[GRASS-SVN] r53769 - grass/trunk/lib/vector/rtree
Sun Nov 11 10:43:43 PST 2012
Author: mmetz
Date: 2012-11-11 10:43:43 -0800 (Sun, 11 Nov 2012)
New Revision: 53769
   grass/trunk/lib/vector/rtree/index.c
   grass/trunk/lib/vector/rtree/indexf.c
   grass/trunk/lib/vector/rtree/indexm.c
   grass/trunk/lib/vector/rtree/rtree.h
rtree: add option to fine-tune rtree creation
Modified: grass/trunk/lib/vector/rtree/index.c
--- grass/trunk/lib/vector/rtree/index.c	2012-11-10 23:35:30 UTC (rev 53768)
+++ grass/trunk/lib/vector/rtree/index.c	2012-11-11 18:43:43 UTC (rev 53769)
@@ -95,6 +95,9 @@
     n = RTreeAllocNode(new_rtree, 0);
     new_rtree->rootlevel = n->level = 0;       /* leaf */
     new_rtree->root = NULL;
+    /* use overflow by default */
+    new_rtree->overflow = 1;
     if (fd > -1) {  /* file based */
 	/* nodecard and leafcard can be adjusted, must NOT be larger than MAXCARD */
@@ -182,6 +185,24 @@
+  \brief Enable/disable R*-tree forced reinsertion (overflow)
+  For dynamic R*-trees with runtime insertion and deletion,
+  forced reinsertion results in a more compact tree, searches are a bit
+  faster. For static R*-trees (no insertion/deletion after creation)
+  forced reinsertion can be disabled at the cost of slower searches.
+  \param t pointer to RTree structure
+  \param overflow binary flag
+  \return nothing
+void RTreeSetOverflow(struct RTree *t, char overflow)
+    t->overflow = overflow != 0;
   \brief Destroy an R*-Tree
   This method releases all memory allocated to a RTree. It deletes all
Modified: grass/trunk/lib/vector/rtree/indexf.c
--- grass/trunk/lib/vector/rtree/indexf.c	2012-11-10 23:35:30 UTC (rev 53768)
+++ grass/trunk/lib/vector/rtree/indexf.c	2012-11-11 18:43:43 UTC (rev 53769)
@@ -248,7 +248,7 @@
     /* R*-tree forced reinsertion: for each level only once */
-    memset(overflow, 1, MAXLEVEL);
+    memset(overflow, t->overflow, MAXLEVEL);
     result =
 	RTreeInsertRect2F(r, child, level, &newnode, &newnode_pos, t,
Modified: grass/trunk/lib/vector/rtree/indexm.c
--- grass/trunk/lib/vector/rtree/indexm.c	2012-11-10 23:35:30 UTC (rev 53768)
+++ grass/trunk/lib/vector/rtree/indexm.c	2012-11-11 18:43:43 UTC (rev 53769)
@@ -195,7 +195,7 @@
     struct RTree_Branch *b = &(t->tmpb1);
     result =
 	RTreeInsertRect2M(r, child, level, &newnode, t, &reInsertList,
Modified: grass/trunk/lib/vector/rtree/rtree.h
--- grass/trunk/lib/vector/rtree/rtree.h	2012-11-10 23:35:30 UTC (rev 53768)
+++ grass/trunk/lib/vector/rtree/rtree.h	2012-11-11 18:43:43 UTC (rev 53769)
@@ -145,6 +145,7 @@
     int min_leaf_fill;      /* balance criteria for leaf removal */
     int minfill_node_split; /* balance criteria for splitting */
     int minfill_leaf_split; /* balance criteria for splitting */
+    char overflow;	    /* enable/disable overflow */
     /* free node positions for recycling */
     struct _recycle {
@@ -211,6 +212,7 @@
 int RTreeDeleteRect(struct RTree_Rect *, int, struct RTree *);
 void RTreePrintRect(struct RTree_Rect *, int, struct RTree *);
 struct RTree *RTreeCreateTree(int, off_t, int);
+void RTreeSetOverflow(struct RTree *, char);
 void RTreeDestroyTree(struct RTree *);
 int RTreeOverlap(struct RTree_Rect *, struct RTree_Rect *, struct RTree *);
 int RTreeContained(struct RTree_Rect *, struct RTree_Rect *, struct RTree *);
