[GRASS-SVN] r53913 - in grass-addons/grass6/raster: . r.mcda.fuzzy
Mon Nov 19 05:38:18 PST 2012
Author: gianluca
Date: 2012-11-19 05:38:17 -0800 (Mon, 19 Nov 2012)
New Revision: 53913
Added:
   grass-addons/grass6/raster/r.mcda.fuzzy/
   grass-addons/grass6/raster/r.mcda.fuzzy/Makefile
   grass-addons/grass6/raster/r.mcda.fuzzy/description.html
   grass-addons/grass6/raster/r.mcda.fuzzy/fuzzy.c
   grass-addons/grass6/raster/r.mcda.fuzzy/local_proto.h
   grass-addons/grass6/raster/r.mcda.fuzzy/main.c
Added: grass-addons/grass6/raster/r.mcda.fuzzy/Makefile
--- grass-addons/grass6/raster/r.mcda.fuzzy/Makefile	                        (rev 0)
+++ grass-addons/grass6/raster/r.mcda.fuzzy/Makefile	2012-11-19 13:38:17 UTC (rev 53913)
@@ -0,0 +1,12 @@
+# fix this relative to include/
+# or use absolute path to the GRASS source code
+MODULE_TOPDIR = ../../..
+PGM = r.mcda.fuzzy
+LIBES= $(GISLIB) $(GMATHLIB)
+DEPENDENCIES = $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass-addons/grass6/raster/r.mcda.fuzzy/description.html
--- grass-addons/grass6/raster/r.mcda.fuzzy/description.html	                        (rev 0)
+++ grass-addons/grass6/raster/r.mcda.fuzzy/description.html	2012-11-19 13:38:17 UTC (rev 53913)
@@ -0,0 +1,36 @@
+<h2>DESCRIPTION</h2>
+<em>r.mcda.fuzzy</em> is the implementation of the FUZZY multicriteria
+algorithm proposed by Yager R., in GRASS GIS environment. It is one of the
+available tools in the r.mcda suite. It requires as an input the list of
+raster representing the criteria to be assessed in the multicriteria
+evaluation and the vector of linguistic modifiers to be assigned. Every
+single cell of the GRASS region is considered as one of the possible
+alternatives to evaluate and it is described with the value assumed for
+the same cell by the raster used as criteria. It is possible to get three
+different output files as the result of the intersection operator, the
+union operator and the ordered weighted averaging (OWA) operator.
+<h2>NOTES</h2>
+The module does not standardize the raster-criteria. Therefore, they must
+be prepared before by using, for example, r.mapcalc. The linguistic
+modifiers vector is always normalized so that the sum of the weights is 1.
+<h2>REFERENCE</h2>
+<p>Yager R. (1977) - Multiple objective decision making using fuzzy set,
+ International Journal of Man-Machine Studies, 12, 299-322;</P>
+<p>GRASS Development Team (2008)</P>
+<h2>SEE ALSO</h2>
+<em>r.mcda.regime, r.mcda.electre, r.roughet, r.mapcalc</em>
+<h2>AUTHORS</h2>
+Antonio Boggia - Gianluca Massei<br>
+Department of Economics and Appraisal - University of Perugia - Italy
+<p>
+<i>Last changed: $Date: 2011-11-08 22:56:45 +0100 (mar, 08 nov 2011) $</i>
Added: grass-addons/grass6/raster/r.mcda.fuzzy/fuzzy.c
--- grass-addons/grass6/raster/r.mcda.fuzzy/fuzzy.c	                        (rev 0)
+++ grass-addons/grass6/raster/r.mcda.fuzzy/fuzzy.c	2012-11-19 13:38:17 UTC (rev 53913)
@@ -0,0 +1,131 @@
+#include "local_proto.h"
+ * global function declaration
+void build_weight_vect(int nrows, int ncols, int ncriteria,
+                       struct Option *weight, double *weight_vect);
+void build_fuzzy_matrix(int nrows, int ncols, int ncriteria,
+                        double *weight_vect, double ***decision_vol);
+ * function definitions
+    int i, nweight = 0;
+    double weight_sum = 0;
+    while (weight->answers[nweight] != NULL)
+        nweight++;
+    if (nweight != ncriteria)
+        G_fatal_error(_("criteria number  and weight number are different"));
+    for (i = 0; i < nweight; i++)
+        weight_vect[i] = (atof(weight->answers[i]));	/*transfer  weight value  in double  array */
+        weight_sum = weight_sum + weight_vect[i];	/*calculate sum weight */
+        weight_vect[i] = weight_vect[i] / weight_sum;	/*normalize vector weight */
+    int row1, col1, row2, col2;
+    int i, j, k, cont;
+    double row_sum_conc, col_sum_conc, row_sum_disc, col_sum_disc;
+    double value;
+    /* apply linguistic modifier - */
+    for (row1 = 0; row1 < nrows; row1++)
+        G_percent(row1, nrows, 2);
+        for (col1 = 0; col1 < ncols; col1++)
+            for (i = 0; i < ncriteria; i++)
+                decision_vol[row1][col1][i] =
+                    pow(decision_vol[row1][col1][i], weight_vect[i]);
+    /* operate intersection - AND logic (find min value -) */
+            value = decision_vol[row1][col1][0];	/* set value to firsth matrix i-value */
+                if (decision_vol[row1][col1][i] >= value)
+                    value = value;
+                else
+                    value = decision_vol[row1][col1][i];
+            decision_vol[row1][col1][ncriteria] = value;
+    /* operate union - OR logic (find max value -) */
+                if (decision_vol[row1][col1][i] <= value)
+                    value = value;
+                else
+            decision_vol[row1][col1][ncriteria + 1] = value;
+    /* operate OWA (find average value -) */
+                value = value + decision_vol[row1][col1][i];
+            decision_vol[row1][col1][ncriteria + 2] = value / ncriteria;
Added: grass-addons/grass6/raster/r.mcda.fuzzy/local_proto.h
--- grass-addons/grass6/raster/r.mcda.fuzzy/local_proto.h	                        (rev 0)
+++ grass-addons/grass6/raster/r.mcda.fuzzy/local_proto.h	2012-11-19 13:38:17 UTC (rev 53913)
@@ -0,0 +1,15 @@
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <math.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include <grass/config.h>
+struct input
+    char *name, *mapset;	/* input raster name  and mapset name */
+    int infd;
+    void *inrast;		/* input buffer */
Added: grass-addons/grass6/raster/r.mcda.fuzzy/main.c
--- grass-addons/grass6/raster/r.mcda.fuzzy/main.c	                        (rev 0)
+++ grass-addons/grass6/raster/r.mcda.fuzzy/main.c	2012-11-19 13:38:17 UTC (rev 53913)
@@ -0,0 +1,263 @@
+ * MODULE:	r.mcda.electre
+ * AUTHORS:	 Gianluca Massei (g_massa at libero.it) - Antonio Boggia (boggia at unipg.it)
+ * PURPOSE:      Make a multicriterio decision  analysis based on Yager fuzzy algorthm
+ * COPYRIGHT:     (C) GRASS Development Team (2008)
+ *		        This program is free software under the GNU General Public
+ *   	    	License (>=v2). Read the file COPYING that comes with GRASS
+ *   	    	for details.
+ * main function
+int main(int argc, char *argv[])
+    struct Cell_head cellhd;	/* it stores region information,  and header information of rasters */
+    char *result_and, *result_or, *result_owa;	/* outputs raster name */
+    char *mapset;		/* mapset name */
+    unsigned char *outrast_and, *outrast_or, *outrast_owa;	/* output buffer */
+    int i, j, ncriteria = 0;	/* index and  files number */
+    int nrows, ncols;
+    int row1, row2, col1, col2;
+    int outfd_and, outfd_or, outfd_owa;	/* output file descriptor */
+    double *weight_vect, ***decision_vol;
+    struct History history;	/* holds meta-data (title, comments,..) */
+    struct GModule *module;	/* GRASS module for parsing arguments */
+    struct Option *criteria, *weight, *and, *or, *owa;	/* options */
+    struct input *attributes;	/*storage  alla input criteria GRID files and output concordance and discordance GRID files */
+    /* initialize GIS environment */
+    G_gisinit(argv[0]);		/* reads grass env, stores program name to G_program_name() */
+    /* initialize module */
+    module = G_define_module();
+    module->keywords = _("raster,fuzzy,MCDA");
+    module->description =
+        _("Multicirtieria decision analysis based on Yager fuzzy method");
+    /* Define the different options as defined in gis.h */
+    criteria = G_define_option();	/* Allocates memory for the Option structure and returns a pointer to this memory */
+    criteria->key = "criteria";
+    criteria->type = TYPE_STRING;
+    criteria->required = YES;
+    criteria->multiple = YES;
+    criteria->gisprompt = "old,cell,raster";
+    criteria->description = "Input geographics criteria in evaluation table";
+    weight = G_define_option();	/* Allocates memory for the Option structure and returns a pointer to this memory */
+    weight->key = "weight";
+    weight->type = TYPE_DOUBLE;
+    weight->required = YES;
+    weight->multiple = YES;
+    weight->description = _("Linguistic modifier (w1,w2,..)");
+    and = G_define_option();	/* Allocates memory for the Option structure and returns a pointer to this memory */
+    and->key = "AND";
+    and->type = TYPE_STRING;
+    and->required = YES;
+    and->gisprompt = "new,cell,raster";
+    and->answer = "intersect";
+    and->description = "Intersection output map";
+    or = G_define_option();	/* Allocates memory for the Option structure and returns a pointer to this memory */
+    or->key = "OR";
+    or->type = TYPE_STRING;
+    or->required = YES;
+    or->gisprompt = "new,cell,raster";
+    or->answer = "union";
+    or->description = "Union output map";
+    owa = G_define_option();	/* Allocates memory for the Option structure and returns a pointer to this memory */
+    owa->key = "OWA";
+    owa->type = TYPE_STRING;
+    owa->required = YES;
+    owa->gisprompt = "new,cell,raster";
+    owa->answer = "OWA";
+    owa->description = "OWA output map";
+    /* options and flags parser */
+    if (G_parser(argc, argv))
+        exit(EXIT_FAILURE);
+    G_message("\n\nstart: %s", G_date());	/*write calculation start time */
+    /* number of file (=criteria) */
+    while (criteria->answers[ncriteria] != NULL)
+        ncriteria++;
+    /* process the input maps:  stores options and flags to variables */
+    /* CRITERIA grid */
+    attributes = G_malloc(ncriteria * sizeof(struct input));	/*attributes is input struct defined in top file and store alla criteria files */
+    weight_vect = G_malloc(ncriteria * sizeof(double));	/*allocate memory fron vector weight */
+    build_weight_vect(nrows, ncols, ncriteria, weight, weight_vect);	/*calcolate weight vector */
+        struct input *p = &attributes[i];
+        p->name = criteria->answers[i];
+        p->mapset = G_find_cell2(p->name, "");	/* G_find_cell: Looks for the raster map "name" in the database. */
+        if (p->mapset == NULL)	/* returns NULL if the map was not found in any mapset,   mapset name otherwise */
+            G_fatal_error(_("Raster file <%s> not found"), p->name);
+        if ((p->infd = G_open_cell_old(p->name, p->mapset)) < 0)	/* G_open_cell_old - returns file destriptor (>0) */
+            G_fatal_error(_("Unable to open input map <%s> in mapset <%s>"),
+                          p->name, p->mapset);
+        if (G_get_cellhd(p->name, p->mapset, &cellhd) < 0)	/* controlling, if we can open input raster */
+            G_fatal_error(_("Unable to read file header of <%s>"), p->name);
+        p->inrast = G_allocate_d_raster_buf();	/* Allocate an array of DCELL based on the number of columns in the current region. Return DCELL   */
+    result_and = and->answer;	/* store outputn name in variables */
+    result_or = or->answer;
+    result_owa = owa->answer;
+    if (G_legal_filename(result_and) < 0)	/* check for legal database file names */
+        G_fatal_error(_("<%s> is an illegal file name"), result_and);
+    if (G_legal_filename(result_or) < 0)	/* check for legal database file names */
+        G_fatal_error(_("<%s> is an illegal file name"), result_or);
+    if (G_legal_filename(result_owa) < 0)	/* check for legal database file names */
+        G_fatal_error(_("<%s> is an illegal file name"), result_owa);
+    /*values = G_malloc(ncriteria * sizeof(DCELL)); */
+    nrows = G_window_rows();
+    ncols = G_window_cols();
+    /*memory allocation for-three dimensional matrix */
+    decision_vol = G_malloc(nrows * sizeof(double *));
+    for (i = 0; i < nrows; ++i)
+        decision_vol[i] = G_malloc(ncols * sizeof(double *));
+        for (j = 0; j < ncols; ++j)
+            decision_vol[i][j] = G_malloc((ncriteria + 3) * sizeof(double));	     /****NOTE: it's storage enven and, or, owa map*/
+    /* Allocate output buffer, use  DCELL_TYPE */
+    outrast_and = G_allocate_raster_buf(DCELL_TYPE);	/* Allocate memory for a raster map of type DCELL_TYPE. */
+    outrast_or = G_allocate_raster_buf(DCELL_TYPE);
+    outrast_owa = G_allocate_raster_buf(DCELL_TYPE);
+    /* controlling, if we can write the raster */
+    if ((outfd_and = G_open_raster_new(result_and, DCELL_TYPE)) < 0)
+        G_fatal_error(_("Unable to create raster map <%s>"), result_and);
+    if ((outfd_or = G_open_raster_new(result_or, DCELL_TYPE)) < 0)
+        G_fatal_error(_("Unable to create raster map <%s>"), result_or);
+    if ((outfd_owa = G_open_raster_new(result_owa, DCELL_TYPE)) < 0)
+        G_fatal_error(_("Unable to create raster map <%s>"), result_owa);
+    /*build a three dimensional matrix for storage all critera maps */
+            G_get_raster_row(attributes[i].infd, attributes[i].inrast, row1, DCELL_TYPE);	/* Reads appropriate information into the buffer buf associated with the requested row */
+            /*G_fatal_error(_("Unable to read raster map <%s> row %d"), criteria->answers[i], row); */
+                /* viene letto il valore di cella e lo si attribuisce ad una variabile di tipo DCELL e poi ad un array */
+                DCELL v1 = ((DCELL *) attributes[i].inrast)[col1];
+                decision_vol[row1][col1][i] = (double)(v1);
+    build_fuzzy_matrix(nrows, ncols, ncriteria, weight_vect, decision_vol);	/*scan all DCELL, make a pairwise comparatione, buil concordance and discordance matrix and relative index */
+            ((DCELL *) outrast_and)[col1] =
+                (DCELL) decision_vol[row1][col1][ncriteria];
+            ((DCELL *) outrast_or)[col1] =
+                (DCELL) decision_vol[row1][col1][ncriteria + 1];
+            ((DCELL *) outrast_owa)[col1] =
+                (DCELL) decision_vol[row1][col1][ncriteria + 2];
+        if (G_put_raster_row(outfd_and, outrast_and, DCELL_TYPE) < 0)
+            G_fatal_error(_("Failed writing raster map <%s>"), result_and);
+        if (G_put_raster_row(outfd_or, outrast_or, DCELL_TYPE) < 0)
+            G_fatal_error(_("Failed writing raster map <%s>"), result_or);
+        if (G_put_raster_row(outfd_owa, outrast_owa, DCELL_TYPE) < 0)
+            G_fatal_error(_("Failed writing raster map <%s>"), result_owa);
+    G_message("end: %s, by!", G_date());
+    /* memory cleanup */
+        G_free(attributes[i].inrast);
+    G_free(outrast_and);
+    G_free(outrast_or);
+    G_free(outrast_owa);
+    G_free(decision_vol);
+    /* closing raster maps */
+        G_close_cell(attributes[i].infd);
+    G_close_cell(outfd_and);
+    G_close_cell(outfd_or);
+    G_close_cell(outfd_owa);
+    /* add command line incantation to history AND file */
+    G_short_history(result_and, "raster", &history);
+    G_command_history(&history);
+    G_write_history(result_and, &history);
+    /* add command line incantation to history OR file */
+    G_short_history(result_or, "raster", &history);
+    G_write_history(result_or, &history);
+    /* add command line incantation to history OWA file */
+    G_short_history(result_owa, "raster", &history);
+    G_write_history(result_owa, &history);
+    exit(EXIT_SUCCESS);
