[GRASS-SVN] r53550 - grass-addons/grass6/imagery/i.landsat.toar
    svn_grass at osgeo.org
    Thu Oct 25 04:56:43 PDT 2012
Author: ejtizado
Date: 2012-10-25 04:56:43 -0700 (Thu, 25 Oct 2012)
New Revision: 53550
   grass-addons/grass6/imagery/i.landsat.toar/landsat.h
   grass-addons/grass6/imagery/i.landsat.toar/landsat_met.c
   grass-addons/grass6/imagery/i.landsat.toar/landsat_set.c
   grass-addons/grass6/imagery/i.landsat.toar/main.c
Update to read metadata MTL.txt to all Landsats
Modified: grass-addons/grass6/imagery/i.landsat.toar/landsat.h
--- grass-addons/grass6/imagery/i.landsat.toar/landsat.h	2012-10-25 10:04:01 UTC (rev 53549)
+++ grass-addons/grass6/imagery/i.landsat.toar/landsat.h	2012-10-25 11:56:43 UTC (rev 53550)
@@ -3,13 +3,16 @@
 #define UNCORRECTED     0
 #define CORRECTED       1
 #define DOS      		10
 #define DOS1			12
 #define DOS2			14
-#define DOS2b			15
+#define DOS2b		15
 #define DOS3			16
 #define DOS4			18
+#define NOMETADATAFILE  0
+#define METADATAFILE    1
  * Landsat Structures
@@ -40,6 +43,7 @@
 typedef struct
+    int flag;
     unsigned char number;	/* Landsat number                */
     char creation[11];		/* Image production date         */
Modified: grass-addons/grass6/imagery/i.landsat.toar/landsat_met.c
--- grass-addons/grass6/imagery/i.landsat.toar/landsat_met.c	2012-10-25 10:04:01 UTC (rev 53549)
+++ grass-addons/grass6/imagery/i.landsat.toar/landsat_met.c	2012-10-25 11:56:43 UTC (rev 53550)
@@ -96,7 +96,7 @@
         lsat->sun_elev = atof(value);
-    /* Fill data with the sensor_XXX functions */
+    // Fill data with the sensor_XXX functions
     switch(lsat->number)
         case 1:
@@ -184,7 +184,7 @@
     get_mtldata(mtldata, "SUN_ELEVATION", value);
         case 1:
@@ -226,7 +226,7 @@
             break;
-    /* Update the information from metadata file */
+    // Update the information from metadata file
     for (i = 0; i < lsat->bands; i++) {
         snprintf(name, MAX_STR, "LMAX_BAND%d", lsat->band[i].code);
         get_mtldata(mtldata, name, value);
@@ -247,3 +247,5 @@
     return;
Modified: grass-addons/grass6/imagery/i.landsat.toar/landsat_set.c
--- grass-addons/grass6/imagery/i.landsat.toar/landsat_set.c	2012-10-25 10:04:01 UTC (rev 53549)
+++ grass-addons/grass6/imagery/i.landsat.toar/landsat_set.c	2012-10-25 11:56:43 UTC (rev 53550)
@@ -421,10 +421,9 @@
     jbuf = julian_char("2004-04-04");
-    if (julian >= jbuf) {
-	G_warning
-	    ("Using QCalMin=1.0 as a NLAPS product processed after 4/4/2004");
-	G_warning("Discard this message if using the metfile option");
+    if (julian >= jbuf && !(lsat->flag & METADATAFILE) )
+        G_warning("Using QCalMin=1.0 as a NLAPS product processed after 04/04/2004");
     lsat->number = 5;
     sensor_TM(lsat);
Modified: grass-addons/grass6/imagery/i.landsat.toar/main.c
--- grass-addons/grass6/imagery/i.landsat.toar/main.c	2012-10-25 10:04:01 UTC (rev 53549)
+++ grass-addons/grass6/imagery/i.landsat.toar/main.c	2012-10-25 11:56:43 UTC (rev 53550)
@@ -10,7 +10,7 @@
  * PURPOSE:      Calculate TOA Radiance or Reflectance and Kinetic Temperature
  *               for Landsat 1/2/3/4/5 MS, 4/5 TM or 7 ETM+
- * COPYRIGHT:    (C) 2002-2012 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2012 by the GRASS Development Team
  *               This program is free software under the GNU General
  *               Public License (>=v2). Read the file COPYING that
@@ -85,6 +85,16 @@
     metfn->description = _("Name of Landsat metadata file (.met or MTL.txt)");
     metfn->guisection = _("Metadata");
+    metho = G_define_option();
+    metho->key = "method";
+    metho->type = TYPE_STRING;
+    metho->required = NO;
+    metho->options = "uncorrected,corrected,dos1,dos2,dos2b,dos3,dos4";
+    metho->label = _("Atmospheric correction method");
+    metho->description = _("Atmospheric correction method");
+    metho->answer = "uncorrected";
+    metho->guisection = _("Metadata");
     sensor = G_define_option();
     sensor->key = "sensor";
     sensor->type = TYPE_STRING;
@@ -103,16 +113,6 @@
     sensor->required = NO;
     sensor->guisection = _("Metadata");
-    metho = G_define_option();
-    metho->key = "method";
-    metho->type = TYPE_STRING;
-    metho->required = NO;
-    metho->options = "uncorrected,corrected,dos1,dos2,dos2b,dos3,dos4";
-    metho->label = _("Atmospheric correction method");
-    metho->description = _("Atmospheric correction method");
-    metho->answer = "uncorrected";
-    metho->guisection = _("Metadata");
     adate = G_define_option();
     adate->key = "date";
     adate->type = TYPE_STRING;
@@ -172,6 +172,7 @@
     atmo->answer = "0.0";
     atmo->guisection = _("Settings");
     /* define the different flags */
     frad = G_define_flag();
     frad->key = 'r';
@@ -200,8 +201,10 @@
 	    G_fatal_error(_("Illegal date format: [%s] (yyyy-mm-dd)"),
 			  lsat.date);
+    /* Unnecessary because G_zero filled
     else
 	lsat.date[0] = '\0';
     if (pdate->answer != NULL) {
 	strncpy(lsat.creation, pdate->answer, 11);
@@ -210,17 +213,23 @@
 			  lsat.creation);
     else
 	lsat.creation[0] = '\0';
     lsat.sun_elev = elev->answer == NULL ? 0. : atof(elev->answer);
     percent = atof(perc->answer);
     pixel = atoi(dark->answer);
     rayleigh = atof(atmo->answer);
+    lsat.flag = NOMETADATAFILE;
     /* Data from metadata file */
     if (met != NULL)
+        lsat.flag = METADATAFILE;
         i = strlen(met);
         if (strcmp(met + i - 7, "MTL.txt") == 0)
@@ -229,7 +238,7 @@
         else if (strcmp(met + i - 4, ".met") == 0)
             if (strcmp(sensorname, "tm7") == 0)
-                lsat_mtldata(met, &lsat);  /* .met of Landsat-7 = new MTL file */
+                lsat_mtldata(met, &lsat);  /* old .met of Landsat-7 = new MTL file */
             else
                 lsat_metdata(met, &lsat);
@@ -281,17 +290,17 @@
 	* ------------ PREPARATION --------------
-    if (G_strcasecmp(metho->answer, "corrected") == 0)
+    if (strcasecmp(metho->answer, "corrected") == 0)
 	method = CORRECTED;
-    else if (G_strcasecmp(metho->answer, "dos1") == 0)
+    else if (strcasecmp(metho->answer, "dos1") == 0)
 	method = DOS1;
-    else if (G_strcasecmp(metho->answer, "dos2") == 0)
+    else if (strcasecmp(metho->answer, "dos2") == 0)
 	method = DOS2;
-    else if (G_strcasecmp(metho->answer, "dos2b") == 0)
+    else if (strcasecmp(metho->answer, "dos2b") == 0)
 	method = DOS2b;
-    else if (G_strcasecmp(metho->answer, "dos3") == 0)
+    else if (strcasecmp(metho->answer, "dos3") == 0)
 	method = DOS3;
-    else if (G_strcasecmp(metho->answer, "dos4") == 0)
+    else if (strcasecmp(metho->answer, "dos4") == 0)
 	method = DOS4;
     else
 	method = UNCORRECTED;
@@ -387,7 +396,7 @@
 	G_fatal_error(_("Unknown production date (defined by '%s')"), pdate->key);
     if (G_verbose() > G_verbose_std()) {
-	fprintf(stderr, " LANDSAT: %d SENSOR: %s\n", lsat.number, lsat.sensor);
+	fprintf(stderr, " LANSAT: %d SENSOR: %s\n", lsat.number, lsat.sensor);
 	fprintf(stderr, " ACQUISITION DATE %s [production date %s]\n",
 		lsat.date, lsat.creation);
 	fprintf(stderr, "   earth-sun distance    = %.8lf\n", lsat.dist_es);
