[GRASS-SVN] r54951 - grass/branches/develbranch_6/gui/wxpython/core
Wed Feb 6 02:48:33 PST 2013
Author: martinl
Date: 2013-02-06 02:48:33 -0800 (Wed, 06 Feb 2013)
New Revision: 54951
   grass/branches/develbranch_6/gui/wxpython/core/render.py
wxGUI: check for invalid map size
Modified: grass/branches/develbranch_6/gui/wxpython/core/render.py
--- grass/branches/develbranch_6/gui/wxpython/core/render.py	2013-02-06 10:41:14 UTC (rev 54950)
+++ grass/branches/develbranch_6/gui/wxpython/core/render.py	2013-02-06 10:48:33 UTC (rev 54951)
@@ -9,7 +9,7 @@
  - render::Overlay
  - render::Map
-(C) 2006-2011 by the GRASS Development Team
+(C) 2006-2013 by the GRASS Development Team
 This program is free software under the GNU General Public License
 (>=v2). Read the file COPYING that comes with GRASS for details.
@@ -557,7 +557,7 @@
     def ChangeMapSize(self, (width, height)):
         """!Change size of rendered map.
-        @param width,height map size
+        @param width,height map size given as tuple
         @return True on success
         @return False on failure
@@ -565,14 +565,17 @@
         try:
             self.width  = int(width)
             self.height = int(height)
-            Debug.msg(2, "Map.ChangeMapSize(): width=%d, height=%d" % \
-                          (self.width, self.height))
-            return True
-        except:
+            if self.width < 1 or self.height < 1:
+                sys.stderr.write(_("Invalid map size %d,%d\n") % (self.width, self.height))
+                raise ValueError
+        except ValueError:
             self.width  = 640
             self.height = 480
-            return False
+        Debug.msg(2, "Map.ChangeMapSize(): width=%d, height=%d" % \
+                      (self.width, self.height))
     def GetRegion(self, rast = [], zoom = False, vect = [], regionName = None,
                   n = None, s = None, e = None, w = None, default = False,
                   update = False):
