[GRASS-SVN] r53294 - grass/trunk/gui/wxpython/gui_core
Sat Sep 29 23:40:33 PDT 2012
Author: annakrat
Date: 2012-09-29 23:40:32 -0700 (Sat, 29 Sep 2012)
New Revision: 53294
   grass/trunk/gui/wxpython/gui_core/gselect.py
wxGUI: enable temporal elements in command dialogs
Modified: grass/trunk/gui/wxpython/gui_core/gselect.py
--- grass/trunk/gui/wxpython/gui_core/gselect.py	2012-09-30 06:24:36 UTC (rev 53293)
+++ grass/trunk/gui/wxpython/gui_core/gselect.py	2012-09-30 06:40:32 UTC (rev 53294)
@@ -49,6 +49,7 @@
 from core import globalvar
 import grass.script as grass
+import grass.temporal as tgis
 from   grass.script import task as gtask
 from core.gcmd     import RunCommand, GError, GMessage
@@ -319,17 +320,24 @@
                        '3d.view':'3dview',
                        '3dview':'3dview',
                        '3D viewing parameters':'3dview',
-                       '3D view parameters':'3dview'}
+                       '3D view parameters':'3dview',
+                       'stds':'stds',
+                       'strds':'strds',
+                       'str3ds':'str3ds',
+                       'stvds':'stvds'}
         if element not in elementdict:
             self.AddItem(_('Not selectable element'))
             return
-        if globalvar.have_mlist:
-            filesdict = grass.mlist_grouped(elementdict[element],
-                                            check_search_path = False)
+        if element in ('stds', 'strds', 'str3ds', 'stvds'):
+            filesdict = tgis.tlist_grouped(elementdict[element])
         else:
-            filesdict = grass.list_grouped(elementdict[element],
+            if globalvar.have_mlist:
+                filesdict = grass.mlist_grouped(elementdict[element],
+                                                check_search_path = False)
+            else:
+                filesdict = grass.list_grouped(elementdict[element],
         # list of mapsets in current location
