[GRASS-SVN] r53296 - grass/trunk/lib/raster3d/test
Mon Oct 1 13:53:02 PDT 2012
Author: huhabla
Date: 2012-10-01 13:53:01 -0700 (Mon, 01 Oct 2012)
New Revision: 53296
   grass/trunk/lib/raster3d/test/test_put_get_value_large_file.c
Added test of 3D raster maps with different value generators.
Modified: grass/trunk/lib/raster3d/test/test_put_get_value_large_file.c
--- grass/trunk/lib/raster3d/test/test_put_get_value_large_file.c	2012-10-01 14:53:28 UTC (rev 53295)
+++ grass/trunk/lib/raster3d/test/test_put_get_value_large_file.c	2012-10-01 20:53:01 UTC (rev 53296)
@@ -22,9 +22,12 @@
 #define EPSILON 0.000000001
 static int test_large_file(int depths, int rows, int cols, int tile_size);
+static int test_large_file_zeros(int depths, int rows, int cols, int tile_size);
+static int test_large_file_random(int depths, int rows, int cols, int tile_size);
+static int test_large_file_sparse_random(int depths, int rows, int cols, int tile_size);
-/* Perfrome the coordinate transformation tests ****************** */
+/* Perform the coordinate transformation tests ****************** */
 int unit_test_put_get_value_large_file(int depths, int rows, int cols, int tile_size)
@@ -33,6 +36,9 @@
     G_message(_("\n++ Running g3d put/get value large file unit tests ++"));
     sum += test_large_file(depths, rows, cols, tile_size);
+    sum += test_large_file_zeros(depths, rows, cols, tile_size);
+    sum += test_large_file_random(depths, rows, cols, tile_size);
+    sum += test_large_file_sparse_random(depths, rows, cols, tile_size);
     if (sum > 0)
@@ -84,7 +90,7 @@
 	G_percent(z, region.depths, 1);
         for(y = 0; y < region.rows; y++) {
             for(x = 0; x < region.cols; x++) {
-                /* Add cols, rows and depths and put this in the map */
+              /* Put the counter as cell value */
                 value = count;
                 Rast3d_put_value(map, x, y, z, &value, DCELL_TYPE);
                 count++;
@@ -106,7 +112,7 @@
+                /* Check the counter as cell value */
                 Rast3d_get_value(map, x, y, z, &value, DCELL_TYPE);
                 if(fabs(value - (double)(count) > EPSILON)) {
                     G_message("At: z %i y %i x %i -- value %.14lf != %.14lf\n", z, y, x, value, (double)(count));
@@ -119,8 +125,272 @@
     G_percent(1, 1, 1);
     Rast3d_close(map);
-    G_remove("grid3", "test_put_get_value_dcell_large");
+    //G_remove("grid3", "test_put_get_value_dcell_large");
     return sum;
+int test_large_file_zeros(int depths, int rows, int cols, int tile_size)
+    int sum = 0;
+    int x, y, z;
+    DCELL value;
+    G_message("Testing DCELL put function for large files filled with zeros");
+    RASTER3D_Region region;
+    RASTER3D_Map *map = NULL;
+    /* We need to set up a specific region for the new g3d map.
+     * First we safe the default region. */
+    Rast3d_get_window(&region);
+    region.bottom = -365.5;
+    region.top = 365.5;
+    region.south = -90;
+    region.north = 90;
+    region.west = -180;
+    region.east = 180;
+    region.rows = rows;
+    region.cols = cols;
+    region.depths = depths;
+    Rast3d_adjust_region(&region);
+    G_message("Creating 3D raster map filled with zeros");
+    map = Rast3d_open_new_opt_tile_size("test_put_get_value_dcell_large_zeros", RASTER3D_USE_CACHE_XY, &region, DCELL_TYPE, tile_size);
+    /* The window is the same as the map region ... of course */
+    Rast3d_set_window_map(map, &region);
+    for(z = 0; z < region.depths; z++) {
+	G_percent(z, region.depths, 1);
+        for(y = 0; y < region.rows; y++) {
+            for(x = 0; x < region.cols; x++) {
+                value = 0.0;
+                Rast3d_put_value(map, x, y, z, &value, DCELL_TYPE);
+    G_percent(1, 1, 1);
+    /* Write everything to the disk */
+    Rast3d_flush_all_tiles(map);
+    Rast3d_close(map);
+    G_message("Verifying 3D raster map filled with zeros");
+    map = Rast3d_open_cell_old("test_put_get_value_dcell_large_zeros", G_mapset(), &region, DCELL_TYPE, RASTER3D_USE_CACHE_XYZ);
+                Rast3d_get_value(map, x, y, z, &value, DCELL_TYPE);
+                if(value > EPSILON) {
+                    G_message("At: z %i y %i x %i -- value %.14lf != 0.0\n", z, y, x, value);
+                    sum++;
+    //G_remove("grid3", "test_put_get_value_dcell_large_zeros");
+    return sum;
+int test_large_file_random(int depths, int rows, int cols, int tile_size)
+    int sum = 0;
+    int x, y, z;
+    DCELL value, radnom_value;
+    G_message("Testing DCELL put function for large files filled with random values");
+    G_message("Creating 3D raster map filled with random values");
+    map = Rast3d_open_new_opt_tile_size("test_put_get_value_dcell_large_random", RASTER3D_USE_CACHE_XY, &region, DCELL_TYPE, tile_size);
+    srand(1);
+                value = (double)rand();
+    G_message("Verifying 3D raster map filled with random values");
+    map = Rast3d_open_cell_old("test_put_get_value_dcell_large_random", G_mapset(), &region, DCELL_TYPE, RASTER3D_USE_CACHE_XYZ);
+    srand(1);
+                radnom_value = (DCELL)rand();
+                if(fabs(value - radnom_value) > EPSILON) {
+                    G_message("At: z %i y %i x %i -- value %.14lf != %.14lf\n", z, y, x, value, radnom_value);
+                    sum++;
+    //G_remove("grid3", "test_put_get_value_dcell_large_random");
+    return sum;
+int test_large_file_sparse_random(int depths, int rows, int cols, int tile_size)
+    int sum = 0;
+    int x, y, z;
+    G_message("Testing DCELL put function for large files filled with sparse random values");
+    G_message("Creating 3D raster map filled with sparse random values");
+    map = Rast3d_open_new_opt_tile_size("test_put_get_value_dcell_large_sparse_random", RASTER3D_USE_CACHE_XY, &region, DCELL_TYPE, tile_size);
+    srand(1);
+                value = (DCELL)rand();
+                value /= RAND_MAX;
+                if(value <= 0.7)
+                	value = 0.0;
+                else if(value <= 0.8)
+                	value = 1.0;
+                else if(value <= 0.9)
+                	value = 2.0;
+                else if(value <= 1.0)
+                	value = 3.0;
+                else
+                	value = 4.0;
+    G_message("Verifying 3D raster map filled with sparse random values");
+    map = Rast3d_open_cell_old("test_put_get_value_dcell_large_sparse_random", G_mapset(), &region, DCELL_TYPE, RASTER3D_USE_CACHE_XYZ);
+    srand(1);
+                radnom_value /= RAND_MAX;
+                if(radnom_value <= 0.7)
+                	radnom_value = 0.0;
+                else if(radnom_value <= 0.8)
+                	radnom_value = 1.0;
+                else if(radnom_value <= 0.9)
+                	radnom_value = 2.0;
+                else if(radnom_value <= 1.0)
+                	radnom_value = 3.0;
+                else
+                	radnom_value = 4.0;
+                    sum++;
+    //G_remove("grid3", "test_put_get_value_dcell_large_sparse_random");
+    return sum;
