[GRASS-SVN] r55921 - grass/trunk/tools
Fri Apr 19 10:54:21 PDT 2013
Author: wenzeslaus
Date: 2013-04-19 10:54:21 -0700 (Fri, 19 Apr 2013)
New Revision: 55921
Added:
   grass/trunk/tools/pep8config.txt
   grass/trunk/tools/pylintrc.txt
python: configuration files for pep8 and pylint tools (a lot of messages now ignored)
Added: grass/trunk/tools/pep8config.txt
--- grass/trunk/tools/pep8config.txt	                        (rev 0)
+++ grass/trunk/tools/pep8config.txt	2013-04-19 17:54:21 UTC (rev 55921)
@@ -0,0 +1,26 @@
+# This is a configuration file for pep8.
+# (C) 2011-2013 by the GRASS Development Team
+# This program is free software under the GNU General Public License
+# (>=v2). Read the file COPYING that comes with GRASS for details.
+# author: Vaclav Petras <wenzeslaus gmail.com>
+# This configuration should work for all Python library, Python scripts and
+# wxPython GUI.
+# Example for gui/wxpython:
+#   pep8 --config=../../tools/pep8config.txt lmgr/
+# A lot of errors need to be ignored now to avoid a large number of messages.
+# Files need to be fixed one by one (without this configuration).
+[pep8]
+# skip errors and warnings (e.g. E4,W)
+ignore=E121,E122,E123,E124,E125,E126,E127,E128,E201,E202,E203,E211,E221,E222,E225,E231,E241,E251,E261,E271,E272,E302,E303,E502,W191,W291,W293
+# set maximum allowed line length (default: 79)
+max-line-length=150
Property changes on: grass/trunk/tools/pep8config.txt
___________________________________________________________________
Added: svn:mime-type
   + text/plain
Added: svn:keywords
   + Author Date Id
Added: svn:eol-style
   + native
Added: grass/trunk/tools/pylintrc.txt
--- grass/trunk/tools/pylintrc.txt	                        (rev 0)
+++ grass/trunk/tools/pylintrc.txt	2013-04-19 17:54:21 UTC (rev 55921)
@@ -0,0 +1,286 @@
+# This is a configuration file for pylint.
+# wxPython GUI.
+#   pylint --rcfile=../../tools/pylintrc.txt -f parseable -r n -i y lmgr/
+# Files need to be fixed one by one (partialy without this configuration).
+[MASTER]
+# Specify a configuration file.
+#rcfile=
+# Python code to execute, usually for sys.path manipulation such as
+# pygtk.require().
+#init-hook=
+# Profiled execution.
+profile=no
+# Add files or directories to the blacklist. They should be base names, not
+# paths.
+ignore=CVS
+# Pickle collected data for later comparisons.
+persistent=no
+# List of plugins (as comma separated values of python modules names) to load,
+# usually to register additional checkers.
+load-plugins=
+[MESSAGES CONTROL]
+# Enable the message, report, category or checker with the given id(s). You can
+# either give multiple identifier separated by comma (,) or put this option
+# multiple time.
+#enable=
+# Disable the message, report, category or checker with the given id(s). You
+# can either give multiple identifier separated by comma (,) or put this option
+# multiple time (only on the command line, not in the configuration file where
+# it should appear only once).
+disable=E1103,W0141,W0201,W0311,W0312,W0612,W0613,W0614,W0622,R0201,R0901,R0904,C0103,C0111,C0322,C0323,C0324,F0401
+# E1103: caused probably by wxPython
+# W0613: unused arg -> solve somewhere here using event
+# C0103: names not defined
+# W0201: define methods used for init
+# W0622: Redefining built-in %r: needs complex solution
+# E1101: %s %r has no %r member: why?
+# R0201: can be solved
+# F0401: somthing is possible to import only in grass
+[REPORTS]
+# Set the output format. Available formats are text, parseable, colorized, msvs
+# (visual studio) and html
+output-format=text
+# Include message's id in output
+include-ids=no
+# Put messages in a separate file for each module / package specified on the
+# command line instead of printing them on stdout. Reports (if any) will be
+# written in a file name "pylint_global.[txt|html]".
+files-output=no
+# Tells whether to display a full report or only the messages
+reports=yes
+# Python expression which should return a note less than 10 (10 is the highest
+# note). You have access to the variables errors warning, statement which
+# respectively contain the number of errors / warnings messages and the total
+# number of statements analyzed. This is used by the global evaluation report
+# (RP0004).
+evaluation=10.0 - ((float(5 * error + warning + refactor + convention) / statement) * 10)
+# Add a comment according to your evaluation note. This is used by the global
+# evaluation report (RP0004).
+comment=no
+[VARIABLES]
+# Tells whether we should check for unused import in __init__ files.
+init-import=yes
+# A regular expression matching the beginning of the name of dummy variables
+# (i.e. not used).
+dummy-variables-rgx=dummy|unused
+# List of additional names supposed to be defined in builtins. Remember that
+# you should avoid to define new builtins when possible.
+additional-builtins=_
+[BASIC]
+# Required attributes for module, separated by a comma
+required-attributes=
+# List of builtins function names that should not be used, separated by a comma
+bad-functions=map,filter,apply,input
+# Regular expression which should only match correct module names
+module-rgx=(([a-z_][a-z0-9_]*)|([A-Z][a-zA-Z0-9]+))$
+# Regular expression which should only match correct module level names
+const-rgx=(([A-Z_][A-Z0-9_]*)|(__.*__))$
+# Regular expression which should only match correct class names
+class-rgx=[A-Z_][a-zA-Z0-9]+$
+# Regular expression which should only match correct function names
+function-rgx=[a-z_][a-zA-Z0-9_]{2,30}$
+# Regular expression which should only match correct method names
+method-rgx=[a-zA-Z_][a-zA-Z0-9_]{2,30}$
+# Regular expression which should only match correct instance attribute names
+attr-rgx=[a-z_][a-zA-Z0-9_]{2,30}$
+# Regular expression which should only match correct argument names
+argument-rgx=[a-z_][a-zA-Z0-9_]{2,30}$
+# Regular expression which should only match correct variable names
+variable-rgx=[a-z_][a-zA-Z0-9_]{2,30}$|[a-z]
+# Regular expression which should only match correct list comprehension /
+# generator expression variable names
+inlinevar-rgx=[A-Za-z_][A-Za-z0-9_]*$
+# Good variable names which should always be accepted, separated by a comma
+good-names=i,j,_,x,y,z,N,E,S,W,id
+# Bad variable names which should always be refused, separated by a comma
+bad-names=foo,bar,baz,toto,tutu,tata
+# Regular expression which should only match functions or classes name which do
+# not require a docstring
+no-docstring-rgx=__.*__
+[MISCELLANEOUS]
+# List of note tags to take in consideration, separated by a comma.
+notes=FIXME,TODO,\\todo, at todo
+# general regexp for convention, warning etc. would be great
+[TYPECHECK]
+# Tells whether missing members accessed in mixin class should be ignored. A
+# mixin class is detected if its name ends with "mixin" (case insensitive).
+ignore-mixin-members=yes
+# List of classes names for which member attributes should not be checked
+# (useful for classes with attributes dynamically set).
+ignored-classes=SQLObject
+# When zope mode is activated, add a predefined set of Zope acquired attributes
+# to generated-members.
+zope=no
+# List of members which are set dynamically and missed by pylint inference
+# system, and so shouldn't trigger E0201 when accessed. Python regular
+# expressions are accepted.
+generated-members=REQUEST,acl_users,aq_parent
+[FORMAT]
+# Maximum number of characters on a single line.
+# Increased form 80.
+# Maximum number of lines in a module
+# Increased from 1000.
+max-module-lines=2000
+# String used as indentation unit. This is usually " " (4 spaces) or "\t" (1
+# tab).
+indent-string='    '
+[SIMILARITIES]
+# Minimum lines number of a similarity.
+min-similarity-lines=4
+# Ignore comments when computing similarities.
+ignore-comments=yes
+# Ignore docstrings when computing similarities.
+ignore-docstrings=yes
+[DESIGN]
+# Maximum number of arguments for function / method
+# Increased from 5.
+max-args=10
+# Argument names that match this expression will be ignored. Default to name
+# with leading underscore
+ignored-argument-names=_.*|event
+# Maximum number of locals for function / method body
+# Changed from 15.
+max-locals=20
+# Maximum number of return / yield for function / method body
+max-returns=6
+# Maximum number of branch for function / method body
+# Changed from 12.
+max-branchs=20
+# Maximum number of statements in function / method body
+max-statements=50
+# Maximum number of parents for a class (see R0901).
+max-parents=7
+# Maximum number of attributes for a class (see R0902).
+# Changed from 7.
+max-attributes=10
+# Minimum number of public methods for a class (see R0903).
+min-public-methods=2
+# Maximum number of public methods for a class (see R0904).
+# Increased from 20
+max-public-methods=30
+[IMPORTS]
+# Deprecated modules which should not be used, separated by a comma
+deprecated-modules=regsub,string,TERMIOS,Bastion,rexec
+# Create a graph of every (i.e. internal and external) dependencies in the
+# given file (report RP0402 must not be disabled)
+import-graph=
+# Create a graph of external dependencies in the given file (report RP0402 must
+# not be disabled)
+ext-import-graph=
+# Create a graph of internal dependencies in the given file (report RP0402 must
+# not be disabled)
+int-import-graph=
+[CLASSES]
+# List of interface methods to ignore, separated by a comma. This is used for
+# instance to not check methods defines in Zope's Interface base class.
+ignore-iface-methods=isImplementedBy,deferred,extends,names,namesAndDescriptions,queryDescriptionFor,getBases,getDescriptionFor,getDoc,getName,getTaggedValue,getTaggedValueTags,isEqualOrExtendedBy,setTaggedValue,isImplementedByInstancesOf,adaptWith,is_implemented_by
+# List of method names used to declare (i.e. assign) instance attributes.
+defining-attr-methods=__init__,__new__,setUp
+# List of valid names for the first argument in a class method.
+valid-classmethod-first-arg=cls
+[EXCEPTIONS]
+# Exceptions that will emit a warning when being caught. Defaults to
+# "Exception"
+overgeneral-exceptions=Exception
Property changes on: grass/trunk/tools/pylintrc.txt
   + text/plain
Added: svn:keywords
   + Author Date Id
   + native
