[GRASS-SVN] r57343 - grass/branches/develbranch_6/mswindows
Thu Aug 1 09:02:57 PDT 2013
Author: martinl
Date: 2013-08-01 09:02:57 -0700 (Thu, 01 Aug 2013)
New Revision: 57343
   grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi.tmpl
   grass/branches/develbranch_6/mswindows/GRASS-Packager.bat.tmpl
   grass/branches/develbranch_6/mswindows/env.bat
wingrass: major clean up of standalone installer
Modified: grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi.tmpl
--- grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi.tmpl	2013-08-01 15:47:41 UTC (rev 57342)
+++ grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi.tmpl	2013-08-01 16:02:57 UTC (rev 57343)
@@ -783,7 +783,6 @@
 	FileWrite $0 '$\r$\n'
 	FileWrite $0 '# Set the PATH variable$\r$\n'
 	FileWrite $0 'PATH="$$GISBASE/extrabin:$$GISBASE/extralib:$$PATH"$\r$\n'
-	FileWrite $0 'PATH="$$GISBASE/tcl-tk/bin:$$GISBASE/sqlite/bin:$$PATH"$\r$\n'
 	FileWrite $0 'export PATH$\r$\n'
 	FileWrite $0 'GRASS_PAGER=more$\r$\n'
@@ -804,17 +803,13 @@
 	FileWrite $0 'export GRASS_HTML_BROWSER$\r$\n'
 	FileWrite $0 '# Set the GRASS_PROJSHARE variable$\r$\n'
-	FileWrite $0 'GRASS_PROJSHARE="$INSTALL_DIR\proj"$\r$\n'
+	FileWrite $0 'GRASS_PROJSHARE="$INSTALL_DIR\share\proj"$\r$\n'
 	FileWrite $0 'export GRASS_PROJSHARE$\r$\n'
 	FileWrite $0 '# Set the GDAL_DATA variable$\r$\n'
 	FileWrite $0 'GDAL_DATA="$INSTALL_DIR\share\gdal"$\r$\n'
 	FileWrite $0 'export GDAL_DATA$\r$\n'
-	FileWrite $0 '# Set the PROJ_LIB variable$\r$\n'
-	FileWrite $0 'PROJ_LIB="$INSTALL_DIR\proj"$\r$\n'
-	FileWrite $0 'export PROJ_LIB $\r$\n'
-	FileWrite $0 '$\r$\n'
 	FileWrite $0 '# Set the GEOTIFF_CSV variable$\r$\n'
 	FileWrite $0 'GEOTIFF_CSV="$INSTALL_DIR\share\epsg_csv"$\r$\n'
 	FileWrite $0 'export GEOTIFF_CSV$\r$\n'
@@ -865,10 +860,10 @@
 	Push 'gisbase = "$INSTDIR"' ; string to replace whole line with
 	Call ReplaceLineStr
-	;replace config_projshare = "/c/OSGeo4W/share/proj" i n grass at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR at .py with $INSTDIR\proj
+	;replace config_projshare = "/c/OSGeo4W/share/proj" i n grass at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR at .py with $INSTDIR\share/proj
 	Push "$INSTDIR\etc\grass at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR at .py" ; file to modify
 	Push 'config_projshare = "/c/OSGeo4W/share/proj"' ; string that a line must begin with *WS Sensitive*
-	Push 'config_projshare = "$INSTDIR\proj"' ; string to replace whole line with
+	Push 'config_projshare = "$INSTDIR\share\proj"' ; string to replace whole line with
 	Call ReplaceLineStr
 SectionEnd
Modified: grass/branches/develbranch_6/mswindows/GRASS-Packager.bat.tmpl
--- grass/branches/develbranch_6/mswindows/GRASS-Packager.bat.tmpl	2013-08-01 15:47:41 UTC (rev 57342)
+++ grass/branches/develbranch_6/mswindows/GRASS-Packager.bat.tmpl	2013-08-01 16:02:57 UTC (rev 57343)
@@ -14,16 +14,18 @@
 set PACKAGE_DIR=.\GRASS- at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR at -Package
-set OSGEO4W_DIR=c:\osgeo4w
+set OSGEO4W_BLD_DIR=C:\OSGeo4W
+if exist C:\OSGeo4W_grass at GRASS_VERSION_MAJOR@ (
+set OSGEO4W_PKG_DIR=C:\OSGeo4W_grass at GRASS_VERSION_MAJOR@
+) else (
-set GRASS_PREFIX=%OSGEO4W_DIR%\apps\grass\grass- at GRASS_VERSION_MAJOR@. at GRASS_VERSION_MINOR@. at GRASS_VERSION_RELEASE@
-set GRASS_BIN_PREFIX=%OSGEO4W_DIR%\bin
+set GRASS_PREFIX=%OSGEO4W_BLD_DIR%\apps\grass\grass- at GRASS_VERSION_MAJOR@. at GRASS_VERSION_MINOR@. at GRASS_VERSION_RELEASE@
-set SVN_PATH=c:\Subversion
 @echo.
 @echo -----------------------------------------------------------------------------------------------------------------------
- at echo Remove the previous Selected Package and create a new PACKAGE_DIR
+ at echo Remove the previous package and create a new PACKAGE_DIR
 @echo.
@@ -32,47 +34,36 @@
 @echo.
- at echo Copy %GRASS_PREFIX% & %GRASS_BIN_PREFIX% content to PACKAGE_DIR
+ at echo Copy %GRASS_PREFIX% content to PACKAGE_DIR
 @echo.
-rem xcopy %GRASS_BIN_PREFIX%\grass at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR at .py %PACKAGE_DIR% /S/V/F
-xcopy %GRASS_PREFIX% %PACKAGE_DIR% /S/V/F
+xcopy %GRASS_PREFIX% %PACKAGE_DIR% /S/V/F/I
 @echo.
- at echo Copy Extralibs to PACKAGE_DIR\extralib
+ at echo Copy DLL libs to PACKAGE_DIR\extralib
 @echo.
 mkdir %PACKAGE_DIR%\extralib
-copy %OSGEO4W_DIR%\bin\*.dll %PACKAGE_DIR%\extralib
-del %PACKAGE_DIR%\extralib\libgrass_*6.4*.dll
-del %PACKAGE_DIR%\extralib\libgrass_*6.5*.dll
-del %PACKAGE_DIR%\extralib\Qt*4.dll
+copy %OSGEO4W_PKG_DIR%\bin\*.dll %PACKAGE_DIR%\extralib
 del %PACKAGE_DIR%\extralib\msvcp*
 del %PACKAGE_DIR%\extralib\msvcr*
-rem copy %OSGEO4W_DIR%\pgsql\lib\libpq.dll %PACKAGE_DIR%\extralib
 @echo.
- at echo Move GRASS libs from extralib to lib
+ at echo Copy extrabins to PACKAGE_DIR\extrabin
 @echo.
-move %PACKAGE_DIR%\extralib\libgrass_*.dll %PACKAGE_DIR%\lib
- at echo.
- at echo -----------------------------------------------------------------------------------------------------------------------
- at echo Copy Extrabins to PACKAGE_DIR\extrabin
- at echo.
 mkdir %PACKAGE_DIR%\extrabin
 mkdir %PACKAGE_DIR%\extrabin\gdalplugins
-copy %OSGEO4W_DIR%\bin\*.exe %PACKAGE_DIR%\extrabin
+copy %OSGEO4W_PKG_DIR%\bin\*.exe %PACKAGE_DIR%\extrabin
+xcopy %OSGEO4W_PKG_DIR%\bin\gdalplugins\* %PACKAGE_DIR%\extrabin\gdalplugins /S/V/F/I
+del %PACKAGE_DIR%\extrabin\apt*.exe
 @echo.
@@ -80,40 +71,17 @@
 @echo.
-copy %OSGEO4W_DIR%\usr\src\grass6_devel\mswindows\external\rbatch\* %PACKAGE_DIR%\extrabin
- at echo.
- at echo Copy SQLite content to PACKAGE_DIR\sqlite
- at echo.
+copy %OSGEO4W_PKG_DIR%\usr\src\grass6_devel\mswindows\external\rbatch\* %PACKAGE_DIR%\extrabin
-mkdir %PACKAGE_DIR%\sqlite
-mkdir %PACKAGE_DIR%\sqlite\bin
-mkdir %PACKAGE_DIR%\sqlite\include
-mkdir %PACKAGE_DIR%\sqlite\lib
-xcopy %OSGEO4W_DIR%\bin\sqlite3.dll %PACKAGE_DIR%\sqlite\bin /S/V/F/I
-copy %OSGEO4W_DIR%\include\btree.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\fts1*.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\hash.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\keywordhash.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\opcodes.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\os.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\os_common.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\pager.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\parse.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\sqlite*.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\vdbe.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\vdbeInt.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\lib\sqlite3_i.lib %PACKAGE_DIR%\sqlite\lib
 @echo.
 @echo Copy shared PROJ.4 files to PACKAGE_DIR\proj
 @echo.
-xcopy %OSGEO4W_DIR%\share\proj %PACKAGE_DIR%\proj /S/V/F/I
+mkdir %PACKAGE_DIR%\share
+mkdir %PACKAGE_DIR%\share\proj
+xcopy %OSGEO4W_PKG_DIR%\share\proj %PACKAGE_DIR%\share\proj /S/V/F/I
 @echo.
@@ -121,9 +89,8 @@
 @echo.
-mkdir %PACKAGE_DIR%\share
 mkdir %PACKAGE_DIR%\share\gdal
-xcopy %OSGEO4W_DIR%\share\gdal %PACKAGE_DIR%\share\gdal /S/V/F/I
+xcopy %OSGEO4W_PKG_DIR%\share\gdal %PACKAGE_DIR%\share\gdal /S/V/F/I
 @echo.
@@ -132,67 +99,25 @@
 @echo.
 mkdir %PACKAGE_DIR%\share\epsg_csv
-xcopy %OSGEO4W_DIR%\share\epsg_csv %PACKAGE_DIR%\share\epsg_csv /S/V/F/I
+xcopy %OSGEO4W_PKG_DIR%\share\epsg_csv %PACKAGE_DIR%\share\epsg_csv /S/V/F/I
 @echo.
- at echo Copy Tcl/Tk content to PACKAGE_DIR\tcl-tk
- at echo.
-mkdir %PACKAGE_DIR%\tcl-tk
-mkdir %PACKAGE_DIR%\tcl-tk\bin
-mkdir %PACKAGE_DIR%\tcl-tk\include
-mkdir %PACKAGE_DIR%\tcl-tk\lib
-mkdir %PACKAGE_DIR%\tcl-tk\lib\tcl8.5
-mkdir %PACKAGE_DIR%\tcl-tk\lib\tk8.5
-mkdir %PACKAGE_DIR%\tcl-tk\lib\tcl8\8.5
-xcopy %OSGEO4W_DIR%\bin\tclpip85.dll %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\bin\tcl85.dll %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\bin\tclsh.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\bin\tclsh85.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\bin\tk85.dll %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\bin\wish.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\bin\wish85.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-copy %OSGEO4W_DIR%\include\tcl*.h %PACKAGE_DIR%\tcl-tk\include
-copy %OSGEO4W_DIR%\include\tk*.h %PACKAGE_DIR%\tcl-tk\include
-copy %OSGEO4W_DIR%\include\tommath_class.h %PACKAGE_DIR%\tcl-tk\include
-copy %OSGEO4W_DIR%\include\tommath_superclass.h %PACKAGE_DIR%\tcl-tk\include
-copy %OSGEO4W_DIR%\include\ttkDecls.h %PACKAGE_DIR%\tcl-tk\include
-copy %OSGEO4W_DIR%\lib\tcl8.5\*.tcl %PACKAGE_DIR%\tcl-tk\lib\tcl8.5
-copy %OSGEO4W_DIR%\lib\tcl8.5\tclIndex %PACKAGE_DIR%\tcl-tk\lib\tcl8.5
-copy %OSGEO4W_DIR%\lib\tk8.5\*.tcl %PACKAGE_DIR%\tcl-tk\lib\tk8.5
-copy %OSGEO4W_DIR%\lib\tk8.5\tclIndex %PACKAGE_DIR%\tcl-tk\lib\tk8.5
-xcopy %OSGEO4W_DIR%\lib\tk8.5\ttk %PACKAGE_DIR%\tcl-tk\lib\tk8.5\ttk /S/V/F/I
-xcopy %OSGEO4W_DIR%\lib\tcl8\8.5 %PACKAGE_DIR%\tcl-tk\lib\tcl8\8.5 /S/V/F/I
- at echo.
 @echo Copy MSYS files to PACKAGE_DIR\msys
 @echo.
 mkdir %PACKAGE_DIR%\msys
-copy %OSGEO4W_DIR%\apps\msys\* %PACKAGE_DIR%\msys
+xcopy %OSGEO4W_PKG_DIR%\apps\msys\* %PACKAGE_DIR%\msys /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\msys\bin %PACKAGE_DIR%\msys\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\msys\doc %PACKAGE_DIR%\msys\doc /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\msys\etc %PACKAGE_DIR%\msys\etc /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\msys\info %PACKAGE_DIR%\msys\info /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\msys\lib %PACKAGE_DIR%\msys\lib /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\msys\man %PACKAGE_DIR%\msys\man /S/V/F/I
-del %PACKAGE_DIR%\msys\etc\fstab
-rem delete msys.bat from osgeo4w because there is an adaption (for spaces in installation path) written by GRASS-Installer.nsi
+rem delete msys.bat and fstab from osgeo4w because there is an
+rem adaption (for spaces in installation path) written by
+rem GRASS-Installer.nsi
 del %PACKAGE_DIR%\msys\msys.bat
+del %PACKAGE_DIR%\msys\etc\fstab
 @echo.
 @echo Copy Python content to PACKAGE_DIR\Python27
@@ -201,24 +126,25 @@
 mkdir %PACKAGE_DIR%\Python27
-copy %OSGEO4W_DIR%\apps\Python27\* %PACKAGE_DIR%\Python27
+xcopy %OSGEO4W_PKG_DIR%\apps\Python27\* %PACKAGE_DIR%\Python27 /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\Python27\DLLs %PACKAGE_DIR%\Python27\DLLs /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\Python27\include %PACKAGE_DIR%\Python27\include /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\Python27\Lib %PACKAGE_DIR%\Python27\Lib /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\Python27\libs %PACKAGE_DIR%\Python27\libs /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\Python27\Scripts %PACKAGE_DIR%\Python27\Scripts /S/V/F/I
 @echo.
- at echo Copy Subversion content to PACKAGE_DIR\extrabin & PACKAGE_DIR\extralib
+ at echo Copy Tcl/Tk content to PACKAGE_DIR\lib
 @echo.
-copy %SVN_PATH%\svn.exe %PACKAGE_DIR%\extrabin
-copy %SVN_PATH%\*.dll %PACKAGE_DIR%\extralib
+mkdir %PACKAGE_DIR%\lib\tcl8.5
+mkdir %PACKAGE_DIR%\lib\tk8.5
+copy %OSGEO4W_PKG_DIR%\lib\tcl8.5\*.tcl %PACKAGE_DIR%\lib\tcl8.5
+copy %OSGEO4W_PKG_DIR%\lib\tcl8.5\tclIndex %PACKAGE_DIR%\lib\tcl8.5
+copy %OSGEO4W_PKG_DIR%\lib\tk8.5\*.tcl %PACKAGE_DIR%\lib\tk8.5
+copy %OSGEO4W_PKG_DIR%\lib\tk8.5\tclIndex %PACKAGE_DIR%\lib\tk8.5
+xcopy %OSGEO4W_PKG_DIR%\lib\tk8.5\ttk %PACKAGE_DIR%\lib\tk8.5\ttk /S/V/F/I
 @echo.
 @echo Copy env.bat
Modified: grass/branches/develbranch_6/mswindows/env.bat
--- grass/branches/develbranch_6/mswindows/env.bat	2013-08-01 15:47:41 UTC (rev 57342)
+++ grass/branches/develbranch_6/mswindows/env.bat	2013-08-01 16:02:57 UTC (rev 57343)
@@ -1,18 +1,18 @@
 rem Environmental variables for GRASS stand-alone installer
 set GRASS_WISH=%GISBASE%\extrabin\wish.exe
-set GRASS_PYTHON=%GISBASE%\extrabin\python.exe
-set GRASS_PROJSHARE=%GISBASE%\proj
-set GRASS_HTML_BROWSER=explorer
 set GRASS_SH=%GISBASE%\msys\bin\sh.exe
 set GRASS_PAGER=more
+set GRASS_HTML_BROWSER=explorer
+set GRASS_PYTHON=%GISBASE%\extrabin\python.exe
 set PYTHONHOME=%GISBASE%\Python27
+set GRASS_PROJSHARE=%GISBASE%\share\proj
 set GDAL_DATA=%GISBASE%\share\gdal
-set PROJ_LIB=%GISBASE%\proj
 set GEOTIFF_CSV=%GISBASE%\share\epsg_csv
 set PATH=%GISBASE%\msys\bin;%PATH%
 set PATH=%GISBASE%\extrabin;%GISBASE%\extralib;%PATH%
-set PATH=%GISBASE%\tcl-tk\bin;%GISBASE%\sqlite\bin;%PATH%
 set PATH=%GISBASE%\bin;%PATH%
