[GRASS-SVN] r54985 - grass/trunk/lib/python/pygrass/vector
Fri Feb 8 06:34:30 PST 2013
Author: lucadelu
Date: 2013-02-08 06:34:29 -0800 (Fri, 08 Feb 2013)
New Revision: 54985
   grass/trunk/lib/python/pygrass/vector/geometry.py
fix return value; change line with cat
Modified: grass/trunk/lib/python/pygrass/vector/geometry.py
--- grass/trunk/lib/python/pygrass/vector/geometry.py	2013-02-08 14:25:36 UTC (rev 54984)
+++ grass/trunk/lib/python/pygrass/vector/geometry.py	2013-02-08 14:34:29 UTC (rev 54985)
@@ -147,7 +147,7 @@
         #SELECT {cols} FROM {tname} WHERE {condition};
-        cur = self.table.execute(sql.SELECT_WHERE.format(key,
+        cur = self.table.execute(sql.SELECT_WHERE.format(cols=key,
                                                          tname=self.table.name,
                                                          condition=self.cond))
         results = cur.fetchone()
@@ -1216,7 +1216,7 @@
             self.isles = self.get_isles()
             libvect.Vect_read_line(self.c_mapinfo, None, self.c_cats,
                                    self.centroid.id)
-            self.line = self.c_cats.contents.cat.contents.value
+            self.cat = self.c_cats.contents.cat.contents.value
         elif boundary and centroid:
             self.boundary = boundary
             self.centroid = centroid
@@ -1226,8 +1226,8 @@
             raise GrassError(str_err)
         # set the attributes
-        if self.attrs and self.line:
-            self.attrs = Attrs(self.line,
+        if self.attrs and self.cat:
+            self.attrs = Attrs(self.cat,
                                self.attrs.table, self.attrs.writable)
         # geometry type
