[GRASS-SVN] r55007 - grass/trunk/imagery/i.segment
Tue Feb 12 02:18:51 PST 2013
Author: martinl
Date: 2013-02-12 02:18:50 -0800 (Tue, 12 Feb 2013)
New Revision: 55007
   grass/trunk/imagery/i.segment/i.segment.xl.html
   grass/trunk/imagery/i.segment/main.c
   grass/trunk/imagery/i.segment/parse_args.c
i.segment.xl: more guisections
	      remove trailing dots
Modified: grass/trunk/imagery/i.segment/i.segment.xl.html
--- grass/trunk/imagery/i.segment/i.segment.xl.html	2013-02-12 09:51:18 UTC (rev 55006)
+++ grass/trunk/imagery/i.segment/i.segment.xl.html	2013-02-12 10:18:50 UTC (rev 55007)
@@ -164,6 +164,7 @@
 <a href="http://grass.osgeo.org/wiki/Image_classification">classification in GRASS</a>
 is at available on the wiki.
 </p>
 <h2>SEE ALSO</h2>
 <em>
 <a href="i.group.html">i.group</a>,
@@ -174,6 +175,7 @@
 </em>
 <h2>AUTHORS</h2>
-Eric Momsen - North Dakota State University<br>
-Markus Metz (GSoC Mentor)
+Eric Momsen - North Dakota State University (Google Summer of Code 2012, mentor: Markus Metz)<br>
+Various improvements by Markus Metz
Modified: grass/trunk/imagery/i.segment/main.c
--- grass/trunk/imagery/i.segment/main.c	2013-02-12 09:51:18 UTC (rev 55006)
+++ grass/trunk/imagery/i.segment/main.c	2013-02-12 10:18:50 UTC (rev 55007)
@@ -2,20 +2,21 @@
  * MODULE:       i.segment
- * AUTHOR(S):    Eric Momsen <eric.momsen at gmail com>
+ * AUTHOR(S):    Eric Momsen <eric.momsen at gmail com> (Google Summer of Code 2012)
+ *               Optimized by Markus Metz
  * PURPOSE:      Segments an image group.
  * COPYRIGHT:    (C) 2012 by Eric Momsen, and the GRASS Development Team
- *               This program is free software under the GNU General Public
- *               License (>=v2). Read the COPYING file that comes with GRASS
- *               for details.
+ *               This program is free software under the GNU General
+ *               Public License (>=v2). Read the COPYING file that
+ *               comes with GRASS for details.
- *               NOTE: the word "segment" is already used by the Segmentation
- *               Library for the data files/tiling, so iseg (image segmentation)
- *               will be used to refer to the image segmentation.
+ *               NOTE: the word "segment" is already used by the
+ *               Segmentation Library for the data files/tiling, so
+ *               iseg (image segmentation) will be used to refer to
+ *               the image segmentation.
 #include <stdlib.h>
@@ -25,7 +26,7 @@
 int main(int argc, char *argv[])
-    struct globals globals;		/* input and output file descriptors, data structure, buffers */
+    struct globals globals; /* input and output file descriptors, data structure, buffers */
     struct GModule *module;
     G_gisinit(argv[0]);
@@ -34,22 +35,21 @@
     G_add_keyword(_("imagery"));
     G_add_keyword(_("segmentation"));
     module->description =
-	_("Outputs a single segmented map (raster) based on input values in an image group.");
+	_("Outputs a single segmented raster map based on input values in an image group.");
-    if (parse_args(argc, argv, &globals) != TRUE)
-	G_fatal_error(_("Error in parse_args()"));
+    parse_args(argc, argv, &globals);
     G_debug(1, "Main: starting open_files()");
     if (open_files(&globals) != TRUE)
-	G_fatal_error(_("Error in open_files()"));
+	G_fatal_error(_("Error in reading data"));
     G_debug(1, "Main: starting create_isegs()");
     if (create_isegs(&globals) != TRUE)
-	G_fatal_error(_("Error in create_isegs()"));
+	G_fatal_error(_("Error in creating segments"));
     G_debug(1, "Main: starting write_output()");
     if (write_output(&globals) != TRUE)
-	G_fatal_error(_("Error in write_output()"));
+	G_fatal_error(_("Error in writing data"));
     G_debug(1, "Main: starting close_files()");
     close_files(&globals);
Modified: grass/trunk/imagery/i.segment/parse_args.c
--- grass/trunk/imagery/i.segment/parse_args.c	2013-02-12 09:51:18 UTC (rev 55006)
+++ grass/trunk/imagery/i.segment/parse_args.c	2013-02-12 10:18:50 UTC (rev 55007)
@@ -27,8 +27,8 @@
     threshold->key = "threshold";
     threshold->type = TYPE_DOUBLE;
     threshold->required = YES;
-    threshold->label = _("Difference threshold between 0 and 1.");
-    threshold->description = _("Threshold = 0 merges only identical segments; threshold = 1 merges all.");
+    threshold->label = _("Difference threshold between 0 and 1");
+    threshold->description = _("Threshold = 0 merges only identical segments; threshold = 1 merges all");
     /* optional parameters */
@@ -37,7 +37,8 @@
     method->type = TYPE_STRING;
     method->required = NO;
     method->answer = "region_growing";
-    method->description = _("Segmentation method.");
+    method->options = "region_growing";
+    method->description = _("Segmentation method");
     method->guisection = _("Settings");
     similarity = G_define_option();
@@ -45,8 +46,8 @@
     similarity->type = TYPE_STRING;
     similarity->required = YES;
     similarity->answer = "euclidean";
-    similarity->options = "euclidean, manhattan";
-    similarity->description = _("Similarity calculation method.");
+    similarity->options = "euclidean,manhattan";
+    similarity->description = _("Similarity calculation method");
     similarity->guisection = _("Settings");
     min_segment_size = G_define_option();
@@ -55,9 +56,9 @@
     min_segment_size->required = NO;
     min_segment_size->answer = "1";
     min_segment_size->options = "1-100000";
-    min_segment_size->label = _("Minimum number of cells in a segment.");
+    min_segment_size->label = _("Minimum number of cells in a segment");
     min_segment_size->description =
-	_("The final step will merge small segments with their best neighbor.");
+	_("The final step will merge small segments with their best neighbor");
     min_segment_size->guisection = _("Settings");
 #ifdef _OR_SHAPE_
@@ -68,7 +69,7 @@
     radio_weight->answer = "1";
     radio_weight->options = "0-1";
     radio_weight->label =
-	_("Importance of radiometric (input raster) values relative to shape.");
+	_("Importance of radiometric (input raster) values relative to shape");
     radio_weight->guisection = _("Settings");
     smooth_weight = G_define_option();
@@ -78,31 +79,16 @@
     smooth_weight->answer = "0.5";
     smooth_weight->options = "0-1";
     smooth_weight->label =
-	_("Importance of smoothness relative to compactness.");
+	_("Importance of smoothness relative to compactness");
     smooth_weight->guisection = _("Settings");
 #endif
-    /* Using raster for seeds
-     * Low priority TODO: allow vector points/centroids seed input. */
-    seeds = G_define_standard_option(G_OPT_R_INPUT);
-    seeds->key = "seeds";
-    seeds->required = NO;
-    seeds->description = _("Optional raster map with starting seeds.");
-    /* Polygon constraints. */
-    bounds = G_define_standard_option(G_OPT_R_INPUT);
-    bounds->key = "bounds";
-    bounds->required = NO;
-    bounds->label = _("Optional bounding/constraining raster map");
-    bounds->description =
-	_("Must be integer values, each area will be segmented independent of the others.");
     mem = G_define_option();
     mem->key = "memory";
     mem->type = TYPE_INTEGER;
     mem->required = NO;
     mem->answer = "300";
-    mem->description = _("Memory in MB.");
+    mem->description = _("Memory in MB");
     /* TODO input for distance function */
@@ -112,23 +98,44 @@
     endt->type = TYPE_INTEGER;
     endt->required = NO;
     endt->answer = "100";
-    endt->description = _("Maximum number of iterations.");
+    endt->description = _("Maximum number of iterations");
+    endt->guisection = _("Settings");
+    /* Using raster for seeds
+     * Low priority TODO: allow vector points/centroids seed input. */
+    seeds = G_define_standard_option(G_OPT_R_INPUT);
+    seeds->key = "seeds";
+    seeds->required = NO;
+    seeds->description = _("Name for output raster map with starting seeds");
+    seeds->guisection = _("Optional outputs");
+    /* Polygon constraints. */
+    bounds = G_define_standard_option(G_OPT_R_INPUT);
+    bounds->key = "bounds";
+    bounds->required = NO;
+    bounds->label = _("Name for output bounding/constraining raster map");
+    bounds->description =
+	_("Must be integer values, each area will be segmented independent of the others");
+    bounds->guisection = _("Optional outputs");
     outband = G_define_standard_option(G_OPT_R_OUTPUT);
     outband->key = "goodness";
     outband->required = NO;
     outband->description =
-	_("Goodness of fit estimate.");
+	_("Name for output goodness of fit estimate");
+    outband->guisection = _("Optional outputs");
     diagonal = G_define_flag();
     diagonal->key = 'd';
     diagonal->description =
-	_("Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for each pixel.");
+	_("Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for each pixel");
+    diagonal->guisection = _("Settings");
     weighted = G_define_flag();
     weighted->key = 'w';
     weighted->description =
-	_("Weighted input, don't perform the default scaling of input maps.");
+	_("Weighted input, don't perform the default scaling of input raster maps");
+    weighted->guisection = _("Settings");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -140,19 +147,19 @@
     if (G_legal_filename(output->answer) == TRUE)
 	globals->out_name = output->answer;
     else
-	G_fatal_error("Invalid output raster name.");
+	G_fatal_error("Invalid output raster name");
     /* Note: this threshold is scaled after we know more at the beginning of create_isegs() */
     globals->alpha = atof(threshold->answer);
     if (globals->alpha <= 0 || globals->alpha >= 1)
-	G_fatal_error(_("threshold should be >= 0 and <= 1"));
+	G_fatal_error(_("Threshold should be >= 0 and <= 1"));
     /* segmentation methods:  1 = region growing */
     if (strcmp(method->answer, "region_growing") == 0)
 	globals->method = 1;
     else
-	G_fatal_error("Couldn't assign segmentation method.");
+	G_fatal_error(_("Unable to assign segmentation method"));
     G_debug(1, "segmentation method: %d", globals->method);
@@ -162,7 +169,7 @@
     else if (strcmp(similarity->answer, "manhattan") == 0)
 	globals->calculate_similarity = calculate_manhattan_similarity;
     else
-	G_fatal_error(_("Invalid similarity method."));
+	G_fatal_error(_("Invalid similarity method"));
 #ifdef _OR_SHAPE_
     /* consider shape */
@@ -201,11 +208,11 @@
     globals->seeds = seeds->answer;
     if (globals->seeds) {
 	if (G_find_raster(globals->seeds, "") == NULL) {
-	    G_fatal_error(_("Seeds map not found."));
+	    G_fatal_error(_("Seeds raster map not found"));
 	if (Rast_map_type(globals->seeds, "") !=
 	    CELL_TYPE) {
-	    G_fatal_error(_("Seeeds map must be CELL type (integers)"));
+	    G_fatal_error(_("Seeeds raster map must be CELL type (integers)"));
@@ -215,11 +222,11 @@
     else {
 	globals->bounds_map = bounds->answer;
 	if ((globals->bounds_mapset = G_find_raster(globals->bounds_map, "")) == NULL) {
-	    G_fatal_error(_("Segmentation constraint/boundary map not found."));
+	    G_fatal_error(_("Segmentation constraint/boundary raster map not found"));
 	if (Rast_map_type(globals->bounds_map, globals->bounds_mapset) !=
 	    CELL_TYPE) {
-	    G_fatal_error(_("Segmentation constraint map must be CELL type (integers)"));
+	    G_fatal_error(_("Segmentation constraint raster map must be CELL type (integers)"));
@@ -234,7 +241,7 @@
 	if (G_legal_filename(outband->answer) == TRUE)
 	    globals->out_band = outband->answer;
 	else
-	    G_fatal_error("Invalid output raster name for goodness of fit.");
+	    G_fatal_error(_("Invalid output raster name for goodness of fit"));
     if (endt->answer) {
@@ -242,7 +249,7 @@
 	    globals->end_t = atoi(endt->answer);
 	else {
 	    globals->end_t = 100;
-	    G_warning(_("Invalid number of iterations, 100 will be used."));
+	    G_warning(_("Invalid number of iterations, 100 will be used"));
     else
@@ -252,7 +259,7 @@
 	globals->mb = atoi(mem->answer);
     else {
 	globals->mb = 300;
-	G_warning(_("Invalid number of MB, 300 will be used."));
+	G_warning(_("Invalid number of MB, 300 will be used"));
     return TRUE;
