzzy
-msgid "Print mapsets in current search path"
-msgstr "छापें"
-#: ../general/g.mapsets/main.c:107
-msgid "Show mapset selection dialog"
-msgstr ""
-#: ../general/g.mapsets/main.c:132 ../general/g.mapsets/main.c:161
-#, fuzzy, c-format
-msgid "Mapset <%s> not found"
-msgstr "नहीं"
-#: ../general/g.mapsets/main.c:163
-#, fuzzy, c-format
-msgid "Mapset <%s> added to search path"
-#: ../general/g.mapsets/main.c:189
-#, c-format
-msgid "Mapset <%s> removed from search path"
-msgstr ""
-#: ../general/g.mapsets/main.c:222
-msgid "Cannot open SEARCH_PATH for write"
-msgstr ""
-#: ../general/g.rename/main.c:45
-#, fuzzy
-msgid "rename"
-msgstr "n"
-#: ../general/g.rename/main.c:47
-#, fuzzy
-msgid "Renames data base element files in the user's current mapset."
-msgstr "बेस."
-#: ../general/g.rename/main.c:53
-#, fuzzy
-msgid "renamed"
-msgstr "n"
-#: ../general/g.rename/main.c:70
-#, fuzzy, c-format
-msgid "%s <%s> not found"
-msgstr "नहीं"
-#: ../general/g.rename/main.c:74
-#, fuzzy, c-format
-msgid "<%s> already exists in mapset <%s>"
-msgstr "के लिए."
-#: ../general/g.rename/main.c:84
-#, c-format
-msgid "%s=%s,%s: files could be the same, no rename possible"
-msgstr ""
-#: ../general/g.rename/main.c:94
-#, fuzzy
-msgid "Renaming reclass maps"
-msgstr "बनाया जा रहा है i n"
-#: ../general/g.copy/main.c:43
-msgid "copy"
-msgstr ""
-#: ../general/g.copy/main.c:45
-#, fuzzy
-msgid "Copies available data files in the current mapset search path to the user's current mapset."
-msgstr "अन्य."
-#: ../general/g.copy/main.c:52
-#, fuzzy
-msgid "copied"
-#: ../general/g.copy/main.c:67
-#, fuzzy, c-format
-msgid "<%s> not found"
-msgstr "नहीं"
-#: ../general/g.copy/main.c:72
-#, c-format
-msgid "%s=%s,%s: files are the same, no copy required"
-msgstr ""
-#: ../general/g.copy/main.c:77
-#, fuzzy, c-format
-msgid "<%s> already exists"
-msgstr "नहीं"
-#: ../vector/v.random/main.c:88
-#, fuzzy
-msgid "Generates randomly 2D/3D vector points map."
-msgstr "a."
-#: ../vector/v.random/main.c:96
-#, fuzzy
-msgid "Number of points to be created"
-msgstr "संख्या का"
-#: ../vector/v.random/main.c:103
-#, fuzzy
-msgid "Minimum z height (needs -z flag or column name)"
-msgstr "ज़ेड ऊंचाई ज़ेड"
-#: ../vector/v.random/main.c:105 ../vector/v.random/main.c:114
-#: ../vector/v.random/main.c:127 ../vector/v.random/main.c:137
-#: ../vector/v.random/main.c:142
-#, fuzzy
-msgid "3D output"
-msgstr "के लिए"
-#: ../vector/v.random/main.c:112
-#, fuzzy
-msgid "Maximum z height (needs -z flag or column name)"
-#: ../vector/v.random/main.c:121
-msgid "The seed to initialize the random generator. If not set the process id is used."
-msgstr ""
-#: ../vector/v.random/main.c:124
-#, fuzzy
-msgid "Name of column for z values"
-msgstr "का"
-#: ../vector/v.random/main.c:126
-#, fuzzy
-msgid "Writes z values to column"
-msgstr "n"
-#: ../vector/v.random/main.c:134
-#, fuzzy
-msgid "Type of column for z values"
-msgstr "का"
-#: ../vector/v.random/main.c:141 ../vector/v.in.ogr/main.c:238
-msgid "Create 3D output"
-msgstr ""
-#: ../vector/v.random/main.c:146
-#, fuzzy
-msgid "Use drand48() function instead of rand()"
-msgstr "फंक्शन"
-#: ../vector/v.random/main.c:150 ../vector/v.edit/args.c:203
-#: ../vector/v.external/args.c:60 ../vector/v.in.dxf/main.c:80
-#: ../vector/v.in.lidar/main.c:224
-#, fuzzy
-msgid "Do not build topology"
-msgstr "नहीं"
-#: ../vector/v.random/main.c:163
-#, fuzzy, c-format
-msgid "Number of points must be > 0 (%d given)"
-msgstr "संख्या का"
-#: ../vector/v.random/main.c:223
-msgid "Table should contain only two columns"
-msgstr ""
-#: ../vector/v.random/main.c:236
-msgid "You have created unsupported column type. This module supports only INTEGER and DOUBLE PRECISION column types."
-msgstr ""
-#: ../vector/v.random/main.c:272
-#, fuzzy
-msgid "Generating points..."
-msgstr "n"
-#: ../vector/v.net.iso/main.c:71
-msgid "Splits net by cost isolines."
-msgstr ""
-#: ../vector/v.net.iso/main.c:73 ../vector/v.net.centrality/main.c:97
-#: ../vector/v.net.steiner/main.c:346 ../vector/v.net/main.c:46
-#: ../vector/v.net.distance/main.c:62 ../vector/v.net.alloc/main.c:61
-#: ../vector/v.net.bridge/main.c:47 ../vector/v.net.flow/main.c:59
-#: ../vector/v.net.timetable/main.c:261 ../vector/v.net.spanningtree/main.c:47
-#: ../vector/v.net.allpairs/main.c:57 ../vector/v.net.components/main.c:71
-#: ../vector/v.net.salesman/main.c:105 ../vector/v.net.path/main.c:41
-#: ../vector/v.net.connectivity/main.c:54
-#, fuzzy
-msgid "network"
-msgstr "n"
-#: ../vector/v.net.iso/main.c:74
-#, fuzzy
-msgid "isolines"
-msgstr "नहीं"
-#: ../vector/v.net.iso/main.c:76
-msgid "Splits net to bands between cost isolines (direction from centre). Centre node must be opened (costs >= 0). Costs of centre node are used in calculation."
-msgstr ""
-#: ../vector/v.net.iso/main.c:100 ../vector/v.net.centrality/main.c:129
-#: ../vector/v.net.distance/main.c:119 ../vector/v.net.alloc/main.c:93
-#: ../vector/v.net.bridge/main.c:72 ../vector/v.net.flow/main.c:90
-#: ../vector/v.net.timetable/main.c:288 ../vector/v.net.spanningtree/main.c:72
-#: ../vector/v.net.allpairs/main.c:87 ../vector/v.net.components/main.c:95
-#: ../vector/v.net.salesman/main.c:135 ../vector/v.net.connectivity/main.c:78
-msgid "Arc forward/both direction(s) cost column (number)"
-msgstr ""
-#: ../vector/v.net.iso/main.c:104 ../vector/v.net.centrality/main.c:135
-#: ../vector/v.net.distance/main.c:125 ../vector/v.net.alloc/main.c:99
-#: ../vector/v.net.bridge/main.c:78 ../vector/v.net.flow/main.c:96
-#: ../vector/v.net.timetable/main.c:295 ../vector/v.net.allpairs/main.c:93
-#: ../vector/v.net.components/main.c:101
-#: ../vector/v.net.connectivity/main.c:84
-msgid "Arc backward direction cost column (number)"
-msgstr ""
-#: ../vector/v.net.iso/main.c:108 ../vector/v.net.centrality/main.c:142
-#: ../vector/v.net.distance/main.c:131 ../vector/v.net.alloc/main.c:105
-#: ../vector/v.net.bridge/main.c:85 ../vector/v.net.flow/main.c:102
-#: ../vector/v.net.timetable/main.c:302 ../vector/v.net.spanningtree/main.c:78
-#: ../vector/v.net.allpairs/main.c:100 ../vector/v.net.components/main.c:108
-#: ../vector/v.net.connectivity/main.c:92
-#, fuzzy
-msgid "Node cost column (number)"
-msgstr "का"
-#: ../vector/v.net.iso/main.c:114
-msgid "Categories of centres (points on nodes) to which net will be allocated. Layer for this categories is given by nlayer option."
-msgstr ""
-#: ../vector/v.net.iso/main.c:123
-msgid "Costs for isolines"
-msgstr ""
-#: ../vector/v.net.iso/main.c:160
-#, c-format
-msgid "Wrong iso cost: %f"
-msgstr ""
-#: ../vector/v.net.iso/main.c:163
-#, c-format
-msgid "Iso cost: %f less than previous"
-msgstr ""
-#: ../vector/v.net.iso/main.c:165
-#, fuzzy, c-format
-msgid "Iso cost %d: %f"
-msgstr "n"
-#: ../vector/v.net.iso/main.c:172
-msgid "Not enough costs, everything reachable falls to first band"
-msgstr ""
-#: ../vector/v.net.iso/main.c:198 ../vector/v.net.steiner/main.c:441
-#: ../vector/v.net.alloc/main.c:163 ../vector/v.net.salesman/main.c:208
-#, fuzzy
-msgid "Point is not connected to the network"
-msgstr "बिन्दु"
-#: ../vector/v.net.iso/main.c:206
-msgid "Centre at closed node (costs = -1) ignored"
-msgstr ""
-#: ../vector/v.net.iso/main.c:224
-#, fuzzy, c-format
-msgid "Number of centres: %d (nlayer %d)"
-msgstr "का."
-#: ../vector/v.net.iso/main.c:227
-msgid "Not enough centres for selected nlayer. Nothing will be allocated."
-msgstr ""
-#: ../vector/v.net.iso/main.c:247
-#, fuzzy, c-format
-msgid "Calculating costs from centre %d..."
-msgstr "n"
-#: ../vector/v.net.iso/main.c:508 ../vector/v.net.alloc/main.c:343
-#: ../vector/v.net.alloc/main.c:354
-#, fuzzy
-msgid "Cannot get line segment, segment out of line"
-msgstr "फ़ाइल"
-#: ../vector/v.net.centrality/main.c:98
-#, fuzzy
-msgid "centrality measures"
-msgstr "n"
-#: ../vector/v.net.centrality/main.c:100
-msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
-msgstr ""
-#: ../vector/v.net.centrality/main.c:110 ../vector/v.net.centrality/main.c:116
-#: ../vector/v.net.centrality/main.c:130 ../vector/v.net.centrality/main.c:136
-#: ../vector/v.net.centrality/main.c:143 ../vector/v.net.distance/main.c:78
-#: ../vector/v.net.distance/main.c:84 ../vector/v.net.distance/main.c:120
-#: ../vector/v.net.distance/main.c:126 ../vector/v.net.distance/main.c:132
-#: ../vector/v.net.bridge/main.c:60 ../vector/v.net.bridge/main.c:66
-#: ../vector/v.net.bridge/main.c:73 ../vector/v.net.bridge/main.c:79
-#: ../vector/v.net.bridge/main.c:86 ../vector/v.net.flow/main.c:71
-#: ../vector/v.net.flow/main.c:77 ../vector/v.net.flow/main.c:91
-#: ../vector/v.net.flow/main.c:97 ../vector/v.net.flow/main.c:103
-#: ../vector/v.net.timetable/main.c:275 ../vector/v.net.timetable/main.c:281
-#: ../vector/v.net.timetable/main.c:289 ../vector/v.net.timetable/main.c:296
-#: ../vector/v.net.timetable/main.c:303 ../vector/v.net.spanningtree/main.c:60
-#: ../vector/v.net.spanningtree/main.c:66
-#: ../vector/v.net.spanningtree/main.c:73
-#: ../vector/v.net.spanningtree/main.c:79 ../vector/v.net.allpairs/main.c:88
-#: ../vector/v.net.allpairs/main.c:94 ../vector/v.net.allpairs/main.c:101
-#: ../vector/v.net.components/main.c:83 ../vector/v.net.components/main.c:89
-#: ../vector/v.net.components/main.c:96 ../vector/v.net.components/main.c:102
-#: ../vector/v.net.components/main.c:109
-#: ../vector/v.net.connectivity/main.c:66
-#: ../vector/v.net.connectivity/main.c:72
-#: ../vector/v.net.connectivity/main.c:79
-#: ../vector/v.net.connectivity/main.c:85
-#: ../vector/v.net.connectivity/main.c:93
-msgid "Cost"
-msgstr ""
-#: ../vector/v.net.centrality/main.c:148
-#, fuzzy
-msgid "Name of degree centrality column"
-msgstr "का"
-#: ../vector/v.net.centrality/main.c:149 ../vector/v.net.centrality/main.c:155
-#: ../vector/v.net.centrality/main.c:161 ../vector/v.net.centrality/main.c:167
-#, fuzzy
-msgid "Columns"
-msgstr "नहीं"
-#: ../vector/v.net.centrality/main.c:154
-#, fuzzy
-msgid "Name of closeness centrality column"
-msgstr "का"
-#: ../vector/v.net.centrality/main.c:160
-#, fuzzy
-msgid "Name of betweenness centrality column"
-msgstr "का"
-#: ../vector/v.net.centrality/main.c:166
-#, fuzzy
-msgid "Name of eigenvector centrality column"
-msgstr "का"
-#: ../vector/v.net.centrality/main.c:175
-#, fuzzy
-msgid "Maximum number of iterations to compute eigenvector centrality"
-msgstr "संख्या का"
-#: ../vector/v.net.centrality/main.c:183
-msgid "Cummulative error tolerance for eigenvector centrality"
-msgstr ""
-#: ../vector/v.net.centrality/main.c:192 ../vector/v.net.components/main.c:125
-#, fuzzy
-msgid "Add points on nodes"
-msgstr "लोड हो गया n"
-#: ../vector/v.net.centrality/main.c:267 ../vector/v.net.distance/main.c:229
-#: ../vector/v.db.connect/main.c:334 ../vector/v.sample/main.c:192
-#: ../vector/v.net.flow/main.c:184 ../vector/v.net.timetable/main.c:107
-#: ../vector/v.net.components/main.c:187 ../vector/v.net.path/path.c:113
-msgid "Cannot create index"
-msgstr ""
-#: ../vector/v.net.centrality/main.c:271 ../vector/v.net.distance/main.c:233
-#: ../vector/v.net.flow/main.c:188 ../vector/v.net.timetable/main.c:112
-#: ../vector/v.net.allpairs/main.c:180 ../vector/v.net.components/main.c:191
-#: ../vector/v.net.path/path.c:117
-#, fuzzy, c-format
-msgid "Cannot grant privileges on table <%s>"
-msgstr "चालू"
-#: ../vector/v.net.centrality/main.c:316
-#, fuzzy
-msgid "Computing degree centrality measure"
-msgstr "n"
-#: ../vector/v.net.centrality/main.c:320
-msgid "Computing betweenness and/or closeness centrality measure"
-msgstr ""
-#: ../vector/v.net.centrality/main.c:327
-#, fuzzy
-msgid "Computing eigenvector centrality measure"
-msgstr "n"
-#: ../vector/v.net.centrality/main.c:334 ../vector/v.net.allpairs/main.c:237
-#, fuzzy
-msgid "Writing data into the table..."
-msgstr "n"
-#: ../vector/v.type/main.c:41
-#, fuzzy
-msgid "Changes type of vector features."
-msgstr "ऊंचाई के लिए"
-#: ../vector/v.type/main.c:53
-#, fuzzy
-msgid "Feature type to convert from"
-msgstr "विशेषता"
-#: ../vector/v.type/main.c:60
-#, fuzzy
-msgid "Feature type to convert to"
-msgstr "विशेषता"
-#: ../vector/v.type/main.c:115
-#, fuzzy
-msgid "Incompatible types"
-#: ../vector/v.type/main.c:148 ../vector/v.net/main.c:151
-#: ../vector/v.proj/main.c:415 ../vector/v.kcv/main.c:146
-#: ../vector/v.build.polylines/main.c:225 ../vector/v.category/main.c:707
-#: ../vector/v.transform/main.c:279 ../vector/v.rectify/main.c:248
-#, fuzzy
-msgid "Failed to copy attribute table to output map"
-msgstr "के लिए"
-#: ../vector/v.colors.out/make_colors.c:26
-#: ../vector/v.colors.out/scan_cats.c:22 ../vector/v.colors/main.c:229
-#: ../vector/v.surf.rst/main.c:532
-#, fuzzy, c-format
-msgid "Layer <%s> not found"
-msgstr "नहीं"
-#: ../vector/v.colors.out/make_colors.c:30 ../vector/v.extract/main.c:251
-#: ../vector/v.db.connect/main.c:211 ../vector/v.distance/main.c:388
-#: ../vector/v.info/print.c:138 ../vector/v.to.3d/trans3.c:49
-#: ../vector/v.to.3d/trans2.c:47 ../vector/v.db.select/main.c:142
-#: ../vector/v.to.rast3/main.c:78 ../vector/v.to.rast/vect2rast.c:48
-#, fuzzy, c-format
-msgid "Database connection not defined for layer <%s>"
-msgstr "नहीं"
-#: ../vector/v.colors.out/make_colors.c:40 ../vector/v.colors/scan_attr.c:36
-#: ../vector/v.distance/main.c:406 ../vector/v.distance/main.c:439
-#: ../vector/v.reclass/main.c:141 ../vector/v.vect.stats/main.c:396
-#: ../vector/v.to.3d/trans3.c:64 ../vector/v.to.3d/trans2.c:62
-#: ../db/drivers/ogr/execute.c:69
-#, fuzzy, c-format
-msgid "Column <%s> not found in table <%s>"
-msgstr "नहीं"
-#: ../vector/v.colors.out/make_colors.c:43 ../vector/v.colors/scan_attr.c:39
-#, fuzzy, c-format
-msgid "Column <%s> is not numeric"
-msgstr "नहीं"
-#: ../vector/v.colors.out/make_colors.c:50 ../vector/v.colors/scan_attr.c:46
-#, fuzzy
-msgid "No data selected"
-msgstr "नहीं"
-#: ../vector/v.colors.out/scan_cats.c:26 ../vector/v.voronoi/main.c:167
-#: ../vector/v.colors/scan_cats.c:19 ../vector/v.to.db/query.c:23
-#: ../vector/v.to.db/lines.c:75 ../vector/v.to.rast/do_lines.c:35
-#, fuzzy
-msgid "Reading features..."
-msgstr "n"
-#: ../vector/v.colors.out/main.c:53
-#, fuzzy
-msgid "Exports the color table associated with a vector map."
-msgstr "a."
-#: ../vector/v.colors.out/main.c:66
-#, fuzzy
-msgid "Name of attribute (numeric) column to which refer color rules"
-msgstr "का के लिए"
-#: ../vector/v.colors.out/main.c:67
-msgid "If not given color rules are refered to categories"
-msgstr ""
-#: ../vector/v.colors.out/main.c:85
-#, fuzzy, c-format
-msgid "Unable to read color table for vector map <%s>"
-msgstr "के लिए."
-#: ../vector/v.colors.out/main.c:88
-#, fuzzy, c-format
-msgid "No color table defined for vector map <%s>"
-msgstr "के लिए"
-#: ../vector/v.voronoi/main.c:122 ../vector/v.delaunay/main.c:87
-#, fuzzy
-msgid "triangulation"
-msgstr "का"
-#: ../vector/v.voronoi/main.c:123
-#, fuzzy
-msgid "Creates a Voronoi diagram in current region from an input vector map containing points or centroids."
-msgstr "a बिन्दु."
-#: ../vector/v.voronoi/main.c:127 ../vector/v.sample/main.c:82
-#, fuzzy
-msgid "Name of input vector point map"
-msgstr "का"
-#: ../vector/v.voronoi/main.c:136
-msgid "Output tessellation as a graph (lines), not areas"
-msgstr ""
-#: ../vector/v.voronoi/main.c:182
-#, fuzzy
-msgid "Processing Voronoi triangulation..."
-msgstr "संख्या का"
-#: ../vector/v.voronoi/main.c:267 ../vector/v.in.db/main.c:176
-#, fuzzy
-msgid "Writing features..."
-msgstr "n"
-#: ../vector/v.voronoi/main.c:328 ../vector/v.extract/copy_tab.c:53
-#: ../vector/v.select/copy_tabs.c:17 ../vector/v.generalize/misc.c:126
-#, fuzzy
-msgid "Writing attributes..."
-msgstr "छापें"
-#: ../vector/v.voronoi/main.c:340
-#, fuzzy
-msgid "No table"
-msgstr "का a"
-#: ../vector/v.voronoi/main.c:355
-#, fuzzy
-msgid "Cannot copy table"
-msgstr "नक़ल"
-#: ../vector/v.voronoi/main.c:413
-msgid "Output needs topological cleaning"
-msgstr ""
-#: ../vector/v.voronoi/main.c:445
-#, fuzzy
-msgid "Removing incorrect boundaries from output"
-msgstr "समूह"
-#: ../vector/v.voronoi/sw_main.c:166 ../vector/v.distance/main.c:284
-#, fuzzy, c-format
-msgid "No points/centroids found in <%s>"
-msgstr "नहीं"
-#: ../vector/v.net.steiner/main.c:58
-#, c-format
-msgid "Init costs from node %d"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:347
-#, fuzzy
-msgid "steiner tree"
-msgstr "Bin"
-#: ../vector/v.net.steiner/main.c:349
-msgid "Create Steiner tree for the network and given terminals"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:351
-msgid "Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:371
-msgid "Node layer (used for terminals)"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:377
-msgid "Arcs' cost column (for both directions)"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:383
-msgid "Categories of points on terminals (layer is specified by nlayer)"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:391
-#, fuzzy
-msgid "Number of steiner points (-1 for all possible)"
-msgstr "सदिश"
-#: ../vector/v.net.steiner/main.c:455
-#, fuzzy
-msgid "Not enough terminals (< 2)"
-msgstr "ज़ेड"
-#: ../vector/v.net.steiner/main.c:461
-msgid "Requested number of Steiner points > than possible"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:513
-#, c-format
-msgid "Terminal at node [%d] cannot be connected to terminal at node [%d]"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:529
-#, c-format
-msgid "[%d] (not reachable) nodes removed from list of Steiner point candidates"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:534
-#, c-format
-msgid "MST costs = %f"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:540
-#, c-format
-msgid "Search for [%d]. Steiner point"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:561
-#, c-format
-msgid "Steiner point at node [%d] was added to terminals (MST costs = %f)"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:573
-msgid "No Steiner point found -> leaving cycle"
-msgstr ""
-#: ../vector/v.overlay/area_area.c:39 ../vector/v.overlay/line_area.c:69
-#, fuzzy
-msgid "Breaking lines..."
-msgstr "n"
-#: ../vector/v.overlay/area_area.c:43 ../vector/v.in.ogr/main.c:1035
-#: ../vector/v.in.ogr/main.c:1049 ../vector/v.delaunay/main.c:143
-#: ../vector/v.buffer/main.c:625 ../vector/v.buffer/main.c:632
-#, fuzzy
-msgid "Removing duplicates..."
-msgstr "के लिए n"
-#: ../vector/v.overlay/area_area.c:46 ../vector/v.in.ogr/main.c:1053
-#, fuzzy
-msgid "Cleaning boundaries at nodes..."
-msgstr "n"
-#: ../vector/v.overlay/area_area.c:55 ../vector/v.buffer/main.c:650
-#, fuzzy
-msgid "Attaching islands..."
-msgstr "n"
-#: ../vector/v.overlay/area_area.c:68 ../vector/v.buffer/main.c:670
-#: ../vector/v.buffer/main.c:762
-msgid "Cannot calculate area centroid"
-msgstr ""
-#: ../vector/v.overlay/area_area.c:78
-#, fuzzy, c-format
-msgid "Querying vector map <%s>..."
-msgstr "n"
-#: ../vector/v.overlay/area_area.c:103 ../vector/v.overlay/area_area.c:183
-#: ../vector/v.overlay/area_area.c:211 ../vector/v.overlay/line_area.c:161
-#: ../vector/v.overlay/line_area.c:189
-#, fuzzy
-msgid "Attribute not found"
-msgstr "नहीं"
-#: ../vector/v.overlay/area_area.c:114 ../vector/v.in.ogr/main.c:1138
-#, fuzzy
-msgid "Writing centroids..."
-msgstr "छापें"
-#: ../vector/v.overlay/area_area.c:264
-#, fuzzy
-msgid "Attaching centroids..."
-msgstr "n"
-#: ../vector/v.overlay/main.c:60
-#, fuzzy
-msgid "Overlays two vector maps."
-msgstr "का "
-#: ../vector/v.overlay/main.c:63 ../vector/v.select/args.c:10
-#, fuzzy
-msgid "Name of input vector map (A)"
-msgstr "का"
-#: ../vector/v.overlay/main.c:67
-#, fuzzy
-msgid "Layer number or name (vector map A)"
-msgstr "का"
-#: ../vector/v.overlay/main.c:71 ../vector/v.select/args.c:19
-#, fuzzy
-msgid "Feature type (vector map A)"
-msgstr "का"
-#: ../vector/v.overlay/main.c:77 ../vector/v.select/args.c:24
-#, fuzzy
-msgid "Name of input vector map (B)"
-msgstr "का"
-#: ../vector/v.overlay/main.c:81
-#, fuzzy
-msgid "Layer number or name (vector map B)"
-msgstr "का"
-#: ../vector/v.overlay/main.c:85 ../vector/v.select/args.c:33
-#, fuzzy
-msgid "Feature type (vector map B)"
-msgstr "का"
-#: ../vector/v.overlay/main.c:96
-#, fuzzy
-msgid "Operator defines features written to output vector map"
-msgstr "n"
-#: ../vector/v.overlay/main.c:99
-msgid "Feature is written to output if the result of operation 'ainput operator binput' is true. Input feature is considered to be true, if category of given layer is defined."
-msgstr ""
-#: ../vector/v.overlay/main.c:104
-msgid "and;also known as 'intersection' in GIS;or;also known as 'union' in GIS (only for atype=area);not;features from ainput not overlayed by features from binput;xor;features from either ainput or binput but not those from ainput overlayed by binput (only for atype=area)"
-msgstr ""
-#: ../vector/v.overlay/main.c:117
-msgid "Output layer for new category, ainput and binput"
-msgstr ""
-#: ../vector/v.overlay/main.c:118
-msgid "If 0 or not given, the category is not written"
-msgstr ""
-#: ../vector/v.overlay/main.c:123 ../vector/v.in.ogr/main.c:243
-#: ../vector/v.select/args.c:79 ../vector/v.to.points/main.c:215
-#: ../vector/v.in.lidar/main.c:197
-#, fuzzy
-msgid "Do not create attribute table"
-msgstr "नहीं"
-#: ../vector/v.overlay/main.c:154
-#, c-format
-msgid "Operator '%s' is not supported for type line"
-msgstr ""
-#: ../vector/v.overlay/main.c:205
-#, fuzzy, c-format
-msgid "Copying vector features from <%s>..."
-msgstr "n"
-#: ../vector/v.overlay/main.c:232
-#, fuzzy, c-format
-msgid "No %s features found in vector map <%s>. Verify '%s' parameter."
-msgstr "नहीं."
-#: ../vector/v.overlay/main.c:267
-#, fuzzy
-msgid "Collecting input attributes..."
-msgstr "n"
-#: ../vector/v.overlay/main.c:302 ../vector/v.label/main.c:318
-#: ../vector/v.label.sa/labels.c:160
-#, fuzzy
-msgid "Unable to select attributes"
-msgstr "सभी"
-#: ../vector/v.overlay/main.c:353
-#, fuzzy, c-format
-msgid "Unknown column type '%s' of column '%s'"
-msgstr "अज्ञात क़िस्म"
-#: ../vector/v.overlay/main.c:366 ../vector/v.lrs/v.lrs.label/main.c:348
-#: ../vector/v.out.svg/main.c:370 ../vector/v.out.ogr/attrb.c:46
-#, fuzzy
-msgid "Unable to fetch data from table"
-msgstr "सभी"
-#: ../vector/v.overlay/main.c:418
-#, fuzzy, c-format
-msgid "Unknown column type '%s' of column '%s', values lost"
-#: ../vector/v.overlay/main.c:483
-#, fuzzy
-msgid "Building partial topology..."
-msgstr "n"
-#: ../vector/v.overlay/main.c:495
-#, fuzzy
-msgid "Rebuilding topology..."
-msgstr "n"
-#: ../vector/v.kernel/main.c:68
-#, fuzzy, c-format
-msgid "\tScore Value=%f\tsmoothing parameter (standard deviation)=%f"
-msgstr "f f"
-#: ../vector/v.kernel/main.c:107
-msgid "kernel density"
-msgstr ""
-#: ../vector/v.kernel/main.c:109
-#, fuzzy
-msgid "Generates a raster density map from vector point data using a moving kernel or optionally generates a vector density map on a vector network."
-msgstr "a घनत्व a a घनत्व चालू a"
-#: ../vector/v.kernel/main.c:113
-msgid "Input vector with training points"
-msgstr ""
-#: ../vector/v.kernel/main.c:117
-#, fuzzy
-msgid "Input network vector map"
-msgstr "का"
-#: ../vector/v.kernel/main.c:125
-#, fuzzy
-msgid "Output raster/vector map"
-msgstr "ढाल"
-#: ../vector/v.kernel/main.c:131
-#, fuzzy
-msgid "Standard deviation in map units"
-msgstr "त्रुटि"
-#: ../vector/v.kernel/main.c:137
-#, fuzzy
-msgid "Discretization error in map units"
-msgstr "त्रुटि"
-#: ../vector/v.kernel/main.c:144
-#, fuzzy
-msgid "Maximum length of segment on network"
-msgstr "का खण्ड चालू"
-#: ../vector/v.kernel/main.c:151
-#, fuzzy
-msgid "Maximum distance from point to network"
-msgstr "बिन्दु"
-#: ../vector/v.kernel/main.c:158
-#, fuzzy
-msgid "Multiply the density result by this number"
-msgstr "घनत्व संख्या"
-#: ../vector/v.kernel/main.c:165
-#, fuzzy
-msgid "Node method"
-#: ../vector/v.kernel/main.c:169
-msgid "none;No method applied at nodes with more than 2 arcs;split;Equal split (Okabe 2009) applied at nodes;"
-msgstr ""
-#: ../vector/v.kernel/main.c:176
-#, fuzzy
-msgid "Kernel function"
-#: ../vector/v.kernel/main.c:184
-#, fuzzy
-msgid "Try to calculate an optimal standard deviation with 'stddeviation' taken as maximum (experimental)"
-msgstr "कोशिश करें"
-#: ../vector/v.kernel/main.c:189
-#, fuzzy
-msgid "Only calculate optimal standard deviation and exit (no map is written)"
-msgstr "है"
-#: ../vector/v.kernel/main.c:194
-msgid "In network mode, normalize values by sum of density multiplied by length of each segment. Integral over the output map then gives 1.0 * mult"
-msgstr ""
-#: ../vector/v.kernel/main.c:199
-msgid "In network mode, multiply the result by number of input points."
-msgstr ""
-#: ../vector/v.kernel/main.c:216
-#, fuzzy
-msgid "Unknown node method"
-#: ../vector/v.kernel/main.c:234
-#, fuzzy
-msgid "Unknown kernel function"
-#: ../vector/v.kernel/main.c:240
-msgid "Optimal standard deviation calculation is supported only for node method 'none' and kernel function 'gaussian'."
-msgstr ""
-#: ../vector/v.kernel/main.c:244
-msgid "Optimal standard deviation calculation is supported only for kernel function 'gaussian'."
-msgstr ""
-#: ../vector/v.kernel/main.c:301
-#, c-format
-msgid "%d points outside threshold"
-msgstr ""
-#: ../vector/v.kernel/main.c:323
-#, fuzzy, c-format
-msgid "Automatic choice of smoothing parameter (standard deviation), maximum possible value of standard deviation is set to %f"
-msgstr "का का है सेट f"
-#: ../vector/v.kernel/main.c:330
-#, fuzzy, c-format
-msgid "Using maximum distance between points: %f"
-msgstr "f"
-#: ../vector/v.kernel/main.c:344
-#, fuzzy, c-format
-msgid "Number of input points: %d."
-msgstr "का."
-#: ../vector/v.kernel/main.c:345
-#, c-format
-msgid "%d distances read from the map."
-msgstr ""
-#: ../vector/v.kernel/main.c:348
-#, fuzzy, c-format
-msgid "Distances between all points are beyond %e (4 * standard deviation), unable to calculate optimal value."
-msgstr "सभी."
-#: ../vector/v.kernel/main.c:359
-#, fuzzy, c-format
-msgid "Optimal smoothing parameter (standard deviation): %f."
-msgstr "f."
-#: ../vector/v.kernel/main.c:386
-#, fuzzy, c-format
-msgid ""
-"\n"
-"Writing output vector map using smooth parameter=%f."
-msgstr "f."
-#: ../vector/v.kernel/main.c:388 ../vector/v.kernel/main.c:495
-#, fuzzy, c-format
-msgid ""
-"\n"
-"Normalising factor=%f."
-msgstr "f."
-#: ../vector/v.kernel/main.c:493
-#, fuzzy, c-format
-msgid ""
-"\n"
-"Writing output raster map using smooth parameter=%f."
-msgstr "f."
-#: ../vector/v.kernel/main.c:527
-#, c-format
-msgid "Maximum value in output: %e."
-msgstr ""
-#: ../vector/v.kernel/function.c:220
-msgid "Dimension > 2 supported only by gaussian function"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:123
-#, fuzzy
-msgid "Converts vector data into a GRASS vector map using OGR library."
-msgstr "n"
-#: ../vector/v.in.ogr/main.c:129
-#, fuzzy
-msgid "OGR datasource name"
-msgstr "डाटाबेस नाम"
-#: ../vector/v.in.ogr/main.c:130
-#, fuzzy
-msgid ""
-"Examples:\n"
-"\t\tESRI Shapefile: directory containing shapefiles\n"
-"\t\tMapInfo File: directory containing mapinfo files"
-msgstr "n n फ़ाइल"
-#: ../vector/v.in.ogr/main.c:140
-#, fuzzy
-msgid "OGR layer name. If not given, all available layers are imported"
-msgstr "नहीं सभी n n फ़ाइल"
-#: ../vector/v.in.ogr/main.c:142
-#, fuzzy
-msgid ""
-"Examples:\n"
-"\t\tESRI Shapefile: shapefile name\n"
-"\t\tMapInfo File: mapinfo file name"
-msgstr "n n फ़ाइल"
-#: ../vector/v.in.ogr/main.c:156 ../vector/v.in.lidar/main.c:169
-#, fuzzy
-msgid "Import subregion only"
-msgstr "छापें"
-#: ../vector/v.in.ogr/main.c:159 ../vector/v.in.lidar/main.c:172
-#, fuzzy
-msgid "Format: xmin,ymin,xmax,ymax - usually W,S,E,N"
-msgstr "आयात प"
-#: ../vector/v.in.ogr/main.c:170
-msgid "Minimum size of area to be imported (square units)"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:172
-#, fuzzy
-msgid "Smaller areas and islands are ignored. Should be greater than snap^2"
-msgstr "आकार  का छोटा"
-#: ../vector/v.in.ogr/main.c:178
-#, fuzzy
-msgid "Optionally change default input type"
-msgstr "शीर्षक"
-#: ../vector/v.in.ogr/main.c:180
-#, fuzzy
-msgid "point;import area centroids as points;line;import area boundaries as lines;boundary;import lines as area boundaries;centroid;import points as centroids"
-msgstr "n बिन्दु n n n"
-#: ../vector/v.in.ogr/main.c:191
-#, fuzzy
-msgid "Snapping threshold for boundaries"
-#: ../vector/v.in.ogr/main.c:192
-msgid "'-1' for no snap"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:207
-#, fuzzy
-msgid "List of column names to be used instead of original names, first is used for category column"
-msgstr "का का असली है के लिए"
-#: ../vector/v.in.ogr/main.c:213 ../vector/v.external/args.c:47
-#, fuzzy
-msgid "List available OGR layers in data source and exit"
-msgstr "स्रोत"
-#: ../vector/v.in.ogr/main.c:219
-#, fuzzy
-msgid "List available OGR layers including feature types in data source and exit"
-msgstr "स्रोत"
-#: ../vector/v.in.ogr/main.c:233
-#, fuzzy
-msgid "Do not clean polygons (not recommended)"
-msgstr "नहीं नहीं"
-#: ../vector/v.in.ogr/main.c:254 ../vector/v.in.lidar/main.c:208
-#, fuzzy
-msgid "Limit import to the current region"
-msgstr "नहीं"
-#: ../vector/v.in.ogr/main.c:266
-msgid "Change column names to lowercase characters"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:272
-msgid "Create the location specified by the \"location\" parameter and exit. Do not import the vector data."
-msgstr ""
-#: ../vector/v.in.ogr/main.c:291
-msgid "Available OGR Drivers:"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:331
-#, fuzzy, c-format
-msgid "Unable to open data source <%s>"
-msgstr "के लिए."
-#: ../vector/v.in.ogr/main.c:339 ../vector/v.external/list.c:43
-#, c-format
-msgid "Data source <%s> (format '%s') contains %d layers:"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:381 ../vector/v.external/main.c:81
-#, fuzzy, c-format
-msgid "Layer <%s> not available"
-msgstr "नहीं"
-#: ../vector/v.in.ogr/main.c:397
-#, fuzzy
-msgid "No OGR layers available"
-msgstr "नहीं"
-#: ../vector/v.in.ogr/main.c:399
-#, fuzzy, c-format
-msgid "All available OGR layers will be imported into vector map <%s>"
-msgstr "के लिए"
-#: ../vector/v.in.ogr/main.c:404 ../vector/v.edit/main.c:92
-#: ../vector/v.in.lidar/main.c:478
-#, fuzzy, c-format
-msgid "Vector map <%s> already exists"
-msgstr "नहीं"
-#: ../vector/v.in.ogr/main.c:413 ../vector/v.in.lidar/main.c:284
-msgid "Select either the current region flag or the spatial option, not both"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:441 ../vector/v.in.lidar/main.c:312
-#, fuzzy
-msgid "4 parameters required for 'spatial' parameter"
-msgstr "के लिए."
-#: ../vector/v.in.ogr/main.c:667
-#, fuzzy, c-format
-msgid "Counting polygons for %d features (OGR layer <%s>)..."
-msgstr "n"
-#: ../vector/v.in.ogr/main.c:687
-#, fuzzy, c-format
-msgid "Boundary splitting distance in map units: %G"
-msgstr "f"
-#: ../vector/v.in.ogr/main.c:700
-#, fuzzy, c-format
-msgid "Using temporary vector <%s>"
-msgstr "के लिए."
-#: ../vector/v.in.ogr/main.c:778
-#, fuzzy, c-format
-msgid "Column name changed: '%s' -> '%s'"
-msgstr "बदला"
-#: ../vector/v.in.ogr/main.c:802
-#, fuzzy, c-format
-msgid "Writing column <%s> with fixed length %d chars (may be truncated)"
-msgstr "स्थिर"
-#: ../vector/v.in.ogr/main.c:825
-#, fuzzy, c-format
-msgid "Width for column %s set to 255 (was not specified by OGR), some strings may be truncated!"
-msgstr "चौड़ाई के लिए सेट नहीं!"
-#: ../vector/v.in.ogr/main.c:837
-#, fuzzy, c-format
-msgid "Writing column %s with fixed length %d chars (may be truncated)"
-msgstr "स्थिर"
-#: ../vector/v.in.ogr/main.c:841
-#, fuzzy, c-format
-msgid "Column type not supported (%s)"
-msgstr "नहीं"
-#: ../vector/v.in.ogr/main.c:856 ../vector/v.in.lidar/main.c:591
-#, fuzzy, c-format
-msgid "Unable open database <%s> by driver <%s>"
-msgstr "स्रोत"
-#: ../vector/v.in.ogr/main.c:888
-#, fuzzy, c-format
-msgid "Importing %d features (OGR layer <%s>)..."
-msgstr "n"
-#: ../vector/v.in.ogr/main.c:984
-#, c-format
-msgid "%d %s without geometry"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1012
-#, fuzzy
-msgid "Cleaning polygons, result is not guaranteed!"
-msgstr "है नहीं n"
-#: ../vector/v.in.ogr/main.c:1016
-#, fuzzy, c-format
-msgid "Snapping boundaries (threshold = %.3e)..."
-msgstr "n"
-#: ../vector/v.in.ogr/main.c:1030 ../vector/v.buffer/main.c:622
-#, fuzzy
-msgid "Breaking polygons..."
-msgstr "प्लाट"
-#: ../vector/v.in.ogr/main.c:1045 ../vector/v.buffer/main.c:629
-#, fuzzy
-msgid "Breaking boundaries..."
-msgstr "n"
-#: ../vector/v.in.ogr/main.c:1060
-#, fuzzy
-msgid "Merging boundaries..."
-msgstr "n"
-#: ../vector/v.in.ogr/main.c:1065
-#, fuzzy
-msgid "Changing boundary dangles to lines..."
-msgstr "n"
-#: ../vector/v.in.ogr/main.c:1069
-#, fuzzy
-msgid "Removing dangles..."
-msgstr "के लिए n"
-#: ../vector/v.in.ogr/main.c:1075
-#, fuzzy
-msgid "Changing boundary bridges to lines..."
-msgstr "n"
-#: ../vector/v.in.ogr/main.c:1079
-#, fuzzy
-msgid "Removing bridges..."
-msgstr "के लिए n"
-#: ../vector/v.in.ogr/main.c:1098 ../vector/v.delaunay/main.c:171
-#: ../vector/v.category/main.c:315
-#, fuzzy
-msgid "Unable to calculate area centroid"
-msgstr "के लिए"
-#: ../vector/v.in.ogr/main.c:1114
-#, fuzzy, c-format
-msgid "Finding centroids for OGR layer <%s>..."
-msgstr "n"
-#: ../vector/v.in.ogr/main.c:1181
-#, fuzzy, c-format
-msgid "%d areas represent more (overlapping) features, because polygons overlap in input layer(s). Such areas are linked to more than 1 row in attribute table. The number of features for those areas is stored as category in layer %d"
-msgstr "अधिक अधिक संख्या का के लिए है"
-#: ../vector/v.in.ogr/main.c:1191
-#, fuzzy, c-format
-msgid "%d input polygons\n"
-msgstr "n"
-#: ../vector/v.in.ogr/main.c:1192
-#, fuzzy, c-format
-msgid "%d input polygons"
-msgstr "n"
-#: ../vector/v.in.ogr/main.c:1195
-#, fuzzy, c-format
-msgid "Total area: %G (%d areas)\n"
-msgstr "n"
-#: ../vector/v.in.ogr/main.c:1196
-#, fuzzy, c-format
-msgid "Total area: %G (%d areas)"
-msgstr "n"
-#: ../vector/v.in.ogr/main.c:1199
-#, fuzzy, c-format
-msgid "Overlapping area: %G (%d areas)\n"
-msgstr "n"
-#: ../vector/v.in.ogr/main.c:1201
-#, fuzzy, c-format
-msgid "Overlapping area: %G (%d areas)"
-msgstr "n"
-#: ../vector/v.in.ogr/main.c:1205
-#, fuzzy, c-format
-msgid "Area without category: %G (%d areas)\n"
-msgstr "संपादन के लिए "
-#: ../vector/v.in.ogr/main.c:1207
-#, fuzzy, c-format
-msgid "Area without category: %G (%d areas)"
-#: ../vector/v.in.ogr/main.c:1264
-#, fuzzy
-msgid "Input data contains 3D features. Created vector is 2D only, use -z flag to import 3D vector."
-msgstr "है ज़ेड."
-#: ../vector/v.in.ogr/geom.c:195 ../vector/v.in.ogr/geom.c:216
-#, fuzzy
-msgid "Unable to read part of geometry"
-msgstr "डाटाटाइप."
-#: ../vector/v.in.ogr/geom.c:256 ../vector/v.in.ogr/geom.c:269
-#: ../vector/v.in.ogr/geom.c:297 ../vector/v.in.ogr/geom.c:343
-msgid "Skipping empty geometry feature"
-msgstr ""
-#: ../vector/v.in.ogr/geom.c:313
-#, c-format
-msgid "Degenerate polygon (%d vertices)"
-msgstr ""
-#: ../vector/v.in.ogr/geom.c:356
-#, c-format
-msgid "Degenerate island ([%d] vertices)"
-msgstr ""
-#: ../vector/v.in.ogr/geom.c:390
-#, fuzzy
-msgid "Unable calculate centroid"
-msgstr "के लिए"
-#: ../vector/v.in.ogr/geom.c:421
-msgid "No centroid written for polygon with 0 vertices"
-msgstr ""
-#: ../vector/v.in.ogr/geom.c:442
-#, fuzzy
-msgid "Unable to write part of geometry"
-msgstr "डाटाटाइप."
-#: ../vector/v.in.ogr/geom.c:448
-#, fuzzy
-msgid "Unknown geometry type"
-#: ../vector/v.net/args.c:12
-#, fuzzy
-msgid "Name of input vector line map (arcs)"
-msgstr "का"
-#: ../vector/v.net/args.c:13
-msgid "Required for operation 'nodes', 'connect', 'report' and 'nreport'"
-msgstr ""
-#: ../vector/v.net/args.c:15 ../vector/v.net/args.c:56
-msgid "Arcs"
-msgstr ""
-#: ../vector/v.net/args.c:19
-#, fuzzy
-msgid "Name of input vector point map (nodes)"
-msgstr "का"
-#: ../vector/v.net/args.c:21
-msgid "Required for operation 'connect' and 'arcs'"
-msgstr ""
-#: ../vector/v.net/args.c:23 ../vector/v.net/args.c:63
-#: ../vector/v.net/args.c:85
-msgid "Nodes"
-msgstr ""
-#: ../vector/v.net/args.c:34
-#: ../locale/scriptstrings/g.extension_to_translate.c:7
-#, fuzzy
-msgid "Operation to be performed"
-msgstr "नहीं"
-#: ../vector/v.net/args.c:36
-msgid "nodes;new point is placed on each node (line end) if doesn't exist;connect;connect still unconnected points to vector network by inserting new line(s);arcs;new line is created from start point to end point;report;print to standard output {line_category start_point_category end_point_category};nreport;print to standard output {point_category line_category[,line_category...]}"
-msgstr ""
-#: ../vector/v.net/args.c:72
-msgid "Required for operation 'connect'. Connect points in given threshold."
-msgstr ""
-#: ../vector/v.net/args.c:78
-#, fuzzy
-msgid "Required for operation 'arcs'. '-' for standard input."
-msgstr "का"
-#: ../vector/v.net/args.c:83
-msgid "Assign unique categories to new points"
-msgstr ""
-#: ../vector/v.net/args.c:84
-#, fuzzy
-msgid "For operation 'nodes'"
-#: ../vector/v.net/args.c:106
-#, fuzzy
-msgid "Unknown operation"
-#: ../vector/v.net/args.c:133
-msgid "Threshold value must be >= 0"
-msgstr ""
-#: ../vector/v.net/connect.c:64
-#, fuzzy
-msgid "Failed to find intersection segment"
-msgstr "का"
-#: ../vector/v.net/main.c:47
-#, fuzzy
-msgid "maintenance"
-msgstr "के लिए थीटा"
-#: ../vector/v.net/main.c:48
-msgid "Performs network maintenance."
-msgstr ""
-#: ../vector/v.net/main.c:119
-#, fuzzy, c-format
-msgid "Unable to open vector map <%s> at topology level %d"
-msgstr "के लिए."
-#: ../vector/v.net/main.c:135
-#, fuzzy, c-format
-msgid "%d new points (nodes) written to output."
-msgstr "n"
-#: ../vector/v.net/main.c:145
-#, fuzzy, c-format
-msgid "%d lines (arcs) written to output."
-msgstr "n"
-#: ../vector/v.net/main.c:149 ../vector/v.transform/main.c:277
-#: ../vector/v.to.3d/main.c:98 ../vector/v.to.3d/main.c:128
-#: ../vector/v.in.db/main.c:215
-#, fuzzy
-msgid "Copying attributes..."
-msgstr "नहीं"
-#: ../vector/v.net/report.c:29
-#, c-format
-msgid "Line %d has no category"
-msgstr ""
-#: ../vector/v.net/report.c:52
-#, c-format
-msgid "Point not found: %.3lf %.3lf %.3lf line category: %d"
-msgstr ""
-#: ../vector/v.net/report.c:55
-#, c-format
-msgid "%d points found: %.3lf %.3lf %.3lf line category: %d"
-msgstr ""
-#: ../vector/v.net/arcs.c:42
-#, fuzzy, c-format
-msgid "Error reading file: '%s'"
-msgstr "त्रुटि के लिए."
-#: ../vector/v.net/arcs.c:48
-#, c-format
-msgid "Skipping arc %d"
-msgstr ""
-#: ../vector/v.net/arcs.c:85
-#, fuzzy, c-format
-msgid "No point with category %d found"
-msgstr "नहीं के लिए"
-#: ../vector/v.net/arcs.c:89
-#, fuzzy, c-format
-msgid "More points with category %d found"
-#: ../vector/v.proj/main.c:69
-#, fuzzy
-msgid "Re-projects a vector map from one location to the current location."
-msgstr "a एक."
-#: ../vector/v.proj/main.c:81
-#, fuzzy
-msgid "Location containing input vector map"
-msgstr "का"
-#: ../vector/v.proj/main.c:89
-#, fuzzy
-msgid "Mapset containing input vector map"
-msgstr "का"
-#: ../vector/v.proj/main.c:105
-#, fuzzy
-msgid "Name for output vector map (default: input)"
-msgstr "शीर्षक"
-#: ../vector/v.proj/main.c:110
-#, fuzzy
-msgid "List vector maps in input location and exit"
-msgstr "स्रोत"
-#: ../vector/v.proj/main.c:114
-#, fuzzy
-msgid "3D vector maps only"
-msgstr "नहीं"
-#: ../vector/v.proj/main.c:116
-msgid "Assume z co-ordinate is ellipsoidal height and transform if possible"
-msgstr ""
-#: ../vector/v.proj/main.c:122
-msgid "Latlon output only, default is -180,180"
-msgstr ""
-#: ../vector/v.proj/main.c:124
-msgid "Disable wrapping to -180,180 for latlon output"
-msgstr ""
-#: ../vector/v.proj/main.c:204
-#, fuzzy, c-format
-msgid "Vector map <%s> in location <%s> mapset <%s> not found"
-msgstr "सदिश नहीं"
-#: ../vector/v.proj/main.c:233
-#, fuzzy, c-format
-msgid "Mapset <%s> in input location <%s> - permission denied"
-msgstr "समूह के लिए n"
-#: ../vector/v.proj/main.c:236
-#, fuzzy, c-format
-msgid "Mapset <%s> in input location <%s> not found"
-#: ../vector/v.proj/main.c:280 ../vector/v.proj/main.c:400
-#: ../vector/v.rectify/main.c:210
-#, fuzzy
-msgid "Reading input vector map"
-msgstr "का"
-#: ../vector/v.proj/main.c:303
-#, fuzzy, c-format
-msgid "Input vector map <%s> is empty"
-msgstr "नहीं"
-#: ../vector/v.proj/main.c:311 ../vector/v.proj/main.c:322
-#: ../vector/v.proj/main.c:337 ../vector/v.proj/main.c:352
-#: ../vector/v.proj/main.c:406
-#, fuzzy
-msgid "Error in pj_do_transform"
-msgstr "त्रुटि"
-#: ../vector/v.proj/main.c:389
-#, fuzzy, c-format
-msgid "Reprojecting primitives: "
-msgstr "बनाया जा रहा है."
-#: ../vector/v.proj/main.c:423
-msgid "Try to disable wrapping to -180,180 if topological errors occurred."
-msgstr ""
-#: ../vector/v.label/main.c:62
-#, fuzzy
-msgid "Creates paint labels for a vector map from attached attributes."
-msgstr "के लिए संलग्न है."
-#: ../vector/v.label/main.c:67 ../vector/v.label.sa/main.c:61
-#, fuzzy
-msgid "Name for new paint-label file"
-msgstr "के लिए"
-#: ../vector/v.label/main.c:69
-msgid "If not given the name of the input map is used"
-msgstr ""
-#: ../vector/v.label/main.c:78 ../vector/v.label.sa/main.c:57
-#, fuzzy
-msgid "Name of attribute column to be used for labels"
-msgstr "का के लिए"
-#: ../vector/v.label/main.c:89
-msgid "Rotate labels to align with lines"
-msgstr ""
-#: ../vector/v.label/main.c:94
-msgid "Curl labels along lines"
-msgstr ""
-#: ../vector/v.label/main.c:99
-msgid "Offset label in x-direction"
-msgstr ""
-#: ../vector/v.label/main.c:102 ../vector/v.label/main.c:109
-#: ../vector/v.label/main.c:118 ../vector/v.label/main.c:162
-msgid "Placement"
-msgstr ""
-#: ../vector/v.label/main.c:106
-msgid "Offset label in y-direction"
-msgstr ""
-#: ../vector/v.label/main.c:113 ../vector/v.lrs/v.lrs.label/main.c:174
-msgid "Reference position"
-msgstr ""
-#: ../vector/v.label/main.c:125 ../vector/v.label/main.c:132
-#: ../vector/v.label/main.c:140 ../vector/v.label/main.c:148
-#: ../vector/v.lrs/v.lrs.label/main.c:181 ../vector/v.label.sa/main.c:72
-#: ../vector/v.label.sa/main.c:80
-#, fuzzy
-msgid "Font"
-msgstr "फ़ॉन्ट"
-#: ../vector/v.label/main.c:129 ../vector/v.lrs/v.lrs.label/main.c:187
-#: ../vector/v.label.sa/main.c:77
-#, fuzzy
-msgid "Label size (in map-units)"
-msgstr "आकार "
-#: ../vector/v.label/main.c:137
-#, fuzzy
-msgid "Space between letters for curled labels (in map-units)"
-msgstr "के लिए"
-#: ../vector/v.label/main.c:144
-#, fuzzy
-msgid "Label size (in points)"
-msgstr "आकार "
-#: ../vector/v.label/main.c:156
-#, fuzzy
-msgid "Rotation angle (degrees counter-clockwise)"
-msgstr "कोण कोण"
-#: ../vector/v.label/main.c:166
-#, fuzzy
-msgid "Border width"
-msgstr "लकीर की चौड़ाई"
-#: ../vector/v.label/main.c:174 ../vector/v.lrs/v.lrs.label/main.c:211
-#: ../vector/v.label.sa/main.c:107
-#, fuzzy
-msgid "Highlight color for text"
-msgstr "उभारें के लिए पाठ के लिए"
-#: ../vector/v.label/main.c:180 ../vector/v.label.sa/main.c:117
-msgid "Width of highlight coloring"
-msgstr ""
-#: ../vector/v.label/main.c:200 ../vector/v.label.sa/main.c:135
-#, fuzzy
-msgid "Opaque to vector (only relevant if background color is selected)"
-msgstr "है"
-#: ../vector/v.label/main.c:251
-#, fuzzy
-msgid "size and space options vary significantly which may lead to crummy output"
-msgstr "आकार "
-#: ../vector/v.label/main.c:259
-#, fuzzy
-msgid "Too many parameters for <reference>"
-msgstr "के लिए<reference>"
-#: ../vector/v.label/main.c:324 ../vector/v.sample/main.c:225
-#: ../vector/v.sample/main.c:233 ../vector/v.buffer/main.c:452
-#: ../vector/v.buffer/main.c:554 ../vector/v.what.rast/main.c:295
-#: ../vector/v.vol.rst/user1.c:172 ../vector/v.label.sa/labels.c:164
-#, fuzzy, c-format
-msgid "No record for category %d in table <%s>"
-#: ../vector/v.label/main.c:437
-#, c-format
-msgid "Labeled %d lines."
-msgstr ""
-#: ../vector/v.univar/main.c:66
-#, fuzzy
-msgid "Calculates univariate statistics for attribute."
-msgstr "का a."
-#: ../vector/v.univar/main.c:67
-msgid "Variance and standard deviation is calculated only for points if specified."
-msgstr ""
-#: ../vector/v.univar/main.c:122
-msgid "Incompatible vector type(s) specified, only number of features, minimum, maximum and range can be calculated"
-msgstr ""
-#: ../vector/v.univar/main.c:127
-msgid "Extended statistics is currently supported only for points/centroids"
-msgstr ""
-#: ../vector/v.univar/main.c:134
-#, fuzzy, c-format
-msgid " Database connection not defined for layer <%s>"
-msgstr "नहीं"
-#: ../vector/v.univar/main.c:151 ../vector/v.sample/main.c:239
-#: ../vector/v.buffer/main.c:387 ../vector/v.class/main.c:118
-#: ../vector/v.what.rast/main.c:139 ../vector/v.to.rast3/main.c:96
-#: ../vector/v.surf.idw/read_sites.c:51 ../vector/v.surf.bspline/main.c:381
-#: ../vector/v.surf.bspline/crosscorr.c:128
-#, fuzzy
-msgid "Column type not supported"
-msgstr "नहीं"
-#: ../vector/v.univar/main.c:408
-#, fuzzy
-msgid "Cannot sort the key/value array"
-msgstr "के लिए"
-#: ../vector/v.net.distance/main.c:63 ../vector/v.net.timetable/main.c:262
-#: ../vector/v.net.allpairs/main.c:58 ../vector/v.net.path/main.c:42
-msgid "shortest path"
-msgstr ""
-#: ../vector/v.net.distance/main.c:64
-msgid "Computes shortest distance via the network between the given sets of features."
-msgstr ""
-#: ../vector/v.net.distance/main.c:67
-msgid "Finds the shortest paths from a feature 'to' to every feature 'from' and various information about this relation are uploaded to the attribute table."
-msgstr ""
-#: ../vector/v.net.distance/main.c:88
-#, fuzzy
-msgid "From category values"
-msgstr "का"
-#: ../vector/v.net.distance/main.c:89 ../vector/v.net.distance/main.c:95
-#: ../vector/v.distance/main.c:92 ../vector/v.distance/main.c:97
-#: ../vector/v.distance/main.c:104
-#, fuzzy
-msgid "From"
-msgstr "विशेषता"
-#: ../vector/v.net.distance/main.c:94
-msgid "From WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-#: ../vector/v.net.distance/main.c:99
-#, fuzzy
-msgid "To category values"
-msgstr "का"
-#: ../vector/v.net.distance/main.c:100 ../vector/v.net.distance/main.c:106
-#: ../vector/v.net.distance/main.c:113 ../vector/v.distance/main.c:109
-#: ../vector/v.distance/main.c:114 ../vector/v.distance/main.c:121
-#: ../vector/v.distance/main.c:180
-msgid "To"
-msgstr ""
-#: ../vector/v.net.distance/main.c:105
-msgid "To WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-#: ../vector/v.net.distance/main.c:112
-#, fuzzy
-msgid "To feature type"
-msgstr "विशेषता"
-#: ../vector/v.lrs/v.lrs.segment/main.c:71
-#: ../vector/v.lrs/v.lrs.where/main.c:58
-#: ../vector/v.lrs/v.lrs.create/main.c:122
-#: ../vector/v.lrs/v.lrs.label/main.c:103
-msgid "LRS"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:74
-msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:78
-#: ../vector/v.lrs/v.lrs.where/main.c:66
-#: ../vector/v.lrs/v.lrs.create/main.c:128
-#: ../vector/v.lrs/v.lrs.label/main.c:109
-#, fuzzy
-msgid "Input vector map containing lines"
-msgstr "का"
-#: ../vector/v.lrs/v.lrs.segment/main.c:82
-#, fuzzy
-msgid "Output vector map where segments will be written"
-msgstr "i n"
-#: ../vector/v.lrs/v.lrs.segment/main.c:87
-#: ../vector/v.lrs/v.lrs.where/main.c:75
-#: ../vector/v.lrs/v.lrs.create/main.c:147
-#: ../vector/v.lrs/v.lrs.label/main.c:118
-#, fuzzy
-msgid "Line layer"
-msgstr "सेट"
-#: ../vector/v.lrs/v.lrs.segment/main.c:93
-#: ../vector/v.lrs/v.lrs.where/main.c:86
-#: ../vector/v.lrs/v.lrs.create/main.c:207
-#: ../vector/v.lrs/v.lrs.label/main.c:124
-#, fuzzy
-msgid "Driver name for reference system table"
-msgstr "फ़ाइल का"
-#: ../vector/v.lrs/v.lrs.segment/main.c:101
-#: ../vector/v.lrs/v.lrs.where/main.c:94
-#: ../vector/v.lrs/v.lrs.create/main.c:215
-#: ../vector/v.lrs/v.lrs.label/main.c:132
-#, fuzzy
-msgid "Database name for reference system table"
-msgstr "फ़ाइल का"
-#: ../vector/v.lrs/v.lrs.segment/main.c:108
-#: ../vector/v.lrs/v.lrs.where/main.c:101
-#: ../vector/v.lrs/v.lrs.label/main.c:139
-#, fuzzy
-msgid "Name of the reference system table"
-msgstr "का"
-#: ../vector/v.lrs/v.lrs.segment/main.c:113
-#, fuzzy
-msgid "Name of file containing segment rules. If not given, read from stdin."
-msgstr "का नहीं"
-#: ../vector/v.lrs/v.lrs.segment/main.c:152
-#: ../vector/v.lrs/v.lrs.where/main.c:145
-#: ../vector/v.lrs/v.lrs.create/main.c:305
-#: ../vector/v.lrs/v.lrs.label/main.c:309
-#, fuzzy
-msgid "Unable to open database for reference table"
-msgstr "स्रोत"
-#: ../vector/v.lrs/v.lrs.segment/main.c:180
-#: ../vector/v.lrs/v.lrs.segment/main.c:234
-#, fuzzy, c-format
-msgid "Cannot read input: %s"
-msgstr "के लिए"
-#: ../vector/v.lrs/v.lrs.segment/main.c:192
-#, fuzzy, c-format
-msgid "No record in LR table for: %s"
-msgstr "के लिए"
-#: ../vector/v.lrs/v.lrs.segment/main.c:196
-#, fuzzy, c-format
-msgid "More than one record in LR table for: %s"
-msgstr "के लिए"
-#: ../vector/v.lrs/v.lrs.segment/main.c:203
-#: ../vector/v.lrs/v.lrs.segment/main.c:290
-#, fuzzy, c-format
-msgid "Unable to find line of cat [%d]"
-msgstr "नहीं"
-#: ../vector/v.lrs/v.lrs.segment/main.c:213
-#, c-format
-msgid ""
-"Cannot get point on line: cat = [%d] distance = [%f] (line length = %f)\n"
-"%s"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:249
-#, fuzzy, c-format
-msgid ""
-"No record in LRS table for 1. point of:\n"
-"  %s"
-#: ../vector/v.lrs/v.lrs.segment/main.c:254
-#, c-format
-msgid ""
-"Using last from more offsets found for 1. point of:\n"
-"  %s"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:258
-#, c-format
-msgid ""
-"Requested offset for the 1. point not found, using nearest found:\n"
-"  %s"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:269
-#, fuzzy, c-format
-msgid ""
-"No record in LRS table for 2. point of:\n"
-"  %s"
-#: ../vector/v.lrs/v.lrs.segment/main.c:274
-#, c-format
-msgid ""
-"Requested offset for the 2. point not found, using nearest found:\n"
-"  %s"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:278
-#, c-format
-msgid ""
-"Using first from more offsets found for 2. point of:\n"
-"  %s"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:283
-msgid "Segment over 2 (or more) segments, not yet supported"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:300
-#, c-format
-msgid "End of segment > line length (%e) -> cut"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:309
-#, c-format
-msgid ""
-"Cannot make line segment: cat = %d : %f - %f (line length = %f)\n"
-"%s"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:332 ../vector/v.segment/main.c:217
-#, fuzzy, c-format
-msgid "Incorrect segment type: %s"
-msgstr "फ़ाइल"
-#: ../vector/v.lrs/v.lrs.segment/main.c:347
-#: ../vector/v.lrs/v.lrs.where/main.c:220
-#, fuzzy, c-format
-msgid "[%d] points read from input"
-msgstr "n"
-#: ../vector/v.lrs/v.lrs.segment/main.c:348
-#, fuzzy, c-format
-msgid "[%d] points written to output map (%d lost)"
-msgstr "n"
-#: ../vector/v.lrs/v.lrs.segment/main.c:350
-#, fuzzy, c-format
-msgid "[%d] lines read from input"
-msgstr "n"
-#: ../vector/v.lrs/v.lrs.segment/main.c:351
-#, fuzzy, c-format
-msgid "[%d] lines written to output map (%d lost)"
-msgstr "n"
-#: ../vector/v.lrs/v.lrs.where/main.c:61
-msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
-msgstr ""
-#: ../vector/v.lrs/v.lrs.where/main.c:70
-#, fuzzy
-msgid "Input vector map containing points"
-msgstr "का"
-#: ../vector/v.lrs/v.lrs.where/main.c:80
-#: ../vector/v.lrs/v.lrs.create/main.c:151
-#, fuzzy
-msgid "Point layer"
-msgstr "फ़ाइलनाम "
-#: ../vector/v.lrs/v.lrs.where/main.c:108
-#, fuzzy
-msgid "Maximum distance to nearest line"
-msgstr "बिन्दु"
-#: ../vector/v.lrs/v.lrs.where/main.c:221
-#, fuzzy, c-format
-msgid "[%d] positions found"
-msgstr "नहीं"
-#: ../vector/v.lrs/v.lrs.where/main.c:223
-#, fuzzy, c-format
-msgid "[%d] points outside threshold"
-msgstr "बिन्दु n"
-#: ../vector/v.lrs/v.lrs.where/main.c:225
-#, fuzzy, c-format
-msgid "[%d] points - no record found"
-msgstr "नहीं"
-#: ../vector/v.lrs/v.lrs.where/main.c:227
-#, fuzzy, c-format
-msgid "[%d] points - too many records found"
-msgstr "नहीं"
-#: ../vector/v.lrs/v.lrs.create/main.c:124
-msgid "Create Linear Reference System"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:133
-#, fuzzy
-msgid "Output vector map where oriented lines are written"
-msgstr "का"
-#: ../vector/v.lrs/v.lrs.create/main.c:138
-#, fuzzy
-msgid "Output vector map of errors"
-msgstr "का"
-#: ../vector/v.lrs/v.lrs.create/main.c:143
-#, fuzzy
-msgid "Input vector map containing reference points"
-msgstr "का"
-#: ../vector/v.lrs/v.lrs.create/main.c:158
-msgid "Column containing line identifiers for lines"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:165
-msgid "Column containing line identifiers for points"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:173
-msgid "Column containing milepost position for the beginning of next segment"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:182
-msgid "Column containing offset from milepost for the beginning of next segment"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:191
-msgid "Column containing milepost position for the end of previous segment"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:200
-msgid "Column containing offset from milepost for the end of previous segment"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:223
-#, fuzzy
-msgid "Name of table where the reference system will be written"
-msgstr "का"
-#: ../vector/v.lrs/v.lrs.create/main.c:224
-msgid "New table is created by this module"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:231
-#, fuzzy
-msgid "Maximum distance of point to line allowed"
-msgstr "बिन्दु"
-#: ../vector/v.lrs/v.lrs.create/main.c:278
-#, fuzzy
-msgid "Cannot get layer info for lines"
-msgstr "फील्ड"
-#: ../vector/v.lrs/v.lrs.create/main.c:281
-#, fuzzy
-msgid "Cannot get layer info for points"
-msgstr "के लिए"
-#: ../vector/v.lrs/v.lrs.create/main.c:316
-#, fuzzy, c-format
-msgid "Unable to drop table: %s"
-msgstr "के लिए."
-#: ../vector/v.lrs/v.lrs.create/main.c:335
-#, fuzzy, c-format
-msgid "Unable to select line id values from %s.%s."
-msgstr "के लिए"
-#: ../vector/v.lrs/v.lrs.create/main.c:345
-#, fuzzy
-msgid "Line id column must be integer"
-msgstr "ज़ेड"
-#: ../vector/v.lrs/v.lrs.create/main.c:356
-#: ../vector/v.lrs/v.lrs.create/main.c:458
-#, fuzzy
-msgid "Unable to fetch line id from line table"
-msgstr "सभी"
-#: ../vector/v.lrs/v.lrs.create/main.c:408
-#, c-format
-msgid "Line [%d] without category (layer [%d])"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:428
-#, fuzzy, c-format
-msgid "No lines selected for line id [%d]"
-msgstr "नहीं"
-#: ../vector/v.lrs/v.lrs.create/main.c:448
-#, fuzzy, c-format
-msgid "Unable to select point attributes from <%s>"
-msgstr "के लिए"
-#: ../vector/v.lrs/v.lrs.create/main.c:479
-#, c-format
-msgid "Milepost (start) %f+%f used as %f+%f (change MP to integer)"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:501
-#, c-format
-msgid "Milepost (end) %f+%f used as %f+%f (change MP to integer)"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:527
-#, fuzzy, c-format
-msgid "Point [%d] without category (layer [%d])"
-#: ../vector/v.lrs/v.lrs.create/main.c:574
-#, c-format
-msgid "Point [%d] cat [%d] is out of threshold (distance = %f)"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:706
-#, fuzzy, c-format
-msgid "End > start for point cat [%d]"
-#: ../vector/v.lrs/v.lrs.create/main.c:723
-msgid "Start of 1. MP >= end of 2. MP for points' cats %[d], [%d]"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:740
-#, c-format
-msgid "Start of 1. MP >= start of 2. MP for points' cats [%d], [%d]"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:750
-#, c-format
-msgid "Distance along line identical for points' cats [%d], [%d]"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:764
-#, c-format
-msgid "Not enough points (%d) attached to the line (cat %d), line skip."
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:769
-#, c-format
-msgid "Unable to guess direction for the line (cat %d), line skip."
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:773
-#, fuzzy, c-format
-msgid "Incorrect order of points along line cat [%d]"
-msgstr "के लिए a"
-#: ../vector/v.lrs/v.lrs.create/main.c:823
-#, fuzzy, c-format
-msgid "Unable to insert reference records: %s"
-msgstr "के लिए"
-#: ../vector/v.lrs/v.lrs.create/main.c:864
-#, fuzzy
-msgid "Building topology for output (out_lines) map..."
-msgstr "n"
-#: ../vector/v.lrs/v.lrs.create/main.c:870
-#, fuzzy
-msgid "Building topology for error (err) map..."
-msgstr "n"
-#: ../vector/v.lrs/v.lrs.label/main.c:105
-msgid "Create stationing from input lines, and linear reference system"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:113
-#, fuzzy
-msgid "Output vector map where stationing will be written"
-msgstr "i n"
-#: ../vector/v.lrs/v.lrs.label/main.c:147
-#, fuzzy
-msgid "Label file"
-msgstr "के लिए"
-#: ../vector/v.lrs/v.lrs.label/main.c:156
-msgid "PM left, MP right, stationing left, stationing right offset"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:161
-#, fuzzy
-msgid "Offset label in label x-direction in map units"
-msgstr "त्रुटि"
-#: ../vector/v.lrs/v.lrs.label/main.c:168
-#, fuzzy
-msgid "Offset label in label y-direction in map units"
-msgstr "त्रुटि"
-#: ../vector/v.lrs/v.lrs.label/main.c:203
-#, fuzzy
-msgid "Line width of text"
-#: ../vector/v.lrs/v.lrs.label/main.c:204
-#: ../vector/v.lrs/v.lrs.label/main.c:212
-#: ../vector/v.lrs/v.lrs.label/main.c:222
-#, fuzzy
-msgid "Only for d.label output"
-msgstr "किनारा के लिए"
-#: ../vector/v.lrs/v.lrs.label/main.c:221
-#, fuzzy
-msgid "Line width of highlight color"
-msgstr "का के लिए"
-#: ../vector/v.lrs/v.lrs.label/main.c:247
-#, fuzzy
-msgid "Opaque to vector"
-msgstr "का"
-#: ../vector/v.lrs/v.lrs.label/main.c:248
-#, fuzzy
-msgid "Only relevant if background color is selected"
-msgstr "है"
-#: ../vector/v.lrs/v.lrs.label/main.c:339
-#, fuzzy, c-format
-msgid "Unable to select records from LRS table: %s"
-msgstr "के लिए"
-#: ../vector/v.lrs/v.lrs.label/main.c:429
-#, fuzzy
-msgid "No record in LR table"
-#: ../vector/v.lrs/v.lrs.label/main.c:433
-msgid "More than one record in LR table"
-msgstr ""
-#: ../vector/v.out.ascii/args.c:28
-#, fuzzy
-msgid "Name for output ASCII file or ASCII vector name if '-o' is defined"
-msgstr "के लिए"
-#: ../vector/v.out.ascii/args.c:30
-#, fuzzy
-msgid "'-' for standard output"
-msgstr "नहीं"
-#: ../vector/v.out.ascii/args.c:35
-#, fuzzy
-msgid "Name of attribute column(s) to be exported (point mode)"
-msgstr "का के लिए"
-#: ../vector/v.out.ascii/args.c:52
-msgid "point;Simple point format (point per row);standard;GRASS ASCII vector format;wkt;OGC well-known text;"
-msgstr ""
-#: ../vector/v.out.ascii/args.c:57
-#, fuzzy
-msgid "Field separator (points mode)"
-msgstr "फील्ड"
-#: ../vector/v.out.ascii/args.c:72
-msgid "Create old (version 4) ASCII file"
-msgstr ""
-#: ../vector/v.out.ascii/args.c:76
-#, fuzzy
-msgid "Include column names in output (points mode)"
-msgstr "नहीं"
-#: ../vector/v.out.ascii/args.c:82
-msgid "Only export points falling within current 3D region (points mode)"
-msgstr ""
-#: ../vector/v.out.ascii/args.c:97 ../vector/v.out.vtk/main.c:177
-msgid "Failed to interpret 'dp' parameter as an integer"
-msgstr ""
-#: ../vector/v.out.ascii/main.c:47
-msgid "ascii"
-msgstr ""
-#: ../vector/v.out.ascii/main.c:49
-#, fuzzy
-msgid "Exports a vector map to a GRASS ASCII vector representation."
-msgstr "a."
-#: ../vector/v.out.ascii/main.c:56
-#, fuzzy
-msgid "Parameter 'column' ignored in standard mode"
-msgstr "का."
-#: ../vector/v.out.ascii/main.c:65
-msgid "Format 'point' is not supported for old version"
-msgstr ""
-#: ../vector/v.out.ascii/main.c:69
-msgid "'output' must be given for old version"
-msgstr ""
-#: ../vector/v.out.ascii/main.c:76
-#, fuzzy, c-format
-msgid "Unable to open vector map <%s> at topology level. Areas will not be processed."
-msgstr "के लिए."
-#: ../vector/v.out.ascii/main.c:116
-msgid "dig_att file already exist"
-msgstr ""
-#: ../vector/v.out.ascii/main.c:119
-#, fuzzy, c-format
-msgid "Unable to open dig_att file <%s>"
-msgstr "के लिए"
-#: ../vector/v.out.ascii/main.c:124
-#, fuzzy
-msgid "Fetching data..."
-msgstr "n"
-#: ../vector/v.out.ascii/main.c:131
-#, fuzzy
-msgid "No points found, nothing to be exported"
-msgstr "नहीं"
-#: ../vector/v.out.ascii/main.c:134
-#, fuzzy
-msgid "No features found, nothing to be exported"
-msgstr "बिन्दु n"
-#: ../vector/v.parallel/main.c:49
-msgid "Creates parallel line to input vector lines."
-msgstr ""
-#: ../vector/v.parallel/main.c:64
-#, fuzzy
-msgid "Offset along major axis in map units"
-msgstr "त्रुटि"
-#: ../vector/v.parallel/main.c:72
-#, fuzzy
-msgid "Offset along minor axis in map units"
-msgstr "त्रुटि"
-#: ../vector/v.parallel/main.c:80 ../vector/v.buffer/main.c:249
-msgid "Angle of major axis in degrees"
-msgstr ""
-#: ../vector/v.parallel/main.c:89
-msgid "Side"
-msgstr ""
-#: ../vector/v.parallel/main.c:91
-msgid "left;Parallel line is on the left;right;Parallel line is on the right;both;Parallel lines on both sides"
-msgstr ""
-#: ../vector/v.parallel/main.c:101
-#, fuzzy
-msgid "Tolerance of arc polylines in map units"
-msgstr "जी"
-#: ../vector/v.parallel/main.c:105
-msgid "Make outside corners round"
-msgstr ""
-#: ../vector/v.parallel/main.c:109
-msgid "Create buffer-like parallel lines"
-msgstr ""
-#: ../vector/v.support/main.c:41
-#, fuzzy
-msgid "Updates vector map metadata."
-msgstr "का"
-#: ../vector/v.support/main.c:52
-msgid "Organization where vector map was created"
-msgstr ""
-#: ../vector/v.support/main.c:61
-msgid "Date of vector map digitization (e.g., \"15 Mar 2007\")"
-msgstr ""
-#: ../vector/v.support/main.c:68
-#, fuzzy
-msgid "Person who created vector map"
-msgstr "के लिए"
-#: ../vector/v.support/main.c:75
-#, fuzzy
-msgid "Vector map title"
-msgstr "सदिश"
-#: ../vector/v.support/main.c:83
-msgid "Date when the source map was originally produced"
-msgstr ""
-#: ../vector/v.support/main.c:89
-msgid "Vector map scale number (e.g., 24000)"
-msgstr ""
-#: ../vector/v.support/main.c:95
-#, fuzzy
-msgid "Vector map projection zone"
-msgstr "सदिश"
-#: ../vector/v.support/main.c:102
-msgid "Vector map digitizing threshold number (e.g., 0.5)"
-msgstr ""
-#: ../vector/v.support/main.c:110
-msgid "Text to append to the comment line of the map's metadata file"
-msgstr ""
-#: ../vector/v.support/main.c:118
-msgid "Command line to store into vector map history file (used for vector scripts)"
-msgstr ""
-#: ../vector/v.support/main.c:122
-msgid "Replace comment instead of appending it"
-msgstr ""
-#: ../vector/v.support/main.c:183
-#, fuzzy, c-format
-msgid "Unable to open history file for vector map <%s>"
-#: ../vector/v.outlier/main.c:70
-#, fuzzy
-msgid "Removes outliers from vector point data."
-msgstr "का"
-#: ../vector/v.outlier/main.c:74 ../vector/v.lidar.edgedetection/main.c:80
-#: ../vector/v.lidar.correction/main.c:75 ../vector/v.surf.bspline/main.c:105
-msgid "Estimate point density and distance"
-msgstr ""
-#: ../vector/v.outlier/main.c:76 ../vector/v.lidar.edgedetection/main.c:82
-#: ../vector/v.lidar.correction/main.c:77 ../vector/v.surf.bspline/main.c:107
-msgid "Estimate point density and distance for the input vector points within the current region extends and quit"
-msgstr ""
-#: ../vector/v.outlier/main.c:88
-#, fuzzy
-msgid "Name of output outlier vector map"
-msgstr "का"
-#: ../vector/v.outlier/main.c:96
-#, fuzzy
-msgid "Name of vector map for visualization in QGIS"
-msgstr "का"
-#: ../vector/v.outlier/main.c:104 ../vector/v.lidar.edgedetection/main.c:94
-#: ../vector/v.lidar.correction/main.c:101
-msgid "Interpolation spline step value in east direction"
-msgstr ""
-#: ../vector/v.outlier/main.c:112 ../vector/v.lidar.edgedetection/main.c:103
-#: ../vector/v.lidar.correction/main.c:109
-msgid "Interpolation spline step value in north direction"
-msgstr ""
-#: ../vector/v.outlier/main.c:118
-msgid "Tykhonov regularization weight"
-msgstr ""
-#: ../vector/v.outlier/main.c:125
-msgid "Threshold for the outliers"
-msgstr ""
-#: ../vector/v.outlier/main.c:135 ../vector/v.lidar.edgedetection/main.c:169
-#: ../vector/v.lidar.correction/main.c:148 ../vector/v.surf.bspline/main.c:223
-#, fuzzy
-msgid "Unable to read name of database"
-msgstr "i n"
-#: ../vector/v.outlier/main.c:138 ../vector/v.lidar.edgedetection/main.c:172
-#: ../vector/v.lidar.correction/main.c:151 ../vector/v.surf.bspline/main.c:226
-#, fuzzy
-msgid "Unable to read name of driver"
-msgstr "i n"
-#: ../vector/v.outlier/main.c:167 ../vector/v.outlier/main.c:233
-#: ../vector/v.lidar.edgedetection/main.c:189
-#: ../vector/v.lidar.edgedetection/main.c:201
-#: ../vector/v.lidar.edgedetection/main.c:251
-#: ../vector/v.lidar.correction/main.c:165
-#: ../vector/v.lidar.correction/main.c:225 ../vector/v.surf.bspline/main.c:242
-#: ../vector/v.surf.bspline/main.c:398 ../vector/v.lidar.growing/main.c:163
-#, fuzzy, c-format
-msgid "No database connection for driver <%s> is defined. Run db.connect."
-msgstr "नहीं"
-#: ../vector/v.outlier/main.c:170 ../vector/v.lidar.edgedetection/main.c:192
-#: ../vector/v.lidar.edgedetection/main.c:204
-#: ../vector/v.lidar.correction/main.c:168 ../vector/v.surf.bspline/main.c:245
-#, fuzzy
-msgid "Old auxiliar table could not be dropped"
-msgstr "नहीं"
-#: ../vector/v.outlier/main.c:177 ../vector/v.surf.bspline/main.c:255
-#: ../vector/v.surf.bspline/main.c:315
-#, fuzzy, c-format
-msgid "Unable to open vector map <%s> at the topological level"
-msgstr "के लिए."
-#: ../vector/v.outlier/main.c:182 ../vector/v.lidar.edgedetection/main.c:223
-#: ../vector/v.lidar.correction/main.c:186
-#, fuzzy, c-format
-msgid "Input vector map <%s> is not 3D!"
-msgstr "नहीं"
-#: ../vector/v.outlier/main.c:192 ../vector/v.lidar.edgedetection/main.c:233
-#: ../vector/v.lidar.correction/main.c:196 ../vector/v.surf.bspline/main.c:279
-#, fuzzy
-msgid "No points in current region!"
-msgstr "बनाम"
-#: ../vector/v.outlier/main.c:239
-#, fuzzy, c-format
-msgid "It was impossible to create <%s> table."
-msgstr "i n"
-#: ../vector/v.outlier/main.c:389 ../vector/v.lidar.edgedetection/main.c:413
-#: ../vector/v.lidar.correction/main.c:399
-#, fuzzy
-msgid "Bilinear interpolation"
-msgstr "संख्या का"
-#: ../vector/v.outlier/main.c:401
-#, fuzzy
-msgid "Outlier detection"
-msgstr "सेट"
-#: ../vector/v.outlier/main.c:419 ../vector/v.lidar.edgedetection/main.c:456
-#: ../vector/v.lidar.correction/main.c:425
-msgid "No data within this subregion. Consider changing the spline step."
-msgstr ""
-#: ../vector/v.outlier/main.c:429 ../vector/v.lidar.edgedetection/main.c:466
-#: ../vector/v.lidar.correction/main.c:436 ../vector/v.surf.bspline/main.c:903
-#, fuzzy
-msgid "Auxiliar table could not be dropped"
-msgstr "नहीं"
-#: ../vector/v.outlier/outlier.c:71 ../vector/v.outlier/outlier.c:108
-#: ../vector/v.outlier/outlier.c:133 ../vector/v.outlier/outlier.c:146
-#: ../vector/v.outlier/outlier.c:170
-#: ../vector/v.lidar.correction/correction.c:93
-#: ../vector/v.lidar.correction/correction.c:127
-#: ../vector/v.lidar.correction/correction.c:151
-#: ../vector/v.lidar.correction/correction.c:163
-#: ../vector/v.lidar.correction/correction.c:187
-msgid "Impossible to read the database"
-msgstr ""
-#: ../vector/v.outlier/outlier.c:75 ../vector/v.outlier/outlier.c:137
-#: ../vector/v.lidar.correction/correction.c:97
-#: ../vector/v.lidar.correction/correction.c:155
-msgid "Impossible to update the database"
-msgstr ""
-#: ../vector/v.outlier/outlier.c:86 ../vector/v.outlier/outlier.c:95
-#: ../vector/v.outlier/outlier.c:192
-#: ../vector/v.lidar.correction/correction.c:107
-#: ../vector/v.lidar.correction/correction.c:115
-#: ../vector/v.lidar.correction/correction.c:210
-msgid "Impossible to write in the database"
-msgstr ""
-#: ../vector/v.build/main.c:39 ../vector/v.build.polylines/main.c:113
-#: ../vector/v.clean/main.c:50 ../vector/v.info/main.c:39
-#: ../locale/scriptstrings/v.build.all_to_translate.c:3
-#, fuzzy
-msgid "topology"
-msgstr "चालू"
-#: ../vector/v.build/main.c:40
-#, fuzzy
-msgid "Creates topology for vector map."
-msgstr "के लिए."
-#: ../vector/v.build/main.c:49
-#, fuzzy
-msgid "Name for vector map where erroneous vector features are written to"
-msgstr "का"
-#: ../vector/v.build/main.c:60
-msgid "Build topology or dump topology or spatial index to stdout"
-msgstr ""
-#: ../vector/v.build/main.c:62
-msgid "build;build topology;dump;write topology to stdout;sdump;write spatial index to stdout;cdump;write category index to stdout"
-msgstr ""
-#: ../vector/v.build/main.c:68
-msgid "Extensive checks for topological errors"
-msgstr ""
-#: ../vector/v.build/main.c:69
-msgid "Perform in-depth checks for topological errors when building topology"
-msgstr ""
-#: ../vector/v.build/main.c:96
-#, c-format
-msgid "Direct read access to OGR layers is not supported by this module. Run %s to create a link as GRASS vector map in the current mapset."
-msgstr ""
-#: ../vector/v.build/main.c:101
-#, fuzzy, c-format
-msgid "Vector map <%s> is not in current mapset"
-msgstr "नहीं"
-#: ../vector/v.build/main.c:108
-#, fuzzy, c-format
-msgid "Unable to build topology for <%s>"
-msgstr "के लिए."
-#: ../vector/v.edit/args.c:20
-#, fuzzy
-msgid "Name of vector map to edit"
-msgstr "का"
-#: ../vector/v.edit/args.c:36
-msgid "Tool"
-msgstr ""
-#: ../vector/v.edit/args.c:58
-#, fuzzy
-msgid "Create new (empty) vector map"
-msgstr "का"
-#: ../vector/v.edit/args.c:59
-#, fuzzy
-msgid "Add new features to existing vector map"
-msgstr "का"
-#: ../vector/v.edit/args.c:60
-#, fuzzy
-msgid "Delete selected features from vector map"
-msgstr "n"
-#: ../vector/v.edit/args.c:61
-#, fuzzy
-msgid "Move selected features in vector map"
-msgstr "त्रुटि"
-#: ../vector/v.edit/args.c:62
-msgid "Move vertex of selected vector lines"
-msgstr ""
-#: ../vector/v.edit/args.c:63
-#, fuzzy
-msgid "Remove vertex from selected vector lines"
-msgstr "का"
-#: ../vector/v.edit/args.c:64
-#, fuzzy
-msgid "Add new vertex to selected vector lines"
-#: ../vector/v.edit/args.c:65
-#, fuzzy
-msgid "Merge selected vector lines"
-msgstr "छापें"
-#: ../vector/v.edit/args.c:66
-#, fuzzy
-msgid "Break/split vector lines"
-msgstr "का"
-#: ../vector/v.edit/args.c:67
-#, fuzzy
-msgid "Select lines and print their ID's"
-msgstr "स्रोत"
-#: ../vector/v.edit/args.c:68
-msgid "Set new categories to selected vector features for defined layer"
-msgstr ""
-#: ../vector/v.edit/args.c:70
-msgid "Delete categories from selected vector features for defined layer"
-msgstr ""
-#: ../vector/v.edit/args.c:72
-#, fuzzy
-msgid "Copy selected features"
-msgstr "छापें"
-#: ../vector/v.edit/args.c:73
-msgid "Snap vector features in given threshold"
-msgstr ""
-#: ../vector/v.edit/args.c:74
-#, fuzzy
-msgid "Flip direction of selected vector lines"
-msgstr "का"
-#: ../vector/v.edit/args.c:75
-#, fuzzy
-msgid "Connect two lines"
-msgstr "नहीं"
-#: ../vector/v.edit/args.c:76
-msgid "Z bulk-labeling (automated assignment of z coordinate to vector lines)"
-msgstr ""
-#: ../vector/v.edit/args.c:78
-msgid "Change feature type (point<->centroid, line<->boundary)"
-msgstr ""
-#: ../vector/v.edit/args.c:79
-msgid "Delete selected areas from vector map (based on selected centroids)"
-msgstr ""
-#: ../vector/v.edit/args.c:87
-#, fuzzy
-msgid "Name of file containing data in GRASS ASCII vector format"
-msgstr "फ़ाइल"
-#: ../vector/v.edit/args.c:89
-#, fuzzy
-msgid "\"-\" reads from standard input"
-msgstr "नहीं"
-#: ../vector/v.edit/args.c:99
-msgid "Difference in x,y,z direction for moving feature or vertex"
-msgstr ""
-#: ../vector/v.edit/args.c:106
-#, fuzzy
-msgid "Threshold distance (coords,snap,query)"
-msgstr "बिन्दु"
-#: ../vector/v.edit/args.c:108
-#, fuzzy
-msgid "'-1' for threshold based on the current resolution settings"
-msgstr "छापें"
-#: ../vector/v.edit/args.c:124
-#, fuzzy
-msgid "List of point coordinates"
-msgstr "ज़ेड"
-#: ../vector/v.edit/args.c:133
-msgid "Bounding box for selecting features"
-msgstr ""
-#: ../vector/v.edit/args.c:142
-msgid "Polygon for selecting features"
-msgstr ""
-#: ../vector/v.edit/args.c:152
-msgid "Query tool"
-msgstr ""
-#: ../vector/v.edit/args.c:154
-msgid "For 'shorter' use negative threshold value, positive value for 'longer'"
-msgstr ""
-#: ../vector/v.edit/args.c:157
-msgid "length;Select only lines or boundaries shorter/longer than threshold distance;dangle;Select dangles shorter/longer than threshold distance"
-msgstr ""
-#: ../vector/v.edit/args.c:165
-#, fuzzy
-msgid "Name of background vector map(s)"
-msgstr "का a"
-#: ../vector/v.edit/args.c:172
-msgid "Snap added or modified features in the given threshold to the nearest existing feature"
-msgstr ""
-#: ../vector/v.edit/args.c:174
-msgid "no;Not apply snapping;node;Snap only to node;vertex;Allow snapping also to vertex"
-msgstr ""
-#: ../vector/v.edit/args.c:182
-msgid "Starting value and step for z bulk-labeling"
-msgstr ""
-#: ../vector/v.edit/args.c:183
-msgid "Pair: value,step (e.g. 1100,10)"
-msgstr ""
-#: ../vector/v.edit/args.c:188 ../vector/v.extract/main.c:95
-#: ../vector/v.select/args.c:87
-#, fuzzy
-msgid "Reverse selection"
-msgstr "ट्रेस"
-#: ../vector/v.edit/args.c:194
-msgid "Close added boundaries (using threshold distance)"
-msgstr ""
-#: ../vector/v.edit/args.c:198
-#, fuzzy
-msgid "Do not expect header of input data"
-msgstr "नहीं n"
-#: ../vector/v.edit/args.c:208
-msgid "Modify only first found feature in bounding box"
-msgstr ""
-#: ../vector/v.edit/args.c:220
-#, fuzzy
-msgid "Polygon must have at least 3 coordinate pairs"
-msgstr "पर"
-#: ../vector/v.edit/args.c:284
-#, fuzzy, c-format
-msgid "Operation '%s' not implemented"
-msgstr "नहीं"
-#: ../vector/v.edit/args.c:293
-#, fuzzy, c-format
-msgid "At least one option from %s must be specified"
-msgstr "थीटा"
-#: ../vector/v.edit/args.c:299 ../vector/v.edit/args.c:308
-#: ../vector/v.edit/args.c:315 ../vector/v.edit/args.c:322
-#: ../vector/v.edit/args.c:326
-#, c-format
-msgid "Tool %s requires option %s"
-msgstr ""
-#: ../vector/v.edit/snap.c:111 ../vector/v.edit/close.c:56
-#, fuzzy, c-format
-msgid "Unable to rewrite line %d"
-msgstr "का a"
-#: ../vector/v.edit/main.c:56
-#, fuzzy
-msgid "editing"
-msgstr "n"
-#: ../vector/v.edit/main.c:58
-msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
-msgstr ""
-#: ../vector/v.edit/main.c:67
-#, fuzzy, c-format
-msgid "Unable to get category list <%s>"
-msgstr "नहीं"
-#: ../vector/v.edit/main.c:103
-#, c-format
-msgid "Supported feature type for OGR layer: %s, %s or %s"
-msgstr ""
-#: ../vector/v.edit/main.c:126 ../vector/v.kcv/main.c:123
-#, fuzzy, c-format
-msgid "Unable to open vector map <%s> at topological level %d"
-msgstr "के लिए."
-#: ../vector/v.edit/main.c:145
-#, fuzzy, c-format
-msgid "Unable to open vector map <%s> as the background map. It is given as vector map to be edited."
-msgstr "के लिए."
-#: ../vector/v.edit/main.c:156
-#, fuzzy, c-format
-msgid "Background vector map <%s> registered"
-msgstr "के लिए."
-#: ../vector/v.edit/main.c:192
-msgid "Threshold for snapping must be > 0. No snapping applied."
-msgstr ""
-#: ../vector/v.edit/main.c:199
-#, fuzzy
-msgid "Selecting features..."
-msgstr "n"
-#: ../vector/v.edit/main.c:211
-msgid "No features selected, nothing to edit"
-msgstr ""
-#: ../vector/v.edit/main.c:219
-#, c-format
-msgid "Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert the vector map to 3D using e.g. %s."
-msgstr ""
-#: ../vector/v.edit/main.c:255
-#, fuzzy, c-format
-msgid "%d features added"
-msgstr "n"
-#: ../vector/v.edit/main.c:264 ../vector/v.edit/main.c:289
-#: ../vector/v.edit/main.c:298 ../vector/v.edit/main.c:322
-#: ../vector/v.edit/main.c:358
-#, fuzzy, c-format
-msgid "Threshold value for snapping is %.2f"
-msgstr "का."
-#: ../vector/v.edit/main.c:276
-#, fuzzy, c-format
-msgid "%d boundaries closed"
-msgstr "n"
-#: ../vector/v.edit/main.c:283
-#, fuzzy, c-format
-msgid "%d features deleted"
-msgstr "n"
-#: ../vector/v.edit/main.c:292
-#, fuzzy, c-format
-msgid "%d features moved"
-msgstr "n"
-#: ../vector/v.edit/main.c:301
-#, fuzzy, c-format
-msgid "%d vertices moved"
-msgstr "n"
-#: ../vector/v.edit/main.c:305
-#, fuzzy, c-format
-msgid "%d vertices added"
-msgstr "n"
-#: ../vector/v.edit/main.c:309
-#, fuzzy, c-format
-msgid "%d vertices removed"
-msgstr "n"
-#: ../vector/v.edit/main.c:319
-#, fuzzy, c-format
-msgid "%d lines broken"
-msgstr "n"
-#: ../vector/v.edit/main.c:325
-#, fuzzy, c-format
-msgid "%d lines connected"
-msgstr "n"
-#: ../vector/v.edit/main.c:329
-#, fuzzy, c-format
-msgid "%d lines merged"
-msgstr "n"
-#: ../vector/v.edit/main.c:336 ../vector/v.edit/main.c:340
-#, fuzzy, c-format
-msgid "%d features modified"
-msgstr "n"
-#: ../vector/v.edit/main.c:345
-#, c-format
-msgid "Multiple background maps were given. Selected features will be copied only from vector map <%s>."
-msgstr ""
-#: ../vector/v.edit/main.c:355
-#, fuzzy, c-format
-msgid "%d features copied"
-msgstr "n"
-#: ../vector/v.edit/main.c:364
-#, fuzzy, c-format
-msgid "%d lines flipped"
-msgstr "n"
-#: ../vector/v.edit/main.c:383
-#, fuzzy, c-format
-msgid "%d lines labeled"
-msgstr "n"
-#: ../vector/v.edit/main.c:390
-#, fuzzy, c-format
-msgid "%d features converted"
-msgstr "n"
-#: ../vector/v.edit/main.c:393
-#, fuzzy
-msgid "No feature modified"
-msgstr "n"
-#: ../vector/v.edit/main.c:400
-#, c-format
-msgid "Select feature %d is not centroid, ignoring..."
-msgstr ""
-#: ../vector/v.edit/main.c:407
-#, fuzzy, c-format
-msgid "%d areas removed"
-msgstr "n"
-#: ../vector/v.edit/main.c:411
-#, fuzzy
-msgid "Operation not implemented"
-msgstr "नहीं"
-#: ../vector/v.edit/select.c:73
-#, fuzzy, c-format
-msgid "Threshold value for coordinates is %.2f"
-msgstr "के लिए ज़ेड"
-#: ../vector/v.edit/select.c:160
-#, fuzzy, c-format
-msgid "Threshold value for querying is %.2f"
-msgstr "का."
-#: ../vector/v.edit/select.c:176
-#, fuzzy, c-format
-msgid "%d of %d features selected from vector map <%s>"
-msgstr "n"
-#: ../vector/v.edit/select.c:493
-msgid "Layer must be > 0 for 'where'"
-msgstr ""
-#: ../vector/v.in.dwg/main.c:84
-#, fuzzy
-msgid "Converts DWG/DXF to GRASS vector map"
-msgstr "n"
-#: ../vector/v.in.dwg/main.c:87
-#, fuzzy
-msgid "Name of DWG or DXF file"
-msgstr "का"
-#: ../vector/v.in.dwg/main.c:97
-#, fuzzy
-msgid "List of layers to import"
-msgstr "का"
-#: ../vector/v.in.dwg/main.c:102
-msgid "Invert selection by layers (don't import layers in list)"
-msgstr ""
-#: ../vector/v.in.dwg/main.c:106 ../vector/v.in.ascii/main.c:140
-#, fuzzy
-msgid "Create 3D vector map"
-msgstr "का"
-#: ../vector/v.in.dwg/main.c:110
-msgid "Write circles as points (centre)"
-msgstr ""
-#: ../vector/v.in.dwg/main.c:114
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:5
-#, fuzzy
-msgid "List available layers and exit"
-msgstr "स्रोत"
-#: ../vector/v.in.dwg/main.c:118
-msgid "Use numeric type for attribute \"layer\""
-msgstr ""
-#: ../vector/v.in.dwg/main.c:138
-#, fuzzy, c-format
-msgid "Unable to initialize OpenDWG Toolkit, error: %d: %s."
-msgstr "के लिए"
-#: ../vector/v.in.dwg/main.c:141
-#, fuzzy, c-format
-msgid "%s Cannot open %s"
-msgstr "फ़ाइल"
-#: ../vector/v.in.dwg/main.c:149
-#, fuzzy, c-format
-msgid "Unable to open input file <%s>. Error %d: %s"
-msgstr "के लिए"
-#: ../vector/v.in.dwg/main.c:284
-#, c-format
-msgid "%d elements skipped (layer name was not in list)"
-msgstr ""
-#: ../vector/v.in.dwg/main.c:287
-#, c-format
-msgid "%d elements processed"
-msgstr ""
-#: ../vector/v.mapcalc/map.c:67
-#, c-format
-msgid "Performing 1 arg map function on map %s"
-msgstr ""
-#: ../vector/v.mapcalc/map.c:78
-#, c-format
-msgid "Performing 2 arg map function on maps %s and %s"
-msgstr ""
-#: ../vector/v.mapcalc/map.c:90
-#, fuzzy, c-format
-msgid "Performing map %s + %s"
-msgstr "त्रुटि के लिए"
-#: ../vector/v.mapcalc/map.c:264
-msgid "Can't call bad map-function"
-msgstr ""
-#: ../vector/v.mapcalc/map.c:276
-#, c-format
-msgid "Bad arguments to mapfunc %s (argc = %d)"
-msgstr ""
-#: ../vector/v.mapcalc/map.c:300
-#, c-format
-msgid "No function defined to perform map %c map"
-msgstr ""
-#: ../vector/v.mapcalc/vector.c:244
-#, fuzzy
-msgid "Can't call bad function"
-msgstr "है a"
-#: ../vector/v.mapcalc/vector.c:281
-#, c-format
-msgid "Bad arguments to pointfunc %s"
-msgstr ""
-#: ../vector/v.mapcalc/vector.c:304 ../vector/v.mapcalc/number.c:216
-#, c-format
-msgid "No function defined to perform ``point %c point''"
-msgstr ""
-#: ../vector/v.mapcalc/any.c:116
-msgid "Can't call bad any-function"
-msgstr ""
-#: ../vector/v.mapcalc/any.c:128
-#, c-format
-msgid "Bad arguments to anyfunc %s (argc = %d)"
-msgstr ""
-#: ../vector/v.mapcalc/number.c:159
-msgid "Can't call bad num-function"
-msgstr ""
-#: ../vector/v.mapcalc/number.c:189
-#, c-format
-msgid "Bad arguments to numfunc %s"
-msgstr ""
-#: ../vector/v.mapcalc/number.c:213
-#, c-format
-msgid "No function defined to perform ``number %c number''"
-msgstr ""
-#: ../vector/v.net.alloc/main.c:62
-#, fuzzy
-msgid "allocation"
-msgstr "n"
-#: ../vector/v.net.alloc/main.c:64
-msgid "Allocate subnets for nearest centers (direction from center)."
-msgstr ""
-#: ../vector/v.net.alloc/main.c:66
-msgid "center node must be opened (costs >= 0). Costs of center node are used in calculation"
-msgstr ""
-#: ../vector/v.net.alloc/main.c:111
-msgid "Categories of centers (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
-msgstr ""
-#: ../vector/v.net.alloc/main.c:189
-#, fuzzy, c-format
-msgid "Number of centers: [%d] (nlayer: [%d])"
-msgstr "का."
-#: ../vector/v.net.alloc/main.c:192
-msgid "Not enough centers for selected nlayer. Nothing will be allocated."
-msgstr ""
-#: ../vector/v.net.alloc/main.c:203
-#, fuzzy
-msgid "Calculating costs from centers ..."
-msgstr "n"
-#: ../vector/v.kcv/main.c:69 ../vector/v.normal/main.c:76
-#: ../vector/v.in.db/main.c:55
-#, fuzzy
-msgid "points"
-msgstr "फ़ॉन्ट"
-#: ../vector/v.kcv/main.c:71
-msgid "Randomly partition points into test/train sets."
-msgstr ""
-#: ../vector/v.kcv/main.c:83
-#, fuzzy
-msgid "Number of partitions"
-msgstr "का"
-#: ../vector/v.kcv/main.c:93
-msgid "Name for new column to which partition number is written"
-msgstr ""
-#: ../vector/v.kcv/main.c:97
-msgid "Use drand48()"
-msgstr ""
-#: ../vector/v.kcv/main.c:132
-#, c-format
-msgid "More partitions than points (%d)"
-msgstr ""
-#: ../vector/v.kcv/main.c:159
-#, fuzzy, c-format
-msgid "Unable to get layer info for vector map <%s>"
-msgstr "के लिए"
-#: ../vector/v.kcv/main.c:183
-#, fuzzy, c-format
-msgid "Unable to alter table: %s"
-msgstr "के लिए"
-#: ../vector/v.kcv/main.c:255 ../vector/v.sample/main.c:262
-#, fuzzy, c-format
-msgid "Unable to insert row: %s"
-msgstr "i n"
-#: ../vector/v.extract/extract.c:171
-#, fuzzy, c-format
-msgid "No category found for area %d. Skipping."
-#: ../vector/v.extract/extract.c:175
-#, c-format
-msgid "More categories (%d) found for area %d. Using first found category %d"
-msgstr ""
-#: ../vector/v.extract/extract.c:225
-#, fuzzy
-msgid "Topology level required for extracting areas for OGR layers. Areas will be not processed."
-msgstr "n"
-#: ../vector/v.extract/copy_tab.c:86
-#, fuzzy, c-format
-msgid "Writing attributes for layer %d"
-msgstr "के लिए"
-#: ../vector/v.extract/copy_tab.c:91
-#, fuzzy, c-format
-msgid "No attribute table for layer %d"
-msgstr "नहीं"
-#: ../vector/v.extract/copy_tab.c:104 ../vector/v.to.points/main.c:271
-#: ../vector/v.generalize/misc.c:176
-#, fuzzy, c-format
-msgid "Unable to copy table <%s>"
-msgstr "का"
-#: ../vector/v.extract/main.c:79
-#: ../locale/scriptstrings/tr.extract_to_translate.c:4
-#: ../locale/scriptstrings/tr.series_to_translate.c:4
-#: ../locale/scriptstrings/tr3.extract_to_translate.c:4
-#, fuzzy
-msgid "extract"
-msgstr "चालू"
-#: ../vector/v.extract/main.c:81
-msgid "Selects vector features from an existing vector map and creates a new vector map containing only the selected features."
-msgstr ""
-#: ../vector/v.extract/main.c:86
-#, fuzzy
-msgid "Dissolve common boundaries (default is no)"
-msgstr "कॉमन है "
-#: ../vector/v.extract/main.c:90
-msgid "Do not copy attributes (see also 'new' parameter)"
-msgstr ""
-#: ../vector/v.extract/main.c:106
-#, fuzzy
-msgid "Types to be extracted"
-msgstr "का"
-#: ../vector/v.extract/main.c:121
-#, fuzzy
-msgid "Input text file with category numbers/number ranges to be extracted"
-msgstr "का के लिए"
-#: ../vector/v.extract/main.c:122
-#, fuzzy
-msgid "If '-' given reads from standard input"
-msgstr "नहीं"
-#: ../vector/v.extract/main.c:130
-msgid "Number of random categories matching vector objects to extract"
-msgstr ""
-#: ../vector/v.extract/main.c:132
-msgid "Number must be smaller than unique cat count in layer"
-msgstr ""
-#: ../vector/v.extract/main.c:140
-msgid "Desired new category value (enter -1 to keep original categories)"
-msgstr ""
-#: ../vector/v.extract/main.c:142
-msgid "If new >= 0, attributes is not copied"
-msgstr ""
-#: ../vector/v.extract/main.c:159
-#, c-format
-msgid "Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only one of them."
-msgstr ""
-#: ../vector/v.extract/main.c:204
-#, fuzzy, c-format
-msgid "Category value in '%s' not valid"
-msgstr "के लिए नहीं"
-#: ../vector/v.extract/main.c:220
-#, fuzzy, c-format
-msgid "Process file <%s> for category numbers..."
-msgstr "नहीं"
-#: ../vector/v.extract/main.c:225
-#, fuzzy, c-format
-msgid "Unable to open specified file <%s>"
-msgstr "फ़ाइल"
-#: ../vector/v.extract/main.c:236
-#, c-format
-msgid "Ignored text entry: %s"
-msgstr ""
-#: ../vector/v.extract/main.c:255
-#, fuzzy, c-format
-msgid "Loading categories from table <%s>..."
-msgstr "लोड हो गया"
-#: ../vector/v.extract/main.c:265
-#, fuzzy, c-format
-msgid "Unable select records from table <%s>"
-msgstr "के लिए"
-#: ../vector/v.extract/main.c:267
-#, fuzzy, c-format
-msgid "%d categories loaded"
-#: ../vector/v.extract/main.c:280
-msgid "This map has no categories attached. Use v.category to attach categories to this vector map."
-msgstr ""
-#: ../vector/v.extract/main.c:287
-#, fuzzy
-msgid "Please specify random number larger than 0"
-msgstr "संख्या का."
-#: ../vector/v.extract/main.c:291
-#, c-format
-msgid "Random category count must be smaller than feature count. There are only %d features of type(s): %s"
-msgstr ""
-#: ../vector/v.extract/main.c:314
-#, c-format
-msgid "Random category count is larger or equal to uniq <%s> feature category count %d"
-msgstr ""
-#: ../vector/v.extract/main.c:319
-msgid "There are more categories than random number generator can reach. Report this as a GRASS bug."
-msgstr ""
-#: ../vector/v.extract/main.c:350
-#, fuzzy
-msgid "Extracting features..."
-msgstr "n"
-#: ../vector/v.extract/main.c:374
-#, fuzzy
-msgid "Removing duplicate centroids..."
-msgstr "के लिए n"
-#: ../vector/v.db.connect/main.c:52 ../vector/v.distance/main.c:84
-#: ../vector/v.to.db/main.c:37 ../vector/v.vect.stats/main.c:129
-#: ../vector/v.db.select/main.c:53 ../vector/v.in.db/main.c:54
-#: ../db/db.drivers/main.c:72 ../db/db.select/main.c:261
-#: ../db/db.connect/main.c:44 ../db/db.databases/main.c:89
-#: ../db/db.copy/main.c:35 ../db/db.login/main.c:38
-#: ../db/db.execute/main.c:114 ../db/db.tables/main.c:94
-#: ../db/db.dropdb/main.c:70 ../db/db.describe/main.c:124
-#: ../db/db.columns/main.c:91 ../db/db.createdb/main.c:70
-#: ../locale/scriptstrings/v.db.droprow_to_translate.c:3
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:3
-#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:3
-#: ../locale/scriptstrings/v.db.join_to_translate.c:3
-#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:3
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:2
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:3
-#: ../locale/scriptstrings/db.droptable_to_translate.c:2
-#: ../locale/scriptstrings/v.db.update_to_translate.c:3
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:2
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:3
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:3
-#: ../locale/scriptstrings/db.test_to_translate.c:2
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:3
-#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:2
-#, fuzzy
-msgid "database"
-msgstr "डाटाबेस नाम"
-#: ../vector/v.db.connect/main.c:53 ../vector/v.distance/main.c:85
-#: ../vector/v.to.db/main.c:38 ../vector/v.vect.stats/main.c:130
-#: ../vector/v.db.select/main.c:54 ../vector/v.what.rast/main.c:72
-#: ../db/db.drivers/main.c:73 ../db/db.select/main.c:262
-#: ../db/db.connect/main.c:45 ../db/db.copy/main.c:36
-#: ../db/db.execute/main.c:115 ../db/db.tables/main.c:95
-#: ../db/db.describe/main.c:125 ../db/db.columns/main.c:92
-#: ../locale/scriptstrings/v.db.droprow_to_translate.c:4
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:4
-#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:4
-#: ../locale/scriptstrings/v.db.join_to_translate.c:4
-#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:4
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:3
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:4
-#: ../locale/scriptstrings/db.droptable_to_translate.c:3
-#: ../locale/scriptstrings/v.db.update_to_translate.c:4
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:3
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:4
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:4
-#: ../locale/scriptstrings/db.test_to_translate.c:3
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:4
-#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:3
-#, fuzzy
-msgid "attribute table"
-msgstr "छापें"
-#: ../vector/v.db.connect/main.c:55
-#, fuzzy
-msgid "Prints/sets DB connection for a vector map to attribute table."
-msgstr "के लिए a"
-#: ../vector/v.db.connect/main.c:77
-msgid "Format: layer number[/layer name]"
-msgstr ""
-#: ../vector/v.db.connect/main.c:81
-#, fuzzy
-msgid "Field separator for shell script style output"
-msgstr "छापें"
-#: ../vector/v.db.connect/main.c:86
-#, fuzzy
-msgid "Print all map connection parameters and exit"
-msgstr "छापें"
-#: ../vector/v.db.connect/main.c:91
-#, fuzzy
-msgid "Print all map connection parameters in shell script style and exit"
-msgstr "छापें"
-#: ../vector/v.db.connect/main.c:93
-msgid "Format: layer[/layer name] table key database driver"
-msgstr ""
-#: ../vector/v.db.connect/main.c:99
-#, fuzzy
-msgid "Print types/names of table columns for specified layer and exit"
-msgstr "छापें का के लिए"
-#: ../vector/v.db.connect/main.c:106
-#, fuzzy
-msgid "Overwrite connection parameter for certain layer"
-msgstr "के लिए"
-#: ../vector/v.db.connect/main.c:111
-#, fuzzy
-msgid "Delete connection for certain layer (not the table)"
-msgstr "मिटाएँ के लिए नहीं"
-#: ../vector/v.db.connect/main.c:145
-#, fuzzy
-msgid "Please choose only one print style"
-msgstr "एक पद्धति"
-#: ../vector/v.db.connect/main.c:153
-#, fuzzy
-msgid "Unable to modify vector map stored in other mapset"
-msgstr "सेट जोड़ा"
-#: ../vector/v.db.connect/main.c:161
-#, fuzzy, c-format
-msgid "Map <%s> is not connected to a database"
-msgstr "नहीं"
-#: ../vector/v.db.connect/main.c:170
-#, fuzzy, c-format
-msgid "Vector map <%s> is connected by:\n"
-msgstr "नहीं"
-#: ../vector/v.db.connect/main.c:195
-#, c-format
-msgid "layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
-msgstr ""
-#: ../vector/v.db.connect/main.c:201
-#, c-format
-msgid "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
-msgstr ""
-#: ../vector/v.db.connect/main.c:264
-#, c-format
-msgid "Use -o to overwrite existing link for layer <%d>"
-msgstr ""
-#: ../vector/v.db.connect/main.c:272 ../vector/v.db.connect/main.c:312
-#, c-format
-msgid "Table <%s> does not exist in database <%s>"
-msgstr ""
-#: ../vector/v.db.connect/main.c:287 ../vector/v.transform/trans_digit.c:94
-#: ../vector/v.in.db/main.c:141
-#, fuzzy, c-format
-msgid "Missing column <%s> in table <%s>"
-msgstr "नहीं"
-#: ../vector/v.db.connect/main.c:293 ../vector/v.in.db/main.c:144
-#, fuzzy
-msgid "Data type of key column must be integer"
-msgstr "ज़ेड"
-#: ../vector/v.db.connect/main.c:300 ../vector/v.db.connect/main.c:318
-#, c-format
-msgid "The table <%s> is now part of vector map <%s> and may be deleted or overwritten by GRASS modules"
-msgstr ""
-#: ../vector/v.db.connect/main.c:339
-#, fuzzy, c-format
-msgid "Cannot grant privileges on table %s"
-msgstr "चालू"
-#: ../vector/v.db.connect/main.c:342
-msgid "Select privileges were granted on the table"
-msgstr ""
-#: ../vector/v.db.connect/main.c:349
-msgid "For defining a new connection you have to specify these parameters: driver, database, table [, key [, layer]]"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:51
-#, fuzzy
-msgid "Creates a vector map from an ASCII points file or ASCII vector file."
-msgstr "a अन्य."
-#: ../vector/v.in.ascii/main.c:55
-#, fuzzy
-msgid "Name of input file to be imported"
-msgstr "का"
-#: ../vector/v.in.ascii/main.c:66
-msgid "point;simple x,y[,z] list;standard;GRASS vector ASCII format"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:69
-#, fuzzy
-msgid "Input file format"
-msgstr "है n"
-#: ../vector/v.in.ascii/main.c:70 ../vector/v.in.ascii/main.c:73
-#: ../vector/v.in.ascii/main.c:151
-#, fuzzy
-msgid "Input format"
-msgstr "है n"
-#: ../vector/v.in.ascii/main.c:82
-#, fuzzy
-msgid "Number of header lines to skip at top of input file (points mode)"
-msgstr "का पर शीर्ष का"
-#: ../vector/v.in.ascii/main.c:91
-msgid "Column definition in SQL style (points mode)"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:92
-#, fuzzy
-msgid "For example: 'x double precision, y double precision, cat int, name varchar(10)'"
-msgstr "के लिए के लिए n"
-#: ../vector/v.in.ascii/main.c:104 ../vector/v.in.ascii/main.c:114
-msgid "First column is 1"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:113
-#, fuzzy
-msgid "Number of column used as y coordinate (points mode)"
-msgstr "का है के लिए"
-#: ../vector/v.in.ascii/main.c:123
-#, fuzzy
-msgid "Number of column used as z coordinate (points mode)"
-#: ../vector/v.in.ascii/main.c:124
-#, fuzzy
-msgid "First column is 1. If 0, z coordinate is not used"
-msgstr "का ज़ेड है के लिए ज़ेड है नहीं."
-#: ../vector/v.in.ascii/main.c:134
-#, fuzzy
-msgid "Number of column used as category (points mode)"
-#: ../vector/v.in.ascii/main.c:136
-#, fuzzy
-msgid "First column is 1. If 0, unique category is assigned to each row and written to new column 'cat'"
-msgstr "का है के लिए है."
-#: ../vector/v.in.ascii/main.c:145
-#, fuzzy
-msgid "Create a new empty vector map and exit. Nothing is read from input."
-msgstr "a है."
-#: ../vector/v.in.ascii/main.c:150
-#, fuzzy
-msgid "Don't expect a header when reading in standard format"
-msgstr "a"
-#: ../vector/v.in.ascii/main.c:155
-#, fuzzy
-msgid "Do not create table in points mode"
-msgstr "नहीं"
-#: ../vector/v.in.ascii/main.c:166
-msgid "Only import points falling within current region (points mode)"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:180
-#, fuzzy
-msgid "Please specify reasonable number of lines to skip"
-#: ../vector/v.in.ascii/main.c:183
-#, fuzzy
-msgid "Please specify z column"
-msgstr "ज़ेड."
-#: ../vector/v.in.ascii/main.c:194
-#, fuzzy
-msgid "Please specify reasonable z column"
-msgstr "ज़ेड."
-#: ../vector/v.in.ascii/main.c:199
-#, fuzzy
-msgid "Column numbers must not be negative"
-msgstr "ज़ेड"
-#: ../vector/v.in.ascii/main.c:203
-#, fuzzy, c-format
-msgid "Unable to open ASCII file <%s>"
-msgstr "के लिए"
-#: ../vector/v.in.ascii/main.c:255
-#, fuzzy, c-format
-msgid "Maximum input row length: %d"
-msgstr "संख्या का n"
-#: ../vector/v.in.ascii/main.c:256
-#, fuzzy, c-format
-msgid "Maximum number of columns: %d"
-#: ../vector/v.in.ascii/main.c:257
-#, fuzzy, c-format
-msgid "Minimum number of columns: %d"
-#: ../vector/v.in.ascii/main.c:262
-#, fuzzy
-msgid ""
-"x column number > minimum last column number\n"
-"(incorrect field separator?)"
-msgstr "संख्या संख्या n फील्ड"
-#: ../vector/v.in.ascii/main.c:266
-#, fuzzy
-msgid ""
-"y column number > minimum last column number\n"
-#: ../vector/v.in.ascii/main.c:270
-#, fuzzy
-msgid "z column number > minimum last column number (incorrect field separator?)"
-msgstr "ज़ेड संख्या संख्या n फील्ड"
-#: ../vector/v.in.ascii/main.c:275
-#, fuzzy
-msgid "cat column number > minimum last column number (incorrect field separator?)"
-#: ../vector/v.in.ascii/main.c:281
-#, fuzzy
-msgid "x column is not of number type"
-msgstr "है नहीं का संख्या"
-#: ../vector/v.in.ascii/main.c:285
-#, fuzzy
-msgid "y column is not of number type"
-#: ../vector/v.in.ascii/main.c:289
-#, fuzzy
-msgid "z column is not of number type"
-msgstr "ज़ेड है नहीं का संख्या"
-#: ../vector/v.in.ascii/main.c:293
-#, fuzzy
-msgid "cat column is not of number type"
-#: ../vector/v.in.ascii/main.c:335
-#, fuzzy
-msgid "Category column is not of integer type"
-msgstr "है नहीं का"
-#: ../vector/v.in.ascii/main.c:416
-#, fuzzy, c-format
-msgid "Number of columns defined (%d) does not match number of columns (%d) in input"
-msgstr "का नहीं जोड़ा संख्या का."
-#: ../vector/v.in.ascii/main.c:444
-#, fuzzy, c-format
-msgid "Column number %d <%s> defined as double has only integer values"
-msgstr "का"
-#: ../vector/v.in.ascii/main.c:449
-#, fuzzy, c-format
-msgid "Column number %d <%s> defined as string has only integer values"
-msgstr "का"
-#: ../vector/v.in.ascii/main.c:457
-#, fuzzy, c-format
-msgid "Column number %d <%s> defined as integer has double values"
-msgstr "का"
-#: ../vector/v.in.ascii/main.c:462
-#, fuzzy, c-format
-msgid "Column number %d <%s> defined as string has double values"
-msgstr "का"
-#: ../vector/v.in.ascii/main.c:470
-#, fuzzy, c-format
-msgid "Column number %d <%s> defined as integer has string values"
-msgstr "का"
-#: ../vector/v.in.ascii/main.c:476
-#, fuzzy, c-format
-msgid "Column number %d <%s> defined as double has string values"
-msgstr "का"
-#: ../vector/v.in.ascii/main.c:482
-#, fuzzy, c-format
-msgid "Length of column %d <%s> (%d) is less than maximum value length (%d)"
-msgstr "का है कम"
-#: ../vector/v.in.ascii/main.c:522
-#, fuzzy
-msgid "Populating table..."
-msgstr "नक़ल"
-#: ../vector/v.in.ascii/main.c:528
-msgid "Could not close attribute table. The DBMI driver did not accept all attributes"
-msgstr ""
-#: ../vector/v.in.ascii/points.c:83
-#, fuzzy
-msgid "Scanning input for column types..."
-msgstr "n"
-#: ../vector/v.in.ascii/points.c:165
-#, fuzzy, c-format
-msgid "Unparsable longitude value in column <%d>: %s"
-msgstr "के लिए."
-#: ../vector/v.in.ascii/points.c:184
-#, fuzzy, c-format
-msgid "Unparsable latitude value in column <%d>: %s"
-msgstr "के लिए."
-#: ../vector/v.in.ascii/points.c:265
-#, fuzzy, c-format
-msgid "Skipping %d of %d rows falling outside of current region"
-msgstr "नहीं"
-#: ../vector/v.in.ascii/points.c:293
-#, fuzzy
-msgid "Importing points..."
-msgstr "n"
-#: ../vector/v.in.ascii/points.c:405 ../vector/v.mkgrid/main.c:297
-#: ../vector/v.in.sites/main.c:242 ../vector/v.in.dxf/write_vect.c:70
-#, fuzzy, c-format
-msgid "Unable to insert new record: %s"
-msgstr "के लिए"
-#: ../vector/v.colors/make_colors.c:14
-#, fuzzy, c-format
-msgid "Color table '%s' is not supported for floating point attributes"
-msgstr "है के लिए बिन्दु!"
-#: ../vector/v.colors/make_colors.c:18 ../vector/v.colors/make_colors.c:25
-#, fuzzy, c-format
-msgid "Color table <%s> not supported"
-msgstr "है नहीं"
-#: ../vector/v.colors/scan_attr.c:60
-#, c-format
-msgid "Min value (%f) is out of range %f,%f"
-msgstr ""
-#: ../vector/v.colors/scan_attr.c:66
-#, c-format
-msgid "Max value (%f) is out of range %f,%f"
-msgstr ""
-#: ../vector/v.colors/scan_attr.c:78 ../vector/v.colors/scan_cats.c:43
-#, c-format
-msgid "Min value (%d) is out of range %d,%d"
-msgstr ""
-#: ../vector/v.colors/scan_attr.c:84 ../vector/v.colors/scan_cats.c:49
-#, c-format
-msgid "Max value (%d) is out of range %d,%d"
-msgstr ""
-#: ../vector/v.colors/write_rgb.c:36
-#, fuzzy, c-format
-msgid "Unable to add column <%s> to table <%s>"
-msgstr "का"
-#: ../vector/v.colors/write_rgb.c:59
-#, fuzzy, c-format
-msgid "Column <%s> added to table <%s>"
-msgstr "नहीं"
-#: ../vector/v.colors/write_rgb.c:63
-#, fuzzy, c-format
-msgid "Data type of column <%s> must be char"
-msgstr "ज़ेड"
-#: ../vector/v.colors/write_rgb.c:67
-#, fuzzy
-msgid "No categories found"
-msgstr "नहीं n"
-#: ../vector/v.colors/write_rgb.c:77
-#, fuzzy, c-format
-msgid "No color value defined for category %d"
-msgstr "नहीं के लिए"
-#: ../vector/v.colors/write_rgb.c:85
-#, fuzzy
-msgid "Unable to update RGB values"
-msgstr "के लिए"
-#: ../vector/v.colors/main.c:58
-#, fuzzy
-msgid "Creates/modifies the color table associated with a vector map."
-msgstr "a."
-#: ../vector/v.colors/main.c:65
-#, fuzzy
-msgid "Name of column containing numeric data"
-msgstr "का"
-#: ../vector/v.colors/main.c:66
-#, fuzzy
-msgid "If not given categories are used"
-msgstr "बिन्दु n"
-#: ../vector/v.colors/main.c:73
-#, fuzzy
-msgid "Manually set range (refers to 'column' option)"
-msgstr "पूर्णांक"
-#: ../vector/v.colors/main.c:74
-msgid "Ignored when 'rules' given"
-msgstr ""
-#: ../vector/v.colors/main.c:103
-#, fuzzy
-msgid "Name of color column to populate RGB values"
-msgstr "का"
-#: ../vector/v.colors/main.c:104
-#, fuzzy
-msgid "If not given writes color table"
-msgstr "रखें"
-#: ../vector/v.colors/main.c:139
-#, fuzzy
-msgid "Convert color rules from RGB values to color table"
-msgstr "अज्ञात क़िस्म"
-#: ../vector/v.colors/main.c:140
-msgid "Option 'rgb_column' with valid RGB values required"
-msgstr ""
-#: ../vector/v.colors/main.c:166
-#, fuzzy
-msgid "No vector map specified"
-msgstr "नहीं."
-#: ../vector/v.colors/main.c:169
-#, c-format
-msgid "Options <%s> and <%s> are mutually exclusive"
-msgstr ""
-#: ../vector/v.colors/main.c:179
-#, fuzzy, c-format
-msgid "One of -%c, -%c or options <%s>, <%s> or <%s> must be specified"
-msgstr "पाठ"
-#: ../vector/v.colors/main.c:193
-#, fuzzy, c-format
-msgid "Option <%s> required for flag -%c"
-msgstr "n"
-#: ../vector/v.colors/main.c:208
-#, fuzzy, c-format
-msgid "Unable to remove color table of vector map <%s>"
-msgstr "के लिए."
-#: ../vector/v.colors/main.c:210
-#, fuzzy, c-format
-msgid "Color table of vector map <%s> not found"
-msgstr "नहीं"
-#: ../vector/v.colors/main.c:235
-#, c-format
-msgid "Option <%s>: min must be greater or equal to max"
-msgstr ""
-#: ../vector/v.colors/main.c:246
-#, fuzzy, c-format
-msgid "Color table <%s> not found"
-msgstr "नहीं"
-#: ../vector/v.colors/main.c:299
-#, fuzzy
-msgid "Writing color rules..."
-msgstr "n"
-#: ../vector/v.colors/main.c:315
-#, fuzzy, c-format
-msgid "Color table for vector map <%s> set to '%s'"
-msgstr "के लिए."
-#: ../vector/v.colors/read_rgb.c:32
-#, fuzzy, c-format
-msgid "Data type of RGB column <%s> must be char"
-msgstr "ज़ेड"
-#: ../vector/v.colors/read_rgb.c:37
-#, fuzzy
-msgid "No RGB values found"
-msgstr "नहीं n"
-#: ../vector/v.colors/read_rgb.c:49
-#, fuzzy, c-format
-msgid "Invalid RGB value '%s'"
-msgstr "के लिए"
-#: ../vector/v.sample/main.c:79
-#, fuzzy
-msgid "Samples a raster map at vector point locations."
-msgstr "a."
-#: ../vector/v.sample/main.c:89
-#, fuzzy
-msgid "Name of attribute column to use for comparison"
-msgstr "का के लिए"
-#: ../vector/v.sample/main.c:92
-#, fuzzy
-msgid "Name for output vector map to store differences"
-msgstr "सदिश"
-#: ../vector/v.sample/main.c:96
-#, fuzzy
-msgid "Name of raster map to be sampled"
-msgstr "का"
-#: ../vector/v.sample/main.c:112
-#, fuzzy
-msgid "Scaling factor for values read from raster map"
-msgstr "के लिए"
-#: ../vector/v.sample/main.c:114
-msgid "Sampled values will be multiplied by this factor"
-msgstr ""
-#: ../vector/v.sample/main.c:140 ../vector/v.reclass/main.c:125
-#: ../vector/v.surf.idw/read_sites.c:36
-#, fuzzy, c-format
-msgid "Database connection not defined for layer %s"
-msgstr "नहीं"
-#: ../vector/v.sample/main.c:154
-#, fuzzy, c-format
-msgid "Column type <%s> not supported (must be integer or double precision)"
-msgstr "नहीं"
-#: ../vector/v.sample/main.c:160 ../vector/v.normal/main.c:134
-#: ../vector/v.surf.idw/read_sites.c:56
-#, c-format
-msgid "%d records selected from table"
-msgstr ""
-#: ../vector/v.sample/main.c:189 ../vector/v.patch/main.c:293
-#, fuzzy, c-format
-msgid "Unable to create table <%s>"
-msgstr "i n"
-#: ../vector/v.sample/main.c:199
-#, fuzzy
-msgid "Reading points..."
-msgstr "छवि "
-#: ../vector/v.distance/main.c:87
-msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
-msgstr ""
-#: ../vector/v.distance/main.c:91
-#, fuzzy
-msgid "Name of existing vector map (from)"
-msgstr "का"
-#: ../vector/v.distance/main.c:96
-#, fuzzy
-msgid "Layer number or name (from)"
-msgstr "नहीं"
-#: ../vector/v.distance/main.c:103
-#, fuzzy
-msgid "Feature type (from)"
-msgstr "विशेषता"
-#: ../vector/v.distance/main.c:108
-#, fuzzy
-msgid "Name of existing vector map (to)"
-msgstr "का"
-#: ../vector/v.distance/main.c:113
-#, fuzzy
-msgid "Layer number or name (to)"
-msgstr "नहीं"
-#: ../vector/v.distance/main.c:120
-#, fuzzy
-msgid "Feature type (to)"
-msgstr "विशेषता"
-#: ../vector/v.distance/main.c:126
-#, fuzzy
-msgid "Name for output vector map containing lines connecting nearest elements"
-msgstr "का"
-#: ../vector/v.distance/main.c:134
-#, fuzzy
-msgid "Maximum distance or -1 for no limit"
-msgstr "बिन्दु"
-#: ../vector/v.distance/main.c:141
-#, fuzzy
-msgid "Minimum distance or -1 for no limit"
-msgstr "बिन्दु"
-#: ../vector/v.distance/main.c:150
-msgid "Values describing the relation between two nearest features"
-msgstr ""
-#: ../vector/v.distance/main.c:152
-msgid "cat;category of the nearest feature;dist;minimum distance to nearest feature;to_x;x coordinate of the nearest point on the 'to' feature;to_y;y coordinate of the nearest point on the 'to' feature;to_along;distance to the nearest point on the 'to' feature along that linear feature;to_angle;angle along the nearest linear feature in the 'to' map, measured CCW from the +x axis, in radians, between -Pi and Pi inclusive;to_attr;attribute of nearest feature given by to_column option"
-msgstr ""
-#: ../vector/v.distance/main.c:173
-msgid "Column name(s) where values specified by 'upload' option will be uploaded"
-msgstr ""
-#: ../vector/v.distance/main.c:174
-msgid "From_map"
-msgstr ""
-#: ../vector/v.distance/main.c:179
-msgid "Column name of nearest feature (used with upload=to_attr)"
-msgstr ""
-#: ../vector/v.distance/main.c:185
-#, fuzzy
-msgid "Name of table created when the 'distance to all' flag is used"
-msgstr "का"
-#: ../vector/v.distance/main.c:190
-msgid "Print output to stdout, don't update attribute table"
-msgstr ""
-#: ../vector/v.distance/main.c:192
-msgid "First column is always category of 'from' feature called from_cat"
-msgstr ""
-#: ../vector/v.distance/main.c:197
-msgid "Calculate distances to all features within the threshold"
-msgstr ""
-#: ../vector/v.distance/main.c:199
-msgid "Output is written to stdout but may be uploaded to a new table created by this module; multiple 'upload' options may be used."
-msgstr ""
-#: ../vector/v.distance/main.c:254
-msgid "to_column option missing"
-msgstr ""
-#: ../vector/v.distance/main.c:266
-#, fuzzy
-msgid "Too many column names"
-msgstr "ज़ेड"
-#: ../vector/v.distance/main.c:273
-#, fuzzy
-msgid "Not enough column names"
-msgstr "ज़ेड"
-#: ../vector/v.distance/main.c:341
-#, fuzzy, c-format
-msgid "No features of selected type in To vector <%s>"
-msgstr "n"
-#: ../vector/v.distance/main.c:415
-#, fuzzy
-msgid "Unable to open default database"
-msgstr "स्रोत"
-#: ../vector/v.distance/main.c:471
-#, fuzzy
-msgid "Incompatible column types"
-#: ../vector/v.distance/main.c:544
-#, fuzzy
-msgid "Finding nearest feature..."
-msgstr "n"
-#: ../vector/v.distance/main.c:728
-#, fuzzy
-msgid "Finding nearest areas..."
-msgstr "n"
-#: ../vector/v.distance/main.c:837
-#, c-format
-msgid "More cats found in to_layer (area=%d)"
-msgstr ""
-#: ../vector/v.distance/main.c:992
-msgid "DATETIME type not yet supported, no attributes will be uploaded"
-msgstr ""
-#: ../vector/v.distance/main.c:1248
-#, fuzzy, c-format
-msgid "%d categories with more than 1 feature in vector map <%s>"
-#: ../vector/v.distance/main.c:1251
-#, fuzzy, c-format
-msgid "%d categories - no nearest feature found"
-#: ../vector/v.distance/main.c:1260
-#, c-format
-msgid "%d distances calculated"
-msgstr ""
-#: ../vector/v.distance/main.c:1261
-#, c-format
-msgid "%d records inserted"
-msgstr ""
-#: ../vector/v.distance/main.c:1263
-#, c-format
-msgid "%d insert errors"
-msgstr ""
-#: ../vector/v.distance/main.c:1267
-#, fuzzy, c-format
-msgid "%d categories read from the map"
-#: ../vector/v.distance/main.c:1269
-#, fuzzy, c-format
-msgid "%d categories exist in the table"
-#: ../vector/v.distance/main.c:1271
-#, fuzzy, c-format
-msgid "%d categories read from the map exist in the table"
-#: ../vector/v.distance/main.c:1274
-#, fuzzy, c-format
-msgid "%d categories read from the map don't exist in the table"
-#: ../vector/v.distance/main.c:1277 ../vector/v.vect.stats/main.c:709
-#: ../vector/v.what.rast/main.c:357
-#, c-format
-msgid "%d update errors"
-msgstr ""
-#: ../vector/v.distance/main.c:1279 ../vector/v.what.rast/main.c:359
-#, fuzzy, c-format
-msgid "%d records updated."
-msgstr "नहीं"
-#: ../vector/v.to.db/query.c:83 ../vector/v.to.db/main.c:53
-#: ../vector/v.to.db/update.c:28 ../vector/v.to.db/update.c:32
-#, fuzzy, c-format
-msgid "Database connection not defined for layer %d. Use v.db.connect first."
-msgstr "नहीं के लिए."
-#: ../vector/v.to.db/query.c:93
-#, fuzzy
-msgid "Querying database... "
-msgstr "छवि "
-#: ../vector/v.to.db/query.c:108
-#, c-format
-msgid "Query for category '0' (no category) was not executed because of too many (%d) query categories. All later reported values for cat 0 are not valid."
-msgstr ""
-#: ../vector/v.to.db/query.c:145
-#, c-format
-msgid "Multiple query results, output value set to NULL (category [%d])"
-msgstr ""
-#: ../vector/v.to.db/query.c:152
-#, fuzzy
-msgid "Unable to fetch record"
-msgstr "के लिए"
-#: ../vector/v.to.db/main.c:39
-msgid "Populates database values from vector features."
-msgstr ""
-#: ../vector/v.to.db/update.c:82
-#, fuzzy
-msgid "Updating database..."
-msgstr "नक़ल"
-#: ../vector/v.to.db/update.c:115
-#, fuzzy, c-format
-msgid "More elements of category %d, nothing loaded to database"
-msgstr "नहीं"
-#: ../vector/v.to.db/update.c:213
-#, fuzzy, c-format
-msgid "Record (cat %d) already exists (not inserted)"
-msgstr "i n"
-#: ../vector/v.to.db/update.c:221 ../vector/v.to.3d/trans3.c:132
-#, fuzzy, c-format
-msgid "Record (cat %d) does not exist (not updated)"
-msgstr "नहीं"
-#: ../vector/v.to.db/parse.c:34
-#, fuzzy
-msgid "Layer number or name (write to)"
-msgstr "नहीं"
-#: ../vector/v.to.db/parse.c:39 ../vector/v.net.bridge/main.c:96
-#: ../vector/v.vect.stats/main.c:147
-#, fuzzy
-msgid "Feature type"
-msgstr "विशेषता"
-#: ../vector/v.to.db/parse.c:41
-#, fuzzy
-msgid "For coor valid point/centroid, for length valid line/boundary"
-msgstr "का के लिए बिन्दु के लिए"
-#: ../vector/v.to.db/parse.c:46
-#, fuzzy
-msgid "Query layer number or name (read from)"
-msgstr "नहीं"
-#: ../vector/v.to.db/parse.c:47 ../vector/v.to.db/parse.c:89
-#: ../db/db.select/main.c:196 ../db/db.select/main.c:201
-#: ../db/db.select/main.c:247 ../db/db.select/main.c:257
-msgid "Query"
-msgstr ""
-#: ../vector/v.to.db/parse.c:56
-msgid "Value to upload"
-msgstr ""
-#: ../vector/v.to.db/parse.c:86
-#, fuzzy
-msgid "Name of attribute column used for 'query' option"
-msgstr "क्वैरी उपयोग में."
-#: ../vector/v.to.db/parse.c:87
-#, fuzzy
-msgid "E.g. 'cat', 'count(*)', 'sum(val)'"
-msgstr "क्वैरी के लिए जी"
-#: ../vector/v.to.db/parse.c:93
-#, fuzzy
-msgid "Print only"
-msgstr "छापें"
-#: ../vector/v.to.db/parse.c:98
-#, fuzzy
-msgid "Only print SQL statements"
-msgstr "फ़ाइलनाम "
-#: ../vector/v.to.db/parse.c:104
-#, fuzzy
-msgid "In print mode prints totals for options: length,area,count"
-msgstr "के लिए"
-#: ../vector/v.to.db/parse.c:139
-#, fuzzy
-msgid "This option requires one column"
-msgstr "एक"
-#: ../vector/v.to.db/parse.c:144
-#, fuzzy
-msgid "This option requires two columns"
-msgstr "एक"
-#: ../vector/v.to.db/parse.c:149
-#, fuzzy
-msgid "This option requires at least two columns"
-msgstr "पर"
-#: ../vector/v.to.db/parse.c:155
-msgid "Parameter 'qcolumn' must be specified for 'option=query'"
-msgstr ""
-#: ../vector/v.to.db/parse.c:160
-#, fuzzy
-msgid "The 'sides' option makes sense only for boundaries"
-msgstr "के लिए"
-#: ../vector/v.to.db/parse.c:163
-#, fuzzy
-msgid "The 'sinuous' option makes sense only for lines"
-msgstr "के लिए"
-#: ../vector/v.to.db/parse.c:166
-#, fuzzy
-msgid "The 'azimuth' option makes sense only for lines"
-msgstr "के लिए"
-#: ../vector/v.to.db/report.c:187
-#, fuzzy, c-format
-msgid "%d categories read from vector map (layer %d)"
-#: ../vector/v.to.db/report.c:191
-#, fuzzy, c-format
-msgid "%d records selected from table (layer %d)"
-msgstr "नहीं"
-#: ../vector/v.to.db/report.c:194
-#, fuzzy, c-format
-msgid "%d categories read from vector map exist in selection from table"
-#: ../vector/v.to.db/report.c:197
-#, fuzzy, c-format
-msgid "%d categories read from vector map don't exist in selection from table"
-#: ../vector/v.to.db/report.c:199
-#, fuzzy, c-format
-msgid "%d records updated/inserted (layer %d)"
-msgstr "नहीं"
-#: ../vector/v.to.db/report.c:202
-#, fuzzy, c-format
-msgid "%d update/insert errors (layer %d)"
-msgstr "नहीं"
-#: ../vector/v.to.db/report.c:205
-#, fuzzy, c-format
-msgid "%d categories with more points (coordinates not loaded)"
-#: ../vector/v.to.db/areas.c:28 ../vector/v.to.rast/do_areas.c:34
-#, fuzzy
-msgid "Reading areas..."
-msgstr "n"
-#: ../vector/v.mkgrid/write_grid.c:42
-#, fuzzy
-msgid "Writing out vector rows..."
-msgstr "n"
-#: ../vector/v.mkgrid/write_grid.c:79
-#, fuzzy
-msgid "Writing out vector columns..."
-msgstr "n"
-#: ../vector/v.mkgrid/main.c:67
-#, fuzzy
-msgid "Creates a vector map of a user-defined grid."
-msgstr "a का a."
-#: ../vector/v.mkgrid/main.c:78
-#, fuzzy
-msgid "Number of rows and columns in grid"
-msgstr "संख्या का"
-#: ../vector/v.mkgrid/main.c:87
-msgid "Where to place the grid"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:88
-msgid "region;current region;coor;use 'coor' and 'box' options"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:98
-#, fuzzy
-msgid "Lower left easting and northing coordinates of map"
-msgstr "बायाँ का"
-#: ../vector/v.mkgrid/main.c:106
-#, fuzzy
-msgid "Width and height of boxes in grid"
-msgstr "का"
-#: ../vector/v.mkgrid/main.c:113
-#, fuzzy
-msgid "Angle of rotation (in degrees counter-clockwise)"
-msgstr "कोण कोण"
-#: ../vector/v.mkgrid/main.c:121
-#, fuzzy
-msgid "Number of horizontal vertex points per grid cell"
-msgstr "का"
-#: ../vector/v.mkgrid/main.c:128
-msgid "Create grid of points instead of areas and centroids"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:177
-msgid "'coor' option missing"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:180
-msgid "'box' option missing"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:184
-#, fuzzy
-msgid "Invalid easting"
-msgstr "के लिए थीटा"
-#: ../vector/v.mkgrid/main.c:187
-#, fuzzy
-msgid "Invalid northing"
-msgstr "के लिए"
-#: ../vector/v.mkgrid/main.c:191 ../vector/v.mkgrid/main.c:194
-#, fuzzy
-msgid "Invalid distance"
-#: ../vector/v.mkgrid/main.c:260
-#, fuzzy
-msgid "Creating centroids..."
-msgstr "बनाया जा रहा है."
-#: ../vector/v.net.bridge/main.c:48
-#, fuzzy
-msgid "articulation points"
-msgstr "का"
-#: ../vector/v.net.bridge/main.c:50
-msgid "Computes bridges and articulation points in the network."
-msgstr ""
-#: ../vector/v.net.bridge/main.c:94
-msgid "bridge;Finds bridges;articulation;Finds articulation points;"
-msgstr ""
-#: ../vector/v.build.polylines/main.c:114
-msgid "Builds polylines from lines or boundaries."
-msgstr ""
-#: ../vector/v.build.polylines/main.c:124
-msgid "Category number mode"
-msgstr ""
-#: ../vector/v.build.polylines/main.c:126
-msgid "no;Do not assign any category number to polyline;first;Assign category number of first line to polyline;multi;Assign multiple category numbers to polyline"
-msgstr ""
-#: ../vector/v.build.polylines/main.c:217
-#, fuzzy, c-format
-msgid "%d lines or boundaries found in vector map <%s@%s>"
-msgstr "नहीं"
-#: ../vector/v.build.polylines/main.c:219
-#, fuzzy, c-format
-msgid "%d polylines stored in vector map <%s@%s>"
-msgstr "n"
-#: ../vector/v.delaunay/in_out.c:93
-#, fuzzy
-msgid "Writing edges..."
-msgstr "छापें"
-#: ../vector/v.delaunay/in_out.c:215
-#, fuzzy
-msgid "Reading point features..."
-msgstr "n"
-#: ../vector/v.delaunay/main.c:88
-#, fuzzy
-msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
-msgstr "a बिन्दु."
-#: ../vector/v.delaunay/main.c:98 ../vector/v.normal/main.c:97
-#, fuzzy
-msgid "Use only points in current region"
-msgstr "बनाम"
-#: ../vector/v.delaunay/main.c:103
-msgid "Output triangulation as a graph (lines), not areas"
-msgstr ""
-#: ../vector/v.delaunay/main.c:146
-#, fuzzy
-msgid "no points to triangulate"
-msgstr "संख्या का"
-#: ../vector/v.delaunay/main.c:149
-msgid "Delaunay triangulation..."
-msgstr ""
-#: ../vector/v.delaunay/main.c:161
-#, fuzzy
-msgid "Calculating area centroids..."
-#: ../vector/v.delaunay/main.c:177
-#, fuzzy
-msgid "Unable to calculate area centroid z coordinate"
-msgstr "के लिए"
-#: ../vector/v.delaunay/memory.c:64 ../vector/v.delaunay/memory.c:70
-#: ../vector/v.delaunay/memory.c:74 ../vector/v.delaunay/memory.c:84
-#: ../vector/v.delaunay/memory.c:92 ../vector/v.delaunay/memory.c:104
-#: ../vector/v.delaunay/memory.c:108
-#, fuzzy
-msgid "Not enough memory."
-msgstr "के लिए"
-#: ../vector/v.delaunay/memory.c:124
-msgid "All allocated edges have been used."
-msgstr ""
-#: ../vector/v.qcount/main.c:62
-msgid "Indices for quadrat counts of sites lists."
-msgstr ""
-#: ../vector/v.qcount/main.c:71
-#, fuzzy
-msgid "Name for output quadrant centres map (number of points is written as category)"
-msgstr "का"
-#: ../vector/v.qcount/main.c:77
-#, fuzzy
-msgid "Number of quadrats"
-msgstr "का फ्रेम्स"
-#: ../vector/v.qcount/main.c:83
-msgid "Quadrat radius"
-msgstr ""
-#: ../vector/v.qcount/main.c:87
-#, fuzzy
-msgid "Print results in shell script style"
-msgstr "छापें"
-#: ../vector/v.qcount/main.c:102
-#, fuzzy
-msgid "Finding quadrats..."
-msgstr "n"
-#: ../vector/v.qcount/main.c:107
-#, fuzzy
-msgid "Counting points quadrats..."
-msgstr "n"
-#: ../vector/v.category/main.c:76
-msgid "Attaches, deletes or reports vector categories to map geometry."
-msgstr ""
-#: ../vector/v.category/main.c:88
-msgid "Feature ids (by default all features are processed)"
-msgstr ""
-#: ../vector/v.category/main.c:100
-#, fuzzy
-msgid "Action to be done"
-msgstr "फ़ाइल"
-#: ../vector/v.category/main.c:101
-msgid "add;add a new category;del;delete category (-1 to delete all categories of given layer);chlayer;change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add the value specified by cat option to the current category value;transfer;copy values from one layer to another (e.g. layer=1,2,3 copies values from layer 1 to layer 2 and 3);report;print report (statistics), in shell style: layer type count min max;print;print category values, more cats in the same layer are separated by '/'"
-msgstr ""
-#: ../vector/v.category/main.c:118
-#: ../locale/scriptstrings/v.centroids_to_translate.c:7
-msgid "Category increment"
-msgstr ""
-#: ../vector/v.category/main.c:122
-msgid "Shell script style, currently only for report"
-msgstr ""
-#: ../vector/v.category/main.c:123
-msgid "Format: layer type count min max"
-msgstr ""
-#: ../vector/v.category/main.c:141
-msgid "Database connection and attribute tables for concerned layers are not changed"
-msgstr ""
-#: ../vector/v.category/main.c:162
-msgid "Invalid category number (must be equal to or greater than 0). Normally category number starts at 1."
-msgstr ""
-#: ../vector/v.category/main.c:171
-#, fuzzy, c-format
-msgid "%d errors in id option"
-msgstr "त्रुटि"
-#: ../vector/v.category/main.c:180
-#, fuzzy
-msgid "Output vector wasn't entered"
-msgstr "का."
-#: ../vector/v.category/main.c:201 ../vector/v.category/main.c:209
-#, fuzzy, c-format
-msgid "Can not open vector <%s> on level %d"
-msgstr "के लिए."
-#: ../vector/v.category/main.c:226
-#, fuzzy
-msgid "Too many layers for this operation"
-msgstr "के लिए"
-#: ../vector/v.category/main.c:229 ../vector/v.category/main.c:232
-msgid "2 layers must be specified"
-msgstr ""
-#: ../vector/v.category/main.c:240
-#, fuzzy, c-format
-msgid "Categories already exist in layer %d"
-#: ../vector/v.category/main.c:283 ../vector/v.select/select.c:40
-#, fuzzy
-msgid "Processing features..."
-msgstr "n"
-#: ../vector/v.category/main.c:328
-#, fuzzy, c-format
-msgid "%d new centroids placed in output map"
-msgstr "n"
-#: ../vector/v.category/main.c:617
-#, fuzzy
-msgid "Layer/table"
-msgstr "नहीं"
-#: ../vector/v.category/main.c:621
-#, fuzzy
-msgid "Layer"
-msgstr "n"
-#: ../vector/v.category/main.c:623
-#, fuzzy, c-format
-msgid "type       count        min        max\n"
-msgstr "n n"
-#: ../vector/v.category/main.c:624
-#, fuzzy
-msgid "point"
-msgstr "फ़ॉन्ट"
-#: ../vector/v.category/main.c:628
-msgid "line"
-msgstr ""
-#: ../vector/v.category/main.c:632
-#, fuzzy
-msgid "boundary"
-msgstr "नक़ल"
-#: ../vector/v.category/main.c:636
-#: ../locale/scriptstrings/v.centroids_to_translate.c:3
-#, fuzzy
-msgid "centroid"
-msgstr "n"
-#: ../vector/v.category/main.c:640
-#: ../locale/scriptstrings/v.centroids_to_translate.c:4
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:3
-#, fuzzy
-msgid "area"
-msgstr "n"
-#: ../vector/v.category/main.c:644
-#, fuzzy
-msgid "face"
-msgstr "नक़ल"
-#: ../vector/v.category/main.c:648
-msgid "kernel"
-msgstr ""
-#: ../vector/v.category/main.c:652
-msgid "all"
-msgstr ""
-#: ../vector/v.category/main.c:705
-#, fuzzy
-msgid "Copying attribute table(s)..."
-msgstr "नहीं"
-#: ../vector/v.category/main.c:713
-#, fuzzy, c-format
-msgid "Categories copied from layer %d to layer %d"
-#: ../vector/v.category/main.c:715
-#, fuzzy, c-format
-msgid "%d features modified."
-msgstr "n"
-#: ../vector/v.net.flow/main.c:60
-msgid "flow"
-msgstr ""
-#: ../vector/v.net.flow/main.c:62
-msgid "Computes the maximum flow between two sets of nodes in the network."
-msgstr ""
-#: ../vector/v.net.flow/main.c:84
-#, fuzzy
-msgid "Name for output vector map containing a minimum cut"
-msgstr "का"
-#: ../vector/v.net.flow/main.c:107
-#, fuzzy
-msgid "Source category values"
-msgstr "के लिए."
-#: ../vector/v.net.flow/main.c:113
-msgid "Source WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-#: ../vector/v.net.flow/main.c:118
-#, fuzzy
-msgid "Sink category values"
-msgstr "छापें"
-#: ../vector/v.net.flow/main.c:119 ../vector/v.net.flow/main.c:125
-msgid "Sink"
-msgstr ""
-#: ../vector/v.net.flow/main.c:124
-msgid "Sink WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-#: ../vector/v.net.flow/main.c:198 ../vector/v.net.flow/main.c:203
-#: ../vector/v.net.connectivity/main.c:148
-#: ../vector/v.net.connectivity/main.c:153
-#, fuzzy, c-format
-msgid "Neither %s nor %s was given"
-msgstr "पाठ"
-#: ../vector/v.net.flow/main.c:211
-#, fuzzy
-msgid "No sources"
-msgstr "नहीं n"
-#: ../vector/v.net.flow/main.c:214
-#, fuzzy
-msgid "No sinks"
-msgstr "घुमाएँ"
-#: ../vector/v.net.flow/main.c:237
-#, fuzzy
-msgid "Writing the output..."
-msgstr "n"
-#: ../vector/v.in.region/main.c:40
-#, fuzzy
-msgid "Create a new vector from the current region."
-msgstr "नहीं"
-#: ../vector/v.in.region/main.c:48
-msgid "Select type: line or area"
-msgstr ""
-#: ../vector/v.buffer/main.c:214
-#, fuzzy
-msgid "Creates a buffer around vector features of given type."
-msgstr "a का रखे हुए."
-#: ../vector/v.buffer/main.c:233
-#, fuzzy
-msgid "Buffer distance along major axis in map units"
-msgstr "f"
-#: ../vector/v.buffer/main.c:234 ../vector/v.buffer/main.c:242
-#: ../vector/v.buffer/main.c:250 ../vector/v.buffer/main.c:256
-#: ../vector/v.buffer/main.c:264 ../vector/v.buffer/main.c:273
-msgid "Distance"
-msgstr ""
-#: ../vector/v.buffer/main.c:241
-#, fuzzy
-msgid "Buffer distance along minor axis in map units"
-msgstr "f"
-#: ../vector/v.buffer/main.c:255
-#, fuzzy
-msgid "Name of column to use for buffer distances"
-msgstr "के लिए"
-#: ../vector/v.buffer/main.c:263
-#, fuzzy
-msgid "Scaling factor for attribute column values"
-msgstr "के लिए"
-#: ../vector/v.buffer/main.c:272
-#, fuzzy
-msgid "Maximum distance between theoretical arc and polygon segments as multiple of buffer"
-msgstr "चाप बहुभुज का"
-#: ../vector/v.buffer/main.c:277
-msgid "Make outside corners straight"
-msgstr ""
-#: ../vector/v.buffer/main.c:281
-msgid "Don't make caps at the ends of polylines"
-msgstr ""
-#: ../vector/v.buffer/main.c:292
-msgid "Select a buffer distance/minordistance/angle or column, but not both."
-msgstr ""
-#: ../vector/v.buffer/main.c:296
-msgid "The bufcol option may contain bugs during the cleaning step. If you encounter problems, use the debug option or clean manually with v.clean tool=break; v.category step=0; v.extract -d type=area"
-msgstr ""
-#: ../vector/v.buffer/main.c:313
-#, fuzzy
-msgid "The bufcol option requires a valid layer."
-msgstr "स्केल"
-#: ../vector/v.buffer/main.c:317
-#, fuzzy
-msgid "The tolerance must be > 0."
-msgstr "जी"
-#: ../vector/v.buffer/main.c:320
-#, fuzzy, c-format
-msgid "The tolerance was reset to %g"
-msgstr "जी"
-#: ../vector/v.buffer/main.c:341
-#, fuzzy, c-format
-msgid "The tolerance in map units = %g"
-msgstr "जी"
-#: ../vector/v.buffer/main.c:381
-#, fuzzy, c-format
-msgid "Unable to select data from table <%s>"
-msgstr "सभी"
-#: ../vector/v.buffer/main.c:417
-msgid "No features available for buffering. Check type option and features available in the input vector."
-msgstr ""
-#: ../vector/v.buffer/main.c:432
-#, fuzzy
-msgid "Buffering lines..."
-msgstr "n"
-#: ../vector/v.buffer/main.c:458 ../vector/v.buffer/main.c:560
-#, fuzzy, c-format
-msgid "Attribute is of invalid size (%.3f) for category %d"
-msgstr "है का अवैध आकार  के लिए."
-#: ../vector/v.buffer/main.c:472 ../vector/v.buffer/main.c:574
-#, fuzzy, c-format
-msgid "The tolerance in map units: %g"
-msgstr "जी"
-#: ../vector/v.buffer/main.c:534
-#, fuzzy
-msgid "Buffering areas..."
-msgstr "n"
-#: ../vector/v.buffer/main.c:613
-#, fuzzy
-msgid "Cleaning buffers..."
-msgstr "n"
-#: ../vector/v.buffer/main.c:616
-#, fuzzy
-msgid "Building parts of topology..."
-msgstr "n"
-#: ../vector/v.buffer/main.c:619
-#, fuzzy
-msgid "Snapping boundaries..."
-msgstr "n"
-#: ../vector/v.buffer/main.c:635
-#, fuzzy
-msgid "Cleaning boundaries at nodes"
-msgstr "n"
-#: ../vector/v.buffer/main.c:656 ../vector/v.buffer/main.c:749
-#, fuzzy
-msgid "Calculating centroids for areas..."
-msgstr "n"
-#: ../vector/v.buffer/main.c:687
-#, fuzzy
-msgid "Generating list of boundaries to be deleted..."
-msgstr "n"
-#: ../vector/v.buffer/main.c:720
-#, fuzzy
-msgid "Deleting boundaries..."
-msgstr "n"
-#: ../vector/v.surf.rst/main.c:145 ../vector/v.vol.rst/main.c:243
-msgid "RST"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:147
-#, fuzzy
-msgid "Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
-msgstr "बिन्दु बिन्दु."
-#: ../vector/v.surf.rst/main.c:154
-#, fuzzy
-msgid "Perform cross-validation procedure without raster approximation"
-msgstr "विधि"
-#: ../vector/v.surf.rst/main.c:159
-#, fuzzy
-msgid "Use scale dependent tension"
-msgstr "स्केल"
-#: ../vector/v.surf.rst/main.c:170 ../vector/v.surf.idw/main.c:123
-#: ../vector/v.surf.bspline/main.c:111
-#, fuzzy
-msgid "Use z coordinates for approximation (3D vector maps only)"
-msgstr "के लिए"
-#: ../vector/v.surf.rst/main.c:183
-#, fuzzy
-msgid "Name of the attribute column with values to be used for approximation"
-msgstr "का के लिए"
-#: ../vector/v.surf.rst/main.c:192
-#, fuzzy
-msgid "Name for output surface raster map (elevation)"
-msgstr "शीर्षक"
-#: ../vector/v.surf.rst/main.c:222
-#, fuzzy
-msgid "Name for output mean curvature raster map"
-msgstr "का"
-#: ../vector/v.surf.rst/main.c:228
-#, fuzzy
-msgid "Name for output deviations vector point map"
-msgstr "का बिन्दु"
-#: ../vector/v.surf.rst/main.c:235
-#, fuzzy
-msgid "Name for output cross-validation errors vector point map"
-msgstr "का बिन्दु"
-#: ../vector/v.surf.rst/main.c:242
-#, fuzzy
-msgid "Name for output vector map showing quadtree segmentation"
-msgstr "का"
-#: ../vector/v.surf.rst/main.c:249
-#, fuzzy
-msgid "Name for output vector map showing overlapping windows"
-msgstr "के लिए के लिए"
-#: ../vector/v.surf.rst/main.c:255
-#, fuzzy
-msgid "Name of raster map used as mask"
-msgstr "का"
-#: ../vector/v.surf.rst/main.c:263 ../vector/v.vol.rst/main.c:276
-msgid "Tension parameter"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:270 ../vector/v.vol.rst/main.c:284
-#, fuzzy
-msgid "Smoothing parameter"
-msgstr "चिकना"
-#: ../vector/v.surf.rst/main.c:278
-#, fuzzy
-msgid "Name of the attribute column with smoothing parameters"
-msgstr "का"
-#: ../vector/v.surf.rst/main.c:286 ../vector/v.vol.rst/main.c:325
-#, fuzzy
-msgid "Maximum number of points in a segment"
-msgstr "संख्या का a खण्ड"
-#: ../vector/v.surf.rst/main.c:295 ../vector/v.vol.rst/main.c:334
-#, fuzzy
-msgid "Minimum number of points for approximation in a segment (>segmax)"
-msgstr "संख्या का के लिए a खण्ड"
-#: ../vector/v.surf.rst/main.c:303 ../vector/v.vol.rst/main.c:351
-msgid "Minimum distance between points (to remove almost identical points)"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:311
-#, fuzzy
-msgid "Maximum distance between points on isoline (to insert additional points)"
-msgstr "चालू"
-#: ../vector/v.surf.rst/main.c:320
-#, fuzzy
-msgid "Conversion factor for values used for approximation"
-#: ../vector/v.surf.rst/main.c:328
-#, fuzzy
-msgid "Anisotropy angle (in degrees counterclockwise from East)"
-msgstr "कोण कोण पूर्व"
-#: ../vector/v.surf.rst/main.c:391 ../vector/v.surf.rst/main.c:396
-#: ../vector/v.surf.rst/main.c:401 ../vector/v.surf.rst/main.c:406
-#, fuzzy, c-format
-msgid "Output vector map name <%s> is not valid map name"
-msgstr "का."
-#: ../vector/v.surf.rst/main.c:419
-#, fuzzy
-msgid "You are not outputting any raster or vector maps"
-msgstr "नहीं"
-#: ../vector/v.surf.rst/main.c:428
-msgid "Both cross-validation options (-c flag and cvdev vector output) must be specified"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:431
-msgid "The cross-validation cannot be computed simultaneously with output raster or devi file"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:449
-#, fuzzy
-msgid "Using anisotropy - both theta and scalex have to be specified"
-msgstr "थीटा"
-#: ../vector/v.surf.rst/main.c:457
-msgid "Both smatt and smooth options specified - using constant"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:467
-#, fuzzy
-msgid "The computation will last too long - lower npmin is suggested"
-msgstr "है"
-#: ../vector/v.surf.rst/main.c:485
-#, fuzzy
-msgid "Not enough memory for az"
-msgstr "के लिए"
-#: ../vector/v.surf.rst/main.c:490
-#, fuzzy
-msgid "Not enough memory for adx"
-msgstr "के लिए"
-#: ../vector/v.surf.rst/main.c:494
-#, fuzzy
-msgid "Not enough memory for ady"
-msgstr "के लिए"
-#: ../vector/v.surf.rst/main.c:499
-#, fuzzy
-msgid "Not enough memory for adxx"
-msgstr "के लिए"
-#: ../vector/v.surf.rst/main.c:503
-#, fuzzy
-msgid "Not enough memory for adyy"
-msgstr "के लिए"
-#: ../vector/v.surf.rst/main.c:507
-#, fuzzy
-msgid "Not enough memory for adxy"
-msgstr "के लिए"
-#: ../vector/v.surf.rst/main.c:514
-msgid "Cannot create quaddata"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:520
-msgid "Cannot create quadfunc"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:523
-msgid "Cannot create tree"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:527
-msgid "Cannot create tree info"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:648
-#, c-format
-msgid "Processing all selected output files will require %d bytes of disk space for temp files"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:668
-#, fuzzy
-msgid "Processing segments..."
-msgstr "n"
-#: ../vector/v.surf.rst/main.c:674
-msgid "Interp_segmets failed"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:692
-#, fuzzy
-msgid "Unable to write raster maps - try to increase resolution"
-msgstr "का a"
-#: ../vector/v.transform/main.c:72
-msgid "Performs an affine transformation (shift, scale and rotate, or GPCs) on vector map."
-msgstr ""
-#: ../vector/v.transform/main.c:77
-msgid "Shift all z values to bottom=0"
-msgstr ""
-#: ../vector/v.transform/main.c:82
-#, fuzzy
-msgid "Print the transformation matrix to stdout"
-msgstr "छापें माट्रिक्स"
-#: ../vector/v.transform/main.c:87
-msgid "Swap coordinates x, y and then apply other parameters"
-msgstr ""
-#: ../vector/v.transform/main.c:92 ../vector/v.transform/main.c:103
-#: ../vector/v.transform/main.c:112 ../vector/v.transform/main.c:121
-#: ../vector/v.transform/main.c:130 ../vector/v.transform/main.c:139
-#: ../vector/v.transform/main.c:148 ../vector/v.transform/main.c:158
-#: ../vector/v.transform/main.c:163 ../vector/v.transform/main.c:170
-msgid "Custom"
-msgstr ""
-#: ../vector/v.transform/main.c:101
-#, fuzzy
-msgid "Shifting value for x coordinates"
-#: ../vector/v.transform/main.c:110
-#, fuzzy
-msgid "Shifting value for y coordinates"
-#: ../vector/v.transform/main.c:119 ../vector/v.extrude/main.c:91
-#, fuzzy
-msgid "Shifting value for z coordinates"
-#: ../vector/v.transform/main.c:128
-#, fuzzy
-msgid "Scaling factor for x coordinates"
-#: ../vector/v.transform/main.c:137
-#, fuzzy
-msgid "Scaling factor for y coordinates"
-#: ../vector/v.transform/main.c:146
-#, fuzzy
-msgid "Scaling factor for z coordinates"
-#: ../vector/v.transform/main.c:156
-#, fuzzy
-msgid "Rotation around z axis in degrees counterclockwise"
-msgstr "कोण कोण"
-#: ../vector/v.transform/main.c:162
-#, fuzzy
-msgid "Name of table containing transformation parameters"
-msgstr "का"
-#: ../vector/v.transform/main.c:167
-#, fuzzy
-msgid "Name of attribute column(s) used as transformation parameters"
-msgstr "का"
-#: ../vector/v.transform/main.c:169
-msgid "Format: parameter:column, e.g. xshift:xs,yshift:ys,zrot:zr"
-msgstr ""
-#: ../vector/v.transform/main.c:181
-#, c-format
-msgid "Table name is not defined. Please use '%s' parameter."
-msgstr ""
-#: ../vector/v.transform/main.c:186
-msgid "Name of table and name for output vector map must be different. Otherwise the table is overwritten."
-msgstr ""
-#: ../vector/v.transform/main.c:256
-#, fuzzy, c-format
-msgid "Unable to tokenize column string: [%s]"
-msgstr "का"
-#: ../vector/v.transform/main.c:272
-#, fuzzy
-msgid "Tranforming features..."
-msgstr "n"
-#: ../vector/v.transform/main.c:284
-#, fuzzy, c-format
-msgid "New vector map <%s> boundary coordinates:"
-msgstr "n"
-#: ../vector/v.transform/main.c:286
-#, fuzzy, c-format
-msgid " N: %-10.3f    S: %-10.3f"
-msgstr "n"
-#: ../vector/v.transform/main.c:287
-#, fuzzy, c-format
-msgid " E: %-10.3f    W: %-10.3f"
-msgstr "प n"
-#: ../vector/v.transform/main.c:288
-#, fuzzy, c-format
-msgid " B: %6.3f    T: %6.3f"
-msgstr "T n"
-#: ../vector/v.transform/trans_digit.c:97
-#, fuzzy, c-format
-msgid "Unsupported column type of <%s>"
-#: ../vector/v.transform/trans_digit.c:105
-#, c-format
-msgid "Unable to select value for category %d from table <%s>, column <%s>. For category %d using default transformation parameter %.3f."
-msgstr ""
-#: ../vector/v.transform/trans_digit.c:116
-msgid "No category number defined. Using default transformation parameters."
-msgstr ""
-#: ../vector/v.reclass/main.c:69 ../vector/v.class/main.c:45
-#, fuzzy
-msgid "attributes"
-msgstr "नहीं"
-#: ../vector/v.reclass/main.c:71
-#, fuzzy
-msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
-msgstr "के लिए का."
-#: ../vector/v.reclass/main.c:88
-#, fuzzy
-msgid "The name of the column whose values are to be used as new categories"
-msgstr "का के लिए"
-#: ../vector/v.reclass/main.c:89
-#, fuzzy
-msgid "The source for the new key column must be type integer or string"
-msgstr "ज़ेड"
-#: ../vector/v.reclass/main.c:94
-#, fuzzy
-msgid "Full path to the reclass rule file"
-msgstr "का a"
-#: ../vector/v.reclass/main.c:104
-#, fuzzy, c-format
-msgid "Either '%s' or '%s' must be specified"
-msgstr "का."
-#: ../vector/v.reclass/main.c:227 ../vector/v.to.rast/support.c:146
-#: ../vector/v.to.rast/support.c:301 ../vector/v.to.rast/vect2rast.c:70
-#, fuzzy, c-format
-msgid "No records selected from table <%s>"
-msgstr "नहीं"
-#: ../vector/v.reclass/main.c:240
-#, fuzzy
-msgid "Key column type is not integer"
-#: ../vector/v.reclass/main.c:250 ../vector/v.db.select/main.c:190
-#, fuzzy, c-format
-msgid "Unable to fetch data from table <%s>"
-msgstr "सभी"
-#: ../vector/v.reclass/main.c:276
-#, fuzzy, c-format
-msgid "Cannot insert data: [%s]"
-msgstr "के लिए"
-#: ../vector/v.reclass/main.c:313
-#, fuzzy
-msgid "Column type must be integer or string"
-msgstr "ज़ेड"
-#: ../vector/v.reclass/main.c:325
-#, fuzzy, c-format
-msgid "Unable to open rule file <%s>"
-msgstr "का"
-#: ../vector/v.reclass/main.c:341
-#, fuzzy, c-format
-msgid "Category %d overwritten by '%s'"
-#: ../vector/v.reclass/main.c:345
-#, fuzzy, c-format
-msgid "Category '%s' invalid"
-#: ../vector/v.reclass/main.c:349
-#, fuzzy, c-format
-msgid "Label '%s' overwritten by '%s'"
-#: ../vector/v.reclass/main.c:355
-#, c-format
-msgid "Condition '%s' overwritten by '%s'"
-msgstr ""
-#: ../vector/v.reclass/main.c:360
-#, fuzzy, c-format
-msgid "Unknown rule option: '%s'"
-#: ../vector/v.reclass/main.c:374
-#, fuzzy
-msgid "Cannot select values from database"
-msgstr "के लिए"
-#: ../vector/v.reclass/main.c:390
-#, c-format
-msgid "%d previously set categories overwritten by new category %d"
-msgstr ""
-#: ../vector/v.reclass/main.c:416
-#, fuzzy
-msgid "Incomplete rule"
-#: ../vector/v.reclass/main.c:452
-#, fuzzy, c-format
-msgid "%d features reclassed."
-msgstr "n"
-#: ../vector/v.neighbors/main.c:51
-#: ../locale/scriptstrings/tr.aggregate.ds_to_translate.c:4
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:4
-#: ../locale/scriptstrings/tr.aggregate_to_translate.c:4
-#, fuzzy
-msgid "aggregation"
-msgstr "का"
-#: ../vector/v.neighbors/main.c:52
-#, fuzzy
-msgid "Neighborhood analysis tool for vector point maps."
-msgstr "n"
-#: ../vector/v.neighbors/main.c:53
-#, fuzzy
-msgid "Makes each cell value a function of the attribute values assigned to the vector points or centroids around it, and stores new cell values in an output raster map."
-msgstr "a फंक्शन का."
-#: ../vector/v.neighbors/main.c:75
-#, fuzzy
-msgid "Neighborhood diameter in map units"
-msgstr "आकार "
-#: ../vector/v.neighbors/main.c:156 ../vector/v.normal/main.c:194
-#: ../vector/v.surf.idw/main.c:169
-#, fuzzy
-msgid "No points found"
-msgstr "n"
-#: ../vector/v.net.timetable/main.c:218
-#, fuzzy, c-format
-msgid "Could not find a path between stops %d and %d"
-msgstr "नहीं"
-#: ../vector/v.net.timetable/main.c:263
-msgid "Finds shortest path using timetables."
-msgstr ""
-#: ../vector/v.net.timetable/main.c:309
-msgid "Layer number or name with walking connections or -1"
-msgstr ""
-#: ../vector/v.net.timetable/main.c:315
-#, fuzzy
-msgid "Name of column with route ids"
-msgstr "का"
-#: ../vector/v.net.timetable/main.c:322
-#, fuzzy
-msgid "Name of column with stop timestamps"
-msgstr "का"
-#: ../vector/v.net.timetable/main.c:328
-#, fuzzy
-msgid "Name of column with stop ids"
-msgstr "का"
-#: ../vector/v.net.timetable/main.c:334
-#, fuzzy
-msgid "Name of column with walk lengths"
-msgstr "का"
-#: ../vector/v.net.timetable/main.c:382
-#, fuzzy
-msgid "Could not initialize the timetables"
-msgstr "नहीं"
-#: ../vector/v.net.timetable/main.c:458 ../vector/v.net.timetable/main.c:489
-#: ../vector/v.net.timetable/main.c:497
-#, fuzzy, c-format
-msgid "No stop with category: %d"
-#: ../vector/v.net.timetable/main.c:481 ../vector/v.net.path/path.c:149
-#, c-format
-msgid "Wrong input format: %s"
-msgstr ""
-#: ../vector/v.net.timetable/main.c:504
-#, fuzzy
-msgid "'From' and 'To' stops are the same"
-msgstr "का"
-#: ../vector/v.net.timetable/main.c:513
-msgid "No path between the stops"
-msgstr ""
-#: ../vector/v.out.svg/main.c:72
-#, fuzzy
-msgid "Exports a vector map to SVG file."
-msgstr "a a."
-#: ../vector/v.out.svg/main.c:81
-#, fuzzy
-msgid "Name for SVG output file"
-msgstr "के लिए"
-#: ../vector/v.out.svg/main.c:90
-#, fuzzy
-msgid "Output type"
-msgstr "नहीं"
-#: ../vector/v.out.svg/main.c:91
-msgid "Defines which feature-type will be extracted"
-msgstr ""
-#: ../vector/v.out.svg/main.c:99
-#, fuzzy
-msgid "Coordinate precision"
-msgstr "के लिए"
-#: ../vector/v.out.svg/main.c:105
-#, fuzzy
-msgid "Attribute(s) to include in output SVG"
-msgstr "का समूह"
-#: ../vector/v.out.svg/main.c:116
-msgid "Precision must not be negative"
-msgstr ""
-#: ../vector/v.out.svg/main.c:119
-msgid "Precision must not be higher than 15"
-msgstr ""
-#: ../vector/v.out.svg/main.c:186
-#, fuzzy, c-format
-msgid "Unable to create SVG file <%s>"
-msgstr "i n"
-#: ../vector/v.out.svg/main.c:201
-#, fuzzy
-msgid "No areas found, skipping type=poly"
-msgstr "नहीं"
-#: ../vector/v.out.svg/main.c:211 ../vector/v.extrude/main.c:201
-#, c-format
-msgid "Skipping area %d without centroid"
-msgstr ""
-#: ../vector/v.out.svg/main.c:238
-#, fuzzy, c-format
-msgid "Extracted %d areas"
-msgstr "n"
-#: ../vector/v.out.svg/main.c:244
-#, fuzzy
-msgid "No points found, skipping type=point"
-msgstr "नहीं"
-#: ../vector/v.out.svg/main.c:269
-#, fuzzy, c-format
-msgid "Extracted %d points"
-msgstr "n"
-#: ../vector/v.out.svg/main.c:275
-msgid "No lines found, skipping type=line"
-msgstr ""
-#: ../vector/v.out.svg/main.c:296
-#, fuzzy, c-format
-msgid "Extracted %d lines"
-msgstr "n"
-#: ../vector/v.out.svg/main.c:366
-#, fuzzy, c-format
-msgid "Cannot select attributes for cat=%d"
-msgstr "के लिए"
-#: ../vector/v.external/args.c:15
-#, fuzzy
-msgid "Name of input OGR data source"
-msgstr "के लिए"
-#: ../vector/v.external/args.c:16
-#, fuzzy
-msgid ""
-"Examples:\n"
-"\t\tESRI Shapefile: directory containing a shapefile\n"
-"\t\tMapInfo File: directory containing a mapinfo file\n"
-"\t\tPostGIS database: PG:dbname=<database>"
-msgstr "n n फ़ाइल"
-#: ../vector/v.external/args.c:27
-#, fuzzy
-msgid "Name of input OGR layer"
-msgstr "का"
-#: ../vector/v.external/args.c:28
-#, fuzzy
-msgid ""
-"Examples:\n"
-"\t\tESRI Shapefile: shapefile name\n"
-"\t\tMapInfo File: mapinfo file name\n"
-"\t\tPostGIS database: table name"
-msgstr "n n फ़ाइल"
-#: ../vector/v.external/args.c:37
-#, fuzzy
-msgid "Name for output GRASS vector map"
-msgstr "का"
-#: ../vector/v.external/args.c:41
-msgid "List supported OGR formats and exit"
-msgstr ""
-#: ../vector/v.external/args.c:53
-#, fuzzy
-msgid "List available OGR layers including feature types in datatsource and exit"
-msgstr "स्रोत"
-#: ../vector/v.external/list.c:13
-#, fuzzy
-msgid "Supported OGR formats for reading:"
-#: ../vector/v.external/list.c:36
-#, fuzzy, c-format
-msgid "Unable to open data source '%s'"
-msgstr "के लिए."
-#: ../vector/v.external/main.c:52
-#, fuzzy
-msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer."
-msgstr "a अन्य."
-#: ../vector/v.external/main.c:102
-#, fuzzy, c-format
-msgid "Unable to delete '%s'"
-msgstr "फ़ाइल"
-#: ../vector/v.external/main.c:125
-#, fuzzy, c-format
-msgid "Link to vector map <%s> created."
-msgstr "नहीं"
-#: ../vector/v.normal/main.c:77
-#, fuzzy
-msgid "Tests for normality for vector points."
-msgstr "घुमाएँ"
-#: ../vector/v.normal/main.c:89
-msgid "Lists of tests (1-15)"
-msgstr ""
-#: ../vector/v.normal/main.c:90
-msgid "E.g. 1,3-8,13"
-msgstr ""
-#: ../vector/v.normal/main.c:101
-msgid "Lognormality instead of normality"
-msgstr ""
-#: ../vector/v.normal/main.c:130
-#, fuzzy
-msgid "Only numeric column type supported"
-msgstr "नहीं"
-#: ../vector/v.normal/main.c:173 ../vector/v.normal/main.c:181
-#, fuzzy, c-format
-msgid "No record for cat %d"
-#: ../vector/v.normal/main.c:191
-#, fuzzy, c-format
-msgid "Number of points: %d"
-msgstr "का"
-#: ../vector/v.normal/main.c:197
-msgid "Too small sample"
-msgstr ""
-#: ../vector/v.normal/main.c:205
-msgid "Negative or very small point values set to -10.0"
-msgstr ""
-#: ../vector/v.normal/main.c:222
-#, c-format
-msgid "Moments \\sqrt{b_1} and b_2: "
-msgstr ""
-#: ../vector/v.normal/main.c:227
-#, c-format
-msgid "Geary's a-statistic & an approx. normal: "
-msgstr ""
-#: ../vector/v.normal/main.c:232
-#, c-format
-msgid "Extreme normal deviates: "
-msgstr ""
-#: ../vector/v.normal/main.c:237
-#, c-format
-msgid "D'Agostino's D & an approx. normal: "
-msgstr ""
-#: ../vector/v.normal/main.c:243
-#, c-format
-msgid "Kuiper's V (regular & modified for normality): "
-msgstr ""
-#: ../vector/v.normal/main.c:249
-#, c-format
-msgid "Watson's U^2 (regular & modified for normality): "
-msgstr ""
-#: ../vector/v.normal/main.c:255
-#, c-format
-msgid "Durbin's Exact Test (modified Kolmogorov): "
-msgstr ""
-#: ../vector/v.normal/main.c:261
-#, c-format
-msgid "Anderson-Darling's A^2 (regular & modified for normality): "
-msgstr ""
-#: ../vector/v.normal/main.c:267
-#, c-format
-msgid "Cramer-Von Mises W^2(regular & modified for normality): "
-msgstr ""
-#: ../vector/v.normal/main.c:273
-#, c-format
-msgid "Kolmogorov-Smirnov's D (regular & modified for normality): "
-msgstr ""
-#: ../vector/v.normal/main.c:279
-#, c-format
-msgid "Chi-Square stat (equal probability classes) and d.f.: "
-msgstr ""
-#: ../vector/v.normal/main.c:285
-msgid "Shapiro-Wilk's W cannot be used for n > 50"
-msgstr ""
-#: ../vector/v.normal/main.c:287
-msgid "Use Weisberg-Binghams's W''"
-msgstr ""
-#: ../vector/v.normal/main.c:290
-#, c-format
-msgid "Shapiro-Wilk W: "
-msgstr ""
-#: ../vector/v.normal/main.c:297
-msgid "Weisberg-Bingham's W'' cannot be used for n < 50 or n > 99"
-msgstr ""
-#: ../vector/v.normal/main.c:299
-#, c-format
-msgid "Weisberg-Bingham's W'': "
-msgstr ""
-#: ../vector/v.normal/main.c:306
-msgid "Royston only extended Shapiro-Wilk's W up to n = 2000"
-msgstr ""
-#: ../vector/v.normal/main.c:308
-#, c-format
-msgid "Shapiro-Wilk W'': "
-msgstr ""
-#: ../vector/v.normal/main.c:314
-#, c-format
-msgid "Kotz' T'_f (Lognormality vs. Normality): "
-msgstr ""
-#: ../vector/v.lidar.edgedetection/edgedetection.c:228
-#: ../vector/v.lidar.edgedetection/edgedetection.c:274
-#: ../vector/v.lidar.edgedetection/edgedetection.c:304
-#: ../vector/v.lidar.edgedetection/edgedetection.c:322
-#: ../vector/v.lidar.edgedetection/edgedetection.c:352
-#, fuzzy
-msgid "Impossible to read from aux table"
-msgstr "i n"
-#: ../vector/v.lidar.edgedetection/edgedetection.c:233
-#: ../vector/v.lidar.edgedetection/edgedetection.c:309
-#, fuzzy
-msgid "Impossible to update aux table"
-msgstr "i n"
-#: ../vector/v.lidar.edgedetection/edgedetection.c:246
-#: ../vector/v.lidar.edgedetection/edgedetection.c:258
-#: ../vector/v.lidar.edgedetection/edgedetection.c:379
-#, fuzzy
-msgid "Impossible to write to aux table"
-msgstr "i n"
-#: ../vector/v.lidar.edgedetection/main.c:76
-msgid "Detects the object's edges from a LIDAR data set."
-msgstr ""
-#: ../vector/v.lidar.edgedetection/main.c:111
-msgid "Regularization weight in gradient evaluation"
-msgstr ""
-#: ../vector/v.lidar.edgedetection/main.c:120
-#, fuzzy
-msgid "High gradient threshold for edge classification"
-msgstr "के लिए"
-#: ../vector/v.lidar.edgedetection/main.c:129
-#, fuzzy
-msgid "Low gradient threshold for edge classification"
-msgstr "के लिए"
-#: ../vector/v.lidar.edgedetection/main.c:137
-msgid "Angle range for same direction detection"
-msgstr ""
-#: ../vector/v.lidar.edgedetection/main.c:146
-msgid "Regularization weight in residual evaluation"
-msgstr ""
-#: ../vector/v.lidar.edgedetection/main.c:256
-#, fuzzy, c-format
-msgid "It was impossible to create <%s>."
-msgstr "i n"
-#: ../vector/v.lidar.edgedetection/main.c:259
-#, c-format
-msgid "It was impossible to create <%s> interpolation table in database."
-msgstr ""
-#: ../vector/v.lidar.edgedetection/main.c:392
-#, fuzzy
-msgid "Allocating memory for bilinear interpolation"
-msgstr "के लिए"
-#: ../vector/v.lidar.edgedetection/main.c:425
-#, fuzzy
-msgid "Allocating memory for bicubic interpolation"
-msgstr "का"
-#: ../vector/v.lidar.edgedetection/main.c:430
-#, fuzzy
-msgid "Bicubic interpolation"
-msgstr "का"
-#: ../vector/v.lidar.edgedetection/main.c:442
-#, fuzzy
-msgid "Point classification"
-msgstr "के लिए"
-#: ../vector/v.lidar.edgedetection/main.c:464
-#: ../vector/v.lidar.correction/main.c:434
-#, c-format
-msgid "Dropping <%s>"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:15
-#, fuzzy
-msgid "Feature type(s)"
-msgstr "विशेषता"
-#: ../vector/v.out.ogr/args.c:17
-#, fuzzy
-msgid "Combination of types is not supported by all output formats. Default is to use first type found in input vector map."
-msgstr "का है नहीं."
-#: ../vector/v.out.ogr/args.c:28
-#, fuzzy
-msgid "OGR output datasource name"
-msgstr "डाटाबेस नाम"
-#: ../vector/v.out.ogr/args.c:30
-msgid "For example: ESRI Shapefile: filename or directory for storage"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:37
-#, fuzzy
-msgid "OGR layer name. If not specified, input name is used."
-msgstr "n n फ़ाइल"
-#: ../vector/v.out.ogr/args.c:39
-#, fuzzy
-msgid "For example: ESRI Shapefile: shapefile name"
-msgstr "n n फ़ाइल"
-#: ../vector/v.out.ogr/args.c:49
-#, fuzzy
-msgid "Data format to write"
-msgstr "सदिश"
-#: ../vector/v.out.ogr/args.c:58
-msgid "OGR dataset creation option (format specific, NAME=VALUE)"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:68
-msgid "OGR layer creation option (format specific, NAME=VALUE)"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:73
-msgid "Open an existing datasource for update"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:77
-msgid "Append to existing layer instead of creating new if it exists"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:82
-msgid "Skip export of GRASS category ID ('cat') attribute"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:88
-#, fuzzy
-msgid "Also export features without category (not labeled). Otherwise only features with category are exported."
-msgstr "निर्यात सभी"
-#: ../vector/v.out.ogr/args.c:94
-msgid "Use ESRI-style .prj file format (applies to Shapefile output only)"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:100
-msgid "Create 3D output if input is 3D (applies to Shapefile output only)"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:106
-#, fuzzy
-msgid "Export lines as polygons"
-msgstr "प्लाट"
-#: ../vector/v.out.ogr/args.c:112
-#, fuzzy
-msgid "Create a new empty OGR layer in defined OGR datasource and exit. Nothing is read from input."
-msgstr "a है."
-#: ../vector/v.out.ogr/create.c:20
-#, fuzzy, c-format
-msgid "OGR driver <%s> not available"
-msgstr "नहीं"
-#: ../vector/v.out.ogr/create.c:26
-#, fuzzy, c-format
-msgid "Creation of output OGR datasource <%s> failed"
-msgstr "स्रोत"
-#: ../vector/v.out.ogr/create.c:36
-#, c-format
-msgid "Creation of OGR layer <%s> failed"
-msgstr ""
-#: ../vector/v.out.ogr/main.c:84
-msgid "ogr"
-msgstr ""
-#: ../vector/v.out.ogr/main.c:87
-#, fuzzy
-msgid "Converts a vector map to any of the supported OGR vector formats."
-msgstr "एक का."
-#: ../vector/v.out.ogr/main.c:155
-msgid "Volumes will be exported as sets of faces"
-msgstr ""
-#: ../vector/v.out.ogr/main.c:173
-#, fuzzy
-msgid "Unable to determine input map's vector feature type(s)."
-msgstr "का a"
-#: ../vector/v.out.ogr/main.c:221
-#, fuzzy
-msgid "The combination of types is not supported by all formats."
-#: ../vector/v.out.ogr/main.c:250
-#, c-format
-msgid "OGR layer <%s> created in datasource <%s> (format '%s')"
-msgstr ""
-#: ../vector/v.out.ogr/main.c:265
-msgid "The map contains islands. With the -c flag, islands will appear as filled areas, not holes in the output map."
-msgstr ""
-#: ../vector/v.out.ogr/main.c:271
-#, fuzzy, c-format
-msgid "%d point(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr "बिंदु नहीं."
-#: ../vector/v.out.ogr/main.c:276
-#, fuzzy, c-format
-msgid "%d line(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr "नहीं."
-#: ../vector/v.out.ogr/main.c:282
-#, fuzzy, c-format
-msgid "%d boundary(ies) found, but not requested to be exported. Verify 'type' parameter."
-msgstr "नहीं."
-#: ../vector/v.out.ogr/main.c:288
-#, fuzzy, c-format
-msgid "%d centroid(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr "नहीं."
-#: ../vector/v.out.ogr/main.c:293
-#, fuzzy, c-format
-msgid "%d area(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr "नहीं."
-#: ../vector/v.out.ogr/main.c:297
-#, fuzzy, c-format
-msgid "%d face(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr "नहीं."
-#: ../vector/v.out.ogr/main.c:302
-#, fuzzy, c-format
-msgid "%d volume(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr "नहीं."
-#: ../vector/v.out.ogr/main.c:308
-#, fuzzy
-msgid "No points found, but requested to be exported. Will skip this feature type."
-#: ../vector/v.out.ogr/main.c:317
-#, fuzzy
-msgid "No lines found, but requested to be exported. Will skip this feature type."
-msgstr "नहीं."
-#: ../vector/v.out.ogr/main.c:327
-#, fuzzy
-msgid "No boundaries found, but requested to be exported. Will skip this feature type."
-msgstr "नहीं."
-#: ../vector/v.out.ogr/main.c:336
-#, fuzzy
-msgid "No areas found, but requested to be exported. Will skip this feature type."
-msgstr "नहीं."
-#: ../vector/v.out.ogr/main.c:346
-#, fuzzy
-msgid "No centroids found, but requested to be exported. Will skip this feature type."
-msgstr "नहीं."
-#: ../vector/v.out.ogr/main.c:355
-#, fuzzy
-msgid "No faces found, but requested to be exported. Will skip this feature type."
-msgstr "नहीं."
-#: ../vector/v.out.ogr/main.c:364
-#, fuzzy
-msgid "No kernels found, but requested to be exported. Will skip this feature type."
-msgstr "नहीं."
-#: ../vector/v.out.ogr/main.c:373
-#, fuzzy
-msgid "No volumes found, but requested to be exported. Will skip this feature type."
-msgstr "नहीं."
-#: ../vector/v.out.ogr/main.c:384
-#, fuzzy
-msgid "Nothing to export"
-msgstr "n"
-#: ../vector/v.out.ogr/main.c:404
-#, fuzzy, c-format
-msgid "OGR driver <%s> not found"
-msgstr "नहीं"
-#: ../vector/v.out.ogr/main.c:408
-#, c-format
-msgid "Append existing layer requires opening data source in update mode, forcing '-%c' flag"
-msgstr ""
-#: ../vector/v.out.ogr/main.c:426
-#, fuzzy, c-format
-msgid "Unable to open OGR data source '%s'"
-msgstr "के लिए."
-#: ../vector/v.out.ogr/main.c:440
-#, fuzzy, c-format
-msgid "Layer <%s> already exists in OGR data source '%s'"
-msgstr "के लिए."
-#: ../vector/v.out.ogr/main.c:444
-#, fuzzy, c-format
-msgid "OGR layer <%s> already exists and will be overwritten"
-msgstr "i n"
-#: ../vector/v.out.ogr/main.c:451
-#, fuzzy, c-format
-msgid "OGR layer <%s> doesn't exists, creating new OGR layer instead"
-msgstr "i n"
-#: ../vector/v.out.ogr/main.c:478
-msgid "Overriding existing user-defined 'SHPT=' LCO."
-msgstr ""
-#: ../vector/v.out.ogr/main.c:493
-#, c-format
-msgid "Vector map <%s> is 3D. Use format specific layer creation options SHPT (parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
-msgstr ""
-#: ../vector/v.out.ogr/main.c:505
-#, c-format
-msgid "Vector map <%s> is 3D. Use format specific layer creation options DIM (parameter 'lco') to export in 3D rather than 2D (default)."
-msgstr ""
-#: ../vector/v.out.ogr/main.c:512
-#, c-format
-msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') to export in 3D rather than 2D (default)."
-msgstr ""
-#: ../vector/v.out.ogr/main.c:529 ../db/drivers/ogr/execute.c:56
-#, fuzzy, c-format
-msgid "OGR layer <%s> not found"
-msgstr "नहीं"
-#: ../vector/v.out.ogr/main.c:531
-#, fuzzy
-msgid "Unable to create OGR layer"
-msgstr "का a"
-#: ../vector/v.out.ogr/main.c:543
-#, fuzzy
-msgid "No attribute table found -> using only category numbers as attributes"
-msgstr "नहीं"
-#: ../vector/v.out.ogr/main.c:547
-msgid "Exporting 'cat' anyway, as it is the only attribute table field"
-msgstr ""
-#: ../vector/v.out.ogr/main.c:556 ../vector/v.out.ogr/main.c:626
-#, fuzzy, c-format
-msgid "New attribute column <%s> added to the table"
-#: ../vector/v.out.ogr/main.c:638
-#, fuzzy, c-format
-msgid "Key column <%s> not found"
-msgstr "नहीं"
-#: ../vector/v.out.ogr/main.c:651
-#, fuzzy, c-format
-msgid "Exporting %i features..."
-msgstr "n"
-#: ../vector/v.out.ogr/main.c:732
-#, c-format
-msgid "Exporting %i areas (may take some time)..."
-msgstr ""
-#: ../vector/v.out.ogr/main.c:807
-#, fuzzy, c-format
-msgid "Exporting %i faces..."
-msgstr "n"
-#: ../vector/v.out.ogr/main.c:869
-#, fuzzy, c-format
-msgid "Exporting %i kernels..."
-msgstr "n"
-#: ../vector/v.out.ogr/main.c:928
-#, fuzzy, c-format
-msgid "Exporting %i volumes..."
-msgstr "n"
-#: ../vector/v.out.ogr/main.c:929
-msgid "Export of volumes not implemented yet. Skipping."
-msgstr ""
-#: ../vector/v.out.ogr/main.c:946
-#, fuzzy, c-format
-msgid "%d features without category were written"
-msgstr "बिन्दु n"
-#: ../vector/v.out.ogr/main.c:948
-#, fuzzy, c-format
-msgid "%d features without attributes were written"
-msgstr "बिन्दु n"
-#: ../vector/v.out.ogr/main.c:950
-#, fuzzy, c-format
-msgid "%d features found without category were skipped"
-msgstr "बिन्दु n"
-#: ../vector/v.out.ogr/main.c:961
-#, fuzzy, c-format
-msgid "%d features written to <%s> (%s)."
-#: ../vector/v.out.ogr/attrb.c:41
-#, fuzzy, c-format
-msgid "Cannot select attributes for cat = %d"
-msgstr "के लिए"
-#: ../vector/v.out.ogr/attrb.c:58
-#, fuzzy, c-format
-msgid "No database record for cat = %d and export of 'cat' disabled"
-#: ../vector/v.patch/main.c:70
-#, fuzzy
-msgid "Creates a new vector map by combining other vector maps."
-msgstr "a अन्य."
-#: ../vector/v.patch/main.c:81
-#, fuzzy
-msgid "Name for output vector map where bounding boxes of input vector maps are written to"
-msgstr "का"
-#: ../vector/v.patch/main.c:85
-msgid "Append files to existing file (overwriting existing files must be activated)"
-msgstr ""
-#: ../vector/v.patch/main.c:90
-#, fuzzy
-msgid "Copy also attribute table"
-msgstr "नहीं"
-#: ../vector/v.patch/main.c:92
-msgid "Only the table of layer 1 is currently supported"
-msgstr ""
-#: ../vector/v.patch/main.c:97 ../vector/v.perturb/main.c:110
-#, fuzzy
-msgid "Do not build topology for output vector"
-msgstr "नहीं"
-#: ../vector/v.patch/main.c:195
-msgid "Missing table"
-msgstr ""
-#: ../vector/v.patch/main.c:199
-#, fuzzy
-msgid "Key columns differ"
-msgstr "का"
-#: ../vector/v.patch/main.c:205
-#, fuzzy
-msgid "Number of columns differ"
-msgstr "का"
-#: ../vector/v.patch/main.c:217
-#, fuzzy
-msgid "Column names differ"
-msgstr "ज़ेड"
-#: ../vector/v.patch/main.c:225
-#, fuzzy
-msgid "Column types differ"
-msgstr "ज़ेड"
-#: ../vector/v.patch/main.c:230
-#, fuzzy
-msgid "Length of string columns differ"
-msgstr "का"
-#: ../vector/v.patch/main.c:244
-#, fuzzy
-msgid "Key column not found"
-msgstr "नहीं"
-#: ../vector/v.patch/main.c:253
-#, fuzzy
-msgid "The output map is not 3D"
-msgstr "नहीं"
-#: ../vector/v.patch/main.c:306
-#, fuzzy, c-format
-msgid "Patching vector map <%s>..."
-msgstr "n"
-#: ../vector/v.patch/main.c:329
-#, c-format
-msgid "Error reading vector map <%s> - some data may not be correct"
-msgstr ""
-#: ../vector/v.patch/main.c:372
-#, fuzzy, c-format
-msgid "Building topology for vector map <%s>..."
-msgstr "n"
-#: ../vector/v.patch/main.c:378
-msgid "Intersections at borders will have to be snapped"
-msgstr ""
-#: ../vector/v.patch/main.c:379
-msgid "Lines common between files will have to be edited"
-msgstr ""
-#: ../vector/v.patch/main.c:380
-#, fuzzy
-msgid "The header information also may have to be edited"
-msgstr "सीमा नहीं."
-#: ../vector/v.patch/main.c:382
-#, fuzzy, c-format
-msgid "%d vector maps patched"
-msgstr "सदिश"
-#: ../vector/v.patch/main.c:405
-#, c-format
-msgid "Cannot open select cursor: '%s'"
-msgstr ""
-#: ../vector/v.patch/main.c:416
-#, fuzzy
-msgid "Cannot fetch row"
-msgstr "के लिए"
-#: ../vector/v.patch/main.c:467
-#, fuzzy
-msgid "Unknown column type"
-#: ../vector/v.patch/main.c:475
-#, fuzzy, c-format
-msgid "Cannot insert new record: '%s'"
-msgstr "के लिए"
-#: ../vector/v.net.spanningtree/main.c:48
-msgid "spanning tree"
-msgstr ""
-#: ../vector/v.net.spanningtree/main.c:50
-msgid "Computes minimum spanning tree for the network."
-msgstr ""
-#: ../vector/v.out.pov/main.c:49
-msgid "Converts GRASS x,y,z points to POV-Ray x,z,y format."
-msgstr ""
-#: ../vector/v.out.pov/main.c:60
-#, fuzzy
-msgid "Name for output POV file"
-msgstr "के लिए"
-#: ../vector/v.out.pov/main.c:67
-msgid "Radius of sphere for points and tube for lines"
-msgstr ""
-#: ../vector/v.out.pov/main.c:68
-msgid "May be also variable, e.g. grass_r."
-msgstr ""
-#: ../vector/v.out.pov/main.c:75
-#, fuzzy
-msgid "Modifier for z coordinates"
-msgstr "के लिए ज़ेड"
-#: ../vector/v.out.pov/main.c:76
-msgid "This string is appended to each z coordinate. Examples: '*10', '+1000', '*10+100', '*exaggeration'"
-msgstr ""
-#: ../vector/v.out.pov/main.c:84
-msgid "Object modifier (OBJECT_MODIFIER in POV-Ray documentation)"
-msgstr ""
-#: ../vector/v.out.pov/main.c:85
-msgid "Example: \"pigment { color red 0 green 1 blue 0 }\""
-msgstr ""
-#: ../vector/v.out.pov/main.c:105
-#, fuzzy, c-format
-msgid "Unable to create output file <%s>"
-msgstr "का"
-#: ../vector/v.out.pov/main.c:171 ../vector/v.select/select.c:166
-#, fuzzy
-msgid "Processing areas..."
-msgstr "n"
-#: ../vector/v.out.pov/main.c:214
-#, fuzzy, c-format
-msgid "%d features written."
-#: ../vector/v.select/args.c:14
-#, fuzzy
-msgid "Layer number (vector map A)"
-msgstr "का"
-#: ../vector/v.select/args.c:28
-#, fuzzy
-msgid "Layer number (vector map B)"
-msgstr "का"
-#: ../vector/v.select/args.c:45
-#, fuzzy
-msgid "Operator defines required relation between features"
-msgstr "n"
-#: ../vector/v.select/args.c:47
-msgid "A feature is written to output if the result of operation 'ainput operator binput' is true. An input feature is considered to be true, if category of given layer is defined."
-msgstr ""
-#: ../vector/v.select/args.c:52
-msgid "overlap;features partially or completely overlap"
-msgstr ""
-#: ../vector/v.select/args.c:57
-msgid "overlap;features partially or completely overlap;equals;features are spatially equals (using GEOS);disjoint;features do not spatially intersect (using GEOS);intersects;features spatially intersect (using GEOS);touches;features spatially touches (using GEOS);crosses;features spatially crosses (using GEOS);within;feature A is completely inside feature B (using GEOS);contains;feature B is completely inside feature A (using GEOS);overlaps;features spatially overlap (using GEOS);relate;feature A is spatially related to feature B (using GEOS, requires 'relate' option);"
-msgstr ""
-#: ../vector/v.select/args.c:74
-msgid "Intersection Matrix Pattern used for 'relate' operator"
-msgstr ""
-#: ../vector/v.select/args.c:83
-#, fuzzy
-msgid "Do not skip features without category"
-msgstr "बिन्दु n"
-#: ../vector/v.select/copy_tabs.c:49
-#, fuzzy, c-format
-msgid "No table for layer %d"
-msgstr "नहीं के लिए"
-#: ../vector/v.select/copy_tabs.c:64
-#, fuzzy, c-format
-msgid "Unable to copy table for layer %d"
-msgstr "का"
-#: ../vector/v.select/main.c:48
-msgid "spatial query"
-msgstr ""
-#: ../vector/v.select/main.c:50
-msgid "Selects features from vector map (A) by features from other vector map (B)."
-msgstr ""
-#: ../vector/v.select/main.c:83
-#, fuzzy, c-format
-msgid "Unknown operator '%s'"
-msgstr "अज्ञात क़िस्म"
-#: ../vector/v.select/main.c:109
-#, fuzzy
-msgid "Output from v.select"
-msgstr "फील्ड"
-#: ../vector/v.select/main.c:157
-#, fuzzy, c-format
-msgid "%d features without category skipped"
-msgstr "बिन्दु n"
-#: ../vector/v.select/main.c:160
-#, fuzzy, c-format
-msgid "%d features written to output."
-#: ../vector/v.select/write.c:26
-#, fuzzy
-msgid "Writing selected features..."
-msgstr "छापें"
-#: ../vector/v.select/select.c:63
-#, fuzzy, c-format
-msgid "Unable to read line id %d from vector map <%s>"
-msgstr "के लिए"
-#: ../vector/v.select/select.c:189
-#, fuzzy, c-format
-msgid "Unable to read area id %d from vector map <%s>"
-msgstr "के लिए."
-#: ../vector/v.convert/att.c:37
-#, fuzzy
-msgid "No category labels (dig_cats) found, no table created"
-msgstr "नहीं n"
-#: ../vector/v.convert/att.c:42
-#, fuzzy
-msgid "Unable to open dig_cats file"
-msgstr "के लिए"
-#: ../vector/v.convert/att.c:68 ../vector/v.info/print.c:142
-#, fuzzy, c-format
-msgid "Unable to open driver <%s>"
-msgstr "के लिए."
-#: ../vector/v.convert/old2new.c:31
-msgid "Failed opening input dig file."
-msgstr ""
-#: ../vector/v.convert/old2new.c:45
-msgid "dig_att file doesn't exist."
-msgstr ""
-#: ../vector/v.convert/old2new.c:49
-msgid "Failed opening input dig_att file."
-msgstr ""
-#: ../vector/v.convert/old2new.c:71
-#, fuzzy
-msgid "Attaching categories..."
-msgstr "n"
-#: ../vector/v.convert/old2new.c:88
-#, fuzzy, c-format
-msgid "Failed to attach an attribute (category %d) to a line."
-msgstr "a."
-#: ../vector/v.convert/old2new.c:93
-#, c-format
-msgid "Line %d label: %d matched another label: %d."
-msgstr ""
-#: ../vector/v.convert/old2new.c:102
-#, fuzzy
-msgid "Writing new file..."
-msgstr "n"
-#: ../vector/v.convert/old2new.c:124
-#, fuzzy, c-format
-msgid "[%d] points and lines written to output file."
-msgstr "n"
-#: ../vector/v.convert/old2new.c:138
-#, fuzzy, c-format
-msgid "[%d] centroids written to output file."
-msgstr "n"
-#: ../vector/v.convert/read.c:41
-#, fuzzy
-msgid "Reading dig file..."
-msgstr "n"
-#: ../vector/v.convert/read.c:82
-#, fuzzy
-msgid "Input file is version 3."
-msgstr "है संस्करण n"
-#: ../vector/v.convert/read.c:86
-#, fuzzy
-msgid "Input file is version 4."
-#: ../vector/v.convert/read.c:96
-#, fuzzy
-msgid "Input file is portable."
-msgstr "है n"
-#: ../vector/v.convert/read.c:99
-#, fuzzy
-msgid "Input file is not portable. We will attempt to convert anyway but conversion may fail. Please read manual for detail information."
-msgstr "है नहीं के लिए."
-#: ../vector/v.convert/read.c:185
-#, fuzzy, c-format
-msgid "[%d] points read to memory"
-msgstr "n"
-#: ../vector/v.convert/read.c:186
-#, fuzzy, c-format
-msgid "[%d] lines read to memory"
-msgstr "n"
-#: ../vector/v.convert/read.c:189
-#, fuzzy, c-format
-msgid "[%d] points read and written to output"
-msgstr "n"
-#: ../vector/v.convert/read.c:190
-#, fuzzy, c-format
-msgid "[%d] lines read and written to output"
-msgstr "n"
-#: ../vector/v.convert/read.c:192
-#, fuzzy, c-format
-msgid "[%d] area boundaries read and written to output"
-msgstr "n"
-#: ../vector/v.convert/read.c:193
-#, fuzzy, c-format
-msgid "[%d] dead points skipped"
-msgstr "n"
-#: ../vector/v.convert/read.c:194
-#, fuzzy, c-format
-msgid "[%d] dead lines skipped"
-msgstr "n"
-#: ../vector/v.convert/read.c:195
-#, fuzzy, c-format
-msgid "[%d] dead area boundaries skipped"
-msgstr "n"
-#: ../vector/v.convert/read.c:196
-#, fuzzy, c-format
-msgid "[%d] elements of unknown type skipped"
-msgstr "का n"
-#: ../vector/v.convert/read.c:198
-#, fuzzy, c-format
-msgid "[%d] elements read to memory"
-msgstr "n"
-#: ../vector/v.convert/read.c:241
-#, fuzzy
-msgid "Reading dig_att file..."
-msgstr "n"
-#: ../vector/v.convert/read.c:249
-#, fuzzy, c-format
-msgid "Error: %s"
-msgstr "त्रुटि"
-#: ../vector/v.convert/read.c:270
-#, c-format
-msgid "Unknown type: %c"
-msgstr ""
-#: ../vector/v.convert/read.c:293
-#, fuzzy, c-format
-msgid "[%d] point categories read"
-msgstr "बिन्दु n"
-#: ../vector/v.convert/read.c:294
-#, fuzzy, c-format
-msgid "[%d] line categories read"
-msgstr "n"
-#: ../vector/v.convert/read.c:295
-#, fuzzy, c-format
-msgid "[%d] centroids read"
-msgstr "n"
-#: ../vector/v.convert/read.c:296
-#, fuzzy, c-format
-msgid "[%d] dead point categories skipped"
-msgstr "बिन्दु n"
-#: ../vector/v.convert/read.c:297
-#, fuzzy, c-format
-msgid "[%d] dead line categories skipped"
-msgstr "n"
-#: ../vector/v.convert/read.c:298
-#, fuzzy, c-format
-msgid "[%d] dead centroids skipped"
-msgstr "n"
-#: ../vector/v.convert/read.c:299
-#, fuzzy, c-format
-msgid "[%d] categories of unknown type skipped"
-msgstr "का n"
-#: ../vector/v.convert/read.c:301
-#, fuzzy, c-format
-msgid "[%d] categories read into memory"
-msgstr "n"
-#: ../vector/v.convert/main.c:39
-#, fuzzy
-msgid "Imports older versions of GRASS vector maps."
-msgstr "का"
-#: ../vector/v.convert/main.c:56
-#, fuzzy
-msgid "Endian of input vector map"
-msgstr "का"
-#: ../vector/v.convert/type.c:29
-#, fuzzy, c-format
-msgid "OLD_T_NEW Got a bad type code [%x]"
-msgstr "त्रुटि T a"
-#: ../vector/v.convert/type.c:50
-#, fuzzy, c-format
-msgid "NEW_T_OLD Got a bad type code [%x]"
-#: ../vector/v.in.sites/main.c:59
-#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:2
-msgid "sites"
-msgstr ""
-#: ../vector/v.in.sites/main.c:61
-#, fuzzy
-msgid "Converts a GRASS site_lists file into a vector map."
-msgstr "a a."
-#: ../vector/v.in.sites/main.c:85
-#, fuzzy, c-format
-msgid "Site file <%s> not found"
-msgstr "नहीं"
-#: ../vector/v.in.sites/main.c:88
-#, fuzzy, c-format
-msgid "Unable to open site file <%s@%s>"
-msgstr "के लिए"
-#: ../vector/v.in.sites/main.c:91
-#, fuzzy
-msgid "Unable to guess site_list format"
-msgstr "है n"
-#: ../vector/v.in.sites/main.c:94
-#, fuzzy
-msgid "Failed to allocate site structure"
-msgstr "के लिए"
-#: ../vector/v.in.sites/main.c:96
-#, c-format
-msgid "Input format: dimension: %d strings: %d FP: %d"
-msgstr ""
-#: ../vector/v.in.sites/main.c:100
-msgid "Floating point category values, using sequential integer for category"
-msgstr ""
-#: ../vector/v.in.sites/main.c:103
-msgid "No category values, using sequential integer for category"
-msgstr ""
-#: ../vector/v.in.sites/main.c:185
-#, fuzzy
-msgid "Transferring sites to vector point map..."
-msgstr "n"
-#: ../vector/v.in.sites/main.c:257
-#, fuzzy, c-format
-msgid "%d sites written."
-#: ../vector/v.clean/split.c:84
-#, fuzzy, c-format
-msgid "Line splits: %d"
-msgstr "ऊंचाई f n"
-#: ../vector/v.clean/rmdac.c:60
-#, fuzzy, c-format
-msgid "Duplicate area centroids: %d"
-msgstr "के लिए n"
-#: ../vector/v.clean/prune.c:215
-#, c-format
-msgid "%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
-msgstr ""
-#: ../vector/v.clean/prune.c:219
-#, c-format
-msgid "%d boundaries not pruned because pruning would damage topology"
-msgstr ""
-#: ../vector/v.clean/main.c:51
-#, fuzzy
-msgid "Toolset for cleaning topology of vector map."
-msgstr "नहीं"
-#: ../vector/v.clean/main.c:66
-#, fuzzy
-msgid "Name of output map where errors are written"
-msgstr "का"
-#: ../vector/v.clean/main.c:77
-msgid "Cleaning tool"
-msgstr ""
-#: ../vector/v.clean/main.c:92
-msgid "break lines at each intersection"
-msgstr ""
-#: ../vector/v.clean/main.c:93
-msgid "remove duplicate geometry features (pay attention to categories!)"
-msgstr ""
-#: ../vector/v.clean/main.c:94
-msgid "remove dangles, threshold ignored if < 0"
-msgstr ""
-#: ../vector/v.clean/main.c:95
-msgid "change the type of boundary dangle to line, threshold ignored if < 0, input line type is ignored"
-msgstr ""
-#: ../vector/v.clean/main.c:97
-msgid "remove bridges connecting area and island or 2 islands"
-msgstr ""
-#: ../vector/v.clean/main.c:98
-msgid "change the type of bridges connecting area and island or 2 islands from boundary to line"
-msgstr ""
-#: ../vector/v.clean/main.c:100
-msgid "snap lines to vertex in threshold"
-msgstr ""
-#: ../vector/v.clean/main.c:101
-#, fuzzy
-msgid "remove duplicate area centroids ('type' option ignored)"
-msgstr "के लिए n"
-#: ../vector/v.clean/main.c:102
-msgid "break (topologically clean) polygons (imported from non topological format, like ShapeFile). Boundaries are broken on each point shared between 2 and more polygons where angles of segments are different;prune;remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachement of centroid), first and last segment of the boundary is never changed"
-msgstr ""
-#: ../vector/v.clean/main.c:109
-msgid "remove small areas, the longest boundary with adjacent area is removed"
-msgstr ""
-#: ../vector/v.clean/main.c:110
-#, fuzzy
-msgid "remove all lines or boundaries of zero length, threshold is ignored"
-msgstr "हटाएँ सभी फ्रेम्स"
-#: ../vector/v.clean/main.c:111
-#, fuzzy
-msgid "remove small angles between lines at nodes"
-#: ../vector/v.clean/main.c:119
-#, fuzzy
-msgid "Threshold in map units, one value for each tool"
-msgstr "एक के लिए"
-#: ../vector/v.clean/main.c:120
-msgid "Default: 0.0[,0.0,...])"
-msgstr ""
-#: ../vector/v.clean/main.c:125
-#, fuzzy
-msgid "Don't build topology for the output vector"
-msgstr "नहीं"
-#: ../vector/v.clean/main.c:130
-msgid "Combine tools with recommended follow-up tools."
-msgstr ""
-#: ../vector/v.clean/main.c:151
-#, fuzzy
-msgid "You must select at least one tool"
-msgstr "पर एक"
-#: ../vector/v.clean/main.c:186
-msgid "Tool doesn't exist"
-msgstr ""
-#: ../vector/v.clean/main.c:206
-#, fuzzy, c-format
-msgid "Threshold for tool %d may not be > 0, set to 0"
-msgstr "के लिए नहीं सेट"
-#: ../vector/v.clean/main.c:215
-#, fuzzy
-msgid "Tool: Threshold"
-msgstr "अल्फा."
-#: ../vector/v.clean/main.c:220
-#, fuzzy
-msgid "Break"
-msgstr "n"
-#: ../vector/v.clean/main.c:223
-#, fuzzy
-msgid "Remove duplicates"
-msgstr "के लिए n"
-#: ../vector/v.clean/main.c:226
-#, fuzzy
-msgid "Remove dangles"
-msgstr "के लिए n"
-#: ../vector/v.clean/main.c:229
-msgid "Change type of boundary dangles"
-msgstr ""
-#: ../vector/v.clean/main.c:233
-#, fuzzy
-msgid "Remove bridges"
-msgstr "के लिए n"
-#: ../vector/v.clean/main.c:236
-msgid "Change type of boundary bridges"
-msgstr ""
-#: ../vector/v.clean/main.c:240
-#, fuzzy
-msgid "Snap vertices"
-msgstr "छापें"
-#: ../vector/v.clean/main.c:243
-#, fuzzy
-msgid "Remove duplicate area centroids"
-msgstr "के लिए n"
-#: ../vector/v.clean/main.c:247
-#, fuzzy
-msgid "Break polygons"
-msgstr "प्लाट"
-#: ../vector/v.clean/main.c:250
-msgid "Prune"
-msgstr ""
-#: ../vector/v.clean/main.c:253
-#, fuzzy
-msgid "Remove small areas"
-msgstr "के लिए n"
-#: ../vector/v.clean/main.c:256
-#, fuzzy
-msgid "Remove small angles at nodes"
-#: ../vector/v.clean/main.c:261
-msgid "Remove all lines or boundaries of zero length"
-msgstr ""
-#: ../vector/v.clean/main.c:296
-#, fuzzy
-msgid "Copying vector features..."
-msgstr "का"
-#: ../vector/v.clean/main.c:314
-#, fuzzy
-msgid "Failed to copy attribute table to output vector map"
-msgstr "के लिए"
-#: ../vector/v.clean/main.c:329 ../vector/v.clean/main.c:340
-#, fuzzy
-msgid "Rebuilding parts of topology..."
-msgstr "n"
-#: ../vector/v.clean/main.c:349 ../vector/v.clean/main.c:394
-#: ../vector/v.clean/main.c:439
-#, fuzzy
-msgid "Tool: Split boundaries"
-msgstr "n"
-#: ../vector/v.clean/main.c:352 ../vector/v.clean/main.c:398
-#: ../vector/v.clean/main.c:445
-msgid "Tool: Break lines at intersections"
-msgstr ""
-#: ../vector/v.clean/main.c:355 ../vector/v.clean/main.c:364
-#: ../vector/v.clean/main.c:400 ../vector/v.clean/main.c:416
-#: ../vector/v.clean/main.c:447
-msgid "Tool: Remove duplicates"
-msgstr ""
-#: ../vector/v.clean/main.c:358 ../vector/v.clean/main.c:407
-#: ../vector/v.clean/main.c:452
-#, fuzzy
-msgid "Tool: Merge boundaries"
-msgstr "n"
-#: ../vector/v.clean/main.c:368
-msgid "Tool: Remove dangles"
-msgstr ""
-#: ../vector/v.clean/main.c:372
-msgid "Tool: Change type of boundary dangles"
-msgstr ""
-#: ../vector/v.clean/main.c:376
-msgid "Tool: Remove bridges"
-msgstr ""
-#: ../vector/v.clean/main.c:380
-msgid "Tool: Change type of boundary bridges"
-msgstr ""
-#: ../vector/v.clean/main.c:384
-#, fuzzy
-msgid "Tool: Remove duplicate area centroids"
-msgstr "के लिए n"
-#: ../vector/v.clean/main.c:388
-msgid "Tool: Snap line to vertex in threshold"
-msgstr ""
-#: ../vector/v.clean/main.c:402 ../vector/v.clean/main.c:430
-#: ../vector/v.clean/main.c:449
-msgid "Tool: Remove small angles at nodes"
-msgstr ""
-#: ../vector/v.clean/main.c:413
-msgid "Tool: Break polygons"
-msgstr ""
-#: ../vector/v.clean/main.c:421
-msgid "Tool: Prune lines/boundaries"
-msgstr ""
-#: ../vector/v.clean/main.c:425
-msgid "Tool: Remove small areas"
-msgstr ""
-#: ../vector/v.clean/main.c:458
-msgid "Tool: Remove all lines and boundaries of zero length"
-msgstr ""
-#: ../vector/v.clean/main.c:467
-#, fuzzy
-msgid "Rebuilding topology for output vector map..."
-msgstr "n"
-#: ../vector/v.clean/main.c:478
-#, fuzzy
-msgid "Building topology for error vector map..."
-msgstr "n"
-#: ../vector/v.clean/rmline.c:64
-#, fuzzy, c-format
-msgid "Lines / boundaries removed: %d"
-msgstr "नाम बदला गया"
-#: ../vector/v.external.out/args.c:13
-#, fuzzy
-msgid "Name for output OGR datasource"
-msgstr "के लिए"
-#: ../vector/v.external.out/args.c:39
-msgid "Cease using OGR, revert to native output and exit"
-msgstr ""
-#: ../vector/v.external.out/args.c:41
-msgid "Native"
-msgstr ""
-#: ../vector/v.external.out/args.c:51
-#, fuzzy
-msgid "Print current status in shell script style"
-msgstr "छापें"
-#: ../vector/v.external.out/list.c:73
-#, fuzzy
-msgid "Supported Formats:"
-#: ../vector/v.external.out/main.c:39
-msgid "Defines vector output format utilizing OGR library."
-msgstr ""
-#: ../vector/v.external.out/status.c:16
-#, fuzzy, c-format
-msgid "format: native\n"
-msgstr "त्रुटि n"
-#: ../vector/v.external.out/status.c:22
-#, fuzzy
-msgid "Unable to open OGR file"
-msgstr "i n"
-#: ../vector/v.external.out/status.c:31
-#, fuzzy, c-format
-msgid "dsn: %s\n"
-msgstr "n"
-#: ../vector/v.external.out/status.c:32
-#, fuzzy
-msgid "not set (default 'ogr')"
-msgstr "है सभी"
-#: ../vector/v.external.out/status.c:39
-#, fuzzy, c-format
-msgid "format: %s\n"
-msgstr "त्रुटि n"
-#: ../vector/v.external.out/status.c:40
-#, fuzzy
-msgid "not set (default ESRI_Shapefile)"
-msgstr "है सभी"
-#: ../vector/v.external.out/status.c:46
-#, fuzzy, c-format
-msgid "options: %s\n"
-msgstr "n"
-#, fuzzy
-msgid "<none>"
-msgstr "n"
-#: ../vector/v.external.out/link.c:44
-#, fuzzy
-msgid "Unable to create OGR file"
-msgstr "i n"
-#: ../vector/v.external.out/link.c:47
-#, fuzzy
-msgid "Error writing OGR file"
-msgstr "त्रुटि n"
-#: ../vector/v.perturb/normalrs.c:31
-msgid "normalsv: restoration of unitialized block"
-msgstr ""
-#: ../vector/v.perturb/main.c:66
-#, fuzzy
-msgid "Random location perturbations of vector points."
-msgstr "a."
-#: ../vector/v.perturb/main.c:80
-#, fuzzy
-msgid "Distribution of perturbation"
-msgstr "वितरण"
-#: ../vector/v.perturb/main.c:87
-#, fuzzy
-msgid "Parameter(s) of distribution"
-msgstr "वितरण"
-#: ../vector/v.perturb/main.c:88
-msgid "If the distribution is uniform, only one parameter, the maximum, is needed. For a normal distribution, two parameters, the mean and standard deviation, are required."
-msgstr ""
-#: ../vector/v.perturb/main.c:98
-#, fuzzy
-msgid "Minimum deviation in map units"
-msgstr "त्रुटि"
-#: ../vector/v.perturb/main.c:105
-msgid "Seed for random number generation"
-msgstr ""
-#: ../vector/v.perturb/main.c:129 ../vector/v.perturb/main.c:136
-msgid "Error scanning arguments"
-msgstr ""
-#: ../vector/v.perturb/main.c:132
-msgid "Maximum of uniform distribution must be >= zero"
-msgstr ""
-#: ../vector/v.perturb/main.c:139
-msgid "Standard deviation of normal distribution must be >= zero"
-msgstr ""
-#: ../vector/v.perturb/main.c:241
-#, fuzzy
-msgid "Cannot get db link info"
-msgstr "फील्ड"
-#: ../vector/v.perturb/normalsv.c:29
-msgid "normalsv: save of unitialized block"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:131
-#, fuzzy
-msgid "Count points in areas, calculate statistics from point attributes."
-msgstr "का a."
-#: ../vector/v.vect.stats/main.c:135
-#, fuzzy
-msgid "Name of existing vector map with points"
-msgstr "का"
-#: ../vector/v.vect.stats/main.c:140
-#, fuzzy
-msgid "Name of existing vector map with areas"
-msgstr "का"
-#: ../vector/v.vect.stats/main.c:152
-#, fuzzy
-msgid "Layer number for points map"
-msgstr "नहीं"
-#: ../vector/v.vect.stats/main.c:156
-#, fuzzy
-msgid "Layer number for area map"
-msgstr "नहीं"
-#: ../vector/v.vect.stats/main.c:172
-#, fuzzy
-msgid "Method for aggregate statistics"
-msgstr "का वस्तु"
-#: ../vector/v.vect.stats/main.c:179
-#, fuzzy
-msgid "Column name of points map to use for statistics"
-msgstr "का रखे हुए"
-#: ../vector/v.vect.stats/main.c:180
-#, fuzzy
-msgid "Column of points map must be numeric"
-msgstr "ज़ेड"
-#: ../vector/v.vect.stats/main.c:187
-#, fuzzy
-msgid "Column name to upload points count"
-msgstr "ज़ेड"
-#: ../vector/v.vect.stats/main.c:189
-msgid "Column to hold points count, must be of type integer, will be created if not existing"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:196
-#, fuzzy
-msgid "Column name to upload statistics"
-msgstr "ज़ेड"
-#: ../vector/v.vect.stats/main.c:198
-msgid "Column to hold statistics, must be of type double, will be created if not existing"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:208
-#, fuzzy
-msgid "Print output to stdout, do not update attribute table"
-msgstr "नहीं"
-#: ../vector/v.vect.stats/main.c:209
-msgid "First column is always area category"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:263
-#, fuzzy, c-format
-msgid "Vector map <%s> is not in user mapset and cannot be updated"
-msgstr "नहीं"
-#: ../vector/v.vect.stats/main.c:310 ../vector/v.vect.stats/main.c:386
-#, fuzzy, c-format
-msgid "Unable to open database <%s> with driver <%s>"
-msgstr "स्रोत"
-#: ../vector/v.vect.stats/main.c:314
-#, fuzzy
-msgid "ccolumn is required to upload point counts"
-msgstr "है के लिए बिन्दु!"
-#: ../vector/v.vect.stats/main.c:323
-#, fuzzy
-msgid "ccolumn must be of type integer"
-msgstr "ज़ेड"
-#: ../vector/v.vect.stats/main.c:336 ../vector/v.vect.stats/main.c:366
-#, fuzzy, c-format
-msgid "Unable to add column <%s>"
-msgstr "का"
-#: ../vector/v.vect.stats/main.c:342
-#, fuzzy
-msgid "scolumn is required to upload point stats"
-#: ../vector/v.vect.stats/main.c:353
-#, fuzzy
-msgid "scolumn must be of type double"
-msgstr "ज़ेड"
-#: ../vector/v.vect.stats/main.c:377
-#, fuzzy
-msgid "collecting attributes from points vector..."
-msgstr "n"
-#: ../vector/v.vect.stats/main.c:409
-#, fuzzy
-msgid "column for points vector must be numeric"
-msgstr "ज़ेड"
-#: ../vector/v.vect.stats/main.c:482
-#, fuzzy
-msgid "Selecting points for each area..."
-msgstr "n"
-#: ../vector/v.vect.stats/main.c:579
-#, fuzzy, c-format
-msgid "could not find area category %d"
-#: ../vector/v.vect.stats/main.c:707
-#, c-format
-msgid "%d records updated"
-msgstr ""
-#: ../vector/v.class/main.c:48
-msgid "Classifies attribute data, e.g. for thematic mapping"
-msgstr ""
-#: ../vector/v.class/main.c:56
-#, fuzzy
-msgid "Column name or expression"
-msgstr "ज़ेड"
-#: ../vector/v.class/main.c:83
-msgid "Print only class breaks (without min and max)"
-msgstr ""
-#: ../vector/v.class/main.c:127
-#, fuzzy
-msgid "Unable to sort array of values"
-msgstr "सभी"
-#: ../vector/v.class/main.c:161
-msgid "The discontinuities algorithm indicates that some class breaks are not statistically significant at alpha=0.05. You are advised to reduce the number of classes."
-msgstr ""
-#: ../vector/v.class/main.c:190
-#, c-format
-msgid ""
-"\n"
-"Classification of %s into %i classes\n"
-msgstr ""
-#: ../vector/v.class/main.c:197
-#, c-format
-msgid "Lowest chi2 = %f\n"
-msgstr ""
-#: ../vector/v.class/main.c:203
-#, c-format
-msgid ""
-"%15s%15s%15s\n"
-"\n"
-msgstr ""
-#: ../vector/v.class/main.c:215
-#, c-format
-msgid ""
-"\n"
-"Note: Minimum of first class is including\n"
-"\n"
-msgstr ""
-#: ../vector/v.net.allpairs/main.c:60
-msgid "Computes the shortest path between all pairs of nodes in the network."
-msgstr ""
-#: ../vector/v.net.allpairs/main.c:110
-msgid "Add points on nodes without points"
-msgstr ""
-#: ../vector/v.info/main.c:40
-#, fuzzy
-msgid "extent"
-msgstr "पाठ रंग"
-#: ../vector/v.info/main.c:42
-#, fuzzy
-msgid "attribute columns"
-msgstr "नहीं"
-#: ../vector/v.info/main.c:45
-#, fuzzy
-msgid "Outputs basic information about a vector map."
-msgstr "a."
-#: ../vector/v.info/parse.c:24
-#, fuzzy
-msgid "Print history instead of info and exit"
-msgstr "छापें का"
-#: ../vector/v.info/parse.c:30
-#, fuzzy
-msgid "Print types/names of table columns for specified layer instead of info and exit"
-msgstr "छापें का के लिए का"
-#: ../vector/v.info/parse.c:35
-#, fuzzy
-msgid "Print region info in shell script style"
-msgstr "छापें"
-#: ../vector/v.info/parse.c:40
-#, fuzzy
-msgid "Print extended metadata info in shell script style"
-msgstr "छापें"
-#: ../vector/v.info/parse.c:45
-#, fuzzy
-msgid "Print topology info in shell script style"
-msgstr "छापें"
-#: ../vector/v.info/print.c:130
-#, fuzzy, c-format
-msgid "Database connection for map <%s> is not defined in DB file"
-msgstr "नहीं"
-#: ../vector/v.info/print.c:134
-#, c-format
-msgid "Displaying column types/names for database connection of layer <%s>:"
-msgstr ""
-#: ../vector/v.info/print.c:255
-#, fuzzy
-msgid "OGR layer:"
-msgstr "फ़ाइलनाम "
-#: ../vector/v.info/print.c:258
-#, fuzzy
-msgid "OGR datasource:"
-#: ../vector/v.info/print.c:263
-msgid "Name:"
-msgstr ""
-#: ../vector/v.info/print.c:266
-#, fuzzy
-msgid "Mapset:"
-msgstr "n"
-#: ../vector/v.info/print.c:271
-#, fuzzy
-msgid "Location:"
-msgstr "n"
-#: ../vector/v.info/print.c:274
-#, fuzzy
-msgid "Database:"
-msgstr "डाटाबेस का नामः"
-#: ../vector/v.info/print.c:277
-msgid "Title:"
-msgstr ""
-#: ../vector/v.info/print.c:280
-msgid "Map scale:"
-msgstr ""
-#: ../vector/v.info/print.c:286 ../vector/v.info/print.c:290
-#, fuzzy
-msgid "Map format:"
-msgstr "n"
-#: ../vector/v.info/print.c:295
-#, fuzzy
-msgid "Name of creator:"
-msgstr "का के लिए"
-#: ../vector/v.info/print.c:298
-msgid "Organization:"
-msgstr ""
-#: ../vector/v.info/print.c:301
-msgid "Source date:"
-msgstr ""
-#: ../vector/v.info/print.c:309
-msgid "Timestamp (first layer): "
-msgstr ""
-#: ../vector/v.info/print.c:319
-#, fuzzy
-msgid "Type of map"
-msgstr "का"
-msgid "level"
-msgstr ""
-#: ../vector/v.info/print.c:327
-#, fuzzy
-msgid "Number of points:"
-msgstr "का"
-#: ../vector/v.info/print.c:329
-#, fuzzy
-msgid "Number of centroids:"
-msgstr "का"
-#: ../vector/v.info/print.c:334
-#, fuzzy
-msgid "Number of lines:"
-msgstr "का"
-#: ../vector/v.info/print.c:336
-#, fuzzy
-msgid "Number of boundaries:"
-msgstr "का फ्रेम्स"
-#: ../vector/v.info/print.c:341
-#, fuzzy
-msgid "Number of areas:"
-#: ../vector/v.info/print.c:343
-#, fuzzy
-msgid "Number of islands:"
-msgstr "का"
-#: ../vector/v.info/print.c:349
-#, fuzzy
-msgid "Number of faces:"
-#: ../vector/v.info/print.c:351
-#, fuzzy
-msgid "Number of kernels:"
-msgstr "का"
-#: ../vector/v.info/print.c:356
-#, fuzzy
-msgid "Number of volumes:"
-msgstr "का"
-#: ../vector/v.info/print.c:358
-#, fuzzy
-msgid "Number of holes:"
-msgstr "का"
-#: ../vector/v.info/print.c:365
-msgid "Map is 3D:"
-msgstr ""
-#: ../vector/v.info/print.c:366
-msgid "Yes"
-msgstr ""
-msgid "No"
-msgstr ""
-#: ../vector/v.info/print.c:369
-#, fuzzy
-msgid "Number of dblinks:"
-msgstr "का"
-#: ../vector/v.info/print.c:380
-#, fuzzy
-msgid "invalid"
-msgstr "के लिए"
-#: ../vector/v.info/print.c:382
-#, fuzzy
-msgid "unspecified"
-msgstr "नहीं."
-#: ../vector/v.info/print.c:387 ../vector/v.info/print.c:392
-#, fuzzy
-msgid "Projection"
-msgstr "नक़ल"
-#: ../vector/v.info/print.c:388
-msgid "zone"
-msgstr ""
-#: ../vector/v.info/print.c:421
-msgid "Digitization threshold"
-msgstr ""
-#: ../vector/v.info/print.c:423
-msgid "Comment"
-msgstr ""
-#: ../vector/v.net.components/main.c:72
-#, fuzzy
-msgid "components"
-#: ../vector/v.net.components/main.c:74
-msgid "Computes strongly and weakly connected components in the network."
-msgstr ""
-#: ../vector/v.net.components/main.c:119
-msgid "weak;Weakly connected components;strong;Strongly connected components;"
-msgstr ""
-#: ../vector/v.net.components/main.c:121
-#, fuzzy
-msgid "Type of components"
-msgstr "का"
-#: ../vector/v.lidar.correction/main.c:71
-msgid "Correction of the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
-msgstr ""
-#: ../vector/v.lidar.correction/main.c:81
-msgid "Input observation vector map name (v.lidar.growing output)"
-msgstr ""
-#: ../vector/v.lidar.correction/main.c:84
-#, fuzzy
-msgid "Output classified vector map name"
-msgstr "फ़ाइलनाम "
-#: ../vector/v.lidar.correction/main.c:93
-#, fuzzy
-msgid "Only 'terrain' points output vector map"
-msgstr "का"
-#: ../vector/v.lidar.correction/main.c:116
-msgid "Regularization weight in reclassification evaluation"
-msgstr ""
-#: ../vector/v.lidar.correction/main.c:124
-#, fuzzy
-msgid "High threshold for object to terrain reclassification"
-msgstr "के लिए"
-#: ../vector/v.lidar.correction/main.c:132
-msgid "Low threshold for terrain to object reclassification"
-msgstr ""
-#: ../vector/v.lidar.correction/main.c:321
-#, c-format
-msgid "nsply = %d"
-msgstr ""
-#: ../vector/v.lidar.correction/main.c:354
-#, c-format
-msgid "nsplx = %d"
-msgstr ""
-#: ../vector/v.lidar.correction/main.c:357
-#, fuzzy
-msgid "read vector region map"
-msgstr "का"
-#: ../vector/v.lidar.correction/main.c:362
-#, c-format
-msgid "npoints = %d, nterrain = %d"
-msgstr ""
-#: ../vector/v.lidar.correction/main.c:368
-#, fuzzy
-msgid "Mean calculation"
-msgstr "है a"
-#: ../vector/v.lidar.correction/main.c:382
-msgid "Only TERRAIN points"
-msgstr ""
-#: ../vector/v.lidar.correction/main.c:412
-msgid "Correction and creation of terrain vector"
-msgstr ""
-#: ../vector/v.to.3d/args.c:11
-#, fuzzy
-msgid "Reverse transformation; 3D vector features to 2D"
-msgstr "ऊंचाई के लिए"
-#: ../vector/v.to.3d/args.c:15
-#, fuzzy
-msgid "Do not copy table"
-msgstr "नक़ल"
-#: ../vector/v.to.3d/args.c:30
-#, fuzzy
-msgid "Name of attribute column used for height"
-msgstr "क्वैरी उपयोग में."
-#: ../vector/v.to.3d/args.c:32
-msgid "Can be used for reverse transformation, to store height of points"
-msgstr ""
-#: ../vector/v.to.3d/args.c:33 ../vector/v.to.3d/args.c:41
-#, fuzzy
-msgid "Height"
-msgstr "n"
-#: ../vector/v.to.3d/args.c:40
-#, fuzzy
-msgid "Fixed height for 3D vector features"
-#: ../vector/v.to.3d/trans3.c:69 ../vector/v.to.3d/trans2.c:67
-#, fuzzy
-msgid "Column must be numeric"
-msgstr "ज़ेड"
-#: ../vector/v.to.3d/trans3.c:103
-#, fuzzy, c-format
-msgid "Feature id %d has no category - skipping"
-msgstr "बिन्दु n"
-#: ../vector/v.to.3d/trans3.c:106
-#, fuzzy, c-format
-msgid "Feature id %d has more categories. Using category %d."
-msgstr "बिन्दु n"
-#: ../vector/v.to.3d/trans2.c:103
-#, fuzzy
-msgid "Skipping feature without category"
-msgstr "बिन्दु n"
-#: ../vector/v.to.3d/trans2.c:118
-#, fuzzy, c-format
-msgid "Unable to get height for feature category %d"
-msgstr "के लिए"
-#: ../vector/v.to.3d/main.c:39 ../vector/v.extrude/main.c:71
-#: ../vector/v.drape/main.c:143
-msgid "3D"
-msgstr ""
-#: ../vector/v.to.3d/main.c:41
-msgid "Performs transformation of 2D vector features to 3D."
-msgstr ""
-#: ../vector/v.to.3d/main.c:53
-#, fuzzy, c-format
-msgid "Either '%s' or '%s' parameter have to be used"
-msgstr "एक का सेट"
-#: ../vector/v.to.3d/main.c:59
-#, fuzzy, c-format
-msgid "Parameters '%s' ignored"
-msgstr "का."
-#: ../vector/v.to.3d/main.c:64
-#, fuzzy
-msgid "Attribute table required"
-msgstr "नहीं"
-#: ../vector/v.to.3d/main.c:77
-#, fuzzy, c-format
-msgid "Vector map <%s> is 2D"
-msgstr "नहीं"
-#: ../vector/v.to.3d/main.c:82
-#, fuzzy, c-format
-msgid "Vector map <%s> is 3D"
-msgstr "नहीं"
-#: ../vector/v.to.3d/main.c:100 ../vector/v.to.3d/main.c:130
-#, fuzzy
-msgid "Unable to copy attributes"
-msgstr "सभी"
-#: ../vector/v.to.3d/main.c:104
-#, fuzzy
-msgid "Transforming features..."
-msgstr "n"
-#: ../vector/v.to.3d/main.c:124
-#, fuzzy, c-format
-msgid "%s failed"
-msgstr "नक़ल"
-#: ../vector/v.to.3d/main.c:139
-#, c-format
-msgid "Vertical extent of vector map <%s>: B: %f T: %f"
-msgstr ""
-#: ../vector/v.db.select/main.c:55
-#, fuzzy
-msgid "Prints vector map attributes."
-msgstr "छापें"
-#: ../vector/v.db.select/main.c:70 ../db/db.select/main.c:223
-msgid "Output vertical record separator"
-msgstr ""
-#: ../vector/v.db.select/main.c:78 ../db/db.select/main.c:231
-#, fuzzy
-msgid "Null value indicator"
-msgstr "शून्य (Null)"
-#: ../vector/v.db.select/main.c:90
-msgid "Print minimal region extent of selected vector features instead of attributes"
-msgstr ""
-#: ../vector/v.db.select/main.c:94 ../db/db.select/main.c:241
-#, fuzzy
-msgid "Do not include column names in output"
-msgstr "नहीं"
-#: ../vector/v.db.select/main.c:99 ../db/db.select/main.c:251
-#, fuzzy
-msgid "Vertical output (instead of horizontal)"
-msgstr "खड़ा का"
-#: ../vector/v.db.select/main.c:135
-#, fuzzy, c-format
-msgid "Unable to open vector map <%s> at topology level. Flag '%c' requires topology level."
-msgstr "के लिए."
-#: ../vector/v.db.select/main.c:169
-#, fuzzy
-msgid "Unable to open select cursor"
-msgstr "का"
-#: ../vector/v.db.select/main.c:237
-#, fuzzy, c-format
-msgid "Unable to get bounding box of area %d"
-msgstr "नहीं"
-#: ../vector/v.db.select/main.c:243
-#, fuzzy, c-format
-msgid "Unable to get bounding box of line %d"
-msgstr "नहीं"
-#: ../vector/v.in.dxf/read_dxf.c:57
-msgid "end of file while looking for HEADER"
-msgstr ""
-#: ../vector/v.in.dxf/add_polyline.c:47
-msgid "vertices following flag missing"
-msgstr ""
-#: ../vector/v.in.dxf/layer_list.c:16
-#, fuzzy, c-format
-msgid "Layer %d: %s\n"
-msgstr "n"
-#: ../vector/v.in.dxf/main.c:66
-msgid "dxf"
-msgstr ""
-#: ../vector/v.in.dxf/main.c:68
-#, fuzzy
-msgid "Converts file in DXF format to GRASS vector map."
-msgstr "एक का."
-#: ../vector/v.in.dxf/main.c:72
-msgid "Ignore the map extent of DXF file"
-msgstr ""
-#: ../vector/v.in.dxf/main.c:76
-#, fuzzy
-msgid "Do not create attribute tables"
-msgstr "नहीं"
-#: ../vector/v.in.dxf/main.c:84
-msgid "Import polyface meshes as 3D wire frame"
-msgstr ""
-#: ../vector/v.in.dxf/main.c:88
-#, fuzzy
-msgid "List available DXF layers and exit"
-msgstr "स्रोत"
-#: ../vector/v.in.dxf/main.c:89 ../vector/v.in.dxf/main.c:96
-#: ../vector/v.in.dxf/main.c:101 ../vector/v.in.dxf/main.c:114
-#, fuzzy
-msgid "DXF layers"
-msgstr "सेट"
-#: ../vector/v.in.dxf/main.c:95
-msgid "Invert selection by DXF layers (don't import layers in list)"
-msgstr ""
-#: ../vector/v.in.dxf/main.c:100
-msgid "Import all objects into one layer"
-msgstr ""
-#: ../vector/v.in.dxf/main.c:104
-#, fuzzy
-msgid "Path to input DXF file"
-msgstr "का"
-#: ../vector/v.in.dxf/main.c:113
-#, fuzzy
-msgid "List of DXF layers to import (default: all)"
-msgstr "का"
-#: ../vector/v.in.dxf/main.c:128
-#, fuzzy
-msgid "Please specify list of DXF layers to exclude"
-msgstr "ज़ेड."
-#: ../vector/v.in.dxf/main.c:132
-#, fuzzy, c-format
-msgid "Unable to open DXF file <%s>"
-msgstr "का"
-#: ../vector/v.in.dxf/main.c:135
-msgid "Layer number: layer name / GRASS compliant name"
-msgstr ""
-#: ../vector/v.in.dxf/main.c:169
-msgid "Building topology failed"
-msgstr ""
-#: ../vector/v.in.dxf/main.c:175
-msgid "Failed to import DXF file!"
-msgstr ""
-#: ../vector/v.in.dxf/write_vect.c:52
-msgid "Entity handle truncated to 16 characters."
-msgstr ""
-#: ../vector/v.in.dxf/write_vect.c:91
-msgid "No DXF layers found!"
-msgstr ""
-#: ../vector/v.in.dxf/write_vect.c:100
-msgid "Following DXF layers found:"
-msgstr ""
-#: ../vector/v.in.dxf/write_vect.c:104
-#, fuzzy, c-format
-msgid "Layer %d: %s"
-msgstr "n"
-#: ../vector/v.in.dxf/write_vect.c:245
-#, fuzzy, c-format
-msgid "Unable to add database link for vector map <%s>"
-msgstr "के लिए"
-#: ../vector/v.split/main.c:54
-msgid "Splits vector lines to shorter segments."
-msgstr ""
-#: ../vector/v.split/main.c:67
-#, fuzzy
-msgid "Maximum segment length"
-msgstr "संख्या का n"
-#: ../vector/v.split/main.c:76
-#, fuzzy
-msgid "Length units"
-msgstr "f n"
-#: ../vector/v.split/main.c:83
-#, fuzzy
-msgid "Maximum number of vertices in segment"
-msgstr "संख्या का a खण्ड"
-#: ../vector/v.split/main.c:90
-#, fuzzy
-msgid "Use either length or vertices"
-msgstr "छापें"
-#: ../vector/v.split/main.c:97
-#, c-format
-msgid "Length must be positive but is %g"
-msgstr ""
-#: ../vector/v.split/main.c:111
-#, fuzzy, c-format
-msgid "Unknown unit %s"
-#: ../vector/v.split/main.c:123
-#, fuzzy
-msgid "Can not get projection units"
-msgstr "का"
-#: ../vector/v.split/main.c:129
-#, fuzzy, c-format
-msgid "length in %s: %g"
-msgstr "f n"
-#: ../vector/v.split/main.c:135
-#, fuzzy
-msgid "Number of vertices must be at least 2"
-msgstr "का!"
-#: ../vector/v.split/main.c:200
-#, fuzzy, c-format
-msgid "Unable to make line segment: %f - %f (line length = %f)"
-msgstr "बनाया जा रहा है."
-#: ../vector/v.what.rast/main.c:74
-#, fuzzy
-msgid "Uploads raster values at positions of vector points to the table."
-msgstr "पर का"
-#: ../vector/v.what.rast/main.c:78
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:5
-#, fuzzy
-msgid "Name of vector points map for which to edit attributes"
-msgstr "का के लिए संपादन (_E)"
-#: ../vector/v.what.rast/main.c:84
-#, fuzzy
-msgid "Name of existing raster map to be queried"
-msgstr "का"
-#: ../vector/v.what.rast/main.c:89
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:6
-#, fuzzy
-msgid "Name of attribute column to be updated with the query result"
-msgstr "का के लिए"
-#: ../vector/v.what.rast/main.c:136 ../vector/v.to.rast/support.c:314
-#: ../vector/v.to.rast/vect2rast.c:61
-#, fuzzy, c-format
-msgid "Column <%s> not found"
-msgstr "नहीं"
-#: ../vector/v.what.rast/main.c:142
-#, fuzzy
-msgid "Raster type is integer and column type is float"
-msgstr "है है"
-#: ../vector/v.what.rast/main.c:145
-#, fuzzy
-msgid "Raster type is float and column type is integer, some data lost!!"
-msgstr "है है!"
-#: ../vector/v.what.rast/main.c:159
-#, fuzzy
-msgid "Reading features from vector map..."
-msgstr "n"
-#: ../vector/v.what.rast/main.c:229
-#, fuzzy, c-format
-msgid "%d points outside current region were skipped"
-msgstr "नहीं"
-#: ../vector/v.what.rast/main.c:233
-#, fuzzy, c-format
-msgid "%d points without category were skipped"
-msgstr "बिन्दु n"
-#: ../vector/v.what.rast/main.c:282
-#, fuzzy, c-format
-msgid "More points (%d) of category %d, value set to 'NULL'"
-msgstr "का सेट"
-#: ../vector/v.what.rast/main.c:351
-#, fuzzy, c-format
-msgid "%d categories loaded from table"
-msgstr "लोड हो गया"
-#: ../vector/v.what.rast/main.c:352
-#, fuzzy, c-format
-msgid "%d categories loaded from vector"
-#: ../vector/v.what.rast/main.c:353
-#, c-format
-msgid "%d categories from vector missing in table"
-msgstr ""
-#: ../vector/v.what.rast/main.c:355
-#, fuzzy, c-format
-msgid "%d duplicate categories in vector"
-msgstr "अनुकृति"
-#: ../vector/v.net.salesman/main.c:106
-msgid "salesman"
-msgstr ""
-#: ../vector/v.net.salesman/main.c:108
-msgid "Creates a cycle connecting given nodes (Traveling salesman problem)."
-msgstr ""
-#: ../vector/v.net.salesman/main.c:110
-msgid "Note that TSP is NP-hard, heuristic algorithm is used by this module and created cycle may be sub optimal"
-msgstr ""
-#: ../vector/v.net.salesman/main.c:128
-#, fuzzy
-msgid "Node layer (used for cities)"
-msgstr "का के लिए"
-#: ../vector/v.net.salesman/main.c:141
-msgid "EXPERIMENTAL: Arc backward direction cost column (number)"
-msgstr ""
-#: ../vector/v.net.salesman/main.c:146
-msgid "Categories of points ('cities') on nodes (layer is specified by nlayer)"
-msgstr ""
-#: ../vector/v.net.salesman/main.c:220
-#, fuzzy, c-format
-msgid "Number of cities: [%d]"
-msgstr "का."
-#: ../vector/v.net.salesman/main.c:222
-#, fuzzy
-msgid "Not enough cities (< 2)"
-msgstr "ज़ेड"
-#: ../vector/v.net.salesman/main.c:268
-#, fuzzy, c-format
-msgid "Destination node [%d] is unreachable from node [%d]"
-msgstr "n"
-#: ../vector/v.net.salesman/main.c:431
-msgid "Cycle:"
-msgstr ""
-#: ../vector/v.net.salesman/main.c:432
-#, c-format
-msgid "Arcs' categories (layer %d, %d arcs):"
-msgstr ""
-#: ../vector/v.net.salesman/main.c:448
-#, c-format
-msgid "Nodes' categories (layer %d, %d nodes):"
-msgstr ""
-#: ../vector/v.to.points/main.c:175
-#, fuzzy
-msgid "Creates points along input lines in new vector map with 2 layers."
-msgstr "a अन्य."
-#: ../vector/v.to.points/main.c:178
-#, fuzzy
-msgid "Name of vector map containing lines"
-msgstr "का"
-#: ../vector/v.to.points/main.c:192
-#, fuzzy
-msgid "Name for output vector map where points will be written"
-msgstr "i n"
-#: ../vector/v.to.points/main.c:196
-#, fuzzy
-msgid "Write line nodes"
-msgstr "n"
-#: ../vector/v.to.points/main.c:200
-#, fuzzy
-msgid "Write line vertices"
-msgstr "छापें"
-#: ../vector/v.to.points/main.c:204
-#, fuzzy
-msgid "Interpolate points between line vertices"
-msgstr "के लिए a"
-#: ../vector/v.to.points/main.c:211
-#, fuzzy
-msgid "Maximum distance between points in map units"
-msgstr "f"
-#: ../vector/v.to.points/main.c:230
-msgid "Use either -n or -v flag, not both"
-msgstr ""
-#: ../vector/v.to.points/main.c:383
-#, fuzzy, c-format
-msgid "%d points written to output vector map."
-msgstr "n"
-#: ../vector/v.extrude/main.c:73
-#, fuzzy
-msgid "Extrudes flat vector features to 3D with defined height."
-msgstr "वस्तु ऊंचाई"
-#: ../vector/v.extrude/main.c:77
-#, fuzzy
-msgid "Trace elevation"
-msgstr "ट्रेस"
-#: ../vector/v.extrude/main.c:99
-#, fuzzy
-msgid "Elevation raster for height extraction"
-msgstr "के लिए ऊंचाई"
-#: ../vector/v.extrude/main.c:106
-#, fuzzy
-msgid "Fixed height for 3D vector objects"
-#: ../vector/v.extrude/main.c:111
-#, fuzzy
-msgid "Name of attribute column with object heights"
-msgstr "का वस्तु"
-#: ../vector/v.extrude/main.c:119
-#, fuzzy, c-format
-msgid "One of '%s' or '%s' parameters must be set"
-msgstr "एक का सेट"
-#: ../vector/v.extrude/main.c:191
-#, fuzzy
-msgid "Extruding areas..."
-msgstr "n"
-#: ../vector/v.extrude/main.c:216
-#, fuzzy, c-format
-msgid "Cannot select attributes for area %d"
-msgstr "के लिए"
-#: ../vector/v.extrude/main.c:255
-#, fuzzy
-msgid "Extruding features..."
-msgstr "n"
-#: ../vector/v.extrude/main.c:288
-#, fuzzy, c-format
-msgid "Cannot select attributes for area #%d"
-msgstr "के लिए"
-#: ../vector/v.extrude/main.c:306
-#, c-format
-msgid "Column <%s>: invalid data type"
-msgstr ""
-#: ../vector/v.segment/main.c:57
-msgid "Creates points/segments from input vector lines and positions."
-msgstr ""
-#: ../vector/v.segment/main.c:60
-#, fuzzy
-msgid "Name of input vector lines map"
-msgstr "का"
-#: ../vector/v.segment/main.c:68
-#, fuzzy
-msgid "Name of file containing segment rules"
-msgstr "फ़ाइल"
-#: ../vector/v.segment/main.c:132 ../vector/v.segment/main.c:172
-#, fuzzy, c-format
-msgid "Unable to read input: %s"
-msgstr "i n"
-#: ../vector/v.segment/main.c:142 ../vector/v.segment/main.c:181
-#, fuzzy, c-format
-msgid "Unable to find line of cat %d"
-msgstr "नहीं"
-#: ../vector/v.segment/main.c:152
-#, c-format
-msgid ""
-"Unable to get point on line: cat = %d offset = %f (line length = %.15g)\n"
-"%s"
-msgstr ""
-#: ../vector/v.segment/main.c:189
-msgid "End of segment > line length -> cut"
-msgstr ""
-#: ../vector/v.segment/main.c:195
-#, c-format
-msgid ""
-"Unable to make line segment: cat = %d : %f - %f (line length = %.15g)\n"
-"%s"
-msgstr ""
-#: ../vector/v.segment/main.c:224
-#, fuzzy, c-format
-msgid "%d points read from input"
-msgstr "n"
-#: ../vector/v.segment/main.c:225
-#, fuzzy, c-format
-msgid "%d points written to output map (%d lost)"
-msgstr "n"
-#: ../vector/v.segment/main.c:227
-#, fuzzy, c-format
-msgid "%d lines read from input"
-msgstr "n"
-#: ../vector/v.segment/main.c:228
-#, fuzzy, c-format
-msgid "%d lines written to output map (%d lost)"
-msgstr "n"
-#: ../vector/v.what/what.c:247
-#, c-format
-msgid ""
-"Id: %d\n"
-"Type: %s\n"
-"Left: %d\n"
-"Right: %d\n"
-msgstr ""
-#: ../vector/v.what/what.c:270
-#, fuzzy, c-format
-msgid ""
-"Node[%d]=%d\n"
-"Number_lines=%d\n"
-"Coordinates=%.6f,%.6f,%.6f\n"
-msgstr "का n"
-#: ../vector/v.what/what.c:275
-#, fuzzy, c-format
-msgid ""
-"Node[%d]: %d\n"
-"Number of lines: %d\n"
-"Coordinates: %.6f, %.6f, %.6f\n"
-msgstr "का n"
-#: ../vector/v.what/what.c:289
-#, fuzzy, c-format
-msgid ""
-"Id: %5d\n"
-"Angle: %.8f\n"
-msgstr "n"
-#: ../vector/v.what/what.c:304
-#, fuzzy, c-format
-msgid "Type: %s\n"
-msgstr "n"
-#: ../vector/v.what/what.c:305
-#, fuzzy, c-format
-msgid "Id: %d\n"
-msgstr "n"
-#: ../vector/v.what/what.c:349
-#, fuzzy, c-format
-msgid ""
-"Line height min: %f\n"
-"Line height max: %f\n"
-msgstr "ऊंचाई f f n"
-#: ../vector/v.what/what.c:363
-#, fuzzy, c-format
-msgid ""
-"Type: Area\n"
-"Area height: %f\n"
-msgstr "ऊंचाई f n"
-#: ../vector/v.what/what.c:371
-#, fuzzy, c-format
-msgid "Type: Area\n"
-msgstr "n"
-#: ../vector/v.what/what.c:393
-#, fuzzy, c-format
-msgid ""
-"Area: %d\n"
-"Number of isles: %d\n"
-msgstr "का n"
-#: ../vector/v.what/what.c:403
-#, fuzzy, c-format
-msgid "Isle[%d]: %d\n"
-msgstr "n"
-#: ../vector/v.what/what.c:416
-#, fuzzy, c-format
-msgid "Island: %d In area: %d\n"
-msgstr "n"
-#: ../vector/v.what/what.c:429 ../vector/v.what/what.c:436
-#, fuzzy, c-format
-msgid ""
-"Sq Meters: %.3f\n"
-"Hectares: %.3f\n"
-msgstr "n"
-#: ../vector/v.what/what.c:431 ../vector/v.what/what.c:439
-#, fuzzy, c-format
-msgid ""
-"Acres: %.3f\n"
-"Sq Miles: %.4f\n"
-msgstr "n"
-#: ../vector/v.what/what.c:462
-#, fuzzy, c-format
-msgid ""
-"Layer: %d\n"
-"Category: %d\n"
-msgstr "n"
-#: ../vector/v.what/what.c:474
-#, fuzzy, c-format
-msgid ""
-"\n"
-"Driver: %s\n"
-"Database: %s\n"
-"Table: %s\n"
-"Key column: %s\n"
-msgstr "n"
-#: ../vector/v.what/main.c:63
-#, fuzzy
-msgid "Queries a vector map at given locations."
-msgstr "क्वैरी का a पर."
-#: ../vector/v.what/main.c:73
-#, fuzzy
-msgid "\"-\" to read from standard input"
-msgstr "नहीं"
-#: ../vector/v.what/main.c:80
-#, fuzzy
-msgid "Query threshold distance"
-msgstr "सेट इंचेस"
-#: ../vector/v.what/main.c:81
-#, fuzzy
-msgid "Threshold"
-msgstr "अल्फा."
-#: ../vector/v.what/main.c:90
-#, fuzzy
-msgid "Print attribute information"
-msgstr "संख्या के लिए"
-#: ../vector/v.what/main.c:140
-#, fuzzy, c-format
-msgid "Number of given vector maps (%d) differs from number of layers (%d)"
-msgstr "का नहीं जोड़ा संख्या का."
-#: ../vector/v.what/main.c:149
-#, fuzzy, c-format
-msgid "You must build topology on vector map <%s>"
-msgstr "नहीं"
-#: ../vector/v.what/main.c:166
-#, fuzzy, c-format
-msgid "Unknown input format, skipping: '%s'"
-#: ../vector/v.generalize/network.c:164
-#, fuzzy
-msgid "Calculating centrality measures..."
-msgstr "n"
-#: ../vector/v.generalize/smoothing.c:86
-#: ../vector/v.generalize/smoothing.c:146
-msgid "Look ahead parameter must be odd"
-msgstr ""
-#: ../vector/v.generalize/smoothing.c:481
-#, fuzzy
-msgid "Unable to find the inverse matrix"
-msgstr "का"
-#: ../vector/v.generalize/smoothing.c:488
-#, fuzzy
-msgid "Unable to calculate the output vectors"
-msgstr "के लिए"
-#: ../vector/v.generalize/misc.c:158
-#, c-format
-msgid "Layer %d"
-msgstr ""
-#: ../vector/v.generalize/misc.c:207 ../vector/v.generalize/misc.c:220
-#, c-format
-msgid "'%s' must be > 0 for '%s'"
-msgstr ""
-#: ../vector/v.generalize/misc.c:209
-msgid "'where' and 'cats' parameters were supplied, cat will be ignored"
-msgstr ""
-#: ../vector/v.generalize/misc.c:215
-#, fuzzy
-msgid "Unable to load data from database"
-msgstr "सभी"
-#: ../vector/v.generalize/misc.c:226
-#, fuzzy
-msgid "Problem loading category values"
-msgstr "का"
-#: ../vector/v.generalize/displacement.c:197
-#, fuzzy
-msgid "Inverting matrix..."
-msgstr "का"
-#: ../vector/v.generalize/displacement.c:199
-#, fuzzy
-msgid "Unable to calculate the inverse matrix"
-msgstr "का"
-#: ../vector/v.generalize/displacement.c:202
-#, fuzzy
-msgid "Resolving conflicts..."
-msgstr "के लिए n"
-#: ../vector/v.generalize/main.c:77
-#, fuzzy
-msgid "generalization"
-msgstr "n"
-#: ../vector/v.generalize/main.c:78
-#, fuzzy
-msgid "simplification"
-msgstr "के लिए"
-#: ../vector/v.generalize/main.c:79
-msgid "smoothing"
-msgstr ""
-#: ../vector/v.generalize/main.c:80
-#, fuzzy
-msgid "displacement"
-msgstr "गामा."
-#: ../vector/v.generalize/main.c:81
-#, fuzzy
-msgid "network generalization"
-msgstr "का"
-#: ../vector/v.generalize/main.c:82
-#, fuzzy
-msgid "Tool for vector based generalization."
-msgstr "का"
-#: ../vector/v.generalize/main.c:103
-msgid "douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker Algorithm with reduction parameter;lang;Lang Simplification Algorithm;reduction;Vertex Reduction Algorithm eliminates points close to each other;reumann;Reumann-Witkam Algorithm;boyle;Boyle's Forward-Looking Algorithm;sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;Interpolation by Cubic Hermite Splines;snakes;Snakes method for line smoothing;network;Network generalization;displacement;Displacement of lines close to each other;"
-msgstr ""
-#: ../vector/v.generalize/main.c:117
-msgid "Generalization algorithm"
-msgstr ""
-#: ../vector/v.generalize/main.c:124
-msgid "Maximal tolerance value"
-msgstr ""
-#: ../vector/v.generalize/main.c:131
-#, fuzzy
-msgid "Look-ahead parameter"
-msgstr "चिकना"
-#: ../vector/v.generalize/main.c:140
-msgid "Percentage of the points in the output of 'douglas_reduction' algorithm"
-msgstr ""
-#: ../vector/v.generalize/main.c:149
-msgid "Slide of computed point toward the original point"
-msgstr ""
-#: ../vector/v.generalize/main.c:158
-msgid "Minimum angle between two consecutive segments in Hermite method"
-msgstr ""
-#: ../vector/v.generalize/main.c:166
-msgid "Degree threshold in network generalization"
-msgstr ""
-#: ../vector/v.generalize/main.c:175
-msgid "Closeness threshold in network generalization"
-msgstr ""
-#: ../vector/v.generalize/main.c:183
-msgid "Betweeness threshold in network generalization"
-msgstr ""
-#: ../vector/v.generalize/main.c:190
-#, fuzzy
-msgid "Snakes alpha parameter"
-msgstr "चिकना"
-#: ../vector/v.generalize/main.c:197
-#, fuzzy
-msgid "Snakes beta parameter"
-msgstr "चिकना"
-#: ../vector/v.generalize/main.c:204
-#, fuzzy
-msgid "Number of iterations"
-msgstr "का"
-#: ../vector/v.generalize/main.c:211
-#, fuzzy
-msgid "Copy attributes"
-msgstr "नहीं"
-#: ../vector/v.generalize/main.c:264
-#, fuzzy
-msgid "Unknown method"
-#: ../vector/v.generalize/main.c:320
-#, fuzzy
-msgid "Displacement..."
-msgstr "n"
-#: ../vector/v.generalize/main.c:329
-#, fuzzy
-msgid "Network generalization..."
-msgstr "का"
-#: ../vector/v.generalize/main.c:344
-msgid "Attributes are needed for 'where' option, copying table"
-msgstr ""
-#: ../vector/v.generalize/main.c:366
-#, fuzzy, c-format
-msgid "Generalization (%s)..."
-msgstr "n"
-#: ../vector/v.generalize/main.c:460
-#, c-format
-msgid "Method '%s' did not preserve first point"
-msgstr ""
-#: ../vector/v.generalize/main.c:465
-#, c-format
-msgid "Method '%s' did not preserve last point"
-msgstr ""
-#: ../vector/v.generalize/main.c:492
-#, c-format
-msgid "%d boundaries were not modified because modification would damage topology"
-msgstr ""
-#: ../vector/v.generalize/main.c:495
-#, c-format
-msgid "%d lines/boundaries were not modified due to over-simplification"
-msgstr ""
-#: ../vector/v.generalize/main.c:510
-#, c-format
-msgid "Number of vertices for selected lines %s from %d to %d (%d%%)."
-msgstr ""
-#: ../vector/v.generalize/main.c:511
-msgid "reduced"
-msgstr ""
-msgid "changed"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:245
-msgid "Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm."
-msgstr ""
-#: ../vector/v.vol.rst/main.c:253
-#, fuzzy
-msgid "Name of the vector map with input x,y,z,w"
-msgstr "का"
-#: ../vector/v.vol.rst/main.c:261
-msgid "Name of the surface raster map for cross-section"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:268
-#, fuzzy
-msgid "Name of the column containing w attribute to interpolate"
-msgstr "का"
-#: ../vector/v.vol.rst/main.c:292
-#, fuzzy
-msgid "Name of the column with smoothing parameters"
-msgstr "का"
-#: ../vector/v.vol.rst/main.c:302
-#, fuzzy
-msgid "Output deviations vector point file"
-msgstr "का बिन्दु"
-#: ../vector/v.vol.rst/main.c:303 ../vector/v.vol.rst/main.c:311
-msgid "Analysis"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:310
-#, fuzzy
-msgid "Output cross-validation vector map"
-msgstr "का बिन्दु"
-#: ../vector/v.vol.rst/main.c:318
-#, fuzzy
-msgid "Name of the raster map used as mask"
-msgstr "का"
-#: ../vector/v.vol.rst/main.c:343
-#, fuzzy
-msgid "Maximum number of points for approximation in a segment (>npmin)"
-msgstr "संख्या का के लिए a खण्ड"
-#: ../vector/v.vol.rst/main.c:360
-#, fuzzy
-msgid "Conversion factor for w-values used for interpolation"
-msgstr "के लिए के लिए"
-#: ../vector/v.vol.rst/main.c:368
-#, fuzzy
-msgid "Conversion factor for z-values"
-#: ../vector/v.vol.rst/main.c:376
-#, fuzzy
-msgid "Output cross-section raster map"
-msgstr "फ़ाइलनाम "
-#: ../vector/v.vol.rst/main.c:385
-#, fuzzy
-msgid "Output elevation g3d-file"
-msgstr "ढाल"
-#: ../vector/v.vol.rst/main.c:393
-msgid "Output gradient magnitude g3d-file"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:403
-msgid "Output gradient horizontal angle g3d-file"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:412
-#, fuzzy
-msgid "Output gradient vertical angle g3d-file"
-msgstr "सभी"
-#: ../vector/v.vol.rst/main.c:421
-msgid "Output change of gradient g3d-file"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:430
-#, fuzzy
-msgid "Output gaussian curvature g3d-file"
-msgstr "फ़ाइलनाम "
-#: ../vector/v.vol.rst/main.c:439
-#, fuzzy
-msgid "Output mean curvature g3d-file"
-msgstr "फ़ाइलनाम "
-#: ../vector/v.vol.rst/main.c:445
-#, fuzzy
-msgid "Perform a cross-validation procedure without volume interpolation"
-msgstr "विधि"
-#: ../vector/v.vol.rst/main.c:509
-msgid "Smoothing must be a positive value"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:515
-msgid "Both crossvalidation options (-c, cvdev) must be specified"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:517
-msgid "Both crossvalidation and deviations file specified"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:599
-#, fuzzy
-msgid "Vector is not 3D"
-msgstr "नहीं"
-#: ../vector/v.vol.rst/main.c:639
-#, c-format
-msgid "Cannot create table: %s"
-msgstr ""
-#: ../vector/v.vol.rst/user1.c:109
-#, fuzzy
-msgid "Column type of wcolumn is not supported (must be integer or double)"
-msgstr "नहीं"
-#: ../vector/v.vol.rst/user1.c:128
-#, fuzzy
-msgid "Column type of smooth column is not supported (must be integer or double)"
-msgstr "नहीं"
-#: ../vector/v.to.rast3/main.c:51
-#, fuzzy
-msgid "Converts a vector map (only points) into a 3D raster map."
-msgstr "a a."
-#: ../vector/v.to.rast3/main.c:62
-#, fuzzy
-msgid "Name of attribute column (data type must be numeric)"
-msgstr "के लिए"
-#: ../vector/v.to.rast3/main.c:104
-#, fuzzy
-msgid "Unable to create output map"
-msgstr "i n"
-#: ../vector/v.to.rast3/main.c:142 ../vector/v.to.rast/do_lines.c:51
-#: ../vector/v.to.rast/do_lines.c:59
-#, fuzzy, c-format
-msgid "No record for line (cat = %d)"
-#: ../vector/v.to.rast3/main.c:154
-#, fuzzy
-msgid "Unable to close new 3d raster map"
-msgstr "का"
-#: ../vector/v.label.sa/labels.c:67
-#, fuzzy, c-format
-msgid "Cannot allocate %d bytes of memory"
-msgstr "के लिए"
-#: ../vector/v.label.sa/labels.c:85
-#, fuzzy
-msgid "Unable to initialise FreeType"
-msgstr "फ्री-टाइप"
-#: ../vector/v.label.sa/labels.c:88
-#, fuzzy, c-format
-msgid "Unable to find font '%s'\n"
-msgstr "फ़ाइल"
-#: ../vector/v.label.sa/labels.c:90
-#, c-format
-msgid "Font '%s' is not a FreeType font\n"
-msgstr ""
-#: ../vector/v.label.sa/labels.c:94
-msgid "Font file format is not supported by FreeType"
-msgstr ""
-#: ../vector/v.label.sa/labels.c:96
-#, fuzzy
-msgid "Font file can not be loaded"
-msgstr "नहीं"
-#: ../vector/v.label.sa/labels.c:105
-#, fuzzy
-msgid "Unable to set font size"
-msgstr "सेट आकार "
-#: ../vector/v.label.sa/labels.c:126
-#, fuzzy
-msgid "Cannot allocate more memory"
-msgstr "के लिए"
-#: ../vector/v.label.sa/labels.c:242
-#, fuzzy, c-format
-msgid "Cannot load glyph for '%c'"
-msgstr "का"
-#: ../vector/v.label.sa/main.c:41
-msgid "Create optimally placed labels for vector map(s)"
-msgstr ""
-#: ../vector/v.label.sa/main.c:71
-msgid "Name of TrueType font (as listed in the fontcap)"
-msgstr ""
-#: ../vector/v.label.sa/main.c:84
-msgid "Icon size of point features (in map-units)"
-msgstr ""
-#: ../vector/v.label.sa/main.c:154
-#, fuzzy
-msgid "Border width (only for ps.map output)"
-msgstr "किनारा के लिए"
-#: ../vector/v.in.db/main.c:57
-msgid "Creates new vector (points) map from database table containing coordinates."
-msgstr ""
-#: ../vector/v.in.db/main.c:61
-msgid "Input table name"
-msgstr ""
-#: ../vector/v.in.db/main.c:66 ../vector/v.in.db/main.c:70
-#: ../db/db.select/main.c:204 ../db/db.select/main.c:209
-#: ../db/db.select/main.c:215 ../db/db.execute/main.c:126
-#: ../db/db.execute/main.c:131 ../db/db.execute/main.c:136
-#, fuzzy
-msgid "Connection"
-msgstr "का"
-#: ../vector/v.in.db/main.c:75
-#, fuzzy
-msgid "Name of column containing x coordinate"
-msgstr "का"
-#: ../vector/v.in.db/main.c:80
-#, fuzzy
-msgid "Name of column containing y coordinate"
-msgstr "का"
-#: ../vector/v.in.db/main.c:84
-#, fuzzy
-msgid "Name of column containing z coordinate"
-msgstr "का"
-#: ../vector/v.in.db/main.c:89
-#, fuzzy
-msgid "Name of column containing category number"
-msgstr "का"
-#: ../vector/v.in.db/main.c:90
-msgid "Must refer to an integer column"
-msgstr ""
-#: ../vector/v.in.db/main.c:133
-#, c-format
-msgid "Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
-msgstr ""
-#: ../vector/v.in.db/main.c:183
-msgid "Key column must be integer"
-msgstr ""
-#: ../vector/v.in.db/main.c:191
-#, fuzzy
-msgid "x/y/z column must be integer or double"
-msgstr "ज़ेड"
-#: ../vector/v.in.db/main.c:228
-#, fuzzy
-msgid "Unable to copy table"
-msgstr "का"
-#: ../vector/v.in.db/main.c:238
-#, fuzzy, c-format
-msgid "%d points written to vector map."
-msgstr "n"
-#: ../vector/v.surf.idw/main.c:90
-#, fuzzy
-msgid "Surface interpolation from vector point data by Inverse Distance Squared Weighting."
-msgstr "सतह बिन्दु."
-#: ../vector/v.surf.idw/main.c:99
-#, fuzzy
-msgid "Name of attribute column with values to interpolate"
-msgstr "का के लिए"
-#: ../vector/v.surf.idw/main.c:100 ../vector/v.surf.idw/main.c:124
-#, fuzzy
-msgid "Values"
-msgstr "नहीं"
-#: ../vector/v.surf.idw/main.c:115
-msgid "Don't index points by raster cell"
-msgstr ""
-#: ../vector/v.surf.idw/main.c:116
-#, fuzzy
-msgid "Slower but uses less memory and includes points from outside region in the interpolation"
-msgstr "कम"
-#: ../vector/v.surf.idw/main.c:131
-#, fuzzy
-msgid "Illegal number of interpolation points"
-msgstr "संख्या का"
-#: ../vector/v.surf.idw/main.c:135
-#, fuzzy
-msgid "No attribute column specified"
-msgstr "नहीं."
-#: ../vector/v.surf.idw/main.c:251
-#, fuzzy, c-format
-msgid "Interpolating raster map <%s> (%d rows, %d cols)... "
-msgstr "n"
-#: ../vector/v.surf.idw/read_sites.c:88
-#: ../vector/v.surf.bspline/crosscorr.c:214
-#, fuzzy, c-format
-msgid "No record for point (cat = %d)"
-#: ../vector/v.surf.idw/read_sites.c:104
-#, fuzzy, c-format
-msgid "%d points loaded"
-msgstr "लोड हो गया n"
-#: ../vector/v.hull/hull.c:107
-#, fuzzy
-msgid "Simple planar hulls not implemented yet"
-msgstr "नहीं"
-#: ../vector/v.hull/main.c:53
-msgid "Produces a convex hull for a given vector map."
-msgstr ""
-#: ../vector/v.hull/main.c:64
-#, fuzzy
-msgid "Use all vector points (do not limit to current region)"
-msgstr "सभी नहीं"
-#: ../vector/v.hull/main.c:69
-msgid "Create a 'flat' 2D hull even if the input is 3D points"
-msgstr ""
-#: ../vector/v.hull/main.c:88
-#, fuzzy, c-format
-msgid "Error loading vector points from <%s>"
-msgstr "का"
-#: ../vector/v.hull/main.c:91
-#, fuzzy, c-format
-msgid "Convex hull calculation requires at least three points (%d found)"
-msgstr "पर"
-#: ../vector/v.hull/main.c:93
-#, fuzzy, c-format
-msgid "%d points read from vector map <%s>"
-msgstr "n"
-#: ../vector/v.out.dxf/main.c:59
-#, fuzzy
-msgid "Exports vector map to DXF file format."
-msgstr "a a."
-#: ../vector/v.out.dxf/main.c:67
-#, fuzzy
-msgid "Name for DXF output file"
-msgstr "के लिए"
-#: ../vector/v.out.dxf/main.c:91
-#, fuzzy, c-format
-msgid "%d features written to '%s'."
-#: ../vector/v.out.dxf/write_dxf.c:21
-#, c-format
-msgid "The file '%s' already exists."
-msgstr ""
-#: ../vector/v.out.dxf/write_dxf.c:23
-#, fuzzy, c-format
-msgid "The file '%s' already exists and will be overwritten."
-msgstr "i n"
-#: ../vector/v.out.dxf/write_dxf.c:27
-#, fuzzy, c-format
-msgid "%s: Cannot write dxf file."
-msgstr "नहीं"
-#: ../vector/v.drape/main.c:142
-#: ../locale/scriptstrings/tv.what.rast_to_translate.c:4
-msgid "sampling"
-msgstr ""
-#: ../vector/v.drape/main.c:146
-#, fuzzy
-msgid "Converts vector map to 3D by sampling of elevation raster map."
-msgstr "एक"
-#: ../vector/v.drape/main.c:157
-#, fuzzy
-msgid "Elevation raster map for height extraction"
-#: ../vector/v.drape/main.c:171
-msgid "Sampling method"
-msgstr ""
-#: ../vector/v.drape/main.c:176
-#, fuzzy
-msgid "Scale sampled raster values"
-msgstr "के लिए."
-#: ../vector/v.drape/main.c:184
-msgid "Vector Z value for unknown height"
-msgstr ""
-#: ../vector/v.drape/main.c:186
-msgid "Will set Z to this value, if value from raster map can not be read"
-msgstr ""
-#: ../vector/v.drape/main.c:262
-msgid "No features match Your query"
-msgstr ""
-#: ../vector/v.drape/main.c:363 ../vector/v.drape/main.c:373
-msgid "Due to error attribute data to new map are not transferred"
-msgstr ""
-#: ../vector/v.drape/main.c:384
-msgid "No features drapped. Check your computational region and input vector map."
-msgstr ""
-#: ../vector/v.net.path/path.c:82
-#, fuzzy, c-format
-msgid "[%d] points without category (nfield: [%d])"
-msgstr "बिन्दु n"
-#: ../vector/v.net.path/path.c:168 ../vector/v.net.path/path.c:188
-#, fuzzy, c-format
-msgid "No point with category [%d]"
-#: ../vector/v.net.path/path.c:209
-#, c-format
-msgid "Point with category [%d] is not reachable from point with category [%d]"
-msgstr ""
-#: ../vector/v.net.path/path.c:266
-#, c-format
-msgid "Point %f,%f is not reachable from point %f,%f"
-msgstr ""
-#: ../vector/v.net.path/path.c:331
-#, fuzzy, c-format
-msgid "[%d] input format errors"
-msgstr "n"
-#: ../vector/v.net.path/path.c:333
-#, fuzzy, c-format
-msgid "[%d] points of given category missing"
-msgstr "बिन्दु n"
-#: ../vector/v.net.path/path.c:335
-#, c-format
-msgid "%d destination(s) unreachable (including points out of threshold)"
-msgstr ""
-#: ../vector/v.net.path/main.c:43
-msgid "Finds shortest path on vector network."
-msgstr ""
-#: ../vector/v.net.path/main.c:66
-#, fuzzy
-msgid "Name of file containing start and end points. If not given, read from stdin"
-msgstr "का नहीं"
-#: ../vector/v.net.path/main.c:93
-#, fuzzy
-msgid "Maximum distance to the network"
-msgstr "बिन्दु"
-#: ../vector/v.net.path/main.c:94
-msgid "If start/end are given as coordinates. If start/end point is outside this threshold, the path is not found and error message is printed. To speed up the process, keep this value as low as possible."
-msgstr ""
-#: ../vector/v.net.path/main.c:107
-msgid "Write output as original input segments, not each path as one line."
-msgstr ""
-#: ../vector/v.rectify/main.c:66
-#, fuzzy
-msgid "Rectifies a vector by computing a coordinate transformation for each object in the vector based on the control points."
-msgstr "छवि a के लिए छवि चालू"
-#: ../vector/v.rectify/main.c:81
-#, fuzzy
-msgid "Name of input file with control points"
-msgstr "घुमाएँ"
-#: ../vector/v.rectify/main.c:93
-#, fuzzy
-msgid "Field separator for RMS report"
-msgstr "छापें"
-#: ../vector/v.rectify/main.c:94
-msgid "Special characters: newline, space, comma, tab"
-msgstr ""
-#: ../vector/v.rectify/main.c:98
-#, fuzzy
-msgid "Perform 3D transformation"
-msgstr "का"
-#: ../vector/v.rectify/main.c:102
-msgid "Print RMS errors"
-msgstr ""
-#: ../vector/v.rectify/main.c:103
-msgid "Print RMS errors and exit without rectifying the input map"
-msgstr ""
-#: ../vector/v.rectify/main.c:107
-#, fuzzy
-msgid "Do not build topology for output"
-msgstr "नहीं"
-#: ../vector/v.rectify/main.c:123
-msgid "Please select a group or give an input file."
-msgstr ""
-#: ../vector/v.rectify/main.c:125
-msgid "Points in group will be ignored, GCPs in input file are used."
-msgstr ""
-#: ../vector/v.rectify/main.c:139
-msgid "A file with 3D control points is needed for 3d transformation"
-msgstr ""
-#: ../vector/v.rectify/main.c:181
-#, fuzzy, c-format
-msgid "The vector map <%s> already exists in"
-msgstr "नहीं"
-#: ../vector/v.rectify/main.c:184
-#, fuzzy
-msgid "Rectification cancelled."
-msgstr "पॉलीनॉम"
-#: ../vector/v.rectify/cp.c:288 ../vector/v.rectify/cp.c:308
-#, fuzzy, c-format
-msgid "Can not open file <%s>"
-msgstr "फ़ाइल"
-#: ../vector/v.rectify/cp.c:295 ../vector/v.rectify/cp.c:315
-#, fuzzy, c-format
-msgid "Bad format in control point file <%s>"
-msgstr "फ़ाइल"
-#: ../vector/v.timestamp/main.c:39
-#, fuzzy
-msgid "Modifies a timestamp for a vector map."
-msgstr "छापें a के लिए a."
-#: ../vector/v.timestamp/main.c:40
-#, fuzzy
-msgid "Print/add/remove a timestamp for a vector map."
-#: ../vector/v.timestamp/main.c:66
-#, fuzzy, c-format
-msgid "Vector map <%s> not found %s"
-msgstr "नहीं"
-#: ../vector/v.net.connectivity/main.c:55
-#, fuzzy
-msgid "connectivity"
-msgstr "का"
-#: ../vector/v.net.connectivity/main.c:57
-msgid "Computes vertex connectivity between two sets of nodes in the network."
-msgstr ""
-#: ../vector/v.net.connectivity/main.c:97
-#, fuzzy
-msgid "Set1 category values"
-msgstr "छापें"
-#: ../vector/v.net.connectivity/main.c:98
-#: ../vector/v.net.connectivity/main.c:104
-msgid "Set1"
-msgstr ""
-#: ../vector/v.net.connectivity/main.c:103
-msgid "Set1 WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-#: ../vector/v.net.connectivity/main.c:108
-#, fuzzy
-msgid "Set2 category values"
-msgstr "छापें"
-#: ../vector/v.net.connectivity/main.c:109
-#: ../vector/v.net.connectivity/main.c:115
-msgid "Set2"
-msgstr ""
-#: ../vector/v.net.connectivity/main.c:114
-msgid "Set2 WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-#: ../vector/v.net.connectivity/main.c:166
-#: ../vector/v.net.connectivity/main.c:169
-#, fuzzy, c-format
-msgid "%s is empty"
-msgstr "है n"
-#: ../vector/v.surf.bspline/main.c:120
-#, fuzzy
-msgid "Name of input vector map of sparse points"
-msgstr "का"
-#: ../vector/v.surf.bspline/main.c:131
-msgid "Raster map to use for masking (applies to raster output only)"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:141
-msgid "Length of each spline step in the east-west direction"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:150
-msgid "Length of each spline step in the north-south direction"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:178
-#, fuzzy
-msgid "Name of attribute column with values to approximate"
-msgstr "का के लिए"
-#: ../vector/v.surf.bspline/main.c:194
-msgid "Maximum memory to be used for raster output (in MB)"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:206
-msgid "Choose either vector or raster output, not both"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:209
-#, fuzzy
-msgid "No raster or vector or cross-validation output"
-msgstr "का"
-#: ../vector/v.surf.bspline/main.c:263
-#, fuzzy
-msgid "Input vector is not 3D, can not use z coordinates"
-msgstr "का"
-#: ../vector/v.surf.bspline/main.c:266
-#, fuzzy
-msgid "Both layer and column with z values must be given"
-msgstr "थीटा"
-#: ../vector/v.surf.bspline/main.c:298
-#, c-format
-msgid "Cross validation finished for sie = %f and sin = %f"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:307
-#, fuzzy, c-format
-msgid "Vector map <%s> of sparse points will be interpolated"
-msgstr "का."
-#: ../vector/v.surf.bspline/main.c:323
-#, c-format
-msgid "Sorry, <%s> driver is not allowed for vector output in this module. Try with a raster output or other driver."
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:345
-#, fuzzy, c-format
-msgid "Points in input vector map <%s> will be interpolated"
-msgstr "का."
-#: ../vector/v.surf.bspline/main.c:356
-#, fuzzy, c-format
-msgid "Cells for raster map <%s> will be interpolated"
-msgstr "का."
-#: ../vector/v.surf.bspline/main.c:365
-#, fuzzy
-msgid "Cannot read field info"
-msgstr "फील्ड"
-#: ../vector/v.surf.bspline/main.c:386
-#, fuzzy, c-format
-msgid "[%d] records selected from table"
-msgstr "नहीं"
-#: ../vector/v.surf.bspline/main.c:405
-#, fuzzy, c-format
-msgid "Interpolation: Creating table: It was impossible to create table <%s>."
-msgstr "i n"
-#: ../vector/v.surf.bspline/main.c:473
-#, fuzzy
-msgid "Load masking map"
-msgstr "त्रुटि के लिए"
-#: ../vector/v.surf.bspline/main.c:714
-#, fuzzy, c-format
-msgid "Interpolation: (%d,%d): No record for point (cat = %d)"
-msgstr "नहीं के लिए"
-#: ../vector/v.surf.bspline/main.c:850
-msgid "No data within this subregion. Consider increasing spline step values."
-msgstr ""
-#: ../vector/v.surf.bspline/crosscorr.c:72
-#, c-format
-msgid "%d are too many points. The cross validation would take too much time."
-msgstr ""
-#: ../vector/v.surf.bspline/crosscorr.c:85
-msgid "Maybe, it takes too long. It will depend on how many points you are considering."
-msgstr ""
-#: ../vector/v.surf.bspline/crosscorr.c:114
-#, c-format
-msgid "CrossCorrelation: driver=%s db=%s"
-msgstr ""
-#: ../vector/v.surf.bspline/crosscorr.c:131
-#, fuzzy, c-format
-msgid "No records selected from table <%s> "
-msgstr "नहीं"
-#: ../vector/v.lidar.growing/ConvexHull.c:269
-msgid "...now exiting to system..."
-msgstr ""
-#: ../vector/v.lidar.growing/main.c:78
-msgid "Building contour determination and Region Growing algorithm for determining the building inside"
-msgstr ""
-#: ../vector/v.lidar.growing/main.c:83
-msgid "Input vector (v.lidar.edgedetection output"
-msgstr ""
-#: ../vector/v.lidar.growing/main.c:93
-#, fuzzy
-msgid "Name of the first pulse vector map"
-msgstr "के लिए"
-#: ../vector/v.lidar.growing/main.c:100
-msgid "Threshold for cell object frequency in region growing"
-msgstr ""
-#: ../vector/v.lidar.growing/main.c:108
-msgid "Threshold for double pulse in region growing"
-msgstr ""
-#: ../vector/v.lidar.growing/main.c:176
-#, fuzzy, c-format
-msgid "Unable to open table <%s>"
-msgstr "का"
-#: ../vector/v.lidar.growing/main.c:201
-msgid "Setting regions and boxes"
-msgstr ""
-#: ../vector/v.lidar.growing/main.c:267
-#, fuzzy, c-format
-msgid "Rows = %d"
-msgstr "n"
-#: ../vector/v.lidar.growing/main.c:268
-#, fuzzy, c-format
-msgid "Columns = %d"
-msgstr "नहीं"
-#: ../vector/v.lidar.growing/main.c:288
-#, fuzzy
-msgid "read points in input vector"
-msgstr "का"
-#: ../vector/v.lidar.growing/main.c:437
-#, fuzzy
-msgid "Region Growing"
-msgstr "n"
-#: ../vector/v.to.rast/support.c:142 ../vector/v.to.rast/support.c:297
-#, fuzzy, c-format
-msgid "Unknown column <%s> in table <%s>"
-msgstr "अज्ञात क़िस्म"
-#: ../vector/v.to.rast/support.c:163 ../vector/v.to.rast/support.c:326
-#, fuzzy
-msgid "No records selected"
-msgstr "नहीं"
-#: ../vector/v.to.rast/support.c:176
-#, c-format
-msgid "Error in color definition column (%s) with cat %d: colorstring [%s]"
-msgstr ""
-#: ../vector/v.to.rast/support.c:179
-msgid "Color set to [200:200:200]"
-msgstr ""
-#: ../vector/v.to.rast/support.c:184
-#, c-format
-msgid "Error in color definition column (%s), with cat %d"
-msgstr ""
-#: ../vector/v.to.rast/support.c:273
-msgid "Label column was not specified, no labels will be written"
-msgstr ""
-#: ../vector/v.to.rast/support.c:349
-#, fuzzy, c-format
-msgid "Column type (%s) not supported"
-msgstr "है नहीं"
-#: ../vector/v.to.rast/support.c:483 ../vector/v.to.rast/vect2rast.c:114
-#, fuzzy, c-format
-msgid "Unknown use type: %d"
-#: ../vector/v.to.rast/vect2rast.c:35
-#, fuzzy
-msgid "Loading data..."
-msgstr "n"
-#: ../vector/v.to.rast/vect2rast.c:41
-#, fuzzy, c-format
-msgid "Vector map <%s> is not 3D"
-msgstr "नहीं"
-#: ../vector/v.to.rast/vect2rast.c:66
-#, fuzzy, c-format
-msgid "Column type (%s) not supported (did you mean 'labelcolumn'?)"
-msgstr "नहीं"
-#: ../vector/v.to.rast/vect2rast.c:96
-#, fuzzy, c-format
-msgid "Unable to use column <%s>"
-msgstr "का"
-#: ../vector/v.to.rast/vect2rast.c:125
-#, fuzzy
-msgid "Unknown raster map type"
-msgstr "छापें"
-#: ../vector/v.to.rast/vect2rast.c:133
-#, fuzzy, c-format
-msgid "Unable to process areas from vector map <%s>"
-msgstr "के लिए."
-#: ../vector/v.to.rast/vect2rast.c:149
-#, fuzzy, c-format
-msgid "Pass %d of %d:"
-msgstr "n"
-#: ../vector/v.to.rast/vect2rast.c:157
-#, fuzzy, c-format
-msgid "Problem processing areas from vector map <%s>, continuing..."
-msgstr "के लिए."
-#: ../vector/v.to.rast/vect2rast.c:168
-#, c-format
-msgid "Problem processing lines from vector map <%s>, continuing..."
-msgstr ""
-#: ../vector/v.to.rast/vect2rast.c:193
-#, fuzzy
-msgid "Creating support files for raster map..."
-msgstr "बनाया जा रहा है के लिए"
-#: ../vector/v.to.rast/vect2rast.c:200
-msgid "Color can be updated from database only if use=attr"
-msgstr ""
-#: ../vector/v.to.rast/vect2rast.c:220
-#, c-format
-msgid "Converted areas: %d of %d"
-msgstr ""
-#: ../vector/v.to.rast/vect2rast.c:222
-#, c-format
-msgid "Converted points/lines: %d of %d"
-msgstr ""
-#: ../vector/v.to.rast/main.c:43
-#, fuzzy
-msgid "rasterization"
-msgstr "ट्रेस"
-#: ../vector/v.to.rast/main.c:44
-#, fuzzy
-msgid "Converts (rasterize) a vector map into a raster map."
-msgstr "a a."
-#: ../vector/v.to.rast/main.c:63
-#, fuzzy
-msgid "Source of raster values"
-msgstr "के लिए."
-#: ../vector/v.to.rast/main.c:64
-#, fuzzy
-msgid "attr;read values from attribute table;cat;use category values;val;use value specified by value option;z;use z coordinate (points or contours only);dir;output as flow direction (lines only)"
-msgstr "का n n n n ज़ेड n"
-#: ../vector/v.to.rast/main.c:73
-#, fuzzy
-msgid "Name of column for 'attr' parameter (data type must be numeric)"
-msgstr "के लिए"
-#: ../vector/v.to.rast/main.c:79
-msgid "Name of color definition column (with RRR:GGG:BBB entries)"
-msgstr ""
-#: ../vector/v.to.rast/main.c:85
-#, fuzzy
-msgid "Name of column used as raster category labels"
-msgstr "का के लिए"
-#: ../vector/v.to.rast/main.c:94
-#, fuzzy
-msgid "Raster value (for use=val)"
-msgstr "के लिए"
-#: ../vector/v.to.rast/main.c:114
-#, fuzzy
-msgid "Column parameter missing (or use value parameter)"
-msgstr "का"
-#: ../vector/v.to.rast/main.c:119
-#, fuzzy
-msgid "Column parameter cannot be combined with use of category values option"
-msgstr "का"
-#: ../vector/v.to.rast/main.c:124
-#, fuzzy
-msgid "Column parameter cannot be combined with use of value option"
-msgstr "का"
-#: ../vector/v.to.rast/main.c:129
-#, fuzzy
-msgid "Column parameter cannot be combined with use of z coordinate"
-msgstr "का ज़ेड"
-#: ../vector/v.to.rast/main.c:135
-#, fuzzy, c-format
-msgid "Unknown option '%s'"
-#: ../vector/v.to.rast/do_lines.c:65 ../vector/v.to.rast/do_areas.c:64
-#, fuzzy
-msgid "Unable to use column specified"
-msgstr "नहीं."
-#: ../vector/v.to.rast/do_lines.c:125
-#, c-format
-msgid "%d lines with varying height were not written to raster"
-msgstr ""
-#: ../vector/v.to.rast/do_areas.c:50 ../vector/v.to.rast/do_areas.c:58
-#, fuzzy, c-format
-msgid "No record for area (cat = %d)"
-#: ../vector/v.to.rast/do_areas.c:79
-#, fuzzy, c-format
-msgid "Get area %d failed"
-msgstr "चालू"
-#: ../vector/v.to.rast/do_areas.c:119
-#, fuzzy
-msgid "Area without centroid (OK for island)"
-msgstr "संपादन के लिए "
-#: ../vector/v.to.rast/do_areas.c:126
-msgid "Area centroid without category"
-msgstr ""
-#: ../vector/v.out.vtk/writeVTK.c:186
-msgid "No coordinates to generate the output! Maybe an empty vector type chosen?"
-msgstr ""
-#: ../vector/v.out.vtk/head.c:27
-msgid "writeVTKHeader: Writing VTK-Header"
-msgstr ""
-#: ../vector/v.out.vtk/main.c:50
-#, fuzzy
-msgid "Converts a vector map to VTK ASCII output."
-msgstr "a."
-#: ../vector/v.out.vtk/main.c:60
-#, fuzzy
-msgid "Path to resulting VTK file"
-msgstr "का"
-#: ../vector/v.out.vtk/main.c:85
-msgid "Layer number"
-msgstr ""
-#: ../vector/v.out.vtk/main.c:179
-msgid "dp has to be from 0 to 8"
-msgstr ""
-#: ../vector/v.out.vtk/main.c:188
-msgid "Failed to interpret 'layer' parameter as an integer"
-msgstr ""
-#: ../vector/v.net.visibility/main.c:46
-msgid "path"
-msgstr ""
-#: ../vector/v.net.visibility/main.c:47
-msgid "visibility"
-msgstr ""
-#: ../vector/v.net.visibility/main.c:48
-msgid "Visibility graph construction."
-msgstr ""
-#: ../vector/v.net.visibility/main.c:60
-#, fuzzy
-msgid "One or more coordinates"
-msgstr "के लिए ज़ेड"
-#: ../vector/v.net.visibility/main.c:66
-msgid "Add points after computing the vis graph"
-msgstr ""
-#: ../vector/v.net.visibility/main.c:90
-#, fuzzy, c-format
-msgid "Unable to copy elements from vector map <%s>"
-msgstr "के लिए"
-#: ../vector/v.net.visibility/main.c:95
-#, fuzzy
-msgid "Lat-long projection"
-#: ../vector/v.in.lidar/main.c:155
-#, fuzzy
-msgid "Converts LAS LiDAR point clouds to a GRASS vector map with libLAS."
-msgstr "n"
-#: ../vector/v.in.lidar/main.c:158
-#, fuzzy
-msgid "LAS input file"
-msgstr "है n"
-#: ../vector/v.in.lidar/main.c:159
-msgid "LiDAR input files in LAS format (*.las or *.laz)"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:170 ../vector/v.in.lidar/main.c:207
-#, fuzzy
-msgid "Subregion"
-msgstr "n"
-#: ../vector/v.in.lidar/main.c:185
-msgid "Only import points of selected return type"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:186
-#, fuzzy
-msgid "If not specified, all points are imported"
-msgstr "बिन्दु"
-#: ../vector/v.in.lidar/main.c:192
-#, fuzzy
-msgid "Print LAS file info and exit"
-msgstr "छापें का"
-#: ../vector/v.in.lidar/main.c:218
-msgid "Create the location specified by the \"location\" parameter and exit. Do not import the vector file."
-msgstr ""
-#: ../vector/v.in.lidar/main.c:279
-#, fuzzy, c-format
-msgid "Unknown filter option <%s>"
-#: ../vector/v.in.lidar/main.c:475
-#, fuzzy, c-format
-msgid "Vector map <%s> already exists and will be overwritten"
-msgstr "i n"
-#: ../vector/v.in.lidar/main.c:625
-#, fuzzy, c-format
-msgid "Importing %d points..."
-msgstr "n"
-#: ../vector/v.in.lidar/main.c:780
-#, fuzzy, c-format
-msgid "%d points imported"
-#: ../vector/v.in.lidar/main.c:782
-#, c-format
-msgid "%d input points were not valid"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:784
-#, fuzzy, c-format
-msgid "%d input points were outside of the selected area"
-msgstr "बिन्दु n"
-#: ../vector/v.in.lidar/main.c:786
-#, fuzzy, c-format
-msgid "%d input points were filtered by return number"
-msgstr "बिन्दु n"
-#: ../db/db.drivers/main.c:39
-#, fuzzy
-msgid "Error trying to read dbmscap file\n"
-msgstr "त्रुटि n"
-#: ../db/db.drivers/main.c:64
-msgid "Full output"
-msgstr ""
-#: ../db/db.drivers/main.c:68
-msgid "print drivers and exit"
-msgstr ""
-#: ../db/db.drivers/main.c:74
-#, fuzzy
-msgid "List all database drivers."
-msgstr "सभी."
-#: ../db/drivers/ogr/cursor.c:65 ../db/drivers/odbc/cursor.c:36
-#, fuzzy
-msgid "Unable to allocate cursor"
-msgstr "के लिए"
-#: ../db/drivers/ogr/cursor.c:74
-#, fuzzy
-msgid "Unable to add new token"
-msgstr "का"
-#: ../db/drivers/ogr/db.c:53
-#, fuzzy
-msgid "Unable to open OGR data source"
-msgstr "के लिए."
-#: ../db/drivers/ogr/fetch.c:55 ../db/drivers/ogr/fetch.c:188
-#: ../db/drivers/mysql/fetch.c:34 ../db/drivers/mysql/fetch.c:276
-#: ../db/drivers/postgres/fetch.c:33 ../db/drivers/sqlite/fetch.c:265
-#, fuzzy
-msgid "Cursor not found"
-msgstr "नहीं"
-#: ../db/drivers/ogr/fetch.c:71
-#, fuzzy
-msgid "DB_PREVIOUS not supported"
-msgstr "नहीं"
-#: ../db/drivers/ogr/fetch.c:82
-#, fuzzy
-msgid "DB_LAST not supported"
-msgstr "नहीं"
-#: ../db/drivers/ogr/fetch.c:160 ../db/drivers/ogr/describe.c:200
-#, fuzzy
-msgid "Unknown type"
-#: ../db/drivers/ogr/listtab.c:49 ../db/drivers/sqlite/listtab.c:78
-#, fuzzy
-msgid "Unable to db_alloc_string_array()"
-msgstr "के लिए"
-#: ../db/drivers/ogr/describe.c:55
-#, fuzzy, c-format
-msgid "OGR layer <%s> does not exist\n"
-msgstr "नहीं"
-#: ../db/drivers/ogr/describe.c:63 ../db/drivers/ogr/select.c:58
-#, fuzzy
-msgid "Unable to describe table\n"
-msgstr "फ़ाइल"
-#: ../db/drivers/ogr/describe.c:112
-#, fuzzy, c-format
-msgid "OGR driver: column '%s', OGR type %d is not supported"
-msgstr "है नहीं"
-#: ../db/drivers/ogr/describe.c:192
-#, c-format
-msgid "column '%s', type 'string': unknown width -> stored as varchar(250) some data may be lost"
-msgstr ""
-#: ../db/drivers/ogr/select.c:50
-#, fuzzy
-msgid "Unable to select: \n"
-msgstr "सेट आकार "
-#: ../db/drivers/odbc/cursor.c:55 ../db/drivers/postgres/cursor.c:50
-#: ../db/drivers/sqlite/cursor.c:56
-#, fuzzy
-msgid "Unable to add new token."
-msgstr "का"
-#: ../db/drivers/odbc/listdb.c:29
-#, fuzzy
-msgid "Unable to allocate handle."
-msgstr "के लिए"
-#: ../db/drivers/odbc/listdb.c:40 ../db/drivers/postgres/listdb.c:81
-#, fuzzy
-msgid "Unable to set handle"
-msgstr "का a"
-#: ../db/drivers/odbc/table.c:159
-#, fuzzy, c-format
-msgid "Table %s doesn't exist"
-msgstr "नहीं"
-#: ../db/drivers/odbc/table.c:176
-#, c-format
-msgid "Table %s isn't 'TABLE' or 'VIEW' but %s"
-msgstr ""
-#: ../db/drivers/mysql/create_table.c:108
-#: ../db/drivers/postgres/create_table.c:103
-#: ../db/drivers/sqlite/create_table.c:122
-#, fuzzy
-msgid "Unable to create table:"
-msgstr "के लिए"
-#: ../db/drivers/mysql/cursor.c:44 ../db/drivers/postgres/cursor.c:41
-#, fuzzy
-msgid "Unable allocate cursor."
-msgstr "के लिए"
-#: ../db/drivers/mysql/cursor.c:53
-#, fuzzy
-msgid "Unable to add dnew token."
-msgstr "का"
-#: ../db/drivers/mysql/db.c:61 ../db/drivers/postgres/db.c:60
-#, fuzzy
-msgid "Connection failed."
-msgstr "का"
-#: ../db/drivers/mysql/index.c:55 ../db/drivers/sqlite/index.c:76
-#, fuzzy
-msgid "Unable to create index:"
-msgstr "का a"
-#: ../db/drivers/mysql/fetch.c:52
-msgid "Cursor position is not supported by MySQL driver"
-msgstr ""
-#: ../db/drivers/mysql/fetch.c:191
-#, fuzzy
-msgid "Unable to scan timestamp: "
-msgstr "के लिए"
-#: ../db/drivers/mysql/fetch.c:200
-msgid "Unknown timestamp format: "
-msgstr ""
-#: ../db/drivers/mysql/fetch.c:215
-#, fuzzy
-msgid "Unable to scan date: "
-msgstr "के लिए."
-#: ../db/drivers/mysql/fetch.c:229
-#, fuzzy
-msgid "Unable to scan time: "
-msgstr "सेट आकार "
-#: ../db/drivers/mysql/fetch.c:245
-#, fuzzy
-msgid "Unable to scan datetime:"
-msgstr "स्रोत"
-#: ../db/drivers/mysql/listtab.c:37
-#, fuzzy
-msgid "Unable get list of tables:"
-msgstr "चालू"
-#: ../db/drivers/mysql/parse.c:61
-#, fuzzy
-msgid "Wrong port number in MySQL database definition: "
-msgstr "के लिए"
-#: ../db/drivers/mysql/parse.c:72 ../db/drivers/postgres/parse.c:59
-#, fuzzy
-msgid "'user' in database definition is not supported, use db.login"
-msgstr "है नहीं"
-#: ../db/drivers/mysql/parse.c:76 ../db/drivers/postgres/parse.c:63
-#, fuzzy
-msgid "'password' in database definition is not supported, use db.login"
-msgstr "है नहीं"
-#: ../db/drivers/mysql/parse.c:81
-#, fuzzy
-msgid "Unknown option in database definition for MySQL: "
-msgstr "के लिए"
-#: ../db/drivers/mysql/dbe.c:45
-#, fuzzy
-msgid "Unable parse MySQL embedded database name"
-msgstr "स्रोत"
-#: ../db/drivers/mysql/dbe.c:61
-msgid "Cannot initialize MySQL embedded server"
-msgstr ""
-#: ../db/drivers/mysql/dbe.c:80
-msgid "Unable to connect to MySQL embedded server: "
-msgstr ""
-#: ../db/drivers/mysql/execute.c:41 ../db/drivers/postgres/execute.c:42
-#, fuzzy
-msgid "Unable to execute:"
-msgstr "सेट आकार "
-#: ../db/drivers/mysql/execute.c:62
-#, fuzzy
-msgid "Unable to start transaction:"
-msgstr "फ़ाइल"
-#: ../db/drivers/mysql/execute.c:77
-#, fuzzy
-msgid "Unable to commit transaction:"
-msgstr "फ़ाइल"
-#: ../db/drivers/mysql/describe.c:32 ../db/drivers/sqlite/describe.c:92
-#: ../db/drivers/sqlite/select.c:95
-#, fuzzy
-msgid "Unable to describe table:"
-msgstr "फ़ाइल"
-#: ../db/drivers/mysql/describe.c:50 ../db/drivers/postgres/select.c:69
-#, fuzzy
-msgid "Unable to describe table"
-msgstr "फ़ाइल"
-#: ../db/drivers/mysql/describe.c:121
-#, fuzzy, c-format
-msgid "MySQL driver: column '%s', type %d is not supported"
-msgstr "है नहीं"
-#: ../db/drivers/mysql/describe.c:127
-#, fuzzy, c-format
-msgid "column '%s' : type BIGINT is stored as integer (4 bytes) some data may be damaged"
-msgstr "है बाइट्स"
-#: ../db/drivers/mysql/select.c:42
-#, fuzzy
-msgid "Unable to select data:"
-msgstr "सेट आकार "
-#: ../db/drivers/mysql/select.c:64 ../db/drivers/postgres/describe.c:40
-#, fuzzy
-msgid "Unable to describe table."
-msgstr "फ़ाइल"
-#: ../db/drivers/postgres/create_table.c:90
-#, fuzzy, c-format
-msgid "Unknown column type (%s)"
-#: ../db/drivers/postgres/create_table.c:132
-#, fuzzy
-msgid "Unable to grant select on table:"
-msgstr "चालू"
-#: ../db/drivers/postgres/db.c:87
-#, fuzzy
-msgid "Unable to set schema:"
-msgstr "सेट आकार "
-#: ../db/drivers/postgres/db.c:105
-#, fuzzy
-msgid "Unable to select data types"
-msgstr "सभी"
-#: ../db/drivers/postgres/listdb.c:29
-#, fuzzy
-msgid "db_driver_list_databases() is not implemented"
-msgstr "नहीं"
-#: ../db/drivers/postgres/listdb.c:50
-#, fuzzy
-msgid "Unable to connect to Postgres:"
-msgstr "सभी"
-#: ../db/drivers/postgres/listdb.c:61
-#, fuzzy
-msgid "Unable to select from Postgres:"
-msgstr "सभी"
-#: ../db/drivers/postgres/index.c:59
-#, fuzzy
-msgid "Unable to create index:\n"
-msgstr "का a"
-#: ../db/drivers/postgres/fetch.c:129 ../db/drivers/sqlite/fetch.c:171
-#, fuzzy
-msgid "Unable to scan date:"
-msgstr "के लिए."
-#: ../db/drivers/postgres/fetch.c:147 ../db/drivers/sqlite/fetch.c:188
-#, fuzzy
-msgid "Unable to scan time:"
-msgstr "सेट आकार "
-#: ../db/drivers/postgres/fetch.c:166
-msgid "Unable to scan timestamp (no idea how to process time zone):"
-msgstr ""
-#: ../db/drivers/postgres/fetch.c:174
-msgid "Unable to scan timestamp (not enough arguments):"
-msgstr ""
-#: ../db/drivers/postgres/fetch.c:188
-#, fuzzy
-msgid "Unable to recognize boolean value"
-msgstr "का"
-#: ../db/drivers/postgres/fetch.c:206
-#, fuzzy
-msgid "Taken not found"
-msgstr "नहीं"
-#: ../db/drivers/postgres/priv.c:53
-#, fuzzy
-msgid "Unable grant on table:"
-msgstr "का"
-#: ../db/drivers/postgres/listtab.c:37
-#, fuzzy
-msgid "Unable to select table names."
-msgstr "सभी"
-#: ../db/drivers/postgres/listtab.c:63
-#, fuzzy
-msgid "Unable to select view names."
-msgstr "सभी"
-#: ../db/drivers/postgres/parse.c:68
-#, fuzzy
-msgid "Unknown option in database definition for PostgreSQL: "
-msgstr "के लिए "
-#: ../db/drivers/postgres/execute.c:68
-#, fuzzy
-msgid "Unable to 'BEGIN' transaction"
-msgstr "फ़ाइल"
-#: ../db/drivers/postgres/execute.c:88
-#, fuzzy
-msgid "Unable to 'COMMIT' transaction"
-msgstr "फ़ाइल"
-#: ../db/drivers/postgres/describe.c:112
-#, fuzzy, c-format
-msgid "PostgreSQL driver: PostGIS column '%s', type 'geometry' will not be converted"
-msgstr "है नहीं"
-#: ../db/drivers/postgres/describe.c:119
-#, fuzzy, c-format
-msgid "PostgreSQL driver: column '%s', type %d is not supported"
-msgstr "है नहीं"
-#: ../db/drivers/postgres/describe.c:126
-#, fuzzy, c-format
-msgid "column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data may be damaged"
-msgstr "है बाइट्स"
-#: ../db/drivers/postgres/describe.c:130
-#, fuzzy, c-format
-msgid "column '%s' : type character varying is stored as varchar(250) some data may be lost"
-msgstr "है"
-#: ../db/drivers/postgres/describe.c:136
-#, fuzzy, c-format
-msgid "column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 (true)"
-msgstr "है चर"
-#: ../db/drivers/postgres/select.c:31
-msgid "Unable set DATESTYLE"
-msgstr ""
-#: ../db/drivers/postgres/select.c:55
-#, fuzzy
-msgid "Unable to select:"
-msgstr "सेट आकार "
-#: ../db/drivers/sqlite/create_table.c:141 ../db/drivers/sqlite/index.c:95
-#: ../db/drivers/sqlite/execute.c:69 ../db/drivers/sqlite/describe.c:78
-#: ../db/drivers/sqlite/describe.c:132 ../db/drivers/sqlite/select.c:80
-msgid "Error in sqlite3_step():"
-msgstr ""
-#: ../db/drivers/sqlite/cursor.c:47
-#, fuzzy
-msgid "Unable to allocate cursor."
-msgstr "के लिए"
-#: ../db/drivers/sqlite/db.c:85
-#, fuzzy
-msgid "Unable to open database: "
-msgstr "के लिए."
-#: ../db/drivers/sqlite/db.c:109
-#, fuzzy
-msgid "SQLite database connection is still busy"
-msgstr "नहीं"
-#: ../db/drivers/sqlite/fetch.c:72
-#, fuzzy
-msgid "Unable to fetch:"
-msgstr "के लिए"
-#: ../db/drivers/sqlite/fetch.c:87
-#, fuzzy
-msgid "DB_PREVIOUS is not supported"
-msgstr "नहीं"
-#: ../db/drivers/sqlite/fetch.c:93
-#, fuzzy
-msgid "DB_LAST is not supported"
-msgstr "नहीं"
-#: ../db/drivers/sqlite/fetch.c:203
-#, fuzzy
-msgid "Unable to scan timestamp:"
-msgstr "के लिए"
-#: ../db/drivers/sqlite/fetch.c:218
-msgid "SQLite driver: parsing of interval values not implemented; assuming seconds"
-msgstr ""
-#: ../db/drivers/sqlite/fetch.c:223
-#, fuzzy
-msgid "Unable to scan interval:"
-msgstr "का a"
-#: ../db/drivers/sqlite/fetch.c:286
-#, fuzzy
-msgid "Unable to get number of rows:"
-msgstr "i n"
-#: ../db/drivers/sqlite/main.c:47
-#, c-format
-msgid "Busy SQLITE db, already waiting for %d seconds..."
-msgstr ""
-#: ../db/drivers/sqlite/listtab.c:50 ../db/drivers/sqlite/listtab.c:66
-#, fuzzy
-msgid "Unable to list tables:"
-msgstr "के लिए."
-#: ../db/drivers/sqlite/execute.c:53 ../db/drivers/sqlite/describe.c:60
-#: ../db/drivers/sqlite/select.c:63
-msgid "Error in sqlite3_prepare():"
-msgstr ""
-#: ../db/drivers/sqlite/execute.c:83
-#, fuzzy
-msgid "Error in sqlite3_finalize():"
-msgstr "त्रुटि"
-#: ../db/drivers/sqlite/execute.c:111
-#, fuzzy
-msgid "'BEGIN' transaction failed:"
-msgstr "फ़ाइल"
-#: ../db/drivers/sqlite/execute.c:139
-#, fuzzy
-msgid "'COMMIT' transaction failed:"
-msgstr "फ़ाइल"
-#: ../db/drivers/sqlite/describe.c:194
-#, fuzzy, c-format
-msgid "SQLite driver: column '%s', SQLite type %d  is not supported"
-msgstr "है नहीं"
-#: ../db/drivers/dbf/create_table.c:22
-#, fuzzy
-msgid "Unable to create table"
-msgstr "के लिए"
-#: ../db/drivers/dbf/cursor.c:47
-#, fuzzy
-msgid "Unable to allocate new cursor"
-msgstr "के लिए"
-#: ../db/drivers/dbf/cursor.c:59
-#, fuzzy
-msgid "Unable to tokenize new cursor"
-msgstr "का"
-#: ../db/drivers/dbf/db.c:93
-#, fuzzy, c-format
-msgid "Unable create DBF database: %s"
-msgstr "के लिए"
-#: ../db/drivers/dbf/db.c:99
-#, fuzzy, c-format
-msgid "Unable to open DBF database: %s"
-msgstr "के लिए."
-#: ../db/drivers/dbf/column.c:49
-#, c-format
-msgid "Column '%s' already exists (duplicate name)"
-msgstr ""
-#: ../db/drivers/dbf/column.c:99
-#, fuzzy, c-format
-msgid "Column '%s' does not exist"
-msgstr "नहीं"
-#: ../db/drivers/dbf/table.c:117 ../db/drivers/dbf/table.c:170
-#, fuzzy
-msgid "Unable to open DBF file."
-msgstr "i n"
-#: ../db/drivers/dbf/table.c:309
-#, fuzzy, c-format
-msgid "Unable to move '%s' to '%s'."
-msgstr "का"
-#: ../db/drivers/dbf/dbfexe.c:72
-#, fuzzy
-msgid "SQL parser error"
-msgstr "n"
-#: ../db/drivers/dbf/dbfexe.c:74
-#, fuzzy
-msgid "in statement:"
-msgstr "गामा."
-#: ../db/drivers/dbf/dbfexe.c:88
-#, fuzzy, c-format
-msgid "Table '%s' doesn't exist."
-msgstr "नहीं"
-#: ../db/drivers/dbf/dbfexe.c:96
-#, fuzzy
-msgid "Unable to load table head."
-msgstr "का"
-#: ../db/drivers/dbf/dbfexe.c:106
-msgid "Unable to modify table, don't have write permission for DBF file."
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:121 ../db/drivers/dbf/dbfexe.c:1023
-#, fuzzy, c-format
-msgid "Column '%s' not found"
-msgstr "नहीं"
-#: ../db/drivers/dbf/dbfexe.c:145
-#, fuzzy
-msgid "Incompatible value type."
-#: ../db/drivers/dbf/dbfexe.c:161
-#, fuzzy
-msgid "Unable to add column."
-msgstr "का"
-#: ../db/drivers/dbf/dbfexe.c:183
-#, fuzzy
-msgid "Unable to delete column."
-msgstr "फ़ाइल"
-#: ../db/drivers/dbf/dbfexe.c:191
-#, fuzzy, c-format
-msgid "Table %s already exists"
-msgstr "नहीं"
-#: ../db/drivers/dbf/dbfexe.c:206
-#, fuzzy
-msgid "Unable to create table."
-msgstr "के लिए"
-#: ../db/drivers/dbf/dbfexe.c:263 ../db/drivers/dbf/dbfexe.c:273
-#: ../db/drivers/dbf/dbfexe.c:303
-#, fuzzy
-msgid "Error in selecting rows"
-msgstr "त्रुटि के लिए."
-#: ../db/drivers/dbf/dbfexe.c:552
-#, fuzzy
-msgid "Cannot load table."
-msgstr "नक़ल"
-#: ../db/drivers/dbf/dbfexe.c:567
-#, fuzzy
-msgid "Incompatible types in WHERE condition."
-#: ../db/drivers/dbf/dbfexe.c:572
-msgid "Result of WHERE condition is not of type BOOL."
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:588
-msgid "Error in evaluation of WHERE condition."
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:600
-#, c-format
-msgid "Unknown result (%d) of WHERE evaluation"
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:607
-msgid "Unknown WHERE condition type (bug in DBF driver)."
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:633
-#, fuzzy, c-format
-msgid "Unable to find order column '%s'"
-msgstr "फ़ाइल"
-#: ../db/drivers/dbf/dbfexe.c:778
-msgid "Division by zero"
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:917
-msgid "Value operand for AND"
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:931
-msgid "Value operand for OR"
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:946
-msgid "Value operand for NOT"
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:954 ../db/drivers/dbf/dbfexe.c:1151
-#, fuzzy, c-format
-msgid "Unknown operator %d"
-#: ../db/drivers/dbf/dbfexe.c:1061
-msgid "Arithmetical operation with strings is not allowed"
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:1083
-msgid "Comparison between string and number is not allowed"
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:1098
-#, fuzzy, c-format
-msgid "Comparison '%s' between strings not allowed"
-msgstr "के लिए नहीं"
-#: ../db/drivers/dbf/dbfexe.c:1112
-msgid "Match (~) between numbers not allowed"
-msgstr ""
-#: ../db/drivers/dbf/execute.c:32
-#, fuzzy
-msgid "Unable to execute statement."
-msgstr "सेट आकार "
-#: ../db/drivers/dbf/describe.c:34
-#, fuzzy, c-format
-msgid "Table '%s' doesn't exist"
-msgstr "नहीं"
-#: ../db/drivers/dbf/select.c:44
-#, fuzzy
-msgid "Unable to open cursor."
-msgstr "का"
-#: ../db/db.select/main.c:92
-#, fuzzy, c-format
-msgid "Test %s."
-msgstr "n"
-msgid "succeeded"
-msgstr ""
-#: ../db/db.select/main.c:193
-msgid "SQL select statement"
-msgstr ""
-#: ../db/db.select/main.c:195
-#, fuzzy
-msgid "For example: 'select * from rybniky where kapri = 'hodne'"
-msgstr "के लिए"
-#: ../db/db.select/main.c:200
-#, fuzzy
-msgid "Name of file with SQL select statement(s)"
-msgstr "फ़ाइलनाम "
-#: ../db/db.select/main.c:246
-msgid "Describe query only (don't run it)"
-msgstr ""
-#: ../db/db.select/main.c:256
-msgid "Only test query, do not execute"
-msgstr ""
-#: ../db/db.select/main.c:263 ../db/db.databases/main.c:90
-#: ../db/db.copy/main.c:37 ../db/db.execute/main.c:116
-#: ../db/db.dropdb/main.c:71 ../db/db.createdb/main.c:71
-msgid "SQL"
-msgstr ""
-#: ../db/db.select/main.c:264
-msgid "Selects data from attribute table (performs SQL query statement(s))."
-msgstr ""
-#: ../db/db.connect/main.c:46 ../db/db.login/main.c:39
-#, fuzzy
-msgid "connection settings"
-msgstr "का"
-#: ../db/db.connect/main.c:48
-#, fuzzy
-msgid "Prints/sets general DB connection for current mapset."
-msgstr "के लिए a"
-#: ../db/db.connect/main.c:52
-#, fuzzy
-msgid "Print current connection parameters and exit"
-msgstr "छापें"
-#: ../db/db.connect/main.c:58
-#, fuzzy
-msgid "Check connection parameters, set if uninitialized, and exit"
-msgstr "छापें"
-#: ../db/db.connect/main.c:63
-#, fuzzy
-msgid "Set from default settings and exit"
-msgstr "सेट"
-#: ../db/db.connect/main.c:64
-#, fuzzy
-msgid "Overwrite current settings if initialized"
-msgstr "डाटाटाइप."
-#: ../db/db.connect/main.c:86
-#, fuzzy
-msgid "Default group of database users to which select privilege is granted"
-msgstr "डिफ़ॉल्ट समूह का है."
-#: ../db/db.connect/main.c:121
-#, fuzzy
-msgid "Database connection not defined. Run db.connect."
-msgstr "नहीं"
-#: ../db/db.connect/main.c:140 ../db/db.connect/main.c:162
-#, c-format
-msgid ""
-"Default driver / database set to:\n"
-"driver: %s\n"
-"database: %s"
-msgstr ""
-#: ../db/db.connect/main.c:147
-msgid "Default driver is not set"
-msgstr ""
-#: ../db/db.connect/main.c:150
-#, fuzzy
-msgid "Default database is not set"
-msgstr "का a"
-#: ../db/db.databases/main.c:55
-#, fuzzy
-msgid "Unable to list databases"
-msgstr "के लिए."
-#: ../db/db.databases/main.c:84
-#, fuzzy
-msgid "Location name"
-msgstr "n"
-#: ../db/db.databases/main.c:92
-#, fuzzy
-msgid "List all databases for a given driver and location."
-msgstr "सभी के लिए a."
-#: ../db/db.copy/main.c:38
-#, fuzzy
-msgid "Copy a table."
-msgstr "नक़ल"
-#: ../db/db.copy/main.c:40
-#, fuzzy
-msgid "Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."
-msgstr "नक़ल a नहीं पर."
-#: ../db/db.copy/main.c:46
-msgid "Input driver name"
-msgstr ""
-#: ../db/db.copy/main.c:52
-msgid "Input database name"
-msgstr ""
-#: ../db/db.copy/main.c:59
-#, fuzzy
-msgid "Input table name (only, if 'select' is not used)"
-msgstr "है नहीं"
-#: ../db/db.copy/main.c:65
-msgid "Output driver name"
-msgstr ""
-#: ../db/db.copy/main.c:71
-msgid "Output database name"
-msgstr ""
-#: ../db/db.copy/main.c:78
-msgid "Output table name"
-msgstr ""
-#: ../db/db.copy/main.c:87
-#, fuzzy
-msgid "Full select statement (only, if 'from_table' and 'where' is not used)"
-msgstr "है नहीं जी n"
-#: ../db/db.copy/main.c:88
-msgid "E.g.: SELECT dedek FROM starobince WHERE obec = 'Frimburg'"
-msgstr ""
-#: ../db/db.copy/main.c:96
-msgid "Cannot combine 'from_table' and 'select' options"
-msgstr ""
-#: ../db/db.copy/main.c:114
-msgid "Either 'from_table' or 'select' option must be given."
-msgstr ""
-#: ../db/db.copy/main.c:117
-msgid "Cannot combine 'select' and 'where' options"
-msgstr ""
-#: ../db/db.copy/main.c:127
-#, fuzzy
-msgid "Copy table failed"
-msgstr "नक़ल"
-#: ../db/db.login/main.c:40
-msgid "Sets user/password for driver/database."
-msgstr ""
-#: ../db/db.login/main.c:56
-#, fuzzy
-msgid "Username"
-msgstr "n"
-#: ../db/db.login/main.c:63
-msgid "Password"
-msgstr ""
-#: ../db/db.login/main.c:70
-#, fuzzy
-msgid "Unable to set user/password"
-msgstr "सेट"
-#: ../db/db.login/main.c:74
-#, c-format
-msgid "The password was stored in file (%s/dblogin)"
-msgstr ""
-#: ../db/db.execute/main.c:55
-#, fuzzy, c-format
-msgid ""
-"Unable to open file <%s> for reading.\n"
-"Details: %s"
-msgstr "के लिए"
-#: ../db/db.execute/main.c:81 ../db/db.execute/main.c:88
-#, fuzzy, c-format
-msgid "Error while executing: '%s'"
-msgstr "त्रुटि n"
-#: ../db/db.execute/main.c:117
-#, fuzzy
-msgid "Executes any SQL statement."
-msgstr "फ़ाइल"
-#: ../db/db.execute/main.c:118
-msgid "For SELECT statements use 'db.select'."
-msgstr ""
-#: ../db/db.execute/main.c:121
-#, fuzzy
-msgid "Name of file containing SQL statements"
-msgstr "फ़ाइल"
-#: ../db/db.execute/main.c:122
-#, fuzzy
-msgid "'-' to read from standard input"
-msgstr "नहीं"
-#: ../db/db.execute/main.c:142
-msgid "Ignore SQL errors and continue"
-msgstr ""
-#: ../db/db.execute/main.c:143
-#, fuzzy
-msgid "Errors"
-msgstr "त्रुटि"
-#: ../db/db.tables/main.c:86
-#, fuzzy
-msgid "Print tables and exit"
-msgstr "स्रोत"
-#: ../db/db.tables/main.c:90
-#, fuzzy
-msgid "System tables instead of user tables"
-msgstr "का"
-#: ../db/db.tables/main.c:96
-#, fuzzy
-msgid "Lists all tables for a given database."
-#: ../db/db.dropdb/main.c:72
-#, fuzzy
-msgid "Removes a database."
-msgstr "के लिए n"
-#: ../db/db.describe/main.c:103
-#, fuzzy
-msgid "Print column names only instead of full column descriptions"
-msgstr "का"
-#: ../db/db.describe/main.c:108
-#, fuzzy
-msgid "Print table structure"
-msgstr "स्रोत"
-#: ../db/db.describe/main.c:126
-#, fuzzy
-msgid "Describes a table in detail."
-msgstr "वर्णित करें a."
-#: ../db/db.columns/main.c:93
-#, fuzzy
-msgid "List all columns for a given table."
-#: ../db/db.createdb/main.c:72
-#, fuzzy
-msgid "Creates an empty database."
-msgstr "स्रोत"
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:1
-#, fuzzy
-msgid "Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector points map."
-msgstr "का"
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:4
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:4
-msgid "gazetteer"
-msgstr ""
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:5
-#, fuzzy
-msgid "Name of input uncompressed GNS file from NGA (with .txt extension)"
-msgstr "का"
-#: ../locale/scriptstrings/tv.list_to_translate.c:1
-#, fuzzy
-msgid "List registered maps of a space time vector dataset"
-msgstr "स्रोत"
-#: ../locale/scriptstrings/tv.list_to_translate.c:2
-#: ../locale/scriptstrings/t.remove_to_translate.c:3
-#: ../locale/scriptstrings/tr.import_to_translate.c:2
-#: ../locale/scriptstrings/t.create_to_translate.c:3
-#: ../locale/scriptstrings/tr.out.vtk_to_translate.c:2
-#: ../locale/scriptstrings/tr.list_to_translate.c:2
-#: ../locale/scriptstrings/t.list_to_translate.c:2
-#: ../locale/scriptstrings/tr.export_to_translate.c:2
-#: ../locale/scriptstrings/tr.to.rast3_to_translate.c:2
-#: ../locale/scriptstrings/t.sample_to_translate.c:2
-#: ../locale/scriptstrings/tr3.list_to_translate.c:2
-#: ../locale/scriptstrings/t.support_to_translate.c:3
-#, fuzzy
-msgid "dataset"
-msgstr "डाटाबेस नाम"
-#: ../locale/scriptstrings/tv.list_to_translate.c:3
-#: ../locale/scriptstrings/t.remove_to_translate.c:2
-#: ../locale/scriptstrings/tr.import_to_translate.c:3
-#: ../locale/scriptstrings/t.create_to_translate.c:2
-#: ../locale/scriptstrings/tr.out.vtk_to_translate.c:3
-#: ../locale/scriptstrings/tr.list_to_translate.c:3
-#: ../locale/scriptstrings/t.list_to_translate.c:3
-#: ../locale/scriptstrings/tr.export_to_translate.c:3
-#: ../locale/scriptstrings/tr.to.rast3_to_translate.c:3
-#: ../locale/scriptstrings/t.sample_to_translate.c:3
-#: ../locale/scriptstrings/tr3.list_to_translate.c:3
-#: ../locale/scriptstrings/t.support_to_translate.c:2
-#, fuzzy
-msgid "spacetime"
-msgstr "गामा."
-#: ../locale/scriptstrings/tv.list_to_translate.c:6
-#: ../locale/scriptstrings/tv.what.rast_to_translate.c:5
-#, fuzzy
-msgid "Name of a space time vector dataset"
-msgstr "का"
-#: ../locale/scriptstrings/tv.list_to_translate.c:7
-#: ../locale/scriptstrings/tr.list_to_translate.c:7
-#: ../locale/scriptstrings/tr3.list_to_translate.c:7
-#, fuzzy
-msgid "Order the space time dataset by category."
-msgstr "स्रोत"
-#: ../locale/scriptstrings/tv.list_to_translate.c:8
-#: ../locale/scriptstrings/tr.list_to_translate.c:8
-#: ../locale/scriptstrings/tr3.list_to_translate.c:8
-#, fuzzy
-msgid "Select columns to be printed to stdout"
-msgstr "ज़ेड"
-#: ../locale/scriptstrings/tv.list_to_translate.c:9
-#: ../locale/scriptstrings/tr.extract_to_translate.c:6
-#: ../locale/scriptstrings/tr.list_to_translate.c:9
-#: ../locale/scriptstrings/t.list_to_translate.c:8
-#: ../locale/scriptstrings/tr3.extract_to_translate.c:6
-msgid "A where statement for selected listing without \"WHERE\" e.g: \"start_time < '2001-01-01' AND end_time > '2001-01-01'\""
-msgstr ""
-#: ../locale/scriptstrings/tv.list_to_translate.c:10
-#: ../locale/scriptstrings/tr.list_to_translate.c:10
-#: ../locale/scriptstrings/tr3.list_to_translate.c:10
-msgid "Which method should be used for data listing"
-msgstr ""
-#: ../locale/scriptstrings/tv.list_to_translate.c:11
-#: ../locale/scriptstrings/tr.list_to_translate.c:11
-#: ../locale/scriptstrings/t.list_to_translate.c:10
-#: ../locale/scriptstrings/tr3.list_to_translate.c:11
-msgid "The field separator character between the columns, default is tabular \"\t\""
-msgstr ""
-#: ../locale/scriptstrings/tv.list_to_translate.c:12
-#: ../locale/scriptstrings/tr.list_to_translate.c:12
-#: ../locale/scriptstrings/tr.univar_to_translate.c:8
-#: ../locale/scriptstrings/t.sample_to_translate.c:12
-#: ../locale/scriptstrings/tr3.list_to_translate.c:12
-#, fuzzy
-msgid "Print column names"
-msgstr "ज़ेड"
-#: ../locale/scriptstrings/t.time.abs_to_translate.c:1
-msgid "Set the absolute valid time interval for maps of type raster, vector and raster3d"
-msgstr ""
-#: ../locale/scriptstrings/t.time.abs_to_translate.c:3
-#: ../locale/scriptstrings/t.time.rel_to_translate.c:3
-msgid "absolute"
-msgstr ""
-#: ../locale/scriptstrings/t.time.abs_to_translate.c:7
-#: ../locale/scriptstrings/t.time.rel_to_translate.c:7
-#, fuzzy
-msgid "Name(s) of existing raster, raster3d or vector map(s)"
-msgstr "का"
-#: ../locale/scriptstrings/t.time.abs_to_translate.c:8
-#: ../locale/scriptstrings/tv.unregister_to_translate.c:5
-#: ../locale/scriptstrings/tv.register_to_translate.c:6
-#: ../locale/scriptstrings/t.time.rel_to_translate.c:8
-msgid "Id(s)/Name(s) of existing vector map layer or the identifier \"file\" in case the layer definition is in the input file"
-msgstr ""
-#: ../locale/scriptstrings/t.time.abs_to_translate.c:9
-#: ../locale/scriptstrings/tv.register_to_translate.c:7
-#: ../locale/scriptstrings/t.time.rel_to_translate.c:9
-msgid "Input file with vector map names, one per line. Additionally the layer, the start time and the end time can be specified per line"
-msgstr ""
-#: ../locale/scriptstrings/t.time.abs_to_translate.c:10
-msgid "The valid start date and time of the first raster map. Time format is \"yyyy-mm-dd HH:MM:SS\" or only \"yyyy-mm-dd\", or \"file\" in case the start time is located in the input file"
-msgstr ""
-#: ../locale/scriptstrings/t.time.abs_to_translate.c:11
-msgid "The valid end date and time of the first raster map. Time format is \"yyyy-mm-dd HH:MM:SS\" or only \"yyyy-mm-dd\", or \"file\" in case the start time is located in the input file"
-msgstr ""
-#: ../locale/scriptstrings/t.time.abs_to_translate.c:12
-msgid "Time increment between maps for valid time interval creation. Interval format: NNN seconds, minutes, hours, days, weeks, months, years"
-msgstr ""
-#: ../locale/scriptstrings/t.time.abs_to_translate.c:13
-#: ../locale/scriptstrings/t.time.rel_to_translate.c:14
-#, fuzzy
-msgid "Input map type"
-msgstr "है n"
-#: ../locale/scriptstrings/t.time.abs_to_translate.c:14
-#: ../locale/scriptstrings/tv.register_to_translate.c:12
-#: ../locale/scriptstrings/t.time.rel_to_translate.c:15
-#: ../locale/scriptstrings/tr3.register_to_translate.c:11
-#: ../locale/scriptstrings/tr.register_to_translate.c:11
-#, fuzzy
-msgid "The field separator character of the input file"
-msgstr "फील्ड"
-#: ../locale/scriptstrings/t.time.abs_to_translate.c:15
-#: ../locale/scriptstrings/tv.register_to_translate.c:13
-#: ../locale/scriptstrings/t.time.rel_to_translate.c:16
-#: ../locale/scriptstrings/tr3.register_to_translate.c:12
-#: ../locale/scriptstrings/tr.register_to_translate.c:12
-msgid "Create an interval (start and end time) in case an increment is provided"
-msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:1
-#, fuzzy
-msgid "Display the HTML manual pages of GRASS modules"
-msgstr "संख्या का"
-#: ../locale/scriptstrings/g.manual_to_translate.c:3
-msgid "manual"
-msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:4
-msgid "help"
-msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:5
-#, fuzzy
-msgid "Display index"
-msgstr "n"
-#: ../locale/scriptstrings/g.manual_to_translate.c:6
-msgid "Display as MAN text page instead of HTML page in browser"
-msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:7
-#, fuzzy
-msgid "Manual entry to be displayed"
-msgstr "का"
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
-#, fuzzy
-msgid "Calculates univariate statistics from a raster map based on vector polygon map and uploads statistics to new attribute columns."
-msgstr "का a."
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
-msgid "Continue if upload column(s) already exist"
-msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
-#, fuzzy
-msgid "Name of input raster map to calculate statistics from"
-msgstr "का रखे हुए"
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:8
-#, fuzzy
-msgid "Column prefix for new attribute columns"
-msgstr "के लिए"
-#: ../locale/scriptstrings/t.topology_to_translate.c:1
-#, fuzzy
-msgid "List and modify temporal topology of a space time dataset"
-msgstr "छापें माट्रिक्स"
-#: ../locale/scriptstrings/t.topology_to_translate.c:2
-#: ../locale/scriptstrings/t.info_to_translate.c:2
-msgid "spacetime dataset"
-msgstr ""
-#: ../locale/scriptstrings/t.topology_to_translate.c:4
-#, fuzzy
-msgid "Name of an existing space time dataset"
-msgstr "का"
-#: ../locale/scriptstrings/t.topology_to_translate.c:5
-#, fuzzy
-msgid "Type of the space time dataset, default is space time raster dataset (strds)"
-msgstr "का"
-#: ../locale/scriptstrings/t.topology_to_translate.c:6
-#, fuzzy
-msgid "Print temporal relation matrix and exit"
-#: ../locale/scriptstrings/t.remove_to_translate.c:1
-#, fuzzy
-msgid "Remove space time or map datasets from temporal database"
-#: ../locale/scriptstrings/t.remove_to_translate.c:5
-#, fuzzy
-msgid "Name(s) of the space time or map dataset to be removed from the temporal database"
-msgstr "का"
-#: ../locale/scriptstrings/t.remove_to_translate.c:6
-#: ../locale/scriptstrings/tr.unregister_to_translate.c:5
-msgid "Input file with raster map names, one per line"
-msgstr ""
-#: ../locale/scriptstrings/t.remove_to_translate.c:7
-#: ../locale/scriptstrings/t.create_to_translate.c:7
-#: ../locale/scriptstrings/t.support_to_translate.c:7
-msgid "Type of the space time dataset, default is strds"
-msgstr ""
-#: ../locale/scriptstrings/r.blend_to_translate.c:1
-msgid "Blends color components of two raster maps by a given ratio."
-msgstr ""
-#: ../locale/scriptstrings/r.blend_to_translate.c:3
-#, fuzzy
-msgid "Name of first raster map for blending"
-msgstr "का"
-#: ../locale/scriptstrings/r.blend_to_translate.c:4
-#, fuzzy
-msgid "Name of second raster map for blending"
-msgstr "का"
-#: ../locale/scriptstrings/r.blend_to_translate.c:5
-#, fuzzy
-msgid "Prefix for red, green and blue output raster maps containing"
-msgstr "का"
-#: ../locale/scriptstrings/r.blend_to_translate.c:6
-#, fuzzy
-msgid "Percentage weight of first map for color blending"
-msgstr "का"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:1
-#, fuzzy
-msgid "Displays thematic vector map"
-msgstr "का "
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:4
-msgid "thematic"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:5
-msgid "legend"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:6
-#, fuzzy
-msgid "Name of attribute column to use for thematic display (must be numeric)"
-msgstr "के लिए"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:7
-#, fuzzy
-msgid "Type of thematic display"
-msgstr "का"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:8
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:10
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:13
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:22
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:42
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:48
-msgid "Theme"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:9
-msgid "Thematic divisions of data for display"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:11
-msgid "Break points for custom breaks option"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:12
-msgid "Separate values by spaces (0 10 20 30 ...)"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:14
-#, fuzzy
-msgid "Vector point icon for point data"
-msgstr "छोटा करें बिन्दु"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:16
-#, fuzzy
-msgid "Icon size for point data"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:17
-msgid "Minimum icon size/line width for graduated points/lines)"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:19
-msgid "Maximum icon size/line width for graduated points and lines"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:21
-#, fuzzy
-msgid "Number of classes for interval theme (integer)"
-msgstr "का फ़िल्टर"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:23
-#, fuzzy
-msgid "Color scheme for graduated color mapping"
-msgstr "के लिए"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:24
-#, fuzzy
-msgid "Select 'single_color' for graduated point/line display"
-msgstr "के लिए"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:26
-#, fuzzy
-msgid "Color for graduated points map"
-msgstr "के लिए"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:27
-#, fuzzy
-msgid "GRASS named color or R:G:B triplet. Set color scheme to single color"
-msgstr "a R जी"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:29
-#, fuzzy
-msgid "Color for graduated lines or point/area outlines"
-msgstr "के लिए"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:30
-#, fuzzy
-msgid "GRASS named color or R:G:B triplet. Set color scheme to single color."
-msgstr "a R जी"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:32
-#, fuzzy
-msgid "Beginning color for custom color gradient"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:33
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:36
-#, fuzzy
-msgid "Must be expressed as R:G:B triplet"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:35
-#, fuzzy
-msgid "Ending color for custom color gradient"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:38
-msgid "Select WXGUI display monitor for legend"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:39
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:54
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:56
-msgid "Misc"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:40
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:45
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:47
-msgid "Files"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:41
-msgid "Save thematic map commands to group file for GIS Manager"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:43
-msgid "Root for the name of psmap instruction files to be in current directory"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:44
-msgid "If not set, no psmap instruction files will be created)"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:46
-msgid "Name of group file where thematic map commands will be saved"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:49
-msgid "Create graphic legend in x11 display monitor"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:51
-msgid "Only draw fills (no outlines) for areas and points"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:53
-msgid "Update color values to GRASSRGB column in attribute table"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:55
-msgid "Output legend for GIS Manager (for scripting use only)"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:57
-msgid "Use math notation brackets in legend"
-msgstr ""
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:1
-#, fuzzy
-msgid "Creates shaded relief map from an elevation map (DEM)."
-msgstr "a बीटा."
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:3
-#: ../locale/scriptstrings/r.plane_to_translate.c:3
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:3
-#, fuzzy
-msgid "elevation"
-msgstr "नहीं n"
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:4
-#, fuzzy
-msgid "Name of input elevation raster map"
-msgstr "का"
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:5
-#, fuzzy
-msgid "Altitude of the sun in degrees above the horizon"
-msgstr "का कोण"
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:6
-#, fuzzy
-msgid "Azimuth of the sun in degrees to the east of north"
-msgstr "का उत्तर कोण"
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:7
-#, fuzzy
-msgid "Factor for exaggerating relief"
-msgstr "के लिए ढाल"
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:8
-#, fuzzy
-msgid "Scale factor for converting horizontal units to elevation units"
-msgstr "ओरिजिन है"
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:9
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:11
-#, fuzzy
-msgid "Scaling"
-msgstr "का"
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:10
-msgid "Set scaling factor (applies to lat./long. locations only, none: scale=1)"
-msgstr ""
-#: ../locale/scriptstrings/v.db.droprow_to_translate.c:1
-#, fuzzy
-msgid "Removes a vector feature from a vector map through attribute selection."
-msgstr "के लिए a"
-#: ../locale/scriptstrings/tv.unregister_to_translate.c:1
-#, fuzzy
-msgid "Unregister vector map(s) from a specific or from all space time vector dataset in which it is registered"
-msgstr "स्रोत"
-#: ../locale/scriptstrings/tv.unregister_to_translate.c:2
-#: ../locale/scriptstrings/tv.register_to_translate.c:2
-#, fuzzy
-msgid "spacetime vector dataset"
-msgstr "का"
-#: ../locale/scriptstrings/tv.unregister_to_translate.c:4
-msgid "Name of an existing space time vector dataset. If no name is provided the vector map(s) are unregistered from all space time datasets in which they are registered."
-msgstr ""
-#: ../locale/scriptstrings/tv.unregister_to_translate.c:6
-#, fuzzy
-msgid "Input file with vector map names, one per line"
-msgstr "का"
-#: ../locale/scriptstrings/tv.unregister_to_translate.c:7
-#, fuzzy
-msgid "Name(s) of existing vector map(s) to unregister"
-msgstr "का"
-#: ../locale/scriptstrings/d.redraw_to_translate.c:1
-msgid "Redraws the content of currently selected monitor."
-msgstr ""
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:1
-msgid "Sets color rules based on stddev from a raster map's mean value."
-msgstr ""
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
-#, fuzzy
-msgid "Color using standard deviation bands"
-msgstr "के लिए n n"
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:5
-msgid "Force center at zero"
-msgstr ""
-#: ../locale/scriptstrings/tr.aggregate.ds_to_translate.c:1
-msgid "Aggregated data of an existing space time raster dataset using the temporal topology of a second space time dataset"
-msgstr ""
-#: ../locale/scriptstrings/tr.aggregate.ds_to_translate.c:2
-#: ../locale/scriptstrings/tr.extract_to_translate.c:2
-#: ../locale/scriptstrings/tr.aggregate_to_translate.c:2
-#: ../locale/scriptstrings/tr.unregister_to_translate.c:2
-#: ../locale/scriptstrings/tr.univar_to_translate.c:2
-#: ../locale/scriptstrings/tr.series_to_translate.c:2
-#: ../locale/scriptstrings/tr.register_to_translate.c:2
-#, fuzzy
-msgid "spacetime raster dataset"
-msgstr "का"
-#: ../locale/scriptstrings/tr.aggregate.ds_to_translate.c:5
-#: ../locale/scriptstrings/tr.import_to_translate.c:7
-#: ../locale/scriptstrings/tr.extract_to_translate.c:5
-#: ../locale/scriptstrings/tr.aggregate_to_translate.c:5
-#: ../locale/scriptstrings/tr.out.vtk_to_translate.c:7
-#: ../locale/scriptstrings/tr.list_to_translate.c:6
-#: ../locale/scriptstrings/tr.univar_to_translate.c:5
-#: ../locale/scriptstrings/tr.export_to_translate.c:6
-#: ../locale/scriptstrings/tr.to.rast3_to_translate.c:6
-#, fuzzy
-msgid "Name of a space time raster dataset"
-msgstr "का"
-#: ../locale/scriptstrings/tr.aggregate.ds_to_translate.c:6
-msgid "The time intervals from this space time dataset (raster, vector or raster3d) are used for aggregation computation."
-msgstr ""
-#: ../locale/scriptstrings/tr.aggregate.ds_to_translate.c:7
-#, fuzzy
-msgid "Type of the aggregation space time dataset, default is strds"
-msgstr "का"
-#: ../locale/scriptstrings/tr.aggregate.ds_to_translate.c:8
-#: ../locale/scriptstrings/tr.extract_to_translate.c:8
-#: ../locale/scriptstrings/tr.aggregate_to_translate.c:7
-#, fuzzy
-msgid "Name of the output space time raster dataset"
-msgstr "का"
-#: ../locale/scriptstrings/tr.aggregate.ds_to_translate.c:9
-#: ../locale/scriptstrings/tr.aggregate_to_translate.c:8
-#: ../locale/scriptstrings/tr.series_to_translate.c:6
-#, fuzzy
-msgid "Aggregate operation to be peformed on the raster maps"
-msgstr "का"
-#: ../locale/scriptstrings/tr.aggregate.ds_to_translate.c:10
-#: ../locale/scriptstrings/tr.aggregate_to_translate.c:9
-msgid "The method to be used for sampling the input dataset"
-msgstr ""
-#: ../locale/scriptstrings/tr.aggregate.ds_to_translate.c:11
-#: ../locale/scriptstrings/tr.extract_to_translate.c:9
-#: ../locale/scriptstrings/tr.aggregate_to_translate.c:10
-#, fuzzy
-msgid "Base name of the new created raster maps"
-msgstr "का"
-#: ../locale/scriptstrings/tr.aggregate.ds_to_translate.c:12
-#: ../locale/scriptstrings/tr.extract_to_translate.c:10
-#: ../locale/scriptstrings/tr.aggregate_to_translate.c:11
-#: ../locale/scriptstrings/tr3.extract_to_translate.c:10
-#, fuzzy
-msgid "Register Null maps"
-msgstr "का"
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
-#, fuzzy
-msgid "Reconnects vectors to a new database."
-msgstr "के लिए n"
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
-#, fuzzy
-msgid "Name of old database"
-msgstr "का"
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:6
-#, fuzzy
-msgid "Name of new database"
-msgstr "का"
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:7
-#, fuzzy
-msgid "Old database schema"
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:8
-#, fuzzy
-msgid "New database schema"
-#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:1
-#, fuzzy
-msgid "Renames a column in the attribute table connected to a given vector map."
-msgstr "का"
-#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:5
-msgid "Old and new name of the column (old,new)"
-msgstr ""
-#: ../locale/scriptstrings/tr.import_to_translate.c:1
-#, fuzzy
-msgid "Import space time raster dataset"
-msgstr "का"
-#: ../locale/scriptstrings/tr.import_to_translate.c:6
-#, fuzzy
-msgid "Name of a space time raster dataset archive file"
-msgstr "का"
-#: ../locale/scriptstrings/tr.import_to_translate.c:8
-msgid "Path to the extraction directory"
-msgstr ""
-#: ../locale/scriptstrings/tr.import_to_translate.c:9
-#: ../locale/scriptstrings/t.create_to_translate.c:9
-msgid "Title of the new space time dataset"
-msgstr ""
-#: ../locale/scriptstrings/tr.import_to_translate.c:10
-#: ../locale/scriptstrings/t.create_to_translate.c:10
-msgid "Description of the new space time dataset"
-msgstr ""
-#: ../locale/scriptstrings/tr.import_to_translate.c:11
-#, fuzzy
-msgid "Link the raster files using r.external"
-msgstr "नहीं"
-#: ../locale/scriptstrings/tr.import_to_translate.c:12
-#, fuzzy
-msgid "Extend location extents based on new dataset"
-msgstr "चालू"
-#: ../locale/scriptstrings/tr.import_to_translate.c:13
-#, fuzzy
-msgid "verride projection (use location's projection)"
-msgstr "का"
-#, fuzzy
-msgid "Create a space time dataset"
-msgstr "स्रोत"
-#: ../locale/scriptstrings/t.create_to_translate.c:4
-#: ../locale/scriptstrings/t.support_to_translate.c:4
-#, fuzzy
-msgid "create"
-msgstr "का"
-#: ../locale/scriptstrings/t.create_to_translate.c:5
-#, fuzzy
-msgid "Name of the new space time dataset"
-msgstr "का"
-#: ../locale/scriptstrings/t.create_to_translate.c:6
-#: ../locale/scriptstrings/t.support_to_translate.c:6
-msgid "The semantic type of the space time dataset"
-msgstr ""
-#: ../locale/scriptstrings/t.create_to_translate.c:8
-#: ../locale/scriptstrings/t.list_to_translate.c:9
-msgid "The temporal type of the space time dataset, default is absolute"
-msgstr ""
-#: ../locale/scriptstrings/r.unpack_to_translate.c:1
-msgid "Unpacks a raster map packed with r.pack."
-msgstr ""
-#: ../locale/scriptstrings/r.unpack_to_translate.c:4
-#: ../locale/scriptstrings/r.pack_to_translate.c:4
-msgid "copying"
-msgstr ""
-#: ../locale/scriptstrings/r.unpack_to_translate.c:5
-#, fuzzy
-msgid "Name of input pack file"
-msgstr "का"
-#: ../locale/scriptstrings/r.unpack_to_translate.c:6
-#, fuzzy
-msgid "Name for output raster map (default: taken from input file internals)"
-msgstr "शीर्षक"
-#: ../locale/scriptstrings/r.unpack_to_translate.c:7
-#, fuzzy
-msgid "Override projection check (use current location's projection)"
-msgstr "का"
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:1
-#, fuzzy
-msgid "Imports SPOT VGT NDVI data into a raster map."
-msgstr "a a"
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:4
-msgid "Also import quality map (SM status map layer) and filter NDVI map"
-msgstr ""
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:5
-#, fuzzy
-msgid "Name of input SPOT VGT NDVI HDF file"
-msgstr "का"
-#: ../locale/scriptstrings/d.polar_to_translate.c:1
-msgid "Draws polar diagram of angle map such as aspect or flow directions"
-msgstr ""
-#: ../locale/scriptstrings/d.polar_to_translate.c:3
-#: ../locale/scriptstrings/d.correlate_to_translate.c:4
-#, fuzzy
-msgid "diagram"
-msgstr "गामा."
-#: ../locale/scriptstrings/d.polar_to_translate.c:4
-#, fuzzy
-msgid "Name of raster angle map"
-msgstr "का"
-#: ../locale/scriptstrings/d.polar_to_translate.c:5
-msgid "Pixel value to be interpreted as undefined (different from NULL)"
-msgstr ""
-#: ../locale/scriptstrings/d.polar_to_translate.c:6
-#, fuzzy
-msgid "Name for optional EPS output file"
-msgstr "का"
-#: ../locale/scriptstrings/d.polar_to_translate.c:7
-msgid "Plot using Xgraph"
-msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:1
-#, fuzzy
-msgid "Allows to join a table to a vector map table."
-msgstr "का"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:5
-#, fuzzy
-msgid "Vector map to which to join other table"
-msgstr "का के लिए संपादन (_E)"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:6
-msgid "layer,column"
-msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:7
-#, fuzzy
-msgid "Layer where to join"
-msgstr "नहीं"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:8
-#, fuzzy
-msgid "column"
-msgstr "नहीं"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:9
-msgid "Identifier column (e.g.: cat) in the vector table to be used for join"
-msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:10
-#, fuzzy
-msgid "Other table name"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:11
-#, fuzzy
-msgid "ocolumn"
-msgstr "नहीं"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:12
-msgid "Identifier column (e.g.: id) in the other table used for join"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:1
-msgid "Creates a MASK for limiting raster operation."
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:3
-#, fuzzy
-msgid "mask"
-msgstr "समूह"
-#: ../locale/scriptstrings/r.mask_to_translate.c:4
-#, fuzzy
-msgid "Name of raster map to use as mask"
-msgstr "का"
-#: ../locale/scriptstrings/r.mask_to_translate.c:5
-msgid "Category values to use for mask (format: 1 2 3 thru 7 *)"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:7
-msgid "Create inverse mask from specified 'maskcats' list"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:9
-msgid "Remove existing mask (overrides other options)"
-msgstr ""
-#: ../locale/scriptstrings/tv.what.rast_to_translate.c:1
-#, fuzzy
-msgid "Uploads raster map values at spatial and temporal positions of vector points to the tables. The maps are registered in space time datasets"
-msgstr "पर का"
-#: ../locale/scriptstrings/tv.what.rast_to_translate.c:2
-#, fuzzy
-msgid "space time vector dataset"
-msgstr "का"
-#: ../locale/scriptstrings/tv.what.rast_to_translate.c:3
-#, fuzzy
-msgid "space time raster dataset"
-msgstr "का"
-#: ../locale/scriptstrings/tv.what.rast_to_translate.c:6
-#, fuzzy
-msgid "The space time raster dataset to use"
-msgstr "का"
-#: ../locale/scriptstrings/tv.what.rast_to_translate.c:7
-msgid "Name of the vector column to be created and to store sampled raster values. The use of a column name forces tv.what.rast to sample only values from the first map found in an interval. Otherwise the raster map names are used as column names."
-msgstr ""
-#: ../locale/scriptstrings/tv.what.rast_to_translate.c:8
-msgid "A where statement for attribute selection related to the input dataset without \"WHERE\" e.g: \"cat < 200\""
-msgstr ""
-#: ../locale/scriptstrings/tv.what.rast_to_translate.c:9
-msgid "A where statement for temporal selection related to the input dataset without \"WHERE\" e.g: \"start_time < '2001-01-01' AND end_time > '2001-01-01'\""
-msgstr ""
-#: ../locale/scriptstrings/tv.what.rast_to_translate.c:10
-#, fuzzy
-msgid "The method to be used for temporal sampling"
-msgstr "का"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:1
-#, fuzzy
-msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
-msgstr "का a."
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:4
-msgid "Extended statistics (quartiles and 90th percentile)"
-msgstr ""
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:5
-#, fuzzy
-msgid "Print stats in shell script style"
-msgstr "छापें"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
-#, fuzzy
-msgid "Name of attribute column on which to calculate statistics (must be numeric)"
-msgstr "के लिए"
-#: ../locale/scriptstrings/v.report_to_translate.c:1
-#, fuzzy
-msgid "Reports geometry statistics for vector maps."
-msgstr "के लिए."
-#: ../locale/scriptstrings/v.report_to_translate.c:5
-#, fuzzy
-msgid "Reverse sort the result"
-msgstr "ट्रेस"
-#: ../locale/scriptstrings/v.report_to_translate.c:6
-#, fuzzy
-msgid "Sort the result"
-msgstr "का"
-#: ../locale/scriptstrings/v.report_to_translate.c:7
-#, fuzzy
-msgid "Value to calculate"
-msgstr "के लिए"
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:1
-msgid "Imports ASCII x,y[,z] coordinates as a series of lines."
-msgstr ""
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:4
-msgid "Create a 3D line from 3 column data"
-msgstr ""
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:5
-#, fuzzy
-msgid "Name of input file (or \"-\" to read from stdin)"
-msgstr "उत्तर पूर्व"
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:1
-#, fuzzy
-msgid "Imports E00 file into a vector map."
-msgstr "का"
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:4
-#, fuzzy
-msgid "Name of input E00 file"
-msgstr "का"
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
-msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
-msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
-msgid "Lesser value option that sets the <= area size limit [hectares]"
-msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:6
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:8
-#, fuzzy
-msgid "Area"
-msgstr "n"
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:7
-msgid "Greater value option that sets the >= area size limit [hectares]"
-msgstr ""
-#, fuzzy
-msgid "Register vector maps in a space time vector dataset"
-msgstr "स्रोत"
-#: ../locale/scriptstrings/tv.register_to_translate.c:4
-#, fuzzy
-msgid "Name of an existing space time vector dataset"
-msgstr "का"
-#: ../locale/scriptstrings/tv.register_to_translate.c:5
-#, fuzzy
-msgid "Name(s) of existing vector map(s)"
-msgstr "का"
-#: ../locale/scriptstrings/tv.register_to_translate.c:8
-msgid "The valid start date and time of the first vector map, in case the map has no valid time (format absolute: \"yyyy-mm-dd HH:MM:SS\", format relative 5.0). Use \"file\" as identifier in case the start time is located in an input file"
-msgstr ""
-#: ../locale/scriptstrings/tv.register_to_translate.c:9
-msgid "The valid end date and time of the first vector map. Absolute time format is \"yyyy-mm-dd HH:MM:SS\" and \"yyyy-mm-dd\", relative time format id double. Use \"file\" as identifier in case the end time is located in the input file"
-msgstr ""
-#: ../locale/scriptstrings/tv.register_to_translate.c:10
-#: ../locale/scriptstrings/t.time.rel_to_translate.c:12
-#: ../locale/scriptstrings/tr3.register_to_translate.c:9
-#: ../locale/scriptstrings/tr.register_to_translate.c:9
-msgid "The unit of the relative time"
-msgstr ""
-#: ../locale/scriptstrings/tv.register_to_translate.c:11
-#: ../locale/scriptstrings/tr3.register_to_translate.c:10
-#: ../locale/scriptstrings/tr.register_to_translate.c:10
-msgid "Time increment between maps for valid time interval creation (format absolute: NNN seconds, minutes, hours, days, weeks, months, years; format relative is integer: 5), or \"file\" in case the increment is located in an input file"
-msgstr ""
-msgid "Extract a subset of a space time raster dataset"
-msgstr ""
-#: ../locale/scriptstrings/tr.extract_to_translate.c:7
-msgid "The r.mapcalc expression assigned to all extracted raster maps"
-msgstr ""
-#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:1
-#, fuzzy
-msgid "Drops a column from the attribute table connected to a given vector map."
-msgstr "का"
-#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:5
-#, fuzzy
-msgid "Name of attribute column(s) to drop"
-msgstr "का"
-msgid "Create a new space time raster dataset from the aggregated data of an existing space time raster dataset"
-msgstr ""
-#: ../locale/scriptstrings/tr.aggregate_to_translate.c:6
-msgid "The aggregation granularity, format absolue time \"x years, x months, x weeks, x days, x hours, x minutes, x seconds\" or a double value for relative time"
-msgstr ""
-#: ../locale/scriptstrings/v.krige_to_translate.c:1
-msgid "Performs ordinary or block kriging for vector maps."
-msgstr ""
-#: ../locale/scriptstrings/v.krige_to_translate.c:5
-msgid "kriging"
-msgstr ""
-#: ../locale/scriptstrings/v.krige_to_translate.c:6
-#, fuzzy
-msgid "Name of point vector map containing sample data"
-msgstr "का"
-#: ../locale/scriptstrings/v.krige_to_translate.c:7
-#, fuzzy
-msgid "Name of attribute column with numerical value to be interpolated"
-msgstr "का के लिए"
-#: ../locale/scriptstrings/v.krige_to_translate.c:9
-msgid "If omitted, will be <input name>_kriging"
-msgstr ""
-#: ../locale/scriptstrings/v.krige_to_translate.c:10
-msgid "R package to use"
-msgstr ""
-#: ../locale/scriptstrings/v.krige_to_translate.c:11
-msgid "Variogram model(s)"
-msgstr ""
-#: ../locale/scriptstrings/v.krige_to_translate.c:12
-msgid "Leave empty to test all models (requires automap)"
-msgstr ""
-#: ../locale/scriptstrings/v.krige_to_translate.c:13
-msgid "Block size (square block)"
-msgstr ""
-#: ../locale/scriptstrings/v.krige_to_translate.c:14
-msgid "Block size. Used by block kriging."
-msgstr ""
-#: ../locale/scriptstrings/v.krige_to_translate.c:15
-#, fuzzy
-msgid "Range value"
-msgstr "n"
-#: ../locale/scriptstrings/v.krige_to_translate.c:16
-#: ../locale/scriptstrings/v.krige_to_translate.c:18
-#: ../locale/scriptstrings/v.krige_to_translate.c:20
-msgid "Automatically fixed if not set"
-msgstr ""
-#: ../locale/scriptstrings/v.krige_to_translate.c:17
-msgid "Nugget value"
-msgstr ""
-#: ../locale/scriptstrings/v.krige_to_translate.c:19
-#, fuzzy
-msgid "Sill value"
-msgstr "ओवरले"
-#: ../locale/scriptstrings/v.krige_to_translate.c:21
-#, fuzzy
-msgid "Name for output variance raster map"
-msgstr "का"
-#: ../locale/scriptstrings/v.krige_to_translate.c:22
-msgid "If omitted, will be <input name>_kriging_var"
-msgstr ""
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
-#, fuzzy
-msgid "Imports attribute tables in various formats."
-msgstr "का."
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:4
-msgid "Table file to be imported or DB connection string"
-msgstr ""
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:5
-msgid "Table name of SQL DB table"
-msgstr ""
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:6
-#, fuzzy
-msgid "Name for output table"
-msgstr "के लिए"
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:7
-#, fuzzy
-msgid "Name for auto-generated unique key column"
-msgstr "का के लिए"
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:1
-#, fuzzy
-msgid "Adds one or more columns to the attribute table connected to a given vector map."
-msgstr "का"
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
-#, fuzzy
-msgid "Layer number where to add column(s)"
-msgstr "नहीं"
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:6
-msgid "Name and type of the new column(s) ('name type [,name type, ...]')"
-msgstr ""
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
-msgid "Data types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE"
-msgstr ""
-#: ../locale/scriptstrings/r.pack_to_translate.c:1
-msgid "Packs up a raster map and support files for copying."
-msgstr ""
-#: ../locale/scriptstrings/r.pack_to_translate.c:5
-#, fuzzy
-msgid "Name of raster map to pack up"
-msgstr "का"
-#: ../locale/scriptstrings/r.pack_to_translate.c:6
-#, fuzzy
-msgid "Name for output file (default is <input>.pack)"
-msgstr "शीर्षक"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:1
-msgid "Performs auto-balancing of colors for LANDSAT images."
-msgstr ""
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:4
-#, fuzzy
-msgid "colors"
-msgstr "n"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:5
-#, fuzzy
-msgid "Name of LANDSAT red channel"
-msgstr "का"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:6
-msgid "Name of LANDSAT green channel"
-msgstr ""
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:7
-msgid "Name of LANDSAT blue channel"
-msgstr ""
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:8
-msgid "Cropping intensity (upper brightness level)"
-msgstr ""
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:9
-msgid "Extend colors to full range of data on each channel"
-msgstr ""
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:10
-msgid "Preserve relative colors, adjust brightness only"
-msgstr ""
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:11
-#, fuzzy
-msgid "Reset to standard color range"
-msgstr "रखें"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:1
-msgid "Displays spectral response at user specified locations in group or images."
-msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:4
-#, fuzzy
-msgid "multispectral"
-msgstr "के लिए ज़ेड"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:5
-#, fuzzy
-msgid "Name for output PNG image"
-msgstr "के लिए"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:6
-#, fuzzy
-msgid "Label with coordinates instead of numbering"
-msgstr "का"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:7
-#, fuzzy
-msgid "Use gnuplot for display"
-msgstr "के लिए"
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
-msgid "Exports a raster map to a text file as x,y,z values based on cell centers."
-msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:1
-#, fuzzy
-msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
-msgstr "a बिन्दु."
-#: ../locale/scriptstrings/r.plane_to_translate.c:4
-#, fuzzy
-msgid "Dip of plane in degrees"
-msgstr "कोण कोण"
-#: ../locale/scriptstrings/r.plane_to_translate.c:5
-#, fuzzy
-msgid "Azimuth of the plane in degrees"
-#: ../locale/scriptstrings/r.plane_to_translate.c:6
-#, fuzzy
-msgid "Easting coordinate of a point on the plane"
-msgstr "एक."
-#: ../locale/scriptstrings/r.plane_to_translate.c:7
-#, fuzzy
-msgid "Northing coordinate of a point on the plane"
-msgstr "एक."
-#: ../locale/scriptstrings/r.plane_to_translate.c:8
-#, fuzzy
-msgid "Elevation coordinate of a point on the plane"
-msgstr "एक."
-#: ../locale/scriptstrings/r.plane_to_translate.c:9
-#, fuzzy
-msgid "Type of the raster map to be created"
-msgstr "का"
-msgid "Set the relative valid time point or interval for maps of type raster, vector and raster3d"
-msgstr ""
-#: ../locale/scriptstrings/t.time.rel_to_translate.c:10
-msgid "The valid integer start value for all maps, or the identifier \"file\" in case the start time is located in the input file"
-msgstr ""
-#: ../locale/scriptstrings/t.time.rel_to_translate.c:11
-msgid "The valid integer end value for all maps, or the identifier \"file\" in case the start time is located in the input file"
-msgstr ""
-#: ../locale/scriptstrings/t.time.rel_to_translate.c:13
-msgid "Increment between maps for valid time interval creation"
-msgstr ""
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:1
-#, fuzzy
-msgid "Imports Mapgen or Matlab-ASCII vector maps into GRASS."
-msgstr "a a."
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:4
-#, fuzzy
-msgid "Input map is in Matlab format"
-msgstr "है n"
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
-msgid "Create a 3D vector points map from 3 column Matlab data"
-msgstr ""
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
-#, fuzzy
-msgid "Name of input file in Mapgen/Matlab format"
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:7
-#, fuzzy
-msgid "Name for output vector map (omit for display to stdout)"
-msgstr "के लिए के लिए"
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:1
-#, fuzzy
-msgid "Imports geonames.org country files into a vector points map."
-msgstr "का"
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:5
-#, fuzzy
-msgid "Name of uncompressed geonames file (with .txt extension)"
-msgstr "का"
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
-msgid "Georeference, rectify, and import Terra-ASTER imagery and relative DEMs using gdalwarp."
-msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:5
-#, fuzzy
-msgid "Name of input ASTER image"
-msgstr "का"
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:6
-msgid "ASTER imagery processing type (Level 1A, Level 1B, or relative DEM)"
-msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:7
-msgid "List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate all bands"
-msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:8
-#, fuzzy
-msgid "Base name for output raster map (band number will be appended to base name)"
-msgstr "शीर्षक"
-#: ../locale/scriptstrings/db.droptable_to_translate.c:1
-#, fuzzy
-msgid "Drops an attribute table."
-msgstr "नहीं"
-#: ../locale/scriptstrings/db.droptable_to_translate.c:5
-#, fuzzy
-msgid "Table name to drop"
-msgstr "के लिए."
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:1
-#, fuzzy
-msgid "Imports SRTM HGT files into raster map."
-msgstr "a a"
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:4
-#, fuzzy
-msgid "Name of SRTM input tile (file without .hgt.zip extension)"
-msgstr "का"
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:5
-#, fuzzy
-msgid "Name for output raster map (default: input tile)"
-msgstr "शीर्षक"
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:6
-msgid "Input is a 1-arcsec tile (default: 3-arcsec)"
-msgstr ""
-msgid "Register raster3d maps in a space time raster3d dataset"
-msgstr ""
-#: ../locale/scriptstrings/tr3.register_to_translate.c:2
-#: ../locale/scriptstrings/tr3.unregister_to_translate.c:2
-#: ../locale/scriptstrings/tr3.extract_to_translate.c:2
-#, fuzzy
-msgid "spacetime raster3d dataset"
-msgstr "का"
-#: ../locale/scriptstrings/tr3.register_to_translate.c:4
-#, fuzzy
-msgid "Name of an existing space time raster3d dataset"
-msgstr "का"
-#: ../locale/scriptstrings/tr3.register_to_translate.c:5
-#, fuzzy
-msgid "Name(s) of existing raster3d map(s)"
-msgstr "का"
-#: ../locale/scriptstrings/tr3.register_to_translate.c:6
-msgid "Input file with raster3d map names, one per line. Additionally the start time and the end time can be specified per line"
-msgstr ""
-#: ../locale/scriptstrings/tr3.register_to_translate.c:7
-msgid "The valid start date and time of the first raster3d map, in case the map has no valid time (format absolute: \"yyyy-mm-dd HH:MM:SS\", format relative 5.0). Use \"file\" as identifier in case the start time is located in an input file"
-msgstr ""
-#: ../locale/scriptstrings/tr3.register_to_translate.c:8
-msgid "The valid end date and time of the first raster3d map. Absolute time format is \"yyyy-mm-dd HH:MM:SS\" and \"yyyy-mm-dd\", relative time format id double. Use \"file\" as identifier in case the end time is located in the input file"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
-#, fuzzy
-msgid "Edits cell values in a raster map."
-msgstr "छवियाँ a"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:4
-#, fuzzy
-msgid "edit"
-msgstr "n"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:6
-msgid "Width of display canvas"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:7
-msgid "Height of display canvas"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:8
-#, fuzzy
-msgid "Minimum size of each cell"
-msgstr "आइसोसरफेस"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:9
-#, fuzzy
-msgid "Maximum number of rows to load"
-msgstr "संख्या का n"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:10
-#, fuzzy
-msgid "Maximum number of columns to load"
-#: ../locale/scriptstrings/v.db.update_to_translate.c:1
-#, fuzzy
-msgid "Allows to update a column in the attribute table connected to a vector map."
-msgstr "का"
-#: ../locale/scriptstrings/v.db.update_to_translate.c:5
-#, fuzzy
-msgid "Name of attribute column to update"
-msgstr "का के लिए"
-#: ../locale/scriptstrings/v.db.update_to_translate.c:6
-msgid "Value to update the column with, can be (combination of) other column(s)"
-msgstr ""
-#: ../locale/scriptstrings/v.db.update_to_translate.c:7
-#, fuzzy
-msgid "Name of attribute column to query"
-msgstr "क्वैरी उपयोग में."
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:1
-#, fuzzy
-msgid "Exports attribute tables into various formats."
-msgstr "का."
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:4
-msgid "Table file to be exported or DB connection string"
-msgstr ""
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:5
-#, fuzzy
-msgid "Table format"
-msgstr "के लिए"
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:6
-#, fuzzy
-msgid "Name for output table (defaut: input)"
-msgstr "शीर्षक"
-#: ../locale/scriptstrings/tr.out.vtk_to_translate.c:1
-#, fuzzy
-msgid "Export space time raster dataset as VTK time series"
-msgstr "का"
-#: ../locale/scriptstrings/tr.out.vtk_to_translate.c:6
-msgid "VTK"
-msgstr ""
-#: ../locale/scriptstrings/tr.out.vtk_to_translate.c:8
-#, fuzzy
-msgid "Path to the export directory"
-msgstr "के लिए"
-#: ../locale/scriptstrings/tr.out.vtk_to_translate.c:10
-msgid "A where statement for selected listing e.g: (start_time < '2001-01-01' and end_time > '2001-01-01')"
-msgstr ""
-#: ../locale/scriptstrings/tr.out.vtk_to_translate.c:14
-msgid "Export files using the space time dataset granularity for equidistant time between maps, where statement will be ignored"
-msgstr ""
-#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:1
-#, fuzzy
-msgid "Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
-msgstr "a a."
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
-#, fuzzy
-msgid "Fills no-data areas in raster maps using spline interpolation."
-msgstr "a."
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
-#, fuzzy
-msgid "Spline tension parameter"
-msgstr "चिकना"
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:6
-#, fuzzy
-msgid "Spline smoothing parameter"
-msgstr "चिकना"
-#: ../locale/scriptstrings/v.centroids_to_translate.c:1
-#, fuzzy
-msgid "Adds missing centroids to closed boundaries."
-msgstr "नाम बदला गया"
-#: ../locale/scriptstrings/v.centroids_to_translate.c:5
-#, fuzzy
-msgid "Action to be taken"
-msgstr "फ़ाइल"
-#: ../locale/scriptstrings/v.centroids_to_translate.c:6
-msgid "Category number starting value"
-msgstr ""
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
-#, fuzzy
-msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
-msgstr "का"
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
-#, fuzzy
-msgid "Name of new attribute table (default: vector map name)"
-msgstr "का"
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:8
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:9
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:12
-#, fuzzy
-msgid "Definition"
-msgstr "के लिए"
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:7
-#, fuzzy
-msgid "Layer number where to add new attribute table"
-msgstr "नहीं"
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:10
-msgid "Name and type of the new column(s)"
-msgstr ""
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:11
-msgid "Types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE. Example: \"label varchar(250), type integer\""
-msgstr ""
-#: ../locale/scriptstrings/tr.unregister_to_translate.c:1
-msgid "Unregister raster map(s) from a specific or from all space time raster dataset in which it is registered"
-msgstr ""
-#: ../locale/scriptstrings/tr.unregister_to_translate.c:4
-msgid "Name of an existing space time raster dataset. If no name is provided the raster map(s) are unregistered from all space time datasets in which they are registered."
-msgstr ""
-#: ../locale/scriptstrings/tr.unregister_to_translate.c:6
-#, fuzzy
-msgid "Name(s) of existing raster map(s) to unregister"
-msgstr "का"
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:1
-msgid "Imports GetFeature from WFS."
-msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:4
-msgid "wfs"
-msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:5
-msgid "GetFeature URL starting with 'http'"
-msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:1
-#, fuzzy
-msgid "Uploads vector values at positions of vector points to the table."
-msgstr "पर का"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:7
-#, fuzzy
-msgid "Name of vector map to be queried"
-msgstr "का"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:8
-#, fuzzy
-msgid "Name of attribute column to be queried"
-msgstr "का के लिए"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:9
-#, fuzzy
-msgid "Maximum query distance in map units"
-msgstr "f"
-#, fuzzy
-msgid "List registered maps of a space time raster dataset"
-msgstr "स्रोत"
-#: ../locale/scriptstrings/t.info_to_translate.c:1
-#, fuzzy
-msgid "List informtion about space time and map datasets"
-msgstr "a."
-#: ../locale/scriptstrings/t.info_to_translate.c:4
-#, fuzzy
-msgid "Name of an existing space time or map dataset"
-msgstr "का"
-#: ../locale/scriptstrings/t.info_to_translate.c:5
-msgid "Type of the dataset, default is strds (space time raster dataset)"
-msgstr ""
-#: ../locale/scriptstrings/t.info_to_translate.c:6
-#, fuzzy
-msgid "Print information in shell style"
-msgstr "छापें"
-#: ../locale/scriptstrings/t.info_to_translate.c:7
-msgid "Print information about the temporal DBMI interface and exit"
-msgstr ""
-#: ../locale/scriptstrings/db.test_to_translate.c:1
-msgid "Test database driver, database must exist and set by db.connect."
-msgstr ""
-#: ../locale/scriptstrings/db.test_to_translate.c:4
-#, fuzzy
-msgid "Test name"
-msgstr "फ़ॉन्ट"
-#: ../locale/scriptstrings/tr.univar_to_translate.c:1
-#, fuzzy
-msgid "Calculates univariate statistics from the non-null cells for each registred raster map of a space time raster dataset"
-msgstr "का a."
-#: ../locale/scriptstrings/tr.univar_to_translate.c:6
-msgid "The field separator character between the columns"
-msgstr ""
-#: ../locale/scriptstrings/v.convert.all_to_translate.c:1
-#, fuzzy
-msgid "Converts all older versions of GRASS vector maps in current mapset to current format."
-msgstr "a a."
-#: ../locale/scriptstrings/g.extension.rebuild.all_to_translate.c:1
-msgid "Rebuilds all locally installed GRASS Addons extensions."
-msgstr ""
-#: ../locale/scriptstrings/g.extension.rebuild.all_to_translate.c:2
-msgid "By default only extensions built against different GIS Library are rebuilt."
-msgstr ""
-#: ../locale/scriptstrings/g.extension.rebuild.all_to_translate.c:4
-#: ../locale/scriptstrings/g.extension_to_translate.c:4
-#, fuzzy
-msgid "installation"
-msgstr "है a"
-#: ../locale/scriptstrings/g.extension.rebuild.all_to_translate.c:5
-#: ../locale/scriptstrings/g.extension_to_translate.c:5
-#, fuzzy
-msgid "extensions"
-msgstr "पाठ रंग"
-#: ../locale/scriptstrings/g.extension.rebuild.all_to_translate.c:6
-msgid "Force to rebuild all extensions"
-msgstr ""
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:1
-msgid "Views BMP images from the PNG driver."
-msgstr ""
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:4
-#, fuzzy
-msgid "Name of input image file"
-msgstr "का"
-#: ../locale/scriptstrings/tr3.unregister_to_translate.c:1
-msgid "Unregister raster3d map(s) from a specific or from all space time raster3d dataset in which it is registered"
-msgstr ""
-#: ../locale/scriptstrings/tr3.unregister_to_translate.c:4
-msgid "Name of an existing space time raster3d dataset. If no name is provided the raster3d map(s) are unregistered from all space time datasets in which they are registered."
-msgstr ""
-#: ../locale/scriptstrings/tr3.unregister_to_translate.c:5
-msgid "Input file with raster3d map names, one per line"
-msgstr ""
-#: ../locale/scriptstrings/tr3.unregister_to_translate.c:6
-#, fuzzy
-msgid "Name(s) of existing raster3d map(s) to unregister"
-msgstr "का"
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:1
-#, fuzzy
-msgid "Displays a raster map and its legend on a graphics window"
-msgstr "a के लिए a का."
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:4
-msgid "Omit entries with missing label"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:5
-#, fuzzy
-msgid "Name of raster map to display"
-msgstr "का"
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:6
-#, fuzzy
-msgid "Number of lines to appear in the legend"
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:7
-#, fuzzy
-msgid "Name of input raster map to generate legend from"
-msgstr "का के लिए"
-#: ../locale/scriptstrings/m.proj_to_translate.c:1
-msgid "Converts coordinates from one projection to another (cs2cs frontend)."
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:4
-#, fuzzy
-msgid "Name of input coordinate file ('-' to read from stdin)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:5
-#: ../locale/scriptstrings/m.proj_to_translate.c:7
-#: ../locale/scriptstrings/m.proj_to_translate.c:10
-#: ../locale/scriptstrings/m.proj_to_translate.c:20
-#: ../locale/scriptstrings/m.proj_to_translate.c:22
-#: ../locale/scriptstrings/m.proj_to_translate.c:24
-#, fuzzy
-msgid "Files & format"
-msgstr "के लिए"
-#: ../locale/scriptstrings/m.proj_to_translate.c:6
-#, fuzzy
-msgid "Name for output coordinate file (omit to send to stdout)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:8
-#, fuzzy
-msgid "Field separator (format: input[,output])"
-msgstr "फील्ड"
-#: ../locale/scriptstrings/m.proj_to_translate.c:9
-msgid "Valid field separators are also \"space\", \"tab\", or \"comma\""
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:11
-msgid "Input projection parameters (PROJ.4 style)"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:12
-#: ../locale/scriptstrings/m.proj_to_translate.c:14
-#: ../locale/scriptstrings/m.proj_to_translate.c:16
-#: ../locale/scriptstrings/m.proj_to_translate.c:18
-#, fuzzy
-msgid "Projections"
-msgstr "नक़ल"
-#: ../locale/scriptstrings/m.proj_to_translate.c:13
-msgid "Output projection parameters (PROJ.4 style)"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:15
-msgid "Use LL WGS84 as input and current location as output projection"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:17
-msgid "Use current location as input and LL WGS84 as output projection"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:19
-msgid "Output long/lat in decimal degrees, or other projections with many decimal places"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:21
-#, fuzzy
-msgid "Include input coordinates in output file"
-msgstr "का"
-#: ../locale/scriptstrings/m.proj_to_translate.c:23
-#, fuzzy
-msgid "Include column names in output file"
-msgstr "नहीं"
-#: ../locale/scriptstrings/i.oif_to_translate.c:1
-msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
-msgstr ""
-#: ../locale/scriptstrings/i.oif_to_translate.c:5
-msgid "LANDSAT TM band 1."
-msgstr ""
-#: ../locale/scriptstrings/i.oif_to_translate.c:6
-msgid "LANDSAT TM band 2."
-msgstr ""
-#: ../locale/scriptstrings/i.oif_to_translate.c:7
-msgid "LANDSAT TM band 3."
-msgstr ""
-#: ../locale/scriptstrings/i.oif_to_translate.c:8
-msgid "LANDSAT TM band 4."
-msgstr ""
-#: ../locale/scriptstrings/i.oif_to_translate.c:9
-msgid "LANDSAT TM band 5."
-msgstr ""
-#: ../locale/scriptstrings/i.oif_to_translate.c:10
-msgid "LANDSAT TM band 7."
-msgstr ""
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
-#, fuzzy
-msgid "Removes existing attribute table of a vector map."
-msgstr "का"
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
-msgid "Force removal (required for actual deletion of table)"
-msgstr ""
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
-#, fuzzy
-msgid "Table name (default: vector map name)"
-msgstr "का"
-#: ../locale/scriptstrings/r.grow_to_translate.c:3
-#, fuzzy
-msgid "Radius is in map units rather than cells"
-msgstr "का"
-#: ../locale/scriptstrings/r.buffer_to_translate.c:1
-#, fuzzy
-msgid "Creates a raster map showing buffer zones surrounding cells that contain non-NULL category values."
-msgstr "a रखे हुए."
-msgid "List space time and map datasets"
-msgstr ""
-#: ../locale/scriptstrings/t.list_to_translate.c:5
-#, fuzzy
-msgid "Type of the space time dataset or map, default is strds"
-msgstr "का"
-#: ../locale/scriptstrings/t.list_to_translate.c:6
-msgid "Sort the space time dataset by category. Columns number_of_maps and granularity only available fpr space time datasets"
-msgstr ""
-#: ../locale/scriptstrings/t.list_to_translate.c:7
-msgid "Which columns should be printed to stdout. Columns number_of_maps and granularity only available for space time datasets"
-msgstr ""
-#: ../locale/scriptstrings/t.list_to_translate.c:11
-msgid "Print the column names as first row"
-msgstr ""
-#: ../locale/scriptstrings/v.build.all_to_translate.c:1
-#, fuzzy
-msgid "Rebuilds topology on all vector maps in the current mapset."
-msgstr "नहीं"
-#: ../locale/scriptstrings/d.correlate_to_translate.c:1
-msgid "Prints a graph of the correlation between raster maps (in pairs)."
-msgstr ""
-#: ../locale/scriptstrings/d.correlate_to_translate.c:5
-#, fuzzy
-msgid "correlation"
-msgstr "का"
-#: ../locale/scriptstrings/tr.series_to_translate.c:1
-msgid "Performe different aggregation algorithms from r.series on all or a subset of raster maps in a space time raster dataset"
-msgstr ""
-#: ../locale/scriptstrings/tr.series_to_translate.c:5
-#: ../locale/scriptstrings/tr.register_to_translate.c:4
-#, fuzzy
-msgid "Name of an existing space time raster dataset"
-msgstr "का"
-#: ../locale/scriptstrings/tr.series_to_translate.c:7
-msgid "Sort the maps by category."
-msgstr ""
-#: ../locale/scriptstrings/tr.series_to_translate.c:8
-msgid "Assign the space time raster dataset start and end time to the output map"
-msgstr ""
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
-msgid "Mosaics several images and extends colormap."
-msgstr ""
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:4
-msgid "mosaicking"
-msgstr ""
-#: ../locale/scriptstrings/v.out.gps_to_translate.c:1
-#, fuzzy
-msgid "Exports a vector map to a GPS receiver or file format supported by GPSBabel."
-msgstr "a a."
-#: ../locale/scriptstrings/v.out.gps_to_translate.c:4
-msgid "GPS"
-msgstr ""
-#: ../locale/scriptstrings/v.out.gps_to_translate.c:5
-#, fuzzy
-msgid "Export as waypoints"
-msgstr "n"
-#: ../locale/scriptstrings/v.out.gps_to_translate.c:6
-#, fuzzy
-msgid "Export as routes"
-msgstr "n"
-#: ../locale/scriptstrings/v.out.gps_to_translate.c:7
-#, fuzzy
-msgid "Export as tracks"
-msgstr "n"
-#: ../locale/scriptstrings/v.out.gps_to_translate.c:8
-#, fuzzy
-msgid "Name for output file or GPS device"
-msgstr "के लिए"
-#: ../locale/scriptstrings/v.out.gps_to_translate.c:9
-#, fuzzy
-msgid "GPSBabel supported output format"
-msgstr "अज्ञात क़िस्म"
-#: ../locale/scriptstrings/v.out.gps_to_translate.c:10
-#: ../locale/scriptstrings/v.out.gps_to_translate.c:11
-msgid "Subset"
-msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:1
-msgid "Produces tilings of the source projection for use in the destination region and projection."
-msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:3
-#, fuzzy
-msgid "tiling"
-msgstr "का"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:4
-#, fuzzy
-msgid "Produces shell script output"
-msgstr "छापें"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:5
-#, fuzzy
-msgid "Produces web map server query string output"
-msgstr "छापें"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:6
-msgid "Name of region to use instead of current region for bounds and resolution"
-msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:7
-#, fuzzy
-msgid "Source projection"
-msgstr "नहीं n"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:8
-#: ../locale/scriptstrings/r.tileset_to_translate.c:10
-#, fuzzy
-msgid "Conversion factor from units to meters in source projection"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:9
-msgid "Destination projection, defaults to this location's projection"
-msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:11
-#, fuzzy
-msgid "Maximum number of columns for a tile in the source projection"
-msgstr "संख्या का a खण्ड"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:12
-#, fuzzy
-msgid "Maximum number of rows for a tile in the source projection"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:13
-#, fuzzy
-msgid "Number of cells tiles should overlap in each direction"
-msgstr "का के लिए"
-#: ../locale/scriptstrings/tr.export_to_translate.c:1
-#, fuzzy
-msgid "Export space time raster dataset"
-msgstr "का"
-#: ../locale/scriptstrings/tr.export_to_translate.c:7
-#, fuzzy
-msgid "Name of a space time raster dataset archive"
-msgstr "का"
-#: ../locale/scriptstrings/tr.export_to_translate.c:8
-msgid "Path to the work directory, default is /tmp"
-msgstr ""
-#: ../locale/scriptstrings/tr.export_to_translate.c:9
-msgid "Chose the compression of the tar archive"
-msgstr ""
-#: ../locale/scriptstrings/tr.export_to_translate.c:10
-msgid "A where statement for selected listing e.g: start_time < '2001-01-01' and end_time > '2001-01-01\"'"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:1
-msgid "Downloads and imports data from WMS servers."
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:4
-msgid "wms"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:6
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:10
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:19
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:21
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:24
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:26
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:28
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:30
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:32
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:34
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:36
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:38
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:41
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:48
-msgid "Request"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:7
-msgid "Skip to downloading (to resume downloads faster)"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:8
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:12
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:43
-msgid "Download"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:9
-msgid "Don't request transparent data"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:11
-msgid "Clean existing data out of download directory"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:14
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:16
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:22
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:45
-#, fuzzy
-msgid "Import"
-msgstr "n"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:15
-msgid "Don't reproject the data, just patch it"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:17
-msgid "Use GET method instead of POST data method"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:18
-msgid "This may be needed to connect to servers which lack POST capability"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:20
-msgid "Use GDAL WMS driver"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:23
-#, fuzzy
-msgid "Mapserver to request data from"
-msgstr "सभी"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:25
-#, fuzzy
-msgid "Layers to request from map server"
-msgstr "पद्धति"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:27
-#, fuzzy
-msgid "Styles to request from map server"
-msgstr "पद्धति"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:29
-#, fuzzy
-msgid "Source projection to request from server"
-msgstr "पद्धति"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:31
-#, fuzzy
-msgid "Image format requested from the server"
-msgstr "पद्धति"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:33
-msgid "Addition query options for server"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:35
-#, fuzzy
-msgid "Maximum columns to request at a time"
-msgstr "बिन्दु"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:37
-#, fuzzy
-msgid "Maximum rows to request at a time"
-msgstr "बिन्दु"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:39
-msgid "Additional options for r.tileset"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:40
-msgid "Named region to request data for. Current region used if omitted"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:42
-msgid "Folder to save downloaded data to (default $GISDBASE/wms_download)"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:44
-#, fuzzy
-msgid "Reprojection method to use"
-msgstr "पद्धति"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:46
-msgid "Filename to save capabilities XML file to"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:47
-#, fuzzy
-msgid "Requires list available layers flag"
-msgstr "स्रोत"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:1
-#, fuzzy
-msgid "Performs Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data."
-msgstr "ऊंचाई के लिए"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:4
-#, fuzzy
-msgid "Use transformation rules for LANDSAT-4"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:5
-#, fuzzy
-msgid "Use transformation rules for LANDSAT-5"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:6
-#, fuzzy
-msgid "Use transformation rules for LANDSAT-7"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:7
-#, fuzzy
-msgid "Name of input raster map (LANDSAT channel 1)"
-msgstr "का"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:8
-#, fuzzy
-msgid "Name of input raster map (LANDSAT channel 2)"
-msgstr "का"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:9
-#, fuzzy
-msgid "Name of input raster map (LANDSAT channel 3)"
-msgstr "का"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:10
-#, fuzzy
-msgid "Name of input raster map (LANDSAT channel 4)"
-msgstr "का"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:11
-#, fuzzy
-msgid "Name of input raster map (LANDSAT channel 5)"
-msgstr "का"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:12
-#, fuzzy
-msgid "Name of input raster map (LANDSAT channel 7)"
-msgstr "का"
-msgid "Register raster maps in a space time raster dataset"
-msgstr ""
-#: ../locale/scriptstrings/tr.register_to_translate.c:5
-#, fuzzy
-msgid "Name(s) of existing raster map(s)"
-msgstr "का"
-#: ../locale/scriptstrings/tr.register_to_translate.c:6
-msgid "Input file with raster map names, one per line. Additionally the start time and the end time can be specified per line"
-msgstr ""
-#: ../locale/scriptstrings/tr.register_to_translate.c:7
-msgid "The valid start date and time of the first raster map, in case the map has no valid time (format absolute: \"yyyy-mm-dd HH:MM:SS\", format relative 5.0). Use \"file\" as identifier in case the start time is located in an input file"
-msgstr ""
-#: ../locale/scriptstrings/tr.register_to_translate.c:8
-msgid "The valid end date and time of the first raster map. Absolute time format is \"yyyy-mm-dd HH:MM:SS\" and \"yyyy-mm-dd\", relative time format id double. Use \"file\" as identifier in case the end time is located in the input file"
-msgstr ""
-#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:1
-#, fuzzy
-msgid "Drops a column from selected attribute table"
-msgstr "नहीं"
-#: ../locale/scriptstrings/tr.to.rast3_to_translate.c:1
-#, fuzzy
-msgid "Convert a space time raster dataset into a rast3d map"
-msgstr "a a."
-#: ../locale/scriptstrings/t.sample_to_translate.c:1
-msgid "Sample the input space time dataset with a sample space time dataset and print the result to stdout"
-msgstr ""
-#: ../locale/scriptstrings/t.sample_to_translate.c:5
-#, fuzzy
-msgid "sample"
-msgstr "का"
-#: ../locale/scriptstrings/t.sample_to_translate.c:6
-#, fuzzy
-msgid "Name of a space time dataset"
-msgstr "का"
-#: ../locale/scriptstrings/t.sample_to_translate.c:7
-#, fuzzy
-msgid "Name of the sample space time dataset"
-msgstr "का"
-#: ../locale/scriptstrings/t.sample_to_translate.c:8
-#, fuzzy
-msgid "Type of the input space time dataset, default is space time raster dataset (strds)"
-msgstr "का"
-#: ../locale/scriptstrings/t.sample_to_translate.c:9
-msgid "Type of the sample space time dataset, default is space time raster dataset (strds)"
-msgstr ""
-#: ../locale/scriptstrings/t.sample_to_translate.c:10
-#, fuzzy
-msgid "The method to be used for sampling"
-msgstr "के लिए."
-#: ../locale/scriptstrings/t.sample_to_translate.c:11
-msgid "The field separator character between the columns, default is tabular \" | \". Do not use \",\" as this char is reserved to list several map ids in a sample granule"
-msgstr ""
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:1
-msgid "Brovey transform to merge multispectral and high-res panchromatic channels"
-msgstr ""
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:3
-msgid "fusion"
-msgstr ""
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:4
-msgid "Brovey"
-msgstr ""
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:5
-msgid "LANDSAT sensor"
-msgstr ""
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:6
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:8
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:10
-msgid "Sensor"
-msgstr ""
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:7
-msgid "QuickBird sensor"
-msgstr ""
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:9
-msgid "SPOT sensor"
-msgstr ""
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:11
-#, fuzzy
-msgid "Name of input raster map (green: tm2 | qbird_green | spot1)"
-msgstr "का"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:12
-#, fuzzy
-msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2"
-msgstr "का"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:13
-#, fuzzy
-msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3"
-msgstr "का"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:14
-#, fuzzy
-msgid "Name of input raster map (etmpan | qbird_pan | spotpan)"
-msgstr "का"
-#: ../locale/scriptstrings/g.extension_to_translate.c:1
-msgid "Maintains GRASS Addons extensions in local GRASS installation."
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:2
-msgid "Downloads, installs extensions from GRASS Addons SVN repository into local GRASS installation or removes installed extensions."
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:6
-#, fuzzy
-msgid "Name of extension to install/remove"
-msgstr "के लिए"
-#: ../locale/scriptstrings/g.extension_to_translate.c:8
-msgid "SVN Addons repository URL"
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:9
-msgid "Prefix where to install extension (ignored when flag -s is given)"
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:10
-#, fuzzy
-msgid "List available extensions in the GRASS Addons SVN repository"
-msgstr "स्रोत"
-#: ../locale/scriptstrings/g.extension_to_translate.c:12
-#, fuzzy
-msgid "List available extensions in the GRASS Addons SVN repository including module description"
-msgstr "स्रोत"
-#: ../locale/scriptstrings/g.extension_to_translate.c:14
-#, fuzzy
-msgid "List available extensions in the GRASS Addons SVN repository (shell script style)"
-msgstr "स्रोत"
-#: ../locale/scriptstrings/g.extension_to_translate.c:16
-msgid "List locally installed extensions"
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:18
-msgid "Install system-wide (may need system administrator rights)"
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:19
-#: ../locale/scriptstrings/g.extension_to_translate.c:21
-#: ../locale/scriptstrings/g.extension_to_translate.c:23
-#, fuzzy
-msgid "Install"
-msgstr "है a"
-#: ../locale/scriptstrings/g.extension_to_translate.c:20
-msgid "Download source code and exit"
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:22
-msgid "Don't install new extension, just compile it"
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:24
-msgid "Force removal when uninstalling extension (operation=remove)"
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:26
-#, fuzzy
-msgid "Operate on toolboxes instead of single modules"
-msgstr "का"
-#, fuzzy
-msgid "Extract a subset of a space time raster3d dataset"
-msgstr "का"
-#: ../locale/scriptstrings/tr3.extract_to_translate.c:5
-#: ../locale/scriptstrings/tr3.list_to_translate.c:6
-#, fuzzy
-msgid "Name of a space time raster3d dataset"
-msgstr "का"
-#: ../locale/scriptstrings/tr3.extract_to_translate.c:7
-msgid "The r3.mapcalc expression assigned to all extracted raster3d maps"
-msgstr ""
-#: ../locale/scriptstrings/tr3.extract_to_translate.c:8
-#, fuzzy
-msgid "Name of the output space time raster3d dataset"
-msgstr "का"
-#: ../locale/scriptstrings/tr3.extract_to_translate.c:9
-#, fuzzy
-msgid "Base name of the new created raster3d maps"
-msgstr "का"
-#: ../locale/scriptstrings/tr3.list_to_translate.c:1
-#, fuzzy
-msgid "List registered maps of a space time raster3d dataset"
-msgstr "स्रोत"
-#: ../locale/scriptstrings/tr3.list_to_translate.c:9
-msgid "A where statement for selected listing e.g: \"start_time < '2001-01-01' and end_time > '2001-01-01'\""
-msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:1
-#, fuzzy
-msgid "Modify the metadata of a space time dataset"
-msgstr "का"
-#: ../locale/scriptstrings/t.support_to_translate.c:5
-#, fuzzy
-msgid "Name of the space time dataset"
-msgstr "का"
-#: ../locale/scriptstrings/t.support_to_translate.c:8
-#, fuzzy
-msgid "Title of the space time dataset"
-msgstr "का"
-#: ../locale/scriptstrings/t.support_to_translate.c:9
-#, fuzzy
-msgid "Description of the space time dataset"
-msgstr "का"
-#: ../locale/scriptstrings/t.support_to_translate.c:10
-msgid "Update metadata information, temporal and spatial extent from registered maps"
-msgstr ""
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:1
-#, fuzzy
-msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
-msgstr "नहीं"
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:4
-msgid "dissolve"
-msgstr ""
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:5
-#, fuzzy
-msgid "Layer number or name. If -1, all layers are extracted."
-msgstr "नहीं सभी n n फ़ाइल"
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:6
-#, fuzzy
-msgid "Name of attribute column used to dissolve common boundaries"
-msgstr "का के लिए"
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:1
-#, fuzzy
-msgid "Drapes a color raster over a shaded relief map."
-msgstr "का"
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:3
-#, fuzzy
-msgid "Name of shaded relief or aspect raster map"
-msgstr "का"
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:4
-#, fuzzy
-msgid "Name of raster to drape over relief raster map"
-msgstr "का"
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:5
-#, fuzzy
-msgid "Percent to brighten"
-msgstr "पूर्ण."
Deleted: grass/trunk/locale/po/grassmods_mr.po
--- grass/trunk/locale/po/grassmods_mr.po	2012-05-29 07:08:35 UTC (rev 51861)
+++ grass/trunk/locale/po/grassmods_mr.po	2012-05-29 09:28:22 UTC (rev 51862)
@@ -1,33704 +0,0 @@
-# Marathi Localization of Grass 6.0
-# Copyright (C) 2005 GRASS Development Team
-# This file is distributed under the same license as the Grass package.
-# Sheetal Nepte <sheetal_nepte at yahoo.co.in>, 2005.
-msgid ""
-msgstr ""
-"Project-Id-Version: Grass 6.0\n"
-"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2012-01-28 11:12+0100\n"
-"PO-Revision-Date: 2005-06-02 18:00+0530\n"
-"Last-Translator: Swapnil Hajare <dreamil at gmail.com>\n"
-"Language-Team: Marathi <www.janabhaaratii.org.in>\n"
-"Language: mr\n"
-"MIME-Version: 1.0\n"
-"Content-Type: text/plain; charset=UTF-8\n"
-"Content-Transfer-Encoding: 8bit\n"
-#: ../visualization/nviz/src/nvizMain.c:71
-#: ../visualization/ximgview/main.c:293 ../misc/m.nviz.script/main.c:73
-#: ../misc/m.nviz.image/main.c:50
-#, fuzzy
-msgid "visualization"
-msgstr "'%s'. ड्राइवर चालू होत नाही"
-#: ../visualization/nviz/src/nvizMain.c:72
-#: ../visualization/ximgview/main.c:291 ../doc/raster/r.example/main.c:83
-#: ../raster3d/r3.to.rast/main.c:207 ../raster3d/r3.cross.rast/main.c:229
-#: ../misc/m.nviz.script/main.c:70 ../misc/m.nviz.image/main.c:51
-#: ../raster/r.external/main.c:55 ../raster/r.uslek/main.c:53
-#: ../raster/r.mode/main.c:54 ../raster/r.profile/main.c:50
-#: ../raster/r.category/main.c:52 ../raster/r.watershed/front/main.c:71
-#: ../raster/r.colors.out/raster_main.c:45 ../raster/r.drain/main.c:107
-#: ../raster/r.param.scale/interface.c:54 ../raster/r.in.gridatb/main.c:45
-#: ../raster/r.support/main.c:55 ../raster/r.topmodel/main.c:62
-#: ../raster/r.external.out/main.c:214 ../raster/r.cross/main.c:73
-#: ../raster/r.usler/main.c:51 ../raster/r.distance/main.c:38
-#: ../raster/r.out.mpeg/main.c:102 ../raster/r.patch/main.c:52
-#: ../raster/r.quant/main.c:47 ../raster/r.spread/main.c:102
-#: ../raster/r.cost/main.c:139 ../raster/r.out.vtk/main.c:59
-#: ../raster/r.recode/main.c:48 ../raster/r.statistics/main.c:55
-#: ../raster/r.rescale.eq/main.c:51 ../raster/r.in.png/main.c:519
-#: ../raster/r.los/main.c:93 ../raster/r.his/main.c:62
-#: ../raster/r.buffer/main.c:66 ../raster/r.resamp.stats/main.c:256
-#: ../raster/r.circle/main.c:51 ../raster/r.walk/main.c:179
-#: ../raster/r.what/main.c:91 ../raster/r.contour/main.c:86
-#: ../raster/r.series/main.c:132 ../raster/r.random.surface/main.c:57
-#: ../raster/r.statistics3/main.c:389 ../raster/r.in.xyz/main.c:160
-#: ../raster/r.composite/main.c:72 ../raster/r.solute.transport/main.c:229
-#: ../raster/r.volume/main.c:58 ../raster/r.gwflow/main.c:205
-#: ../raster/r.topidx/main.c:39 ../raster/r.ros/main.c:211
-#: ../raster/r.in.arc/main.c:60 ../raster/r.fill.dir/main.c:85
-#: ../raster/r.mfilter/main.c:56 ../raster/r.statistics2/main.c:101
-#: ../raster/r.out.arc/main.c:60 ../raster/r.rescale/main.c:48
-#: ../raster/r.clump/main.c:46 ../raster/r.colors/edit_colors.c:60
-#: ../raster/r.to.rast3/main.c:197 ../raster/r.sun/main.c:229
-#: ../raster/r.le/r.le.patch/main.c:48 ../raster/r.le/r.le.trace/main.c:56
-#: ../raster/r.le/r.le.setup/main.c:57 ../raster/r.le/r.le.pixel/main.c:45
-#: ../raster/r.digit/main.c:44 ../raster/r.surf.contour/main.c:60
-#: ../raster/r.in.bin/main.c:235 ../raster/r.kappa/main.c:68
-#: ../raster/r.out.png/main.c:112 ../raster/r.resamp.rst/main.c:148
-#: ../raster/r.quantile/main.c:255 ../raster/r.compress/main.c:62
-#: ../raster/r.support.stats/main.c:38 ../raster/r.spreadpath/main.c:89
-#: ../raster/r.random/main.c:51 ../raster/r.grow.distance/main.c:149
-#: ../raster/r.report/main.c:66 ../raster/r.out.pov/main.c:121
-#: ../raster/r.water.outlet/main.c:65 ../raster/r.carve/main.c:74
-#: ../raster/r.out.tiff/main.c:91 ../raster/r.null/main.c:59
-#: ../raster/r.basins.fill/main.c:54 ../raster/r.surf.idw2/main.c:61
-#: ../raster/r.stats/main.c:102 ../raster/r.region/main.c:51
-#: ../raster/r.univar/r.univar_main.c:96 ../raster/r.describe/main.c:54
-#: ../raster/r.out.mat/main.c:62 ../raster/r.in.lidar/main.c:161
-#: ../raster/r.sunmask/main.c:116 ../raster/r.regression.line/main.c:46
-#: ../raster/r.out.bin/main.c:279 ../raster/r.surf.random/main.c:36
-#: ../raster/r.resample/main.c:54 ../raster/r.in.mat/main.c:91
-#: ../raster/r.li/r.li.shape/main.c:34 ../raster/r.li/r.li.cwed/cwed.c:46
-#: ../raster/r.li/r.li.patchnum/main.c:36
-#: ../raster/r.li/r.li.simpson/simpson.c:39
-#: ../raster/r.li/r.li.dominance/dominance.c:41
-#: ../raster/r.li/r.li.pielou/pielou.c:58 ../raster/r.li/r.li.mps/mps.c:40
-#: ../raster/r.li/r.li.shannon/shannon.c:38
-#: ../raster/r.li/r.li.richness/richness.c:39
-#: ../raster/r.li/r.li.renyi/renyi.c:45
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:39
-#: ../raster/r.li/r.li.padrange/padrange.c:39
-#: ../raster/r.li/r.li.padsd/padsd.c:37 ../raster/r.li/r.li.mpa/mpa.c:39
-#: ../raster/r.li/r.li.padcv/padcv.c:39
-#: ../raster/r.li/r.li.patchdensity/main.c:35 ../raster/r.out.ppm/main.c:53
-#: ../raster/r.random.cells/main.c:45 ../raster/r.timestamp/main.c:35
-#: ../raster/r.out.ascii/main.c:59 ../raster/r.slope.aspect/main.c:152
-#: ../raster/r.bitpattern/main.c:63 ../raster/r.to.vect/main.c:70
-#: ../raster/r.series.interp/main.c:64 ../raster/r.out.ppm3/main.c:56
-#: ../raster/r.resamp.bspline/main.c:81 ../raster/r.transect/main.c:103
-#: ../raster/r.surf.idw/main.c:103 ../raster/r.surf.area/main.c:76
-#: ../raster/r.grow/main.c:122 ../raster/r.neighbors/main.c:117
-#: ../raster/r.resamp.interp/main.c:76 ../raster/r.proj/main.c:146
-#: ../raster/r.info/main.c:69 ../raster/r.reclass/main.c:50
-#: ../raster/r.coin/main.c:66 ../raster/r.texture/main.c:101
-#: ../raster/r.in.gdal/main.c:81 ../raster/r.horizon/main.c:177
-#: ../raster/simwe/r.sim.sediment/main.c:111
-#: ../raster/simwe/r.sim.water/main.c:110 ../raster/r.thin/main.c:56
-#: ../raster/r.covar/main.c:51 ../raster/r.out.gdal/main.c:129
-#: ../raster/r.lake/main.c:150 ../raster/r.surf.gauss/main.c:38
-#: ../raster/r.in.poly/main.c:29 ../raster/r.in.ascii/main.c:69
-#: ../raster/r.what.color/main.c:88 ../raster/r.out.vrml/main.c:47
-#: ../raster/r.surf.fractal/main.c:38 ../raster/r.out.gridatb/main.c:67
-#: ../raster/r.resamp.filter/main.c:384 ../raster/r.to.rast3elev/main.c:361
-#: ../raster/r.mapcalc/main.c:111 ../raster/r.flow/main.c:421
-#: ../display/d.profile/main.c:192 ../display/d.what.rast/main.c:49
-#: ../display/d.rast.num/main.c:72 ../display/d.colortable/main.c:61
-#: ../display/d.colors/main.c:41 ../display/d.rast/main.c:54
-#: ../display/d.rgb/main.c:54 ../display/d.rast.arrow/main.c:96
-#: ../vector/v.sample/main.c:76 ../vector/v.neighbors/main.c:50
-#: ../vector/v.what.rast/main.c:69 ../vector/v.to.rast/main.c:41
-#: ../locale/scriptstrings/t.time.abs_to_translate.c:4
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:3
-#: ../locale/scriptstrings/r.blend_to_translate.c:2
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:2
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:2
-#: ../locale/scriptstrings/tr.aggregate.ds_to_translate.c:3
-#: ../locale/scriptstrings/tr.import_to_translate.c:4
-#: ../locale/scriptstrings/r.unpack_to_translate.c:2
-#: ../locale/scriptstrings/r.mask_to_translate.c:2
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:2
-#: ../locale/scriptstrings/tr.extract_to_translate.c:3
-#: ../locale/scriptstrings/tr.aggregate_to_translate.c:3
-#: ../locale/scriptstrings/v.krige_to_translate.c:3
-#: ../locale/scriptstrings/r.pack_to_translate.c:2
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:2
-#: ../locale/scriptstrings/i.spectral_to_translate.c:3
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
-#: ../locale/scriptstrings/r.plane_to_translate.c:2
-#: ../locale/scriptstrings/t.time.rel_to_translate.c:4
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:2
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:2
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:3
-#: ../locale/scriptstrings/tr.out.vtk_to_translate.c:4
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:2
-#: ../locale/scriptstrings/tr.unregister_to_translate.c:3
-#: ../locale/scriptstrings/tr.list_to_translate.c:4
-#: ../locale/scriptstrings/tr.univar_to_translate.c:3
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:3
-#: ../locale/scriptstrings/i.oif_to_translate.c:2
-#: ../locale/scriptstrings/r.grow_to_translate.c:2
-#: ../locale/scriptstrings/r.buffer_to_translate.c:2
-#: ../locale/scriptstrings/d.correlate_to_translate.c:3
-#: ../locale/scriptstrings/tr.series_to_translate.c:3
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:2
-#: ../locale/scriptstrings/r.tileset_to_translate.c:2
-#: ../locale/scriptstrings/tr.export_to_translate.c:4
-#: ../locale/scriptstrings/tr.register_to_translate.c:3
-#: ../locale/scriptstrings/tr.to.rast3_to_translate.c:4
-#: ../locale/scriptstrings/t.sample_to_translate.c:4
-msgid "raster"
-msgstr ""
-#: ../visualization/nviz/src/nvizMain.c:73 ../raster3d/r3.mask/main.c:132
-#: ../raster3d/r3.retile/main.c:101
-#: ../raster3d/r3.timestamp/r3.timestamp.main.c:43
-#: ../raster3d/r3.null/main.c:185 ../raster3d/r3.in.v5d/main.c:192
-#: ../raster3d/r3.info/r3.info.main.c:79 ../raster3d/r3.gwflow/main.c:159
-#: ../raster3d/r3.mkdspf/main.c:79 ../raster3d/r3.out.ascii/main.c:308
-#: ../raster3d/r3.out.v5d/main.c:286 ../raster3d/r3.to.rast/main.c:206
-#: ../raster3d/r3.cross.rast/main.c:228 ../raster3d/r3.out.vtk/main.c:376
-#: ../raster3d/r3.in.ascii/main.c:325 ../raster3d/r3.stats/main.c:568
-#: ../misc/m.nviz.script/main.c:71 ../misc/m.nviz.image/main.c:53
-#: ../raster/r.colors.out/raster3d_main.c:46
-#: ../raster/r.colors/edit_colors.c:56 ../raster/r.univar/r3.univar_main.c:99
-#: ../raster/r.to.rast3elev/main.c:362
-#: ../locale/scriptstrings/t.time.abs_to_translate.c:6
-#: ../locale/scriptstrings/t.time.rel_to_translate.c:6
-#: ../locale/scriptstrings/tr3.register_to_translate.c:3
-#: ../locale/scriptstrings/tr3.unregister_to_translate.c:3
-#: ../locale/scriptstrings/tr.to.rast3_to_translate.c:5
-#: ../locale/scriptstrings/tr3.extract_to_translate.c:3
-#: ../locale/scriptstrings/tr3.list_to_translate.c:4
-#, fuzzy
-msgid "raster3d"
-#: ../visualization/nviz/src/nvizMain.c:74
-#: ../visualization/ximgview/main.c:292 ../doc/vector/v.example/main.c:50
-#: ../misc/m.nviz.script/main.c:72 ../misc/m.nviz.image/main.c:52
-#: ../raster/r.contour/main.c:89 ../raster/r.random/main.c:53
-#: ../display/d.vect/main.c:71 ../display/d.what.vect/main.c:57
-#: ../display/d.extract/main.c:50 ../vector/v.random/main.c:85
-#: ../vector/v.net.iso/main.c:72 ../vector/v.net.centrality/main.c:96
-#: ../vector/v.type/main.c:39 ../vector/v.colors.out/main.c:49
-#: ../vector/v.voronoi/main.c:120 ../vector/v.net.steiner/main.c:345
-#: ../vector/v.overlay/main.c:58 ../vector/v.kernel/main.c:106
-#: ../vector/v.in.ogr/main.c:121 ../vector/v.net/main.c:45
-#: ../vector/v.proj/main.c:66 ../vector/v.label/main.c:59
-#: ../vector/v.univar/main.c:63 ../vector/v.net.distance/main.c:61
-#: ../vector/v.lrs/v.lrs.segment/main.c:70
-#: ../vector/v.lrs/v.lrs.where/main.c:57
-#: ../vector/v.lrs/v.lrs.create/main.c:121
-#: ../vector/v.lrs/v.lrs.label/main.c:102 ../vector/v.out.ascii/main.c:45
-#: ../vector/v.parallel/main.c:47 ../vector/v.support/main.c:39
-#: ../vector/v.outlier/main.c:68 ../vector/v.build/main.c:37
-#: ../vector/v.edit/main.c:55 ../vector/v.in.dwg/main.c:82
-#: ../vector/v.net.alloc/main.c:60 ../vector/v.kcv/main.c:67
-#: ../vector/v.extract/main.c:78 ../vector/v.db.connect/main.c:51
-#: ../vector/v.in.ascii/main.c:48 ../vector/v.colors/main.c:55
-#: ../vector/v.sample/main.c:75 ../vector/v.distance/main.c:83
-#: ../vector/v.to.db/main.c:36 ../vector/v.mkgrid/main.c:64
-#: ../vector/v.net.bridge/main.c:46 ../vector/v.build.polylines/main.c:111
-#: ../vector/v.delaunay/main.c:85 ../vector/v.qcount/main.c:60
-#: ../vector/v.category/main.c:73 ../vector/v.net.flow/main.c:58
-#: ../vector/v.in.region/main.c:38 ../vector/v.buffer/main.c:210
-#: ../vector/v.surf.rst/main.c:142 ../vector/v.transform/main.c:69
-#: ../vector/v.reclass/main.c:67 ../vector/v.neighbors/main.c:49
-#: ../vector/v.net.timetable/main.c:260 ../vector/v.out.svg/main.c:73
-#: ../vector/v.external/main.c:48 ../vector/v.normal/main.c:74
-#: ../vector/v.lidar.edgedetection/main.c:72 ../vector/v.out.ogr/main.c:82
-#: ../vector/v.patch/main.c:68 ../vector/v.net.spanningtree/main.c:46
-#: ../vector/v.out.pov/main.c:46 ../vector/v.select/main.c:47
-#: ../vector/v.convert/main.c:36 ../vector/v.in.sites/main.c:57
-#: ../vector/v.clean/test/topocheck.c:42 ../vector/v.clean/main.c:49
-#: ../vector/v.external.out/main.c:34 ../vector/v.perturb/main.c:61
-#: ../vector/v.vect.stats/main.c:128 ../vector/v.class/main.c:44
-#: ../vector/v.net.allpairs/main.c:56 ../vector/v.info/main.c:37
-#: ../vector/v.info/print.c:319 ../vector/v.net.components/main.c:70
-#: ../vector/v.lidar.correction/main.c:68 ../vector/v.to.3d/main.c:37
-#: ../vector/v.db.select/main.c:52 ../vector/v.in.dxf/main.c:64
-#: ../vector/v.split/main.c:52 ../vector/v.what.rast/main.c:68
-#: ../vector/v.net.salesman/main.c:104 ../vector/v.to.points/main.c:172
-#: ../vector/v.extrude/main.c:69 ../vector/v.segment/main.c:54
-#: ../vector/v.what/main.c:60 ../vector/v.generalize/main.c:76
-#: ../vector/v.vol.rst/main.c:240 ../vector/v.to.rast3/main.c:48
-#: ../vector/v.label.sa/main.c:38 ../vector/v.in.db/main.c:52
-#: ../vector/v.surf.idw/main.c:85 ../vector/v.hull/main.c:50
-#: ../vector/v.out.dxf/main.c:56 ../vector/v.drape/main.c:140
-#: ../vector/v.net.path/main.c:40 ../vector/v.rectify/main.c:63
-#: ../vector/v.timestamp/main.c:36 ../vector/v.net.connectivity/main.c:53
-#: ../vector/v.surf.bspline/main.c:91 ../vector/v.lidar.growing/main.c:75
-#: ../vector/v.to.rast/main.c:40 ../vector/v.out.vtk/main.c:47
-#: ../vector/v.net.visibility/main.c:45 ../vector/v.in.lidar/main.c:153
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:2
-#: ../locale/scriptstrings/tv.list_to_translate.c:4
-#: ../locale/scriptstrings/t.time.abs_to_translate.c:5
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:2
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:3
-#: ../locale/scriptstrings/v.db.droprow_to_translate.c:2
-#: ../locale/scriptstrings/tv.unregister_to_translate.c:3
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:2
-#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:2
-#: ../locale/scriptstrings/v.db.join_to_translate.c:2
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:2
-#: ../locale/scriptstrings/v.report_to_translate.c:2
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:2
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:2
-#: ../locale/scriptstrings/tv.register_to_translate.c:3
-#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:2
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:2
-#: ../locale/scriptstrings/t.time.rel_to_translate.c:5
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:2
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:2
-#: ../locale/scriptstrings/v.db.update_to_translate.c:2
-#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:3
-#: ../locale/scriptstrings/v.centroids_to_translate.c:2
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:2
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:2
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:2
-#: ../locale/scriptstrings/v.convert.all_to_translate.c:2
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:2
-#: ../locale/scriptstrings/v.build.all_to_translate.c:2
-#: ../locale/scriptstrings/v.out.gps_to_translate.c:2
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:2
-msgid "vector"
-msgstr ""
-#: ../visualization/nviz/src/nvizMain.c:75
-#: ../visualization/ximgview/main.c:290 ../misc/m.nviz.script/main.c:69
-#: ../display/d.histogram/main.c:84 ../display/d.vect/main.c:70
-#: ../display/d.rhumbline/main.c:43 ../display/d.where/main.c:43
-#: ../display/d.what.vect/main.c:56 ../display/d.text/main.c:139
-#: ../display/d.linegraph/main.c:119 ../display/d.profile/main.c:191
-#: ../display/d.what.rast/main.c:48 ../display/d.info/main.c:31
-#: ../display/d.vect.chart/main.c:63 ../display/d.barscale/main.c:53
-#: ../display/d.erase/main.c:29 ../display/d.zoom/main.c:61
-#: ../display/d.rast.num/main.c:71 ../display/d.grid/main.c:51
-#: ../display/d.colorlist/main.c:35 ../display/d.his/main.c:62
-#: ../display/d.geodesic/main.c:43 ../display/d.labels/main.c:43
-#: ../display/d.mon/main.c:37 ../display/d.colortable/main.c:60
-#: ../display/d.colors/main.c:40 ../display/d.rast/main.c:53
-#: ../display/d.thematic.area/main.c:76 ../display/d.fontlist/main.c:38
-#: ../display/d.graph/main.c:58 ../display/d.rgb/main.c:53
-#: ../display/d.path/main.c:48 ../display/d.rast.arrow/main.c:95
-#: ../display/d.extract/main.c:49 ../display/d.legend/main.c:84
-#: ../display/d.measure/main.c:46 ../display/d.title/main.c:49
-#: ../display/d.font/main.c:46
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:2
-#: ../locale/scriptstrings/d.redraw_to_translate.c:2
-#: ../locale/scriptstrings/d.polar_to_translate.c:2
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:2
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:2
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:2
-#: ../locale/scriptstrings/d.correlate_to_translate.c:2
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:2
-msgid "display"
-msgstr ""
-#: ../visualization/nviz/src/nvizMain.c:77
-msgid "nviz - Visualization and animation tool for GRASS data."
-msgstr ""
-#: ../visualization/nviz/src/nvizMain.c:82
-#, fuzzy
-msgid "Name of raster map(s) for Elevation"
-#: ../visualization/nviz/src/nvizMain.c:83
-#: ../visualization/nviz/src/nvizMain.c:92
-#: ../visualization/nviz/src/nvizMain.c:119 ../general/g.mremove/main.c:86
-msgid "Raster"
-msgstr ""
-#: ../visualization/nviz/src/nvizMain.c:91
-#, fuzzy
-msgid "Name of raster map(s) for Color"
-#: ../visualization/nviz/src/nvizMain.c:100
-#, fuzzy
-msgid "Name of vector lines/areas overlay map(s)"
-#: ../visualization/nviz/src/nvizMain.c:101
-#: ../visualization/nviz/src/nvizMain.c:110
-msgid "Vector"
-msgstr ""
-#: ../visualization/nviz/src/nvizMain.c:109
-#, fuzzy
-msgid "Name of vector points overlay file(s)"
-#: ../visualization/nviz/src/nvizMain.c:118
-#, fuzzy
-msgid "Name of existing 3d raster map"
-#: ../visualization/nviz/src/nvizMain.c:123
-msgid "Quickstart - Do not load any data"
-msgstr ""
-#: ../visualization/nviz/src/nvizMain.c:128
-msgid "Exit after completing script launched from the command line"
-msgstr ""
-#: ../visualization/nviz/src/nvizMain.c:133
-msgid "Start in Demo mode (skip the \"please wait\" message)"
-msgstr ""
-#: ../visualization/nviz/src/nvizMain.c:139
-msgid "Set alternative panel path"
-msgstr ""
-#: ../visualization/nviz/src/nvizMain.c:145
-msgid "Execute script file at startup"
-msgstr ""
-#: ../visualization/nviz/src/nvizMain.c:151
-msgid "Load previously saved state file"
-msgstr ""
-#: ../visualization/nviz/src/nviz_init.c:148
-msgid "Number of elevation files does not match number of colors files"
-msgstr ""
-#: ../visualization/nviz/src/nviz_init.c:159
-#, fuzzy
-msgid "Loading data failed"
-#: ../visualization/ximgview/main.c:64 ../general/g.cairocomp/main.c:88
-#: ../general/g.cairocomp/main.c:260
-#, fuzzy
-msgid "Unable to open display"
-#: ../visualization/ximgview/main.c:84
-#, fuzzy
-msgid "Unable to get window attributes"
-msgstr "डेटाबेसची यादी दाखवता येणार नाही"
-#: ../visualization/ximgview/main.c:258
-#, fuzzy
-msgid "Unable to open image file"
-#: ../visualization/ximgview/main.c:261
-#, fuzzy
-msgid "Unable to read BMP header"
-#: ../visualization/ximgview/main.c:264
-#, fuzzy
-msgid "Invalid BMP header"
-#: ../visualization/ximgview/main.c:270
-#, fuzzy
-msgid "Unable to map image file"
-#: ../visualization/ximgview/main.c:294
-msgid "View BMP images from the PNG driver."
-msgstr ""
-#: ../visualization/ximgview/main.c:302
-msgid "Image file"
-msgstr ""
-#: ../visualization/ximgview/main.c:309
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:5
-msgid "Percentage of CPU time to use"
-msgstr ""
-#: ../visualization/ximgview/color.c:90 ../visualization/ximgview/color.c:288
-#, c-format
-msgid "Unknown visual class [%d]."
-msgstr ""
-#: ../visualization/ximgview/color.c:239
-msgid "Unable to get sufficient gray shades."
-msgstr ""
-#: ../visualization/ximgview/color.c:256
-msgid "Unable to get sufficient colors."
-msgstr ""
-#: ../visualization/ximgview/color.c:269
-msgid "Using private colormap for DirectColor visual."
-msgstr ""
-#: ../doc/raster/r.example/main.c:84 ../doc/vector/v.example/main.c:51
-msgid "keyword2"
-msgstr ""
-#: ../doc/raster/r.example/main.c:85 ../doc/vector/v.example/main.c:52
-msgid "keyword3"
-msgstr ""
-#: ../doc/raster/r.example/main.c:86
-msgid "My first raster module"
-msgstr ""
-#: ../doc/raster/r.example/main.c:105 ../misc/m.nviz.image/surface.c:50
-#: ../misc/m.nviz.image/surface.c:107 ../raster/r.category/main.c:127
-#: ../raster/r.category/main.c:148 ../raster/r.cross/main.c:110
-#: ../raster/r.distance/parse.c:64 ../raster/r.distance/parse.c:71
-#: ../raster/r.spread/main.c:358 ../raster/r.spread/main.c:361
-#: ../raster/r.spread/main.c:364 ../raster/r.spread/main.c:368
-#: ../raster/r.spread/main.c:371 ../raster/r.spread/main.c:374
-#: ../raster/r.cost/main.c:356 ../raster/r.cost/main.c:673
-#: ../raster/r.los/main.c:174 ../raster/r.los/main.c:180
-#: ../raster/r.buffer/main.c:112 ../raster/r.walk/main.c:447
-#: ../raster/r.walk/main.c:452 ../raster/r.walk/main.c:854
-#: ../raster/r.ros/main.c:291 ../raster/r.ros/main.c:302
-#: ../raster/r.ros/main.c:307 ../raster/r.ros/main.c:312
-#: ../raster/r.ros/main.c:317 ../raster/r.ros/main.c:331
-#: ../raster/r.ros/main.c:335 ../raster/r.ros/main.c:350
-#: ../raster/r.ros/main.c:354 ../raster/r.ros/main.c:365
-#: ../raster/r.colors/edit_colors.c:268 ../raster/r.kappa/main.c:144
-#: ../raster/r.kappa/stats.c:33 ../raster/r.kappa/stats.c:38
-#: ../raster/r.report/parse.c:245 ../raster/r.carve/main.c:164
-#: ../raster/r.null/main.c:121 ../raster/r.univar/r.univar_main.c:215
-#: ../raster/r.info/main.c:99 ../raster/r.reclass/main.c:79
-#: ../raster/r.coin/main.c:127 ../raster/r.coin/main.c:129
-#: ../raster/simwe/simlib/output.c:346 ../raster/simwe/simlib/output.c:355
-#: ../raster/simwe/simlib/output.c:386 ../raster/simwe/simlib/output.c:395
-#: ../raster/simwe/simlib/output.c:441 ../raster/simwe/simlib/output.c:458
-#: ../raster/simwe/simlib/output.c:480 ../raster/simwe/simlib/output.c:519
-#: ../raster/simwe/simlib/output.c:556 ../raster/simwe/simlib/output.c:723
-#: ../raster/r.mapcalc/map.c:506 ../raster/r.flow/io.c:65
-#: ../imagery/i.group/main.c:204 ../imagery/i.group/main.c:243
-#: ../imagery/i.gensig/parse.c:36 ../imagery/i.gensigset/parse.c:42
-#: ../display/d.what.rast/main.c:118 ../display/d.what.rast/opencell.c:13
-#: ../general/g.region/main.c:463 ../general/g.region/main.c:787
-#: ../general/g.region/main.c:795 ../vector/v.colors/main.c:264
-#: ../vector/v.vol.rst/main.c:649
-#, c-format
-msgid "Raster map <%s> not found"
-msgstr ""
-#: ../doc/vector/v.example/main.c:53
-msgid "My first vector module"
-msgstr ""
-#: ../doc/vector/v.example/main.c:75 ../misc/m.nviz.image/vector.c:83
-#: ../raster/r.cost/main.c:331 ../raster/r.walk/main.c:422
-#: ../raster/r.carve/main.c:158 ../display/d.what.vect/main.c:133
-#: ../display/d.extract/main.c:98 ../general/g.region/main.c:512
-#: ../vector/v.lrs/v.lrs.segment/main.c:139
-#: ../vector/v.lrs/v.lrs.where/main.c:127
-#: ../vector/v.lrs/v.lrs.where/main.c:135
-#: ../vector/v.lrs/v.lrs.create/main.c:251
-#: ../vector/v.lrs/v.lrs.create/main.c:258
-#: ../vector/v.lrs/v.lrs.label/main.c:287 ../vector/v.outlier/main.c:152
-#: ../vector/v.edit/main.c:140 ../vector/v.colors/main.c:202
-#: ../vector/v.lidar.edgedetection/main.c:213 ../vector/v.convert/att.c:31
-#: ../vector/v.convert/old2new.c:26 ../vector/v.clean/test/topocheck.c:63
-#: ../vector/v.vect.stats/main.c:254 ../vector/v.vect.stats/main.c:261
-#: ../vector/v.lidar.correction/main.c:178 ../vector/v.surf.bspline/main.c:251
-#: ../vector/v.surf.bspline/main.c:311 ../vector/v.lidar.growing/main.c:126
-#, c-format
-msgid "Vector map <%s> not found"
-msgstr ""
-#: ../doc/vector/v.example/main.c:81
-#, fuzzy
-msgid "Unable to set predetermined vector open level"
-#: ../doc/vector/v.example/main.c:87 ../misc/m.nviz.image/vector.c:246
-#: ../raster/r.drain/main.c:270 ../raster/r.cost/main.c:546
-#: ../raster/r.cost/main.c:614 ../raster/r.walk/main.c:729
-#: ../raster/r.walk/main.c:795 ../raster/r.region/main.c:202
-#: ../raster/simwe/simlib/observation_points.c:39
-#: ../display/d.what.vect/main.c:111 ../vector/v.net.centrality/main.c:209
-#: ../vector/v.net/main.c:66 ../vector/v.net/main.c:90
-#: ../vector/v.net.distance/main.c:156 ../vector/v.out.ascii/main.c:83
-#: ../vector/v.support/main.c:130 ../vector/v.edit/main.c:155
-#: ../vector/v.net.bridge/main.c:113 ../vector/v.net.flow/main.c:143
-#: ../vector/v.surf.rst/main.c:535 ../vector/v.surf.rst/main.c:618
-#: ../vector/v.net.timetable/main.c:354
-#: ../vector/v.lidar.edgedetection/main.c:219
-#: ../vector/v.net.spanningtree/main.c:101 ../vector/v.net.allpairs/main.c:127
-#: ../vector/v.info/main.c:60 ../vector/v.net.components/main.c:142
-#: ../vector/v.lidar.correction/main.c:182 ../vector/v.to.3d/main.c:73
-#: ../vector/v.generalize/main.c:293 ../vector/v.hull/main.c:81
-#: ../vector/v.net.connectivity/main.c:132
-#: ../vector/v.lidar.growing/main.c:138 ../vector/v.lidar.growing/main.c:142
-#: ../vector/v.net.visibility/main.c:78 ../vector/v.net.visibility/main.c:87
-#, fuzzy, c-format
-msgid "Unable to open vector map <%s>"
-#: ../doc/vector/v.example/main.c:98 ../raster/r.drain/main.c:202
-#: ../raster/r.resamp.bspline/main.c:484 ../raster/r.flow/io.c:175
-#: ../vector/v.net.centrality/main.c:215 ../vector/v.net.distance/main.c:162
-#: ../vector/v.outlier/main.c:201 ../vector/v.outlier/main.c:206
-#: ../vector/v.outlier/main.c:212 ../vector/v.edit/main.c:108
-#: ../vector/v.mkgrid/main.c:211 ../vector/v.net.bridge/main.c:119
-#: ../vector/v.delaunay/main.c:125 ../vector/v.net.flow/main.c:149
-#: ../vector/v.net.flow/main.c:155 ../vector/v.surf.rst/main.c:712
-#: ../vector/v.net.timetable/main.c:360
-#: ../vector/v.lidar.edgedetection/main.c:241
-#: ../vector/v.net.spanningtree/main.c:107 ../vector/v.net.allpairs/main.c:133
-#: ../vector/v.net.components/main.c:148
-#: ../vector/v.lidar.correction/main.c:205
-#: ../vector/v.lidar.correction/main.c:211 ../vector/v.to.3d/main.c:89
-#: ../vector/v.in.dxf/main.c:148 ../vector/v.generalize/main.c:299
-#: ../vector/v.hull/main.c:106 ../vector/v.drape/main.c:296
-#: ../vector/v.drape/main.c:336 ../vector/v.net.path/main.c:134
-#: ../vector/v.net.connectivity/main.c:138 ../vector/v.surf.bspline/main.c:331
-#: ../vector/v.net.visibility/main.c:82
-#, fuzzy, c-format
-msgid "Unable to create vector map <%s>"
-#: ../doc/vector/v.example/main.c:105 ../display/d.vect/shape.c:31
-#: ../display/d.vect.chart/plot.c:37 ../display/d.thematic.area/plot1.c:105
-#: ../vector/v.overlay/main.c:285 ../vector/v.edit/select.c:499
-#: ../vector/v.colors/scan_attr.c:26 ../vector/v.colors/write_rgb.c:20
-#: ../vector/v.colors/read_rgb.c:23 ../vector/v.distance/main.c:423
-#: ../vector/v.buffer/main.c:366 ../vector/v.vect.stats/main.c:305
-#: ../vector/v.vect.stats/main.c:381 ../vector/v.what.rast/main.c:111
-#: ../vector/v.extrude/main.c:166 ../vector/v.generalize/misc.c:162
-#: ../vector/v.drape/main.c:228 ../vector/v.surf.bspline/crosscorr.c:109
-#: ../vector/v.to.rast/support.c:127 ../vector/v.to.rast/support.c:284
-#, c-format
-msgid "Database connection not defined for layer %d"
-msgstr ""
-#: ../doc/vector/v.example/main.c:126 ../display/d.vect/opt.c:147
-#: ../display/d.thematic.area/main.c:200 ../vector/v.edit/select.c:506
-#: ../vector/v.db.connect/main.c:215 ../vector/v.db.connect/main.c:281
-#: ../vector/v.out.svg/main.c:137 ../vector/v.in.sites/main.c:160
-#: ../vector/v.drape/main.c:245 ../db/db.select/main.c:66
-#: ../db/db.databases/main.c:51 ../db/db.execute/main.c:65
-#: ../db/db.tables/main.c:45 ../db/db.dropdb/main.c:42
-#: ../db/db.describe/main.c:51 ../db/db.columns/main.c:44
-#: ../db/db.createdb/main.c:42
-#, fuzzy, c-format
-msgid "Unable to start driver <%s>"
-#: ../doc/vector/v.example/main.c:131 ../misc/m.nviz.image/vector.c:252
-#: ../raster/r.contour/main.c:161 ../raster/r.random/random.c:73
-#: ../raster/r.to.vect/main.c:168 ../ps/ps.map/catval.c:54
-#: ../ps/ps.map/catval.c:116 ../ps/ps.map/catval.c:182
-#: ../display/d.vect/attr.c:43 ../display/d.vect/shape.c:37
-#: ../display/d.vect.chart/plot.c:43 ../display/d.thematic.area/plot1.c:111
-#: ../vector/v.random/main.c:177 ../vector/v.net.centrality/main.c:243
-#: ../vector/v.colors.out/make_colors.c:35 ../vector/v.overlay/main.c:188
-#: ../vector/v.overlay/main.c:293 ../vector/v.label/main.c:277
-#: ../vector/v.net.distance/main.c:213 ../vector/v.lrs/v.lrs.create/main.c:288
-#: ../vector/v.lrs/v.lrs.create/main.c:296 ../vector/v.edit/select.c:513
-#: ../vector/v.in.dwg/main.c:212 ../vector/v.kcv/main.c:166
-#: ../vector/v.extract/main.c:259 ../vector/v.db.connect/main.c:221
-#: ../vector/v.db.connect/main.c:329 ../vector/v.in.ascii/main.c:316
-#: ../vector/v.colors/scan_attr.c:31 ../vector/v.colors/write_rgb.c:25
-#: ../vector/v.colors/read_rgb.c:28 ../vector/v.sample/main.c:180
-#: ../vector/v.distance/main.c:393 ../vector/v.distance/main.c:429
-#: ../vector/v.to.db/query.c:89 ../vector/v.to.db/update.c:46
-#: ../vector/v.mkgrid/main.c:225 ../vector/v.net.flow/main.c:169
-#: ../vector/v.buffer/main.c:371 ../vector/v.surf.rst/main.c:573
-#: ../vector/v.transform/trans_digit.c:38 ../vector/v.reclass/main.c:130
-#: ../vector/v.net.timetable/main.c:93 ../vector/v.out.svg/main.c:144
-#: ../vector/v.normal/main.c:121 ../vector/v.out.ogr/main.c:571
-#: ../vector/v.patch/main.c:138 ../vector/v.patch/main.c:168
-#: ../vector/v.patch/main.c:282 ../vector/v.patch/main.c:339
-#: ../vector/v.in.sites/main.c:165 ../vector/v.class/main.c:106
-#: ../vector/v.net.allpairs/main.c:160 ../vector/v.info/print.c:147
-#: ../vector/v.net.components/main.c:173 ../vector/v.to.3d/trans3.c:56
-#: ../vector/v.to.3d/trans2.c:54 ../vector/v.db.select/main.c:148
-#: ../vector/v.in.dxf/write_vect.c:211 ../vector/v.what.rast/main.c:117
-#: ../vector/v.to.points/main.c:283 ../vector/v.extrude/main.c:171
-#: ../vector/v.vol.rst/main.c:633 ../vector/v.vol.rst/user1.c:99
-#: ../vector/v.to.rast3/main.c:82 ../vector/v.label.sa/labels.c:77
-#: ../vector/v.in.db/main.c:122 ../vector/v.surf.idw/read_sites.c:41
-#: ../vector/v.drape/main.c:250 ../vector/v.net.path/path.c:96
-#: ../vector/v.surf.bspline/main.c:371
-#: ../vector/v.surf.bspline/crosscorr.c:118 ../vector/v.to.rast/support.c:132
-#: ../vector/v.to.rast/support.c:290 ../vector/v.to.rast/vect2rast.c:53
-#, fuzzy, c-format
-msgid "Unable to open database <%s> by driver <%s>"
-#: ../doc/vector/v.example/main.c:137 ../vector/v.random/main.c:216
-#: ../vector/v.db.connect/main.c:226 ../vector/v.in.ascii/main.c:407
-#: ../vector/v.reclass/main.c:177 ../vector/v.out.svg/main.c:150
-#: ../vector/v.out.ogr/main.c:576 ../vector/v.patch/main.c:145
-#: ../vector/v.patch/main.c:183 ../vector/v.info/print.c:152
-#: ../vector/v.drape/main.c:256 ../db/db.describe/main.c:62
-#, fuzzy, c-format
-msgid "Unable to describe table <%s>"
-#: ../doc/vector/v.example/main.c:170
-#, fuzzy, c-format
-msgid "Unable to get attribute data for cat %d"
-#: ../doc/vector/v.example/main.c:179
-#, c-format
-msgid "Error while retrieving database record for cat %d"
-msgstr ""
-#: ../doc/vector/v.example/main.c:212
-#, fuzzy, c-format
-msgid "Unable to copy attribute table to vector map <%s>"
-#: ../raster3d/r3.mask/main.c:57 ../raster3d/r3.null/main.c:102
-#: ../raster3d/r3.out.ascii/main.c:330 ../raster3d/r3.out.v5d/main.c:309
-#: ../raster3d/r3.to.rast/main.c:221 ../raster3d/r3.cross.rast/main.c:244
-#: ../raster3d/r3.out.vtk/main.c:142 ../raster3d/r3.stats/main.c:612
-#: ../raster/r.colors/edit_colors.c:275
-#: ../raster/r.univar/r3.univar_main.c:147
-#: ../raster/r.univar/r3.univar_main.c:185 ../general/g.region/main.c:489
-#: ../vector/v.colors/main.c:271
-#, c-format
-msgid "3D raster map <%s> not found"
-msgstr ""
-#: ../raster3d/r3.mask/main.c:63 ../raster3d/r3.null/main.c:109
-#: ../raster3d/r3.info/r3.info.main.c:135 ../raster3d/r3.out.v5d/main.c:314
-#: ../raster3d/r3.cross.rast/main.c:278 ../raster3d/r3.out.vtk/main.c:207
-#: ../raster3d/r3.out.vtk/main.c:292 ../raster3d/r3.out.vtk/main.c:512
-#: ../raster3d/r3.stats/main.c:619 ../raster/r.univar/r3.univar_main.c:154
-#: ../raster/r.univar/r3.univar_main.c:192
-#, fuzzy, c-format
-msgid "Unable to open 3D raster map <%s>"
-#: ../raster3d/r3.mask/main.c:74
-#, fuzzy
-msgid "Unable to open 3D raster mask file"
-#: ../raster3d/r3.mask/main.c:103
-msgid "makeMask: error flushing tiles in cube"
-msgstr ""
-#: ../raster3d/r3.mask/main.c:108
-msgid "makeMask: error flushing all tiles"
-msgstr ""
-#: ../raster3d/r3.mask/main.c:116
-#, fuzzy
-msgid "Unable to close 3D raster mask file"
-#: ../raster3d/r3.mask/main.c:118
-#, fuzzy, c-format
-msgid "Unable to close raster map <%s>"
-#: ../raster3d/r3.mask/main.c:133 ../raster3d/r3.retile/main.c:103
-#: ../raster3d/r3.timestamp/r3.timestamp.main.c:44
-#: ../raster3d/r3.null/main.c:186 ../raster3d/r3.in.v5d/main.c:193
-#: ../raster3d/r3.info/r3.info.main.c:80 ../raster3d/r3.gwflow/main.c:160
-#: ../raster3d/r3.mkdspf/main.c:80 ../raster3d/r3.out.ascii/main.c:309
-#: ../raster3d/r3.out.v5d/main.c:287 ../raster3d/r3.to.rast/main.c:208
-#: ../raster3d/r3.cross.rast/main.c:230 ../raster3d/r3.out.vtk/main.c:377
-#: ../raster3d/r3.in.ascii/main.c:326 ../raster/r.to.rast3elev/main.c:363
-msgid "voxel"
-msgstr ""
-#: ../raster3d/r3.mask/main.c:135
-msgid "Establishes the current working 3D raster mask."
-msgstr ""
-#: ../raster3d/r3.mask/main.c:143
-#, fuzzy
-msgid "3D raster map with reference values"
-#: ../raster3d/r3.mask/main.c:151
-msgid "List of cell values to be masked out"
-msgstr ""
-#: ../raster3d/r3.mask/main.c:157
-msgid "Cannot create mask file: RASTER3D_MASK already exists"
-msgstr ""
-#: ../raster3d/r3.retile/main.c:54
-#, fuzzy
-msgid "Unable to close the 3d raster map"
-#: ../raster3d/r3.retile/main.c:76
-#, fuzzy
-msgid "Name of the retiled 3D raster map"
-#: ../raster3d/r3.retile/main.c:102
-msgid "retile"
-msgstr ""
-#: ../raster3d/r3.retile/main.c:104
-msgid "Retiles an existing RASTER3D map with user defined x, y and z tile size"
-msgstr ""
-#: ../raster3d/r3.retile/main.c:113
-#, c-format
-msgid "Open 3d raster map <%s>"
-msgstr ""
-#: ../raster3d/r3.retile/main.c:118 ../misc/m.nviz.image/volume.c:42
-#: ../misc/m.nviz.image/volume.c:125
-#, fuzzy, c-format
-msgid "3d raster map <%s> not found"
-#: ../raster3d/r3.retile/main.c:132
-#, fuzzy, c-format
-msgid "Unable to open 3d raster map <%s>"
-#: ../raster3d/r3.retile/main.c:140
-msgid "Rast3d_get_standard3d_params: tile dimension value invalid"
-msgstr ""
-#: ../raster3d/r3.retile/main.c:153 ../raster/r.to.rast3/main.c:326
-#: ../raster/r.to.rast3elev/main.c:501
-msgid "Error closing 3d raster map"
-msgstr ""
-#: ../raster3d/r3.timestamp/r3.timestamp.main.c:46
-msgid "Print/add/remove a timestamp for a 3D raster map"
-msgstr ""
-#: ../raster3d/r3.timestamp/r3.timestamp.main.c:55
-msgid "Datetime, datetime1/datetime2, or none"
-msgstr ""
-#: ../raster3d/r3.timestamp/r3.timestamp.main.c:70
-#, fuzzy, c-format
-msgid "Raster3d map <%s> not found %s"
-#: ../raster3d/r3.null/main.c:54
-msgid "3d raster map for which to modify null values"
-msgstr ""
-#: ../raster3d/r3.null/main.c:62 ../raster/r.null/main.c:72
-msgid "List of cell values to be set to NULL"
-msgstr ""
-#: ../raster3d/r3.null/main.c:69 ../raster/r.null/main.c:80
-msgid "The value to replace the null value by"
-msgstr ""
-#: ../raster3d/r3.null/main.c:84
-msgid "Illegal value for null"
-msgstr ""
-#: ../raster3d/r3.null/main.c:121
-msgid "modifyNull: error opening tmp file"
-msgstr ""
-#: ../raster3d/r3.null/main.c:155
-msgid "modifyNull: error flushing tiles in cube"
-msgstr ""
-#: ../raster3d/r3.null/main.c:160
-msgid "modifyNull: error flushing all tiles"
-msgstr ""
-#: ../raster3d/r3.null/main.c:168
-#, fuzzy
-msgid "Unable to close raster map"
-#: ../raster3d/r3.null/main.c:170
-#, fuzzy
-msgid "modifyNull: Unable to close tmp file"
-#: ../raster3d/r3.null/main.c:188
-msgid "Explicitly create the 3D NULL-value bitmap file."
-msgstr ""
-#: ../raster3d/r3.in.v5d/main.c:195
-msgid "Import 3-dimensional Vis5D files."
-msgstr ""
-#: ../raster3d/r3.in.v5d/main.c:215 ../raster3d/r3.in.ascii/main.c:357
-#, fuzzy
-msgid "Unable to open 3D raster map"
-#: ../raster3d/r3.in.v5d/main.c:220 ../raster3d/r3.out.ascii/main.c:62
-#: ../raster3d/r3.out.ascii/main.c:371 ../raster3d/r3.out.v5d/main.c:54
-#: ../raster3d/r3.out.v5d/main.c:328 ../raster3d/r3.to.rast/main.c:55
-#: ../raster3d/r3.to.rast/main.c:382 ../raster3d/r3.cross.rast/main.c:55
-#: ../raster3d/r3.out.vtk/main.c:252 ../raster3d/r3.out.vtk/main.c:338
-#: ../raster3d/r3.in.ascii/main.c:363
-#, fuzzy
-msgid "Unable to close 3D raster map"
-#: ../raster3d/r3.info/r3.info.main.c:82
-msgid "Outputs basic information about a user-specified 3D raster map layer."
-msgstr ""
-#: ../raster3d/r3.info/r3.info.main.c:89
-msgid "Name of input 3D raster map"
-msgstr ""
-#: ../raster3d/r3.info/r3.info.main.c:93 ../raster/r.info/main.c:83
-msgid "Print range only"
-msgstr ""
-#: ../raster3d/r3.info/r3.info.main.c:98
-msgid "Print 3D raster map resolution (NS-res, EW-res, TB-res) only"
-msgstr ""
-#: ../raster3d/r3.info/r3.info.main.c:102
-msgid "Print 3D raster map type (float/double) only"
-msgstr ""
-#: ../raster3d/r3.info/r3.info.main.c:106
-msgid "Print 3D raster map region only"
-msgstr ""
-#: ../raster3d/r3.info/r3.info.main.c:110
-msgid "Print 3D raster tile number and size information only"
-msgstr ""
-#: ../raster3d/r3.info/r3.info.main.c:114
-msgid "Print 3D raster history instead of info"
-msgstr ""
-#: ../raster3d/r3.info/r3.info.main.c:119
-msgid "Print 3D raster map timestamp (day.month.year hour:minute:seconds) only"
-msgstr ""
-#: ../raster3d/r3.info/r3.info.main.c:128
-#, fuzzy, c-format
-msgid "3D Raster map <%s> not found"
-#: ../raster3d/r3.info/r3.info.main.c:164
-#: ../raster3d/r3.info/r3.info.main.c:171
-#: ../raster3d/r3.info/r3.info.main.c:177
-#: ../raster3d/r3.info/r3.info.main.c:182
-#: ../raster3d/r3.info/r3.info.main.c:188
-#: ../raster3d/r3.info/r3.info.main.c:199
-#: ../raster3d/r3.info/r3.info.main.c:205
-#: ../raster3d/r3.info/r3.info.main.c:220
-#: ../raster3d/r3.info/r3.info.main.c:227
-#: ../raster3d/r3.info/r3.info.main.c:234
-#: ../raster3d/r3.info/r3.info.main.c:239
-#: ../raster3d/r3.info/r3.info.main.c:244
-#: ../raster3d/r3.info/r3.info.main.c:251
-#: ../raster3d/r3.info/r3.info.main.c:261
-#: ../raster3d/r3.info/r3.info.main.c:267
-#: ../raster3d/r3.info/r3.info.main.c:273
-#: ../raster3d/r3.info/r3.info.main.c:289
-#: ../raster3d/r3.info/r3.info.main.c:296
-#: ../raster3d/r3.info/r3.info.main.c:303
-#: ../raster3d/r3.info/r3.info.main.c:312
-#: ../raster3d/r3.info/r3.info.main.c:322
-#: ../raster3d/r3.info/r3.info.main.c:332
-#: ../raster3d/r3.info/r3.info.main.c:342
-#: ../raster3d/r3.info/r3.info.main.c:362
-#: ../raster3d/r3.info/r3.info.main.c:372
-#: ../raster3d/r3.info/r3.info.main.c:377
-#: ../raster3d/r3.info/r3.info.main.c:385
-#: ../raster3d/r3.info/r3.info.main.c:398 ../raster/r.info/main.c:285
-#: ../raster/r.info/main.c:408
-msgid "Cannot allocate memory for string"
-msgstr ""
-#: ../raster3d/r3.info/r3.info.main.c:344
-#: ../raster3d/r3.info/r3.info.main.c:413
-#, fuzzy, c-format
-msgid "Unable to read range of 3D raster map <%s>"
-#: ../raster3d/r3.info/r3.info.main.c:482
-msgid "Error while reading history file"
-msgstr ""
-#: ../raster3d/r3.info/r3.info.main.c:503 ../raster3d/r3.cross.rast/main.c:342
-#: ../raster3d/r3.out.vtk/errorHandling.c:65
-#, fuzzy, c-format
-msgid "Unable to close 3D raster map <%s>"
-#: ../raster3d/r3.gwflow/main.c:54
-msgid "Input 3D raster map with initial piezometric heads in [m]"
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:60
-msgid "Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:65
-#, fuzzy
-msgid "Input 3D raster map with the x-part of the hydraulic conductivity tensor in [m/s]"
-#: ../raster3d/r3.gwflow/main.c:70
-#, fuzzy
-msgid "Input 3D raster map with the y-part of the hydraulic conductivity tensor in [m/s]"
-#: ../raster3d/r3.gwflow/main.c:75
-#, fuzzy
-msgid "Input 3D raster map with the z-part of the hydraulic conductivity tensor in [m/s]"
-#: ../raster3d/r3.gwflow/main.c:80
-#, fuzzy
-msgid "Input 3D raster map with sources and sinks in [m^3/s]"
-#: ../raster3d/r3.gwflow/main.c:84
-#, fuzzy
-msgid "Specific yield [1/m] input 3D raster map"
-#: ../raster3d/r3.gwflow/main.c:89
-#, fuzzy
-msgid "Recharge input 3D raster map in m^3/s"
-#: ../raster3d/r3.gwflow/main.c:93
-#, fuzzy
-msgid "Output 3D raster map storing the piezometric head result of the numerical calculation"
-#: ../raster3d/r3.gwflow/main.c:99
-#, fuzzy
-msgid "Output 3D raster map storing the groundwater filter velocity vector part in x direction [m/s]"
-#: ../raster3d/r3.gwflow/main.c:105
-#, fuzzy
-msgid "Output 3D raster map storing the groundwater filter velocity vector part in y direction [m/s]"
-#: ../raster3d/r3.gwflow/main.c:111
-#, fuzzy
-msgid "Output 3D raster map storing the groundwater filter velocity vector part in z direction [m/s]"
-#: ../raster3d/r3.gwflow/main.c:117
-#, fuzzy
-msgid "Output 3D raster map Storing the groundwater budget for each cell [m^3/s]\n"
-#: ../raster3d/r3.gwflow/main.c:127
-msgid "Use RASTER3D mask (if exists)"
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:131 ../raster/r.solute.transport/main.c:192
-msgid "Use a full filled quadratic linear equation system, default is a sparse linear equation system."
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:161 ../raster/r.uslek/main.c:54
-#: ../raster/r.watershed/front/main.c:72 ../raster/r.drain/main.c:108
-#: ../raster/r.topmodel/main.c:63 ../raster/r.usler/main.c:52
-#: ../raster/r.solute.transport/main.c:230 ../raster/r.topidx/main.c:40
-#: ../raster/r.fill.dir/main.c:86 ../raster/r.water.outlet/main.c:66
-#: ../raster/r.carve/main.c:75 ../raster/r.basins.fill/main.c:55
-#: ../raster/simwe/r.sim.sediment/main.c:112
-#: ../raster/simwe/r.sim.water/main.c:111 ../raster/r.lake/main.c:151
-#: ../raster/r.flow/main.c:422
-msgid "hydrology"
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:162
-#, fuzzy
-msgid "groundwater"
-#: ../raster3d/r3.gwflow/main.c:163
-msgid "numeric"
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:164
-#, fuzzy
-msgid "simulation"
-#: ../raster3d/r3.gwflow/main.c:165
-msgid "Numerical calculation program for transient, confined groundwater flow in three dimensions"
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:182
-msgid ""
-"The cholesky solver does not work with sparse matrices.\n"
-"Consider to choose a full filled quadratic matrix with flag -f "
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:281 ../raster/r.gwflow/main.c:542
-#, fuzzy
-msgid "Unable to create and solve the linear equation system"
-#: ../raster3d/r3.gwflow/main.c:367
-#, fuzzy, c-format
-msgid "Unable to create 3D raster map <%s>"
-#: ../raster3d/r3.gwflow/main.c:414
-#, fuzzy
-msgid "Error closing g3d file"
-#: ../raster3d/r3.mkdspf/main.c:82
-msgid "Creates a display file from an existing grid3 file according to specified threshold levels."
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:90
-msgid "Name of an existing 3d raster map"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:97
-msgid "Name of output display file"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:104
-msgid "List of thresholds for isosurfaces"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:110
-msgid "Minimum isosurface level"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:116
-msgid "Maximum isosurface level"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:122
-msgid "Positive increment between isosurface levels"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:129
-msgid "Number of isosurface threshold levels"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:133
-msgid "Suppress progress report & min/max information"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:137
-msgid "Use flat shading rather than gradient"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:145
-#, c-format
-msgid "Region from getWindow: %d %d %d"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:157
-#, c-format
-msgid "Not able to find grid3 file for [%s]"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:169
-#, c-format
-msgid "Error opening grid3 file [%s]"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:172
-#, c-format
-msgid "Error reading range for [%s]"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:201
-#, c-format
-msgid "Error opening display file [%s]"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:222
-#, c-format
-msgid "Writing %s from %s..."
-msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:81
-#, fuzzy
-msgid "3D raster map to be converted to ASCII"
-#: ../raster3d/r3.out.ascii/main.c:88
-msgid "Name for ASCII output file"
-msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:97
-msgid "Number of decimal places for floats"
-msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:103 ../raster/r.what/main.c:119
-#: ../raster/r.transect/main.c:125
-msgid "Char string to represent no data cell"
-msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:108 ../raster/r.out.arc/main.c:82
-#: ../raster/r.out.ascii/main.c:105
-msgid "Suppress printing of header information"
-msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:112
-msgid "Switch the row order in output from north->south to south->north"
-msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:116
-msgid "Switch the depth order in output from bottom->top to top->bottom"
-msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:120
-msgid "Print grass6 compatible format. Flags -d and -r are ignored."
-msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:124 ../raster3d/r3.to.rast/main.c:91
-#: ../raster3d/r3.cross.rast/main.c:109
-msgid "Use 3D raster mask (if exists) with input map"
-msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:310 ../raster3d/r3.out.v5d/main.c:288
-#: ../raster3d/r3.out.vtk/main.c:378 ../raster/r.colors.out/raster_main.c:47
-#: ../raster/r.colors.out/raster3d_main.c:48
-#: ../raster/r.external.out/main.c:215 ../raster/r.out.mpeg/main.c:103
-#: ../raster/r.out.vtk/main.c:60 ../raster/r.out.arc/main.c:61
-#: ../raster/r.out.png/main.c:113 ../raster/r.out.pov/main.c:122
-#: ../raster/r.out.tiff/main.c:92 ../raster/r.out.mat/main.c:63
-#: ../raster/r.out.bin/main.c:280 ../raster/r.out.ppm/main.c:54
-#: ../raster/r.out.ascii/main.c:60 ../raster/r.out.ppm3/main.c:57
-#: ../raster/r.out.gdal/main.c:130 ../raster/r.out.vrml/main.c:48
-#: ../raster/r.out.gridatb/main.c:68 ../vector/v.colors.out/main.c:51
-#: ../vector/v.out.ascii/main.c:46 ../vector/v.out.svg/main.c:74
-#: ../vector/v.out.ogr/main.c:83 ../vector/v.out.pov/main.c:47
-#: ../vector/v.external.out/main.c:35 ../vector/v.out.dxf/main.c:57
-#: ../vector/v.out.vtk/main.c:48
-#: ../locale/scriptstrings/r.pack_to_translate.c:3
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:3
-#: ../locale/scriptstrings/tr.out.vtk_to_translate.c:5
-#: ../locale/scriptstrings/v.out.gps_to_translate.c:3
-#: ../locale/scriptstrings/tr.export_to_translate.c:5
-msgid "export"
-msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:312
-#, fuzzy
-msgid "Converts a 3D raster map layer into a ASCII text file."
-#: ../raster3d/r3.out.ascii/main.c:343
-#, c-format
-msgid "Error opening 3d raster map <%s>"
-msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:375
-#, fuzzy
-msgid "Unable to close new ASCII file"
-#: ../raster3d/r3.out.v5d/main.c:72
-msgid "3D raster map to be converted to Vis5D (V5D) file"
-msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:79
-#, fuzzy
-msgid "Name for V5D output file"
-msgstr "तक्त्याचे नाव"
-#: ../raster3d/r3.out.v5d/main.c:149
-#, c-format
-msgid "Vis5D allows %d columns, %d columns found"
-msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:152
-#, c-format
-msgid "Vis5D allows %d rows, %d rows found"
-msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:259
-#, fuzzy, c-format
-msgid "Unable to create V5D file <%s>"
-#: ../raster3d/r3.out.v5d/main.c:264
-#, fuzzy
-msgid "Failed writing V5D file"
-#: ../raster3d/r3.out.v5d/main.c:290
-msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
-msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:297
-msgid "Use map coordinates instead of xyz coordinates"
-msgstr ""
-#: ../raster3d/r3.to.rast/main.c:80
-msgid "3D raster map(s) to be converted to 2D raster slices"
-msgstr ""
-#: ../raster3d/r3.to.rast/main.c:86
-msgid "Basename for resultant raster slice maps"
-msgstr ""
-#: ../raster3d/r3.to.rast/main.c:96
-msgid "Use the same resolution as the input 3D raster map for the 2D output maps, independent of the current region settings"
-msgstr ""
-#: ../raster3d/r3.to.rast/main.c:209
-msgid "Converts 3D raster maps to 2D raster maps"
-msgstr ""
-#: ../raster3d/r3.to.rast/main.c:218
-#, fuzzy, c-format
-msgid "Open 3D raster map <%s>"
-#: ../raster3d/r3.to.rast/main.c:236 ../raster3d/r3.to.rast/main.c:260
-#, fuzzy, c-format
-msgid "Error opening 3D raster map <%s>"
-#: ../raster3d/r3.to.rast/main.c:270 ../raster3d/r3.out.vtk/main.c:450
-msgid "The 2D and 3D region settings are different. Using the 2D window settings to adjust the 2D part of the 3D region."
-msgstr ""
-#: ../raster3d/r3.to.rast/main.c:294 ../raster/r.gwflow/main.c:366
-#: ../raster/r.to.rast3/main.c:244 ../raster/r.li/r.li.daemon/list.c:49
-#: ../imagery/i.smap/multialloc.c:115 ../vector/v.net.centrality/main.c:288
-#: ../vector/v.net.centrality/main.c:293 ../vector/v.net.centrality/main.c:299
-#: ../vector/v.net.centrality/main.c:305 ../vector/v.net.centrality/main.c:311
-#: ../vector/v.net.distance/main.c:184 ../vector/v.mapcalc/list.c:54
-#: ../vector/v.mapcalc/list.c:501 ../vector/v.mkgrid/write_grid.c:131
-#: ../vector/v.net.flow/main.c:227 ../vector/v.surf.rst/main.c:786
-#: ../vector/v.net.timetable/main.c:390 ../vector/v.net.timetable/main.c:400
-#: ../vector/v.net.allpairs/main.c:194 ../vector/v.net.allpairs/main.c:198
-#: ../vector/v.net.components/main.c:163 ../vector/v.generalize/matrix.c:145
-#: ../vector/v.generalize/network.c:94 ../vector/v.generalize/network.c:129
-#: ../vector/v.generalize/smoothing.c:95
-#: ../vector/v.generalize/smoothing.c:152
-#: ../vector/v.generalize/smoothing.c:253
-#: ../vector/v.generalize/smoothing.c:377
-#: ../vector/v.generalize/smoothing.c:406
-#: ../vector/v.generalize/smoothing.c:410
-#: ../vector/v.generalize/smoothing.c:414
-#: ../vector/v.generalize/smoothing.c:418
-#: ../vector/v.generalize/smoothing.c:422
-#: ../vector/v.generalize/smoothing.c:426
-#: ../vector/v.generalize/smoothing.c:430
-#: ../vector/v.generalize/simplification.c:33
-#: ../vector/v.generalize/simplification.c:40
-#: ../vector/v.generalize/simplification.c:309
-#: ../vector/v.generalize/simplification.c:317
-#: ../vector/v.generalize/simplification.c:341
-#: ../vector/v.net.connectivity/main.c:184
-#: ../vector/v.net.connectivity/main.c:200 ../db/drivers/postgres/listdb.c:73
-#: ../db/drivers/postgres/listtab.c:90
-msgid "Out of memory"
-msgstr ""
-#: ../raster3d/r3.to.rast/main.c:296
-#, fuzzy, c-format
-msgid "Creating %i raster maps"
-#: ../raster3d/r3.to.rast/main.c:302
-#, c-format
-msgid "Raster map %i Filename: %s"
-msgstr ""
-#: ../raster3d/r3.to.rast/main.c:307
-#, fuzzy, c-format
-msgid "Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
-#: ../raster3d/r3.cross.rast/main.c:90
-msgid "Input 3D raster map for cross section."
-msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:97
-msgid "2D elevation map used to create the cross section map"
-msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:104
-msgid "Resulting cross section 2D raster map"
-msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:232
-msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map"
-msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:258
-msgid "The 2D and 3D region settings are different. Using the 3D raster map settings to adjust the 2D region."
-msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:301
-msgid "Output map already exists. Will be overwritten!"
-msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:337
-#, fuzzy
-msgid "Wrong 3D raster datatype! Cannot create raster map"
-#: ../raster3d/r3.out.vtk/errorHandling.c:105
-#, fuzzy
-msgid "Unable to close input raster maps"
-#: ../raster3d/r3.out.vtk/writeVTKData.c:122
-msgid "write_vtk_points: Writing point coordinates"
-msgstr ""
-#: ../raster3d/r3.out.vtk/writeVTKData.c:256
-msgid "write_vtk_unstructured_grid_cells: Writing the cells"
-msgstr ""
-#: ../raster3d/r3.out.vtk/writeVTKData.c:335
-#, c-format
-msgid "write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-ascii file"
-msgstr ""
-#: ../raster3d/r3.out.vtk/writeVTKData.c:441
-msgid "Wrong 3d raster map values! Values should in between 0 and 255!\n"
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:30
-msgid "RASTER3D map(s) to be converted to VTK-ASCII data format"
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:34 ../raster/r.out.vtk/parameters.c:41
-msgid "Name for VTK-ASCII output file"
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:41
-msgid "Float value to represent no data cell/points"
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:47
-msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:56
-#, fuzzy
-msgid "top surface 2D raster map"
-#: ../raster3d/r3.out.vtk/parameters.c:65
-#, fuzzy
-msgid "bottom surface 2D raster map"
-#: ../raster3d/r3.out.vtk/parameters.c:71
-msgid "Create 3d elevation output with a top and a bottom surface, both raster maps are required."
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:82
-msgid "Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:92
-msgid "Three (x,y,z) 3D raster maps to create vector values [xmap,ymap,zmap]"
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:98 ../raster/r.out.vtk/parameters.c:96
-#: ../vector/v.out.vtk/main.c:77
-msgid "Scale factor for elevation"
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:111
-#: ../raster/r.out.vtk/parameters.c:108 ../raster/r.out.ascii/main.c:86
-#: ../display/d.rast.num/main.c:104 ../vector/v.out.ascii/args.c:67
-#: ../vector/v.out.vtk/main.c:71
-msgid "Number of significant digits (floating point only)"
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:116
-msgid "Use 3D raster mask (if exists) with input maps"
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:121
-msgid "Scale factor effects the origin"
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:127
-#: ../raster/r.out.vtk/parameters.c:138 ../vector/v.out.vtk/main.c:90
-#: ../locale/scriptstrings/tr.out.vtk_to_translate.c:13
-msgid "Correct the coordinates to fit the VTK-OpenGL precision"
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:133
-msgid "Do not convert the top-bottom resolution in case of lat long projection to meters"
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:117
-msgid "Specify top and bottom map"
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:124
-#, c-format
-msgid "Top cell map <%s> not found"
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:133
-#, c-format
-msgid "Bottom cell map <%s> not found"
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:152
-#, fuzzy, c-format
-msgid "3D raster map RGB map <%s> not found"
-#: ../raster3d/r3.out.vtk/main.c:155
-#, fuzzy
-msgid "Please provide three RGB 3D raster maps"
-#: ../raster3d/r3.out.vtk/main.c:165
-#, fuzzy, c-format
-msgid "3D vector map <%s> not found"
-#: ../raster3d/r3.out.vtk/main.c:168
-msgid "Please provide three G3D vector maps [x,y,z]"
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:175
-msgid "No 3D raster data, RGB or xyz-vector maps are provided! Will only write the geometry."
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:209
-msgid "No RGB Data will be created."
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:294
-msgid "No vector data will be created."
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:380
-#, fuzzy
-msgid "Converts 3D raster maps into the VTK-ASCII format."
-#: ../raster3d/r3.out.vtk/main.c:391
-msgid "failed to interpret dp as an integer"
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:393 ../raster/r.out.ascii/main.c:126
-msgid "dp has to be from 0 to 20"
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:541
-#, fuzzy
-msgid "Unable to close 3D raster map, the VTK file may be incomplete"
-#: ../raster3d/r3.out.vtk/main.c:556
-#, fuzzy
-msgid "Unable to close VTK-ASCII file"
-#: ../raster3d/r3.out.vtk/writeVTKHead.c:40
-msgid "write_vtk_structured_point_header: Writing VTKStructuredPoint-Header"
-msgstr ""
-#: ../raster3d/r3.out.vtk/writeVTKHead.c:96
-msgid "write_vtk_structured_grid_header: Writing VTKStructuredGrid-Header"
-msgstr ""
-#: ../raster3d/r3.out.vtk/writeVTKHead.c:118
-msgid "write_vtk_unstructured_grid_header: Writing VTKUnstructuredGrid-Header"
-msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:87
-#, fuzzy
-msgid "ASCII raster map to be imported"
-#: ../raster3d/r3.in.ascii/main.c:98
-msgid "String representing NULL value data cell (use 'none' if no such value)"
-msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:188
-#, fuzzy, c-format
-msgid "Unsupported GRASS version %s"
-#: ../raster3d/r3.in.ascii/main.c:231
-#, c-format
-msgid "Loading data ...  (%dx%dx%d)"
-msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:264
-msgid "End of file reached while still loading data."
-msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:276
-#, fuzzy
-msgid "Invalid value detected."
-#: ../raster3d/r3.in.ascii/main.c:293
-#, c-format
-msgid "Data exists in input file after fully importing expected data.  [%.4f ...]"
-msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:327 ../raster/r.external/main.c:56
-#: ../raster/r.in.gridatb/main.c:46 ../raster/r.in.png/main.c:520
-#: ../raster/r.in.xyz/main.c:161 ../raster/r.in.arc/main.c:61
-#: ../raster/r.in.bin/main.c:236 ../raster/r.in.lidar/main.c:162
-#: ../raster/r.in.mat/main.c:92 ../raster/r.in.gdal/main.c:82
-#: ../raster/r.in.poly/main.c:30 ../raster/r.in.ascii/main.c:70
-#: ../vector/v.in.ogr/main.c:122 ../vector/v.in.dwg/main.c:83
-#: ../vector/v.in.ascii/main.c:49 ../vector/v.external/main.c:49
-#: ../vector/v.convert/main.c:37 ../vector/v.in.sites/main.c:58
-#: ../vector/v.in.dxf/main.c:65 ../vector/v.in.db/main.c:53
-#: ../vector/v.in.lidar/main.c:154
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:3
-#: ../locale/scriptstrings/tr.import_to_translate.c:5
-#: ../locale/scriptstrings/r.unpack_to_translate.c:3
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:3
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:3
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:3
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:3
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:3
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:4
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:3
-#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:4
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:3
-#: ../locale/scriptstrings/v.convert.all_to_translate.c:3
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:3
-msgid "import"
-msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:329
-#, fuzzy
-msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
-#: ../raster3d/r3.in.ascii/main.c:372
-#, fuzzy
-msgid "Unable to close ASCII file"
-#: ../raster3d/r3.stats/main.c:569 ../raster/r.mode/main.c:56
-#: ../raster/r.cross/main.c:74 ../raster/r.quant/main.c:49
-#: ../raster/r.statistics/main.c:56 ../raster/r.statistics3/main.c:390
-#: ../raster/r.mfilter/main.c:58 ../raster/r.statistics2/main.c:102
-#: ../raster/r.clump/main.c:47 ../raster/r.kappa/main.c:69
-#: ../raster/r.quantile/main.c:257 ../raster/r.support.stats/main.c:39
-#: ../raster/r.report/main.c:67 ../raster/r.stats/main.c:103
-#: ../raster/r.univar/r.univar_main.c:97
-#: ../raster/r.univar/r3.univar_main.c:100
-#: ../raster/r.regression.line/main.c:47 ../raster/r.surf.area/main.c:78
-#: ../raster/r.neighbors/main.c:119 ../raster/r.coin/main.c:67
-#: ../raster/r.texture/main.c:103 ../raster/r.covar/main.c:52
-#: ../imagery/i.cca/main.c:85 ../display/d.histogram/main.c:86
-#: ../vector/v.random/main.c:86 ../vector/v.univar/main.c:64
-#: ../vector/v.outlier/main.c:69 ../vector/v.kcv/main.c:68
-#: ../vector/v.qcount/main.c:61 ../vector/v.normal/main.c:75
-#: ../vector/v.perturb/main.c:63 ../vector/v.class/main.c:46
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:4
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:3
-#: ../locale/scriptstrings/v.report_to_translate.c:4
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:3
-#: ../locale/scriptstrings/tr.univar_to_translate.c:4
-#: ../locale/scriptstrings/i.oif_to_translate.c:4
-#, fuzzy
-msgid "statistics"
-#: ../raster3d/r3.stats/main.c:570
-#, fuzzy
-msgid "Generates volume statistics for 3D raster maps."
-msgstr "'%s'. ड्राइवर चालू होत नाही"
-#: ../raster3d/r3.stats/main.c:581
-#, fuzzy
-msgid "Number of subranges to collect stats from"
-#: ../raster3d/r3.stats/main.c:587
-msgid "Calculate statistics based on equal value groups"
-msgstr ""
-#: ../raster3d/r3.stats/main.c:607
-msgid "The number of subranges has to be equal or greater than 1"
-msgstr ""
-#: ../raster3d/r3.stats/main.c:666
-msgid "Sort non-null values"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:74
-msgid "Creates fly-through script to run in NVIZ."
-msgstr ""
-#: ../misc/m.nviz.script/main.c:79
-msgid "Name of output script"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:85
-msgid "Prefix of output images (default = NVIZ)"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:93
-msgid "Route coordinates (east,north)"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:99
-msgid "Camera layback distance (in map units)"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:105
-msgid "Camera height above terrain"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:111
-msgid "Number of frames"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:117
-msgid "Start frame number (default=0)"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:122
-msgid "Full render -- Save images"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:126
-msgid "Fly at constant elevation (ht)"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:131
-msgid "Include command in the script to output a KeyFrame file"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:135
-msgid "Render images off-screen"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:139
-msgid "Enable vector and sites drawing"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:147
-msgid "Either -i flag and/or route parameter must be used"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:171
-msgid "Off-screen only available with full render mode"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:201 ../misc/m.transform/main.c:276
-#: ../raster/r.profile/main.c:146 ../raster/r.category/main.c:178
-#: ../raster/r.recode/main.c:89 ../raster/r.out.arc/main.c:129
-#: ../raster/r.out.ascii/main.c:167 ../raster/r.out.ppm3/main.c:127
-#: ../general/g.pnmcomp/main.c:241 ../general/g.pnmcomp/main.c:258
-#: ../vector/v.net/main.c:98 ../vector/v.out.ascii/main.c:100
-#: ../vector/v.edit/main.c:76 ../vector/v.out.vtk/main.c:167
-#, fuzzy, c-format
-msgid "Unable to open file <%s>"
-#: ../misc/m.nviz.script/main.c:249
-#, c-format
-msgid "You must provide at least four points %d"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:323
-#, c-format
-msgid "Created NVIZ script <%s>."
-msgstr ""
-#: ../misc/m.nviz.script/main.c:439
-msgid "Skipping this point, selected point is outside region. Perhaps the camera setback distance puts it beyond the edge?"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:51
-msgid "Use draw mode for all loaded surfaces"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:52 ../misc/m.nviz.image/args.c:130
-#: ../misc/m.nviz.image/args.c:139 ../misc/m.nviz.image/args.c:146
-#: ../misc/m.nviz.image/args.c:152 ../misc/m.nviz.image/args.c:160
-#: ../misc/m.nviz.image/args.c:169 ../misc/m.nviz.image/args.c:179
-#: ../misc/m.nviz.image/args.c:187 ../misc/m.nviz.image/args.c:197
-#: ../misc/m.nviz.image/args.c:205 ../misc/m.nviz.image/args.c:215
-msgid "Surfaces"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:89
-#, fuzzy
-msgid "Name for output image file (without extension)"
-#: ../misc/m.nviz.image/args.c:90 ../misc/m.nviz.image/args.c:104
-#: ../misc/m.nviz.image/args.c:114
-msgid "Image"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:102
-#, fuzzy
-msgid "Graphics file format"
-#: ../misc/m.nviz.image/args.c:112
-msgid "Size (width, height) of output image"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:129
-#, fuzzy
-msgid "Name of raster map(s) for elevation"
-#: ../misc/m.nviz.image/args.c:138
-#, fuzzy
-msgid "Elevation value(s)"
-#: ../misc/m.nviz.image/args.c:145
-#, fuzzy
-msgid "Name of raster map(s) for color"
-#: ../misc/m.nviz.image/args.c:151
-msgid "Color value(s)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:159
-#, fuzzy
-msgid "Name of raster map(s) for mask"
-#: ../misc/m.nviz.image/args.c:168
-#, fuzzy
-msgid "Name of raster map(s) for transparency"
-#: ../misc/m.nviz.image/args.c:178
-msgid "Transparency value(s)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:186
-#, fuzzy
-msgid "Name of raster map(s) for shininess"
-#: ../misc/m.nviz.image/args.c:196
-msgid "Shininess value(s)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:204
-#, fuzzy
-msgid "Name of raster map(s) for emission"
-#: ../misc/m.nviz.image/args.c:214
-msgid "Emission value(s)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:228
-msgid "Draw mode"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:231 ../misc/m.nviz.image/args.c:242
-#: ../misc/m.nviz.image/args.c:253 ../misc/m.nviz.image/args.c:265
-#: ../misc/m.nviz.image/args.c:277 ../misc/m.nviz.image/args.c:286
-#: ../misc/m.nviz.image/args.c:296 ../misc/m.nviz.image/args.c:584
-#: ../misc/m.nviz.image/args.c:596
-msgid "Draw"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:240
-msgid "Fine resolution"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:251
-msgid "Coarse resolution"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:262
-msgid "Draw style"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:274
-msgid "Shading"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:283
-msgid "Wire color"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:295
-#, fuzzy
-msgid "Surface position"
-#: ../misc/m.nviz.image/args.c:307
-#, fuzzy
-msgid "Name of line vector overlay map(s)"
-#: ../misc/m.nviz.image/args.c:308 ../misc/m.nviz.image/args.c:315
-#: ../misc/m.nviz.image/args.c:327 ../misc/m.nviz.image/args.c:336
-#: ../misc/m.nviz.image/args.c:345 ../misc/m.nviz.image/args.c:352
-#: ../misc/m.nviz.image/args.c:364 ../misc/m.nviz.image/args.c:374
-#: ../misc/m.nviz.image/args.c:386
-#, fuzzy
-msgid "Vector lines"
-#: ../misc/m.nviz.image/args.c:314 ../misc/m.nviz.image/args.c:404
-#, fuzzy
-msgid "Layer number or name for thematic mapping"
-#: ../misc/m.nviz.image/args.c:326
-#, fuzzy
-msgid "Vector line width"
-#: ../misc/m.nviz.image/args.c:334 ../misc/m.nviz.image/args.c:443
-#, fuzzy
-msgid "Name of width definition column"
-#: ../misc/m.nviz.image/args.c:342
-#, fuzzy
-msgid "Vector line color"
-#: ../misc/m.nviz.image/args.c:350 ../misc/m.nviz.image/args.c:459
-#, fuzzy
-msgid "Name of color definition column"
-#: ../misc/m.nviz.image/args.c:361
-msgid "Vector line display mode"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:373
-msgid "Vector line height"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:385
-#, fuzzy
-msgid "Vector lines position"
-#: ../misc/m.nviz.image/args.c:397
-#, fuzzy
-msgid "Name of point vector overlay map(s)"
-#: ../misc/m.nviz.image/args.c:398 ../misc/m.nviz.image/args.c:405
-#: ../misc/m.nviz.image/args.c:417 ../misc/m.nviz.image/args.c:426
-#: ../misc/m.nviz.image/args.c:436 ../misc/m.nviz.image/args.c:445
-#: ../misc/m.nviz.image/args.c:454 ../misc/m.nviz.image/args.c:461
-#: ../misc/m.nviz.image/args.c:474 ../misc/m.nviz.image/args.c:481
-#: ../misc/m.nviz.image/args.c:491
-#, fuzzy
-msgid "Vector points"
-#: ../misc/m.nviz.image/args.c:416
-msgid "Icon size"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:424
-#, fuzzy
-msgid "Name of size definition column"
-#: ../misc/m.nviz.image/args.c:435
-msgid "Icon width"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:451
-msgid "Icon color"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:470
-msgid "Icon marker"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:479
-#, fuzzy
-msgid "Name of marker definition column"
-#: ../misc/m.nviz.image/args.c:490
-#, fuzzy
-msgid "Vector points position"
-#: ../misc/m.nviz.image/args.c:507
-msgid "Viewpoint position (x,y model coordinates)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:508 ../misc/m.nviz.image/args.c:519
-#: ../misc/m.nviz.image/args.c:529 ../misc/m.nviz.image/args.c:541
-#: ../misc/m.nviz.image/args.c:562
-msgid "Viewpoint"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:518
-msgid "Viewpoint height (in map units)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:528
-msgid "Viewpoint field of view (in degrees)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:540
-msgid "Viewpoint twist angle (in degrees)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:552 ../raster/r.out.vrml/main.c:72
-msgid "Vertical exaggeration"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:561
-msgid "Focus to point on surface (from SW corner in map units)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:571 ../misc/m.nviz.image/args.c:606
-#: ../misc/m.nviz.image/args.c:618 ../misc/m.nviz.image/args.c:628
-#: ../misc/m.nviz.image/args.c:636 ../misc/m.nviz.image/args.c:644
-#: ../misc/m.nviz.image/args.c:653 ../misc/m.nviz.image/args.c:663
-#: ../misc/m.nviz.image/args.c:671 ../misc/m.nviz.image/args.c:681
-#: ../misc/m.nviz.image/args.c:693 ../misc/m.nviz.image/args.c:703
-#: ../misc/m.nviz.image/args.c:714
-msgid "Volumes"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:581
-msgid "Volume draw mode"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:593
-msgid "Volume shading"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:605
-msgid "Volume position"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:616
-msgid "Volume resolution"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:627
-msgid "Isosurface level"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:635
-#, fuzzy
-msgid "Name of volume for isosurface color"
-#: ../misc/m.nviz.image/args.c:643
-#, fuzzy
-msgid "Isosurface color"
-#: ../misc/m.nviz.image/args.c:652
-#, fuzzy
-msgid "Name of 3D raster map(s) for isosurface transparency"
-#: ../misc/m.nviz.image/args.c:662
-msgid "Transparency value(s)for isosurfaces"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:670
-#, fuzzy
-msgid "Name of 3D raster map(s) for shininess"
-#: ../misc/m.nviz.image/args.c:680
-msgid "Shininess value(s) for isosurfaces"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:692
-msgid "Volume slice parallel to given axis (x, y, z)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:702
-#, fuzzy
-msgid "Volume slice position"
-#: ../misc/m.nviz.image/args.c:713
-msgid "Volume slice transparency"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:730
-msgid "Light position (x,y,z model coordinates)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:731 ../misc/m.nviz.image/args.c:737
-#: ../misc/m.nviz.image/args.c:746 ../misc/m.nviz.image/args.c:756
-msgid "Lighting"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:736
-msgid "Light color"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:745
-msgid "Light brightness"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:755
-msgid "Light ambient"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:769
-msgid "Cutting plane index (0-5)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:770 ../misc/m.nviz.image/args.c:779
-#: ../misc/m.nviz.image/args.c:788 ../misc/m.nviz.image/args.c:799
-#: ../misc/m.nviz.image/args.c:810
-#, fuzzy
-msgid "Cutting planes"
-#: ../misc/m.nviz.image/args.c:778
-#, fuzzy
-msgid "Cutting plane x,y,z coordinates"
-#: ../misc/m.nviz.image/args.c:789
-msgid "Cutting plane rotation along the vertical axis"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:800
-#, fuzzy
-msgid "Cutting plane tilt"
-#: ../misc/m.nviz.image/args.c:811
-msgid "Cutting plane color (between two surfaces)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:822
-msgid "nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:826
-#, fuzzy
-msgid "Fringe edges"
-#: ../misc/m.nviz.image/args.c:827 ../misc/m.nviz.image/args.c:833
-#: ../misc/m.nviz.image/args.c:842
-msgid "Fringe"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:832
-#, fuzzy
-msgid "Fringe color"
-#: ../misc/m.nviz.image/args.c:841
-#, fuzzy
-msgid "Fringe elevation"
-#: ../misc/m.nviz.image/args.c:854
-msgid "Place north arrow at given position \t(in screen coordinates from bottom left corner)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:856 ../misc/m.nviz.image/args.c:865
-#: ../misc/m.nviz.image/args.c:872
-#, fuzzy
-msgid "Decoration"
-msgstr "डेटाबेसचे स्थान"
-#: ../misc/m.nviz.image/args.c:864
-msgid "North arrow size (in map units)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:871
-msgid "North arrow color"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:921
-#, c-format
-msgid "At least one <%s> or <%s> required"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:935 ../misc/m.nviz.image/args.c:965
-#: ../misc/m.nviz.image/args.c:977 ../misc/m.nviz.image/args.c:983
-#: ../misc/m.nviz.image/args.c:989 ../misc/m.nviz.image/args.c:995
-#, c-format
-msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:971
-#, c-format
-msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:1005
-#, c-format
-msgid "Inconsistent number of attributes (<%s> %d: <%s> %d x 3)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:1010 ../misc/m.nviz.image/args.c:1015
-#: ../misc/m.nviz.image/args.c:1026 ../misc/m.nviz.image/args.c:1040
-#: ../misc/m.nviz.image/args.c:1047 ../misc/m.nviz.image/args.c:1054
-#: ../misc/m.nviz.image/args.c:1093
-#, c-format
-msgid "Inconsistent number of attributes (<%s> %d: <%s> %d)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:1033
-#, c-format
-msgid "Inconsistent number of attributes (<%s> %d: <%s> %d"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:1077 ../misc/m.nviz.image/args.c:1086
-#, c-format
-msgid "Inconsistent number of attributes (<%s> %d: <%s> %d, <%s> %d"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:1099
-#, c-format
-msgid "Inconsistent number of attributes (<%s> %d: <%s> %d x 6)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:1110
-#, c-format
-msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d, <%s> %d)"
-msgstr ""
-#: ../misc/m.nviz.image/volume.c:92 ../misc/m.nviz.image/volume.c:231
-#, fuzzy, c-format
-msgid "Error tokenize '%s'"
-#: ../misc/m.nviz.image/volume.c:99 ../misc/m.nviz.image/volume.c:247
-#, fuzzy, c-format
-msgid "Volume set number %d is not available"
-#: ../misc/m.nviz.image/volume.c:105
-#, fuzzy, c-format
-msgid "Unable to add isosurface (volume set %d)"
-#: ../misc/m.nviz.image/volume.c:113 ../misc/m.nviz.image/volume.c:131
-#: ../misc/m.nviz.image/volume.c:139 ../misc/m.nviz.image/volume.c:155
-#: ../misc/m.nviz.image/volume.c:162 ../misc/m.nviz.image/volume.c:173
-#: ../misc/m.nviz.image/volume.c:180
-#, fuzzy, c-format
-msgid "Unable to set isosurface (%d) attribute (%d) of volume %d)"
-#: ../misc/m.nviz.image/volume.c:144 ../misc/m.nviz.image/surface.c:128
-#, c-format
-msgid "Color attribute not defined, using default <%s>"
-msgstr ""
-#: ../misc/m.nviz.image/volume.c:242
-#, fuzzy, c-format
-msgid "Wrong name for axis: %s"
-#: ../misc/m.nviz.image/volume.c:253
-#, fuzzy, c-format
-msgid "Unable to add slice (volume set %d)"
-#: ../misc/m.nviz.image/volume.c:266
-#, fuzzy, c-format
-msgid "Unable to set slice (%d) position of volume %d"
-#: ../misc/m.nviz.image/volume.c:271
-#, fuzzy, c-format
-msgid "Unable to set slice (%d) transparency of volume %d"
-#: ../misc/m.nviz.image/cplane.c:40
-#, fuzzy, c-format
-msgid "Cutting plane number <%d> not found"
-#: ../misc/m.nviz.image/main.c:54
-msgid "Creates a 3D rendering of GIS data."
-msgstr ""
-#: ../misc/m.nviz.image/main.c:55
-msgid "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in 3D."
-msgstr ""
-#: ../misc/m.nviz.image/main.c:138
-#, c-format
-msgid "Vertical exaggeration not given, using calculated value %.0f"
-msgstr ""
-#: ../misc/m.nviz.image/main.c:150
-#, c-format
-msgid "Viewpoint height not given, using calculated value %.0f"
-msgstr ""
-#: ../misc/m.nviz.image/main.c:232
-#, fuzzy
-msgid "Unsupported output format"
-#: ../misc/m.nviz.image/main.c:234 ../imagery/i.cluster/main.c:335
-#, fuzzy, c-format
-msgid "File <%s> created."
-#: ../misc/m.nviz.image/surface.c:67
-#, c-format
-msgid "Missing topography attribute for surface %d"
-msgstr ""
-#: ../misc/m.nviz.image/surface.c:133
-#, fuzzy, c-format
-msgid "Missing color attribute for surface %d"
-#: ../misc/m.nviz.image/surface.c:210
-#, fuzzy, c-format
-msgid "Surface id %d doesn't exist"
-#: ../misc/m.nviz.image/surface.c:257 ../misc/m.nviz.image/surface.c:264
-#, fuzzy, c-format
-msgid "Unable to set draw mode for surface id %d"
-#: ../misc/m.nviz.image/vector.c:258 ../misc/m.nviz.image/vector.c:267
-#: ../misc/m.nviz.image/vector.c:277 ../misc/m.nviz.image/vector.c:287
-#, fuzzy, c-format
-msgid "Column <%s> in table <%s> not found"
-#: ../misc/m.nviz.image/vector.c:262
-msgid "Data type of color column must be character"
-msgstr ""
-#: ../misc/m.nviz.image/vector.c:272
-#, fuzzy
-msgid "Data type of size column must be numeric"
-#: ../misc/m.nviz.image/vector.c:282
-#, fuzzy
-msgid "Data type of width column must be numeric"
-#: ../misc/m.nviz.image/vector.c:292
-msgid "Data type of marker column must be character"
-msgstr ""
-#: ../misc/m.cogo/main.c:225 ../misc/m.measure/main.c:46
-#: ../locale/scriptstrings/m.proj_to_translate.c:2
-msgid "miscellaneous"
-msgstr ""
-#: ../misc/m.cogo/main.c:226 ../raster/r.distance/main.c:39
-#: ../raster/r.grow.distance/main.c:150 ../display/d.rhumbline/main.c:44
-#: ../display/d.geodesic/main.c:44
-#, fuzzy
-msgid "distance"
-#: ../misc/m.cogo/main.c:227
-msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
-msgstr ""
-#: ../misc/m.cogo/main.c:229
-msgid "It assumes a cartesian coordinate system"
-msgstr ""
-#: ../misc/m.cogo/main.c:233
-msgid "Lines are labelled"
-msgstr ""
-#: ../misc/m.cogo/main.c:237
-msgid "Suppress warnings"
-msgstr ""
-#: ../misc/m.cogo/main.c:242
-msgid "Convert from coordinates to bearing and distance"
-msgstr ""
-#: ../misc/m.cogo/main.c:257
-msgid "Starting coordinate pair"
-msgstr ""
-#: ../misc/m.cogo/main.c:267
-#, fuzzy, c-format
-msgid "Couldn't open COGO file <%s>"
-#: ../misc/m.cogo/main.c:276
-#, fuzzy, c-format
-msgid "Couldn't open output file <%s>"
-#: ../misc/m.cogo/main.c:306 ../misc/m.cogo/main.c:309
-#, fuzzy
-msgid "Converting starting coordinate pair"
-#: ../misc/m.cogo/main.c:325
-#, c-format
-msgid "Input parse error on line %d"
-msgstr ""
-#: ../misc/m.transform/main.c:92
-#, c-format
-msgid "Not enough points, %d are required"
-msgstr ""
-#: ../misc/m.transform/main.c:96
-#, fuzzy, c-format
-msgid "Error conducting transform (%d)"
-#: ../misc/m.transform/main.c:194
-msgid "Poorly placed control points"
-msgstr ""
-#: ../misc/m.transform/main.c:196
-msgid "Insufficient memory"
-msgstr ""
-#: ../misc/m.transform/main.c:198
-msgid "Parameter error"
-msgstr ""
-#: ../misc/m.transform/main.c:200
-msgid "No active control points"
-msgstr ""
-#: ../misc/m.transform/main.c:295
-#, fuzzy, c-format
-msgid "Invalid coordinates: [%s]"
-#: ../misc/m.transform/main.c:315 ../general/g.filename/main.c:39
-#: ../general/g.gui/main.c:36 ../general/g.access/main.c:37
-#: ../general/g.tempfile/main.c:38 ../general/g.findfile/main.c:38
-#: ../general/g.proj/main.c:62 ../general/g.mremove/main.c:61
-#: ../general/g.mapset/main.c:49 ../general/g.pnmcat/main.c:121
-#: ../general/g.cairocomp/main.c:193 ../general/g.mlist/main.c:62
-#: ../general/g.version/main.c:43 ../general/g.gisenv/main.c:38
-#: ../general/g.region/main.c:63 ../general/g.list/main.c:44
-#: ../general/g.mkfontcap/main.c:70 ../general/g.findetc/main.c:28
-#: ../general/g.setproj/main.c:78 ../general/g.remove/main.c:101
-#: ../general/g.pnmcomp/main.c:281 ../general/g.ppmtopng/main.c:117
-#: ../general/g.message/main.c:33 ../general/g.dirseps/main.c:34
-#: ../general/g.mapsets/main.c:59 ../general/g.rename/main.c:43
-#: ../general/g.copy/main.c:41
-#: ../locale/scriptstrings/g.manual_to_translate.c:2
-#: ../locale/scriptstrings/g.extension.rebuild.all_to_translate.c:3
-#: ../locale/scriptstrings/g.extension_to_translate.c:3
-msgid "general"
-msgstr ""
-#: ../misc/m.transform/main.c:316 ../raster/r.proj/main.c:148
-#: ../vector/v.proj/main.c:68 ../vector/v.transform/main.c:70
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:3
-#, fuzzy
-msgid "transformation"
-#: ../misc/m.transform/main.c:317
-msgid "GCP"
-msgstr ""
-#: ../misc/m.transform/main.c:319
-msgid "Computes a coordinate transformation based on the control points."
-msgstr ""
-#: ../misc/m.transform/main.c:328
-msgid "Rectification polynomial order"
-msgstr ""
-#: ../misc/m.transform/main.c:336
-msgid "idx;point index;src;source coordinates;dst;destination coordinates;fwd;forward coordinates (destination);rev;reverse coordinates (source);fxy;forward coordinates difference (destination);rxy;reverse coordinates difference (source);fd;forward error (destination);rd;reverse error (source)"
-msgstr ""
-#: ../misc/m.transform/main.c:346 ../vector/v.out.ascii/args.c:51
-msgid "Output format"
-msgstr ""
-#: ../misc/m.transform/main.c:350
-msgid "Display summary information"
-msgstr ""
-#: ../misc/m.transform/main.c:356
-#, fuzzy
-msgid "File containing coordinates to transform (\"-\" to read from stdin)"
-#: ../misc/m.transform/main.c:357
-msgid "Local x,y coordinates to target east,north"
-msgstr ""
-#: ../misc/m.transform/main.c:361
-msgid "Reverse transform of coords file or coeff. dump"
-msgstr ""
-#: ../misc/m.transform/main.c:362
-#, fuzzy
-msgid "Target east,north coordinates to local x,y"
-#: ../misc/m.transform/main.c:366
-msgid "Display transform matrix coefficients"
-msgstr ""
-#: ../misc/m.measure/main.c:45
-msgid "Measures the lengths and areas of features."
-msgstr ""
-#: ../misc/m.measure/main.c:47
-msgid "measurement"
-msgstr ""
-#: ../misc/m.measure/main.c:51
-#, fuzzy
-msgid "Vertex coordinates"
-#: ../misc/m.measure/main.c:58 ../raster/r.report/parse.c:45
-msgid "Units"
-msgstr ""
-#: ../misc/m.measure/main.c:59
-msgid "Default: location map units"
-msgstr ""
-#: ../misc/m.measure/main.c:63
-#, fuzzy
-msgid "Shell script style"
-#: ../misc/m.measure/main.c:106
-msgid "Length:"
-msgstr ""
-#: ../misc/m.measure/main.c:117
-msgid "Area:"
-msgstr ""
-#: ../raster/r.external/proj.c:18 ../raster/r.in.gdal/main.c:356
-msgid "Unable to convert input raster map projection information to GRASS format for checking"
-msgstr ""
-#: ../raster/r.external/proj.c:34 ../raster/r.in.lidar/main.c:297
-#: ../raster/r.in.gdal/main.c:372 ../vector/v.in.ogr/main.c:553
-#: ../vector/v.in.lidar/main.c:381
-#, fuzzy
-msgid "Over-riding projection check"
-#: ../raster/r.external/proj.c:42 ../raster/r.in.lidar/main.c:306
-#: ../raster/r.in.gdal/main.c:382 ../vector/v.in.ogr/main.c:562
-#: ../vector/v.in.lidar/main.c:390
-msgid ""
-"Projection of dataset does not appear to match current location.\n"
-"\n"
-msgstr ""
-#: ../raster/r.external/proj.c:47 ../raster/r.in.gdal/main.c:387
-msgid "Location PROJ_INFO is:\n"
-msgstr ""
-#: ../raster/r.external/proj.c:58 ../raster/r.in.gdal/main.c:398
-msgid "Dataset PROJ_INFO is:\n"
-msgstr ""
-#: ../raster/r.external/proj.c:85 ../raster/r.in.lidar/main.c:322
-#: ../raster/r.in.lidar/main.c:329 ../raster/r.in.gdal/main.c:425
-#: ../vector/v.in.ogr/main.c:578 ../vector/v.in.ogr/main.c:585
-#: ../vector/v.in.lidar/main.c:406 ../vector/v.in.lidar/main.c:413
-msgid "Import dataset PROJ_INFO is:\n"
-msgstr ""
-#: ../raster/r.external/proj.c:107
-msgid ""
-"\n"
-"You can use the -o flag to r.external to override this check and use the location definition for the dataset.\n"
-msgstr ""
-#: ../raster/r.external/proj.c:110 ../raster/r.in.gdal/main.c:450
-msgid "Consider generating a new location from the input dataset using the 'location' parameter.\n"
-msgstr ""
-#: ../raster/r.external/proj.c:115 ../raster/r.in.lidar/main.c:380
-#: ../raster/r.in.gdal/main.c:455 ../vector/v.in.ogr/main.c:636
-#: ../vector/v.in.lidar/main.c:464
-msgid "Projection of input dataset and current location appear to match"
-msgstr ""
-#: ../raster/r.external/window.c:23
-msgid "Input raster map is rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
-msgstr ""
-#: ../raster/r.external/window.c:26
-msgid "Applying horizontal flip"
-msgstr ""
-#: ../raster/r.external/window.c:30
-msgid "Applying vertical flip"
-msgstr ""
-#: ../raster/r.external/window.c:93 ../raster/r.in.gdal/main.c:635
-#: ../vector/v.in.ogr/main.c:1257
-msgid "Default region for this location updated"
-msgstr ""
-#: ../raster/r.external/window.c:96 ../raster/r.in.gdal/main.c:638
-#: ../vector/v.in.ogr/main.c:1260
-#, fuzzy
-msgid "Region for the current mapset updated"
-#: ../raster/r.external/list.c:22
-#, fuzzy
-msgid "Supported formats:"
-#: ../raster/r.external/main.c:57 ../vector/v.external/main.c:50
-#, fuzzy
-msgid "input"
-#: ../raster/r.external/main.c:58 ../raster/r.external.out/main.c:217
-#: ../vector/v.external/main.c:51 ../vector/v.external.out/main.c:37
-msgid "external"
-msgstr ""
-#: ../raster/r.external/main.c:60
-#, fuzzy
-msgid "Links GDAL supported raster data as a pseudo GRASS raster map."
-#: ../raster/r.external/main.c:63
-#, fuzzy
-msgid "Name of raster file to be linked"
-#: ../raster/r.external/main.c:65 ../raster/r.external/main.c:73
-#: ../raster/r.external/main.c:82 ../raster/r.topmodel/main.c:70
-#: ../raster/r.topmodel/main.c:78 ../raster/r.in.xyz/main.c:191
-#: ../raster/r.in.xyz/main.c:200 ../raster/r.in.xyz/main.c:208
-#: ../raster/r.in.xyz/main.c:216 ../raster/simwe/r.sim.sediment/main.c:153
-#: ../raster/simwe/r.sim.sediment/main.c:161
-#: ../raster/simwe/r.sim.water/main.c:131
-#: ../raster/simwe/r.sim.water/main.c:140
-#: ../raster/simwe/r.sim.water/main.c:147
-#: ../raster/simwe/r.sim.water/main.c:156
-#: ../raster/simwe/r.sim.water/main.c:162
-#: ../raster/simwe/r.sim.water/main.c:170
-#: ../raster/simwe/r.sim.water/main.c:177 ../vector/v.edit/args.c:90
-#: ../vector/v.edit/args.c:199
-#, fuzzy
-msgid "Input"
-#: ../raster/r.external/main.c:69
-#, fuzzy
-msgid "Name of non-file GDAL data source"
-#: ../raster/r.external/main.c:81
-#, fuzzy
-msgid "Band to select (default: all)"
-msgstr "डेटाबेसची यादी दाखवता येणार नाही"
-#: ../raster/r.external/main.c:89 ../raster/r.in.arc/main.c:88
-#: ../raster/r.in.bin/main.c:279 ../raster/r.in.gdal/main.c:119
-#: ../raster/r.in.poly/main.c:45 ../raster/r.in.ascii/main.c:88
-msgid "Title for resultant raster map"
-msgstr ""
-#: ../raster/r.external/main.c:90 ../raster/r.in.gdal/main.c:120
-#: ../raster/r.in.gdal/main.c:128 ../imagery/i.landsat.toar/main.c:92
-#: ../imagery/i.landsat.toar/main.c:108 ../imagery/i.landsat.toar/main.c:118
-#: ../imagery/i.landsat.toar/main.c:127 ../imagery/i.landsat.toar/main.c:135
-#: ../imagery/i.landsat.toar/main.c:144 ../imagery/i.landsat.toar/main.c:200
-msgid "Metadata"
-msgstr ""
-#: ../raster/r.external/main.c:94 ../raster/r.external.out/main.c:250
-#: ../raster/r.in.gdal/main.c:150 ../vector/v.in.ogr/main.c:226
-#: ../vector/v.external.out/args.c:33
-msgid "List supported formats and exit"
-msgstr ""
-#: ../raster/r.external/main.c:95 ../raster/r.external.out/main.c:251
-#: ../raster/r.external.out/main.c:262 ../raster/r.colors/edit_colors.c:110
-#: ../raster/r.stats/main.c:147 ../raster/r.stats/main.c:152
-#: ../raster/r.stats/main.c:157 ../raster/r.stats/main.c:163
-#: ../raster/r.stats/main.c:168 ../raster/r.stats/main.c:173
-#: ../raster/r.stats/main.c:178 ../raster/r.stats/main.c:183
-#: ../raster/r.sunmask/main.c:229 ../raster/r.sunmask/main.c:235
-#: ../raster/r.in.gdal/main.c:151 ../raster/r.out.gdal/main.c:135
-#: ../imagery/i.group/main.c:80 ../imagery/i.group/main.c:86
-#: ../display/d.mon/main.c:90 ../display/d.mon/main.c:95
-#: ../display/d.mon/main.c:100 ../general/g.proj/main.c:78
-#: ../general/g.proj/main.c:84 ../general/g.proj/main.c:90
-#: ../general/g.proj/main.c:96 ../general/g.proj/main.c:102
-#: ../general/g.proj/main.c:113 ../general/g.proj/main.c:118
-#: ../general/g.mapset/main.c:89 ../general/g.mapset/main.c:95
-#: ../general/g.mlist/main.c:114 ../general/g.mlist/main.c:119
-#: ../general/g.mlist/main.c:124 ../general/g.mlist/main.c:129
-#: ../general/g.region/main.c:83 ../general/g.region/main.c:89
-#: ../general/g.region/main.c:94 ../general/g.region/main.c:100
-#: ../general/g.region/main.c:106 ../general/g.region/main.c:112
-#: ../general/g.region/main.c:118 ../general/g.region/main.c:126
-#: ../general/g.region/main.c:131 ../general/g.region/main.c:137
-#: ../general/g.region/main.c:142 ../general/g.mapsets/main.c:98
-#: ../general/g.mapsets/main.c:103 ../vector/v.in.ogr/main.c:215
-#: ../vector/v.in.ogr/main.c:222 ../vector/v.in.ogr/main.c:228
-#: ../vector/v.db.connect/main.c:82 ../vector/v.db.connect/main.c:87
-#: ../vector/v.db.connect/main.c:94 ../vector/v.db.connect/main.c:101
-#: ../vector/v.colors/main.c:120 ../vector/v.to.db/parse.c:94
-#: ../vector/v.to.db/parse.c:99 ../vector/v.to.db/parse.c:105
-#: ../vector/v.external/args.c:42 ../vector/v.external/args.c:48
-#: ../vector/v.external/args.c:55 ../vector/v.external.out/args.c:34
-#: ../vector/v.external.out/args.c:46 ../vector/v.external.out/args.c:52
-#: ../vector/v.info/parse.c:25 ../vector/v.info/parse.c:31
-#: ../vector/v.info/parse.c:36 ../vector/v.info/parse.c:41
-#: ../vector/v.info/parse.c:46 ../vector/v.what/main.c:86
-#: ../vector/v.what/main.c:91 ../vector/v.what/main.c:96
-#: ../db/db.connect/main.c:53
-#: ../locale/scriptstrings/g.extension_to_translate.c:11
-#: ../locale/scriptstrings/g.extension_to_translate.c:13
-#: ../locale/scriptstrings/g.extension_to_translate.c:15
-#: ../locale/scriptstrings/g.extension_to_translate.c:17
-msgid "Print"
-msgstr ""
-#: ../raster/r.external/main.c:101 ../raster/r.in.gdal/main.c:140
-msgid "Override projection (use location's projection)"
-msgstr ""
-#: ../raster/r.external/main.c:105 ../raster/r.in.gdal/main.c:144
-#: ../vector/v.in.ogr/main.c:259 ../vector/v.in.lidar/main.c:213
-msgid "Extend region extents based on new dataset"
-msgstr ""
-#: ../raster/r.external/main.c:106 ../raster/r.in.gdal/main.c:146
-#: ../vector/v.in.ogr/main.c:261
-msgid "Also updates the default region if in the PERMANENT mapset"
-msgstr ""
-#: ../raster/r.external/main.c:110
-msgid "Require exact range"
-msgstr ""
-#: ../raster/r.external/main.c:114
-msgid "Flip horizontally"
-msgstr ""
-#: ../raster/r.external/main.c:118
-msgid "Flip vertically"
-msgstr ""
-#: ../raster/r.external/main.c:148
-#, fuzzy, c-format
-msgid "One of options <%s> or <%s> must be given"
-#: ../raster/r.external/main.c:152
-#, c-format
-msgid "Option <%s> and <%s> are mutually exclusive"
-msgstr ""
-#: ../raster/r.external/main.c:181 ../raster/r.in.gdal/main.c:461
-msgid "Proceeding with import..."
-msgstr ""
-#: ../raster/r.external/main.c:185
-#, fuzzy, c-format
-msgid "Imagery group <%s> already exists and will be overwritten."
-#: ../raster/r.external/main.c:192
-#, fuzzy, c-format
-msgid "Reading band %d of %d..."
-#: ../raster/r.external/main.c:197 ../raster/r.in.gdal/main.c:486
-#, c-format
-msgid "Selected band (%d) does not exist"
-msgstr ""
-#: ../raster/r.external/main.c:226
-#, fuzzy, c-format
-msgid "Imagery group <%s> created"
-#: ../raster/r.external/link.c:48
-#, fuzzy
-msgid "Complex types not supported"
-#: ../raster/r.external/link.c:63
-#, fuzzy, c-format
-msgid "Copying color table for %s"
-#: ../raster/r.external/link.c:81
-#, fuzzy, c-format
-msgid "Setting grey color table for <%s> (full 8bit range)"
-#: ../raster/r.external/link.c:87
-#, fuzzy, c-format
-msgid "Setting grey color table for <%s> (data range)"
-#: ../raster/r.external/link.c:101
-#, fuzzy, c-format
-msgid "Unable to create cell/%s file"
-#: ../raster/r.external/link.c:110
-#, fuzzy, c-format
-msgid "Unable to create fcell/%s file"
-#: ../raster/r.external/link.c:146
-#, fuzzy, c-format
-msgid "Unable to create cell_misc/%s/gdal file"
-#: ../raster/r.external/link.c:149
-#, fuzzy, c-format
-msgid "Error writing cell_misc/%s/gdal file"
-#: ../raster/r.external/link.c:174
-#, fuzzy, c-format
-msgid "Unable to create cell_misc/%s/f_format file"
-#: ../raster/r.external/link.c:177
-#, fuzzy, c-format
-msgid "Error writing cell_misc/%s/f_format file"
-#: ../raster/r.external/link.c:224
-#, fuzzy, c-format
-msgid "Creating support files for %s"
-#: ../raster/r.external/link.c:236
-#, fuzzy, c-format
-msgid "Link to raster map <%s> created."
-#: ../raster/r.uslek/main.c:55
-msgid "soil"
-msgstr ""
-#: ../raster/r.uslek/main.c:56 ../raster/r.usler/main.c:54
-#: ../raster/simwe/r.sim.sediment/main.c:114
-msgid "erosion"
-msgstr ""
-#: ../raster/r.uslek/main.c:57
-msgid "Computes USLE Soil Erodibility Factor (K)."
-msgstr ""
-#: ../raster/r.uslek/main.c:62
-#, fuzzy
-msgid "Name of soil sand fraction raster map [0.0-1.0]"
-#: ../raster/r.uslek/main.c:66
-#, fuzzy
-msgid "Name of soil clay fraction raster map [0.0-1.0]"
-#: ../raster/r.uslek/main.c:70
-#, fuzzy
-msgid "Name of soil silt fraction raster map [0.0-1.0]"
-#: ../raster/r.uslek/main.c:74
-#, fuzzy
-msgid "Name of soil organic matter raster map [0.0-1.0]"
-#: ../raster/r.uslek/main.c:77
-#, fuzzy
-msgid "Name for output USLE K factor raster map [t.ha.hr/ha.MJ.mm]"
-#: ../raster/r.mode/main.c:55 ../raster/r.mfilter/main.c:57
-#: ../raster/r.quantile/main.c:256 ../raster/r.bitpattern/main.c:64
-#: ../raster/r.neighbors/main.c:118 ../raster/r.texture/main.c:102
-#: ../raster/r.mapcalc/main.c:112
-#, fuzzy
-msgid "algebra"
-#: ../raster/r.mode/main.c:58
-msgid "Finds the mode of values in a cover map within areas assigned the same category value in a user-specified base map."
-msgstr ""
-#: ../raster/r.mode/main.c:64
-msgid "Base map to be reclassified"
-msgstr ""
-#: ../raster/r.mode/main.c:71
-msgid "Coverage map"
-msgstr ""
-#: ../raster/r.mode/main.c:78
-msgid "Output map"
-msgstr ""
-#: ../raster/r.mode/main.c:91
-#, fuzzy, c-format
-msgid "%s: Unable to read category labels"
-#: ../raster/r.mode/read_stats.c:14
-msgid "reading r.stats output"
-msgstr ""
-#: ../raster/r.profile/main.c:51 ../display/d.profile/main.c:193
-msgid "profile"
-msgstr ""
-#: ../raster/r.profile/main.c:53
-msgid "Outputs the raster map layer values lying on user-defined line(s)."
-msgstr ""
-#: ../raster/r.profile/main.c:64
-msgid "Name of file for output (use output=- for stdout)"
-msgstr ""
-#: ../raster/r.profile/main.c:72 ../display/d.profile/main.c:206
-msgid "Profile coordinate pairs"
-msgstr ""
-#: ../raster/r.profile/main.c:79
-msgid "Resolution along profile (default = current region resolution)"
-msgstr ""
-#: ../raster/r.profile/main.c:86
-msgid "Character to represent no data cell"
-msgstr ""
-#: ../raster/r.profile/main.c:91 ../raster/r.transect/main.c:130
-msgid "Output easting and northing in first two columns of four column output"
-msgstr ""
-#: ../raster/r.profile/main.c:96
-msgid "Output RRR:GGG:BBB color values for each profile point"
-msgstr ""
-#: ../raster/r.profile/main.c:115
-#, c-format
-msgid "Illegal resolution! [%g]"
-msgstr ""
-#: ../raster/r.profile/main.c:122
-#, c-format
-msgid "Using resolution [%g]"
-msgstr ""
-#: ../raster/r.profile/main.c:153
-msgid "Output Format:"
-msgstr ""
-#: ../raster/r.profile/main.c:156
-#, c-format
-msgid "[Easting] [Northing] [Along Track Dist.(m)] [Elevation]"
-msgstr ""
-#: ../raster/r.profile/main.c:158
-#, c-format
-msgid "[Along Track Dist.(m)] [Elevation]"
-msgstr ""
-#: ../raster/r.profile/main.c:160
-msgid " [RGB Color]"
-msgstr ""
-#: ../raster/r.profile/main.c:170
-#, c-format
-msgid "Invalid coordinates %s %s"
-msgstr ""
-#: ../raster/r.profile/main.c:238
-#, c-format
-msgid "Approx. transect length [%f] m"
-msgstr ""
-#: ../raster/r.profile/main.c:241
-msgid "Endpoint coordinates are outside of current region settings"
-msgstr ""
-#: ../raster/r.profile/input.c:29 ../raster/r.profile/input.c:46
-#: ../raster/r.profile/input.c:59
-msgid "One coordinate pair per line, please"
-msgstr ""
-#: ../raster/r.category/main.c:53 ../vector/v.category/main.c:74
-#, fuzzy
-msgid "category"
-#: ../raster/r.category/main.c:55
-msgid "Manages category values and labels associated with user-specified raster map layers."
-msgstr ""
-#: ../raster/r.category/main.c:68
-#, fuzzy
-msgid "Comma separated value list"
-#: ../raster/r.category/main.c:69
-msgid "Example: 1.4,3.8,13"
-msgstr ""
-#: ../raster/r.category/main.c:74 ../raster/r.distance/parse.c:47
-#: ../raster/r.stats/main.c:119 ../vector/v.vect.stats/main.c:203
-#: ../vector/v.db.select/main.c:65 ../db/db.select/main.c:218
-#: ../locale/scriptstrings/r.tileset_to_translate.c:14
-msgid "Output field separator"
-msgstr ""
-#: ../raster/r.category/main.c:80 ../raster/r.support/main.c:116
-#, fuzzy
-msgid "Raster map from which to copy category table"
-#: ../raster/r.category/main.c:86
-msgid "File containing category label rules (or \"-\" to read from stdin)"
-msgstr ""
-#: ../raster/r.category/main.c:93
-msgid "Default label or format string for dynamic labeling"
-msgstr ""
-#: ../raster/r.category/main.c:95
-msgid "Used when no explicit label exists for the category"
-msgstr ""
-#: ../raster/r.category/main.c:103
-msgid "Dynamic label coefficients"
-msgstr ""
-#: ../raster/r.category/main.c:105
-msgid "Two pairs of category multiplier and offsets, for $1 and $2"
-msgstr ""
-#: ../raster/r.category/main.c:138 ../raster/r.support/main.c:148
-#, fuzzy, c-format
-msgid "Raster map <%s> not found in current mapset"
-#: ../raster/r.category/main.c:156 ../raster/r.category/main.c:212
-#: ../raster/r.report/parse.c:266 ../raster/r.mapcalc/map.c:216
-#: ../raster/r.mapcalc/map3.c:188
-#, fuzzy, c-format
-msgid "Unable to read category file of raster map <%s@%s>"
-#: ../raster/r.category/main.c:160
-#, fuzzy, c-format
-msgid "Category table for <%s> set from <%s>"
-#: ../raster/r.category/main.c:249
-#, fuzzy, c-format
-msgid "Unable to read category file of raster map <%s> in <%s>"
-#: ../raster/r.category/main.c:265
-msgid "The map is floating point! Ignoring cats list, using vals list"
-msgstr ""
-#: ../raster/r.category/main.c:282
-msgid "vals argument is required for floating point map!"
-msgstr ""
-#: ../raster/r.category/cats.c:47
-#, fuzzy, c-format
-msgid "Reading <%s> in <%s>"
-#: ../raster/r.watershed/ram/init_vars.c:109
-#, c-format
-msgid "SECTION 1a (of %1d): Initiating Memory."
-msgstr ""
-#: ../raster/r.watershed/ram/init_vars.c:284
-#, c-format
-msgid "SECTION 1b (of %1d): Determining Offmap Flow."
-msgstr ""
-#: ../raster/r.watershed/ram/sg_factor.c:14
-msgid "SECTION 4: RUSLE LS and/or S factor determination."
-msgstr ""
-#: ../raster/r.watershed/ram/do_astar.c:27
-#: ../raster/r.watershed/seg/do_astar.c:33
-msgid "SECTION 2: A* Search."
-msgstr ""
-#: ../raster/r.watershed/ram/do_astar.c:220
-msgid "heapsize too large"
-msgstr ""
-#: ../raster/r.watershed/ram/do_cum.c:16 ../raster/r.watershed/seg/do_cum.c:20
-msgid "SECTION 3: Accumulating Surface Flow with SFD."
-msgstr ""
-#: ../raster/r.watershed/ram/do_cum.c:111
-#: ../raster/r.watershed/seg/do_cum.c:132
-msgid "SECTION 3: Accumulating Surface Flow with MFD."
-msgstr ""
-#: ../raster/r.watershed/ram/do_cum.c:306
-#: ../raster/r.watershed/seg/do_cum.c:352
-#, c-format
-msgid "MFD: cumulative proportion of flow distribution not 1.0 but %f"
-msgstr ""
-#: ../raster/r.watershed/ram/do_cum.c:354
-#: ../raster/r.watershed/seg/do_cum.c:410
-#, c-format
-msgid "MFD: A * path already processed when distributing flow: %d of %d cells"
-msgstr ""
-#: ../raster/r.watershed/ram/main.c:82 ../raster/r.watershed/ram/main.c:98
-#: ../raster/r.watershed/seg/main.c:90 ../raster/r.watershed/seg/main.c:105
-#, c-format
-msgid "SECTION %d: Closing Maps."
-msgstr ""
-#: ../raster/r.watershed/ram/main.c:96 ../raster/r.watershed/seg/main.c:103
-#, c-format
-msgid "SECTION %d: Watershed determination."
-msgstr ""
-#: ../raster/r.watershed/ram/usage.c:9 ../raster/r.watershed/seg/usage.c:9
-#, c-format
-msgid ""
-"USAGE for basin delineation:\n"
-"%s -4 elevation=elevation_map threshold=swale_threshold [flow=overland_flow_map] [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [basin=watershed_basin_map] [stream=stream_segment_map]\n"
-"\n"
-"USAGE for slope length determination:\n"
-"%s [-4] elevation=elevation_map threshold=swale_threshold [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [max_slope_length=max_slope_length] [blocking=overland_blocking_map] [slope_steepness=slope_steepness_map] length_slope=length_slope_map [disturbed_land=rill_erosion_map] [slope_deposition=slope_deposition value or map]USAGE for ARMSED FILE creation:\n"
-"%s [-4] elevation=elevation_map threshold=swale_threshold [flow=overland_flow_map] [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [basin=watershed_basin_map] [stream=stream_segment_map] [half_basin=half_basin_map] ar=ARMSED_file_name\n"
-"\n"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:56
-msgid "Beautify flat areas: priority queue error"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:229
-msgid "flat cell escaped for uphill correction"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:235
-#, c-format
-msgid "queue error: last uphill order %d > current uphill order %d"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:240
-msgid "uphill order not set"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:266
-msgid "flat cell escaped in uphill correction"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:302
-msgid "downhill order: no more points in down queue"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:310
-msgid "flat cell escaped for downhill correction"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:316
-#, c-format
-msgid "queue error: last downhill order %d > current downhill order %d"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:321
-msgid "downhill order: downhill order not set"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:344
-msgid "flat cell escaped in downhill correction"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:382
-msgid "flat cell escaped for adjustment"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:389
-msgid "adjustment: uphill order not set"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:391
-msgid "adjustment: downhill order not set"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:417
-msgid "flat cell escaped in adjustment"
-msgstr ""
-#: ../raster/r.watershed/seg/init_vars.c:124
-#, c-format
-msgid "SECTION 1 beginning: Initiating Variables. %d sections total."
-msgstr ""
-#: ../raster/r.watershed/seg/init_vars.c:158
-msgid "Maximum memory to be used was smaller than 3 MB, set to 3 MB."
-msgstr ""
-#: ../raster/r.watershed/seg/init_vars.c:233
-#, c-format
-msgid "Will need up to %.2f MB of disk space"
-msgstr ""
-#: ../raster/r.watershed/seg/init_vars.c:235
-#, c-format
-msgid "Will need up to %.2f GB (%.0f MB) of disk space"
-msgstr ""
-#: ../raster/r.watershed/seg/init_vars.c:447
-msgid "SECTION 1b: Determining Offmap Flow."
-msgstr ""
-#: ../raster/r.watershed/seg/sg_factor.c:14
-msgid "SECTION 5: RUSLE LS and/or S factor determination."
-msgstr ""
-#: ../raster/r.watershed/seg/do_astar.c:51
-msgid "No seeds for A* Search"
-msgstr ""
-#: ../raster/r.watershed/seg/do_astar.c:163
-#, c-format
-msgid "bug in A* Search: doer %d heap size %d count %d"
-msgstr ""
-#: ../raster/r.watershed/seg/close_maps2.c:82
-msgid "Closing stream segments map"
-msgstr ""
-#: ../raster/r.watershed/seg/close_maps2.c:105
-#, fuzzy
-msgid "Closing basins map"
-#: ../raster/r.watershed/seg/close_maps2.c:112
-msgid "Closing half basins map"
-msgstr ""
-#: ../raster/r.watershed/seg/close_maps.c:20
-msgid "Closing accumulation map"
-msgstr ""
-#: ../raster/r.watershed/seg/close_maps.c:128
-msgid "Closing flow direction map"
-msgstr ""
-#: ../raster/r.watershed/seg/close_maps.c:136
-msgid "Closing LS map"
-msgstr ""
-#: ../raster/r.watershed/seg/close_maps.c:141
-msgid "Closing SL map"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:23
-msgid ""
-"\n"
-"This set of questions will organize the command line for the"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:24
-#, c-format
-msgid "%s program to run properly for your application."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:26
-#, c-format
-msgid "The first question is whether you want %s to run"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:28
-#, c-format
-msgid "in its fast mode or its slow mode.  If you run %s"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:30
-msgid "in the fast mode, the computer will finish about 10 times faster"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:31
-msgid "than in the slow mode, but will not allow other programs to run"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:32
-msgid "at the same time.  The fast mode also places all of the data into"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:33
-msgid "RAM, which limits the size of window that can be run.  The slow"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:34
-msgid "mode uses disk space in the same hard disk partition as where GRASS is"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:35
-msgid "stored.  Thus, if the program does not work in the slow mode, you will"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:36
-msgid "need to remove unnecessary files from that partition.  The slow mode"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:37
-#, c-format
-msgid "will allow other processes to run concurrently with %s.\n"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:69
-#: ../raster/r.watershed/shed/com_line.c:182
-msgid ""
-"\n"
-"If you hit <return> by itself for the next question, this"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:70
-#: ../raster/r.watershed/shed/com_line.c:183
-msgid "program will terminate."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:81
-#, c-format
-msgid ""
-"\n"
-"One of the options for %s is a `depression map'.  A"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:83
-msgid "depression map indicates all the locations in the current map window where"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:84
-msgid "water accumulates and does not leave by the edge of the map. Lakes without"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:85
-msgid "outlet streams and sinkholes are examples of `depressions'.  If you wish to"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:86
-msgid "have a depression map, prepare a map where non-zero values indicate the"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:87
-msgid "locations where depressions occur.\n"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:88
-msgid "Hit <return> by itself for the next question if there is no depression map."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:99
-#, c-format
-msgid ""
-"\n"
-"The %s program will divide the elevation map into a number of"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:101
-msgid "watershed basins.  The number of watershed basins is indirectly determined"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:102
-msgid "by the `basin threshold' value.  The basin threshold is the area necessary for"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:103
-#, c-format
-msgid "%s to define a unique watershed basin.  This area only applies to"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:105
-msgid "`exterior drainage basins'.  An exterior drainage basin does not have any"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:106
-msgid "drainage basins flowing into it.  Interior drainage basin size is determined"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:107
-msgid "by the surface flow going into stream segments between stream interceptions."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:108
-#, c-format
-msgid "Thus interior drainage basins can be of any size.  The %s program"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:110
-msgid "also allows the user to relate basin size to potential overland flow"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:111
-msgid "(i.e., areas with low infiltration capacities will need smaller areas to"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:112
-msgid "develop stream channels than neighboring areas with high infiltration rates)."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:113
-msgid "The user can create a map layer with potential overland flow values, and"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:114
-#, c-format
-msgid "%s will accumulate those values instead of area.\n"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:116
-msgid "What unit of measure will you use for the basin threshold:"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:119
-msgid " 1) acres,          2) meters sq., 3) miles sq., 4) hectares,"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:120
-msgid " 5) kilometers sq., 6) map cells,  7) overland flow units"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:121
-#, c-format
-msgid "Choose 1-7 or 0 to exit this program: "
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:131
-msgid ""
-"\n"
-"How large an area (or how many overland flow units) must a drainage basin"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:132
-#, c-format
-msgid "be for it to be an exterior drainage basin: "
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:201
-#, c-format
-msgid ""
-"\n"
-"%s must create a map layer of watershed basins"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:203
-#: ../raster/r.watershed/shed/com_line.c:224
-#, c-format
-msgid "before %s can run properly."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:222
-#, c-format
-msgid ""
-"\n"
-"%s must create a file of watershed basin relationships"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:228
-#: ../raster/r.watershed/shed/com_line.c:263
-#, c-format
-msgid ""
-"\n"
-"Please name this file:"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:231
-#: ../raster/r.watershed/shed/com_line.c:266 ../raster/r.drain/main.c:199
-#: ../imagery/i.landsat.acca/main.c:189 ../imagery/i.landsat.toar/main.c:498
-#: ../general/g.rename/main.c:79 ../general/g.copy/main.c:81
-#, c-format
-msgid "<%s> is an illegal file name"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:257
-#, c-format
-msgid ""
-"\n"
-"%s will generate a lot of output.  Indicate a file"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:259
-#, c-format
-msgid "name for %s to send the output to."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:277
-#, c-format
-msgid ""
-"\n"
-"The accumulation map from %s must be present for"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:279
-#, c-format
-msgid "%s to work properly."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:290
-#, c-format
-msgid ""
-"\n"
-"%s can produce several maps not necessary for"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:292
-#, c-format
-msgid "%s to function (stream channels, overland flow aspect, and"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:294
-#, c-format
-msgid "a display version of the accumulation map).  %s also has the"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:296
-msgid "ability to generate several variables in the Revised Universal Soil Loss"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:297
-msgid "Equation (Rusle): Slope Length (LS), and Slope Steepness (S).\n"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:348
-msgid ""
-"\n"
-"The Slope Length factor (LS) and Slope Steepness (S) are influenced by"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:349
-#, c-format
-msgid "disturbed land.  %s reflects this with an optional map layer or value"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:351
-msgid "where the value indicates the percent of disturbed (barren) land in that cell."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:352
-msgid "Type <return> if you do not have a disturbed land map layer."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:364
-msgid ""
-"\n"
-"Type the value indicating the percent of disturbed land.  This value will"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:365
-msgid "be used for every cell in the current region."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:368
-#, c-format
-msgid ""
-"\n"
-"Input value here [0-100]: "
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:379
-msgid ""
-"\n"
-"Overland surface flow only occurs for a set distance before swales form."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:380
-#, c-format
-msgid "Because of digital terrain model limitations, %s cannot pick up"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:382
-#, c-format
-msgid "these swales.  %s allows for an input (warning: kludge factor)"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:384
-msgid "that prevents the surface flow distance from getting too long.  Normally,"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:385
-msgid "maximum slope length is around 600 feet (about 183 meters)."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:400
-msgid ""
-"\n"
-"Roads, ditches, changes in ground cover, and other factors will stop"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:401
-msgid "slope length.  You may input a raster map indicating the locations of these"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:402
-msgid "blocking factors.\n"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:403
-msgid "Hit <return> by itself for the next question if there is no blocking map."
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:12
-msgid ""
-"\n"
-"\n"
-"Please indicate which map layers you wish to use in the lumped"
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:13
-msgid "parameter hydrologic/soil erosion model.  Continue inputing cell map"
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:14
-msgid "layers, one at a time, until all desired map layers are in."
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:15
-#, c-format
-msgid "You can have %s include a list of categories in each."
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:17
-#, c-format
-msgid ""
-"\n"
-"Hit <return> at the map prompt to continue with %s"
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:36
-#, c-format
-msgid ""
-"\n"
-"The output from %s will be divided into watershed"
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:38
-msgid "basins.  There are two possible methods of tabulating the information:"
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:39
-msgid "1) by only including data pertaining to the basin itself, or 2) using"
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:40
-msgid "data from the basin, and all basins upstream of it."
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:43
-msgid ""
-"\n"
-"Would you like the data organized:"
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:44
-msgid ""
-"1) Basin only\n"
-"2) Upstream only\n"
-"3) Both\n"
-"OR 0) to cancel program"
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:45
-#, c-format
-msgid ""
-"\n"
-"Your choice: "
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:69
-#: ../raster/r.watershed/shed/basin_maps.c:73
-#, c-format
-msgid ""
-"\n"
-"OK, %s should start running now using the following form:\n"
-"%s"
-msgstr ""
-#: ../raster/r.watershed/shed/read.c:23
-msgid "unable to open basin/half basin map"
-msgstr ""
-#: ../raster/r.watershed/shed/intro.c:8
-#, c-format
-msgid "%s provides a text-based user-interface to the %s program."
-msgstr ""
-#: ../raster/r.watershed/shed/intro.c:10
-#, c-format
-msgid "%s also allows the user to prepare a report of map layers for each"
-msgstr ""
-#: ../raster/r.watershed/shed/intro.c:12
-#, c-format
-msgid "watershed basin determined in %s.\n"
-msgstr ""
-#: ../raster/r.watershed/shed/intro.c:14
-#, c-format
-msgid "%s will help the user determine which options to use for the"
-msgstr ""
-#: ../raster/r.watershed/shed/intro.c:16
-#, c-format
-msgid "%s program.  %s will then ask for map layers that will be"
-msgstr ""
-#: ../raster/r.watershed/shed/intro.c:18
-#, c-format
-msgid "divided by basin. %s will then run %s and create the report."
-msgstr ""
-#: ../raster/r.watershed/shed/valid.c:24
-msgid "accum file missing in valid_basins()"
-msgstr ""
-#: ../raster/r.watershed/shed/file_in.c:15
-msgid "unable to open ARMSED file"
-msgstr ""
-#: ../raster/r.watershed/shed/main.c:41
-msgid "Slow version of water analysis program starting now"
-msgstr ""
-#: ../raster/r.watershed/shed/main.c:46 ../raster/r.watershed/shed/main.c:55
-#, c-format
-msgid "<<%s>> command line failed"
-msgstr ""
-#: ../raster/r.watershed/shed/main.c:72
-msgid "unable to open output file"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:73
-msgid "Calculates hydrological parameters and RUSLE factors."
-msgstr ""
-#: ../raster/r.watershed/front/main.c:76 ../raster/r.watershed/front/main.c:83
-#: ../raster/r.watershed/front/main.c:89 ../raster/r.watershed/front/main.c:96
-#: ../raster/r.watershed/front/main.c:105
-#: ../raster/r.watershed/front/main.c:113
-#: ../raster/r.watershed/front/main.c:122
-#, fuzzy
-msgid "Inputs"
-#: ../raster/r.watershed/front/main.c:80
-#, fuzzy
-msgid "Name of input depressions raster map"
-#: ../raster/r.watershed/front/main.c:81
-msgid "All non-NULL and non-zero cells are considered as real depressions"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:87
-#, fuzzy
-msgid "Name of input raster representing amount of overland flow per cell"
-#: ../raster/r.watershed/front/main.c:93
-#, fuzzy
-msgid "Name of input raster map percent of disturbed land"
-#: ../raster/r.watershed/front/main.c:94
-#: ../raster/r.watershed/front/main.c:119
-msgid "For USLE"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:101
-#, fuzzy
-msgid "IName of input raster map blocking overland surface flow"
-#: ../raster/r.watershed/front/main.c:103
-msgid "For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
-msgstr ""
-#: ../raster/r.watershed/front/main.c:110
-msgid "Minimum size of exterior watershed basin"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:118
-msgid "Maximum length of surface flow in map units"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:127
-#, fuzzy
-msgid "Name for output accumulation raster map"
-#: ../raster/r.watershed/front/main.c:129
-#, fuzzy
-msgid "Number of cells that drain through each cell"
-#: ../raster/r.watershed/front/main.c:131
-#: ../raster/r.watershed/front/main.c:137
-#: ../raster/r.watershed/front/main.c:145
-#: ../raster/r.watershed/front/main.c:151
-#: ../raster/r.watershed/front/main.c:159
-#: ../raster/r.watershed/front/main.c:167
-#: ../raster/r.watershed/front/main.c:174 ../raster/r.slope.aspect/main.c:164
-#: ../raster/r.slope.aspect/main.c:170 ../raster/r.slope.aspect/main.c:196
-#: ../raster/r.slope.aspect/main.c:203 ../raster/r.slope.aspect/main.c:210
-#: ../raster/r.slope.aspect/main.c:217 ../raster/r.slope.aspect/main.c:224
-#: ../raster/r.slope.aspect/main.c:231 ../raster/r.slope.aspect/main.c:238
-#: ../vector/v.surf.rst/main.c:166 ../vector/v.surf.rst/main.c:193
-#: ../vector/v.surf.rst/main.c:199 ../vector/v.surf.rst/main.c:205
-#: ../vector/v.surf.rst/main.c:211 ../vector/v.surf.rst/main.c:217
-#: ../vector/v.surf.rst/main.c:223 ../vector/v.surf.rst/main.c:229
-#: ../vector/v.surf.rst/main.c:236 ../vector/v.surf.rst/main.c:243
-#: ../vector/v.surf.rst/main.c:250
-msgid "Outputs"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:135
-#, fuzzy
-msgid "Name for output drainage direction raster map"
-#: ../raster/r.watershed/front/main.c:142
-#, fuzzy
-msgid "Name for basins raster map"
-#: ../raster/r.watershed/front/main.c:143
-msgid "Unique label for each watershed basin"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:149
-#, fuzzy
-msgid "Name for output stream segments raster map"
-#: ../raster/r.watershed/front/main.c:155
-#, fuzzy
-msgid "Name for output half basins raster map"
-#: ../raster/r.watershed/front/main.c:157
-msgid "Each half-basin is given a unique value"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:163
-#, fuzzy
-msgid "Name for output slope length raster map"
-#: ../raster/r.watershed/front/main.c:165
-msgid "Slope length and steepness (LS) factor for USLE"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:171
-#, fuzzy
-msgid "Name for output slope steepness raster map"
-msgstr "'%s'. ड्राइवर चालू होत नाही"
-#: ../raster/r.watershed/front/main.c:172
-msgid "Slope steepness (S) factor for USLE"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:181
-msgid "Convergence factor for MFD (1-10)"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:183
-msgid "1 = most diverging flow, 10 = most converging flow. Recommended: 5"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:190
-msgid "Maximum memory to be used with -m flag (in MB)"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:194
-msgid "SFD (D8) flow (default is MFD)"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:196
-msgid "SFD: single flow direction, MFD: multiple flow direction"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:201
-msgid "Allow only horizontal and vertical flow of water"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:206
-msgid "Enable disk swap memory option: Operation is slow"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:208
-msgid "Only needed if memory requirements exceed available RAM; see manual on how to calculate memory requirements"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:213
-msgid "Use positive flow accumulation even for likely underestimates"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:215
-msgid "See manual for a detailed description of flow accumulation output"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:220
-msgid "Beautify flat areas"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:222
-msgid "Flow direction in flat areas is modified to look prettier"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:238
-#, fuzzy
-msgid "Sorry, you must choose an output map."
-#: ../raster/r.watershed/front/main.c:254
-msgid ""
-"Sorry, if any of the following options are set:\n"
-"    basin, stream, half_basin, length_slope, or slope_steepness\n"
-"    you MUST provide a value for the basin threshold parameter."
-msgstr ""
-#: ../raster/r.watershed/front/main.c:281
-msgid "Beautify flat areas is not yet supported for disk swap mode"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:307
-#, c-format
-msgid "Subprocess failed with exit code %d"
-msgstr ""
-#: ../raster/r.colors.out/raster_main.c:46
-#: ../raster/r.colors.out/raster3d_main.c:47
-#: ../raster/r.colors/edit_colors.c:64 ../raster/r.what.color/main.c:90
-#: ../vector/v.colors.out/main.c:50 ../vector/v.colors/main.c:56
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:3
-#, fuzzy
-msgid "color table"
-msgstr "तक्त्याचे नाव"
-#: ../raster/r.colors.out/raster_main.c:49
-#, fuzzy
-msgid "Exports the color table associated with a raster map."
-#: ../raster/r.colors.out/raster_main.c:55
-#: ../raster/r.colors.out/raster3d_main.c:56 ../vector/v.colors.out/main.c:61
-#, fuzzy
-msgid "Path to output rules file"
-#: ../raster/r.colors.out/raster_main.c:56
-#: ../raster/r.colors.out/raster3d_main.c:57 ../vector/v.colors.out/main.c:62
-#, fuzzy
-msgid "\"-\" to write to stdout"
-#: ../raster/r.colors.out/raster_main.c:61
-#: ../raster/r.colors.out/raster3d_main.c:62 ../vector/v.colors.out/main.c:72
-#, fuzzy
-msgid "Output values as percentages"
-#: ../raster/r.colors.out/raster_main.c:69
-#: ../raster/r.colors/edit_colors.c:271 ../raster/r.grow.distance/main.c:357
-#: ../vector/v.colors/main.c:267
-#, fuzzy, c-format
-msgid "Unable to read color table for raster map <%s>"
-#: ../raster/r.colors.out/raster_main.c:79
-#: ../raster/r.colors.out/raster3d_main.c:80 ../raster/r.support/main.c:166
-#: ../raster/r.out.png/main.c:205 ../raster/r.out.pov/main.c:173
-#: ../raster/r.out.mat/main.c:93 ../raster/r.out.vrml/main.c:141
-#: ../general/g.pnmcat/main.c:174 ../general/g.cairocomp/main.c:65
-#: ../vector/v.colors.out/main.c:103
-#, c-format
-msgid "Unable to open output file <%s>"
-msgstr ""
-#: ../raster/r.colors.out/raster3d_main.c:50
-#, fuzzy
-msgid "Exports the color table associated with a 3D raster map."
-#: ../raster/r.colors.out/raster3d_main.c:70
-#, fuzzy, c-format
-msgid "Unable to read color table for raster3d map <%s>"
-#: ../raster/r.drain/main.c:110
-#, fuzzy
-msgid "Traces a flow through an elevation model on a raster map."
-#: ../raster/r.drain/main.c:120
-msgid "Name of movement direction map associated with the cost surface"
-msgstr ""
-#: ../raster/r.drain/main.c:130
-msgid "Output drain vector map (recommended for cost surface made using knight's move)"
-msgstr ""
-#: ../raster/r.drain/main.c:138
-msgid "Map coordinates of starting point(s) (E,N)"
-msgstr ""
-#: ../raster/r.drain/main.c:139 ../raster/r.drain/main.c:145
-#: ../raster/r.cost/main.c:172 ../raster/r.cost/main.c:184
-#: ../raster/r.cost/main.c:193 ../raster/r.cost/main.c:243
-msgid "Start"
-msgstr ""
-#: ../raster/r.drain/main.c:144
-#, fuzzy
-msgid "Name of vector map(s) containing starting point(s)"
-#: ../raster/r.drain/main.c:149
-msgid "Copy input cell values on output"
-msgstr ""
-#: ../raster/r.drain/main.c:153
-msgid "Accumulate input values along the path"
-msgstr ""
-#: ../raster/r.drain/main.c:157
-msgid "Count cell numbers along the path"
-msgstr ""
-#: ../raster/r.drain/main.c:162
-msgid "The input surface is a cost surface (if checked, a direction surface must also be specified"
-msgstr ""
-#: ../raster/r.drain/main.c:174
-msgid "Directional drain selected... checking for direction raster"
-msgstr ""
-#: ../raster/r.drain/main.c:177
-msgid "Surface/Hydrology drain selected"
-msgstr ""
-#: ../raster/r.drain/main.c:183
-msgid "Direction raster not specified, if direction flag is on, a direction raster must be given"
-msgstr ""
-#: ../raster/r.drain/main.c:191
-#, c-format
-msgid "Direction map <%s> should not be specified for Surface/Hydrology drains"
-msgstr ""
-#: ../raster/r.drain/main.c:197
-#, fuzzy
-msgid "Outputting a vector path"
-#: ../raster/r.drain/main.c:214
-msgid "Specify just one of the -c, -a and -n flags"
-msgstr ""
-#: ../raster/r.drain/main.c:233
-#, fuzzy
-msgid "Metrics allocation"
-#: ../raster/r.drain/main.c:244
-#, c-format
-msgid "Starting point %d is outside the current region"
-msgstr ""
-#: ../raster/r.drain/main.c:252 ../raster/r.drain/main.c:303
-#, fuzzy
-msgid "Too many start points"
-#: ../raster/r.drain/main.c:262 ../raster/r.cost/main.c:538
-#: ../raster/r.walk/main.c:721
-#, fuzzy, c-format
-msgid "Reading vector map <%s> with start points..."
-#: ../raster/r.drain/main.c:282 ../raster/r.cost/main.c:558
-#: ../raster/r.cost/main.c:626 ../raster/r.walk/main.c:741
-#: ../raster/r.walk/main.c:807 ../display/d.vect/dir.c:27
-#: ../display/d.vect/lines.c:143 ../display/d.vect/attr.c:51
-#: ../display/d.vect/topo.c:49 ../display/d.vect/label.c:39
-#: ../vector/v.colors.out/scan_cats.c:30 ../vector/v.label/main.c:292
-#: ../vector/v.colors/scan_cats.c:24 ../vector/v.perturb/main.c:178
-#: ../vector/v.info/level1.c:37 ../vector/v.to.3d/trans3.c:84
-#: ../vector/v.to.3d/trans2.c:83 ../vector/v.label.sa/labels.c:139
-#, fuzzy
-msgid "Unable to read vector map"
-#: ../raster/r.drain/main.c:310
-#, fuzzy, c-format
-msgid "Starting vector map <%s> contains no points in the current region"
-#: ../raster/r.drain/main.c:318
-msgid "No start/stop point(s) specified"
-msgstr ""
-#: ../raster/r.drain/main.c:393
-#, fuzzy
-msgid "Calculating flow directions..."
-#: ../raster/r.drain/main.c:462 ../raster/r.drain/main.c:515
-#: ../raster/r.cost/main.c:1033 ../raster/r.random.surface/save.c:98
-#: ../raster/r.composite/main.c:190 ../raster/r.random.cells/indep.c:134
-#: ../imagery/i.smap/write_img.c:13 ../imagery/i.ifft/main.c:207
-#, fuzzy, c-format
-msgid "Writing raster map <%s>..."
-#: ../raster/r.drain/main.c:682
-#, c-format
-msgid "direction read: %lf, neighbour found: %i"
-msgstr ""
-#: ../raster/r.param.scale/process.c:74
-msgid "E-W and N-S grid resolutions are different. Taking average."
-msgstr ""
-#: ../raster/r.param.scale/main.c:42
-msgid "Lat/Long locations are not supported by this module"
-msgstr ""
-#: ../raster/r.param.scale/interface.c:55
-msgid "geomorphology"
-msgstr ""
-#: ../raster/r.param.scale/interface.c:56
-msgid "Extracts terrain parameters from a DEM."
-msgstr ""
-#: ../raster/r.param.scale/interface.c:57
-msgid "Uses a multi-scale approach by taking fitting quadratic parameters to any size window (via least squares)."
-msgstr ""
-#: ../raster/r.param.scale/interface.c:75
-msgid "Output raster layer containing morphometric parameter"
-msgstr ""
-#: ../raster/r.param.scale/interface.c:79
-msgid "Slope tolerance that defines a 'flat' surface (degrees)"
-msgstr ""
-#: ../raster/r.param.scale/interface.c:86
-msgid "Curvature tolerance that defines 'planar' surface"
-msgstr ""
-#: ../raster/r.param.scale/interface.c:91
-#, c-format
-msgid "Size of processing window (odd number only, max: %i)"
-msgstr ""
-#: ../raster/r.param.scale/interface.c:101
-msgid "Morphometric parameter in 'size' window to calculate"
-msgstr ""
-#: ../raster/r.param.scale/interface.c:109
-msgid "Exponent for distance weighting (0.0-4.0)"
-msgstr ""
-#: ../raster/r.param.scale/interface.c:115 ../raster/r.out.pov/main.c:150
-msgid "Vertical scaling factor"
-msgstr ""
-#: ../raster/r.param.scale/interface.c:121
-msgid "Constrain model through central window cell"
-msgstr ""
-#: ../raster/r.param.scale/interface.c:164
-msgid "Morphometric parameter not recognised. Assuming 'Elevation'"
-msgstr ""
-#: ../raster/r.param.scale/interface.c:172
-msgid "Inappropriate window size (too big or even)"
-msgstr ""
-#: ../raster/r.in.gridatb/main.c:48
-msgid "Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map"
-msgstr ""
-#: ../raster/r.in.gridatb/main.c:52
-msgid "GRIDATB i/o map file"
-msgstr ""
-#: ../raster/r.in.gridatb/main.c:58 ../imagery/i.ifft/main.c:93
-#: ../locale/scriptstrings/v.krige_to_translate.c:8
-#, fuzzy
-msgid "Name for output raster map"
-#: ../raster/r.in.gridatb/main.c:72
-#, c-format
-msgid "File not found: %s"
-msgstr ""
-#: ../raster/r.in.gridatb/file_io.c:35
-msgid "Setting window header failed"
-msgstr ""
-#: ../raster/r.in.gridatb/file_io.c:38
-msgid "Rows changed"
-msgstr ""
-#: ../raster/r.in.gridatb/file_io.c:41
-msgid "Cols changed"
-msgstr ""
-#: ../raster/r.support/check.c:26
-#, c-format
-msgid ""
-"\n"
-"  Updating statistics for [%s]"
-msgstr ""
-#: ../raster/r.support/check.c:69
-#, c-format
-msgid ""
-"   Updating the number of categories for [%s]\n"
-"\n"
-msgstr ""
-#: ../raster/r.support/main.c:56 ../raster/r.region/main.c:52
-#: ../raster/r.describe/main.c:55 ../raster/r.timestamp/main.c:36
-#: ../raster/r.info/main.c:70 ../vector/v.support/main.c:40
-#: ../vector/v.info/main.c:38 ../vector/v.timestamp/main.c:37
-#, fuzzy
-msgid "metadata"
-#: ../raster/r.support/main.c:57
-msgid "Allows creation and/or modification of raster map layer support files."
-msgstr ""
-#: ../raster/r.support/main.c:67
-#, fuzzy
-msgid "Text to use for map title"
-#: ../raster/r.support/main.c:75
-msgid "Text to append to the next line of the map's metadata file"
-msgstr ""
-#: ../raster/r.support/main.c:81
-msgid "Text to use for map data units"
-msgstr ""
-#: ../raster/r.support/main.c:87
-msgid "Text to use for map vertical datum"
-msgstr ""
-#: ../raster/r.support/main.c:94
-msgid "Text to use for data source, line 1"
-msgstr ""
-#: ../raster/r.support/main.c:101
-msgid "Text to use for data source, line 2"
-msgstr ""
-#: ../raster/r.support/main.c:109
-msgid "Text to use for data description or keyword(s)"
-msgstr ""
-#: ../raster/r.support/main.c:121
-msgid "Text file from which to load history"
-msgstr ""
-#: ../raster/r.support/main.c:126
-msgid "Text file in which to save history"
-msgstr ""
-#: ../raster/r.support/main.c:130
-msgid "Update statistics (histogram, range)"
-msgstr ""
-#: ../raster/r.support/main.c:134
-msgid "Create/reset the null file"
-msgstr ""
-#: ../raster/r.support/main.c:138
-#, fuzzy
-msgid "Delete the null file"
-#: ../raster/r.support/main.c:180 ../raster/r.series/main.c:209
-#: ../raster/r.in.xyz/main.c:475 ../raster/r.in.arc/main.c:125
-#: ../raster/r.in.mat/main.c:130 ../raster/r.mapcalc/main.c:91
-#: ../display/d.where/main.c:162 ../display/d.text/main.c:371
-#: ../display/d.linegraph/main.c:200 ../display/d.linegraph/main.c:211
-#: ../display/d.linegraph/main.c:346 ../general/g.cairocomp/main.c:45
-#: ../vector/v.lrs/v.lrs.segment/main.c:132 ../vector/v.segment/main.c:87
-#: ../vector/v.net.path/path.c:49
-#, fuzzy, c-format
-msgid "Unable to open input file <%s>"
-#: ../raster/r.support/main.c:249 ../raster/r.statistics/main.c:98
-#: ../display/d.title/main.c:110
-#, fuzzy, c-format
-msgid "Unable to read category file of raster map <%s>"
-#: ../raster/r.support/main.c:253
-#, c-format
-msgid "cats table for [%s] set to %s"
-msgstr ""
-#: ../raster/r.support/main.c:277 ../raster/r.support/main.c:305
-#, c-format
-msgid "[%s] is a reclass of another map. Exiting."
-msgstr ""
-#: ../raster/r.support/main.c:288
-#, c-format
-msgid "Writing new null file for [%s]... "
-msgstr ""
-#: ../raster/r.support/main.c:309
-#, c-format
-msgid "Removing null file for [%s]...\n"
-msgstr ""
-#: ../raster/r.support/main.c:316 ../display/d.what.vect/main.c:156
-msgid "Done."
-msgstr ""
-#: ../raster/r.topmodel/main.c:65
-msgid "Simulates TOPMODEL which is a physically based hydrologic model."
-msgstr ""
-#: ../raster/r.topmodel/main.c:75
-#, fuzzy
-msgid "Name of input basin raster map"
-#: ../raster/r.topmodel/main.c:76
-msgid "Created by r.water.outlet (MASK)"
-msgstr ""
-#: ../raster/r.topmodel/main.c:82 ../raster/r.fill.dir/main.c:95
-#, fuzzy
-msgid "Name for output depressionless elevation raster map"
-#: ../raster/r.topmodel/main.c:84 ../raster/r.topmodel/main.c:91
-#: ../raster/r.topmodel/main.c:98 ../raster/r.topmodel/main.c:106
-#: ../raster/r.topmodel/main.c:137 ../raster/r.resamp.rst/main.c:176
-#: ../raster/r.resamp.rst/main.c:184 ../raster/r.resamp.rst/main.c:192
-#: ../raster/r.resamp.rst/main.c:200 ../raster/r.resamp.rst/main.c:208
-#: ../raster/r.resamp.rst/main.c:216 ../raster/r.resamp.rst/main.c:280
-#: ../raster/r.grow.distance/main.c:160 ../raster/r.grow.distance/main.c:166
-#: ../raster/simwe/r.sim.sediment/main.c:182
-#: ../raster/simwe/r.sim.sediment/main.c:188
-#: ../raster/simwe/r.sim.sediment/main.c:195
-#: ../raster/simwe/r.sim.sediment/main.c:202
-#: ../raster/simwe/r.sim.sediment/main.c:208
-#: ../raster/simwe/r.sim.sediment/main.c:215
-#: ../raster/simwe/r.sim.water/main.c:191
-#: ../raster/simwe/r.sim.water/main.c:197
-#: ../raster/simwe/r.sim.water/main.c:203
-#: ../raster/simwe/r.sim.water/main.c:209 ../vector/v.in.ogr/main.c:148
-#: ../vector/v.in.ogr/main.c:234 ../vector/v.in.ogr/main.c:239
-#, fuzzy
-msgid "Output"
-msgstr "पूर्ण तपशिल"
-#: ../raster/r.topmodel/main.c:89 ../raster/r.fill.dir/main.c:99
-#, fuzzy
-msgid "Name for output flow direction map for depressionless elevation raster map"
-#: ../raster/r.topmodel/main.c:95
-#, fuzzy
-msgid "Name for output basin elevation raster map (o/i)"
-#: ../raster/r.topmodel/main.c:96 ../raster/r.topmodel/main.c:104
-msgid "MASK applied"
-msgstr ""
-#: ../raster/r.topmodel/main.c:103
-#, fuzzy
-msgid "Name for output topographic index ln(a/tanB) raster map"
-#: ../raster/r.topmodel/main.c:111
-#, fuzzy
-msgid "Number of topographic index classes"
-#: ../raster/r.topmodel/main.c:115 ../raster/r.topmodel/main.c:145
-#: ../raster/r.topmodel/main.c:153 ../raster/simwe/r.sim.sediment/main.c:222
-#: ../raster/simwe/r.sim.sediment/main.c:230
-#: ../raster/simwe/r.sim.sediment/main.c:239
-#: ../raster/simwe/r.sim.sediment/main.c:257
-#: ../raster/simwe/r.sim.water/main.c:224
-#: ../raster/simwe/r.sim.water/main.c:232
-#: ../raster/simwe/r.sim.water/main.c:241
-#: ../raster/simwe/r.sim.water/main.c:259
-#: ../raster/simwe/r.sim.water/main.c:269
-#: ../raster/simwe/r.sim.water/main.c:277
-#: ../raster/simwe/r.sim.water/main.c:286 ../imagery/i.eb.h_SEBAL01/main.c:118
-#: ../imagery/i.eb.h_SEBAL01/main.c:126 ../imagery/i.eb.h_SEBAL01/main.c:133
-#: ../imagery/i.eb.h_SEBAL01/main.c:140 ../imagery/i.eb.h_SEBAL01/main.c:147
-#: ../imagery/i.eb.h_SEBAL01/main.c:154 ../vector/v.surf.rst/main.c:155
-#: ../vector/v.surf.rst/main.c:160 ../vector/v.surf.rst/main.c:171
-#: ../vector/v.surf.rst/main.c:184 ../vector/v.surf.rst/main.c:256
-#: ../vector/v.surf.rst/main.c:264 ../vector/v.surf.rst/main.c:271
-#: ../vector/v.surf.rst/main.c:279 ../vector/v.surf.rst/main.c:287
-#: ../vector/v.surf.rst/main.c:296 ../vector/v.surf.rst/main.c:304
-#: ../vector/v.surf.rst/main.c:312 ../vector/v.surf.rst/main.c:321
-#: ../vector/v.surf.rst/main.c:329 ../vector/v.surf.rst/main.c:336
-msgid "Parameters"
-msgstr ""
-#: ../raster/r.topmodel/main.c:120
-msgid "Name of topographic index statistics file (o/i)"
-msgstr ""
-#: ../raster/r.topmodel/main.c:124
-#, fuzzy
-msgid "Name of TOPMODEL parameters file"
-#: ../raster/r.topmodel/main.c:128
-msgid "Name of rainfall and potential evapotranspiration data file"
-msgstr ""
-#: ../raster/r.topmodel/main.c:131 ../raster/r.out.mpeg/main.c:121
-msgid "Name for output file"
-msgstr ""
-#: ../raster/r.topmodel/main.c:135
-#, fuzzy
-msgid "Name for observed flow file"
-#: ../raster/r.topmodel/main.c:142
-msgid "Time step"
-msgstr ""
-#: ../raster/r.topmodel/main.c:150
-#, fuzzy
-msgid "Topographic index class"
-#: ../raster/r.topmodel/main.c:158
-msgid "Input data given for (o/i)"
-msgstr ""
-#: ../raster/r.external.out/main.c:38
-#, c-format
-msgid "Supported Formats:\n"
-msgstr ""
-#: ../raster/r.external.out/main.c:111
-#, fuzzy
-msgid "Unable to open GDAL file"
-#: ../raster/r.external.out/main.c:135 ../vector/v.external.out/format.c:14
-#, fuzzy, c-format
-msgid "Format <%s> not supported"
-#: ../raster/r.external.out/main.c:141
-#, c-format
-msgid "Format <%s> does not support direct write"
-msgstr ""
-#: ../raster/r.external.out/main.c:145 ../vector/v.external.out/format.c:19
-#, fuzzy, c-format
-msgid "Format <%s> does not support writing"
-#: ../raster/r.external.out/main.c:193
-#, fuzzy
-msgid "Unable to create GDAL file"
-#: ../raster/r.external.out/main.c:196
-#, fuzzy
-msgid "Error writing GDAL file"
-#: ../raster/r.external.out/main.c:216 ../vector/v.external.out/main.c:36
-#, fuzzy
-msgid "output"
-#: ../raster/r.external.out/main.c:219
-msgid "Defines raster output format utilizing GDAL library."
-msgstr ""
-#: ../raster/r.external.out/main.c:223
-#, fuzzy
-msgid "Name of output directory"
-#: ../raster/r.external.out/main.c:230
-#, fuzzy
-msgid "Extension for output files"
-#: ../raster/r.external.out/main.c:236 ../vector/v.external.out/args.c:19
-#, fuzzy
-msgid "Format of output files"
-#: ../raster/r.external.out/main.c:243 ../vector/v.external.out/args.c:26
-msgid "Creation options"
-msgstr ""
-#: ../raster/r.external.out/main.c:256
-msgid "Cease using GDAL and revert to native output"
-msgstr ""
-#: ../raster/r.external.out/main.c:261 ../vector/v.external.out/args.c:45
-msgid "Print current status"
-msgstr ""
-#: ../raster/r.cross/cross.c:53
-#, c-format
-msgid "%s: STEP 1 ... "
-msgstr ""
-#: ../raster/r.cross/main.c:76
-msgid "Creates a cross product of the category values from multiple raster map layers."
-msgstr ""
-#: ../raster/r.cross/main.c:85
-#, c-format
-msgid "Names of 2-%d input raster maps"
-msgstr ""
-#: ../raster/r.cross/main.c:94
-msgid "Non-zero data only"
-msgstr ""
-#: ../raster/r.cross/main.c:107
-#, c-format
-msgid "More than %d files not allowed"
-msgstr ""
-#: ../raster/r.cross/main.c:123
-msgid "Must specify 2 or more input maps"
-msgstr ""
-#: ../raster/r.cross/main.c:140
-#, c-format
-msgid "%s: STEP 2 ..."
-msgstr ""
-#: ../raster/r.cross/main.c:173 ../raster/r.in.png/main.c:485
-#: ../raster/r.basins.fill/main.c:145 ../raster/r.resample/main.c:125
-#, fuzzy, c-format
-msgid "Creating support files for <%s>..."
-#: ../raster/r.cross/main.c:183
-#, c-format
-msgid "%ld categories"
-msgstr ""
-#: ../raster/r.cross/renumber.c:33
-#, c-format
-msgid "%s: STEP 3 ... "
-msgstr ""
-#: ../raster/r.usler/main.c:53
-msgid "rainfall"
-msgstr ""
-#: ../raster/r.usler/main.c:55
-msgid "Computes USLE R factor, Rainfall erosivity index."
-msgstr ""
-#: ../raster/r.usler/main.c:58
-#, fuzzy
-msgid "Name of annual precipitation raster map [mm/year]"
-#: ../raster/r.usler/main.c:61
-#, fuzzy
-msgid "Name for output USLE R raster map [MJ.mm/ha.hr.year]"
-#: ../raster/r.usler/main.c:68
-#, fuzzy
-msgid "Name of USLE R equation"
-#: ../raster/r.usler/main.c:70
-msgid "roose;Roosle (1975);morgan;Morgan (1974);foster;Foster (1981);elswaify;El-Swaify (1985)"
-msgstr ""
-#: ../raster/r.distance/edges.c:46
-#, c-format
-msgid "Reading map %s ..."
-msgstr ""
-#: ../raster/r.distance/main.c:41
-msgid "Locates the closest points between objects in two raster maps."
-msgstr ""
-#: ../raster/r.distance/parse.c:38
-msgid "Maps for computing inter-class distances"
-msgstr ""
-#: ../raster/r.distance/parse.c:51
-msgid "Include category labels in the output"
-msgstr ""
-#: ../raster/r.distance/parse.c:56
-msgid "Report zero distance if rasters are overlapping"
-msgstr ""
-#: ../raster/r.distance/report.c:43
-msgid "Processing..."
-msgstr ""
-#: ../raster/r.distance/distance.c:101
-#, c-format
-msgid "Reading maps  <%s,%s> while finding 0 distance ..."
-msgstr ""
-#: ../raster/r.out.mpeg/main.c:104
-#, fuzzy
-msgid "animation"
-#: ../raster/r.out.mpeg/main.c:107
-#, fuzzy
-msgid "Converts raster map series to MPEG movie."
-#: ../raster/r.out.mpeg/main.c:115
-#, fuzzy, c-format
-msgid "Name of input raster map(s) for view no.%d"
-#: ../raster/r.out.mpeg/main.c:131
-msgid "Quality factor (1 = highest quality, lowest compression)"
-msgstr ""
-#: ../raster/r.out.mpeg/main.c:135
-msgid "Convert on the fly, uses less disk space"
-msgstr ""
-#: ../raster/r.out.mpeg/main.c:136
-msgid "Requires r.out.ppm with stdout option"
-msgstr ""
-#: ../raster/r.out.mpeg/main.c:159
-msgid "Either mpeg_encode or ppmtompeg must be installed"
-msgstr ""
-#: ../raster/r.out.mpeg/main.c:285 ../raster/r.colors/stats.c:36
-#: ../raster/r.grow.distance/main.c:252 ../raster/r.surf.idw2/read_cell.c:27
-#: ../raster/r.surf.idw/main.c:707 ../ps/ps.map/ps_raster.c:102
-#, fuzzy, c-format
-msgid "Reading raster map <%s>..."
-#: ../raster/r.out.mpeg/main.c:290
-#, fuzzy, c-format
-msgid "Unable to read color table for <%s>"
-#: ../raster/r.out.mpeg/main.c:340 ../raster/r.out.mpeg/main.c:373
-msgid "mpeg_encode ERROR"
-msgstr ""
-#: ../raster/r.out.mpeg/main.c:416
-msgid "Error reading wildcard"
-msgstr ""
-#: ../raster/r.out.mpeg/write.c:81 ../raster/r.out.mpeg/write.c:178
-msgid "Size mismatch error!"
-msgstr ""
-#: ../raster/r.out.mpeg/write.c:139 ../raster/r.out.mpeg/write.c:181
-msgid "Unable to open output file"
-msgstr ""
-#: ../raster/r.out.mpeg/write.c:215
-msgid "Unable to create temporary files."
-msgstr ""
-#: ../raster/r.patch/main.c:53 ../raster/r.circle/main.c:52
-#: ../raster/r.to.vect/main.c:72 ../raster/r.thin/main.c:57
-#: ../imagery/i.points/main.c:97 ../imagery/i.vpoints/main.c:95
-#: ../display/d.measure/main.c:47 ../vector/v.type/main.c:40
-#: ../vector/v.voronoi/main.c:121 ../vector/v.overlay/main.c:59
-#: ../vector/v.parallel/main.c:48 ../vector/v.build/main.c:38
-#: ../vector/v.edit/main.c:57 ../vector/v.mkgrid/main.c:65
-#: ../vector/v.build.polylines/main.c:112 ../vector/v.delaunay/main.c:86
-#: ../vector/v.in.region/main.c:39 ../vector/v.buffer/main.c:211
-#: ../vector/v.patch/main.c:69 ../vector/v.perturb/main.c:62
-#: ../vector/v.to.3d/main.c:38 ../vector/v.split/main.c:53
-#: ../vector/v.to.points/main.c:173 ../vector/v.extrude/main.c:70
-#: ../vector/v.segment/main.c:55 ../vector/v.hull/main.c:51
-#: ../vector/v.drape/main.c:141
-#: ../locale/scriptstrings/v.report_to_translate.c:3
-msgid "geometry"
-msgstr ""
-#: ../raster/r.patch/main.c:55
-msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
-msgstr ""
-#: ../raster/r.patch/main.c:62
-msgid "Name of raster maps to be patched together"
-msgstr ""
-#: ../raster/r.patch/main.c:65
-#, fuzzy
-msgid "Name for resultant raster map"
-#: ../raster/r.patch/main.c:72
-msgid "Use zero (0) for transparency instead of NULL"
-msgstr ""
-#: ../raster/r.patch/main.c:88
-msgid "The minimum number of input raster maps is two"
-msgstr ""
-#: ../raster/r.patch/main.c:119 ../raster/r.series/main.c:335
-#: ../raster/r.slope.aspect/main.c:544 ../raster/r.series.interp/main.c:329
-msgid "Percent complete..."
-msgstr ""
-#: ../raster/r.patch/main.c:144
-#, fuzzy, c-format
-msgid "Creating support files for raster map <%s>"
-#: ../raster/r.quant/main.c:48
-#, fuzzy
-msgid "quantization"
-#: ../raster/r.quant/main.c:51
-msgid "Produces the quantization file for a floating-point map."
-msgstr ""
-#: ../raster/r.quant/main.c:59
-msgid "Raster map(s) to be quantized"
-msgstr ""
-#: ../raster/r.quant/main.c:64
-#, fuzzy
-msgid "Path to rules file (\"-\" to read from stdin)"
-#: ../raster/r.quant/main.c:70
-msgid "Base map to take quant rules from"
-msgstr ""
-#: ../raster/r.quant/main.c:75
-msgid "Floating point range: dmin,dmax"
-msgstr ""
-#: ../raster/r.quant/main.c:81
-msgid "Integer range: min,max"
-msgstr ""
-#: ../raster/r.quant/main.c:86
-msgid "Truncate floating point data"
-msgstr ""
-#: ../raster/r.quant/main.c:90
-msgid "Round floating point data"
-msgstr ""
-#: ../raster/r.quant/main.c:111
-msgid "-t, -r, rules=, basemap= and fprange= are mutually exclusive"
-msgstr ""
-#: ../raster/r.quant/main.c:119
-msgid "fprange= and range= must be used together"
-msgstr ""
-#: ../raster/r.quant/main.c:129
-#, c-format
-msgid "%s is integer map, it can't be quantized"
-msgstr ""
-#: ../raster/r.quant/main.c:137
-msgid "Truncating..."
-msgstr ""
-#: ../raster/r.quant/main.c:142
-msgid "Rounding..."
-msgstr ""
-#: ../raster/r.quant/main.c:150
-#, c-format
-msgid "%s is integer map, it can't be used as basemap"
-msgstr ""
-#: ../raster/r.quant/main.c:154
-#, fuzzy, c-format
-msgid "unable to read quant rules for basemap <%s>"
-#: ../raster/r.quant/main.c:161
-#, fuzzy, c-format
-msgid "invalid value for fprange= <%s>"
-#: ../raster/r.quant/main.c:163
-#, c-format
-msgid "invalid value for range= <%s>"
-msgstr ""
-#: ../raster/r.quant/main.c:164
-#, c-format
-msgid "Setting quant rules for input map(s) to (%f,%f) -> (%d,%d)"
-msgstr ""
-#: ../raster/r.quant/main.c:177
-msgid "No rules specified. Quant table(s) not changed."
-msgstr ""
-#: ../raster/r.quant/main.c:179 ../raster/r.recode/main.c:98
-#: ../raster/r.reclass/main.c:142
-msgid "No rules specified"
-msgstr ""
-#: ../raster/r.quant/main.c:185
-#, c-format
-msgid "New quant table created for %s"
-msgstr ""
-#: ../raster/r.quant/read_rules.c:50
-msgid "Old data range is empty"
-msgstr ""
-#: ../raster/r.quant/read_rules.c:56
-#, c-format
-msgid "Old data range is %s to %s"
-msgstr ""
-#: ../raster/r.quant/read_rules.c:59
-msgid "Old integer data range is empty"
-msgstr ""
-#: ../raster/r.quant/read_rules.c:61
-#, c-format
-msgid "Old integer data range is %d to %d"
-msgstr ""
-#: ../raster/r.quant/read_rules.c:83
-#, fuzzy, c-format
-msgid "unable to open input file <%s>"
-#: ../raster/r.quant/read_rules.c:89
-#, c-format
-msgid ""
-"\n"
-"Enter the rule or 'help' for the format description or 'end' to exit:\n"
-msgstr ""
-#: ../raster/r.quant/read_rules.c:112
-#, fuzzy
-msgid "quant rules do not cover the whole range map"
-#: ../raster/r.quant/read_rules.c:158 ../raster/r.recode/read_rules.c:131
-#, c-format
-msgid "%s is not a valid rule"
-msgstr ""
-#: ../raster/r.spread/main.c:103 ../raster/r.ros/main.c:212
-#: ../raster/r.spreadpath/main.c:90
-#, fuzzy
-msgid "fire"
-#: ../raster/r.spread/main.c:105
-msgid "Simulates elliptically anisotropic spread on a graphics window and generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins."
-msgstr ""
-#: ../raster/r.spread/main.c:110
-msgid "It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths."
-msgstr ""
-#: ../raster/r.spread/main.c:118 ../raster/r.spread/main.c:127
-#: ../raster/r.spread/main.c:136 ../raster/r.spread/main.c:145
-#: ../raster/r.spread/main.c:153 ../raster/r.spread/main.c:161
-#: ../raster/r.spread/main.c:169
-#, fuzzy
-msgid "Input_maps"
-#: ../raster/r.spread/main.c:120
-msgid "Name of raster map containing MAX rate of spread (ROS) (cm/min)"
-msgstr ""
-#: ../raster/r.spread/main.c:129
-msgid "Name of raster map containing DIRections of max ROS (degree)"
-msgstr ""
-#: ../raster/r.spread/main.c:138
-msgid "Name of raster map containing BASE ROS (cm/min)"
-msgstr ""
-#: ../raster/r.spread/main.c:147
-msgid "Name of raster map containing STARTing sources"
-msgstr ""
-#: ../raster/r.spread/main.c:155
-msgid "Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
-msgstr ""
-#: ../raster/r.spread/main.c:163
-msgid "Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
-msgstr ""
-#: ../raster/r.spread/main.c:171
-msgid "Name of raster map containing fine Fuel MOISture of the cell receiving a spotting firebrand (%) (required w/ -s)"
-msgstr ""
-#: ../raster/r.spread/main.c:179
-msgid "Basic sampling window SIZE needed to meet certain accuracy (3)"
-msgstr ""
-#: ../raster/r.spread/main.c:186
-msgid "Sampling DENSity for additional COMPutin (range: 0.0 - 1.0 (0.5))"
-msgstr ""
-#: ../raster/r.spread/main.c:193
-msgid "INITial TIME for current simulation (0) (min)"
-msgstr ""
-#: ../raster/r.spread/main.c:200
-msgid "Simulating time duration LAG (fill the region) (min)"
-msgstr ""
-#: ../raster/r.spread/main.c:207
-msgid "Name of raster map as a display backdrop"
-msgstr ""
-#: ../raster/r.spread/main.c:214 ../raster/r.spread/main.c:222
-#: ../raster/r.spread/main.c:230
-msgid "Output_maps"
-msgstr ""
-#: ../raster/r.spread/main.c:216
-msgid "Name of raster map to contain OUTPUT spread time (min)"
-msgstr ""
-#: ../raster/r.spread/main.c:224
-#, fuzzy
-msgid "Name of raster map to contain X_BACK coordinates"
-#: ../raster/r.spread/main.c:232
-#, fuzzy
-msgid "Name of raster map to contain Y_BACK coordinates"
-#: ../raster/r.spread/main.c:237
-msgid "DISPLAY 'live' spread process on screen"
-msgstr ""
-#: ../raster/r.spread/main.c:239
-msgid "Live display - currently DISABLED"
-msgstr ""
-#: ../raster/r.spread/main.c:244
-msgid "For wildfires: consider SPOTTING effect"
-msgstr ""
-#: ../raster/r.spread/main.c:256
-#, fuzzy
-msgid "The display feature is disabled"
-msgstr "डेटाबेसची यादी दाखवता येणार नाही"
-#: ../raster/r.spread/main.c:421
-#, fuzzy
-msgid "Reading inputs..."
-#: ../raster/r.spread/main.c:463
-#, c-format
-msgid "Reading %s..."
-msgstr ""
-#: ../raster/r.cost/main.c:140 ../raster/r.walk/main.c:180
-msgid "cost surface"
-msgstr ""
-#: ../raster/r.cost/main.c:141 ../raster/r.walk/main.c:181
-#: ../raster/r.spreadpath/main.c:91
-msgid "cumulative costs"
-msgstr ""
-#: ../raster/r.cost/main.c:143
-msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
-msgstr ""
-#: ../raster/r.cost/main.c:150
-msgid "Name of raster map containing grid cell cost information"
-msgstr ""
-#: ../raster/r.cost/main.c:158
-#, fuzzy
-msgid "Name of output raster map with nearest start point"
-#: ../raster/r.cost/main.c:166 ../raster/r.walk/main.c:212
-#, fuzzy
-msgid "Name of output raster map to contain movement directions"
-#: ../raster/r.cost/main.c:171
-#, fuzzy
-msgid "Name of starting vector points map"
-#: ../raster/r.cost/main.c:177
-#, fuzzy
-msgid "Name of stop vector points map"
-#: ../raster/r.cost/main.c:178 ../raster/r.cost/main.c:202
-msgid "Stop"
-msgstr ""
-#: ../raster/r.cost/main.c:183
-#, fuzzy
-msgid "Name of starting raster points map"
-#: ../raster/r.cost/main.c:192
-msgid "Map grid coordinates of a starting point (E,N)"
-msgstr ""
-#: ../raster/r.cost/main.c:201
-msgid "Map grid coordinates of a stopping point (E,N)"
-msgstr ""
-#: ../raster/r.cost/main.c:211
-msgid "Optional maximum cumulative cost"
-msgstr ""
-#: ../raster/r.cost/main.c:220 ../raster/r.walk/main.c:266
-msgid "Cost assigned to null cells. By default, null cells are excluded"
-msgstr ""
-#: ../raster/r.cost/main.c:229 ../raster/r.walk/main.c:274
-#: ../raster/r.in.xyz/main.c:238 ../raster/r.in.lidar/main.c:211
-msgid "Percent of map to keep in memory"
-msgstr ""
-#: ../raster/r.cost/main.c:234 ../raster/r.walk/main.c:307
-msgid "Use the 'Knight's move'; slower, but more accurate"
-msgstr ""
-#: ../raster/r.cost/main.c:238
-#, fuzzy
-msgid "Keep null values in output raster map"
-#: ../raster/r.cost/main.c:242 ../raster/r.walk/main.c:315
-msgid "Start with values in raster map"
-msgstr ""
-#: ../raster/r.cost/main.c:247 ../raster/r.walk/main.c:319
-msgid "Only print info about disk space and memory requirements"
-msgstr ""
-#: ../raster/r.cost/main.c:302 ../raster/r.walk/main.c:368
-msgid "Must specify exactly one of start_points, start_rast or coordinate"
-msgstr ""
-#: ../raster/r.cost/main.c:307 ../raster/r.cost/main.c:720
-#: ../raster/r.walk/main.c:373
-msgid "No start points"
-msgstr ""
-#: ../raster/r.cost/main.c:314 ../raster/r.walk/main.c:380
-#, c-format
-msgid "Inappropriate maximum cost: %d"
-msgstr ""
-#: ../raster/r.cost/main.c:318 ../raster/r.walk/main.c:384
-#, c-format
-msgid "Inappropriate percent memory: %d"
-msgstr ""
-#: ../raster/r.cost/main.c:336
-msgid "Assigning negative cost to null cell. Null cells excluded."
-msgstr ""
-#: ../raster/r.cost/main.c:409 ../raster/r.cost/main.c:419
-#: ../raster/r.walk/main.c:562 ../raster/r.walk/main.c:572
-#, c-format
-msgid "Will need at least %.2f MB of disk space"
-msgstr ""
-#: ../raster/r.cost/main.c:410 ../raster/r.cost/main.c:420
-#: ../raster/r.walk/main.c:563 ../raster/r.walk/main.c:573
-#, c-format
-msgid "Will need at least %.2f MB of memory"
-msgstr ""
-#: ../raster/r.cost/main.c:430 ../raster/r.walk/main.c:584
-#, fuzzy
-msgid "Creating some temporary files..."
-#: ../raster/r.cost/main.c:458
-#, fuzzy, c-format
-msgid "Reading raster map <%s>, initializing output..."
-#: ../raster/r.cost/main.c:514 ../raster/r.walk/main.c:697
-msgid "Initializing directional output "
-msgstr ""
-#: ../raster/r.cost/main.c:594 ../raster/r.walk/main.c:775
-#, fuzzy, c-format
-msgid "No start points found in vector <%s>"
-#: ../raster/r.cost/main.c:606 ../raster/r.walk/main.c:787
-#, fuzzy, c-format
-msgid "Reading vector map <%s> with stop points..."
-#: ../raster/r.cost/main.c:660 ../raster/r.walk/main.c:841
-#, fuzzy, c-format
-msgid "No stop points found in vector <%s>"
-#: ../raster/r.cost/main.c:681 ../raster/r.walk/main.c:861
-#: ../raster/r.texture/h_measure.c:594 ../imagery/i.smap/interp.c:66
-msgid "Unable to allocate memory"
-msgstr ""
-#: ../raster/r.cost/main.c:683
-#, fuzzy, c-format
-msgid "Reading raster map <%s> with start points..."
-#: ../raster/r.cost/main.c:734 ../raster/r.walk/main.c:914
-msgid "Specified starting location outside database window"
-msgstr ""
-#: ../raster/r.cost/main.c:755
-#, fuzzy
-msgid "Finding cost path..."
-#: ../raster/r.cost/main.c:1009 ../raster/r.walk/main.c:1393
-msgid "Error, ct == pres_cell"
-msgstr ""
-#: ../raster/r.cost/main.c:1035
-#, fuzzy, c-format
-msgid "Writing raster map with nearest start point <%s>..."
-#: ../raster/r.cost/main.c:1128 ../raster/r.walk/main.c:1468
-#, fuzzy, c-format
-msgid "Writing movement direction file %s..."
-#: ../raster/r.cost/main.c:1204 ../raster/r.walk/main.c:1516
-#, c-format
-msgid "Peak cost value: %f."
-msgstr ""
-#: ../raster/r.cost/main.c:1226 ../raster/r.walk/main.c:1541
-#, c-format
-msgid "Illegal x coordinate <%s>"
-msgstr ""
-#: ../raster/r.cost/main.c:1228 ../raster/r.walk/main.c:1543
-#, c-format
-msgid "Illegal y coordinate <%s>"
-msgstr ""
-#: ../raster/r.cost/main.c:1232 ../raster/r.walk/main.c:1547
-#, c-format
-msgid "Warning, ignoring point outside window: %.4f,%.4f"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:75
-msgid "write_vtk_normal_header: Writing VTK-Header"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:108
-msgid "write_vtk_structured_elevation_header: Writing VTK-Header"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:124
-msgid "write_vtk_polygonal_elevation_header: Writing VTK-Header"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:139
-msgid "write_vtk_celldata_header: Writing VTK-DataHeader"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:148
-msgid "writeVTKPointHeader: Writing VTK-DataHeader"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:169
-msgid "write_vtk_structured_coordinates: Writing Coordinates"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:225
-msgid "write_vtk_polygonal_coordinates: Writing VTK Polygonal data"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:334
-msgid "write_vtk_data: Writing VTK-Data"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:384
-msgid "write_vtk_rgb_image_data: Writing VTK-ImageData"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:412
-msgid "Wrong map values! Values should in between 0 and 255!\n"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:442
-msgid "write_vtk_vector_data: Writing VTK-vector data"
-msgstr ""
-#: ../raster/r.out.vtk/parameters.c:34
-#, fuzzy
-msgid "Raster map(s) to be converted to VTK-ASCII data format"
-#: ../raster/r.out.vtk/parameters.c:49
-#: ../locale/scriptstrings/tr.out.vtk_to_translate.c:9
-#, fuzzy
-msgid "Elevation raster map"
-#: ../raster/r.out.vtk/parameters.c:55
-#: ../locale/scriptstrings/tr.out.vtk_to_translate.c:11
-msgid "Value to represent no data cell"
-msgstr ""
-#: ../raster/r.out.vtk/parameters.c:63
-msgid "Elevation (if no elevation map is specified)"
-msgstr ""
-#: ../raster/r.out.vtk/parameters.c:69
-#: ../locale/scriptstrings/tr.out.vtk_to_translate.c:12
-msgid "Create VTK point data instead of VTK cell data (if no elevation map is given)"
-msgstr ""
-#: ../raster/r.out.vtk/parameters.c:79
-msgid "Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
-msgstr ""
-#: ../raster/r.out.vtk/parameters.c:89
-msgid "Three (x,y,z) raster maps to create vector values [xmap,ymap,zmap]"
-msgstr ""
-#: ../raster/r.out.vtk/parameters.c:114
-msgid "Use structured grid for elevation (not recommended)"
-msgstr ""
-#: ../raster/r.out.vtk/parameters.c:120
-msgid "Use polydata-trianglestrips for elevation grid creation"
-msgstr ""
-#: ../raster/r.out.vtk/parameters.c:126
-msgid "Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
-msgstr ""
-#: ../raster/r.out.vtk/parameters.c:132
-msgid "Scale factor effects the origin (if no elevation map is given)"
-msgstr ""
-#: ../raster/r.out.vtk/main.c:61
-#, fuzzy
-msgid "Converts raster maps into the VTK-ASCII format."
-#: ../raster/r.out.vtk/main.c:72
-msgid "No input maps specified. You need to specify at least one input map or three vector maps or three rgb maps."
-msgstr ""
-#: ../raster/r.out.vtk/main.c:130 ../raster/r.out.vtk/main.c:190
-#: ../raster/r.out.vtk/main.c:211 ../raster/r.out.vtk/main.c:250
-#, c-format
-msgid "Open Raster file %s"
-msgstr ""
-#: ../raster/r.out.vtk/main.c:221
-msgid "Writing VTK ImageData\n"
-msgstr ""
-#: ../raster/r.out.vtk/main.c:231
-msgid "Wrong RGB maps. Maps should have the same type! RGB output not added!"
-msgstr ""
-#: ../raster/r.out.vtk/main.c:260
-msgid "Writing VTK Vector Data\n"
-msgstr ""
-#: ../raster/r.out.vtk/main.c:270
-msgid "Wrong vector maps. Maps should have the same type! Vector output not added!"
-msgstr ""
-#: ../raster/r.out.vtk/main.c:282
-msgid "Error closing VTK-ASCII file"
-msgstr ""
-#: ../raster/r.recode/main.c:49
-#, fuzzy
-msgid "recode categories"
-#: ../raster/r.recode/main.c:50
-#, fuzzy
-msgid "Recodes categorical raster maps."
-#: ../raster/r.recode/main.c:53
-#, fuzzy
-msgid "Name of raster map to be recoded"
-#: ../raster/r.recode/main.c:59
-#, fuzzy
-msgid "File containing recode rules"
-#: ../raster/r.recode/main.c:60 ../raster/r.reclass/main.c:66
-#, fuzzy
-msgid "\"-\" to read from stdin"
-#: ../raster/r.recode/main.c:66
-#, fuzzy
-msgid "Title for output raster map"
-#: ../raster/r.recode/main.c:70
-#, fuzzy
-msgid "Align the current region to the input raster map"
-#: ../raster/r.recode/main.c:74
-msgid "Force output to 'double' raster map type (DCELL)"
-msgstr ""
-#: ../raster/r.recode/main.c:95
-#, c-format
-msgid "No rules specified. Raster map <%s> not created."
-msgstr ""
-#: ../raster/r.recode/read_rules.c:20
-#, fuzzy, c-format
-msgid "Unable to read f_range for map %s"
-#: ../raster/r.recode/read_rules.c:24 ../display/d.colortable/main.c:149
-#, fuzzy
-msgid "Data range is empty"
-#: ../raster/r.recode/read_rules.c:30
-#, fuzzy, c-format
-msgid "Data range of %s is %s to %s (entire map)"
-#: ../raster/r.recode/read_rules.c:35 ../raster/r.stats/main.c:334
-#, fuzzy, c-format
-msgid "Unable to read range for map <%s>"
-#: ../raster/r.recode/read_rules.c:39
-#, fuzzy, c-format
-msgid "Integer data range of %s is empty"
-#: ../raster/r.recode/read_rules.c:41
-#, fuzzy, c-format
-msgid "Integer data range of %s is %d to %d"
-#: ../raster/r.recode/read_rules.c:60
-msgid "Enter the rule or 'help' for the format description"
-msgstr ""
-#: ../raster/r.recode/read_rules.c:84
-msgid "Enter a rule in one of these formats:"
-msgstr ""
-#: ../raster/r.recode/read_rules.c:86
-msgid "old_low:old_high:new_low:new_high"
-msgstr ""
-#: ../raster/r.recode/read_rules.c:87
-msgid "old_low:old_high:new_val      (i.e. new_high == new_low)"
-msgstr ""
-#: ../raster/r.recode/read_rules.c:88
-msgid "*:old_val:new_val             (interval [inf, old_val])"
-msgstr ""
-#: ../raster/r.recode/read_rules.c:89
-msgid "old_val:*:new_val             (interval [old_val, inf])"
-msgstr ""
-#: ../raster/r.recode/read_rules.c:91
-msgid "When finished type \"end\"."
-msgstr ""
-#: ../raster/r.statistics/o_skew.c:91
-msgid "o_skew: No data in array"
-msgstr ""
-#: ../raster/r.statistics/o_adev.c:93
-msgid "o_adev: No data in array"
-msgstr ""
-#: ../raster/r.statistics/o_kurt.c:91
-msgid "o_kurto: No data in array"
-msgstr ""
-#: ../raster/r.statistics/main.c:58
-msgid "Calculates category or object oriented statistics."
-msgstr ""
-#: ../raster/r.statistics/main.c:76 ../raster/r.statistics2/main.c:114
-msgid "Method of object-based statistic"
-msgstr ""
-#: ../raster/r.statistics/main.c:80 ../raster/r.statistics2/main.c:137
-#, fuzzy
-msgid "Resultant raster map"
-#: ../raster/r.statistics/main.c:86 ../raster/r.statistics2/main.c:143
-msgid "Cover values extracted from the category labels of the cover map"
-msgstr ""
-#: ../raster/r.statistics/main.c:92 ../raster/r.statistics/main.c:95
-msgid "This module currently only works for integer (CELL) maps"
-msgstr ""
-#: ../raster/r.statistics/main.c:106 ../raster/r.statistics2/main.c:164
-#: ../raster/r.neighbors/main.c:233 ../raster/r.proj/main.c:244
-#: ../imagery/i.rectify/main.c:163 ../vector/v.vect.stats/main.c:278
-#, c-format
-msgid "<%s=%s> unknown %s"
-msgstr ""
-#: ../raster/r.statistics/read_stats.c:20
-msgid "Reading r.stats output"
-msgstr ""
-#: ../raster/r.statistics/o_var.c:95 ../raster/r.statistics/o_sdev.c:94
-msgid "o_var: No data in array"
-msgstr ""
-#: ../raster/r.rescale.eq/main.c:52 ../raster/r.rescale/main.c:49
-msgid "rescale"
-msgstr ""
-#: ../raster/r.rescale.eq/main.c:54
-msgid "Rescales histogram equalized the range of category values in a raster map layer."
-msgstr ""
-#: ../raster/r.rescale.eq/main.c:64 ../raster/r.rescale/main.c:60
-msgid "The name of the raster map to be rescaled"
-msgstr ""
-#: ../raster/r.rescale.eq/main.c:72 ../raster/r.rescale/main.c:68
-msgid "The input data range to be rescaled (default: full range of input map)"
-msgstr ""
-#: ../raster/r.rescale.eq/main.c:79 ../raster/r.rescale/main.c:75
-msgid "The resulting raster map name"
-msgstr ""
-#: ../raster/r.rescale.eq/main.c:86 ../raster/r.rescale/main.c:82
-msgid "The output data range"
-msgstr ""
-#: ../raster/r.rescale.eq/main.c:93 ../raster/r.rescale/main.c:89
-msgid "Title for new raster map"
-msgstr ""
-#: ../raster/r.rescale.eq/main.c:122
-#, c-format
-msgid "Rescale %s[%d,%d] to %s[%d,%d]"
-msgstr ""
-#: ../raster/r.rescale.eq/get_stats.c:19 ../raster/r.rescale/get_range.c:24
-#, c-format
-msgid "Reading %s ..."
-msgstr ""
-#: ../raster/r.in.png/main.c:297
-#, fuzzy, c-format
-msgid "Unable to open PNG file '%s'"
-#: ../raster/r.in.png/main.c:300
-#, fuzzy
-msgid "Input file empty or too short"
-#: ../raster/r.in.png/main.c:303
-#, fuzzy
-msgid "Input file not a PNG file"
-#: ../raster/r.in.png/main.c:307 ../raster/r.in.png/main.c:311
-#, fuzzy
-msgid "Unable to allocate PNG structure"
-#: ../raster/r.in.png/main.c:314
-msgid "PNG error"
-msgstr ""
-#: ../raster/r.in.png/main.c:521
-#, fuzzy
-msgid "Imports non-georeferenced PNG format image."
-#: ../raster/r.in.png/main.c:531
-#, fuzzy
-msgid "Title for created raster map"
-#: ../raster/r.in.png/main.c:537
-#, fuzzy
-msgid "Display gamma"
-#: ../raster/r.in.png/main.c:543
-msgid "Alpha threshold"
-msgstr ""
-#: ../raster/r.in.png/main.c:547
-#, fuzzy
-msgid "Create floating-point map (0.0 - 1.0)"
-#: ../raster/r.in.png/main.c:551
-#, fuzzy
-msgid "Output image file header only and exit"
-#: ../raster/r.los/main.c:94
-msgid "viewshed"
-msgstr ""
-#: ../raster/r.los/main.c:95
-msgid "Line-of-sight raster analysis program."
-msgstr ""
-#: ../raster/r.los/main.c:109
-msgid "Coordinate identifying the viewing position"
-msgstr ""
-#: ../raster/r.los/main.c:114
-msgid "Binary (1/0) raster map to use as a mask"
-msgstr ""
-#: ../raster/r.los/main.c:121
-msgid "Viewing position height above the ground"
-msgstr ""
-#: ../raster/r.los/main.c:129
-msgid "Maximum distance from the viewing point (meters)"
-msgstr ""
-#: ../raster/r.los/main.c:135
-msgid "Consider earth curvature (current ellipsoid)"
-msgstr ""
-#: ../raster/r.los/main.c:162
-msgid "Lat/Long support is not (yet) implemented for this module."
-msgstr ""
-#: ../raster/r.los/main.c:167
-msgid "Specified observer coordinate is outside current region bounds."
-msgstr ""
-#: ../raster/r.los/main.c:211
-msgid "Pattern map should be a binary 0/1 CELL map"
-msgstr ""
-#: ../raster/r.los/main.c:245
-msgid "Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
-msgstr ""
-#: ../raster/r.los/main.c:250
-#, c-format
-msgid "Using maximum distance from the viewing point (meters): %f"
-msgstr ""
-#: ../raster/r.his/main.c:63 ../imagery/i.his.rgb/main.c:47
-#: ../imagery/i.rgb.his/main.c:47 ../display/d.his/main.c:63
-#, fuzzy
-msgid "color transformation"
-#: ../raster/r.his/main.c:64 ../imagery/i.his.rgb/main.c:48
-#: ../imagery/i.rgb.his/main.c:48 ../display/d.his/main.c:64
-#: ../display/d.rgb/main.c:55
-msgid "RGB"
-msgstr ""
-#: ../raster/r.his/main.c:65 ../imagery/i.his.rgb/main.c:49
-#: ../imagery/i.rgb.his/main.c:49 ../display/d.his/main.c:65
-msgid "HIS"
-msgstr ""
-#: ../raster/r.his/main.c:67
-msgid "Generates red, green and blue raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
-msgstr ""
-#: ../raster/r.his/main.c:76 ../display/d.his/main.c:76
-msgid "Name of layer to be used for HUE"
-msgstr ""
-#: ../raster/r.his/main.c:83 ../display/d.his/main.c:83
-msgid "Name of layer to be used for INTENSITY"
-msgstr ""
-#: ../raster/r.his/main.c:90 ../display/d.his/main.c:90
-msgid "Name of layer to be used for SATURATION"
-msgstr ""
-#: ../raster/r.his/main.c:97
-msgid "Name of output layer to be used for RED"
-msgstr ""
-#: ../raster/r.his/main.c:104
-msgid "Name of output layer to be used for GREEN"
-msgstr ""
-#: ../raster/r.his/main.c:111
-msgid "Name of output layer to be used for BLUE"
-msgstr ""
-#: ../raster/r.his/main.c:115 ../display/d.his/main.c:101
-msgid "Respect NULL values while drawing"
-msgstr ""
-#: ../raster/r.his/main.c:139 ../raster/r.his/main.c:155
-#: ../raster/r.his/main.c:173 ../raster/r.out.ppm3/main.c:109
-#: ../display/d.histogram/main.c:174 ../display/d.rast.num/main.c:222
-#: ../display/d.his/main.c:139 ../display/d.his/main.c:156
-#: ../display/d.his/main.c:174 ../display/d.colortable/main.c:137
-#: ../display/d.rast/display.c:23 ../display/d.rgb/main.c:100
-#: ../display/d.legend/main.c:273
-#, fuzzy, c-format
-msgid "Color file for <%s> not available"
-#: ../raster/r.buffer/read_map.c:52
-#, fuzzy, c-format
-msgid "Reading input raster map <%s>..."
-#: ../raster/r.buffer/main.c:67 ../vector/v.buffer/main.c:212
-#: ../locale/scriptstrings/r.buffer_to_translate.c:3
-#, fuzzy
-msgid "buffer"
-#: ../raster/r.buffer/main.c:69
-msgid "Creates a raster map layer showing buffer zones surrounding cells that contain non-NULL category values."
-msgstr ""
-#: ../raster/r.buffer/main.c:81
-#: ../locale/scriptstrings/r.buffer_to_translate.c:5
-msgid "Distance zone(s)"
-msgstr ""
-#: ../raster/r.buffer/main.c:88
-#: ../locale/scriptstrings/r.buffer_to_translate.c:6
-msgid "Units of distance"
-msgstr ""
-#: ../raster/r.buffer/main.c:94
-#: ../locale/scriptstrings/r.buffer_to_translate.c:4
-msgid "Ignore zero (0) data cells instead of NULL cells"
-msgstr ""
-#: ../raster/r.buffer/main.c:131
-msgid "Parse distances error"
-msgstr ""
-#: ../raster/r.buffer/main.c:150
-#, c-format
-msgid "Pass %d (of %d)"
-msgstr ""
-#: ../raster/r.buffer/write_map.c:45
-#, fuzzy, c-format
-msgid "Writing output raster map <%s>..."
-#: ../raster/r.buffer/parse_dist.c:54
-#, c-format
-msgid "%s: %s - illegal distance specification"
-msgstr ""
-#: ../raster/r.buffer/execute.c:34
-msgid "Finding buffer zones..."
-msgstr ""
-#: ../raster/r.resamp.stats/main.c:257 ../raster/r.resamp.rst/main.c:149
-#: ../raster/r.resample/main.c:55 ../raster/r.resamp.bspline/main.c:83
-#: ../raster/r.resamp.interp/main.c:77 ../raster/r.resamp.filter/main.c:385
-#: ../vector/v.sample/main.c:77
-msgid "resample"
-msgstr ""
-#: ../raster/r.resamp.stats/main.c:259
-#, fuzzy
-msgid "Resamples raster map layers to a coarser grid using aggregation."
-#: ../raster/r.resamp.stats/main.c:269
-msgid "Aggregation method"
-msgstr ""
-#: ../raster/r.resamp.stats/main.c:277 ../raster/r.series/main.c:162
-#: ../raster/r.neighbors/main.c:182
-#, fuzzy
-msgid "Quantile to calculate for method=quantile"
-#: ../raster/r.resamp.stats/main.c:283 ../raster/r.series/main.c:181
-#: ../raster/r.resamp.filter/main.c:424
-msgid "Propagate NULLs"
-msgstr ""
-#: ../raster/r.resamp.stats/main.c:287
-msgid "Weight according to area (slower)"
-msgstr ""
-#: ../raster/r.resamp.stats/main.c:296 ../raster/r.series/main.c:101
-#, c-format
-msgid "Unknown method <%s>"
-msgstr ""
-#: ../raster/r.resamp.stats/main.c:370 ../raster/r.resamp.interp/main.c:355
-#: ../raster/r.resamp.filter/main.c:552
-#, c-format
-msgid "Unable to read color table for %s"
-msgstr ""
-#: ../raster/r.circle/main.c:54
-msgid "Creates a raster map containing concentric rings around a given point."
-msgstr ""
-#: ../raster/r.circle/main.c:64
-msgid "The coordinate of the center (east,north)"
-msgstr ""
-#: ../raster/r.circle/main.c:70
-msgid "Minimum radius for ring/circle map (in meters)"
-msgstr ""
-#: ../raster/r.circle/main.c:76
-msgid "Maximum radius for ring/circle map (in meters)"
-msgstr ""
-#: ../raster/r.circle/main.c:82
-msgid "Data value multiplier"
-msgstr ""
-#: ../raster/r.circle/main.c:86
-msgid "Generate binary raster map"
-msgstr ""
-#: ../raster/r.circle/main.c:109
-msgid "Please specify a radius in which min < max"
-msgstr ""
-#: ../raster/r.circle/main.c:117
-msgid "Please specify min and/or max radius when using the binary flag"
-msgstr ""
-#: ../raster/r.circle/main.c:154 ../raster/r.composite/main.c:261
-#: ../raster/r.in.gdal/main.c:973 ../raster/r.surf.fractal/main.c:85
-#, fuzzy, c-format
-msgid "Raster map <%s> created."
-#: ../raster/r.walk/main.c:183
-msgid "Outputs a raster map layer showing the anisotropic cumulative cost of moving between different geographic locations on an input elevation raster map layer whose cell category values represent elevation combined with an input raster map layer whose cell values represent friction cost."
-msgstr ""
-#: ../raster/r.walk/main.c:193
-msgid "Name of elevation input raster map"
-msgstr ""
-#: ../raster/r.walk/main.c:199
-msgid "Name of input raster map containing friction costs"
-msgstr ""
-#: ../raster/r.walk/main.c:203
-#, fuzzy
-msgid "output map with walking costs"
-#: ../raster/r.walk/main.c:204
-#, fuzzy
-msgid "Name of output raster map to contain walking costs"
-#: ../raster/r.walk/main.c:219
-msgid "Starting points vector map"
-msgstr ""
-#: ../raster/r.walk/main.c:226
-msgid "Stop points vector map"
-msgstr ""
-#: ../raster/r.walk/main.c:234
-#, fuzzy
-msgid "Starting points raster map"
-#: ../raster/r.walk/main.c:242
-msgid "The map E and N grid coordinates of a starting point (E,N)"
-msgstr ""
-#: ../raster/r.walk/main.c:250
-msgid "The map E and N grid coordinates of a stopping point (E,N)"
-msgstr ""
-#: ../raster/r.walk/main.c:258
-msgid "An optional maximum cumulative cost"
-msgstr ""
-#: ../raster/r.walk/main.c:284
-msgid "Coefficients for walking energy formula parameters a,b,c,d"
-msgstr ""
-#: ../raster/r.walk/main.c:293
-msgid "Lambda coefficients for combining walking energy and friction cost"
-msgstr ""
-#: ../raster/r.walk/main.c:302
-msgid "Slope factor determines travel energy cost per height step"
-msgstr ""
-#: ../raster/r.walk/main.c:311
-msgid "Keep null values in output map"
-msgstr ""
-#: ../raster/r.walk/main.c:389
-#, c-format
-msgid "Missing required value: got %d instead of 4"
-msgstr ""
-#: ../raster/r.walk/main.c:392
-#, c-format
-msgid "Walking costs are a=%lf b=%lf c=%lf d=%lf"
-msgstr ""
-#: ../raster/r.walk/main.c:397 ../raster/r.walk/main.c:405
-#, c-format
-msgid "Missing required value: %d"
-msgstr ""
-#: ../raster/r.walk/main.c:400
-#, c-format
-msgid "Lambda is %lf"
-msgstr ""
-#: ../raster/r.walk/main.c:408
-#, c-format
-msgid "Slope_factor is %lf"
-msgstr ""
-#: ../raster/r.walk/main.c:427
-msgid "Warning: assigning negative cost to null cell. Null cells excluded."
-msgstr ""
-#: ../raster/r.walk/main.c:612
-#, fuzzy, c-format
-msgid "Reading raster maps <%s> and <%s>, initializing output..."
-#: ../raster/r.walk/main.c:863
-#, fuzzy, c-format
-msgid "Reading %s... "
-#: ../raster/r.walk/main.c:900
-#, fuzzy, c-format
-msgid "No start points found in raster <%s>"
-#: ../raster/r.walk/main.c:934
-msgid "Finding cost path"
-msgstr ""
-#: ../raster/r.walk/main.c:1405
-#, fuzzy, c-format
-msgid "Writing output raster map %s... "
-#: ../raster/r.what/main.c:92 ../display/d.where/main.c:44
-#: ../display/d.what.vect/main.c:58 ../display/d.what.rast/main.c:50
-#: ../vector/v.what.rast/main.c:70 ../vector/v.what/main.c:61
-#, fuzzy
-msgid "position"
-#: ../raster/r.what/main.c:93 ../raster/r.what.color/main.c:89
-#: ../display/d.where/main.c:45 ../display/d.what.vect/main.c:59
-#: ../display/d.what.rast/main.c:51 ../vector/v.what.rast/main.c:71
-#: ../vector/v.what/main.c:62
-#, fuzzy
-msgid "querying"
-#: ../raster/r.what/main.c:95
-msgid "Queries raster map layers on their category values and category labels."
-msgstr ""
-#: ../raster/r.what/main.c:103
-msgid "Name of existing raster map(s) to query"
-msgstr ""
-#: ../raster/r.what/main.c:110
-msgid "Size of point cache"
-msgstr ""
-#: ../raster/r.what/main.c:112 ../raster/r.what/main.c:150
-#: ../display/d.legend/main.c:107 ../display/d.legend/main.c:116
-#: ../display/d.legend/main.c:124 ../display/d.legend/main.c:145
-#: ../display/d.legend/main.c:154 ../display/d.legend/main.c:161
-#: ../display/d.legend/main.c:169 ../display/d.legend/main.c:177
-#: ../display/d.legend/main.c:182 ../display/d.legend/main.c:187
-#: ../display/d.legend/main.c:192 ../display/d.legend/main.c:197
-#: ../display/d.legend/main.c:202
-msgid "Advanced"
-msgstr ""
-#: ../raster/r.what/main.c:129 ../vector/v.what/main.c:72
-msgid "Coordinates for query"
-msgstr ""
-#: ../raster/r.what/main.c:133
-#, fuzzy
-msgid "Output header row"
-#: ../raster/r.what/main.c:137
-#, fuzzy
-msgid "Show the category labels of the grid cell(s)"
-#: ../raster/r.what/main.c:141
-msgid "Output color values as RRR:GGG:BBB"
-msgstr ""
-#: ../raster/r.what/main.c:145
-msgid "Output integer category values, not cell values"
-msgstr ""
-#: ../raster/r.what/main.c:149
-msgid "Turn on cache reporting"
-msgstr ""
-#: ../raster/r.what/main.c:196
-#, fuzzy, c-format
-msgid "can only do up to %d raster maps"
-#: ../raster/r.what/main.c:212
-#, fuzzy, c-format
-msgid "Unable to read category file for <%s>"
-#: ../raster/r.contour/main.c:87
-msgid "DEM"
-msgstr ""
-#: ../raster/r.contour/main.c:88
-msgid "contours"
-msgstr ""
-#: ../raster/r.contour/main.c:90
-msgid "Produces a vector map of specified contours from a raster map."
-msgstr ""
-#: ../raster/r.contour/main.c:101
-msgid "List of contour levels"
-msgstr ""
-#: ../raster/r.contour/main.c:107
-msgid "Minimum contour level"
-msgstr ""
-#: ../raster/r.contour/main.c:113
-msgid "Maximum contour level"
-msgstr ""
-#: ../raster/r.contour/main.c:119
-msgid "Increment between contour levels"
-msgstr ""
-#: ../raster/r.contour/main.c:127
-msgid "Minimum number of points for a contour line (0 -> no limit)"
-msgstr ""
-#: ../raster/r.contour/main.c:133
-msgid "Neither \"levels\" nor \"step\" parameter specified."
-msgstr ""
-#: ../raster/r.contour/main.c:141 ../raster/r.stats/main.c:307
-#, fuzzy, c-format
-msgid "Unable to read fp range of raster map <%s>"
-#: ../raster/r.contour/main.c:172 ../vector/v.net.centrality/main.c:263
-#: ../vector/v.overlay/main.c:465 ../vector/v.in.ogr/main.c:863
-#: ../vector/v.net.distance/main.c:225 ../vector/v.in.dwg/main.c:237
-#: ../vector/v.distance/main.c:955 ../vector/v.net.flow/main.c:180
-#: ../vector/v.surf.rst/main.c:579 ../vector/v.net.timetable/main.c:103
-#: ../vector/v.convert/att.c:81 ../vector/v.net.allpairs/main.c:172
-#: ../vector/v.net.components/main.c:183 ../vector/v.to.points/main.c:293
-#: ../vector/v.net.path/path.c:109 ../vector/v.in.lidar/main.c:598
-#, fuzzy, c-format
-msgid "Unable to create table: '%s'"
-#: ../raster/r.contour/main.c:177 ../vector/v.in.ogr/main.c:868
-#: ../vector/v.in.dwg/main.c:241 ../vector/v.in.ascii/main.c:504
-#: ../vector/v.reclass/main.c:300 ../vector/v.convert/att.c:86
-#: ../vector/v.in.sites/main.c:176 ../vector/v.in.dxf/write_vect.c:240
-#: ../vector/v.to.points/main.c:298 ../vector/v.in.lidar/main.c:603
-#, fuzzy, c-format
-msgid "Unable to create index for table <%s>, key <%s>"
-#: ../raster/r.contour/main.c:182 ../raster/r.to.vect/main.c:218
-#: ../vector/v.random/main.c:206 ../vector/v.overlay/main.c:475
-#: ../vector/v.in.ogr/main.c:874 ../vector/v.in.dwg/main.c:246
-#: ../vector/v.in.ascii/main.c:394 ../vector/v.sample/main.c:196
-#: ../vector/v.distance/main.c:960 ../vector/v.mkgrid/main.c:251
-#: ../vector/v.reclass/main.c:305 ../vector/v.convert/att.c:91
-#: ../vector/v.in.sites/main.c:181 ../vector/v.in.dxf/write_vect.c:237
-#: ../vector/v.to.points/main.c:304 ../vector/v.in.lidar/main.c:609
-#, fuzzy, c-format
-msgid "Unable to grant privileges on table <%s>"
-#: ../raster/r.contour/main.c:200 ../vector/v.overlay/area_area.c:238
-#: ../vector/v.overlay/line_area.c:217 ../vector/v.convert/att.c:111
-#: ../vector/v.to.points/main.c:63
-#, fuzzy, c-format
-msgid "Unable to insert new record: '%s'"
-#: ../raster/r.contour/main.c:220 ../vector/v.generalize/displacement.c:79
-#, fuzzy
-msgid "Reading data..."
-#: ../raster/r.contour/main.c:246
-#, fuzzy, c-format
-msgid "Range of data: min=%f, max=%f"
-#: ../raster/r.contour/main.c:248
-#, fuzzy
-msgid "Range of data: empty"
-#: ../raster/r.contour/main.c:276 ../raster/r.contour/main.c:279
-#, fuzzy
-msgid "This step value is not allowed"
-#: ../raster/r.contour/main.c:304
-#, c-format
-msgid "Range of levels: min = %f, max = %f"
-msgstr ""
-#: ../raster/r.contour/main.c:333
-#, fuzzy
-msgid "Displacing data..."
-#: ../raster/r.contour/cont.c:82
-#, fuzzy, c-format
-msgid "Writing vector contours (total levels %d)..."
-#: ../raster/r.contour/cont.c:212
-#, c-format
-msgid "%d crossings founds"
-msgstr ""
-#: ../raster/r.contour/cont.c:263
-msgid "Illegal edge number"
-msgstr ""
-#: ../raster/r.contour/cont.c:371
-msgid "Edge number out of range"
-msgstr ""
-#: ../raster/r.series/main.c:133 ../raster/r.series.interp/main.c:65
-#, fuzzy
-msgid "series"
-msgstr "'%s'. ड्राइवर चालू होत नाही"
-#: ../raster/r.series/main.c:135
-msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
-msgstr ""
-#: ../raster/r.series/main.c:144
-msgid "Input file with raster map names and optional weights per line, field separator between name and weight is |"
-msgstr ""
-#: ../raster/r.series/main.c:155
-msgid "Aggregate operation"
-msgstr ""
-#: ../raster/r.series/main.c:170
-msgid "Weighting factor for each input map, default value is 1.0 for each input map"
-msgstr ""
-#: ../raster/r.series/main.c:177
-msgid "Ignore values outside this range"
-msgstr ""
-#: ../raster/r.series/main.c:185
-#, fuzzy
-msgid "Don't keep files open"
-#: ../raster/r.series/main.c:196
-msgid "input= and file= are mutually exclusive"
-msgstr ""
-#: ../raster/r.series/main.c:199
-#, fuzzy
-msgid "Please specify input= or file="
-#: ../raster/r.series/main.c:249 ../raster/r.series/main.c:292
-#, fuzzy, c-format
-msgid "Reading raster map <%s> using weight %f..."
-#: ../raster/r.series/main.c:256
-#, fuzzy
-msgid "No raster map name found in input file"
-#: ../raster/r.series/main.c:266 ../raster/r.stats/main.c:261
-#, fuzzy
-msgid "Raster map not found"
-#: ../raster/r.series/main.c:278
-msgid "input= and weights= must have the same number of values"
-msgstr ""
-#: ../raster/r.series/main.c:307
-msgid "output= and method= must have the same number of values"
-msgstr ""
-#: ../raster/r.random.surface/init.c:73
-#, c-format
-msgid "High (%d) must be greater than 1"
-msgstr ""
-#: ../raster/r.random.surface/init.c:82
-#, fuzzy, c-format
-msgid "Rastar map <%s> repeated, maps must be unique"
-#: ../raster/r.random.surface/init.c:92
-#, fuzzy
-msgid "Output raster map required"
-#: ../raster/r.random.surface/init.c:108
-#, c-format
-msgid "Seed (%d) larger than maximum (%d)"
-msgstr ""
-#: ../raster/r.random.surface/init.c:111 ../raster/r.random.surface/init.c:120
-#, c-format
-msgid " seed is set to %d"
-msgstr ""
-#: ../raster/r.random.surface/init.c:116
-#, c-format
-msgid "Seed (%d) smaller than minimum (%d)"
-msgstr ""
-#: ../raster/r.random.surface/init.c:159
-#, c-format
-msgid "Distance value (%d): %lf must be >= 0.0"
-msgstr ""
-#: ../raster/r.random.surface/init.c:187
-#, c-format
-msgid "Exponent value (%lf) must be > 0.0"
-msgstr ""
-#: ../raster/r.random.surface/init.c:211
-#, c-format
-msgid "Flat value (%lf) must be less than distance value (%lf)"
-msgstr ""
-#: ../raster/r.random.surface/init.c:232
-msgid "Must have a distance value for each filter"
-msgstr ""
-#: ../raster/r.random.surface/init.c:264
-msgid "Must have a exponent value for each filter"
-msgstr ""
-#: ../raster/r.random.surface/init.c:281
-msgid "Must have a weight value for each filter"
-msgstr ""
-#: ../raster/r.random.surface/main.c:58 ../raster/r.random/main.c:52
-#: ../raster/r.surf.random/main.c:38 ../raster/r.random.cells/main.c:46
-#: ../raster/r.surf.gauss/main.c:40 ../vector/v.random/main.c:87
-#, fuzzy
-msgid "random"
-msgstr "तक्त्याचे नाव"
-#: ../raster/r.random.surface/main.c:59 ../raster/r.surf.contour/main.c:61
-#: ../raster/r.surf.idw2/main.c:62 ../raster/r.surf.random/main.c:37
-#: ../raster/r.resamp.bspline/main.c:82 ../raster/r.surf.idw/main.c:104
-#: ../raster/r.surf.area/main.c:77 ../raster/r.surf.gauss/main.c:39
-#: ../raster/r.surf.fractal/main.c:39 ../vector/v.surf.rst/main.c:143
-#: ../vector/v.vol.rst/main.c:241 ../vector/v.surf.idw/main.c:86
-#: ../vector/v.surf.bspline/main.c:92
-msgid "surface"
-msgstr ""
-#: ../raster/r.random.surface/main.c:61
-msgid "Generates random surface(s) with spatial dependence."
-msgstr ""
-#: ../raster/r.random.surface/main.c:68
-#, fuzzy
-msgid "Name for output raster map(s)"
-#: ../raster/r.random.surface/main.c:77
-msgid "Maximum distance of spatial correlation (value >= 0.0)"
-msgstr ""
-#: ../raster/r.random.surface/main.c:85
-msgid "Distance decay exponent (value > 0.0)"
-msgstr ""
-#: ../raster/r.random.surface/main.c:94
-msgid "Distance filter remains flat before beginning exponent"
-msgstr ""
-#: ../raster/r.random.surface/main.c:102
-msgid "Random seed (SEED_MIN >= value >= SEED_MAX), default [random]"
-msgstr ""
-#: ../raster/r.random.surface/main.c:108
-msgid "Maximum cell value of distribution"
-msgstr ""
-#: ../raster/r.random.surface/main.c:113
-msgid "Uniformly distributed cell values"
-msgstr ""
-#: ../raster/r.random.surface/main.c:128 ../raster/r.random.cells/init.c:89
-#, fuzzy, c-format
-msgid "Generating raster map <%s>..."
-#: ../raster/r.statistics3/main.c:76
-#, fuzzy
-msgid "Computing histograms"
-#: ../raster/r.statistics3/main.c:111 ../raster/r.quantile/main.c:97
-#, fuzzy
-msgid "Computing bins"
-#: ../raster/r.statistics3/main.c:166 ../raster/r.quantile/main.c:134
-#, fuzzy
-msgid "Binning data"
-#: ../raster/r.statistics3/main.c:218 ../raster/r.quantile/main.c:179
-#, fuzzy
-msgid "Sorting bins"
-#: ../raster/r.statistics3/main.c:242
-#, fuzzy
-msgid "Printing quantiles"
-#: ../raster/r.statistics3/main.c:257 ../raster/r.quantile/main.c:189
-#, fuzzy
-msgid "Computing quantiles"
-#: ../raster/r.statistics3/main.c:294
-#, fuzzy
-msgid "Generating reclass maps"
-#: ../raster/r.statistics3/main.c:309 ../raster/r.statistics2/main.c:480
-#: ../raster/r.proj/readcell.c:58 ../imagery/i.rectify/readcell.c:56
-#, fuzzy
-msgid "Unable to open temporary file"
-#: ../raster/r.statistics3/main.c:333
-#, fuzzy
-msgid "Writing output maps"
-#: ../raster/r.statistics3/main.c:391
-msgid "Compute category quantiles using two passes."
-msgstr ""
-#: ../raster/r.statistics3/main.c:401 ../raster/r.quantile/main.c:266
-#, fuzzy
-msgid "Number of quantiles"
-#: ../raster/r.statistics3/main.c:407 ../raster/r.quantile/main.c:274
-msgid "List of percentiles"
-msgstr ""
-#: ../raster/r.statistics3/main.c:414 ../raster/r.quantile/main.c:280
-#, fuzzy
-msgid "Number of bins to use"
-#: ../raster/r.statistics3/main.c:418
-#, fuzzy
-msgid "Resultant raster map(s)"
-#: ../raster/r.statistics3/main.c:425 ../raster/r.statistics2/main.c:148
-msgid "Create reclass map with statistics as category labels"
-msgstr ""
-#: ../raster/r.statistics3/main.c:430
-msgid "Don't create output maps; just print statistics"
-msgstr ""
-#: ../raster/r.statistics3/main.c:442
-#, fuzzy
-msgid "Either -p or output= must be given"
-#: ../raster/r.statistics3/main.c:445
-msgid "-p and output= are mutually exclusive"
-msgstr ""
-#: ../raster/r.statistics3/main.c:469
-#, c-format
-msgid "Number of quantiles (%d) does not match number of output maps (%d)"
-msgstr ""
-#: ../raster/r.statistics3/main.c:478 ../raster/r.statistics2/main.c:180
-#, fuzzy
-msgid "The base map must be an integer (CELL) map"
-#: ../raster/r.statistics3/main.c:481 ../raster/r.statistics2/main.c:183
-#, fuzzy, c-format
-msgid "Unable to read range of base map <%s>"
-#: ../raster/r.statistics3/main.c:486
-#, c-format
-msgid "Base map <%s> has too many categories (max: %d)"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:162 ../raster/r.in.lidar/main.c:163
-#: ../vector/v.lidar.edgedetection/main.c:73
-#: ../vector/v.lidar.correction/main.c:69 ../vector/v.surf.bspline/main.c:94
-#: ../vector/v.lidar.growing/main.c:76
-msgid "LIDAR"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:164
-msgid "Create a raster map from an assemblage of many coordinates using univariate statistics."
-msgstr ""
-#: ../raster/r.in.xyz/main.c:168
-msgid "ASCII file containing input data (or \"-\" to read from stdin)"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:176 ../raster/r.in.lidar/main.c:177
-msgid "Statistic to use for raster values"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:180 ../raster/r.in.xyz/main.c:248
-#: ../raster/r.in.xyz/main.c:257 ../raster/r.in.lidar/main.c:181
-#: ../raster/r.in.lidar/main.c:221 ../raster/r.in.lidar/main.c:230
-msgid "Statistic"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:188 ../raster/r.in.arc/main.c:81
-#: ../raster/r.in.lidar/main.c:189
-msgid "Storage type for resultant raster map"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:199
-msgid "Column number of x coordinates in input file (first column is 1)"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:207
-msgid "Column number of y coordinates in input file"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:215
-msgid "Column number of data values in input file"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:223 ../raster/r.in.lidar/main.c:196
-msgid "Filter range for z data (min,max)"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:230 ../raster/r.in.lidar/main.c:203
-msgid "Scale to apply to z data"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:247 ../raster/r.in.lidar/main.c:220
-msgid "pth percentile of the values"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:256 ../raster/r.in.lidar/main.c:229
-msgid "Discard <trim> percent of the smallest and <trim> percent of the largest observations"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:261 ../raster/r.in.lidar/main.c:239
-msgid "Scan data file for extent then exit"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:266 ../raster/r.in.lidar/main.c:245
-msgid "In scan mode, print using shell script style"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:270
-msgid "Ignore broken lines"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:296
-msgid "Please specify a reasonable column number."
-msgstr ""
-#: ../raster/r.in.xyz/main.c:307 ../raster/r.in.lidar/main.c:392
-#, fuzzy
-msgid "Invalid zrange"
-#: ../raster/r.in.xyz/main.c:394 ../raster/r.in.lidar/main.c:486
-msgid "Unable to calculate percentile without the pth option specified!"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:406 ../raster/r.in.lidar/main.c:498
-msgid "Unable to calculate trimmed mean without the trim option specified!"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:482
-msgid "If input is not from a file it is only possible to perform a single pass."
-msgstr ""
-#: ../raster/r.in.xyz/main.c:488 ../raster/r.in.lidar/main.c:561
-msgid "zrange will not be taken into account during scan"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:524 ../raster/r.in.lidar/main.c:580
-#, fuzzy
-msgid "Reading data ..."
-#: ../raster/r.in.xyz/main.c:531 ../raster/r.in.lidar/main.c:592
-#: ../raster/r.in.poly/poly2rast.c:55
-#, c-format
-msgid "Pass #%d (of %d) ..."
-msgstr ""
-#: ../raster/r.in.xyz/main.c:602 ../raster/r.in.xyz/main.c:610
-#: ../raster/r.in.xyz/main.c:1101 ../raster/r.in.xyz/main.c:1109
-#, c-format
-msgid ""
-"Not enough data columns. Incorrect delimiter or column number? Found the following character(s) in row %lu:\n"
-"[%s]"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:606 ../raster/r.in.xyz/main.c:1105
-msgid "Line ignored as requested"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:625 ../raster/r.in.xyz/main.c:1139
-#, c-format
-msgid "Bad y-coordinate line %lu column %d. <%s>"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:632 ../raster/r.in.xyz/main.c:1124
-#, c-format
-msgid "Bad x-coordinate line %lu column %d. <%s>"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:639 ../raster/r.in.xyz/main.c:1154
-#, c-format
-msgid "Bad z-coordinate line %lu column %d. <%s>"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:721 ../raster/r.in.lidar/main.c:758
-msgid "Writing to map ..."
-msgstr ""
-#: ../raster/r.in.xyz/main.c:1059 ../raster/r.in.lidar/main.c:1104
-#, fuzzy, c-format
-msgid "%lu points found in region."
-#: ../raster/r.in.xyz/main.c:1086 ../raster/r.in.lidar/main.c:1128
-msgid "Scanning data ..."
-msgstr ""
-#: ../raster/r.in.xyz/main.c:1174 ../raster/r.in.lidar/main.c:1179
-#, c-format
-msgid "Range:     min         max\n"
-msgstr ""
-#: ../raster/r.composite/main.c:73
-#, fuzzy
-msgid "composite"
-#: ../raster/r.composite/main.c:75
-msgid "Combines red, green and blue raster maps into a single composite raster map."
-msgstr ""
-#: ../raster/r.composite/main.c:89 ../raster/r.out.ppm3/main.c:63
-#, c-format
-msgid "Name of raster map to be used for <%s>"
-msgstr ""
-#: ../raster/r.composite/main.c:101
-msgid "Number of levels to be used for each component"
-msgstr ""
-#: ../raster/r.composite/main.c:102 ../raster/r.composite/main.c:120
-msgid "Levels"
-msgstr ""
-#: ../raster/r.composite/main.c:117
-#, c-format
-msgid "Number of levels to be used for <%s>"
-msgstr ""
-#: ../raster/r.composite/main.c:127
-msgid "Dither"
-msgstr ""
-#: ../raster/r.composite/main.c:131
-msgid "Use closest color"
-msgstr ""
-#: ../raster/r.composite/main.c:163
-#, fuzzy, c-format
-msgid "Unable to read color file of raster map <%s>"
-#: ../raster/r.composite/main.c:285
-#, fuzzy
-msgid "Creating color table for output raster map..."
-#: ../raster/r.solute.transport/main.c:59
-msgid "The initial concentration in [kg/m^3]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:63
-msgid "The piezometric head in [m]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:68
-msgid "The x-part of the hydraulic conductivity tensor in [m/s]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:73
-msgid "The y-part of the hydraulic conductivity tensor in [m/s]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:79
-msgid "The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - dirichlet- and 3 - transfer boundary condition"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:85
-msgid "The x-part of the diffusion tensor in [m^2/s]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:90
-msgid "The y-part of the diffusion tensor in [m^2/s]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:94
-#: ../raster/r.solute.transport/main.c:102
-#: ../raster/r.solute.transport/main.c:138
-#: ../raster/r.solute.transport/main.c:145
-msgid "Water flow"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:96
-msgid "Groundwater sources and sinks in [m^3/s]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:103
-msgid "Concentration sources and sinks bounded to a water source or sink in [kg/s]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:112
-msgid "Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical reaction)"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:117
-msgid "Retardation factor [-]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:121
-msgid "Effective porosity [-]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:125
-msgid "Top surface of the aquifer in [m]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:129
-#, fuzzy
-msgid "Bottom surface of the aquifer in [m]"
-#: ../raster/r.solute.transport/main.c:132
-msgid "The resulting concentration of the numerical solute transport calculation will be written to this map. [kg/m^3]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:140
-msgid "Calculate and store the groundwater filter velocity vector part in x direction [m/s]\n"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:147
-msgid "Calculate and store the groundwater filter velocity vector part in y direction [m/s]\n"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:161
-msgid "The longditudinal dispersivity length. [m]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:169
-msgid "The transversal dispersivity length. [m]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:177
-msgid "Use this number of time loops if the CFL flag is off. The timestep will become dt/loops."
-msgstr ""
-#: ../raster/r.solute.transport/main.c:187
-msgid "Set the flow stabilizing scheme (full or exponential upwinding)."
-msgstr ""
-#: ../raster/r.solute.transport/main.c:199
-msgid "Use the Courant-Friedrichs-Lewy criteria for time step calculation"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:231
-#, fuzzy
-msgid "solute transport"
-#: ../raster/r.solute.transport/main.c:233
-msgid "Numerical calculation program for transient, confined and unconfined solute transport in two dimensions"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:244 ../raster/r.gwflow/main.c:218
-#: ../raster/r.topidx/main.c:53
-#, c-format
-msgid "Lat/Long location is not supported by %s. Please reproject map first."
-msgstr ""
-#: ../raster/r.solute.transport/main.c:258
-msgid "The direct LU solver do not work with sparse matrices"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:260
-msgid "The direct Gauss solver do not work with sparse matrices"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:370
-#, c-format
-msgid "The Courant-Friedrichs-Lewy criteria is %g it should be within [0:1]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:371
-#, c-format
-msgid "The largest stable time step is %g"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:380
-#, fuzzy, c-format
-msgid "Number of inner loops is %g"
-#: ../raster/r.solute.transport/main.c:381
-#, c-format
-msgid "Time step for each loop %g"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:385
-#, c-format
-msgid "The time step is to large: %gs. The largest time step should be of size %gs."
-msgstr ""
-#: ../raster/r.solute.transport/main.c:397
-#, c-format
-msgid "Time step %i with time sum %g"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:543
-#, fuzzy
-msgid "Could not create and solve the linear equation system"
-#: ../raster/r.volume/main.c:59 ../raster/r.to.rast3/main.c:198
-#: ../vector/v.to.rast3/main.c:49
-msgid "volume"
-msgstr ""
-#: ../raster/r.volume/main.c:61
-msgid "Calculates the volume of data \"clumps\", and (optionally) produces a GRASS vector points map containing the calculated centroids of these clumps."
-msgstr ""
-#: ../raster/r.volume/main.c:67
-msgid "Existing raster map representing data that will be summed within clumps"
-msgstr ""
-#: ../raster/r.volume/main.c:73
-msgid "Existing raster map, preferably the output of r.clump"
-msgstr ""
-#: ../raster/r.volume/main.c:78
-msgid "Vector points map to contain clump centroids"
-msgstr ""
-#: ../raster/r.volume/main.c:82
-msgid "Generate unformatted report"
-msgstr ""
-#: ../raster/r.volume/main.c:110
-msgid "No data map specified"
-msgstr ""
-#: ../raster/r.volume/main.c:133
-#, fuzzy
-msgid "Unable to open centroids vector points map"
-#: ../raster/r.gwflow/main.c:57
-#, fuzzy
-msgid "Name of input raster map with initial piezometric head in [m]"
-#: ../raster/r.gwflow/main.c:62
-msgid "Name of input raster map providing Boundary condition status: 0-inactive, 1-active, 2-dirichlet"
-msgstr ""
-#: ../raster/r.gwflow/main.c:67
-#, fuzzy
-msgid "Name of input raster map with x-part of the hydraulic conductivity tensor in [m/s]"
-#: ../raster/r.gwflow/main.c:72
-#, fuzzy
-msgid "Name of input raster map with y-part of the hydraulic conductivity tensor in [m/s]"
-#: ../raster/r.gwflow/main.c:77
-#, fuzzy
-msgid "Name of input raster map with water sources and sinks in [m^3/s]"
-#: ../raster/r.gwflow/main.c:81
-msgid "Name of input raster map with storativity for confined or effective porosity for unconfined groundwater flow booth in [-] "
-msgstr ""
-#: ../raster/r.gwflow/main.c:86
-msgid "Recharge"
-msgstr ""
-#: ../raster/r.gwflow/main.c:88
-#, fuzzy
-msgid "Recharge input raster map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
-#: ../raster/r.gwflow/main.c:92
-#, fuzzy
-msgid "Name of input raster map describing the top surface of the aquifer in [m]"
-#: ../raster/r.gwflow/main.c:96
-#, fuzzy
-msgid "Name of input raster map describing the bottom surface of the aquifer in [m]"
-#: ../raster/r.gwflow/main.c:100
-#, fuzzy
-msgid "Output raster map storing the numerical result [m]"
-#: ../raster/r.gwflow/main.c:106
-#, fuzzy
-msgid "Output raster map to store the groundwater filter velocity vector part in x direction [m/s]"
-#: ../raster/r.gwflow/main.c:112
-#, fuzzy
-msgid "Output raster map to store the groundwater filter velocity vector part in y direction [m/s]"
-#: ../raster/r.gwflow/main.c:118
-#, fuzzy
-msgid "Output raster map to store the groundwater budget for each cell [m^3/s]"
-#: ../raster/r.gwflow/main.c:126
-msgid "The type of groundwater flow"
-msgstr ""
-#: ../raster/r.gwflow/main.c:132
-#, fuzzy
-msgid "Name of input raster map providing the height of the river bed in [m]"
-#: ../raster/r.gwflow/main.c:140
-msgid "Name of input raster map providing the water level (head) of the river with leakage connection in [m]"
-msgstr ""
-#: ../raster/r.gwflow/main.c:147
-#, fuzzy
-msgid "Name of input raster map providing the leakage coefficient of the river bed in [1/s]."
-#: ../raster/r.gwflow/main.c:155
-#, fuzzy
-msgid "Name of input raster map providing the height of the drainage bed in [m]"
-#: ../raster/r.gwflow/main.c:162
-#, fuzzy
-msgid "Name of input raster map providing the leakage coefficient of the drainage bed in [1/s]"
-#: ../raster/r.gwflow/main.c:173
-msgid "Allocate a full quadratic linear equation system, default is a sparse linear equation system."
-msgstr ""
-#: ../raster/r.gwflow/main.c:206
-msgid "groundwater flow"
-msgstr ""
-#: ../raster/r.gwflow/main.c:208
-msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
-msgstr ""
-#: ../raster/r.gwflow/main.c:233
-msgid "Please provide river_head, river_leak and river_bed maps"
-msgstr ""
-#: ../raster/r.gwflow/main.c:245
-msgid "Please provide drain_head and drain_leak maps"
-msgstr ""
-#: ../raster/r.gwflow/main.c:257
-msgid "The cholesky solver dos not work with sparse matrices. You may choose a full filled quadratic matrix, flag -f."
-msgstr ""
-#: ../raster/r.gwflow/main.c:287
-#, fuzzy, c-format
-msgid "Calculation time: %g"
-#: ../raster/r.gwflow/main.c:376
-#, c-format
-msgid "Calculation of unconfined groundwater flow loop %i"
-msgstr ""
-#: ../raster/r.gwflow/main.c:399
-#, c-format
-msgid "Maximum difference between this and last increment: %g"
-msgstr ""
-#: ../raster/r.topidx/topidx.c:42 ../imagery/i.landsat.toar/main.c:472
-#, fuzzy
-msgid "Calculating..."
-#: ../raster/r.topidx/topidx.c:278
-#, fuzzy, c-format
-msgid "Number of sinks or boundaries: %d"
-#: ../raster/r.topidx/main.c:42
-#, fuzzy
-msgid "Creates topographic index map from elevation raster map."
-#: ../raster/r.topidx/file_io.c:30
-#, c-format
-msgid "Current region resolution [%.2fx%.2f] lower than input map resolution [%.2fx%.2f]! Needs to be at least identical or the current region resolution lower than the input map resolution"
-msgstr ""
-#: ../raster/r.topidx/file_io.c:32 ../raster/r.fill.dir/main.c:184
-#, fuzzy
-msgid "Reading elevation map..."
-#: ../raster/r.topidx/file_io.c:78
-#, fuzzy
-msgid "Writing topographic index map..."
-#: ../raster/r.ros/main.c:213
-#, fuzzy
-msgid "Generates rate of spread raster map layers."
-#: ../raster/r.ros/main.c:215
-msgid "Generates three, or four raster map layers showing 1) the base (perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the direction of the maximum ROS, and optionally 4) the maximum potential spotting distance."
-msgstr ""
-#: ../raster/r.ros/main.c:222
-msgid "Name of raster map containing fuel MODELs"
-msgstr ""
-#: ../raster/r.ros/main.c:228
-msgid "Name of raster map containing the 1-HOUR fuel MOISTURE (%)"
-msgstr ""
-#: ../raster/r.ros/main.c:234
-msgid "Name of raster map containing the 10-HOUR fuel MOISTURE (%)"
-msgstr ""
-#: ../raster/r.ros/main.c:240
-msgid "Name of raster map containing the 100-HOUR fuel MOISTURE (%)"
-msgstr ""
-#: ../raster/r.ros/main.c:245
-msgid "Name of raster map containing LIVE fuel MOISTURE (%)"
-msgstr ""
-#: ../raster/r.ros/main.c:251
-msgid "Name of raster map containing midflame wind VELOCITYs (ft/min)"
-msgstr ""
-#: ../raster/r.ros/main.c:257
-msgid "Name of raster map containing wind DIRECTIONs (degree)"
-msgstr ""
-#: ../raster/r.ros/main.c:263
-msgid "Name of raster map containing SLOPE (degree)"
-msgstr ""
-#: ../raster/r.ros/main.c:269
-msgid "Name of raster map containing ASPECT (degree, anti-clockwise from E)"
-msgstr ""
-#: ../raster/r.ros/main.c:274
-msgid "Name of raster map containing ELEVATION (m) (required w/ -s)"
-msgstr ""
-#: ../raster/r.ros/main.c:277
-#, fuzzy
-msgid "Name prefix for output raster maps (.base, .max, .maxdir)"
-#: ../raster/r.ros/main.c:281
-msgid "Also produce maximum SPOTTING distance"
-msgstr ""
-#: ../raster/r.ros/main.c:296
-msgid "No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h moisture layers is required."
-msgstr ""
-#: ../raster/r.ros/main.c:320
-#, c-format
-msgid "A wind direction layer should be given if the wind velocity layer <%s> has been given"
-msgstr ""
-#: ../raster/r.ros/main.c:325
-#, c-format
-msgid "A wind velocity layer should be given if the wind direction layer <%s> has been given"
-msgstr ""
-#: ../raster/r.ros/main.c:339
-#, c-format
-msgid "An aspect layer should be given if the slope layer <%s> has been given"
-msgstr ""
-#: ../raster/r.ros/main.c:344
-#, c-format
-msgid "A slope layer should be given if the aspect layer <%s> has been given"
-msgstr ""
-#: ../raster/r.ros/main.c:360
-msgid "An elevation layer should be given if considering spotting"
-msgstr ""
-#: ../raster/r.ros/main.c:378 ../raster/r.ros/main.c:382
-#: ../raster/r.ros/main.c:386 ../raster/r.ros/main.c:393
-#, fuzzy, c-format
-msgid "Raster map <%s> already exists in mapset <%s>"
-#: ../raster/r.ros/main.c:815
-#, fuzzy, c-format
-msgid "Raster maps <%s>, <%s> and <%s> created."
-#: ../raster/r.in.arc/main.c:63
-#, fuzzy
-msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map."
-#: ../raster/r.in.arc/main.c:70
-msgid "ARC/INFO ASCII raster file (GRID) to be imported"
-msgstr ""
-#: ../raster/r.in.arc/main.c:95 ../raster/r.in.ascii/main.c:95
-msgid "Multiplier for ASCII data"
-msgstr ""
-#: ../raster/r.in.arc/main.c:115 ../raster/r.resamp.rst/main.c:553
-#: ../raster/r.in.ascii/main.c:131 ../raster/r.in.ascii/main.c:158
-#: ../display/d.title/main.c:117 ../general/g.setproj/get_stp.c:162
-#: ../general/g.setproj/get_stp.c:165 ../general/g.setproj/get_stp.c:282
-#: ../general/g.setproj/get_stp.c:286 ../vector/v.in.ascii/main.c:247
-#: ../vector/v.surf.rst/main.c:807
-#, fuzzy, c-format
-msgid "Unable to open temporary file <%s>"
-#: ../raster/r.in.arc/main.c:128 ../raster/r.in.ascii/main.c:188
-msgid "Can't get cell header"
-msgstr ""
-#: ../raster/r.in.arc/main.c:135 ../raster/r.horizon/main.c:594
-#: ../raster/r.in.ascii/main.c:195
-#, c-format
-msgid "OOPS: rows changed from %d to %d"
-msgstr ""
-#: ../raster/r.in.arc/main.c:138 ../raster/r.horizon/main.c:598
-#: ../raster/r.in.ascii/main.c:198
-#, c-format
-msgid "OOPS: cols changed from %d to %d"
-msgstr ""
-#: ../raster/r.in.arc/main.c:159 ../raster/r.in.ascii/main.c:210
-#, c-format
-msgid "Data conversion failed at row %d, col %d"
-msgstr ""
-#: ../raster/r.in.arc/main.c:226
-msgid "Failed to copy file"
-msgstr ""
-#: ../raster/r.in.arc/gethead.c:88
-msgid "Illegal line in header"
-msgstr ""
-#: ../raster/r.in.arc/gethead.c:157 ../raster/r.in.ascii/gethead.c:248
-#, c-format
-msgid "Duplicate \"%s\" field in header"
-msgstr ""
-#: ../raster/r.in.arc/gethead.c:162
-#, c-format
-msgid "Illegal \"%s\" value in header: \"%s\""
-msgstr ""
-#: ../raster/r.in.arc/gethead.c:170 ../raster/r.in.ascii/gethead.c:261
-#, c-format
-msgid "\"%s\" field missing from header"
-msgstr ""
-#: ../raster/r.fill.dir/wtrshed.c:95
-#, c-format
-msgid "wtrshed pass %d"
-msgstr ""
-#: ../raster/r.fill.dir/main.c:88
-msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
-msgstr ""
-#: ../raster/r.fill.dir/main.c:104
-#, fuzzy
-msgid "Name for output raster map of problem areas"
-#: ../raster/r.fill.dir/main.c:111
-#, fuzzy
-msgid "Aspect direction format"
-#: ../raster/r.fill.dir/main.c:117
-msgid "Find unresolved areas only"
-msgstr ""
-#: ../raster/r.fill.dir/main.c:123
-#, fuzzy, c-format
-msgid "The '%c' flag requires '%s'to be specified"
-#: ../raster/r.fill.dir/main.c:144
-msgid "Direction map is D8 resolution, i.e. 45 degrees"
-msgstr ""
-#: ../raster/r.fill.dir/main.c:194
-msgid "Filling sinks..."
-msgstr ""
-#: ../raster/r.fill.dir/main.c:198
-msgid "Determining flow directions for ambiguous cases..."
-msgstr ""
-#: ../raster/r.fill.dir/main.c:211
-msgid "Repeat to get the final directions..."
-msgstr ""
-#: ../raster/r.fill.dir/dopolys.c:84
-#, c-format
-msgid "Found %d unresolved areas"
-msgstr ""
-#: ../raster/r.fill.dir/resolve.c:136
-#, c-format
-msgid "Downward pass %d"
-msgstr ""
-#: ../raster/r.fill.dir/resolve.c:173
-#, c-format
-msgid "Upward pass %d"
-msgstr ""
-#: ../raster/r.mfilter/getrow.c:23
-#, fuzzy
-msgid "Error reading temporary file"
-#: ../raster/r.mfilter/perform.c:40 ../raster/r.mfilter/perform.c:51
-#, fuzzy
-msgid "Unable to create temporary file"
-#: ../raster/r.mfilter/perform.c:81
-#, fuzzy, c-format
-msgid "Writing raster map <%s>"
-#: ../raster/r.mfilter/main.c:59
-msgid "Performs raster map matrix filter."
-msgstr ""
-#: ../raster/r.mfilter/main.c:70
-#, fuzzy
-msgid "Path to filter file"
-#: ../raster/r.mfilter/main.c:78
-msgid "Number of times to repeat the filter"
-msgstr ""
-#: ../raster/r.mfilter/main.c:79 ../raster/r.mfilter/main.c:98
-msgid "Filter"
-msgstr ""
-#: ../raster/r.mfilter/main.c:85
-msgid "Output raster map title"
-msgstr ""
-#: ../raster/r.mfilter/main.c:97
-msgid "Apply filter only to null data values"
-msgstr ""
-#: ../raster/r.mfilter/main.c:124
-msgid "Raster map too small for the size of the filter"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:27
-#, fuzzy, c-format
-msgid "Cannot open filter file '%s'"
-#: ../raster/r.mfilter/getfilt.c:47
-msgid "Illegal filter matrix size specified"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:50
-msgid "Even filter matrix size specified"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:72
-msgid "Illegal filter matrix"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:80 ../raster/r.mfilter/getfilt.c:107
-#: ../raster/r.mfilter/getfilt.c:124
-#, fuzzy
-msgid "Filter file format error"
-#: ../raster/r.mfilter/getfilt.c:83
-msgid "Duplicate filter divisor specified"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:101
-msgid "Illegal divisor matrix"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:110
-msgid "Duplicate filter type specified"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:117
-msgid "Illegal filter type specified"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:127
-msgid "Duplicate filter start specified"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:135
-#, c-format
-msgid "Filter start %s ignored, using UL"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:157
-#, fuzzy
-msgid "Illegal filter file format"
-#: ../raster/r.statistics2/main.c:104
-msgid "Calculates category or object oriented statistics (accumulator-based statistics)."
-msgstr ""
-#: ../raster/r.statistics2/main.c:177
-#, fuzzy, c-format
-msgid "Unable to read category file of cover map <%s>"
-msgstr "डेटाबेसची यादी दाखवता येणार नाही"
-#: ../raster/r.statistics2/main.c:247
-msgid "First pass"
-msgstr ""
-#: ../raster/r.statistics2/main.c:326
-msgid "Second pass"
-msgstr ""
-#: ../raster/r.statistics2/main.c:472
-#, fuzzy
-msgid "Generating reclass map"
-#: ../raster/r.statistics2/main.c:494
-#, fuzzy
-msgid "Writing output map"
-#: ../raster/r.out.arc/main.c:63
-msgid "Converts a raster map layer into an ESRI ARCGRID file."
-msgstr ""
-#: ../raster/r.out.arc/main.c:71
-msgid "Name of an output ARC-GRID map (use out=- for stdout)"
-msgstr ""
-#: ../raster/r.out.arc/main.c:78
-msgid "Number of decimal places"
-msgstr ""
-#: ../raster/r.out.arc/main.c:88
-msgid "List one entry per line instead of full row"
-msgstr ""
-#: ../raster/r.out.arc/main.c:94
-msgid "Use cell center reference in header instead of cell corner"
-msgstr ""
-#: ../raster/r.rescale/main.c:51
-msgid "Rescales the range of category values in a raster map layer."
-msgstr ""
-#: ../raster/r.rescale/main.c:118
-#, c-format
-msgid "Rescale %s[%ld,%ld] to %s[%ld,%ld]"
-msgstr ""
-#: ../raster/r.clump/clump.c:99
-#, c-format
-msgid "Pass %d..."
-msgstr ""
-#: ../raster/r.clump/main.c:48 ../vector/v.reclass/main.c:68
-msgid "reclass"
-msgstr ""
-#: ../raster/r.clump/main.c:50
-msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
-msgstr ""
-#: ../raster/r.clump/main.c:61
-msgid "Title"
-msgstr ""
-#: ../raster/r.clump/main.c:96
-#, fuzzy, c-format
-msgid "%d clumps."
-#: ../raster/r.colors/edit_colors.c:58
-#, fuzzy
-msgid "Creates/modifies the color table associated with a 3D raster map."
-#: ../raster/r.colors/edit_colors.c:62
-#, fuzzy
-msgid "Creates/modifies the color table associated with a raster map."
-#: ../raster/r.colors/edit_colors.c:73 ../raster/r.colors/edit_colors.c:80
-#: ../raster/r.colors/edit_colors.c:87 ../raster/r.colors/edit_colors.c:94
-#: ../raster/r.colors/edit_colors.c:115 ../raster/r.colors/edit_colors.c:120
-#: ../raster/r.colors/edit_colors.c:125 ../raster/r.colors/edit_colors.c:130
-#: ../vector/v.colors/main.c:67 ../vector/v.colors/main.c:78
-#: ../vector/v.colors/main.c:85 ../vector/v.colors/main.c:92
-#: ../vector/v.colors/main.c:99 ../vector/v.colors/main.c:125
-#: ../vector/v.colors/main.c:130 ../vector/v.colors/main.c:135
-msgid "Define"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:79 ../vector/v.colors/main.c:84
-#, fuzzy
-msgid "Raster map from which to copy color table"
-#: ../raster/r.colors/edit_colors.c:86 ../vector/v.colors/main.c:91
-#, fuzzy
-msgid "3D raster map from which to copy color table"
-#: ../raster/r.colors/edit_colors.c:92 ../vector/v.colors/main.c:97
-#, fuzzy
-msgid "Path to rules file"
-#: ../raster/r.colors/edit_colors.c:93 ../vector/v.colors/main.c:98
-#, fuzzy
-msgid "\"-\" to read rules from stdin"
-#: ../raster/r.colors/edit_colors.c:98 ../vector/v.colors/main.c:108
-msgid "Remove existing color table"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:99 ../raster/r.null/main.c:107
-#: ../vector/v.colors/main.c:109
-#: ../locale/scriptstrings/r.mask_to_translate.c:10
-#: ../locale/scriptstrings/g.extension_to_translate.c:25
-msgid "Remove"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:104 ../vector/v.colors/main.c:114
-msgid "Only write new color table if one doesn't already exist"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:108 ../vector/v.colors/main.c:118
-msgid "List available rules then exit"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:114 ../vector/v.colors/main.c:124
-msgid "Invert colors"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:119 ../vector/v.colors/main.c:129
-msgid "Logarithmic scaling"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:124 ../vector/v.colors/main.c:134
-msgid "Logarithmic-absolute scaling"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:129
-msgid "Histogram equalization"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:147
-#, fuzzy, c-format
-msgid "No %s map specified"
-#: ../raster/r.colors/edit_colors.c:150
-#, c-format
-msgid "Options <%s> and <%s> options are mutually exclusive"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:159
-#, fuzzy, c-format
-msgid "One of -%c or options <%s>, <%s> or <%s> must be specified"
-#: ../raster/r.colors/edit_colors.c:164
-#, c-format
-msgid "Options <%s>, <%s>, and <%s> options are mutually exclusive"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:169 ../vector/v.colors/main.c:189
-#, c-format
-msgid "Flags -%c and -%c flags are mutually exclusive"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:182
-#, fuzzy, c-format
-msgid "%s map <%s> not found"
-#: ../raster/r.colors/edit_colors.c:192
-#, fuzzy, c-format
-msgid "Unable to remove color table of %s map <%s>"
-#: ../raster/r.colors/edit_colors.c:194
-#, fuzzy, c-format
-msgid "Color table of %s map <%s> not found"
-#: ../raster/r.colors/edit_colors.c:210 ../vector/v.colors/main.c:218
-msgid "Color table exists. Exiting."
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:233
-#, fuzzy, c-format
-msgid "Color table 'random' is not supported for floating point %s map"
-#: ../raster/r.colors/edit_colors.c:237
-#, fuzzy, c-format
-msgid "Color table 'grey.eq' is not supported for floating point %s map"
-#: ../raster/r.colors/edit_colors.c:243
-#, fuzzy, c-format
-msgid "Color table 'grey.log' is not supported for floating point %s map"
-#: ../raster/r.colors/edit_colors.c:251
-#, fuzzy, c-format
-msgid "Unknown color request '%s'"
-#: ../raster/r.colors/edit_colors.c:261 ../vector/v.colors/make_colors.c:51
-#, fuzzy, c-format
-msgid "Unable to load rules file <%s>"
-#: ../raster/r.colors/edit_colors.c:278 ../vector/v.colors/main.c:274
-#, fuzzy, c-format
-msgid "Unable to read color table for 3D raster map <%s>"
-#: ../raster/r.colors/edit_colors.c:318
-#, fuzzy, c-format
-msgid "Color table for %s map <%s> set to '%s'"
-#: ../raster/r.colors/rules.c:40
-#, c-format
-msgid "Enter rules, \"end\" when done, \"help\" if you need it.\n"
-msgstr ""
-#: ../raster/r.colors/rules.c:49
-#, c-format
-msgid "fp: Data range is %s to %s\n"
-msgstr ""
-#: ../raster/r.colors/rules.c:53
-#, c-format
-msgid "Data range is %ld to %ld\n"
-msgstr ""
-#: ../raster/r.colors/rules.c:64
-#, c-format
-msgid ""
-"Your color rules do not cover the whole range of data!\n"
-" (rules %f to %f but data %f to %f)"
-msgstr ""
-#: ../raster/r.colors/rules.c:104 ../raster/r.reclass/parse.c:41
-#, c-format
-msgid "Enter a rule in one of these formats:\n"
-msgstr ""
-#: ../raster/r.colors/rules.c:105
-#, c-format
-msgid " val color\n"
-msgstr ""
-#: ../raster/r.colors/rules.c:106
-#, c-format
-msgid " n%% color\n"
-msgstr ""
-#: ../raster/r.colors/rules.c:107
-#, c-format
-msgid " nv color\n"
-msgstr ""
-#: ../raster/r.colors/rules.c:108
-#, c-format
-msgid " default color\n"
-msgstr ""
-#: ../raster/r.colors/rules.c:109
-#, c-format
-msgid "color can be one of:\n"
-msgstr ""
-#: ../raster/r.colors/rules.c:111
-#, c-format
-msgid "or an R:G:B triplet, e.g.: 0:127:255\n"
-msgstr ""
-#: ../raster/r.colors/rules.c:132
-#, c-format
-msgid "bad rule (%s); rule not added"
-msgstr ""
-#: ../raster/r.colors/rules.c:134
-#, c-format
-msgid "bad rule (%s): [%s]"
-msgstr ""
-#: ../raster/r.colors/stats.c:71 ../raster/r.to.rast3/main.c:291
-#: ../raster/r.to.rast3elev/main.c:443
-msgid "Error opening 3d raster map"
-msgstr ""
-#: ../raster/r.colors/stats.c:84
-msgid "Unable to use logarithmic scaling if range includes zero"
-msgstr ""
-#: ../raster/r.colors/stats.c:112
-#, fuzzy, c-format
-msgid "Reading map <%s>..."
-#: ../raster/r.to.rast3/main.c:59 ../raster/r.to.rast3elev/main.c:136
-msgid "Could not close the map"
-msgstr ""
-#: ../raster/r.to.rast3/main.c:79
-msgid "2d raster maps which represent the slices"
-msgstr ""
-#: ../raster/r.to.rast3/main.c:84 ../raster/r.to.rast3elev/main.c:175
-msgid "The maximum tile size in kilo bytes. Default is 32KB."
-msgstr ""
-#: ../raster/r.to.rast3/main.c:93
-msgid "Use RASTER3D mask (if exists) with output map"
-msgstr ""
-#: ../raster/r.to.rast3/main.c:199 ../raster/r.to.vect/main.c:71
-#: ../raster/r.in.ascii/main.c:71 ../raster/r.to.rast3elev/main.c:364
-#: ../vector/v.convert/main.c:38 ../vector/v.to.rast3/main.c:50
-#: ../vector/v.to.rast/main.c:42
-#: ../locale/scriptstrings/v.convert.all_to_translate.c:4
-#, fuzzy
-msgid "conversion"
-#: ../raster/r.to.rast3/main.c:201
-msgid "Converts 2D raster map slices to one 3D raster volume map."
-msgstr ""
-#: ../raster/r.to.rast3/main.c:213
-msgid "No output map"
-msgstr ""
-#: ../raster/r.to.rast3/main.c:230 ../raster/r.to.rast3elev/main.c:427
-msgid "The 2d and 3d region settings are different. I will use the g3d settings to adjust the 2d region."
-msgstr ""
-#: ../raster/r.to.rast3/main.c:262
-#, c-format
-msgid "Open raster map %s - one time for each depth (%d/%d)"
-msgstr ""
-#: ../raster/r.to.rast3/main.c:275
-msgid "Input maps have to be from the same type. CELL, FCELL or DCELL!"
-msgstr ""
-#: ../raster/r.to.rast3/main.c:279 ../raster/r.to.rast3elev/main.c:457
-#, fuzzy
-msgid "Creating 3D raster map"
-#: ../raster/r.sun/main.c:230
-msgid "sun energy"
-msgstr ""
-#: ../raster/r.sun/main.c:231
-msgid "Solar irradiance and irradiation model."
-msgstr ""
-#: ../raster/r.sun/main.c:233
-msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
-msgstr ""
-#: ../raster/r.sun/main.c:247 ../raster/r.horizon/main.c:196
-msgid "Name of the input elevation raster map [meters]"
-msgstr ""
-#: ../raster/r.sun/main.c:248 ../raster/r.sun/main.c:257
-#: ../raster/r.sun/main.c:266 ../raster/r.sun/main.c:275
-#: ../raster/r.sun/main.c:283 ../raster/r.sun/main.c:292
-#: ../raster/r.sun/main.c:302 ../raster/r.sun/main.c:312
-#: ../raster/r.sun/main.c:322 ../raster/r.sun/main.c:332
-#: ../raster/r.sun/main.c:341 ../raster/r.sun/main.c:350
-#: ../raster/r.sun/main.c:359 ../raster/r.sun/main.c:367
-#: ../raster/r.sun/main.c:375 ../raster/r.horizon/main.c:197
-#: ../raster/r.horizon/main.c:206 ../raster/r.horizon/main.c:214
-#: ../raster/r.horizon/main.c:222 ../raster/r.horizon/main.c:230
-#: ../raster/r.horizon/main.c:238 ../raster/r.horizon/main.c:246
-#: ../raster/r.horizon/main.c:254 ../raster/r.horizon/main.c:262
-#: ../raster/simwe/r.sim.sediment/main.c:175
-#: ../raster/simwe/r.sim.water/main.c:184
-msgid "Input_options"
-msgstr ""
-#: ../raster/r.sun/main.c:256
-msgid "Name of the input aspect map (terrain aspect or azimuth of the solar panel) [decimal degrees]"
-msgstr ""
-#: ../raster/r.sun/main.c:265
-msgid "A single value of the orientation (aspect), 270 is south"
-msgstr ""
-#: ../raster/r.sun/main.c:274
-msgid "Name of the input slope raster map (terrain slope or solar panel inclination) [decimal degrees]"
-msgstr ""
-#: ../raster/r.sun/main.c:282
-msgid "A single value of inclination (slope)"
-msgstr ""
-#: ../raster/r.sun/main.c:291
-msgid "Name of the Linke atmospheric turbidity coefficient input raster map [-]"
-msgstr ""
-#: ../raster/r.sun/main.c:301
-msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
-msgstr ""
-#: ../raster/r.sun/main.c:311
-msgid "Name of the ground albedo coefficient input raster map [-]"
-msgstr ""
-#: ../raster/r.sun/main.c:321
-msgid "A single value of the ground albedo coefficient [-]"
-msgstr ""
-#: ../raster/r.sun/main.c:331
-#, fuzzy
-msgid "Name of input raster map containing latitudes [decimal degrees]"
-#: ../raster/r.sun/main.c:340
-#, fuzzy
-msgid "Name of input raster map containing longitudes [decimal degrees]"
-#: ../raster/r.sun/main.c:349
-#, fuzzy
-msgid "Name of real-sky beam radiation coefficient (thick cloud) input raster map [0-1]"
-#: ../raster/r.sun/main.c:358
-#, fuzzy
-msgid "Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
-#: ../raster/r.sun/main.c:366
-msgid "The horizon information input map prefix"
-msgstr ""
-#: ../raster/r.sun/main.c:374 ../raster/r.horizon/main.c:213
-msgid "Angle step size for multidirectional horizon [degrees]"
-msgstr ""
-#: ../raster/r.sun/main.c:383
-msgid "Output incidence angle raster map (mode 1 only)"
-msgstr ""
-#: ../raster/r.sun/main.c:384 ../raster/r.sun/main.c:393
-#: ../raster/r.sun/main.c:402 ../raster/r.sun/main.c:411
-#: ../raster/r.sun/main.c:420 ../raster/r.sun/main.c:429
-#: ../raster/r.horizon/main.c:271 ../raster/r.horizon/main.c:281
-#: ../raster/r.horizon/main.c:289 ../raster/simwe/r.sim.sediment/main.c:168
-#: ../raster/simwe/r.sim.water/main.c:216 ../vector/v.vol.rst/main.c:377
-#: ../vector/v.vol.rst/main.c:394 ../vector/v.vol.rst/main.c:404
-#: ../vector/v.vol.rst/main.c:413 ../vector/v.vol.rst/main.c:422
-#: ../vector/v.vol.rst/main.c:431 ../vector/v.vol.rst/main.c:440
-msgid "Output_options"
-msgstr ""
-#: ../raster/r.sun/main.c:392
-msgid "Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
-msgstr ""
-#: ../raster/r.sun/main.c:401
-msgid "Output insolation time raster map [h] (mode 2 only)"
-msgstr ""
-#: ../raster/r.sun/main.c:410
-msgid "Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
-msgstr ""
-#: ../raster/r.sun/main.c:419
-msgid "Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
-msgstr ""
-#: ../raster/r.sun/main.c:428
-msgid "Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)"
-msgstr ""
-#: ../raster/r.sun/main.c:435
-msgid "No. of day of the year (1-365)"
-msgstr ""
-#: ../raster/r.sun/main.c:444
-msgid "Time step when computing all-day radiation sums [decimal hours]"
-msgstr ""
-#: ../raster/r.sun/main.c:451
-msgid "Declination value (overriding the internally computed value) [radians]"
-msgstr ""
-#: ../raster/r.sun/main.c:459
-msgid "Local (solar) time (to be set for mode 1 only) [decimal hours]"
-msgstr ""
-#: ../raster/r.sun/main.c:482 ../raster/r.horizon/main.c:288
-msgid "Sampling distance step coefficient (0.5-1.5)"
-msgstr ""
-#: ../raster/r.sun/main.c:490
-msgid "Read the input files in this number of chunks"
-msgstr ""
-#: ../raster/r.sun/main.c:497
-msgid "Civil time zone value, if none, the time will be local solar time"
-msgstr ""
-#: ../raster/r.sun/main.c:503
-msgid "Incorporate the shadowing effect of terrain"
-msgstr ""
-#: ../raster/r.sun/main.c:508
-msgid "Use the low-memory version of the program"
-msgstr ""
-#: ../raster/r.sun/main.c:555
-msgid "You must give the longitude raster if you use civil time"
-msgstr ""
-#: ../raster/r.sun/main.c:558
-#, fuzzy
-msgid "Error reading civil time zone value"
-#: ../raster/r.sun/main.c:561
-#, fuzzy
-msgid "Invalid civil time zone value"
-#: ../raster/r.sun/main.c:586
-msgid "insol_time and incidout are incompatible options"
-msgstr ""
-#: ../raster/r.sun/main.c:591
-#, fuzzy
-msgid "Error reading time step size"
-#: ../raster/r.sun/main.c:593
-#, fuzzy
-msgid "Invalid time step size"
-#: ../raster/r.sun/main.c:597
-#, fuzzy
-msgid "Error reading horizon step size"
-#: ../raster/r.sun/main.c:601
-msgid "The horizon step size must be greater than 0."
-msgstr ""
-#: ../raster/r.sun/main.c:604
-msgid "If you use the horizon option you must also set the 'horizonstep' parameter."
-msgstr ""
-#: ../raster/r.sun/main.c:610
-msgid "Time and insol_time are incompatible options"
-msgstr ""
-#: ../raster/r.sun/main.c:612
-msgid "Mode 1: instantaneous solar incidence angle & irradiance using a set local time"
-msgstr ""
-#: ../raster/r.sun/main.c:617
-msgid "incidout requires time parameter to be set"
-msgstr ""
-#: ../raster/r.sun/main.c:619
-msgid "Mode 2: integrated daily irradiation for a given day of the year"
-msgstr ""
-#: ../raster/r.sun/main.c:665
-msgid "If you use -s and no horizon rasters, numpartitions must be =1"
-msgstr ""
-#: ../raster/r.sun/main.c:678
-msgid "If you want to save memory and to use shadows, you must use pre-calculated horizons."
-msgstr ""
-#: ../raster/r.sun/main.c:723 ../imagery/i.latlong/main.c:102
-#: ../display/d.where/main.c:106 ../general/g.region/printwindow.c:247
-#: ../general/g.region/printwindow.c:503 ../general/g.region/printwindow.c:622
-msgid "Can't get projection info of current location"
-msgstr ""
-#: ../raster/r.sun/main.c:727 ../raster/r.horizon/main.c:475
-#: ../imagery/i.latlong/main.c:104 ../display/d.where/main.c:109
-#: ../general/g.region/printwindow.c:250 ../general/g.region/printwindow.c:506
-#: ../general/g.region/printwindow.c:625
-msgid "Can't get projection units of current location"
-msgstr ""
-#: ../raster/r.sun/main.c:731 ../raster/r.horizon/main.c:479
-#: ../imagery/i.latlong/main.c:106 ../ps/ps.map/do_geogrid.c:271
-#: ../display/d.where/main.c:112 ../display/d.grid/plot.c:335
-#: ../general/g.region/printwindow.c:253 ../general/g.region/printwindow.c:509
-#: ../general/g.region/printwindow.c:628
-msgid "Can't get projection key values of current location"
-msgstr ""
-#: ../raster/r.sun/main.c:741 ../raster/r.horizon/main.c:489
-#: ../imagery/i.latlong/main.c:115 ../ps/ps.map/do_geogrid.c:277
-#: ../display/d.where/main.c:119 ../display/d.where/main.c:145
-#: ../display/d.grid/plot.c:342 ../display/d.grid/plot.c:369
-msgid "Unable to set up lat/long projection parameters"
-msgstr ""
-#: ../raster/r.sun/main.c:745
-msgid "latin and longin raster maps have no effect when in a Lat/Lon location"
-msgstr ""
-#: ../raster/r.sun/main.c:750
-msgid "Both latin and longin raster maps must be given, or neither"
-msgstr ""
-#: ../raster/r.le/r.le.patch/main.c:50
-msgid "Calculates attribute, patch size, core (interior) size, shape, fractal dimension, and perimeter measures for sets of patches in a landscape."
-msgstr ""
-#: ../raster/r.le/r.le.trace/main.c:58
-msgid "Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file."
-msgstr ""
-#: ../raster/r.le/r.le.setup/main.c:59
-msgid "Interactive tool used to setup the sampling and analysis framework that will be used by the other r.le programs."
-msgstr ""
-#: ../raster/r.le/r.le.setup/main.c:63
-msgid "Raster map to use to setup sampling"
-msgstr ""
-#: ../raster/r.le/r.le.setup/main.c:67
-msgid "Vector map to overlay"
-msgstr ""
-#: ../raster/r.le/r.le.setup/sample.c:1049
-#, fuzzy
-msgid "Cannot read vector"
-#: ../raster/r.le/r.le.pixel/main.c:47
-msgid "Contains a set of measures for attributes, diversity, texture, juxtaposition, and edge."
-msgstr ""
-#: ../raster/r.digit/get_label.c:31
-#, c-format
-msgid "Enter the category number for this %s: "
-msgstr ""
-#: ../raster/r.digit/get_label.c:46
-#, c-format
-msgid "Enter a label for category %ld [%s] "
-msgstr ""
-#: ../raster/r.digit/get_label.c:68
-msgid "Look ok? "
-msgstr ""
-#: ../raster/r.digit/main.c:46
-msgid "Interactive tool used to draw and save vector features on a graphics monitor using a pointing device (mouse) and save to a raster map."
-msgstr ""
-#: ../raster/r.digit/main.c:55
-msgid "Display commands to be used for canvas backdrop (separated by ';')"
-msgstr ""
-#: ../raster/r.digit/main.c:78
-msgid "No graphics device selected!"
-msgstr ""
-#: ../raster/r.digit/main.c:97
-msgid "No map created"
-msgstr ""
-#: ../raster/r.digit/get_type.c:31
-#, c-format
-msgid "Please choose one of the following\n"
-msgstr ""
-#: ../raster/r.digit/get_type.c:32
-#, c-format
-msgid "   A define an area\n"
-msgstr ""
-#: ../raster/r.digit/get_type.c:33
-#, c-format
-msgid "   C define a circle\n"
-msgstr ""
-#: ../raster/r.digit/get_type.c:34
-#, c-format
-msgid "   L define a line\n"
-msgstr ""
-#: ../raster/r.digit/get_type.c:35
-#, c-format
-msgid "   X exit (and create map)\n"
-msgstr ""
-#: ../raster/r.digit/get_type.c:36
-#, c-format
-msgid "   Q quit (without creating map)\n"
-msgstr ""
-#: ../raster/r.digit/digitize.c:49
-msgid "Quit without creating a map?? "
-msgstr ""
-#: ../raster/r.surf.contour/main.c:62 ../raster/r.surf.idw2/main.c:63
-#: ../raster/r.series.interp/main.c:66 ../raster/r.resamp.bspline/main.c:84
-#: ../raster/r.surf.idw/main.c:105 ../vector/v.surf.rst/main.c:144
-#: ../vector/v.vol.rst/main.c:242 ../vector/v.surf.idw/main.c:87
-#: ../vector/v.surf.bspline/main.c:93
-#: ../locale/scriptstrings/v.krige_to_translate.c:4
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:4
-#, fuzzy
-msgid "interpolation"
-#: ../raster/r.surf.contour/main.c:64
-#, fuzzy
-msgid "Generates surface raster map from rasterized contours."
-#: ../raster/r.surf.contour/main.c:67
-#, fuzzy
-msgid "Name of input raster map containing contours"
-#: ../raster/r.in.bin/main.c:50 ../raster/r.in.bin/main.c:59
-#: ../raster/r.in.bin/main.c:512
-#, fuzzy
-msgid "Error reading data"
-#: ../raster/r.in.bin/main.c:238
-msgid "Import a binary raster file into a GRASS raster map layer."
-msgstr ""
-#: ../raster/r.in.bin/main.c:243
-msgid "Import as floating-point data (default: integer)"
-msgstr ""
-#: ../raster/r.in.bin/main.c:248
-msgid "Import as double-precision floating-point data (default: integer)"
-msgstr ""
-#: ../raster/r.in.bin/main.c:252
-msgid "Signed data (two's complement)"
-msgstr ""
-#: ../raster/r.in.bin/main.c:253 ../raster/r.in.bin/main.c:258
-#: ../raster/r.in.bin/main.c:287 ../raster/r.in.bin/main.c:348
-#: ../raster/r.resamp.rst/main.c:224 ../raster/r.resamp.rst/main.c:232
-#: ../raster/r.resamp.rst/main.c:240 ../raster/r.resamp.rst/main.c:248
-#: ../raster/r.resamp.rst/main.c:256 ../raster/r.slope.aspect/main.c:179
-#: ../raster/r.slope.aspect/main.c:189 ../raster/r.slope.aspect/main.c:247
-#: ../raster/r.slope.aspect/main.c:256 ../raster/r.slope.aspect/main.c:262
-#: ../raster/r.resamp.bspline/main.c:109 ../raster/r.resamp.bspline/main.c:117
-#: ../raster/r.resamp.bspline/main.c:126 ../raster/r.resamp.bspline/main.c:134
-#: ../raster/r.resamp.bspline/main.c:139 ../imagery/i.landsat.toar/main.c:152
-#: ../imagery/i.landsat.toar/main.c:160 ../imagery/i.landsat.toar/main.c:169
-#: ../imagery/i.landsat.toar/main.c:177 ../imagery/i.landsat.toar/main.c:185
-#: ../imagery/i.landsat.toar/main.c:195 ../imagery/i.cluster/main.c:102
-#: ../imagery/i.cluster/main.c:118 ../imagery/i.cluster/main.c:126
-#: ../imagery/i.cluster/main.c:135 ../imagery/i.cluster/main.c:143
-#: ../imagery/i.cluster/main.c:151 ../display/d.mon/main.c:69
-#: ../display/d.mon/main.c:76 ../display/d.mon/main.c:79
-#: ../display/d.mon/main.c:85 ../general/g.access/main.c:50
-#: ../general/g.access/main.c:58 ../general/g.mapset/main.c:57
-#: ../general/g.mapset/main.c:67 ../general/g.mapset/main.c:77
-#: ../vector/v.colors.out/main.c:68 ../vector/v.colors.out/main.c:73
-#: ../vector/v.db.connect/main.c:64 ../vector/v.db.connect/main.c:70
-#: ../vector/v.lidar.edgedetection/main.c:95
-#: ../vector/v.lidar.edgedetection/main.c:104
-#: ../vector/v.lidar.edgedetection/main.c:113
-#: ../vector/v.lidar.edgedetection/main.c:122
-#: ../vector/v.lidar.edgedetection/main.c:131
-#: ../vector/v.lidar.edgedetection/main.c:139
-#: ../vector/v.lidar.edgedetection/main.c:148 ../vector/v.vol.rst/main.c:277
-#: ../vector/v.vol.rst/main.c:285 ../vector/v.vol.rst/main.c:293
-#: ../vector/v.vol.rst/main.c:326 ../vector/v.vol.rst/main.c:335
-#: ../vector/v.vol.rst/main.c:344 ../vector/v.vol.rst/main.c:352
-#: ../vector/v.vol.rst/main.c:361 ../vector/v.vol.rst/main.c:369
-#: ../vector/v.surf.idw/main.c:111 ../vector/v.surf.idw/main.c:119
-#: ../vector/v.surf.bspline/main.c:112 ../vector/v.surf.bspline/main.c:142
-#: ../vector/v.surf.bspline/main.c:151 ../vector/v.surf.bspline/main.c:160
-#: ../vector/v.surf.bspline/main.c:168 ../vector/v.surf.bspline/main.c:172
-#: ../vector/v.surf.bspline/main.c:179
-msgid "Settings"
-msgstr ""
-#: ../raster/r.in.bin/main.c:257
-msgid "Byte Swap the Data During Import"
-msgstr ""
-#: ../raster/r.in.bin/main.c:262
-msgid "Get region info from GMT style header"
-msgstr ""
-#: ../raster/r.in.bin/main.c:263 ../raster/r.in.bin/main.c:303
-#: ../raster/r.in.bin/main.c:311 ../raster/r.in.bin/main.c:319
-#: ../raster/r.in.bin/main.c:327 ../raster/r.in.bin/main.c:334
-#: ../raster/r.in.bin/main.c:341 ../general/g.region/main.c:149
-#: ../general/g.region/main.c:208 ../general/g.region/main.c:217
-#: ../general/g.region/main.c:226 ../general/g.region/main.c:235
-#: ../general/g.region/main.c:244 ../general/g.region/main.c:253
-#: ../general/g.region/main.c:329 ../general/g.region/main.c:340
-msgid "Bounds"
-msgstr ""
-#: ../raster/r.in.bin/main.c:269
-msgid "Binary raster file to be imported"
-msgstr ""
-#: ../raster/r.in.bin/main.c:286 ../raster/r.out.bin/main.c:311
-#, fuzzy
-msgid "Number of bytes per cell"
-#: ../raster/r.in.bin/main.c:294 ../raster/r.out.bin/main.c:318
-#, fuzzy
-msgid "Output byte order"
-msgstr "पूर्ण तपशिल"
-#: ../raster/r.in.bin/main.c:302
-msgid "Northern limit of geographic region (outer edge)"
-msgstr ""
-#: ../raster/r.in.bin/main.c:310
-msgid "Southern limit of geographic region (outer edge)"
-msgstr ""
-#: ../raster/r.in.bin/main.c:318
-msgid "Eastern limit of geographic region (outer edge)"
-msgstr ""
-#: ../raster/r.in.bin/main.c:326
-msgid "Western limit of geographic region (outer edge)"
-msgstr ""
-#: ../raster/r.in.bin/main.c:333 ../general/g.pnmcat/main.c:141
-msgid "Number of rows"
-msgstr ""
-#: ../raster/r.in.bin/main.c:340 ../general/g.pnmcat/main.c:147
-msgid "Number of columns"
-msgstr ""
-#: ../raster/r.in.bin/main.c:347
-msgid "Set Value to NULL"
-msgstr ""
-#: ../raster/r.in.bin/main.c:368
-msgid "order= and -b are mutually exclusive"
-msgstr ""
-#: ../raster/r.in.bin/main.c:383
-msgid "-f and -d are mutually exclusive"
-msgstr ""
-#: ../raster/r.in.bin/main.c:387
-#, c-format
-msgid "-f incompatible with bytes=%d; must be 4 or 8"
-msgstr ""
-#: ../raster/r.in.bin/main.c:395
-#, c-format
-msgid "-d incompatible with bytes=%d; must be 8"
-msgstr ""
-#: ../raster/r.in.bin/main.c:402
-msgid "bytes= required for integer data"
-msgstr ""
-#: ../raster/r.in.bin/main.c:406
-msgid "Integer input doesn't support size=8 in this build"
-msgstr ""
-#: ../raster/r.in.bin/main.c:410
-msgid "bytes= must be 1, 2, 4 or 8"
-msgstr ""
-#: ../raster/r.in.bin/main.c:423
-#, fuzzy
-msgid "Either -h or rows= and cols= must be given"
-#: ../raster/r.in.bin/main.c:428
-#, fuzzy
-msgid "Either all or none of north=, south=, east= and west= must be given"
-#: ../raster/r.in.bin/main.c:435 ../display/d.grid/main.c:224
-#, c-format
-msgid "Illegal north coordinate <%s>"
-msgstr ""
-#: ../raster/r.in.bin/main.c:437
-#, fuzzy, c-format
-msgid "Illegal south coordinate <%s>"
-#: ../raster/r.in.bin/main.c:439 ../display/d.grid/main.c:218
-#, c-format
-msgid "Illegal east coordinate <%s>"
-msgstr ""
-#: ../raster/r.in.bin/main.c:441
-#, fuzzy, c-format
-msgid "Illegal west coordinate <%s>"
-#: ../raster/r.in.bin/main.c:447
-#, fuzzy, c-format
-msgid "Unable to open <%s>"
-#: ../raster/r.in.bin/main.c:466
-#, c-format
-msgid "East-West (ewres: %f) and North-South (nwres: %f) resolution differ significantly. Did you assign east= and west= correctly?"
-msgstr ""
-#: ../raster/r.in.bin/main.c:489
-msgid "File Size %"
-msgstr ""
-#: ../raster/r.in.bin/main.c:491
-msgid "Bytes do not match file size"
-msgstr ""
-#: ../raster/r.kappa/prt_hdr.c:18
-#, fuzzy, c-format
-msgid "Cannot open file <%s> to write header"
-#: ../raster/r.kappa/prt_label.c:17
-#, fuzzy, c-format
-msgid "Can't open file <%s> to write label"
-#: ../raster/r.kappa/main.c:71
-msgid "Calculate error matrix and kappa parameter for accuracy assessment of classification result."
-msgstr ""
-#: ../raster/r.kappa/main.c:77
-#, fuzzy
-msgid "Name of raster map containing classification result"
-#: ../raster/r.kappa/main.c:82
-#, fuzzy
-msgid "Name of raster map containing reference classes"
-#: ../raster/r.kappa/main.c:87
-#, fuzzy
-msgid "Name for output file containing error matrix and kappa"
-#: ../raster/r.kappa/main.c:93
-msgid "Title for error matrix and kappa"
-msgstr ""
-#: ../raster/r.kappa/main.c:98
-msgid "Wide report"
-msgstr ""
-#: ../raster/r.kappa/main.c:99
-msgid "132 columns (default: 80)"
-msgstr ""
-#: ../raster/r.kappa/main.c:103
-msgid "No header in the report"
-msgstr ""
-#: ../raster/r.kappa/stats.c:14 ../raster/r.report/stats.c:123
-msgid "Problem reading r.stats output"
-msgstr ""
-#: ../raster/r.kappa/calc_kappa.c:32
-#, c-format
-msgid "Cannot open file <%s> to write kappa and relevant parameters"
-msgstr ""
-#: ../raster/r.kappa/prt_mat.c:39
-#, c-format
-msgid "Cannot open file <%s> to write cats and counts (error matrix)"
-msgstr ""
-#: ../raster/r.out.png/main.c:116
-#, fuzzy
-msgid "Export a GRASS raster map as a non-georeferenced PNG image."
-#: ../raster/r.out.png/main.c:122
-msgid "Name for new PNG file (use out=- for stdout)"
-msgstr ""
-#: ../raster/r.out.png/main.c:130
-#, fuzzy
-msgid "Compression level of PNG file"
-#: ../raster/r.out.png/main.c:131
-msgid "(0 = none, 1 = fastest, 9 = best)"
-msgstr ""
-#: ../raster/r.out.png/main.c:138
-msgid "Make NULL cells transparent"
-msgstr ""
-#: ../raster/r.out.png/main.c:142
-#, fuzzy
-msgid "Output world file"
-#: ../raster/r.out.png/main.c:175 ../raster/r.out.tiff/main.c:163
-#: ../display/d.labels/color.c:68 ../display/d.rast/display.c:27
-#: ../display/d.graph/do_graph.c:105 ../display/d.graph/do_graph.c:355
-#: ../display/d.graph/do_graph.c:370 ../display/d.graph/main.c:109
-#, c-format
-msgid "[%s]: No such color"
-msgstr ""
-#: ../raster/r.out.png/main.c:257
-#, fuzzy, c-format
-msgid "Converting <%s>..."
-#: ../raster/r.out.png/main.c:272 ../raster/r.univar/r.univar_main.c:182
-#, fuzzy, c-format
-msgid "Raster <%s> type mismatch"
-msgstr "'%s'. ड्राइवर चालू होत नाही"
-#: ../raster/r.out.png/main.c:422
-#, fuzzy
-msgid "Writing world file"
-#: ../raster/r.out.png/main.c:425 ../raster/r.out.tiff/main.c:422
-msgid "Got null file name"
-msgstr ""
-#: ../raster/r.out.png/main.c:427 ../raster/r.out.tiff/main.c:424
-msgid "Got null region struct"
-msgstr ""
-#: ../raster/r.out.png/main.c:429
-#, fuzzy
-msgid "Unable to open world file for writing"
-#: ../raster/r.resamp.rst/main.c:151
-msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:162
-msgid "Desired east-west resolution"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:168
-msgid "Desired north-south resolution"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:175
-msgid "Output z-file (elevation) map"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:183
-msgid "Output slope map (or fx)"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:191
-msgid "Output aspect map (or fy)"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:199
-msgid "Output profile curvature map (or fxx)"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:207
-msgid "Output tangential curvature map (or fyy)"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:215
-msgid "Output mean curvature map (or fxy)"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:223
-msgid "Name of raster map containing smoothing"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:231
-msgid "Name of raster map to be used as mask"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:239
-msgid "Rows/columns overlap for segmentation"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:247
-msgid "Multiplier for z-values"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:255
-msgid "Spline tension value"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:262
-msgid "Anisotropy angle (in degrees)"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:263 ../raster/r.resamp.rst/main.c:270
-msgid "Anisotropy"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:269 ../vector/v.surf.rst/main.c:335
-msgid "Anisotropy scaling factor"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:274
-msgid "Use dnorm independent tension"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:279 ../vector/v.surf.rst/main.c:165
-msgid "Output partial derivatives instead of topographic parameters"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:313
-#, fuzzy
-msgid "Unable to read ew_res value"
-#: ../raster/r.resamp.rst/main.c:316
-#, fuzzy
-msgid "Unable to read ns_res value"
-#: ../raster/r.resamp.rst/main.c:319
-msgid "Invalid value for tension"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:322
-msgid "Invalid value for zmult"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:325
-msgid "Invalid value for overlap"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:329
-msgid "Invalid value for theta"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:333
-msgid "Invalid value for scalex"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:335
-msgid "When using anisotropy both theta and scalex must be specified"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:375
-#, c-format
-msgid "Map <%s> is the wrong resolution"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:383
-msgid "Smoothing values can not be negative or NULL"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:389
-msgid "Input map resolution differs from current region resolution!"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:407
-msgid "Processing all selected output files will require"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:411
-#, c-format
-msgid "%.2f GB of disk space for temp files."
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:414
-#, c-format
-msgid "%.2f MB of disk space for temp files."
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:417
-#, c-format
-msgid "%.2f KB of disk space for temp files."
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:420
-#, c-format
-msgid "%d bytes of disk space for temp files."
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:451
-msgid "Maximum value of a raster map is NULL."
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:479
-msgid "Temporarily changing the region to desired resolution ..."
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:484
-msgid "Changing back to the original region ..."
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:489 ../raster/r.resample/main.c:112
-msgid "Percent complete: "
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:501
-#, c-format
-msgid "dnorm in mainc after grid before out1= %f"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:505
-msgid "split_and_interpolate() failed"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:520
-#, c-format
-msgid "dnorm in mainc after grid before out2= %f"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:526
-#, fuzzy
-msgid "Unable to write raster maps -- try increasing cell size"
-#: ../raster/r.resamp.rst/main.c:558 ../vector/v.surf.rst/main.c:812
-#, fuzzy, c-format
-msgid "Error writing temporary file <%s>"
-#: ../raster/r.quantile/main.c:63
-msgid "Computing histogram"
-msgstr ""
-#: ../raster/r.quantile/main.c:258
-msgid "Compute quantiles using two passes."
-msgstr ""
-#: ../raster/r.quantile/main.c:285
-msgid "Generate recode rules based on quantile-defined intervals."
-msgstr ""
-#: ../raster/r.compress/main.c:63 ../imagery/i.group/main.c:53
-#: ../imagery/i.target/main.c:46 ../general/g.filename/main.c:40
-#: ../general/g.access/main.c:38 ../general/g.findfile/main.c:39
-#: ../general/g.mremove/main.c:62 ../general/g.mlist/main.c:63
-#: ../general/g.list/main.c:45 ../general/g.findetc/main.c:29
-#: ../general/g.remove/main.c:102 ../general/g.dirseps/main.c:35
-#: ../general/g.rename/main.c:44 ../general/g.copy/main.c:42
-#, fuzzy
-msgid "map management"
-msgstr "तक्त्याचे नाव"
-#: ../raster/r.compress/main.c:64
-msgid "Compresses and decompresses raster maps."
-msgstr ""
-#: ../raster/r.compress/main.c:72 ../display/d.what.rast/main.c:66
-msgid "Name of existing raster map(s)"
-msgstr ""
-#: ../raster/r.compress/main.c:76
-msgid "Uncompress the map"
-msgstr ""
-#: ../raster/r.compress/main.c:104
-#, c-format
-msgid "[%s] not found"
-msgstr ""
-#: ../raster/r.compress/main.c:110
-#, c-format
-msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't uncompress"
-msgstr ""
-#: ../raster/r.compress/main.c:112
-#, c-format
-msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't compress"
-msgstr ""
-#: ../raster/r.compress/main.c:117
-#, c-format
-msgid "[%s] is a GDAL-linked map - can't (un)compress"
-msgstr ""
-#: ../raster/r.compress/main.c:159
-#, c-format
-msgid "DONE: uncompressed file is %lu bytes smaller"
-msgstr ""
-#: ../raster/r.compress/main.c:160
-#, c-format
-msgid "DONE: compressed file is %lu bytes smaller"
-msgstr ""
-#: ../raster/r.compress/main.c:164
-#, c-format
-msgid "DONE: uncompressed file is %lu bytes bigger"
-msgstr ""
-#: ../raster/r.compress/main.c:165
-#, c-format
-msgid "DONE: compressed file is %lu bytes bigger"
-msgstr ""
-#: ../raster/r.compress/main.c:183
-#, c-format
-msgid "[%s] already uncompressed"
-msgstr ""
-#: ../raster/r.compress/main.c:187
-#, c-format
-msgid "[%s] already compressed"
-msgstr ""
-#: ../raster/r.compress/main.c:191
-#, c-format
-msgid ""
-"\n"
-"%sCOMPRESS [%s]"
-msgstr ""
-#: ../raster/r.support.stats/check.c:43
-#, c-format
-msgid "Updating statistics for [%s]..."
-msgstr ""
-#: ../raster/r.support.stats/check.c:56
-msgid "Updating histogram range..."
-msgstr ""
-#: ../raster/r.support.stats/check.c:88
-#, c-format
-msgid "Updating the number of categories for [%s]..."
-msgstr ""
-#: ../raster/r.support.stats/main.c:37
-msgid "Update raster map statistics"
-msgstr ""
-#: ../raster/r.support.stats/main.c:49
-#, fuzzy, c-format
-msgid "Statistics for <%s> updated"
-#: ../raster/r.spreadpath/main.c:93
-msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
-msgstr ""
-#: ../raster/r.spreadpath/main.c:102
-msgid "Name of raster map containing back-path easting information"
-msgstr ""
-#: ../raster/r.spreadpath/main.c:110
-#, fuzzy
-msgid "Name of raster map containing back-path northing information"
-#: ../raster/r.spreadpath/main.c:118
-msgid "The map E and N grid coordinates of starting points"
-msgstr ""
-#: ../raster/r.spreadpath/main.c:125
-msgid "Name of spread path raster map"
-msgstr ""
-#: ../raster/r.spreadpath/main.c:129
-msgid "Run verbosely"
-msgstr ""
-#: ../raster/r.random/random.c:42 ../raster/r.random/random.c:46
-#: ../raster/r.mapcalc/map3.c:513 ../imagery/i.landsat.acca/main.c:57
-#: ../imagery/i.landsat.acca/algorithm.c:380
-#: ../imagery/i.landsat.acca/tools.c:126 ../imagery/i.landsat.toar/main.c:350
-#: ../imagery/i.landsat.toar/main.c:478
-#, fuzzy, c-format
-msgid "Unable to open raster map <%s>"
-#: ../raster/r.random/random.c:99
-#, fuzzy
-msgid "Cannot create new table"
-#: ../raster/r.random/random.c:109
-#, fuzzy, c-format
-msgid "Writing raster map <%s> and vector map <%s> ..."
-#: ../raster/r.random/random.c:112
-#, fuzzy, c-format
-msgid "Writing raster map <%s> ..."
-#: ../raster/r.random/random.c:114
-#, fuzzy, c-format
-msgid "Writing vector map <%s> ..."
-#: ../raster/r.random/random.c:181 ../vector/v.net.centrality/main.c:69
-#: ../vector/v.net.distance/main.c:280 ../vector/v.net.flow/main.c:257
-#: ../vector/v.net.timetable/main.c:134 ../vector/v.net.timetable/main.c:156
-#: ../vector/v.net.allpairs/main.c:252 ../vector/v.net.components/main.c:38
-#: ../vector/v.net.path/path.c:313
-#, fuzzy, c-format
-msgid "Cannot insert new record: %s"
-#: ../raster/r.random/random.c:233
-#, c-format
-msgid "Only [%ld] random points created"
-msgstr ""
-#: ../raster/r.random/count.c:68
-#, fuzzy
-msgid "Collecting Stats..."
-#: ../raster/r.random/count.c:123
-msgid "Programmer error in get_stats/switch"
-msgstr ""
-#: ../raster/r.random/main.c:55
-#, fuzzy
-msgid "Creates a raster map layer and vector point map containing randomly located points."
-#: ../raster/r.random/main.c:59 ../raster/r.out.bin/main.c:290
-#: ../imagery/i.zc/main.c:65
-msgid "Name of input raster map"
-msgstr ""
-#: ../raster/r.random/main.c:64
-#, fuzzy
-msgid "Name of cover raster map"
-#: ../raster/r.random/main.c:71
-msgid "The number of points to allocate"
-msgstr ""
-#: ../raster/r.random/main.c:83
-msgid "Generate points also for NULL category"
-msgstr ""
-#: ../raster/r.random/main.c:88
-msgid "Report information about input raster and exit"
-msgstr ""
-#: ../raster/r.random/main.c:92
-msgid "Generate vector points as 3D points"
-msgstr ""
-#: ../raster/r.random/main.c:96 ../vector/v.in.ascii/main.c:160
-msgid "Do not build topology in points mode"
-msgstr ""
-#: ../raster/r.random/main.c:97 ../vector/v.out.ascii/args.c:36
-#: ../vector/v.out.ascii/args.c:58 ../vector/v.out.ascii/args.c:68
-#: ../vector/v.out.ascii/args.c:77 ../vector/v.out.ascii/args.c:83
-#: ../vector/v.in.ascii/main.c:83 ../vector/v.in.ascii/main.c:90
-#: ../vector/v.in.ascii/main.c:102 ../vector/v.in.ascii/main.c:112
-#: ../vector/v.in.ascii/main.c:122 ../vector/v.in.ascii/main.c:132
-#: ../vector/v.in.ascii/main.c:156 ../vector/v.in.ascii/main.c:161
-#: ../vector/v.in.ascii/main.c:167
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:15
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:18
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:20
-#, fuzzy
-msgid "Points"
-#: ../raster/r.random/main.c:133
-#, c-format
-msgid "Note: one (or both) of %s and %s must be specified"
-msgstr ""
-#: ../raster/r.random/main.c:141
-#, c-format
-msgid "<%s=%s> invalid percentage"
-msgstr ""
-#: ../raster/r.random/main.c:148
-#, c-format
-msgid "<%s=%s> invalid number of points"
-msgstr ""
-#: ../raster/r.random/main.c:161
-#, fuzzy, c-format
-msgid "There aren't [%ld] cells in the current region"
-#: ../raster/r.random/main.c:164
-#, fuzzy, c-format
-msgid "There aren't [%ld] non-NULL cells in the current region"
-#: ../raster/r.random/main.c:169
-#, fuzzy
-msgid "There are no valid locations in the current region"
-#: ../raster/r.grow.distance/main.c:152
-#, fuzzy
-msgid "Generates a raster map of distance to features in input raster map."
-#: ../raster/r.grow.distance/main.c:159
-#, fuzzy
-msgid "Name for distance output raster map"
-#: ../raster/r.grow.distance/main.c:165
-#, fuzzy
-msgid "Name for value output raster map"
-#: ../raster/r.grow.distance/main.c:172 ../raster/r.grow/main.c:142
-#: ../locale/scriptstrings/r.grow_to_translate.c:5
-msgid "Metric"
-msgstr ""
-#: ../raster/r.grow.distance/main.c:178
-msgid "Output distances in meters instead of map units"
-msgstr ""
-#: ../raster/r.grow.distance/main.c:188
-#, fuzzy
-msgid "At least one of distance= and value= must be given"
-#: ../raster/r.grow.distance/main.c:203
-msgid "metric=geodesic is only valid for lat/lon"
-msgstr ""
-#: ../raster/r.grow.distance/main.c:209
-#, fuzzy, c-format
-msgid "Unknown metric: '%s'"
-#: ../raster/r.grow.distance/main.c:225
-#, fuzzy, c-format
-msgid "Unable to create temporary file <%s>"
-#: ../raster/r.grow.distance/main.c:300
-#, fuzzy
-msgid "Writing output raster maps..."
-#: ../raster/r.report/main.c:68
-#, fuzzy
-msgid "Reports statistics for raster maps."
-#: ../raster/r.report/parse.c:38
-msgid "Raster map(s) to report on"
-msgstr ""
-#: ../raster/r.report/parse.c:47
-msgid "mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;percent cover"
-msgstr ""
-#: ../raster/r.report/parse.c:50 ../raster/r.report/parse.c:86
-#: ../ps/ps.map/main.c:101 ../ps/ps.map/main.c:114 ../ps/ps.map/main.c:136
-#, fuzzy
-msgid "Output settings"
-#: ../raster/r.report/parse.c:58
-msgid "Character representing no data cell value"
-msgstr ""
-#: ../raster/r.report/parse.c:59 ../raster/r.report/parse.c:68
-#: ../raster/r.report/parse.c:77 ../raster/r.report/parse.c:101
-#: ../raster/r.report/parse.c:106 ../raster/r.report/parse.c:111
-msgid "Formatting"
-msgstr ""
-#: ../raster/r.report/parse.c:65
-#, c-format
-msgid "Page length (default: %d lines)"
-msgstr ""
-#: ../raster/r.report/parse.c:74
-#, c-format
-msgid "Page width (default: %d characters)"
-msgstr ""
-#: ../raster/r.report/parse.c:83
-#, fuzzy
-msgid "Name for output file to hold the report"
-#: ../raster/r.report/parse.c:85
-#, fuzzy
-msgid "If no output given report is printed to standard output"
-#: ../raster/r.report/parse.c:95 ../raster/r.stats/main.c:136
-msgid "Number of fp subranges to collect stats from"
-msgstr ""
-#: ../raster/r.report/parse.c:96 ../raster/r.report/parse.c:124
-#: ../raster/r.report/parse.c:130
-msgid "FP maps"
-msgstr ""
-#: ../raster/r.report/parse.c:100
-msgid "Suppress page headers"
-msgstr ""
-#: ../raster/r.report/parse.c:105
-msgid "Use formfeeds between pages"
-msgstr ""
-#: ../raster/r.report/parse.c:110
-msgid "Scientific format"
-msgstr ""
-#: ../raster/r.report/parse.c:115
-msgid "Filter out all no data cells"
-msgstr ""
-#: ../raster/r.report/parse.c:119
-msgid "Filter out cells where all maps have no data"
-msgstr ""
-#: ../raster/r.report/parse.c:123 ../raster/r.stats/main.c:196
-msgid "Report for cats fp ranges (fp maps only)"
-msgstr ""
-#: ../raster/r.report/parse.c:129 ../raster/r.stats/main.c:200
-msgid "Read fp map as integer (use map's quant rules)"
-msgstr ""
-#: ../raster/r.report/parse.c:172
-msgid "nsteps has to be > 0; using nsteps=255"
-msgstr ""
-#: ../raster/r.report/parse.c:179
-msgid "Illegal page length"
-msgstr ""
-#: ../raster/r.report/parse.c:186
-msgid "Illegal page width"
-msgstr ""
-#: ../raster/r.report/parse.c:225
-#, c-format
-msgid "Only %d unit%s allowed"
-msgstr ""
-#: ../raster/r.report/parse.c:258
-#, fuzzy, c-format
-msgid "Unable to read fp range for raster map <%s>"
-#: ../raster/r.report/stats.c:88
-#, fuzzy, c-format
-msgid "Unable to open result file <%s>"
-#: ../raster/r.out.pov/main.c:124
-#, fuzzy
-msgid "Converts a raster map layer into a height-field file for POV-Ray."
-#: ../raster/r.out.pov/main.c:131
-msgid "Name of output povray file (TGA height field file)"
-msgstr ""
-#: ../raster/r.out.pov/main.c:138
-msgid "Height-field type (0=actual heights 1=normalized)"
-msgstr ""
-#: ../raster/r.out.pov/main.c:144
-msgid "Elevation bias"
-msgstr ""
-#: ../raster/r.out.pov/main.c:170
-#, c-format
-msgid "Invalid output filename <%s>"
-msgstr ""
-#: ../raster/r.out.pov/main.c:180
-#, c-format
-msgid "Raster map is too big! Exceeds %d columns or %d rows"
-msgstr ""
-#: ../raster/r.out.pov/main.c:201
-msgid "Negative elevation values in input"
-msgstr ""
-#: ../raster/r.water.outlet/main.c:64
-msgid "Creates watershed basins."
-msgstr ""
-#: ../raster/r.water.outlet/main.c:78
-#, fuzzy
-msgid "Easting grid coordinates"
-#: ../raster/r.water.outlet/main.c:86
-#, fuzzy
-msgid "Northing grid coordinates"
-#: ../raster/r.water.outlet/main.c:97
-#, c-format
-msgid "Illegal east coordinate <%s>\n"
-msgstr ""
-#: ../raster/r.water.outlet/main.c:102
-#, c-format
-msgid "Illegal north coordinate <%s>\n"
-msgstr ""
-#: ../raster/r.water.outlet/main.c:109
-#, c-format
-msgid ""
-"Warning, ignoring point outside window: \n"
-"    %.4f,%.4f\n"
-msgstr ""
-#: ../raster/r.carve/raster.c:13 ../raster/r.texture/main.c:292
-#: ../imagery/i.zc/main.c:152
-#, fuzzy
-msgid "Reading raster map..."
-#: ../raster/r.carve/raster.c:33 ../raster/r.in.poly/poly2rast.c:77
-#: ../vector/v.to.rast/vect2rast.c:175
-#, fuzzy
-msgid "Writing raster map..."
-#: ../raster/r.carve/enforce_ds.c:82
-msgid "Processing lines... "
-msgstr ""
-#: ../raster/r.carve/enforce_ds.c:174
-msgid "Vect runs out of region and re-enters - this case is not yet implemented."
-msgstr ""
-#: ../raster/r.carve/lobf.c:74
-msgid "trying to divide by zero...no unique solution for system...skipping..."
-msgstr ""
-#: ../raster/r.carve/main.c:76
-msgid "Generates stream channels."
-msgstr ""
-#: ../raster/r.carve/main.c:77
-msgid "Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
-msgstr ""
-#: ../raster/r.carve/main.c:82
-msgid "Name of input raster elevation map"
-msgstr ""
-#: ../raster/r.carve/main.c:87
-#, fuzzy
-msgid "Name of input vector map containing stream(s)"
-#: ../raster/r.carve/main.c:95
-#, fuzzy
-msgid "Name for output vector map for adjusted stream points"
-#: ../raster/r.carve/main.c:100
-msgid "Stream width (in meters)"
-msgstr ""
-#: ../raster/r.carve/main.c:101
-msgid "Default is raster cell width"
-msgstr ""
-#: ../raster/r.carve/main.c:106
-msgid "Additional stream depth (in meters)"
-msgstr ""
-#: ../raster/r.carve/main.c:110
-msgid "No flat areas allowed in flow direction"
-msgstr ""
-#: ../raster/r.carve/main.c:134
-#, c-format
-msgid "Invalid width value '%s' - using default."
-msgstr ""
-#: ../raster/r.carve/main.c:148
-#, c-format
-msgid "Invalid depth value '%s' - using default."
-msgstr ""
-#: ../raster/r.carve/main.c:212
-msgid "lat/lon projection not supported at this time."
-msgstr ""
-#: ../raster/r.out.tiff/main.c:94
-msgid "Exports a GRASS raster map to a 8/24bit TIFF image file."
-msgstr ""
-#: ../raster/r.out.tiff/main.c:103
-#, fuzzy
-msgid "Name for new TIFF file"
-#: ../raster/r.out.tiff/main.c:110
-msgid "TIFF file compression"
-msgstr ""
-#: ../raster/r.out.tiff/main.c:115
-msgid "TIFF Palette output (8bit instead of 24bit)."
-msgstr ""
-#: ../raster/r.out.tiff/main.c:124
-msgid "Output TIFF world file"
-msgstr ""
-#: ../raster/r.out.tiff/main.c:128
-msgid "Output Tiled TIFF"
-msgstr ""
-#: ../raster/r.out.tiff/main.c:176
-#, c-format
-msgid "Raster map <%s>> is a floating point map. Fractional values will be rounded to integer"
-msgstr ""
-#: ../raster/r.out.tiff/main.c:182
-msgid "Color map for palette must have less than 256 colors for the available range of data"
-msgstr ""
-#: ../raster/r.out.tiff/main.c:196
-#, fuzzy, c-format
-msgid "Unable to open TIFF file <%s>"
-#: ../raster/r.out.tiff/main.c:419
-msgid "Writing TIFF World file"
-msgstr ""
-#: ../raster/r.out.tiff/main.c:427
-#, fuzzy
-msgid "Unable to open TIFF world file for writing"
-#: ../raster/r.null/main.c:60
-#, fuzzy
-msgid "null data"
-#: ../raster/r.null/main.c:61
-#, fuzzy
-msgid "Manages NULL-values of given raster map."
-#: ../raster/r.null/main.c:64
-#, fuzzy
-msgid "Name of raster map for which to edit null values"
-#: ../raster/r.null/main.c:73 ../raster/r.null/main.c:81
-#: ../general/g.proj/main.c:178
-msgid "Modify"
-msgstr ""
-#: ../raster/r.null/main.c:85
-msgid "Only do the work if the map is floating-point"
-msgstr ""
-#: ../raster/r.null/main.c:86 ../raster/r.null/main.c:91
-#: ../raster/r.null/main.c:97
-msgid "Check"
-msgstr ""
-#: ../raster/r.null/main.c:90
-msgid "Only do the work if the map is integer"
-msgstr ""
-#: ../raster/r.null/main.c:96
-msgid "Only do the work if the map doesn't have a NULL-value bitmap file"
-msgstr ""
-#: ../raster/r.null/main.c:102
-msgid "Create NULL-value bitmap file validating all data cells"
-msgstr ""
-#: ../raster/r.null/main.c:106
-msgid "Remove NULL-value bitmap file"
-msgstr ""
-#: ../raster/r.null/main.c:125
-#, c-format
-msgid "Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy with r.mapcalc. Exiting."
-msgstr ""
-#: ../raster/r.null/main.c:131
-#, fuzzy, c-format
-msgid "Raster map <%s> is not in your mapset <%s>"
-#: ../raster/r.null/main.c:138
-#, c-format
-msgid "%s is illegal entry for null"
-msgstr ""
-#: ../raster/r.null/main.c:145
-#, fuzzy, c-format
-msgid "Raster map <%s> already has a null bitmap file"
-#: ../raster/r.null/main.c:149
-#, fuzzy, c-format
-msgid "<%s> is integer raster map (CELL)"
-#: ../raster/r.null/main.c:153
-#, fuzzy, c-format
-msgid "<%s> is integer raster map (CELL). Using null=%d."
-#: ../raster/r.null/main.c:159
-#, fuzzy, c-format
-msgid "<%s> is floating pointing raster map"
-#: ../raster/r.null/main.c:175
-#, fuzzy, c-format
-msgid "Writing new null file for raster map <%s>..."
-#: ../raster/r.null/main.c:185 ../raster/r.null/main.c:198
-#, fuzzy, c-format
-msgid "Raster map <%s> modified."
-#: ../raster/r.null/main.c:192
-#, fuzzy, c-format
-msgid "Removing null file for raster map <%s>..."
-#: ../raster/r.null/main.c:262
-#, fuzzy, c-format
-msgid "%s: %s: illegal value spec"
-#: ../raster/r.null/main.c:264
-#, c-format
-msgid "%s: illegal value spec"
-msgstr ""
-#: ../raster/r.null/main.c:325
-#, fuzzy, c-format
-msgid "Writing new data for raster map <%s>..."
-#: ../raster/r.basins.fill/read_map.c:39
-#, fuzzy, c-format
-msgid "Reading <%s> ... "
-#: ../raster/r.basins.fill/main.c:57
-#, fuzzy
-msgid "Generates watershed subbasins raster map."
-#: ../raster/r.basins.fill/main.c:61
-#, fuzzy
-msgid "Name of input coded stream network raster map"
-#: ../raster/r.basins.fill/main.c:65
-#, fuzzy
-msgid "Name of input thinned ridge network raster map"
-#: ../raster/r.basins.fill/main.c:73
-msgid "Number of passes through the dataset"
-msgstr ""
-#: ../raster/r.basins.fill/main.c:121
-msgid "Forward sweep complete"
-msgstr ""
-#: ../raster/r.basins.fill/main.c:138
-msgid "Reverse sweep complete"
-msgstr ""
-#: ../raster/r.surf.idw2/main.c:64 ../raster/r.surf.idw/main.c:106
-#: ../vector/v.surf.idw/main.c:88
-msgid "IDW"
-msgstr ""
-#: ../raster/r.surf.idw2/main.c:65
-msgid "Surface generation program."
-msgstr ""
-#: ../raster/r.surf.idw2/main.c:76 ../raster/r.surf.idw/main.c:118
-#: ../vector/v.surf.idw/main.c:109
-msgid "Number of interpolation points"
-msgstr ""
-#: ../raster/r.surf.idw2/main.c:84
-msgid "Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
-msgstr ""
-#: ../raster/r.surf.idw2/main.c:88
-#, c-format
-msgid "%s=%s - illegal number of interpolation points"
-msgstr ""
-#: ../raster/r.surf.idw2/main.c:97
-#, c-format
-msgid "%s: no data points found"
-msgstr ""
-#: ../raster/r.surf.idw2/main.c:112
-#, fuzzy, c-format
-msgid "Interpolating raster map <%s>... %d rows... "
-#: ../raster/r.stats/main.c:105
-msgid "Generates area statistics for raster map layers."
-msgstr ""
-#: ../raster/r.stats/main.c:114 ../raster/r.univar/r.univar_main.c:41
-#: ../raster/r.univar/r3.univar_main.c:42 ../vector/v.db.select/main.c:85
-#: ../db/db.select/main.c:237
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
-msgid "Name for output file (if omitted or \"-\" output to stdout)"
-msgstr ""
-#: ../raster/r.stats/main.c:127 ../raster/r.describe/main.c:68
-msgid "String representing no data cell value"
-msgstr ""
-#: ../raster/r.stats/main.c:142
-msgid "One cell (range) per line"
-msgstr ""
-#: ../raster/r.stats/main.c:146
-msgid "Print averaged values instead of intervals"
-msgstr ""
-#: ../raster/r.stats/main.c:151
-msgid "Print area totals"
-msgstr ""
-#: ../raster/r.stats/main.c:156
-msgid "Print cell counts"
-msgstr ""
-#: ../raster/r.stats/main.c:162
-msgid "Print APPROXIMATE percents (total percent may not be 100%)"
-msgstr ""
-#: ../raster/r.stats/main.c:167
-msgid "Print category labels"
-msgstr ""
-#: ../raster/r.stats/main.c:172
-msgid "Print grid coordinates (east and north)"
-msgstr ""
-#: ../raster/r.stats/main.c:177
-msgid "Print x and y (column and row)"
-msgstr ""
-#: ../raster/r.stats/main.c:182
-msgid "Print raw indexes of fp ranges (fp maps only)"
-msgstr ""
-#: ../raster/r.stats/main.c:187 ../raster/r.describe/main.c:90
-msgid "Suppress reporting of any NULLs"
-msgstr ""
-#: ../raster/r.stats/main.c:192
-msgid "Suppress reporting of NULLs when all values are NULL"
-msgstr ""
-#: ../raster/r.stats/main.c:208 ../raster/r.univar/r.univar_main.c:110
-#: ../raster/r.univar/r3.univar_main.c:123
-#: ../raster/r.regression.line/main.c:76 ../vector/v.db.select/main.c:110
-#: ../db/db.select/main.c:129
-#, fuzzy, c-format
-msgid "Unable to open file <%s> for writing"
-#: ../raster/r.stats/main.c:214
-#, c-format
-msgid "'%s' must be greater than zero; using %s=255"
-msgstr ""
-#: ../raster/r.stats/main.c:279
-#, c-format
-msgid "Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option will be ignored."
-msgstr ""
-#: ../raster/r.stats/main.c:295
-#, c-format
-msgid "Cats for raster map <%s> are either missing or have no explicit labels. Using %s=%d."
-msgstr ""
-#: ../raster/r.stats/main.c:301
-#, c-format
-msgid "Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' option"
-msgstr ""
-#: ../raster/r.region/main.c:54
-msgid "Sets the boundary definitions for a raster map."
-msgstr ""
-#: ../raster/r.region/main.c:60
-msgid "Set from current region"
-msgstr ""
-#: ../raster/r.region/main.c:64 ../general/g.region/main.c:72
-msgid "Set from default region"
-msgstr ""
-#: ../raster/r.region/main.c:75
-msgid "Raster map to change"
-msgstr ""
-#: ../raster/r.region/main.c:83
-msgid "Set region from named region"
-msgstr ""
-#: ../raster/r.region/main.c:90 ../general/g.region/main.c:172
-msgid "Set region to match this raster map"
-msgstr ""
-#: ../raster/r.region/main.c:96 ../general/g.region/main.c:188
-msgid "Set region to match this vector map"
-msgstr ""
-#: ../raster/r.region/main.c:104 ../general/g.region/main.c:197
-msgid "Set region to match this 3dview file"
-msgstr ""
-#: ../raster/r.region/main.c:113 ../general/g.region/main.c:207
-msgid "Value for the northern edge"
-msgstr ""
-#: ../raster/r.region/main.c:121 ../general/g.region/main.c:216
-msgid "Value for the southern edge"
-msgstr ""
-#: ../raster/r.region/main.c:129 ../general/g.region/main.c:225
-msgid "Value for the eastern edge"
-msgstr ""
-#: ../raster/r.region/main.c:137 ../general/g.region/main.c:234
-msgid "Value for the western edge"
-msgstr ""
-#: ../raster/r.region/main.c:143
-msgid "Raster map to align to"
-msgstr ""
-#: ../raster/r.region/main.c:174
-#, fuzzy, c-format
-msgid "Unable to open 3dview file <%s>"
-#: ../raster/r.region/main.c:178
-#, fuzzy, c-format
-msgid "Unable to read 3dview file <%s>"
-#: ../raster/r.region/main.c:180
-#, fuzzy, c-format
-msgid "Old 3dview file. Region <%s> not found"
-#: ../raster/r.univar/r.univar_main.c:36
-msgid "Raster map used for zoning, must be of type CELL"
-msgstr ""
-#: ../raster/r.univar/r.univar_main.c:51
-#: ../raster/r.univar/r3.univar_main.c:52 ../vector/v.univar/main.c:89
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:9
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
-msgid "Percentile to calculate (requires extended statistics flag)"
-msgstr ""
-#: ../raster/r.univar/r.univar_main.c:54
-#: ../raster/r.univar/r3.univar_main.c:55
-msgid "Special characters: space, comma, tab"
-msgstr ""
-#: ../raster/r.univar/r.univar_main.c:59
-#: ../raster/r.univar/r3.univar_main.c:60 ../vector/v.univar/main.c:93
-#: ../vector/v.what/main.c:95
-msgid "Print the stats in shell script style"
-msgstr ""
-#: ../raster/r.univar/r.univar_main.c:63
-#: ../raster/r.univar/r3.univar_main.c:64 ../vector/v.univar/main.c:97
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:6
-#: ../locale/scriptstrings/tr.univar_to_translate.c:7
-msgid "Calculate extended statistics"
-msgstr ""
-#: ../raster/r.univar/r.univar_main.c:67
-#: ../raster/r.univar/r3.univar_main.c:68
-msgid "Table output format instead of standard output format"
-msgstr ""
-#: ../raster/r.univar/r.univar_main.c:99
-msgid "Calculates univariate statistics from the non-null cells of a raster map."
-msgstr ""
-#: ../raster/r.univar/r3.univar_main.c:37
-msgid "3D Raster map used for zoning, must be of type CELL"
-msgstr ""
-#: ../raster/r.univar/r3.univar_main.c:102
-#, fuzzy
-msgid "Calculates univariate statistics from the non-null 3d cells of a raster3d map."
-#: ../raster/r.describe/main.c:57
-msgid "Prints terse list of category values found in a raster map layer."
-msgstr ""
-#: ../raster/r.describe/main.c:76
-#, fuzzy
-msgid "Number of quantization steps"
-#: ../raster/r.describe/main.c:82
-msgid "Print the output one value per line"
-msgstr ""
-#: ../raster/r.describe/main.c:86
-msgid "Only print the range of the data"
-msgstr ""
-#: ../raster/r.describe/main.c:94
-msgid "Use the current region"
-msgstr ""
-#: ../raster/r.describe/main.c:98
-msgid "Read fp map as integer"
-msgstr ""
-#: ../raster/r.describe/main.c:110
-#, c-format
-msgid "%s = %s -- must be greater than zero"
-msgstr ""
-#: ../raster/r.describe/describe.c:94
-#, fuzzy, c-format
-msgid "Reading <%s> ..."
-#: ../raster/r.out.mat/main.c:64
-msgid "Exports a GRASS raster to a binary MAT-File."
-msgstr ""
-#: ../raster/r.out.mat/main.c:75
-msgid "Name for the output binary MAT-File"
-msgstr ""
-#: ../raster/r.out.mat/main.c:115
-#, c-format
-msgid "Exporting <%s>"
-msgstr ""
-#: ../raster/r.out.mat/main.c:175
-msgid "Using the Current Region settings:"
-msgstr ""
-#: ../raster/r.out.mat/main.c:176 ../raster/r.in.mat/main.c:397
-#, c-format
-msgid "northern edge=%f"
-msgstr ""
-#: ../raster/r.out.mat/main.c:177 ../raster/r.in.mat/main.c:398
-#, c-format
-msgid "southern edge=%f"
-msgstr ""
-#: ../raster/r.out.mat/main.c:178 ../raster/r.in.mat/main.c:399
-#, c-format
-msgid "eastern edge=%f"
-msgstr ""
-#: ../raster/r.out.mat/main.c:179 ../raster/r.in.mat/main.c:400
-#, c-format
-msgid "western edge=%f"
-msgstr ""
-#: ../raster/r.out.mat/main.c:180 ../raster/r.in.mat/main.c:401
-#, c-format
-msgid "nsres=%f"
-msgstr ""
-#: ../raster/r.out.mat/main.c:181 ../raster/r.in.mat/main.c:402
-#, c-format
-msgid "ewres=%f"
-msgstr ""
-#: ../raster/r.out.mat/main.c:182 ../raster/r.in.mat/main.c:403
-#, c-format
-msgid "rows=%d"
-msgstr ""
-#: ../raster/r.out.mat/main.c:183 ../raster/r.in.mat/main.c:404
-#, c-format
-msgid "cols=%d"
-msgstr ""
-#: ../raster/r.out.mat/main.c:250
-msgid "Exporting raster as integer values"
-msgstr ""
-#: ../raster/r.out.mat/main.c:255
-msgid "Exporting raster as floating point values"
-msgstr ""
-#: ../raster/r.out.mat/main.c:260
-msgid "Exporting raster as double FP values"
-msgstr ""
-#: ../raster/r.out.mat/main.c:303
-#, fuzzy
-msgid "Reading in map ... "
-#: ../raster/r.out.mat/main.c:316
-#, fuzzy
-msgid "Writing out map..."
-#: ../raster/r.out.mat/main.c:376
-#, fuzzy, c-format
-msgid "%ld bytes written to '%s'"
-#: ../raster/r.in.lidar/main.c:165
-msgid "Create a raster map from LAS LiDAR points using univariate statistics."
-msgstr ""
-#: ../raster/r.in.lidar/main.c:169
-#, fuzzy
-msgid "LiDAR LAS input file"
-#: ../raster/r.in.lidar/main.c:235 ../vector/v.in.ogr/main.c:249
-#: ../vector/v.in.lidar/main.c:203
-msgid "Override dataset projection (use location's projection)"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:264 ../vector/v.in.lidar/main.c:239
-#, c-format
-msgid "Input file <%s> is not a LAS LiDAR point cloud"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:282 ../vector/v.in.ogr/main.c:538
-#: ../vector/v.in.lidar/main.c:366
-msgid "Unable to convert input map projection information to GRASS format for checking"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:312 ../vector/v.in.ogr/main.c:568
-#: ../vector/v.in.lidar/main.c:396
-msgid "GRASS LOCATION PROJ_INFO is:\n"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:372 ../vector/v.in.ogr/main.c:628
-#: ../vector/v.in.lidar/main.c:456
-#, c-format
-msgid ""
-"\n"
-"You can use the -o flag to %s to override this projection check.\n"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:375 ../vector/v.in.ogr/main.c:631
-#: ../vector/v.in.lidar/main.c:459
-msgid "Consider generating a new location with 'location' parameter from input data set.\n"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:597
-#, fuzzy
-msgid "Could not rewind input file"
-#: ../raster/r.sunmask/g_solposition.c:66
-msgid "Unable to calculate sun position in un-projected locations. Specify sunposition directly."
-msgstr ""
-#: ../raster/r.sunmask/g_solposition.c:88
-#, c-format
-msgid "Specified point %f, %f outside of current region, is that intended? Anyway, it will be used."
-msgstr ""
-#: ../raster/r.sunmask/g_solposition.c:98
-#, fuzzy
-msgid "Unable to get projection info of current location"
-#: ../raster/r.sunmask/g_solposition.c:101
-#, fuzzy
-msgid "Unable to get projection units of current location"
-#: ../raster/r.sunmask/g_solposition.c:104
-#, fuzzy
-msgid "Unable to get projection key values of current location"
-msgstr "डेटाबेसची यादी दाखवता येणार नाही"
-#: ../raster/r.sunmask/g_solposition.c:127 ../raster/r.proj/main.c:360
-#: ../raster/r.proj/main.c:362 ../general/g.region/printwindow.c:281
-#: ../general/g.region/printwindow.c:289 ../general/g.region/printwindow.c:297
-#: ../general/g.region/printwindow.c:305 ../general/g.region/printwindow.c:534
-#: ../general/g.region/printwindow.c:542 ../general/g.region/printwindow.c:550
-#: ../general/g.region/printwindow.c:558 ../general/g.region/printwindow.c:676
-#: ../general/g.region/printwindow.c:684 ../general/g.region/printwindow.c:692
-#: ../general/g.region/printwindow.c:700
-msgid "Error in pj_do_proj (projection of input coordinate pair)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:117 ../raster/r.horizon/main.c:178
-msgid "sun position"
-msgstr ""
-#: ../raster/r.sunmask/main.c:118
-#, fuzzy
-msgid "Calculates cast shadow areas from sun position and elevation raster map."
-#: ../raster/r.sunmask/main.c:119
-msgid "Either exact sun position (A) is specified, or date/time to calculate the sun position (B) by r.sunmask itself."
-msgstr ""
-#: ../raster/r.sunmask/main.c:133
-msgid "Altitude of the sun above horizon, degrees (A)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:134 ../raster/r.sunmask/main.c:143
-#: ../raster/r.sunmask/main.c:210 ../raster/r.sunmask/main.c:220
-msgid "Position"
-msgstr ""
-#: ../raster/r.sunmask/main.c:142
-msgid "Azimuth of the sun from the north, degrees (A)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:149
-msgid "Year (B)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:151 ../raster/r.sunmask/main.c:159
-#: ../raster/r.sunmask/main.c:167 ../raster/r.sunmask/main.c:175
-#: ../raster/r.sunmask/main.c:183 ../raster/r.sunmask/main.c:191
-#: ../raster/r.sunmask/main.c:200
-msgid "Time"
-msgstr ""
-#: ../raster/r.sunmask/main.c:157
-msgid "Month (B)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:165
-msgid "Day (B)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:173
-msgid "Hour (B)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:181
-msgid "Minutes (B)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:189
-msgid "Seconds (B)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:198
-msgid "Timezone"
-msgstr ""
-#: ../raster/r.sunmask/main.c:199
-msgid "East positive, offset from GMT, also use to adjust daylight savings"
-msgstr ""
-#: ../raster/r.sunmask/main.c:208
-msgid "Easting coordinate (point of interest)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:209 ../raster/r.sunmask/main.c:219
-msgid "Default: map center"
-msgstr ""
-#: ../raster/r.sunmask/main.c:218
-msgid "Northing coordinate (point of interest)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:224
-msgid "Don't ignore zero elevation"
-msgstr ""
-#: ../raster/r.sunmask/main.c:228
-msgid "Calculate sun position only and exit"
-msgstr ""
-#: ../raster/r.sunmask/main.c:234
-msgid "Print the sun position output in shell script style"
-msgstr ""
-#: ../raster/r.sunmask/main.c:248
-#, fuzzy, c-format
-msgid "Using map center coordinates: %f %f"
-#: ../raster/r.sunmask/main.c:255
-#, fuzzy
-msgid "Empty east coordinate specified"
-#: ../raster/r.sunmask/main.c:257
-msgid "Empty north coordinate specified"
-msgstr ""
-#: ../raster/r.sunmask/main.c:276
-msgid "Either define sun position or location/date/time parameters"
-msgstr ""
-#: ../raster/r.sunmask/main.c:279
-msgid "Neither sun position nor east/north, date/time/timezone definition are complete"
-msgstr ""
-#: ../raster/r.sunmask/main.c:283
-#, c-format
-msgid "Calculating sun position... (using solpos (V. %s) from NREL)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:288
-msgid "Using user defined sun azimuth, altitude settings (ignoring eventual other values)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:396
-#, fuzzy
-msgid "Please correct settings"
-#: ../raster/r.sunmask/main.c:410
-#, c-format
-msgid "Time (%02i:%02i:%02i) is before sunrise (%02d:%02d:%02d)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:414
-#, c-format
-msgid "Time (%02i:%02i:%02i) is before sunrise"
-msgstr ""
-#: ../raster/r.sunmask/main.c:417 ../raster/r.sunmask/main.c:427
-msgid "Nothing to calculate. Please verify settings."
-msgstr ""
-#: ../raster/r.sunmask/main.c:421
-#, c-format
-msgid "Time (%02i:%02i:%02i) is after sunset (%02d:%02d:%02d)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:425
-#, c-format
-msgid "Time (%02i:%02i:%02i) is after sunset"
-msgstr ""
-#: ../raster/r.sunmask/main.c:436
-msgid "You already know the sun position"
-msgstr ""
-#: ../raster/r.sunmask/main.c:441
-#, fuzzy, c-format
-msgid "Option <%s> required"
-#: ../raster/r.sunmask/main.c:453
-#, fuzzy, c-format
-msgid "Unable to open range file for raster map <%s>"
-#: ../raster/r.sunmask/main.c:469
-msgid "Calculating shadows from DEM..."
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:949
-#, c-format
-msgid "S_decode ==> Please fix the year: %d [1950-2050]"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:952
-#, c-format
-msgid "S_decode ==> Please fix the month: %d"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:954
-#, c-format
-msgid "S_decode ==> Please fix the day-of-month: %d"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:957
-#, c-format
-msgid "S_decode ==> Please fix the day-of-year: %d"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:960
-#, c-format
-msgid "S_decode ==> Please fix the hour: %d"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:962
-#, c-format
-msgid "S_decode ==> Please fix the minute: %d"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:964
-#, c-format
-msgid "S_decode ==> Please fix the second: %d"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:966
-#, c-format
-msgid "S_decode ==> Please fix the time zone: %f"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:969
-#, c-format
-msgid "S_decode ==> Please fix the interval: %d"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:972
-#, c-format
-msgid "S_decode ==> Please fix the latitude: %f"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:975
-#, c-format
-msgid "S_decode ==> Please fix the longitude: %f"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:978
-#, c-format
-msgid "S_decode ==> Please fix the temperature: %f"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:981
-#, c-format
-msgid "S_decode ==> Please fix the pressure: %f"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:983
-#, c-format
-msgid "S_decode ==> Please fix the tilt: %f"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:985
-#, c-format
-msgid "S_decode ==> Please fix the aspect: %f"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:987
-#, c-format
-msgid "S_decode ==> Please fix the shadowband width: %f"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:990
-#, c-format
-msgid "S_decode ==> Please fix the shadowband radius: %f"
-msgstr ""
-#: ../raster/r.sunmask/solpos00.c:993
-#, c-format
-msgid "S_decode ==> Please fix the shadowband sky factor: %f"
-msgstr ""
-#: ../raster/r.regression.line/main.c:49
-msgid "Calculates linear regression from two raster maps: y = a + b*x."
-msgstr ""
-#: ../raster/r.regression.line/main.c:54
-msgid "Map for x coefficient"
-msgstr ""
-#: ../raster/r.regression.line/main.c:58
-msgid "Map for y coefficient"
-msgstr ""
-#: ../raster/r.regression.line/main.c:64
-msgid "ASCII file for storing regression coefficients (output to screen if file not specified)."
-msgstr ""
-#: ../raster/r.regression.line/main.c:68 ../general/g.region/main.c:141
-#: ../locale/scriptstrings/i.oif_to_translate.c:11
-msgid "Print in shell script style"
-msgstr ""
-#: ../raster/r.out.bin/main.c:53 ../raster/r.out.bin/main.c:62
-#: ../raster/r.out.bin/main.c:462 ../raster/r.mapcalc/map3.c:126
-#: ../raster/r.mapcalc/map3.c:140 ../raster/r.mapcalc/map3.c:154
-#, fuzzy
-msgid "Error writing data"
-#: ../raster/r.out.bin/main.c:139
-#, c-format
-msgid "Header File = %s"
-msgstr ""
-#: ../raster/r.out.bin/main.c:144 ../raster/r.out.bin/main.c:228
-#: ../raster/r.out.bin/main.c:408
-#, fuzzy, c-format
-msgid "Unable to create file <%s>"
-#: ../raster/r.out.bin/main.c:223
-#, c-format
-msgid "World File = %s"
-msgstr ""
-#: ../raster/r.out.bin/main.c:281
-msgid "Exports a GRASS raster to a binary array."
-msgstr ""
-#: ../raster/r.out.bin/main.c:297
-msgid "Name for output binary map (use output=- for stdout)"
-msgstr ""
-#: ../raster/r.out.bin/main.c:304
-msgid "Value to write out for null"
-msgstr ""
-#: ../raster/r.out.bin/main.c:323
-#, fuzzy
-msgid "Generate integer output"
-#: ../raster/r.out.bin/main.c:327
-#, fuzzy
-msgid "Generate floating-point output"
-#: ../raster/r.out.bin/main.c:331
-msgid "Export array with GMT compatible header"
-msgstr ""
-#: ../raster/r.out.bin/main.c:335
-msgid "Generate BIL world and header files"
-msgstr ""
-#: ../raster/r.out.bin/main.c:339
-msgid "Byte swap output"
-msgstr ""
-#: ../raster/r.out.bin/main.c:345
-msgid "Invalid value for null (integers only)"
-msgstr ""
-#: ../raster/r.out.bin/main.c:367
-msgid "order= and -s are mutually exclusive"
-msgstr ""
-#: ../raster/r.out.bin/main.c:376
-msgid "-i and -f are mutually exclusive"
-msgstr ""
-#: ../raster/r.out.bin/main.c:395
-msgid "Floating-point output requires bytes=4 or bytes=8"
-msgstr ""
-#: ../raster/r.out.bin/main.c:399
-msgid "Integer output doesn't support bytes=8 in this build"
-msgstr ""
-#: ../raster/r.out.bin/main.c:413
-msgid "GMT grid doesn't support 64-bit integers"
-msgstr ""
-#: ../raster/r.out.bin/main.c:419
-#, fuzzy
-msgid "Creating BIL support files..."
-#: ../raster/r.out.bin/main.c:436
-#, c-format
-msgid "Exporting raster as floating values (bytes=%d)"
-msgstr ""
-#: ../raster/r.out.bin/main.c:438
-msgid "Writing GMT float format ID=1"
-msgstr ""
-#: ../raster/r.out.bin/main.c:441
-#, c-format
-msgid "Exporting raster as integer values (bytes=%d)"
-msgstr ""
-#: ../raster/r.out.bin/main.c:443
-msgid "Writing GMT integer format ID=2"
-msgstr ""
-#: ../raster/r.out.bin/main.c:446
-#, fuzzy
-msgid "Using the current region settings..."
-#: ../raster/r.out.bin/main.c:447
-#, c-format
-msgid "north=%f"
-msgstr ""
-#: ../raster/r.out.bin/main.c:448
-#, c-format
-msgid "south=%f"
-msgstr ""
-#: ../raster/r.out.bin/main.c:449
-#, c-format
-msgid "east=%f"
-msgstr ""
-#: ../raster/r.out.bin/main.c:450
-#, c-format
-msgid "west=%f"
-msgstr ""
-#: ../raster/r.out.bin/main.c:451
-#, c-format
-msgid "r=%d"
-msgstr ""
-#: ../raster/r.out.bin/main.c:452
-#, c-format
-msgid "c=%d"
-msgstr ""
-#: ../raster/r.surf.random/main.c:40
-msgid "Produces a raster map of uniform random deviates whose range can be expressed by the user."
-msgstr ""
-#: ../raster/r.surf.random/main.c:47
-msgid "Minimum random value"
-msgstr ""
-#: ../raster/r.surf.random/main.c:53
-msgid "Maximum random value"
-msgstr ""
-#: ../raster/r.surf.random/main.c:59
-#, fuzzy
-msgid "Create an integer raster map"
-#: ../raster/r.surf.random/main.c:67
-#, fuzzy, c-format
-msgid "Raster map <%s> generated."
-#: ../raster/r.resample/main.c:57
-msgid "GRASS raster map layer data resampling capability."
-msgstr ""
-#: ../raster/r.resample/main.c:66
-msgid "Name of an input layer"
-msgstr ""
-#: ../raster/r.resample/main.c:73
-msgid "Name of an output layer"
-msgstr ""
-#: ../raster/r.resample/main.c:138
-#, fuzzy
-msgid "Creating new cats file..."
-#: ../raster/r.in.mat/main.c:94
-msgid "Imports a binary MAT-File(v4) to a GRASS raster."
-msgstr ""
-#: ../raster/r.in.mat/main.c:103
-msgid "Name of an existing MAT-File(v4)"
-msgstr ""
-#: ../raster/r.in.mat/main.c:110
-msgid "Name for the output raster map (override)"
-msgstr ""
-#: ../raster/r.in.mat/main.c:154
-#, fuzzy
-msgid "Reading MAT-File..."
-#: ../raster/r.in.mat/main.c:180
-msgid "Array contains no data"
-msgstr ""
-#: ../raster/r.in.mat/main.c:185
-msgid "Array contains imaginary data"
-msgstr ""
-#: ../raster/r.in.mat/main.c:191
-msgid "Invalid array name"
-msgstr ""
-#: ../raster/r.in.mat/main.c:211
-msgid "Invalid 'map_name' array"
-msgstr ""
-#: ../raster/r.in.mat/main.c:221
-msgid "Error reading 'map_name' array"
-msgstr ""
-#: ../raster/r.in.mat/main.c:232
-msgid "Invalid 'map_northern_edge' array"
-msgstr ""
-#: ../raster/r.in.mat/main.c:241
-msgid "Invalid 'map_southern_edge' array"
-msgstr ""
-#: ../raster/r.in.mat/main.c:250
-msgid "Invalid 'map_eastern_edge' array"
-msgstr ""
-#: ../raster/r.in.mat/main.c:259
-msgid "Invalid 'map_western_edge' array"
-msgstr ""
-#: ../raster/r.in.mat/main.c:267
-msgid "Invalid 'map_title' array"
-msgstr ""
-#: ../raster/r.in.mat/main.c:277
-msgid "Error reading 'map_title' array"
-msgstr ""
-#: ../raster/r.in.mat/main.c:290
-msgid "Invalid 'map_data' array"
-msgstr ""
-#: ../raster/r.in.mat/main.c:316 ../raster/r.in.mat/main.c:448
-#: ../raster/r.in.mat/main.c:527
-msgid "Please contact the GRASS development team"
-msgstr ""
-#: ../raster/r.in.mat/main.c:321
-#, c-format
-msgid "Skipping unknown array '%s'"
-msgstr ""
-#: ../raster/r.in.mat/main.c:349
-#, c-format
-msgid "No 'map_data' array found in <%s>"
-msgstr ""
-#: ../raster/r.in.mat/main.c:356
-#, c-format
-msgid "Setting map name to <%s> which overrides <%s>"
-msgstr ""
-#: ../raster/r.in.mat/main.c:363
-#, fuzzy, c-format
-msgid "Setting map name to <%s>"
-#: ../raster/r.in.mat/main.c:367
-msgid "No 'map_name' array found; using <MatFile>"
-msgstr ""
-#: ../raster/r.in.mat/main.c:378
-msgid "Missing bound"
-msgstr ""
-#: ../raster/r.in.mat/main.c:382
-msgid "Using default bounds"
-msgstr ""
-#: ../raster/r.in.mat/main.c:396
-#, c-format
-msgid "Map <%s> bounds set to:"
-msgstr ""
-#: ../raster/r.in.mat/main.c:413
-#, fuzzy
-msgid "Writing new raster map..."
-#: ../raster/r.li/r.li.shape/main.c:33
-msgid "Calculates shape index on a raster map"
-msgstr ""
-#: ../raster/r.li/r.li.shape/main.c:35 ../raster/r.li/r.li.cwed/cwed.c:47
-#: ../raster/r.li/r.li.patchnum/main.c:37
-#: ../raster/r.li/r.li.simpson/simpson.c:40
-#: ../raster/r.li/r.li.dominance/dominance.c:42
-#: ../raster/r.li/r.li.pielou/pielou.c:59 ../raster/r.li/r.li.mps/mps.c:41
-#: ../raster/r.li/r.li.shannon/shannon.c:39
-#: ../raster/r.li/r.li.richness/richness.c:40
-#: ../raster/r.li/r.li.renyi/renyi.c:46
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:40
-#: ../raster/r.li/r.li.padrange/padrange.c:40
-#: ../raster/r.li/r.li.padsd/padsd.c:38 ../raster/r.li/r.li.mpa/mpa.c:40
-#: ../raster/r.li/r.li.padcv/padcv.c:40
-#: ../raster/r.li/r.li.patchdensity/main.c:36
-#, fuzzy
-msgid "landscape structure analysis"
-#: ../raster/r.li/r.li.shape/main.c:36 ../raster/r.li/r.li.cwed/cwed.c:48
-#: ../raster/r.li/r.li.patchnum/main.c:38 ../raster/r.li/r.li.mps/mps.c:42
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:41
-#: ../raster/r.li/r.li.padrange/padrange.c:41
-#: ../raster/r.li/r.li.padsd/padsd.c:39 ../raster/r.li/r.li.mpa/mpa.c:41
-#: ../raster/r.li/r.li.padcv/padcv.c:41
-#: ../raster/r.li/r.li.patchdensity/main.c:37
-#, fuzzy
-msgid "patch index"
-#: ../raster/r.li/r.li.shape/main.c:44 ../raster/r.li/r.li.cwed/cwed.c:56
-#: ../raster/r.li/r.li.patchnum/main.c:46
-#: ../raster/r.li/r.li.simpson/simpson.c:49
-#: ../raster/r.li/r.li.dominance/dominance.c:51
-#: ../raster/r.li/r.li.pielou/pielou.c:68 ../raster/r.li/r.li.mps/mps.c:49
-#: ../raster/r.li/r.li.shannon/shannon.c:48
-#: ../raster/r.li/r.li.richness/richness.c:49
-#: ../raster/r.li/r.li.renyi/renyi.c:55
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:49
-#: ../raster/r.li/r.li.padrange/padrange.c:48
-#: ../raster/r.li/r.li.padsd/padsd.c:46 ../raster/r.li/r.li.mpa/mpa.c:48
-#: ../raster/r.li/r.li.padcv/padcv.c:48
-#: ../raster/r.li/r.li.patchdensity/main.c:45
-#, fuzzy
-msgid "Configuration file"
-#: ../raster/r.li/r.li.cwed/cwed.c:45
-#, fuzzy
-msgid "Calculates contrast weighted edge density index on a raster map"
-#: ../raster/r.li/r.li.patchnum/main.c:35
-msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
-msgstr ""
-#: ../raster/r.li/r.li.simpson/simpson.c:38
-#, fuzzy
-msgid "Calculates Simpson's diversity index on a raster map"
-#: ../raster/r.li/r.li.simpson/simpson.c:41
-#: ../raster/r.li/r.li.dominance/dominance.c:43
-#: ../raster/r.li/r.li.pielou/pielou.c:60
-#: ../raster/r.li/r.li.shannon/shannon.c:40
-#: ../raster/r.li/r.li.renyi/renyi.c:47
-#, fuzzy
-msgid "diversity index"
-msgstr "ड्राइवरचे नाव"
-#: ../raster/r.li/r.li.dominance/dominance.c:40
-#: ../raster/r.li/r.li.richness/richness.c:38
-#, fuzzy
-msgid "Calculates dominance's diversity index on a raster map"
-#: ../raster/r.li/r.li.pielou/pielou.c:57
-#, fuzzy
-msgid "Calculates Pielou's diversity index on a raster map"
-#: ../raster/r.li/r.li.mps/mps.c:39
-msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
-#: ../raster/r.li/r.li.shannon/shannon.c:37
-#, fuzzy
-msgid "Calculates Shannon's diversity index on a raster map"
-#: ../raster/r.li/r.li.richness/richness.c:41
-msgid "dominance index"
-msgstr ""
-#: ../raster/r.li/r.li.renyi/renyi.c:44
-#, fuzzy
-msgid "Calculates Renyi's diversity index on a raster map"
-#: ../raster/r.li/r.li.renyi/renyi.c:63
-msgid "Alpha value is the order of the generalized entropy"
-msgstr ""
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:38
-msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
-#: ../raster/r.li/r.li.padrange/padrange.c:38
-#, fuzzy
-msgid "Calculates range of patch area size on a raster map"
-#: ../raster/r.li/r.li.padsd/padsd.c:36
-msgid "Calculates standard deviation of patch area a raster map"
-msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:101
-#, fuzzy
-msgid "Cannot create random access file"
-#: ../raster/r.li/r.li.daemon/daemon.c:108
-#, fuzzy, c-format
-msgid "Cannot create %s/.grass7/ directory"
-#: ../raster/r.li/r.li.daemon/daemon.c:114
-#, fuzzy, c-format
-msgid "Cannot create %s/.grass7/r.li/ directory"
-#: ../raster/r.li/r.li.daemon/daemon.c:121
-#, fuzzy, c-format
-msgid "Cannot create %s/.grass7/r.li/output/ directory"
-#: ../raster/r.li/r.li.daemon/daemon.c:196
-#, fuzzy, c-format
-msgid "Cannot find configuration file <%s>"
-#: ../raster/r.li/r.li.daemon/daemon.c:203
-#: ../raster/r.li/r.li.daemon/daemon.c:207
-#, fuzzy
-msgid "Cannot read setup file"
-#: ../raster/r.li/r.li.daemon/daemon.c:211
-#, fuzzy
-msgid "Unable to parse configuration file"
-#: ../raster/r.li/r.li.daemon/daemon.c:362
-msgid "Irregular maskedoverlay areas definition"
-msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:365
-#, c-format
-msgid "The configuration file can be used only with \t\t\t%s rasterfile"
-msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:372
-msgid "Illegal configuration file (sample area)"
-msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:406
-msgid "Too many units to place"
-msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:475
-#, fuzzy
-msgid "Too many strats for raster map"
-#: ../raster/r.li/r.li.daemon/daemon.c:509
-msgid "Illegal areas disposition"
-msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:578
-#, fuzzy
-msgid "Cannot make lseek"
-#: ../raster/r.li/r.li.daemon/worker.c:125
-#: ../raster/r.li/r.li.daemon/worker.c:135
-#, c-format
-msgid "unable to open <%s> mask ... continuing without!"
-msgstr ""
-#: ../raster/r.li/r.li.mpa/mpa.c:38
-#, fuzzy
-msgid "Calculates mean pixel attribute index on a raster map"
-#: ../raster/r.li/r.li.padcv/padcv.c:38
-msgid "Calculates coefficient of variation of patch area on a raster map"
-msgstr ""
-#: ../raster/r.li/r.li.patchdensity/main.c:34
-msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
-#: ../raster/r.out.ppm/main.c:55
-#, fuzzy
-msgid "Converts a GRASS raster map to a PPM image file."
-#: ../raster/r.out.ppm/main.c:63
-msgid "Name for new PPM file (use '-' for stdout)"
-msgstr ""
-#: ../raster/r.out.ppm/main.c:67
-msgid "Output greyscale instead of color"
-msgstr ""
-#: ../raster/r.out.ppm/main.c:96 ../raster/r.out.ppm3/main.c:94
-#, c-format
-msgid "rows = %d, cols = %d"
-msgstr ""
-#: ../raster/r.out.ppm/main.c:115
-#, fuzzy, c-format
-msgid "Unable to open file <%s> for write"
-#: ../raster/r.out.ppm/main.c:144
-#, fuzzy
-msgid "Converting..."
-#: ../raster/r.out.ppm/main.c:224
-#, c-format
-msgid "File <%s> created"
-msgstr ""
-#: ../raster/r.random.cells/init.c:70
-msgid "Distance must be >= 0.0"
-msgstr ""
-#: ../raster/r.random.cells/random.c:50
-#, c-format
-msgid "RAN1: j == %d shouldn't happen"
-msgstr ""
-#: ../raster/r.random.cells/main.c:47
-msgid "cell"
-msgstr ""
-#: ../raster/r.random.cells/main.c:49
-msgid "Generates random cell values with spatial dependence."
-msgstr ""
-#: ../raster/r.random.cells/main.c:59
-msgid "Maximum distance of spatial correlation (value(s) >= 0.0)"
-msgstr ""
-#: ../raster/r.random.cells/main.c:66
-msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default [random])"
-msgstr ""
-#: ../raster/r.timestamp/main.c:37 ../vector/v.timestamp/main.c:38
-msgid "timestamp"
-msgstr ""
-#: ../raster/r.timestamp/main.c:38
-#, fuzzy
-msgid "Modifies a timestamp for a raster map."
-#: ../raster/r.timestamp/main.c:39
-msgid "Print/add/remove a timestamp for a raster map."
-msgstr ""
-#: ../raster/r.timestamp/main.c:48 ../vector/v.timestamp/main.c:50
-msgid "Datetime, datetime1/datetime2, or 'none' to remove"
-msgstr ""
-#: ../raster/r.timestamp/main.c:49 ../vector/v.timestamp/main.c:51
-msgid "Format: '15 jan 1994' (absolute) or '2 years' (relative)"
-msgstr ""
-#: ../raster/r.timestamp/main.c:64
-#, fuzzy, c-format
-msgid "Raster map <%s> not found %s"
-#: ../raster/r.out.ascii/main.c:62
-#, fuzzy
-msgid "Converts a raster map layer into a GRASS ASCII text file."
-#: ../raster/r.out.ascii/main.c:71
-msgid "Name of an existing raster map"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:79
-msgid "Name for output ASCII grid map (use out=- for stdout)"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:93
-msgid "Number of values printed before wrapping a line (only SURFER or MODFLOW format)"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:101
-msgid "String to represent null cell (GRASS grid only)"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:109
-msgid "Write SURFER (Golden Software) ASCII grid"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:113
-msgid "Write MODFLOW (USGS) ASCII array"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:117
-msgid "Force output of integer values"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:124
-msgid "Failed to interpret dp as an integer"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:132
-msgid "Failed to interpret width as an integer"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:138
-msgid "Both -s and -h doesn't make sense"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:141
-msgid "Use -M or -s, not both"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:176
-#, fuzzy, c-format
-msgid "Unable to read fp range for <%s>"
-#: ../raster/r.out.ascii/main.c:192
-#, fuzzy, c-format
-msgid "Read failed at row %d"
-#: ../raster/r.slope.aspect/main.c:153
-#, fuzzy
-msgid "terrain"
-#: ../raster/r.slope.aspect/main.c:154
-msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from a elevation raster map."
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:156
-msgid "Aspect is calculated counterclockwise from east."
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:163 ../vector/v.surf.rst/main.c:198
-#, fuzzy
-msgid "Name for output slope raster map"
-#: ../raster/r.slope.aspect/main.c:169 ../vector/v.surf.rst/main.c:204
-#, fuzzy
-msgid "Name for output aspect raster map"
-#: ../raster/r.slope.aspect/main.c:178
-msgid "Format for reporting the slope"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:188
-msgid "Type of output aspect and slope maps"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:195 ../vector/v.surf.rst/main.c:210
-#, fuzzy
-msgid "Name for output profile curvature raster map"
-#: ../raster/r.slope.aspect/main.c:202 ../vector/v.surf.rst/main.c:216
-#, fuzzy
-msgid "Name for output tangential curvature raster map"
-#: ../raster/r.slope.aspect/main.c:209
-msgid "Name for output first order partial derivative dx (E-W slope) raster map"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:216
-msgid "Name for output first order partial derivative dy (N-S slope) raster map"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:223
-msgid "Name for output second order partial derivative dxx raster map"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:230
-msgid "Name for output second order partial derivative dyy raster map"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:237
-msgid "Name for output second order partial derivative dxy raster map"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:243
-msgid "Multiplicative factor to convert elevation units to meters"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:252
-msgid "Minimum slope val. (in percent) for which aspect is computed"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:261
-msgid "Do not align the current region to the elevation layer"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:313
-#, c-format
-msgid "%s=%s - must be a positive number"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:319
-#, c-format
-msgid "%s=%s - must be a non-negative number"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:334
-#, c-format
-msgid "You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> or <%s>"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:358
-#, fuzzy, c-format
-msgid "Wrong raster type: %s"
-#: ../raster/r.slope.aspect/main.c:388
-#, c-format
-msgid "Converting units to meters, factor=%.6f"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:968
-#, fuzzy, c-format
-msgid "Elevation products for mapset <%s> in <%s>"
-#: ../raster/r.slope.aspect/main.c:987
-#, c-format
-msgid "Min computed aspect %.4f, max computed aspect %.4f"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:1051
-#, fuzzy, c-format
-msgid "Aspect raster map <%s> complete"
-#: ../raster/r.slope.aspect/main.c:1108
-#, c-format
-msgid "Min computed slope %.4f, max computed slope %.4f"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:1161
-#, fuzzy, c-format
-msgid "Slope raster map <%s> complete"
-#: ../raster/r.slope.aspect/main.c:1233
-#, fuzzy, c-format
-msgid "Profile curve raster map <%s> complete"
-#: ../raster/r.slope.aspect/main.c:1260
-#, fuzzy, c-format
-msgid "Tangential curve raster map <%s> complete"
-#: ../raster/r.slope.aspect/main.c:1285
-#, fuzzy, c-format
-msgid "E-W slope raster map <%s> complete"
-msgstr "'%s'. ड्राइवर चालू होत नाही"
-#: ../raster/r.slope.aspect/main.c:1310
-#, fuzzy, c-format
-msgid "N-S slope raster map <%s> complete"
-#: ../raster/r.slope.aspect/main.c:1335
-#, fuzzy, c-format
-msgid "Dxx raster map <%s> complete"
-#: ../raster/r.slope.aspect/main.c:1360
-#, fuzzy, c-format
-msgid "Dyy raster map <%s> complete"
-#: ../raster/r.slope.aspect/main.c:1385
-#, fuzzy, c-format
-msgid "Dxy raster map <%s> complete"
-#: ../raster/r.bitpattern/main.c:65
-#, fuzzy
-msgid "Compares bit patterns with a raster map."
-#: ../raster/r.bitpattern/main.c:77
-msgid "Bit pattern position(s)"
-msgstr ""
-#: ../raster/r.bitpattern/main.c:83
-msgid "Bit pattern value"
-msgstr ""
-#: ../raster/r.bitpattern/main.c:89
-msgid "Quiet"
-msgstr ""
-#: ../raster/r.to.vect/lines_io.c:76
-msgid "write_line:  found half a loop!"
-msgstr ""
-#: ../raster/r.to.vect/lines_io.c:128
-#, c-format
-msgid ""
-"write_line: line terminated unexpectedly\n"
-"  previous (%d) point %p (%d,%d,%d) %p %p"
-msgstr ""
-#: ../raster/r.to.vect/lines.c:70
-#, fuzzy
-msgid "Extracting lines..."
-#: ../raster/r.to.vect/lines.c:494
-msgid ""
-"Raster map is not thinned properly.\n"
-"Please run r.thin."
-msgstr ""
-#: ../raster/r.to.vect/lines.c:568
-msgid "join_lines: p front pointer not NULL!"
-msgstr ""
-#: ../raster/r.to.vect/lines.c:574
-msgid "join_lines: q front pointer not NULL!"
-msgstr ""
-#: ../raster/r.to.vect/lines.c:592
-msgid "extend line:  p is NULL"
-msgstr ""
-#: ../raster/r.to.vect/lines.c:618
-msgid "extend_lines: p front pointer not NULL!"
-msgstr ""
-#: ../raster/r.to.vect/lines.c:625
-msgid "extend_lines: q back pointer not NULL!"
-msgstr ""
-#: ../raster/r.to.vect/util.c:157 ../raster/r.to.vect/areas_io.c:370
-#: ../vector/v.random/main.c:305 ../vector/v.in.ogr/main.c:968
-#: ../vector/v.in.lidar/main.c:757
-#, c-format
-msgid "Cannot insert new row: %s"
-msgstr ""
-#: ../raster/r.to.vect/main.c:73
-#, fuzzy
-msgid "vectorization"
-#: ../raster/r.to.vect/main.c:74
-#, fuzzy
-msgid "Converts a raster map into a vector map."
-#: ../raster/r.to.vect/main.c:87
-#, fuzzy
-msgid "Name of attribute column to store value"
-#: ../raster/r.to.vect/main.c:88
-msgid "Name must be SQL compliant"
-msgstr ""
-#: ../raster/r.to.vect/main.c:93
-msgid "Smooth corners of area features"
-msgstr ""
-#: ../raster/r.to.vect/main.c:98
-msgid "Use raster values as categories instead of unique sequence (CELL only)"
-msgstr ""
-#: ../raster/r.to.vect/main.c:99 ../raster/r.to.vect/main.c:106
-#: ../vector/v.in.ogr/main.c:209 ../vector/v.in.ogr/main.c:244
-#: ../vector/v.in.ogr/main.c:267 ../vector/v.extract/main.c:91
-#: ../vector/v.extract/main.c:143 ../vector/v.to.rast/main.c:74
-#: ../vector/v.to.rast/main.c:80 ../vector/v.to.rast/main.c:86
-#: ../vector/v.in.lidar/main.c:198
-#, fuzzy
-msgid "Attributes"
-#: ../raster/r.to.vect/main.c:103
-#, fuzzy
-msgid "Write raster values as z coordinate"
-#: ../raster/r.to.vect/main.c:104
-msgid "Table is not created. Currently supported only for points."
-msgstr ""
-#: ../raster/r.to.vect/main.c:110
-#, fuzzy
-msgid "Do not build vector topology"
-#: ../raster/r.to.vect/main.c:111
-msgid "Recommended for massive point conversion"
-msgstr ""
-#: ../raster/r.to.vect/main.c:121
-msgid "z flag is supported only for points"
-msgstr ""
-#: ../raster/r.to.vect/main.c:131
-msgid "Raster is not CELL, '-v' flag ignored, raster values will be written to the table."
-msgstr ""
-#: ../raster/r.to.vect/main.c:209 ../vector/v.random/main.c:195
-#: ../vector/v.lrs/v.lrs.create/main.c:327 ../vector/v.in.ascii/main.c:385
-#: ../vector/v.mkgrid/main.c:243 ../vector/v.in.sites/main.c:172
-#: ../vector/v.in.dxf/write_vect.c:232
-#, fuzzy, c-format
-msgid "Unable to create table: %s"
-#: ../raster/r.to.vect/main.c:213 ../vector/v.overlay/main.c:470
-#: ../vector/v.mkgrid/main.c:247
-#, fuzzy
-msgid "Unable to create index"
-#: ../raster/r.to.vect/main.c:288
-#, fuzzy, c-format
-msgid "Unable to insert into table: %s"
-#: ../raster/r.to.vect/areas_io.c:106
-#, c-format
-msgid ""
-"Line terminated unexpectedly\n"
-"previous (%d) point %p (%d,%d,%d) %p %p"
-msgstr ""
-#: ../raster/r.to.vect/areas.c:120
-#, fuzzy
-msgid "Extracting areas..."
-#: ../raster/r.to.vect/points.c:36
-#, fuzzy
-msgid "Extracting points..."
-#: ../raster/r.series.interp/main.c:68
-msgid "Interpolate raster maps located (temporal or spatial) in between input raster maps at specific sampling positions."
-msgstr ""
-#: ../raster/r.series.interp/main.c:78
-#, fuzzy
-msgid "Data point position for each input map"
-#: ../raster/r.series.interp/main.c:83
-msgid "Input file with an input raster map name and data point position per line, field separator between name and sample point is |"
-msgstr ""
-#: ../raster/r.series.interp/main.c:95
-#, fuzzy
-msgid "Sampling point position for each output map"
-#: ../raster/r.series.interp/main.c:99
-msgid "Input infile with an output raster map name and sample point position per line, field separator between name and sample point is |"
-msgstr ""
-#: ../raster/r.series.interp/main.c:109
-msgid "Interpolation method, currently only linear interpolation is supported"
-msgstr ""
-#: ../raster/r.series.interp/main.c:116
-msgid "output= and outfile= are mutually exclusive"
-msgstr ""
-#: ../raster/r.series.interp/main.c:119
-msgid "samplingpos= and outfile= are mutually exclusive"
-msgstr ""
-#: ../raster/r.series.interp/main.c:122
-#, fuzzy
-msgid "Please specify output= or outfile="
-#: ../raster/r.series.interp/main.c:125
-#, fuzzy
-msgid "Please specify output= and samplingpos="
-#: ../raster/r.series.interp/main.c:128
-msgid "input= and infile= are mutually exclusive"
-msgstr ""
-#: ../raster/r.series.interp/main.c:131
-msgid "datapos= and infile= are mutually exclusive"
-msgstr ""
-#: ../raster/r.series.interp/main.c:134
-#, fuzzy
-msgid "Please specify input= or infile="
-msgstr "तक्त्याचे नाव"
-#: ../raster/r.series.interp/main.c:137
-#, fuzzy
-msgid "Please specify input= and datapos="
-#: ../raster/r.series.interp/main.c:170
-#, fuzzy, c-format
-msgid "Unable to open %s file <%s>"
-#: ../raster/r.series.interp/main.c:203
-#, c-format
-msgid "Missing point position for %s map <%s> in file <%s> near line %i"
-msgstr ""
-#: ../raster/r.series.interp/main.c:218 ../raster/r.series.interp/main.c:252
-#, fuzzy, c-format
-msgid "Preparing %s map <%s> at position %g"
-#: ../raster/r.series.interp/main.c:222
-#, fuzzy, c-format
-msgid "No raster map name found in %s file <%s>"
-#: ../raster/r.series.interp/main.c:233
-#, fuzzy, c-format
-msgid "No %s raster map not found"
-#: ../raster/r.series.interp/main.c:240
-#, c-format
-msgid "The number of %s maps and %s point positions must be equal"
-msgstr ""
-#: ../raster/r.series.interp/main.c:269
-#, c-format
-msgid "Start interpolation run with %i input maps and %i output maps"
-msgstr ""
-#: ../raster/r.series.interp/main.c:289
-#, c-format
-msgid "map <%s> at position %g was not interpolated. Check the interpolation interval."
-msgstr ""
-#: ../raster/r.series.interp/main.c:309
-#, fuzzy
-msgid "At least 2 input maps are required for linear interpolation"
-#: ../raster/r.series.interp/main.c:327
-#, c-format
-msgid "Interpolate map <%s> at position %g in interval (%g;%g)"
-msgstr ""
-#: ../raster/r.out.ppm3/main.c:58
-msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
-msgstr ""
-#: ../raster/r.out.ppm3/main.c:83
-msgid "Name for new PPM file. (use out=- for stdout)"
-msgstr ""
-#: ../raster/r.out.ppm3/main.c:87
-msgid "Add comments to describe the region"
-msgstr ""
-#: ../raster/r.out.ppm3/main.c:154
-msgid "Converting ... "
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:86 ../vector/v.surf.bspline/main.c:96
-msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:94
-#, fuzzy
-msgid "Output vector with interpolation grid"
-#: ../raster/r.resamp.bspline/main.c:99
-#, fuzzy
-msgid "Raster map to use for masking"
-#: ../raster/r.resamp.bspline/main.c:100 ../vector/v.surf.bspline/main.c:132
-msgid "Only cells that are not NULL and not zero are interpolated"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:108
-msgid "Length of each spline step in the east-west direction. Default: 1.5 * ewres."
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:116
-msgid "Length of each spline step in the north-south direction. Default: 1.5 * nsres."
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:123 ../vector/v.surf.bspline/main.c:157
-msgid "Spline interpolation algorithm"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:132 ../vector/v.surf.bspline/main.c:166
-msgid "Tykhonov regularization parameter (affects smoothing)"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:138
-#, fuzzy
-msgid "Only interpolate null cells in input raster map"
-#: ../raster/r.resamp.bspline/main.c:144 ../vector/v.surf.bspline/main.c:101
-msgid "Find the best Tykhonov regularizing parameter using a \"leave-one-out\" cross validation method"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:151
-msgid "Maximum memory to be used (in MB)"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:186
-msgid "se must be positive"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:194
-msgid "sn must be positive"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:221
-#, c-format
-msgid "spline step in ew direction %g"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:222
-#, c-format
-msgid "spline step in ns direction %g"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:223 ../vector/v.outlier/main.c:272
-#: ../vector/v.lidar.edgedetection/main.c:294
-#: ../vector/v.lidar.correction/main.c:274 ../vector/v.surf.bspline/main.c:530
-#, c-format
-msgid "adjusted EW splines %d"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:224 ../vector/v.outlier/main.c:273
-#: ../vector/v.lidar.edgedetection/main.c:295
-#: ../vector/v.lidar.correction/main.c:275 ../vector/v.surf.bspline/main.c:531
-#, c-format
-msgid "adjusted NS splines %d"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:291 ../vector/v.surf.bspline/main.c:436
-msgid "Memory in MB must be >= 3"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:307 ../raster/r.resamp.bspline/main.c:393
-#: ../raster/r.resamp.bspline/main.c:464 ../vector/v.surf.bspline/main.c:450
-#: ../vector/v.surf.bspline/main.c:478
-#, fuzzy
-msgid "Can not create temporary file"
-#: ../raster/r.resamp.bspline/main.c:312 ../raster/r.resamp.bspline/main.c:398
-#: ../raster/r.resamp.bspline/main.c:469 ../vector/v.surf.bspline/main.c:455
-#: ../vector/v.surf.bspline/main.c:483
-#, fuzzy
-msgid "Can not initialize temporary file"
-#: ../raster/r.resamp.bspline/main.c:318
-#, fuzzy, c-format
-msgid "Loading input raster <%s>"
-#: ../raster/r.resamp.bspline/main.c:338
-#, fuzzy
-msgid "Only NULL cells in input raster"
-#: ../raster/r.resamp.bspline/main.c:362 ../vector/v.surf.bspline/main.c:292
-msgid "Cross validation didn't finish correctly"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:366
-#, c-format
-msgid "Cross validation finished for se = %f and sn = %f"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:386
-#, fuzzy
-msgid "Mark cells for interpolation"
-#: ../raster/r.resamp.bspline/main.c:457
-msgid "No NULL cells found in input raster."
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:472 ../vector/v.surf.bspline/main.c:458
-#, fuzzy
-msgid "Initializing output..."
-#: ../raster/r.resamp.bspline/main.c:545 ../vector/v.outlier/main.c:328
-#: ../vector/v.lidar.edgedetection/main.c:350
-#: ../vector/v.lidar.correction/main.c:330 ../vector/v.surf.bspline/main.c:599
-#: ../vector/v.lidar.growing/main.c:246
-#, c-format
-msgid "subregion %d of %d"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:719
-msgid "No data within this subregion. Consider increasing the spline step."
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:735 ../vector/v.surf.bspline/main.c:856
-#, fuzzy
-msgid "Writing output..."
-#: ../raster/r.resamp.bspline/crosscorr.c:160
-#, c-format
-msgid "%d are too many cells, recommended are < 100 cells. The cross validation would take too much time."
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:169
-#: ../vector/v.surf.bspline/crosscorr.c:81
-#, fuzzy, c-format
-msgid "%d points read in region"
-#: ../raster/r.resamp.bspline/crosscorr.c:173
-msgid "Maybe it takes too long.Consider reducing the region extends."
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:193
-#: ../vector/v.surf.bspline/crosscorr.c:146
-#, c-format
-msgid "Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:211
-#: ../vector/v.surf.bspline/crosscorr.c:164
-#, c-format
-msgid "Beginning cross validation with lambda_i=%.4f..."
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:296
-#: ../vector/v.surf.bspline/crosscorr.c:284
-#, c-format
-msgid "Mean = %.5lf"
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:297
-#: ../vector/v.surf.bspline/crosscorr.c:285
-#, c-format
-msgid "Root Means Square (RMS) = %.5lf"
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:313
-#: ../vector/v.surf.bspline/crosscorr.c:301
-msgid "Different number of splines and lambda_i values have been taken for the cross correlation"
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:315
-#: ../vector/v.surf.bspline/crosscorr.c:303
-#, c-format
-msgid "The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:323
-#: ../vector/v.surf.bspline/crosscorr.c:311
-msgid "Results into a table:"
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:324
-#: ../vector/v.surf.bspline/crosscorr.c:312
-msgid " lambda    | mean        | rms         |"
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:326
-#: ../vector/v.surf.bspline/crosscorr.c:314
-#, c-format
-msgid " %-10.5f| %-12.4f| %-12.4f|"
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:334
-#: ../vector/v.surf.bspline/crosscorr.c:322
-#, fuzzy
-msgid "No point lies into the current region"
-#: ../raster/r.transect/main.c:84
-#, c-format
-msgid "End coordinate: %.15g, %.15g"
-msgstr ""
-#: ../raster/r.transect/main.c:104
-#, fuzzy
-msgid "transect"
-#: ../raster/r.transect/main.c:106
-msgid "Outputs raster map layer values lying along user defined transect line(s)."
-msgstr ""
-#: ../raster/r.transect/main.c:110
-msgid "Raster map to be queried"
-msgstr ""
-#: ../raster/r.transect/main.c:116
-msgid "Transect definition"
-msgstr ""
-#: ../raster/r.surf.idw/main.c:108
-#, fuzzy
-msgid "Surface interpolation utility for raster map."
-#: ../raster/r.surf.idw/main.c:123
-msgid "Output is the interpolation error"
-msgstr ""
-#: ../raster/r.surf.idw/main.c:129
-#, fuzzy, c-format
-msgid "Illegal value for '%s' (%s)"
-#: ../raster/r.surf.idw/main.c:255
-#, fuzzy, c-format
-msgid "Interpolating raster map <%s> (%d rows)..."
-#: ../raster/r.surf.area/main.c:79
-#, fuzzy
-msgid "area estimation"
-#: ../raster/r.surf.area/main.c:80
-#, fuzzy
-msgid "Prints estimation of surface area for raster map."
-#: ../raster/r.surf.area/main.c:89
-msgid "Vertical scale"
-msgstr ""
-#: ../raster/r.surf.area/main.c:93
-#, fuzzy
-msgid "Output units"
-msgstr "पूर्ण तपशिल"
-#: ../raster/r.surf.area/main.c:94
-msgid "Default: square map units"
-msgstr ""
-#: ../raster/r.surf.area/main.c:102
-#, fuzzy, c-format
-msgid "Output in '%s'"
-#: ../raster/r.surf.area/main.c:106
-msgid "Output in 'square map units'"
-msgstr ""
-#: ../raster/r.surf.area/main.c:151
-msgid "Null value area ignored in calculation:"
-msgstr ""
-#: ../raster/r.surf.area/main.c:153
-#, fuzzy
-msgid "Plan area used in calculation:"
-msgstr "डेटाबेसचे स्थान"
-#: ../raster/r.surf.area/main.c:156
-msgid "Surface area calculation(low, high, avg):"
-msgstr ""
-#: ../raster/r.surf.area/main.c:161
-msgid "Current region plan area:"
-msgstr ""
-#: ../raster/r.surf.area/main.c:163
-msgid "Estimated region Surface Area:"
-msgstr ""
-#: ../raster/r.grow/main.c:124 ../locale/scriptstrings/r.grow_to_translate.c:1
-msgid "Generates a raster map layer with contiguous areas grown by one cell."
-msgstr ""
-#: ../raster/r.grow/main.c:135 ../locale/scriptstrings/r.grow_to_translate.c:4
-msgid "Radius of buffer in raster cells"
-msgstr ""
-#: ../raster/r.grow/main.c:151 ../locale/scriptstrings/r.grow_to_translate.c:6
-msgid "Value to write for input cells which are non-NULL (-1 => NULL)"
-msgstr ""
-#: ../raster/r.grow/main.c:157 ../locale/scriptstrings/r.grow_to_translate.c:7
-msgid "Value to write for \"grown\" cells"
-msgstr ""
-#: ../raster/r.grow/main.c:183
-#, c-format
-msgid "Unknown metric: [%s]."
-msgstr ""
-#: ../raster/r.grow/main.c:192
-#, fuzzy, c-format
-msgid "Error reading category file for <%s>"
-#: ../raster/r.grow/main.c:197
-#, fuzzy, c-format
-msgid "Error in reading color file for <%s>"
-#: ../raster/r.neighbors/main.c:121
-msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
-msgstr ""
-#: ../raster/r.neighbors/main.c:131
-#, fuzzy
-msgid "Name of an input raster map to select the cells which should be processed"
-#: ../raster/r.neighbors/main.c:149 ../vector/v.neighbors/main.c:69
-msgid "Neighborhood operation"
-msgstr ""
-#: ../raster/r.neighbors/main.c:150 ../raster/r.neighbors/main.c:158
-#: ../raster/r.neighbors/main.c:193
-msgid "Neighborhood"
-msgstr ""
-#: ../raster/r.neighbors/main.c:156
-msgid "Neighborhood size"
-msgstr ""
-#: ../raster/r.neighbors/main.c:165
-msgid "Title of the output raster map"
-msgstr ""
-#: ../raster/r.neighbors/main.c:170
-#, fuzzy
-msgid "Text file containing weights"
-#: ../raster/r.neighbors/main.c:176
-msgid "Sigma (in cells) for Gaussian filter"
-msgstr ""
-#: ../raster/r.neighbors/main.c:188
-msgid "Do not align output with the input"
-msgstr ""
-#: ../raster/r.neighbors/main.c:192
-msgid "Use circular neighborhood"
-msgstr ""
-#: ../raster/r.neighbors/main.c:200
-msgid "Neighborhood size must be positive"
-msgstr ""
-#: ../raster/r.neighbors/main.c:202
-msgid "Neighborhood size must be odd"
-msgstr ""
-#: ../raster/r.neighbors/main.c:206
-msgid "weight= and -c are mutually exclusive"
-msgstr ""
-#: ../raster/r.neighbors/main.c:209
-msgid "weight= and gauss= are mutually exclusive"
-msgstr ""
-#: ../raster/r.neighbors/main.c:267
-#, c-format
-msgid "Method %s not compatible with Gaussian filter"
-msgstr ""
-#: ../raster/r.neighbors/main.c:293
-#, fuzzy, c-format
-msgid "Opening selection map <%s>"
-#: ../raster/r.neighbors/readweights.c:18
-#, fuzzy, c-format
-msgid "Unable to open weights file %s"
-#: ../raster/r.neighbors/readweights.c:23
-#, fuzzy, c-format
-msgid "Error reading weights file %s"
-#: ../raster/r.resamp.interp/main.c:79
-#, fuzzy
-msgid "Resamples raster map layers to a finer grid using interpolation."
-#: ../raster/r.resamp.interp/main.c:88 ../vector/v.sample/main.c:102
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:7
-msgid "Interpolation method"
-msgstr ""
-#: ../raster/r.resamp.interp/main.c:104
-#, c-format
-msgid "Invalid method: %s"
-msgstr ""
-#: ../raster/r.proj/readcell.c:64 ../imagery/i.rectify/readcell.c:62
-msgid "Allocating memory and reading input map..."
-msgstr ""
-#: ../raster/r.proj/readcell.c:90 ../raster/r.proj/readcell.c:129
-#: ../imagery/i.rectify/readcell.c:88 ../imagery/i.rectify/readcell.c:127
-#, fuzzy
-msgid "Error writing segment file"
-#: ../raster/r.proj/readcell.c:117 ../imagery/i.rectify/readcell.c:115
-msgid "Internal error: cache miss on fully-cached map"
-msgstr ""
-#: ../raster/r.proj/readcell.c:126 ../imagery/i.rectify/readcell.c:124
-#, fuzzy
-msgid "Error seeking on segment file"
-#: ../raster/r.proj/main.c:147 ../imagery/i.latlong/main.c:59
-#: ../general/g.proj/main.c:63 ../general/g.setproj/main.c:79
-#: ../vector/v.proj/main.c:67 ../locale/scriptstrings/m.proj_to_translate.c:3
-#, fuzzy
-msgid "projection"
-#: ../raster/r.proj/main.c:150
-#, fuzzy
-msgid "Re-projects a raster map from given location to the current location."
-#: ../raster/r.proj/main.c:153
-#, fuzzy
-msgid "Name of input raster map to re-project"
-#: ../raster/r.proj/main.c:155 ../raster/r.proj/main.c:168
-#: ../raster/r.proj/main.c:177 ../vector/v.proj/main.c:75
-#: ../vector/v.proj/main.c:92 ../vector/v.proj/main.c:101
-#: ../vector/v.net.flow/main.c:108 ../vector/v.net.flow/main.c:114
-#, fuzzy
-msgid "Source"
-#: ../raster/r.proj/main.c:161
-#, fuzzy
-msgid "Location containing input raster map"
-#: ../raster/r.proj/main.c:166
-#, fuzzy
-msgid "Mapset containing input raster map"
-#: ../raster/r.proj/main.c:167
-#, fuzzy
-msgid "default: name of current mapset"
-#: ../raster/r.proj/main.c:174 ../vector/v.proj/main.c:98
-msgid "Path to GRASS database of input location"
-msgstr ""
-#: ../raster/r.proj/main.c:181
-#, fuzzy
-msgid "Name for output raster map (default: same as 'input')"
-#: ../raster/r.proj/main.c:182 ../raster/r.proj/main.c:193
-#: ../raster/r.proj/main.c:207 ../raster/r.proj/main.c:221
-#: ../raster/r.proj/main.c:227 ../vector/v.proj/main.c:106
-#: ../vector/v.proj/main.c:118 ../vector/v.proj/main.c:125
-#, fuzzy
-msgid "Target"
-#: ../raster/r.proj/main.c:192 ../imagery/i.rectify/main.c:143
-msgid "Interpolation method to use"
-msgstr ""
-#: ../raster/r.proj/main.c:200 ../raster/r.in.gdal/main.c:104
-msgid "Cache size (MiB)"
-msgstr ""
-#: ../raster/r.proj/main.c:206
-#, fuzzy
-msgid "Resolution of output raster map"
-#: ../raster/r.proj/main.c:211
-msgid "List raster maps in input location and exit"
-msgstr ""
-#: ../raster/r.proj/main.c:215
-msgid "Do not perform region cropping optimization"
-msgstr ""
-#: ../raster/r.proj/main.c:220
-msgid "Print input map's bounds in the current projection and exit"
-msgstr ""
-#: ../raster/r.proj/main.c:226
-msgid "Print input map's bounds in the current projection and exit (shell style)"
-msgstr ""
-#: ../raster/r.proj/main.c:251 ../vector/v.proj/main.c:144
-#: ../vector/v.external/main.c:87
-#, c-format
-msgid "option <%s>: <%s> exists."
-msgstr ""
-#: ../raster/r.proj/main.c:257 ../vector/v.proj/main.c:161
-msgid "Input and output locations can not be the same"
-msgstr ""
-#: ../raster/r.proj/main.c:259
-msgid "Input and output locations are the same"
-msgstr ""
-#: ../raster/r.proj/main.c:269
-#, fuzzy
-msgid "Unable to get projection info of output raster map"
-#: ../raster/r.proj/main.c:272
-#, fuzzy
-msgid "Unable to get projection units of output raster map"
-#: ../raster/r.proj/main.c:275
-#, fuzzy
-msgid "Unable to get projection key values of output raster map"
-#: ../raster/r.proj/main.c:284
-#, fuzzy, c-format
-msgid "Mapset <%s> in input location <%s> - %s"
-#: ../raster/r.proj/main.c:286 ../raster/r.in.gdal/main.c:691
-#: ../imagery/i.rectify/target.c:33 ../vector/v.rectify/target.c:38
-msgid "permission denied"
-msgstr ""
-#: ../raster/r.proj/main.c:287 ../raster/r.in.gdal/main.c:692
-#, fuzzy
-msgid "not found"
-#: ../raster/r.proj/main.c:293 ../vector/v.proj/main.c:185
-#, fuzzy, c-format
-msgid "Checking location <%s> mapset <%s>"
-#: ../raster/r.proj/main.c:305 ../vector/v.in.ogr/main.c:310
-#: ../vector/v.net/args.c:111 ../vector/v.net/args.c:117
-#: ../vector/v.net/args.c:123 ../vector/v.net/args.c:127
-#: ../vector/v.net/args.c:137 ../vector/v.proj/main.c:197
-#: ../vector/v.edit/main.c:84 ../vector/v.external/main.c:66
-#: ../vector/v.select/main.c:86
-#, c-format
-msgid "Required parameter <%s> not set"
-msgstr ""
-#: ../raster/r.proj/main.c:308
-#, fuzzy, c-format
-msgid "Raster map <%s> in location <%s> in mapset <%s> not found"
-#: ../raster/r.proj/main.c:316
-#, fuzzy
-msgid "Unable to get projection info of input map"
-#: ../raster/r.proj/main.c:319
-#, fuzzy
-msgid "Unable to get projection units of input map"
-#: ../raster/r.proj/main.c:322
-#, fuzzy
-msgid "Unable to get projection key values of input map"
-#: ../raster/r.proj/main.c:337
-msgid "Unable to work with unprojected data (xy location)"
-msgstr ""
-#: ../raster/r.proj/main.c:356
-#, fuzzy, c-format
-msgid "Input map <%s@%s> in location <%s>:"
-#: ../raster/r.proj/main.c:445
-msgid "Input:"
-msgstr ""
-#: ../raster/r.proj/main.c:446 ../raster/r.proj/main.c:457
-#, c-format
-msgid "Cols: %d (%d)"
-msgstr ""
-#: ../raster/r.proj/main.c:447 ../raster/r.proj/main.c:458
-#, c-format
-msgid "Rows: %d (%d)"
-msgstr ""
-#: ../raster/r.proj/main.c:448 ../raster/r.proj/main.c:459
-#, c-format
-msgid "North: %f (%f)"
-msgstr ""
-#: ../raster/r.proj/main.c:449 ../raster/r.proj/main.c:460
-#, c-format
-msgid "South: %f (%f)"
-msgstr ""
-#: ../raster/r.proj/main.c:450 ../raster/r.proj/main.c:461
-#, c-format
-msgid "West: %f (%f)"
-msgstr ""
-#: ../raster/r.proj/main.c:451 ../raster/r.proj/main.c:462
-#, c-format
-msgid "East: %f (%f)"
-msgstr ""
-#: ../raster/r.proj/main.c:452 ../raster/r.proj/main.c:463
-#, c-format
-msgid "EW-res: %f"
-msgstr ""
-#: ../raster/r.proj/main.c:453 ../raster/r.proj/main.c:464
-#, c-format
-msgid "NS-res: %f"
-msgstr ""
-#: ../raster/r.proj/main.c:456
-msgid "Output:"
-msgstr ""
-#: ../raster/r.proj/main.c:492
-#, fuzzy
-msgid "Projecting..."
-#: ../raster/r.proj/bordwalk.c:183
-#, fuzzy
-msgid "Input raster map is outside current region"
-#: ../raster/r.info/main.c:71 ../vector/v.info/main.c:41
-msgid "history"
-msgstr ""
-#: ../raster/r.info/main.c:73
-#, fuzzy
-msgid "Outputs basic information about a raster map."
-#: ../raster/r.info/main.c:79
-#, fuzzy
-msgid "Print raster array information only"
-#: ../raster/r.info/main.c:87
-msgid "Print extended metadata information only"
-msgstr ""
-#: ../raster/r.info/main.c:91
-msgid "Print raster history instead of info"
-msgstr ""
-#: ../raster/r.info/main.c:122
-#, fuzzy
-msgid "Unable to read range file"
-#: ../raster/r.reclass/reclass.c:50 ../raster/r.reclass/reclass.c:110
-msgid "Too many categories"
-msgstr ""
-#: ../raster/r.reclass/reclass.c:215
-#, fuzzy, c-format
-msgid "Cannot read header file of <%s@%s>"
-#: ../raster/r.reclass/reclass.c:230
-#, fuzzy, c-format
-msgid "Cannot create reclass file of <%s>"
-#: ../raster/r.reclass/reclass.c:238
-#, fuzzy, c-format
-msgid "Cannot create raster map <%s>"
-#: ../raster/r.reclass/main.c:51
-#, fuzzy
-msgid "reclassification"
-#: ../raster/r.reclass/main.c:52
-#, fuzzy
-msgid "Reclassify raster map based on category values."
-#: ../raster/r.reclass/main.c:54
-msgid "Creates a new raster map whose category values are based upon a reclassification of the categories in an existing raster map."
-msgstr ""
-#: ../raster/r.reclass/main.c:59
-#, fuzzy
-msgid "Name of raster map to be reclassified"
-#: ../raster/r.reclass/main.c:65
-#, fuzzy
-msgid "File containing reclass rules"
-#: ../raster/r.reclass/main.c:72
-msgid "Title for the resulting raster map"
-msgstr ""
-#: ../raster/r.reclass/main.c:83
-msgid "Input map can NOT be the same as output map"
-msgstr ""
-#: ../raster/r.reclass/main.c:89
-#, fuzzy, c-format
-msgid "Cannot open rules file <%s>"
-#: ../raster/r.reclass/main.c:103
-#, c-format
-msgid "Enter rule(s), \"end\" when done, \"help\" if you need it\n"
-msgstr ""
-#: ../raster/r.reclass/main.c:105
-#, c-format
-msgid "FCELL: Data range is %.7g to %.7g\n"
-msgstr ""
-#: ../raster/r.reclass/main.c:108
-#, c-format
-msgid "DCELL: Data range is %.15g to %.15g\n"
-msgstr ""
-#: ../raster/r.reclass/main.c:111
-#, fuzzy, c-format
-msgid "CELL: Data range is %ld to %ld\n"
-#: ../raster/r.reclass/main.c:119
-#, c-format
-msgid "Illegal reclass rule -"
-msgstr ""
-#: ../raster/r.reclass/main.c:120
-#, c-format
-msgid " ignored\n"
-msgstr ""
-#: ../raster/r.reclass/main.c:123
-msgid " - invalid reclass rule"
-msgstr ""
-#: ../raster/r.reclass/main.c:139
-#, c-format
-msgid "No rules specified. Raster map <%s> not created"
-msgstr ""
-#: ../raster/r.reclass/parse.c:42
-msgid "poor quality"
-msgstr ""
-#: ../raster/r.reclass/parse.c:44
-msgid "medium quality"
-msgstr ""
-#: ../raster/r.reclass/parse.c:59
-msgid "Can't have null on the left-hand side of the rule"
-msgstr ""
-#: ../raster/r.reclass/parse.c:88 ../raster/r.reclass/parse.c:100
-msgid "Can't have null on the right-hand side of the rule"
-msgstr ""
-#: ../raster/r.reclass/parse.c:196
-#, c-format
-msgid "%f rounded up to %d\n"
-msgstr ""
-#: ../raster/r.coin/main.c:69
-msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
-msgstr ""
-#: ../raster/r.coin/main.c:77
-#, fuzzy
-msgid "Name of first raster map"
-#: ../raster/r.coin/main.c:84
-#, fuzzy
-msgid "Name of second raster map"
-#: ../raster/r.coin/main.c:90
-msgid "Unit of measure"
-msgstr ""
-#: ../raster/r.coin/main.c:92
-msgid "c(ells), p(ercent), x(percent of category [column]), y(percent of category [row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
-msgstr ""
-#: ../raster/r.coin/main.c:99
-msgid "Wide report, 132 columns (default: 80)"
-msgstr ""
-#: ../raster/r.coin/make_coin.c:48
-#, c-format
-msgid "Tabulating Coincidence between '%s' and '%s'"
-msgstr ""
-#: ../raster/r.coin/make_coin.c:61
-#, fuzzy
-msgid "Unable to create any tempfiles"
-#: ../raster/r.coin/make_coin.c:65
-#, fuzzy
-msgid "Unable to run r.stats"
-#: ../raster/r.coin/make_coin.c:72
-msgid "Unexpected output from r.stats"
-msgstr ""
-#: ../raster/r.coin/make_coin.c:84
-#, fuzzy
-msgid "Unable to open tempfile"
-#: ../raster/r.coin/print_coin.c:44
-#, c-format
-msgid "Preparing report ..."
-msgstr ""
-#: ../raster/r.texture/h_measure.c:123
-#, c-format
-msgid "Too many categories (found: %i, max: %i). Try to rescale or reclassify the map"
-msgstr ""
-#: ../raster/r.texture/main.c:67
-#, fuzzy, c-format
-msgid "Unknown measure <%s>"
-#: ../raster/r.texture/main.c:104
-#, fuzzy
-msgid "texture"
-#: ../raster/r.texture/main.c:106
-#, fuzzy
-msgid "Generate images with textural features from a raster map."
-#: ../raster/r.texture/main.c:117
-#, fuzzy
-msgid "Prefix for output raster map(s)"
-#: ../raster/r.texture/main.c:124
-msgid "The size of moving window (odd and >= 3)"
-msgstr ""
-#: ../raster/r.texture/main.c:134
-msgid "The distance between two samples (>= 1)"
-msgstr ""
-#: ../raster/r.texture/main.c:150
-#, fuzzy
-msgid "Textural measurement method"
-#: ../raster/r.texture/main.c:154
-msgid "Separate output for each angle (0, 45, 90, 135)"
-msgstr ""
-#: ../raster/r.texture/main.c:158
-#, fuzzy
-msgid "Calculate all textural measurements"
-#: ../raster/r.texture/main.c:167
-msgid "Size of the moving window must be > 0"
-msgstr ""
-#: ../raster/r.texture/main.c:169
-msgid "Size of the moving window must be odd"
-msgstr ""
-#: ../raster/r.texture/main.c:172
-msgid "The distance between two samples must be > 0"
-msgstr ""
-#: ../raster/r.texture/main.c:193
-msgid "Nothing to compute. Use at least one textural measure."
-msgstr ""
-#: ../raster/r.texture/main.c:331
-#, fuzzy, c-format
-msgid "Calculating %d texture measures"
-#: ../raster/r.texture/main.c:333
-#, fuzzy, c-format
-msgid "Calculating %s"
-#: ../raster/r.in.gdal/main.c:84
-#, fuzzy
-msgid "Imports raster data into a GRASS raster map using GDAL library."
-#: ../raster/r.in.gdal/main.c:90
-#, fuzzy
-msgid "Name of raster file to be imported"
-#: ../raster/r.in.gdal/main.c:98
-msgid "Band to select (default is all bands)"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:111
-msgid "Name of location to read projection from for GCPs transformation"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:127
-msgid "The offset will be added to the band number while output raster map name creation"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:134 ../vector/v.in.ogr/main.c:198
-#: ../vector/v.in.lidar/main.c:178
-msgid "Name for new location to create"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:157
-msgid "Force Lat/Lon maps to fit into geographic coordinates (90N,S; 180E,W)"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:162
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:13
-msgid "Keep band numbers instead of using band color names"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:167
-msgid "Create the location specified by the \"location\" parameter and exit. Do not import the raster file."
-msgstr ""
-#: ../raster/r.in.gdal/main.c:192
-msgid "You have to specify a target location different from output location"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:196
-msgid "You need to specify valid location name."
-msgstr ""
-#: ../raster/r.in.gdal/main.c:200
-msgid "The '-l' flag only works in Lat/Lon locations"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:218
-msgid "Available GDAL Drivers:"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:240 ../imagery/i.landsat.toar/main.c:482
-#, fuzzy, c-format
-msgid "Raster map <%s> already exists and will be overwritten"
-#: ../raster/r.in.gdal/main.c:243
-#, fuzzy, c-format
-msgid "Raster map <%s> already exists"
-#: ../raster/r.in.gdal/main.c:260
-msgid "The polynomial rectification used in i.rectify does not work well with NOAA/AVHRR data. Try using gdalwarp with thin plate spline rectification instead. (-tps)"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:276
-msgid "Input raster map is flipped or rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
-msgstr ""
-#: ../raster/r.in.gdal/main.c:317
-msgid "Map bounds have been constrained to geographic coordinates. You will almost certainly want to check map bounds and resolution with r.info and reset them with r.region before going any further."
-msgstr ""
-#: ../raster/r.in.gdal/main.c:337 ../vector/v.in.ogr/main.c:517
-#: ../vector/v.in.lidar/main.c:341
-msgid "Unable to convert input map projection to GRASS format; cannot create new location."
-msgstr ""
-#: ../raster/r.in.gdal/main.c:343 ../general/g.proj/create.c:15
-#: ../vector/v.in.ogr/main.c:523 ../vector/v.in.lidar/main.c:347
-#, fuzzy, c-format
-msgid "Location <%s> created"
-#: ../raster/r.in.gdal/main.c:447
-msgid ""
-"\n"
-"You can use the -o flag to r.in.gdal to override this check and use the location definition for the dataset.\n"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:565
-#, fuzzy, c-format
-msgid "Copying %d GCPS in points file for <%s>"
-#: ../raster/r.in.gdal/main.c:570
-msgid "GCPs have the following OpenGIS WKT Coordinate System:"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:577
-#, fuzzy
-msgid "Re-projecting GCPs table:"
-#: ../raster/r.in.gdal/main.c:578
-#, c-format
-msgid "* Input projection for GCP table: %s"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:580
-#, c-format
-msgid "* Output projection for GCP table: %s"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:597
-#, c-format
-msgid "Error in pj_do_proj (can't re-projection GCP %i)"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:666
-#, fuzzy
-msgid "Unable to translate projection key values of input GCPs"
-msgstr "डेटाबेसची यादी दाखवता येणार नाही"
-#: ../raster/r.in.gdal/main.c:682
-#, fuzzy
-msgid "Unable to get projection info of target location"
-#: ../raster/r.in.gdal/main.c:684
-#, fuzzy
-msgid "Unable to get projection units of target location"
-#: ../raster/r.in.gdal/main.c:686
-#, fuzzy
-msgid "Unable to get projection key values of target location"
-#: ../raster/r.in.gdal/main.c:689 ../imagery/i.rectify/target.c:32
-#: ../vector/v.rectify/target.c:37
-#, fuzzy, c-format
-msgid "Mapset <%s> in target location <%s> - "
-#: ../raster/r.in.gdal/main.c:949
-#, fuzzy, c-format
-msgid "Setting grey color table for <%s> (8bit, full range)"
-#: ../raster/r.in.gdal/main.c:962
-#, fuzzy, c-format
-msgid "Setting grey color table for <%s> (16bit, image range)"
-#: ../raster/r.horizon/main.c:180
-msgid "Horizon angle computation from a digital elevation model."
-msgstr ""
-#: ../raster/r.horizon/main.c:182
-msgid "Computes horizon angle height from a digital elevation model. The module has two different modes of operation:  1. Computes the entire horizon around a single point whose coordinates are given with the 'coord' option. The horizon height (in radians). 2. Computes one or more raster maps of the horizon height in a single direction.  The input for this is the angle (in degrees), which is measured  counterclockwise with east=0, north=90 etc. The output is the horizon height in radians."
-msgstr ""
-#: ../raster/r.horizon/main.c:205
-msgid "Direction in which you want to know the horizon height"
-msgstr ""
-#: ../raster/r.horizon/main.c:221
-msgid "For horizon rasters, read from the DEM an extra buffer around the present region"
-msgstr ""
-#: ../raster/r.horizon/main.c:229
-msgid "For horizon rasters, read from the DEM an extra buffer eastward the present region"
-msgstr ""
-#: ../raster/r.horizon/main.c:237
-msgid "For horizon rasters, read from the DEM an extra buffer westward the present region"
-msgstr ""
-#: ../raster/r.horizon/main.c:245
-msgid "For horizon rasters, read from the DEM an extra buffer northward the present region"
-msgstr ""
-#: ../raster/r.horizon/main.c:253
-msgid "For horizon rasters, read from the DEM an extra buffer southward the present region"
-msgstr ""
-#: ../raster/r.horizon/main.c:261
-msgid "The maximum distance to consider when finding the horizon height"
-msgstr ""
-#: ../raster/r.horizon/main.c:270
-#, fuzzy
-msgid "Prefix of the horizon raster output maps"
-#: ../raster/r.horizon/main.c:280
-msgid "Coordinate for which you want to calculate the horizon"
-msgstr ""
-#: ../raster/r.horizon/main.c:295
-msgid "Write output in degrees (default is radians)"
-msgstr ""
-#: ../raster/r.horizon/main.c:343
-msgid "Can't read the coordinates from the \"coord\" option."
-msgstr ""
-#: ../raster/r.horizon/main.c:361
-msgid "You didn't specify a direction value or step size. Aborting."
-msgstr ""
-#: ../raster/r.horizon/main.c:366
-msgid "You didn't specify a horizon raster name. Aborting."
-msgstr ""
-#: ../raster/r.horizon/main.c:376
-msgid "You didn't specify an angle step size. Aborting."
-msgstr ""
-#: ../raster/r.horizon/main.c:389
-#, fuzzy
-msgid "Could not read bufferzone size. Aborting."
-#: ../raster/r.horizon/main.c:394 ../raster/r.horizon/main.c:400
-#: ../raster/r.horizon/main.c:407 ../raster/r.horizon/main.c:414
-#, c-format
-msgid "Could not read %s bufferzone size. Aborting."
-msgstr ""
-#: ../raster/r.horizon/main.c:395
-msgid "east"
-msgstr ""
-#: ../raster/r.horizon/main.c:401
-msgid "west"
-msgstr ""
-#: ../raster/r.horizon/main.c:408
-msgid "south"
-msgstr ""
-#: ../raster/r.horizon/main.c:415
-msgid "north"
-msgstr ""
-#: ../raster/r.horizon/main.c:420
-msgid "Could not read maximum distance. Aborting."
-msgstr ""
-#: ../raster/r.horizon/main.c:471
-msgid "Can't get projection info of current location: please set latitude via 'lat' or 'latin' option!"
-msgstr ""
-#: ../raster/r.horizon/main.c:786 ../raster/r.horizon/main.c:804
-#: ../imagery/i.latlong/main.c:134 ../ps/ps.map/do_geogrid.c:86
-#: ../ps/ps.map/do_geogrid.c:91 ../ps/ps.map/do_geogrid.c:115
-#: ../ps/ps.map/do_geogrid.c:120 ../ps/ps.map/do_geogrid.c:190
-#: ../ps/ps.map/do_geogrid.c:229 ../ps/ps.map/do_geogrid.c:305
-#: ../ps/ps.map/do_geogrid.c:321 ../ps/ps.map/do_geogrid.c:338
-#: ../ps/ps.map/do_geogrid.c:355 ../ps/ps.map/do_geogrid.c:411
-#: ../ps/ps.map/do_geogrid.c:417 ../ps/ps.map/do_geogrid.c:421
-#: ../ps/ps.map/do_geogrid.c:429 ../ps/ps.map/do_geogrid.c:433
-#: ../display/d.grid/plot.c:196 ../display/d.grid/plot.c:202
-#: ../display/d.grid/plot.c:254 ../display/d.grid/plot.c:260
-#: ../display/d.grid/plot.c:420 ../display/d.grid/plot.c:436
-#: ../display/d.grid/plot.c:453 ../display/d.grid/plot.c:470
-msgid "Error in pj_do_proj"
-msgstr ""
-#: ../raster/r.horizon/main.c:1106
-#, fuzzy, c-format
-msgid "Calculating map %01d of %01d (angle %.2f, raster map <%s>)"
-#: ../raster/simwe/r.sim.sediment/main.c:113
-msgid "sediment flow"
-msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:115
-msgid "deposition"
-msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:117
-msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
-msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:124
-#, fuzzy
-msgid "Name of water depth raster map [m]"
-#: ../raster/simwe/r.sim.sediment/main.c:128
-#: ../raster/simwe/r.sim.water/main.c:120
-#, fuzzy
-msgid "Name of x-derivatives raster map [m/m]"
-#: ../raster/simwe/r.sim.sediment/main.c:132
-#: ../raster/simwe/r.sim.water/main.c:124
-#, fuzzy
-msgid "Name of y-derivatives raster map [m/m]"
-#: ../raster/simwe/r.sim.sediment/main.c:137
-#, fuzzy
-msgid "Name of detachment capacity coefficient raster map [s/m]"
-#: ../raster/simwe/r.sim.sediment/main.c:142
-#, fuzzy
-msgid "Name of transport capacity coefficient raster map [s]"
-#: ../raster/simwe/r.sim.sediment/main.c:147
-#, fuzzy
-msgid "Name of critical shear stress raster map [Pa]"
-#: ../raster/simwe/r.sim.sediment/main.c:152
-#: ../raster/simwe/r.sim.water/main.c:161
-#, fuzzy
-msgid "Name of mannings n raster map"
-#: ../raster/simwe/r.sim.sediment/main.c:160
-#, fuzzy
-msgid "Name of mannings n value"
-#: ../raster/simwe/r.sim.sediment/main.c:167
-#: ../raster/simwe/r.sim.water/main.c:215
-#, fuzzy
-msgid "Base name of the output walkers vector points map"
-#: ../raster/simwe/r.sim.sediment/main.c:174
-#: ../raster/simwe/r.sim.water/main.c:183
-#, fuzzy
-msgid "Name of the sampling locations vector points map"
-#: ../raster/simwe/r.sim.sediment/main.c:181
-msgid "Name of the sampling points output text file. For each observation vector point the time series of sediment transport is stored."
-msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:187
-#, fuzzy
-msgid "Name for output transport capacity raster map [kg/ms]"
-#: ../raster/simwe/r.sim.sediment/main.c:194
-#, fuzzy
-msgid "Name for output transp.limited erosion-deposition raster map [kg/m2s]"
-#: ../raster/simwe/r.sim.sediment/main.c:201
-#, fuzzy
-msgid "Name for output sediment concentration raster map [particle/m3]"
-#: ../raster/simwe/r.sim.sediment/main.c:207
-#, fuzzy
-msgid "Name for output sediment flux raster map [kg/ms]"
-#: ../raster/simwe/r.sim.sediment/main.c:214
-#, fuzzy
-msgid "Name for output erosion-deposition raster map [kg/m2s]"
-#: ../raster/simwe/r.sim.sediment/main.c:221
-msgid "Number of walkers"
-msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:229
-#: ../raster/simwe/r.sim.water/main.c:231
-msgid "Time used for iterations [minutes]"
-msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:238
-#: ../raster/simwe/r.sim.water/main.c:240
-msgid "Time interval for creating output maps [minutes]"
-msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:256
-#: ../raster/simwe/r.sim.water/main.c:258
-msgid "Water diffusion constant"
-msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:336
-#: ../raster/simwe/r.sim.water/main.c:432
-msgid "More than 100 files are going to be created !!!!!"
-msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:342
-#: ../raster/simwe/r.sim.water/main.c:438
-#, c-format
-msgid "default nwalk=%d, rwalk=%f"
-msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:351
-#: ../raster/simwe/r.sim.water/main.c:448
-#, c-format
-msgid "Using metric conversion factor %f, step=%f"
-msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:357
-#, fuzzy
-msgid "You are not outputting any raster or site files"
-#: ../raster/simwe/r.sim.sediment/main.c:360
-#: ../raster/simwe/r.sim.water/main.c:455 ../vector/v.surf.rst/main.c:609
-#: ../vector/v.surf.rst/main.c:664
-msgid "Input failed"
-msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:384
-#: ../raster/simwe/r.sim.water/main.c:474
-#, fuzzy
-msgid "Cannot write raster maps"
-#: ../raster/simwe/r.sim.water/main.c:113
-msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
-msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:130
-#, fuzzy
-msgid "Name of rainfall excess rate (rain-infilt) raster map [mm/hr]"
-#: ../raster/simwe/r.sim.water/main.c:139
-msgid "Rainfall excess rate unique value [mm/hr]"
-msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:146
-#, fuzzy
-msgid "Name of runoff infiltration rate raster map [mm/hr]"
-#: ../raster/simwe/r.sim.water/main.c:155
-#, fuzzy
-msgid "Runoff infiltration rate unique value [mm/hr]"
-#: ../raster/simwe/r.sim.water/main.c:169
-msgid "Mannings n unique value"
-msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:176
-#, fuzzy
-msgid "Name of flow controls raster map (permeability ratio 0-1)"
-#: ../raster/simwe/r.sim.water/main.c:190
-msgid "Name of the sampling points output text file. For each observation vector point the time series of water depth is stored."
-msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:196
-#, fuzzy
-msgid "Name for output water depth raster map [m]"
-#: ../raster/simwe/r.sim.water/main.c:202
-#, fuzzy
-msgid "Name for output water discharge raster map [m3/s]"
-#: ../raster/simwe/r.sim.water/main.c:208
-#, fuzzy
-msgid "Name for output simulation error raster map [m]"
-#: ../raster/simwe/r.sim.water/main.c:223
-msgid "Number of walkers, default is twice the no. of cells"
-msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:267
-msgid "Threshold water depth [m]"
-msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:268
-msgid "Diffusion increases after this water depth is reached"
-msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:276
-msgid "Diffusion increase constant"
-msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:285
-msgid "Weighting factor for water flow velocity vector"
-msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:290
-msgid "Time-series output"
-msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:452
-#, fuzzy
-msgid "You are not outputting any raster maps"
-#: ../raster/simwe/simlib/hydro.c:205
-#, c-format
-msgid "nwalk (%d) > maxw (%d)!"
-msgstr ""
-#: ../raster/simwe/simlib/hydro.c:400
-#, fuzzy
-msgid "Unable to write raster maps"
-#: ../raster/simwe/simlib/observation_points.c:59
-#, fuzzy, c-format
-msgid "Unable to read points from map %s"
-#: ../raster/simwe/simlib/observation_points.c:80
-#, fuzzy, c-format
-msgid "Unable to open observation logfile %s for writing"
-#: ../raster/simwe/simlib/input.c:58
-#, c-format
-msgid "Raster map <%s> not found, and manin_val undefined, choose one to be allowed to process"
-msgstr ""
-#: ../raster/simwe/simlib/input.c:171
-msgid "Zero value in Mannings n"
-msgstr ""
-#: ../raster/simwe/simlib/input.c:222
-msgid "Infiltration exceeds the rainfall rate everywhere! No overland flow."
-msgstr ""
-#: ../raster/simwe/simlib/input.c:246
-#, c-format
-msgid ""
-"Min elevation \t= %.2f m\n"
-"Max elevation \t= %.2f m\n"
-msgstr ""
-#: ../raster/simwe/simlib/input.c:248
-#, c-format
-msgid "Mean Source Rate (rainf. excess or sediment) \t= %f m/s or kg/m2s \n"
-msgstr ""
-#: ../raster/simwe/simlib/input.c:250
-#, c-format
-msgid "Mean flow velocity \t= %f m/s\n"
-msgstr ""
-#: ../raster/simwe/simlib/input.c:251
-#, c-format
-msgid "Mean Mannings \t= %f\n"
-msgstr ""
-#: ../raster/simwe/simlib/input.c:255
-#, fuzzy, c-format
-msgid "Number of iterations \t= %d cells\n"
-#: ../raster/simwe/simlib/input.c:256
-#, c-format
-msgid "Time step \t= %.2f s\n"
-msgstr ""
-#: ../raster/simwe/simlib/input.c:258
-#, c-format
-msgid ""
-"Sigmax \t= %f\n"
-"Max velocity \t= %f m/s\n"
-msgstr ""
-#: ../raster/simwe/simlib/input.c:260
-#, c-format
-msgid "Time step used \t= %.2f s\n"
-msgstr ""
-#: ../raster/simwe/simlib/input.c:312
-#, fuzzy
-msgid "Unable to write et file"
-#: ../raster/simwe/simlib/output.c:304 ../raster/simwe/simlib/output.c:312
-#, fuzzy, c-format
-msgid "FP raster map <%s> not found"
-#: ../raster/r.thin/main.c:59
-msgid "Thins non-zero cells that denote linear features in a raster map layer."
-msgstr ""
-#: ../raster/r.thin/main.c:71
-msgid "Maximal number of iterations"
-msgstr ""
-#: ../raster/r.thin/io.c:96
-#, fuzzy
-msgid "Input raster must be of type CELL."
-#: ../raster/r.thin/io.c:101
-#, c-format
-msgid "File %s -- %d rows X %d columns"
-msgstr ""
-#: ../raster/r.thin/io.c:111
-#, fuzzy, c-format
-msgid "%s: Unable to create temporary file <%s> -- errno = %d"
-#: ../raster/r.thin/io.c:120 ../raster/r.thin/io.c:128
-#: ../raster/r.thin/io.c:138
-#, fuzzy, c-format
-msgid "%s: Error writing temporary file"
-#: ../raster/r.thin/io.c:161
-#, c-format
-msgid "Output file %d rows X %d columns"
-msgstr ""
-#: ../raster/r.thin/io.c:162
-#, c-format
-msgid "Window %d rows X %d columns"
-msgstr ""
-#: ../raster/r.thin/thin_lines.c:68
-#, c-format
-msgid "%s: Unable to find bounding box for lines"
-msgstr ""
-#: ../raster/r.thin/thin_lines.c:71
-#, c-format
-msgid "Bounding box:  l = %d, r = %d, t = %d, b = %d"
-msgstr ""
-#: ../raster/r.thin/thin_lines.c:118
-#, c-format
-msgid "Pass number %d"
-msgstr ""
-#: ../raster/r.thin/thin_lines.c:169
-#, c-format
-msgid "Deleted %d  pixels "
-msgstr ""
-#: ../raster/r.thin/thin_lines.c:173
-msgid "Thinning completed successfully."
-msgstr ""
-#: ../raster/r.thin/thin_lines.c:175
-msgid "Thinning not completed, consider to increase 'iterations' parameter."
-msgstr ""
-#: ../raster/r.covar/main.c:54
-msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
-msgstr ""
-#: ../raster/r.covar/main.c:61
-msgid "Print correlation matrix"
-msgstr ""
-#: ../raster/r.covar/main.c:86
-#, c-format
-msgid "%s: complete ... "
-msgstr ""
-#: ../raster/r.covar/main.c:110 ../imagery/i.pca/main.c:143
-msgid "No non-null values"
-msgstr ""
-#: ../raster/r.out.gdal/export_band.c:63
-#: ../raster/r.out.gdal/export_band.c:354
-#, fuzzy
-msgid "Unable to allocate buffer for reading raster map"
-#: ../raster/r.out.gdal/export_band.c:171
-#, c-format
-msgid "Input raster map contains cells with NULL-value (no-data). The value %d will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
-msgstr ""
-#: ../raster/r.out.gdal/export_band.c:176
-#, c-format
-msgid "Input raster map contains cells with NULL-value (no-data). The value %g will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
-msgstr ""
-#: ../raster/r.out.gdal/export_band.c:186
-#, c-format
-msgid "The default nodata value is present in rasterband <%s> and would lead to data loss. Please specify a custom nodata value with the %s parameter."
-msgstr ""
-#: ../raster/r.out.gdal/export_band.c:193
-#, c-format
-msgid "The user given nodata value %g is present in rasterband <%s> and would lead to data loss. Please specify a different nodata value with the %s parameter."
-msgstr ""
-#: ../raster/r.out.gdal/export_band.c:235
-#, fuzzy
-msgid "Unable to get raster band"
-#: ../raster/r.out.gdal/export_band.c:391
-#: ../raster/r.out.gdal/export_band.c:420
-#: ../raster/r.out.gdal/export_band.c:449
-#, fuzzy
-msgid "Unable to write GDAL raster file"
-#: ../raster/r.out.gdal/export_band.c:468
-#: ../raster/r.out.gdal/export_band.c:480
-#: ../raster/r.out.gdal/export_band.c:493
-#: ../raster/r.out.gdal/export_band.c:506
-#: ../raster/r.out.gdal/export_band.c:518
-#: ../raster/r.out.gdal/export_band.c:531
-#: ../raster/r.out.gdal/export_band.c:545 ../raster/r.out.gdal/main.c:625
-#: ../raster/r.out.gdal/main.c:637 ../raster/r.out.gdal/main.c:650
-#: ../raster/r.out.gdal/main.c:663 ../raster/r.out.gdal/main.c:675
-#: ../raster/r.out.gdal/main.c:688
-msgid "Selected GDAL datatype does not cover data range."
-msgstr ""
-#: ../raster/r.out.gdal/export_band.c:469
-#: ../raster/r.out.gdal/export_band.c:481
-#: ../raster/r.out.gdal/export_band.c:494
-#: ../raster/r.out.gdal/export_band.c:507 ../raster/r.out.gdal/main.c:626
-#: ../raster/r.out.gdal/main.c:638 ../raster/r.out.gdal/main.c:651
-#: ../raster/r.out.gdal/main.c:664
-#, c-format
-msgid "GDAL datatype: %s, range: %d - %d"
-msgstr ""
-#: ../raster/r.out.gdal/export_band.c:472
-#: ../raster/r.out.gdal/export_band.c:484
-#: ../raster/r.out.gdal/export_band.c:497
-#: ../raster/r.out.gdal/export_band.c:510
-#: ../raster/r.out.gdal/export_band.c:522
-#: ../raster/r.out.gdal/export_band.c:535
-#: ../raster/r.out.gdal/export_band.c:549
-#, fuzzy, c-format
-msgid "Raster map <%s> range: %g - %g"
-#: ../raster/r.out.gdal/export_band.c:519 ../raster/r.out.gdal/main.c:676
-#, c-format
-msgid "GDAL datatype: %s, range: %u - %u"
-msgstr ""
-#: ../raster/r.out.gdal/export_band.c:532
-#: ../raster/r.out.gdal/export_band.c:546 ../raster/r.out.gdal/main.c:689
-#, c-format
-msgid "GDAL datatype: %s, range: %g - %g"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:50
-#, c-format
-msgid "Supported formats:\n"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:128
-msgid "Exports GRASS raster maps into GDAL supported formats."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:134
-msgid "List supported output formats"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:140
-#, fuzzy
-msgid "Do not write GDAL standard colortable"
-#: ../raster/r.out.gdal/main.c:141
-msgid "Only applicable to Byte or UInt16 data types."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:142 ../raster/r.out.gdal/main.c:184
-#: ../raster/r.out.gdal/main.c:195 ../raster/r.out.gdal/main.c:206
-#: ../raster/r.out.gdal/main.c:215 ../vector/v.out.ogr/args.c:40
-#: ../vector/v.out.ogr/args.c:59 ../vector/v.out.ogr/args.c:69
-#: ../vector/v.out.ogr/args.c:83 ../vector/v.out.ogr/args.c:96
-#: ../vector/v.out.ogr/args.c:102 ../vector/v.out.ogr/args.c:107
-#: ../vector/v.out.ogr/args.c:114
-msgid "Creation"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:146
-msgid "Force raster export despite any warnings of data loss"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:147
-msgid "Overrides nodata safety check."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:150
-#, fuzzy
-msgid "Name of raster map (or group) to export"
-#: ../raster/r.out.gdal/main.c:153
-#, fuzzy
-msgid "Name for output raster file"
-#: ../raster/r.out.gdal/main.c:159
-msgid "Raster data format to write (case sensitive, see also -l flag)"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:180
-#, fuzzy
-msgid "Data type"
-#: ../raster/r.out.gdal/main.c:190
-msgid "Creation option(s) to pass to the output format driver"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:192
-msgid "In the form of \"NAME=VALUE\", separate multiple entries with a comma."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:200
-msgid "Metadata key(s) and value(s) to include"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:202
-msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. Not supported by all output format drivers."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:212
-msgid "Assign a specified nodata value to output bands"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:242
-#, fuzzy, c-format
-msgid "Raster map or group <%s> not found"
-#: ../raster/r.out.gdal/main.c:246
-#, fuzzy, c-format
-msgid "No raster maps in group <%s>"
-#: ../raster/r.out.gdal/main.c:260
-#, fuzzy, c-format
-msgid "Unable to get <%s> driver"
-#: ../raster/r.out.gdal/main.c:266
-#, c-format
-msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:271
-#, fuzzy
-msgid "Unable to get in-memory raster driver"
-#: ../raster/r.out.gdal/main.c:275
-#, c-format
-msgid "Driver <%s> does not support creating rasters"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:351
-#, fuzzy, c-format
-msgid "Could not read data range of raster <%s>"
-#: ../raster/r.out.gdal/main.c:408
-#, c-format
-msgid "Exporting to GDAL data type: %s"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:423
-msgid "Raster export would result in complete data loss, aborting."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:434
-#, c-format
-msgid "Precision loss: Raster map <%s> of type %s to be exported as %s. This can be avoided by using %s."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:445
-#, c-format
-msgid "Precision loss: The range of <%s> can not be accurately preserved with GDAL datatype Float32. This can be avoided by exporting to Int32 or Float64."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:453
-#, c-format
-msgid "Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. This can be avoided by using Float64"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:462 ../raster/r.out.gdal/main.c:505
-#, fuzzy
-msgid "Forcing raster export."
-#: ../raster/r.out.gdal/main.c:464 ../raster/r.out.gdal/main.c:478
-#: ../raster/r.out.gdal/main.c:507 ../raster/r.out.gdal/main.c:511
-#, fuzzy
-msgid "Raster export aborted."
-#: ../raster/r.out.gdal/main.c:488
-msgid "Checking GDAL data type and nodata value..."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:491
-#, fuzzy, c-format
-msgid "Checking options for raster map <%s> (band %d)..."
-#: ../raster/r.out.gdal/main.c:536
-#, fuzzy
-msgid "Unable to create dataset using memory raster driver"
-#: ../raster/r.out.gdal/main.c:545
-#, fuzzy, c-format
-msgid "Unable to create <%s> dataset using <%s> driver"
-#: ../raster/r.out.gdal/main.c:560
-#, fuzzy
-msgid "Unable to set geo transform"
-#: ../raster/r.out.gdal/main.c:568
-#, fuzzy
-msgid "Unable to set projection"
-#: ../raster/r.out.gdal/main.c:574
-#, fuzzy, c-format
-msgid "Exporting raster data to %s format..."
-#: ../raster/r.out.gdal/main.c:577
-#, fuzzy, c-format
-msgid "Exporting raster map <%s> (band %d)..."
-#: ../raster/r.out.gdal/main.c:590
-#, fuzzy, c-format
-msgid "Unable to export raster map <%s>"
-#: ../raster/r.out.gdal/main.c:602
-#, fuzzy, c-format
-msgid "Unable to create raster map <%s> using driver <%s>"
-#: ../raster/r.out.gdal/main.c:629 ../raster/r.out.gdal/main.c:641
-#: ../raster/r.out.gdal/main.c:654 ../raster/r.out.gdal/main.c:667
-#: ../raster/r.out.gdal/main.c:679 ../raster/r.out.gdal/main.c:692
-#, fuzzy, c-format
-msgid "Range to be exported: %g - %g"
-#: ../raster/r.out.gdal/main.c:716 ../raster/r.out.gdal/main.c:729
-#: ../raster/r.out.gdal/main.c:743 ../raster/r.out.gdal/main.c:756
-#: ../raster/r.out.gdal/main.c:771
-#, c-format
-msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %d by selected GDAL datatype."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:719 ../raster/r.out.gdal/main.c:746
-#: ../raster/r.out.gdal/main.c:774
-#, c-format
-msgid "GDAL datatype: %s, valid range: %d - %d"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:732 ../raster/r.out.gdal/main.c:759
-#, c-format
-msgid "GDAL datatype: %s, valid range: %u - %u"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:785
-#, c-format
-msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %g by selected GDAL datatype."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:788
-#, c-format
-msgid "GDAL datatype: %s, valid range: %g - %g"
-msgstr ""
-#: ../raster/r.lake/main.c:152
-msgid "Fills lake at given point to given level."
-msgstr ""
-#: ../raster/r.lake/main.c:158
-msgid "Water level"
-msgstr ""
-#: ../raster/r.lake/main.c:168
-msgid "Seed point coordinates"
-msgstr ""
-#: ../raster/r.lake/main.c:177
-#, fuzzy
-msgid "Name of input raster map with given starting point(s) (at least 1 cell > 0)"
-#: ../raster/r.lake/main.c:183
-msgid "Use negative depth values for lake raster map"
-msgstr ""
-#: ../raster/r.lake/main.c:188
-msgid "Overwrite seed map with result (lake) map"
-msgstr ""
-#: ../raster/r.lake/main.c:194
-msgid "Both seed map and coordinates cannot be specified"
-msgstr ""
-#: ../raster/r.lake/main.c:197
-msgid "Seed map or seed coordinates must be set!"
-msgstr ""
-#: ../raster/r.lake/main.c:200
-msgid "Seed coordinates and output map lake= must be set!"
-msgstr ""
-#: ../raster/r.lake/main.c:203
-msgid "Both lake and overwrite cannot be specified"
-msgstr ""
-#: ../raster/r.lake/main.c:206
-msgid "Output lake map or overwrite flag must be set!"
-msgstr ""
-#: ../raster/r.lake/main.c:233
-#, fuzzy
-msgid "Seed point outside the current region"
-#: ../raster/r.lake/main.c:247
-#, fuzzy
-msgid "G_malloc: out of memory"
-#: ../raster/r.lake/main.c:269
-msgid "Given water level at seed point is below earth surface. Increase water level or move seed point."
-msgstr ""
-#: ../raster/r.lake/main.c:348
-#, c-format
-msgid "Lake depth from %f to %f"
-msgstr ""
-#: ../raster/r.lake/main.c:349
-#, c-format
-msgid "Lake area %f square meters"
-msgstr ""
-#: ../raster/r.lake/main.c:350
-#, c-format
-msgid "Lake volume %f cubic meters"
-msgstr ""
-#: ../raster/r.lake/main.c:351
-msgid "Volume is correct only if lake depth (terrain raster map) is in meters"
-msgstr ""
-#: ../raster/r.surf.gauss/main.c:42
-msgid "GRASS module to produce a raster map layer of gaussian deviates whose mean and standard deviation can be expressed by the user. It uses a gaussian random number generator."
-msgstr ""
-#: ../raster/r.surf.gauss/main.c:48
-#, fuzzy
-msgid "Name of the output random surface"
-msgstr "'%s'. ड्राइवर चालू होत नाही"
-#: ../raster/r.surf.gauss/main.c:52
-msgid "Distribution mean"
-msgstr ""
-#: ../raster/r.surf.gauss/main.c:58
-msgid "Standard deviation"
-msgstr ""
-#: ../raster/r.in.poly/get_item.c:76
-#, fuzzy, c-format
-msgid "Illegal coordinate <%s, %s>, skipping."
-#: ../raster/r.in.poly/get_item.c:81
-#, fuzzy, c-format
-msgid "Illegal north coordinate <%s>, skipping."
-#: ../raster/r.in.poly/get_item.c:86
-#, fuzzy, c-format
-msgid "Illegal east coordinate <%s>, skipping."
-#: ../raster/r.in.poly/main.c:32
-msgid "Creates raster maps from ASCII polygon/line/point data files."
-msgstr ""
-#: ../raster/r.in.poly/main.c:36
-#, fuzzy
-msgid "Name of input file; or \"-\" to read from stdin"
-#: ../raster/r.in.poly/main.c:51 ../vector/v.to.rast/main.c:102
-msgid "Number of rows to hold in memory"
-msgstr ""
-#: ../raster/r.in.poly/main.c:60
-msgid "Minimum number of rows to hold in memory is 1"
-msgstr ""
-#: ../raster/r.in.ascii/main.c:73
-#, fuzzy
-msgid "Converts a GRASS ASCII raster file to binary raster map."
-#: ../raster/r.in.ascii/main.c:77
-msgid "ASCII raster file to be imported. If not given reads from standard input"
-msgstr ""
-#: ../raster/r.in.ascii/main.c:103
-msgid "String representing NULL value data cell"
-msgstr ""
-#: ../raster/r.in.ascii/main.c:107
-msgid "Integer values are imported"
-msgstr ""
-#: ../raster/r.in.ascii/main.c:111
-msgid "Floating point values are imported"
-msgstr ""
-#: ../raster/r.in.ascii/main.c:115
-msgid "Double floating point values are imported"
-msgstr ""
-#: ../raster/r.in.ascii/main.c:120
-msgid "SURFER (Golden Software) ASCII file will be imported"
-msgstr ""
-#: ../raster/r.in.ascii/main.c:138
-#, c-format
-msgid "Wrong entry for multiplier: %s"
-msgstr ""
-#: ../raster/r.in.ascii/main.c:161
-#, fuzzy
-msgid "Unable to read input from stdin"
-#: ../raster/r.in.ascii/main.c:168
-#, fuzzy, c-format
-msgid "Unable to read input from <%s>"
-#: ../raster/r.in.ascii/main.c:283
-#, fuzzy
-msgid "Unable to write to file"
-#: ../raster/r.in.ascii/gethead.c:35
-msgid "input file is not a Surfer ascii grid file"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:41
-msgid "error reading the column and row dimension from the Surfer grid file"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:47
-msgid "error reading the X range from the Surfer grid file"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:53
-msgid "error reading the Y range from the Surfer grid file"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:59
-msgid "error reading the Z range from the Surfer grid file"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:105
-msgid "error getting file position"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:164
-msgid "illegal type field: using type int"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:169
-msgid "ignoring type filed in header, type is set on command line"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:176
-msgid "illegal multiplier field: using 1.0"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:181
-msgid "ignoring multiplier filed in header, multiplier is set on command line"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:189
-msgid "ignoring null filed in header, null string is set on command line"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:218
-msgid "error in ascii data format"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:253
-#, c-format
-msgid "Illegal \"%s\" value in header: %s"
-msgstr ""
-#: ../raster/r.what.color/main.c:91
-msgid "Queries colors for a raster map layer."
-msgstr ""
-#: ../raster/r.what.color/main.c:99
-#, fuzzy
-msgid "Name of existing raster map to query colors"
-#: ../raster/r.what.color/main.c:106
-#, fuzzy
-msgid "Values to query colors for"
-#: ../raster/r.what.color/main.c:113
-msgid "Output format (printf-style)"
-msgstr ""
-#: ../raster/r.what.color/main.c:117
-#, fuzzy
-msgid "Read values from stdin"
-#: ../raster/r.what.color/main.c:123
-msgid "Either \"-i\" or \"value=\" must be given"
-msgstr ""
-#: ../raster/r.out.vrml/main.c:49
-msgid "VRML"
-msgstr ""
-#: ../raster/r.out.vrml/main.c:51
-msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
-msgstr ""
-#: ../raster/r.out.vrml/main.c:58
-#, fuzzy
-msgid "Name of elevation map"
-#: ../raster/r.out.vrml/main.c:65
-msgid "Name of color file"
-msgstr ""
-#: ../raster/r.out.vrml/main.c:79
-msgid "Name for new VRML file"
-msgstr ""
-#: ../raster/r.out.vrml/main.c:98
-#, c-format
-msgid "Range info for [%s] not available (run r.support)"
-msgstr ""
-#: ../raster/r.out.vrml/main.c:107
-#, fuzzy, c-format
-msgid "Range info for <%s> not available (run r.support)"
-#: ../raster/r.out.vrml/main.c:139
-#, c-format
-msgid "Opening %s for writing... "
-msgstr ""
-#: ../raster/r.out.vrml/put_grid.c:38
-msgid "Writing vertices..."
-msgstr ""
-#: ../raster/r.out.vrml/put_grid.c:83
-msgid "Writing color file..."
-msgstr ""
-#: ../raster/r.surf.fractal/process.c:54
-#, fuzzy
-msgid "Unable to allocate data buffer. Check current region with g.region."
-#: ../raster/r.surf.fractal/main.c:40
-msgid "fractal"
-msgstr ""
-#: ../raster/r.surf.fractal/main.c:42
-msgid "Creates a fractal surface of a given fractal dimension."
-msgstr ""
-#: ../raster/r.surf.fractal/main.c:48
-msgid "Fractal dimension of surface (2 < D < 3)"
-msgstr ""
-#: ../raster/r.surf.fractal/main.c:55
-msgid "Number of intermediate images to produce"
-msgstr ""
-#: ../raster/r.surf.fractal/main.c:79
-#, c-format
-msgid "Fractal dimension of %.2lf must be between 2 and 3."
-msgstr ""
-#: ../raster/r.surf.fractal/spec_syn.c:61
-msgid "Preliminary surface calculations..."
-msgstr ""
-#: ../raster/r.surf.fractal/spec_syn.c:120
-#, fuzzy, c-format
-msgid "Calculating surface %d (of %d)..."
-#: ../raster/r.out.gridatb/main.c:70
-msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)."
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:142
-#, fuzzy, c-format
-msgid "Filter <%s> not found"
-#: ../raster/r.resamp.filter/main.c:387
-#, fuzzy
-msgid "Resamples raster map layers using an analytic kernel."
-#: ../raster/r.resamp.filter/main.c:398
-msgid "Filter kernel(s)"
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:406
-msgid "Filter radius"
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:413
-msgid "Filter radius (horizontal)"
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:420
-msgid "Filter radius (vertical)"
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:431
-msgid "radius= and x_radius=/y_radius= are mutually exclusive"
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:435
-msgid "Either radius= or x_radius=/y_radius= required"
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:437
-msgid "Both x_radius= and y_radius= required"
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:459
-msgid "Differing number of values for filter= and [xy_]radius="
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:462
-#, c-format
-msgid "Too many filters (max: %d)"
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:480
-#, fuzzy
-msgid "At least one filter must be finite"
-#: ../raster/r.to.rast3elev/main.c:99
-msgid "The number of input and elevation maps is not equal"
-msgstr ""
-#: ../raster/r.to.rast3elev/main.c:165
-msgid "The value to fill the upper cells, default is null"
-msgstr ""
-#: ../raster/r.to.rast3elev/main.c:172
-msgid "The value to fill the lower cells, default is null"
-msgstr ""
-#: ../raster/r.to.rast3elev/main.c:185
-msgid "Use the input map values to fill the upper cells"
-msgstr ""
-#: ../raster/r.to.rast3elev/main.c:190
-msgid "Use the input map values to fill the lower cells"
-msgstr ""
-#: ../raster/r.to.rast3elev/main.c:194
-msgid "Use RASTER3D mask (if exists) with input map"
-msgstr ""
-#: ../raster/r.to.rast3elev/main.c:287 ../raster/r.to.rast3elev/main.c:320
-msgid "Error writing RASTER3D double data"
-msgstr ""
-#: ../raster/r.to.rast3elev/main.c:366
-msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
-msgstr ""
-#: ../raster/r.to.rast3elev/main.c:400
-msgid "The upper value is not valid"
-msgstr ""
-#: ../raster/r.to.rast3elev/main.c:410
-msgid "The lower value is not valid"
-msgstr ""
-#: ../raster/r.mapcalc/map.c:207 ../raster/r.mapcalc/map3.c:179
-#, fuzzy, c-format
-msgid "Unable to read color file for raster map <%s@%s>"
-#: ../raster/r.mapcalc/map.c:220 ../raster/r.mapcalc/map3.c:192
-#, fuzzy, c-format
-msgid "Unable to create btree for raster map <%s@%s>"
-#: ../raster/r.mapcalc/map.c:269 ../raster/r.mapcalc/map.c:481
-#: ../raster/r.mapcalc/map.c:525 ../raster/r.mapcalc/map.c:621
-#: ../raster/r.mapcalc/map3.c:237 ../raster/r.mapcalc/map3.c:420
-#: ../raster/r.mapcalc/map3.c:464 ../raster/r.mapcalc/map3.c:555
-#: ../raster/r.mapcalc/expression.c:353
-#, c-format
-msgid "Invalid map modifier: '%c'"
-msgstr ""
-#: ../raster/r.mapcalc/map.c:412 ../raster/r.mapcalc/evaluate.c:94
-#: ../raster/r.mapcalc/evaluate.c:234 ../raster/r.mapcalc/map3.c:351
-#, fuzzy, c-format
-msgid "Unknown type: %d"
-#: ../raster/r.mapcalc/evaluate.c:140
-#, c-format
-msgid "Invalid type: %d"
-msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:179
-#, c-format
-msgid "Too few arguments for function '%s'"
-msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:183
-#, c-format
-msgid "Too many arguments for function '%s'"
-msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:187
-#, c-format
-msgid "Invalid argument type for function '%s'"
-msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:191
-#, c-format
-msgid "Invalid return type for function '%s'"
-msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:195
-#, fuzzy, c-format
-msgid "Unknown type for function '%s'"
-#: ../raster/r.mapcalc/evaluate.c:198
-#, c-format
-msgid "Number of arguments for function '%s'"
-msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:202
-#, c-format
-msgid "Unknown error for function '%s'"
-msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:303
-#, fuzzy, c-format
-msgid "output map <%s> exists"
-#: ../raster/r.mapcalc/map3.c:370
-#, fuzzy, c-format
-msgid "Unable to close raster map <%s@%s>"
-#: ../raster/r.mapcalc/map3.c:586 ../imagery/i.landsat.acca/algorithm.c:234
-#: ../imagery/i.landsat.acca/algorithm.c:388
-#: ../imagery/i.landsat.acca/tools.c:136 ../imagery/i.landsat.toar/main.c:501
-#, c-format
-msgid "Unable to create raster map <%s>"
-msgstr ""
-#: ../raster/r.mapcalc/map3.c:611
-#, fuzzy
-msgid "Unable to close output raster map"
-#: ../raster/r.mapcalc/main.c:113
-#, fuzzy
-msgid "Raster map calculator."
-#: ../raster/r.mapcalc/main.c:120
-msgid "Expression to evaluate"
-msgstr ""
-#: ../raster/r.mapcalc/main.c:121 ../raster/r.mapcalc/main.c:127
-#, fuzzy
-msgid "Expression"
-#: ../raster/r.mapcalc/main.c:126
-#, fuzzy
-msgid "File containing expression(s) to evaluate"
-#: ../raster/r.mapcalc/main.c:145
-msgid "file= and expression= are mutually exclusive"
-msgstr ""
-#: ../raster/r.mapcalc/main.c:155
-msgid "parse error"
-msgstr ""
-#: ../raster/r.mapcalc/main.c:164
-msgid "Floating point error(s) occured in the calculation"
-msgstr ""
-#: ../raster/r.mapcalc/main.c:169
-msgid "Overflow occured in the calculation"
-msgstr ""
-#: ../raster/r.mapcalc/expression.c:202
-#, c-format
-msgid "Undefined variable '%s'"
-msgstr ""
-#: ../raster/r.mapcalc/expression.c:217
-#, fuzzy, c-format
-msgid "Invalid map <%s>"
-msgstr "तक्त्याचे नाव"
-#: ../raster/r.mapcalc/expression.c:258
-#, c-format
-msgid "Undefined function '%s'"
-msgstr ""
-#: ../raster/r.mapcalc/expression.c:263
-#, c-format
-msgid "Too few arguments (%d) to function %s()"
-msgstr ""
-#: ../raster/r.mapcalc/expression.c:267
-#, c-format
-msgid "Too many arguments (%d) to function %s()"
-msgstr ""
-#: ../raster/r.mapcalc/expression.c:271
-#, fuzzy, c-format
-msgid "Incorrect argument types to function %s()"
-#: ../raster/r.mapcalc/expression.c:274
-#, c-format
-msgid "Internal error for function %s()"
-msgstr ""
-#: ../raster/r.mapcalc/expression.c:444
-#, c-format
-msgid "Illegal number of arguments (%d) for operator '%s'"
-msgstr ""
-#: ../raster/r.mapcalc/expression.c:484
-#, c-format
-msgid "Format_expression_prec: unknown type: %d"
-msgstr ""
-#: ../raster/r.mapcalc/function.c:94
-#, c-format
-msgid "Known functions:"
-msgstr ""
-#: ../raster/r.flow/precomp.c:48
-msgid "Precomputing: e/w distances"
-msgstr ""
-#: ../raster/r.flow/precomp.c:50
-msgid "Precomputing: quantization tolerances"
-msgstr ""
-#: ../raster/r.flow/precomp.c:53
-msgid "Precomputing: inverted elevations"
-msgstr ""
-#: ../raster/r.flow/precomp.c:57
-msgid "Precomputing: interpolated border elevations"
-msgstr ""
-#: ../raster/r.flow/precomp.c:63
-msgid "Precomputing: re-oriented aspects"
-msgstr ""
-#: ../raster/r.flow/precomp.c:67
-msgid "Precomputing: aspects"
-msgstr ""
-#: ../raster/r.flow/precomp.c:111
-#, c-format
-msgid ""
-"Resolution too unbalanced:\n"
-"atan2(%f deg, %f deg) =%f < %f tolerance\n"
-"please resample input map"
-msgstr ""
-#: ../raster/r.flow/precomp.c:116
-#, c-format
-msgid "Resolution too unbalanced (%f x %f); please resample input map"
-msgstr ""
-#: ../raster/r.flow/main.c:316
-msgid "Calculating maps ..."
-msgstr ""
-#: ../raster/r.flow/main.c:423
-msgid "Constructs flowlines."
-msgstr ""
-#: ../raster/r.flow/main.c:425
-msgid "Computes flowlines, flowpath lengths, and flowaccumulation (contributing areas) from a elevation raster map."
-msgstr ""
-#: ../raster/r.flow/main.c:434
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:5
-#, fuzzy
-msgid "Name of input aspect raster map"
-#: ../raster/r.flow/main.c:439
-#, fuzzy
-msgid "Name of input barrier raster map"
-#: ../raster/r.flow/main.c:445
-msgid "Number of cells between flowlines"
-msgstr ""
-#: ../raster/r.flow/main.c:451
-msgid "Maximum number of segments per flowline"
-msgstr ""
-#: ../raster/r.flow/main.c:456
-#, fuzzy
-msgid "Name for output flowline vector map"
-#: ../raster/r.flow/main.c:461
-#, fuzzy
-msgid "Name for output flowpath length raster map"
-#: ../raster/r.flow/main.c:466
-#, fuzzy
-msgid "Name for output flowaccumulation raster map"
-#: ../raster/r.flow/main.c:471
-msgid "Compute upslope flowlines instead of default downhill flowlines"
-msgstr ""
-#: ../raster/r.flow/main.c:475
-msgid "3D lengths instead of 2D"
-msgstr ""
-#: ../raster/r.flow/main.c:479
-msgid "Use less memory, at a performance penalty"
-msgstr ""
-#: ../raster/r.flow/main.c:534
-msgid "You must select one or more output maps (flout, lgout, dsout)"
-msgstr ""
-#: ../raster/r.flow/main.c:550
-msgid "lat/long projection not supported by r.flow. Please use 'r.watershed' for calculating flow accumulation."
-msgstr ""
-#: ../raster/r.flow/io.c:85
-msgid "Reading input files: elevation"
-msgstr ""
-#: ../raster/r.flow/io.c:89
-msgid "Elevation file's resolution differs from current region resolution"
-msgstr ""
-#: ../raster/r.flow/io.c:101
-msgid "Reading input files: aspect"
-msgstr ""
-#: ../raster/r.flow/io.c:104
-msgid "Resolution of aspect file differs from current region resolution"
-msgstr ""
-#: ../raster/r.flow/io.c:118
-msgid "Reading input files: barrier"
-msgstr ""
-#: ../raster/r.flow/io.c:146
-#, fuzzy, c-format
-msgid "Cannot create segment file %s"
-#: ../raster/r.flow/io.c:151
-#, fuzzy, c-format
-msgid "Cannot format segment file %s"
-#: ../raster/r.flow/io.c:157
-#, fuzzy, c-format
-msgid "Cannot open segment file %s"
-#: ../raster/r.flow/io.c:204
-msgid "Writing density file"
-msgstr ""
-#: ../raster/r.flow/io.c:237
-#, fuzzy, c-format
-msgid "Unable to find file %s"
-#: ../raster/r.flow/mem.c:40
-#, fuzzy, c-format
-msgid "Unable to write segment file for %s"
-#: ../imagery/i.evapo.pt/main.c:66 ../imagery/i.points/main.c:96
-#: ../imagery/i.latlong/main.c:56 ../imagery/i.zc/main.c:52
-#: ../imagery/i.smap/main.c:38 ../imagery/i.eb.eta/main.c:43
-#: ../imagery/i.vi/main.c:83 ../imagery/i.landsat.acca/main.c:105
-#: ../imagery/i.maxlik/main.c:61 ../imagery/i.eb.h_SEBAL01/main.c:83
-#: ../imagery/i.landsat.toar/main.c:67 ../imagery/i.class/main.c:91
-#: ../imagery/i.group/main.c:52 ../imagery/i.aster.toar/main.c:97
-#: ../imagery/i.gensig/main.c:39 ../imagery/i.his.rgb/main.c:46
-#: ../imagery/i.evapo.mh/main.c:69 ../imagery/i.rectify/main.c:94
-#: ../imagery/i.target/main.c:45 ../imagery/i.vpoints/main.c:94
-#: ../imagery/i.albedo/main.c:88 ../imagery/i.ifft/main.c:77
-#: ../imagery/i.fft/main.c:78 ../imagery/i.gensigset/main.c:40
-#: ../imagery/i.cca/main.c:84 ../imagery/i.cluster/main.c:75
-#: ../imagery/i.biomass/main.c:50 ../imagery/i.eb.netrad/main.c:56
-#: ../imagery/i.eb.evapfr/main.c:47 ../imagery/i.evapo.time/main.c:77
-#: ../imagery/i.pca/main.c:67 ../imagery/i.rgb.his/main.c:46
-#: ../imagery/i.evapo.pm/main.c:58 ../imagery/i.eb.soilheatflux/main.c:49
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:2
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:3
-#: ../locale/scriptstrings/i.spectral_to_translate.c:2
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:3
-#: ../locale/scriptstrings/i.oif_to_translate.c:3
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:3
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:2
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:2
-msgid "imagery"
-msgstr ""
-#: ../imagery/i.evapo.pt/main.c:67 ../imagery/i.evapo.mh/main.c:70
-#: ../imagery/i.evapo.time/main.c:78 ../imagery/i.evapo.pm/main.c:59
-#, fuzzy
-msgid "evapotranspiration"
-#: ../imagery/i.evapo.pt/main.c:69
-msgid "Computes evapotranspiration calculation Prestley and Taylor formulation, 1972."
-msgstr ""
-#: ../imagery/i.evapo.pt/main.c:75
-#, fuzzy
-msgid "Name of input net radiation raster map [W/m2]"
-#: ../imagery/i.evapo.pt/main.c:79
-#, fuzzy
-msgid "Name of input soil heat flux raster map [W/m2]"
-#: ../imagery/i.evapo.pt/main.c:83
-#, fuzzy
-msgid "Name of input air temperature raster map [K]"
-#: ../imagery/i.evapo.pt/main.c:87
-#, fuzzy
-msgid "Name of input atmospheric pressure raster map [millibars]"
-#: ../imagery/i.evapo.pt/main.c:93
-msgid "Prestley-Taylor coefficient"
-msgstr ""
-#: ../imagery/i.evapo.pt/main.c:97
-#, fuzzy
-msgid "Name of output evapotranspiration raster map [mm/d]"
-#: ../imagery/i.evapo.pt/main.c:102 ../imagery/i.evapo.mh/main.c:105
-msgid "Set negative ETa to zero"
-msgstr ""
-#: ../imagery/i.points/main.c:99
-msgid "Mark ground control points on image to be rectified."
-msgstr ""
-#: ../imagery/i.points/main.c:106 ../imagery/i.vpoints/main.c:105
-msgid "Name of imagery group to be registered"
-msgstr ""
-#: ../imagery/i.points/main.c:124 ../imagery/i.class/main.c:129
-#: ../display/d.what.vect/main.c:145 ../display/d.what.rast/main.c:98
-#: ../display/d.zoom/main.c:218 ../display/d.zoom/redraw.c:38
-#: ../display/d.extract/main.c:79 ../display/d.measure/main.c:85
-#: ../vector/v.label/main.c:233
-msgid "No graphics device selected"
-msgstr ""
-#: ../imagery/i.points/main.c:131 ../imagery/i.vpoints/main.c:128
-#, c-format
-msgid "[%s] Only local groups may be used"
-msgstr ""
-#: ../imagery/i.points/main.c:140 ../imagery/i.points/main.c:144
-#: ../imagery/i.vpoints/main.c:137 ../imagery/i.vpoints/main.c:141
-#, c-format
-msgid "Group [%s] contains no maps, run i.group"
-msgstr ""
-#: ../imagery/i.points/main.c:250 ../imagery/i.vpoints/main.c:256
-#, c-format
-msgid "ERROR: %s"
-msgstr ""
-#: ../imagery/i.points/main.c:252 ../imagery/i.vpoints/main.c:258
-#, c-format
-msgid "WARNING: %s (click mouse to continue)"
-msgstr ""
-#: ../imagery/i.latlong/main.c:57 ../imagery/i.sunhours/main.c:57
-msgid "latitude"
-msgstr ""
-#: ../imagery/i.latlong/main.c:58
-msgid "longitude"
-msgstr ""
-#: ../imagery/i.latlong/main.c:60
-#, fuzzy
-msgid "Creates a latitude/longitude map."
-#: ../imagery/i.latlong/main.c:64
-#, fuzzy
-msgid "Name of the input map"
-#: ../imagery/i.latlong/main.c:67
-#, fuzzy
-msgid "Name of the output latitude or longitude layer"
-#: ../imagery/i.latlong/main.c:71
-msgid "Longitude output"
-msgstr ""
-#: ../imagery/i.zc/main.c:53 ../vector/v.lidar.edgedetection/main.c:74
-msgid "edges"
-msgstr ""
-#: ../imagery/i.zc/main.c:55
-msgid "Zero-crossing \"edge detection\" raster function for image processing."
-msgstr ""
-#: ../imagery/i.zc/main.c:73
-#, fuzzy
-msgid "Zero crossing raster map"
-#: ../imagery/i.zc/main.c:80
-msgid "x-y extent of the Gaussian filter"
-msgstr ""
-#: ../imagery/i.zc/main.c:88
-msgid "Sensitivity of Gaussian filter"
-msgstr ""
-#: ../imagery/i.zc/main.c:96
-#, fuzzy
-msgid "Number of azimuth directions categorized"
-#: ../imagery/i.zc/main.c:108
-msgid "Threshold less than or equal to zero not allowed"
-msgstr ""
-#: ../imagery/i.zc/main.c:114
-msgid "Width less than or equal to zero not allowed"
-msgstr ""
-#: ../imagery/i.zc/main.c:118
-msgid "Fewer than 1 orientation classes not allowed"
-msgstr ""
-#: ../imagery/i.zc/main.c:132
-#, c-format
-msgid "Power 2 values : %d rows %d columns"
-msgstr ""
-#: ../imagery/i.zc/main.c:142
-msgid "Initializing data..."
-msgstr ""
-#: ../imagery/i.zc/main.c:172
-msgid "Writing transformed data to file..."
-msgstr ""
-#: ../imagery/i.zc/main.c:192
-msgid "Transform successful"
-msgstr ""
-#: ../imagery/i.smap/interp.c:225
-#, fuzzy
-msgid "Invalid parameter values"
-#: ../imagery/i.smap/read_sig.c:13 ../imagery/i.smap/openfiles.c:18
-#: ../imagery/i.gensig/openfiles.c:19 ../imagery/i.gensigset/openfiles.c:18
-#, fuzzy, c-format
-msgid "Unable to read REF file for subgroup <%s> in group <%s>"
-#: ../imagery/i.smap/read_sig.c:17 ../imagery/i.smap/openfiles.c:22
-#, fuzzy, c-format
-msgid "Subgroup <%s> in group <%s> contains no raster maps"
-#: ../imagery/i.smap/read_sig.c:23 ../imagery/i.maxlik/open.c:53
-#: ../imagery/i.cluster/open_files.c:70
-#, fuzzy, c-format
-msgid "Unable to read signature file <%s>"
-#: ../imagery/i.smap/read_sig.c:27
-#, fuzzy, c-format
-msgid "Signature file <%s> is invalid"
-#: ../imagery/i.smap/read_sig.c:30
-#, fuzzy, c-format
-msgid "Signature file <%s> is empty"
-#: ../imagery/i.smap/model.c:43
-#, c-format
-msgid "Nonsymetric covariance for class %d subclass %d"
-msgstr ""
-#: ../imagery/i.smap/model.c:55
-#, c-format
-msgid "Nonpositive eigenvalues for class %d subclass %d"
-msgstr ""
-#: ../imagery/i.smap/main.c:39 ../imagery/i.maxlik/main.c:62
-#: ../imagery/i.class/main.c:92 ../imagery/i.gensig/main.c:40
-#: ../imagery/i.gensigset/main.c:41 ../imagery/i.cluster/main.c:76
-#, fuzzy
-msgid "classification"
-#: ../imagery/i.smap/main.c:40 ../imagery/i.gensig/main.c:41
-#: ../imagery/i.gensigset/main.c:42
-msgid "supervised"
-msgstr ""
-#: ../imagery/i.smap/main.c:41 ../imagery/i.gensigset/main.c:43
-msgid "SMAP"
-msgstr ""
-#: ../imagery/i.smap/main.c:43
-msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
-msgstr ""
-#: ../imagery/i.smap/parse.c:20 ../imagery/i.maxlik/main.c:79
-#, fuzzy
-msgid "Name of file containing signatures"
-#: ../imagery/i.smap/parse.c:21
-msgid "Generated by i.gensigset"
-msgstr ""
-#: ../imagery/i.smap/parse.c:30
-msgid "Size of submatrix to process at one time"
-msgstr ""
-#: ../imagery/i.smap/parse.c:38
-msgid "Use maximum likelihood estimation (instead of smap)"
-msgstr ""
-#: ../imagery/i.smap/parse.c:52 ../imagery/i.maxlik/open.c:17
-#: ../imagery/i.gensig/parse.c:39 ../imagery/i.gensigset/parse.c:45
-#: ../imagery/i.cluster/open_files.c:18
-#, fuzzy, c-format
-msgid "Group <%s> not found"
-#: ../imagery/i.smap/parse.c:55 ../imagery/i.gensig/parse.c:42
-#: ../imagery/i.gensigset/parse.c:48
-#, fuzzy, c-format
-msgid "Subgroup <%s> not found"
-#: ../imagery/i.smap/segment.c:66
-#, fuzzy
-msgid "Number of classes must be < 256"
-#: ../imagery/i.smap/segment.c:91
-#, c-format
-msgid "Processing rows %d-%d (of %d)..."
-msgstr ""
-#: ../imagery/i.eb.eta/main.c:44 ../imagery/i.eb.h_SEBAL01/main.c:84
-#: ../imagery/i.emissivity/main.c:46 ../imagery/i.eb.netrad/main.c:57
-#: ../imagery/i.eb.evapfr/main.c:48 ../imagery/i.eb.soilheatflux/main.c:50
-msgid "energy balance"
-msgstr ""
-#: ../imagery/i.eb.eta/main.c:45
-msgid "actual evapotranspiration"
-msgstr ""
-#: ../imagery/i.eb.eta/main.c:46 ../imagery/i.eb.h_SEBAL01/main.c:87
-#: ../imagery/i.eb.netrad/main.c:59 ../imagery/i.eb.evapfr/main.c:51
-#: ../imagery/i.eb.soilheatflux/main.c:52
-msgid "SEBAL"
-msgstr ""
-#: ../imagery/i.eb.eta/main.c:48
-msgid "Actual evapotranspiration for diurnal period (Bastiaanssen, 1995)."
-msgstr ""
-#: ../imagery/i.eb.eta/main.c:53
-#, fuzzy
-msgid "Name of the diurnal Net Radiation map [W/m2]"
-#: ../imagery/i.eb.eta/main.c:58
-#, fuzzy
-msgid "Name of the evaporative fraction map [-]"
-#: ../imagery/i.eb.eta/main.c:63
-#, fuzzy
-msgid "Name of the surface skin temperature [K]"
-#: ../imagery/i.eb.eta/main.c:68
-#, fuzzy
-msgid "Name of the output actual evapotranspiration layer [mm/d]"
-#: ../imagery/i.vi/main.c:84
-#, fuzzy
-msgid "vegetation index"
-#: ../imagery/i.vi/main.c:85
-msgid "biophysical parameters"
-msgstr ""
-#: ../imagery/i.vi/main.c:87
-msgid "Calculates different types of vegetation indices."
-msgstr ""
-#: ../imagery/i.vi/main.c:88
-msgid "Uses red and nir bands mostly, and some indices require additional bands."
-msgstr ""
-#: ../imagery/i.vi/main.c:93
-#, fuzzy
-msgid "viname"
-#: ../imagery/i.vi/main.c:96
-#, fuzzy
-msgid "Name of vegetation index"
-#: ../imagery/i.vi/main.c:97
-msgid "arvi;Atmospherically Resistant Vegetation Indices;dvi;Difference Vegetation Index;evi;Enhanced Vegetation Index;gvi;Green Vegetation Index;gari;Green atmospherically resistant vegetation index;gemi;Global Environmental Monitoring Index;ipvi;Infrared Percentage Vegetation Index;msavi;Modified Soil Adjusted Vegetation Index;msavi2;second Modified Soil Adjusted Vegetation Index;ndvi;Normalized Difference Vegetation Index;pvi;Perpendicular Vegetation Index;savi;Soil Adjusted Vegetation Index;sr;Simple Ratio;vari;Visible Atmospherically Resistant Index;wdvi;Weighted Difference Vegetation Index;"
-msgstr ""
-#: ../imagery/i.vi/main.c:118
-#, fuzzy
-msgid "Name of the red channel surface reflectance map"
-#: ../imagery/i.vi/main.c:119 ../imagery/i.vi/main.c:126
-#: ../imagery/i.vi/main.c:133 ../imagery/i.vi/main.c:140
-#: ../imagery/i.vi/main.c:147 ../imagery/i.vi/main.c:154
-msgid "Range: [0.0;1.0]"
-msgstr ""
-#: ../imagery/i.vi/main.c:125
-#, fuzzy
-msgid "Name of the nir channel surface reflectance map"
-#: ../imagery/i.vi/main.c:132
-#, fuzzy
-msgid "Name of the green channel surface reflectance map"
-#: ../imagery/i.vi/main.c:139
-#, fuzzy
-msgid "Name of the blue channel surface reflectance map"
-#: ../imagery/i.vi/main.c:146
-#, fuzzy
-msgid "Name of the chan5 channel surface reflectance map"
-#: ../imagery/i.vi/main.c:153
-#, fuzzy
-msgid "Name of the chan7 channel surface reflectance map"
-#: ../imagery/i.vi/main.c:160
-msgid "MSAVI2: Value of the slope of the soil line"
-msgstr ""
-#: ../imagery/i.vi/main.c:166
-msgid "MSAVI2: Value of the intercept of the soil line"
-msgstr ""
-#: ../imagery/i.vi/main.c:172
-msgid "MSAVI2: Value of the factor of reduction of soil noise"
-msgstr ""
-#: ../imagery/i.vi/main.c:178
-msgid "If your data is in Digital Numbers (i.e. integer type), give the max bits (i.e. 8 for Landsat -> [0-255])"
-msgstr ""
-#: ../imagery/i.vi/main.c:205
-msgid "sr index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:208
-msgid "ndvi index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:211
-msgid "ipvi index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:214
-msgid "dvi index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:217
-msgid "pvi index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:220
-msgid "wdvi index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:223
-msgid "savi index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:226
-msgid "msavi index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:229
-msgid "msavi2 index requires red and nir maps, and 3 parameters related to soil line"
-msgstr ""
-#: ../imagery/i.vi/main.c:232
-msgid "gemi index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:236
-msgid "arvi index requires blue, red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:240
-msgid "evi index requires blue, red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:244
-msgid "vari index requires blue, green and red maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:248
-msgid "gari index requires blue, green, red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:253
-msgid "gvi index requires blue, green, red, nir, chan5 and chan7 maps"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:70
-#, c-format
-msgid "Input raster map <%s> is not floating point (process DN using i.landsat.toar to radiance first)"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:104
-msgid "Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)."
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:106 ../imagery/i.landsat.toar/main.c:68
-msgid "landsat"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:107
-msgid "acca"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:111 ../imagery/i.landsat.toar/main.c:76
-#, fuzzy
-msgid "Base name of input raster bands"
-#: ../imagery/i.landsat.acca/main.c:112 ../imagery/i.landsat.toar/main.c:77
-msgid "Example: 'B.' for B.1, B.2, ..."
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:122
-msgid "B56composite (step 6)"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:129
-msgid "B45ratio: Desert detection (step 10)"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:137
-#, fuzzy
-msgid "Number of classes in the cloud temperature histogram"
-#: ../imagery/i.landsat.acca/main.c:139 ../imagery/i.landsat.acca/main.c:154
-#: ../imagery/i.landsat.acca/main.c:160 ../imagery/i.landsat.acca/main.c:165
-#, fuzzy
-msgid "Cloud settings"
-#: ../imagery/i.landsat.acca/main.c:143
-msgid "Data is Landsat-5 TM"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:144
-msgid "I.e. Thermal band is '.6' not '.61')"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:149
-msgid "Apply post-processing filter to remove small holes"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:153
-msgid "Always use cloud signature (step 14)"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:159
-msgid "Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:164
-msgid "Include a category for cloud shadows"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:124
-msgid "Preliminary scene analysis:"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:125
-#, c-format
-msgid "* Desert index: %.2lf"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:126
-#, c-format
-msgid "* Snow cover: %.2lf %%"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:127
-#, c-format
-msgid "* Cloud cover: %.2lf %%"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:128
-msgid "* Temperature of clouds:"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:129
-#, c-format
-msgid "** Maximum: %.2lf K"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:130
-#, c-format
-msgid "** Mean (%s cloud): %.2lf K"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:132
-#, c-format
-msgid "** Minimum: %.2lf K"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:142
-msgid "Histogram cloud signature:"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:148
-#, c-format
-msgid "* Mean temperature: %.2lf K"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:149
-#, c-format
-msgid "* Standard deviation: %.2lf"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:150
-#, c-format
-msgid "* Skewness: %.2lf"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:151
-#, c-format
-msgid "* Histogram classes: %d"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:163
-#, c-format
-msgid "* 98.75 percentile: %.2lf K"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:164
-#, c-format
-msgid "* 97.50 percentile: %.2lf K"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:165
-#, c-format
-msgid "* 83.50 percentile: %.2lf K"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:186
-msgid "Maximum temperature:"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:187
-#, c-format
-msgid "* Cold cloud: %.2lf K"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:188
-#, c-format
-msgid "* Warm cloud: %.2lf K"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:193
-msgid "Result: Scene with clouds"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:200
-msgid "Result: Scene cloud free"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:237
-#, fuzzy
-msgid "Processing first pass..."
-#: ../imagery/i.landsat.acca/algorithm.c:391
-#, fuzzy
-msgid "Removing ambiguous pixels..."
-#: ../imagery/i.landsat.acca/algorithm.c:393
-#, fuzzy
-msgid "Pass two processing..."
-#: ../imagery/i.landsat.acca/tools.c:138
-msgid "Filling small holes in clouds..."
-msgstr ""
-#: ../imagery/i.maxlik/main.c:63 ../imagery/i.gensig/main.c:42
-msgid "MLC"
-msgstr ""
-#: ../imagery/i.maxlik/main.c:65
-msgid "Classifies the cell spectral reflectances in imagery data."
-msgstr ""
-#: ../imagery/i.maxlik/main.c:67
-msgid "Classification is based on the spectral signature information generated by either i.cluster, i.class, or i.gensig."
-msgstr ""
-#: ../imagery/i.maxlik/main.c:80
-msgid "Generated by either i.cluster, i.class, or i.gensig"
-msgstr ""
-#: ../imagery/i.maxlik/main.c:85
-#, fuzzy
-msgid "Name for raster map holding classification results"
-#: ../imagery/i.maxlik/main.c:91
-#, fuzzy
-msgid "Name for raster map holding reject threshold results"
-#: ../imagery/i.maxlik/open.c:20 ../imagery/i.cluster/open_files.c:22
-#, fuzzy, c-format
-msgid "Subgroup <%s> in group <%s> not found"
-#: ../imagery/i.maxlik/open.c:27
-#, c-format
-msgid "Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must have at least 2 raster maps."
-msgstr ""
-#: ../imagery/i.maxlik/open.c:30
-#, c-format
-msgid "Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at least 2 raster maps."
-msgstr ""
-#: ../imagery/i.maxlik/open.c:47
-#, fuzzy, c-format
-msgid "Unable to open signature file <%s>"
-#: ../imagery/i.maxlik/open.c:57 ../imagery/i.cluster/open_files.c:74
-#, c-format
-msgid "<%s> has too many signatures (limit is 255)"
-msgstr ""
-#: ../imagery/i.maxlik/invert.c:28
-#, c-format
-msgid "Signature %d is not valid (ill-conditioned) - ignored"
-msgstr ""
-#: ../imagery/i.maxlik/invert.c:31
-#, c-format
-msgid "Signature %d is not valid (singular) - ignored"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:85 ../imagery/i.eb.evapfr/main.c:49
-msgid "soil moisture"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:86 ../imagery/i.eb.evapfr/main.c:50
-msgid "evaporative fraction"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:88
-msgid "Computes sensible heat flux iteration SEBAL 01."
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:94
-#, fuzzy
-msgid "Name of instantaneous Net Radiation raster map [W/m2]"
-#: ../imagery/i.eb.h_SEBAL01/main.c:99
-#, fuzzy
-msgid "Name of instantaneous soil heat flux raster map [W/m2]"
-#: ../imagery/i.eb.h_SEBAL01/main.c:104
-#, fuzzy
-msgid "Name of aerodynamic resistance to heat momentum raster map [s/m]"
-#: ../imagery/i.eb.h_SEBAL01/main.c:109
-#, fuzzy
-msgid "Name of altitude corrected surface temperature raster map [K]"
-#: ../imagery/i.eb.h_SEBAL01/main.c:117
-msgid "Value of the height independent friction velocity (u*) [m/s]"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:125
-#, fuzzy
-msgid "Value of the actual vapour pressure (e_act) [KPa]"
-#: ../imagery/i.eb.h_SEBAL01/main.c:132
-msgid "Row value of the wet pixel"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:139
-msgid "Column value of the wet pixel"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:146
-msgid "Row value of the dry pixel"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:153
-msgid "Column value of the dry pixel"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:157
-#, fuzzy
-msgid "Name for output sensible heat flux raster map [W/m2]"
-#: ../imagery/i.eb.h_SEBAL01/main.c:162
-msgid "Automatic wet/dry pixel (careful!)"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:167
-msgid "Dry/Wet pixels coordinates are in image projection, not row/col"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:195
-msgid "Either auto-mode either wet/dry pixels coordinates should be provided!"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:198
-msgid "Manual wet/dry pixels in image coordinates"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:199
-#, c-format
-msgid "Wet Pixel=> x:%f y:%f"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:200
-#, c-format
-msgid "Dry Pixel=> x:%f y:%f"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:204
-msgid "Automatic mode selected"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:206
-#, c-format
-msgid "Wet Pixel=> row:%.0f col:%.0f"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:207
-#, c-format
-msgid "Dry Pixel=> row:%.0f col:%.0f"
-msgstr ""
-#: ../imagery/i.eb.h_SEBAL01/main.c:212
-#, fuzzy, c-format
-msgid "<%s> is an illegal name"
-#: ../imagery/i.landsat.toar/landsat_met.c:57
-#: ../imagery/i.landsat.toar/landsat_met.c:146
-#: ../imagery/i.landsat.toar/landsat_met.c:234
-#, fuzzy, c-format
-msgid "Metadata file <%s> not found"
-#: ../imagery/i.landsat.toar/landsat_met.c:160
-#, c-format
-msgid "Product creation date not in metadata file <%s>"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:66
-msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+."
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:69
-msgid "top-of-atmosphere reflectance"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:70
-msgid "dos-type simple atmospheric correction"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:83
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:13
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:15
-#, fuzzy
-msgid "Prefix for output raster maps"
-#: ../imagery/i.landsat.toar/main.c:84
-msgid "Example: 'B.toar.' generates B.toar.1, B.toar.2, ..."
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:91
-msgid "Name of Landsat ETM+ or TM5 header file (.met/MTL.txt)"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:97
-msgid "Spacecraft sensor"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:98 ../imagery/i.landsat.toar/main.c:116
-#: ../imagery/i.landsat.toar/main.c:126 ../imagery/i.landsat.toar/main.c:134
-#: ../imagery/i.landsat.toar/main.c:143
-msgid "Required only if 'metfile' not given"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:101
-msgid "mss1;Landsat-1 MSS;mss2;Landsat-2 MSS;mss3;Landsat-3 MSS;tm4;Landsat-4 TM;tm5;Landsat-5 TM;tm7;Landsat-7 ETM+"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:115
-#, fuzzy
-msgid "Atmospheric correction method"
-#: ../imagery/i.landsat.toar/main.c:125
-msgid "Image acquisition date (yyyy-mm-dd)"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:133
-msgid "Solar elevation in degrees"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:142
-msgid "Image creation date (yyyy-mm-dd)"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:151
-msgid "Gain (H/L) of all Landsat ETM+ bands (1-5,61,62,7,8)"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:158
-msgid "Percent of solar radiance in path radiance"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:167
-msgid "Minimum pixels to consider digital number as dark object"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:175
-msgid "Satellite zenith in degrees"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:183
-msgid "Rayleigh atmosphere"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:190
-msgid "Output at-sensor radiance for all bands"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:194
-msgid "Set sensor of Landsat TM4/5 to MSS"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:199
-msgid "Landsat ETM+/TM5 has a MTL.txt file instead of .met"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:224 ../imagery/i.landsat.toar/main.c:234
-#, fuzzy, c-format
-msgid "Illegal date format: [%s] (yyyy-mm-dd)"
-#: ../imagery/i.landsat.toar/main.c:258
-msgid "Failed to identify satellite"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:267
-#, c-format
-msgid "Lacking '%s' or '%s' for this satellite"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:277
-msgid "Landsat-7 requires band gain with 9 (H/L) data"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:308
-#, fuzzy, c-format
-msgid "Unknown satellite type (defined by '%s')"
-#: ../imagery/i.landsat.toar/main.c:414
-#, c-format
-msgid "Unknown production date (defined by '%s')"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:485
-#, fuzzy, c-format
-msgid "Raster map <%s> exists. Skipping."
-#: ../imagery/i.landsat.toar/main.c:510
-#, fuzzy, c-format
-msgid "Writing %s of <%s> to <%s>..."
-#: ../imagery/i.landsat.toar/main.c:511 ../imagery/i.aster.toar/main.c:100
-#, fuzzy
-msgid "radiance"
-#: ../imagery/i.landsat.toar/main.c:513 ../imagery/i.eb.netrad/main.c:75
-msgid "temperature"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:513 ../imagery/i.aster.toar/main.c:101
-#, fuzzy
-msgid "reflectance"
-#: ../imagery/i.class/signature.c:50 ../imagery/i.class/signature.c:55
-msgid "Unable to allocate space for signature statistics."
-msgstr ""
-#: ../imagery/i.class/signature.c:82
-msgid "prepare_signature: outline has odd number of points."
-msgstr ""
-#: ../imagery/i.class/signature.c:113
-#, c-format
-msgid "prepare_signature: scan line %d has odd number of points."
-msgstr ""
-#: ../imagery/i.class/signature.c:123
-msgid "signature: perimeter points out of order."
-msgstr ""
-#: ../imagery/i.class/signature.c:132
-msgid "prepare_signature: data error."
-msgstr ""
-#: ../imagery/i.class/signature.c:234
-msgid "Unknown Menu selection in show_signature()."
-msgstr ""
-#: ../imagery/i.class/add_point.c:22
-#, c-format
-msgid "Can't mark another point.  Only %d points allowed.  Sorry."
-msgstr ""
-#: ../imagery/i.class/draw_reg.c:89
-#, c-format
-msgid ""
-"\n"
-"Orig:(x1 y1), (x2 y2) = (%d %d), (%d %d)"
-msgstr ""
-#: ../imagery/i.class/draw_reg.c:97
-#, c-format
-msgid ""
-"\n"
-"New:(x1 y1), (x2 y2) = (%d %d), (%d %d)"
-msgstr ""
-#: ../imagery/i.class/analyze_sig.c:12
-msgid "Cannot analyze until region is completed."
-msgstr ""
-#: ../imagery/i.class/redisplay.c:56
-msgid "No zoom window is defined."
-msgstr ""
-#: ../imagery/i.class/curses.c:22
-#, c-format
-msgid "make_window(%d,%d,%d,%d): illegal screen values."
-msgstr ""
-#: ../imagery/i.class/curses.c:153
-#, c-format
-msgid "%s"
-msgstr ""
-#: ../imagery/i.class/remove_mask.c:15
-msgid "Error while removing the old MASK cell map."
-msgstr ""
-#: ../imagery/i.class/main.c:94
-msgid "Generates spectral signatures for an image by allowing the user to outline regions of interest."
-msgstr ""
-#: ../imagery/i.class/main.c:97
-msgid "The resulting signature file can be used as input for i.maxlik or as a seed signature file for i.cluster."
-msgstr ""
-#: ../imagery/i.class/main.c:101 ../display/d.rast/main.c:60
-#, fuzzy
-msgid "Name of raster map to be displayed"
-#: ../imagery/i.class/main.c:111 ../imagery/i.cca/main.c:95
-#, fuzzy
-msgid "Name of input imagery subgroup"
-#: ../imagery/i.class/main.c:116
-#, fuzzy
-msgid "File to contain result signatures"
-#: ../imagery/i.class/main.c:121
-#, fuzzy
-msgid "File containing input signatures (seed)"
-#: ../imagery/i.class/main.c:133
-msgid "You have a mask set. Unset mask and run again"
-msgstr ""
-#: ../imagery/i.class/main.c:142 ../imagery/i.group/main.c:113
-#: ../imagery/i.target/main.c:80
-#, fuzzy
-msgid "Group must exist in the current mapset"
-#: ../imagery/i.class/main.c:251
-#, c-format
-msgid "** The following raster maps in subgroup [%s] do not exist:"
-msgstr ""
-#: ../imagery/i.class/main.c:260
-#, c-format
-msgid "Subgroup [%s] does not have any files"
-msgstr ""
-#: ../imagery/i.class/main.c:261 ../imagery/i.class/main.c:265
-msgid "The subgroup must have at least 2 files to run"
-msgstr ""
-#: ../imagery/i.class/main.c:264
-#, c-format
-msgid "Subgroup [%s] only has 1 file"
-msgstr ""
-#: ../imagery/i.class/main.c:273
-msgid ""
-"\n"
-"RESULT SIGNATURE"
-msgstr ""
-#: ../imagery/i.class/main.c:278
-#, fuzzy, c-format
-msgid "Unable to open output signature file '%s'"
-#: ../imagery/i.class/main.c:284
-msgid ""
-"\n"
-"SEED SIGNATURES"
-msgstr ""
-#: ../imagery/i.class/main.c:290
-#, fuzzy, c-format
-msgid "Unable to read signature file [%s]"
-#: ../imagery/i.class/main.c:293
-#, fuzzy, c-format
-msgid "** Unable to read signature file [%s] **"
-#: ../imagery/i.class/main.c:300
-#, c-format
-msgid "%s has too many signatures"
-msgstr ""
-#: ../imagery/i.class/outline.c:57
-msgid "Absurd polygon."
-msgstr ""
-#: ../imagery/i.class/outline.c:99
-msgid "Outlined area is too large."
-msgstr ""
-#: ../imagery/i.class/save_reg.c:14
-msgid "Region is not complete, can not save."
-msgstr ""
-#: ../imagery/i.class/restore_reg.c:15
-msgid "No region is saved, can not restore."
-msgstr ""
-#: ../imagery/i.class/complete_reg.c:12
-msgid "Too few points for region.  Must have at least 3 points."
-msgstr ""
-#: ../imagery/i.class/complete_reg.c:14
-msgid "Area already completed."
-msgstr ""
-#: ../imagery/i.class/erase_reg.c:10
-msgid "Can not erase an undefined region."
-msgstr ""
-#: ../imagery/i.group/main.c:55
-msgid "Creates, edits, and lists groups of imagery data."
-msgstr ""
-#: ../imagery/i.group/main.c:59
-msgid "Name of imagery group"
-msgstr ""
-#: ../imagery/i.group/main.c:65
-msgid "Name of imagery sub-group"
-msgstr ""
-#: ../imagery/i.group/main.c:69
-#, fuzzy
-msgid "Name of raster map(s) to include in group"
-#: ../imagery/i.group/main.c:70 ../imagery/i.group/main.c:75
-msgid "Maps"
-msgstr ""
-#: ../imagery/i.group/main.c:74
-msgid "Remove selected files from specified group"
-msgstr ""
-#: ../imagery/i.group/main.c:79
-msgid "List files from specified (sub)group (fancy)"
-msgstr ""
-#: ../imagery/i.group/main.c:85
-msgid "List files from specified (sub)group (shell script style)"
-msgstr ""
-#: ../imagery/i.group/main.c:105
-#, fuzzy
-msgid "No input raster map(s) specified"
-#: ../imagery/i.group/main.c:123 ../imagery/i.group/main.c:144
-#, fuzzy
-msgid "Specified group does not exist in current mapset"
-#: ../imagery/i.group/main.c:127
-#, fuzzy, c-format
-msgid "Removing raster maps from subgroup <%s>..."
-#: ../imagery/i.group/main.c:132
-#, fuzzy, c-format
-msgid "Removing raster maps from group <%s>..."
-#: ../imagery/i.group/main.c:167
-#, fuzzy, c-format
-msgid "Group <%s> does not yet exist. Creating..."
-#: ../imagery/i.group/main.c:171 ../imagery/i.group/main.c:180
-#, fuzzy, c-format
-msgid "Adding raster maps to group <%s>..."
-#: ../imagery/i.group/main.c:175
-#, fuzzy, c-format
-msgid "Adding raster maps to subgroup <%s>..."
-#: ../imagery/i.group/main.c:206
-#, fuzzy, c-format
-msgid "Adding raster map <%s> to group"
-#: ../imagery/i.group/main.c:212
-#, c-format
-msgid "Raster map <%s> exists in group. Skipping..."
-msgstr ""
-#: ../imagery/i.group/main.c:246
-#, fuzzy, c-format
-msgid "Adding raster map <%s> to subgroup"
-#: ../imagery/i.group/main.c:252
-#, c-format
-msgid "Raster map <%s> exists in subgroup. Skipping..."
-msgstr ""
-#: ../imagery/i.group/main.c:301
-#, fuzzy, c-format
-msgid "Removing raster map <%s> from group"
-#: ../imagery/i.group/main.c:318 ../imagery/i.group/main.c:377
-#, fuzzy
-msgid "No raster map removed"
-#: ../imagery/i.group/main.c:360
-#, fuzzy, c-format
-msgid "Removing raster map <%s> from subgroup"
-#: ../imagery/i.aster.toar/main.c:98
-msgid "Terra-ASTER"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:99
-msgid "DN"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:102
-msgid "brightness temperature"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:104
-msgid "Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature from ASTER DN.\n"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:108
-msgid "Names of ASTER DN layers (15 layers)"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:115
-#, fuzzy
-msgid "Day of Year of satellite overpass [0-366]"
-#: ../imagery/i.aster.toar/main.c:122
-msgid "Sun elevation angle (degrees, < 90.0)"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:125
-#, fuzzy
-msgid "Base name of the output layers (will add .x)"
-#: ../imagery/i.aster.toar/main.c:130
-msgid "Output is radiance (W/m2)"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:134
-msgid "VNIR is High Gain"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:138
-msgid "SWIR is High Gain"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:142
-msgid "VNIR is Low Gain 1"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:146
-msgid "SWIR is Low Gain 1"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:150
-msgid "SWIR is Low Gain 2"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:229 ../imagery/i.albedo/main.c:150
-#, c-format
-msgid "Too many input maps. Only %d allowed."
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:244
-msgid "The input band number should be 15"
-msgstr ""
-#: ../imagery/i.gensig/check.c:21
-#, c-format
-msgid "Signature %d not invertible"
-msgstr ""
-#: ../imagery/i.gensig/check.c:27
-#, c-format
-msgid "Signature %d unable to get eigen values"
-msgstr ""
-#: ../imagery/i.gensig/check.c:33
-#, c-format
-msgid "Signature %d not positive definite"
-msgstr ""
-#: ../imagery/i.gensig/covariance.c:30
-msgid "Calculating class covariance matrices..."
-msgstr ""
-#: ../imagery/i.gensig/means.c:26
-#, fuzzy
-msgid "Calculating class means..."
-#: ../imagery/i.gensig/main.c:44
-#, fuzzy
-msgid "Generates statistics for i.maxlik from raster map."
-#: ../imagery/i.gensig/get_train.c:32 ../imagery/i.gensigset/get_train.c:35
-#, fuzzy
-msgid "Finding training classes..."
-#: ../imagery/i.gensig/get_train.c:55 ../imagery/i.gensigset/get_train.c:58
-#, c-format
-msgid "Training class %d only has one cell - this class will be ignored"
-msgstr ""
-#: ../imagery/i.gensig/get_train.c:60 ../imagery/i.gensigset/get_train.c:63
-#, fuzzy
-msgid "Training map has no classes"
-#: ../imagery/i.gensig/get_train.c:75 ../imagery/i.gensigset/get_train.c:79
-#, fuzzy
-msgid "1 class found"
-#: ../imagery/i.gensig/get_train.c:77 ../imagery/i.gensigset/get_train.c:81
-#, fuzzy, c-format
-msgid "%d classes found"
-msgstr "डेटाबेसची यादी दाखवता येणार नाही"
-#: ../imagery/i.gensig/parse.c:14 ../imagery/i.gensigset/parse.c:13
-msgid "Ground truth training map"
-msgstr ""
-#: ../imagery/i.gensig/parse.c:22 ../imagery/i.gensigset/parse.c:21
-#: ../imagery/i.cluster/main.c:94
-#, fuzzy
-msgid "Name for output file containing result signatures"
-#: ../imagery/i.gensig/write_sig.c:15 ../imagery/i.gensigset/write_sig.c:13
-#, fuzzy, c-format
-msgid "Unable to create signature file <%s>"
-#: ../imagery/i.gensig/write_sig.c:18 ../imagery/i.gensigset/write_sig.c:16
-#, fuzzy
-msgid "Writing signatures..."
-#: ../imagery/i.gensig/openfiles.c:23 ../imagery/i.gensigset/openfiles.c:22
-#, fuzzy, c-format
-msgid "Subgroup <%s> in group <%s> contains no raster maps."
-#: ../imagery/i.his.rgb/main.c:51
-msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
-msgstr ""
-#: ../imagery/i.his.rgb/main.c:57
-#, fuzzy
-msgid "Name of input raster map (hue)"
-#: ../imagery/i.his.rgb/main.c:61
-#, fuzzy
-msgid "Name of input raster map (intensity)"
-#: ../imagery/i.his.rgb/main.c:65
-#, fuzzy
-msgid "Name of input raster map (saturation)"
-#: ../imagery/i.his.rgb/main.c:69
-#, fuzzy
-msgid "Name for output raster map (red)"
-#: ../imagery/i.his.rgb/main.c:73
-#, fuzzy
-msgid "Name for output raster map (green)"
-#: ../imagery/i.his.rgb/main.c:77
-#, fuzzy
-msgid "Name for output raster map (blue)"
-#: ../imagery/i.evapo.mh/main.c:72
-msgid "Computes evapotranspiration calculation modified or original Hargreaves formulation, 2001."
-msgstr ""
-#: ../imagery/i.evapo.mh/main.c:78
-#, fuzzy
-msgid "Name of input diurnal net radiation raster map [W/m2/d]"
-#: ../imagery/i.evapo.mh/main.c:82
-#, fuzzy
-msgid "Name of input average air temperature raster map [C]"
-#: ../imagery/i.evapo.mh/main.c:86
-#, fuzzy
-msgid "Name of input minimum air temperature raster map [C]"
-#: ../imagery/i.evapo.mh/main.c:90
-#, fuzzy
-msgid "Name of input maximum air temperature raster map [C]"
-#: ../imagery/i.evapo.mh/main.c:96
-#, fuzzy
-msgid "Name of precipitation raster map [mm/month]"
-#: ../imagery/i.evapo.mh/main.c:97
-msgid "Disabled for original Hargreaves (1985)"
-msgstr ""
-#: ../imagery/i.evapo.mh/main.c:100
-#, fuzzy
-msgid "Name for output raster map [mm/d]"
-#: ../imagery/i.evapo.mh/main.c:109
-msgid "Use original Hargreaves (1985)"
-msgstr ""
-#: ../imagery/i.evapo.mh/main.c:113
-msgid "Use Hargreaves-Samani (1985)"
-msgstr ""
-#: ../imagery/i.rectify/rectify.c:41
-#, fuzzy, c-format
-msgid "Rectify <%s@%s> (location <%s>)"
-#: ../imagery/i.rectify/rectify.c:44
-#, fuzzy, c-format
-msgid "into  <%s@%s> (location <%s>) ..."
-#: ../imagery/i.rectify/rectify.c:105
-#, fuzzy, c-format
-msgid "Raster map <%s@%s>: projection don't match current settings"
-#: ../imagery/i.rectify/rectify.c:111
-#, fuzzy, c-format
-msgid "Raster map <%s@%s>: zone don't match current settings"
-#: ../imagery/i.rectify/main.c:95 ../vector/v.rectify/main.c:64
-msgid "rectify"
-msgstr ""
-#: ../imagery/i.rectify/main.c:97
-msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
-msgstr ""
-#: ../imagery/i.rectify/main.c:111
-#, fuzzy
-msgid "Output raster map(s) suffix"
-#: ../imagery/i.rectify/main.c:119 ../vector/v.rectify/main.c:90
-msgid "Rectification polynom order (1-3)"
-msgstr ""
-#: ../imagery/i.rectify/main.c:125
-msgid "Target resolution (ignored if -c flag used)"
-msgstr ""
-#: ../imagery/i.rectify/main.c:133
-msgid "Amount of memory to use in MB"
-msgstr ""
-#: ../imagery/i.rectify/main.c:148
-msgid "Use current region settings in target location (def.=calculate smallest area)"
-msgstr ""
-#: ../imagery/i.rectify/main.c:152
-#, fuzzy
-msgid "Rectify all raster maps in group"
-#: ../imagery/i.rectify/main.c:190 ../vector/v.rectify/main.c:130
-#, c-format
-msgid "Invalid order (%d); please enter 1 to %d"
-msgstr ""
-#: ../imagery/i.rectify/main.c:195
-#, fuzzy, c-format
-msgid "Location: %s"
-#: ../imagery/i.rectify/main.c:196
-#, c-format
-msgid "Mapset: %s"
-msgstr ""
-#: ../imagery/i.rectify/main.c:197
-#, fuzzy, c-format
-msgid "Group <%s> does not exist"
-#: ../imagery/i.rectify/main.c:201
-#, c-format
-msgid "Group <%s> contains no raster maps; run i.group"
-msgstr ""
-#: ../imagery/i.rectify/main.c:276
-#, fuzzy, c-format
-msgid "Extension <%s> is illegal"
-#: ../imagery/i.rectify/main.c:279
-#, fuzzy
-msgid "The following raster map already exists in"
-#: ../imagery/i.rectify/main.c:280 ../vector/v.rectify/main.c:182
-#, c-format
-msgid "target LOCATION %s, MAPSET %s:"
-msgstr ""
-#: ../imagery/i.rectify/main.c:283
-msgid "Orthorectification cancelled."
-msgstr ""
-#: ../imagery/i.rectify/main.c:298
-msgid "Target resolution must be > 0, ignored"
-msgstr ""
-#: ../imagery/i.rectify/main.c:309
-#, c-format
-msgid "Using region: N=%f S=%f, E=%f W=%f"
-msgstr ""
-#: ../imagery/i.rectify/main.c:324
-#, fuzzy, c-format
-msgid "Input raster map <%s> does not exist in group <%s>."
-#: ../imagery/i.rectify/main.c:326
-msgid "Try:"
-msgstr ""
-#: ../imagery/i.rectify/main.c:331
-msgid "Exit!"
-msgstr ""
-#: ../imagery/i.rectify/report.c:10
-msgid "complete"
-msgstr ""
-#: ../imagery/i.rectify/report.c:10 ../db/db.select/main.c:92
-msgid "failed"
-msgstr ""
-#: ../imagery/i.rectify/report.c:20
-#, c-format
-msgid "%d rows, %d cols (%ld cells) completed in"
-msgstr ""
-#: ../imagery/i.rectify/report.c:23
-#, c-format
-msgid "%d:%02d:%02ld hours"
-msgstr ""
-#: ../imagery/i.rectify/report.c:25
-#, c-format
-msgid "%d:%02ld minutes"
-msgstr ""
-#: ../imagery/i.rectify/report.c:27
-#, c-format
-msgid "%.1f cells per minute"
-msgstr ""
-#: ../imagery/i.rectify/get_wind.c:112
-#, c-format
-msgid "Region N=%f S=%f E=%f W=%f"
-msgstr ""
-#: ../imagery/i.rectify/get_wind.c:114
-#, c-format
-msgid "Resolution EW=%f NS=%f"
-msgstr ""
-#: ../imagery/i.rectify/cp.c:15 ../vector/v.rectify/cp.c:327
-#, c-format
-msgid "Control Point file for group <%s@%s> - "
-msgstr ""
-#: ../imagery/i.rectify/cp.c:21 ../vector/v.rectify/cp.c:336
-#, c-format
-msgid "Not enough active control points for current order, %d are required."
-msgstr ""
-#: ../imagery/i.rectify/cp.c:25 ../vector/v.rectify/cp.c:340
-msgid "Poorly placed control points."
-msgstr ""
-#: ../imagery/i.rectify/cp.c:26 ../vector/v.rectify/cp.c:341
-#, fuzzy
-msgid " Can not generate the transformation equation."
-#: ../imagery/i.rectify/cp.c:29 ../vector/v.rectify/cp.c:344
-#, fuzzy
-msgid "Not enough memory to solve for transformation equation"
-#: ../imagery/i.rectify/cp.c:32 ../vector/v.rectify/cp.c:347
-#, fuzzy
-msgid "Invalid order"
-#: ../imagery/i.rectify/target.c:14 ../vector/v.rectify/target.c:15
-#, c-format
-msgid "Target information for group <%s> missing"
-msgstr ""
-#: ../imagery/i.rectify/target.c:20 ../vector/v.rectify/target.c:26
-#, fuzzy, c-format
-msgid "Target location <%s> not found"
-#: ../imagery/i.rectify/target.c:35 ../vector/v.rectify/target.c:40
-msgid "Please run i.target for group."
-msgstr ""
-#: ../imagery/i.target/main.c:48
-msgid "Targets an imagery group to a GRASS location and mapset."
-msgstr ""
-#: ../imagery/i.target/main.c:57
-msgid "Name of imagery target location"
-msgstr ""
-#: ../imagery/i.target/main.c:63
-msgid "Name of target mapset"
-msgstr ""
-#: ../imagery/i.target/main.c:68
-msgid "Set current location and mapset as target for of imagery group"
-msgstr ""
-#: ../imagery/i.target/main.c:90 ../imagery/i.target/main.c:107
-#: ../imagery/i.target/main.c:116
-#, c-format
-msgid "Group <%s> targeted for location [%s], mapset [%s]"
-msgstr ""
-#: ../imagery/i.target/main.c:93
-#, c-format
-msgid "Group <%s> has no target"
-msgstr ""
-#: ../imagery/i.target/main.c:101
-msgid ""
-"Use either the Current Mapset and Location Flag (-c)\n"
-" OR\n"
-" manually enter the variables"
-msgstr ""
-#: ../imagery/i.vpoints/plot.c:56 ../imagery/i.vpoints/plot.c:126
-#: ../display/d.graph/do_graph.c:377
-msgid "Cannot read symbol, cannot display points"
-msgstr ""
-#: ../imagery/i.vpoints/main.c:97
-msgid "Set registration points for an imagery group from a vector map or keyboard entry."
-msgstr ""
-#: ../imagery/i.albedo/main.c:89 ../imagery/i.eb.netrad/main.c:65
-#: ../imagery/i.eb.netrad/main.c:67
-msgid "albedo"
-msgstr ""
-#: ../imagery/i.albedo/main.c:90
-msgid "surface reflectance"
-msgstr ""
-#: ../imagery/i.albedo/main.c:91
-#, fuzzy
-msgid "Computes broad band albedo from surface reflectance."
-#: ../imagery/i.albedo/main.c:104
-msgid "Modis (7 input bands:1,2,3,4,5,6,7)"
-msgstr ""
-#: ../imagery/i.albedo/main.c:108
-msgid "NOAA AVHRR (2 input bands:1,2)"
-msgstr ""
-#: ../imagery/i.albedo/main.c:112
-msgid "Landsat (6 input bands:1,2,3,4,5,7)"
-msgstr ""
-#: ../imagery/i.albedo/main.c:116
-msgid "Aster (6 input bands:1,3,5,6,8,9)"
-msgstr ""
-#: ../imagery/i.albedo/main.c:120
-msgid "Agressive mode (Landsat)"
-msgstr ""
-#: ../imagery/i.albedo/main.c:122 ../imagery/i.albedo/main.c:129
-msgid "Albedo dry run to calculate some water to beach/sand/desert stretching, a kind of simple atmospheric correction"
-msgstr ""
-#: ../imagery/i.albedo/main.c:127
-msgid "Soft mode (Modis)"
-msgstr ""
-#: ../imagery/i.albedo/main.c:164
-#, fuzzy
-msgid "At least two raster maps are required"
-#: ../imagery/i.ifft/main.c:78 ../imagery/i.fft/main.c:79
-msgid "FFT"
-msgstr ""
-#: ../imagery/i.ifft/main.c:80
-msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
-msgstr ""
-#: ../imagery/i.ifft/main.c:85
-#, fuzzy
-msgid "Name of input raster map (image fft, real part)"
-#: ../imagery/i.ifft/main.c:89
-#, fuzzy
-msgid "Name of input raster map (image fft, imaginary part"
-#: ../imagery/i.ifft/main.c:115
-msgid "The real and imaginary original windows did not match"
-msgstr ""
-#: ../imagery/i.ifft/main.c:141 ../imagery/i.gensigset/read_data.c:22
-#: ../imagery/i.cluster/main.c:276
-#, fuzzy
-msgid "Reading raster maps..."
-#: ../imagery/i.ifft/main.c:157
-#, fuzzy
-msgid "Masking raster maps..."
-msgstr "'%s'. ड्राइवर चालू होत नाही"
-#: ../imagery/i.ifft/main.c:191 ../imagery/i.fft/main.c:166
-msgid "Rotating data..."
-msgstr ""
-#: ../imagery/i.ifft/main.c:200
-msgid "Starting Inverse FFT..."
-msgstr ""
-#: ../imagery/i.fft/main.c:81
-msgid "Fast Fourier Transform (FFT) for image processing."
-msgstr ""
-#: ../imagery/i.fft/main.c:90
-#, fuzzy
-msgid "Name for output real part arrays stored as raster map"
-#: ../imagery/i.fft/main.c:94
-#, fuzzy
-msgid "Name for output imaginary part arrays stored as raster map"
-#: ../imagery/i.fft/main.c:106
-msgid "Raster MASK found, consider to remove (see man-page). Will continue..."
-msgstr ""
-#: ../imagery/i.fft/main.c:129
-#, fuzzy, c-format
-msgid "Reading the raster map <%s>..."
-#: ../imagery/i.fft/main.c:145
-msgid "Starting FFT..."
-msgstr ""
-#: ../imagery/i.fft/main.c:174
-#, fuzzy
-msgid "Writing transformed data..."
-#: ../imagery/i.fft/main.c:200
-msgid " "
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:117
-msgid "QC"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:118
-msgid "Quality Control"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:119
-#, fuzzy
-msgid "Surface Reflectance"
-#: ../imagery/i.modis.qc/main.c:120
-msgid "Land Surface Temperature"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:121
-#, fuzzy
-msgid "Vegetation"
-#: ../imagery/i.modis.qc/main.c:122
-msgid "Modis"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:124
-msgid "Extract quality control parameters from Modis QC layers."
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:131
-msgid "Name of MODIS product type"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:132
-msgid "mod09Q1;surf. refl. 250m 8-days;mod09A1;surf. refl. 500m 8-days;mod09A1s;surf. refl. 500m 8-days, State QA;mod11A1;LST 1Km daily (Day/Night);mod11A2;LST 1Km 8-days (Day/Night);mod13A2;VI 1Km 16-days;mcd43B2;Brdf-Albedo Quality (Ancillary SDS) 1Km 8-days;mcd43B2q;Brdf-Albedo Quality (BRDF SDS) 1Km 8-days;"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:147
-#, fuzzy
-msgid "Name of QC type to extract"
-#: ../imagery/i.modis.qc/main.c:148
-msgid "adjcorr;mod09: Adjacency Correction;atcorr;mod09: Atmospheric Correction;cloud;mod09: Cloud State;data_quality;mod09: Band-Wise Data Quality Flag;diff_orbit_from_500m;mod09: 250m Band is at Different Orbit than 500m;modland_qa;mod09: MODIS Land General Quality Assessment;mandatory_qa_11A1;mod11A1: MODIS Land General Quality Assessment;data_quality_flag_11A1;mod11A1: Detailed Quality Indications;emis_error_11A1;mod11A1: Average Emissivity Error Classes;lst_error_11A1;mod11A1: Average LST Error Classes;data_quality_flag_11A2;mod11A2: Detailed Quality Indications;emis_error_11A2;mod11A2: Average Emissivity Error Classes;mandatory_qa_11A2;mod11A2: MODIS Land General Quality Assessment;lst_error_11A2;mod11A2: Average LST Error Classes;aerosol_quantity;mod09A1s: StateQA Internal Snow Maskbrdf_correction_performed;mod09A1s: StateQA Internal Snow Maskcirrus_detected;mod09A1s: StateQA Internal Snow Maskcloud_shadow;mod09A1s: StateQA Internal Snow Maskcloud_state;mod09A1s: Stat
 eQA Internal Snow Maskinternal_cloud_algorithm;mod09A1s: StateQA Internal Snow Maskinternal_fire_algorithm;mod09A1s: StateQA Internal Snow Maskinternal_snow_mask;mod09A1s: StateQA Internal Snow Maskland_water;mod09A1s: StateQA Internal Snow Maskmod35_snow_ice;mod09A1s: StateQA Internal Snow Maskpixel_adjacent_to_cloud;mod09A1s: StateQA Internal Snow Maskmodland_qa;mod13A2: MODIS Land General Quality Assessmentvi_usefulness;mod13A2: Quality estimation of the pixelaerosol_quantity;mod13A2: Quantity range of Aerosolpixel_adjacent_to_cloud;mod13A2: if pixel is a cloud neighbourbrdf_correction_performed;mod13A2: if BRDF correction performedmixed_clouds;mod13A2: if pixel mixed with cloudsland_water;mod13A2: separate land from various water objectspossible_snow_ice;mod13A2: if snow/ice present in pixelpossible_shadow;mod13A2: if shadow is present in pixelplatform;mcd43B2: Quality of BRDF correction performedland_water;mcd43B2: Quality of BRDF correction performedsun_z_angle_at_loca
 l_noon;mcd43B2: Quality of BRDF correction performedbrdf_correction_performed;mcd43B2q: Quality of BRDF correction performed"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:191
-#, fuzzy
-msgid "Name of the input QC layer [bit array]"
-#: ../imagery/i.modis.qc/main.c:199
-msgid "Band number of Modis product mod09Q1=[1,2],mod09A1=[1-7], mcd43B2q=[1-7]"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:200
-msgid "1;Band 1: Red;2;Band 2: NIR;3;Band 3: Blue;4;Band 4: Green;5;Band 5: SWIR 1;6;Band 6: SWIR 2;7;Band 7: SWIR 3;"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:211
-#, fuzzy
-msgid "Name of the output QC type classification layer"
-#: ../imagery/i.modis.qc/main.c:229
-msgid "This flag is only available for MOD09Q1 @ 250m products"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:233 ../imagery/i.modis.qc/main.c:263
-msgid "Band number out of allowed range [1-7]"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:235
-msgid "mod09Q1 product only has 2 bands"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:246
-msgid "This flag is only available for MOD09A1s @ 500m products"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:253
-msgid "This flag is only available for MOD13A2 @ 1Km products"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:259
-msgid "This flag is only available for MCD43B2 @ 1Km products"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:448
-msgid "Unknown names and/or combination, please check spelling"
-msgstr ""
-#: ../imagery/i.sunhours/main.c:46
-msgid "sunshine"
-msgstr ""
-#: ../imagery/i.sunhours/main.c:47
-msgid "hours"
-msgstr ""
-#: ../imagery/i.sunhours/main.c:48
-msgid "daytime"
-msgstr ""
-#: ../imagery/i.sunhours/main.c:49
-#, fuzzy
-msgid "Creates a sunshine hours map."
-#: ../imagery/i.sunhours/main.c:53 ../imagery/i.eb.netrad/main.c:104
-msgid "dayofyear"
-msgstr ""
-#: ../imagery/i.sunhours/main.c:54
-#, fuzzy
-msgid "Name of the day of year input map"
-#: ../imagery/i.sunhours/main.c:58
-#, fuzzy
-msgid "Name of the latitude input map"
-#: ../imagery/i.sunhours/main.c:61
-#, fuzzy
-msgid "Name of the output sunshine hours map"
-#: ../imagery/i.gensigset/main.c:45
-#, fuzzy
-msgid "Generates statistics for i.smap from raster map."
-#: ../imagery/i.gensigset/main.c:55
-#, fuzzy, c-format
-msgid "Clustering class %d (%d pixels)..."
-#: ../imagery/i.gensigset/main.c:58
-#, fuzzy, c-format
-msgid "Number of subclasses is %d"
-#: ../imagery/i.gensigset/parse.c:27
-msgid "Maximum number of sub-signatures in any class"
-msgstr ""
-#: ../imagery/i.gensigset/parse.c:52
-#, fuzzy, c-format
-msgid "Illegal number of sub-signatures (%s)"
-#: ../imagery/i.gensigset/subcluster.c:76
-#, c-format
-msgid "Not enough pixels in class %d"
-msgstr ""
-#: ../imagery/i.gensigset/subcluster.c:86
-#, fuzzy, c-format
-msgid "Too many subclasses for class index %d"
-#: ../imagery/i.gensigset/subcluster.c:88
-#, fuzzy, c-format
-msgid "Number of subclasses set to %d"
-#: ../imagery/i.gensigset/subcluster.c:106
-#, c-format
-msgid "Combining subclasses (%d,%d)..."
-msgstr ""
-#: ../imagery/i.gensigset/subcluster.c:318
-#, c-format
-msgid "Subsignature %d only contains %.0f pixels"
-msgstr ""
-#: ../imagery/i.gensigset/subcluster.c:552
-msgid "Unreliable clustering. Try a smaller initial number of clusters"
-msgstr ""
-#: ../imagery/i.gensigset/subcluster.c:561
-#, c-format
-msgid "Removed a singular subsignature number %d (%d remain)"
-msgstr ""
-#: ../imagery/i.emissivity/main.c:44 ../imagery/i.eb.netrad/main.c:93
-#: ../imagery/i.eb.netrad/main.c:95
-msgid "emissivity"
-msgstr ""
-#: ../imagery/i.emissivity/main.c:45
-msgid "land flux"
-msgstr ""
-#: ../imagery/i.emissivity/main.c:48
-msgid "Computes emissivity from NDVI, generic method for spares land."
-msgstr ""
-#: ../imagery/i.emissivity/main.c:52
-#, fuzzy
-msgid "Name of the NDVI map [-]"
-#: ../imagery/i.emissivity/main.c:55
-#, fuzzy
-msgid "Name of the output emissivity layer"
-#: ../imagery/i.cca/main.c:86
-msgid "CCA"
-msgstr ""
-#: ../imagery/i.cca/main.c:88
-msgid "Canonical components analysis (cca) program for image processing."
-msgstr ""
-#: ../imagery/i.cca/main.c:102
-#, fuzzy
-msgid "File containing spectral signatures"
-#: ../imagery/i.cca/main.c:105
-msgid "Output raster map prefix name"
-msgstr ""
-#: ../imagery/i.cca/main.c:113
-msgid "Unknown imagery group."
-msgstr ""
-#: ../imagery/i.cca/main.c:116
-msgid "Unable to find subgroup reference information."
-msgstr ""
-#: ../imagery/i.cca/main.c:122
-#, fuzzy
-msgid "Unable to open the signature file"
-#: ../imagery/i.cca/main.c:126
-msgid "Error while reading the signatures file."
-msgstr ""
-#: ../imagery/i.cca/main.c:131
-msgid "Need at least two signatures in signature file."
-msgstr ""
-#: ../imagery/i.cca/main.c:225
-#, c-format
-msgid "The output cell map <%s.%d> has values outside the 0-255 range."
-msgstr ""
-#: ../imagery/i.cca/transform.c:24
-msgid "Unable to allocate cell buffers."
-msgstr ""
-#: ../imagery/i.cca/transform.c:58
-msgid "Transform completed.\n"
-msgstr ""
-#: ../imagery/i.cluster/print1.c:12
-#, c-format
-msgid ""
-"means and standard deviations for %d band%s\n"
-"\n"
-msgstr ""
-#: ../imagery/i.cluster/print1.c:14
-#, c-format
-msgid " means  "
-msgstr ""
-#: ../imagery/i.cluster/print1.c:18
-#, c-format
-msgid " stddev "
-msgstr ""
-#: ../imagery/i.cluster/print4.c:16
-#, c-format
-msgid "class centroids (sum/count=mean)\n"
-msgstr ""
-#: ../imagery/i.cluster/print4.c:18
-#, c-format
-msgid "band %d"
-msgstr ""
-#: ../imagery/i.cluster/print6.c:11
-#, c-format
-msgid "class distribution"
-msgstr ""
-#: ../imagery/i.cluster/print3.c:16
-#, c-format
-msgid ""
-"\n"
-"initial means for each band\n"
-"\n"
-msgstr ""
-#: ../imagery/i.cluster/print3.c:19
-#, c-format
-msgid "class %-3d "
-msgstr ""
-#: ../imagery/i.cluster/checkpt.c:16
-#, c-format
-msgid "using seed means (%d files)\n"
-msgstr ""
-#: ../imagery/i.cluster/checkpt.c:28
-#, c-format
-msgid ""
-"\n"
-"######## iteration %d ###########\n"
-msgstr ""
-#: ../imagery/i.cluster/checkpt.c:30
-#, c-format
-msgid "%d classes, %.2f%% points stable\n"
-msgstr ""
-#: ../imagery/i.cluster/checkpt.c:40
-#, c-format
-msgid "Iteration %.2d: convergence %.2f%% (%s elapsed, %s left)"
-msgstr ""
-#: ../imagery/i.cluster/print2.c:18
-#, c-format
-msgid ""
-"\n"
-"class means/stddev for each band\n"
-"\n"
-msgstr ""
-#: ../imagery/i.cluster/print2.c:22
-#, c-format
-msgid "class %d (%d)\n"
-msgstr ""
-#: ../imagery/i.cluster/print2.c:23
-#, c-format
-msgid "  means "
-msgstr ""
-#: ../imagery/i.cluster/print2.c:28
-#, c-format
-msgid "  stddev"
-msgstr ""
-#: ../imagery/i.cluster/open_files.c:34
-#, fuzzy, c-format
-msgid "Raster map <%s> do not exists in subgroup <%s>"
-#: ../imagery/i.cluster/open_files.c:39
-#, fuzzy
-msgid "No raster maps found"
-#: ../imagery/i.cluster/open_files.c:43
-#, fuzzy, c-format
-msgid "Subgroup <%s> doesn't have any raster maps"
-#: ../imagery/i.cluster/open_files.c:46
-#, fuzzy, c-format
-msgid "Subgroup <%s> only has 1 raster map"
-#: ../imagery/i.cluster/open_files.c:47
-#, fuzzy
-msgid "Subgroup must have at least 2 raster maps"
-#: ../imagery/i.cluster/open_files.c:64
-#, fuzzy, c-format
-msgid "Unable to open seed signature file <%s>"
-#: ../imagery/i.cluster/main.c:77
-#, fuzzy
-msgid "signatures"
-#: ../imagery/i.cluster/main.c:79
-msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm."
-msgstr ""
-#: ../imagery/i.cluster/main.c:82
-msgid "The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification."
-msgstr ""
-#: ../imagery/i.cluster/main.c:101
-msgid "Initial number of classes"
-msgstr ""
-#: ../imagery/i.cluster/main.c:109
-#, fuzzy
-msgid "Name of file containing initial signatures"
-#: ../imagery/i.cluster/main.c:117
-msgid "Sampling intervals (by row and col); default: ~10,000 pixels"
-msgstr ""
-#: ../imagery/i.cluster/main.c:124
-msgid "Maximum number of iterations"
-msgstr ""
-#: ../imagery/i.cluster/main.c:133
-msgid "Percent convergence"
-msgstr ""
-#: ../imagery/i.cluster/main.c:141
-msgid "Cluster separation"
-msgstr ""
-#: ../imagery/i.cluster/main.c:149
-msgid "Minimum number of pixels in a class"
-msgstr ""
-#: ../imagery/i.cluster/main.c:156
-#, fuzzy
-msgid "Name for output file containing final report"
-#: ../imagery/i.cluster/main.c:175
-#, fuzzy, c-format
-msgid "Illegal number of initial classes (%s)"
-#: ../imagery/i.cluster/main.c:186
-#, fuzzy, c-format
-msgid "Illegal value(s) of sample intervals (%s)"
-msgstr "तक्त्याचे नाव"
-#: ../imagery/i.cluster/main.c:200
-#, fuzzy, c-format
-msgid "Illegal value of iterations (%s>)"
-#: ../imagery/i.cluster/main.c:206
-#, fuzzy, c-format
-msgid "Illegal value of convergence (%s)"
-#: ../imagery/i.cluster/main.c:211
-#, fuzzy, c-format
-msgid "Illegal value of separation (%s)"
-#: ../imagery/i.cluster/main.c:216
-#, fuzzy, c-format
-msgid "Illegal value of min_size (%s)"
-#: ../imagery/i.cluster/main.c:225
-#, fuzzy, c-format
-msgid "Unable to create report file <%s>"
-#: ../imagery/i.cluster/main.c:233
-#, c-format
-msgid ""
-"#################### CLUSTER (%s) ####################\n"
-"\n"
-msgstr ""
-#: ../imagery/i.cluster/main.c:235
-#, c-format
-msgid "Location: %s\n"
-msgstr ""
-#: ../imagery/i.cluster/main.c:236
-#, c-format
-msgid "Mapset:   %s\n"
-msgstr ""
-#: ../imagery/i.cluster/main.c:237
-#, c-format
-msgid "Group:    %s\n"
-msgstr ""
-#: ../imagery/i.cluster/main.c:238
-#, c-format
-msgid "Subgroup: %s\n"
-msgstr ""
-#: ../imagery/i.cluster/main.c:240
-#, c-format
-msgid " %s\n"
-msgstr ""
-#: ../imagery/i.cluster/main.c:243
-#, c-format
-msgid "Result signature file: %s\n"
-msgstr ""
-#: ../imagery/i.cluster/main.c:245
-#, c-format
-msgid "Region\n"
-msgstr ""
-#: ../imagery/i.cluster/main.c:246
-#, c-format
-msgid "  North: %12.2f  East: %12.2f\n"
-msgstr ""
-#: ../imagery/i.cluster/main.c:248
-#, c-format
-msgid "  South: %12.2f  West: %12.2f\n"
-msgstr ""
-#: ../imagery/i.cluster/main.c:250
-#, c-format
-msgid "  Res:   %12.2f  Res:  %12.2f\n"
-msgstr ""
-#: ../imagery/i.cluster/main.c:252
-#, c-format
-msgid "  Rows:  %12d  Cols: %12d  Cells: %d\n"
-msgstr ""
-#: ../imagery/i.cluster/main.c:254
-#, c-format
-msgid "Mask: %s\n"
-msgstr ""
-#: ../imagery/i.cluster/main.c:256
-#, c-format
-msgid "Cluster parameters\n"
-msgstr ""
-#: ../imagery/i.cluster/main.c:257
-#, c-format
-msgid " Number of initial classes:    %d"
-msgstr ""
-#: ../imagery/i.cluster/main.c:259
-#, c-format
-msgid " [from signature file %s]"
-msgstr ""
-#: ../imagery/i.cluster/main.c:261
-#, c-format
-msgid " Minimum class size:           %d\n"
-msgstr ""
-#: ../imagery/i.cluster/main.c:262
-#, c-format
-msgid " Minimum class separation:     %f\n"
-msgstr ""
-#: ../imagery/i.cluster/main.c:263
-#, c-format
-msgid " Percent convergence:          %f\n"
-msgstr ""
-#: ../imagery/i.cluster/main.c:264
-#, c-format
-msgid " Maximum number of iterations: %d\n"
-msgstr ""
-#: ../imagery/i.cluster/main.c:266
-#, c-format
-msgid " Row sampling interval:        %d\n"
-msgstr ""
-#: ../imagery/i.cluster/main.c:267
-#, c-format
-msgid " Col sampling interval:        %d\n"
-msgstr ""
-#: ../imagery/i.cluster/main.c:286
-msgid "Out of Memory. Please run again and choose a smaller sample size."
-msgstr ""
-#: ../imagery/i.cluster/main.c:292
-#, c-format
-msgid "Sample size: %d points\n"
-msgstr ""
-#: ../imagery/i.cluster/main.c:295
-msgid "Not enough sample points. Please run again and choose a larger sample size."
-msgstr ""
-#: ../imagery/i.cluster/main.c:299
-msgid "Not enough non-zero sample data points. Check your current region (and mask)."
-msgstr ""
-#: ../imagery/i.cluster/main.c:312
-#, c-format
-msgid ""
-"\n"
-"########## final results #############\n"
-msgstr ""
-#: ../imagery/i.cluster/main.c:313
-#, c-format
-msgid "%d classes (convergence=%.1f%%)\n"
-msgstr ""
-#: ../imagery/i.cluster/main.c:324
-#, fuzzy, c-format
-msgid "Unable to create signature file <%s> for group <%s>, subsgroup <%s>"
-#: ../imagery/i.cluster/main.c:329
-#, c-format
-msgid ""
-"\n"
-"\n"
-"#################### CLASSES ####################\n"
-msgstr ""
-#: ../imagery/i.cluster/main.c:330
-#, c-format
-msgid ""
-"\n"
-"%d classes, %.2f%% points stable\n"
-msgstr ""
-#: ../imagery/i.cluster/main.c:332
-#, c-format
-msgid ""
-"\n"
-"######## CLUSTER END (%s) ########\n"
-msgstr ""
-#: ../imagery/i.cluster/print5.c:15
-#, c-format
-msgid ""
-"\n"
-"class separability matrix\n"
-"\n"
-msgstr ""
-#: ../imagery/i.biomass/main.c:51
-msgid "biomass"
-msgstr ""
-#: ../imagery/i.biomass/main.c:52
-msgid "fpar"
-msgstr ""
-#: ../imagery/i.biomass/main.c:53
-msgid "yield"
-msgstr ""
-#: ../imagery/i.biomass/main.c:55
-msgid "Computes biomass growth, precursor of crop yield calculation."
-msgstr ""
-#: ../imagery/i.biomass/main.c:60
-#, fuzzy
-msgid "Name of fPAR raster map"
-#: ../imagery/i.biomass/main.c:65
-#, fuzzy
-msgid "Name of light use efficiency raster map (UZB:cotton=1.9)"
-#: ../imagery/i.biomass/main.c:69
-#, fuzzy
-msgid "Name of degree latitude raster map [dd.ddd]"
-#: ../imagery/i.biomass/main.c:73
-#, fuzzy
-msgid "Name of Day of Year raster map [1-366]"
-#: ../imagery/i.biomass/main.c:78
-#, fuzzy
-msgid "Name of single-way transmissivity raster map [0.0-1.0]"
-#: ../imagery/i.biomass/main.c:83
-#, fuzzy
-msgid "Value of water availability raster map [0.0-1.0]"
-#: ../imagery/i.biomass/main.c:87
-#, fuzzy
-msgid "Name for output daily biomass growth raster map [kg/ha/d]"
-#: ../imagery/i.eb.netrad/main.c:58
-#, fuzzy
-msgid "net radiation"
-#: ../imagery/i.eb.netrad/main.c:61
-msgid "Net radiation approximation (Bastiaanssen, 1995)."
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:66
-#, fuzzy
-msgid "Name of the Albedo map [0.0;1.0]"
-#: ../imagery/i.eb.netrad/main.c:70 ../imagery/i.eb.netrad/main.c:72
-msgid "ndvi"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:71
-#, fuzzy
-msgid "Name of the ndvi map [-1.0;+1.0]"
-#: ../imagery/i.eb.netrad/main.c:77
-#, fuzzy
-msgid "Name of the Surface temperature map [degree Kelvin]"
-#: ../imagery/i.eb.netrad/main.c:78
-msgid "tempk"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:81
-msgid "localutctime"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:83
-#, fuzzy
-msgid "Name of the map of local UTC time of satellite overpass [hh.hhh]"
-#: ../imagery/i.eb.netrad/main.c:84
-#: ../locale/scriptstrings/t.time.abs_to_translate.c:2
-#: ../locale/scriptstrings/t.time.rel_to_translate.c:2
-#, fuzzy
-msgid "time"
-#: ../imagery/i.eb.netrad/main.c:87
-msgid "temperaturedifference2m"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:89
-msgid "Name of the difference of temperature from surface skin to about 2 m height [K]"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:90
-msgid "dtair"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:94
-#, fuzzy
-msgid "Name of the emissivity map [-]"
-#: ../imagery/i.eb.netrad/main.c:98
-msgid "transmissivitysingleway"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:100
-#, fuzzy
-msgid "Name of the single-way atmospheric transmissivitymap [-]"
-#: ../imagery/i.eb.netrad/main.c:101
-msgid "tsw"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:105
-#, fuzzy
-msgid "Name of the Day Of Year (DOY) map [-]"
-#: ../imagery/i.eb.netrad/main.c:106
-msgid "doy"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:109
-msgid "sunzenithangle"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:110
-#, fuzzy
-msgid "Name of the sun zenith angle map [degrees]"
-#: ../imagery/i.eb.netrad/main.c:111
-msgid "sunzangle"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:114
-#, fuzzy
-msgid "Name of the output net radiation layer"
-#: ../imagery/i.find/main.c:63
-#, c-format
-msgid "usage: %s location mapset element file."
-msgstr ""
-#: ../imagery/i.find/main.c:83
-#, fuzzy
-msgid "Unable to open temp file."
-#: ../imagery/i.eb.evapfr/main.c:53
-msgid "Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil moisture (Makin, Molden and Bastiaanssen, 2001)."
-msgstr ""
-#: ../imagery/i.eb.evapfr/main.c:59 ../imagery/i.eb.soilheatflux/main.c:71
-#, fuzzy
-msgid "Name of Net Radiation raster map [W/m2]"
-#: ../imagery/i.eb.evapfr/main.c:63
-#, fuzzy
-msgid "Name of soil heat flux raster map [W/m2]"
-#: ../imagery/i.eb.evapfr/main.c:67
-#, fuzzy
-msgid "Name of sensible heat flux raster map [W/m2]"
-#: ../imagery/i.eb.evapfr/main.c:72
-#, fuzzy
-msgid "Name for output evaporative fraction raster map"
-#: ../imagery/i.eb.evapfr/main.c:78
-#, fuzzy
-msgid "Name for output root zone soil moisture raster map"
-#: ../imagery/i.eb.evapfr/main.c:83
-msgid "Root zone soil moisture output (Makin, Molden and Bastiaanssen, 2001)"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:79
-msgid "Computes temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s)."
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:86
-#, fuzzy
-msgid "Names of satellite ETa raster maps [mm/d or cm/d]"
-#: ../imagery/i.evapo.time/main.c:91
-msgid "Names of satellite ETa Day of Year (DOY) raster maps [0-400] [-]"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:96
-#, fuzzy
-msgid "Names of meteorological station ETo raster maps [0-400] [mm/d or cm/d]"
-#: ../imagery/i.evapo.time/main.c:102
-msgid "Value of DOY for ETo first day"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:108
-msgid "Value of DOY for the first day of the period studied"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:114
-msgid "Value of DOY for the last day of the period studied"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:142
-msgid "The DOY for end_period can not be smaller than start_period"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:146
-msgid "The DOY for start_period can not be smaller than eto_doy_min"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:151
-#, c-format
-msgid "Too many ETa files. Only %d allowed."
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:162 ../imagery/i.evapo.time/main.c:178
-#: ../imagery/i.evapo.time/main.c:200
-msgid "The min specified input map is two"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:167
-#, c-format
-msgid "Too many ETa_doy files. Only %d allowed."
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:183
-msgid "ETa and ETa_DOY file numbers are not equal!"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:189
-#, c-format
-msgid "Too many ETo files. Only %d allowed."
-msgstr ""
-#: ../imagery/i.pca/support.c:44
-msgid "Eigen values, (vectors), and [percent importance]:"
-msgstr ""
-#: ../imagery/i.pca/main.c:68
-#, fuzzy
-msgid "image transformation"
-#: ../imagery/i.pca/main.c:69
-msgid "PCA"
-msgstr ""
-#: ../imagery/i.pca/main.c:70
-msgid "Principal components analysis (PCA) for image processing."
-msgstr ""
-#: ../imagery/i.pca/main.c:75
-#, fuzzy
-msgid "Name of two or more input raster maps"
-#: ../imagery/i.pca/main.c:78
-#, fuzzy
-msgid "Base name for output raster maps"
-#: ../imagery/i.pca/main.c:80
-msgid "A numerical suffix will be added for each component map"
-msgstr ""
-#: ../imagery/i.pca/main.c:93
-#, fuzzy
-msgid "Rescaling range for output maps"
-#: ../imagery/i.pca/main.c:95
-msgid "For no rescaling use 0,0"
-msgstr ""
-#: ../imagery/i.pca/main.c:96
-msgid "Rescale"
-msgstr ""
-#: ../imagery/i.pca/main.c:100
-msgid "Normalize (center and scale) input maps"
-msgstr ""
-#: ../imagery/i.pca/main.c:110
-#, fuzzy
-msgid "Sorry, at least 2 input bands must be provided"
-#: ../imagery/i.pca/main.c:215
-msgid "Scale range length should be > 0. Using default values: 0,255."
-msgstr ""
-#: ../imagery/i.pca/main.c:261
-#, fuzzy
-msgid "Computing covariance matrix..."
-#: ../imagery/i.pca/main.c:370
-#, fuzzy, c-format
-msgid "Rescaling to range %d,%d..."
-#: ../imagery/i.pca/main.c:378
-#, fuzzy
-msgid "Calculating principal components..."
-#: ../imagery/i.rgb.his/main.c:51
-msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
-msgstr ""
-#: ../imagery/i.rgb.his/main.c:57
-#, fuzzy
-msgid "Name of input raster map (red)"
-#: ../imagery/i.rgb.his/main.c:61
-#, fuzzy
-msgid "Name of input raster map (green)"
-#: ../imagery/i.rgb.his/main.c:65
-#, fuzzy
-msgid "Name of input raster map (blue)"
-#: ../imagery/i.rgb.his/main.c:69
-#, fuzzy
-msgid "Name for output raster map (hue)"
-#: ../imagery/i.rgb.his/main.c:73
-#, fuzzy
-msgid "Name for output raster map (intensity)"
-#: ../imagery/i.rgb.his/main.c:77
-#, fuzzy
-msgid "Name for output raster map (saturation)"
-#: ../imagery/i.evapo.pm/main.c:61
-msgid "Computes potential evapotranspiration calculation with hourly Penman-Monteith."
-msgstr ""
-#: ../imagery/i.evapo.pm/main.c:65
-#, fuzzy
-msgid "Name of input elevation raster map [m a.s.l.]"
-#: ../imagery/i.evapo.pm/main.c:69
-#, fuzzy
-msgid "Name of input temperature raster map [C]"
-#: ../imagery/i.evapo.pm/main.c:73
-#, fuzzy
-msgid "Name of input relative humidity raster map [%]"
-#: ../imagery/i.evapo.pm/main.c:77
-#, fuzzy
-msgid "Name of input wind speed raster map [m/s]"
-#: ../imagery/i.evapo.pm/main.c:82
-#, fuzzy
-msgid "Name of input net solar radiation raster map [MJ/m2/h]"
-#: ../imagery/i.evapo.pm/main.c:86
-#, fuzzy
-msgid "Name of input crop height raster map [m]"
-#: ../imagery/i.evapo.pm/main.c:89
-#, fuzzy
-msgid "Name for output raster map [mm/h]"
-#: ../imagery/i.evapo.pm/main.c:93
-#, fuzzy
-msgid "Set negative evapotranspiration to zero"
-#: ../imagery/i.evapo.pm/main.c:97
-msgid "Use Night-time"
-msgstr ""
-#: ../imagery/i.eb.soilheatflux/main.c:51
-msgid "soil heat flux"
-msgstr ""
-#: ../imagery/i.eb.soilheatflux/main.c:53
-msgid "Soil heat flux approximation (Bastiaanssen, 1995)."
-msgstr ""
-#: ../imagery/i.eb.soilheatflux/main.c:58
-#, fuzzy
-msgid "Name of Albedo raster map [0.0;1.0]"
-#: ../imagery/i.eb.soilheatflux/main.c:62
-#, fuzzy
-msgid "Name of NDVI raster map [-1.0;+1.0]"
-#: ../imagery/i.eb.soilheatflux/main.c:67
-#, fuzzy
-msgid "Name of Surface temperature raster map [K]"
-#: ../imagery/i.eb.soilheatflux/main.c:76
-#, fuzzy
-msgid "Name of time of satellite overpass raster map [local time in UTC]"
-#: ../imagery/i.eb.soilheatflux/main.c:83
-msgid "HAPEX-Sahel empirical correction (Roerink, 1995)"
-msgstr ""
-#: ../ps/ps.map/r_info.c:48 ../ps/ps.map/r_colortable.c:62
-#: ../ps/ps.map/r_vlegend.c:49
-msgid "illegal where request"
-msgstr ""
-#: ../ps/ps.map/r_info.c:67 ../ps/ps.map/ps_outline.c:87
-#: ../ps/ps.map/getgrid.c:61 ../ps/ps.map/getgrid.c:85
-#: ../ps/ps.map/getgrid.c:171 ../ps/ps.map/getgrid.c:195
-#: ../ps/ps.map/r_header.c:65
-#, fuzzy
-msgid "Unsupported color request"
-#: ../ps/ps.map/r_info.c:69 ../ps/ps.map/r_instructions.c:131
-#: ../ps/ps.map/r_instructions.c:446 ../ps/ps.map/ps_outline.c:89
-#: ../ps/ps.map/getgrid.c:63 ../ps/ps.map/getgrid.c:87
-#: ../ps/ps.map/getgrid.c:173 ../ps/ps.map/getgrid.c:197
-#: ../ps/ps.map/r_header.c:67
-msgid "illegal color request"
-msgstr ""
-#: ../ps/ps.map/r_info.c:81
-msgid "illegal bgcolor request"
-msgstr ""
-#: ../ps/ps.map/r_info.c:93 ../ps/ps.map/r_vlegend.c:86
-msgid "illegal border color request"
-msgstr ""
-#: ../ps/ps.map/r_info.c:103
-msgid "illegal mapinfo sub-request"
-msgstr ""
-#: ../ps/ps.map/ps_vpoints.c:72 ../ps/ps.map/ps_vareas.c:164
-#: ../ps/ps.map/ps_vlines.c:56
-#, fuzzy
-msgid "Cannot load data from table"
-#: ../ps/ps.map/ps_vpoints.c:88 ../ps/ps.map/do_plt.c:147
-msgid "Cannot read symbol, using default icon"
-msgstr ""
-#: ../ps/ps.map/ps_vpoints.c:128 ../ps/ps.map/ps_vareas.c:67
-#: ../ps/ps.map/ps_vareas.c:78 ../ps/ps.map/ps_vlines.c:84
-msgid "Read error in vector map"
-msgstr ""
-#: ../ps/ps.map/ps_vpoints.c:165 ../ps/ps.map/ps_vpoints.c:176
-#: ../ps/ps.map/ps_vpoints.c:200 ../ps/ps.map/ps_vpoints.c:241
-#: ../ps/ps.map/ps_vpoints.c:251 ../ps/ps.map/ps_vareas.c:102
-#: ../ps/ps.map/ps_vlines.c:119
-#, c-format
-msgid "No record for category [%d]"
-msgstr ""
-#: ../ps/ps.map/ps_vpoints.c:182
-#, c-format
-msgid "Attribute is of invalid size [%.3f] for category [%d]"
-msgstr ""
-#: ../ps/ps.map/ps_vpoints.c:206 ../ps/ps.map/ps_vareas.c:108
-#: ../ps/ps.map/ps_vlines.c:125
-#, c-format
-msgid "Invalid RGB color definition in column <%s> for category [%d]"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:48
-msgid "Data exists after final 'end' instruction!"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:62
-#, fuzzy
-msgid "no file specified"
-#: ../ps/ps.map/r_instructions.c:66
-#, fuzzy
-msgid "unable to open"
-#: ../ps/ps.map/r_instructions.c:97
-#, fuzzy
-msgid "illegal maploc request"
-#: ../ps/ps.map/r_instructions.c:111 ../ps/ps.map/main.c:220
-msgid "illegal copies request"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:126 ../ps/ps.map/r_instructions.c:322
-#, fuzzy
-msgid "no raster map selected yet"
-#: ../ps/ps.map/r_instructions.c:142
-#, fuzzy
-msgid "illegal value list"
-#: ../ps/ps.map/r_instructions.c:178
-msgid "scalebar is not appropriate for this projection"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:186
-msgid "Bad scalebar length"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:202
-#, fuzzy
-msgid "illegal text request"
-#: ../ps/ps.map/r_instructions.c:216
-#, fuzzy
-msgid "illegal point request"
-#: ../ps/ps.map/r_instructions.c:230
-#, fuzzy
-msgid "illegal eps request"
-#: ../ps/ps.map/r_instructions.c:247
-#, fuzzy
-msgid "illegal line request"
-#: ../ps/ps.map/r_instructions.c:264
-#, fuzzy
-msgid "illegal rectangle request"
-#: ../ps/ps.map/r_instructions.c:275
-#, fuzzy
-msgid "illegal comments request"
-#: ../ps/ps.map/r_instructions.c:291
-#, fuzzy
-msgid "illegal scale request"
-#: ../ps/ps.map/r_instructions.c:351
-#, fuzzy
-msgid "group not found"
-#: ../ps/ps.map/r_instructions.c:393
-msgid "illegal grid spacing"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:404
-msgid "geogrid is not available for this projection"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:414
-msgid "illegal geo-grid spacing"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:451
-#, fuzzy
-msgid "illegal request"
-#: ../ps/ps.map/catval.c:49 ../ps/ps.map/catval.c:111
-#: ../ps/ps.map/catval.c:177 ../vector/v.label/main.c:273
-#: ../vector/v.class/main.c:100 ../vector/v.vol.rst/user1.c:95
-#: ../vector/v.label.sa/labels.c:74
-#, fuzzy
-msgid "Unable to get layer info for vector map"
-#: ../ps/ps.map/catval.c:64
-msgid "Column type not supported (must be string)"
-msgstr ""
-#: ../ps/ps.map/catval.c:67 ../ps/ps.map/catval.c:132
-#: ../ps/ps.map/catval.c:199 ../vector/v.univar/main.c:154
-#: ../vector/v.sample/main.c:158 ../vector/v.normal/main.c:133
-#: ../vector/v.class/main.c:121 ../vector/v.to.rast3/main.c:92
-#: ../vector/v.surf.idw/read_sites.c:54 ../vector/v.surf.bspline/main.c:384
-#, fuzzy
-msgid "Unable to select data from table"
-#: ../ps/ps.map/catval.c:129
-msgid "Size column type must be numeric"
-msgstr ""
-#: ../ps/ps.map/catval.c:196
-msgid "Rotation column type must be numeric"
-msgstr ""
-#: ../ps/ps.map/ps_raster.c:42
-#, fuzzy
-msgid "Can't create temporary PostScript mask file."
-#: ../ps/ps.map/ps_raster.c:105
-#, fuzzy, c-format
-msgid "Reading raster maps in group <%s>..."
-#: ../ps/ps.map/do_psfiles.c:20
-#, fuzzy, c-format
-msgid "Reading PostScript include file <%s> ..."
-#: ../ps/ps.map/r_vpoints.c:244
-#, c-format
-msgid "The mapping instruction <%s> will be renamed to <%s> in future versions of GRASS. Please use <%s> instead."
-msgstr ""
-#: ../ps/ps.map/ps_outline.c:43
-#, fuzzy, c-format
-msgid "Outlining areas in raster map <%s in %s> ..."
-#: ../ps/ps.map/ps_outline.c:100 ../ps/ps.map/r_colortable.c:70
-msgid "illegal width request"
-msgstr ""
-#: ../ps/ps.map/ps_outline.c:107
-#, fuzzy
-msgid "illegal outline sub-request"
-#: ../ps/ps.map/r_group.c:29
-#, fuzzy
-msgid "Can't get group information"
-#: ../ps/ps.map/scale.c:136
-msgid "PSmap: do_scale(): shouldn't happen"
-msgstr ""
-#: ../ps/ps.map/r_colortable.c:78
-msgid "illegal height request"
-msgstr ""
-#: ../ps/ps.map/r_colortable.c:95
-msgid "illegal range request"
-msgstr ""
-#: ../ps/ps.map/r_colortable.c:111
-#, fuzzy
-msgid "illegal columns request"
-#: ../ps/ps.map/r_colortable.c:130
-#, fuzzy
-msgid "Unsupported color request (colortable)"
-#: ../ps/ps.map/r_colortable.c:132
-msgid "illegal color request (colortable)"
-msgstr ""
-#: ../ps/ps.map/r_colortable.c:159
-msgid "illegal colortabe sub-request"
-msgstr ""
-#: ../ps/ps.map/r_colortable.c:170
-#, fuzzy
-msgid "No raster selected for colortable!"
-#: ../ps/ps.map/do_scalebar.c:194
-msgid "meters"
-msgstr ""
-#: ../ps/ps.map/do_scalebar.c:196
-msgid "kilometers"
-msgstr ""
-#: ../ps/ps.map/do_scalebar.c:198
-msgid "feet"
-msgstr ""
-#: ../ps/ps.map/do_scalebar.c:200
-#, fuzzy
-msgid "miles"
-#: ../ps/ps.map/do_scalebar.c:202
-msgid "nautical miles"
-msgstr ""
-#: ../ps/ps.map/ps_fclrtbl.c:46 ../ps/ps.map/ps_clrtbl.c:35
-#, fuzzy, c-format
-msgid "Creating color table for <%s in %s>..."
-#: ../ps/ps.map/ps_fclrtbl.c:51
-msgid "Range information not available (run r.support)"
-msgstr ""
-#: ../ps/ps.map/ps_fclrtbl.c:64
-msgid "A floating point colortable must contain a range of values"
-msgstr ""
-#: ../ps/ps.map/ps_fclrtbl.c:69 ../ps/ps.map/ps_clrtbl.c:44
-msgid "Unable to read colors for colorbar"
-msgstr ""
-#: ../ps/ps.map/ps_fclrtbl.c:92 ../ps/ps.map/ps_fclrtbl.c:97
-#: ../ps/ps.map/ps_clrtbl.c:69
-msgid "Colorbar y location beyond page margins. Adjusting."
-msgstr ""
-#: ../ps/ps.map/ps_fclrtbl.c:103 ../ps/ps.map/ps_fclrtbl.c:108
-#: ../ps/ps.map/ps_clrtbl.c:75
-msgid "Colorbar x location beyond page margins. Adjusting."
-msgstr ""
-#: ../ps/ps.map/getgrid.c:95 ../ps/ps.map/getgrid.c:206
-#, fuzzy
-msgid "illegal numbers request"
-#: ../ps/ps.map/getgrid.c:126 ../ps/ps.map/getgrid.c:234
-#, fuzzy
-msgid "illegal grid width request"
-#: ../ps/ps.map/getgrid.c:132
-#, fuzzy
-msgid "illegal request (grid)"
-#: ../ps/ps.map/getgrid.c:240
-#, fuzzy
-msgid "illegal request (geogrid)"
-#: ../ps/ps.map/r_plt.c:174
-#, fuzzy
-msgid "Can't open eps file"
-#: ../ps/ps.map/map_setup.c:86
-#, fuzzy, c-format
-msgid "Scale set to %s"
-#: ../ps/ps.map/do_vectors.c:33
-#, fuzzy, c-format
-msgid "Reading vector map <%s in %s> ..."
-#: ../ps/ps.map/do_vectors.c:137
-#, fuzzy, c-format
-msgid "Reading vector points file <%s in %s> ..."
-#: ../ps/ps.map/r_header.c:77
-#, fuzzy
-msgid "illegal header sub-request"
-#: ../ps/ps.map/do_labels.c:44
-#, c-format
-msgid "Can't open label file <%s> in mapset <%s>"
-msgstr ""
-#: ../ps/ps.map/do_labels.c:48
-#, fuzzy, c-format
-msgid "Reading labels file <%s in %s> ..."
-#: ../ps/ps.map/do_labels.c:66
-#, c-format
-msgid "Can't open temporary label file <%s>"
-msgstr ""
-#: ../ps/ps.map/do_labels.c:69
-#, fuzzy
-msgid "Reading text file ..."
-#: ../ps/ps.map/do_labels.c:162
-msgid "Text labels: 'fontsize' given so ignoring 'size'"
-msgstr ""
-#: ../ps/ps.map/main.c:93
-msgid "postscript"
-msgstr ""
-#: ../ps/ps.map/main.c:94
-msgid "map"
-msgstr ""
-#: ../ps/ps.map/main.c:95
-#, fuzzy
-msgid "printing"
-#: ../ps/ps.map/main.c:96
-msgid "Produces hardcopy PostScript map output."
-msgstr ""
-#: ../ps/ps.map/main.c:100
-msgid "Rotate plot 90 degrees"
-msgstr ""
-#: ../ps/ps.map/main.c:106
-msgid "List paper formats (name width height left right top bottom(margin))"
-msgstr ""
-#: ../ps/ps.map/main.c:108 ../ps/ps.map/main.c:121
-msgid "Utility"
-msgstr ""
-#: ../ps/ps.map/main.c:113
-msgid "Create EPS (Encapsulated PostScript) instead of PostScript file"
-msgstr ""
-#: ../ps/ps.map/main.c:119
-msgid "Describe map-box's position on the page and exit (inches from top-left of paper)"
-msgstr ""
-#: ../ps/ps.map/main.c:124
-#, fuzzy
-msgid "File containing mapping instructions"
-#: ../ps/ps.map/main.c:125
-msgid "Use '-' to enter instructions from keyboard)"
-msgstr ""
-#: ../ps/ps.map/main.c:128
-#, fuzzy
-msgid "Name for PostScript output file"
-#: ../ps/ps.map/main.c:134
-msgid "Number of copies to print"
-msgstr ""
-#: ../ps/ps.map/main.c:205
-#, fuzzy, c-format
-msgid "Unable to open file '%s': %s"
-#: ../ps/ps.map/main.c:213 ../ps/ps.map/main.c:232
-#, c-format
-msgid ""
-"Required parameter <%s> not set:\n"
-"\t(%s)"
-msgstr ""
-#: ../ps/ps.map/main.c:265
-#, c-format
-msgid "PostScript file '%s' successfully written."
-msgstr ""
-#: ../ps/ps.map/do_masking.c:23
-#, fuzzy
-msgid "Can't open temporary PostScript mask file."
-#: ../ps/ps.map/read_cfg.c:64
-#, c-format
-msgid "Paper '%s' not found, using defaults"
-msgstr ""
-#: ../ps/ps.map/makeprocs.c:29
-#, fuzzy, c-format
-msgid "Unable to open prolog <%s>"
-#: ../ps/ps.map/r_vlegend.c:97
-msgid "illegal vlegend sub-request"
-msgstr ""
-#: ../ps/ps.map/eps.c:18
-#, fuzzy, c-format
-msgid "Can't open eps file <%s>"
-#: ../ps/ps.map/eps.c:37
-#, fuzzy, c-format
-msgid "Bounding box in eps file <%s> was not found"
-#: ../ps/ps.map/ps_clrtbl.c:39 ../display/d.histogram/main.c:177
-#: ../display/d.legend/main.c:283
-#, fuzzy, c-format
-msgid "Category file for <%s> not available"
-#: ../ps/ps.map/ps_clrtbl.c:54
-msgid "Your cats/ file is invalid. A cats/ file with categories and labels is required for 'colortable' when using categorical legends; see the r.category help page. Colortable creation has been skipped."
-msgstr ""
-#: ../ps/ps.map/do_plt.c:40
-#, fuzzy
-msgid "Reading point/line file ..."
-#: ../display/d.histogram/main.c:85
-#, fuzzy
-msgid "histogram"
-#: ../display/d.histogram/main.c:88
-msgid "Displays a histogram in the form of a pie or bar chart for a user-specified raster map."
-msgstr ""
-#: ../display/d.histogram/main.c:92
-msgid "Raster map for which histogram will be displayed"
-msgstr ""
-#: ../display/d.histogram/main.c:96
-msgid "Indicate if a pie or bar chart is desired"
-msgstr ""
-#: ../display/d.histogram/main.c:105
-msgid "Color for text and axes"
-msgstr ""
-#: ../display/d.histogram/main.c:113
-msgid "Indicate if cell counts or map areas should be displayed"
-msgstr ""
-#: ../display/d.histogram/main.c:123
-msgid "Number of steps to divide the data range into (fp maps only)"
-msgstr ""
-#: ../display/d.histogram/main.c:130
-msgid "Display information for null cells"
-msgstr ""
-#: ../display/d.histogram/main.c:134
-msgid "Gather the histogram quietly"
-msgstr ""
-#: ../display/d.histogram/main.c:139
-msgid "Report for ranges defined in cats file (fp maps only)"
-msgstr ""
-#: ../display/d.histogram/main.c:163
-#, c-format
-msgid "Invalid number of steps: %s"
-msgstr ""
-#: ../display/d.histogram/main.c:168
-msgid "When -C flag is set, the nsteps argument is ignored"
-msgstr ""
-#: ../display/d.histogram/main.c:180 ../display/d.legend/main.c:521
-#, c-format
-msgid "Range information for <%s> not available"
-msgstr ""
-#: ../display/d.histogram/main.c:190 ../display/d.vect/main.c:328
-#: ../display/d.rhumbline/main.c:96 ../display/d.where/main.c:169
-#: ../display/d.text/main.c:291 ../display/d.linegraph/main.c:258
-#: ../display/d.profile/main.c:263 ../display/d.info/main.c:69
-#: ../display/d.vect.chart/main.c:253 ../display/d.barscale/main.c:128
-#: ../display/d.erase/main.c:46 ../display/d.rast.num/main.c:193
-#: ../display/d.grid/main.c:230 ../display/d.his/main.c:117
-#: ../display/d.geodesic/main.c:96 ../display/d.labels/main.c:117
-#: ../display/d.colortable/main.c:141 ../display/d.rast/main.c:96
-#: ../display/d.thematic.area/main.c:366 ../display/d.fontlist/main.c:54
-#: ../display/d.graph/main.c:101 ../display/d.rgb/main.c:81
-#: ../display/d.path/main.c:153 ../display/d.rast.arrow/main.c:224
-#: ../display/d.legend/main.c:288 ../display/d.font/main.c:87
-msgid "No graphics device selected. Use d.mon to select graphics device."
-msgstr ""
-#: ../display/d.vect/opt.c:126
-#, fuzzy, c-format
-msgid "Unknown color: '%s'"
-#: ../display/d.vect/opt.c:143 ../display/d.what.vect/what.c:409
-#: ../display/d.thematic.area/main.c:196 ../vector/v.db.connect/main.c:175
-#, c-format
-msgid "Database connection not defined"
-msgstr ""
-#: ../display/d.vect/opt.c:152 ../display/d.thematic.area/main.c:205
-#: ../vector/v.convert/att.c:74 ../db/db.select/main.c:72
-#: ../db/db.execute/main.c:71 ../db/db.tables/main.c:50
-#: ../db/db.describe/main.c:56
-#, fuzzy, c-format
-msgid "Unable to open database <%s>"
-#: ../display/d.vect/lines.c:107 ../display/d.vect/lines.c:329
-#, fuzzy, c-format
-msgid "Unable to read symbol <%s>, unable to display points"
-#: ../display/d.vect/lines.c:121
-#, fuzzy
-msgid "Unable to display features by id, topology not available. Please try to rebuild topology using v.build or v.build.all."
-#: ../display/d.vect/lines.c:169
-#, fuzzy, c-format
-msgid "%d points plotted"
-#: ../display/d.vect/lines.c:171
-#, fuzzy, c-format
-msgid "%d lines plotted"
-#: ../display/d.vect/lines.c:173
-#, fuzzy, c-format
-msgid "%d centroids plotted"
-#: ../display/d.vect/lines.c:175
-#, fuzzy, c-format
-msgid "%d boundaries plotted"
-#: ../display/d.vect/lines.c:177
-#, fuzzy, c-format
-msgid "%d faces plotted"
-#: ../display/d.vect/attr.c:28
-msgid "attrcol not specified, cannot display attributes"
-msgstr ""
-#: ../display/d.vect/attr.c:110 ../display/d.vect.chart/plot.c:84
-#: ../vector/v.in.db/main.c:166
-#, fuzzy, c-format
-msgid "Unable to open select cursor: '%s'"
-#: ../display/d.vect/attr.c:129
-#, c-format
-msgid "No attribute found for cat %d: %s"
-msgstr ""
-#: ../display/d.vect/topo.c:17
-msgid "Unable to display topology, not available.Please try to rebuild topology using v.build or v.build.all."
-msgstr ""
-#: ../display/d.vect/main.c:72
-msgid "Displays user-specified vector map in the active graphics frame."
-msgstr ""
-#: ../display/d.vect/main.c:86
-msgid "Display"
-msgstr ""
-#: ../display/d.vect/main.c:87
-msgid "shape;Display geometry of features;cat;Display category numbers of features;topo;Display topology information (nodes, edges);dir;Display direction of linear features;attr;Display selected attribute based on 'attrcolumn';zcoor;Display z-coordinate of features (only for 3D vector maps)"
-msgstr ""
-#: ../display/d.vect/main.c:98 ../display/d.vect/main.c:101
-#: ../display/d.vect/main.c:104 ../display/d.vect/main.c:307
-#: ../display/d.rast/main.c:69 ../display/d.rast/main.c:86
-#: ../display/d.thematic.area/main.c:130 ../display/d.thematic.area/main.c:133
-#: ../vector/v.net.centrality/main.c:121 ../vector/v.net.centrality/main.c:123
-#: ../vector/v.in.ogr/main.c:144 ../vector/v.in.ogr/main.c:157
-#: ../vector/v.in.ogr/main.c:162 ../vector/v.in.ogr/main.c:171
-#: ../vector/v.in.ogr/main.c:184 ../vector/v.in.ogr/main.c:253
-#: ../vector/v.out.ascii/args.c:22 ../vector/v.out.ascii/args.c:25
-#: ../vector/v.out.ascii/args.c:39 ../vector/v.out.ascii/args.c:42
-#: ../vector/v.edit/args.c:24 ../vector/v.edit/args.c:29
-#: ../vector/v.edit/args.c:112 ../vector/v.edit/args.c:116
-#: ../vector/v.edit/args.c:125 ../vector/v.edit/args.c:134
-#: ../vector/v.edit/args.c:143 ../vector/v.edit/args.c:146
-#: ../vector/v.edit/args.c:160 ../vector/v.edit/args.c:189
-#: ../vector/v.extract/main.c:96 ../vector/v.extract/main.c:101
-#: ../vector/v.extract/main.c:107 ../vector/v.extract/main.c:110
-#: ../vector/v.extract/main.c:113 ../vector/v.extract/main.c:123
-#: ../vector/v.extract/main.c:133 ../vector/v.category/main.c:82
-#: ../vector/v.category/main.c:85 ../vector/v.category/main.c:89
-#: ../vector/v.buffer/main.c:219 ../vector/v.buffer/main.c:224
-#: ../vector/v.surf.rst/main.c:177 ../vector/v.surf.rst/main.c:187
-#: ../vector/v.reclass/main.c:77 ../vector/v.reclass/main.c:82
-#: ../vector/v.out.ogr/args.c:19 ../vector/v.out.ogr/args.c:22
-#: ../vector/v.out.ogr/args.c:90 ../vector/v.select/args.c:16
-#: ../vector/v.select/args.c:21 ../vector/v.select/args.c:30
-#: ../vector/v.select/args.c:35 ../vector/v.select/args.c:88
-#: ../vector/v.clean/main.c:57 ../vector/v.clean/main.c:60
-#: ../vector/v.net.allpairs/main.c:70 ../vector/v.net.allpairs/main.c:76
-#: ../vector/v.net.allpairs/main.c:79 ../vector/v.net.allpairs/main.c:81
-#: ../vector/v.to.3d/args.c:20 ../vector/v.to.3d/args.c:25
-#: ../vector/v.to.points/main.c:184 ../vector/v.to.points/main.c:188
-#: ../vector/v.to.rast/main.c:53
-#, fuzzy
-msgid "Selection"
-#: ../display/d.vect/main.c:112
-#, fuzzy
-msgid "Feature color"
-#: ../display/d.vect/main.c:113 ../display/d.vect/main.c:123
-#: ../display/d.vect/main.c:130 ../display/d.vect/main.c:138
-#: ../display/d.vect/main.c:293 ../display/d.vect/main.c:299
-#: ../display/d.vect/main.c:313 ../display/d.rast.arrow/main.c:119
-#: ../display/d.rast.arrow/main.c:128 ../display/d.rast.arrow/main.c:137
-#: ../display/d.rast.arrow/main.c:146 ../vector/v.label/main.c:152
-#: ../vector/v.label/main.c:176 ../vector/v.label/main.c:189
-#: ../vector/v.label/main.c:195 ../vector/v.label/main.c:205
-#: ../vector/v.label.sa/main.c:103 ../vector/v.label.sa/main.c:113
-#: ../vector/v.label.sa/main.c:120 ../vector/v.label.sa/main.c:130
-#: ../vector/v.label.sa/main.c:140 ../vector/v.label.sa/main.c:150
-#: ../vector/v.label.sa/main.c:157
-msgid "Colors"
-msgstr ""
-#: ../display/d.vect/main.c:116 ../display/d.vect/main.c:126
-#: ../display/d.vect/main.c:227 ../display/d.vect/main.c:237
-msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
-msgstr ""
-#: ../display/d.vect/main.c:122
-msgid "Area fill color"
-msgstr ""
-#: ../display/d.vect/main.c:131
-msgid "Name of color definition column (for use with -a flag)"
-msgstr ""
-#: ../display/d.vect/main.c:136
-#, fuzzy
-msgid "Name of color table (for use with -z flag)"
-#: ../display/d.vect/main.c:145 ../display/d.vect/main.c:150
-#: ../display/d.vect/main.c:158
-msgid "Lines"
-msgstr ""
-#: ../display/d.vect/main.c:146
-msgid "Line width"
-msgstr ""
-#: ../display/d.vect/main.c:151
-#, fuzzy
-msgid "Name of numeric column containing line width"
-#: ../display/d.vect/main.c:152
-msgid "These values will be scaled by width_scale"
-msgstr ""
-#: ../display/d.vect/main.c:159
-msgid "Scale factor for width_column"
-msgstr ""
-#: ../display/d.vect/main.c:167 ../display/d.vect/main.c:177
-#: ../display/d.vect/main.c:184 ../display/d.vect/main.c:190
-#: ../display/d.vect/main.c:321
-msgid "Symbols"
-msgstr ""
-#: ../display/d.vect/main.c:171
-msgid "Point and centroid symbol"
-msgstr ""
-#: ../display/d.vect/main.c:178
-msgid "Symbol size"
-msgstr ""
-#: ../display/d.vect/main.c:180
-msgid "When used with the size_column option this becomes the scale factor"
-msgstr ""
-#: ../display/d.vect/main.c:186
-#, fuzzy
-msgid "Name of numeric column containing symbol size"
-#: ../display/d.vect/main.c:192
-#, fuzzy
-msgid "Name of numeric column containing symbol rotation angle"
-#: ../display/d.vect/main.c:194
-msgid "Measured in degrees CCW from east"
-msgstr ""
-#: ../display/d.vect/main.c:200 ../display/d.vect/main.c:207
-#: ../display/d.vect/main.c:215 ../display/d.vect/main.c:223
-#: ../display/d.vect/main.c:233 ../display/d.vect/main.c:243
-#: ../display/d.vect/main.c:249 ../display/d.vect/main.c:255
-#: ../display/d.vect/main.c:261 ../display/d.vect/main.c:269
-msgid "Labels"
-msgstr ""
-#: ../display/d.vect/main.c:202
-msgid "Layer number for labels (default: the given layer number)"
-msgstr ""
-#: ../display/d.vect/main.c:208
-msgid "Name of column to be displayed"
-msgstr ""
-#: ../display/d.vect/main.c:214
-msgid "Label color"
-msgstr ""
-#: ../display/d.vect/main.c:217 ../display/d.rast/main.c:75
-msgid "Either a standard color name or R:G:B triplet"
-msgstr ""
-#: ../display/d.vect/main.c:224
-msgid "Label background color"
-msgstr ""
-#: ../display/d.vect/main.c:234
-msgid "Label border color"
-msgstr ""
-#: ../display/d.vect/main.c:244
-msgid "Label size (pixels)"
-msgstr ""
-#: ../display/d.vect/main.c:250 ../display/d.text/main.c:219
-#: ../display/d.legend/main.c:160 ../vector/v.label/main.c:122
-#, fuzzy
-msgid "Font name"
-#: ../display/d.vect/main.c:256
-msgid "Text encoding"
-msgstr ""
-#: ../display/d.vect/main.c:264
-msgid "Label horizontal justification"
-msgstr ""
-#: ../display/d.vect/main.c:272
-msgid "Label vertical justification"
-msgstr ""
-#: ../display/d.vect/main.c:279
-msgid "Minimum region size (average from height and width) when map is displayed"
-msgstr ""
-#: ../display/d.vect/main.c:287
-msgid "Maximum region size (average from height and width) when map is displayed"
-msgstr ""
-#: ../display/d.vect/main.c:295
-msgid "Get colors from attribute table (see 'rgb_column' option)"
-msgstr ""
-#: ../display/d.vect/main.c:301
-msgid "Random colors according to category number (or layer number if 'layer=-1' is given)"
-msgstr ""
-#: ../display/d.vect/main.c:308
-msgid "Use values from 'cats' option as feature id"
-msgstr ""
-#: ../display/d.vect/main.c:312
-msgid "Colorize features according to z-coordinate (only for 3D vector maps)"
-msgstr ""
-#: ../display/d.vect/main.c:317
-msgid "Use square root of the value of size_column"
-msgstr ""
-#: ../display/d.vect/main.c:319
-msgid "This makes circle areas proportionate to the size_column values instead of circle radius"
-msgstr ""
-#: ../display/d.vect/main.c:339
-msgid "Region size is lower than minreg, nothing displayed"
-msgstr ""
-#: ../display/d.vect/main.c:347
-msgid "Region size is greater than maxreg, nothing displayed"
-msgstr ""
-#: ../display/d.vect/main.c:361
-msgid "The '-c' and '-a' flags cannot be used together, the '-c' flag will be ignored!"
-msgstr ""
-#: ../display/d.vect/main.c:383 ../display/d.vect/main.c:389
-#: ../vector/v.out.ascii/args.c:138
-#, fuzzy, c-format
-msgid "Option <%s> must be > 0"
-#: ../display/d.vect/main.c:393 ../vector/v.out.ascii/args.c:141
-#, c-format
-msgid "%d errors in cat option"
-msgstr ""
-#: ../display/d.vect/main.c:409
-#, fuzzy
-msgid "Plotting..."
-#: ../display/d.vect/main.c:417
-#, fuzzy
-msgid "The bounding box of the map is outside the current region, nothing drawn"
-#: ../display/d.vect/main.c:480
-#, fuzzy
-msgid "Rendering failed"
-#: ../display/d.vect/area.c:37
-#, fuzzy
-msgid "Unable to display areas, topology not available. Please try to rebuild topology using v.build or v.build.all."
-#: ../display/d.vect/label.c:28
-#, fuzzy
-msgid "Topology level required for drawing centroids for OGR layers"
-#: ../display/d.vect/zcoor.c:19
-#, fuzzy
-msgid "Vector map is not 3D. Unable to display z-coordinates."
-#: ../display/d.vect/shape.c:48 ../display/d.thematic.area/plot1.c:119
-#, fuzzy
-msgid "Color definition column not specified"
-#: ../display/d.vect/shape.c:58 ../display/d.thematic.area/plot1.c:129
-#, c-format
-msgid "Color definition column (%s) not a string. Column must be of form RRR:GGG:BBB where RGB values range 0-255."
-msgstr ""
-#: ../display/d.vect/shape.c:63 ../display/d.vect/shape.c:92
-#: ../display/d.vect/shape.c:123 ../display/d.vect/shape.c:154
-#, fuzzy, c-format
-msgid "Unable to select data (%s) from table"
-msgstr "डेटाबेसची यादी दाखवता येणार नाही"
-#: ../display/d.vect/shape.c:77
-#, fuzzy
-msgid "Line width column not specified"
-#: ../display/d.vect/shape.c:88
-#, fuzzy, c-format
-msgid "Line width column (%s) not a number"
-#: ../display/d.vect/shape.c:108
-#, fuzzy
-msgid "Symbol size column not specified"
-#: ../display/d.vect/shape.c:119
-#, fuzzy, c-format
-msgid "Symbol size column (%s) is not numeric"
-#: ../display/d.vect/shape.c:139
-#, fuzzy
-msgid "Symbol rotation column not specified"
-#: ../display/d.vect/shape.c:150
-#, fuzzy, c-format
-msgid "Symbol rotation column (%s) is not numeric"
-#: ../display/d.vect/shape.c:173
-msgid "Vector map is not 3D. Unable to colorize features based on z-coordinates."
-msgstr ""
-#: ../display/d.vect/shape.c:244 ../display/d.vect/shape.c:249
-#, fuzzy, c-format
-msgid "Error in color definition (%s) - feature %d with category %d"
-#: ../display/d.vect/shape.c:315
-#, fuzzy, c-format
-msgid "Invalid negative value - feature %d with category %d"
-#: ../display/d.rhumbline/main.c:46
-msgid "Displays the rhumbline joining two longitude/latitude coordinates."
-msgstr ""
-#: ../display/d.rhumbline/main.c:53 ../display/d.geodesic/main.c:55
-#: ../display/d.path/main.c:65
-msgid "Starting and ending coordinates"
-msgstr ""
-#: ../display/d.rhumbline/main.c:59 ../display/d.geodesic/main.c:61
-msgid "Line color"
-msgstr ""
-#: ../display/d.rhumbline/main.c:68 ../display/d.barscale/main.c:82
-#: ../display/d.grid/main.c:93 ../vector/v.label/main.c:151
-#: ../vector/v.lrs/v.lrs.label/main.c:194 ../vector/v.label.sa/main.c:98
-msgid "Text color"
-msgstr ""
-#: ../display/d.rhumbline/main.c:76 ../display/d.geodesic/main.c:77
-#, fuzzy, c-format
-msgid "Location is not %s"
-#: ../display/d.rhumbline/main.c:80 ../display/d.geodesic/main.c:80
-#: ../display/d.path/main.c:140
-msgid "No coordinates given"
-msgstr ""
-#: ../display/d.rhumbline/main.c:83 ../display/d.rhumbline/main.c:86
-#: ../display/d.rhumbline/main.c:89 ../display/d.rhumbline/main.c:92
-#: ../display/d.geodesic/main.c:83 ../display/d.geodesic/main.c:86
-#: ../display/d.geodesic/main.c:89 ../display/d.geodesic/main.c:92
-#, fuzzy, c-format
-msgid "%s - illegal longitude"
-#: ../display/d.where/main.c:47
-msgid "Identifies the geographic coordinates associated with point locations given in display coordinates."
-msgstr ""
-#: ../display/d.where/main.c:57
-msgid "Display coordinates to convert"
-msgstr ""
-#: ../display/d.where/main.c:62
-#, fuzzy
-msgid "File from which to read coordinates (\"-\" to read from stdin)"
-#: ../display/d.where/main.c:66
-msgid "Output lat/long in decimal degree"
-msgstr ""
-#: ../display/d.where/main.c:71
-msgid "Output lat/long referenced to current ellipsoid"
-msgstr ""
-#: ../display/d.where/main.c:76
-msgid "Output lat/long referenced to WGS84 ellipsoid using datum transformation parameters defined in current location (if available)"
-msgstr ""
-#: ../display/d.where/main.c:82
-msgid "Output frame coordinates of current display monitor (percentage)"
-msgstr ""
-#: ../display/d.where/main.c:90
-msgid "Ambiguous request for lat/long ellipsoids"
-msgstr ""
-#: ../display/d.where/main.c:93
-msgid "Please specify a lat/long ellipsoid with -l or -w"
-msgstr ""
-#: ../display/d.where/main.c:135
-msgid ""
-"WGS84 output not possible as this location does not contain\n"
-"datum transformation parameters. Try running g.setproj."
-msgstr ""
-#: ../display/d.where/where.c:29
-#, fuzzy, c-format
-msgid "Invalid coordinates <%s,%s>"
-#: ../display/d.what.vect/what.c:152 ../display/d.what.vect/what.c:154
-#: ../vector/v.what/what.c:191 ../vector/v.what/what.c:193
-#, c-format
-msgid "Nothing Found.\n"
-msgstr ""
-#: ../display/d.what.vect/what.c:210
-#, c-format
-msgid "Line: %d  Type: %s  Left: %d  Right: %d  "
-msgstr ""
-#: ../display/d.what.vect/what.c:214 ../vector/v.what/what.c:252
-#: ../vector/v.what/what.c:307
-#, c-format
-msgid "Length: %f\n"
-msgstr ""
-#: ../display/d.what.vect/what.c:230
-#, c-format
-msgid "  Node[%d]: %d  Number of lines: %d  Coordinates: %.6f, %.6f, %.6f\n"
-msgstr ""
-#: ../display/d.what.vect/what.c:239
-#, c-format
-msgid "    Line: %5d  Angle: %.8f\n"
-msgstr ""
-#: ../display/d.what.vect/what.c:248
-#, c-format
-msgid "length %f\n"
-msgstr ""
-#: ../display/d.what.vect/what.c:268 ../vector/v.what/what.c:321
-#, c-format
-msgid "Point height: %f\n"
-msgstr ""
-#: ../display/d.what.vect/what.c:286 ../vector/v.what/what.c:338
-#, c-format
-msgid "Line height: %f\n"
-msgstr ""
-#: ../display/d.what.vect/what.c:295
-#, c-format
-msgid "Line height min: %f max: %f\n"
-msgstr ""
-#: ../display/d.what.vect/what.c:311
-#, c-format
-msgid "Area height: %f\n"
-msgstr ""
-#: ../display/d.what.vect/what.c:320
-#, c-format
-msgid "Area\n"
-msgstr ""
-#: ../display/d.what.vect/what.c:342
-#, c-format
-msgid "Area: %d  Number of isles: %d\n"
-msgstr ""
-#: ../display/d.what.vect/what.c:347
-#, c-format
-msgid "  Isle[%d]: %d\n"
-msgstr ""
-#: ../display/d.what.vect/what.c:354
-#, c-format
-msgid "Island: %d  In area: %d\n"
-msgstr ""
-#: ../display/d.what.vect/what.c:361 ../display/d.what.vect/what.c:369
-#, c-format
-msgid "Size - Sq Meters: %.3f\t\tHectares: %.3f\n"
-msgstr ""
-#: ../display/d.what.vect/what.c:365 ../display/d.what.vect/what.c:373
-#, c-format
-msgid "           Acres: %.3f\t\tSq Miles: %.4f\n"
-msgstr ""
-#: ../display/d.what.vect/what.c:396
-#, c-format
-msgid ""
-"Layer: %d\n"
-"category: %d\n"
-msgstr ""
-#: ../display/d.what.vect/what.c:421
-#, c-format
-msgid ""
-"driver: %s\n"
-"database: %s\n"
-"table: %s\n"
-"key column: %s\n"
-msgstr ""
-#: ../display/d.what.vect/what.c:475
-#, c-format
-msgid ""
-"\n"
-"Click mouse button on desired location\n"
-"\n"
-msgstr ""
-#: ../display/d.what.vect/what.c:480
-#, c-format
-msgid "Buttons\n"
-msgstr ""
-#: ../display/d.what.vect/what.c:481
-#, c-format
-msgid " Left:  what's here\n"
-msgstr ""
-#: ../display/d.what.vect/what.c:482
-#, c-format
-msgid " Right: quit\n"
-msgstr ""
-#: ../display/d.what.vect/openvect.c:11
-#, c-format
-msgid "warning: %s - vector map not found\n"
-msgstr ""
-#: ../display/d.what.vect/main.c:61
-msgid "Allows the user to interactively query a vector map layer at user-selected locations within the current geographic region."
-msgstr ""
-#: ../display/d.what.vect/main.c:68 ../display/d.what.rast/main.c:79
-#, fuzzy
-msgid "Identify just one location"
-msgstr "डेटाबेसचे स्थान"
-#: ../display/d.what.vect/main.c:77
-msgid "Name of existing vector map"
-msgstr ""
-#: ../display/d.what.vect/main.c:81 ../display/d.what.rast/main.c:83
-msgid "Terse output. For parsing by programs"
-msgstr ""
-#: ../display/d.what.vect/main.c:86
-msgid "Print information as plain text to terminal window"
-msgstr ""
-#: ../display/d.what.vect/main.c:90 ../vector/v.what/main.c:85
-msgid "Print topological information (debugging)"
-msgstr ""
-#: ../display/d.what.vect/main.c:94
-msgid "Open form in edit mode"
-msgstr ""
-#: ../display/d.what.vect/main.c:136
-#, c-format
-msgid "%s: You must build topology on vector map"
-msgstr ""
-#: ../display/d.what.vect/main.c:139
-msgid "Building spatial index..."
-msgstr ""
-#: ../display/d.text/main.c:140 ../display/d.linegraph/main.c:120
-#: ../display/d.vect.chart/main.c:64 ../display/d.barscale/main.c:54
-#: ../display/d.grid/main.c:52 ../display/d.thematic.area/main.c:77
-#: ../display/d.graph/main.c:59 ../display/d.legend/main.c:85
-#: ../display/d.title/main.c:50
-msgid "cartography"
-msgstr ""
-#: ../display/d.text/main.c:142
-msgid "Draws text in the active display frame on the graphics monitor using the current font."
-msgstr ""
-#: ../display/d.text/main.c:148
-msgid "Text to display"
-msgstr ""
-#: ../display/d.text/main.c:157
-msgid "Height of letters in percentage of available frame height"
-msgstr ""
-#: ../display/d.text/main.c:165
-msgid "Text color, either a standard GRASS color or R:G:B triplet"
-msgstr ""
-#: ../display/d.text/main.c:173
-msgid "Text background color, either a standard GRASS color or R:G:B triplet"
-msgstr ""
-#: ../display/d.text/main.c:182
-msgid "The screen line number on which text will begin to be drawn"
-msgstr ""
-#: ../display/d.text/main.c:190
-msgid "Screen position at which text will begin to be drawn (percentage, [0,0] is lower left)"
-msgstr ""
-#: ../display/d.text/main.c:198
-msgid "Text alignment"
-msgstr ""
-#: ../display/d.text/main.c:206
-msgid "Rotation angle in degrees (counter-clockwise)"
-msgstr ""
-#: ../display/d.text/main.c:213
-msgid "Line spacing"
-msgstr ""
-#: ../display/d.text/main.c:225 ../display/d.legend/main.c:167
-#, fuzzy
-msgid "Path to font file"
-#: ../display/d.text/main.c:233 ../display/d.legend/main.c:176
-msgid "Text encoding (only applicable to TrueType fonts)"
-msgstr ""
-#: ../display/d.text/main.c:237
-#, fuzzy
-msgid "Input file"
-#: ../display/d.text/main.c:241
-msgid "Screen position in pixels ([0,0] is top left)"
-msgstr ""
-#: ../display/d.text/main.c:245
-msgid "Screen position in geographic coordinates"
-msgstr ""
-#: ../display/d.text/main.c:249
-msgid "Use bold text"
-msgstr ""
-#: ../display/d.text/main.c:253
-msgid "Use radians instead of degrees for rotation"
-msgstr ""
-#: ../display/d.text/main.c:257 ../display/d.legend/main.c:206
-msgid "Font size is height in pixels"
-msgstr ""
-#: ../display/d.text/main.c:261
-msgid "Ignored (compatibility with d.text.freetype)"
-msgstr ""
-#: ../display/d.text/main.c:271
-msgid "Please choose only one placement method"
-msgstr ""
-#: ../display/d.text/main.c:332
-msgid "Invalid coordinates"
-msgstr ""
-#: ../display/d.text/main.c:376
-#, c-format
-msgid ""
-"\n"
-"Please enter text instructions.  Enter EOF (ctrl-d) on last line to quit\n"
-msgstr ""
-#: ../display/d.text/main.c:567
-#, c-format
-msgid "[%s]: No such color. Use '%s'"
-msgstr ""
-#: ../display/d.linegraph/main.c:122
-msgid "Generates and displays simple line graphs in the active graphics monitor display frame."
-msgstr ""
-#: ../display/d.linegraph/main.c:126
-msgid "Name of data file for X axis of graph"
-msgstr ""
-#: ../display/d.linegraph/main.c:132
-msgid "Name of data file(s) for Y axis of graph"
-msgstr ""
-#: ../display/d.linegraph/main.c:139
-#, fuzzy
-msgid "Path to file location"
-msgstr "'%s'. ड्राइवर चालू होत नाही"
-#: ../display/d.linegraph/main.c:146
-msgid "Color for Y data"
-msgstr ""
-#: ../display/d.linegraph/main.c:155
-msgid "Color for axis, tics, numbers, and title"
-msgstr ""
-#: ../display/d.linegraph/main.c:163
-msgid "Title for X data"
-msgstr ""
-#: ../display/d.linegraph/main.c:170
-msgid "Title for Y data"
-msgstr ""
-#: ../display/d.linegraph/main.c:177
-msgid "Title for Graph"
-msgstr ""
-#: ../display/d.linegraph/main.c:216
-msgid "Maximum of 10 Y data files exceeded"
-msgstr ""
-#: ../display/d.linegraph/main.c:245
-#, c-format
-msgid "Only <%d> colors given for <%d> lines"
-msgstr ""
-#: ../display/d.linegraph/main.c:299
-#, c-format
-msgid "Y input file <%s> contains %s data points than the X input file"
-msgstr ""
-#: ../display/d.linegraph/main.c:304
-#, c-format
-msgid "The last %d point(s) will be ignored"
-msgstr ""
-#: ../display/d.linegraph/main.c:365
-#, fuzzy, c-format
-msgid "Problem reading X data file at line %d"
-#: ../display/d.linegraph/main.c:375
-#, c-format
-msgid "Problem reading <%s> data file at line %d"
-msgstr ""
-#: ../display/d.profile/main.c:68
-#, fuzzy, c-format
-msgid "Unable to read range for %s"
-#: ../display/d.profile/main.c:79
-#, fuzzy, c-format
-msgid "Unable to read FP range for %s"
-#: ../display/d.profile/main.c:194
-msgid "Plots profile of a transect."
-msgstr ""
-#: ../display/d.profile/main.c:198
-msgid "Raster map to be profiled"
-msgstr ""
-#: ../display/d.profile/main.c:210
-msgid "Use map's range recorded range"
-msgstr ""
-#: ../display/d.profile/main.c:259
-#, fuzzy
-msgid "At least two points are required"
-#: ../display/d.what.rast/what.c:56
-msgid "You are clicking outside the map"
-msgstr ""
-#: ../display/d.what.rast/main.c:53
-msgid "Allows the user to interactively query the category contents of multiple raster map layers at user specified locations within the current geographic region."
-msgstr ""
-#: ../display/d.what.rast/main.c:74
-msgid "Field separator (terse mode only)"
-msgstr ""
-#: ../display/d.what.rast/main.c:88
-msgid "Print out col/row for the entire map in grid resolution of the region"
-msgstr ""
-#: ../display/d.info/main.c:32 ../display/d.erase/main.c:31
-#: ../display/d.mon/main.c:39
-#: ../locale/scriptstrings/d.redraw_to_translate.c:4
-msgid "monitors"
-msgstr ""
-#: ../display/d.info/main.c:34
-#, fuzzy
-msgid "Displays information about the active display monitor."
-#: ../display/d.info/main.c:36
-msgid "Display monitors are maintained by d.mon."
-msgstr ""
-#: ../display/d.info/main.c:41
-msgid "Display screen rectangle (left, right, top, bottom)"
-msgstr ""
-#: ../display/d.info/main.c:45
-msgid "Display screen dimensions (width, height)"
-msgstr ""
-#: ../display/d.info/main.c:49
-msgid "Display active frame rectangle"
-msgstr ""
-#: ../display/d.info/main.c:53
-msgid "Display screen rectangle of current region"
-msgstr ""
-#: ../display/d.info/main.c:58
-msgid "Display geographic coordinates and resolution of entire screen"
-msgstr ""
-#: ../display/d.info/main.c:65
-msgid "No flag given"
-msgstr ""
-#: ../display/d.vect.chart/main.c:66
-msgid "Displays charts of vector data in the active frame on the graphics monitor."
-msgstr ""
-#: ../display/d.vect.chart/main.c:83
-msgid "Chart type"
-msgstr ""
-#: ../display/d.vect.chart/main.c:84 ../display/d.vect.chart/main.c:98
-#: ../display/d.vect.chart/main.c:106 ../display/d.vect.chart/main.c:113
-#: ../display/d.vect.chart/main.c:121 ../display/d.vect.chart/main.c:130
-#: ../display/d.vect.chart/main.c:136
-msgid "Chart properties"
-msgstr ""
-#: ../display/d.vect.chart/main.c:91
-msgid "Attribute columns containing data"
-msgstr ""
-#: ../display/d.vect.chart/main.c:97
-msgid "Column used for pie chart size"
-msgstr ""
-#: ../display/d.vect.chart/main.c:105
-msgid "Size of chart (diameter for pie, total width for bar)"
-msgstr ""
-#: ../display/d.vect.chart/main.c:112
-msgid "Scale for size (to get size in pixels)"
-msgstr ""
-#: ../display/d.vect.chart/main.c:119
-msgid "Outline color"
-msgstr ""
-#: ../display/d.vect.chart/main.c:128
-msgid "Colors used to fill charts"
-msgstr ""
-#: ../display/d.vect.chart/main.c:135
-msgid "Center the bar chart around a data point"
-msgstr ""
-#: ../display/d.vect.chart/main.c:144
-msgid "Maximum value used for bar plot reference"
-msgstr ""
-#: ../display/d.vect.chart/main.c:149 ../display/d.thematic.area/main.c:159
-msgid "Create legend information and send to stdout"
-msgstr ""
-#: ../display/d.barscale/main.c:55
-msgid "Displays a barscale on the graphics monitor."
-msgstr ""
-#: ../display/d.barscale/main.c:59
-msgid "Use feet/miles instead of meters"
-msgstr ""
-#: ../display/d.barscale/main.c:63
-msgid "Draw a line scale instead of a bar scale"
-msgstr ""
-#: ../display/d.barscale/main.c:67
-msgid "Write text on top of the scale, not to the right"
-msgstr ""
-#: ../display/d.barscale/main.c:71
-msgid "Draw a north arrow only"
-msgstr ""
-#: ../display/d.barscale/main.c:75
-msgid "Draw a scale bar only"
-msgstr ""
-#: ../display/d.barscale/main.c:92
-msgid "The screen coordinates for top-left corner of label ([0,0] is lower-left of frame)"
-msgstr ""
-#: ../display/d.barscale/main.c:100
-#, fuzzy
-msgid "Font size"
-#: ../display/d.barscale/main.c:108
-#, c-format
-msgid "%s does not work with a latitude-longitude location"
-msgstr ""
-#: ../display/d.barscale/main.c:116
-msgid "Choose either -n or -s flag"
-msgstr ""
-#: ../display/d.erase/main.c:30 ../display/d.mon/main.c:38
-#: ../locale/scriptstrings/d.redraw_to_translate.c:3
-msgid "graphics"
-msgstr ""
-#: ../display/d.erase/main.c:32 ../display/d.mon/main.c:40
-#: ../locale/scriptstrings/d.redraw_to_translate.c:5
-msgid "CLI"
-msgstr ""
-#: ../display/d.erase/main.c:34
-msgid "Erases the contents of the active graphics display frame with user defined color."
-msgstr ""
-#: ../display/d.erase/main.c:40
-msgid "Remove all frames and erase the screen"
-msgstr ""
-#: ../display/d.zoom/main.c:62
-msgid "zoom"
-msgstr ""
-#: ../display/d.zoom/main.c:64
-msgid "Allows the user to change the current geographic region settings interactively, with a mouse."
-msgstr ""
-#: ../display/d.zoom/main.c:76 ../display/d.legend/main.c:91
-msgid "Name of raster map"
-msgstr ""
-#: ../display/d.zoom/main.c:84 ../vector/v.build/main.c:44
-msgid "Name of vector map"
-msgstr ""
-#: ../display/d.zoom/main.c:92
-msgid "Magnification: >1.0 zooms in, <1.0 zooms out"
-msgstr ""
-#: ../display/d.zoom/main.c:102
-msgid "Full menu (zoom + pan) & Quit menu"
-msgstr ""
-#: ../display/d.zoom/main.c:106
-msgid "Pan mode"
-msgstr ""
-#: ../display/d.zoom/main.c:110
-msgid "Handheld mode"
-msgstr ""
-#: ../display/d.zoom/main.c:114
-msgid "Return to previous zoom"
-msgstr ""
-#: ../display/d.zoom/main.c:120
-msgid "Please choose only one mode of operation"
-msgstr ""
-#: ../display/d.zoom/main.c:223
-#, c-format
-msgid "%d raster%s, %d vector%s\n"
-msgstr ""
-#: ../display/d.zoom/main.c:232
-msgid "No previous zoom available"
-msgstr ""
-#: ../display/d.zoom/main.c:236
-msgid "Returning to previous zoom"
-msgstr ""
-#: ../display/d.zoom/main.c:271
-msgid "Zooming complete."
-msgstr ""
-#: ../display/d.zoom/zoom.c:14 ../display/d.zoom/pan.c:16
-#, c-format
-msgid ""
-"\n"
-"\n"
-"Buttons:\n"
-msgstr ""
-#: ../display/d.zoom/zoom.c:15
-#, c-format
-msgid "Left:   Zoom menu\n"
-msgstr ""
-#: ../display/d.zoom/zoom.c:16
-#, c-format
-msgid "Middle: Pan\n"
-msgstr ""
-#: ../display/d.zoom/zoom.c:17
-#, c-format
-msgid "Right:  Quit menu\n"
-msgstr ""
-#: ../display/d.zoom/zoom.c:39
-#, c-format
-msgid ""
-"This region now saved as current region.\n"
-"\n"
-msgstr ""
-#: ../display/d.zoom/zoom.c:41
-#, c-format
-msgid "Note: run 'd.erase' for the new region to affect the graphics.\n"
-msgstr ""
-#: ../display/d.zoom/pan.c:17
-#, c-format
-msgid "Left:   Pan\n"
-msgstr ""
-#: ../display/d.zoom/pan.c:18
-#, c-format
-msgid "Right:  Quit\n"
-msgstr ""
-#: ../display/d.rast.num/main.c:74
-msgid "Overlays cell category values on a raster map layer displayed to the graphics monitor."
-msgstr ""
-#: ../display/d.rast.num/main.c:86
-msgid "Color for drawing grid, or \"none\""
-msgstr ""
-#: ../display/d.rast.num/main.c:95
-msgid "Color for drawing text"
-msgstr ""
-#: ../display/d.rast.num/main.c:108 ../display/d.rast.arrow/main.c:173
-msgid "Align grids with raster cells"
-msgstr ""
-#: ../display/d.rast.num/main.c:112
-msgid "Get text color from cell color value"
-msgstr ""
-#: ../display/d.rast.num/main.c:177
-msgid "Current window size:"
-msgstr ""
-#: ../display/d.rast.num/main.c:178
-#, c-format
-msgid "rows:    %d"
-msgstr ""
-#: ../display/d.rast.num/main.c:179
-#, c-format
-msgid "columns: %d"
-msgstr ""
-#: ../display/d.rast.num/main.c:181
-msgid ""
-"\n"
-"Your current window setting may be too large. Cells displayed on your graphics window may be too small for cell category number to be visible."
-msgstr ""
-#: ../display/d.rast.num/main.c:187
-msgid "Aborting."
-msgstr ""
-#: ../display/d.grid/plot.c:356
-msgid ""
-"WGS84 grid output not possible as this location does not contain\n"
-msgstr ""
-#: ../display/d.grid/plot.c:528
-msgid "Error in pj_do_proj1"
-msgstr ""
-#: ../display/d.grid/plot.c:534
-msgid "Error in pj_do_proj2"
-msgstr ""
-#: ../display/d.grid/plot.c:538
-msgid "Error in pj_do_proj3"
-msgstr ""
-#: ../display/d.grid/plot.c:546
-msgid "Error in pj_do_proj5"
-msgstr ""
-#: ../display/d.grid/plot.c:550
-msgid "Error in pj_do_proj6"
-msgstr ""
-#: ../display/d.grid/main.c:54
-msgid "Overlays a user-specified grid in the active display frame on the graphics monitor."
-msgstr ""
-#: ../display/d.grid/main.c:62
-msgid "Size of grid to be drawn (0: north-south resolution of the current region)"
-msgstr ""
-#: ../display/d.grid/main.c:63
-msgid "In map units or DDD:MM:SS format. Example: \"1000\" or \"0:10\""
-msgstr ""
-#: ../display/d.grid/main.c:72
-msgid "Lines of the grid pass through this coordinate"
-msgstr ""
-#: ../display/d.grid/main.c:78
-#, fuzzy
-msgid "Grid line width"
-#: ../display/d.grid/main.c:82
-msgid "Grid color"
-msgstr ""
-#: ../display/d.grid/main.c:83 ../display/d.grid/main.c:88
-#: ../display/d.grid/main.c:94
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:25
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:28
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:31
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:34
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:37
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:50
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:52
-msgid "Color"
-msgstr ""
-#: ../display/d.grid/main.c:87 ../vector/v.label/main.c:193
-#: ../vector/v.lrs/v.lrs.label/main.c:238 ../vector/v.label.sa/main.c:144
-msgid "Border color"
-msgstr ""
-#: ../display/d.grid/main.c:102
-msgid "Font size for gridline coordinate labels"
-msgstr ""
-#: ../display/d.grid/main.c:106
-#, fuzzy
-msgid "Align the origin to the east-north corner of the current region"
-#: ../display/d.grid/main.c:111
-msgid "Draw geographic grid (referenced to current ellipsoid)"
-msgstr ""
-#: ../display/d.grid/main.c:116
-msgid "Draw geographic grid (referenced to WGS84 ellipsoid)"
-msgstr ""
-#: ../display/d.grid/main.c:120
-msgid "Draw '+' marks instead of grid lines"
-msgstr ""
-#: ../display/d.grid/main.c:124
-msgid "Draw '.' marks instead of grid lines"
-msgstr ""
-#: ../display/d.grid/main.c:128
-msgid "Draw fiducial marks instead of grid lines"
-msgstr ""
-#: ../display/d.grid/main.c:132
-msgid "Disable grid drawing"
-msgstr ""
-#: ../display/d.grid/main.c:133 ../display/d.grid/main.c:138
-#: ../display/d.grid/main.c:143
-msgid "Disable"
-msgstr ""
-#: ../display/d.grid/main.c:137
-msgid "Disable border drawing"
-msgstr ""
-#: ../display/d.grid/main.c:142
-msgid "Disable text drawing"
-msgstr ""
-#: ../display/d.grid/main.c:152
-msgid "Both grid and border drawing are disabled"
-msgstr ""
-#: ../display/d.grid/main.c:156
-msgid "Geo-Grid option is not available for LL projection"
-msgstr ""
-#: ../display/d.grid/main.c:158
-msgid "Geo-Grid option is not available for XY projection"
-msgstr ""
-#: ../display/d.grid/main.c:177
-msgid "Choose a single mark style"
-msgstr ""
-#: ../display/d.grid/main.c:198
-#, c-format
-msgid "Invalid geo-grid size <%s>"
-msgstr ""
-#: ../display/d.grid/main.c:203
-#, c-format
-msgid "Invalid grid size <%s>"
-msgstr ""
-#: ../display/d.grid/fiducial.c:61
-#, fuzzy
-msgid "Reading symbol"
-#: ../display/d.colorlist/main.c:36 ../display/d.fontlist/main.c:39
-#: ../display/d.font/main.c:47
-msgid "setup"
-msgstr ""
-#: ../display/d.his/main.c:67
-msgid "Displays the result obtained by combining hue, intensity, and saturation (his) values from user-specified input raster map layers."
-msgstr ""
-#: ../display/d.his/main.c:95
-msgid "Percent to brighten intensity channel"
-msgstr ""
-#: ../display/d.geodesic/main.c:46
-msgid "Displays a geodesic line, tracing the shortest distance between two geographic points along a great circle, in a longitude/latitude data set."
-msgstr ""
-#: ../display/d.geodesic/main.c:69
-msgid "Text color or \"none\""
-msgstr ""
-#: ../display/d.labels/do_labels.c:142
-#, c-format
-msgid "Error: %s\n"
-msgstr ""
-#: ../display/d.labels/main.c:44 ../vector/v.label/main.c:60
-#: ../vector/v.label.sa/main.c:39
-#, fuzzy
-msgid "paint labels"
-msgstr "तक्त्याचे नाव"
-#: ../display/d.labels/main.c:46
-msgid "Displays text labels (created with v.label) to the active frame on the graphics monitor."
-msgstr ""
-#: ../display/d.labels/main.c:52
-msgid "Ignore rotation setting and draw horizontally"
-msgstr ""
-#: ../display/d.labels/main.c:59
-msgid "Name of label file"
-msgstr ""
-#: ../display/d.labels/main.c:66
-msgid "Minimum region size (diagonal) when labels are displayed"
-msgstr ""
-#: ../display/d.labels/main.c:73
-msgid "Maximum region size (diagonal) when labels are displayed"
-msgstr ""
-#: ../display/d.labels/main.c:85
-#, fuzzy, c-format
-msgid "Label file <%s> not found"
-#: ../display/d.labels/main.c:97
-msgid "Region size is lower than minreg, nothing displayed."
-msgstr ""
-#: ../display/d.labels/main.c:105
-msgid "Region size is greater than maxreg, nothing displayed."
-msgstr ""
-#: ../display/d.labels/main.c:114 ../vector/v.lrs/v.lrs.label/main.c:300
-#, fuzzy, c-format
-msgid "Unable to open label file <%s>"
-#: ../display/d.mon/start.c:58
-#, fuzzy, c-format
-msgid "Monitor <%s> already running"
-#: ../display/d.mon/start.c:68
-#, fuzzy, c-format
-msgid "Unable to create file '%s'"
-#: ../display/d.mon/start.c:96
-#, c-format
-msgid "Staring monitor <%s> with env file '%s'"
-msgstr ""
-#: ../display/d.mon/stop.c:18 ../display/d.mon/select.c:30
-#, fuzzy, c-format
-msgid "Monitor <%s> is not running"
-#: ../display/d.mon/stop.c:37
-#, fuzzy
-msgid "Env file not found"
-#: ../display/d.mon/stop.c:55
-#, fuzzy
-msgid "PID file not found"
-#: ../display/d.mon/list.c:45
-msgid "List of running monitors:"
-msgstr ""
-#: ../display/d.mon/list.c:47
-msgid "No monitors running"
-msgstr ""
-#: ../display/d.mon/list.c:82
-#, fuzzy
-msgid "Command file not found"
-#: ../display/d.mon/list.c:86
-#, fuzzy
-msgid "Unable to read command file"
-#: ../display/d.mon/main.c:41
-msgid "Controls graphics display monitors which can be controlled from the command line."
-msgstr ""
-#: ../display/d.mon/main.c:46
-#, fuzzy
-msgid "Name of monitor to start"
-#: ../display/d.mon/main.c:48 ../display/d.mon/main.c:55
-#: ../display/d.mon/main.c:62 ../display/d.mon/main.c:105
-#: ../display/d.mon/main.c:110 ../display/d.mon/main.c:115
-msgid "Manage"
-msgstr ""
-#: ../display/d.mon/main.c:53
-#, fuzzy
-msgid "Name of monitor to stop"
-#: ../display/d.mon/main.c:60
-#, fuzzy
-msgid "Name of monitor to select"
-#: ../display/d.mon/main.c:66
-msgid "Width for display monitor if not set by GRASS_WIDTH"
-msgstr ""
-#: ../display/d.mon/main.c:73
-msgid "Height for display monitor if not set by GRASS_HEIGHT"
-msgstr ""
-#: ../display/d.mon/main.c:83
-#, fuzzy
-msgid "Name for output file (when starting new monitor)"
-#: ../display/d.mon/main.c:84
-msgid "Ignored for 'wx' monitors"
-msgstr ""
-#: ../display/d.mon/main.c:89
-msgid "List running monitors and exit"
-msgstr ""
-#: ../display/d.mon/main.c:94
-msgid "Print name of currently selected monitor and exit"
-msgstr ""
-#: ../display/d.mon/main.c:99
-msgid "Print commands for currently selected monitor and exit"
-msgstr ""
-#: ../display/d.mon/main.c:104
-msgid "Do not automatically select when starting"
-msgstr ""
-#: ../display/d.mon/main.c:109
-msgid "Release currently selected monitor and exit"
-msgstr ""
-#: ../display/d.mon/main.c:114
-#, fuzzy
-msgid "Disable true colors"
-#: ../display/d.mon/main.c:122
-#, c-format
-msgid "Flag -%c ignored"
-msgstr ""
-#: ../display/d.mon/main.c:126
-msgid "Currently selected monitor:"
-msgstr ""
-#: ../display/d.mon/main.c:130
-#, c-format
-msgid "List of commands for monitor <%s>:"
-msgstr ""
-#: ../display/d.mon/main.c:135
-#, c-format
-msgid "Monitor <%s> released"
-msgstr ""
-#: ../display/d.mon/main.c:139
-msgid "No monitor selected"
-msgstr ""
-#: ../display/d.mon/main.c:158
-#, fuzzy, c-format
-msgid "Either <%s>, <%s> or <%s> must be given"
-#: ../display/d.mon/main.c:163
-#, fuzzy, c-format
-msgid "Option <%s> ignored"
-#: ../display/d.mon/select.c:14
-#, fuzzy, c-format
-msgid "Monitor <%s> is already selected"
-#: ../display/d.colortable/main.c:63
-msgid "Displays the color table associated with a raster map layer."
-msgstr ""
-#: ../display/d.colortable/main.c:67
-#, fuzzy
-msgid "Name of raster map whose color table is to be displayed"
-#: ../display/d.colortable/main.c:75
-msgid "Color of lines separating the colors of the color table"
-msgstr ""
-#: ../display/d.colortable/main.c:81
-#, fuzzy
-msgid "Number of lines to appear in the color table"
-#: ../display/d.colortable/main.c:87
-#, fuzzy
-msgid "Number of columns to appear in the color table"
-#: ../display/d.colortable/main.c:92
-msgid "Don't draw a collar showing the NULL color in FP maps"
-msgstr ""
-#: ../display/d.colortable/main.c:114
-#, c-format
-msgid "<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
-msgstr ""
-#: ../display/d.colortable/main.c:128
-#, c-format
-msgid "<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
-msgstr ""
-#: ../display/d.colortable/main.c:139
-#, fuzzy, c-format
-msgid "Range file for <%s> not available"
-#: ../display/d.rast/main.c:55
-msgid "Displays user-specified raster map in the active graphics frame."
-msgstr ""
-#: ../display/d.rast/main.c:68
-#, fuzzy
-msgid "List of categories or values to be displayed"
-#: ../display/d.rast/main.c:74
-msgid "Background color (for null)"
-msgstr ""
-#: ../display/d.rast/main.c:76 ../display/d.rast/main.c:81
-#: ../display/d.rgb/main.c:63
-msgid "Null cells"
-msgstr ""
-#: ../display/d.rast/main.c:80 ../display/d.rgb/main.c:62
-msgid "Make null cells opaque"
-msgstr ""
-#: ../display/d.rast/main.c:85
-#, fuzzy
-msgid "Invert value list"
-#: ../display/d.rast/main.c:205
-#, fuzzy, c-format
-msgid "[%s]: illegal category specified"
-#: ../display/d.rast/main.c:236
-#, fuzzy, c-format
-msgid "[%s]: illegal value specified"
-#: ../display/d.thematic.area/main.c:79
-msgid "Displays a thematic vector area map in the active frame on the graphics monitor."
-msgstr ""
-#: ../display/d.thematic.area/main.c:89
-msgid "Data to be classified: column name or expression"
-msgstr ""
-#: ../display/d.thematic.area/main.c:96
-msgid "Class breaks, without minimum and maximum"
-msgstr ""
-#: ../display/d.thematic.area/main.c:104 ../vector/v.class/main.c:66
-msgid "Algorithm to use for classification"
-msgstr ""
-#: ../display/d.thematic.area/main.c:105 ../vector/v.class/main.c:67
-msgid "int;simple intervals;std;standard deviations;qua;quantiles;equ;equiprobable (normal distribution);"
-msgstr ""
-#: ../display/d.thematic.area/main.c:116 ../vector/v.class/main.c:78
-msgid "Number of classes to define"
-msgstr ""
-#: ../display/d.thematic.area/main.c:123
-msgid "Colors (one per class)."
-msgstr ""
-#: ../display/d.thematic.area/main.c:129
-msgid "Layer number. If -1, all layers are displayed."
-msgstr ""
-#: ../display/d.thematic.area/main.c:139 ../display/d.thematic.area/main.c:147
-#, fuzzy
-msgid "Boundaries"
-#: ../display/d.thematic.area/main.c:140
-msgid "Boundary width"
-msgstr ""
-#: ../display/d.thematic.area/main.c:146
-msgid "Boundary color"
-msgstr ""
-#: ../display/d.thematic.area/main.c:153
-msgid "File in which to save d.graph instructions for legend display"
-msgstr ""
-#: ../display/d.thematic.area/main.c:164
-msgid "When printing legend info , include extended statistical info from classification algorithm"
-msgstr ""
-#: ../display/d.thematic.area/main.c:168
-msgid "Do not draw map, only output the legend"
-msgstr ""
-#: ../display/d.thematic.area/main.c:187
-#, fuzzy, c-format
-msgid "%s: You must build topology on vector map. Run v.build."
-#: ../display/d.thematic.area/main.c:194
-msgid "'layer' must be > 0"
-msgstr ""
-#: ../display/d.thematic.area/main.c:220
-#, c-format
-msgid "Data (%s) not numeric. Column must be numeric."
-msgstr ""
-#: ../display/d.thematic.area/main.c:224
-#: ../display/d.thematic.area/plot1.c:134
-#: ../display/d.thematic.area/plot1.c:162
-#, fuzzy, c-format
-msgid "Cannot select data (%s) from table"
-#: ../display/d.thematic.area/main.c:287
-#, c-format
-msgid "Unknown color: [%s]"
-msgstr ""
-#: ../display/d.thematic.area/main.c:298
-msgid "You gave both manual breaks and a classification algorithm or a number of classes. The manual breaks have precedence and will thus be used."
-msgstr ""
-#: ../display/d.thematic.area/main.c:335
-msgid "You must either give classbreaks or a classification algorithm"
-msgstr ""
-#: ../display/d.thematic.area/main.c:348
-#, c-format
-msgid ""
-"Not enough colors or error in color specifications.\n"
-"Need %i colors."
-msgstr ""
-#: ../display/d.thematic.area/main.c:353
-#, fuzzy, c-format
-msgid "Error interpreting color %s"
-#: ../display/d.thematic.area/main.c:372
-msgid "Plotting ..."
-msgstr ""
-#: ../display/d.thematic.area/main.c:379
-msgid "The bounding box of the map is outside the current region, nothing drawn."
-msgstr ""
-#: ../display/d.thematic.area/main.c:429
-#, c-format
-msgid ""
-"\n"
-"Total number of records: %.0f\n"
-msgstr ""
-#: ../display/d.thematic.area/main.c:431
-#, c-format
-msgid "Classification of %s into %i classes\n"
-msgstr ""
-#: ../display/d.thematic.area/main.c:433 ../vector/v.class/main.c:192
-#, c-format
-msgid "Using algorithm: *** %s ***\n"
-msgstr ""
-#: ../display/d.thematic.area/main.c:435 ../vector/v.class/main.c:193
-#, c-format
-msgid "Mean: %f\tStandard deviation = %f\n"
-msgstr ""
-#: ../display/d.thematic.area/main.c:439
-#, c-format
-msgid "Last chi2 = %f\n"
-msgstr ""
-#: ../display/d.thematic.area/main.c:442 ../vector/v.class/main.c:200
-#, c-format
-msgid "Stdev multiplied by %.4f to define step\n"
-msgstr ""
-#: ../display/d.thematic.area/plot1.c:147
-msgid "Line width column not specified."
-msgstr ""
-#: ../display/d.thematic.area/plot1.c:158
-#, c-format
-msgid "Line width column (%s) not a number."
-msgstr ""
-#: ../display/d.thematic.area/plot1.c:203
-#, c-format
-msgid ""
-"\n"
-"ERROR: vector map - can't read\n"
-msgstr ""
-#: ../display/d.thematic.area/plot1.c:278
-#, c-format
-msgid "Error in color definition column (%s), element %d with cat %d: colorstring [%s]"
-msgstr ""
-#: ../display/d.thematic.area/plot1.c:285
-#, c-format
-msgid "Error in color definition column (%s), element %d with cat %d"
-msgstr ""
-#: ../display/d.thematic.area/plot1.c:353
-#, c-format
-msgid "Error in line width column (%s), element %d with cat %d: line width [%d]"
-msgstr ""
-#: ../display/d.fontlist/main.c:40
-msgid "Lists the available fonts."
-msgstr ""
-#: ../display/d.fontlist/main.c:44
-msgid "List fonts (default; provided for compatibility with d.font)"
-msgstr ""
-#: ../display/d.fontlist/main.c:48 ../display/d.font/main.c:80
-msgid "List fonts verbosely"
-msgstr ""
-#: ../display/d.graph/do_graph.c:65 ../display/d.graph/do_graph.c:81
-#, c-format
-msgid "Problem parsing coordinates [%s]"
-msgstr ""
-#: ../display/d.graph/do_graph.c:98
-msgid "Unable to read color"
-msgstr ""
-#: ../display/d.graph/do_graph.c:129 ../display/d.graph/do_graph.c:195
-#: ../display/d.graph/do_graph.c:216 ../display/d.graph/do_graph.c:267
-#: ../display/d.graph/do_graph.c:334 ../display/d.graph/graphics.c:60
-#, c-format
-msgid "Problem parsing command [%s]"
-msgstr ""
-#: ../display/d.graph/main.c:61
-msgid "Program for generating and displaying simple graphics on the display monitor."
-msgstr ""
-#: ../display/d.graph/main.c:68
-msgid "Name of file containing graphics commands, if not given reads from standard input"
-msgstr ""
-#: ../display/d.graph/main.c:76
-msgid "Color to draw with, either a standard GRASS color or R:G:B triplet"
-msgstr ""
-#: ../display/d.graph/main.c:83
-msgid "Coordinates are given in map units"
-msgstr ""
-#: ../display/d.graph/main.c:94
-#, c-format
-msgid "Graph file <%s> not found"
-msgstr ""
-#: ../display/d.rgb/main.c:57
-msgid "Displays three user-specified raster maps as red, green, and blue overlays in the active graphics frame."
-msgstr ""
-#: ../display/d.rgb/main.c:68
-#, fuzzy, c-format
-msgid "Name of raster map to be used for '%s'"
-#: ../display/d.path/main.c:49 ../vector/v.lrs/v.lrs.segment/main.c:72
-#: ../vector/v.lrs/v.lrs.where/main.c:59
-#: ../vector/v.lrs/v.lrs.create/main.c:123
-#: ../vector/v.lrs/v.lrs.label/main.c:104
-msgid "networking"
-msgstr ""
-#: ../display/d.path/main.c:51
-msgid "Finds shortest path for selected starting and ending node."
-msgstr ""
-#: ../display/d.path/main.c:58 ../vector/v.net.iso/main.c:86
-#: ../vector/v.net.steiner/main.c:361 ../vector/v.net.alloc/main.c:76
-#: ../vector/v.net.salesman/main.c:119 ../vector/v.net.path/main.c:51
-msgid "Arc type"
-msgstr ""
-#: ../display/d.path/main.c:70 ../vector/v.net.iso/main.c:90
-#: ../vector/v.net.centrality/main.c:109 ../vector/v.net.steiner/main.c:366
-#: ../vector/v.net/args.c:55 ../vector/v.net.distance/main.c:77
-#: ../vector/v.net.alloc/main.c:81 ../vector/v.net.bridge/main.c:59
-#: ../vector/v.net.flow/main.c:70 ../vector/v.net.timetable/main.c:274
-#: ../vector/v.net.spanningtree/main.c:59 ../vector/v.net.allpairs/main.c:69
-#: ../vector/v.net.components/main.c:82 ../vector/v.net.salesman/main.c:123
-#: ../vector/v.net.path/main.c:56 ../vector/v.net.connectivity/main.c:65
-msgid "Arc layer"
-msgstr ""
-#: ../display/d.path/main.c:75 ../vector/v.net.iso/main.c:95
-#: ../vector/v.net.centrality/main.c:115 ../vector/v.net/args.c:62
-#: ../vector/v.net.distance/main.c:83 ../vector/v.net.alloc/main.c:86
-#: ../vector/v.net.bridge/main.c:65 ../vector/v.net.flow/main.c:76
-#: ../vector/v.net.timetable/main.c:280 ../vector/v.net.spanningtree/main.c:65
-#: ../vector/v.net.allpairs/main.c:75 ../vector/v.net.components/main.c:88
-#: ../vector/v.net.path/main.c:61 ../vector/v.net.connectivity/main.c:71
-msgid "Node layer"
-msgstr ""
-#: ../display/d.path/main.c:81 ../vector/v.net.path/main.c:74
-msgid "Arc forward/both direction(s) cost column"
-msgstr ""
-#: ../display/d.path/main.c:87 ../vector/v.net.path/main.c:80
-msgid "Arc backward direction cost column"
-msgstr ""
-#: ../display/d.path/main.c:93 ../vector/v.net.path/main.c:86
-msgid "Node cost column"
-msgstr ""
-#: ../display/d.path/main.c:99 ../display/d.extract/main.c:65
-msgid "Original line color"
-msgstr ""
-#: ../display/d.path/main.c:101 ../display/d.path/main.c:109
-#: ../display/d.path/main.c:117 ../display/d.path/main.c:127
-msgid "Rendering"
-msgstr ""
-#: ../display/d.path/main.c:107 ../display/d.extract/main.c:71
-msgid "Highlight color"
-msgstr ""
-#: ../display/d.path/main.c:115 ../general/g.cairocomp/main.c:245
-#: ../vector/v.label/main.c:187 ../vector/v.lrs/v.lrs.label/main.c:229
-#: ../vector/v.label.sa/main.c:124
-msgid "Background color"
-msgstr ""
-#: ../display/d.path/main.c:122 ../vector/v.net.iso/main.c:128
-#: ../vector/v.net.centrality/main.c:188 ../vector/v.net.steiner/main.c:396
-#: ../vector/v.net.distance/main.c:139 ../vector/v.net.alloc/main.c:118
-#: ../vector/v.net.spanningtree/main.c:84 ../vector/v.net.allpairs/main.c:106
-#: ../vector/v.net.salesman/main.c:152 ../vector/v.net.path/main.c:103
-msgid "Use geodesic calculation for longitude-latitude locations"
-msgstr ""
-#: ../display/d.path/main.c:126
-msgid "Render bold lines"
-msgstr ""
-#: ../display/d.path/main.c:143 ../display/d.path/main.c:147
-#, c-format
-msgid "%s - illegal x value"
-msgstr ""
-#: ../display/d.path/main.c:145 ../display/d.path/main.c:149
-#, c-format
-msgid "%s - illegal y value"
-msgstr ""
-#: ../display/d.path/main.c:180 ../vector/v.net.centrality/main.c:222
-#: ../vector/v.net.distance/main.c:169 ../vector/v.net.spanningtree/main.c:113
-#: ../vector/v.net.allpairs/main.c:139 ../vector/v.net.path/main.c:121
-msgid "The current projection is not longitude-latitude"
-msgstr ""
-#: ../display/d.path/select.c:84 ../display/d.path/select.c:101
-#, c-format
-msgid "Node %d: %f %f\n"
-msgstr ""
-#: ../display/d.path/select.c:122
-#, c-format
-msgid "Destination unreachable\n"
-msgstr ""
-#: ../display/d.path/select.c:125
-#, c-format
-msgid "Costs on the network = %f\n"
-msgstr ""
-#: ../display/d.path/select.c:126
-#, c-format
-msgid ""
-"  Distance to the network = %f, distance from the network = %f\n"
-"\n"
-msgstr ""
-#: ../display/d.rast.arrow/main.c:98
-msgid "Draws arrows representing cell aspect direction for a raster map containing aspect data."
-msgstr ""
-#: ../display/d.rast.arrow/main.c:102
-msgid "Name of raster aspect map to be displayed"
-msgstr ""
-#: ../display/d.rast.arrow/main.c:110
-msgid "Type of existing raster aspect map"
-msgstr ""
-#: ../display/d.rast.arrow/main.c:118
-msgid "Color for drawing arrows"
-msgstr ""
-#: ../display/d.rast.arrow/main.c:127
-msgid "Color for drawing grid or \"none\""
-msgstr ""
-#: ../display/d.rast.arrow/main.c:136
-msgid "Color for drawing X's (null values)"
-msgstr ""
-#: ../display/d.rast.arrow/main.c:145
-msgid "Color for showing unknown information"
-msgstr ""
-#: ../display/d.rast.arrow/main.c:153
-msgid "Draw arrow every Nth grid cell"
-msgstr ""
-#: ../display/d.rast.arrow/main.c:162
-msgid "Raster map containing values used for arrow length"
-msgstr ""
-#: ../display/d.rast.arrow/main.c:169
-msgid "Scale factor for arrows (magnitude map)"
-msgstr ""
-#: ../display/d.rast.arrow/main.c:205
-#, fuzzy
-msgid "Illegal value for scale factor"
-#: ../display/d.rast.arrow/main.c:209
-#, fuzzy
-msgid "Illegal value for skip factor"
-#: ../display/d.rast.arrow/main.c:214
-msgid "Magnitude is only supported for GRASS and compass aspect maps."
-msgstr ""
-#: ../display/d.rast.arrow/main.c:219
-msgid "Scale option requires magnitude_map"
-msgstr ""
-#: ../display/d.rast.arrow/main.c:272
-#, fuzzy
-msgid "Problem reading range file"
-#: ../display/d.extract/extract.c:43
-msgid "Select vector(s) with mouse"
-msgstr ""
-#: ../display/d.extract/extract.c:44
-msgid " - L: draw box with left mouse button to select"
-msgstr ""
-#: ../display/d.extract/extract.c:45
-msgid " - M: draw box with middle mouse button to remove from display"
-msgstr ""
-#: ../display/d.extract/extract.c:46
-msgid " - R: quit and save selected vectors to new map\n"
-msgstr ""
-#: ../display/d.extract/extract.c:48
-msgid "L: add  M: remove  R: quit and save\n"
-msgstr ""
-#: ../display/d.extract/main.c:52
-msgid "Selects and extracts vectors with mouse into new vector map."
-msgstr ""
-#: ../display/d.extract/main.c:117
-#, fuzzy
-msgid "Copying tables..."
-#: ../display/d.extract/main.c:125
-#, fuzzy
-msgid "Cannot get db link info -> cannot copy table."
-#: ../display/d.legend/main.c:87
-msgid "Displays a legend for a raster map in the active frame of the graphics monitor."
-msgstr ""
-#: ../display/d.legend/main.c:98
-msgid "Sets the legend's text color"
-msgstr ""
-#: ../display/d.legend/main.c:106
-msgid "Number of text lines (useful for truncating long legends)"
-msgstr ""
-#: ../display/d.legend/main.c:115
-msgid "Thinning factor (thin=10 gives cats 0,10,20...)"
-msgstr ""
-#: ../display/d.legend/main.c:123
-msgid "Number of text labels for smooth gradient legend"
-msgstr ""
-#: ../display/d.legend/main.c:133
-msgid "Size and placement as percentage of screen coordinates (0,0 is lower left)"
-msgstr ""
-#: ../display/d.legend/main.c:143
-msgid "List of discrete category numbers/values for legend"
-msgstr ""
-#: ../display/d.legend/main.c:153
-msgid "Use a subset of the map range for the legend (min,max)"
-msgstr ""
-#: ../display/d.legend/main.c:181
-msgid "Do not show category labels"
-msgstr ""
-#: ../display/d.legend/main.c:186
-msgid "Do not show category numbers"
-msgstr ""
-#: ../display/d.legend/main.c:191
-msgid "Skip categories with no label"
-msgstr ""
-#: ../display/d.legend/main.c:196
-msgid "Draw smooth gradient"
-msgstr ""
-#: ../display/d.legend/main.c:201
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:3
-msgid "Flip legend"
-msgstr ""
-#: ../display/d.legend/main.c:224
-#, c-format
-msgid "Don't know the color %s"
-msgstr ""
-#: ../display/d.legend/main.c:342
-msgid "Legend box lies outside of frame. Text may not display properly."
-msgstr ""
-#: ../display/d.legend/main.c:346
-msgid "Drawing horizontal legend as box width exceeds height"
-msgstr ""
-#: ../display/d.legend/main.c:357
-#, c-format
-msgid "Range information for <%s> not available (run r.support)"
-msgstr ""
-#: ../display/d.legend/main.c:362
-#, fuzzy
-msgid "Input map contains no data"
-#: ../display/d.legend/main.c:375 ../display/d.legend/main.c:535
-msgid "Color range exceeds lower limit of actual data"
-msgstr ""
-#: ../display/d.legend/main.c:381 ../display/d.legend/main.c:539
-msgid "Color range exceeds upper limit of actual data"
-msgstr ""
-#: ../display/d.legend/main.c:440
-#, c-format
-msgid "use=%s out of range [%d,%d] (extend with range= ?)"
-msgstr ""
-#: ../display/d.legend/main.c:481
-msgid "Nothing to draw! (no categories with labels? out of range?)"
-msgstr ""
-#: ../display/d.legend/main.c:491
-msgid "Forcing a smooth legend: too many categories for current window height"
-msgstr ""
-#: ../display/d.legend/main.c:546
-#, c-format
-msgid "use=%s out of range [%.3f, %.3f] (extend with range= ?)"
-msgstr ""
-#: ../display/d.legend/main.c:917
-msgid "Nothing to draw! (no categories with labels?)"
-msgstr ""
-#: ../display/d.measure/main.c:49
-msgid "Measures the lengths and areas of features drawn by the user in the active display frame on the graphics monitor."
-msgstr ""
-#: ../display/d.measure/main.c:55
-msgid "Line color 1"
-msgstr ""
-#: ../display/d.measure/main.c:63
-msgid "Line color 2"
-msgstr ""
-#: ../display/d.measure/main.c:71
-msgid "Suppress clear screen"
-msgstr ""
-#: ../display/d.measure/main.c:75
-msgid "Output in meters only"
-msgstr ""
-#: ../display/d.measure/main.c:79
-msgid "Output in kilometers as well"
-msgstr ""
-#: ../display/d.title/main.c:52
-msgid "Create a TITLE for a raster map in a form suitable for display with d.text."
-msgstr ""
-#: ../display/d.title/main.c:63
-msgid "Sets the text color"
-msgstr ""
-#: ../display/d.title/main.c:71
-msgid "Sets the text size as percentage of the frame's height"
-msgstr ""
-#: ../display/d.title/main.c:75
-#, fuzzy
-msgid "Draw title on current display"
-#: ../display/d.title/main.c:79
-msgid "Do a fancier title"
-msgstr ""
-#: ../display/d.title/main.c:84
-msgid "Do a simple title"
-msgstr ""
-#: ../display/d.title/main.c:102
-msgid "Title can be fancy or simple, not both"
-msgstr ""
-#: ../display/d.title/main.c:105
-msgid "No map name given"
-msgstr ""
-#: ../display/d.font/main.c:49
-msgid "Selects the font in which text will be displayed on the user's graphics monitor."
-msgstr ""
-#: ../display/d.font/main.c:57
-msgid "Choose new current font"
-msgstr ""
-#: ../display/d.font/main.c:64
-msgid "Path to Freetype-compatible font including file name"
-msgstr ""
-#: ../display/d.font/main.c:72
-msgid "Character encoding"
-msgstr ""
-#: ../display/d.font/main.c:76
-msgid "List fonts"
-msgstr ""
-#: ../display/d.font/main.c:107
-#, fuzzy, c-format
-msgid "Unable to access font path %s: %s"
-#: ../display/d.font/main.c:111
-#, c-format
-msgid "Font path %s is not a file"
-msgstr ""
-#: ../display/d.font/main.c:128
-#, c-format
-msgid "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
-msgstr ""
-#: ../general/g.filename/main.c:41
-msgid "Prints GRASS data base file names."
-msgstr ""
-#: ../general/g.filename/main.c:49 ../general/g.findfile/main.c:53
-msgid "Name of an element"
-msgstr ""
-#: ../general/g.filename/main.c:55
-msgid "Name of a database file"
-msgstr ""
-#: ../general/g.filename/main.c:61
-msgid "Name of a mapset (default: current)"
-msgstr ""
-#: ../general/g.gui/main.c:37 ../general/g.cairocomp/main.c:194
-#: ../general/g.mkfontcap/main.c:71 ../general/g.pnmcomp/main.c:283
-#: ../general/g.ppmtopng/main.c:118
-msgid "gui"
-msgstr ""
-#: ../general/g.gui/main.c:39
-msgid "Launches a GRASS graphical user interface (GUI) session."
-msgstr ""
-#: ../general/g.gui/main.c:44
-msgid "GUI type"
-msgstr ""
-#: ../general/g.gui/main.c:45
-msgid "Default value: GRASS_GUI if defined otherwise wxpython"
-msgstr ""
-#: ../general/g.gui/main.c:46
-msgid "wxpython;wxPython based GUI (wxGUI);text;command line interface only"
-msgstr ""
-#: ../general/g.gui/main.c:53
-msgid "Name of workspace file to load on start-up (valid only for wxGUI)"
-msgstr ""
-#: ../general/g.gui/main.c:57
-msgid "Update default GUI setting"
-msgstr ""
-#: ../general/g.gui/main.c:62
-msgid "Do not launch GUI after updating the default GUI setting"
-msgstr ""
-#: ../general/g.gui/main.c:89
-#, c-format
-msgid "<%s> is now the default GUI"
-msgstr ""
-#: ../general/g.gui/main.c:103
-#, c-format
-msgid "Launching <%s> GUI in the background, please wait..."
-msgstr ""
-#: ../general/g.access/set_perms.c:26
-#, fuzzy
-msgid "Unable to change mapset permissions"
-#: ../general/g.access/main.c:39
-#, fuzzy
-msgid "permission"
-#: ../general/g.access/main.c:41
-msgid "Controls access to the current mapset for other users on the system."
-msgstr ""
-#: ../general/g.access/main.c:42
-#, fuzzy
-msgid "If no option given, prints current status."
-#: ../general/g.access/main.c:49
-msgid "Access for group"
-msgstr ""
-#: ../general/g.access/main.c:57
-msgid "Access for others"
-msgstr ""
-#: ../general/g.access/main.c:64
-msgid "UNIX filesystem access controls are not supported by MS-Windows"
-msgstr ""
-#: ../general/g.access/main.c:72
-msgid "Access to the PERMANENT mapset must be open, nothing changed"
-msgstr ""
-#: ../general/g.access/main.c:76
-#, fuzzy
-msgid "Unable to determine mapset permissions"
-#: ../general/g.access/exp_perms.c:11 ../general/g.access/exp_perms.c:29
-msgid "have"
-msgstr ""
-#: ../general/g.access/exp_perms.c:12
-msgid "read "
-msgstr ""
-#: ../general/g.access/exp_perms.c:15
-msgid "Everyone"
-msgstr ""
-#: ../general/g.access/exp_perms.c:16
-msgid "has"
-msgstr ""
-#: ../general/g.access/exp_perms.c:19
-msgid "Only users in your group"
-msgstr ""
-#: ../general/g.access/exp_perms.c:22
-msgid "Only users outside your group"
-msgstr ""
-#: ../general/g.access/exp_perms.c:25
-msgid "Only you"
-msgstr ""
-#: ../general/g.access/exp_perms.c:31
-#, c-format
-msgid "%s %s %s %saccess to mapset %s"
-msgstr ""
-#: ../general/g.access/exp_perms.c:32
-msgid "will"
-msgstr ""
-msgid "now"
-msgstr ""
-#: ../general/g.tempfile/main.c:39 ../general/g.pnmcomp/main.c:282
-#, fuzzy
-msgid "support"
-#: ../general/g.tempfile/main.c:41
-msgid "Creates a temporary file and prints it's file name."
-msgstr ""
-#: ../general/g.tempfile/main.c:47
-msgid "Process id to use when naming the tempfile"
-msgstr ""
-#: ../general/g.tempfile/main.c:51
-msgid "Dry run - don't create a file, just prints it's file name"
-msgstr ""
-#: ../general/g.findfile/element.c:7
-msgid "List of available elements:"
-msgstr ""
-#: ../general/g.findfile/main.c:40
-#, fuzzy
-msgid "data base files"
-msgstr "डाटाबेसचे नाव"
-#: ../general/g.findfile/main.c:42
-msgid "Searches for GRASS data base files and sets variables for the shell."
-msgstr ""
-#: ../general/g.findfile/main.c:59
-#, fuzzy
-msgid "Name of an existing map"
-#: ../general/g.findfile/main.c:65
-#, fuzzy
-msgid "Name of a mapset (default: search path)"
-#: ../general/g.findfile/main.c:66
-#, fuzzy
-msgid "'.' for current mapset"
-#: ../general/g.findfile/main.c:70
-msgid "Don't add quotes"
-msgstr ""
-#: ../general/g.findfile/main.c:74
-msgid "List available elements and exit"
-msgstr ""
-#: ../general/g.findfile/main.c:97
-#, c-format
-msgid "Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%s> does not correspond"
-msgstr ""
-#: ../general/g.proj/create.c:17
-#, fuzzy, c-format
-msgid "Unable to create location <%s>: %s"
-#: ../general/g.proj/create.c:20
-#, fuzzy, c-format
-msgid "Unable to create projection files: %s"
-#: ../general/g.proj/create.c:24
-msgid "Unspecified error while creating new location"
-msgstr ""
-#: ../general/g.proj/create.c:26
-#, c-format
-msgid ""
-"You can switch to the new location by\n"
-"`%s=%s`"
-msgstr ""
-#: ../general/g.proj/create.c:36
-#, c-format
-msgid "You must select the PERMANENT mapset before updating the current location's projection (current mapset is <%s>)."
-msgstr ""
-#: ../general/g.proj/create.c:62
-msgid "Default region was updated to the new projection, but if you have multiple mapsets `g.region -d` should be run in each to update the region from the default"
-msgstr ""
-#: ../general/g.proj/create.c:66
-msgid "Projection information updated"
-msgstr ""
-#: ../general/g.proj/main.c:64
-#, fuzzy
-msgid "create location"
-#: ../general/g.proj/main.c:67
-msgid "Prints and manipulates GRASS projection information files (in various co-ordinate system descriptions)."
-msgstr ""
-#: ../general/g.proj/main.c:70
-#, fuzzy
-msgid "Can also be used to create new GRASS locations."
-#: ../general/g.proj/main.c:73
-msgid "Prints and manipulates GRASS projection information files."
-msgstr ""
-#: ../general/g.proj/main.c:80
-msgid "Print projection information in conventional GRASS format"
-msgstr ""
-#: ../general/g.proj/main.c:86
-#, fuzzy
-msgid "Print projection information in shell script style"
-#: ../general/g.proj/main.c:92
-msgid "Verify datum information and print transformation parameters"
-msgstr ""
-#: ../general/g.proj/main.c:98
-msgid "Print projection information in PROJ.4 format"
-msgstr ""
-#: ../general/g.proj/main.c:104
-msgid "Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
-msgstr ""
-#: ../general/g.proj/main.c:114
-msgid "Print projection information in WKT format"
-msgstr ""
-#: ../general/g.proj/main.c:120
-msgid "Use ESRI-style format (applies to WKT output only)"
-msgstr ""
-#: ../general/g.proj/main.c:127 ../general/g.proj/main.c:136
-#: ../general/g.proj/main.c:146 ../general/g.proj/main.c:155
-#, fuzzy
-msgid "Specification"
-#: ../general/g.proj/main.c:128
-msgid "Name of georeferenced data file to read projection information from"
-msgstr ""
-#: ../general/g.proj/main.c:137
-#, fuzzy
-msgid "Name of ASCII file containing a WKT projection description"
-#: ../general/g.proj/main.c:139 ../general/g.proj/main.c:148
-#: ../vector/v.segment/main.c:69
-#, fuzzy
-msgid "'-' for standard input"
-#: ../general/g.proj/main.c:147
-msgid "PROJ.4 projection description"
-msgstr ""
-#: ../general/g.proj/main.c:156
-msgid "EPSG projection code"
-msgstr ""
-#: ../general/g.proj/main.c:165 ../general/g.proj/main.c:171
-msgid "Datum"
-msgstr ""
-#: ../general/g.proj/main.c:166
-#, fuzzy
-msgid "Index number of datum transform parameters"
-#: ../general/g.proj/main.c:167
-msgid "\"0\" for unspecified or \"-1\" to list and exit"
-msgstr ""
-#: ../general/g.proj/main.c:173
-msgid "Force override of datum transformation information in input co-ordinate system"
-msgstr ""
-#: ../general/g.proj/main.c:179
-#, fuzzy
-msgid "Create new projection files (modifies current location)"
-#: ../general/g.proj/main.c:187 ../general/g.mapset/main.c:83
-#: ../locale/scriptstrings/r.mask_to_translate.c:6
-#: ../locale/scriptstrings/r.mask_to_translate.c:8
-msgid "Create"
-msgstr ""
-#: ../general/g.proj/main.c:188
-msgid "Name of new location to create"
-msgstr ""
-#: ../general/g.proj/main.c:204
-#, c-format
-msgid "Only one of '%s', '%s', '%s' or '%s' options may be specified"
-msgstr ""
-#: ../general/g.proj/main.c:233
-msgid "Projection files missing"
-msgstr ""
-#: ../general/g.proj/main.c:249
-#, c-format
-msgid "Only one of -%c, -%c, -%c, -%c, -%c or -%c flags may be specified"
-msgstr ""
-#: ../general/g.proj/main.c:276
-#, c-format
-msgid "No output format specified, define one of flags -%c, -%c, -%c, or -%c"
-msgstr ""
-#: ../general/g.proj/main.c:280
-#, c-format
-msgid "No output format specified, define one of flags -%c, -%c, or -%c"
-msgstr ""
-#: ../general/g.proj/input.c:91
-msgid "Error reading WKT projection description"
-msgstr ""
-#: ../general/g.proj/input.c:98
-#, fuzzy, c-format
-msgid "Unable to open file '%s' for reading"
-#: ../general/g.proj/input.c:143
-msgid "Can't parse PROJ.4-style parameter string"
-msgstr ""
-#: ../general/g.proj/input.c:181
-#, fuzzy
-msgid "Unable to translate EPSG code"
-#: ../general/g.proj/input.c:218
-msgid "Trying to open with OGR..."
-msgstr ""
-#: ../general/g.proj/input.c:226 ../general/g.proj/input.c:245
-msgid "...succeeded."
-msgstr ""
-#: ../general/g.proj/input.c:239
-msgid "Trying to open with GDAL..."
-msgstr ""
-#: ../general/g.proj/input.c:254
-#, c-format
-msgid "Could not read georeferenced file %s using either OGR nor GDAL"
-msgstr ""
-#: ../general/g.proj/input.c:259
-#, c-format
-msgid "Read of file %s was successful, but it did not contain projection information. 'XY (unprojected)' will be used"
-msgstr ""
-#: ../general/g.proj/output.c:181
-#, c-format
-msgid "%s: Unable to convert to WKT"
-msgstr ""
-#: ../general/g.mremove/check_reclass.c:18 ../general/g.remove/main.c:38
-#, fuzzy, c-format
-msgid "Raster map <%s@%s> is a base map for <%s>. Remove forced."
-#: ../general/g.mremove/check_reclass.c:22
-#, fuzzy, c-format
-msgid "Raster map <%s@%s> is a base map. Remove reclassed map first: %s"
-#: ../general/g.mremove/check_reclass.c:45
-#: ../general/g.mremove/check_reclass.c:59
-#, c-format
-msgid "Removing information about reclassed map from [%s@%s] failed"
-msgstr ""
-#: ../general/g.mremove/main.c:63 ../general/g.remove/main.c:103
-#: ../locale/scriptstrings/t.topology_to_translate.c:3
-#: ../locale/scriptstrings/t.remove_to_translate.c:4
-#: ../locale/scriptstrings/t.info_to_translate.c:3
-#, fuzzy
-msgid "remove"
-#: ../general/g.mremove/main.c:64
-#, fuzzy
-msgid "multi"
-#: ../general/g.mremove/main.c:66
-msgid "Removes data base element files from the user's current mapset using regular expressions."
-msgstr ""
-#: ../general/g.mremove/main.c:71 ../general/g.mlist/main.c:102
-msgid "Use basic regular expressions instead of wildcards"
-msgstr ""
-#: ../general/g.mremove/main.c:76 ../general/g.mlist/main.c:108
-msgid "Use extended regular expressions instead of wildcards"
-msgstr ""
-#: ../general/g.mremove/main.c:81
-#: ../locale/scriptstrings/db.droptable_to_translate.c:4
-#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:4
-msgid "Force removal (required for actual deletion of files)"
-msgstr ""
-#: ../general/g.mremove/main.c:85
-#, fuzzy
-msgid "Remove base raster maps"
-#: ../general/g.mremove/main.c:93
-#, fuzzy
-msgid "removed"
-#: ../general/g.mremove/main.c:100
-#, c-format
-msgid "-%c and -%c are mutually exclusive"
-msgstr ""
-#: ../general/g.mremove/main.c:104
-msgid "The following data base element files would be deleted:"
-msgstr ""
-#: ../general/g.mremove/main.c:128
-#, fuzzy, c-format
-msgid "Unable to compile pattern <%s>"
-#: ../general/g.mremove/main.c:153
-#, c-format
-msgid "You must use the force flag (-%c) to actually remove them. Exiting."
-msgstr ""
-#: ../general/g.mapset/main.c:50 ../general/g.gisenv/main.c:39
-#: ../general/g.region/main.c:64 ../general/g.mapsets/main.c:60
-#, fuzzy
-msgid "settings"
-#: ../general/g.mapset/main.c:51
-#, fuzzy
-msgid "Changes/reports current mapset."
-#: ../general/g.mapset/main.c:52
-msgid "Optionally create new mapset or list available mapsets in given location."
-msgstr ""
-#: ../general/g.mapset/main.c:56
-#, fuzzy
-msgid "Name of mapset where to switch"
-#: ../general/g.mapset/main.c:66
-msgid "Location name (not location path)"
-msgstr ""
-#: ../general/g.mapset/main.c:75
-msgid "GIS data directory"
-msgstr ""
-#: ../general/g.mapset/main.c:76
-msgid "Full path to the directory where the new location is"
-msgstr ""
-#: ../general/g.mapset/main.c:81
-msgid "Create mapset if it doesn't exist"
-msgstr ""
-#: ../general/g.mapset/main.c:88
-msgid "List available mapsets and exit"
-msgstr ""
-#: ../general/g.mapset/main.c:94
-#, fuzzy
-msgid "Print current mapset and exit"
-#: ../general/g.mapset/main.c:149
-#, fuzzy, c-format
-msgid "<%s> is already the current mapset"
-#: ../general/g.mapset/main.c:158
-#, c-format
-msgid "You don't have permission to use the mapset <%s>"
-msgstr ""
-#: ../general/g.mapset/main.c:168
-#, fuzzy, c-format
-msgid "Mapset <%s> does not exist. Use -c flag to create it."
-#: ../general/g.mapset/main.c:178
-#, fuzzy
-msgid "Unable to read GIS_LOCK environment variable"
-#: ../general/g.mapset/main.c:194
-#, c-format
-msgid "Lock file of mapset <%s> cannot be checked"
-msgstr ""
-#: ../general/g.mapset/main.c:197
-#, c-format
-msgid "<%s> is currently running GRASS in selected mapset <%s>"
-msgstr ""
-#: ../general/g.mapset/main.c:203
-#, fuzzy
-msgid "Cleaning up temporary files..."
-#: ../general/g.mapset/main.c:217
-msgid "Your shell continues to use the history for the old mapset"
-msgstr ""
-#: ../general/g.mapset/main.c:222
-#, c-format
-msgid ""
-"You can switch the history by commands:\n"
-"history -w; history -r %s/.bash_history; HISTFILE=%s/.bash_history"
-msgstr ""
-#: ../general/g.mapset/main.c:227
-#, c-format
-msgid ""
-"history -S; history -L %s/.history; setenv histfile=%s/.history"
-msgstr ""
-#: ../general/g.mapset/main.c:233
-#, fuzzy, c-format
-msgid "Your current mapset is <%s>"
-#: ../general/g.pnmcat/main.c:30 ../general/g.pnmcomp/main.c:53
-msgid "Error reading PPM file"
-msgstr ""
-#: ../general/g.pnmcat/main.c:46 ../general/g.pnmcat/main.c:54
-#: ../general/g.pnmcat/main.c:59 ../general/g.pnmcomp/main.c:68
-#: ../general/g.pnmcomp/main.c:73 ../general/g.pnmcomp/main.c:82
-#: ../general/g.pnmcomp/main.c:133 ../general/g.pnmcomp/main.c:146
-msgid "Invalid PPM file"
-msgstr ""
-#: ../general/g.pnmcat/main.c:49
-msgid "Unsupported PPM file (format = P6 required)"
-msgstr ""
-#: ../general/g.pnmcat/main.c:62
-msgid "Unsupported PPM file (maxval = 255 required)"
-msgstr ""
-#: ../general/g.pnmcat/main.c:83 ../general/g.pnmcomp/main.c:95
-#, fuzzy, c-format
-msgid "File <%s> not found"
-#: ../general/g.pnmcat/main.c:93
-#, c-format
-msgid "File <%s> has wrong height (expected %d, got %d"
-msgstr ""
-#: ../general/g.pnmcat/main.c:128
-#, fuzzy
-msgid "Base name of input files"
-#: ../general/g.pnmcat/main.c:134 ../general/g.cairocomp/main.c:209
-#: ../general/g.ppmtopng/main.c:133
-#, fuzzy
-msgid "Name of output file"
-#: ../general/g.pnmcat/main.c:153 ../general/g.cairocomp/main.c:234
-#: ../general/g.pnmcomp/main.c:311
-msgid "Image width"
-msgstr ""
-#: ../general/g.pnmcat/main.c:159 ../general/g.cairocomp/main.c:240
-#: ../general/g.pnmcomp/main.c:317
-msgid "Image height"
-msgstr ""
-#: ../general/g.pnmcat/main.c:185
-#, c-format
-msgid "Row <%d> has wrong width (expected %d, got %d"
-msgstr ""
-#: ../general/g.pnmcat/main.c:190
-#, c-format
-msgid "Invalid height (expected %d, got %d"
-msgstr ""
-#: ../general/g.pnmcat/main.c:198
-#, fuzzy, c-format
-msgid "Error reading PPM file for tile <%d,%d> at row <%d>"
-#: ../general/g.pnmcat/main.c:204
-#, fuzzy, c-format
-msgid "Error writing PPM file for tile row <%d> at row <%d>"
-#: ../general/g.pnmcat/main.c:213
-#, c-format
-msgid "Incorrect height (expected %d, got %d"
-msgstr ""
-#: ../general/g.cairocomp/main.c:48
-#, fuzzy, c-format
-msgid "Unable to read input file <%s>"
-#: ../general/g.cairocomp/main.c:51
-#, fuzzy, c-format
-msgid "Unable to parse input file <%s>"
-#: ../general/g.cairocomp/main.c:70
-#, fuzzy, c-format
-msgid "Unable to write output file <%s>"
-#: ../general/g.cairocomp/main.c:112
-#, fuzzy
-msgid "Unable to obtain visual"
-#: ../general/g.cairocomp/main.c:128
-#, fuzzy
-msgid "Failed to initialize output surface"
-#: ../general/g.cairocomp/main.c:147 ../general/g.pnmcomp/main.c:37
-#, c-format
-msgid "Invalid color: %s"
-msgstr ""
-#: ../general/g.cairocomp/main.c:168
-#, fuzzy
-msgid "Failed to initialize input surface"
-#: ../general/g.cairocomp/main.c:195
-#, fuzzy
-msgid "Overlays multiple X Pixmaps"
-#: ../general/g.cairocomp/main.c:202
-#, fuzzy
-msgid "Names of input files"
-#: ../general/g.cairocomp/main.c:216
-msgid "Output Visual XID"
-msgstr ""
-#: ../general/g.cairocomp/main.c:222
-msgid "Output screen"
-msgstr ""
-#: ../general/g.cairocomp/main.c:228 ../general/g.pnmcomp/main.c:298
-msgid "Layer opacities"
-msgstr ""
-#: ../general/g.cairocomp/main.c:249
-msgid "Don't composite; just delete input Pixmaps"
-msgstr ""
-#: ../general/g.cairocomp/main.c:281
-msgid "input= and opacity= must have the same number of values"
-msgstr ""
-#: ../general/g.mlist/main.c:64 ../general/g.list/main.c:46
-#: ../locale/scriptstrings/tv.list_to_translate.c:5
-#: ../locale/scriptstrings/tr.list_to_translate.c:5
-#: ../locale/scriptstrings/t.list_to_translate.c:4
-#: ../locale/scriptstrings/tr3.list_to_translate.c:5
-msgid "list"
-msgstr ""
-#: ../general/g.mlist/main.c:66
-msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
-msgstr ""
-#: ../general/g.mlist/main.c:81
-msgid "Map name search pattern (default: all)"
-msgstr ""
-#: ../general/g.mlist/main.c:82 ../general/g.mlist/main.c:90
-#: ../general/g.mlist/main.c:103 ../general/g.mlist/main.c:109
-msgid "Pattern"
-msgstr ""
-#: ../general/g.mlist/main.c:89
-msgid "Map name exclusion pattern (default: none)"
-msgstr ""
-#: ../general/g.mlist/main.c:94
-#, fuzzy
-msgid "Name of mapset to list (default: current search path)"
-#: ../general/g.mlist/main.c:113
-#, fuzzy
-msgid "Print data types"
-#: ../general/g.mlist/main.c:118
-msgid "Print fully-qualified map names (including mapsets)"
-msgstr ""
-#: ../general/g.mlist/main.c:123
-msgid "Pretty printing in human readable format"
-msgstr ""
-#: ../general/g.mlist/main.c:128 ../general/g.list/main.c:59
-msgid "Verbose listing (also list map titles)"
-msgstr ""
-#: ../general/g.mlist/main.c:135
-msgid "-r and -e are mutually exclusive"
-msgstr ""
-#: ../general/g.mlist/main.c:254
-#, fuzzy, c-format
-msgid "%s available in mapset <%s>:"
-#: ../general/g.version/main.c:44
-#, fuzzy
-msgid "version"
-msgstr "डेटाबेसची यादी दाखवता येणार नाही"
-#: ../general/g.version/main.c:45
-msgid "Displays version and copyright information."
-msgstr ""
-#: ../general/g.version/main.c:49
-msgid "Print also the copyright message"
-msgstr ""
-#: ../general/g.version/main.c:53
-msgid "Print also the GRASS build information"
-msgstr ""
-#: ../general/g.version/main.c:58
-msgid "Print also the GIS library revision number and time"
-msgstr ""
-#: ../general/g.version/main.c:62
-msgid "Print info in shell script style"
-msgstr ""
-#: ../general/g.parser/revoke.c:63
-msgid "G_spawn() failed"
-msgstr ""
-#: ../general/g.parser/revoke.c:71
-msgid "execl() failed"
-msgstr ""
-#: ../general/g.parser/main.c:63
-msgid "Usage"
-msgstr ""
-#: ../general/g.parser/main.c:73
-#, fuzzy
-msgid "Unable to open script file"
-#: ../general/g.parser/main.c:88
-#, c-format
-msgid "Line too long or missing newline at line %d\n"
-msgstr ""
-#: ../general/g.parser/main.c:125
-#, fuzzy
-msgid "Error closing script file"
-#: ../general/g.parser/parse.c:22
-#, c-format
-msgid "Unknown boolean value \"%s\" at line %d\n"
-msgstr ""
-#: ../general/g.parser/parse.c:65
-#, fuzzy, c-format
-msgid "Unknown command \"%s\" at line %d\n"
-#: ../general/g.parser/parse.c:92
-#, c-format
-msgid "Unknown module parameter \"%s\" at line %d\n"
-msgstr ""
-#: ../general/g.parser/parse.c:134
-#, c-format
-msgid "Unknown flag parameter \"%s\" at line %d\n"
-msgstr ""
-#: ../general/g.parser/parse.c:149
-#, fuzzy, c-format
-msgid "Unknown type \"%s\" at line %d\n"
-#: ../general/g.parser/parse.c:227
-#, c-format
-msgid "Unknown option parameter \"%s\" at line %d\n"
-msgstr ""
-#: ../general/g.gisenv/main.c:40
-#, fuzzy
-msgid "variables"
-#: ../general/g.gisenv/main.c:42
-msgid "Outputs and modifies the user's current GRASS variable settings."
-msgstr ""
-#: ../general/g.gisenv/main.c:43
-msgid "Prints all defined GRASS variables if no option is given."
-msgstr ""
-#: ../general/g.gisenv/main.c:48
-msgid "GRASS variable to get"
-msgstr ""
-#: ../general/g.gisenv/main.c:51
-msgid "Get"
-msgstr ""
-#: ../general/g.gisenv/main.c:56
-msgid "GRASS variable to set"
-msgstr ""
-#: ../general/g.gisenv/main.c:59 ../general/g.gisenv/main.c:67
-#: ../general/g.gisenv/main.c:76 ../db/db.connect/main.c:59
-#: ../db/db.connect/main.c:65 ../db/db.connect/main.c:70
-#: ../db/db.connect/main.c:74 ../db/db.connect/main.c:78
-#: ../db/db.connect/main.c:88
-msgid "Set"
-msgstr ""
-#: ../general/g.gisenv/main.c:64
-#, fuzzy
-msgid "GRASS variable to unset"
-#: ../general/g.gisenv/main.c:74
-msgid "Where GRASS variable is stored"
-msgstr ""
-#: ../general/g.gisenv/main.c:80
-msgid "Use shell syntax (for \"eval\")"
-msgstr ""
-#: ../general/g.gisenv/main.c:81 ../general/g.gisenv/main.c:86
-#: ../vector/v.db.select/main.c:66 ../vector/v.db.select/main.c:72
-#: ../vector/v.db.select/main.c:79 ../vector/v.db.select/main.c:95
-#: ../vector/v.db.select/main.c:100 ../db/db.select/main.c:219
-#: ../db/db.select/main.c:225 ../db/db.select/main.c:232
-#: ../db/db.select/main.c:242 ../db/db.select/main.c:252
-#, fuzzy
-msgid "Format"
-#: ../general/g.gisenv/main.c:85
-msgid "Don't use shell syntax"
-msgstr ""
-#: ../general/g.gisenv/main.c:92
-#, c-format
-msgid "Flags -%c and -%c are mutually exclusive"
-msgstr ""
-#: ../general/g.gisenv/main.c:126 ../vector/v.colors/main.c:184
-#, c-format
-msgid "Options <%s>, <%s>, and <%s> are mutually exclusive"
-msgstr ""
-#: ../general/g.region/main.c:66
-msgid "Manages the boundary definitions for the geographic region."
-msgstr ""
-#: ../general/g.region/main.c:73 ../general/g.region/main.c:78
-#: ../general/g.region/main.c:166 ../general/g.region/main.c:173
-#: ../general/g.region/main.c:182 ../general/g.region/main.c:189
-#: ../general/g.region/main.c:199
-msgid "Existing"
-msgstr ""
-#: ../general/g.region/main.c:77
-msgid "Save as default region"
-msgstr ""
-#: ../general/g.region/main.c:82
-msgid "Print the current region"
-msgstr ""
-#: ../general/g.region/main.c:87
-msgid "Print the current region in lat/long using the current ellipsoid/datum"
-msgstr ""
-#: ../general/g.region/main.c:93
-msgid "Print the current region extent"
-msgstr ""
-#: ../general/g.region/main.c:99
-msgid "Print the current region map center coordinates"
-msgstr ""
-#: ../general/g.region/main.c:105
-#, fuzzy
-msgid "Print the current region in GMT style"
-#: ../general/g.region/main.c:111
-#, fuzzy
-msgid "Print the current region in WMS style"
-#: ../general/g.region/main.c:117
-msgid "Print region resolution in meters (geodesic)"
-msgstr ""
-#: ../general/g.region/main.c:122
-msgid "Print the convergence angle (degrees CCW)"
-msgstr ""
-#: ../general/g.region/main.c:124
-msgid "The difference between the projection's grid north and true north, measured at the center coordinates of the current region."
-msgstr ""
-#: ../general/g.region/main.c:130
-msgid "Print also 3D settings"
-msgstr ""
-#: ../general/g.region/main.c:136
-msgid "Print the maximum bounding box in lat/long on WGS84"
-msgstr ""
-#: ../general/g.region/main.c:147
-msgid "Align region to resolution (default = align to bounds, works only for 2D resolution)"
-msgstr ""
-#: ../general/g.region/main.c:153
-msgid "Do not update the current region"
-msgstr ""
-#: ../general/g.region/main.c:154 ../general/g.region/main.c:351
-#: ../vector/v.label/main.c:90 ../vector/v.label/main.c:95
-#: ../vector/v.label/main.c:170 ../vector/v.label/main.c:183
-msgid "Effects"
-msgstr ""
-#: ../general/g.region/main.c:164
-msgid "Set current region from named region"
-msgstr ""
-#: ../general/g.region/main.c:180
-msgid "Set region to match this 3D raster map (both 2D and 3D values)"
-msgstr ""
-#: ../general/g.region/main.c:243
-msgid "Value for the top edge"
-msgstr ""
-#: ../general/g.region/main.c:252
-msgid "Value for the bottom edge"
-msgstr ""
-#: ../general/g.region/main.c:261
-msgid "Number of rows in the new region"
-msgstr ""
-#: ../general/g.region/main.c:262 ../general/g.region/main.c:271
-#: ../general/g.region/main.c:281 ../general/g.region/main.c:291
-#: ../general/g.region/main.c:300 ../general/g.region/main.c:309
-#: ../general/g.region/main.c:318
-msgid "Resolution"
-msgstr ""
-#: ../general/g.region/main.c:270
-msgid "Number of columns in the new region"
-msgstr ""
-#: ../general/g.region/main.c:280
-msgid "Grid resolution 2D (both north-south and east-west)"
-msgstr ""
-#: ../general/g.region/main.c:290
-msgid "3D grid resolution (north-south, east-west and top-bottom)"
-msgstr ""
-#: ../general/g.region/main.c:299
-msgid "North-south grid resolution 2D"
-msgstr ""
-#: ../general/g.region/main.c:308
-msgid "East-west grid resolution 2D"
-msgstr ""
-#: ../general/g.region/main.c:317
-msgid "Top-bottom grid resolution 3D"
-msgstr ""
-#: ../general/g.region/main.c:327
-msgid "Shrink region until it meets non-NULL data from this raster map"
-msgstr ""
-#: ../general/g.region/main.c:338
-msgid "Adjust region cells to cleanly align with this raster map"
-msgstr ""
-#: ../general/g.region/main.c:349
-msgid "Save current region settings in named region file"
-msgstr ""
-#: ../general/g.region/main.c:408
-#, c-format
-msgid "Region <%s> not found"
-msgstr ""
-#: ../general/g.region/main.c:420
-#, c-format
-msgid "3dview file <%s> not found"
-msgstr ""
-#: ../general/g.region/main.c:425
-#, fuzzy, c-format
-msgid "Unable to open 3dview file <%s> in <%s>"
-msgstr "'%s'. ड्राइवर चालू होत नाही"
-#: ../general/g.region/main.c:431
-#, fuzzy, c-format
-msgid "Unable to read 3dview file <%s> in <%s>"
-#: ../general/g.region/main.c:434
-#, fuzzy, c-format
-msgid "Old 3dview file. Region <%s> not found in <%s>"
-#: ../general/g.region/main.c:492
-#, fuzzy, c-format
-msgid "Unable to read header of 3D raster map <%s@%s>"
-#: ../general/g.region/main.c:518
-#, fuzzy, c-format
-msgid "Unable to open vector map <%s@%s>"
-#: ../general/g.region/main.c:805
-#, fuzzy, c-format
-msgid "Unable to set region <%s>"
-#: ../general/g.region/main.c:811
-msgid "Unable to update current region"
-msgstr ""
-#: ../general/g.region/main.c:819
-msgid "Unable to change default region. The current mapset is not <PERMANENT>."
-msgstr ""
-#: ../general/g.region/main.c:836
-#, fuzzy, c-format
-msgid "Invalid input <%s=%s>"
-#: ../general/g.region/printwindow.c:263 ../general/g.region/printwindow.c:516
-#: ../general/g.region/printwindow.c:647
-msgid "Unable to update lat/long projection parameters"
-msgstr ""
-#: ../general/g.region/printwindow.c:410
-msgid "You are already in Lat/Long. Use the -p flag instead."
-msgstr ""
-#: ../general/g.region/printwindow.c:412
-msgid "You are in a simple XY location, projection to Lat/Lon is not possible. Use the -p flag instead."
-msgstr ""
-#: ../general/g.region/printwindow.c:637
-msgid "WGS84 output not possible as this location does not contain datum transformation parameters. Try running g.setproj."
-msgstr ""
-#: ../general/g.region/printwindow.c:783
-msgid "Lat/Long calculations are not possible from a simple XY system"
-msgstr ""
-#: ../general/g.list/main.c:48
-msgid "Lists available GRASS data base files of the user-specified data type."
-msgstr ""
-#: ../general/g.mkfontcap/main.c:73
-msgid "Generates the font configuration file by scanning various directories for fonts"
-msgstr ""
-#: ../general/g.mkfontcap/main.c:79
-msgid "Overwrite font configuration file if already existing"
-msgstr ""
-#: ../general/g.mkfontcap/main.c:84
-msgid "Write font configuration file to standard output instead of $GISBASE/etc"
-msgstr ""
-#: ../general/g.mkfontcap/main.c:92
-msgid "Comma-separated list of extra directories to scan for Freetype-compatible fonts as well as the defaults (see documentation)"
-msgstr ""
-#: ../general/g.mkfontcap/main.c:109
-#, c-format
-msgid "Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
-msgstr ""
-#: ../general/g.mkfontcap/main.c:121
-msgid "This GRASS installation was compiled without Freetype support, extradirs parameter ignored"
-msgstr ""
-#: ../general/g.mkfontcap/main.c:148
-#, fuzzy, c-format
-msgid "Cannot open %s for writing: %s"
-#: ../general/g.setproj/proj.c:168
-#, c-format
-msgid "Unrecognized 'ask' value in parms.table: %s"
-msgstr ""
-#: ../general/g.setproj/proj.c:178
-#, c-format
-msgid "Unrecognized default value in parms.table: %s"
-msgstr ""
-#: ../general/g.setproj/main.c:81
-msgid "Interactively reset the location's projection settings."
-msgstr ""
-#: ../general/g.setproj/main.c:88
-msgid "You must be in the PERMANENT mapset to run g.setproj"
-msgstr ""
-#: ../general/g.setproj/main.c:101
-msgid "PERMANENT: permission denied"
-msgstr ""
-#: ../general/g.setproj/main.c:105
-msgid "Current region cannot be set"
-msgstr ""
-#: ../general/g.setproj/main.c:108
-msgid "Retrieving and setting region failed"
-msgstr ""
-#: ../general/g.setproj/main.c:135
-msgid "Would you still like to change some of the parameters?"
-msgstr ""
-#: ../general/g.setproj/main.c:137
-msgid "The projection information will not be updated"
-msgstr ""
-#: ../general/g.setproj/main.c:148
-#, c-format
-msgid ""
-"Zone in default geographic region definition: %d\n"
-" is different from zone in PROJ_INFO file: %d"
-msgstr ""
-#: ../general/g.setproj/main.c:158
-msgid "XY-location cannot be projected"
-msgstr ""
-#: ../general/g.setproj/main.c:192
-msgid "Unknown projection"
-msgstr ""
-#: ../general/g.setproj/main.c:198
-#, c-format
-msgid "Projection %s is not specified in the file 'proj-parms.table'"
-msgstr ""
-#: ../general/g.setproj/main.c:205
-msgid "Do you wish to specify a geodetic datum for this location?"
-msgstr ""
-#: ../general/g.setproj/main.c:214
-#, c-format
-msgid "The current datum is %s (%s)"
-msgstr ""
-#: ../general/g.setproj/main.c:217
-msgid "Do you wish to change the datum (or datum transformation parameters)?"
-msgstr ""
-#: ../general/g.setproj/main.c:225
-msgid "The datum information has not been changed"
-msgstr ""
-#: ../general/g.setproj/main.c:288
-#, c-format
-msgid "The current ellipsoid is %s"
-msgstr ""
-#: ../general/g.setproj/main.c:290
-msgid "Do you want to change ellipsoid parameter?"
-msgstr ""
-#: ../general/g.setproj/main.c:294
-msgid "The ellipse information has not been changed"
-msgstr ""
-#: ../general/g.setproj/main.c:311
-#, c-format
-msgid "The radius is currently %f"
-msgstr ""
-#: ../general/g.setproj/main.c:312
-msgid "Do you want to change the radius?"
-msgstr ""
-#: ../general/g.setproj/main.c:314 ../general/g.setproj/main.c:320
-msgid "Enter radius for the sphere in meters"
-msgstr ""
-#: ../general/g.setproj/main.c:336
-msgid "Invalid input ellipsoid"
-msgstr ""
-#: ../general/g.setproj/main.c:447
-#, c-format
-msgid "The UTM zone is now set to %d"
-msgstr ""
-#: ../general/g.setproj/main.c:450
-msgid "Do you want to change the UTM zone?"
-msgstr ""
-#: ../general/g.setproj/main.c:451
-msgid "UTM zone information has not been updated"
-msgstr ""
-#: ../general/g.setproj/main.c:456
-msgid "But if you change zone, all the existing data will be interpreted by projection software. GRASS will not automatically re-project or even change the headers for existing maps."
-msgstr ""
-#: ../general/g.setproj/main.c:461
-msgid "Would you still like to change the UTM zone?"
-msgstr ""
-#: ../general/g.setproj/main.c:497
-#, fuzzy, c-format
-msgid "Error writing PROJ_INFO file <%s>"
-#: ../general/g.setproj/main.c:571
-#, c-format
-msgid "Enter plural form of units [meters]: "
-msgstr ""
-#: ../general/g.setproj/main.c:603
-#, c-format
-msgid "Enter singular for unit: "
-msgstr ""
-#: ../general/g.setproj/main.c:611
-#, c-format
-msgid "Enter conversion factor from %s to meters: "
-msgstr ""
-#: ../general/g.setproj/main.c:636
-#, fuzzy, c-format
-msgid "Error writing into UNITS output file <%s>"
-#: ../general/g.setproj/main.c:643
-#, fuzzy
-msgid "Unable to write to DEFAULT_WIND region file"
-#: ../general/g.setproj/main.c:645
-#, c-format
-msgid ""
-"\n"
-"Projection information has been recorded for this location\n"
-"\n"
-msgstr ""
-#: ../general/g.setproj/main.c:647
-msgid "The geographic region information in WIND is now obsolete"
-msgstr ""
-#: ../general/g.setproj/main.c:648
-msgid "Run g.region -d to update it"
-msgstr ""
-#: ../general/g.setproj/get_stp.c:43
-msgid "This should not happen see your system admin"
-msgstr ""
-#: ../general/g.setproj/get_stp.c:99
-#, fuzzy
-msgid "Unable to open FIPS code file"
-#: ../general/g.setproj/get_stp.c:125
-#, c-format
-msgid "No match of fips state %d county %d"
-msgstr ""
-#: ../general/g.setproj/get_stp.c:179
-#, fuzzy
-msgid "Reading sf key_value temp file"
-#: ../general/g.setproj/get_stp.c:212
-#, fuzzy
-msgid "Invalid State FIPS code"
-#: ../general/g.setproj/get_stp.c:302
-#, fuzzy
-msgid "Reading cf key_value temp file"
-#: ../general/g.setproj/get_stp.c:336
-msgid "Invalid County FIPS code"
-msgstr ""
-#: ../general/g.remove/main.c:41
-#, c-format
-msgid "Raster <%s@%s> is a base map. Remove reclassed map <%s> first."
-msgstr ""
-#: ../general/g.remove/main.c:63 ../general/g.remove/main.c:76
-#, c-format
-msgid "Removing information about reclassed map from <%s@%s> failed"
-msgstr ""
-#: ../general/g.remove/main.c:105
-msgid "Removes data base element files from the user's current mapset."
-msgstr ""
-#: ../general/g.remove/main.c:110
-#, fuzzy
-msgid "Force removal for base raster maps"
-#: ../general/g.pnmcomp/main.c:103
-msgid "Expecting PPM but got PGM"
-msgstr ""
-#: ../general/g.pnmcomp/main.c:108
-msgid "Expecting PGM but got PPM"
-msgstr ""
-#: ../general/g.pnmcomp/main.c:111
-#, c-format
-msgid "Invalid magic number: 'P%c'"
-msgstr ""
-#: ../general/g.pnmcomp/main.c:124 ../general/g.pnmcomp/main.c:141
-msgid "Invalid PGM file"
-msgstr ""
-#: ../general/g.pnmcomp/main.c:246
-msgid "Error writing PPM file"
-msgstr ""
-#: ../general/g.pnmcomp/main.c:263
-msgid "Error writing PGM file"
-msgstr ""
-#: ../general/g.pnmcomp/main.c:285
-#, fuzzy
-msgid "Overlays multiple PPM image files,"
-#: ../general/g.pnmcomp/main.c:292
-#, fuzzy
-msgid "Name of mask files"
-#: ../general/g.pnmcomp/main.c:305
-#, fuzzy
-msgid "Name for output mask file"
-#: ../general/g.ppmtopng/main.c:34
-#, fuzzy, c-format
-msgid "unable to open input file %s"
-#: ../general/g.ppmtopng/main.c:37
-#, fuzzy, c-format
-msgid "invalid input file %s"
-#: ../general/g.ppmtopng/main.c:70 ../general/g.ppmtopng/main.c:74
-#, fuzzy
-msgid "unable to allocate PNG structure"
-#: ../general/g.ppmtopng/main.c:77
-#, fuzzy
-msgid "error writing PNG file"
-#: ../general/g.ppmtopng/main.c:81
-#, fuzzy, c-format
-msgid "unable to open output file %s"
-#: ../general/g.ppmtopng/main.c:126 ../vector/v.net/args.c:76
-#, fuzzy
-msgid "Name of input file"
-#: ../general/g.message/main.c:34
-#, fuzzy
-msgid "scripts"
-#: ../general/g.message/main.c:36
-msgid "Prints a message, warning, progress info, or fatal error in the GRASS way."
-msgstr ""
-#: ../general/g.message/main.c:38
-msgid "This module should be used in scripts for messages served to user."
-msgstr ""
-#: ../general/g.message/main.c:42 ../general/g.message/main.c:47
-#: ../general/g.message/main.c:52 ../general/g.message/main.c:57
-msgid "Type"
-msgstr ""
-#: ../general/g.message/main.c:43
-msgid "Print message as warning"
-msgstr ""
-#: ../general/g.message/main.c:48
-msgid "Print message as fatal error"
-msgstr ""
-#: ../general/g.message/main.c:53
-msgid "Print message as debug message"
-msgstr ""
-#: ../general/g.message/main.c:58
-msgid "Print message as progress info"
-msgstr ""
-#: ../general/g.message/main.c:62 ../general/g.message/main.c:67
-#: ../general/g.message/main.c:81
-msgid "Level"
-msgstr ""
-#: ../general/g.message/main.c:63
-msgid "Print message in all but full quiet mode"
-msgstr ""
-#: ../general/g.message/main.c:68
-msgid "Print message only in verbose mode"
-msgstr ""
-#: ../general/g.message/main.c:75
-#, fuzzy
-msgid "Text of the message to be printed"
-#: ../general/g.message/main.c:84
-msgid "Level to use for debug messages"
-msgstr ""
-#: ../general/g.message/main.c:91
-msgid "Select only one message level"
-msgstr ""
-#: ../general/g.message/main.c:104
-#, fuzzy
-msgid "Unable to parse input message"
-#: ../general/g.dirseps/main.c:37
-msgid "Internal GRASS utility for converting directory separator characters."
-msgstr ""
-#: ../general/g.mapsets/list.c:10
-msgid "Available mapsets:"
-msgstr ""
-#: ../general/g.mapsets/list.c:35
-msgid "Accessible mapsets:"
-msgstr ""
-#: ../general/g.mapsets/main.c:61
-msgid "search path"
-msgstr ""
-#: ../general/g.mapsets/main.c:62
-msgid "Modifies the user's current mapset search path."
-msgstr ""
-#: ../general/g.mapsets/main.c:63
-msgid "Affects the user's access to data existing under the other mapsets in the current location."
-msgstr ""
-#: ../general/g.mapsets/main.c:71
-#, fuzzy
-msgid "Name(s) of existing mapset(s)"
-#: ../general/g.mapsets/main.c:72 ../general/g.mapsets/main.c:81
-#: ../general/g.mapsets/main.c:90
-msgid "Search path"
-msgstr ""
-#: ../general/g.mapsets/main.c:80
-#, fuzzy
-msgid "Name(s) of existing mapset(s) to add to search path"
-#: ../general/g.mapsets/main.c:89
-#, fuzzy
-msgid "Name(s) of existing mapset(s) to remove from search path"
-#: ../general/g.mapsets/main.c:97
-msgid "List all available mapsets in alphabetical order"
-msgstr ""
-#: ../general/g.mapsets/main.c:102
-msgid "Print mapsets in current search path"
-msgstr ""
-#: ../general/g.mapsets/main.c:107
-msgid "Show mapset selection dialog"
-msgstr ""
-#: ../general/g.mapsets/main.c:132 ../general/g.mapsets/main.c:161
-#, fuzzy, c-format
-msgid "Mapset <%s> not found"
-#: ../general/g.mapsets/main.c:163
-#, c-format
-msgid "Mapset <%s> added to search path"
-msgstr ""
-#: ../general/g.mapsets/main.c:189
-#, c-format
-msgid "Mapset <%s> removed from search path"
-msgstr ""
-#: ../general/g.mapsets/main.c:222
-msgid "Cannot open SEARCH_PATH for write"
-msgstr ""
-#: ../general/g.rename/main.c:45
-#, fuzzy
-msgid "rename"
-msgstr "तक्त्याचे नाव"
-#: ../general/g.rename/main.c:47
-msgid "Renames data base element files in the user's current mapset."
-msgstr ""
-#: ../general/g.rename/main.c:53
-#, fuzzy
-msgid "renamed"
-#: ../general/g.rename/main.c:70
-#, fuzzy, c-format
-msgid "%s <%s> not found"
-#: ../general/g.rename/main.c:74
-#, fuzzy, c-format
-msgid "<%s> already exists in mapset <%s>"
-#: ../general/g.rename/main.c:84
-#, c-format
-msgid "%s=%s,%s: files could be the same, no rename possible"
-msgstr ""
-#: ../general/g.rename/main.c:94
-#, fuzzy
-msgid "Renaming reclass maps"
-#: ../general/g.copy/main.c:43
-msgid "copy"
-msgstr ""
-#: ../general/g.copy/main.c:45
-msgid "Copies available data files in the current mapset search path to the user's current mapset."
-msgstr ""
-#: ../general/g.copy/main.c:52
-#, fuzzy
-msgid "copied"
-#: ../general/g.copy/main.c:67
-#, fuzzy, c-format
-msgid "<%s> not found"
-#: ../general/g.copy/main.c:72
-#, c-format
-msgid "%s=%s,%s: files are the same, no copy required"
-msgstr ""
-#: ../general/g.copy/main.c:77
-#, c-format
-msgid "<%s> already exists"
-msgstr ""
-#: ../vector/v.random/main.c:88
-#, fuzzy
-msgid "Generates randomly 2D/3D vector points map."
-#: ../vector/v.random/main.c:96
-#, fuzzy
-msgid "Number of points to be created"
-#: ../vector/v.random/main.c:103
-msgid "Minimum z height (needs -z flag or column name)"
-msgstr ""
-#: ../vector/v.random/main.c:105 ../vector/v.random/main.c:114
-#: ../vector/v.random/main.c:127 ../vector/v.random/main.c:137
-#: ../vector/v.random/main.c:142
-#, fuzzy
-msgid "3D output"
-msgstr "पूर्ण तपशिल"
-#: ../vector/v.random/main.c:112
-msgid "Maximum z height (needs -z flag or column name)"
-msgstr ""
-#: ../vector/v.random/main.c:121
-msgid "The seed to initialize the random generator. If not set the process id is used."
-msgstr ""
-#: ../vector/v.random/main.c:124
-#, fuzzy
-msgid "Name of column for z values"
-#: ../vector/v.random/main.c:126
-#, fuzzy
-msgid "Writes z values to column"
-#: ../vector/v.random/main.c:134
-#, fuzzy
-msgid "Type of column for z values"
-#: ../vector/v.random/main.c:141 ../vector/v.in.ogr/main.c:238
-msgid "Create 3D output"
-msgstr ""
-#: ../vector/v.random/main.c:146
-msgid "Use drand48() function instead of rand()"
-msgstr ""
-#: ../vector/v.random/main.c:150 ../vector/v.edit/args.c:203
-#: ../vector/v.external/args.c:60 ../vector/v.in.dxf/main.c:80
-#: ../vector/v.in.lidar/main.c:224
-msgid "Do not build topology"
-msgstr ""
-#: ../vector/v.random/main.c:163
-#, fuzzy, c-format
-msgid "Number of points must be > 0 (%d given)"
-#: ../vector/v.random/main.c:223
-msgid "Table should contain only two columns"
-msgstr ""
-#: ../vector/v.random/main.c:236
-msgid "You have created unsupported column type. This module supports only INTEGER and DOUBLE PRECISION column types."
-msgstr ""
-#: ../vector/v.random/main.c:272
-#, fuzzy
-msgid "Generating points..."
-#: ../vector/v.net.iso/main.c:71
-msgid "Splits net by cost isolines."
-msgstr ""
-#: ../vector/v.net.iso/main.c:73 ../vector/v.net.centrality/main.c:97
-#: ../vector/v.net.steiner/main.c:346 ../vector/v.net/main.c:46
-#: ../vector/v.net.distance/main.c:62 ../vector/v.net.alloc/main.c:61
-#: ../vector/v.net.bridge/main.c:47 ../vector/v.net.flow/main.c:59
-#: ../vector/v.net.timetable/main.c:261 ../vector/v.net.spanningtree/main.c:47
-#: ../vector/v.net.allpairs/main.c:57 ../vector/v.net.components/main.c:71
-#: ../vector/v.net.salesman/main.c:105 ../vector/v.net.path/main.c:41
-#: ../vector/v.net.connectivity/main.c:54
-msgid "network"
-msgstr ""
-#: ../vector/v.net.iso/main.c:74
-#, fuzzy
-msgid "isolines"
-#: ../vector/v.net.iso/main.c:76
-msgid "Splits net to bands between cost isolines (direction from centre). Centre node must be opened (costs >= 0). Costs of centre node are used in calculation."
-msgstr ""
-#: ../vector/v.net.iso/main.c:100 ../vector/v.net.centrality/main.c:129
-#: ../vector/v.net.distance/main.c:119 ../vector/v.net.alloc/main.c:93
-#: ../vector/v.net.bridge/main.c:72 ../vector/v.net.flow/main.c:90
-#: ../vector/v.net.timetable/main.c:288 ../vector/v.net.spanningtree/main.c:72
-#: ../vector/v.net.allpairs/main.c:87 ../vector/v.net.components/main.c:95
-#: ../vector/v.net.salesman/main.c:135 ../vector/v.net.connectivity/main.c:78
-msgid "Arc forward/both direction(s) cost column (number)"
-msgstr ""
-#: ../vector/v.net.iso/main.c:104 ../vector/v.net.centrality/main.c:135
-#: ../vector/v.net.distance/main.c:125 ../vector/v.net.alloc/main.c:99
-#: ../vector/v.net.bridge/main.c:78 ../vector/v.net.flow/main.c:96
-#: ../vector/v.net.timetable/main.c:295 ../vector/v.net.allpairs/main.c:93
-#: ../vector/v.net.components/main.c:101
-#: ../vector/v.net.connectivity/main.c:84
-msgid "Arc backward direction cost column (number)"
-msgstr ""
-#: ../vector/v.net.iso/main.c:108 ../vector/v.net.centrality/main.c:142
-#: ../vector/v.net.distance/main.c:131 ../vector/v.net.alloc/main.c:105
-#: ../vector/v.net.bridge/main.c:85 ../vector/v.net.flow/main.c:102
-#: ../vector/v.net.timetable/main.c:302 ../vector/v.net.spanningtree/main.c:78
-#: ../vector/v.net.allpairs/main.c:100 ../vector/v.net.components/main.c:108
-#: ../vector/v.net.connectivity/main.c:92
-msgid "Node cost column (number)"
-msgstr ""
-#: ../vector/v.net.iso/main.c:114
-msgid "Categories of centres (points on nodes) to which net will be allocated. Layer for this categories is given by nlayer option."
-msgstr ""
-#: ../vector/v.net.iso/main.c:123
-msgid "Costs for isolines"
-msgstr ""
-#: ../vector/v.net.iso/main.c:160
-#, c-format
-msgid "Wrong iso cost: %f"
-msgstr ""
-#: ../vector/v.net.iso/main.c:163
-#, c-format
-msgid "Iso cost: %f less than previous"
-msgstr ""
-#: ../vector/v.net.iso/main.c:165
-#, c-format
-msgid "Iso cost %d: %f"
-msgstr ""
-#: ../vector/v.net.iso/main.c:172
-msgid "Not enough costs, everything reachable falls to first band"
-msgstr ""
-#: ../vector/v.net.iso/main.c:198 ../vector/v.net.steiner/main.c:441
-#: ../vector/v.net.alloc/main.c:163 ../vector/v.net.salesman/main.c:208
-#, fuzzy
-msgid "Point is not connected to the network"
-#: ../vector/v.net.iso/main.c:206
-msgid "Centre at closed node (costs = -1) ignored"
-msgstr ""
-#: ../vector/v.net.iso/main.c:224
-#, c-format
-msgid "Number of centres: %d (nlayer %d)"
-msgstr ""
-#: ../vector/v.net.iso/main.c:227
-msgid "Not enough centres for selected nlayer. Nothing will be allocated."
-msgstr ""
-#: ../vector/v.net.iso/main.c:247
-#, fuzzy, c-format
-msgid "Calculating costs from centre %d..."
-#: ../vector/v.net.iso/main.c:508 ../vector/v.net.alloc/main.c:343
-#: ../vector/v.net.alloc/main.c:354
-#, fuzzy
-msgid "Cannot get line segment, segment out of line"
-#: ../vector/v.net.centrality/main.c:98
-#, fuzzy
-msgid "centrality measures"
-#: ../vector/v.net.centrality/main.c:100
-msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
-msgstr ""
-#: ../vector/v.net.centrality/main.c:110 ../vector/v.net.centrality/main.c:116
-#: ../vector/v.net.centrality/main.c:130 ../vector/v.net.centrality/main.c:136
-#: ../vector/v.net.centrality/main.c:143 ../vector/v.net.distance/main.c:78
-#: ../vector/v.net.distance/main.c:84 ../vector/v.net.distance/main.c:120
-#: ../vector/v.net.distance/main.c:126 ../vector/v.net.distance/main.c:132
-#: ../vector/v.net.bridge/main.c:60 ../vector/v.net.bridge/main.c:66
-#: ../vector/v.net.bridge/main.c:73 ../vector/v.net.bridge/main.c:79
-#: ../vector/v.net.bridge/main.c:86 ../vector/v.net.flow/main.c:71
-#: ../vector/v.net.flow/main.c:77 ../vector/v.net.flow/main.c:91
-#: ../vector/v.net.flow/main.c:97 ../vector/v.net.flow/main.c:103
-#: ../vector/v.net.timetable/main.c:275 ../vector/v.net.timetable/main.c:281
-#: ../vector/v.net.timetable/main.c:289 ../vector/v.net.timetable/main.c:296
-#: ../vector/v.net.timetable/main.c:303 ../vector/v.net.spanningtree/main.c:60
-#: ../vector/v.net.spanningtree/main.c:66
-#: ../vector/v.net.spanningtree/main.c:73
-#: ../vector/v.net.spanningtree/main.c:79 ../vector/v.net.allpairs/main.c:88
-#: ../vector/v.net.allpairs/main.c:94 ../vector/v.net.allpairs/main.c:101
-#: ../vector/v.net.components/main.c:83 ../vector/v.net.components/main.c:89
-#: ../vector/v.net.components/main.c:96 ../vector/v.net.components/main.c:102
-#: ../vector/v.net.components/main.c:109
-#: ../vector/v.net.connectivity/main.c:66
-#: ../vector/v.net.connectivity/main.c:72
-#: ../vector/v.net.connectivity/main.c:79
-#: ../vector/v.net.connectivity/main.c:85
-#: ../vector/v.net.connectivity/main.c:93
-msgid "Cost"
-msgstr ""
-#: ../vector/v.net.centrality/main.c:148
-#, fuzzy
-msgid "Name of degree centrality column"
-#: ../vector/v.net.centrality/main.c:149 ../vector/v.net.centrality/main.c:155
-#: ../vector/v.net.centrality/main.c:161 ../vector/v.net.centrality/main.c:167
-msgid "Columns"
-msgstr ""
-#: ../vector/v.net.centrality/main.c:154
-#, fuzzy
-msgid "Name of closeness centrality column"
-#: ../vector/v.net.centrality/main.c:160
-#, fuzzy
-msgid "Name of betweenness centrality column"
-#: ../vector/v.net.centrality/main.c:166
-#, fuzzy
-msgid "Name of eigenvector centrality column"
-#: ../vector/v.net.centrality/main.c:175
-msgid "Maximum number of iterations to compute eigenvector centrality"
-msgstr ""
-#: ../vector/v.net.centrality/main.c:183
-msgid "Cummulative error tolerance for eigenvector centrality"
-msgstr ""
-#: ../vector/v.net.centrality/main.c:192 ../vector/v.net.components/main.c:125
-#, fuzzy
-msgid "Add points on nodes"
-#: ../vector/v.net.centrality/main.c:267 ../vector/v.net.distance/main.c:229
-#: ../vector/v.db.connect/main.c:334 ../vector/v.sample/main.c:192
-#: ../vector/v.net.flow/main.c:184 ../vector/v.net.timetable/main.c:107
-#: ../vector/v.net.components/main.c:187 ../vector/v.net.path/path.c:113
-msgid "Cannot create index"
-msgstr ""
-#: ../vector/v.net.centrality/main.c:271 ../vector/v.net.distance/main.c:233
-#: ../vector/v.net.flow/main.c:188 ../vector/v.net.timetable/main.c:112
-#: ../vector/v.net.allpairs/main.c:180 ../vector/v.net.components/main.c:191
-#: ../vector/v.net.path/path.c:117
-#, fuzzy, c-format
-msgid "Cannot grant privileges on table <%s>"
-#: ../vector/v.net.centrality/main.c:316
-#, fuzzy
-msgid "Computing degree centrality measure"
-#: ../vector/v.net.centrality/main.c:320
-msgid "Computing betweenness and/or closeness centrality measure"
-msgstr ""
-#: ../vector/v.net.centrality/main.c:327
-#, fuzzy
-msgid "Computing eigenvector centrality measure"
-#: ../vector/v.net.centrality/main.c:334 ../vector/v.net.allpairs/main.c:237
-#, fuzzy
-msgid "Writing data into the table..."
-#: ../vector/v.type/main.c:41
-msgid "Changes type of vector features."
-msgstr ""
-#: ../vector/v.type/main.c:53
-msgid "Feature type to convert from"
-msgstr ""
-#: ../vector/v.type/main.c:60
-msgid "Feature type to convert to"
-msgstr ""
-#: ../vector/v.type/main.c:115
-msgid "Incompatible types"
-msgstr ""
-#: ../vector/v.type/main.c:148 ../vector/v.net/main.c:151
-#: ../vector/v.proj/main.c:415 ../vector/v.kcv/main.c:146
-#: ../vector/v.build.polylines/main.c:225 ../vector/v.category/main.c:707
-#: ../vector/v.transform/main.c:279 ../vector/v.rectify/main.c:248
-#, fuzzy
-msgid "Failed to copy attribute table to output map"
-#: ../vector/v.colors.out/make_colors.c:26
-#: ../vector/v.colors.out/scan_cats.c:22 ../vector/v.colors/main.c:229
-#: ../vector/v.surf.rst/main.c:532
-#, fuzzy, c-format
-msgid "Layer <%s> not found"
-#: ../vector/v.colors.out/make_colors.c:30 ../vector/v.extract/main.c:251
-#: ../vector/v.db.connect/main.c:211 ../vector/v.distance/main.c:388
-#: ../vector/v.info/print.c:138 ../vector/v.to.3d/trans3.c:49
-#: ../vector/v.to.3d/trans2.c:47 ../vector/v.db.select/main.c:142
-#: ../vector/v.to.rast3/main.c:78 ../vector/v.to.rast/vect2rast.c:48
-#, c-format
-msgid "Database connection not defined for layer <%s>"
-msgstr ""
-#: ../vector/v.colors.out/make_colors.c:40 ../vector/v.colors/scan_attr.c:36
-#: ../vector/v.distance/main.c:406 ../vector/v.distance/main.c:439
-#: ../vector/v.reclass/main.c:141 ../vector/v.vect.stats/main.c:396
-#: ../vector/v.to.3d/trans3.c:64 ../vector/v.to.3d/trans2.c:62
-#: ../db/drivers/ogr/execute.c:69
-#, fuzzy, c-format
-msgid "Column <%s> not found in table <%s>"
-#: ../vector/v.colors.out/make_colors.c:43 ../vector/v.colors/scan_attr.c:39
-#, fuzzy, c-format
-msgid "Column <%s> is not numeric"
-#: ../vector/v.colors.out/make_colors.c:50 ../vector/v.colors/scan_attr.c:46
-msgid "No data selected"
-msgstr ""
-#: ../vector/v.colors.out/scan_cats.c:26 ../vector/v.voronoi/main.c:167
-#: ../vector/v.colors/scan_cats.c:19 ../vector/v.to.db/query.c:23
-#: ../vector/v.to.db/lines.c:75 ../vector/v.to.rast/do_lines.c:35
-#, fuzzy
-msgid "Reading features..."
-#: ../vector/v.colors.out/main.c:53
-#, fuzzy
-msgid "Exports the color table associated with a vector map."
-#: ../vector/v.colors.out/main.c:66
-#, fuzzy
-msgid "Name of attribute (numeric) column to which refer color rules"
-#: ../vector/v.colors.out/main.c:67
-msgid "If not given color rules are refered to categories"
-msgstr ""
-#: ../vector/v.colors.out/main.c:85
-#, fuzzy, c-format
-msgid "Unable to read color table for vector map <%s>"
-#: ../vector/v.colors.out/main.c:88
-#, fuzzy, c-format
-msgid "No color table defined for vector map <%s>"
-#: ../vector/v.voronoi/main.c:122 ../vector/v.delaunay/main.c:87
-#, fuzzy
-msgid "triangulation"
-#: ../vector/v.voronoi/main.c:123
-msgid "Creates a Voronoi diagram in current region from an input vector map containing points or centroids."
-msgstr ""
-#: ../vector/v.voronoi/main.c:127 ../vector/v.sample/main.c:82
-#, fuzzy
-msgid "Name of input vector point map"
-#: ../vector/v.voronoi/main.c:136
-msgid "Output tessellation as a graph (lines), not areas"
-msgstr ""
-#: ../vector/v.voronoi/main.c:182
-msgid "Processing Voronoi triangulation..."
-msgstr ""
-#: ../vector/v.voronoi/main.c:267 ../vector/v.in.db/main.c:176
-#, fuzzy
-msgid "Writing features..."
-#: ../vector/v.voronoi/main.c:328 ../vector/v.extract/copy_tab.c:53
-#: ../vector/v.select/copy_tabs.c:17 ../vector/v.generalize/misc.c:126
-#, fuzzy
-msgid "Writing attributes..."
-#: ../vector/v.voronoi/main.c:340
-#, fuzzy
-msgid "No table"
-#: ../vector/v.voronoi/main.c:355
-msgid "Cannot copy table"
-msgstr ""
-#: ../vector/v.voronoi/main.c:413
-msgid "Output needs topological cleaning"
-msgstr ""
-#: ../vector/v.voronoi/main.c:445
-#, fuzzy
-msgid "Removing incorrect boundaries from output"
-#: ../vector/v.voronoi/sw_main.c:166 ../vector/v.distance/main.c:284
-#, fuzzy, c-format
-msgid "No points/centroids found in <%s>"
-#: ../vector/v.net.steiner/main.c:58
-#, c-format
-msgid "Init costs from node %d"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:347
-msgid "steiner tree"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:349
-msgid "Create Steiner tree for the network and given terminals"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:351
-msgid "Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:371
-msgid "Node layer (used for terminals)"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:377
-msgid "Arcs' cost column (for both directions)"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:383
-msgid "Categories of points on terminals (layer is specified by nlayer)"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:391
-#, fuzzy
-msgid "Number of steiner points (-1 for all possible)"
-#: ../vector/v.net.steiner/main.c:455
-msgid "Not enough terminals (< 2)"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:461
-msgid "Requested number of Steiner points > than possible"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:513
-#, c-format
-msgid "Terminal at node [%d] cannot be connected to terminal at node [%d]"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:529
-#, c-format
-msgid "[%d] (not reachable) nodes removed from list of Steiner point candidates"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:534
-#, c-format
-msgid "MST costs = %f"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:540
-#, c-format
-msgid "Search for [%d]. Steiner point"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:561
-#, c-format
-msgid "Steiner point at node [%d] was added to terminals (MST costs = %f)"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:573
-msgid "No Steiner point found -> leaving cycle"
-msgstr ""
-#: ../vector/v.overlay/area_area.c:39 ../vector/v.overlay/line_area.c:69
-#, fuzzy
-msgid "Breaking lines..."
-#: ../vector/v.overlay/area_area.c:43 ../vector/v.in.ogr/main.c:1035
-#: ../vector/v.in.ogr/main.c:1049 ../vector/v.delaunay/main.c:143
-#: ../vector/v.buffer/main.c:625 ../vector/v.buffer/main.c:632
-#, fuzzy
-msgid "Removing duplicates..."
-#: ../vector/v.overlay/area_area.c:46 ../vector/v.in.ogr/main.c:1053
-#, fuzzy
-msgid "Cleaning boundaries at nodes..."
-#: ../vector/v.overlay/area_area.c:55 ../vector/v.buffer/main.c:650
-#, fuzzy
-msgid "Attaching islands..."
-#: ../vector/v.overlay/area_area.c:68 ../vector/v.buffer/main.c:670
-#: ../vector/v.buffer/main.c:762
-msgid "Cannot calculate area centroid"
-msgstr ""
-#: ../vector/v.overlay/area_area.c:78
-#, fuzzy, c-format
-msgid "Querying vector map <%s>..."
-#: ../vector/v.overlay/area_area.c:103 ../vector/v.overlay/area_area.c:183
-#: ../vector/v.overlay/area_area.c:211 ../vector/v.overlay/line_area.c:161
-#: ../vector/v.overlay/line_area.c:189
-#, fuzzy
-msgid "Attribute not found"
-#: ../vector/v.overlay/area_area.c:114 ../vector/v.in.ogr/main.c:1138
-#, fuzzy
-msgid "Writing centroids..."
-#: ../vector/v.overlay/area_area.c:264
-#, fuzzy
-msgid "Attaching centroids..."
-#: ../vector/v.overlay/main.c:60
-#, fuzzy
-msgid "Overlays two vector maps."
-#: ../vector/v.overlay/main.c:63 ../vector/v.select/args.c:10
-#, fuzzy
-msgid "Name of input vector map (A)"
-#: ../vector/v.overlay/main.c:67
-#, fuzzy
-msgid "Layer number or name (vector map A)"
-#: ../vector/v.overlay/main.c:71 ../vector/v.select/args.c:19
-#, fuzzy
-msgid "Feature type (vector map A)"
-#: ../vector/v.overlay/main.c:77 ../vector/v.select/args.c:24
-#, fuzzy
-msgid "Name of input vector map (B)"
-#: ../vector/v.overlay/main.c:81
-#, fuzzy
-msgid "Layer number or name (vector map B)"
-#: ../vector/v.overlay/main.c:85 ../vector/v.select/args.c:33
-#, fuzzy
-msgid "Feature type (vector map B)"
-#: ../vector/v.overlay/main.c:96
-#, fuzzy
-msgid "Operator defines features written to output vector map"
-#: ../vector/v.overlay/main.c:99
-msgid "Feature is written to output if the result of operation 'ainput operator binput' is true. Input feature is considered to be true, if category of given layer is defined."
-msgstr ""
-#: ../vector/v.overlay/main.c:104
-msgid "and;also known as 'intersection' in GIS;or;also known as 'union' in GIS (only for atype=area);not;features from ainput not overlayed by features from binput;xor;features from either ainput or binput but not those from ainput overlayed by binput (only for atype=area)"
-msgstr ""
-#: ../vector/v.overlay/main.c:117
-msgid "Output layer for new category, ainput and binput"
-msgstr ""
-#: ../vector/v.overlay/main.c:118
-msgid "If 0 or not given, the category is not written"
-msgstr ""
-#: ../vector/v.overlay/main.c:123 ../vector/v.in.ogr/main.c:243
-#: ../vector/v.select/args.c:79 ../vector/v.to.points/main.c:215
-#: ../vector/v.in.lidar/main.c:197
-msgid "Do not create attribute table"
-msgstr ""
-#: ../vector/v.overlay/main.c:154
-#, c-format
-msgid "Operator '%s' is not supported for type line"
-msgstr ""
-#: ../vector/v.overlay/main.c:205
-#, fuzzy, c-format
-msgid "Copying vector features from <%s>..."
-#: ../vector/v.overlay/main.c:232
-#, c-format
-msgid "No %s features found in vector map <%s>. Verify '%s' parameter."
-msgstr ""
-#: ../vector/v.overlay/main.c:267
-#, fuzzy
-msgid "Collecting input attributes..."
-#: ../vector/v.overlay/main.c:302 ../vector/v.label/main.c:318
-#: ../vector/v.label.sa/labels.c:160
-#, fuzzy
-msgid "Unable to select attributes"
-#: ../vector/v.overlay/main.c:353
-#, fuzzy, c-format
-msgid "Unknown column type '%s' of column '%s'"
-#: ../vector/v.overlay/main.c:366 ../vector/v.lrs/v.lrs.label/main.c:348
-#: ../vector/v.out.svg/main.c:370 ../vector/v.out.ogr/attrb.c:46
-#, fuzzy
-msgid "Unable to fetch data from table"
-#: ../vector/v.overlay/main.c:418
-#, fuzzy, c-format
-msgid "Unknown column type '%s' of column '%s', values lost"
-#: ../vector/v.overlay/main.c:483
-msgid "Building partial topology..."
-msgstr ""
-#: ../vector/v.overlay/main.c:495
-#, fuzzy
-msgid "Rebuilding topology..."
-#: ../vector/v.kernel/main.c:68
-#, c-format
-msgid "\tScore Value=%f\tsmoothing parameter (standard deviation)=%f"
-msgstr ""
-#: ../vector/v.kernel/main.c:107
-msgid "kernel density"
-msgstr ""
-#: ../vector/v.kernel/main.c:109
-msgid "Generates a raster density map from vector point data using a moving kernel or optionally generates a vector density map on a vector network."
-msgstr ""
-#: ../vector/v.kernel/main.c:113
-msgid "Input vector with training points"
-msgstr ""
-#: ../vector/v.kernel/main.c:117
-msgid "Input network vector map"
-msgstr ""
-#: ../vector/v.kernel/main.c:125
-#, fuzzy
-msgid "Output raster/vector map"
-#: ../vector/v.kernel/main.c:131
-msgid "Standard deviation in map units"
-msgstr ""
-#: ../vector/v.kernel/main.c:137
-msgid "Discretization error in map units"
-msgstr ""
-#: ../vector/v.kernel/main.c:144
-msgid "Maximum length of segment on network"
-msgstr ""
-#: ../vector/v.kernel/main.c:151
-msgid "Maximum distance from point to network"
-msgstr ""
-#: ../vector/v.kernel/main.c:158
-msgid "Multiply the density result by this number"
-msgstr ""
-#: ../vector/v.kernel/main.c:165
-#, fuzzy
-msgid "Node method"
-#: ../vector/v.kernel/main.c:169
-msgid "none;No method applied at nodes with more than 2 arcs;split;Equal split (Okabe 2009) applied at nodes;"
-msgstr ""
-#: ../vector/v.kernel/main.c:176
-msgid "Kernel function"
-msgstr ""
-#: ../vector/v.kernel/main.c:184
-msgid "Try to calculate an optimal standard deviation with 'stddeviation' taken as maximum (experimental)"
-msgstr ""
-#: ../vector/v.kernel/main.c:189
-msgid "Only calculate optimal standard deviation and exit (no map is written)"
-msgstr ""
-#: ../vector/v.kernel/main.c:194
-msgid "In network mode, normalize values by sum of density multiplied by length of each segment. Integral over the output map then gives 1.0 * mult"
-msgstr ""
-#: ../vector/v.kernel/main.c:199
-msgid "In network mode, multiply the result by number of input points."
-msgstr ""
-#: ../vector/v.kernel/main.c:216
-#, fuzzy
-msgid "Unknown node method"
-#: ../vector/v.kernel/main.c:234
-#, fuzzy
-msgid "Unknown kernel function"
-#: ../vector/v.kernel/main.c:240
-msgid "Optimal standard deviation calculation is supported only for node method 'none' and kernel function 'gaussian'."
-msgstr ""
-#: ../vector/v.kernel/main.c:244
-msgid "Optimal standard deviation calculation is supported only for kernel function 'gaussian'."
-msgstr ""
-#: ../vector/v.kernel/main.c:301
-#, c-format
-msgid "%d points outside threshold"
-msgstr ""
-#: ../vector/v.kernel/main.c:323
-#, c-format
-msgid "Automatic choice of smoothing parameter (standard deviation), maximum possible value of standard deviation is set to %f"
-msgstr ""
-#: ../vector/v.kernel/main.c:330
-#, c-format
-msgid "Using maximum distance between points: %f"
-msgstr ""
-#: ../vector/v.kernel/main.c:344
-#, c-format
-msgid "Number of input points: %d."
-msgstr ""
-#: ../vector/v.kernel/main.c:345
-#, c-format
-msgid "%d distances read from the map."
-msgstr ""
-#: ../vector/v.kernel/main.c:348
-#, c-format
-msgid "Distances between all points are beyond %e (4 * standard deviation), unable to calculate optimal value."
-msgstr ""
-#: ../vector/v.kernel/main.c:359
-#, c-format
-msgid "Optimal smoothing parameter (standard deviation): %f."
-msgstr ""
-#: ../vector/v.kernel/main.c:386
-#, c-format
-msgid ""
-"\n"
-"Writing output vector map using smooth parameter=%f."
-msgstr ""
-#: ../vector/v.kernel/main.c:388 ../vector/v.kernel/main.c:495
-#, c-format
-msgid ""
-"\n"
-"Normalising factor=%f."
-msgstr ""
-#: ../vector/v.kernel/main.c:493
-#, c-format
-msgid ""
-"\n"
-"Writing output raster map using smooth parameter=%f."
-msgstr ""
-#: ../vector/v.kernel/main.c:527
-#, c-format
-msgid "Maximum value in output: %e."
-msgstr ""
-#: ../vector/v.kernel/function.c:220
-msgid "Dimension > 2 supported only by gaussian function"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:123
-#, fuzzy
-msgid "Converts vector data into a GRASS vector map using OGR library."
-#: ../vector/v.in.ogr/main.c:129
-#, fuzzy
-msgid "OGR datasource name"
-#: ../vector/v.in.ogr/main.c:130
-msgid ""
-"Examples:\n"
-"\t\tESRI Shapefile: directory containing shapefiles\n"
-"\t\tMapInfo File: directory containing mapinfo files"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:140
-msgid "OGR layer name. If not given, all available layers are imported"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:142
-msgid ""
-"Examples:\n"
-"\t\tESRI Shapefile: shapefile name\n"
-"\t\tMapInfo File: mapinfo file name"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:156 ../vector/v.in.lidar/main.c:169
-msgid "Import subregion only"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:159 ../vector/v.in.lidar/main.c:172
-msgid "Format: xmin,ymin,xmax,ymax - usually W,S,E,N"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:170
-msgid "Minimum size of area to be imported (square units)"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:172
-msgid "Smaller areas and islands are ignored. Should be greater than snap^2"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:178
-msgid "Optionally change default input type"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:180
-msgid "point;import area centroids as points;line;import area boundaries as lines;boundary;import lines as area boundaries;centroid;import points as centroids"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:191
-msgid "Snapping threshold for boundaries"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:192
-msgid "'-1' for no snap"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:207
-msgid "List of column names to be used instead of original names, first is used for category column"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:213 ../vector/v.external/args.c:47
-msgid "List available OGR layers in data source and exit"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:219
-msgid "List available OGR layers including feature types in data source and exit"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:233
-msgid "Do not clean polygons (not recommended)"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:254 ../vector/v.in.lidar/main.c:208
-#, fuzzy
-msgid "Limit import to the current region"
-#: ../vector/v.in.ogr/main.c:266
-msgid "Change column names to lowercase characters"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:272
-msgid "Create the location specified by the \"location\" parameter and exit. Do not import the vector data."
-msgstr ""
-#: ../vector/v.in.ogr/main.c:291
-msgid "Available OGR Drivers:"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:331
-#, fuzzy, c-format
-msgid "Unable to open data source <%s>"
-#: ../vector/v.in.ogr/main.c:339 ../vector/v.external/list.c:43
-#, c-format
-msgid "Data source <%s> (format '%s') contains %d layers:"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:381 ../vector/v.external/main.c:81
-#, fuzzy, c-format
-msgid "Layer <%s> not available"
-#: ../vector/v.in.ogr/main.c:397
-#, fuzzy
-msgid "No OGR layers available"
-#: ../vector/v.in.ogr/main.c:399
-#, fuzzy, c-format
-msgid "All available OGR layers will be imported into vector map <%s>"
-#: ../vector/v.in.ogr/main.c:404 ../vector/v.edit/main.c:92
-#: ../vector/v.in.lidar/main.c:478
-#, fuzzy, c-format
-msgid "Vector map <%s> already exists"
-#: ../vector/v.in.ogr/main.c:413 ../vector/v.in.lidar/main.c:284
-msgid "Select either the current region flag or the spatial option, not both"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:441 ../vector/v.in.lidar/main.c:312
-msgid "4 parameters required for 'spatial' parameter"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:667
-#, fuzzy, c-format
-msgid "Counting polygons for %d features (OGR layer <%s>)..."
-#: ../vector/v.in.ogr/main.c:687
-#, c-format
-msgid "Boundary splitting distance in map units: %G"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:700
-#, fuzzy, c-format
-msgid "Using temporary vector <%s>"
-#: ../vector/v.in.ogr/main.c:778
-#, c-format
-msgid "Column name changed: '%s' -> '%s'"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:802
-#, c-format
-msgid "Writing column <%s> with fixed length %d chars (may be truncated)"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:825
-#, c-format
-msgid "Width for column %s set to 255 (was not specified by OGR), some strings may be truncated!"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:837
-#, c-format
-msgid "Writing column %s with fixed length %d chars (may be truncated)"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:841
-#, c-format
-msgid "Column type not supported (%s)"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:856 ../vector/v.in.lidar/main.c:591
-#, fuzzy, c-format
-msgid "Unable open database <%s> by driver <%s>"
-#: ../vector/v.in.ogr/main.c:888
-#, fuzzy, c-format
-msgid "Importing %d features (OGR layer <%s>)..."
-#: ../vector/v.in.ogr/main.c:984
-#, c-format
-msgid "%d %s without geometry"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1012
-msgid "Cleaning polygons, result is not guaranteed!"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1016
-#, fuzzy, c-format
-msgid "Snapping boundaries (threshold = %.3e)..."
-#: ../vector/v.in.ogr/main.c:1030 ../vector/v.buffer/main.c:622
-#, fuzzy
-msgid "Breaking polygons..."
-#: ../vector/v.in.ogr/main.c:1045 ../vector/v.buffer/main.c:629
-#, fuzzy
-msgid "Breaking boundaries..."
-#: ../vector/v.in.ogr/main.c:1060
-#, fuzzy
-msgid "Merging boundaries..."
-#: ../vector/v.in.ogr/main.c:1065
-#, fuzzy
-msgid "Changing boundary dangles to lines..."
-#: ../vector/v.in.ogr/main.c:1069
-#, fuzzy
-msgid "Removing dangles..."
-#: ../vector/v.in.ogr/main.c:1075
-#, fuzzy
-msgid "Changing boundary bridges to lines..."
-#: ../vector/v.in.ogr/main.c:1079
-#, fuzzy
-msgid "Removing bridges..."
-#: ../vector/v.in.ogr/main.c:1098 ../vector/v.delaunay/main.c:171
-#: ../vector/v.category/main.c:315
-#, fuzzy
-msgid "Unable to calculate area centroid"
-#: ../vector/v.in.ogr/main.c:1114
-#, fuzzy, c-format
-msgid "Finding centroids for OGR layer <%s>..."
-#: ../vector/v.in.ogr/main.c:1181
-#, c-format
-msgid "%d areas represent more (overlapping) features, because polygons overlap in input layer(s). Such areas are linked to more than 1 row in attribute table. The number of features for those areas is stored as category in layer %d"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1191
-#, c-format
-msgid "%d input polygons\n"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1192
-#, c-format
-msgid "%d input polygons"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1195
-#, fuzzy, c-format
-msgid "Total area: %G (%d areas)\n"
-#: ../vector/v.in.ogr/main.c:1196
-#, fuzzy, c-format
-msgid "Total area: %G (%d areas)"
-#: ../vector/v.in.ogr/main.c:1199
-#, c-format
-msgid "Overlapping area: %G (%d areas)\n"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1201
-#, c-format
-msgid "Overlapping area: %G (%d areas)"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1205
-#, fuzzy, c-format
-msgid "Area without category: %G (%d areas)\n"
-#: ../vector/v.in.ogr/main.c:1207
-#, fuzzy, c-format
-msgid "Area without category: %G (%d areas)"
-#: ../vector/v.in.ogr/main.c:1264
-msgid "Input data contains 3D features. Created vector is 2D only, use -z flag to import 3D vector."
-msgstr ""
-#: ../vector/v.in.ogr/geom.c:195 ../vector/v.in.ogr/geom.c:216
-#, fuzzy
-msgid "Unable to read part of geometry"
-#: ../vector/v.in.ogr/geom.c:256 ../vector/v.in.ogr/geom.c:269
-#: ../vector/v.in.ogr/geom.c:297 ../vector/v.in.ogr/geom.c:343
-msgid "Skipping empty geometry feature"
-msgstr ""
-#: ../vector/v.in.ogr/geom.c:313
-#, c-format
-msgid "Degenerate polygon (%d vertices)"
-msgstr ""
-#: ../vector/v.in.ogr/geom.c:356
-#, c-format
-msgid "Degenerate island ([%d] vertices)"
-msgstr ""
-#: ../vector/v.in.ogr/geom.c:390
-#, fuzzy
-msgid "Unable calculate centroid"
-#: ../vector/v.in.ogr/geom.c:421
-msgid "No centroid written for polygon with 0 vertices"
-msgstr ""
-#: ../vector/v.in.ogr/geom.c:442
-#, fuzzy
-msgid "Unable to write part of geometry"
-#: ../vector/v.in.ogr/geom.c:448
-msgid "Unknown geometry type"
-msgstr ""
-#: ../vector/v.net/args.c:12
-#, fuzzy
-msgid "Name of input vector line map (arcs)"
-#: ../vector/v.net/args.c:13
-msgid "Required for operation 'nodes', 'connect', 'report' and 'nreport'"
-msgstr ""
-#: ../vector/v.net/args.c:15 ../vector/v.net/args.c:56
-msgid "Arcs"
-msgstr ""
-#: ../vector/v.net/args.c:19
-#, fuzzy
-msgid "Name of input vector point map (nodes)"
-#: ../vector/v.net/args.c:21
-msgid "Required for operation 'connect' and 'arcs'"
-msgstr ""
-#: ../vector/v.net/args.c:23 ../vector/v.net/args.c:63
-#: ../vector/v.net/args.c:85
-msgid "Nodes"
-msgstr ""
-#: ../vector/v.net/args.c:34
-#: ../locale/scriptstrings/g.extension_to_translate.c:7
-msgid "Operation to be performed"
-msgstr ""
-#: ../vector/v.net/args.c:36
-msgid "nodes;new point is placed on each node (line end) if doesn't exist;connect;connect still unconnected points to vector network by inserting new line(s);arcs;new line is created from start point to end point;report;print to standard output {line_category start_point_category end_point_category};nreport;print to standard output {point_category line_category[,line_category...]}"
-msgstr ""
-#: ../vector/v.net/args.c:72
-msgid "Required for operation 'connect'. Connect points in given threshold."
-msgstr ""
-#: ../vector/v.net/args.c:78
-msgid "Required for operation 'arcs'. '-' for standard input."
-msgstr ""
-#: ../vector/v.net/args.c:83
-msgid "Assign unique categories to new points"
-msgstr ""
-#: ../vector/v.net/args.c:84
-msgid "For operation 'nodes'"
-msgstr ""
-#: ../vector/v.net/args.c:106
-#, fuzzy
-msgid "Unknown operation"
-#: ../vector/v.net/args.c:133
-msgid "Threshold value must be >= 0"
-msgstr ""
-#: ../vector/v.net/connect.c:64
-#, fuzzy
-msgid "Failed to find intersection segment"
-#: ../vector/v.net/main.c:47
-#, fuzzy
-msgid "maintenance"
-#: ../vector/v.net/main.c:48
-msgid "Performs network maintenance."
-msgstr ""
-#: ../vector/v.net/main.c:119
-#, fuzzy, c-format
-msgid "Unable to open vector map <%s> at topology level %d"
-#: ../vector/v.net/main.c:135
-#, fuzzy, c-format
-msgid "%d new points (nodes) written to output."
-#: ../vector/v.net/main.c:145
-#, fuzzy, c-format
-msgid "%d lines (arcs) written to output."
-#: ../vector/v.net/main.c:149 ../vector/v.transform/main.c:277
-#: ../vector/v.to.3d/main.c:98 ../vector/v.to.3d/main.c:128
-#: ../vector/v.in.db/main.c:215
-#, fuzzy
-msgid "Copying attributes..."
-#: ../vector/v.net/report.c:29
-#, c-format
-msgid "Line %d has no category"
-msgstr ""
-#: ../vector/v.net/report.c:52
-#, c-format
-msgid "Point not found: %.3lf %.3lf %.3lf line category: %d"
-msgstr ""
-#: ../vector/v.net/report.c:55
-#, c-format
-msgid "%d points found: %.3lf %.3lf %.3lf line category: %d"
-msgstr ""
-#: ../vector/v.net/arcs.c:42
-#, fuzzy, c-format
-msgid "Error reading file: '%s'"
-#: ../vector/v.net/arcs.c:48
-#, c-format
-msgid "Skipping arc %d"
-msgstr ""
-#: ../vector/v.net/arcs.c:85
-#, fuzzy, c-format
-msgid "No point with category %d found"
-#: ../vector/v.net/arcs.c:89
-#, fuzzy, c-format
-msgid "More points with category %d found"
-msgstr "डे
