[GRASS-SVN] r53998 - grass/trunk/vector/v.hull
Fri Nov 23 11:37:03 PST 2012
Author: mmetz
Date: 2012-11-23 11:37:02 -0800 (Fri, 23 Nov 2012)
New Revision: 53998
   grass/trunk/vector/v.hull/main.c
   grass/trunk/vector/v.hull/read.c
v.hull: use new vector li fns for cats and where options
Modified: grass/trunk/vector/v.hull/main.c
--- grass/trunk/vector/v.hull/main.c	2012-11-23 19:31:30 UTC (rev 53997)
+++ grass/trunk/vector/v.hull/main.c	2012-11-23 19:37:02 UTC (rev 53998)
@@ -86,9 +86,11 @@
 	G_fatal_error(_("Unable to open vector map <%s>"), sitefile);
     layer = Vect_get_field_number(&Map, field->answer);
-    cat_list = parse_filter_options(&Map, layer, where_opt->answer,
-                                  cats_opt->answer);
+    if (layer > 0)
+	cat_list = Vect_cats_set_constraint(&Map, layer, where_opt->answer,
+                                            cats_opt->answer);
     /* load site coordinates */
     G_get_window(&window);
     numSitePoints = loadSiteCoordinates(&Map, &points, region_flag->answer, &window,
Modified: grass/trunk/vector/v.hull/read.c
--- grass/trunk/vector/v.hull/read.c	2012-11-23 19:31:30 UTC (rev 53997)
+++ grass/trunk/vector/v.hull/read.c	2012-11-23 19:37:02 UTC (rev 53998)
@@ -11,7 +11,7 @@
     struct line_pnts *sites;
     struct line_cats *cats;
     struct bound_box box;
-    int cat, type;
+    int type;
     sites = Vect_new_line_struct();
     cats = Vect_new_cats_struct();
@@ -27,26 +27,12 @@
 	if (type != GV_POINT && !(type & GV_LINES))
 	    continue;
-	if (cat_list) {
-	    int found = 0;
-	    for (i = 0; i < cats->n_cats; i++) {
-		if (cats->field[i] == field &&
-		    Vect_cat_in_cat_list(cats->cat[i], cat_list)) {
-		    found = 1;
-		    break;
-	    if (!found)
-		continue;
-	else if (field > 0 && Vect_cat_get(cats, field, &cat) == 0)
+	if (field > 0 && !Vect_cats_in_constraint(cats, field, cat_list))
 	    continue;
 	for (i = 0; i < sites->n_points; i++) {
-	    G_debug(4, "Point: %f|%f|%f|#%d", sites->x[i], sites->y[i],
-		    sites->z[i], cat);
+	    G_debug(4, "Point: %f|%f|%f", sites->x[i], sites->y[i],
+		    sites->z[i]);
 	    if (region && !Vect_point_in_box(sites->x[i], sites->y[i], sites->z[i], &box))
 		continue;
@@ -70,92 +56,3 @@
     return pointIdx;
-static int cmp_int(const void *a, const void *b)
-    int ai = *(int *)a;
-    int bi = *(int *)b;
-    return (ai < bi ? -1 : (ai > bi));
-/* parse filter options */
-/* return cat list or NULL */
-struct cat_list *parse_filter_options(struct Map_info *Map, int layer,
-                      char *where, char *catstr)
-    struct cat_list *list = NULL;
-    if (where) {
-	struct field_info *Fi = NULL;
-	dbDriver *driver = NULL;
-	int ncats, *cats = NULL;
-	int i, j;
-	if (layer < 1)
-	    G_fatal_error(_("'%s' must be > 0 for '%s'"), "layer", "where");
-	if (catstr)
-	    G_warning(_("'where' and 'cats' parameters were supplied, cat will be ignored"));
-	Fi = Vect_get_field(Map, layer);
-	if (!Fi) {
-	    G_fatal_error(_("Database connection not defined for layer %d"),
-			  layer);
-	G_verbose_message(_("Loading categories from table <%s>..."), Fi->table);
-	driver = db_start_driver_open_database(Fi->driver, Fi->database);
-	if (driver == NULL)
-	    G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
-			  Fi->database, Fi->driver);
-	ncats = db_select_int(driver, Fi->table, Fi->key, where,
-			      &cats);
-	if (ncats == -1)
-		G_fatal_error(_("Unable select records from table <%s>"),
-			      Fi->table);
-	G_verbose_message(_("%d categories loaded"), ncats);
-	db_close_database_shutdown_driver(driver);
-	/* sort */
-	qsort(cats, ncats, sizeof(int), cmp_int);
-	/* remove duplicates */
-	j = 1;
-	for (i = 1; i < ncats; i++) {
-	    if (cats[i] != cats[j - 1]) {
-		cats[j] = cats[i];
-		j++;
-	ncats = j;
-	/* convert to cat list */
-	list = Vect_new_cat_list();
-	Vect_array_to_cat_list(cats, ncats, list);
-	if (cats)
-	    G_free(cats);
-    else if (catstr) {
-	if (layer < 1)
-	    G_fatal_error(_("'%s' must be > 0 for '%s'"), "layer", GV_KEY_COLUMN);
-	if (Vect_str_to_cat_list(catstr, list) > 0) {
-	    G_warning(_("Problem loading category values"));
-    if (list) {
-	if (list->n_ranges < 1) {
-	    Vect_destroy_cat_list(list);
-	    list = NULL;
-    return list;
