[GRASS-SVN] r53818 - grass/trunk/gui/wxpython/xml
Wed Nov 14 09:29:35 PST 2012
Author: martinl
Date: 2012-11-14 09:29:35 -0800 (Wed, 14 Nov 2012)
New Revision: 53818
   grass/trunk/gui/wxpython/xml/menudata.xml
wxGUI: add r3.in/out.bin to the menu
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml	2012-11-14 17:21:39 UTC (rev 53817)
+++ grass/trunk/gui/wxpython/xml/menudata.xml	2012-11-14 17:29:35 UTC (rev 53818)
@@ -310,6 +310,13 @@
               <command>r3.in.ascii</command>
             </menuitem>
             <menuitem>
+              <label>Raw binary array 3D import</label>
+              <help>Import a binary raster file into a GRASS 3D raster map.</help>
+              <keywords>raster3d,import</keywords>
+              <handler>OnMenuCmd</handler>
+              <command>r3.in.bin</command>
+            </menuitem>
+            <menuitem>
               <label>Vis5D import</label>
               <help>Import 3-dimensional Vis5D files.</help>
               <keywords>raster3d,voxel</keywords>
@@ -518,6 +525,13 @@
               <command>r3.out.ascii</command>
             </menuitem>
             <menuitem>
+              <label>Raw binary array 3D export</label>
+              <help>Exports a GRASS 3D raster map to a binary array.</help>
+              <keywords>raster3d,export</keywords>
+              <command>r3.out.bin</command>
+            </menuitem>
+            <menuitem>
               <label>Vis5D export</label>
               <help>Exports GRASS 3D raster map to 3-dimensional Vis5D file.</help>
               <keywords>raster3d,voxel,export</keywords>
