[GRASS-SVN] r54930 - grass/trunk/gui/wxpython/web_services
    svn_grass at osgeo.org
    Tue Feb  5 06:20:08 PST 2013
Author: martinl
Date: 2013-02-05 06:20:07 -0800 (Tue, 05 Feb 2013)
New Revision: 54930
   grass/trunk/gui/wxpython/web_services/dialogs.py
   grass/trunk/gui/wxpython/web_services/widgets.py
wxGUI/web services: fix default buttons
	  overwrite temp cap files
	  (patch provided by Stepan Turek)
Modified: grass/trunk/gui/wxpython/web_services/dialogs.py
--- grass/trunk/gui/wxpython/web_services/dialogs.py	2013-02-05 14:04:23 UTC (rev 54929)
+++ grass/trunk/gui/wxpython/web_services/dialogs.py	2013-02-05 14:20:07 UTC (rev 54930)
@@ -97,7 +97,6 @@
         self.btn_connect = wx.Button(parent = self,
                                      id = wx.ID_ANY, label = _("&Connect"))
         self.btn_connect.SetToolTipString(_("Connect to the server"))
-        self.btn_connect.SetDefault()
         if not self.server.GetValue():
             self.btn_connect.Enable(False)
@@ -367,8 +366,6 @@
                                                         password = self.password.GetValue())
             self.ws_panels[ws]['panel'].Hide()
-        self.btn_add.SetDefault()
     def OnPanelCapParsed(self, event):
         """!Called when panel has downloaded and parsed capabilities file.
@@ -381,14 +378,25 @@
             self.Layout()
             self.Fit()
+    def _getConnectedWS(self):
+        @return list of found web services on server (identified as keys in self.ws_panels)
+        conn_ws = []
+        for ws, data in self.ws_panels.iteritems():
+            if data['panel'].IsConnected():
+                conn_ws.append(ws)
+        return conn_ws
     def UpdateDialogAfterConnection(self):
         """!Update dialog after all web service panels downloaded and parsed capabilities data.
-        avail_ws = {}
-        for ws, data in self.ws_panels.iteritems():
+        avail_ws = {}
+        conn_ws = self._getConnectedWS()
-            if data['panel'].IsConnected():
-                avail_ws[ws] = data
+        for ws in conn_ws:
+            avail_ws[ws] = self.ws_panels[ws]
         self.web_service_sel = []
         self.rb_choices = []
@@ -466,6 +474,7 @@
         self.SetTitle(_("Add web service layer"))
         self.gmframe = gmframe
+        self.btn_connect.SetDefault()
     def _createWidgets(self):
@@ -488,6 +497,16 @@
         # bindings
         self.btn_add.Bind(wx.EVT_BUTTON, self.OnAddLayer)
+    def UpdateDialogAfterConnection(self):
+        """!Connect to the server
+        WSDialogBase.UpdateDialogAfterConnection(self)
+        if self._getConnectedWS():
+            self.btn_add.SetDefault()
+        else:
     def OnAddLayer(self, event):
         """!Add web service layer.
@@ -569,6 +588,7 @@
         self._setRevertCapFiles(ws_cap_files)
         self.LoadCapFiles(ws_cap_files = self.revert_ws_cap_files, cmd = cmd)
+        self.btn_ok.SetDefault()
     def __del__(self):
         for f in self.revert_ws_cap_files.itervalues():
@@ -593,10 +613,10 @@
         self.btn_apply.Enable(False)
         self.run_btns.append(self.btn_apply)
-        self.btn_save = wx.Button(parent = self, id = wx.ID_ANY, label = _("&Save"))
-        self.btn_save.SetToolTipString(_("Revert changes"))
-        self.btn_save.Enable(False)
-        self.run_btns.append(self.btn_save)
+        self.btn_ok = wx.Button(parent = self, id = wx.ID_ANY, label = _("&OK"))
+        self.btn_ok.SetToolTipString(_("Apply changes and close dialog"))
+        self.btn_ok.Enable(False)
+        self.run_btns.append(self.btn_ok)
     def _doLayout(self):
@@ -606,13 +626,13 @@
                           flag = wx.ALL | wx.ALIGN_CENTER,
                           border = 10)
-        self.btnsizer.Add(item = self.btn_save, proportion = 0,
+        self.btnsizer.Add(item = self.btn_ok, proportion = 0,
                           border = 10)
         # bindings
         self.btn_apply.Bind(wx.EVT_BUTTON, self.OnApply)
-        self.btn_save.Bind(wx.EVT_BUTTON, self.OnSave)
+        self.btn_ok.Bind(wx.EVT_BUTTON, self.OnSave)
     def LoadCapFiles(self, ws_cap_files, cmd):
         """!Parse cap files and update dialog.
@@ -678,6 +698,15 @@
         event = gUpdateMap()
         wx.PostEvent(display, event)
+        else:
     def OnApply(self, event):
         self._apply()
@@ -775,8 +804,8 @@
         self.btn_close = wx.Button(parent = self, id = wx.ID_CLOSE)
         self.btn_close.SetToolTipString(_("Close dialog"))
-        self.btn_save = wx.Button(parent = self, id = wx.ID_ANY, label = _("&Save layer"))
-        self.btn_save.SetToolTipString(_("Add web service layer"))
+        self.btn_ok = wx.Button(parent = self, id = wx.ID_ANY, label = _("&Save layer"))
+        self.btn_ok.SetToolTipString(_("Add web service layer"))
         # statusbar
         self.statusbar = wx.StatusBar(parent = self, id = wx.ID_ANY)
@@ -817,7 +846,7 @@
                           border = 10)
                           border = 10)
@@ -835,7 +864,7 @@
         # bindings
         self.btn_close.Bind(wx.EVT_BUTTON, self.OnClose)
         self.Bind(EVT_CMD_DONE,   self.OnCmdDone)
         self.Bind(EVT_CMD_OUTPUT, self.OnCmdOutput)
Modified: grass/trunk/gui/wxpython/web_services/widgets.py
--- grass/trunk/gui/wxpython/web_services/widgets.py	2013-02-05 14:04:23 UTC (rev 54929)
+++ grass/trunk/gui/wxpython/web_services/widgets.py	2013-02-05 14:20:07 UTC (rev 54930)
@@ -35,8 +35,8 @@
 from core              import globalvar
 from core.debug        import Debug
-from core.gcmd         import GWarning, GMessage
-from core.gconsole     import CmdThread, EVT_CMD_DONE
+from core.gcmd         import GWarning, GMessage, GError
+from core.gconsole     import CmdThread, GStderr, EVT_CMD_DONE, EVT_CMD_OUTPUT
 from web_services.cap_interface import WMSCapabilities, WMTSCapabilities, OnEarthCapabilities
@@ -107,6 +107,7 @@
+        self.cmdStdErr = GStderr(self)
         self.cmd_thread = CmdThread(self)
         self.cap_file = grass.tempfile()
@@ -119,6 +120,7 @@
         self._layout()
         self.Bind(EVT_CMD_DONE, self.OnCapDownloadDone)
+        self.Bind(EVT_CMD_OUTPUT, self.OnCmdOutput)
     def __del__(self):
         self.cmd_thread.abort(abortall =True)
@@ -417,11 +419,19 @@
         @param password - password for connection
         self._prepareForNewConn(url, username, password)
-        cap_cmd = ['r.in.wms', '-c', ('capfile_output=%s' % self.cap_file)] + self.ws_cmdl
+        cap_cmd = ['r.in.wms', '-c', ('capfile_output=%s' % self.cap_file), '--overwrite'] + self.ws_cmdl
         self.currentPid = self.cmd_thread.GetId()
-        self.cmd_thread.RunCmd(cap_cmd)
+        self.cmd_thread.RunCmd(cap_cmd, stderr = self.cmdStdErr)
+    def OnCmdOutput(self, event):
+        """!Print cmd output according to debug level.
+        @todo Replace with error dialog
+        if Debug.GetLevel() != 0:
+            Debug.msg(1, event.text)
     def _prepareForNewConn(self, url, username, password):
         """!Prepare panel for new connection
