[GRASS-SVN] r51892 - in grass/trunk/temporal: . t.rast.gapfill t.register
Wed May 30 08:54:44 PDT 2012
Author: huhabla
Date: 2012-05-30 08:54:44 -0700 (Wed, 30 May 2012)
New Revision: 51892
   grass/trunk/temporal/run_all_tests.sh
   grass/trunk/temporal/t.rast.gapfill/test.t.rast.gapfill.sh
   grass/trunk/temporal/t.register/t.register.py
Fixed bashism
Modified: grass/trunk/temporal/run_all_tests.sh
--- grass/trunk/temporal/run_all_tests.sh	2012-05-30 14:42:26 UTC (rev 51891)
+++ grass/trunk/temporal/run_all_tests.sh	2012-05-30 15:54:44 UTC (rev 51892)
@@ -12,13 +12,14 @@
 # For each directory
 for mydir in `ls -d t*` ; do
-    if [ -d $mydir ] ; then
-        echo $mydir
-        cd $mydir
+    if [ -d "${mydir}" ] ; then
+        echo "${mydir}"
+        cd "${mydir}"
         for myfile in `ls test.* | grep -v '~'` ; do
-            sh $myfile >> $LOG_FILE 2>&1
+	    echo "####### TEST ####### ${myfile}" >> "${LOG_FILE}" 2>&1
+            sh "${myfile}" >> "${LOG_FILE}" 2>&1
         done
         cd ..
     fi
 done
-mv $LOG_FILE .
+mv "${LOG_FILE}" .
Modified: grass/trunk/temporal/t.rast.gapfill/test.t.rast.gapfill.sh
--- grass/trunk/temporal/t.rast.gapfill/test.t.rast.gapfill.sh	2012-05-30 14:42:26 UTC (rev 51891)
+++ grass/trunk/temporal/t.rast.gapfill/test.t.rast.gapfill.sh	2012-05-30 15:54:44 UTC (rev 51892)
@@ -18,7 +18,7 @@
 EOF
 t.create --v --o type=strds temporaltype=absolute output=precip_abs title="A test" descr="A test"
-t.register --v type=rast input=precip_abs file=${n1}
+t.register --v type=rast input=precip_abs file="${n1}"
 # @test
 t.rast.gapfill input=precip_abs base="prec" nprocs=2
Modified: grass/trunk/temporal/t.register/t.register.py
--- grass/trunk/temporal/t.register/t.register.py	2012-05-30 14:42:26 UTC (rev 51891)
+++ grass/trunk/temporal/t.register/t.register.py	2012-05-30 15:54:44 UTC (rev 51892)
@@ -15,7 +15,7 @@
 #%module
-#% description: Registers raster, vector adn raster3d maps in a space time datasets.
+#% description: Registers raster, vector and raster3d maps in a space time datasets.
 #% keywords: temporal
 #% keywords: register
 #%end
