[GRASS-SVN] r55077 - grass-addons/grass7/raster/r.in.srtm.region
Sat Feb 16 06:44:14 PST 2013
Author: mmetz
Date: 2013-02-16 06:44:14 -0800 (Sat, 16 Feb 2013)
New Revision: 55077
   grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.py
r.in.srtm.region small bugfixes
Modified: grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.py
--- grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.py	2013-02-16 13:50:02 UTC (rev 55076)
+++ grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.py	2013-02-16 14:44:14 UTC (rev 55077)
@@ -197,22 +197,30 @@
 	north = tmpint + 1
     else:
 	north = tmpint
     tmpint = int(south)
     if tmpint > south:
 	south = tmpint - 1
     else:
 	south = tmpint
     tmpint = int(east)
     if tmpint < east:
 	east = tmpint + 1
     else:
 	east = tmpint
     tmpint = int(west)
     if tmpint > west:
 	west = tmpint - 1
     else:
 	west = tmpint
+    if north == south:
+	north += 1
+    if east == west:
+	east += 1
     rows = abs(north - south)
     cols = abs(east - west)
     ntiles = rows * cols
@@ -274,11 +282,12 @@
 		grass.run_command('g.region', region = tmpregionname)
-    # g.mlist with fs = comma does not work ???
+    # g.mlist with sep = comma does not work ???
+    pattern = '*.r.in.srtm2.tmp.%d' % pid
     srtmtiles = grass.read_command('g.mlist',
                                    type = 'rast',
-				   pattern = '*.r.in.srtm2.tmp.%d' % pid,
-				   fs = 'newline',
+				   pattern = pattern,
+				   sep = 'newline',
 				   quiet = True)
     srtmtiles = srtmtiles.splitlines()
@@ -322,7 +331,7 @@
 			      rast = '%s,%s,%s' % (output + '.holes', output + '.interp', output + '.float'),
 			      quiet = True)
-    grass.run_command('g.remove', rast = str(srtmtiles), quiet = True)
+    grass.run_command('g.mremove', rast = pattern, flags = 'f', quiet = True)
     # nice color table
     grass.run_command('r.colors', map = output, color = 'srtm', quiet = True)
