[GRASS-SVN] r58534 - in grass/trunk/gui/wxpython: core gui_core lmgr mapswipe
Thu Dec 26 18:30:24 PST 2013
Author: annakrat
Date: 2013-12-26 18:30:24 -0800 (Thu, 26 Dec 2013)
New Revision: 58534
   grass/trunk/gui/wxpython/core/settings.py
   grass/trunk/gui/wxpython/gui_core/preferences.py
   grass/trunk/gui/wxpython/lmgr/frame.py
   grass/trunk/gui/wxpython/mapswipe/dialogs.py
   grass/trunk/gui/wxpython/mapswipe/frame.py
   grass/trunk/gui/wxpython/mapswipe/mapwindow.py
   grass/trunk/gui/wxpython/mapswipe/toolbars.py
wxGUI/mapswipe: add preferences dialog to change mirrored cursor appearance
Modified: grass/trunk/gui/wxpython/core/settings.py
--- grass/trunk/gui/wxpython/core/settings.py	2013-12-27 02:24:42 UTC (rev 58533)
+++ grass/trunk/gui/wxpython/core/settings.py	2013-12-27 02:30:24 UTC (rev 58534)
@@ -789,6 +789,16 @@
+            'mapswipe' : {
+                'cursor': {
+                    'color': (0, 0, 0, 255),
+                    'size': 12,
+                    'width': 1,
+                    'type': {
+                        'selection': 0,
         # quick fix, http://trac.osgeo.org/grass/ticket/1233
@@ -883,7 +893,12 @@
        _("histogram"))
         self.internalSettings['vdigit']['bgmap'] = {}
         self.internalSettings['vdigit']['bgmap']['value'] = ''
+        self.internalSettings['mapswipe']['cursor']['type'] = {}
+        self.internalSettings['mapswipe']['cursor']['type']['choices'] = (_("cross"),
+        _("box"),
+        _("circle"))
     def ReadSettingsFile(self, settings = None):
         """!Reads settings file (mapset, location, gisdbase)"""
         if settings is None:
Modified: grass/trunk/gui/wxpython/gui_core/preferences.py
--- grass/trunk/gui/wxpython/gui_core/preferences.py	2013-12-27 02:24:42 UTC (rev 58533)
+++ grass/trunk/gui/wxpython/gui_core/preferences.py	2013-12-27 02:30:24 UTC (rev 58534)
@@ -220,34 +220,10 @@
                 self.settings.Set(group, value, key, [subkey, subkey1])
             else:
                 self.settings.Set(group, value, key, subkey)
-        if self.parent.GetName() == 'Modeler':
-            return True
-        # update default window dimension
-        if self.settings.Get(group = 'general', key = 'defWindowPos', subkey = 'enabled') is True:
-            dim = ''
-            # layer manager
-            pos = self.parent.GetPosition()
-            size = self.parent.GetSize()
-            dim = '%d,%d,%d,%d' % (pos[0], pos[1], size[0], size[1])
-            # opened displays
-            for mapdisp in self._giface.GetAllMapDisplays():
-                pos  = mapdisp.GetPosition()
-                size = mapdisp.GetSize()
-                # window size must be larger than zero
-                if size[0] > 0 and size[1] > 0:
-                    dim += ',%d,%d,%d,%d' % (pos[0], pos[1], size[0], size[1])
+        return True
-            self.settings.Set(group = 'general', key = 'defWindowPos', subkey = 'dim', value = dim)
-        else:
-            self.settings.Set(group = 'general', key = 'defWindowPos', subkey = 'dim', value = '')
-        return True
 class PreferencesDialog(PreferencesBaseDialog):
     """!User preferences dialog"""
     def __init__(self, parent, giface, title = _("GUI Settings"),
@@ -1353,6 +1329,33 @@
         return panel
+    def _updateSettings(self):
+        if not PreferencesBaseDialog._updateSettings(self):
+            return False
+        # update default window dimension
+        if self.settings.Get(group = 'general', key = 'defWindowPos', subkey = 'enabled') is True:
+            dim = ''
+            # layer manager
+            pos = self.parent.GetPosition()
+            size = self.parent.GetSize()
+            dim = '%d,%d,%d,%d' % (pos[0], pos[1], size[0], size[1])
+            # opened displays
+            for mapdisp in self._giface.GetAllMapDisplays():
+                pos  = mapdisp.GetPosition()
+                size = mapdisp.GetSize()
+                # window size must be larger than zero
+                if size[0] > 0 and size[1] > 0:
+                    dim += ',%d,%d,%d,%d' % (pos[0], pos[1], size[0], size[1])
+            self.settings.Set(group = 'general', key = 'defWindowPos', subkey = 'dim', value = dim)
+        else:
+            self.settings.Set(group = 'general', key = 'defWindowPos', subkey = 'dim', value = '')
+        return True
     def OnCheckColorTable(self, event):
         """!Set/unset default color table"""
         win = self.FindWindowById(self.winId['rasterLayer:colorTable:selection'])
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py	2013-12-27 02:24:42 UTC (rev 58533)
+++ grass/trunk/gui/wxpython/lmgr/frame.py	2013-12-27 02:30:24 UTC (rev 58534)
@@ -451,7 +451,7 @@
     def OnMapSwipe(self, event):
         """!Launch Map Swipe"""
-        win = SwipeMapFrame(parent = self)
+        win = SwipeMapFrame(parent=self, giface=self._giface)
         rasters = []
         tree = self.GetLayerTree()
Modified: grass/trunk/gui/wxpython/mapswipe/dialogs.py
--- grass/trunk/gui/wxpython/mapswipe/dialogs.py	2013-12-27 02:24:42 UTC (rev 58533)
+++ grass/trunk/gui/wxpython/mapswipe/dialogs.py	2013-12-27 02:30:24 UTC (rev 58534)
@@ -16,13 +16,17 @@
 import copy
 import wx
+import wx.lib.scrolledpanel as SP
+import wx.lib.colourselect as csel
-from core               import globalvar
+from core import globalvar
 from core.utils import _
-from gui_core           import gselect
-from gui_core.widgets   import SimpleValidator
-from core.gcmd          import GMessage
+from gui_core import gselect
+from gui_core.widgets import SimpleValidator
+from gui_core.preferences import PreferencesBaseDialog
+from core.gcmd import GMessage
 from core.layerlist import LayerList
+from core.settings import UserSettings
 from gui_core.simplelmgr import SimpleLayerManager, SIMPLE_LMGR_RASTER, \
    SIMPLE_LMGR_VECTOR, SIMPLE_LMGR_TB_LEFT, SIMPLE_LMGR_TB_RIGHT
@@ -207,3 +211,89 @@
     def GetSecondSimpleLmgr(self):
         return self._secondLmgr
+class PreferencesDialog(PreferencesBaseDialog):
+    """!Mapswipe preferences dialog"""
+    def __init__(self, parent, giface, title=_("Map Swipe settings"),
+                 settings=UserSettings):
+        PreferencesBaseDialog.__init__(self, parent=parent, giface=giface, title=title,
+                                       settings=settings, size=(-1, 300))
+        # create notebook pages
+        self._createMirrorModePage(self.notebook)
+        self.SetMinSize(self.GetBestSize())
+        self.SetSize(self.size)
+    def _createMirrorModePage(self, notebook):
+        """!Create notebook page for general settings"""
+        panel = SP.ScrolledPanel(parent=notebook)
+        panel.SetupScrolling(scroll_x=False, scroll_y=True)
+        notebook.AddPage(page=panel, text=_("Mirror mode"))
+        border = wx.BoxSizer(wx.VERTICAL)
+        box = wx.StaticBox(parent=panel, label=" %s " % _("Mirrored cursor"))
+        sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+        gridSizer = wx.GridBagSizer(hgap=3, vgap=3)
+        row = 0
+        gridSizer.Add(item=wx.StaticText(parent=panel,
+                                         label=_("Color:")),
+                      flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL, pos=(row, 0))
+        color = csel.ColourSelect(parent=panel,
+                                  colour=UserSettings.Get(group='mapswipe',
+                                                          key='cursor', subkey='color'),
+                                  size=globalvar.DIALOG_COLOR_SIZE)
+        color.SetName('GetColour')
+        self.winId['mapswipe:cursor:color'] = color.GetId()
+        gridSizer.Add(item=color, pos=(row, 1), flag=wx.ALIGN_RIGHT)
+        row += 1
+                                         label=_("Shape:")),
+        cursors = wx.Choice(parent=panel,
+                            choices=self.settings.Get(group='mapswipe', key='cursor',
+                                                      subkey=['type', 'choices'], internal=True),
+                            name="GetSelection")
+        cursors.SetSelection(self.settings.Get(group='mapswipe', key='cursor',
+                                               subkey=['type', 'selection']))
+        self.winId['mapswipe:cursor:type:selection'] = cursors.GetId()
+        gridSizer.Add(item=cursors, flag=wx.ALIGN_RIGHT | wx.ALIGN_CENTER_VERTICAL | wx.EXPAND,
+                      pos=(row, 1))
+        row += 1
+                                         label=_("Line width:")),
+        width = wx.SpinCtrl(parent=panel, min=1, max=10,
+                            initial=self.settings.Get(group='mapswipe', key='cursor',
+                                                      subkey='width'),
+                            name="GetValue")
+        self.winId['mapswipe:cursor:width'] = width.GetId()
+        gridSizer.Add(item=width, flag=wx.ALIGN_RIGHT | wx.ALIGN_CENTER_VERTICAL | wx.EXPAND,
+                      pos=(row, 1))
+        row += 1
+                                         label=_("Size:")),
+        size = wx.SpinCtrl(parent=panel, min=4, max=50,
+                                                     subkey='size'),
+                           name="GetValue")
+        self.winId['mapswipe:cursor:size'] = size.GetId()
+        gridSizer.Add(item=size, flag=wx.ALIGN_RIGHT | wx.ALIGN_CENTER_VERTICAL | wx.EXPAND,
+                      pos=(row, 1))
+        gridSizer.AddGrowableCol(1)
+        sizer.Add(item=gridSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=3)
+        border.Add(item=sizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=3)
+        panel.SetSizer(border)
+        return panel
Modified: grass/trunk/gui/wxpython/mapswipe/frame.py
--- grass/trunk/gui/wxpython/mapswipe/frame.py	2013-12-27 02:24:42 UTC (rev 58533)
+++ grass/trunk/gui/wxpython/mapswipe/frame.py	2013-12-27 02:30:24 UTC (rev 58534)
@@ -33,7 +33,7 @@
 from mapswipe.toolbars  import SwipeMapToolbar, SwipeMainToolbar, SwipeMiscToolbar
 from mapswipe.mapwindow import SwipeBufferedWindow
-from mapswipe.dialogs   import SwipeMapDialog
+from mapswipe.dialogs   import SwipeMapDialog, PreferencesDialog
 class SwipeMapFrame(DoubleMapFrame):
@@ -99,6 +99,7 @@
         self.rasters = {'first': None, 'second': None}
         self._inputDialog = None
+        self._preferencesDialog = None
         # default action in map toolbar
         self.GetMapToolbar().SelectDefault()
@@ -117,9 +118,9 @@
             return
         coords = event.GetPosition()
         if showInFirst:
-            self.firstMapWindow.DrawMouseCross(coords = coords)
+            self.firstMapWindow.DrawMouseCursor(coords=coords)
         else:
-            self.secondMapWindow.DrawMouseCross(coords = coords)
+            self.secondMapWindow.DrawMouseCursor(coords=coords)
         event.Skip()
@@ -612,6 +613,14 @@
     def OnHelp(self, event):
         self._giface.Help(entry = 'wxGUI.mapswipe')
+    def OnPreferences(self, event):
+        if not self._preferencesDialog:
+            dlg = PreferencesDialog(parent=self, giface=self._giface)
+            self._preferencesDialog = dlg
+            self._preferencesDialog.CenterOnParent()
+        self._preferencesDialog.ShowModal()
     def OnCloseWindow(self, event):
         self.GetFirstMap().Clean()
         self.GetSecondMap().Clean()
Modified: grass/trunk/gui/wxpython/mapswipe/mapwindow.py
--- grass/trunk/gui/wxpython/mapswipe/mapwindow.py	2013-12-27 02:24:42 UTC (rev 58533)
+++ grass/trunk/gui/wxpython/mapswipe/mapwindow.py	2013-12-27 02:30:24 UTC (rev 58534)
@@ -21,6 +21,7 @@
 from core.debug import Debug
 from mapwin.buffered import BufferedMapWindow
@@ -182,10 +183,25 @@
         end = (self.mouse['end'][0] + offsetX, self.mouse['end'][1] + offsetY)
         super(SwipeBufferedWindow, self).MouseDraw(pdc, begin, end)
-    def DrawMouseCross(self, coords):
+    def DrawMouseCursor(self, coords):
         """!Draw moving cross."""
         self.pdcTmp.ClearId(self.lineid)
-        self.lineid = self.DrawCross(pdc = self.pdcTmp, coords = coords, size = 10, pen = wx.BLACK_PEN)
+        color = UserSettings.Get(group='mapswipe', key='cursor', subkey='color')
+        cursType = UserSettings.Get(group='mapswipe', key='cursor', subkey=['type', 'selection'])
+        size = UserSettings.Get(group='mapswipe', key='cursor', subkey='size')
+        width = UserSettings.Get(group='mapswipe', key='cursor', subkey='width')
+        if cursType == 0:
+            self.lineid = self.DrawCross(pdc=self.pdcTmp, coords=coords, size=size,
+                                         pen=wx.Pen(wx.Colour(*color), width))
+        elif cursType == 1:
+            self.lineid = self.DrawRectangle(pdc=self.pdcTmp,
+                                             point1=(coords[0] - size / 2, coords[1] - size / 2),
+                                             point2=(coords[0] + size / 2, coords[1] + size / 2),
+        elif cursType == 2:
+            self.lineid = self.DrawCircle(pdc=self.pdcTmp,
+                                          coords=coords, radius=size / 2,
 class _MouseEvent(wx.PyCommandEvent):
Modified: grass/trunk/gui/wxpython/mapswipe/toolbars.py
--- grass/trunk/gui/wxpython/mapswipe/toolbars.py	2013-12-27 02:24:42 UTC (rev 58533)
+++ grass/trunk/gui/wxpython/mapswipe/toolbars.py	2013-12-27 02:30:24 UTC (rev 58534)
@@ -165,8 +165,10 @@
     def _toolbarData(self):
         """!Toolbar data"""
-        return self._getToolbarData((("help", BaseIcons['help'],
+        return self._getToolbarData((("settings", BaseIcons['settings'],
+                                      self.parent.OnPreferences),
+                                     ("help", BaseIcons['help'],
                                       self.parent.OnHelp),
-                                    ("quit", swipeIcons['quit'],
+                                     ("quit", swipeIcons['quit'],
                                       self.parent.OnCloseWindow),
