[GRASS-SVN] r54961 - in grass/trunk: db/db.select raster/r.category raster/r.what vector/v.to.db
Wed Feb 6 10:08:02 PST 2013
Author: martinl
Date: 2013-02-06 10:08:02 -0800 (Wed, 06 Feb 2013)
New Revision: 54961
   grass/trunk/db/db.select/main.c
   grass/trunk/raster/r.category/main.c
   grass/trunk/raster/r.what/main.c
   grass/trunk/vector/v.to.db/global.h
   grass/trunk/vector/v.to.db/report.c
update modules which are using G_option_to_separator() to support multi-character separators
@todo change rest of modules which have separator as one of the options to use G_option_to_separator()
Modified: grass/trunk/db/db.select/main.c
--- grass/trunk/db/db.select/main.c	2013-02-06 18:04:38 UTC (rev 54960)
+++ grass/trunk/db/db.select/main.c	2013-02-06 18:08:02 UTC (rev 54961)
@@ -27,7 +27,7 @@
 #include "local_proto.h"
 struct {
-    char *driver, *database, *table, *sql, fs, vs, *nv, *input, *output;
+    char *driver, *database, *table, *sql, *fs, *vs, *nv, *input, *output;
     int c, d, h, test_only;
 } parms;
@@ -141,7 +141,7 @@
 	for (col = 0; col < ncols; col++) {
 	    column = db_get_table_column(table, col);
 	    if (col)
-		fprintf(stdout, "%c", parms.fs);
+		fprintf(stdout, "%s", parms.fs);
 	    fprintf(stdout, "%s", db_get_column_name(column));
 	fprintf(stdout, "\n");
@@ -159,9 +159,9 @@
 	    value = db_get_column_value(column);
 	    db_convert_column_value_to_string(column, &value_string);
 	    if (parms.c && !parms.h)
-		fprintf(stdout, "%s%c", db_get_column_name(column), parms.fs);
+		fprintf(stdout, "%s%s", db_get_column_name(column), parms.fs);
 	    if (col && parms.h)
 	    if (parms.nv && db_test_value_isnull(value))
 		fprintf(stdout, "%s", parms.nv);
 	    else
@@ -172,7 +172,7 @@
 	if (parms.h)
 	else if (parms.vs)
-	    fprintf(stdout, "%c\n", parms.vs);
+	    fprintf(stdout, "%s\n", parms.vs);
     return OK;
Modified: grass/trunk/raster/r.category/main.c
--- grass/trunk/raster/r.category/main.c	2013-02-06 18:04:38 UTC (rev 54960)
+++ grass/trunk/raster/r.category/main.c	2013-02-06 18:08:02 UTC (rev 54961)
@@ -25,14 +25,14 @@
 #include <grass/glocale.h>
-static char fs = '\t';
 static struct Categories cats;
+static char *fs;
 int main(int argc, char *argv[])
     const char *name;
     const char *mapset;
     long x, y;
     double dx;
     RASTER_MAP_TYPE map_type;
@@ -287,7 +287,7 @@
     char *label;
     G_squeeze(label = Rast_get_c_cat((CELL *) &x, &cats));
-    fprintf(stdout, "%ld%c%s\n", x, fs, label);
+    fprintf(stdout, "%ld%s%s\n", x, fs, label);
     return 0;
@@ -301,7 +301,7 @@
     G_squeeze(label = Rast_get_d_cat(&dtmp, &cats));
     sprintf(tmp, "%.10f", x);
     G_trim_decimal(tmp);
-    fprintf(stdout, "%s%c%s\n", tmp, fs, label);
+    fprintf(stdout, "%s%s%s\n", tmp, fs, label);
     return 0;
Modified: grass/trunk/raster/r.what/main.c
--- grass/trunk/raster/r.what/main.c	2013-02-06 18:04:38 UTC (rev 54960)
+++ grass/trunk/raster/r.what/main.c	2013-02-06 18:08:02 UTC (rev 54961)
@@ -75,7 +75,7 @@
     struct _flg {
 	struct Flag *label, *cache, *cat_int, *color, *header;
     } flg;
-    char fs;
+    char *fs;
     int Cache_size;
     int done = FALSE;
     int point, point_cnt;
@@ -230,19 +230,19 @@
     /* print header row */
     if(flg.header->answer) {
-	fprintf(stdout, "easting%cnorthing%csite_name", fs, fs);
+	fprintf(stdout, "easting%snorthing%ssite_name", fs, fs);
 	ptr = opt.input->answers;
 	for (; *ptr != NULL; ptr++) {
 	    char name[GNAME_MAX];
 	    strcpy(name, *ptr);
-	    fprintf(stdout, "%c%s", fs, name);
+	    fprintf(stdout, "%s%s", fs, name);
 	    if (flg.label->answer)
-		fprintf(stdout, "%c%s_label", fs, name);
+		fprintf(stdout, "%s%s_label", fs, name);
 	    if (flg.color->answer)
-		fprintf(stdout, "%c%s_color", fs, name);
+		fprintf(stdout, "%s%s_color", fs, name);
@@ -427,29 +427,29 @@
 		    cache[point].col, cache[point].row);
-	    fprintf(stdout, "%s%c%s%c%s", cache[point].east_buf, fs,
+	    fprintf(stdout, "%s%s%s%s%s", cache[point].east_buf, fs,
 		    cache[point].north_buf, fs, cache[point].lab_buf);
 	    for (i = 0; i < nfiles; i++) {
 		if (out_type[i] == CELL_TYPE) {
 		    if (Rast_is_c_null_value(&cache[point].value[i])) {
-			fprintf(stdout, "%c%s", fs, null_str);
+			fprintf(stdout, "%s%s", fs, null_str);
-			    fprintf(stdout, "%c", fs);
+			    fprintf(stdout, "%s", fs);
 			continue;
-		    fprintf(stdout, "%c%ld", fs, (long)cache[point].value[i]);
+		    fprintf(stdout, "%s%ld", fs, (long)cache[point].value[i]);
 		else {		/* FCELL or DCELL */
 		    if (Rast_is_d_null_value(&cache[point].dvalue[i])) {
 			continue;
 		    if (out_type[i] == FCELL_TYPE)
@@ -457,13 +457,13 @@
 		    else /* DCELL */
 			sprintf(tmp_buf, "%.15g", cache[point].dvalue[i]);
 		    G_trim_decimal(tmp_buf); /* not needed with %g? */
-		    fprintf(stdout, "%c%s", fs, tmp_buf);
+		    fprintf(stdout, "%s%s", fs, tmp_buf);
 			    Rast_get_c_cat(&(cache[point].value[i]), &cats[i]));
-		    fprintf(stdout, "%c%s", fs, cache[point].clr_buf[i]);
+		    fprintf(stdout, "%s%s", fs, cache[point].clr_buf[i]);
Modified: grass/trunk/vector/v.to.db/global.h
--- grass/trunk/vector/v.to.db/global.h	2013-02-06 18:04:38 UTC (rev 54960)
+++ grass/trunk/vector/v.to.db/global.h	2013-02-06 18:08:02 UTC (rev 54961)
@@ -31,7 +31,7 @@
     int total;			/* print totals */
     int units;
     int qfield;			/* query field */
-    char fs;
+    char *fs;
 extern struct options options;
Modified: grass/trunk/vector/v.to.db/report.c
--- grass/trunk/vector/v.to.db/report.c	2013-02-06 18:04:38 UTC (rev 54960)
+++ grass/trunk/vector/v.to.db/report.c	2013-02-06 18:08:02 UTC (rev 54961)
@@ -25,9 +25,9 @@
     case O_COUNT:
         if (options.print) {
             if (G_verbose() > G_verbose_min())
-                fprintf(stdout, "cat%ccount\n", options.fs);
+                fprintf(stdout, "cat%scount\n", options.fs);
             for (i = 0; i < vstat.rcat; i++)
-                fprintf(stdout, "%d%c%d\n", Values[i].cat, options.fs, Values[i].count1);
+                fprintf(stdout, "%d%s%d\n", Values[i].cat, options.fs, Values[i].count1);
 	if (options.total) {
 	    int sum = 0;
@@ -35,16 +35,16 @@
 	    for (i = 0; i < vstat.rcat; i++) {
 		sum += Values[i].count1;
-	    fprintf(stdout, "total count%c%d\n", options.fs, sum);
+	    fprintf(stdout, "total count%s%d\n", options.fs, sum);
 	break;
     case O_AREA:
-                fprintf(stdout, "cat%carea\n", options.fs);
+                fprintf(stdout, "cat%sarea\n", options.fs);
-                fprintf(stdout, "%d%c%.15g\n", Values[i].cat, options.fs, Values[i].d1);
+                fprintf(stdout, "%d%s%.15g\n", Values[i].cat, options.fs, Values[i].d1);
 	    double sum = 0.0;
@@ -52,30 +52,30 @@
 		sum += Values[i].d1;
-	    fprintf(stdout, "total area%c%.15g\n", options.fs, sum);
+	    fprintf(stdout, "total area%s%.15g\n", options.fs, sum);
 	break;
     case O_COMPACT:
-	    fprintf(stdout, "cat%ccompact\n", options.fs);
+	    fprintf(stdout, "cat%scompact\n", options.fs);
 	break;
     case O_PERIMETER:
-	    fprintf(stdout, "cat%cperimeter\n", options.fs);
+	    fprintf(stdout, "cat%sperimeter\n", options.fs);
 	break;
     case O_LENGTH:
-                fprintf(stdout, "cat%clength\n", options.fs);
+                fprintf(stdout, "cat%slength\n", options.fs);
 	    double sum = 0.0;
@@ -83,38 +83,38 @@
-	    fprintf(stdout, "total length%c%.15g\n", options.fs, sum);
+	    fprintf(stdout, "total length%s%.15g\n", options.fs, sum);
 	break;
     case O_SLOPE:
-	    fprintf(stdout, "cat%cslope\n", options.fs);
+	    fprintf(stdout, "cat%sslope\n", options.fs);
 	break;
     case O_SINUOUS:
-	    fprintf(stdout, "cat%csinuous\n", options.fs);
+	    fprintf(stdout, "cat%ssinuous\n", options.fs);
 	break;
     case O_COOR:
     case O_START:
     case O_END:
-	    fprintf(stdout, "cat%cx%cy%cz\n", options.fs, options.fs, options.fs);
+	    fprintf(stdout, "cat%sx%sy%sz\n", options.fs, options.fs, options.fs);
 	    if (Values[i].count1 == 1)
-		fprintf(stdout, "%d%c%.15g%c%.15g%c%.15g\n", Values[i].cat, options.fs,
+		fprintf(stdout, "%d%s%.15g%s%.15g%s%.15g\n", Values[i].cat, options.fs,
 			Values[i].d1, options.fs, Values[i].d2, options.fs, Values[i].d3);
 	break;
     case O_SIDES:
-	    fprintf(stdout, "cat%cleft%cright\n", options.fs, options.fs);
+	    fprintf(stdout, "cat%sleft%sright\n", options.fs, options.fs);
 	    if (Values[i].count1 == 1) {
 		if (Values[i].i1 >= 0)
@@ -145,13 +145,13 @@
 		sprintf(right, "-");
-	    fprintf(stdout, "%d%c%s%c%s\n", Values[i].cat, options.fs, left, options.fs, right);
+	    fprintf(stdout, "%d%s%s%s%s\n", Values[i].cat, options.fs, left, options.fs, right);
 	break;
     case O_QUERY:
-	    fprintf(stdout, "cat%cquery\n", options.fs);
+	    fprintf(stdout, "cat%squery\n", options.fs);
 	    if (Values[i].null) {
 		fprintf(stdout, "%d|-\n", Values[i].cat);
@@ -159,13 +159,13 @@
 	    else {
 		switch (vstat.qtype) {
 		case (DB_C_TYPE_INT):
-		    fprintf(stdout, "%d%c%d\n", Values[i].cat, options.fs, Values[i].i1);
+		    fprintf(stdout, "%d%s%d\n", Values[i].cat, options.fs, Values[i].i1);
 		    break;
 		case (DB_C_TYPE_DOUBLE):
-		    fprintf(stdout, "%d%c%15g\n", Values[i].cat, options.fs, Values[i].d1);
+		    fprintf(stdout, "%d%s%15g\n", Values[i].cat, options.fs, Values[i].d1);
 		    break;
 		case (DB_C_TYPE_STRING):
-		    fprintf(stdout, "%d%c%s\n", Values[i].cat, options.fs, Values[i].str1);
+		    fprintf(stdout, "%d%s%s\n", Values[i].cat, options.fs, Values[i].str1);
 		    break;
@@ -173,9 +173,9 @@
 	break;
     case O_AZIMUTH:
-	    fprintf(stdout, "cat%cazimuth\n", options.fs);
+	    fprintf(stdout, "cat%sazimuth\n", options.fs);
 	break;
