[GRASS-SVN] r57557 - sandbox/turek/scatter_plot
Fri Aug 30 06:52:44 PDT 2013
Author: turek
Date: 2013-08-30 06:52:44 -0700 (Fri, 30 Aug 2013)
New Revision: 57557
   sandbox/turek/scatter_plot/testing_patch.diff
scatter plots: various plotting improvemnts, bug fixing
Modified: sandbox/turek/scatter_plot/testing_patch.diff
--- sandbox/turek/scatter_plot/testing_patch.diff	2013-08-30 09:49:39 UTC (rev 57556)
+++ sandbox/turek/scatter_plot/testing_patch.diff	2013-08-30 13:52:44 UTC (rev 57557)
@@ -1,1648 +1,579 @@
-Index: lib/vector/Vlib/open.c
+Index: include/defs/imagery.h
---- lib/vector/Vlib/open.c	(revision 57546)
-+++ lib/vector/Vlib/open.c	(working copy)
-@@ -240,7 +240,9 @@
-         else {
-             char file_path[GPATH_MAX];
-+            /* reduce to current mapset if search path was set */
-+            if(strcmp(Map->mapset, "") == 0)
-+                Map->mapset = G_store(G_mapset());
-             /* temporary map: reduce to current mapset if search path
-              * was set */
-             if (strcmp(Map->mapset, "") == 0)
-Index: lib/imagery/scatt.c
---- lib/imagery/scatt.c	(revision 0)
-+++ lib/imagery/scatt.c	(working copy)
-@@ -0,0 +1,746 @@
-+   \file lib/imagery/scatt.c
+--- include/defs/imagery.h	(revision 57556)
++++ include/defs/imagery.h	(working copy)
+@@ -110,6 +110,23 @@
+ FILE *I_fopen_subgroup_ref_new(const char *, const char *);
+ FILE *I_fopen_subgroup_ref_old(const char *, const char *);
++/* scatt_plt.c */
++void I_sc_init_cats(struct scCats *, int, int);
++void I_sc_free_cats(struct scCats *);
++int I_sc_add_cat(struct scCats *);
++int I_sc_insert_scatt_data(struct scCats *, struct scdScattData *, int, int);
-+   \brief Imagery library - functions for wx Scatter Plot Tool.
++void I_scd_init_scatt_data(struct scdScattData *, int, int, void *);
-+   Low level functions used by wx Scatter Plot Tool.
++int I_compute_scatts(struct Cell_head *, struct scCats *, const char **,
++	                 const char **, int, struct scCats *, const char **);
-+   Copyright (C) 2013 by the GRASS Development Team
++int I_create_cat_rast(struct Cell_head *, const char *);
++int I_insert_patch_to_cat_rast(const char *, struct Cell_head *,  const char *);
-+   This program is free software under the GNU General Public License
-+   (>=v2).  Read the file COPYING that comes with GRASS for details.
++int I_id_scatt_to_bands(const int, const int, int *, int *);
++int I_bands_to_id_scatt(const int, const int, const int, int *);
-+   \author Stepan Turek <stepan.turek at seznam.cz> (Mentor: Martin Landa)
+ /* sig.c */
+ int I_init_signatures(struct Signature *, int);
+ int I_new_signature(struct Signature *);
+Index: include/defs/vedit.h
+--- include/defs/vedit.h	(revision 57556)
++++ include/defs/vedit.h	(working copy)
+@@ -33,6 +33,8 @@
+ int Vedit_merge_lines(struct Map_info *, struct ilist *);
+ /* move.c */
++int Vedit_move_areas(struct Map_info *, struct Map_info **, int,
++		     		 struct ilist *, double, double, double, int, double);
+ int Vedit_move_lines(struct Map_info *, struct Map_info **, int,
+Index: include/imagery.h
+--- include/imagery.h	(revision 57556)
++++ include/imagery.h	(working copy)
+@@ -135,6 +135,56 @@
+ } IClass_statistics;
++/* Scatter Plot backend */
-+#include <grass/raster.h>
-+#include <grass/imagery.h>
-+#include <grass/gis.h>
-+#include <grass/glocale.h>
++#define SC_SCATT_DATA          0
++#define SC_SCATT_CONDITIONS    1
-+#include <stdio.h>
-+#include <stdlib.h>
-+#include <math.h>
-+#include <string.h>
-+struct rast_row
++/*! Holds list of all catagories.
++    It can contain selected areas for scatter plots (SC_SCATT_CONDITIONS type) or computed scatter plots (SC_SCATT_DATA type).
++struct scCats
-+    CELL * row;
-+    char * null_row;
-+    struct Range rast_range; /*Range of whole raster.*/
++    int type;        /*!< SC_SCATT_DATA -> computed scatter plots, SC_SCATT_CONDITIONS -> set conditions for scatter plots to be computed*/
-+   \brief Create pgm header.
-+   Scatter plot internally generates pgm files. These pgms have header in format created by this function.
++    int n_cats;      /*!< number of alocated categories */
-+   \param region region to be pgm header generated for
-+   \param [out] header header of pgm file
-+static int get_cat_rast_header(struct Cell_head * region, char * header){
-+    return sprintf(header, "P5\n%d\n%d\n1\n", region->cols, region->rows);
++    int n_bands;     /*!< number of analyzed bands */
++    int n_scatts;    /*!< number of possible scattter plot which can be created from bands */
-+   \brief Create category raster conditions file.
-+   \param cat_rast_region region to be file generated for
-+   \param cat_rast path of generated category raster file
-+int I_create_cat_rast(struct Cell_head * cat_rast_region,  const char * cat_rast)
-+    FILE * f_cat_rast;
-+    char cat_rast_header[1024];//TODO magic number
-+    int i_row, i_col;
-+    int head_nchars;
++    int   n_a_cats;  /*!< number of used/active categories */
++    int * cats_ids;  /*!< (cat_idx->cat_id) array index is internal idx (position in cats_arr) and id is saved in it's position*/
++    int * cats_idxs; /*!< (cat_id->cat_idx) array index is id and internal idx is saved in it's position*/
-+    unsigned char * row_data;
++    struct scScatts ** cats_arr; /*!< array of pointers to struct scScatts */
-+    f_cat_rast = fopen(cat_rast, "wb");
-+    if(!f_cat_rast) {
-+        G_warning("Unable to create category raster condition file <%s>.", cat_rast);
-+        return -1;
-+    head_nchars = get_cat_rast_header(cat_rast_region, cat_rast_header);
-+    fwrite(cat_rast_header, sizeof(char), head_nchars/sizeof(char), f_cat_rast);
-+    if (ferror(f_cat_rast)){
-+        fclose(f_cat_rast);
-+        G_warning(_("Unable to write header into category raster condition file <%s>."), cat_rast);
-+        return -1;
-+    row_data = (unsigned char *) G_malloc(cat_rast_region->cols * sizeof(unsigned char));
-+    for(i_col = 0; i_col < cat_rast_region->cols; i_col++)
-+        row_data[i_col] = 0 & 255;
-+    for(i_row = 0; i_row < cat_rast_region->rows; i_row++) {
-+        fwrite(row_data, sizeof(unsigned char), (cat_rast_region->cols)/sizeof(unsigned char), f_cat_rast);
-+            G_warning(_("Unable to write into category raster condition file <%s>."), cat_rast);
-+            return -1;
-+    return 0;
-+static int print_reg(struct Cell_head * intersec, const char * pref, int dbg_level)
-+    G_debug(dbg_level, "%s:\n n:%f\ns:%f\ne:%f\nw:%f\nns_res:%f\new_res:%f", pref, intersec->north, intersec->south,
-+               intersec->east, intersec->west, intersec->ns_res, intersec->ew_res);
-+   \brief Find intersection region of two regions.
-+   \param A pointer to intersected region
-+   \param B pointer to intersected region
-+   \param [out] intersec pointer to intersection region of regions A B (relevant params of the region are: south, north, east, west)
-+   \return  0 if interection exists
-+   \return -1 if regions does not intersect
-+static int regions_intersecion(struct Cell_head * A, struct Cell_head * B, struct Cell_head * intersec)
-+    if(B->north < A->south) return -1;
-+    else if(B->north > A->north) intersec->north = A->north;
-+    else intersec->north = B->north;
-+    if(B->south > A->north) return -1;
-+    else if(B->south < A->south) intersec->south = A->south;
-+    else intersec->south = B->south;
-+    if(B->east < A->west) return -1;
-+    else if(B->east > A->east) intersec->east = A->east;
-+    else intersec->east = B->east;
-+    if(B->west > A->east) return -1;
-+    else if(B->west < A->west) intersec->west = A->west;
-+    else intersec->west = B->west;
-+    if(intersec->north == intersec->south) return -1;
-+    if(intersec->east == intersec->west) return -1;
-+    return 0;
-+   \brief Get rows and cols numbers, which defines intersection of the regions.
-+   \param B pointer to intersected region (A and B must have same resolution)
-+   \param [out] A_bounds rows and cols numbers of A stored in south, north, east, west, which defines intersection of A and B
-+   \param [out] B_bounds rows and cols numbers of B stored in south, north, east, west, which defines intersection of A and B
-+   \return -1 if regions do not intersect
-+   \return -2 resolution of regions is not same
++/*! Holds list of all scatter plots, which belongs to category.
-+static int get_rows_and_cols_bounds(struct Cell_head * A,  struct Cell_head * B, struct Cell_head * A_bounds,  struct Cell_head * B_bounds)
++struct scScatts
-+    float ns_res, ew_res;
-+    struct Cell_head intersec;
-+    /* TODO is it right check? */
-+    if(abs(A->ns_res - B->ns_res) > GRASS_EPSILON) {
-+        G_debug(0, "'get_rows_and_cols_bounds' ns_res does not fit, A->ns_res: %f B->ns_res: %f", A->ns_res, B->ns_res);
-+        return -2;
-+    if(abs(A->ew_res - B->ew_res) > GRASS_EPSILON) {
-+        G_debug(0, "'get_rows_and_cols_bounds' ew_res does not fit, A->ew_res: %f B->ew_res: %f", A->ew_res, B->ew_res);
-+        return -2;
-+    ns_res = A->ns_res;
-+    ew_res = A->ew_res;
-+    if(regions_intersecion(A, B, &intersec) == -1)
-+        return -1;
-+    A_bounds->north = ceil((A->north - intersec.north - ns_res * 0.5) / ns_res);
-+    A_bounds->south = ceil((A->north - intersec.south - ns_res * 0.5) / ns_res);
-+    A_bounds->east = ceil((intersec.east - A->west - ew_res * 0.5) / ew_res);
-+    A_bounds->west = ceil((intersec.west - A->west - ew_res * 0.5) / ew_res);
-+    B_bounds->north = ceil((B->north - intersec.north - ns_res * 0.5) / ns_res);
-+    B_bounds->south = ceil((B->north - intersec.south - ns_res * 0.5) / ns_res);
-+    B_bounds->east = ceil((intersec.east - B->west - ew_res * 0.5) / ew_res);
-+    B_bounds->west = ceil((intersec.west - B->west - ew_res * 0.5) / ew_res);
-+    return 0;
-+   \brief Insert raster map patch into pgm file.
-+   \param patch_rast name of raster map
-+   \param cat_rast_region region of category raster file
-+   \param cat_rast path to category raster file
-+   \return  0 on success
-+   \return -1 on failure
-+int I_insert_patch_to_cat_rast(const char * patch_rast, struct Cell_head * cat_rast_region,  const char * cat_rast)
-+    struct Cell_head patch_region, patch_bounds, cat_rast_bounds;
-+    int i_row, i_col, ncols, nrows, cat_rast_col, patch_col, val;
-+    int head_nchars, ret;
-+    int fd_patch_rast, init_shift, step_shift;
-+    unsigned char * patch_data;
-+    char * null_chunk_row;
-+    const char *mapset;
-+    struct Cell_head patch_lines, cat_rast_lines;
-+    f_cat_rast = fopen(cat_rast, "rb+");
-+        G_warning(_("Unable to open category raster condtions file <%s>."), cat_rast);
-+        return -1;
-+    if ((mapset = G_find_raster(patch_rast,"")) == NULL) {
-+        G_warning(_("Unable to find patch raster <%s>."), patch_rast);
-+        return -1;
-+    Rast_get_cellhd(patch_rast, mapset, &patch_region);
-+    Rast_set_window(&patch_region);
-+    if ((fd_patch_rast = Rast_open_old(patch_rast, mapset)) < 0) {
-+        return -1;
-+    ret = get_rows_and_cols_bounds(cat_rast_region, &patch_region, &cat_rast_bounds, &patch_bounds);
-+    if(ret == -2) {
-+        G_warning(_("Resolutions of patch <%s> and patched file <%s> are not same."), patch_rast, cat_rast);
-+        Rast_close(fd_patch_rast);
-+        return -1;
-+    else if (ret == -1){
-+        return 0;
-+    ncols = cat_rast_bounds.east - cat_rast_bounds.west;
-+    nrows = cat_rast_bounds.south - cat_rast_bounds.north;
-+    patch_data = (unsigned char *) G_malloc(ncols * sizeof(unsigned char));
-+    init_shift = head_nchars + cat_rast_region->cols * cat_rast_bounds.north + cat_rast_bounds.west;
-+    if(fseek(f_cat_rast, init_shift, SEEK_SET) != 0) {
-+        G_warning(_("Corrupted  category raster conditions file <%s> (fseek failed)"), cat_rast);
-+        G_free(null_chunk_row);
-+        return -1;
-+    step_shift = cat_rast_region->cols - ncols;
-+    null_chunk_row =  Rast_allocate_null_buf();
++    int n_a_scatts;     /*!< number of used/active scatter plots*/
-+    for(i_row = 0; i_row < nrows; i_row++) {
-+        Rast_get_null_value_row (fd_patch_rast, null_chunk_row, i_row + patch_bounds.north);
++    int * scatts_bands; /*!< array of bands for which represents the scatter plots,
++                             every scatter plot has assigned two bads (size of array is n_a_scatts * 2)*/
++    int * scatt_idxs;   /*!< (scatt_id->scatt_idx) internal idx of the scatter plot (position in scatts_arr)*/
-+        for(i_col = 0; i_col < ncols; i_col++) {
-+            patch_col = patch_bounds.west + i_col;
++    struct scdScattData ** scatts_arr; /*!< array of pointers to scdScattData */
-+            if(null_chunk_row[patch_col] != 1)
-+                patch_data[i_col] = 1 & 255;
-+            else {
-+                patch_data[i_col] = 0 & 255;
-+        fwrite(patch_data, sizeof(unsigned char), (ncols)/sizeof(unsigned char), f_cat_rast);
-+            G_warning(_("Unable to write into category raster conditions file <%s>"), cat_rast);
-+            return -1;
-+        if(fseek(f_cat_rast, step_shift, SEEK_CUR) != 0) {
-+            return -1;
-+    return 0;
-+   \brief Updates scatter plots data in category by pixels which meets category conditions.
-+   \param bands_rows data represents data describig one row from raster band
-+   \param belongs_pix array which defines which pixels belongs to category (1 value) and which not (0 value)
-+   \param [out] scatts pointer to scScatts struct of type SC_SCATT_DATA, which are modified according to values in belongs_pix
++/*! Holds scatter plot data.
-+static inline void update_cat_scatt_plts(struct rast_row * bands_rows, unsigned short * belongs_pix, struct scScatts * scatts)
++struct scdScattData
-+    int band_axis_1, band_axis_2, i_scatt, array_idx, cat_idx, i_chunk_rows_pix, max_arr_idx;
++    int n_vals; /*!< Number of values in scatter plot. */
-+    CELL * b_1_row;
-+    CELL * b_2_row;
-+    char * b_1_null_row,* b_2_null_row;
-+    struct rast_row b_1_rast_row, b_2_rast_row;
++    unsigned char  * b_conds_arr; /*!< array of selected areas (used for SC_SCATT_CONDITIONS type) otherwise NULL */
++    unsigned int  * scatt_vals_arr; /*!< array of computed areas (used for SC_SCATT_DATA type) otherwise NULL */
-+    struct Range b_1_range, b_2_range;
-+    int b_1_range_size;
-+    int row_size = Rast_window_cols();
+ #define SIGNATURE_TYPE_MIXED 1
+ #define GROUPFILE "CURGROUP"
+Index: gui/wxpython/scatt_plot/gthreading.py
+--- gui/wxpython/scatt_plot/gthreading.py	(revision 0)
++++ gui/wxpython/scatt_plot/gthreading.py	(working copy)
+@@ -0,0 +1,133 @@
++ at package scatt_plot.gthreading
-+    int * scatts_bands = scatts->scatts_bands;
++Classes:
-+    for(i_scatt = 0; i_scatt < scatts->n_a_scatts; i_scatt++)
-+        b_1_rast_row = bands_rows[scatts_bands[i_scatt * 2]];
-+        b_2_rast_row = bands_rows[scatts_bands[i_scatt * 2 + 1]];
++(C) 2013 by the GRASS Development Team
-+        b_1_row = b_1_rast_row.row;
-+        b_2_row = b_2_rast_row.row;
++This program is free software under the GNU General Public License
++(>=v2). Read the file COPYING that comes with GRASS for details.
-+        b_1_null_row =  b_1_rast_row.null_row;
-+        b_2_null_row =  b_2_rast_row.null_row;
++ at author Stepan Turek <stepan.turek seznam.cz> (mentor: Martin Landa)
-+        b_1_range = b_1_rast_row.rast_range;
-+        b_2_range = b_2_rast_row.rast_range;
-+        b_1_range_size = b_1_range.max - b_1_range.min + 1;
-+        max_arr_idx = (b_1_range.max -  b_1_range.min + 1) * (b_2_range.max -  b_2_range.min + 1);
++import os
++import sys
++import time
++import threading
++import Queue
-+        for(i_chunk_rows_pix = 0; i_chunk_rows_pix < row_size; i_chunk_rows_pix++)
-+            /* pixel does not belongs to scatter plot or has null value in one of the bands */
-+            if(!belongs_pix[i_chunk_rows_pix] ||
-+                b_1_null_row[i_chunk_rows_pix] == 1 ||
-+                b_2_null_row[i_chunk_rows_pix] == 1)
-+                continue;
++import wx
++from core.gconsole import wxCmdRun, wxCmdDone, wxCmdPrepare
-+            /* index in scatter plot array */
-+            array_idx = b_1_row[i_chunk_rows_pix] - b_1_range.min + (b_2_row[i_chunk_rows_pix] - b_2_range.min) * b_1_range_size;
++class gThread(threading.Thread):
++    """!Thread for GRASS commands"""
++    requestId = 0
-+            if(array_idx < 0 || array_idx >= max_arr_idx) {
-+                        G_warning ("Data inconsistent. Value computed for scatter plot is out of initialized range.");
-+                continue;
++    def __init__(self, receiver, requestQ=None, resultQ=None, **kwds):
++        @param receiver event receiver (used in PostEvent)
++        threading.Thread.__init__(self, **kwds)
-+            /* increment scatter plot value */
-+            ++scatts->scatts_arr[i_scatt]->scatt_vals_arr[array_idx];
++        if requestQ is None:
++            self.requestQ = Queue.Queue()
++        else:
++            self.requestQ = requestQ
-+   \brief Computes scatter plots data from chunk_rows.
++        if resultQ is None:
++            self.resultQ = Queue.Queue()
++        else:
++            self.resultQ = resultQ
-+   \param scatts pointer to scScatts struct of type SC_SCATT_DATA, where are computed scatter plots stored
-+   \param scatt_conds pointer to scScatts struct of type SC_SCATT_CONDITIONS, where are selected areas (condtitions)stored
++        self.setDaemon(True)
-+   \param chunk_rows data arrays of chunk_rows from analyzed raster bands (all data in chunk_rows, null_chunk_rows and belongs_pix arrays represents same region)
-+   \param null_chunk_rows null data arrays of chunk_rows from analyzed raster bands
-+   \param row_size size of data in chunk_rows, null_chunk_rows and belongs_pix arrays
-+   \param f_cats_rasts_conds file which stores selected areas (conditions) from mapwindow see I_create_cat_rast() and I_pa
-+   \param fd_cats_rasts array of openedraster maps which represents all selected pixels for category
-+   \param region analysis region
++        self.receiver = receiver
++        self._want_abort_all = False
-+static inline int compute_scatts_from_chunk_row(struct Cell_head *region, struct scCats * scatt_conds,
-+                                                FILE ** f_cats_rasts_conds, struct rast_row * bands_rows,
-+                                                struct scCats * scatts, int * fd_cats_rasts)
++        self.start()
-+    int i_rows_pix, i_cat, i_scatt, n_a_scatts, n_pixs;
-+    int cat_id, scatt_plts_cat_idx, array_idx, max_arr_idx;
-+    CELL * cat_rast_row;
++    def Run(self, *args, **kwds):
++        """!Run command in queue
-+    struct scScatts * scatts_conds;
-+    struct scScatts * scatts_scatt_plts;
-+    struct scdScattData * conds;
++        @param args unnamed command arguments
++        @param kwds named command arguments
++        @return request id in queue
++        gThread.requestId += 1
++        self.requestQ.put((gThread.requestId, args, kwds))
-+    int * scatts_bands;
-+    struct scdScattData ** scatts_arr;
++        return gThread.requestId
-+    CELL * b_1_row;
-+    CELL * b_2_row;
-+    unsigned char * i_scatt_conds;
++    def GetId(self):
++         """!Get id for next command"""
++         return gThread.requestId + 1
++    def SetId(self, id):
++        """!Set starting id"""
++        gThread.requestId = id
-+    unsigned short * belongs_pix = (unsigned short *) G_malloc(row_size * sizeof(unsigned short));
-+    unsigned char * rast_pixs = (unsigned char *) G_malloc(row_size * sizeof(unsigned char));
-+    cat_rast_row =  Rast_allocate_c_buf();
++    def run(self):
++        os.environ['GRASS_MESSAGE_FORMAT'] = 'gui'
++        while True:
++            requestId, args, kwds = self.requestQ.get()
++            for key in ('callable', 'onDone', 'onPrepare', 'userData'):
++                if key in kwds:
++                    vars()[key] = kwds[key]
++                    del kwds[key]
++                else:
++                    vars()[key] = None
-+    for(i_cat = 0; i_cat < scatt_conds->n_a_cats; i_cat++)
-+        scatts_conds = scatt_conds->cats_arr[i_cat];
++            requestTime = time.time()
-+        cat_id = scatt_conds->cats_ids[i_cat];
++            #if self._want_abort_all and self.requestCmd is not None:
++            #    self.requestCmd.abort()
++            #    if self.requestQ.empty():
++            #        self._want_abort_all = False
-+        scatt_plts_cat_idx = scatts->cats_idxs[cat_id];
-+        if(scatt_plts_cat_idx < 0)
-+            continue;
-+        scatts_scatt_plts = scatts->cats_arr[scatt_plts_cat_idx];
++            # prepare
++            if self.receiver:
++                event = wxCmdPrepare(type = 'method',
++                                     time=requestTime,
++                                     pid=requestId)
-+        G_zero(belongs_pix, row_size * sizeof(unsigned short));
++                wx.PostEvent(self.receiver, event)
-+        /* if category has no conditions defined, scatter plots without any constraint are computed (default scatter plots) */
-+        if(!scatts_conds->n_a_scatts && !f_cats_rasts_conds[i_cat]) {
-+            for(i_scatt = 0; i_scatt < scatts_scatt_plts->n_a_scatts; i_scatt++)
-+                /* all pixels belongs */
-+                for(i_rows_pix = 0; i_rows_pix < row_size; i_rows_pix++)
-+                    belongs_pix[i_rows_pix] = 1;
-+        /* compute belonging pixels for defined conditions */
-+        else
-+            scatts_bands = scatts_conds->scatts_bands;
++                # run command
++                event = wxCmdRun(type = 'method',
++                                 pid=requestId)
-+            /* check conditions from category raster condtitions file */
-+            if(f_cats_rasts_conds[i_cat]) {
-+                n_pixs = fread(rast_pixs, sizeof(unsigned char), (row_size)/sizeof(unsigned char), f_cats_rasts_conds[i_cat]);
-+                if (ferror(f_cats_rasts_conds[i_cat]))
-+                    G_free(rast_pixs);
-+                    G_free(belongs_pix);
-+                    G_warning(_("Unable to read from category raster condtition file."));
-+                    return -1;
-+                if (n_pixs != n_pixs) {
-+                    G_warning(_("Invalid size of category raster conditions file."));
-+                    return -1;
++            time.sleep(.1)
-+                    if(rast_pixs[i_rows_pix] != 0 & 255)
-+            /* check condtions defined in scatter plots*/
-+            for(i_scatt = 0; i_scatt < scatts_conds->n_a_scatts; i_scatt++)
-+                i_scatt_conds = scatts_conds->scatts_arr[i_scatt]->b_conds_arr;
-+                    /* pixels already belongs to category from category raster conditions file or contains null value in one of the bands */
-+                    if(belongs_pix[i_rows_pix] ||
-+                       b_1_null_row[i_rows_pix] == 1 ||
-+                       b_2_null_row[i_rows_pix] == 1)
-+                        continue;
-+                    array_idx = b_1_row[i_rows_pix] - b_1_range.min + (b_2_row[i_rows_pix] - b_2_range.min) * b_1_range_size;
-+                        continue;
-+                    /* pixels meets condtion defined in scatter plot */
-+                    if(i_scatt_conds[array_idx])
-+        /* update category raster with belonging pixels */
-+        if(fd_cats_rasts[i_cat] >= 0) {
-+            Rast_set_null_value(cat_rast_row, Rast_window_cols(), CELL_TYPE);
-+                if(belongs_pix[i_rows_pix])
-+                    cat_rast_row[i_rows_pix] = belongs_pix[i_rows_pix];
-+            Rast_put_c_row (fd_cats_rasts[i_cat], cat_rast_row);
-+        /* update scatter plots with belonging pixels */
-+        update_cat_scatt_plts(bands_rows, belongs_pix, scatts_scatt_plts);
-+    G_free(cat_rast_row);
-+    return 0;
-+   \brief Get list if bands needed to be opened for analysis from scCats struct.
-+static void get_needed_bands(struct scCats * cats, int * b_needed_bands)
-+    // results in b_needed_bands - array of bools - if item has value 1, band (defined by item index) is needed to be opened
-+    int i_cat, i_scatt, cat_id;
-+    for(i_cat = 0;  i_cat < cats->n_a_cats; i_cat++)
-+        for(i_scatt = 0;  i_scatt < cats->cats_arr[i_cat]->n_a_scatts; i_scatt++)
-+            G_debug(3, "Active scatt %d in catt %d", i_scatt, i_cat);
-+            b_needed_bands[cats->cats_arr[i_cat]->scatts_bands[i_scatt * 2]] = 1;
-+            b_needed_bands[cats->cats_arr[i_cat]->scatts_bands[i_scatt * 2 + 1]] = 1;
-+    return;
-+   \brief Helper function for clean up.
-+static void free_compute_scatts_data(int * fd_bands, struct rast_row * bands_rows, int n_a_bands, int * bands_ids,
-+                                     int * fd_cats_rasts, FILE ** f_cats_rasts_conds, int n_a_cats)
-+    int i, band_id;
-+    for(i = 0; i < n_a_bands; i++)
-+        band_id = bands_ids[i];
-+        if(band_id >= 0) {
-+            Rast_close(fd_bands[i]);
-+            G_free(bands_rows[band_id].row);
-+            G_free(bands_rows[band_id].null_row);
-+    if(f_cats_rasts_conds)
-+        for(i = 0; i < n_a_cats; i++)
-+            if(f_cats_rasts_conds[i])
-+                fclose(f_cats_rasts_conds[i]);
-+    if(fd_cats_rasts)
-+            if(fd_cats_rasts[i] >= 0)
-+                Rast_close(fd_cats_rasts[i]);
-+   \brief Compute scatter plots data.
-+    If category has not defined no category raster condition file and no scatter plot with consdtion,
-+    default scatter plot is computed.
-+   \param region analysis region, beaware that all input data must be prepared for this region (bands (their ranges), cats_rasts_conds rasters...)
-+   \param region function calls Rast_set_window for this region
-+   \param scatt_conds pointer to scScatts struct of type SC_SCATT_CONDITIONS, where are stored selected areas (conditions) in scatter plots
-+   \param cats_rasts_conds paths to category raster conditions files representing selected areas (conditions) in rasters for every category
-+   \param cats_rasts_conds index in array represents corresponding category id
-+   \param cats_rasts_conds for manupulation with category raster conditions file see also I_id_scatt_to_bands() and I_insert_patch_to_cat_rast()
-+   \param bands names of analyzed bands, order of bands is defined by their id
-+   \param n_bands number of bands
-+   \param [out] scatts pointer to scScatts struct of type SC_SCATT_DATA, where are computed scatter plots stored
-+   \param [out] cats_rasts array of raster maps names where will be stored all selected pixels for every category
-+int I_compute_scatts(struct Cell_head *region, struct scCats * scatt_conds, const char ** cats_rasts_conds,
-+                     const char ** bands, int n_bands, struct scCats * scatts, const char ** cats_rasts)
-+    char header[1024];
-+    int fd_cats_rasts[scatt_conds->n_a_cats];
-+    FILE * f_cats_rasts_conds[scatt_conds->n_a_cats];
-+    struct rast_row bands_rows[n_bands];
-+    RASTER_MAP_TYPE data_type;
-+    int nrows, i_band, n_a_bands, band_id,
-+        i, i_row, head_nchars, i_cat, id_cat;
-+    int fd_bands[n_bands];
-+    int bands_ids[n_bands];
-+    int b_needed_bands[n_bands];
-+    Rast_set_window(region);
-+    for(i_band = 0; i_band < n_bands; i_band++)
-+        fd_bands[i_band] = -1;
-+        bands_ids[i_band] = -1;
-+    if (n_bands != scatts->n_bands ||
-+        n_bands != scatt_conds->n_bands)
-+        return -1;
-+    memset(b_needed_bands, 0, (size_t)n_bands * sizeof(int));
-+    get_needed_bands(scatt_conds, &b_needed_bands[0]);
-+    get_needed_bands(scatts, &b_needed_bands[0]);
-+    n_a_bands = 0;
-+    /* open band rasters, which are needed for computation */
-+    for(band_id = 0; band_id < n_bands; band_id++)
-+        if(b_needed_bands[band_id])
-+            G_debug(3, "Opening raster no. %d with name: %s", band_id, bands[band_id]);
-+            if ((mapset = G_find_raster2(bands[band_id],"")) == NULL) {
-+                free_compute_scatts_data(fd_bands, bands_rows, n_a_bands,
-+                                         bands_ids, NULL, NULL, scatt_conds->n_a_cats);
-+                G_warning(_("Unbale to read find raster <%s>"), bands[band_id]);
-+                return -1;
++            ret = None
++            exception = None
-+            if ((fd_bands[n_a_bands] = Rast_open_old(bands[band_id], mapset)) < 0) {
-+                G_warning(_("Unbale to open raster <%s>"), bands[band_id]);
-+                return -1;
++            #to
++            #try:
++            ret = vars()['callable'](*args, **kwds)
++            #except Exception as e:
++            #    exception  = e;
-+            data_type = Rast_get_map_type(fd_bands[n_a_bands]);
-+            if(data_type != CELL_TYPE) {
-+                G_warning(_("Raster <%s> type is not <%s>"), bands[band_id], "CELL");
-+                return -1;
++            self.resultQ.put((requestId, ret))
-+            bands_rows[band_id].row =  Rast_allocate_c_buf();
-+            bands_rows[band_id].null_row =  Rast_allocate_null_buf();
++            time.sleep(.1)
-+            if(Rast_read_range(bands[band_id], mapset, &bands_rows[band_id].rast_range) != 1){
-+                G_warning(_("Unable to read range of raster <%s>"), bands[band_id]);
-+                return -1;
++                event = wxCmdDone(kwds = kwds,
++                                  args = args, #TODO expand args to kwds
++                                  ret=ret,
++                                  exception=exception,
++                                  pid=requestId)
-+            bands_ids[n_a_bands] = band_id;
-+            ++n_a_bands;
++                # send event
-+    /* open category rasters condition files and category rasters */
-+    for(i_cat = 0; i_cat < scatts->n_a_cats; i_cat++)
-+        id_cat = scatts->cats_ids[i_cat];
-+        if(cats_rasts[id_cat]) {
-+            fd_cats_rasts[i_cat] = Rast_open_new(cats_rasts[id_cat], CELL_TYPE);
-+        else
-+            fd_cats_rasts[i_cat] = -1;
-+        if(cats_rasts_conds[id_cat]) {
-+            f_cats_rasts_conds[i_cat] = fopen(cats_rasts_conds[id_cat], "r");
-+            if(!f_cats_rasts_conds[i_cat]) {
-+                free_compute_scatts_data(fd_bands, bands_rows, n_a_bands, bands_ids,
-+                                         f_cats_rasts_conds, f_cats_rasts_conds, scatt_conds->n_a_cats);
-+                G_warning(_("Unable to open category raster condtition file <%s>"), bands[band_id]);
-+                return -1;
-+        else
-+            f_cats_rasts_conds[i_cat] = NULL;
-+    head_nchars =  get_cat_rast_header(region, header);
-+            if( fseek(f_cats_rasts_conds[i_cat] , head_nchars, SEEK_SET) != 0) {
-+                G_warning(_("Corrupted category raster conditions file (fseek failed)"));
-+                return -1;
-+    nrows = Rast_window_rows();
-+    /* analyze bands by rows */
-+    for (i_row = 0; i_row < nrows; i_row++)
-+        for(i_band = 0; i_band < n_a_bands; i_band++)
-+            band_id = bands_ids[i_band];
-+            Rast_get_c_row(fd_bands[i_band], bands_rows[band_id].row, i_row);
-+            Rast_get_null_value_row (fd_bands[i_band], bands_rows[band_id].null_row, i_row);
-+        if(compute_scatts_from_chunk_row(region, scatt_conds, f_cats_rasts_conds, bands_rows, scatts, fd_cats_rasts) == -1)
-+            free_compute_scatts_data(fd_bands, bands_rows, n_a_bands, bands_ids, fd_cats_rasts,
-+                                     f_cats_rasts_conds, scatt_conds->n_a_cats);
-+            return -1;
-+                             fd_cats_rasts, f_cats_rasts_conds, scatt_conds->n_a_cats);
-+    return 0;
++    def abort(self, abortall=True):
++        """!Abort command(s)"""
++        if abortall:
++            self._want_abort_all = True
++        if self.requestQ.empty():
 \ No newline at end of file
-Index: lib/imagery/scatt_sccats.c
+Index: gui/wxpython/scatt_plot/dialogs.py
---- lib/imagery/scatt_sccats.c	(revision 0)
-+++ lib/imagery/scatt_sccats.c	(working copy)
-@@ -0,0 +1,405 @@
-+   \file lib/imagery/scatt_cat_rast.c
+--- gui/wxpython/scatt_plot/dialogs.py	(revision 0)
++++ gui/wxpython/scatt_plot/dialogs.py	(working copy)
+@@ -0,0 +1,142 @@
++ at package scatt_plot.dialogs
-+   \brief Imagery library - functions for manipulation with scatter plot structs.
++ at brief GUI.
++Classes:
++import os
++import sys
-+#include <math.h>
++import wx
++from scatt_plot.scatt_core import idBandsToidScatt
-+   \brief Compute band ids from scatter plot id.
++class AddScattPlotDialog(wx.Dialog):
-+    Scatter plot id describes which bands defines the scatter plot.
++    def __init__(self, parent, bands, id  = wx.ID_ANY):
++        wx.Dialog.__init__(self, parent, title = ("Add scatter plot"), id = id)
-+    Let say we have 3 bands, their ids are 0, 1 and 2.
-+    Scatter plot with id 0 consists of band 1 (b_1_id) 0 and  band 2 (b_2_id) 1.
-+    All scatter plots:
-+    scatt_id b_1_id b_2_id
-+    0        0      1
-+    1        0      2
-+    2        1      2
++        self.bands = bands
-+   \param scatt_id scatter plot id
-+   \param [out] b_1_id id of band1
-+   \param[out] b_2_id id of band2
++        self.scatt_id = None
-+   \return 0
-+int I_id_scatt_to_bands(const int scatt_id, const int n_bands, int * b_1_id, int * b_2_id)
-+    int n_b1 = n_bands - 1;
++        self._createWidgets()
-+    * b_1_id = (int) ((2 * n_b1 + 1 - sqrt((double)((2 * n_b1 + 1) * (2 * n_b1 + 1) - 8 * scatt_id))) / 2);
++    def _createWidgets(self):
-+    * b_2_id = scatt_id - ((* b_1_id) * (2 * n_b1 + 1) - (* b_1_id) * (* b_1_id)) / 2 + (* b_1_id) + 1;
++        self.labels = {}
++        self.params = {}
-+    return 0;
++        self.band_1_label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Band 1:"))
++        self.band_1_ch = wx.ComboBox(parent = self, id = wx.ID_ANY,
++                                     choices = self.bands,
++                                     style = wx.CB_READONLY, size = (350, 30))
-+   \brief Compute scatter plot id from band ids.
++        self.band_2_label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Band 2:"))
-+    See also I_id_scatt_to_bands().
++        self.band_2_ch = wx.ComboBox(parent = self, id = wx.ID_ANY,
-+   \param b_1_id id of band1
-+   \param b_1_id id of band2
-+   \param [out] scatt_id scatter plot id
++        # buttons
++        self.btn_close = wx.Button(parent = self, id = wx.ID_CANCEL)
++        self.btn_ok = wx.Button(parent = self, id = wx.ID_OK, label = _("&OK"))
-+   \return 0
-+int I_bands_to_id_scatt(const int b_1_id, const int b_2_id, const int n_bands, int * scatt_id)
++        self._layout()
-+    * scatt_id = (b_1_id * (2 * n_b1 + 1) - b_1_id * b_1_id) / 2 + b_2_id - b_1_id - 1;
++    def _layout(self):
-+    return 0;
++        border = wx.BoxSizer(wx.VERTICAL)
++        dialogSizer = wx.BoxSizer(wx.VERTICAL)
-+   \brief Initialize structure for storing scatter plots data.
++        regionSizer = wx.BoxSizer(wx.HORIZONTAL)
-+   \param cats pointer to scCats struct
-+   \param type SC_SCATT_DATA - stores scatter plots
-+   \param type SC_SCATT_CONDITIONS - stores selected areas in scatter plots
-+void I_sc_init_cats(struct scCats * cats, int n_bands, int type)
-+    int i_cat;
++        dialogSizer.Add(item = self._addSelectSizer(title = self.band_1_label,
++                                                    sel = self.band_1_ch))
-+    cats->type = type;
++        dialogSizer.Add(item = self._addSelectSizer(title = self.band_2_label,
++                                                    sel = self.band_2_ch))
-+    cats->n_cats = 100;
-+    cats->n_a_cats = 0;
++        # buttons
++        self.btnsizer = wx.BoxSizer(orient = wx.HORIZONTAL)
-+    cats->n_bands = n_bands;
-+    cats->n_scatts = (n_bands - 1) * n_bands / 2;
++        self.btnsizer.Add(item = self.btn_close, proportion = 0,
++                          flag = wx.ALL | wx.ALIGN_CENTER,
++                          border = 10)
++        self.btnsizer.Add(item = self.btn_ok, proportion = 0,
++                          border = 10)
-+    cats->cats_arr = (struct scScatts **) G_malloc(cats->n_cats * sizeof(struct scScatts *));
-+    memset(cats->cats_arr, 0, cats-> n_cats * sizeof(struct scScatts *));
++        dialogSizer.Add(item = self.btnsizer, proportion = 0,
++                        flag = wx.ALIGN_CENTER)
-+    cats->cats_ids = (int *)  G_malloc(cats->n_cats * sizeof(int));
-+    cats->cats_idxs =(int *)  G_malloc(cats->n_cats * sizeof(int));
++        border.Add(item = dialogSizer, proportion = 0,
++                   flag = wx.ALL, border = 5)
-+    for(i_cat = 0; i_cat < cats->n_cats; i_cat++)
-+        cats->cats_idxs[i_cat] = -1;
++        self.SetSizer(border)
++        self.Layout()
++        self.Fit()
-+    return;
++        # bindings
++        self.btn_close.Bind(wx.EVT_BUTTON, self.OnClose)
++        self.btn_ok.Bind(wx.EVT_BUTTON, self.OnOk)
-+   \brief Free data of struct scCats, the structure itself remains alocated.
++    def _addSelectSizer(self, title, sel):
++        """!Helper layout function.
++        selSizer = wx.BoxSizer(orient = wx.VERTICAL)
-+   \param cats pointer to existing scCats struct
-+void I_sc_free_cats(struct scCats * cats)
-+    int i_cat;
++        selTitleSizer = wx.BoxSizer(wx.HORIZONTAL)
++        selTitleSizer.Add(item = title, proportion = 1,
++                          flag = wx.LEFT | wx.TOP | wx.EXPAND, border = 5)
-+        if(cats->cats_arr[i_cat])
-+            G_free(cats->cats_arr[i_cat]->scatt_idxs);
-+            G_free(cats->cats_arr[i_cat]->scatts_bands);
-+            G_free(cats->cats_arr[i_cat]->scatts_arr);
-+            G_free(cats->cats_arr[i_cat]);
++        selSizer.Add(item = selTitleSizer, proportion = 0,
++                     flag = wx.EXPAND)
-+    G_free(cats->cats_ids);
-+    G_free(cats->cats_idxs);
-+    G_free(cats->cats_arr);
++        selSizer.Add(item = sel, proportion = 1,
++                     flag = wx.EXPAND | wx.ALL| wx.ALIGN_CENTER_VERTICAL,
++                     border = 5)
-+    cats->n_cats = 0;
-+    cats->n_bands = 0;
-+    cats->n_scatts = 0;
-+    cats->type = -1;
++        return selSizer
-+    return;
++    def OnClose(self, event):
++        """!Close dialog
++        if not self.IsModal():
++            self.Destroy()
++        event.Skip()
-+#if 0
-+void I_sc_get_active_categories(int * a_cats_ids, int * n_a_cats, struct scCats * cats)
-+    a_cats_ids = cats->cats_ids;
-+    * n_a_cats = cats->n_a_cats;
-+#endif
++    def OnOk(self, event):
++        band_1 = self.band_1_ch.GetSelection()
++        band_2 = self.band_2_ch.GetSelection()
-+   \brief Add category.
-+    Category represents group of scatter plots.
++        if band_1 == band_2:
++            GError(_("Selected bands must be different."))
++            return
++        #TODO axes selection
++        if band_1 > band_2:
++            tmp_band = band_2
++            band_2 = band_1
++            band_1 = band_2
-+   \return assigned category id (starts with 0)
-+   \return -1 if maximum nuber of categories was reached
-+int I_sc_add_cat(struct scCats * cats)
-+    int i_scatt, i_cat_id, cat_id;
-+    int n_a_cats = cats->n_a_cats;
++        self.scatt_id = idBandsToidScatt(band_1, band_2, len(self.bands))
-+    if(cats->n_a_cats >= cats->n_cats)
-+        return -1;
++        event.Skip()
-+    for(i_cat_id = 0; i_cat_id < cats->n_cats; i_cat_id++)
-+        if(cats->cats_idxs[i_cat_id] < 0) {
-+            cat_id = i_cat_id;
-+            break;
-+    cats->cats_ids[n_a_cats] = cat_id;
-+    cats->cats_idxs[cat_id] = n_a_cats;
-+    cats->cats_arr[n_a_cats] = (struct scScatts *) G_malloc(sizeof(struct scScatts));
-+    cats->cats_arr[n_a_cats]->scatts_arr = (struct scdScattData **) G_malloc(cats->n_scatts * sizeof(struct scdScattData *));
-+    memset((cats->cats_arr[n_a_cats]->scatts_arr), 0, cats->n_scatts * sizeof(struct scdScattData *));
-+    cats->cats_arr[n_a_cats]->n_a_scatts = 0;
-+    cats->cats_arr[n_a_cats]->scatts_bands = (int *) G_malloc(cats->n_scatts * 2 * sizeof(int));
-+    cats->cats_arr[n_a_cats]->scatt_idxs = (int *) G_malloc(cats->n_scatts * sizeof(int));
-+    for(i_scatt = 0; i_scatt < cats->n_scatts; i_scatt++)
-+        cats->cats_arr[n_a_cats]->scatt_idxs[i_scatt] = -1;
-+    ++cats->n_a_cats;
-+    return cat_id;
-+#if 0
-+int I_sc_delete_cat(struct scCats * cats, int cat_id)
-+    int cat_idx, i_cat;
-+    if(cat_id < 0 || cat_id >= cats->n_cats)
-+        return -1;
-+    cat_idx = cats->cats_idxs[cat_id];
-+    if(cat_idx < 0)
-+        return -1;
-+    G_free(cats->cats_arr[cat_idx]->scatt_idxs);
-+    G_free(cats->cats_arr[cat_idx]->scatts_bands);
-+    G_free(cats->cats_arr[cat_idx]->scatts_arr);
-+    G_free(cats->cats_arr[cat_idx]);
-+    for(i_cat = cat_idx; i_cat < cats->n_a_cats - 1; i_cat++)
-+        cats->cats_arr[i_cat] = cats->cats_arr[i_cat + 1];
-+        cats->cats_ids[i_cat] = cats->cats_ids[i_cat + 1];
-+    cats->cats_idxs[cat_id] = -1;
-+    --cats->n_a_cats;
-+    return 0;
-+#endif
-+   \brief Insert scatter plot data .
-+    Inserted scatt_data struct must have same type as cats struct (SC_SCATT_DATA or SC_SCATT_CONDITIONS).
-+   \param cat_id id number of category.
-+   \param scatt_id id number of scatter plot.
-+int I_sc_insert_scatt_data(struct scCats * cats, struct scdScattData * scatt_data, int cat_id, int scatt_id)
-+    int band_1, band_2, cat_idx, n_a_scatts;
-+    struct scScatts * scatts;
-+        return -1;
-+    if(cat_idx < 0)
-+        return -1;
-+    if(scatt_id < 0 && scatt_id >= cats->n_scatts)
-+        return -1;
-+    scatts = cats->cats_arr[cat_idx];
-+    if(scatts->scatt_idxs[scatt_id] >= 0)
-+        return -1;
-+    if(!scatt_data->b_conds_arr && cats->type == SC_SCATT_CONDITIONS)
-+        return -1;
-+    if(!scatt_data->scatt_vals_arr && cats->type == SC_SCATT_DATA)
-+        return -1;
-+    n_a_scatts = scatts->n_a_scatts;
-+    scatts->scatt_idxs[scatt_id] = n_a_scatts;
-+    I_id_scatt_to_bands(scatt_id, cats->n_bands, &band_1, &band_2);
-+    scatts->scatts_bands[n_a_scatts * 2] = band_1;
-+    scatts->scatts_bands[n_a_scatts * 2 + 1] = band_2;
-+    scatts->scatts_arr[n_a_scatts] = scatt_data;
-+    ++scatts->n_a_scatts;
-+    return 0;
-+#if 0
-+int I_sc_remove_scatt_data(struct scCats * cats, struct scdScattData * scatt_data, int cat_id, int scatt_id)
-+    int cat_idx, scatt_idx, n_init_scatts, i_scatt;
-+    if(cat_id < 0 && cat_id >= cats->n_cats)
-+        return -1;
-+    if(cat_idx < 0)
-+        return -1;
-+    if(scatt_id < 0 || scatt_id >= cats->n_scatts)
-+        return -1;
-+    if(scatts->scatt_idxs[scatt_id] < 0)
-+        return -1;
-+    scatt_data = scatts->scatts_arr[scatt_idx];
-+    for(i_scatt = scatt_idx; i_scatt < scatts->n_a_scatts - 1; i_scatt++)
-+        scatts->scatts_arr[i_scatt] = scatts->scatts_arr[i_scatt + 1];
-+        scatts->scatts_bands[i_scatt * 2] = scatts->scatts_bands[(i_scatt + 1)* 2];
-+        scatts->scatts_bands[i_scatt * 2 + 1] = scatts->scatts_bands[(i_scatt + 1) * 2 + 1];
-+    scatts->scatts_arr[scatts->n_a_scatts] = NULL;
-+    scatts->scatt_idxs[scatt_id] = -1;
-+    scatt_data = scatts->scatts_arr[scatt_id];
-+    scatts->n_a_scatts--;
-+    return 0;
-+int I_sc_set_value(struct scCats * cats, int cat_id, int scatt_id, int value_idx, int value)
-+    int n_a_scatts = cats->cats_arr[cat_id]->n_a_scatts;
-+    int cat_idx, scatt_idx, ret;
-+    if(cat_idx < 0)
-+        return -1;
-+    if(cats->cats_arr[cat_idx]->scatt_idxs[scatt_id] < 0)
-+        return -1;
-+    scatt_idx = cats->cats_arr[cat_idx]->scatt_idxs[scatt_id];
-+    I_scd_set_value(cats->cats_arr[cat_idx]->scatts_arr[scatt_idx], value_idx, value);
-+    return 0;
-+#endif
-+   \brief Insert scatter plot data.
-+   \param scatt_data pointer to existing struct scdScattData
-+   \param type SC_SCATT_DATA for scatter plots or SC_SCATT_CONDITIONS for selected areas in scatter plot
-+   \param n_vals number of data values
-+   \param data array of values (unsigned char for SC_SCATT_CONDITIONS, unsigned int for SC_SCATT_DATA)
-+void I_scd_init_scatt_data(struct scdScattData * scatt_data, int type, int n_vals, void * data)
-+    scatt_data->n_vals = n_vals;
-+    if(type == SC_SCATT_DATA)
-+        if(data)
-+            scatt_data->scatt_vals_arr = (unsigned int *) data;
-+        else {
-+            scatt_data->scatt_vals_arr = (unsigned int *) G_malloc(n_vals * sizeof(unsigned int));
-+            memset(scatt_data->scatt_vals_arr, 0, n_vals * sizeof(unsigned int));
-+        scatt_data->b_conds_arr = NULL;
-+    else if(type == SC_SCATT_CONDITIONS)
-+        if(data)
-+            scatt_data->b_conds_arr = (unsigned char *) data;
-+        else {
-+            scatt_data->b_conds_arr = (unsigned char *) G_malloc(n_vals * sizeof(unsigned char));
-+            memset(scatt_data->b_conds_arr, 0, n_vals * sizeof(unsigned char));
-+        scatt_data->scatt_vals_arr = NULL;
-+    return;
-+#if 0
-+void I_scd_get_range_min_max(struct scdScattData * scatt_data, CELL * band_1_min, CELL * band_1_max, CELL * band_2_min, CELL * band_2_max)
-+    Rast_get_range_min_max(&(scatt_data->band_1_range), band_1_min, band_2_min);
-+    Rast_get_range_min_max(&(scatt_data->band_2_range), band_2_min, band_2_max);
-+    return;
-+s
-+void * I_scd_get_data_ptr(struct scdScattData * scatt_data)
-+    if(!scatt_data->b_conds_arr)
-+        return scatt_data->b_conds_arr;
-+    else if(!scatt_data->scatt_vals_arr)
-+        return scatt_data->scatt_vals_arr;
-+    return NULL;
-+int I_scd_set_value(struct scdScattData * scatt_data, unsigned int val_idx, unsigned int val)
-+    if(val_idx < 0 && val_idx >  scatt_data->n_vals)
-+        return -1;
-+    if(scatt_data->b_conds_arr)
-+        scatt_data->b_conds_arr[val_idx] = val;
-+    else if(scatt_data->scatt_vals_arr)
-+        scatt_data->scatt_vals_arr[val_idx] = val;
-+    else
-+        return -1;
-+    return 0;
-+#endif
-Index: include/imagery.h
++    def GetScattId(self):
++        return self.scatt_id
+Index: gui/wxpython/scatt_plot/toolbars.py
---- include/imagery.h	(revision 57546)
-+++ include/imagery.h	(working copy)
-@@ -135,6 +135,56 @@
- } IClass_statistics;
-+/* Scatter Plot backend */
+--- gui/wxpython/scatt_plot/toolbars.py	(revision 0)
++++ gui/wxpython/scatt_plot/toolbars.py	(working copy)
+@@ -0,0 +1,178 @@
++ at package scatt_plot.toolbars
-+#define SC_SCATT_DATA          0
-+#define SC_SCATT_CONDITIONS    1
++ at brief Scatter plot - toolbars
++Classes:
++ - toolbars::MainToolbar
-+/*! Holds list of all catagories.
-+    It can contain selected areas for scatter plots (SC_SCATT_CONDITIONS type) or computed scatter plots (SC_SCATT_DATA type).
-+struct scCats
-+    int type;        /*!< SC_SCATT_DATA -> computed scatter plots, SC_SCATT_CONDITIONS -> set conditions for scatter plots to be computed*/
-+    int n_cats;      /*!< number of alocated categories */
-+    int n_bands;     /*!< number of analyzed bands */
-+    int n_scatts;    /*!< number of possible scattter plot which can be created from bands */
-+    int   n_a_cats;  /*!< number of used/active categories */
-+    int * cats_ids;  /*!< (cat_idx->cat_id) array index is internal idx (position in cats_arr) and id is saved in it's position*/
-+    int * cats_idxs; /*!< (cat_id->cat_idx) array index is id and internal idx is saved in it's position*/
++import wx
-+    struct scScatts ** cats_arr; /*!< array of pointers to struct scScatts */
++from icons.icon import MetaIcon
++from gui_core.toolbars import BaseToolbar, BaseIcons
++from core.gcmd import RunCommand
++from core.gcmd import GException, GError, RunCommand
-+/*! Holds list of all scatter plots, which belongs to category.
-+struct scScatts
-+    int n_a_scatts;     /*!< number of used/active scatter plots*/
-+    int * scatts_bands; /*!< array of bands for which represents the scatter plots,
-+                             every scatter plot has assigned two bads (size of array is n_a_scatts * 2)*/
-+    int * scatt_idxs;   /*!< (scatt_id->scatt_idx) internal idx of the scatter plot (position in scatts_arr)*/
++class MainToolbar(BaseToolbar):
++    """!Main toolbar
++    def __init__(self, parent, scatt_mgr):
++        BaseToolbar.__init__(self, parent)
++        self.scatt_mgr = scatt_mgr
-+    struct scdScattData ** scatts_arr; /*!< array of pointers to scdScattData */
++        self.InitToolbar(self._toolbarData())
++        # realize the toolbar
++        self.Realize()
-+/*! Holds scatter plot data.
-+struct scdScattData
-+    int n_vals; /*!< Number of values in scatter plot. */
++    def _toolbarData(self):
-+    unsigned char  * b_conds_arr; /*!< array of selected areas (used for SC_SCATT_CONDITIONS type) otherwise NULL */
-+    unsigned int  * scatt_vals_arr; /*!< array of computed areas (used for SC_SCATT_DATA type) otherwise NULL */
++        icons = {
++                'settings'   : BaseIcons['settings'].SetLabel( _('Ssettings')),
++                'help'       : MetaIcon(img = 'help',
++                                         label = _('Show manual')),
++                'add_scatt_pl'  : MetaIcon(img = 'layer-raster-analyze',
++                                            label = _('Add scatter plot')),
++                'selCatPol'  : MetaIcon(img = 'polygon-create',
++                                      label = _('Select area with polygon')),
++                'pan'        : MetaIcon(img = 'pan',
++                                         label = _('Pan'),
++                                         desc = _('Pan scatter plot')),
++                'zoomIn'     : MetaIcon(img = 'zoom-in',
++                                          label = _('Zoom'),
++                                          desc = _('Zoom whith mouse wheel')),
++                'cats_mgr' : MetaIcon(img = 'table-manager',
++                                          label = _('Show/hide class manager'))
++        return self._getToolbarData((
++                                     ("cats_mgr", icons['cats_mgr'],
++                                     lambda event: self.parent.ShowCategoryPanel(event.Checked()), wx.ITEM_CHECK),
++                                     (None, ),
++                                     ("pan", icons["pan"],
++                                     lambda event: self.SetPloltsMode(event, 'pan'),
++                                      wx.ITEM_CHECK),
++                                     ("zoom", icons["zoomIn"],
++                                     lambda event: self.SetPloltsMode(event, 'zoom'),
++                                      wx.ITEM_CHECK),
++                                     ('sel_pol_mode', icons['selCatPol'],
++                                      self.ActivateSelectionPolygonMode,
++                                     wx.ITEM_CHECK),
++                                     (None, ),
++                                     ('add_scatt', icons["add_scatt_pl"],
++                                     lambda event : self.scatt_mgr.AddScattPlot())
++                                     #('settings', icon["settings"],
++                                     # self.parent.OnSettings),
++                                     #('help', icons["help"],
++                                     # self.OnHelp),
- #define SIGNATURE_TYPE_MIXED 1
- #define GROUPFILE "CURGROUP"
-Index: include/defs/imagery.h
---- include/defs/imagery.h	(revision 57546)
-+++ include/defs/imagery.h	(working copy)
-@@ -110,6 +110,23 @@
- FILE *I_fopen_subgroup_ref_new(const char *, const char *);
- FILE *I_fopen_subgroup_ref_old(const char *, const char *);
-+/* scatt_plt.c */
-+void I_sc_init_cats(struct scCats *, int, int);
-+void I_sc_free_cats(struct scCats *);
-+int I_sc_add_cat(struct scCats *);
-+int I_sc_insert_scatt_data(struct scCats *, struct scdScattData *, int, int);
++    def GetToolId(self, toolName): #TODO can be useful in base
-+void I_scd_init_scatt_data(struct scdScattData *, int, int, void *);
++        return vars(self)[toolName]
-+int I_compute_scatts(struct Cell_head *, struct scCats *, const char **,
-+	                 const char **, int, struct scCats *, const char **);
++    def SetPloltsMode(self, event, tool_name):
-+int I_create_cat_rast(struct Cell_head *, const char *);
-+int I_insert_patch_to_cat_rast(const char *, struct Cell_head *,  const char *);
++        if event.Checked()  == True:
++            for i_tool_data in  self._data:
++                i_tool_name = i_tool_data[0]
++                if not i_tool_name or i_tool_name == "cats_mgr":
++                    continue
++                if i_tool_name == tool_name:
++                    continue
++                i_tool_id = vars(self)[i_tool_name]
++                self.ToggleTool(i_tool_id, False)
-+int I_id_scatt_to_bands(const int, const int, int *, int *);
-+int I_bands_to_id_scatt(const int, const int, const int, int *);
- /* sig.c */
- int I_init_signatures(struct Signature *, int);
- int I_new_signature(struct Signature *);
-Index: include/defs/vedit.h
---- include/defs/vedit.h	(revision 57546)
-+++ include/defs/vedit.h	(working copy)
-@@ -33,6 +33,8 @@
- int Vedit_merge_lines(struct Map_info *, struct ilist *);
- /* move.c */
-+int Vedit_move_areas(struct Map_info *, struct Map_info **, int,
-+		     		 struct ilist *, double, double, double, int, double);
- int Vedit_move_lines(struct Map_info *, struct Map_info **, int,
- 		     struct ilist *, double, double, double, int, double);
-Index: gui/wxpython/mapdisp/toolbars.py
---- gui/wxpython/mapdisp/toolbars.py	(revision 57546)
-+++ gui/wxpython/mapdisp/toolbars.py	(working copy)
-@@ -239,7 +239,8 @@
-                       (MapIcons["scatter"],     self.parent.OnScatterplot),
-                       (MapIcons["histogram"],   self.parent.OnHistogramPyPlot),
-                       (BaseIcons["histogramD"], self.parent.OnHistogram),
--                      (MapIcons["vnet"],        self.parent.OnVNet)))
-+                      (MapIcons["vnet"],        self.parent.OnVNet),
-+                      (MapIcons["scatter"],     self.parent.OnScatterplot2)))
-     def OnDecoration(self, event):
-         """!Decorations overlay menu
-Index: gui/wxpython/mapdisp/frame.py
---- gui/wxpython/mapdisp/frame.py	(revision 57546)
-+++ gui/wxpython/mapdisp/frame.py	(working copy)
-@@ -225,6 +225,7 @@
-         self.dialogs = {}
-         self.dialogs['attributes'] = None
-+        self.dialogs['scatt_plot'] = None
-         self.dialogs['category'] = None
-         self.dialogs['barscale'] = None
-         self.dialogs['legend'] = None
-@@ -1168,6 +1169,19 @@
-         """!Returns toolbar with zooming tools"""
-         return self.toolbars['map']
-+    def OnScatterplot2(self, event):
-+        """!Init interactive scatterplot tools
-+        if self.dialogs['scatt_plot']:
-+            self.dialogs['scatt_plot'].Raise()
-+            return
-+        from scatt_plot.dialogs import ScattPlotMainDialog
-+        self.dialogs['scatt_plot'] = ScattPlotMainDialog(parent=self, giface=self._giface)
-+        self.dialogs['scatt_plot'].CenterOnScreen()
-+        self.dialogs['scatt_plot'].Show()
-     def OnVNet(self, event):
-         """!Dialog for v.net* modules
-Index: gui/wxpython/iclass/dialogs.py
---- gui/wxpython/iclass/dialogs.py	(revision 57546)
-+++ gui/wxpython/iclass/dialogs.py	(working copy)
-@@ -333,13 +333,19 @@
-         toolbar.SetCategories(catNames = catNames, catIdx = cats)
-         if name in catNames:
-             toolbar.choice.SetStringSelection(name)
-+            cat = toolbar.GetSelectedCategoryIdx()
-         elif catNames:
-             toolbar.choice.SetSelection(0)
++            self.scatt_mgr.SetPlotsMode(mode = tool_name)
 +        else:
-+            cat = None
++            self.scatt_mgr.SetPlotsMode(mode = None)
-         if toolbar.choice.IsEmpty():
-             toolbar.EnableControls(False)
-         else:
-             toolbar.EnableControls(True)
++    def ActivateSelectionPolygonMode(self, event):
-+        self.mapWindow.CategoryChanged(cat)
-         # don't forget to update maps, histo, ...
-     def GetSelectedIndices(self, state =  wx.LIST_STATE_SELECTED):
-Index: gui/wxpython/iclass/toolbars.py
---- gui/wxpython/iclass/toolbars.py	(revision 57546)
-+++ gui/wxpython/iclass/toolbars.py	(working copy)
-@@ -46,9 +46,7 @@
-         'importAreas' : MetaIcon(img = 'layer-import',
-                             label = _('Import training areas from vector map')),
-         'addRgb' : MetaIcon(img = 'layer-rgb-add',
--                            label = _('Add RGB map layer')),
--        'scatt_plot'    : MetaIcon(img = 'layer-raster-analyze',
--                                   label = _('Open Scatter Plot Tool (EXPERIMENTAL GSoC 2013)')),
-+                            label = _('Add RGB map layer'))
- class IClassMapToolbar(BaseToolbar):
-@@ -117,10 +115,7 @@
-                                      ("zoomBack", icons["zoomBack"],
-                                       self.parent.OnZoomBack),
-                                      ("zoomToMap", icons["zoomExtent"],
--                                      self.parent.OnZoomToMap),
--                                     (None, ),
--                                     ("scatt_plot", iClassIcons["scatt_plot"],
--                                      self.parent.OnScatterplot)
-+                                      self.parent.OnZoomToMap)
- class IClassToolbar(BaseToolbar):
-     """!IClass toolbar
-@@ -156,7 +151,7 @@
-         """!Toolbar data"""
-         icons = iClassIcons
-         return self._getToolbarData((("selectGroup", icons['selectGroup'],
--                                      self.parent.OnAddBands),
-+                                      lambda event : self.parent.AddBands()),
-                                       (None, ),
-                                       ("classManager", icons['classManager'],
-                                       self.parent.OnCategoryManager),
-Index: gui/wxpython/iclass/frame.py
---- gui/wxpython/iclass/frame.py	(revision 57546)
-+++ gui/wxpython/iclass/frame.py	(working copy)
-@@ -64,6 +64,8 @@
-                                IClassExportAreasDialog, IClassMapDialog
- from iclass.plots       import PlotPanel
-+from grass.pydispatch.signal import Signal
++        activated = self.scatt_mgr.ActivateSelectionPolygonMode(event.Checked())
++        self.parent.ShowPlotEditingToolbar(activated)
- class IClassMapFrame(DoubleMapFrame):
-     """! wxIClass main frame
-@@ -114,6 +116,10 @@
-             lambda:
-             self.statusbarManager.statusbarItems['coordinates'].SetAdditionalInfo(None))
-         self.SetSize(size)
++        i_tool_id = vars(self)['sel_pol_mode']
++        self.ToggleTool(i_tool_id, activated)
-+        self.groupSet = Signal("IClassMapFrame.groupSet")
-+        self.categoryChanged = Signal('IClassMapFrame.categoryChanged')
++class EditingToolbar(BaseToolbar):
++    """!Main toolbar
-         # Add toolbars
-@@ -177,7 +183,7 @@
-         # PyPlot init
--        self.plotPanel = PlotPanel(self, stats_data = self.stats_data)
-+        self.plotPanel = PlotPanel(self, giface = self._giface, stats_data = self.stats_data)
-         self._addPanes()
-         self._mgr.Update()
-@@ -237,7 +243,7 @@
-             return False
-         return vectorName
-     def RemoveTempVector(self):
-         """!Removes temporary vector map with training areas"""
-         ret = RunCommand(prog = 'g.remove',
-@@ -477,7 +483,7 @@
-         self.Render(self.GetFirstWindow())
--    def OnAddBands(self, event):
-+    def AddBands(self):
-         """!Add imagery group"""
-         dlg = IClassGroupDialog(self, group = self.group)
-         if dlg.ShowModal() == wx.ID_OK:
-@@ -488,7 +494,8 @@
-         """!Set imagery group"""
-         group = grass.find_file(name = name, element = 'group')
-         if group['name']:
--            self.group = group['name']
-+           self.group = group['name']
-+           self.groupSet.emit(group = group['name'])
-         else:
-             GError(_("Group <%s> not found") % name, parent = self)
-@@ -768,17 +775,20 @@
-         Updates number of stddev, histograms, layer in preview display.
--        stat = self.stats_data.GetStatistics(currentCat)
--        nstd = stat.nstd
--        self.toolbars['iClass'].UpdateStddev(nstd)
--        self.plotPanel.UpdateCategory(currentCat)
--        self.plotPanel.OnPlotTypeSelected(None)
-+        if currentCat:
-+          stat = self.stats_data.GetStatistics(currentCat)
-+          nstd = stat.nstd
-+          self.toolbars['iClass'].UpdateStddev(nstd)
-+          self.plotPanel.UpdateCategory(currentCat)
-+          self.plotPanel.OnPlotTypeSelected(None)
--        name = stat.rasterName
--        name = self.previewMapManager.GetAlias(name)
--        if name:
--            self.previewMapManager.SelectLayer(name)
-+          name = stat.rasterName
-+          name = self.previewMapManager.GetAlias(name)
-+          if name:
-+              self.previewMapManager.SelectLayer(name)
++        self.Realize()
-+        self.categoryChanged.emit(cat = currentCat)
-     def DeleteAreas(self, cats):
-         """!Removes all training areas of given categories
-@@ -1105,27 +1115,6 @@
-         self.GetFirstWindow().SetModePointer()
-         self.GetSecondWindow().SetModePointer()
--    def OnScatterplot(self, event):
--        """!Init interactive scatterplot tools
--        if self.dialogs['scatt_plot']:
--            self.dialogs['scatt_plot'].Raise()
--            return
--        try:
--          from scatt_plot.dialogs import ScattPlotMainDialog
--        except:
--          GError(parent  = self, message = _("The Scatter Plot Tool is not installed."))
--          return
--        self.dialogs['scatt_plot'] = ScattPlotMainDialog(parent=self, giface=self._giface, iclass_mapwin = self.GetFirstWindow())
--        scatt_mgr = self.dialogs['scatt_plot'].GetScattMgr()
--        scatt_mgr.DigitDataChanged(self.toolbars['vdigit'].mapLayer.GetName(), self.GetFirstWindow().GetDigit())
--        self.dialogs['scatt_plot'].CenterOnScreen()
--        self.dialogs['scatt_plot'].Show()
- class MapManager:
-     """! Class for managing map renderer.
-Index: gui/wxpython/iclass/plots.py
---- gui/wxpython/iclass/plots.py	(revision 57546)
-+++ gui/wxpython/iclass/plots.py	(working copy)
-@@ -28,7 +28,7 @@
-     for each band and for one category. Coincidence plots show min max range
-     of classes for each band.
--    def __init__(self, parent, stats_data):
-+    def __init__(self, parent, giface, stats_data):
-         scrolled.ScrolledPanel.__init__(self, parent)
-         self.SetupScrolling(scroll_x = False, scroll_y = True)
-@@ -38,26 +38,64 @@
-         self.stats_data = stats_data
-         self.currentCat = None
-+        self._giface = giface
-         self.mainSizer = wx.BoxSizer(wx.VERTICAL)
-         self._createControlPanel()
-+        self._createPlotPanel()
-+        self._createScatterPlotPanel()
-         self.SetSizer(self.mainSizer)
-         self.mainSizer.Fit(self)
-         self.Layout()
-+    def _createPlotPanel(self):
-+        self.canvasPanel = wx.Panel(parent=self)
-+        self.mainSizer.Add(item = self.canvasPanel, proportion = 1, flag = wx.EXPAND, border = 0)
-+        self.canvasSizer = wx.BoxSizer(wx.VERTICAL)
-+        self.canvasPanel.SetSizer(self.canvasSizer)
-     def _createControlPanel(self):
-         self.plotSwitch = wx.Choice(self, id = wx.ID_ANY,
-                                      choices = [_("Histograms"),
--                                                _("Coincident plots")])
-+                                                _("Coincident plots"),
-+                                                _("Scatter plots")])
-         self.mainSizer.Add(self.plotSwitch, proportion = 0, flag = wx.EXPAND|wx.ALL, border = 5)
-         self.plotSwitch.Bind(wx.EVT_CHOICE, self.OnPlotTypeSelected)
-+    def _createScatterPlotPanel(self):
++        """!Toolbar data
-+        try:
-+            from scatt_plot.frame import IClassScatterPlotsPanel
-+            self.scatt_plot_panel = IClassScatterPlotsPanel(parent=self, giface=self._giface, iclass_mapwin = self.parent.GetFirstWindow())
-+            self.mainSizer.Add(self.scatt_plot_panel, proportion = 1, flag = wx.EXPAND, border = 0)
-+            self.scatt_plot_panel.Hide()
-+        except ImportError as e:#TODO
-+            print "ahoj"
-+            print e
-+            self.scatt_plot_panel = None
++        self.icons = {
++            'sel_add'         : MetaIcon(img = 'layer-add',
++                                         label = _('Include selected area to class.'),
++                                         desc = _('Include selected area to class.')),
++            'sel_remove'      : MetaIcon(img = 'layer-remove',
++                                         label = _('Exclude selected area from class.'),
++                                         desc = _('Exclude selected area from class.')),
++            'addVertex'       : MetaIcon(img = 'vertex-create',
++                                         label = _('Add new vertex'),
++                                         desc = _('Add new vertex to polygon boundary scatter plot')),
++            'editLine'        : MetaIcon(img = 'line-edit',
++                                         label = _('Edit line/boundary'),
++                                         desc = _('Add new vertex between last and first points of the boundary')),
++            'moveVertex'      : MetaIcon(img = 'vertex-move',
++                                         label = _('Move vertex'),
++                                         desc = _('Move boundary vertex')),
++            'removeVertex'    : MetaIcon(img = 'vertex-delete',
++                                         label = _('Remove vertex'),
++                                         desc = _('Remove boundary vertex.')),
-     def OnPlotTypeSelected(self, event):
-         """!Plot type selected"""
++                                    ("sel_add", self.icons["sel_add"],
++                                     lambda event: self.scatt_mgr.ProcessSelectionPolygons('add')),
++                                     ("sel_remove", self.icons['sel_remove'],
++                                     lambda event: self.scatt_mgr.ProcessSelectionPolygons('remove')),
++                                     (None, ),
++                                     ("add_vertex", self.icons["editLine"],
++                                     lambda event: self.SetMode(event, 'add_vertex'),
++                                     wx.ITEM_CHECK),
++                                     ("add_boundary_vertex", self.icons['addVertex'],
++                                     lambda event: self.SetMode(event, 'add_boundary_vertex'),
++                                     wx.ITEM_CHECK),
++                                     ("move_vertex", self.icons["moveVertex"],
++                                     lambda event: self.SetMode(event, 'move_vertex'),
++                                     wx.ITEM_CHECK),
++                                     ('delete_vertex', self.icons['removeVertex'],
++                                     lambda event: self.SetMode(event, 'delete_vertex'),
++                                     wx.ITEM_CHECK)
-+        if self.plotSwitch.GetSelection() in [0, 1]:
-+            self.SetupScrolling(scroll_x = False, scroll_y = True)
-+            self.canvasPanel.Show()
-+            self.Layout()
++    def SetMode(self, event, tool_name):
++                if not i_tool_name:
++                    continue
++                    continue
++            self.scatt_mgr.SetPlotsEditingMode(tool_name)
++        else:
++            self.scatt_mgr.SetPlotsEditingMode(None)
-+        elif self.plotSwitch.GetSelection() == 2:
-+            self.SetupScrolling(scroll_x = False, scroll_y = False)
-+            self.scatt_plot_panel.Show()
-+            self.canvasPanel.Hide()
-+            self.Layout()
-         if self.currentCat is None:
-             return
-         if self.plotSwitch.GetSelection() == 0:
-             stat = self.stats_data.GetStatistics(self.currentCat)
-             if not stat.IsReady():
-@@ -66,7 +104,10 @@
-             self.DrawHistograms(stat)
-         else:
-             self.DrawCoincidencePlots()
-+        self.Layout()
-     def StddevChanged(self):
-         """!Standard deviation multiplier changed, redraw histograms"""
-@@ -89,7 +130,7 @@
-             panel.Destroy()
-         self.canvasList = []
-     def ClearPlots(self):
-         """!Clears plot canvases"""
-         for bandIdx in range(len(self.bandList)):
-@@ -104,15 +145,15 @@
-     def CreatePlotCanvases(self):
-         """!Create plot canvases according to the number of bands"""
-         for band in self.bandList:
--            canvas = plot.PlotCanvas(self)
-+            canvas = plot.PlotCanvas(self.canvasPanel)
-             canvas.SetMinSize((-1, 140))
-             canvas.SetFontSizeTitle(10)
-             canvas.SetFontSizeAxis(8)
-             self.canvasList.append(canvas)
--            self.mainSizer.Add(item = canvas, proportion = 1, flag = wx.EXPAND, border = 0)
--        self.SetVirtualSize(self.GetBestVirtualSize())
-+            self.canvasSizer.Add(item = canvas, proportion = 1, flag = wx.EXPAND, border = 0)
-+        self.SetVirtualSize(self.GetBestVirtualSize())
-         self.Layout()
-     def UpdatePlots(self, group, currentCat, stats_data):
-@@ -138,7 +179,7 @@
-     def UpdateCategory(self, cat):
-         self.currentCat = cat
-     def DrawCoincidencePlots(self):
-         """!Draw coincidence plots"""
 Index: gui/wxpython/scatt_plot/scatt_core.py
 --- gui/wxpython/scatt_plot/scatt_core.py	(revision 0)
 +++ gui/wxpython/scatt_plot/scatt_core.py	(working copy)
-@@ -0,0 +1,785 @@
+@@ -0,0 +1,784 @@
 + at package scatt_plot.scatt_plot
@@ -1742,7 +673,7 @@
 +            bbox[k] = self._validExtend(v)
 +        arr[bbox['btm_y'] : bbox['up_y'], bbox['btm_x'] : bbox['up_x']] = value
-+        arr.flush()
++        #arr.flush()
 +        #del arr
 +        start_time = time.clock()
@@ -1806,7 +737,7 @@
 +            arr = self.scatt_conds_dt.GetValuesArr(cat_id, scatt_id)
 +            arr[raster_ind] = value
-+            arr.flush()
++            #arr.flush()
 +        rescaled = (255.0 / arr.max() * (arr - arr.min())).astype(np.uint8)
 +        im = Image.fromarray(rescaled)
@@ -2114,7 +1045,6 @@
 +        shape = (b_i['b2']['max'] - b_i['b2']['min'] + 1, b_i['b1']['max'] - b_i['b1']['min'] + 1)
 +        np_vals = np.memmap(grass.tempfile(), dtype=self.dtype, mode='w+', shape = shape)
-+        np_vals.flush()
 +        self.cats[cat_id][scatt_id] = {
 +                                        'np_vals' : np_vals,
@@ -2603,7 +1533,7 @@
 --- gui/wxpython/scatt_plot/frame.py	(revision 0)
 +++ gui/wxpython/scatt_plot/frame.py	(working copy)
-@@ -0,0 +1,494 @@
+@@ -0,0 +1,543 @@
@@ -2624,13 +1554,12 @@
 +import wx
 +import wx.lib.scrolledpanel as scrolled
 +import wx.lib.mixins.listctrl as listmix
-+import wx.lib.flatnotebook  as FN
-+import wx.aui
 +from core import globalvar
 +from gui_core.gselect import Select
++from gui_core.dialogs import SetOpacityDialog
 +from scatt_plot.controllers import ScattsManager
 +from scatt_plot.toolbars import MainToolbar, EditingToolbar
@@ -2756,10 +1685,8 @@
 +            event.pane.window.CleanUp()
 +    def OnScrollChanged(self, event):
-+        print "changed"
 +        wx.CallAfter(self.Layout)
 +    def OnScroll(self, event):
 +        if self.ignore_scroll > 0:
 +            self.ignore_scroll -= 1
@@ -2799,7 +1726,8 @@
 +        self._mgr.AddPane(scatt,
 +                           aui.AuiPaneInfo().Dockable(True).Floatable(True).
-+                           Name("scatter plot %d" % scatt_id).MinSize((-1, 300)).Caption(("%s x: %s y: %s") % (_("scatter plot"), bands[b1_id], bands[b2_id])).
++                           Name("scatter plot %d" % scatt_id).MinSize((-1, 300)).
++                           Caption(("%s x: %s y: %s") % (_("scatter plot"), bands[b1_id], bands[b2_id])).
 +                           Center().Position(1).MaximizeButton(True).
 +                           MinimizeButton(True).CaptionVisible(True).
 +                           CloseButton(True).Layer(0))
@@ -2835,7 +1763,10 @@
 +        listmix.ListCtrlAutoWidthMixin.__init__(self)
 +        listmix.TextEditMixin.__init__(self)
++        self.Bind(wx.EVT_COMMAND_RIGHT_CLICK, self.OnCategoryRightUp) #wxMSW
++        self.Bind(wx.EVT_RIGHT_UP,            self.OnCategoryRightUp) #wxGTK
 +        self.Bind(wx.EVT_LIST_BEGIN_LABEL_EDIT, self.OnEdit)
 +        self.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnSel)
@@ -2955,27 +1886,75 @@
 +    def OnGetItemAttr(self, item):
 +        return None
-+    def OnClassRightUp(self, event):
++    def OnCategoryRightUp(self, event):
 +        """!Show context menu on right click"""
 +        item, flags = self.HitTest((event.GetX(), event.GetY()))
 +        if item != wx.NOT_FOUND and flags & wx.LIST_HITTEST_ONITEM:
 +            self.rightClickedItemIdx = item
-+        self.popupZoomtoAreas = wx.NewId()
-+        self.Bind(wx.EVT_MENU, self.OnZoomToAreasByCat, id = self.popupZoomtoAreas)
 +        # generate popup-menu
++        cat_id = self.cats_mgr.GetCategories()[self.rightClickedItemIdx]
++        showed = self.cats_mgr.GetCategoryAttrs(cat_id)['show']
 +        menu = wx.Menu()
-+        menu.Append(self.popupZoomtoAreas, _("Zoom to training areas of selected class"))
++        if showed:
++            text = _("Hide")
++        else:
++            text = _("Show")
++        item_id = wx.NewId()
++        menu.Append(item_id, text = text)
++        self.Bind(wx.EVT_MENU, lambda event : self._setCatAttrs(cat_id=cat_id,
++        attrs={'show' : not showed}),
++                  id=item_id)
++        menu.AppendSeparator()
++        menu.Append(item_id, text=_("Move item up"))
++        self.Bind(wx.EVT_MENU, self.OnPopupOpacityLevel, id=item_id)
++        menu.Append(item_id, text=_("Move item down"))
++        menu.Append(item_id, text=_("Change opacity level"))
 +        self.PopupMenu(menu)
 +        menu.Destroy()
-+    def OnZoomToAreasByCat(self, event):
-+        """!Zoom to areas of given category"""
-+        cat = self.stats_data.GetCategories()[self.rightClickedItemIdx]
-+        self.mapWindow.ZoomToAreasByCat(cat)
++    def OnPopupOpacityLevel(self, event):
++        """!Popup opacity level indicator"""
++        cat_attrs = self.cats_mgr.GetCategoryAttrs(cat_id)
++        value = cat_attrs['opacity'] * 100
++        name = cat_attrs['name']
++        dlg = SetOpacityDialog(self, opacity = value,
++                               title = _("Change opacity of class <%s>" % name))
++        dlg.applyOpacity.connect(lambda value:
++                                 self._setCatAttrs(cat_id=cat_id, attrs={'opacity' : value}))
++        dlg.CentreOnParent()
++        if dlg.ShowModal() == wx.ID_OK:
++            self._setCatAttrs(cat_id=cat_id, attrs='opacity', value=dlg.GetOpacity())
++        dlg.Destroy()
++    def _setCatAttrs(self, cat_id, attrs):
++        self.cats_mgr.setCategoryAttrs.disconnect(self.Update)
++        self.cats_mgr.SetCategoryAttrs(cat_id, attrs)
++        self.cats_mgr.setCategoryAttrs.connect(self.Update)
@@ -3118,7 +2097,7 @@
 --- gui/wxpython/scatt_plot/plots.py	(revision 0)
 +++ gui/wxpython/scatt_plot/plots.py	(working copy)
-@@ -0,0 +1,667 @@
+@@ -0,0 +1,671 @@
@@ -3135,16 +2114,13 @@
 +import wx
 +import numpy as np
-+from numpy.lib.stride_tricks import as_strided
-+import random
++#TODO
++#from numpy.lib.stride_tricks import as_strided
 +from copy import deepcopy
-+import scipy.misc as misc
 +try:
-+    haveMatPlot = True
 +    import matplotlib
-+    #matplotlib.use('WXAgg')
++    matplotlib.use('WXAgg')
 +    from matplotlib.figure import Figure
 +    from matplotlib.backends.backend_wxagg import \
 +    FigureCanvasWxAgg as FigCanvas, \
@@ -3156,8 +2132,9 @@
 +    import matplotlib.image as mi
 +    import matplotlib.colors as mcolors
 +    import matplotlib.cbook as cbook
-+except ImportError:
-+    haveMatPlot = False
++except ImportError as e:
++    raise ImportError(_("Unable to import matplotlib (try to install it).\n%s") % e)
 +#class PlotImages()?
@@ -3299,6 +2276,11 @@
 +        init = True
 +        for cat_id, scatt in scatts.iteritems():
++            #TODO make more general
++            if cat_id != 0 and (styles[cat_id]['opacity'] == 0.0 or \
++               not styles[cat_id]['show']):
++                continue
 +            b1_i = scatt['bands_info']['b1']
 +            b2_i = scatt['bands_info']['b2']
@@ -3333,18 +2315,19 @@
 +            else:
 +                #c_img_a = np.memmap(grass.tempfile(), dtype="uint16", mode='w+', shape = shape)
-+                c_img_a = colored_cat.astype('uint16')[:,:,3]
-+                c_img_ai= 255 - colored_cat.astype('uint16')[:,:,3]
++                c_img_a = colored_cat.astype('uint16')[:,:,3] * styles[cat_id]['opacity']
-+                #TODO strides
++                #TODO apply strides and there will be no need for loop
 +                #b = as_strided(a, strides=(0, a.strides[3], a.strides[3], a.strides[3]), shape=(3, a.shape[0], a.shape[1]))
 +                for i in range(3):
 +                    m_i = merged_img[:,:,i]
-+                    merged_img[:,:,i] = (m_i * c_img_ai + colored_cat[:,:,i] * c_img_a) / 256;
++                    merged_img[:,:,i] = (m_i * (255 - c_img_a) + colored_cat[:,:,i] * c_img_a) / 255;
-+                merged_img[:,:,3] = (merged_img[:,:,3] * c_img_ai + 255 * c_img_a) / 256;
++                merged_img[:,:,3] = (merged_img[:,:,3] * (255 - c_img_a) + 255 * c_img_a) / 255;
 +                del colored_cat
++                del c_img_a
 +            del masked_cat
 +        img = imshow(self.axes, merged_img,
@@ -3791,7 +2774,7 @@
 --- gui/wxpython/scatt_plot/controllers.py	(revision 0)
 +++ gui/wxpython/scatt_plot/controllers.py	(working copy)
-@@ -0,0 +1,606 @@
+@@ -0,0 +1,621 @@
 + at package scatt_plot.controllers
@@ -3815,7 +2798,6 @@
 +from core.gcmd import GException, GError, GMessage, RunCommand
 +from scatt_plot.scatt_core import Core, idBandsToidScatt
-+from scatt_plot.plots import haveMatPlot
 +from scatt_plot.dialogs import AddScattPlotDialog
 +from scatt_plot.gthreading import gThread
@@ -3825,8 +2807,6 @@
 +class ScattsManager(wx.EvtHandler):
 +    def __init__(self, guiparent, giface, iclass_mapwin):
 +        #TODO remove iclass parameter
-+        if not haveMatPlot:
-+            raise GException(_("The interactive scatter plot tool needs \"Matplotlib\" package to be installed."))
 +        wx.EvtHandler.__init__(self)
 +        self.giface = giface
@@ -3987,7 +2967,7 @@
 +        self.thread.Run(callable = self.core.AddScattPlot, scatt_id = scatt_id)
-+    def RenderScattPlts(self, cats_ids = None):
++    def RenderScattPlts(self):
 +        cats_attrs = self.cats_mgr.GetCategoriesAttrs()
 +        for scatt_id, scatt in self.plots.iteritems():
@@ -4079,11 +3059,12 @@
 +    def SetEditCatDataDone(self, event):
 +        if event.exception:
-+            GError(_("Error occured during computation of scatter plot category:\n%s") , parent = self.guiparent, showTraceback = False)
++            GError(_("Error occured during computation of scatter plot category:\n%s"),
++                      parent = self.guiparent, showTraceback = False)
 +        cat_id = event.ret
-+        self.RenderScattPlts(cats_ids = [cat_id])
++        self.RenderScattPlts()
 +        cat_id = event.kwds["cat_id"]
@@ -4180,8 +3161,11 @@
 +        self.cats[cat_id] = {
 +                                'name' : _('Category %s' % cat_id ),
-+                                'color' : "0:0:0"
++                                'color' : "0:0:0",
++                                'opacity' : 1.0,
++                                'show' : True
 +        self.cats_ids.append(cat_id)
 +        if name is not None:
@@ -4196,9 +3180,17 @@
 +        return cat_id
 +    def SetCategoryAttrs(self, cat_id, attrs_dict):
++        render = False
 +        for k, v in attrs_dict.iteritems():
++            if not render and k in ['name', 'color', 'opacity', 'show']:
++                render = True
 +            self.cats[cat_id][k] = v
++        #TODO optimization
++        if render:
++            self.scatt_mgr.RenderScattPlts()
 +        self.setCategoryAttrs.emit(cat_id = cat_id, attrs_dict = attrs_dict)
 +    def DeleteCategory(self, cat_id):
@@ -4228,6 +3220,12 @@
 +    def GetCategories(self):
 +        return self.cats_ids[:]
++    def SetCategoryPosition(self):
++        if newindex > oldindex:
++            newindex -= 1
++        self.cats_ids.insert(newindex, self.cats_ids.pop(oldindex))
 +class MapWinConnection:
 +    def __init__(self, scatt_mgr, mapWin, scatt_rast_updater):
 +        self.mapWin = mapWin
@@ -4399,478 +3397,33 @@
 +            bands = res.split('\n')
 +            self.scatt_mgr.SetData(bands)
-Index: gui/wxpython/scatt_plot/gthreading.py
+Index: gui/wxpython/Makefile
---- gui/wxpython/scatt_plot/gthreading.py	(revision 0)
-+++ gui/wxpython/scatt_plot/gthreading.py	(working copy)
-@@ -0,0 +1,133 @@
-+ at package scatt_plot.gthreading
+--- gui/wxpython/Makefile	(revision 57556)
++++ gui/wxpython/Makefile	(working copy)
+@@ -13,7 +13,7 @@
+ 	$(wildcard animation/* core/*.py dbmgr/* gcp/*.py gmodeler/* \
+ 	gui_core/*.py iclass/* lmgr/*.py location_wizard/*.py mapwin/*.py mapdisp/*.py \
+ 	mapswipe/* modules/*.py nviz/*.py psmap/* rlisetup/* timeline/* vdigit/* \
+-	vnet/*.py web_services/*.py wxplot/*.py) \
++	vnet/*.py web_services/*.py wxplot/*.py scatt_plot/*.py) \
+ 	gis_set.py gis_set_error.py wxgui.py README
+ DSTFILES := $(patsubst %,$(ETCDIR)/%,$(SRCFILES)) \
+@@ -21,8 +21,9 @@
+ PYDSTDIRS := $(patsubst %,$(ETCDIR)/%,animation core dbmgr gcp gmodeler \
+ 	gui_core iclass lmgr location_wizard mapwin mapdisp modules nviz psmap \
+-	mapswipe vdigit wxplot web_services rlisetup vnet timeline)
++	mapswipe vdigit wxplot web_services rlisetup vnet timeline scatt_plot)
-+Classes:
-+(C) 2013 by the GRASS Development Team
-+This program is free software under the GNU General Public License
-+(>=v2). Read the file COPYING that comes with GRASS for details.
-+ at author Stepan Turek <stepan.turek seznam.cz> (mentor: Martin Landa)
-+import os
-+import sys
-+import time
-+import threading
-+import Queue
-+import wx
-+from core.gconsole import wxCmdRun, wxCmdDone, wxCmdPrepare
-+class gThread(threading.Thread):
-+    """!Thread for GRASS commands"""
-+    requestId = 0
-+    def __init__(self, receiver, requestQ=None, resultQ=None, **kwds):
-+        @param receiver event receiver (used in PostEvent)
-+        threading.Thread.__init__(self, **kwds)
-+        if requestQ is None:
-+            self.requestQ = Queue.Queue()
-+        else:
-+            self.requestQ = requestQ
-+        if resultQ is None:
-+            self.resultQ = Queue.Queue()
-+        else:
-+            self.resultQ = resultQ
-+        self.setDaemon(True)
-+        self.receiver = receiver
-+        self._want_abort_all = False
-+        self.start()
-+    def Run(self, *args, **kwds):
-+        """!Run command in queue
-+        @param args unnamed command arguments
-+        @param kwds named command arguments
-+        @return request id in queue
-+        gThread.requestId += 1
-+        self.requestQ.put((gThread.requestId, args, kwds))
-+        return gThread.requestId
-+    def GetId(self):
-+         """!Get id for next command"""
-+         return gThread.requestId + 1
-+    def SetId(self, id):
-+        """!Set starting id"""
-+        gThread.requestId = id
-+    def run(self):
-+        os.environ['GRASS_MESSAGE_FORMAT'] = 'gui'
-+        while True:
-+            requestId, args, kwds = self.requestQ.get()
-+            for key in ('callable', 'onDone', 'onPrepare', 'userData'):
-+                if key in kwds:
-+                    vars()[key] = kwds[key]
-+                    del kwds[key]
-+                else:
-+                    vars()[key] = None
-+            requestTime = time.time()
-+            #if self._want_abort_all and self.requestCmd is not None:
-+            #    self.requestCmd.abort()
-+            #    if self.requestQ.empty():
-+            #        self._want_abort_all = False
-+            # prepare
-+            if self.receiver:
-+                event = wxCmdPrepare(type = 'method',
-+                                     time=requestTime,
-+                                     pid=requestId)
-+                wx.PostEvent(self.receiver, event)
-+                # run command
-+                event = wxCmdRun(type = 'method',
-+                                 pid=requestId)
-+            time.sleep(.1)
-+            ret = None
-+            exception = None
-+            #to
-+            #try:
-+            ret = vars()['callable'](*args, **kwds)
-+            #except Exception as e:
-+            #    exception  = e;
-+            self.resultQ.put((requestId, ret))
-+            time.sleep(.1)
-+                event = wxCmdDone(kwds = kwds,
-+                                  args = args, #TODO expand args to kwds
-+                                  ret=ret,
-+                                  exception=exception,
-+                                  pid=requestId)
-+                # send event
-+    def abort(self, abortall=True):
-+        """!Abort command(s)"""
-+        if abortall:
-+            self._want_abort_all = True
-+        if self.requestQ.empty():
-\ No newline at end of file
-Index: gui/wxpython/scatt_plot/dialogs.py
---- gui/wxpython/scatt_plot/dialogs.py	(revision 0)
-+++ gui/wxpython/scatt_plot/dialogs.py	(working copy)
-@@ -0,0 +1,142 @@
-+ at package scatt_plot.dialogs
-+ at brief GUI.
-+Classes:
-+import os
-+import sys
-+import wx
-+from scatt_plot.scatt_core import idBandsToidScatt
-+class AddScattPlotDialog(wx.Dialog):
-+    def __init__(self, parent, bands, id  = wx.ID_ANY):
-+        wx.Dialog.__init__(self, parent, title = ("Add scatter plot"), id = id)
-+        self.bands = bands
-+        self.scatt_id = None
-+        self._createWidgets()
-+    def _createWidgets(self):
-+        self.labels = {}
-+        self.params = {}
-+        self.band_1_label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Band 1:"))
-+        self.band_1_ch = wx.ComboBox(parent = self, id = wx.ID_ANY,
-+                                     choices = self.bands,
-+                                     style = wx.CB_READONLY, size = (350, 30))
-+        self.band_2_label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Band 2:"))
-+        self.band_2_ch = wx.ComboBox(parent = self, id = wx.ID_ANY,
-+        # buttons
-+        self.btn_close = wx.Button(parent = self, id = wx.ID_CANCEL)
-+        self.btn_ok = wx.Button(parent = self, id = wx.ID_OK, label = _("&OK"))
-+        self._layout()
-+    def _layout(self):
-+        border = wx.BoxSizer(wx.VERTICAL)
-+        dialogSizer = wx.BoxSizer(wx.VERTICAL)
-+        regionSizer = wx.BoxSizer(wx.HORIZONTAL)
-+        dialogSizer.Add(item = self._addSelectSizer(title = self.band_1_label,
-+                                                    sel = self.band_1_ch))
-+        dialogSizer.Add(item = self._addSelectSizer(title = self.band_2_label,
-+                                                    sel = self.band_2_ch))
-+        # buttons
-+        self.btnsizer = wx.BoxSizer(orient = wx.HORIZONTAL)
-+        self.btnsizer.Add(item = self.btn_close, proportion = 0,
-+                          flag = wx.ALL | wx.ALIGN_CENTER,
-+                          border = 10)
-+        self.btnsizer.Add(item = self.btn_ok, proportion = 0,
-+                          border = 10)
-+        dialogSizer.Add(item = self.btnsizer, proportion = 0,
-+                        flag = wx.ALIGN_CENTER)
-+        border.Add(item = dialogSizer, proportion = 0,
-+                   flag = wx.ALL, border = 5)
-+        self.SetSizer(border)
-+        self.Layout()
-+        self.Fit()
-+        # bindings
-+        self.btn_close.Bind(wx.EVT_BUTTON, self.OnClose)
-+        self.btn_ok.Bind(wx.EVT_BUTTON, self.OnOk)
-+    def _addSelectSizer(self, title, sel):
-+        """!Helper layout function.
-+        selSizer = wx.BoxSizer(orient = wx.VERTICAL)
-+        selTitleSizer = wx.BoxSizer(wx.HORIZONTAL)
-+        selTitleSizer.Add(item = title, proportion = 1,
-+                          flag = wx.LEFT | wx.TOP | wx.EXPAND, border = 5)
-+        selSizer.Add(item = selTitleSizer, proportion = 0,
-+                     flag = wx.EXPAND)
-+        selSizer.Add(item = sel, proportion = 1,
-+                     flag = wx.EXPAND | wx.ALL| wx.ALIGN_CENTER_VERTICAL,
-+                     border = 5)
-+        return selSizer
-+    def OnClose(self, event):
-+        """!Close dialog
-+        if not self.IsModal():
-+            self.Destroy()
-+        event.Skip()
-+    def OnOk(self, event):
-+        band_1 = self.band_1_ch.GetSelection()
-+        band_2 = self.band_2_ch.GetSelection()
-+        if band_1 == band_2:
-+            GError(_("Selected bands must be different."))
-+            return
-+        #TODO axes selection
-+        if band_1 > band_2:
-+            tmp_band = band_2
-+            band_2 = band_1
-+            band_1 = band_2
-+        self.scatt_id = idBandsToidScatt(band_1, band_2, len(self.bands))
-+        event.Skip()
-+    def GetScattId(self):
-+        return self.scatt_id
-Index: gui/wxpython/scatt_plot/toolbars.py
---- gui/wxpython/scatt_plot/toolbars.py	(revision 0)
-+++ gui/wxpython/scatt_plot/toolbars.py	(working copy)
-@@ -0,0 +1,178 @@
-+ at package scatt_plot.toolbars
-+ at brief Scatter plot - toolbars
-+Classes:
-+ - toolbars::MainToolbar
-+import wx
-+from icons.icon import MetaIcon
-+from gui_core.toolbars import BaseToolbar, BaseIcons
-+from core.gcmd import RunCommand
-+from core.gcmd import GException, GError, RunCommand
-+class MainToolbar(BaseToolbar):
-+    """!Main toolbar
-+    def __init__(self, parent, scatt_mgr):
-+        BaseToolbar.__init__(self, parent)
-+        self.scatt_mgr = scatt_mgr
-+        self.InitToolbar(self._toolbarData())
-+        # realize the toolbar
-+        self.Realize()
-+    def _toolbarData(self):
-+        icons = {
-+                'settings'   : BaseIcons['settings'].SetLabel( _('Ssettings')),
-+                'help'       : MetaIcon(img = 'help',
-+                                         label = _('Show manual')),
-+                'add_scatt_pl'  : MetaIcon(img = 'layer-raster-analyze',
-+                                            label = _('Add scatter plot')),
-+                'selCatPol'  : MetaIcon(img = 'polygon-create',
-+                                      label = _('Select area with polygon')),
-+                'pan'        : MetaIcon(img = 'pan',
-+                                         label = _('Pan'),
-+                                         desc = _('Pan scatter plot')),
-+                'zoomIn'     : MetaIcon(img = 'zoom-in',
-+                                          label = _('Zoom'),
-+                                          desc = _('Zoom whith mouse wheel')),
-+                'cats_mgr' : MetaIcon(img = 'table-manager',
-+                                          label = _('Show/hide class manager'))
-+        return self._getToolbarData((
-+                                     ("cats_mgr", icons['cats_mgr'],
-+                                     lambda event: self.parent.ShowCategoryPanel(event.Checked()), wx.ITEM_CHECK),
-+                                     (None, ),
-+                                     ("pan", icons["pan"],
-+                                     lambda event: self.SetPloltsMode(event, 'pan'),
-+                                      wx.ITEM_CHECK),
-+                                     ("zoom", icons["zoomIn"],
-+                                     lambda event: self.SetPloltsMode(event, 'zoom'),
-+                                      wx.ITEM_CHECK),
-+                                     ('sel_pol_mode', icons['selCatPol'],
-+                                      self.ActivateSelectionPolygonMode,
-+                                     wx.ITEM_CHECK),
-+                                     (None, ),
-+                                     ('add_scatt', icons["add_scatt_pl"],
-+                                     lambda event : self.scatt_mgr.AddScattPlot())
-+                                     #('settings', icon["settings"],
-+                                     # self.parent.OnSettings),
-+                                     #('help', icons["help"],
-+                                     # self.OnHelp),
-+    def GetToolId(self, toolName): #TODO can be useful in base
-+        return vars(self)[toolName]
-+    def SetPloltsMode(self, event, tool_name):
-+        if event.Checked()  == True:
-+            for i_tool_data in  self._data:
-+                i_tool_name = i_tool_data[0]
-+                if not i_tool_name or i_tool_name == "cats_mgr":
-+                    continue
-+                if i_tool_name == tool_name:
-+                    continue
-+                i_tool_id = vars(self)[i_tool_name]
-+                self.ToggleTool(i_tool_id, False)
-+            self.scatt_mgr.SetPlotsMode(mode = tool_name)
-+        else:
-+            self.scatt_mgr.SetPlotsMode(mode = None)
-+    def ActivateSelectionPolygonMode(self, event):
-+        activated = self.scatt_mgr.ActivateSelectionPolygonMode(event.Checked())
-+        self.parent.ShowPlotEditingToolbar(activated)
-+        i_tool_id = vars(self)['sel_pol_mode']
-+        self.ToggleTool(i_tool_id, activated)
-+class EditingToolbar(BaseToolbar):
-+    """!Main toolbar
-+        self.Realize()
-+        """!Toolbar data
-+        self.icons = {
-+            'sel_add'         : MetaIcon(img = 'layer-add',
-+                                         label = _('Include selected area to class.'),
-+                                         desc = _('Include selected area to class.')),
-+            'sel_remove'      : MetaIcon(img = 'layer-remove',
-+                                         label = _('Exclude selected area from class.'),
-+                                         desc = _('Exclude selected area from class.')),
-+            'addVertex'       : MetaIcon(img = 'vertex-create',
-+                                         label = _('Add new vertex'),
-+                                         desc = _('Add new vertex to polygon boundary scatter plot')),
-+            'editLine'        : MetaIcon(img = 'line-edit',
-+                                         label = _('Edit line/boundary'),
-+                                         desc = _('Add new vertex between last and first points of the boundary')),
-+            'moveVertex'      : MetaIcon(img = 'vertex-move',
-+                                         label = _('Move vertex'),
-+                                         desc = _('Move boundary vertex')),
-+            'removeVertex'    : MetaIcon(img = 'vertex-delete',
-+                                         label = _('Remove vertex'),
-+                                         desc = _('Remove boundary vertex.')),
-+                                    ("sel_add", self.icons["sel_add"],
-+                                     lambda event: self.scatt_mgr.ProcessSelectionPolygons('add')),
-+                                     ("sel_remove", self.icons['sel_remove'],
-+                                     lambda event: self.scatt_mgr.ProcessSelectionPolygons('remove')),
-+                                     (None, ),
-+                                     ("add_vertex", self.icons["editLine"],
-+                                     lambda event: self.SetMode(event, 'add_vertex'),
-+                                     wx.ITEM_CHECK),
-+                                     ("add_boundary_vertex", self.icons['addVertex'],
-+                                     lambda event: self.SetMode(event, 'add_boundary_vertex'),
-+                                     wx.ITEM_CHECK),
-+                                     ("move_vertex", self.icons["moveVertex"],
-+                                     lambda event: self.SetMode(event, 'move_vertex'),
-+                                     wx.ITEM_CHECK),
-+                                     ('delete_vertex', self.icons['removeVertex'],
-+                                     lambda event: self.SetMode(event, 'delete_vertex'),
-+                                     wx.ITEM_CHECK)
-+    def SetMode(self, event, tool_name):
-+                if not i_tool_name:
-+                    continue
-+                    continue
-+            self.scatt_mgr.SetPlotsEditingMode(tool_name)
-+        else:
-+            self.scatt_mgr.SetPlotsEditingMode(None)
+ DSTDIRS := $(patsubst %,$(ETCDIR)/%,icons scripts xml)
+ default: $(DSTFILES)
 Index: gui/wxpython/vdigit/wxdigit.py
---- gui/wxpython/vdigit/wxdigit.py	(revision 57546)
+--- gui/wxpython/vdigit/wxdigit.py	(revision 57556)
 +++ gui/wxpython/vdigit/wxdigit.py	(working copy)
 @@ -17,7 +17,7 @@
  (and NumPy would be an excellent candidate for acceleration via
@@ -5390,7 +3943,7 @@
      def GetLineCats(self, line):
 Index: gui/wxpython/vdigit/toolbars.py
---- gui/wxpython/vdigit/toolbars.py	(revision 57546)
+--- gui/wxpython/vdigit/toolbars.py	(revision 57556)
 +++ gui/wxpython/vdigit/toolbars.py	(working copy)
 @@ -17,6 +17,7 @@
  import wx
@@ -5417,27 +3970,1556 @@
          return True
      def StopEditing(self):
-Index: gui/wxpython/Makefile
+Index: gui/wxpython/mapdisp/toolbars.py
---- gui/wxpython/Makefile	(revision 57546)
-+++ gui/wxpython/Makefile	(working copy)
-@@ -13,7 +13,7 @@
- 	$(wildcard animation/* core/*.py dbmgr/* gcp/*.py gmodeler/* \
- 	gui_core/*.py iclass/* lmgr/*.py location_wizard/*.py mapwin/*.py mapdisp/*.py \
- 	mapswipe/* modules/*.py nviz/*.py psmap/* rlisetup/* timeline/* vdigit/* \
--	vnet/*.py web_services/*.py wxplot/*.py) \
-+	vnet/*.py web_services/*.py wxplot/*.py scatt_plot/*.py) \
- 	gis_set.py gis_set_error.py wxgui.py README
+--- gui/wxpython/mapdisp/toolbars.py	(revision 57556)
++++ gui/wxpython/mapdisp/toolbars.py	(working copy)
+@@ -239,7 +239,8 @@
+                       (MapIcons["scatter"],     self.parent.OnScatterplot),
+                       (MapIcons["histogram"],   self.parent.OnHistogramPyPlot),
+                       (BaseIcons["histogramD"], self.parent.OnHistogram),
+-                      (MapIcons["vnet"],        self.parent.OnVNet)))
++                      (MapIcons["vnet"],        self.parent.OnVNet),
++                      (MapIcons["scatter"],     self.parent.OnScatterplot2)))
+     def OnDecoration(self, event):
+         """!Decorations overlay menu
+Index: gui/wxpython/mapdisp/frame.py
+--- gui/wxpython/mapdisp/frame.py	(revision 57556)
++++ gui/wxpython/mapdisp/frame.py	(working copy)
+@@ -225,6 +225,7 @@
+         self.dialogs = {}
+         self.dialogs['attributes'] = None
++        self.dialogs['scatt_plot'] = None
+         self.dialogs['category'] = None
+         self.dialogs['barscale'] = None
+         self.dialogs['legend'] = None
+@@ -1168,6 +1169,19 @@
+         """!Returns toolbar with zooming tools"""
+         return self.toolbars['map']
- DSTFILES := $(patsubst %,$(ETCDIR)/%,$(SRCFILES)) \
-@@ -21,8 +21,9 @@
++    def OnScatterplot2(self, event):
++        """!Init interactive scatterplot tools
++        if self.dialogs['scatt_plot']:
++            self.dialogs['scatt_plot'].Raise()
++            return
++        from scatt_plot.dialogs import ScattPlotMainDialog
++        self.dialogs['scatt_plot'] = ScattPlotMainDialog(parent=self, giface=self._giface)
++        self.dialogs['scatt_plot'].CenterOnScreen()
++        self.dialogs['scatt_plot'].Show()
+     def OnVNet(self, event):
+         """!Dialog for v.net* modules
+Index: gui/wxpython/iclass/dialogs.py
+--- gui/wxpython/iclass/dialogs.py	(revision 57556)
++++ gui/wxpython/iclass/dialogs.py	(working copy)
+@@ -333,13 +333,19 @@
+         toolbar.SetCategories(catNames = catNames, catIdx = cats)
+         if name in catNames:
+             toolbar.choice.SetStringSelection(name)
++            cat = toolbar.GetSelectedCategoryIdx()
+         elif catNames:
+             toolbar.choice.SetSelection(0)
++        else:
++            cat = None
+         if toolbar.choice.IsEmpty():
+             toolbar.EnableControls(False)
+         else:
+             toolbar.EnableControls(True)
++        self.mapWindow.CategoryChanged(cat)
+         # don't forget to update maps, histo, ...
+     def GetSelectedIndices(self, state =  wx.LIST_STATE_SELECTED):
+Index: gui/wxpython/iclass/toolbars.py
+--- gui/wxpython/iclass/toolbars.py	(revision 57556)
++++ gui/wxpython/iclass/toolbars.py	(working copy)
+@@ -46,9 +46,7 @@
+         'importAreas' : MetaIcon(img = 'layer-import',
+                             label = _('Import training areas from vector map')),
+         'addRgb' : MetaIcon(img = 'layer-rgb-add',
+-                            label = _('Add RGB map layer')),
+-        'scatt_plot'    : MetaIcon(img = 'layer-raster-analyze',
+-                                   label = _('Open Scatter Plot Tool (EXPERIMENTAL GSoC 2013)')),
++                            label = _('Add RGB map layer'))
+ class IClassMapToolbar(BaseToolbar):
+@@ -117,10 +115,7 @@
+                                      ("zoomBack", icons["zoomBack"],
+                                       self.parent.OnZoomBack),
+                                      ("zoomToMap", icons["zoomExtent"],
+-                                      self.parent.OnZoomToMap),
+-                                     (None, ),
+-                                     ("scatt_plot", iClassIcons["scatt_plot"],
+-                                      self.parent.OnScatterplot)
++                                      self.parent.OnZoomToMap)
+ class IClassToolbar(BaseToolbar):
+     """!IClass toolbar
+@@ -156,7 +151,7 @@
+         """!Toolbar data"""
+         icons = iClassIcons
+         return self._getToolbarData((("selectGroup", icons['selectGroup'],
+-                                      self.parent.OnAddBands),
++                                      lambda event : self.parent.AddBands()),
+                                       (None, ),
+                                       ("classManager", icons['classManager'],
+                                       self.parent.OnCategoryManager),
+Index: gui/wxpython/iclass/frame.py
+--- gui/wxpython/iclass/frame.py	(revision 57556)
++++ gui/wxpython/iclass/frame.py	(working copy)
+@@ -64,6 +64,8 @@
+                                IClassExportAreasDialog, IClassMapDialog
+ from iclass.plots       import PlotPanel
- PYDSTDIRS := $(patsubst %,$(ETCDIR)/%,animation core dbmgr gcp gmodeler \
- 	gui_core iclass lmgr location_wizard mapwin mapdisp modules nviz psmap \
--	mapswipe vdigit wxplot web_services rlisetup vnet timeline)
-+	mapswipe vdigit wxplot web_services rlisetup vnet timeline scatt_plot)
++from grass.pydispatch.signal import Signal
+ class IClassMapFrame(DoubleMapFrame):
+     """! wxIClass main frame
+@@ -114,6 +116,10 @@
+             lambda:
+             self.statusbarManager.statusbarItems['coordinates'].SetAdditionalInfo(None))
+         self.SetSize(size)
++        self.groupSet = Signal("IClassMapFrame.groupSet")
++        self.categoryChanged = Signal('IClassMapFrame.categoryChanged')
+         # Add toolbars
+@@ -177,7 +183,7 @@
+         # PyPlot init
+-        self.plotPanel = PlotPanel(self, stats_data = self.stats_data)
++        self.plotPanel = PlotPanel(self, giface = self._giface, stats_data = self.stats_data)
+         self._addPanes()
+         self._mgr.Update()
+@@ -237,7 +243,7 @@
+             return False
+         return vectorName
+     def RemoveTempVector(self):
+         """!Removes temporary vector map with training areas"""
+         ret = RunCommand(prog = 'g.remove',
+@@ -477,7 +483,7 @@
+         self.Render(self.GetFirstWindow())
+-    def OnAddBands(self, event):
++    def AddBands(self):
+         """!Add imagery group"""
+         dlg = IClassGroupDialog(self, group = self.group)
+@@ -488,7 +494,8 @@
+         """!Set imagery group"""
+         group = grass.find_file(name = name, element = 'group')
+         if group['name']:
+-            self.group = group['name']
++           self.group = group['name']
++           self.groupSet.emit(group = group['name'])
+         else:
+             GError(_("Group <%s> not found") % name, parent = self)
+@@ -768,17 +775,20 @@
+         Updates number of stddev, histograms, layer in preview display.
+-        stat = self.stats_data.GetStatistics(currentCat)
+-        nstd = stat.nstd
+-        self.toolbars['iClass'].UpdateStddev(nstd)
+-        self.plotPanel.UpdateCategory(currentCat)
+-        self.plotPanel.OnPlotTypeSelected(None)
++        if currentCat:
++          stat = self.stats_data.GetStatistics(currentCat)
++          nstd = stat.nstd
++          self.toolbars['iClass'].UpdateStddev(nstd)
++          self.plotPanel.UpdateCategory(currentCat)
++          self.plotPanel.OnPlotTypeSelected(None)
+-        name = stat.rasterName
+-        name = self.previewMapManager.GetAlias(name)
+-        if name:
+-            self.previewMapManager.SelectLayer(name)
++          name = stat.rasterName
++          name = self.previewMapManager.GetAlias(name)
++          if name:
++              self.previewMapManager.SelectLayer(name)
++        self.categoryChanged.emit(cat = currentCat)
+     def DeleteAreas(self, cats):
+         """!Removes all training areas of given categories
+@@ -1105,27 +1115,6 @@
+         self.GetFirstWindow().SetModePointer()
+         self.GetSecondWindow().SetModePointer()
+-    def OnScatterplot(self, event):
+-        """!Init interactive scatterplot tools
+-        if self.dialogs['scatt_plot']:
+-            self.dialogs['scatt_plot'].Raise()
+-            return
+-        try:
+-          from scatt_plot.dialogs import ScattPlotMainDialog
+-        except:
+-          GError(parent  = self, message = _("The Scatter Plot Tool is not installed."))
+-          return
+-        self.dialogs['scatt_plot'] = ScattPlotMainDialog(parent=self, giface=self._giface, iclass_mapwin = self.GetFirstWindow())
+-        scatt_mgr = self.dialogs['scatt_plot'].GetScattMgr()
+-        scatt_mgr.DigitDataChanged(self.toolbars['vdigit'].mapLayer.GetName(), self.GetFirstWindow().GetDigit())
+-        self.dialogs['scatt_plot'].CenterOnScreen()
+-        self.dialogs['scatt_plot'].Show()
+ class MapManager:
+     """! Class for managing map renderer.
+Index: gui/wxpython/iclass/plots.py
+--- gui/wxpython/iclass/plots.py	(revision 57556)
++++ gui/wxpython/iclass/plots.py	(working copy)
+@@ -19,6 +19,7 @@
+ import wx.lib.plot as plot
+ import wx.lib.scrolledpanel as scrolled
+ from core.utils import _
++from core.gcmd import GError
+ class PlotPanel(scrolled.ScrolledPanel):
+     """!Panel for drawing multiple plots.
+@@ -28,7 +29,7 @@
+     for each band and for one category. Coincidence plots show min max range
+     of classes for each band.
+-    def __init__(self, parent, stats_data):
++    def __init__(self, parent, giface, stats_data):
+         scrolled.ScrolledPanel.__init__(self, parent)
+@@ -38,26 +39,71 @@
+         self.stats_data = stats_data
+         self.currentCat = None
++        self._giface = giface
- DSTDIRS := $(patsubst %,$(ETCDIR)/%,icons scripts xml)
- default: $(DSTFILES)
+         self.mainSizer = wx.BoxSizer(wx.VERTICAL)
+         self._createControlPanel()
++        self._createPlotPanel()
++        self._createScatterPlotPanel()
+         self.SetSizer(self.mainSizer)
+         self.mainSizer.Fit(self)
+         self.Layout()
++    def _createPlotPanel(self):
++        self.canvasPanel = wx.Panel(parent=self)
++        self.mainSizer.Add(item = self.canvasPanel, proportion = 1, flag = wx.EXPAND, border = 0)
++        self.canvasSizer = wx.BoxSizer(wx.VERTICAL)
++        self.canvasPanel.SetSizer(self.canvasSizer)
+     def _createControlPanel(self):
+         self.plotSwitch = wx.Choice(self, id = wx.ID_ANY,
+                                      choices = [_("Histograms"),
+-                                                _("Coincident plots")])
++                                                _("Coincident plots"),
++                                                _("Scatter plots")])
+         self.mainSizer.Add(self.plotSwitch, proportion = 0, flag = wx.EXPAND|wx.ALL, border = 5)
+         self.plotSwitch.Bind(wx.EVT_CHOICE, self.OnPlotTypeSelected)
++    def _createScatterPlotPanel(self):
++        try:
++            from scatt_plot.frame import IClassScatterPlotsPanel
++            self.scatt_plot_panel = IClassScatterPlotsPanel(parent=self,
++                                                            giface=self._giface,
++                                                            iclass_mapwin = self.parent.GetFirstWindow())
++            self.mainSizer.Add(self.scatt_plot_panel, proportion = 1, flag = wx.EXPAND, border = 0)
++            self.scatt_plot_panel.Hide()
++        except ImportError as e:#TODO
++            self.scatt_error = _("Scatter plot functionality is disabled. Reason:\n" \
++                                 "Unable to import packages needed for scatter plot.\n%s" % e)
++            GError(self.scatt_error)
++            self.scatt_plot_panel = None
+     def OnPlotTypeSelected(self, event):
+         """!Plot type selected"""
++        if self.plotSwitch.GetSelection() in [0, 1]:
++            self.SetupScrolling(scroll_x = False, scroll_y = True)
++            if self.scatt_plot_panel:
++            self.canvasPanel.Show()
++            self.Layout()
++        elif self.plotSwitch.GetSelection() == 2:
++            self.SetupScrolling(scroll_x = False, scroll_y = False)
++                self.scatt_plot_panel.Show()
++            else:
++            self.canvasPanel.Hide()
++            self.Layout()
+         if self.currentCat is None:
+             return
+         if self.plotSwitch.GetSelection() == 0:
+             stat = self.stats_data.GetStatistics(self.currentCat)
+             if not stat.IsReady():
+@@ -66,7 +112,10 @@
+             self.DrawHistograms(stat)
+         else:
+             self.DrawCoincidencePlots()
++        self.Layout()
+     def StddevChanged(self):
+         """!Standard deviation multiplier changed, redraw histograms"""
+@@ -89,7 +138,7 @@
+             panel.Destroy()
+         self.canvasList = []
+     def ClearPlots(self):
+         """!Clears plot canvases"""
+         for bandIdx in range(len(self.bandList)):
+@@ -104,15 +153,15 @@
+     def CreatePlotCanvases(self):
+         """!Create plot canvases according to the number of bands"""
+         for band in self.bandList:
+-            canvas = plot.PlotCanvas(self)
++            canvas = plot.PlotCanvas(self.canvasPanel)
+             canvas.SetMinSize((-1, 140))
+             canvas.SetFontSizeTitle(10)
+             canvas.SetFontSizeAxis(8)
+             self.canvasList.append(canvas)
+-            self.mainSizer.Add(item = canvas, proportion = 1, flag = wx.EXPAND, border = 0)
+-        self.SetVirtualSize(self.GetBestVirtualSize())
++            self.canvasSizer.Add(item = canvas, proportion = 1, flag = wx.EXPAND, border = 0)
++        self.SetVirtualSize(self.GetBestVirtualSize())
+         self.Layout()
+     def UpdatePlots(self, group, currentCat, stats_data):
+@@ -138,7 +187,7 @@
+     def UpdateCategory(self, cat):
+         self.currentCat = cat
+     def DrawCoincidencePlots(self):
+         """!Draw coincidence plots"""
+Index: lib/imagery/scatt_sccats.c
+--- lib/imagery/scatt_sccats.c	(revision 0)
++++ lib/imagery/scatt_sccats.c	(working copy)
+@@ -0,0 +1,405 @@
++   \file lib/imagery/scatt_cat_rast.c
++   \brief Imagery library - functions for manipulation with scatter plot structs.
++   Copyright (C) 2013 by the GRASS Development Team
++   This program is free software under the GNU General Public License
++   (>=v2).  Read the file COPYING that comes with GRASS for details.
++   \author Stepan Turek <stepan.turek at seznam.cz> (Mentor: Martin Landa)
++#include <grass/raster.h>
++#include <grass/imagery.h>
++#include <grass/gis.h>
++#include <stdio.h>
++#include <stdlib.h>
++#include <math.h>
++#include <string.h>
++   \brief Compute band ids from scatter plot id.
++    Scatter plot id describes which bands defines the scatter plot.
++    Let say we have 3 bands, their ids are 0, 1 and 2.
++    Scatter plot with id 0 consists of band 1 (b_1_id) 0 and  band 2 (b_2_id) 1.
++    All scatter plots:
++    scatt_id b_1_id b_2_id
++    0        0      1
++    1        0      2
++    2        1      2
++   \param scatt_id scatter plot id
++   \param n_bands number of bands
++   \param [out] b_1_id id of band1
++   \param[out] b_2_id id of band2
++   \return 0
++int I_id_scatt_to_bands(const int scatt_id, const int n_bands, int * b_1_id, int * b_2_id)
++    int n_b1 = n_bands - 1;
++    * b_1_id = (int) ((2 * n_b1 + 1 - sqrt((double)((2 * n_b1 + 1) * (2 * n_b1 + 1) - 8 * scatt_id))) / 2);
++    * b_2_id = scatt_id - ((* b_1_id) * (2 * n_b1 + 1) - (* b_1_id) * (* b_1_id)) / 2 + (* b_1_id) + 1;
++    return 0;
++   \brief Compute scatter plot id from band ids.
++    See also I_id_scatt_to_bands().
++   \param b_1_id id of band1
++   \param b_1_id id of band2
++   \param [out] scatt_id scatter plot id
++   \return 0
++int I_bands_to_id_scatt(const int b_1_id, const int b_2_id, const int n_bands, int * scatt_id)
++    * scatt_id = (b_1_id * (2 * n_b1 + 1) - b_1_id * b_1_id) / 2 + b_2_id - b_1_id - 1;
++    return 0;
++   \brief Initialize structure for storing scatter plots data.
++   \param cats pointer to scCats struct
++   \param type SC_SCATT_DATA - stores scatter plots
++   \param type SC_SCATT_CONDITIONS - stores selected areas in scatter plots
++void I_sc_init_cats(struct scCats * cats, int n_bands, int type)
++    int i_cat;
++    cats->type = type;
++    cats->n_cats = 100;
++    cats->n_a_cats = 0;
++    cats->n_bands = n_bands;
++    cats->n_scatts = (n_bands - 1) * n_bands / 2;
++    cats->cats_arr = (struct scScatts **) G_malloc(cats->n_cats * sizeof(struct scScatts *));
++    memset(cats->cats_arr, 0, cats-> n_cats * sizeof(struct scScatts *));
++    cats->cats_ids = (int *)  G_malloc(cats->n_cats * sizeof(int));
++    cats->cats_idxs =(int *)  G_malloc(cats->n_cats * sizeof(int));
++    for(i_cat = 0; i_cat < cats->n_cats; i_cat++)
++        cats->cats_idxs[i_cat] = -1;
++    return;
++   \brief Free data of struct scCats, the structure itself remains alocated.
++   \param cats pointer to existing scCats struct
++void I_sc_free_cats(struct scCats * cats)
++    int i_cat;
++    for(i_cat = 0; i_cat < cats->n_a_cats; i_cat++)
++        if(cats->cats_arr[i_cat])
++            G_free(cats->cats_arr[i_cat]->scatt_idxs);
++            G_free(cats->cats_arr[i_cat]->scatts_bands);
++            G_free(cats->cats_arr[i_cat]->scatts_arr);
++            G_free(cats->cats_arr[i_cat]);
++    G_free(cats->cats_ids);
++    G_free(cats->cats_idxs);
++    G_free(cats->cats_arr);
++    cats->n_cats = 0;
++    cats->n_bands = 0;
++    cats->n_scatts = 0;
++    cats->type = -1;
++    return;
++#if 0
++void I_sc_get_active_categories(int * a_cats_ids, int * n_a_cats, struct scCats * cats)
++    a_cats_ids = cats->cats_ids;
++    * n_a_cats = cats->n_a_cats;
++#endif
++   \brief Add category.
++    Category represents group of scatter plots.
++   \return assigned category id (starts with 0)
++   \return -1 if maximum nuber of categories was reached
++int I_sc_add_cat(struct scCats * cats)
++    int i_scatt, i_cat_id, cat_id;
++    int n_a_cats = cats->n_a_cats;
++    if(cats->n_a_cats >= cats->n_cats)
++        return -1;
++    for(i_cat_id = 0; i_cat_id < cats->n_cats; i_cat_id++)
++        if(cats->cats_idxs[i_cat_id] < 0) {
++            cat_id = i_cat_id;
++            break;
++    cats->cats_ids[n_a_cats] = cat_id;
++    cats->cats_idxs[cat_id] = n_a_cats;
++    cats->cats_arr[n_a_cats] = (struct scScatts *) G_malloc(sizeof(struct scScatts));
++    cats->cats_arr[n_a_cats]->scatts_arr = (struct scdScattData **) G_malloc(cats->n_scatts * sizeof(struct scdScattData *));
++    memset((cats->cats_arr[n_a_cats]->scatts_arr), 0, cats->n_scatts * sizeof(struct scdScattData *));
++    cats->cats_arr[n_a_cats]->n_a_scatts = 0;
++    cats->cats_arr[n_a_cats]->scatts_bands = (int *) G_malloc(cats->n_scatts * 2 * sizeof(int));
++    cats->cats_arr[n_a_cats]->scatt_idxs = (int *) G_malloc(cats->n_scatts * sizeof(int));
++    for(i_scatt = 0; i_scatt < cats->n_scatts; i_scatt++)
++        cats->cats_arr[n_a_cats]->scatt_idxs[i_scatt] = -1;
++    ++cats->n_a_cats;
++    return cat_id;
++#if 0
++int I_sc_delete_cat(struct scCats * cats, int cat_id)
++    int cat_idx, i_cat;
++    if(cat_id < 0 || cat_id >= cats->n_cats)
++        return -1;
++    cat_idx = cats->cats_idxs[cat_id];
++    if(cat_idx < 0)
++        return -1;
++    G_free(cats->cats_arr[cat_idx]->scatt_idxs);
++    G_free(cats->cats_arr[cat_idx]->scatts_bands);
++    G_free(cats->cats_arr[cat_idx]->scatts_arr);
++    G_free(cats->cats_arr[cat_idx]);
++    for(i_cat = cat_idx; i_cat < cats->n_a_cats - 1; i_cat++)
++        cats->cats_arr[i_cat] = cats->cats_arr[i_cat + 1];
++        cats->cats_ids[i_cat] = cats->cats_ids[i_cat + 1];
++    cats->cats_idxs[cat_id] = -1;
++    --cats->n_a_cats;
++    return 0;
++#endif
++   \brief Insert scatter plot data .
++    Inserted scatt_data struct must have same type as cats struct (SC_SCATT_DATA or SC_SCATT_CONDITIONS).
++   \param cat_id id number of category.
++   \param scatt_id id number of scatter plot.
++   \return  0 on success
++   \return -1 on failure
++int I_sc_insert_scatt_data(struct scCats * cats, struct scdScattData * scatt_data, int cat_id, int scatt_id)
++    int band_1, band_2, cat_idx, n_a_scatts;
++    struct scScatts * scatts;
++        return -1;
++    if(cat_idx < 0)
++        return -1;
++    if(scatt_id < 0 && scatt_id >= cats->n_scatts)
++        return -1;
++    scatts = cats->cats_arr[cat_idx];
++    if(scatts->scatt_idxs[scatt_id] >= 0)
++        return -1;
++    if(!scatt_data->b_conds_arr && cats->type == SC_SCATT_CONDITIONS)
++        return -1;
++    if(!scatt_data->scatt_vals_arr && cats->type == SC_SCATT_DATA)
++        return -1;
++    n_a_scatts = scatts->n_a_scatts;
++    scatts->scatt_idxs[scatt_id] = n_a_scatts;
++    I_id_scatt_to_bands(scatt_id, cats->n_bands, &band_1, &band_2);
++    scatts->scatts_bands[n_a_scatts * 2] = band_1;
++    scatts->scatts_bands[n_a_scatts * 2 + 1] = band_2;
++    scatts->scatts_arr[n_a_scatts] = scatt_data;
++    ++scatts->n_a_scatts;
++    return 0;
++#if 0
++int I_sc_remove_scatt_data(struct scCats * cats, struct scdScattData * scatt_data, int cat_id, int scatt_id)
++    int cat_idx, scatt_idx, n_init_scatts, i_scatt;
++    if(cat_id < 0 && cat_id >= cats->n_cats)
++        return -1;
++    if(cat_idx < 0)
++        return -1;
++    if(scatt_id < 0 || scatt_id >= cats->n_scatts)
++        return -1;
++    if(scatts->scatt_idxs[scatt_id] < 0)
++        return -1;
++    scatt_data = scatts->scatts_arr[scatt_idx];
++    for(i_scatt = scatt_idx; i_scatt < scatts->n_a_scatts - 1; i_scatt++)
++        scatts->scatts_arr[i_scatt] = scatts->scatts_arr[i_scatt + 1];
++        scatts->scatts_bands[i_scatt * 2] = scatts->scatts_bands[(i_scatt + 1)* 2];
++        scatts->scatts_bands[i_scatt * 2 + 1] = scatts->scatts_bands[(i_scatt + 1) * 2 + 1];
++    scatts->scatts_arr[scatts->n_a_scatts] = NULL;
++    scatts->scatt_idxs[scatt_id] = -1;
++    scatt_data = scatts->scatts_arr[scatt_id];
++    scatts->n_a_scatts--;
++    return 0;
++int I_sc_set_value(struct scCats * cats, int cat_id, int scatt_id, int value_idx, int value)
++    int n_a_scatts = cats->cats_arr[cat_id]->n_a_scatts;
++    int cat_idx, scatt_idx, ret;
++    if(cat_idx < 0)
++        return -1;
++    if(cats->cats_arr[cat_idx]->scatt_idxs[scatt_id] < 0)
++        return -1;
++    scatt_idx = cats->cats_arr[cat_idx]->scatt_idxs[scatt_id];
++    I_scd_set_value(cats->cats_arr[cat_idx]->scatts_arr[scatt_idx], value_idx, value);
++    return 0;
++#endif
++   \brief Insert scatter plot data.
++   \param scatt_data pointer to existing struct scdScattData
++   \param type SC_SCATT_DATA for scatter plots or SC_SCATT_CONDITIONS for selected areas in scatter plot
++   \param n_vals number of data values
++   \param data array of values (unsigned char for SC_SCATT_CONDITIONS, unsigned int for SC_SCATT_DATA)
++void I_scd_init_scatt_data(struct scdScattData * scatt_data, int type, int n_vals, void * data)
++    scatt_data->n_vals = n_vals;
++    if(type == SC_SCATT_DATA)
++        if(data)
++            scatt_data->scatt_vals_arr = (unsigned int *) data;
++        else {
++            scatt_data->scatt_vals_arr = (unsigned int *) G_malloc(n_vals * sizeof(unsigned int));
++            memset(scatt_data->scatt_vals_arr, 0, n_vals * sizeof(unsigned int));
++        scatt_data->b_conds_arr = NULL;
++    else if(type == SC_SCATT_CONDITIONS)
++        if(data)
++            scatt_data->b_conds_arr = (unsigned char *) data;
++        else {
++            scatt_data->b_conds_arr = (unsigned char *) G_malloc(n_vals * sizeof(unsigned char));
++            memset(scatt_data->b_conds_arr, 0, n_vals * sizeof(unsigned char));
++        scatt_data->scatt_vals_arr = NULL;
++    return;
++#if 0
++void I_scd_get_range_min_max(struct scdScattData * scatt_data, CELL * band_1_min, CELL * band_1_max, CELL * band_2_min, CELL * band_2_max)
++    Rast_get_range_min_max(&(scatt_data->band_1_range), band_1_min, band_2_min);
++    Rast_get_range_min_max(&(scatt_data->band_2_range), band_2_min, band_2_max);
++    return;
++s
++void * I_scd_get_data_ptr(struct scdScattData * scatt_data)
++    if(!scatt_data->b_conds_arr)
++        return scatt_data->b_conds_arr;
++    else if(!scatt_data->scatt_vals_arr)
++        return scatt_data->scatt_vals_arr;
++    return NULL;
++int I_scd_set_value(struct scdScattData * scatt_data, unsigned int val_idx, unsigned int val)
++    if(val_idx < 0 && val_idx >  scatt_data->n_vals)
++        return -1;
++    if(scatt_data->b_conds_arr)
++        scatt_data->b_conds_arr[val_idx] = val;
++    else if(scatt_data->scatt_vals_arr)
++        scatt_data->scatt_vals_arr[val_idx] = val;
++    else
++        return -1;
++    return 0;
++#endif
+Index: lib/imagery/scatt.c
+--- lib/imagery/scatt.c	(revision 0)
++++ lib/imagery/scatt.c	(working copy)
+@@ -0,0 +1,746 @@
++   \file lib/imagery/scatt.c
++   \brief Imagery library - functions for wx Scatter Plot Tool.
++   Low level functions used by wx Scatter Plot Tool.
++#include <grass/glocale.h>
++#include <math.h>
++struct rast_row
++    CELL * row;
++    char * null_row;
++    struct Range rast_range; /*Range of whole raster.*/
++   \brief Create pgm header.
++   Scatter plot internally generates pgm files. These pgms have header in format created by this function.
++   \param region region to be pgm header generated for
++   \param [out] header header of pgm file
++static int get_cat_rast_header(struct Cell_head * region, char * header){
++    return sprintf(header, "P5\n%d\n%d\n1\n", region->cols, region->rows);
++   \brief Create category raster conditions file.
++   \param cat_rast_region region to be file generated for
++   \param cat_rast path of generated category raster file
++int I_create_cat_rast(struct Cell_head * cat_rast_region,  const char * cat_rast)
++    FILE * f_cat_rast;
++    char cat_rast_header[1024];//TODO magic number
++    int i_row, i_col;
++    int head_nchars;
++    unsigned char * row_data;
++    f_cat_rast = fopen(cat_rast, "wb");
++    if(!f_cat_rast) {
++        G_warning("Unable to create category raster condition file <%s>.", cat_rast);
++        return -1;
++    head_nchars = get_cat_rast_header(cat_rast_region, cat_rast_header);
++    fwrite(cat_rast_header, sizeof(char), head_nchars/sizeof(char), f_cat_rast);
++    if (ferror(f_cat_rast)){
++        fclose(f_cat_rast);
++        G_warning(_("Unable to write header into category raster condition file <%s>."), cat_rast);
++        return -1;
++    row_data = (unsigned char *) G_malloc(cat_rast_region->cols * sizeof(unsigned char));
++    for(i_col = 0; i_col < cat_rast_region->cols; i_col++)
++        row_data[i_col] = 0 & 255;
++    for(i_row = 0; i_row < cat_rast_region->rows; i_row++) {
++        fwrite(row_data, sizeof(unsigned char), (cat_rast_region->cols)/sizeof(unsigned char), f_cat_rast);
++            G_warning(_("Unable to write into category raster condition file <%s>."), cat_rast);
++            return -1;
++    return 0;
++static int print_reg(struct Cell_head * intersec, const char * pref, int dbg_level)
++    G_debug(dbg_level, "%s:\n n:%f\ns:%f\ne:%f\nw:%f\nns_res:%f\new_res:%f", pref, intersec->north, intersec->south,
++               intersec->east, intersec->west, intersec->ns_res, intersec->ew_res);
++   \brief Find intersection region of two regions.
++   \param A pointer to intersected region
++   \param B pointer to intersected region
++   \param [out] intersec pointer to intersection region of regions A B (relevant params of the region are: south, north, east, west)
++   \return  0 if interection exists
++   \return -1 if regions does not intersect
++static int regions_intersecion(struct Cell_head * A, struct Cell_head * B, struct Cell_head * intersec)
++    if(B->north < A->south) return -1;
++    else if(B->north > A->north) intersec->north = A->north;
++    else intersec->north = B->north;
++    if(B->south > A->north) return -1;
++    else if(B->south < A->south) intersec->south = A->south;
++    else intersec->south = B->south;
++    if(B->east < A->west) return -1;
++    else if(B->east > A->east) intersec->east = A->east;
++    else intersec->east = B->east;
++    if(B->west > A->east) return -1;
++    else if(B->west < A->west) intersec->west = A->west;
++    else intersec->west = B->west;
++    if(intersec->north == intersec->south) return -1;
++    if(intersec->east == intersec->west) return -1;
++    return 0;
++   \brief Get rows and cols numbers, which defines intersection of the regions.
++   \param B pointer to intersected region (A and B must have same resolution)
++   \param [out] A_bounds rows and cols numbers of A stored in south, north, east, west, which defines intersection of A and B
++   \param [out] B_bounds rows and cols numbers of B stored in south, north, east, west, which defines intersection of A and B
++   \return -1 if regions do not intersect
++   \return -2 resolution of regions is not same
++static int get_rows_and_cols_bounds(struct Cell_head * A,  struct Cell_head * B, struct Cell_head * A_bounds,  struct Cell_head * B_bounds)
++    float ns_res, ew_res;
++    struct Cell_head intersec;
++    /* TODO is it right check? */
++    if(abs(A->ns_res - B->ns_res) > GRASS_EPSILON) {
++        G_debug(0, "'get_rows_and_cols_bounds' ns_res does not fit, A->ns_res: %f B->ns_res: %f", A->ns_res, B->ns_res);
++        return -2;
++    if(abs(A->ew_res - B->ew_res) > GRASS_EPSILON) {
++        G_debug(0, "'get_rows_and_cols_bounds' ew_res does not fit, A->ew_res: %f B->ew_res: %f", A->ew_res, B->ew_res);
++        return -2;
++    ns_res = A->ns_res;
++    ew_res = A->ew_res;
++    if(regions_intersecion(A, B, &intersec) == -1)
++        return -1;
++    A_bounds->north = ceil((A->north - intersec.north - ns_res * 0.5) / ns_res);
++    A_bounds->south = ceil((A->north - intersec.south - ns_res * 0.5) / ns_res);
++    A_bounds->east = ceil((intersec.east - A->west - ew_res * 0.5) / ew_res);
++    A_bounds->west = ceil((intersec.west - A->west - ew_res * 0.5) / ew_res);
++    B_bounds->north = ceil((B->north - intersec.north - ns_res * 0.5) / ns_res);
++    B_bounds->south = ceil((B->north - intersec.south - ns_res * 0.5) / ns_res);
++    B_bounds->east = ceil((intersec.east - B->west - ew_res * 0.5) / ew_res);
++    B_bounds->west = ceil((intersec.west - B->west - ew_res * 0.5) / ew_res);
++    return 0;
++   \brief Insert raster map patch into pgm file.
++   \param patch_rast name of raster map
++   \param cat_rast_region region of category raster file
++   \param cat_rast path to category raster file
++int I_insert_patch_to_cat_rast(const char * patch_rast, struct Cell_head * cat_rast_region,  const char * cat_rast)
++    struct Cell_head patch_region, patch_bounds, cat_rast_bounds;
++    int i_row, i_col, ncols, nrows, cat_rast_col, patch_col, val;
++    int head_nchars, ret;
++    int fd_patch_rast, init_shift, step_shift;
++    unsigned char * patch_data;
++    char * null_chunk_row;
++    const char *mapset;
++    struct Cell_head patch_lines, cat_rast_lines;
++    f_cat_rast = fopen(cat_rast, "rb+");
++        G_warning(_("Unable to open category raster condtions file <%s>."), cat_rast);
++        return -1;
++    if ((mapset = G_find_raster(patch_rast,"")) == NULL) {
++        G_warning(_("Unable to find patch raster <%s>."), patch_rast);
++        return -1;
++    Rast_get_cellhd(patch_rast, mapset, &patch_region);
++    Rast_set_window(&patch_region);
++    if ((fd_patch_rast = Rast_open_old(patch_rast, mapset)) < 0) {
++        return -1;
++    ret = get_rows_and_cols_bounds(cat_rast_region, &patch_region, &cat_rast_bounds, &patch_bounds);
++    if(ret == -2) {
++        G_warning(_("Resolutions of patch <%s> and patched file <%s> are not same."), patch_rast, cat_rast);
++        Rast_close(fd_patch_rast);
++        return -1;
++    else if (ret == -1){
++        return 0;
++    ncols = cat_rast_bounds.east - cat_rast_bounds.west;
++    nrows = cat_rast_bounds.south - cat_rast_bounds.north;
++    patch_data = (unsigned char *) G_malloc(ncols * sizeof(unsigned char));
++    init_shift = head_nchars + cat_rast_region->cols * cat_rast_bounds.north + cat_rast_bounds.west;
++    if(fseek(f_cat_rast, init_shift, SEEK_SET) != 0) {
++        G_warning(_("Corrupted  category raster conditions file <%s> (fseek failed)"), cat_rast);
++        G_free(null_chunk_row);
++        return -1;
++    step_shift = cat_rast_region->cols - ncols;
++    null_chunk_row =  Rast_allocate_null_buf();
++    for(i_row = 0; i_row < nrows; i_row++) {
++        Rast_get_null_value_row (fd_patch_rast, null_chunk_row, i_row + patch_bounds.north);
++        for(i_col = 0; i_col < ncols; i_col++) {
++            patch_col = patch_bounds.west + i_col;
++            if(null_chunk_row[patch_col] != 1)
++                patch_data[i_col] = 1 & 255;
++            else {
++                patch_data[i_col] = 0 & 255;
++        fwrite(patch_data, sizeof(unsigned char), (ncols)/sizeof(unsigned char), f_cat_rast);
++            G_warning(_("Unable to write into category raster conditions file <%s>"), cat_rast);
++            return -1;
++        if(fseek(f_cat_rast, step_shift, SEEK_CUR) != 0) {
++            return -1;
++    return 0;
++   \brief Updates scatter plots data in category by pixels which meets category conditions.
++   \param bands_rows data represents data describig one row from raster band
++   \param belongs_pix array which defines which pixels belongs to category (1 value) and which not (0 value)
++   \param [out] scatts pointer to scScatts struct of type SC_SCATT_DATA, which are modified according to values in belongs_pix
++static inline void update_cat_scatt_plts(struct rast_row * bands_rows, unsigned short * belongs_pix, struct scScatts * scatts)
++    int band_axis_1, band_axis_2, i_scatt, array_idx, cat_idx, i_chunk_rows_pix, max_arr_idx;
++    CELL * b_1_row;
++    CELL * b_2_row;
++    char * b_1_null_row,* b_2_null_row;
++    struct rast_row b_1_rast_row, b_2_rast_row;
++    struct Range b_1_range, b_2_range;
++    int b_1_range_size;
++    int row_size = Rast_window_cols();
++    int * scatts_bands = scatts->scatts_bands;
++    for(i_scatt = 0; i_scatt < scatts->n_a_scatts; i_scatt++)
++        b_1_rast_row = bands_rows[scatts_bands[i_scatt * 2]];
++        b_2_rast_row = bands_rows[scatts_bands[i_scatt * 2 + 1]];
++        b_1_row = b_1_rast_row.row;
++        b_2_row = b_2_rast_row.row;
++        b_1_null_row =  b_1_rast_row.null_row;
++        b_2_null_row =  b_2_rast_row.null_row;
++        b_1_range = b_1_rast_row.rast_range;
++        b_2_range = b_2_rast_row.rast_range;
++        b_1_range_size = b_1_range.max - b_1_range.min + 1;
++        max_arr_idx = (b_1_range.max -  b_1_range.min + 1) * (b_2_range.max -  b_2_range.min + 1);
++        for(i_chunk_rows_pix = 0; i_chunk_rows_pix < row_size; i_chunk_rows_pix++)
++            /* pixel does not belongs to scatter plot or has null value in one of the bands */
++            if(!belongs_pix[i_chunk_rows_pix] ||
++                b_1_null_row[i_chunk_rows_pix] == 1 ||
++                b_2_null_row[i_chunk_rows_pix] == 1)
++                continue;
++            /* index in scatter plot array */
++            array_idx = b_1_row[i_chunk_rows_pix] - b_1_range.min + (b_2_row[i_chunk_rows_pix] - b_2_range.min) * b_1_range_size;
++            if(array_idx < 0 || array_idx >= max_arr_idx) {
++                        G_warning ("Data inconsistent. Value computed for scatter plot is out of initialized range.");
++                continue;
++            /* increment scatter plot value */
++            ++scatts->scatts_arr[i_scatt]->scatt_vals_arr[array_idx];
++   \brief Computes scatter plots data from chunk_rows.
++   \param scatts pointer to scScatts struct of type SC_SCATT_DATA, where are computed scatter plots stored
++   \param scatt_conds pointer to scScatts struct of type SC_SCATT_CONDITIONS, where are selected areas (condtitions)stored
++   \param chunk_rows data arrays of chunk_rows from analyzed raster bands (all data in chunk_rows, null_chunk_rows and belongs_pix arrays represents same region)
++   \param null_chunk_rows null data arrays of chunk_rows from analyzed raster bands
++   \param row_size size of data in chunk_rows, null_chunk_rows and belongs_pix arrays
++   \param f_cats_rasts_conds file which stores selected areas (conditions) from mapwindow see I_create_cat_rast() and I_pa
++   \param fd_cats_rasts array of openedraster maps which represents all selected pixels for category
++   \param region analysis region
++static inline int compute_scatts_from_chunk_row(struct Cell_head *region, struct scCats * scatt_conds,
++                                                FILE ** f_cats_rasts_conds, struct rast_row * bands_rows,
++                                                struct scCats * scatts, int * fd_cats_rasts)
++    int i_rows_pix, i_cat, i_scatt, n_a_scatts, n_pixs;
++    int cat_id, scatt_plts_cat_idx, array_idx, max_arr_idx;
++    CELL * cat_rast_row;
++    struct scScatts * scatts_conds;
++    struct scScatts * scatts_scatt_plts;
++    struct scdScattData * conds;
++    int * scatts_bands;
++    struct scdScattData ** scatts_arr;
++    CELL * b_1_row;
++    CELL * b_2_row;
++    unsigned char * i_scatt_conds;
++    unsigned short * belongs_pix = (unsigned short *) G_malloc(row_size * sizeof(unsigned short));
++    unsigned char * rast_pixs = (unsigned char *) G_malloc(row_size * sizeof(unsigned char));
++    cat_rast_row =  Rast_allocate_c_buf();
++    for(i_cat = 0; i_cat < scatt_conds->n_a_cats; i_cat++)
++        scatts_conds = scatt_conds->cats_arr[i_cat];
++        cat_id = scatt_conds->cats_ids[i_cat];
++        scatt_plts_cat_idx = scatts->cats_idxs[cat_id];
++        if(scatt_plts_cat_idx < 0)
++            continue;
++        scatts_scatt_plts = scatts->cats_arr[scatt_plts_cat_idx];
++        G_zero(belongs_pix, row_size * sizeof(unsigned short));
++        /* if category has no conditions defined, scatter plots without any constraint are computed (default scatter plots) */
++        if(!scatts_conds->n_a_scatts && !f_cats_rasts_conds[i_cat]) {
++            for(i_scatt = 0; i_scatt < scatts_scatt_plts->n_a_scatts; i_scatt++)
++                /* all pixels belongs */
++                for(i_rows_pix = 0; i_rows_pix < row_size; i_rows_pix++)
++                    belongs_pix[i_rows_pix] = 1;
++        /* compute belonging pixels for defined conditions */
++        else
++            scatts_bands = scatts_conds->scatts_bands;
++            /* check conditions from category raster condtitions file */
++            if(f_cats_rasts_conds[i_cat]) {
++                n_pixs = fread(rast_pixs, sizeof(unsigned char), (row_size)/sizeof(unsigned char), f_cats_rasts_conds[i_cat]);
++                if (ferror(f_cats_rasts_conds[i_cat]))
++                    G_free(rast_pixs);
++                    G_free(belongs_pix);
++                    G_warning(_("Unable to read from category raster condtition file."));
++                    return -1;
++                if (n_pixs != n_pixs) {
++                    G_warning(_("Invalid size of category raster conditions file."));
++                    return -1;
++                    if(rast_pixs[i_rows_pix] != 0 & 255)
++            /* check condtions defined in scatter plots*/
++            for(i_scatt = 0; i_scatt < scatts_conds->n_a_scatts; i_scatt++)
++                i_scatt_conds = scatts_conds->scatts_arr[i_scatt]->b_conds_arr;
++                    /* pixels already belongs to category from category raster conditions file or contains null value in one of the bands */
++                    if(belongs_pix[i_rows_pix] ||
++                       b_1_null_row[i_rows_pix] == 1 ||
++                       b_2_null_row[i_rows_pix] == 1)
++                        continue;
++                    array_idx = b_1_row[i_rows_pix] - b_1_range.min + (b_2_row[i_rows_pix] - b_2_range.min) * b_1_range_size;
++                        continue;
++                    /* pixels meets condtion defined in scatter plot */
++                    if(i_scatt_conds[array_idx])
++        /* update category raster with belonging pixels */
++        if(fd_cats_rasts[i_cat] >= 0) {
++            Rast_set_null_value(cat_rast_row, Rast_window_cols(), CELL_TYPE);
++                if(belongs_pix[i_rows_pix])
++                    cat_rast_row[i_rows_pix] = belongs_pix[i_rows_pix];
++            Rast_put_c_row (fd_cats_rasts[i_cat], cat_rast_row);
++        /* update scatter plots with belonging pixels */
++        update_cat_scatt_plts(bands_rows, belongs_pix, scatts_scatt_plts);
++    G_free(cat_rast_row);
++    return 0;
++   \brief Get list if bands needed to be opened for analysis from scCats struct.
++static void get_needed_bands(struct scCats * cats, int * b_needed_bands)
++    // results in b_needed_bands - array of bools - if item has value 1, band (defined by item index) is needed to be opened
++    int i_cat, i_scatt, cat_id;
++        for(i_scatt = 0;  i_scatt < cats->cats_arr[i_cat]->n_a_scatts; i_scatt++)
++            G_debug(3, "Active scatt %d in catt %d", i_scatt, i_cat);
++            b_needed_bands[cats->cats_arr[i_cat]->scatts_bands[i_scatt * 2]] = 1;
++            b_needed_bands[cats->cats_arr[i_cat]->scatts_bands[i_scatt * 2 + 1]] = 1;
++    return;
++   \brief Helper function for clean up.
++static void free_compute_scatts_data(int * fd_bands, struct rast_row * bands_rows, int n_a_bands, int * bands_ids,
++                                     int * fd_cats_rasts, FILE ** f_cats_rasts_conds, int n_a_cats)
++    int i, band_id;
++    for(i = 0; i < n_a_bands; i++)
++        band_id = bands_ids[i];
++        if(band_id >= 0) {
++            Rast_close(fd_bands[i]);
++            G_free(bands_rows[band_id].row);
++            G_free(bands_rows[band_id].null_row);
++    if(f_cats_rasts_conds)
++        for(i = 0; i < n_a_cats; i++)
++            if(f_cats_rasts_conds[i])
++                fclose(f_cats_rasts_conds[i]);
++    if(fd_cats_rasts)
++            if(fd_cats_rasts[i] >= 0)
++                Rast_close(fd_cats_rasts[i]);
++   \brief Compute scatter plots data.
++    If category has not defined no category raster condition file and no scatter plot with consdtion,
++    default scatter plot is computed.
++   \param region analysis region, beaware that all input data must be prepared for this region (bands (their ranges), cats_rasts_conds rasters...)
++   \param region function calls Rast_set_window for this region
++   \param scatt_conds pointer to scScatts struct of type SC_SCATT_CONDITIONS, where are stored selected areas (conditions) in scatter plots
++   \param cats_rasts_conds paths to category raster conditions files representing selected areas (conditions) in rasters for every category
++   \param cats_rasts_conds index in array represents corresponding category id
++   \param cats_rasts_conds for manupulation with category raster conditions file see also I_id_scatt_to_bands() and I_insert_patch_to_cat_rast()
++   \param bands names of analyzed bands, order of bands is defined by their id
++   \param [out] scatts pointer to scScatts struct of type SC_SCATT_DATA, where are computed scatter plots stored
++   \param [out] cats_rasts array of raster maps names where will be stored all selected pixels for every category
++int I_compute_scatts(struct Cell_head *region, struct scCats * scatt_conds, const char ** cats_rasts_conds,
++                     const char ** bands, int n_bands, struct scCats * scatts, const char ** cats_rasts)
++    char header[1024];
++    int fd_cats_rasts[scatt_conds->n_a_cats];
++    FILE * f_cats_rasts_conds[scatt_conds->n_a_cats];
++    struct rast_row bands_rows[n_bands];
++    RASTER_MAP_TYPE data_type;
++    int nrows, i_band, n_a_bands, band_id,
++        i, i_row, head_nchars, i_cat, id_cat;
++    int fd_bands[n_bands];
++    int bands_ids[n_bands];
++    int b_needed_bands[n_bands];
++    Rast_set_window(region);
++    for(i_band = 0; i_band < n_bands; i_band++)
++        fd_bands[i_band] = -1;
++        bands_ids[i_band] = -1;
++    if (n_bands != scatts->n_bands ||
++        n_bands != scatt_conds->n_bands)
++        return -1;
++    memset(b_needed_bands, 0, (size_t)n_bands * sizeof(int));
++    get_needed_bands(scatt_conds, &b_needed_bands[0]);
++    get_needed_bands(scatts, &b_needed_bands[0]);
++    n_a_bands = 0;
++    /* open band rasters, which are needed for computation */
++    for(band_id = 0; band_id < n_bands; band_id++)
++        if(b_needed_bands[band_id])
++            G_debug(3, "Opening raster no. %d with name: %s", band_id, bands[band_id]);
++            if ((mapset = G_find_raster2(bands[band_id],"")) == NULL) {
++                free_compute_scatts_data(fd_bands, bands_rows, n_a_bands,
++                                         bands_ids, NULL, NULL, scatt_conds->n_a_cats);
++                G_warning(_("Unbale to read find raster <%s>"), bands[band_id]);
++                return -1;
++            if ((fd_bands[n_a_bands] = Rast_open_old(bands[band_id], mapset)) < 0) {
++                G_warning(_("Unbale to open raster <%s>"), bands[band_id]);
++                return -1;
++            data_type = Rast_get_map_type(fd_bands[n_a_bands]);
++            if(data_type != CELL_TYPE) {
++                G_warning(_("Raster <%s> type is not <%s>"), bands[band_id], "CELL");
++                return -1;
++            bands_rows[band_id].row =  Rast_allocate_c_buf();
++            bands_rows[band_id].null_row =  Rast_allocate_null_buf();
++            if(Rast_read_range(bands[band_id], mapset, &bands_rows[band_id].rast_range) != 1){
++                G_warning(_("Unable to read range of raster <%s>"), bands[band_id]);
++                return -1;
++            bands_ids[n_a_bands] = band_id;
++            ++n_a_bands;
++    /* open category rasters condition files and category rasters */
++    for(i_cat = 0; i_cat < scatts->n_a_cats; i_cat++)
++        id_cat = scatts->cats_ids[i_cat];
++        if(cats_rasts[id_cat]) {
++            fd_cats_rasts[i_cat] = Rast_open_new(cats_rasts[id_cat], CELL_TYPE);
++        else
++            fd_cats_rasts[i_cat] = -1;
++        if(cats_rasts_conds[id_cat]) {
++            f_cats_rasts_conds[i_cat] = fopen(cats_rasts_conds[id_cat], "r");
++            if(!f_cats_rasts_conds[i_cat]) {
++                free_compute_scatts_data(fd_bands, bands_rows, n_a_bands, bands_ids,
++                                         f_cats_rasts_conds, f_cats_rasts_conds, scatt_conds->n_a_cats);
++                G_warning(_("Unable to open category raster condtition file <%s>"), bands[band_id]);
++                return -1;
++        else
++            f_cats_rasts_conds[i_cat] = NULL;
++    head_nchars =  get_cat_rast_header(region, header);
++            if( fseek(f_cats_rasts_conds[i_cat] , head_nchars, SEEK_SET) != 0) {
++                G_warning(_("Corrupted category raster conditions file (fseek failed)"));
++                return -1;
++    nrows = Rast_window_rows();
++    /* analyze bands by rows */
++    for (i_row = 0; i_row < nrows; i_row++)
++        for(i_band = 0; i_band < n_a_bands; i_band++)
++            band_id = bands_ids[i_band];
++            Rast_get_c_row(fd_bands[i_band], bands_rows[band_id].row, i_row);
++            Rast_get_null_value_row (fd_bands[i_band], bands_rows[band_id].null_row, i_row);
++        if(compute_scatts_from_chunk_row(region, scatt_conds, f_cats_rasts_conds, bands_rows, scatts, fd_cats_rasts) == -1)
++            free_compute_scatts_data(fd_bands, bands_rows, n_a_bands, bands_ids, fd_cats_rasts,
++                                     f_cats_rasts_conds, scatt_conds->n_a_cats);
++            return -1;
++                             fd_cats_rasts, f_cats_rasts_conds, scatt_conds->n_a_cats);
++    return 0;
+\ No newline at end of file
+Index: lib/vector/Vlib/open.c
+--- lib/vector/Vlib/open.c	(revision 57556)
++++ lib/vector/Vlib/open.c	(working copy)
+@@ -240,7 +240,9 @@
+         else {
+             char file_path[GPATH_MAX];
++            /* reduce to current mapset if search path was set */
++            if(strcmp(Map->mapset, "") == 0)
++                Map->mapset = G_store(G_mapset());
+             /* temporary map: reduce to current mapset if search path
+              * was set */
+             if (strcmp(Map->mapset, "") == 0)
