[GRASS-SVN] r55582 - grass/trunk/lib/vector/Vlib
Mon Apr 1 08:15:14 PDT 2013
Author: martinl
Date: 2013-04-01 08:15:14 -0700 (Mon, 01 Apr 2013)
New Revision: 55582
   grass/trunk/lib/vector/Vlib/bridges.c
   grass/trunk/lib/vector/Vlib/local_proto.h
   grass/trunk/lib/vector/Vlib/open.c
   grass/trunk/lib/vector/Vlib/read.c
   grass/trunk/lib/vector/Vlib/read_nat.c
   grass/trunk/lib/vector/Vlib/read_sfa.c
   grass/trunk/lib/vector/Vlib/write.c
   grass/trunk/lib/vector/Vlib/write_nat.c
   grass/trunk/lib/vector/Vlib/write_sfa.c
vlib: add V2__delete_line_topo_nat()
      update V2__add_line_topo_nat()
      add extra checks (invalid line id) + update doxygen (note required build level)
      various minor issue
Modified: grass/trunk/lib/vector/Vlib/bridges.c
--- grass/trunk/lib/vector/Vlib/bridges.c	2013-04-01 14:13:18 UTC (rev 55581)
+++ grass/trunk/lib/vector/Vlib/bridges.c	2013-04-01 15:15:14 UTC (rev 55582)
@@ -28,9 +28,8 @@
     return (*ai < *bi ? -1 : (*ai > *bi));
-static void
-remove_bridges(struct Map_info *Map, int chtype, struct Map_info *Err,
-               int *lrm, int *brm);
+static void remove_bridges(struct Map_info *Map, int chtype, struct Map_info *Err,
+                           int *lrm, int *brm);
    \brief Remove bridges from vector map.
@@ -45,12 +44,9 @@
    \param Err vector map where deleted bridges are written or NULL
    \param lines_removed number of lines removed
    \param bridges_removed Err number of bridges removed
-   \return
-void
-Vect_remove_bridges(struct Map_info *Map, struct Map_info *Err,
-                    int *lines_removed, int *bridges_removed)
+void Vect_remove_bridges(struct Map_info *Map, struct Map_info *Err,
+                         int *lines_removed, int *bridges_removed)
     remove_bridges(Map, 0, Err, lines_removed, bridges_removed);
@@ -69,12 +65,8 @@
    \param Err vector map where changed bridges are written or NULL
    \param lines_changed number of lines changed
    \param bridges_changed Err number of bridges changed
-   \return
-void
-Vect_chtype_bridges(struct Map_info *Map, struct Map_info *Err,
+void Vect_chtype_bridges(struct Map_info *Map, struct Map_info *Err,
                     int *lines_changed, int *bridges_changed)
     remove_bridges(Map, 1, Err, lines_changed, bridges_changed);
@@ -93,11 +85,10 @@
    List of all lines in chain is created during the cycle.
-void
+void remove_bridges(struct Map_info *Map, int chtype, struct Map_info *Err,
-    int i, type, nlines, line, *bline;
+    int type, nlines, line, *bline;
     int left, right, node1, node2, current_line, next_line, abs_line;
     int bridges_removed = 0;	/* number of removed bridges */
     int lines_removed = 0;	/* number of lines removed */
@@ -219,6 +210,6 @@
     if (brm)
 	*brm = bridges_removed;
-    G_verbose_message("Removed lines: %d", lines_removed);
-    G_verbose_message("Removed bridges: %d", bridges_removed);
+    G_verbose_message(_("Removed lines: %d"), lines_removed);
+    G_verbose_message(_("Removed bridges: %d"), bridges_removed);
Modified: grass/trunk/lib/vector/Vlib/local_proto.h
--- grass/trunk/lib/vector/Vlib/local_proto.h	2013-04-01 14:13:18 UTC (rev 55581)
+++ grass/trunk/lib/vector/Vlib/local_proto.h	2013-04-01 15:15:14 UTC (rev 55582)
@@ -3,9 +3,8 @@
 #include <grass/vector.h>
-void V2__add_line_to_topo_nat(struct Map_info *, int ,
-                              const struct line_pnts *, const struct line_cats *,
-                              int (*external_routine) (const struct Map_info *, int));
+/* Internal vector library subroutines which are not part of public
+   API*/
 /* map.c */
 int Vect__delete(const char *, int);
@@ -16,4 +15,11 @@
 char *Vect__get_path(const struct Map_info *);
 char *Vect__get_element_path(const struct Map_info *, const char *);
+/* write_nat.c */
+int V2__add_line_to_topo_nat(struct Map_info *, off_t, int,
+                             const struct line_pnts *, const struct line_cats *, int,
+                             int (*external_routine) (const struct Map_info *, int));
+int V2__delete_line_from_topo_nat(struct Map_info *, int, int,
+                                  const struct line_pnts *, const struct line_cats *);
 #endif /* PG_LOCAL_PROTO_H__ */
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c	2013-04-01 14:13:18 UTC (rev 55581)
+++ grass/trunk/lib/vector/Vlib/open.c	2013-04-01 15:15:14 UTC (rev 55582)
@@ -782,6 +782,8 @@
     /* set 2D/3D */
     Map->plus.spidx_with_z = Map->plus.with_z = Map->head.with_z = (with_z != 0);
+    Map->level = LEVEL_1;
     if ((*Open_new_array[Map->format][1]) (Map, name, with_z) < 0) {
         if (getenv("GRASS_VECTOR_PGFILE") == NULL)  /* GRASS_VECTOR_PGFILE defined by v.out.postgis */
             Vect_delete(name); /* clean up */
@@ -798,7 +800,6 @@
     Vect_open_sidx(Map, 2);
     Map->open = VECT_OPEN_CODE;
-    Map->level = 1;
     Map->head_only = FALSE;
     Map->support_updated = FALSE;
     Map->plus.built = GV_BUILD_NONE;
Modified: grass/trunk/lib/vector/Vlib/read.c
--- grass/trunk/lib/vector/Vlib/read.c	2013-04-01 14:13:18 UTC (rev 55581)
+++ grass/trunk/lib/vector/Vlib/read.c	2013-04-01 15:15:14 UTC (rev 55582)
@@ -5,7 +5,7 @@
    Higher level functions for reading/writing/manipulating vectors.
-   (C) 2001-2009, 2011 by the GRASS Development Team
+   (C) 2001-2009, 2011-2013 by the GRASS Development Team
    This program is free software under the GNU General Public License
    (>=v2). Read the file COPYING that comes with GRASS for details.
@@ -83,13 +83,16 @@
   \param Map pointer to Map_info struct
   \return feature id
+  \return -1 on error
 int Vect_get_next_line_id(const struct Map_info *Map)
     G_debug(3, "Vect_get_next_line()");
-    if (!VECT_OPEN(Map))
-	G_fatal_error(_("Vector map is not open for reading"));
+    if (!VECT_OPEN(Map)) {
+	G_warning(_("Vector map is not open for reading"));
+        return -1;
     return Map->next_line - 1;
@@ -99,17 +102,17 @@
    This function implements sequential access, constraints are
    reflected, see Vect_set_constraint_region(),
-   Vect_set_constraint_type(), or Vect_set_constraint_field().
+   Vect_set_constraint_type(), or Vect_set_constraint_field() for
+   details.
-   Use Vect_rewind() to reset reading.
+   Use Vect_rewind() to reset reading. Topological level is not
+   required.
-   G_fatal_error() is called on failure.
+   A warning is printed on failure.
    \param Map pointer Map_info struct
-   \param[out] line_p feature geometry
-   (pointer to line_pnts struct)
-   \param[out] line_c feature categories
-   (pointer to line_cats struct)
+   \param[out] line_p feature geometry (pointer to line_pnts struct)
+   \param[out] line_c feature categories (pointer to line_cats struct)
    \return feature type (GV_POINT, GV_LINE, ...)
    \return -1 on error
@@ -122,32 +125,32 @@
     G_debug(3, "Vect_read_next_line(): next_line = %d", Map->next_line);
+        return -1;
     ret = (*Read_next_line_array[Map->format][Map->level]) (Map, line_p,
 							    line_c);
     if (ret == -1)
-	G_fatal_error(_("Unable to read feature %d vector map <%s>"),
-		      Map->next_line, Vect_get_full_name(Map));
+        G_warning(_("Unable to read feature %d from vector map <%s>"),
+                  Map->next_line, Vect_get_full_name(Map));
     return ret;
-   \brief Read vector feature
+   \brief Read vector feature (topological level required)
-   This function implements random access. Note that constraits are
-   ignored!
+   This function implements random access. Constraits are ignored.
+   Note: Topology must be built at level >= GV_BUILD_BASE
    \param Map pointer to vector map
    \param line feature id (starts at 1)
@@ -161,35 +164,43 @@
     G_debug(3, "Vect_read_line(): line = %d", line);
-    if (line < 1 || line > Map->plus.n_lines)
-	G_fatal_error(_("Requested feature id %d is not reasonable"
-			"(max features in vector map <%s>: %d)"),
-		      line, Vect_get_full_name(Map), Map->plus.n_lines);
+        return -1;
+    if (line < 1 || line > Map->plus.n_lines) {
+        G_warning(_("Attempt to access feature with invalid id (%d)"), line);
+        return -1;
     ret = (*Read_line_array[Map->format]) (Map, line_p, line_c, line);
     if (ret == -1)
-	G_fatal_error(_("Unable to read feature %d from vector map <%s>"),
-		      line, Vect_get_full_name(Map));
+                  line, Vect_get_full_name(Map));
     return ret;
-  \brief Check if feature is alive or dead (level 2 required)
+  \brief Check if feature is alive or dead (topological level required)
   \param Map pointer to Map_info structure
   \return 1 feature alive
   \return 0 feature is dead
 int Vect_line_alive(const struct Map_info *Map, int line)
+        return -1;
     if (Map->plus.Line[line] != NULL)
 	return 1;
@@ -197,8 +208,10 @@
-  \brief Check if node is alive or dead (level 2 required)
+  \brief Check if node is alive or dead (topological level required)
   \param node node id
@@ -207,6 +220,10 @@
 int Vect_node_alive(const struct Map_info *Map, int node)
+    if (node < 1 || node > Map->plus.n_nodes) {
+        return -1;
     if (Map->plus.Node[node] != NULL)
 	return 1;
@@ -214,16 +231,22 @@
-  \brief Check if area is alive or dead (level 2 required)
+  \brief Check if area is alive or dead (topological level required)
+  Note: Topology must be built at level >= GV_BUILD_AREAS
   \param area area id
   \return 1 area alive
   \return 0 area is dead
 int Vect_area_alive(const struct Map_info *Map, int area)
+    if (area < 1 || area > Map->plus.n_areas)
+        return -1;
     if (Map->plus.Area[area] != NULL)
 	return 1;
@@ -231,8 +254,10 @@
-  \brief Check if isle is alive or dead (level 2 required)
+  \brief Check if isle is alive or dead (topological level required)
   \param isle isle id
@@ -241,6 +266,9 @@
 int Vect_isle_alive(const struct Map_info *Map, int isle)
+    if (isle < 1 || isle > Map->plus.n_isles)
+        return -1;
     if (Map->plus.Isle[isle] != NULL)
 	return 1;
@@ -248,8 +276,10 @@
-  \brief Get feature offset
+  \brief Get feature offset (topological level required)
   Used for Vect_restore_line().
@@ -260,8 +290,9 @@
 off_t Vect_get_line_offset(const struct Map_info *Map, int line)
 	return -1;
     if (Map->plus.Line[line] != NULL) {
 	return Map->plus.Line[line]->offset;
Modified: grass/trunk/lib/vector/Vlib/read_nat.c
--- grass/trunk/lib/vector/Vlib/read_nat.c	2013-04-01 14:13:18 UTC (rev 55581)
+++ grass/trunk/lib/vector/Vlib/read_nat.c	2013-04-01 15:15:14 UTC (rev 55582)
@@ -122,11 +122,11 @@
   This function implements random access for native format,
   constraints are ignored!
-  \param[out] Points container used to store line points within
-  \param[out] Cats container used to store line categories within
+  \param[out] Points container used to store line points within (pointer to line_pnts struct)
+  \param[out] Cats container used to store line categories within (pointer to line_cats struct)
   \param line feature id to read (starts at 1)
@@ -140,10 +140,14 @@
     G_debug(3, "V2_read_line_nat(): line = %d", line);
+        return -1;
     Line = Map->plus.Line[line];
     if (Line == NULL) {
-	G_warning(_("Attempt to read dead feature %d"), line);
+	G_warning(_("Attempt to access dead feature %d"), line);
 	return -1;
Modified: grass/trunk/lib/vector/Vlib/read_sfa.c
--- grass/trunk/lib/vector/Vlib/read_sfa.c	2013-04-01 14:13:18 UTC (rev 55581)
+++ grass/trunk/lib/vector/Vlib/read_sfa.c	2013-04-01 15:15:14 UTC (rev 55582)
@@ -24,6 +24,8 @@
   This function implements random access on level 2.
   \param[out] line_p container used to store line points within
@@ -44,9 +46,14 @@
     G_debug(4, "V2_read_line_sfa() line = %d", line);
+        return -1;
     if (Line == NULL) {
         return -1;
@@ -106,9 +113,11 @@
     else
         type = V1_read_line_ogr(Map, line_p, line_c, Line->offset);
-    if (type != Line->type)
-        G_fatal_error(_("Unexpected feature type (%d) - should be (%d)"),
-                      type, Line->type);
+    if (type != Line->type) {
+        G_warning(_("Unexpected feature type (%d) - should be (%d)"),
+                  type, Line->type);
+        return -1;
     return type;
 #else
Modified: grass/trunk/lib/vector/Vlib/write.c
--- grass/trunk/lib/vector/Vlib/write.c	2013-04-01 14:13:18 UTC (rev 55581)
+++ grass/trunk/lib/vector/Vlib/write.c	2013-04-01 15:15:14 UTC (rev 55582)
@@ -5,20 +5,19 @@
-   Operations:
-    - Write new feature
-    - Rewrite feature
-    - Delete feature
+   Supported operations:
+    - Write a new feature
+    - Rewrite existing feature
+    - Delete existing feature
     - Restore deleted feature
-   (C) 2001-2010, 2012 by the GRASS Development Team
+   (C) 2001-2010, 2012-2013 by the GRASS Development Team
    \author Radim Blazek
-   \author Updated by Martin Landa <landa.martin gmail.com>
-   (restore lines, OGR & PostGIS support)
+   \author Updated by Martin Landa <landa.martin gmail.com> (restore lines, OGR & PostGIS support)
 #include <sys/types.h>
@@ -104,7 +103,7 @@
 #endif
 #ifdef HAVE_POSTGRES
-	rewrite_dummy, V1_rewrite_line_pg, V2_rewrite_line_sfa}
+	rewrite_dummy, V1_rewrite_line_pg, V2_rewrite_line_pg}
 #else
 	rewrite_dummy, format_l, format_l}
@@ -127,7 +126,7 @@
 #endif
-	delete_dummy, V1_delete_line_pg, V2_delete_line_sfa}
+	delete_dummy, V1_delete_line_pg, V2_delete_line_pg}
 #else
 	delete_dummy, format, format}
@@ -157,20 +156,22 @@
 #endif
+static int check_map(const struct Map_info *);
-   \brief Writes new feature
+   \brief Writes a new feature
    New feature is written to the end of file (in the case of native
-   format). Vector map topology is not required.
+   format). Topological level is not required.
-   Calls G_fatal_error() when vector map is not opened.
+   A warning is printed on error.
    \param type feature type (see dig_defines.h for supported types)
-   \param points ointer to line_pnts structure (feature geometry)
+   \param points pointer to line_pnts structure (feature geometry)
    \param cats pointer to line_cats structure (feature categories)
-   \return new feature id (on level 2)
+   \return new feature id (on level 2) (or 0 when build level < GV_BUILD_BASE)
    \return offset into file where the feature starts (on level 1)
    \return -1 on error
@@ -182,44 +183,42 @@
     G_debug(3, "Vect_write_line(): name = %s, format = %d, level = %d",
 	    Map->name, Map->format, Map->level);
-	G_fatal_error(_("Unable to write feature, vector map is not opened"));
+	G_warning(_("Vector map <%s> is not opened"), Vect_get_name(Map));
+        return -1;
     if (!(Map->plus.update_cidx)) {
-	Map->plus.cidx_up_to_date = FALSE;
+	Map->plus.cidx_up_to_date = FALSE; /* category index will be outdated */
     offset =
 	(*Vect_write_line_array[Map->format][Map->level]) (Map, type, points,
 							   cats);
-    if (offset == -1)
-	G_fatal_error(_("Unable to write feature (negative offset)"));
+    if (offset < 0)
+	G_warning(_("Unable to write feature in vector map <%s>"), Vect_get_name(Map));
-    /* note: returns new feature id on level 2 and file offset on
-       level 1 */
     return offset;
-   \brief Rewrites feature info at the given offset.
+   \brief Rewrites existing feature (topological level required)
-   Vector map must be opened with full topology (level 2).
    The number of points or cats or type may change. If necessary, the
    old feature is deleted and new is written.
-   This function calls G_fatal_error() on error.
    \param type feature type (GV_POINT, GV_LINE, ...)
    \param points feature geometry
    \param cats feature categories
-   \return feature offset
+   \return new feature offset
    \return -1 on error
 off_t Vect_rewrite_line(struct Map_info *Map, int line, int type,
@@ -227,33 +226,39 @@
     off_t ret, offset;
-	G_fatal_error(_("Unable to rewrite feature, vector map is not opened"));
+    if (!check_map(Map))
+        return -1;
+        return -1;
     offset = Map->plus.Line[line]->offset;
-    G_debug(3, "Vect_rewrite_line(): name = %s, line = %d offset = %lu",
+    G_debug(3, "Vect_rewrite_line(): name = %s, line = %d, offset = %lu",
 	    Map->name, line, offset);
     ret = (*Vect_rewrite_line_array[Map->format][Map->level]) (Map, line, type,
 							       offset,
 							       points, cats);
     if (ret == -1)
-	G_fatal_error(_("Unable to rewrite feature %d"), line);
+        G_warning(_("Unable to rewrite feature %d in vector map <%s>"), line, Vect_get_name(Map));
     return ret;
-   \brief Delete feature
+   \brief Delete existing feature (topological level required)
@@ -266,41 +271,37 @@
     G_debug(3, "Vect_delete_line(): name = %s, line = %d", Map->name, line);
-    if (Map->level < 2) {
-	G_fatal_error(_("Unable to delete feature %d, "
-			"vector map <%s> is not opened on topology level"),
-		      line, Map->name);
+        return -1;
+        return -1;
-    if (Map->mode != GV_MODE_RW && Map->mode != GV_MODE_WRITE) {
-			"vector map <%s> is not opened in 'write' mode"),
-		      line, Map->name);
     ret = (*Vect_delete_line_array[Map->format][Map->level]) (Map, line);
     if (ret == -1)
-	G_fatal_error(_("Unable to delete feature id %d from vector map <%s>"),
+	G_warning(_("Unable to delete feature %d from vector map <%s>"),
+                  line, Vect_get_name(Map));
     return ret;
-   \brief Restore previously deleted feature
+   \brief Restore previously deleted feature (topological level required)
    \param line feature id to be restored
+   \param offset feature offset
    \return 0 on success
    \return -1 on error
@@ -311,16 +312,12 @@
     G_debug(3, "Vect_restore_line(): name = %s, line = %d", Map->name, line);
-	G_fatal_error(_("Unable to restore feature %d, "
-		      line, Map->name);
+        return -1;
-		      line, Map->name);
+        return -1;
@@ -329,10 +326,31 @@
     ret = (*Vect_restore_line_array[Map->format][Map->level]) (Map, line, offset);
     if (ret == -1)
-	G_fatal_error(_("Unable to restore feature %d from vector map <%s>"),
-		      line, Map->name);
+	G_warning(_("Unable to restore feature %d in vector map <%s>"),
     return ret;
+int check_map(const struct Map_info *Map)
+        return 0;
+    if (Map->level < 2) {
+	G_warning(_("Vector map <%s> is not opened on topology level"),
+                  Vect_get_name(Map));
+        return 0;
+    if (Map->mode != GV_MODE_RW && Map->mode != GV_MODE_WRITE) {
+	G_warning(_("Vector map <%s> is not opened in write mode"),
+        return 0;
+    return 1;
Modified: grass/trunk/lib/vector/Vlib/write_nat.c
--- grass/trunk/lib/vector/Vlib/write_nat.c	2013-04-01 14:13:18 UTC (rev 55581)
+++ grass/trunk/lib/vector/Vlib/write_nat.c	2013-04-01 15:15:14 UTC (rev 55582)
@@ -1,11 +1,11 @@
    \file lib/vector/Vlib/write_nat.c
-   \brief Vector library - write/modify vector feature (native format)
+   \brief Vector library - write/modify/delete vector feature (native format)
-   (C) 2001-2012 by the GRASS Development Team
+   (C) 2001-2013 by the GRASS Development Team
@@ -24,298 +24,16 @@
 #include "local_proto.h"
+static struct line_cats *Cats;
+static struct line_pnts *Points;
 static off_t V1__rewrite_line_nat(struct Map_info *, off_t, int,
+static void V2__delete_area_cats_from_cidx_nat(struct Map_info *, int);
+static void V2__add_area_cats_to_cidx_nat(struct Map_info *, int);
-  \brief Deletes area (i.e. centroid) categories from category
-  index (internal use only)
-  Call G_fatal_error() when area do not exits.
-  \param Map pointer to Map_info structure
-  \param area area id
-static void V2__delete_area_cats_from_cidx_nat(struct Map_info *Map, int area)
-    int i;
-    struct P_area *Area;
-    static struct line_cats *Cats = NULL;
-    G_debug(3, "V2__delete_area_cats_from_cidx_nat(), area = %d", area);
-    Area = Map->plus.Area[area];
-    if (!Area)
-	G_fatal_error(_("%s: Area %d does not exist"),
-		      "delete_area_cats_from_cidx()", area);
-    if (Area->centroid == 0) /* no centroid found */
-	return;
-    if (!Cats)
-	Cats = Vect_new_cats_struct();
-    V2_read_line_nat(Map, NULL, Cats, Area->centroid);
-    for (i = 0; i < Cats->n_cats; i++) {
-	dig_cidx_del_cat(&(Map->plus), Cats->field[i], Cats->cat[i], area,
-			 GV_AREA);
-  \brief Adds area (i.e. centroid) categories from category index
-  (internal use only)
-static void V2__add_area_cats_to_cidx_nat(struct Map_info *Map, int area)
-    int i;
-    G_debug(3, "V2__add_area_cats_to_cidx_nat(), area = %d", area);
-    if (!Area)
-		      "add_area_cats_to_cidx():", area);
-	return;
-    if (!Cats)
-	dig_cidx_add_cat_sorted(&(Map->plus), Cats->field[i], Cats->cat[i],
-				area, GV_AREA);
-  \brief Add feature (line) to topo file (internal use only)
-  Update areas. Areas are modified if:
-  1) first or/and last point are existing nodes ->
-   - drop areas/islands whose boundaries are neighbour to this boundary at these nodes
-   - try build areas and islands for this boundary and neighbour boundaries going through these nodes
-   Question: may be by adding line created new area/isle which doesn't go through nodes of this line
-   <pre>
-             old         new line
-         | A1 | A2 |  +      /      ->  | A1 |   /|   or +   \   -> | A1 | A2 | \
-           I1   I1                        I1   I1
-   </pre>
-   - re-attach all centroids/isles inside new area(s)
-   - attach new isle to area outside
-  2) line is closed ring (node at the end is new, so it is not case above)
-    - build new area/isle
-    - check if it is island or contains island(s)
-    Note that 1) and 2) is done by the same code.
-    \param line feature id
-    \param points pointer to line_pnts structure (feature's geometry)
-    \param cats pointer to line_cats structure (feature's categories)
-void V2__add_line_to_topo_nat(struct Map_info *Map, int line,
-                              const struct line_pnts *points, const struct line_cats *cats,
-    int first, s, n, i;
-    int type, node, next_line, area, side, sel_area, new_area[2];
-    struct Plus_head *plus;
-    struct P_line *Line, *NLine;
-    struct P_node *Node;
-    struct bound_box box, abox;
-    G_debug(3, "V2__add_line_to_topo_nat(), line = %d", line);
-    plus = &(Map->plus);
-    Line = plus->Line[line];
-    type = Line->type;
-    if (plus->built >= GV_BUILD_AREAS &&
-	type == GV_BOUNDARY) {
-	struct P_topo_b *topo = (struct P_topo_b *)Line->topo;
-	/* Delete neighbour areas/isles */
-	first = TRUE;
-	for (s = 0; s < 2; s++) {	/* for each node */
-	    node = (s == 0 ? topo->N1 : topo->N2);
-	    G_debug(3,
-		    "  delete neighbour areas/isles: %s node = %d",
-		    (s == 0 ? "first" : "second"), node);
-	    Node = plus->Node[node];
-	    n = 0;
-	    for (i = 0; i < Node->n_lines; i++) {
-		NLine = plus->Line[abs(Node->lines[i])];
-		if (NLine->type == GV_BOUNDARY)
-		    n++;
-	    G_debug(3, "  number of boundaries at node = %d", n);
-	    if (n > 2) {
-		/* more than 2 boundaries at node ( >= 2 old + 1 new ) */
-		/* Line above (to the right), it is enough to check to
-		   the right, because if area/isle exists it is the
-		   same to the left */
-		if (!s)
-		    next_line =
-			dig_angle_next_line(plus, line, GV_RIGHT,
-					    GV_BOUNDARY, NULL);
-		else
-		    next_line =
-			dig_angle_next_line(plus, -line, GV_RIGHT,
-		if (next_line != 0) {	/* there is a boundary to the right */
-		    NLine = plus->Line[abs(next_line)];
-		    topo = (struct P_topo_b *)NLine->topo;
-		    if (next_line > 0)	/* the boundary is connected by 1. node */
-			/* we are interested just in this side (close to our line) */
-			area = topo->right;
-		    else if (next_line < 0)	/* the boundary is connected by 2. node */
-			area = topo->left;
-		    G_debug(3, "  next_line = %d area = %d", next_line,
-			    area);
-		    if (area > 0) {	/* is area */
-			Vect_get_area_box(Map, area, &box);
-			if (first) {
-			    Vect_box_copy(&abox, &box);
-			    first = FALSE;
-			else
-			    Vect_box_extend(&abox, &box);
-			if (plus->update_cidx) {
-			    V2__delete_area_cats_from_cidx_nat(Map, area);
-			dig_del_area(plus, area);
-                        if (external_routine) /* call external subroutine if defined */
-                            external_routine(Map, area);
-		    else if (area < 0) {	/* is isle */
-			dig_del_isle(plus, -area);
-	/* Build new areas/isles.
-	 * It's true that we deleted also adjacent areas/isles, but
-	 * if they form new one our boundary must participate, so
-	 * we need to build areas/isles just for our boundary */
-	    side = (s == 0 ? GV_LEFT : GV_RIGHT);
-	    area = Vect_build_line_area(Map, line, side);
-	    if (area > 0) {	/* area */
-		if (first) {
-		    first = FALSE;
-		else
-		/* isle -> must be attached -> add to abox */
-		Vect_get_isle_box(Map, -area, &box);
-		if (first) {
-		    first = FALSE;
-		else
-	    new_area[s] = area;
-	/* Reattach all centroids/isles in deleted areas + new area.
-	 * Because isles are selected by box it covers also possible
-	 * new isle created above */
-	if (!first) { /* i.e. old area/isle was deleted or new one created */
-	    /* Reattach isles */
-	    if (plus->built >= GV_BUILD_ATTACH_ISLES)
-		Vect_attach_isles(Map, &abox);
-	    /* Reattach centroids */
-	    if (plus->built >= GV_BUILD_CENTROIDS)
-		Vect_attach_centroids(Map, &abox);
-	/* Add to category index */
-		if (new_area[s] > 0) {
-		    V2__add_area_cats_to_cidx_nat(Map, new_area[s]);
-    /* Attach centroid */
-    if (plus->built >= GV_BUILD_CENTROIDS) {
-	struct P_topo_c *topo;
-	if (type == GV_CENTROID) {
-	    sel_area = Vect_find_area(Map, points->x[0], points->y[0]);
-	    G_debug(3, "  new centroid %d is in area %d", line, sel_area);
-	    if (sel_area > 0) {
-		Area = plus->Area[sel_area];
-		topo = (struct P_topo_c *)Line->topo;
-		if (Area->centroid == 0) {	/* first centroid */
-		    G_debug(3, "  first centroid -> attach to area");
-		    Area->centroid = line;
-		    topo->area = sel_area;
-			V2__add_area_cats_to_cidx_nat(Map, sel_area);
-		else {		/* duplicate centroid */
-		    G_debug(3,
-			    "  duplicate centroid -> do not attach to area");
-		    topo->area = -sel_area;
-    /* Add category index */
-    if (cats) {
-        for (i = 0; i < cats->n_cats; i++) {
-            dig_cidx_add_cat_sorted(plus, cats->field[i], cats->cat[i], line,
-                                    type);
-    return;
-  \brief Writes feature to 'coor' file (level 1)
+  \brief Writes feature to 'coor' file at level 1 (internal use only)
@@ -325,8 +43,8 @@
   \return feature offset into file
   \return -1 on error
-off_t V1_write_line_nat(struct Map_info *Map,
-		       int type, const struct line_pnts *points, const struct line_cats *cats)
+off_t V1_write_line_nat(struct Map_info *Map, int type,
+                        const struct line_pnts *points, const struct line_cats *cats)
     off_t offset;
@@ -334,6 +52,7 @@
 	return -1;
     offset = dig_ftell(&(Map->dig_fp));
+    G_debug(3, "V1_write_line_nat(): offset = %lu", offset);
     if (offset == -1)
 	return -1;
@@ -342,65 +61,46 @@
   \brief Writes feature to 'coor' file at topological level (internal use only)
+  Note: Function returns feature id, but is defined as off_t for
+  compatibility with level 1 functions.
+  \return 0 topology is not requested to be built (build level < GV_BUILD_BASE)
   \return -1 on error
 off_t V2_write_line_nat(struct Map_info *Map, int type,
-    int line;
     off_t offset;
-    struct bound_box box;
-    line = 0;
+    G_debug(3, "V2_write_line_nat(): type=%d", type);
-    G_debug(3, "V2_write_line_nat()");
+    /* write feature to 'coor' file */
     offset = V1_write_line_nat(Map, type, points, cats);
     if (offset < 0)
 	return -1;
-    /* Update topology */
-    /* Add line */
-    if (plus->built >= GV_BUILD_BASE) {
-	dig_line_box(points, &box);
-	line = dig_add_line(plus, type, points, &box, offset);
-	G_debug(3, "  line added to topo with id = %d", line);
-	if (line == 1)
-	    Vect_box_copy(&(plus->box), &box);
-	else
-	    Vect_box_extend(&(plus->box), &box);
-    V2__add_line_to_topo_nat(Map, line, points, cats, NULL);
-    G_debug(3, "updated lines : %d , updated nodes : %d", plus->uplist.n_uplines,
-	    plus->uplist.n_upnodes);
-    /* returns int line, but is defined as off_t for compatibility with
-     * Vect_write_line_array in write.c */
-    return line;
+    /* update topology (build level >= GV_BUILD_BASE) */
+    return V2__add_line_to_topo_nat(Map, offset, type, points, cats, -1, NULL);
-  \brief Rewrites feature at the given offset (level 1)
+  \brief Rewrites feature to 'coor' file at level 1 (internal use only)
-  If the number of points or cats differs from the original one or
-  the type is changed: GV_POINTS -> GV_LINES or GV_LINES ->
-  GV_POINTS, the old one is deleted and the new is appended to the
-  end of the file.
+  If the number of points or cats differs from the original one or the
+  type is changed: GV_POINTS -> GV_LINES or GV_LINES -> GV_POINTS, the
+  old one is deleted and the new is appended to the end of the file.
-  Old feature is deleted (marked as dead), new feature written.
+  Old feature is deleted (marked as dead), and a new feature written.
+  \param line feature id to be rewritten
@@ -458,14 +158,20 @@
   \brief Rewrites feature to 'coor' file at topological level (internal use only)
-  \param type feature type  (GV_POINT, GV_LINE, ...)
+  \param type feature type (GV_POINT, GV_LINE, ...)
+  \param old_offset feature offset
-  \return offset where line was rewritten
   \return -1 on error
 off_t V2_rewrite_line_nat(struct Map_info *Map, int line, int type, off_t old_offset,
@@ -478,45 +184,216 @@
      *        angles not changed etc.) */
     off_t offset;
-    V2_delete_line_nat(Map, line);
+    if (0 != V2_delete_line_nat(Map, line))
+        return -1;
     G_debug(3, "V2_write_line_nat(), line = %d", line);
+    /* rewrite feature in 'coor' file */
     offset = V1_rewrite_line_nat(Map, line, type, old_offset, points, cats);
     if (offset < 0)
 	return -1;
+    /* update topology */
+  \brief Deletes feature at level 1 (internal use only)
+  \param Map pointer Map_info structure
+  \return  0 on success
+int V1_delete_line_nat(struct Map_info *Map, off_t offset)
+    char rhead;
+    struct gvfile *dig_fp;
+    G_debug(3, "V1_delete_line_nat(): offset = %lu", (unsigned long) offset);
+    dig_set_cur_port(&(Map->head.port));
+    dig_fp = &(Map->dig_fp);
+    if (dig_fseek(dig_fp, offset, 0) == -1)
+	return -1;
+    /* read old */
+    if (0 >= dig__fread_port_C(&rhead, 1, dig_fp))
+	return -1;
+    rhead &= 0xFE;
+	return -1;
+    if (0 >= dig__fwrite_port_C(&rhead, 1, dig_fp))
+	return -1;
+    if (0 != dig_fflush(dig_fp))
+	return -1;
+    return 0;
+  \brief Deletes feature at topological level (internal use only)
+  \param pointer to Map_info structure
+int V2_delete_line_nat(struct Map_info *Map, int line)
+    int type;
+    struct P_line *Line;
+    struct Plus_head *plus;
+    G_debug(3, "V2_delete_line_nat(): line = %d", line);
+    Line = NULL;
-    /* Add line */
-	if (line == 1)
-	else
+    if (line < 1 || line > plus->n_lines) {
+        return -1;
+    Line = Map->plus.Line[line];
+    if (Line == NULL) {
+        return -1;
+    /* read the line */
+    if (!Points) {
+	Points = Vect_new_line_struct();
+    if (!Cats) {
+	Cats = Vect_new_cats_struct();
+    type = V2_read_line_nat(Map, Points, Cats, line);
+    if (type < 0)
+        return -1;
+    /* delete feature from coor file */
+    if (0 != V1_delete_line_nat(Map, Line->offset))
+        return -1;
-     * Vect_rewrite_line_array in write.c */
+    /* delete feature from topology */
+    if (0 != V2__delete_line_from_topo_nat(Map, line, type, Points, Cats))
+        return -1;
-    return line;
+    return 0;
-  \brief Rewrites feature at the given offset.
+  \brief Restores feature at level 1 (internal use only)
+int V1_restore_line_nat(struct Map_info *Map, off_t offset)
+    char rhead;
+    G_debug(3, "V1_restore_line_nat(), offset = %lu", (unsigned long) offset);
+	return -1;
+    /* read old */
+	return -1;
+    /* mark as alive */
+    rhead |= 1;
+    /* write new */
+	return -1;
+	return -1;
+	return -1;
+    return 0;
+  \brief Restores feature at topological level (internal use only)
+  Note: This function requires build level >= GV_BUILD_BASE.
+  \param Map pointer to Map_info structure
+int V2_restore_line_nat(struct Map_info *Map, int line, off_t offset)
+    int type;
+    plus = &(Map->plus);
+    G_debug(3, "V2_restore_line_nat(), line = %d", line);
+        return -1;
+    if (Line != NULL) {
+        G_warning(_("Attempt to access alive feature %d"), line);
+        return -1;
+    /* restore feature in 'coor' file */
+    if (0 != V1_restore_line_nat(Map, offset))
+	return -1;
+    /* read feature geometry */
+    if (!Points)
+    if (!Cats)
+    type = V1_read_line_nat(Map, Points, Cats, offset);
+    if (type < 0)
+	return -1;
+    return V2__add_line_to_topo_nat(Map, offset, type, Points, Cats, line, NULL) > 0 ? 0 : -1;
+/*** static or internal subroutines bellow ****/
+  \brief Rewrites feature at the given offset
@@ -611,109 +488,135 @@
     return offset;
-  \brief Deletes feature at the given offset (level 1)
+  \brief Deletes area (i.e. centroid) categories from category
+  index (internal use only)
+  Call G_fatal_error() when area do not exits.
-  \param Map pointer Map_info structure
-  \param offset feature offset
-  \return  0 on success
-  \return -1 on error
+  \param area area id
-int V1_delete_line_nat(struct Map_info *Map, off_t offset)
+void V2__delete_area_cats_from_cidx_nat(struct Map_info *Map, int area)
-    char rhead;
-    struct gvfile *dig_fp;
+    int i;
+    struct P_area *Area;
+    static struct line_cats *Cats = NULL;
-    G_debug(3, "V1_delete_line_nat(), offset = %lu", (unsigned long) offset);
+    G_debug(3, "V2__delete_area_cats_from_cidx_nat(), area = %d", area);
-    dig_set_cur_port(&(Map->head.port));
-    dig_fp = &(Map->dig_fp);
+    Area = Map->plus.Area[area];
+    if (!Area)
+	G_fatal_error(_("%s: Area %d does not exist"),
+		      "delete_area_cats_from_cidx()", area);
+    if (Area->centroid == 0) /* no centroid found */
+	return;
-    if (dig_fseek(dig_fp, offset, 0) == -1)
-	return -1;
+    if (!Cats)
-    /* read old */
-    if (0 >= dig__fread_port_C(&rhead, 1, dig_fp))
-	return (-1);
+    V2_read_line_nat(Map, NULL, Cats, Area->centroid);
-    rhead &= 0xFE;
+    for (i = 0; i < Cats->n_cats; i++) {
+	dig_cidx_del_cat(&(Map->plus), Cats->field[i], Cats->cat[i], area,
+			 GV_AREA);
-	return -1;
+  \brief Adds area (i.e. centroid) categories from category index
+  (internal use only)
-    if (0 >= dig__fwrite_port_C(&rhead, 1, dig_fp))
-	return -1;
-    if (0 != dig_fflush(dig_fp))
-	return -1;
-    return 0;
-  \brief Deletes feature at topological level (internal use only)
-  \param pointer to Map_info structure
-int V2_delete_line_nat(struct Map_info *Map, int line)
+void V2__add_area_cats_to_cidx_nat(struct Map_info *Map, int area)
-    int ret, i, side, type, first, next_line, area;
-    struct P_line *Line;
+    int i;
-    int adjacent[4], n_adjacent;
-    static struct line_pnts *Points = NULL;
-    G_debug(3, "V2_delete_line_nat(), line = %d", line);
+    G_debug(3, "V2__add_area_cats_to_cidx_nat(), area = %d", area);
-    type = first = n_adjacent = 0;
-    Line = NULL;
+    if (!Area)
+		      "add_area_cats_to_cidx():", area);
-	Line = Map->plus.Line[line];
+	return;
-	if (Line == NULL)
-	    G_fatal_error(_("Attempt to delete dead feature"));
-    if (!Cats) {
+    if (!Cats)
-    if (!Points) {
-	Points = Vect_new_line_struct();
-    type = V2_read_line_nat(Map, Points, Cats, line);
-    /* Update category index */
-	    dig_cidx_del_cat(plus, Cats->field[i], Cats->cat[i], line, type);
+	dig_cidx_add_cat_sorted(&(Map->plus), Cats->field[i], Cats->cat[i],
+				area, GV_AREA);
-    /* delete the line from coor */
-    ret = V1_delete_line_nat(Map, Line->offset);
+  \brief Delete feature from topology (internal use only)
-    if (ret == -1) {
-	return ret;
+  Also updates category index if requested.
+  Calls G_warning() on error.
+  \param line feature id to be removed
+  \param Points feature geometry (pointer to line_pnts struct)
+  \param external_routine external subroutine to execute (used by PostGIS Topology)
+  \return -1 on failure
+int V2__delete_line_from_topo_nat(struct Map_info *Map, int line, int type,
+    int i, first;
+    int adjacent[4], n_adjacent;
+    struct bound_box box, abox;
+    n_adjacent = 0;
+        return -1;
+    if (!Line) {
+        return -1;
-    if (plus->built >= GV_BUILD_AREAS && type == GV_BOUNDARY) {
+    /* delete feature from category index */
+    if (plus->update_cidx && cats) {
+        for (i = 0; i < cats->n_cats; i++) {
+            dig_cidx_del_cat(plus, cats->field[i], cats->cat[i], line, type);
+    /* update areas when deleting boundary from topology */
+    if (plus->built >= GV_BUILD_AREAS && Line->type == GV_BOUNDARY) {
+        int next_line;
+        struct P_topo_b *topo = (struct P_topo_b *)Line->topo;
-	/* Store adjacent boundaries at nodes (will be used to rebuild area/isle) */
-	/* Adjacent are stored: > 0 - we want right side; < 0 - we want left side */
+	/* store adjacent boundaries at nodes (will be used to rebuild area/isle) */
+	/* adjacent are stored: > 0 - we want right side; < 0 - we want left side */
 	n_adjacent = 0;
 	next_line = dig_angle_next_line(plus, line, GV_RIGHT, GV_BOUNDARY, NULL);
@@ -741,7 +644,7 @@
 	    n_adjacent++;
-	/* Delete area(s) and islands this line forms */
+	/* delete area(s) and islands this line forms */
 	first = 1;
 	if (topo->left > 0) {	/* delete area */
 	    Vect_get_area_box(Map, topo->left, &box);
@@ -779,8 +682,10 @@
-    /* Delete reference from area */
-    if (plus->built >= GV_BUILD_CENTROIDS && type == GV_CENTROID) {
+    /* delete reference from area */
+    if (plus->built >= GV_BUILD_CENTROIDS && Line->type == GV_CENTROID) {
 	struct P_topo_c *topo = (struct P_topo_c *)Line->topo;
 	if (topo->area > 0) {
@@ -792,15 +697,17 @@
 	    if (Area)
 		Area->centroid = 0;
 	    else
-		G_warning(_("Attempt to access dead area (%d)"), topo->area);
+		G_warning(_("Attempt to access dead area %d"), topo->area);
     /* delete the line from topo */
-    dig_del_line(plus, line, Points->x[0], Points->y[0], Points->z[0]);
-    /* Rebuild areas/isles and attach centroids and isles */
+    if (0 != dig_del_line(plus, line, points->x[0], points->y[0], points->z[0]))
+        return -1;
+    /* rebuild areas/isles and attach centroids and isles */
+        int i, side, area;
 	int new_areas[4], nnew_areas = 0;
 	/* Rebuild areas/isles */
@@ -834,14 +741,14 @@
-	 *  Because isles are selected by box it covers also possible new isle created above */
+	/* reattach all centroids/isles in deleted areas + new area.
+	 *  because isles are selected by box it covers also possible new isle created above */
+	    /* reattach isles */
+	    /* reattach centroids */
@@ -853,128 +760,257 @@
-    return ret;
+    if (plus->uplist.do_uplist) {
+        G_debug(3, "updated lines : %d , updated nodes : %d", plus->uplist.n_uplines,
+                plus->uplist.n_upnodes);
+    return 0;
-  \brief Restores feature at the given offset.
-int V1_restore_line_nat(struct Map_info *Map, off_t offset)
-    char rhead;
-    G_debug(3, "V1_restore_line_nat(), offset = %lu", (unsigned long) offset);
-	return -1;
-    /* read old */
-	return (-1);
+  \brief Add feature (line) to topology (internal use only)
-    /* mark as alive */
-    rhead |= 1;
-    /* write new */
-	return -1;
-	return -1;
+  Update areas. Areas are modified if:
+  1) first or/and last point are existing nodes ->
+   - drop areas/islands whose boundaries are neighbour to this boundary at these nodes
+   - try build areas and islands for this boundary and neighbour boundaries going through these nodes
+   Question: may be by adding line created new area/isle which doesn't go through nodes of this line
+   <pre>
+             old         new line
+         | A1 | A2 |  +      /      ->  | A1 |   /|   or +   \   -> | A1 | A2 | \
+           I1   I1                        I1   I1
+   </pre>
+   - re-attach all centroids/isles inside new area(s)
+   - attach new isle to area outside
+  2) line is closed ring (node at the end is new, so it is not case above)
+    - build new area/isle
+    - check if it is island or contains island(s)
-	return -1;
-    return 0;
+    Note that 1) and 2) is done by the same code.
-  \brief Restores feature at topological level (internal use only)
+    \param line feature id to be added
+    \param points pointer to line_pnts structure (feature's geometry)
+    \param cats pointer to line_cats structure (feature's categories)
+    \param external_routine pointer to external routine (used by PostGIS Topology)
+    \return feature id to be added
+    \return 0 nothing to do (build level must be >= GV_BUILD_BASE)
-int V2_restore_line_nat(struct Map_info *Map, int line, off_t offset)
+int V2__add_line_to_topo_nat(struct Map_info *Map, off_t offset, int type,
+                             const struct line_pnts *points, const struct line_cats *cats,
+                             int restore_line,
-    int i, ret, type;
+    int first, s, n, i, line;
+    int node, next_line, area, side, sel_area, new_area[2];
+    struct P_line *Line, *NLine;
+    struct P_node *Node;
-    static struct line_pnts *points = NULL;
-    static struct line_cats *cats = NULL;
-    Line = NULL;
-    type = 0;
-    G_debug(3, "V2_restore_line_nat(), line = %d", line);
+    G_debug(3, "V2__add_line_to_topo_nat(): offset = %ld (build level = %d)", offset, plus->built);
+    if (plus->built < GV_BUILD_BASE) /* nothing to build */
+        return 0;
+    /* add line to topology */
+    dig_line_box(points, &box);
+    if (restore_line > 0)
+        line = dig_restore_line(plus, restore_line, type, points, &box, offset);
+    else
+        line = dig_add_line(plus, type, points, &box, offset);
+    G_debug(3, "  line added to topo with id = %d", line);
+    Line = plus->Line[line];
+    /* extend map bounding box */
+    if (line == 1)
+        Vect_box_copy(&(plus->box), &box);
+    else
+        Vect_box_extend(&(plus->box), &box);
-	if (Line != NULL)
-	    G_fatal_error(_("Attempt to restore alive feature"));
+    /* build areas on left/right side */
+	type == GV_BOUNDARY) {
+	/* delete neighbour areas/isles */
+	first = TRUE;
+	for (s = 0; s < 2; s++) {	/* for each node */
+	    node = (s == 0 ? topo->N1 : topo->N2);
+	    G_debug(3,
+		    "  delete neighbour areas/isles: %s node = %d",
+		    (s == 0 ? "first" : "second"), node);
+	    Node = plus->Node[node];
+	    n = 0;
+	    for (i = 0; i < Node->n_lines; i++) {
+		NLine = plus->Line[abs(Node->lines[i])];
+		if (NLine->type == GV_BOUNDARY)
+		    n++;
+	    G_debug(3, "  number of boundaries at node = %d", n);
+	    if (n > 2) {
+		/* more than 2 boundaries at node ( >= 2 old + 1 new ) */
+		/* Line above (to the right), it is enough to check to
+		   the right, because if area/isle exists it is the
+		   same to the left */
+		if (!s)
+		    next_line =
+			dig_angle_next_line(plus, line, GV_RIGHT,
+					    GV_BOUNDARY, NULL);
+		else
+		    next_line =
+			dig_angle_next_line(plus, -line, GV_RIGHT,
+		if (next_line != 0) {	/* there is a boundary to the right */
+		    NLine = plus->Line[abs(next_line)];
+		    topo = (struct P_topo_b *)NLine->topo;
+		    if (next_line > 0)	/* the boundary is connected by 1. node */
+			/* we are interested just in this side (close to our line) */
+			area = topo->right;
+		    else if (next_line < 0)	/* the boundary is connected by 2. node */
+			area = topo->left;
+		    G_debug(3, "  next_line = %d area = %d", next_line,
+			    area);
+		    if (area > 0) {	/* is area */
+			Vect_get_area_box(Map, area, &box);
+			if (first) {
+			    Vect_box_copy(&abox, &box);
+			    first = FALSE;
+			else
+			    Vect_box_extend(&abox, &box);
+			if (plus->update_cidx) {
+			    V2__delete_area_cats_from_cidx_nat(Map, area);
+			dig_del_area(plus, area);
+                        if (external_routine) /* call external subroutine if defined */
+                            external_routine(Map, area);
+		    else if (area < 0) {	/* is isle */
+			dig_del_isle(plus, -area);
+	/* Build new areas/isles.
+	 * It's true that we deleted also adjacent areas/isles, but
+	 * if they form new one our boundary must participate, so
+	 * we need to build areas/isles just for our boundary */
+	    side = (s == 0 ? GV_LEFT : GV_RIGHT);
+	    area = Vect_build_line_area(Map, line, side);
+	    if (area > 0) {	/* area */
+		if (first) {
+		    first = FALSE;
+		else
+		/* isle -> must be attached -> add to abox */
+		Vect_get_isle_box(Map, -area, &box);
+		if (first) {
+		    first = FALSE;
+		else
+	    new_area[s] = area;
+	/* Reattach all centroids/isles in deleted areas + new area.
+	 * Because isles are selected by box it covers also possible
+	 * new isle created above */
+	if (!first) { /* i.e. old area/isle was deleted or new one created */
+	    /* Reattach isles */
+	    if (plus->built >= GV_BUILD_ATTACH_ISLES)
+		Vect_attach_isles(Map, &abox);
+	    /* Reattach centroids */
+	    if (plus->built >= GV_BUILD_CENTROIDS)
+		Vect_attach_centroids(Map, &abox);
+	/* Add to category index */
+		if (new_area[s] > 0) {
+		    V2__add_area_cats_to_cidx_nat(Map, new_area[s]);
+    /* attach centroid */
+    if (plus->built >= GV_BUILD_CENTROIDS) {
+	struct P_topo_c *topo;
-    if (!points) {
-	points = Vect_new_line_struct();
+	if (type == GV_CENTROID) {
+	    sel_area = Vect_find_area(Map, points->x[0], points->y[0]);
+	    G_debug(3, "  new centroid %d is in area %d", line, sel_area);
+	    if (sel_area > 0) {
+		Area = plus->Area[sel_area];
+		topo = (struct P_topo_c *)Line->topo;
+		if (Area->centroid == 0) {	/* first centroid */
+		    G_debug(3, "  first centroid -> attach to area");
+		    Area->centroid = line;
+		    topo->area = sel_area;
+			V2__add_area_cats_to_cidx_nat(Map, sel_area);
+		else {		/* duplicate centroid */
+		    G_debug(3,
+			    "  duplicate centroid -> do not attach to area");
+		    topo->area = -sel_area;
-    if (!cats) {
-	cats = Vect_new_cats_struct();
+    /* add category index */
+            dig_cidx_add_cat_sorted(plus, cats->field[i], cats->cat[i], line,
+                                    type);
-    /* restore the line in coor */
-    ret = V1_restore_line_nat(Map, offset);
-    if (ret == -1) {
-	return ret;
-    /* read feature geometry */
-    type = V1_read_line_nat(Map, points, cats, offset);
-    if (type < 0) {
-	return -1;
-    /* update category index */
-	    dig_cidx_add_cat(plus, cats->field[i], cats->cat[i], line, type);
-    /* restore the line from topo */
-	dig_restore_line(plus, line, type, points, &box, offset);
-	G_debug(3, "  line restored in topo with id = %d", line);
-    return ret;
+    return line;
Modified: grass/trunk/lib/vector/Vlib/write_sfa.c
--- grass/trunk/lib/vector/Vlib/write_sfa.c	2013-04-01 14:13:18 UTC (rev 55581)
+++ grass/trunk/lib/vector/Vlib/write_sfa.c	2013-04-01 15:15:14 UTC (rev 55582)
@@ -126,7 +126,9 @@
   \brief Rewrites feature at the given offset on level 2 (OGR/PostGIS
   interface, pseudo-topological level)
   \param type feature type (see V1_write_line_ogr() for supported types)
@@ -143,13 +145,19 @@
     G_debug(3, "V2_rewrite_line_sfa(): line=%d type=%d offset=%lu",
 	    line, type, offset);
+        return -1;
 #if defined HAVE_OGR || defined HAVE_POSTGRES
     if (type != V2_read_line_sfa(Map, NULL, NULL, line)) {
 	G_warning(_("Unable to rewrite feature (incompatible feature types)"));
 	return -1;
-    V2_delete_line_sfa(Map, line);
+    if (V2_delete_line_sfa(Map, line) != 0)
+        return -1;
     return V2_write_line_sfa(Map, type, points, cats);
 #else
@@ -160,6 +168,8 @@
   \brief Deletes feature on level 2 (OGR/PostGIS interface)
   \todo Update fidx
@@ -178,12 +188,17 @@
-    G_debug(3, "V2_delete_line_sfa(), line = %d", line);
+    G_debug(3, "V2_delete_line_sfa(): line = %d", line);
     type = first = 0;
     Line = NULL;
+        return -1;
@@ -200,7 +215,9 @@
     type = V2_read_line_sfa(Map, Points, Cats, line);
+    if (type < 0)
+        return -1;
