[GRASS-SVN] r55114 - in grass/trunk: db/db.columns db/db.connect db/db.copy db/db.createdb db/db.databases db/db.describe db/db.drivers db/db.dropdb db/db.execute db/db.select db/db.tables display/d.fontlist display/d.thematic.area doc/python general/g.cairocomp general/g.copy general/g.list general/g.mlist general/g.mremove general/g.pnmcat general/g.ppmtopng general/g.remove general/g.rename gui/icons/flags gui/images/symbols gui/wxpython gui/wxpython/animation gui/wxpython/gui_core gui/wxpython/mapdisp gui/wxpython/rlisetup gui/xml imagery/i.albedo imagery/i.biomass imagery/i.emissivity imagery/i.evapo.time imagery/i.landsat.toar imagery/i.latlong imagery/i.ortho.photo/lib imagery/i.segment imagery/i.sunhours imagery/i.vi include lib/arraystats lib/btree2 lib/cluster lib/db/dbmi_base/test lib/external/ccmath lib/gmath/test lib/htmldriver lib/lidar lib/python/ctypes lib/python/pygrass lib/python/pygrass/docs lib/python/pygrass/gis lib/python/pygrass/modules lib/python/pygrass/ raster lib/python/pygrass/tests lib/python/pygrass/vector lib/python/temporal lib/raster3d/test lib/temporal/SQL lib/temporal/lib lib/temporal/t.connect lib/vector/vedit man/sphinx mswindows/external/rbatch raster/r.external raster/r.external.out raster/r.horizon raster/r.in.png raster/r.quantile raster/r.resamp.bspline raster/r.resamp.filter raster/r.series.interp raster/r.solute.transport raster/r.statistics2 raster/r.statistics3 raster/r.sun raster/r.uslek raster/r.usler raster3d/r3.in.bin raster3d/r3.info raster3d/r3.out.bin raster3d/r3.out.netcdf raster3d/r3.retile raster3d/r3.support raster3d/r3.timestamp scripts/db.droptable scripts/r.grow scripts/r.rgb scripts/v.in.geonames scripts/v.pack scripts/v.unpack scripts/wxpyimgview temporal/t.create temporal/t.info temporal/t.list temporal/t.rast.aggregate temporal/t.rast.aggregate.ds temporal/t.rast.colors temporal/t.rast.export temporal/t.rast.extract temporal/t.rast.gapfill temporal/t.rast.import temporal/t.rast.list tem poral/t.rast.mapcalc temporal/t.rast.out.vtk temporal/t.rast.series temporal/t.rast.to.rast3 temporal/t.rast.univar temporal/t.rast3d.extract temporal/t.rast3d.list temporal/t.rast3d.mapcalc temporal/t.rast3d.univar temporal/t.register temporal/t.remove temporal/t.rename temporal/t.sample temporal/t.support temporal/t.topology temporal/t.unregister temporal/t.vect.db.select temporal/t.vect.export temporal/t.vect.extract temporal/t.vect.import temporal/t.vect.list temporal/t.vect.observe.strds temporal/t.vect.univar temporal/t.vect.what.strds tools/g.html2man vector/v.buffer vector/v.class vector/v.delaunay vector/v.lidar.correction vector/v.lidar.edgedetection vector/v.lidar.growing vector/v.outlier vector/v.surf.bspline vector/v.timestamp vector/v.what.rast3
Mon Feb 18 05:05:53 PST 2013
Author: neteler
Date: 2013-02-18 05:05:51 -0800 (Mon, 18 Feb 2013)
New Revision: 55114
   grass/trunk/db/db.columns/Makefile
   grass/trunk/db/db.connect/Makefile
   grass/trunk/db/db.copy/Makefile
   grass/trunk/db/db.createdb/Makefile
   grass/trunk/db/db.databases/Makefile
   grass/trunk/db/db.describe/Makefile
   grass/trunk/db/db.drivers/Makefile
   grass/trunk/db/db.dropdb/Makefile
   grass/trunk/db/db.execute/Makefile
   grass/trunk/db/db.select/Makefile
   grass/trunk/db/db.tables/Makefile
   grass/trunk/display/d.fontlist/Makefile
   grass/trunk/display/d.thematic.area/Makefile
   grass/trunk/doc/python/README
   grass/trunk/general/g.cairocomp/Makefile
   grass/trunk/general/g.copy/Makefile
   grass/trunk/general/g.list/Makefile
   grass/trunk/general/g.mlist/Makefile
   grass/trunk/general/g.mremove/Makefile
   grass/trunk/general/g.pnmcat/Makefile
   grass/trunk/general/g.ppmtopng/Makefile
   grass/trunk/general/g.remove/Makefile
   grass/trunk/general/g.rename/Makefile
   grass/trunk/gui/icons/flags/README
   grass/trunk/gui/images/symbols/README
   grass/trunk/gui/wxpython/README
   grass/trunk/gui/wxpython/animation/Makefile
   grass/trunk/gui/wxpython/gui_core/query.py
   grass/trunk/gui/wxpython/mapdisp/overlays.py
   grass/trunk/gui/wxpython/rlisetup/Makefile
   grass/trunk/gui/xml/Makefile
   grass/trunk/imagery/i.albedo/Makefile
   grass/trunk/imagery/i.biomass/Makefile
   grass/trunk/imagery/i.emissivity/Makefile
   grass/trunk/imagery/i.evapo.time/Makefile
   grass/trunk/imagery/i.landsat.toar/Makefile
   grass/trunk/imagery/i.latlong/Makefile
   grass/trunk/imagery/i.ortho.photo/lib/TODO
   grass/trunk/imagery/i.segment/Makefile
   grass/trunk/imagery/i.sunhours/Makefile
   grass/trunk/imagery/i.vi/Makefile
   grass/trunk/imagery/i.vi/evi2.c
   grass/trunk/include/Makefile
   grass/trunk/lib/arraystats/Makefile
   grass/trunk/lib/btree2/Makefile
   grass/trunk/lib/btree2/README
   grass/trunk/lib/cluster/Makefile
   grass/trunk/lib/db/dbmi_base/test/Makefile
   grass/trunk/lib/external/ccmath/Makefile
   grass/trunk/lib/external/ccmath/README
   grass/trunk/lib/gmath/test/Makefile
   grass/trunk/lib/htmldriver/Makefile
   grass/trunk/lib/htmldriver/README
   grass/trunk/lib/lidar/README
   grass/trunk/lib/python/ctypes/Makefile
   grass/trunk/lib/python/pygrass/Makefile
   grass/trunk/lib/python/pygrass/docs/Makefile
   grass/trunk/lib/python/pygrass/gis/Makefile
   grass/trunk/lib/python/pygrass/gis/__init__.py
   grass/trunk/lib/python/pygrass/modules/Makefile
   grass/trunk/lib/python/pygrass/raster/Makefile
   grass/trunk/lib/python/pygrass/tests/Makefile
   grass/trunk/lib/python/pygrass/vector/Makefile
   grass/trunk/lib/python/temporal/Makefile
   grass/trunk/lib/raster3d/test/Makefile
   grass/trunk/lib/temporal/SQL/Makefile
   grass/trunk/lib/temporal/lib/Makefile
   grass/trunk/lib/temporal/t.connect/Makefile
   grass/trunk/lib/vector/vedit/Makefile
   grass/trunk/man/sphinx/Makefile
   grass/trunk/mswindows/external/rbatch/README
   grass/trunk/raster/r.external.out/Makefile
   grass/trunk/raster/r.external/Makefile
   grass/trunk/raster/r.horizon/TODO
   grass/trunk/raster/r.in.png/Makefile
   grass/trunk/raster/r.quantile/Makefile
   grass/trunk/raster/r.resamp.bspline/Makefile
   grass/trunk/raster/r.resamp.bspline/README
   grass/trunk/raster/r.resamp.filter/Makefile
   grass/trunk/raster/r.series.interp/Makefile
   grass/trunk/raster/r.solute.transport/Makefile
   grass/trunk/raster/r.statistics2/Makefile
   grass/trunk/raster/r.statistics3/Makefile
   grass/trunk/raster/r.sun/Makefile
   grass/trunk/raster/r.sun/README
   grass/trunk/raster/r.sun/TODO
   grass/trunk/raster/r.uslek/Makefile
   grass/trunk/raster/r.usler/Makefile
   grass/trunk/raster3d/r3.in.bin/Makefile
   grass/trunk/raster3d/r3.info/Makefile
   grass/trunk/raster3d/r3.out.bin/Makefile
   grass/trunk/raster3d/r3.out.netcdf/Makefile
   grass/trunk/raster3d/r3.retile/Makefile
   grass/trunk/raster3d/r3.support/Makefile
   grass/trunk/raster3d/r3.timestamp/Makefile
   grass/trunk/scripts/db.droptable/Makefile
   grass/trunk/scripts/r.grow/Makefile
   grass/trunk/scripts/r.rgb/Makefile
   grass/trunk/scripts/v.in.geonames/Makefile
   grass/trunk/scripts/v.pack/Makefile
   grass/trunk/scripts/v.unpack/Makefile
   grass/trunk/scripts/wxpyimgview/Makefile
   grass/trunk/temporal/t.create/Makefile
   grass/trunk/temporal/t.info/Makefile
   grass/trunk/temporal/t.list/Makefile
   grass/trunk/temporal/t.rast.aggregate.ds/Makefile
   grass/trunk/temporal/t.rast.aggregate/Makefile
   grass/trunk/temporal/t.rast.colors/Makefile
   grass/trunk/temporal/t.rast.export/Makefile
   grass/trunk/temporal/t.rast.extract/Makefile
   grass/trunk/temporal/t.rast.gapfill/Makefile
   grass/trunk/temporal/t.rast.import/Makefile
   grass/trunk/temporal/t.rast.list/Makefile
   grass/trunk/temporal/t.rast.mapcalc/Makefile
   grass/trunk/temporal/t.rast.out.vtk/Makefile
   grass/trunk/temporal/t.rast.series/Makefile
   grass/trunk/temporal/t.rast.to.rast3/Makefile
   grass/trunk/temporal/t.rast.univar/Makefile
   grass/trunk/temporal/t.rast3d.extract/Makefile
   grass/trunk/temporal/t.rast3d.list/Makefile
   grass/trunk/temporal/t.rast3d.mapcalc/Makefile
   grass/trunk/temporal/t.rast3d.univar/Makefile
   grass/trunk/temporal/t.register/Makefile
   grass/trunk/temporal/t.remove/Makefile
   grass/trunk/temporal/t.rename/Makefile
   grass/trunk/temporal/t.sample/Makefile
   grass/trunk/temporal/t.support/Makefile
   grass/trunk/temporal/t.topology/Makefile
   grass/trunk/temporal/t.unregister/Makefile
   grass/trunk/temporal/t.vect.db.select/Makefile
   grass/trunk/temporal/t.vect.export/Makefile
   grass/trunk/temporal/t.vect.extract/Makefile
   grass/trunk/temporal/t.vect.import/Makefile
   grass/trunk/temporal/t.vect.list/Makefile
   grass/trunk/temporal/t.vect.observe.strds/Makefile
   grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.layer_bug.sh
   grass/trunk/temporal/t.vect.univar/Makefile
   grass/trunk/temporal/t.vect.what.strds/Makefile
   grass/trunk/tools/g.html2man/Makefile
   grass/trunk/vector/v.buffer/Makefile
   grass/trunk/vector/v.class/Makefile
   grass/trunk/vector/v.class/TODO
   grass/trunk/vector/v.delaunay/Makefile
   grass/trunk/vector/v.lidar.correction/README
   grass/trunk/vector/v.lidar.edgedetection/README
   grass/trunk/vector/v.lidar.growing/README
   grass/trunk/vector/v.outlier/README
   grass/trunk/vector/v.surf.bspline/README
   grass/trunk/vector/v.timestamp/Makefile
   grass/trunk/vector/v.what.rast3/Makefile
svn propset
Property changes on: grass/trunk/db/db.columns/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Property changes on: grass/trunk/db/db.connect/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/db/db.copy/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/db/db.createdb/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/db/db.databases/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/db/db.describe/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/db/db.drivers/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/db/db.dropdb/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/db/db.execute/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/db/db.select/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/db/db.tables/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/display/d.fontlist/Makefile
   + text/x-makefile
Property changes on: grass/trunk/display/d.thematic.area/Makefile
   + text/x-makefile
Property changes on: grass/trunk/doc/python/README
   + text/plain
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass/trunk/general/g.cairocomp/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/general/g.copy/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/general/g.list/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/general/g.mlist/Makefile
   + text/x-makefile
Property changes on: grass/trunk/general/g.mremove/Makefile
   + text/x-makefile
Property changes on: grass/trunk/general/g.pnmcat/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/general/g.ppmtopng/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/general/g.remove/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/general/g.rename/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/gui/icons/flags/README
   + text/plain
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass/trunk/gui/images/symbols/README
   + text/plain
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass/trunk/gui/wxpython/README
   + text/plain
   + native
Property changes on: grass/trunk/gui/wxpython/animation/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/gui/wxpython/gui_core/query.py
   + text/x-python
   + native
Property changes on: grass/trunk/gui/wxpython/mapdisp/overlays.py
   + text/x-python
   + native
Property changes on: grass/trunk/gui/wxpython/rlisetup/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/gui/xml/Makefile
   + text/x-makefile
Property changes on: grass/trunk/imagery/i.albedo/Makefile
   + text/x-makefile
Property changes on: grass/trunk/imagery/i.biomass/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/imagery/i.emissivity/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/imagery/i.evapo.time/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/imagery/i.landsat.toar/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/imagery/i.latlong/Makefile
   + text/x-makefile
Property changes on: grass/trunk/imagery/i.ortho.photo/lib/TODO
   + text/plain
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass/trunk/imagery/i.segment/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/imagery/i.sunhours/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/imagery/i.vi/Makefile
   + text/x-makefile
Property changes on: grass/trunk/imagery/i.vi/evi2.c
   + text/x-csrc
   + native
Property changes on: grass/trunk/include/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/lib/arraystats/Makefile
   + text/x-makefile
Property changes on: grass/trunk/lib/btree2/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/lib/btree2/README
   + text/plain
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass/trunk/lib/cluster/Makefile
   + text/x-makefile
Property changes on: grass/trunk/lib/db/dbmi_base/test/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/lib/external/ccmath/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/lib/external/ccmath/README
   + text/plain
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass/trunk/lib/gmath/test/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/lib/htmldriver/Makefile
   + text/x-makefile
Property changes on: grass/trunk/lib/htmldriver/README
   + text/plain
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass/trunk/lib/lidar/README
   + text/plain
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass/trunk/lib/python/ctypes/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/lib/python/pygrass/Makefile
   + text/x-makefile
Property changes on: grass/trunk/lib/python/pygrass/docs/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/lib/python/pygrass/gis/Makefile
   + text/x-makefile
Property changes on: grass/trunk/lib/python/pygrass/gis/__init__.py
   + text/x-python
   + native
Property changes on: grass/trunk/lib/python/pygrass/modules/Makefile
   + text/x-makefile
Property changes on: grass/trunk/lib/python/pygrass/raster/Makefile
   + text/x-makefile
Property changes on: grass/trunk/lib/python/pygrass/tests/Makefile
   + text/x-makefile
Property changes on: grass/trunk/lib/python/pygrass/vector/Makefile
   + text/x-makefile
Property changes on: grass/trunk/lib/python/temporal/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/lib/raster3d/test/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/lib/temporal/SQL/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/lib/temporal/lib/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/lib/temporal/t.connect/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/lib/vector/vedit/Makefile
   + text/x-makefile
Property changes on: grass/trunk/man/sphinx/Makefile
   + text/x-makefile
   + native
Modified: grass/trunk/mswindows/external/rbatch/README
--- grass/trunk/mswindows/external/rbatch/README	2013-02-18 13:05:22 UTC (rev 55113)
+++ grass/trunk/mswindows/external/rbatch/README	2013-02-18 13:05:51 UTC (rev 55114)
@@ -1,367 +1,367 @@
-batchfiles contains GPL-2 batch files for installing and maintaining R.
-Each is self contained, independent of the others and need no installation.
-Just place it anywhere on your path.
-PROGRAM LIST
-Legend:
-h = no args gives help
-0 = common usage is to enter command name without arguments
-d = in development
-2.11 = only works with R 2.11
-* = all files marked with one star are the same.  Program checks name by which its called to determine action.
-** = all files marked with two stars are the same.  Program checks name by which its called to determine action.
-#Rscript.bat - put at top of R file to make it a batch file (h) (*)
-clip2r.js - pastes clipboard into Rgui.  See comments in file for use from vim. (0)(d)
-copydir.bat - copy a library from one version of R to another (h)
-el.js - run elevated - Vista and up, e.g. el Rgui  runs R elevated
-find-miktex.hta - GUI to find MiKTeX (0)
-kopy.bat - copy Rcmd to other batch files (h)(d)
-movedir.bat - move library from one version of R to another (h)
-R.bat - like R.exe but finds R from registry (0) (*)
-Rcmd.bat - like Rcmd.exe but finds R from registry (h) (*)
-Rgui.bat - like Rgui.exe but finds R from registry (0) (*)
-RguiStart.bat - like Rgui.bat but arg1 defines folder to start R in (*)
-Rscript.bat - run .R script (h) (*)
-Rterm.bat - like rterm.exe but finds R from registry (h) (*)
-Rtidy.bat - reformat a .R file, e.g. Rtidy myfile.R > outfile.R (d)
-Rtools.bat - place Rtools on path for remainder of console session (0) (*)
-Rversions.bat - list R and set R version in registry, e.g. on Vista: el cmd/c Rversions R-2.10.1 (0)
-Rversions.hta - GUI interface to RSetReg.  List and set R version, e.g. on Vista: el cmd /c Rversions.hta (0)(2.11)
-show-svn-info.hta - show svn info if current folder is an svn checkout (0)
-Stangle.bat - run arg1 through Stangle (h) (**)
-Sweave.bat - run arg1 through Sweave (h) (**)
-DESCRIPTIONS
-R.bat, Rcmd.bat, Rscript.bat, Rgui.bat, and RguiStart.bat are all the same
-file.  They query the name by which they were called to determine what they do.
-Similarly Sweave.bat and Stangle.bat are the same file.
-The home page and NEWS file provide more info.
-BATCH PROGRAMS
-0. Rtools.bat
-1. R.bat, Rcmd.bat, Rscript.bat, Rgui.bat
-2. #Rscript.bat
-3. RguiStart.bat
-4. Sweave.bat and Stangle.bat
-5. copydir.bat
-6. movedir.bat
-7. find-miktex.hta
-0. Rtools.bat.  Sets path to what Rcmd.bat and others use internally.
-This only sets the path for the current command shell instance.
-1. R.bat, Rcmd.bat, Rscript.bat, Rgui.bat, Rscript.bat - are front
-ends to  the corresponding .exe files.  They locate R in the registry (and also
-look in a few other places if not found there).  Then they look for Rtools and
-MiKTeX and if found they add them temporarily to the path.  (Rtools and MiKTeX
-are needed when building R packages from source but are not needed for just
-running R nor are they need to download and install binary packages from CRAN.)
-Then they run R.exe, Rcmd.exe, Rscript.exe, Rgui.exe or JGR.exe with the same
-arguments.    They are actually all the same file just renamed.  (RguiStart.bat
-described separately is also the same file and all the code from this file is
-also at the end of Sweave.bat, also described separately.)  The file checks
-what name it was called by and acts accordingly.
-Their main advantages are:
-- you don't have to modify your path just to run R.
-- you don't have to modify your path to build R packages from source.
-- when you upgrade R they automatically work without change
-  since they will pick up the new version of R from the registry
-  automatically.
-- Sweave.bat and Stangle.bat, unlike, Rcmd Sweave and Rcmd Stangle
-  do not depend on rtools.
-You can put Rgui.bat on your desktop and associate a Windows
-ShortCut key (http://support.microsoft.com/kb/310417) with
-it so that you can just press the Windows key and
-R, say, to activate R.
-Here are some examples of using them from the command line.
-It assumes you have placed el.js, Rcmd.bat and Rgui.bat in
-your path.  el cmd spawns a command console with Administrator
-rights.  This is needed to build HTML help but you can omit
-the el command if you don't need that.
-    el cmd
-	Rcmd check mypackage
-	Rcmd build mypackage
-	Rcmd build mypackage --binary
-	Rcmd INSTALL mypackage_1.0-0.tar.gz
-	Rcmd INSTALL mypackage_1.0-0.tar.gz -l library
-	Rscript myprog.R < mydata.dat
-	Rgui
-(When installing packages on Vista it is recommended that
-you do this from within a console session that has Administrator
-rights.  It will typically work even without that; however, the
-HTML help will not be created.)
-Older version of the Rcmd BATCH command in R had problems
-with spaces in pathnames so be sure you use a sufficiently
-recent version of R.  If you are using an old version of R
-that has problems use the short name corresponding to any
-long name with spaces:
-For example, suppose we have a file
-   C:\Documents and Settings\Administrator\myfile.R .
-Then try this:
-	cd \
-	dir/x doc*
-	Rcmd BATCH c:\docume~1\Administrator\myfile.R
-where the dir/x command showed us the short name corresponding to
-the longer space-embedded name: Documents and Settings.
-2. #Rscript.bat
-#Rscript.bat can be used as the first line of an R script to make
-it callable as a batch file.  For example, if we have a myfile.R
-file then we can create a myfile.bat file that looks like this:
-#Rscript %0 %*
-...R code from myfile.R goes here...
-and now we can just issue the command myfile to run it.  We
-no longer need myfile.R.
-See the Rtidy.bat file for an example.  Note that it does have
-the disadvantage that the output of the R program starts off
-with the command itself.  R needs to be able to handle the
-perl/python/ruby -x switch.  In the meantime #Rscript.bat
-will mainly be useful for those scripts where the output does
-not go to the standard output or where the addition of this
-line is acceptable.
-3. RguiStart.bat
-This is like Rgui.bat except it intercepts the first argument
-and interprets it as the folder in which to start R (or if its
-an .Rdata file then it interprets it as the .Rdata file to start
-R with).  The main reason for its existence is so that you can
-place it in your SendTo folder.  On Vista do this:
-  copy RguiStart.bat %APPDATA%\Microsoft\Windows\SendTo
-(or to locate locate the SendTo folder in Windows Explorer on Vista
-enter shell:sendto into the Windows Explorer address bar and copy
-your RguiStart.bat file there.)
-Then, on Vista, when you are in Windows Explorer you can right click
-on any folder in your user area and choose SendTo.  From the SendTo
-menu choose RGuiStart.bat to start up R in that folder.  If you
-right click on an .Rdata file rather than a folder then R will
-start up with that file loaded (although in that case its probably
-easier to just double click the .Rdata file provided you have
-file type associations set up -- if you don't then the RguiStart.bat
-will provide an alternative).
-A second possibility is to place RguiStart.bat on your desktop and
-then drag a folder to it to start R in that folder.
-A third possibility is to just shift right click a folder in Windows
-Explorer and choose Open Command Window Here and then when the command
-window opens enter Rgui assuming you have placed Rgui.bat somewhere in
-your path.
-4. Sweave.bat and Stangle.bat - will run Sweave, then pdflatex and then
-display latex file.  Stangle.bat will run Stangle producing an R file.
-Unlike Rcmd Sweave and Rcmd Stangle these do not depend on rtools.
-Sweave.bat and Stangle.bat are actually the same file.  The file determines
-what to do by looking at the name by which it was called.
-      Sweave mydoc.Rnw
-   or
-      Sweave mydoc
-The script runs Sweave, pdflatex and then displays the pdf
-file (assuming the user has .pdf extension associated with a
-pdf viewer).  If there is an error in Sweave or the .tex
-file is not newer than the Sweave'd file the script stops.
-Similarly if there is an error in pdflatex or the .pdf is
-not newer than the .tex file then the script stops.  Note
-that _two_ .pdf files are generated.  They are identical
-except one has a unique name created by suffixing the base
-with the date and time and .bck.pdf.  The one with the unique name
-is the one viewed.  This overcomes problems of not being able to
-view the .pdf if the .pdf from a prior run is current being
-viewed (which would happen since by default the Acrobat viewer
-won't allow you to view two files of the same name concurrently).
-Every so often the user should delete all *.bck.pdf files.
-Try:
-sweave
-without arguments to see options and get more info.
-Aside from using sweave from the command line, if you place
-sweave.bat in your SendTo folder as discussed under
-RguiStart.bat you can right click .Rnw files and choose
-SendTo > sweave to sweave them.
-You may need to copy Sweave.sty to the directory containing
-your .Rnw sweave file to use sweave.bat .
-5. Rversions.bat - similar to Rversions.hta but
--- its batch whereas Rversions.hta is GUI
--- uses slightly different heuristic to find R versions
--- run without args to list versions available; run with any of
-   the listed versions to set that as the new version
--- both forms work on XP; to run arg form on Vista run it elevated
-   e.g. el cmd /c Rversions.bat R-2.10.0
-Examples:
-	:: list R versions
-	rversions.bat
-	:: check mypkg using R current version, 2.4.0, say
-	Rcmd check mypkg
-	:: switch to version R-2.5.0 and recheck
-	rversions R-2.5.0
-	Rcmd check mypkg
-	:: reset back to version 2.4.0
-	rversions.bat R-2.4.0
-6. copydir.bat - can be used to copy the libraries from an
-old version of R to your new one.  It will not overwrite any
-libraries already there so it should be safe to use. e.g. to
-upgrade R to a new version
-  :: Example is for upgrading from R-2.4.1 to R-2.5.0
-  :: first, download and install R-2.11.0
-  :: now perform the next two commands at the Windows console
-  cd %userprofile%\Documents\R\win-library
-  :: you can use movedir instead of copydir if you prefer to move them
-  copydir 2.10\library 2.11\library
-  :: ... now startup new version of R (R 2.11.0 in this example)
-  # issue this command in R 2.5.0
-  update.packages(checkBuilt = TRUE, ask = "graphics")
-  # or (see note below)
-  update.packages(ask = "graphics")
-  :: press OK and it will update those packages as necessary
-  # ... optionally check for deprecated packages
-  # 1. first select all repositories that you use with menu:
-  #    Packages | Repositories
-  # 2. second check if there are any deprecated packages that
-  #    were copied over but are not longer on CRAN or other repository
-  dp <- setdiff(installed.packages()[,1], available.packages()[,1])
-  # look at what we have
-  dp
-  # if you wish to remove them issue the remove.packages command:
-  # remove.packages(dp)
-  :: ... exit R and start it up again ...
-Note that the checkBuilt=TRUE argument will potentially
-cause all your packages to be downloaded again so you could
-try leaving it off and then reissue the command with
-checkBuilt=TRUE later only if you run into problems.  I
-normally do it without the checkBuilt=TRUE.
-It is anticipated that this command will ultimately be
-superceded by functionality in the R setup procedure at
-which time this will be deprecated.  Note that this method
-of just copying libraries may not work depending on the
-versions of R involved.  If its necessary to re-install most
-packages it can be done by issuing the following R command
-after performing the copydir.bat:
-install.packages(installed.packages()[,1])
-(Note that 2.8 of the R Windows FAQ
-http://cran.r-project.org/bin/windows/base/rw-FAQ.html#What_0027s-the-best-way-to-upgrade_003f
-refers to copying any installed package to the library
-folder but does not address how to accomplish that.  That
-omission is what copydir.bat addresses.)
-An alternative to copydir is to reinstall all packages
-	# Alternative to copydir.bat #1
-	# this example is for moving from 2.4.1 to 2.5.0
-	# run this in R 2.5.0
-	setwd(R.home())
-	ip <- installed.packages(lib.loc = "../R-2.4.1/library")
-	ip <- ip[ip[,1]!="base" ,1]
-	install.packages(ip)
-The above is taken from:
-https://www.stat.math.ethz.ch/pipermail/r-help/2007-May/131806.html
-Note that you may still have to use movedir.bat or copydir.bat
-after the above if it fails to install everything.  Since movedir.bat
-and copydir.bat won't overwrite anything this should be safe.
-	# Alternative to copydir.bat #2
-	#---run in previous version, e.g. R 2.4.1
-	packages <- installed.packages()[,"Package"]
-	save(packages, file = "~/Rpackages")
-	#---run in new version, e.g. R 2.5.0
-	load("~/Rpackages")
-	install.packages(setdiff(packages, installed.packages()[,"Package"]))
-	file.remove("~/Rpackages")
-This copydir alternative is based on:
-https://www.stat.math.ethz.ch/pipermail/r-help/2007-May/131131.html
-7. movedir - same arguments as copydir.  Only difference is
-that it moves the directories rather than copying them.  This
-can be used if you are no longer interested in using the
-packages with the old version of R other than by
-reinstalling them.)  This has the advantage that its much
-faster than copydir.  The example under copydir works with
-movedir too.  Just replace copydir with movedir in that
-example.  Comments under copydir.bat apply here too.  I
-mostly use movedir.bat myself instead of copydir.bat since
-its so much faster.
-8. show-svn-info.hta - Just run this from any Tortoise SVN folder
-and it will display some information about it.  Requires version 1.5
-or higher of Tortoise SVN.
-9. find-miktex.hta - displays the path to the MiKTeX bin directory.
-Just enter find-miktex.hta at the Windows command line (no arguments
-are needed) or double click it from Windows Explorer.
-ADDITIONAL FILES
-1. RESOURCES - additional information on writing Windows XP
-batch files.
-2. COPYRIGHT and COPYING - this is free software subject to
-   the GPL license as described.
-3. THANKS - acknowledgments.
-DEPRECATED AND CHANGED
-- Rfind.bat
-- makepkg.bat
-- Rversions.hta
-- toggerDoc.pl
-These are no longer distributed but can be found in older distributions of this
-package.  It is unknown whether they work with recent versions of R.  (I found
-I was not using these so am no longer maintaining them.)
+batchfiles contains GPL-2 batch files for installing and maintaining R.
+Each is self contained, independent of the others and need no installation.
+Just place it anywhere on your path.
+PROGRAM LIST
+Legend:
+h = no args gives help
+0 = common usage is to enter command name without arguments
+d = in development
+2.11 = only works with R 2.11
+* = all files marked with one star are the same.  Program checks name by which its called to determine action.
+** = all files marked with two stars are the same.  Program checks name by which its called to determine action.
+#Rscript.bat - put at top of R file to make it a batch file (h) (*)
+clip2r.js - pastes clipboard into Rgui.  See comments in file for use from vim. (0)(d)
+copydir.bat - copy a library from one version of R to another (h)
+el.js - run elevated - Vista and up, e.g. el Rgui  runs R elevated
+find-miktex.hta - GUI to find MiKTeX (0)
+kopy.bat - copy Rcmd to other batch files (h)(d)
+movedir.bat - move library from one version of R to another (h)
+R.bat - like R.exe but finds R from registry (0) (*)
+Rcmd.bat - like Rcmd.exe but finds R from registry (h) (*)
+Rgui.bat - like Rgui.exe but finds R from registry (0) (*)
+RguiStart.bat - like Rgui.bat but arg1 defines folder to start R in (*)
+Rscript.bat - run .R script (h) (*)
+Rterm.bat - like rterm.exe but finds R from registry (h) (*)
+Rtidy.bat - reformat a .R file, e.g. Rtidy myfile.R > outfile.R (d)
+Rtools.bat - place Rtools on path for remainder of console session (0) (*)
+Rversions.bat - list R and set R version in registry, e.g. on Vista: el cmd/c Rversions R-2.10.1 (0)
+Rversions.hta - GUI interface to RSetReg.  List and set R version, e.g. on Vista: el cmd /c Rversions.hta (0)(2.11)
+show-svn-info.hta - show svn info if current folder is an svn checkout (0)
+Stangle.bat - run arg1 through Stangle (h) (**)
+Sweave.bat - run arg1 through Sweave (h) (**)
+DESCRIPTIONS
+R.bat, Rcmd.bat, Rscript.bat, Rgui.bat, and RguiStart.bat are all the same
+file.  They query the name by which they were called to determine what they do.
+Similarly Sweave.bat and Stangle.bat are the same file.
+The home page and NEWS file provide more info.
+BATCH PROGRAMS
+0. Rtools.bat
+1. R.bat, Rcmd.bat, Rscript.bat, Rgui.bat
+2. #Rscript.bat
+3. RguiStart.bat
+4. Sweave.bat and Stangle.bat
+5. copydir.bat
+6. movedir.bat
+7. find-miktex.hta
+0. Rtools.bat.  Sets path to what Rcmd.bat and others use internally.
+This only sets the path for the current command shell instance.
+1. R.bat, Rcmd.bat, Rscript.bat, Rgui.bat, Rscript.bat - are front
+ends to  the corresponding .exe files.  They locate R in the registry (and also
+look in a few other places if not found there).  Then they look for Rtools and
+MiKTeX and if found they add them temporarily to the path.  (Rtools and MiKTeX
+are needed when building R packages from source but are not needed for just
+running R nor are they need to download and install binary packages from CRAN.)
+Then they run R.exe, Rcmd.exe, Rscript.exe, Rgui.exe or JGR.exe with the same
+arguments.    They are actually all the same file just renamed.  (RguiStart.bat
+described separately is also the same file and all the code from this file is
+also at the end of Sweave.bat, also described separately.)  The file checks
+what name it was called by and acts accordingly.
+Their main advantages are:
+- you don't have to modify your path just to run R.
+- you don't have to modify your path to build R packages from source.
+- when you upgrade R they automatically work without change
+  since they will pick up the new version of R from the registry
+  automatically.
+- Sweave.bat and Stangle.bat, unlike, Rcmd Sweave and Rcmd Stangle
+  do not depend on rtools.
+You can put Rgui.bat on your desktop and associate a Windows
+ShortCut key (http://support.microsoft.com/kb/310417) with
+it so that you can just press the Windows key and
+R, say, to activate R.
+Here are some examples of using them from the command line.
+It assumes you have placed el.js, Rcmd.bat and Rgui.bat in
+your path.  el cmd spawns a command console with Administrator
+rights.  This is needed to build HTML help but you can omit
+the el command if you don't need that.
+    el cmd
+	Rcmd check mypackage
+	Rcmd build mypackage
+	Rcmd build mypackage --binary
+	Rcmd INSTALL mypackage_1.0-0.tar.gz
+	Rcmd INSTALL mypackage_1.0-0.tar.gz -l library
+	Rscript myprog.R < mydata.dat
+	Rgui
+(When installing packages on Vista it is recommended that
+you do this from within a console session that has Administrator
+rights.  It will typically work even without that; however, the
+HTML help will not be created.)
+Older version of the Rcmd BATCH command in R had problems
+with spaces in pathnames so be sure you use a sufficiently
+recent version of R.  If you are using an old version of R
+that has problems use the short name corresponding to any
+long name with spaces:
+For example, suppose we have a file
+   C:\Documents and Settings\Administrator\myfile.R .
+Then try this:
+	cd \
+	dir/x doc*
+	Rcmd BATCH c:\docume~1\Administrator\myfile.R
+where the dir/x command showed us the short name corresponding to
+the longer space-embedded name: Documents and Settings.
+2. #Rscript.bat
+#Rscript.bat can be used as the first line of an R script to make
+it callable as a batch file.  For example, if we have a myfile.R
+file then we can create a myfile.bat file that looks like this:
+#Rscript %0 %*
+...R code from myfile.R goes here...
+and now we can just issue the command myfile to run it.  We
+no longer need myfile.R.
+See the Rtidy.bat file for an example.  Note that it does have
+the disadvantage that the output of the R program starts off
+with the command itself.  R needs to be able to handle the
+perl/python/ruby -x switch.  In the meantime #Rscript.bat
+will mainly be useful for those scripts where the output does
+not go to the standard output or where the addition of this
+line is acceptable.
+3. RguiStart.bat
+This is like Rgui.bat except it intercepts the first argument
+and interprets it as the folder in which to start R (or if its
+an .Rdata file then it interprets it as the .Rdata file to start
+R with).  The main reason for its existence is so that you can
+place it in your SendTo folder.  On Vista do this:
+  copy RguiStart.bat %APPDATA%\Microsoft\Windows\SendTo
+(or to locate locate the SendTo folder in Windows Explorer on Vista
+enter shell:sendto into the Windows Explorer address bar and copy
+your RguiStart.bat file there.)
+Then, on Vista, when you are in Windows Explorer you can right click
+on any folder in your user area and choose SendTo.  From the SendTo
+menu choose RGuiStart.bat to start up R in that folder.  If you
+right click on an .Rdata file rather than a folder then R will
+start up with that file loaded (although in that case its probably
+easier to just double click the .Rdata file provided you have
+file type associations set up -- if you don't then the RguiStart.bat
+will provide an alternative).
+A second possibility is to place RguiStart.bat on your desktop and
+then drag a folder to it to start R in that folder.
+A third possibility is to just shift right click a folder in Windows
+Explorer and choose Open Command Window Here and then when the command
+window opens enter Rgui assuming you have placed Rgui.bat somewhere in
+your path.
+4. Sweave.bat and Stangle.bat - will run Sweave, then pdflatex and then
+display latex file.  Stangle.bat will run Stangle producing an R file.
+Unlike Rcmd Sweave and Rcmd Stangle these do not depend on rtools.
+Sweave.bat and Stangle.bat are actually the same file.  The file determines
+what to do by looking at the name by which it was called.
+      Sweave mydoc.Rnw
+   or
+      Sweave mydoc
+The script runs Sweave, pdflatex and then displays the pdf
+file (assuming the user has .pdf extension associated with a
+pdf viewer).  If there is an error in Sweave or the .tex
+file is not newer than the Sweave'd file the script stops.
+Similarly if there is an error in pdflatex or the .pdf is
+not newer than the .tex file then the script stops.  Note
+that _two_ .pdf files are generated.  They are identical
+except one has a unique name created by suffixing the base
+with the date and time and .bck.pdf.  The one with the unique name
+is the one viewed.  This overcomes problems of not being able to
+view the .pdf if the .pdf from a prior run is current being
+viewed (which would happen since by default the Acrobat viewer
+won't allow you to view two files of the same name concurrently).
+Every so often the user should delete all *.bck.pdf files.
+Try:
+sweave
+without arguments to see options and get more info.
+Aside from using sweave from the command line, if you place
+sweave.bat in your SendTo folder as discussed under
+RguiStart.bat you can right click .Rnw files and choose
+SendTo > sweave to sweave them.
+You may need to copy Sweave.sty to the directory containing
+your .Rnw sweave file to use sweave.bat .
+5. Rversions.bat - similar to Rversions.hta but
+-- its batch whereas Rversions.hta is GUI
+-- uses slightly different heuristic to find R versions
+-- run without args to list versions available; run with any of
+   the listed versions to set that as the new version
+-- both forms work on XP; to run arg form on Vista run it elevated
+   e.g. el cmd /c Rversions.bat R-2.10.0
+Examples:
+	:: list R versions
+	rversions.bat
+	:: check mypkg using R current version, 2.4.0, say
+	Rcmd check mypkg
+	:: switch to version R-2.5.0 and recheck
+	rversions R-2.5.0
+	Rcmd check mypkg
+	:: reset back to version 2.4.0
+	rversions.bat R-2.4.0
+6. copydir.bat - can be used to copy the libraries from an
+old version of R to your new one.  It will not overwrite any
+libraries already there so it should be safe to use. e.g. to
+upgrade R to a new version
+  :: Example is for upgrading from R-2.4.1 to R-2.5.0
+  :: first, download and install R-2.11.0
+  :: now perform the next two commands at the Windows console
+  cd %userprofile%\Documents\R\win-library
+  :: you can use movedir instead of copydir if you prefer to move them
+  copydir 2.10\library 2.11\library
+  :: ... now startup new version of R (R 2.11.0 in this example)
+  # issue this command in R 2.5.0
+  update.packages(checkBuilt = TRUE, ask = "graphics")
+  # or (see note below)
+  update.packages(ask = "graphics")
+  :: press OK and it will update those packages as necessary
+  # ... optionally check for deprecated packages
+  # 1. first select all repositories that you use with menu:
+  #    Packages | Repositories
+  # 2. second check if there are any deprecated packages that
+  #    were copied over but are not longer on CRAN or other repository
+  dp <- setdiff(installed.packages()[,1], available.packages()[,1])
+  # look at what we have
+  dp
+  # if you wish to remove them issue the remove.packages command:
+  # remove.packages(dp)
+  :: ... exit R and start it up again ...
+Note that the checkBuilt=TRUE argument will potentially
+cause all your packages to be downloaded again so you could
+try leaving it off and then reissue the command with
+checkBuilt=TRUE later only if you run into problems.  I
+normally do it without the checkBuilt=TRUE.
+It is anticipated that this command will ultimately be
+superceded by functionality in the R setup procedure at
+which time this will be deprecated.  Note that this method
+of just copying libraries may not work depending on the
+versions of R involved.  If its necessary to re-install most
+packages it can be done by issuing the following R command
+after performing the copydir.bat:
+install.packages(installed.packages()[,1])
+(Note that 2.8 of the R Windows FAQ
+http://cran.r-project.org/bin/windows/base/rw-FAQ.html#What_0027s-the-best-way-to-upgrade_003f
+refers to copying any installed package to the library
+folder but does not address how to accomplish that.  That
+omission is what copydir.bat addresses.)
+An alternative to copydir is to reinstall all packages
+	# Alternative to copydir.bat #1
+	# this example is for moving from 2.4.1 to 2.5.0
+	# run this in R 2.5.0
+	setwd(R.home())
+	ip <- installed.packages(lib.loc = "../R-2.4.1/library")
+	ip <- ip[ip[,1]!="base" ,1]
+	install.packages(ip)
+The above is taken from:
+https://www.stat.math.ethz.ch/pipermail/r-help/2007-May/131806.html
+Note that you may still have to use movedir.bat or copydir.bat
+after the above if it fails to install everything.  Since movedir.bat
+and copydir.bat won't overwrite anything this should be safe.
+	# Alternative to copydir.bat #2
+	#---run in previous version, e.g. R 2.4.1
+	packages <- installed.packages()[,"Package"]
+	save(packages, file = "~/Rpackages")
+	#---run in new version, e.g. R 2.5.0
+	load("~/Rpackages")
+	install.packages(setdiff(packages, installed.packages()[,"Package"]))
+	file.remove("~/Rpackages")
+This copydir alternative is based on:
+https://www.stat.math.ethz.ch/pipermail/r-help/2007-May/131131.html
+7. movedir - same arguments as copydir.  Only difference is
+that it moves the directories rather than copying them.  This
+can be used if you are no longer interested in using the
+packages with the old version of R other than by
+reinstalling them.)  This has the advantage that its much
+faster than copydir.  The example under copydir works with
+movedir too.  Just replace copydir with movedir in that
+example.  Comments under copydir.bat apply here too.  I
+mostly use movedir.bat myself instead of copydir.bat since
+its so much faster.
+8. show-svn-info.hta - Just run this from any Tortoise SVN folder
+and it will display some information about it.  Requires version 1.5
+or higher of Tortoise SVN.
+9. find-miktex.hta - displays the path to the MiKTeX bin directory.
+Just enter find-miktex.hta at the Windows command line (no arguments
+are needed) or double click it from Windows Explorer.
+ADDITIONAL FILES
+1. RESOURCES - additional information on writing Windows XP
+batch files.
+2. COPYRIGHT and COPYING - this is free software subject to
+   the GPL license as described.
+3. THANKS - acknowledgments.
+DEPRECATED AND CHANGED
+- Rfind.bat
+- makepkg.bat
+- Rversions.hta
+- toggerDoc.pl
+These are no longer distributed but can be found in older distributions of this
+package.  It is unknown whether they work with recent versions of R.  (I found
+I was not using these so am no longer maintaining them.)
Property changes on: grass/trunk/mswindows/external/rbatch/README
   + text/plain
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass/trunk/raster/r.external/Makefile
   + text/x-makefile
Property changes on: grass/trunk/raster/r.external.out/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/raster/r.horizon/TODO
   + text/plain
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass/trunk/raster/r.in.png/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/raster/r.quantile/Makefile
   + text/x-makefile
Property changes on: grass/trunk/raster/r.resamp.bspline/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/raster/r.resamp.bspline/README
   + text/plain
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass/trunk/raster/r.resamp.filter/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/raster/r.series.interp/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/raster/r.solute.transport/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/raster/r.statistics2/Makefile
   + text/x-makefile
Property changes on: grass/trunk/raster/r.statistics3/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/raster/r.sun/Makefile
   + text/x-makefile
Property changes on: grass/trunk/raster/r.sun/README
   + text/plain
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass/trunk/raster/r.sun/TODO
   + text/plain
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass/trunk/raster/r.uslek/Makefile
   + text/x-makefile
Property changes on: grass/trunk/raster/r.usler/Makefile
   + text/x-makefile
Property changes on: grass/trunk/raster3d/r3.in.bin/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/raster3d/r3.info/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/raster3d/r3.out.bin/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/raster3d/r3.out.netcdf/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/raster3d/r3.retile/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/raster3d/r3.support/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/raster3d/r3.timestamp/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/scripts/db.droptable/Makefile
   + text/x-makefile
Property changes on: grass/trunk/scripts/r.grow/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/scripts/r.rgb/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/scripts/v.in.geonames/Makefile
   + text/x-makefile
Property changes on: grass/trunk/scripts/v.pack/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/scripts/v.unpack/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/scripts/wxpyimgview/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.create/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.info/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.list/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.rast.aggregate/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.rast.aggregate.ds/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.rast.colors/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.rast.export/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.rast.extract/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.rast.gapfill/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.rast.import/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.rast.list/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.rast.mapcalc/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.rast.out.vtk/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.rast.series/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.rast.to.rast3/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.rast.univar/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.rast3d.extract/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.rast3d.list/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.rast3d.mapcalc/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.rast3d.univar/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.register/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.remove/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.rename/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.sample/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.support/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.topology/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.unregister/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.vect.db.select/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.vect.export/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.vect.extract/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.vect.import/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.vect.list/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.vect.observe.strds/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.layer_bug.sh
   + text/x-sh
   + native
Property changes on: grass/trunk/temporal/t.vect.univar/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/temporal/t.vect.what.strds/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/tools/g.html2man/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/vector/v.buffer/Makefile
   + text/x-makefile
Property changes on: grass/trunk/vector/v.class/Makefile
   + text/x-makefile
Property changes on: grass/trunk/vector/v.class/TODO
   + text/plain
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass/trunk/vector/v.delaunay/Makefile
   + text/x-makefile
Property changes on: grass/trunk/vector/v.lidar.correction/README
   + text/plain
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass/trunk/vector/v.lidar.edgedetection/README
   + text/plain
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass/trunk/vector/v.lidar.growing/README
   + text/plain
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass/trunk/vector/v.outlier/README
   + text/plain
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass/trunk/vector/v.surf.bspline/README
   + text/plain
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass/trunk/vector/v.timestamp/Makefile
   + text/x-makefile
   + native
Property changes on: grass/trunk/vector/v.what.rast3/Makefile
   + text/x-makefile
   + native
