[GRASS-SVN] r57379 - in grass/trunk: lib/python/temporal temporal/t.rast.neighbors temporal/t.unregister
Fri Aug 2 12:29:58 PDT 2013
Author: huhabla
Date: 2013-08-02 12:29:58 -0700 (Fri, 02 Aug 2013)
New Revision: 57379
   grass/trunk/lib/python/temporal/abstract_dataset.py
   grass/trunk/lib/python/temporal/abstract_map_dataset.py
   grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
   grass/trunk/lib/python/temporal/space_time_datasets.py
   grass/trunk/lib/python/temporal/spatial_extent.py
   grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py
   grass/trunk/temporal/t.unregister/t.unregister.py
Implementing spatial buffering and direct extent object exchange for map objects. Removed spaces.
Modified: grass/trunk/lib/python/temporal/abstract_dataset.py
--- grass/trunk/lib/python/temporal/abstract_dataset.py	2013-08-02 17:11:11 UTC (rev 57378)
+++ grass/trunk/lib/python/temporal/abstract_dataset.py	2013-08-02 19:29:58 UTC (rev 57379)
@@ -39,30 +39,30 @@
         self.msg = msg
     def __str__(self):
         return repr(self.msg)
 class AbstractDataset(SpatialTopologyDatasetConnector, TemporalTopologyDatasetConnector):
-    """!This is the base class for all datasets
+    """!This is the base class for all datasets
        (raster, vector, raster3d, strds, stvds, str3ds)"""
     __metaclass__ = ABCMeta
     def __init__(self):
         SpatialTopologyDatasetConnector.__init__(self)
         TemporalTopologyDatasetConnector.__init__(self)
     def reset_topology(self):
         """!Reset any information about temporal topology"""
         self.reset_spatial_topology()
         self.reset_temporal_topology()
-    def get_number_of_relations(self):
+    def get_number_of_relations(self):
         """! Return a dictionary in which the keys are the relation names and the value
         are the number of relations.
         The following relations are available:
         Spatial relations
         - equivalent
         - overlap
@@ -71,7 +71,7 @@
         - meet
         - cover
         - covered
         Temporal relations
         - equal
         - follows
@@ -84,10 +84,10 @@
         - started
         - finishes
         - finished
         To access topological information the spatial, temporal or booth topologies must be build first
         using the SpatioTemporalTopologyBuilder.
         @return the dictionary with relations as keys and number as values or None in case the topology  wasn't build
         if self.is_temporal_topology_build() and not self.is_spatial_topology_build():
@@ -97,15 +97,15 @@
         else:
             return  self.get_number_of_temporal_relations() + \
                     self.get_number_of_spatial_relations()
         return None
     def set_topology_build_true(self):
         """!Use this method when the spatio-temporal topology was build"""
         self.set_spatial_topology_build_true()
         self.set_temporal_topology_build_true()
     def set_topology_build_false(self):
         """!Use this method when the spatio-temporal topology was not build"""
         self.set_spatial_topology_build_false()
@@ -113,53 +113,53 @@
     def is_topology_build(self):
         """!Check if the spatial and temporal topology was build
            @return A dictionary with "spatial" and "temporal" as keys that have boolen values
         d = {}
         d["spatial"] = self.is_spatial_topology_build()
         d["temporal"] = self.is_temporal_topology_build()
         return d
     def print_topology_info(self):
         if self.is_temporal_topology_build():
             self.print_temporal_topology_info()
         if self.is_spatial_topology_build():
             self.print_spatial_topology_info()
     def print_topology_shell_info(self):
             self.print_temporal_topology_shell_info()
             self.print_spatial_topology_shell_info()
     @abstractmethod
     def reset(self, ident):
         """!Reset the internal structure and set the identifier
             This method creates the dataset specific internal objects
             that store the base information, the spatial and temporal extent
             and the metadata. It must be implemented in the dataset
-            specific subclasses. This is the code for the
+            specific subclasses. This is the code for the
             vector dataset:
             self.base = VectorBase(ident=ident)
             self.absolute_time = VectorAbsoluteTime(ident=ident)
             self.relative_time = VectorRelativeTime(ident=ident)
             self.spatial_extent = VectorSpatialExtent(ident=ident)
             self.metadata = VectorMetadata(ident=ident)
            @param ident The identifier of the dataset that  "name at mapset" or in case of vector maps "name:layer at mapset"
     @abstractmethod
     def get_type(self):
         """!Return the type of this class as string
-           The type can be "vect", "rast", "rast3d", "stvds", "strds" or "str3ds"
+           The type can be "vect", "rast", "rast3d", "stvds", "strds" or "str3ds"
            @return "vect", "rast", "rast3d", "stvds", "strds" or "str3ds"
@@ -174,41 +174,41 @@
     @abstractmethod
     def spatial_overlapping(self, dataset):
         """!Return True if the spatial extents overlap
            @param dataset The abstract dataset to check spatial overlapping
            @return True if self and the provided dataset spatial overlap
     @abstractmethod
     def spatial_intersection(self, dataset):
-        """!Return the spatial intersection as spatial_extent
+        """!Return the spatial intersection as spatial_extent
            object or None in case no intersection was found.
            @param dataset The abstract dataset to intersect with
            @return The intersection spatial extent
     @abstractmethod
     def spatial_union(self, dataset):
-        """!Return the spatial union as spatial_extent
+        """!Return the spatial union as spatial_extent
            object or None in case the extents does not overlap or meet.
            @param dataset The abstract dataset to create a union with
            @return The union spatial extent
     @abstractmethod
     def spatial_disjoint_union(self, dataset):
         """!Return the spatial union as spatial_extent object.
     @abstractmethod
     def spatial_relation(self, dataset):
         """!Return the spatial relationship between self and dataset
            @param dataset The abstract dataset to compute the spatial relation with self
            @return The spatial relationship as string
@@ -252,10 +252,10 @@
     def get_temporal_extent_as_tuple(self):
         """!Returns a tuple of the valid start and end time
            Start and end time can be either of type datetime or of type integer,
            depending on the temporal type.
            @return A tuple of (start_time, end_time)
         start = self.temporal_extent.get_start_time()
@@ -263,16 +263,16 @@
         return (start, end)
     def get_absolute_time(self):
-        """!Returns the start time, the end
+        """!Returns the start time, the end
            time and the timezone of the map as tuple
            @attention: The timezone is currently not used.
            The start time is of type datetime.
-           The end time is of type datetime in case of interval time,
+           The end time is of type datetime in case of interval time,
            or None on case of a time instance.
            @return A tuple of (start_time, end_time, timezone)
@@ -283,14 +283,14 @@
         return (start, end, tz)
     def get_relative_time(self):
            time and the temporal unit of the dataset as tuple
            The start time is of type integer.
-           The end time is of type integer in case of interval time,
+           The end time is of type integer in case of interval time,
            @return A tuple of (start_time, end_time, unit)
@@ -307,14 +307,14 @@
         return self.relative_time.get_unit()
     def check_relative_time_unit(self, unit):
-        """!Check if unit is of type  year(s), month(s), day(s), hour(s),
+        """!Check if unit is of type  year(s), month(s), day(s), hour(s),
            minute(s) or second(s)
            @param unit The unit string
            @return True if success, False otherwise
         # Check unit
-        units = ["year", "years", "month", "months", "day", "days", "hour",
+        units = ["year", "years", "month", "months", "day", "days", "hour",
                  "hours", "minute", "minutes", "second", "seconds"]
         if unit not in units:
             return False
@@ -322,30 +322,35 @@
     def get_temporal_type(self):
         """!Return the temporal type of this dataset
            The temporal type can be absolute or relative
            @return The temporal type of the dataset as string
         return self.base.get_ttype()
     def get_spatial_extent_as_tuple(self):
         """!Return the spatial extent as tuple
            Top and bottom are set to 0 in case of a two dimensional spatial extent.
-           @return A the spatial extent as tuple (north, south, east, west, top, bottom)
+           @return A the spatial extent as tuple (north, south, east, west, top, bottom)
         return self.spatial_extent.get_spatial_extent_as_tuple()
+    def get_spatial_extent(self):
+        """!Return the spatial extent
+        return self.spatial_extent
     def select(self, dbif=None):
-        """!Select temporal dataset entry from database and fill
+        """!Select temporal dataset entry from database and fill
            The content of every dataset is stored in the temporal database.
-           This method must be used to fill this object with the content
+           This method must be used to fill this object with the content
            from the temporal database.
            @param dbif The database interface to be used
@@ -367,16 +372,16 @@
         return self.base.is_in_db(dbif)
+    @abstractmethod
     def delete(self):
         """!Delete dataset from database if it exists"""
-        raise ImplementationError("This method must be implemented in the subclasses")
     def insert(self, dbif=None, execute=True):
         """!Insert dataset into database
            @param execute If True the SQL statements will be executed.
-                           If False the prepared SQL statements are returned
+                           If False the prepared SQL statements are returned
                            and must be executed by the caller.
             @return The SQL insert statement in case execute=False, or an empty string otherwise
@@ -388,7 +393,7 @@
         statement += self.temporal_extent.get_insert_statement_mogrified(dbif)
         statement += self.spatial_extent.get_insert_statement_mogrified(dbif)
         statement += self.metadata.get_insert_statement_mogrified(dbif)
         if execute:
             dbif.execute_transaction(statement)
             if connected:
@@ -405,7 +410,7 @@
            @param ident The identifier to be updated, useful for renaming
            @return The SQL update statement in case execute=False, or an empty string otherwise
@@ -415,9 +420,9 @@
         # Build the UPDATE SQL statement
         statement = self.base.get_update_statement_mogrified(dbif, ident)
-        statement += self.temporal_extent.get_update_statement_mogrified(dbif,
+        statement += self.temporal_extent.get_update_statement_mogrified(dbif,
        ident)
-        statement += self.spatial_extent.get_update_statement_mogrified(dbif,
+        statement += self.spatial_extent.get_update_statement_mogrified(dbif,
        ident)
         statement += self.metadata.get_update_statement_mogrified(dbif, ident)
@@ -437,7 +442,7 @@
@@ -447,7 +452,7 @@
         statement = self.base.get_update_all_statement_mogrified(dbif, ident)
-        statement += self.temporal_extent.get_update_all_statement_mogrified(dbif,
+        statement += self.temporal_extent.get_update_all_statement_mogrified(dbif,
        ident)
         statement += self.spatial_extent.get_update_all_statement_mogrified(
             dbif, ident)
@@ -465,7 +470,7 @@
     def is_time_absolute(self):
         """!Return True in case the temporal type is absolute
             @return True if temporal type is absolute, False otherwise
         if "temporal_type" in self.base.D:
@@ -475,14 +480,14 @@
     def is_time_relative(self):
         """!Return True in case the temporal type is relative
             @return True if temporal type is relative, False otherwise
             return self.base.get_ttype() == "relative"
         else:
             return None
     def _get_temporal_extent(self):
         """!Return the temporal extent of the correct internal type
@@ -491,49 +496,49 @@
         if self.is_time_relative():
         return None
     temporal_extent = property(fget=_get_temporal_extent)
     def temporal_relation(self, dataset):
         """!Return the temporal relation of self and the provided dataset
             @return The temporal relation as string
         return self.temporal_extent.temporal_relation(dataset.temporal_extent)
     def temporal_intersection(self, dataset):
         """!Intersect self with the provided dataset and
            return a new temporal extent with the new start and end time
            @param dataset The abstract dataset to temporal intersect with
-           @return The new temporal extent with start and end time,
+           @return The new temporal extent with start and end time,
                    or None in case of no intersection
         return self.temporal_extent.intersect(dataset.temporal_extent)
     def temporal_union(self, dataset):
         """!Creates a union with the provided dataset and
            return a new temporal extent with the new start and end time.
            @param dataset The abstract dataset to create temporal union with
         return self.temporal_extent.union(dataset.temporal_extent)
     def temporal_disjoint_union(self, dataset):
         return self.temporal_extent.disjoint_union(dataset.temporal_extent)
 class AbstractDatasetComparisonKeyStartTime(object):
-    """!This comparison key can be used to sort lists of abstract datasets
+    """!This comparison key can be used to sort lists of abstract datasets
        by start time
         Example:
@@ -581,7 +586,7 @@
 class AbstractDatasetComparisonKeyEndTime(object):
        by end time
         Example:
@@ -627,7 +632,7 @@
         return endA != endB
 if __name__ == "__main__":
     import doctest
     doctest.testmod()
Modified: grass/trunk/lib/python/temporal/abstract_map_dataset.py
--- grass/trunk/lib/python/temporal/abstract_map_dataset.py	2013-08-02 17:11:11 UTC (rev 57378)
+++ grass/trunk/lib/python/temporal/abstract_map_dataset.py	2013-08-02 19:29:58 UTC (rev 57379)
@@ -36,9 +36,9 @@
         - Abstract methods that must be implemented in the map specific
           subclasses
     def __init__(self):
         AbstractDataset.__init__(self)
@@ -207,7 +207,7 @@
         self.temporal_extent.print_self()
         self.spatial_extent.print_self()
         self.metadata.print_self()
     def print_info(self):
         """!Print information about this object in human readable style"""
@@ -328,7 +328,7 @@
     def set_time_to_relative(self):
         """!Set the temporal type to relative"""
         self.base.set_ttype("relative")
     def set_absolute_time(self, start_time, end_time=None, timezone=None):
         """!Set the absolute time with start time and end time
@@ -348,7 +348,7 @@
             if self.get_layer() is not None:
                 core.fatal(_("Start time must be of type datetime for %(type)s"
                              " map <%(id)s> with layer: %(l)s") % {
-                             'type': self.get_type(), 'id': self.get_map_id(),
+                             'type': self.get_type(), 'id': self.get_map_id(),
                              'l': self.get_layer()})
             else:
                 core.fatal(_("Start time must be of type datetime for "
@@ -507,6 +507,43 @@
         self.write_timestamp_to_grass()
+    def set_temporal_extent(self, temporal_extent):
+        """!Convenient method to set the temporal extent from a temporal extent object
+           @param temporal_extent The temporal axtent that should be set for this object
+           @code
+           >>> import datetime
+           >>> import grass.temporal as tgis
+           >>> map      = tgis.RasterDataset(None)
+           >>> temp_ext = tgis.RelativeTemporalExtent(start_time=1, end_time=2, unit="years")
+           >>> map.set_temporal_extent(temp_ext)
+           >>> print map.get_temporal_extent_as_tuple()
+           (1, 2)
+           >>> map      = tgis.VectorDataset(None)
+           >>> temp_ext = tgis.AbsoluteTemporalExtent(start_time=datetime.datetime(2000, 1, 1),
+           ...                                        end_time=datetime.datetime(2001, 1, 1))
+           (datetime.datetime(2000, 1, 1, 0, 0), datetime.datetime(2001, 1, 1, 0, 0))
+           @endcode
+        if issubclass(RelativeTemporalExtent, type(temporal_extent)):
+            start = temporal_extent.get_start_time()
+            end = temporal_extent.get_end_time()
+            unit = temporal_extent.get_unit()
+            self.set_relative_time(start, end, unit)
+        elif issubclass(AbsoluteTemporalExtent, type(temporal_extent)):
+            tz = temporal_extent.get_timezone()
+            self.set_absolute_time(start, end, tz)
     def temporal_buffer(self, increment, update=False, dbif=None):
         """!Create a temporal buffer based on an increment
@@ -610,8 +647,8 @@
             else:
                 self.set_relative_time(new_start, new_end, unit)
-    def set_spatial_extent(self, north, south, east, west, top=0, bottom=0):
-        """!Set the spatial extent of the map
+    def set_spatial_extent_from_values(self, north, south, east, west, top=0, bottom=0):
+        """!Set the spatial extent of the map from values
             This method only modifies this object and does not commit
             the modifications to the temporal database.
@@ -623,9 +660,84 @@
            @param top The top edge
            @param bottom The bottom edge
-        self.spatial_extent.set_spatial_extent(
+        self.spatial_extent.set_spatial_extent_from_values(
+    def set_spatial_extent(self, spatial_extent):
+            This method only modifies this object and does not commit
+            the modifications to the temporal database.
+            @param spatial_extent An object of type SpatialExtent or its subclasses
+           @code
+           >>> spat_ext = tgis.SpatialExtent(north=10, south=-10, east=20, west=-20, top=5, bottom=-5)
+           >>> map.set_spatial_extent(spat_ext)
+           >>> print map.get_spatial_extent_as_tuple()
+           (10.0, -10.0, 20.0, -20.0, 5.0, -5.0)
+           @endcode
+        self.spatial_extent.set_spatial_extent(spatial_extent)
+    def spatial_buffer(self, size, update=False, dbif=None):
+        """!Buffer the spatial extent by a given size in all
+           spatial directions.
+           @param size The buffer size, using the unit of the grass region
+           @code
+           >>> map.spatial_buffer(10)
+           (20.0, -20.0, 30.0, -30.0, 15.0, -15.0)
+           @endcode
+        self.spatial_extent.north   += size
+        self.spatial_extent.south   -= size
+        self.spatial_extent.east    += size
+        self.spatial_extent.west    -= size
+        self.spatial_extent.top     += size
+        self.spatial_extent.bottom  -= size
+        if update:
+            self.spatial_extent.update(dbif)
+    def spatial_buffer_2d(self, size, update=False, dbif=None):
+        """!Buffer the spatial extent by a given size in 2d
+           @code
+           >>> map.spatial_buffer_2d(10)
+           (20.0, -20.0, 30.0, -30.0, 5.0, -5.0)
+           @endcode
+        if update:
     def check_for_correct_time(self):
         """!Check for correct time"""
         if self.is_time_absolute():
@@ -696,7 +808,7 @@
             #core.verbose(_("Delete %s dataset <%s> from temporal database")
             #             % (self.get_type(), self.get_id()))
-            # Delete yourself from the database, trigger functions will
+            # Delete yourself from the database, trigger functions will
             # take care of dependencies
             statement += self.base.get_delete_statement()
@@ -736,7 +848,7 @@
         #if self.get_layer() is not None:
         #    core.verbose(_("Unregister %(type)s map <%(map)s> with "
         #                   "layer %(layer)s from space time datasets" % \
-        #                 {'type':self.get_type(), 'map':self.get_map_id(),
+        #                 {'type':self.get_type(), 'map':self.get_map_id(),
         #                  'layer':self.get_layer()}))
         #else:
         #    core.verbose(_("Unregister %(type)s map <%(map)s> "
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2013-08-02 17:11:11 UTC (rev 57378)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2013-08-02 19:29:58 UTC (rev 57379)
@@ -32,9 +32,9 @@
        database, like the computation of the temporal and spatial extent as
        well as the collecting of metadata.
     def __init__(self, ident):
         self.reset(ident)
@@ -63,7 +63,7 @@
            @param ident The unique identifier of the new object
     @abstractmethod
     def get_map_register(self):
         """!Return the name of the map register table
@@ -120,11 +120,11 @@
         self.metadata.print_shell_info()
     def print_history(self):
-        """!Print history information about this class in human readable
+        """!Print history information about this class in human readable
             shell style
         self.metadata.print_history()
     def set_initial_values(self, temporal_type, semantic_type,
                            title=None, description=None):
         """!Set the initial values of the space time dataset
@@ -1041,7 +1041,8 @@
                                           self.get_relative_time_unit())
                 # The fast way
                 if has_bt_columns:
-                    map.set_spatial_extent(west=row["west"], east=row["east"],
+                    map.set_spatial_extent_from_values(west=row["west"],
+                                                       east=row["east"],
                                            south=row["south"], top=row["top"],
                                            north=row["north"],
                                            bottom=row["bottom"])
@@ -1491,16 +1492,15 @@
         # Get the update statement, we update the table entry of the old
         # identifier
         statement = self.update(dbif, execute=False, ident=old_ident)
         # We need to rename the raster register table
-        statement += "ALTER TABLE %s RENAME TO \'%s\';\n" % \
+        statement += "ALTER TABLE %s RENAME TO \"%s\";\n" % \
                      (old_map_register_table, new_map_register_table)
         # We need to rename the space time dataset in the maps register table
         if maps:
             for map in maps:
                 map.select()
-                statement += "UPDATE %s SET id = \'%s\' WHERE id = \'%s\';\n"%\
+                statement += "UPDATE %s SET id = \"%s\" WHERE id = \"%s\";\n"%\
                              (map.get_stds_register(), ident, old_ident)
         # Execute the accumulated statements
@@ -1656,7 +1656,7 @@
                 dbif)
             # Commented because of performance issue calling g.message thousend times
             #core.verbose(_("Set temporal unit for space time %s dataset "
-            #               "<%s> to %s") % (map.get_type(), self.get_id(),
+            #               "<%s> to %s") % (map.get_type(), self.get_id(),
             #                                map_rel_time_unit))
         stds_rel_time_unit = self.get_relative_time_unit()
@@ -1739,11 +1739,11 @@
             #if map.get_layer():
             #    core.verbose(_("Created register table <%s> for "
             #                   "%s map <%s> with layer %s") %
-            #                    (map_register_table, map.get_type(),
+            #                    (map_register_table, map.get_type(),
             #                     map.get_map_id(), map.get_layer()))
             #else:
             #    core.verbose(_("Created register table <%s> for %s map <%s>") %
             #                     map.get_map_id()))
         # We need to create the table and register it
@@ -2002,7 +2002,7 @@
         else:
             # Check if the end time is smaller than the maximum start time
-                sql = """SELECT max(start_time) FROM GRASS_MAP_absolute_time
+                sql = """SELECT max(start_time) FROM GRASS_MAP_absolute_time
                          WHERE GRASS_MAP_absolute_time.id IN
                         (SELECT id FROM SPACETIME_NAME_GRASS_MAP_register);"""
                 sql = sql.replace("GRASS_MAP", self.get_new_map_instance(
@@ -2010,7 +2010,7 @@
                 sql = sql.replace("SPACETIME_NAME",
                     stds_name + "_" + stds_mapset)
             else:
-                sql = """SELECT max(start_time) FROM GRASS_MAP_relative_time
+                sql = """SELECT max(start_time) FROM GRASS_MAP_relative_time
                          WHERE GRASS_MAP_relative_time.id IN
@@ -2046,7 +2046,7 @@
         if use_start_time:
                 sql = """UPDATE STDS_absolute_time SET end_time =
-               (SELECT max(start_time) FROM GRASS_MAP_absolute_time WHERE
+               (SELECT max(start_time) FROM GRASS_MAP_absolute_time WHERE
                ) WHERE id = 'SPACETIME_ID';"""
@@ -2058,7 +2058,7 @@
                 sql = sql.replace("STDS", self.get_type())
             elif self.is_time_relative():
                 sql = """UPDATE STDS_relative_time SET end_time =
-               (SELECT max(start_time) FROM GRASS_MAP_relative_time WHERE
+               (SELECT max(start_time) FROM GRASS_MAP_relative_time WHERE
Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py	2013-08-02 17:11:11 UTC (rev 57378)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py	2013-08-02 19:29:58 UTC (rev 57379)
@@ -14,7 +14,7 @@
 >>> grass.run_command("r3.mapcalc", overwrite=True, expression="str3ds_map_test_case = 1")
 0
->>> grass.run_command("v.random", overwrite=True, output="stvds_map_test_case",
+>>> grass.run_command("v.random", overwrite=True, output="stvds_map_test_case",
 ... n=100, zmin=0, zmax=100, flags="z", column="elevation")
 0
@@ -38,25 +38,25 @@
        This class provides functions to select, update, insert or delete raster
        map information and valid time stamps into the SQL temporal database.
        Usage:
         @code
         >>> import grass.script as grass
         >>> init()
         >>> grass.use_temp_region()
-        >>> grass.run_command("g.region", n=80.0, s=0.0, e=120.0, w=0.0,
+        >>> grass.run_command("g.region", n=80.0, s=0.0, e=120.0, w=0.0,
         ... t=1.0, b=0.0, res=10.0)
         0
-        >>> grass.run_command("r.mapcalc", overwrite=True,
+        >>> grass.run_command("r.mapcalc", overwrite=True,
         ... expression="strds_map_test_case = 1")
         0
         >>> mapset = grass.gisenv()["MAPSET"]
         >>> name = "strds_map_test_case"
         >>> identifier = "%s@%s" % (name, mapset)
         >>> rmap = RasterDataset(identifier)
-        >>> rmap.set_absolute_time(start_time=datetime(2001,1,1),
+        >>> rmap.set_absolute_time(start_time=datetime(2001,1,1),
         ...                        end_time=datetime(2012,1,1))
         True
         >>> rmap.map_exists()
@@ -85,7 +85,7 @@
          | Minimum value:.............. 1.0
          | Maximum value:.............. 1.0
          | STRDS register table ....... None
         >>> newmap = rmap.get_new_instance("new at PERMANENT")
         >>> isinstance(newmap, RasterDataset)
         True
@@ -111,11 +111,11 @@
         True
         >>> rmap.is_time_relative()
         False
         >>> grass.run_command("g.remove", rast=name)
         0
         >>> grass.del_temp_region()
         @endcode
@@ -130,17 +130,17 @@
         return RasterDataset(ident)
     def get_new_stds_instance(self, ident):
-        """!Return a new space time dataset instance in which maps
+        """!Return a new space time dataset instance in which maps
         are stored with the type of this class"""
         return SpaceTimeRasterDataset(ident)
     def get_stds_register(self):
-        """!Return the space time dataset register table name in which stds
+        """!Return the space time dataset register table name in which stds
         are listed in which this map is registered"""
         return self.metadata.get_strds_register()
     def set_stds_register(self, name):
-        """!Set the space time dataset register table name in which stds
+        """!Set the space time dataset register table name in which stds
         self.metadata.set_strds_register(name)
@@ -153,43 +153,43 @@
         return self.spatial_extent.spatial_relation_2d(dataset.spatial_extent)
-        """!Return the two dimensional intersection as spatial_extent
+        """!Return the two dimensional intersection as spatial_extent
            @return The intersection spatial extent or None
         return self.spatial_extent.intersect_2d(dataset.spatial_extent)
-        """!Return the two dimensional union as spatial_extent
+        """!Return the two dimensional union as spatial_extent
            @return The union spatial extent or None
         return self.spatial_extent.union_2d(dataset.spatial_extent)
         """!Return the two dimensional union as spatial_extent object.
         return self.spatial_extent.disjoint_union_2d(dataset.spatial_extent)
     def get_np_array(self):
         """!Return this raster map as memmap numpy style array to access the raster
            values in numpy style without loading the whole map in the RAM.
-           In case this raster map does exists in the grass spatial database,
-           the map will be exported using r.out.bin to a temporary location
+           In case this raster map does exists in the grass spatial database,
+           the map will be exported using r.out.bin to a temporary location
            and assigned to the memmap object that is returned by this function.
-           In case the raster map does not exists, an empty temporary
+           In case the raster map does not exists, an empty temporary
            binary file will be created and assigned to the memap object.
-           You need to call the write function to write the memmap
+           You need to call the write function to write the memmap
            array back into grass.
@@ -217,7 +217,7 @@
             return False
     def write_timestamp_to_grass(self):
-        """!Write the timestamp of this map into the map metadata in
+        """!Write the timestamp of this map into the map metadata in
            the grass file system based spatial database.
            Internally the libgis API functions are used for writing
@@ -237,7 +237,7 @@
                          (self.get_map_id())))
     def remove_timestamp_from_grass(self):
-        """!Remove the timestamp from the grass file system based
+        """!Remove the timestamp from the grass file system based
            spatial database
            Internally the libgis API functions are used for removal
@@ -350,7 +350,7 @@
         # Fill spatial extent
-        self.set_spatial_extent(north=kvp["north"], south=kvp["south"],
+        self.set_spatial_extent_from_values(north=kvp["north"], south=kvp["south"],
                                 east=kvp["east"], west=kvp["west"])
         # Fill metadata
@@ -390,17 +390,17 @@
         return Raster3DDataset(ident)
         return SpaceTimeRaster3DDataset(ident)
         which stds are listed in which this map is registered"""
         return self.metadata.get_str3ds_register()
         self.metadata.set_str3ds_register(name)
@@ -419,9 +419,9 @@
-        """!Return the three or two dimensional intersection as spatial_extent
+        """!Return the three or two dimensional intersection as spatial_extent
@@ -431,9 +431,9 @@
-        """!Return the three or two dimensional union as spatial_extent
+        """!Return the three or two dimensional union as spatial_extent
@@ -441,10 +441,10 @@
             return self.spatial_extent.union(dataset.spatial_extent)
         else:
         """!Return the three or two dimensional union as spatial_extent object.
@@ -452,19 +452,19 @@
             return self.spatial_extent.disjoint_union(dataset.spatial_extent)
         else:
         """!Return this 3D raster map as memmap numpy style array to access the 3D raster
-           In case this 3D raster map does exists in the grass spatial database,
-           the map will be exported using r3.out.bin to a temporary location
+           In case this 3D raster map does exists in the grass spatial database,
+           the map will be exported using r3.out.bin to a temporary location
-           In case the 3D raster map does not exists, an empty temporary
+           In case the 3D raster map does not exists, an empty temporary
@@ -474,7 +474,7 @@
             a.read(self.get_map_id())
         return a
         """!Reset the internal structure and set the identifier"""
         self.base = Raster3DBase(ident=ident)
@@ -492,7 +492,7 @@
             return False
         in the grass file system based spatial database.
@@ -568,12 +568,12 @@
         kvp["bottom"] = region.bottom
         # We need to open the map, this function returns a void pointer
-        # but we may need the correct type which is RASTER3D_Map, hence
+        # but we may need the correct type which is RASTER3D_Map, hence
         # the casting
         g3map = cast(libraster3d.Rast3d_open_cell_old(name, mapset,
-                     libraster3d.RASTER3D_DEFAULT_WINDOW,
+                     libraster3d.RASTER3D_DEFAULT_WINDOW,
                      libraster3d.RASTER3D_TILE_SAME_AS_FILE,
-                     libraster3d.RASTER3D_NO_CACHE),
+                     libraster3d.RASTER3D_NO_CACHE),
                      POINTER(libraster3d.RASTER3D_Map))
         if not g3map:
@@ -624,7 +624,7 @@
         else:
             kvp = grass.raster3d_info(self.get_id())
                                 east=kvp["east"], west=kvp["west"],
                                 top=kvp["top"], bottom=kvp["bottom"])
@@ -667,17 +667,17 @@
         return VectorDataset(ident)
         return SpaceTimeVectorDataset(ident)
         return self.metadata.get_stvds_register()
         self.metadata.set_stvds_register(name)
@@ -696,31 +696,31 @@
@@ -732,14 +732,14 @@
     def has_grass_timestamp(self):
         """!Check if a grass file bsased time stamp exists for this map.
-        if G_has_vector_timestamp(self.get_name(), self.get_layer(),
+        if G_has_vector_timestamp(self.get_name(), self.get_layer(),
                                   self.get_mapset()):
             return True
         else:
             return False
@@ -760,7 +760,7 @@
-        """!Remove the timestamp from the grass file system based spatial
+        """!Remove the timestamp from the grass file system based spatial
            database
@@ -810,18 +810,18 @@
         # Code lend from v.info main.c
         if libvector.Vect_open_old_head2(byref(Map), name, mapset, "1") < 2:
             # force level 1, open fully
-            # NOTE: number of points, lines, boundaries, centroids,
+            # NOTE: number of points, lines, boundaries, centroids,
             # faces, kernels is still available
             libvector.Vect_set_open_level(1)  # no topology
             with_topo = False
             core.message(_("Open map without topology support"))
             if libvector.Vect_open_old2(byref(Map), name, mapset, "1") < 1:
-                core.fatal(_("Unable to open vector map <%s>" %
+                core.fatal(_("Unable to open vector map <%s>" %
                              (libvector.Vect_get_full_name(byref(Map)))))
         # Release the vector spatial index memory when closed
         libvector.Vect_set_release_support(byref(Map))
         # Read the extent information
         bbox = libvector.bound_box()
         libvector.Vect_get_map_box(byref(Map), byref(bbox))
@@ -882,7 +882,7 @@
         return kvp
     def load(self):
-        """!Load all info from an existing vector map into the internal
+        """!Load all info from an existing vector map into the internal
         structure"""
         # Fill base information
@@ -896,7 +896,7 @@
             kvp = grass.vector_info(self.get_map_id())
@@ -952,31 +952,31 @@
@@ -1004,7 +1004,7 @@
     def get_new_map_instance(self, ident):
-        """!Return a new instance of a map dataset which is associated
+        """!Return a new instance of a map dataset which is associated
@@ -1034,9 +1034,9 @@
@@ -1046,9 +1046,9 @@
@@ -1056,10 +1056,10 @@
         else:
@@ -1067,7 +1067,7 @@
         else:
@@ -1096,7 +1096,7 @@
@@ -1117,31 +1117,31 @@
Modified: grass/trunk/lib/python/temporal/spatial_extent.py
--- grass/trunk/lib/python/temporal/spatial_extent.py	2013-08-02 17:11:11 UTC (rev 57378)
+++ grass/trunk/lib/python/temporal/spatial_extent.py	2013-08-02 19:29:58 UTC (rev 57379)
@@ -10,22 +10,22 @@
 >>> tgis.init()
->>> extent = tgis.RasterSpatialExtent(
+>>> extent = tgis.RasterSpatialExtent(
 ... ident="raster at PERMANENT", north=90, south=90, east=180, west=180,
 ... top=100, bottom=-20)
->>> extent = tgis.Raster3DSpatialExtent(
+>>> extent = tgis.Raster3DSpatialExtent(
 ... ident="raster3d at PERMANENT", north=90, south=90, east=180, west=180,
->>> extent = tgis.VectorSpatialExtent(
+>>> extent = tgis.VectorSpatialExtent(
 ... ident="vector at PERMANENT", north=90, south=90, east=180, west=180,
->>> extent = tgis.STRDSSpatialExtent(
+>>> extent = tgis.STRDSSpatialExtent(
 ... ident="strds at PERMANENT", north=90, south=90, east=180, west=180,
->>> extent = tgis.STR3DSSpatialExtent(
+>>> extent = tgis.STR3DSSpatialExtent(
 ... ident="str3ds at PERMANENT", north=90, south=90, east=180, west=180,
->>> extent = tgis.STVDSSpatialExtent(
+>>> extent = tgis.STVDSSpatialExtent(
 ... ident="stvds at PERMANENT", north=90, south=90, east=180, west=180,
@@ -43,16 +43,16 @@
 class SpatialExtent(SQLDatabaseInterface):
     """!This is the spatial extent base class for all maps and space time datasets
         This class implements a three dimensional axis aligned bounding box
         and functions to compute topological relationships
         Usage:
         @code
         >>> init()
-        >>> extent = SpatialExtent(table="raster_spatial_extent",
+        >>> extent = SpatialExtent(table="raster_spatial_extent",
         ... ident="soil at PERMANENT", north=90, south=90, east=180, west=180,
         >>> extent.id
@@ -84,39 +84,39 @@
         west=180.0
         top=100.0
         bottom=-20.0
         @endcode
-    def __init__(self, table=None, ident=None, north=None, south=None,
+    def __init__(self, table=None, ident=None, north=None, south=None,
                  east=None, west=None, top=None, bottom=None, proj="XY"):
         SQLDatabaseInterface.__init__(self, table, ident)
         self.set_id(ident)
-        self.set_spatial_extent(north, south, east, west, top, bottom)
+        self.set_spatial_extent_from_values(north, south, east, west, top, bottom)
         self.set_projection(proj)
     def overlapping_2d(self, extent):
         """!Return True if this (A) and the provided spatial extent (B) overlaps
-        in two dimensional space.
+        in two dimensional space.
         Code is lend from wind_overlap.c in lib/gis
         Overlapping includes the spatial relations:
         - contain
         - in
         - cover
         - covered
         - equivalent
          @code
          >>> A = SpatialExtent(north=80, south=20, east=60, west=10)
          >>> B = SpatialExtent(north=80, south=20, east=60, west=10)
          >>> A.overlapping_2d(B)
          True
          @endcode
         @param extent The spatial extent to check overlapping with
         @return True or False
@@ -156,28 +156,28 @@
         return True
     def overlapping(self, extent):
-        """!Return True if this (A) and the provided spatial
+        """!Return True if this (A) and the provided spatial
         extent (B) overlaps in three dimensional space.
         - contain
         - in
         - cover
         - covered
         - equivalent
          Usage:
          @code
          >>> A = SpatialExtent(north=80, south=20, east=60, west=10, bottom=-50, top=50)
          >>> B = SpatialExtent(north=80, south=20, east=60, west=10, bottom=-50, top=50)
          >>> A.overlapping(B)
          True
          @endcode
@@ -197,9 +197,9 @@
         return True
     def intersect_2d(self, extent):
         @param extent The spatial extent to intersect with
@@ -247,16 +247,16 @@
         return new
     def intersect(self, extent):
-        """!Return the three dimensional intersection as spatial_extent
+        """!Return the three dimensional intersection as spatial_extent
         Usage:
         @code
-        >>> A = SpatialExtent(north=80, south=20, east=60, west=10,
+        >>> A = SpatialExtent(north=80, south=20, east=60, west=10,
         ... bottom=-50, top=50)
-        >>> B = SpatialExtent(north=80, south=20, east=60, west=10,
+        >>> B = SpatialExtent(north=80, south=20, east=60, west=10,
         >>> C = A.intersect(B)
         >>> C.print_info()
@@ -267,7 +267,7 @@
          | West:....................... 10.0
          | Top:........................ 50.0
          | Bottom:..................... -50.0
-        >>> B = SpatialExtent(north=40, south=30, east=60, west=10,
+        >>> B = SpatialExtent(north=40, south=30, east=60, west=10,
         >>> C = A.intersect(B)
         >>> C.print_info()
@@ -278,7 +278,7 @@
-        >>> B = SpatialExtent(north=40, south=30, east=60, west=30,
+        >>> B = SpatialExtent(north=40, south=30, east=60, west=30,
         >>> C = A.intersect(B)
         >>> C.print_info()
@@ -289,7 +289,7 @@
          | West:....................... 30.0
         ... bottom=-30, top=50)
         >>> C = A.intersect(B)
         >>> C.print_info()
@@ -300,7 +300,7 @@
          | Bottom:..................... -30.0
         ... bottom=-30, top=30)
         >>> C = A.intersect(B)
         >>> C.print_info()
@@ -311,10 +311,10 @@
          | Top:........................ 30.0
          @endcode
@@ -342,22 +342,22 @@
         new.set_bottom(nB)
         return new
     def union_2d(self, extent):
         @param extent The spatial extent to create a union with
         if not self.overlapping_2d(extent) and not self.meet_2d(extent):
             return None
         return self.disjoint_union_2d(extent)
     def disjoint_union_2d(self, extent):
         """!Return the two dimensional union as spatial_extent.
@@ -401,27 +401,27 @@
         return new
     def union(self, extent):
-        """!Return the three dimensional union as spatial_extent
+        """!Return the three dimensional union as spatial_extent
         if not self.overlapping(extent) and not self.meet(extent):
             return None
         return self.disjoint_union(extent)
     def disjoint_union(self, extent):
         """!Return the three dimensional union as spatial_extent .
         Usage:
         @code
         >>> C = A.disjoint_union(B)
         >>> C.print_info()
@@ -432,7 +432,7 @@
         >>> C.print_info()
@@ -443,7 +443,7 @@
         >>> C.print_info()
@@ -454,7 +454,7 @@
         >>> C.print_info()
@@ -465,7 +465,7 @@
         >>> C.print_info()
@@ -476,9 +476,9 @@
-        >>> B = SpatialExtent(north=90, south=80, east=70, west=20,
+        >>> B = SpatialExtent(north=90, south=80, east=70, west=20,
         ... bottom=-30, top=60)
         >>> C.print_info()
@@ -489,9 +489,9 @@
          | Top:........................ 60.0
          @endcode
          @param extent The spatial extent to create a disjoint union with
@@ -516,19 +516,19 @@
         new.set_bottom(nB)
         return new
     def is_in_2d(self, extent):
         """!Return True if this extent (A) is located in the provided spatial
         extent (B) in two dimensions.
         @verbatim
          _____
         |A _  |
         | |_| |
-        |_____|B
+        |_____|B
         @endverbatim
@@ -571,22 +571,22 @@
     def is_in(self, extent):
         extent (B) in three dimensions.
         Usage:
         @code
-        >>> A = SpatialExtent(north=79, south=21, east=59, west=11,
+        >>> A = SpatialExtent(north=79, south=21, east=59, west=11,
         ... bottom=-49, top=49)
         >>> A.is_in(B)
         True
         >>> B.is_in(A)
         False
         @endcode
@@ -609,44 +609,44 @@
     def contain_2d(self, extent):
         """!Return True if this extent (A) contains the provided spatial
         Usage:
         @code
         >>> B = SpatialExtent(north=79, south=21, east=59, west=11)
         >>> A.contain_2d(B)
         True
         >>> B.contain_2d(A)
         False
         @endcode
         return extent.is_in_2d(self)
-    def contain(self, extent):
+    def contain(self, extent):
         Usage:
         @code
-        >>> B = SpatialExtent(north=79, south=21, east=59, west=11,
+        >>> B = SpatialExtent(north=79, south=21, east=59, west=11,
         >>> A.contain(B)
         True
         >>> B.contain(A)
         False
         @endcode
@@ -655,20 +655,20 @@
     def equivalent_2d(self, extent):
         """!Return True if this extent (A) is equal to the provided spatial
         Usage:
         @code
         >>> A.equivalent_2d(B)
         True
         >>> B.equivalent_2d(A)
         True
         @endcode
@@ -711,22 +711,22 @@
     def equivalent(self, extent):
         Usage:
         @code
         >>> A.equivalent(B)
         True
         >>> B.equivalent(A)
         True
         @endcode
@@ -750,27 +750,27 @@
     def cover_2d(self, extent):
         """!Return True if this extent (A) covers the provided spatial
         @verbatim
          _____    _____    _____    _____
         |A  __|  |__  A|  |A | B|  |B | A|
         |  |B |  | B|  |  |  |__|  |__|  |
         |__|__|  |__|__|  |_____|  |_____|
         |A|B| |  |A  __|  |A _  |  |__  A|
         | |_| |  |  |__|B | |B| | B|__|  |
         |_____|  |_____|  |_|_|_|  |_____|
         |A|B  |  |_____|A |A|B|A|  |_____|A
         | |   |  |B    |  | | | |  |_____|B
         |_|___|  |_____|  |_|_|_|  |_____|A
         @endverbatim
         The following cases are excluded:
         - contain
         - in
         - equivalent
@@ -840,9 +840,9 @@
     def cover(self, extent):
         """!Return True if this extent covers the provided spatial
         extent in three dimensions.
         - contain
         - in
         - equivalent
@@ -930,9 +930,9 @@
     def covered_2d(self, extent):
         """!Return True if this extent is covered by the provided spatial
         extent in two dimensions.
         - contain
         - in
         - equivalent
@@ -946,9 +946,9 @@
     def covered(self, extent):
         - contain
         - in
         - equivalent
@@ -963,24 +963,24 @@
         """!Return True if this extent (A) overlaps with the provided spatial
         @verbatim
          _____
         |A  __|__
         |  |  | B|
         |__|__|  |
            |_____|
         @endverbatim
         - contain
         - in
         - cover
         - covered
         - equivalent
@@ -1034,13 +1034,13 @@
         - contain
         - in
         - cover
         - covered
         - equivalent
@@ -1100,9 +1100,9 @@
     def meet_2d(self, extent):
         """!Return True if this extent (A) meets with the provided spatial
         @verbatim
-          _____ _____
+          _____ _____
          |  A  |  B  |
          |_____|     |
                |_____|
@@ -1113,10 +1113,10 @@
            ___
           | A |
-          |___|
+          |___|
          |  B  |
-         |_____|
+         |_____|
           _____
          |  B  |
@@ -1124,9 +1124,9 @@
            |  A  |
            |_____|
          @endverbatim
@@ -1136,9 +1136,6 @@
         eE = extent.get_east()
         eW = extent.get_west()
-        eT = extent.get_top()
-        eB = extent.get_bottom()
         N = self.get_north()
         S = self.get_south()
         E = self.get_east()
@@ -1188,7 +1185,7 @@
     def meet(self, extent):
         """!Return True if this extent meets with the provided spatial
@@ -1309,7 +1306,7 @@
     def disjoint(self, extent):
         """!Return True if this extent is disjoint with the provided spatial
@@ -1334,7 +1331,7 @@
         if  self.meet(extent):
             return False
         return True
     def spatial_relation_2d(self, extent):
@@ -1342,7 +1339,7 @@
         extent and the provided spatial extent in two dimensions.
         Spatial relations are:
         - disjoint
         - meet
         - overlap
@@ -1351,7 +1348,7 @@
         - in
         - contain
         - equivalent
         Usage: see self.spatial_relation()
@@ -1379,7 +1376,7 @@
         extent and the provided spatial extent in three dimensions.
         - disjoint
         - meet
         - overlap
@@ -1388,12 +1385,12 @@
         - in
         - contain
         - equivalent
         Usage:
         @code
         >>> A.spatial_relation(B)
@@ -1551,7 +1548,7 @@
         >>> B = SpatialExtent(north=90, south=80, east=60, west=10, bottom=-50, top=50)
         'meet'
         @endcode
@@ -1574,9 +1571,17 @@
         return "unknown"
-    def set_spatial_extent(self, north, south, east, west, top, bottom):
-        """!Set the three dimensional spatial extent"""
+    def set_spatial_extent_from_values(self, north, south, east, west, top, bottom):
+        """!Set the three dimensional spatial extent
+           @param north The northern edge
+           @param south The southern edge
+           @param east The eastern edge
+           @param west The western edge
+           @param top The top edge
+           @param bottom The bottom edge
         self.set_north(north)
         self.set_south(south)
         self.set_east(east)
@@ -1584,6 +1589,19 @@
         self.set_top(top)
         self.set_bottom(bottom)
+        self.set_north(spatial_extent.get_north())
+        self.set_south(spatial_extent.get_south())
+        self.set_east(spatial_extent.get_east())
+        self.set_west(spatial_extent.get_west())
+        self.set_top(spatial_extent.get_top())
+        self.set_bottom(spatial_extent.get_bottom())
     def set_projection(self, proj):
         """!Set the projection of the spatial extent it should be XY or LL.
            As default the projection is XY
@@ -1593,14 +1611,31 @@
         else:
             self.D["proj"] = proj
-    def set_spatial_extent_2d(self, north, south, east, west):
-        """!Set the two dimensional spatial extent"""
+    def set_spatial_extent_from_values_2d(self, north, south, east, west):
+        """!Set the two dimensional spatial extent from values
         self.set_east(east)
         self.set_west(west)
+    def set_spatial_extent_2d(self, spatial_extent):
+        self.set_north(spatial_extent.north)
+        self.set_south(spatial_extent.south)
+        self.set_east(spatial_extent.east)
+        self.set_west(spatial_extent.west)
     def set_id(self, ident):
         """!Convenient method to set the unique identifier (primary key)"""
         self.ident = ident
@@ -1662,7 +1697,7 @@
         return self.D["proj"]
     def get_volume(self):
-        """!Compute the volume of the extent, in case z is zero
+        """!Compute the volume of the extent, in case z is zero
            (top == bottom or top - bottom = 1) the area is returned"""
         if self.get_projection() == "LL":
@@ -1695,7 +1730,7 @@
         return x * y
-        """!Return a tuple (north, south, east, west, top, bottom)
+        """!Return a tuple (north, south, east, west, top, bottom)
            of the spatial extent"""
         return (
@@ -1754,7 +1789,7 @@
             return self.D["bottom"]
         else:
             return None
     id = property(fget=get_id, fset=set_id)
     north = property(fget=get_north, fset=set_north)
     south = property(fget=get_south, fset=set_south)
@@ -1787,37 +1822,37 @@
 class RasterSpatialExtent(SpatialExtent):
-    def __init__(self, ident=None, north=None, south=None, east=None,
+    def __init__(self, ident=None, north=None, south=None, east=None,
                  west=None, top=None, bottom=None):
         SpatialExtent.__init__(self, "raster_spatial_extent",
                                 ident, north, south, east, west, top, bottom)
 class Raster3DSpatialExtent(SpatialExtent):
         SpatialExtent.__init__(self, "raster3d_spatial_extent",
 class VectorSpatialExtent(SpatialExtent):
         SpatialExtent.__init__(self, "vector_spatial_extent",
 class STRDSSpatialExtent(SpatialExtent):
         SpatialExtent.__init__(self, "strds_spatial_extent",
 class STR3DSSpatialExtent(SpatialExtent):
         SpatialExtent.__init__(self, "str3ds_spatial_extent",
 class STVDSSpatialExtent(SpatialExtent):
         SpatialExtent.__init__(self, "stvds_spatial_extent",
Modified: grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py
--- grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py	2013-08-02 17:11:11 UTC (rev 57378)
+++ grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py	2013-08-02 19:29:58 UTC (rev 57379)
@@ -23,6 +23,9 @@
 #%option G_OPT_STRDS_INPUT
 #%end
+#%option G_OPT_STRDS_OUTPUT
+#%end
 #%option G_OPT_T_WHERE
 #%end
@@ -36,14 +39,6 @@
 #%end
 #%option
-#% key: output
-#% type: string
-#% description: Name of the output space time raster dataset
-#% required: yes
-#% multiple: no
-#%end
-#%option
 #% key: method
 #% type: string
 #% description: Aggregate operation to be performed on the raster maps
@@ -53,7 +48,6 @@
 #% answer: average
 #%end
 #%option G_OPT_R_BASE
 #%end
Modified: grass/trunk/temporal/t.unregister/t.unregister.py
--- grass/trunk/temporal/t.unregister/t.unregister.py	2013-08-02 17:11:11 UTC (rev 57378)
+++ grass/trunk/temporal/t.unregister/t.unregister.py	2013-08-02 19:29:58 UTC (rev 57379)
@@ -162,7 +162,8 @@
         count += 1
     # Execute the collected SQL statenents
-    dbif.execute_transaction(statement)
+    if statement:
+        dbif.execute_transaction(statement)
     grass.percent(num_maps, num_maps, 1)
