[GRASS-SVN] r55125 - grass/branches/releasebranch_6_4/raster/r.out.arc
Wed Feb 20 01:49:53 PST 2013
Author: hamish
Date: 2013-02-20 01:49:53 -0800 (Wed, 20 Feb 2013)
New Revision: 55125
   grass/branches/releasebranch_6_4/raster/r.out.arc/main.c
output is to a file not a raster, descr wording (merge from trunk)
Modified: grass/branches/releasebranch_6_4/raster/r.out.arc/main.c
--- grass/branches/releasebranch_6_4/raster/r.out.arc/main.c	2013-02-20 09:48:25 UTC (rev 55124)
+++ grass/branches/releasebranch_6_4/raster/r.out.arc/main.c	2013-02-20 09:49:53 UTC (rev 55125)
@@ -64,10 +64,9 @@
     /* Define the different options */
     parm.map = G_define_standard_option(G_OPT_R_INPUT);
-    parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
-    parm.output->gisprompt = "new_file,file,output";
+    parm.output = G_define_standard_option(G_OPT_F_OUTPUT);
     parm.output->description =
-	_("Name of an output ARC-GRID map (use out=- for stdout)");
+	_("Name for output ARC-GRID map (use out=- for stdout)");
     parm.dp = G_define_option();
     parm.dp->key = "dp";
