[GRASS-SVN] r54953 - grass/trunk
Wed Feb 6 06:16:24 PST 2013
Author: wenzeslaus
Date: 2013-02-06 06:16:23 -0800 (Wed, 06 Feb 2013)
New Revision: 54953
Added:
   grass/trunk/SUBMITTING_WXGUI
   grass/trunk/SUBMITTING_DOCS
   grass/trunk/SUBMITTING_PYTHON
wxGUI: submitting file created
Modified: grass/trunk/SUBMITTING
--- grass/trunk/SUBMITTING	2013-02-06 10:49:54 UTC (rev 54952)
+++ grass/trunk/SUBMITTING	2013-02-06 14:16:23 UTC (rev 54953)
@@ -5,8 +5,9 @@
 when submitting C code to GRASS SVN repository, please take care of
 following rules:
-[ see also SUBMITTING_PYTHON for Python code hints ]
-[ see alse SUBMITTING_DOCS   for documentation ]
+[ see SUBMITTING_PYTHON for Python code hints ]
+[ see SUBMITTING_WXGUI for wxPython GUI code hints ]
+[ see SUBMITTING_DOCS for documentation ]
 1.  Get and read the GRASS Programmer's Manual here:
     http://grass.osgeo.org/programming7/
Modified: grass/trunk/SUBMITTING_DOCS
--- grass/trunk/SUBMITTING_DOCS	2013-02-06 10:49:54 UTC (rev 54952)
+++ grass/trunk/SUBMITTING_DOCS	2013-02-06 14:16:23 UTC (rev 54953)
@@ -5,7 +5,8 @@
 when submitting documentation to GRASS SVN repository, please take
 care of following rules:
-[ see SUBMITTING        for C hints ]
+[ see SUBMITTING for C hints ]
Modified: grass/trunk/SUBMITTING_PYTHON
--- grass/trunk/SUBMITTING_PYTHON	2013-02-06 10:49:54 UTC (rev 54952)
+++ grass/trunk/SUBMITTING_PYTHON	2013-02-06 14:16:23 UTC (rev 54953)
@@ -5,7 +5,8 @@
 when submitting Python code to GRASS SVN repository, please take
 See also http://www.python.org/dev/peps/pep-0008/
@@ -148,58 +149,27 @@
       svn:ignore : *.pyc
     or e.g. for Python file
       svn:mime-type : text/python
       svn:keywords : Author Date Id
       svn:eol-style : native
+      svn propset svn:mime-type text/python new/file.py
+      svn propset svn:keywords "Author Date Id" new/file.py
+      svn propset svn:eol-style native new/file.py
     See
     http://svnbook.red-bean.com/en/1.4/svn.advanced.props.html
-13. wxGUI (gui/wxpython)
-    See http://wiki.wxpython.org/wxPython_Style_Guide
-    Major rules:
-    - use named parameters in functions, e.g.
-    dlg = wx.FileDialog(parent = self, message = _("Choose file to save current workspace"),
-                        wildcard = _("GRASS Workspace File (*.gxw)|*.gxw"), style = wx.FD_SAVE)
-    instead of
-    dlg = wx.FileDialog(self, _("Choose file to save current workspace"),
-                        _("GRASS Workspace File (*.gxw)|*.gxw"), wx.FD_SAVE)
-    - use wx.ID_ANY instead of `-1`
-    - use gcmd.GError(), gcmd.GWarning and gcmd.GMessage instead of wx.MessageBox()
-    - use gcmd.RunCommand() instead of grass.run_command() or grass.read_command()
-    - use full strings, eg.
-      if ...:
-          win.SetLabel(_('Name for new 3D raster map to create'))
-      else:
-          win.SetLabel(_('Name for new raster map to create'))
-      instead of
-      _('Name for new %s to create') % maplabel
-      where `maplabel` can be 'raster map' or '3D raster map'
-14. Tell the other developers about the new code using the following e-mail:
+13. Tell the other developers about the new code using the following e-mail:
     grass-dev at lists.osgeo.org
     To subscribe to this mailing list, see
     http://lists.osgeo.org/mailman/listinfo/grass-dev
-15. In case of questions feel free to contact the developers at the above
+14. In case of questions feel free to contact the developers at the above
     mailing list.
     http://grass.osgeo.org/devel/index.php#submission
Added: grass/trunk/SUBMITTING_WXGUI
--- grass/trunk/SUBMITTING_WXGUI	                        (rev 0)
+++ grass/trunk/SUBMITTING_WXGUI	2013-02-06 14:16:23 UTC (rev 54953)
@@ -0,0 +1,156 @@
+NOTE: Please improve this list!
+Dear (new) GRASS developer,
+when submitting Python code to GRASS SVN repository, please take
+care of following rules:
+0.  Introduction
+    For general GRASS, svn and Python issues and module related issues see
+    SUBMITTING_PYTHON and SUBMITTING.
+    GUI is divided into components. One component is usually placed in one
+    directory.
+1.  GRASS documentation
+    GRASS Programming manual for API and existing classes
+    http://grass.osgeo.org/programming7/wxpythonlib.html
+    GRASS wiki has pages about how to develop wxGUI
+    http://grasswiki.osgeo.org
+    GRASS Trac wiki has pages about the state of wxGUI development
+    http://trac.osgeo.org/grass/wiki/wxGUIDevelopment
+2.  External documentation
+    Style Guide for Python Code
+    http://www.python.org/dev/peps/pep-0008/
+    Python Style Guide by Guido van Rossum
+    http://www.python.org/doc/essays/styleguide.html
+    wxPython Style Guide
+    http://wiki.wxpython.org/wxPython_Style_Guide
+    Additional info on Python docstrings
+    http://epydoc.sourceforge.net/docstrings.html
+3.  Remember that functionality such as generating plots should be primarily
+    provided by modules not GUI.
+4.  Try to create create also g.gui.* module for the new GUI component. It helps
+    advanced users to access functionality and developers to test it. Moreover,
+    it helps to keep components separated and thus, supports re-usability.
+5.  Add a header section to each file you submit and make sure you
+    include the copyright. The purpose section is meant to contain a
+    general over view of the code in the file to assist other
+    programmers that will need to make changes to your code. For this
+    purpose use Python docstring.
+    The copyright protects your rights according to GNU General Public
+    License (www.gnu.org).
+    Please use the following docstring template:
+    @package dir.example
+    @brief Short example package description
+    Classes:
+     - example::ExampleClass
+    (C) 2012 by the GRASS Development Team
+    This program is free software under the GNU General Public License
+    (>=v2). Read the file COPYING that comes with GRASS for details.
+    @author First Author <first somewhere.com>
+    @author Second Author <second somewhere.com>
+    @author Some Other <third somewhere.com> (some particular change)
+6.  Comment your classes and functions with docstrings. Use Doxygen syntax,
+    particularly, use commands which begins with @
+    (www.doxygen.org/manual/commands.html).
+    Comment also the code itself such as the meaning of variables,
+    conditions etc.
+7.  Make sure a new line is at the end of each file. Non empty line breaks the
+    build process.
+8.  Basic rules
+    Do not use print command unless you know what are you doing.
+    Use named parameters in functions, e.g.
+    dlg = wx.FileDialog(parent=self, message=_("Choose file to save current workspace"),
+                        wildcard=_("GRASS Workspace File (*.gxw)|*.gxw"), style = wx.FD_SAVE)
+    instead of
+    dlg = wx.FileDialog(self, _("Choose file to save current workspace"),
+                        _("GRASS Workspace File (*.gxw)|*.gxw"), wx.FD_SAVE)
+    Use wx.ID_ANY instead of `-1`.
+    Use GError, GWarning and GMessage instead of wx.MessageBox()
+    Do not use grass.run_command() or grass.read_command(). Use functions and
+    classes which uses threads such as RunCommand.
+    Use full strings, e.g.
+      if ...:
+          win.SetLabel(_('Name for new 3D raster map to create'))
+      else:
+          win.SetLabel(_('Name for new raster map to create'))
+      instead of
+      _('Name for new %s to create') % maplabel
+      where `maplabel` can be 'raster map' or '3D raster map'
+9.  Use tools such as pylint and pep8 to check your code (both style and
+    correctness). Just note that default settings of these tools is not fully
+    compatible with wxGUI/wxPython style and that some of the reported errors
+    may not apply to your code.
+14. Tell the other developers about the new code using the following e-mail:
+    grass-dev at lists.osgeo.org
+    To subscribe to this mailing list, see
+    http://lists.osgeo.org/mailman/listinfo/grass-dev
+15. In case of questions feel free to contact the other developers at the above
+    mailing list.
+    http://grass.osgeo.org/devel/index.php#submission
+[please add further hints if required]
+"Your attention to detail is appreciated."
Property changes on: grass/trunk/SUBMITTING_WXGUI
___________________________________________________________________
Added: svn:mime-type
   + text/plain
Added: svn:keywords
   + Author Date Id
Added: svn:eol-style
   + native
