[GRASS-SVN] r55694 - grass/trunk/lib/vector/Vlib
Wed Apr 10 13:57:57 PDT 2013
Author: martinl
Date: 2013-04-10 13:57:56 -0700 (Wed, 10 Apr 2013)
New Revision: 55694
   grass/trunk/lib/vector/Vlib/open_ogr.c
   grass/trunk/lib/vector/Vlib/open_pg.c
vlib/ogr|pg: remove unused function
             dox cosmetics
Modified: grass/trunk/lib/vector/Vlib/open_ogr.c
--- grass/trunk/lib/vector/Vlib/open_ogr.c	2013-04-10 20:37:27 UTC (rev 55693)
+++ grass/trunk/lib/vector/Vlib/open_ogr.c	2013-04-10 20:57:56 UTC (rev 55694)
@@ -26,8 +26,6 @@
 #ifdef HAVE_OGR
 #include <ogr_api.h>
-static int sqltype_to_ogrtype(int);
 #endif
@@ -161,7 +159,8 @@
    \brief Prepare OGR datasource for creating new OGR layer (level 1)
-   New OGR layer is created by Vect__open_new_ogr().
+   New OGR layer is created when writing features by
+   Vect_wrile_line().
    \param[out] Map pointer to Map_info structure
    \param name name of OGR layer to create
@@ -317,32 +316,3 @@
     return 0;
-#ifdef HAVE_OGR
-int sqltype_to_ogrtype(int sqltype)
-    int ctype, ogrtype;
-    ctype = db_sqltype_to_Ctype(sqltype);
-    switch(ctype) {
-    case DB_C_TYPE_INT:
-	ogrtype = OFTInteger;
-	break;
-    case DB_C_TYPE_DOUBLE:
-	ogrtype = OFTReal;
-	break;
-    case DB_C_TYPE_STRING:
-	ogrtype = OFTString;
-	break;
-    case DB_C_TYPE_DATETIME:
-	break;
-    default:
-	break;
-    return ogrtype;
-#endif
Modified: grass/trunk/lib/vector/Vlib/open_pg.c
--- grass/trunk/lib/vector/Vlib/open_pg.c	2013-04-10 20:37:27 UTC (rev 55693)
+++ grass/trunk/lib/vector/Vlib/open_pg.c	2013-04-10 20:57:56 UTC (rev 55694)
@@ -5,7 +5,7 @@
    Higher level functions for reading/writing/manipulating vectors.
-   (C) 2011-2012 by the GRASS Development Team
+   (C) 2011-2013 by the GRASS Development Team
    This program is free software under the GNU General Public License
    (>=v2). Read the file COPYING that comes with GRASS for details.
@@ -48,10 +48,9 @@
 #endif
-   \brief Open vector map - PostGIS feature table (level 1 - without topology)
+   \brief Open vector map - PostGIS feature table on non-topological
+   level
-   \todo Check database instead of geometry_columns
    \param[in,out] Map pointer to Map_info structure
    \param update TRUE for write mode, otherwise read-only
@@ -144,8 +143,13 @@
-   \brief Open vector map - PostGIS feature table (level 2 - feature index)
+   \brief Open vector map - PostGIS feature table on topological level
+   Simple feature access:
+    - open feature index file
+   PostGIS Topology:
+    - check if topological schema exists
    \return 0 success
@@ -199,7 +203,8 @@
    \brief Prepare PostGIS database for creating new feature table
    (level 1)
-   \todo To implement
+   New PostGIS table is created when writing features by
    \param name name of PostGIS feature table to create
